[GRASS-SVN] r37900 - in grass/branches/develbranch_6/mswindows: .
Installer-Files
svn_grass at osgeo.org
Mon Jun 15 20:03:00 EDT 2009
Author: hamish
Date: 2009-06-15 20:03:00 -0400 (Mon, 15 Jun 2009)
New Revision: 37900
Added:
grass/branches/develbranch_6/mswindows/Installer-Files/GRASS_MSys.ico
grass/branches/develbranch_6/mswindows/Installer-Files/GRASS_tcltk.ico
grass/branches/develbranch_6/mswindows/GRASS-Installer.nsi
grass/branches/develbranch_6/mswindows/GRASS-Packager.bat
grass/branches/develbranch_6/mswindows/Installer-Files/GRASS.ico
grass/branches/develbranch_6/mswindows/Installer-Files/GRASS_CMD.ico
grass/branches/develbranch_6/mswindows/Installer-Files/GRASS_Web.ico
grass/branches/develbranch_6/mswindows/Installer-Files/Install_GRASS.ico
grass/branches/develbranch_6/mswindows/Installer-Files/MSYS_Custom_Icon.ico
grass/branches/develbranch_6/mswindows/Installer-Files/Uninstall_GRASS.ico
grass/branches/develbranch_6/mswindows/Installer-Files/WinGRASS.ico
grass/branches/develbranch_6/mswindows/README.html
updates and new icons from Colin Nielsen
Modified: grass/branches/develbranch_6/mswindows/GRASS-Installer.nsi
--- grass/branches/develbranch_6/mswindows/GRASS-Installer.nsi 2009-06-15 21:25:53 UTC (rev 37899)
+++ grass/branches/develbranch_6/mswindows/GRASS-Installer.nsi 2009-06-16 00:03:00 UTC (rev 37900)
@@ -430,6 +430,8 @@
SetOutPath "$INSTALL_DIR\icons"
File .\Installer-Files\GRASS.ico
File .\Installer-Files\GRASS_Web.ico
+ File .\Installer-Files\GRASS_tcltk.ico
+ File .\Installer-Files\GRASS_MSys.ico
File .\Installer-Files\GRASS_CMD.ico
File .\Installer-Files\MSYS_Custom_Icon.ico
File .\Installer-Files\WinGRASS.ico
@@ -485,7 +487,7 @@
"$INSTALL_DIR\icons\GRASS.ico" "" SW_SHOWMINIMIZED "" "Launch GRASS ${VERSION_NUMBER} with the new wxPython GUI"
CreateShortCut "$DESKTOP\GRASS ${VERSION_NUMBER} with MSYS.lnk" "$INSTALL_DIR\msys\msys.bat" "/grass/bin/${GRASS_COMMAND} -wxpython"\
- "$INSTALL_DIR\icons\GRASS.ico" "" SW_SHOWNORMAL "" "Launch GRASS ${VERSION_NUMBER} with the new wxPython GUI and a MSYS UNIX terminal"
+ "$INSTALL_DIR\icons\GRASS_MSys.ico" "" SW_SHOWNORMAL "" "Launch GRASS ${VERSION_NUMBER} with the new wxPython GUI and a MSYS UNIX terminal"
;Create the Windows Start Menu Shortcuts
SetShellVarContext all
@@ -493,7 +495,7 @@
CreateDirectory "$SMPROGRAMS\${GRASS_BASE}"
CreateShortCut "$SMPROGRAMS\${GRASS_BASE}\GRASS Old TclTk GUI.lnk" "$INSTALL_DIR\${GRASS_COMMAND}.bat" "-tcltk"\
- "$INSTALL_DIR\icons\GRASS.ico" "" SW_SHOWMINIMIZED "" "Launch GRASS ${VERSION_NUMBER} with the old TclTk GUI"
+ "$INSTALL_DIR\icons\GRASS_tcltk.ico" "" SW_SHOWMINIMIZED "" "Launch GRASS ${VERSION_NUMBER} with the old TclTk GUI"
CreateShortCut "$SMPROGRAMS\${GRASS_BASE}\GRASS ${VERSION_NUMBER}.lnk" "$INSTALL_DIR\${GRASS_COMMAND}.bat" "-wxpython"\
@@ -508,7 +510,7 @@
"$INSTALL_DIR\icons\GRASS_Web.ico" "" SW_SHOWNORMAL "" "Visit the GRASS website"
CreateShortCut "$SMPROGRAMS\${GRASS_BASE}\GRASS ${VERSION_NUMBER} with MSYS.lnk" "$INSTALL_DIR\msys\msys.bat" "/grass/bin/${GRASS_COMMAND} -wxpython"\
; FIXME: ship the WinGrass release notes .html file instead of URL
; http://trac.osgeo.org/grass/browser/grass-web/trunk/grass64/binary/mswindows/native/README.html?format=raw
Modified: grass/branches/develbranch_6/mswindows/GRASS-Packager.bat
--- grass/branches/develbranch_6/mswindows/GRASS-Packager.bat 2009-06-15 21:25:53 UTC (rev 37899)
+++ grass/branches/develbranch_6/mswindows/GRASS-Packager.bat 2009-06-16 00:03:00 UTC (rev 37900)
@@ -19,7 +19,7 @@
@echo -----------------------------------------------------------------------------------------------------------------------
@echo Edited by: Marco Pasetti
@echo Revised for OSGeo4W by: Colin Nielsen
- at echo Last Update: 30 March 2009
+ at echo Last Update: 10 June 2009
@echo Select the GRASS version to pack:
@echo.
@@ -183,7 +183,7 @@
xcopy %OSGEO4W_DIR%\apps\msys\info %PACKAGE_DIR%\msys\info /S/V/F/I
xcopy %OSGEO4W_DIR%\apps\msys\lib %PACKAGE_DIR%\msys\lib /S/V/F/I
xcopy %OSGEO4W_DIR%\apps\msys\man %PACKAGE_DIR%\msys\man /S/V/F/I
-del %OSGEO4W_DIR%\apps\msys\etc\fstab
+del %PACKAGE_DIR%\msys\etc\fstab
@echo.
@@ -205,7 +205,6 @@
@echo.
@echo Packaging Completed
- at echo Remove lines 11-16 from %PACKAGE_DIR%\msys\msys.bat
@echo.
pause
Property changes on: grass/branches/develbranch_6/mswindows/Installer-Files/GRASS.ico
___________________________________________________________________
- application/octet-stream
+ image/x-icon
Property changes on: grass/branches/develbranch_6/mswindows/Installer-Files/GRASS_CMD.ico
+ image/x-icon
Added: grass/branches/develbranch_6/mswindows/Installer-Files/GRASS_MSys.ico
(Binary files differ)
Property changes on: grass/branches/develbranch_6/mswindows/Installer-Files/GRASS_MSys.ico
+ image/x-icon
Property changes on: grass/branches/develbranch_6/mswindows/Installer-Files/GRASS_Web.ico
+ image/x-icon
Added: grass/branches/develbranch_6/mswindows/Installer-Files/GRASS_tcltk.ico
Property changes on: grass/branches/develbranch_6/mswindows/Installer-Files/GRASS_tcltk.ico
+ image/x-icon
Property changes on: grass/branches/develbranch_6/mswindows/Installer-Files/Install_GRASS.ico
+ image/x-icon
Property changes on: grass/branches/develbranch_6/mswindows/Installer-Files/MSYS_Custom_Icon.ico
+ image/x-icon
Property changes on: grass/branches/develbranch_6/mswindows/Installer-Files/Uninstall_GRASS.ico
+ image/x-icon
Property changes on: grass/branches/develbranch_6/mswindows/Installer-Files/WinGRASS.ico
+ image/x-icon
Modified: grass/branches/develbranch_6/mswindows/README.html
--- grass/branches/develbranch_6/mswindows/README.html 2009-06-15 21:25:53 UTC (rev 37899)
+++ grass/branches/develbranch_6/mswindows/README.html 2009-06-16 00:03:00 UTC (rev 37900)
@@ -211,6 +211,9 @@
<p>When finished, you should have a GRASS self-contained release package
in <code>c:\temp\GRASS-Release-Package</code>.</p>
+<p>Download README.html from <a href="http://trac.osgeo.org/grass/browser/grass-web/trunk/grass64/binary/mswindows/native/README.html?format=raw">here</a>,
+place in <code>c:\temp\GRASS-Release-Package</code> (update version numbers as necessary).</p>
</div>
@@ -226,11 +229,10 @@
<p>At the end of line 88 (also in msys.bat) change:
<pre><code>start %WD%rxvt -backspacekey -sl 2500 -fg %FGCOLOR% -bg %BGCOLOR% -sr -fn Courier-12 -tn msys -geometry 80x25 -e /bin/sh --login -c "%*"</code></pre>
To:
-<pre><code>if "x%*" == "x" start %WD%rxvt -backspacekey -sl 2500 -fg %FGCOLOR% -bg %BGCOLOR% -sr -fn Courier-12 -tn msys -geometry 80x25 -e /bin/sh --login -i
-if NOT "x%*" == "x" start %WD%rxvt -backspacekey -sl 2500 -fg %FGCOLOR% -bg %BGCOLOR% -sr -fn Courier-12 -tn msys -geometry 80x25 -e /bin/sh --login -c "%*"</code></pre>
+<pre><code>if "x%*" == "x" start "MSYS 1.0" "%WD%rxvt" -backspacekey -sl 2500 -fg %FGCOLOR% -bg %BGCOLOR% -sr -fn Courier-12 -tn msys -geometry 80x25 -e /bin/sh --login -i
+if NOT "x%*" == "x" start "MSYS 1.0" "%WD%rxvt" -backspacekey -sl 2500 -fg %FGCOLOR% -bg %BGCOLOR% -sr -fn Courier-12 -tn msys -geometry 80x25 -e /bin/sh --login -c "%*"
+</code></pre>
-<p>Delete <code>c:\temp\GRASS-Release-Package\msys\etc\fstab</code></p>
</div>
@@ -302,7 +304,7 @@
<p>To contact them, e-mail to: GRASS Development Mailing List
(<a target="_blank" href="http://lists.osgeo.org/mailman/listinfo/grass-dev">http://lists.osgeo.org/mailman/listinfo/grass-dev</a>).</p>
-<p>Last edited by Colin Nielsen on 29 April 2009.</p>
+<p>Last edited by Colin Nielsen on 10 June 2009.</p>
</div>
