[GRASS-SVN] r37928 - grass-addons/vector/v.krige
svn_grass at osgeo.org
Thu Jun 18 12:44:15 EDT 2009
Author: aghisla
Date: 2009-06-18 12:44:15 -0400 (Thu, 18 Jun 2009)
New Revision: 37928
grass-addons/vector/v.krige/v.krige.py
refactoring of notebook page creation - sill, value and range widgets added to interface
Modified: grass-addons/vector/v.krige/v.krige.py
--- grass-addons/vector/v.krige/v.krige.py 2009-06-17 20:47:08 UTC (rev 37927)
+++ grass-addons/vector/v.krige/v.krige.py 2009-06-18 16:44:15 UTC (rev 37928)
@@ -31,7 +31,8 @@
print >> sys.stderr, "Rpy2 not found. Please install it and re-run."
haveRpy2 = False
-#@TODO(anne): check all dependencies and data at the beginning.
+#@TODO(anne): check all dependencies and data at the beginning:
+# grass - rpy2 - R - one of automap/gstat/geoR
# a nice splash screen like QGIS does can fit the purpose, with a log message on the bottom and
# popup windows for missing stuff messages.
# For the moment, deps are checked when creating the notebook pages for each package, and the
@@ -43,15 +44,14 @@
gisenv = grass.gisenv()
#classes in alphabetical order
class KrigingPanel(wx.Panel):
- Main panel. Contains all widgets except Menus and Statusbar.
+ """ Main panel. Contains all widgets except Menus and Statusbar. """
def __init__(self, parent, *args, **kwargs):
wx.Panel.__init__(self, parent, *args, **kwargs)
self.parent = parent
- self.border = 7
+ self.border = 5
# 1. Input data
InputBoxSizer = wx.StaticBoxSizer(wx.StaticBox(self, id=wx.ID_ANY, label='Input Data'),
@@ -76,6 +76,7 @@
self.__createGstatPage()
self.__createGeoRPage()
+ #@TODO(anne): check this dependency at the beginning.
if self.RPackagesBook.GetPageCount() == 0:
wx.MessageBox(parent=self,
message=("No R package with kriging functions available. Install either automap, gstat or geoR."),
@@ -88,12 +89,11 @@
ButtonSizer = wx.BoxSizer(wx.HORIZONTAL)
QuitButton = wx.Button(self, id=wx.ID_EXIT)
QuitButton.Bind(wx.EVT_BUTTON, self.OnCloseWindow)
- RunButton = wx.Button(self, id=wx.ID_ANY, label='Run')
+ RunButton = wx.Button(self, id=wx.ID_ANY, label='Run') # no stock ID for Run button..
RunButton.Bind(wx.EVT_BUTTON, self.OnRunButton)
ButtonSizer.Add(QuitButton, proportion=0, flag=wx.ALIGN_RIGHT | wx.ALL, border=self.border)
ButtonSizer.Add(RunButton, proportion=0, flag=wx.ALIGN_RIGHT | wx.ALL, border=self.border)
# Main Sizer. Add each child sizer as soon as it is ready.
Sizer = wx.BoxSizer(wx.VERTICAL)
Sizer.Add(InputBoxSizer, proportion=0, flag=wx.EXPAND | wx.ALL, border=self.border)
@@ -105,48 +105,27 @@
def __createAutomapPage(self):
# 1. check if the package automap exists
if robjects.r.require('automap') and robjects.r.require('spgrass6'):
- self.AutomapPanel = wx.Panel(self, id=wx.ID_ANY)
+ self.AutomapPanel = RBookAutomapPanel(self, id=wx.ID_ANY)
self.RPackagesBook.AddPage(page=self.AutomapPanel, text="automap")
- # unlock options as soon as they are available. Stone soup!
- self.VariogramList = ["Auto-fit variogram"]#, "Choose variogram parameters"]
- VariogramRadioBox = wx.RadioBox(self.AutomapPanel, id=wx.ID_ANY, label="Variogram Fitting",
- pos=wx.DefaultPosition, #size=wx.DefaultSize,
- choices=self.VariogramList, majorDimension=1, style=wx.RA_SPECIFY_COLS)
- self.KrigingList = ["Ordinary kriging"]
- KrigingRadioBox = wx.RadioBox(self.AutomapPanel, id=wx.ID_ANY, label="Kriging techniques",
- pos=wx.DefaultPosition,# size=wx.DefaultSize,
- choices=self.KrigingList, majorDimension=1, style=wx.RA_SPECIFY_COLS)
- Sizer = wx.BoxSizer(wx.VERTICAL)
- Sizer.Add(VariogramRadioBox, proportion=0, flag=wx.EXPAND | wx.ALL, border=0)
- Sizer.Add(KrigingRadioBox, proportion=0, flag=wx.EXPAND | wx.ALL, border=0)
- self.AutomapPanel.SetSizerAndFit(Sizer)
else:
pass
def __createGstatPage(self):
if robjects.r.require('gstat'):
- self.GstatPanel = wx.Panel(self, id=wx.ID_ANY)
+ self.GstatPanel = RBookPanel(self, id=wx.ID_ANY)
self.RPackagesBook.AddPage(page=self.GstatPanel, text="gstat")
- # add stuff to panel
else:
pass
def __createGeoRPage(self):
if robjects.r.require('geoR'):
- self.GeoRPanel = wx.Panel(self, id=wx.ID_ANY)
+ self.GeoRPanel = RBookPanel(self, id=wx.ID_ANY)
self.RPackagesBook.AddPage(page=self.GeoRPanel, text="geoR")
else:
pass
def __getVectors(self, *args, **kwargs):
- """Get list of tables for given location and mapset"""
+ """ Get list of tables for given location and mapset. """
vectors = grass.list_grouped('vect')[gisenv['MAPSET']]
#@WARNING: this cycle is quite time-consuming.
# see if it is possible to postpone this filtering, and immediately show the dialog.
@@ -160,7 +139,7 @@
if grass.vector_info_topo(n)['points'] > 0:
pointVectors.append(n)
except KeyError:
- pass
+ pass # why pass?! it's an error...
if pointVectors == []:
message=("No point vector maps available. Check if the location is correct."),
@@ -169,6 +148,11 @@
def OnRunButton(self,event):
""" Execute R analysis. """
+ #-1: get the selected notebook page. The user shall know that he/she can modify settings in all
+ # pages, but only the selected one will be executed when Run is pressed.
+ self.SelectedPanel = self.RPackagesBook.GetCurrentPage()
#0. require packages. See creation of the notebook pages and note after import directives.
#1. get the data in R format, i.e. SpatialPointsDataFrame
@@ -176,21 +160,24 @@
#2. collect options
#@TODO(anne): let user pick up the column name from a list. this is hardwired code.
self.Column = 'elev'
+ #@TODO(anne): pick up parameters if user chooses to set variogram parameters.
#3. Fit variogram
self.parent.log.write('Variogram fitting')
self.Formula = robjects.r['as.formula'](robjects.r.paste(self.Column, "~ 1"))
- self.Variogram= robjects.r.autofitVariogram(self.Formula, self.InputData)
+ self.Variogram = self.SelectedPanel.FitVariogram(self.Formula, self.InputData)
+ print type(self.Variogram)
# print variogram somehow
- robjects.r.plot(self.Variogram)
+ #robjects.r.plot(self.Variogram)
self.parent.log.write('Variogram fitted.')
#4. Kriging
- self.parent.log.write('Kriging...')
+# self.parent.log.write('Kriging...')
+ ## AUTOMAP
#@TODO(anne): the prediced values grid is autogenerated without projection. wait for patch.
- self.KrigingResult = robjects.r.autoKrige(self.Formula, self.InputData)
- self.parent.log.write('Kriging performed..')
+ #self.KrigingResult = robjects.r.autoKrige(self.Formula, self.InputData)
+# self.parent.log.write('Kriging performed..')
#5. Format output
@@ -200,17 +187,14 @@
event.Skip()
class KrigingModule(wx.Frame):
- Kriging module for GRASS GIS. Depends on R and its packages gstat and geoR.
+ """ Kriging module for GRASS GIS. Depends on R and its packages gstat and geoR. """
wx.Frame.__init__(self, parent, *args, **kwargs)
# setting properties and all widgettery
self.SetTitle("Kriging Module")
self.log = Log(self) # writes on statusbar
self.CreateStatusBar()
- # debug: remove before flight
- self.log.write("Under construction.")
+ self.log.write("Ready.")
self.Panel = KrigingPanel(self)
# size. It is the minimum size. No way to get it in a single command.
@@ -219,17 +203,68 @@
class Log:
- The log output is redirected to the status bar of the containing frame.
+ """ The log output is redirected to the status bar of the containing frame. """
def __init__(self, parent):
def write(self, text_string):
- """Update status bar"""
+ """ Updates status bar """
self.parent.SetStatusText(text_string.strip())
+class RBookPanel(wx.Panel):
+ """ Generic notebook page with all widgets and empty kriging functions. """
+ def __init__(self, parent, *args, **kwargs):
+ wx.Panel.__init__(self, parent, *args, **kwargs)
-#main
+ # unlock options as soon as they are available. Stone soup!
+ self.VariogramSizer = wx.StaticBoxSizer(wx.StaticBox(self, id=wx.ID_ANY,
+ label='Variogram fitting'), wx.VERTICAL)
+ VariogramCheckBox = wx.CheckBox(self, id=wx.ID_ANY, label="Auto-fit variogram")
+ VariogramCheckBox.SetValue(state = True) # check it by default
+ self.ParametersSizer = wx.BoxSizer(wx.VERTICAL)
+ for n in ["Sill", "Nugget", "Range"]:
+ Sizer = wx.BoxSizer(wx.HORIZONTAL)
+ Text = wx.StaticText(self, id= wx.ID_ANY, label = n)
+ Ctrl = wx.SpinCtrl(self, id = wx.ID_ANY, max= 100000) #@FIXME: get max int value!!
+ Sizer.Add(Text, proportion=0, flag=wx.ALIGN_LEFT | wx.ALIGN_CENTER | wx.ALL, border=3)
+ Sizer.Add(Ctrl, proportion=0, flag=wx.ALIGN_RIGHT | wx.ALL, border=3)
+ self.ParametersSizer.Add(Sizer, proportion = 0, flag=wx.EXPAND | wx.ALL, border=3)
+ self.VariogramSizer.Add(VariogramCheckBox, proportion=1, flag=wx.EXPAND | wx.ALL, border=3)
+ self.VariogramSizer.Add(self.ParametersSizer, proportion=0, flag=wx.EXPAND | wx.ALL, border=3)
+ # hides Parameters when Autofit variogram is selected
+# VariogramCheckBox.Bind(wx.EVT_CHECKBOX, self.HideOptions)
+ self.KrigingList = ["Ordinary kriging", "Universal Kriging", "Block kriging"]
+ KrigingRadioBox = wx.RadioBox(self, id=wx.ID_ANY, label="Kriging techniques",
+ pos=wx.DefaultPosition, size=wx.DefaultSize,
+ choices=self.KrigingList, majorDimension=1, style=wx.RA_SPECIFY_COLS)
+ Sizer = wx.BoxSizer(wx.VERTICAL)
+ Sizer.Add(self.VariogramSizer, proportion=0, flag=wx.EXPAND | wx.ALL, border=3)
+ Sizer.Add(KrigingRadioBox, proportion=0, flag=wx.EXPAND | wx.ALL, border=3)
+ self.SetSizerAndFit(Sizer)
+ def FitVariogram():
+ pass
+ def DoKriging():
+ pass
+ def HideOptions(self, event):
+ for n in self.ParametersSizer.GetChildren(): n.Disable()
+ #@TODO(anne): set it right.
+class RBookAutomapPanel(RBookPanel):
+ """ Subclass of RBookPanel, with specific automap options and kriging functions. """
+ RBookPanel.__init__(self, parent, *args, **kwargs)
+ def FitVariogram(self, Formula, InputData):
+ return robjects.r.autofitVariogram(Formula, InputData)
def main(argv=None):
if argv is None:
argv = sys.argv
@@ -249,6 +284,7 @@
##some applications might require image handlers
#wx.InitAllImageHandlers()
+ #@TODO(anne): move this code in the initial deps-data-check.
if not haveRpy2:
sys.exit(1)
