[GRASS-SVN] r37941 - in grass/branches/develbranch_6/vector/lidar:
lidarlib v.lidar.edgedetection
svn_grass at osgeo.org
Fri Jun 19 03:33:27 EDT 2009
Author: hamish
Date: 2009-06-19 03:33:25 -0400 (Fri, 19 Jun 2009)
New Revision: 37941
grass/branches/develbranch_6/vector/lidar/lidarlib/TcholBand.c
grass/branches/develbranch_6/vector/lidar/v.lidar.edgedetection/main.c
add G_verbose_message(), G_percent() for long running process
Modified: grass/branches/develbranch_6/vector/lidar/lidarlib/TcholBand.c
--- grass/branches/develbranch_6/vector/lidar/lidarlib/TcholBand.c 2009-06-19 03:10:36 UTC (rev 37940)
+++ grass/branches/develbranch_6/vector/lidar/lidarlib/TcholBand.c 2009-06-19 07:33:25 UTC (rev 37941)
@@ -12,7 +12,10 @@
int i, j, k;
double somma;
+ G_debug(3, "tcholDec(): n=%d BW=%d", n, BW);
for (i = 0; i < n; i++) {
+ G_percent(i, n, 2);
for (j = 0; j < BW; j++) {
somma = N[i][j];
for (k = 1; k < BW; k++)
@@ -28,6 +31,7 @@
return;
Modified: grass/branches/develbranch_6/vector/lidar/v.lidar.edgedetection/main.c
--- grass/branches/develbranch_6/vector/lidar/v.lidar.edgedetection/main.c 2009-06-19 03:10:36 UTC (rev 37940)
+++ grass/branches/develbranch_6/vector/lidar/v.lidar.edgedetection/main.c 2009-06-19 07:33:25 UTC (rev 37941)
@@ -242,7 +242,7 @@
if (nsply > NSPLY_MAX) {
nsply = NSPLY_MAX;
- G_debug(1, _("nsply = %d"), nsply);
+ G_debug(1, "nsply = %d", nsply);
elaboration_reg.east = original_reg.west;
last_column = FALSE;
@@ -269,11 +269,11 @@
if (nsplx > NSPLX_MAX) {
nsplx = NSPLX_MAX;
- G_debug(1, _("nsplx = %d"), nsplx);
+ G_debug(1, "nsplx = %d", nsplx);
/*Setting the active region */
dim_vect = nsplx * nsply;
- G_debug(1, _("read vector region map"));
+ G_debug(1, "read vector region map");
observ =
P_Read_Vector_Region_Map(&In, &elaboration_reg, &npoints,
dim_vect, 1);
@@ -308,7 +308,7 @@
/*G_free (observ); */
- G_debug(1, _("Bilinear interpolation"));
+ G_verbose_message(_("Bilinear interpolation"));
normalDefBilin(N, TN, Q, obsVect, passoE, passoN, nsplx,
nsply, elaboration_reg.west,
elaboration_reg.south, npoints, nparameters,
@@ -325,7 +325,7 @@
N = G_alloc_matrix(nparameters, BW); /* Normal matrix */
parVect_bicub = G_alloc_vector(nparameters); /* Bicubic parameters vector */
- G_debug(1, _("Bicubic interpolation"));
+ G_verbose_message(_("Bicubic interpolation"));
normalDefBicubic(N, TN, Q, obsVect, passoE, passoN, nsplx,
@@ -345,7 +345,7 @@
G_fatal_error(_("It was impossible to create <%s>."),
table_name);
- G_debug(1, _("Point classification"));
+ G_verbose_message(_("Point classification"));
classification(&Out, elaboration_reg, general_box,
overlap_box, obsVect, parVect_bilin,
parVect_bicub, mean, alpha, grad_H, grad_L,
