[GRASS-SVN] r37943 - grass/trunk/include/Make
svn_grass at osgeo.org
Fri Jun 19 04:09:20 EDT 2009
Author: mmetz
Date: 2009-06-19 04:09:19 -0400 (Fri, 19 Jun 2009)
New Revision: 37943
grass/trunk/include/Make/Grass.make
vector modules need LFS too if requested
Modified: grass/trunk/include/Make/Grass.make
--- grass/trunk/include/Make/Grass.make 2009-06-19 07:35:31 UTC (rev 37942)
+++ grass/trunk/include/Make/Grass.make 2009-06-19 08:09:19 UTC (rev 37943)
@@ -77,15 +77,16 @@
COMPILE_FLAGS = $(CPPFLAGS) $(CFLAGS1) $(INCLUDE_DIRS)
COMPILE_FLAGS_CXX = $(CPPFLAGS) $(CXXFLAGS1) $(INCLUDE_DIRS)
+# crude hack for vector LFS, LFS_FLAGS should be set by configure
+ifdef USE_LARGEFILES
+VECT_LFS_FLAGS = -D_FILE_OFFSET_BITS=64
+endif
CFLAGS = $(INC) $(COMPILE_FLAGS)
CXXFLAGS = $(INC) $(COMPILE_FLAGS_CXX)
LDFLAGS = $(LIBPATH) $(LINK_FLAGS) $(LD_SEARCH_FLAGS) $(PQLIBPATH)
-VECT_CFLAGS = $(GDALCFLAGS) $(GEOSCFLAGS)
+VECT_CFLAGS = $(GDALCFLAGS) $(GEOSCFLAGS) $(VECT_LFS_FLAGS)
-ifdef USE_LARGEFILES
-VECT_CFLAGS += -D_FILE_OFFSET_BITS=64
-endif
# Object with _fmode which must be linked to each executable on Windows
ifdef MINGW
FMODE_OBJ = $(BASE_LIBDIR)/fmode.o
