[GRASS-SVN] r37957 - grass-addons/vector/v.krige
svn_grass at osgeo.org
Fri Jun 19 08:16:10 EDT 2009
Author: aghisla
Date: 2009-06-19 08:16:10 -0400 (Fri, 19 Jun 2009)
New Revision: 37957
grass-addons/vector/v.krige/v.krige.py
added choicebox with chosen layer's numerical column(s)
Modified: grass-addons/vector/v.krige/v.krige.py
--- grass-addons/vector/v.krige/v.krige.py 2009-06-19 11:57:58 UTC (rev 37956)
+++ grass-addons/vector/v.krige/v.krige.py 2009-06-19 12:16:10 UTC (rev 37957)
@@ -61,8 +61,19 @@
self.InputDataLabel = wx.StaticText(self, id=wx.ID_ANY, label="Point dataset")
self.InputDataChoicebox = wx.Choice(self, id=wx.ID_ANY, pos=wx.DefaultPosition,
choices=self.SampleList)
+ self.ColumnList = self.__getColumns(self.InputDataChoicebox.GetStringSelection())
+ self.InputDataColumnLabel = wx.StaticText(self, id=wx.ID_ANY, label="Column")
+ self.InputDataColumn = wx.Choice(self, id=wx.ID_ANY, pos=wx.DefaultPosition,
+ choices=self.ColumnList)
+ self.InputDataChoicebox.Bind(wx.EVT_CHOICE, self.OnInputDataChanged)
InputBoxSizer.Add(self.InputDataLabel, proportion=0, flag=wx.CENTER | wx.ALL, border=self.border)
InputBoxSizer.Add(self.InputDataChoicebox, proportion=0, flag=wx.CENTER| wx.ALL, border=self.border)
+ InputBoxSizer.Add(self.InputDataColumnLabel, proportion=0, flag=wx.CENTER | wx.ALL, border=self.border)
+ InputBoxSizer.Add(self.InputDataColumn, proportion=0, flag=wx.CENTER| wx.ALL, border=self.border)
# 2. Kriging. In book pages one for each R package. Includes variogram fit.
KrigingSizer = wx.StaticBoxSizer(wx.StaticBox(self, id=wx.ID_ANY, label='Kriging'), wx.HORIZONTAL)
@@ -124,8 +135,18 @@
else:
pass
+ def __getColumns(self, layer):
+ """ Lists the numerical columns of the given layer. """
+ ColumnList = grass.db_describe(layer)['cols']
+ # filter it to pick up numerical cols
+ NumericalColumnList = []
+ for i in ColumnList:
+ if i[1] == 'INTEGER' or i[1] == 'DOUBLE PRECISION':
+ NumericalColumnList.append(i[0])
+ return NumericalColumnList
def __getVectors(self, *args, **kwargs):
- """ Get list of tables for given location and mapset. """
+ """ Get list of vector point layers for given location and mapset. """
vectors = grass.list_grouped('vect')[gisenv['MAPSET']]
#@WARNING: this cycle is quite time-consuming.
# see if it is possible to postpone this filtering, and immediately show the dialog.
@@ -146,6 +167,15 @@
caption=("Missing Input Data"), style=wx.OK | wx.ICON_ERROR | wx.CENTRE)
return sorted(pointVectors)
+ def OnInputDataChanged(self,event):
+ """ Refreshes list of columns. """
+ table = event.GetString()
+ cols = self.__getColumns(table)
+ self.InputDataColumn.SetItems(cols)
+ self.InputDataColumn.SetSelection(0)
+ event.Skip() #?
def OnRunButton(self,event):
""" Execute R analysis. """
@@ -159,17 +189,14 @@
self.InputData = robjects.r.readVECT6(self.InputDataChoicebox.GetStringSelection(), type= 'point')
#2. collect options
#@TODO(anne): let user pick up the column name from a list. this is hardwired code.
- self.Column = 'elev'
+ self.Column = self.InputDataColumn.GetStringSelection()
#@TODO(anne): pick up parameters if user chooses to set variogram parameters.
#3. Fit variogram
self.parent.log.write('Variogram fitting')
self.Formula = robjects.r['as.formula'](robjects.r.paste(self.Column, "~ 1"))
+ Variogram = self.SelectedPanel.FitVariogram(self.Formula, self.InputData)
+ # print variogram?
- self.Variogram = self.SelectedPanel.FitVariogram(self.Formula, self.InputData)
- print type(self.Variogram)
- # print variogram somehow
- #robjects.r.plot(self.Variogram)
self.parent.log.write('Variogram fitted.')
#4. Kriging
@@ -224,16 +251,17 @@
self.ParametersSizer = wx.BoxSizer(wx.VERTICAL)
for n in ["Sill", "Nugget", "Range"]:
- Sizer = wx.BoxSizer(wx.HORIZONTAL)
- Text = wx.StaticText(self, id= wx.ID_ANY, label = n)
- Ctrl = wx.SpinCtrl(self, id = wx.ID_ANY, max= 100000) #@FIXME: get max int value!!
- Sizer.Add(Text, proportion=0, flag=wx.ALIGN_LEFT | wx.ALIGN_CENTER | wx.ALL, border=3)
- Sizer.Add(Ctrl, proportion=0, flag=wx.ALIGN_RIGHT | wx.ALL, border=3)
- self.ParametersSizer.Add(Sizer, proportion = 0, flag=wx.EXPAND | wx.ALL, border=3)
+ setattr(self, n+"Sizer", (wx.BoxSizer(wx.HORIZONTAL)))
+ setattr(self, n+"Text", (wx.StaticText(self, id= wx.ID_ANY, label = n)))
+ setattr(self, n+"Ctrl", (wx.SpinCtrl(self, id = wx.ID_ANY, max=sys.maxint)))
+ a = getattr(self, n+"Sizer")
+ a.Add(getattr(self, n+"Text"), proportion=0, flag=wx.ALIGN_LEFT | wx.ALIGN_CENTER | wx.ALL, border=3)
+ a.Add(getattr(self, n+"Ctrl"), proportion=0, flag=wx.ALIGN_RIGHT | wx.ALL, border=3)
+ self.ParametersSizer.Add(a, proportion = 0, flag=wx.EXPAND | wx.ALL, border=3)
self.VariogramSizer.Add(VariogramCheckBox, proportion=1, flag=wx.EXPAND | wx.ALL, border=3)
self.VariogramSizer.Add(self.ParametersSizer, proportion=0, flag=wx.EXPAND | wx.ALL, border=3)
- # hides Parameters when Autofit variogram is selected
+ #@TODO(anne); hides Parameters when Autofit variogram is selected
# VariogramCheckBox.Bind(wx.EVT_CHECKBOX, self.HideOptions)
self.KrigingList = ["Ordinary kriging", "Universal Kriging", "Block kriging"]
@@ -284,7 +312,7 @@
##some applications might require image handlers
#wx.InitAllImageHandlers()
- #@TODO(anne): move this code in the initial deps-data-check.
+ #@TODO(anne):add here all dependency checking
if not haveRpy2:
sys.exit(1)
