[GRASS-SVN] r37979 - in grass/branches/develbranch_6:
display/d.profile general/g.region lib/gis raster/r.distance
raster/r.out.ascii raster/r.stats sites/s.out.ascii
svn_grass at osgeo.org
Fri Jun 19 21:11:11 EDT 2009
Author: hamish
Date: 2009-06-19 21:11:11 -0400 (Fri, 19 Jun 2009)
New Revision: 37979
grass/branches/develbranch_6/display/d.profile/DumpProfile.c
grass/branches/develbranch_6/display/d.profile/PlotProfile.c
grass/branches/develbranch_6/display/d.profile/What.c
grass/branches/develbranch_6/general/g.region/printwindow.c
grass/branches/develbranch_6/lib/gis/wind_format.c
grass/branches/develbranch_6/raster/r.distance/report.c
grass/branches/develbranch_6/raster/r.out.ascii/formspecific.c
grass/branches/develbranch_6/raster/r.stats/raw_stats.c
grass/branches/develbranch_6/sites/s.out.ascii/main.c
output correct precision for different projection types (bugs #654 and #335)
Modified: grass/branches/develbranch_6/display/d.profile/DumpProfile.c
--- grass/branches/develbranch_6/display/d.profile/DumpProfile.c 2009-06-19 22:17:11 UTC (rev 37978)
+++ grass/branches/develbranch_6/display/d.profile/DumpProfile.c 2009-06-20 01:11:11 UTC (rev 37979)
@@ -17,6 +17,7 @@
char *buf2 = G_calloc(UCAT_STR_SIZE, sizeof(char));
char *outfile = G_calloc(strlen(fname) + 3, sizeof(char));
char coords[4][80];
+ char outfmt[24];
FILE *outFile;
struct ProfileNode *ptr;
@@ -55,10 +56,15 @@
_fmt_ucat(&profile->MaxCat, &profile->MinCat, buf2));
fprintf(outFile, "# dist value east north\n");
+ if (G_projection() == PROJECTION_LL)
+ strcpy(outfmt, "%f %s %.8f %.8f\n");
+ else
+ strcpy(outfmt, "%f %s %.3f %.3f\n");
/* Now loop through the nodes, one value per line */
for (ptr = profile->ptr; ptr != NULL; ptr = ptr->next) {
- fprintf(outFile, "%f %s %f %f\n",
- ptr->dist,
+ fprintf(outFile, outfmt, ptr->dist,
_fmt_ucat(&ptr->cat, &profile->MinCat, buf),
ptr->east, ptr->north);
Modified: grass/branches/develbranch_6/display/d.profile/PlotProfile.c
--- grass/branches/develbranch_6/display/d.profile/PlotProfile.c 2009-06-19 22:17:11 UTC (rev 37978)
+++ grass/branches/develbranch_6/display/d.profile/PlotProfile.c 2009-06-20 01:11:11 UTC (rev 37979)
@@ -98,8 +98,14 @@
text_height = TEXT_HEIGHT * (b - t);
text_width = text_height * 0.8;
R_standard_color(D_translate_color(DEFAULT_FG_COLOR));
- sprintf(txt_buf, "%s: From (%10.2f,%10.2f) to (%10.2f,%10.2f)",
+ sprintf(txt_buf, "%s: From (%10.6f,%10.6f) to (%10.6f,%10.6f)",
letter, profile.e1, profile.n1, profile.e2, profile.n2);
+ else
+ sprintf(txt_buf, "%s: From (%10.2f,%10.2f) to (%10.2f,%10.2f)",
+ letter, profile.e1, profile.n1, profile.e2, profile.n2);
done = 0;
do {
R_get_text_box(txt_buf, &tt, &tb, &tl, &tr);
Modified: grass/branches/develbranch_6/display/d.profile/What.c
--- grass/branches/develbranch_6/display/d.profile/What.c 2009-06-19 22:17:11 UTC (rev 37978)
+++ grass/branches/develbranch_6/display/d.profile/What.c 2009-06-20 01:11:11 UTC (rev 37979)
@@ -35,10 +35,19 @@
sprintf(txt_buf, "%s in mapset %s", name, mapset);
DrawText(22, 1, 1, txt_buf);
- sprintf(txt_buf, "EAST: %10.2f", east);
+ sprintf(txt_buf, "EAST: %10.6f", east);
+ else
+ sprintf(txt_buf, "EAST: %10.2f", east);
DrawText(22, 2, 1, txt_buf);
- sprintf(txt_buf, "NORTH: %10.2f", north);
+ sprintf(txt_buf, "NORTH: %10.6f", north);
+ else
+ sprintf(txt_buf, "NORTH: %10.2f", north);
DrawText(22, 3, 1, txt_buf);
if (NoCatStrings)
sprintf(txt_buf, "(%d)", buf[col]);
else
Modified: grass/branches/develbranch_6/general/g.region/printwindow.c
--- grass/branches/develbranch_6/general/g.region/printwindow.c 2009-06-19 22:17:11 UTC (rev 37978)
+++ grass/branches/develbranch_6/general/g.region/printwindow.c 2009-06-20 01:11:11 UTC (rev 37979)
@@ -23,7 +23,7 @@
double longitude, latitude;
if (print_flag & PRINT_SH)
- x = -1;
+ x = G_projection() == PROJECTION_LL ? -1 : 0;
else
x = window->proj;
Modified: grass/branches/develbranch_6/lib/gis/wind_format.c
--- grass/branches/develbranch_6/lib/gis/wind_format.c 2009-06-19 22:17:11 UTC (rev 37978)
+++ grass/branches/develbranch_6/lib/gis/wind_format.c 2009-06-20 01:11:11 UTC (rev 37979)
@@ -18,7 +18,7 @@
#include <grass/gis.h>
-static int format_double(double, char *);
+static void format_double(double, char *, int);
@@ -29,7 +29,7 @@
* \param[in] north northing
* \param[in,out] buf buffer to hold formatted string
- * \param[in] projection
+ * \param[in] projection, or -1 to force full precision FP
* \return always returns 0
@@ -37,8 +37,10 @@
if (projection == PROJECTION_LL)
G_lat_format(north, buf);
+ else if (projection == -1)
+ format_double(north, buf, TRUE);
else
- format_double(north, buf);
+ format_double(north, buf, FALSE);
return 0;
@@ -52,7 +54,7 @@
* \param[in] east easting
@@ -60,8 +62,10 @@
G_lon_format(east, buf);
+ format_double(east, buf, TRUE);
else
- format_double(east, buf);
+ format_double(east, buf, FALSE);
return 0;
@@ -75,7 +79,7 @@
* \param[in] resolution
@@ -83,23 +87,28 @@
G_llres_format(res, buf);
+ format_double(res, buf, TRUE);
else
- format_double(res, buf);
+ format_double(res, buf, FALSE);
return 0;
-static int format_double(double value, char *buf)
+ * 'full_prec' is boolean, FALSE uses %.8f, TRUE uses %.15g
+ * The reason to have this is that for lat/lon "%.8f" is not
+ * enough to preserve fidelity once converted back into D:M:S,
+ * which leads to rounding errors, especially for resolution.
+static void format_double(double value, char *buf, int full_prec)
- /* if the programmer has lied to G_format_resolution() about the
- projection type in order to get FP values for lat/lon coords,
- "%.8f" is not enough to preserve fidelity once converted
- back into D:M:S, which leads to rounding errors. */
- if (G_projection() == PROJECTION_LL)
+ if (full_prec)
sprintf(buf, "%.15g", value);
else
sprintf(buf, "%.8f", value);
G_trim_decimal(buf);
- return 0;
+ return;
Modified: grass/branches/develbranch_6/raster/r.distance/report.c
--- grass/branches/develbranch_6/raster/r.distance/report.c 2009-06-19 22:17:11 UTC (rev 37978)
+++ grass/branches/develbranch_6/raster/r.distance/report.c 2009-06-20 01:11:11 UTC (rev 37979)
@@ -59,13 +59,17 @@
fprintf(stdout, "%s%s", fs, temp);
/* print coordinates of the closest pair */
- G_format_easting(east1, temp, -1);
+ G_format_easting(east1, temp,
+ G_projection() == PROJECTION_LL ? -1 : 0);
- G_format_northing(north1, temp, -1);
+ G_format_northing(north1, temp,
- G_format_easting(east2, temp, -1);
+ G_format_easting(east2, temp,
- G_format_northing(north2, temp, -1);
+ G_format_northing(north2, temp,
/* print category labels */
Modified: grass/branches/develbranch_6/raster/r.out.ascii/formspecific.c
--- grass/branches/develbranch_6/raster/r.out.ascii/formspecific.c 2009-06-19 22:17:11 UTC (rev 37978)
+++ grass/branches/develbranch_6/raster/r.out.ascii/formspecific.c 2009-06-20 01:11:11 UTC (rev 37979)
@@ -142,12 +142,16 @@
fprintf(fp, "%d %d\n", region.cols, region.rows);
/* Projection set to -1 to force floating point output */
- G_format_easting(region.west + region.ew_res / 2., fromc, -1);
- G_format_easting(region.east - region.ew_res / 2., toc, -1);
+ G_format_easting(region.west + region.ew_res / 2., fromc,
+ G_format_easting(region.east - region.ew_res / 2., toc,
fprintf(fp, "%s %s\n", fromc, toc);
- G_format_northing(region.south + region.ns_res / 2., fromc, -1);
- G_format_northing(region.north - region.ns_res / 2., toc, -1);
+ G_format_northing(region.south + region.ns_res / 2., fromc,
+ G_format_northing(region.north - region.ns_res / 2., toc,
G_get_fp_range_min_max(&range, &Z_MIN, &Z_MAX);
Modified: grass/branches/develbranch_6/raster/r.stats/raw_stats.c
--- grass/branches/develbranch_6/raster/r.stats/raw_stats.c 2009-06-19 22:17:11 UTC (rev 37978)
+++ grass/branches/develbranch_6/raster/r.stats/raw_stats.c 2009-06-20 01:11:11 UTC (rev 37979)
@@ -44,7 +44,8 @@
if (with_coordinates)
- G_format_northing(G_row_to_northing(row + .5, &window), nbuf, -1);
+ G_format_northing(G_row_to_northing(row + .5, &window), nbuf,
for (col = 0; col < ncols; col++) {
if (no_nulls || no_nulls_all) {
@@ -69,7 +70,7 @@
if (with_coordinates) {
G_format_easting(G_col_to_easting(col + .5, &window), ebuf,
- -1);
fprintf(stdout, "%s%s%s%s", ebuf, fs, nbuf, fs);
if (with_xy)
Modified: grass/branches/develbranch_6/sites/s.out.ascii/main.c
--- grass/branches/develbranch_6/sites/s.out.ascii/main.c 2009-06-19 22:17:11 UTC (rev 37978)
+++ grass/branches/develbranch_6/sites/s.out.ascii/main.c 2009-06-20 01:11:11 UTC (rev 37979)
@@ -115,9 +115,12 @@
while (G_site_get(fd, site) == 0) {
if (all || G_site_in_region(site, &window)) {
if (!full) {
- G_format_easting(site->east, ebuf, -1);
- G_format_northing(site->north, nbuf, -1);
+ G_format_easting(site->east, ebuf,
+ G_format_northing(site->north, nbuf,
fprintf(stdout, "%s%s%s", ebuf, fs, nbuf);
for (n = 0; n < site->dim_alloc; ++n) {
sprintf(nbuf, "%.8f", site->dim[n]);
G_trim_decimal(nbuf);
