[GRASS-SVN] r37995 - in grass/branches/releasebranch_6_4:
lib/python swig/python
svn_grass at osgeo.org
Sat Jun 20 05:17:43 EDT 2009
Author: martinl
Date: 2009-06-20 05:17:43 -0400 (Sat, 20 Jun 2009)
New Revision: 37995
Added:
grass/branches/releasebranch_6_4/lib/python/grass__init__.py
grass/branches/releasebranch_6_4/lib/python/Makefile
grass/branches/releasebranch_6_4/lib/python/__init__.py
grass/branches/releasebranch_6_4/swig/python/Makefile
fix grass/__init__.py
(merge from trunk, r37993)
Modified: grass/branches/releasebranch_6_4/lib/python/Makefile
--- grass/branches/releasebranch_6_4/lib/python/Makefile 2009-06-20 09:17:04 UTC (rev 37994)
+++ grass/branches/releasebranch_6_4/lib/python/Makefile 2009-06-20 09:17:43 UTC (rev 37995)
@@ -24,8 +24,7 @@
$(DSTDIR): $(GDIR)
test -d $@ || $(MKDIR) -p $@
- test -f __init__.py || touch $(GDIR)/__init__.py
- @echo "import script" >> $(GDIR)/__init__.py
+ @cat grass__init__.py > $(GDIR)/__init__.py
$(DSTDIR)/%: %
$(INSTALL_DATA) $< $@
Modified: grass/branches/releasebranch_6_4/lib/python/__init__.py
--- grass/branches/releasebranch_6_4/lib/python/__init__.py 2009-06-20 09:17:04 UTC (rev 37994)
+++ grass/branches/releasebranch_6_4/lib/python/__init__.py 2009-06-20 09:17:43 UTC (rev 37995)
@@ -2,4 +2,3 @@
from db import *
from raster import *
from vector import *
Copied: grass/branches/releasebranch_6_4/lib/python/grass__init__.py (from rev 37993, grass/trunk/lib/python/grass__init__.py)
--- grass/branches/releasebranch_6_4/lib/python/grass__init__.py (rev 0)
+++ grass/branches/releasebranch_6_4/lib/python/grass__init__.py 2009-06-20 09:17:43 UTC (rev 37995)
@@ -0,0 +1,4 @@
+import os
+__all__ = ["script"]
+if os.path.exists(os.path.join(os.path.dirname(__file__), "lib", "__init__.py")):
+ __all__.append("lib")
Modified: grass/branches/releasebranch_6_4/swig/python/Makefile
--- grass/branches/releasebranch_6_4/swig/python/Makefile 2009-06-20 09:17:04 UTC (rev 37994)
+++ grass/branches/releasebranch_6_4/swig/python/Makefile 2009-06-20 09:17:43 UTC (rev 37995)
@@ -64,8 +64,6 @@
$(DSTDIR): $(GDIR)
- @echo "import lib" >> $(GDIR)/__init__.py
$(DSTDIR)/_%.so: _%.so
$(INSTALL) $< $@
