[GRASS-SVN] r37997 - grass-addons/vector/v.krige
svn_grass at osgeo.org
Sat Jun 20 08:18:07 EDT 2009
Author: martinl
Date: 2009-06-20 08:18:07 -0400 (Sat, 20 Jun 2009)
New Revision: 37997
grass-addons/vector/v.krige/v.krige.py
Use gselect.VectorSelect
Modified: grass-addons/vector/v.krige/v.krige.py
--- grass-addons/vector/v.krige/v.krige.py 2009-06-20 10:16:58 UTC (rev 37996)
+++ grass-addons/vector/v.krige/v.krige.py 2009-06-20 12:18:07 UTC (rev 37997)
@@ -62,17 +62,15 @@
# 1. Input data
InputBoxSizer = wx.StaticBoxSizer(wx.StaticBox(self, id=wx.ID_ANY, label='Input Data'),
orient=wx.HORIZONTAL)
- self.SampleList = self.__getVectors()
self.InputDataLabel = wx.StaticText(self, id=wx.ID_ANY, label="Point dataset")
- self.InputDataChoicebox = wx.Choice(self, id=wx.ID_ANY, pos=wx.DefaultPosition,
- choices=self.SampleList)
+ self.InputDataChoicebox = gselect.VectorSelect(parent = self,
+ ftype = 'point')
- self.ColumnList = self.__getColumns(self.InputDataChoicebox.GetStringSelection())
+ ### self.ColumnList = self.__getColumns(self.InputDataChoicebox.GetStringSelection())
self.InputDataColumnLabel = wx.StaticText(self, id=wx.ID_ANY, label="Column")
- self.InputDataColumn = wx.Choice(self, id=wx.ID_ANY, pos=wx.DefaultPosition,
- choices=self.ColumnList)
+ self.InputDataColumn = wx.Choice(self, id=wx.ID_ANY, pos=wx.DefaultPosition)
+ ### choices=self.ColumnList)
self.InputDataChoicebox.Bind(wx.EVT_CHOICE, self.OnInputDataChanged)
@@ -154,28 +152,6 @@
if i[1] == 'INTEGER' or i[1] == 'DOUBLE PRECISION':
NumericalColumnList.append(i[0])
return NumericalColumnList
- def __getVectors(self, *args, **kwargs):
- """ Get list of vector point layers for given location and mapset. """
- vectors = grass.list_grouped('vect')[gisenv['MAPSET']]
- #@WARNING: this cycle is quite time-consuming.
- # see if it is possible to postpone this filtering, and immediately show the dialog.
- if vectors == []:
- wx.MessageBox(parent=self,
- message=("No vector maps available. Check if the location is correct."),
- caption=("Missing Input Data"), style=wx.OK | wx.ICON_ERROR | wx.CENTRE)
- pointVectors = []
- for n in vectors:
- try:
- if grass.vector_info_topo(n)['points'] > 0:
- pointVectors.append(n)
- except KeyError:
- pass # why pass?! it's an error...
- if pointVectors == []:
- message=("No point vector maps available. Check if the location is correct."),
- return sorted(pointVectors)
def OnInputDataChanged(self,event):
""" Refreshes list of columns. """
