[GRASS-SVN] r38003 - in grass/trunk: display/d.colors display/d.colortable display/d.extract display/d.graph display/d.grid display/d.his display/d.histogram display/d.labels display/d.legend display/d.nviz display/d.path display/d.profile display/d.rast display/d.rast.arrow display/d.rast.num display/d.rgb display/d.thematic.area display/d.title display/d.vect display/d.vect.chart display/d.what.rast display/d.zoom doc/raster/r.example general/g.mremove general/g.region general/g.remove general/g.rename general/manage/lister imagery/i.albedo imagery/i.atcorr imagery/i.cca imagery/i.class imagery/i.cluster imagery/i.eb.eta imagery/i.eb.evapfr imagery/i.eb.h_SEBAL01 imagery/i.eb.soilheatflux imagery/i.emissivity imagery/i.evapo.time_integration imagery/i.fft imagery/i.gensig imagery/i.gensigset imagery/i.his.rgb imagery/i.ifft imagery/i.latlong imagery/i.maxlik imagery/i.modis.qc imagery/i.pca imagery/i.points imagery/i.rectify imagery/i.rgb.his imagery/i.smap imagery/i.sunhours imagery/i.vi imagery/i.vpoints imagery/i.zc include include/Make lib lib/cluster lib/display lib/g3d lib/gis lib/gpde lib/nviz lib/ogsf lib/raster lib/rst/interp_float lib/stats ps/ps.map raster/r.basins.fill raster/r.bitpattern raster/r.buffer raster/r.carve raster/r.category raster/r.circle raster/r.clump raster/r.coin raster/r.colors raster/r.colors.out raster/r.composite raster/r.compress raster/r.contour raster/r.cost raster/r.covar raster/r.cross raster/r.describe raster/r.digit raster/r.distance raster/r.drain raster/r.external raster/r.fill.dir raster/r.flow raster/r.grow raster/r.grow.distance raster/r.gwflow raster/r.his raster/r.horizon raster/r.in.arc raster/r.in.ascii raster/r.in.bin raster/r.in.gdal raster/r.in.gridatb raster/r.in.mat raster/r.in.poly raster/r.in.xyz raster/r.info raster/r.kappa raster/r.lake raster/r.le/r.le.patch raster/r.le/r.le.pixel raster/r.le/r.le.setup raster/r.le/r.le.setup/polytocell raster/r.le/r.le.trace raster/r.li/r.li.cwed raster/r.li/r.li.daemon raster/r.li/r.li.dominance raster/r.li/r.li.edgedensity raster/r.li/r.li.mpa raster/r.li/r.li.mps raster/r.li/r.li.padcv raster/r.li/r.li.padrange raster/r.li/r.li.padsd raster/r.li/r.li.patchdensity raster/r.li/r.li.patchnum raster/r.li/r.li.richness raster/r.li/r.li.shannon raster/r.li/r.li.shape raster/r.li/r.li.simpson raster/r.los raster/r.mapcalc raster/r.mfilter raster/r.mode raster/r.neighbors raster/r.null raster/r.out.arc raster/r.out.ascii raster/r.out.bin raster/r.out.gdal raster/r.out.gridatb raster/r.out.mat raster/r.out.mpeg raster/r.out.png raster/r.out.pov raster/r.out.ppm raster/r.out.ppm3 raster/r.out.tiff raster/r.out.vrml raster/r.out.vtk raster/r.param.scale raster/r.patch raster/r.profile raster/r.proj raster/r.quant raster/r.quantile raster/r.random raster/r.random.cells raster/r.random.surface raster/r.reclass raster/r.recode raster/r.region raster/r.report raster/r.resamp.interp raster/r.resamp.rst raster/r.resamp.stats raster/r.resample raster/r.rescale raster/r.rescale.eq raster/r.ros raster/r.series raster/r.slope.aspect raster/r.spread raster/r.spreadpath raster/r.statistics raster/r.statistics2 raster/r.statistics3 raster/r.stats raster/r.sun raster/r.sun2 raster/r.sunmask raster/r.support raster/r.support.stats raster/r.surf.area raster/r.surf.contour raster/r.surf.fractal raster/r.surf.gauss raster/r.surf.idw raster/r.surf.idw2 raster/r.surf.random raster/r.terraflow raster/r.texture raster/r.thin raster/r.to.rast3 raster/r.to.rast3elev raster/r.to.vect raster/r.topidx raster/r.topmodel raster/r.univar raster/r.uslek raster/r.usler raster/r.volume raster/r.walk raster/r.water.outlet raster/r.watershed/front raster/r.watershed/ram raster/r.watershed/seg raster/r.watershed/shed raster/r.what raster/r.what.color raster/simwe/simlib raster3d/r3.cross.rast raster3d/r3.gwflow raster3d/r3.mkdspf raster3d/r3.out.vtk raster3d/r3.to.rast swig/perl/R_slope_aspect/r_slope_aspect vector/lidar/lidarlib vector/lidar/v.lidar.correction vector/lidar/v.lidar.edgedetection vector/lidar/v.lidar.growing vector/lidar/v.outlier vector/lidar/v.surf.bspline vector/v.convert vector/v.drape vector/v.extrude vector/v.kernel vector/v.neighbors vector/v.sample vector/v.surf.idw vector/v.to.rast vector/v.vol.rst vector/v.what.rast visualization/xganim
Sat Jun 20 18:03:27 EDT 2009
Author: martinl
Date: 2009-06-20 18:03:23 -0400 (Sat, 20 Jun 2009)
New Revision: 38003
Added:
   grass/trunk/include/Rast.h
   grass/trunk/lib/raster/
   grass/trunk/lib/raster/G.h
   grass/trunk/lib/raster/adj_cellhd.c
   grass/trunk/lib/raster/alloc_cell.c
   grass/trunk/lib/raster/auto_mask.c
   grass/trunk/lib/raster/cats.c
   grass/trunk/lib/raster/cell_stats.c
   grass/trunk/lib/raster/cell_title.c
   grass/trunk/lib/raster/cellstats_eq.c
   grass/trunk/lib/raster/closecell.c
   grass/trunk/lib/raster/color_compat.c
   grass/trunk/lib/raster/color_free.c
   grass/trunk/lib/raster/color_get.c
   grass/trunk/lib/raster/color_hist.c
   grass/trunk/lib/raster/color_init.c
   grass/trunk/lib/raster/color_insrt.c
   grass/trunk/lib/raster/color_invrt.c
   grass/trunk/lib/raster/color_look.c
   grass/trunk/lib/raster/color_org.c
   grass/trunk/lib/raster/color_rand.c
   grass/trunk/lib/raster/color_range.c
   grass/trunk/lib/raster/color_read.c
   grass/trunk/lib/raster/color_remove.c
   grass/trunk/lib/raster/color_rule.c
   grass/trunk/lib/raster/color_rule_get.c
   grass/trunk/lib/raster/color_rules.c
   grass/trunk/lib/raster/color_set.c
   grass/trunk/lib/raster/color_shift.c
   grass/trunk/lib/raster/color_str.c
   grass/trunk/lib/raster/color_write.c
   grass/trunk/lib/raster/color_xform.c
   grass/trunk/lib/raster/format.c
   grass/trunk/lib/raster/fpreclass.c
   grass/trunk/lib/raster/gdal.c
   grass/trunk/lib/raster/get_cellhd.c
   grass/trunk/lib/raster/get_row.c
   grass/trunk/lib/raster/get_row_colr.c
   grass/trunk/lib/raster/histo_eq.c
   grass/trunk/lib/raster/histogram.c
   grass/trunk/lib/raster/history.c
   grass/trunk/lib/raster/interp.c
   grass/trunk/lib/raster/mask_info.c
   grass/trunk/lib/raster/maskfd.c
   grass/trunk/lib/raster/null_val.c
   grass/trunk/lib/raster/opencell.c
   grass/trunk/lib/raster/put_cellhd.c
   grass/trunk/lib/raster/put_row.c
   grass/trunk/lib/raster/put_title.c
   grass/trunk/lib/raster/quant.c
   grass/trunk/lib/raster/quant_io.c
   grass/trunk/lib/raster/quant_rw.c
   grass/trunk/lib/raster/range.c
   grass/trunk/lib/raster/raster.c
   grass/trunk/lib/raster/raster_metadata.c
   grass/trunk/lib/raster/rd_cellhd.c
   grass/trunk/lib/raster/reclass.c
   grass/trunk/lib/raster/sample.c
   grass/trunk/lib/raster/zero_cell.c
Removed:
   grass/trunk/lib/gis/G.h
   grass/trunk/lib/gis/adj_cellhd.c
   grass/trunk/lib/gis/alloc_cell.c
   grass/trunk/lib/gis/auto_mask.c
   grass/trunk/lib/gis/cats.c
   grass/trunk/lib/gis/cell_stats.c
   grass/trunk/lib/gis/cell_title.c
   grass/trunk/lib/gis/cellstats_eq.c
   grass/trunk/lib/gis/closecell.c
   grass/trunk/lib/gis/color_compat.c
   grass/trunk/lib/gis/color_free.c
   grass/trunk/lib/gis/color_get.c
   grass/trunk/lib/gis/color_hist.c
   grass/trunk/lib/gis/color_init.c
   grass/trunk/lib/gis/color_insrt.c
   grass/trunk/lib/gis/color_invrt.c
   grass/trunk/lib/gis/color_look.c
   grass/trunk/lib/gis/color_org.c
   grass/trunk/lib/gis/color_rand.c
   grass/trunk/lib/gis/color_range.c
   grass/trunk/lib/gis/color_read.c
   grass/trunk/lib/gis/color_remove.c
   grass/trunk/lib/gis/color_rule.c
   grass/trunk/lib/gis/color_rule_get.c
   grass/trunk/lib/gis/color_rules.c
   grass/trunk/lib/gis/color_set.c
   grass/trunk/lib/gis/color_shift.c
   grass/trunk/lib/gis/color_str.c
   grass/trunk/lib/gis/color_write.c
   grass/trunk/lib/gis/color_xform.c
   grass/trunk/lib/gis/format.c
   grass/trunk/lib/gis/fpreclass.c
   grass/trunk/lib/gis/gdal.c
   grass/trunk/lib/gis/get_cellhd.c
   grass/trunk/lib/gis/get_row.c
   grass/trunk/lib/gis/get_row_colr.c
   grass/trunk/lib/gis/histo_eq.c
   grass/trunk/lib/gis/histogram.c
   grass/trunk/lib/gis/history.c
   grass/trunk/lib/gis/interp.c
   grass/trunk/lib/gis/mask_info.c
   grass/trunk/lib/gis/maskfd.c
   grass/trunk/lib/gis/null_val.c
   grass/trunk/lib/gis/opencell.c
   grass/trunk/lib/gis/put_cellhd.c
   grass/trunk/lib/gis/put_row.c
   grass/trunk/lib/gis/put_title.c
   grass/trunk/lib/gis/quant.c
   grass/trunk/lib/gis/quant_io.c
   grass/trunk/lib/gis/quant_rw.c
   grass/trunk/lib/gis/range.c
   grass/trunk/lib/gis/raster.c
   grass/trunk/lib/gis/raster_metadata.c
   grass/trunk/lib/gis/rd_cellhd.c
   grass/trunk/lib/gis/reclass.c
   grass/trunk/lib/gis/sample.c
   grass/trunk/lib/gis/zero_cell.c
   grass/trunk/display/d.colors/curses.c
   grass/trunk/display/d.colors/get_info.c
   grass/trunk/display/d.colors/interact.c
   grass/trunk/display/d.colors/main.c
   grass/trunk/display/d.colors/tbl_toggle.c
   grass/trunk/display/d.colortable/main.c
   grass/trunk/display/d.extract/main.c
   grass/trunk/display/d.graph/do_graph.c
   grass/trunk/display/d.graph/graphics.c
   grass/trunk/display/d.graph/main.c
   grass/trunk/display/d.grid/fiducial.c
   grass/trunk/display/d.grid/main.c
   grass/trunk/display/d.grid/plot.c
   grass/trunk/display/d.grid/plotborder.c
   grass/trunk/display/d.his/his.c
   grass/trunk/display/d.his/main.c
   grass/trunk/display/d.histogram/bar.c
   grass/trunk/display/d.histogram/draw_slice.c
   grass/trunk/display/d.histogram/get_stats.c
   grass/trunk/display/d.histogram/main.c
   grass/trunk/display/d.histogram/pie.c
   grass/trunk/display/d.labels/color.c
   grass/trunk/display/d.labels/do_labels.c
   grass/trunk/display/d.labels/main.c
   grass/trunk/display/d.legend/main.c
   grass/trunk/display/d.nviz/main.c
   grass/trunk/display/d.path/main.c
   grass/trunk/display/d.path/select.c
   grass/trunk/display/d.profile/main.c
   grass/trunk/display/d.rast.arrow/main.c
   grass/trunk/display/d.rast.num/main.c
   grass/trunk/display/d.rast/display.c
   grass/trunk/display/d.rast/main.c
   grass/trunk/display/d.rast/mask.c
   grass/trunk/display/d.rgb/main.c
   grass/trunk/display/d.thematic.area/area.c
   grass/trunk/display/d.thematic.area/main.c
   grass/trunk/display/d.thematic.area/plot1.c
   grass/trunk/display/d.title/fancy.c
   grass/trunk/display/d.title/main.c
   grass/trunk/display/d.title/normal.c
   grass/trunk/display/d.vect.chart/bar.c
   grass/trunk/display/d.vect.chart/main.c
   grass/trunk/display/d.vect.chart/pie.c
   grass/trunk/display/d.vect.chart/plot.c
   grass/trunk/display/d.vect/area.c
   grass/trunk/display/d.vect/attr.c
   grass/trunk/display/d.vect/dir.c
   grass/trunk/display/d.vect/label.c
   grass/trunk/display/d.vect/main.c
   grass/trunk/display/d.vect/plot1.c
   grass/trunk/display/d.vect/topo.c
   grass/trunk/display/d.vect/utils.c
   grass/trunk/display/d.vect/zcoor.c
   grass/trunk/display/d.what.rast/main.c
   grass/trunk/display/d.what.rast/opencell.c
   grass/trunk/display/d.what.rast/show.c
   grass/trunk/display/d.what.rast/what.c
   grass/trunk/display/d.zoom/main.c
   grass/trunk/display/d.zoom/set.c
   grass/trunk/doc/raster/r.example/main.c
   grass/trunk/general/g.mremove/check_reclass.c
   grass/trunk/general/g.mremove/wc2regex.c
   grass/trunk/general/g.region/adjust.c
   grass/trunk/general/g.region/main.c
   grass/trunk/general/g.region/printwindow.c
   grass/trunk/general/g.region/zoom.c
   grass/trunk/general/g.remove/main.c
   grass/trunk/general/g.rename/main.c
   grass/trunk/general/manage/lister/cell.c
   grass/trunk/general/manage/lister/vector.c
   grass/trunk/imagery/i.albedo/main.c
   grass/trunk/imagery/i.atcorr/main.cpp
   grass/trunk/imagery/i.cca/main.c
   grass/trunk/imagery/i.cca/matrix.c
   grass/trunk/imagery/i.cca/stats.c
   grass/trunk/imagery/i.cca/transform.c
   grass/trunk/imagery/i.class/band_files.c
   grass/trunk/imagery/i.class/draw_cell.c
   grass/trunk/imagery/i.class/main.c
   grass/trunk/imagery/i.class/readbands.c
   grass/trunk/imagery/i.class/signature.c
   grass/trunk/imagery/i.cluster/checkpt.c
   grass/trunk/imagery/i.cluster/main.c
   grass/trunk/imagery/i.cluster/open_files.c
   grass/trunk/imagery/i.cluster/print1.c
   grass/trunk/imagery/i.cluster/print2.c
   grass/trunk/imagery/i.cluster/print3.c
   grass/trunk/imagery/i.cluster/print4.c
   grass/trunk/imagery/i.cluster/print5.c
   grass/trunk/imagery/i.cluster/print6.c
   grass/trunk/imagery/i.cluster/timer.c
   grass/trunk/imagery/i.eb.eta/main.c
   grass/trunk/imagery/i.eb.evapfr/main.c
   grass/trunk/imagery/i.eb.h_SEBAL01/main.c
   grass/trunk/imagery/i.eb.soilheatflux/main.c
   grass/trunk/imagery/i.emissivity/main.c
   grass/trunk/imagery/i.evapo.time_integration/main.c
   grass/trunk/imagery/i.fft/main.c
   grass/trunk/imagery/i.gensig/alloc.c
   grass/trunk/imagery/i.gensig/can_invert.c
   grass/trunk/imagery/i.gensig/closefiles.c
   grass/trunk/imagery/i.gensig/covariance.c
   grass/trunk/imagery/i.gensig/eigen.c
   grass/trunk/imagery/i.gensig/get_train.c
   grass/trunk/imagery/i.gensig/labels.c
   grass/trunk/imagery/i.gensig/lookup_class.c
   grass/trunk/imagery/i.gensig/means.c
   grass/trunk/imagery/i.gensig/openfiles.c
   grass/trunk/imagery/i.gensig/parse.c
   grass/trunk/imagery/i.gensig/read_train.c
   grass/trunk/imagery/i.gensigset/closefiles.c
   grass/trunk/imagery/i.gensigset/get_train.c
   grass/trunk/imagery/i.gensigset/invert.c
   grass/trunk/imagery/i.gensigset/labels.c
   grass/trunk/imagery/i.gensigset/lookup_class.c
   grass/trunk/imagery/i.gensigset/main.c
   grass/trunk/imagery/i.gensigset/openfiles.c
   grass/trunk/imagery/i.gensigset/parse.c
   grass/trunk/imagery/i.gensigset/read_data.c
   grass/trunk/imagery/i.gensigset/read_train.c
   grass/trunk/imagery/i.gensigset/subcluster.c
   grass/trunk/imagery/i.his.rgb/closefiles.c
   grass/trunk/imagery/i.his.rgb/his2rgb.c
   grass/trunk/imagery/i.his.rgb/main.c
   grass/trunk/imagery/i.his.rgb/openfiles.c
   grass/trunk/imagery/i.ifft/main.c
   grass/trunk/imagery/i.latlong/main.c
   grass/trunk/imagery/i.maxlik/classify.c
   grass/trunk/imagery/i.maxlik/hist.c
   grass/trunk/imagery/i.maxlik/invert.c
   grass/trunk/imagery/i.maxlik/main.c
   grass/trunk/imagery/i.maxlik/open.c
   grass/trunk/imagery/i.modis.qc/main.c
   grass/trunk/imagery/i.pca/main.c
   grass/trunk/imagery/i.pca/support.c
   grass/trunk/imagery/i.points/cell.c
   grass/trunk/imagery/i.points/drawcell.c
   grass/trunk/imagery/i.points/graphics.c
   grass/trunk/imagery/i.points/main.c
   grass/trunk/imagery/i.rectify/crs.c
   grass/trunk/imagery/i.rectify/exec.c
   grass/trunk/imagery/i.rectify/main.c
   grass/trunk/imagery/i.rectify/perform.c
   grass/trunk/imagery/i.rectify/rectify.c
   grass/trunk/imagery/i.rectify/write.c
   grass/trunk/imagery/i.rgb.his/closefiles.c
   grass/trunk/imagery/i.rgb.his/main.c
   grass/trunk/imagery/i.rgb.his/openfiles.c
   grass/trunk/imagery/i.rgb.his/rgb2his.c
   grass/trunk/imagery/i.smap/closefiles.c
   grass/trunk/imagery/i.smap/decimate.c
   grass/trunk/imagery/i.smap/history.c
   grass/trunk/imagery/i.smap/interp.c
   grass/trunk/imagery/i.smap/invert.c
   grass/trunk/imagery/i.smap/labels.c
   grass/trunk/imagery/i.smap/model.c
   grass/trunk/imagery/i.smap/multialloc.c
   grass/trunk/imagery/i.smap/opencell.c
   grass/trunk/imagery/i.smap/openfiles.c
   grass/trunk/imagery/i.smap/parse.c
   grass/trunk/imagery/i.smap/read_block.c
   grass/trunk/imagery/i.smap/write_img.c
   grass/trunk/imagery/i.sunhours/main.c
   grass/trunk/imagery/i.vi/main.c
   grass/trunk/imagery/i.vpoints/cell.c
   grass/trunk/imagery/i.vpoints/colors.c
   grass/trunk/imagery/i.vpoints/drawcell.c
   grass/trunk/imagery/i.vpoints/graphics.c
   grass/trunk/imagery/i.vpoints/main.c
   grass/trunk/imagery/i.zc/main.c
   grass/trunk/include/Make/Grass.make
   grass/trunk/include/arraystats.h
   grass/trunk/include/cluster.h
   grass/trunk/include/gis.h
   grass/trunk/include/gisdefs.h
   grass/trunk/include/nviz.h
   grass/trunk/include/vedit.h
   grass/trunk/lib/Makefile
   grass/trunk/lib/cluster/c_point.c
   grass/trunk/lib/display/raster.c
   grass/trunk/lib/display/raster2.c
   grass/trunk/lib/display/tran_colr.c
   grass/trunk/lib/g3d/g3dcats.c
   grass/trunk/lib/g3d/g3dclose.c
   grass/trunk/lib/g3d/g3dcolor.c
   grass/trunk/lib/g3d/g3dfpxdr.c
   grass/trunk/lib/g3d/g3dhistory.c
   grass/trunk/lib/g3d/g3dmisc.c
   grass/trunk/lib/g3d/g3dnull.c
   grass/trunk/lib/g3d/g3drange.c
   grass/trunk/lib/g3d/g3dregion.c
   grass/trunk/lib/g3d/g3dvolume.c
   grass/trunk/lib/g3d/getblock.c
   grass/trunk/lib/g3d/tileread.c
   grass/trunk/lib/g3d/tilewrite.c
   grass/trunk/lib/gis/Makefile
   grass/trunk/lib/gis/align_window.c
   grass/trunk/lib/gis/debug.c
   grass/trunk/lib/gis/get_window.c
   grass/trunk/lib/gis/gisinit.c
   grass/trunk/lib/gis/set_window.c
   grass/trunk/lib/gis/window_map.c
   grass/trunk/lib/gpde/N_arrays.c
   grass/trunk/lib/gpde/N_arrays_calc.c
   grass/trunk/lib/gpde/N_arrays_io.c
   grass/trunk/lib/nviz/nviz.c
   grass/trunk/lib/ogsf/GS2.c
   grass/trunk/lib/ogsf/Gp3.c
   grass/trunk/lib/ogsf/Gs3.c
   grass/trunk/lib/ogsf/Gvl3.c
   grass/trunk/lib/ogsf/gsd_legend.c
   grass/trunk/lib/rst/interp_float/input2d.c
   grass/trunk/lib/rst/interp_float/interp2d.c
   grass/trunk/lib/rst/interp_float/output2d.c
   grass/trunk/lib/rst/interp_float/resout2d.c
   grass/trunk/lib/rst/interp_float/ressegm2d.c
   grass/trunk/lib/stats/c_ave.c
   grass/trunk/lib/stats/c_count.c
   grass/trunk/lib/stats/c_intr.c
   grass/trunk/lib/stats/c_kurt.c
   grass/trunk/lib/stats/c_max.c
   grass/trunk/lib/stats/c_maxx.c
   grass/trunk/lib/stats/c_median.c
   grass/trunk/lib/stats/c_min.c
   grass/trunk/lib/stats/c_minx.c
   grass/trunk/lib/stats/c_mode.c
   grass/trunk/lib/stats/c_percentile.c
   grass/trunk/lib/stats/c_range.c
   grass/trunk/lib/stats/c_reg.c
   grass/trunk/lib/stats/c_skew.c
   grass/trunk/lib/stats/c_stddev.c
   grass/trunk/lib/stats/c_sum.c
   grass/trunk/lib/stats/c_var.c
   grass/trunk/lib/stats/sort_cell.c
   grass/trunk/ps/ps.map/catval.c
   grass/trunk/ps/ps.map/distance.c
   grass/trunk/ps/ps.map/do_geogrid.c
   grass/trunk/ps/ps.map/do_header.c
   grass/trunk/ps/ps.map/do_labels.c
   grass/trunk/ps/ps.map/do_masking.c
   grass/trunk/ps/ps.map/do_plt.c
   grass/trunk/ps/ps.map/do_psfiles.c
   grass/trunk/ps/ps.map/do_vectors.c
   grass/trunk/ps/ps.map/error.c
   grass/trunk/ps/ps.map/get_font.c
   grass/trunk/ps/ps.map/input.c
   grass/trunk/ps/ps.map/main.c
   grass/trunk/ps/ps.map/makeprocs.c
   grass/trunk/ps/ps.map/map_setup.c
   grass/trunk/ps/ps.map/outl_io.c
   grass/trunk/ps/ps.map/parse_list.c
   grass/trunk/ps/ps.map/ps_clrtbl.c
   grass/trunk/ps/ps.map/ps_fclrtbl.c
   grass/trunk/ps/ps.map/ps_header.c
   grass/trunk/ps/ps.map/ps_info.h
   grass/trunk/ps/ps.map/ps_outline.c
   grass/trunk/ps/ps.map/ps_raster.c
   grass/trunk/ps/ps.map/ps_vareas.c
   grass/trunk/ps/ps.map/ps_vlines.c
   grass/trunk/ps/ps.map/ps_vpoints.c
   grass/trunk/ps/ps.map/r_border.c
   grass/trunk/ps/ps.map/r_cell.c
   grass/trunk/ps/ps.map/r_colortable.c
   grass/trunk/ps/ps.map/r_group.c
   grass/trunk/ps/ps.map/r_labels.c
   grass/trunk/ps/ps.map/r_plt.c
   grass/trunk/ps/ps.map/r_rgb.c
   grass/trunk/ps/ps.map/r_text.c
   grass/trunk/ps/ps.map/r_vareas.c
   grass/trunk/ps/ps.map/r_vlines.c
   grass/trunk/ps/ps.map/r_vpoints.c
   grass/trunk/ps/ps.map/r_wind.c
   grass/trunk/ps/ps.map/read_cfg.c
   grass/trunk/ps/ps.map/scale.c
   grass/trunk/ps/ps.map/scan_gis.c
   grass/trunk/ps/ps.map/session.c
   grass/trunk/ps/ps.map/vect.c
   grass/trunk/ps/ps.map/vector.c
   grass/trunk/raster/r.basins.fill/main.c
   grass/trunk/raster/r.basins.fill/read_map.c
   grass/trunk/raster/r.bitpattern/main.c
   grass/trunk/raster/r.buffer/distance.h
   grass/trunk/raster/r.buffer/find_dist.c
   grass/trunk/raster/r.buffer/init.c
   grass/trunk/raster/r.buffer/main.c
   grass/trunk/raster/r.buffer/read_map.c
   grass/trunk/raster/r.buffer/support.c
   grass/trunk/raster/r.buffer/write_map.c
   grass/trunk/raster/r.carve/enforce.h
   grass/trunk/raster/r.carve/enforce_ds.c
   grass/trunk/raster/r.carve/main.c
   grass/trunk/raster/r.carve/raster.c
   grass/trunk/raster/r.carve/support.c
   grass/trunk/raster/r.carve/vect.c
   grass/trunk/raster/r.category/cats.c
   grass/trunk/raster/r.category/main.c
   grass/trunk/raster/r.circle/main.c
   grass/trunk/raster/r.clump/clump.c
   grass/trunk/raster/r.clump/main.c
   grass/trunk/raster/r.coin/coin.h
   grass/trunk/raster/r.coin/main.c
   grass/trunk/raster/r.coin/make_coin.c
   grass/trunk/raster/r.coin/print_hdr.c
   grass/trunk/raster/r.colors.out/main.c
   grass/trunk/raster/r.colors/local_proto.h
   grass/trunk/raster/r.colors/main.c
   grass/trunk/raster/r.colors/rules.c
   grass/trunk/raster/r.colors/stats.c
   grass/trunk/raster/r.composite/main.c
   grass/trunk/raster/r.compress/main.c
   grass/trunk/raster/r.contour/cont.c
   grass/trunk/raster/r.contour/main.c
   grass/trunk/raster/r.cost/btree.c
   grass/trunk/raster/r.cost/main.c
   grass/trunk/raster/r.cost/memory.c
   grass/trunk/raster/r.covar/main.c
   grass/trunk/raster/r.cross/cats.c
   grass/trunk/raster/r.cross/cross.c
   grass/trunk/raster/r.cross/glob.h
   grass/trunk/raster/r.cross/main.c
   grass/trunk/raster/r.cross/renumber.c
   grass/trunk/raster/r.describe/describe.c
   grass/trunk/raster/r.describe/dumplist.c
   grass/trunk/raster/r.describe/main.c
   grass/trunk/raster/r.describe/tree.c
   grass/trunk/raster/r.digit/digitize.c
   grass/trunk/raster/r.digit/get_label.c
   grass/trunk/raster/r.distance/defs.h
   grass/trunk/raster/r.distance/distance.c
   grass/trunk/raster/r.distance/edges.c
   grass/trunk/raster/r.distance/labels.c
   grass/trunk/raster/r.distance/main.c
   grass/trunk/raster/r.distance/parse.c
   grass/trunk/raster/r.drain/filldir.c
   grass/trunk/raster/r.drain/main.c
   grass/trunk/raster/r.drain/resolve.c
   grass/trunk/raster/r.drain/tinf.c
   grass/trunk/raster/r.external/main.c
   grass/trunk/raster/r.fill.dir/dopolys.c
   grass/trunk/raster/r.fill.dir/filldir.c
   grass/trunk/raster/r.fill.dir/main.c
   grass/trunk/raster/r.fill.dir/ppupdate.c
   grass/trunk/raster/r.fill.dir/resolve.c
   grass/trunk/raster/r.fill.dir/tinf.c
   grass/trunk/raster/r.fill.dir/wtrshed.c
   grass/trunk/raster/r.flow/aspect.c
   grass/trunk/raster/r.flow/aspect.h
   grass/trunk/raster/r.flow/io.c
   grass/trunk/raster/r.flow/io.h
   grass/trunk/raster/r.flow/main.c
   grass/trunk/raster/r.flow/mem.c
   grass/trunk/raster/r.flow/mem.h
   grass/trunk/raster/r.flow/precomp.c
   grass/trunk/raster/r.flow/r.flow.h
   grass/trunk/raster/r.grow.distance/main.c
   grass/trunk/raster/r.grow/main.c
   grass/trunk/raster/r.gwflow/main.c
   grass/trunk/raster/r.his/his.c
   grass/trunk/raster/r.his/main.c
   grass/trunk/raster/r.horizon/main.c
   grass/trunk/raster/r.in.arc/gethead.c
   grass/trunk/raster/r.in.arc/main.c
   grass/trunk/raster/r.in.ascii/gethead.c
   grass/trunk/raster/r.in.ascii/main.c
   grass/trunk/raster/r.in.bin/main.c
   grass/trunk/raster/r.in.gdal/main.c
   grass/trunk/raster/r.in.gridatb/file_io.c
   grass/trunk/raster/r.in.gridatb/local_proto.h
   grass/trunk/raster/r.in.gridatb/main.c
   grass/trunk/raster/r.in.mat/main.c
   grass/trunk/raster/r.in.poly/get_item.c
   grass/trunk/raster/r.in.poly/getformat.c
   grass/trunk/raster/r.in.poly/main.c
   grass/trunk/raster/r.in.poly/poly2rast.c
   grass/trunk/raster/r.in.poly/raster.c
   grass/trunk/raster/r.in.xyz/local_proto.h
   grass/trunk/raster/r.in.xyz/main.c
   grass/trunk/raster/r.in.xyz/support.c
   grass/trunk/raster/r.info/main.c
   grass/trunk/raster/r.info/reclas_txt.c
   grass/trunk/raster/r.kappa/calc_kappa.c
   grass/trunk/raster/r.kappa/kappa.h
   grass/trunk/raster/r.kappa/main.c
   grass/trunk/raster/r.kappa/mask.c
   grass/trunk/raster/r.kappa/prt_hdr.c
   grass/trunk/raster/r.kappa/prt_label.c
   grass/trunk/raster/r.kappa/prt_mat.c
   grass/trunk/raster/r.kappa/stats.c
   grass/trunk/raster/r.lake/main.c
   grass/trunk/raster/r.le/r.le.patch/driver.c
   grass/trunk/raster/r.le/r.le.patch/patch.h
   grass/trunk/raster/r.le/r.le.patch/trace.c
   grass/trunk/raster/r.le/r.le.pixel/cellclip.c
   grass/trunk/raster/r.le/r.le.pixel/driver.c
   grass/trunk/raster/r.le/r.le.pixel/pixel.h
   grass/trunk/raster/r.le/r.le.pixel/texture.c
   grass/trunk/raster/r.le/r.le.setup/mv_wind.c
   grass/trunk/raster/r.le/r.le.setup/polytocell/bmf_to_cll.c
   grass/trunk/raster/r.le/r.le.setup/sample.c
   grass/trunk/raster/r.le/r.le.setup/setup.c
   grass/trunk/raster/r.le/r.le.setup/setup.h
   grass/trunk/raster/r.le/r.le.trace/main.c
   grass/trunk/raster/r.le/r.le.trace/r.le.trace.h
   grass/trunk/raster/r.li/r.li.cwed/cwed.c
   grass/trunk/raster/r.li/r.li.cwed/utility.c
   grass/trunk/raster/r.li/r.li.daemon/GenericCell.h
   grass/trunk/raster/r.li/r.li.daemon/avl.c
   grass/trunk/raster/r.li/r.li.daemon/avlID.c
   grass/trunk/raster/r.li/r.li.daemon/daemon.c
   grass/trunk/raster/r.li/r.li.daemon/daemon.h
   grass/trunk/raster/r.li/r.li.daemon/ipc.c
   grass/trunk/raster/r.li/r.li.daemon/list.c
   grass/trunk/raster/r.li/r.li.daemon/worker.c
   grass/trunk/raster/r.li/r.li.dominance/dominance.c
   grass/trunk/raster/r.li/r.li.edgedensity/edgedensity.c
   grass/trunk/raster/r.li/r.li.mpa/mpa.c
   grass/trunk/raster/r.li/r.li.mps/mps.c
   grass/trunk/raster/r.li/r.li.padcv/padcv.c
   grass/trunk/raster/r.li/r.li.padrange/padrange.c
   grass/trunk/raster/r.li/r.li.padsd/padsd.c
   grass/trunk/raster/r.li/r.li.patchdensity/main.c
   grass/trunk/raster/r.li/r.li.patchnum/main.c
   grass/trunk/raster/r.li/r.li.richness/richness.c
   grass/trunk/raster/r.li/r.li.shannon/shannon.c
   grass/trunk/raster/r.li/r.li.shape/main.c
   grass/trunk/raster/r.li/r.li.simpson/simpson.c
   grass/trunk/raster/r.los/delete.c
   grass/trunk/raster/r.los/main.c
   grass/trunk/raster/r.los/make_list.c
   grass/trunk/raster/r.los/make_point.c
   grass/trunk/raster/r.los/mark_pts.c
   grass/trunk/raster/r.los/pts_elim.c
   grass/trunk/raster/r.los/radians.h
   grass/trunk/raster/r.mapcalc/column_shift.c
   grass/trunk/raster/r.mapcalc/evaluate.c
   grass/trunk/raster/r.mapcalc/expression.c
   grass/trunk/raster/r.mapcalc/expression.h
   grass/trunk/raster/r.mapcalc/map.c
   grass/trunk/raster/r.mapcalc/map3.c
   grass/trunk/raster/r.mapcalc/mapcalc.h
   grass/trunk/raster/r.mapcalc/xabs.c
   grass/trunk/raster/r.mapcalc/xacos.c
   grass/trunk/raster/r.mapcalc/xadd.c
   grass/trunk/raster/r.mapcalc/xand.c
   grass/trunk/raster/r.mapcalc/xand2.c
   grass/trunk/raster/r.mapcalc/xasin.c
   grass/trunk/raster/r.mapcalc/xatan.c
   grass/trunk/raster/r.mapcalc/xbitand.c
   grass/trunk/raster/r.mapcalc/xbitnot.c
   grass/trunk/raster/r.mapcalc/xbitor.c
   grass/trunk/raster/r.mapcalc/xbitxor.c
   grass/trunk/raster/r.mapcalc/xcoor.c
   grass/trunk/raster/r.mapcalc/xcoor3.c
   grass/trunk/raster/r.mapcalc/xcos.c
   grass/trunk/raster/r.mapcalc/xdiv.c
   grass/trunk/raster/r.mapcalc/xdouble.c
   grass/trunk/raster/r.mapcalc/xeq.c
   grass/trunk/raster/r.mapcalc/xeval.c
   grass/trunk/raster/r.mapcalc/xexp.c
   grass/trunk/raster/r.mapcalc/xfloat.c
   grass/trunk/raster/r.mapcalc/xge.c
   grass/trunk/raster/r.mapcalc/xgraph.c
   grass/trunk/raster/r.mapcalc/xgt.c
   grass/trunk/raster/r.mapcalc/xif.c
   grass/trunk/raster/r.mapcalc/xint.c
   grass/trunk/raster/r.mapcalc/xisnull.c
   grass/trunk/raster/r.mapcalc/xle.c
   grass/trunk/raster/r.mapcalc/xlog.c
   grass/trunk/raster/r.mapcalc/xlt.c
   grass/trunk/raster/r.mapcalc/xmax.c
   grass/trunk/raster/r.mapcalc/xmedian.c
   grass/trunk/raster/r.mapcalc/xmin.c
   grass/trunk/raster/r.mapcalc/xmod.c
   grass/trunk/raster/r.mapcalc/xmode.c
   grass/trunk/raster/r.mapcalc/xmul.c
   grass/trunk/raster/r.mapcalc/xne.c
   grass/trunk/raster/r.mapcalc/xneg.c
   grass/trunk/raster/r.mapcalc/xnot.c
   grass/trunk/raster/r.mapcalc/xnull.c
   grass/trunk/raster/r.mapcalc/xor.c
   grass/trunk/raster/r.mapcalc/xor2.c
   grass/trunk/raster/r.mapcalc/xpow.c
   grass/trunk/raster/r.mapcalc/xrand.c
   grass/trunk/raster/r.mapcalc/xres.c
   grass/trunk/raster/r.mapcalc/xres3.c
   grass/trunk/raster/r.mapcalc/xround.c
   grass/trunk/raster/r.mapcalc/xrowcol.c
   grass/trunk/raster/r.mapcalc/xshiftl.c
   grass/trunk/raster/r.mapcalc/xshiftr.c
   grass/trunk/raster/r.mapcalc/xshiftru.c
   grass/trunk/raster/r.mapcalc/xsin.c
   grass/trunk/raster/r.mapcalc/xsqrt.c
   grass/trunk/raster/r.mapcalc/xsub.c
   grass/trunk/raster/r.mapcalc/xtan.c
   grass/trunk/raster/r.mfilter/apply.c
   grass/trunk/raster/r.mfilter/execute.c
   grass/trunk/raster/r.mfilter/filter.h
   grass/trunk/raster/r.mfilter/getrow.c
   grass/trunk/raster/r.mfilter/main.c
   grass/trunk/raster/r.mfilter/perform.c
   grass/trunk/raster/r.mode/main.c
   grass/trunk/raster/r.mode/read_stats.c
   grass/trunk/raster/r.neighbors/bufs.c
   grass/trunk/raster/r.neighbors/divr_cats.c
   grass/trunk/raster/r.neighbors/gather.c
   grass/trunk/raster/r.neighbors/intr_cats.c
   grass/trunk/raster/r.neighbors/main.c
   grass/trunk/raster/r.neighbors/null_cats.c
   grass/trunk/raster/r.neighbors/readcell.c
   grass/trunk/raster/r.neighbors/readweights.c
   grass/trunk/raster/r.null/main.c
   grass/trunk/raster/r.null/mask.c
   grass/trunk/raster/r.out.arc/main.c
   grass/trunk/raster/r.out.ascii/formspecific.c
   grass/trunk/raster/r.out.ascii/main.c
   grass/trunk/raster/r.out.bin/main.c
   grass/trunk/raster/r.out.gdal/export_band.c
   grass/trunk/raster/r.out.gdal/main.c
   grass/trunk/raster/r.out.gridatb/file_io.c
   grass/trunk/raster/r.out.gridatb/local_proto.h
   grass/trunk/raster/r.out.gridatb/main.c
   grass/trunk/raster/r.out.mat/main.c
   grass/trunk/raster/r.out.mpeg/main.c
   grass/trunk/raster/r.out.mpeg/write.c
   grass/trunk/raster/r.out.png/main.c
   grass/trunk/raster/r.out.pov/main.c
   grass/trunk/raster/r.out.ppm/main.c
   grass/trunk/raster/r.out.ppm3/main.c
   grass/trunk/raster/r.out.tiff/main.c
   grass/trunk/raster/r.out.vrml/main.c
   grass/trunk/raster/r.out.vrml/put_grid.c
   grass/trunk/raster/r.out.vrml/pv.h
   grass/trunk/raster/r.out.vtk/main.c
   grass/trunk/raster/r.out.vtk/parameters.c
   grass/trunk/raster/r.out.vtk/writeascii.c
   grass/trunk/raster/r.param.scale/close_down.c
   grass/trunk/raster/r.param.scale/interface.c
   grass/trunk/raster/r.param.scale/nrutil.c
   grass/trunk/raster/r.param.scale/open_files.c
   grass/trunk/raster/r.param.scale/param.h
   grass/trunk/raster/r.param.scale/process.c
   grass/trunk/raster/r.param.scale/write_cats.c
   grass/trunk/raster/r.param.scale/write_cols.c
   grass/trunk/raster/r.patch/do_patch.c
   grass/trunk/raster/r.patch/main.c
   grass/trunk/raster/r.patch/support.c
   grass/trunk/raster/r.profile/local_proto.h
   grass/trunk/raster/r.profile/main.c
   grass/trunk/raster/r.profile/read_rast.c
   grass/trunk/raster/r.proj/bilinear.c
   grass/trunk/raster/r.proj/bilinear_f.c
   grass/trunk/raster/r.proj/bordwalk.c
   grass/trunk/raster/r.proj/cubic.c
   grass/trunk/raster/r.proj/cubic_f.c
   grass/trunk/raster/r.proj/main.c
   grass/trunk/raster/r.proj/nearest.c
   grass/trunk/raster/r.proj/readcell.c
   grass/trunk/raster/r.quant/global.h
   grass/trunk/raster/r.quant/main.c
   grass/trunk/raster/r.quant/read_rules.c
   grass/trunk/raster/r.quantile/main.c
   grass/trunk/raster/r.random.cells/flag.c
   grass/trunk/raster/r.random.cells/indep.c
   grass/trunk/raster/r.random.cells/init.c
   grass/trunk/raster/r.random.cells/main.c
   grass/trunk/raster/r.random.cells/random.c
   grass/trunk/raster/r.random.cells/ransurf.h
   grass/trunk/raster/r.random.surface/calcsurf.c
   grass/trunk/raster/r.random.surface/gennorm.c
   grass/trunk/raster/r.random.surface/init.c
   grass/trunk/raster/r.random.surface/main.c
   grass/trunk/raster/r.random.surface/random.c
   grass/trunk/raster/r.random.surface/ransurf.h
   grass/trunk/raster/r.random.surface/save.c
   grass/trunk/raster/r.random/count.c
   grass/trunk/raster/r.random/main.c
   grass/trunk/raster/r.random/random.c
   grass/trunk/raster/r.random/support.c
   grass/trunk/raster/r.reclass/input.c
   grass/trunk/raster/r.reclass/main.c
   grass/trunk/raster/r.reclass/parse.c
   grass/trunk/raster/r.reclass/range.c
   grass/trunk/raster/r.reclass/reclass.c
   grass/trunk/raster/r.reclass/rule.h
   grass/trunk/raster/r.reclass/stats.c
   grass/trunk/raster/r.recode/global.h
   grass/trunk/raster/r.recode/main.c
   grass/trunk/raster/r.recode/read_rules.c
   grass/trunk/raster/r.recode/recode.c
   grass/trunk/raster/r.region/main.c
   grass/trunk/raster/r.report/global.h
   grass/trunk/raster/r.report/header.c
   grass/trunk/raster/r.report/maskinfo.c
   grass/trunk/raster/r.report/parse.c
   grass/trunk/raster/r.report/prt_report.c
   grass/trunk/raster/r.report/stats.c
   grass/trunk/raster/r.resamp.interp/main.c
   grass/trunk/raster/r.resamp.rst/main.c
   grass/trunk/raster/r.resamp.stats/main.c
   grass/trunk/raster/r.resample/main.c
   grass/trunk/raster/r.rescale.eq/get_range.c
   grass/trunk/raster/r.rescale.eq/get_stats.c
   grass/trunk/raster/r.rescale.eq/main.c
   grass/trunk/raster/r.rescale/get_range.c
   grass/trunk/raster/r.rescale/main.c
   grass/trunk/raster/r.ros/main.c
   grass/trunk/raster/r.ros/spot_dist.c
   grass/trunk/raster/r.series/main.c
   grass/trunk/raster/r.slope.aspect/main.c
   grass/trunk/raster/r.slope.aspect/opennew.c
   grass/trunk/raster/r.spread/collect_ori.c
   grass/trunk/raster/r.spread/display.c
   grass/trunk/raster/r.spread/insert2Ha.c
   grass/trunk/raster/r.spread/main.c
   grass/trunk/raster/r.spread/ram2out.c
   grass/trunk/raster/r.spread/replaceHa.c
   grass/trunk/raster/r.spread/select_linksB.c
   grass/trunk/raster/r.spread/spot.c
   grass/trunk/raster/r.spread/spread.c
   grass/trunk/raster/r.spreadpath/insert.c
   grass/trunk/raster/r.spreadpath/main.c
   grass/trunk/raster/r.statistics/main.c
   grass/trunk/raster/r.statistics/o_adev.c
   grass/trunk/raster/r.statistics/o_average.c
   grass/trunk/raster/r.statistics/o_distrib.c
   grass/trunk/raster/r.statistics/o_divr.c
   grass/trunk/raster/r.statistics/o_kurt.c
   grass/trunk/raster/r.statistics/o_max.c
   grass/trunk/raster/r.statistics/o_median.c
   grass/trunk/raster/r.statistics/o_min.c
   grass/trunk/raster/r.statistics/o_mode.c
   grass/trunk/raster/r.statistics/o_sdev.c
   grass/trunk/raster/r.statistics/o_skew.c
   grass/trunk/raster/r.statistics/o_sum.c
   grass/trunk/raster/r.statistics/o_var.c
   grass/trunk/raster/r.statistics/read_stats.c
   grass/trunk/raster/r.statistics2/main.c
   grass/trunk/raster/r.statistics3/main.c
   grass/trunk/raster/r.stats/cell_stats.c
   grass/trunk/raster/r.stats/global.h
   grass/trunk/raster/r.stats/main.c
   grass/trunk/raster/r.stats/raw_stats.c
   grass/trunk/raster/r.stats/stats.c
   grass/trunk/raster/r.sun/main.c
   grass/trunk/raster/r.sun2/main.c
   grass/trunk/raster/r.sun2/rsunlib.c
   grass/trunk/raster/r.sunmask/g_solposition.c
   grass/trunk/raster/r.sunmask/main.c
   grass/trunk/raster/r.sunmask/solpos00.c
   grass/trunk/raster/r.support.stats/check.c
   grass/trunk/raster/r.support.stats/histo.c
   grass/trunk/raster/r.support.stats/main.c
   grass/trunk/raster/r.support/check.c
   grass/trunk/raster/r.support/histo.c
   grass/trunk/raster/r.support/main.c
   grass/trunk/raster/r.surf.area/main.c
   grass/trunk/raster/r.surf.contour/contour.h
   grass/trunk/raster/r.surf.contour/flag_create.c
   grass/trunk/raster/r.surf.contour/flag_destroy.c
   grass/trunk/raster/r.surf.contour/main.c
   grass/trunk/raster/r.surf.contour/read_cell.c
   grass/trunk/raster/r.surf.fractal/frac.h
   grass/trunk/raster/r.surf.fractal/spec_syn.c
   grass/trunk/raster/r.surf.fractal/write_rast.c
   grass/trunk/raster/r.surf.gauss/gaussurf.c
   grass/trunk/raster/r.surf.gauss/main.c
   grass/trunk/raster/r.surf.idw/dist.c
   grass/trunk/raster/r.surf.idw/ll.c
   grass/trunk/raster/r.surf.idw/main.c
   grass/trunk/raster/r.surf.idw/pi.h
   grass/trunk/raster/r.surf.idw2/main.c
   grass/trunk/raster/r.surf.idw2/read_cell.c
   grass/trunk/raster/r.surf.random/main.c
   grass/trunk/raster/r.surf.random/randsurf.c
   grass/trunk/raster/r.terraflow/common.h
   grass/trunk/raster/r.terraflow/grass2str.h
   grass/trunk/raster/r.terraflow/main.cc
   grass/trunk/raster/r.texture/h_measure.c
   grass/trunk/raster/r.texture/main.c
   grass/trunk/raster/r.thin/io.c
   grass/trunk/raster/r.thin/main.c
   grass/trunk/raster/r.thin/thin_lines.c
   grass/trunk/raster/r.to.rast3/main.c
   grass/trunk/raster/r.to.rast3elev/main.c
   grass/trunk/raster/r.to.vect/areas.c
   grass/trunk/raster/r.to.vect/areas_io.c
   grass/trunk/raster/r.to.vect/lines.c
   grass/trunk/raster/r.to.vect/lines_io.c
   grass/trunk/raster/r.to.vect/main.c
   grass/trunk/raster/r.to.vect/points.c
   grass/trunk/raster/r.to.vect/util.c
   grass/trunk/raster/r.topidx/file_io.c
   grass/trunk/raster/r.topidx/global.h
   grass/trunk/raster/r.topidx/main.c
   grass/trunk/raster/r.topidx/topidx.c
   grass/trunk/raster/r.topmodel/file_io.c
   grass/trunk/raster/r.topmodel/global.h
   grass/trunk/raster/r.topmodel/infiltration.c
   grass/trunk/raster/r.topmodel/topmodel.c
   grass/trunk/raster/r.univar/globals.h
   grass/trunk/raster/r.univar/r.univar_main.c
   grass/trunk/raster/r.uslek/main.c
   grass/trunk/raster/r.usler/main.c
   grass/trunk/raster/r.volume/centroids.c
   grass/trunk/raster/r.volume/main.c
   grass/trunk/raster/r.walk/btree.c
   grass/trunk/raster/r.walk/main.c
   grass/trunk/raster/r.walk/memory.c
   grass/trunk/raster/r.water.outlet/basin.h
   grass/trunk/raster/r.water.outlet/flag_create.c
   grass/trunk/raster/r.water.outlet/flag_destroy.c
   grass/trunk/raster/r.water.outlet/main.c
   grass/trunk/raster/r.watershed/front/main.c
   grass/trunk/raster/r.watershed/ram/Gwater.h
   grass/trunk/raster/r.watershed/ram/close_maps.c
   grass/trunk/raster/r.watershed/ram/close_maps2.c
   grass/trunk/raster/r.watershed/ram/do_astar.c
   grass/trunk/raster/r.watershed/ram/do_cum.c
   grass/trunk/raster/r.watershed/ram/flag_create.c
   grass/trunk/raster/r.watershed/ram/flag_destroy.c
   grass/trunk/raster/r.watershed/ram/init_vars.c
   grass/trunk/raster/r.watershed/ram/main.c
   grass/trunk/raster/r.watershed/ram/sg_factor.c
   grass/trunk/raster/r.watershed/ram/usage.c
   grass/trunk/raster/r.watershed/seg/Gwater.h
   grass/trunk/raster/r.watershed/seg/bseg_close.c
   grass/trunk/raster/r.watershed/seg/bseg_get.c
   grass/trunk/raster/r.watershed/seg/bseg_open.c
   grass/trunk/raster/r.watershed/seg/bseg_put.c
   grass/trunk/raster/r.watershed/seg/bseg_read.c
   grass/trunk/raster/r.watershed/seg/bseg_write.c
   grass/trunk/raster/r.watershed/seg/close_maps.c
   grass/trunk/raster/r.watershed/seg/close_maps2.c
   grass/trunk/raster/r.watershed/seg/cseg_close.c
   grass/trunk/raster/r.watershed/seg/cseg_get.c
   grass/trunk/raster/r.watershed/seg/cseg_open.c
   grass/trunk/raster/r.watershed/seg/cseg_put.c
   grass/trunk/raster/r.watershed/seg/cseg_read.c
   grass/trunk/raster/r.watershed/seg/cseg_write.c
   grass/trunk/raster/r.watershed/seg/do_astar.c
   grass/trunk/raster/r.watershed/seg/do_cum.c
   grass/trunk/raster/r.watershed/seg/dseg_close.c
   grass/trunk/raster/r.watershed/seg/dseg_get.c
   grass/trunk/raster/r.watershed/seg/dseg_open.c
   grass/trunk/raster/r.watershed/seg/dseg_put.c
   grass/trunk/raster/r.watershed/seg/dseg_read.c
   grass/trunk/raster/r.watershed/seg/dseg_write.c
   grass/trunk/raster/r.watershed/seg/init_vars.c
   grass/trunk/raster/r.watershed/seg/main.c
   grass/trunk/raster/r.watershed/seg/sg_factor.c
   grass/trunk/raster/r.watershed/seg/sseg_close.c
   grass/trunk/raster/r.watershed/seg/sseg_get.c
   grass/trunk/raster/r.watershed/seg/sseg_open.c
   grass/trunk/raster/r.watershed/seg/sseg_put.c
   grass/trunk/raster/r.watershed/seg/usage.c
   grass/trunk/raster/r.watershed/shed/print.c
   grass/trunk/raster/r.watershed/shed/read.c
   grass/trunk/raster/r.watershed/shed/valid.c
   grass/trunk/raster/r.watershed/shed/watershed.h
   grass/trunk/raster/r.what.color/main.c
   grass/trunk/raster/r.what/main.c
   grass/trunk/raster/simwe/simlib/input.c
   grass/trunk/raster/simwe/simlib/output.c
   grass/trunk/raster3d/r3.cross.rast/main.c
   grass/trunk/raster3d/r3.gwflow/main.c
   grass/trunk/raster3d/r3.mkdspf/calc_linefax.c
   grass/trunk/raster3d/r3.mkdspf/iso_surface.c
   grass/trunk/raster3d/r3.mkdspf/main.c
   grass/trunk/raster3d/r3.mkdspf/r3_find.c
   grass/trunk/raster3d/r3.out.vtk/errorHandling.c
   grass/trunk/raster3d/r3.out.vtk/main.c
   grass/trunk/raster3d/r3.out.vtk/parameters.c
   grass/trunk/raster3d/r3.out.vtk/writeVTKData.c
   grass/trunk/raster3d/r3.out.vtk/writeVTKHead.c
   grass/trunk/raster3d/r3.to.rast/main.c
   grass/trunk/swig/perl/R_slope_aspect/r_slope_aspect/opennew.c
   grass/trunk/swig/perl/R_slope_aspect/r_slope_aspect/r_slope_aspect.c
   grass/trunk/vector/lidar/lidarlib/TcholBand.c
   grass/trunk/vector/lidar/lidarlib/raster.c
   grass/trunk/vector/lidar/lidarlib/zones.c
   grass/trunk/vector/lidar/v.lidar.correction/correction.c
   grass/trunk/vector/lidar/v.lidar.correction/main.c
   grass/trunk/vector/lidar/v.lidar.edgedetection/edgedetection.c
   grass/trunk/vector/lidar/v.lidar.edgedetection/main.c
   grass/trunk/vector/lidar/v.lidar.growing/ConvexHull.c
   grass/trunk/vector/lidar/v.lidar.growing/main.c
   grass/trunk/vector/lidar/v.outlier/main.c
   grass/trunk/vector/lidar/v.outlier/outlier.c
   grass/trunk/vector/lidar/v.surf.bspline/crosscorr.c
   grass/trunk/vector/lidar/v.surf.bspline/main.c
   grass/trunk/vector/v.convert/att.c
   grass/trunk/vector/v.convert/dist.c
   grass/trunk/vector/v.convert/main.c
   grass/trunk/vector/v.convert/old2new.c
   grass/trunk/vector/v.convert/read.c
   grass/trunk/vector/v.drape/main.c
   grass/trunk/vector/v.extrude/main.c
   grass/trunk/vector/v.kernel/function.c
   grass/trunk/vector/v.kernel/main.c
   grass/trunk/vector/v.neighbors/main.c
   grass/trunk/vector/v.sample/main.c
   grass/trunk/vector/v.surf.idw/main.c
   grass/trunk/vector/v.surf.idw/read_sites.c
   grass/trunk/vector/v.to.rast/do_areas.c
   grass/trunk/vector/v.to.rast/do_lines.c
   grass/trunk/vector/v.to.rast/local.h
   grass/trunk/vector/v.to.rast/main.c
   grass/trunk/vector/v.to.rast/raster.c
   grass/trunk/vector/v.to.rast/support.c
   grass/trunk/vector/v.to.rast/vect2rast.c
   grass/trunk/vector/v.vol.rst/dataoct.c
   grass/trunk/vector/v.vol.rst/main.c
   grass/trunk/vector/v.vol.rst/oct.c
   grass/trunk/vector/v.vol.rst/user1.c
   grass/trunk/vector/v.vol.rst/user2.c
   grass/trunk/vector/v.vol.rst/user3.c
   grass/trunk/vector/v.vol.rst/user4.c
   grass/trunk/vector/v.vol.rst/vector.c
   grass/trunk/vector/v.what.rast/main.c
   grass/trunk/visualization/xganim/main.cc
rasterlib: raster-related fns moved from gislib to rasterlib (step 1)
Modified: grass/trunk/display/d.colors/curses.c
--- grass/trunk/display/d.colors/curses.c	2009-06-20 21:39:23 UTC (rev 38002)
+++ grass/trunk/display/d.colors/curses.c	2009-06-20 22:03:23 UTC (rev 38003)
@@ -63,11 +63,11 @@
     CELL tmp = current_cat;
     int start_cat, end_cat, at_cat, at_line;
-    if (G_is_c_null_value(&tmp))
+    if (Rast_is_c_null_value(&tmp))
 	current_cat = 0;
     else
 	current_cat++;
-    G_set_c_null_value(&tmp, 1);
+    Rast_set_c_null_value(&tmp, 1);
     start_cat = current_cat - 2;
     start_cat = start_cat > 0 ? start_cat : 0;
     end_cat = start_cat + 4;
@@ -85,18 +85,18 @@
 	if (at_cat == current_cat) {
 	    if (!at_cat)
 		sprintf(buffer, "-> %3s %s", "N",
-			G_get_c_raster_cat(&tmp, pcats));
+			Rast_get_c_raster_cat(&tmp, pcats));
 	    else
 		sprintf(buffer, "-> %3d %s", at_cat - 1,
-			G_get_cat(at_cat - 1, pcats));
+			Rast_get_cat(at_cat - 1, pcats));
 	else {
 	    if (!at_cat)
 		sprintf(buffer, "   %3s %s", "N",
 	    else
 		sprintf(buffer, "   %3d %s", at_cat - 1,
 	wmove(CAT_WIN, at_line++, 1);
 	waddstr(CAT_WIN, buffer);
@@ -155,7 +155,7 @@
     if (hi_mode)
 	sprintf(buffer, "HIGHLIGHT COLOR");
     else {
-	if (!G_is_c_null_value(&tmp))
+	if (!Rast_is_c_null_value(&tmp))
 	    sprintf(buffer, "CATEGORY NUMBER: %d", at_cat);
 	else
 	    sprintf(buffer, "CATEGORY NUMBER: N");
Modified: grass/trunk/display/d.colors/get_info.c
--- grass/trunk/display/d.colors/get_info.c	2009-06-20 21:39:23 UTC (rev 38002)
+++ grass/trunk/display/d.colors/get_info.c	2009-06-20 22:03:23 UTC (rev 38003)
@@ -18,13 +18,13 @@
 	exit(0);
     /* Reading color lookup table */
-    if (G_read_cats(name, mapset, &categories) == -1) {
+    if (Rast_read_cats(name, mapset, &categories) == -1) {
 	sprintf(buff, "category file for [%s] not available", name);
 	G_fatal_error(buff);
-    if (G_read_colors(name, mapset, &colors) == -1) {
+    if (Rast_read_colors(name, mapset, &colors) == -1) {
 	sprintf(buff, "color file for [%s] not available", name);
Modified: grass/trunk/display/d.colors/interact.c
--- grass/trunk/display/d.colors/interact.c	2009-06-20 21:39:23 UTC (rev 38002)
+++ grass/trunk/display/d.colors/interact.c	2009-06-20 22:03:23 UTC (rev 38003)
@@ -43,8 +43,8 @@
     hi_save_mode = 0;
     colors_changed = 0;
-    G_set_c_null_value(&at_cat, 1);
-    G_get_color(at_cat, &cur_red, &cur_grn, &cur_blu, colors);
+    Rast_set_c_null_value(&at_cat, 1);
+    Rast_get_color(at_cat, &cur_red, &cur_grn, &cur_blu, colors);
     shift_incr = 10;
     Initialize_curses();
@@ -89,10 +89,10 @@
 	case 'd':
 	case 'u':
 	    if (hi_mode && !hi_save_mode) {
 	    /*              tmark_category(at_cat, 0) ; */
-	    if (G_is_c_null_value(&at_cat))
+	    if (Rast_is_c_null_value(&at_cat))
 		tmp = 0;
 	    else
 		tmp = at_cat + 1;
@@ -115,7 +115,7 @@
 	    tmp = tmp % (categories->num + 2);	/* changed 11/99 M.N. */
 	    if (!tmp)
 	    else
 		at_cat = tmp - 1;
@@ -124,12 +124,12 @@
 		cur_grn = grn_hi;
 		cur_blu = blu_hi;
 		if (hi_save_mode) {
-		    G_set_color(at_cat, cur_red, cur_grn, cur_blu, colors);
+		    Rast_set_color(at_cat, cur_red, cur_grn, cur_blu, colors);
 		    colors_changed = 1;
 	    else {
 	    WRITE_CATS;
@@ -167,12 +167,12 @@
 		cur_grn = grn_hi;
 		cur_blu = blu_hi;
 		if (hi_save_mode) {
 		    colors_changed = 1;
 	    else {
 		switch (cur_char) {
 		case 'r':
 		    cur_red = shift_color(cur_red, -shift_incr);
@@ -193,7 +193,7 @@
 		    cur_blu = shift_color(cur_blu, shift_incr);
 		    break;
 		colors_changed = 1;
 	    WRITE_STATUS;
@@ -207,25 +207,25 @@
 	    WRITE_STATUS;
 	    break;
 	case '+':
-	    G_shift_colors(1, colors);
+	    Rast_shift_colors(1, colors);
 	    if (hi_mode) {
 		cur_red = red_hi;
 		cur_grn = grn_hi;
 		cur_blu = blu_hi;
 		if (hi_save_mode)
 	    colors_changed = 1;
 	    WRITE_STATUS;
 	    break;
 	case '-':
-	    G_shift_colors(-1, colors);
+	    Rast_shift_colors(-1, colors);
 	    if (hi_mode) {
 		cur_red = red_hi;
 		cur_grn = grn_hi;
 		cur_blu = blu_hi;
 		if (hi_save_mode)
 	    colors_changed = 1;
 	    WRITE_STATUS;
@@ -245,14 +245,14 @@
 		cur_grn = grn_hi;
 		cur_blu = blu_hi;
 		if (hi_save_mode)
 	    colors_changed = 1;
 	    break;
 	case 'h':
 	case 'H':
 	    if (hi_mode) {
 		hi_mode = 0;
 		hi_save_mode = 0;
@@ -262,7 +262,7 @@
 		cur_blu = blu_hi;
 		hi_mode = 1;
 		if (cur_char == 'H') {
 		    hi_save_mode = 1;
 		    colors_changed = 1;
@@ -319,7 +319,7 @@
     Clear_message();
     Write_message(2, "Writing color table      ");
-    if (G_write_colors(name, mapset, colors) == -1) {
+    if (Rast_write_colors(name, mapset, colors) == -1) {
 	G_sleep(1);
 	Write_message(2, "Can't write color table  ");
 	G_sleep(2);
Modified: grass/trunk/display/d.colors/main.c
--- grass/trunk/display/d.colors/main.c	2009-06-20 21:39:23 UTC (rev 38002)
+++ grass/trunk/display/d.colors/main.c	2009-06-20 22:03:23 UTC (rev 38003)
@@ -69,7 +69,7 @@
 	G_fatal_error(msg);
-    if (G_raster_map_is_fp(map->answer, mapset)) {
+    if (Rast_raster_map_is_fp(map->answer, mapset)) {
 	sprintf(buff,
 		"Raster file [%s] is floating point! \nd.colors only works with integer maps",
 		map->answer);
Modified: grass/trunk/display/d.colors/tbl_toggle.c
--- grass/trunk/display/d.colors/tbl_toggle.c	2009-06-20 21:39:23 UTC (rev 38002)
+++ grass/trunk/display/d.colors/tbl_toggle.c	2009-06-20 22:03:23 UTC (rev 38003)
@@ -9,8 +9,8 @@
     char *msg = '\0';
     char info[100];
-    G_get_color_range(&min, &max, colors);
-    G_free_colors(colors);
+    Rast_get_color_range(&min, &max, colors);
+    Rast_free_colors(colors);
     sprintf(info, "Color range: %d to %d\n", min, max);
     toggle_number++;
@@ -18,27 +18,27 @@
     switch (toggle_number) {
     case 0:
 	msg = "Original colors";
-	G_read_colors(name, mapset, colors);
+	Rast_read_colors(name, mapset, colors);
 	break;
     case 1:
 	msg = "Ramp colors";
-	G_make_ramp_colors(colors, min, max);
+	Rast_make_ramp_colors(colors, min, max);
 	break;
     case 2:
 	msg = "Grey scale colors";
-	G_make_grey_scale_colors(colors, min, max);
+	Rast_make_grey_scale_colors(colors, min, max);
 	break;
     case 3:
 	msg = "Random colors";
-	G_make_random_colors(colors, min, max);
+	Rast_make_random_colors(colors, min, max);
 	break;
     case 4:
 	msg = "Wave colors";
-	G_make_wave_colors(colors, min, max);
+	Rast_make_wave_colors(colors, min, max);
 	break;
     case 5:
 	msg = "Aspect colors";
-	G_make_aspect_colors(colors, min, max);
+	Rast_make_aspect_colors(colors, min, max);
 	break;
     Write_message(2, msg);
Modified: grass/trunk/display/d.colortable/main.c
--- grass/trunk/display/d.colortable/main.c	2009-06-20 21:39:23 UTC (rev 38002)
+++ grass/trunk/display/d.colortable/main.c	2009-06-20 22:03:23 UTC (rev 38003)
@@ -24,6 +24,7 @@
 #include <math.h>
 #include <grass/display.h>
 #include <grass/gis.h>
+#include <grass/Rast.h>
 #include <grass/display_raster.h>
 #include <grass/glocale.h>
@@ -96,7 +97,7 @@
 	exit(EXIT_FAILURE);
     map_name = opt1->answer;
-    fp = G_raster_map_is_fp(map_name, "");
+    fp = Rast_raster_map_is_fp(map_name, "");
     if (opt2->answer != NULL) {
 	new_colr = D_translate_color(opt2->answer);
@@ -128,9 +129,9 @@
     /* Make sure map is available */
-    if (G_read_colors(map_name, "", &colors) == -1)
+    if (Rast_read_colors(map_name, "", &colors) == -1)
 	G_fatal_error(_("Color file for <%s> not available"), map_name);
-    if (G_read_fp_range(map_name, "", &fp_range) == -1)
+    if (Rast_read_fp_range(map_name, "", &fp_range) == -1)
 	G_fatal_error(_("Range file for <%s> not available"), map_name);
     if (R_open_driver() != 0)
 	G_fatal_error(_("No graphics device selected"));
@@ -138,8 +139,8 @@
     D_setup_unity(0);
     D_get_src(&t, &b, &l, &r);
-    G_get_fp_range_min_max(&fp_range, &dmin, &dmax);
-    if (G_is_d_null_value(&dmin) || G_is_d_null_value(&dmax))
+    Rast_get_fp_range_min_max(&fp_range, &dmin, &dmax);
+    if (Rast_is_d_null_value(&dmin) || Rast_is_d_null_value(&dmax))
 	G_fatal_error("Data range is empty");
     cats_num = (int)dmax - (int)dmin + 1;
     if (lines <= 0 && cols <= 0) {
@@ -173,7 +174,7 @@
     white = D_translate_color("white");
     black = D_translate_color("black");
-    G_set_c_null_value(&atcat, 1);
+    Rast_set_c_null_value(&atcat, 1);
     if (!fp) {
 	for (atcol = 0; atcol < cols; atcol++) {
 	    cur_dot_row = t;
@@ -250,7 +251,7 @@
 	fprintf(stdout, "dots_per_line: %d\n", dots_per_line);
 	for (r = 0; r < dots_per_line - 6; r++) {
 	    if (r <= 4)
-		G_set_d_null_value(&dval, 1);
+		Rast_set_d_null_value(&dval, 1);
 	    else
 		dval =
 		    dmin + (r - 1) * (dmax - dmin) / (dots_per_line - 6 - 5);
Modified: grass/trunk/display/d.extract/main.c
--- grass/trunk/display/d.extract/main.c	2009-06-20 21:39:23 UTC (rev 38002)
+++ grass/trunk/display/d.extract/main.c	2009-06-20 22:03:23 UTC (rev 38003)
@@ -79,14 +79,14 @@
     color = G_standard_color_rgb(BLACK);
-    if (G_str_to_color(color_opt->answer, &r, &g, &b)) {
+    if (Rast_str_to_color(color_opt->answer, &r, &g, &b)) {
 	color.r = r;
 	color.g = g;
 	color.b = b;
     hcolor = G_standard_color_rgb(RED);
-    if (G_str_to_color(hcolor_opt->answer, &r, &g, &b)) {
+    if (Rast_str_to_color(hcolor_opt->answer, &r, &g, &b)) {
 	hcolor.r = r;
 	hcolor.g = g;
 	hcolor.b = b;
Modified: grass/trunk/display/d.graph/do_graph.c
--- grass/trunk/display/d.graph/do_graph.c	2009-06-20 21:39:23 UTC (rev 38002)
+++ grass/trunk/display/d.graph/do_graph.c	2009-06-20 22:03:23 UTC (rev 38003)
@@ -1,6 +1,7 @@
 #include <stdio.h>
 #include <string.h>
 #include <grass/symbol.h>
@@ -99,7 +100,7 @@
     /* Parse and select color */
-    color = G_str_to_color(in_color, &R, &G, &B);
+    color = Rast_str_to_color(in_color, &R, &G, &B);
     if (color == 0) {
 	G_warning(_("[%s]: No such color"), in_color);
 	/* store for backup */
@@ -339,7 +340,7 @@
     size *= yincr;
     /* parse line color */
-    ret = G_str_to_color(line_color_str, &R, &G, &B);
+    ret = Rast_str_to_color(line_color_str, &R, &G, &B);
     line_color->r = (unsigned char)R;
     line_color->g = (unsigned char)G;
     line_color->b = (unsigned char)B;
@@ -356,7 +357,7 @@
     /* parse fill color */
-    ret = G_str_to_color(fill_color_str, &R, &G, &B);
+    ret = Rast_str_to_color(fill_color_str, &R, &G, &B);
     fill_color->r = (unsigned char)R;
     fill_color->g = (unsigned char)G;
     fill_color->b = (unsigned char)B;
Modified: grass/trunk/display/d.graph/graphics.c
--- grass/trunk/display/d.graph/graphics.c	2009-06-20 21:39:23 UTC (rev 38002)
+++ grass/trunk/display/d.graph/graphics.c	2009-06-20 22:03:23 UTC (rev 38003)
@@ -1,5 +1,6 @@
 #include <string.h>
 #include "local_proto.h"
Modified: grass/trunk/display/d.graph/main.c
--- grass/trunk/display/d.graph/main.c	2009-06-20 21:39:23 UTC (rev 38002)
+++ grass/trunk/display/d.graph/main.c	2009-06-20 22:03:23 UTC (rev 38003)
@@ -31,6 +31,7 @@
 #include <stdio.h>
 #include <stdlib.h>
@@ -100,7 +101,7 @@
-	color = G_str_to_color(opt2->answer, &R, &G, &B);
+	color = Rast_str_to_color(opt2->answer, &R, &G, &B);
 	if (color == 0)
 	    G_fatal_error(_("[%s]: No such color"), opt2->answer);
Modified: grass/trunk/display/d.grid/fiducial.c
--- grass/trunk/display/d.grid/fiducial.c	2009-06-20 21:39:23 UTC (rev 38002)
+++ grass/trunk/display/d.grid/fiducial.c	2009-06-20 22:03:23 UTC (rev 38003)
@@ -1,4 +1,5 @@
 #include <grass/colors.h>
@@ -33,7 +34,7 @@
     if (D_color_number_to_RGB(color, &R, &G, &B) == 0)
 	/* fall back to black on failure */
-	G_str_to_color(DEFAULT_FG_COLOR, &R, &G, &B);
+	Rast_str_to_color(DEFAULT_FG_COLOR, &R, &G, &B);
Modified: grass/trunk/display/d.grid/main.c
--- grass/trunk/display/d.grid/main.c	2009-06-20 21:39:23 UTC (rev 38002)
+++ grass/trunk/display/d.grid/main.c	2009-06-20 22:03:23 UTC (rev 38003)
@@ -21,6 +21,7 @@
 #include <stdlib.h>
 #include <string.h>
 #include <grass/gprojects.h>
Modified: grass/trunk/display/d.grid/plot.c
--- grass/trunk/display/d.grid/plot.c	2009-06-20 21:39:23 UTC (rev 38002)
+++ grass/trunk/display/d.grid/plot.c	2009-06-20 22:03:23 UTC (rev 38003)
@@ -2,6 +2,7 @@
 #include <string.h>
Modified: grass/trunk/display/d.grid/plotborder.c
--- grass/trunk/display/d.grid/plotborder.c	2009-06-20 21:39:23 UTC (rev 38002)
+++ grass/trunk/display/d.grid/plotborder.c	2009-06-20 22:03:23 UTC (rev 38003)
@@ -1,5 +1,6 @@
 #include <math.h>
 int plot_border(double grid_size, double east, double north)
Modified: grass/trunk/display/d.his/his.c
--- grass/trunk/display/d.his/his.c	2009-06-20 21:39:23 UTC (rev 38002)
+++ grass/trunk/display/d.his/his.c	2009-06-20 22:03:23 UTC (rev 38003)
@@ -1,5 +1,6 @@
 #include "his.h"
@@ -65,10 +66,10 @@
     int i;
-    G_init_colors(gray);
+    Rast_init_colors(gray);
     for (i = 0; i < 256; i++)
-	G_set_color((CELL) i, i, i, i, gray);
+	Rast_set_color((CELL) i, i, i, i, gray);
     return 0;
Modified: grass/trunk/display/d.his/main.c
--- grass/trunk/display/d.his/main.c	2009-06-20 21:39:23 UTC (rev 38002)
+++ grass/trunk/display/d.his/main.c	2009-06-20 22:03:23 UTC (rev 38003)
@@ -23,6 +23,7 @@
 #include <stdio.h>
 #include <string.h>
@@ -121,7 +122,7 @@
     name_h = opt_h->answer;
-    if ((hue_file = G_open_cell_old(name_h, "")) == -1)
+    if ((hue_file = Rast_open_cell_old(name_h, "")) == -1)
 	G_fatal_error(_("Unable to open raster map <%s>"), name_h);
     hue_r = G_malloc(window.cols);
@@ -132,7 +133,7 @@
     dummy = G_malloc(window.cols);
-    if (G_read_colors(name_h, "", &hue_colors) == -1)
+    if (Rast_read_colors(name_h, "", &hue_colors) == -1)
 	G_fatal_error(_("Color file for <%s> not available"), name_h);
     int_used = 0;
@@ -143,14 +144,14 @@
 	int_used = 1;
-	if ((int_file = G_open_cell_old(name_i, "")) == -1)
+	if ((int_file = Rast_open_cell_old(name_i, "")) == -1)
 	    G_fatal_error(_("Unable to open raster map <%s>"), name_i);
 	int_r = G_malloc(window.cols);
 	int_n = G_malloc(window.cols);
-	if (G_read_colors(name_i, "", &int_colors) == -1)
+	if (Rast_read_colors(name_i, "", &int_colors) == -1)
 	    G_fatal_error(_("Color file for <%s> not available"), name_i);
@@ -162,20 +163,20 @@
 	sat_used = 1;
-	if ((sat_file = G_open_cell_old(name_s, "")) == -1)
+	if ((sat_file = Rast_open_cell_old(name_s, "")) == -1)
 	    G_fatal_error("Unable to open raster map <%s>", name_s);
 	sat_r = G_malloc(window.cols);
 	sat_n = G_malloc(window.cols);
-	if (G_read_colors(name_s, "", &sat_colors) == -1)
+	if (Rast_read_colors(name_s, "", &sat_colors) == -1)
 	    G_fatal_error(_("Color file for <%s> not available"), name_s);
-    r_array = G_allocate_cell_buf();
-    g_array = G_allocate_cell_buf();
-    b_array = G_allocate_cell_buf();
+    r_array = Rast_allocate_cell_buf();
+    g_array = Rast_allocate_cell_buf();
+    b_array = Rast_allocate_cell_buf();
     /* Make color table */
     make_gray_scale(&gray_colors);
@@ -190,17 +191,17 @@
     for (atrow = 0; atrow < window.rows;) {
 	G_percent(atrow, window.rows, 2);
-	if (G_get_raster_row_colors
+	if (Rast_get_raster_row_colors
 	    (hue_file, atrow, &hue_colors, hue_r, hue_g, hue_b, hue_n) < 0)
 	    G_fatal_error(_("Error reading hue data"));
 	if (int_used &&
-	    (G_get_raster_row_colors
+	    (Rast_get_raster_row_colors
 	     (int_file, atrow, &int_colors, int_r, dummy, dummy, int_n) < 0))
 	    G_fatal_error(_("Error reading intensity data"));
 	if (sat_used &&
 	     (sat_file, atrow, &sat_colors, sat_r, dummy, dummy, sat_n) < 0))
 	    G_fatal_error(_("Error reading saturation data"));
@@ -209,9 +210,9 @@
 		if (hue_n[atcol]
 		    || (int_used && int_n[atcol])
 		    || (sat_used && sat_n[atcol])) {
-		    G_set_c_null_value(&r_array[atcol], 1);
-		    G_set_c_null_value(&g_array[atcol], 1);
-		    G_set_c_null_value(&b_array[atcol], 1);
+		    Rast_set_c_null_value(&r_array[atcol], 1);
+		    Rast_set_c_null_value(&g_array[atcol], 1);
+		    Rast_set_c_null_value(&b_array[atcol], 1);
 		    continue;
@@ -246,11 +247,11 @@
     R_close_driver();
     /* Close the raster maps */
-    G_close_cell(hue_file);
+    Rast_close_cell(hue_file);
     if (int_used)
-	G_close_cell(int_file);
+	Rast_close_cell(int_file);
     if (sat_used)
-	G_close_cell(sat_file);
+	Rast_close_cell(sat_file);
     exit(EXIT_SUCCESS);
Modified: grass/trunk/display/d.histogram/bar.c
--- grass/trunk/display/d.histogram/bar.c	2009-06-20 21:39:23 UTC (rev 38002)
+++ grass/trunk/display/d.histogram/bar.c	2009-06-20 22:03:23 UTC (rev 38003)
@@ -27,8 +27,11 @@
 #include <string.h>
 #include "bar.h"
 int bar(struct stat_list *dist_stats,	/* list of distribution statistics */
@@ -102,9 +105,9 @@
 	    max_tics--;
 	i = 0;
 	if (is_fp) {
-	    G_get_fp_range_min_max(&fp_range, &range_dmin, &range_dmax);
-	    if (G_is_d_null_value(&range_dmin) ||
-		G_is_d_null_value(&range_dmax))
+	    Rast_get_fp_range_min_max(&fp_range, &range_dmin, &range_dmax);
+	    if (Rast_is_d_null_value(&range_dmin) ||
+		Rast_is_d_null_value(&range_dmax))
 		G_fatal_error("Floating point data range is empty");
 	    if ((range_dmax - range_dmin) < 1.0)
@@ -124,9 +127,9 @@
     else {
 	if (is_fp && !cat_ranges) {
 	tic_every = 1;
@@ -160,7 +163,7 @@
 		draw = NO;
 	    else {
 		draw = YES;
-		G_set_c_null_value(&bar_color, 1);
+		Rast_set_c_null_value(&bar_color, 1);
 		bar_height =
 		    (yoffset - yscale * (double)dist_stats->null_stat);
@@ -212,9 +215,9 @@
 	if (draw == YES) {
 	    if (xscale != 1) {
 		/* draw the bar as a box */
-		if (!G_is_c_null_value(&bar_color) && is_fp) {
+		if (!Rast_is_c_null_value(&bar_color) && is_fp) {
 		    if (cat_ranges)
-			G_get_ith_d_raster_cat(&cats, bar_color,
+			Rast_get_ith_d_raster_cat(&cats, bar_color,
 					       &dmin, &dmax);
 		    else {
 			dmin = range_dmin + i * (range_dmax - range_dmin) / nsteps;
@@ -267,7 +270,7 @@
 		/* draw the bar as a line */
 		if (is_fp) {
 		    if (cat_ranges)
 					       &dmin, &dmax);
 		    else {
Modified: grass/trunk/display/d.histogram/draw_slice.c
--- grass/trunk/display/d.histogram/draw_slice.c	2009-06-20 21:39:23 UTC (rev 38002)
+++ grass/trunk/display/d.histogram/draw_slice.c	2009-06-20 22:03:23 UTC (rev 38003)
@@ -2,6 +2,7 @@
 char percent[] = "%";
Modified: grass/trunk/display/d.histogram/get_stats.c
--- grass/trunk/display/d.histogram/get_stats.c	2009-06-20 21:39:23 UTC (rev 38002)
+++ grass/trunk/display/d.histogram/get_stats.c	2009-06-20 22:03:23 UTC (rev 38003)
@@ -4,6 +4,7 @@
 #include <stdarg.h>
 #include <unistd.h>
 #include "options.h"
 #include "dhist.h"
@@ -50,17 +51,17 @@
     /* write stats to a temp file */
     tempfile = G_tempfile();
-    is_fp = G_raster_map_is_fp(mapname, "");
+    is_fp = Rast_raster_map_is_fp(mapname, "");
     if (is_fp) {
 	if (cat_ranges) {
-	    if (G_read_raster_cats(mapname, "", &cats) < 0)
+	    if (Rast_read_raster_cats(mapname, "", &cats) < 0)
 		G_fatal_error("Can't read category file");
-	    if (G_number_of_raster_cats(&cats) <= 0) {
+	    if (Rast_number_of_raster_cats(&cats) <= 0) {
 		G_warning("There are no labeled cats, using nsteps argument");
 		cat_ranges = 0;
-	if (G_read_fp_range(map_name, "", &fp_range) <= 0)
+	if (Rast_read_fp_range(map_name, "", &fp_range) <= 0)
 	    G_fatal_error("Can't read frange file");
     if (cat_ranges) {
Modified: grass/trunk/display/d.histogram/main.c
--- grass/trunk/display/d.histogram/main.c	2009-06-20 21:39:23 UTC (rev 38002)
+++ grass/trunk/display/d.histogram/main.c	2009-06-20 22:03:23 UTC (rev 38003)
@@ -34,6 +34,7 @@
 #include <stdlib.h>
 #include <string.h>
@@ -168,13 +169,13 @@
     nodata = flag1->answer;
     quiet = flag2->answer ? YES : NO;
-    if (G_read_colors(map_name, "", &pcolors) == -1)
+    if (Rast_read_colors(map_name, "", &pcolors) == -1)
-    if (G_read_cats(map_name, "", &cats) == -1)
+    if (Rast_read_cats(map_name, "", &cats) == -1)
 	G_fatal_error(_("Category file for <%s> not available"), map_name);
-    if (G_read_range(map_name, "", &range) == -1)
+    if (Rast_read_range(map_name, "", &range) == -1)
 	G_fatal_error(_("Range information for <%s> not available"),
 		      map_name);
Modified: grass/trunk/display/d.histogram/pie.c
--- grass/trunk/display/d.histogram/pie.c	2009-06-20 21:39:23 UTC (rev 38002)
+++ grass/trunk/display/d.histogram/pie.c	2009-06-20 22:03:23 UTC (rev 38003)
@@ -29,8 +29,11 @@
 #include <string.h>
 #include "pie.h"
 /*#define DEBUG */
@@ -108,9 +111,9 @@
 	max_tics = (x_line[2] - x_line[1]) / XTIC_DIST;
 	i = 0;
 	if (is_fp) {
 	    while ((range_dmax - range_dmin) / tics[i].every > max_tics)
@@ -125,9 +128,9 @@
     else {
 	tic_every = 1;
@@ -165,7 +168,7 @@
 		draw = NO;
 	    else {
 		draw = YES;
 		arc = 360.0 *((double)dist_stats->null_stat
 				    / (double)dist_stats->sumstat);
 		draw_slice_filled(colors, dval, color, ORIGIN_X,
@@ -185,7 +188,7 @@
 		draw = YES;
 		if (is_fp) {
 		    if (cat_ranges)
-			G_get_ith_d_raster_cat(&cats, (CELL) i, &dmin, &dmax);
+			Rast_get_ith_d_raster_cat(&cats, (CELL) i, &dmin, &dmax);
 		    else {
 			dmax = range_dmin + (i + 1) * (range_dmax - range_dmin) / nsteps;
@@ -225,7 +228,7 @@
 		    draw = YES;
 		    if (is_fp) {
 			if (cat_ranges)
 			else {
Modified: grass/trunk/display/d.labels/color.c
--- grass/trunk/display/d.labels/color.c	2009-06-20 21:39:23 UTC (rev 38002)
+++ grass/trunk/display/d.labels/color.c	2009-06-20 22:03:23 UTC (rev 38003)
@@ -16,6 +16,7 @@
 /**  ??? move these into libgis ??? (libraster for set_color_from_RGBA()) **/
@@ -52,7 +53,7 @@
     int r, g, b;
     int ret;
-    ret = G_str_to_color(clr_str, &r, &g, &b);
+    ret = Rast_str_to_color(clr_str, &r, &g, &b);
     if (ret == 1) {
 	color->a = RGBA_COLOR_OPAQUE;
Modified: grass/trunk/display/d.labels/do_labels.c
--- grass/trunk/display/d.labels/do_labels.c	2009-06-20 21:39:23 UTC (rev 38002)
+++ grass/trunk/display/d.labels/do_labels.c	2009-06-20 22:03:23 UTC (rev 38003)
@@ -3,6 +3,7 @@
 #include <stdlib.h>
 #include <math.h>
Modified: grass/trunk/display/d.labels/main.c
--- grass/trunk/display/d.labels/main.c	2009-06-20 21:39:23 UTC (rev 38002)
+++ grass/trunk/display/d.labels/main.c	2009-06-20 22:03:23 UTC (rev 38003)
@@ -19,6 +19,7 @@
 #include <stdlib.h>
 #include <math.h>
Modified: grass/trunk/display/d.legend/main.c
--- grass/trunk/display/d.legend/main.c	2009-06-20 21:39:23 UTC (rev 38002)
+++ grass/trunk/display/d.legend/main.c	2009-06-20 22:03:23 UTC (rev 38003)
@@ -29,6 +29,7 @@
 #include <string.h>
 #include <math.h>
@@ -243,20 +244,20 @@
     if (fp && !use_catlist) {
 	do_smooth = TRUE;
 	/* fprintf(stderr, "FP map found - switching gradient legend on\n"); */
 	flip = !flip;
 	G_warning(_("Category file for <%s> not available"), map_name);
-    G_set_c_null_value(&null_cell, 1);
+    Rast_set_c_null_value(&null_cell, 1);
@@ -318,15 +319,15 @@
     /* How many categories to show */
     if (!fp) {
 	    G_fatal_error(_("Range information for <%s> not available (run r.support)"),
 			  map_name);
-	G_get_range_min_max(&range, &min_ind, &max_ind);
-	if (G_is_c_null_value(&min_ind))
+	Rast_get_range_min_max(&range, &min_ind, &max_ind);
+	if (Rast_is_c_null_value(&min_ind))
 	    G_fatal_error(_("Input map contains no data"));
-	G_get_color_range(&min_colr, &max_colr, &colors);
+	Rast_get_color_range(&min_colr, &max_colr, &colors);
 	if (UserRange) {
 	    if (min_ind < UserRangeMin)
@@ -371,9 +372,9 @@
 	for (i = min_ind, j = 1, k = 0; j <= do_cats && i <= max_ind;
 	     j++, i += thin) {
 	    if (!flip)
-		cstr = G_get_cat(i, &cats);
+		cstr = Rast_get_cat(i, &cats);
 	    else
-		cstr = G_get_cat((max_ind - (i - min_ind)), &cats);
+		cstr = Rast_get_cat((max_ind - (i - min_ind)), &cats);
 	    if (!use_catlist)
 		catlist[j - 1] = (double)i;
@@ -404,7 +405,7 @@
 				  opt8->answers[i], min_ind, max_ind);
-		cstr = G_get_cat(catlist[i], &cats);
+		cstr = Rast_get_cat(catlist[i], &cats);
 		if (!cstr[0]) {	/* no cat label found, skip str output */
 		    if (hide_nodata)
 			continue;
@@ -464,7 +465,7 @@
 	/*      R_text_size((int)(dots_per_line*4/5), (int)(dots_per_line*4/5)) ;    redundant */
-	/* if(G_is_c_null_value(&min_ind) && G_is_c_null_value(&max_ind))
+	/* if(Rast_is_c_null_value(&min_ind) && Rast_is_c_null_value(&max_ind))
 	   min_ind = 1;
 	   max_ind = 0;
@@ -480,13 +481,13 @@
     else {			/* is fp */
-	if (G_read_fp_range(map_name, "", &fprange) == -1)
+	if (Rast_read_fp_range(map_name, "", &fprange) == -1)
 			  map_name);
-	G_get_fp_range_min_max(&fprange, &dmin, &dmax);
+	Rast_get_fp_range_min_max(&fprange, &dmin, &dmax);
-	G_get_d_color_range(&min_dcolr, &max_dcolr, &colors);
+	Rast_get_d_color_range(&min_dcolr, &max_dcolr, &colors);
 	if (UserRange) {
 	    if (dmin < UserRangeMin)
@@ -603,7 +604,7 @@
 			max_ind - k * (double)(max_ind - min_ind) / (steps -
 								     1);
-		cstr = G_get_cat(tcell, &cats);
+		cstr = Rast_get_cat(tcell, &cats);
 		if (!cstr[0])	/* no cats found, disable str output */
 		    hide_catstr = 1;
 		else
@@ -779,9 +780,9 @@
 	    /*              for(i=min_ind, j=1, k=0; j<=do_cats && i<=max_ind; j++, i+=thin)        */
 	    if (!flip)
 	    else
-		cstr = G_get_cat(catlist[catlistCount - i - 1], &cats);
+		cstr = Rast_get_cat(catlist[catlistCount - i - 1], &cats);
Modified: grass/trunk/display/d.nviz/main.c
--- grass/trunk/display/d.nviz/main.c	2009-06-20 21:39:23 UTC (rev 38002)
+++ grass/trunk/display/d.nviz/main.c	2009-06-20 22:03:23 UTC (rev 38003)
@@ -24,6 +24,7 @@
 #include <math.h>
 #include <string.h>
 #include "local.h"
@@ -178,7 +179,7 @@
     /* Open Raster File */
     if (NULL == (mapset = G_find_cell2(name, "")))
 	G_fatal_error(_("Raster map <%s> not found"), name);
-    if (0 > (fd = G_open_cell_old(name, mapset)))
+    if (0 > (fd = Rast_open_cell_old(name, mapset)))
 	G_fatal_error(_("Unable to open raster map <%s>"), name);
     /* Set Image name */
@@ -199,7 +200,7 @@
 	G_fatal_error(_("Unable to open file <%s>"), outfile);
     /* Get Raster Type */
-    data_type = G_get_raster_map_type(fd);
+    data_type = Rast_get_raster_map_type(fd);
     /* Done with file */
     /* Output initial startup stuff */
@@ -315,7 +316,7 @@
     fprintf(fp, "SendScriptLine \"set ScriptPlaying 0\"\n");
     fprintf(fp, "puts \"DONE!\"\n");
-    G_close_cell(fd);
+    Rast_close_cell(fd);
     fclose(fp);
     sprintf(buf1, _("Created NVIZ script <%s>."), outfile);
@@ -442,31 +443,31 @@
     if (data_type == CELL_TYPE) {
-	cell = G_allocate_c_raster_buf();
-	if (G_get_c_raster_row(fd, cell, row) < 0)
+	cell = Rast_allocate_c_raster_buf();
+	if (Rast_get_c_raster_row(fd, cell, row) < 0)
 	    exit(1);
-	if (G_is_c_null_value(&cell[col]))
+	if (Rast_is_c_null_value(&cell[col]))
 	    camera_height = (double)9999.;
 	else
 	    camera_height = (double)cell[col];
     if (data_type == FCELL_TYPE) {
-	fcell = G_allocate_f_raster_buf();
-	if (G_get_f_raster_row(fd, fcell, row) < 0)
+	fcell = Rast_allocate_f_raster_buf();
+	if (Rast_get_f_raster_row(fd, fcell, row) < 0)
 	    exit(1);
-	if (G_is_f_null_value(&fcell[col]))
+	if (Rast_is_f_null_value(&fcell[col]))
 	else
 	    camera_height = (double)fcell[col];
     if (data_type == DCELL_TYPE) {
-	dcell = G_allocate_d_raster_buf();
-	if (G_get_d_raster_row(fd, dcell, row) < 0)
+	dcell = Rast_allocate_d_raster_buf();
+	if (Rast_get_d_raster_row(fd, dcell, row) < 0)
 	    exit(1);
-	if (G_is_d_null_value(&dcell[col]))
+	if (Rast_is_d_null_value(&dcell[col]))
 	else
 	    camera_height = (double)dcell[col];
Modified: grass/trunk/display/d.path/main.c
--- grass/trunk/display/d.path/main.c	2009-06-20 21:39:23 UTC (rev 38002)
+++ grass/trunk/display/d.path/main.c	2009-06-20 22:03:23 UTC (rev 38003)
@@ -20,6 +20,7 @@
 #include <stdlib.h>
 #include <string.h>
@@ -152,21 +153,21 @@
 	color.r = r;
 	color.g = g;
 	color.b = b;
 	hcolor.r = r;
 	hcolor.g = g;
 	hcolor.b = b;
     bgcolor = G_standard_color_rgb(WHITE);
-    if (G_str_to_color(bgcolor_opt->answer, &r, &g, &b)) {
+    if (Rast_str_to_color(bgcolor_opt->answer, &r, &g, &b)) {
 	bgcolor.r = r;
 	bgcolor.g = g;
 	bgcolor.b = b;
Modified: grass/trunk/display/d.path/select.c
--- grass/trunk/display/d.path/select.c	2009-06-20 21:39:23 UTC (rev 38002)
+++ grass/trunk/display/d.path/select.c	2009-06-20 22:03:23 UTC (rev 38003)
@@ -3,6 +3,7 @@
 #include <unistd.h>
 #include <math.h>
 #include <grass/Vect.h>
Modified: grass/trunk/display/d.profile/main.c
--- grass/trunk/display/d.profile/main.c	2009-06-20 21:39:23 UTC (rev 38002)
+++ grass/trunk/display/d.profile/main.c	2009-06-20 22:03:23 UTC (rev 38003)
@@ -23,6 +23,7 @@
 #include <stdlib.h>
 #include <math.h>
@@ -38,7 +39,7 @@
 static void get_region_range(int fd)
-    DCELL *buf = G_allocate_d_raster_buf();
+    DCELL *buf = Rast_allocate_d_raster_buf();
     int nrows = G_window_rows();
     int ncols = G_window_cols();
     int row, col;
@@ -47,7 +48,7 @@
     max = -1e300;
     for (row = 0; row < nrows; row++) {
-	G_get_d_raster_row(fd, buf, row);
+	Rast_get_d_raster_row(fd, buf, row);
 	for (col = 0; col < ncols; col++) {
 	    if (min > buf[col])
 		min = buf[col];
@@ -59,14 +60,14 @@
 static void get_map_range(void)
-    if (G_raster_map_type(mapname, "") == CELL_TYPE) {
+    if (Rast_raster_map_type(mapname, "") == CELL_TYPE) {
 	struct Range range;
 	CELL xmin, xmax;
-	if (G_read_range(mapname, "", &range) <= 0)
+	if (Rast_read_range(mapname, "", &range) <= 0)
 	    G_fatal_error(_("Unable to read range for %s"), mapname);
-	G_get_range_min_max(&range, &xmin, &xmax);
+	Rast_get_range_min_max(&range, &xmin, &xmax);
 	max = xmax;
 	min = xmin;
@@ -74,10 +75,10 @@
     else {
 	struct FPRange fprange;
-	if (G_read_fp_range(mapname, "", &fprange) <= 0)
+	if (Rast_read_fp_range(mapname, "", &fprange) <= 0)
 	    G_fatal_error(_("Unable to read FP range for %s"), mapname);
-	G_get_fp_range_min_max(&fprange, &min, &max);
+	Rast_get_fp_range_min_max(&fprange, &min, &max);
@@ -123,8 +124,8 @@
     DCELL *tmp;
     if (!row1) {
-	row1 = G_allocate_d_raster_buf();
-	row2 = G_allocate_d_raster_buf();
+	row1 = Rast_allocate_d_raster_buf();
+	row2 = Rast_allocate_d_raster_buf();
     col = (int)floor(x - 0.5);
@@ -134,33 +135,33 @@
     if (row < 0 || row + 1 >= G_window_rows() ||
 	col < 0 || col + 1 >= G_window_cols()) {
-	G_set_d_null_value(result, 1);
+	Rast_set_d_null_value(result, 1);
 	return 0;
     if (cur_row != row) {
 	if (cur_row == row + 1) {
 	    tmp = row1; row1 = row2; row2 = tmp;
-	    G_get_d_raster_row(fd, row1, row);
+	    Rast_get_d_raster_row(fd, row1, row);
 	else if (cur_row == row - 1) {
-	    G_get_d_raster_row(fd, row2, row + 1);
+	    Rast_get_d_raster_row(fd, row2, row + 1);
 	else {
 	cur_row = row;
-    if (G_is_d_null_value(&row1[col]) || G_is_d_null_value(&row1[col+1]) ||
-	G_is_d_null_value(&row2[col]) || G_is_d_null_value(&row2[col+1])) {
+    if (Rast_is_d_null_value(&row1[col]) || Rast_is_d_null_value(&row1[col+1]) ||
+	Rast_is_d_null_value(&row2[col]) || Rast_is_d_null_value(&row2[col+1])) {
 	return 0;
-    *result = G_interp_bilinear(x, y,
+    *result = Rast_interp_bilinear(x, y,
 				row1[col], row1[col+1],
 				row2[col], row2[col+1]);
@@ -211,7 +212,7 @@
     mapname = map->answer;
-    fd = G_open_cell_old(mapname, "");
+    fd = Rast_open_cell_old(mapname, "");
     if (fd < 0)
 	G_fatal_error(_("Unable to open raster map <%s>"), mapname);
Modified: grass/trunk/display/d.rast/display.c
--- grass/trunk/display/d.rast/display.c	2009-06-20 21:39:23 UTC (rev 38002)
+++ grass/trunk/display/d.rast/display.c	2009-06-20 22:03:23 UTC (rev 38003)
@@ -1,11 +1,15 @@
 #include <stdlib.h>
+#include <grass/glocale.h>
 #include "mask.h"
-#include <grass/glocale.h>
 static int cell_draw(const char *, struct Colors *, int, int, RASTER_MAP_TYPE);
 int display(const char *name,
@@ -15,15 +19,15 @@
     struct Colors colors;
     int r, g, b;
-    if (G_read_colors(name, "", &colors) == -1)
+    if (Rast_read_colors(name, "", &colors) == -1)
 	G_fatal_error(_("Color file for <%s> not available"), name);
     if (bg) {
-	if (G_str_to_color(bg, &r, &g, &b) != 1) {
+	if (Rast_str_to_color(bg, &r, &g, &b) != 1) {
 	    G_warning(_("[%s]: No such color"), bg);
 	    r = g = b = 255;
-	G_set_null_value_color(r, g, b, &colors);
+	Rast_set_null_value_color(r, g, b, &colors);
     D_setup(0);
@@ -32,7 +36,7 @@
     cell_draw(name, &colors, overlay, invert, data_type);
     /* release the colors now */
-    G_free_colors(&colors);
+    Rast_free_colors(&colors);
     return 0;
@@ -54,11 +58,11 @@
     D_set_overlay_mode(overlay);
-    if ((cellfile = G_open_cell_old(name, "")) == -1)
+    if ((cellfile = Rast_open_cell_old(name, "")) == -1)
     /* Allocate space for cell buffer */
-    xarray = G_allocate_raster_buf(data_type);
+    xarray = Rast_allocate_raster_buf(data_type);
     D_cell_draw_begin();
@@ -66,7 +70,7 @@
     for (cur_A_row = 0; cur_A_row != -1;) {
 	G_percent(cur_A_row, nrows, 2);
 	/* Get window (array) row currently required */
-	G_get_raster_row(cellfile, xarray, cur_A_row, data_type);
+	Rast_get_raster_row(cellfile, xarray, cur_A_row, data_type);
 	mask_raster_array(xarray, ncols, invert, data_type);
 	/* Draw the cell row, and get the next row number */
@@ -78,7 +82,7 @@
     G_percent(nrows, nrows, 2);
     /* Wrap up and return */
-    G_close_cell(cellfile);
+    Rast_close_cell(cellfile);
     G_free(xarray);
     return (0);
Modified: grass/trunk/display/d.rast/main.c
--- grass/trunk/display/d.rast/main.c	2009-06-20 21:39:23 UTC (rev 38002)
+++ grass/trunk/display/d.rast/main.c	2009-06-20 22:03:23 UTC (rev 38003)
@@ -20,6 +20,7 @@
 #include <stdlib.h>
 #include "mask.h"
@@ -103,7 +104,7 @@
-    fp = G_raster_map_is_fp(name, "");
+    fp = Rast_raster_map_is_fp(name, "");
     if (catlist->answer) {
 	if (fp)
 	    G_warning(_("Ignoring catlist: map is floating point (please use 'val=')"));
Modified: grass/trunk/display/d.rast/mask.c
--- grass/trunk/display/d.rast/mask.c	2009-06-20 21:39:23 UTC (rev 38002)
+++ grass/trunk/display/d.rast/mask.c	2009-06-20 22:03:23 UTC (rev 38003)
@@ -1,5 +1,6 @@
 #include <stdlib.h>
 #include "mask.h"
@@ -50,7 +51,7 @@
 	if (mask_select(&x, mask, invert))
 	    *cell++ = x;
 	else
-	    G_set_c_null_value(cell++, 1);
+	    Rast_set_c_null_value(cell++, 1);
     return 0;
@@ -64,7 +65,7 @@
 	if (mask_d_select(&x, mask, invert))
 	    *dcell++ = x;
 	else
-	    G_set_d_null_value(dcell++, 1);
+	    Rast_set_d_null_value(dcell++, 1);
     return 0;
Modified: grass/trunk/display/d.rast.arrow/main.c
--- grass/trunk/display/d.rast.arrow/main.c	2009-06-20 21:39:23 UTC (rev 38002)
+++ grass/trunk/display/d.rast.arrow/main.c	2009-06-20 22:03:23 UTC (rev 38003)
@@ -38,6 +38,7 @@
 #include <string.h>
 #include <math.h>
@@ -231,7 +232,7 @@
     if (align->answer) {
 	struct Cell_head wind;
-	if (G_get_cellhd(layer_name, "", &wind) < 0)
+	if (Rast_get_cellhd(layer_name, "", &wind) < 0)
 	    G_fatal_error(_("Unable to read header of raster map <%s>"), layer_name);
 	/* expand window extent by one wind resolution */
@@ -267,10 +268,10 @@
     /* figure out arrow scaling if using a magnitude map */
     if (opt7->answer) {
-	G_init_fp_range(&range);	/* really needed? */
-	if (G_read_fp_range(mag_map, "", &range) != 1)
+	Rast_init_fp_range(&range);	/* really needed? */
+	if (Rast_read_fp_range(mag_map, "", &range) != 1)
 	    G_fatal_error(_("Problem reading range file"));
-	G_get_fp_range_min_max(&range, &mag_min, &mag_max);
+	Rast_get_fp_range_min_max(&range, &mag_min, &mag_max);
 	scale *= 1.5 / fabs(mag_max);
 	G_debug(3, "scaling=%.2f  rast_max=%.2f", scale, mag_max);
@@ -290,26 +291,26 @@
     /* open the raster map */
-    layer_fd = G_open_cell_old(layer_name, "");
+    layer_fd = Rast_open_cell_old(layer_name, "");
     if (layer_fd < 0)
 	G_fatal_error(_("Unable to open raster map <%s>"), layer_name);
-    raster_type = G_get_raster_map_type(layer_fd);
+    raster_type = Rast_get_raster_map_type(layer_fd);
     /* allocate the cell array */
-    raster_row = G_allocate_raster_buf(raster_type);
+    raster_row = Rast_allocate_raster_buf(raster_type);
     if (opt7->answer) {
 	/* open the magnitude raster map */
-	mag_fd = G_open_cell_old(mag_map, "");
+	mag_fd = Rast_open_cell_old(mag_map, "");
 	if (mag_fd < 0)
 	    G_fatal_error("Unable to open raster map <%s>", mag_map);
-	mag_raster_type = G_get_raster_map_type(mag_fd);
+	mag_raster_type = Rast_get_raster_map_type(mag_fd);
-	mag_raster_row = G_allocate_raster_buf(mag_raster_type);
+	mag_raster_row = Rast_allocate_raster_buf(mag_raster_type);
@@ -317,11 +318,11 @@
        and call appropriate function to draw an arrow on the cell */
-	G_get_raster_row(layer_fd, raster_row, row, raster_type);
+	Rast_get_raster_row(layer_fd, raster_row, row, raster_type);
 	ptr = raster_row;
 	if (opt7->answer) {
-	    G_get_raster_row(mag_fd, mag_raster_row, row, mag_raster_type);
+	    Rast_get_raster_row(mag_fd, mag_raster_row, row, mag_raster_type);
 	    mag_ptr = mag_raster_row;
@@ -355,7 +356,7 @@
 		length *= scale;
-		if (G_is_null_value(mag_ptr, mag_raster_type)) {
+		if (Rast_is_null_value(mag_ptr, mag_raster_type)) {
 		    G_debug(5, "Invalid arrow length [NULL]. Skipping.");
 		    no_arrow = TRUE;
@@ -367,11 +368,11 @@
 	    if (no_arrow) {
-		ptr = G_incr_void_ptr(ptr, G_raster_size(raster_type));
+		ptr = Rast_incr_void_ptr(ptr, Rast_raster_size(raster_type));
 		if (opt7->answer)
 		    mag_ptr =
-			G_incr_void_ptr(mag_ptr,
-					G_raster_size(mag_raster_type));
+			Rast_incr_void_ptr(mag_ptr,
+					Rast_raster_size(mag_raster_type));
 		no_arrow = FALSE;
 		continue;
@@ -379,7 +380,7 @@
 	    /* treat AGNPS and ANSWERS data like old zero-as-null CELL */
 	    /*   TODO: update models */
 	    if (map_type == 2 || map_type == 3) {
-		if (G_is_null_value(ptr, raster_type))
+		if (Rast_is_null_value(ptr, raster_type))
 		    aspect_c = 0;
 		else
 		    aspect_c = (int)(aspect_f + 0.5);
@@ -393,7 +394,7 @@
 	    if (map_type == 1) {
 		D_use_color(arrow_color);
-		if (G_is_null_value(ptr, raster_type)) {
+		if (Rast_is_null_value(ptr, raster_type)) {
 		    D_use_color(x_color);
 		    draw_x();
@@ -476,7 +477,7 @@
 	    else if (map_type == 4) {
 		    draw_x();
@@ -494,16 +495,16 @@
 	    if (opt7->answer)
 		mag_ptr =
-		    G_incr_void_ptr(mag_ptr, G_raster_size(mag_raster_type));
+		    Rast_incr_void_ptr(mag_ptr, Rast_raster_size(mag_raster_type));
-    G_close_cell(layer_fd);
+    Rast_close_cell(layer_fd);
     if (opt7->answer)
-	G_close_cell(mag_fd);
+	Rast_close_cell(mag_fd);
     R_close_driver();
Modified: grass/trunk/display/d.rast.num/main.c
--- grass/trunk/display/d.rast.num/main.c	2009-06-20 21:39:23 UTC (rev 38002)
+++ grass/trunk/display/d.rast.num/main.c	2009-06-20 22:03:23 UTC (rev 38003)
@@ -38,6 +38,7 @@
 #include <string.h>
 #include <math.h>
@@ -126,12 +127,12 @@
     else
 	fixed_color = 1;
-    layer_fd = G_open_cell_old(map_name, "");
+    layer_fd = Rast_open_cell_old(map_name, "");
     if (layer_fd < 0)
 	G_fatal_error(_("Unable to open raster map <%s>"), map_name);
     /* determine the inputmap type (CELL/FCELL/DCELL) */
-    inmap_type = G_get_raster_map_type(layer_fd);
+    inmap_type = Rast_get_raster_map_type(layer_fd);
     map_type = DCELL_TYPE;
     /* Read in the map window associated with window */
@@ -141,7 +142,7 @@
-	if (G_get_cellhd(map_name, "", &wind) < 0)
+	if (Rast_get_cellhd(map_name, "", &wind) < 0)
 	    G_fatal_error(_("Unable to read header of raster map <%s>"), map_name);
@@ -216,10 +217,10 @@
-    cell = G_allocate_raster_buf(map_type);
+    cell = Rast_allocate_raster_buf(map_type);
     /* read the color table in the color structures of the displayed map */
     /* fixed text color */
@@ -228,12 +229,12 @@
     /* loop through cells, find value, and draw text for value */
-	G_get_raster_row(layer_fd, cell, row, map_type);
+	Rast_get_raster_row(layer_fd, cell, row, map_type);
 	    if (fixed_color == 0) {
-		G_get_raster_color(&cell[col], &R, &G, &B, &colors, map_type);
+		Rast_get_raster_color(&cell[col], &R, &G, &B, &colors, map_type);
 		D_RGB_color(R, G, B);
@@ -241,7 +242,7 @@
     R_close_driver();
@@ -264,13 +265,13 @@
     /* maybe ugly, but works */
     if (map_type == CELL_TYPE) {
-	if (!G_is_c_null_value(&cell))
+	if (!Rast_is_c_null_value(&cell))
 	    sprintf(no, "%d", (int)number);
 	else
 	    sprintf(no, "Null");
     else {
-	if (!G_is_d_null_value(&dcell))
+	if (!Rast_is_d_null_value(&dcell))
 	    sprintf(no, "%.*f", prec, number);
 	else
Modified: grass/trunk/display/d.rgb/main.c
--- grass/trunk/display/d.rgb/main.c	2009-06-20 21:39:23 UTC (rev 38002)
+++ grass/trunk/display/d.rgb/main.c	2009-06-20 22:03:23 UTC (rev 38003)
@@ -21,6 +21,7 @@
 #include <stdlib.h>
 #include <string.h>
@@ -89,16 +90,16 @@
 	char *name = B[i].opt->answer;
-	if ((B[i].file = G_open_cell_old(name, "")) == -1)
+	if ((B[i].file = Rast_open_cell_old(name, "")) == -1)
-	B[i].type = G_get_raster_map_type(B[i].file);
+	B[i].type = Rast_get_raster_map_type(B[i].file);
-	if (G_read_colors(name, "", &B[i].colors) == -1)
+	if (Rast_read_colors(name, "", &B[i].colors) == -1)
-	B[i].array = G_allocate_raster_buf(B[i].type);
+	B[i].array = Rast_allocate_raster_buf(B[i].type);
     /* read in current window */
@@ -111,7 +112,7 @@
 	G_percent(row, window.rows, 5);
 	for (i = 0; i < 3; i++)
-	    if (G_get_raster_row(B[i].file, B[i].array, row, B[i].type) < 0)
+	    if (Rast_get_raster_row(B[i].file, B[i].array, row, B[i].type) < 0)
 		G_fatal_error(_("Error reading row of data"));
 	if (row == next_row)
@@ -132,7 +133,7 @@
-	G_close_cell(B[i].file);
+	Rast_close_cell(B[i].file);
     exit(EXIT_SUCCESS);
Modified: grass/trunk/display/d.thematic.area/area.c
--- grass/trunk/display/d.thematic.area/area.c	2009-06-20 21:39:23 UTC (rev 38002)
+++ grass/trunk/display/d.thematic.area/area.c	2009-06-20 22:03:23 UTC (rev 38003)
@@ -4,6 +4,7 @@
 #include <string.h>
 #include <stdlib.h>
Modified: grass/trunk/display/d.thematic.area/main.c
--- grass/trunk/display/d.thematic.area/main.c	2009-06-20 21:39:23 UTC (rev 38002)
+++ grass/trunk/display/d.thematic.area/main.c	2009-06-20 22:03:23 UTC (rev 38003)
@@ -19,6 +19,7 @@
 #include <dirent.h>
 #include <grass/config.h>
@@ -272,7 +273,7 @@
     /*get border line color */
     bcolor = G_standard_color_rgb(WHITE);
-    ret = G_str_to_color(bcolor_opt->answer, &r, &g, &b);
+    ret = Rast_str_to_color(bcolor_opt->answer, &r, &g, &b);
     if (ret == 1) {
 	has_color = 1;
 	bcolor.r = r;
@@ -347,7 +348,7 @@
 		G_fatal_error(_("Not enough colors or error in color specifications.\nNeed %i colors."),
 			      nclass);
-	    ret = G_str_to_color(colors_opt->answers[i], &r, &g, &b);
+	    ret = Rast_str_to_color(colors_opt->answers[i], &r, &g, &b);
 	    if (!ret)
 		G_fatal_error(_("Error interpreting color %s"),
 			      colors_opt->answers[i]);
Modified: grass/trunk/display/d.thematic.area/plot1.c
--- grass/trunk/display/d.thematic.area/plot1.c	2009-06-20 21:39:23 UTC (rev 38002)
+++ grass/trunk/display/d.thematic.area/plot1.c	2009-06-20 22:03:23 UTC (rev 38003)
@@ -2,6 +2,7 @@
 #include <string.h>
@@ -267,7 +268,7 @@
 			G_debug(3, "element %d: colorstring: %s", line,
 				colorstring);
-			if (G_str_to_color(colorstring, &red, &grn, &blu) ==
+			if (Rast_str_to_color(colorstring, &red, &grn, &blu) ==
 			    1) {
 			    custom_rgb = TRUE;
 			    G_debug(3, "element:%d  cat %d r:%d g:%d b:%d",
Modified: grass/trunk/display/d.title/fancy.c
--- grass/trunk/display/d.title/fancy.c	2009-06-20 21:39:23 UTC (rev 38002)
+++ grass/trunk/display/d.title/fancy.c	2009-06-20 22:03:23 UTC (rev 38003)
@@ -1,4 +1,5 @@
 void fancy(struct Cell_head *window, struct Categories *cats, FILE * fp)
Modified: grass/trunk/display/d.title/main.c
--- grass/trunk/display/d.title/main.c	2009-06-20 21:39:23 UTC (rev 38002)
+++ grass/trunk/display/d.title/main.c	2009-06-20 22:03:23 UTC (rev 38003)
@@ -21,6 +21,7 @@
@@ -103,11 +104,11 @@
     if (!strlen(map_name))
 	G_fatal_error(_("No map name given"));
-    if (G_get_cellhd(map_name, "", &window) == -1)
+    if (Rast_get_cellhd(map_name, "", &window) == -1)
 		      map_name);
 	G_fatal_error(_("Unable to read category file of raster map <%s>"),
 		      map_name);
Modified: grass/trunk/display/d.title/normal.c
--- grass/trunk/display/d.title/normal.c	2009-06-20 21:39:23 UTC (rev 38002)
+++ grass/trunk/display/d.title/normal.c	2009-06-20 22:03:23 UTC (rev 38003)
@@ -1,4 +1,5 @@
Modified: grass/trunk/display/d.vect/area.c
--- grass/trunk/display/d.vect/area.c	2009-06-20 21:39:23 UTC (rev 38002)
+++ grass/trunk/display/d.vect/area.c	2009-06-20 22:03:23 UTC (rev 38003)
@@ -4,6 +4,7 @@
 #include <string.h>
@@ -242,8 +243,8 @@
 		    area, centroid, cat, Points->x[0], Points->y[0],
 		    Points->z[0]);
 	    rgb = 1;
-	    G_make_fp_colors(&colors, style, box.B, box.T);
-	    G_get_raster_color(&zval, &red, &grn, &blu, &colors, DCELL_TYPE);
+	    Rast_make_fp_colors(&colors, style, box.B, box.T);
+	    Rast_get_raster_color(&zval, &red, &grn, &blu, &colors, DCELL_TYPE);
 	    G_debug(3, "b %d, g: %d, r %d", blu, grn, red);
@@ -267,7 +268,7 @@
 			G_debug(3, "area %d: colorstring: %s", area,
 				colorstring);
 			    1) {
 			    rgb = 1;
 			    G_debug(3, "area:%d  cat %d r:%d g:%d b:%d", area,
Modified: grass/trunk/display/d.vect/attr.c
--- grass/trunk/display/d.vect/attr.c	2009-06-20 21:39:23 UTC (rev 38002)
+++ grass/trunk/display/d.vect/attr.c	2009-06-20 22:03:23 UTC (rev 38003)
@@ -1,5 +1,6 @@
 #include <string.h>
Modified: grass/trunk/display/d.vect/dir.c
--- grass/trunk/display/d.vect/dir.c	2009-06-20 21:39:23 UTC (rev 38002)
+++ grass/trunk/display/d.vect/dir.c	2009-06-20 22:03:23 UTC (rev 38003)
@@ -1,4 +1,5 @@
Modified: grass/trunk/display/d.vect/label.c
--- grass/trunk/display/d.vect/label.c	2009-06-20 21:39:23 UTC (rev 38002)
+++ grass/trunk/display/d.vect/label.c	2009-06-20 22:03:23 UTC (rev 38003)
@@ -1,4 +1,5 @@
Modified: grass/trunk/display/d.vect/main.c
--- grass/trunk/display/d.vect/main.c	2009-06-20 21:39:23 UTC (rev 38002)
+++ grass/trunk/display/d.vect/main.c	2009-06-20 22:03:23 UTC (rev 38003)
@@ -18,6 +18,7 @@
 #include <sys/types.h>
 #include <dirent.h>
@@ -392,7 +393,7 @@
-    ret = G_str_to_color(color_opt->answer, &r, &g, &b);
+    ret = Rast_str_to_color(color_opt->answer, &r, &g, &b);
     if (ret == 1) {
 	has_color = 1;
 	color.r = r;
@@ -407,7 +408,7 @@
     fcolor = G_standard_color_rgb(WHITE);
-    ret = G_str_to_color(fcolor_opt->answer, &r, &g, &b);
+    ret = Rast_str_to_color(fcolor_opt->answer, &r, &g, &b);
     if (ret == 1) {
 	has_fcolor = 1;
 	fcolor.r = r;
@@ -532,20 +533,20 @@
 	lattr.field = Clist->field;
     lattr.color.R = lattr.color.G = lattr.color.B = 255;
-    if (G_str_to_color(lcolor_opt->answer, &r, &g, &b)) {
+    if (Rast_str_to_color(lcolor_opt->answer, &r, &g, &b)) {
 	lattr.color.R = r;
 	lattr.color.G = g;
 	lattr.color.B = b;
     lattr.has_bgcolor = 0;
-    if (G_str_to_color(bgcolor_opt->answer, &r, &g, &b) == 1) {
+    if (Rast_str_to_color(bgcolor_opt->answer, &r, &g, &b) == 1) {
 	lattr.has_bgcolor = 1;
 	lattr.bgcolor.R = r;
 	lattr.bgcolor.G = g;
 	lattr.bgcolor.B = b;
     lattr.has_bcolor = 0;
-    if (G_str_to_color(bcolor_opt->answer, &r, &g, &b) == 1) {
+    if (Rast_str_to_color(bcolor_opt->answer, &r, &g, &b) == 1) {
 	lattr.has_bcolor = 1;
 	lattr.bcolor.R = r;
 	lattr.bcolor.G = g;
Modified: grass/trunk/display/d.vect/plot1.c
--- grass/trunk/display/d.vect/plot1.c	2009-06-20 21:39:23 UTC (rev 38002)
+++ grass/trunk/display/d.vect/plot1.c	2009-06-20 22:03:23 UTC (rev 38003)
@@ -2,6 +2,7 @@
 #include <string.h>
@@ -257,8 +258,8 @@
 	    G_debug(3, "display line %d, cat %d, x: %f, y: %f, z: %f", line,
 		    cat, Points->x[0], Points->y[0], Points->z[0]);
 	    custom_rgb = TRUE;
@@ -284,7 +285,7 @@
 				colorstring);
 			    1) {
 			    custom_rgb = TRUE;
Modified: grass/trunk/display/d.vect/topo.c
--- grass/trunk/display/d.vect/topo.c	2009-06-20 21:39:23 UTC (rev 38002)
+++ grass/trunk/display/d.vect/topo.c	2009-06-20 22:03:23 UTC (rev 38003)
@@ -1,4 +1,5 @@
Modified: grass/trunk/display/d.vect/utils.c
--- grass/trunk/display/d.vect/utils.c	2009-06-20 21:39:23 UTC (rev 38002)
+++ grass/trunk/display/d.vect/utils.c	2009-06-20 22:03:23 UTC (rev 38003)
@@ -1,4 +1,5 @@
Modified: grass/trunk/display/d.vect/zcoor.c
--- grass/trunk/display/d.vect/zcoor.c	2009-06-20 21:39:23 UTC (rev 38002)
+++ grass/trunk/display/d.vect/zcoor.c	2009-06-20 22:03:23 UTC (rev 38003)
@@ -1,6 +1,7 @@
 /* Print z coordinate value for each node */
Modified: grass/trunk/display/d.vect.chart/bar.c
--- grass/trunk/display/d.vect.chart/bar.c	2009-06-20 21:39:23 UTC (rev 38002)
+++ grass/trunk/display/d.vect.chart/bar.c	2009-06-20 22:03:23 UTC (rev 38003)
@@ -1,4 +1,5 @@
 #include <grass/dbmi.h>
Modified: grass/trunk/display/d.vect.chart/main.c
--- grass/trunk/display/d.vect.chart/main.c	2009-06-20 21:39:23 UTC (rev 38002)
+++ grass/trunk/display/d.vect.chart/main.c	2009-06-20 22:03:23 UTC (rev 38003)
@@ -18,6 +18,7 @@
 #include <stdlib.h>
 #include <string.h>
@@ -170,7 +171,7 @@
     field = atoi(field_opt->answer);
     /* Outline color */
-    ret = G_str_to_color(ocolor_opt->answer, &r, &g, &b);
+    ret = Rast_str_to_color(ocolor_opt->answer, &r, &g, &b);
     if (ret == 1) {
 	ocolor.none = 0;
 	ocolor.r = r;
@@ -214,7 +215,7 @@
 	    if (colors_opt->answers[i] == NULL)
 		break;
 	    if (ret == 1) {
 		colors[i].none = 0;
 		colors[i].r = r;
Modified: grass/trunk/display/d.vect.chart/pie.c
--- grass/trunk/display/d.vect.chart/pie.c	2009-06-20 21:39:23 UTC (rev 38002)
+++ grass/trunk/display/d.vect.chart/pie.c	2009-06-20 22:03:23 UTC (rev 38003)
@@ -1,5 +1,6 @@
 #include <math.h>
Modified: grass/trunk/display/d.vect.chart/plot.c
--- grass/trunk/display/d.vect.chart/plot.c	2009-06-20 21:39:23 UTC (rev 38002)
+++ grass/trunk/display/d.vect.chart/plot.c	2009-06-20 22:03:23 UTC (rev 38003)
@@ -1,4 +1,5 @@
Modified: grass/trunk/display/d.what.rast/main.c
--- grass/trunk/display/d.what.rast/main.c	2009-06-20 21:39:23 UTC (rev 38002)
+++ grass/trunk/display/d.what.rast/main.c	2009-06-20 22:03:23 UTC (rev 38003)
@@ -123,7 +123,7 @@
 	    if (j > mwidth)
 		mwidth = j;
-	    if (G_read_cats(name[i], mapset[i], &cats[i]) < 0)
+	    if (Rast_read_cats(name[i], mapset[i], &cats[i]) < 0)
 		cats[i].ncats = -1;
Modified: grass/trunk/display/d.what.rast/opencell.c
--- grass/trunk/display/d.what.rast/opencell.c	2009-06-20 21:39:23 UTC (rev 38002)
+++ grass/trunk/display/d.what.rast/opencell.c	2009-06-20 22:03:23 UTC (rev 38003)
@@ -19,7 +19,7 @@
     else
 	strcpy(mapset, m);
-    fd = G_open_cell_old(name, mapset);
+    fd = Rast_open_cell_old(name, mapset);
     if (fd < 0)
 	G_warning(_("Unable to open raster map <%s>"), name);
Modified: grass/trunk/display/d.what.rast/show.c
--- grass/trunk/display/d.what.rast/show.c	2009-06-20 21:39:23 UTC (rev 38002)
+++ grass/trunk/display/d.what.rast/show.c	2009-06-20 22:03:23 UTC (rev 38003)
@@ -19,7 +19,7 @@
 	sprintf(buf, " ");
     if (terse) {
 	fname = G_fully_qualified_name(name, mapset);
-	if (G_is_c_null_value(&cell_val)) {
+	if (Rast_is_c_null_value(&cell_val)) {
 	    if (!isatty(fileno(stdout)))
 		fprintf(stdout, "%s%s%sNull%s%s\n", fname, buf, fs, fs,
 			label);
@@ -33,7 +33,7 @@
     else {
 		fprintf(stdout, "%*s in %-*s%s (Null)%s\n", width, name,
 			mwidth, mapset, buf, label);
@@ -63,7 +63,7 @@
     dcell_val = dval;
     if (terse) {
-	if (G_is_d_null_value(&dcell_val)) {
+	if (Rast_is_d_null_value(&dcell_val)) {
 		fprintf(stdout, "%s, actual %sNull%s%s\n", fname, fs, fs,
 			label);
@@ -78,7 +78,7 @@
     else {
 		fprintf(stdout, "%*s in %-*s, actual  (Null)%s\n", width,
 			name, mwidth, mapset, label);
@@ -120,7 +120,7 @@
     if (once) {
 	/* speed up? */
 	once = 0;
-	G_get_cellhd(name, mapset, &cellhd);
+	Rast_get_cellhd(name, mapset, &cellhd);
     n_row = (int)((cellhd.north - north) / window->ns_res);
Modified: grass/trunk/display/d.what.rast/what.c
--- grass/trunk/display/d.what.rast/what.c	2009-06-20 21:39:23 UTC (rev 38002)
+++ grass/trunk/display/d.what.rast/what.c	2009-06-20 22:03:23 UTC (rev 38003)
@@ -23,14 +23,14 @@
     G_get_set_window(&window);
     nrows = window.rows;
     ncols = window.cols;
-    buf = G_allocate_c_raster_buf();
-    dbuf = G_allocate_d_raster_buf();
+    buf = Rast_allocate_c_raster_buf();
+    dbuf = Rast_allocate_d_raster_buf();
     screen_x = ((int)D_get_d_west() + (int)D_get_d_east()) / 2;
     screen_y = ((int)D_get_d_north() + (int)D_get_d_south()) / 2;
     for (i = 0; i < nrasts; i++)
-	map_type[i] = G_get_raster_map_type(fd[i]);
+	map_type[i] = Rast_get_raster_map_type(fd[i]);
     do {
 	if (!terse)
@@ -50,19 +50,19 @@
 	show_utm(name[0], mapset[0], north, east, &window, terse, colrow,
 		 button, fs);
-	G_set_d_null_value(&null_dcell, 1);
+	Rast_set_d_null_value(&null_dcell, 1);
 	for (i = 0; i < nrasts; i++) {
 	    if (row < 0 || row >= nrows || col < 0 || col >= ncols) {
 		G_message(_("You are clicking outside the map"));
 		continue;
-	    if (G_get_c_raster_row(fd[i], buf, row) < 0)
+	    if (Rast_get_c_raster_row(fd[i], buf, row) < 0)
 		show_cat(width, mwidth, name[i], mapset[i], null_cell,
 			 "ERROR reading raster map", terse, fs, map_type[i]);
 	    else if (map_type[i] == CELL_TYPE) {
 		show_cat(width, mwidth, name[i], mapset[i], buf[col],
-			 G_get_c_raster_cat(&buf[col], &cats[i]), terse, fs,
+			 Rast_get_c_raster_cat(&buf[col], &cats[i]), terse, fs,
 			 map_type[i]);
 		continue;
@@ -75,12 +75,12 @@
 		continue;
-	    if (G_get_d_raster_row(fd[i], dbuf, row) < 0)
+	    if (Rast_get_d_raster_row(fd[i], dbuf, row) < 0)
 		show_dval(width, mwidth, name[i], mapset[i], null_dcell,
 			  "ERROR reading fcell file", terse, fs);
 	    else
 		show_dval(width, mwidth, name[i], mapset[i], dbuf[col],
-			  G_get_d_raster_cat(&dbuf[col], &cats[i]), terse,
+			  Rast_get_d_raster_cat(&dbuf[col], &cats[i]), terse,
 			  fs);
Modified: grass/trunk/display/d.zoom/main.c
--- grass/trunk/display/d.zoom/main.c	2009-06-20 21:39:23 UTC (rev 38002)
+++ grass/trunk/display/d.zoom/main.c	2009-06-20 22:03:23 UTC (rev 38003)
@@ -138,7 +138,7 @@
 	nrasts = i;
-	    if (G_get_cellhd(rast[i], "", &window) >= 0) {
+	    if (Rast_get_cellhd(rast[i], "", &window) >= 0) {
 		if (first) {
 		    first = 0;
 		    U_east = window.east;
Modified: grass/trunk/display/d.zoom/set.c
--- grass/trunk/display/d.zoom/set.c	2009-06-20 21:39:23 UTC (rev 38002)
+++ grass/trunk/display/d.zoom/set.c	2009-06-20 22:03:23 UTC (rev 38003)
@@ -176,7 +176,7 @@
 	limit = print_limit(window, &defwin);
-	G_adjust_Cell_head3(window, 0, 0, 0);
+	Rast_adjust_Cell_head3(window, 0, 0, 0);
 	G_put_window(window);
 	G_set_window(window);
 	redraw();
Modified: grass/trunk/doc/raster/r.example/main.c
--- grass/trunk/doc/raster/r.example/main.c	2009-06-20 21:39:23 UTC (rev 38002)
+++ grass/trunk/doc/raster/r.example/main.c	2009-06-20 22:03:23 UTC (rev 38003)
@@ -111,29 +111,29 @@
-    data_type = G_raster_map_type(name, mapset);
+    data_type = Rast_raster_map_type(name, mapset);
-    /* G_open_cell_old - returns file destriptor (>0) */
-    if ((infd = G_open_cell_old(name, mapset)) < 0)
+    /* Rast_open_cell_old - returns file destriptor (>0) */
+    if ((infd = Rast_open_cell_old(name, mapset)) < 0)
     /* controlling, if we can open input raster */
-    if (G_get_cellhd(name, mapset, &cellhd) < 0)
+    if (Rast_get_cellhd(name, mapset, &cellhd) < 0)
 	G_fatal_error(_("Unable to read file header of <%s>"), name);
     G_debug(3, "number of rows %d", cellhd.rows);
     /* Allocate input buffer */
-    inrast = G_allocate_raster_buf(data_type);
+    inrast = Rast_allocate_raster_buf(data_type);
     /* Allocate output buffer, use input map data_type */
-    outrast = G_allocate_raster_buf(data_type);
+    outrast = Rast_allocate_raster_buf(data_type);
     /* controlling, if we can write the raster */
-    if ((outfd = G_open_raster_new(result, data_type)) < 0)
+    if ((outfd = Rast_open_raster_new(result, data_type)) < 0)
 	G_fatal_error(_("Unable to create raster map <%s>"), result);
     /* for each row */
@@ -146,7 +146,7 @@
 	    G_percent(row, nrows, 2);
 	/* read input map */
-	if (G_get_raster_row(infd, inrast, row, data_type) < 0)
+	if (Rast_get_raster_row(infd, inrast, row, data_type) < 0)
 	    G_fatal_error(_("Unable to read raster map <%s> row %d"), name,
 			  row);
@@ -173,7 +173,7 @@
 	/* write raster row to output raster map */
-	if (G_put_raster_row(outfd, outrast, data_type) < 0)
+	if (Rast_put_raster_row(outfd, outrast, data_type) < 0)
 	    G_fatal_error(_("Failed writing raster map <%s>"), result);
@@ -182,13 +182,13 @@
     G_free(outrast);
     /* closing raster maps */
-    G_close_cell(infd);
-    G_close_cell(outfd);
+    Rast_close_cell(infd);
+    Rast_close_cell(outfd);
     /* add command line incantation to history file */
-    G_short_history(result, "raster", &history);
-    G_command_history(&history);
-    G_write_history(result, &history);
+    Rast_short_history(result, "raster", &history);
+    Rast_command_history(&history);
+    Rast_write_history(result, &history);
     exit(EXIT_SUCCESS);
Modified: grass/trunk/general/g.mremove/check_reclass.c
--- grass/trunk/general/g.mremove/check_reclass.c	2009-06-20 21:39:23 UTC (rev 38002)
+++ grass/trunk/general/g.mremove/check_reclass.c	2009-06-20 22:03:23 UTC (rev 38003)
@@ -1,4 +1,7 @@
 #include <string.h>
 #include "global.h"
 int check_reclass(const char *name, const char *mapset, int force)
@@ -7,7 +10,7 @@
     char **rmaps;
     int nrmaps;
-    if (G_is_reclassed_to(name, mapset, &nrmaps, &rmaps) > 0) {
+    if (Rast_is_reclassed_to(name, mapset, &nrmaps, &rmaps) > 0) {
 	for (; *rmaps; rmaps++) {
 	    /* force remove */
 	    if (force)
@@ -23,8 +26,8 @@
 	    return 1;
-    if (G_is_reclass(name, mapset, rname, rmapset) > 0 &&
-	G_is_reclassed_to(rname, rmapset, &nrmaps, &rmaps) > 0) {
+    if (Rast_is_reclass(name, mapset, rname, rmapset) > 0 &&
+	Rast_is_reclassed_to(rname, rmapset, &nrmaps, &rmaps) > 0) {
 	char path[GPATH_MAX];
 	char *p = strchr(rname, '@');
 	char *qname = G_fully_qualified_name(name, mapset);
Modified: grass/trunk/general/g.mremove/wc2regex.c
--- grass/trunk/general/g.mremove/wc2regex.c	2009-06-20 21:39:23 UTC (rev 38002)
+++ grass/trunk/general/g.mremove/wc2regex.c	2009-06-20 22:03:23 UTC (rev 38003)
@@ -1,4 +1,5 @@
 char *wc2regex(const char *wc)
Modified: grass/trunk/general/g.region/adjust.c
--- grass/trunk/general/g.region/adjust.c	2009-06-20 21:39:23 UTC (rev 38002)
+++ grass/trunk/general/g.region/adjust.c	2009-06-20 22:03:23 UTC (rev 38003)
@@ -1,10 +1,11 @@
 void adjust_window(struct Cell_head *window, int row_flag, int col_flag, int depth_flag)
-    const char *err = G_adjust_Cell_head3(window, row_flag, col_flag, depth_flag);
+    const char *err = Rast_adjust_Cell_head3(window, row_flag, col_flag, depth_flag);
     if (err)
 	G_fatal_error(_("Invalid region: %s"), err);
Modified: grass/trunk/general/g.region/main.c
--- grass/trunk/general/g.region/main.c	2009-06-20 21:39:23 UTC (rev 38002)
+++ grass/trunk/general/g.region/main.c	2009-06-20 22:03:23 UTC (rev 38003)
@@ -16,6 +16,7 @@
 #include <string.h>
 #include <stdlib.h>
 #include <grass/G3d.h>
@@ -441,7 +442,7 @@
 	    mapset = G_find_cell2(rast_name, "");
 	    if (!mapset)
 		G_fatal_error(_("Raster map <%s> not found"), rast_name);
-	    if (G_get_cellhd(rast_name, mapset, &temp_window) < 0)
+	    if (Rast_get_cellhd(rast_name, mapset, &temp_window) < 0)
 		G_fatal_error(_("Unable to read header of raster map <%s@%s>"),
 			      rast_name, mapset);
 	    if (!first) {
@@ -459,7 +460,7 @@
 		    window.west : temp_window.west;
-	G_adjust_Cell_head3(&window, 0, 0, 0);
+	Rast_adjust_Cell_head3(&window, 0, 0, 0);
@@ -775,7 +776,7 @@
 	mapset = G_find_cell2(name, "");
 	if (!mapset)
-	if (G_get_cellhd(name, mapset, &temp_window) < 0)
+	if (Rast_get_cellhd(name, mapset, &temp_window) < 0)
 			  name, mapset);
 	if ((err = G_align_window(&window, &temp_window)))
Modified: grass/trunk/general/g.region/printwindow.c
--- grass/trunk/general/g.region/printwindow.c	2009-06-20 21:39:23 UTC (rev 38002)
+++ grass/trunk/general/g.region/printwindow.c	2009-06-20 22:03:23 UTC (rev 38003)
@@ -2,6 +2,7 @@
 #include <stdlib.h>
 #include <projects.h>
Modified: grass/trunk/general/g.region/zoom.c
--- grass/trunk/general/g.region/zoom.c	2009-06-20 21:39:23 UTC (rev 38002)
+++ grass/trunk/general/g.region/zoom.c	2009-06-20 22:03:23 UTC (rev 38003)
@@ -1,5 +1,6 @@
 #include <stdlib.h>
@@ -18,12 +19,12 @@
     nrows = window->rows;
     ncols = window->cols;
     if (fd < 0)
 	G_fatal_error(_("Unable to open raster map <%s> in <%s>"),
 		      name, mapset);
-    map_type = G_get_raster_map_type(fd);
-    raster = G_allocate_raster_buf(map_type);
+    map_type = Rast_get_raster_map_type(fd);
+    raster = Rast_allocate_raster_buf(map_type);
     /* find first non-null row */
     top = nrows;
@@ -31,12 +32,12 @@
     left = ncols;
     right = -1;
-	if (G_get_raster_row(fd, rast_ptr = raster, row, map_type) < 0)
+	if (Rast_get_raster_row(fd, rast_ptr = raster, row, map_type) < 0)
 	    G_fatal_error(_("Could not read from <%s>"), name);
-	    if (!G_is_null_value(rast_ptr, map_type))
+	    if (!Rast_is_null_value(rast_ptr, map_type))
 		break;
-	    rast_ptr = G_incr_void_ptr(rast_ptr, G_raster_size(map_type));
+	    rast_ptr = Rast_incr_void_ptr(rast_ptr, Rast_raster_size(map_type));
 	if (col == ncols)
 	    continue;
@@ -47,14 +48,14 @@
 	if (col < left)
 	    left = col;
 	for (mark = col; col < ncols; col++) {
 		mark = col;
 	if (mark > right)
 	    right = mark;
-    G_close_cell(fd);
     G_free(raster);
     /* no data everywhere? */
Modified: grass/trunk/general/g.remove/main.c
--- grass/trunk/general/g.remove/main.c	2009-06-20 21:39:23 UTC (rev 38002)
+++ grass/trunk/general/g.remove/main.c	2009-06-20 22:03:23 UTC (rev 38003)
@@ -20,6 +20,8 @@
 #include <stdlib.h>
 #include <string.h>
 #include <grass/list.h>
@@ -29,7 +31,7 @@
     char **rmaps;
     int nrmaps;
 	    /* force remove */
 	    if (force)
@@ -44,8 +46,8 @@
 	    return 1;
Modified: grass/trunk/general/g.rename/main.c
--- grass/trunk/general/g.rename/main.c	2009-06-20 21:39:23 UTC (rev 38002)
+++ grass/trunk/general/g.rename/main.c	2009-06-20 22:03:23 UTC (rev 38003)
@@ -20,6 +20,7 @@
 #include <stdlib.h>
 #include <string.h>
@@ -93,7 +94,7 @@
 		continue;
-	    if (G_is_reclassed_to(old, mapset, &nrmaps, &rmaps) > 0) {
+	    if (Rast_is_reclassed_to(old, mapset, &nrmaps, &rmaps) > 0) {
 		int ptr, l;
 		char buf1[256], buf2[256], buf3[256], *str;
 		FILE *fp;
Modified: grass/trunk/general/manage/lister/cell.c
--- grass/trunk/general/manage/lister/cell.c	2009-06-20 21:39:23 UTC (rev 38002)
+++ grass/trunk/general/manage/lister/cell.c	2009-06-20 22:03:23 UTC (rev 38003)
@@ -1,6 +1,7 @@
 #include <stdlib.h>
 #include <string.h>
 int main(int argc, char *argv[])
@@ -16,7 +17,7 @@
     *title = 0;
     if (*name)
-	strcpy(title, G_get_cell_title(name, mapset));
+	strcpy(title, Rast_get_cell_title(name, mapset));
     return 0;
Modified: grass/trunk/general/manage/lister/vector.c
--- grass/trunk/general/manage/lister/vector.c	2009-06-20 21:39:23 UTC (rev 38002)
+++ grass/trunk/general/manage/lister/vector.c	2009-06-20 22:03:23 UTC (rev 38003)
@@ -1,6 +1,7 @@
 #include <stdlib.h>
 #include <string.h>
Modified: grass/trunk/imagery/i.albedo/main.c
--- grass/trunk/imagery/i.albedo/main.c	2009-06-20 21:39:23 UTC (rev 38002)
+++ grass/trunk/imagery/i.albedo/main.c	2009-06-20 22:03:23 UTC (rev 38003)
@@ -18,6 +18,7 @@
 #include <stdlib.h>
 #include <string.h>
 #define MAXFILES 8
@@ -146,19 +147,19 @@
 	    G_fatal_error(_("Too many input maps. Only %d allowed."), MAXFILES);
 	name = *ptr;
-	infd[nfiles] = G_open_cell_old(name, "");
+	infd[nfiles] = Rast_open_cell_old(name, "");
 	if (infd[nfiles] < 0)
 	    continue;
-	in_data_type[nfiles] = G_raster_map_type(name, "");
-	if ((infd[nfiles] = G_open_cell_old(name, "")) < 0)
+	in_data_type[nfiles] = Rast_raster_map_type(name, "");
+	if ((infd[nfiles] = Rast_open_cell_old(name, "")) < 0)
-	if ((G_get_cellhd(name, "", &cellhd)) < 0)
+	if ((Rast_get_cellhd(name, "", &cellhd)) < 0)
 	    G_fatal_error(_("Unable to read header of raster map <%s>"), name);
-	inrast[nfiles] = G_allocate_raster_buf(in_data_type[nfiles]);
+	inrast[nfiles] = Rast_allocate_raster_buf(in_data_type[nfiles]);
 	nfiles++;
     nfiles--;
@@ -168,10 +169,10 @@
-    outrast = G_allocate_raster_buf(out_data_type);
+    outrast = Rast_allocate_raster_buf(out_data_type);
     /* Create New raster files */
-    if ((outfd = G_open_raster_new(result, 1)) < 0)
+    if ((outfd = Rast_open_raster_new(result, 1)) < 0)
     /*START ALBEDO HISTOGRAM STRETCH */
@@ -189,7 +190,7 @@
 	    for (i = 1; i <= nfiles; i++) {
-		if ((G_get_raster_row(
+		if ((Rast_get_raster_row(
 			 infd[i], inrast[i], row, in_data_type[i])) < 0)
 		    G_fatal_error(_("Unable to read raster map <%s> row %d >"),
 				  name, row);
@@ -222,7 +223,7 @@
 		else if (aster) {
 		    de = bb_alb_aster(d[1], d[2], d[3], d[4], d[5], d[6]);
-		if (G_is_d_null_value(&de)) {
+		if (Rast_is_d_null_value(&de)) {
 		    /*Do nothing */
 		else {
@@ -347,7 +348,7 @@
 			      name, row);
@@ -385,24 +386,24 @@
 	    ((DCELL *) outrast)[col] = de;
-	if (G_put_raster_row(outfd, outrast, out_data_type) < 0)
+	if (Rast_put_raster_row(outfd, outrast, out_data_type) < 0)
 	    G_fatal_error(_("Failed writing raster map <%s> row %d"),
 			  result, row);
 	G_free(inrast[i]);
-	G_close_cell(infd[i]);
+	Rast_close_cell(infd[i]);
     G_free(outrast);
     /* Color table from 0.0 to 1.0 */
-    G_init_colors(&colors);
-    G_add_color_rule(0.0, 0, 0, 0, 1.0, 255, 255, 255, &colors);
+    Rast_init_colors(&colors);
+    Rast_add_color_rule(0.0, 0, 0, 0, 1.0, 255, 255, 255, &colors);
     /* Metadata */
     exit(EXIT_SUCCESS);
Modified: grass/trunk/imagery/i.atcorr/main.cpp
--- grass/trunk/imagery/i.atcorr/main.cpp	2009-06-20 21:39:23 UTC (rev 38002)
+++ grass/trunk/imagery/i.atcorr/main.cpp	2009-06-20 22:03:23 UTC (rev 38003)
@@ -37,6 +37,7 @@
 extern "C" {
@@ -95,7 +96,7 @@
     struct Cell_head iimg_head;	/* the input image header file */
-    if(G_get_cellhd(name, mapset, &iimg_head) < 0)
+    if(Rast_get_cellhd(name, mapset, &iimg_head) < 0)
 	G_fatal_error (_("Unable to read header of raster map <%s>"),
 		       G_fully_qualified_name(name, mapset));
@@ -120,10 +121,10 @@
     CELL* cbuf;
     int col;
-    cbuf = (CELL*)G_allocate_raster_buf(CELL_TYPE);
+    cbuf = (CELL*)Rast_allocate_raster_buf(CELL_TYPE);
     for(col = 0; col < G_window_cols(); col++) cbuf[col] = round_c(buf[col]);
-    G_put_raster_row(ofd, cbuf, CELL_TYPE);
+    Rast_put_raster_row(ofd, cbuf, CELL_TYPE);
@@ -292,9 +293,9 @@
     TICache ticache;    /* use this to increase computation speed when an elevation map with categories are given */
     /* allocate memory for buffers */
-    buf = (FCELL*)G_allocate_raster_buf(FCELL_TYPE);
-    if(ialt_fd >= 0) alt = (FCELL*)G_allocate_raster_buf(FCELL_TYPE);
-    if(ivis_fd >= 0) vis = (FCELL*)G_allocate_raster_buf(FCELL_TYPE);
+    buf = (FCELL*)Rast_allocate_raster_buf(FCELL_TYPE);
+    if(ialt_fd >= 0) alt = (FCELL*)Rast_allocate_raster_buf(FCELL_TYPE);
+    if(ivis_fd >= 0) vis = (FCELL*)Rast_allocate_raster_buf(FCELL_TYPE);
     G_verbose_message(_("Percent complete..."));
@@ -305,30 +306,30 @@
 	G_percent(row, nrows, 1);     /* keep the user informed of our progress */
         /* read the next row */
-	if(G_get_raster_row(ifd, buf, row, FCELL_TYPE) < 0)
+	if(Rast_get_raster_row(ifd, buf, row, FCELL_TYPE) < 0)
 	    G_fatal_error (_("Unable to read input raster map row %d"),
 			     row);
         /* read the next row of elevation values */
         if(ialt_fd >= 0)
-	    if(G_get_raster_row(ialt_fd, alt, row, FCELL_TYPE) < 0)
+	    if(Rast_get_raster_row(ialt_fd, alt, row, FCELL_TYPE) < 0)
 		G_fatal_error (_("Unable to read elevation raster map row %d"),
 			       row);
         if(ivis_fd >= 0)
-	    if(G_get_raster_row(ivis_fd, vis, row, FCELL_TYPE) < 0)
+	    if(Rast_get_raster_row(ivis_fd, vis, row, FCELL_TYPE) < 0)
 		G_fatal_error (_("Unable to read visibility raster map row %d"),
 			       row);
         /* loop over all the values in the row */
 	for(col = 0; col < ncols; col++)
-	    if(vis && G_is_f_null_value(&vis[col]) ||
-	       alt && G_is_f_null_value(&alt[col]) ||
-	              G_is_f_null_value(&buf[col]))
+	    if(vis && Rast_is_f_null_value(&vis[col]) ||
+	       alt && Rast_is_f_null_value(&alt[col]) ||
+	              Rast_is_f_null_value(&buf[col]))
-	        G_set_f_null_value(&buf[col], 1);
+	        Rast_set_f_null_value(&buf[col], 1);
 	        continue;
 	    alt[col] /= 1000.0f; /* converting to km from input which should be in meter */
@@ -404,7 +405,7 @@
         /* write output */
-	if(oflt) G_put_raster_row(ofd, buf, FCELL_TYPE);
+	if(oflt) Rast_put_raster_row(ofd, buf, FCELL_TYPE);
 	else write_fp_to_cell(ofd, buf);
@@ -421,8 +422,8 @@
-    G_read_colors(iname, imapset, &colors);
-    G_write_colors(oname, G_mapset(), &colors);
+    Rast_read_colors(iname, imapset, &colors);
+    Rast_write_colors(oname, G_mapset(), &colors);
@@ -588,7 +589,7 @@
     /* open input raster */
     if ( (iimg_mapset = G_find_cell2 ( opts.iimg->answer, "") ) == NULL )
 	G_fatal_error ( _("Raster map <%s> not found"), opts.iimg->answer);
-    if((iimg_fd = G_open_cell_old(opts.iimg->answer, iimg_mapset)) < 0)
+    if((iimg_fd = Rast_open_cell_old(opts.iimg->answer, iimg_mapset)) < 0)
 	G_fatal_error (_("Unable to open raster map <%s>"),
 		       G_fully_qualified_name(opts.iimg->answer, iimg_mapset));
@@ -597,7 +598,7 @@
     if(opts.ialt->answer) {
 	if ( (ialt_mapset = G_find_cell2 ( opts.ialt->answer, "") ) == NULL )
 	    G_fatal_error ( _("Raster map <%s> not found"), opts.ialt->answer);
-	if((ialt_fd = G_open_cell_old(opts.ialt->answer, ialt_mapset)) < 0)
+	if((ialt_fd = Rast_open_cell_old(opts.ialt->answer, ialt_mapset)) < 0)
 			   G_fully_qualified_name(opts.ialt->answer, ialt_mapset));
@@ -605,7 +606,7 @@
     if(opts.ivis->answer) {
 	if ( (iviz_mapset = G_find_cell2 ( opts.ivis->answer, "") ) == NULL )
 	    G_fatal_error ( _("Raster map <%s> not found"), opts.ivis->answer);
-	if((ivis_fd = G_open_cell_old(opts.ivis->answer, iviz_mapset)) < 0)
+	if((ivis_fd = Rast_open_cell_old(opts.ivis->answer, iviz_mapset)) < 0)
 			   G_fully_qualified_name(opts.ivis->answer, iviz_mapset));
@@ -613,13 +614,13 @@
     /* open a floating point raster or not? */
     if(opts.oflt->answer)
-	if((oimg_fd = G_open_fp_cell_new(opts.oimg->answer)) < 0)
+	if((oimg_fd = Rast_open_fp_cell_new(opts.oimg->answer)) < 0)
 	    G_fatal_error (_("Unable to create raster map <%s>"),
 			   opts.oimg->answer);
     else
-	if((oimg_fd = G_open_raster_new(opts.oimg->answer, CELL_TYPE)) < 0)
+	if((oimg_fd = Rast_open_raster_new(opts.oimg->answer, CELL_TYPE)) < 0)
 			   opts.oimg->answer);
@@ -644,14 +645,14 @@
     /* Close the input and output file descriptors */
-    G_short_history(opts.oimg->answer, "raster", &hist);
-    G_close_cell(iimg_fd);
-    if(opts.ialt->answer) G_close_cell(ialt_fd);
-    if(opts.ivis->answer) G_close_cell(ivis_fd);
-    G_close_cell(oimg_fd);
+    Rast_short_history(opts.oimg->answer, "raster", &hist);
+    Rast_close_cell(iimg_fd);
+    if(opts.ialt->answer) Rast_close_cell(ialt_fd);
+    if(opts.ivis->answer) Rast_close_cell(ivis_fd);
+    Rast_close_cell(oimg_fd);
-    G_command_history(&hist);
-    G_write_history(opts.oimg->answer, &hist);
+    Rast_command_history(&hist);
+    Rast_write_history(opts.oimg->answer, &hist);
     /* Copy the colors of the input raster to the output raster.
        Scaling is ignored and color ranges might not be correct. */
Modified: grass/trunk/imagery/i.cca/main.c
--- grass/trunk/imagery/i.cca/main.c	2009-06-20 21:39:23 UTC (rev 38002)
+++ grass/trunk/imagery/i.cca/main.c	2009-06-20 22:03:23 UTC (rev 38003)
@@ -38,6 +38,7 @@
 #include <string.h>
 #include <math.h>
+#include <grass/Rast.h>
 #include <grass/imagery.h>
 #include <grass/gmath.h>
@@ -167,14 +168,14 @@
 	outbandmax[i] = (CELL) 0;
 	outbandmin[i] = (CELL) 0;
-	if ((datafds[i] = G_open_cell_old(refs.file[i - 1].name,
+	if ((datafds[i] = Rast_open_cell_old(refs.file[i - 1].name,
 					  refs.file[i - 1].mapset)) < 0) {
 	    G_fatal_error(_("Cannot open raster map <%s>"),
 			  refs.file[i - 1].name);
 	sprintf(tempname, "%s.%d", out_opt->answer, i);
-	if ((outfds[i] = G_open_cell_new(tempname)) < 0)
+	if ((outfds[i] = Rast_open_cell_new(tempname)) < 0)
 	    G_fatal_error(_("Cannot create raster map <%s>"), tempname);
@@ -183,23 +184,23 @@
 	      outbandmin, outbandmax);
     /* make grey scale color table */
-    G_init_colors(&color_tbl);
+    Rast_init_colors(&color_tbl);
     /* close the cell maps */
     for (i = 1; i <= bands; i++) {
-	G_close_cell(datafds[i]);
-	G_close_cell(outfds[i]);
+	Rast_close_cell(datafds[i]);
+	Rast_close_cell(outfds[i]);
 	if (outbandmin[i] < (CELL) 0 || outbandmax[i] > (CELL) 255) {
 	    G_warning(_("The output cell map <%s.%d> has values "
 			"outside the 0-255 range."), out_opt->answer, i);
-	G_make_grey_scale_colors(&color_tbl, 0, outbandmax[i]);
+	Rast_make_grey_scale_colors(&color_tbl, 0, outbandmax[i]);
 	/* write a color table */
-	G_write_colors(tempname, G_mapset(), &color_tbl);
+	Rast_write_colors(tempname, G_mapset(), &color_tbl);
     I_free_signatures(&sigs);
Modified: grass/trunk/imagery/i.cca/matrix.c
--- grass/trunk/imagery/i.cca/matrix.c	2009-06-20 21:39:23 UTC (rev 38002)
+++ grass/trunk/imagery/i.cca/matrix.c	2009-06-20 22:03:23 UTC (rev 38003)
@@ -1,5 +1,6 @@
 #include <math.h>
 #include <grass/gis.h>
Modified: grass/trunk/imagery/i.cca/stats.c
--- grass/trunk/imagery/i.cca/stats.c	2009-06-20 21:39:23 UTC (rev 38002)
+++ grass/trunk/imagery/i.cca/stats.c	2009-06-20 22:03:23 UTC (rev 38003)
@@ -1,4 +1,5 @@
Modified: grass/trunk/imagery/i.cca/transform.c
--- grass/trunk/imagery/i.cca/transform.c	2009-06-20 21:39:23 UTC (rev 38002)
+++ grass/trunk/imagery/i.cca/transform.c	2009-06-20 22:03:23 UTC (rev 38003)
@@ -1,5 +1,6 @@
 #include <stdlib.h>
@@ -14,13 +15,13 @@
     /* allocate row buffers for each band */
-	if ((rowbufs[i] = G_allocate_cell_buf()) == NULL)
+	if ((rowbufs[i] = Rast_allocate_cell_buf()) == NULL)
 	    G_fatal_error(_("Unable to allocate cell buffers."));
     for (i = 0; i < rows; i++) {
 	/* get one row of data */
 	for (j = 1; j <= bands; j++)
-	    if (G_get_map_row(datafds[j], rowbufs[j], i) < 0)
+	    if (Rast_get_map_row(datafds[j], rowbufs[j], i) < 0)
 		G_fatal_error(_("Error reading cell map during transform."));
 	/* transform each cell in the row */
@@ -42,7 +43,7 @@
 	/* output the row of data */
-	    if (G_put_raster_row(outfds[j], rowbufs[j], CELL_TYPE) < 0)
+	    if (Rast_put_raster_row(outfds[j], rowbufs[j], CELL_TYPE) < 0)
 		G_fatal_error(_("Error writing cell map during transform."));
Modified: grass/trunk/imagery/i.class/band_files.c
--- grass/trunk/imagery/i.class/band_files.c	2009-06-20 21:39:23 UTC (rev 38002)
+++ grass/trunk/imagery/i.class/band_files.c	2009-06-20 22:03:23 UTC (rev 38003)
@@ -15,10 +15,10 @@
     Bandbuf = (CELL **) G_malloc(nbands * sizeof(CELL *));
     Bandfd = (int *)G_malloc(nbands * sizeof(int));
     for (n = 0; n < nbands; n++) {
-	Bandbuf[n] = G_allocate_cell_buf();
+	Bandbuf[n] = Rast_allocate_cell_buf();
 	name = Refer.file[n].name;
 	mapset = Refer.file[n].mapset;
-	if ((Bandfd[n] = G_open_cell_old(name, mapset)) < 0)
+	if ((Bandfd[n] = Rast_open_cell_old(name, mapset)) < 0)
 	    G_fatal_error(_("Unable to open band files."));
@@ -34,7 +34,7 @@
     nbands = Refer.nfiles;
 	G_free(Bandbuf[n]);
-	G_close_cell(Bandfd[n]);
+	Rast_close_cell(Bandfd[n]);
     G_free(Bandbuf);
     G_free(Bandfd);
Modified: grass/trunk/imagery/i.class/draw_cell.c
--- grass/trunk/imagery/i.class/draw_cell.c	2009-06-20 21:39:23 UTC (rev 38002)
+++ grass/trunk/imagery/i.class/draw_cell.c	2009-06-20 22:03:23 UTC (rev 38003)
@@ -18,7 +18,7 @@
     if (!view->cell.configured)
 	return 0;
-    if (G_read_colors(view->cell.name, view->cell.mapset, &colr) < 0)
+    if (Rast_read_colors(view->cell.name, view->cell.mapset, &colr) < 0)
 	return 0;
     if (overlay == OVER_WRITE)
@@ -35,16 +35,16 @@
     Outline_box(top, top + nrows - 1, left, left + ncols - 1);
     if (getenv("NO_DRAW")) {
-	G_free_colors(&colr);
+	Rast_free_colors(&colr);
 	return 1;
-    fd = G_open_cell_old(view->cell.name, view->cell.mapset);
+    fd = Rast_open_cell_old(view->cell.name, view->cell.mapset);
     if (fd < 0) {
 	return 0;
     sprintf(msg, "Plotting %s ...", view->cell.name);
@@ -53,14 +53,14 @@
     D_set_overlay_mode(!overlay);
     D_cell_draw_setup(top, top + nrows, left, left + ncols);
-	if (G_get_d_raster_row_nomask(fd, dcell, row) < 0)
+	if (Rast_get_d_raster_row_nomask(fd, dcell, row) < 0)
 	    break;
 	D_draw_d_raster(row, dcell, &colr);
     D_cell_draw_end();
-    G_close_cell(fd);
     G_free(dcell);
     return row == nrows;
Modified: grass/trunk/imagery/i.class/main.c
--- grass/trunk/imagery/i.class/main.c	2009-06-20 21:39:23 UTC (rev 38002)
+++ grass/trunk/imagery/i.class/main.c	2009-06-20 22:03:23 UTC (rev 38003)
@@ -128,7 +128,7 @@
 	G_fatal_error(_("No graphics device selected"));
     /* check to see if a MASK is set */
-    if (G_maskfd() >= 0)
+    if (Rast_maskfd() >= 0)
 	G_fatal_error(_("You have a mask set. Unset mask and run again"));
@@ -161,7 +161,7 @@
     display_title(VIEW_MAP1);
     mapset = G_find_cell(bg_map->answer, "");
-    if (G_get_cellhd(bg_map->answer, mapset, &cellhd) != 0)
+    if (Rast_get_cellhd(bg_map->answer, mapset, &cellhd) != 0)
 	G_fatal_error(_("Raster map <%s> not found"), bg_map->answer);
     G_adjust_window_to_box(&cellhd, &VIEW_MAP1->cell.head, VIEW_MAP1->nrows,
@@ -265,7 +265,7 @@
 	G_fatal_error(_("The subgroup must have at least 2 files to run"));
-    if (G_get_cellhd(Refer.file[0].name, Refer.file[0].mapset, &Band_cellhd)
+    if (Rast_get_cellhd(Refer.file[0].name, Refer.file[0].mapset, &Band_cellhd)
 	!= 0)
 	G_fatal_error(_("Unable to read cell header for first band file"));
Modified: grass/trunk/imagery/i.class/readbands.c
--- grass/trunk/imagery/i.class/readbands.c	2009-06-20 21:39:23 UTC (rev 38002)
+++ grass/trunk/imagery/i.class/readbands.c	2009-06-20 22:03:23 UTC (rev 38003)
@@ -8,7 +8,7 @@
     register int i;
     for (i = 0; i < nbands; i++)
-	if (G_get_map_row_nomask(Bandfd[i], Bandbuf[i], cur) < 0)
+	if (Rast_get_map_row_nomask(Bandfd[i], Bandbuf[i], cur) < 0)
 	    G_fatal_error(_("Error reading raster map in function readbands."));
     return 0;
Modified: grass/trunk/imagery/i.class/signature.c
--- grass/trunk/imagery/i.class/signature.c	2009-06-20 21:39:23 UTC (rev 38002)
+++ grass/trunk/imagery/i.class/signature.c	2009-06-20 22:03:23 UTC (rev 38003)
@@ -272,9 +272,9 @@
 	G_set_window(&VIEW_MAP1->cell.head);
 	open_band_files();
-	if ((fd = G_open_cell_new(MASK)) < 0)
+	if ((fd = Rast_open_cell_new(MASK)) < 0)
 	    G_fatal_error(_("Unable to open the cell map MASK."));
-	if ((buffer = G_allocate_cell_buf()) == NULL)
+	if ((buffer = Rast_allocate_cell_buf()) == NULL)
 	    G_fatal_error(_("Unable to allocate the cell buffer in display_signature()."));
@@ -291,22 +291,22 @@
 		buffer[col] = (CELL) 1;
 	      past:;
-	    G_put_raster_row(fd, buffer, CELL_TYPE);
+	    Rast_put_raster_row(fd, buffer, CELL_TYPE);
-	G_close_cell(fd);
 	close_band_files();
     }				/* end of if first_display */
     /* generate and write the color table for the mask */
-    G_init_colors(&mask_colors);
-    G_set_color((CELL) 1, Color_table[Display_color].red,
+    Rast_init_colors(&mask_colors);
+    Rast_set_color((CELL) 1, Color_table[Display_color].red,
 		Color_table[Display_color].grn,
 		Color_table[Display_color].blue, &mask_colors);
-    G_write_colors(MASK, G_mapset(), &mask_colors);
+    Rast_write_colors(MASK, G_mapset(), &mask_colors);
     /* display new mask */
-    if (G_get_cellhd(MASK, G_mapset(), &cellhd) != 0)
+    if (Rast_get_cellhd(MASK, G_mapset(), &cellhd) != 0)
 	G_fatal_error(_("Did not find input cell map MASK."));
     G_adjust_window_to_box(&cellhd, &VIEW_MASK1->cell.head, VIEW_MASK1->nrows,
 			   VIEW_MASK1->ncols);
Modified: grass/trunk/imagery/i.cluster/checkpt.c
--- grass/trunk/imagery/i.cluster/checkpt.c	2009-06-20 21:39:23 UTC (rev 38002)
+++ grass/trunk/imagery/i.cluster/checkpt.c	2009-06-20 22:03:23 UTC (rev 38003)
@@ -1,4 +1,5 @@
 #include "global.h"
 #include "local_proto.h"
Modified: grass/trunk/imagery/i.cluster/main.c
--- grass/trunk/imagery/i.cluster/main.c	2009-06-20 21:39:23 UTC (rev 38002)
+++ grass/trunk/imagery/i.cluster/main.c	2009-06-20 22:03:23 UTC (rev 38003)
@@ -21,6 +21,7 @@
 #include <stdlib.h>
 #include <time.h>
 #define GLOBAL
 #include "global.h"
@@ -248,7 +249,7 @@
 	    window.ew_res);
     fprintf(report, _("  Rows:  %12d  Cols: %12d  Cells: %d\n"), nrows, ncols,
 	    nrows * ncols);
-    fprintf(report, _("Mask: %s\n"), G_mask_info());
+    fprintf(report, _("Mask: %s\n"), Rast_mask_info());
     fprintf(report, "\n");
     fprintf(report, _("Cluster parameters\n"));
     fprintf(report, _(" Number of initial classes:    %d"), maxclass);
@@ -274,7 +275,7 @@
     for (row = sample_rows - 1; row < nrows; row += sample_rows) {
 	for (n = 0; n < ref.nfiles; n++)
-	    if (G_get_d_raster_row(cellfd[n], cell[n], row) < 0)
+	    if (Rast_get_d_raster_row(cellfd[n], cell[n], row) < 0)
 		G_fatal_error(_("Unable to read raster map row %d"),
 			      row);
 	for (col = sample_cols - 1; col < ncols; col += sample_cols) {
@@ -300,7 +301,7 @@
     for (n = 0; n < ref.nfiles; n++) {
 	G_free(cell[n]);
-	G_close_cell(cellfd[n]);
+	Rast_close_cell(cellfd[n]);
     G_free(x);
Modified: grass/trunk/imagery/i.cluster/open_files.c
--- grass/trunk/imagery/i.cluster/open_files.c	2009-06-20 21:39:23 UTC (rev 38002)
+++ grass/trunk/imagery/i.cluster/open_files.c	2009-06-20 22:03:23 UTC (rev 38003)
@@ -1,5 +1,6 @@
 #include <stdlib.h>
 #include "global.h"
@@ -49,10 +50,10 @@
     cell = (DCELL **) G_malloc(ref.nfiles * sizeof(DCELL *));
     cellfd = (int *)G_malloc(ref.nfiles * sizeof(int));
-	cell[n] = G_allocate_d_raster_buf();
+	cell[n] = Rast_allocate_d_raster_buf();
 	name = ref.file[n].name;
 	mapset = ref.file[n].mapset;
-	if ((cellfd[n] = G_open_cell_old(name, mapset)) < 0)
+	if ((cellfd[n] = Rast_open_cell_old(name, mapset)) < 0)
Modified: grass/trunk/imagery/i.cluster/print1.c
--- grass/trunk/imagery/i.cluster/print1.c	2009-06-20 21:39:23 UTC (rev 38002)
+++ grass/trunk/imagery/i.cluster/print1.c	2009-06-20 22:03:23 UTC (rev 38003)
@@ -1,4 +1,5 @@
 #include <grass/cluster.h>
Modified: grass/trunk/imagery/i.cluster/print2.c
--- grass/trunk/imagery/i.cluster/print2.c	2009-06-20 21:39:23 UTC (rev 38002)
+++ grass/trunk/imagery/i.cluster/print2.c	2009-06-20 22:03:23 UTC (rev 38003)
@@ -1,4 +1,5 @@
Modified: grass/trunk/imagery/i.cluster/print3.c
--- grass/trunk/imagery/i.cluster/print3.c	2009-06-20 21:39:23 UTC (rev 38002)
+++ grass/trunk/imagery/i.cluster/print3.c	2009-06-20 22:03:23 UTC (rev 38003)
@@ -1,4 +1,5 @@
Modified: grass/trunk/imagery/i.cluster/print4.c
--- grass/trunk/imagery/i.cluster/print4.c	2009-06-20 21:39:23 UTC (rev 38002)
+++ grass/trunk/imagery/i.cluster/print4.c	2009-06-20 22:03:23 UTC (rev 38003)
@@ -1,4 +1,5 @@
Modified: grass/trunk/imagery/i.cluster/print5.c
--- grass/trunk/imagery/i.cluster/print5.c	2009-06-20 21:39:23 UTC (rev 38002)
+++ grass/trunk/imagery/i.cluster/print5.c	2009-06-20 22:03:23 UTC (rev 38003)
@@ -1,4 +1,5 @@
Modified: grass/trunk/imagery/i.cluster/print6.c
--- grass/trunk/imagery/i.cluster/print6.c	2009-06-20 21:39:23 UTC (rev 38002)
+++ grass/trunk/imagery/i.cluster/print6.c	2009-06-20 22:03:23 UTC (rev 38003)
@@ -1,4 +1,5 @@
Modified: grass/trunk/imagery/i.cluster/timer.c
--- grass/trunk/imagery/i.cluster/timer.c	2009-06-20 21:39:23 UTC (rev 38002)
+++ grass/trunk/imagery/i.cluster/timer.c	2009-06-20 22:03:23 UTC (rev 38003)
@@ -1,5 +1,6 @@
 #include <stdio.h>
 #include "global.h"
Modified: grass/trunk/imagery/i.eb.eta/main.c
--- grass/trunk/imagery/i.eb.eta/main.c	2009-06-20 21:39:23 UTC (rev 38002)
+++ grass/trunk/imagery/i.eb.eta/main.c	2009-06-20 22:03:23 UTC (rev 38003)
@@ -19,6 +19,7 @@
 #include <stdlib.h>
 #include <string.h>
 double et_a(double r_net_day, double evap_fr, double tempk);
@@ -72,23 +73,23 @@
     tempk = input3->answer;
     result1 = output1->answer;
-    if ((infd_rnetday = G_open_cell_old(rnetday, "")) < 0)
+    if ((infd_rnetday = Rast_open_cell_old(rnetday, "")) < 0)
 	G_fatal_error(_("Unable to open raster map <%s>"), rnetday);
-    inrast_rnetday = G_allocate_d_raster_buf();
+    inrast_rnetday = Rast_allocate_d_raster_buf();
-    if ((infd_evapfr = G_open_cell_old(evapfr, "")) < 0)
+    if ((infd_evapfr = Rast_open_cell_old(evapfr, "")) < 0)
 	G_fatal_error(_("Unable to open raster map <%s>"), evapfr);
-    inrast_evapfr = G_allocate_d_raster_buf();
+    inrast_evapfr = Rast_allocate_d_raster_buf();
-    if ((infd_tempk = G_open_cell_old(tempk, "")) < 0)
+    if ((infd_tempk = Rast_open_cell_old(tempk, "")) < 0)
 	G_fatal_error(_("Unable to open raster map <%s>"), tempk);
-    inrast_tempk = G_allocate_d_raster_buf();
+    inrast_tempk = Rast_allocate_d_raster_buf();
-    outrast1 = G_allocate_d_raster_buf();
+    outrast1 = Rast_allocate_d_raster_buf();
-    if ((outfd1 = G_open_raster_new(result1, DCELL_TYPE)) < 0)
+    if ((outfd1 = Rast_open_raster_new(result1, DCELL_TYPE)) < 0)
         G_fatal_error(_("Unable to create raster map <%s>"), result1);
     /* Process pixels */
@@ -101,11 +102,11 @@
 	/* read input maps */
-	if (G_get_d_raster_row(infd_rnetday,inrast_rnetday,row)<0)
+	if (Rast_get_d_raster_row(infd_rnetday,inrast_rnetday,row)<0)
 	    G_fatal_error(_("Unable to read from <%s> row %d"), rnetday, row);
-	if (G_get_d_raster_row(infd_evapfr,inrast_evapfr,row)<0)
+	if (Rast_get_d_raster_row(infd_evapfr,inrast_evapfr,row)<0)
 	    G_fatal_error(_("Unable to read from <%s> row %d"), evapfr, row);
-	if (G_get_d_raster_row(infd_tempk,inrast_tempk,row)<0)
+	if (Rast_get_d_raster_row(infd_tempk,inrast_tempk,row)<0)
 	    G_fatal_error(_("Unable to read from <%s> row %d"), tempk, row);
     /*process the data */
@@ -114,29 +115,29 @@
             d_rnetday = ((DCELL *) inrast_rnetday)[col];
             d_evapfr = ((DCELL *) inrast_evapfr)[col];
             d_tempk = ((DCELL *) inrast_tempk)[col];
-	    if (G_is_d_null_value(&d_rnetday) ||
-		 G_is_d_null_value(&d_evapfr) ||
-		 G_is_d_null_value(&d_tempk))
-		G_set_d_null_value(&outrast1[col], 1);
+	    if (Rast_is_d_null_value(&d_rnetday) ||
+		 Rast_is_d_null_value(&d_evapfr) ||
+		 Rast_is_d_null_value(&d_tempk))
+		Rast_set_d_null_value(&outrast1[col], 1);
 	    else {
 		d = et_a(d_rnetday, d_evapfr, d_tempk);
 		outrast1[col] = d;
-	if (G_put_d_raster_row(outfd1,outrast1) < 0)
+	if (Rast_put_d_raster_row(outfd1,outrast1) < 0)
 	    G_fatal_error(_("Failed writing raster map <%s>"), result1);
     G_free(inrast_rnetday);
     G_free(inrast_evapfr);
     G_free(inrast_tempk);
-    G_close_cell(infd_rnetday);
-    G_close_cell(infd_evapfr);
-    G_close_cell(infd_tempk);
+    Rast_close_cell(infd_rnetday);
+    Rast_close_cell(infd_evapfr);
+    Rast_close_cell(infd_tempk);
     G_free(outrast1);
-    G_close_cell(outfd1);
-    G_short_history(result1, "raster", &history);
-    G_write_history(result1, &history);
+    Rast_close_cell(outfd1);
+    Rast_short_history(result1, "raster", &history);
+    Rast_write_history(result1, &history);
     exit(EXIT_SUCCESS);
Modified: grass/trunk/imagery/i.eb.evapfr/main.c
--- grass/trunk/imagery/i.eb.evapfr/main.c	2009-06-20 21:39:23 UTC (rev 38002)
+++ grass/trunk/imagery/i.eb.evapfr/main.c	2009-06-20 22:03:23 UTC (rev 38003)
@@ -19,6 +19,7 @@
 #include <stdlib.h>
 #include <string.h>
 double evap_fr(double r_net, double g0, double h0);
@@ -91,32 +92,32 @@
     makin = flag1->answer;
-    if ((infd_rnet = G_open_cell_old(rnet, "")) < 0)
+    if ((infd_rnet = Rast_open_cell_old(rnet, "")) < 0)
 	G_fatal_error(_("Unable to open raster map <%s>"), rnet);
-    inrast_rnet = G_allocate_d_raster_buf();
+    inrast_rnet = Rast_allocate_d_raster_buf();
-    if ((infd_g0 = G_open_cell_old(g0, "")) < 0)
+    if ((infd_g0 = Rast_open_cell_old(g0, "")) < 0)
 	G_fatal_error(_("Unable to open raster map <%s>"), g0);
-    inrast_g0 = G_allocate_d_raster_buf();
+    inrast_g0 = Rast_allocate_d_raster_buf();
-    if ((infd_h0 = G_open_cell_old(h0, "")) < 0)
+    if ((infd_h0 = Rast_open_cell_old(h0, "")) < 0)
 	G_fatal_error(_("Unable to open raster map <%s>"), h0);
-    inrast_h0 = G_allocate_d_raster_buf();
+    inrast_h0 = Rast_allocate_d_raster_buf();
     if (makin)
-	outrast2 = G_allocate_d_raster_buf();
+	outrast2 = Rast_allocate_d_raster_buf();
     if (makin)
-	if ((outfd2 = G_open_raster_new(result2, DCELL_TYPE)) < 0)
+	if ((outfd2 = Rast_open_raster_new(result2, DCELL_TYPE)) < 0)
 	    G_fatal_error(_("Unable to create raster map <%s>"), result2);
@@ -129,11 +130,11 @@
-        if (G_get_d_raster_row(infd_rnet, inrast_rnet, row)<0)
+        if (Rast_get_d_raster_row(infd_rnet, inrast_rnet, row)<0)
 	  G_fatal_error(_("Unable to read raster map <%s> row %d"), rnet, row);
-	if (G_get_d_raster_row(infd_g0, inrast_g0, row) < 0)
+	if (Rast_get_d_raster_row(infd_g0, inrast_g0, row) < 0)
 	  G_fatal_error(_("Unable to read raster map <%s> row %d"), g0, row);
-	if (G_get_d_raster_row(infd_h0, inrast_h0, row) < 0)
+	if (Rast_get_d_raster_row(infd_h0, inrast_h0, row) < 0)
 	  G_fatal_error(_("Unable to read raster map <%s> row %d"), h0, row);
@@ -142,12 +143,12 @@
             d_rnet = ((DCELL *) inrast_rnet)[col];
             d_g0 = ((DCELL *) inrast_g0)[col];
             d_h0 = ((DCELL *) inrast_h0)[col];
-	    if (G_is_d_null_value(&d_rnet) ||
-                G_is_d_null_value(&d_g0) ||
-		G_is_d_null_value(&d_h0)) {
+	    if (Rast_is_d_null_value(&d_rnet) ||
+                Rast_is_d_null_value(&d_g0) ||
+		Rast_is_d_null_value(&d_h0)) {
 		if (makin)
-		    G_set_d_null_value(&outrast2[col], 1);
+		    Rast_set_d_null_value(&outrast2[col], 1);
 	    else {
                 /* calculate evaporative fraction       */
@@ -161,33 +162,33 @@
-	if (G_put_d_raster_row(outfd1, outrast1) < 0)
+	if (Rast_put_d_raster_row(outfd1, outrast1) < 0)
 	if (makin)
-            if (G_put_d_raster_row(outfd2, outrast2) < 0)
+            if (Rast_put_d_raster_row(outfd2, outrast2) < 0)
 		G_fatal_error(_("Failed writing raster map <%s>"), result2);
     G_free(inrast_rnet);
     G_free(inrast_g0);
     G_free(inrast_h0);
-    G_close_cell(infd_rnet);
-    G_close_cell(infd_g0);
-    G_close_cell(infd_h0);
+    Rast_close_cell(infd_rnet);
+    Rast_close_cell(infd_g0);
+    Rast_close_cell(infd_h0);
     G_free(outrast1);
     G_free(outrast2);
     if (makin) {
-	G_close_cell(outfd2);
+	Rast_close_cell(outfd2);
     if (makin) {
-	G_short_history(result2, "raster", &history);
-	G_write_history(result2, &history);
+	Rast_short_history(result2, "raster", &history);
+	Rast_write_history(result2, &history);
     exit(EXIT_SUCCESS);
Modified: grass/trunk/imagery/i.eb.h_SEBAL01/main.c
--- grass/trunk/imagery/i.eb.h_SEBAL01/main.c	2009-06-20 21:39:23 UTC (rev 38002)
+++ grass/trunk/imagery/i.eb.h_SEBAL01/main.c	2009-06-20 22:03:23 UTC (rev 38003)
@@ -24,6 +24,7 @@
 #include <stdlib.h>
 #include <math.h>
 double **G_alloc_matrix(int rows, int cols)
@@ -199,29 +200,29 @@
     if (G_legal_filename(h0) < 0)
 	G_fatal_error(_("<%s> is an illegal name"), h0);
-    if ((infd_Rn = G_open_cell_old(Rn, "")) < 0)
+    if ((infd_Rn = Rast_open_cell_old(Rn, "")) < 0)
 	G_fatal_error(_("Unable to open raster map <%s>"), Rn);
-    if ((infd_z0m = G_open_cell_old(z0m, "")) < 0)
+    if ((infd_z0m = Rast_open_cell_old(z0m, "")) < 0)
 	G_fatal_error(_("Unable to open raster map <%s>"), z0m);
-    if ((infd_t0dem = G_open_cell_old(t0dem, "")) < 0)
+    if ((infd_t0dem = Rast_open_cell_old(t0dem, "")) < 0)
 	G_fatal_error(_("Unable to open raster map <%s>"), t0dem);
-    if (G_get_cellhd(Rn, "", &cellhd) < 0)
+    if (Rast_get_cellhd(Rn, "", &cellhd) < 0)
 	G_fatal_error(_("Unable to read header of raster map <%s>"), Rn);
-    if (G_get_cellhd(g0, "", &cellhd) < 0)
+    if (Rast_get_cellhd(g0, "", &cellhd) < 0)
 	G_fatal_error(_("Unable to read header of raster map <%s>"), g0);
-    if (G_get_cellhd(z0m, "", &cellhd) < 0)
+    if (Rast_get_cellhd(z0m, "", &cellhd) < 0)
 	G_fatal_error(_("Unable to read header of raster map <%s>"), z0m);
-    if (G_get_cellhd(t0dem, "", &cellhd) < 0)
+    if (Rast_get_cellhd(t0dem, "", &cellhd) < 0)
 	G_fatal_error(_("Unable to read header of raster map <%s>"), t0dem);
-    inrast_Rn = G_allocate_d_raster_buf();
-    inrast_z0m = G_allocate_d_raster_buf();
-    inrast_t0dem = G_allocate_d_raster_buf();
+    inrast_Rn = Rast_allocate_d_raster_buf();
+    inrast_z0m = Rast_allocate_d_raster_buf();
+    inrast_t0dem = Rast_allocate_d_raster_buf();
     /* Setup pixel location variables */
@@ -240,9 +241,9 @@
     /* Allocate output buffer */
-    outrast = G_allocate_d_raster_buf();
+    outrast = Rast_allocate_d_raster_buf();
-    if ((outfd = G_open_raster_new(h0, DCELL_TYPE)) < 0)
+    if ((outfd = Rast_open_raster_new(h0, DCELL_TYPE)) < 0)
 	G_fatal_error(_("Unable to create raster map <%s>"), h0);
@@ -275,20 +276,20 @@
 	for (row = 0; row < nrows; row++) {
 	    DCELL d_t0dem;
-	    if (G_get_d_raster_row(infd_t0dem,inrast_t0dem,row)<0)
+	    if (Rast_get_d_raster_row(infd_t0dem,inrast_t0dem,row)<0)
 	      G_fatal_error(_("Unable to read raster map <%s> row %d"), t0dem, row);
-	    if (G_get_d_raster_row(infd_Rn,inrast_Rn,row)<0)
+	    if (Rast_get_d_raster_row(infd_Rn,inrast_Rn,row)<0)
 	      G_fatal_error(_("Unable to read raster map <%s> row %d"), Rn, row);
-	    if (G_get_d_raster_row(infd_g0,inrast_g0,row)<0)
+	    if (Rast_get_d_raster_row(infd_g0,inrast_g0,row)<0)
 	    for (col = 0; col < ncols; col++) {
 		d_t0dem = ((DCELL *) inrast_t0dem)[col];
 		d_Rn = ((DCELL *) inrast_Rn)[col];
-		if (G_is_d_null_value(&d_t0dem) ||
-		    G_is_d_null_value(&d_Rn) ||
-                    G_is_d_null_value(&d_g0)) {
+		if (Rast_is_d_null_value(&d_t0dem) ||
+		    Rast_is_d_null_value(&d_Rn) ||
+                    Rast_is_d_null_value(&d_g0)) {
 		    /* do nothing */
 		else {
@@ -348,11 +349,11 @@
     rowDry = row;
     colDry = col;
-    if (G_get_d_raster_row(infd_Rn, inrast_Rn, row) < 0)
+    if (Rast_get_d_raster_row(infd_Rn, inrast_Rn, row) < 0)
-    if (G_get_d_raster_row(infd_t0dem, inrast_t0dem, row) < 0)
+    if (Rast_get_d_raster_row(infd_t0dem, inrast_t0dem, row) < 0)
     d_Rn_dry = ((DCELL *) inrast_Rn)[col];
     d_g0_dry = ((DCELL *) inrast_g0)[col];
@@ -371,7 +372,7 @@
     rowWet = row;
     colWet = col;
     d_t0dem_wet = ((DCELL *) inrast_t0dem)[col];
     /* END OF MANUAL WET/DRY PIXELS */
@@ -393,15 +394,15 @@
 	DCELL d_u5;
 	/* read a line input maps into buffers */
-	if (G_get_d_raster_row(infd_z0m, inrast_z0m, row) < 0)
+	if (Rast_get_d_raster_row(infd_z0m, inrast_z0m, row) < 0)
 	    G_fatal_error(_("Unable to read raster map <%s> row %d"), z0m, row);
-	if (G_get_d_raster_row(infd_t0dem, inrast_t0dem,row)<0)
+	if (Rast_get_d_raster_row(infd_t0dem, inrast_t0dem,row)<0)
 	/* read every cell in the line buffers */
             d_z0m = ((DCELL *) inrast_z0m)[col];
-	    if (G_is_d_null_value(&d_t0dem) || G_is_d_null_value(&d_z0m)) {
+	    if (Rast_is_d_null_value(&d_t0dem) || Rast_is_d_null_value(&d_z0m)) {
 		/* do nothing */
 		d_Roh[row][col] = -999.9;
 		d_Rah[row][col] = -999.9;
@@ -456,9 +457,9 @@
 	DCELL d_u5;
@@ -466,7 +467,7 @@
 	    d_rah1 = d_Rah[row][col];
 	    d_roh1 = d_Roh[row][col];
 		/* do nothing */
 	    else {
@@ -525,9 +526,9 @@
 	DCELL d_u5;
-	if (G_get_d_raster_row(infd_z0m,inrast_z0m,row)<0)
+	if (Rast_get_d_raster_row(infd_z0m,inrast_z0m,row)<0)
@@ -535,7 +536,7 @@
 	    d_rah2 = d_Rah[row][col];
 		/* do nothing */
 	    else {
@@ -595,9 +596,9 @@
 	DCELL d;		/* Output pixel */
@@ -605,8 +606,8 @@
 	    d_rah3 = d_Rah[row][col];
-		G_set_d_null_value(&outrast[col], 1);
+		Rast_set_d_null_value(&outrast[col], 1);
 	    else {
 		if (d_rah3 < 1.0) {
@@ -619,28 +620,28 @@
 		    d_h3 = 0.0;
 		if (d_h3 < -50 || d_h3 > 1000) {
 		outrast[col] = d_h3;
-	if (G_put_d_raster_row(outfd, outrast) < 0)
+	if (Rast_put_d_raster_row(outfd, outrast) < 0)
 	    G_fatal_error("Failed writing raster map <%s>", h0);
     G_free(inrast_z0m);
-    G_close_cell(infd_z0m);
+    Rast_close_cell(infd_z0m);
     G_free(inrast_t0dem);
-    G_close_cell(infd_t0dem);
+    Rast_close_cell(infd_t0dem);
     G_free(outrast);
-    G_short_history(h0, "raster", &history);
-    G_write_history(h0, &history);
+    Rast_short_history(h0, "raster", &history);
+    Rast_write_history(h0, &history);
     exit(EXIT_SUCCESS);
Modified: grass/trunk/imagery/i.eb.soilheatflux/main.c
--- grass/trunk/imagery/i.eb.soilheatflux/main.c	2009-06-20 21:39:23 UTC (rev 38002)
+++ grass/trunk/imagery/i.eb.soilheatflux/main.c	2009-06-20 22:03:23 UTC (rev 38003)
@@ -19,6 +19,7 @@
 #include <stdlib.h>
 #include <string.h>
 #include <grass/glocale.h>
 double g_0(double bbalb, double ndvi, double tempk, double rnet,
@@ -89,32 +90,32 @@
     result = output1->answer;
     roerink = flag1->answer;
-    if ((infd_albedo = G_open_cell_old(albedo, "")) < 0)
+    if ((infd_albedo = Rast_open_cell_old(albedo, "")) < 0)
 	G_fatal_error(_("Unable to open raster map <%s>"), albedo);
-    inrast_albedo = G_allocate_d_raster_buf();
+    inrast_albedo = Rast_allocate_d_raster_buf();
-    if ((infd_ndvi = G_open_cell_old(ndvi, "")) < 0)
+    if ((infd_ndvi = Rast_open_cell_old(ndvi, "")) < 0)
 	G_fatal_error(_("Unable to open raster map <%s>"), ndvi);
-    inrast_ndvi = G_allocate_d_raster_buf();
+    inrast_ndvi = Rast_allocate_d_raster_buf();
-    if ((infd_time = G_open_cell_old(time, "")) < 0)
+    if ((infd_time = Rast_open_cell_old(time, "")) < 0)
 	G_fatal_error(_("Unable to open raster map <%s>"), time);
-    inrast_time = G_allocate_d_raster_buf();
+    inrast_time = Rast_allocate_d_raster_buf();
     nrows = G_window_rows();
     ncols = G_window_cols();
-    if ((outfd = G_open_raster_new(result,DCELL_TYPE)) < 0)
+    if ((outfd = Rast_open_raster_new(result,DCELL_TYPE)) < 0)
@@ -128,19 +129,19 @@
 	DCELL d_time;
-        if (G_get_d_raster_row(infd_albedo, inrast_albedo, row) < 0)
+        if (Rast_get_d_raster_row(infd_albedo, inrast_albedo, row) < 0)
 			  albedo, row);
-	if (G_get_d_raster_row(infd_ndvi, inrast_ndvi, row)<0)
+	if (Rast_get_d_raster_row(infd_ndvi, inrast_ndvi, row)<0)
 			  ndvi, row);
-	if (G_get_d_raster_row(infd_tempk, inrast_tempk, row)< 0)
+	if (Rast_get_d_raster_row(infd_tempk, inrast_tempk, row)< 0)
 			  tempk, row);
 			  rnet, row);
-	if (G_get_d_raster_row(infd_time, inrast_time, row)<0)
+	if (Rast_get_d_raster_row(infd_time, inrast_time, row)<0)
 			  time, row);
@@ -151,12 +152,12 @@
             d_time   = ((DCELL *) inrast_time)[col];
-	    if (G_is_d_null_value(&d_albedo) ||
-                 G_is_d_null_value(&d_ndvi) ||
-                 G_is_d_null_value(&d_tempk) ||
-		 G_is_d_null_value(&d_rnet) ||
-                 G_is_d_null_value(&d_time)) {
+	    if (Rast_is_d_null_value(&d_albedo) ||
+                 Rast_is_d_null_value(&d_ndvi) ||
+                 Rast_is_d_null_value(&d_tempk) ||
+		 Rast_is_d_null_value(&d_rnet) ||
+                 Rast_is_d_null_value(&d_time)) {
 	    else {
                 /* calculate soil heat flux         */
@@ -164,7 +165,7 @@
 		outrast[col] = d;
     G_free(inrast_albedo);
@@ -172,20 +173,20 @@
     G_free(inrast_time);
-    G_close_cell(infd_albedo);
-    G_close_cell(infd_ndvi);
-    G_close_cell(infd_time);
+    Rast_close_cell(infd_albedo);
+    Rast_close_cell(infd_ndvi);
+    Rast_close_cell(infd_time);
     G_free(outrast);
     /* Colors in grey shade */
-    G_add_color_rule(0.0, 0, 0, 0, 200.0, 255, 255, 255, &colors);
+    Rast_add_color_rule(0.0, 0, 0, 0, 200.0, 255, 255, 255, &colors);
     exit(EXIT_SUCCESS);
Modified: grass/trunk/imagery/i.emissivity/main.c
--- grass/trunk/imagery/i.emissivity/main.c	2009-06-20 21:39:23 UTC (rev 38002)
+++ grass/trunk/imagery/i.emissivity/main.c	2009-06-20 22:03:23 UTC (rev 38003)
@@ -17,6 +17,7 @@
 #include <stdlib.h>
 #include <string.h>
 double emissivity_generic(double ndvi);
@@ -59,17 +60,17 @@
     result1 = output->answer;
-    if ((infd = G_open_cell_old(ndvi, "")) < 0)
+    if ((infd = Rast_open_cell_old(ndvi, "")) < 0)
 	G_fatal_error(_("Cannot open cell file [%s]"), ndvi);
-    inr = G_allocate_d_raster_buf();
+    inr = Rast_allocate_d_raster_buf();
-    outr = G_allocate_d_raster_buf();
+    outr = Rast_allocate_d_raster_buf();
-    if ((outfd = G_open_raster_new(result1, DCELL_TYPE)) < 0)
+    if ((outfd = Rast_open_raster_new(result1, DCELL_TYPE)) < 0)
 	G_fatal_error(_("Could not open <%s>"), result1);
@@ -80,15 +81,15 @@
-        if (G_get_raster_row(infd,inr,row,DCELL_TYPE)< 0)
+        if (Rast_get_raster_row(infd,inr,row,DCELL_TYPE)< 0)
 	    G_fatal_error(_("Could not read from <%s>"), ndvi);
             d_ndvi = ((DCELL *) inr)[col];
-	    if (G_is_d_null_value(&d_ndvi))
-		G_set_d_null_value(&outr[col], 1);
+	    if (Rast_is_d_null_value(&d_ndvi))
+		Rast_set_d_null_value(&outr[col], 1);
 	    else {
                 /* calculate emissivity     */
@@ -96,17 +97,17 @@
 		outr[col] = d;
-	if (G_put_raster_row(outfd, outr, DCELL_TYPE) < 0)
+	if (Rast_put_raster_row(outfd, outr, DCELL_TYPE) < 0)
 	    G_fatal_error(_("Cannot write to output raster file"));
     G_free(inr);
     G_free(outr);
     exit(EXIT_SUCCESS);
Modified: grass/trunk/imagery/i.evapo.time_integration/main.c
--- grass/trunk/imagery/i.evapo.time_integration/main.c	2009-06-20 21:39:23 UTC (rev 38002)
+++ grass/trunk/imagery/i.evapo.time_integration/main.c	2009-06-20 22:03:23 UTC (rev 38003)
@@ -17,7 +17,8 @@
 #include <stdio.h>
 #include <stdlib.h>
 #include <string.h>
-#include <grass/gis.h>
+#include <grass/gis.h>
 #define MAXFILES 400
@@ -160,18 +161,18 @@
 	if (!ok)
 	    continue;
-	infd[nfiles] = G_open_cell_old(name, mapset);
+	infd[nfiles] = Rast_open_cell_old(name, mapset);
 	if (infd[nfiles] < 0) {
 	    ok = 0;
 	    continue;
-	in_data_type[nfiles] = G_raster_map_type(name, mapset);
-	if ((infd[nfiles] = G_open_cell_old(name, mapset)) < 0)
+	in_data_type[nfiles] = Rast_raster_map_type(name, mapset);
+	if ((infd[nfiles] = Rast_open_cell_old(name, mapset)) < 0)
 	    G_fatal_error(_("Unable to open raster map <%s>"), name);
-	if ((G_get_cellhd(name, mapset, &cellhd)) < 0)
+	if ((Rast_get_cellhd(name, mapset, &cellhd)) < 0)
 	    G_fatal_error(_("Unable to read file header of raster map <%s>"), name);
 	nfiles++;
     nfiles--;
@@ -193,18 +194,18 @@
 	if (!ok)
 	    continue;
-	infd1[nfiles1] = G_open_cell_old(name1, mapset);
+	infd1[nfiles1] = Rast_open_cell_old(name1, mapset);
 	if (infd1[nfiles1] < 0) {
 	    ok = 0;
 	    continue;
-	in_data_type1[nfiles1] = G_raster_map_type(name1, mapset);
-	if ((infd1[nfiles1] = G_open_cell_old(name1, mapset)) < 0)
+	in_data_type1[nfiles1] = Rast_raster_map_type(name1, mapset);
+	if ((infd1[nfiles1] = Rast_open_cell_old(name1, mapset)) < 0)
 	    G_fatal_error(_("Unable to open raster map <%s>"), name1);
-	if ((G_get_cellhd(name1, mapset, &cellhd)) < 0)
+	if ((Rast_get_cellhd(name1, mapset, &cellhd)) < 0)
 	    G_fatal_error(_("Unable to read file header of raster map <%s>"), name1);
-	inrast1[nfiles1] = G_allocate_raster_buf(in_data_type1[nfiles1]);
+	inrast1[nfiles1] = Rast_allocate_raster_buf(in_data_type1[nfiles1]);
 	nfiles1++;
     nfiles1--;
@@ -232,20 +233,20 @@
 	if (!ok)
 	    continue;
-	infd2[nfiles2] = G_open_cell_old(name2, mapset);
+	infd2[nfiles2] = Rast_open_cell_old(name2, mapset);
 	if (infd2[nfiles2] < 0) {
 	    ok = 0;
 	    continue;
-	in_data_type2[nfiles2] = G_raster_map_type(name2, mapset);
-	if ((infd2[nfiles2] = G_open_cell_old(name2, mapset)) < 0) {
+	in_data_type2[nfiles2] = Rast_raster_map_type(name2, mapset);
+	if ((infd2[nfiles2] = Rast_open_cell_old(name2, mapset)) < 0) {
 	    G_fatal_error(_("Unable to open raster map <%s>"), name2);
-	if ((G_get_cellhd(name2, mapset, &cellhd)) < 0) {
+	if ((Rast_get_cellhd(name2, mapset, &cellhd)) < 0) {
 	    G_fatal_error(_("Unable to read file header of raster map <%s>"), name2);
-	inrast2[nfiles2] = G_allocate_d_raster_buf();
+	inrast2[nfiles2] = Rast_allocate_d_raster_buf();
 	nfiles2++;
     nfiles2--;
@@ -255,11 +256,11 @@
@@ -278,15 +279,15 @@
-	    if ((G_get_d_raster_row(infd[i], inrast[i], row)) <	0)
+	    if ((Rast_get_d_raster_row(infd[i], inrast[i], row)) <	0)
 		G_fatal_error(_("Unable to read raster map <%s> row %d"), name, row);
 	for (i = 1; i <= nfiles1; i++)
-	    if ((G_get_d_raster_row(infd1[i], inrast1[i], row)) < 0)
+	    if ((Rast_get_d_raster_row(infd1[i], inrast1[i], row)) < 0)
 		G_fatal_error(_("Unable to read raster map <%s> row %d"), name1, row);
 	for (i = 1; i <= nfiles2; i++)
-	    if ((G_get_d_raster_row (infd2[i], inrast2[i], row)) < 0)
+	    if ((Rast_get_d_raster_row (infd2[i], inrast2[i], row)) < 0)
 		G_fatal_error(_("Unable to read raster map <%s> row %d"), name2, row);
@@ -296,14 +297,14 @@
             int	d_null=0;
-		    if (G_is_d_null_value(&((DCELL *) inrast[i])[col]))
+		    if (Rast_is_d_null_value(&((DCELL *) inrast[i])[col]))
 		    	d_null=1;
 		    else
 	                d[i] = (double)((DCELL *) inrast[i])[col];
-		    if (G_is_d_null_value(&((DCELL *) inrast1[i])[col]))
+		    if (Rast_is_d_null_value(&((DCELL *) inrast1[i])[col]))
 			d1_null=1;
 		    else
 	                d1[i] = ((DCELL *) inrast1[i])[col];
@@ -316,12 +317,12 @@
 		if ( d_null==1 || d1_null==1 )
-			G_set_d_null_value(&outrast[col],1);
+			Rast_set_d_null_value(&outrast[col],1);
 		else
 			doy[i] = d1[i] - etodoy+1;
-			if (G_is_d_null_value(&d2[(int)doy[i]]) || d2[(int)doy[i]]==0 )
+			if (Rast_is_d_null_value(&d2[(int)doy[i]]) || d2[(int)doy[i]]==0 )
 			else
 				d_ETrF[i] = d[i] / d2[(int)doy[i]];
@@ -384,7 +385,7 @@
                 else
 			if (DOYbeforeETa[i]==0 || DOYbeforeETa[i]==0 )
 			else
 				bfr = (int)DOYbeforeETa[i];
@@ -400,7 +401,7 @@
 		if(d_null==1 || d_null==1)
 		else
 			d_out += d_ETrF[i] * sum[i];
@@ -408,28 +409,28 @@
 	    G_fatal_error(_("Unable to write to raster map<%s>"), result);
 	G_free(inrast[i]);
 	G_free(inrast1[i]);
-	G_close_cell(infd1[i]);
+	Rast_close_cell(infd1[i]);
 	G_free(inrast2[i]);
-	G_close_cell(infd2[i]);
+	Rast_close_cell(infd2[i]);
     G_free(outrast);
     /* Color table from 0.0 to 10.0 */
-    G_add_color_rule(0.0, 0, 0, 0, 10.0, 255, 255, 255, &colors);
+    Rast_add_color_rule(0.0, 0, 0, 0, 10.0, 255, 255, 255, &colors);
     /* Metadata */
     exit(EXIT_SUCCESS);
Modified: grass/trunk/imagery/i.fft/main.c
--- grass/trunk/imagery/i.fft/main.c	2009-06-20 21:39:23 UTC (rev 38002)
+++ grass/trunk/imagery/i.fft/main.c	2009-06-20 22:03:23 UTC (rev 38003)
@@ -37,6 +37,7 @@
 #include <stdlib.h>
 #include <math.h>
@@ -46,12 +47,12 @@
     struct FPRange range;
     DCELL min, max;
-    G_read_fp_range(name, G_mapset(), &range);
-    G_get_fp_range_min_max(&range, &min, &max);
-    G_make_wave_colors(&wave, min, max);
-    G_abs_log_colors(&colors, &wave, 100);
-    G_write_colors(name, G_mapset(), &colors);
-    G_free_colors(&colors);
+    Rast_read_fp_range(name, G_mapset(), &range);
+    Rast_get_fp_range_min_max(&range, &min, &max);
+    Rast_make_wave_colors(&wave, min, max);
+    Rast_abs_log_colors(&colors, &wave, 100);
+    Rast_write_colors(name, G_mapset(), &colors);
+    Rast_free_colors(&colors);
@@ -98,11 +99,11 @@
     Cellmap_real = opt.real->answer;
     Cellmap_imag = opt.imag->answer;
-    inputfd = G_open_cell_old(Cellmap_orig, "");
+    inputfd = Rast_open_cell_old(Cellmap_orig, "");
     if (inputfd < 0)
 	G_fatal_error(_("Unable to open raster map <%s>"), Cellmap_orig);
 	G_warning(_("Raster MASK found, consider to remove "
 		    "(see man-page). Will continue..."));
@@ -120,8 +121,8 @@
     data = G_malloc(rows * cols * 2 * sizeof(double));
     /* allocate the space for one row of cell map data */
-    cell_real = G_allocate_d_raster_buf();
-    cell_imag = G_allocate_d_raster_buf();
+    cell_real = Rast_allocate_d_raster_buf();
+    cell_imag = Rast_allocate_d_raster_buf();
 #define C(i, j) ((i) * cols + (j))
@@ -129,7 +130,7 @@
     G_message(_("Reading the raster map <%s>..."),
 	      Cellmap_orig);
-	if (G_get_d_raster_row(inputfd, cell_real, i) < 0)
+	if (Rast_get_d_raster_row(inputfd, cell_real, i) < 0)
 			  Cellmap_orig, i);
 	for (j = 0; j < cols; j++) {
@@ -141,16 +142,16 @@
     /* close input cell map */
-    G_close_cell(inputfd);
+    Rast_close_cell(inputfd);
     /* perform FFT */
     G_message(_("Starting FFT..."));
     fft2(-1, data, totsize, cols, rows);
     /* open the output cell maps */
-    if ((realfd = G_open_fp_cell_new(Cellmap_real)) < 0)
+    if ((realfd = Rast_open_fp_cell_new(Cellmap_real)) < 0)
 	G_fatal_error(_("Unable to create raster map <%s>"), Cellmap_real);
-    if ((imagfd = G_open_fp_cell_new(Cellmap_imag)) < 0)
+    if ((imagfd = Rast_open_fp_cell_new(Cellmap_imag)) < 0)
 	G_fatal_error(_("Unable to create raster map <%s>"), Cellmap_imag);
 #define SWAP1(a, b)				\
@@ -182,14 +183,14 @@
 	    cell_real[j] = data[C(i, j)][0];
 	    cell_imag[j] = data[C(i, j)][1];
-	G_put_d_raster_row(realfd, cell_real);
-	G_put_d_raster_row(imagfd, cell_imag);
+	Rast_put_d_raster_row(realfd, cell_real);
+	Rast_put_d_raster_row(imagfd, cell_imag);
 	G_percent(i+1, rows, 2);
-    G_close_cell(realfd);
-    G_close_cell(imagfd);
+    Rast_close_cell(realfd);
+    Rast_close_cell(imagfd);
     G_free(cell_real);
     G_free(cell_imag);
Modified: grass/trunk/imagery/i.gensig/alloc.c
--- grass/trunk/imagery/i.gensig/alloc.c	2009-06-20 21:39:23 UTC (rev 38002)
+++ grass/trunk/imagery/i.gensig/alloc.c	2009-06-20 22:03:23 UTC (rev 38003)
@@ -1,4 +1,5 @@
 double *vector(int nl, int nh)
Modified: grass/trunk/imagery/i.gensig/can_invert.c
--- grass/trunk/imagery/i.gensig/can_invert.c	2009-06-20 21:39:23 UTC (rev 38002)
+++ grass/trunk/imagery/i.gensig/can_invert.c	2009-06-20 22:03:23 UTC (rev 38003)
@@ -1,5 +1,6 @@
 #include <math.h>
 int can_invert(double **a, int n)
Modified: grass/trunk/imagery/i.gensig/closefiles.c
--- grass/trunk/imagery/i.gensig/closefiles.c	2009-06-20 21:39:23 UTC (rev 38002)
+++ grass/trunk/imagery/i.gensig/closefiles.c	2009-06-20 22:03:23 UTC (rev 38003)
@@ -1,3 +1,4 @@
 #include "files.h"
@@ -6,9 +7,9 @@
     int n;
-    G_close_cell(files->train_fd);
+    Rast_close_cell(files->train_fd);
     for (n = 0; n < files->nbands; n++)
-	G_close_cell(files->band_fd[n]);
+	Rast_close_cell(files->band_fd[n]);
     return 0;
Modified: grass/trunk/imagery/i.gensig/covariance.c
--- grass/trunk/imagery/i.gensig/covariance.c	2009-06-20 21:39:23 UTC (rev 38002)
+++ grass/trunk/imagery/i.gensig/covariance.c	2009-06-20 22:03:23 UTC (rev 38003)
@@ -1,6 +1,9 @@
 #include <stdlib.h>
 #include "signature.h"
 #include "files.h"
@@ -30,8 +33,7 @@
 	read_training_map(class, row, ncols, files);
 	for (b = 0; b < files->nbands; b++)	/* NOTE: files->nbands == S->nbands */
-		(files->band_fd[b], files->band_cell[b], row) < 0)
+	    if (Rast_get_d_raster_row(files->band_fd[b], files->band_cell[b], row) < 0)
 			      row);
 	for (b1 = 0; b1 < files->nbands; b1++) {
Modified: grass/trunk/imagery/i.gensig/eigen.c
--- grass/trunk/imagery/i.gensig/eigen.c	2009-06-20 21:39:23 UTC (rev 38002)
+++ grass/trunk/imagery/i.gensig/eigen.c	2009-06-20 22:03:23 UTC (rev 38003)
@@ -1,4 +1,5 @@
 #include <math.h>
 double **matrix(), *vector();
Modified: grass/trunk/imagery/i.gensig/get_train.c
--- grass/trunk/imagery/i.gensig/get_train.c	2009-06-20 21:39:23 UTC (rev 38002)
+++ grass/trunk/imagery/i.gensig/get_train.c	2009-06-20 22:03:23 UTC (rev 38003)
@@ -1,7 +1,10 @@
 #include <stdlib.h>
 #include <string.h>
 #include "files.h"
@@ -25,27 +28,27 @@
     /* determine the categories in the map */
     I_init_signatures(S, files->nbands);
-    G_init_cell_stats(&cell_stats);
+    Rast_init_cell_stats(&cell_stats);
     G_message(_("Finding training classes..."));
-	if (G_get_c_raster_row(fd, cell, row) < 0)
+	if (Rast_get_c_raster_row(fd, cell, row) < 0)
 	    G_fatal_error(_("Unable to read raster map <%s> row %d"), cell,
 			  row);
-	G_update_cell_stats(cell, ncols, &cell_stats);
+	Rast_update_cell_stats(cell, ncols, &cell_stats);
     G_percent(nrows, nrows, 2);
     /* convert this to an array */
-    G_rewind_cell_stats(&cell_stats);
+    Rast_rewind_cell_stats(&cell_stats);
     n = 0;
-    while (G_next_cell_stat(&cat, &count, &cell_stats)) {
+    while (Rast_next_cell_stat(&cat, &count, &cell_stats)) {
 	if (count > 1) {
 	    I_new_signature(S);
 	    S->sig[n].status = 1;
 	    S->sig[n].npoints = count;
 	    strncpy(S->sig[n].desc,
-		      G_get_cat(cat, &files->training_labels),
+		      Rast_get_cat(cat, &files->training_labels),
 		      sizeof(S->sig[n].desc)
 	    n++;
@@ -60,12 +63,12 @@
     list = (CELL *) G_calloc(n, sizeof(CELL));
     n = 0;
 	if (count > 1)
 	    list[n++] = cat;
-    G_free_cell_stats(&cell_stats);
+    Rast_free_cell_stats(&cell_stats);
     files->ncats = n;
     files->training_cats = list;
Modified: grass/trunk/imagery/i.gensig/labels.c
--- grass/trunk/imagery/i.gensig/labels.c	2009-06-20 21:39:23 UTC (rev 38002)
+++ grass/trunk/imagery/i.gensig/labels.c	2009-06-20 22:03:23 UTC (rev 38003)
@@ -1,3 +1,4 @@
 #include "parms.h"
 #include "files.h"
@@ -9,6 +10,6 @@
     map = parms->training_map;
     mapset = G_find_cell2(map, "");
-    if (G_read_cats(map, mapset, &files->training_labels) < 0)
-	G_init_cats((CELL) 0, "", &files->training_labels);
+    if (Rast_read_cats(map, mapset, &files->training_labels) < 0)
+	Rast_init_cats((CELL) 0, "", &files->training_labels);
Modified: grass/trunk/imagery/i.gensig/lookup_class.c
--- grass/trunk/imagery/i.gensig/lookup_class.c	2009-06-20 21:39:23 UTC (rev 38002)
+++ grass/trunk/imagery/i.gensig/lookup_class.c	2009-06-20 22:03:23 UTC (rev 38003)
@@ -1,4 +1,5 @@
 /* build index of cell values from list */
 /* -1 means not found in list */
@@ -14,7 +15,7 @@
     while (ncats-- > 0) {
 	c = *cats++;		/* extract the category */
-	if (G_is_c_null_value(&c)) {
+	if (Rast_is_c_null_value(&c)) {
 	    *class++ = -1;
 	    continue;
Modified: grass/trunk/imagery/i.gensig/means.c
--- grass/trunk/imagery/i.gensig/means.c	2009-06-20 21:39:23 UTC (rev 38002)
+++ grass/trunk/imagery/i.gensig/means.c	2009-06-20 22:03:23 UTC (rev 38003)
@@ -1,4 +1,5 @@
 #include <stdlib.h>
@@ -28,11 +29,10 @@
 	for (b = 0; b < files->nbands; b++) {	/* NOTE: files->nbands == S->nbands */
-		(files->band_fd[b], cell = files->band_cell[b], row) < 0)
+	    if (Rast_get_d_raster_row(files->band_fd[b], cell = files->band_cell[b], row) < 0)
 		exit(1);
-		if (G_is_d_null_value(&cell[col])) {
+		if (Rast_is_d_null_value(&cell[col])) {
 		    n_nulls++;
 		    continue;
Modified: grass/trunk/imagery/i.gensig/openfiles.c
--- grass/trunk/imagery/i.gensig/openfiles.c	2009-06-20 21:39:23 UTC (rev 38002)
+++ grass/trunk/imagery/i.gensig/openfiles.c	2009-06-20 22:03:23 UTC (rev 38003)
@@ -1,6 +1,9 @@
 #include <stdlib.h>
 #include "parms.h"
 #include "files.h"
@@ -27,20 +30,20 @@
     /* open training map for reading */
     mapset = G_find_cell2(parms->training_map, "");
-    files->train_fd = G_open_cell_old(parms->training_map, mapset);
+    files->train_fd = Rast_open_cell_old(parms->training_map, mapset);
     if (files->train_fd < 0)
 	G_fatal_error(_("Unable to open training map <%s>"),
 		      parms->training_map);
-    files->train_cell = G_allocate_c_raster_buf();
+    files->train_cell = Rast_allocate_c_raster_buf();
     /* open all maps for reading */
     for (n = 0; n < Ref.nfiles; n++) {
 	files->band_fd[n] =
-	    G_open_cell_old(Ref.file[n].name, Ref.file[n].mapset);
+	    Rast_open_cell_old(Ref.file[n].name, Ref.file[n].mapset);
 	if (files->band_fd[n] < 0)
 	    G_fatal_error(_("Unable to open training map <%s in %s>"),
-	files->band_cell[n] = G_allocate_d_raster_buf();
+	files->band_cell[n] = Rast_allocate_d_raster_buf();
     return 0;
Modified: grass/trunk/imagery/i.gensig/parse.c
--- grass/trunk/imagery/i.gensig/parse.c	2009-06-20 21:39:23 UTC (rev 38002)
+++ grass/trunk/imagery/i.gensig/parse.c	2009-06-20 22:03:23 UTC (rev 38003)
@@ -1,5 +1,6 @@
 #include <stdlib.h>
 #include "parms.h"
Modified: grass/trunk/imagery/i.gensig/read_train.c
--- grass/trunk/imagery/i.gensig/read_train.c	2009-06-20 21:39:23 UTC (rev 38002)
+++ grass/trunk/imagery/i.gensig/read_train.c	2009-06-20 22:03:23 UTC (rev 38003)
@@ -1,12 +1,15 @@
 #include <stdlib.h>
 #include "files.h"
 int read_training_map(CELL * class, int row, int ncols, struct files *files)
-    if (G_get_c_raster_row(files->train_fd, files->train_cell, row) < 0)
+    if (Rast_get_c_raster_row(files->train_fd, files->train_cell, row) < 0)
 		      row);
     lookup_class(files->train_cell, ncols, files->training_cats, files->ncats,
Modified: grass/trunk/imagery/i.gensigset/closefiles.c
--- grass/trunk/imagery/i.gensigset/closefiles.c	2009-06-20 21:39:23 UTC (rev 38002)
+++ grass/trunk/imagery/i.gensigset/closefiles.c	2009-06-20 22:03:23 UTC (rev 38003)
@@ -1,4 +1,6 @@
 #include "files.h"
 int closefiles(struct files *files)
@@ -6,9 +8,9 @@
     int n;
     return 0;
Modified: grass/trunk/imagery/i.gensigset/get_train.c
--- grass/trunk/imagery/i.gensigset/get_train.c	2009-06-20 21:39:23 UTC (rev 38002)
+++ grass/trunk/imagery/i.gensigset/get_train.c	2009-06-20 22:03:23 UTC (rev 38003)
@@ -1,6 +1,9 @@
 #include <stdlib.h>
 #include "files.h"
 #include "parms.h"
@@ -26,26 +29,26 @@
     /* determine the non-zero categories in the map */
     I_InitSigSet(S);
     I_SigSetNBands(S, files->nbands);
-    I_SetSigTitle(S, G_get_cats_title(&files->training_labels));
+    I_SetSigTitle(S, Rast_get_cats_title(&files->training_labels));
 			  row);
     n = 0;
 	if (count > 1) {
 	    Sig = I_NewClassSig(S);
-	    I_SetClassTitle(Sig, G_get_cat(cat, &files->training_labels));
+	    I_SetClassTitle(Sig, Rast_get_cat(cat, &files->training_labels));
 	    Sig->classnum = cat;
 	    /* initialize this class with maxsubclasses (by allocating them) */
 	    for (i = 0; i < parms->maxsubclasses; i++)
@@ -64,12 +67,12 @@
     n = 0;
 	if (count > 1)
 	    list[n++] = cat;
     files->ncats = n;
Modified: grass/trunk/imagery/i.gensigset/invert.c
--- grass/trunk/imagery/i.gensigset/invert.c	2009-06-20 21:39:23 UTC (rev 38002)
+++ grass/trunk/imagery/i.gensigset/invert.c	2009-06-20 22:03:23 UTC (rev 38003)
@@ -1,4 +1,5 @@
 int invert(
Modified: grass/trunk/imagery/i.gensigset/labels.c
--- grass/trunk/imagery/i.gensigset/labels.c	2009-06-20 21:39:23 UTC (rev 38002)
+++ grass/trunk/imagery/i.gensigset/labels.c	2009-06-20 22:03:23 UTC (rev 38003)
@@ -1,4 +1,6 @@
 #include "parms.h"
 #include "files.h"
@@ -9,6 +11,6 @@
Modified: grass/trunk/imagery/i.gensigset/lookup_class.c
--- grass/trunk/imagery/i.gensigset/lookup_class.c	2009-06-20 21:39:23 UTC (rev 38002)
+++ grass/trunk/imagery/i.gensigset/lookup_class.c	2009-06-20 22:03:23 UTC (rev 38003)
@@ -1,4 +1,5 @@
@@ -14,7 +15,7 @@
 	    *class++ = -1;
 	    continue;
Modified: grass/trunk/imagery/i.gensigset/main.c
--- grass/trunk/imagery/i.gensigset/main.c	2009-06-20 21:39:23 UTC (rev 38002)
+++ grass/trunk/imagery/i.gensigset/main.c	2009-06-20 22:03:23 UTC (rev 38003)
@@ -19,6 +19,7 @@
 #include <stdlib.h>
 #include "files.h"
Modified: grass/trunk/imagery/i.gensigset/openfiles.c
--- grass/trunk/imagery/i.gensigset/openfiles.c	2009-06-20 21:39:23 UTC (rev 38002)
+++ grass/trunk/imagery/i.gensigset/openfiles.c	2009-06-20 22:03:23 UTC (rev 38003)
@@ -1,6 +1,9 @@
 #include <stdlib.h>
 #include "files.h"
 #include "parms.h"
@@ -27,20 +30,20 @@
 	files->band_fd[n] =
     return 0;
Modified: grass/trunk/imagery/i.gensigset/parse.c
--- grass/trunk/imagery/i.gensigset/parse.c	2009-06-20 21:39:23 UTC (rev 38002)
+++ grass/trunk/imagery/i.gensigset/parse.c	2009-06-20 22:03:23 UTC (rev 38003)
@@ -1,5 +1,6 @@
 #include <stdlib.h>
 #include "parms.h"
Modified: grass/trunk/imagery/i.gensigset/read_data.c
--- grass/trunk/imagery/i.gensigset/read_data.c	2009-06-20 21:39:23 UTC (rev 38002)
+++ grass/trunk/imagery/i.gensigset/read_data.c	2009-06-20 22:03:23 UTC (rev 38003)
@@ -1,6 +1,9 @@
 #include <stdlib.h>
 #include "files.h"
 /* #include "local_proto.h" */
@@ -22,7 +25,7 @@
 	G_percent(row, nrows, 2);
 			      row);
@@ -33,8 +36,8 @@
 		continue;
 	    Data = &S->ClassSig[n].ClassData;
-		if (G_is_d_null_value(&files->band_cell[b][col]))
-		    G_set_d_null_value(&Data->x[Data->count][b], 1);
+		if (Rast_is_d_null_value(&files->band_cell[b][col]))
+		    Rast_set_d_null_value(&Data->x[Data->count][b], 1);
 		else
 		    Data->x[Data->count][b] = files->band_cell[b][col];
Modified: grass/trunk/imagery/i.gensigset/read_train.c
--- grass/trunk/imagery/i.gensigset/read_train.c	2009-06-20 21:39:23 UTC (rev 38002)
+++ grass/trunk/imagery/i.gensigset/read_train.c	2009-06-20 22:03:23 UTC (rev 38003)
@@ -1,12 +1,15 @@
 #include <stdlib.h>
 #include "files.h"
 		      row);
Modified: grass/trunk/imagery/i.gensigset/subcluster.c
--- grass/trunk/imagery/i.gensigset/subcluster.c	2009-06-20 21:39:23 UTC (rev 38002)
+++ grass/trunk/imagery/i.gensigset/subcluster.c	2009-06-20 22:03:23 UTC (rev 38003)
@@ -1,6 +1,7 @@
 #include <math.h>
 #include <stdlib.h>
@@ -131,7 +132,7 @@
 	n_nulls[b1] = 0;
 	mean[b1] = 0.0;
 	for (i = 0; i < Sig->ClassData.npixels; i++) {
-	    if (G_is_d_null_value(&Sig->ClassData.x[i][b1])) {
+	    if (Rast_is_d_null_value(&Sig->ClassData.x[i][b1])) {
 		n_nulls[b1]++;
 		total_nulls++;
@@ -145,8 +146,8 @@
 	for (b2 = 0; b2 < nbands; b2++) {
 	    R[b1][b2] = 0.0;
-		if (!G_is_d_null_value(&Sig->ClassData.x[i][b1]) &&
-		    !G_is_d_null_value(&Sig->ClassData.x[i][b2]))
+		if (!Rast_is_d_null_value(&Sig->ClassData.x[i][b1]) &&
+		    !Rast_is_d_null_value(&Sig->ClassData.x[i][b2]))
 		    R[b1][b2] +=
 			(Sig->ClassData.x[i][b1]) * (Sig->ClassData.x[i][b2]);
@@ -166,8 +167,8 @@
     /* Seed the means and set the diagonal covariance components */
     for (i = 0; i < Sig->nsubclasses; i++) {
 	for (b1 = 0; b1 < nbands; b1++) {
-	    if (G_is_d_null_value(&Sig->ClassData.x[(int)(i * period)][b1]))
-		G_set_d_null_value(&Sig->SubSig[i].means[b1], 1);
+	    if (Rast_is_d_null_value(&Sig->ClassData.x[(int)(i * period)][b1]))
+		Rast_set_d_null_value(&Sig->SubSig[i].means[b1], 1);
 	    else
 		Sig->SubSig[i].means[b1] =
 		    Sig->ClassData.x[(int)(i * period)][b1];
@@ -284,7 +285,7 @@
 		Sig->SubSig[i].means[b1] = 0;
 		for (s = 0; s < Data->npixels; s++)
-		    if (!G_is_d_null_value(&Data->x[s][b1]))
+		    if (!Rast_is_d_null_value(&Data->x[s][b1]))
 			Sig->SubSig[i].means[b1] +=
 			    Data->p[s][i] * Data->x[s][b1];
 		Sig->SubSig[i].means[b1] /= (Sig->SubSig[i].N);
@@ -295,8 +296,8 @@
 		for (b2 = b1; b2 < nbands; b2++) {
 		    Sig->SubSig[i].R[b1][b2] = 0;
 		    for (s = 0; s < Data->npixels; s++) {
-			    && !G_is_d_null_value(&Data->x[s][b2])) {
+			    && !Rast_is_d_null_value(&Data->x[s][b2])) {
 			    diff1 = Data->x[s][b1] - Sig->SubSig[i].means[b1];
 			    diff2 = Data->x[s][b2] - Sig->SubSig[i].means[b2];
 			    Sig->SubSig[i].R[b1][b2] +=
@@ -456,8 +457,8 @@
     sum = 0;
-	    if (G_is_d_null_value(&x[b1])
-		|| G_is_d_null_value(&x[b2]))
+	    if (Rast_is_d_null_value(&x[b1])
+		|| Rast_is_d_null_value(&x[b2]))
 		continue;
 	    diff1 = x[b1] - SubSig->means[b1];
 	    diff2 = x[b2] - SubSig->means[b2];
Modified: grass/trunk/imagery/i.his.rgb/closefiles.c
--- grass/trunk/imagery/i.his.rgb/closefiles.c	2009-06-20 21:39:23 UTC (rev 38002)
+++ grass/trunk/imagery/i.his.rgb/closefiles.c	2009-06-20 22:03:23 UTC (rev 38003)
@@ -1,5 +1,6 @@
 #include <stdlib.h>
 #include "globals.h"
 /* This routine closes up the cell maps, frees up the row buffers and
@@ -16,26 +17,26 @@
     const char *mapset;
     for (i = 0; i < 3; i++) {
-	G_close_cell(fd_output[i]);
+	Rast_close_cell(fd_output[i]);
 	G_free(rowbuf[i]);
     mapset = G_mapset();
-    G_read_range(r_name, mapset, &range);
-    G_get_range_min_max(&range, &min, &max);
-    G_make_grey_scale_colors(&colors, min, max);
-    G_write_colors(r_name, mapset, &colors);
+    Rast_read_range(r_name, mapset, &range);
+    Rast_get_range_min_max(&range, &min, &max);
+    Rast_make_grey_scale_colors(&colors, min, max);
+    Rast_write_colors(r_name, mapset, &colors);
-    G_read_range(g_name, mapset, &range);
-    G_write_colors(g_name, mapset, &colors);
+    Rast_read_range(g_name, mapset, &range);
+    Rast_write_colors(g_name, mapset, &colors);
-    G_read_range(b_name, mapset, &range);
-    G_write_colors(b_name, mapset, &colors);
+    Rast_read_range(b_name, mapset, &range);
+    Rast_write_colors(b_name, mapset, &colors);
     return 0;
Modified: grass/trunk/imagery/i.his.rgb/his2rgb.c
--- grass/trunk/imagery/i.his.rgb/his2rgb.c	2009-06-20 21:39:23 UTC (rev 38002)
+++ grass/trunk/imagery/i.his.rgb/his2rgb.c	2009-06-20 22:03:23 UTC (rev 38003)
@@ -17,6 +17,7 @@
    each band is processed and written out.   CWU GIS Lab: DBS 8/90 */
 void his2rgb(CELL * rowbuffer[3], int columns)
Modified: grass/trunk/imagery/i.his.rgb/main.c
--- grass/trunk/imagery/i.his.rgb/main.c	2009-06-20 21:39:23 UTC (rev 38002)
+++ grass/trunk/imagery/i.his.rgb/main.c	2009-06-20 22:03:23 UTC (rev 38003)
@@ -22,6 +22,7 @@
 #include <stdio.h>
 #include <string.h>
@@ -90,7 +91,7 @@
 	/* read in a row from each cell map */
 	for (band = 0; band < 3; band++)
-	    if (G_get_map_row(fd_input[band], rowbuffer[band], i) < 0)
+	    if (Rast_get_map_row(fd_input[band], rowbuffer[band], i) < 0)
 		G_fatal_error(_("Unable to read raster map row %d"), i);
 	/* process this row of the map */
@@ -98,7 +99,7 @@
 	/* write out the new row for each cell map */
-	    if (G_put_raster_row(fd_output[band], rowbuffer[band], CELL_TYPE)
+	    if (Rast_put_raster_row(fd_output[band], rowbuffer[band], CELL_TYPE)
 		< 0)
 		G_fatal_error(_("Failed writing raster map row %d"), i);
Modified: grass/trunk/imagery/i.his.rgb/openfiles.c
--- grass/trunk/imagery/i.his.rgb/openfiles.c	2009-06-20 21:39:23 UTC (rev 38002)
+++ grass/trunk/imagery/i.his.rgb/openfiles.c	2009-06-20 22:03:23 UTC (rev 38003)
@@ -1,5 +1,6 @@
 #include <stdio.h>
@@ -9,28 +10,28 @@
 	       int fd_input[3], int fd_output[3], CELL * rowbuf[3])
     /* open output files */
-    if ((fd_output[0] = G_open_cell_new(r_name)) < 0)
+    if ((fd_output[0] = Rast_open_cell_new(r_name)) < 0)
 	G_fatal_error(_("Unable to create raster map <%s>"), r_name);
-    if ((fd_output[1] = G_open_cell_new(g_name)) < 0)
+    if ((fd_output[1] = Rast_open_cell_new(g_name)) < 0)
 	G_fatal_error(_("Unable to create raster map <%s>"), g_name);
-    if ((fd_output[2] = G_open_cell_new(b_name)) < 0)
+    if ((fd_output[2] = Rast_open_cell_new(b_name)) < 0)
 	G_fatal_error(_("Unable to create raster map <%s>"), b_name);
     /* allocate the cell row buffer */
-    if ((rowbuf[0] = G_allocate_cell_buf()) == NULL)
+    if ((rowbuf[0] = Rast_allocate_cell_buf()) == NULL)
 	G_fatal_error(_("Unable to allocate the input row buffer"));
-    if ((rowbuf[1] = G_allocate_cell_buf()) == NULL)
+    if ((rowbuf[1] = Rast_allocate_cell_buf()) == NULL)
-    if ((rowbuf[2] = G_allocate_cell_buf()) == NULL)
+    if ((rowbuf[2] = Rast_allocate_cell_buf()) == NULL)
     /* open input files (maps can be in different mapsets) */
-    if ((fd_input[0] = G_open_cell_old(h_name, "")) < 0)
+    if ((fd_input[0] = Rast_open_cell_old(h_name, "")) < 0)
 	G_fatal_error(_("Unable to open raster map <%s>"), h_name);
-    if ((fd_input[1] = G_open_cell_old(i_name, "")) < 0)
+    if ((fd_input[1] = Rast_open_cell_old(i_name, "")) < 0)
 	G_fatal_error(_("Unable to open raster map <%s>"), i_name);
-    if ((fd_input[2] = G_open_cell_old(s_name, "")) < 0)
+    if ((fd_input[2] = Rast_open_cell_old(s_name, "")) < 0)
 	G_fatal_error(_("Unable to open raster map <%s>"), s_name);
Modified: grass/trunk/imagery/i.ifft/main.c
--- grass/trunk/imagery/i.ifft/main.c	2009-06-20 21:39:23 UTC (rev 38002)
+++ grass/trunk/imagery/i.ifft/main.c	2009-06-20 22:03:23 UTC (rev 38003)
@@ -34,6 +34,7 @@
 #include <stdlib.h>
 #include <math.h>
@@ -44,10 +45,10 @@
     DCELL min, max;
     /* make a real component color table */
-    G_make_grey_scale_fp_colors(&colors, min, max);
+    Rast_make_grey_scale_fp_colors(&colors, min, max);
 int main(int argc, char *argv[])
@@ -99,19 +100,19 @@
     Cellmap_orig = opt.orig->answer;
     /* open input raster map */
-    realfd = G_open_cell_old(Cellmap_real, "");
+    realfd = Rast_open_cell_old(Cellmap_real, "");
     if (realfd < 0)
 		      Cellmap_real);
-    imagfd = G_open_cell_old(Cellmap_imag, "");
+    imagfd = Rast_open_cell_old(Cellmap_imag, "");
     if (imagfd < 0)
 		      Cellmap_imag);
     /* get and compare the original window data */
-    G_get_cellhd(Cellmap_real, "", &realhead);
-    G_get_cellhd(Cellmap_imag, "", &imaghead);
+    Rast_get_cellhd(Cellmap_real, "", &realhead);
+    Rast_get_cellhd(Cellmap_imag, "", &imaghead);
     if (realhead.proj   != imaghead.proj   ||
 	realhead.zone   != imaghead.zone   ||
@@ -137,18 +138,18 @@
     /* Read in cell map values */
     G_message(_("Reading raster maps..."));
-	if (G_get_d_raster_row(realfd, cell_real, i) < 0)
+	if (Rast_get_d_raster_row(realfd, cell_real, i) < 0)
 			  Cellmap_real, i);
-	if (G_get_d_raster_row(imagfd, cell_imag, i) < 0)
+	if (Rast_get_d_raster_row(imagfd, cell_imag, i) < 0)
 			  Cellmap_imag, i);
@@ -159,17 +160,17 @@
     /* close input cell maps */
     G_message(_("Masking raster maps..."));
-    maskfd = G_maskfd();
+    maskfd = Rast_maskfd();
     if (maskfd >= 0) {
-	maskbuf = G_allocate_cell_buf();
+	maskbuf = Rast_allocate_cell_buf();
-	    G_get_map_row(maskfd, maskbuf, i);
+	    Rast_get_map_row(maskfd, maskbuf, i);
 		if (maskbuf[j] == 0) {
 		    data[C(i, j)][0] = 0.0;
@@ -179,7 +180,7 @@
-	G_close_cell(maskfd);
+	Rast_close_cell(maskfd);
 	G_free(maskbuf);
@@ -210,7 +211,7 @@
     fft2(1, data, totsize, cols, rows);
     /* open the output cell map */
-    if ((outputfd = G_open_fp_cell_new(Cellmap_orig)) < 0)
+    if ((outputfd = Rast_open_fp_cell_new(Cellmap_orig)) < 0)
 		      Cellmap_orig);
@@ -221,12 +222,12 @@
-	G_put_d_raster_row(outputfd, cell_real);
+	Rast_put_d_raster_row(outputfd, cell_real);
-    G_close_cell(outputfd);
+    Rast_close_cell(outputfd);
     G_free(cell_real);
     G_free(cell_imag);
Modified: grass/trunk/imagery/i.latlong/main.c
--- grass/trunk/imagery/i.latlong/main.c	2009-06-20 21:39:23 UTC (rev 38002)
+++ grass/trunk/imagery/i.latlong/main.c	2009-06-20 22:03:23 UTC (rev 38003)
@@ -16,6 +16,7 @@
 #include <stdlib.h>
 #include <string.h>
 #include <grass/gprojects.h>
@@ -74,11 +75,11 @@
-    if ((infd = G_open_cell_old(in, "")) < 0)
+    if ((infd = Rast_open_cell_old(in, "")) < 0)
 	G_fatal_error(_("Cannot open cell file [%s]"), in);
-    if (G_get_cellhd(in, "", &cellhd) < 0)
+    if (Rast_get_cellhd(in, "", &cellhd) < 0)
 	G_fatal_error(_("Cannot read file header of [%s])"), in);
-    inrast = G_allocate_d_raster_buf();
+    inrast = Rast_allocate_d_raster_buf();
     stepx = cellhd.ew_res;
@@ -113,16 +114,16 @@
 	    G_fatal_error(_("Unable to set up lat/long projection parameters"));
     }	/* End of stolen from r.sun */
-    if ((outfd1 = G_open_raster_new(result1,DCELL_TYPE)) < 0)
+    if ((outfd1 = Rast_open_raster_new(result1,DCELL_TYPE)) < 0)
-	if (G_get_d_raster_row(infd, inrast, row) < 0)
+	if (Rast_get_d_raster_row(infd, inrast, row) < 0)
 	    G_fatal_error(_("Could not read from <%s>"), in);
@@ -138,17 +139,17 @@
 	        d = latitude;
 	    outrast1[col] = d;
     G_free(inrast);
-    G_close_cell(infd);
+    Rast_close_cell(infd);
     G_free(outrast1);
-    G_command_history(&history);
+    Rast_command_history(&history);
     exit(EXIT_SUCCESS);
Modified: grass/trunk/imagery/i.maxlik/classify.c
--- grass/trunk/imagery/i.maxlik/classify.c	2009-06-20 21:39:23 UTC (rev 38002)
+++ grass/trunk/imagery/i.maxlik/classify.c	2009-06-20 22:03:23 UTC (rev 38003)
@@ -1,4 +1,5 @@
 #include "global.h"
@@ -24,13 +25,13 @@
 	valid_data = 0;
 	for (band = 0; band < nfiles; band++)
-	    if ((valid_data = !G_is_d_null_value(&cell[band][col])))
+	    if ((valid_data = !Rast_is_d_null_value(&cell[band][col])))
 		break;
 	if (!valid_data) {	/* all nulls are classified as nulls */
-	    G_set_c_null_value(class++, 1);
+	    Rast_set_c_null_value(class++, 1);
 	    if (reject)
-		G_set_c_null_value(reject++, 1);
+		Rast_set_c_null_value(reject++, 1);
 	    continue;
Modified: grass/trunk/imagery/i.maxlik/hist.c
--- grass/trunk/imagery/i.maxlik/hist.c	2009-06-20 21:39:23 UTC (rev 38002)
+++ grass/trunk/imagery/i.maxlik/hist.c	2009-06-20 22:03:23 UTC (rev 38003)
@@ -1,12 +1,13 @@
 int make_history(char *name, char *group, char *subgroup, char *sigfile)
     struct History hist;
-    if (G_read_history(name, G_mapset(), &hist) >= 0) {
+    if (Rast_read_history(name, G_mapset(), &hist) >= 0) {
 	sprintf(hist.datsrc_1, "Group/subgroup: %s/%s", group, subgroup);
 	sprintf(hist.datsrc_2, "Signature file: %s", sigfile);
-	G_write_history(name, &hist);
+	Rast_write_history(name, &hist);
     return 0;
Modified: grass/trunk/imagery/i.maxlik/invert.c
--- grass/trunk/imagery/i.maxlik/invert.c	2009-06-20 21:39:23 UTC (rev 38002)
+++ grass/trunk/imagery/i.maxlik/invert.c	2009-06-20 22:03:23 UTC (rev 38003)
@@ -1,6 +1,7 @@
 #include <stdlib.h>
 #include <math.h>
 #include "global.h"
Modified: grass/trunk/imagery/i.maxlik/main.c
--- grass/trunk/imagery/i.maxlik/main.c	2009-06-20 21:39:23 UTC (rev 38002)
+++ grass/trunk/imagery/i.maxlik/main.c	2009-06-20 22:03:23 UTC (rev 38003)
@@ -21,6 +21,7 @@
 #include <stdlib.h>
 #include "global.h"
@@ -105,63 +106,63 @@
 	for (band = 0; band < Ref.nfiles; band++)
-	    if (G_get_d_raster_row(cellfd[band], cell[band], row) < 0)
+	    if (Rast_get_d_raster_row(cellfd[band], cell[band], row) < 0)
 			      row);
 	classify(class_cell, reject_cell, ncols);
-	G_put_raster_row(class_fd, class_cell, CELL_TYPE);
+	Rast_put_raster_row(class_fd, class_cell, CELL_TYPE);
 	if (reject_fd > 0)
-	    G_put_raster_row(reject_fd, reject_cell, CELL_TYPE);
+	    Rast_put_raster_row(reject_fd, reject_cell, CELL_TYPE);
-    G_close_cell(class_fd);
+    Rast_close_cell(class_fd);
     if (reject_fd > 0)
-	G_close_cell(reject_fd);
+	Rast_close_cell(reject_fd);
-    G_init_cats((CELL) S.nsigs, "Maximum Likelihood Classification", &cats);
+    Rast_init_cats((CELL) S.nsigs, "Maximum Likelihood Classification", &cats);
     for (i = 0; i < S.nsigs; i++) {
 	if (*S.sig[i].desc)
-	    G_set_cat((CELL) (i + 1), S.sig[i].desc, &cats);
+	    Rast_set_cat((CELL) (i + 1), S.sig[i].desc, &cats);
-    G_write_cats(class_name, &cats);
-    G_free_cats(&cats);
+    Rast_write_cats(class_name, &cats);
+    Rast_free_cats(&cats);
     if (reject_fd > 0) {
 	char title[100];
 	sprintf(title, "Rejection Probability for %s", class_name);
-	G_init_cats((CELL) 17, title, &cats);
-	G_set_cats_title(title, &cats);
-	G_set_cat((CELL) 0, "no data", &cats);
-	G_set_cat((CELL) 1, "0.1%", &cats);
-	G_set_cat((CELL) 2, "0.5%", &cats);
-	G_set_cat((CELL) 3, "1%", &cats);
-	G_set_cat((CELL) 4, "2%", &cats);
-	G_set_cat((CELL) 5, "5%", &cats);
-	G_set_cat((CELL) 6, "10%", &cats);
-	G_set_cat((CELL) 7, "20%", &cats);
-	G_set_cat((CELL) 8, "30%", &cats);
-	G_set_cat((CELL) 9, "50%", &cats);
-	G_set_cat((CELL) 10, "70%", &cats);
-	G_set_cat((CELL) 11, "80%", &cats);
-	G_set_cat((CELL) 12, "90%", &cats);
-	G_set_cat((CELL) 13, "95%", &cats);
-	G_set_cat((CELL) 14, "98%", &cats);
-	G_set_cat((CELL) 15, "99%", &cats);
-	G_set_cat((CELL) 16, "100%", &cats);
-	G_set_cat((CELL) 17, "bad", &cats);
-	G_write_cats(reject_name, &cats);
+	Rast_init_cats((CELL) 17, title, &cats);
+	Rast_set_cats_title(title, &cats);
+	Rast_set_cat((CELL) 0, "no data", &cats);
+	Rast_set_cat((CELL) 1, "0.1%", &cats);
+	Rast_set_cat((CELL) 2, "0.5%", &cats);
+	Rast_set_cat((CELL) 3, "1%", &cats);
+	Rast_set_cat((CELL) 4, "2%", &cats);
+	Rast_set_cat((CELL) 5, "5%", &cats);
+	Rast_set_cat((CELL) 6, "10%", &cats);
+	Rast_set_cat((CELL) 7, "20%", &cats);
+	Rast_set_cat((CELL) 8, "30%", &cats);
+	Rast_set_cat((CELL) 9, "50%", &cats);
+	Rast_set_cat((CELL) 10, "70%", &cats);
+	Rast_set_cat((CELL) 11, "80%", &cats);
+	Rast_set_cat((CELL) 12, "90%", &cats);
+	Rast_set_cat((CELL) 13, "95%", &cats);
+	Rast_set_cat((CELL) 14, "98%", &cats);
+	Rast_set_cat((CELL) 15, "99%", &cats);
+	Rast_set_cat((CELL) 16, "100%", &cats);
+	Rast_set_cat((CELL) 17, "bad", &cats);
+	Rast_write_cats(reject_name, &cats);
-	G_make_grey_scale_colors(&colr, (CELL) 1, (CELL) 16);
+	Rast_make_grey_scale_colors(&colr, (CELL) 1, (CELL) 16);
-	G_set_color((CELL) 0, 0, 255, 0, &colr);
-	G_set_color((CELL) 17, 255, 0, 0, &colr);
-	G_write_colors(reject_name, G_mapset(), &colr);
+	Rast_set_color((CELL) 0, 0, 255, 0, &colr);
+	Rast_set_color((CELL) 17, 255, 0, 0, &colr);
+	Rast_write_colors(reject_name, G_mapset(), &colr);
     /* associate the output files with the group */
Modified: grass/trunk/imagery/i.maxlik/open.c
--- grass/trunk/imagery/i.maxlik/open.c	2009-06-20 21:39:23 UTC (rev 38002)
+++ grass/trunk/imagery/i.maxlik/open.c	2009-06-20 22:03:23 UTC (rev 38003)
@@ -1,5 +1,6 @@
 #include <stdlib.h>
+#include <grass/Rast.h>
 #include "global.h"
@@ -34,10 +35,10 @@
     cellfd = (int *)G_malloc(Ref.nfiles * sizeof(int));
     P = (double *)G_malloc(Ref.nfiles * sizeof(double));
 	name = Ref.file[n].name;
 	mapset = Ref.file[n].mapset;
 			  G_fully_qualified_name(name, mapset));
@@ -61,20 +62,20 @@
     B = (double *)G_malloc(S.nsigs * sizeof(double));
     invert_signatures();
-    class_fd = G_open_cell_new(class_name);
+    class_fd = Rast_open_cell_new(class_name);
     if (class_fd < 0)
 	exit(EXIT_FAILURE);
-    class_cell = G_allocate_cell_buf();
+    class_cell = Rast_allocate_cell_buf();
     reject_cell = NULL;
     if (reject_name) {
-	reject_fd = G_open_cell_new(reject_name);
+	reject_fd = Rast_open_cell_new(reject_name);
 	if (reject_fd < 0)
 			  reject_name);
 	else
-	    reject_cell = G_allocate_cell_buf();
+	    reject_cell = Rast_allocate_cell_buf();
     return 0;
Modified: grass/trunk/imagery/i.modis.qc/main.c
--- grass/trunk/imagery/i.modis.qc/main.c	2009-06-20 21:39:23 UTC (rev 38002)
+++ grass/trunk/imagery/i.modis.qc/main.c	2009-06-20 22:03:23 UTC (rev 38003)
@@ -20,6 +20,7 @@
 #include <stdlib.h>
 #include <string.h>
     /* MOD09Q1 Products (250m, 8-Days) */
@@ -192,21 +193,21 @@
 	(!strcmp(qcflag, "pixel_adjacent_to_cloud") && (strcmp(product, "mod09A1s"))))
 	G_fatal_error(_("This flag is only available for MOD09A1s @ 500m products"));
-    if ((infd = G_open_cell_old(qcchan, "")) < 0)
+    if ((infd = Rast_open_cell_old(qcchan, "")) < 0)
 	G_fatal_error(_("Unable to open raster map <%s>"), qcchan);
-    if (G_get_cellhd(qcchan, "", &cellhd) < 0)
+    if (Rast_get_cellhd(qcchan, "", &cellhd) < 0)
 	G_fatal_error(_("Unable to read header of raster map <%s> "), qcchan);
-    inrast = G_allocate_c_raster_buf();
+    inrast = Rast_allocate_c_raster_buf();
     G_debug(3, "number of rows %d", cellhd.rows);
-    outrast = G_allocate_c_raster_buf();
+    outrast = Rast_allocate_c_raster_buf();
     /* Create New raster files */
-    if ((outfd = G_open_raster_new(result, data_type_output)) < 0)
+    if ((outfd = Rast_open_raster_new(result, data_type_output)) < 0)
 	G_fatal_error(_("Unable to create raster map <%s>"), result);
@@ -214,7 +215,7 @@
 	CELL c;
-	if (G_get_c_raster_row(infd, inrast, row) < 0)
+	if (Rast_get_c_raster_row(infd, inrast, row) < 0)
 			  qcchan, row);
@@ -222,8 +223,8 @@
 	    c = inrast[col];
-		G_set_c_null_value(&outrast[col], 1);
+		Rast_set_c_null_value(&outrast[col], 1);
             else if (!strcmp(product, "mod09A1"))
 	        if (!strcmp(qcflag, "modland_qa_bits"))
@@ -318,22 +319,22 @@
 	    outrast[col] = c;
-	if (G_put_c_raster_row(outfd, outrast) < 0)
+	if (Rast_put_c_raster_row(outfd, outrast) < 0)
 	    G_fatal_error(_("Failed writing raster map <%s> row %d"),
 			  output->answer, row);
     G_free(inrast);
     G_free(outrast);
-    G_close_cell(outfd);
+    Rast_close_cell(outfd);
     /* Color from 0 to 10 in grey */
-    G_init_colors(&colors);
-    G_add_color_rule(0, 0, 0, 0, 10, 255, 255, 255, &colors);
-    G_short_history(result, "raster", &history);
-    G_write_history(result, &history);
+    Rast_init_colors(&colors);
+    Rast_add_color_rule(0, 0, 0, 0, 10, 255, 255, 255, &colors);
+    Rast_short_history(result, "raster", &history);
+    Rast_write_history(result, &history);
     exit(EXIT_SUCCESS);
Modified: grass/trunk/imagery/i.pca/main.c
--- grass/trunk/imagery/i.pca/main.c	2009-06-20 21:39:23 UTC (rev 38002)
+++ grass/trunk/imagery/i.pca/main.c	2009-06-20 22:03:23 UTC (rev 38003)
@@ -22,6 +22,7 @@
 #include <string.h>
 #include <math.h>
 #include <grass/gmath.h>
@@ -124,7 +125,7 @@
 	sprintf(tmpbuf, "%s.%d", opt_out->answer, i + 1);
 	G_check_input_output_name(opt_in->answers[i], tmpbuf, GR_FATAL_EXIT);
-	if ((inp_fd[i] = G_open_cell_old(opt_in->answers[i], "")) < 0)
+	if ((inp_fd[i] = Rast_open_cell_old(opt_in->answers[i], "")) < 0)
 			  opt_in->answers[i]);
@@ -171,7 +172,7 @@
 	write_support(bands, outname, eigmat, eigval);
 	/* close output file */
-	G_unopen_cell(inp_fd[i]);
+	Rast_unopen_cell(inp_fd[i]);
     exit(EXIT_SUCCESS);
@@ -236,12 +237,12 @@
 	int row, col;
 	double sum = 0.;
-	maptype = G_get_raster_map_type(fds[i]);
+	maptype = Rast_get_raster_map_type(fds[i]);
 	/* don't assume each image is of the same type */
 	if (rowbuf)
 	    G_free(rowbuf);
-	if ((rowbuf = G_allocate_raster_buf(maptype)) == NULL)
+	if ((rowbuf = Rast_allocate_raster_buf(maptype)) == NULL)
 	    G_fatal_error(_("Unable allocate memory for row buffer"));
 	G_verbose_message(_("Computing means for band %d..."), i + 1);
@@ -251,18 +252,18 @@
 	    if(G_verbose() > G_verbose_std())
 		G_percent(row, rows - 1, 2);
-	    if (G_get_raster_row(fds[i], rowbuf, row, maptype) < 0)
+	    if (Rast_get_raster_row(fds[i], rowbuf, row, maptype) < 0)
 		G_fatal_error(_("Unable to read raster map row %d"), row);
 	    for (col = 0; col < cols; col++) {
 		/* skip null cells */
-		if (G_is_null_value(rowbuf, maptype)) {
-		    ptr = G_incr_void_ptr(ptr, G_raster_size(maptype));
+		if (Rast_is_null_value(rowbuf, maptype)) {
+		    ptr = Rast_incr_void_ptr(ptr, Rast_raster_size(maptype));
 		    continue;
-		sum += G_get_raster_value_d(rowbuf, maptype);
+		sum += Rast_get_raster_value_d(rowbuf, maptype);
@@ -284,14 +285,14 @@
     int row, col;
     for (j = 0; j < bands; j++) {
-	RASTER_MAP_TYPE maptype = G_get_raster_map_type(fds[j]);
+	RASTER_MAP_TYPE maptype = Rast_get_raster_map_type(fds[j]);
 	void *rowbuf1 = NULL;
 	void *rowbuf2 = NULL;
 	if (rowbuf1)
 	    G_free(rowbuf1);
-	if ((rowbuf1 = G_allocate_raster_buf(maptype)) == NULL)
+	if ((rowbuf1 = Rast_allocate_raster_buf(maptype)) == NULL)
 	G_verbose_message(_("Computing row %d of covariance matrix..."),
@@ -302,19 +303,19 @@
-	    if (G_get_raster_row(fds[j], rowbuf1, row, maptype) < 0)
+	    if (Rast_get_raster_row(fds[j], rowbuf1, row, maptype) < 0)
 	    for (k = j; k < bands; k++) {
-		RASTER_MAP_TYPE maptype2 = G_get_raster_map_type(fds[k]);
+		RASTER_MAP_TYPE maptype2 = Rast_get_raster_map_type(fds[k]);
 		if (rowbuf2)
 		    G_free(rowbuf2);
-		if ((rowbuf2 = G_allocate_raster_buf(maptype2)) == NULL)
+		if ((rowbuf2 = Rast_allocate_raster_buf(maptype2)) == NULL)
 		    G_fatal_error(_("Unable to allocate memory for row buffer"));
-		if (G_get_raster_row(fds[k], rowbuf2, row, maptype2) < 0)
+		if (Rast_get_raster_row(fds[k], rowbuf2, row, maptype2) < 0)
 		ptr1 = rowbuf1;
@@ -322,20 +323,20 @@
-		    if (G_is_null_value(ptr1, maptype) ||
-			G_is_null_value(ptr2, maptype2)) {
-			ptr1 = G_incr_void_ptr(ptr1, G_raster_size(maptype));
-			ptr2 = G_incr_void_ptr(ptr2, G_raster_size(maptype2));
+		    if (Rast_is_null_value(ptr1, maptype) ||
+			Rast_is_null_value(ptr2, maptype2)) {
+			ptr1 = Rast_incr_void_ptr(ptr1, Rast_raster_size(maptype));
+			ptr2 = Rast_incr_void_ptr(ptr2, Rast_raster_size(maptype2));
 			continue;
 		    covar[j][k] +=
-			((double)G_get_raster_value_d(ptr1, maptype) -
-			 mu[j]) * ((double)G_get_raster_value_d(ptr2,
+			((double)Rast_get_raster_value_d(ptr1, maptype) -
+			 mu[j]) * ((double)Rast_get_raster_value_d(ptr2,
 						   maptype2) - mu[k]);
 		covar[k][j] = covar[j][k];
@@ -359,8 +360,8 @@
     double new_range = 0.;
     int rows = G_window_rows();
     int cols = G_window_cols();
-    int cell_mapsiz = G_raster_size(CELL_TYPE);
-    int dcell_mapsiz = G_raster_size(DCELL_TYPE);
+    int cell_mapsiz = Rast_raster_size(CELL_TYPE);
+    int dcell_mapsiz = Rast_raster_size(DCELL_TYPE);
     DCELL *d_buf;
     /* 2 passes for rescale.  1 pass for no rescale */
@@ -370,8 +371,8 @@
     d_buf = (DCELL *) G_malloc(cols * sizeof(double));
     /* allocate memory for output row buffer */
-    outbuf = (scale) ? G_allocate_raster_buf(CELL_TYPE) :
-	G_allocate_raster_buf(DCELL_TYPE);
+    outbuf = (scale) ? Rast_allocate_raster_buf(CELL_TYPE) :
+	Rast_allocate_raster_buf(DCELL_TYPE);
     if (!outbuf)
 	G_fatal_error(_("Unable to allocate memory for raster row"));
@@ -387,10 +388,10 @@
 	/* open a new file for output */
 	if (scale)
-	    out_fd = G_open_cell_new(name);
+	    out_fd = Rast_open_cell_new(name);
 	else {
-	    out_fd = G_open_fp_cell_new(name);
-	    G_set_fp_type(DCELL_TYPE);
+	    out_fd = Rast_open_fp_cell_new(name);
+	    Rast_set_fp_type(DCELL_TYPE);
 	if (out_fd < 0)
@@ -421,15 +422,15 @@
-			G_get_raster_map_type(inp_fd[j]);
+			Rast_get_raster_map_type(inp_fd[j]);
 		    if (rowbuf)
 			G_free(rowbuf);
-		    if (!(rowbuf = G_allocate_raster_buf(maptype)))
+		    if (!(rowbuf = Rast_allocate_raster_buf(maptype)))
-		    if (G_get_raster_row(inp_fd[j], rowbuf, row, maptype) < 0)
+		    if (Rast_get_raster_row(inp_fd[j], rowbuf, row, maptype) < 0)
 		    rowptr = rowbuf;
@@ -439,26 +440,26 @@
 		     * of j-th band for current j */
 			/* handle null cells */
-			if (G_is_null_value(rowptr, maptype)) {
+			if (Rast_is_null_value(rowptr, maptype)) {
 			    if (scale) {
-				G_set_null_value(outptr, 1, CELL_TYPE);
-				outptr = G_incr_void_ptr(outptr, cell_mapsiz);
+				Rast_set_null_value(outptr, 1, CELL_TYPE);
+				outptr = Rast_incr_void_ptr(outptr, cell_mapsiz);
 			    else {
-				G_set_null_value(outptr, 1, DCELL_TYPE);
+				Rast_set_null_value(outptr, 1, DCELL_TYPE);
 				outptr =
-				    G_incr_void_ptr(outptr, dcell_mapsiz);
+				    Rast_incr_void_ptr(outptr, dcell_mapsiz);
 			    rowptr =
-				G_incr_void_ptr(rowptr,
-						G_raster_size(maptype));
+				Rast_incr_void_ptr(rowptr,
+						Rast_raster_size(maptype));
 			    continue;
 			/* corresp. cell of j-th band */
 			d_buf[col] +=
-			    eigmat[i][j] * G_get_raster_value_d(rowptr,
+			    eigmat[i][j] * Rast_get_raster_value_d(rowptr,
 								maptype);
 			/* the cell entry is complete */
@@ -476,7 +477,7 @@
 			    else if (scale) {
 				if (min == max) {
-				    G_set_raster_value_c(outptr, 1,
+				    Rast_set_raster_value_c(outptr, 1,
 							 CELL_TYPE);
 				else {
@@ -487,31 +488,31 @@
 						  min) / old_range) +
 						scale_min);
-				    G_set_raster_value_c(outptr, tmpcell,
+				    Rast_set_raster_value_c(outptr, tmpcell,
 							 CELL_TYPE);
 			    else {	/* (!scale) */
-				G_set_raster_value_d(outptr, d_buf[col],
+				Rast_set_raster_value_d(outptr, d_buf[col],
 						     DCELL_TYPE);
 			outptr = (scale) ?
-			    G_incr_void_ptr(outptr, cell_mapsiz) :
+			    Rast_incr_void_ptr(outptr, cell_mapsiz) :
 			rowptr =
-			    G_incr_void_ptr(rowptr, G_raster_size(maptype));
+			    Rast_incr_void_ptr(rowptr, Rast_raster_size(maptype));
 		}		/* for j = 0 to bands */
 		if (pass == PASSES) {
 		    if (scale)
-			G_put_raster_row(out_fd, outbuf, CELL_TYPE);
+			Rast_put_raster_row(out_fd, outbuf, CELL_TYPE);
 		    else
-			G_put_raster_row(out_fd, outbuf, DCELL_TYPE);
+			Rast_put_raster_row(out_fd, outbuf, DCELL_TYPE);
@@ -520,7 +521,7 @@
 	    if (pass == PASSES)
-		G_close_cell(out_fd);
+		Rast_close_cell(out_fd);
Modified: grass/trunk/imagery/i.pca/support.c
--- grass/trunk/imagery/i.pca/support.c	2009-06-20 21:39:23 UTC (rev 38002)
+++ grass/trunk/imagery/i.pca/support.c	2009-06-20 22:03:23 UTC (rev 38003)
@@ -1,5 +1,6 @@
 #include <string.h>
@@ -15,15 +16,15 @@
     DCELL min, max;
     /* make grey scale color table */
-    G_read_fp_range(outname, mapset, &range);
+    Rast_read_fp_range(outname, mapset, &range);
-    if (G_raster_map_is_fp(outname, mapset))
-	G_mark_colors_as_fp(&colors);
+    if (Rast_raster_map_is_fp(outname, mapset))
+	Rast_mark_colors_as_fp(&colors);
-    if (G_write_colors(outname, mapset, &colors) < 0)
+    if (Rast_write_colors(outname, mapset, &colors) < 0)
 	G_message(_("Unable to write color table for raster map <%s>"), outname);
     return write_history(bands, outname, eigmat, eigval);
@@ -37,7 +38,7 @@
     double eigval_total = 0.0;
-    G_short_history(outname, "raster", &hist);
+    Rast_short_history(outname, "raster", &hist);
     sprintf(hist.edhist[0], "Eigen values, (vectors), and [percent importance]:");
     if(first_map)
@@ -71,10 +72,10 @@
     hist.edlinecnt = i + 1;
-    G_command_history(&hist);
+    Rast_command_history(&hist);
     /* only write to stderr the first time (this fn runs for every output map) */
     first_map = FALSE;
-    return G_write_history(outname, &hist);
+    return Rast_write_history(outname, &hist);
Modified: grass/trunk/imagery/i.points/cell.c
--- grass/trunk/imagery/i.points/cell.c	2009-06-20 21:39:23 UTC (rev 38002)
+++ grass/trunk/imagery/i.points/cell.c	2009-06-20 22:03:23 UTC (rev 38003)
@@ -41,7 +41,7 @@
     if (x > VIEW_MAP1->left && x < VIEW_MAP1->right) {
 	if (!choose_groupfile(name, mapset))
 	    return 1;
-	if (G_get_cellhd(name, mapset, &cellhd) < 0)
+	if (Rast_get_cellhd(name, mapset, &cellhd) < 0)
 	    return 1;
 	Erase_view(VIEW_MAP1_ZOOM);
@@ -57,7 +57,7 @@
 	    return 1;
 	select_target_env();
-	if (G_get_cellhd(name, mapset, &cellhd) < 0) {
+	if (Rast_get_cellhd(name, mapset, &cellhd) < 0) {
 	    select_current_env();
 	    return 1;
Modified: grass/trunk/imagery/i.points/drawcell.c
--- grass/trunk/imagery/i.points/drawcell.c	2009-06-20 21:39:23 UTC (rev 38002)
+++ grass/trunk/imagery/i.points/drawcell.c	2009-06-20 22:03:23 UTC (rev 38003)
@@ -28,8 +28,8 @@
 	read_colors = view == VIEW_MAP2;
     if (read_colors) {
-	G_free_colors(colors);
-	if (G_read_colors(view->cell.name, view->cell.mapset, colors) < 0)
+	Rast_free_colors(colors);
+	if (Rast_read_colors(view->cell.name, view->cell.mapset, colors) < 0)
 	    return 0;
@@ -50,22 +50,22 @@
     if (getenv("NO_DRAW"))
 	return 1;
-    fd = G_open_cell_old(view->cell.name, view->cell.mapset);
+    fd = Rast_open_cell_old(view->cell.name, view->cell.mapset);
     if (fd < 0)
 	return 0;
-    dcell = G_allocate_d_raster_buf();
+    dcell = Rast_allocate_d_raster_buf();
     sprintf(msg, "Plotting %s ...", view->cell.name);
     Menu_msg(msg);
     D_cell_draw_setup(top, top + nrows, left, left + ncols);
-	if (G_get_d_raster_row_nomask(fd, dcell, row) < 0)
+	if (Rast_get_d_raster_row_nomask(fd, dcell, row) < 0)
 	    break;
 	D_draw_d_raster(row, dcell, colors);
     D_cell_draw_end();
-    G_close_cell(fd);
+    Rast_close_cell(fd);
     G_free(dcell);
     if (colors != &VIEW_MAP1->cell.colors)
 	set_colors(&VIEW_MAP1->cell.colors);
Modified: grass/trunk/imagery/i.points/graphics.c
--- grass/trunk/imagery/i.points/graphics.c	2009-06-20 21:39:23 UTC (rev 38002)
+++ grass/trunk/imagery/i.points/graphics.c	2009-06-20 22:03:23 UTC (rev 38003)
@@ -74,8 +74,8 @@
     VIEW_MAP2_ZOOM = makeview(2.5, 47.5, 50.0, 100.0);
     VIEW_MENU = makeview(0.0, 2.5, 0.0, 100.0);
-    G_init_colors(&VIEW_MAP1->cell.colors);
-    G_init_colors(&VIEW_MAP2->cell.colors);
+    Rast_init_colors(&VIEW_MAP1->cell.colors);
+    Rast_init_colors(&VIEW_MAP2->cell.colors);
     return 0;
Modified: grass/trunk/imagery/i.points/main.c
--- grass/trunk/imagery/i.points/main.c	2009-06-20 21:39:23 UTC (rev 38002)
+++ grass/trunk/imagery/i.points/main.c	2009-06-20 22:03:23 UTC (rev 38003)
@@ -108,7 +108,7 @@
 	exit(EXIT_FAILURE);
-    G_suppress_masking();	/* need to do this for target location */
+    Rast_suppress_masking();	/* need to do this for target location */
     interrupt_char = G_intr_char();
     tempfile1 = G_tempfile();
@@ -185,7 +185,7 @@
 	    quit(0);
 	/* display this file in "map1" */
-    while (G_get_cellhd(name, mapset, &cellhd) < 0);
+    while (Rast_get_cellhd(name, mapset, &cellhd) < 0);
     G_adjust_window_to_box(&cellhd, &VIEW_MAP1->cell.head, VIEW_MAP1->nrows,
 			   VIEW_MAP1->ncols);
     Configure_view(VIEW_MAP1, name, mapset, cellhd.ns_res, cellhd.ew_res);
Modified: grass/trunk/imagery/i.rectify/crs.c
--- grass/trunk/imagery/i.rectify/crs.c	2009-06-20 21:39:23 UTC (rev 38002)
+++ grass/trunk/imagery/i.rectify/crs.c	2009-06-20 22:03:23 UTC (rev 38003)
@@ -32,6 +32,7 @@
 #include <math.h>
 #include <limits.h>
    #define MSDOS 1
Modified: grass/trunk/imagery/i.rectify/exec.c
--- grass/trunk/imagery/i.rectify/exec.c	2009-06-20 21:39:23 UTC (rev 38002)
+++ grass/trunk/imagery/i.rectify/exec.c	2009-06-20 22:03:23 UTC (rev 38003)
@@ -13,7 +13,10 @@
 #include <fcntl.h>
 #include <time.h>
 #include <unistd.h>
 #include "global.h"
 int exec_rectify(int order, char *extension)
@@ -33,10 +36,10 @@
     /* allocate the output cell matrix */
     cell_buf = (void **)G_calloc(NROWS, sizeof(void *));
-    n = NCOLS * G_raster_size(map_type);
+    n = NCOLS * Rast_raster_size(map_type);
     for (i = 0; i < NROWS; i++) {
 	cell_buf[i] = (void *)G_malloc(n);
-	G_set_null_value(cell_buf[i], NCOLS, map_type);
+	Rast_set_null_value(cell_buf[i], NCOLS, map_type);
     /* rectify each file */
@@ -56,12 +59,12 @@
-	    cats_ok = G_read_cats(name, mapset, &cats) >= 0;
-	    colr_ok = G_read_colors(name, mapset, &colr) > 0;
+	    cats_ok = Rast_read_cats(name, mapset, &cats) >= 0;
+	    colr_ok = Rast_read_colors(name, mapset, &colr) > 0;
 	    /* Initialze History */
 	    type = "raster";
-	    G_short_history(name, type, &hist);
+	    Rast_short_history(name, type, &hist);
 	    time(&start_time);
@@ -72,15 +75,15 @@
 	     * This clobbers (with wrong values) head
 	     * written by gislib.  99% sure it should
 	     * be removed.  EGM 2002/01/03
-            G_put_cellhd (result,&target_window);
+            Rast_put_cellhd (result,&target_window);
 		if (cats_ok) {
-		    G_write_cats(result, &cats);
+		    Rast_write_cats(result, &cats);
 		if (colr_ok) {
-		    G_write_colors(result, G_mapset(), &colr);
-		    G_free_colors(&colr);
+		    Rast_write_colors(result, G_mapset(), &colr);
+		    Rast_free_colors(&colr);
 		/* Write out History Structure History */
@@ -89,7 +92,7 @@
 		sprintf(hist.edhist[0], "Created from: i.rectify");
 		sprintf(hist.edhist[1], "Transformation order = %d", order);
 		hist.edlinecnt = 2;
-		G_write_history(result, &hist);
+		Rast_write_history(result, &hist);
 		time(&rectify_time);
Modified: grass/trunk/imagery/i.rectify/main.c
--- grass/trunk/imagery/i.rectify/main.c	2009-06-20 21:39:23 UTC (rev 38002)
+++ grass/trunk/imagery/i.rectify/main.c	2009-06-20 22:03:23 UTC (rev 38003)
@@ -24,7 +24,10 @@
 #include <stdlib.h>
 #include <string.h>
 #include "global.h"
 #include "crs.h"
@@ -188,13 +191,13 @@
     else {
 	/* Calculate smallest region */
 	if (a->answer) {
-	    if (G_get_cellhd(ref.file[0].name, ref.file[0].mapset, &cellhd) <
+	    if (Rast_get_cellhd(ref.file[0].name, ref.file[0].mapset, &cellhd) <
 		0)
 			      ref.file[0].name);
 	else {
-	    if (G_get_cellhd(ifile->answers[0], ref.file[0].mapset, &cellhd) <
+	    if (Rast_get_cellhd(ifile->answers[0], ref.file[0].mapset, &cellhd) <
 		0)
 			      ifile->answers[0]);
Modified: grass/trunk/imagery/i.rectify/perform.c
--- grass/trunk/imagery/i.rectify/perform.c	2009-06-20 21:39:23 UTC (rev 38002)
+++ grass/trunk/imagery/i.rectify/perform.c	2009-06-20 22:03:23 UTC (rev 38003)
@@ -1,3 +1,6 @@
 #include "global.h"
 static ROWCOL *rmap, *cmap, left, right;
@@ -12,10 +15,10 @@
     int idx;
     int i;
-    rast_size = G_raster_size(map_type);
+    rast_size = Rast_raster_size(map_type);
     for (row = 0; row < matrix_rows; row++)
-	G_set_null_value(cell_buf[row], matrix_cols, map_type);
+	Rast_set_null_value(cell_buf[row], matrix_cols, map_type);
     curidx = 0;
     while (1) {
@@ -36,8 +39,8 @@
 	   fprintf (stderr, "read row %d\n", row);
-	if (G_get_raster_row_nomask
-	    (infd, G_incr_void_ptr(rast, rast_size), row, map_type) < 0)
+	if (Rast_get_raster_row_nomask
+	    (infd, Rast_incr_void_ptr(rast, rast_size), row, map_type) < 0)
 	    return 0;
 	for (i = curidx; i < matrix_rows; i++) {
@@ -51,7 +54,7 @@
 	    cmap = col_map[idx];
 	    left = row_left[idx];
 	    right = row_right[idx];
-	    do_cell(row, G_incr_void_ptr(rast, rast_size), cell_buf[idx]);
+	    do_cell(row, Rast_incr_void_ptr(rast, rast_size), cell_buf[idx]);
 	    row_min[idx]++;
 	    if (row_min[idx] > row_max[idx])
@@ -70,28 +73,28 @@
     void *inptr, *outptr;
     for (; left <= right; left++) {
-	inptr = G_incr_void_ptr(in, cmap[left] * rast_size);
-	outptr = G_incr_void_ptr(out, left * rast_size);
+	inptr = Rast_incr_void_ptr(in, cmap[left] * rast_size);
+	outptr = Rast_incr_void_ptr(out, left * rast_size);
 	if (rmap[left] < 0)
 	    continue;
 	if (rmap[left] != row)
 	    break;
-	G_raster_cpy(outptr, inptr, 1, map_type);
+	Rast_raster_cpy(outptr, inptr, 1, map_type);
     for (; left <= right; right--) {
-	inptr = G_incr_void_ptr(in, cmap[right] * rast_size);
-	outptr = G_incr_void_ptr(out, right * rast_size);
+	inptr = Rast_incr_void_ptr(in, cmap[right] * rast_size);
+	outptr = Rast_incr_void_ptr(out, right * rast_size);
 	if (rmap[right] < 0)
 	    continue;
 	if (rmap[right] != row)
 	    break;
     for (col = left; col <= right; col++) {
-	inptr = G_incr_void_ptr(in, cmap[col] * rast_size);
-	outptr = G_incr_void_ptr(out, col * rast_size);
+	inptr = Rast_incr_void_ptr(in, cmap[col] * rast_size);
+	outptr = Rast_incr_void_ptr(out, col * rast_size);
 	if (rmap[col] == row)
     return 0;
Modified: grass/trunk/imagery/i.rectify/rectify.c
--- grass/trunk/imagery/i.rectify/rectify.c	2009-06-20 21:39:23 UTC (rev 38002)
+++ grass/trunk/imagery/i.rectify/rectify.c	2009-06-20 22:03:23 UTC (rev 38003)
@@ -1,5 +1,8 @@
 #include <unistd.h>
 #include "global.h"
 /* Modified to support Grass 5.0 fp format 11 april 2000
@@ -18,7 +21,7 @@
     char buf[2048] = "";
 	return 0;
     /* open the result file into target window
@@ -32,21 +35,21 @@
     G_set_window(&target_window);
-    G_set_cell_format(cellhd.format);
+    Rast_set_cell_format(cellhd.format);
     /* open the file to be rectified
      * set window to cellhd first to be able to read file exactly
     G_set_window(&cellhd);
-    infd = G_open_cell_old(name, mapset);
+    infd = Rast_open_cell_old(name, mapset);
     if (infd < 0) {
 	close(infd);
 	return 0;
-    map_type = G_get_raster_map_type(infd);
-    rast = (void *)G_calloc(G_window_cols() + 1, G_raster_size(map_type));
-    G_set_null_value(rast, G_window_cols() + 1, map_type);
+    map_type = Rast_get_raster_map_type(infd);
+    rast = (void *)G_calloc(G_window_cols() + 1, Rast_raster_size(map_type));
+    Rast_set_null_value(rast, G_window_cols() + 1, map_type);
     G_copy(&win, &target_window, sizeof(win));
@@ -102,7 +105,7 @@
     target_window.compressed = cellhd.compressed;
-    G_close_cell(infd);		/* (pmx) 17 april 2000 */
+    Rast_close_cell(infd);		/* (pmx) 17 april 2000 */
     write_map(result);
Modified: grass/trunk/imagery/i.rectify/write.c
--- grass/trunk/imagery/i.rectify/write.c	2009-06-20 21:39:23 UTC (rev 38002)
+++ grass/trunk/imagery/i.rectify/write.c	2009-06-20 22:03:23 UTC (rev 38003)
@@ -2,7 +2,10 @@
 #include <sys/stat.h>
 #include <fcntl.h>
 #include <unistd.h>
 #include "global.h"
 int write_matrix(int row, int col)
@@ -18,15 +21,15 @@
     for (n = 0; n < matrix_rows; n++) {
 	offset =
 	    ((off_t) row++ * target_window.cols +
-	     col) * G_raster_size(map_type);
+	     col) * Rast_raster_size(map_type);
 	lseek(temp_fd, offset, SEEK_SET);
-	if (write(temp_fd, cell_buf[n], G_raster_size(map_type) * matrix_cols)
-	    != G_raster_size(map_type) * matrix_cols) {
+	if (write(temp_fd, cell_buf[n], Rast_raster_size(map_type) * matrix_cols)
+	    != Rast_raster_size(map_type) * matrix_cols) {
 	    unlink(temp_name);
 	    G_fatal_error(_("Error while writing to temp file"));
-	/*G_put_map_row_random (outfd, cell_buf[n], row++, col, matrix_cols); */
+	/*Rast_put_map_row_random (outfd, cell_buf[n], row++, col, matrix_cols); */
@@ -40,19 +43,19 @@
-    rast = G_allocate_raster_buf(map_type);
+    rast = Rast_allocate_raster_buf(map_type);
     close(temp_fd);
     temp_fd = open(temp_name, 0);
-    fd = G_open_raster_new(name, map_type);
+    fd = Rast_open_raster_new(name, map_type);
     if (fd <= 0)
 	G_fatal_error(_("Unable to create raster map <%s>"), name);
     for (row = 0; row < target_window.rows; row++) {
-	if (read(temp_fd, rast, target_window.cols * G_raster_size(map_type))
-	    != target_window.cols * G_raster_size(map_type))
+	if (read(temp_fd, rast, target_window.cols * Rast_raster_size(map_type))
+	    != target_window.cols * Rast_raster_size(map_type))
 	    G_fatal_error(_("Error writing row %d"), row);
-	if (G_put_raster_row(fd, rast, map_type) < 0) {
+	if (Rast_put_raster_row(fd, rast, map_type) < 0) {
 			  name, row);
 	    unlink(temp_name);
@@ -60,7 +63,7 @@
     close(temp_fd);
     unlink(temp_name);
-    G_close_cell(fd);
     return 0;
Modified: grass/trunk/imagery/i.rgb.his/closefiles.c
--- grass/trunk/imagery/i.rgb.his/closefiles.c	2009-06-20 21:39:23 UTC (rev 38002)
+++ grass/trunk/imagery/i.rgb.his/closefiles.c	2009-06-20 22:03:23 UTC (rev 38003)
@@ -1,5 +1,6 @@
 #include <stdlib.h>
@@ -16,26 +17,26 @@
     const char *mapset;
 	G_free(rowbuf[i]);
-    G_read_range(h_name, mapset, &range);
-    G_write_colors(h_name, mapset, &colors);
+    Rast_read_range(h_name, mapset, &range);
+    Rast_write_colors(h_name, mapset, &colors);
-    G_read_range(i_name, mapset, &range);
-    G_write_colors(i_name, mapset, &colors);
+    Rast_read_range(i_name, mapset, &range);
+    Rast_write_colors(i_name, mapset, &colors);
-    G_read_range(s_name, mapset, &range);
-    G_write_colors(s_name, mapset, &colors);
+    Rast_read_range(s_name, mapset, &range);
+    Rast_write_colors(s_name, mapset, &colors);
     return 0;
Modified: grass/trunk/imagery/i.rgb.his/main.c
--- grass/trunk/imagery/i.rgb.his/main.c	2009-06-20 21:39:23 UTC (rev 38002)
+++ grass/trunk/imagery/i.rgb.his/main.c	2009-06-20 22:03:23 UTC (rev 38003)
@@ -22,6 +22,7 @@
 #include <stdlib.h>
 #include <string.h>
 #include <grass/glocale.h>
@@ -88,7 +89,7 @@
 	G_percent(i, rows, 2);
@@ -96,7 +97,7 @@
 		< 0)
Modified: grass/trunk/imagery/i.rgb.his/openfiles.c
--- grass/trunk/imagery/i.rgb.his/openfiles.c	2009-06-20 21:39:23 UTC (rev 38002)
+++ grass/trunk/imagery/i.rgb.his/openfiles.c	2009-06-20 22:03:23 UTC (rev 38003)
@@ -1,5 +1,6 @@
 #include <stdio.h>
@@ -8,26 +9,26 @@
 	       char *h_name, char *i_name, char *s_name,
-    if ((fd_input[0] = G_open_cell_old(r_name, "")) < 0)
+    if ((fd_input[0] = Rast_open_cell_old(r_name, "")) < 0)
 	G_fatal_error(_("Unable to open raster map <%s>"), r_name);
-    if ((fd_input[1] = G_open_cell_old(g_name, "")) < 0)
+    if ((fd_input[1] = Rast_open_cell_old(g_name, "")) < 0)
 	G_fatal_error(_("Unable to open raster map <%s>"), g_name);
-    if ((fd_input[2] = G_open_cell_old(b_name, "")) < 0)
+    if ((fd_input[2] = Rast_open_cell_old(b_name, "")) < 0)
 	G_fatal_error(_("Unable to open raster map <%s>"), b_name);
-    if ((fd_output[0] = G_open_cell_new(h_name)) < 0)
+    if ((fd_output[0] = Rast_open_cell_new(h_name)) < 0)
 	G_fatal_error(_("Unable to create raster map <%s>"), h_name);
-    if ((fd_output[1] = G_open_cell_new(i_name)) < 0)
+    if ((fd_output[1] = Rast_open_cell_new(i_name)) < 0)
 	G_fatal_error(_("Unable to create raster map <%s>"), i_name);
-    if ((fd_output[2] = G_open_cell_new(s_name)) < 0)
+    if ((fd_output[2] = Rast_open_cell_new(s_name)) < 0)
 	G_fatal_error(_("Unable to create raster map <%s>"), s_name);
Modified: grass/trunk/imagery/i.rgb.his/rgb2his.c
--- grass/trunk/imagery/i.rgb.his/rgb2his.c	2009-06-20 21:39:23 UTC (rev 38002)
+++ grass/trunk/imagery/i.rgb.his/rgb2his.c	2009-06-20 22:03:23 UTC (rev 38003)
@@ -17,6 +17,7 @@
 void rgb2his(CELL * rowbuffer[3], int columns)
Modified: grass/trunk/imagery/i.smap/closefiles.c
--- grass/trunk/imagery/i.smap/closefiles.c	2009-06-20 21:39:23 UTC (rev 38002)
+++ grass/trunk/imagery/i.smap/closefiles.c	2009-06-20 22:03:23 UTC (rev 38003)
@@ -1,5 +1,6 @@
 #include <unistd.h>
 #include <grass/imagery.h>
 #include "bouman.h"
@@ -13,10 +14,10 @@
     G_debug(1, "Creating support files for <%s>...", parms->output_map);
-    G_close_cell(files->output_fd);
-    G_write_cats(parms->output_map, &files->output_labels);
+    Rast_close_cell(files->output_fd);
+    Rast_write_cats(parms->output_map, &files->output_labels);
     make_history(parms->output_map,
 		 parms->group, parms->subgroup, parms->sigfile);
Modified: grass/trunk/imagery/i.smap/decimate.c
--- grass/trunk/imagery/i.smap/decimate.c	2009-06-20 21:39:23 UTC (rev 38002)
+++ grass/trunk/imagery/i.smap/decimate.c	2009-06-20 22:03:23 UTC (rev 38003)
@@ -1,4 +1,5 @@
 #include "bouman.h"
 #include "region.h"
Modified: grass/trunk/imagery/i.smap/history.c
--- grass/trunk/imagery/i.smap/history.c	2009-06-20 21:39:23 UTC (rev 38002)
+++ grass/trunk/imagery/i.smap/history.c	2009-06-20 22:03:23 UTC (rev 38003)
@@ -1,12 +1,13 @@
 void make_history(const char *name, const char *group, const char *subgroup, const char *sigfile)
 	sprintf(hist.datsrc_2, "Sigset file: %s", sigfile);
Modified: grass/trunk/imagery/i.smap/interp.c
--- grass/trunk/imagery/i.smap/interp.c	2009-06-20 21:39:23 UTC (rev 38002)
+++ grass/trunk/imagery/i.smap/interp.c	2009-06-20 22:03:23 UTC (rev 38003)
@@ -1,6 +1,7 @@
 #include <stdlib.h>
 #include <math.h>
 #include <grass/gis.h>
 #include "bouman.h"
 #include "region.h"
Modified: grass/trunk/imagery/i.smap/invert.c
--- grass/trunk/imagery/i.smap/invert.c	2009-06-20 21:39:23 UTC (rev 38002)
+++ grass/trunk/imagery/i.smap/invert.c	2009-06-20 22:03:23 UTC (rev 38003)
@@ -1,5 +1,6 @@
 #include <math.h>
 int invert(
Modified: grass/trunk/imagery/i.smap/labels.c
--- grass/trunk/imagery/i.smap/labels.c	2009-06-20 21:39:23 UTC (rev 38002)
+++ grass/trunk/imagery/i.smap/labels.c	2009-06-20 22:03:23 UTC (rev 38003)
@@ -1,4 +1,6 @@
 #include "bouman.h"
 int create_output_labels(struct SigSet *S, struct files *files)
@@ -6,10 +8,10 @@
     int n;
     struct ClassSig *C;
-    G_init_cats((CELL) 0, S->title, &files->output_labels);
+    Rast_init_cats((CELL) 0, S->title, &files->output_labels);
     for (n = 0; n < S->nclasses; n++) {
 	C = &S->ClassSig[n];
-	G_set_cat((CELL) C->classnum, C->title, &files->output_labels);
+	Rast_set_cat((CELL) C->classnum, C->title, &files->output_labels);
     return 0;
Modified: grass/trunk/imagery/i.smap/model.c
--- grass/trunk/imagery/i.smap/model.c	2009-06-20 21:39:23 UTC (rev 38002)
+++ grass/trunk/imagery/i.smap/model.c	2009-06-20 22:03:23 UTC (rev 38003)
@@ -1,4 +1,5 @@
@@ -105,7 +106,7 @@
 	    /* Check for no data condition */
 	    no_data = 1;
 	    for (b1 = 0; (b1 < nbands) && no_data; b1++)
-		no_data = no_data && (G_is_d_null_value(&img[b1][i][j]));
+		no_data = no_data && (Rast_is_d_null_value(&img[b1][i][j]));
 	    if (no_data) {
 		for (m = 0; m < S->nclasses; m++)
Modified: grass/trunk/imagery/i.smap/multialloc.c
--- grass/trunk/imagery/i.smap/multialloc.c	2009-06-20 21:39:23 UTC (rev 38002)
+++ grass/trunk/imagery/i.smap/multialloc.c	2009-06-20 22:03:23 UTC (rev 38003)
@@ -2,6 +2,7 @@
 #include <stdio.h>
 #include <stdarg.h>
Modified: grass/trunk/imagery/i.smap/opencell.c
--- grass/trunk/imagery/i.smap/opencell.c	2009-06-20 21:39:23 UTC (rev 38002)
+++ grass/trunk/imagery/i.smap/opencell.c	2009-06-20 22:03:23 UTC (rev 38003)
@@ -1,5 +1,6 @@
 #include <stdlib.h>
@@ -9,7 +10,7 @@
     if (mapset == NULL)
 	mapset = G_find_cell2(name, "");
-    fd = G_open_cell_old(name, mapset);
+    fd = Rast_open_cell_old(name, mapset);
     if (fd >= 0)
 	return fd;
@@ -23,7 +24,7 @@
     int fd;
-    fd = G_open_cell_new(name);
+    fd = Rast_open_cell_new(name);
     if (fd >= 0)
 	return fd;
Modified: grass/trunk/imagery/i.smap/openfiles.c
--- grass/trunk/imagery/i.smap/openfiles.c	2009-06-20 21:39:23 UTC (rev 38002)
+++ grass/trunk/imagery/i.smap/openfiles.c	2009-06-20 22:03:23 UTC (rev 38003)
@@ -1,6 +1,9 @@
 #include <stdlib.h>
 #include "bouman.h"
@@ -20,8 +23,8 @@
 		      parms->subgroup, parms->group);
     /* allocate file descriptors, and io buffer */
-    files->cellbuf = G_allocate_d_raster_buf();
-    files->outbuf = G_allocate_c_raster_buf();
+    files->cellbuf = Rast_allocate_d_raster_buf();
+    files->outbuf = Rast_allocate_c_raster_buf();
     files->isdata = G_malloc(G_window_cols());
     files->nbands = Ref.nfiles;
Modified: grass/trunk/imagery/i.smap/parse.c
--- grass/trunk/imagery/i.smap/parse.c	2009-06-20 21:39:23 UTC (rev 38002)
+++ grass/trunk/imagery/i.smap/parse.c	2009-06-20 22:03:23 UTC (rev 38003)
@@ -1,5 +1,6 @@
 #include <stdlib.h>
 #include "bouman.h"
Modified: grass/trunk/imagery/i.smap/read_block.c
--- grass/trunk/imagery/i.smap/read_block.c	2009-06-20 21:39:23 UTC (rev 38002)
+++ grass/trunk/imagery/i.smap/read_block.c	2009-06-20 22:03:23 UTC (rev 38003)
@@ -1,6 +1,9 @@
 #include <stdlib.h>
 #include "bouman.h"
 #include "region.h"
@@ -11,7 +14,7 @@
     for (band = 0; band < files->nbands; band++) {
 	for (row = region->ymin; row < region->ymax; row++) {
-	    if (G_get_d_raster_row(files->band_fd[band], files->cellbuf, row)
+	    if (Rast_get_d_raster_row(files->band_fd[band], files->cellbuf, row)
 		< 0)
 			      row);
Modified: grass/trunk/imagery/i.smap/write_img.c
--- grass/trunk/imagery/i.smap/write_img.c	2009-06-20 21:39:23 UTC (rev 38002)
+++ grass/trunk/imagery/i.smap/write_img.c	2009-06-20 22:03:23 UTC (rev 38003)
@@ -1,8 +1,9 @@
 #include "bouman.h"
 int write_img(unsigned char **img, int ncols, int nrows, struct SigSet *S,	/* class parameters */
 	      struct parms *parms,	/* parms: command line parameters */
@@ -19,7 +20,7 @@
 	    G_debug(3, "class: [%d] row/col: [%d][%d]", class, row, col);
 	    files->outbuf[col] = (CELL) S->ClassSig[class].classnum;
-	G_put_raster_row(files->output_fd, files->outbuf, CELL_TYPE);
+	Rast_put_raster_row(files->output_fd, files->outbuf, CELL_TYPE);
Modified: grass/trunk/imagery/i.sunhours/main.c
--- grass/trunk/imagery/i.sunhours/main.c	2009-06-20 21:39:23 UTC (rev 38002)
+++ grass/trunk/imagery/i.sunhours/main.c	2009-06-20 22:03:23 UTC (rev 38003)
@@ -19,6 +19,7 @@
 #include <string.h>
 #include <math.h>
 #define PI 3.1415927
@@ -67,21 +68,21 @@
     result1 = output1->answer;
-    if ((infd_doy = G_open_cell_old(doy, "")) < 0)
+    if ((infd_doy = Rast_open_cell_old(doy, "")) < 0)
 	G_fatal_error(_("Cannot open cell file [%s]"), doy);
-    inrast_doy = G_allocate_d_raster_buf();
+    inrast_doy = Rast_allocate_d_raster_buf();
-    if ((infd_lat = G_open_cell_old(lat, "")) < 0)
+    if ((infd_lat = Rast_open_cell_old(lat, "")) < 0)
 	G_fatal_error(_("Cannot open cell file [%s]"), lat);
-    inrast_lat = G_allocate_d_raster_buf();
+    inrast_lat = Rast_allocate_d_raster_buf();
     nrows = G_window_rows();
     ncols = G_window_cols();
-    outrast1 = G_allocate_d_raster_buf();
-    if ((outfd1 = G_open_raster_new(result1, DCELL_TYPE)) < 0)
+    outrast1 = Rast_allocate_d_raster_buf();
+    if ((outfd1 = Rast_open_raster_new(result1, DCELL_TYPE)) < 0)
 	G_fatal_error(_("Could not open <%s>"), result1);
     for (row = 0; row < nrows; row++)
@@ -95,9 +96,9 @@
 	DCELL d_doy;
-	if (G_get_raster_row(infd_doy, inrast_doy, row, DCELL_TYPE) < 0)
+	if (Rast_get_raster_row(infd_doy, inrast_doy, row, DCELL_TYPE) < 0)
 	    G_fatal_error(_("Could not read from <%s>"), doy);
-	if (G_get_raster_row(infd_lat, inrast_lat, row, DCELL_TYPE) < 0)
+	if (Rast_get_raster_row(infd_lat, inrast_lat, row, DCELL_TYPE) < 0)
 	    G_fatal_error(_("Could not read from <%s>"), lat);
 	for (col = 0; col < ncols; col++)
@@ -114,19 +115,19 @@
 	    d_N = (360.0 / (15.0 * PI)) * d_Ws;
 	    ((DCELL *) outrast1)[col] = d_N;
-	if (G_put_raster_row(outfd1, outrast1, DCELL_TYPE) < 0)
+	if (Rast_put_raster_row(outfd1, outrast1, DCELL_TYPE) < 0)
 	    G_fatal_error(_("Cannot write to output raster file"));
     G_free(inrast_lat);
     G_free(inrast_doy);
-    G_close_cell(infd_lat);
-    G_close_cell(infd_doy);
+    Rast_close_cell(infd_lat);
+    Rast_close_cell(infd_doy);
     G_free(outrast1);
-    G_close_cell(outfd1);
+    Rast_close_cell(outfd1);
-    G_short_history(result1, "raster", &history);
-    G_write_history(result1, &history);
+    Rast_short_history(result1, "raster", &history);
+    Rast_write_history(result1, &history);
     exit(EXIT_SUCCESS);
Modified: grass/trunk/imagery/i.vi/main.c
--- grass/trunk/imagery/i.vi/main.c	2009-06-20 21:39:23 UTC (rev 38002)
+++ grass/trunk/imagery/i.vi/main.c	2009-06-20 22:03:23 UTC (rev 38003)
@@ -29,6 +29,7 @@
 #include <stdlib.h>
 #include <string.h>
 double s_r(double redchan, double nirchan);
@@ -206,46 +207,46 @@
                 || !(input6->answer) || !(input7->answer)) )
 	G_fatal_error(_("gvi index requires blue, green, red, nir, chan5 and chan7 maps"));
-    if ((infd_redchan = G_open_cell_old(redchan, "")) < 0)
+    if ((infd_redchan = Rast_open_cell_old(redchan, "")) < 0)
 	G_fatal_error(_("Unable to open raster map <%s>"), redchan);
-    inrast_redchan = G_allocate_d_raster_buf();
+    inrast_redchan = Rast_allocate_d_raster_buf();
     if (nirchan) {
-        if ((infd_nirchan = G_open_cell_old(nirchan, "")) < 0)
+        if ((infd_nirchan = Rast_open_cell_old(nirchan, "")) < 0)
             G_fatal_error(_("Unable to open raster map <%s>"), nirchan);
-        inrast_nirchan = G_allocate_d_raster_buf();
+        inrast_nirchan = Rast_allocate_d_raster_buf();
     if (greenchan) {
-	if ((infd_greenchan = G_open_cell_old(greenchan, "")) < 0)
+	if ((infd_greenchan = Rast_open_cell_old(greenchan, "")) < 0)
 	    G_fatal_error(_("Unable to open raster map <%s>"), greenchan);
-	inrast_greenchan = G_allocate_d_raster_buf();
+	inrast_greenchan = Rast_allocate_d_raster_buf();
     if (bluechan) {
-	if ((infd_bluechan = G_open_cell_old(bluechan, "")) < 0)
+	if ((infd_bluechan = Rast_open_cell_old(bluechan, "")) < 0)
 	    G_fatal_error(_("Unable to open raster map <%s>"), bluechan);
-	inrast_bluechan = G_allocate_d_raster_buf();
+	inrast_bluechan = Rast_allocate_d_raster_buf();
     if (chan5chan) {
-	if ((infd_chan5chan = G_open_cell_old(chan5chan, "")) < 0)
+	if ((infd_chan5chan = Rast_open_cell_old(chan5chan, "")) < 0)
 	    G_fatal_error(_("Unable to open raster map <%s>"), chan5chan);
-	inrast_chan5chan = G_allocate_d_raster_buf();
+	inrast_chan5chan = Rast_allocate_d_raster_buf();
     if (chan7chan) {
-	if ((infd_chan7chan = G_open_cell_old(chan7chan, "")) < 0)
+	if ((infd_chan7chan = Rast_open_cell_old(chan7chan, "")) < 0)
 	    G_fatal_error(_("Unable to open raster map <%s>"), chan7chan);
-	inrast_chan7chan = G_allocate_d_raster_buf();
+	inrast_chan7chan = Rast_allocate_d_raster_buf();
-    outrast = G_allocate_d_raster_buf();
+    outrast = Rast_allocate_d_raster_buf();
-    if ((outfd = G_open_raster_new(result, DCELL_TYPE)) < 0)
+    if ((outfd = Rast_open_raster_new(result, DCELL_TYPE)) < 0)
     /* Process pixels */
@@ -260,31 +261,31 @@
-	if (G_get_d_raster_row(infd_redchan, inrast_redchan, row) < 0)
+	if (Rast_get_d_raster_row(infd_redchan, inrast_redchan, row) < 0)
 			  redchan, row);
 	if (nirchan) {
-	    if (G_get_d_raster_row(infd_nirchan, inrast_nirchan, row) < 0)
+	    if (Rast_get_d_raster_row(infd_nirchan, inrast_nirchan, row) < 0)
 	        G_fatal_error(_("Unable to read raster map <%s> row %d"),
 			      nirchan, row);
 	if (greenchan) {
-	    if (G_get_d_raster_row(infd_greenchan, inrast_greenchan, row) < 0)
+	    if (Rast_get_d_raster_row(infd_greenchan, inrast_greenchan, row) < 0)
 			      greenchan, row);
 	if (bluechan) {
-	    if (G_get_d_raster_row(infd_bluechan, inrast_bluechan, row) < 0)
+	    if (Rast_get_d_raster_row(infd_bluechan, inrast_bluechan, row) < 0)
 			      bluechan, row);
 	if (chan5chan) {
-	    if (G_get_d_raster_row(infd_chan5chan, inrast_chan5chan, row) < 0)
+	    if (Rast_get_d_raster_row(infd_chan5chan, inrast_chan5chan, row) < 0)
 			      chan5chan, row);
 	if (chan7chan) {
-	    if (G_get_d_raster_row(infd_chan7chan, inrast_chan7chan, row) < 0)
+	    if (Rast_get_d_raster_row(infd_chan7chan, inrast_chan7chan, row) < 0)
 			      chan7chan, row);
@@ -304,13 +305,13 @@
             if(chan7chan)
 	    d_chan7chan = inrast_chan7chan[col];
-	    if (G_is_d_null_value(&d_redchan) ||
-		((nirchan) && G_is_d_null_value(&d_nirchan)) ||
-		((greenchan) && G_is_d_null_value(&d_greenchan)) ||
-		((bluechan) && G_is_d_null_value(&d_bluechan)) ||
-		((chan5chan) && G_is_d_null_value(&d_chan5chan)) ||
-		((chan7chan) && G_is_d_null_value(&d_chan7chan))) {
-		G_set_d_null_value(&outrast[col], 1);
+	    if (Rast_is_d_null_value(&d_redchan) ||
+		((nirchan) && Rast_is_d_null_value(&d_nirchan)) ||
+		((greenchan) && Rast_is_d_null_value(&d_greenchan)) ||
+		((bluechan) && Rast_is_d_null_value(&d_bluechan)) ||
+		((chan5chan) && Rast_is_d_null_value(&d_chan5chan)) ||
+		((chan7chan) && Rast_is_d_null_value(&d_chan7chan))) {
+		Rast_set_d_null_value(&outrast[col], 1);
 	    else {
 		/* calculate simple_ratio        */
@@ -320,7 +321,7 @@
 		/* calculate ndvi                    */
 		if (!strcmp(viflag, "ndvi")) {
 		    if (d_redchan + d_nirchan < 0.001)
 		    else
 			outrast[col] = nd_vi(d_redchan, d_nirchan);
@@ -366,41 +367,41 @@
 		    outrast[col] = va_ri(d_redchan, d_greenchan, d_bluechan);
-	if (G_put_d_raster_row(outfd, outrast) < 0)
+	if (Rast_put_d_raster_row(outfd, outrast) < 0)
 			  result, row);
     G_free(inrast_redchan);
-    G_close_cell(infd_redchan);
+    Rast_close_cell(infd_redchan);
     G_free(inrast_nirchan);
-    G_close_cell(infd_nirchan);
+    Rast_close_cell(infd_nirchan);
     if (greenchan) {
 	G_free(inrast_greenchan);
-	G_close_cell(infd_greenchan);
+	Rast_close_cell(infd_greenchan);
     if (bluechan) {
 	G_free(inrast_bluechan);
-	G_close_cell(infd_bluechan);
+	Rast_close_cell(infd_bluechan);
     if (chan5chan) {
 	G_free(inrast_chan5chan);
-	G_close_cell(infd_chan5chan);
+	Rast_close_cell(infd_chan5chan);
     if (chan7chan) {
 	G_free(inrast_chan7chan);
-	G_close_cell(infd_chan7chan);
+	Rast_close_cell(infd_chan7chan);
     G_free(outrast);
     /* Color from -1.0 to +1.0 in grey */
-    G_add_color_rule(-1.0, 0, 0, 0, 1.0, 255, 255, 255, &colors);
+    Rast_add_color_rule(-1.0, 0, 0, 0, 1.0, 255, 255, 255, &colors);
     exit(EXIT_SUCCESS);
Modified: grass/trunk/imagery/i.vpoints/cell.c
--- grass/trunk/imagery/i.vpoints/cell.c	2009-06-20 21:39:23 UTC (rev 38002)
+++ grass/trunk/imagery/i.vpoints/cell.c	2009-06-20 22:03:23 UTC (rev 38003)
@@ -41,7 +41,7 @@
 	    return 1;
 	    return 1;
@@ -57,7 +57,7 @@
 	    return 1;
 	    return 1;
Modified: grass/trunk/imagery/i.vpoints/colors.c
--- grass/trunk/imagery/i.vpoints/colors.c	2009-06-20 21:39:23 UTC (rev 38002)
+++ grass/trunk/imagery/i.vpoints/colors.c	2009-06-20 22:03:23 UTC (rev 38003)
@@ -29,48 +29,48 @@
     /* SCREEN OUTLINE and CURSOR */
-    G_add_color_rule((CELL) 241, 180, 180, 180, (CELL) 241, 180, 180, 180,
+    Rast_add_color_rule((CELL) 241, 180, 180, 180, (CELL) 241, 180, 180, 180,
 		     colors);
     /* RED */
-    G_add_color_rule((CELL) 242, 200, 90, 90, (CELL) 242, 200, 90, 90,
+    Rast_add_color_rule((CELL) 242, 200, 90, 90, (CELL) 242, 200, 90, 90,
 		     colors);
     /* ORANGE */
-    G_add_color_rule((CELL) 243, 150, 100, 50, (CELL) 243, 150, 100, 50,
+    Rast_add_color_rule((CELL) 243, 150, 100, 50, (CELL) 243, 150, 100, 50,
 		     colors);
     /* YELLOW */
-    G_add_color_rule((CELL) 244, 200, 200, 10, (CELL) 244, 200, 200, 10,
+    Rast_add_color_rule((CELL) 244, 200, 200, 10, (CELL) 244, 200, 200, 10,
 		     colors);
     /* GREEN */
-    G_add_color_rule((CELL) 245, 90, 200, 90, (CELL) 245, 90, 200, 90,
+    Rast_add_color_rule((CELL) 245, 90, 200, 90, (CELL) 245, 90, 200, 90,
 		     colors);
     /* BLUE */
-    G_add_color_rule((CELL) 246, 90, 90, 200, (CELL) 246, 90, 90, 200,
+    Rast_add_color_rule((CELL) 246, 90, 90, 200, (CELL) 246, 90, 90, 200,
 		     colors);
     /* INDIGO */
-    G_add_color_rule((CELL) 247, 100, 100, 10, (CELL) 247, 100, 100, 10,
+    Rast_add_color_rule((CELL) 247, 100, 100, 10, (CELL) 247, 100, 100, 10,
 		     colors);
     /* VIOLET */
-    G_add_color_rule((CELL) 248, 150, 150, 10, (CELL) 248, 150, 150, 10,
+    Rast_add_color_rule((CELL) 248, 150, 150, 10, (CELL) 248, 150, 150, 10,
 		     colors);
     /* WHITE */
-    G_add_color_rule((CELL) 249, 250, 250, 250, (CELL) 249, 250, 250, 250,
+    Rast_add_color_rule((CELL) 249, 250, 250, 250, (CELL) 249, 250, 250, 250,
 		     colors);
     /* BLACK */
-    G_add_color_rule((CELL) 250, 0, 0, 0, (CELL) 250, 0, 0, 0, colors);
+    Rast_add_color_rule((CELL) 250, 0, 0, 0, (CELL) 250, 0, 0, 0, colors);
     /* GRAY */
-    G_add_color_rule((CELL) 251, 180, 180, 180, (CELL) 251, 180, 180, 180,
+    Rast_add_color_rule((CELL) 251, 180, 180, 180, (CELL) 251, 180, 180, 180,
 		     colors);
     /* BROWN */
-    G_add_color_rule((CELL) 252, 100, 100, 30, (CELL) 252, 100, 100, 30,
+    Rast_add_color_rule((CELL) 252, 100, 100, 30, (CELL) 252, 100, 100, 30,
 		     colors);
     /* MAGENTA */
-    G_add_color_rule((CELL) 253, 150, 90, 150, (CELL) 253, 150, 90, 150,
+    Rast_add_color_rule((CELL) 253, 150, 90, 150, (CELL) 253, 150, 90, 150,
 		     colors);
     /* AQUA */
-    G_add_color_rule((CELL) 254, 50, 120, 120, (CELL) 254, 50, 120, 120,
+    Rast_add_color_rule((CELL) 254, 50, 120, 120, (CELL) 254, 50, 120, 120,
 		     colors);
-    G_add_color_rule((CELL) 255, 250, 0, 0, (CELL) 255, 250, 0, 0, colors);
+    Rast_add_color_rule((CELL) 255, 250, 0, 0, (CELL) 255, 250, 0, 0, colors);
     set_colors(colors);
@@ -144,32 +144,32 @@
     switch (curs_color) {
     case BLUE:
-	G_add_color_rule((CELL) 241, 90, 90, 200, (CELL) 241, 90, 90, 200,
+	Rast_add_color_rule((CELL) 241, 90, 90, 200, (CELL) 241, 90, 90, 200,
 			 colors);
 	break;
     case GRAY:
 			 colors);
 	break;
     case GREEN:
-	G_add_color_rule((CELL) 241, 90, 200, 90, (CELL) 241, 90, 200, 90,
+	Rast_add_color_rule((CELL) 241, 90, 200, 90, (CELL) 241, 90, 200, 90,
 			 colors);
 	break;
     case RED:
-	G_add_color_rule((CELL) 241, 200, 90, 90, (CELL) 241, 200, 90, 90,
+	Rast_add_color_rule((CELL) 241, 200, 90, 90, (CELL) 241, 200, 90, 90,
 			 colors);
 	break;
     case WHITE:
-	G_add_color_rule((CELL) 241, 250, 250, 250, (CELL) 241, 250, 250, 250,
+	Rast_add_color_rule((CELL) 241, 250, 250, 250, (CELL) 241, 250, 250, 250,
 			 colors);
 	break;
     case YELLOW:
-	G_add_color_rule((CELL) 241, 200, 200, 10, (CELL) 241, 200, 200, 10,
+	Rast_add_color_rule((CELL) 241, 200, 200, 10, (CELL) 241, 200, 200, 10,
 			 colors);
 	break;
Modified: grass/trunk/imagery/i.vpoints/drawcell.c
--- grass/trunk/imagery/i.vpoints/drawcell.c	2009-06-20 21:39:23 UTC (rev 38002)
+++ grass/trunk/imagery/i.vpoints/drawcell.c	2009-06-20 22:03:23 UTC (rev 38003)
@@ -27,8 +27,8 @@
     if (read_colors) {
 	    return 0;
 	/* set_menu_colors(colors); */
@@ -60,17 +60,17 @@
 	return 1;
     if (fd < 0)
 	return 0;
     sprintf(msg, "Displaying %s ...", view->cell.name);
     Menu_msg(msg);
     for (row = 0; row < nrows; row++) {
 	    break;
@@ -80,7 +80,7 @@
     if (view == VIEW_MAP2 || view == VIEW_MAP2_ZOOM)
 	cellmap_present = 1;	/* for drawcell */
-    G_close_cell(fd);
     G_free(dcell);
Modified: grass/trunk/imagery/i.vpoints/graphics.c
--- grass/trunk/imagery/i.vpoints/graphics.c	2009-06-20 21:39:23 UTC (rev 38002)
+++ grass/trunk/imagery/i.vpoints/graphics.c	2009-06-20 22:03:23 UTC (rev 38003)
@@ -61,8 +61,8 @@
     return 0;
Modified: grass/trunk/imagery/i.vpoints/main.c
--- grass/trunk/imagery/i.vpoints/main.c	2009-06-20 21:39:23 UTC (rev 38002)
+++ grass/trunk/imagery/i.vpoints/main.c	2009-06-20 22:03:23 UTC (rev 38003)
@@ -107,7 +107,7 @@
 	exit(EXIT_FAILURE);
-    G_suppress_masking();	/* to do this for target location */
+    Rast_suppress_masking();	/* to do this for target location */
@@ -181,7 +181,7 @@
 	    quit(0);
 			   VIEW_MAP1->ncols);
Modified: grass/trunk/imagery/i.zc/main.c
--- grass/trunk/imagery/i.zc/main.c	2009-06-20 21:39:23 UTC (rev 38002)
+++ grass/trunk/imagery/i.zc/main.c	2009-06-20 22:03:23 UTC (rev 38003)
@@ -22,6 +22,7 @@
 #include <stdlib.h>
 #include <math.h>
@@ -99,7 +100,7 @@
 	exit(EXIT_FAILURE);
     /* open input cell map */
-    inputfd = G_open_cell_old(input_map->answer, "");
+    inputfd = Rast_open_cell_old(input_map->answer, "");
     if (inputfd < 0)
 	exit(EXIT_FAILURE);
@@ -146,19 +147,19 @@
     /* allocate the space for one row of cell map data */
-    cell_row = G_allocate_cell_buf();
+    cell_row = Rast_allocate_cell_buf();
     G_message(_("Reading raster map..."));
     for (i = 0; i < or; i++) {
-	if (G_get_map_row(inputfd, cell_row, i) < 0)
+	if (Rast_get_map_row(inputfd, cell_row, i) < 0)
 	    G_fatal_error(_("Error while reading input raster map."));
 	for (j = 0; j < oc; j++)
 	    *(data[0] + (i * size) + j) = (double)cell_row[j];
     /* close input cell map and release the row buffer */
-    G_close_cell(inputfd);
+    Rast_close_cell(inputfd);
     G_free(cell_row);
     /* take the del**2g of image */
@@ -171,19 +172,19 @@
     /* open the output cell maps and allocate cell row buffers */
     G_message(_("Writing transformed data to file..."));
-    if ((zcfd = G_open_cell_new(output_map->answer)) < 0)
+    if ((zcfd = Rast_open_cell_new(output_map->answer)) < 0)
 	exit(EXIT_FAILURE);
     /* Write out result to a new cell map */
 	for (j = 0; j < oc; j++) {
 	    *(cell_row + j) = (CELL) (*(data[1] + i * cols + j));
-	G_put_raster_row(zcfd, cell_row, CELL_TYPE);
+	Rast_put_raster_row(zcfd, cell_row, CELL_TYPE);
-    G_close_cell(zcfd);
+    Rast_close_cell(zcfd);
     G_free(cell_row);
Modified: grass/trunk/include/Make/Grass.make
--- grass/trunk/include/Make/Grass.make	2009-06-20 21:39:23 UTC (rev 38002)
+++ grass/trunk/include/Make/Grass.make	2009-06-20 22:03:23 UTC (rev 38003)
@@ -142,6 +142,9 @@
 XGI_LIBNAME	      = grass_Xgi
 XPM_LIBNAME	      = grass_Xpm
+# Raster
+RASTR_LIBNAME         = grass_rast
 # Vector
 DIG_LIBNAME           = grass_dig
 DIG2_LIBNAME          = grass_dig2
@@ -238,6 +241,9 @@
 XGILIB        = -l$(XGI_LIBNAME)
 XPMLIB        = -l$(XPM_LIBNAME)
+# Raster
+RASTRLIB      = -l$(RASTR_LIBNAME) $(DATETIMELIB) $(XDRLIB) $(SOCKLIB) $(INTLLIB)
 # DBMI
 DBMIBASELIB   = -l$(DBMIBASE_LIBNAME) $(GISLIB)
 DBMICLIENTLIB = -l$(DBMICLIENT_LIBNAME) $(DBMIBASELIB) $(GISLIB)
@@ -333,6 +339,9 @@
 XGIDEP	    = $(BASE_LIBDIR)/$(LIB_PREFIX)$(XGI_LIBNAME)$(LIB_SUFFIX)
 XPMDEP	    = $(BASE_LIBDIR)/$(LIB_PREFIX)$(XPM_LIBNAME)$(LIB_SUFFIX)
+# Raster
+RASTRDEP    = $(BASE_LIBDIR)/$(LIB_PREFIX)$(RASTR_LIBNAME)$(LIB_SUFFIX)
 # DBMI
 DBMIBASEDEP     = $(BASE_LIBDIR)/$(LIB_PREFIX)$(DBMIBASE_LIBNAME)$(LIB_SUFFIX)
 DBMICLIENTDEP   = $(BASE_LIBDIR)/$(LIB_PREFIX)$(DBMICLIENT_LIBNAME)$(LIB_SUFFIX)
Added: grass/trunk/include/Rast.h
--- grass/trunk/include/Rast.h	                        (rev 0)
+++ grass/trunk/include/Rast.h	2009-06-20 22:03:23 UTC (rev 38003)
@@ -0,0 +1,537 @@
+#ifndef GRASS_RAST_H
+#define GRASS_RAST_H
+#include <grass/gis.h>
+/* --- ANSI prototypes for the lib/raster functions --- */
+/* adj_cellhd.c */
+const char *Rast_adjust_Cell_head(struct Cell_head *, int, int);
+const char *Rast_adjust_Cell_head3(struct Cell_head *, int, int, int);
+/* alloc_cell.c */
+size_t Rast_raster_size(RASTER_MAP_TYPE);
+CELL *Rast_allocate_cell_buf(void);
+void *Rast_allocate_raster_buf(RASTER_MAP_TYPE);
+CELL *Rast_allocate_c_raster_buf(void);
+FCELL *Rast_allocate_f_raster_buf(void);
+DCELL *Rast_allocate_d_raster_buf(void);
+char *Rast_allocate_null_buf(void);
+unsigned char *Rast__allocate_null_bits(int);
+int Rast__null_bitstream_size(int);
+/* auto_mask.c */
+int Rast__check_for_auto_masking(void);
+void Rast_suppress_masking(void);
+void Rast_unsuppress_masking(void);
+/* cats.c */
+int Rast_read_cats(const char *, const char *, struct Categories *);
+int Rast_read_raster_cats(const char *, const char *, struct Categories *);
+int Rast_read_vector_cats(const char *, const char *, struct Categories *);
+CELL Rast_number_of_cats(const char *, const char *);
+char *Rast_get_cats_title(const struct Categories *);
+char *Rast_get_raster_cats_title(const struct Categories *);
+char *Rast_get_cat(CELL, struct Categories *);
+char *Rast_get_c_raster_cat(CELL *, struct Categories *);
+char *Rast_get_f_raster_cat(FCELL *, struct Categories *);
+char *Rast_get_d_raster_cat(DCELL *, struct Categories *);
+char *Rast_get_raster_cat(void *, struct Categories *, RASTER_MAP_TYPE);
+void Rast_unmark_raster_cats(struct Categories *);
+void Rast_mark_c_raster_cats(const CELL *, int, struct Categories *);
+void Rast_mark_f_raster_cats(const FCELL *, int, struct Categories *);
+void Rast_mark_d_raster_cats(const DCELL *, int, struct Categories *);
+int Rast_mark_raster_cats(const void *, int, struct Categories *, RASTER_MAP_TYPE);
+void Rast_rewind_raster_cats(struct Categories *);
+char *Rast_get_next_marked_d_raster_cat(struct Categories *, DCELL *, DCELL *,
+				     long *);
+char *Rast_get_next_marked_c_raster_cat(struct Categories *, CELL *, CELL *,
+				     long *);
+char *Rast_get_next_marked_f_raster_cat(struct Categories *, FCELL *, FCELL *,
+				     long *);
+char *Rast_get_next_marked_raster_cat(struct Categories *, void *, void *,
+				   long *, RASTER_MAP_TYPE);
+int Rast_set_cat(CELL, const char *, struct Categories *);
+int Rast_set_c_raster_cat(const CELL *, const CELL *, const char *, struct Categories *);
+int Rast_set_f_raster_cat(const FCELL *, const FCELL *, const char *, struct Categories *);
+int Rast_set_d_raster_cat(const DCELL *, const DCELL *, const char *, struct Categories *);
+int Rast_set_raster_cat(const void *, const void *, const char *, struct Categories *,
+		     RASTER_MAP_TYPE);
+int Rast_write_cats(const char *, struct Categories *);
+int Rast_write_raster_cats(const char *, struct Categories *);
+int Rast_write_vector_cats(const char *, struct Categories *);
+char *Rast_get_ith_d_raster_cat(const struct Categories *, int, DCELL *,
+			     DCELL *);
+char *Rast_get_ith_f_raster_cat(const struct Categories *, int, void *, void *);
+char *Rast_get_ith_c_raster_cat(const struct Categories *, int, void *, void *);
+char *Rast_get_ith_raster_cat(const struct Categories *, int, void *, void *,
+			   RASTER_MAP_TYPE);
+void Rast_init_cats(CELL, const char *, struct Categories *);
+void Rast_init_raster_cats(const char *, struct Categories *);
+void Rast_set_cats_title(const char *, struct Categories *);
+void Rast_set_raster_cats_title(const char *, struct Categories *);
+void Rast_set_cats_fmt(const char *, double, double, double, double,
+		   struct Categories *);
+void Rast_set_raster_cats_fmt(const char *, double, double, double, double,
+void Rast_free_cats(struct Categories *);
+void Rast_free_raster_cats(struct Categories *);
+void Rast_copy_raster_cats(struct Categories *, const struct Categories *);
+int Rast_number_of_raster_cats(struct Categories *);
+int Rast_sort_cats(struct Categories *);
+/* cell_stats.c */
+void Rast_init_cell_stats(struct Cell_stats *);
+int Rast_update_cell_stats(const CELL *, int, struct Cell_stats *);
+int Rast_find_cell_stat(CELL, long *, const struct Cell_stats *);
+int Rast_rewind_cell_stats(struct Cell_stats *);
+int Rast_next_cell_stat(CELL *, long *, struct Cell_stats *);
+void Rast_get_stats_for_null_value(long *, const struct Cell_stats *);
+void Rast_free_cell_stats(struct Cell_stats *);
+/* cell_title.c */
+char *Rast_get_cell_title(const char *, const char *);
+/* cellstats_eq.c */
+int Rast_cell_stats_histo_eq(struct Cell_stats *, CELL, CELL, CELL, CELL, int,
+			  void (*)(CELL, CELL, CELL));
+/* closecell.c */
+int Rast_close_cell(int);
+int Rast_unopen_cell(int);
+/* color_compat.c */
+void Rast_make_ryg_colors(struct Colors *, CELL, CELL);
+void Rast_make_ryg_fp_colors(struct Colors *, DCELL, DCELL);
+void Rast_make_aspect_colors(struct Colors *, CELL, CELL);
+void Rast_make_aspect_fp_colors(struct Colors *, DCELL, DCELL);
+void Rast_make_byr_colors(struct Colors *, CELL, CELL);
+void Rast_make_byr_fp_colors(struct Colors *, DCELL, DCELL);
+void Rast_make_bgyr_colors(struct Colors *, CELL, CELL);
+void Rast_make_bgyr_fp_colors(struct Colors *, DCELL, DCELL);
+void Rast_make_byg_colors(struct Colors *, CELL, CELL);
+void Rast_make_byg_fp_colors(struct Colors *, DCELL, DCELL);
+void Rast_make_grey_scale_colors(struct Colors *, CELL, CELL);
+void Rast_make_grey_scale_fp_colors(struct Colors *, DCELL, DCELL);
+void Rast_make_gyr_colors(struct Colors *, CELL, CELL);
+void Rast_make_gyr_fp_colors(struct Colors *, DCELL, DCELL);
+void Rast_make_rainbow_colors(struct Colors *, CELL, CELL);
+void Rast_make_rainbow_fp_colors(struct Colors *, DCELL, DCELL);
+void Rast_make_ramp_colors(struct Colors *, CELL, CELL);
+void Rast_make_ramp_fp_colors(struct Colors *, DCELL, DCELL);
+void Rast_make_wave_colors(struct Colors *, CELL, CELL);
+void Rast_make_wave_fp_colors(struct Colors *, DCELL, DCELL);
+/* color_free.c */
+void Rast_free_colors(struct Colors *);
+void Rast__color_free_rules(struct _Color_Info_ *);
+void Rast__color_free_lookup(struct _Color_Info_ *);
+void Rast__color_free_fp_lookup(struct _Color_Info_ *);
+void Rast__color_reset(struct Colors *);
+/* color_get.c */
+int Rast_get_color(CELL, int *, int *, int *, struct Colors *);
+int Rast_get_raster_color(const void *, int *, int *, int *, struct Colors *,
+		       RASTER_MAP_TYPE);
+int Rast_get_c_raster_color(const CELL *, int *, int *, int *, struct Colors *);
+int Rast_get_f_raster_color(const FCELL *, int *, int *, int *, struct Colors *);
+int Rast_get_d_raster_color(const DCELL *, int *, int *, int *, struct Colors *);
+void Rast_get_null_value_color(int *, int *, int *, const struct Colors *);
+void Rast_get_default_color(int *, int *, int *, const struct Colors *);
+/* color_hist.c */
+void Rast_make_histogram_eq_colors(struct Colors *, struct Cell_stats *);
+void Rast_make_histogram_log_colors(struct Colors *, struct Cell_stats *, int, int);
+/* color_init.c */
+void Rast_init_colors(struct Colors *);
+/* color_insrt.c */
+int Rast__insert_color_into_lookup(CELL, int, int, int, struct _Color_Info_ *);
+/* color_invrt.c */
+int Rast_invert_colors(struct Colors *);
+/* color_look.c */
+void Rast_lookup_colors(const CELL *, unsigned char *, unsigned char *,
+		     unsigned char *, unsigned char *, int, struct Colors *);
+void Rast_lookup_c_raster_colors(const CELL *, unsigned char *, unsigned char *,
+			      struct Colors *);
+void Rast_lookup_raster_colors(const void *, unsigned char *, unsigned char *,
+			    struct Colors *, RASTER_MAP_TYPE);
+void Rast_lookup_f_raster_colors(const FCELL *, unsigned char *, unsigned char *,
+			     struct Colors *);
+void Rast_lookup_d_raster_colors(const DCELL *, unsigned char *, unsigned char *,
+			     struct Colors *);
+void Rast__lookup_colors(const void *, unsigned char *, unsigned char *,
+		      unsigned char *, unsigned char *, int, struct Colors *,
+		      int, int, RASTER_MAP_TYPE);
+void Rast__interpolate_color_rule(DCELL, unsigned char *, unsigned char *,
+			       unsigned char *, const struct _Color_Rule_ *);
+/* color_org.c */
+void Rast__organize_colors(struct Colors *);
+/* color_rand.c */
+void Rast_make_random_colors(struct Colors *, CELL, CELL);
+/* color_range.c */
+void Rast_set_color_range(CELL, CELL, struct Colors *);
+void Rast_set_d_color_range(DCELL, DCELL, struct Colors *);
+void Rast_get_color_range(CELL *, CELL *, const struct Colors *);
+void Rast_get_d_color_range(DCELL *, DCELL *, const struct Colors *);
+/* color_read.c */
+int Rast_read_colors(const char *, const char *, struct Colors *);
+void Rast_mark_colors_as_fp(struct Colors *);
+/* color_remove.c */
+int Rast_remove_colors(const char *, const char *);
+/* color_rule.c */
+void Rast_add_d_raster_color_rule(const DCELL *, int, int, int,
+			       const DCELL *, int, int, int,
+			       struct Colors *);
+void Rast_add_f_raster_color_rule(const FCELL *, int, int, int,
+			       const FCELL *, int, int, int,
+			       struct Colors *);
+void Rast_add_c_raster_color_rule(const CELL *, int, int, int,
+			       const CELL *, int, int, int,
+			       struct Colors *);
+void Rast_add_raster_color_rule(const void *, int, int, int,
+			     const void *, int, int, int,
+void Rast_add_color_rule(const CELL, int, int, int,
+		      const CELL, int, int, int,
+		      struct Colors *);
+int Rast_add_modular_d_raster_color_rule(const DCELL *, int, int, int,
+				      struct Colors *);
+int Rast_add_modular_f_raster_color_rule(const FCELL *, int, int, int,
+				      struct Colors *);
+int Rast_add_modular_c_raster_color_rule(const CELL *, int, int, int,
+				      struct Colors *);
+int Rast_add_modular_raster_color_rule(const void *, int, int, int,
+int Rast_add_modular_color_rule(CELL, int, int, int,
+			     CELL, int, int, int,
+			     struct Colors *);
+/* color_rule_get.c */
+int Rast_colors_count(const struct Colors *);
+int Rast_get_f_color_rule(DCELL *, unsigned char *, unsigned char *,
+		       unsigned char *, DCELL *, unsigned char *,
+		       const struct Colors *, int);
+/* color_rules.c */
+typedef int read_rule_fn(void *, DCELL, DCELL,
+			 DCELL *, int *, int *, int *, int *, int *, int *);
+int Rast_parse_color_rule(DCELL, DCELL, const char *, DCELL *, int *, int *,
+		       int *, int *, int *, int *);
+const char *Rast_parse_color_rule_error(int);
+int Rast_read_color_rule(void *, DCELL, DCELL, DCELL *, int *, int *, int *,
+		      int *, int *, int *);
+int Rast_read_color_rules(struct Colors *, DCELL, DCELL, read_rule_fn *, void *);
+int Rast_load_colors(struct Colors *, const char *, CELL, CELL);
+int Rast_load_fp_colors(struct Colors *, const char *, DCELL, DCELL);
+void Rast_make_colors(struct Colors *, const char *, CELL, CELL);
+void Rast_make_fp_colors(struct Colors *, const char *, DCELL, DCELL);
+/* color_set.c */
+void Rast_set_color(CELL, int, int, int, struct Colors *);
+void Rast_set_d_color(DCELL, int, int, int, struct Colors *);
+void Rast_set_null_value_color(int, int, int, struct Colors *);
+void Rast_set_default_color(int, int, int, struct Colors *);
+/* color_shift.c */
+void Rast_shift_colors(int, struct Colors *);
+void Rast_shift_d_colors(DCELL, struct Colors *);
+/* color_str.c */
+int Rast_str_to_color(const char *, int *, int *, int *);
+/* color_write.c */
+int Rast_write_colors(const char *, const char *, struct Colors *);
+void Rast__write_colors(FILE *, struct Colors *);
+/* color_xform.c */
+void Rast_histogram_eq_colors(struct Colors *, struct Colors *,
+			   struct Cell_stats *);
+void Rast_histogram_eq_colors_fp(struct Colors *,
+			      struct Colors *, struct FP_stats *);
+void Rast_log_colors(struct Colors *, struct Colors *, int);
+void Rast_abs_log_colors(struct Colors *, struct Colors *, int);
+/* format.c */
+int Rast__check_format(int);
+int Rast__read_row_ptrs(int);
+int Rast__write_row_ptrs(int);
+/* fpreclass.c */
+void Rast_fpreclass_clear(struct FPReclass *);
+void Rast_fpreclass_reset(struct FPReclass *);
+void Rast_fpreclass_init(struct FPReclass *);
+void Rast_fpreclass_set_domain(struct FPReclass *, DCELL, DCELL);
+void Rast_fpreclass_set_range(struct FPReclass *, DCELL, DCELL);
+int Rast_fpreclass_get_limits(const struct FPReclass *, DCELL *, DCELL *,
+			   DCELL *, DCELL *);
+int Rast_fpreclass_nof_rules(const struct FPReclass *);
+void Rast_fpreclass_get_ith_rule(const struct FPReclass *, int, DCELL *, DCELL *,
+void Rast_fpreclass_set_neg_infinite_rule(struct FPReclass *, DCELL, DCELL);
+int Rast_fpreclass_get_neg_infinite_rule(const struct FPReclass *, DCELL *,
+				      DCELL *);
+void Rast_fpreclass_set_pos_infinite_rule(struct FPReclass *, DCELL, DCELL);
+int Rast_fpreclass_get_pos_infinite_rule(const struct FPReclass *, DCELL *,
+				      DCELL *);
+void Rast_fpreclass_add_rule(struct FPReclass *, DCELL, DCELL, DCELL, DCELL);
+void Rast_fpreclass_reverse_rule_order(struct FPReclass *);
+DCELL Rast_fpreclass_get_cell_value(const struct FPReclass *, DCELL);
+void Rast_fpreclass_perform_di(const struct FPReclass *, const DCELL *, CELL *,
+			    int);
+void Rast_fpreclass_perform_df(const struct FPReclass *, const DCELL *, FCELL *,
+			    int);
+void Rast_fpreclass_perform_dd(const struct FPReclass *, const DCELL *, DCELL *,
+			    int);
+void Rast_fpreclass_perform_fi(const struct FPReclass *, const FCELL *, CELL *,
+			    int);
+void Rast_fpreclass_perform_ff(const struct FPReclass *, const FCELL *, FCELL *,
+			    int);
+void Rast_fpreclass_perform_fd(const struct FPReclass *, const FCELL *, DCELL *,
+			    int);
+void Rast_fpreclass_perform_ii(const struct FPReclass *, const CELL *, CELL *,
+			    int);
+void Rast_fpreclass_perform_if(const struct FPReclass *, const CELL *, FCELL *,
+			    int);
+void Rast_fpreclass_perform_id(const struct FPReclass *, const CELL *, DCELL *,
+			    int);
+/* gdal.c */
+void Rast_init_gdal(void);
+struct GDAL_link *Rast_get_gdal_link(const char *, const char *);
+struct GDAL_link *Rast_create_gdal_link(const char *, RASTER_MAP_TYPE);
+void Rast_close_gdal_link(struct GDAL_link *);
+int Rast_close_gdal_write_link(struct GDAL_link *);
+/* get_cellhd.c */
+int Rast_get_cellhd(const char *, const char *, struct Cell_head *);
+/* get_row.c */
+int Rast_get_map_row_nomask(int, CELL *, int);
+int Rast_get_raster_row_nomask(int, void *, int, RASTER_MAP_TYPE);
+int Rast_get_c_raster_row_nomask(int, CELL *, int);
+int Rast_get_f_raster_row_nomask(int, FCELL *, int);
+int Rast_get_d_raster_row_nomask(int, DCELL *, int);
+int Rast_get_map_row(int, CELL *, int);
+int Rast_get_raster_row(int, void *, int, RASTER_MAP_TYPE);
+int Rast_get_c_raster_row(int, CELL *, int);
+int Rast_get_f_raster_row(int, FCELL *, int);
+int Rast_get_d_raster_row(int, DCELL *, int);
+int Rast_get_null_value_row(int, char *, int);
+/* get_row_colr.c */
+int Rast_get_raster_row_colors(int, int, struct Colors *,
+			    unsigned char *, unsigned char *, unsigned char *,
+			    unsigned char *);
+/* histo_eq.c */
+void Rast_histogram_eq(const struct Histogram *, unsigned char **,
+		    CELL *, CELL *);
+/* histogram.c */
+void Rast_init_histogram(struct Histogram *);
+int Rast_read_histogram(const char *, const char *, struct Histogram *);
+int Rast_write_histogram(const char *, const struct Histogram *);
+int Rast_write_histogram_cs(const char *, struct Cell_stats *);
+void Rast_make_histogram_cs(struct Cell_stats *, struct Histogram *);
+int Rast_get_histogram_num(const struct Histogram *);
+CELL Rast_get_histogram_cat(int, const struct Histogram *);
+long Rast_get_histogram_count(int, const struct Histogram *);
+void Rast_free_histogram(struct Histogram *);
+int Rast_sort_histogram(struct Histogram *);
+int Rast_sort_histogram_by_count(struct Histogram *);
+void Rast_remove_histogram(const char *);
+int Rast_add_histogram(CELL, long, struct Histogram *);
+int Rast_set_histogram(CELL, long, struct Histogram *);
+void Rast_extend_histogram(CELL, long, struct Histogram *);
+void Rast_zero_histogram(struct Histogram *);
+/* history.c */
+int Rast_read_history(const char *, const char *, struct History *);
+int Rast_write_history(const char *, struct History *);
+void Rast_short_history(const char *, const char *, struct History *);
+int Rast_command_history(struct History *);
+/* interp.c */
+DCELL Rast_interp_linear(double, DCELL, DCELL);
+DCELL Rast_interp_bilinear(double, double, DCELL, DCELL, DCELL, DCELL);
+DCELL Rast_interp_cubic(double, DCELL, DCELL, DCELL, DCELL);
+DCELL Rast_interp_bicubic(double, double,
+		       DCELL, DCELL, DCELL, DCELL, DCELL, DCELL, DCELL, DCELL,
+		       DCELL);
+/* mask_info.c */
+char *Rast_mask_info(void);
+int Rast__mask_info(char *, char *);
+/* maskfd.c */
+int Rast_maskfd(void);
+/* null_val.c */
+void Rast__set_null_value(void *, int, int, RASTER_MAP_TYPE);
+void Rast_set_null_value(void *, int, RASTER_MAP_TYPE);
+void Rast_set_c_null_value(CELL *, int);
+void Rast_set_f_null_value(FCELL *, int);
+void Rast_set_d_null_value(DCELL *, int);
+int Rast_is_null_value(const void *, RASTER_MAP_TYPE);
+int Rast_is_c_null_value(const CELL *);
+int Rast_is_f_null_value(const FCELL *);
+int Rast_is_d_null_value(const DCELL *);
+void Rast_insert_null_values(void *, char *, int, RASTER_MAP_TYPE);
+void Rast_insert_c_null_values(CELL *, char *, int);
+void Rast_insert_f_null_values(FCELL *, char *, int);
+void Rast_insert_d_null_values(DCELL *, char *, int);
+int Rast__check_null_bit(const unsigned char *, int, int);
+void Rast__convert_01_flags(const char *, unsigned char *, int);
+void Rast__convert_flags_01(char *, const unsigned char *, int);
+void Rast__init_null_bits(unsigned char *, int);
+/* opencell.c */
+int Rast_open_cell_old(const char *, const char *);
+int Rast__open_cell_old(const char *, const char *);
+int Rast_open_cell_new(const char *);
+int Rast_open_cell_new_uncompressed(const char *);
+void Rast_want_histogram(int);
+void Rast_set_cell_format(int);
+int Rast_cellvalue_format(CELL);
+int Rast_open_fp_cell_new(const char *);
+int Rast_open_fp_cell_new_uncompressed(const char *);
+int Rast_set_fp_type(RASTER_MAP_TYPE);
+int Rast_raster_map_is_fp(const char *, const char *);
+RASTER_MAP_TYPE Rast_raster_map_type(const char *, const char *);
+RASTER_MAP_TYPE Rast__check_fp_type(const char *, const char *);
+RASTER_MAP_TYPE Rast_get_raster_map_type(int);
+int Rast_open_raster_new(const char *, RASTER_MAP_TYPE);
+int Rast_open_raster_new_uncompressed(const char *, RASTER_MAP_TYPE);
+int Rast_set_quant_rules(int, struct Quant *);
+/* put_cellhd.c */
+int Rast_put_cellhd(const char *, struct Cell_head *);
+/* put_row.c */
+int Rast_put_map_row(int, const CELL *);
+int Rast_put_raster_row(int, const void *, RASTER_MAP_TYPE);
+int Rast_put_c_raster_row(int, const CELL *);
+int Rast_put_f_raster_row(int, const FCELL *);
+int Rast_put_d_raster_row(int, const DCELL *);
+int Rast__open_null_write(int);
+int Rast__write_null_bits(int, const unsigned char *, int, int, int);
+/* put_title.c */
+int Rast_put_cell_title(const char *, const char *);
+/* quant.c */
+void Rast_quant_clear(struct Quant *);
+void Rast_quant_free(struct Quant *);
+int Rast__quant_organize_fp_lookup(struct Quant *);
+void Rast_quant_init(struct Quant *);
+int Rast_quant_is_truncate(const struct Quant *);
+int Rast_quant_is_round(const struct Quant *);
+void Rast_quant_truncate(struct Quant *);
+void Rast_quant_round(struct Quant *);
+int Rast_quant_get_limits(const struct Quant *, DCELL *, DCELL *, CELL *,
+		       CELL *);
+int Rast_quant_nof_rules(const struct Quant *);
+void Rast_quant_get_ith_rule(const struct Quant *, int, DCELL *, DCELL *, CELL *,
+			  CELL *);
+void Rast_quant_set_neg_infinite_rule(struct Quant *, DCELL, CELL);
+int Rast_quant_get_neg_infinite_rule(const struct Quant *, DCELL *, CELL *);
+void Rast_quant_set_pos_infinite_rule(struct Quant *, DCELL, CELL);
+int Rast_quant_get_pos_infinite_rule(const struct Quant *, DCELL *, CELL *);
+void Rast_quant_add_rule(struct Quant *, DCELL, DCELL, CELL, CELL);
+void Rast_quant_reverse_rule_order(struct Quant *);
+CELL Rast_quant_get_cell_value(struct Quant *, DCELL);
+void Rast_quant_perform_d(struct Quant *, const DCELL *, CELL *, int);
+void Rast_quant_perform_f(struct Quant *, const FCELL *, CELL *, int);
+struct Quant_table *Rast__quant_get_rule_for_d_raster_val(const struct Quant *,
+						       DCELL);
+/* quant_io.c */
+int Rast__quant_import(const char *, const char *, struct Quant *);
+int Rast__quant_export(const char *, const char *, const struct Quant *);
+/* quant_rw.c */
+int Rast_truncate_fp_map(const char *, const char *);
+int Rast_round_fp_map(const char *, const char *);
+int Rast_quantize_fp_map(const char *, const char *, CELL, CELL);
+int Rast_quantize_fp_map_range(const char *, const char *, DCELL, DCELL, CELL,
+			    CELL);
+int Rast_write_quant(const char *, const char *, const struct Quant *);
+int Rast_read_quant(const char *, const char *, struct Quant *);
+/* range.c */
+void Rast__remove_fp_range(const char *);
+void Rast_construct_default_range(struct Range *);
+int Rast_read_fp_range(const char *, const char *, struct FPRange *);
+int Rast_read_range(const char *, const char *, struct Range *);
+int Rast_write_range(const char *, const struct Range *);
+int Rast_write_fp_range(const char *, const struct FPRange *);
+void Rast_update_range(CELL, struct Range *);
+void Rast_update_fp_range(DCELL, struct FPRange *);
+void Rast_row_update_range(const CELL *, int, struct Range *);
+void Rast__row_update_range(const CELL *, int, struct Range *, int);
+void Rast_row_update_fp_range(const void *, int, struct FPRange *,
+			  RASTER_MAP_TYPE);
+void Rast_init_range(struct Range *);
+void Rast_get_range_min_max(const struct Range *, CELL *, CELL *);
+void Rast_init_fp_range(struct FPRange *);
+void Rast_get_fp_range_min_max(const struct FPRange *, DCELL *, DCELL *);
+/* raster.c */
+void *Rast_incr_void_ptr(const void *, const size_t);
+int Rast_raster_cmp(const void *, const void *, RASTER_MAP_TYPE);
+void Rast_raster_cpy(void *, const void *, int, RASTER_MAP_TYPE);
+void Rast_set_raster_value_c(void *, CELL, RASTER_MAP_TYPE);
+void Rast_set_raster_value_f(void *, FCELL, RASTER_MAP_TYPE);
+void Rast_set_raster_value_d(void *, DCELL, RASTER_MAP_TYPE);
+CELL Rast_get_raster_value_c(const void *, RASTER_MAP_TYPE);
+FCELL Rast_get_raster_value_f(const void *, RASTER_MAP_TYPE);
+DCELL Rast_get_raster_value_d(const void *, RASTER_MAP_TYPE);
+/* raster_metadata.c */
+int Rast_read_raster_units(const char *, const char *, char *);
+int Rast_read_raster_vdatum(const char *, const char *, char *);
+int Rast_write_raster_units(const char *, const char *);
+int Rast_write_raster_vdatum(const char *, const char *);
+int Rast__raster_misc_read_line(const char *, const char *, const char *,
+			     char *);
+int Rast__raster_misc_write_line(const char *, const char *, const char *);
+/* rd_cellhd.c */
+char *Rast__read_Cell_head(FILE *, struct Cell_head *, int);
+char *Rast__read_Cell_head_array(char **, struct Cell_head *, int);
+/* reclass.c */
+int Rast_is_reclass(const char *, const char *, char *, char *);
+int Rast_is_reclassed_to(const char *, const char *, int *, char ***);
+int Rast_get_reclass(const char *, const char *, struct Reclass *);
+void Rast_free_reclass(struct Reclass *);
+int Rast_put_reclass(const char *, const struct Reclass *);
+/* sample.c */
+DCELL Rast_get_raster_sample_nearest(int, const struct Cell_head *, struct Categories *, double, double, int);
+DCELL Rast_get_raster_sample_bilinear(int, const struct Cell_head *, struct Categories *, double, double, int);
+DCELL Rast_get_raster_sample_cubic(int, const struct Cell_head *, struct Categories *, double, double, int);
+DCELL Rast_get_raster_sample(int, const struct Cell_head *, struct Categories *, double, double, int, INTERP_TYPE);
+/* zero_cell.c */
+void Rast_zero_cell_buf(CELL *);
+void Rast_zero_raster_buf(void *, RASTER_MAP_TYPE);
+#endif
Property changes on: grass/trunk/include/Rast.h
___________________________________________________________________
   + text/x-chdr
   + Author Date Id
   + native
Property changes on: grass/trunk/include/arraystats.h
   + text/x-chdr
   + Author Date Id
Property changes on: grass/trunk/include/cluster.h
   + text/x-chdr
   + Author Date Id
Modified: grass/trunk/include/gis.h
--- grass/trunk/include/gis.h	2009-06-20 21:39:23 UTC (rev 38002)
+++ grass/trunk/include/gis.h	2009-06-20 22:03:23 UTC (rev 38003)
@@ -38,7 +38,7 @@
 static const char *GRASS_copyright __attribute__ ((unused))
     = "GRASS GNU GPL licensed Software";
-#define GIS_H_VERSION "$Revision$"
+#define GIS_H_VERSION "$Revision: 37043 $"
 #define GIS_H_DATE    "$Date$"
 #define G_gisinit(pgm) G__gisinit(GIS_H_VERSION, (pgm))
Property changes on: grass/trunk/include/gis.h
   - Author Date Id Revision
   + Author Date Id
Modified: grass/trunk/include/gisdefs.h
--- grass/trunk/include/gisdefs.h	2009-06-20 21:39:23 UTC (rev 38002)
+++ grass/trunk/include/gisdefs.h	2009-06-20 22:03:23 UTC (rev 38003)
@@ -46,10 +46,6 @@
 #include <sys/types.h>
-/* adj_cellhd.c */
-const char *G_adjust_Cell_head(struct Cell_head *, int, int);
-const char *G_adjust_Cell_head3(struct Cell_head *, int, int, int);
 /* align_window.c */
 const char *G_align_window(struct Cell_head *, const struct Cell_head *);
@@ -63,17 +59,6 @@
 #define G_calloc(m, n)  G__calloc(__FILE__, __LINE__, (m), (n))
 #define G_realloc(p, n) G__realloc(__FILE__, __LINE__, (p), (n))
-/* alloc_cell.c */
-size_t G_raster_size(RASTER_MAP_TYPE);
-CELL *G_allocate_cell_buf(void);
-void *G_allocate_raster_buf(RASTER_MAP_TYPE);
-CELL *G_allocate_c_raster_buf(void);
-FCELL *G_allocate_f_raster_buf(void);
-DCELL *G_allocate_d_raster_buf(void);
-char *G_allocate_null_buf(void);
-unsigned char *G__allocate_null_bits(int);
-int G__null_bitstream_size(int);
 /* area.c */
 int G_begin_cell_area_calculations(void);
 double G_area_of_cell_at_row(int);
@@ -116,268 +101,18 @@
 int G_asprintf(char **, const char *, ...)
     __attribute__ ((format(printf, 2, 3)));
-/* auto_mask.c */
-int G__check_for_auto_masking(void);
-void G_suppress_masking(void);
-void G_unsuppress_masking(void);
 /* basename.c */
 char *G_basename(char *, const char *);
 /* bres_line.c */
 void G_bresenham_line(int, int, int, int, int (*)(int, int));
-/* cats.c */
-int G_read_cats(const char *, const char *, struct Categories *);
-int G_read_raster_cats(const char *, const char *, struct Categories *);
-int G_read_vector_cats(const char *, const char *, struct Categories *);
-CELL G_number_of_cats(const char *, const char *);
-char *G_get_cats_title(const struct Categories *);
-char *G_get_raster_cats_title(const struct Categories *);
-char *G_get_cat(CELL, struct Categories *);
-char *G_get_c_raster_cat(CELL *, struct Categories *);
-char *G_get_f_raster_cat(FCELL *, struct Categories *);
-char *G_get_d_raster_cat(DCELL *, struct Categories *);
-char *G_get_raster_cat(void *, struct Categories *, RASTER_MAP_TYPE);
-void G_unmark_raster_cats(struct Categories *);
-void G_mark_c_raster_cats(const CELL *, int, struct Categories *);
-void G_mark_f_raster_cats(const FCELL *, int, struct Categories *);
-void G_mark_d_raster_cats(const DCELL *, int, struct Categories *);
-int G_mark_raster_cats(const void *, int, struct Categories *, RASTER_MAP_TYPE);
-void G_rewind_raster_cats(struct Categories *);
-char *G_get_next_marked_d_raster_cat(struct Categories *, DCELL *, DCELL *,
-				     long *);
-char *G_get_next_marked_c_raster_cat(struct Categories *, CELL *, CELL *,
-				     long *);
-char *G_get_next_marked_f_raster_cat(struct Categories *, FCELL *, FCELL *,
-				     long *);
-char *G_get_next_marked_raster_cat(struct Categories *, void *, void *,
-				   long *, RASTER_MAP_TYPE);
-int G_set_cat(CELL, const char *, struct Categories *);
-int G_set_c_raster_cat(const CELL *, const CELL *, const char *, struct Categories *);
-int G_set_f_raster_cat(const FCELL *, const FCELL *, const char *, struct Categories *);
-int G_set_d_raster_cat(const DCELL *, const DCELL *, const char *, struct Categories *);
-int G_set_raster_cat(const void *, const void *, const char *, struct Categories *,
-		     RASTER_MAP_TYPE);
-int G_write_cats(const char *, struct Categories *);
-int G_write_raster_cats(const char *, struct Categories *);
-int G_write_vector_cats(const char *, struct Categories *);
-char *G_get_ith_d_raster_cat(const struct Categories *, int, DCELL *,
-			     DCELL *);
-char *G_get_ith_f_raster_cat(const struct Categories *, int, void *, void *);
-char *G_get_ith_c_raster_cat(const struct Categories *, int, void *, void *);
-char *G_get_ith_raster_cat(const struct Categories *, int, void *, void *,
-			   RASTER_MAP_TYPE);
-void G_init_cats(CELL, const char *, struct Categories *);
-void G_init_raster_cats(const char *, struct Categories *);
-void G_set_cats_title(const char *, struct Categories *);
-void G_set_raster_cats_title(const char *, struct Categories *);
-void G_set_cats_fmt(const char *, double, double, double, double,
-		   struct Categories *);
-void G_set_raster_cats_fmt(const char *, double, double, double, double,
-void G_free_cats(struct Categories *);
-void G_free_raster_cats(struct Categories *);
-void G_copy_raster_cats(struct Categories *, const struct Categories *);
-int G_number_of_raster_cats(struct Categories *);
-int G_sort_cats(struct Categories *);
-/* cell_stats.c */
-void G_init_cell_stats(struct Cell_stats *);
-int G_update_cell_stats(const CELL *, int, struct Cell_stats *);
-int G_find_cell_stat(CELL, long *, const struct Cell_stats *);
-int G_rewind_cell_stats(struct Cell_stats *);
-int G_next_cell_stat(CELL *, long *, struct Cell_stats *);
-void G_get_stats_for_null_value(long *, const struct Cell_stats *);
-void G_free_cell_stats(struct Cell_stats *);
-/* cell_title.c */
-char *G_get_cell_title(const char *, const char *);
-/* cellstats_eq.c */
-int G_cell_stats_histo_eq(struct Cell_stats *, CELL, CELL, CELL, CELL, int,
-			  void (*)(CELL, CELL, CELL));
 /* clear_scrn.c */
 void G_clear_screen(void);
 /* clicker.c */
 void G_clicker(void);
-/* closecell.c */
-int G_close_cell(int);
-int G_unopen_cell(int);
-/* color_compat.c */
-void G_make_ryg_colors(struct Colors *, CELL, CELL);
-void G_make_ryg_fp_colors(struct Colors *, DCELL, DCELL);
-void G_make_aspect_colors(struct Colors *, CELL, CELL);
-void G_make_aspect_fp_colors(struct Colors *, DCELL, DCELL);
-void G_make_byr_colors(struct Colors *, CELL, CELL);
-void G_make_byr_fp_colors(struct Colors *, DCELL, DCELL);
-void G_make_bgyr_colors(struct Colors *, CELL, CELL);
-void G_make_bgyr_fp_colors(struct Colors *, DCELL, DCELL);
-void G_make_byg_colors(struct Colors *, CELL, CELL);
-void G_make_byg_fp_colors(struct Colors *, DCELL, DCELL);
-void G_make_grey_scale_colors(struct Colors *, CELL, CELL);
-void G_make_grey_scale_fp_colors(struct Colors *, DCELL, DCELL);
-void G_make_gyr_colors(struct Colors *, CELL, CELL);
-void G_make_gyr_fp_colors(struct Colors *, DCELL, DCELL);
-void G_make_rainbow_colors(struct Colors *, CELL, CELL);
-void G_make_rainbow_fp_colors(struct Colors *, DCELL, DCELL);
-void G_make_ramp_colors(struct Colors *, CELL, CELL);
-void G_make_ramp_fp_colors(struct Colors *, DCELL, DCELL);
-void G_make_wave_colors(struct Colors *, CELL, CELL);
-void G_make_wave_fp_colors(struct Colors *, DCELL, DCELL);
-/* color_free.c */
-void G_free_colors(struct Colors *);
-void G__color_free_rules(struct _Color_Info_ *);
-void G__color_free_lookup(struct _Color_Info_ *);
-void G__color_free_fp_lookup(struct _Color_Info_ *);
-void G__color_reset(struct Colors *);
-/* color_get.c */
-int G_get_color(CELL, int *, int *, int *, struct Colors *);
-int G_get_raster_color(const void *, int *, int *, int *, struct Colors *,
-		       RASTER_MAP_TYPE);
-int G_get_c_raster_color(const CELL *, int *, int *, int *, struct Colors *);
-int G_get_f_raster_color(const FCELL *, int *, int *, int *, struct Colors *);
-int G_get_d_raster_color(const DCELL *, int *, int *, int *, struct Colors *);
-void G_get_null_value_color(int *, int *, int *, const struct Colors *);
-void G_get_default_color(int *, int *, int *, const struct Colors *);
-/* color_hist.c */
-void G_make_histogram_eq_colors(struct Colors *, struct Cell_stats *);
-void G_make_histogram_log_colors(struct Colors *, struct Cell_stats *, int, int);
-/* color_init.c */
-void G_init_colors(struct Colors *);
-/* color_insrt.c */
-int G__insert_color_into_lookup(CELL, int, int, int, struct _Color_Info_ *);
-/* color_invrt.c */
-void G_invert_colors(struct Colors *);
-/* color_look.c */
-void G_lookup_colors(const CELL *, unsigned char *, unsigned char *,
-		     unsigned char *, unsigned char *, int, struct Colors *);
-void G_lookup_c_raster_colors(const CELL *, unsigned char *, unsigned char *,
-			      struct Colors *);
-void G_lookup_raster_colors(const void *, unsigned char *, unsigned char *,
-			    struct Colors *, RASTER_MAP_TYPE);
-void G_lookup_f_raster_colors(const FCELL *, unsigned char *, unsigned char *,
-			     struct Colors *);
-void G_lookup_d_raster_colors(const DCELL *, unsigned char *, unsigned char *,
-			     struct Colors *);
-void G__lookup_colors(const void *, unsigned char *, unsigned char *,
-		      unsigned char *, unsigned char *, int, struct Colors *,
-		      int, int, RASTER_MAP_TYPE);
-void G__interpolate_color_rule(DCELL, unsigned char *, unsigned char *,
-			       unsigned char *, const struct _Color_Rule_ *);
-/* color_org.c */
-void G__organize_colors(struct Colors *);
-/* color_rand.c */
-void G_make_random_colors(struct Colors *, CELL, CELL);
-/* color_range.c */
-void G_set_color_range(CELL, CELL, struct Colors *);
-void G_set_d_color_range(DCELL, DCELL, struct Colors *);
-void G_get_color_range(CELL *, CELL *, const struct Colors *);
-void G_get_d_color_range(DCELL *, DCELL *, const struct Colors *);
-/* color_read.c */
-int G_read_colors(const char *, const char *, struct Colors *);
-void G_mark_colors_as_fp(struct Colors *);
-/* color_remove.c */
-int G_remove_colors(const char *, const char *);
-/* color_rule.c */
-void G_add_d_raster_color_rule(const DCELL *, int, int, int,
-			       const DCELL *, int, int, int,
-			       struct Colors *);
-void G_add_f_raster_color_rule(const FCELL *, int, int, int,
-			       const FCELL *, int, int, int,
-			       struct Colors *);
-void G_add_c_raster_color_rule(const CELL *, int, int, int,
-			       const CELL *, int, int, int,
-			       struct Colors *);
-void G_add_raster_color_rule(const void *, int, int, int,
-			     const void *, int, int, int,
-void G_add_color_rule(const CELL, int, int, int,
-		      const CELL, int, int, int,
-		      struct Colors *);
-int G_add_modular_d_raster_color_rule(const DCELL *, int, int, int,
-				      struct Colors *);
-int G_add_modular_f_raster_color_rule(const FCELL *, int, int, int,
-				      struct Colors *);
-int G_add_modular_c_raster_color_rule(const CELL *, int, int, int,
-				      struct Colors *);
-int G_add_modular_raster_color_rule(const void *, int, int, int,
-int G_add_modular_color_rule(CELL, int, int, int,
-			     CELL, int, int, int,
-			     struct Colors *);
-/* color_rule_get.c */
-int G_colors_count(const struct Colors *);
-int G_get_f_color_rule(DCELL *, unsigned char *, unsigned char *,
-		       unsigned char *, DCELL *, unsigned char *,
-		       const struct Colors *, int);
-/* color_rules.c */
-typedef int read_rule_fn(void *, DCELL, DCELL,
-			 DCELL *, int *, int *, int *, int *, int *, int *);
-int G_parse_color_rule(DCELL, DCELL, const char *, DCELL *, int *, int *,
-		       int *, int *, int *, int *);
-const char *G_parse_color_rule_error(int);
-int G_read_color_rule(void *, DCELL, DCELL, DCELL *, int *, int *, int *,
-		      int *, int *, int *);
-int G_read_color_rules(struct Colors *, DCELL, DCELL, read_rule_fn *, void *);
-int G_load_colors(struct Colors *, const char *, CELL, CELL);
-int G_load_fp_colors(struct Colors *, const char *, DCELL, DCELL);
-void G_make_colors(struct Colors *, const char *, CELL, CELL);
-void G_make_fp_colors(struct Colors *, const char *, DCELL, DCELL);
-/* color_set.c */
-void G_set_color(CELL, int, int, int, struct Colors *);
-void G_set_d_color(DCELL, int, int, int, struct Colors *);
-void G_set_null_value_color(int, int, int, struct Colors *);
-void G_set_default_color(int, int, int, struct Colors *);
-/* color_shift.c */
-void G_shift_colors(int, struct Colors *);
-void G_shift_d_colors(DCELL, struct Colors *);
-/* color_str.c */
-int G_str_to_color(const char *, int *, int *, int *);
-/* color_write.c */
-int G_write_colors(const char *, const char *, struct Colors *);
-void G__write_colors(FILE *, struct Colors *);
-/* color_xform.c */
-void G_histogram_eq_colors(struct Colors *, struct Colors *,
-			   struct Cell_stats *);
-void G_histogram_eq_colors_fp(struct Colors *,
-			      struct Colors *, struct FP_stats *);
-void G_log_colors(struct Colors *, struct Colors *, int);
-void G_abs_log_colors(struct Colors *, struct Colors *, int);
 /* commas.c */
 int G_insert_commas(char *);
 void G_remove_commas(char *);
@@ -493,56 +228,6 @@
 int G_zlib_read(int, int, unsigned char *, int);
 int G_zlib_write_noCompress(int, const unsigned char *, int);
-/* format.c */
-int G__check_format(int);
-int G__read_row_ptrs(int);
-int G__write_row_ptrs(int);
-/* fpreclass.c */
-void G_fpreclass_clear(struct FPReclass *);
-void G_fpreclass_reset(struct FPReclass *);
-void G_fpreclass_init(struct FPReclass *);
-void G_fpreclass_set_domain(struct FPReclass *, DCELL, DCELL);
-void G_fpreclass_set_range(struct FPReclass *, DCELL, DCELL);
-int G_fpreclass_get_limits(const struct FPReclass *, DCELL *, DCELL *,
-			   DCELL *, DCELL *);
-int G_fpreclass_nof_rules(const struct FPReclass *);
-void G_fpreclass_get_ith_rule(const struct FPReclass *, int, DCELL *, DCELL *,
-void G_fpreclass_set_neg_infinite_rule(struct FPReclass *, DCELL, DCELL);
-int G_fpreclass_get_neg_infinite_rule(const struct FPReclass *, DCELL *,
-				      DCELL *);
-void G_fpreclass_set_pos_infinite_rule(struct FPReclass *, DCELL, DCELL);
-int G_fpreclass_get_pos_infinite_rule(const struct FPReclass *, DCELL *,
-				      DCELL *);
-void G_fpreclass_add_rule(struct FPReclass *, DCELL, DCELL, DCELL, DCELL);
-void G_fpreclass_reverse_rule_order(struct FPReclass *);
-DCELL G_fpreclass_get_cell_value(const struct FPReclass *, DCELL);
-void G_fpreclass_perform_di(const struct FPReclass *, const DCELL *, CELL *,
-			    int);
-void G_fpreclass_perform_df(const struct FPReclass *, const DCELL *, FCELL *,
-			    int);
-void G_fpreclass_perform_dd(const struct FPReclass *, const DCELL *, DCELL *,
-			    int);
-void G_fpreclass_perform_fi(const struct FPReclass *, const FCELL *, CELL *,
-			    int);
-void G_fpreclass_perform_ff(const struct FPReclass *, const FCELL *, FCELL *,
-			    int);
-void G_fpreclass_perform_fd(const struct FPReclass *, const FCELL *, DCELL *,
-			    int);
-void G_fpreclass_perform_ii(const struct FPReclass *, const CELL *, CELL *,
-			    int);
-void G_fpreclass_perform_if(const struct FPReclass *, const CELL *, FCELL *,
-			    int);
-void G_fpreclass_perform_id(const struct FPReclass *, const CELL *, DCELL *,
-			    int);
-/* gdal.c */
-void G_init_gdal(void);
-struct GDAL_link *G_get_gdal_link(const char *, const char *);
-struct GDAL_link *G_create_gdal_link(const char *, RASTER_MAP_TYPE);
-void G_close_gdal_link(struct GDAL_link *);
-int G_close_gdal_write_link(struct GDAL_link *);
 /* geodesic.c */
 int G_begin_geodesic_equation(double, double, double, double);
 double G_geodesic_lat_from_lon(double);
@@ -554,9 +239,6 @@
 double G_geodesic_distance_lon_to_lon(double, double);
 double G_geodesic_distance(double, double, double, double);
-/* get_cellhd.c */
-int G_get_cellhd(const char *, const char *, struct Cell_head *);
 /* get_ellipse.c */
 int G_get_ellipsoid_parameters(double *, double *);
 int G_get_spheroid_by_name(const char *, double *, double *, double *);
@@ -569,24 +251,6 @@
 struct Key_Value *G_get_projunits(void);
 struct Key_Value *G_get_projinfo(void);
-/* get_row.c */
-int G_get_map_row_nomask(int, CELL *, int);
-int G_get_raster_row_nomask(int, void *, int, RASTER_MAP_TYPE);
-int G_get_c_raster_row_nomask(int, CELL *, int);
-int G_get_f_raster_row_nomask(int, FCELL *, int);
-int G_get_d_raster_row_nomask(int, DCELL *, int);
-int G_get_map_row(int, CELL *, int);
-int G_get_raster_row(int, void *, int, RASTER_MAP_TYPE);
-int G_get_c_raster_row(int, CELL *, int);
-int G_get_f_raster_row(int, FCELL *, int);
-int G_get_d_raster_row(int, DCELL *, int);
-int G_get_null_value_row(int, char *, int);
-/* get_row_colr.c */
-int G_get_raster_row_colors(int, int, struct Colors *,
-			    unsigned char *, unsigned char *, unsigned char *,
-			    unsigned char *);
 /* get_window.c */
 void G_get_window(struct Cell_head *);
 void G_get_default_window(struct Cell_head *);
@@ -609,34 +273,6 @@
 void G__check_gisinit(void);
 void G_init_all(void);
-/* histo_eq.c */
-void G_histogram_eq(const struct Histogram *, unsigned char **,
-		    CELL *, CELL *);
-/* histogram.c */
-void G_init_histogram(struct Histogram *);
-int G_read_histogram(const char *, const char *, struct Histogram *);
-int G_write_histogram(const char *, const struct Histogram *);
-int G_write_histogram_cs(const char *, struct Cell_stats *);
-void G_make_histogram_cs(struct Cell_stats *, struct Histogram *);
-int G_get_histogram_num(const struct Histogram *);
-CELL G_get_histogram_cat(int, const struct Histogram *);
-long G_get_histogram_count(int, const struct Histogram *);
-void G_free_histogram(struct Histogram *);
-int G_sort_histogram(struct Histogram *);
-int G_sort_histogram_by_count(struct Histogram *);
-void G_remove_histogram(const char *);
-int G_add_histogram(CELL, long, struct Histogram *);
-int G_set_histogram(CELL, long, struct Histogram *);
-void G_extend_histogram(CELL, long, struct Histogram *);
-void G_zero_histogram(struct Histogram *);
-/* history.c */
-int G_read_history(const char *, const char *, struct History *);
-int G_write_history(const char *, struct History *);
-void G_short_history(const char *, const char *, struct History *);
-int G_command_history(struct History *);
 /* home.c */
 const char *G_home(void);
 const char *G__home(void);
@@ -645,15 +281,6 @@
 char *G_index(const char *, int);
 char *G_rindex(const char *, int);
-/* interp.c */
-DCELL G_interp_linear(double, DCELL, DCELL);
-DCELL G_interp_bilinear(double, double, DCELL, DCELL, DCELL, DCELL);
-DCELL G_interp_cubic(double, DCELL, DCELL, DCELL, DCELL);
-DCELL G_interp_bicubic(double, double,
-		       DCELL, DCELL, DCELL, DCELL, DCELL, DCELL, DCELL, DCELL,
-		       DCELL);
 /* intersect.c */
 int G_intersect_line_segments(double, double, double, double, double, double,
 			      double, double, double *, double *, double *,
@@ -765,13 +392,6 @@
 void G_add_mapset_to_search_path(const char *);
 int G_is_mapset_in_search_path(const char *);
-/* mask_info.c */
-char *G_mask_info(void);
-int G__mask_info(char *, char *);
-/* maskfd.c */
-int G_maskfd(void);
 /* myname.c */
 char *G_myname(void);
@@ -787,25 +407,6 @@
 char *G_fully_qualified_name(const char *, const char *);
 int G__unqualified_name(const char *, const char *, char *, char *);
-/* null_val.c */
-void G__set_null_value(void *, int, int, RASTER_MAP_TYPE);
-void G_set_null_value(void *, int, RASTER_MAP_TYPE);
-void G_set_c_null_value(CELL *, int);
-void G_set_f_null_value(FCELL *, int);
-void G_set_d_null_value(DCELL *, int);
-int G_is_null_value(const void *, RASTER_MAP_TYPE);
-int G_is_c_null_value(const CELL *);
-int G_is_f_null_value(const FCELL *);
-int G_is_d_null_value(const DCELL *);
-void G_insert_null_values(void *, char *, int, RASTER_MAP_TYPE);
-void G_insert_c_null_values(CELL *, char *, int);
-void G_insert_f_null_values(FCELL *, char *, int);
-void G_insert_d_null_values(DCELL *, char *, int);
-int G__check_null_bit(const unsigned char *, int, int);
-void G__convert_01_flags(const char *, unsigned char *, int);
-void G__convert_flags_01(char *, const unsigned char *, int);
-void G__init_null_bits(unsigned char *, int);
 /* open.c */
 int G_open_new(const char *, const char *);
 int G_open_old(const char *, const char *, const char *);
@@ -825,25 +426,6 @@
 FILE *G_fopen_append_misc(const char *, const char *, const char *);
 FILE *G_fopen_modify_misc(const char *, const char *, const char *);
-/* opencell.c */
-int G_open_cell_old(const char *, const char *);
-int G__open_cell_old(const char *, const char *);
-int G_open_cell_new(const char *);
-int G_open_cell_new_uncompressed(const char *);
-void G_want_histogram(int);
-void G_set_cell_format(int);
-int G_cellvalue_format(CELL);
-int G_open_fp_cell_new(const char *);
-int G_open_fp_cell_new_uncompressed(const char *);
-int G_set_fp_type(RASTER_MAP_TYPE);
-int G_raster_map_is_fp(const char *, const char *);
-RASTER_MAP_TYPE G_raster_map_type(const char *, const char *);
-RASTER_MAP_TYPE G__check_fp_type(const char *, const char *);
-RASTER_MAP_TYPE G_get_raster_map_type(int);
-int G_open_raster_new(const char *, RASTER_MAP_TYPE);
-int G_open_raster_new_uncompressed(const char *, RASTER_MAP_TYPE);
-int G_set_quant_rules(int, struct Quant *);
 /* overwrite.c */
 int G_check_overwrite(int argc, char **argv);
@@ -912,21 +494,6 @@
 const char *G_database_ellipse_name(void);
 double G_database_units_to_meters_factor(void);
-/* put_cellhd.c */
-int G_put_cellhd(const char *, struct Cell_head *);
-/* put_row.c */
-int G_put_map_row(int, const CELL *);
-int G_put_raster_row(int, const void *, RASTER_MAP_TYPE);
-int G_put_c_raster_row(int, const CELL *);
-int G_put_f_raster_row(int, const FCELL *);
-int G_put_d_raster_row(int, const DCELL *);
-int G__open_null_write(int);
-int G__write_null_bits(int, const unsigned char *, int, int, int);
-/* put_title.c */
-int G_put_cell_title(const char *, const char *);
 /* put_window.c */
 int G_put_window(const struct Cell_head *);
 int G__put_window(const struct Cell_head *, const char *, const char *);
@@ -934,99 +501,11 @@
 /* putenv.c */
 void G_putenv(const char *, const char *);
-/* quant.c */
-void G_quant_clear(struct Quant *);
-void G_quant_free(struct Quant *);
-int G__quant_organize_fp_lookup(struct Quant *);
-void G_quant_init(struct Quant *);
-int G_quant_is_truncate(const struct Quant *);
-int G_quant_is_round(const struct Quant *);
-void G_quant_truncate(struct Quant *);
-void G_quant_round(struct Quant *);
-int G_quant_get_limits(const struct Quant *, DCELL *, DCELL *, CELL *,
-		       CELL *);
-int G_quant_nof_rules(const struct Quant *);
-void G_quant_get_ith_rule(const struct Quant *, int, DCELL *, DCELL *, CELL *,
-			  CELL *);
-void G_quant_set_neg_infinite_rule(struct Quant *, DCELL, CELL);
-int G_quant_get_neg_infinite_rule(const struct Quant *, DCELL *, CELL *);
-void G_quant_set_pos_infinite_rule(struct Quant *, DCELL, CELL);
-int G_quant_get_pos_infinite_rule(const struct Quant *, DCELL *, CELL *);
-void G_quant_add_rule(struct Quant *, DCELL, DCELL, CELL, CELL);
-void G_quant_reverse_rule_order(struct Quant *);
-CELL G_quant_get_cell_value(struct Quant *, DCELL);
-void G_quant_perform_d(struct Quant *, const DCELL *, CELL *, int);
-void G_quant_perform_f(struct Quant *, const FCELL *, CELL *, int);
-struct Quant_table *G__quant_get_rule_for_d_raster_val(const struct Quant *,
-						       DCELL);
-/* quant_io.c */
-int G__quant_import(const char *, const char *, struct Quant *);
-int G__quant_export(const char *, const char *, const struct Quant *);
-/* quant_rw.c */
-int G_truncate_fp_map(const char *, const char *);
-int G_round_fp_map(const char *, const char *);
-int G_quantize_fp_map(const char *, const char *, CELL, CELL);
-int G_quantize_fp_map_range(const char *, const char *, DCELL, DCELL, CELL,
-			    CELL);
-int G_write_quant(const char *, const char *, const struct Quant *);
-int G_read_quant(const char *, const char *, struct Quant *);
 /* radii.c */
 double G_meridional_radius_of_curvature(double, double, double);
 double G_transverse_radius_of_curvature(double, double, double);
 double G_radius_of_conformal_tangent_sphere(double, double, double);
-/* range.c */
-void G__remove_fp_range(const char *);
-void G_construct_default_range(struct Range *);
-int G_read_fp_range(const char *, const char *, struct FPRange *);
-int G_read_range(const char *, const char *, struct Range *);
-int G_write_range(const char *, const struct Range *);
-int G_write_fp_range(const char *, const struct FPRange *);
-void G_update_range(CELL, struct Range *);
-void G_update_fp_range(DCELL, struct FPRange *);
-void G_row_update_range(const CELL *, int, struct Range *);
-void G__row_update_range(const CELL *, int, struct Range *, int);
-void G_row_update_fp_range(const void *, int, struct FPRange *,
-			  RASTER_MAP_TYPE);
-void G_init_range(struct Range *);
-void G_get_range_min_max(const struct Range *, CELL *, CELL *);
-void G_init_fp_range(struct FPRange *);
-void G_get_fp_range_min_max(const struct FPRange *, DCELL *, DCELL *);
-/* raster.c */
-void *G_incr_void_ptr(const void *, const size_t);
-int G_raster_cmp(const void *, const void *, RASTER_MAP_TYPE);
-void G_raster_cpy(void *, const void *, int, RASTER_MAP_TYPE);
-void G_set_raster_value_c(void *, CELL, RASTER_MAP_TYPE);
-void G_set_raster_value_f(void *, FCELL, RASTER_MAP_TYPE);
-void G_set_raster_value_d(void *, DCELL, RASTER_MAP_TYPE);
-CELL G_get_raster_value_c(const void *, RASTER_MAP_TYPE);
-FCELL G_get_raster_value_f(const void *, RASTER_MAP_TYPE);
-DCELL G_get_raster_value_d(const void *, RASTER_MAP_TYPE);
-/* raster_metadata.c */
-int G_read_raster_units(const char *, const char *, char *);
-int G_read_raster_vdatum(const char *, const char *, char *);
-int G_write_raster_units(const char *, const char *);
-int G_write_raster_vdatum(const char *, const char *);
-int G__raster_misc_read_line(const char *, const char *, const char *,
-			     char *);
-int G__raster_misc_write_line(const char *, const char *, const char *);
-/* rd_cellhd.c */
-char *G__read_Cell_head(FILE *, struct Cell_head *, int);
-char *G__read_Cell_head_array(char **, struct Cell_head *, int);
-/* reclass.c */
-int G_is_reclass(const char *, const char *, char *, char *);
-int G_is_reclassed_to(const char *, const char *, int *, char ***);
-int G_get_reclass(const char *, const char *, struct Reclass *);
-void G_free_reclass(struct Reclass *);
-int G_put_reclass(const char *, const struct Reclass *);
 /* remove.c */
 int G_remove(const char *, const char *);
 int G_remove_misc(const char *, const char *, const char *);
@@ -1043,12 +522,6 @@
 void G_rotate_around_point(double, double, double *, double *, double);
 void G_rotate_around_point_int(int, int, int *, int *, double);
-/* sample.c */
-DCELL G_get_raster_sample_nearest(int, const struct Cell_head *, struct Categories *, double, double, int);
-DCELL G_get_raster_sample_bilinear(int, const struct Cell_head *, struct Categories *, double, double, int);
-DCELL G_get_raster_sample_cubic(int, const struct Cell_head *, struct Categories *, double, double, int);
-DCELL G_get_raster_sample(int, const struct Cell_head *, struct Categories *, double, double, int, INTERP_TYPE);
 /* seek.c */
 off_t G_ftell(FILE *);
 void G_fseek(FILE *, off_t, int);
@@ -1195,10 +668,6 @@
 /* zero.c */
 void G_zero(void *, int);
-/* zero_cell.c */
-void G_zero_cell_buf(CELL *);
-void G_zero_raster_buf(void *, RASTER_MAP_TYPE);
 /* zone.c */
 int G_zone(void);
Property changes on: grass/trunk/include/nviz.h
   - text/x-chrc
   + text/x-chdr
Property changes on: grass/trunk/include/vedit.h
   + text/x-chdr
   + Author Date Id
Modified: grass/trunk/lib/Makefile
--- grass/trunk/lib/Makefile	2009-06-20 21:39:23 UTC (rev 38002)
+++ grass/trunk/lib/Makefile	2009-06-20 22:03:23 UTC (rev 38003)
@@ -6,6 +6,7 @@
 SUBDIRS = \
 	datetime \
 	gis \
+	raster \
 	gmath \
 	linkm \
 	driver \
Modified: grass/trunk/lib/cluster/c_point.c
--- grass/trunk/lib/cluster/c_point.c	2009-06-20 21:39:23 UTC (rev 38002)
+++ grass/trunk/lib/cluster/c_point.c	2009-06-20 22:03:23 UTC (rev 38003)
@@ -17,7 +17,9 @@
  * note: if all values in x are zero, the point is rejected
+#include <grass/Rast.h>
 #include <grass/cluster.h>
 static int extend(struct Cluster *, int);
 static int all_zero(struct Cluster *, int);
@@ -27,7 +29,7 @@
     /* reject points which contain nulls in one of the bands */
     for (band = 0; band < C->nbands; band++)
-	if (G_is_d_null_value(&x[band]))
+	if (Rast_is_d_null_value(&x[band]))
 	    return 1;		/* fixed 11/99 Agus Carr */
        if (band >= C->nbands)
@@ -42,7 +44,7 @@
     for (band = 0; band < C->nbands; band++) {
 	register double z;
-	/*       if(G_is_d_null_value(&x[band])) continue; */
+	/*       if(Rast_is_d_null_value(&x[band])) continue; */
 	z = C->points[band][C->npoints] = x[band];
 	C->band_sum[band] += z;
 	C->band_sum2[band] += z * z;
@@ -60,7 +62,7 @@
     DCELL tmp = x;
-    if (G_is_d_null_value(&tmp))
+    if (Rast_is_d_null_value(&tmp))
 	return 1;
     C->points[band][C->npoints + n] = x;
     C->band_sum[band] += x;
Modified: grass/trunk/lib/display/raster.c
--- grass/trunk/lib/display/raster.c	2009-06-20 21:39:23 UTC (rev 38002)
+++ grass/trunk/lib/display/raster.c	2009-06-20 22:03:23 UTC (rev 38003)
@@ -25,7 +25,9 @@
 #include <stdio.h>
 #include <stdlib.h>
 #include <grass/display_raster.h>
 #include <grass/display.h>
@@ -98,13 +100,13 @@
 	set = G_realloc(set, nalloc);
-    G_lookup_raster_colors(array, red, grn, blu, set, ncols, colors,
+    Rast_lookup_raster_colors(array, red, grn, blu, set, ncols, colors,
 			   data_type);
     if (D__overlay_mode)
 	for (i = 0; i < ncols; i++) {
-	    set[i] = G_is_null_value(array, data_type);
-	    array = G_incr_void_ptr(array, G_raster_size(data_type));
+	    set[i] = Rast_is_null_value(array, data_type);
+	    array = Rast_incr_void_ptr(array, Rast_raster_size(data_type));
     A_row =
@@ -148,9 +150,9 @@
     static unsigned char *r_buf, *g_buf, *b_buf, *n_buf;
     static int nalloc;
-    int r_size = G_raster_size(r_type);
-    int g_size = G_raster_size(g_type);
-    int b_size = G_raster_size(b_type);
+    int r_size = Rast_raster_size(r_type);
+    int g_size = Rast_raster_size(g_type);
+    int b_size = Rast_raster_size(b_type);
     int ncols = src[0][1] - src[0][0];
     int i;
@@ -164,22 +166,22 @@
     /* convert cell values to bytes */
-    G_lookup_raster_colors(r_raster, r_buf, n_buf, n_buf, n_buf, ncols,
+    Rast_lookup_raster_colors(r_raster, r_buf, n_buf, n_buf, n_buf, ncols,
 			   r_colors, r_type);
-    G_lookup_raster_colors(g_raster, n_buf, g_buf, n_buf, n_buf, ncols,
+    Rast_lookup_raster_colors(g_raster, n_buf, g_buf, n_buf, n_buf, ncols,
 			   g_colors, g_type);
-    G_lookup_raster_colors(b_raster, n_buf, n_buf, b_buf, n_buf, ncols,
+    Rast_lookup_raster_colors(b_raster, n_buf, n_buf, b_buf, n_buf, ncols,
 			   b_colors, b_type);
-	    n_buf[i] = (G_is_null_value(r_raster, r_type) ||
-			G_is_null_value(g_raster, g_type) ||
-			G_is_null_value(b_raster, b_type));
+	    n_buf[i] = (Rast_is_null_value(r_raster, r_type) ||
+			Rast_is_null_value(g_raster, g_type) ||
+			Rast_is_null_value(b_raster, b_type));
-	    r_raster = G_incr_void_ptr(r_raster, r_size);
-	    g_raster = G_incr_void_ptr(g_raster, g_size);
-	    b_raster = G_incr_void_ptr(b_raster, b_size);
+	    r_raster = Rast_incr_void_ptr(r_raster, r_size);
+	    g_raster = Rast_incr_void_ptr(g_raster, g_size);
+	    b_raster = Rast_incr_void_ptr(b_raster, b_size);
     A_row =
Modified: grass/trunk/lib/display/raster2.c
--- grass/trunk/lib/display/raster2.c	2009-06-20 21:39:23 UTC (rev 38002)
+++ grass/trunk/lib/display/raster2.c	2009-06-20 22:03:23 UTC (rev 38003)
@@ -28,7 +28,9 @@
 #include <stdlib.h>
@@ -136,7 +138,7 @@
     int r, g, b;
-    G_get_raster_color(raster, &r, &g, &b, colors, data_type);
+    Rast_get_raster_color(raster, &r, &g, &b, colors, data_type);
     R__RGB_color((unsigned char)r, (unsigned char)g, (unsigned char)b);
     return 0;
Modified: grass/trunk/lib/display/tran_colr.c
--- grass/trunk/lib/display/tran_colr.c	2009-06-20 21:39:23 UTC (rev 38002)
+++ grass/trunk/lib/display/tran_colr.c	2009-06-20 22:03:23 UTC (rev 38003)
@@ -3,8 +3,10 @@
 #include <string.h>
 #include <grass/colors.h>
 #include <grass/glocale.h>
@@ -55,7 +57,7 @@
 	    colors[i] = G_standard_color_rgb(i);
-    ret = G_str_to_color(str, &red, &grn, &blu);
+    ret = Rast_str_to_color(str, &red, &grn, &blu);
     /* None color */
     if (ret == 2)
Modified: grass/trunk/lib/g3d/g3dcats.c
--- grass/trunk/lib/g3d/g3dcats.c	2009-06-20 21:39:23 UTC (rev 38002)
+++ grass/trunk/lib/g3d/g3dcats.c	2009-06-20 22:03:23 UTC (rev 38003)
@@ -4,7 +4,10 @@
 #include <unistd.h>
 #include <rpc/types.h>
 #include <rpc/xdr.h>
 #include "G3d_intern.h"
@@ -15,7 +18,7 @@
  *  Writes the
  * categories stored in the <em>cats</em> structure into the categories file for
- * map <em>name</em> in the current mapset.  See <em>G_write_cats</em>
+ * map <em>name</em> in the current mapset.  See <em>Rast_write_cats</em>
  * (Raster_Category_File) for details and return values.
  *  \param name
@@ -24,7 +27,7 @@
 int G3d_writeCats(const char *name, struct Categories *cats)
- /* adapted from G_write_cats */
+ /* adapted from Rast_write_cats */
     FILE *fd;
     int i;
@@ -48,8 +51,8 @@
 	    cats->m1, cats->a1, cats->m2, cats->a2);
     /* write the cat numbers:label */
-    for (i = 0; i < G_quant_nof_rules(&cats->q); i++) {
-	descr = G_get_ith_d_raster_cat(cats, i, &val1, &val2);
+    for (i = 0; i < Rast_quant_nof_rules(&cats->q); i++) {
+	descr = Rast_get_ith_d_raster_cat(cats, i, &val1, &val2);
 	if ((cats->fmt && cats->fmt[0]) || (descr && descr[0])) {
 	    if (val1 == val2) {
 		sprintf(str1, "%.10f", val1);
@@ -101,7 +104,7 @@
 	goto error;
     G_strip(buff);
-    G_init_raster_cats(buff, pcats);
+    Rast_init_raster_cats(buff, pcats);
     if (num >= 0)
 	pcats->num = num;
@@ -116,7 +119,7 @@
 	    goto error;
 	if (sscanf(buff, "%f %f %f %f", &m1, &a1, &m2, &a2) != 4)
 	    goto error;
-	G_set_raster_cats_fmt(fmt, m1, a1, m2, a2, pcats);
+	Rast_set_raster_cats_fmt(fmt, m1, a1, m2, a2, pcats);
     /* Read all category names */
@@ -127,7 +130,7 @@
 	    break;
 	if (old)
-	    G_set_cat(cat, buff, pcats);
+	    Rast_set_cat(cat, buff, pcats);
 	else {
 	    *label = 0;
 	    if (sscanf(buff, "%1s", label) != 1)
@@ -138,11 +141,11 @@
 	    /* try to read a range of data */
 	    if (sscanf(buff, "%lf:%lf:%[^\n]", &val1, &val2, label) == 3)
-		G_set_raster_cat(&val1, &val2, label, pcats, DCELL_TYPE);
+		Rast_set_raster_cat(&val1, &val2, label, pcats, DCELL_TYPE);
 	    else if (sscanf(buff, "%d:%[^\n]", &cat, label) >= 1)
-		G_set_raster_cat(&cat, &cat, label, pcats, CELL_TYPE);
+		Rast_set_raster_cat(&cat, &cat, label, pcats, CELL_TYPE);
 	    else if (sscanf(buff, "%lf:%[^\n]", &val1, label) >= 1)
-		G_set_raster_cat(&val1, &val1, label, pcats, DCELL_TYPE);
+		Rast_set_raster_cat(&val1, &val1, label, pcats, DCELL_TYPE);
 	    else
 		goto error;
@@ -163,7 +166,7 @@
  * \brief
  * Reads the categories file for map <em>name</em> in <em>mapset</em> and
- * stores the categories in the <em>pcats</em> structure.  See <em>G_read_cats</em>
+ * stores the categories in the <em>pcats</em> structure.  See <em>Rast_read_cats</em>
  *  \param name
@@ -174,7 +177,7 @@
 int
 G3d_readCats(const char *name, const char *mapset, struct Categories *pcats)
- /* adapted from G_read_cats */
+ /* adapted from Rast_read_cats */
     const char *type;
Modified: grass/trunk/lib/g3d/g3dclose.c
--- grass/trunk/lib/g3d/g3dclose.c	2009-06-20 21:39:23 UTC (rev 38002)
+++ grass/trunk/lib/g3d/g3dclose.c	2009-06-20 22:03:23 UTC (rev 38003)
@@ -5,6 +5,9 @@
 #include <stdlib.h>
 #include <unistd.h>
@@ -18,13 +21,13 @@
     G3d_removeColor(map->fileName);
     /* create empty cats file */
-    G_init_raster_cats(NULL, &cats);
+    Rast_init_raster_cats(NULL, &cats);
     G3d_writeCats(map->fileName, &cats);
-    G_free_cats(&cats);
+    Rast_free_cats(&cats);
     /*genrate the history file, use the normal G_ functions */
-    G_short_history(map->fileName, "raster3d", &hist);
-    G_command_history(&hist);
+    Rast_short_history(map->fileName, "raster3d", &hist);
+    Rast_command_history(&hist);
     /*Use the G3d function to write the history file,
      * otherwise the path is wrong */
     if (!G3d_writeHistory(map->fileName, &hist)) {
Modified: grass/trunk/lib/g3d/g3dcolor.c
--- grass/trunk/lib/g3d/g3dcolor.c	2009-06-20 21:39:23 UTC (rev 38002)
+++ grass/trunk/lib/g3d/g3dcolor.c	2009-06-20 22:03:23 UTC (rev 38003)
@@ -1,5 +1,4 @@
 #include <stdio.h>
 #include <stdlib.h>
 #include <string.h>
@@ -7,8 +6,11 @@
 #include <unistd.h>
 static int read_colors(const char *, const char *, struct Colors *);
@@ -27,22 +29,22 @@
 int
 G3d_readColors(const char *name, const char *mapset, struct Colors *colors)
- /* adapted from G_read_colors */
+ /* adapted from Rast_read_colors */
     const char *err;
     struct FPRange drange;
     DCELL dmin, dmax;
-    G_init_colors(colors);
+    Rast_init_colors(colors);
-    G_mark_colors_as_fp(colors);
+    Rast_mark_colors_as_fp(colors);
     switch (read_colors(name, mapset, colors)) {
     case -2:
 	if (G3d_readRange(name, mapset, &drange) >= 0) {
-	    G_get_fp_range_min_max(&drange, &dmin, &dmax);
-	    if (!G_is_d_null_value(&dmin) && !G_is_d_null_value(&dmax))
-		G_make_rainbow_fp_colors(colors, dmin, dmax);
+	    Rast_get_fp_range_min_max(&drange, &dmin, &dmax);
+	    if (!Rast_is_d_null_value(&dmin) && !Rast_is_d_null_value(&dmax))
+		Rast_make_rainbow_fp_colors(colors, dmin, dmax);
 	    return 0;
 	err = "missing";
@@ -122,7 +124,7 @@
     G_strip(buf);
     if (sscanf(buf + 1, "%lf %lf", &val1, &val2) == 2)
-	G_set_d_color_range((DCELL) val1, (DCELL) val2, colors);
+	Rast_set_d_color_range((DCELL) val1, (DCELL) val2, colors);
     modular = 0;
     while (fgets(buf, sizeof buf, fd)) {
@@ -135,11 +137,11 @@
 	if (sscanf(word1, "shift:%lf", &shift) == 1
 	    || (strcmp(word1, "shift:") == 0 &&
 		sscanf(word2, "%lf", &shift) == 1)) {
-	    G_shift_d_colors(shift, colors);
+	    Rast_shift_d_colors(shift, colors);
 	    continue;
 	if (strcmp(word1, "invert") == 0) {
-	    G_invert_colors(colors);
+	    Rast_invert_colors(colors);
 	    continue;
 	if (strcmp(word1, "%%") == 0) {
@@ -220,26 +222,26 @@
 	    b2 = b1;
 	if (null)
-	    G_set_null_value_color(r1, g1, b1, colors);
+	    Rast_set_null_value_color(r1, g1, b1, colors);
 	else if (undef)
-	    G_set_default_color(r1, g1, b1, colors);
+	    Rast_set_default_color(r1, g1, b1, colors);
 	else if (modular) {
 	    if (fp_rule)
-		G_add_modular_d_raster_color_rule((DCELL *) & val1, r1, g1,
+		Rast_add_modular_d_raster_color_rule((DCELL *) & val1, r1, g1,
 						  b1, (DCELL *) & val2, r2,
 						  g2, b2, colors);
 	    else
-		G_add_modular_color_rule((CELL) cat1, r1, g1, b1,
+		Rast_add_modular_color_rule((CELL) cat1, r1, g1, b1,
 					 (CELL) cat2, r2, g2, b2, colors);
 	else {
 	    if (fp_rule)
-		G_add_d_raster_color_rule((DCELL *) & val1, r1, g1, b1,
+		Rast_add_d_raster_color_rule((DCELL *) & val1, r1, g1, b1,
 					  (DCELL *) & val2, r2, g2, b2,
 					  colors);
 	    else
-		G_add_color_rule((CELL) cat1, r1, g1, b1,
+		Rast_add_color_rule((CELL) cat1, r1, g1, b1,
@@ -259,7 +261,7 @@
     int old;
     int zero;
      * first line in pre 3.0 color files is number of colors - ignore
      * otherwise it is #min first color, and the next line is for color 0
@@ -306,12 +308,12 @@
 	if (zero) {
-	    G__insert_color_into_lookup((CELL) 0, red, grn, blu,
+	    Rast__insert_color_into_lookup((CELL) 0, red, grn, blu,
 					&colors->fixed);
 	    zero = 0;
 	else
-	    G__insert_color_into_lookup((CELL) n++, red, grn, blu,
+	    Rast__insert_color_into_lookup((CELL) n++, red, grn, blu,
 					&colors->fixed);
     colors->cmax = n - 1;
@@ -323,7 +325,7 @@
 int
 G3d_writeColors(const char *name, const char *mapset, struct Colors *colors)
- /* adapted from G_write_colors */
+ /* adapted from Rast_write_colors */
     FILE *fd;
@@ -336,7 +338,7 @@
     if (!fd)
 	return -1;
-    G__write_colors(fd, colors);
+    Rast__write_colors(fd, colors);
     fclose(fd);
     return 1;
Modified: grass/trunk/lib/g3d/g3dfpxdr.c
--- grass/trunk/lib/g3d/g3dfpxdr.c	2009-06-20 21:39:23 UTC (rev 38002)
+++ grass/trunk/lib/g3d/g3dfpxdr.c	2009-06-20 22:03:23 UTC (rev 38003)
@@ -5,6 +5,9 @@
 #include <unistd.h>
@@ -150,11 +153,11 @@
     if (useXdr == G3D_NO_XDR) {
 	G3d_copyValues(src, 0, srcType, xdrTmp, 0, type, nofNum);
-	xdrTmp = G_incr_void_ptr(xdrTmp, nofNum * G3d_externLength(type));
+	xdrTmp = Rast_incr_void_ptr(xdrTmp, nofNum * G3d_externLength(type));
 	return 1;
-    for (i = 0; i < nofNum; i++, src = G_incr_void_ptr(src, eltLength)) {
+    for (i = 0; i < nofNum; i++, src = Rast_incr_void_ptr(src, eltLength)) {
 	if (G3d_isNullValueNum(src, srcType)) {
 	    G3d_setXdrNullNum(xdrTmp, isFloat);
@@ -182,7 +185,7 @@
-	xdrTmp = G_incr_void_ptr(xdrTmp, externLength);
+	xdrTmp = Rast_incr_void_ptr(xdrTmp, externLength);
     return 1;
@@ -225,11 +228,11 @@
 	G3d_copyValues(xdrTmp, 0, type, dst, 0, dstType, nofNum);
 	return 1;
-    for (i = 0; i < nofNum; i++, dst = G_incr_void_ptr(dst, eltLength)) {
+    for (i = 0; i < nofNum; i++, dst = Rast_incr_void_ptr(dst, eltLength)) {
 	if (G3d_isXdrNullNum(xdrTmp, isFloat)) {
 	    G3d_setNullValue(dst, 1, dstType);
@@ -257,7 +260,7 @@
     return 1;
Modified: grass/trunk/lib/g3d/g3dhistory.c
--- grass/trunk/lib/g3d/g3dhistory.c	2009-06-20 21:39:23 UTC (rev 38002)
+++ grass/trunk/lib/g3d/g3dhistory.c	2009-06-20 22:03:23 UTC (rev 38003)
@@ -61,7 +61,7 @@
 int G3d_readHistory(const char *name, const char *mapset, struct History *hist)
-/* This function is adapted from G_read_history */
+/* This function is adapted from Rast_read_history */
     FILE *fd;
@@ -140,7 +140,7 @@
  * A diagnostic message is printed and -1 is returned if there is an error
  * writing the History file. Otherwise, 0 is returned.
  * <b>Note.</b> The <b>history</b> structure should first be initialized
- * using <i>G_short_history.</i>
+ * using <i>Rast_short_history.</i>
  *  \param name
  *  \param history
@@ -148,7 +148,7 @@
 int G3d_writeHistory(const char *name, struct History *hist)
-/* This function is adapted from G_write_history */
+/* This function is adapted from Rast_write_history */
     FILE *fd;
     int i;
Modified: grass/trunk/lib/g3d/g3dmisc.c
--- grass/trunk/lib/g3d/g3dmisc.c	2009-06-20 21:39:23 UTC (rev 38002)
+++ grass/trunk/lib/g3d/g3dmisc.c	2009-06-20 22:03:23 UTC (rev 38003)
@@ -5,6 +5,9 @@
 #include <unistd.h>
@@ -66,8 +69,8 @@
     eltLength = G3d_length(typeSrc);
-    src = G_incr_void_ptr(src, eltLength * offsSrc);
-    dst = G_incr_void_ptr(dst, eltLength * offsDst);
+    src = Rast_incr_void_ptr(src, eltLength * offsSrc);
+    dst = Rast_incr_void_ptr(dst, eltLength * offsDst);
     memcpy(dst, src, nElts * eltLength);
Modified: grass/trunk/lib/g3d/g3dnull.c
--- grass/trunk/lib/g3d/g3dnull.c	2009-06-20 21:39:23 UTC (rev 38002)
+++ grass/trunk/lib/g3d/g3dnull.c	2009-06-20 22:03:23 UTC (rev 38003)
@@ -2,6 +2,9 @@
 #include <stdlib.h>
 #include <unistd.h>
@@ -9,9 +12,9 @@
 int G3d_isNullValueNum(const void *n, int type)
     if (type == FCELL_TYPE)
-	return G_is_f_null_value(n);
+	return Rast_is_f_null_value(n);
     else
-	return G_is_d_null_value(n);
+	return Rast_is_d_null_value(n);
@@ -32,9 +35,9 @@
 void G3d_setNullValue(void *c, int nofElts, int type)
     if (type == FCELL_TYPE) {
-	G_set_f_null_value((float *)c, nofElts);
+	Rast_set_f_null_value((float *)c, nofElts);
 	return;
-    G_set_d_null_value((double *)c, nofElts);
+    Rast_set_d_null_value((double *)c, nofElts);
Modified: grass/trunk/lib/g3d/g3drange.c
--- grass/trunk/lib/g3d/g3drange.c	2009-06-20 21:39:23 UTC (rev 38002)
+++ grass/trunk/lib/g3d/g3drange.c	2009-06-20 22:03:23 UTC (rev 38003)
@@ -4,8 +4,11 @@
 #include <unistd.h>
 #include <grass/gis.h>
@@ -22,19 +25,19 @@
     cellType = G3d_g3dType2cellType(type);
     if (nofNum == map->tileSize) {
-	G_row_update_fp_range(tile, map->tileSize, range, cellType);
+	Rast_row_update_fp_range(tile, map->tileSize, range, cellType);
 	return;
     if (xRedundant) {
 	for (z = 0; z < depths; z++) {
 	    for (y = 0; y < rows; y++) {
-		G_row_update_fp_range(tile, cols, range, cellType);
-		tile = G_incr_void_ptr(tile, map->tileX * G3d_length(type));
+		Rast_row_update_fp_range(tile, cols, range, cellType);
+		tile = Rast_incr_void_ptr(tile, map->tileX * G3d_length(type));
 	    if (yRedundant)
 		tile =
-		    G_incr_void_ptr(tile,
+		    Rast_incr_void_ptr(tile,
 				    map->tileX * yRedundant *
 				    G3d_length(type));
@@ -43,27 +46,27 @@
     if (yRedundant) {
-	    G_row_update_fp_range(tile, map->tileX * rows, range, cellType);
-	    tile = G_incr_void_ptr(tile, map->tileXY * G3d_length(type));
+	    Rast_row_update_fp_range(tile, map->tileX * rows, range, cellType);
+	    tile = Rast_incr_void_ptr(tile, map->tileXY * G3d_length(type));
 	return;
-    G_row_update_fp_range(tile, map->tileXY * depths, range, cellType);
+    Rast_row_update_fp_range(tile, map->tileXY * depths, range, cellType);
 int
 G3d_readRange(const char *name, const char *mapset, struct FPRange *drange)
- /* adapted from G_read_fp_range */
+ /* adapted from Rast_read_fp_range */
     int fd;
     char xdr_buf[100];
     DCELL dcell1, dcell2;
     XDR xdr_str;
-    G_init_fp_range(drange);
+    Rast_init_fp_range(drange);
     fd = -1;
@@ -89,8 +92,8 @@
 	return -1;
-    G_update_fp_range(dcell1, drange);
-    G_update_fp_range(dcell2, drange);
+    Rast_update_fp_range(dcell1, drange);
+    Rast_update_fp_range(dcell2, drange);
     close(fd);
     return 1;
@@ -136,13 +139,13 @@
 void G3d_range_min_max(G3D_Map * map, double *min, double *max)
-    G_get_fp_range_min_max(&(map->range), min, max);
+    Rast_get_fp_range_min_max(&(map->range), min, max);
 static int writeRange(const char *name, struct FPRange *range)
- /* adapted from G_write_fp_range */
+ /* adapted from Rast_write_fp_range */
     char xdr_buf[100];
     int fd;
@@ -214,6 +217,6 @@
 int G3d_range_init(G3D_Map * map)
-    G_init_fp_range(&(map->range));
+    Rast_init_fp_range(&(map->range));
     return 0;
Modified: grass/trunk/lib/g3d/g3dregion.c
--- grass/trunk/lib/g3d/g3dregion.c	2009-06-20 21:39:23 UTC (rev 38002)
+++ grass/trunk/lib/g3d/g3dregion.c	2009-06-20 22:03:23 UTC (rev 38003)
@@ -1,6 +1,9 @@
 #include <stdio.h>
 #include <grass/G3d.h>
@@ -152,7 +155,7 @@
     const char *err;
     G3d_regionToCellHead(region, &region2d);
-    if ((err = G_adjust_Cell_head3(&region2d, 1, 1, 1)) != NULL) {
+    if ((err = Rast_adjust_Cell_head3(&region2d, 1, 1, 1)) != NULL) {
 	G_fatal_error("G3d_adjustRegion: %s", err);
     G3d_regionFromToCellHead(&region2d, region);
@@ -181,7 +184,7 @@
     const char *err;
 	G_fatal_error("G3d_adjustRegionRes: %s", err);
Modified: grass/trunk/lib/g3d/g3dvolume.c
--- grass/trunk/lib/g3d/g3dvolume.c	2009-06-20 21:39:23 UTC (rev 38002)
+++ grass/trunk/lib/g3d/g3dvolume.c	2009-06-20 22:03:23 UTC (rev 38003)
@@ -2,6 +2,8 @@
 #include <stdlib.h>
 #include <unistd.h>
@@ -248,7 +250,7 @@
 	    for (x = 0; x < nx; x++) {
 		/* G3d_putValueRegion? */
 		if (!G3d_putValue(mapVolume, x, y, z,
-				  G_incr_void_ptr(volumeBuf,
+				  Rast_incr_void_ptr(volumeBuf,
 						  (z * ny * nx + y * nx +
 						   x) * eltLength),
 				  G3d_fileTypeMap(mapVolume)))
Modified: grass/trunk/lib/g3d/getblock.c
--- grass/trunk/lib/g3d/getblock.c	2009-06-20 21:39:23 UTC (rev 38002)
+++ grass/trunk/lib/g3d/getblock.c	2009-06-20 22:03:23 UTC (rev 38003)
@@ -2,6 +2,8 @@
 #include <stdlib.h>
 #include <unistd.h>
@@ -120,15 +122,15 @@
 	for (y = y0; y < y1; y++) {
 	    for (x = x0; x < x1; x++) {
 		G3d_getValueRegion(map, x, y, z, block, type);
-		block = G_incr_void_ptr(block, length);
+		block = Rast_incr_void_ptr(block, length);
 	    nNull = x0 + nx - x;
 	    G3d_setNullValue(block, nNull, type);
-	    block = G_incr_void_ptr(block, length * nNull);
+	    block = Rast_incr_void_ptr(block, length * nNull);
 	nNull = (y0 + ny - y) * nx;
     nNull = (z0 + nz - z) * ny * nx;
Modified: grass/trunk/lib/g3d/tileread.c
--- grass/trunk/lib/g3d/tileread.c	2009-06-20 21:39:23 UTC (rev 38002)
+++ grass/trunk/lib/g3d/tileread.c	2009-06-20 22:03:23 UTC (rev 38003)
@@ -4,6 +4,8 @@
 #include <unistd.h>
 static int
@@ -37,13 +39,13 @@
 		    G3d_error("G3d_xdrTile2tile: error in G3d_copyFromXdr");
 		    return 0;
-		tile = G_incr_void_ptr(tile, cols * length);
+		tile = Rast_incr_void_ptr(tile, cols * length);
 		G3d_setNullValue(tile, xRedundant, type);
-		tile = G_incr_void_ptr(tile, xLength);
+		tile = Rast_incr_void_ptr(tile, xLength);
 	    if (yRedundant) {
 		G3d_setNullValue(tile, map->tileX * yRedundant, type);
-		tile = G_incr_void_ptr(tile, yLength);
+		tile = Rast_incr_void_ptr(tile, yLength);
 	if (!zRedundant)
@@ -59,9 +61,9 @@
 		return 0;
-	    tile = G_incr_void_ptr(tile, map->tileX * rows * length);
+	    tile = Rast_incr_void_ptr(tile, map->tileX * rows * length);
 	if (!zRedundant)
 	    return 1;
@@ -78,7 +80,7 @@
     if (!zRedundant)
 	return 1;
-    tile = G_incr_void_ptr(tile, map->tileXY * depths * length);
+    tile = Rast_incr_void_ptr(tile, map->tileXY * depths * length);
     G3d_setNullValue(tile, map->tileXY * zRedundant, type);
     return 1;
Modified: grass/trunk/lib/g3d/tilewrite.c
--- grass/trunk/lib/g3d/tilewrite.c	2009-06-20 21:39:23 UTC (rev 38002)
+++ grass/trunk/lib/g3d/tilewrite.c	2009-06-20 22:03:23 UTC (rev 38003)
@@ -4,6 +4,8 @@
 #include <unistd.h>
@@ -37,11 +39,11 @@
 		    G3d_error("G3d_tile2xdrTile: error in G3d_copyToXdr");
 		    return 0;
 	    if (yRedundant)
 		tile =
 				    G3d_length(type));
@@ -54,7 +56,7 @@
 		return 0;
 	return 1;
Deleted: grass/trunk/lib/gis/G.h
--- grass/trunk/lib/gis/G.h	2009-06-20 21:39:23 UTC (rev 38002)
+++ grass/trunk/lib/gis/G.h	2009-06-20 22:03:23 UTC (rev 38003)
@@ -1,94 +0,0 @@
-#include <grass/config.h>
-#include <grass/gis.h>
-#include <rpc/types.h>
-#include <rpc/xdr.h>
-#ifdef HAVE_GDAL
-#include <gdal.h>
-#endif
-#define XDR_FLOAT_NBYTES 4
-#define XDR_DOUBLE_NBYTES 8
-#define NULL_ROWS_INMEM 8
-/* if short is 16 bits, then
- *       short will allow 32767 cols
- *       unsigned short will allow 65536 cols
- * use int if you need more columns (but this will take more memory).
-typedef int COLUMN_MAPPING;
-struct GDAL_link
-    char *filename;
-    int band_num;
-    DCELL null_val;
-    int hflip;
-    int vflip;
-#ifdef HAVE_GDAL
-    GDALDatasetH data;
-    GDALRasterBandH band;
-    GDALDataType type;
-#endif
-#ifdef HAVE_GDAL
-extern CPLErr G_gdal_raster_IO(
-    GDALRasterBandH, GDALRWFlag,
-    int, int, int, int,
-    void *, int, int, GDALDataType,
-    int, int);
-#endif
-struct fileinfo			/* Information for opened cell files */
-    int open_mode;		/* see defines below            */
-    struct Cell_head cellhd;	/* Cell header                  */
-    struct Reclass reclass;	/* Table reclass                */
-    struct Cell_stats statf;	/* Cell stats                   */
-    struct Range range;		/* Range structure              */
-    struct FPRange fp_range;	/* float Range structure        */
-    int want_histogram;
-    int reclass_flag;		/* Automatic reclass flag       */
-    off_t *row_ptr;		/* File row addresses           */
-    COLUMN_MAPPING *col_map;	/* Data to window col mapping   */
-    double C1, C2;		/* Data to window row constants */
-    int cur_row;		/* Current data row in memory   */
-    int null_cur_row;		/* Current null row in memory   */
-    int cur_nbytes;		/* nbytes per cell for current row */
-    unsigned char *data;	/* Decompressed data buffer     */
-    int nbytes;			/* bytes per cell               */
-    RASTER_MAP_TYPE map_type;	/* type: int, float or double map */
-    char *temp_name;		/* Temporary name for NEW files */
-    char *null_temp_name;	/* Temporary name for NEW NULL files */
-    int null_file_exists;	/* for existing raster maps     */
-    char *name;			/* Name of open file            */
-    char *mapset;		/* Mapset of open file          */
-    int io_error;		/* io error warning given       */
-    XDR xdrstream;		/* xdr stream for reading fp    */
-    unsigned char *NULL_ROWS[NULL_ROWS_INMEM];
-    int min_null_row;		/* Minimum row null row number in memory */
-    struct Quant quant;
-    struct GDAL_link *gdal;
-struct G__			/*  Structure of library globals */
-    RASTER_MAP_TYPE fp_type;	/* type for writing floating maps */
-    struct Cell_head window;	/* Contains the current window          */
-    int window_set;		/* Flag: window set?                    */
-    int mask_fd;		/* File descriptor for automatic mask   */
-    int auto_mask;		/* Flag denoting automatic masking      */
-    int nbytes;
-    int compression_type;
-    int fileinfo_count;
-    struct fileinfo *fileinfo;
-extern struct G__ G__;		/* allocated in gisinit */
-#define OPEN_OLD              1
-#define OPEN_NEW_COMPRESSED   2
-#define OPEN_NEW_UNCOMPRESSED 3
Modified: grass/trunk/lib/gis/Makefile
--- grass/trunk/lib/gis/Makefile	2009-06-20 21:39:23 UTC (rev 38002)
+++ grass/trunk/lib/gis/Makefile	2009-06-20 22:03:23 UTC (rev 38003)
@@ -1,13 +1,13 @@
 MODULE_TOPDIR = ../..
-GDAL_LINK = $(USE_GDAL)
-GDAL_DYNAMIC = 1
 LIB_NAME = $(GIS_LIBNAME)
-EXTRA_LIBS = $(XDRLIB) $(SOCKLIB) $(DATETIMELIB) $(PTHREADLIBPATH) $(PTHREADLIB) $(INTLLIB) $(MATHLIB)
-DATASRC = ellipse.table datum.table datumtransform.table FIPS.code state27 state83 projections
+EXTRA_LIBS = $(XDRLIB) $(SOCKLIB) $(DATETIMELIB) $(PTHREADLIBPATH) $(PTHREADLIB) \
+	$(INTLLIB) $(MATHLIB) $(RASTRLIB)
 EXTRA_INC = $(ZLIBINCPATH) $(PTHREADINCPATH)
+DATASRC = ellipse.table datum.table datumtransform.table FIPS.code state27 state83 projections
 include $(MODULE_TOPDIR)/include/Make/Vars.make
 MOD_OBJS := $(filter-out fmode.o,$(AUTO_OBJS))
@@ -16,6 +16,7 @@
 include $(MODULE_TOPDIR)/include/Make/Doxygen.make
 DATAFILES := $(patsubst %,$(ETC)/%,$(DATASRC))
 COLORSRC := $(filter-out colors/CVS,$(wildcard colors/[abcdefghijklmnopqrstuvwxyz]*))
 COLORFILES := $(patsubst colors/%,$(ETC)/colors/%,$(COLORSRC))
@@ -24,23 +25,6 @@
 	EXTRA_CFLAGS = -D_FILE_OFFSET_BITS=64
 endif
-ifneq ($(GDAL_LINK),)
-EXTRA_CFLAGS += -DGDAL_LINK=1
-EXTRA_INC += $(PROJINC) $(GDALCFLAGS)
-ifneq ($(GDAL_DYNAMIC),)
-EXTRA_CFLAGS += -DGDAL_DYNAMIC=1
-ifneq ($(MINGW),)
-EXTRA_LIBS += -lkernel32
-else
-EXTRA_LIBS += $(DLLIB)
-endif
-else
-EXTRA_LIBS += $(GDALLIBS)
-endif
-endif
 default: lib $(FMODE_OBJ) $(DATAFILES) $(COLORFILES) $(ETC)/colors.desc $(ETC)/element_list
 ifdef MINGW
@@ -61,23 +45,16 @@
 $(ETC)/%: %
 	$(INSTALL_DATA) $< $@
-#doxygen:
-DOXNAME=gis
+DOXNAME=gislib
 $(OBJDIR)/area_ellipse.o: pi.h
 $(OBJDIR)/area_sphere.o: pi.h
-$(OBJDIR)/auto_mask.o: G.h
-$(OBJDIR)/closecell.o: G.h
-$(OBJDIR)/format.o: G.h
+$(OBJDIR)/debug.o: ../raster/G.h
 $(OBJDIR)/geodesic.o: pi.h
 $(OBJDIR)/geodist.o: pi.h
-$(OBJDIR)/get_row.o: G.h
-$(OBJDIR)/get_window.o: G.h
-$(OBJDIR)/gisinit.o: G.h
-$(OBJDIR)/maskfd.o: G.h
-$(OBJDIR)/opencell.o: G.h
-$(OBJDIR)/put_row.o: G.h
+$(OBJDIR)/get_window.o: ../raster/G.h
+$(OBJDIR)/gisinit.o: ../raster/G.h
 $(OBJDIR)/radii.o: pi.h
 $(OBJDIR)/rhumbline.o: pi.h
-$(OBJDIR)/set_window.o: G.h
-$(OBJDIR)/window_map.o: G.h
+$(OBJDIR)/set_window.o: ../raster/G.h
+$(OBJDIR)/window_map.o: ../raster/G.h
Deleted: grass/trunk/lib/gis/adj_cellhd.c
--- grass/trunk/lib/gis/adj_cellhd.c	2009-06-20 21:39:23 UTC (rev 38002)
+++ grass/trunk/lib/gis/adj_cellhd.c	2009-06-20 22:03:23 UTC (rev 38003)
@@ -1,356 +0,0 @@
- * \file gis/adj_cellhd.c
- * \brief GIS Library - CELL header adjustment.
- * (C) 2001-2009 by the GRASS Development Team
- * This program is free software under the GNU General Public License
- * (>=v2). Read the file COPYING that comes with GRASS for details.
- * \author Original author CERL
-#include <grass/glocale.h>
- * \brief Adjust cell header.
- * This function fills in missing parts of the input cell header (or
- * region). It also makes projection-specific adjustments. The
- * <i>cellhd</i> structure must have its <i>north, south, east,
- * west</i>, and <i>proj</i> fields set.
- * If <i>row_flag</i> is true, then the north-south resolution is
- * computed from the number of <i>rows</i> in the <i>cellhd</i>
- * structure. Otherwise the number of <i>rows</i> is computed from the
- * north-south resolution in the structure, similarly for
- * <i>col_flag</i> and the number of columns and the east-west
- * resolution.
- * <b>Note:</b> 3D values are not adjusted.
- * \param[in,out] cellhd pointer to Cell_head structure
- * \param row_flag compute n-s resolution
- * \param col_flag compute e-w resolution
- * \return NULL on success
- * \return localized text string on error
-const char *G_adjust_Cell_head(struct Cell_head *cellhd, int row_flag, int col_flag)
-    if (!row_flag) {
-	if (cellhd->ns_res <= 0)
-	    return (_("Illegal n-s resolution value"));
-    else {
-	if (cellhd->rows <= 0)
-	    return (_("Illegal row value"));
-    if (!col_flag) {
-	if (cellhd->ew_res <= 0)
-	    return (_("Illegal e-w resolution value"));
-    else {
-	if (cellhd->cols <= 0)
-	    return (_("Illegal col value"));
-    /* for lat/lon, check north,south. force east larger than west */
-    if (cellhd->proj == PROJECTION_LL) {
-	double epsilon_ns, epsilon_ew;
-	/* TODO: find good thresholds */
-	epsilon_ns = 1. / cellhd->rows * 0.001;
-	epsilon_ew = .000001;	/* epsilon_ew calculation doesn't work due to cellhd->cols update/global wraparound below */
-	G_debug(3, "G_adjust_Cell_head: epsilon_ns: %g, epsilon_ew: %g",
-		epsilon_ns, epsilon_ew);
-	/* TODO: once working, change below G_warning to G_debug */
-	/* fix rounding problems if input map slightly exceeds the world definition -180 90 180 -90 */
-	if (cellhd->north > 90.0) {
-	    if (((cellhd->north - 90.0) < epsilon_ns) &&
-		((cellhd->north - 90.0) > GRASS_EPSILON)) {
-		G_warning(_("Fixing subtle input data rounding error of north boundary (%g>%g)"),
-			  cellhd->north - 90.0, epsilon_ns);
-		cellhd->north = 90.0;
-	    else
-		return (_("Illegal latitude for North"));
-	if (cellhd->south < -90.0) {
-	    if (((cellhd->south + 90.0) < epsilon_ns) &&
-		((cellhd->south + 90.0) < GRASS_EPSILON)) {
-		G_warning(_("Fixing subtle input data rounding error of south boundary (%g>%g)"),
-			  cellhd->south + 90.0, epsilon_ns);
-		cellhd->south = -90.0;
-	    else
-		return (_("Illegal latitude for South"));
-#if 0
-	/* DISABLED: this breaks global wrap-around */
-	G_debug(3,
-		"G_adjust_Cell_head()  cellhd->west: %f, devi: %g, eps: %g",
-		cellhd->west, cellhd->west + 180.0, epsilon_ew);
-	if ((cellhd->west < -180.0) && ((cellhd->west + 180.0) < epsilon_ew)
-	    && ((cellhd->west + 180.0) < GRASS_EPSILON)) {
-	    G_warning(_("Fixing subtle input data rounding error of west boundary (%g>%g)"),
-		      cellhd->west + 180.0, epsilon_ew);
-	    cellhd->west = -180.0;
-	G_debug(3,
-		"G_adjust_Cell_head()  cellhd->east: %f, devi: %g, eps: %g",
-		cellhd->east, cellhd->east - 180.0, epsilon_ew);
-	if ((cellhd->east > 180.0) && ((cellhd->east - 180.0) > epsilon_ew)
-	    && ((cellhd->east - 180.0) > GRASS_EPSILON)) {
-	    G_warning(_("Fixing subtle input data rounding error of east boundary (%g>%g)"),
-		      cellhd->east - 180.0, epsilon_ew);
-	    cellhd->east = 180.0;
-#endif
-	while (cellhd->east <= cellhd->west)
-	    cellhd->east += 360.0;
-    /* check the edge values */
-    if (cellhd->north <= cellhd->south) {
-	    return (_("North must be north of South"));
-	else
-	    return (_("North must be larger than South"));
-    if (cellhd->east <= cellhd->west)
-	return (_("East must be larger than West"));
-    /* compute rows and columns, if not set */
-    if (!row_flag) {
-	cellhd->rows =
-	    (cellhd->north - cellhd->south +
-	     cellhd->ns_res / 2.0) / cellhd->ns_res;
-	if (cellhd->rows == 0)
-	    cellhd->rows = 1;
-    if (!col_flag) {
-	cellhd->cols =
-	    (cellhd->east - cellhd->west +
-	     cellhd->ew_res / 2.0) / cellhd->ew_res;
-	if (cellhd->cols == 0)
-	    cellhd->cols = 1;
-    if (cellhd->cols < 0 || cellhd->rows < 0) {
-	return (_("Invalid coordinates"));
-    /* (re)compute the resolutions */
-    cellhd->ns_res = (cellhd->north - cellhd->south) / cellhd->rows;
-    cellhd->ew_res = (cellhd->east - cellhd->west) / cellhd->cols;
-    return NULL;
- * \brief Adjust cell header for 3D values.
- * If <i>row_flag</i> is true, then the north-south resolution is computed
- * from the number of <i>rows</i> in the <i>cellhd</i> structure.
- * Otherwise the number of <i>rows</i> is computed from the north-south
- * resolution in the structure, similarly for <i>col_flag</i> and the
- * number of columns and the east-west resolution.
- * If <i>depth_flag</i> is true, top-bottom resolution is calculated
- * from depths.
- * If <i>depth_flag</i> are false, number of depths is calculated from
- * top-bottom resolution.
- * \param depth_flag compute t-b resolution
-const char *G_adjust_Cell_head3(struct Cell_head *cellhd, int row_flag,
-				int col_flag, int depth_flag)
-    if (!row_flag) {
-	if (cellhd->ns_res3 <= 0)
-	    return (_("Illegal n-s3 resolution value"));
-    else {
-	if (cellhd->rows3 <= 0)
-	    return (_("Illegal row3 value"));
-    if (!col_flag) {
-	if (cellhd->ew_res3 <= 0)
-	    return (_("Illegal e-w3 resolution value"));
-    else {
-	if (cellhd->cols3 <= 0)
-	    return (_("Illegal col3 value"));
-    if (!depth_flag) {
-	if (cellhd->tb_res <= 0)
-	    return (_("Illegal t-b3 resolution value"));
-    else {
-	if (cellhd->depths <= 0)
-	    return (_("Illegal depths value"));
-	    else
-	    else
-#if 0
-	G_debug(3,
-		"G_adjust_Cell_head3() cellhd->west: %f, devi: %g, eps: %g",
-	G_debug(3,
-		"G_adjust_Cell_head3() cellhd->east: %f, devi: %g, eps: %g",
-#endif
-	else
-    if (cellhd->top <= cellhd->bottom)
-	return (_("Top must be larger than Bottom"));
-    if (!row_flag) {
-	cellhd->rows =
-	    cellhd->rows = 1;
-	cellhd->rows3 =
-	     cellhd->ns_res3 / 2.0) / cellhd->ns_res3;
-	if (cellhd->rows3 == 0)
-	    cellhd->rows3 = 1;
-    if (!col_flag) {
-	cellhd->cols =
-	    cellhd->cols = 1;
-	cellhd->cols3 =
-	     cellhd->ew_res3 / 2.0) / cellhd->ew_res3;
-	if (cellhd->cols3 == 0)
-	    cellhd->cols3 = 1;
-	cellhd->depths =
-	    (cellhd->top - cellhd->bottom +
-	     cellhd->tb_res / 2.0) / cellhd->tb_res;
-	if (cellhd->depths == 0)
-	    cellhd->depths = 1;
-    if (cellhd->cols < 0 || cellhd->rows < 0 || cellhd->cols3 < 0 ||
-	cellhd->rows3 < 0 || cellhd->depths < 0) {
-    cellhd->ns_res3 = (cellhd->north - cellhd->south) / cellhd->rows3;
-    cellhd->ew_res3 = (cellhd->east - cellhd->west) / cellhd->cols3;
-    cellhd->tb_res = (cellhd->top - cellhd->bottom) / cellhd->depths;
-    return NULL;
Modified: grass/trunk/lib/gis/align_window.c
--- grass/trunk/lib/gis/align_window.c	2009-06-20 21:39:23 UTC (rev 38002)
+++ grass/trunk/lib/gis/align_window.c	2009-06-20 22:03:23 UTC (rev 38003)
@@ -14,6 +14,7 @@
 #include <stdio.h>
 #include <math.h>
  * \brief Align two regions.
@@ -70,5 +71,5 @@
 		window->east -= window->ew_res;
-    return G_adjust_Cell_head(window, 0, 0);
+    return Rast_adjust_Cell_head(window, 0, 0);
Deleted: grass/trunk/lib/gis/alloc_cell.c
--- grass/trunk/lib/gis/alloc_cell.c	2009-06-20 21:39:23 UTC (rev 38002)
+++ grass/trunk/lib/gis/alloc_cell.c	2009-06-20 22:03:23 UTC (rev 38003)
@@ -1,164 +0,0 @@
- * \file gis/alloc_cell.c
- * \brief GIS Library - Raster allocation routines.
-#include <math.h>
-/* convert type "RASTER_MAP_TYPE" into index */
-#define F2I(map_type) \
-	(map_type == CELL_TYPE ? 0 : (map_type == FCELL_TYPE ? 1 : 2))
-static const int type_size[3] = { sizeof(CELL), sizeof(FCELL), sizeof(DCELL) };
- * \brief Returns size of a raster CELL in bytes.
- *  - If <i>data_type</i> is CELL_TYPE, returns sizeof(CELL)
- *  - If <i>data_type</i> is FCELL_TYPE, returns sizeof(FCELL)
- *  - If <i>data_type</i> is DCELL_TYPE, returns sizeof(DCELL)
- * \param data_type raster type (CELL, FCELL, DCELL)
- * \return raster type size
-size_t G_raster_size(RASTER_MAP_TYPE data_type)
-    return (type_size[F2I(data_type)]);
- * \brief Allocate memory for a CELL type raster map.
- * This routine allocates a buffer of type CELL just large enough to
- * hold one row of raster data based on the number of columns in the
- * active region.
- \code
- CELL *cell;
- cell = G_allocate_cell_buf();
- \endcode
- * If larger buffers are required, the routine G_malloc() can be used.
- * The routine is generally used with each open cell file.
- * <b>Note:</b> G_allocate_raster_buf() or G_alloc_c_raster_buf() is
- * preferred over G_allocate_cell_buf().
- * Prints error message and calls exit() on error.
- * \return CELL * pointer to allocated buffer
-CELL *G_allocate_cell_buf(void)
-    return (CELL *) G_calloc(G_window_cols() + 1, sizeof(CELL));
- * \brief Allocate memory for a raster map of given type
- * Allocate an array of CELL, FCELL, or DCELL (depending on
- * <i>data_type</i>) based on the number of columns in the current
- * region.
- * \return pointer to allocated buffer
-void *G_allocate_raster_buf(RASTER_MAP_TYPE data_type)
-    return (void *)G_calloc(G_window_cols() + 1, G_raster_size(data_type));
- * \brief Allocates memory for a raster map of type CELL.
- * Allocate an array of CELL based on the number of columns in the
- * current region.
-CELL *G_allocate_c_raster_buf(void)
- * \brief Allocates memory for a raster map of type FCELL.
- * Allocate an array of FCELL based on the number of columns in the
- * current region.
-FCELL *G_allocate_f_raster_buf(void)
-    return (FCELL *) G_calloc(G_window_cols() + 1, sizeof(FCELL));
- * \brief Allocates memory for a raster map of type DCELL.
- * Allocate an array of DCELL based on the number of columns in the
- * current region.
-DCELL *G_allocate_d_raster_buf(void)
-    return (DCELL *) G_calloc(G_window_cols() + 1, sizeof(DCELL));
- * \brief Allocates memory for a null buffer.
- * Allocate an array of char based on the number of columns in the
- * current region.
-char *G_allocate_null_buf(void)
-    return (char *)G_calloc(G_window_cols() + 1, sizeof(char));
- * \brief Allocates memory for null bits.
- * Allocates an array of unsigned char based on <i>cols</i>.
- * \param cols number of columns in region
-unsigned char *G__allocate_null_bits(int cols)
-    return (unsigned char *)G_calloc(G__null_bitstream_size(cols) + 1,
-				     sizeof(unsigned char));
- * \brief Determines null bitstream size.
- * \return -1 if <i>cols</i> is invalid (<= 0)
- * \return size of null bistream
-int G__null_bitstream_size(int cols)
-    if (cols <= 0)
-	return -1;
-    return (cols / 8 + (cols % 8 != 0));
Deleted: grass/trunk/lib/gis/auto_mask.c
--- grass/trunk/lib/gis/auto_mask.c	2009-06-20 21:39:23 UTC (rev 38002)
+++ grass/trunk/lib/gis/auto_mask.c	2009-06-20 22:03:23 UTC (rev 38003)
@@ -1,105 +0,0 @@
- * \file auto_mask.c
- * \brief GIS Library - Auto masking routines.
- * (C) 2001-2008 by the GRASS Development Team
- * \author GRASS GIS Development Team
- * \date 1999-2008
-#include <stdlib.h>
-#include "G.h"
- * \brief Checks for auto masking.
- * On first call, opens the mask file if declared and available and
- * allocates buffer for reading mask rows.
- * On second call, returns 0 or 1.
- * \return 0 if mask unset or unavailable
- * \return 1 if mask set and available and ready to use
-int G__check_for_auto_masking(void)
-    /* if mask is switched off (-2) return -2
-       if G__.auto_mask is not set (-1) or set (>=0) recheck the MASK */
-    if (G__.auto_mask < -1)
-	return G__.auto_mask;
-    /* if(G__.mask_fd > 0) G_free (G__.mask_buf); */
-    /* look for the existence of the MASK file */
-    G__.auto_mask = (G_find_cell("MASK", G_mapset()) != 0);
-    if (G__.auto_mask <= 0)
-	return 0;
-    /* check MASK projection/zone against current region */
-    if (G_get_cellhd("MASK", G_mapset(), &cellhd) >= 0) {
-	if (cellhd.zone != G_zone() || cellhd.proj != G_projection()) {
-	    G__.auto_mask = 0;
-	    return 0;
-    G_unopen_cell(G__.mask_fd);
-    G__.mask_fd = G__open_cell_old("MASK", G_mapset());
-    if (G__.mask_fd < 0) {
-	G_warning(_("Unable to open automatic MASK file"));
-	return 0;
-    /*    G__.mask_buf = G_allocate_cell_buf(); */
-    G__.auto_mask = 1;
-    return 1;
- * \brief Suppresses masking.
- * \return
-void G_suppress_masking(void)
-    if (G__.auto_mask > 0) {
-	G_close_cell(G__.mask_fd);
-	/* G_free (G__.mask_buf); */
-	G__.mask_fd = -1;
-    G__.auto_mask = -2;
- * \brief Unsuppresses masking.
- * \return
-void G_unsuppress_masking(void)
-    if (G__.auto_mask < -1) {
-	G__.mask_fd = -1;
-	G__check_for_auto_masking();
Deleted: grass/trunk/lib/gis/cats.c
--- grass/trunk/lib/gis/cats.c	2009-06-20 21:39:23 UTC (rev 38002)
+++ grass/trunk/lib/gis/cats.c	2009-06-20 22:03:23 UTC (rev 38003)
@@ -1,1488 +0,0 @@
- * \file gis/cats.c
- * \brief GIS Library - Raster categories management
- * Code in this file works with category files.  There are two formats:
- * Pre 3.0 direct category encoding form:
- *    2 categories
- *    Map Title
- *    Elevation: 1000.00 to 1005.00 feet
- *    Elevation: 1005.00 to 1010.00 feet
- *    Elevation: 1010.00 to 1015.00 feet
- * 3.0 format
- *    # 2 categories
- *    Map Title
- *    Elevation: $1.2 to $2.2 feet       ## Format Statement
- *    5.0 1000 5.0 1005                  ## Coefficients
- * The coefficient line can be followed by explicit category labels
- * which override the format label generation.
- *    0:no data
- *    2:   .
- *    5:   .                             ## explicit category labels
- *    7:   .
- * explicit labels can be also of the form:
- *    5.5:5:9 label description
- *    or
- *    15:30  label description
- * In the format line
- *   $1 refers to the value num*5.0+1000 (ie, using the first 2 coefficients)
- *   $2 refers to the value num*5.0+1005 (ie, using the last 2 coefficients)
- *   $1.2 will print $1 with 2 decimal places.
- * Also, the form $?xxx$yyy$ translates into yyy if the category is 1, xxx
- * otherwise. The $yyy$ is optional. Thus
- *   $1 meter$?s
- * will become: 1 meter (for category 1)
- *              2 meters (for category 2), etc.
- * The format and coefficients above would be used to generate the
- * following statement in creation of the format appropriate category
- * string for category "num":
- *   sprintf(buff,"Elevation: %.2f to %.2f feet", num*5.0+1000, num*5.0*1005)
- * Note: while both the format and coefficent lins must be present
- *       a blank line for the fmt will effectively suppress automatic
- *       label generation
- * Note: quant rules of Categories structures are heavily dependent
- * on the fact that rules are stored in the same order they are entered.
- * since i-th rule and i-th label are entered at the same time, we
- * know that i-th rule maps fp range to i, thus we know for sure
- * that cats.labels[i] corresponds to i-th quant rule
-#include <string.h>
-static void get_cond(char **, char *, DCELL);
-static int get_fmt(char **, char *, int *);
-static int cmp(const void *, const void *);
-static int write_cats(const char *element, const char *name, struct Categories *cats);
-static CELL read_cats(const char *element,
-		      const char *name,
-		      const char *mapset, struct Categories * pcats, int full);
-static struct Categories save_cats;
- * \brief Read raster category file
- * \todo Remove, the function G_read_raster_cats()
- * The category file for raster map <i>name</i> in <i>mapset</i> is
- * read into the <i>cats</i> structure. If there is an error reading
- * the category file, a diagnostic message is printed and -1 is
- * returned. Otherwise, 0 is returned.
- * \param name map name
- * \param mapset mapset name
- * \param[out] cats pointer to Cats structure
- * \return -1 on error
- * \return 0 on success
-int G_read_cats(const char *name,
-		const char *mapset, struct Categories *pcats)
-    return G_read_raster_cats(name, mapset, pcats);
-int G_read_raster_cats(const char *name,
-    char *type;
-    switch (read_cats("cats", name, mapset, pcats, 1)) {
-    case -2:
-	type = "missing";
-	break;
-    case -1:
-	type = "invalid";
-	break;
-    default:
-	return 0;
-    G_warning(_("Category support for <%s@%s> %s"),
-	      name, mapset, type);
-    return -1;
- * \brief Read vector category file
- * <b>Note:</b> This function works with <b>old</b> vector format.
- * The category file for vector map <i>name</i> in <i>mapset</i> is
-int G_read_vector_cats(const char *name,
-    char *type;
-    switch (read_cats("dig_cats", name, mapset, pcats, 1)) {
-    case -2:
-	type = "missing";
-	break;
-    case -1:
-	type = "invalid";
-	break;
-    default:
-	return 0;
-    G_warning(_("Category support for vector map <%s@%s> %s"),
-    return -1;
-  \brief Get number of categories
-  \param name map name
-  \param mapset mapset name
-  \return -1 on error
-  \return number of cats
-CELL G_number_of_cats(const char *name, const char *mapset)
-    CELL min, max;
-    /* return the max category number */
-    if (G_read_range(name, mapset, &range) < 0)
-	return -1;
-    G_get_range_min_max(&range, &min, &max);
-    if (G_is_c_null_value(&max))
-	max = 0;
-    return max;
-		      const char *name,
-    FILE *fd;
-    char buff[1024];
-    CELL cat;
-    DCELL val1, val2;
-    int old = 0, fp_map;
-    long num = -1;
-    if (strncmp(element, "dig", 3) == 0)
-	fp_map = 0;
-    else
-	fp_map = G_raster_map_is_fp(name, mapset);
-    if (!(fd = G_fopen_old(element, name, mapset)))
-	return -2;
-    /* Read the number of categories */
-    if (G_getl(buff, sizeof buff, fd) == 0)
-	goto error;
-    if (sscanf(buff, "# %ld", &num) == 1)
-	old = 0;
-    else if (sscanf(buff, "%ld", &num) == 1)
-	old = 1;
-    if (!full) {
-	fclose(fd);
-	if (num < 0)
-	    return 0;		/* coorect */
-	return (CELL) num;
-    /* Read the title for the file */
-	goto error;
-    G_strip(buff);
-    /*    G_ascii_check(buff) ; */
-    if (num >= 0)
-	pcats->num = num;
-    if (!old) {
-	char fmt[256];
-	float m1, a1, m2, a2;
-	if (G_getl(fmt, sizeof fmt, fd) == 0)
-	    goto error;
-	/* next line contains equation coefficients */
-	    goto error;
-	if (sscanf(buff, "%f %f %f %f", &m1, &a1, &m2, &a2) != 4)
-	    goto error;
-    /* Read all category names */
-    for (cat = 0;; cat++) {
-	char label[1024];
-	    break;
-	if (old)
-	else {
-	    *label = 0;
-	    if (sscanf(buff, "%1s", label) != 1)
-		continue;
-	    if (*label == '#')
-		continue;
-	    *label = 0;
-	    /* for fp maps try to read a range of data */
-	    if (fp_map
-		&& sscanf(buff, "%lf:%lf:%[^\n]", &val1, &val2, label) == 3)
-	    else if (sscanf(buff, "%d:%[^\n]", &cat, label) >= 1)
-	    else if (sscanf(buff, "%lf:%[^\n]", &val1, label) >= 1)
-	    else
-		goto error;
-    fclose(fd);
-    return 0;
-  error:
-    fclose(fd);
-    return -1;
- * \brief Get title from category structure struct
- * \todo Remove from GIS Library, replace by G_get_raster_cats_title().
- * Map layers store a one-line title in the category structure as
- * well. This routine returns a pointer to the title contained in the
- * <i>cats</i> structure. A legal pointer is always returned. If the
- * map layer does not have a title, then a pointer to the empty string
- * "" is returned.
- * \param cats pointer to Categories structure
- * \return title
- * \return "" if missing
-char *G_get_cats_title(const struct Categories *pcats)
-    return G_get_raster_cats_title(pcats);
- * \brief Get raster cats title
- * Returns pointer to a string with title.
- * \param pcats pointer to Categories structure
- * \return title
-char *G_get_raster_cats_title(const struct Categories *pcats)
-    return pcats->title ? pcats->title : "";
- * \brief Get a raster category label
- * \todo Remove from GIS Library, replaced by G_get_c_raster_cat().
- * This routine looks up category <i>num</i> in the <i>pcats</i>
- * structure and returns a pointer to a string which is the label for
- * the category. A legal pointer is always returned. If the category
- * does not exist in <i>pcats</i>, then a pointer to the empty string
- * "" is returned.
- * <b>Warning:</b> The pointer that is returned points to a hidden
- * static buffer. Successive calls to G_get_cat() overwrite this
- * buffer.
- * \param num cell value
- * \return pointer to category label
- * \return "" if category is not found
-char *G_get_cat(CELL num, struct Categories *pcats)
-    return G_get_c_raster_cat(&num, pcats);
- * \brief Get a raster category label (CELL)
- * This routine looks up category <i>rast</i> in the <i>pcats</i>
- * "" is returned.
- * buffer.
- * \param rast cell value
-char *G_get_c_raster_cat(CELL * rast, struct Categories *pcats)
-    return G_get_raster_cat(rast, pcats, CELL_TYPE);
- * \brief Get a raster category label (FCELL)
- * "" is returned.
- * buffer.
-char *G_get_f_raster_cat(FCELL * rast, struct Categories *pcats)
-    return G_get_raster_cat(rast, pcats, FCELL_TYPE);
- * \brief Get a raster category label (DCELL)
- * "" is returned.
- * buffer.
-char *G_get_d_raster_cat(DCELL * rast, struct Categories *pcats)
-    return G_get_raster_cat(rast, pcats, DCELL_TYPE);
- * "" is returned.
- * buffer.
- * \param data_type map type (CELL, FCELL, DCELL)
-char *G_get_raster_cat(void *rast,
-		       struct Categories *pcats, RASTER_MAP_TYPE data_type)
-    static char label[1024];
-    char *f, *l, *v;
-    CELL i;
-    DCELL val;
-    float a[2];
-    char fmt[30], value_str[30];
-    if (G_is_null_value(rast, data_type)) {
-	sprintf(label, "no data");
-	return label;
-    /* first search the list of labels */
-    *label = 0;
-    val = G_get_raster_value_d(rast, data_type);
-    i = G_quant_get_cell_value(&pcats->q, val);
-    G_debug(5, "G_get_raster_cat(): val %lf found i %d", val, i);
-    if (!G_is_c_null_value(&i) && i < pcats->ncats) {
-	if (pcats->labels[i] != NULL)
-	    return pcats->labels[i];
-	return label;
-    /* generate the label */
-    if ((f = pcats->fmt) == NULL)
-	return label;
-    a[0] = (float)val *pcats->m1 + pcats->a1;
-    a[1] = (float)val *pcats->m2 + pcats->a2;
-    l = label;
-    while (*f) {
-	if (*f == '$') {
-	    f++;
-	    if (*f == '$')
-		*l++ = *f++;
-	    else if (*f == '?') {
-		f++;
-		get_cond(&f, v = value_str, val);
-		while (*v)
-		    *l++ = *v++;
-	    else if (get_fmt(&f, fmt, &i)) {
-		sprintf(v = value_str, fmt, a[i]);
-		while (*v)
-		    *l++ = *v++;
-	    else
-		*l++ = '$';
-	else {
-	    *l++ = *f++;
-    *l = 0;
-    return label;
- * \brief Sets marks for all categories to 0.
- * This initializes Categories structure for subsequest calls to
- * G_mark_raster_cats() for each row of data, where non-zero mark for
- * i-th label means that some of the cells in rast_row are labeled
- * with i-th label and fall into i-th data range. These marks help
- * determine from the Categories structure which labels were used and
- * which weren't.
-void G_unmark_raster_cats(struct Categories *pcats)
-    int i;
-    for (i = 0; i < pcats->ncats; i++)
-	pcats->marks[i] = 0;
- * \brief Looks up the category label for each raster value (CELL).
- * Looks up the category label for each raster value in the
- * <i>rast_row</i> and updates the marks for labels found.
- * <b>Note:</b> Non-zero mark for i-th label stores the number of of
- * raster cells read so far which are labeled with i-th label and fall
- * into i-th data range.
- * \param rast_row raster row to update stats
- * \param ncols number of columns
-void G_mark_c_raster_cats(const CELL * rast_row,
-			  int ncols, struct Categories *pcats)
-    G_mark_raster_cats(rast_row, ncols, pcats, CELL_TYPE);
- * \brief Looks up the category label for each raster value (FCELL).
-void G_mark_f_raster_cats(const FCELL * rast_row,
-    G_mark_raster_cats(rast_row, ncols, pcats, FCELL_TYPE);
- * \brief Looks up the category label for each raster value (DCELL).
-void G_mark_d_raster_cats(const DCELL * rast_row,
-    G_mark_raster_cats(rast_row, ncols, pcats, DCELL_TYPE);
- * \return 1 on success
-int G_mark_raster_cats(const void *rast_row,
-		       int ncols, struct Categories *pcats,
-		       RASTER_MAP_TYPE data_type)
-    CELL i;
-    while (ncols-- > 0) {
-				   G_get_raster_value_d(rast_row, data_type));
-	if (G_is_c_null_value(&i))
-	    continue;
-	if (i > pcats->ncats)
-	    return -1;
-	pcats->marks[i]++;
-	rast_row = G_incr_void_ptr(rast_row, G_raster_size(data_type));
-    return 1;
- * \brief Rewind raster categories
- * After call to this function G_get_next_marked_raster_cat() returns
- * the first marked cat label.
-void G_rewind_raster_cats(struct Categories *pcats)
-    pcats->last_marked_rule = -1;
-  \brief Get next marked raster categories (DCELL)
-  \param pcats pointer to Categories structure
-  \param rast1, rast2 cell values (raster range)
-  \param[out] count count
-  \return NULL if not found
-  \return description if found
-char *G_get_next_marked_d_raster_cat(struct Categories *pcats,
-				     DCELL * rast1, DCELL * rast2,
-				     long *count)
-    char *descr = NULL;
-    int found, i;
-    found = 0;
-    /* pcats->ncats should be == G_quant_nof_rules(&pcats->q) */
-    G_debug(3, "last marked %d nrules %d\n", pcats->last_marked_rule, G_quant_nof_rules(&pcats->q));
-    for (i = pcats->last_marked_rule + 1; i < G_quant_nof_rules(&pcats->q); i++) {
-	descr = G_get_ith_d_raster_cat(pcats, i, rast1, rast2);
-	G_debug(5, "%d %d", i, pcats->marks[i]);
-	if (pcats->marks[i]) {
-	    found = 1;
-	    break;
-    if (!found)
-	return NULL;
-    *count = pcats->marks[i];
-    pcats->last_marked_rule = i;
-    return descr;
-  \brief Get next marked raster categories (CELL)
-char *G_get_next_marked_c_raster_cat(struct Categories *pcats,
-				     CELL * rast1, CELL * rast2,
-				     long *count)
-    return G_get_next_marked_raster_cat(pcats, rast1, rast2, count,
-					CELL_TYPE);
-  \brief Get next marked raster categories (FCELL)
-char *G_get_next_marked_f_raster_cat(struct Categories *pcats,
-				     FCELL * rast1, FCELL * rast2,
-				     long *count)
-					FCELL_TYPE);
-  \param data_type map type
-char *G_get_next_marked_raster_cat(struct Categories *pcats,
-				   void *rast1, void *rast2,
-				   long *count, RASTER_MAP_TYPE data_type)
-    DCELL val1, val2;
-    char *lab;
-    lab = G_get_next_marked_d_raster_cat(pcats, &val1, &val2, count);
-    G_set_raster_value_d(rast1, val1, data_type);
-    G_set_raster_value_d(rast2, val2, data_type);
-    return lab;
-static int get_fmt(char **f, char *fmt, int *i)
-    char *ff;
-    ff = *f;
-    if (*ff == 0)
-	return 0;
-    if (*ff == '$') {
-	*f = ff + 1;
-	return 0;
-    switch (*ff++) {
-    case '1':
-	*i = 0;
-	break;
-    case '2':
-	*i = 1;
-	break;
-    default:
-	return 0;
-    *fmt++ = '%';
-    *fmt++ = '.';
-    if (*ff++ != '.') {
-	*f = ff - 1;
-	*fmt++ = '0';
-	*fmt++ = 'f';
-	*fmt = 0;
-	return 1;
-    *fmt = '0';
-    while (*ff >= '0' && *ff <= '9')
-	*fmt++ = *ff++;
-    *fmt++ = 'f';
-    *fmt = 0;
-    *f = ff;
-    return 1;
-static void get_cond(char **f, char *value, DCELL val)
-    char *ff;
-    ff = *f;
-    if (val == 1.) {
-	while (*ff)
-	    if (*ff++ == '$')
-		break;
-    while (*ff)
-	if (*ff == '$') {
-	    ff++;
-	    break;
-	else
-	    *value++ = *ff++;
-    if (val != 1.) {
-	while (*ff)
-	    if (*ff++ == '$')
-		break;
-    *value = 0;
-    *f = ff;
- * \brief Set a raster category label
- * \todo To be removed, replaced by G_set_c_raster_cat().
- * The <i>label</i> is copied into the <i>pcats</i> structure for
- * category <i>num</i>.
- * \param num raster cell
- * \param label category label
- * \return 0 if null value detected
-int G_set_cat(CELL num, const char *label, struct Categories *pcats)
-    return G_set_c_raster_cat(&num, &num, label, pcats);
- * \brief Set a raster category label (CELL)
- * Adds the label for range <i>rast1</i> through <i>rast2</i> in
- * category structure <i>pcats</i>.
- * \param rast1, rast2 raster values (range)
-int G_set_c_raster_cat(const CELL * rast1, const CELL * rast2,
-		       const char *label, struct Categories *pcats)
-    return G_set_raster_cat(rast1, rast2, label, pcats, CELL_TYPE);
- * \brief Set a raster category label (FCELL)
- * \return
-int G_set_f_raster_cat(const FCELL * rast1, const FCELL * rast2,
-    return G_set_raster_cat(rast1, rast2, label, pcats, FCELL_TYPE);
- * \brief Set a raster category label (DCELL)
-int G_set_d_raster_cat(const DCELL * rast1, const DCELL * rast2,
-    long len;
-    DCELL dtmp1, dtmp2;
-    int i;
-    char *descr;
-    /* DEBUG fprintf(stderr,"G_set_d_raster_cat(rast1 = %p,rast2 = %p,label = '%s',pcats = %p)\n",
-       rast1,rast2,label,pcats); */
-    if (G_is_d_null_value(rast1))
-	return 0;
-    if (G_is_d_null_value(rast2))
-	return 0;
-    /* DEBUG fprintf (stderr, "G_set_d_raster_cat(): adding quant rule: %f %f %d %d\n", *rast1, *rast2, pcats->ncats, pcats->ncats); */
-    /* the set_cat() functions are used in many places to reset the labels
-       for the range (or cat) with existing label. In this case we don't
-       want to store both rules with identical range even though the result
-       of get_cat() will be correct, since it will use rule added later.
-       we don't want to overuse memory and we don't want rules which are
-       not used to be writen out in cats file. So we first look if
-       the label for this range has been sen, and if it has, overwrite it */
-    for (i = 0; i < pcats->ncats; i++) {
-	descr = G_get_ith_d_raster_cat(pcats, i, &dtmp1, &dtmp2);
-	if ((dtmp1 == *rast1 && dtmp2 == *rast2)
-	    || (dtmp1 == *rast2 && dtmp2 == *rast1)) {
-		G_free(pcats->labels[i]);
-	    pcats->labels[i] = G_store(label);
-	    G_newlines_to_spaces(pcats->labels[i]);
-	    G_strip(pcats->labels[i]);
-	    return 1;
-    /* when rule for this range does not exist */
-    /* DEBUG fprintf (stderr, "G_set_d_raster_cat(): New rule: adding %d %p\n", i, pcats->labels); */
-    G_quant_add_rule(&pcats->q, *rast1, *rast2, pcats->ncats, pcats->ncats);
-    pcats->ncats++;
-    if (pcats->nalloc < pcats->ncats) {
-	/* DEBUG fprintf (stderr, "G_set_d_raster_cat(): need more space nalloc = %d ncats = %d\n", pcats->nalloc,pcats->ncats); */
-	len = (pcats->nalloc + 256) * sizeof(char *);
-	/* DEBUG fprintf (stderr, "G_set_d_raster_cat(): allocating %d labels(%d)\n", pcats->nalloc + 256,(int)len); */
-	if (len != (int)len) {	/* make sure len doesn't overflow int */
-	    pcats->ncats--;
-	    return -1;
-	/* DEBUG fprintf(stderr,"G_set_d_raster_cat(): pcats->nalloc = %d, pcats->labels = (%p), len = %d\n",pcats->nalloc,pcats->labels,(int)len); */
-	if (pcats->nalloc) {
-	    /* DEBUG fprintf(stderr,"G_set_d_raster_cat(): Realloc-ing pcats->labels (%p)\n",pcats->labels); */
-	    pcats->labels =
-		(char **)G_realloc((char *)pcats->labels, (int)len);
-	else {
-	    /* DEBUG fprintf(stderr,"G_set_d_raster_cat(): alloc-ing new labels pointer array\n"); */
-	    pcats->labels = (char **)G_malloc((int)len);
-	/* fflush(stderr); */
-	/* DEBUG fprintf (stderr, "G_set_d_raster_cats(): allocating %d marks(%d)\n", pcats->nalloc + 256,(int)len); */
-	len = (pcats->nalloc + 256) * sizeof(int);
-	    pcats->ncats--;
-	    return -1;
-	    pcats->marks = (int *)G_realloc((char *)pcats->marks, (int)len);
-	else
-	    pcats->marks = (int *)G_malloc((int)len);
-	pcats->nalloc += 256;
-    /* DEBUG fprintf(stderr,"G_set_d_raster_cats(): store new label\n"); */
-    pcats->labels[pcats->ncats - 1] = G_store(label);
-    G_newlines_to_spaces(pcats->labels[pcats->ncats - 1]);
-    G_strip(pcats->labels[pcats->ncats - 1]);
-    /* DEBUG
-       fprintf (stderr, "%d %s\n", pcats->ncats - 1, pcats->labels[pcats->ncats - 1]);
-    /* updates cats.num = max cat values. This is really just used in old
-       raster programs, and I am doing it for backwards cmpatibility (Olga) */
-    if ((CELL) * rast1 > pcats->num)
-	pcats->num = (CELL) * rast1;
-    if ((CELL) * rast2 > pcats->num)
-	pcats->num = (CELL) * rast2;
-    /* DEBUG fprintf(stderr,"G_set_d_raster_cat(): done\n"); */
-    /* DEBUG fflush(stderr); */
-    return 1;
-int G_set_raster_cat(const void *rast1, const void *rast2,
-    DCELL val1, val2;
-    val1 = G_get_raster_value_d(rast1, data_type);
-    val2 = G_get_raster_value_d(rast2, data_type);
-    return G_set_d_raster_cat(&val1, &val2, label, pcats);
- * \brief Write raster category file
- * \todo To be removed, replaced by G_write_raster_cats().
- * Writes the category file for the raster map <i>name</i> in the
- * current mapset from the <i>cats</i> structure.
- * \return -1 is returned (no diagnostic is printed)
-int G_write_cats(const char *name, struct Categories *cats)
-    return write_cats("cats", name, cats);
-int G_write_raster_cats(const char *name, struct Categories *cats)
- * \brief Write vector category file
- * <b>Note:</b> Used for only old vector format!
-int G_write_vector_cats(const char *name, struct Categories *cats)
-    return write_cats("dig_cats", name, cats);
-    FILE *fd;
-    int i, fp_map;
-    char *descr;
-    DCELL val1, val2;
-    char str1[100], str2[100];
-    if (!(fd = G_fopen_new(element, name)))
-	return -1;
-    /* write # cats - note # indicate 3.0 or later */
-    fprintf(fd, "# %ld categories\n", (long)cats->num);
-    /* title */
-    fprintf(fd, "%s\n", cats->title != NULL ? cats->title : "");
-    /* write format and coefficients */
-    fprintf(fd, "%s\n", cats->fmt != NULL ? cats->fmt : "");
-    fprintf(fd, "%.2f %.2f %.2f %.2f\n",
-	    cats->m1, cats->a1, cats->m2, cats->a2);
-    /* if the map is integer or if this is a vector map, sort labels */
-	fp_map = 0;
-    else
-	fp_map = G_raster_map_is_fp(name, G_mapset());
-    if (!fp_map)
-	G_sort_cats(cats);
-    /* write the cat numbers:label */
-	if ((cats->fmt && cats->fmt[0])
-	    || (descr && descr[0])) {
-	    if (val1 == val2) {
-		sprintf(str1, "%.10f", val1);
-		G_trim_decimal(str1);
-		fprintf(fd, "%s:%s\n", str1, descr != NULL ? descr : "");
-	    else {
-		sprintf(str2, "%.10f", val2);
-		G_trim_decimal(str2);
-		fprintf(fd, "%s:%s:%s\n", str1, str2,
-			descr != NULL ? descr : "");
-    fclose(fd);
-    return (1);
- * \brief Get category description (DCELL)
- * Returns i-th description and i-th data range from the list of
- * category descriptions with corresponding data ranges. end points of
- * data interval in <i>rast1</i> and <i>rast2</i>.
- * \param i index
- * \return "" on error
- * \return pointer to category description
-char *G_get_ith_d_raster_cat(const struct Categories *pcats,
-			     int i, DCELL * rast1, DCELL * rast2)
-    int index;
-    if (i > pcats->ncats) {
-	G_set_d_null_value(rast1, 1);
-	G_set_d_null_value(rast2, 1);
-	return "";
-    G_quant_get_ith_rule(&pcats->q, i, rast1, rast2, &index, &index);
-    return pcats->labels[index];
- * \brief Get category description (FCELL)
- * \param i index
-char *G_get_ith_f_raster_cat(const struct Categories *pcats,
-			     int i, void *rast1, void *rast2)
-    RASTER_MAP_TYPE data_type = FCELL_TYPE;
-    char *tmp;
-    DCELL val1, val2;
-    tmp = G_get_ith_d_raster_cat(pcats, i, &val1, &val2);
-    return tmp;
- * \brief Get category description (CELL)
- * \param i index
-char *G_get_ith_c_raster_cat(const struct Categories *pcats,
-    RASTER_MAP_TYPE data_type = CELL_TYPE;
-    char *tmp;
-    DCELL val1, val2;
-    return tmp;
- * \param i index
-char *G_get_ith_raster_cat(const struct Categories *pcats, int i, void *rast1,
-			   void *rast2, RASTER_MAP_TYPE data_type)
-    char *tmp;
-    DCELL val1, val2;
-    return tmp;
- * \brief Initialize category structure
- * To construct a new category file, the structure must first be
- * initialized. This routine initializes the <i>cats</i> structure,
- * and copies the <i>title</i> into the structure. The number of
- * categories is set initially to <i>n</i>.
- * For example:
- \code
- struct Categories cats;
- G_init_cats ((CELL)0, * "", &cats);
- \endcode
- * \param num raster value
- * \param title title
-void G_init_cats(CELL num, const char *title, struct Categories *pcats)
-    G_init_raster_cats(title, pcats);
-    pcats->num = num;
- * Same as existing G_init_raster_cats() only ncats argument is
- * missign. ncats has no meaning in new Categories structure and only
- * stores (int) largets data value for backwards compatibility.
-void G_init_raster_cats(const char *title, struct Categories *pcats)
-    G_set_raster_cats_title(title, pcats);
-    pcats->labels = NULL;
-    pcats->nalloc = 0;
-    pcats->ncats = 0;
-    pcats->num = 0;
-    pcats->fmt = NULL;
-    pcats->m1 = 0.0;
-    pcats->a1 = 0.0;
-    pcats->m2 = 0.0;
-    pcats->a2 = 0.0;
-    G_quant_init(&pcats->q);
- * \brief Set title in category structure
- * \todo To be removed, replaced by G_set_raster_cats_title().
- * The <i>title</i> is copied into the <i>pcats</i> structure.
-void G_set_cats_title(const char *title, struct Categories *pcats)
-void G_set_raster_cats_title(const char *title, struct Categories *pcats)
-    if (title == NULL)
-	title = "";
-    pcats->title = G_store(title);
-    G_newlines_to_spaces(pcats->title);
-    G_strip(pcats->title);
-  \brief Set category fmt (?)
-  \todo To be removed, replaced by G_set_raster_cats_fmt().
-  \param fmt
-  \param m1,
-  \param a1,m2,a2
-void G_set_cats_fmt(const char *fmt, double m1, double a1, double m2,
-		    double a2, struct Categories *pcats)
-  \param fmt
-  \param m1,
-  \param a1,m2,a2
-void G_set_raster_cats_fmt(const char *fmt, double m1, double a1, double m2,
-    pcats->m1 = m1;
-    pcats->a1 = a1;
-    pcats->m2 = m2;
-    pcats->a2 = a2;
-    pcats->fmt = G_store(fmt);
-    G_newlines_to_spaces(pcats->fmt);
-    G_strip(pcats->fmt);
- * \brief Free category structure memory
- * \todo To be removed, replaced by G_free_raster_cats().
- * Frees memory allocated by G_read_cats(), G_init_cats() and
- * G_set_cat().
-void G_free_cats(struct Categories *pcats)
-    G_free_raster_cats(pcats);
- * G_set_cat().
-void G_free_raster_cats(struct Categories *pcats)
-    int i;
-    if (pcats->title != NULL) {
-	G_free(pcats->title);
-	pcats->title = NULL;
-    if (pcats->fmt != NULL) {
-	G_free(pcats->fmt);
-    if (pcats->ncats > 0) {
-	G_free(pcats->labels);
-	G_free(pcats->marks);
-    G_quant_free(&pcats->q);
-    pcats->ncats = 0;
- * \brief Copy raster categories
- * Allocates NEW space for quant rules and labels n <i>pcats_to</i>
- * and copies all info from <i>pcats_from</i> cats to
- * <i>pcats_to</i> cats.
- * \param pcats_to pointer to destination Categories structure
- * \param pcats_from pointer to source Categories structure
-void G_copy_raster_cats(struct Categories *pcats_to,
-			const struct Categories *pcats_from)
-    int i;
-    char *descr;
-    DCELL d1, d2;
-    G_init_raster_cats(pcats_from->title, pcats_to);
-    for (i = 0; i < pcats_from->ncats; i++) {
-	descr = G_get_ith_d_raster_cat(pcats_from, i, &d1, &d2);
-	G_set_d_raster_cat(&d1, &d2, descr, pcats_to);
-  \brief Get number of raster categories
-  \return number of categories
-int G_number_of_raster_cats(struct Categories *pcats)
-    return pcats->ncats;
-  \brief Sort categories
-  \return -1 on error (nothing to sort)
-  \return 0 on success
-int G_sort_cats(struct Categories *pcats)
-    int *indexes, i, ncats;
-    char *descr;
-    DCELL d1, d2;
-    if (pcats->ncats <= 1)
-	return -1;
-    ncats = pcats->ncats;
-    G_debug(3, "G_sort_cats(): Copying to save cats buffer");
-    G_copy_raster_cats(&save_cats, pcats);
-    indexes = (int *)G_malloc(sizeof(int) * ncats);
-    for (i = 0; i < ncats; i++)
-	indexes[i] = i;
-    qsort(indexes, ncats, sizeof(int), cmp);
-    G_init_raster_cats(save_cats.title, pcats);
-    for (i = 0; i < ncats; i++) {
-	descr = G_get_ith_d_raster_cat(&save_cats, indexes[i], &d1, &d2);
-	G_debug(4, "  Write sorted cats, pcats = %p pcats->labels = %p",
-		pcats, pcats->labels);
-	G_set_d_raster_cat(&d1, &d2, descr, pcats);
-    G_free_raster_cats(&save_cats);
-    return 0;
-static int cmp(const void *aa, const void *bb)
-    const int *a = aa, *b = bb;
-    DCELL min_rast1, min_rast2, max_rast1, max_rast2;
-    CELL index;
-    G_quant_get_ith_rule(&(save_cats.q), *a,
-			 &min_rast1, &max_rast1, &index, &index);
-    G_quant_get_ith_rule(&(save_cats.q), *b,
-			 &min_rast2, &max_rast2, &index, &index);
-    if (min_rast1 < min_rast2)
-	return -1;
-    if (min_rast1 > min_rast2)
-	return 1;
-    return 0;
Deleted: grass/trunk/lib/gis/cell_stats.c
--- grass/trunk/lib/gis/cell_stats.c	2009-06-20 21:39:23 UTC (rev 38002)
+++ grass/trunk/lib/gis/cell_stats.c	2009-06-20 22:03:23 UTC (rev 38003)
@@ -1,390 +0,0 @@
- * \file gis/cell_stats.c
- * \brief GIS Library - Raster cell statistics
- * (C) 2001-2009 GRASS Development Team
-#define INCR 10
-#define SHIFT 6
-static const int NCATS = 1 << SHIFT;
-#define NODE struct Cell_stats_node
-static int next_node(struct Cell_stats *);
-static void init_node(NODE *, int, int);
- * \brief Initialize cell stats
- * This routine, which must be called first, initializes the
- * Cell_stats structure.
- * Set the count for NULL-values to zero.
- * \param s pointer to Cell_stats structure
-void G_init_cell_stats(struct Cell_stats *s)
-    s->N = 0;
-    s->tlen = INCR;
-    s->node = (NODE *) G_malloc(s->tlen * sizeof(NODE));
-    s->null_data_count = 0;
- * \brief Sdd data to cell stats
- * The <i>n</i> CELL values in the <i>data</i> array are inserted (and
- * counted) in the Cell_stats structure.
- * Look for NULLs and update the NULL-value count.
- * \param cell raster values
- * \param n number of values
- * \param s pointer to Cell_stats structure which holds cell stats info
- * \return 1 on failure
-int G_update_cell_stats(const CELL * cell, int n, struct Cell_stats *s)
-    CELL cat;
-    int p, q;
-    int idx, offset;
-    int N;
-    NODE *node, *pnode;
-    NODE *new_node;
-    if (n <= 0)
-	return 1;
-    node = s->node;
-    /* first non-null node is special case */
-    if ((N = s->N) == 0) {
-	cat = *cell++;
-	while (G_is_c_null_value(&cat)) {
-	    s->null_data_count++;
-	    cat = *cell++;
-	    n--;
-	if (n > 0) {		/* if there are some non-null cells */
-	    N = 1;
-	    if (cat < 0) {
-		idx = -((-cat) >> SHIFT) - 1;
-		offset = cat + ((-idx) << SHIFT) - 1;
-	    else {
-		idx = cat >> SHIFT;
-		offset = cat - (idx << SHIFT);
-	    fflush(stderr);
-	    init_node(&node[1], idx, offset);
-	    node[1].right = 0;
-	    n--;
-    while (n-- > 0) {
-	cat = *cell++;
-	if (G_is_c_null_value(&cat)) {
-	    continue;
-	if (cat < 0) {
-	else {
-	q = 1;
-	while (q > 0) {
-	    pnode = &node[p = q];
-	    if (pnode->idx == idx) {
-		pnode->count[offset]++;
-		break;
-	    if (pnode->idx > idx)
-		q = pnode->left;	/* go left */
-	    else
-		q = pnode->right;	/* go right */
-	if (q > 0)
-	    continue;		/* found */
-	/* new node */
-	N++;
-	/* grow the tree? */
-	if (N >= s->tlen) {
-	    node =
-		(NODE *) G_realloc((char *)node,
-				   sizeof(NODE) * (s->tlen += INCR));
-	    pnode = &node[p];	/* realloc moves node, must reassign pnode */
-	/* add node to tree */
-	init_node(new_node = &node[N], idx, offset);
-	if (pnode->idx > idx) {
-	    new_node->right = -p;	/* create thread */
-	    pnode->left = N;	/* insert left */
-	else {
-	    new_node->right = pnode->right;	/* copy right link/thread */
-	    pnode->right = N;	/* add right */
-    }				/* while n-- > 0 */
-    s->N = N;
-    s->node = node;
-    return 0;
-static void init_node(NODE * node, int idx, int offset)
-    long *count;
-    int i;
-    count = node->count = (long *)G_calloc(i = NCATS, sizeof(long));
-    while (i--)
-	*count++ = 0;
-    node->idx = idx;
-    node->count[offset] = 1;
-    node->left = 0;
- * \brief Random query of cell stats
- * This routine allows a random query of the Cell_stats structure. The
- * <i>count</i> associated with the raster value <i>cat</i> is
- * set. The routine returns 1 if <i>cat<i> was found in the
- * structure, 0 otherwise.
- * Allow finding the count for the NULL-value.
- * \param cat raster value
- * \param[out] count count
- * \return 1 if found
- * \return 0 if not found
-int G_find_cell_stat(CELL cat, long *count, const struct Cell_stats *s)
-    int q;
-    int idx;
-    int offset;
-    *count = 0;
-	*count = s->null_data_count;
-	return (*count != 0);
-    if (s->N <= 0)
-	return 0;
-       if (cat < 0)
-       idx = -(-cat/NCATS) - 1;
-       offset = cat - idx*NCATS - 1;
-       else
-       idx = cat/NCATS;
-       offset = cat - idx*NCATS;
-    if (cat < 0) {
-    else {
-    q = 1;
-    while (q > 0) {
-	if (s->node[q].idx == idx) {
-	    *count = s->node[q].count[offset];
-	if (s->node[q].idx > idx)
-	    q = s->node[q].left;	/* go left */
-	else
-	    q = s->node[q].right;	/* go right */
-    return 0;
- * \brief Reset/rewind cell stats
- * The structure <i>s</i> is rewound (i.e., positioned at the first
- * raster category) so that sorted sequential retrieval can begin.
- * \return 0
-int G_rewind_cell_stats(struct Cell_stats *s)
-    int q;
-    if (s->N <= 0)
-	return 1;
-    /* start at root and go all the way to the left */
-    s->curp = 1;
-    while ((q = s->node[s->curp].left))
-	s->curp = q;
-    s->curoffset = -1;
-    return 0;
-static int next_node(struct Cell_stats *s)
-    int q;
-    /* go to the right */
-    s->curp = s->node[s->curp].right;
-    if (s->curp == 0)		/* no more */
-	return 0;
-    if (s->curp < 0) {		/* thread. stop here */
-	s->curp = -(s->curp);
-	return 1;
-    while ((q = s->node[s->curp].left))	/* now go all the way left */
-	s->curp = q;
-    return 1;
- * \brief Retrieve sorted cell stats
- * Retrieves the next <i>cat, count</i> combination from the
- * structure. Returns 0 if there are no more items, non-zero if there
- * are more. For example:
- \code
- struct Cell_stats s;
- CELL cat;
- long count;
- // updating <b>s</b> occurs here
- G_rewind_cell_stats(&s);
- while (G_next_cell_stat(&cat,&count,&s)
- fprintf(stdout, "%ld %ld\n", (long) cat, count);
- \endcode
- * Do not return a record for the NULL-value
- * \return 0 if there are no more items
- * \return non-zero if there are more
-int G_next_cell_stat(CELL * cat, long *count, struct Cell_stats *s)
-    int idx;
-    /* first time report stats for null */
-    /* decided not to return stats for null in this function
-       static int null_reported = 0;
-       if(!null_reported && s->null_data_count > 0)
-       G_set_c_null_value(&cat,1);
-       null_reported = 1;
-       return 1;
-    if (s->N <= 0)
-	return 0;
-    for (;;) {
-	s->curoffset++;
-	if (s->curoffset >= NCATS) {
-	    if (!next_node(s))
-		return 0;
-	    continue;
-	if ((*count = s->node[s->curp].count[s->curoffset])) {
-	    idx = s->node[s->curp].idx;
-	       if (idx < 0)
-	       *cat = idx*NCATS + s->curoffset+1;
-	       else
-	       *cat = idx*NCATS + s->curoffset;
-	    if (idx < 0)
-		*cat = -((-idx) << SHIFT) + s->curoffset + 1;
-	    else
-		*cat = (idx << SHIFT) + s->curoffset;
-	    return 1;
- * \brief Get number of null values.
- * Get a number of null values from stats structure.
- * Note: when reporting values which appear in a map using
- * G_next_cell_stats(), to get stats for null, call
- * G_get_stats_for_null_value() first, since G_next_cell_stats() does
- * not report stats for null.
- * \param count count
-void G_get_stats_for_null_value(long *count, const struct Cell_stats *s)
- * \brief Free cell stats structure
- * The memory associated with structure <i>s</i> is freed. This
- * routine may be called any time after calling G_init_cell_stats().
-void G_free_cell_stats(struct Cell_stats *s)
-    int i;
-    for (i = 1; i <= s->N; i++)
-	G_free(s->node[i].count);
-    G_free(s->node);
Deleted: grass/trunk/lib/gis/cell_title.c
--- grass/trunk/lib/gis/cell_title.c	2009-06-20 21:39:23 UTC (rev 38002)
+++ grass/trunk/lib/gis/cell_title.c	2009-06-20 22:03:23 UTC (rev 38003)
@@ -1,50 +0,0 @@
- * char *G_get_cell_title (name, mapset)
- *   char *name        name of map file
- *   char *mapset      mapset containing name
- *   returns pointer to string containing cell title. (from cats file)
- * \brief get raster map title
- * If only the map layer title is needed, it is not necessary to read the
- * entire category file into memory. This routine gets the title for raster map
- * <b>name</b> in <b>mapset</b> directly from the category file, and returns
- * a pointer to the title. A legal pointer is always returned. If the map layer
- * does not have a title, then a pointer to the empty string "" is returned.
- *  \param name
- *  \param mapset
- *  \return char *
-char *G_get_cell_title(const char *name, const char *mapset)
-    FILE *fd;
-    int stat;
-    char title[1024];
-    stat = -1;
-    fd = G_fopen_old("cats", name, mapset);
-    if (fd) {
-	stat = 1;
-	if (!fgets(title, sizeof title, fd))	/* skip number of cats */
-	    stat = -1;
-	else if (!G_getl(title, sizeof title, fd))	/* read title */
-	    stat = -1;
-	fclose(fd);
-    if (stat < 0)
-	*title = 0;
-    else
-	G_strip(title);
-    return G_store(title);
Deleted: grass/trunk/lib/gis/cellstats_eq.c
--- grass/trunk/lib/gis/cellstats_eq.c	2009-06-20 21:39:23 UTC (rev 38002)
+++ grass/trunk/lib/gis/cellstats_eq.c	2009-06-20 22:03:23 UTC (rev 38003)
@@ -1,74 +0,0 @@
-int G_cell_stats_histo_eq(struct Cell_stats *statf, CELL min1, CELL max1,	/* input range to be rescaled */
-			  CELL min2, CELL max2,	/* output range */
-			  int zero,	/* include zero if min1 <= 0 <= min2 ? */
-			  void (*func) (CELL, CELL, CELL))
-    long count, total;
-    CELL prev = 0;
-    CELL cat;
-    CELL x;
-    CELL newcat = 0;
-    int first;
-    double span, sum;
-    double range2;
-    if (min1 > max1 || min2 > max2)
-	return 0;
-    total = 0;
-    G_rewind_cell_stats(statf);
-    while (G_next_cell_stat(&cat, &count, statf)) {
-	if (cat < min1)
-	    continue;
-	if (cat > max1)
-	    break;
-	if (cat == 0 && !zero)
-	    continue;
-	total += count;
-    if (total <= 0)
-	return 0;
-    range2 = max2 - min2 + 1;
-    span = total / range2;
-    first = 1;
-    sum = 0;
-	if (cat < min1)
-	    continue;
-	if (cat > max1)
-	    break;
-	    continue;
-	x = (sum + (count / 2.0)) / span;
-	if (x < 0)
-	    x = 0;
-	x += min2;
-	sum += count;
-	if (first) {
-	    prev = cat;
-	    newcat = x;
-	    first = 0;
-	else if (newcat != x) {
-	    func(prev, cat - 1, newcat);
-	    newcat = x;
-	    prev = cat;
-    if (!first) {
-	func(prev, cat, newcat);
-	if (!zero && min1 <= 0 && max1 >= 0)
-	    func((CELL) 0, (CELL) 0, (CELL) 0);
-    return first == 0;
Deleted: grass/trunk/lib/gis/closecell.c
--- grass/trunk/lib/gis/closecell.c	2009-06-20 21:39:23 UTC (rev 38002)
+++ grass/trunk/lib/gis/closecell.c	2009-06-20 22:03:23 UTC (rev 38003)
@@ -1,502 +0,0 @@
- * \file gis/closecell.c
- * \brief GIS Library - Close raster file
- * (C) 1999-2009 by the GRASS Development Team
- * License (>=v2). Read the file COPYING that comes with GRASS
- * for details.
- * \author USACERL and many others
-#ifdef __MINGW32__
-#  include <windows.h>
-#endif
-#include <stdio.h>
-#include <unistd.h>
-#include <fcntl.h>
-#include <signal.h>
-#include "G.h"
-#define FORMAT_FILE "f_format"
-#define QUANT_FILE  "f_quant"
-#define NULL_FILE   "null"
-static int close_old(int);
-static int close_new(int, int);
-static int write_fp_format(int fd);
- * \brief Close a raster map
- * The raster map opened on file descriptor <i>fd</i> is
- * closed. Memory allocated for raster processing is freed. If open
- * for writing, skeletal support files for the new raster map are
- * created as well.
- * <b>Note:</b> If a module wants to explicitly write support files
- * (e.g., a specific color table) for a raster map it creates, it must
- * do so after the raster map is closed. Otherwise the close will
- * overwrite the support files. See \ref
- * Raster_Map_Layer_Support_Routines for routines which write raster
- * support files.
- * If the map is a new floating point, move the <tt>.tmp</tt> file
- * into the <tt>fcell</tt> element, create an empty file in the
- * <tt>cell</tt> directory; write the floating-point range file; write
- * a default quantization file quantization file is set here to round
- * fp numbers (this is a default for now). create an empty category
- * file, with max cat = max value (for backwards compatibility). Move
- * the <tt>.tmp</tt> NULL-value bitmap file to the <tt>cell_misc</tt>
- * directory.
- * \param fd file descriptor
-int G_close_cell(int fd)
-    struct fileinfo *fcb = &G__.fileinfo[fd];
-    if (fd < 0 || fd >= G__.fileinfo_count || fcb->open_mode <= 0)
-	return -1;
-    if (fcb->open_mode == OPEN_OLD)
-	return close_old(fd);
-    return close_new(fd, 1);
- * \brief Unopen a raster map
- * for writing, the raster map is not created and the temporary file
- * created when the raster map was opened is removed (see \ref
- * Creating_and_Opening_New_Raster_Files). This routine is useful when
- * errors are detected and it is desired to not create the new raster
- * map. While it is true that the raster map will not be created if
- * the module exits without closing the file, the temporary file will
- * not be removed at module exit. GRASS database management will
- * eventually remove the temporary file, but the file can be quite
- * large and will take up disk space until GRASS does remove it. Use
- * this routine as a courtesy to the user.
-int G_unopen_cell(int fd)
-	return -1;
-    else
-	return close_new(fd, 0);
-static int close_old(int fd)
-    int i;
-    /* if G__.auto_mask was only allocated for reading map rows to create
-       non-existant null rows, and not for actuall mask, free G__.mask_row
-       if(G__.auto_mask <=0)
-       G_free (G__.mask_buf);
-       This is obsolete since now the mask_bus is always allocated
-    if (fcb->gdal)
-	G_close_gdal_link(fcb->gdal);
-    for (i = 0; i < NULL_ROWS_INMEM; i++)
-	G_free(fcb->NULL_ROWS[i]);
-    if (fcb->cellhd.compressed)
-	G_free(fcb->row_ptr);
-    G_free(fcb->col_map);
-    G_free(fcb->mapset);
-    G_free(fcb->data);
-    G_free(fcb->name);
-    if (fcb->reclass_flag)
-	G_free_reclass(&fcb->reclass);
-    fcb->open_mode = -1;
-    if (fcb->map_type != CELL_TYPE) {
-	G_quant_free(&fcb->quant);
-	xdr_destroy(&fcb->xdrstream);
-    close(fd);
-    return 1;
-static void write_support_files(int fd)
-    struct History hist;
-    CELL cell_min, cell_max;
-    char path[GPATH_MAX];
-    /* remove color table */
-    G_remove_colors(fcb->name, "");
-    /* create a history file */
-    G_short_history(fcb->name, "raster", &hist);
-    G_write_history(fcb->name, &hist);
-    /* write the range */
-    if (fcb->map_type == CELL_TYPE) {
-	G_write_range(fcb->name, &fcb->range);
-	G__remove_fp_range(fcb->name);
-    /*NOTE: int range for floating point maps is not written out */
-    else {			/* if(fcb->map_type != CELL_TYPE) */
-	G_write_fp_range(fcb->name, &fcb->fp_range);
-	G_construct_default_range(&fcb->range);
-	/* this range will be used to add default rule to quant structure */
-	fcb->cellhd.format = -1;
-    else			/* CELL map */
-	fcb->cellhd.format = fcb->nbytes - 1;
-    /* write header file */
-    G_put_cellhd(fcb->name, &fcb->cellhd);
-    /* if map is floating point write the quant rules, otherwise remove f_quant */
-	/* DEFAULT RANGE QUANT
-	   G_get_fp_range_min_max(&fcb->fp_range, &dcell_min, &dcell_max);
-	   if(!G_is_d_null_value(&dcell_min) && !G_is_d_null_value(&dcell_max))
-	   G_get_range_min_max(&fcb->range, &cell_min, &cell_max);
-	   G_quant_add_rule(&fcb->quant, dcell_min, dcell_max,
-	   cell_min, cell_max);
-	G_quant_round(&fcb->quant);
-	if (G_write_quant(fcb->name, fcb->mapset, &fcb->quant) < 0)
-	    G_warning(_("unable to write quant file!"));
-    else {
-	/* remove cell_misc/name/f_quant */
-	G__file_name_misc(path, "cell_misc", QUANT_FILE, fcb->name,
-			  fcb->mapset);
-	remove(path);
-    /* create empty cats file */
-    if (G_is_c_null_value(&cell_max))
-	cell_max = 0;
-    G_init_cats(cell_max, (char *)NULL, &cats);
-    G_write_cats(fcb->name, &cats);
-    G_free_cats(&cats);
-    /* write the histogram */
-    /* only works for integer maps */
-    if ((fcb->map_type == CELL_TYPE)
-	&& (fcb->want_histogram)) {
-	G_write_histogram_cs(fcb->name, &fcb->statf);
-	G_free_cell_stats(&fcb->statf);
-    else {
-	G_remove_histogram(fcb->name);
-static int close_new_gdal(int fd, int ok)
-    int stat = 1;
-    if (ok) {
-	int cell_fd;
-	G_debug(1, "close %s GDAL", fcb->name);
-	if (fcb->cur_row < fcb->cellhd.rows) {
-	    int row;
-	    G_zero_raster_buf(fcb->data, fcb->map_type);
-	    for (row = fcb->cur_row; row < fcb->cellhd.rows; row++)
-		G_put_raster_row(fd, fcb->data, fcb->map_type);
-	    fcb->data = NULL;
-	/* create path : full null file name */
-	G__make_mapset_element_misc("cell_misc", fcb->name);
-	G__file_name_misc(path, "cell_misc", NULL_FILE, fcb->name,
-			  G_mapset());
-	remove(path);
-	/* write 0-length cell file */
-	G__make_mapset_element("cell");
-	G__file_name(path, "cell", fcb->name, fcb->mapset);
-	cell_fd = creat(path, 0666);
-	close(cell_fd);
-	if (fcb->map_type != CELL_TYPE) {	/* floating point map */
-	    if (write_fp_format(fd) != 0) {
-		G_warning(_("Error writing floating point format file for map %s"),
-			  fcb->name);
-		stat = -1;
-	    /* write 0-length fcell file */
-	    G__make_mapset_element("fcell");
-	    G__file_name(path, "fcell", fcb->name, fcb->mapset);
-	    close(cell_fd);
-	else {
-	    /* remove fcell/name file */
-	    remove(path);
-	    /* remove cell_misc/name/f_format */
-	    G__file_name_misc(path, "cell_misc", FORMAT_FILE, fcb->name,
-			      fcb->mapset);
-	    remove(path);
-	if (G_close_gdal_write_link(fcb->gdal) < 0)
-	    stat = -1;
-    else {
-	remove(fcb->gdal->filename);
-    /* NOW CLOSE THE FILE DESCRIPTOR */
-    close(fd);
-    if (fcb->data != NULL)
-    if (ok)
-	write_support_files(fd);
-    return stat;
-static int close_new(int fd, int ok)
-    int stat;
-    int row, i;
-    const char *CELL_DIR;
-    if (fcb->gdal)
-	return close_new_gdal(fd, ok);
-    if (ok) {
-	switch (fcb->open_mode) {
-	case OPEN_NEW_COMPRESSED:
-	    G_debug(1, "close %s compressed", fcb->name);
-	    break;
-	case OPEN_NEW_UNCOMPRESSED:
-	    G_debug(1, "close %s uncompressed", fcb->name);
-	    break;
-	    fcb->data = NULL;
-			  G_mapset());
-	remove(path);
-	if (fcb->null_cur_row > 0) {
-	    /* if temporary NULL file exists, write it into cell_misc/name/null */
-	    int null_fd;
-	    null_fd = G__open_null_write(fd);
-	    if (null_fd <= 0)
-		return -1;
-	    if (null_fd < 1)
-		return -1;
-	    /* first finish writing null file */
-	    /* write out the rows stored in memory */
-	    for (row = fcb->min_null_row; row < fcb->null_cur_row; row++)
-		G__write_null_bits(null_fd,
-				   fcb->NULL_ROWS[row - fcb->min_null_row],
-				   row, fcb->cellhd.cols, fd);
-	    /* write missing rows */
-	    if (fcb->null_cur_row < fcb->cellhd.rows) {
-		unsigned char *null_work_buf = G__allocate_null_bits(fcb->cellhd.cols);
-		G__init_null_bits(null_work_buf, fcb->cellhd.cols);
-		for (row = fcb->null_cur_row; row < fcb->cellhd.rows; row++)
-		    G__write_null_bits(null_fd, null_work_buf, row,
-				       fcb->cellhd.cols, fd);
-		G_free(null_work_buf);
-	    close(null_fd);
-	    if (rename(fcb->null_temp_name, path)) {
-		G_warning(_("Unable to renae null file '%s'"),
-			  fcb->null_temp_name, path);
-		stat = -1;
-	    else {
-		remove(fcb->null_temp_name);
-	else {
-	    remove(path);
-	}			/* null_cur_row > 0 */
-	if (fcb->open_mode == OPEN_NEW_COMPRESSED) {	/* auto compression */
-	    fcb->row_ptr[fcb->cellhd.rows] = lseek(fd, 0L, SEEK_CUR);
-	    G__write_row_ptrs(fd);
-	    int cell_fd;
-		G_warning(_("Error writing floating point format file for map <%s>"),
-			  fcb->name);
-		stat = -1;
-	    /* now write 0-length cell file */
-	    cell_fd =
-		creat(G__file_name(path, "cell", fcb->name, fcb->mapset),
-		      0666);
-	    close(cell_fd);
-	    CELL_DIR = "fcell";
-	else {
-	    remove(path);
-			      fcb->mapset);
-	    remove(path);
-	    CELL_DIR = "cell";
-	    close(fd);
-    }				/* ok */
-    close(fd);
-    if (fcb->null_temp_name != NULL) {
-	G_free(fcb->null_temp_name);
-	fcb->null_temp_name = NULL;
-    /* if the cell file was written to a temporary file
-     * move this temporary file into the cell file
-     * if the move fails, tell the user, but go ahead and create
-     * the support files
-    stat = 1;
-    if (ok && (fcb->temp_name != NULL)) {
-	G__file_name(path, CELL_DIR, fcb->name, fcb->mapset);
-	remove(path);
-	if (rename(fcb->temp_name, path)) {
-	    G_warning(_("Unable to rename cell file '%s'"),
-		      fcb->temp_name, path);
-	    stat = -1;
-	else {
-	    remove(fcb->temp_name);
-    if (fcb->temp_name != NULL) {
-	G_free(fcb->temp_name);
-    if (ok)
-    return stat;
-/* returns 0 on success, 1 on failure */
-    struct Key_Value *format_kv;
-    int stat;
-	G_warning(_("unable to write f_format file for CELL maps"));
-	return 0;
-    format_kv = G_create_key_value();
-    if (fcb->map_type == FCELL_TYPE)
-	G_set_key_value("type", "float", format_kv);
-    else
-	G_set_key_value("type", "double", format_kv);
-    G_set_key_value("byte_order", "xdr", format_kv);
-	G_set_key_value("lzw_compression_bits", "-1", format_kv);
-    G__file_name_misc(path, "cell_misc", FORMAT_FILE, fcb->name, fcb->mapset);
-    G_write_key_value_file(path, format_kv, &stat);
-    G_free_key_value(format_kv);
-    return stat;
Deleted: grass/trunk/lib/gis/color_compat.c
--- grass/trunk/lib/gis/color_compat.c	2009-06-20 21:39:23 UTC (rev 38002)
+++ grass/trunk/lib/gis/color_compat.c	2009-06-20 22:03:23 UTC (rev 38003)
@@ -1,314 +0,0 @@
- * \file gis/color_compat.c
- * \brief GIS Library - Predefined color tables
- * (C) 2007-2009 Glynn Clements and the GRASS Development Team
- * \author Glynn Clements <glynn at gclements.plus.com>
-#include <grass/gis.h>
- * \brief Make color wave (integer)
- * Generates a color table with 3 sections: red only, green only, and
- * blue only, each increasing from none to full intensity and back
- * down to none. This table is good for continuous data like
- * elevation.
- * \param colors pointer to Colors structure which holds color info
- * \param min minimum value
- * \param max maximum value
-void G_make_wave_colors(struct Colors *colors, CELL min, CELL max)
-    G_make_colors(colors, "wave", min, max);
- * \brief Make color wave (floating-point)
- * elevation.
-void G_make_wave_fp_colors(struct Colors *colors, DCELL min, DCELL max)
-    G_make_fp_colors(colors, "wave", min, max);
- * \brief Create RYG color table (integer)
- * Generates a color table red-yellow-green.
-void G_make_ryg_colors(struct Colors *colors, CELL min, CELL max)
-    G_make_colors(colors, "ryg", min, max);
- * \brief Create RYG color table (floating-point)
-void G_make_ryg_fp_colors(struct Colors *colors, DCELL min, DCELL max)
-    G_make_fp_colors(colors, "ryg", min, max);
- * \brief Make color ramp (integer)
- * blue only, each increasing from none to full intensity. This table
- * is good for continuous data, such as elevation.
-void G_make_ramp_colors(struct Colors *colors, CELL min, CELL max)
-    G_make_colors(colors, "ramp", min, max);
- * \brief Make color ramp (floating-point)
-void G_make_ramp_fp_colors(struct Colors *colors, DCELL min, DCELL max)
-    G_make_fp_colors(colors, "ramp", min, max);
- * \brief Make rainbow colors (integer)
- * Generates a "shifted" rainbow color table - yellow to green to cyan
- * to blue to magenta to red. The color table is based on rainbow
- * colors. (Normal rainbow colors are red, orange, yellow, green,
- * blue, indigo, and violet.) This table is good for continuous data,
- * such as elevation.
-void G_make_rainbow_colors(struct Colors *colors, CELL min, CELL max)
-    G_make_colors(colors, "rainbow", min, max);
- * \brief Make rainbow colors (floating-point)
-void G_make_rainbow_fp_colors(struct Colors *colors, DCELL min, DCELL max)
-    G_make_fp_colors(colors, "rainbow", min, max);
- * \brief Create GYR color table (integer)
- * Generates a color table green-yellow-red.
-void G_make_gyr_colors(struct Colors *colors, CELL min, CELL max)
-    G_make_colors(colors, "gyr", min, max);
- * \brief Create GYR color table (floating-point)
-void G_make_gyr_fp_colors(struct Colors *colors, DCELL min, DCELL max)
-    G_make_fp_colors(colors, "gyr", min, max);
- * \brief Make linear grey scale (integer)
- * Generates a grey scale color table. Each color is a level of grey,
- * increasing from black to white.
-void G_make_grey_scale_colors(struct Colors *colors, CELL min, CELL max)
-    G_make_colors(colors, "grey", min, max);
- * \brief Make linear grey scale (floating-point)
-void G_make_grey_scale_fp_colors(struct Colors *colors, DCELL min, DCELL max)
-    G_make_fp_colors(colors, "grey", min, max);
- * \brief Create BYR color table (integer)
- * Generates a color table blue-yellow-red.
-void G_make_byr_colors(struct Colors *colors, CELL min, CELL max)
-    G_make_colors(colors, "byr", min, max);
- * \brief Create BYR color table (floating-point)
-void G_make_byr_fp_colors(struct Colors *colors, DCELL min, DCELL max)
-    G_make_fp_colors(colors, "byr", min, max);
- * \brief Create BGYR color table (integer)
- * Generates a color table blue-green-yellow-red.
-void G_make_bgyr_colors(struct Colors *colors, CELL min, CELL max)
-    G_make_colors(colors, "bgyr", min, max);
- * \brief Create BGYR color table (floating-point)
-void G_make_bgyr_fp_colors(struct Colors *colors, DCELL min, DCELL max)
-    G_make_fp_colors(colors, "bgyr", min, max);
- * \brief Create BYG color table (integer)
- * Generates a color table blue-yellow-green.
-void G_make_byg_colors(struct Colors *colors, CELL min, CELL max)
-    G_make_colors(colors, "byg", min, max);
- * \brief Create BYG color table (floating-point)
-void G_make_byg_fp_colors(struct Colors *colors, DCELL min, DCELL max)
-    G_make_fp_colors(colors, "byg", min, max);
- * \brief Make aspect colors (integer)
- * Generates a color table for aspect data.
-void G_make_aspect_colors(struct Colors *colors, CELL min, CELL max)
-    G_make_colors(colors, "aspect", min, max);
- * \brief Make aspect colors (floating-point)
-void G_make_aspect_fp_colors(struct Colors *colors, DCELL min, DCELL max)
-    G_make_fp_colors(colors, "aspect", min, max);
Deleted: grass/trunk/lib/gis/color_free.c
--- grass/trunk/lib/gis/color_free.c	2009-06-20 21:39:23 UTC (rev 38002)
+++ grass/trunk/lib/gis/color_free.c	2009-06-20 22:03:23 UTC (rev 38003)
@@ -1,103 +0,0 @@
- * \file gis/color_free.c
- * \brief GIS Library - Free Colors structure
- * (C) 2001-2009 by the GRASS Development Team
- * This program is free software under the GNU General Public License
- * (>=v2). Read the file COPYING that comes with GRASS for details.
- * \author Original author CERL
- * \brief Free color structure memory
- * The dynamically allocated memory associated with the <i>colors</i>
- * structure is freed.
- * <b>Note:</b> This routine may be used after G_read_colors() as well
- * as after G_init_colors().
-void G_free_colors(struct Colors *colors)
-    G__color_reset(colors);
-    G_init_colors(colors);
-  \brief Free color rules structure
-  Note: Only for internal use.
-  \param cp pointer to _Color_Info structure
-void G__color_free_rules(struct _Color_Info_ *cp)
-    struct _Color_Rule_ *rule, *next;
-    for (rule = cp->rules; rule; rule = next) {
-	next = rule->next;
-	G_free(rule);
-    cp->rules = NULL;
-void G__color_free_lookup(struct _Color_Info_ *cp)
-    if (cp->lookup.active) {
-	G_free(cp->lookup.red);
-	G_free(cp->lookup.blu);
-	G_free(cp->lookup.grn);
-	G_free(cp->lookup.set);
-	cp->lookup.active = 0;
-void G__color_free_fp_lookup(struct _Color_Info_ *cp)
-    if (cp->fp_lookup.active) {
-	G_free(cp->fp_lookup.vals);
-	G_free(cp->fp_lookup.rules);
-	cp->fp_lookup.active = 0;
-	cp->fp_lookup.nalloc = 0;
-  \brief Reset colors structure
-  This routine should NOT init the colors.
-  \param colors pointer to Colors structure
-void G__color_reset(struct Colors *colors)
-    G__color_free_lookup(&colors->fixed);
-    G__color_free_lookup(&colors->modular);
-    G__color_free_rules(&colors->fixed);
-    G__color_free_rules(&colors->modular);
-    colors->version = 0;
Deleted: grass/trunk/lib/gis/color_get.c
--- grass/trunk/lib/gis/color_get.c	2009-06-20 21:39:23 UTC (rev 38002)
+++ grass/trunk/lib/gis/color_get.c	2009-06-20 22:03:23 UTC (rev 38003)
@@ -1,193 +0,0 @@
- * \file gis/color_get.c
- * \brief GIS Library - Get colors from a raster map.
- * \brief Get a category color.
- * \todo To be removed, replaced by G_get_raster_color().
- * The <i>red, green</i>, and <i>blue</i> intensities for the color
- * associated with category <i>n</i> are extracted from the
- * <i>colors</i> structure. The intensities will be in the range 0 ­-
- * 255. Also works for null cells.
- * \param n cell to get color from
- * \param[out] red red value
- * \param[out] grn green value
- * \param[out] blu blue value
- * \return 1 if color is set
- * \return 0 if color is not set
-int G_get_color(CELL n, int *red, int *grn, int *blu, struct Colors *colors)
-    CELL cat;
-    unsigned char r, g, b, set;
-    cat = n;
-    G_lookup_colors(&cat, &r, &g, &b, &set, 1, colors);
-    *red = (int)r;
-    *grn = (int)g;
-    *blu = (int)b;
-    return (int)set;
- * \brief Gets color from raster map
- * Looks up the rgb colors for <i>rast</i> in the color table
- * <i>colors</i>.
- * \param rast raster cell value
- * \param map_type map type (CELL, FCELL, DCELL)
-int G_get_raster_color(const void *rast,
-		       int *red, int *grn, int *blu,
-		       struct Colors *colors, RASTER_MAP_TYPE map_type)
-    G_lookup_raster_colors(rast, &r, &g, &b, &set, 1, colors, map_type);
-    *red = (int)r;
-    *grn = (int)g;
-    *blu = (int)b;
-    return (int)set;
- * \brief Gets color from raster map (CELL)
- * <i>colors</i>.
-int G_get_c_raster_color(const CELL * rast,
-			 int *red, int *grn, int *blu, struct Colors *colors)
-    return G_get_raster_color(rast, red, grn, blu, colors, CELL_TYPE);
- * \brief Gets color from raster map (FCELL)
- * <i>colors</i>.
-int G_get_f_raster_color(const FCELL * rast,
-    return G_get_raster_color(rast, red, grn, blu, colors, FCELL_TYPE);
- * \brief Gets color from raster map (DCELL)
- * <i>colors</i>.
-int G_get_d_raster_color(const DCELL * rast,
-    return G_get_raster_color(rast, red, grn, blu, colors, DCELL_TYPE);
- * \brief Gets color for null value.
- * Puts the red, green, and blue components of <i>colors</i> for the
- * NULL-value into <i>red, grn, and blu</i>.
-void G_get_null_value_color(int *red, int *grn, int *blu,
-			   const struct Colors *colors)
-    if (colors->null_set) {
-	*red = (int)colors->null_red;
-	*grn = (int)colors->null_grn;
-	*blu = (int)colors->null_blu;
-    else if (colors->undef_set) {
-	*red = (int)colors->undef_red;
-	*grn = (int)colors->undef_grn;
-	*blu = (int)colors->undef_blu;
-    else
-	*red = *blu = *grn = 255;	/* white */
- * \brief Gets default color.
- * Puts the red, green, and blue components of the <tt>"default"</tt>
- * color into <i>red, grn, and blu</i>.
-void G_get_default_color(int *red, int *grn, int *blu,
-    if (colors->undef_set) {
-    else
Deleted: grass/trunk/lib/gis/color_hist.c
--- grass/trunk/lib/gis/color_hist.c	2009-06-20 21:39:23 UTC (rev 38002)
+++ grass/trunk/lib/gis/color_hist.c	2009-06-20 22:03:23 UTC (rev 38003)
@@ -1,155 +0,0 @@
- * \file gis/color_hist.c
- * \brief GIS Library - histogram grey scale colors
-#include <math.h>
- * \brief Make histogram-stretched grey colors
- * Generates a histogram contrast-stretched grey scale color table
- * that goes from the, histogram information in the Cell_stats
- * structure (see \ref Raster_Histograms).
- * Color range is 0-255.
- * \param stalf pointer to Cell_stats structure which holds cell stats info
-void G_make_histogram_eq_colors(struct Colors *colors,
-				struct Cell_stats *statf)
-    CELL prev = 0, cat;
-    double span, sum;
-    int first;
-    int x, grey;
-    int R, G, B;
-    G_str_to_color(DEFAULT_BG_COLOR, &R, &G, &B);
-    G_set_null_value_color(R, G, B, colors);
-    total = 0;
-	if (count > 0)
-	    total += count;
-    if (total <= 0)
-	return;
-    span = total / 256.0;
-    first = 1;
-    grey = 0;
-    sum = 0.0;
-	if (count <= 0)
-	    continue;
-	if (x < 0)
-	    x = 0;
-	else if (x > 255)
-	    x = 255;
-	sum += count;
-	if (first) {
-	    prev = cat;
-	    grey = x;
-	    first = 0;
-	else if (grey != x) {
-	    G_add_color_rule(prev, grey, grey, grey, cat - 1, grey, grey,
-			     grey, colors);
-	    grey = x;
-	    prev = cat;
-    if (!first) {
-	G_add_color_rule(prev, grey, grey, grey, cat, grey, grey, grey,
-			 colors);
-  \brief Generates histogram with normalized log transformed grey scale.
-  Generates histogram with normalized log transformed grey scale from
-  cell stats structure info. Color range is 0-255.
-  \param colors pointer to Colors structure which holds color info
-  \param stalf pointer to Cell_stats structure which holds cell stats info
-  \param min minimum value
-  \param max maximum value
-void G_make_histogram_log_colors(struct Colors *colors,
-				 struct Cell_stats *statf, int min, int max)
-    double lmin, lmax;
-    int first;
-    int x, grey;
-    int R, G, B;
-    total = 0;
-	if (count > 0)
-	    total += count;
-    if (total <= 0)
-	return;
-    first = 1;
-    grey = 0;
-    lmin = log(min);
-    lmax = log(max);
-	if (count <= 0)
-	    continue;
-	/* log transform normalized */
-	x = (int)(255 * (log(cat) - lmin) / (lmax - lmin));
-	if (x < 0)
-	    x = 0;
-	else if (x > 255)
-	    x = 255;
-	if (first) {
-	    prev = cat;
-	    grey = x;
-	    first = 0;
-			     grey, colors);
-	    grey = x;
-	    prev = cat;
-    if (!first) {
-			 colors);
Deleted: grass/trunk/lib/gis/color_init.c
--- grass/trunk/lib/gis/color_init.c	2009-06-20 21:39:23 UTC (rev 38002)
+++ grass/trunk/lib/gis/color_init.c	2009-06-20 22:03:23 UTC (rev 38003)
@@ -1,49 +0,0 @@
- * \file gis/color_init.c
- * \brief GIS Library - Initialize Colors structure
- * \brief Initialize color structure
- * The <i>colors</i> structure is initialized for subsequent calls
- * to G_add_color_rule() and G_set_color().
-void G_init_colors(struct Colors *colors)
-    colors->null_set = 0;
-    colors->undef_set = 0;
-    colors->shift = 0.0;
-    colors->invert = 0;
-    colors->cmin = 0;
-    colors->is_float = 0;
-    colors->cmax = -1;
-    colors->fixed.min = 0;
-    colors->fixed.max = -1;
-    colors->fixed.rules = NULL;
-    colors->fixed.n_rules = 0;
-    colors->fixed.lookup.active = 0;
-    colors->fixed.fp_lookup.active = 0;
-    colors->fixed.fp_lookup.nalloc = 0;
-    colors->modular.min = 0;
-    colors->modular.max = -1;
-    colors->modular.rules = NULL;
-    colors->modular.n_rules = 0;
-    colors->modular.lookup.active = 0;
-    colors->modular.fp_lookup.active = 0;
-    colors->modular.fp_lookup.nalloc = 0;
-    colors->organizing = 0;
Deleted: grass/trunk/lib/gis/color_insrt.c
--- grass/trunk/lib/gis/color_insrt.c	2009-06-20 21:39:23 UTC (rev 38002)
+++ grass/trunk/lib/gis/color_insrt.c	2009-06-20 22:03:23 UTC (rev 38003)
@@ -1,108 +0,0 @@
-/* This routine is public only because source is in different files.
- * It should NEVER be called directly.
- * It is used by G_add_color_rule() and G__read_old_colors().
- * These routines know when it is approriate to call this routine.
-#define umalloc(n) (unsigned char *) G_malloc((size_t)n)
-#define urealloc(s,n) (unsigned char *) G_realloc(s,(size_t)n)
-#define LIMIT(x) if (x < 0) x = 0; else if (x > 255) x = 255;
-int G__insert_color_into_lookup(CELL cat,
-				int red, int grn, int blu,
-				struct _Color_Info_ *cp)
-    long nalloc;
-    long i;
-    long newlen, curlen, gap;
-    LIMIT(red);
-    LIMIT(grn);
-    LIMIT(blu);
-    /* first color? */
-    if (!cp->lookup.active) {
-	cp->lookup.active = 1;
-	cp->lookup.nalloc = 256;
-	cp->lookup.red = umalloc(cp->lookup.nalloc);
-	cp->lookup.grn = umalloc(cp->lookup.nalloc);
-	cp->lookup.blu = umalloc(cp->lookup.nalloc);
-	cp->lookup.set = umalloc(cp->lookup.nalloc);
-	cp->max = cp->min = cat;
-    /* extend the color table? */
-    else if (cat > cp->max) {
-	curlen = cp->max - cp->min + 1;
-	newlen = cat - cp->min + 1;
-	nalloc = newlen;
-	if (nalloc != (int)nalloc)	/* check for int overflow */
-	    return -1;
-	if (nalloc > cp->lookup.nalloc) {
-	    while (cp->lookup.nalloc < nalloc)
-		cp->lookup.nalloc += 256;
-	    nalloc = cp->lookup.nalloc;
-	    cp->lookup.red = urealloc((char *)cp->lookup.red, nalloc);
-	    cp->lookup.grn = urealloc((char *)cp->lookup.grn, nalloc);
-	    cp->lookup.blu = urealloc((char *)cp->lookup.blu, nalloc);
-	    cp->lookup.set = urealloc((char *)cp->lookup.set, nalloc);
-	/* fill in gap with white */
-	for (i = curlen; i < newlen; i++) {
-	    cp->lookup.red[i] = 255;
-	    cp->lookup.grn[i] = 255;
-	    cp->lookup.blu[i] = 255;
-	    cp->lookup.set[i] = 0;
-	cp->max = cat;
-    else if (cat < cp->min) {
-	newlen = cp->max - cat + 1;
-	gap = newlen - curlen;
-	nalloc = newlen;
-	    return -1;
-	/* shift the table to make room in front */
-	for (i = 1; i <= curlen; i++) {
-	    cp->lookup.red[newlen - i] = cp->lookup.red[curlen - i];
-	    cp->lookup.grn[newlen - i] = cp->lookup.grn[curlen - i];
-	    cp->lookup.blu[newlen - i] = cp->lookup.blu[curlen - i];
-	    cp->lookup.set[newlen - i] = cp->lookup.set[curlen - i];
-	for (i = 1; i < gap; i++) {
-	cp->min = cat;
-    /* set the color! */
-    i = cat - cp->min;
-    cp->lookup.red[i] = red;
-    cp->lookup.grn[i] = grn;
-    cp->lookup.blu[i] = blu;
-    cp->lookup.set[i] = 1;
-    return 1;
Deleted: grass/trunk/lib/gis/color_invrt.c
--- grass/trunk/lib/gis/color_invrt.c	2009-06-20 21:39:23 UTC (rev 38002)
+++ grass/trunk/lib/gis/color_invrt.c	2009-06-20 22:03:23 UTC (rev 38003)
@@ -1,6 +0,0 @@
-void G_invert_colors(struct Colors *colors)
-    colors->invert = !colors->invert;
Deleted: grass/trunk/lib/gis/color_look.c
--- grass/trunk/lib/gis/color_look.c	2009-06-20 21:39:23 UTC (rev 38002)
+++ grass/trunk/lib/gis/color_look.c	2009-06-20 22:03:23 UTC (rev 38003)
@@ -1,475 +0,0 @@
- * \file gis/color_lookup.c
- * \brief GIS Library - Lookup array of colors
- * for details.
-#include <math.h>
- * \brief Lookup an array of colors
- * \todo To be removed, replaced by G_lookup_c_raster_colors().
- * Extracts colors for an array of <i>cell</i> values. The colors
- * for the <i>n</i> values in the <i>cell</i> array are stored in
- * the <i>red, green</i>, and <i>blue</i> arrays. The values in the
- * <i>set</i> array will indicate if the corresponding <i>cell</i>
- * value has a color or not (1 means it does, 0 means it does not).
- * The programmer must allocate the <i>red, green, blue</i>, and
- * <b>set</b> arrays to be at least dimension <i>n</i>.
- * <b>Note:</b> The <i>red, green</i>, and <i>blue</i> intensities
- * will be in the range 0 -­ 255.
- * Modified to return a color for NULL-values.
- * \param cell raster cell value
- * \param set array which indicates if color is set or not
-void G_lookup_colors(const CELL * cell,
-		     unsigned char *red, unsigned char *grn,
-		     unsigned char *blu, unsigned char *set, int n,
-		     struct Colors *colors)
-    G_lookup_c_raster_colors(cell, red, grn, blu, set, n, colors);
-void G_lookup_c_raster_colors(const CELL * cell,
-    G__organize_colors(colors);	/* make sure the lookup tables are in place */
-    G_zero((char *)set, n * sizeof(unsigned char));
-    /* first lookup the fixed colors */
-    G__lookup_colors((void *)cell, red, grn, blu, set, n, colors, 0, 0,
-		     CELL_TYPE);
-    /* now lookup unset colors using the modular rules */
-    G__lookup_colors((void *)cell, red, grn, blu, set, n, colors, 1, 0,
-		     CELL_TYPE);
- * - If the <em>map_type</em> is CELL_TYPE, calls G_lookup_colors()
- * - If the <em>map_type</em> is FCELL_TYPE, calls G_lookup_f_raster_colors()
- * - If the <em>map_type</em> is DCELL_TYPE, calls G_lookup_d_raster_colors()
- * \param raster raster cell value
- * \param map_type raster type (CELL, FCELL, DCELL)
-void G_lookup_raster_colors(const void *raster,
-    /* in case of float color rules, fp_lookup table is created */
-    G__lookup_colors(raster, red, grn, blu, set, n, colors, 0, 0, map_type);
-    G__lookup_colors(raster, red, grn, blu, set, n, colors, 1, 0, map_type);
- * \brief Lookup an array of colors (FCELL)
- * Converts the <em>n</em> floating-point values in the <em>fcell</em>
- * array to their <em>r,g,b</em> color components. Embedded
- * NULL-values are handled properly as well.
- * \param fcell raster cell value
-void G_lookup_f_raster_colors(const FCELL * fcell, unsigned char *red,
-			      unsigned char *grn, unsigned char *blu,
-			      unsigned char *set, int n, struct Colors *colors)
-    G__lookup_colors((void *)fcell, red, grn, blu, set, n, colors, 0, 0,
-		     FCELL_TYPE);
-    G__lookup_colors((void *)fcell, red, grn, blu, set, n, colors, 1, 0,
-		     FCELL_TYPE);
- * \brief Lookup an array of colors (DCELL)
- * Converts the <em>n</em> double-precision values in the
- * <em>dcell</em> array to their <em>r,g,b</em> color
- * components. Embedded NULL-values are handled properly as well.
- * \param dcell raster cell value
-void G_lookup_d_raster_colors(const DCELL * dcell, unsigned char *red,
-    G__lookup_colors((void *)dcell, red, grn, blu, set, n, colors, 0, 0,
-		     DCELL_TYPE);
-    G__lookup_colors((void *)dcell, red, grn, blu, set, n, colors, 1, 0,
-		     DCELL_TYPE);
-static int less_or_equal(double x, double y)
-    if (x <= y)
-	return 1;
-    else
-	return 0;
-static int less(double x, double y)
-    if (x < y)
-	return 1;
-    else
-	return 0;
- * \param mod
- * \param rules_only
- * \param data_type raster type (CELL, FCELL, DCELL)
-void G__lookup_colors(const void *raster, unsigned char *red,
-		      unsigned char *set, int n, struct Colors *colors,
-		      int mod, int rules_only, RASTER_MAP_TYPE data_type)
-    struct _Color_Info_ *cp;
-    struct _Color_Rule_ *rule;
-    DCELL dmin, dmax, val, dmod = 0L, shift;
-    CELL cat, min, max;
-    const void *ptr, *last_ptr = NULL;
-    int invert;
-    int found, r, g, b;
-    int cell_type;
-    int lookup, max_ind, min_ind, try;
-    int (*lower) ();
-    if (mod)
-	cp = &colors->modular;
-    else
-	cp = &colors->fixed;
-    /* rules_only will be true only when called by G__organize_colors()
-     * when building the integer lookup talbes from the rules,
-     * so do not shift, invert, use lookup table or modulate cats.
-     * these operations will happen when lookup is called by user code
-    /* we want min, max for cp, not min, max overall */
-    dmin = cp->min;
-    dmax = cp->max;
-    min = (CELL) dmin;
-    max = (CELL) dmax + 1;
-    cell_type = (data_type == CELL_TYPE);
-    if (rules_only) {
-	shift = invert = lookup = mod = 0;
-    else {
-	if (mod) {
-	    dmod = dmax - dmin;
-	    /* for integers color table we make a gap of 1 in order
-	       to make the same colors as before */
-	    if (cell_type)
-		dmod += 1;
-	shift = colors->shift;
-	invert = colors->invert;
-	lookup = cp->lookup.active;
-    ptr = raster;
-    for (; n-- > 0;
-	 ptr =
-	 G_incr_void_ptr(ptr, G_raster_size(data_type)), red++, grn++, blu++,
-	 *set++ = found) {
-	/* if the cell is the same as last one, use the prev color values */
-	if (ptr != raster && G_raster_cmp(ptr, last_ptr, data_type) == 0) {
-	    *red = *(red - 1);
-	    *blu = *(blu - 1);
-	    *grn = *(grn - 1);
-	    found = *(set - 1);
-	    last_ptr = ptr;
-	    continue;
-	val = G_get_raster_value_d(ptr, data_type);
-	/* DEBUG fprintf (stderr, "val: %.4lf\n", val); */
-	last_ptr = ptr;
-	if (*set) {
-	    found = 1;
-	    continue;
-	if (G_is_null_value(ptr, data_type)) {
-	    /* returns integers, not unsigned chars */
-	    G_get_null_value_color(&r, &g, &b, colors);
-	    *red = r;
-	    *grn = g;
-	    *blu = b;
-	    found = 1;
-	    continue;
-	if (shift && val >= dmin && val <= dmax) {
-	    val += shift;
-	    while (val < dmin)
-		val += dmax - dmin + 1;
-	    while (val > dmax)
-		val -= dmax - dmin + 1;
-	/* invert non-null data around midpoint of range [min:max] */
-	if (invert)
-	    val = dmin + dmax - val;
-	if (mod) {
-	    if (dmod > 0) {
-		val -= dmin;
-		while (val < 0)
-		    val += dmod;
-		val = val - dmod * floor(val / dmod);
-		val += dmin;
-	    else
-		val = dmin;
-	cat = (CELL) val;
-	found = 0;
-	/* for non-null integers  try to look them up in lookup table */
-	/* note: lookup table exists only for integer maps, and we also must
-	   check if val is really integer */
-	if (lookup && ((double)cat - val == 0.)) {
-	    if (cat >= min && cat <= max) {
-		cat -= min;
-		if (cp->lookup.set[cat]) {
-		    *red = cp->lookup.red[cat];
-		    *grn = cp->lookup.grn[cat];
-		    *blu = cp->lookup.blu[cat];
-		    found = 1;
-		    /*DEBUG
-		       fprintf (stderr, "lookup %d %.2lf %d %d %d\n\n", cat, val, *red, *grn, *blu);
-	if (found)
-	    continue;
-	/* if floating point lookup table is active, look up in there */
-	    try = (cp->fp_lookup.nalloc - 1) / 2;
-	    min_ind = 0;
-	    max_ind = cp->fp_lookup.nalloc - 2;
-	    while (1) {
-		/* when the rule for the interval is NULL, we exclude the end points.
-		   when it exists, we include the end-points */
-		if (cp->fp_lookup.rules[try])
-		    lower = less;
-		else
-		    lower = less_or_equal;
-		/* DEBUG
-		   fprintf (stderr, "%d %d %d %lf %lf %lf\n", min_ind, try, max_ind,
-		   cp->fp_lookup.vals[try-1],
-		   val,
-		   cp->fp_lookup.vals[try]);
-		if (lower(cp->fp_lookup.vals[try + 1], val)) {	/* recurse to the second half */
-		    min_ind = try + 1;
-		    /* must be still < nalloc-1, since number is within the range */
-		    try = (max_ind + min_ind) / 2;
-		    if (min_ind > max_ind) {
-			rule = NULL;
-			break;
-		    continue;
-		if (lower(val, cp->fp_lookup.vals[try])) {	/* recurse to the second half */
-		    max_ind = try - 1;
-		    /* must be still >= 0, since number is within the range */
-		    if (max_ind < min_ind) {
-			rule = NULL;
-			break;
-		    continue;
-		rule = cp->fp_lookup.rules[try];
-		break;
-	else {
-	    /* find the [low:high] rule that applies */
-	    for (rule = cp->rules; rule; rule = rule->next) {
-		/* DEBUG
-		   fprintf (stderr, "%.2lf %.2lf %.2lf\n",
-		   val, rule->low.value, rule->high.value);
-		if (rule->low.value <= val && val <= rule->high.value)
-		    break;
-	/* if found, perform linear interpolation from low to high.
-	 * else set colors to colors->undef or white if undef not set
-	if (rule) {
-	    G__interpolate_color_rule(val, red, grn, blu, rule);
-	    found = 1;
-	if (!found) {
-	    /* otherwise use default color */
-	    G_get_default_color(&r, &g, &b, colors);
-	    *red = r;
-	    *grn = g;
-	    *blu = b;
-	/* DEBUG
-	   if (rule)
-	   fprintf (stderr, "%.2lf %d %d %d   %.2lf %d %d %d \n", rule->low.value , (int)rule->low.red, (int)rule->low.grn, (int)rule->low.blu, rule->high.value, (int)rule->high.red, (int)rule->high.grn, (int)rule->high.blu);
-	   fprintf (stderr, "rule found %d %.2lf %d %d %d\n\n", cat, val, *red, *grn, *blu);
-  \brief Interpolate color rules
-  \param val raster cell value
-  \param[out] red red value
-  \param[out] grn green value
-  \param[out] blu blue value
-  \param rule pointer to _Color_Rule which holds color rules info
-void G__interpolate_color_rule(DCELL val, unsigned char *red,
-			       const struct _Color_Rule_ *rule)
-    DCELL delta;
-    if ((delta = rule->high.value - rule->low.value)) {
-	val -= rule->low.value;
-	*red =
-	    (int)(val * (double)((int)rule->high.red - (int)rule->low.red) /
-		  delta)
-	    + (int)rule->low.red;
-	*grn =
-	    (int)(val * (double)((int)rule->high.grn - (int)rule->low.grn) /
-		  delta)
-	    + (int)rule->low.grn;
-	*blu =
-	    (int)(val * (double)((int)rule->high.blu - (int)rule->low.blu) /
-		  delta)
-	    + (int)rule->low.blu;
-    else {
-	*red = rule->low.red;
-	*grn = rule->low.grn;
-	*blu = rule->low.blu;
Deleted: grass/trunk/lib/gis/color_org.c
--- grass/trunk/lib/gis/color_org.c	2009-06-20 21:39:23 UTC (rev 38002)
+++ grass/trunk/lib/gis/color_org.c	2009-06-20 22:03:23 UTC (rev 38003)
@@ -1,145 +0,0 @@
-#include <stdlib.h>
-#define LOOKUP_COLORS 2048
-static void organize_lookup(struct Colors *, int);
-static int organize_fp_lookup(struct Colors *, int);
-static int double_comp(const void *, const void *);
-void G__organize_colors(struct Colors *colors)
-    /* don't do anything if called recursively */
-    if (!colors->organizing) {
-	colors->organizing = 1;
-	organize_lookup(colors, 0);
-	organize_lookup(colors, 1);
-	organize_fp_lookup(colors, 0);
-	organize_fp_lookup(colors, 1);
-static int organize_fp_lookup(struct Colors *colors, int mod)
-    int i;
-    DCELL val;
-    if (mod)
-    else
-    /* if one of the lookup tables exist, don't do anything */
-    if (cp->lookup.active || cp->fp_lookup.active)
-	return 1;
-    if (cp->n_rules == 0)
-	return 1;
-    cp->fp_lookup.vals = (DCELL *)
-	G_calloc(cp->n_rules * 2, sizeof(DCELL));
-    /* 2 endpoints for each rule */
-    cp->fp_lookup.rules = (struct _Color_Rule_ **)
-	G_calloc(cp->n_rules * 2, sizeof(struct _Color_Rule_ *));
-    /* get the list of DCELL values from set of all lows and highs
-       of all rules */
-    /* NOTE: if low==high in a rule, the value appears twice in a list
-       but if low==high of the previous, rule the value appears only once */
-    i = 0;
-    /* go through the list of rules from end to beginning,
-       because rules are sored in reverse order of reading,
-       and we want to read the in correct order, to ignore
-       the same values in the end of rule and beginning of next rule */
-    /* first go to the last rules */
-    for (rule = cp->rules; rule->next; rule = rule->next) ;
-    /* now traverse from the last to the first rule */
-    for (; rule; rule = rule->prev) {
-	/* check if the min is the same as previous maximum */
-	if (i == 0 || rule->low.value != cp->fp_lookup.vals[i - 1])
-	    cp->fp_lookup.vals[i++] = rule->low.value;
-	cp->fp_lookup.vals[i++] = rule->high.value;
-    cp->fp_lookup.nalloc = i;
-    /* now sort the values */
-    qsort((char *)cp->fp_lookup.vals, cp->fp_lookup.nalloc,
-	  sizeof(DCELL), &double_comp);
-    /* now find the rule to apply inbetween each 2 values in a list */
-    for (i = 0; i < cp->fp_lookup.nalloc - 1; i++) {
-	val = (cp->fp_lookup.vals[i] + cp->fp_lookup.vals[i + 1]) / 2.;
-	/* fprintf (stderr, "%lf %lf ", cp->fp_lookup.vals[i], cp->fp_lookup.vals[i+1]); */
-		break;
-	/* if(rule) fprintf (stderr, "%d %lf %lf %d\n", i, rule->low.value, rule->high.value, rule);
-	   else fprintf (stderr, "null\n");
-	cp->fp_lookup.rules[i] = rule;
-    cp->fp_lookup.active = 1;
-    return 0;
-static void organize_lookup(struct Colors *colors, int mod)
-    int i, n;
-    CELL x;
-    CELL cat[LOOKUP_COLORS];
-    /* don't do anything if the color structure is float */
-    if (colors->is_float)
-	return;
-    if (mod)
-    else
-	return;
-    n = (CELL) cp->max - (CELL) cp->min + 1;
-    if (n >= LOOKUP_COLORS || n <= 0)
-	return;
-    x = (CELL) cp->min;
-    for (i = 0; i < n; i++)
-	cat[i] = x++;;
-    cp->lookup.nalloc = n;
-    cp->lookup.red = (unsigned char *)G_malloc(n);
-    cp->lookup.grn = (unsigned char *)G_malloc(n);
-    cp->lookup.blu = (unsigned char *)G_malloc(n);
-    cp->lookup.set = (unsigned char *)G_malloc(n);
-    G_zero(cp->lookup.set, n * sizeof(unsigned char));
-    G__lookup_colors((void *)cat,
-		     cp->lookup.red, cp->lookup.grn, cp->lookup.blu,
-		     cp->lookup.set, n, colors, mod, 1, CELL_TYPE);
-static int double_comp(const void *xx, const void *yy)
-    const DCELL *x = xx, *y = yy;
-    if (*x < *y)
-	return -1;
-    else if (*x == *y)
-	return 0;
-    else
-	return 1;
Deleted: grass/trunk/lib/gis/color_rand.c
--- grass/trunk/lib/gis/color_rand.c	2009-06-20 21:39:23 UTC (rev 38002)
+++ grass/trunk/lib/gis/color_rand.c	2009-06-20 22:03:23 UTC (rev 38003)
@@ -1,47 +0,0 @@
-#include <time.h>		/*  For time()  */
-#include <stdio.h>		/*  For NULL */
-#include <stdlib.h>		/*  For rand() and srand() */
-#include <grass/glocale.h>
-#define MAX_COLORS 1024
-#define DEVIATION 128
- * \brief make random colors
- * Generates random colors. Good as a first pass at a
- * color table for nominal data.
- *  \param colors
- *  \param min
- *  \param max
- *  \return
-void G_make_random_colors(struct Colors *colors, CELL min, CELL max)
-    unsigned char red, grn, blu;
-    int count;
-    CELL n;
-    if (min > max)
-	G_fatal_error(_("G_make_random_colors: min (%d) > max (%d)"),
-		      min, max);
-    srand(time(NULL));
-    count = MAX_COLORS - DEVIATION + rand() % DEVIATION;
-    if (count > max - min + 1)
-	count = max - min + 1;
-    for (n = 1; n <= count; n++) {
-	red = rand() & 0377;
-	grn = rand() & 0377;
-	blu = rand() & 0377;
-	G_add_modular_color_rule(n, red, grn, blu, n, red, grn, blu, colors);
-    G_set_color_range(min, max, colors);
Deleted: grass/trunk/lib/gis/color_range.c
--- grass/trunk/lib/gis/color_range.c	2009-06-20 21:39:23 UTC (rev 38002)
+++ grass/trunk/lib/gis/color_range.c	2009-06-20 22:03:23 UTC (rev 38003)
@@ -1,93 +0,0 @@
- * \file gis/color_range.c
- * \brief GIS Library - Color range functions.
-#include <math.h>
-  \brief Set color range (CELL version)
-  \todo Rename to G_set_c_color_range() ?
-  \param min,max minimum and maximum value
-void G_set_color_range(CELL min, CELL max, struct Colors *colors)
-    if (min < max) {
-	colors->cmin = (DCELL) min;
-	colors->cmax = (DCELL) max;
-    else {
-	colors->cmin = (DCELL) max;
-	colors->cmax = (DCELL) min;
-  \brief Set color range (DCELL version)
-void G_set_d_color_range(DCELL min, DCELL max, struct Colors *colors)
-    if (min < max) {
-	colors->cmin = min;
-	colors->cmax = max;
-    else {
-	colors->cmin = max;
-	colors->cmax = min;
-  \brief Get color range values (CELL)
-  \todo Rename to G_get_c_color_range() ?
-  Returns min and max category in the range or huge numbers if the
-  color table is defined on floating cell values and not on
-  categories.
-  \param[out] min,max minimum and maximum value
-void G_get_color_range(CELL * min, CELL * max, const struct Colors *colors)
-    if (!colors->is_float) {
-	*min = (CELL) floor(colors->cmin);
-	*max = (CELL) ceil(colors->cmax);
-    else {
-	*min = -255 * 255 * 255;
-	*max = 255 * 255 * 255;
-  \brief Get color range values (DELL)
-  categories.
-void G_get_d_color_range(DCELL * min, DCELL * max, const struct Colors *colors)
-    *min = colors->cmin;
-    *max = colors->cmax;
Deleted: grass/trunk/lib/gis/color_read.c
--- grass/trunk/lib/gis/color_read.c	2009-06-20 21:39:23 UTC (rev 38002)
+++ grass/trunk/lib/gis/color_read.c	2009-06-20 22:03:23 UTC (rev 38003)
@@ -1,389 +0,0 @@
- * \file gis/color_read.c
- * \brief GIS Library - Read color table of raster map
- * for details.
-#include <string.h>
-static int read_colors(const char *, const char *, const char *,
-		       struct Colors *);
-static int read_new_colors(FILE *, struct Colors *);
-static int read_old_colors(FILE *, struct Colors *);
- * \brief Read raster map layer color table
- * The color table for the raster map <i>name</i> in the specified
- * <i>mapset</i> is read into the <i>colors</i> structure. If the data
- * layer has no color table, a default color table is generated and 0
- * is returned. If there is an error reading the color table, a
- * diagnostic message is printed and -1 is returned. If the color
- * table is read ok, 1 is returned.
- * This routine reads the rules from the color file. If the input
- * raster map is is a floating-point map it calls
- * G_mark_colors_as_fp().
- *  Note: If a secondary color file for map name <i>name</i> exists in
- *  the current project, that color file is read.  This allows the
- *  user to define their own color lookup tables for cell maps found
- *  in other mapsets.
- *  Warning message is printed if the color file is
- *  missing or invalid.
- * \param name map name
- * \param mapset mapset name
- * \param[out] colors pointer to Colors structure
- * \return -1 on error
- * \return 0 if missing, but default colors generated
- * \return 1 on success
-int G_read_colors(const char *name, const char *mapset, struct Colors *colors)
-    int fp;
-    char buf[GNAME_MAX];
-    char *err;
-    char xname[GNAME_MAX];
-    struct Range range;
-    struct FPRange drange;
-    CELL min, max;
-    DCELL dmin, dmax;
-    fp = G_raster_map_is_fp(name, mapset);
-    strcpy(xname, name);
-    mapset = G_find_cell(xname, mapset);
-    name = xname;
-    if (fp)
-	G_mark_colors_as_fp(colors);
-    /* first look for secondary color table in current mapset */
-    sprintf(buf, "colr2/%s", mapset);
-    if (read_colors(buf, name, G_mapset(), colors) >= 0)
-	return 1;
-    /* now look for the regular color table */
-    switch (read_colors("colr", name, mapset, colors)) {
-    case -2:
-	if (!fp) {
-	    if (G_read_range(name, mapset, &range) >= 0) {
-		G_get_range_min_max(&range, &min, &max);
-		if (!G_is_c_null_value(&min) && !G_is_c_null_value(&max))
-		    G_make_rainbow_colors(colors, min, max);
-		return 0;
-	else {
-	    if (G_read_fp_range(name, mapset, &drange) >= 0) {
-		G_get_fp_range_min_max(&drange, &dmin, &dmax);
-		if (!G_is_d_null_value(&dmin) && !G_is_d_null_value(&dmax))
-		    G_make_rainbow_fp_colors(colors, dmin, dmax);
-		return 0;
-	err = _("missing");
-	break;
-    case -1:
-	err = _("invalid");
-	break;
-    default:
-	return 1;
-    G_warning(_("Color support for <%s@%s> %s"), name, mapset,
-	      err);
-    return -1;
-static int read_colors(const char *element, const char *name,
-		       const char *mapset, struct Colors *colors)
-    FILE *fd;
-    int stat;
-    char buf[1024];
-    if (!(fd = G_fopen_old(element, name, mapset)))
-	return -2;
-     * first line in 4.0 color files is %
-     * otherwise it is pre 4.0
-    if (fgets(buf, sizeof buf, fd) == NULL) {
-	fclose(fd);
-	return -1;
-    fseek(fd, 0L, 0);
-    G_strip(buf);
-    if (*buf == '%') {		/* 4.0 format */
-	stat = read_new_colors(fd, colors);
-	colors->version = 0;	/* 4.0 format */
-    else {
-	stat = read_old_colors(fd, colors);
-	colors->version = -1;	/* pre 4.0 format */
-    fclose(fd);
-    return stat;
-/* parse input lines with the following formats
- *   val1:r:g:b val2:r:g:b
- *   val:r:g:b          (implies cat1==cat2)
- * r:g:b can be just a single grey level
- *   cat1:x cat2:y
- *   cat:x
- * optional lines are
- *    invert            invert color table
- *    shift:n           where n is the amount to shift the color table
- *    nv:r:g:b          color to use for NULL values
- *    *:r:g:b           color to use for undefined (beyond color rules)
-static int read_new_colors(FILE * fd, struct Colors *colors)
-    double val1, val2;
-    long cat1, cat2;
-    int r1, g1, b1;
-    int r2, g2, b2;
-    char buf[1024];
-    char word1[256], word2[256];
-    int n, fp_rule;
-    int null, undef;
-    int modular;
-    DCELL shift;
-	return -1;
-    G_strip(buf);
-    if (sscanf(buf + 1, "%lf %lf", &val1, &val2) == 2)
-	G_set_d_color_range((DCELL) val1, (DCELL) val2, colors);
-    modular = 0;
-    while (fgets(buf, sizeof buf, fd)) {
-	null = undef = fp_rule = 0;
-	*word1 = *word2 = 0;
-	n = sscanf(buf, "%s %s", word1, word2);
-	if (n < 1)
-	    continue;
-	if (sscanf(word1, "shift:%lf", &shift) == 1
-	    || (strcmp(word1, "shift:") == 0 &&
-		sscanf(word2, "%lf", &shift) == 1)) {
-	    G_shift_d_colors(shift, colors);
-	    continue;
-	if (strcmp(word1, "invert") == 0) {
-	    G_invert_colors(colors);
-	    continue;
-	if (strcmp(word1, "%%") == 0) {
-	    modular = !modular;
-	    continue;
-	switch (sscanf(word1, "nv:%d:%d:%d", &r1, &g1, &b1)) {
-	case 1:
-	    null = 1;
-	    b1 = g1 = r1;
-	    break;
-	case 3:
-	    null = 1;
-	    break;
-	if (!null)
-	    switch (sscanf(word1, "*:%d:%d:%d", &r1, &g1, &b1)) {
-	    case 1:
-		undef = 1;
-		b1 = g1 = r1;
-		break;
-	    case 3:
-		undef = 1;
-		break;
-	if (!null && !undef)
-	    switch (sscanf(word1, "%ld:%d:%d:%d", &cat1, &r1, &g1, &b1)) {
-	    case 2:
-		b1 = g1 = r1;
-		break;
-	    case 4:
-		break;
-	    default:
-		if (sscanf(word1, "%lf:%d:%d:%d", &val1, &r1, &g1, &b1) == 4)
-		    fp_rule = 1;
-		else if (sscanf(word1, "%lf:%d", &val1, &r1) == 2) {
-		    fp_rule = 1;
-		    b1 = g1 = r1;
-		else
-		    continue;	/* other lines are ignored */
-	if (n == 2) {
-	    switch (sscanf(word2, "%ld:%d:%d:%d", &cat2, &r2, &g2, &b2)) {
-	    case 2:
-		b2 = g2 = r2;
-		if (fp_rule)
-		    val2 = (DCELL) cat2;
-		break;
-	    case 4:
-		if (fp_rule)
-		break;
-	    default:
-		if (sscanf(word2, "%lf:%d:%d:%d", &val2, &r2, &g2, &b2) == 4) {
-		    if (!fp_rule)
-			val1 = (DCELL) cat1;
-		    fp_rule = 1;
-		else if (sscanf(word2, "%lf:%d", &val2, &r2) == 2) {
-		    if (!fp_rule)
-		    fp_rule = 1;
-		    b2 = g2 = r2;
-		else
-	else {
-	    if (!fp_rule)
-		cat2 = cat1;
-	    else
-		val2 = val1;
-	    r2 = r1;
-	    g2 = g1;
-	    b2 = b1;
-	if (null)
-	    G_set_null_value_color(r1, g1, b1, colors);
-	else if (undef)
-	    G_set_default_color(r1, g1, b1, colors);
-	else if (modular) {
-	    if (fp_rule)
-		G_add_modular_d_raster_color_rule((DCELL *) & val1, r1, g1,
-						  b1, (DCELL *) & val2, r2,
-						  g2, b2, colors);
-	    else
-		G_add_modular_color_rule((CELL) cat1, r1, g1, b1,
-					 (CELL) cat2, r2, g2, b2, colors);
-	else {
-	    if (fp_rule)
-		G_add_d_raster_color_rule((DCELL *) & val1, r1, g1, b1,
-					  (DCELL *) & val2, r2, g2, b2,
-					  colors);
-	    else
-		G_add_color_rule((CELL) cat1, r1, g1, b1,
-	G_debug(3, "adding rule %d=%.2lf %d %d %d  %d=%.2lf %d %d %d",
-		cat1, val1,  r1, g1, b1, cat2, val2, r2, g2, b2);
-    return 1;
-static int read_old_colors(FILE * fd, struct Colors *colors)
-    char buf[256];
-    long n;
-    long min;
-    float red_f, grn_f, blu_f;
-    int red, grn, blu;
-    int old;
-    int zero;
-     * first line in pre 3.0 color files is number of colors - ignore
-     * otherwise it is #min first color, and the next line is for color 0
-	return -1;
-    G_strip(buf);
-    if (*buf == '#') {		/* 3.0 format */
-	old = 0;
-	if (sscanf(buf + 1, "%ld", &min) != 1)	/* first color */
-	    return -1;
-	zero = 1;
-    else {
-	old = 1;
-	min = 0;
-	zero = 0;
-    n = min;
-	if (old) {
-	    if (sscanf(buf, "%f %f %f", &red_f, &grn_f, &blu_f) != 3)
-		return -1;
-	    red = 256 * red_f;
-	    grn = 256 * grn_f;
-	    blu = 256 * blu_f;
-	else {
-	    switch (sscanf(buf, "%d %d %d", &red, &grn, &blu)) {
-	    case 1:
-		blu = grn = red;
-		break;
-	    case 2:
-		blu = grn;
-		break;
-	    case 3:
-		break;
-	    default:
-		return -1;
-	if (zero) {
-	    G__insert_color_into_lookup((CELL) 0, red, grn, blu,
-					&colors->fixed);
-	    zero = 0;
-	else
-	    G__insert_color_into_lookup((CELL) n++, red, grn, blu,
-					&colors->fixed);
-    colors->cmax = n - 1;
-    return 0;
- * \brief Mark colors as floating-point.
- * Sets a flag in the <i>colors</i> structure that indicates that
- * these colors should only be looked up using floating-point raster
- * data (not integer data). In particular if this flag is set, the
- * routine G_get_colors_min_max() should return min=-255$^3$ and
- * max=255$^3$.
-void G_mark_colors_as_fp(struct Colors *colors)
-    colors->is_float = 1;
Deleted: grass/trunk/lib/gis/color_remove.c
--- grass/trunk/lib/gis/color_remove.c	2009-06-20 21:39:23 UTC (rev 38002)
+++ grass/trunk/lib/gis/color_remove.c	2009-06-20 22:03:23 UTC (rev 38003)
@@ -1,44 +0,0 @@
- * MODULE:       gis library
- * AUTHOR(S):    Glynn Clements <glynn at gclements.plus.com>
- * COPYRIGHT:    (C) 2007 Glynn Clements
- *  This program is free software; you can redistribute it and/or modify
- *  it under the terms of the GNU General Public License as published by
- *  the Free Software Foundation; either version 2 of the License, or
- *  (at your option) any later version.
- *  This program is distributed in the hope that it will be useful,
- *  but WITHOUT ANY WARRANTY; without even the implied warranty of
- *  MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.  See the
- *  GNU General Public License for more details.
-#include <stdio.h>
-int G_remove_colors(const char *name, const char *mapset)
-    char element[GMAPSET_MAX + 6];
-    char xname[GNAME_MAX], xmapset[GMAPSET_MAX];
-    int stat;
-    if (G__name_is_fully_qualified(name, xname, xmapset)) {
-	if (strcmp(xmapset, mapset) != 0)
-	    return -1;
-	name = xname;
-    /* get rid of existing colr2, if any */
-    sprintf(element, "colr2/%s", mapset);
-    stat = G_remove(element, name);
-    if (strcmp(mapset, G_mapset()) == 0)
-	stat = G_remove("colr", name);
-    return stat;
Deleted: grass/trunk/lib/gis/color_rule.c
--- grass/trunk/lib/gis/color_rule.c	2009-06-20 21:39:23 UTC (rev 38002)
+++ grass/trunk/lib/gis/color_rule.c	2009-06-20 22:03:23 UTC (rev 38003)
@@ -1,440 +0,0 @@
- * \file gis/color_rule.c
- * \brief GIS Library - Color rules.
-static void add_color_rule(const void *, int, int, int,
-			   const void *, int, int, int,
-			   struct _Color_Info_ *, int,
-			   DCELL *, DCELL *, RASTER_MAP_TYPE);
- * \brief Adds the floating-point rule (DCELL version)
- * See G_add_raster_color_rule() for details.
- *  \param v1 cell value
- *  \param r1,g1,b1 color value
- *  \param v2 cell value
- *  \param r2,g2,b2 color value
- *  \param[in,out] colors pointer to color table structure
- *  \return
-void G_add_d_raster_color_rule(const DCELL * val1, int r1, int g1, int b1,
-			       const DCELL * val2, int r2, int g2, int b2,
-    add_color_rule(val1, r1, g1, b1, val2, r2, g2, b2, &colors->fixed,
-		   colors->version, &colors->cmin, &colors->cmax, DCELL_TYPE);
- * \brief Adds the floating-point rule (FCELL version)
- *  \return
-void G_add_f_raster_color_rule(const FCELL * cat1, int r1, int g1, int b1,
-			       const FCELL * cat2, int r2, int g2, int b2,
-    add_color_rule(cat1, r1, g1, b1, cat2, r2, g2, b2, &colors->fixed,
-		   colors->version, &colors->cmin, &colors->cmax, FCELL_TYPE);
- * \brief Adds the floating-point rule (CCELL version)
- *  \return
-void G_add_c_raster_color_rule(const CELL * cat1, int r1, int g1, int b1,
-			       const CELL * cat2, int r2, int g2, int b2,
-		   colors->version, &colors->cmin, &colors->cmax, CELL_TYPE);
- * Adds the floating-point rule that the range [<em>v1,v2</em>] gets a
- * linear ramp of colors from [<em>r1,g1,b1</em>] to
- * [<em>r2,g2,b2</em>].
- * If either <em>v1</em> or <em>v2</em> is the NULL-value, this call is converted into
- * <tt>G_set_null_value_color (r1, g1, b1, colors)</tt>
- *  - If <em>map_type</em> is CELL_TYPE, calls G_add_c_raster_color_rule()
- *  - If <em>map_type</em> is FCELL_TYPE, calls G_add_f_raster_color_rule()
- *  - If <em>map_type</em> is DCELL_TYPE, calls G_add_d_raster_color_rule()
- *  \param data_type raster data type (CELL, FCELL, DCELL)
- *  \return
-void G_add_raster_color_rule(const void *val1, int r1, int g1, int b1,
-			     const void *val2, int r2, int g2, int b2,
-			     struct Colors *colors, RASTER_MAP_TYPE data_type)
-		   colors->version, &colors->cmin, &colors->cmax, data_type);
- * \brief Set colors rules
- * This is the heart
- * and soul of the new color logic. It adds a color rule to the <b>colors</b>
- * structure. The colors defined by the red, green, and blue values
- * <b>r1,g1,b1</b> and <b>r2,g2,b2</b> are assigned to <b>cat1</b> and
- * <b>cat2</b> respectively. Colors for data values between <b>cat1</b> and
- * <b>cat2</b> are not stored in the structure but are interpolated when
- * queried by <i>G_lookup_colors</i> and<i>G_get_color.</i> The color
- * components <b>r1,g1,b1</b> and <b>r2,g2,b2</b> must be in the range
- * 0 -- 255.
- * For example, to create a linear grey scale for the range 200 -- 1000:
- \code
- struct Colors colr;
- G_init_colors (&colr);
- G_add_color_rule ((CELL)200, 0,0,0, (CELL) 1000, 255,255,255);
- \endcode
- * The programmer is encouraged to review \ref
- * Raster_Color_Table_Format how this routine fits into the 5.x raster
- * color logic.
- * <b>Note:</b> The <i>colors</i> structure must have been initialized
- * by G_init_colors(). See \ref Predefined_Color_Tables for routines
- * to build some predefined color tables.
- *  \param cat1 cell value
- *  \param cat2 cell value
- *  \return
-void G_add_color_rule(CELL cat1, int r1, int g1, int b1,
-		      CELL cat2, int r2, int g2,
-		      int b2, struct Colors *colors)
-    add_color_rule((void *)&cat1, r1, g1, b1, (void *)&cat2, r2, g2, b2,
-		   &colors->fixed, colors->version, &colors->cmin,
-		   &colors->cmax, CELL_TYPE);
- * \brief Add modular color rule (DCELL version)
- * \param val1 cell value
- * \param val2 cell value
- * \return -1 on failure
-int G_add_modular_d_raster_color_rule(const DCELL * val1, int r1, int g1, int b1,
-    DCELL min, max;
-    if (colors->version < 0)
-	return -1;		/* can't use this on 3.0 colors */
-    min = colors->cmin;
-    max = colors->cmax;
-    add_color_rule(val1, r1, g1, b1, val2, r2, g2, b2, &colors->modular, 0,
-		   &colors->cmin, &colors->cmax, DCELL_TYPE);
-    colors->cmin = min;		/* don't reset these */
-    return 1;
- * \brief Add modular color rule (FCELL version)
-int G_add_modular_f_raster_color_rule(const FCELL * val1, int r1, int g1, int b1,
-				      const FCELL * val2, int r2, int g2, int b2,
-    DCELL min, max;
-	return -1;		/* can;t use this on 3.0 colors */
-		   &colors->cmin, &colors->cmax, FCELL_TYPE);
-    return 1;
- * \brief Add modular color rule (CCELL version)
-int G_add_modular_c_raster_color_rule(const CELL * val1, int r1, int g1, int b1,
-				      const CELL * val2, int r2, int g2, int b2,
-    return G_add_modular_color_rule(*val1, r1, g1, b1, *val2, r2, g2, b2,
-				    colors);
- * \todo Question: shouldn't this function call
- * G_add_modular_<data_type>_raster_color_rule() instead?
-int G_add_modular_raster_color_rule(
-    const void *val1, int r1, int g1, int b1,
-    CELL min, max;
-		   &colors->cmin, &colors->cmax, data_type);
-    return 1;
- * \todo This function seems to be same as
- * G_add_modular_raster_color_rule(). Can be removed?
-int G_add_modular_color_rule(CELL cat1, int r1, int g1,
-			     int b1, CELL cat2, int r2,
-			     int g2, int b2, struct Colors *colors)
-    CELL min, max;
-		   &colors->modular, 0, &colors->cmin, &colors->cmax,
-		   CELL_TYPE);
-    return 1;
-static void add_color_rule(const void *pt1, int r1, int g1, int b1,
-			   const void *pt2, int r2, int g2, int b2,
-			   struct _Color_Info_ *cp, int version, DCELL * cmin,
-			   DCELL * cmax, RASTER_MAP_TYPE data_type)
-    DCELL min, max, val1, val2;
-    CELL cat;
-    val1 = G_get_raster_value_d(pt1, data_type);
-    val2 = G_get_raster_value_d(pt2, data_type);
-    /* allocate a low:high rule */
-    rule = (struct _Color_Rule_ *)G_malloc(sizeof(*rule));
-    rule->next = rule->prev = NULL;
-    /* make sure colors are in the range [0,255] */
-    LIMIT(r1);
-    LIMIT(g1);
-    LIMIT(b1);
-    LIMIT(r2);
-    LIMIT(g2);
-    LIMIT(b2);
-    /* val1==val2, use average color */
-    /* otherwise make sure low < high */
-    if (val1 == val2) {
-	rule->low.value = rule->high.value = val1;
-	rule->low.red = rule->high.red = (r1 + r2) / 2;
-	rule->low.grn = rule->high.grn = (g1 + g2) / 2;
-	rule->low.blu = rule->high.blu = (b1 + b2) / 2;
-    else if (val1 < val2) {
-	rule->low.value = val1;
-	rule->low.red = r1;
-	rule->low.grn = g1;
-	rule->low.blu = b1;
-	rule->high.value = val2;
-	rule->high.red = r2;
-	rule->high.grn = g2;
-	rule->high.blu = b2;
-    else {
-	rule->low.value = val2;
-	rule->low.red = r2;
-	rule->low.grn = g2;
-	rule->low.blu = b2;
-	rule->high.value = val1;
-	rule->high.red = r1;
-	rule->high.grn = g1;
-	rule->high.blu = b1;
-    /* keep track of the overall min and max, excluding null */
-    if (G_is_d_null_value(&(rule->low.value)))
-	return;
-    if (G_is_d_null_value(&(rule->high.value)))
-	return;
-    min = rule->low.value;
-    max = rule->high.value;
-    if (min <= max) {
-	if (cp->min > cp->max) {
-	    cp->min = min;
-	    cp->max = max;
-	else {
-	    if (cp->min > min)
-		cp->min = min;
-	    if (cp->max < max)
-		cp->max = max;
-    if (*cmin > *cmax) {
-	*cmin = cp->min;
-	*cmax = cp->max;
-    else {
-	if (*cmin > cp->min)
-	    *cmin = cp->min;
-	if (*cmax < cp->max)
-	    *cmax = cp->max;
-    /* If version is old style (i.e., pre 4.0),
-     *     interpolate this rule from min to max
-     *     and insert each cat into the lookup table.
-     *     Then free the rule.
-     * Otherwise, free the lookup table, if active.
-     *     G_organize_colors() will regenerate it
-     *     Link this rule into the list of rules
-    if (version < 0) {
-	for (cat = (CELL) min; cat <= (CELL) max; cat++) {
-	    G__interpolate_color_rule((DCELL) cat, &red, &grn, &blu, rule);
-	    G__insert_color_into_lookup(cat, (int)red, (int)grn, (int)blu,
-					cp);
-	G_free(rule);
-    else {
-	if (cp->rules)
-	    cp->rules->prev = rule;
-	rule->next = cp->rules;
-	cp->rules = rule;
-	/* prune the rules:
-	 * remove all rules that are contained by this rule
-	min = rule->low.value;	/* mod 4.1 */
-	max = rule->high.value;	/* mod 4.1 */
-	cp->n_rules++;
-	for (rule = rule->next; rule; rule = next) {
-	    next = rule->next;	/* has to be done here, not in for stmt */
-	    if (min <= rule->low.value && max >= rule->high.value) {
-		if ((rule->prev->next = next))	/* remove from the list */
-		    next->prev = rule->prev;
-		G_free(rule);
-		cp->n_rules--;
-	/* free lookup array, if allocated */
-	G__color_free_lookup(cp);
-	G__color_free_fp_lookup(cp);
Deleted: grass/trunk/lib/gis/color_rule_get.c
--- grass/trunk/lib/gis/color_rule_get.c	2009-06-20 21:39:23 UTC (rev 38002)
+++ grass/trunk/lib/gis/color_rule_get.c	2009-06-20 22:03:23 UTC (rev 38003)
@@ -1,123 +0,0 @@
- * \file color_rule_get.c
- * \brief GIS Library - Get color rules.
- * (C) 2001-2008 by the GRASS Development Team
- * \author GRASS GIS Development Team
- * \date 1999-2008
-   \brief Get both modular and fixed rules count
-   \param colors pointer to color table structure
-   \return number of rules in color table
-int G_colors_count(const struct Colors *colors)
-    int count = 0;
-    if (colors->fixed.rules) {
-	count++;
-	rule = colors->fixed.rules;
-	while (rule->next) {
-	    count++;
-	    rule = rule->next;
-    if (colors->modular.rules) {
-	count++;
-	rule = colors->modular.rules;
-	    count++;
-    return count;
-   \brief Get color rule from both modular and fixed rules
-   Rules are returned in the order as stored in the table (i.e. unexpected, high values first)
-   \param val1 color value
-   \param[out] r1,g1,b1 color value
-   \param val2 color value
-   \param[out] r2,g2,b2 color value
-   \param rule rule index from 0 to G_color_count()-1
-   \return 0 success
-   \return 1 index out of range
-int G_get_f_color_rule(DCELL * val1, unsigned char *r1, unsigned char *g1,
-		       unsigned char *b1, DCELL * val2, unsigned char *r2,
-		       unsigned char *g2, unsigned char *b2,
-		       const struct Colors *colors, int rule)
-    int index = -1;
-    int found = 0;
-    const struct _Color_Rule_ *rl;
-    *val1 = *val2 = 0.0;
-    *r1 = *g1 = *b1 = *r2 = *g2 = *b2 = 0;
-    /* Find the rule */
-	rl = colors->fixed.rules;
-	index++;
-	if (index == rule)
-	    found = 1;
-	while (!found && rl->next) {
-	    rl = rl->next;
-	    index++;
-		found = 1;
-    if (!found && colors->modular.rules) {
-	rl = colors->modular.rules;
-	index++;
-	    found = 1;
-	    rl = rl->next;
-	    index++;
-		found = 1;
-    if (!found)
-	return 1;
-    /* Set values */
-    *val1 = rl->low.value;
-    *val2 = rl->high.value;
-    *r1 = rl->low.red;
-    *g1 = rl->low.grn;
-    *b1 = rl->low.blu;
-    *r2 = rl->high.red;
-    *g2 = rl->high.grn;
-    *b2 = rl->high.blu;
-    return 0;
Deleted: grass/trunk/lib/gis/color_rules.c
--- grass/trunk/lib/gis/color_rules.c	2009-06-20 21:39:23 UTC (rev 38002)
+++ grass/trunk/lib/gis/color_rules.c	2009-06-20 22:03:23 UTC (rev 38003)
@@ -1,270 +0,0 @@
- * COPYRIGHT:    (C) 2007 Glynn Clements and the GRASS Development Team
- * NOTE:         Based upon r.colors/rules.c
- *               The colors are stored in ./colors/
-#include <stdio.h>
-struct rule
-    int set;
-    int r, g, b;
-    DCELL val;
-enum rule_error
-    CR_OK = 0,
-    CR_ERROR_SYNTAX,
-    CR_ERROR_RGB,
-    CR_ERROR_COLOR,
-    CR_ERROR_PERCENT,
-    CR_ERROR_VALUE,
-int G_parse_color_rule(DCELL min, DCELL max, const char *buf,
-		       DCELL * val, int *r, int *g, int *b,
-		       int *norm, int *nval, int *dflt)
-    char value[80], color[80];
-    double x;
-    char c;
-    *norm = *nval = *dflt = 0;
-    if (sscanf(buf, "%s %[^\n]", value, color) != 2)
-	return CR_ERROR_SYNTAX;
-    G_chop(color);
-    if (sscanf(color, "%d:%d:%d", r, g, b) == 3 ||
-	sscanf(color, "%d %d %d", r, g, b) == 3) {
-	if (*r < 0 || *r > 255 || *g < 0 || *g > 255 || *b < 0 || *b > 255)
-	    return CR_ERROR_RGB;
-    else {
-	float fr, fg, fb;
-	if (G_color_values(color, &fr, &fg, &fb) < 0)
-	    return CR_ERROR_COLOR;
-	*r = (int)(fr * 255.99);
-	*g = (int)(fg * 255.99);
-	*b = (int)(fb * 255.99);
-    G_chop(value);
-    if (G_strcasecmp(value, "default") == 0) {
-	*dflt = 1;
-	return CR_OK;
-    if (G_strcasecmp(value, "nv") == 0) {
-	*nval = 1;
-	return CR_OK;
-    if (sscanf(value, "%lf%c", &x, &c) == 2 && c == '%') {
-	if (x < 0 || x > 100)
-	    return CR_ERROR_PERCENT;
-	*val = min + (max - min) * (x / 100);
-	*norm = 1;
-	return CR_OK;
-    if (sscanf(value, "%lf", val) == 1) {
-	*norm = 1;
-	return CR_OK;
-    return CR_ERROR_VALUE;
-const char *G_parse_color_rule_error(int code)
-    switch (code) {
-    case CR_OK:
-	return "";
-    case CR_ERROR_SYNTAX:
-	return _("syntax error");
-    case CR_ERROR_RGB:
-	return _("R/G/B not in range 0-255");
-    case CR_ERROR_COLOR:
-	return _("invalid color name");
-    case CR_ERROR_PERCENT:
-	return _("percentage not in range 0-100");
-    case CR_ERROR_VALUE:
-	return _("invalid value");
-    default:
-	return _("unknown error");
-int G_read_color_rule(void *closure, DCELL min, DCELL max,
-    char buf[1024];
-    FILE *fp = closure;
-    int ret;
-    for (;;) {
-	if (!G_getl2(buf, sizeof(buf), fp))
-	    return 0;
-	G_strip(buf);
-	G_debug(5, "color buf = [%s]", buf);
-	if (*buf == '\0')
-	    continue;
-	if (*buf == '#')
-	    continue;
-	ret =
-	    G_parse_color_rule(min, max, buf, val, r, g, b, norm, nval, dflt);
-	if (ret == 0)
-	    return 1;
-	G_fatal_error(_("bad rule (%s): [%s]"),
-		      G_parse_color_rule_error(ret), buf);
-    return 0;
-int G_read_color_rules(struct Colors *colors, DCELL min, DCELL max,
-		       read_rule_fn * read_rule, void *closure)
-    struct rule *rule = NULL;
-    int nrules = 0;
-    struct rule dflt, null;
-    int set, is_null, is_dflt, r, g, b;
-    DCELL val;
-    int n;
-    if (!read_rule)
-	read_rule = G_read_color_rule;
-    /* initialization */
-    dflt.r = dflt.g = dflt.b = dflt.set = 0;
-    null.r = null.g = null.b = null.set = 0;
-    while ((*read_rule)
-	   (closure, min, max, &val, &r, &g, &b, &set, &is_null, &is_dflt)) {
-	struct rule *p;
-	if (set) {
-	    n = nrules++;
-	    rule = G_realloc(rule, nrules * sizeof(struct rule));
-	    p = &rule[n];
-	else if (is_dflt)
-	    p = &dflt;
-	else if (is_null)
-	    p = &null;
-	p->r = r;
-	p->g = g;
-	p->b = b;
-	p->set = 1;
-	p->val = val;
-    if (nrules == 0)
-	return 0;
-    if (nrules == 1) {
-	const struct rule *p = &rule[0];
-	G_set_d_color(p->val, p->r, p->g, p->b, colors);
-    for (n = 1; n < nrules; n++) {
-	struct rule *lo = &rule[n - 1];
-	struct rule *hi = &rule[n];
-	G_add_d_raster_color_rule(&lo->val, lo->r, lo->g, lo->b,
-				  &hi->val, hi->r, hi->g, hi->b, colors);
-    /* null value and default color set up, if rules are set up by user */
-    if (null.set)
-	G_set_null_value_color(null.r, null.g, null.b, colors);
-    if (dflt.set)
-	G_set_default_color(dflt.r, dflt.g, dflt.b, colors);
-    return 1;
-static int load_rules_file(struct Colors *colors, const char *path, DCELL min, DCELL max)
-    FILE *fp;
-    int ret;
-    fp = fopen(path, "r");
-    if (!fp)
-	return 0;
-    ret = G_read_color_rules(colors, min, max, G_read_color_rule, (void *)fp);
-    fclose(fp);
-    return ret;
-int G_load_colors(struct Colors *colors, const char *path, CELL min, CELL max)
-    return load_rules_file(colors, path, (DCELL) min, (DCELL) max);
-int G_load_fp_colors(struct Colors *colors, const char *path, DCELL min, DCELL max)
-    return load_rules_file(colors, path, min, max);
-static void load_rules_name(struct Colors *colors, const char *name, DCELL min, DCELL max)
-    char path[GPATH_MAX];
-    sprintf(path, "%s/etc/colors/%s", G_gisbase(), name);
-    if (!load_rules_file(colors, path, min, max))
-	G_fatal_error(_("Unable to load color rules <%s>"), name);
-void G_make_colors(struct Colors *colors, const char *name, CELL min, CELL max)
-    return load_rules_name(colors, name, (DCELL) min, (DCELL) max);
-void G_make_fp_colors(struct Colors *colors, const char *name, DCELL min, DCELL max)
-    return load_rules_name(colors, name, min, max);
Deleted: grass/trunk/lib/gis/color_set.c
--- grass/trunk/lib/gis/color_set.c	2009-06-20 21:39:23 UTC (rev 38002)
+++ grass/trunk/lib/gis/color_set.c	2009-06-20 22:03:23 UTC (rev 38003)
@@ -1,104 +0,0 @@
- * \file gis/color_set.c
- * \brief GIS Library - Set colors for raster maps.
- * \brief Set a category color (CELL)
- * associated with category <i>cat</i> are set in the <i>colors</i>
- * structure.  The intensities must be in the range 0 -­ 255. Values
- * below zero are set as zero, values above 255 are set as 255.
- * <b>Warning: Use of this routine is discouraged because it defeats the new
- * color logic.</b>
- * It is provided only for backward compatibility. Overuse can create
- * large color tables. G_add_color_rule() should be used whenever
- * possible.
- * initialized by G_init_color().
- * \param cat raster cell value
- * \param r red value
- * \param g green value
- * \param b blue value
-void G_set_color(CELL cat, int r, int g, int b, struct Colors *colors)
-    if (G_is_c_null_value(&cat))
-	G_set_null_value_color(r, g, b, colors);
-    else
-	G_add_color_rule(cat, r, g, b, cat, r, g, b, colors);
- * \brief Set a category color (DCELL)
- * See G_set_color() for detailed information.
-void G_set_d_color(DCELL val, int r, int g, int b, struct Colors *colors)
-    if (G_is_d_null_value(&val))
-    else
-	G_add_d_raster_color_rule(&val, r, g, b, &val, r, g, b, colors);
- * \brief Set color for NULL-value
- * Sets the color (in <i>colors</i>) for the NULL-value to
- * <i>red, green, blue</i>.
- * \param red red value
- * \param grn green value
- * \param blu blue value
-void G_set_null_value_color(int red, int grn, int blu, struct Colors *colors)
-    colors->null_red = red;
-    colors->null_grn = grn;
-    colors->null_blu = blu;
-    colors->null_set = 1;
- * \brief Set default color value
- * Sets the default color (in <i>colors</i>) to <i>red, green,
- * blue</i>. This is the color for values which do not have an
- * explicit rule.
-void G_set_default_color(int red, int grn, int blu, struct Colors *colors)
-    colors->undef_red = red;
-    colors->undef_grn = grn;
-    colors->undef_blu = blu;
-    colors->undef_set = 1;
Deleted: grass/trunk/lib/gis/color_shift.c
--- grass/trunk/lib/gis/color_shift.c	2009-06-20 21:39:23 UTC (rev 38002)
+++ grass/trunk/lib/gis/color_shift.c	2009-06-20 22:03:23 UTC (rev 38003)
@@ -1,10 +0,0 @@
-void G_shift_colors(int shift, struct Colors *colors)
-    colors->shift += (DCELL) shift;
-void G_shift_d_colors(DCELL shift, struct Colors *colors)
-    colors->shift += shift;
Deleted: grass/trunk/lib/gis/color_str.c
--- grass/trunk/lib/gis/color_str.c	2009-06-20 21:39:23 UTC (rev 38002)
+++ grass/trunk/lib/gis/color_str.c	2009-06-20 22:03:23 UTC (rev 38003)
@@ -1,150 +0,0 @@
-   \file color_str.c
-   \brief GIS library - color management, named color to RGB triplet
-   (C) 2001-2008 by the GRASS Development Team
-   This program is free software under the
-   GNU General Public License (>=v2).
-   Read the file COPYING that comes with GRASS
-   for details.
-   \author Original author CERL
-#include <grass/colors.h>
-/* The order in this table is important! It will be indexed by color number */
-static const struct color_rgb standard_colors_rgb[] = {
-    {0, 0, 0},			/* This is a dummy value to make lookup easier */
-    {0, 0, 0},			/* BLACK   */
-    {255, 0, 0},		/* RED     */
-    {0, 255, 0},		/* GREEN   */
-    {0, 0, 255},		/* BLUE    */
-    {255, 255, 0},		/* YELLOW  */
-    {0, 255, 255},		/* CYAN    */
-    {255, 0, 255},		/* MAGENTA */
-    {255, 255, 255},		/* WHITE   */
-    {128, 128, 128},		/* GRAY    */
-    {255, 128, 0},		/* ORANGE  */
-    {100, 128, 255},		/* AQUA    */
-    {0, 128, 255},		/* INDIGO  */
-    {128, 0, 255},		/* VIOLET  */
-    {180, 77, 25}		/* BROWN   */
-/* The order in this table has no meaning. */
-static const struct color_name standard_color_names[] = {
-    {"black", BLACK},
-    {"red", RED},
-    {"green", GREEN},
-    {"blue", BLUE},
-    {"yellow", YELLOW},
-    {"cyan", CYAN},
-    {"magenta", MAGENTA},
-    {"white", WHITE},
-    {"grey", GREY},
-    {"gray", GRAY},
-    {"orange", ORANGE},
-    {"aqua", AQUA},
-    {"indigo", INDIGO},
-    {"violet", VIOLET},
-    {"purple", PURPLE},
-    {"brown", BROWN}
-   \brief Get number of named colors (RGB triplets)
-   \return number of colors
-int G_num_standard_colors(void)
-    return sizeof(standard_colors_rgb) / sizeof(standard_colors_rgb[0]);
-   \brief Get RGB triplet of given color
-   \param n color index
-struct color_rgb G_standard_color_rgb(int n)
-    return standard_colors_rgb[n];
-   \brief Get number of named colors (color names)
-int G_num_standard_color_names(void)
-    return sizeof(standard_color_names) / sizeof(standard_color_names[0]);
-   \brief Get color name
-const struct color_name *G_standard_color_name(int n)
-    return &standard_color_names[n];
-   \brief Parse color string and set red,green,blue
-   \param str color string
-   \return 1 OK
-   \return 2 NONE
-   \return 0 on error
-int G_str_to_color(const char *str, int *red, int *grn, int *blu)
-    char buf[100];
-    int num_names = G_num_standard_color_names();
-    int i;
-    strcpy(buf, str);
-    G_chop(buf);
-    G_debug(3, "G_str_to_color(): str = '%s'", buf);
-    if (G_strcasecmp(buf, "NONE") == 0)
-	return 2;
-    if (sscanf(buf, "%d%*[,:; ]%d%*[,:; ]%d", red, grn, blu) == 3) {
-	if (*red < 0 || *red > 255 ||
-	    *grn < 0 || *grn > 255 || *blu < 0 || *blu > 255)
-	    return 0;
-	return 1;
-    /* Look for this color in the standard (preallocated) colors */
-    for (i = 0; i < num_names; i++) {
-	const struct color_name *name = &standard_color_names[i];
-	if (G_strcasecmp(buf, name->name) == 0) {
-	    struct color_rgb rgb = standard_colors_rgb[name->number];
-	    *red = (int)rgb.r;
-	    *grn = (int)rgb.g;
-	    *blu = (int)rgb.b;
-	    return 1;
-    return 0;
Deleted: grass/trunk/lib/gis/color_write.c
--- grass/trunk/lib/gis/color_write.c	2009-06-20 21:39:23 UTC (rev 38002)
+++ grass/trunk/lib/gis/color_write.c	2009-06-20 22:03:23 UTC (rev 38003)
@@ -1,266 +0,0 @@
- * \file gis/color_write.c
- * \brief GIS Library - Write color table of raster map
- * (C) 1999-2009 by the GRASS Development Team
- * License (>=v2). Read the file COPYING that comes with GRASS
- * for details.
- * \author USACERL and many others
-#include <stdio.h>
-#include <grass/gis.h>
-#define PRECISION 30
-#define THRESHOLD .0000000000000000000000000000005 /* .5 * 10 ^(-30) */
-static void write_rules(FILE *, struct _Color_Rule_ *, DCELL, DCELL);
-static void write_new_colors(FILE *, struct Colors *);
-static void write_old_colors(FILE *, struct Colors *);
-static void forced_write_old_colors(FILE *, struct Colors *);
-static void format_min(char *, double);
-static void format_max(char *, double);
- * \brief Write map layer color table
- * The color table is written for the raster map <i>name</i> in the
- * specified <i>mapset</i> from the <i>colors</i> structure.
- * If there is an error, -1 is returned. No diagnostic is
- * printed. Otherwise, 1 is returned.
- * The <i>colors</i> structure must be created properly, i.e.,
- * G_init_colors() to initialize the structure and G_add_color_rule()
- * to set the category colors. These routines are called by
- * higher level routines which read or create entire color tables,
- * such as G_read_colors() or G_make_ramp_colors().
- * <b>Note:</b> The calling sequence for this function deserves
- * special attention. The <i>mapset</i> parameter seems to imply that
- * it is possible to overwrite the color table for a raster map which
- * is in another mapset. However, this is not what actually
- * happens. It is very useful for users to create their own color
- * tables for raster maps in other mapsets, but without overwriting
- * other users' color tables for the same raster map. If <i>mapset</i>
- * is the current mapset, then the color file for <i>name</i> will be
- * overwritten by the new color table. But if <i>mapset</i> is not the
- * current mapset, then the color table is actually written in the
- * current mapset under the <tt>colr2</tt> element as:
- * <tt>colr2/mapset/name</tt>.
- * The rules are written out using floating-point format, removing
- * trailing zeros (possibly producing integers).  The flag marking the
- * colors as floating-point is <b>not</b> written.
- * If the environment variable FORCE_GRASS3_COLORS is set (to anything at all)
- * then the output format is 3.0, even if the structure contains 4.0 rules.
- * This allows users to create 3.0 color files for export to sites which
- * don't yet have 4.0
- * \param colors pointer to structure Colors which holds color info
-int G_write_colors(const char *name, const char *mapset,
-    char element[512];
-    FILE *fd;
-	    return -1;
-	name = xname;
-     * if mapset is current mapset, remove colr2 file (created by pre 3.0 grass)
-     *    and then write original color table
-     * else write secondary color table
-    if (strcmp(mapset, G_mapset()) == 0) {
-	G_remove(element, name);	/* get rid of existing colr2, if any */
-	strcpy(element, "colr");
-    if (!(fd = G_fopen_new(element, name)))
-	return -1;
-    G__write_colors(fd, colors);
-    fclose(fd);
-    return 1;
- * \param fd file descriptor
- * \param colors pointer to Colors structure which holds color info
-void G__write_colors(FILE * fd, struct Colors *colors)
-    if (getenv("FORCE_GRASS3_COLORS"))
-	forced_write_old_colors(fd, colors);
-    else if (colors->version < 0)
-	write_old_colors(fd, colors);
-    else
-	write_new_colors(fd, colors);
-static void write_new_colors(FILE * fd, struct Colors *colors)
-    char str1[100], str2[100];
-    format_min(str1, (double)colors->cmin);
-    format_max(str2, (double)colors->cmax);
-    fprintf(fd, "%% %s %s\n", str1, str2);
-    if (colors->shift) {
-	sprintf(str2, "%.10f", (double)colors->shift);
-	G_trim_decimal(str2);
-	fprintf(fd, "shift:%s\n", str2);
-    if (colors->invert)
-	fprintf(fd, "invert\n");
-	fprintf(fd, "nv:%d", colors->null_red);
-	if (colors->null_red != colors->null_grn || colors->null_red
-	    != colors->null_blu)
-	    fprintf(fd, ":%d:%d", colors->null_grn, colors->null_blu);
-	fprintf(fd, "\n");
-	fprintf(fd, "*:%d", colors->undef_red);
-	if (colors->undef_red != colors->undef_grn || colors->undef_red
-	    != colors->undef_blu)
-	    fprintf(fd, ":%d:%d", colors->undef_grn, colors->undef_blu);
-	fprintf(fd, "%s\n", "%%");
-	write_rules(fd, colors->modular.rules, colors->cmin, colors->cmax);
-	write_rules(fd, colors->fixed.rules, colors->cmin, colors->cmax);
-/* overall min and max data values in color table */
-static void write_rules(FILE * fd, struct _Color_Rule_ *crules, DCELL dmin, DCELL dmax)
-    char str[100];
-    /* find the end of the rules list */
-    rule = crules;
-    /* write out the rules in reverse order */
-	if (rule->low.value == dmin)
-	    format_min(str, (double)rule->low.value);
-	else {
-	    sprintf(str, "%.10f", (double)rule->low.value);
-	    G_trim_decimal(str);
-	fprintf(fd, "%s:%d", str, (int)rule->low.red);
-	if (rule->low.red != rule->low.grn || rule->low.red != rule->low.blu)
-	    fprintf(fd, ":%d:%d", rule->low.grn, rule->low.blu);
-	/* even if low==high, write second end when the high is dmax */
-	if (rule->high.value == dmax || rule->low.value != rule->high.value) {
-	    if (rule->high.value == dmax)
-		format_max(str, (double)rule->high.value);
-	    else {
-		sprintf(str, "%.10f", (double)rule->high.value);
-	    fprintf(fd, " %s:%d", str, (int)rule->high.red);
-	    if (rule->high.red != rule->high.grn ||
-		rule->high.red != rule->high.blu)
-		fprintf(fd, ":%d:%d", rule->high.grn, rule->high.blu);
-static void write_old_colors(FILE * fd, struct Colors *colors)
-    int i, n;
-    fprintf(fd, "#%ld first color\n", (long)colors->fixed.min);
-	fprintf(fd, "%d %d %d\n",
-		(int)colors->null_red,
-		(int)colors->null_grn, (int)colors->null_blu);
-    else
-	fprintf(fd, "255 255 255\n");	/* white */
-    n = colors->fixed.max - colors->fixed.min + 1;
-    for (i = 0; i < n; i++) {
-	fprintf(fd, "%d", (int)colors->fixed.lookup.red[i]);
-	if (colors->fixed.lookup.red[i] != colors->fixed.lookup.grn[i]
-	    || colors->fixed.lookup.red[i] != colors->fixed.lookup.blu[i])
-	    fprintf(fd, " %d %d",
-		    (int)colors->fixed.lookup.grn[i],
-		    (int)colors->fixed.lookup.blu[i]);
-static void forced_write_old_colors(FILE * fd, struct Colors *colors)
-    CELL cat;
-    fprintf(fd, "#%ld first color\n", (long)colors->cmin);
-    G_get_color((CELL) 0, &red, &grn, &blu, colors);
-    fprintf(fd, "%d %d %d\n", red, grn, blu);
-    for (cat = colors->cmin; cat <= colors->cmax; cat++) {
-	G_get_color(cat, &red, &grn, &blu, colors);
-	fprintf(fd, "%d", red);
-	if (red != grn || red != blu)
-	    fprintf(fd, " %d %d", grn, blu);
-static void format_min(char *str, double dval)
-    double dtmp;
-    sprintf(str, "%.*f", PRECISION, dval);
-    sscanf(str, "%lf", &dtmp);
-    if (dtmp != dval) {		/* if  no zeros after decimal point were trimmed */
-	sprintf(str, "%.*f", PRECISION, dval - THRESHOLD);
-	/* because precision is probably higher than PRECISION */
-static void format_max(char *str, double dval)
-    double dtmp;
-	sprintf(str, "%.*f", PRECISION, dval + THRESHOLD);
Deleted: grass/trunk/lib/gis/color_xform.c
--- grass/trunk/lib/gis/color_xform.c	2009-06-20 21:39:23 UTC (rev 38002)
+++ grass/trunk/lib/gis/color_xform.c	2009-06-20 22:03:23 UTC (rev 38003)
@@ -1,316 +0,0 @@
- *  G_histogram_eq_colors (dst, src, statf)
- *   struct Colors *dst         struct to hold new colors
- *   struct Colors *src         struct containing original colors
- *   struct Cell_stats *statf   cell stats info
- *  Generates histogram equalized version of an existing color table from
- *  cell stats structure info.
- *  G_log_colors (dst, src, samples)
- *   int samples                number of samples
- *  Generates logarithmically-scaled version of an existing color table.
-#include <math.h>
- * \brief make histogram-stretched version of existing color table
- * Generates a histogram
- * contrast-stretched color table that goes from the histogram
- * information in the Cell_stats structure <b>statf.</b>  (See
- * Raster_Histograms).
- *  \param dst
- *  \param src
- *  \param statf
- *  \return
-void G_histogram_eq_colors(struct Colors *dst,
-			   struct Colors *src, struct Cell_stats *statf)
-    DCELL min, max;
-    long count, total, sum;
-    CELL cat, prev;
-    int first;
-    G_init_colors(dst);
-    G_get_d_color_range(&min, &max, src);
-    G_get_default_color(&red, &grn, &blu, src);
-    G_set_default_color(red, grn, blu, dst);
-    G_get_null_value_color(&red, &grn, &blu, src);
-    G_set_null_value_color(red, grn, blu, dst);
-    total = 0;
-    G_rewind_cell_stats(statf);
-    while (G_next_cell_stat(&cat, &count, statf))
-	if (count > 0)
-	    total += count;
-    if (total <= 0)
-	return;
-    sum = 0;
-    prev = 0;
-    first = 1;
-    while (G_next_cell_stat(&cat, &count, statf)) {
-	int red2, grn2, blu2;
-	DCELL x;
-	if (count <= 0)
-	    continue;
-	x = min + (max - min) * (sum + count / 2.0) / total;
-	G_get_d_raster_color(&x, &red2, &grn2, &blu2, src);
-	if (!first)
-	    G_add_color_rule(prev, red, grn, blu, cat, red2, grn2, blu2, dst);
-	sum += count;
-	first = 0;
-	prev = cat;
-	red = red2;
-	grn = grn2;
-	blu = blu2;
- * \brief make histogram-stretched version of existing color table (FP version)
- * information in the FP_stats structure <b>statf.</b>  (See
- *  \param dst
- *  \param src
- *  \param statf
- *  \return void
-void G_histogram_eq_colors_fp(struct Colors *dst,
-			      struct Colors *src, struct FP_stats *statf)
-    DCELL min, max;
-    unsigned long sum;
-    DCELL val;
-    int first;
-    int i;
-    if (!statf->total)
-	return;
-    sum = 0;
-    first = 1;
-    for (i = 0; i <= statf->count; i++) {
-	DCELL val2, x;
-	val2 = statf->min + (statf->max - statf->min) * i / statf->count;
-	if (statf->geometric)
-	    val2 = exp(val2);
-	if (statf->geom_abs)
-	    val2 = exp(val2) - 1;
-	if (statf->flip)
-	    val2 = -val2;
-	x = min + (max - min) * sum / statf->total;
-	if (!first)
-	    G_add_d_raster_color_rule(&val, red, grn, blu, &val2, red2, grn2, blu2, dst);
-	first = 0;
-	if (i == statf->count)
-	    break;
-	sum += statf->stats[i];
-	val = val2;
-	red = red2;
-	grn = grn2;
-	blu = blu2;
- * \brief make logarithmically-scaled version of an existing color table
- *  \param dst
- *  \param src
- *  \param samples
- *  \return
-void G_log_colors(struct Colors *dst, struct Colors *src, int samples)
-    DCELL min, max;
-    double lmin, lmax;
-    DCELL prev;
-    int i;
-    lmin = log(min);
-    lmax = log(max);
-    for (i = 0; i <= samples; i++) {
-	double lx;
-	DCELL x, y;
-	y = min + (max - min) * i / samples;
-	G_get_d_raster_color(&y, &red2, &grn2, &blu2, src);
-	if (i == 0)
-	    x = min;
-	else if (i == samples)
-	    x = max;
-	else {
-	    lx = lmin + (lmax - lmin) * i / samples;
-	    x = exp(lx);
-	if (i > 0)
-	    G_add_d_raster_color_rule(&prev, red, grn, blu,
-				      &x, red2, grn2, blu2,
-				      dst);
-	prev = x;
-	red = red2;
-	grn = grn2;
-	blu = blu2;
- * \brief make logarithmically-scaled version of an existing color table, allowing for signed values
- *  \param dst
- *  \param src
- *  \param samples
- *  \return
-void G_abs_log_colors(struct Colors *dst, struct Colors *src, int samples)
-    DCELL min, max;
-    DCELL amax, lamax;
-    DCELL prev;
-    int i;
-    lmin = log(fabs(min) + 1.0);
-    lmax = log(fabs(max) + 1.0);
-    amax = fabs(min) > fabs(max) ? fabs(min) : fabs(max);
-    lamax = lmin > lmax ? lmin : lmax;
-	double lx;
-	DCELL x, y;
-	if (i == 0)
-	    x = 1;
-	    x = amax;
-	else {
-	    lx = 0 + lamax * i / samples;
-	    x = exp(lx);
-	if (i > 0) {
-	    DCELL x0 = prev, x1 = x;
-	    G_add_d_raster_color_rule(&x0, red, grn, blu,
-				      &x1, red2, grn2, blu2,
-				      dst);
-	    x0 = -x0;
-	    x1 = -x1;
-				      dst);
-	prev = x;
-	red = red2;
-	grn = grn2;
-	blu = blu2;
Modified: grass/trunk/lib/gis/debug.c
--- grass/trunk/lib/gis/debug.c	2009-06-20 21:39:23 UTC (rev 38002)
+++ grass/trunk/lib/gis/debug.c	2009-06-20 22:03:23 UTC (rev 38003)
@@ -20,8 +20,8 @@
 #include <stdarg.h>
-#include "G.h"
+#include "../raster/G.h"
 static int initialized;
 static int grass_debug_level;
Deleted: grass/trunk/lib/gis/format.c
--- grass/trunk/lib/gis/format.c	2009-06-20 21:39:23 UTC (rev 38002)
+++ grass/trunk/lib/gis/format.c	2009-06-20 22:03:23 UTC (rev 38003)
@@ -1,192 +0,0 @@
-#include <unistd.h>
-#include <grass/config.h>
-#ifdef HAVE_UNISTD_H
-#endif
-#include "G.h"
-   <h3>GRASS Raster Format</h3>
-   Small example to illustrate the raster format:
-   A file may contain the following 3x3 floating point matrix:
-   \verbatim
-   10.000 20.000 30.000
-   20.000 40.000 50.000
-   30.000 50.000 60.000
-   \endverbatim
-   The header is a single byte, equal to sizeof(off_t) (typically 4 on a
-   32-bit platform, 8 on a 64-bit platform). Then, NROWS+1 offsets are
-   written as off_t's (i.e. 4 or 8 bytes, depending upon platform) in
-   big-endian (Motorola) byte order.
-   <P>
-   Thus, above example is actually interpreted as:
-   \verbatim
-   4               sizeof(off_t)
-   0 0 0 17        offset of row 0
-   0 0 0 36        offset of row 1
-   0 0 0 55        offset of row 2
-   0 0 0 74        offset of end of data
-   \endverbatim
-   See G__write_row_ptrs() below for the code which writes this data.
-   However, note that the row offsets are initially zero;
-   they get overwritten later (if you are writing compressed data,
-   you don't know how much space it will require until you've compressed
-   it).
-   As for the format of the actual row data, see put_fp_data() in
-   src/libes/gis/put_row.c and RFC 1014 (the XDR specification):
-   http://www.faqs.org/rfcs/rfc1014.html
- *   G__check_format(int fd)
- *   Check to see if map with file descriptor "fd" is in compressed
- *   format.   If it is, the offset table at the beginning of the
- *   file (which gives seek addresses into the file where code for
- *   each row is found) is read into the File Control Buffer (FCB).
- *   The compressed flag in the FCB is appropriately set.
- *   returns:    1 if row pointers were read successfully, -1 otherwise
-int G__check_format(int fd)
-    struct fileinfo *fcb = &G__.fileinfo[fd];
-    unsigned char compress[4];
-     * Check to see if the file is in compress mode
-     * 4 possibilites
-     *   compressed flag in cellhd is negative (meaning pre 3.0 cell file)
-     *       compression flag is first 3 bytes of cell file
-     *   compression flag is 0 - not compressed
-     *   compression flag is 1 - compressed using RLE (int) or zlib (FP)
-     *   compression flag is 2 - compressed using zlib
-    if (fcb->cellhd.compressed < 0) {
-	if (read(fd, compress, 3) != 3
-	    || compress[0] != 251 || compress[1] != 255 || compress[2] != 251)
-	    fcb->cellhd.compressed = 0;
-    if (!fcb->cellhd.compressed)
-	return fd;
-    /* allocate space to hold the row address array */
-    fcb->row_ptr = G_calloc(fcb->cellhd.rows + 1, sizeof(off_t));
-    /* read the row address array */
-    return G__read_row_ptrs(fd);
-int G__read_row_ptrs(int fd)
-    int nrows = fcb->cellhd.rows;
-    unsigned char nbytes;
-    unsigned char *buf, *b;
-    int n;
-    int row;
-     * pre3.0 row addresses were written directly from the array of off_t's
-     * (this makes them machine dependent)
-	n = (nrows + 1) * sizeof(off_t);
-	if (read(fd, fcb->row_ptr, n) != n)
-	    goto badread;
-	return 1;
-     * 3.0 row address array is in a machine independent format
-     * (warning - the format will work even if the sizeof(off_t) is
-     *  not the same from machine to machine, as long as the
-     *  actual values do not exceed the capability of the off_t)
-    if (read(fd, &nbytes, 1) != 1)
-	goto badread;
-    if (nbytes == 0)
-	goto badread;
-    n = (nrows + 1) * nbytes;
-    buf = G_malloc(n);
-    if (read(fd, buf, n) != n)
-	goto badread;
-    for (row = 0, b = buf; row <= nrows; row++) {
-	off_t v = 0;
-	for (n = 0; n < (int)nbytes; n++) {
-	    unsigned char c = *b++;
-	    if (nbytes > sizeof(off_t) && n < nbytes - sizeof(off_t) &&
-		c != 0)
-		goto badread;
-	    v <<= 8;
-	    v += c;
-	fcb->row_ptr[row] = v;
-    G_free(buf);
-    return 1;
-  badread:
-    G_warning(_("Fail of initial read of compressed file [%s in %s]"),
-	      fcb->name, fcb->mapset);
-    return -1;
-int G__write_row_ptrs(int fd)
-    int nbytes = sizeof(off_t);
-    int len, row, result;
-    lseek(fd, 0L, SEEK_SET);
-    len = (nrows + 1) * nbytes + 1;
-    b = buf = G_malloc(len);
-    *b++ = nbytes;
-    for (row = 0; row <= nrows; row++) {
-	off_t v = fcb->row_ptr[row];
-	int i;
-	for (i = nbytes - 1; i >= 0; i--) {
-	    b[i] = v & 0xff;
-	    v >>= 8;
-	b += nbytes;
-    result = (write(fd, buf, len) == len);
-    G_free(buf);
-    return result;
Deleted: grass/trunk/lib/gis/fpreclass.c
--- grass/trunk/lib/gis/fpreclass.c	2009-06-20 21:39:23 UTC (rev 38002)
+++ grass/trunk/lib/gis/fpreclass.c	2009-06-20 22:03:23 UTC (rev 38003)
@@ -1,719 +0,0 @@
- *  G_fpreclass_init (r)
- *       struct FPReclass *r;
- *  initializes new reclassification structure. calls
- *  G_fpreclass_clear() before it returns.
- *  void
- *  G_fpreclass_reset (r)
- *  resets the number of defined rules to 0 and free's space allocated
- *  for rules. calls G_fpreclass_clear ().
- *  void
- *  G_fpreclass_clear (r)
- *  resets the number of defined rules to 0. Resets default Min and Max
- *  to be unknown. (see G_fpreclass_set_domain (), G_fpreclass_set_range ()).
- *  deactivates default mapping.
- *  void
- *  G_fpreclass_set_domain (r, dLow, dHigh)
- *       DCELL dLow, dHigh;
- *  defines the domain for the default mapping and
- *  activates default mapping. (see G_fpreclass_perform_d ()).
- *  note: dHigh < dLow is valid.
- *  void
- *  G_fpreclass_set_range (r, low, high)
- *       DCELL low, high;
- *  defines the range for the default mapping. does NOT
- *  activate default mapping. (see G_fpreclass_perform_d ()).
- *  int
- *  G_fpreclass_get_limits (r, dMin, dMax, rMin, rmax)
- *       const struct FPReclass *r;
- *       DCELL *dMin, *dMax;
- *       DCELL *rMin, *rmax;
- *  returns the minimum and maximum values of all the rules defined.
- *  returns: -1 if after G_fpreclass_init (), or any call to
- *                 G_fpreclass_clear () or G_fpreclass_reset () neither
- *                 G_fpreclass_add_rule () nor G_fpreclass_set_domain () is
- *                 used. in this case the returned minimum and maximum
- *                 range and domain values are undefined.
- *            0 if the default rule values are returned.domain values
- *                 are identical to those set with G_fpreclass_set_domain ().
- *                 range values are either reclassification internal default,
- *                 or the values set with G_fpreclass_set_range ().
- *            1 otherwise. in this case the values returned correspond
- *                 to the extreme values of the defined rules (they need
- *                 not be identical to the values set with
- *                 G_fpreclass_set_domain ()).
- *  int
- *  G_fpreclass_nof_rules (r)
- *  returns the number of reclassification rules defined. This number does
- *  not include the 2 infinite intervals.
- *  void
- *  G_fpreclass_get_ith_rule (r, i, dLow, dHigh, rLow, rHigh)
- *       int i;
- *       DCELL *dLow, *dHigh;
- *       DCELL *rLow, *rHigh;
- *  returns the i'th reclassification rule, for
- *  0 <= i < G_fpreclass_nof_rules().
- *  a larger value for i means that the rule has been added later.
- *   void
- *   G_fpreclass_set_neg_infinite_rule (r, dLeft, c)
- *       DCELL dLeft;
- *       DCELL c;
- *   defines a rule for values "dLeft" and smaller. values in this range
- *   are mapped to "c" if none of the "finite" reclassification rules applies.
- *  int
- *  G_fpreclass_get_neg_infinite_rule (r, dLeft, c)
- *       DCELL *dLeft;
- *       DCELL *c;
- *  returns in "dLeft" and "c" the rule values for the negative infinite
- *  interval (see G_fpreclass_set_neg_infinite_rule ()).
- *  returns: 0 if this rule is not defined
- *           1 otherwise.
- *   void
- *   G_fpreclass_set_pos_infinite_rule (r, dRight, c)
- *       DCELL dRight;
- *       DCELL c;
- *   defines a rule for values "dRight" and larger. values in this range
- *   are mapped to "c" if neither any of the "finite" reclassification
- *   rules nor the negative infinite rule applies.
- *  int
- *  G_fpreclass_get_pos_infinite_rule (r, dRight, c)
- *       DCELL *dRight;
- *       DCELL *c;
- *  returns in "dRight" and "c" the rule values for the positive infinite
- *  interval (see G_fpreclass_set_pos_infinite_rule ()).
- *           1 otherwise.
- *  void
- *  G_fpreclass_reverse_rule_order (r)
- *  reverses the order in which the reclassification rules are stored. (see
- *  also G_fpreclass_get_ith_rule () and G_fpreclass_perform_XY ()).
- *  void
- *  G_fpreclass_add_rule (r, dLow, dHigh, rLow, rHigh)
- *       DCELL rLow, rHigh;
- *  adds a new rule to the set of reclassification rules. if dLow > dHigh
- *  the rule will be stored with the low and high values interchanged.
- *  Note: currently no cleanup of rules is performed, i.e. redundant
- *        rules are not removed.
- *  DCELL
- *  G_fpreclass_get_cell_value (r, cellValue)
- *       DCELL *cellValue;
- *  returns the reclassified value corresponding to "cellValue".
- *  if several reclassification rules apply for cellValue, the one which has
- *  been inserted latest (i.e. the one of them which is returned by
- *  G_fpreclass_get_ith_rule() for the largest i) is used. if no such rule
- *  applies the cellValue is first tested against the negative infinite
- *  rule, and finally against the positive infinite rule. if none of
- *  these rules apply, NO_DATA is returned. the actual value of NO_DATA
- *  is found by calling G_set_d_null_value()
- *  if after G_fpreclass_init (), or any call to G_fpreclass_clear () or
- *  G_fpreclass_reset () neither G_fpreclass_add_rule (),
- *  G_fpreclass_set_neg_infinite_rule (),
- *  G_fpreclass_set_pos_infinite_rule (), *  nor  G_fpreclass_set_domain ()
- *  is used NO_DATA is returned independently of the cellValue.
- *  if G_fpreclass_set_domain () is called but no explicit reclassification
- *  rule is set, the default mapping to the cell range set with
- *  G_fpreclass_set_range () or, if the cell range is not set,
- *  to the default CELL range [0,256 - 1] is applied.
- *  void
- *  G_fpreclass_perform_XY (r, xcell, ycell, n)
- *       XCELL *xcell;
- *       YCELL *ycell;
- *       int n;
- *  "X" and "Y" in the function name can be any of "d", "f", or "i". These
- *  correspond to "DCELL", "FCELL", and "CELL", respectively, and denote
- *  the type of the domain and range values.
- *  returns in "ycell" the reclassified YCELL values corresponding to the
- *  XCELL values stored in "xcell". the number of elements reclassified
- *  is n. reclassification is performed by repeated application of
- *  G_fpreclass_get_cell_value ().
-   the reclassification table is stored as a linear array. rules are added
-   starting from index 0. redundant rules are not eliminated. rules are tested
-   from the highest index downto 0. there are two "infinite" rules. support is
-   provided to reverse the order of the rules.
-#undef MIN
-#undef MAX
-#define MIN(a,b) ((a) < (b) ? (a) : (b))
-#define MAX(a,b) ((a) > (b) ? (a) : (b))
-#define NO_DEFAULT_RULE (! r->defaultDRuleSet)
-#define NO_LEFT_INFINITE_RULE (! r->infiniteLeftSet)
-#define NO_RIGHT_INFINITE_RULE (! r->infiniteRightSet)
-#define NO_FINITE_RULE (r->nofRules <= 0)
-#define NO_EXPLICIT_RULE (NO_FINITE_RULE && \
-			  NO_LEFT_INFINITE_RULE && NO_RIGHT_INFINITE_RULE)
-#define DEFAULT_MIN ((DCELL) 1)
-#define DEFAULT_MAX ((DCELL) 255)
-void G_fpreclass_clear(struct FPReclass *r)
-    r->nofRules = 0;
-    r->defaultDRuleSet = 0;
-    r->defaultRRuleSet = 0;
-    r->infiniteRightSet = r->infiniteLeftSet = 0;
-void G_fpreclass_reset(struct FPReclass *r)
-    G_fpreclass_clear(r);
-    if (r->maxNofRules > 0)
-	G_free(r->table);
-    r->maxNofRules = 0;
-void G_fpreclass_init(struct FPReclass *r)
-    G_fpreclass_reset(r);
-void G_fpreclass_set_domain(struct FPReclass *r, DCELL dLow, DCELL dHigh)
-    r->defaultDMin = dLow;
-    r->defaultDMax = dHigh;
-    r->defaultDRuleSet = 1;
-void G_fpreclass_set_range(struct FPReclass *r, DCELL low, DCELL high)
-    r->defaultRMin = low;
-    r->defaultRMax = high;
-    r->defaultRRuleSet = 1;
-static void fpreclass_set_limits(struct FPReclass *r,
-				 DCELL dLow, DCELL dHigh,
-				 DCELL rLow, DCELL rHigh)
-    r->dMin = dLow;
-    r->dMax = dHigh;
-    r->rMin = rLow;
-    r->rMax = rHigh;
-static void fpreclass_update_limits(struct FPReclass *r,
-    if (NO_EXPLICIT_RULE) {
-	fpreclass_set_limits(r, dLow, dHigh, rLow, rHigh);
-	return;
-    r->dMin = MIN(r->dMin, MIN(dLow, dHigh));
-    r->dMax = MAX(r->dMax, MAX(dLow, dHigh));
-    r->rMin = MIN(r->rMin, MIN(rLow, rHigh));
-    r->rMax = MAX(r->rMax, MAX(rLow, rHigh));
-int G_fpreclass_get_limits(const struct FPReclass *r,
-			   DCELL * dMin, DCELL * dMax,
-			   DCELL * rMin, DCELL * rMax)
-	if (NO_DEFAULT_RULE)
-	    return -1;
-	*dMin = r->defaultDMin;
-	*dMax = r->defaultDMax;
-	if (r->defaultRRuleSet) {
-	    *rMin = r->defaultRMin;
-	    *rMax = r->defaultRMax;
-	else {
-	    *rMin = DEFAULT_MIN;
-	    *rMax = DEFAULT_MAX;
-	return 0;
-    *dMin = r->dMin;
-    *dMax = r->dMax;
-    *rMin = r->rMin;
-    *rMax = r->rMax;
-    return 1;
-int G_fpreclass_nof_rules(const struct FPReclass *r)
-    return r->nofRules;
-void G_fpreclass_get_ith_rule(const struct FPReclass *r, int i,
-			      DCELL *dLow, DCELL *dHigh,
-			      DCELL *rLow, DCELL *rHigh)
-    *dLow = r->table[i].dLow;
-    *dHigh = r->table[i].dHigh;
-    *rLow = r->table[i].rLow;
-    *rHigh = r->table[i].rHigh;
-static void fpreclass_table_increase(struct FPReclass *r)
-    if (r->nofRules < r->maxNofRules)
-	return;
-    if (r->maxNofRules == 0) {
-	r->maxNofRules = 50;
-	r->table = (struct FPReclass_table *)
-	    G_malloc(r->maxNofRules * sizeof(struct FPReclass_table));
-    else {
-	r->maxNofRules += 50;
-	    G_realloc((char *)r->table,
-		      r->maxNofRules * sizeof(struct FPReclass_table));
-void
-G_fpreclass_set_neg_infinite_rule(struct FPReclass *r, DCELL dLeft, DCELL c)
-    r->infiniteDLeft = dLeft;
-    r->infiniteRLeft = c;
-    fpreclass_update_limits(r, dLeft, dLeft, c, c);
-    r->infiniteLeftSet = 1;
-int G_fpreclass_get_neg_infinite_rule(const struct FPReclass *r,
-				      DCELL *dLeft, DCELL *c)
-    if (r->infiniteLeftSet == 0)
-	return 0;
-    *dLeft = r->infiniteDLeft;
-    *c = r->infiniteRLeft;
-    return 1;
-void G_fpreclass_set_pos_infinite_rule(struct FPReclass *r, DCELL dRight, DCELL c)
-    r->infiniteDRight = dRight;
-    r->infiniteRRight = c;
-    fpreclass_update_limits(r, dRight, dRight, c, c);
-    r->infiniteRightSet = 1;
-int G_fpreclass_get_pos_infinite_rule(const struct FPReclass *r,
-				      DCELL *dRight, DCELL *c)
-    if (r->infiniteRightSet == 0)
-	return 0;
-    *dRight = r->infiniteDRight;
-    *c = r->infiniteRRight;
-    return 1;
-void G_fpreclass_add_rule(struct FPReclass *r,
-    int i;
-    struct FPReclass_table *p;
-    fpreclass_table_increase(r);
-    i = r->nofRules;
-    p = &(r->table[i]);
-    if (dHigh >= dLow) {
-	p->dLow = dLow;
-	p->dHigh = dHigh;
-	p->rLow = rLow;
-	p->rHigh = rHigh;
-    else {
-	p->dLow = dHigh;
-	p->dHigh = dLow;
-	p->rLow = rHigh;
-	p->rHigh = rLow;
-    fpreclass_update_limits(r, dLow, dHigh, rLow, rHigh);
-    r->nofRules++;
-void G_fpreclass_reverse_rule_order(struct FPReclass *r)
-    struct FPReclass_table tmp;
-    struct FPReclass_table *pLeft, *pRight;
-    pLeft = r->table;
-    pRight = &(r->table[r->nofRules - 1]);
-    while (pLeft < pRight) {
-	tmp.dLow = pLeft->dLow;
-	tmp.dHigh = pLeft->dHigh;
-	tmp.rLow = pLeft->rLow;
-	tmp.rHigh = pLeft->rHigh;
-	pLeft->dLow = pRight->dLow;
-	pLeft->dHigh = pRight->dHigh;
-	pLeft->rLow = pRight->rLow;
-	pLeft->rHigh = pRight->rHigh;
-	pRight->dLow = tmp.dLow;
-	pRight->dHigh = tmp.dHigh;
-	pRight->rLow = tmp.rLow;
-	pRight->rHigh = tmp.rHigh;
-	pLeft++;
-	pRight--;
-static DCELL fpreclass_interpolate(
-    DCELL rLow, DCELL rHigh,
-    DCELL dValue)
-    if (rLow == rHigh)
-	return rLow;
-    if (dLow == dHigh)
-	return rLow;
-    return ((dValue - dLow) / (dHigh - dLow) * (rHigh - rLow) + rLow);
-static DCELL fpreclass_get_default_cell_value(const struct FPReclass *r, DCELL cellVal)
-    DCELL tmp;
-    G_set_d_null_value(&tmp, 1);
-    if ((cellVal < MIN(r->defaultDMin, r->defaultDMax)) ||
-	(cellVal > MAX(r->defaultDMin, r->defaultDMax)))
-	return tmp;
-	return fpreclass_interpolate(r->defaultDMin, r->defaultDMax,
-				     r->defaultRMin, r->defaultRMax, cellVal);
-    else
-				     DEFAULT_MIN, DEFAULT_MAX, cellVal);
-DCELL G_fpreclass_get_cell_value(const struct FPReclass * r, DCELL cellVal)
-    DCELL tmp;
-    const struct FPReclass_table *p;
-	    return tmp;
-	return fpreclass_get_default_cell_value(r, cellVal);
-    if (!NO_FINITE_RULE)
-	for (p = &(r->table[r->nofRules - 1]); p >= r->table; p--)
-	    if ((cellVal >= p->dLow) && (cellVal <= p->dHigh))
-		return fpreclass_interpolate(p->dLow, p->dHigh, p->rLow,
-					     p->rHigh, cellVal);
-    if ((!NO_LEFT_INFINITE_RULE) && (cellVal <= r->infiniteDLeft))
-	return r->infiniteRLeft;
-    if ((NO_RIGHT_INFINITE_RULE) || (cellVal < r->infiniteDRight))
-	return tmp;
-    return r->infiniteRRight;
-void G_fpreclass_perform_di(const struct FPReclass *r,
-			    const DCELL *dcell, CELL *cell, int n)
-    int i;
-    for (i = 0; i < n; i++, dcell++)
-	if (!G_is_d_null_value(dcell))
-	    *cell++ = G_fpreclass_get_cell_value(r, *dcell);
-	else
-	    G_set_c_null_value(cell++, 1);
-void G_fpreclass_perform_df(const struct FPReclass *r,
-			    const DCELL *dcell, FCELL *cell, int n)
-    int i;
-	else
-	    G_set_f_null_value(cell++, 1);
-void G_fpreclass_perform_dd(const struct FPReclass *r,
-			    const DCELL *dcell, DCELL *cell, int n)
-    int i;
-	else
-	    G_set_d_null_value(cell++, 1);
-void G_fpreclass_perform_fi(const struct FPReclass *r,
-			    const FCELL *fcell, CELL *cell, int n)
-    int i;
-    for (i = 0; i < n; i++, fcell++)
-	if (!G_is_f_null_value(fcell))
-	    *cell++ = G_fpreclass_get_cell_value(r, (DCELL) * fcell);
-	else
-void G_fpreclass_perform_ff(const struct FPReclass *r,
-			    const FCELL *fcell, FCELL *cell, int n)
-    int i;
-	else
-void G_fpreclass_perform_fd(const struct FPReclass *r,
-			    const FCELL *fcell, DCELL *cell, int n)
-    int i;
-	else
-void G_fpreclass_perform_ii(const struct FPReclass *r,
-			    const CELL *icell, CELL *cell, int n)
-    int i;
-    for (i = 0; i < n; i++, icell++)
-	if (!G_is_c_null_value(icell))
-	    *cell++ = G_fpreclass_get_cell_value(r, (DCELL) * icell);
-	else
-void G_fpreclass_perform_if(const struct FPReclass *r,
-			    const CELL *icell, FCELL *cell, int n)
-    int i;
-	else
-void G_fpreclass_perform_id(const struct FPReclass *r,
-			    const CELL *icell, DCELL *cell, int n)
-    int i;
-	else
Deleted: grass/trunk/lib/gis/gdal.c
--- grass/trunk/lib/gis/gdal.c	2009-06-20 21:39:23 UTC (rev 38002)
+++ grass/trunk/lib/gis/gdal.c	2009-06-20 22:03:23 UTC (rev 38003)
@@ -1,530 +0,0 @@
-#include <stdlib.h>
-#include <string.h>
-#include <grass/glocale.h>
-#include "G.h"
-#ifndef HAVE_GDAL
-#undef GDAL_LINK
-#endif
-#ifdef GDAL_LINK
-#ifdef GDAL_DYNAMIC
-# if defined(__unix) || defined(__unix__)
-#  include <dlfcn.h>
-# endif
-# ifdef _WIN32
-#  include <windows.h>
-# endif
-#endif
-static void CPL_STDCALL (*pGDALAllRegister)(void);
-static void CPL_STDCALL (*pGDALClose)(GDALDatasetH);
-static GDALRasterBandH CPL_STDCALL (*pGDALGetRasterBand)(GDALDatasetH, int);
-static GDALDatasetH CPL_STDCALL (*pGDALOpen)(
-    const char *pszFilename, GDALAccess eAccess);
-static CPLErr CPL_STDCALL (*pGDALRasterIO)(
-    GDALRasterBandH hRBand, GDALRWFlag eRWFlag,
-    int nDSXOff, int nDSYOff, int nDSXSize, int nDSYSize,
-    void * pBuffer, int nBXSize, int nBYSize,GDALDataType eBDataType,
-    int nPixelSpace, int nLineSpace);
-static GDALDriverH CPL_STDCALL (*pGDALGetDriverByName)(const char *);
-static const char * CPL_STDCALL (*pGDALGetMetadataItem)(GDALMajorObjectH, const char *, const char *);
-static GDALDatasetH CPL_STDCALL (*pGDALCreate)(GDALDriverH hDriver, const char *, int, int, int, GDALDataType, char **);
-static GDALDatasetH CPL_STDCALL (*pGDALCreateCopy)(GDALDriverH, const char *, GDALDatasetH, int, char **, GDALProgressFunc, void *);
-static CPLErr CPL_STDCALL (*pGDALSetRasterNoDataValue)(GDALRasterBandH, double);
-static CPLErr CPL_STDCALL (*pGDALSetGeoTransform)(GDALDatasetH, double *);
-static CPLErr CPL_STDCALL (*pGDALSetProjection)(GDALDatasetH, const char *);
-static const char * CPL_STDCALL (*pGDALGetDriverShortName)(GDALDriverH);
-static GDALDriverH CPL_STDCALL (*pGDALGetDatasetDriver)(GDALDatasetH);
-#if GDAL_DYNAMIC
-# if defined(__unix) && !defined(__unix__)
-#  define __unix__ __unix
-# endif
-static void *library_h;
-static void *get_symbol(const char *name)
-    void *sym;
-# ifdef __unix__
-    sym = dlsym(library_h, name);
-# endif
-# ifdef _WIN32
-    sym = GetProcAddress((HINSTANCE) library_h, name);
-# endif
-    if (!sym)
-	G_fatal_error(_("Unable to locate symbol <%s>"), name);
-    return sym;
-static void try_load_library(const char *name)
-# ifdef __unix__
-    library_h = dlopen(name, RTLD_NOW);
-# endif
-# ifdef _WIN32
-    library_h = LoadLibrary(name);
-# endif
-static void load_library(void)
-    static const char * const candidates[] = {
-# ifdef __unix__
-	"libgdal.1.1.so",
-	"gdal.1.0.so",
-	"gdal.so.1.0",
-	"libgdal.so.1",
-	"libgdal.so",
-# endif
-# ifdef _WIN32
-	"gdal11.dll",
-	"gdal.1.0.dll",
-	"gdal.dll",
-# endif
-	NULL
-    int i;
-    for (i = 0; candidates[i]; i++) {
-	try_load_library(candidates[i]);
-	if (library_h)
-	    return;
-    G_fatal_error(_("Unable to load GDAL library"));
-static void init_gdal(void)
-    load_library();
-    pGDALAllRegister          = get_symbol("GDALAllRegister");
-    pGDALOpen                 = get_symbol("GDALOpen");
-    pGDALClose                = get_symbol("GDALClose");
-    pGDALGetRasterBand        = get_symbol("GDALGetRasterBand");
-    pGDALRasterIO             = get_symbol("GDALRasterIO");
-    pGDALGetDriverByName      = get_symbol("GDALGetDriverByName");
-    pGDALGetMetadataItem      = get_symbol("GDALGetMetadataItem");
-    pGDALCreate               = get_symbol("GDALCreate");
-    pGDALCreateCopy           = get_symbol("GDALCreateCopy");
-    pGDALSetRasterNoDataValue = get_symbol("GDALSetRasterNoDataValue");
-    pGDALSetGeoTransform      = get_symbol("GDALSetGeoTransform");
-    pGDALSetProjection        = get_symbol("GDALSetProjection");
-    pGDALGetDriverShortName   = get_symbol("GDALGetDriverShortName");
-    pGDALGetDatasetDriver     = get_symbol("GDALGetDatasetDriver");
-#else /* GDAL_DYNAMIC */
-    pGDALAllRegister          = &GDALAllRegister;
-    pGDALOpen                 = &GDALOpen;
-    pGDALClose                = &GDALClose;
-    pGDALGetRasterBand        = &GDALGetRasterBand;
-    pGDALRasterIO             = &GDALRasterIO;
-    pGDALGetDriverByName      = &GDALGetDriverByName;
-    pGDALGetMetadataItem      = &GDALGetMetadataItem;
-    pGDALCreate               = &GDALCreate;
-    pGDALCreateCopy           = &GDALCreateCopy;
-    pGDALSetRasterNoDataValue = &GDALSetRasterNoDataValue;
-    pGDALSetGeoTransform      = &GDALSetGeoTransform;
-    pGDALSetProjection        = &GDALSetProjection;
-    pGDALGetDriverShortName   = &GDALGetDriverShortName;
-    pGDALGetDatasetDriver     = &GDALGetDatasetDriver;
-#endif /* GDAL_DYNAMIC */
-#endif /* GDAL_LINK */
-void G_init_gdal(void)
-#ifdef GDAL_LINK
-    static int initialized;
-    if (G_is_initialized(&initialized))
-	return;
-    init_gdal();
-    (*pGDALAllRegister)();
-    G_initialize_done(&initialized);
-#endif
-struct GDAL_link *G_get_gdal_link(const char *name, const char *mapset)
-#ifdef GDAL_LINK
-    GDALDatasetH data;
-    GDALRasterBandH band;
-    GDALDataType type;
-    RASTER_MAP_TYPE req_type;
-#endif
-    const char *filename;
-    int band_num;
-    struct GDAL_link *gdal;
-    RASTER_MAP_TYPE map_type;
-    FILE *fp;
-    struct Key_Value *key_val;
-    const char *p;
-    DCELL null_val;
-    int hflip, vflip;
-    if (!G_find_cell2(name, mapset))
-	return NULL;
-    map_type = G_raster_map_type(name, mapset);
-    if (map_type < 0)
-	return NULL;
-    fp = G_fopen_old_misc("cell_misc", "gdal", name, mapset);
-    if (!fp)
-	return NULL;
-    key_val = G_fread_key_value(fp);
-    fclose(fp);
-    if (!key_val)
-	return NULL;
-    filename = G_find_key_value("file", key_val);
-    if (!filename)
-	return NULL;
-    p = G_find_key_value("band", key_val);
-    if (!p)
-	return NULL;
-    band_num = atoi(p);
-    if (!band_num)
-	return NULL;
-    p = G_find_key_value("null", key_val);
-    if (!p)
-	return NULL;
-    if (strcmp(p, "none") == 0)
-	G_set_d_null_value(&null_val, 1);
-    else
-	null_val = atof(p);
-    hflip = G_find_key_value("hflip", key_val) ? 1 : 0;
-    vflip = G_find_key_value("vflip", key_val) ? 1 : 0;
-#ifdef GDAL_LINK
-    p = G_find_key_value("type", key_val);
-    if (!p)
-	return NULL;
-    type = atoi(p);
-    switch (type) {
-    case GDT_Byte:
-    case GDT_Int16:
-    case GDT_UInt16:
-    case GDT_Int32:
-    case GDT_UInt32:
-	req_type = CELL_TYPE;
-	break;
-    case GDT_Float32:
-	req_type = FCELL_TYPE;
-	break;
-    case GDT_Float64:
-	req_type = DCELL_TYPE;
-	break;
-    default:
-	return NULL;
-    if (req_type != map_type)
-	return NULL;
-    G_init_gdal();
-    data = (*pGDALOpen)(filename, GA_ReadOnly);
-    if (!data)
-	return NULL;
-    band = (*pGDALGetRasterBand)(data, band_num);
-    if (!band) {
-	(*pGDALClose)(data);
-	return NULL;
-#endif
-    gdal = G_calloc(1, sizeof(struct GDAL_link));
-    gdal->filename = G_store(filename);
-    gdal->band_num = band_num;
-    gdal->null_val = null_val;
-    gdal->hflip = hflip;
-    gdal->vflip = vflip;
-#ifdef GDAL_LINK
-    gdal->data = data;
-    gdal->band = band;
-    gdal->type = type;
-#endif
-    return gdal;
-struct GDAL_Options {
-    const char *dir;
-    const char *ext;
-    const char *format;
-    char **options;
-static struct state {
-    int initialized;
-    struct GDAL_Options opts;
-    struct Key_Value *projinfo, *projunits;
-    char *srswkt;
-} state;
-static struct state *st = &state;
-static void read_gdal_options(void)
-    FILE *fp;
-    const char *p;
-    fp = G_fopen_old("", "GDAL", G_mapset());
-    if (!fp)
-	G_fatal_error(_("Unable to open GDAL file"));
-    fclose(fp);
-    p = G_find_key_value("directory", key_val);
-    if (!p)
-	p = "gdal";
-    if (*p == '/')
-	st->opts.dir = G_store(p);
-    else;
-	G__file_name(path, p, "", G_mapset());
-	st->opts.dir = G_store(path);
-	if (access(path, 0) != 0)
-	    G__make_mapset_element(p);
-    p = G_find_key_value("extension", key_val);
-    st->opts.ext = G_store(p ? p : "");
-    p = G_find_key_value("format", key_val);
-    st->opts.format = G_store(p ? p : "GTiff");
-    p = G_find_key_value("options", key_val);
-    st->opts.options = p ? G_tokenize(p, ",") : NULL;
-    G_free_key_value(key_val);
-struct GDAL_link *G_create_gdal_link(const char *name, RASTER_MAP_TYPE map_type)
-#ifdef GDAL_LINK
-    GDALDriverH driver;
-    double transform[6];
-    FILE *fp;
-    char buf[32];
-    G_init_gdal();
-    if (!G_is_initialized(&st->initialized)) {
-	read_gdal_options();
-	st->projinfo = G_get_projinfo();
-	st->projunits = G_get_projunits();
-#if 0
-	/* We cannot use GPJ_grass_to_wkt() here because that would create a
-	   circular dependency between libgis and libgproj */
-	if (st->projinfo && st->projunits)
-	    st->srswkt = GPJ_grass_to_wkt(st->projinfo, st->projunits);
-#endif
-	G_initialize_done(&st->initialized);
-    sprintf(path, "%s/%s%s", st->opts.dir, name, st->opts.ext);
-    gdal->filename = G_store(path);
-    gdal->band_num = 1;
-    gdal->hflip = 0;
-    gdal->vflip = 0;
-    switch (map_type) {
-    case CELL_TYPE:
-	switch (G__.nbytes) {
-	case 1:
-	    gdal->type = GDT_Byte;
-	    gdal->null_val = (DCELL) 0xFF;
-	    break;
-	case 2:
-	    gdal->type = GDT_UInt16;
-	    gdal->null_val = (DCELL) 0xFFFF;
-	    break;
-	case 3:
-	case 4:
-	    gdal->type = GDT_Int32;
-	    gdal->null_val = (DCELL) 0x80000000U;
-	    break;
-	break;
-    case FCELL_TYPE:
-	gdal->type = GDT_Float32;
-	G_set_d_null_value(&gdal->null_val, 1);
-	break;
-    case DCELL_TYPE:
-	gdal->type = GDT_Float64;
-	break;
-    default:
-	G_fatal_error(_("Invalid map type <%d>"), map_type);
-	break;
-    driver = (*pGDALGetDriverByName)(st->opts.format);
-    if (!driver)
-	G_fatal_error(_("Unable to get <%s> driver"), st->opts.format);
-    /* Does driver support GDALCreate ? */
-    if ((*pGDALGetMetadataItem)(driver, GDAL_DCAP_CREATE, NULL))
-	gdal->data = (*pGDALCreate)(driver, gdal->filename, G__.window.cols, G__.window.rows,
-				1, gdal->type, st->opts.options);
-	if (!gdal->data)
-	    G_fatal_error(_("Unable to create <%s> dataset using <%s> driver"),
-			  name, st->opts.format);
-    /* If not - create MEM driver for intermediate dataset.
-     * Check if raster can be created at all (with GDALCreateCopy) */
-    else if ((*pGDALGetMetadataItem)(driver, GDAL_DCAP_CREATECOPY, NULL)) {
-	GDALDriverH mem_driver;
-	G_message(_("Driver <%s> does not support direct writing. "
-		    "Using MEM driver for intermediate dataset."),
-		  st->opts.format);
-	mem_driver = (*pGDALGetDriverByName)("MEM");
-	if (!mem_driver)
-	    G_fatal_error(_("Unable to get in-memory raster driver"));
-	gdal->data = (*pGDALCreate)(mem_driver, "", G__.window.cols, G__.window.rows,
-	if (!gdal->data)
-	    G_fatal_error(_("Unable to create <%s> dataset using memory driver"),
-			  name);
-    else
-	G_fatal_error(_("Driver <%s> does not support creating rasters"),
-		      st->opts.format);
-    gdal->band = (*pGDALGetRasterBand)(gdal->data, gdal->band_num);
-    (*pGDALSetRasterNoDataValue)(gdal->band, gdal->null_val);
-    /* Set Geo Transform  */
-    transform[0] = G__.window.west;
-    transform[1] = G__.window.ew_res;
-    transform[2] = 0.0;
-    transform[3] = G__.window.north;
-    transform[4] = 0.0;
-    transform[5] = -G__.window.ns_res;
-    if ((*pGDALSetGeoTransform)(gdal->data, transform) >= CE_Failure)
-	G_warning(_("Unable to set geo transform"));
-    if (st->srswkt)
-	if ((*pGDALSetProjection)(gdal->data, st->srswkt) == CE_Failure)
-	    G_warning(_("Unable to set projection"));
-    fp = G_fopen_new_misc("cell_misc", "gdal", name);
-    if (!fp)
-	G_fatal_error(_("Unable to create cell_misc/%s/gdal file"), name);
-    key_val = G_create_key_value();
-    G_set_key_value("file", gdal->filename, key_val);
-    sprintf(buf, "%d", gdal->band_num);
-    G_set_key_value("band", buf, key_val);
-    sprintf(buf, "%.22g", gdal->null_val);
-    G_set_key_value("null", buf, key_val);
-    sprintf(buf, "%d", gdal->type);
-    G_set_key_value("type", buf, key_val);
-    if (G_fwrite_key_value(fp, key_val) < 0)
-	G_fatal_error(_("Error writing cell_misc/%s/gdal file"), name);
-    fclose(fp);
-    return gdal;
-#else
-    return NULL;
-#endif
-void G_close_gdal_link(struct GDAL_link *gdal)
-#ifdef GDAL_LINK
-    (*pGDALClose)(gdal->data);
-#endif
-    G_free(gdal->filename);
-    G_free(gdal);
-int G_close_gdal_write_link(struct GDAL_link *gdal)
-    int stat = 1;
-#ifdef GDAL_LINK
-    GDALDriverH src_drv = (*pGDALGetDatasetDriver)(gdal->data);
-    if (G_strcasecmp((*pGDALGetDriverShortName)(src_drv), "MEM") == 0) {
-	GDALDriverH dst_drv = (*pGDALGetDriverByName)(st->opts.format);
-	GDALDatasetH dst = (*pGDALCreateCopy)(dst_drv, gdal->filename, gdal->data, FALSE,
-					      st->opts.options, NULL, NULL);
-	if (!dst) {
-	    G_warning(_("Unable to create output file <%s> using driver <%s>"),
-		      gdal->filename, st->opts.format);
-	    stat = -1;
-	(*pGDALClose)(dst);
-#endif
-    G_free(gdal);
-    return stat;
-#ifdef GDAL_LINK
-CPLErr G_gdal_raster_IO(
-    GDALRasterBandH band, GDALRWFlag rw_flag,
-    int x_off, int y_off, int x_size, int y_size,
-    void *buffer, int buf_x_size, int buf_y_size, GDALDataType buf_type,
-    int pixel_size, int line_size)
-    return (*pGDALRasterIO)(
-	band, rw_flag, x_off, y_off, x_size, y_size,
-	buffer, buf_x_size, buf_y_size, buf_type,
-	pixel_size, line_size);
-#endif
Deleted: grass/trunk/lib/gis/get_cellhd.c
--- grass/trunk/lib/gis/get_cellhd.c	2009-06-20 21:39:23 UTC (rev 38002)
+++ grass/trunk/lib/gis/get_cellhd.c	2009-06-20 22:03:23 UTC (rev 38003)
@@ -1,95 +0,0 @@
-  \file gis/get_cellhd.c
-  \brief GIS library - Read raster map header
-  (C) 2001-2009 by the GRASS Development Team
-  This program is free software under the GNU General Public License
-  (>=v2).  Read the file COPYING that comes with GRASS for details.
-  \brief Read the raster header
-  The raster header for the raster map <i>name</i> in the specified
-  <i>mapset</i> is read into the <i>cellhd</i> structure. If there is
-  an error reading the raster header file, a diagnostic message is
-  printed and -1 is returned. Otherwise, 0 is returned.
-  <b>Note</b>:a warning message for errors encountered.
-  Cell header files may contain either grid cell header information or
-  reclass information. If it is a reclass file, it will specify the
-  map and mapset names of the actual grid cell file being
-  reclassed. G_get_cellhd(), upon reading reclass information will go
-  read the cell header information for the referenced file. Only one
-  reference is allowed.
-  \param name name of map
-  \param mapset mapset that map belongs to
-  \param[out] cellhd structure to hold cell header info
-  \return 0 on success
-  \return -1 on error
-int G_get_cellhd(const char *name, const char *mapset,
-		 struct Cell_head *cellhd)
-    FILE *fd;
-    int is_reclass;
-    char real_name[GNAME_MAX], real_mapset[GMAPSET_MAX];
-    char buf[1024];
-    char *tail;
-       is_reclass = G_is_reclass (name, mapset, real_name, real_mapset);
-       if (is_reclass < 0)
-       sprintf (buf,"Can't read header file for [%s in %s]\n", name, mapset);
-       tail = buf + strlen(buf);
-       strcpy (tail, "It is a reclass file, but with an invalid format");
-       G_warning(buf);
-       return -1;
-    is_reclass = (G_is_reclass(name, mapset, real_name, real_mapset) > 0);
-    if (is_reclass) {
-	fd = G_fopen_old("cellhd", real_name, real_mapset);
-	if (fd == NULL) {
-	    sprintf(buf,
-		    _("Unable to read header file for raster map <%s@%s>."),
-		    name, mapset);
-	    sprintf(tail, _(" It is a reclass of raster map <%s@%s> "),
-		    real_name, real_mapset);
-	    if (!G_find_cell(real_name, real_mapset))
-		sprintf(tail, _("which is missing."));
-	    else
-		sprintf(tail, _("whose header file can't be opened."));
-	    G_warning ("%s", buf);
-	    return -1;
-    else {
-	fd = G_fopen_old("cellhd", name, mapset);
-	if (fd == NULL) {
-	    G_warning(_("Unable to open header file for raster map <%s@%s>"),
-		      name, mapset);
-	    return -1;
-    G__read_Cell_head(fd, cellhd, 1);
-    fclose(fd);
-    return 0;
Deleted: grass/trunk/lib/gis/get_row.c
--- grass/trunk/lib/gis/get_row.c	2009-06-20 21:39:23 UTC (rev 38002)
+++ grass/trunk/lib/gis/get_row.c	2009-06-20 22:03:23 UTC (rev 38003)
@@ -1,1220 +0,0 @@
-  \file gis/get_row.c
-  \brief GIS library - Get raster row
-  (C) 2003-2009 by the GRASS Development Team
-#include <sys/types.h>
-#include <rpc/types.h>		/* need this for sgi */
-#include <rpc/xdr.h>
-#include "G.h"
-#define NULL_FILE   "null"
-static int embed_nulls(int, void *, int, RASTER_MAP_TYPE, int, int);
-static int compute_window_row(int fd, int row, int *cellRow)
-    double f;
-    int r;
-    /* check for row in window */
-    if (row < 0 || row >= G__.window.rows) {
-	G_warning(_("Reading raster map <%s@%s> request for row %d is outside region"),
-		  fcb->name, fcb->mapset, row);
-	return -1;
-    /* convert window row to cell file row */
-    f = row * fcb->C1 + fcb->C2;
-    r = (int)f;
-    if (f < r)			/* adjust for rounding up of negatives */
-	r--;
-    if (r < 0 || r >= fcb->cellhd.rows)
-	return 0;
-    *cellRow = r;
-    return 1;
-static void do_reclass_int(int fd, void *cell, int null_is_zero)
-    CELL *c = cell;
-    CELL *reclass_table = fcb->reclass.table;
-    CELL min = fcb->reclass.min;
-    CELL max = fcb->reclass.max;
-    int i;
-    for (i = 0; i < G__.window.cols; i++) {
-	if (G_is_c_null_value(&c[i])) {
-	    if (null_is_zero)
-		c[i] = 0;
-	    continue;
-	if (c[i] < min || c[i] > max) {
-	    if (null_is_zero)
-		c[i] = 0;
-	    else
-		G_set_c_null_value(&c[i], 1);
-	    continue;
-	c[i] = reclass_table[c[i] - min];
-	if (null_is_zero && G_is_c_null_value(&c[i]))
-	    c[i] = 0;
-static int read_data_fp_compressed(int fd, int row, unsigned char *data_buf,
-				   int *nbytes)
-    off_t t1 = fcb->row_ptr[row];
-    off_t t2 = fcb->row_ptr[row + 1];
-    size_t readamount = t2 - t1;
-    size_t bufsize = fcb->cellhd.cols * fcb->nbytes;
-    if (lseek(fd, t1, SEEK_SET) < 0)
-	return -1;
-    *nbytes = fcb->nbytes;
-    if ((size_t) G_zlib_read(fd, readamount, data_buf, bufsize) != bufsize)
-	return -1;
-    return 0;
-static void rle_decompress(unsigned char *dst, const unsigned char *src,
-			   int nbytes, int size)
-    int pairs = size / (nbytes + 1);
-    int i;
-    for (i = 0; i < pairs; i++) {
-	int repeat = *src++;
-	int j;
-	for (j = 0; j < repeat; j++) {
-	    memcpy(dst, src, nbytes);
-	    dst += nbytes;
-	src += nbytes;
-static int read_data_compressed(int fd, int row, unsigned char *data_buf,
-				int *nbytes)
-    ssize_t readamount = t2 - t1;
-    unsigned char *cmp;
-    int n;
-	return -1;
-    cmp = G__alloca(readamount);
-    if (read(fd, cmp, readamount) != readamount) {
-	G__freea(cmp);
-	return -1;
-    /* Now decompress the row */
-    if (fcb->cellhd.compressed > 0) {
-	/* one byte is nbyte count */
-	n = *nbytes = *cmp++;
-	readamount--;
-    else
-	/* pre 3.0 compression */
-	n = *nbytes = fcb->nbytes;
-    if (fcb->cellhd.compressed < 0 || readamount < n * fcb->cellhd.cols) {
-	if (fcb->cellhd.compressed == 2)
-	    G_zlib_expand(cmp, readamount, data_buf, n * fcb->cellhd.cols);
-	else
-	    rle_decompress(data_buf, cmp, n, readamount);
-    else
-	memcpy(data_buf, cmp, readamount);
-    G__freea(cmp);
-    return 0;
-static int read_data_uncompressed(int fd, int row, unsigned char *data_buf,
-				  int *nbytes)
-    ssize_t bufsize = fcb->cellhd.cols * fcb->nbytes;
-    if (lseek(fd, (off_t) row * bufsize, SEEK_SET) == -1)
-	return -1;
-    if (read(fd, data_buf, bufsize) != bufsize)
-	return -1;
-    return 0;
-#ifdef HAVE_GDAL
-static int read_data_gdal(int fd, int row, unsigned char *data_buf, int *nbytes)
-    unsigned char *buf;
-    CPLErr err;
-    if (fcb->gdal->vflip)
-	row = fcb->cellhd.rows - 1 - row;
-    buf = fcb->gdal->hflip
-	? G__alloca(fcb->cellhd.cols * fcb->cur_nbytes)
-	: data_buf;
-    err = G_gdal_raster_IO(
-	fcb->gdal->band, GF_Read, 0, row, fcb->cellhd.cols, 1, buf,
-	fcb->cellhd.cols, 1, fcb->gdal->type, 0, 0);
-    if (fcb->gdal->hflip) {
-	int i;
-	for (i = 0; i < fcb->cellhd.cols; i++)
-	    memcpy(data_buf + i * fcb->cur_nbytes,
-		   buf + (fcb->cellhd.cols - 1 - i) * fcb->cur_nbytes,
-		   fcb->cur_nbytes);
-	G__freea(buf);
-    return err == CE_None ? 0 : -1;
-#endif
-static int read_data(int fd, int row, unsigned char *data_buf, int *nbytes)
-#ifdef HAVE_GDAL
-    if (fcb->gdal)
-	return read_data_gdal(fd, row, data_buf, nbytes);
-#endif
-	return read_data_uncompressed(fd, row, data_buf, nbytes);
-    /* map is in compressed form */
-    if (fcb->map_type == CELL_TYPE)
-	return read_data_compressed(fd, row, data_buf, nbytes);
-    else
-	return read_data_fp_compressed(fd, row, data_buf, nbytes);
-/* copy cell file data to user buffer translated by window column mapping */
-static void cell_values_int(int fd, const unsigned char *data,
-			    const COLUMN_MAPPING * cmap, int nbytes,
-			    void *cell, int n)
-    CELL *c = cell;
-    COLUMN_MAPPING cmapold = 0;
-    int big = (size_t) nbytes >= sizeof(CELL);
-    int i;
-	const unsigned char *d;
-	int neg;
-	CELL v;
-	int j;
-	if (!cmap[i]) {
-	    c[i] = 0;
-	    continue;
-	if (cmap[i] == cmapold) {
-	    c[i] = c[i - 1];
-	    continue;
-	d = data + (cmap[i] - 1) * nbytes;
-	if (big && (*d & 0x80)) {
-	    neg = 1;
-	    v = *d++ & 0x7f;
-	else {
-	    neg = 0;
-	    v = *d++;
-	for (j = 1; j < nbytes; j++)
-	    v = (v << 8) + *d++;
-	c[i] = neg ? -v : v;
-	cmapold = cmap[i];
-static void cell_values_float(int fd, const unsigned char *data,
-    FCELL *c = cell;
-    XDR *xdrs = &fcb->xdrstream;
-    int i;
-    /* xdr stream is initialized to read from */
-    /* fcb->data in 'opencell.c' */
-    xdr_setpos(xdrs, 0);
-	if (!cmap[i]) {
-	    c[i] = 0;
-	    continue;
-	    c[i] = c[i - 1];
-	    continue;
-	if (cmap[i] < cmapold) {
-	    cmapold = 0;
-	while (cmapold++ != cmap[i])	/* skip */
-	    if (!xdr_float(xdrs, &c[i]))
-		G_fatal_error(_("cell_values_float: xdr_float failed for index %d"),
-			      i);
-	cmapold--;
-static void cell_values_double(int fd, const unsigned char *data,
-    DCELL *c = cell;
-    int i;
-	if (!cmap[i]) {
-	    c[i] = 0;
-	    continue;
-	    c[i] = c[i - 1];
-	    continue;
-	    cmapold = 0;
-	    if (!xdr_double(xdrs, &c[i]))
-		G_fatal_error(_("cell_values_double: xdr_double failed for index %d"),
-			      i);
-	cmapold--;
-#ifdef HAVE_GDAL
-static void gdal_values_int(int fd, const unsigned char *data,
-			    const COLUMN_MAPPING *cmap, int nbytes,
-			    CELL *cell, int n)
-    int i;
-	if (!cmap[i]) {
-	    cell[i] = 0;
-	    continue;
-	    cell[i] = cell[i-1];
-	    continue;
-	switch (fcb->gdal->type) {
-	case GDT_Byte:	    cell[i] = *(GByte   *)d;	break;
-	case GDT_Int16:	    cell[i] = *(GInt16  *)d;	break;
-	case GDT_UInt16:    cell[i] = *(GUInt16 *)d;	break;
-	case GDT_Int32:	    cell[i] = *(GInt32  *)d;	break;
-	case GDT_UInt32:    cell[i] = *(GUInt32 *)d;	break;
-	default:
-	    /* shouldn't happen */
-	    G_set_c_null_value(&cell[i], 1);
-	    break;
-static void gdal_values_float(int fd, const float *data,
-			      FCELL *cell, int n)
-    int i;
-	if (!cmap[i]) {
-	    cell[i] = 0;
-	    continue;
-	    continue;
-	cell[i] = data[cmap[i] - 1];
-static void gdal_values_double(int fd, const double *data,
-			       DCELL *cell, int n)
-    int i;
-	if (!cmap[i]) {
-	    cell[i] = 0;
-	    continue;
-	    continue;
-#endif
-/* transfer_to_cell_XY takes bytes from fcb->data, converts these bytes with
-   the appropriate procedure (e.g. XDR or byte reordering) into type X
-   values which are put into array work_buf.
-   finally the values in work_buf are converted into
-   type Y and put into 'cell'.
-   if type X == type Y the intermediate step of storing the values in
-   work_buf might be ommited. check the appropriate function for XY to
-   determine the procedure of conversion.
-static void transfer_to_cell_XX(int fd, void *cell)
-    static void (*cell_values_type[3]) () = {
-    cell_values_int, cell_values_float, cell_values_double};
-#ifdef HAVE_GDAL
-    static void (*gdal_values_type[3]) () = {
-    gdal_values_int, gdal_values_float, gdal_values_double};
-#endif
-#ifdef HAVE_GDAL
-    if (fcb->gdal)
-    (gdal_values_type[fcb->map_type]) (fd, fcb->data, fcb->col_map,
-				       fcb->cur_nbytes, cell,
-				       G__.window.cols);
-    else
-#endif
-    (cell_values_type[fcb->map_type]) (fd, fcb->data, fcb->col_map,
-				       G__.window.cols);
-static void transfer_to_cell_fi(int fd, void *cell)
-    FCELL *work_buf = G__alloca(G__.window.cols * sizeof(FCELL));
-    int i;
-    transfer_to_cell_XX(fd, work_buf);
-	((CELL *) cell)[i] = (fcb->col_map[i] == 0)
-	    ? 0
-	    : G_quant_get_cell_value(&fcb->quant, work_buf[i]);
-    G__freea(work_buf);
-static void transfer_to_cell_di(int fd, void *cell)
-    DCELL *work_buf = G__alloca(G__.window.cols * sizeof(DCELL));
-    int i;
-	    ? 0
-static void transfer_to_cell_if(int fd, void *cell)
-    CELL *work_buf = G__alloca(G__.window.cols * sizeof(CELL));
-    int i;
-	((FCELL *) cell)[i] = work_buf[i];
-static void transfer_to_cell_df(int fd, void *cell)
-    int i;
-static void transfer_to_cell_id(int fd, void *cell)
-    int i;
-	((DCELL *) cell)[i] = work_buf[i];
-static void transfer_to_cell_fd(int fd, void *cell)
-    int i;
- *   works for all map types and doesn't consider
- *   null row corresponding to the requested row
-static int get_map_row_nomask(int fd, void *rast, int row,
-			      RASTER_MAP_TYPE data_type)
-    static void (*transfer_to_cell_FtypeOtype[3][3])() = {
-	{transfer_to_cell_XX, transfer_to_cell_if, transfer_to_cell_id},
-	{transfer_to_cell_fi, transfer_to_cell_XX, transfer_to_cell_fd},
-	{transfer_to_cell_di, transfer_to_cell_df, transfer_to_cell_XX}
-    int r;
-    int rowStatus;
-    rowStatus = compute_window_row(fd, row, &r);
-    if (rowStatus <= 0) {
-	fcb->cur_row = -1;
-	G_zero_raster_buf(rast, data_type);
-	return rowStatus;
-    /* read cell file row if not in memory */
-    if (r != fcb->cur_row) {
-	fcb->cur_row = r;
-	if (read_data(fd, fcb->cur_row, fcb->data, &fcb->cur_nbytes) < 0) {
-	    if (!fcb->io_error) {
-		if (fcb->cellhd.compressed)
-		    G_warning(_("Error reading compressed map <%s@%s>, row %d"),
-			      fcb->name, fcb->mapset, r);
-		else
-		    G_warning(_("Error reading map <%s@%s>, row %d"),
-		fcb->io_error = 1;
-	    return -1;
-    (transfer_to_cell_FtypeOtype[fcb->map_type][data_type]) (fd, rast);
-    return 1;
-static int get_map_row_no_reclass(int fd, void *rast, int row,
-				  RASTER_MAP_TYPE data_type, int null_is_zero,
-				  int with_mask)
-    int stat;
-    stat = get_map_row_nomask(fd, rast, row, data_type);
-    if (stat < 0)
-	return stat;
-    stat = embed_nulls(fd, rast, row, data_type, null_is_zero, with_mask);
-    if (stat < 0)
-	return stat;
-    return 1;
-static int get_map_row(int fd, void *rast, int row, RASTER_MAP_TYPE data_type,
-		       int null_is_zero, int with_mask)
-    int size = G_raster_size(data_type);
-    CELL *temp_buf = NULL;
-    void *buf;
-    int type;
-    int stat;
-    int i;
-    if (fcb->reclass_flag && data_type != CELL_TYPE) {
-	temp_buf = G__alloca(G__.window.cols * sizeof(CELL));
-	buf = temp_buf;
-	type = CELL_TYPE;
-    else {
-	buf = rast;
-	type = data_type;
-    stat = get_map_row_no_reclass(fd, buf, row, type, null_is_zero, with_mask);
-    if (stat < 0) {
-	if (temp_buf)
-	    G__freea(temp_buf);
-	return stat;
-    if (!fcb->reclass_flag)
-	return 1;
-    /* if the map is reclass table, get and
-       reclass CELL row and copy results to needed type  */
-    do_reclass_int(fd, buf, null_is_zero);
-    if (data_type == CELL_TYPE)
-	return 1;
-	G_set_raster_value_c(rast, temp_buf[i], data_type);
-	rast = G_incr_void_ptr(rast, size);
-    return 1;
- * \brief Read raster row without masking (this routine is deprecated)
- * This routine reads the specified <em>row</em> from the raster map
- * open on file descriptor <em>fd</em> into the <em>buf</em> buffer
- * like G_get_map_row() does. The difference is that masking is
- * suppressed. If the user has a mask set, G_get_map_row() will apply
- * the mask but G_get_map_row_nomask() will ignore it. This routine
- * prints a diagnostic message and returns -1 if there is an error
- * reading the raster map. Otherwise a nonnegative value is returned.
- * <b>Note.</b> Ignoring the mask is not generally acceptable. Users
- * expect the mask to be applied. However, in some cases ignoring the
- * mask is justified. For example, the GRASS modules
- * <i>r.describe</i>, which reads the raster map directly to report
- * all data values in a raster map, and <i>r.slope.aspect</i>, which
- * produces slope and aspect from elevation, ignore both the mask and
- * the region. However, the number of GRASS modules which do this
- * should be minimal. See Mask for more information about the mask.
- * <b>This routine is deprecated! Use G_get_raster_row_nomask()
- * instead.</b>
- * \param fd file descriptor for the opened raster map
- * \param buf buffer for the row to be placed into
- * \param row data row desired
- * \return 1 on success
- * \return 0 row requested not within window
- * \return -1 on error
-int G_get_map_row_nomask(int fd, CELL * buf, int row)
-    return get_map_row(fd, buf, row, CELL_TYPE, 1, 0);
- *  Same as G_get_raster_row() except no masking occurs.
- * \param data_type data type
-int G_get_raster_row_nomask(int fd, void *buf, int row,
-    return get_map_row(fd, buf, row, data_type, 0, 0);
- * \brief Read raster row without masking (CELL type)
- *  Same as G_get_c_raster_row() except no masking occurs.
-int G_get_c_raster_row_nomask(int fd, CELL * buf, int row)
-    return G_get_raster_row_nomask(fd, buf, row, CELL_TYPE);
- * \brief Read raster row without masking (FCELL type)
- *  Same as G_get_f_raster_row() except no masking occurs.
-int G_get_f_raster_row_nomask(int fd, FCELL * buf, int row)
-    return G_get_raster_row_nomask(fd, buf, row, FCELL_TYPE);
- * \brief Read raster row without masking (DCELL type)
- *  Same as G_get_d_raster_row() except no masking occurs.
-int G_get_d_raster_row_nomask(int fd, DCELL * buf, int row)
-    return G_get_raster_row_nomask(fd, buf, row, DCELL_TYPE);
- * \brief Get raster row (this routine is deprecated!)
- * If the map is floating-point, quantize the floating-point values to
- * integer using the quantization rules established for the map when
- * the map was opened for reading (this quantization is read from
- * cell_misc/name/f_quant file, but can be reset after opening raster
- * map by G_set_quant_rules()). NULL values are converted to zeros.
- * <b>This routine is deprecated! Use G_get_raster_row() instead.</b>
-int G_get_map_row(int fd, CELL * buf, int row)
-    return get_map_row(fd, buf, row, CELL_TYPE, 1, 1);
- * If <em>data_type</em> is
- *  - CELL_TYPE, calls G_get_c_raster_row()
- *  - FCELL_TYPE, calls G_get_f_raster_row()
- *  - DCELL_TYPE, calls G_get_d_raster_row()
- *   Reads appropriate information into the buffer <em>buf</em> associated
- *   with the requested row <em>row</em>. <em>buf</em> is associated with the
- *   current window.
- *   Note, that the type of the data in <em>buf</em> (say X) is independent of
- *   the type of the data in the file described by <em>fd</em> (say Y).
- *    - Step 1:  Read appropriate raw map data into a intermediate buffer.
- *    - Step 2:  Convert the data into a CPU readable format, and subsequently
- *            resample the data. the data is stored in a second intermediate
- *            buffer (the type of the data in this buffer is Y).
- *    - Step 3:  Convert this type Y data into type X data and store it in
- *            buffer "buf". Conversion is performed in functions
- *            "transfer_to_cell_XY". (For details of the conversion between
- *            two particular types check the functions).
- *    - Step 4:  read or simmulate null value row and zero out cells corresponding
- *            to null value cells. The masked out cells are set to null when the
- *            mask exists. (the MASK is taken care of by null values
- *            (if the null file doesn't exist for this map, then the null row
- *            is simulated by assuming that all zero are nulls *** in case
- *            of G_get_raster_row() and assuming that all data is valid
- *            in case of G_get_f/d_raster_row(). In case of deprecated function
- *            G_get_map_row() all nulls are converted to zeros (so there are
- *            no embedded nulls at all). Also all masked out cells become zeros.
-int G_get_raster_row(int fd, void *buf, int row, RASTER_MAP_TYPE data_type)
-    return get_map_row(fd, buf, row, data_type, 0, 1);
- * \brief Get raster row (CELL type)
- * Reads a row of raster data and leaves the NULL values intact. (As
- * opposed to the deprecated function G_get_map_row() which
- * converts NULL values to zero.)
- * <b>NOTE.</b> When the raster map is old and null file doesn't
- * exist, it is assumed that all 0-cells are no-data. When map is
- * floating point, uses quant rules set explicitly by
- * G_set_quant_rules() or stored in map's quant file to convert floats
- * to integers.
-int G_get_c_raster_row(int fd, CELL * buf, int row)
-    return G_get_raster_row(fd, buf, row, CELL_TYPE);
- * \brief Get raster row (FCELL type)
- * Read a row from the raster map open on <em>fd</em> into the
- * <tt>float</tt> array <em>fcell</em> performing type conversions as
- * necessary based on the actual storage type of the map. Masking,
- * resampling into the current region.  NULL-values are always
- * embedded in <tt>fcell</tt> (<em>never converted to a value</em>).
-int G_get_f_raster_row(int fd, FCELL * buf, int row)
-    return G_get_raster_row(fd, buf, row, FCELL_TYPE);
- * \brief Get raster row (DCELL type)
- * Same as G_get_f_raster_row() except that the array <em>dcell</em>
- * is <tt>double</tt>.
-int G_get_d_raster_row(int fd, DCELL * buf, int row)
-    return G_get_raster_row(fd, buf, row, DCELL_TYPE);
-static int open_null_read(int fd)
-    const char *name, *mapset, *dummy;
-    int null_fd;
-    if (fcb->null_file_exists == 0)
-	return -1;
-    if (fcb->reclass_flag) {
-	name = fcb->reclass.name;
-	mapset = fcb->reclass.mapset;
-    else {
-	name = fcb->name;
-	mapset = fcb->mapset;
-    dummy = G_find_file2_misc("cell_misc", NULL_FILE, name, mapset);
-    if (!dummy) {
-	/* G_warning("unable to find [%s]",path); */
-	fcb->null_file_exists = 0;
-	return -1;
-    null_fd = G_open_old_misc("cell_misc", NULL_FILE, name, mapset);
-    if (null_fd < 0)
-	return -1;
-    fcb->null_file_exists = 1;
-    return null_fd;
-static int read_null_bits(int null_fd, unsigned char *flags, int row,
-			  int cols, int fd)
-    off_t offset;
-    ssize_t size;
-    int R;
-    if (compute_window_row(fd, row, &R) <= 0) {
-	G__init_null_bits(flags, cols);
-	return 1;
-    if (null_fd < 0)
-	return -1;
-    size = G__null_bitstream_size(cols);
-    offset = (off_t) size *R;
-    if (lseek(null_fd, offset, SEEK_SET) < 0) {
-	G_warning(_("Error reading null row %d"), R);
-	return -1;
-    if (read(null_fd, flags, size) != size) {
-	return -1;
-    return 1;
-static void get_null_value_row_nomask(int fd, char *flags, int row)
-    int i, j, null_fd;
-    if (row > G__.window.rows || row < 0) {
-    if ((fcb->min_null_row > row) ||
-	(fcb->min_null_row + NULL_ROWS_INMEM - 1 < row))
-	/* the null row row is not in memory */
-	unsigned char *null_work_buf = G__alloca(
-	    G__null_bitstream_size(fcb->cellhd.cols));
-	/* read in NULL_ROWS_INMEM rows from null file
-	   so that the requested row is between fcb->min_null_row
-	   and fcb->min_null_row + NULL_ROWS_INMEM */
-	fcb->min_null_row = (row / NULL_ROWS_INMEM) * NULL_ROWS_INMEM;
-	null_fd = open_null_read(fd);
-	for (i = 0; i < NULL_ROWS_INMEM; i++) {
-	    /* G__.window.rows doesn't have to be a multiple of NULL_ROWS_INMEM */
-	    if (i + fcb->min_null_row >= G__.window.rows)
-		break;
-	    if (read_null_bits(null_fd, null_work_buf,
-			       i + fcb->min_null_row, fcb->cellhd.cols,
-			       fd) < 0) {
-		if (fcb->map_type == CELL_TYPE) {
-		    /* If can't read null row, assume  that all map 0's are nulls */
-		    CELL *mask_buf = G__alloca(G__.window.cols * sizeof(CELL));
-		    get_map_row_nomask(fd, mask_buf, i + fcb->min_null_row,
-				       CELL_TYPE);
-		    for (j = 0; j < G__.window.cols; j++)
-			flags[j] = (mask_buf[j] == 0);
-		    G__freea(mask_buf);
-		else {		/* fp map */
-		    /* if can't read null row, assume  that all data is valid */
-		    G_zero(flags, sizeof(char) * G__.window.cols);
-		    /* the flags row is ready now */
-	    }			/*if no null file */
-	    else {
-		/* copy null row to flags row translated by window column mapping */
-		/* the fcb->NULL_ROWS[row-fcb->min_null_row] has G__.window.cols bits, */
-		/* the null_work_buf has size fcb->cellhd.cols */
-		for (j = 0; j < G__.window.cols; j++) {
-		    if (!fcb->col_map[j])
-			flags[j] = 1;
-		    else
-			flags[j] = G__check_null_bit(null_work_buf,
-						     fcb->col_map[j] - 1,
-						     fcb->cellhd.cols);
-	    /* remember the null row for i for the future reference */
-	    /*bf-We should take of the size - or we get
-	       zeros running on their own after flags convertions -A.Sh. */
-	    fcb->NULL_ROWS[i] = G_realloc(fcb->NULL_ROWS[i],
-					  G__null_bitstream_size(G__.window.
-								 cols) + 1);
-	    if (fcb->NULL_ROWS[i] == NULL)
-		G_fatal_error("get_null_value_row_nomask: %s",
-			      _("Unable to realloc buffer"));
-	    G__convert_01_flags(flags, fcb->NULL_ROWS[i], G__.window.cols);
-	}			/* for loop */
-	if (null_fd > 0)
-	    close(null_fd);
-	G__freea(null_work_buf);
-    }				/* row is not in memory */
-    /* copy null file data translated by column mapping to user null row */
-    /* the user requested flags row is of size G__.window.cols */
-    G__convert_flags_01(flags, fcb->NULL_ROWS[row - fcb->min_null_row],
-			G__.window.cols);
-#ifdef HAVE_GDAL
-static void get_null_value_row_gdal(int fd, char *flags, int row)
-    DCELL *tmp_buf = G_allocate_d_raster_buf();
-    int i;
-    if (get_map_row_nomask(fd, tmp_buf, row, DCELL_TYPE) <= 0) {
-	memset(flags, 1, G__.window.cols);
-	G_free(tmp_buf);
-	return;
-	/* note: using == won't work if the null value is NaN */
-	flags[i] = memcmp(&tmp_buf[i], &fcb->gdal->null_val, sizeof(DCELL)) == 0;
-    G_free(tmp_buf);
-#endif
-static void embed_mask(char *flags, int row)
-    int i;
-    if (G__.auto_mask <= 0)
-	return;
-    if (get_map_row_nomask(G__.mask_fd, mask_buf, row, CELL_TYPE) < 0) {
-	return;
-    if (G__.fileinfo[G__.mask_fd].reclass_flag)
-	do_reclass_int(G__.mask_fd, mask_buf, 1);
-	if (mask_buf[i] == 0)
-	    flags[i] = 1;
-static void get_null_value_row(int fd, char *flags, int row, int with_mask)
-#ifdef HAVE_GDAL
-    if (fcb->gdal)
-	get_null_value_row_gdal(fd, flags, row);
-    else
-#endif
-    get_null_value_row_nomask(fd, flags, row);
-    if (with_mask)
-	embed_mask(flags, row);
-static int embed_nulls(int fd, void *buf, int row, RASTER_MAP_TYPE map_type,
-    char *null_buf;
-    int i;
-    /* this is because without null file the nulls can be only due to 0's
-       in data row or mask */
-    if (null_is_zero && !fcb->null_file_exists
-	&& (G__.auto_mask <= 0 || !with_mask))
-	return 1;
-    null_buf = G__alloca(G__.window.cols);
-    get_null_value_row(fd, null_buf, row, with_mask);
-	/* also check for nulls which might be already embedded by quant
-	   rules in case of fp map. */
-	if (null_buf[i] || G_is_null_value(buf, map_type)) {
-	    /* G__set_[f/d]_null_value() sets it to 0 is the embedded mode
-	       is not set and calls G_set_[f/d]_null_value() otherwise */
-	    G__set_null_value(buf, 1, null_is_zero, map_type);
-	buf = G_incr_void_ptr(buf, G_raster_size(map_type));
-    G__freea(null_buf);
-    return 1;
-   \brief Read or simmulate null value row
-   Read or simmulate null value row and set the cells corresponding
-   to null value to 1. The masked out cells are set to null when the
-   mask exists. (the MASK is taken care of by null values
-   (if the null file doesn't exist for this map, then the null row
-   is simulated by assuming that all zeros in raster map are nulls.
-   Also all masked out cells become nulls.
-   \param fd file descriptor for the opened map
-   \param buf buffer for the row to be placed into
-   \param row data row desired
-   \return 1
-int G_get_null_value_row(int fd, char *flags, int row)
-    get_null_value_row(fd, flags, row, 1);
-    return 1;
Deleted: grass/trunk/lib/gis/get_row_colr.c
--- grass/trunk/lib/gis/get_row_colr.c	2009-06-20 21:39:23 UTC (rev 38002)
+++ grass/trunk/lib/gis/get_row_colr.c	2009-06-20 22:03:23 UTC (rev 38003)
@@ -1,69 +0,0 @@
- * \file gis/get_row_colr.c
- * \brief GIS Library - Get raster row (colors)
- * (C) 1999-2009 by the GRASS Development Team
- * This program is free software under the GNU General Public
- * License (>=v2). Read the file COPYING that comes with GRASS
- * for details.
- * \author USACERL and many others
-#include <grass/gis.h>
-#include "G.h"
- * \brief Reads a row of raster data and converts it to RGB.
- * Reads a row of raster data and converts it to red, green and blue
- * components according to the <em>colors</em> parameter. This
- * provides a convenient way to treat a raster layer as a color image
- * without having to explictly cater for each of <tt>CELL</tt>,
- * <tt>FCELL</tt> and <tt>DCELL</tt> types.
- *  \param fd field descriptor
- *  \param row row number
- *  \param colors pointer to Colors structure which holds color info
- *  \param[out] red red value
- *  \param[out] grn green value
- *  \param[out] blu blue value
- *  \param[out] nul null value
- *  \return 0 on success
-int G_get_raster_row_colors(int fd, int row, struct Colors *colors,
-			    unsigned char *red, unsigned char *grn,
-			    unsigned char *blu, unsigned char *nul)
-    int cols = G_window_cols();
-    int type = G_get_raster_map_type(fd);
-    int size = G_raster_size(type);
-    void *array;
-    unsigned char *set;
-    void *p;
-    int i;
-    array = G__alloca(cols * size);
-    if (G_get_raster_row(fd, array, row, type) < 0) {
-	G__freea(array);
-	return -1;
-    if (nul)
-	for (i = 0, p = array; i < cols; i++, p = G_incr_void_ptr(p, size))
-	    nul[i] = G_is_null_value(p, type);
-    set = G__alloca(cols);
-    G_lookup_raster_colors(array, red, grn, blu, set, cols, colors, type);
-    G__freea(array);
-    G__freea(set);
-    return 0;
Modified: grass/trunk/lib/gis/get_window.c
--- grass/trunk/lib/gis/get_window.c	2009-06-20 21:39:23 UTC (rev 38002)
+++ grass/trunk/lib/gis/get_window.c	2009-06-20 22:03:23 UTC (rev 38003)
@@ -12,10 +12,13 @@
 #include <stdlib.h>
-#include "G.h"
+#include <grass/Rast.h>
     int initialized;
     struct Cell_head dbwindow;
@@ -56,7 +59,7 @@
     if (regvar) {
 	char **tokens = G_tokenize(regvar, ";");
-	err = G__read_Cell_head_array(tokens, &st->dbwindow, 0);
+	err = Rast__read_Cell_head_array(tokens, &st->dbwindow, 0);
 	G_free_tokens(tokens);
     else {
@@ -125,7 +128,7 @@
     if (!fp)
 	return G_store(_("is not set"));
-    err = G__read_Cell_head(fp, window, 0);
+    err = Rast__read_Cell_head(fp, window, 0);
     fclose(fp);
     if (err) {
Modified: grass/trunk/lib/gis/gisinit.c
--- grass/trunk/lib/gis/gisinit.c	2009-06-20 21:39:23 UTC (rev 38002)
+++ grass/trunk/lib/gis/gisinit.c	2009-06-20 22:03:23 UTC (rev 38003)
@@ -22,9 +22,11 @@
 #include <locale.h>
-#include "G.h"
 struct G__ G__;
 static int initialized = 0; /** Is set when engine is initialized */
@@ -139,12 +141,12 @@
     G_init_env();
     G_init_logging();
     G__init_window();
-    G__check_for_auto_masking();
+    Rast__check_for_auto_masking();
     G_init_locale();
     G_init_debug();
     G_verbose();
     G_init_tempfile();
-    G_init_gdal();
+    Rast_init_gdal();
     G_get_list_of_mapsets();
     G__home();
     G__machine_name();
Deleted: grass/trunk/lib/gis/histo_eq.c
--- grass/trunk/lib/gis/histo_eq.c	2009-06-20 21:39:23 UTC (rev 38002)
+++ grass/trunk/lib/gis/histo_eq.c	2009-06-20 22:03:23 UTC (rev 38003)
@@ -1,77 +0,0 @@
-* G_histogram_eq (histo, map, min, max)
-*   struct Histogram *histo;    histogram as returned by G_read_histogram()
-*   unsigned char **map;        equalized category mapping
-*   CELL *min, *max;            min,max category for map
-* perform histogram equalization
-* inputs are histo, output is map,min,max
-void G_histogram_eq(const struct Histogram *histo,
-		    unsigned char **map, CELL *min, CELL *max)
-    int i;
-    int x;
-    CELL cat, prev;
-    double total;
-    double sum;
-    double span;
-    int ncats;
-    long count;
-    unsigned char *xmap;
-    int len;
-    int first, last;
-    ncats = G_get_histogram_num(histo);
-    if (ncats == 1) {
-	*min = *max = G_get_histogram_cat(0, histo);
-	*map = xmap = (unsigned char *)G_malloc(1);
-	*xmap = 0;
-	return;
-    if ((*min = G_get_histogram_cat(first = 0, histo)) == 0)
-	*min = G_get_histogram_cat(++first, histo);
-    if ((*max = G_get_histogram_cat(last = ncats - 1, histo)) == 0)
-	*max = G_get_histogram_cat(--last, histo);
-    len = *max - *min + 1;
-    *map = xmap = (unsigned char *)G_malloc(len);
-    total = 0;
-    for (i = first; i <= last; i++) {
-	if (G_get_histogram_cat(i, histo) == 0)
-	    continue;
-	count = G_get_histogram_count(i, histo);
-	if (count > 0)
-	    total += count;
-    if (total <= 0) {
-	for (i = 0; i < len; i++)
-	    xmap[i] = 0;
-	return;
-    span = total / 256;
-    sum = 0.0;
-    cat = *min - 1;
-	prev = cat + 1;
-	cat = G_get_histogram_cat(i, histo);
-	if (count < 0 || cat == 0)
-	    count = 0;
-	x = (sum + (count / 2.0)) / span;
-	if (x < 0)
-	    x = 0;
-	else if (x > 255)
-	    x = 255;
-	sum += count;
-	while (prev++ <= cat)
-	    *xmap++ = x;
Deleted: grass/trunk/lib/gis/histogram.c
--- grass/trunk/lib/gis/histogram.c	2009-06-20 21:39:23 UTC (rev 38002)
+++ grass/trunk/lib/gis/histogram.c	2009-06-20 22:03:23 UTC (rev 38003)
@@ -1,454 +0,0 @@
-#define LIST struct Histogram_list
-static FILE *fopen_histogram_new(const char *);
-static int cmp(const void *, const void *);
-static int cmp_count(const void *, const void *);
- * \brief initializes the histogram structure
- * initializes the histogram structure for calls to G_set_histogram()
- * and G_add_histogram()
- * \param  histogram
- * \return
-void G_init_histogram(struct Histogram *histogram)
-    histogram->num = 0;
-    histogram->list = NULL;
- * \brief read the histogram information
- *  Reads the histogram information associated with map layer "map"
- *  in mapset "mapset" into the structure "histogram".
- *  note:   a warning message is printed if the file is missing or incorrect
- * \param name: name of map
- * \param mapset: mapset that map belongs to
- * \param histogram: struct for histogram
- * \return 1  if successful,
- *               0  if no histogram file,
- *              -1  on fail
-int G_read_histogram(const char *name, const char *mapset,
-		     struct Histogram *histogram)
-    FILE *fd = NULL;
-    long cat;
-    long count;
-    char buf[200];
-    G_init_histogram(histogram);
-    if (G_find_file2_misc("cell_misc", "histogram", name, mapset) == NULL) {
-	G_warning(_("Histogram for [%s in %s] missing (run r.support)"), name,
-		  mapset);
-	return 0;
-    fd = G_fopen_old_misc("cell_misc", "histogram", name, mapset);
-    if (!fd) {
-	G_warning(_("Can't read histogram for [%s in %s]"), name, mapset);
-	return -1;
-    while (fgets(buf, sizeof buf, fd)) {
-	if (sscanf(buf, "%ld:%ld", &cat, &count) != 2) {
-	    G_free_histogram(histogram);
-	    fclose(fd);
-	    G_warning(_("Invalid histogram file for [%s in %s]"), name,
-		      mapset);
-	    return -1;
-	G_extend_histogram((CELL) cat, count, histogram);
-    fclose(fd);
-    if (histogram->num == 0) {
-	G_warning(_("Invalid histogram file for [%s in %s]"), name, mapset);
-	return -1;
-    G_sort_histogram(histogram);
-    return 1;
- * \brief Writes the histogram information
- *  Writes the histogram information associated with map layer "name"
- *              -1  on fail
-int G_write_histogram(const char *name, const struct Histogram *histogram)
-    FILE *fd;
-    int n;
-    LIST *list;
-    fd = fopen_histogram_new(name);
-    if (fd == NULL)
-	return -1;
-    list = histogram->list;
-    for (n = 0; n < histogram->num; n++) {
-	if (list[n].count)
-	    fprintf(fd, "%ld:%ld\n", (long)list[n].cat, list[n].count);
-    fclose(fd);
-    return 1;
- * \brief Writes the histogram based on cell statistics to file
- * \param statf: cell statistics
- *        -1 on failure
-int G_write_histogram_cs(const char *name, struct Cell_stats *statf)
-    FILE *fd;
-    CELL cat;
-    long count;
-    if (fd == NULL)
-	return -1;
-    G_rewind_cell_stats(statf);
-    while (G_next_cell_stat(&cat, &count, statf)) {
-	if (count > 0)
-	    fprintf(fd, "%ld:%ld\n", (long)cat, count);
-    fclose(fd);
-    return 1;
- * \brief Creates histogram based on cell statistics
- * \param histogram: raster histogram
- * \return
-void G_make_histogram_cs(struct Cell_stats *statf, struct Histogram *histogram)
-    CELL cat;
-    long count;
-	G_add_histogram(cat, count, histogram);
- * \brief Sorts the histogram in ascending order by counts then category
- *  Sorts the histogram in ascending order by counts then category.
- *  No combining is done.
- *              -1  on fail
-int G_get_histogram_num(const struct Histogram *histogram)
-    return histogram->num;
- * \brief Returns cat for the nth element in the histogram
- *  Returns cat for the nth element in the histogram
- * \return CELL
-CELL G_get_histogram_cat(int n, const struct Histogram * histogram)
-    if (n < 0 || n >= histogram->num)
-	return 0;
-    return histogram->list[n].cat;
- * \brief Returns count for the nth element in the histogram
- *  Returns count for the nth element in the histogram
- * \param n: nth element
- * \return count
-long G_get_histogram_count(int n, const struct Histogram *histogram)
-	return 0;
-    return histogram->list[n].count;
- * \brief Frees memory allocated for the histogram
- * frees the memory allocated for the histogram
- * \return
-void G_free_histogram(struct Histogram *histogram)
-    if (histogram->num > 0)
-	G_free(histogram->list);
- *  Sorts the histogram in ascending order by category,
- *  combining (by adding) elements that have the same category.
- * \return  0  if successful,
- *              1  on fail
-int G_sort_histogram(struct Histogram *histogram)
-    int a, b, n;
-    LIST *list;
-    /* if histogram only has 1 entry, nothing to do */
-    if ((n = histogram->num) <= 1)
-	return 1;
-    /* quick check to see if sorting needed */
-    for (a = 1; a < n; a++)
-	if (list[a - 1].cat >= list[a].cat)
-	    break;
-    if (a >= n)
-	return 1;
-    /* sort */
-    qsort(list, n, sizeof(LIST), &cmp);
-    /* sum duplicate entries */
-    for (a = 0, b = 1; b < n; b++) {
-	if (list[a].cat != list[b].cat) {
-	    a++;
-	    list[a].count = list[b].count;
-	    list[a].cat = list[b].cat;
-	else {
-	    list[a].count += list[b].count;
-    histogram->num = a + 1;
-    return 0;
-static int cmp(const void *aa, const void *bb)
-    const LIST *a = aa, *b = bb;
-    if (a->cat < b->cat)
-	return -1;
-    if (a->cat > b->cat)
-	return 1;
-    return 0;
- * \brief Sorts the histogram by counts
- *              1  on fail
-int G_sort_histogram_by_count(struct Histogram *histogram)
-    int n;
-    LIST *list;
-	return 1;
-    /* sort */
-    qsort(list, n, sizeof(LIST), &cmp_count);
-    return 0;
-static int cmp_count(const void *aa, const void *bb)
-    if (a->count < b->count)
-	return -1;
-    if (a->count > b->count)
-	return 1;
-	return -1;
-	return 1;
-    return 0;
-static FILE *fopen_histogram_new(const char *name)
-    FILE *fd;
-    fd = G_fopen_new_misc("cell_misc", "histogram", name);
-    if (fd == NULL)
-	G_warning(_("can't create histogram for [%s in %s]"), name,
-		  G_mapset());
-    return fd;
- * \brief Removes the histogram
- *  Removes the histogram information associated with map layer "name"
- * \return
-void G_remove_histogram(const char *name)
-    G_remove_misc("cell_misc", "histogram", name);
- * \brief adds count to the histogram value for cat
- *  adds count to the histogram value for cat
- * \param cat: category
- * \param count
- *              1  on fail
-int G_add_histogram(CELL cat, long count, struct Histogram *histogram)
-    int i;
-    for (i = 0; i < histogram->num; i++) {
-	if (histogram->list[i].cat == cat) {
-	    histogram->list[i].count += count;
-	    return 1;
-    G_extend_histogram(cat, count, histogram);
-    return 0;
- * \brief sets the histogram value for cat to count
- *  sets the histogram value for cat to count
- * \param count
- *              1  on fail
-int G_set_histogram(CELL cat, long count, struct Histogram *histogram)
-    int i;
-	    histogram->list[i].count = count;
-	    return 1;
-    return 0;
- * \brief Extends histogram struct to accomodate a new value
- * \param count
- * \return
-void G_extend_histogram(CELL cat, long count, struct Histogram *histogram)
-    histogram->num++;
-    histogram->list =
-	(LIST *) G_realloc(histogram->list,
-			   histogram->num * sizeof(LIST));
-    histogram->list[histogram->num - 1].cat = cat;
-    histogram->list[histogram->num - 1].count = count;
- * \brief Zero out histogram struct
- * \return
-void G_zero_histogram(struct Histogram *histogram)
-    int i;
-	histogram->list[i].count = 0;
Deleted: grass/trunk/lib/gis/history.c
--- grass/trunk/lib/gis/history.c	2009-06-20 21:39:23 UTC (rev 38002)
+++ grass/trunk/lib/gis/history.c	2009-06-20 22:03:23 UTC (rev 38003)
@@ -1,271 +0,0 @@
- * \file gis/history.c
- * \brief GIS Library - History management
- * (C) 2001-2009 GRASS Development Team
- * This program is free software under the GNU General Public License
- * (>=v2). Read the file COPYING that comes with GRASS for details.
- * \author Original author CERL
-static void print_history_error(const char *, const char *, FILE *);
- * \brief Read raster history file
- * This routine reads the history file for the raster map <i>name</i>
- * in <i>mapset</i> into the <i>hist</i> structure.
- * A diagnostic message is printed and -1 is returned if there is an
- * error reading the history file. Otherwise, 0 is returned.
- * \param name map name
- * \param mapset mapset name
- * \param hist pointer to History structure which holds history info
-int G_read_history(const char *name, const char *mapset, struct History *hist)
-    FILE *fd;
-    G_zero(hist, sizeof(struct History));
-    fd = G_fopen_old("hist", name, mapset);
-    if (!fd) {
-	print_history_error(name, mapset, fd);
-	return -1;
-    if (!G_getl(hist->mapid, sizeof(hist->mapid), fd)) {
-	return -1;
-    G_ascii_check(hist->mapid);
-    if (!G_getl(hist->title, sizeof(hist->title), fd)) {
-	return -1;
-    G_ascii_check(hist->title);
-    if (!G_getl(hist->mapset, sizeof(hist->mapset), fd)) {
-	return -1;
-    G_ascii_check(hist->mapset);
-    if (!G_getl(hist->creator, sizeof(hist->creator), fd)) {
-	return -1;
-    G_ascii_check(hist->creator);
-    if (!G_getl(hist->maptype, sizeof(hist->maptype), fd)) {
-	return -1;
-    G_ascii_check(hist->maptype);
-    if (!G_getl(hist->datsrc_1, sizeof(hist->datsrc_1), fd)) {
-	return -1;
-    G_ascii_check(hist->datsrc_1);
-    if (!G_getl(hist->datsrc_2, sizeof(hist->datsrc_2), fd)) {
-	return -1;
-    G_ascii_check(hist->datsrc_2);
-    if (!G_getl(hist->keywrd, sizeof(hist->keywrd), fd)) {
-	return -1;
-    G_ascii_check(hist->keywrd);
-    hist->edlinecnt = 0;
-    while ((hist->edlinecnt < MAXEDLINES) &&
-	   (G_getl
-	    (hist->edhist[hist->edlinecnt], sizeof(hist->edhist[0]), fd))) {
-	G_ascii_check(hist->edhist[hist->edlinecnt]);
-	hist->edlinecnt++;
-    fclose(fd);
-    return 0;
-void print_history_error(const char *name, const char *mapset, FILE *fd)
-    if (fd != NULL)
-	fclose(fd);
-    if (mapset) {
-	G_warning(_("Unable to get history information for <%s@%s>"),
-		  name, mapset);
-    else { /* write */
-	G_warning(_("Unable to write history information for <%s>"), name);
- * \brief Write raster history file
- * This routine writes the history file for the raster map
- * <i>name</i> in the current mapset from the <i>hist</i> structure.
- * error writing the history file. Otherwise, 0 is returned.
- * <b>Note:</b> The <i>hist</i> structure should first be initialized
- * using G_short_history().
- * \param[out] hist pointer to History structure which holds history info
-int G_write_history(const char *name, struct History *hist)
-    FILE *fd;
-    int i;
-    fd = G_fopen_new("hist", name);
-    if (!fd) {
-	print_history_error(name, NULL, fd);
-	return -1;
-    fprintf(fd, "%s\n", hist->mapid);
-    fprintf(fd, "%s\n", hist->title);
-    fprintf(fd, "%s\n", hist->mapset);
-    fprintf(fd, "%s\n", hist->creator);
-    fprintf(fd, "%s\n", hist->maptype);
-    fprintf(fd, "%s\n", hist->datsrc_1);
-    fprintf(fd, "%s\n", hist->datsrc_2);
-    fprintf(fd, "%s\n", hist->keywrd);
-    for (i = 0; i < hist->edlinecnt; i++)
-	fprintf(fd, "%s\n", hist->edhist[i]);
-    fclose(fd);
-    return 0;
- * \brief Initialize history structure
- * This routine initializes the <i>hist</i> structure, recording the
- * date, user, module name and the raster map <i>name</i>
- * structure. The <i>type</i> is an anachronism from earlier versions
- * of GRASS and should be specified as "raster".
- * <b>Note:</b> This routine only initializes the data structure. It
- * does not write the history file.
- * \param type map type
-void G_short_history(const char *name, const char *type, struct History *hist)
-    strncpy(hist->mapid, G_date(), RECORD_LEN);
-    strncpy(hist->title, name, RECORD_LEN);
-    strncpy(hist->mapset, G_mapset(), RECORD_LEN);
-    strncpy(hist->creator, G_whoami(), RECORD_LEN);
-    strncpy(hist->maptype, type, RECORD_LEN);
-    sprintf(hist->keywrd, _("generated by %s"), G_program_name());
-    strcpy(hist->datsrc_1, "");
-    strcpy(hist->datsrc_2, "");
- * \brief Save command line to raster history structure
- * This routine takes an existing (run G_short_history first() history
- * structure and adds the command line to the end of the comments
- * array, as cleaned & expanded by the parser.
- * History file is limited to [80]x[50], as defined in include/gis.h
- *  - First version had for loops of [i][j] character assignments and ending
- *    nulls, but using the string libraries is cleaner and less bug prone.
- *  - Second version had white space detection, intelligent wrapping, and
- *    indentation of continued lines, but this proved a pain in the neck for
- *    things like r.patch which can have long strings without any
- *    parser-acceptable breaks.
- *  - This is MK-III, simplified, but that's good: it's cut & paste-able.
- * Note: use G_write_history() to write the structure.
- * Sample Usage:
- * \code
- *   struct History history;
- *   G_short_history(rasterfile, "raster", &history);
- *   G_command_history(&history);
- *   G_write_history(rasterfile, &history);
- * \endcode
- * \return 1 on failure (history file full, no change)
- * \return 2 on failure (history file full, added as much as we could)
-int G_command_history(struct History *hist)
-    int j, cmdlen;
-    char *cmdlin;
-    cmdlin = G_recreate_command();
-    cmdlen = strlen(cmdlin);
-    if (hist->edlinecnt > MAXEDLINES - 2) {
-	G_warning(_("Not enough room in history file to record command line"));
-	return 1;
-    if (hist->edlinecnt > 0) {	/* add a blank line if preceding history exists */
-	strcpy(hist->edhist[hist->edlinecnt], "");
-    if (cmdlen < 70) {		/* ie if it will fit on a single line */
-	sprintf(hist->edhist[hist->edlinecnt], G_recreate_command());
-    else {			/* multi-line required */
-	j = 0;			/* j is the current position in the command line string */
-	while ((cmdlen - j) > 70) {
-	    strncpy(hist->edhist[hist->edlinecnt], &cmdlin[j], 68);
-	    hist->edhist[hist->edlinecnt][68] = '\0';
-	    strcat(hist->edhist[hist->edlinecnt], "\\");
-	    j += 68;
-		G_warning(_("Not enough room in history file for command line (truncated)"));
-		return 2;
-	if ((cmdlen - j) > 0) {	/* ie anything left */
-	    strcpy(hist->edhist[hist->edlinecnt], &cmdlin[j]);
-    return 0;
Deleted: grass/trunk/lib/gis/interp.c
--- grass/trunk/lib/gis/interp.c	2009-06-20 21:39:23 UTC (rev 38002)
+++ grass/trunk/lib/gis/interp.c	2009-06-20 22:03:23 UTC (rev 38003)
@@ -1,36 +0,0 @@
-DCELL G_interp_linear(double u, DCELL c0, DCELL c1)
-    return u * (c1 - c0) + c0;
-DCELL G_interp_bilinear(double u, double v,
-			DCELL c00, DCELL c01, DCELL c10, DCELL c11)
-    DCELL c0 = G_interp_linear(u, c00, c01);
-    DCELL c1 = G_interp_linear(u, c10, c11);
-    return G_interp_linear(v, c0, c1);
-DCELL G_interp_cubic(double u, DCELL c0, DCELL c1, DCELL c2, DCELL c3)
-    return (u * (u * (u * (c3 - 3 * c2 + 3 * c1 - c0) +
-	      (-c3 + 4 * c2 - 5 * c1 + 2 * c0)) + (c2 - c0)) + 2 * c1) / 2;
-DCELL G_interp_bicubic(double u, double v,
-		       DCELL c00, DCELL c01, DCELL c02, DCELL c03,
-		       DCELL c10, DCELL c11, DCELL c12, DCELL c13,
-		       DCELL c20, DCELL c21, DCELL c22, DCELL c23,
-		       DCELL c30, DCELL c31, DCELL c32, DCELL c33)
-    DCELL c0 = G_interp_cubic(u, c00, c01, c02, c03);
-    DCELL c1 = G_interp_cubic(u, c10, c11, c12, c13);
-    DCELL c2 = G_interp_cubic(u, c20, c21, c22, c23);
-    DCELL c3 = G_interp_cubic(u, c30, c31, c32, c33);
-    return G_interp_cubic(v, c0, c1, c2, c3);
Deleted: grass/trunk/lib/gis/mask_info.c
--- grass/trunk/lib/gis/mask_info.c	2009-06-20 21:39:23 UTC (rev 38002)
+++ grass/trunk/lib/gis/mask_info.c	2009-06-20 22:03:23 UTC (rev 38003)
@@ -1,70 +0,0 @@
- * char * G_mask_info ()
- *   returns a printable text of mask information
- * G__mask_info (name, mapset)
- *      char name[GNAME_MAX], mapset[GMAPSET_MAX];
- * function:
- *   determine the status off the automatic masking
- *   and the name of the cell file which forms the mask
- *   (the mask file is actually MASK in the current mapset,
- *   but is usually a reclassed cell file, and the reclass
- *   name and mapset are returned)
- * returns:
- *   -1   no masking (name, mapset undefined)
- *        name, mapset are undefined
- *    1   mask file present, masking on
- *        name, mapset hold mask file name, mapset
-char *G_mask_info(void)
-    char text[GNAME_MAX + GMAPSET_MAX + 16];
-    char name[GNAME_MAX];
-    char mapset[GMAPSET_MAX];
-    switch (G__mask_info(name, mapset)) {
-    case 1:
-	sprintf(text, _("<%s> in mapset <%s>"), name, mapset);
-	break;
-    case -1:
-	strcpy(text, _("none"));
-	break;
-    default:
-	strcpy(text, _("not known"));
-	break;
-    return G_store(text);
-int G__mask_info(char *name, char *mapset)
-    char rname[GNAME_MAX], rmapset[GMAPSET_MAX];
-    strcpy(name, "MASK");
-    strcpy(mapset, G_mapset());
-    if (!G_find_cell(name, mapset))
-	return -1;
-    if (G_is_reclass(name, mapset, rname, rmapset) > 0) {
-	strcpy(name, rname);
-	strcpy(mapset, rmapset);
-    return 1;
Deleted: grass/trunk/lib/gis/maskfd.c
--- grass/trunk/lib/gis/maskfd.c	2009-06-20 21:39:23 UTC (rev 38002)
+++ grass/trunk/lib/gis/maskfd.c	2009-06-20 22:03:23 UTC (rev 38003)
@@ -1,29 +0,0 @@
- * \file gis/maskfd.c
- * \brief GIS Library - Mask functions.
- * (C) 2001-2009 by the GRASS Development Team
-#include "G.h"
- * \brief Test for MASK.
- * \return -1 if no MASK
- * \return file descriptor if MASK
-int G_maskfd(void)
-    return G__.auto_mask > 0 ? G__.mask_fd : -1;
Deleted: grass/trunk/lib/gis/null_val.c
--- grass/trunk/lib/gis/null_val.c	2009-06-20 21:39:23 UTC (rev 38002)
+++ grass/trunk/lib/gis/null_val.c	2009-06-20 22:03:23 UTC (rev 38003)
@@ -1,506 +0,0 @@
- * \file gis/null_value.c
- * \brief GIS Library - NULL value management
- * To provide functionality to handle NULL values for data types CELL,
- * FCELL, and DCELL. May need more...
- * \author Original author unknown - probably CERL
- * \author Justin Hickey - Thailand - jhickey at hpcc.nectec.or.th
-/* System include files */
-#include <string.h>
-/* Grass and local include files */
-#include <grass/glocale.h>
-static void EmbedGivenNulls(void *, char *, RASTER_MAP_TYPE, int);
-  \brief To insert null values into a map. Needs more.....
-  \param cell raster values
-  \param nulls raster null values
-  \param map_type type of raster - CELL, FCELL, DCELL
-  \param ncols number of columns
-void EmbedGivenNulls(void *cell, char *nulls, RASTER_MAP_TYPE map_type,
-		     int ncols)
-    CELL *c;
-    FCELL *f;
-    DCELL *d;
-    int i;
-    c = (CELL *) cell;
-    f = (FCELL *) cell;
-    d = (DCELL *) cell;
-    for (i = 0; i < ncols; i++) {
-	if (nulls[i]) {
-	    case CELL_TYPE:
-		G_set_c_null_value((CELL *) (c + i), 1);
-		break;
-	    case FCELL_TYPE:
-		G_set_f_null_value((FCELL *) (f + i), 1);
-		break;
-	    case DCELL_TYPE:
-		G_set_d_null_value((DCELL *) (d + i), 1);
-		break;
-	    default:
-		G_warning(_("EmbedGivenNulls: wrong data type"));
-  \brief To set one or more raster values to null.
-  It also sets null to zero if null_is_zero is TRUE.
-  \param rast pointer to values to set to null
-  \param numVals number of values to set to null
-  \param null_is_zero flag to indicate if NULL = 0
-  \param data_type type of raster - CELL, FCELL, DCELL
-void G__set_null_value(void *rast, int numVals, int null_is_zero,
-    if (null_is_zero) {
-	G_zero((char *)rast, numVals * G_raster_size(data_type));
-	return;
-    G_set_null_value(rast, numVals, data_type);
- \param buf pointer to values to set to null
-void G_set_null_value(void *buf, int numVals, RASTER_MAP_TYPE data_type)
-    switch (data_type) {
-    case CELL_TYPE:
-	G_set_c_null_value((CELL *) buf, numVals);
-	break;
-    case FCELL_TYPE:
-	G_set_f_null_value((FCELL *) buf, numVals);
-	break;
-    case DCELL_TYPE:
-	G_set_d_null_value((DCELL *) buf, numVals);
-	break;
-    default:
-	G_warning(_("G_set_null_value: wrong data type!"));
-  \brief To set a number of CELL raster values to NULL.
-  \param cellVals pointer to CELL values to set to null
-void G_set_c_null_value(CELL *cellVals, int numVals)
-    int i;			/* counter */
-    for (i = 0; i < numVals; i++)
-	cellVals[i] = (int) 0x80000000;
- \brief To set a number of FCELL raster values to NULL.
- \param fcellVals pointer to FCELL values to set to null
-void G_set_f_null_value(FCELL *fcellVals, int numVals)
-    static const unsigned char null_bits[4] = {
-	0xFF, 0xFF, 0xFF, 0xFF};
-    int i;
-	memcpy(&fcellVals[i], null_bits, sizeof(null_bits));
-  \brief To set a number of DCELL raster values to NULL.
-  \param dcellVals pointer to DCELL values to set to null
-void G_set_d_null_value(DCELL *dcellVals, int numVals)
-    static const unsigned char null_bits[8] = {
-	0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF};
-    int i;
-	memcpy(&dcellVals[i], null_bits, sizeof(null_bits));
-  \brief To check if a raster value is set to NULL
-    - If the <em>data_type</em> is CELL_TYPE, calls G_is_c_null_value()
-    - If the <em>data_type</em> is FCELL_TYPE, calls G_is_f_null_value()
-    - If the <em>data_type</em> is DCELL_TYPE, calls G_is_d_null_value()
-  \param rast raster value to check
-  \return TRUE if raster value is NULL
-  \return FALSE otherwise
-int G_is_null_value(const void *rast, RASTER_MAP_TYPE data_type)
-    case CELL_TYPE:
-	return (G_is_c_null_value((CELL *) rast));
-    case FCELL_TYPE:
-	return (G_is_f_null_value((FCELL *) rast));
-    case DCELL_TYPE:
-	return (G_is_d_null_value((DCELL *) rast));
-    default:
-	G_warning("G_is_null_value: wrong data type!");
-	return FALSE;
-  \brief To check if a CELL raster value is set to NULL
-  Returns 1 if <em>cell</em> is NULL, 0 otherwise. This will test if the
-  value <em>cell</em> is the largest <tt>int</tt>.
-  \param cellVal CELL raster value to check
-  \return TRUE if CELL raster value is NULL
-int G_is_c_null_value(const CELL * cellVal)
-    /* Check if the CELL value matches the null pattern */
-    return *cellVal == (CELL) 0x80000000;
-  \brief To check if a FCELL raster value is set to NULL
-  Returns 1 if <em>fcell</em> is NULL, 0 otherwise. This will test if
-  the value <em>fcell</em> is a NaN. It isn't good enough to test for
-  a particular NaN bit pattern since the machine code may change this
-  bit pattern to a different NaN. The test will be
-  \code
-  if(fcell==0.0) return 0;
-  if(fcell>0.0) return 0;
-  if(fcell<0.0) return 0;
-  return 1;
-  \endcode
-  or (as suggested by Mark Line)
-  \code
-  return (fcell != fcell);
-  \endcode
-  \param fcellVal FCELL raster value to check
-  \return TRUE if FCELL raster value is NULL
-int G_is_f_null_value(const FCELL * fcellVal)
-    return *fcellVal != *fcellVal;
-  \brief To check if a DCELL raster value is set to NULL
-  Returns 1 if <em>dcell</em> is NULL, 0 otherwise. This will test if
-  the value <em>dcell</em> is a NaN. Same test as in
-  G_is_f_null_value().
-  \param dcellVal DCELL raster value to check
-  \return TRUE if DCELL raster value is NULL
-int G_is_d_null_value(const DCELL * dcellVal)
-    return *dcellVal != *dcellVal;
-  - If the <em>data_type</em> is CELL_TYPE, calls G_insert_c_null_values()
-  - If the <em>data_type</em> is FCELL_TYPE, calls G_insert_f_null_values()
-  - If the <em>data_type</em> is DCELL_TYPE, calls G_insert_d_null_values()
-  \param rast pointer raster values
-  \param null_row null row
-void G_insert_null_values(void *rast, char *null_row, int ncols,
-    EmbedGivenNulls(rast, null_row, data_type, ncols);
-  \brief To insert null values into an integer raster map (CELL)
-  For each of the <em>count</em> <em>flags</em> which is true(!=0),
-  set the corresponding <em>cell</em> to the NULL value.
-void G_insert_c_null_values(CELL * cellVal, char *null_row, int ncols)
-    EmbedGivenNulls((void *)cellVal, null_row, CELL_TYPE, ncols);
-  \brief To insert null values into an floating-point raster map (FCELL)
-  \param fcellVal pointer raster values
-void G_insert_f_null_values(FCELL * fcellVal, char *null_row, int ncols)
-    EmbedGivenNulls((void *)fcellVal, null_row, FCELL_TYPE, ncols);
-  For each for the <em>count</em> <em>flag</em> which is true(!=0), set
-  the corresponding <em>dcell</em> to the NULL value.
-  \param dcellVal pointer raster values
-void G_insert_d_null_values(DCELL * dcellVal, char *null_row, int ncols)
-    EmbedGivenNulls((void *)dcellVal, null_row, DCELL_TYPE, ncols);
-  \brief Check NULL
-  Note: Only for internal use.
-  \param flags ?
-  \param bit_num ?
-  \param n ?
-int G__check_null_bit(const unsigned char *flags, int bit_num, int n)
-    int ind;
-    int offset;
-    /* find the index of the unsigned char in which this bit appears */
-    ind = G__null_bitstream_size(bit_num + 1) - 1;
-    /* find how many unsigned chars the buffer with bit_num+1 (counting from 0
-       has and subtract 1 to get unsigned char index */
-    if (ind > G__null_bitstream_size(n) - 1) {
-	G_warning("G__check_null_bit: Unable to access index %d. "
-		  "Size of flags is %d (bit # is %d)",
-		  ind, G__null_bitstream_size(n) - 1, bit_num);
-	return -1;
-    offset = (ind + 1) * 8 - bit_num - 1;
-    return ((flags[ind] & ((unsigned char)1 << offset)) != 0);
-  \brief Given array of 0/1 of length n starting from column.
-  Given array of 0/1 of length n starting from column set the
-  corresponding bits of flags; total number of bits in flags is ncols.
-  \param zero_ones
-  \param flags
-  \param col
-  \param n
-  \param ncols
-  \return 0
-  \return 1
-int G__set_flags_from_01_random(const char *zero_ones, unsigned char *flags,
-				int col, int n, int ncols)
-    unsigned char v;
-    int count;
-    int size;
-    int i, k;
-    if (col == 0 && n == ncols) {
-	G__convert_01_flags(zero_ones, flags, n);
-	return 0;
-    count = 0;
-    size = G__null_bitstream_size(ncols);
-    for (i = 0; i < size; i++) {
-	v = 0;
-	k = 8;
-	while (k-- > 0) {
-	    if (count >= col && count < (col + n)) {
-		v = v | ((unsigned char)zero_ones[count - col] << k);
-	    else if (count < ncols) {
-		v = v |
-		    ((unsigned char)G__check_null_bit(flags, count, ncols) << k);
-	    /* otherwise  keep this bit the same as it was */
-	    count++;
-	flags[i] = v;
-    return 1;
-  \brief ?
-  \param zero_ones
-  \param flags
-  \param n
-void G__convert_01_flags(const char *zero_ones, unsigned char *flags, int n)
-    unsigned char *v;
-    int count;
-    int size;
-    int i, k;
-    /* pad the flags with 0's to make size multiple of 8 */
-    v = flags;
-    size = G__null_bitstream_size(n);
-    count = 0;
-	*v = 0;
-	k = 8;
-	while (k-- > 0) {
-	    if (count < n) {
-		*v = *v | ((unsigned char)zero_ones[count] << k);
-	    count++;
-	v++;
-  \brief ?
-  \param zero_ones
-  \param flags
-  \param n
-void G__convert_flags_01(char *zero_ones, const unsigned char *flags, int n)
-    const unsigned char *v;
-    int count;
-    int size;
-    int i, k;
-    count = 0;
-    v = flags;
-	k = 8;
-	while (k-- > 0) {
-	    if (count < n) {
-		zero_ones[count] = ((*v & ((unsigned char)1 << k)) != 0);
-		count++;
-	v++;
-  \brief ?
-  \param flags
-  \param cols
-void G__init_null_bits(unsigned char *flags, int cols)
-    unsigned char *v;
-    int size;
-    int i;
-    v = flags;
-	if ((i + 1) * 8 <= cols) {
-	    *v = (unsigned char)255;
-	else {
-	    *v = (unsigned char)255 << ((i + 1) * 8 - cols);
-	v++;
Deleted: grass/trunk/lib/gis/opencell.c
--- grass/trunk/lib/gis/opencell.c	2009-06-20 21:39:23 UTC (rev 38002)
+++ grass/trunk/lib/gis/opencell.c	2009-06-20 22:03:23 UTC (rev 38003)
@@ -1,970 +0,0 @@
- * \file gis/opencell.c
- * \brief GIS Library - Open raster file
- * for details.
-#include <unistd.h>
-#include <sys/stat.h>
-#include <fcntl.h>
-#include <grass/config.h>
-#include "G.h"
-#define FORMAT_FILE "f_format"
-static struct fileinfo *new_fileinfo(int fd)
-    int oldsize = G__.fileinfo_count;
-    int newsize = oldsize;
-    int i;
-    if (fd < oldsize)
-	return &G__.fileinfo[fd];
-    newsize *= 2;
-    if (newsize <= fd)
-	newsize = fd + 20;
-    G__.fileinfo = G_realloc(G__.fileinfo, newsize * sizeof(struct fileinfo));
-    /* Mark all cell files as closed */
-    for (i = oldsize; i < newsize; i++) {
-	memset(&G__.fileinfo[i], 0, sizeof(struct fileinfo));
-	G__.fileinfo[i].open_mode = -1;
-    G__.fileinfo_count = newsize;
- * \brief Open raster file
- * Arrange for the NULL-value bitmap to be read as well as the raster
- * map. If no NULL-value bitmap exists, arrange for the production of
- * NULL-values based on zeros in the raster map. If the map is
- * floating-point, arrange for quantization to integer for
- * G_get_c_raster_row(), et. al., by reading the quantization rules
- * for the map using G_read_quant(). If the programmer wants to read
- * the floating point map using uing quant rules other than the ones
- * stored in map's quant file, he/she should call G_set_quant_rules()
- * after the call to G_open_cell_old().
- * \param open_mode mode
- * \param map_type map type (CELL, FCELL, DCELL)
- * \return open file descriptor ( >= 0) if successful
- *  \return negative integer if error
-static int G__open_raster_new(const char *name, int open_mode,
-			      RASTER_MAP_TYPE map_type);
-  \brief Open an existing integer raster map (cell)
-  Opens the existing cell file <i>name</i> in the <i>mapset</i> for
-  reading by G_get_raster_row() with mapping into the current window.
-  This routine opens the raster map <i>name</i> in <i>mapset</i> for
-  reading. A nonnegative file descriptor is returned if the open is
-  successful. Otherwise a diagnostic message is printed and a negative
-  value is returned. This routine does quite a bit of work. Since
-  GRASS users expect that all raster maps will be resampled into the
-  current region, the resampling index for the raster map is prepared
-  by this routine after the file is opened. The resampling is based on
-  the active module region (see also \ref The_Region}. Preparation
-  required for reading the various raster file formats (see \ref
-  Raster_File_Format for an explanation of the various raster file
-  formats) is also done.
-  Diagnostics: warning message printed if open fails.
-  \param name map name
-  \param mapset mapset name where raster map <i>name</i> lives
-  \return nonnegative file descriptor (int)
-  \return -1 on failure
-int G_open_cell_old(const char *name, const char *mapset)
-    int fd;
-    if ((fd = G__open_cell_old(name, mapset)) < 0) {
-	G_warning(_("Unable to open raster map <%s@%s>"), name, mapset);
-	return fd;
-    /* turn on auto masking, if not already on */
-       if(G__.auto_mask <= 0)
-       G__.mask_buf = G_allocate_cell_buf();
-       now we don't ever free it!, so no need to allocate it  (Olga)
-    /* mask_buf is used for reading MASK file when mask is set and
-       for reading map rows when the null file doesn't exist */
-    return fd;
-/*!  \brief Lower level function, open cell files, supercell files,
-  and the MASK file.
-  Actions:
-   - opens the named cell file, following reclass reference if
-   named layer is a reclass layer.
-   - creates the required mapping between the data and the window
-   for use by the get_map_row family of routines.
-  Diagnostics: Errors other than actual open failure will cause a
-  diagnostic to be delivered thru G_warning() open failure messages
-  are left to the calling routine since the masking logic will want to
-  issue a different warning.
-  Note: This routine does NOT open the MASK layer. If it did we would
-  get infinite recursion.  This routine is called to open the mask by
-  G__check_for_auto_masking() which is called by G_open_cell_old().
-  \param mapset mapset of cell file to be opened
-  \return open file descriptor
-  \return -1 if error
-int G__open_cell_old(const char *name, const char *mapset)
-    struct fileinfo *fcb;
-    int fd;
-    char *cell_dir;
-    const char *r_name;
-    const char *r_mapset;
-    struct Cell_head cellhd;
-    int CELL_nbytes = 0;	/* bytes per cell in CELL map */
-    int INTERN_SIZE;
-    int reclass_flag, i;
-    int MAP_NBYTES;
-    RASTER_MAP_TYPE MAP_TYPE;
-    struct Reclass reclass;
-    char xname[GNAME_MAX], xmapset[GMAPSET_MAX];
-    struct GDAL_link *gdal;
-    /* make sure window is set    */
-    G__init_window();
-    G__unqualified_name(name, mapset, xname, xmapset);
-    name = xname;
-    mapset = xmapset;
-    if (!G_find_cell2(name, mapset)) {
-	G_warning(_("Unable to find <%s@%s>"), name, mapset);
-	return -1;
-    /* Check for reclassification */
-    reclass_flag = G_get_reclass(name, mapset, &reclass);
-    switch (reclass_flag) {
-    case 0:
-	r_name = name;
-	r_mapset = mapset;
-	break;
-    case 1:
-	r_name = reclass.name;
-	r_mapset = reclass.mapset;
-	if (G_find_cell2(r_name, r_mapset) == NULL) {
-	    G_warning(_("Unable to open raster map <%s@%s> since it is a reclass "
-			"of raster map <%s@%s> which does not exist"),
-		      name, mapset, r_name, r_mapset);
-	    return -1;
-	break;
-    default:			/* Error reading cellhd/reclass file */
-	return -1;
-    /* read the cell header */
-    if (G_get_cellhd(r_name, r_mapset, &cellhd) < 0)
-	return -1;
-    /* now check the type */
-    MAP_TYPE = G_raster_map_type(r_name, r_mapset);
-    if (MAP_TYPE < 0)
-	return -1;
-    if (MAP_TYPE == CELL_TYPE)
-	/* set the number of bytes for CELL map */
-	CELL_nbytes = cellhd.format + 1;
-	if (CELL_nbytes < 1) {
-	    G_warning(_("Raster map <%s@%s>: format field in header file invalid"),
-		      r_name, r_mapset);
-	    return -1;
-    if (cellhd.proj != G__.window.proj) {
-	G_warning(_("Raster map <%s@%s> is in different projection than current region. "
-		    "Found raster map <%s@%s>, should be <%s>."),
-		  name, mapset, name, G__projection_name(cellhd.proj),
-		  G__projection_name(G__.window.proj));
-	return -1;
-    if (cellhd.zone != G__.window.zone) {
-	G_warning(_("Raster map <%s@%s> is in different zone (%d) than current region (%d)"),
-		  name, mapset, cellhd.zone, G__.window.zone);
-	return -1;
-    /* when map is int warn if too large cell size */
-    if (MAP_TYPE == CELL_TYPE && (unsigned int) CELL_nbytes > sizeof(CELL)) {
-	G_warning(_("Raster map <%s@%s>: bytes per cell (%d) too large"),
-		  name, mapset, CELL_nbytes);
-	return -1;
-    /* record number of bytes per cell */
-    if (MAP_TYPE == FCELL_TYPE) {
-	cell_dir = "fcell";
-	INTERN_SIZE = sizeof(FCELL);
-	MAP_NBYTES = XDR_FLOAT_NBYTES;
-    else if (MAP_TYPE == DCELL_TYPE) {
-	INTERN_SIZE = sizeof(DCELL);
-	MAP_NBYTES = XDR_DOUBLE_NBYTES;
-    else {			/* integer */
-	cell_dir = "cell";
-	INTERN_SIZE = sizeof(CELL);
-	MAP_NBYTES = CELL_nbytes;
-    gdal = G_get_gdal_link(r_name, r_mapset);
-    if (gdal) {
-#ifdef HAVE_GDAL
-	/* dummy descriptor to reserve the fileinfo slot */
-	fd = open(G_DEV_NULL, O_RDONLY);
-#else
-	G_warning(_("map <%s@%s> is a GDAL link but GRASS is compiled without GDAL support"),
-	return -1;
-#endif
-    else
-	/* now actually open file for reading */
-	fd = G_open_old(cell_dir, r_name, r_mapset);
-    if (fd < 0)
-	return -1;
-    fcb = new_fileinfo(fd);
-    fcb->map_type = MAP_TYPE;
-    /* Save cell header */
-    G_copy((char *)&fcb->cellhd, (char *)&cellhd, sizeof(cellhd));
-    /* allocate null bitstream buffers for reading null rows */
-	fcb->NULL_ROWS[i] = G__allocate_null_bits(G__.window.cols);
-    /* initialize : no NULL rows in memory */
-    fcb->min_null_row = (-1) * NULL_ROWS_INMEM;
-    /* mark closed */
-    fcb->open_mode = -1;
-    /* save name and mapset */
-    fcb->name = G_store(name);
-    fcb->mapset = G_store(mapset);
-    /* mark no data row in memory  */
-    /* fcb->null_cur_row is not used for reading, only for writing */
-    fcb->null_cur_row = -1;
-    /* if reclass, copy reclass structure */
-    if ((fcb->reclass_flag = reclass_flag))
-	G_copy(&fcb->reclass, &reclass, sizeof(reclass));
-    fcb->gdal = gdal;
-    if (!gdal)
-	/* check for compressed data format, making initial reads if necessary */
-	if (G__check_format(fd) < 0) {
-	    close(fd);		/* warning issued by check_format() */
-	    return -1;
-    /* create the mapping from cell file to window */
-    G__create_window_mapping(fd);
-     * allocate the data buffer
-     * number of bytes per cell is cellhd.format+1
-    /* for reading fcb->data is allocated to be fcb->cellhd.cols * fcb->nbytes
-       (= XDR_FLOAT/DOUBLE_NBYTES) */
-    fcb->data = (unsigned char *)G_calloc(fcb->cellhd.cols, MAP_NBYTES);
-    /* initialize/read in quant rules for float point maps */
-    if (fcb->map_type != CELL_TYPE) {
-	    G_read_quant(fcb->reclass.name, fcb->reclass.mapset,
-			 &(fcb->quant));
-	else
-	    G_read_quant(fcb->name, fcb->mapset, &(fcb->quant));
-    /* now mark open for read: this must follow create_window_mapping() */
-    fcb->open_mode = OPEN_OLD;
-    fcb->io_error = 0;
-    fcb->nbytes = MAP_NBYTES;
-    fcb->null_file_exists = -1;
-	xdrmem_create(&fcb->xdrstream, (caddr_t) fcb->data,
-		      (u_int) (fcb->nbytes * fcb->cellhd.cols), XDR_DECODE);
-    return fd;
-  \brief Opens a new cell file in a database (compressed)
-  Opens a new cell file <i>name</i> in the current mapset for writing
-  by G_put_raster_row().
-  The file is created and filled with no data it is assumed that the
-  new cell file is to conform to the current window.
-  The file must be written sequentially. Use G_open_cell_new_random()
-  for non sequential writes.
-  Note: the open actually creates a temporary file G_close_cell() will
-  move the temporary file to the cell file and write out the necessary
-  support files (cellhd, cats, hist, etc.).
-  Warning: calls to G_set_window() made after opening a new cell file
-  may create confusion and should be avoided the new cell file will be
-  created to conform to the window at the time of the open.
-  \return open file descriptor ( >= 0) if successful
-  \return negative integer if error
-int G_open_cell_new(const char *name)
-    return G__open_raster_new(name, OPEN_NEW_COMPRESSED, CELL_TYPE);
-  \brief Opens a new cell file in a database (uncompressed)
-  See also G_open_cell_new().
-int G_open_cell_new_uncompressed(const char *name)
-    return G__open_raster_new(name, OPEN_NEW_UNCOMPRESSED, CELL_TYPE);
-  \brief Save histogram for newly create raster map (cell)
-  If newly created cell files should have histograms, set flag=1
-  otherwise set flag=0. Applies to subsequent opens.
-  \param flag flag indicator
-void G_want_histogram(int flag)
-    G__.want_histogram = flag;
-  \brief Sets the format for subsequent opens on new integer cell files
-  (uncompressed and random only).
-  Warning: subsequent put_row calls will only write n+1 bytes per
-  cell. If the data requires more, the cell file will be written
-  incorrectly (but with n+1 bytes per cell)
-  When writing float map: format is -1
-  \param n format
-void G_set_cell_format(int n)
-/* sets the format for integer raster map */
-    G__.nbytes = n + 1;
-    if (G__.nbytes <= 0)
-	G__.nbytes = 1;
-    if (G__.nbytes > sizeof(CELL))
-	G__.nbytes = sizeof(CELL);
-  \brief Get cell value format
-  \param v cell
-  \return cell format
-int G_cellvalue_format(CELL v)
-    unsigned int i;
-    if (v >= 0)
-	for (i = 0; i < sizeof(CELL); i++)
-	    if (!(v /= 256))
-		return i;
-    return sizeof(CELL) - 1;
-  \brief Opens new fcell file in a database
-  Opens a new floating-point map <i>name</i> in the current mapset for
-  writing. The type of the file (i.e. either double or float) is
-  determined and fixed at this point. The default is FCELL_TYPE. In
-  order to change this default
-  Use G_set_fp_type() where type is one of DCELL_TYPE or FCELL_TYPE.
-  See warnings and notes for G_open_cell_new().
-  \return -1 on error
-int G_open_fp_cell_new(const char *name)
-    return G__open_raster_new(name, OPEN_NEW_COMPRESSED, G__.fp_type);
-  \brief Opens new fcell file in a database (uncompressed)
-  See G_open_fp_cell_new() for details.
-int G_open_fp_cell_new_uncompressed(const char *name)
-    return G__open_raster_new(name, OPEN_NEW_UNCOMPRESSED, G__.fp_type);
-#ifdef HAVE_GDAL
-static int G__open_raster_new_gdal(char *map, char *mapset, RASTER_MAP_TYPE map_type)
-    int fd;
-    int i;
-    fd = open("/dev/null", O_RDONLY);
-    if (fd < 0)
-	return -1;
-    /* mark closed */
-    fcb->map_type = map_type;
-    fcb->gdal = G_create_gdal_link(map, map_type);
-    if (!fcb->gdal)
-	return -1;
-    fcb->cellhd = G__.window;
-    fcb->cellhd.compressed = 0;
-    fcb->nbytes = G_raster_size(fcb->map_type);
-    /* for writing fcb->data is allocated to be G__.window.cols *
-       sizeof(CELL or DCELL or FCELL)  */
-    fcb->data = G_calloc(G__.window.cols, fcb->nbytes);
-    fcb->name = map;
-    fcb->mapset = mapset;
-    fcb->cur_row = 0;
-    fcb->row_ptr = NULL;
-    fcb->temp_name = NULL;
-    fcb->null_temp_name = NULL;
-    fcb->null_cur_row = 0;
-    fcb->min_null_row = 0;
-	fcb->NULL_ROWS[i] = NULL;
-	G_quant_init(&(fcb->quant));
-    /* init cell stats */
-    /* now works only for int maps */
-	if ((fcb->want_histogram = G__.want_histogram))
-	    G_init_cell_stats(&fcb->statf);
-    /* init range and if map is double/float init d/f_range */
-    G_init_range(&fcb->range);
-	G_init_fp_range(&fcb->fp_range);
-    /* mark file as open for write */
-    fcb->open_mode = OPEN_NEW_UNCOMPRESSED;
-    return fd;
-#endif /* HAVE_GDAL */
-    int i, null_fd, fd;
-    char *tempname;
-    char *map;
-    char *mapset;
-    const char *cell_dir;
-    int nbytes;
-    switch (map_type) {
-    case CELL_TYPE:
-	nbytes = G__.nbytes;
-	break;
-    case FCELL_TYPE:
-	nbytes = XDR_FLOAT_NBYTES;
-	break;
-    case DCELL_TYPE:
-	nbytes =  XDR_DOUBLE_NBYTES;
-	break;
-    default:
-	G_fatal_error(_("Invalid map type <%d>"), map_type);
-	break;
-    if (G__unqualified_name(name, G_mapset(), xname, xmapset) < 0)
-	G_fatal_error(_("Raster map <%s> is not in the current mapset (%s)"),
-		      name, G_mapset());
-    map = G_store(xname);
-    mapset = G_store(xmapset);
-    /* check for legal grass name */
-    if (G_legal_filename(map) < 0) {
-	G_warning(_("<%s> is an illegal file name"), map);
-	return -1;
-    G__init_window();
-#ifdef HAVE_GDAL
-    if (G_find_file2("", "GDAL", G_mapset()))
-	return G__open_raster_new_gdal(map, mapset, map_type);
-#endif
-    /* open a tempfile name */
-    tempname = G_tempfile();
-    fd = creat(tempname, 0666);
-    if (fd < 0) {
-	G_warning(_("G__open_raster_new(): no temp files available"));
-	G_free(mapset);
-	G_free(tempname);
-	G_free(map);
-	return -1;
-     * since we are bypassing the normal open logic
-     * must create the cell element
-    G__make_mapset_element(cell_dir);
-    /* mark closed */
-    fcb->gdal = NULL;
-    fcb->data = (unsigned char *)G_calloc(G__.window.cols,
-					  G_raster_size(fcb->map_type));
-     * copy current window into cell header
-     * set format to cell/supercell
-     * for compressed writing
-     *   allocate space to hold the row address array
-    G_copy((char *)&fcb->cellhd, (char *)&G__.window, sizeof(fcb->cellhd));
-    if (open_mode == OPEN_NEW_COMPRESSED && fcb->map_type == CELL_TYPE) {
-	fcb->row_ptr = G_calloc(fcb->cellhd.rows + 1, sizeof(off_t));
-	G_zero(fcb->row_ptr, (fcb->cellhd.rows + 1) * sizeof(off_t));
-	G__write_row_ptrs(fd);
-	fcb->cellhd.compressed = G__.compression_type;
-	fcb->nbytes = 1;	/* to the minimum */
-    else {
-	fcb->nbytes = nbytes;
-	if (open_mode == OPEN_NEW_COMPRESSED) {
-	else
-    /* save name and mapset, and tempfile name */
-    fcb->name = map;
-    fcb->temp_name = tempname;
-    /* next row to be written (in order) is zero */
-    fcb->cur_row = 0;
-    /* open a null tempfile name */
-    null_fd = creat(tempname, 0666);
-    if (null_fd < 0) {
-	G_free(tempname);
-	G_free(fcb->name);
-	G_free(fcb->mapset);
-	G_free(fcb->temp_name);
-	close(fd);
-	return -1;
-    fcb->null_temp_name = tempname;
-    close(null_fd);
-    /* allocate null bitstream buffers for writing */
-	fcb->NULL_ROWS[i] = G__allocate_null_bits(fcb->cellhd.cols);
-    fcb->open_mode = open_mode;
-    return fd;
-  \brief Set raster map floating-point data format.
-  This controls the storage type for floating-point maps. It affects
-  subsequent calls to G_open_fp_map_new(). The <i>type</i> must be
-  one of FCELL_TYPE (float) or DCELL_TYPE (double). The use of this
-  routine by applications is discouraged since its use would override
-  user preferences.
-  \param type raster data type
-  \return 1 on success
-int G_set_fp_type(RASTER_MAP_TYPE map_type)
-    case FCELL_TYPE:
-    case DCELL_TYPE:
-	G__.fp_type = map_type;
-	return 1;
-    default:
-	G_warning(_("G_set_fp_type(): can only be called with FCELL_TYPE or DCELL_TYPE"));
-	return -1;
-  \brief Check if raster map is floating-point
-  Returns true (1) if raster map <i>name</i> in <i>mapset</i>
-  is a floating-point dataset; false(0) otherwise.
-  \return 1 floating-point
-  \return 0 int
-int G_raster_map_is_fp(const char *name, const char *mapset)
-    char path[GPATH_MAX];
-    const char *xmapset;
-    xmapset = G_find_cell2(name, mapset);
-    if (!xmapset) {
-	return -1;
-    G__file_name(path, "fcell", name, xmapset);
-    if (access(path, 0) == 0)
-	return 1;
-    G__file_name(path, "g3dcell", name, xmapset);
-	return 1;
-    return 0;
-  \brief Determine raster data type
-  Determines if the raster map is floating point or integer. Returns
-  DCELL_TYPE for double maps, FCELL_TYPE for float maps, CELL_TYPE for
-  integer maps, -1 if error has occured
-  \param mapset mapset where map <i>name</i> lives
-  \return raster data type
-RASTER_MAP_TYPE G_raster_map_type(const char *name, const char *mapset)
-    if (!xmapset) {
-	if (mapset && *mapset)
-	    G_warning(_("Raster map <%s> not found in mapset <%s>"), name, mapset);
-	else
-	    G_warning(_("Raster map <%s> not found"), name);
-	return -1;
-	return G__check_fp_type(name, xmapset);
-	return DCELL_TYPE;
-    return CELL_TYPE;
-  \brief Determine raster type from descriptor
-RASTER_MAP_TYPE G_get_raster_map_type(int fd)
-    struct fileinfo *fcb = &G__.fileinfo[fd];
-    return fcb->map_type;
-  \brief Determines whether the floating points cell file has double or float type
-  \return raster type (fcell, dcell)
-RASTER_MAP_TYPE G__check_fp_type(const char *name, const char *mapset)
-    struct Key_Value *format_keys;
-    int in_stat;
-    const char *str, *str1;
-    RASTER_MAP_TYPE map_type;
-    if (!xmapset) {
-	return -1;
-    G__file_name_misc(path, "cell_misc", FORMAT_FILE, name, xmapset);
-    if (access(path, 0) != 0) {
-	G_warning(_("Unable to find '%s'"), path);
-	return -1;
-    format_keys = G_read_key_value_file(path, &in_stat);
-    if (in_stat != 0) {
-	G_warning(_("Unable to open '%s'"), path);
-	return -1;
-    if ((str = G_find_key_value("type", format_keys)) != NULL) {
-	if (strcmp(str, "double") == 0)
-	    map_type = DCELL_TYPE;
-	else if (strcmp(str, "float") == 0)
-	    map_type = FCELL_TYPE;
-	else {
-	    G_warning(_("Invalid type: field '%s' in file '%s'"),
-		      str, path);
-	    G_free_key_value(format_keys);
-	    return -1;
-    else {
-	return -1;
-    if ((str1 = G_find_key_value("byte_order", format_keys)) != NULL) {
-	if (strcmp(str1, "xdr") != 0)
-	    G_warning(_("Raster map <%s> is not xdr: byte_order: %s"),
-			name, str);
-	/* here read and translate  byte order if not using xdr */
-    return map_type;
-  \brief Opens a new raster map
-  Opens a new raster map of type <i>wr_type</i>
-  Supported data types:
-   - CELL_TYPE
-   - FCELL_TYPE
-   - DCELL_TYPE
-  On CELL_TYPE calls G_open_cell_new() otherwise G_open_fp_cell_new().
-  \param wr_type raster data type
-int G_open_raster_new(const char *name, RASTER_MAP_TYPE wr_type)
-    return G__open_raster_new(name, OPEN_NEW_COMPRESSED, wr_type);
-  \brief Opens a new raster map (uncompressed)
-  See G_open_raster_new().
-int G_open_raster_new_uncompressed(const char *name, RASTER_MAP_TYPE wr_type)
-    return G__open_raster_new(name, OPEN_NEW_UNCOMPRESSED, wr_type);
-  \brief Sets quant translation rules for raster map opened for
-  reading.
-  Returned by G_open_cell_old(). After calling this function,
-  G_get_c_raster_row() and G_get_map_row() will use rules defined by q
-  (instead of using rules defined in map's quant file) to convert floats to
-  ints.
-  \param fd file descriptor (cell file)
-  \param q pointer to Quant structure
-  \return 0 success
-  \return -1 failure
-int G_set_quant_rules(int fd, struct Quant *q)
-    CELL cell;
-    DCELL dcell;
-    struct Quant_table *p;
-    if (fcb->open_mode != OPEN_OLD) {
-	G_warning(_("G_set_quant_rules() can be called only for "
-		    "raster maps opened for reading"));
-	return -1;
-    /* copy all info from q to fcb->quant) */
-    G_quant_init(&fcb->quant);
-    if (q->truncate_only) {
-	G_quant_truncate(&fcb->quant);
-	return 0;
-    for (p = &(q->table[q->nofRules - 1]); p >= q->table; p--)
-	G_quant_add_rule(&fcb->quant, p->dLow, p->dHigh, p->cLow, p->cHigh);
-    if (G_quant_get_neg_infinite_rule(q, &dcell, &cell) > 0)
-	G_quant_set_neg_infinite_rule(&fcb->quant, dcell, cell);
-    if (G_quant_get_pos_infinite_rule(q, &dcell, &cell) > 0)
-	G_quant_set_pos_infinite_rule(&fcb->quant, dcell, cell);
-    return 0;
Deleted: grass/trunk/lib/gis/put_cellhd.c
--- grass/trunk/lib/gis/put_cellhd.c	2009-06-20 21:39:23 UTC (rev 38002)
+++ grass/trunk/lib/gis/put_cellhd.c	2009-06-20 22:03:23 UTC (rev 38003)
@@ -1,42 +0,0 @@
- * \file gis/put_cellhd.c
- * \brief GIS Library - Write raster header.
-  \brief Writes the raster file header.
-  Writes the cell file header information associated with map layer "map"
-  into current mapset from the structure "cellhd".
-  \param name name of map
-  \param cellhd structure holding cell header info
-  \return 0 on success
-int G_put_cellhd(const char *name, struct Cell_head *cellhd)
-    FILE *fd;
-    if (!(fd = G_fopen_new("cellhd", name))) {
-	G_warning(_("Unable to create header file for <%s>"), name);
-	return -1;
-    G__write_Cell_head(fd, cellhd, 1);
-    fclose(fd);
-    return 0;
Deleted: grass/trunk/lib/gis/put_row.c
--- grass/trunk/lib/gis/put_row.c	2009-06-20 21:39:23 UTC (rev 38002)
+++ grass/trunk/lib/gis/put_row.c	2009-06-20 22:03:23 UTC (rev 38003)
@@ -1,877 +0,0 @@
- *   G_put_[c/f/d]_raster_row(fd, buf)
- *      int fd           file descriptor of the opened map
- *      [F/D]CELL *buf   buffer holding row info to be written
- *   Writes the next row for the cell file opened on 'fd' from 'buf'
- *   All writes go into NEW files that exactly match the current window.
- *   The file must have been opened with G_open_cell_new()
- *   and be written sequentially, ie no skipping rows
- *   when the null values are embeded into the data, corresponding cells are
- *   changed to 0's and the corresponding null value row is written into null
- *   file.
- *   *** NOTE ***
- *   A map cannot be copied using G_get_raster_row() and G_put_raster_row().
- *   The former resamples the data of the original map into a row buffer
- *   that matches the current window.  The later writes out rows associated
- *   with the window.
- *   returns:    1  if successful
- *              -1  on fail
- *  Keeps track of the minimum and maximum cell value  for use in updating
- *  the range file upon close of the cell file.
- *  HOWEVER when nulls are not embeded, the cells are considered 0's as far
- *  as updating range is concerned, even if the corresponding cell is null
- *  in the resulting null file, so programmer should be carefult to set all
- *  the null values using G_set_null_value() or G_insert_[d/f_]null_values()
- *   G_put_map_row(fd, buf)
- *      CELL *buf        buffer holding row info to be written
- *   NULLS are written into null bitmap file for all cells which are zero,
- *   and cells which have null value (these cells are converted to 0's before
- *   writing)
- *   *** NOTE ***
- *   A map cannot be copied using G_get_map_row() and G_put_map_row().
- *              -1  on fail
- *  put_null_value_row(fd, buf)
- *      int fd                  File descriptor where data is to be written
- *      char *buf               Buffer holding null data
- *   converts a buffer of zero's and ones to bitstream and stores this
- *   bitstream in memory. (the null rows from memory are written into null
- *   file after the limit is reached, and the place for new null rows
- *   to be kept in memory is freed. Should not be used by application
- *   programs.
- *   returns:    0  if successful
- *              -1  on fail
-#include <sys/types.h>
-#include <fcntl.h>
-#include "G.h"
-static int put_raster_data(int, char *, const void *, int, int, int,
-			   RASTER_MAP_TYPE);
-static int put_data(int, char *, const CELL *, int, int, int);
-static int check_open(const char *, int);
-static void write_error(int, int);
-static int same(const unsigned char *, const unsigned char *, int);
-static void set_file_pointer(int, int);
-static int put_fp_data(int, char *, const void *, int, int, RASTER_MAP_TYPE);
-static int put_null_data(int, const char *, int);
-static int convert_and_write_if(int, const CELL *);
-static int convert_and_write_id(int, const CELL *);
-static int convert_and_write_df(int, const DCELL *);
-static int convert_and_write_fd(int, const FCELL *);
-static int put_raster_row(int fd, const void *buf, RASTER_MAP_TYPE data_type,
-			  int zeros_r_nulls);
-static int put_null_value_row(int fd, const char *buf)
-    if (fcb->gdal)
-	G_fatal_error(_("GDAL output doesn't support writing null rows separately"));
-    switch (put_null_data(fd, buf, fcb->null_cur_row)) {
-    case -1:
-	return -1;
-    case 0:
-	return 1;
-    fcb->null_cur_row++;
-    return 1;
-int G_put_map_row(int fd, const CELL * buf)
-	G_fatal_error(_("G_put_map_row: %s is not integer! Use G_put_[f/d]_raster_row()!"),
-		      fcb->name);
-	return -1;
-    return put_raster_row(fd, buf, CELL_TYPE, 1);
-int G_put_raster_row(int fd, const void *buf, RASTER_MAP_TYPE data_type)
-    return put_raster_row(fd, buf, data_type, 0);
-int G_put_c_raster_row(int fd, const CELL * buf)
-    return G_put_raster_row(fd, buf, CELL_TYPE);
-int G_put_f_raster_row(int fd, const FCELL * buf)
-    return G_put_raster_row(fd, buf, FCELL_TYPE);
-int G_put_d_raster_row(int fd, const DCELL * buf)
-    return G_put_raster_row(fd, buf, DCELL_TYPE);
-static int check_open(const char *me, int fd)
-    switch (fcb->open_mode) {
-    case OPEN_OLD:
-	G_warning(_("%s: map [%s] not open for write - request ignored"), me,
-		  fcb->name);
-	break;
-    case OPEN_NEW_COMPRESSED:
-    case OPEN_NEW_UNCOMPRESSED:
-	return 1;
-	break;
-    default:
-	G_warning(_("%s: unopened file descriptor - request ignored"), me);
-	break;
-    return 0;
-static void write_error(int fd, int row)
-    if (fcb->io_error)
-	return;
-    G_warning(_("map [%s] - unable to write row %d"), fcb->name, row);
-    fcb->io_error = 1;
-static int write_data(int fd, int row, unsigned char *buf, int n)
-    ssize_t nwrite = fcb->nbytes * n;
-    if (write(fd, buf, nwrite) != nwrite) {
-	write_error(fd, row);
-	return -1;
-    return 0;
-static int write_data_compressed(int fd, int row, unsigned char *buf, int n)
-    int nwrite = fcb->nbytes * n;
-    if (G_zlib_write(fd, buf, nwrite) < 0) {
-	return -1;
-    return 0;
-static void set_file_pointer(int fd, int row)
-    fcb->row_ptr[row] = lseek(fd, 0L, SEEK_CUR);
-static int convert_float(XDR * xdrs, char *null_buf, const FCELL * rast,
-			 int row, int n)
-    int i;
-    for (i = 0; i < n; i++) {
-	FCELL f;
-	/* substitute embeded null vals by 0's */
-	if (G_is_f_null_value(&rast[i])) {
-	    f = 0.;
-	    null_buf[i] = 1;
-	else
-	    f = rast[i];
-	if (!xdr_float(xdrs, &f)) {
-	    G_warning(_("xdr_float failed for index %d of row %d"), i, row);
-	    return -1;
-    return 0;
-static int convert_double(XDR * xdrs, char *null_buf, const DCELL * rast,
-			  int row, int n)
-    int i;
-	DCELL d;
-	if (G_is_d_null_value(&rast[i])) {
-	    d = 0.;
-	    null_buf[i] = 1;
-	else
-	    d = rast[i];
-	if (!xdr_double(xdrs, &d)) {
-	    G_warning(_("xdr_double failed for index %d of row %d"), i, row);
-	    return -1;
-    return 0;
-/* writes data to fcell file for either full or partial rows */
-static int put_fp_data(int fd, char *null_buf, const void *rast,
-		       int row, int n, RASTER_MAP_TYPE data_type)
-    int compressed = (fcb->open_mode == OPEN_NEW_COMPRESSED);
-    XDR *xdrs = &fcb->xdrstream;
-    char *work_buf;
-    if (row < 0 || row >= fcb->cellhd.rows)
-	return 0;
-    if (n <= 0)
-	return 0;
-    work_buf = G__alloca(G__.window.cols * fcb->nbytes + 1);
-    if (compressed)
-	set_file_pointer(fd, row);
-    xdrmem_create(xdrs, work_buf,
-		  (unsigned int) fcb->nbytes * fcb->cellhd.cols, XDR_ENCODE);
-    xdr_setpos(xdrs, 0);
-    if (data_type == FCELL_TYPE) {
-	if (convert_float(xdrs, null_buf, rast, row, n) < 0) {
-	    G__freea(work_buf);
-	    return -1;
-    else {
-	if (convert_double(xdrs, null_buf, rast, row, n) < 0) {
-	    return -1;
-    xdr_destroy(&fcb->xdrstream);
-    if (compressed) {
-	if (write_data_compressed(fd, row, work_buf, n) == -1) {
-	    return -1;
-    else if (write_data(fd, row, work_buf, n) == -1) {
-	return -1;
-    return 1;
-static void convert_int(unsigned char *wk, char *null_buf, const CELL * rast,
-			int n, int len, int zeros_r_nulls)
-    int i;
-    /* transform CELL data into non-machine dependent multi-byte format */
-	CELL v = rast[i];
-	int neg;
-	int k;
-	if (G_is_c_null_value(&v)) {
-	    v = 0;
-	    null_buf[i] = 1;
-	else if (zeros_r_nulls && !v)
-	    null_buf[i] = 1;
-	/* negatives */
-	if (v < 0) {
-	    neg = 1;
-	    v = -v;
-	else
-	    neg = 0;
-	/* copy byte by byte */
-	for (k = len - 1; k >= 0; k--) {
-	    wk[k] = v & 0xff;
-	    v >>= 8;
-	/* set negative bit in first byte */
-	if (neg)
-	    wk[0] |= 0x80;
-	wk += len;
-static int count_bytes(const unsigned char *wk, int n, int len)
-    int i, j;
-    for (i = 0; i < len - 1; i++)
-	for (j = 0; j < n; j++)
-	    if (wk[j * len + i] != 0)
-		return len - i;
-    return 1;
-static void trim_bytes(unsigned char *wk, int n, int slen, int trim)
-    unsigned char *wk2 = wk;
-    int i, j;
-	for (j = 0; j < trim; j++)
-	    wk++;
-	for (; j < slen; j++)
-	    *wk2++ = *wk++;
-static int same(const unsigned char *x, const unsigned char *y, int n)
-    return (memcmp(x, y, n) == 0);
-static int count_run(const unsigned char *src, int n, int nbytes)
-    const unsigned char *cur = src + nbytes;
-    int i;
-    for (i = 1; i < n; i++) {
-	if (i == 255 || !same(cur, src, nbytes))
-	    return i;
-	cur += nbytes;
-    return n;
-static int rle_compress(unsigned char *dst, unsigned char *src, int n,
-			int nbytes)
-    int nwrite = 0;
-    int total = nbytes * n;
-    while (n > 0) {
-	int count;
-	nwrite += nbytes + 1;
-	if (nwrite >= total)
-	    return 0;
-	count = count_run(src, n, nbytes);
-	*dst++ = count;
-	memcpy(dst, src, nbytes);
-	dst += nbytes;
-	src += count * nbytes;
-	n -= count;
-    return nwrite;
-static int zlib_compress(unsigned char *dst, unsigned char *src, int n,
-			 int nbytes)
-    int nwrite = G_zlib_compress(src, total, dst, total);
-    return (nwrite >= total) ? 0 : nwrite;
-static int put_data(int fd, char *null_buf, const CELL *cell,
-		    int row, int n, int zeros_r_nulls)
-    int compressed = fcb->cellhd.compressed;
-    int len = compressed ? sizeof(CELL) : fcb->nbytes;
-    unsigned char *work_buf, *wk;
-    ssize_t nwrite;
-	return 0;
-    if (n <= 0)
-	return 0;
-    work_buf = G__alloca(G__.window.cols * sizeof(CELL) + 1);
-    wk = work_buf;
-    if (compressed)
-    if (compressed)
-	wk++;
-    convert_int(wk, null_buf, cell, n, len, zeros_r_nulls);
-    if (compressed) {
-	unsigned char *wk = work_buf + 1;
-	int nbytes = count_bytes(wk, n, len);
-	unsigned char *compressed_buf;
-	int total;
-	if (fcb->nbytes < nbytes)
-	/* first trim away zero high bytes */
-	if (nbytes < len)
-	    trim_bytes(wk, n, len, len - nbytes);
-	total = nbytes * n;
-	compressed_buf = G__alloca(total + 1);
-	compressed_buf[0] = work_buf[0] = nbytes;
-	/* then compress the data */
-	nwrite = compressed == 1
-	    ? rle_compress(compressed_buf + 1, work_buf + 1, n,
-			   nbytes)
-	    : zlib_compress(compressed_buf + 1, work_buf + 1, n,
-			    nbytes);
-	if (nwrite > 0) {
-	    nwrite++;
-	    if (write(fd, compressed_buf, nwrite) != nwrite) {
-		G__freea(compressed_buf);
-		return -1;
-	else {
-	    nwrite = nbytes * n + 1;
-	    if (write(fd, work_buf, nwrite) != nwrite) {
-		return -1;
-    else {
-	nwrite = fcb->nbytes * n;
-	    return -1;
-    return 1;
-static int put_data_gdal(int fd, const void *rast, int row, int n,
-			 int zeros_r_nulls, RASTER_MAP_TYPE map_type)
-#ifdef HAVE_GDAL
-    int size = G_raster_size(map_type);
-    DCELL null_val = fcb->gdal->null_val;
-    const void *src;
-    void *work_buf, *dst;
-    GDALDataType datatype;
-    CPLErr err;
-    int i;
-	return 0;
-    if (n <= 0)
-	return 0;
-    work_buf = G__alloca(n * size);
-    case CELL_TYPE:	datatype = GDT_Int32;	break;
-    case FCELL_TYPE:	datatype = GDT_Float32;	break;
-    case DCELL_TYPE:	datatype = GDT_Float64;	break;
-    src = rast;
-    dst = work_buf;
-	if (G_is_null_value(src, map_type) || zeros_r_nulls && !*(CELL *)src)
-	    G_set_raster_value_d(dst, null_val, map_type);
-	else
-	    memcpy(dst, src, size);
-	src = G_incr_void_ptr(src, size);
-	dst = G_incr_void_ptr(dst, size);
-    err = G_gdal_raster_IO(fcb->gdal->band, GF_Write, 0, row, n, 1, work_buf,
-			   n, 1, datatype, 0, 0);
-    return err == CE_None ? 1 : -1;
-#else
-    return -1;
-#endif
-static int put_raster_data(int fd, char *null_buf, const void *rast,
-			   int row, int n,
-    if (fcb->gdal)
-	return put_data_gdal(fd, rast, row, n, zeros_r_nulls, map_type);
-    return (map_type == CELL_TYPE)
-	? put_data(fd, null_buf, rast, row, n, zeros_r_nulls)
-	: put_fp_data(fd, null_buf, rast, row, n, map_type);
-static int put_null_data(int fd, const char *flags, int row)
-    int null_fd, i;
-    if (fcb->min_null_row + NULL_ROWS_INMEM <= row) {
-	/* the row is out of the range of rows stored in memory */
-	/* write out all the rows kept in memory, and initialize memory
-	   for keeping new NULL_ROWS_INMEM rows */
-	if (fcb->min_null_row >= 0) {
-	    null_fd = G__open_null_write(fd);
-	    if (null_fd < 0)
-		return -1;
-	    for (i = 0; i < NULL_ROWS_INMEM; i++) {
-		/* fcb->cellhd.rows doesn't have to be a miultiple of NULL_ROWS_INMEM */
-		if (i + fcb->min_null_row >= fcb->cellhd.rows)
-		    break;
-		if (G__write_null_bits(null_fd, fcb->NULL_ROWS[i],
-				       i + fcb->min_null_row,
-				       fcb->cellhd.cols, fd) < 0)
-		    return -1;
-	    }			/* done writing out memory rows */
-	    if (null_fd >= 0)
-		close(null_fd);
-	/* now initialize memory to store new NULL_ROWS_INMEM rows */
-	fcb->min_null_row = fcb->min_null_row + NULL_ROWS_INMEM;
-	/* init memory to store next NULL_ROWS_INMEM rows */
-    /* remember the null row for i for the future writing */
-    G__convert_01_flags(flags, fcb->NULL_ROWS[row - fcb->min_null_row],
-			fcb->cellhd.cols);
-    return 1;
-int G__open_null_write(int fd)
-    int null_fd;
-    if (access(fcb->null_temp_name, 0) != 0) {
-	G_warning(_("unable to find a temporary null file %s"),
-		  fcb->null_temp_name);
-	return -1;
-    null_fd = open(fcb->null_temp_name, O_WRONLY);
-    if (null_fd < 0)
-	return -1;
-    return null_fd;
-int G__write_null_bits(int null_fd, const unsigned char *flags, int row,
-		       int cols, int fd)
-    off_t offset;
-    size_t size;
-    size = G__null_bitstream_size(cols);
-    offset = (off_t) size *row;
-    if (lseek(null_fd, offset, SEEK_SET) < 0) {
-	G_warning(_("error writing null row %d"), row);
-	return -1;
-    if (write(null_fd, flags, size) != size) {
-	return -1;
-    return 1;
-static int convert_and_write_if(int fd, const CELL * buf)
-    FCELL *p = (FCELL *) fcb->data;
-    int i;
-    for (i = 0; i < fcb->cellhd.cols; i++)
-	if (G_is_c_null_value(&buf[i]))
-	    G_set_f_null_value(&p[i], 1);
-	else
-	    p[i] = (FCELL) buf[i];
-    return G_put_f_raster_row(fd, p);
-static int convert_and_write_df(int fd, const DCELL * buf)
-    int i;
-	if (G_is_d_null_value(&buf[i]))
-	else
-static int convert_and_write_id(int fd, const CELL * buf)
-    DCELL *p = (DCELL *) fcb->data;
-    int i;
-	    G_set_d_null_value(&p[i], 1);
-	else
-	    p[i] = (DCELL) buf[i];
-    return G_put_d_raster_row(fd, p);
-static int convert_and_write_fd(int fd, const FCELL * buf)
-    int i;
-	if (G_is_f_null_value(&buf[i]))
-	else
-static int convert_and_write_fi(int fd, const FCELL * buf)
-    CELL *p = (CELL *) fcb->data;
-    int i;
-	    G_set_c_null_value(&p[i], 1);
-	else
-	    p[i] = (CELL) buf[i];
-    return G_put_c_raster_row(fd, p);
-static int convert_and_write_di(int fd, const DCELL * buf)
-    int i;
-	else
-    static int (*convert_and_write_FtypeOtype[3][3])() = {
-	{NULL, convert_and_write_if, convert_and_write_id},
-	{convert_and_write_fi, NULL, convert_and_write_fd},
-	{convert_and_write_di, convert_and_write_df, NULL}
-    char *null_buf;
-    int stat;
-    if (!check_open("put_raster_row", fd))
-	return -1;
-    if (fcb->map_type != data_type)
-	return convert_and_write_FtypeOtype[data_type][fcb->map_type] (fd,
-								       buf);
-    null_buf = G__alloca(fcb->cellhd.cols);
-    G_zero(null_buf, fcb->cellhd.cols);
-    switch (put_raster_data(
-		fd, null_buf, buf, fcb->cur_row, fcb->cellhd.cols,
-		zeros_r_nulls, data_type)) {
-    case -1:
-	G__freea(null_buf);
-	return -1;
-    case 0:
-	return 1;
-    /* only for integer maps */
-    if (data_type == CELL_TYPE) {
-	if (fcb->want_histogram)
-	    G_update_cell_stats(buf, fcb->cellhd.cols, &fcb->statf);
-	G__row_update_range(buf, fcb->cellhd.cols, &fcb->range,
-			    zeros_r_nulls);
-    else
-	G_row_update_fp_range(buf, fcb->cellhd.cols, &fcb->fp_range,
-			      data_type);
-    fcb->cur_row++;
-    /* write the null row for the data row */
-    if (fcb->gdal)
-	stat = 0;
-    else
-	stat = put_null_value_row(fd, null_buf);
-    return stat;
Deleted: grass/trunk/lib/gis/put_title.c
--- grass/trunk/lib/gis/put_title.c	2009-06-20 21:39:23 UTC (rev 38002)
+++ grass/trunk/lib/gis/put_title.c	2009-06-20 22:03:23 UTC (rev 38003)
@@ -1,81 +0,0 @@
- * G_put_cell_title (name, title)
- *   char *name        name of map file
- *   char *title       new title
- *   changes the title for the cell file 'name' in  current mapset
- *   returns  1 if ok, -1 if error
-#include <grass/gis.h>
-int G_put_cell_title(const char *name, const char *title)
-    const char *mapset;
-    FILE *in, *out;
-    char *tempfile;
-    int line;
-    char buf[1024];
-    mapset = G_mapset();
-    in = out = 0;
-    in = G_fopen_old("cats", name, mapset);
-    if (!in) {
-	G_warning (_("category information for [%s] in [%s]"
-		     " missing or invalid"),
-		   name, mapset);
-	return -1;
-    tempfile = G_tempfile();
-    out = fopen(tempfile, "w");
-    if (!out) {
-	fclose(in);
-	G_warning (_("G_put_title - can't create a temp file"));
-	return -1;
-    for (line = 0; G_getl(buf, sizeof buf, in); line++) {
-	if (line == 1) {
-	    strcpy(buf, title);
-	    G_strip(buf);
-	fprintf(out, "%s\n", buf);
-    fclose(in);
-    fclose(out);
-    /* must be #cats line, title line, and label for cat 0 */
-    if (line < 3) {
-	G_warning (_("category information for [%s] in [%s] invalid"),
-		   name, mapset);
-	return -1;
-    in = fopen(tempfile, "r");
-    if (!in) {
-	G_warning (_("G_put_title - can't reopen temp file"));
-	return -1;
-    out = G_fopen_new("cats", name);
-    if (!out) {
-	fclose(in);
-	G_warning (_("can't write category information for [%s] in [%s]"),
-		   name, mapset);
-	return -1;
-    while (fgets(buf, sizeof buf, in))
-	fprintf(out, "%s", buf);
-    fclose(in);
-    fclose(out);
-    remove(tempfile);
-    return 1;
Deleted: grass/trunk/lib/gis/quant.c
--- grass/trunk/lib/gis/quant.c	2009-06-20 21:39:23 UTC (rev 38002)
+++ grass/trunk/lib/gis/quant.c	2009-06-20 22:03:23 UTC (rev 38003)
@@ -1,791 +0,0 @@
- * \file gis/quant.c
- * \brief GIS Library - Quantization rules.
- * The quantization table is stored as a linear array. rules are added
- * starting from index 0. redundant rules are not eliminated. rules
- * are tested from the highest index downto 0. there are two
- * "infinite" rules. support is provided to reverse the order of the
- * rules.
- * (C) 1999-2009 by the GRASS Development Team
- * License (>=v2). Read the file COPYING that comes with GRASS
- * for details.
- * \author USACERL and many others
-#include <stdlib.h>
-static int double_comp(const void *, const void *);
-#define USE_LOOKUP 1
-#define MAX_LOOKUP_TABLE_SIZE 2048
-#define NO_DATA (G_set_c_null_value (&tmp, 1), (CELL) tmp)
-#undef MIN
-#undef MAX
-#define MIN(a,b) ((a) < (b) ? (a) : (b))
-#define MAX(a,b) ((a) > (b) ? (a) : (b))
-#define NO_LEFT_INFINITE_RULE (! q->infiniteLeftSet)
-#define NO_RIGHT_INFINITE_RULE (! q->infiniteRightSet)
-#define NO_FINITE_RULE (q->nofRules <= 0)
-#define NO_EXPLICIT_RULE (NO_FINITE_RULE && \
-			  NO_LEFT_INFINITE_RULE && NO_RIGHT_INFINITE_RULE)
-  \brief Resets the number of defined rules and number of infinite rules to 0
-  \param q pointer to Quant structure to be reset
-void G_quant_clear(struct Quant *q)
-    q->nofRules = 0;
-    q->infiniteRightSet = q->infiniteLeftSet = 0;
-  \brief Resets and frees allocated memory
-  Resets the number of defined rules to 0 and free's space allocated
-  for rules. Calls G_quant_clear().
-void G_quant_free(struct Quant *q)
-    G_quant_clear(q);
-    if (q->maxNofRules > 0)
-	G_free(q->table);
-    if (q->fp_lookup.active) {
-	G_free(q->fp_lookup.vals);
-	G_free(q->fp_lookup.rules);
-	q->fp_lookup.nalloc = 0;
-	q->fp_lookup.active = 0;
-    q->maxNofRules = 0;
- * \brief Organized fp_lookup table.
- *  Organizes fp_lookup table for faster (logarithmic) lookup time
- *  G_quant_organize_fp_lookup() creates a list of min and max for
- *  each quant rule, sorts this list, and stores the pointer to quant
- *  rule that should be used inbetween any 2 numbers in this list.
- *  Also it stores extreme points for 2 infinite rules, if exist.
- *  After the call to G_quant_organize_fp_lookup()
- *  instead of linearly searching through list of rules to find
- *  a rule to apply, quant lookup will perform a binary search
- *  to find an interval containing floating point value, and then use
- *  the rule associated with this interval.
- *  when the value doesn't fall within any interval, check for the
- *  infinite rules.
- * \param q pointer to Quant structure which holds quant rules info
- * \return 1 on success
-int G__quant_organize_fp_lookup(struct Quant *q)
-    int i;
-    DCELL val;
-    CELL tmp;
-    if (q->nofRules * 2 > MAX_LOOKUP_TABLE_SIZE)
-	return -1;
-    if (q->nofRules == 0)
-	return -1;
-    q->fp_lookup.vals = (DCELL *)
-	G_calloc(q->nofRules * 2, sizeof(DCELL));
-    /* 2 endpoints for each rule */
-    q->fp_lookup.rules = (struct Quant_table **)
-	G_calloc(q->nofRules * 2, sizeof(struct Quant_table *));
-    /* first we organize finite rules into a table */
-    if (!NO_FINITE_RULE) {
-	i = 0;
-	/* get the list of DCELL values from set of all dLows and dHighs
-	   of all rules */
-	/* NOTE: if dLow==DHigh in a rule, the value appears twice in a list
-	   but if dLow==DHigh of the previous, rule the value appears only once */
-	for (p = &(q->table[q->nofRules - 1]); p >= q->table; p--) {
-	    /* check if the min is the same as previous maximum */
-	    if (i == 0 || p->dLow != q->fp_lookup.vals[i - 1])
-		q->fp_lookup.vals[i++] = p->dLow;
-	    q->fp_lookup.vals[i++] = p->dHigh;
-	q->fp_lookup.nalloc = i;
-	/* now sort the values */
-	qsort((char *)q->fp_lookup.vals, q->fp_lookup.nalloc,
-	      sizeof(DCELL), double_comp);
-	/* now find the rule to apply inbetween each 2 values in a list */
-	for (i = 0; i < q->fp_lookup.nalloc - 1; i++) {
-	    /*debug
-	       fprintf (stderr, "%lf %lf ", q->fp_lookup.vals[i], q->fp_lookup.vals[i+1]);
-	    val = (q->fp_lookup.vals[i] + q->fp_lookup.vals[i + 1]) / 2.;
-	    q->fp_lookup.rules[i] =
-		G__quant_get_rule_for_d_raster_val(q, val);
-	    /* debug
-	       if(q->fp_lookup.rules[i])
-	       fprintf (stderr, "%lf %lf %d %d\n", q->fp_lookup.rules[i]->dLow, q->fp_lookup.rules[i]->dHigh, q->fp_lookup.rules[i]->cLow, q->fp_lookup.rules[i]->cHigh);
-	       else fprintf (stderr, "null\n");
-    }				/* organizing finite rules */
-    if (!NO_LEFT_INFINITE_RULE) {
-	q->fp_lookup.inf_dmin = q->infiniteDLeft;
-	q->fp_lookup.inf_min = q->infiniteCLeft;
-    else {
-	if (q->fp_lookup.nalloc)
-	    q->fp_lookup.inf_dmin = q->fp_lookup.vals[0];
-	q->fp_lookup.inf_min = NO_DATA;
-    if (!NO_RIGHT_INFINITE_RULE) {
-	    q->fp_lookup.inf_dmax = q->infiniteDRight;
-	q->fp_lookup.inf_max = q->infiniteCRight;
-    else {
-	q->fp_lookup.inf_dmax = q->fp_lookup.vals[q->fp_lookup.nalloc - 1];
-	q->fp_lookup.inf_max = NO_DATA;
-    q->fp_lookup.active = 1;
-    return 1;
- * \brief Initialize the structure
- * Initializes the <i>q</i> struct.
- * \param quant pointer to Quant structure to be initialized
-void G_quant_init(struct Quant *quant)
-    quant->fp_lookup.active = 0;
-    quant->maxNofRules = 0;
-    quant->truncate_only = 0;
-    quant->round_only = 0;
-    G_quant_clear(quant);
-  \brief Returns wether or not quant rules are set to truncate map
-  \param quant pointer to Quant structure which holds quant rules info
-  \return 1 if truncate is enable
-  \return 0 if not truncated
-int G_quant_is_truncate(const struct Quant *quant)
-    return quant->truncate_only;
-  \brief  Returns wether or not quant rules are set to round map
-  \return 1 is round
-  \return 0 not round
-int G_quant_is_round(const struct Quant *quant)
-    return quant->round_only;
- * \brief Sets the quant rules to perform simple truncation on floats.
- * Sets the quant for <i>q</i> rules to perform simple truncation on
- * floats.
- * \param quant pointer to Quant structure which holds quant rules info
-void G_quant_truncate(struct Quant *quant)
-    quant->truncate_only = 1;
- * \brief Sets the quant rules to perform simple rounding on floats.
- * Sets the quant for <i>q</i> rules to perform simple rounding on
- * floats.
-void G_quant_round(struct Quant *quant)
-    quant->round_only = 1;
-static void quant_set_limits(struct Quant *q,
-			     DCELL dLow, DCELL dHigh, CELL cLow, CELL cHigh)
-    q->dMin = dLow;
-    q->dMax = dHigh;
-    q->cMin = cLow;
-    q->cMax = cHigh;
-static void quant_update_limits(struct Quant *q,
-				CELL cLow, DCELL cHigh)
-    if (NO_EXPLICIT_RULE) {
-	quant_set_limits(q, dLow, dHigh, cLow, cHigh);
-	return;
-    q->dMin = MIN(q->dMin, MIN(dLow, dHigh));
-    q->dMax = MAX(q->dMax, MAX(dLow, dHigh));
-    q->cMin = MIN(q->cMin, MIN(cLow, cHigh));
-    q->cMax = MAX(q->cMax, MAX(cLow, cHigh));
- * \brief Returns the minimum and maximum cell and dcell values of all
- *  the ranges defined.
- * Extracts the minimum and maximum floating-point and integer values
- * from all the rules (except the "infinite" rules) in <i>q</i> into
- * <i>dmin</i>, <i>dmax</i>, <i>cmin</i>, and <i>cmax</i>.
- * \param[out] dmin minimum fp value
- * \param[out] dmax maximum fp value
- * \param[out] cmin minimum value
- * \param[out] cmax maximum value
- * \return -1 if q->truncate or q->round are true or after
- * G_quant_init (), or any call to G_quant_clear () or G_quant_free()
- * no explicit rules have been added. In this case the returned
- * minimum and maximum CELL and DCELL values are null.
- * \return 1 if there are any explicit rules
- * \return 0 if there are no explicit rules (this includes cases when
- * q is set to truncate or round map), and sets <i>dmin</i>,
- * <i>dmax</i>, <i>cmin</i>, and <i>cmax</i> to NULL.
-int G_quant_get_limits(const struct Quant *q,
-		       DCELL * dMin, DCELL * dMax, CELL * cMin, CELL * cMax)
-	G_set_c_null_value(cMin, 1);
-	G_set_c_null_value(cMax, 1);
-	G_set_d_null_value(dMin, 1);
-	G_set_d_null_value(dMax, 1);
-	return -1;
-    *dMin = q->dMin;
-    *dMax = q->dMax;
-    *cMin = q->cMin;
-    *cMax = q->cMax;
-    return 1;
-  \brief Returns the number of quantization rules defined.
-  This number does not include the 2 infinite intervals.
-  \param q pointer to Quant structure which holds quant rules info
-  \return number of quantization rules
-int G_quant_nof_rules(const struct Quant *q)
-    return q->nofRules;
-  \brief Returns the i'th quantization rule.
-  For 0 <= i < G_quant_nof_rules(). A larger value for i means that
-  the rule has been added later.
-  \param i index
-  \param[out] dLow minimum fp value
-  \param[out] dHigh maximum fp value
-  \param[out] cLow minimum value
-  \param[out] cHigh maximum value
-void G_quant_get_ith_rule(const struct Quant *q,
-			  int i,
-			  DCELL * dLow, DCELL * dHigh,
-			  CELL * cLow, CELL * cHigh)
-    *dLow = q->table[i].dLow;
-    *dHigh = q->table[i].dHigh;
-    *cLow = q->table[i].cLow;
-    *cHigh = q->table[i].cHigh;
-static void quant_table_increase(struct Quant *q)
-    if (q->nofRules < q->maxNofRules)
-	return;
-    if (q->maxNofRules == 0) {
-	q->maxNofRules = 50;
-	q->table = (struct Quant_table *)
-	    G_malloc(q->maxNofRules * sizeof(struct Quant_table));
-    else {
-	q->maxNofRules += 50;
-	    G_realloc((char *)q->table,
-		      q->maxNofRules * sizeof(struct Quant_table));
-  \brief Defines a rule for values "dLeft" and smaller.
-  Values in this range are mapped to "c" if none of the "finite"
-  quantization rules applies.
-  \param dLeft fp value
-  \param c value
-void G_quant_set_neg_infinite_rule(struct Quant *q, DCELL dLeft, CELL c)
-    q->infiniteDLeft = dLeft;
-    q->infiniteCLeft = c;
-    quant_update_limits(q, dLeft, dLeft, c, c);
-    /* update lookup table */
-    q->infiniteLeftSet = 1;
-  \brief Returns in "dLeft" and "c" the rule values.
-  For the negative infinite interval (see G_quant_set_neg_infinite_rule()).
-  \param[out] dLeft fp value
-  \param[out] c value
-  \return 0 if this rule is not defined
-  \return 1 otherwise
-int G_quant_get_neg_infinite_rule(const struct Quant *q,
-				  DCELL * dLeft, CELL * c)
-    if (q->infiniteLeftSet == 0)
-	return 0;
-    *dLeft = q->infiniteDLeft;
-    *c = q->infiniteCLeft;
-    return 1;
-  \brief Defines a rule for values "dRight" and larger.
-  quantization rules or the negative infinite rule applies.
-  \param dRight fp value
-  \param c value
-void G_quant_set_pos_infinite_rule(struct Quant *q, DCELL dRight, CELL c)
-    q->infiniteDRight = dRight;
-    q->infiniteCRight = c;
-    quant_update_limits(q, dRight, dRight, c, c);
-    q->infiniteRightSet = 1;
-  \brief Returns in "dRight" and "c" the rule values.
-  For the positive infinite interval (see G_quant_set_pos_infinite_rule()).
-  \param[out] dRight fp value
-int G_quant_get_pos_infinite_rule(const struct Quant *q,
-				  DCELL * dRight, CELL * c)
-    if (q->infiniteRightSet == 0)
-	return 0;
-    *dRight = q->infiniteDRight;
-    *c = q->infiniteCRight;
-    return 1;
- \brief Adds a new rule to the set of quantization rules.
- If dLow < dHigh the rule will be stored with the low and high values
- interchanged.
- Note: currently no cleanup of rules is performed, i.e. redundant
- rules are not removed. This can't be changed because Categories
- structure HEAVILY depends of quant rules stored in exactly the same
- order they are entered. So if the cleanup or rearrangement is done in
- the future make a flag for add_rule wether or not to do it, then
- quant will not set this flag.
- \param dLow minimum fp value
- \param dHigh maximum fp value
- \param cLow minimum value
- \param cHigh maximum value
-void G_quant_add_rule(struct Quant *q,
-    int i;
-    quant_table_increase(q);
-    i = q->nofRules;
-    p = &(q->table[i]);
-    if (dHigh >= dLow) {
-	p->dLow = dLow;
-	p->dHigh = dHigh;
-	p->cLow = cLow;
-	p->cHigh = cHigh;
-    else {
-	p->dLow = dHigh;
-	p->dHigh = dLow;
-	p->cLow = cHigh;
-	p->cHigh = cLow;
-    /* destroy lookup table, it has to be rebuilt */
-    quant_update_limits(q, dLow, dHigh, cLow, cHigh);
-    q->nofRules++;
-  \brief Rreverses the order in which the qunatization rules are stored.
-  See also G_quant_get_ith_rule() and G_quant_perform_d()).
-  \param q pointer to Quant rules which holds quant rules info
-void G_quant_reverse_rule_order(struct Quant *q)
-    struct Quant_table tmp;
-    struct Quant_table *pLeft, *pRight;
-    pLeft = q->table;
-    pRight = &(q->table[q->nofRules - 1]);
-    while (pLeft < pRight) {
-	tmp.dLow = pLeft->dLow;
-	tmp.dHigh = pLeft->dHigh;
-	tmp.cLow = pLeft->cLow;
-	tmp.cHigh = pLeft->cHigh;
-	pLeft->dLow = pRight->dLow;
-	pLeft->dHigh = pRight->dHigh;
-	pLeft->cLow = pRight->cLow;
-	pLeft->cHigh = pRight->cHigh;
-	pRight->dLow = tmp.dLow;
-	pRight->dHigh = tmp.dHigh;
-	pRight->cLow = tmp.cLow;
-	pRight->cHigh = tmp.cHigh;
-	pLeft++;
-	pRight--;
-static CELL quant_interpolate(DCELL dLow, DCELL dHigh,
-			      CELL cLow, CELL cHigh, DCELL dValue)
-    if (cLow == cHigh)
-	return cLow;
-    if (dLow == dHigh)
-	return cLow;
-    return (CELL) ((dValue - dLow) / (dHigh - dLow) * (DCELL) (cHigh - cLow) +
-		   (DCELL) cLow);
-static int less_or_equal(double x, double y)
-    if (x <= y)
-	return 1;
-    else
-	return 0;
-static int less(double x, double y)
-    if (x < y)
-	return 1;
-    else
-	return 0;
- * \brief
- * Returns a CELL category for the floating-point <i>value</i> based
- * on the quantization rules in <i>q</i>. The first rule found that
- * applies is used. The rules are searched in the reverse order they
- * are added to <i>q</i>. If no rule is found, the <i>value</i>
- * is first tested against the negative infinite rule, and finally
- * against the positive infinite rule. If none of these rules apply,
- * the NULL-value is returned.
- * <b>Note:</b> See G_quant_organize_fp_lookup() for details on how
- * the values are looked up from fp_lookup table when it is
- * active. Right now fp_lookup is automatically organized during the
- * first call to G_quant_get_cell_value().
- * \param dcellValue fp cell value
- * \return cell value (integer)
-CELL G_quant_get_cell_value(struct Quant * q, DCELL dcellVal)
-    CELL tmp;
-    DCELL dtmp;
-    int try, min_ind, max_ind;
-    int (*lower) ();
-    dtmp = dcellVal;
-    /* I know the functions which call me already check for null values,
-       but I am a public function, and can be called from outside */
-    if (G_is_d_null_value(&dtmp))
-	return NO_DATA;
-	return (CELL) dtmp;
-    if (q->round_only) {
-	if (dcellVal > 0)
-	    return (CELL) (dcellVal + .5);
-	return (CELL) (dcellVal - .5);
-	return NO_DATA;
-	return NO_DATA;
-    if (USE_LOOKUP &&
-	(q->fp_lookup.active || G__quant_organize_fp_lookup(q) > 0)) {
-	/* first check if values fall within range */
-	/* if value is below the range */
-	if (dcellVal < q->fp_lookup.vals[0]) {
-	    if (dcellVal <= q->fp_lookup.inf_dmin)
-		return q->fp_lookup.inf_min;
-	    else
-		return NO_DATA;
-	/* if value is below above range */
-	if (dcellVal > q->fp_lookup.vals[q->fp_lookup.nalloc - 1]) {
-	    if (dcellVal >= q->fp_lookup.inf_dmax)
-		return q->fp_lookup.inf_max;
-	    else
-		return NO_DATA;
-	/* make binary search to find which interval our value belongs to
-	   and apply the rule for this interval */
-	try = (q->fp_lookup.nalloc - 1) / 2;
-	min_ind = 0;
-	max_ind = q->fp_lookup.nalloc - 2;
-	while (1) {
-	    /* DEBUG
-	       fprintf (stderr, "%d %d %d\n", min_ind, max_ind, try);
-	    /* when the ruke for the interval is NULL, we exclude the end points.
-	       when it exists, we include the end-points */
-	    if (q->fp_lookup.rules[try])
-		lower = less;
-	    else
-		lower = less_or_equal;
-	    if (lower(q->fp_lookup.vals[try + 1], dcellVal)) {	/* recurse to the second half */
-		min_ind = try + 1;
-		/* must be still < nalloc-1, since number is within the range */
-		try = (max_ind + min_ind) / 2;
-		continue;
-	    if (lower(dcellVal, q->fp_lookup.vals[try])) {	/* recurse to the second half */
-		max_ind = try - 1;
-		/* must be still >= 0, since number is within the range */
-		continue;
-	    /* the value fits into the interval! */
-	    p = q->fp_lookup.rules[try];
-	    if (p)
-		return quant_interpolate(p->dLow, p->dHigh, p->cLow, p->cHigh,
-					 dcellVal);
-	    /* otherwise when finite rule for this interval doesn't exist */
-	    else {		/* first check if maybe infinite rule applies */
-		else
-		    return NO_DATA;
-	}			/* while */
-    }				/* looking up in fp_lookup */
-	p = G__quant_get_rule_for_d_raster_val(q, dcellVal);
-	if (!p)
-	    return NO_DATA;
-				 dcellVal);
-    if ((!NO_LEFT_INFINITE_RULE) && (dcellVal <= q->infiniteDLeft))
-	return q->infiniteCLeft;
-    if ((NO_RIGHT_INFINITE_RULE) || (dcellVal < q->infiniteDRight))
-	return NO_DATA;
-    return q->infiniteCRight;
-  \brief Returns in "cell" the quantized CELL values.
-  Returns in "cell" the quantized CELL values corresponding to the
-  DCELL values stored in "dcell". the number of elements quantized
-  is n. quantization is performed by repeated application of
-  G_quant_get_cell_value().
-  \param dcell pointer to fp cell values array
-  \param[out] cell pointer cell values array
-  \param n number of cells
-void G_quant_perform_d(struct Quant *q,
-		       const DCELL * dcell, CELL * cell, int n)
-    int i;
-    for (i = 0; i < n; i++, dcell++)
-	if (!G_is_d_null_value(dcell))
-	    *cell++ = G_quant_get_cell_value(q, *dcell);
-	else
-	    G_set_c_null_value(cell++, 1);
-  \brief Same as G_quant_perform_d(), except the type.
-  \param fcell pointer to fp cell values array
-void G_quant_perform_f(struct Quant *q,
-		       const FCELL * fcell, CELL * cell, int n)
-    int i;
-    for (i = 0; i < n; i++, fcell++)
-	if (!G_is_f_null_value(fcell))
-	    *cell++ = G_quant_get_cell_value(q, (DCELL) * fcell);
-	else
-static int double_comp(const void *xx, const void *yy)
-    const DCELL *x = xx;
-    const DCELL *y = yy;
-    if (G_is_d_null_value(x))
-	return 0;
-    if (*x < *y)
-	return -1;
-    else if (*x == *y)
-	return 0;
-    else
-	return 1;
-  \brief Returns quant rule which will be applied.
-  Returns quant rule which will be applied when looking up the integer
-  quant value for val (used when organizing fp_lookup).
-  \param val fp cell value
-  \return pointer to the Quant_table (color rule)
-  \return NULL otherwise
-struct Quant_table *G__quant_get_rule_for_d_raster_val(const struct Quant *q,
-						       DCELL val)
-    const struct Quant_table *p;
-	if ((val >= p->dLow) && (val <= p->dHigh))
-	    break;
-    if (p >= q->table)
-	return (struct Quant_table *)p;
-    else
-	return (struct Quant_table *)NULL;
Deleted: grass/trunk/lib/gis/quant_io.c
--- grass/trunk/lib/gis/quant_io.c	2009-06-20 21:39:23 UTC (rev 38002)
+++ grass/trunk/lib/gis/quant_io.c	2009-06-20 22:03:23 UTC (rev 38003)
@@ -1,316 +0,0 @@
- *  int
- *  G__quant_import (name, mapset, quant)
- *      char *name;
- *      char *mapset;
- *      struct Quant *quant;
- *  reads quantization rules for "name" in "mapset" and stores them
- *  in the quantization structure "quant". If the map is in another
- *  mapset, first checks for quant2 table for this map in current
- *  mapset.
- *  returns: -2 if raster map is of type integer.
- *           -1 if (! G__name_is_fully_qualified ()).
- *            0 if quantization file does not exist, or the file is empty,
- *            1 if non-empty quantization file exists.
- *                 read.
- *  note: in the case of negative return value, the result of using the
- *        quantization structure is not defined.
- *        in case of return value 0, calls to G_quant_perform_d ()
- *        and G_quant_perform_f () return NO_DATA (see description of
- *        G_quant_perform_d () for more details). in case of
- *        return values 2 and 3, the explicit rule for quant is set:
- *        floating range is mapped to integer range.
- *  note: use G_quant_init () to allocate and initialize the quantization
- *        staructure quant before the first usage of G_quant_import ().
- *  note: this function uses G_quant_free () to clear all previously
- *        stored rules in quant.
- *  int
- *  G__quant_export (name, mapset, quant)
- *     char *name, *mapset;
- *  writes the quantization rules stored in "quant" for "name" . if the
- *  mapset is the same as the current mapset, the quant file is created
- *  in cell_misc/name directory, otherwise it is created in quant2/mapset
- *  directory, much like writing colors for map in another mapset.
- *  The rules are written in decreasing order
- *  of priority (i.e. rules added earlier are written later).
- *  returns: -1 if (! G__name_is_fully_qualified) or file could not be
- *                 opened.
- *            1 otherwise.
- *  note: if no rules are defined an empty file is created.
-#include <grass/glocale.h>
-#include <string.h>
-#define QUANT_FILE_NAME "f_quant"
-static int quant_parse_file(FILE *, struct Quant *);
-#if 0
-static int
-/* redundant: integer range doesn't exist now: it is defined by
-   the quant rules */
-quant_load_range(struct Quant *quant, const char *name, const char *mapset)
-    struct FPRange fprange;
-    struct Range range;
-    char buf[300];
-    DCELL dMin, dMax;
-    CELL min, max;
-    if (G_read_fp_range(name, mapset, &fprange) <= 0)
-	return 0;
-    G_get_fp_range_min_max(&fprange, &dMin, &dMax);
-    if (G_is_d_null_value(&dMin) || G_is_d_null_value(&dMax)) {
-	G_warning (_("The floating data range for %s@%s is empty"),
-		   name, mapset);
-	return -3;
-    if (G_read_range(name, mapset, &range) < 0)
-	return 0;
-    G_get_range_min_max(&range, &min, &max);
-    if (G_is_c_null_value(&min) && G_is_c_null_value(&max)) {
-	G_warning (_("The integer data range for %s@%s is empty"),
-		   name, mapset);
-	return -3;
-    G_quant_add_rule(quant, dMin, dMax, min, max);
-    return 1;
-#endif
-int G__quant_import(const char *name, const char *mapset, struct Quant *quant)
-    char buf[1024];
-    char *err;
-    char xname[GNAME_MAX], xmapset[GMAPSET_MAX], element[GNAME_MAX + 7];
-    int parsStat;
-    FILE *fd;
-    G_quant_free(quant);
-    if (G_raster_map_type(name, mapset) == CELL_TYPE) {
-	G_warning (_("G__quant_import: attempt to open quantization"
-		     " table for CELL_TYPE file [%s] in mapset {%s]"),
-		   name, mapset);
-	return -2;
-    if (G__name_is_fully_qualified(name, xname, xmapset)) {
-	if (strcmp(xmapset, mapset) != 0)
-	    return -1;
-	name = xname;
-    /* first check if quant2/mapset/name exists in the current mapset */
-    sprintf(element, "quant2/%s", mapset);
-    if ((fd = G_fopen_old(element, name, G_mapset()))) {
-	parsStat = quant_parse_file(fd, quant);
-	fclose(fd);
-	if (parsStat)
-	    return 1;
-	sprintf(buf,
-		"quantization file in quant2 for [%s] in mapset [%s] is empty",
-		name, mapset);
-    /* now try reading regular : cell_misc/name/quant file */
-    if (!(fd = G_fopen_old_misc("cell_misc", QUANT_FILE_NAME, name, mapset))) {
-	/* int range doesn't exist anymore if (quant_load_range (quant, name, mapset)>0) return 3; */
-	err = "missing";
-    else {
-	fclose(fd);
-	if (parsStat)
-	    return 1;
-	/* int range doesn't exist anymore if (quant_load_range (quant, name, mapset)>0) return 2; */
-	err = "empty";
-    G_warning (_("quantization file [%s] in mapset [%s] %s"),
-	       name, mapset, err);
-    return 0;
-/* parse input lines with the following formats
- *   d_high:d_low:c_high:c_low
- *   d_high:d_low:c_val          (i.e. c_high == c_low)
- *   *:d_val:c_val               (interval [inf, d_val])  (**)
- *   d_val:*:c_val               (interval [d_val, inf])  (**)
- *   all other lines are ignored
- *  (**) only the first appearances in the file are considered.
-static int quant_parse_file(FILE * fd, struct Quant *quant)
-    CELL cLow, cHigh;
-    DCELL dLow, dHigh;
-    char buf[1024];
-    int foundNegInf = 0, foundPosInf = 0;
-    while (fgets(buf, sizeof(buf), fd)) {
-	if (strncmp(buf, "truncate", 8) == 0) {
-	    return 1;
-	if (strncmp(buf, "round", 5) == 0) {
-	    return 1;
-	switch (sscanf(buf, "%lf:%lf:%d:%d", &dLow, &dHigh, &cLow, &cHigh)) {
-	case 3:
-	    G_quant_add_rule(quant, dLow, dHigh, cLow, cLow);
-	    break;
-	case 4:
-	    G_quant_add_rule(quant, dLow, dHigh, cLow, cHigh);
-	    break;
-	default:
-	    switch (sscanf(buf, "*:%lf:%d", &dLow, &cLow)) {
-	    case 2:
-		if (!foundNegInf) {
-		    G_quant_set_neg_infinite_rule(quant, dLow, cLow);
-		    foundNegInf = 1;
-		break;
-	    default:
-		switch (sscanf(buf, "%lf:*:%d", &dLow, &cLow)) {
-		case 2:
-		    if (!foundPosInf) {
-			G_quant_set_pos_infinite_rule(quant, dLow, cLow);
-			foundPosInf = 1;
-		    break;
-		default:
-		    continue;	/* other lines are ignored */
-    if (G_quant_nof_rules(quant) > 0)
-	G_quant_reverse_rule_order(quant);
-    return ((G_quant_nof_rules(quant) > 0) ||
-	    (G_quant_get_neg_infinite_rule(quant, &dLow, &cLow) > 0) ||
-	    (G_quant_get_pos_infinite_rule(quant, &dLow, &cLow) > 0));
-static void quant_write(FILE * fd, const struct Quant *quant)
-    CELL cLow, cHigh;
-    int i;
-    if (quant->truncate_only) {
-	fprintf(fd, "truncate");
-	return;
-    if (quant->round_only) {
-	fprintf(fd, "round");
-	return;
-    if (G_quant_get_neg_infinite_rule(quant, &dLow, &cLow) > 0)
-	fprintf(fd, "*:%.20g:%d\n", dLow, cLow);
-    if (G_quant_get_pos_infinite_rule(quant, &dLow, &cLow) > 0)
-	fprintf(fd, "%.20g:*:%d\n", dLow, cLow);
-    for (i = G_quant_nof_rules(quant) - 1; i >= 0; i--) {
-	G_quant_get_ith_rule(quant, i, &dLow, &dHigh, &cLow, &cHigh);
-	fprintf(fd, "%.20g:%.20g:%d", dLow, dHigh, cLow);
-	if (cLow != cHigh)
-	    fprintf(fd, ":%d", cHigh);
-	fprintf(fd, "\n");
-int
-G__quant_export(const char *name, const char *mapset,
-		const struct Quant *quant)
-    char element[GNAME_MAX + 7];
-    FILE *fd;
-	    return -1;
-	name = xname;
-    if (strcmp(G_mapset(), mapset) == 0) {
-	G_remove_misc("cell_misc", QUANT_FILE_NAME, name);
-	G__make_mapset_element_misc("cell_misc", name);
-	if (!(fd = G_fopen_new_misc("cell_misc", QUANT_FILE_NAME, name)))
-	    return -1;
-    else {
-	G_remove(element, name);
-	G__make_mapset_element(element);
-	if (!(fd = G_fopen_new(element, name)))
-	    return -1;
-    quant_write(fd, quant);
-    fclose(fd);
-    return 1;
Deleted: grass/trunk/lib/gis/quant_rw.c
--- grass/trunk/lib/gis/quant_rw.c	2009-06-20 21:39:23 UTC (rev 38002)
+++ grass/trunk/lib/gis/quant_rw.c	2009-06-20 22:03:23 UTC (rev 38003)
@@ -1,227 +0,0 @@
- * \file gis/quant_rw.c
- * \brief GIS Library - Quantization rules (read/write).
- * This program is free software under the GNU General Public
- * for details.
-  \brief Writes the quant rules.
-  Writes the quant rules which indicate that all floating numbers
-  should be truncated instead of applying any quant rules from
-  floats to integers.
-  \param name map name
-  \param mapset mapset name
-int G_truncate_fp_map(const char *name, const char *mapset)
-    struct Quant quant;
-    G_quant_init(&quant);
-    G_quant_truncate(&quant);
-    /* quantize the map */
-    if (G_write_quant(name, mapset, &quant) < 0) {
-	G_warning(_("Unable to write quant rules for raster map <%s>"),
-		  name);
-	return -1;
-    return 1;
-  should be rounded instead of applying any quant rules from
-int G_round_fp_map(const char *name, const char *mapset)
-    G_quant_round(&quant);
-    /* round the map */
-		  name);
-	return -1;
-    return 1;
- * \brief Write quant rules (f_quant) for floating-point raster map.
- * Writes the <tt>f_quant</tt> file for the raster map <em>name</em>
- * with one rule. The rule is generated using the floating-point range
- * in <tt>f_range</tt> producing the integer range
- * [<em>cmin,cmax</em>].
- * Make a rule for map <name> that maps floating range (d_min, d_max)
- * into integer range (min, max)
- * This function is useful when the quant rule doesn't depend of the
- * range of produced float data, for example the slope map whould
- * want to have a quant rule: 0.0, 90.0 -> 0 , 90
- * no matter what the min and max slope of this map is.
- * \param name map name
- * \param mapset mapset name
- * \param cmin minimum value
- * \param cmax maximum value
- * \return -1 on error
-int G_quantize_fp_map(const char *name, const char *mapset,
-		      CELL min, CELL max)
-    DCELL d_min, d_max;
-    struct FPRange fp_range;
-    if (G_read_fp_range(name, mapset, &fp_range) < 0) {
-	G_warning(_("Unable to read fp range for raster map <%s>"),
-		  G_fully_qualified_name(name, mapset));
-	return -1;
-    G_get_fp_range_min_max(&fp_range, &d_min, &d_max);
-    if (G_is_d_null_value(&d_min) || G_is_d_null_value(&d_max)) {
-	G_warning(_("Raster map <%s> is empty"),
-	return -1;
-    return G_quantize_fp_map_range(name, mapset, d_min, d_max, min, max);
- * <em>name</em> with one rule. The rule is generated using the floating-point
- * range [<em>dmin,dmax</em>] and the integer range
- * [<em>min,max</em>].
- * This routine differs from the one above in that the application controls the
- * floating-point range. For example, r.slope.aspect will use this routine to
- * quantize the slope map from [0.0, 90.0] to [0,
- * 90] even if the range of slopes is not 0-90. The aspect map would be
- * quantized from [0.0, 360.0] to [0, 360].
- * \param d_min minimum fp value
- * \param d_max maximum fp value
- * \param min minimum value
- * \param max maximum value
-int G_quantize_fp_map_range(const char *name, const char *mapset,
-			    DCELL d_min, DCELL d_max, CELL min, CELL max)
-    G_quant_add_rule(&quant, d_min, d_max, min, max);
-		  name);
-	return -1;
-    return 1;
- * \brief Writes the quant rule table for the raster map
- * from <em>q</em>.  if mapset==G_mapset() i.e. the map is in current
- * mapset, then the original quant file in cell_misc/map/f_quant is
- * written. Otherwise <em>q</em> is written into quant2/mapset/name
- * (much like colr2 element). This results in map at mapset being read
- * using quant rules stored in <em>q</em> from G_mapset(). See
- * G_read_quant() for detailes.
- * \param quant pointer to Quant structure which hold quant rules info
-int G_write_quant(const char *name, const char *mapset,
-    CELL cell_min, cell_max;
-	G_warning(_("Unable to write quant rules: raster map <%s> is integer"),
-		  name);
-	return -1;
-    G_quant_get_limits(quant, &d_min, &d_max, &cell_min, &cell_max);
-    /* first actually write the rules */
-    if (G__quant_export(name, mapset, quant) < 0) {
-	G_warning (_("Unable to write quant rules for raster map <%s>"),
-		   name);
-	return -1;
-    return 1;
- * \brief
- * Reads quantization rules for <i>name</i> in <i>mapset</i> and
- * stores them in the quantization structure. If the map is in another
- * mapset.
- *  \param name
- *  \param mapset
- *  \param q
- * \return -2 if raster map is of type integer
- * \return -1 if (!G__name_is_fully_qualified())
- * \return 0 if quantization file does not exist, or the file is empty or has wrong format
- * \return 1 if non-empty quantization file exists
-int G_read_quant(const char *name, const char *mapset, struct Quant *quant)
-    G_quant_init(quant);
-    return G__quant_import(name, mapset, quant);
Deleted: grass/trunk/lib/gis/range.c
--- grass/trunk/lib/gis/range.c	2009-06-20 21:39:23 UTC (rev 38002)
+++ grass/trunk/lib/gis/range.c	2009-06-20 22:03:23 UTC (rev 38003)
@@ -1,600 +0,0 @@
- * \file gis/range.c
- * \brief GIS Library - Raster range file management
- * (C) 2001-2009 GRASS Development Team
- * This program is free software under the GNU General Public License
- * (>=v2). Read the file COPYING that comes with GRASS for details.
- * \author Original author CERL
-#include <unistd.h>
-#include <rpc/types.h>		/* need this for sgi */
-#include <rpc/xdr.h>
-#include "G.h"
-#define DEFAULT_CELL_MIN 1
-#define DEFAULT_CELL_MAX 255
-  \brief Remove floating-point range
-  Note: For internal use only.
-void G__remove_fp_range(const char *name)
-    G_remove_misc("cell_misc", "f_range", name);
- * \brief Construct default range
- * Sets the integer range to [1,255]
- * \param[out] r pointer to Range structure which holds range info
-void G_construct_default_range(struct Range *range)
-    G_update_range(DEFAULT_CELL_MIN, range);
-    G_update_range(DEFAULT_CELL_MAX, range);
- * \brief Read floating-point range
- * Read the floating point range file <i>drange</i>. This file is
- * written in binary using XDR format.
- * An empty range file indicates that the min, max are undefined. This
- * is a valid case, and the result should be an initialized range
- * struct with no defined min/max.  If the range file is missing and
- * the map is a floating-point map, this function will create a
- * default range by calling G_construct_default_range().
- * \param drange pointer to FPRange structure which holds fp range
- * \return 2 range is empty
-int G_read_fp_range(const char *name, const char *mapset,
-		    struct FPRange *drange)
-    int fd;
-    char xdr_buf[100];
-    DCELL dcell1, dcell2;
-    XDR xdr_str;
-    G_init_fp_range(drange);
-	/* if map is integer
-	   read integer range and convert it to double */
-	if (G_read_range(name, mapset, &range) >= 0) {
-	    /* if the integer range is empty */
-	    if (range.first_time)
-		return 2;
-	    G_update_fp_range((DCELL) range.min, drange);
-	    G_update_fp_range((DCELL) range.max, drange);
-	    return 1;
-	return -1;
-    fd = -1;
-    if (G_find_file2_misc("cell_misc", "f_range", name, mapset)) {
-	fd = G_open_old_misc("cell_misc", "f_range", name, mapset);
-	if (fd < 0) {
-	  G_warning(_("Unable to read fp range file for <%s@%s>"),
-		    name, mapset);
-	  return -1;
-	if (read(fd, xdr_buf, 2 * XDR_DOUBLE_NBYTES) != 2 * XDR_DOUBLE_NBYTES)
-	    return 2;
-	xdrmem_create(&xdr_str, xdr_buf, (u_int) XDR_DOUBLE_NBYTES * 2,
-		      XDR_DECODE);
-	/* if the f_range file exists, but empty */
-	if (!xdr_double(&xdr_str, &dcell1) || !xdr_double(&xdr_str, &dcell2)) {
-	  if (fd)
-	    close(fd);
-		    name, mapset);
-	  return -1;
-	G_update_fp_range(dcell1, drange);
-	G_update_fp_range(dcell2, drange);
-	close(fd);
-    return 1;
- * \brief Read raster range (CELL)
- * This routine reads the range information for the raster map
- * <i>name</i> in <i>mapset</i> into the <i>range</i> structure.
- * A diagnostic message is printed and -1 is returned if there is an error
- * reading the range file. Otherwise, 0 is returned.
- * Old range file (those with 4 numbers) should treat zeros in this
- * file as NULL-values. New range files (those with just 2 numbers)
- * should treat these numbers as real data (zeros are real data in
- * this case).  An empty range file indicates that the min, max are
- * undefined. This is a valid case, and the result should be an
- * initialized range struct with no defined min/max. If the range file
- * is missing and the map is a floating-point map, this function will
- * create a default range by calling G_construct_default_range().
- * \param range pointer to Range structure which holds range info
- * \return 2 if range is empty
- * \return 3 if raster map is floating-point, get range from quant rules
-int G_read_range(const char *name, const char *mapset, struct Range *range)
-    FILE *fd;
-    CELL x[4];
-    char buf[200];
-    int n, count;
-    struct FPRange drange;
-    G_init_range(range);
-    fd = NULL;
-    /* if map is not integer, read quant rules, and get limits */
-    if (G_raster_map_type(name, mapset) != CELL_TYPE) {
-	DCELL dmin, dmax;
-	if (G_read_quant(name, mapset, &quant) < 0) {
-	    G_warning(_("Unable to read quant rules for raster map <%s@%s>"),
-		       name, mapset);
-	    return -1;
-	if (G_quant_is_truncate(&quant) || G_quant_is_round(&quant)) {
-	    if (G_read_fp_range(name, mapset, &drange) >= 0) {
-		G_get_fp_range_min_max(&drange, &dmin, &dmax);
-		if (G_quant_is_truncate(&quant)) {
-		    x[0] = (CELL) dmin;
-		    x[1] = (CELL) dmax;
-		else {		/* round */
-		    if (dmin > 0)
-			x[0] = (CELL) (dmin + .5);
-		    else
-			x[0] = (CELL) (dmin - .5);
-		    if (dmax > 0)
-			x[1] = (CELL) (dmax + .5);
-		    else
-			x[1] = (CELL) (dmax - .5);
-	    else
-		return -1;
-	else
-	    G_quant_get_limits(&quant, &dmin, &dmax, &x[0], &x[1]);
-	G_update_range(x[0], range);
-	G_update_range(x[1], range);
-	return 3;
-    if (G_find_file2_misc("cell_misc", "range", name, mapset)) {
-	fd = G_fopen_old_misc("cell_misc", "range", name, mapset);
-	if (!fd) {
-	    G_warning(_("Unable to read range file for <%s@%s>"),
-		      name, mapset);
-	    return -1;
-	/* if range file exists but empty */
-	if (!fgets(buf, sizeof buf, fd))
-	    return 2;
-	x[0] = x[1] = x[2] = x[3] = 0;
-	count = sscanf(buf, "%d%d%d%d", &x[0], &x[1], &x[2], &x[3]);
-	/* if wrong format */
-	if (count <= 0) {
-	    if (fd)
-		fclose(fd);
-		      name, mapset);
-	    return -1;
-	for (n = 0; n < count; n++) {
-	    /* if count==4, the range file is old (4.1) and 0's in it
-	       have to be ignored */
-	    if (count < 4 || x[n])
-		G_update_range((CELL) x[n], range);
-	fclose(fd);
-    return 1;
- * \brief Write raster range file
- * This routine writes the range information for the raster map
- * <i>name</i> in the current mapset from the <i>range</i> structure.
- * error writing the range file. Otherwise, 0 is returned.
- * This routine only writes 2 numbers (min,max) to the range
- * file, instead of the 4 (pmin,pmax,nmin,nmax) previously written.
- * If there is no defined min,max, an empty file is written.
- * \return -1 on error (or raster map is floating-point)
- * \return 0 on success
-int G_write_range(const char *name, const struct Range *range)
-    FILE *fd;
-    if (G_raster_map_type(name, G_mapset()) != CELL_TYPE) {
-	G_remove_misc("cell_misc", "range", name);	/* remove the old file with this name */
-	G_warning(_("Unable to write range file for <%s>"),
-		  name);
-	return -1;
-    fd = G_fopen_new_misc("cell_misc", "range", name);
-    if (!fd) {
-		  name);
-	return -1;
-    /* if range hasn't been updated */
-    if (range->first_time) {
-	fclose(fd);
-	return 0;
-    fprintf(fd, "%ld %ld\n", (long)range->min, (long)range->max);
-    fclose(fd);
-    return 0;
- * \brief Write raster range file (floating-point)
- * Write the floating point range file <tt>f_range</tt>. This file is
- * written in binary using XDR format. If there is no defined min/max
- * in <em>range</em>, an empty <tt>f_range</tt> file is created.
- * \param range pointer to FPRange which holds fp range info
-int G_write_fp_range(const char *name, const struct FPRange *range)
-    int fd;
-    XDR xdr_str;
-    fd = G_open_new_misc("cell_misc", "f_range", name);
-    if (fd < 0) {
-		  name);
-	return -1;
-    /* if range hasn't been updated, write empty file meaning Nulls */
-	close(fd);
-	return 0;
-		  XDR_ENCODE);
-    if (!xdr_double(&xdr_str, (double *)&(range->min))) {
-		  name);
-	return -1;
-    if (!xdr_double(&xdr_str, (double *)&(range->max))) {
-		  name);
-	return -1;
-    write(fd, xdr_buf, XDR_DOUBLE_NBYTES * 2);
-    close(fd);
-    return 0;
- * \brief Update range structure (CELL)
- * Compares the <i>cat</i> value with the minimum and maximum values
- * in the <i>range</i> structure, modifying the range if <i>cat</i>
- * extends the range.
- * NULL-values must be detected and ignored.
- * \param cat raster value
-void G_update_range(CELL cat, struct Range *range)
-    if (!G_is_c_null_value(&cat)) {
-	    range->first_time = 0;
-	    range->min = cat;
-	    range->max = cat;
-	    return;
-	if (cat < range->min)
-	    range->min = cat;
-	if (cat > range->max)
-	    range->max = cat;
- * \brief Update range structure (floating-point)
- * \param val raster value
-void G_update_fp_range(DCELL val, struct FPRange *range)
-    if (!G_is_d_null_value(&val)) {
-	    range->min = val;
-	    range->max = val;
-	    return;
-	if (val < range->min)
-	    range->min = val;
-	if (val > range->max)
-	    range->max = val;
- * \brief Update range structure based on raster row (CELL)
- * This routine updates the <i>range</i> data just like
- * G_update_range(), but for <i>n</i> values from the <i>cell</i>
- * array.
- * \param cell raster values
- * \param n number of values
-void G_row_update_range(const CELL *cell, int n, struct Range *range)
-    G__row_update_range(cell, n, range, 0);
- * Note: for internal use only.
- * \param ignore_zeros ignore zeros
-void G__row_update_range(const CELL *cell, int n,
-			 struct Range *range, int ignore_zeros)
-    CELL cat;
-    while (n-- > 0) {
-	cat = *cell++;
-	if (G_is_c_null_value(&cat) || (ignore_zeros && !cat))
-	    continue;
-	    range->min = cat;
-	    range->max = cat;
-	    continue;
-	    range->min = cat;
-	    range->max = cat;
- * \brief Update range structure based on raster row (floating-point)
- * array.
- * \param data_type raster type (CELL, FCELL, DCELL)
-void G_row_update_fp_range(const void *rast, int n,
-			   struct FPRange *range, RASTER_MAP_TYPE data_type)
-    DCELL val = 0L;
-    while (n-- > 0) {
-	switch (data_type) {
-	case CELL_TYPE:
-	    val = (DCELL) * ((CELL *) rast);
-	    break;
-	case FCELL_TYPE:
-	    val = (DCELL) * ((FCELL *) rast);
-	    break;
-	case DCELL_TYPE:
-	    val = *((DCELL *) rast);
-	    break;
-	if (G_is_null_value(rast, data_type)) {
-	    rast = G_incr_void_ptr(rast, G_raster_size(data_type));
-	    continue;
-	    range->min = val;
-	    range->max = val;
-	else {
-		range->min = val;
-		range->max = val;
- * \brief Initialize range structure
- * Initializes the <i>range</i> structure for updates by
- * G_update_range() and G_row_update_range().
- * Must set a flag in the range structure that indicates that no
- * min/max have been defined - probably a <tt>"first"</tt> boolean
- * flag.
-void G_init_range(struct Range *range)
-    G_set_c_null_value(&(range->min), 1);
-    G_set_c_null_value(&(range->max), 1);
-    range->first_time = 1;
- * \brief Get range min and max
- * The mininum and maximum CELL values are extracted from the
- * <i>range</i> structure.
- * If the range structure has no defined min/max (first!=0) there will
- * not be a valid range. In this case the min and max returned must be
- * the NULL-value.
- * \param[out] min minimum value
- * \param[out] max maximum value
-void G_get_range_min_max(const struct Range *range, CELL * min, CELL * max)
-	G_set_c_null_value(min, 1);
-	G_set_c_null_value(max, 1);
-    else {
-	if (G_is_c_null_value(&(range->min)))
-	else
-	    *min = range->min;
-	if (G_is_c_null_value(&(range->max)))
-	else
-	    *max = range->max;
- * \brief Initialize fp range
- * flag.
-void G_init_fp_range(struct FPRange *range)
-    G_set_d_null_value(&(range->min), 1);
-    G_set_d_null_value(&(range->max), 1);
- * \brief Get minumum and maximum value from fp range
- * Extract the min/max from the range structure <i>range</i>.  If the
- * range structure has no defined min/max (first!=0) there will not be
- * a valid range. In this case the min and max returned must be the
- * NULL-value.
-void G_get_fp_range_min_max(const struct FPRange *range,
-			    DCELL *min, DCELL *max)
-	G_set_d_null_value(min, 1);
-	G_set_d_null_value(max, 1);
-    else {
-	if (G_is_d_null_value(&(range->min)))
-	else
-	if (G_is_d_null_value(&(range->max)))
-	else
Deleted: grass/trunk/lib/gis/raster.c
--- grass/trunk/lib/gis/raster.c	2009-06-20 21:39:23 UTC (rev 38002)
+++ grass/trunk/lib/gis/raster.c	2009-06-20 22:03:23 UTC (rev 38003)
@@ -1,320 +0,0 @@
- * \file gis/raster.c
- * \brief GIS Library - Raster cell value routines.
- * (C) 2001-2009 by the GRASS Development Team
- * \brief Advance void pointer
- * Advances void pointer by <i>size</i> bytes. Returns new pointer
- * value.
- * Useful in raster row processing loops, substitutes
- \code
- CELL *cell;
- cell += n;
- \endcode
- * Now
- \code
- \endcode
- * (where rast is void* and <i>data_type</i> is RASTER_MAP_TYPE can be
- * used instead of rast++.)
- * Very useful to generalize the row processing - loop i.e.
- * \code
- *   void * buf_ptr += G_raster_size(data_type)
- * \endcode
- * \param ptr pointer
- * \param size buffer size
- * \return pointer to the data
-void *G_incr_void_ptr(const void *ptr, const size_t size)
-    /* assuming that the size of unsigned char is 1 */
-    return (void *)((const unsigned char *)ptr + size);
- * \brief Compares raster values.
- * \param v1,v2 values to be compared
- * \return  1 if p > q or only q is null value
- * \return -1 if p < q or only p is null value
- * \return  0 if p == q or p==q==null value
-int G_raster_cmp(const void *v1, const void *v2, RASTER_MAP_TYPE data_type)
-    if (G_is_null_value(v1, data_type)) {
-	if (G_is_null_value(v2, data_type))
-	    return 0;
-	else
-	    return -1;
-    else if (G_is_null_value(v2, data_type))
-	return 1;
-    case CELL_TYPE:
-	if (*((const CELL *)v1) > *((const CELL *)v2))
-	    return 1;
-	else if (*((const CELL *)v1) == *((const CELL *)v2))
-	    return 0;
-	else
-	    return -1;
-    case FCELL_TYPE:
-	if (*((const FCELL *)v1) > *((const FCELL *)v2))
-	    return 1;
-	else if (*((const FCELL *)v1) == *((const FCELL *)v2))
-	    return 0;
-	else
-	    return -1;
-    case DCELL_TYPE:
-	if (*((const DCELL *)v1) > *((const DCELL *)v2))
-	    return 1;
-	else if (*((const DCELL *)v1) == *((const DCELL *)v2))
-	    return 0;
-	else
-	    return -1;
-    return 0;
- * \brief Copies raster values.
- * If v2 is null value, sets v2 to null value.
- * \param v1, v2 raster values
- * \param n ?
-void G_raster_cpy(void *v1, const void *v2, int n, RASTER_MAP_TYPE data_type)
-    G_copy(v1, v2, n * G_raster_size(data_type));
- * \brief Places a CELL raster value
- * If G_is_c_null_value() is true, sets p to null value. Converts CELL
- * val to data_type (type of p) and stores result in p. Used for
- * assigning CELL values to raster cells of any type.
- * \param rast pointer to raster cell value
- * \param cval value to set
-void G_set_raster_value_c(void *rast, CELL cval, RASTER_MAP_TYPE data_type)
-    CELL c;
-    c = cval;
-    if (G_is_c_null_value(&c)) {
-	G_set_null_value(rast, 1, data_type);
-	return;
-    case CELL_TYPE:
-	*((CELL *) rast) = cval;
-	break;
-    case FCELL_TYPE:
-	*((FCELL *) rast) = (FCELL) cval;
-	break;
-    case DCELL_TYPE:
-	*((DCELL *) rast) = (DCELL) cval;
-	break;
- * \brief Places a FCELL raster value
- * If G_is_f_null_value() is true, sets p to null value. Converts
- * FCELL val to data_type (type of p) and stores result in p. Used for
- * assigning FCELL values to raster cells of any type.
- * \param fval value to set
-void G_set_raster_value_f(void *rast, FCELL fval, RASTER_MAP_TYPE data_type)
-    FCELL f;
-    f = fval;
-    if (G_is_f_null_value(&f)) {
-	return;
-    case CELL_TYPE:
-	*((CELL *) rast) = (CELL) fval;
-	break;
-    case FCELL_TYPE:
-	*((FCELL *) rast) = fval;
-	break;
-    case DCELL_TYPE:
-	*((DCELL *) rast) = (DCELL) fval;
-	break;
- * \brief  Places a DCELL raster value
- * If G_is_d_null_value() is true, sets p to null value. Converts
- * DCELL val to data_type (type of p) and stores result in p. Used for
- * assigning DCELL values to raster cells of any type.
-void G_set_raster_value_d(void *rast, DCELL dval, RASTER_MAP_TYPE data_type)
-    DCELL d;
-    d = dval;
-    if (G_is_d_null_value(&d)) {
-	return;
-    case CELL_TYPE:
-	*((CELL *) rast) = (CELL) dval;
-	break;
-    case FCELL_TYPE:
-	*((FCELL *) rast) = (FCELL) dval;
-	break;
-    case DCELL_TYPE:
-	*((DCELL *) rast) = dval;
-	break;
- * \brief Retrieves the value of give type from pointer p
- * Retrieves the value of type data_type from pointer p, converts it
- * to CELL type and returns the result. If null value is stored in p,
- * returns CELL null value.
- * Used for retrieving CELL values from raster cells of any type.
- * Note: when data_type != CELL_TYPE, no quantization is used, only
- * type conversion.
- * \return raster value
-CELL G_get_raster_value_c(const void *rast, RASTER_MAP_TYPE data_type)
-    CELL c;
-	G_set_c_null_value(&c, 1);
-	return c;
-    case CELL_TYPE:
-	return *((const CELL *)rast);
-    case FCELL_TYPE:
-	return (CELL) *((const FCELL *)rast);
-    case DCELL_TYPE:
-	return (CELL) *((const DCELL *)rast);
-    return 0;
- * \brief Retrieves the value of given raster type from pointer p (FCELL)
- * to FCELL type and returns the result. If null value is stored in p,
- * returns FCELL null value.
- * Used for retrieving FCELL values from raster cells of any type.
-FCELL G_get_raster_value_f(const void *rast, RASTER_MAP_TYPE data_type)
-    FCELL f;
-	G_set_f_null_value(&f, 1);
-	return f;
-    case CELL_TYPE:
-	return (FCELL) * ((const CELL *)rast);
-    case FCELL_TYPE:
-	return *((const FCELL *)rast);
-    case DCELL_TYPE:
-	return (FCELL) * ((const DCELL *)rast);
-    return 0;
- * \brief Retrieves the value of given type from pointer p (DCELL)
- * to DCELL type and returns the result. If null value is stored in p,
- * returns DCELL null value.
- * Used for retrieving DCELL values from raster cells of any type.
-DCELL G_get_raster_value_d(const void *rast, RASTER_MAP_TYPE data_type)
-    DCELL d;
-	G_set_d_null_value(&d, 1);
-	return d;
-    case CELL_TYPE:
-	return (DCELL) * ((const CELL *)rast);
-    case FCELL_TYPE:
-	return (DCELL) * ((const FCELL *)rast);
-    case DCELL_TYPE:
-	return *((const DCELL *)rast);
-    return 0;
Deleted: grass/trunk/lib/gis/raster_metadata.c
--- grass/trunk/lib/gis/raster_metadata.c	2009-06-20 21:39:23 UTC (rev 38002)
+++ grass/trunk/lib/gis/raster_metadata.c	2009-06-20 22:03:23 UTC (rev 38003)
@@ -1,152 +0,0 @@
-/* raster_metadata.c
- * PURPOSE: functions to read and write raster "units" and "vertical datum"
- *              meta-data info
- *   Copyright (C) 2007 by Hamish Bowman, and the GRASS Development Team
- *   Author(s): Hamish Bowman, Dunedin, New Zealand
- *   for details.
-#include <stdio.h>
- * \brief Get a raster map's units metadata string
- * Read the raster's units metadata file and put string in str
- * \param name
- * \param mapset
- * \param *str  string to be populated with data
- * \return -1, EOF (fclose() result) on error
-int G_read_raster_units(const char *name, const char *mapset, char *str)
-    return G__raster_misc_read_line("units", name, mapset, str);
- * \brief Write a string to a raster map's units metadata file
- * Map must exist in the current mapset.
- * \param name
- * \param *str  string containing data to be written
-int G_write_raster_units(const char *name, const char *str)
-    return G__raster_misc_write_line("units", name, str);
- * \brief Get a raster map's vertical datum metadata string
- * Read the raster's vertical datum metadata file and put string in str
- * \param name
- * \param mapset
-int G_read_raster_vdatum(const char *name, const char *mapset, char *str)
-    return G__raster_misc_read_line("vertical_datum", name, mapset, str);
- * \brief Write a string into a raster's vertical datum metadata file
- * \param name
-int G_write_raster_vdatum(const char *name, const char *str)
-    return G__raster_misc_write_line("vertical_datum", name, str);
- * \brief Read the first line of a file in cell_misc/
- * Read the first line of data from a cell_misc/ meta-data file.
- * \param element  metadata component filename
- * \param name
- * \param mapset
-int G__raster_misc_read_line(const char *elem, const char *name,
-			     const char *mapset, char *str)
-    FILE *fd;
-    char buff[GNAME_MAX];
-    buff[0] = '\0';
-    if (G_find_file2_misc("cell_misc", elem, name, mapset) == NULL)
-	return -1;
-    fd = G_fopen_old_misc("cell_misc", elem, name, mapset);
-    if (!fd) {
-	G_warning(_("Can't read %s for [%s in %s]"), elem, name, mapset);
-	return -1;
-    if (G_getl2(buff, sizeof(buff) - 1, fd) == 0) {
-	/* file is empty */
-	return fclose(fd);
-    strcpy(str, buff);
- * \brief Write a line to a raster map metadata file
- * Write (including overwrite) a string into a raster map's metadata file
- * found in in cell_misc/ in the current mapset.
- * \param name
-int G__raster_misc_write_line(const char *elem, const char *name,
-			      const char *str)
-    FILE *fd;
-    fd = G_fopen_new_misc("cell_misc", elem, name);
-    if (fd == NULL) {
-	G_warning(_("Can't create %s metadata file for [%s in %s]"),
-		  elem, name, G_mapset());
-	return -1;
-    fprintf(fd, "%s", str);
Deleted: grass/trunk/lib/gis/rd_cellhd.c
--- grass/trunk/lib/gis/rd_cellhd.c	2009-06-20 21:39:23 UTC (rev 38002)
+++ grass/trunk/lib/gis/rd_cellhd.c	2009-06-20 22:03:23 UTC (rev 38003)
@@ -1,433 +0,0 @@
-/* read cell header, or window.
-   returns NULL if ok, error message otherwise
-   note:  the error message can be freed using G_free ().
-#define ERROR(x,line) return error(x,line)
-static int scan_item(const char *, char *, char *);
-static int scan_int(const char *, int *);
-static double scan_double(const char *, double *);
-static char *error(const char *, int);
-#define F_PROJ   1
-#define F_ZONE   2
-#define F_NORTH  3
-#define F_SOUTH  4
-#define F_EAST   5
-#define F_WEST   6
-#define F_EWRES  7
-#define F_NSRES  8
-#define F_FORMAT 9
-#define F_COMP   10
-#define F_COLS   11
-#define F_ROWS   12
-#define F_EWRES3 13
-#define F_NSRES3 14
-#define F_COLS3  15
-#define F_ROWS3  16
-#define F_TOP    17
-#define F_BOTTOM 18
-#define F_TBRES  19
-#define F_DEPTHS 20
-#define SET(x) flags|=(1<<x)
-#define TEST(x) (flags&(1<<x))
-char *G__read_Cell_head_array(char **array,
-			      struct Cell_head *cellhd, int is_cellhd);
-char *G__read_Cell_head(FILE * fd, struct Cell_head *cellhd, int is_cellhd)
-    int count;
-    char *result, **array;
-    char buf[1024];
-    G_debug(2, "G__read_Cell_head");
-    /* Count lines */
-    count = 0;
-    fseek(fd, 0L, 0);
-    while (G_getl(buf, sizeof(buf), fd))
-	count++;
-    array = (char **)G_calloc(count + 1, sizeof(char **));
-    count = 0;
-    fseek(fd, 0L, 0);
-    while (G_getl(buf, sizeof(buf), fd)) {
-	array[count] = G_store(buf);
-	count++;
-    result = G__read_Cell_head_array(array, cellhd, is_cellhd);
-    count = 0;
-    while (array[count]) {
-	G_free(array[count]);
-	count++;
-    G_free(array);
-    return result;
-/* Read window from NULL terminated array of strings */
-    char *buf;
-    char label[200];
-    char value[200];
-    int i, line;
-    int flags;
-    const char *err;
-    G_debug(2, "G__read_Cell_head_array");
-    flags = 0;
-    /* initialize the cell header */
-    cellhd->format = 0;
-    cellhd->rows = 0;
-    cellhd->rows3 = 0;
-    cellhd->cols = 0;
-    cellhd->cols3 = 0;
-    cellhd->depths = 1;
-    cellhd->proj = -1;
-    cellhd->zone = -1;
-    cellhd->compressed = -1;
-    cellhd->ew_res = 0.0;
-    cellhd->ew_res3 = 1.0;
-    cellhd->ns_res = 0.0;
-    cellhd->ns_res3 = 1.0;
-    cellhd->tb_res = 1.0;
-    cellhd->north = 0.0;
-    cellhd->south = 0.0;
-    cellhd->east = 0.0;
-    cellhd->west = 0.0;
-    cellhd->top = 1.0;
-    cellhd->bottom = 0.0;
-    /* determine projection, zone first */
-    i = 0;
-    for (line = 1; (buf = array[i++]); line++) {
-	if (TEST(F_PROJ) && TEST(F_ZONE))
-	    break;
-	switch (scan_item(buf, label, value)) {
-	case -1:
-	    ERROR(buf, line);
-	case 0:
-	    continue;
-	case 1:
-	    break;
-	if (strncmp(label, "proj", 4) == 0) {
-	    if (TEST(F_PROJ))
-		ERROR(_("duplicate projection field"), line);
-	    if (!scan_int(value, &cellhd->proj))
-		ERROR(buf, line);
-	    SET(F_PROJ);
-	    continue;
-	if (strncmp(label, "zone", 4) == 0) {
-	    if (TEST(F_ZONE))
-		ERROR(_("duplicate zone field"), line);
-	    if (!scan_int(value, &cellhd->zone))
-		ERROR(buf, line);
-	    SET(F_ZONE);
-	    continue;
-    if (!TEST(F_PROJ))
-	ERROR(_("projection field missing"), 0);
-    if (!TEST(F_ZONE))
-	ERROR(_("zone field missing"), 0);
-    /* read the other info */
-    i = 0;
-	G_debug(3, "region item: %s", buf);
-	case -1:
-	    ERROR(buf, line);
-	case 0:
-	    continue;
-	case 1:
-	    break;
-	    continue;
-	    continue;
-	if (strncmp(label, "nort", 4) == 0) {
-	    if (TEST(F_NORTH))
-		ERROR(_("duplicate north field"), line);
-	    if (!G_scan_northing(value, &cellhd->north, cellhd->proj))
-		ERROR(buf, line);
-	    SET(F_NORTH);
-	    continue;
-	if (strncmp(label, "sout", 4) == 0) {
-	    if (TEST(F_SOUTH))
-		ERROR(_("duplicate south field"), line);
-	    if (!G_scan_northing(value, &cellhd->south, cellhd->proj))
-		ERROR(buf, line);
-	    SET(F_SOUTH);
-	    continue;
-	if (strncmp(label, "east", 4) == 0) {
-	    if (TEST(F_EAST))
-		ERROR(_("duplicate east field"), line);
-	    if (!G_scan_easting(value, &cellhd->east, cellhd->proj))
-		ERROR(buf, line);
-	    SET(F_EAST);
-	    continue;
-	if (strncmp(label, "west", 4) == 0) {
-	    if (TEST(F_WEST))
-		ERROR(_("duplicate west field"), line);
-	    if (!G_scan_easting(value, &cellhd->west, cellhd->proj))
-		ERROR(buf, line);
-	    SET(F_WEST);
-	    continue;
-	if (strncmp(label, "top", 3) == 0) {
-	    if (TEST(F_TOP))
-		ERROR(_("duplicate top field"), line);
-	    if (!scan_double(value, &cellhd->top))
-		ERROR(buf, line);
-	    SET(F_TOP);
-	    continue;
-	if (strncmp(label, "bottom", 6) == 0) {
-	    if (TEST(F_BOTTOM))
-		ERROR(_("duplicate bottom field"), line);
-	    if (!scan_double(value, &cellhd->bottom))
-		ERROR(buf, line);
-	    SET(F_BOTTOM);
-	    continue;
-	if (strncmp(label, "e-w ", 4) == 0 && strlen(label) == 9) {
-	    if (TEST(F_EWRES))
-		ERROR(_("duplicate e-w resolution field"), line);
-	    if (!G_scan_resolution(value, &cellhd->ew_res, cellhd->proj))
-		ERROR(buf, line);
-	    if (cellhd->ew_res <= 0.0)
-		ERROR(buf, line);
-	    SET(F_EWRES);
-	    continue;
-	if (strncmp(label, "e-w resol3", 10) == 0) {
-	    if (TEST(F_EWRES3))
-		ERROR(_("duplicate 3D e-w resolution field"), line);
-	    if (!G_scan_resolution(value, &cellhd->ew_res3, cellhd->proj))
-		ERROR(buf, line);
-	    if (cellhd->ew_res3 <= 0.0)
-		ERROR(buf, line);
-	    SET(F_EWRES3);
-	    continue;
-	if (strncmp(label, "n-s ", 4) == 0 && strlen(label) == 9) {
-	    if (TEST(F_NSRES))
-		ERROR(_("duplicate n-s resolution field"), line);
-	    if (!G_scan_resolution(value, &cellhd->ns_res, cellhd->proj))
-		ERROR(buf, line);
-	    if (cellhd->ns_res <= 0.0)
-		ERROR(buf, line);
-	    SET(F_NSRES);
-	    continue;
-	if (strncmp(label, "n-s resol3", 10) == 0) {
-	    if (TEST(F_NSRES3))
-		ERROR(_("duplicate 3D n-s resolution field"), line);
-	    if (!G_scan_resolution(value, &cellhd->ns_res3, cellhd->proj))
-		ERROR(buf, line);
-	    if (cellhd->ns_res3 <= 0.0)
-		ERROR(buf, line);
-	    SET(F_NSRES3);
-	    continue;
-	if (strncmp(label, "t-b ", 4) == 0) {
-	    if (TEST(F_TBRES))
-		ERROR(_("duplicate t-b resolution field"), line);
-	    if (!scan_double(value, &cellhd->tb_res))
-		ERROR(buf, line);
-	    if (cellhd->tb_res <= 0.0)
-		ERROR(buf, line);
-	    SET(F_TBRES);
-	    continue;
-	if (strncmp(label, "rows", 4) == 0 && strlen(label) == 4) {
-	    if (TEST(F_ROWS))
-		ERROR(_("duplicate rows field"), line);
-	    if (!scan_int(value, &cellhd->rows))
-		ERROR(buf, line);
-	    if (cellhd->rows <= 0)
-		ERROR(buf, line);
-	    SET(F_ROWS);
-	    continue;
-	if (strncmp(label, "rows3", 5) == 0) {
-	    if (TEST(F_ROWS3))
-		ERROR(_("duplicate 3D rows field"), line);
-	    if (!scan_int(value, &cellhd->rows3))
-		ERROR(buf, line);
-	    if (cellhd->rows3 <= 0)
-		ERROR(buf, line);
-	    SET(F_ROWS3);
-	    continue;
-	if (strncmp(label, "cols", 4) == 0 && strlen(label) == 4) {
-	    if (TEST(F_COLS))
-		ERROR(_("duplicate cols field"), line);
-	    if (!scan_int(value, &cellhd->cols))
-		ERROR(buf, line);
-	    if (cellhd->cols <= 0)
-		ERROR(buf, line);
-	    SET(F_COLS);
-	    continue;
-	if (strncmp(label, "cols3", 5) == 0) {
-	    if (TEST(F_COLS3))
-		ERROR(_("duplicate 3D cols field"), line);
-	    if (!scan_int(value, &cellhd->cols3))
-		ERROR(buf, line);
-	    if (cellhd->cols3 <= 0)
-		ERROR(buf, line);
-	    SET(F_COLS3);
-	    continue;
-	if (strncmp(label, "depths", 6) == 0) {
-	    if (TEST(F_DEPTHS))
-		ERROR(_("duplicate depths field"), line);
-	    if (!scan_int(value, &cellhd->depths))
-		ERROR(buf, line);
-	    if (cellhd->depths <= 0)
-		ERROR(buf, line);
-	    SET(F_DEPTHS);
-	    continue;
-	if (strncmp(label, "form", 4) == 0) {
-	    if (TEST(F_FORMAT))
-		ERROR(_("duplicate format field"), line);
-	    if (!scan_int(value, &cellhd->format))
-		ERROR(buf, line);
-	    SET(F_FORMAT);
-	    continue;
-	if (strncmp(label, "comp", 4) == 0) {
-	    if (TEST(F_COMP))
-		ERROR(_("duplicate compressed field"), line);
-	    if (!scan_int(value, &cellhd->compressed))
-		ERROR(buf, line);
-	    SET(F_COMP);
-	    continue;
-	ERROR(buf, line);
-    /* check some of the fields */
-    if (!TEST(F_NORTH))
-	ERROR(_("north field missing"), 0);
-    if (!TEST(F_SOUTH))
-	ERROR(_("south field missing"), 0);
-    if (!TEST(F_WEST))
-	ERROR(_("west field missing"), 0);
-    if (!TEST(F_EAST))
-	ERROR(_("east field missing"), 0);
-    if (!TEST(F_EWRES) && !TEST(F_COLS))
-	ERROR(_("cols field missing"), 0);
-    if (!TEST(F_NSRES) && !TEST(F_ROWS))
-	ERROR(_("rows field missing"), 0);
-    /* This next stmt is commented out to allow wr_cellhd.c to write
-     * headers that will be readable by GRASS 3.1
-     if ((TEST(F_ROWS) && TEST(F_NSRES))
-     ||  (TEST(F_COLS) && TEST(F_EWRES)))
-     ERROR ("row/col and resolution information can not both appear ",0);
-    /* 3D defined? */
-    if (TEST(F_EWRES3) || TEST(F_NSRES3) || TEST(F_COLS3) || TEST(F_ROWS3)) {
-	if (!TEST(F_EWRES3))
-	    ERROR(_("ewres3 field missing"), 0);
-	if (!TEST(F_NSRES3))
-	    ERROR(_("nsres3 field missing"), 0);
-	if (!TEST(F_COLS3))
-	    ERROR(_("cols3 field missing"), 0);
-	if (!TEST(F_ROWS3))
-	    ERROR(_("rows3 field missing"), 0);
-    else {			/* use 2D */
-	cellhd->ew_res3 = cellhd->ew_res;
-	cellhd->ns_res3 = cellhd->ns_res;
-	cellhd->cols3 = cellhd->cols;
-	cellhd->rows3 = cellhd->rows;
-    /* Adjust and complete the cell header  */
-    if ((err = G_adjust_Cell_head(cellhd, TEST(F_ROWS), TEST(F_COLS))))
-	ERROR(err, 0);
-    return NULL;
-static int scan_item(const char *buf, char *label, char *value)
-    /* skip blank lines */
-    if (sscanf(buf, "%1s", label) != 1)
-	return 0;
-    /* skip comment lines */
-    if (*label == '#')
-	return 0;
-    /* must be label: value */
-    if (sscanf(buf, "%[^:]:%[^\n]", label, value) != 2)
-	return -1;
-    G_strip(label);
-    G_strip(value);
-    return 1;
-static int scan_int(const char *buf, int *n)
-    char dummy[3];
-    *dummy = 0;
-    return (sscanf(buf, "%d%1s", n, dummy) == 1 && *dummy == 0);
-static double scan_double(const char *buf, double *n)
-    char dummy[3];
-    *dummy = 0;
-    return (sscanf(buf, "%lf%1s", n, dummy) == 1 && *dummy == 0);
-static char *error(const char *msg, int line)
-    char buf[1024];
-    if (line)
-	sprintf(buf, _("line %d: <%s>"), line, msg);
-    else
-	sprintf(buf, "<%s>", msg);
-    return G_store(buf);
Deleted: grass/trunk/lib/gis/reclass.c
--- grass/trunk/lib/gis/reclass.c	2009-06-20 21:39:23 UTC (rev 38002)
+++ grass/trunk/lib/gis/reclass.c	2009-06-20 22:03:23 UTC (rev 38003)
@@ -1,403 +0,0 @@
- * \file gis/reclass.c
- * \brief GIS Library - Check if raster map is reclassified
-#include <grass/gis.h>
-static const char NULL_STRING[] = "null";
-static int reclass_type(FILE *, char **, char **);
-static FILE *fopen_cellhd_old(const char *, const char *);
-static FILE *fopen_cellhd_new(const char *);
-static int get_reclass_table(FILE *, struct Reclass *);
- * \brief Check if raster map is reclassified
- * This function determines if the raster map <i>name</i> in
- * <i>mapset</i> is a reclass file. If it is, then the name and mapset
- * of the referenced raster map are copied into the <i>r_name</i> and
- * <i>r_mapset</i> buffers.
- * \param[out] r_name name of reference map
- * \param[out] r_mapset mapset where reference map lives
- * \returns 1 if it is a reclass file
- * \return 0 if it is not
- * \return -1 if there was a problem reading the raster header
-int G_is_reclass(const char *name, const char *mapset, char *rname,
-		 char *rmapset)
-    FILE *fd;
-    int type;
-    fd = fopen_cellhd_old(name, mapset);
-    if (fd == NULL)
-	return -1;
-    type = reclass_type(fd, &rname, &rmapset);
-    fclose(fd);
-    if (type < 0)
-	return -1;
-    else
-	return type != 0;
- * \brief Get child reclass maps list
- * This function generates a child reclass maps list from the
- * cell_misc/reclassed_to file which stores this list. The
- * cell_misc/reclassed_to file is written by G_put_reclass().
- * G_is_reclassed_to() is used by <tt>g.rename</tt>, <tt>g.remove</tt>
- * and <tt>r.reclass</tt> to prevent accidentally deleting the parent
- * map of a reclassed raster map.
- * \param[out] nrmaps number of reference maps
- * \param[out] rmaps array of names of reference maps
- * \return number of reference maps
-int G_is_reclassed_to(const char *name, const char *mapset, int *nrmaps,
-		      char ***rmaps)
-    FILE *fd;
-    int i, j, k, l;
-    char buf2[256], buf3[256];
-    fd = G_fopen_old_misc("cell_misc", "reclassed_to", name, mapset);
-    if (fd == NULL) {
-	return -1;
-    if (rmaps)
-	*rmaps = NULL;
-    for (i = 0; !feof(fd) && fgets(buf2, 255, fd);) {
-	l = strlen(buf2);
-	for (j = 0, k = 0; j < l; j++) {
-	    if (buf2[j] == '#' ||
-		((buf2[j] == ' ' || buf2[j] == '\t' || buf2[j] == '\n') && k))
-		break;
-	    else if (buf2[j] != ' ' && buf2[j] != '\t')
-		buf3[k++] = buf2[j];
-	if (k) {
-	    buf3[k] = 0;
-	    i++;
-	    if (rmaps) {
-		*rmaps = (char **)G_realloc(*rmaps, i * sizeof(char *));
-		(*rmaps)[i - 1] = (char *)G_malloc(k + 1);
-		strncpy((*rmaps)[i - 1], buf3, k);
-		(*rmaps)[i - 1][k] = 0;
-    if (nrmaps)
-	*nrmaps = i;
-    if (i && rmaps) {
-	i++;
-	(*rmaps)[i - 1] = NULL;
-    return i;
-  \brief Get reclass
-  \param[out] reclass pointer to Reclass structure
-  \return -1 on error
-  \return type code
-int G_get_reclass(const char *name, const char *mapset,
-		  struct Reclass *reclass)
-    FILE *fd;
-    int stat;
-    if (fd == NULL)
-	return -1;
-    reclass->name = NULL;
-    reclass->mapset = NULL;
-    reclass->type = reclass_type(fd, &reclass->name, &reclass->mapset);
-    if (reclass->type <= 0) {
-	fclose(fd);
-	return reclass->type;
-    switch (reclass->type) {
-    case RECLASS_TABLE:
-	stat = get_reclass_table(fd, reclass);
-	break;
-    default:
-	stat = -1;
-    fclose(fd);
-    if (stat < 0) {
-	if (stat == -2)
-	    G_warning(_("Too many reclass categories for <%s@%s>"),
-		      name, mapset);
-	else
-	    G_warning(_("Illegal reclass format in header file for <%s@%s>"),
-		      name, mapset);
-	stat = -1;
-    return stat;
-  \brief Free Reclass structure
-  \param reclass pointer to Reclass structure
-void G_free_reclass(struct Reclass *reclass)
-	if (reclass->num > 0)
-	    G_free(reclass->table);
-	reclass->num = 0;
-	if (reclass->name)
-	    G_free(reclass->name);
-	if (reclass->mapset)
-	    G_free(reclass->mapset);
-	break;
-    default:
-	break;
-static int reclass_type(FILE * fd, char **rname, char **rmapset)
-    char buf[128];
-    char label[128], arg[128];
-    int i;
-    int type;
-    /* Check to see if this is a reclass file */
-    if (fgets(buf, sizeof(buf), fd) == NULL)
-	return 0;
-    if (strncmp(buf, "reclas", 6))
-	return 0;
-    /* later may add other types of reclass */
-    type = RECLASS_TABLE;
-    /* Read the mapset and file name of the REAL cell file */
-    if (*rname)
-	**rname = '\0';
-    if (*rmapset)
-	**rmapset = '\0';
-    for (i = 0; i < 2; i++) {
-	if (fgets(buf, sizeof buf, fd) == NULL)
-	    return -1;
-	if (sscanf(buf, "%[^:]:%s", label, arg) != 2)
-	    return -1;
-	if (strncmp(label, "maps", 4) == 0) {
-	    if (*rmapset)
-		strcpy(*rmapset, arg);
-	    else
-		*rmapset = G_store(arg);
-	else if (strncmp(label, "name", 4) == 0) {
-	    if (*rname)
-		strcpy(*rname, arg);
-	    else
-		*rname = G_store(arg);
-	else
-	    return -1;
-    if (**rmapset && **rname)
-	return type;
-    else
-	return -1;
-static FILE *fopen_cellhd_old(const char *name, const char *mapset)
-    return G_fopen_old("cellhd", name, mapset);
-  \brief Put reclass
-  \return 1 on success
-int G_put_reclass(const char *name, const struct Reclass *reclass)
-    FILE *fd;
-    long min, max;
-    int i;
-    char buf1[GPATH_MAX], buf2[GNAME_MAX], buf3[GNAME_MAX], *p;
-	if (reclass->min > reclass->max || reclass->num <= 0) {
-	    G_fatal_error(_("Illegal reclass request"));
-	    return -1;
-	break;
-    default:
-	G_fatal_error(_("Illegal reclass type"));
-	return -1;
-    fd = fopen_cellhd_new(name);
-    if (fd == NULL) {
-	G_warning(_("Unable to create header file for <%s@%s>"),
-		  name, G_mapset());
-	return -1;
-    fprintf(fd, "reclass\n");
-    fprintf(fd, "name: %s\n", reclass->name);
-    fprintf(fd, "mapset: %s\n", reclass->mapset);
-    /* find first non-null entry */
-    for (min = 0; min < reclass->num; min++)
-	if (!G_is_c_null_value(&reclass->table[min]))
-	    break;
-    /* find last non-zero entry */
-    for (max = reclass->num - 1; max >= 0; max--)
-	if (!G_is_c_null_value(&reclass->table[max]))
-	    break;
-     * if the resultant table is empty, write out a dummy table
-     * else write out the table
-     *   first entry is #min
-     *   rest are translations for cat min+i
-    if (min > max)
-	fprintf(fd, "0\n");
-    else {
-	fprintf(fd, "#%ld\n", (long)reclass->min + min);
-	while (min <= max) {
-	    if (G_is_c_null_value(&reclass->table[min]))
-		fprintf(fd, "%s\n", NULL_STRING);
-	    else
-		fprintf(fd, "%ld\n", (long)reclass->table[min]);
-	    min++;
-    fclose(fd);
-    strcpy(buf2, reclass->name);
-    if ((p = strchr(buf2, '@')))
-	*p = 0;
-    G__file_name_misc(buf1, "cell_misc", "reclassed_to", reclass->name,
-		      reclass->mapset);
-    fd = fopen(buf1, "a+");
-    if (fd == NULL) {
-#if 0
-	G_warning(_("Unable to create dependency file in <%s@%s>"),
-		  buf2, reclass->mapset);
-#endif
-	return 1;
-    fseek(fd, 0L, SEEK_SET);
-    sprintf(buf2, "%s@%s\n", name, G_mapset());
-    for (i = 0; !feof(fd) && fgets(buf3, 255, fd);) {
-	if (!(strcmp(buf2, buf3))) {
-	    i = 1;
-	    break;
-    if (!i) {
-	fprintf(fd, "%s@%s\n", name, G_mapset());
-    fclose(fd);
-    return 1;
-static FILE *fopen_cellhd_new(const char *name)
-    return G_fopen_new("cellhd", name);
-static int get_reclass_table(FILE * fd, struct Reclass *reclass)
-    char buf[128];
-    int n;
-    int first, null_str_size;
-    CELL cat;
-    long len;
-     * allocate the table, expanding as each entry is read
-     * note that G_realloc() will become G_malloc() if ptr in
-     * NULL
-    reclass->min = 0;
-    reclass->table = NULL;
-    null_str_size = strlen(NULL_STRING);
-    n = 0;
-    first = 1;
-    while (fgets(buf, sizeof buf, fd)) {
-	if (first) {
-	    first = 0;
-	    if (sscanf(buf, "#%d", &cat) == 1) {
-		reclass->min = cat;
-		continue;
-	if (strncmp(buf, NULL_STRING, null_str_size) == 0)
-	    G_set_c_null_value(&cat, 1);
-	else {
-	    if (sscanf(buf, "%d", &cat) != 1)
-		return -1;
-	n++;
-	len = (long)n *sizeof(CELL);
-	if (len != (int)len) {	/* check for int overflow */
-	    if (reclass->table != NULL)
-	    return -2;
-	reclass->table = (CELL *) G_realloc((char *)reclass->table, (int)len);
-	reclass->table[n - 1] = cat;
-    reclass->max = reclass->min + n - 1;
-    reclass->num = n;
-    return 1;
Deleted: grass/trunk/lib/gis/sample.c
--- grass/trunk/lib/gis/sample.c	2009-06-20 21:39:23 UTC (rev 38002)
+++ grass/trunk/lib/gis/sample.c	2009-06-20 22:03:23 UTC (rev 38003)
@@ -1,338 +0,0 @@
-   \file gis/sample.c
-   \brief GIS library - Sampling methods (extract a cell value from
-   raster map)
-   1/2006: moved to libgis from v.sample/v.drape for clone removal
-   (C) 2001-2009 by the GRASS Development Team
-   This program is free software under the GNU General Public License
-   (>=v2).  Read the file COPYING that comes with GRASS for details.
-   \author James Darrell McCauley <darrell mccauley-usa.com>, http://mccauley-usa.com/
-#include <math.h>
-/* prototypes */
-static double scancatlabel(const char *);
-static void raster_row_error(const struct Cell_head *window, double north,
-			     double east);
- *  \brief Extract a cell value from raster map.
- *  Extract a cell value from raster map at given northing and easting
- *  with a sampled 3x3 window using a specified interpolation method.
- *  - NEAREST  neighbor interpolation
- *  - BILINEAR bilinear interpolation
- *  - CUBIC    cubic interpolation
- *  \param fd file descriptor
- *  \param window region settings
- *  \param cats categories
- *  \param north northing position
- *  \param east easting position
- *  \param usedesc flag to scan category label
- *  \param itype interpolation method
- *  \return cell value at given position
-DCELL G_get_raster_sample(int fd,
-			  const struct Cell_head *window,
-			  struct Categories *cats,
-			  double north, double east,
-			  int usedesc, INTERP_TYPE itype)
-    double retval;
-    switch (itype) {
-    case NEAREST:
-	retval = G_get_raster_sample_nearest(fd, window, cats, north, east, usedesc);
-	break;
-    case BILINEAR:
-	retval = G_get_raster_sample_bilinear(fd, window, cats, north, east, usedesc);
-	break;
-    case CUBIC:
-	retval = G_get_raster_sample_cubic(fd, window, cats, north, east, usedesc);
-	break;
-    default:
-	G_fatal_error("G_get_raster_sample: %s",
-		      _("Unknown interpolation type"));
-    return retval;
- *  \brief Extract a cell value from raster map (neighbor interpolation)
- *  with a sampled 3x3 window using a neighbor interpolation.
-DCELL G_get_raster_sample_nearest(int fd,
-				  double north, double east, int usedesc)
-    int row, col;
-    DCELL result;
-    DCELL *maprow = G_allocate_d_raster_buf();
-    /* convert northing and easting to row and col, resp */
-    row = (int)floor(G_northing_to_row(north, window));
-    col = (int)floor(G_easting_to_col(east, window));
-    if (row < 0 || row >= G_window_rows() ||
-	col < 0 || col >= G_window_cols()) {
-	G_set_d_null_value(&result, 1);
-	goto done;
-    if (G_get_d_raster_row(fd, maprow, row) < 0)
-	raster_row_error(window, north, east);
-    if (G_is_d_null_value(&maprow[col])) {
-	goto done;
-    if (usedesc) {
-	char *buf = G_get_cat(maprow[col], cats);
-	G_squeeze(buf);
-	result = scancatlabel(buf);
-    else
-	result = maprow[col];
-done:
-    G_free(maprow);
-    return result;
- *  \brief Extract a cell value from raster map (bilinear interpolation).
- *  with a sampled 3x3 window using a bilinear interpolation.
-DCELL G_get_raster_sample_bilinear(int fd,
-    int row, col;
-    double grid[2][2];
-    DCELL *arow = G_allocate_d_raster_buf();
-    DCELL *brow = G_allocate_d_raster_buf();
-    double frow, fcol, trow, tcol;
-    DCELL result;
-    frow = G_northing_to_row(north, window);
-    fcol = G_easting_to_col(east, window);
-    row = (int)floor(frow - 0.5);
-    col = (int)floor(fcol - 0.5);
-    trow = frow - row - 0.5;
-    tcol = fcol - col - 0.5;
-    if (row < 0 || row + 1 >= G_window_rows() ||
-	col < 0 || col + 1 >= G_window_cols()) {
-	goto done;
-    if (G_get_d_raster_row(fd, arow, row) < 0)
-    if (G_get_d_raster_row(fd, brow, row + 1) < 0)
-    if (G_is_d_null_value(&arow[col]) || G_is_d_null_value(&arow[col + 1]) ||
-	G_is_d_null_value(&brow[col]) || G_is_d_null_value(&brow[col + 1])) {
-	goto done;
-     * now were ready to do bilinear interpolation over
-     * arow[col], arow[col+1],
-     * brow[col], brow[col+1]
-    if (usedesc) {
-	char *buf;
-	G_squeeze(buf = G_get_cat((int)arow[col], cats));
-	grid[0][0] = scancatlabel(buf);
-	G_squeeze(buf = G_get_cat((int)arow[col + 1], cats));
-	grid[0][1] = scancatlabel(buf);
-	G_squeeze(buf = G_get_cat((int)brow[col], cats));
-	grid[1][0] = scancatlabel(buf);
-	G_squeeze(buf = G_get_cat((int)brow[col + 1], cats));
-	grid[1][1] = scancatlabel(buf);
-    else {
-	grid[0][0] = arow[col];
-	grid[0][1] = arow[col + 1];
-	grid[1][0] = brow[col];
-	grid[1][1] = brow[col + 1];
-    result = G_interp_bilinear(tcol, trow,
-			       grid[0][0], grid[0][1], grid[1][0], grid[1][1]);
-done:
-    G_free(arow);
-    G_free(brow);
-    return result;
- *  \brief Extract a cell value from raster map (cubic interpolation).
- *  with a sampled 3x3 window using a cubic interpolation.
-DCELL G_get_raster_sample_cubic(int fd,
-    int i, j, row, col;
-    double grid[4][4];
-    DCELL *rows[4];
-    DCELL result;
-    for (i = 0; i < 4; i++)
-	rows[i] = G_allocate_d_raster_buf();
-    row = (int)floor(frow - 1.5);
-    col = (int)floor(fcol - 1.5);
-    trow = frow - row - 1.5;
-    tcol = fcol - col - 1.5;
-    if (row < 0 || row + 3 >= G_window_rows() ||
-	col < 0 || col + 3 >= G_window_cols()) {
-	goto done;
-	if (G_get_d_raster_row(fd, rows[i], row + i) < 0)
-	for (j = 0; j < 4; j++)
-	    if (G_is_d_null_value(&rows[i][col + j])) {
-		goto done;
-     * now were ready to do cubic interpolation over
-     * arow[col], arow[col+1], arow[col+2], arow[col+3],
-     * brow[col], brow[col+1], brow[col+2], brow[col+3],
-     * crow[col], crow[col+1], crow[col+2], crow[col+3],
-     * drow[col], drow[col+1], drow[col+2], drow[col+3],
-    if (usedesc) {
-	char *buf;
-	for (i = 0; i < 4; i++) {
-	    for (j = 0; j < 4; j++) {
-		G_squeeze(buf = G_get_cat(rows[i][col + j], cats));
-		grid[i][j] = scancatlabel(buf);
-    else {
-		grid[i][j] = rows[i][col + j];
-    result = G_interp_bicubic(tcol, trow,
-			      grid[0][0], grid[0][1], grid[0][2], grid[0][3],
-			      grid[1][0], grid[1][1], grid[1][2], grid[1][3],
-			      grid[2][0], grid[2][1], grid[2][2], grid[2][3],
-			      grid[3][0], grid[3][1], grid[3][2], grid[3][3]);
-done:
-	G_free(rows[i]);
-    return result;
-static double scancatlabel(const char *str)
-    double val;
-    if (strcmp(str, "no data") != 0)
-	sscanf(str, "%lf", &val);
-    else {
-	G_warning(_("\"no data\" label found; setting to zero"));
-	val = 0.0;
-    return val;
-			     double east)
-    G_debug(3, "DIAG: \tRegion is: n=%g s=%g e=%g w=%g",
-	    window->north, window->south, window->east, window->west);
-    G_debug(3, "      \tData point is north=%g east=%g", north, east);
-    G_fatal_error(_("Problem reading raster map"));
Modified: grass/trunk/lib/gis/set_window.c
--- grass/trunk/lib/gis/set_window.c	2009-06-20 21:39:23 UTC (rev 38002)
+++ grass/trunk/lib/gis/set_window.c	2009-06-20 22:03:23 UTC (rev 38003)
@@ -12,8 +12,9 @@
+#include <grass/Rast.h>
-#include "G.h"
+#include "../raster/G.h"
  * \brief Get the current working window (region)
@@ -52,7 +53,7 @@
        window = &twindow;
-    if ((err = G_adjust_Cell_head(window, 0, 0))) {
+    if ((err = Rast_adjust_Cell_head(window, 0, 0))) {
 	G_warning("G_set_window(): %s", err);
 	return -1;
@@ -77,7 +78,7 @@
     /* close the mask */
     if (G__.auto_mask > 0) {
-	G_close_cell(maskfd);
+	Rast_close_cell(maskfd);
 	/* G_free (G__.mask_buf); */
 	G__.mask_fd = -1;
 	G__.auto_mask = -1;	/* turn off masking */
@@ -110,14 +111,14 @@
 	    /* opened for writing */
 	    G_free (fcb->data);
 	    fcb->data = (unsigned char *) G_calloc (G__.window.cols,
-						    G_raster_size(fcb->map_type));
+						    Rast_raster_size(fcb->map_type));
 	/* allocate null bitstream buffers for reading/writing null rows */
 	for (j=0;j< NULL_ROWS_INMEM; j++)
 	    G_free (fcb->NULL_ROWS[j]);
-	    fcb->NULL_ROWS[j] = G__allocate_null_bits(G__.window.cols);
+	    fcb->NULL_ROWS[j] = (G__.window.cols);
@@ -133,7 +134,7 @@
     /* turn masking (back) on if necessary */
-    G__check_for_auto_masking();
+    Rast__check_for_auto_masking();
     /* we want the number of bytes per cell to be maximum
        so that there is enough memory for reading and writing rows */
Modified: grass/trunk/lib/gis/window_map.c
--- grass/trunk/lib/gis/window_map.c	2009-06-20 21:39:23 UTC (rev 38002)
+++ grass/trunk/lib/gis/window_map.c	2009-06-20 22:03:23 UTC (rev 38003)
@@ -13,9 +13,10 @@
 #include <stdlib.h>
-#include "G.h"
 #define alloc_index(n) (COLUMN_MAPPING *) G_malloc((n)*sizeof(COLUMN_MAPPING))
Deleted: grass/trunk/lib/gis/zero_cell.c
--- grass/trunk/lib/gis/zero_cell.c	2009-06-20 21:39:23 UTC (rev 38002)
+++ grass/trunk/lib/gis/zero_cell.c	2009-06-20 22:03:23 UTC (rev 38003)
@@ -1,55 +0,0 @@
- * \file gis/zero_cell.c
- * \brief GIS Library - Zero cell buffer functions.
- * \brief Zero a raster CELL buffer.
- * This routines assigns each member of the raster buffer array
- * <i>buf</i> to zero. It assumes that <i>buf</i> has been allocated
- * using G_allocate_cell_buf().
- * \param buf data buffer
-void G_zero_cell_buf(CELL * buf)
-    int i = G_window_cols();
-    while (i--)
-	*buf++ = 0;
- * \brief Zero a raster buffer.
- * <i>rast</i> to zero. It assumes that <i>rast</i> has been allocated
- * \param rast data buffer
-void G_zero_raster_buf(void *rast, RASTER_MAP_TYPE data_type)
-    int i;
-    unsigned char *ptr;
-    /* assuming that the size of unsigned char is 1 byte */
-    i = G_window_cols() * G_raster_size(data_type);
-    ptr = (unsigned char *)rast;
-    while (i--)
-	*ptr++ = 0;
Modified: grass/trunk/lib/gpde/N_arrays.c
--- grass/trunk/lib/gpde/N_arrays.c	2009-06-20 21:39:23 UTC (rev 38002)
+++ grass/trunk/lib/gpde/N_arrays.c	2009-06-20 22:03:23 UTC (rev 38003)
@@ -16,10 +16,13 @@
-#include "grass/N_pde.h"
-#include "grass/glocale.h"
 #include <math.h>
+#include <grass/N_pde.h>
+#include <grass/glocale.h>
 /* ******************** 2D ARRAY FUNCTIONS *********************** */
@@ -233,7 +236,7 @@
 	    G_debug(6,
 		    "N_is_array_2d_value_null: null value is of type CELL at pos [%i][%i]",
 		    col, row);
-	    return G_is_null_value((void *)
+	    return Rast_is_null_value((void *)
 				   &(data->
 				     cell_array[row * data->cols_intern +
 						col]), CELL_TYPE);
@@ -242,7 +245,7 @@
 	    G_debug(6,
 		    "N_is_array_2d_value_null: null value is of type FCELL at pos [%i][%i]",
 		    col, row);
 				   &(data->
 				     fcell_array[row * data->cols_intern +
 						 col]), FCELL_TYPE);
@@ -251,7 +254,7 @@
 	    G_debug(6,
 		    "N_is_array_2d_value_null: null value is of type DCELL at pos [%i][%i]",
 		    col, row);
 				   &(data->
 				     dcell_array[row * data->cols_intern +
 						 col]), DCELL_TYPE);
@@ -262,7 +265,7 @@
 	    G_debug(6,
 		    col, row);
 				   &(data->
 				     cell_array[(row +
 						 data->offset) *
@@ -273,7 +276,7 @@
 	    G_debug(6,
 		    col, row);
 				   &(data->
 				     fcell_array[(row +
 						  data->offset) *
@@ -284,7 +287,7 @@
 	    G_debug(6,
 		    col, row);
 				   &(data->
 				     dcell_array[(row +
 						  data->offset) *
@@ -461,19 +464,19 @@
     if (data->offset == 0) {
 	if (data->type == CELL_TYPE && data->cell_array != NULL) {
-	    G_set_c_null_value((void *)
+	    Rast_set_c_null_value((void *)
 			       &(data->
 				 cell_array[row * data->cols_intern + col]),
 			       1);
 	else if (data->type == FCELL_TYPE && data->fcell_array != NULL) {
-	    G_set_f_null_value((void *)
+	    Rast_set_f_null_value((void *)
 			       &(data->
 				 fcell_array[row * data->cols_intern + col]),
 			       1);
 	else if (data->type == DCELL_TYPE && data->dcell_array != NULL) {
-	    G_set_d_null_value((void *)
+	    Rast_set_d_null_value((void *)
 			       &(data->
 				 dcell_array[row * data->cols_intern + col]),
 			       1);
@@ -481,7 +484,7 @@
     else {
 			       &(data->
 				 cell_array[(row +
 					     data->offset) *
@@ -489,7 +492,7 @@
 					    data->offset]), 1);
 			       &(data->
 				 fcell_array[(row +
 					      data->offset) *
@@ -497,7 +500,7 @@
 					     data->offset]), 1);
 			       &(data->
 				 dcell_array[(row +
 					      data->offset) *
Modified: grass/trunk/lib/gpde/N_arrays_calc.c
--- grass/trunk/lib/gpde/N_arrays_calc.c	2009-06-20 21:39:23 UTC (rev 38002)
+++ grass/trunk/lib/gpde/N_arrays_calc.c	2009-06-20 22:03:23 UTC (rev 38003)
@@ -15,11 +15,13 @@
 *               for details.
 #include <math.h>
@@ -64,7 +66,7 @@
     for (i = 0; i < source->cols_intern * source->rows_intern; i++) {
 	null = 0;
 	if (source->type == CELL_TYPE) {
-	    if (G_is_c_null_value((void *)&source->cell_array[i]))
+	    if (Rast_is_c_null_value((void *)&source->cell_array[i]))
 		null = 1;
 	    if (target->type == CELL_TYPE) {
@@ -72,25 +74,25 @@
 	    if (target->type == FCELL_TYPE) {
 		if (null)
-		    G_set_f_null_value((void *)&(target->fcell_array[i]), 1);
+		    Rast_set_f_null_value((void *)&(target->fcell_array[i]), 1);
 		else
 		    target->fcell_array[i] = (FCELL) source->cell_array[i];
 	    if (target->type == DCELL_TYPE) {
 		if (null)
-		    G_set_d_null_value((void *)&(target->dcell_array[i]), 1);
+		    Rast_set_d_null_value((void *)&(target->dcell_array[i]), 1);
 		else
 		    target->dcell_array[i] = (DCELL) source->cell_array[i];
 	if (source->type == FCELL_TYPE) {
-	    if (G_is_f_null_value((void *)&source->fcell_array[i]))
+	    if (Rast_is_f_null_value((void *)&source->fcell_array[i]))
 		null = 1;
 		if (null)
-		    G_set_c_null_value((void *)&(target->cell_array[i]), 1);
+		    Rast_set_c_null_value((void *)&(target->cell_array[i]), 1);
 		else
 		    target->cell_array[i] = (CELL) source->fcell_array[i];
@@ -99,24 +101,24 @@
 		if (null)
 		else
 		    target->dcell_array[i] = (DCELL) source->fcell_array[i];
 	if (source->type == DCELL_TYPE) {
-	    if (G_is_d_null_value((void *)&source->dcell_array[i]))
+	    if (Rast_is_d_null_value((void *)&source->dcell_array[i]))
 		null = 1;
 		if (null)
 		else
 		    target->cell_array[i] = (CELL) source->dcell_array[i];
 		if (null)
 		else
 		    target->fcell_array[i] = (FCELL) source->dcell_array[i];
@@ -163,27 +165,27 @@
 	v2 = 0.0;
 	if (a->type == CELL_TYPE) {
-	    if (!G_is_f_null_value((void *)&(a->cell_array[i])))
+	    if (!Rast_is_f_null_value((void *)&(a->cell_array[i])))
 		v1 = (double)a->cell_array[i];
 	if (a->type == FCELL_TYPE) {
-	    if (!G_is_f_null_value((void *)&(a->fcell_array[i])))
+	    if (!Rast_is_f_null_value((void *)&(a->fcell_array[i])))
 		v1 = (double)a->fcell_array[i];
 	if (a->type == DCELL_TYPE) {
-	    if (!G_is_f_null_value((void *)&(a->dcell_array[i])))
+	    if (!Rast_is_f_null_value((void *)&(a->dcell_array[i])))
 		v1 = (double)a->dcell_array[i];
 	if (b->type == CELL_TYPE) {
-	    if (!G_is_f_null_value((void *)&(b->cell_array[i])))
+	    if (!Rast_is_f_null_value((void *)&(b->cell_array[i])))
 		v2 = (double)b->cell_array[i];
 	if (b->type == FCELL_TYPE) {
-	    if (!G_is_f_null_value((void *)&(b->fcell_array[i])))
+	    if (!Rast_is_f_null_value((void *)&(b->fcell_array[i])))
 		v2 = (double)b->fcell_array[i];
 	if (b->type == DCELL_TYPE) {
-	    if (!G_is_f_null_value((void *)&(b->dcell_array[i])))
+	    if (!Rast_is_f_null_value((void *)&(b->dcell_array[i])))
 		v2 = (double)b->dcell_array[i];
@@ -438,7 +440,7 @@
 	for (i = 0; i < a->cols_intern * a->rows_intern; i++) {
-	    if (G_is_c_null_value((void *)&(a->cell_array[i]))) {
+	    if (Rast_is_c_null_value((void *)&(a->cell_array[i]))) {
 		a->cell_array[i] = 0;
 		count++;
@@ -446,7 +448,7 @@
-	    if (G_is_f_null_value((void *)&(a->fcell_array[i]))) {
+	    if (Rast_is_f_null_value((void *)&(a->fcell_array[i]))) {
 		a->fcell_array[i] = 0.0;
 		count++;
@@ -455,7 +457,7 @@
-	    if (G_is_d_null_value((void *)&(a->dcell_array[i]))) {
+	    if (Rast_is_d_null_value((void *)&(a->dcell_array[i]))) {
 		a->dcell_array[i] = 0.0;
 		count++;
Modified: grass/trunk/lib/gpde/N_arrays_io.c
--- grass/trunk/lib/gpde/N_arrays_io.c	2009-06-20 21:39:23 UTC (rev 38002)
+++ grass/trunk/lib/gpde/N_arrays_io.c	2009-06-20 22:03:23 UTC (rev 38003)
@@ -15,11 +15,13 @@
 *               for details.
 #include <math.h>
@@ -62,11 +64,11 @@
     cols = region.cols;
     /*open the raster map */
-    map = G_open_cell_old(name, G_find_cell2(name, ""));
+    map = Rast_open_cell_old(name, G_find_cell2(name, ""));
     if (map < 0)
 	G_fatal_error(_("Unable to open raster map <%s>"), name);
-    type = G_get_raster_map_type(map);
+    type = Rast_get_raster_map_type(map);
     /*if the array is NULL create a new one with the data type of the raster map */
     /*the offset is 0 by default */
@@ -91,22 +93,22 @@
 		("N_read_rast_to_array_2d: the data array size is different from the current region settings");
-    rast = G_allocate_raster_buf(type);
+    rast = Rast_allocate_raster_buf(type);
     G_message(_("Reading raster map <%s> into memory"), name);
     for (y = 0; y < rows; y++) {
 	G_percent(y, rows - 1, 10);
-	if (!G_get_raster_row(map, rast, y, type)) {
-	    G_close_cell(map);
+	if (!Rast_get_raster_row(map, rast, y, type)) {
+	    Rast_close_cell(map);
 	    G_fatal_error(_("Could not get raster row"));
 	for (x = 0, ptr = rast; x < cols;
-	     x++, ptr = G_incr_void_ptr(ptr, G_raster_size(type))) {
+	     x++, ptr = Rast_incr_void_ptr(ptr, Rast_raster_size(type))) {
 	    if (type == CELL_TYPE) {
-		if (G_is_c_null_value(ptr)) {
+		if (Rast_is_c_null_value(ptr)) {
 		    N_put_array_2d_value_null(data, x, y);
 		else {
@@ -122,7 +124,7 @@
 	    if (type == FCELL_TYPE) {
-		if (G_is_f_null_value(ptr)) {
+		if (Rast_is_f_null_value(ptr)) {
 		else {
@@ -138,7 +140,7 @@
 	    if (type == DCELL_TYPE) {
-		if (G_is_d_null_value(ptr)) {
+		if (Rast_is_d_null_value(ptr)) {
 		else {
@@ -157,7 +159,7 @@
     /* Close file */
-    if (G_close_cell(map) < 0)
+    if (Rast_close_cell(map) < 0)
 	G_fatal_error(_("Unable to close input map"));
     return data;
@@ -197,16 +199,16 @@
     type = array->type;
     /*Open the new map */
-    map = G_open_raster_new(name, type);
+    map = Rast_open_raster_new(name, type);
     if (map < 0)
 	G_fatal_error(_("Unable to create raster map <%s>"), name);
-	frast = G_allocate_raster_buf(type);
+	frast = Rast_allocate_raster_buf(type);
-	drast = G_allocate_raster_buf(type);
+	drast = Rast_allocate_raster_buf(type);
     G_message(_("Write 2d array to raster map <%s>"), name);
@@ -222,24 +224,24 @@
 		drast[x] = N_get_array_2d_d_value(array, x, y);
-	    if (!G_put_c_raster_row(map, rast)) {
-		G_unopen_cell(map);	/*unopen the new raster map */
+	    if (!Rast_put_c_raster_row(map, rast)) {
+		Rast_unopen_cell(map);	/*unopen the new raster map */
 		G_fatal_error(_("Unable to write raster row %i"), y);
-	    if (!G_put_f_raster_row(map, frast)) {
+	    if (!Rast_put_f_raster_row(map, frast)) {
-	    if (!G_put_d_raster_row(map, drast)) {
+	    if (!Rast_put_d_raster_row(map, drast)) {
     /* Close file */
     return;
@@ -347,7 +349,7 @@
 	    for (x = 0; x < cols; x++) {
 		    G3d_getValue(map, x, y, z, &f1, type);
-		    if (G_is_f_null_value((void *)&f1)) {
+		    if (Rast_is_f_null_value((void *)&f1)) {
 			N_put_array_3d_value_null(data, x, y, z);
 		    else {
@@ -359,7 +361,7 @@
 		else {
 		    G3d_getValue(map, x, y, z, &d1, type);
-		    if (G_is_d_null_value((void *)&d1)) {
+		    if (Rast_is_d_null_value((void *)&d1)) {
 		    else {
Modified: grass/trunk/lib/nviz/nviz.c
--- grass/trunk/lib/nviz/nviz.c	2009-06-20 21:39:23 UTC (rev 38002)
+++ grass/trunk/lib/nviz/nviz.c	2009-06-20 22:03:23 UTC (rev 38003)
@@ -16,6 +16,7 @@
    \date 2008
 #include <grass/nviz.h>
@@ -72,7 +73,7 @@
     int red, grn, blu;
-    if (G_str_to_color(color_str, &red, &grn, &blu) != 1) {
+    if (Rast_str_to_color(color_str, &red, &grn, &blu) != 1) {
 	G_warning(_("Invalid color (%s), using \"white\" as default"),
 		  color_str);
 	red = grn = blu = 255;
Modified: grass/trunk/lib/ogsf/GS2.c
--- grass/trunk/lib/ogsf/GS2.c	2009-06-20 21:39:23 UTC (rev 38002)
+++ grass/trunk/lib/ogsf/GS2.c	2009-06-20 22:03:23 UTC (rev 38003)
@@ -43,6 +43,7 @@
 #endif
 #include <grass/gstypes.h>
@@ -1630,7 +1631,7 @@
     /* Check to see if map is in Region */
-    G_get_cellhd(filename, mapset, &rast_head);
+    Rast_get_cellhd(filename, mapset, &rast_head);
     if (rast_head.north <= wind.south ||
 	rast_head.south >= wind.north ||
 	rast_head.east <= wind.west || rast_head.west >= wind.east) {
Modified: grass/trunk/lib/ogsf/Gp3.c
--- grass/trunk/lib/ogsf/Gp3.c	2009-06-20 21:39:23 UTC (rev 38002)
+++ grass/trunk/lib/ogsf/Gp3.c	2009-06-20 22:03:23 UTC (rev 38003)
@@ -19,6 +19,7 @@
 #include <stdlib.h>
 #include <grass/site.h>
 #include <grass/Vect.h>
@@ -55,13 +56,13 @@
 	    return 0;
-	G_read_colors(grassname, col_map, &sc);
+	Rast_read_colors(grassname, col_map, &sc);
 	for (tp = gp; tp; tp = tp->next) {
 	    cat = (int)tp->fattr;
 	    color = NULL_COLOR;
-	    if (G_get_color(cat, &r, &g, &b, &sc)) {
+	    if (Rast_get_color(cat, &r, &g, &b, &sc)) {
 		color = (r & 0xff) | ((g & 0xff) << 8) | ((b & 0xff) << 16);
Modified: grass/trunk/lib/ogsf/Gs3.c
--- grass/trunk/lib/ogsf/Gs3.c	2009-06-20 21:39:23 UTC (rev 38002)
+++ grass/trunk/lib/ogsf/Gs3.c	2009-06-20 22:03:23 UTC (rev 38003)
@@ -20,6 +20,7 @@
 #include <string.h>
 #include <grass/bitmap.h>
@@ -128,12 +129,12 @@
     *has_null = 0;
-    nullflags = G_allocate_null_buf();	/* G_fatal_error */
+    nullflags = Rast_allocate_null_buf();	/* G_fatal_error */
     if (!nullflags) {
 	G_fatal_error(_("Unable to allocate memory for a null buffer"));
-    if ((cellfile = G_open_cell_old(map_name, map_set)) == -1) {
+    if ((cellfile = Rast_open_cell_old(map_name, map_set)) == -1) {
 	G_fatal_error(_("Unable to open raster map <%s>"), map_name);
@@ -142,13 +143,13 @@
     for (row = 0; row < wind->rows; row++) {
 	offset = row * wind->cols;
-	G_get_f_raster_row(cellfile, &(buff[offset]), row);
-	G_get_null_value_row(cellfile, nullflags, row);
+	Rast_get_f_raster_row(cellfile, &(buff[offset]), row);
+	Rast_get_null_value_row(cellfile, nullflags, row);
 	G_percent(row, wind->rows, 2);
 	for (col = 0; col < wind->cols; col++) {
-	    if (nullflags[col] || G_is_f_null_value(buff + offset + col)) {
+	    if (nullflags[col] || Rast_is_f_null_value(buff + offset + col)) {
 		*has_null = 1;
 		BM_set(nullmap, col, row, 1);
@@ -159,7 +160,7 @@
     G_debug(4, "  has_null=%d", *has_null);
-    G_close_cell(cellfile);
+    Rast_close_cell(cellfile);
     G_free(nullflags);
@@ -203,12 +204,12 @@
     *has_null = 0;
     if (!nullflags) {
@@ -217,8 +218,8 @@
-	G_get_c_raster_row(cellfile, &(buff[offset]), row);
+	Rast_get_c_raster_row(cellfile, &(buff[offset]), row);
@@ -233,7 +234,7 @@
     G_percent(1, 1, 1);
     G_free(nullflags);
@@ -246,7 +247,7 @@
    \param filename raster map name
    \param negflag
-   \return -1 if map is integer and G_read_range() fails
+   \return -1 if map is integer and Rast_read_range() fails
    \return data type (ARRY_*)
 int Gs_numtype(const char *filename, int *negflag)
@@ -287,17 +288,17 @@
 	return -1;
-    if (G_raster_map_is_fp(filename, mapset)) {
+    if (Rast_raster_map_is_fp(filename, mapset)) {
 	G_debug(3, "Gs_numtype(): fp map detected");
 	return (ATTY_FLOAT);
-    if (-1 == G_read_range(filename, mapset, &range)) {
+    if (-1 == Rast_read_range(filename, mapset, &range)) {
 	return (-1);
-    G_get_range_min_max(&range, &min, &max);
+    Rast_get_range_min_max(&range, &min, &max);
     *negflag = (min < 0);
     if (max < max_char && min > 0) {
@@ -361,12 +362,12 @@
     *has_null = 0;
     if (!nullflags) {
@@ -380,8 +381,8 @@
-	G_get_c_raster_row(cellfile, tmp_buf, row);
+	Rast_get_c_raster_row(cellfile, tmp_buf, row);
@@ -412,7 +413,7 @@
     G_percent(1, 1, 1);
     G_free(tmp_buf);
     G_free(nullflags);
@@ -477,12 +478,12 @@
     *has_null = 0;
     if (!nullflags) {
@@ -496,8 +497,8 @@
 	tc = (unsigned char *)&(buff[offset]);
 	ti = tmp_buf;
@@ -529,7 +530,7 @@
     G_percent(1, 1, 1);
     G_free(tmp_buf);
     G_free(nullflags);
@@ -573,7 +574,7 @@
 	return -1;
@@ -582,7 +583,7 @@
 	return -1;
     if (!nullflags) {
@@ -591,7 +592,7 @@
 	      G_fully_qualified_name(map_name, map_set));
 	    if (nullflags[col]) {
@@ -604,7 +605,7 @@
     G_free(tmp_buf);
     G_free(nullflags);
@@ -640,8 +641,8 @@
 	return 0;
-    G_read_colors(filename, mapset, &colrules);
-    G_get_color_range(&min, &max, &colrules);
+    Rast_read_colors(filename, mapset, &colrules);
+    Rast_get_color_range(&min, &max, &colrules);
     if (min < 0 || max > 255) {
 	G_warning(_("Color table range doesn't match data (mincol=%d, maxcol=%d"),
@@ -657,7 +658,7 @@
 	cats[i] = i;
-    G_lookup_colors(cats, r, g, b, set, 256, &colrules);
+    Rast_lookup_colors(cats, r, g, b, set, 256, &colrules);
     for (i = 0; i < 256; i++) {
@@ -702,14 +703,14 @@
     b = (unsigned char *)G_malloc(cols);
     set = (unsigned char *)G_malloc(cols);
     cur = buff;
     G_message(_("Translating colors from raster map <%s>..."), filename);
     for (i = 0; i < rows; i++) {
-	G_lookup_colors(cur, r, g, b, set, cols, &colrules);
+	Rast_lookup_colors(cur, r, g, b, set, cols, &colrules);
 	G_percent(i, rows, 2);
 	for (j = 0; j < cols; j++) {
@@ -727,7 +728,7 @@
     G_percent(1, 1, 1);
-    G_free_colors(&colrules);
+    Rast_free_colors(&colrules);
     G_free(r);
     G_free(g);
@@ -772,7 +773,7 @@
     fcur = fbuf;
     icur = ibuf;
@@ -780,7 +781,7 @@
-	G_lookup_f_raster_colors(fcur, r, g, b, set, cols, &colrules);
+	Rast_lookup_f_raster_colors(fcur, r, g, b, set, cols, &colrules);
@@ -799,7 +800,7 @@
     G_percent(1, 1, 1);
     G_free(r);
     G_free(g);
@@ -836,23 +837,23 @@
 	return 0;
-    if (-1 != G_read_cats(filename, mapset, &cats)) {
-	fd = G_open_cell_old(filename, mapset);
-	map_type = G_get_raster_map_type(fd);
+    if (-1 != Rast_read_cats(filename, mapset, &cats)) {
+	fd = Rast_open_cell_old(filename, mapset);
+	map_type = Rast_get_raster_map_type(fd);
 	if (map_type == CELL_TYPE) {
-	    buf = G_allocate_c_raster_buf();
+	    buf = Rast_allocate_c_raster_buf();
-	    if (G_get_c_raster_row(fd, buf, drow) < 0) {
+	    if (Rast_get_c_raster_row(fd, buf, drow) < 0) {
 		sprintf(catstr, "error");
-	    else if (G_is_c_null_value(&buf[dcol])) {
+	    else if (Rast_is_c_null_value(&buf[dcol])) {
 		sprintf(catstr, "(NULL) %s",
-			G_get_c_raster_cat(&buf[dcol], &cats));
+			Rast_get_c_raster_cat(&buf[dcol], &cats));
 	    else {
 		sprintf(catstr, "(%d) %s", buf[dcol],
 	    G_free(buf);
@@ -860,18 +861,18 @@
 	else {
 	    /* fp map */
-	    dbuf = G_allocate_d_raster_buf();
+	    dbuf = Rast_allocate_d_raster_buf();
-	    if (G_get_d_raster_row(fd, dbuf, drow) < 0) {
+	    if (Rast_get_d_raster_row(fd, dbuf, drow) < 0) {
-	    else if (G_is_d_null_value(&dbuf[dcol])) {
+	    else if (Rast_is_d_null_value(&dbuf[dcol])) {
-			G_get_d_raster_cat(&dbuf[dcol], &cats));
+			Rast_get_d_raster_cat(&dbuf[dcol], &cats));
 	    else {
 		sprintf(catstr, "(%g) %s", dbuf[dcol],
 	    G_free(dbuf);
@@ -882,9 +883,9 @@
     /* TODO: may want to keep these around for multiple queries */
-    G_free_cats(&cats);
+    Rast_free_cats(&cats);
-    G_close_cell(fd);
+    Rast_close_cell(fd);
     return (1);
Modified: grass/trunk/lib/ogsf/Gvl3.c
--- grass/trunk/lib/ogsf/Gvl3.c	2009-06-20 21:39:23 UTC (rev 38002)
+++ grass/trunk/lib/ogsf/Gvl3.c	2009-06-20 22:03:23 UTC (rev 38003)
@@ -17,6 +17,7 @@
 #include <grass/G3d.h>
@@ -63,7 +64,7 @@
 int Gvl_unload_colors_data(void *color_data)
-    G_free_colors(color_data);
+    Rast_free_colors(color_data);
     G_free(color_data);
@@ -82,6 +83,6 @@
     int r, g, b;
-    G_get_f_raster_color((FCELL *) value, &r, &g, &b, color_data);
+    Rast_get_f_raster_color((FCELL *) value, &r, &g, &b, color_data);
     return ((r & 0xff) | ((g & 0xff) << 8) | ((b & 0xff) << 16));
Modified: grass/trunk/lib/ogsf/gsd_legend.c
--- grass/trunk/lib/ogsf/gsd_legend.c	2009-06-20 21:39:23 UTC (rev 38002)
+++ grass/trunk/lib/ogsf/gsd_legend.c	2009-06-20 22:03:23 UTC (rev 38003)
@@ -32,6 +32,7 @@
 #endif
@@ -239,15 +240,15 @@
 	return (-1);
-    is_fp = G_raster_map_is_fp(name, mapset);
+    is_fp = Rast_raster_map_is_fp(name, mapset);
-    if (G_read_colors(name, mapset, &colors) == -1) {
+    if (Rast_read_colors(name, mapset, &colors) == -1) {
 	G_warning(_("Unable to read color file of raster map <%s>"), name);
 	return (-1);
     if (cat_labs)
-	if (G_read_cats(name, mapset, &cats) == -1) {
+	if (Rast_read_cats(name, mapset, &cats) == -1) {
 	    G_warning(_("Unable to read category file of raster map <%s>"),
 		      name);
 	    cat_labs = 0;
@@ -264,23 +265,23 @@
     else {
 	if (is_fp) {
-	    if (G_read_fp_range(name, mapset, &fp_range) != 1) {
+	    if (Rast_read_fp_range(name, mapset, &fp_range) != 1) {
 		G_warning(_("Unable to read fp range of raster map <%s>"),
 			  name);
 		return (-1);
-	    G_get_fp_range_min_max(&fp_range, &fmin, &fmax);
+	    Rast_get_fp_range_min_max(&fp_range, &fmin, &fmax);
 	    if (flags[4] && rangef[0] != -9999.)
 		fmin = rangef[0];
 	    if (flags[4] && rangef[1] != -9999.)
 		fmax = rangef[1];
 	else {
-	    if (G_read_range(name, mapset, &range) == -1) {
+	    if (Rast_read_range(name, mapset, &range) == -1) {
 		G_warning(_("Unable to read range of raster map <%s>"), name);
 		return (-1);
 		min = rangef[0];
@@ -402,7 +403,7 @@
 		if (is_fp) {
 		    tdcell = discrete ? Listcats[k] : labvals[k];
 		    if (cat_labs) {
-			cstr = G_get_d_raster_cat(&tdcell, &cats);
+			cstr = Rast_get_d_raster_cat(&tdcell, &cats);
 		    if (cat_labs && !cat_vals) {
 			sprintf(buff, "%s", cstr);
@@ -423,10 +424,10 @@
 		    tcell = discrete ? Listnum ?
 			Listcats[k] : min + k : labvals[k];
-			sprintf(buff, "%s", G_get_cat(tcell, &cats));
+			sprintf(buff, "%s", Rast_get_cat(tcell, &cats));
 		    else {
 			if (cat_labs && cat_vals) {
-			    cstr = G_get_cat(tcell, &cats);
+			    cstr = Rast_get_cat(tcell, &cats);
 			    if (cstr[0])
 				sprintf(buff, "%*d) %s", iprec, tcell, cstr);
 			    else
@@ -514,10 +515,10 @@
 	    if (k == 0 || tdcell != pdcell) {
 		if (is_fp)
-		    G_get_d_raster_color(&tdcell,
+		    Rast_get_d_raster_color(&tdcell,
 					 &red, &green, &blue, &colors);
 		else
-		    G_get_color((CELL) tdcell, &red, &green, &blue, &colors);
+		    Rast_get_color((CELL) tdcell, &red, &green, &blue, &colors);
 		RGB_TO_INT(red, green, blue, colr);
 		if (discrete) {	/* draw black-white-black separator */
@@ -634,9 +635,9 @@
 		    labpos = 1. - labpos;
 		if (cat_labs) {
 		    if (!is_fp)
 		    else
@@ -688,9 +689,9 @@
     if (cat_labs)
-    G_free_colors(&colors);
+    Rast_free_colors(&colors);
     gsd_end_legend_viewport();
Copied: grass/trunk/lib/raster/G.h (from rev 37989, grass/trunk/lib/gis/G.h)
--- grass/trunk/lib/raster/G.h	                        (rev 0)
+++ grass/trunk/lib/raster/G.h	2009-06-20 22:03:23 UTC (rev 38003)
@@ -0,0 +1,94 @@
+#include <grass/config.h>
+#include <grass/gis.h>
+#include <rpc/types.h>
+#include <rpc/xdr.h>
+#ifdef HAVE_GDAL
+#include <gdal.h>
+#endif
+#define XDR_FLOAT_NBYTES 4
+#define XDR_DOUBLE_NBYTES 8
+#define NULL_ROWS_INMEM 8
+/* if short is 16 bits, then
+ *       short will allow 32767 cols
+ *       unsigned short will allow 65536 cols
+ * use int if you need more columns (but this will take more memory).
+typedef int COLUMN_MAPPING;
+struct GDAL_link
+    char *filename;
+    int band_num;
+    DCELL null_val;
+    int hflip;
+    int vflip;
+#ifdef HAVE_GDAL
+    GDALDatasetH data;
+    GDALRasterBandH band;
+    GDALDataType type;
+#endif
+#ifdef HAVE_GDAL
+extern CPLErr G_gdal_raster_IO(
+    GDALRasterBandH, GDALRWFlag,
+    int, int, int, int,
+    void *, int, int, GDALDataType,
+    int, int);
+#endif
+struct fileinfo			/* Information for opened cell files */
+    int open_mode;		/* see defines below            */
+    struct Cell_head cellhd;	/* Cell header                  */
+    struct Reclass reclass;	/* Table reclass                */
+    struct Cell_stats statf;	/* Cell stats                   */
+    struct Range range;		/* Range structure              */
+    struct FPRange fp_range;	/* float Range structure        */
+    int want_histogram;
+    int reclass_flag;		/* Automatic reclass flag       */
+    off_t *row_ptr;		/* File row addresses           */
+    COLUMN_MAPPING *col_map;	/* Data to window col mapping   */
+    double C1, C2;		/* Data to window row constants */
+    int cur_row;		/* Current data row in memory   */
+    int null_cur_row;		/* Current null row in memory   */
+    int cur_nbytes;		/* nbytes per cell for current row */
+    unsigned char *data;	/* Decompressed data buffer     */
+    int nbytes;			/* bytes per cell               */
+    RASTER_MAP_TYPE map_type;	/* type: int, float or double map */
+    char *temp_name;		/* Temporary name for NEW files */
+    char *null_temp_name;	/* Temporary name for NEW NULL files */
+    int null_file_exists;	/* for existing raster maps     */
+    char *name;			/* Name of open file            */
+    char *mapset;		/* Mapset of open file          */
+    int io_error;		/* io error warning given       */
+    XDR xdrstream;		/* xdr stream for reading fp    */
+    unsigned char *NULL_ROWS[NULL_ROWS_INMEM];
+    int min_null_row;		/* Minimum row null row number in memory */
+    struct Quant quant;
+    struct GDAL_link *gdal;
+struct G__			/*  Structure of library globals */
+    RASTER_MAP_TYPE fp_type;	/* type for writing floating maps */
+    struct Cell_head window;	/* Contains the current window          */
+    int window_set;		/* Flag: window set?                    */
+    int mask_fd;		/* File descriptor for automatic mask   */
+    int auto_mask;		/* Flag denoting automatic masking      */
+    int nbytes;
+    int compression_type;
+    int fileinfo_count;
+    struct fileinfo *fileinfo;
+extern struct G__ G__;		/* allocated in gisinit */
+#define OPEN_OLD              1
+#define OPEN_NEW_COMPRESSED   2
+#define OPEN_NEW_UNCOMPRESSED 3
Copied: grass/trunk/lib/raster/adj_cellhd.c (from rev 37989, grass/trunk/lib/gis/adj_cellhd.c)
--- grass/trunk/lib/raster/adj_cellhd.c	                        (rev 0)
+++ grass/trunk/lib/raster/adj_cellhd.c	2009-06-20 22:03:23 UTC (rev 38003)
@@ -0,0 +1,356 @@
+ * \file gis/adj_cellhd.c
+ * \brief GIS Library - CELL header adjustment.
+ * (C) 2001-2009 by the GRASS Development Team
+ * This program is free software under the GNU General Public License
+ * (>=v2). Read the file COPYING that comes with GRASS for details.
+ * \author Original author CERL
+ * \brief Adjust cell header.
+ * This function fills in missing parts of the input cell header (or
+ * region). It also makes projection-specific adjustments. The
+ * <i>cellhd</i> structure must have its <i>north, south, east,
+ * west</i>, and <i>proj</i> fields set.
+ * If <i>row_flag</i> is true, then the north-south resolution is
+ * computed from the number of <i>rows</i> in the <i>cellhd</i>
+ * structure. Otherwise the number of <i>rows</i> is computed from the
+ * north-south resolution in the structure, similarly for
+ * <i>col_flag</i> and the number of columns and the east-west
+ * resolution.
+ * <b>Note:</b> 3D values are not adjusted.
+ * \param[in,out] cellhd pointer to Cell_head structure
+ * \param row_flag compute n-s resolution
+ * \param col_flag compute e-w resolution
+ * \return NULL on success
+ * \return localized text string on error
+const char *Rast_adjust_Cell_head(struct Cell_head *cellhd, int row_flag, int col_flag)
+    if (!row_flag) {
+	if (cellhd->ns_res <= 0)
+	    return (_("Illegal n-s resolution value"));
+    else {
+	if (cellhd->rows <= 0)
+	    return (_("Illegal row value"));
+    if (!col_flag) {
+	if (cellhd->ew_res <= 0)
+	    return (_("Illegal e-w resolution value"));
+    else {
+	if (cellhd->cols <= 0)
+	    return (_("Illegal col value"));
+    /* for lat/lon, check north,south. force east larger than west */
+    if (cellhd->proj == PROJECTION_LL) {
+	double epsilon_ns, epsilon_ew;
+	/* TODO: find good thresholds */
+	epsilon_ns = 1. / cellhd->rows * 0.001;
+	epsilon_ew = .000001;	/* epsilon_ew calculation doesn't work due to cellhd->cols update/global wraparound below */
+	G_debug(3, "Rast_adjust_Cell_head: epsilon_ns: %g, epsilon_ew: %g",
+		epsilon_ns, epsilon_ew);
+	/* TODO: once working, change below G_warning to G_debug */
+	/* fix rounding problems if input map slightly exceeds the world definition -180 90 180 -90 */
+	if (cellhd->north > 90.0) {
+	    if (((cellhd->north - 90.0) < epsilon_ns) &&
+		((cellhd->north - 90.0) > GRASS_EPSILON)) {
+		G_warning(_("Fixing subtle input data rounding error of north boundary (%g>%g)"),
+			  cellhd->north - 90.0, epsilon_ns);
+		cellhd->north = 90.0;
+	    else
+		return (_("Illegal latitude for North"));
+	if (cellhd->south < -90.0) {
+	    if (((cellhd->south + 90.0) < epsilon_ns) &&
+		((cellhd->south + 90.0) < GRASS_EPSILON)) {
+		G_warning(_("Fixing subtle input data rounding error of south boundary (%g>%g)"),
+			  cellhd->south + 90.0, epsilon_ns);
+		cellhd->south = -90.0;
+	    else
+		return (_("Illegal latitude for South"));
+#if 0
+	/* DISABLED: this breaks global wrap-around */
+	G_debug(3,
+		"Rast_adjust_Cell_head()  cellhd->west: %f, devi: %g, eps: %g",
+		cellhd->west, cellhd->west + 180.0, epsilon_ew);
+	if ((cellhd->west < -180.0) && ((cellhd->west + 180.0) < epsilon_ew)
+	    && ((cellhd->west + 180.0) < GRASS_EPSILON)) {
+	    G_warning(_("Fixing subtle input data rounding error of west boundary (%g>%g)"),
+		      cellhd->west + 180.0, epsilon_ew);
+	    cellhd->west = -180.0;
+	G_debug(3,
+		"Rast_adjust_Cell_head()  cellhd->east: %f, devi: %g, eps: %g",
+		cellhd->east, cellhd->east - 180.0, epsilon_ew);
+	if ((cellhd->east > 180.0) && ((cellhd->east - 180.0) > epsilon_ew)
+	    && ((cellhd->east - 180.0) > GRASS_EPSILON)) {
+	    G_warning(_("Fixing subtle input data rounding error of east boundary (%g>%g)"),
+		      cellhd->east - 180.0, epsilon_ew);
+	    cellhd->east = 180.0;
+#endif
+	while (cellhd->east <= cellhd->west)
+	    cellhd->east += 360.0;
+    /* check the edge values */
+    if (cellhd->north <= cellhd->south) {
+	    return (_("North must be north of South"));
+	else
+	    return (_("North must be larger than South"));
+    if (cellhd->east <= cellhd->west)
+	return (_("East must be larger than West"));
+    /* compute rows and columns, if not set */
+    if (!row_flag) {
+	cellhd->rows =
+	    (cellhd->north - cellhd->south +
+	     cellhd->ns_res / 2.0) / cellhd->ns_res;
+	if (cellhd->rows == 0)
+	    cellhd->rows = 1;
+    if (!col_flag) {
+	cellhd->cols =
+	    (cellhd->east - cellhd->west +
+	     cellhd->ew_res / 2.0) / cellhd->ew_res;
+	if (cellhd->cols == 0)
+	    cellhd->cols = 1;
+    if (cellhd->cols < 0 || cellhd->rows < 0) {
+	return (_("Invalid coordinates"));
+    /* (re)compute the resolutions */
+    cellhd->ns_res = (cellhd->north - cellhd->south) / cellhd->rows;
+    cellhd->ew_res = (cellhd->east - cellhd->west) / cellhd->cols;
+    return NULL;
+ * \brief Adjust cell header for 3D values.
+ * If <i>row_flag</i> is true, then the north-south resolution is computed
+ * from the number of <i>rows</i> in the <i>cellhd</i> structure.
+ * Otherwise the number of <i>rows</i> is computed from the north-south
+ * resolution in the structure, similarly for <i>col_flag</i> and the
+ * number of columns and the east-west resolution.
+ * If <i>depth_flag</i> is true, top-bottom resolution is calculated
+ * from depths.
+ * If <i>depth_flag</i> are false, number of depths is calculated from
+ * top-bottom resolution.
+ * \param depth_flag compute t-b resolution
+const char *Rast_adjust_Cell_head3(struct Cell_head *cellhd, int row_flag,
+				int col_flag, int depth_flag)
+    if (!row_flag) {
+	if (cellhd->ns_res3 <= 0)
+	    return (_("Illegal n-s3 resolution value"));
+    else {
+	if (cellhd->rows3 <= 0)
+	    return (_("Illegal row3 value"));
+    if (!col_flag) {
+	if (cellhd->ew_res3 <= 0)
+	    return (_("Illegal e-w3 resolution value"));
+    else {
+	if (cellhd->cols3 <= 0)
+	    return (_("Illegal col3 value"));
+    if (!depth_flag) {
+	if (cellhd->tb_res <= 0)
+	    return (_("Illegal t-b3 resolution value"));
+    else {
+	if (cellhd->depths <= 0)
+	    return (_("Illegal depths value"));
+	    else
+	    else
+#if 0
+	G_debug(3,
+		"Rast_adjust_Cell_head3() cellhd->west: %f, devi: %g, eps: %g",
+	G_debug(3,
+		"Rast_adjust_Cell_head3() cellhd->east: %f, devi: %g, eps: %g",
+#endif
+	else
+    if (cellhd->top <= cellhd->bottom)
+	return (_("Top must be larger than Bottom"));
+    if (!row_flag) {
+	cellhd->rows =
+	    cellhd->rows = 1;
+	cellhd->rows3 =
+	     cellhd->ns_res3 / 2.0) / cellhd->ns_res3;
+	if (cellhd->rows3 == 0)
+	    cellhd->rows3 = 1;
+    if (!col_flag) {
+	cellhd->cols =
+	    cellhd->cols = 1;
+	cellhd->cols3 =
+	     cellhd->ew_res3 / 2.0) / cellhd->ew_res3;
+	if (cellhd->cols3 == 0)
+	    cellhd->cols3 = 1;
+	cellhd->depths =
+	    (cellhd->top - cellhd->bottom +
+	     cellhd->tb_res / 2.0) / cellhd->tb_res;
+	if (cellhd->depths == 0)
+	    cellhd->depths = 1;
+    if (cellhd->cols < 0 || cellhd->rows < 0 || cellhd->cols3 < 0 ||
+	cellhd->rows3 < 0 || cellhd->depths < 0) {
+    cellhd->ns_res3 = (cellhd->north - cellhd->south) / cellhd->rows3;
+    cellhd->ew_res3 = (cellhd->east - cellhd->west) / cellhd->cols3;
+    cellhd->tb_res = (cellhd->top - cellhd->bottom) / cellhd->depths;
+    return NULL;
Copied: grass/trunk/lib/raster/alloc_cell.c (from rev 37989, grass/trunk/lib/gis/alloc_cell.c)
--- grass/trunk/lib/raster/alloc_cell.c	                        (rev 0)
+++ grass/trunk/lib/raster/alloc_cell.c	2009-06-20 22:03:23 UTC (rev 38003)
@@ -0,0 +1,166 @@
+ * \file gis/alloc_cell.c
+ * \brief GIS Library - Raster allocation routines.
+#include <math.h>
+/* convert type "RASTER_MAP_TYPE" into index */
+#define F2I(map_type) \
+	(map_type == CELL_TYPE ? 0 : (map_type == FCELL_TYPE ? 1 : 2))
+static const int type_size[3] = { sizeof(CELL), sizeof(FCELL), sizeof(DCELL) };
+ * \brief Returns size of a raster CELL in bytes.
+ *  - If <i>data_type</i> is CELL_TYPE, returns sizeof(CELL)
+ *  - If <i>data_type</i> is FCELL_TYPE, returns sizeof(FCELL)
+ *  - If <i>data_type</i> is DCELL_TYPE, returns sizeof(DCELL)
+ * \param data_type raster type (CELL, FCELL, DCELL)
+ * \return raster type size
+size_t Rast_raster_size(RASTER_MAP_TYPE data_type)
+    return (type_size[F2I(data_type)]);
+ * \brief Allocate memory for a CELL type raster map.
+ * This routine allocates a buffer of type CELL just large enough to
+ * hold one row of raster data based on the number of columns in the
+ * active region.
+ \code
+ CELL *cell;
+ cell = Rast_allocate_cell_buf();
+ \endcode
+ * If larger buffers are required, the routine G_malloc() can be used.
+ * The routine is generally used with each open cell file.
+ * <b>Note:</b> Rast_allocate_raster_buf() or G_alloc_c_raster_buf() is
+ * preferred over Rast_allocate_cell_buf().
+ * Prints error message and calls exit() on error.
+ * \return CELL * pointer to allocated buffer
+CELL *Rast_allocate_cell_buf(void)
+    return (CELL *) G_calloc(G_window_cols() + 1, sizeof(CELL));
+ * \brief Allocate memory for a raster map of given type
+ * Allocate an array of CELL, FCELL, or DCELL (depending on
+ * <i>data_type</i>) based on the number of columns in the current
+ * region.
+ * \return pointer to allocated buffer
+void *Rast_allocate_raster_buf(RASTER_MAP_TYPE data_type)
+    return (void *)G_calloc(G_window_cols() + 1, Rast_raster_size(data_type));
+ * \brief Allocates memory for a raster map of type CELL.
+ * Allocate an array of CELL based on the number of columns in the
+ * current region.
+CELL *Rast_allocate_c_raster_buf(void)
+ * \brief Allocates memory for a raster map of type FCELL.
+ * Allocate an array of FCELL based on the number of columns in the
+ * current region.
+FCELL *Rast_allocate_f_raster_buf(void)
+    return (FCELL *) G_calloc(G_window_cols() + 1, sizeof(FCELL));
+ * \brief Allocates memory for a raster map of type DCELL.
+ * Allocate an array of DCELL based on the number of columns in the
+ * current region.
+DCELL *Rast_allocate_d_raster_buf(void)
+    return (DCELL *) G_calloc(G_window_cols() + 1, sizeof(DCELL));
+ * \brief Allocates memory for a null buffer.
+ * Allocate an array of char based on the number of columns in the
+ * current region.
+char *Rast_allocate_null_buf(void)
+    return (char *)G_calloc(G_window_cols() + 1, sizeof(char));
+ * \brief Allocates memory for null bits.
+ * Allocates an array of unsigned char based on <i>cols</i>.
+ * \param cols number of columns in region
+unsigned char *Rast__allocate_null_bits(int cols)
+    return (unsigned char *)G_calloc(Rast__null_bitstream_size(cols) + 1,
+				     sizeof(unsigned char));
+ * \brief Determines null bitstream size.
+ * \return -1 if <i>cols</i> is invalid (<= 0)
+ * \return size of null bistream
+int Rast__null_bitstream_size(int cols)
+    if (cols <= 0)
+	return -1;
+    return (cols / 8 + (cols % 8 != 0));
Copied: grass/trunk/lib/raster/auto_mask.c (from rev 37989, grass/trunk/lib/gis/auto_mask.c)
--- grass/trunk/lib/raster/auto_mask.c	                        (rev 0)
+++ grass/trunk/lib/raster/auto_mask.c	2009-06-20 22:03:23 UTC (rev 38003)
@@ -0,0 +1,108 @@
+ * \file auto_mask.c
+ * \brief GIS Library - Auto masking routines.
+ * (C) 2001-2008 by the GRASS Development Team
+ * \author GRASS GIS Development Team
+ * \date 1999-2008
+#include <stdlib.h>
+#include "G.h"
+ * \brief Checks for auto masking.
+ * On first call, opens the mask file if declared and available and
+ * allocates buffer for reading mask rows.
+ * On second call, returns 0 or 1.
+ * \return 0 if mask unset or unavailable
+ * \return 1 if mask set and available and ready to use
+int Rast__check_for_auto_masking(void)
+    /* if mask is switched off (-2) return -2
+       if G__.auto_mask is not set (-1) or set (>=0) recheck the MASK */
+    if (G__.auto_mask < -1)
+	return G__.auto_mask;
+    /* if(G__.mask_fd > 0) G_free (G__.mask_buf); */
+    /* look for the existence of the MASK file */
+    G__.auto_mask = (G_find_cell("MASK", G_mapset()) != 0);
+    if (G__.auto_mask <= 0)
+	return 0;
+    /* check MASK projection/zone against current region */
+    if (Rast_get_cellhd("MASK", G_mapset(), &cellhd) >= 0) {
+	if (cellhd.zone != G_zone() || cellhd.proj != G_projection()) {
+	    G__.auto_mask = 0;
+	    return 0;
+    Rast_unopen_cell(G__.mask_fd);
+    G__.mask_fd = Rast__open_cell_old("MASK", G_mapset());
+    if (G__.mask_fd < 0) {
+	G_warning(_("Unable to open automatic MASK file"));
+	return 0;
+    /*    G__.mask_buf = Rast_allocate_cell_buf(); */
+    G__.auto_mask = 1;
+    return 1;
+ * \brief Suppresses masking.
+ * \return
+void Rast_suppress_masking(void)
+    if (G__.auto_mask > 0) {
+	Rast_close_cell(G__.mask_fd);
+	/* G_free (G__.mask_buf); */
+	G__.mask_fd = -1;
+    G__.auto_mask = -2;
+ * \brief Unsuppresses masking.
+ * \return
+void Rast_unsuppress_masking(void)
+    if (G__.auto_mask < -1) {
+	G__.mask_fd = -1;
Copied: grass/trunk/lib/raster/cats.c (from rev 37989, grass/trunk/lib/gis/cats.c)
--- grass/trunk/lib/raster/cats.c	                        (rev 0)
+++ grass/trunk/lib/raster/cats.c	2009-06-20 22:03:23 UTC (rev 38003)
@@ -0,0 +1,1490 @@
+ * \file gis/cats.c
+ * \brief GIS Library - Raster categories management
+ * Code in this file works with category files.  There are two formats:
+ * Pre 3.0 direct category encoding form:
+ *    2 categories
+ *    Map Title
+ *    Elevation: 1000.00 to 1005.00 feet
+ *    Elevation: 1005.00 to 1010.00 feet
+ *    Elevation: 1010.00 to 1015.00 feet
+ * 3.0 format
+ *    # 2 categories
+ *    Map Title
+ *    Elevation: $1.2 to $2.2 feet       ## Format Statement
+ *    5.0 1000 5.0 1005                  ## Coefficients
+ * The coefficient line can be followed by explicit category labels
+ * which override the format label generation.
+ *    0:no data
+ *    2:   .
+ *    5:   .                             ## explicit category labels
+ *    7:   .
+ * explicit labels can be also of the form:
+ *    5.5:5:9 label description
+ *    or
+ *    15:30  label description
+ * In the format line
+ *   $1 refers to the value num*5.0+1000 (ie, using the first 2 coefficients)
+ *   $2 refers to the value num*5.0+1005 (ie, using the last 2 coefficients)
+ *   $1.2 will print $1 with 2 decimal places.
+ * Also, the form $?xxx$yyy$ translates into yyy if the category is 1, xxx
+ * otherwise. The $yyy$ is optional. Thus
+ *   $1 meter$?s
+ * will become: 1 meter (for category 1)
+ *              2 meters (for category 2), etc.
+ * The format and coefficients above would be used to generate the
+ * following statement in creation of the format appropriate category
+ * string for category "num":
+ *   sprintf(buff,"Elevation: %.2f to %.2f feet", num*5.0+1000, num*5.0*1005)
+ * Note: while both the format and coefficent lins must be present
+ *       a blank line for the fmt will effectively suppress automatic
+ *       label generation
+ * Note: quant rules of Categories structures are heavily dependent
+ * on the fact that rules are stored in the same order they are entered.
+ * since i-th rule and i-th label are entered at the same time, we
+ * know that i-th rule maps fp range to i, thus we know for sure
+ * that cats.labels[i] corresponds to i-th quant rule
+#include <string.h>
+static void get_cond(char **, char *, DCELL);
+static int get_fmt(char **, char *, int *);
+static int cmp(const void *, const void *);
+static int write_cats(const char *element, const char *name, struct Categories *cats);
+static CELL read_cats(const char *element,
+		      const char *name,
+		      const char *mapset, struct Categories * pcats, int full);
+static struct Categories save_cats;
+ * \brief Read raster category file
+ * \todo Remove, the function Rast_read_raster_cats()
+ * The category file for raster map <i>name</i> in <i>mapset</i> is
+ * read into the <i>cats</i> structure. If there is an error reading
+ * the category file, a diagnostic message is printed and -1 is
+ * returned. Otherwise, 0 is returned.
+ * \param name map name
+ * \param mapset mapset name
+ * \param[out] cats pointer to Cats structure
+ * \return -1 on error
+ * \return 0 on success
+int Rast_read_cats(const char *name,
+		const char *mapset, struct Categories *pcats)
+    return Rast_read_raster_cats(name, mapset, pcats);
+int Rast_read_raster_cats(const char *name,
+    char *type;
+    switch (read_cats("cats", name, mapset, pcats, 1)) {
+    case -2:
+	type = "missing";
+	break;
+    case -1:
+	type = "invalid";
+	break;
+    default:
+	return 0;
+    G_warning(_("Category support for <%s@%s> %s"),
+	      name, mapset, type);
+    return -1;
+ * \brief Read vector category file
+ * <b>Note:</b> This function works with <b>old</b> vector format.
+ * The category file for vector map <i>name</i> in <i>mapset</i> is
+int Rast_read_vector_cats(const char *name,
+    char *type;
+    switch (read_cats("dig_cats", name, mapset, pcats, 1)) {
+    case -2:
+	type = "missing";
+	break;
+    case -1:
+	type = "invalid";
+	break;
+    default:
+	return 0;
+    G_warning(_("Category support for vector map <%s@%s> %s"),
+    return -1;
+  \brief Get number of categories
+  \param name map name
+  \param mapset mapset name
+  \return -1 on error
+  \return number of cats
+CELL Rast_number_of_cats(const char *name, const char *mapset)
+    CELL min, max;
+    /* return the max category number */
+    if (Rast_read_range(name, mapset, &range) < 0)
+	return -1;
+    if (Rast_is_c_null_value(&max))
+	max = 0;
+    return max;
+		      const char *name,
+    FILE *fd;
+    char buff[1024];
+    CELL cat;
+    DCELL val1, val2;
+    int old = 0, fp_map;
+    long num = -1;
+    if (strncmp(element, "dig", 3) == 0)
+	fp_map = 0;
+    else
+	fp_map = Rast_raster_map_is_fp(name, mapset);
+    if (!(fd = G_fopen_old(element, name, mapset)))
+	return -2;
+    /* Read the number of categories */
+    if (G_getl(buff, sizeof buff, fd) == 0)
+	goto error;
+    if (sscanf(buff, "# %ld", &num) == 1)
+	old = 0;
+    else if (sscanf(buff, "%ld", &num) == 1)
+	old = 1;
+    if (!full) {
+	fclose(fd);
+	if (num < 0)
+	    return 0;		/* coorect */
+	return (CELL) num;
+    /* Read the title for the file */
+	goto error;
+    G_strip(buff);
+    /*    G_ascii_check(buff) ; */
+    Rast_init_raster_cats(buff, pcats);
+    if (num >= 0)
+	pcats->num = num;
+    if (!old) {
+	char fmt[256];
+	float m1, a1, m2, a2;
+	if (G_getl(fmt, sizeof fmt, fd) == 0)
+	    goto error;
+	/* next line contains equation coefficients */
+	    goto error;
+	if (sscanf(buff, "%f %f %f %f", &m1, &a1, &m2, &a2) != 4)
+	    goto error;
+	Rast_set_raster_cats_fmt(fmt, m1, a1, m2, a2, pcats);
+    /* Read all category names */
+    for (cat = 0;; cat++) {
+	char label[1024];
+	    break;
+	if (old)
+	    Rast_set_cat(cat, buff, pcats);
+	else {
+	    *label = 0;
+	    if (sscanf(buff, "%1s", label) != 1)
+		continue;
+	    if (*label == '#')
+		continue;
+	    *label = 0;
+	    /* for fp maps try to read a range of data */
+	    if (fp_map
+		&& sscanf(buff, "%lf:%lf:%[^\n]", &val1, &val2, label) == 3)
+		Rast_set_raster_cat(&val1, &val2, label, pcats, DCELL_TYPE);
+	    else if (sscanf(buff, "%d:%[^\n]", &cat, label) >= 1)
+		Rast_set_raster_cat(&cat, &cat, label, pcats, CELL_TYPE);
+	    else if (sscanf(buff, "%lf:%[^\n]", &val1, label) >= 1)
+		Rast_set_raster_cat(&val1, &val1, label, pcats, DCELL_TYPE);
+	    else
+		goto error;
+    fclose(fd);
+    return 0;
+  error:
+    fclose(fd);
+    return -1;
+ * \brief Get title from category structure struct
+ * \todo Remove from GIS Library, replace by Rast_get_raster_cats_title().
+ * Map layers store a one-line title in the category structure as
+ * well. This routine returns a pointer to the title contained in the
+ * <i>cats</i> structure. A legal pointer is always returned. If the
+ * map layer does not have a title, then a pointer to the empty string
+ * "" is returned.
+ * \param cats pointer to Categories structure
+ * \return title
+ * \return "" if missing
+char *Rast_get_cats_title(const struct Categories *pcats)
+    return Rast_get_raster_cats_title(pcats);
+ * \brief Get raster cats title
+ * Returns pointer to a string with title.
+ * \param pcats pointer to Categories structure
+ * \return title
+char *Rast_get_raster_cats_title(const struct Categories *pcats)
+    return pcats->title ? pcats->title : "";
+ * \brief Get a raster category label
+ * \todo Remove from GIS Library, replaced by Rast_get_c_raster_cat().
+ * This routine looks up category <i>num</i> in the <i>pcats</i>
+ * structure and returns a pointer to a string which is the label for
+ * the category. A legal pointer is always returned. If the category
+ * does not exist in <i>pcats</i>, then a pointer to the empty string
+ * "" is returned.
+ * <b>Warning:</b> The pointer that is returned points to a hidden
+ * static buffer. Successive calls to Rast_get_cat() overwrite this
+ * buffer.
+ * \param num cell value
+ * \return pointer to category label
+ * \return "" if category is not found
+char *Rast_get_cat(CELL num, struct Categories *pcats)
+    return Rast_get_c_raster_cat(&num, pcats);
+ * \brief Get a raster category label (CELL)
+ * This routine looks up category <i>rast</i> in the <i>pcats</i>
+ * "" is returned.
+ * buffer.
+ * \param rast cell value
+char *Rast_get_c_raster_cat(CELL * rast, struct Categories *pcats)
+    return Rast_get_raster_cat(rast, pcats, CELL_TYPE);
+ * \brief Get a raster category label (FCELL)
+ * "" is returned.
+ * buffer.
+char *Rast_get_f_raster_cat(FCELL * rast, struct Categories *pcats)
+    return Rast_get_raster_cat(rast, pcats, FCELL_TYPE);
+ * \brief Get a raster category label (DCELL)
+ * "" is returned.
+ * buffer.
+char *Rast_get_d_raster_cat(DCELL * rast, struct Categories *pcats)
+    return Rast_get_raster_cat(rast, pcats, DCELL_TYPE);
+ * "" is returned.
+ * buffer.
+ * \param data_type map type (CELL, FCELL, DCELL)
+char *Rast_get_raster_cat(void *rast,
+		       struct Categories *pcats, RASTER_MAP_TYPE data_type)
+    static char label[1024];
+    char *f, *l, *v;
+    CELL i;
+    DCELL val;
+    float a[2];
+    char fmt[30], value_str[30];
+    if (Rast_is_null_value(rast, data_type)) {
+	sprintf(label, "no data");
+	return label;
+    /* first search the list of labels */
+    *label = 0;
+    val = Rast_get_raster_value_d(rast, data_type);
+    i = Rast_quant_get_cell_value(&pcats->q, val);
+    G_debug(5, "Rast_get_raster_cat(): val %lf found i %d", val, i);
+    if (!Rast_is_c_null_value(&i) && i < pcats->ncats) {
+	if (pcats->labels[i] != NULL)
+	    return pcats->labels[i];
+	return label;
+    /* generate the label */
+    if ((f = pcats->fmt) == NULL)
+	return label;
+    a[0] = (float)val *pcats->m1 + pcats->a1;
+    a[1] = (float)val *pcats->m2 + pcats->a2;
+    l = label;
+    while (*f) {
+	if (*f == '$') {
+	    f++;
+	    if (*f == '$')
+		*l++ = *f++;
+	    else if (*f == '?') {
+		f++;
+		get_cond(&f, v = value_str, val);
+		while (*v)
+		    *l++ = *v++;
+	    else if (get_fmt(&f, fmt, &i)) {
+		sprintf(v = value_str, fmt, a[i]);
+		while (*v)
+		    *l++ = *v++;
+	    else
+		*l++ = '$';
+	else {
+	    *l++ = *f++;
+    *l = 0;
+    return label;
+ * \brief Sets marks for all categories to 0.
+ * This initializes Categories structure for subsequest calls to
+ * Rast_mark_raster_cats() for each row of data, where non-zero mark for
+ * i-th label means that some of the cells in rast_row are labeled
+ * with i-th label and fall into i-th data range. These marks help
+ * determine from the Categories structure which labels were used and
+ * which weren't.
+void Rast_unmark_raster_cats(struct Categories *pcats)
+    int i;
+    for (i = 0; i < pcats->ncats; i++)
+	pcats->marks[i] = 0;
+ * \brief Looks up the category label for each raster value (CELL).
+ * Looks up the category label for each raster value in the
+ * <i>rast_row</i> and updates the marks for labels found.
+ * <b>Note:</b> Non-zero mark for i-th label stores the number of of
+ * raster cells read so far which are labeled with i-th label and fall
+ * into i-th data range.
+ * \param rast_row raster row to update stats
+ * \param ncols number of columns
+void Rast_mark_c_raster_cats(const CELL * rast_row,
+			  int ncols, struct Categories *pcats)
+    Rast_mark_raster_cats(rast_row, ncols, pcats, CELL_TYPE);
+ * \brief Looks up the category label for each raster value (FCELL).
+void Rast_mark_f_raster_cats(const FCELL * rast_row,
+    Rast_mark_raster_cats(rast_row, ncols, pcats, FCELL_TYPE);
+ * \brief Looks up the category label for each raster value (DCELL).
+void Rast_mark_d_raster_cats(const DCELL * rast_row,
+    Rast_mark_raster_cats(rast_row, ncols, pcats, DCELL_TYPE);
+ * \return 1 on success
+int Rast_mark_raster_cats(const void *rast_row,
+		       int ncols, struct Categories *pcats,
+		       RASTER_MAP_TYPE data_type)
+    CELL i;
+    while (ncols-- > 0) {
+				   Rast_get_raster_value_d(rast_row, data_type));
+	if (Rast_is_c_null_value(&i))
+	    continue;
+	if (i > pcats->ncats)
+	    return -1;
+	pcats->marks[i]++;
+	rast_row = Rast_incr_void_ptr(rast_row, Rast_raster_size(data_type));
+    return 1;
+ * \brief Rewind raster categories
+ * After call to this function Rast_get_next_marked_raster_cat() returns
+ * the first marked cat label.
+void Rast_rewind_raster_cats(struct Categories *pcats)
+    pcats->last_marked_rule = -1;
+  \brief Get next marked raster categories (DCELL)
+  \param pcats pointer to Categories structure
+  \param rast1, rast2 cell values (raster range)
+  \param[out] count count
+  \return NULL if not found
+  \return description if found
+char *Rast_get_next_marked_d_raster_cat(struct Categories *pcats,
+				     DCELL * rast1, DCELL * rast2,
+				     long *count)
+    char *descr = NULL;
+    int found, i;
+    found = 0;
+    /* pcats->ncats should be == Rast_quant_nof_rules(&pcats->q) */
+    G_debug(3, "last marked %d nrules %d\n", pcats->last_marked_rule, Rast_quant_nof_rules(&pcats->q));
+    for (i = pcats->last_marked_rule + 1; i < Rast_quant_nof_rules(&pcats->q); i++) {
+	descr = Rast_get_ith_d_raster_cat(pcats, i, rast1, rast2);
+	G_debug(5, "%d %d", i, pcats->marks[i]);
+	if (pcats->marks[i]) {
+	    found = 1;
+	    break;
+    if (!found)
+	return NULL;
+    *count = pcats->marks[i];
+    pcats->last_marked_rule = i;
+    return descr;
+  \brief Get next marked raster categories (CELL)
+char *Rast_get_next_marked_c_raster_cat(struct Categories *pcats,
+				     CELL * rast1, CELL * rast2,
+				     long *count)
+    return Rast_get_next_marked_raster_cat(pcats, rast1, rast2, count,
+					CELL_TYPE);
+  \brief Get next marked raster categories (FCELL)
+char *Rast_get_next_marked_f_raster_cat(struct Categories *pcats,
+				     FCELL * rast1, FCELL * rast2,
+				     long *count)
+					FCELL_TYPE);
+  \param data_type map type
+char *Rast_get_next_marked_raster_cat(struct Categories *pcats,
+				   void *rast1, void *rast2,
+				   long *count, RASTER_MAP_TYPE data_type)
+    DCELL val1, val2;
+    char *lab;
+    lab = Rast_get_next_marked_d_raster_cat(pcats, &val1, &val2, count);
+    Rast_set_raster_value_d(rast1, val1, data_type);
+    Rast_set_raster_value_d(rast2, val2, data_type);
+    return lab;
+static int get_fmt(char **f, char *fmt, int *i)
+    char *ff;
+    ff = *f;
+    if (*ff == 0)
+	return 0;
+    if (*ff == '$') {
+	*f = ff + 1;
+	return 0;
+    switch (*ff++) {
+    case '1':
+	*i = 0;
+	break;
+    case '2':
+	*i = 1;
+	break;
+    default:
+	return 0;
+    *fmt++ = '%';
+    *fmt++ = '.';
+    if (*ff++ != '.') {
+	*f = ff - 1;
+	*fmt++ = '0';
+	*fmt++ = 'f';
+	*fmt = 0;
+	return 1;
+    *fmt = '0';
+    while (*ff >= '0' && *ff <= '9')
+	*fmt++ = *ff++;
+    *fmt++ = 'f';
+    *fmt = 0;
+    *f = ff;
+    return 1;
+static void get_cond(char **f, char *value, DCELL val)
+    char *ff;
+    ff = *f;
+    if (val == 1.) {
+	while (*ff)
+	    if (*ff++ == '$')
+		break;
+    while (*ff)
+	if (*ff == '$') {
+	    ff++;
+	    break;
+	else
+	    *value++ = *ff++;
+    if (val != 1.) {
+	while (*ff)
+	    if (*ff++ == '$')
+		break;
+    *value = 0;
+    *f = ff;
+ * \brief Set a raster category label
+ * \todo To be removed, replaced by Rast_set_c_raster_cat().
+ * The <i>label</i> is copied into the <i>pcats</i> structure for
+ * category <i>num</i>.
+ * \param num raster cell
+ * \param label category label
+ * \return 0 if null value detected
+int Rast_set_cat(CELL num, const char *label, struct Categories *pcats)
+    return Rast_set_c_raster_cat(&num, &num, label, pcats);
+ * \brief Set a raster category label (CELL)
+ * Adds the label for range <i>rast1</i> through <i>rast2</i> in
+ * category structure <i>pcats</i>.
+ * \param rast1, rast2 raster values (range)
+int Rast_set_c_raster_cat(const CELL * rast1, const CELL * rast2,
+		       const char *label, struct Categories *pcats)
+    return Rast_set_raster_cat(rast1, rast2, label, pcats, CELL_TYPE);
+ * \brief Set a raster category label (FCELL)
+ * \return
+int Rast_set_f_raster_cat(const FCELL * rast1, const FCELL * rast2,
+    return Rast_set_raster_cat(rast1, rast2, label, pcats, FCELL_TYPE);
+ * \brief Set a raster category label (DCELL)
+int Rast_set_d_raster_cat(const DCELL * rast1, const DCELL * rast2,
+    long len;
+    DCELL dtmp1, dtmp2;
+    int i;
+    char *descr;
+    /* DEBUG fprintf(stderr,"Rast_set_d_raster_cat(rast1 = %p,rast2 = %p,label = '%s',pcats = %p)\n",
+       rast1,rast2,label,pcats); */
+    if (Rast_is_d_null_value(rast1))
+	return 0;
+    if (Rast_is_d_null_value(rast2))
+	return 0;
+    /* DEBUG fprintf (stderr, "Rast_set_d_raster_cat(): adding quant rule: %f %f %d %d\n", *rast1, *rast2, pcats->ncats, pcats->ncats); */
+    /* the set_cat() functions are used in many places to reset the labels
+       for the range (or cat) with existing label. In this case we don't
+       want to store both rules with identical range even though the result
+       of get_cat() will be correct, since it will use rule added later.
+       we don't want to overuse memory and we don't want rules which are
+       not used to be writen out in cats file. So we first look if
+       the label for this range has been sen, and if it has, overwrite it */
+    for (i = 0; i < pcats->ncats; i++) {
+	descr = Rast_get_ith_d_raster_cat(pcats, i, &dtmp1, &dtmp2);
+	if ((dtmp1 == *rast1 && dtmp2 == *rast2)
+	    || (dtmp1 == *rast2 && dtmp2 == *rast1)) {
+		G_free(pcats->labels[i]);
+	    pcats->labels[i] = G_store(label);
+	    G_newlines_to_spaces(pcats->labels[i]);
+	    G_strip(pcats->labels[i]);
+	    return 1;
+    /* when rule for this range does not exist */
+    /* DEBUG fprintf (stderr, "Rast_set_d_raster_cat(): New rule: adding %d %p\n", i, pcats->labels); */
+    Rast_quant_add_rule(&pcats->q, *rast1, *rast2, pcats->ncats, pcats->ncats);
+    pcats->ncats++;
+    if (pcats->nalloc < pcats->ncats) {
+	/* DEBUG fprintf (stderr, "Rast_set_d_raster_cat(): need more space nalloc = %d ncats = %d\n", pcats->nalloc,pcats->ncats); */
+	len = (pcats->nalloc + 256) * sizeof(char *);
+	/* DEBUG fprintf (stderr, "Rast_set_d_raster_cat(): allocating %d labels(%d)\n", pcats->nalloc + 256,(int)len); */
+	if (len != (int)len) {	/* make sure len doesn't overflow int */
+	    pcats->ncats--;
+	    return -1;
+	/* DEBUG fprintf(stderr,"Rast_set_d_raster_cat(): pcats->nalloc = %d, pcats->labels = (%p), len = %d\n",pcats->nalloc,pcats->labels,(int)len); */
+	if (pcats->nalloc) {
+	    /* DEBUG fprintf(stderr,"Rast_set_d_raster_cat(): Realloc-ing pcats->labels (%p)\n",pcats->labels); */
+	    pcats->labels =
+		(char **)G_realloc((char *)pcats->labels, (int)len);
+	else {
+	    /* DEBUG fprintf(stderr,"Rast_set_d_raster_cat(): alloc-ing new labels pointer array\n"); */
+	    pcats->labels = (char **)G_malloc((int)len);
+	/* fflush(stderr); */
+	/* DEBUG fprintf (stderr, "Rast_set_d_raster_cats(): allocating %d marks(%d)\n", pcats->nalloc + 256,(int)len); */
+	len = (pcats->nalloc + 256) * sizeof(int);
+	    pcats->ncats--;
+	    return -1;
+	    pcats->marks = (int *)G_realloc((char *)pcats->marks, (int)len);
+	else
+	    pcats->marks = (int *)G_malloc((int)len);
+	pcats->nalloc += 256;
+    /* DEBUG fprintf(stderr,"Rast_set_d_raster_cats(): store new label\n"); */
+    pcats->labels[pcats->ncats - 1] = G_store(label);
+    G_newlines_to_spaces(pcats->labels[pcats->ncats - 1]);
+    G_strip(pcats->labels[pcats->ncats - 1]);
+    /* DEBUG
+       fprintf (stderr, "%d %s\n", pcats->ncats - 1, pcats->labels[pcats->ncats - 1]);
+    /* updates cats.num = max cat values. This is really just used in old
+       raster programs, and I am doing it for backwards cmpatibility (Olga) */
+    if ((CELL) * rast1 > pcats->num)
+	pcats->num = (CELL) * rast1;
+    if ((CELL) * rast2 > pcats->num)
+	pcats->num = (CELL) * rast2;
+    /* DEBUG fprintf(stderr,"Rast_set_d_raster_cat(): done\n"); */
+    /* DEBUG fflush(stderr); */
+    return 1;
+int Rast_set_raster_cat(const void *rast1, const void *rast2,
+    DCELL val1, val2;
+    val1 = Rast_get_raster_value_d(rast1, data_type);
+    val2 = Rast_get_raster_value_d(rast2, data_type);
+    return Rast_set_d_raster_cat(&val1, &val2, label, pcats);
+ * \brief Write raster category file
+ * \todo To be removed, replaced by Rast_write_raster_cats().
+ * Writes the category file for the raster map <i>name</i> in the
+ * current mapset from the <i>cats</i> structure.
+ * \return -1 is returned (no diagnostic is printed)
+int Rast_write_cats(const char *name, struct Categories *cats)
+    return write_cats("cats", name, cats);
+int Rast_write_raster_cats(const char *name, struct Categories *cats)
+ * \brief Write vector category file
+ * <b>Note:</b> Used for only old vector format!
+int Rast_write_vector_cats(const char *name, struct Categories *cats)
+    return write_cats("dig_cats", name, cats);
+    FILE *fd;
+    int i, fp_map;
+    char *descr;
+    DCELL val1, val2;
+    char str1[100], str2[100];
+    if (!(fd = G_fopen_new(element, name)))
+	return -1;
+    /* write # cats - note # indicate 3.0 or later */
+    fprintf(fd, "# %ld categories\n", (long)cats->num);
+    /* title */
+    fprintf(fd, "%s\n", cats->title != NULL ? cats->title : "");
+    /* write format and coefficients */
+    fprintf(fd, "%s\n", cats->fmt != NULL ? cats->fmt : "");
+    fprintf(fd, "%.2f %.2f %.2f %.2f\n",
+	    cats->m1, cats->a1, cats->m2, cats->a2);
+    /* if the map is integer or if this is a vector map, sort labels */
+	fp_map = 0;
+    else
+	fp_map = Rast_raster_map_is_fp(name, G_mapset());
+    if (!fp_map)
+	Rast_sort_cats(cats);
+    /* write the cat numbers:label */
+    for (i = 0; i < Rast_quant_nof_rules(&cats->q); i++) {
+	descr = Rast_get_ith_d_raster_cat(cats, i, &val1, &val2);
+	if ((cats->fmt && cats->fmt[0])
+	    || (descr && descr[0])) {
+	    if (val1 == val2) {
+		sprintf(str1, "%.10f", val1);
+		G_trim_decimal(str1);
+		fprintf(fd, "%s:%s\n", str1, descr != NULL ? descr : "");
+	    else {
+		sprintf(str2, "%.10f", val2);
+		G_trim_decimal(str2);
+		fprintf(fd, "%s:%s:%s\n", str1, str2,
+			descr != NULL ? descr : "");
+    fclose(fd);
+    return (1);
+ * \brief Get category description (DCELL)
+ * Returns i-th description and i-th data range from the list of
+ * category descriptions with corresponding data ranges. end points of
+ * data interval in <i>rast1</i> and <i>rast2</i>.
+ * \param i index
+ * \return "" on error
+ * \return pointer to category description
+char *Rast_get_ith_d_raster_cat(const struct Categories *pcats,
+			     int i, DCELL * rast1, DCELL * rast2)
+    int index;
+    if (i > pcats->ncats) {
+	Rast_set_d_null_value(rast1, 1);
+	Rast_set_d_null_value(rast2, 1);
+	return "";
+    Rast_quant_get_ith_rule(&pcats->q, i, rast1, rast2, &index, &index);
+    return pcats->labels[index];
+ * \brief Get category description (FCELL)
+ * \param i index
+char *Rast_get_ith_f_raster_cat(const struct Categories *pcats,
+			     int i, void *rast1, void *rast2)
+    RASTER_MAP_TYPE data_type = FCELL_TYPE;
+    char *tmp;
+    DCELL val1, val2;
+    tmp = Rast_get_ith_d_raster_cat(pcats, i, &val1, &val2);
+    return tmp;
+ * \brief Get category description (CELL)
+ * \param i index
+char *Rast_get_ith_c_raster_cat(const struct Categories *pcats,
+    RASTER_MAP_TYPE data_type = CELL_TYPE;
+    char *tmp;
+    DCELL val1, val2;
+    return tmp;
+ * \param i index
+char *Rast_get_ith_raster_cat(const struct Categories *pcats, int i, void *rast1,
+			   void *rast2, RASTER_MAP_TYPE data_type)
+    char *tmp;
+    DCELL val1, val2;
+    return tmp;
+ * \brief Initialize category structure
+ * To construct a new category file, the structure must first be
+ * initialized. This routine initializes the <i>cats</i> structure,
+ * and copies the <i>title</i> into the structure. The number of
+ * categories is set initially to <i>n</i>.
+ * For example:
+ \code
+ struct Categories cats;
+ Rast_init_cats ((CELL)0, * "", &cats);
+ \endcode
+ * \param num raster value
+ * \param title title
+void Rast_init_cats(CELL num, const char *title, struct Categories *pcats)
+    Rast_init_raster_cats(title, pcats);
+    pcats->num = num;
+ * Same as existing Rast_init_raster_cats() only ncats argument is
+ * missign. ncats has no meaning in new Categories structure and only
+ * stores (int) largets data value for backwards compatibility.
+void Rast_init_raster_cats(const char *title, struct Categories *pcats)
+    Rast_set_raster_cats_title(title, pcats);
+    pcats->labels = NULL;
+    pcats->nalloc = 0;
+    pcats->ncats = 0;
+    pcats->num = 0;
+    pcats->fmt = NULL;
+    pcats->m1 = 0.0;
+    pcats->a1 = 0.0;
+    pcats->m2 = 0.0;
+    pcats->a2 = 0.0;
+    Rast_quant_init(&pcats->q);
+ * \brief Set title in category structure
+ * \todo To be removed, replaced by Rast_set_raster_cats_title().
+ * The <i>title</i> is copied into the <i>pcats</i> structure.
+void Rast_set_cats_title(const char *title, struct Categories *pcats)
+void Rast_set_raster_cats_title(const char *title, struct Categories *pcats)
+    if (title == NULL)
+	title = "";
+    pcats->title = G_store(title);
+    G_newlines_to_spaces(pcats->title);
+    G_strip(pcats->title);
+  \brief Set category fmt (?)
+  \todo To be removed, replaced by Rast_set_raster_cats_fmt().
+  \param fmt
+  \param m1,
+  \param a1,m2,a2
+void Rast_set_cats_fmt(const char *fmt, double m1, double a1, double m2,
+		    double a2, struct Categories *pcats)
+  \param fmt
+  \param m1,
+  \param a1,m2,a2
+void Rast_set_raster_cats_fmt(const char *fmt, double m1, double a1, double m2,
+    pcats->m1 = m1;
+    pcats->a1 = a1;
+    pcats->m2 = m2;
+    pcats->a2 = a2;
+    pcats->fmt = G_store(fmt);
+    G_newlines_to_spaces(pcats->fmt);
+    G_strip(pcats->fmt);
+ * \brief Free category structure memory
+ * \todo To be removed, replaced by Rast_free_raster_cats().
+ * Frees memory allocated by Rast_read_cats(), Rast_init_cats() and
+ * Rast_set_cat().
+void Rast_free_cats(struct Categories *pcats)
+    Rast_free_raster_cats(pcats);
+ * Rast_set_cat().
+void Rast_free_raster_cats(struct Categories *pcats)
+    int i;
+    if (pcats->title != NULL) {
+	G_free(pcats->title);
+	pcats->title = NULL;
+    if (pcats->fmt != NULL) {
+	G_free(pcats->fmt);
+    if (pcats->ncats > 0) {
+	G_free(pcats->labels);
+	G_free(pcats->marks);
+    Rast_quant_free(&pcats->q);
+    pcats->ncats = 0;
+ * \brief Copy raster categories
+ * Allocates NEW space for quant rules and labels n <i>pcats_to</i>
+ * and copies all info from <i>pcats_from</i> cats to
+ * <i>pcats_to</i> cats.
+ * \param pcats_to pointer to destination Categories structure
+ * \param pcats_from pointer to source Categories structure
+void Rast_copy_raster_cats(struct Categories *pcats_to,
+			const struct Categories *pcats_from)
+    int i;
+    char *descr;
+    DCELL d1, d2;
+    Rast_init_raster_cats(pcats_from->title, pcats_to);
+    for (i = 0; i < pcats_from->ncats; i++) {
+	descr = Rast_get_ith_d_raster_cat(pcats_from, i, &d1, &d2);
+	Rast_set_d_raster_cat(&d1, &d2, descr, pcats_to);
+  \brief Get number of raster categories
+  \return number of categories
+int Rast_number_of_raster_cats(struct Categories *pcats)
+    return pcats->ncats;
+  \brief Sort categories
+  \return -1 on error (nothing to sort)
+  \return 0 on success
+int Rast_sort_cats(struct Categories *pcats)
+    int *indexes, i, ncats;
+    char *descr;
+    DCELL d1, d2;
+    if (pcats->ncats <= 1)
+	return -1;
+    ncats = pcats->ncats;
+    G_debug(3, "Rast_sort_cats(): Copying to save cats buffer");
+    Rast_copy_raster_cats(&save_cats, pcats);
+    indexes = (int *)G_malloc(sizeof(int) * ncats);
+    for (i = 0; i < ncats; i++)
+	indexes[i] = i;
+    qsort(indexes, ncats, sizeof(int), cmp);
+    Rast_init_raster_cats(save_cats.title, pcats);
+    for (i = 0; i < ncats; i++) {
+	descr = Rast_get_ith_d_raster_cat(&save_cats, indexes[i], &d1, &d2);
+	G_debug(4, "  Write sorted cats, pcats = %p pcats->labels = %p",
+		pcats, pcats->labels);
+	Rast_set_d_raster_cat(&d1, &d2, descr, pcats);
+    Rast_free_raster_cats(&save_cats);
+    return 0;
+static int cmp(const void *aa, const void *bb)
+    const int *a = aa, *b = bb;
+    DCELL min_rast1, min_rast2, max_rast1, max_rast2;
+    CELL index;
+    Rast_quant_get_ith_rule(&(save_cats.q), *a,
+			 &min_rast1, &max_rast1, &index, &index);
+    Rast_quant_get_ith_rule(&(save_cats.q), *b,
+			 &min_rast2, &max_rast2, &index, &index);
+    if (min_rast1 < min_rast2)
+	return -1;
+    if (min_rast1 > min_rast2)
+	return 1;
+    return 0;
Copied: grass/trunk/lib/raster/cell_stats.c (from rev 37989, grass/trunk/lib/gis/cell_stats.c)
--- grass/trunk/lib/raster/cell_stats.c	                        (rev 0)
+++ grass/trunk/lib/raster/cell_stats.c	2009-06-20 22:03:23 UTC (rev 38003)
@@ -0,0 +1,392 @@
+ * \file gis/cell_stats.c
+ * \brief GIS Library - Raster cell statistics
+ * (C) 2001-2009 GRASS Development Team
+#include <grass/Rast.h>
+#define INCR 10
+#define SHIFT 6
+static const int NCATS = 1 << SHIFT;
+#define NODE struct Cell_stats_node
+static int next_node(struct Cell_stats *);
+static void init_node(NODE *, int, int);
+ * \brief Initialize cell stats
+ * This routine, which must be called first, initializes the
+ * Cell_stats structure.
+ * Set the count for NULL-values to zero.
+ * \param s pointer to Cell_stats structure
+void Rast_init_cell_stats(struct Cell_stats *s)
+    s->N = 0;
+    s->tlen = INCR;
+    s->node = (NODE *) G_malloc(s->tlen * sizeof(NODE));
+    s->null_data_count = 0;
+ * \brief Sdd data to cell stats
+ * The <i>n</i> CELL values in the <i>data</i> array are inserted (and
+ * counted) in the Cell_stats structure.
+ * Look for NULLs and update the NULL-value count.
+ * \param cell raster values
+ * \param n number of values
+ * \param s pointer to Cell_stats structure which holds cell stats info
+ * \return 1 on failure
+int Rast_update_cell_stats(const CELL * cell, int n, struct Cell_stats *s)
+    CELL cat;
+    int p, q;
+    int idx, offset;
+    int N;
+    NODE *node, *pnode;
+    NODE *new_node;
+    if (n <= 0)
+	return 1;
+    node = s->node;
+    /* first non-null node is special case */
+    if ((N = s->N) == 0) {
+	cat = *cell++;
+	while (Rast_is_c_null_value(&cat)) {
+	    s->null_data_count++;
+	    cat = *cell++;
+	    n--;
+	if (n > 0) {		/* if there are some non-null cells */
+	    N = 1;
+	    if (cat < 0) {
+		idx = -((-cat) >> SHIFT) - 1;
+		offset = cat + ((-idx) << SHIFT) - 1;
+	    else {
+		idx = cat >> SHIFT;
+		offset = cat - (idx << SHIFT);
+	    fflush(stderr);
+	    init_node(&node[1], idx, offset);
+	    node[1].right = 0;
+	    n--;
+    while (n-- > 0) {
+	cat = *cell++;
+	if (Rast_is_c_null_value(&cat)) {
+	    continue;
+	if (cat < 0) {
+	else {
+	q = 1;
+	while (q > 0) {
+	    pnode = &node[p = q];
+	    if (pnode->idx == idx) {
+		pnode->count[offset]++;
+		break;
+	    if (pnode->idx > idx)
+		q = pnode->left;	/* go left */
+	    else
+		q = pnode->right;	/* go right */
+	if (q > 0)
+	    continue;		/* found */
+	/* new node */
+	N++;
+	/* grow the tree? */
+	if (N >= s->tlen) {
+	    node =
+		(NODE *) G_realloc((char *)node,
+				   sizeof(NODE) * (s->tlen += INCR));
+	    pnode = &node[p];	/* realloc moves node, must reassign pnode */
+	/* add node to tree */
+	init_node(new_node = &node[N], idx, offset);
+	if (pnode->idx > idx) {
+	    new_node->right = -p;	/* create thread */
+	    pnode->left = N;	/* insert left */
+	else {
+	    new_node->right = pnode->right;	/* copy right link/thread */
+	    pnode->right = N;	/* add right */
+    }				/* while n-- > 0 */
+    s->N = N;
+    s->node = node;
+    return 0;
+static void init_node(NODE * node, int idx, int offset)
+    long *count;
+    int i;
+    count = node->count = (long *)G_calloc(i = NCATS, sizeof(long));
+    while (i--)
+	*count++ = 0;
+    node->idx = idx;
+    node->count[offset] = 1;
+    node->left = 0;
+ * \brief Random query of cell stats
+ * This routine allows a random query of the Cell_stats structure. The
+ * <i>count</i> associated with the raster value <i>cat</i> is
+ * set. The routine returns 1 if <i>cat<i> was found in the
+ * structure, 0 otherwise.
+ * Allow finding the count for the NULL-value.
+ * \param cat raster value
+ * \param[out] count count
+ * \return 1 if found
+ * \return 0 if not found
+int Rast_find_cell_stat(CELL cat, long *count, const struct Cell_stats *s)
+    int q;
+    int idx;
+    int offset;
+    *count = 0;
+	*count = s->null_data_count;
+	return (*count != 0);
+    if (s->N <= 0)
+	return 0;
+       if (cat < 0)
+       idx = -(-cat/NCATS) - 1;
+       offset = cat - idx*NCATS - 1;
+       else
+       idx = cat/NCATS;
+       offset = cat - idx*NCATS;
+    if (cat < 0) {
+    else {
+    q = 1;
+    while (q > 0) {
+	if (s->node[q].idx == idx) {
+	    *count = s->node[q].count[offset];
+	if (s->node[q].idx > idx)
+	    q = s->node[q].left;	/* go left */
+	else
+	    q = s->node[q].right;	/* go right */
+    return 0;
+ * \brief Reset/rewind cell stats
+ * The structure <i>s</i> is rewound (i.e., positioned at the first
+ * raster category) so that sorted sequential retrieval can begin.
+ * \return 0
+int Rast_rewind_cell_stats(struct Cell_stats *s)
+    int q;
+    if (s->N <= 0)
+	return 1;
+    /* start at root and go all the way to the left */
+    s->curp = 1;
+    while ((q = s->node[s->curp].left))
+	s->curp = q;
+    s->curoffset = -1;
+    return 0;
+static int next_node(struct Cell_stats *s)
+    int q;
+    /* go to the right */
+    s->curp = s->node[s->curp].right;
+    if (s->curp == 0)		/* no more */
+	return 0;
+    if (s->curp < 0) {		/* thread. stop here */
+	s->curp = -(s->curp);
+	return 1;
+    while ((q = s->node[s->curp].left))	/* now go all the way left */
+	s->curp = q;
+    return 1;
+ * \brief Retrieve sorted cell stats
+ * Retrieves the next <i>cat, count</i> combination from the
+ * structure. Returns 0 if there are no more items, non-zero if there
+ * are more. For example:
+ \code
+ struct Cell_stats s;
+ CELL cat;
+ long count;
+ // updating <b>s</b> occurs here
+ Rast_rewind_cell_stats(&s);
+ while (Rast_next_cell_stat(&cat,&count,&s)
+ fprintf(stdout, "%ld %ld\n", (long) cat, count);
+ \endcode
+ * Do not return a record for the NULL-value
+ * \return 0 if there are no more items
+ * \return non-zero if there are more
+int Rast_next_cell_stat(CELL * cat, long *count, struct Cell_stats *s)
+    int idx;
+    /* first time report stats for null */
+    /* decided not to return stats for null in this function
+       static int null_reported = 0;
+       if(!null_reported && s->null_data_count > 0)
+       Rast_set_c_null_value(&cat,1);
+       null_reported = 1;
+       return 1;
+    if (s->N <= 0)
+	return 0;
+    for (;;) {
+	s->curoffset++;
+	if (s->curoffset >= NCATS) {
+	    if (!next_node(s))
+		return 0;
+	    continue;
+	if ((*count = s->node[s->curp].count[s->curoffset])) {
+	    idx = s->node[s->curp].idx;
+	       if (idx < 0)
+	       *cat = idx*NCATS + s->curoffset+1;
+	       else
+	       *cat = idx*NCATS + s->curoffset;
+	    if (idx < 0)
+		*cat = -((-idx) << SHIFT) + s->curoffset + 1;
+	    else
+		*cat = (idx << SHIFT) + s->curoffset;
+	    return 1;
+ * \brief Get number of null values.
+ * Get a number of null values from stats structure.
+ * Note: when reporting values which appear in a map using
+ * Rast_next_cell_stats(), to get stats for null, call
+ * Rast_get_stats_for_null_value() first, since Rast_next_cell_stats() does
+ * not report stats for null.
+ * \param count count
+void Rast_get_stats_for_null_value(long *count, const struct Cell_stats *s)
+ * \brief Free cell stats structure
+ * The memory associated with structure <i>s</i> is freed. This
+ * routine may be called any time after calling Rast_init_cell_stats().
+void Rast_free_cell_stats(struct Cell_stats *s)
+    int i;
+    for (i = 1; i <= s->N; i++)
+	G_free(s->node[i].count);
+    G_free(s->node);
Copied: grass/trunk/lib/raster/cell_title.c (from rev 37989, grass/trunk/lib/gis/cell_title.c)
--- grass/trunk/lib/raster/cell_title.c	                        (rev 0)
+++ grass/trunk/lib/raster/cell_title.c	2009-06-20 22:03:23 UTC (rev 38003)
@@ -0,0 +1,50 @@
+ * char *Rast_get_cell_title (name, mapset)
+ *   char *name        name of map file
+ *   char *mapset      mapset containing name
+ *   returns pointer to string containing cell title. (from cats file)
+ * \brief get raster map title
+ * If only the map layer title is needed, it is not necessary to read the
+ * entire category file into memory. This routine gets the title for raster map
+ * <b>name</b> in <b>mapset</b> directly from the category file, and returns
+ * a pointer to the title. A legal pointer is always returned. If the map layer
+ * does not have a title, then a pointer to the empty string "" is returned.
+ *  \param name
+ *  \param mapset
+ *  \return char *
+char *Rast_get_cell_title(const char *name, const char *mapset)
+    FILE *fd;
+    int stat;
+    char title[1024];
+    stat = -1;
+    fd = G_fopen_old("cats", name, mapset);
+    if (fd) {
+	stat = 1;
+	if (!fgets(title, sizeof title, fd))	/* skip number of cats */
+	    stat = -1;
+	else if (!G_getl(title, sizeof title, fd))	/* read title */
+	    stat = -1;
+	fclose(fd);
+    if (stat < 0)
+	*title = 0;
+    else
+	G_strip(title);
+    return G_store(title);
Copied: grass/trunk/lib/raster/cellstats_eq.c (from rev 37989, grass/trunk/lib/gis/cellstats_eq.c)
--- grass/trunk/lib/raster/cellstats_eq.c	                        (rev 0)
+++ grass/trunk/lib/raster/cellstats_eq.c	2009-06-20 22:03:23 UTC (rev 38003)
@@ -0,0 +1,76 @@
+int Rast_cell_stats_histo_eq(struct Cell_stats *statf, CELL min1, CELL max1,	/* input range to be rescaled */
+			  CELL min2, CELL max2,	/* output range */
+			  int zero,	/* include zero if min1 <= 0 <= min2 ? */
+			  void (*func) (CELL, CELL, CELL))
+    long count, total;
+    CELL prev = 0;
+    CELL cat;
+    CELL x;
+    CELL newcat = 0;
+    int first;
+    double span, sum;
+    double range2;
+    if (min1 > max1 || min2 > max2)
+	return 0;
+    total = 0;
+    Rast_rewind_cell_stats(statf);
+    while (Rast_next_cell_stat(&cat, &count, statf)) {
+	if (cat < min1)
+	    continue;
+	if (cat > max1)
+	    break;
+	if (cat == 0 && !zero)
+	    continue;
+	total += count;
+    if (total <= 0)
+	return 0;
+    range2 = max2 - min2 + 1;
+    span = total / range2;
+    first = 1;
+    sum = 0;
+	if (cat < min1)
+	    continue;
+	if (cat > max1)
+	    break;
+	    continue;
+	x = (sum + (count / 2.0)) / span;
+	if (x < 0)
+	    x = 0;
+	x += min2;
+	sum += count;
+	if (first) {
+	    prev = cat;
+	    newcat = x;
+	    first = 0;
+	else if (newcat != x) {
+	    func(prev, cat - 1, newcat);
+	    newcat = x;
+	    prev = cat;
+    if (!first) {
+	func(prev, cat, newcat);
+	if (!zero && min1 <= 0 && max1 >= 0)
+	    func((CELL) 0, (CELL) 0, (CELL) 0);
+    return first == 0;
Copied: grass/trunk/lib/raster/closecell.c (from rev 37989, grass/trunk/lib/gis/closecell.c)
--- grass/trunk/lib/raster/closecell.c	                        (rev 0)
+++ grass/trunk/lib/raster/closecell.c	2009-06-20 22:03:23 UTC (rev 38003)
@@ -0,0 +1,505 @@
+ * \file gis/closecell.c
+ * \brief GIS Library - Close raster file
+ * (C) 1999-2009 by the GRASS Development Team
+ * License (>=v2). Read the file COPYING that comes with GRASS
+ * for details.
+ * \author USACERL and many others
+#ifdef __MINGW32__
+#  include <windows.h>
+#endif
+#include <stdio.h>
+#include <unistd.h>
+#include <fcntl.h>
+#include <signal.h>
+#include <grass/glocale.h>
+#include "G.h"
+#define FORMAT_FILE "f_format"
+#define QUANT_FILE  "f_quant"
+#define NULL_FILE   "null"
+static int close_old(int);
+static int close_new(int, int);
+static int write_fp_format(int fd);
+ * \brief Close a raster map
+ * The raster map opened on file descriptor <i>fd</i> is
+ * closed. Memory allocated for raster processing is freed. If open
+ * for writing, skeletal support files for the new raster map are
+ * created as well.
+ * <b>Note:</b> If a module wants to explicitly write support files
+ * (e.g., a specific color table) for a raster map it creates, it must
+ * do so after the raster map is closed. Otherwise the close will
+ * overwrite the support files. See \ref
+ * Raster_Map_Layer_Support_Routines for routines which write raster
+ * support files.
+ * If the map is a new floating point, move the <tt>.tmp</tt> file
+ * into the <tt>fcell</tt> element, create an empty file in the
+ * <tt>cell</tt> directory; write the floating-point range file; write
+ * a default quantization file quantization file is set here to round
+ * fp numbers (this is a default for now). create an empty category
+ * file, with max cat = max value (for backwards compatibility). Move
+ * the <tt>.tmp</tt> NULL-value bitmap file to the <tt>cell_misc</tt>
+ * directory.
+ * \param fd file descriptor
+int Rast_close_cell(int fd)
+    struct fileinfo *fcb = &G__.fileinfo[fd];
+    if (fd < 0 || fd >= G__.fileinfo_count || fcb->open_mode <= 0)
+	return -1;
+    if (fcb->open_mode == OPEN_OLD)
+	return close_old(fd);
+    return close_new(fd, 1);
+ * \brief Unopen a raster map
+ * for writing, the raster map is not created and the temporary file
+ * created when the raster map was opened is removed (see \ref
+ * Creating_and_Opening_New_Raster_Files). This routine is useful when
+ * errors are detected and it is desired to not create the new raster
+ * map. While it is true that the raster map will not be created if
+ * the module exits without closing the file, the temporary file will
+ * not be removed at module exit. GRASS database management will
+ * eventually remove the temporary file, but the file can be quite
+ * large and will take up disk space until GRASS does remove it. Use
+ * this routine as a courtesy to the user.
+int Rast_unopen_cell(int fd)
+	return -1;
+    else
+	return close_new(fd, 0);
+static int close_old(int fd)
+    int i;
+    /* if G__.auto_mask was only allocated for reading map rows to create
+       non-existant null rows, and not for actuall mask, free G__.mask_row
+       if(G__.auto_mask <=0)
+       G_free (G__.mask_buf);
+       This is obsolete since now the mask_bus is always allocated
+    if (fcb->gdal)
+	Rast_close_gdal_link(fcb->gdal);
+    for (i = 0; i < NULL_ROWS_INMEM; i++)
+	G_free(fcb->NULL_ROWS[i]);
+    if (fcb->cellhd.compressed)
+	G_free(fcb->row_ptr);
+    G_free(fcb->col_map);
+    G_free(fcb->mapset);
+    G_free(fcb->data);
+    G_free(fcb->name);
+    if (fcb->reclass_flag)
+	Rast_free_reclass(&fcb->reclass);
+    fcb->open_mode = -1;
+    if (fcb->map_type != CELL_TYPE) {
+	Rast_quant_free(&fcb->quant);
+	xdr_destroy(&fcb->xdrstream);
+    close(fd);
+    return 1;
+static void write_support_files(int fd)
+    struct History hist;
+    CELL cell_min, cell_max;
+    char path[GPATH_MAX];
+    /* remove color table */
+    Rast_remove_colors(fcb->name, "");
+    /* create a history file */
+    Rast_short_history(fcb->name, "raster", &hist);
+    Rast_write_history(fcb->name, &hist);
+    /* write the range */
+    if (fcb->map_type == CELL_TYPE) {
+	Rast_write_range(fcb->name, &fcb->range);
+	Rast__remove_fp_range(fcb->name);
+    /*NOTE: int range for floating point maps is not written out */
+    else {			/* if(fcb->map_type != CELL_TYPE) */
+	Rast_write_fp_range(fcb->name, &fcb->fp_range);
+	Rast_construct_default_range(&fcb->range);
+	/* this range will be used to add default rule to quant structure */
+	fcb->cellhd.format = -1;
+    else			/* CELL map */
+	fcb->cellhd.format = fcb->nbytes - 1;
+    /* write header file */
+    Rast_put_cellhd(fcb->name, &fcb->cellhd);
+    /* if map is floating point write the quant rules, otherwise remove f_quant */
+	/* DEFAULT RANGE QUANT
+	   Rast_get_fp_range_min_max(&fcb->fp_range, &dcell_min, &dcell_max);
+	   if(!Rast_is_d_null_value(&dcell_min) && !Rast_is_d_null_value(&dcell_max))
+	   Rast_get_range_min_max(&fcb->range, &cell_min, &cell_max);
+	   Rast_quant_add_rule(&fcb->quant, dcell_min, dcell_max,
+	   cell_min, cell_max);
+	Rast_quant_round(&fcb->quant);
+	if (Rast_write_quant(fcb->name, fcb->mapset, &fcb->quant) < 0)
+	    G_warning(_("unable to write quant file!"));
+    else {
+	/* remove cell_misc/name/f_quant */
+	G__file_name_misc(path, "cell_misc", QUANT_FILE, fcb->name,
+			  fcb->mapset);
+	remove(path);
+    /* create empty cats file */
+    if (Rast_is_c_null_value(&cell_max))
+	cell_max = 0;
+    Rast_init_cats(cell_max, (char *)NULL, &cats);
+    Rast_write_cats(fcb->name, &cats);
+    Rast_free_cats(&cats);
+    /* write the histogram */
+    /* only works for integer maps */
+    if ((fcb->map_type == CELL_TYPE)
+	&& (fcb->want_histogram)) {
+	Rast_write_histogram_cs(fcb->name, &fcb->statf);
+	Rast_free_cell_stats(&fcb->statf);
+    else {
+	Rast_remove_histogram(fcb->name);
+static int close_new_gdal(int fd, int ok)
+    int stat = 1;
+    if (ok) {
+	int cell_fd;
+	G_debug(1, "close %s GDAL", fcb->name);
+	if (fcb->cur_row < fcb->cellhd.rows) {
+	    int row;
+	    Rast_zero_raster_buf(fcb->data, fcb->map_type);
+	    for (row = fcb->cur_row; row < fcb->cellhd.rows; row++)
+		Rast_put_raster_row(fd, fcb->data, fcb->map_type);
+	    fcb->data = NULL;
+	/* create path : full null file name */
+	G__make_mapset_element_misc("cell_misc", fcb->name);
+	G__file_name_misc(path, "cell_misc", NULL_FILE, fcb->name,
+			  G_mapset());
+	remove(path);
+	/* write 0-length cell file */
+	G__make_mapset_element("cell");
+	G__file_name(path, "cell", fcb->name, fcb->mapset);
+	cell_fd = creat(path, 0666);
+	close(cell_fd);
+	if (fcb->map_type != CELL_TYPE) {	/* floating point map */
+	    if (write_fp_format(fd) != 0) {
+		G_warning(_("Error writing floating point format file for map %s"),
+			  fcb->name);
+		stat = -1;
+	    /* write 0-length fcell file */
+	    G__make_mapset_element("fcell");
+	    G__file_name(path, "fcell", fcb->name, fcb->mapset);
+	    close(cell_fd);
+	else {
+	    /* remove fcell/name file */
+	    remove(path);
+	    /* remove cell_misc/name/f_format */
+	    G__file_name_misc(path, "cell_misc", FORMAT_FILE, fcb->name,
+			      fcb->mapset);
+	    remove(path);
+	if (Rast_close_gdal_write_link(fcb->gdal) < 0)
+	    stat = -1;
+    else {
+	remove(fcb->gdal->filename);
+    /* NOW CLOSE THE FILE DESCRIPTOR */
+    close(fd);
+    if (fcb->data != NULL)
+    if (ok)
+	write_support_files(fd);
+    return stat;
+static int close_new(int fd, int ok)
+    int stat;
+    int row, i;
+    const char *CELL_DIR;
+    if (fcb->gdal)
+	return close_new_gdal(fd, ok);
+    if (ok) {
+	switch (fcb->open_mode) {
+	case OPEN_NEW_COMPRESSED:
+	    G_debug(1, "close %s compressed", fcb->name);
+	    break;
+	case OPEN_NEW_UNCOMPRESSED:
+	    G_debug(1, "close %s uncompressed", fcb->name);
+	    break;
+	    fcb->data = NULL;
+			  G_mapset());
+	remove(path);
+	if (fcb->null_cur_row > 0) {
+	    /* if temporary NULL file exists, write it into cell_misc/name/null */
+	    int null_fd;
+	    null_fd = Rast__open_null_write(fd);
+	    if (null_fd <= 0)
+		return -1;
+	    if (null_fd < 1)
+		return -1;
+	    /* first finish writing null file */
+	    /* write out the rows stored in memory */
+	    for (row = fcb->min_null_row; row < fcb->null_cur_row; row++)
+		Rast__write_null_bits(null_fd,
+				   fcb->NULL_ROWS[row - fcb->min_null_row],
+				   row, fcb->cellhd.cols, fd);
+	    /* write missing rows */
+	    if (fcb->null_cur_row < fcb->cellhd.rows) {
+		unsigned char *null_work_buf = Rast__allocate_null_bits(fcb->cellhd.cols);
+		Rast__init_null_bits(null_work_buf, fcb->cellhd.cols);
+		for (row = fcb->null_cur_row; row < fcb->cellhd.rows; row++)
+		    Rast__write_null_bits(null_fd, null_work_buf, row,
+				       fcb->cellhd.cols, fd);
+		G_free(null_work_buf);
+	    close(null_fd);
+	    if (rename(fcb->null_temp_name, path)) {
+		G_warning(_("Unable to renae null file '%s'"),
+			  fcb->null_temp_name, path);
+		stat = -1;
+	    else {
+		remove(fcb->null_temp_name);
+	else {
+	    remove(path);
+	}			/* null_cur_row > 0 */
+	if (fcb->open_mode == OPEN_NEW_COMPRESSED) {	/* auto compression */
+	    fcb->row_ptr[fcb->cellhd.rows] = lseek(fd, 0L, SEEK_CUR);
+	    Rast__write_row_ptrs(fd);
+	    int cell_fd;
+		G_warning(_("Error writing floating point format file for map <%s>"),
+			  fcb->name);
+		stat = -1;
+	    /* now write 0-length cell file */
+	    cell_fd =
+		creat(G__file_name(path, "cell", fcb->name, fcb->mapset),
+		      0666);
+	    close(cell_fd);
+	    CELL_DIR = "fcell";
+	else {
+	    remove(path);
+			      fcb->mapset);
+	    remove(path);
+	    CELL_DIR = "cell";
+	    close(fd);
+    }				/* ok */
+    close(fd);
+    if (fcb->null_temp_name != NULL) {
+	G_free(fcb->null_temp_name);
+	fcb->null_temp_name = NULL;
+    /* if the cell file was written to a temporary file
+     * move this temporary file into the cell file
+     * if the move fails, tell the user, but go ahead and create
+     * the support files
+    stat = 1;
+    if (ok && (fcb->temp_name != NULL)) {
+	G__file_name(path, CELL_DIR, fcb->name, fcb->mapset);
+	remove(path);
+	if (rename(fcb->temp_name, path)) {
+	    G_warning(_("Unable to rename cell file '%s'"),
+		      fcb->temp_name, path);
+	    stat = -1;
+	else {
+	    remove(fcb->temp_name);
+    if (fcb->temp_name != NULL) {
+	G_free(fcb->temp_name);
+    if (ok)
+    return stat;
+/* returns 0 on success, 1 on failure */
+    struct Key_Value *format_kv;
+    int stat;
+	G_warning(_("unable to write f_format file for CELL maps"));
+	return 0;
+    format_kv = G_create_key_value();
+    if (fcb->map_type == FCELL_TYPE)
+	G_set_key_value("type", "float", format_kv);
+    else
+	G_set_key_value("type", "double", format_kv);
+    G_set_key_value("byte_order", "xdr", format_kv);
+	G_set_key_value("lzw_compression_bits", "-1", format_kv);
+    G__file_name_misc(path, "cell_misc", FORMAT_FILE, fcb->name, fcb->mapset);
+    G_write_key_value_file(path, format_kv, &stat);
+    G_free_key_value(format_kv);
+    return stat;
Copied: grass/trunk/lib/raster/color_compat.c (from rev 37989, grass/trunk/lib/gis/color_compat.c)
--- grass/trunk/lib/raster/color_compat.c	                        (rev 0)
+++ grass/trunk/lib/raster/color_compat.c	2009-06-20 22:03:23 UTC (rev 38003)
@@ -0,0 +1,315 @@
+ * \file gis/color_compat.c
+ * \brief GIS Library - Predefined color tables
+ * (C) 2007-2009 Glynn Clements and the GRASS Development Team
+ * This program is free software under the GNU General Public License
+ * (>=v2). Read the file COPYING that comes with GRASS for details.
+ * \author Glynn Clements <glynn at gclements.plus.com>
+#include <grass/gis.h>
+ * \brief Make color wave (integer)
+ * Generates a color table with 3 sections: red only, green only, and
+ * blue only, each increasing from none to full intensity and back
+ * down to none. This table is good for continuous data like
+ * elevation.
+ * \param colors pointer to Colors structure which holds color info
+ * \param min minimum value
+ * \param max maximum value
+void Rast_make_wave_colors(struct Colors *colors, CELL min, CELL max)
+    Rast_make_colors(colors, "wave", min, max);
+ * \brief Make color wave (floating-point)
+ * elevation.
+void Rast_make_wave_fp_colors(struct Colors *colors, DCELL min, DCELL max)
+    Rast_make_fp_colors(colors, "wave", min, max);
+ * \brief Create RYG color table (integer)
+ * Generates a color table red-yellow-green.
+void Rast_make_ryg_colors(struct Colors *colors, CELL min, CELL max)
+    Rast_make_colors(colors, "ryg", min, max);
+ * \brief Create RYG color table (floating-point)
+void Rast_make_ryg_fp_colors(struct Colors *colors, DCELL min, DCELL max)
+    Rast_make_fp_colors(colors, "ryg", min, max);
+ * \brief Make color ramp (integer)
+ * blue only, each increasing from none to full intensity. This table
+ * is good for continuous data, such as elevation.
+void Rast_make_ramp_colors(struct Colors *colors, CELL min, CELL max)
+    Rast_make_colors(colors, "ramp", min, max);
+ * \brief Make color ramp (floating-point)
+void Rast_make_ramp_fp_colors(struct Colors *colors, DCELL min, DCELL max)
+    Rast_make_fp_colors(colors, "ramp", min, max);
+ * \brief Make rainbow colors (integer)
+ * Generates a "shifted" rainbow color table - yellow to green to cyan
+ * to blue to magenta to red. The color table is based on rainbow
+ * colors. (Normal rainbow colors are red, orange, yellow, green,
+ * blue, indigo, and violet.) This table is good for continuous data,
+ * such as elevation.
+void Rast_make_rainbow_colors(struct Colors *colors, CELL min, CELL max)
+    Rast_make_colors(colors, "rainbow", min, max);
+ * \brief Make rainbow colors (floating-point)
+void Rast_make_rainbow_fp_colors(struct Colors *colors, DCELL min, DCELL max)
+    Rast_make_fp_colors(colors, "rainbow", min, max);
+ * \brief Create GYR color table (integer)
+ * Generates a color table green-yellow-red.
+void Rast_make_gyr_colors(struct Colors *colors, CELL min, CELL max)
+    Rast_make_colors(colors, "gyr", min, max);
+ * \brief Create GYR color table (floating-point)
+void Rast_make_gyr_fp_colors(struct Colors *colors, DCELL min, DCELL max)
+    Rast_make_fp_colors(colors, "gyr", min, max);
+ * \brief Make linear grey scale (integer)
+ * Generates a grey scale color table. Each color is a level of grey,
+ * increasing from black to white.
+void Rast_make_grey_scale_colors(struct Colors *colors, CELL min, CELL max)
+    Rast_make_colors(colors, "grey", min, max);
+ * \brief Make linear grey scale (floating-point)
+void Rast_make_grey_scale_fp_colors(struct Colors *colors, DCELL min, DCELL max)
+    Rast_make_fp_colors(colors, "grey", min, max);
+ * \brief Create BYR color table (integer)
+ * Generates a color table blue-yellow-red.
+void Rast_make_byr_colors(struct Colors *colors, CELL min, CELL max)
+    Rast_make_colors(colors, "byr", min, max);
+ * \brief Create BYR color table (floating-point)
+void Rast_make_byr_fp_colors(struct Colors *colors, DCELL min, DCELL max)
+    Rast_make_fp_colors(colors, "byr", min, max);
+ * \brief Create BGYR color table (integer)
+ * Generates a color table blue-green-yellow-red.
+void Rast_make_bgyr_colors(struct Colors *colors, CELL min, CELL max)
+    Rast_make_colors(colors, "bgyr", min, max);
+ * \brief Create BGYR color table (floating-point)
+void Rast_make_bgyr_fp_colors(struct Colors *colors, DCELL min, DCELL max)
+    Rast_make_fp_colors(colors, "bgyr", min, max);
+ * \brief Create BYG color table (integer)
+ * Generates a color table blue-yellow-green.
+void Rast_make_byg_colors(struct Colors *colors, CELL min, CELL max)
+    Rast_make_colors(colors, "byg", min, max);
+ * \brief Create BYG color table (floating-point)
+void Rast_make_byg_fp_colors(struct Colors *colors, DCELL min, DCELL max)
+    Rast_make_fp_colors(colors, "byg", min, max);
+ * \brief Make aspect colors (integer)
+ * Generates a color table for aspect data.
+void Rast_make_aspect_colors(struct Colors *colors, CELL min, CELL max)
+    Rast_make_colors(colors, "aspect", min, max);
+ * \brief Make aspect colors (floating-point)
+void Rast_make_aspect_fp_colors(struct Colors *colors, DCELL min, DCELL max)
+    Rast_make_fp_colors(colors, "aspect", min, max);
Copied: grass/trunk/lib/raster/color_free.c (from rev 37989, grass/trunk/lib/gis/color_free.c)
--- grass/trunk/lib/raster/color_free.c	                        (rev 0)
+++ grass/trunk/lib/raster/color_free.c	2009-06-20 22:03:23 UTC (rev 38003)
@@ -0,0 +1,105 @@
+ * \file gis/color_free.c
+ * \brief GIS Library - Free Colors structure
+ * (C) 2001-2009 by the GRASS Development Team
+ * \author Original author CERL
+ * \brief Free color structure memory
+ * The dynamically allocated memory associated with the <i>colors</i>
+ * structure is freed.
+ * <b>Note:</b> This routine may be used after Rast_read_colors() as well
+ * as after Rast_init_colors().
+void Rast_free_colors(struct Colors *colors)
+    Rast__color_reset(colors);
+    Rast_init_colors(colors);
+  \brief Free color rules structure
+  Note: Only for internal use.
+  \param cp pointer to _Color_Info structure
+void Rast__color_free_rules(struct _Color_Info_ *cp)
+    struct _Color_Rule_ *rule, *next;
+    for (rule = cp->rules; rule; rule = next) {
+	next = rule->next;
+	G_free(rule);
+    cp->rules = NULL;
+void Rast__color_free_lookup(struct _Color_Info_ *cp)
+    if (cp->lookup.active) {
+	G_free(cp->lookup.red);
+	G_free(cp->lookup.blu);
+	G_free(cp->lookup.grn);
+	G_free(cp->lookup.set);
+	cp->lookup.active = 0;
+void Rast__color_free_fp_lookup(struct _Color_Info_ *cp)
+    if (cp->fp_lookup.active) {
+	G_free(cp->fp_lookup.vals);
+	G_free(cp->fp_lookup.rules);
+	cp->fp_lookup.active = 0;
+	cp->fp_lookup.nalloc = 0;
+  \brief Reset colors structure
+  This routine should NOT init the colors.
+  \param colors pointer to Colors structure
+void Rast__color_reset(struct Colors *colors)
+    Rast__color_free_lookup(&colors->fixed);
+    Rast__color_free_lookup(&colors->modular);
+    Rast__color_free_rules(&colors->fixed);
+    Rast__color_free_rules(&colors->modular);
+    colors->version = 0;
Copied: grass/trunk/lib/raster/color_get.c (from rev 37989, grass/trunk/lib/gis/color_get.c)
--- grass/trunk/lib/raster/color_get.c	                        (rev 0)
+++ grass/trunk/lib/raster/color_get.c	2009-06-20 22:03:23 UTC (rev 38003)
@@ -0,0 +1,194 @@
+ * \file gis/color_get.c
+ * \brief GIS Library - Get colors from a raster map.
+ * \brief Get a category color.
+ * \todo To be removed, replaced by Rast_get_raster_color().
+ * The <i>red, green</i>, and <i>blue</i> intensities for the color
+ * associated with category <i>n</i> are extracted from the
+ * <i>colors</i> structure. The intensities will be in the range 0 ­-
+ * 255. Also works for null cells.
+ * \param n cell to get color from
+ * \param[out] red red value
+ * \param[out] grn green value
+ * \param[out] blu blue value
+ * \return 1 if color is set
+ * \return 0 if color is not set
+int Rast_get_color(CELL n, int *red, int *grn, int *blu, struct Colors *colors)
+    CELL cat;
+    unsigned char r, g, b, set;
+    cat = n;
+    Rast_lookup_colors(&cat, &r, &g, &b, &set, 1, colors);
+    *red = (int)r;
+    *grn = (int)g;
+    *blu = (int)b;
+    return (int)set;
+ * \brief Gets color from raster map
+ * Looks up the rgb colors for <i>rast</i> in the color table
+ * <i>colors</i>.
+ * \param rast raster cell value
+ * \param map_type map type (CELL, FCELL, DCELL)
+int Rast_get_raster_color(const void *rast,
+		       int *red, int *grn, int *blu,
+		       struct Colors *colors, RASTER_MAP_TYPE map_type)
+    Rast_lookup_raster_colors(rast, &r, &g, &b, &set, 1, colors, map_type);
+    *red = (int)r;
+    *grn = (int)g;
+    *blu = (int)b;
+    return (int)set;
+ * \brief Gets color from raster map (CELL)
+ * <i>colors</i>.
+int Rast_get_c_raster_color(const CELL * rast,
+			 int *red, int *grn, int *blu, struct Colors *colors)
+    return Rast_get_raster_color(rast, red, grn, blu, colors, CELL_TYPE);
+ * \brief Gets color from raster map (FCELL)
+ * <i>colors</i>.
+int Rast_get_f_raster_color(const FCELL * rast,
+    return Rast_get_raster_color(rast, red, grn, blu, colors, FCELL_TYPE);
+ * \brief Gets color from raster map (DCELL)
+ * <i>colors</i>.
+int Rast_get_d_raster_color(const DCELL * rast,
+    return Rast_get_raster_color(rast, red, grn, blu, colors, DCELL_TYPE);
+ * \brief Gets color for null value.
+ * Puts the red, green, and blue components of <i>colors</i> for the
+ * NULL-value into <i>red, grn, and blu</i>.
+void Rast_get_null_value_color(int *red, int *grn, int *blu,
+			   const struct Colors *colors)
+    if (colors->null_set) {
+	*red = (int)colors->null_red;
+	*grn = (int)colors->null_grn;
+	*blu = (int)colors->null_blu;
+    else if (colors->undef_set) {
+	*red = (int)colors->undef_red;
+	*grn = (int)colors->undef_grn;
+	*blu = (int)colors->undef_blu;
+    else
+	*red = *blu = *grn = 255;	/* white */
+ * \brief Gets default color.
+ * Puts the red, green, and blue components of the <tt>"default"</tt>
+ * color into <i>red, grn, and blu</i>.
+void Rast_get_default_color(int *red, int *grn, int *blu,
+    if (colors->undef_set) {
+    else
Copied: grass/trunk/lib/raster/color_hist.c (from rev 37989, grass/trunk/lib/gis/color_hist.c)
--- grass/trunk/lib/raster/color_hist.c	                        (rev 0)
+++ grass/trunk/lib/raster/color_hist.c	2009-06-20 22:03:23 UTC (rev 38003)
@@ -0,0 +1,157 @@
+ * \file gis/color_hist.c
+ * \brief GIS Library - histogram grey scale colors
+#include <math.h>
+ * \brief Make histogram-stretched grey colors
+ * Generates a histogram contrast-stretched grey scale color table
+ * that goes from the, histogram information in the Cell_stats
+ * structure (see \ref Raster_Histograms).
+ * Color range is 0-255.
+ * \param stalf pointer to Cell_stats structure which holds cell stats info
+void Rast_make_histogram_eq_colors(struct Colors *colors,
+				struct Cell_stats *statf)
+    CELL prev = 0, cat;
+    double span, sum;
+    int first;
+    int x, grey;
+    int R, G, B;
+    Rast_str_to_color(DEFAULT_BG_COLOR, &R, &G, &B);
+    Rast_set_null_value_color(R, G, B, colors);
+    total = 0;
+	if (count > 0)
+	    total += count;
+    if (total <= 0)
+	return;
+    span = total / 256.0;
+    first = 1;
+    grey = 0;
+    sum = 0.0;
+	if (count <= 0)
+	    continue;
+	if (x < 0)
+	    x = 0;
+	else if (x > 255)
+	    x = 255;
+	sum += count;
+	if (first) {
+	    prev = cat;
+	    grey = x;
+	    first = 0;
+	else if (grey != x) {
+	    Rast_add_color_rule(prev, grey, grey, grey, cat - 1, grey, grey,
+			     grey, colors);
+	    grey = x;
+	    prev = cat;
+    if (!first) {
+	Rast_add_color_rule(prev, grey, grey, grey, cat, grey, grey, grey,
+			 colors);
+  \brief Generates histogram with normalized log transformed grey scale.
+  Generates histogram with normalized log transformed grey scale from
+  cell stats structure info. Color range is 0-255.
+  \param colors pointer to Colors structure which holds color info
+  \param stalf pointer to Cell_stats structure which holds cell stats info
+  \param min minimum value
+  \param max maximum value
+void Rast_make_histogram_log_colors(struct Colors *colors,
+				 struct Cell_stats *statf, int min, int max)
+    double lmin, lmax;
+    int first;
+    int x, grey;
+    int R, G, B;
+    total = 0;
+	if (count > 0)
+	    total += count;
+    if (total <= 0)
+	return;
+    first = 1;
+    grey = 0;
+    lmin = log(min);
+    lmax = log(max);
+	if (count <= 0)
+	    continue;
+	/* log transform normalized */
+	x = (int)(255 * (log(cat) - lmin) / (lmax - lmin));
+	if (x < 0)
+	    x = 0;
+	else if (x > 255)
+	    x = 255;
+	if (first) {
+	    prev = cat;
+	    grey = x;
+	    first = 0;
+			     grey, colors);
+	    grey = x;
+	    prev = cat;
+    if (!first) {
+			 colors);
Copied: grass/trunk/lib/raster/color_init.c (from rev 37989, grass/trunk/lib/gis/color_init.c)
--- grass/trunk/lib/raster/color_init.c	                        (rev 0)
+++ grass/trunk/lib/raster/color_init.c	2009-06-20 22:03:23 UTC (rev 38003)
@@ -0,0 +1,49 @@
+ * \file gis/color_init.c
+ * \brief GIS Library - Initialize Colors structure
+ * \brief Initialize color structure
+ * The <i>colors</i> structure is initialized for subsequent calls
+ * to Rast_add_color_rule() and Rast_set_color().
+void Rast_init_colors(struct Colors *colors)
+    colors->null_set = 0;
+    colors->undef_set = 0;
+    colors->shift = 0.0;
+    colors->invert = 0;
+    colors->cmin = 0;
+    colors->is_float = 0;
+    colors->cmax = -1;
+    colors->fixed.min = 0;
+    colors->fixed.max = -1;
+    colors->fixed.rules = NULL;
+    colors->fixed.n_rules = 0;
+    colors->fixed.lookup.active = 0;
+    colors->fixed.fp_lookup.active = 0;
+    colors->fixed.fp_lookup.nalloc = 0;
+    colors->modular.min = 0;
+    colors->modular.max = -1;
+    colors->modular.rules = NULL;
+    colors->modular.n_rules = 0;
+    colors->modular.lookup.active = 0;
+    colors->modular.fp_lookup.active = 0;
+    colors->modular.fp_lookup.nalloc = 0;
+    colors->organizing = 0;
Copied: grass/trunk/lib/raster/color_insrt.c (from rev 37989, grass/trunk/lib/gis/color_insrt.c)
--- grass/trunk/lib/raster/color_insrt.c	                        (rev 0)
+++ grass/trunk/lib/raster/color_insrt.c	2009-06-20 22:03:23 UTC (rev 38003)
@@ -0,0 +1,108 @@
+/* This routine is public only because source is in different files.
+ * It should NEVER be called directly.
+ * It is used by Rast_add_color_rule() and G__read_old_colors().
+ * These routines know when it is approriate to call this routine.
+#define umalloc(n) (unsigned char *) G_malloc((size_t)n)
+#define urealloc(s,n) (unsigned char *) G_realloc(s,(size_t)n)
+#define LIMIT(x) if (x < 0) x = 0; else if (x > 255) x = 255;
+int Rast__insert_color_into_lookup(CELL cat,
+				int red, int grn, int blu,
+				struct _Color_Info_ *cp)
+    long nalloc;
+    long i;
+    long newlen, curlen, gap;
+    LIMIT(red);
+    LIMIT(grn);
+    LIMIT(blu);
+    /* first color? */
+    if (!cp->lookup.active) {
+	cp->lookup.active = 1;
+	cp->lookup.nalloc = 256;
+	cp->lookup.red = umalloc(cp->lookup.nalloc);
+	cp->lookup.grn = umalloc(cp->lookup.nalloc);
+	cp->lookup.blu = umalloc(cp->lookup.nalloc);
+	cp->lookup.set = umalloc(cp->lookup.nalloc);
+	cp->max = cp->min = cat;
+    /* extend the color table? */
+    else if (cat > cp->max) {
+	curlen = cp->max - cp->min + 1;
+	newlen = cat - cp->min + 1;
+	nalloc = newlen;
+	if (nalloc != (int)nalloc)	/* check for int overflow */
+	    return -1;
+	if (nalloc > cp->lookup.nalloc) {
+	    while (cp->lookup.nalloc < nalloc)
+		cp->lookup.nalloc += 256;
+	    nalloc = cp->lookup.nalloc;
+	    cp->lookup.red = urealloc((char *)cp->lookup.red, nalloc);
+	    cp->lookup.grn = urealloc((char *)cp->lookup.grn, nalloc);
+	    cp->lookup.blu = urealloc((char *)cp->lookup.blu, nalloc);
+	    cp->lookup.set = urealloc((char *)cp->lookup.set, nalloc);
+	/* fill in gap with white */
+	for (i = curlen; i < newlen; i++) {
+	    cp->lookup.red[i] = 255;
+	    cp->lookup.grn[i] = 255;
+	    cp->lookup.blu[i] = 255;
+	    cp->lookup.set[i] = 0;
+	cp->max = cat;
+    else if (cat < cp->min) {
+	newlen = cp->max - cat + 1;
+	gap = newlen - curlen;
+	nalloc = newlen;
+	    return -1;
+	/* shift the table to make room in front */
+	for (i = 1; i <= curlen; i++) {
+	    cp->lookup.red[newlen - i] = cp->lookup.red[curlen - i];
+	    cp->lookup.grn[newlen - i] = cp->lookup.grn[curlen - i];
+	    cp->lookup.blu[newlen - i] = cp->lookup.blu[curlen - i];
+	    cp->lookup.set[newlen - i] = cp->lookup.set[curlen - i];
+	for (i = 1; i < gap; i++) {
+	cp->min = cat;
+    /* set the color! */
+    i = cat - cp->min;
+    cp->lookup.red[i] = red;
+    cp->lookup.grn[i] = grn;
+    cp->lookup.blu[i] = blu;
+    cp->lookup.set[i] = 1;
+    return 1;
Copied: grass/trunk/lib/raster/color_invrt.c (from rev 37989, grass/trunk/lib/gis/color_invrt.c)
--- grass/trunk/lib/raster/color_invrt.c	                        (rev 0)
+++ grass/trunk/lib/raster/color_invrt.c	2009-06-20 22:03:23 UTC (rev 38003)
@@ -0,0 +1,6 @@
+void Rast_invert_colors(struct Colors *colors)
+    colors->invert = !colors->invert;
Copied: grass/trunk/lib/raster/color_look.c (from rev 37989, grass/trunk/lib/gis/color_look.c)
--- grass/trunk/lib/raster/color_look.c	                        (rev 0)
+++ grass/trunk/lib/raster/color_look.c	2009-06-20 22:03:23 UTC (rev 38003)
@@ -0,0 +1,477 @@
+ * \file gis/color_lookup.c
+ * \brief GIS Library - Lookup array of colors
+ * for details.
+#include <math.h>
+ * \brief Lookup an array of colors
+ * \todo To be removed, replaced by Rast_lookup_c_raster_colors().
+ * Extracts colors for an array of <i>cell</i> values. The colors
+ * for the <i>n</i> values in the <i>cell</i> array are stored in
+ * the <i>red, green</i>, and <i>blue</i> arrays. The values in the
+ * <i>set</i> array will indicate if the corresponding <i>cell</i>
+ * value has a color or not (1 means it does, 0 means it does not).
+ * The programmer must allocate the <i>red, green, blue</i>, and
+ * <b>set</b> arrays to be at least dimension <i>n</i>.
+ * <b>Note:</b> The <i>red, green</i>, and <i>blue</i> intensities
+ * will be in the range 0 -­ 255.
+ * Modified to return a color for NULL-values.
+ * \param cell raster cell value
+ * \param set array which indicates if color is set or not
+void Rast_lookup_colors(const CELL * cell,
+		     unsigned char *red, unsigned char *grn,
+		     unsigned char *blu, unsigned char *set, int n,
+		     struct Colors *colors)
+    Rast_lookup_c_raster_colors(cell, red, grn, blu, set, n, colors);
+void Rast_lookup_c_raster_colors(const CELL * cell,
+    Rast__organize_colors(colors);	/* make sure the lookup tables are in place */
+    G_zero((char *)set, n * sizeof(unsigned char));
+    /* first lookup the fixed colors */
+    Rast__lookup_colors((void *)cell, red, grn, blu, set, n, colors, 0, 0,
+		     CELL_TYPE);
+    /* now lookup unset colors using the modular rules */
+    Rast__lookup_colors((void *)cell, red, grn, blu, set, n, colors, 1, 0,
+		     CELL_TYPE);
+ * - If the <em>map_type</em> is CELL_TYPE, calls Rast_lookup_colors()
+ * - If the <em>map_type</em> is FCELL_TYPE, calls Rast_lookup_f_raster_colors()
+ * - If the <em>map_type</em> is DCELL_TYPE, calls Rast_lookup_d_raster_colors()
+ * \param raster raster cell value
+ * \param map_type raster type (CELL, FCELL, DCELL)
+void Rast_lookup_raster_colors(const void *raster,
+    /* in case of float color rules, fp_lookup table is created */
+    Rast__lookup_colors(raster, red, grn, blu, set, n, colors, 0, 0, map_type);
+    Rast__lookup_colors(raster, red, grn, blu, set, n, colors, 1, 0, map_type);
+ * \brief Lookup an array of colors (FCELL)
+ * Converts the <em>n</em> floating-point values in the <em>fcell</em>
+ * array to their <em>r,g,b</em> color components. Embedded
+ * NULL-values are handled properly as well.
+ * \param fcell raster cell value
+void Rast_lookup_f_raster_colors(const FCELL * fcell, unsigned char *red,
+			      unsigned char *grn, unsigned char *blu,
+			      unsigned char *set, int n, struct Colors *colors)
+    Rast__lookup_colors((void *)fcell, red, grn, blu, set, n, colors, 0, 0,
+		     FCELL_TYPE);
+    Rast__lookup_colors((void *)fcell, red, grn, blu, set, n, colors, 1, 0,
+		     FCELL_TYPE);
+ * \brief Lookup an array of colors (DCELL)
+ * Converts the <em>n</em> double-precision values in the
+ * <em>dcell</em> array to their <em>r,g,b</em> color
+ * components. Embedded NULL-values are handled properly as well.
+ * \param dcell raster cell value
+void Rast_lookup_d_raster_colors(const DCELL * dcell, unsigned char *red,
+    Rast__lookup_colors((void *)dcell, red, grn, blu, set, n, colors, 0, 0,
+		     DCELL_TYPE);
+    Rast__lookup_colors((void *)dcell, red, grn, blu, set, n, colors, 1, 0,
+		     DCELL_TYPE);
+static int less_or_equal(double x, double y)
+    if (x <= y)
+	return 1;
+    else
+	return 0;
+static int less(double x, double y)
+    if (x < y)
+	return 1;
+    else
+	return 0;
+ * \param mod
+ * \param rules_only
+ * \param data_type raster type (CELL, FCELL, DCELL)
+void Rast__lookup_colors(const void *raster, unsigned char *red,
+		      unsigned char *set, int n, struct Colors *colors,
+		      int mod, int rules_only, RASTER_MAP_TYPE data_type)
+    struct _Color_Info_ *cp;
+    struct _Color_Rule_ *rule;
+    DCELL dmin, dmax, val, dmod = 0L, shift;
+    CELL cat, min, max;
+    const void *ptr, *last_ptr = NULL;
+    int invert;
+    int found, r, g, b;
+    int cell_type;
+    int lookup, max_ind, min_ind, try;
+    int (*lower) ();
+    if (mod)
+	cp = &colors->modular;
+    else
+	cp = &colors->fixed;
+    /* rules_only will be true only when called by Rast__organize_colors()
+     * when building the integer lookup talbes from the rules,
+     * so do not shift, invert, use lookup table or modulate cats.
+     * these operations will happen when lookup is called by user code
+    /* we want min, max for cp, not min, max overall */
+    dmin = cp->min;
+    dmax = cp->max;
+    min = (CELL) dmin;
+    max = (CELL) dmax + 1;
+    cell_type = (data_type == CELL_TYPE);
+    if (rules_only) {
+	shift = invert = lookup = mod = 0;
+    else {
+	if (mod) {
+	    dmod = dmax - dmin;
+	    /* for integers color table we make a gap of 1 in order
+	       to make the same colors as before */
+	    if (cell_type)
+		dmod += 1;
+	shift = colors->shift;
+	invert = colors->invert;
+	lookup = cp->lookup.active;
+    ptr = raster;
+    for (; n-- > 0;
+	 ptr =
+	 Rast_incr_void_ptr(ptr, Rast_raster_size(data_type)), red++, grn++, blu++,
+	 *set++ = found) {
+	/* if the cell is the same as last one, use the prev color values */
+	if (ptr != raster && Rast_raster_cmp(ptr, last_ptr, data_type) == 0) {
+	    *red = *(red - 1);
+	    *blu = *(blu - 1);
+	    *grn = *(grn - 1);
+	    found = *(set - 1);
+	    last_ptr = ptr;
+	    continue;
+	val = Rast_get_raster_value_d(ptr, data_type);
+	/* DEBUG fprintf (stderr, "val: %.4lf\n", val); */
+	last_ptr = ptr;
+	if (*set) {
+	    found = 1;
+	    continue;
+	if (Rast_is_null_value(ptr, data_type)) {
+	    /* returns integers, not unsigned chars */
+	    Rast_get_null_value_color(&r, &g, &b, colors);
+	    *red = r;
+	    *grn = g;
+	    *blu = b;
+	    found = 1;
+	    continue;
+	if (shift && val >= dmin && val <= dmax) {
+	    val += shift;
+	    while (val < dmin)
+		val += dmax - dmin + 1;
+	    while (val > dmax)
+		val -= dmax - dmin + 1;
+	/* invert non-null data around midpoint of range [min:max] */
+	if (invert)
+	    val = dmin + dmax - val;
+	if (mod) {
+	    if (dmod > 0) {
+		val -= dmin;
+		while (val < 0)
+		    val += dmod;
+		val = val - dmod * floor(val / dmod);
+		val += dmin;
+	    else
+		val = dmin;
+	cat = (CELL) val;
+	found = 0;
+	/* for non-null integers  try to look them up in lookup table */
+	/* note: lookup table exists only for integer maps, and we also must
+	   check if val is really integer */
+	if (lookup && ((double)cat - val == 0.)) {
+	    if (cat >= min && cat <= max) {
+		cat -= min;
+		if (cp->lookup.set[cat]) {
+		    *red = cp->lookup.red[cat];
+		    *grn = cp->lookup.grn[cat];
+		    *blu = cp->lookup.blu[cat];
+		    found = 1;
+		    /*DEBUG
+		       fprintf (stderr, "lookup %d %.2lf %d %d %d\n\n", cat, val, *red, *grn, *blu);
+	if (found)
+	    continue;
+	/* if floating point lookup table is active, look up in there */
+	    try = (cp->fp_lookup.nalloc - 1) / 2;
+	    min_ind = 0;
+	    max_ind = cp->fp_lookup.nalloc - 2;
+	    while (1) {
+		/* when the rule for the interval is NULL, we exclude the end points.
+		   when it exists, we include the end-points */
+		if (cp->fp_lookup.rules[try])
+		    lower = less;
+		else
+		    lower = less_or_equal;
+		/* DEBUG
+		   fprintf (stderr, "%d %d %d %lf %lf %lf\n", min_ind, try, max_ind,
+		   cp->fp_lookup.vals[try-1],
+		   val,
+		   cp->fp_lookup.vals[try]);
+		if (lower(cp->fp_lookup.vals[try + 1], val)) {	/* recurse to the second half */
+		    min_ind = try + 1;
+		    /* must be still < nalloc-1, since number is within the range */
+		    try = (max_ind + min_ind) / 2;
+		    if (min_ind > max_ind) {
+			rule = NULL;
+			break;
+		    continue;
+		if (lower(val, cp->fp_lookup.vals[try])) {	/* recurse to the second half */
+		    max_ind = try - 1;
+		    /* must be still >= 0, since number is within the range */
+		    if (max_ind < min_ind) {
+			rule = NULL;
+			break;
+		    continue;
+		rule = cp->fp_lookup.rules[try];
+		break;
+	else {
+	    /* find the [low:high] rule that applies */
+	    for (rule = cp->rules; rule; rule = rule->next) {
+		/* DEBUG
+		   fprintf (stderr, "%.2lf %.2lf %.2lf\n",
+		   val, rule->low.value, rule->high.value);
+		if (rule->low.value <= val && val <= rule->high.value)
+		    break;
+	/* if found, perform linear interpolation from low to high.
+	 * else set colors to colors->undef or white if undef not set
+	if (rule) {
+	    Rast__interpolate_color_rule(val, red, grn, blu, rule);
+	    found = 1;
+	if (!found) {
+	    /* otherwise use default color */
+	    Rast_get_default_color(&r, &g, &b, colors);
+	    *red = r;
+	    *grn = g;
+	    *blu = b;
+	/* DEBUG
+	   if (rule)
+	   fprintf (stderr, "%.2lf %d %d %d   %.2lf %d %d %d \n", rule->low.value , (int)rule->low.red, (int)rule->low.grn, (int)rule->low.blu, rule->high.value, (int)rule->high.red, (int)rule->high.grn, (int)rule->high.blu);
+	   fprintf (stderr, "rule found %d %.2lf %d %d %d\n\n", cat, val, *red, *grn, *blu);
+  \brief Interpolate color rules
+  \param val raster cell value
+  \param[out] red red value
+  \param[out] grn green value
+  \param[out] blu blue value
+  \param rule pointer to _Color_Rule which holds color rules info
+void Rast__interpolate_color_rule(DCELL val, unsigned char *red,
+			       const struct _Color_Rule_ *rule)
+    DCELL delta;
+    if ((delta = rule->high.value - rule->low.value)) {
+	val -= rule->low.value;
+	*red =
+	    (int)(val * (double)((int)rule->high.red - (int)rule->low.red) /
+		  delta)
+	    + (int)rule->low.red;
+	*grn =
+	    (int)(val * (double)((int)rule->high.grn - (int)rule->low.grn) /
+		  delta)
+	    + (int)rule->low.grn;
+	*blu =
+	    (int)(val * (double)((int)rule->high.blu - (int)rule->low.blu) /
+		  delta)
+	    + (int)rule->low.blu;
+    else {
+	*red = rule->low.red;
+	*grn = rule->low.grn;
+	*blu = rule->low.blu;
Copied: grass/trunk/lib/raster/color_org.c (from rev 37989, grass/trunk/lib/gis/color_org.c)
--- grass/trunk/lib/raster/color_org.c	                        (rev 0)
+++ grass/trunk/lib/raster/color_org.c	2009-06-20 22:03:23 UTC (rev 38003)
@@ -0,0 +1,147 @@
+#include <stdlib.h>
+#define LOOKUP_COLORS 2048
+static void organize_lookup(struct Colors *, int);
+static int organize_fp_lookup(struct Colors *, int);
+static int double_comp(const void *, const void *);
+void Rast__organize_colors(struct Colors *colors)
+    /* don't do anything if called recursively */
+    if (!colors->organizing) {
+	colors->organizing = 1;
+	organize_lookup(colors, 0);
+	organize_lookup(colors, 1);
+	organize_fp_lookup(colors, 0);
+	organize_fp_lookup(colors, 1);
+static int organize_fp_lookup(struct Colors *colors, int mod)
+    int i;
+    DCELL val;
+    if (mod)
+    else
+    /* if one of the lookup tables exist, don't do anything */
+    if (cp->lookup.active || cp->fp_lookup.active)
+	return 1;
+    if (cp->n_rules == 0)
+	return 1;
+    cp->fp_lookup.vals = (DCELL *)
+	G_calloc(cp->n_rules * 2, sizeof(DCELL));
+    /* 2 endpoints for each rule */
+    cp->fp_lookup.rules = (struct _Color_Rule_ **)
+	G_calloc(cp->n_rules * 2, sizeof(struct _Color_Rule_ *));
+    /* get the list of DCELL values from set of all lows and highs
+       of all rules */
+    /* NOTE: if low==high in a rule, the value appears twice in a list
+       but if low==high of the previous, rule the value appears only once */
+    i = 0;
+    /* go through the list of rules from end to beginning,
+       because rules are sored in reverse order of reading,
+       and we want to read the in correct order, to ignore
+       the same values in the end of rule and beginning of next rule */
+    /* first go to the last rules */
+    for (rule = cp->rules; rule->next; rule = rule->next) ;
+    /* now traverse from the last to the first rule */
+    for (; rule; rule = rule->prev) {
+	/* check if the min is the same as previous maximum */
+	if (i == 0 || rule->low.value != cp->fp_lookup.vals[i - 1])
+	    cp->fp_lookup.vals[i++] = rule->low.value;
+	cp->fp_lookup.vals[i++] = rule->high.value;
+    cp->fp_lookup.nalloc = i;
+    /* now sort the values */
+    qsort((char *)cp->fp_lookup.vals, cp->fp_lookup.nalloc,
+	  sizeof(DCELL), &double_comp);
+    /* now find the rule to apply inbetween each 2 values in a list */
+    for (i = 0; i < cp->fp_lookup.nalloc - 1; i++) {
+	val = (cp->fp_lookup.vals[i] + cp->fp_lookup.vals[i + 1]) / 2.;
+	/* fprintf (stderr, "%lf %lf ", cp->fp_lookup.vals[i], cp->fp_lookup.vals[i+1]); */
+		break;
+	/* if(rule) fprintf (stderr, "%d %lf %lf %d\n", i, rule->low.value, rule->high.value, rule);
+	   else fprintf (stderr, "null\n");
+	cp->fp_lookup.rules[i] = rule;
+    cp->fp_lookup.active = 1;
+    return 0;
+static void organize_lookup(struct Colors *colors, int mod)
+    int i, n;
+    CELL x;
+    CELL cat[LOOKUP_COLORS];
+    /* don't do anything if the color structure is float */
+    if (colors->is_float)
+	return;
+    if (mod)
+    else
+	return;
+    n = (CELL) cp->max - (CELL) cp->min + 1;
+    if (n >= LOOKUP_COLORS || n <= 0)
+	return;
+    x = (CELL) cp->min;
+    for (i = 0; i < n; i++)
+	cat[i] = x++;;
+    cp->lookup.nalloc = n;
+    cp->lookup.red = (unsigned char *)G_malloc(n);
+    cp->lookup.grn = (unsigned char *)G_malloc(n);
+    cp->lookup.blu = (unsigned char *)G_malloc(n);
+    cp->lookup.set = (unsigned char *)G_malloc(n);
+    G_zero(cp->lookup.set, n * sizeof(unsigned char));
+    Rast__lookup_colors((void *)cat,
+		     cp->lookup.red, cp->lookup.grn, cp->lookup.blu,
+		     cp->lookup.set, n, colors, mod, 1, CELL_TYPE);
+static int double_comp(const void *xx, const void *yy)
+    const DCELL *x = xx, *y = yy;
+    if (*x < *y)
+	return -1;
+    else if (*x == *y)
+	return 0;
+    else
+	return 1;
Copied: grass/trunk/lib/raster/color_rand.c (from rev 37989, grass/trunk/lib/gis/color_rand.c)
--- grass/trunk/lib/raster/color_rand.c	                        (rev 0)
+++ grass/trunk/lib/raster/color_rand.c	2009-06-20 22:03:23 UTC (rev 38003)
@@ -0,0 +1,49 @@
+#include <time.h>		/*  For time()  */
+#include <stdio.h>		/*  For NULL */
+#include <stdlib.h>		/*  For rand() and srand() */
+#define MAX_COLORS 1024
+#define DEVIATION 128
+ * \brief make random colors
+ * Generates random colors. Good as a first pass at a
+ * color table for nominal data.
+ *  \param colors
+ *  \param min
+ *  \param max
+ *  \return
+void Rast_make_random_colors(struct Colors *colors, CELL min, CELL max)
+    unsigned char red, grn, blu;
+    int count;
+    CELL n;
+    if (min > max)
+	G_fatal_error(_("Rast_make_random_colors: min (%d) > max (%d)"),
+		      min, max);
+    srand(time(NULL));
+    count = MAX_COLORS - DEVIATION + rand() % DEVIATION;
+    if (count > max - min + 1)
+	count = max - min + 1;
+    for (n = 1; n <= count; n++) {
+	red = rand() & 0377;
+	grn = rand() & 0377;
+	blu = rand() & 0377;
+	Rast_add_modular_color_rule(n, red, grn, blu, n, red, grn, blu, colors);
+    Rast_set_color_range(min, max, colors);
Copied: grass/trunk/lib/raster/color_range.c (from rev 37989, grass/trunk/lib/gis/color_range.c)
--- grass/trunk/lib/raster/color_range.c	                        (rev 0)
+++ grass/trunk/lib/raster/color_range.c	2009-06-20 22:03:23 UTC (rev 38003)
@@ -0,0 +1,93 @@
+ * \file gis/color_range.c
+ * \brief GIS Library - Color range functions.
+#include <math.h>
+  \brief Set color range (CELL version)
+  \todo Rename to G_set_c_color_range() ?
+  \param min,max minimum and maximum value
+void Rast_set_color_range(CELL min, CELL max, struct Colors *colors)
+    if (min < max) {
+	colors->cmin = (DCELL) min;
+	colors->cmax = (DCELL) max;
+    else {
+	colors->cmin = (DCELL) max;
+	colors->cmax = (DCELL) min;
+  \brief Set color range (DCELL version)
+void Rast_set_d_color_range(DCELL min, DCELL max, struct Colors *colors)
+    if (min < max) {
+	colors->cmin = min;
+	colors->cmax = max;
+    else {
+	colors->cmin = max;
+	colors->cmax = min;
+  \brief Get color range values (CELL)
+  \todo Rename to G_get_c_color_range() ?
+  Returns min and max category in the range or huge numbers if the
+  color table is defined on floating cell values and not on
+  categories.
+  \param[out] min,max minimum and maximum value
+void Rast_get_color_range(CELL * min, CELL * max, const struct Colors *colors)
+    if (!colors->is_float) {
+	*min = (CELL) floor(colors->cmin);
+	*max = (CELL) ceil(colors->cmax);
+    else {
+	*min = -255 * 255 * 255;
+	*max = 255 * 255 * 255;
+  \brief Get color range values (DELL)
+  categories.
+void Rast_get_d_color_range(DCELL * min, DCELL * max, const struct Colors *colors)
+    *min = colors->cmin;
+    *max = colors->cmax;
Copied: grass/trunk/lib/raster/color_read.c (from rev 37989, grass/trunk/lib/gis/color_read.c)
--- grass/trunk/lib/raster/color_read.c	                        (rev 0)
+++ grass/trunk/lib/raster/color_read.c	2009-06-20 22:03:23 UTC (rev 38003)
@@ -0,0 +1,391 @@
+ * \file gis/color_read.c
+ * \brief GIS Library - Read color table of raster map
+ * for details.
+#include <string.h>
+static int read_colors(const char *, const char *, const char *,
+		       struct Colors *);
+static int read_new_colors(FILE *, struct Colors *);
+static int read_old_colors(FILE *, struct Colors *);
+ * \brief Read raster map layer color table
+ * The color table for the raster map <i>name</i> in the specified
+ * <i>mapset</i> is read into the <i>colors</i> structure. If the data
+ * layer has no color table, a default color table is generated and 0
+ * is returned. If there is an error reading the color table, a
+ * diagnostic message is printed and -1 is returned. If the color
+ * table is read ok, 1 is returned.
+ * This routine reads the rules from the color file. If the input
+ * raster map is is a floating-point map it calls
+ * Rast_mark_colors_as_fp().
+ *  Note: If a secondary color file for map name <i>name</i> exists in
+ *  the current project, that color file is read.  This allows the
+ *  user to define their own color lookup tables for cell maps found
+ *  in other mapsets.
+ *  Warning message is printed if the color file is
+ *  missing or invalid.
+ * \param name map name
+ * \param mapset mapset name
+ * \param[out] colors pointer to Colors structure
+ * \return -1 on error
+ * \return 0 if missing, but default colors generated
+ * \return 1 on success
+int Rast_read_colors(const char *name, const char *mapset, struct Colors *colors)
+    int fp;
+    char buf[GNAME_MAX];
+    char *err;
+    char xname[GNAME_MAX];
+    struct Range range;
+    struct FPRange drange;
+    CELL min, max;
+    DCELL dmin, dmax;
+    fp = Rast_raster_map_is_fp(name, mapset);
+    strcpy(xname, name);
+    mapset = G_find_cell(xname, mapset);
+    name = xname;
+    if (fp)
+	Rast_mark_colors_as_fp(colors);
+    /* first look for secondary color table in current mapset */
+    sprintf(buf, "colr2/%s", mapset);
+    if (read_colors(buf, name, G_mapset(), colors) >= 0)
+	return 1;
+    /* now look for the regular color table */
+    switch (read_colors("colr", name, mapset, colors)) {
+    case -2:
+	if (!fp) {
+	    if (Rast_read_range(name, mapset, &range) >= 0) {
+		Rast_get_range_min_max(&range, &min, &max);
+		if (!Rast_is_c_null_value(&min) && !Rast_is_c_null_value(&max))
+		    Rast_make_rainbow_colors(colors, min, max);
+		return 0;
+	else {
+	    if (Rast_read_fp_range(name, mapset, &drange) >= 0) {
+		Rast_get_fp_range_min_max(&drange, &dmin, &dmax);
+		if (!Rast_is_d_null_value(&dmin) && !Rast_is_d_null_value(&dmax))
+		    Rast_make_rainbow_fp_colors(colors, dmin, dmax);
+		return 0;
+	err = _("missing");
+	break;
+    case -1:
+	err = _("invalid");
+	break;
+    default:
+	return 1;
+    G_warning(_("Color support for <%s@%s> %s"), name, mapset,
+	      err);
+    return -1;
+static int read_colors(const char *element, const char *name,
+		       const char *mapset, struct Colors *colors)
+    FILE *fd;
+    int stat;
+    char buf[1024];
+    if (!(fd = G_fopen_old(element, name, mapset)))
+	return -2;
+     * first line in 4.0 color files is %
+     * otherwise it is pre 4.0
+    if (fgets(buf, sizeof buf, fd) == NULL) {
+	fclose(fd);
+	return -1;
+    fseek(fd, 0L, 0);
+    G_strip(buf);
+    if (*buf == '%') {		/* 4.0 format */
+	stat = read_new_colors(fd, colors);
+	colors->version = 0;	/* 4.0 format */
+    else {
+	stat = read_old_colors(fd, colors);
+	colors->version = -1;	/* pre 4.0 format */
+    fclose(fd);
+    return stat;
+/* parse input lines with the following formats
+ *   val1:r:g:b val2:r:g:b
+ *   val:r:g:b          (implies cat1==cat2)
+ * r:g:b can be just a single grey level
+ *   cat1:x cat2:y
+ *   cat:x
+ * optional lines are
+ *    invert            invert color table
+ *    shift:n           where n is the amount to shift the color table
+ *    nv:r:g:b          color to use for NULL values
+ *    *:r:g:b           color to use for undefined (beyond color rules)
+static int read_new_colors(FILE * fd, struct Colors *colors)
+    double val1, val2;
+    long cat1, cat2;
+    int r1, g1, b1;
+    int r2, g2, b2;
+    char buf[1024];
+    char word1[256], word2[256];
+    int n, fp_rule;
+    int null, undef;
+    int modular;
+    DCELL shift;
+	return -1;
+    G_strip(buf);
+    if (sscanf(buf + 1, "%lf %lf", &val1, &val2) == 2)
+	Rast_set_d_color_range((DCELL) val1, (DCELL) val2, colors);
+    modular = 0;
+    while (fgets(buf, sizeof buf, fd)) {
+	null = undef = fp_rule = 0;
+	*word1 = *word2 = 0;
+	n = sscanf(buf, "%s %s", word1, word2);
+	if (n < 1)
+	    continue;
+	if (sscanf(word1, "shift:%lf", &shift) == 1
+	    || (strcmp(word1, "shift:") == 0 &&
+		sscanf(word2, "%lf", &shift) == 1)) {
+	    Rast_shift_d_colors(shift, colors);
+	    continue;
+	if (strcmp(word1, "invert") == 0) {
+	    Rast_invert_colors(colors);
+	    continue;
+	if (strcmp(word1, "%%") == 0) {
+	    modular = !modular;
+	    continue;
+	switch (sscanf(word1, "nv:%d:%d:%d", &r1, &g1, &b1)) {
+	case 1:
+	    null = 1;
+	    b1 = g1 = r1;
+	    break;
+	case 3:
+	    null = 1;
+	    break;
+	if (!null)
+	    switch (sscanf(word1, "*:%d:%d:%d", &r1, &g1, &b1)) {
+	    case 1:
+		undef = 1;
+		b1 = g1 = r1;
+		break;
+	    case 3:
+		undef = 1;
+		break;
+	if (!null && !undef)
+	    switch (sscanf(word1, "%ld:%d:%d:%d", &cat1, &r1, &g1, &b1)) {
+	    case 2:
+		b1 = g1 = r1;
+		break;
+	    case 4:
+		break;
+	    default:
+		if (sscanf(word1, "%lf:%d:%d:%d", &val1, &r1, &g1, &b1) == 4)
+		    fp_rule = 1;
+		else if (sscanf(word1, "%lf:%d", &val1, &r1) == 2) {
+		    fp_rule = 1;
+		    b1 = g1 = r1;
+		else
+		    continue;	/* other lines are ignored */
+	if (n == 2) {
+	    switch (sscanf(word2, "%ld:%d:%d:%d", &cat2, &r2, &g2, &b2)) {
+	    case 2:
+		b2 = g2 = r2;
+		if (fp_rule)
+		    val2 = (DCELL) cat2;
+		break;
+	    case 4:
+		if (fp_rule)
+		break;
+	    default:
+		if (sscanf(word2, "%lf:%d:%d:%d", &val2, &r2, &g2, &b2) == 4) {
+		    if (!fp_rule)
+			val1 = (DCELL) cat1;
+		    fp_rule = 1;
+		else if (sscanf(word2, "%lf:%d", &val2, &r2) == 2) {
+		    if (!fp_rule)
+		    fp_rule = 1;
+		    b2 = g2 = r2;
+		else
+	else {
+	    if (!fp_rule)
+		cat2 = cat1;
+	    else
+		val2 = val1;
+	    r2 = r1;
+	    g2 = g1;
+	    b2 = b1;
+	if (null)
+	    Rast_set_null_value_color(r1, g1, b1, colors);
+	else if (undef)
+	    Rast_set_default_color(r1, g1, b1, colors);
+	else if (modular) {
+	    if (fp_rule)
+		Rast_add_modular_d_raster_color_rule((DCELL *) & val1, r1, g1,
+						  b1, (DCELL *) & val2, r2,
+						  g2, b2, colors);
+	    else
+		Rast_add_modular_color_rule((CELL) cat1, r1, g1, b1,
+					 (CELL) cat2, r2, g2, b2, colors);
+	else {
+	    if (fp_rule)
+		Rast_add_d_raster_color_rule((DCELL *) & val1, r1, g1, b1,
+					  (DCELL *) & val2, r2, g2, b2,
+					  colors);
+	    else
+		Rast_add_color_rule((CELL) cat1, r1, g1, b1,
+	G_debug(3, "adding rule %d=%.2lf %d %d %d  %d=%.2lf %d %d %d",
+		cat1, val1,  r1, g1, b1, cat2, val2, r2, g2, b2);
+    return 1;
+static int read_old_colors(FILE * fd, struct Colors *colors)
+    char buf[256];
+    long n;
+    long min;
+    float red_f, grn_f, blu_f;
+    int red, grn, blu;
+    int old;
+    int zero;
+     * first line in pre 3.0 color files is number of colors - ignore
+     * otherwise it is #min first color, and the next line is for color 0
+	return -1;
+    G_strip(buf);
+    if (*buf == '#') {		/* 3.0 format */
+	old = 0;
+	if (sscanf(buf + 1, "%ld", &min) != 1)	/* first color */
+	    return -1;
+	zero = 1;
+    else {
+	old = 1;
+	min = 0;
+	zero = 0;
+    n = min;
+	if (old) {
+	    if (sscanf(buf, "%f %f %f", &red_f, &grn_f, &blu_f) != 3)
+		return -1;
+	    red = 256 * red_f;
+	    grn = 256 * grn_f;
+	    blu = 256 * blu_f;
+	else {
+	    switch (sscanf(buf, "%d %d %d", &red, &grn, &blu)) {
+	    case 1:
+		blu = grn = red;
+		break;
+	    case 2:
+		blu = grn;
+		break;
+	    case 3:
+		break;
+	    default:
+		return -1;
+	if (zero) {
+	    Rast__insert_color_into_lookup((CELL) 0, red, grn, blu,
+					&colors->fixed);
+	    zero = 0;
+	else
+	    Rast__insert_color_into_lookup((CELL) n++, red, grn, blu,
+					&colors->fixed);
+    colors->cmax = n - 1;
+    return 0;
+ * \brief Mark colors as floating-point.
+ * Sets a flag in the <i>colors</i> structure that indicates that
+ * these colors should only be looked up using floating-point raster
+ * data (not integer data). In particular if this flag is set, the
+ * routine Rast_get_colors_min_max() should return min=-255$^3$ and
+ * max=255$^3$.
+void Rast_mark_colors_as_fp(struct Colors *colors)
+    colors->is_float = 1;
Copied: grass/trunk/lib/raster/color_remove.c (from rev 37989, grass/trunk/lib/gis/color_remove.c)
--- grass/trunk/lib/raster/color_remove.c	                        (rev 0)
+++ grass/trunk/lib/raster/color_remove.c	2009-06-20 22:03:23 UTC (rev 38003)
@@ -0,0 +1,44 @@
+ * MODULE:       gis library
+ * AUTHOR(S):    Glynn Clements <glynn at gclements.plus.com>
+ * COPYRIGHT:    (C) 2007 Glynn Clements
+ *  This program is free software; you can redistribute it and/or modify
+ *  it under the terms of the GNU General Public License as published by
+ *  the Free Software Foundation; either version 2 of the License, or
+ *  (at your option) any later version.
+ *  This program is distributed in the hope that it will be useful,
+ *  but WITHOUT ANY WARRANTY; without even the implied warranty of
+ *  MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.  See the
+ *  GNU General Public License for more details.
+#include <stdio.h>
+int Rast_remove_colors(const char *name, const char *mapset)
+    char element[GMAPSET_MAX + 6];
+    char xname[GNAME_MAX], xmapset[GMAPSET_MAX];
+    int stat;
+    if (G__name_is_fully_qualified(name, xname, xmapset)) {
+	if (strcmp(xmapset, mapset) != 0)
+	    return -1;
+	name = xname;
+    /* get rid of existing colr2, if any */
+    sprintf(element, "colr2/%s", mapset);
+    stat = G_remove(element, name);
+    if (strcmp(mapset, G_mapset()) == 0)
+	stat = G_remove("colr", name);
+    return stat;
Copied: grass/trunk/lib/raster/color_rule.c (from rev 37989, grass/trunk/lib/gis/color_rule.c)
--- grass/trunk/lib/raster/color_rule.c	                        (rev 0)
+++ grass/trunk/lib/raster/color_rule.c	2009-06-20 22:03:23 UTC (rev 38003)
@@ -0,0 +1,441 @@
+ * \file gis/color_rule.c
+ * \brief GIS Library - Color rules.
+#include <grass/Rast.h>
+static void add_color_rule(const void *, int, int, int,
+			   const void *, int, int, int,
+			   struct _Color_Info_ *, int,
+			   DCELL *, DCELL *, RASTER_MAP_TYPE);
+ * \brief Adds the floating-point rule (DCELL version)
+ * See Rast_add_raster_color_rule() for details.
+ *  \param v1 cell value
+ *  \param r1,g1,b1 color value
+ *  \param v2 cell value
+ *  \param r2,g2,b2 color value
+ *  \param[in,out] colors pointer to color table structure
+ *  \return
+void Rast_add_d_raster_color_rule(const DCELL * val1, int r1, int g1, int b1,
+			       const DCELL * val2, int r2, int g2, int b2,
+    add_color_rule(val1, r1, g1, b1, val2, r2, g2, b2, &colors->fixed,
+		   colors->version, &colors->cmin, &colors->cmax, DCELL_TYPE);
+ * \brief Adds the floating-point rule (FCELL version)
+ *  \return
+void Rast_add_f_raster_color_rule(const FCELL * cat1, int r1, int g1, int b1,
+			       const FCELL * cat2, int r2, int g2, int b2,
+    add_color_rule(cat1, r1, g1, b1, cat2, r2, g2, b2, &colors->fixed,
+		   colors->version, &colors->cmin, &colors->cmax, FCELL_TYPE);
+ * \brief Adds the floating-point rule (CCELL version)
+ *  \return
+void Rast_add_c_raster_color_rule(const CELL * cat1, int r1, int g1, int b1,
+			       const CELL * cat2, int r2, int g2, int b2,
+		   colors->version, &colors->cmin, &colors->cmax, CELL_TYPE);
+ * Adds the floating-point rule that the range [<em>v1,v2</em>] gets a
+ * linear ramp of colors from [<em>r1,g1,b1</em>] to
+ * [<em>r2,g2,b2</em>].
+ * If either <em>v1</em> or <em>v2</em> is the NULL-value, this call is converted into
+ * <tt>Rast_set_null_value_color (r1, g1, b1, colors)</tt>
+ *  - If <em>map_type</em> is CELL_TYPE, calls Rast_add_c_raster_color_rule()
+ *  - If <em>map_type</em> is FCELL_TYPE, calls Rast_add_f_raster_color_rule()
+ *  - If <em>map_type</em> is DCELL_TYPE, calls Rast_add_d_raster_color_rule()
+ *  \param data_type raster data type (CELL, FCELL, DCELL)
+ *  \return
+void Rast_add_raster_color_rule(const void *val1, int r1, int g1, int b1,
+			     const void *val2, int r2, int g2, int b2,
+			     struct Colors *colors, RASTER_MAP_TYPE data_type)
+		   colors->version, &colors->cmin, &colors->cmax, data_type);
+ * \brief Set colors rules
+ * This is the heart
+ * and soul of the new color logic. It adds a color rule to the <b>colors</b>
+ * structure. The colors defined by the red, green, and blue values
+ * <b>r1,g1,b1</b> and <b>r2,g2,b2</b> are assigned to <b>cat1</b> and
+ * <b>cat2</b> respectively. Colors for data values between <b>cat1</b> and
+ * <b>cat2</b> are not stored in the structure but are interpolated when
+ * queried by <i>Rast_lookup_colors</i> and<i>Rast_get_color.</i> The color
+ * components <b>r1,g1,b1</b> and <b>r2,g2,b2</b> must be in the range
+ * 0 -- 255.
+ * For example, to create a linear grey scale for the range 200 -- 1000:
+ \code
+ struct Colors colr;
+ Rast_init_colors (&colr);
+ Rast_add_color_rule ((CELL)200, 0,0,0, (CELL) 1000, 255,255,255);
+ \endcode
+ * The programmer is encouraged to review \ref
+ * Raster_Color_Table_Format how this routine fits into the 5.x raster
+ * color logic.
+ * <b>Note:</b> The <i>colors</i> structure must have been initialized
+ * by Rast_init_colors(). See \ref Predefined_Color_Tables for routines
+ * to build some predefined color tables.
+ *  \param cat1 cell value
+ *  \param cat2 cell value
+ *  \return
+void Rast_add_color_rule(CELL cat1, int r1, int g1, int b1,
+		      CELL cat2, int r2, int g2,
+		      int b2, struct Colors *colors)
+    add_color_rule((void *)&cat1, r1, g1, b1, (void *)&cat2, r2, g2, b2,
+		   &colors->fixed, colors->version, &colors->cmin,
+		   &colors->cmax, CELL_TYPE);
+ * \brief Add modular color rule (DCELL version)
+ * \param val1 cell value
+ * \param val2 cell value
+ * \return -1 on failure
+int Rast_add_modular_d_raster_color_rule(const DCELL * val1, int r1, int g1, int b1,
+    DCELL min, max;
+    if (colors->version < 0)
+	return -1;		/* can't use this on 3.0 colors */
+    min = colors->cmin;
+    max = colors->cmax;
+    add_color_rule(val1, r1, g1, b1, val2, r2, g2, b2, &colors->modular, 0,
+		   &colors->cmin, &colors->cmax, DCELL_TYPE);
+    colors->cmin = min;		/* don't reset these */
+    return 1;
+ * \brief Add modular color rule (FCELL version)
+int Rast_add_modular_f_raster_color_rule(const FCELL * val1, int r1, int g1, int b1,
+				      const FCELL * val2, int r2, int g2, int b2,
+    DCELL min, max;
+	return -1;		/* can;t use this on 3.0 colors */
+		   &colors->cmin, &colors->cmax, FCELL_TYPE);
+    return 1;
+ * \brief Add modular color rule (CCELL version)
+int Rast_add_modular_c_raster_color_rule(const CELL * val1, int r1, int g1, int b1,
+				      const CELL * val2, int r2, int g2, int b2,
+    return Rast_add_modular_color_rule(*val1, r1, g1, b1, *val2, r2, g2, b2,
+				    colors);
+ * \todo Question: shouldn't this function call
+ * G_add_modular_<data_type>_raster_color_rule() instead?
+int Rast_add_modular_raster_color_rule(
+    const void *val1, int r1, int g1, int b1,
+    CELL min, max;
+		   &colors->cmin, &colors->cmax, data_type);
+    return 1;
+ * \todo This function seems to be same as
+ * Rast_add_modular_raster_color_rule(). Can be removed?
+int Rast_add_modular_color_rule(CELL cat1, int r1, int g1,
+			     int b1, CELL cat2, int r2,
+			     int g2, int b2, struct Colors *colors)
+    CELL min, max;
+		   &colors->modular, 0, &colors->cmin, &colors->cmax,
+		   CELL_TYPE);
+    return 1;
+static void add_color_rule(const void *pt1, int r1, int g1, int b1,
+			   const void *pt2, int r2, int g2, int b2,
+			   struct _Color_Info_ *cp, int version, DCELL * cmin,
+			   DCELL * cmax, RASTER_MAP_TYPE data_type)
+    DCELL min, max, val1, val2;
+    CELL cat;
+    val1 = Rast_get_raster_value_d(pt1, data_type);
+    val2 = Rast_get_raster_value_d(pt2, data_type);
+    /* allocate a low:high rule */
+    rule = (struct _Color_Rule_ *)G_malloc(sizeof(*rule));
+    rule->next = rule->prev = NULL;
+    /* make sure colors are in the range [0,255] */
+    LIMIT(r1);
+    LIMIT(g1);
+    LIMIT(b1);
+    LIMIT(r2);
+    LIMIT(g2);
+    LIMIT(b2);
+    /* val1==val2, use average color */
+    /* otherwise make sure low < high */
+    if (val1 == val2) {
+	rule->low.value = rule->high.value = val1;
+	rule->low.red = rule->high.red = (r1 + r2) / 2;
+	rule->low.grn = rule->high.grn = (g1 + g2) / 2;
+	rule->low.blu = rule->high.blu = (b1 + b2) / 2;
+    else if (val1 < val2) {
+	rule->low.value = val1;
+	rule->low.red = r1;
+	rule->low.grn = g1;
+	rule->low.blu = b1;
+	rule->high.value = val2;
+	rule->high.red = r2;
+	rule->high.grn = g2;
+	rule->high.blu = b2;
+    else {
+	rule->low.value = val2;
+	rule->low.red = r2;
+	rule->low.grn = g2;
+	rule->low.blu = b2;
+	rule->high.value = val1;
+	rule->high.red = r1;
+	rule->high.grn = g1;
+	rule->high.blu = b1;
+    /* keep track of the overall min and max, excluding null */
+    if (Rast_is_d_null_value(&(rule->low.value)))
+	return;
+    if (Rast_is_d_null_value(&(rule->high.value)))
+	return;
+    min = rule->low.value;
+    max = rule->high.value;
+    if (min <= max) {
+	if (cp->min > cp->max) {
+	    cp->min = min;
+	    cp->max = max;
+	else {
+	    if (cp->min > min)
+		cp->min = min;
+	    if (cp->max < max)
+		cp->max = max;
+    if (*cmin > *cmax) {
+	*cmin = cp->min;
+	*cmax = cp->max;
+    else {
+	if (*cmin > cp->min)
+	    *cmin = cp->min;
+	if (*cmax < cp->max)
+	    *cmax = cp->max;
+    /* If version is old style (i.e., pre 4.0),
+     *     interpolate this rule from min to max
+     *     and insert each cat into the lookup table.
+     *     Then free the rule.
+     * Otherwise, free the lookup table, if active.
+     *     G_organize_colors() will regenerate it
+     *     Link this rule into the list of rules
+    if (version < 0) {
+	for (cat = (CELL) min; cat <= (CELL) max; cat++) {
+	    Rast__interpolate_color_rule((DCELL) cat, &red, &grn, &blu, rule);
+	    Rast__insert_color_into_lookup(cat, (int)red, (int)grn, (int)blu,
+					cp);
+	G_free(rule);
+    else {
+	if (cp->rules)
+	    cp->rules->prev = rule;
+	rule->next = cp->rules;
+	cp->rules = rule;
+	/* prune the rules:
+	 * remove all rules that are contained by this rule
+	min = rule->low.value;	/* mod 4.1 */
+	max = rule->high.value;	/* mod 4.1 */
+	cp->n_rules++;
+	for (rule = rule->next; rule; rule = next) {
+	    next = rule->next;	/* has to be done here, not in for stmt */
+	    if (min <= rule->low.value && max >= rule->high.value) {
+		if ((rule->prev->next = next))	/* remove from the list */
+		    next->prev = rule->prev;
+		G_free(rule);
+		cp->n_rules--;
+	/* free lookup array, if allocated */
+	Rast__color_free_lookup(cp);
+	Rast__color_free_fp_lookup(cp);
Copied: grass/trunk/lib/raster/color_rule_get.c (from rev 37989, grass/trunk/lib/gis/color_rule_get.c)
--- grass/trunk/lib/raster/color_rule_get.c	                        (rev 0)
+++ grass/trunk/lib/raster/color_rule_get.c	2009-06-20 22:03:23 UTC (rev 38003)
@@ -0,0 +1,123 @@
+ * \file color_rule_get.c
+ * \brief GIS Library - Get color rules.
+ * (C) 2001-2008 by the GRASS Development Team
+ * \author GRASS GIS Development Team
+ * \date 1999-2008
+   \brief Get both modular and fixed rules count
+   \param colors pointer to color table structure
+   \return number of rules in color table
+int Rast_colors_count(const struct Colors *colors)
+    int count = 0;
+    if (colors->fixed.rules) {
+	count++;
+	rule = colors->fixed.rules;
+	while (rule->next) {
+	    count++;
+	    rule = rule->next;
+    if (colors->modular.rules) {
+	count++;
+	rule = colors->modular.rules;
+	    count++;
+    return count;
+   \brief Get color rule from both modular and fixed rules
+   Rules are returned in the order as stored in the table (i.e. unexpected, high values first)
+   \param val1 color value
+   \param[out] r1,g1,b1 color value
+   \param val2 color value
+   \param[out] r2,g2,b2 color value
+   \param rule rule index from 0 to G_color_count()-1
+   \return 0 success
+   \return 1 index out of range
+int Rast_get_f_color_rule(DCELL * val1, unsigned char *r1, unsigned char *g1,
+		       unsigned char *b1, DCELL * val2, unsigned char *r2,
+		       unsigned char *g2, unsigned char *b2,
+		       const struct Colors *colors, int rule)
+    int index = -1;
+    int found = 0;
+    const struct _Color_Rule_ *rl;
+    *val1 = *val2 = 0.0;
+    *r1 = *g1 = *b1 = *r2 = *g2 = *b2 = 0;
+    /* Find the rule */
+	rl = colors->fixed.rules;
+	index++;
+	if (index == rule)
+	    found = 1;
+	while (!found && rl->next) {
+	    rl = rl->next;
+	    index++;
+		found = 1;
+    if (!found && colors->modular.rules) {
+	rl = colors->modular.rules;
+	index++;
+	    found = 1;
+	    rl = rl->next;
+	    index++;
+		found = 1;
+    if (!found)
+	return 1;
+    /* Set values */
+    *val1 = rl->low.value;
+    *val2 = rl->high.value;
+    *r1 = rl->low.red;
+    *g1 = rl->low.grn;
+    *b1 = rl->low.blu;
+    *r2 = rl->high.red;
+    *g2 = rl->high.grn;
+    *b2 = rl->high.blu;
+    return 0;
Copied: grass/trunk/lib/raster/color_rules.c (from rev 37989, grass/trunk/lib/gis/color_rules.c)
--- grass/trunk/lib/raster/color_rules.c	                        (rev 0)
+++ grass/trunk/lib/raster/color_rules.c	2009-06-20 22:03:23 UTC (rev 38003)
@@ -0,0 +1,272 @@
+ * COPYRIGHT:    (C) 2007 Glynn Clements and the GRASS Development Team
+ * NOTE:         Based upon r.colors/rules.c
+ *               The colors are stored in ./colors/
+#include <stdio.h>
+#include <grass/glocale.h>
+struct rule
+    int set;
+    int r, g, b;
+    DCELL val;
+enum rule_error
+    CR_OK = 0,
+    CR_ERROR_SYNTAX,
+    CR_ERROR_RGB,
+    CR_ERROR_COLOR,
+    CR_ERROR_PERCENT,
+    CR_ERROR_VALUE,
+int Rast_parse_color_rule(DCELL min, DCELL max, const char *buf,
+		       DCELL * val, int *r, int *g, int *b,
+		       int *norm, int *nval, int *dflt)
+    char value[80], color[80];
+    double x;
+    char c;
+    *norm = *nval = *dflt = 0;
+    if (sscanf(buf, "%s %[^\n]", value, color) != 2)
+	return CR_ERROR_SYNTAX;
+    G_chop(color);
+    if (sscanf(color, "%d:%d:%d", r, g, b) == 3 ||
+	sscanf(color, "%d %d %d", r, g, b) == 3) {
+	if (*r < 0 || *r > 255 || *g < 0 || *g > 255 || *b < 0 || *b > 255)
+	    return CR_ERROR_RGB;
+    else {
+	float fr, fg, fb;
+	if (G_color_values(color, &fr, &fg, &fb) < 0)
+	    return CR_ERROR_COLOR;
+	*r = (int)(fr * 255.99);
+	*g = (int)(fg * 255.99);
+	*b = (int)(fb * 255.99);
+    G_chop(value);
+    if (G_strcasecmp(value, "default") == 0) {
+	*dflt = 1;
+	return CR_OK;
+    if (G_strcasecmp(value, "nv") == 0) {
+	*nval = 1;
+	return CR_OK;
+    if (sscanf(value, "%lf%c", &x, &c) == 2 && c == '%') {
+	if (x < 0 || x > 100)
+	    return CR_ERROR_PERCENT;
+	*val = min + (max - min) * (x / 100);
+	*norm = 1;
+	return CR_OK;
+    if (sscanf(value, "%lf", val) == 1) {
+	*norm = 1;
+	return CR_OK;
+    return CR_ERROR_VALUE;
+const char *Rast_parse_color_rule_error(int code)
+    switch (code) {
+    case CR_OK:
+	return "";
+    case CR_ERROR_SYNTAX:
+	return _("syntax error");
+    case CR_ERROR_RGB:
+	return _("R/G/B not in range 0-255");
+    case CR_ERROR_COLOR:
+	return _("invalid color name");
+    case CR_ERROR_PERCENT:
+	return _("percentage not in range 0-100");
+    case CR_ERROR_VALUE:
+	return _("invalid value");
+    default:
+	return _("unknown error");
+int Rast_read_color_rule(void *closure, DCELL min, DCELL max,
+    char buf[1024];
+    FILE *fp = closure;
+    int ret;
+    for (;;) {
+	if (!G_getl2(buf, sizeof(buf), fp))
+	    return 0;
+	G_strip(buf);
+	G_debug(5, "color buf = [%s]", buf);
+	if (*buf == '\0')
+	    continue;
+	if (*buf == '#')
+	    continue;
+	ret =
+	    Rast_parse_color_rule(min, max, buf, val, r, g, b, norm, nval, dflt);
+	if (ret == 0)
+	    return 1;
+	G_fatal_error(_("bad rule (%s): [%s]"),
+		      Rast_parse_color_rule_error(ret), buf);
+    return 0;
+int Rast_read_color_rules(struct Colors *colors, DCELL min, DCELL max,
+		       read_rule_fn * read_rule, void *closure)
+    struct rule *rule = NULL;
+    int nrules = 0;
+    struct rule dflt, null;
+    int set, is_null, is_dflt, r, g, b;
+    DCELL val;
+    int n;
+    if (!read_rule)
+	read_rule = Rast_read_color_rule;
+    /* initialization */
+    dflt.r = dflt.g = dflt.b = dflt.set = 0;
+    null.r = null.g = null.b = null.set = 0;
+    while ((*read_rule)
+	   (closure, min, max, &val, &r, &g, &b, &set, &is_null, &is_dflt)) {
+	struct rule *p;
+	if (set) {
+	    n = nrules++;
+	    rule = G_realloc(rule, nrules * sizeof(struct rule));
+	    p = &rule[n];
+	else if (is_dflt)
+	    p = &dflt;
+	else if (is_null)
+	    p = &null;
+	p->r = r;
+	p->g = g;
+	p->b = b;
+	p->set = 1;
+	p->val = val;
+    if (nrules == 0)
+	return 0;
+    if (nrules == 1) {
+	const struct rule *p = &rule[0];
+	Rast_set_d_color(p->val, p->r, p->g, p->b, colors);
+    for (n = 1; n < nrules; n++) {
+	struct rule *lo = &rule[n - 1];
+	struct rule *hi = &rule[n];
+	Rast_add_d_raster_color_rule(&lo->val, lo->r, lo->g, lo->b,
+				  &hi->val, hi->r, hi->g, hi->b, colors);
+    /* null value and default color set up, if rules are set up by user */
+    if (null.set)
+	Rast_set_null_value_color(null.r, null.g, null.b, colors);
+    if (dflt.set)
+	Rast_set_default_color(dflt.r, dflt.g, dflt.b, colors);
+    return 1;
+static int load_rules_file(struct Colors *colors, const char *path, DCELL min, DCELL max)
+    FILE *fp;
+    int ret;
+    fp = fopen(path, "r");
+    if (!fp)
+	return 0;
+    ret = Rast_read_color_rules(colors, min, max, Rast_read_color_rule, (void *)fp);
+    fclose(fp);
+    return ret;
+int Rast_load_colors(struct Colors *colors, const char *path, CELL min, CELL max)
+    return load_rules_file(colors, path, (DCELL) min, (DCELL) max);
+int Rast_load_fp_colors(struct Colors *colors, const char *path, DCELL min, DCELL max)
+    return load_rules_file(colors, path, min, max);
+static void load_rules_name(struct Colors *colors, const char *name, DCELL min, DCELL max)
+    char path[GPATH_MAX];
+    sprintf(path, "%s/etc/colors/%s", G_gisbase(), name);
+    if (!load_rules_file(colors, path, min, max))
+	G_fatal_error(_("Unable to load color rules <%s>"), name);
+void Rast_make_colors(struct Colors *colors, const char *name, CELL min, CELL max)
+    return load_rules_name(colors, name, (DCELL) min, (DCELL) max);
+void Rast_make_fp_colors(struct Colors *colors, const char *name, DCELL min, DCELL max)
+    return load_rules_name(colors, name, min, max);
Copied: grass/trunk/lib/raster/color_set.c (from rev 37989, grass/trunk/lib/gis/color_set.c)
--- grass/trunk/lib/raster/color_set.c	                        (rev 0)
+++ grass/trunk/lib/raster/color_set.c	2009-06-20 22:03:23 UTC (rev 38003)
@@ -0,0 +1,105 @@
+ * \file gis/color_set.c
+ * \brief GIS Library - Set colors for raster maps.
+ * \brief Set a category color (CELL)
+ * associated with category <i>cat</i> are set in the <i>colors</i>
+ * structure.  The intensities must be in the range 0 -­ 255. Values
+ * below zero are set as zero, values above 255 are set as 255.
+ * <b>Warning: Use of this routine is discouraged because it defeats the new
+ * color logic.</b>
+ * It is provided only for backward compatibility. Overuse can create
+ * large color tables. Rast_add_color_rule() should be used whenever
+ * possible.
+ * initialized by G_init_color().
+ * \param cat raster cell value
+ * \param r red value
+ * \param g green value
+ * \param b blue value
+void Rast_set_color(CELL cat, int r, int g, int b, struct Colors *colors)
+    if (Rast_is_c_null_value(&cat))
+	Rast_set_null_value_color(r, g, b, colors);
+    else
+	Rast_add_color_rule(cat, r, g, b, cat, r, g, b, colors);
+ * \brief Set a category color (DCELL)
+ * See Rast_set_color() for detailed information.
+void Rast_set_d_color(DCELL val, int r, int g, int b, struct Colors *colors)
+    if (Rast_is_d_null_value(&val))
+    else
+	Rast_add_d_raster_color_rule(&val, r, g, b, &val, r, g, b, colors);
+ * \brief Set color for NULL-value
+ * Sets the color (in <i>colors</i>) for the NULL-value to
+ * <i>red, green, blue</i>.
+ * \param red red value
+ * \param grn green value
+ * \param blu blue value
+void Rast_set_null_value_color(int red, int grn, int blu, struct Colors *colors)
+    colors->null_red = red;
+    colors->null_grn = grn;
+    colors->null_blu = blu;
+    colors->null_set = 1;
+ * \brief Set default color value
+ * Sets the default color (in <i>colors</i>) to <i>red, green,
+ * blue</i>. This is the color for values which do not have an
+ * explicit rule.
+void Rast_set_default_color(int red, int grn, int blu, struct Colors *colors)
+    colors->undef_red = red;
+    colors->undef_grn = grn;
+    colors->undef_blu = blu;
+    colors->undef_set = 1;
Copied: grass/trunk/lib/raster/color_shift.c (from rev 37989, grass/trunk/lib/gis/color_shift.c)
--- grass/trunk/lib/raster/color_shift.c	                        (rev 0)
+++ grass/trunk/lib/raster/color_shift.c	2009-06-20 22:03:23 UTC (rev 38003)
@@ -0,0 +1,10 @@
+void Rast_shift_colors(int shift, struct Colors *colors)
+    colors->shift += (DCELL) shift;
+void Rast_shift_d_colors(DCELL shift, struct Colors *colors)
+    colors->shift += shift;
Copied: grass/trunk/lib/raster/color_str.c (from rev 37989, grass/trunk/lib/gis/color_str.c)
--- grass/trunk/lib/raster/color_str.c	                        (rev 0)
+++ grass/trunk/lib/raster/color_str.c	2009-06-20 22:03:23 UTC (rev 38003)
@@ -0,0 +1,150 @@
+   \file color_str.c
+   \brief GIS library - color management, named color to RGB triplet
+   (C) 2001-2008 by the GRASS Development Team
+   This program is free software under the
+   GNU General Public License (>=v2).
+   Read the file COPYING that comes with GRASS
+   for details.
+   \author Original author CERL
+#include <grass/gis.h>
+#include <grass/colors.h>
+/* The order in this table is important! It will be indexed by color number */
+static const struct color_rgb standard_colors_rgb[] = {
+    {0, 0, 0},			/* This is a dummy value to make lookup easier */
+    {0, 0, 0},			/* BLACK   */
+    {255, 0, 0},		/* RED     */
+    {0, 255, 0},		/* GREEN   */
+    {0, 0, 255},		/* BLUE    */
+    {255, 255, 0},		/* YELLOW  */
+    {0, 255, 255},		/* CYAN    */
+    {255, 0, 255},		/* MAGENTA */
+    {255, 255, 255},		/* WHITE   */
+    {128, 128, 128},		/* GRAY    */
+    {255, 128, 0},		/* ORANGE  */
+    {100, 128, 255},		/* AQUA    */
+    {0, 128, 255},		/* INDIGO  */
+    {128, 0, 255},		/* VIOLET  */
+    {180, 77, 25}		/* BROWN   */
+/* The order in this table has no meaning. */
+static const struct color_name standard_color_names[] = {
+    {"black", BLACK},
+    {"red", RED},
+    {"green", GREEN},
+    {"blue", BLUE},
+    {"yellow", YELLOW},
+    {"cyan", CYAN},
+    {"magenta", MAGENTA},
+    {"white", WHITE},
+    {"grey", GREY},
+    {"gray", GRAY},
+    {"orange", ORANGE},
+    {"aqua", AQUA},
+    {"indigo", INDIGO},
+    {"violet", VIOLET},
+    {"purple", PURPLE},
+    {"brown", BROWN}
+   \brief Get number of named colors (RGB triplets)
+   \return number of colors
+int G_num_standard_colors(void)
+    return sizeof(standard_colors_rgb) / sizeof(standard_colors_rgb[0]);
+   \brief Get RGB triplet of given color
+   \param n color index
+struct color_rgb G_standard_color_rgb(int n)
+    return standard_colors_rgb[n];
+   \brief Get number of named colors (color names)
+int G_num_standard_color_names(void)
+    return sizeof(standard_color_names) / sizeof(standard_color_names[0]);
+   \brief Get color name
+const struct color_name *G_standard_color_name(int n)
+    return &standard_color_names[n];
+   \brief Parse color string and set red,green,blue
+   \param str color string
+   \return 1 OK
+   \return 2 NONE
+   \return 0 on error
+int Rast_str_to_color(const char *str, int *red, int *grn, int *blu)
+    char buf[100];
+    int num_names = G_num_standard_color_names();
+    int i;
+    strcpy(buf, str);
+    G_chop(buf);
+    G_debug(3, "Rast_str_to_color(): str = '%s'", buf);
+    if (G_strcasecmp(buf, "NONE") == 0)
+	return 2;
+    if (sscanf(buf, "%d%*[,:; ]%d%*[,:; ]%d", red, grn, blu) == 3) {
+	if (*red < 0 || *red > 255 ||
+	    *grn < 0 || *grn > 255 || *blu < 0 || *blu > 255)
+	    return 0;
+	return 1;
+    /* Look for this color in the standard (preallocated) colors */
+    for (i = 0; i < num_names; i++) {
+	const struct color_name *name = &standard_color_names[i];
+	if (G_strcasecmp(buf, name->name) == 0) {
+	    struct color_rgb rgb = standard_colors_rgb[name->number];
+	    *red = (int)rgb.r;
+	    *grn = (int)rgb.g;
+	    *blu = (int)rgb.b;
+	    return 1;
+    return 0;
Copied: grass/trunk/lib/raster/color_write.c (from rev 37989, grass/trunk/lib/gis/color_write.c)
--- grass/trunk/lib/raster/color_write.c	                        (rev 0)
+++ grass/trunk/lib/raster/color_write.c	2009-06-20 22:03:23 UTC (rev 38003)
@@ -0,0 +1,268 @@
+ * \file gis/color_write.c
+ * \brief GIS Library - Write color table of raster map
+ * (C) 1999-2009 by the GRASS Development Team
+ * This program is free software under the GNU General Public
+ * License (>=v2). Read the file COPYING that comes with GRASS
+ * for details.
+ * \author USACERL and many others
+#include <stdio.h>
+#define PRECISION 30
+#define THRESHOLD .0000000000000000000000000000005 /* .5 * 10 ^(-30) */
+static void write_rules(FILE *, struct _Color_Rule_ *, DCELL, DCELL);
+static void write_new_colors(FILE *, struct Colors *);
+static void write_old_colors(FILE *, struct Colors *);
+static void forced_write_old_colors(FILE *, struct Colors *);
+static void format_min(char *, double);
+static void format_max(char *, double);
+ * \brief Write map layer color table
+ * The color table is written for the raster map <i>name</i> in the
+ * specified <i>mapset</i> from the <i>colors</i> structure.
+ * If there is an error, -1 is returned. No diagnostic is
+ * printed. Otherwise, 1 is returned.
+ * The <i>colors</i> structure must be created properly, i.e.,
+ * Rast_init_colors() to initialize the structure and Rast_add_color_rule()
+ * to set the category colors. These routines are called by
+ * higher level routines which read or create entire color tables,
+ * such as Rast_read_colors() or Rast_make_ramp_colors().
+ * <b>Note:</b> The calling sequence for this function deserves
+ * special attention. The <i>mapset</i> parameter seems to imply that
+ * it is possible to overwrite the color table for a raster map which
+ * is in another mapset. However, this is not what actually
+ * happens. It is very useful for users to create their own color
+ * tables for raster maps in other mapsets, but without overwriting
+ * other users' color tables for the same raster map. If <i>mapset</i>
+ * is the current mapset, then the color file for <i>name</i> will be
+ * overwritten by the new color table. But if <i>mapset</i> is not the
+ * current mapset, then the color table is actually written in the
+ * current mapset under the <tt>colr2</tt> element as:
+ * <tt>colr2/mapset/name</tt>.
+ * The rules are written out using floating-point format, removing
+ * trailing zeros (possibly producing integers).  The flag marking the
+ * colors as floating-point is <b>not</b> written.
+ * If the environment variable FORCE_GRASS3_COLORS is set (to anything at all)
+ * then the output format is 3.0, even if the structure contains 4.0 rules.
+ * This allows users to create 3.0 color files for export to sites which
+ * don't yet have 4.0
+ * \param colors pointer to structure Colors which holds color info
+int Rast_write_colors(const char *name, const char *mapset,
+    char element[512];
+    FILE *fd;
+	    return -1;
+	name = xname;
+     * if mapset is current mapset, remove colr2 file (created by pre 3.0 grass)
+     *    and then write original color table
+     * else write secondary color table
+    if (strcmp(mapset, G_mapset()) == 0) {
+	G_remove(element, name);	/* get rid of existing colr2, if any */
+	strcpy(element, "colr");
+    if (!(fd = G_fopen_new(element, name)))
+	return -1;
+    Rast__write_colors(fd, colors);
+    fclose(fd);
+    return 1;
+ * \param fd file descriptor
+ * \param colors pointer to Colors structure which holds color info
+void Rast__write_colors(FILE * fd, struct Colors *colors)
+    if (getenv("FORCE_GRASS3_COLORS"))
+	forced_write_old_colors(fd, colors);
+    else if (colors->version < 0)
+	write_old_colors(fd, colors);
+    else
+	write_new_colors(fd, colors);
+static void write_new_colors(FILE * fd, struct Colors *colors)
+    char str1[100], str2[100];
+    format_min(str1, (double)colors->cmin);
+    format_max(str2, (double)colors->cmax);
+    fprintf(fd, "%% %s %s\n", str1, str2);
+    if (colors->shift) {
+	sprintf(str2, "%.10f", (double)colors->shift);
+	G_trim_decimal(str2);
+	fprintf(fd, "shift:%s\n", str2);
+    if (colors->invert)
+	fprintf(fd, "invert\n");
+	fprintf(fd, "nv:%d", colors->null_red);
+	if (colors->null_red != colors->null_grn || colors->null_red
+	    != colors->null_blu)
+	    fprintf(fd, ":%d:%d", colors->null_grn, colors->null_blu);
+	fprintf(fd, "\n");
+	fprintf(fd, "*:%d", colors->undef_red);
+	if (colors->undef_red != colors->undef_grn || colors->undef_red
+	    != colors->undef_blu)
+	    fprintf(fd, ":%d:%d", colors->undef_grn, colors->undef_blu);
+	fprintf(fd, "%s\n", "%%");
+	write_rules(fd, colors->modular.rules, colors->cmin, colors->cmax);
+	write_rules(fd, colors->fixed.rules, colors->cmin, colors->cmax);
+/* overall min and max data values in color table */
+static void write_rules(FILE * fd, struct _Color_Rule_ *crules, DCELL dmin, DCELL dmax)
+    char str[100];
+    /* find the end of the rules list */
+    rule = crules;
+    /* write out the rules in reverse order */
+	if (rule->low.value == dmin)
+	    format_min(str, (double)rule->low.value);
+	else {
+	    sprintf(str, "%.10f", (double)rule->low.value);
+	    G_trim_decimal(str);
+	fprintf(fd, "%s:%d", str, (int)rule->low.red);
+	if (rule->low.red != rule->low.grn || rule->low.red != rule->low.blu)
+	    fprintf(fd, ":%d:%d", rule->low.grn, rule->low.blu);
+	/* even if low==high, write second end when the high is dmax */
+	if (rule->high.value == dmax || rule->low.value != rule->high.value) {
+	    if (rule->high.value == dmax)
+		format_max(str, (double)rule->high.value);
+	    else {
+		sprintf(str, "%.10f", (double)rule->high.value);
+	    fprintf(fd, " %s:%d", str, (int)rule->high.red);
+	    if (rule->high.red != rule->high.grn ||
+		rule->high.red != rule->high.blu)
+		fprintf(fd, ":%d:%d", rule->high.grn, rule->high.blu);
+static void write_old_colors(FILE * fd, struct Colors *colors)
+    int i, n;
+    fprintf(fd, "#%ld first color\n", (long)colors->fixed.min);
+    if (colors->null_set) {
+	fprintf(fd, "%d %d %d\n",
+		(int)colors->null_red,
+		(int)colors->null_grn, (int)colors->null_blu);
+    else
+	fprintf(fd, "255 255 255\n");	/* white */
+    n = colors->fixed.max - colors->fixed.min + 1;
+    for (i = 0; i < n; i++) {
+	fprintf(fd, "%d", (int)colors->fixed.lookup.red[i]);
+	if (colors->fixed.lookup.red[i] != colors->fixed.lookup.grn[i]
+	    || colors->fixed.lookup.red[i] != colors->fixed.lookup.blu[i])
+	    fprintf(fd, " %d %d",
+		    (int)colors->fixed.lookup.grn[i],
+		    (int)colors->fixed.lookup.blu[i]);
+static void forced_write_old_colors(FILE * fd, struct Colors *colors)
+    CELL cat;
+    fprintf(fd, "#%ld first color\n", (long)colors->cmin);
+    Rast_get_color((CELL) 0, &red, &grn, &blu, colors);
+    fprintf(fd, "%d %d %d\n", red, grn, blu);
+    for (cat = colors->cmin; cat <= colors->cmax; cat++) {
+	Rast_get_color(cat, &red, &grn, &blu, colors);
+	fprintf(fd, "%d", red);
+	if (red != grn || red != blu)
+	    fprintf(fd, " %d %d", grn, blu);
+static void format_min(char *str, double dval)
+    double dtmp;
+    sprintf(str, "%.*f", PRECISION, dval);
+    sscanf(str, "%lf", &dtmp);
+    if (dtmp != dval) {		/* if  no zeros after decimal point were trimmed */
+	sprintf(str, "%.*f", PRECISION, dval - THRESHOLD);
+	/* because precision is probably higher than PRECISION */
+static void format_max(char *str, double dval)
+    double dtmp;
+	sprintf(str, "%.*f", PRECISION, dval + THRESHOLD);
Copied: grass/trunk/lib/raster/color_xform.c (from rev 37989, grass/trunk/lib/gis/color_xform.c)
--- grass/trunk/lib/raster/color_xform.c	                        (rev 0)
+++ grass/trunk/lib/raster/color_xform.c	2009-06-20 22:03:23 UTC (rev 38003)
@@ -0,0 +1,319 @@
+ *  Rast_histogram_eq_colors (dst, src, statf)
+ *   struct Colors *dst         struct to hold new colors
+ *   struct Colors *src         struct containing original colors
+ *   struct Cell_stats *statf   cell stats info
+ *  Generates histogram equalized version of an existing color table from
+ *  cell stats structure info.
+ *  Rast_log_colors (dst, src, samples)
+ *   int samples                number of samples
+ *  Generates logarithmically-scaled version of an existing color table.
+#include <math.h>
+ * \brief make histogram-stretched version of existing color table
+ * Generates a histogram
+ * contrast-stretched color table that goes from the histogram
+ * information in the Cell_stats structure <b>statf.</b>  (See
+ * Raster_Histograms).
+ *  \param dst
+ *  \param src
+ *  \param statf
+ *  \return
+void Rast_histogram_eq_colors(struct Colors *dst,
+			   struct Colors *src, struct Cell_stats *statf)
+    DCELL min, max;
+    long count, total, sum;
+    CELL cat, prev;
+    int first;
+    Rast_init_colors(dst);
+    Rast_get_d_color_range(&min, &max, src);
+    Rast_get_default_color(&red, &grn, &blu, src);
+    Rast_set_default_color(red, grn, blu, dst);
+    Rast_get_null_value_color(&red, &grn, &blu, src);
+    Rast_set_null_value_color(red, grn, blu, dst);
+    total = 0;
+    Rast_rewind_cell_stats(statf);
+    while (Rast_next_cell_stat(&cat, &count, statf))
+	if (count > 0)
+	    total += count;
+    if (total <= 0)
+	return;
+    sum = 0;
+    prev = 0;
+    first = 1;
+    while (Rast_next_cell_stat(&cat, &count, statf)) {
+	int red2, grn2, blu2;
+	DCELL x;
+	if (count <= 0)
+	    continue;
+	x = min + (max - min) * (sum + count / 2.0) / total;
+	Rast_get_d_raster_color(&x, &red2, &grn2, &blu2, src);
+	if (!first)
+	    Rast_add_color_rule(prev, red, grn, blu, cat, red2, grn2, blu2, dst);
+	sum += count;
+	first = 0;
+	prev = cat;
+	red = red2;
+	grn = grn2;
+	blu = blu2;
+ * \brief make histogram-stretched version of existing color table (FP version)
+ * information in the FP_stats structure <b>statf.</b>  (See
+ *  \param dst
+ *  \param src
+ *  \param statf
+ *  \return void
+void Rast_histogram_eq_colors_fp(struct Colors *dst,
+			      struct Colors *src, struct FP_stats *statf)
+    DCELL min, max;
+    unsigned long sum;
+    DCELL val;
+    int first;
+    int i;
+    if (!statf->total)
+	return;
+    sum = 0;
+    first = 1;
+    for (i = 0; i <= statf->count; i++) {
+	DCELL val2, x;
+	val2 = statf->min + (statf->max - statf->min) * i / statf->count;
+	if (statf->geometric)
+	    val2 = exp(val2);
+	if (statf->geom_abs)
+	    val2 = exp(val2) - 1;
+	if (statf->flip)
+	    val2 = -val2;
+	x = min + (max - min) * sum / statf->total;
+	if (!first)
+	    Rast_add_d_raster_color_rule(&val, red, grn, blu, &val2, red2, grn2, blu2, dst);
+	first = 0;
+	if (i == statf->count)
+	    break;
+	sum += statf->stats[i];
+	val = val2;
+	red = red2;
+	grn = grn2;
+	blu = blu2;
+ * \brief make logarithmically-scaled version of an existing color table
+ *  \param dst
+ *  \param src
+ *  \param samples
+ *  \return
+void Rast_log_colors(struct Colors *dst, struct Colors *src, int samples)
+    DCELL min, max;
+    double lmin, lmax;
+    DCELL prev;
+    int i;
+    lmin = log(min);
+    lmax = log(max);
+    for (i = 0; i <= samples; i++) {
+	double lx;
+	DCELL x, y;
+	y = min + (max - min) * i / samples;
+	Rast_get_d_raster_color(&y, &red2, &grn2, &blu2, src);
+	if (i == 0)
+	    x = min;
+	else if (i == samples)
+	    x = max;
+	else {
+	    lx = lmin + (lmax - lmin) * i / samples;
+	    x = exp(lx);
+	if (i > 0)
+	    Rast_add_d_raster_color_rule(&prev, red, grn, blu,
+				      &x, red2, grn2, blu2,
+				      dst);
+	prev = x;
+	red = red2;
+	grn = grn2;
+	blu = blu2;
+ * \brief make logarithmically-scaled version of an existing color table, allowing for signed values
+ *  \param dst
+ *  \param src
+ *  \param samples
+ *  \return
+void Rast_abs_log_colors(struct Colors *dst, struct Colors *src, int samples)
+    DCELL min, max;
+    DCELL amax, lamax;
+    DCELL prev;
+    int i;
+    lmin = log(fabs(min) + 1.0);
+    lmax = log(fabs(max) + 1.0);
+    amax = fabs(min) > fabs(max) ? fabs(min) : fabs(max);
+    lamax = lmin > lmax ? lmin : lmax;
+	double lx;
+	DCELL x, y;
+	if (i == 0)
+	    x = 1;
+	    x = amax;
+	else {
+	    lx = 0 + lamax * i / samples;
+	    x = exp(lx);
+	if (i > 0) {
+	    DCELL x0 = prev, x1 = x;
+	    Rast_add_d_raster_color_rule(&x0, red, grn, blu,
+				      &x1, red2, grn2, blu2,
+				      dst);
+	    x0 = -x0;
+	    x1 = -x1;
+				      dst);
+	prev = x;
+	red = red2;
+	grn = grn2;
+	blu = blu2;
Copied: grass/trunk/lib/raster/format.c (from rev 37989, grass/trunk/lib/gis/format.c)
--- grass/trunk/lib/raster/format.c	                        (rev 0)
+++ grass/trunk/lib/raster/format.c	2009-06-20 22:03:23 UTC (rev 38003)
@@ -0,0 +1,189 @@
+#include <unistd.h>
+#include <grass/config.h>
+#include "G.h"
+   <h3>GRASS Raster Format</h3>
+   Small example to illustrate the raster format:
+   A file may contain the following 3x3 floating point matrix:
+   \verbatim
+   10.000 20.000 30.000
+   20.000 40.000 50.000
+   30.000 50.000 60.000
+   \endverbatim
+   The header is a single byte, equal to sizeof(off_t) (typically 4 on a
+   32-bit platform, 8 on a 64-bit platform). Then, NROWS+1 offsets are
+   written as off_t's (i.e. 4 or 8 bytes, depending upon platform) in
+   big-endian (Motorola) byte order.
+   <P>
+   Thus, above example is actually interpreted as:
+   \verbatim
+   4               sizeof(off_t)
+   0 0 0 17        offset of row 0
+   0 0 0 36        offset of row 1
+   0 0 0 55        offset of row 2
+   0 0 0 74        offset of end of data
+   \endverbatim
+   See Rast__write_row_ptrs() below for the code which writes this data.
+   However, note that the row offsets are initially zero;
+   they get overwritten later (if you are writing compressed data,
+   you don't know how much space it will require until you've compressed
+   it).
+   As for the format of the actual row data, see put_fp_data() in
+   src/libes/gis/put_row.c and RFC 1014 (the XDR specification):
+   http://www.faqs.org/rfcs/rfc1014.html
+ *   Rast__check_format(int fd)
+ *   Check to see if map with file descriptor "fd" is in compressed
+ *   format.   If it is, the offset table at the beginning of the
+ *   file (which gives seek addresses into the file where code for
+ *   each row is found) is read into the File Control Buffer (FCB).
+ *   The compressed flag in the FCB is appropriately set.
+ *   returns:    1 if row pointers were read successfully, -1 otherwise
+int Rast__check_format(int fd)
+    struct fileinfo *fcb = &G__.fileinfo[fd];
+    unsigned char compress[4];
+     * Check to see if the file is in compress mode
+     * 4 possibilites
+     *   compressed flag in cellhd is negative (meaning pre 3.0 cell file)
+     *       compression flag is first 3 bytes of cell file
+     *   compression flag is 0 - not compressed
+     *   compression flag is 1 - compressed using RLE (int) or zlib (FP)
+     *   compression flag is 2 - compressed using zlib
+    if (fcb->cellhd.compressed < 0) {
+	if (read(fd, compress, 3) != 3
+	    || compress[0] != 251 || compress[1] != 255 || compress[2] != 251)
+	    fcb->cellhd.compressed = 0;
+    if (!fcb->cellhd.compressed)
+	return fd;
+    /* allocate space to hold the row address array */
+    fcb->row_ptr = G_calloc(fcb->cellhd.rows + 1, sizeof(off_t));
+    /* read the row address array */
+    return Rast__read_row_ptrs(fd);
+int Rast__read_row_ptrs(int fd)
+    int nrows = fcb->cellhd.rows;
+    unsigned char nbytes;
+    unsigned char *buf, *b;
+    int n;
+    int row;
+     * pre3.0 row addresses were written directly from the array of off_t's
+     * (this makes them machine dependent)
+	n = (nrows + 1) * sizeof(off_t);
+	if (read(fd, fcb->row_ptr, n) != n)
+	    goto badread;
+	return 1;
+     * 3.0 row address array is in a machine independent format
+     * (warning - the format will work even if the sizeof(off_t) is
+     *  not the same from machine to machine, as long as the
+     *  actual values do not exceed the capability of the off_t)
+    if (read(fd, &nbytes, 1) != 1)
+	goto badread;
+    if (nbytes == 0)
+	goto badread;
+    n = (nrows + 1) * nbytes;
+    buf = G_malloc(n);
+    if (read(fd, buf, n) != n)
+	goto badread;
+    for (row = 0, b = buf; row <= nrows; row++) {
+	off_t v = 0;
+	for (n = 0; n < (int)nbytes; n++) {
+	    unsigned char c = *b++;
+	    if (nbytes > sizeof(off_t) && n < nbytes - sizeof(off_t) &&
+		c != 0)
+		goto badread;
+	    v <<= 8;
+	    v += c;
+	fcb->row_ptr[row] = v;
+    G_free(buf);
+    return 1;
+  badread:
+    G_warning(_("Fail of initial read of compressed file [%s in %s]"),
+	      fcb->name, fcb->mapset);
+    return -1;
+int Rast__write_row_ptrs(int fd)
+    int nbytes = sizeof(off_t);
+    int len, row, result;
+    lseek(fd, 0L, SEEK_SET);
+    len = (nrows + 1) * nbytes + 1;
+    b = buf = G_malloc(len);
+    *b++ = nbytes;
+    for (row = 0; row <= nrows; row++) {
+	off_t v = fcb->row_ptr[row];
+	int i;
+	for (i = nbytes - 1; i >= 0; i--) {
+	    b[i] = v & 0xff;
+	    v >>= 8;
+	b += nbytes;
+    result = (write(fd, buf, len) == len);
+    G_free(buf);
+    return result;
Copied: grass/trunk/lib/raster/fpreclass.c (from rev 37989, grass/trunk/lib/gis/fpreclass.c)
--- grass/trunk/lib/raster/fpreclass.c	                        (rev 0)
+++ grass/trunk/lib/raster/fpreclass.c	2009-06-20 22:03:23 UTC (rev 38003)
@@ -0,0 +1,720 @@
+ *  Rast_fpreclass_init (r)
+ *       struct FPReclass *r;
+ *  initializes new reclassification structure. calls
+ *  Rast_fpreclass_clear() before it returns.
+ *  void
+ *  Rast_fpreclass_reset (r)
+ *  resets the number of defined rules to 0 and free's space allocated
+ *  for rules. calls Rast_fpreclass_clear ().
+ *  void
+ *  Rast_fpreclass_clear (r)
+ *  resets the number of defined rules to 0. Resets default Min and Max
+ *  to be unknown. (see Rast_fpreclass_set_domain (), Rast_fpreclass_set_range ()).
+ *  deactivates default mapping.
+ *  void
+ *  Rast_fpreclass_set_domain (r, dLow, dHigh)
+ *       DCELL dLow, dHigh;
+ *  defines the domain for the default mapping and
+ *  activates default mapping. (see G_fpreclass_perform_d ()).
+ *  note: dHigh < dLow is valid.
+ *  void
+ *  Rast_fpreclass_set_range (r, low, high)
+ *       DCELL low, high;
+ *  defines the range for the default mapping. does NOT
+ *  activate default mapping. (see G_fpreclass_perform_d ()).
+ *  int
+ *  Rast_fpreclass_get_limits (r, dMin, dMax, rMin, rmax)
+ *       const struct FPReclass *r;
+ *       DCELL *dMin, *dMax;
+ *       DCELL *rMin, *rmax;
+ *  returns the minimum and maximum values of all the rules defined.
+ *  returns: -1 if after Rast_fpreclass_init (), or any call to
+ *                 Rast_fpreclass_clear () or Rast_fpreclass_reset () neither
+ *                 Rast_fpreclass_add_rule () nor Rast_fpreclass_set_domain () is
+ *                 used. in this case the returned minimum and maximum
+ *                 range and domain values are undefined.
+ *            0 if the default rule values are returned.domain values
+ *                 are identical to those set with Rast_fpreclass_set_domain ().
+ *                 range values are either reclassification internal default,
+ *                 or the values set with Rast_fpreclass_set_range ().
+ *            1 otherwise. in this case the values returned correspond
+ *                 to the extreme values of the defined rules (they need
+ *                 not be identical to the values set with
+ *                 Rast_fpreclass_set_domain ()).
+ *  int
+ *  Rast_fpreclass_nof_rules (r)
+ *  returns the number of reclassification rules defined. This number does
+ *  not include the 2 infinite intervals.
+ *  void
+ *  Rast_fpreclass_get_ith_rule (r, i, dLow, dHigh, rLow, rHigh)
+ *       int i;
+ *       DCELL *dLow, *dHigh;
+ *       DCELL *rLow, *rHigh;
+ *  returns the i'th reclassification rule, for
+ *  0 <= i < Rast_fpreclass_nof_rules().
+ *  a larger value for i means that the rule has been added later.
+ *   void
+ *   Rast_fpreclass_set_neg_infinite_rule (r, dLeft, c)
+ *       DCELL dLeft;
+ *       DCELL c;
+ *   defines a rule for values "dLeft" and smaller. values in this range
+ *   are mapped to "c" if none of the "finite" reclassification rules applies.
+ *  int
+ *  Rast_fpreclass_get_neg_infinite_rule (r, dLeft, c)
+ *       DCELL *dLeft;
+ *       DCELL *c;
+ *  returns in "dLeft" and "c" the rule values for the negative infinite
+ *  interval (see Rast_fpreclass_set_neg_infinite_rule ()).
+ *  returns: 0 if this rule is not defined
+ *           1 otherwise.
+ *   void
+ *   Rast_fpreclass_set_pos_infinite_rule (r, dRight, c)
+ *       DCELL dRight;
+ *       DCELL c;
+ *   defines a rule for values "dRight" and larger. values in this range
+ *   are mapped to "c" if neither any of the "finite" reclassification
+ *   rules nor the negative infinite rule applies.
+ *  int
+ *  Rast_fpreclass_get_pos_infinite_rule (r, dRight, c)
+ *       DCELL *dRight;
+ *       DCELL *c;
+ *  returns in "dRight" and "c" the rule values for the positive infinite
+ *  interval (see Rast_fpreclass_set_pos_infinite_rule ()).
+ *           1 otherwise.
+ *  void
+ *  Rast_fpreclass_reverse_rule_order (r)
+ *  reverses the order in which the reclassification rules are stored. (see
+ *  also Rast_fpreclass_get_ith_rule () and G_fpreclass_perform_XY ()).
+ *  void
+ *  Rast_fpreclass_add_rule (r, dLow, dHigh, rLow, rHigh)
+ *       DCELL rLow, rHigh;
+ *  adds a new rule to the set of reclassification rules. if dLow > dHigh
+ *  the rule will be stored with the low and high values interchanged.
+ *  Note: currently no cleanup of rules is performed, i.e. redundant
+ *        rules are not removed.
+ *  DCELL
+ *  Rast_fpreclass_get_cell_value (r, cellValue)
+ *       DCELL *cellValue;
+ *  returns the reclassified value corresponding to "cellValue".
+ *  if several reclassification rules apply for cellValue, the one which has
+ *  been inserted latest (i.e. the one of them which is returned by
+ *  Rast_fpreclass_get_ith_rule() for the largest i) is used. if no such rule
+ *  applies the cellValue is first tested against the negative infinite
+ *  rule, and finally against the positive infinite rule. if none of
+ *  these rules apply, NO_DATA is returned. the actual value of NO_DATA
+ *  is found by calling Rast_set_d_null_value()
+ *  if after Rast_fpreclass_init (), or any call to Rast_fpreclass_clear () or
+ *  Rast_fpreclass_reset () neither Rast_fpreclass_add_rule (),
+ *  Rast_fpreclass_set_neg_infinite_rule (),
+ *  Rast_fpreclass_set_pos_infinite_rule (), *  nor  Rast_fpreclass_set_domain ()
+ *  is used NO_DATA is returned independently of the cellValue.
+ *  if Rast_fpreclass_set_domain () is called but no explicit reclassification
+ *  rule is set, the default mapping to the cell range set with
+ *  Rast_fpreclass_set_range () or, if the cell range is not set,
+ *  to the default CELL range [0,256 - 1] is applied.
+ *  void
+ *  G_fpreclass_perform_XY (r, xcell, ycell, n)
+ *       XCELL *xcell;
+ *       YCELL *ycell;
+ *       int n;
+ *  "X" and "Y" in the function name can be any of "d", "f", or "i". These
+ *  correspond to "DCELL", "FCELL", and "CELL", respectively, and denote
+ *  the type of the domain and range values.
+ *  returns in "ycell" the reclassified YCELL values corresponding to the
+ *  XCELL values stored in "xcell". the number of elements reclassified
+ *  is n. reclassification is performed by repeated application of
+ *  Rast_fpreclass_get_cell_value ().
+   the reclassification table is stored as a linear array. rules are added
+   starting from index 0. redundant rules are not eliminated. rules are tested
+   from the highest index downto 0. there are two "infinite" rules. support is
+   provided to reverse the order of the rules.
+#undef MIN
+#undef MAX
+#define MIN(a,b) ((a) < (b) ? (a) : (b))
+#define MAX(a,b) ((a) > (b) ? (a) : (b))
+#define NO_DEFAULT_RULE (! r->defaultDRuleSet)
+#define NO_LEFT_INFINITE_RULE (! r->infiniteLeftSet)
+#define NO_RIGHT_INFINITE_RULE (! r->infiniteRightSet)
+#define NO_FINITE_RULE (r->nofRules <= 0)
+#define NO_EXPLICIT_RULE (NO_FINITE_RULE && \
+			  NO_LEFT_INFINITE_RULE && NO_RIGHT_INFINITE_RULE)
+#define DEFAULT_MIN ((DCELL) 1)
+#define DEFAULT_MAX ((DCELL) 255)
+void Rast_fpreclass_clear(struct FPReclass *r)
+    r->nofRules = 0;
+    r->defaultDRuleSet = 0;
+    r->defaultRRuleSet = 0;
+    r->infiniteRightSet = r->infiniteLeftSet = 0;
+void Rast_fpreclass_reset(struct FPReclass *r)
+    Rast_fpreclass_clear(r);
+    if (r->maxNofRules > 0)
+	G_free(r->table);
+    r->maxNofRules = 0;
+void Rast_fpreclass_init(struct FPReclass *r)
+    Rast_fpreclass_reset(r);
+void Rast_fpreclass_set_domain(struct FPReclass *r, DCELL dLow, DCELL dHigh)
+    r->defaultDMin = dLow;
+    r->defaultDMax = dHigh;
+    r->defaultDRuleSet = 1;
+void Rast_fpreclass_set_range(struct FPReclass *r, DCELL low, DCELL high)
+    r->defaultRMin = low;
+    r->defaultRMax = high;
+    r->defaultRRuleSet = 1;
+static void fpreclass_set_limits(struct FPReclass *r,
+				 DCELL dLow, DCELL dHigh,
+				 DCELL rLow, DCELL rHigh)
+    r->dMin = dLow;
+    r->dMax = dHigh;
+    r->rMin = rLow;
+    r->rMax = rHigh;
+static void fpreclass_update_limits(struct FPReclass *r,
+    if (NO_EXPLICIT_RULE) {
+	fpreclass_set_limits(r, dLow, dHigh, rLow, rHigh);
+	return;
+    r->dMin = MIN(r->dMin, MIN(dLow, dHigh));
+    r->dMax = MAX(r->dMax, MAX(dLow, dHigh));
+    r->rMin = MIN(r->rMin, MIN(rLow, rHigh));
+    r->rMax = MAX(r->rMax, MAX(rLow, rHigh));
+int Rast_fpreclass_get_limits(const struct FPReclass *r,
+			   DCELL * dMin, DCELL * dMax,
+			   DCELL * rMin, DCELL * rMax)
+	if (NO_DEFAULT_RULE)
+	    return -1;
+	*dMin = r->defaultDMin;
+	*dMax = r->defaultDMax;
+	if (r->defaultRRuleSet) {
+	    *rMin = r->defaultRMin;
+	    *rMax = r->defaultRMax;
+	else {
+	    *rMin = DEFAULT_MIN;
+	    *rMax = DEFAULT_MAX;
+	return 0;
+    *dMin = r->dMin;
+    *dMax = r->dMax;
+    *rMin = r->rMin;
+    *rMax = r->rMax;
+    return 1;
+int Rast_fpreclass_nof_rules(const struct FPReclass *r)
+    return r->nofRules;
+void Rast_fpreclass_get_ith_rule(const struct FPReclass *r, int i,
+			      DCELL *dLow, DCELL *dHigh,
+			      DCELL *rLow, DCELL *rHigh)
+    *dLow = r->table[i].dLow;
+    *dHigh = r->table[i].dHigh;
+    *rLow = r->table[i].rLow;
+    *rHigh = r->table[i].rHigh;
+static void fpreclass_table_increase(struct FPReclass *r)
+    if (r->nofRules < r->maxNofRules)
+	return;
+    if (r->maxNofRules == 0) {
+	r->maxNofRules = 50;
+	r->table = (struct FPReclass_table *)
+	    G_malloc(r->maxNofRules * sizeof(struct FPReclass_table));
+    else {
+	r->maxNofRules += 50;
+	    G_realloc((char *)r->table,
+		      r->maxNofRules * sizeof(struct FPReclass_table));
+void
+Rast_fpreclass_set_neg_infinite_rule(struct FPReclass *r, DCELL dLeft, DCELL c)
+    r->infiniteDLeft = dLeft;
+    r->infiniteRLeft = c;
+    fpreclass_update_limits(r, dLeft, dLeft, c, c);
+    r->infiniteLeftSet = 1;
+int Rast_fpreclass_get_neg_infinite_rule(const struct FPReclass *r,
+				      DCELL *dLeft, DCELL *c)
+    if (r->infiniteLeftSet == 0)
+	return 0;
+    *dLeft = r->infiniteDLeft;
+    *c = r->infiniteRLeft;
+    return 1;
+void Rast_fpreclass_set_pos_infinite_rule(struct FPReclass *r, DCELL dRight, DCELL c)
+    r->infiniteDRight = dRight;
+    r->infiniteRRight = c;
+    fpreclass_update_limits(r, dRight, dRight, c, c);
+    r->infiniteRightSet = 1;
+int Rast_fpreclass_get_pos_infinite_rule(const struct FPReclass *r,
+				      DCELL *dRight, DCELL *c)
+    if (r->infiniteRightSet == 0)
+	return 0;
+    *dRight = r->infiniteDRight;
+    *c = r->infiniteRRight;
+    return 1;
+void Rast_fpreclass_add_rule(struct FPReclass *r,
+    int i;
+    struct FPReclass_table *p;
+    fpreclass_table_increase(r);
+    i = r->nofRules;
+    p = &(r->table[i]);
+    if (dHigh >= dLow) {
+	p->dLow = dLow;
+	p->dHigh = dHigh;
+	p->rLow = rLow;
+	p->rHigh = rHigh;
+    else {
+	p->dLow = dHigh;
+	p->dHigh = dLow;
+	p->rLow = rHigh;
+	p->rHigh = rLow;
+    fpreclass_update_limits(r, dLow, dHigh, rLow, rHigh);
+    r->nofRules++;
+void Rast_fpreclass_reverse_rule_order(struct FPReclass *r)
+    struct FPReclass_table tmp;
+    struct FPReclass_table *pLeft, *pRight;
+    pLeft = r->table;
+    pRight = &(r->table[r->nofRules - 1]);
+    while (pLeft < pRight) {
+	tmp.dLow = pLeft->dLow;
+	tmp.dHigh = pLeft->dHigh;
+	tmp.rLow = pLeft->rLow;
+	tmp.rHigh = pLeft->rHigh;
+	pLeft->dLow = pRight->dLow;
+	pLeft->dHigh = pRight->dHigh;
+	pLeft->rLow = pRight->rLow;
+	pLeft->rHigh = pRight->rHigh;
+	pRight->dLow = tmp.dLow;
+	pRight->dHigh = tmp.dHigh;
+	pRight->rLow = tmp.rLow;
+	pRight->rHigh = tmp.rHigh;
+	pLeft++;
+	pRight--;
+static DCELL fpreclass_interpolate(
+    DCELL rLow, DCELL rHigh,
+    DCELL dValue)
+    if (rLow == rHigh)
+	return rLow;
+    if (dLow == dHigh)
+	return rLow;
+    return ((dValue - dLow) / (dHigh - dLow) * (rHigh - rLow) + rLow);
+static DCELL fpreclass_get_default_cell_value(const struct FPReclass *r, DCELL cellVal)
+    DCELL tmp;
+    Rast_set_d_null_value(&tmp, 1);
+    if ((cellVal < MIN(r->defaultDMin, r->defaultDMax)) ||
+	(cellVal > MAX(r->defaultDMin, r->defaultDMax)))
+	return tmp;
+	return fpreclass_interpolate(r->defaultDMin, r->defaultDMax,
+				     r->defaultRMin, r->defaultRMax, cellVal);
+    else
+				     DEFAULT_MIN, DEFAULT_MAX, cellVal);
+DCELL Rast_fpreclass_get_cell_value(const struct FPReclass * r, DCELL cellVal)
+    DCELL tmp;
+    const struct FPReclass_table *p;
+	    return tmp;
+	return fpreclass_get_default_cell_value(r, cellVal);
+    if (!NO_FINITE_RULE)
+	for (p = &(r->table[r->nofRules - 1]); p >= r->table; p--)
+	    if ((cellVal >= p->dLow) && (cellVal <= p->dHigh))
+		return fpreclass_interpolate(p->dLow, p->dHigh, p->rLow,
+					     p->rHigh, cellVal);
+    if ((!NO_LEFT_INFINITE_RULE) && (cellVal <= r->infiniteDLeft))
+	return r->infiniteRLeft;
+    if ((NO_RIGHT_INFINITE_RULE) || (cellVal < r->infiniteDRight))
+	return tmp;
+    return r->infiniteRRight;
+void Rast_fpreclass_perform_di(const struct FPReclass *r,
+			    const DCELL *dcell, CELL *cell, int n)
+    int i;
+    for (i = 0; i < n; i++, dcell++)
+	if (!Rast_is_d_null_value(dcell))
+	    *cell++ = Rast_fpreclass_get_cell_value(r, *dcell);
+	else
+	    Rast_set_c_null_value(cell++, 1);
+void Rast_fpreclass_perform_df(const struct FPReclass *r,
+			    const DCELL *dcell, FCELL *cell, int n)
+    int i;
+	else
+	    Rast_set_f_null_value(cell++, 1);
+void Rast_fpreclass_perform_dd(const struct FPReclass *r,
+			    const DCELL *dcell, DCELL *cell, int n)
+    int i;
+	else
+	    Rast_set_d_null_value(cell++, 1);
+void Rast_fpreclass_perform_fi(const struct FPReclass *r,
+			    const FCELL *fcell, CELL *cell, int n)
+    int i;
+    for (i = 0; i < n; i++, fcell++)
+	if (!Rast_is_f_null_value(fcell))
+	    *cell++ = Rast_fpreclass_get_cell_value(r, (DCELL) * fcell);
+	else
+void Rast_fpreclass_perform_ff(const struct FPReclass *r,
+			    const FCELL *fcell, FCELL *cell, int n)
+    int i;
+	else
+void Rast_fpreclass_perform_fd(const struct FPReclass *r,
+			    const FCELL *fcell, DCELL *cell, int n)
+    int i;
+	else
+void Rast_fpreclass_perform_ii(const struct FPReclass *r,
+			    const CELL *icell, CELL *cell, int n)
+    int i;
+    for (i = 0; i < n; i++, icell++)
+	if (!Rast_is_c_null_value(icell))
+	    *cell++ = Rast_fpreclass_get_cell_value(r, (DCELL) * icell);
+	else
+void Rast_fpreclass_perform_if(const struct FPReclass *r,
+			    const CELL *icell, FCELL *cell, int n)
+    int i;
+	else
+void Rast_fpreclass_perform_id(const struct FPReclass *r,
+			    const CELL *icell, DCELL *cell, int n)
+    int i;
+	else
Copied: grass/trunk/lib/raster/gdal.c (from rev 37989, grass/trunk/lib/gis/gdal.c)
--- grass/trunk/lib/raster/gdal.c	                        (rev 0)
+++ grass/trunk/lib/raster/gdal.c	2009-06-20 22:03:23 UTC (rev 38003)
@@ -0,0 +1,533 @@
+#include <stdlib.h>
+#include <string.h>
+#include "G.h"
+#ifndef HAVE_GDAL
+#undef GDAL_LINK
+#endif
+#ifdef GDAL_LINK
+#ifdef GDAL_DYNAMIC
+# if defined(__unix) || defined(__unix__)
+#  include <dlfcn.h>
+# endif
+# ifdef _WIN32
+#  include <windows.h>
+# endif
+#endif
+static void CPL_STDCALL (*pGDALAllRegister)(void);
+static void CPL_STDCALL (*pGDALClose)(GDALDatasetH);
+static GDALRasterBandH CPL_STDCALL (*pGDALGetRasterBand)(GDALDatasetH, int);
+static GDALDatasetH CPL_STDCALL (*pGDALOpen)(
+    const char *pszFilename, GDALAccess eAccess);
+static CPLErr CPL_STDCALL (*pGDALRasterIO)(
+    GDALRasterBandH hRBand, GDALRWFlag eRWFlag,
+    int nDSXOff, int nDSYOff, int nDSXSize, int nDSYSize,
+    void * pBuffer, int nBXSize, int nBYSize,GDALDataType eBDataType,
+    int nPixelSpace, int nLineSpace);
+static GDALDriverH CPL_STDCALL (*pGDALGetDriverByName)(const char *);
+static const char * CPL_STDCALL (*pGDALGetMetadataItem)(GDALMajorObjectH, const char *, const char *);
+static GDALDatasetH CPL_STDCALL (*pGDALCreate)(GDALDriverH hDriver, const char *, int, int, int, GDALDataType, char **);
+static GDALDatasetH CPL_STDCALL (*pGDALCreateCopy)(GDALDriverH, const char *, GDALDatasetH, int, char **, GDALProgressFunc, void *);
+static CPLErr CPL_STDCALL (*pGDALSetRasterNoDataValue)(GDALRasterBandH, double);
+static CPLErr CPL_STDCALL (*pGDALSetGeoTransform)(GDALDatasetH, double *);
+static CPLErr CPL_STDCALL (*pGDALSetProjection)(GDALDatasetH, const char *);
+static const char * CPL_STDCALL (*pGDALGetDriverShortName)(GDALDriverH);
+static GDALDriverH CPL_STDCALL (*pGDALGetDatasetDriver)(GDALDatasetH);
+#if GDAL_DYNAMIC
+# if defined(__unix) && !defined(__unix__)
+#  define __unix__ __unix
+# endif
+static void *library_h;
+static void *get_symbol(const char *name)
+    void *sym;
+# ifdef __unix__
+    sym = dlsym(library_h, name);
+# endif
+# ifdef _WIN32
+    sym = GetProcAddress((HINSTANCE) library_h, name);
+# endif
+    if (!sym)
+	G_fatal_error(_("Unable to locate symbol <%s>"), name);
+    return sym;
+static void try_load_library(const char *name)
+# ifdef __unix__
+    library_h = dlopen(name, RTLD_NOW);
+# endif
+# ifdef _WIN32
+    library_h = LoadLibrary(name);
+# endif
+static void load_library(void)
+    static const char * const candidates[] = {
+# ifdef __unix__
+	"libgdal.1.1.so",
+	"gdal.1.0.so",
+	"gdal.so.1.0",
+	"libgdal.so.1",
+	"libgdal.so",
+# endif
+# ifdef _WIN32
+	"gdal11.dll",
+	"gdal.1.0.dll",
+	"gdal.dll",
+# endif
+	NULL
+    int i;
+    for (i = 0; candidates[i]; i++) {
+	try_load_library(candidates[i]);
+	if (library_h)
+	    return;
+    G_fatal_error(_("Unable to load GDAL library"));
+static void init_gdal(void)
+    load_library();
+    pGDALAllRegister          = get_symbol("GDALAllRegister");
+    pGDALOpen                 = get_symbol("GDALOpen");
+    pGDALClose                = get_symbol("GDALClose");
+    pGDALGetRasterBand        = get_symbol("GDALGetRasterBand");
+    pGDALRasterIO             = get_symbol("GDALRasterIO");
+    pGDALGetDriverByName      = get_symbol("GDALGetDriverByName");
+    pGDALGetMetadataItem      = get_symbol("GDALGetMetadataItem");
+    pGDALCreate               = get_symbol("GDALCreate");
+    pGDALCreateCopy           = get_symbol("GDALCreateCopy");
+    pGDALSetRasterNoDataValue = get_symbol("GDALSetRasterNoDataValue");
+    pGDALSetGeoTransform      = get_symbol("GDALSetGeoTransform");
+    pGDALSetProjection        = get_symbol("GDALSetProjection");
+    pGDALGetDriverShortName   = get_symbol("GDALGetDriverShortName");
+    pGDALGetDatasetDriver     = get_symbol("GDALGetDatasetDriver");
+#else /* GDAL_DYNAMIC */
+    pGDALAllRegister          = &GDALAllRegister;
+    pGDALOpen                 = &GDALOpen;
+    pGDALClose                = &GDALClose;
+    pGDALGetRasterBand        = &GDALGetRasterBand;
+    pGDALRasterIO             = &GDALRasterIO;
+    pGDALGetDriverByName      = &GDALGetDriverByName;
+    pGDALGetMetadataItem      = &GDALGetMetadataItem;
+    pGDALCreate               = &GDALCreate;
+    pGDALCreateCopy           = &GDALCreateCopy;
+    pGDALSetRasterNoDataValue = &GDALSetRasterNoDataValue;
+    pGDALSetGeoTransform      = &GDALSetGeoTransform;
+    pGDALSetProjection        = &GDALSetProjection;
+    pGDALGetDriverShortName   = &GDALGetDriverShortName;
+    pGDALGetDatasetDriver     = &GDALGetDatasetDriver;
+#endif /* GDAL_DYNAMIC */
+#endif /* GDAL_LINK */
+void Rast_init_gdal(void)
+#ifdef GDAL_LINK
+    static int initialized;
+    if (G_is_initialized(&initialized))
+	return;
+    init_gdal();
+    (*pGDALAllRegister)();
+    G_initialize_done(&initialized);
+#endif
+struct GDAL_link *Rast_get_gdal_link(const char *name, const char *mapset)
+#ifdef GDAL_LINK
+    GDALDatasetH data;
+    GDALRasterBandH band;
+    GDALDataType type;
+    RASTER_MAP_TYPE req_type;
+#endif
+    const char *filename;
+    int band_num;
+    struct GDAL_link *gdal;
+    RASTER_MAP_TYPE map_type;
+    FILE *fp;
+    struct Key_Value *key_val;
+    const char *p;
+    DCELL null_val;
+    int hflip, vflip;
+    if (!G_find_cell2(name, mapset))
+	return NULL;
+    map_type = Rast_raster_map_type(name, mapset);
+    if (map_type < 0)
+	return NULL;
+    fp = G_fopen_old_misc("cell_misc", "gdal", name, mapset);
+    if (!fp)
+	return NULL;
+    key_val = G_fread_key_value(fp);
+    fclose(fp);
+    if (!key_val)
+	return NULL;
+    filename = G_find_key_value("file", key_val);
+    if (!filename)
+	return NULL;
+    p = G_find_key_value("band", key_val);
+    if (!p)
+	return NULL;
+    band_num = atoi(p);
+    if (!band_num)
+	return NULL;
+    p = G_find_key_value("null", key_val);
+    if (!p)
+	return NULL;
+    if (strcmp(p, "none") == 0)
+	Rast_set_d_null_value(&null_val, 1);
+    else
+	null_val = atof(p);
+    hflip = G_find_key_value("hflip", key_val) ? 1 : 0;
+    vflip = G_find_key_value("vflip", key_val) ? 1 : 0;
+#ifdef GDAL_LINK
+    p = G_find_key_value("type", key_val);
+    if (!p)
+	return NULL;
+    type = atoi(p);
+    switch (type) {
+    case GDT_Byte:
+    case GDT_Int16:
+    case GDT_UInt16:
+    case GDT_Int32:
+    case GDT_UInt32:
+	req_type = CELL_TYPE;
+	break;
+    case GDT_Float32:
+	req_type = FCELL_TYPE;
+	break;
+    case GDT_Float64:
+	req_type = DCELL_TYPE;
+	break;
+    default:
+	return NULL;
+    if (req_type != map_type)
+	return NULL;
+    Rast_init_gdal();
+    data = (*pGDALOpen)(filename, GA_ReadOnly);
+    if (!data)
+	return NULL;
+    band = (*pGDALGetRasterBand)(data, band_num);
+    if (!band) {
+	(*pGDALClose)(data);
+	return NULL;
+#endif
+    gdal = G_calloc(1, sizeof(struct GDAL_link));
+    gdal->filename = G_store(filename);
+    gdal->band_num = band_num;
+    gdal->null_val = null_val;
+    gdal->hflip = hflip;
+    gdal->vflip = vflip;
+#ifdef GDAL_LINK
+    gdal->data = data;
+    gdal->band = band;
+    gdal->type = type;
+#endif
+    return gdal;
+struct GDAL_Options {
+    const char *dir;
+    const char *ext;
+    const char *format;
+    char **options;
+static struct state {
+    int initialized;
+    struct GDAL_Options opts;
+    struct Key_Value *projinfo, *projunits;
+    char *srswkt;
+} state;
+static struct state *st = &state;
+static void read_gdal_options(void)
+    FILE *fp;
+    const char *p;
+    fp = G_fopen_old("", "GDAL", G_mapset());
+    if (!fp)
+	G_fatal_error(_("Unable to open GDAL file"));
+    fclose(fp);
+    p = G_find_key_value("directory", key_val);
+    if (!p)
+	p = "gdal";
+    if (*p == '/') {
+	st->opts.dir = G_store(p);
+    else {
+	G__file_name(path, p, "", G_mapset());
+	st->opts.dir = G_store(path);
+	if (access(path, 0) != 0)
+	    G__make_mapset_element(p);
+    p = G_find_key_value("extension", key_val);
+    st->opts.ext = G_store(p ? p : "");
+    p = G_find_key_value("format", key_val);
+    st->opts.format = G_store(p ? p : "GTiff");
+    p = G_find_key_value("options", key_val);
+    st->opts.options = p ? G_tokenize(p, ",") : NULL;
+    G_free_key_value(key_val);
+struct GDAL_link *Rast_create_gdal_link(const char *name, RASTER_MAP_TYPE map_type)
+#ifdef GDAL_LINK
+    GDALDriverH driver;
+    double transform[6];
+    FILE *fp;
+    char buf[32];
+    Rast_init_gdal();
+    if (!G_is_initialized(&st->initialized)) {
+	read_gdal_options();
+	st->projinfo = G_get_projinfo();
+	st->projunits = G_get_projunits();
+#if 0
+	/* We cannot use GPJ_grass_to_wkt() here because that would create a
+	   circular dependency between libgis and libgproj */
+	if (st->projinfo && st->projunits)
+	    st->srswkt = GPJ_grass_to_wkt(st->projinfo, st->projunits);
+#endif
+	G_initialize_done(&st->initialized);
+    sprintf(path, "%s/%s%s", st->opts.dir, name, st->opts.ext);
+    gdal->filename = G_store(path);
+    gdal->band_num = 1;
+    gdal->hflip = 0;
+    gdal->vflip = 0;
+    switch (map_type) {
+    case CELL_TYPE:
+	switch (G__.nbytes) {
+	case 1:
+	    gdal->type = GDT_Byte;
+	    gdal->null_val = (DCELL) 0xFF;
+	    break;
+	case 2:
+	    gdal->type = GDT_UInt16;
+	    gdal->null_val = (DCELL) 0xFFFF;
+	    break;
+	case 3:
+	case 4:
+	    gdal->type = GDT_Int32;
+	    gdal->null_val = (DCELL) 0x80000000U;
+	    break;
+	break;
+    case FCELL_TYPE:
+	gdal->type = GDT_Float32;
+	Rast_set_d_null_value(&gdal->null_val, 1);
+	break;
+    case DCELL_TYPE:
+	gdal->type = GDT_Float64;
+	break;
+    default:
+	G_fatal_error(_("Invalid map type <%d>"), map_type);
+	break;
+    driver = (*pGDALGetDriverByName)(st->opts.format);
+    if (!driver)
+	G_fatal_error(_("Unable to get <%s> driver"), st->opts.format);
+    /* Does driver support GDALCreate ? */
+    if ((*pGDALGetMetadataItem)(driver, GDAL_DCAP_CREATE, NULL))
+	gdal->data = (*pGDALCreate)(driver, gdal->filename, G__.window.cols, G__.window.rows,
+				1, gdal->type, st->opts.options);
+	if (!gdal->data)
+	    G_fatal_error(_("Unable to create <%s> dataset using <%s> driver"),
+			  name, st->opts.format);
+    /* If not - create MEM driver for intermediate dataset.
+     * Check if raster can be created at all (with GDALCreateCopy) */
+    else if ((*pGDALGetMetadataItem)(driver, GDAL_DCAP_CREATECOPY, NULL)) {
+	GDALDriverH mem_driver;
+	G_message(_("Driver <%s> does not support direct writing. "
+		    "Using MEM driver for intermediate dataset."),
+		  st->opts.format);
+	mem_driver = (*pGDALGetDriverByName)("MEM");
+	if (!mem_driver)
+	    G_fatal_error(_("Unable to get in-memory raster driver"));
+	gdal->data = (*pGDALCreate)(mem_driver, "", G__.window.cols, G__.window.rows,
+	if (!gdal->data)
+	    G_fatal_error(_("Unable to create <%s> dataset using memory driver"),
+			  name);
+    else
+	G_fatal_error(_("Driver <%s> does not support creating rasters"),
+		      st->opts.format);
+    gdal->band = (*pGDALGetRasterBand)(gdal->data, gdal->band_num);
+    (*pGDALSetRasterNoDataValue)(gdal->band, gdal->null_val);
+    /* Set Geo Transform  */
+    transform[0] = G__.window.west;
+    transform[1] = G__.window.ew_res;
+    transform[2] = 0.0;
+    transform[3] = G__.window.north;
+    transform[4] = 0.0;
+    transform[5] = -G__.window.ns_res;
+    if ((*pGDALSetGeoTransform)(gdal->data, transform) >= CE_Failure)
+	G_warning(_("Unable to set geo transform"));
+    if (st->srswkt)
+	if ((*pGDALSetProjection)(gdal->data, st->srswkt) == CE_Failure)
+	    G_warning(_("Unable to set projection"));
+    fp = G_fopen_new_misc("cell_misc", "gdal", name);
+    if (!fp)
+	G_fatal_error(_("Unable to create cell_misc/%s/gdal file"), name);
+    key_val = G_create_key_value();
+    G_set_key_value("file", gdal->filename, key_val);
+    sprintf(buf, "%d", gdal->band_num);
+    G_set_key_value("band", buf, key_val);
+    sprintf(buf, "%.22g", gdal->null_val);
+    G_set_key_value("null", buf, key_val);
+    sprintf(buf, "%d", gdal->type);
+    G_set_key_value("type", buf, key_val);
+    if (G_fwrite_key_value(fp, key_val) < 0)
+	G_fatal_error(_("Error writing cell_misc/%s/gdal file"), name);
+    fclose(fp);
+    return gdal;
+#else
+    return NULL;
+#endif
+void Rast_close_gdal_link(struct GDAL_link *gdal)
+#ifdef GDAL_LINK
+    (*pGDALClose)(gdal->data);
+#endif
+    G_free(gdal->filename);
+    G_free(gdal);
+int Rast_close_gdal_write_link(struct GDAL_link *gdal)
+    int stat = 1;
+#ifdef GDAL_LINK
+    GDALDriverH src_drv = (*pGDALGetDatasetDriver)(gdal->data);
+    if (G_strcasecmp((*pGDALGetDriverShortName)(src_drv), "MEM") == 0) {
+	GDALDriverH dst_drv = (*pGDALGetDriverByName)(st->opts.format);
+	GDALDatasetH dst = (*pGDALCreateCopy)(dst_drv, gdal->filename, gdal->data, FALSE,
+					      st->opts.options, NULL, NULL);
+	if (!dst) {
+	    G_warning(_("Unable to create output file <%s> using driver <%s>"),
+		      gdal->filename, st->opts.format);
+	    stat = -1;
+	(*pGDALClose)(dst);
+#endif
+    G_free(gdal);
+    return stat;
+#ifdef GDAL_LINK
+CPLErr G_gdal_raster_IO(
+    GDALRasterBandH band, GDALRWFlag rw_flag,
+    int x_off, int y_off, int x_size, int y_size,
+    void *buffer, int buf_x_size, int buf_y_size, GDALDataType buf_type,
+    int pixel_size, int line_size)
+    return (*pGDALRasterIO)(
+	band, rw_flag, x_off, y_off, x_size, y_size,
+	buffer, buf_x_size, buf_y_size, buf_type,
+	pixel_size, line_size);
+#endif
Copied: grass/trunk/lib/raster/get_cellhd.c (from rev 37989, grass/trunk/lib/gis/get_cellhd.c)
--- grass/trunk/lib/raster/get_cellhd.c	                        (rev 0)
+++ grass/trunk/lib/raster/get_cellhd.c	2009-06-20 22:03:23 UTC (rev 38003)
@@ -0,0 +1,97 @@
+  \file gis/get_cellhd.c
+  \brief GIS library - Read raster map header
+  (C) 2001-2009 by the GRASS Development Team
+  This program is free software under the GNU General Public License
+  (>=v2).  Read the file COPYING that comes with GRASS for details.
+#include <grass/Rast.h>
+  \brief Read the raster header
+  The raster header for the raster map <i>name</i> in the specified
+  <i>mapset</i> is read into the <i>cellhd</i> structure. If there is
+  an error reading the raster header file, a diagnostic message is
+  printed and -1 is returned. Otherwise, 0 is returned.
+  <b>Note</b>:a warning message for errors encountered.
+  Cell header files may contain either grid cell header information or
+  reclass information. If it is a reclass file, it will specify the
+  map and mapset names of the actual grid cell file being
+  reclassed. Rast_get_cellhd(), upon reading reclass information will go
+  read the cell header information for the referenced file. Only one
+  reference is allowed.
+  \param name name of map
+  \param mapset mapset that map belongs to
+  \param[out] cellhd structure to hold cell header info
+  \return 0 on success
+  \return -1 on error
+int Rast_get_cellhd(const char *name, const char *mapset,
+		 struct Cell_head *cellhd)
+    FILE *fd;
+    int is_reclass;
+    char real_name[GNAME_MAX], real_mapset[GMAPSET_MAX];
+    char buf[1024];
+    char *tail;
+       is_reclass = Rast_is_reclass (name, mapset, real_name, real_mapset);
+       if (is_reclass < 0)
+       sprintf (buf,"Can't read header file for [%s in %s]\n", name, mapset);
+       tail = buf + strlen(buf);
+       strcpy (tail, "It is a reclass file, but with an invalid format");
+       G_warning(buf);
+       return -1;
+    is_reclass = (Rast_is_reclass(name, mapset, real_name, real_mapset) > 0);
+    if (is_reclass) {
+	fd = G_fopen_old("cellhd", real_name, real_mapset);
+	if (fd == NULL) {
+	    sprintf(buf,
+		    _("Unable to read header file for raster map <%s@%s>."),
+		    name, mapset);
+	    sprintf(tail, _(" It is a reclass of raster map <%s@%s> "),
+		    real_name, real_mapset);
+	    if (!G_find_cell(real_name, real_mapset))
+		sprintf(tail, _("which is missing."));
+	    else
+		sprintf(tail, _("whose header file can't be opened."));
+	    G_warning ("%s", buf);
+	    return -1;
+    else {
+	fd = G_fopen_old("cellhd", name, mapset);
+	if (fd == NULL) {
+	    G_warning(_("Unable to open header file for raster map <%s@%s>"),
+		      name, mapset);
+	    return -1;
+    Rast__read_Cell_head(fd, cellhd, 1);
+    fclose(fd);
+    return 0;
Copied: grass/trunk/lib/raster/get_row.c (from rev 37989, grass/trunk/lib/gis/get_row.c)
--- grass/trunk/lib/raster/get_row.c	                        (rev 0)
+++ grass/trunk/lib/raster/get_row.c	2009-06-20 22:03:23 UTC (rev 38003)
@@ -0,0 +1,1221 @@
+  \file gis/get_row.c
+  \brief GIS library - Get raster row
+  (C) 2003-2009 by the GRASS Development Team
+#include <sys/types.h>
+#include <rpc/types.h>		/* need this for sgi */
+#include <rpc/xdr.h>
+#include "G.h"
+#define NULL_FILE   "null"
+static int embed_nulls(int, void *, int, RASTER_MAP_TYPE, int, int);
+static int compute_window_row(int fd, int row, int *cellRow)
+    double f;
+    int r;
+    /* check for row in window */
+    if (row < 0 || row >= G__.window.rows) {
+	G_warning(_("Reading raster map <%s@%s> request for row %d is outside region"),
+		  fcb->name, fcb->mapset, row);
+	return -1;
+    /* convert window row to cell file row */
+    f = row * fcb->C1 + fcb->C2;
+    r = (int)f;
+    if (f < r)			/* adjust for rounding up of negatives */
+	r--;
+    if (r < 0 || r >= fcb->cellhd.rows)
+	return 0;
+    *cellRow = r;
+    return 1;
+static void do_reclass_int(int fd, void *cell, int null_is_zero)
+    CELL *c = cell;
+    CELL *reclass_table = fcb->reclass.table;
+    CELL min = fcb->reclass.min;
+    CELL max = fcb->reclass.max;
+    int i;
+    for (i = 0; i < G__.window.cols; i++) {
+	if (Rast_is_c_null_value(&c[i])) {
+	    if (null_is_zero)
+		c[i] = 0;
+	    continue;
+	if (c[i] < min || c[i] > max) {
+	    if (null_is_zero)
+		c[i] = 0;
+	    else
+		Rast_set_c_null_value(&c[i], 1);
+	    continue;
+	c[i] = reclass_table[c[i] - min];
+	if (null_is_zero && Rast_is_c_null_value(&c[i]))
+	    c[i] = 0;
+static int read_data_fp_compressed(int fd, int row, unsigned char *data_buf,
+				   int *nbytes)
+    off_t t1 = fcb->row_ptr[row];
+    off_t t2 = fcb->row_ptr[row + 1];
+    size_t readamount = t2 - t1;
+    size_t bufsize = fcb->cellhd.cols * fcb->nbytes;
+    if (lseek(fd, t1, SEEK_SET) < 0)
+	return -1;
+    *nbytes = fcb->nbytes;
+    if ((size_t) G_zlib_read(fd, readamount, data_buf, bufsize) != bufsize)
+	return -1;
+    return 0;
+static void rle_decompress(unsigned char *dst, const unsigned char *src,
+			   int nbytes, int size)
+    int pairs = size / (nbytes + 1);
+    int i;
+    for (i = 0; i < pairs; i++) {
+	int repeat = *src++;
+	int j;
+	for (j = 0; j < repeat; j++) {
+	    memcpy(dst, src, nbytes);
+	    dst += nbytes;
+	src += nbytes;
+static int read_data_compressed(int fd, int row, unsigned char *data_buf,
+				int *nbytes)
+    ssize_t readamount = t2 - t1;
+    unsigned char *cmp;
+    int n;
+	return -1;
+    cmp = G__alloca(readamount);
+    if (read(fd, cmp, readamount) != readamount) {
+	G__freea(cmp);
+	return -1;
+    /* Now decompress the row */
+    if (fcb->cellhd.compressed > 0) {
+	/* one byte is nbyte count */
+	n = *nbytes = *cmp++;
+	readamount--;
+    else
+	/* pre 3.0 compression */
+	n = *nbytes = fcb->nbytes;
+    if (fcb->cellhd.compressed < 0 || readamount < n * fcb->cellhd.cols) {
+	if (fcb->cellhd.compressed == 2)
+	    G_zlib_expand(cmp, readamount, data_buf, n * fcb->cellhd.cols);
+	else
+	    rle_decompress(data_buf, cmp, n, readamount);
+    else
+	memcpy(data_buf, cmp, readamount);
+    G__freea(cmp);
+    return 0;
+static int read_data_uncompressed(int fd, int row, unsigned char *data_buf,
+				  int *nbytes)
+    ssize_t bufsize = fcb->cellhd.cols * fcb->nbytes;
+    if (lseek(fd, (off_t) row * bufsize, SEEK_SET) == -1)
+	return -1;
+    if (read(fd, data_buf, bufsize) != bufsize)
+	return -1;
+    return 0;
+#ifdef HAVE_GDAL
+static int read_data_gdal(int fd, int row, unsigned char *data_buf, int *nbytes)
+    unsigned char *buf;
+    CPLErr err;
+    if (fcb->gdal->vflip)
+	row = fcb->cellhd.rows - 1 - row;
+    buf = fcb->gdal->hflip
+	? G__alloca(fcb->cellhd.cols * fcb->cur_nbytes)
+	: data_buf;
+    err = G_gdal_raster_IO(
+	fcb->gdal->band, GF_Read, 0, row, fcb->cellhd.cols, 1, buf,
+	fcb->cellhd.cols, 1, fcb->gdal->type, 0, 0);
+    if (fcb->gdal->hflip) {
+	int i;
+	for (i = 0; i < fcb->cellhd.cols; i++)
+	    memcpy(data_buf + i * fcb->cur_nbytes,
+		   buf + (fcb->cellhd.cols - 1 - i) * fcb->cur_nbytes,
+		   fcb->cur_nbytes);
+	G__freea(buf);
+    return err == CE_None ? 0 : -1;
+#endif
+static int read_data(int fd, int row, unsigned char *data_buf, int *nbytes)
+#ifdef HAVE_GDAL
+    if (fcb->gdal)
+	return read_data_gdal(fd, row, data_buf, nbytes);
+#endif
+	return read_data_uncompressed(fd, row, data_buf, nbytes);
+    /* map is in compressed form */
+    if (fcb->map_type == CELL_TYPE)
+	return read_data_compressed(fd, row, data_buf, nbytes);
+    else
+	return read_data_fp_compressed(fd, row, data_buf, nbytes);
+/* copy cell file data to user buffer translated by window column mapping */
+static void cell_values_int(int fd, const unsigned char *data,
+			    const COLUMN_MAPPING * cmap, int nbytes,
+			    void *cell, int n)
+    CELL *c = cell;
+    COLUMN_MAPPING cmapold = 0;
+    int big = (size_t) nbytes >= sizeof(CELL);
+    int i;
+	const unsigned char *d;
+	int neg;
+	CELL v;
+	int j;
+	if (!cmap[i]) {
+	    c[i] = 0;
+	    continue;
+	if (cmap[i] == cmapold) {
+	    c[i] = c[i - 1];
+	    continue;
+	d = data + (cmap[i] - 1) * nbytes;
+	if (big && (*d & 0x80)) {
+	    neg = 1;
+	    v = *d++ & 0x7f;
+	else {
+	    neg = 0;
+	    v = *d++;
+	for (j = 1; j < nbytes; j++)
+	    v = (v << 8) + *d++;
+	c[i] = neg ? -v : v;
+	cmapold = cmap[i];
+static void cell_values_float(int fd, const unsigned char *data,
+    FCELL *c = cell;
+    XDR *xdrs = &fcb->xdrstream;
+    int i;
+    /* xdr stream is initialized to read from */
+    /* fcb->data in 'opencell.c' */
+    xdr_setpos(xdrs, 0);
+	if (!cmap[i]) {
+	    c[i] = 0;
+	    continue;
+	    c[i] = c[i - 1];
+	    continue;
+	if (cmap[i] < cmapold) {
+	    cmapold = 0;
+	while (cmapold++ != cmap[i])	/* skip */
+	    if (!xdr_float(xdrs, &c[i]))
+		G_fatal_error(_("cell_values_float: xdr_float failed for index %d"),
+			      i);
+	cmapold--;
+static void cell_values_double(int fd, const unsigned char *data,
+    DCELL *c = cell;
+    int i;
+	if (!cmap[i]) {
+	    c[i] = 0;
+	    continue;
+	    c[i] = c[i - 1];
+	    continue;
+	    cmapold = 0;
+	    if (!xdr_double(xdrs, &c[i]))
+		G_fatal_error(_("cell_values_double: xdr_double failed for index %d"),
+			      i);
+	cmapold--;
+#ifdef HAVE_GDAL
+static void gdal_values_int(int fd, const unsigned char *data,
+			    const COLUMN_MAPPING *cmap, int nbytes,
+			    CELL *cell, int n)
+    int i;
+	if (!cmap[i]) {
+	    cell[i] = 0;
+	    continue;
+	    cell[i] = cell[i-1];
+	    continue;
+	switch (fcb->gdal->type) {
+	case GDT_Byte:	    cell[i] = *(GByte   *)d;	break;
+	case GDT_Int16:	    cell[i] = *(GInt16  *)d;	break;
+	case GDT_UInt16:    cell[i] = *(GUInt16 *)d;	break;
+	case GDT_Int32:	    cell[i] = *(GInt32  *)d;	break;
+	case GDT_UInt32:    cell[i] = *(GUInt32 *)d;	break;
+	default:
+	    /* shouldn't happen */
+	    Rast_set_c_null_value(&cell[i], 1);
+	    break;
+static void gdal_values_float(int fd, const float *data,
+			      FCELL *cell, int n)
+    int i;
+	if (!cmap[i]) {
+	    cell[i] = 0;
+	    continue;
+	    continue;
+	cell[i] = data[cmap[i] - 1];
+static void gdal_values_double(int fd, const double *data,
+			       DCELL *cell, int n)
+    int i;
+	if (!cmap[i]) {
+	    cell[i] = 0;
+	    continue;
+	    continue;
+#endif
+/* transfer_to_cell_XY takes bytes from fcb->data, converts these bytes with
+   the appropriate procedure (e.g. XDR or byte reordering) into type X
+   values which are put into array work_buf.
+   finally the values in work_buf are converted into
+   type Y and put into 'cell'.
+   if type X == type Y the intermediate step of storing the values in
+   work_buf might be ommited. check the appropriate function for XY to
+   determine the procedure of conversion.
+static void transfer_to_cell_XX(int fd, void *cell)
+    static void (*cell_values_type[3]) () = {
+    cell_values_int, cell_values_float, cell_values_double};
+#ifdef HAVE_GDAL
+    static void (*gdal_values_type[3]) () = {
+    gdal_values_int, gdal_values_float, gdal_values_double};
+#endif
+#ifdef HAVE_GDAL
+    if (fcb->gdal)
+    (gdal_values_type[fcb->map_type]) (fd, fcb->data, fcb->col_map,
+				       fcb->cur_nbytes, cell,
+				       G__.window.cols);
+    else
+#endif
+    (cell_values_type[fcb->map_type]) (fd, fcb->data, fcb->col_map,
+				       G__.window.cols);
+static void transfer_to_cell_fi(int fd, void *cell)
+    FCELL *work_buf = G__alloca(G__.window.cols * sizeof(FCELL));
+    int i;
+    transfer_to_cell_XX(fd, work_buf);
+	((CELL *) cell)[i] = (fcb->col_map[i] == 0)
+	    ? 0
+	    : Rast_quant_get_cell_value(&fcb->quant, work_buf[i]);
+    G__freea(work_buf);
+static void transfer_to_cell_di(int fd, void *cell)
+    DCELL *work_buf = G__alloca(G__.window.cols * sizeof(DCELL));
+    int i;
+	    ? 0
+static void transfer_to_cell_if(int fd, void *cell)
+    CELL *work_buf = G__alloca(G__.window.cols * sizeof(CELL));
+    int i;
+	((FCELL *) cell)[i] = work_buf[i];
+static void transfer_to_cell_df(int fd, void *cell)
+    int i;
+static void transfer_to_cell_id(int fd, void *cell)
+    int i;
+	((DCELL *) cell)[i] = work_buf[i];
+static void transfer_to_cell_fd(int fd, void *cell)
+    int i;
+ *   works for all map types and doesn't consider
+ *   null row corresponding to the requested row
+static int get_map_row_nomask(int fd, void *rast, int row,
+			      RASTER_MAP_TYPE data_type)
+    static void (*transfer_to_cell_FtypeOtype[3][3])() = {
+	{transfer_to_cell_XX, transfer_to_cell_if, transfer_to_cell_id},
+	{transfer_to_cell_fi, transfer_to_cell_XX, transfer_to_cell_fd},
+	{transfer_to_cell_di, transfer_to_cell_df, transfer_to_cell_XX}
+    int r;
+    int rowStatus;
+    rowStatus = compute_window_row(fd, row, &r);
+    if (rowStatus <= 0) {
+	fcb->cur_row = -1;
+	Rast_zero_raster_buf(rast, data_type);
+	return rowStatus;
+    /* read cell file row if not in memory */
+    if (r != fcb->cur_row) {
+	fcb->cur_row = r;
+	if (read_data(fd, fcb->cur_row, fcb->data, &fcb->cur_nbytes) < 0) {
+	    if (!fcb->io_error) {
+		if (fcb->cellhd.compressed)
+		    G_warning(_("Error reading compressed map <%s@%s>, row %d"),
+			      fcb->name, fcb->mapset, r);
+		else
+		    G_warning(_("Error reading map <%s@%s>, row %d"),
+		fcb->io_error = 1;
+	    return -1;
+    (transfer_to_cell_FtypeOtype[fcb->map_type][data_type]) (fd, rast);
+    return 1;
+static int get_map_row_no_reclass(int fd, void *rast, int row,
+				  RASTER_MAP_TYPE data_type, int null_is_zero,
+				  int with_mask)
+    int stat;
+    stat = get_map_row_nomask(fd, rast, row, data_type);
+    if (stat < 0)
+	return stat;
+    stat = embed_nulls(fd, rast, row, data_type, null_is_zero, with_mask);
+    if (stat < 0)
+	return stat;
+    return 1;
+static int get_map_row(int fd, void *rast, int row, RASTER_MAP_TYPE data_type,
+		       int null_is_zero, int with_mask)
+    int size = Rast_raster_size(data_type);
+    CELL *temp_buf = NULL;
+    void *buf;
+    int type;
+    int stat;
+    int i;
+    if (fcb->reclass_flag && data_type != CELL_TYPE) {
+	temp_buf = G__alloca(G__.window.cols * sizeof(CELL));
+	buf = temp_buf;
+	type = CELL_TYPE;
+    else {
+	buf = rast;
+	type = data_type;
+    stat = get_map_row_no_reclass(fd, buf, row, type, null_is_zero, with_mask);
+    if (stat < 0) {
+	if (temp_buf)
+	    G__freea(temp_buf);
+	return stat;
+    if (!fcb->reclass_flag)
+	return 1;
+    /* if the map is reclass table, get and
+       reclass CELL row and copy results to needed type  */
+    do_reclass_int(fd, buf, null_is_zero);
+    if (data_type == CELL_TYPE)
+	return 1;
+	Rast_set_raster_value_c(rast, temp_buf[i], data_type);
+	rast = Rast_incr_void_ptr(rast, size);
+    return 1;
+ * \brief Read raster row without masking (this routine is deprecated)
+ * This routine reads the specified <em>row</em> from the raster map
+ * open on file descriptor <em>fd</em> into the <em>buf</em> buffer
+ * like Rast_get_map_row() does. The difference is that masking is
+ * suppressed. If the user has a mask set, Rast_get_map_row() will apply
+ * the mask but Rast_get_map_row_nomask() will ignore it. This routine
+ * prints a diagnostic message and returns -1 if there is an error
+ * reading the raster map. Otherwise a nonnegative value is returned.
+ * <b>Note.</b> Ignoring the mask is not generally acceptable. Users
+ * expect the mask to be applied. However, in some cases ignoring the
+ * mask is justified. For example, the GRASS modules
+ * <i>r.describe</i>, which reads the raster map directly to report
+ * all data values in a raster map, and <i>r.slope.aspect</i>, which
+ * produces slope and aspect from elevation, ignore both the mask and
+ * the region. However, the number of GRASS modules which do this
+ * should be minimal. See Mask for more information about the mask.
+ * <b>This routine is deprecated! Use Rast_get_raster_row_nomask()
+ * instead.</b>
+ * \param fd file descriptor for the opened raster map
+ * \param buf buffer for the row to be placed into
+ * \param row data row desired
+ * \return 1 on success
+ * \return 0 row requested not within window
+ * \return -1 on error
+int Rast_get_map_row_nomask(int fd, CELL * buf, int row)
+    return get_map_row(fd, buf, row, CELL_TYPE, 1, 0);
+ *  Same as Rast_get_raster_row() except no masking occurs.
+ * \param data_type data type
+int Rast_get_raster_row_nomask(int fd, void *buf, int row,
+    return get_map_row(fd, buf, row, data_type, 0, 0);
+ * \brief Read raster row without masking (CELL type)
+ *  Same as Rast_get_c_raster_row() except no masking occurs.
+int Rast_get_c_raster_row_nomask(int fd, CELL * buf, int row)
+    return Rast_get_raster_row_nomask(fd, buf, row, CELL_TYPE);
+ * \brief Read raster row without masking (FCELL type)
+ *  Same as Rast_get_f_raster_row() except no masking occurs.
+int Rast_get_f_raster_row_nomask(int fd, FCELL * buf, int row)
+    return Rast_get_raster_row_nomask(fd, buf, row, FCELL_TYPE);
+ * \brief Read raster row without masking (DCELL type)
+ *  Same as Rast_get_d_raster_row() except no masking occurs.
+int Rast_get_d_raster_row_nomask(int fd, DCELL * buf, int row)
+    return Rast_get_raster_row_nomask(fd, buf, row, DCELL_TYPE);
+ * \brief Get raster row (this routine is deprecated!)
+ * If the map is floating-point, quantize the floating-point values to
+ * integer using the quantization rules established for the map when
+ * the map was opened for reading (this quantization is read from
+ * cell_misc/name/f_quant file, but can be reset after opening raster
+ * map by Rast_set_quant_rules()). NULL values are converted to zeros.
+ * <b>This routine is deprecated! Use Rast_get_raster_row() instead.</b>
+int Rast_get_map_row(int fd, CELL * buf, int row)
+    return get_map_row(fd, buf, row, CELL_TYPE, 1, 1);
+ * If <em>data_type</em> is
+ *  - CELL_TYPE, calls Rast_get_c_raster_row()
+ *  - FCELL_TYPE, calls Rast_get_f_raster_row()
+ *  - DCELL_TYPE, calls Rast_get_d_raster_row()
+ *   Reads appropriate information into the buffer <em>buf</em> associated
+ *   with the requested row <em>row</em>. <em>buf</em> is associated with the
+ *   current window.
+ *   Note, that the type of the data in <em>buf</em> (say X) is independent of
+ *   the type of the data in the file described by <em>fd</em> (say Y).
+ *    - Step 1:  Read appropriate raw map data into a intermediate buffer.
+ *    - Step 2:  Convert the data into a CPU readable format, and subsequently
+ *            resample the data. the data is stored in a second intermediate
+ *            buffer (the type of the data in this buffer is Y).
+ *    - Step 3:  Convert this type Y data into type X data and store it in
+ *            buffer "buf". Conversion is performed in functions
+ *            "transfer_to_cell_XY". (For details of the conversion between
+ *            two particular types check the functions).
+ *    - Step 4:  read or simmulate null value row and zero out cells corresponding
+ *            to null value cells. The masked out cells are set to null when the
+ *            mask exists. (the MASK is taken care of by null values
+ *            (if the null file doesn't exist for this map, then the null row
+ *            is simulated by assuming that all zero are nulls *** in case
+ *            of Rast_get_raster_row() and assuming that all data is valid
+ *            in case of G_get_f/d_raster_row(). In case of deprecated function
+ *            Rast_get_map_row() all nulls are converted to zeros (so there are
+ *            no embedded nulls at all). Also all masked out cells become zeros.
+int Rast_get_raster_row(int fd, void *buf, int row, RASTER_MAP_TYPE data_type)
+    return get_map_row(fd, buf, row, data_type, 0, 1);
+ * \brief Get raster row (CELL type)
+ * Reads a row of raster data and leaves the NULL values intact. (As
+ * opposed to the deprecated function Rast_get_map_row() which
+ * converts NULL values to zero.)
+ * <b>NOTE.</b> When the raster map is old and null file doesn't
+ * exist, it is assumed that all 0-cells are no-data. When map is
+ * floating point, uses quant rules set explicitly by
+ * Rast_set_quant_rules() or stored in map's quant file to convert floats
+ * to integers.
+int Rast_get_c_raster_row(int fd, CELL * buf, int row)
+    return Rast_get_raster_row(fd, buf, row, CELL_TYPE);
+ * \brief Get raster row (FCELL type)
+ * Read a row from the raster map open on <em>fd</em> into the
+ * <tt>float</tt> array <em>fcell</em> performing type conversions as
+ * necessary based on the actual storage type of the map. Masking,
+ * resampling into the current region.  NULL-values are always
+ * embedded in <tt>fcell</tt> (<em>never converted to a value</em>).
+int Rast_get_f_raster_row(int fd, FCELL * buf, int row)
+    return Rast_get_raster_row(fd, buf, row, FCELL_TYPE);
+ * \brief Get raster row (DCELL type)
+ * Same as Rast_get_f_raster_row() except that the array <em>dcell</em>
+ * is <tt>double</tt>.
+int Rast_get_d_raster_row(int fd, DCELL * buf, int row)
+    return Rast_get_raster_row(fd, buf, row, DCELL_TYPE);
+static int open_null_read(int fd)
+    const char *name, *mapset, *dummy;
+    int null_fd;
+    if (fcb->null_file_exists == 0)
+	return -1;
+    if (fcb->reclass_flag) {
+	name = fcb->reclass.name;
+	mapset = fcb->reclass.mapset;
+    else {
+	name = fcb->name;
+	mapset = fcb->mapset;
+    dummy = G_find_file2_misc("cell_misc", NULL_FILE, name, mapset);
+    if (!dummy) {
+	/* G_warning("unable to find [%s]",path); */
+	fcb->null_file_exists = 0;
+	return -1;
+    null_fd = G_open_old_misc("cell_misc", NULL_FILE, name, mapset);
+    if (null_fd < 0)
+	return -1;
+    fcb->null_file_exists = 1;
+    return null_fd;
+static int read_null_bits(int null_fd, unsigned char *flags, int row,
+			  int cols, int fd)
+    off_t offset;
+    ssize_t size;
+    int R;
+    if (compute_window_row(fd, row, &R) <= 0) {
+	Rast__init_null_bits(flags, cols);
+	return 1;
+    if (null_fd < 0)
+	return -1;
+    size = Rast__null_bitstream_size(cols);
+    offset = (off_t) size *R;
+    if (lseek(null_fd, offset, SEEK_SET) < 0) {
+	G_warning(_("Error reading null row %d"), R);
+	return -1;
+    if (read(null_fd, flags, size) != size) {
+	return -1;
+    return 1;
+static void get_null_value_row_nomask(int fd, char *flags, int row)
+    int i, j, null_fd;
+    if (row > G__.window.rows || row < 0) {
+    if ((fcb->min_null_row > row) ||
+	(fcb->min_null_row + NULL_ROWS_INMEM - 1 < row))
+	/* the null row row is not in memory */
+	unsigned char *null_work_buf = G__alloca(
+	    Rast__null_bitstream_size(fcb->cellhd.cols));
+	/* read in NULL_ROWS_INMEM rows from null file
+	   so that the requested row is between fcb->min_null_row
+	   and fcb->min_null_row + NULL_ROWS_INMEM */
+	fcb->min_null_row = (row / NULL_ROWS_INMEM) * NULL_ROWS_INMEM;
+	null_fd = open_null_read(fd);
+	for (i = 0; i < NULL_ROWS_INMEM; i++) {
+	    /* G__.window.rows doesn't have to be a multiple of NULL_ROWS_INMEM */
+	    if (i + fcb->min_null_row >= G__.window.rows)
+		break;
+	    if (read_null_bits(null_fd, null_work_buf,
+			       i + fcb->min_null_row, fcb->cellhd.cols,
+			       fd) < 0) {
+		if (fcb->map_type == CELL_TYPE) {
+		    /* If can't read null row, assume  that all map 0's are nulls */
+		    CELL *mask_buf = G__alloca(G__.window.cols * sizeof(CELL));
+		    get_map_row_nomask(fd, mask_buf, i + fcb->min_null_row,
+				       CELL_TYPE);
+		    for (j = 0; j < G__.window.cols; j++)
+			flags[j] = (mask_buf[j] == 0);
+		    G__freea(mask_buf);
+		else {		/* fp map */
+		    /* if can't read null row, assume  that all data is valid */
+		    G_zero(flags, sizeof(char) * G__.window.cols);
+		    /* the flags row is ready now */
+	    }			/*if no null file */
+	    else {
+		/* copy null row to flags row translated by window column mapping */
+		/* the fcb->NULL_ROWS[row-fcb->min_null_row] has G__.window.cols bits, */
+		/* the null_work_buf has size fcb->cellhd.cols */
+		for (j = 0; j < G__.window.cols; j++) {
+		    if (!fcb->col_map[j])
+			flags[j] = 1;
+		    else
+			flags[j] = Rast__check_null_bit(null_work_buf,
+						     fcb->col_map[j] - 1,
+						     fcb->cellhd.cols);
+	    /* remember the null row for i for the future reference */
+	    /*bf-We should take of the size - or we get
+	       zeros running on their own after flags convertions -A.Sh. */
+	    fcb->NULL_ROWS[i] = G_realloc(fcb->NULL_ROWS[i],
+					  Rast__null_bitstream_size(G__.window.
+								 cols) + 1);
+	    if (fcb->NULL_ROWS[i] == NULL)
+		G_fatal_error("get_null_value_row_nomask: %s",
+			      _("Unable to realloc buffer"));
+	    Rast__convert_01_flags(flags, fcb->NULL_ROWS[i], G__.window.cols);
+	}			/* for loop */
+	if (null_fd > 0)
+	    close(null_fd);
+	G__freea(null_work_buf);
+    }				/* row is not in memory */
+    /* copy null file data translated by column mapping to user null row */
+    /* the user requested flags row is of size G__.window.cols */
+    Rast__convert_flags_01(flags, fcb->NULL_ROWS[row - fcb->min_null_row],
+			G__.window.cols);
+#ifdef HAVE_GDAL
+static void get_null_value_row_gdal(int fd, char *flags, int row)
+    DCELL *tmp_buf = Rast_allocate_d_raster_buf();
+    int i;
+    if (get_map_row_nomask(fd, tmp_buf, row, DCELL_TYPE) <= 0) {
+	memset(flags, 1, G__.window.cols);
+	G_free(tmp_buf);
+	return;
+	/* note: using == won't work if the null value is NaN */
+	flags[i] = memcmp(&tmp_buf[i], &fcb->gdal->null_val, sizeof(DCELL)) == 0;
+    G_free(tmp_buf);
+#endif
+static void embed_mask(char *flags, int row)
+    int i;
+    if (G__.auto_mask <= 0)
+	return;
+    if (get_map_row_nomask(G__.mask_fd, mask_buf, row, CELL_TYPE) < 0) {
+	return;
+    if (G__.fileinfo[G__.mask_fd].reclass_flag)
+	do_reclass_int(G__.mask_fd, mask_buf, 1);
+	if (mask_buf[i] == 0)
+	    flags[i] = 1;
+static void get_null_value_row(int fd, char *flags, int row, int with_mask)
+#ifdef HAVE_GDAL
+    if (fcb->gdal)
+	get_null_value_row_gdal(fd, flags, row);
+    else
+#endif
+    get_null_value_row_nomask(fd, flags, row);
+    if (with_mask)
+	embed_mask(flags, row);
+static int embed_nulls(int fd, void *buf, int row, RASTER_MAP_TYPE map_type,
+    char *null_buf;
+    int i;
+    /* this is because without null file the nulls can be only due to 0's
+       in data row or mask */
+    if (null_is_zero && !fcb->null_file_exists
+	&& (G__.auto_mask <= 0 || !with_mask))
+	return 1;
+    null_buf = G__alloca(G__.window.cols);
+    get_null_value_row(fd, null_buf, row, with_mask);
+	/* also check for nulls which might be already embedded by quant
+	   rules in case of fp map. */
+	if (null_buf[i] || Rast_is_null_value(buf, map_type)) {
+	    /* G__set_[f/d]_null_value() sets it to 0 is the embedded mode
+	       is not set and calls G_set_[f/d]_null_value() otherwise */
+	    Rast__set_null_value(buf, 1, null_is_zero, map_type);
+	buf = Rast_incr_void_ptr(buf, Rast_raster_size(map_type));
+    G__freea(null_buf);
+    return 1;
+   \brief Read or simmulate null value row
+   Read or simmulate null value row and set the cells corresponding
+   to null value to 1. The masked out cells are set to null when the
+   mask exists. (the MASK is taken care of by null values
+   (if the null file doesn't exist for this map, then the null row
+   is simulated by assuming that all zeros in raster map are nulls.
+   Also all masked out cells become nulls.
+   \param fd file descriptor for the opened map
+   \param buf buffer for the row to be placed into
+   \param row data row desired
+   \return 1
+int Rast_get_null_value_row(int fd, char *flags, int row)
+    get_null_value_row(fd, flags, row, 1);
+    return 1;
Copied: grass/trunk/lib/raster/get_row_colr.c (from rev 37989, grass/trunk/lib/gis/get_row_colr.c)
--- grass/trunk/lib/raster/get_row_colr.c	                        (rev 0)
+++ grass/trunk/lib/raster/get_row_colr.c	2009-06-20 22:03:23 UTC (rev 38003)
@@ -0,0 +1,71 @@
+ * \file gis/get_row_colr.c
+ * \brief GIS Library - Get raster row (colors)
+ * (C) 1999-2009 by the GRASS Development Team
+ * This program is free software under the GNU General Public
+ * License (>=v2). Read the file COPYING that comes with GRASS
+ * for details.
+ * \author USACERL and many others
+#include <grass/gis.h>
+#include "G.h"
+ * \brief Reads a row of raster data and converts it to RGB.
+ * Reads a row of raster data and converts it to red, green and blue
+ * components according to the <em>colors</em> parameter. This
+ * provides a convenient way to treat a raster layer as a color image
+ * without having to explictly cater for each of <tt>CELL</tt>,
+ * <tt>FCELL</tt> and <tt>DCELL</tt> types.
+ *  \param fd field descriptor
+ *  \param row row number
+ *  \param colors pointer to Colors structure which holds color info
+ *  \param[out] red red value
+ *  \param[out] grn green value
+ *  \param[out] blu blue value
+ *  \param[out] nul null value
+ *  \return 0 on success
+int Rast_get_raster_row_colors(int fd, int row, struct Colors *colors,
+			    unsigned char *red, unsigned char *grn,
+			    unsigned char *blu, unsigned char *nul)
+    int cols = G_window_cols();
+    int type = Rast_get_raster_map_type(fd);
+    int size = Rast_raster_size(type);
+    void *array;
+    unsigned char *set;
+    void *p;
+    int i;
+    array = G__alloca(cols * size);
+    if (Rast_get_raster_row(fd, array, row, type) < 0) {
+	G__freea(array);
+	return -1;
+    if (nul)
+	for (i = 0, p = array; i < cols; i++, p = Rast_incr_void_ptr(p, size))
+	    nul[i] = Rast_is_null_value(p, type);
+    set = G__alloca(cols);
+    Rast_lookup_raster_colors(array, red, grn, blu, set, cols, colors, type);
+    G__freea(array);
+    G__freea(set);
+    return 0;
Copied: grass/trunk/lib/raster/histo_eq.c (from rev 37989, grass/trunk/lib/gis/histo_eq.c)
--- grass/trunk/lib/raster/histo_eq.c	                        (rev 0)
+++ grass/trunk/lib/raster/histo_eq.c	2009-06-20 22:03:23 UTC (rev 38003)
@@ -0,0 +1,78 @@
+* Rast_histogram_eq (histo, map, min, max)
+*   struct Histogram *histo;    histogram as returned by Rast_read_histogram()
+*   unsigned char **map;        equalized category mapping
+*   CELL *min, *max;            min,max category for map
+* perform histogram equalization
+* inputs are histo, output is map,min,max
+void Rast_histogram_eq(const struct Histogram *histo,
+		    unsigned char **map, CELL *min, CELL *max)
+    int i;
+    int x;
+    CELL cat, prev;
+    double total;
+    double sum;
+    double span;
+    int ncats;
+    long count;
+    unsigned char *xmap;
+    int len;
+    int first, last;
+    ncats = Rast_get_histogram_num(histo);
+    if (ncats == 1) {
+	*min = *max = Rast_get_histogram_cat(0, histo);
+	*map = xmap = (unsigned char *)G_malloc(1);
+	*xmap = 0;
+	return;
+    if ((*min = Rast_get_histogram_cat(first = 0, histo)) == 0)
+	*min = Rast_get_histogram_cat(++first, histo);
+    if ((*max = Rast_get_histogram_cat(last = ncats - 1, histo)) == 0)
+	*max = Rast_get_histogram_cat(--last, histo);
+    len = *max - *min + 1;
+    *map = xmap = (unsigned char *)G_malloc(len);
+    total = 0;
+    for (i = first; i <= last; i++) {
+	if (Rast_get_histogram_cat(i, histo) == 0)
+	    continue;
+	count = Rast_get_histogram_count(i, histo);
+	if (count > 0)
+	    total += count;
+    if (total <= 0) {
+	for (i = 0; i < len; i++)
+	    xmap[i] = 0;
+	return;
+    span = total / 256;
+    sum = 0.0;
+    cat = *min - 1;
+	prev = cat + 1;
+	cat = Rast_get_histogram_cat(i, histo);
+	if (count < 0 || cat == 0)
+	    count = 0;
+	x = (sum + (count / 2.0)) / span;
+	if (x < 0)
+	    x = 0;
+	else if (x > 255)
+	    x = 255;
+	sum += count;
+	while (prev++ <= cat)
+	    *xmap++ = x;
Copied: grass/trunk/lib/raster/histogram.c (from rev 37989, grass/trunk/lib/gis/histogram.c)
--- grass/trunk/lib/raster/histogram.c	                        (rev 0)
+++ grass/trunk/lib/raster/histogram.c	2009-06-20 22:03:23 UTC (rev 38003)
@@ -0,0 +1,455 @@
+#include <grass/glocale.h>
+#define LIST struct Histogram_list
+static FILE *fopen_histogram_new(const char *);
+static int cmp(const void *, const void *);
+static int cmp_count(const void *, const void *);
+ * \brief initializes the histogram structure
+ * initializes the histogram structure for calls to Rast_set_histogram()
+ * and Rast_add_histogram()
+ * \param  histogram
+ * \return
+void Rast_init_histogram(struct Histogram *histogram)
+    histogram->num = 0;
+    histogram->list = NULL;
+ * \brief read the histogram information
+ *  Reads the histogram information associated with map layer "map"
+ *  in mapset "mapset" into the structure "histogram".
+ *  note:   a warning message is printed if the file is missing or incorrect
+ * \param name: name of map
+ * \param mapset: mapset that map belongs to
+ * \param histogram: struct for histogram
+ * \return 1  if successful,
+ *               0  if no histogram file,
+ *              -1  on fail
+int Rast_read_histogram(const char *name, const char *mapset,
+		     struct Histogram *histogram)
+    FILE *fd = NULL;
+    long cat;
+    long count;
+    char buf[200];
+    Rast_init_histogram(histogram);
+    if (G_find_file2_misc("cell_misc", "histogram", name, mapset) == NULL) {
+	G_warning(_("Histogram for [%s in %s] missing (run r.support)"), name,
+		  mapset);
+	return 0;
+    fd = G_fopen_old_misc("cell_misc", "histogram", name, mapset);
+    if (!fd) {
+	G_warning(_("Can't read histogram for [%s in %s]"), name, mapset);
+	return -1;
+    while (fgets(buf, sizeof buf, fd)) {
+	if (sscanf(buf, "%ld:%ld", &cat, &count) != 2) {
+	    Rast_free_histogram(histogram);
+	    fclose(fd);
+	    G_warning(_("Invalid histogram file for [%s in %s]"), name,
+		      mapset);
+	    return -1;
+	Rast_extend_histogram((CELL) cat, count, histogram);
+    fclose(fd);
+    if (histogram->num == 0) {
+	G_warning(_("Invalid histogram file for [%s in %s]"), name, mapset);
+	return -1;
+    Rast_sort_histogram(histogram);
+    return 1;
+ * \brief Writes the histogram information
+ *  Writes the histogram information associated with map layer "name"
+ *              -1  on fail
+int Rast_write_histogram(const char *name, const struct Histogram *histogram)
+    FILE *fd;
+    int n;
+    LIST *list;
+    fd = fopen_histogram_new(name);
+    if (fd == NULL)
+	return -1;
+    list = histogram->list;
+    for (n = 0; n < histogram->num; n++) {
+	if (list[n].count)
+	    fprintf(fd, "%ld:%ld\n", (long)list[n].cat, list[n].count);
+    fclose(fd);
+    return 1;
+ * \brief Writes the histogram based on cell statistics to file
+ * \param statf: cell statistics
+ *        -1 on failure
+int Rast_write_histogram_cs(const char *name, struct Cell_stats *statf)
+    FILE *fd;
+    CELL cat;
+    long count;
+    if (fd == NULL)
+	return -1;
+    Rast_rewind_cell_stats(statf);
+    while (Rast_next_cell_stat(&cat, &count, statf)) {
+	if (count > 0)
+	    fprintf(fd, "%ld:%ld\n", (long)cat, count);
+    fclose(fd);
+    return 1;
+ * \brief Creates histogram based on cell statistics
+ * \param histogram: raster histogram
+ * \return
+void Rast_make_histogram_cs(struct Cell_stats *statf, struct Histogram *histogram)
+    CELL cat;
+    long count;
+	Rast_add_histogram(cat, count, histogram);
+ * \brief Sorts the histogram in ascending order by counts then category
+ *  Sorts the histogram in ascending order by counts then category.
+ *  No combining is done.
+ *              -1  on fail
+int Rast_get_histogram_num(const struct Histogram *histogram)
+    return histogram->num;
+ * \brief Returns cat for the nth element in the histogram
+ *  Returns cat for the nth element in the histogram
+ * \return CELL
+CELL Rast_get_histogram_cat(int n, const struct Histogram * histogram)
+    if (n < 0 || n >= histogram->num)
+	return 0;
+    return histogram->list[n].cat;
+ * \brief Returns count for the nth element in the histogram
+ *  Returns count for the nth element in the histogram
+ * \param n: nth element
+ * \return count
+long Rast_get_histogram_count(int n, const struct Histogram *histogram)
+	return 0;
+    return histogram->list[n].count;
+ * \brief Frees memory allocated for the histogram
+ * frees the memory allocated for the histogram
+ * \return
+void Rast_free_histogram(struct Histogram *histogram)
+    if (histogram->num > 0)
+	G_free(histogram->list);
+ *  Sorts the histogram in ascending order by category,
+ *  combining (by adding) elements that have the same category.
+ * \return  0  if successful,
+ *              1  on fail
+int Rast_sort_histogram(struct Histogram *histogram)
+    int a, b, n;
+    LIST *list;
+    /* if histogram only has 1 entry, nothing to do */
+    if ((n = histogram->num) <= 1)
+	return 1;
+    /* quick check to see if sorting needed */
+    for (a = 1; a < n; a++)
+	if (list[a - 1].cat >= list[a].cat)
+	    break;
+    if (a >= n)
+	return 1;
+    /* sort */
+    qsort(list, n, sizeof(LIST), &cmp);
+    /* sum duplicate entries */
+    for (a = 0, b = 1; b < n; b++) {
+	if (list[a].cat != list[b].cat) {
+	    a++;
+	    list[a].count = list[b].count;
+	    list[a].cat = list[b].cat;
+	else {
+	    list[a].count += list[b].count;
+    histogram->num = a + 1;
+    return 0;
+static int cmp(const void *aa, const void *bb)
+    const LIST *a = aa, *b = bb;
+    if (a->cat < b->cat)
+	return -1;
+    if (a->cat > b->cat)
+	return 1;
+    return 0;
+ * \brief Sorts the histogram by counts
+ *              1  on fail
+int Rast_sort_histogram_by_count(struct Histogram *histogram)
+    int n;
+    LIST *list;
+	return 1;
+    /* sort */
+    qsort(list, n, sizeof(LIST), &cmp_count);
+    return 0;
+static int cmp_count(const void *aa, const void *bb)
+    if (a->count < b->count)
+	return -1;
+    if (a->count > b->count)
+	return 1;
+	return -1;
+	return 1;
+    return 0;
+static FILE *fopen_histogram_new(const char *name)
+    FILE *fd;
+    fd = G_fopen_new_misc("cell_misc", "histogram", name);
+    if (fd == NULL)
+	G_warning(_("can't create histogram for [%s in %s]"), name,
+		  G_mapset());
+    return fd;
+ * \brief Removes the histogram
+ *  Removes the histogram information associated with map layer "name"
+ * \return
+void Rast_remove_histogram(const char *name)
+    G_remove_misc("cell_misc", "histogram", name);
+ * \brief adds count to the histogram value for cat
+ *  adds count to the histogram value for cat
+ * \param cat: category
+ * \param count
+ *              1  on fail
+int Rast_add_histogram(CELL cat, long count, struct Histogram *histogram)
+    int i;
+    for (i = 0; i < histogram->num; i++) {
+	if (histogram->list[i].cat == cat) {
+	    histogram->list[i].count += count;
+	    return 1;
+    Rast_extend_histogram(cat, count, histogram);
+    return 0;
+ * \brief sets the histogram value for cat to count
+ *  sets the histogram value for cat to count
+ * \param count
+ *              1  on fail
+int Rast_set_histogram(CELL cat, long count, struct Histogram *histogram)
+    int i;
+	    histogram->list[i].count = count;
+	    return 1;
+    return 0;
+ * \brief Extends histogram struct to accomodate a new value
+ * \param count
+ * \return
+void Rast_extend_histogram(CELL cat, long count, struct Histogram *histogram)
+    histogram->num++;
+    histogram->list =
+	(LIST *) G_realloc(histogram->list,
+			   histogram->num * sizeof(LIST));
+    histogram->list[histogram->num - 1].cat = cat;
+    histogram->list[histogram->num - 1].count = count;
+ * \brief Zero out histogram struct
+ * \return
+void Rast_zero_histogram(struct Histogram *histogram)
+    int i;
+	histogram->list[i].count = 0;
Copied: grass/trunk/lib/raster/history.c (from rev 37989, grass/trunk/lib/gis/history.c)
--- grass/trunk/lib/raster/history.c	                        (rev 0)
+++ grass/trunk/lib/raster/history.c	2009-06-20 22:03:23 UTC (rev 38003)
@@ -0,0 +1,271 @@
+ * \file gis/history.c
+ * \brief GIS Library - History management
+ * (C) 2001-2009 GRASS Development Team
+ * This program is free software under the GNU General Public License
+ * (>=v2). Read the file COPYING that comes with GRASS for details.
+ * \author Original author CERL
+static void print_history_error(const char *, const char *, FILE *);
+ * \brief Read raster history file
+ * This routine reads the history file for the raster map <i>name</i>
+ * in <i>mapset</i> into the <i>hist</i> structure.
+ * A diagnostic message is printed and -1 is returned if there is an
+ * error reading the history file. Otherwise, 0 is returned.
+ * \param name map name
+ * \param mapset mapset name
+ * \param hist pointer to History structure which holds history info
+int Rast_read_history(const char *name, const char *mapset, struct History *hist)
+    FILE *fd;
+    G_zero(hist, sizeof(struct History));
+    fd = G_fopen_old("hist", name, mapset);
+    if (!fd) {
+	print_history_error(name, mapset, fd);
+	return -1;
+    if (!G_getl(hist->mapid, sizeof(hist->mapid), fd)) {
+	return -1;
+    G_ascii_check(hist->mapid);
+    if (!G_getl(hist->title, sizeof(hist->title), fd)) {
+	return -1;
+    G_ascii_check(hist->title);
+    if (!G_getl(hist->mapset, sizeof(hist->mapset), fd)) {
+	return -1;
+    G_ascii_check(hist->mapset);
+    if (!G_getl(hist->creator, sizeof(hist->creator), fd)) {
+	return -1;
+    G_ascii_check(hist->creator);
+    if (!G_getl(hist->maptype, sizeof(hist->maptype), fd)) {
+	return -1;
+    G_ascii_check(hist->maptype);
+    if (!G_getl(hist->datsrc_1, sizeof(hist->datsrc_1), fd)) {
+	return -1;
+    G_ascii_check(hist->datsrc_1);
+    if (!G_getl(hist->datsrc_2, sizeof(hist->datsrc_2), fd)) {
+	return -1;
+    G_ascii_check(hist->datsrc_2);
+    if (!G_getl(hist->keywrd, sizeof(hist->keywrd), fd)) {
+	return -1;
+    G_ascii_check(hist->keywrd);
+    hist->edlinecnt = 0;
+    while ((hist->edlinecnt < MAXEDLINES) &&
+	   (G_getl
+	    (hist->edhist[hist->edlinecnt], sizeof(hist->edhist[0]), fd))) {
+	G_ascii_check(hist->edhist[hist->edlinecnt]);
+	hist->edlinecnt++;
+    fclose(fd);
+    return 0;
+void print_history_error(const char *name, const char *mapset, FILE *fd)
+    if (fd != NULL)
+	fclose(fd);
+    if (mapset) {
+	G_warning(_("Unable to get history information for <%s@%s>"),
+		  name, mapset);
+    else { /* write */
+	G_warning(_("Unable to write history information for <%s>"), name);
+ * \brief Write raster history file
+ * This routine writes the history file for the raster map
+ * <i>name</i> in the current mapset from the <i>hist</i> structure.
+ * error writing the history file. Otherwise, 0 is returned.
+ * <b>Note:</b> The <i>hist</i> structure should first be initialized
+ * using Rast_short_history().
+ * \param[out] hist pointer to History structure which holds history info
+int Rast_write_history(const char *name, struct History *hist)
+    FILE *fd;
+    int i;
+    fd = G_fopen_new("hist", name);
+    if (!fd) {
+	print_history_error(name, NULL, fd);
+	return -1;
+    fprintf(fd, "%s\n", hist->mapid);
+    fprintf(fd, "%s\n", hist->title);
+    fprintf(fd, "%s\n", hist->mapset);
+    fprintf(fd, "%s\n", hist->creator);
+    fprintf(fd, "%s\n", hist->maptype);
+    fprintf(fd, "%s\n", hist->datsrc_1);
+    fprintf(fd, "%s\n", hist->datsrc_2);
+    fprintf(fd, "%s\n", hist->keywrd);
+    for (i = 0; i < hist->edlinecnt; i++)
+	fprintf(fd, "%s\n", hist->edhist[i]);
+    fclose(fd);
+    return 0;
+ * \brief Initialize history structure
+ * This routine initializes the <i>hist</i> structure, recording the
+ * date, user, module name and the raster map <i>name</i>
+ * structure. The <i>type</i> is an anachronism from earlier versions
+ * of GRASS and should be specified as "raster".
+ * <b>Note:</b> This routine only initializes the data structure. It
+ * does not write the history file.
+ * \param type map type
+void Rast_short_history(const char *name, const char *type, struct History *hist)
+    strncpy(hist->mapid, G_date(), RECORD_LEN);
+    strncpy(hist->title, name, RECORD_LEN);
+    strncpy(hist->mapset, G_mapset(), RECORD_LEN);
+    strncpy(hist->creator, G_whoami(), RECORD_LEN);
+    strncpy(hist->maptype, type, RECORD_LEN);
+    sprintf(hist->keywrd, _("generated by %s"), G_program_name());
+    strcpy(hist->datsrc_1, "");
+    strcpy(hist->datsrc_2, "");
+ * \brief Save command line to raster history structure
+ * This routine takes an existing (run Rast_short_history first() history
+ * structure and adds the command line to the end of the comments
+ * array, as cleaned & expanded by the parser.
+ * History file is limited to [80]x[50], as defined in include/gis.h
+ *  - First version had for loops of [i][j] character assignments and ending
+ *    nulls, but using the string libraries is cleaner and less bug prone.
+ *  - Second version had white space detection, intelligent wrapping, and
+ *    indentation of continued lines, but this proved a pain in the neck for
+ *    things like r.patch which can have long strings without any
+ *    parser-acceptable breaks.
+ *  - This is MK-III, simplified, but that's good: it's cut & paste-able.
+ * Note: use Rast_write_history() to write the structure.
+ * Sample Usage:
+ * \code
+ *   struct History history;
+ *   Rast_short_history(rasterfile, "raster", &history);
+ *   Rast_command_history(&history);
+ *   Rast_write_history(rasterfile, &history);
+ * \endcode
+ * \return 1 on failure (history file full, no change)
+ * \return 2 on failure (history file full, added as much as we could)
+int Rast_command_history(struct History *hist)
+    int j, cmdlen;
+    char *cmdlin;
+    cmdlin = G_recreate_command();
+    cmdlen = strlen(cmdlin);
+    if (hist->edlinecnt > MAXEDLINES - 2) {
+	G_warning(_("Not enough room in history file to record command line"));
+	return 1;
+    if (hist->edlinecnt > 0) {	/* add a blank line if preceding history exists */
+	strcpy(hist->edhist[hist->edlinecnt], "");
+    if (cmdlen < 70) {		/* ie if it will fit on a single line */
+	sprintf(hist->edhist[hist->edlinecnt], G_recreate_command());
+    else {			/* multi-line required */
+	j = 0;			/* j is the current position in the command line string */
+	while ((cmdlen - j) > 70) {
+	    strncpy(hist->edhist[hist->edlinecnt], &cmdlin[j], 68);
+	    hist->edhist[hist->edlinecnt][68] = '\0';
+	    strcat(hist->edhist[hist->edlinecnt], "\\");
+	    j += 68;
+		G_warning(_("Not enough room in history file for command line (truncated)"));
+		return 2;
+	if ((cmdlen - j) > 0) {	/* ie anything left */
+	    strcpy(hist->edhist[hist->edlinecnt], &cmdlin[j]);
+    return 0;
Copied: grass/trunk/lib/raster/interp.c (from rev 37989, grass/trunk/lib/gis/interp.c)
--- grass/trunk/lib/raster/interp.c	                        (rev 0)
+++ grass/trunk/lib/raster/interp.c	2009-06-20 22:03:23 UTC (rev 38003)
@@ -0,0 +1,36 @@
+DCELL Rast_interp_linear(double u, DCELL c0, DCELL c1)
+    return u * (c1 - c0) + c0;
+DCELL Rast_interp_bilinear(double u, double v,
+			DCELL c00, DCELL c01, DCELL c10, DCELL c11)
+    DCELL c0 = Rast_interp_linear(u, c00, c01);
+    DCELL c1 = Rast_interp_linear(u, c10, c11);
+    return Rast_interp_linear(v, c0, c1);
+DCELL Rast_interp_cubic(double u, DCELL c0, DCELL c1, DCELL c2, DCELL c3)
+    return (u * (u * (u * (c3 - 3 * c2 + 3 * c1 - c0) +
+	      (-c3 + 4 * c2 - 5 * c1 + 2 * c0)) + (c2 - c0)) + 2 * c1) / 2;
+DCELL Rast_interp_bicubic(double u, double v,
+		       DCELL c00, DCELL c01, DCELL c02, DCELL c03,
+		       DCELL c10, DCELL c11, DCELL c12, DCELL c13,
+		       DCELL c20, DCELL c21, DCELL c22, DCELL c23,
+		       DCELL c30, DCELL c31, DCELL c32, DCELL c33)
+    DCELL c0 = Rast_interp_cubic(u, c00, c01, c02, c03);
+    DCELL c1 = Rast_interp_cubic(u, c10, c11, c12, c13);
+    DCELL c2 = Rast_interp_cubic(u, c20, c21, c22, c23);
+    DCELL c3 = Rast_interp_cubic(u, c30, c31, c32, c33);
+    return Rast_interp_cubic(v, c0, c1, c2, c3);
Copied: grass/trunk/lib/raster/mask_info.c (from rev 37989, grass/trunk/lib/gis/mask_info.c)
--- grass/trunk/lib/raster/mask_info.c	                        (rev 0)
+++ grass/trunk/lib/raster/mask_info.c	2009-06-20 22:03:23 UTC (rev 38003)
@@ -0,0 +1,72 @@
+ * char * Rast_mask_info ()
+ *   returns a printable text of mask information
+ * Rast__mask_info (name, mapset)
+ *      char name[GNAME_MAX], mapset[GMAPSET_MAX];
+ * function:
+ *   determine the status off the automatic masking
+ *   and the name of the cell file which forms the mask
+ *   (the mask file is actually MASK in the current mapset,
+ *   but is usually a reclassed cell file, and the reclass
+ *   name and mapset are returned)
+ * returns:
+ *   -1   no masking (name, mapset undefined)
+ *        name, mapset are undefined
+ *    1   mask file present, masking on
+ *        name, mapset hold mask file name, mapset
+char *Rast_mask_info(void)
+    char text[GNAME_MAX + GMAPSET_MAX + 16];
+    char name[GNAME_MAX];
+    char mapset[GMAPSET_MAX];
+    switch (Rast__mask_info(name, mapset)) {
+    case 1:
+	sprintf(text, _("<%s> in mapset <%s>"), name, mapset);
+	break;
+    case -1:
+	strcpy(text, _("none"));
+	break;
+    default:
+	strcpy(text, _("not known"));
+	break;
+    return G_store(text);
+int Rast__mask_info(char *name, char *mapset)
+    char rname[GNAME_MAX], rmapset[GMAPSET_MAX];
+    strcpy(name, "MASK");
+    strcpy(mapset, G_mapset());
+    if (!G_find_cell(name, mapset))
+	return -1;
+    if (Rast_is_reclass(name, mapset, rname, rmapset) > 0) {
+	strcpy(name, rname);
+	strcpy(mapset, rmapset);
+    return 1;
Copied: grass/trunk/lib/raster/maskfd.c (from rev 37989, grass/trunk/lib/gis/maskfd.c)
--- grass/trunk/lib/raster/maskfd.c	                        (rev 0)
+++ grass/trunk/lib/raster/maskfd.c	2009-06-20 22:03:23 UTC (rev 38003)
@@ -0,0 +1,31 @@
+ * \file gis/maskfd.c
+ * \brief GIS Library - Mask functions.
+ * (C) 2001-2009 by the GRASS Development Team
+#include "G.h"
+ * \brief Test for MASK.
+ * \return -1 if no MASK
+ * \return file descriptor if MASK
+int Rast_maskfd(void)
+    Rast__check_for_auto_masking();
+    return G__.auto_mask > 0 ? G__.mask_fd : -1;
Copied: grass/trunk/lib/raster/null_val.c (from rev 37989, grass/trunk/lib/gis/null_val.c)
--- grass/trunk/lib/raster/null_val.c	                        (rev 0)
+++ grass/trunk/lib/raster/null_val.c	2009-06-20 22:03:23 UTC (rev 38003)
@@ -0,0 +1,507 @@
+ * \file gis/null_value.c
+ * \brief GIS Library - NULL value management
+ * To provide functionality to handle NULL values for data types CELL,
+ * FCELL, and DCELL. May need more...
+ * \author Original author unknown - probably CERL
+ * \author Justin Hickey - Thailand - jhickey at hpcc.nectec.or.th
+/* System include files */
+/* Grass and local include files */
+static void EmbedGivenNulls(void *, char *, RASTER_MAP_TYPE, int);
+  \brief To insert null values into a map. Needs more.....
+  \param cell raster values
+  \param nulls raster null values
+  \param map_type type of raster - CELL, FCELL, DCELL
+  \param ncols number of columns
+void EmbedGivenNulls(void *cell, char *nulls, RASTER_MAP_TYPE map_type,
+		     int ncols)
+    CELL *c;
+    FCELL *f;
+    DCELL *d;
+    int i;
+    c = (CELL *) cell;
+    f = (FCELL *) cell;
+    d = (DCELL *) cell;
+    for (i = 0; i < ncols; i++) {
+	if (nulls[i]) {
+	    case CELL_TYPE:
+		Rast_set_c_null_value((CELL *) (c + i), 1);
+		break;
+	    case FCELL_TYPE:
+		Rast_set_f_null_value((FCELL *) (f + i), 1);
+		break;
+	    case DCELL_TYPE:
+		Rast_set_d_null_value((DCELL *) (d + i), 1);
+		break;
+	    default:
+		G_warning(_("EmbedGivenNulls: wrong data type"));
+  \brief To set one or more raster values to null.
+  It also sets null to zero if null_is_zero is TRUE.
+  \param rast pointer to values to set to null
+  \param numVals number of values to set to null
+  \param null_is_zero flag to indicate if NULL = 0
+  \param data_type type of raster - CELL, FCELL, DCELL
+void Rast__set_null_value(void *rast, int numVals, int null_is_zero,
+    if (null_is_zero) {
+	G_zero((char *)rast, numVals * Rast_raster_size(data_type));
+	return;
+    Rast_set_null_value(rast, numVals, data_type);
+ \param buf pointer to values to set to null
+void Rast_set_null_value(void *buf, int numVals, RASTER_MAP_TYPE data_type)
+    switch (data_type) {
+    case CELL_TYPE:
+	Rast_set_c_null_value((CELL *) buf, numVals);
+	break;
+    case FCELL_TYPE:
+	Rast_set_f_null_value((FCELL *) buf, numVals);
+	break;
+    case DCELL_TYPE:
+	Rast_set_d_null_value((DCELL *) buf, numVals);
+	break;
+    default:
+	G_warning(_("Rast_set_null_value: wrong data type!"));
+  \brief To set a number of CELL raster values to NULL.
+  \param cellVals pointer to CELL values to set to null
+void Rast_set_c_null_value(CELL *cellVals, int numVals)
+    int i;			/* counter */
+    for (i = 0; i < numVals; i++)
+	cellVals[i] = (int) 0x80000000;
+ \brief To set a number of FCELL raster values to NULL.
+ \param fcellVals pointer to FCELL values to set to null
+void Rast_set_f_null_value(FCELL *fcellVals, int numVals)
+    static const unsigned char null_bits[4] = {
+	0xFF, 0xFF, 0xFF, 0xFF};
+    int i;
+	memcpy(&fcellVals[i], null_bits, sizeof(null_bits));
+  \brief To set a number of DCELL raster values to NULL.
+  \param dcellVals pointer to DCELL values to set to null
+void Rast_set_d_null_value(DCELL *dcellVals, int numVals)
+    static const unsigned char null_bits[8] = {
+	0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF};
+    int i;
+	memcpy(&dcellVals[i], null_bits, sizeof(null_bits));
+  \brief To check if a raster value is set to NULL
+    - If the <em>data_type</em> is CELL_TYPE, calls Rast_is_c_null_value()
+    - If the <em>data_type</em> is FCELL_TYPE, calls Rast_is_f_null_value()
+    - If the <em>data_type</em> is DCELL_TYPE, calls Rast_is_d_null_value()
+  \param rast raster value to check
+  \return TRUE if raster value is NULL
+  \return FALSE otherwise
+int Rast_is_null_value(const void *rast, RASTER_MAP_TYPE data_type)
+    case CELL_TYPE:
+	return (Rast_is_c_null_value((CELL *) rast));
+    case FCELL_TYPE:
+	return (Rast_is_f_null_value((FCELL *) rast));
+    case DCELL_TYPE:
+	return (Rast_is_d_null_value((DCELL *) rast));
+    default:
+	G_warning("Rast_is_null_value: wrong data type!");
+	return FALSE;
+  \brief To check if a CELL raster value is set to NULL
+  Returns 1 if <em>cell</em> is NULL, 0 otherwise. This will test if the
+  value <em>cell</em> is the largest <tt>int</tt>.
+  \param cellVal CELL raster value to check
+  \return TRUE if CELL raster value is NULL
+int Rast_is_c_null_value(const CELL * cellVal)
+    /* Check if the CELL value matches the null pattern */
+    return *cellVal == (CELL) 0x80000000;
+  \brief To check if a FCELL raster value is set to NULL
+  Returns 1 if <em>fcell</em> is NULL, 0 otherwise. This will test if
+  the value <em>fcell</em> is a NaN. It isn't good enough to test for
+  a particular NaN bit pattern since the machine code may change this
+  bit pattern to a different NaN. The test will be
+  \code
+  if(fcell==0.0) return 0;
+  if(fcell>0.0) return 0;
+  if(fcell<0.0) return 0;
+  return 1;
+  \endcode
+  or (as suggested by Mark Line)
+  \code
+  return (fcell != fcell);
+  \endcode
+  \param fcellVal FCELL raster value to check
+  \return TRUE if FCELL raster value is NULL
+int Rast_is_f_null_value(const FCELL * fcellVal)
+    return *fcellVal != *fcellVal;
+  \brief To check if a DCELL raster value is set to NULL
+  Returns 1 if <em>dcell</em> is NULL, 0 otherwise. This will test if
+  the value <em>dcell</em> is a NaN. Same test as in
+  Rast_is_f_null_value().
+  \param dcellVal DCELL raster value to check
+  \return TRUE if DCELL raster value is NULL
+int Rast_is_d_null_value(const DCELL * dcellVal)
+    return *dcellVal != *dcellVal;
+  - If the <em>data_type</em> is CELL_TYPE, calls Rast_insert_c_null_values()
+  - If the <em>data_type</em> is FCELL_TYPE, calls Rast_insert_f_null_values()
+  - If the <em>data_type</em> is DCELL_TYPE, calls Rast_insert_d_null_values()
+  \param rast pointer raster values
+  \param null_row null row
+void Rast_insert_null_values(void *rast, char *null_row, int ncols,
+    EmbedGivenNulls(rast, null_row, data_type, ncols);
+  \brief To insert null values into an integer raster map (CELL)
+  For each of the <em>count</em> <em>flags</em> which is true(!=0),
+  set the corresponding <em>cell</em> to the NULL value.
+void Rast_insert_c_null_values(CELL * cellVal, char *null_row, int ncols)
+    EmbedGivenNulls((void *)cellVal, null_row, CELL_TYPE, ncols);
+  \brief To insert null values into an floating-point raster map (FCELL)
+  \param fcellVal pointer raster values
+void Rast_insert_f_null_values(FCELL * fcellVal, char *null_row, int ncols)
+    EmbedGivenNulls((void *)fcellVal, null_row, FCELL_TYPE, ncols);
+  For each for the <em>count</em> <em>flag</em> which is true(!=0), set
+  the corresponding <em>dcell</em> to the NULL value.
+  \param dcellVal pointer raster values
+void Rast_insert_d_null_values(DCELL * dcellVal, char *null_row, int ncols)
+    EmbedGivenNulls((void *)dcellVal, null_row, DCELL_TYPE, ncols);
+  \brief Check NULL
+  Note: Only for internal use.
+  \param flags ?
+  \param bit_num ?
+  \param n ?
+int Rast__check_null_bit(const unsigned char *flags, int bit_num, int n)
+    int ind;
+    int offset;
+    /* find the index of the unsigned char in which this bit appears */
+    ind = Rast__null_bitstream_size(bit_num + 1) - 1;
+    /* find how many unsigned chars the buffer with bit_num+1 (counting from 0
+       has and subtract 1 to get unsigned char index */
+    if (ind > Rast__null_bitstream_size(n) - 1) {
+	G_warning("Rast__check_null_bit: Unable to access index %d. "
+		  "Size of flags is %d (bit # is %d)",
+		  ind, Rast__null_bitstream_size(n) - 1, bit_num);
+	return -1;
+    offset = (ind + 1) * 8 - bit_num - 1;
+    return ((flags[ind] & ((unsigned char)1 << offset)) != 0);
+  \brief Given array of 0/1 of length n starting from column.
+  Given array of 0/1 of length n starting from column set the
+  corresponding bits of flags; total number of bits in flags is ncols.
+  \param zero_ones
+  \param flags
+  \param col
+  \param n
+  \param ncols
+  \return 0
+  \return 1
+int G__set_flags_from_01_random(const char *zero_ones, unsigned char *flags,
+				int col, int n, int ncols)
+    unsigned char v;
+    int count;
+    int size;
+    int i, k;
+    if (col == 0 && n == ncols) {
+	Rast__convert_01_flags(zero_ones, flags, n);
+	return 0;
+    count = 0;
+    size = Rast__null_bitstream_size(ncols);
+    for (i = 0; i < size; i++) {
+	v = 0;
+	k = 8;
+	while (k-- > 0) {
+	    if (count >= col && count < (col + n)) {
+		v = v | ((unsigned char)zero_ones[count - col] << k);
+	    else if (count < ncols) {
+		v = v |
+		    ((unsigned char)Rast__check_null_bit(flags, count, ncols) << k);
+	    /* otherwise  keep this bit the same as it was */
+	    count++;
+	flags[i] = v;
+    return 1;
+  \brief ?
+  \param zero_ones
+  \param flags
+  \param n
+void Rast__convert_01_flags(const char *zero_ones, unsigned char *flags, int n)
+    unsigned char *v;
+    int count;
+    int size;
+    int i, k;
+    /* pad the flags with 0's to make size multiple of 8 */
+    v = flags;
+    size = Rast__null_bitstream_size(n);
+    count = 0;
+	*v = 0;
+	k = 8;
+	while (k-- > 0) {
+	    if (count < n) {
+		*v = *v | ((unsigned char)zero_ones[count] << k);
+	    count++;
+	v++;
+  \brief ?
+  \param zero_ones
+  \param flags
+  \param n
+void Rast__convert_flags_01(char *zero_ones, const unsigned char *flags, int n)
+    const unsigned char *v;
+    int count;
+    int size;
+    int i, k;
+    count = 0;
+    v = flags;
+	k = 8;
+	while (k-- > 0) {
+	    if (count < n) {
+		zero_ones[count] = ((*v & ((unsigned char)1 << k)) != 0);
+		count++;
+	v++;
+  \brief ?
+  \param flags
+  \param cols
+void Rast__init_null_bits(unsigned char *flags, int cols)
+    unsigned char *v;
+    int size;
+    int i;
+    v = flags;
+	if ((i + 1) * 8 <= cols) {
+	    *v = (unsigned char)255;
+	else {
+	    *v = (unsigned char)255 << ((i + 1) * 8 - cols);
+	v++;
Copied: grass/trunk/lib/raster/opencell.c (from rev 37989, grass/trunk/lib/gis/opencell.c)
--- grass/trunk/lib/raster/opencell.c	                        (rev 0)
+++ grass/trunk/lib/raster/opencell.c	2009-06-20 22:03:23 UTC (rev 38003)
@@ -0,0 +1,972 @@
+ * \file gis/opencell.c
+ * \brief GIS Library - Open raster file
+ * for details.
+#include <unistd.h>
+#include <string.h>
+#include <sys/stat.h>
+#include <fcntl.h>
+#include <grass/config.h>
+#include "G.h"
+#define FORMAT_FILE "f_format"
+static struct fileinfo *new_fileinfo(int fd)
+    int oldsize = G__.fileinfo_count;
+    int newsize = oldsize;
+    int i;
+    if (fd < oldsize)
+	return &G__.fileinfo[fd];
+    newsize *= 2;
+    if (newsize <= fd)
+	newsize = fd + 20;
+    G__.fileinfo = G_realloc(G__.fileinfo, newsize * sizeof(struct fileinfo));
+    /* Mark all cell files as closed */
+    for (i = oldsize; i < newsize; i++) {
+	memset(&G__.fileinfo[i], 0, sizeof(struct fileinfo));
+	G__.fileinfo[i].open_mode = -1;
+    G__.fileinfo_count = newsize;
+ * \brief Open raster file
+ * Arrange for the NULL-value bitmap to be read as well as the raster
+ * map. If no NULL-value bitmap exists, arrange for the production of
+ * NULL-values based on zeros in the raster map. If the map is
+ * floating-point, arrange for quantization to integer for
+ * Rast_get_c_raster_row(), et. al., by reading the quantization rules
+ * for the map using Rast_read_quant(). If the programmer wants to read
+ * the floating point map using uing quant rules other than the ones
+ * stored in map's quant file, he/she should call Rast_set_quant_rules()
+ * after the call to Rast_open_cell_old().
+ * \param open_mode mode
+ * \param map_type map type (CELL, FCELL, DCELL)
+ * \return open file descriptor ( >= 0) if successful
+ *  \return negative integer if error
+static int G__open_raster_new(const char *name, int open_mode,
+			      RASTER_MAP_TYPE map_type);
+  \brief Open an existing integer raster map (cell)
+  Opens the existing cell file <i>name</i> in the <i>mapset</i> for
+  reading by Rast_get_raster_row() with mapping into the current window.
+  This routine opens the raster map <i>name</i> in <i>mapset</i> for
+  reading. A nonnegative file descriptor is returned if the open is
+  successful. Otherwise a diagnostic message is printed and a negative
+  value is returned. This routine does quite a bit of work. Since
+  GRASS users expect that all raster maps will be resampled into the
+  current region, the resampling index for the raster map is prepared
+  by this routine after the file is opened. The resampling is based on
+  the active module region (see also \ref The_Region}. Preparation
+  required for reading the various raster file formats (see \ref
+  Raster_File_Format for an explanation of the various raster file
+  formats) is also done.
+  Diagnostics: warning message printed if open fails.
+  \param name map name
+  \param mapset mapset name where raster map <i>name</i> lives
+  \return nonnegative file descriptor (int)
+  \return -1 on failure
+int Rast_open_cell_old(const char *name, const char *mapset)
+    int fd;
+    if ((fd = Rast__open_cell_old(name, mapset)) < 0) {
+	G_warning(_("Unable to open raster map <%s@%s>"), name, mapset);
+	return fd;
+    /* turn on auto masking, if not already on */
+       if(G__.auto_mask <= 0)
+       G__.mask_buf = Rast_allocate_cell_buf();
+       now we don't ever free it!, so no need to allocate it  (Olga)
+    /* mask_buf is used for reading MASK file when mask is set and
+       for reading map rows when the null file doesn't exist */
+    return fd;
+/*!  \brief Lower level function, open cell files, supercell files,
+  and the MASK file.
+  Actions:
+   - opens the named cell file, following reclass reference if
+   named layer is a reclass layer.
+   - creates the required mapping between the data and the window
+   for use by the get_map_row family of routines.
+  Diagnostics: Errors other than actual open failure will cause a
+  diagnostic to be delivered thru G_warning() open failure messages
+  are left to the calling routine since the masking logic will want to
+  issue a different warning.
+  Note: This routine does NOT open the MASK layer. If it did we would
+  get infinite recursion.  This routine is called to open the mask by
+  Rast__check_for_auto_masking() which is called by Rast_open_cell_old().
+  \param mapset mapset of cell file to be opened
+  \return open file descriptor
+  \return -1 if error
+int Rast__open_cell_old(const char *name, const char *mapset)
+    struct fileinfo *fcb;
+    int fd;
+    char *cell_dir;
+    const char *r_name;
+    const char *r_mapset;
+    struct Cell_head cellhd;
+    int CELL_nbytes = 0;	/* bytes per cell in CELL map */
+    int INTERN_SIZE;
+    int reclass_flag, i;
+    int MAP_NBYTES;
+    RASTER_MAP_TYPE MAP_TYPE;
+    struct Reclass reclass;
+    char xname[GNAME_MAX], xmapset[GMAPSET_MAX];
+    struct GDAL_link *gdal;
+    /* make sure window is set    */
+    G__init_window();
+    G__unqualified_name(name, mapset, xname, xmapset);
+    name = xname;
+    mapset = xmapset;
+    if (!G_find_cell2(name, mapset)) {
+	G_warning(_("Unable to find <%s@%s>"), name, mapset);
+	return -1;
+    /* Check for reclassification */
+    reclass_flag = Rast_get_reclass(name, mapset, &reclass);
+    switch (reclass_flag) {
+    case 0:
+	r_name = name;
+	r_mapset = mapset;
+	break;
+    case 1:
+	r_name = reclass.name;
+	r_mapset = reclass.mapset;
+	if (G_find_cell2(r_name, r_mapset) == NULL) {
+	    G_warning(_("Unable to open raster map <%s@%s> since it is a reclass "
+			"of raster map <%s@%s> which does not exist"),
+		      name, mapset, r_name, r_mapset);
+	    return -1;
+	break;
+    default:			/* Error reading cellhd/reclass file */
+	return -1;
+    /* read the cell header */
+    if (Rast_get_cellhd(r_name, r_mapset, &cellhd) < 0)
+	return -1;
+    /* now check the type */
+    MAP_TYPE = Rast_raster_map_type(r_name, r_mapset);
+    if (MAP_TYPE < 0)
+	return -1;
+    if (MAP_TYPE == CELL_TYPE)
+	/* set the number of bytes for CELL map */
+	CELL_nbytes = cellhd.format + 1;
+	if (CELL_nbytes < 1) {
+	    G_warning(_("Raster map <%s@%s>: format field in header file invalid"),
+		      r_name, r_mapset);
+	    return -1;
+    if (cellhd.proj != G__.window.proj) {
+	G_warning(_("Raster map <%s@%s> is in different projection than current region. "
+		    "Found raster map <%s@%s>, should be <%s>."),
+		  name, mapset, name, G__projection_name(cellhd.proj),
+		  G__projection_name(G__.window.proj));
+	return -1;
+    if (cellhd.zone != G__.window.zone) {
+	G_warning(_("Raster map <%s@%s> is in different zone (%d) than current region (%d)"),
+		  name, mapset, cellhd.zone, G__.window.zone);
+	return -1;
+    /* when map is int warn if too large cell size */
+    if (MAP_TYPE == CELL_TYPE && (unsigned int) CELL_nbytes > sizeof(CELL)) {
+	G_warning(_("Raster map <%s@%s>: bytes per cell (%d) too large"),
+		  name, mapset, CELL_nbytes);
+	return -1;
+    /* record number of bytes per cell */
+    if (MAP_TYPE == FCELL_TYPE) {
+	cell_dir = "fcell";
+	INTERN_SIZE = sizeof(FCELL);
+	MAP_NBYTES = XDR_FLOAT_NBYTES;
+    else if (MAP_TYPE == DCELL_TYPE) {
+	INTERN_SIZE = sizeof(DCELL);
+	MAP_NBYTES = XDR_DOUBLE_NBYTES;
+    else {			/* integer */
+	cell_dir = "cell";
+	INTERN_SIZE = sizeof(CELL);
+	MAP_NBYTES = CELL_nbytes;
+    gdal = Rast_get_gdal_link(r_name, r_mapset);
+    if (gdal) {
+#ifdef HAVE_GDAL
+	/* dummy descriptor to reserve the fileinfo slot */
+	fd = open(G_DEV_NULL, O_RDONLY);
+#else
+	G_warning(_("map <%s@%s> is a GDAL link but GRASS is compiled without GDAL support"),
+	return -1;
+#endif
+    else
+	/* now actually open file for reading */
+	fd = G_open_old(cell_dir, r_name, r_mapset);
+    if (fd < 0)
+	return -1;
+    fcb = new_fileinfo(fd);
+    fcb->map_type = MAP_TYPE;
+    /* Save cell header */
+    G_copy((char *)&fcb->cellhd, (char *)&cellhd, sizeof(cellhd));
+    /* allocate null bitstream buffers for reading null rows */
+	fcb->NULL_ROWS[i] = Rast__allocate_null_bits(G__.window.cols);
+    /* initialize : no NULL rows in memory */
+    fcb->min_null_row = (-1) * NULL_ROWS_INMEM;
+    /* mark closed */
+    fcb->open_mode = -1;
+    /* save name and mapset */
+    fcb->name = G_store(name);
+    fcb->mapset = G_store(mapset);
+    /* mark no data row in memory  */
+    /* fcb->null_cur_row is not used for reading, only for writing */
+    fcb->null_cur_row = -1;
+    /* if reclass, copy reclass structure */
+    if ((fcb->reclass_flag = reclass_flag))
+	G_copy(&fcb->reclass, &reclass, sizeof(reclass));
+    fcb->gdal = gdal;
+    if (!gdal)
+	/* check for compressed data format, making initial reads if necessary */
+	if (Rast__check_format(fd) < 0) {
+	    close(fd);		/* warning issued by check_format() */
+	    return -1;
+    /* create the mapping from cell file to window */
+    G__create_window_mapping(fd);
+     * allocate the data buffer
+     * number of bytes per cell is cellhd.format+1
+    /* for reading fcb->data is allocated to be fcb->cellhd.cols * fcb->nbytes
+       (= XDR_FLOAT/DOUBLE_NBYTES) */
+    fcb->data = (unsigned char *)G_calloc(fcb->cellhd.cols, MAP_NBYTES);
+    /* initialize/read in quant rules for float point maps */
+    if (fcb->map_type != CELL_TYPE) {
+	    Rast_read_quant(fcb->reclass.name, fcb->reclass.mapset,
+			 &(fcb->quant));
+	else
+	    Rast_read_quant(fcb->name, fcb->mapset, &(fcb->quant));
+    /* now mark open for read: this must follow create_window_mapping() */
+    fcb->open_mode = OPEN_OLD;
+    fcb->io_error = 0;
+    fcb->nbytes = MAP_NBYTES;
+    fcb->null_file_exists = -1;
+	xdrmem_create(&fcb->xdrstream, (caddr_t) fcb->data,
+		      (u_int) (fcb->nbytes * fcb->cellhd.cols), XDR_DECODE);
+    return fd;
+  \brief Opens a new cell file in a database (compressed)
+  Opens a new cell file <i>name</i> in the current mapset for writing
+  by Rast_put_raster_row().
+  The file is created and filled with no data it is assumed that the
+  new cell file is to conform to the current window.
+  The file must be written sequentially. Use Rast_open_cell_new_random()
+  for non sequential writes.
+  Note: the open actually creates a temporary file Rast_close_cell() will
+  move the temporary file to the cell file and write out the necessary
+  support files (cellhd, cats, hist, etc.).
+  Warning: calls to G_set_window() made after opening a new cell file
+  may create confusion and should be avoided the new cell file will be
+  created to conform to the window at the time of the open.
+  \return open file descriptor ( >= 0) if successful
+  \return negative integer if error
+int Rast_open_cell_new(const char *name)
+    return G__open_raster_new(name, OPEN_NEW_COMPRESSED, CELL_TYPE);
+  \brief Opens a new cell file in a database (uncompressed)
+  See also Rast_open_cell_new().
+int Rast_open_cell_new_uncompressed(const char *name)
+    return G__open_raster_new(name, OPEN_NEW_UNCOMPRESSED, CELL_TYPE);
+  \brief Save histogram for newly create raster map (cell)
+  If newly created cell files should have histograms, set flag=1
+  otherwise set flag=0. Applies to subsequent opens.
+  \param flag flag indicator
+void Rast_want_histogram(int flag)
+    G__.want_histogram = flag;
+  \brief Sets the format for subsequent opens on new integer cell files
+  (uncompressed and random only).
+  Warning: subsequent put_row calls will only write n+1 bytes per
+  cell. If the data requires more, the cell file will be written
+  incorrectly (but with n+1 bytes per cell)
+  When writing float map: format is -1
+  \param n format
+void Rast_set_cell_format(int n)
+/* sets the format for integer raster map */
+    G__.nbytes = n + 1;
+    if (G__.nbytes <= 0)
+	G__.nbytes = 1;
+    if (G__.nbytes > sizeof(CELL))
+	G__.nbytes = sizeof(CELL);
+  \brief Get cell value format
+  \param v cell
+  \return cell format
+int Rast_cellvalue_format(CELL v)
+    unsigned int i;
+    if (v >= 0)
+	for (i = 0; i < sizeof(CELL); i++)
+	    if (!(v /= 256))
+		return i;
+    return sizeof(CELL) - 1;
+  \brief Opens new fcell file in a database
+  Opens a new floating-point map <i>name</i> in the current mapset for
+  writing. The type of the file (i.e. either double or float) is
+  determined and fixed at this point. The default is FCELL_TYPE. In
+  order to change this default
+  Use Rast_set_fp_type() where type is one of DCELL_TYPE or FCELL_TYPE.
+  See warnings and notes for Rast_open_cell_new().
+  \return -1 on error
+int Rast_open_fp_cell_new(const char *name)
+    return G__open_raster_new(name, OPEN_NEW_COMPRESSED, G__.fp_type);
+  \brief Opens new fcell file in a database (uncompressed)
+  See Rast_open_fp_cell_new() for details.
+int Rast_open_fp_cell_new_uncompressed(const char *name)
+    return G__open_raster_new(name, OPEN_NEW_UNCOMPRESSED, G__.fp_type);
+#ifdef HAVE_GDAL
+static int G__open_raster_new_gdal(char *map, char *mapset, RASTER_MAP_TYPE map_type)
+    int fd;
+    int i;
+    fd = open("/dev/null", O_RDONLY);
+    if (fd < 0)
+	return -1;
+    /* mark closed */
+    fcb->map_type = map_type;
+    fcb->gdal = Rast_create_gdal_link(map, map_type);
+    if (!fcb->gdal)
+	return -1;
+    fcb->cellhd = G__.window;
+    fcb->cellhd.compressed = 0;
+    fcb->nbytes = Rast_raster_size(fcb->map_type);
+    /* for writing fcb->data is allocated to be G__.window.cols *
+       sizeof(CELL or DCELL or FCELL)  */
+    fcb->data = G_calloc(G__.window.cols, fcb->nbytes);
+    fcb->name = map;
+    fcb->mapset = mapset;
+    fcb->cur_row = 0;
+    fcb->row_ptr = NULL;
+    fcb->temp_name = NULL;
+    fcb->null_temp_name = NULL;
+    fcb->null_cur_row = 0;
+    fcb->min_null_row = 0;
+	fcb->NULL_ROWS[i] = NULL;
+	Rast_quant_init(&(fcb->quant));
+    /* init cell stats */
+    /* now works only for int maps */
+	if ((fcb->want_histogram = G__.want_histogram))
+	    Rast_init_cell_stats(&fcb->statf);
+    /* init range and if map is double/float init d/f_range */
+    Rast_init_range(&fcb->range);
+	Rast_init_fp_range(&fcb->fp_range);
+    /* mark file as open for write */
+    fcb->open_mode = OPEN_NEW_UNCOMPRESSED;
+    return fd;
+#endif /* HAVE_GDAL */
+    int i, null_fd, fd;
+    char *tempname;
+    char *map;
+    char *mapset;
+    const char *cell_dir;
+    int nbytes;
+    switch (map_type) {
+    case CELL_TYPE:
+	nbytes = G__.nbytes;
+	break;
+    case FCELL_TYPE:
+	nbytes = XDR_FLOAT_NBYTES;
+	break;
+    case DCELL_TYPE:
+	nbytes =  XDR_DOUBLE_NBYTES;
+	break;
+    default:
+	G_fatal_error(_("Invalid map type <%d>"), map_type);
+	break;
+    if (G__unqualified_name(name, G_mapset(), xname, xmapset) < 0)
+	G_fatal_error(_("Raster map <%s> is not in the current mapset (%s)"),
+		      name, G_mapset());
+    map = G_store(xname);
+    mapset = G_store(xmapset);
+    /* check for legal grass name */
+    if (G_legal_filename(map) < 0) {
+	G_warning(_("<%s> is an illegal file name"), map);
+	return -1;
+    G__init_window();
+#ifdef HAVE_GDAL
+    if (G_find_file2("", "GDAL", G_mapset()))
+	return G__open_raster_new_gdal(map, mapset, map_type);
+#endif
+    /* open a tempfile name */
+    tempname = G_tempfile();
+    fd = creat(tempname, 0666);
+    if (fd < 0) {
+	G_warning(_("G__open_raster_new(): no temp files available"));
+	G_free(mapset);
+	G_free(tempname);
+	G_free(map);
+	return -1;
+     * since we are bypassing the normal open logic
+     * must create the cell element
+    G__make_mapset_element(cell_dir);
+    /* mark closed */
+    fcb->gdal = NULL;
+    fcb->data = (unsigned char *)G_calloc(G__.window.cols,
+					  Rast_raster_size(fcb->map_type));
+     * copy current window into cell header
+     * set format to cell/supercell
+     * for compressed writing
+     *   allocate space to hold the row address array
+    G_copy((char *)&fcb->cellhd, (char *)&G__.window, sizeof(fcb->cellhd));
+    if (open_mode == OPEN_NEW_COMPRESSED && fcb->map_type == CELL_TYPE) {
+	fcb->row_ptr = G_calloc(fcb->cellhd.rows + 1, sizeof(off_t));
+	G_zero(fcb->row_ptr, (fcb->cellhd.rows + 1) * sizeof(off_t));
+	Rast__write_row_ptrs(fd);
+	fcb->cellhd.compressed = G__.compression_type;
+	fcb->nbytes = 1;	/* to the minimum */
+    else {
+	fcb->nbytes = nbytes;
+	if (open_mode == OPEN_NEW_COMPRESSED) {
+	else
+    /* save name and mapset, and tempfile name */
+    fcb->name = map;
+    fcb->temp_name = tempname;
+    /* next row to be written (in order) is zero */
+    fcb->cur_row = 0;
+    /* open a null tempfile name */
+    null_fd = creat(tempname, 0666);
+    if (null_fd < 0) {
+	G_free(tempname);
+	G_free(fcb->name);
+	G_free(fcb->mapset);
+	G_free(fcb->temp_name);
+	close(fd);
+	return -1;
+    fcb->null_temp_name = tempname;
+    close(null_fd);
+    /* allocate null bitstream buffers for writing */
+	fcb->NULL_ROWS[i] = Rast__allocate_null_bits(fcb->cellhd.cols);
+    fcb->open_mode = open_mode;
+    return fd;
+  \brief Set raster map floating-point data format.
+  This controls the storage type for floating-point maps. It affects
+  subsequent calls to G_open_fp_map_new(). The <i>type</i> must be
+  one of FCELL_TYPE (float) or DCELL_TYPE (double). The use of this
+  routine by applications is discouraged since its use would override
+  user preferences.
+  \param type raster data type
+  \return 1 on success
+int Rast_set_fp_type(RASTER_MAP_TYPE map_type)
+    case FCELL_TYPE:
+    case DCELL_TYPE:
+	G__.fp_type = map_type;
+	return 1;
+    default:
+	G_warning(_("Rast_set_fp_type(): can only be called with FCELL_TYPE or DCELL_TYPE"));
+	return -1;
+  \brief Check if raster map is floating-point
+  Returns true (1) if raster map <i>name</i> in <i>mapset</i>
+  is a floating-point dataset; false(0) otherwise.
+  \return 1 floating-point
+  \return 0 int
+int Rast_raster_map_is_fp(const char *name, const char *mapset)
+    char path[GPATH_MAX];
+    const char *xmapset;
+    xmapset = G_find_cell2(name, mapset);
+    if (!xmapset) {
+	return -1;
+    G__file_name(path, "fcell", name, xmapset);
+    if (access(path, 0) == 0)
+	return 1;
+    G__file_name(path, "g3dcell", name, xmapset);
+	return 1;
+    return 0;
+  \brief Determine raster data type
+  Determines if the raster map is floating point or integer. Returns
+  DCELL_TYPE for double maps, FCELL_TYPE for float maps, CELL_TYPE for
+  integer maps, -1 if error has occured
+  \param mapset mapset where map <i>name</i> lives
+  \return raster data type
+RASTER_MAP_TYPE Rast_raster_map_type(const char *name, const char *mapset)
+    if (!xmapset) {
+	if (mapset && *mapset)
+	    G_warning(_("Raster map <%s> not found in mapset <%s>"), name, mapset);
+	else
+	    G_warning(_("Raster map <%s> not found"), name);
+	return -1;
+	return Rast__check_fp_type(name, xmapset);
+	return DCELL_TYPE;
+    return CELL_TYPE;
+  \brief Determine raster type from descriptor
+RASTER_MAP_TYPE Rast_get_raster_map_type(int fd)
+    struct fileinfo *fcb = &G__.fileinfo[fd];
+    return fcb->map_type;
+  \brief Determines whether the floating points cell file has double or float type
+  \return raster type (fcell, dcell)
+RASTER_MAP_TYPE Rast__check_fp_type(const char *name, const char *mapset)
+    struct Key_Value *format_keys;
+    int in_stat;
+    const char *str, *str1;
+    RASTER_MAP_TYPE map_type;
+    if (!xmapset) {
+	return -1;
+    G__file_name_misc(path, "cell_misc", FORMAT_FILE, name, xmapset);
+    if (access(path, 0) != 0) {
+	G_warning(_("Unable to find '%s'"), path);
+	return -1;
+    format_keys = G_read_key_value_file(path, &in_stat);
+    if (in_stat != 0) {
+	G_warning(_("Unable to open '%s'"), path);
+	return -1;
+    if ((str = G_find_key_value("type", format_keys)) != NULL) {
+	if (strcmp(str, "double") == 0)
+	    map_type = DCELL_TYPE;
+	else if (strcmp(str, "float") == 0)
+	    map_type = FCELL_TYPE;
+	else {
+	    G_warning(_("Invalid type: field '%s' in file '%s'"),
+		      str, path);
+	    G_free_key_value(format_keys);
+	    return -1;
+    else {
+	return -1;
+    if ((str1 = G_find_key_value("byte_order", format_keys)) != NULL) {
+	if (strcmp(str1, "xdr") != 0)
+	    G_warning(_("Raster map <%s> is not xdr: byte_order: %s"),
+			name, str);
+	/* here read and translate  byte order if not using xdr */
+    return map_type;
+  \brief Opens a new raster map
+  Opens a new raster map of type <i>wr_type</i>
+  Supported data types:
+   - CELL_TYPE
+   - FCELL_TYPE
+   - DCELL_TYPE
+  On CELL_TYPE calls Rast_open_cell_new() otherwise Rast_open_fp_cell_new().
+  \param wr_type raster data type
+int Rast_open_raster_new(const char *name, RASTER_MAP_TYPE wr_type)
+    return G__open_raster_new(name, OPEN_NEW_COMPRESSED, wr_type);
+  \brief Opens a new raster map (uncompressed)
+  See Rast_open_raster_new().
+int Rast_open_raster_new_uncompressed(const char *name, RASTER_MAP_TYPE wr_type)
+    return G__open_raster_new(name, OPEN_NEW_UNCOMPRESSED, wr_type);
+  \brief Sets quant translation rules for raster map opened for
+  reading.
+  Returned by Rast_open_cell_old(). After calling this function,
+  Rast_get_c_raster_row() and Rast_get_map_row() will use rules defined by q
+  (instead of using rules defined in map's quant file) to convert floats to
+  ints.
+  \param fd file descriptor (cell file)
+  \param q pointer to Quant structure
+  \return 0 success
+  \return -1 failure
+int Rast_set_quant_rules(int fd, struct Quant *q)
+    CELL cell;
+    DCELL dcell;
+    struct Quant_table *p;
+    if (fcb->open_mode != OPEN_OLD) {
+	G_warning(_("Rast_set_quant_rules() can be called only for "
+		    "raster maps opened for reading"));
+	return -1;
+    /* copy all info from q to fcb->quant) */
+    Rast_quant_init(&fcb->quant);
+    if (q->truncate_only) {
+	Rast_quant_truncate(&fcb->quant);
+	return 0;
+    for (p = &(q->table[q->nofRules - 1]); p >= q->table; p--)
+	Rast_quant_add_rule(&fcb->quant, p->dLow, p->dHigh, p->cLow, p->cHigh);
+    if (Rast_quant_get_neg_infinite_rule(q, &dcell, &cell) > 0)
+	Rast_quant_set_neg_infinite_rule(&fcb->quant, dcell, cell);
+    if (Rast_quant_get_pos_infinite_rule(q, &dcell, &cell) > 0)
+	Rast_quant_set_pos_infinite_rule(&fcb->quant, dcell, cell);
+    return 0;
Copied: grass/trunk/lib/raster/put_cellhd.c (from rev 37989, grass/trunk/lib/gis/put_cellhd.c)
--- grass/trunk/lib/raster/put_cellhd.c	                        (rev 0)
+++ grass/trunk/lib/raster/put_cellhd.c	2009-06-20 22:03:23 UTC (rev 38003)
@@ -0,0 +1,42 @@
+ * \file gis/put_cellhd.c
+ * \brief GIS Library - Write raster header.
+  \brief Writes the raster file header.
+  Writes the cell file header information associated with map layer "map"
+  into current mapset from the structure "cellhd".
+  \param name name of map
+  \param cellhd structure holding cell header info
+  \return 0 on success
+int Rast_put_cellhd(const char *name, struct Cell_head *cellhd)
+    FILE *fd;
+    if (!(fd = G_fopen_new("cellhd", name))) {
+	G_warning(_("Unable to create header file for <%s>"), name);
+	return -1;
+    G__write_Cell_head(fd, cellhd, 1);
+    fclose(fd);
+    return 0;
Copied: grass/trunk/lib/raster/put_row.c (from rev 37989, grass/trunk/lib/gis/put_row.c)
--- grass/trunk/lib/raster/put_row.c	                        (rev 0)
+++ grass/trunk/lib/raster/put_row.c	2009-06-20 22:03:23 UTC (rev 38003)
@@ -0,0 +1,878 @@
+ *   G_put_[c/f/d]_raster_row(fd, buf)
+ *      int fd           file descriptor of the opened map
+ *      [F/D]CELL *buf   buffer holding row info to be written
+ *   Writes the next row for the cell file opened on 'fd' from 'buf'
+ *   All writes go into NEW files that exactly match the current window.
+ *   The file must have been opened with Rast_open_cell_new()
+ *   and be written sequentially, ie no skipping rows
+ *   when the null values are embeded into the data, corresponding cells are
+ *   changed to 0's and the corresponding null value row is written into null
+ *   file.
+ *   *** NOTE ***
+ *   A map cannot be copied using Rast_get_raster_row() and Rast_put_raster_row().
+ *   The former resamples the data of the original map into a row buffer
+ *   that matches the current window.  The later writes out rows associated
+ *   with the window.
+ *   returns:    1  if successful
+ *              -1  on fail
+ *  Keeps track of the minimum and maximum cell value  for use in updating
+ *  the range file upon close of the cell file.
+ *  HOWEVER when nulls are not embeded, the cells are considered 0's as far
+ *  as updating range is concerned, even if the corresponding cell is null
+ *  in the resulting null file, so programmer should be carefult to set all
+ *  the null values using Rast_set_null_value() or G_insert_[d/f_]null_values()
+ *   Rast_put_map_row(fd, buf)
+ *      CELL *buf        buffer holding row info to be written
+ *   NULLS are written into null bitmap file for all cells which are zero,
+ *   and cells which have null value (these cells are converted to 0's before
+ *   writing)
+ *   *** NOTE ***
+ *   A map cannot be copied using Rast_get_map_row() and Rast_put_map_row().
+ *              -1  on fail
+ *  put_null_value_row(fd, buf)
+ *      int fd                  File descriptor where data is to be written
+ *      char *buf               Buffer holding null data
+ *   converts a buffer of zero's and ones to bitstream and stores this
+ *   bitstream in memory. (the null rows from memory are written into null
+ *   file after the limit is reached, and the place for new null rows
+ *   to be kept in memory is freed. Should not be used by application
+ *   programs.
+ *   returns:    0  if successful
+ *              -1  on fail
+#include <sys/types.h>
+#include <fcntl.h>
+#include <grass/Rast.h>
+#include "G.h"
+static int put_raster_data(int, char *, const void *, int, int, int,
+			   RASTER_MAP_TYPE);
+static int put_data(int, char *, const CELL *, int, int, int);
+static int check_open(const char *, int);
+static void write_error(int, int);
+static int same(const unsigned char *, const unsigned char *, int);
+static void set_file_pointer(int, int);
+static int put_fp_data(int, char *, const void *, int, int, RASTER_MAP_TYPE);
+static int put_null_data(int, const char *, int);
+static int convert_and_write_if(int, const CELL *);
+static int convert_and_write_id(int, const CELL *);
+static int convert_and_write_df(int, const DCELL *);
+static int convert_and_write_fd(int, const FCELL *);
+static int put_raster_row(int fd, const void *buf, RASTER_MAP_TYPE data_type,
+			  int zeros_r_nulls);
+static int put_null_value_row(int fd, const char *buf)
+    if (fcb->gdal)
+	G_fatal_error(_("GDAL output doesn't support writing null rows separately"));
+    switch (put_null_data(fd, buf, fcb->null_cur_row)) {
+    case -1:
+	return -1;
+    case 0:
+	return 1;
+    fcb->null_cur_row++;
+    return 1;
+int Rast_put_map_row(int fd, const CELL * buf)
+	G_fatal_error(_("Rast_put_map_row: %s is not integer! Use G_put_[f/d]_raster_row()!"),
+		      fcb->name);
+	return -1;
+    return put_raster_row(fd, buf, CELL_TYPE, 1);
+int Rast_put_raster_row(int fd, const void *buf, RASTER_MAP_TYPE data_type)
+    return put_raster_row(fd, buf, data_type, 0);
+int Rast_put_c_raster_row(int fd, const CELL * buf)
+    return Rast_put_raster_row(fd, buf, CELL_TYPE);
+int Rast_put_f_raster_row(int fd, const FCELL * buf)
+    return Rast_put_raster_row(fd, buf, FCELL_TYPE);
+int Rast_put_d_raster_row(int fd, const DCELL * buf)
+    return Rast_put_raster_row(fd, buf, DCELL_TYPE);
+static int check_open(const char *me, int fd)
+    switch (fcb->open_mode) {
+    case OPEN_OLD:
+	G_warning(_("%s: map [%s] not open for write - request ignored"), me,
+		  fcb->name);
+	break;
+    case OPEN_NEW_COMPRESSED:
+    case OPEN_NEW_UNCOMPRESSED:
+	return 1;
+	break;
+    default:
+	G_warning(_("%s: unopened file descriptor - request ignored"), me);
+	break;
+    return 0;
+static void write_error(int fd, int row)
+    if (fcb->io_error)
+	return;
+    G_warning(_("map [%s] - unable to write row %d"), fcb->name, row);
+    fcb->io_error = 1;
+static int write_data(int fd, int row, unsigned char *buf, int n)
+    ssize_t nwrite = fcb->nbytes * n;
+    if (write(fd, buf, nwrite) != nwrite) {
+	write_error(fd, row);
+	return -1;
+    return 0;
+static int write_data_compressed(int fd, int row, unsigned char *buf, int n)
+    int nwrite = fcb->nbytes * n;
+    if (G_zlib_write(fd, buf, nwrite) < 0) {
+	return -1;
+    return 0;
+static void set_file_pointer(int fd, int row)
+    fcb->row_ptr[row] = lseek(fd, 0L, SEEK_CUR);
+static int convert_float(XDR * xdrs, char *null_buf, const FCELL * rast,
+			 int row, int n)
+    int i;
+    for (i = 0; i < n; i++) {
+	FCELL f;
+	/* substitute embeded null vals by 0's */
+	if (Rast_is_f_null_value(&rast[i])) {
+	    f = 0.;
+	    null_buf[i] = 1;
+	else
+	    f = rast[i];
+	if (!xdr_float(xdrs, &f)) {
+	    G_warning(_("xdr_float failed for index %d of row %d"), i, row);
+	    return -1;
+    return 0;
+static int convert_double(XDR * xdrs, char *null_buf, const DCELL * rast,
+			  int row, int n)
+    int i;
+	DCELL d;
+	if (Rast_is_d_null_value(&rast[i])) {
+	    d = 0.;
+	    null_buf[i] = 1;
+	else
+	    d = rast[i];
+	if (!xdr_double(xdrs, &d)) {
+	    G_warning(_("xdr_double failed for index %d of row %d"), i, row);
+	    return -1;
+    return 0;
+/* writes data to fcell file for either full or partial rows */
+static int put_fp_data(int fd, char *null_buf, const void *rast,
+		       int row, int n, RASTER_MAP_TYPE data_type)
+    int compressed = (fcb->open_mode == OPEN_NEW_COMPRESSED);
+    XDR *xdrs = &fcb->xdrstream;
+    char *work_buf;
+    if (row < 0 || row >= fcb->cellhd.rows)
+	return 0;
+    if (n <= 0)
+	return 0;
+    work_buf = G__alloca(G__.window.cols * fcb->nbytes + 1);
+    if (compressed)
+	set_file_pointer(fd, row);
+    xdrmem_create(xdrs, work_buf,
+		  (unsigned int) fcb->nbytes * fcb->cellhd.cols, XDR_ENCODE);
+    xdr_setpos(xdrs, 0);
+    if (data_type == FCELL_TYPE) {
+	if (convert_float(xdrs, null_buf, rast, row, n) < 0) {
+	    G__freea(work_buf);
+	    return -1;
+    else {
+	if (convert_double(xdrs, null_buf, rast, row, n) < 0) {
+	    return -1;
+    xdr_destroy(&fcb->xdrstream);
+    if (compressed) {
+	if (write_data_compressed(fd, row, work_buf, n) == -1) {
+	    return -1;
+    else if (write_data(fd, row, work_buf, n) == -1) {
+	return -1;
+    return 1;
+static void convert_int(unsigned char *wk, char *null_buf, const CELL * rast,
+			int n, int len, int zeros_r_nulls)
+    int i;
+    /* transform CELL data into non-machine dependent multi-byte format */
+	CELL v = rast[i];
+	int neg;
+	int k;
+	if (Rast_is_c_null_value(&v)) {
+	    v = 0;
+	    null_buf[i] = 1;
+	else if (zeros_r_nulls && !v)
+	    null_buf[i] = 1;
+	/* negatives */
+	if (v < 0) {
+	    neg = 1;
+	    v = -v;
+	else
+	    neg = 0;
+	/* copy byte by byte */
+	for (k = len - 1; k >= 0; k--) {
+	    wk[k] = v & 0xff;
+	    v >>= 8;
+	/* set negative bit in first byte */
+	if (neg)
+	    wk[0] |= 0x80;
+	wk += len;
+static int count_bytes(const unsigned char *wk, int n, int len)
+    int i, j;
+    for (i = 0; i < len - 1; i++)
+	for (j = 0; j < n; j++)
+	    if (wk[j * len + i] != 0)
+		return len - i;
+    return 1;
+static void trim_bytes(unsigned char *wk, int n, int slen, int trim)
+    unsigned char *wk2 = wk;
+    int i, j;
+	for (j = 0; j < trim; j++)
+	    wk++;
+	for (; j < slen; j++)
+	    *wk2++ = *wk++;
+static int same(const unsigned char *x, const unsigned char *y, int n)
+    return (memcmp(x, y, n) == 0);
+static int count_run(const unsigned char *src, int n, int nbytes)
+    const unsigned char *cur = src + nbytes;
+    int i;
+    for (i = 1; i < n; i++) {
+	if (i == 255 || !same(cur, src, nbytes))
+	    return i;
+	cur += nbytes;
+    return n;
+static int rle_compress(unsigned char *dst, unsigned char *src, int n,
+			int nbytes)
+    int nwrite = 0;
+    int total = nbytes * n;
+    while (n > 0) {
+	int count;
+	nwrite += nbytes + 1;
+	if (nwrite >= total)
+	    return 0;
+	count = count_run(src, n, nbytes);
+	*dst++ = count;
+	memcpy(dst, src, nbytes);
+	dst += nbytes;
+	src += count * nbytes;
+	n -= count;
+    return nwrite;
+static int zlib_compress(unsigned char *dst, unsigned char *src, int n,
+			 int nbytes)
+    int nwrite = G_zlib_compress(src, total, dst, total);
+    return (nwrite >= total) ? 0 : nwrite;
+static int put_data(int fd, char *null_buf, const CELL *cell,
+		    int row, int n, int zeros_r_nulls)
+    int compressed = fcb->cellhd.compressed;
+    int len = compressed ? sizeof(CELL) : fcb->nbytes;
+    unsigned char *work_buf, *wk;
+    ssize_t nwrite;
+	return 0;
+    if (n <= 0)
+	return 0;
+    work_buf = G__alloca(G__.window.cols * sizeof(CELL) + 1);
+    wk = work_buf;
+    if (compressed)
+    if (compressed)
+	wk++;
+    convert_int(wk, null_buf, cell, n, len, zeros_r_nulls);
+    if (compressed) {
+	unsigned char *wk = work_buf + 1;
+	int nbytes = count_bytes(wk, n, len);
+	unsigned char *compressed_buf;
+	int total;
+	if (fcb->nbytes < nbytes)
+	/* first trim away zero high bytes */
+	if (nbytes < len)
+	    trim_bytes(wk, n, len, len - nbytes);
+	total = nbytes * n;
+	compressed_buf = G__alloca(total + 1);
+	compressed_buf[0] = work_buf[0] = nbytes;
+	/* then compress the data */
+	nwrite = compressed == 1
+	    ? rle_compress(compressed_buf + 1, work_buf + 1, n,
+			   nbytes)
+	    : zlib_compress(compressed_buf + 1, work_buf + 1, n,
+			    nbytes);
+	if (nwrite > 0) {
+	    nwrite++;
+	    if (write(fd, compressed_buf, nwrite) != nwrite) {
+		G__freea(compressed_buf);
+		return -1;
+	else {
+	    nwrite = nbytes * n + 1;
+	    if (write(fd, work_buf, nwrite) != nwrite) {
+		return -1;
+    else {
+	nwrite = fcb->nbytes * n;
+	    return -1;
+    return 1;
+static int put_data_gdal(int fd, const void *rast, int row, int n,
+			 int zeros_r_nulls, RASTER_MAP_TYPE map_type)
+#ifdef HAVE_GDAL
+    int size = Rast_raster_size(map_type);
+    DCELL null_val = fcb->gdal->null_val;
+    const void *src;
+    void *work_buf, *dst;
+    GDALDataType datatype;
+    CPLErr err;
+    int i;
+	return 0;
+    if (n <= 0)
+	return 0;
+    work_buf = G__alloca(n * size);
+    case CELL_TYPE:	datatype = GDT_Int32;	break;
+    case FCELL_TYPE:	datatype = GDT_Float32;	break;
+    case DCELL_TYPE:	datatype = GDT_Float64;	break;
+    src = rast;
+    dst = work_buf;
+	if (Rast_is_null_value(src, map_type) || zeros_r_nulls && !*(CELL *)src)
+	    Rast_set_raster_value_d(dst, null_val, map_type);
+	else
+	    memcpy(dst, src, size);
+	src = Rast_incr_void_ptr(src, size);
+	dst = Rast_incr_void_ptr(dst, size);
+    err = G_gdal_raster_IO(fcb->gdal->band, GF_Write, 0, row, n, 1, work_buf,
+			   n, 1, datatype, 0, 0);
+    return err == CE_None ? 1 : -1;
+#else
+    return -1;
+#endif
+static int put_raster_data(int fd, char *null_buf, const void *rast,
+			   int row, int n,
+    if (fcb->gdal)
+	return put_data_gdal(fd, rast, row, n, zeros_r_nulls, map_type);
+    return (map_type == CELL_TYPE)
+	? put_data(fd, null_buf, rast, row, n, zeros_r_nulls)
+	: put_fp_data(fd, null_buf, rast, row, n, map_type);
+static int put_null_data(int fd, const char *flags, int row)
+    int null_fd, i;
+    if (fcb->min_null_row + NULL_ROWS_INMEM <= row) {
+	/* the row is out of the range of rows stored in memory */
+	/* write out all the rows kept in memory, and initialize memory
+	   for keeping new NULL_ROWS_INMEM rows */
+	if (fcb->min_null_row >= 0) {
+	    null_fd = Rast__open_null_write(fd);
+	    if (null_fd < 0)
+		return -1;
+	    for (i = 0; i < NULL_ROWS_INMEM; i++) {
+		/* fcb->cellhd.rows doesn't have to be a miultiple of NULL_ROWS_INMEM */
+		if (i + fcb->min_null_row >= fcb->cellhd.rows)
+		    break;
+		if (Rast__write_null_bits(null_fd, fcb->NULL_ROWS[i],
+				       i + fcb->min_null_row,
+				       fcb->cellhd.cols, fd) < 0)
+		    return -1;
+	    }			/* done writing out memory rows */
+	    if (null_fd >= 0)
+		close(null_fd);
+	/* now initialize memory to store new NULL_ROWS_INMEM rows */
+	fcb->min_null_row = fcb->min_null_row + NULL_ROWS_INMEM;
+	/* init memory to store next NULL_ROWS_INMEM rows */
+    /* remember the null row for i for the future writing */
+    Rast__convert_01_flags(flags, fcb->NULL_ROWS[row - fcb->min_null_row],
+			fcb->cellhd.cols);
+    return 1;
+int Rast__open_null_write(int fd)
+    int null_fd;
+    if (access(fcb->null_temp_name, 0) != 0) {
+	G_warning(_("unable to find a temporary null file %s"),
+		  fcb->null_temp_name);
+	return -1;
+    null_fd = open(fcb->null_temp_name, O_WRONLY);
+    if (null_fd < 0)
+	return -1;
+    return null_fd;
+int Rast__write_null_bits(int null_fd, const unsigned char *flags, int row,
+		       int cols, int fd)
+    off_t offset;
+    size_t size;
+    size = Rast__null_bitstream_size(cols);
+    offset = (off_t) size *row;
+    if (lseek(null_fd, offset, SEEK_SET) < 0) {
+	G_warning(_("error writing null row %d"), row);
+	return -1;
+    if (write(null_fd, flags, size) != size) {
+	return -1;
+    return 1;
+static int convert_and_write_if(int fd, const CELL * buf)
+    FCELL *p = (FCELL *) fcb->data;
+    int i;
+    for (i = 0; i < fcb->cellhd.cols; i++)
+	if (Rast_is_c_null_value(&buf[i]))
+	    Rast_set_f_null_value(&p[i], 1);
+	else
+	    p[i] = (FCELL) buf[i];
+    return Rast_put_f_raster_row(fd, p);
+static int convert_and_write_df(int fd, const DCELL * buf)
+    int i;
+	if (Rast_is_d_null_value(&buf[i]))
+	else
+static int convert_and_write_id(int fd, const CELL * buf)
+    DCELL *p = (DCELL *) fcb->data;
+    int i;
+	    Rast_set_d_null_value(&p[i], 1);
+	else
+	    p[i] = (DCELL) buf[i];
+    return Rast_put_d_raster_row(fd, p);
+static int convert_and_write_fd(int fd, const FCELL * buf)
+    int i;
+	if (Rast_is_f_null_value(&buf[i]))
+	else
+static int convert_and_write_fi(int fd, const FCELL * buf)
+    CELL *p = (CELL *) fcb->data;
+    int i;
+	    Rast_set_c_null_value(&p[i], 1);
+	else
+	    p[i] = (CELL) buf[i];
+    return Rast_put_c_raster_row(fd, p);
+static int convert_and_write_di(int fd, const DCELL * buf)
+    int i;
+	else
+    static int (*convert_and_write_FtypeOtype[3][3])() = {
+	{NULL, convert_and_write_if, convert_and_write_id},
+	{convert_and_write_fi, NULL, convert_and_write_fd},
+	{convert_and_write_di, convert_and_write_df, NULL}
+    char *null_buf;
+    int stat;
+    if (!check_open("put_raster_row", fd))
+	return -1;
+    if (fcb->map_type != data_type)
+	return convert_and_write_FtypeOtype[data_type][fcb->map_type] (fd,
+								       buf);
+    null_buf = G__alloca(fcb->cellhd.cols);
+    G_zero(null_buf, fcb->cellhd.cols);
+    switch (put_raster_data(
+		fd, null_buf, buf, fcb->cur_row, fcb->cellhd.cols,
+		zeros_r_nulls, data_type)) {
+    case -1:
+	G__freea(null_buf);
+	return -1;
+    case 0:
+	return 1;
+    /* only for integer maps */
+    if (data_type == CELL_TYPE) {
+	if (fcb->want_histogram)
+	    Rast_update_cell_stats(buf, fcb->cellhd.cols, &fcb->statf);
+	Rast__row_update_range(buf, fcb->cellhd.cols, &fcb->range,
+			    zeros_r_nulls);
+    else
+	Rast_row_update_fp_range(buf, fcb->cellhd.cols, &fcb->fp_range,
+			      data_type);
+    fcb->cur_row++;
+    /* write the null row for the data row */
+    if (fcb->gdal)
+	stat = 0;
+    else
+	stat = put_null_value_row(fd, null_buf);
+    return stat;
Copied: grass/trunk/lib/raster/put_title.c (from rev 37989, grass/trunk/lib/gis/put_title.c)
--- grass/trunk/lib/raster/put_title.c	                        (rev 0)
+++ grass/trunk/lib/raster/put_title.c	2009-06-20 22:03:23 UTC (rev 38003)
@@ -0,0 +1,81 @@
+ * Rast_put_cell_title (name, title)
+ *   char *name        name of map file
+ *   char *title       new title
+ *   changes the title for the cell file 'name' in  current mapset
+ *   returns  1 if ok, -1 if error
+#include <grass/gis.h>
+#include <grass/glocale.h>
+int Rast_put_cell_title(const char *name, const char *title)
+    const char *mapset;
+    FILE *in, *out;
+    char *tempfile;
+    int line;
+    char buf[1024];
+    mapset = G_mapset();
+    in = out = 0;
+    in = G_fopen_old("cats", name, mapset);
+    if (!in) {
+	G_warning (_("category information for [%s] in [%s]"
+		     " missing or invalid"),
+		   name, mapset);
+	return -1;
+    tempfile = G_tempfile();
+    out = fopen(tempfile, "w");
+    if (!out) {
+	fclose(in);
+	G_warning (_("G_put_title - can't create a temp file"));
+	return -1;
+    for (line = 0; G_getl(buf, sizeof buf, in); line++) {
+	if (line == 1) {
+	    strcpy(buf, title);
+	    G_strip(buf);
+	fprintf(out, "%s\n", buf);
+    fclose(in);
+    fclose(out);
+    /* must be #cats line, title line, and label for cat 0 */
+    if (line < 3) {
+	G_warning (_("category information for [%s] in [%s] invalid"),
+		   name, mapset);
+	return -1;
+    in = fopen(tempfile, "r");
+    if (!in) {
+	G_warning (_("G_put_title - can't reopen temp file"));
+	return -1;
+    out = G_fopen_new("cats", name);
+    if (!out) {
+	fclose(in);
+	G_warning (_("can't write category information for [%s] in [%s]"),
+		   name, mapset);
+	return -1;
+    while (fgets(buf, sizeof buf, in))
+	fprintf(out, "%s", buf);
+    fclose(in);
+    fclose(out);
+    remove(tempfile);
+    return 1;
Copied: grass/trunk/lib/raster/quant.c (from rev 37989, grass/trunk/lib/gis/quant.c)
--- grass/trunk/lib/raster/quant.c	                        (rev 0)
+++ grass/trunk/lib/raster/quant.c	2009-06-20 22:03:23 UTC (rev 38003)
@@ -0,0 +1,792 @@
+ * \file gis/quant.c
+ * \brief GIS Library - Quantization rules.
+ * The quantization table is stored as a linear array. rules are added
+ * starting from index 0. redundant rules are not eliminated. rules
+ * are tested from the highest index downto 0. there are two
+ * "infinite" rules. support is provided to reverse the order of the
+ * rules.
+ * (C) 1999-2009 by the GRASS Development Team
+ * License (>=v2). Read the file COPYING that comes with GRASS
+ * for details.
+ * \author USACERL and many others
+#include <stdlib.h>
+static int double_comp(const void *, const void *);
+#define USE_LOOKUP 1
+#define MAX_LOOKUP_TABLE_SIZE 2048
+#define NO_DATA (Rast_set_c_null_value (&tmp, 1), (CELL) tmp)
+#undef MIN
+#undef MAX
+#define MIN(a,b) ((a) < (b) ? (a) : (b))
+#define MAX(a,b) ((a) > (b) ? (a) : (b))
+#define NO_LEFT_INFINITE_RULE (! q->infiniteLeftSet)
+#define NO_RIGHT_INFINITE_RULE (! q->infiniteRightSet)
+#define NO_FINITE_RULE (q->nofRules <= 0)
+#define NO_EXPLICIT_RULE (NO_FINITE_RULE && \
+			  NO_LEFT_INFINITE_RULE && NO_RIGHT_INFINITE_RULE)
+  \brief Resets the number of defined rules and number of infinite rules to 0
+  \param q pointer to Quant structure to be reset
+void Rast_quant_clear(struct Quant *q)
+    q->nofRules = 0;
+    q->infiniteRightSet = q->infiniteLeftSet = 0;
+  \brief Resets and frees allocated memory
+  Resets the number of defined rules to 0 and free's space allocated
+  for rules. Calls Rast_quant_clear().
+void Rast_quant_free(struct Quant *q)
+    Rast_quant_clear(q);
+    if (q->maxNofRules > 0)
+	G_free(q->table);
+    if (q->fp_lookup.active) {
+	G_free(q->fp_lookup.vals);
+	G_free(q->fp_lookup.rules);
+	q->fp_lookup.nalloc = 0;
+	q->fp_lookup.active = 0;
+    q->maxNofRules = 0;
+ * \brief Organized fp_lookup table.
+ *  Organizes fp_lookup table for faster (logarithmic) lookup time
+ *  G_quant_organize_fp_lookup() creates a list of min and max for
+ *  each quant rule, sorts this list, and stores the pointer to quant
+ *  rule that should be used inbetween any 2 numbers in this list.
+ *  Also it stores extreme points for 2 infinite rules, if exist.
+ *  After the call to G_quant_organize_fp_lookup()
+ *  instead of linearly searching through list of rules to find
+ *  a rule to apply, quant lookup will perform a binary search
+ *  to find an interval containing floating point value, and then use
+ *  the rule associated with this interval.
+ *  when the value doesn't fall within any interval, check for the
+ *  infinite rules.
+ * \param q pointer to Quant structure which holds quant rules info
+ * \return 1 on success
+int Rast__quant_organize_fp_lookup(struct Quant *q)
+    int i;
+    DCELL val;
+    CELL tmp;
+    if (q->nofRules * 2 > MAX_LOOKUP_TABLE_SIZE)
+	return -1;
+    if (q->nofRules == 0)
+	return -1;
+    q->fp_lookup.vals = (DCELL *)
+	G_calloc(q->nofRules * 2, sizeof(DCELL));
+    /* 2 endpoints for each rule */
+    q->fp_lookup.rules = (struct Quant_table **)
+	G_calloc(q->nofRules * 2, sizeof(struct Quant_table *));
+    /* first we organize finite rules into a table */
+    if (!NO_FINITE_RULE) {
+	i = 0;
+	/* get the list of DCELL values from set of all dLows and dHighs
+	   of all rules */
+	/* NOTE: if dLow==DHigh in a rule, the value appears twice in a list
+	   but if dLow==DHigh of the previous, rule the value appears only once */
+	for (p = &(q->table[q->nofRules - 1]); p >= q->table; p--) {
+	    /* check if the min is the same as previous maximum */
+	    if (i == 0 || p->dLow != q->fp_lookup.vals[i - 1])
+		q->fp_lookup.vals[i++] = p->dLow;
+	    q->fp_lookup.vals[i++] = p->dHigh;
+	q->fp_lookup.nalloc = i;
+	/* now sort the values */
+	qsort((char *)q->fp_lookup.vals, q->fp_lookup.nalloc,
+	      sizeof(DCELL), double_comp);
+	/* now find the rule to apply inbetween each 2 values in a list */
+	for (i = 0; i < q->fp_lookup.nalloc - 1; i++) {
+	    /*debug
+	       fprintf (stderr, "%lf %lf ", q->fp_lookup.vals[i], q->fp_lookup.vals[i+1]);
+	    val = (q->fp_lookup.vals[i] + q->fp_lookup.vals[i + 1]) / 2.;
+	    q->fp_lookup.rules[i] =
+		Rast__quant_get_rule_for_d_raster_val(q, val);
+	    /* debug
+	       if(q->fp_lookup.rules[i])
+	       fprintf (stderr, "%lf %lf %d %d\n", q->fp_lookup.rules[i]->dLow, q->fp_lookup.rules[i]->dHigh, q->fp_lookup.rules[i]->cLow, q->fp_lookup.rules[i]->cHigh);
+	       else fprintf (stderr, "null\n");
+    }				/* organizing finite rules */
+    if (!NO_LEFT_INFINITE_RULE) {
+	q->fp_lookup.inf_dmin = q->infiniteDLeft;
+	q->fp_lookup.inf_min = q->infiniteCLeft;
+    else {
+	if (q->fp_lookup.nalloc)
+	    q->fp_lookup.inf_dmin = q->fp_lookup.vals[0];
+	q->fp_lookup.inf_min = NO_DATA;
+    if (!NO_RIGHT_INFINITE_RULE) {
+	    q->fp_lookup.inf_dmax = q->infiniteDRight;
+	q->fp_lookup.inf_max = q->infiniteCRight;
+    else {
+	q->fp_lookup.inf_dmax = q->fp_lookup.vals[q->fp_lookup.nalloc - 1];
+	q->fp_lookup.inf_max = NO_DATA;
+    q->fp_lookup.active = 1;
+    return 1;
+ * \brief Initialize the structure
+ * Initializes the <i>q</i> struct.
+ * \param quant pointer to Quant structure to be initialized
+void Rast_quant_init(struct Quant *quant)
+    quant->fp_lookup.active = 0;
+    quant->maxNofRules = 0;
+    quant->truncate_only = 0;
+    quant->round_only = 0;
+    Rast_quant_clear(quant);
+  \brief Returns wether or not quant rules are set to truncate map
+  \param quant pointer to Quant structure which holds quant rules info
+  \return 1 if truncate is enable
+  \return 0 if not truncated
+int Rast_quant_is_truncate(const struct Quant *quant)
+    return quant->truncate_only;
+  \brief  Returns wether or not quant rules are set to round map
+  \return 1 is round
+  \return 0 not round
+int Rast_quant_is_round(const struct Quant *quant)
+    return quant->round_only;
+ * \brief Sets the quant rules to perform simple truncation on floats.
+ * Sets the quant for <i>q</i> rules to perform simple truncation on
+ * floats.
+ * \param quant pointer to Quant structure which holds quant rules info
+void Rast_quant_truncate(struct Quant *quant)
+    quant->truncate_only = 1;
+ * \brief Sets the quant rules to perform simple rounding on floats.
+ * Sets the quant for <i>q</i> rules to perform simple rounding on
+ * floats.
+void Rast_quant_round(struct Quant *quant)
+    quant->round_only = 1;
+static void quant_set_limits(struct Quant *q,
+			     DCELL dLow, DCELL dHigh, CELL cLow, CELL cHigh)
+    q->dMin = dLow;
+    q->dMax = dHigh;
+    q->cMin = cLow;
+    q->cMax = cHigh;
+static void quant_update_limits(struct Quant *q,
+				CELL cLow, DCELL cHigh)
+    if (NO_EXPLICIT_RULE) {
+	quant_set_limits(q, dLow, dHigh, cLow, cHigh);
+	return;
+    q->dMin = MIN(q->dMin, MIN(dLow, dHigh));
+    q->dMax = MAX(q->dMax, MAX(dLow, dHigh));
+    q->cMin = MIN(q->cMin, MIN(cLow, cHigh));
+    q->cMax = MAX(q->cMax, MAX(cLow, cHigh));
+ * \brief Returns the minimum and maximum cell and dcell values of all
+ *  the ranges defined.
+ * Extracts the minimum and maximum floating-point and integer values
+ * from all the rules (except the "infinite" rules) in <i>q</i> into
+ * <i>dmin</i>, <i>dmax</i>, <i>cmin</i>, and <i>cmax</i>.
+ * \param[out] dmin minimum fp value
+ * \param[out] dmax maximum fp value
+ * \param[out] cmin minimum value
+ * \param[out] cmax maximum value
+ * \return -1 if q->truncate or q->round are true or after
+ * Rast_quant_init (), or any call to Rast_quant_clear () or Rast_quant_free()
+ * no explicit rules have been added. In this case the returned
+ * minimum and maximum CELL and DCELL values are null.
+ * \return 1 if there are any explicit rules
+ * \return 0 if there are no explicit rules (this includes cases when
+ * q is set to truncate or round map), and sets <i>dmin</i>,
+ * <i>dmax</i>, <i>cmin</i>, and <i>cmax</i> to NULL.
+int Rast_quant_get_limits(const struct Quant *q,
+		       DCELL * dMin, DCELL * dMax, CELL * cMin, CELL * cMax)
+	Rast_set_c_null_value(cMin, 1);
+	Rast_set_c_null_value(cMax, 1);
+	Rast_set_d_null_value(dMin, 1);
+	Rast_set_d_null_value(dMax, 1);
+	return -1;
+    *dMin = q->dMin;
+    *dMax = q->dMax;
+    *cMin = q->cMin;
+    *cMax = q->cMax;
+    return 1;
+  \brief Returns the number of quantization rules defined.
+  This number does not include the 2 infinite intervals.
+  \param q pointer to Quant structure which holds quant rules info
+  \return number of quantization rules
+int Rast_quant_nof_rules(const struct Quant *q)
+    return q->nofRules;
+  \brief Returns the i'th quantization rule.
+  For 0 <= i < Rast_quant_nof_rules(). A larger value for i means that
+  the rule has been added later.
+  \param i index
+  \param[out] dLow minimum fp value
+  \param[out] dHigh maximum fp value
+  \param[out] cLow minimum value
+  \param[out] cHigh maximum value
+void Rast_quant_get_ith_rule(const struct Quant *q,
+			  int i,
+			  DCELL * dLow, DCELL * dHigh,
+			  CELL * cLow, CELL * cHigh)
+    *dLow = q->table[i].dLow;
+    *dHigh = q->table[i].dHigh;
+    *cLow = q->table[i].cLow;
+    *cHigh = q->table[i].cHigh;
+static void quant_table_increase(struct Quant *q)
+    if (q->nofRules < q->maxNofRules)
+	return;
+    if (q->maxNofRules == 0) {
+	q->maxNofRules = 50;
+	q->table = (struct Quant_table *)
+	    G_malloc(q->maxNofRules * sizeof(struct Quant_table));
+    else {
+	q->maxNofRules += 50;
+	    G_realloc((char *)q->table,
+		      q->maxNofRules * sizeof(struct Quant_table));
+  \brief Defines a rule for values "dLeft" and smaller.
+  Values in this range are mapped to "c" if none of the "finite"
+  quantization rules applies.
+  \param dLeft fp value
+  \param c value
+void Rast_quant_set_neg_infinite_rule(struct Quant *q, DCELL dLeft, CELL c)
+    q->infiniteDLeft = dLeft;
+    q->infiniteCLeft = c;
+    quant_update_limits(q, dLeft, dLeft, c, c);
+    /* update lookup table */
+    q->infiniteLeftSet = 1;
+  \brief Returns in "dLeft" and "c" the rule values.
+  For the negative infinite interval (see Rast_quant_set_neg_infinite_rule()).
+  \param[out] dLeft fp value
+  \param[out] c value
+  \return 0 if this rule is not defined
+  \return 1 otherwise
+int Rast_quant_get_neg_infinite_rule(const struct Quant *q,
+				  DCELL * dLeft, CELL * c)
+    if (q->infiniteLeftSet == 0)
+	return 0;
+    *dLeft = q->infiniteDLeft;
+    *c = q->infiniteCLeft;
+    return 1;
+  \brief Defines a rule for values "dRight" and larger.
+  quantization rules or the negative infinite rule applies.
+  \param dRight fp value
+  \param c value
+void Rast_quant_set_pos_infinite_rule(struct Quant *q, DCELL dRight, CELL c)
+    q->infiniteDRight = dRight;
+    q->infiniteCRight = c;
+    quant_update_limits(q, dRight, dRight, c, c);
+    q->infiniteRightSet = 1;
+  \brief Returns in "dRight" and "c" the rule values.
+  For the positive infinite interval (see Rast_quant_set_pos_infinite_rule()).
+  \param[out] dRight fp value
+int Rast_quant_get_pos_infinite_rule(const struct Quant *q,
+				  DCELL * dRight, CELL * c)
+    if (q->infiniteRightSet == 0)
+	return 0;
+    *dRight = q->infiniteDRight;
+    *c = q->infiniteCRight;
+    return 1;
+ \brief Adds a new rule to the set of quantization rules.
+ If dLow < dHigh the rule will be stored with the low and high values
+ interchanged.
+ Note: currently no cleanup of rules is performed, i.e. redundant
+ rules are not removed. This can't be changed because Categories
+ structure HEAVILY depends of quant rules stored in exactly the same
+ order they are entered. So if the cleanup or rearrangement is done in
+ the future make a flag for add_rule wether or not to do it, then
+ quant will not set this flag.
+ \param dLow minimum fp value
+ \param dHigh maximum fp value
+ \param cLow minimum value
+ \param cHigh maximum value
+void Rast_quant_add_rule(struct Quant *q,
+    int i;
+    quant_table_increase(q);
+    i = q->nofRules;
+    p = &(q->table[i]);
+    if (dHigh >= dLow) {
+	p->dLow = dLow;
+	p->dHigh = dHigh;
+	p->cLow = cLow;
+	p->cHigh = cHigh;
+    else {
+	p->dLow = dHigh;
+	p->dHigh = dLow;
+	p->cLow = cHigh;
+	p->cHigh = cLow;
+    /* destroy lookup table, it has to be rebuilt */
+    quant_update_limits(q, dLow, dHigh, cLow, cHigh);
+    q->nofRules++;
+  \brief Rreverses the order in which the qunatization rules are stored.
+  See also Rast_quant_get_ith_rule() and Rast_quant_perform_d()).
+  \param q pointer to Quant rules which holds quant rules info
+void Rast_quant_reverse_rule_order(struct Quant *q)
+    struct Quant_table tmp;
+    struct Quant_table *pLeft, *pRight;
+    pLeft = q->table;
+    pRight = &(q->table[q->nofRules - 1]);
+    while (pLeft < pRight) {
+	tmp.dLow = pLeft->dLow;
+	tmp.dHigh = pLeft->dHigh;
+	tmp.cLow = pLeft->cLow;
+	tmp.cHigh = pLeft->cHigh;
+	pLeft->dLow = pRight->dLow;
+	pLeft->dHigh = pRight->dHigh;
+	pLeft->cLow = pRight->cLow;
+	pLeft->cHigh = pRight->cHigh;
+	pRight->dLow = tmp.dLow;
+	pRight->dHigh = tmp.dHigh;
+	pRight->cLow = tmp.cLow;
+	pRight->cHigh = tmp.cHigh;
+	pLeft++;
+	pRight--;
+static CELL quant_interpolate(DCELL dLow, DCELL dHigh,
+			      CELL cLow, CELL cHigh, DCELL dValue)
+    if (cLow == cHigh)
+	return cLow;
+    if (dLow == dHigh)
+	return cLow;
+    return (CELL) ((dValue - dLow) / (dHigh - dLow) * (DCELL) (cHigh - cLow) +
+		   (DCELL) cLow);
+static int less_or_equal(double x, double y)
+    if (x <= y)
+	return 1;
+    else
+	return 0;
+static int less(double x, double y)
+    if (x < y)
+	return 1;
+    else
+	return 0;
+ * \brief
+ * Returns a CELL category for the floating-point <i>value</i> based
+ * on the quantization rules in <i>q</i>. The first rule found that
+ * applies is used. The rules are searched in the reverse order they
+ * are added to <i>q</i>. If no rule is found, the <i>value</i>
+ * is first tested against the negative infinite rule, and finally
+ * against the positive infinite rule. If none of these rules apply,
+ * the NULL-value is returned.
+ * <b>Note:</b> See G_quant_organize_fp_lookup() for details on how
+ * the values are looked up from fp_lookup table when it is
+ * active. Right now fp_lookup is automatically organized during the
+ * first call to Rast_quant_get_cell_value().
+ * \param dcellValue fp cell value
+ * \return cell value (integer)
+CELL Rast_quant_get_cell_value(struct Quant * q, DCELL dcellVal)
+    CELL tmp;
+    DCELL dtmp;
+    int try, min_ind, max_ind;
+    int (*lower) ();
+    dtmp = dcellVal;
+    /* I know the functions which call me already check for null values,
+       but I am a public function, and can be called from outside */
+    if (Rast_is_d_null_value(&dtmp))
+	return NO_DATA;
+	return (CELL) dtmp;
+    if (q->round_only) {
+	if (dcellVal > 0)
+	    return (CELL) (dcellVal + .5);
+	return (CELL) (dcellVal - .5);
+	return NO_DATA;
+	return NO_DATA;
+    if (USE_LOOKUP &&
+	(q->fp_lookup.active || Rast__quant_organize_fp_lookup(q) > 0)) {
+	/* first check if values fall within range */
+	/* if value is below the range */
+	if (dcellVal < q->fp_lookup.vals[0]) {
+	    if (dcellVal <= q->fp_lookup.inf_dmin)
+		return q->fp_lookup.inf_min;
+	    else
+		return NO_DATA;
+	/* if value is below above range */
+	if (dcellVal > q->fp_lookup.vals[q->fp_lookup.nalloc - 1]) {
+	    if (dcellVal >= q->fp_lookup.inf_dmax)
+		return q->fp_lookup.inf_max;
+	    else
+		return NO_DATA;
+	/* make binary search to find which interval our value belongs to
+	   and apply the rule for this interval */
+	try = (q->fp_lookup.nalloc - 1) / 2;
+	min_ind = 0;
+	max_ind = q->fp_lookup.nalloc - 2;
+	while (1) {
+	    /* DEBUG
+	       fprintf (stderr, "%d %d %d\n", min_ind, max_ind, try);
+	    /* when the ruke for the interval is NULL, we exclude the end points.
+	       when it exists, we include the end-points */
+	    if (q->fp_lookup.rules[try])
+		lower = less;
+	    else
+		lower = less_or_equal;
+	    if (lower(q->fp_lookup.vals[try + 1], dcellVal)) {	/* recurse to the second half */
+		min_ind = try + 1;
+		/* must be still < nalloc-1, since number is within the range */
+		try = (max_ind + min_ind) / 2;
+		continue;
+	    if (lower(dcellVal, q->fp_lookup.vals[try])) {	/* recurse to the second half */
+		max_ind = try - 1;
+		/* must be still >= 0, since number is within the range */
+		continue;
+	    /* the value fits into the interval! */
+	    p = q->fp_lookup.rules[try];
+	    if (p)
+		return quant_interpolate(p->dLow, p->dHigh, p->cLow, p->cHigh,
+					 dcellVal);
+	    /* otherwise when finite rule for this interval doesn't exist */
+	    else {		/* first check if maybe infinite rule applies */
+		else
+		    return NO_DATA;
+	}			/* while */
+    }				/* looking up in fp_lookup */
+	p = Rast__quant_get_rule_for_d_raster_val(q, dcellVal);
+	if (!p)
+	    return NO_DATA;
+				 dcellVal);
+    if ((!NO_LEFT_INFINITE_RULE) && (dcellVal <= q->infiniteDLeft))
+	return q->infiniteCLeft;
+    if ((NO_RIGHT_INFINITE_RULE) || (dcellVal < q->infiniteDRight))
+	return NO_DATA;
+    return q->infiniteCRight;
+  \brief Returns in "cell" the quantized CELL values.
+  Returns in "cell" the quantized CELL values corresponding to the
+  DCELL values stored in "dcell". the number of elements quantized
+  is n. quantization is performed by repeated application of
+  Rast_quant_get_cell_value().
+  \param dcell pointer to fp cell values array
+  \param[out] cell pointer cell values array
+  \param n number of cells
+void Rast_quant_perform_d(struct Quant *q,
+		       const DCELL * dcell, CELL * cell, int n)
+    int i;
+    for (i = 0; i < n; i++, dcell++)
+	if (!Rast_is_d_null_value(dcell))
+	    *cell++ = Rast_quant_get_cell_value(q, *dcell);
+	else
+	    Rast_set_c_null_value(cell++, 1);
+  \brief Same as Rast_quant_perform_d(), except the type.
+  \param fcell pointer to fp cell values array
+void Rast_quant_perform_f(struct Quant *q,
+		       const FCELL * fcell, CELL * cell, int n)
+    int i;
+    for (i = 0; i < n; i++, fcell++)
+	if (!Rast_is_f_null_value(fcell))
+	    *cell++ = Rast_quant_get_cell_value(q, (DCELL) * fcell);
+	else
+static int double_comp(const void *xx, const void *yy)
+    const DCELL *x = xx;
+    const DCELL *y = yy;
+    if (Rast_is_d_null_value(x))
+	return 0;
+    if (*x < *y)
+	return -1;
+    else if (*x == *y)
+	return 0;
+    else
+	return 1;
+  \brief Returns quant rule which will be applied.
+  Returns quant rule which will be applied when looking up the integer
+  quant value for val (used when organizing fp_lookup).
+  \param val fp cell value
+  \return pointer to the Quant_table (color rule)
+  \return NULL otherwise
+struct Quant_table *Rast__quant_get_rule_for_d_raster_val(const struct Quant *q,
+						       DCELL val)
+    const struct Quant_table *p;
+	if ((val >= p->dLow) && (val <= p->dHigh))
+	    break;
+    if (p >= q->table)
+	return (struct Quant_table *)p;
+    else
+	return (struct Quant_table *)NULL;
Copied: grass/trunk/lib/raster/quant_io.c (from rev 37989, grass/trunk/lib/gis/quant_io.c)
--- grass/trunk/lib/raster/quant_io.c	                        (rev 0)
+++ grass/trunk/lib/raster/quant_io.c	2009-06-20 22:03:23 UTC (rev 38003)
@@ -0,0 +1,318 @@
+ *  int
+ *  Rast__quant_import (name, mapset, quant)
+ *      char *name;
+ *      char *mapset;
+ *      struct Quant *quant;
+ *  reads quantization rules for "name" in "mapset" and stores them
+ *  in the quantization structure "quant". If the map is in another
+ *  mapset, first checks for quant2 table for this map in current
+ *  mapset.
+ *  returns: -2 if raster map is of type integer.
+ *           -1 if (! G__name_is_fully_qualified ()).
+ *            0 if quantization file does not exist, or the file is empty,
+ *            1 if non-empty quantization file exists.
+ *                 read.
+ *  note: in the case of negative return value, the result of using the
+ *        quantization structure is not defined.
+ *        in case of return value 0, calls to Rast_quant_perform_d ()
+ *        and Rast_quant_perform_f () return NO_DATA (see description of
+ *        Rast_quant_perform_d () for more details). in case of
+ *        return values 2 and 3, the explicit rule for quant is set:
+ *        floating range is mapped to integer range.
+ *  note: use Rast_quant_init () to allocate and initialize the quantization
+ *        staructure quant before the first usage of G_quant_import ().
+ *  note: this function uses Rast_quant_free () to clear all previously
+ *        stored rules in quant.
+ *  int
+ *  Rast__quant_export (name, mapset, quant)
+ *     char *name, *mapset;
+ *  writes the quantization rules stored in "quant" for "name" . if the
+ *  mapset is the same as the current mapset, the quant file is created
+ *  in cell_misc/name directory, otherwise it is created in quant2/mapset
+ *  directory, much like writing colors for map in another mapset.
+ *  The rules are written in decreasing order
+ *  of priority (i.e. rules added earlier are written later).
+ *  returns: -1 if (! G__name_is_fully_qualified) or file could not be
+ *                 opened.
+ *            1 otherwise.
+ *  note: if no rules are defined an empty file is created.
+#define QUANT_FILE_NAME "f_quant"
+static int quant_parse_file(FILE *, struct Quant *);
+#if 0
+static int
+/* redundant: integer range doesn't exist now: it is defined by
+   the quant rules */
+quant_load_range(struct Quant *quant, const char *name, const char *mapset)
+    struct FPRange fprange;
+    struct Range range;
+    char buf[300];
+    DCELL dMin, dMax;
+    CELL min, max;
+    if (Rast_read_fp_range(name, mapset, &fprange) <= 0)
+	return 0;
+    Rast_get_fp_range_min_max(&fprange, &dMin, &dMax);
+    if (Rast_is_d_null_value(&dMin) || Rast_is_d_null_value(&dMax)) {
+	G_warning (_("The floating data range for %s@%s is empty"),
+		   name, mapset);
+	return -3;
+    if (Rast_read_range(name, mapset, &range) < 0)
+	return 0;
+    Rast_get_range_min_max(&range, &min, &max);
+    if (Rast_is_c_null_value(&min) && Rast_is_c_null_value(&max)) {
+	G_warning (_("The integer data range for %s@%s is empty"),
+		   name, mapset);
+	return -3;
+    Rast_quant_add_rule(quant, dMin, dMax, min, max);
+    return 1;
+#endif
+int Rast__quant_import(const char *name, const char *mapset, struct Quant *quant)
+    char buf[1024];
+    char *err;
+    char xname[GNAME_MAX], xmapset[GMAPSET_MAX], element[GNAME_MAX + 7];
+    int parsStat;
+    FILE *fd;
+    Rast_quant_free(quant);
+    if (Rast_raster_map_type(name, mapset) == CELL_TYPE) {
+	G_warning (_("Rast__quant_import: attempt to open quantization"
+		     " table for CELL_TYPE file [%s] in mapset {%s]"),
+		   name, mapset);
+	return -2;
+    if (G__name_is_fully_qualified(name, xname, xmapset)) {
+	if (strcmp(xmapset, mapset) != 0)
+	    return -1;
+	name = xname;
+    /* first check if quant2/mapset/name exists in the current mapset */
+    sprintf(element, "quant2/%s", mapset);
+    if ((fd = G_fopen_old(element, name, G_mapset()))) {
+	parsStat = quant_parse_file(fd, quant);
+	fclose(fd);
+	if (parsStat)
+	    return 1;
+	sprintf(buf,
+		"quantization file in quant2 for [%s] in mapset [%s] is empty",
+		name, mapset);
+    /* now try reading regular : cell_misc/name/quant file */
+    if (!(fd = G_fopen_old_misc("cell_misc", QUANT_FILE_NAME, name, mapset))) {
+	/* int range doesn't exist anymore if (quant_load_range (quant, name, mapset)>0) return 3; */
+	err = "missing";
+    else {
+	fclose(fd);
+	if (parsStat)
+	    return 1;
+	/* int range doesn't exist anymore if (quant_load_range (quant, name, mapset)>0) return 2; */
+	err = "empty";
+    G_warning (_("quantization file [%s] in mapset [%s] %s"),
+	       name, mapset, err);
+    return 0;
+/* parse input lines with the following formats
+ *   d_high:d_low:c_high:c_low
+ *   d_high:d_low:c_val          (i.e. c_high == c_low)
+ *   *:d_val:c_val               (interval [inf, d_val])  (**)
+ *   d_val:*:c_val               (interval [d_val, inf])  (**)
+ *   all other lines are ignored
+ *  (**) only the first appearances in the file are considered.
+static int quant_parse_file(FILE * fd, struct Quant *quant)
+    CELL cLow, cHigh;
+    DCELL dLow, dHigh;
+    char buf[1024];
+    int foundNegInf = 0, foundPosInf = 0;
+    while (fgets(buf, sizeof(buf), fd)) {
+	if (strncmp(buf, "truncate", 8) == 0) {
+	    return 1;
+	if (strncmp(buf, "round", 5) == 0) {
+	    return 1;
+	switch (sscanf(buf, "%lf:%lf:%d:%d", &dLow, &dHigh, &cLow, &cHigh)) {
+	case 3:
+	    Rast_quant_add_rule(quant, dLow, dHigh, cLow, cLow);
+	    break;
+	case 4:
+	    Rast_quant_add_rule(quant, dLow, dHigh, cLow, cHigh);
+	    break;
+	default:
+	    switch (sscanf(buf, "*:%lf:%d", &dLow, &cLow)) {
+	    case 2:
+		if (!foundNegInf) {
+		    Rast_quant_set_neg_infinite_rule(quant, dLow, cLow);
+		    foundNegInf = 1;
+		break;
+	    default:
+		switch (sscanf(buf, "%lf:*:%d", &dLow, &cLow)) {
+		case 2:
+		    if (!foundPosInf) {
+			Rast_quant_set_pos_infinite_rule(quant, dLow, cLow);
+			foundPosInf = 1;
+		    break;
+		default:
+		    continue;	/* other lines are ignored */
+    if (Rast_quant_nof_rules(quant) > 0)
+	Rast_quant_reverse_rule_order(quant);
+    return ((Rast_quant_nof_rules(quant) > 0) ||
+	    (Rast_quant_get_neg_infinite_rule(quant, &dLow, &cLow) > 0) ||
+	    (Rast_quant_get_pos_infinite_rule(quant, &dLow, &cLow) > 0));
+static void quant_write(FILE * fd, const struct Quant *quant)
+    CELL cLow, cHigh;
+    int i;
+    if (quant->truncate_only) {
+	fprintf(fd, "truncate");
+	return;
+    if (quant->round_only) {
+	fprintf(fd, "round");
+	return;
+    if (Rast_quant_get_neg_infinite_rule(quant, &dLow, &cLow) > 0)
+	fprintf(fd, "*:%.20g:%d\n", dLow, cLow);
+    if (Rast_quant_get_pos_infinite_rule(quant, &dLow, &cLow) > 0)
+	fprintf(fd, "%.20g:*:%d\n", dLow, cLow);
+    for (i = Rast_quant_nof_rules(quant) - 1; i >= 0; i--) {
+	Rast_quant_get_ith_rule(quant, i, &dLow, &dHigh, &cLow, &cHigh);
+	fprintf(fd, "%.20g:%.20g:%d", dLow, dHigh, cLow);
+	if (cLow != cHigh)
+	    fprintf(fd, ":%d", cHigh);
+	fprintf(fd, "\n");
+int
+Rast__quant_export(const char *name, const char *mapset,
+		const struct Quant *quant)
+    char element[GNAME_MAX + 7];
+    FILE *fd;
+	    return -1;
+	name = xname;
+    if (strcmp(G_mapset(), mapset) == 0) {
+	G_remove_misc("cell_misc", QUANT_FILE_NAME, name);
+	G__make_mapset_element_misc("cell_misc", name);
+	if (!(fd = G_fopen_new_misc("cell_misc", QUANT_FILE_NAME, name)))
+	    return -1;
+    else {
+	G_remove(element, name);
+	G__make_mapset_element(element);
+	if (!(fd = G_fopen_new(element, name)))
+	    return -1;
+    quant_write(fd, quant);
+    fclose(fd);
+    return 1;
Copied: grass/trunk/lib/raster/quant_rw.c (from rev 37989, grass/trunk/lib/gis/quant_rw.c)
--- grass/trunk/lib/raster/quant_rw.c	                        (rev 0)
+++ grass/trunk/lib/raster/quant_rw.c	2009-06-20 22:03:23 UTC (rev 38003)
@@ -0,0 +1,229 @@
+ * \file gis/quant_rw.c
+ * \brief GIS Library - Quantization rules (read/write).
+ * This program is free software under the GNU General Public
+ * for details.
+#include <string.h>
+  \brief Writes the quant rules.
+  Writes the quant rules which indicate that all floating numbers
+  should be truncated instead of applying any quant rules from
+  floats to integers.
+  \param name map name
+  \param mapset mapset name
+int Rast_truncate_fp_map(const char *name, const char *mapset)
+    struct Quant quant;
+    Rast_quant_init(&quant);
+    Rast_quant_truncate(&quant);
+    /* quantize the map */
+    if (Rast_write_quant(name, mapset, &quant) < 0) {
+	G_warning(_("Unable to write quant rules for raster map <%s>"),
+		  name);
+	return -1;
+    return 1;
+  should be rounded instead of applying any quant rules from
+int Rast_round_fp_map(const char *name, const char *mapset)
+    Rast_quant_round(&quant);
+    /* round the map */
+		  name);
+	return -1;
+    return 1;
+ * \brief Write quant rules (f_quant) for floating-point raster map.
+ * Writes the <tt>f_quant</tt> file for the raster map <em>name</em>
+ * with one rule. The rule is generated using the floating-point range
+ * in <tt>f_range</tt> producing the integer range
+ * [<em>cmin,cmax</em>].
+ * Make a rule for map <name> that maps floating range (d_min, d_max)
+ * into integer range (min, max)
+ * This function is useful when the quant rule doesn't depend of the
+ * range of produced float data, for example the slope map whould
+ * want to have a quant rule: 0.0, 90.0 -> 0 , 90
+ * no matter what the min and max slope of this map is.
+ * \param name map name
+ * \param mapset mapset name
+ * \param cmin minimum value
+ * \param cmax maximum value
+ * \return -1 on error
+int Rast_quantize_fp_map(const char *name, const char *mapset,
+		      CELL min, CELL max)
+    DCELL d_min, d_max;
+    struct FPRange fp_range;
+    if (Rast_read_fp_range(name, mapset, &fp_range) < 0) {
+	G_warning(_("Unable to read fp range for raster map <%s>"),
+		  G_fully_qualified_name(name, mapset));
+	return -1;
+    Rast_get_fp_range_min_max(&fp_range, &d_min, &d_max);
+    if (Rast_is_d_null_value(&d_min) || Rast_is_d_null_value(&d_max)) {
+	G_warning(_("Raster map <%s> is empty"),
+	return -1;
+    return Rast_quantize_fp_map_range(name, mapset, d_min, d_max, min, max);
+ * <em>name</em> with one rule. The rule is generated using the floating-point
+ * range [<em>dmin,dmax</em>] and the integer range
+ * [<em>min,max</em>].
+ * This routine differs from the one above in that the application controls the
+ * floating-point range. For example, r.slope.aspect will use this routine to
+ * quantize the slope map from [0.0, 90.0] to [0,
+ * 90] even if the range of slopes is not 0-90. The aspect map would be
+ * quantized from [0.0, 360.0] to [0, 360].
+ * \param d_min minimum fp value
+ * \param d_max maximum fp value
+ * \param min minimum value
+ * \param max maximum value
+int Rast_quantize_fp_map_range(const char *name, const char *mapset,
+			    DCELL d_min, DCELL d_max, CELL min, CELL max)
+    Rast_quant_add_rule(&quant, d_min, d_max, min, max);
+		  name);
+	return -1;
+    return 1;
+ * \brief Writes the quant rule table for the raster map
+ * from <em>q</em>.  if mapset==G_mapset() i.e. the map is in current
+ * mapset, then the original quant file in cell_misc/map/f_quant is
+ * written. Otherwise <em>q</em> is written into quant2/mapset/name
+ * (much like colr2 element). This results in map at mapset being read
+ * using quant rules stored in <em>q</em> from G_mapset(). See
+ * Rast_read_quant() for detailes.
+ * \param quant pointer to Quant structure which hold quant rules info
+int Rast_write_quant(const char *name, const char *mapset,
+    CELL cell_min, cell_max;
+	G_warning(_("Unable to write quant rules: raster map <%s> is integer"),
+		  name);
+	return -1;
+    Rast_quant_get_limits(quant, &d_min, &d_max, &cell_min, &cell_max);
+    /* first actually write the rules */
+    if (Rast__quant_export(name, mapset, quant) < 0) {
+	G_warning (_("Unable to write quant rules for raster map <%s>"),
+		   name);
+	return -1;
+    return 1;
+ * \brief
+ * Reads quantization rules for <i>name</i> in <i>mapset</i> and
+ * stores them in the quantization structure. If the map is in another
+ * mapset.
+ *  \param name
+ *  \param mapset
+ *  \param q
+ * \return -2 if raster map is of type integer
+ * \return -1 if (!G__name_is_fully_qualified())
+ * \return 0 if quantization file does not exist, or the file is empty or has wrong format
+ * \return 1 if non-empty quantization file exists
+int Rast_read_quant(const char *name, const char *mapset, struct Quant *quant)
+    Rast_quant_init(quant);
+    return Rast__quant_import(name, mapset, quant);
Copied: grass/trunk/lib/raster/range.c (from rev 37989, grass/trunk/lib/gis/range.c)
--- grass/trunk/lib/raster/range.c	                        (rev 0)
+++ grass/trunk/lib/raster/range.c	2009-06-20 22:03:23 UTC (rev 38003)
@@ -0,0 +1,603 @@
+ * \file gis/range.c
+ * \brief GIS Library - Raster range file management
+ * (C) 2001-2009 GRASS Development Team
+ * This program is free software under the GNU General Public License
+ * (>=v2). Read the file COPYING that comes with GRASS for details.
+ * \author Original author CERL
+#include <unistd.h>
+#include <rpc/types.h>		/* need this for sgi */
+#include <rpc/xdr.h>
+#include "G.h"
+#define DEFAULT_CELL_MIN 1
+#define DEFAULT_CELL_MAX 255
+  \brief Remove floating-point range
+  Note: For internal use only.
+void Rast__remove_fp_range(const char *name)
+    G_remove_misc("cell_misc", "f_range", name);
+ * \brief Construct default range
+ * Sets the integer range to [1,255]
+ * \param[out] r pointer to Range structure which holds range info
+void Rast_construct_default_range(struct Range *range)
+    Rast_update_range(DEFAULT_CELL_MIN, range);
+    Rast_update_range(DEFAULT_CELL_MAX, range);
+ * \brief Read floating-point range
+ * Read the floating point range file <i>drange</i>. This file is
+ * written in binary using XDR format.
+ * An empty range file indicates that the min, max are undefined. This
+ * is a valid case, and the result should be an initialized range
+ * struct with no defined min/max.  If the range file is missing and
+ * the map is a floating-point map, this function will create a
+ * default range by calling G_construct_default_range().
+ * \param drange pointer to FPRange structure which holds fp range
+ * \return 2 range is empty
+int Rast_read_fp_range(const char *name, const char *mapset,
+		    struct FPRange *drange)
+    int fd;
+    char xdr_buf[100];
+    DCELL dcell1, dcell2;
+    XDR xdr_str;
+    Rast_init_fp_range(drange);
+	/* if map is integer
+	   read integer range and convert it to double */
+	if (Rast_read_range(name, mapset, &range) >= 0) {
+	    /* if the integer range is empty */
+	    if (range.first_time)
+		return 2;
+	    Rast_update_fp_range((DCELL) range.min, drange);
+	    Rast_update_fp_range((DCELL) range.max, drange);
+	    return 1;
+	return -1;
+    fd = -1;
+    if (G_find_file2_misc("cell_misc", "f_range", name, mapset)) {
+	fd = G_open_old_misc("cell_misc", "f_range", name, mapset);
+	if (fd < 0) {
+	  G_warning(_("Unable to read fp range file for <%s@%s>"),
+		    name, mapset);
+	  return -1;
+	if (read(fd, xdr_buf, 2 * XDR_DOUBLE_NBYTES) != 2 * XDR_DOUBLE_NBYTES)
+	    return 2;
+	xdrmem_create(&xdr_str, xdr_buf, (u_int) XDR_DOUBLE_NBYTES * 2,
+		      XDR_DECODE);
+	/* if the f_range file exists, but empty */
+	if (!xdr_double(&xdr_str, &dcell1) || !xdr_double(&xdr_str, &dcell2)) {
+	  if (fd)
+	    close(fd);
+		    name, mapset);
+	  return -1;
+	Rast_update_fp_range(dcell1, drange);
+	Rast_update_fp_range(dcell2, drange);
+	close(fd);
+    return 1;
+ * \brief Read raster range (CELL)
+ * This routine reads the range information for the raster map
+ * <i>name</i> in <i>mapset</i> into the <i>range</i> structure.
+ * A diagnostic message is printed and -1 is returned if there is an error
+ * reading the range file. Otherwise, 0 is returned.
+ * Old range file (those with 4 numbers) should treat zeros in this
+ * file as NULL-values. New range files (those with just 2 numbers)
+ * should treat these numbers as real data (zeros are real data in
+ * this case).  An empty range file indicates that the min, max are
+ * undefined. This is a valid case, and the result should be an
+ * initialized range struct with no defined min/max. If the range file
+ * is missing and the map is a floating-point map, this function will
+ * create a default range by calling G_construct_default_range().
+ * \param range pointer to Range structure which holds range info
+ * \return 2 if range is empty
+ * \return 3 if raster map is floating-point, get range from quant rules
+int Rast_read_range(const char *name, const char *mapset, struct Range *range)
+    FILE *fd;
+    CELL x[4];
+    char buf[200];
+    int n, count;
+    struct FPRange drange;
+    Rast_init_range(range);
+    fd = NULL;
+    /* if map is not integer, read quant rules, and get limits */
+    if (Rast_raster_map_type(name, mapset) != CELL_TYPE) {
+	DCELL dmin, dmax;
+	if (Rast_read_quant(name, mapset, &quant) < 0) {
+	    G_warning(_("Unable to read quant rules for raster map <%s@%s>"),
+		       name, mapset);
+	    return -1;
+	if (Rast_quant_is_truncate(&quant) || Rast_quant_is_round(&quant)) {
+	    if (Rast_read_fp_range(name, mapset, &drange) >= 0) {
+		Rast_get_fp_range_min_max(&drange, &dmin, &dmax);
+		if (Rast_quant_is_truncate(&quant)) {
+		    x[0] = (CELL) dmin;
+		    x[1] = (CELL) dmax;
+		else {		/* round */
+		    if (dmin > 0)
+			x[0] = (CELL) (dmin + .5);
+		    else
+			x[0] = (CELL) (dmin - .5);
+		    if (dmax > 0)
+			x[1] = (CELL) (dmax + .5);
+		    else
+			x[1] = (CELL) (dmax - .5);
+	    else
+		return -1;
+	else
+	    Rast_quant_get_limits(&quant, &dmin, &dmax, &x[0], &x[1]);
+	Rast_update_range(x[0], range);
+	Rast_update_range(x[1], range);
+	return 3;
+    if (G_find_file2_misc("cell_misc", "range", name, mapset)) {
+	fd = G_fopen_old_misc("cell_misc", "range", name, mapset);
+	if (!fd) {
+	    G_warning(_("Unable to read range file for <%s@%s>"),
+		      name, mapset);
+	    return -1;
+	/* if range file exists but empty */
+	if (!fgets(buf, sizeof buf, fd))
+	    return 2;
+	x[0] = x[1] = x[2] = x[3] = 0;
+	count = sscanf(buf, "%d%d%d%d", &x[0], &x[1], &x[2], &x[3]);
+	/* if wrong format */
+	if (count <= 0) {
+	    if (fd)
+		fclose(fd);
+		      name, mapset);
+	    return -1;
+	for (n = 0; n < count; n++) {
+	    /* if count==4, the range file is old (4.1) and 0's in it
+	       have to be ignored */
+	    if (count < 4 || x[n])
+		Rast_update_range((CELL) x[n], range);
+	fclose(fd);
+    return 1;
+ * \brief Write raster range file
+ * This routine writes the range information for the raster map
+ * <i>name</i> in the current mapset from the <i>range</i> structure.
+ * error writing the range file. Otherwise, 0 is returned.
+ * This routine only writes 2 numbers (min,max) to the range
+ * file, instead of the 4 (pmin,pmax,nmin,nmax) previously written.
+ * If there is no defined min,max, an empty file is written.
+ * \return -1 on error (or raster map is floating-point)
+ * \return 0 on success
+int Rast_write_range(const char *name, const struct Range *range)
+    FILE *fd;
+    if (Rast_raster_map_type(name, G_mapset()) != CELL_TYPE) {
+	G_remove_misc("cell_misc", "range", name);	/* remove the old file with this name */
+	G_warning(_("Unable to write range file for <%s>"),
+		  name);
+	return -1;
+    fd = G_fopen_new_misc("cell_misc", "range", name);
+    if (!fd) {
+		  name);
+	return -1;
+    /* if range hasn't been updated */
+    if (range->first_time) {
+	fclose(fd);
+	return 0;
+    fprintf(fd, "%ld %ld\n", (long)range->min, (long)range->max);
+    fclose(fd);
+    return 0;
+ * \brief Write raster range file (floating-point)
+ * Write the floating point range file <tt>f_range</tt>. This file is
+ * written in binary using XDR format. If there is no defined min/max
+ * in <em>range</em>, an empty <tt>f_range</tt> file is created.
+ * \param range pointer to FPRange which holds fp range info
+int Rast_write_fp_range(const char *name, const struct FPRange *range)
+    int fd;
+    XDR xdr_str;
+    fd = G_open_new_misc("cell_misc", "f_range", name);
+    if (fd < 0) {
+		  name);
+	return -1;
+    /* if range hasn't been updated, write empty file meaning Nulls */
+	close(fd);
+	return 0;
+		  XDR_ENCODE);
+    if (!xdr_double(&xdr_str, (double *)&(range->min))) {
+		  name);
+	return -1;
+    if (!xdr_double(&xdr_str, (double *)&(range->max))) {
+		  name);
+	return -1;
+    write(fd, xdr_buf, XDR_DOUBLE_NBYTES * 2);
+    close(fd);
+    return 0;
+ * \brief Update range structure (CELL)
+ * Compares the <i>cat</i> value with the minimum and maximum values
+ * in the <i>range</i> structure, modifying the range if <i>cat</i>
+ * extends the range.
+ * NULL-values must be detected and ignored.
+ * \param cat raster value
+void Rast_update_range(CELL cat, struct Range *range)
+    if (!Rast_is_c_null_value(&cat)) {
+	    range->first_time = 0;
+	    range->min = cat;
+	    range->max = cat;
+	    return;
+	if (cat < range->min)
+	    range->min = cat;
+	if (cat > range->max)
+	    range->max = cat;
+ * \brief Update range structure (floating-point)
+ * \param val raster value
+void Rast_update_fp_range(DCELL val, struct FPRange *range)
+    if (!Rast_is_d_null_value(&val)) {
+	    range->min = val;
+	    range->max = val;
+	    return;
+	if (val < range->min)
+	    range->min = val;
+	if (val > range->max)
+	    range->max = val;
+ * \brief Update range structure based on raster row (CELL)
+ * This routine updates the <i>range</i> data just like
+ * Rast_update_range(), but for <i>n</i> values from the <i>cell</i>
+ * array.
+ * \param cell raster values
+ * \param n number of values
+void Rast_row_update_range(const CELL *cell, int n, struct Range *range)
+    Rast__row_update_range(cell, n, range, 0);
+ * Note: for internal use only.
+ * \param ignore_zeros ignore zeros
+void Rast__row_update_range(const CELL *cell, int n,
+			 struct Range *range, int ignore_zeros)
+    CELL cat;
+    while (n-- > 0) {
+	cat = *cell++;
+	if (Rast_is_c_null_value(&cat) || (ignore_zeros && !cat))
+	    continue;
+	    range->min = cat;
+	    range->max = cat;
+	    continue;
+	    range->min = cat;
+	    range->max = cat;
+ * \brief Update range structure based on raster row (floating-point)
+ * array.
+ * \param data_type raster type (CELL, FCELL, DCELL)
+void Rast_row_update_fp_range(const void *rast, int n,
+			   struct FPRange *range, RASTER_MAP_TYPE data_type)
+    DCELL val = 0L;
+    while (n-- > 0) {
+	switch (data_type) {
+	case CELL_TYPE:
+	    val = (DCELL) * ((CELL *) rast);
+	    break;
+	case FCELL_TYPE:
+	    val = (DCELL) * ((FCELL *) rast);
+	    break;
+	case DCELL_TYPE:
+	    val = *((DCELL *) rast);
+	    break;
+	if (Rast_is_null_value(rast, data_type)) {
+	    rast = Rast_incr_void_ptr(rast, Rast_raster_size(data_type));
+	    continue;
+	    range->min = val;
+	    range->max = val;
+	else {
+		range->min = val;
+		range->max = val;
+ * \brief Initialize range structure
+ * Initializes the <i>range</i> structure for updates by
+ * Rast_update_range() and Rast_row_update_range().
+ * Must set a flag in the range structure that indicates that no
+ * min/max have been defined - probably a <tt>"first"</tt> boolean
+ * flag.
+void Rast_init_range(struct Range *range)
+    Rast_set_c_null_value(&(range->min), 1);
+    Rast_set_c_null_value(&(range->max), 1);
+    range->first_time = 1;
+ * \brief Get range min and max
+ * The mininum and maximum CELL values are extracted from the
+ * <i>range</i> structure.
+ * If the range structure has no defined min/max (first!=0) there will
+ * not be a valid range. In this case the min and max returned must be
+ * the NULL-value.
+ * \param[out] min minimum value
+ * \param[out] max maximum value
+void Rast_get_range_min_max(const struct Range *range, CELL * min, CELL * max)
+	Rast_set_c_null_value(min, 1);
+	Rast_set_c_null_value(max, 1);
+    else {
+	if (Rast_is_c_null_value(&(range->min)))
+	else
+	    *min = range->min;
+	if (Rast_is_c_null_value(&(range->max)))
+	else
+	    *max = range->max;
+ * \brief Initialize fp range
+ * flag.
+void Rast_init_fp_range(struct FPRange *range)
+    Rast_set_d_null_value(&(range->min), 1);
+    Rast_set_d_null_value(&(range->max), 1);
+ * \brief Get minumum and maximum value from fp range
+ * Extract the min/max from the range structure <i>range</i>.  If the
+ * range structure has no defined min/max (first!=0) there will not be
+ * a valid range. In this case the min and max returned must be the
+ * NULL-value.
+void Rast_get_fp_range_min_max(const struct FPRange *range,
+			    DCELL *min, DCELL *max)
+	Rast_set_d_null_value(min, 1);
+	Rast_set_d_null_value(max, 1);
+    else {
+	if (Rast_is_d_null_value(&(range->min)))
+	else
+	if (Rast_is_d_null_value(&(range->max)))
+	else
Copied: grass/trunk/lib/raster/raster.c (from rev 37989, grass/trunk/lib/gis/raster.c)
--- grass/trunk/lib/raster/raster.c	                        (rev 0)
+++ grass/trunk/lib/raster/raster.c	2009-06-20 22:03:23 UTC (rev 38003)
@@ -0,0 +1,321 @@
+ * \file gis/raster.c
+ * \brief GIS Library - Raster cell value routines.
+ * (C) 2001-2009 by the GRASS Development Team
+ * \brief Advance void pointer
+ * Advances void pointer by <i>size</i> bytes. Returns new pointer
+ * value.
+ * Useful in raster row processing loops, substitutes
+ \code
+ CELL *cell;
+ cell += n;
+ \endcode
+ * Now
+ \code
+ \endcode
+ * (where rast is void* and <i>data_type</i> is RASTER_MAP_TYPE can be
+ * used instead of rast++.)
+ * Very useful to generalize the row processing - loop i.e.
+ * \code
+ *   void * buf_ptr += Rast_raster_size(data_type)
+ * \endcode
+ * \param ptr pointer
+ * \param size buffer size
+ * \return pointer to the data
+void *Rast_incr_void_ptr(const void *ptr, const size_t size)
+    /* assuming that the size of unsigned char is 1 */
+    return (void *)((const unsigned char *)ptr + size);
+ * \brief Compares raster values.
+ * \param v1,v2 values to be compared
+ * \return  1 if p > q or only q is null value
+ * \return -1 if p < q or only p is null value
+ * \return  0 if p == q or p==q==null value
+int Rast_raster_cmp(const void *v1, const void *v2, RASTER_MAP_TYPE data_type)
+    if (Rast_is_null_value(v1, data_type)) {
+	if (Rast_is_null_value(v2, data_type))
+	    return 0;
+	else
+	    return -1;
+    else if (Rast_is_null_value(v2, data_type))
+	return 1;
+    case CELL_TYPE:
+	if (*((const CELL *)v1) > *((const CELL *)v2))
+	    return 1;
+	else if (*((const CELL *)v1) == *((const CELL *)v2))
+	    return 0;
+	else
+	    return -1;
+    case FCELL_TYPE:
+	if (*((const FCELL *)v1) > *((const FCELL *)v2))
+	    return 1;
+	else if (*((const FCELL *)v1) == *((const FCELL *)v2))
+	    return 0;
+	else
+	    return -1;
+    case DCELL_TYPE:
+	if (*((const DCELL *)v1) > *((const DCELL *)v2))
+	    return 1;
+	else if (*((const DCELL *)v1) == *((const DCELL *)v2))
+	    return 0;
+	else
+	    return -1;
+    return 0;
+ * \brief Copies raster values.
+ * If v2 is null value, sets v2 to null value.
+ * \param v1, v2 raster values
+ * \param n ?
+void Rast_raster_cpy(void *v1, const void *v2, int n, RASTER_MAP_TYPE data_type)
+    G_copy(v1, v2, n * Rast_raster_size(data_type));
+ * \brief Places a CELL raster value
+ * If Rast_is_c_null_value() is true, sets p to null value. Converts CELL
+ * val to data_type (type of p) and stores result in p. Used for
+ * assigning CELL values to raster cells of any type.
+ * \param rast pointer to raster cell value
+ * \param cval value to set
+void Rast_set_raster_value_c(void *rast, CELL cval, RASTER_MAP_TYPE data_type)
+    CELL c;
+    c = cval;
+    if (Rast_is_c_null_value(&c)) {
+	Rast_set_null_value(rast, 1, data_type);
+	return;
+    case CELL_TYPE:
+	*((CELL *) rast) = cval;
+	break;
+    case FCELL_TYPE:
+	*((FCELL *) rast) = (FCELL) cval;
+	break;
+    case DCELL_TYPE:
+	*((DCELL *) rast) = (DCELL) cval;
+	break;
+ * \brief Places a FCELL raster value
+ * If Rast_is_f_null_value() is true, sets p to null value. Converts
+ * FCELL val to data_type (type of p) and stores result in p. Used for
+ * assigning FCELL values to raster cells of any type.
+ * \param fval value to set
+void Rast_set_raster_value_f(void *rast, FCELL fval, RASTER_MAP_TYPE data_type)
+    FCELL f;
+    f = fval;
+    if (Rast_is_f_null_value(&f)) {
+	return;
+    case CELL_TYPE:
+	*((CELL *) rast) = (CELL) fval;
+	break;
+    case FCELL_TYPE:
+	*((FCELL *) rast) = fval;
+	break;
+    case DCELL_TYPE:
+	*((DCELL *) rast) = (DCELL) fval;
+	break;
+ * \brief  Places a DCELL raster value
+ * If Rast_is_d_null_value() is true, sets p to null value. Converts
+ * DCELL val to data_type (type of p) and stores result in p. Used for
+ * assigning DCELL values to raster cells of any type.
+void Rast_set_raster_value_d(void *rast, DCELL dval, RASTER_MAP_TYPE data_type)
+    DCELL d;
+    d = dval;
+    if (Rast_is_d_null_value(&d)) {
+	return;
+    case CELL_TYPE:
+	*((CELL *) rast) = (CELL) dval;
+	break;
+    case FCELL_TYPE:
+	*((FCELL *) rast) = (FCELL) dval;
+	break;
+    case DCELL_TYPE:
+	*((DCELL *) rast) = dval;
+	break;
+ * \brief Retrieves the value of give type from pointer p
+ * Retrieves the value of type data_type from pointer p, converts it
+ * to CELL type and returns the result. If null value is stored in p,
+ * returns CELL null value.
+ * Used for retrieving CELL values from raster cells of any type.
+ * Note: when data_type != CELL_TYPE, no quantization is used, only
+ * type conversion.
+ * \return raster value
+CELL Rast_get_raster_value_c(const void *rast, RASTER_MAP_TYPE data_type)
+    CELL c;
+	Rast_set_c_null_value(&c, 1);
+	return c;
+    case CELL_TYPE:
+	return *((const CELL *)rast);
+    case FCELL_TYPE:
+	return (CELL) *((const FCELL *)rast);
+    case DCELL_TYPE:
+	return (CELL) *((const DCELL *)rast);
+    return 0;
+ * \brief Retrieves the value of given raster type from pointer p (FCELL)
+ * to FCELL type and returns the result. If null value is stored in p,
+ * returns FCELL null value.
+ * Used for retrieving FCELL values from raster cells of any type.
+FCELL Rast_get_raster_value_f(const void *rast, RASTER_MAP_TYPE data_type)
+    FCELL f;
+	Rast_set_f_null_value(&f, 1);
+	return f;
+    case CELL_TYPE:
+	return (FCELL) * ((const CELL *)rast);
+    case FCELL_TYPE:
+	return *((const FCELL *)rast);
+    case DCELL_TYPE:
+	return (FCELL) * ((const DCELL *)rast);
+    return 0;
+ * \brief Retrieves the value of given type from pointer p (DCELL)
+ * to DCELL type and returns the result. If null value is stored in p,
+ * returns DCELL null value.
+ * Used for retrieving DCELL values from raster cells of any type.
+DCELL Rast_get_raster_value_d(const void *rast, RASTER_MAP_TYPE data_type)
+    DCELL d;
+	Rast_set_d_null_value(&d, 1);
+	return d;
+    case CELL_TYPE:
+	return (DCELL) * ((const CELL *)rast);
+    case FCELL_TYPE:
+	return (DCELL) * ((const FCELL *)rast);
+    case DCELL_TYPE:
+	return *((const DCELL *)rast);
+    return 0;
Copied: grass/trunk/lib/raster/raster_metadata.c (from rev 37989, grass/trunk/lib/gis/raster_metadata.c)
--- grass/trunk/lib/raster/raster_metadata.c	                        (rev 0)
+++ grass/trunk/lib/raster/raster_metadata.c	2009-06-20 22:03:23 UTC (rev 38003)
@@ -0,0 +1,154 @@
+/* raster_metadata.c
+ * PURPOSE: functions to read and write raster "units" and "vertical datum"
+ *              meta-data info
+ *   Copyright (C) 2007 by Hamish Bowman, and the GRASS Development Team
+ *   Author(s): Hamish Bowman, Dunedin, New Zealand
+ *   for details.
+#include <stdio.h>
+#include <grass/Rast.h>
+ * \brief Get a raster map's units metadata string
+ * Read the raster's units metadata file and put string in str
+ * \param name
+ * \param mapset
+ * \param *str  string to be populated with data
+ * \return -1, EOF (fclose() result) on error
+int Rast_read_raster_units(const char *name, const char *mapset, char *str)
+    return Rast__raster_misc_read_line("units", name, mapset, str);
+ * \brief Write a string to a raster map's units metadata file
+ * Map must exist in the current mapset.
+ * \param name
+ * \param *str  string containing data to be written
+int Rast_write_raster_units(const char *name, const char *str)
+    return Rast__raster_misc_write_line("units", name, str);
+ * \brief Get a raster map's vertical datum metadata string
+ * Read the raster's vertical datum metadata file and put string in str
+ * \param name
+ * \param mapset
+int Rast_read_raster_vdatum(const char *name, const char *mapset, char *str)
+    return Rast__raster_misc_read_line("vertical_datum", name, mapset, str);
+ * \brief Write a string into a raster's vertical datum metadata file
+ * \param name
+int Rast_write_raster_vdatum(const char *name, const char *str)
+    return Rast__raster_misc_write_line("vertical_datum", name, str);
+ * \brief Read the first line of a file in cell_misc/
+ * Read the first line of data from a cell_misc/ meta-data file.
+ * \param element  metadata component filename
+ * \param name
+ * \param mapset
+int Rast__raster_misc_read_line(const char *elem, const char *name,
+			     const char *mapset, char *str)
+    FILE *fd;
+    char buff[GNAME_MAX];
+    buff[0] = '\0';
+    if (G_find_file2_misc("cell_misc", elem, name, mapset) == NULL)
+	return -1;
+    fd = G_fopen_old_misc("cell_misc", elem, name, mapset);
+    if (!fd) {
+	G_warning(_("Can't read %s for [%s in %s]"), elem, name, mapset);
+	return -1;
+    if (G_getl2(buff, sizeof(buff) - 1, fd) == 0) {
+	/* file is empty */
+	return fclose(fd);
+    strcpy(str, buff);
+ * \brief Write a line to a raster map metadata file
+ * Write (including overwrite) a string into a raster map's metadata file
+ * found in in cell_misc/ in the current mapset.
+ * \param name
+int Rast__raster_misc_write_line(const char *elem, const char *name,
+			      const char *str)
+    FILE *fd;
+    fd = G_fopen_new_misc("cell_misc", elem, name);
+    if (fd == NULL) {
+	G_warning(_("Can't create %s metadata file for [%s in %s]"),
+		  elem, name, G_mapset());
+	return -1;
+    fprintf(fd, "%s", str);
Copied: grass/trunk/lib/raster/rd_cellhd.c (from rev 37989, grass/trunk/lib/gis/rd_cellhd.c)
--- grass/trunk/lib/raster/rd_cellhd.c	                        (rev 0)
+++ grass/trunk/lib/raster/rd_cellhd.c	2009-06-20 22:03:23 UTC (rev 38003)
@@ -0,0 +1,434 @@
+/* read cell header, or window.
+   returns NULL if ok, error message otherwise
+   note:  the error message can be freed using G_free ().
+#define ERROR(x,line) return error(x,line)
+static int scan_item(const char *, char *, char *);
+static int scan_int(const char *, int *);
+static double scan_double(const char *, double *);
+static char *error(const char *, int);
+#define F_PROJ   1
+#define F_ZONE   2
+#define F_NORTH  3
+#define F_SOUTH  4
+#define F_EAST   5
+#define F_WEST   6
+#define F_EWRES  7
+#define F_NSRES  8
+#define F_FORMAT 9
+#define F_COMP   10
+#define F_COLS   11
+#define F_ROWS   12
+#define F_EWRES3 13
+#define F_NSRES3 14
+#define F_COLS3  15
+#define F_ROWS3  16
+#define F_TOP    17
+#define F_BOTTOM 18
+#define F_TBRES  19
+#define F_DEPTHS 20
+#define SET(x) flags|=(1<<x)
+#define TEST(x) (flags&(1<<x))
+char *Rast__read_Cell_head_array(char **array,
+			      struct Cell_head *cellhd, int is_cellhd);
+char *Rast__read_Cell_head(FILE * fd, struct Cell_head *cellhd, int is_cellhd)
+    int count;
+    char *result, **array;
+    char buf[1024];
+    G_debug(2, "Rast__read_Cell_head");
+    /* Count lines */
+    count = 0;
+    fseek(fd, 0L, 0);
+    while (G_getl(buf, sizeof(buf), fd))
+	count++;
+    array = (char **)G_calloc(count + 1, sizeof(char **));
+    count = 0;
+    fseek(fd, 0L, 0);
+    while (G_getl(buf, sizeof(buf), fd)) {
+	array[count] = G_store(buf);
+	count++;
+    result = Rast__read_Cell_head_array(array, cellhd, is_cellhd);
+    count = 0;
+    while (array[count]) {
+	G_free(array[count]);
+	count++;
+    G_free(array);
+    return result;
+/* Read window from NULL terminated array of strings */
+    char *buf;
+    char label[200];
+    char value[200];
+    int i, line;
+    int flags;
+    const char *err;
+    G_debug(2, "Rast__read_Cell_head_array");
+    flags = 0;
+    /* initialize the cell header */
+    cellhd->format = 0;
+    cellhd->rows = 0;
+    cellhd->rows3 = 0;
+    cellhd->cols = 0;
+    cellhd->cols3 = 0;
+    cellhd->depths = 1;
+    cellhd->proj = -1;
+    cellhd->zone = -1;
+    cellhd->compressed = -1;
+    cellhd->ew_res = 0.0;
+    cellhd->ew_res3 = 1.0;
+    cellhd->ns_res = 0.0;
+    cellhd->ns_res3 = 1.0;
+    cellhd->tb_res = 1.0;
+    cellhd->north = 0.0;
+    cellhd->south = 0.0;
+    cellhd->east = 0.0;
+    cellhd->west = 0.0;
+    cellhd->top = 1.0;
+    cellhd->bottom = 0.0;
+    /* determine projection, zone first */
+    i = 0;
+    for (line = 1; (buf = array[i++]); line++) {
+	if (TEST(F_PROJ) && TEST(F_ZONE))
+	    break;
+	switch (scan_item(buf, label, value)) {
+	case -1:
+	    ERROR(buf, line);
+	case 0:
+	    continue;
+	case 1:
+	    break;
+	if (strncmp(label, "proj", 4) == 0) {
+	    if (TEST(F_PROJ))
+		ERROR(_("duplicate projection field"), line);
+	    if (!scan_int(value, &cellhd->proj))
+		ERROR(buf, line);
+	    SET(F_PROJ);
+	    continue;
+	if (strncmp(label, "zone", 4) == 0) {
+	    if (TEST(F_ZONE))
+		ERROR(_("duplicate zone field"), line);
+	    if (!scan_int(value, &cellhd->zone))
+		ERROR(buf, line);
+	    SET(F_ZONE);
+	    continue;
+    if (!TEST(F_PROJ))
+	ERROR(_("projection field missing"), 0);
+    if (!TEST(F_ZONE))
+	ERROR(_("zone field missing"), 0);
+    /* read the other info */
+    i = 0;
+	G_debug(3, "region item: %s", buf);
+	case -1:
+	    ERROR(buf, line);
+	case 0:
+	    continue;
+	case 1:
+	    break;
+	    continue;
+	    continue;
+	if (strncmp(label, "nort", 4) == 0) {
+	    if (TEST(F_NORTH))
+		ERROR(_("duplicate north field"), line);
+	    if (!G_scan_northing(value, &cellhd->north, cellhd->proj))
+		ERROR(buf, line);
+	    SET(F_NORTH);
+	    continue;
+	if (strncmp(label, "sout", 4) == 0) {
+	    if (TEST(F_SOUTH))
+		ERROR(_("duplicate south field"), line);
+	    if (!G_scan_northing(value, &cellhd->south, cellhd->proj))
+		ERROR(buf, line);
+	    SET(F_SOUTH);
+	    continue;
+	if (strncmp(label, "east", 4) == 0) {
+	    if (TEST(F_EAST))
+		ERROR(_("duplicate east field"), line);
+	    if (!G_scan_easting(value, &cellhd->east, cellhd->proj))
+		ERROR(buf, line);
+	    SET(F_EAST);
+	    continue;
+	if (strncmp(label, "west", 4) == 0) {
+	    if (TEST(F_WEST))
+		ERROR(_("duplicate west field"), line);
+	    if (!G_scan_easting(value, &cellhd->west, cellhd->proj))
+		ERROR(buf, line);
+	    SET(F_WEST);
+	    continue;
+	if (strncmp(label, "top", 3) == 0) {
+	    if (TEST(F_TOP))
+		ERROR(_("duplicate top field"), line);
+	    if (!scan_double(value, &cellhd->top))
+		ERROR(buf, line);
+	    SET(F_TOP);
+	    continue;
+	if (strncmp(label, "bottom", 6) == 0) {
+	    if (TEST(F_BOTTOM))
+		ERROR(_("duplicate bottom field"), line);
+	    if (!scan_double(value, &cellhd->bottom))
+		ERROR(buf, line);
+	    SET(F_BOTTOM);
+	    continue;
+	if (strncmp(label, "e-w ", 4) == 0 && strlen(label) == 9) {
+	    if (TEST(F_EWRES))
+		ERROR(_("duplicate e-w resolution field"), line);
+	    if (!G_scan_resolution(value, &cellhd->ew_res, cellhd->proj))
+		ERROR(buf, line);
+	    if (cellhd->ew_res <= 0.0)
+		ERROR(buf, line);
+	    SET(F_EWRES);
+	    continue;
+	if (strncmp(label, "e-w resol3", 10) == 0) {
+	    if (TEST(F_EWRES3))
+		ERROR(_("duplicate 3D e-w resolution field"), line);
+	    if (!G_scan_resolution(value, &cellhd->ew_res3, cellhd->proj))
+		ERROR(buf, line);
+	    if (cellhd->ew_res3 <= 0.0)
+		ERROR(buf, line);
+	    SET(F_EWRES3);
+	    continue;
+	if (strncmp(label, "n-s ", 4) == 0 && strlen(label) == 9) {
+	    if (TEST(F_NSRES))
+		ERROR(_("duplicate n-s resolution field"), line);
+	    if (!G_scan_resolution(value, &cellhd->ns_res, cellhd->proj))
+		ERROR(buf, line);
+	    if (cellhd->ns_res <= 0.0)
+		ERROR(buf, line);
+	    SET(F_NSRES);
+	    continue;
+	if (strncmp(label, "n-s resol3", 10) == 0) {
+	    if (TEST(F_NSRES3))
+		ERROR(_("duplicate 3D n-s resolution field"), line);
+	    if (!G_scan_resolution(value, &cellhd->ns_res3, cellhd->proj))
+		ERROR(buf, line);
+	    if (cellhd->ns_res3 <= 0.0)
+		ERROR(buf, line);
+	    SET(F_NSRES3);
+	    continue;
+	if (strncmp(label, "t-b ", 4) == 0) {
+	    if (TEST(F_TBRES))
+		ERROR(_("duplicate t-b resolution field"), line);
+	    if (!scan_double(value, &cellhd->tb_res))
+		ERROR(buf, line);
+	    if (cellhd->tb_res <= 0.0)
+		ERROR(buf, line);
+	    SET(F_TBRES);
+	    continue;
+	if (strncmp(label, "rows", 4) == 0 && strlen(label) == 4) {
+	    if (TEST(F_ROWS))
+		ERROR(_("duplicate rows field"), line);
+	    if (!scan_int(value, &cellhd->rows))
+		ERROR(buf, line);
+	    if (cellhd->rows <= 0)
+		ERROR(buf, line);
+	    SET(F_ROWS);
+	    continue;
+	if (strncmp(label, "rows3", 5) == 0) {
+	    if (TEST(F_ROWS3))
+		ERROR(_("duplicate 3D rows field"), line);
+	    if (!scan_int(value, &cellhd->rows3))
+		ERROR(buf, line);
+	    if (cellhd->rows3 <= 0)
+		ERROR(buf, line);
+	    SET(F_ROWS3);
+	    continue;
+	if (strncmp(label, "cols", 4) == 0 && strlen(label) == 4) {
+	    if (TEST(F_COLS))
+		ERROR(_("duplicate cols field"), line);
+	    if (!scan_int(value, &cellhd->cols))
+		ERROR(buf, line);
+	    if (cellhd->cols <= 0)
+		ERROR(buf, line);
+	    SET(F_COLS);
+	    continue;
+	if (strncmp(label, "cols3", 5) == 0) {
+	    if (TEST(F_COLS3))
+		ERROR(_("duplicate 3D cols field"), line);
+	    if (!scan_int(value, &cellhd->cols3))
+		ERROR(buf, line);
+	    if (cellhd->cols3 <= 0)
+		ERROR(buf, line);
+	    SET(F_COLS3);
+	    continue;
+	if (strncmp(label, "depths", 6) == 0) {
+	    if (TEST(F_DEPTHS))
+		ERROR(_("duplicate depths field"), line);
+	    if (!scan_int(value, &cellhd->depths))
+		ERROR(buf, line);
+	    if (cellhd->depths <= 0)
+		ERROR(buf, line);
+	    SET(F_DEPTHS);
+	    continue;
+	if (strncmp(label, "form", 4) == 0) {
+	    if (TEST(F_FORMAT))
+		ERROR(_("duplicate format field"), line);
+	    if (!scan_int(value, &cellhd->format))
+		ERROR(buf, line);
+	    SET(F_FORMAT);
+	    continue;
+	if (strncmp(label, "comp", 4) == 0) {
+	    if (TEST(F_COMP))
+		ERROR(_("duplicate compressed field"), line);
+	    if (!scan_int(value, &cellhd->compressed))
+		ERROR(buf, line);
+	    SET(F_COMP);
+	    continue;
+	ERROR(buf, line);
+    /* check some of the fields */
+    if (!TEST(F_NORTH))
+	ERROR(_("north field missing"), 0);
+    if (!TEST(F_SOUTH))
+	ERROR(_("south field missing"), 0);
+    if (!TEST(F_WEST))
+	ERROR(_("west field missing"), 0);
+    if (!TEST(F_EAST))
+	ERROR(_("east field missing"), 0);
+    if (!TEST(F_EWRES) && !TEST(F_COLS))
+	ERROR(_("cols field missing"), 0);
+    if (!TEST(F_NSRES) && !TEST(F_ROWS))
+	ERROR(_("rows field missing"), 0);
+    /* This next stmt is commented out to allow wr_cellhd.c to write
+     * headers that will be readable by GRASS 3.1
+     if ((TEST(F_ROWS) && TEST(F_NSRES))
+     ||  (TEST(F_COLS) && TEST(F_EWRES)))
+     ERROR ("row/col and resolution information can not both appear ",0);
+    /* 3D defined? */
+    if (TEST(F_EWRES3) || TEST(F_NSRES3) || TEST(F_COLS3) || TEST(F_ROWS3)) {
+	if (!TEST(F_EWRES3))
+	    ERROR(_("ewres3 field missing"), 0);
+	if (!TEST(F_NSRES3))
+	    ERROR(_("nsres3 field missing"), 0);
+	if (!TEST(F_COLS3))
+	    ERROR(_("cols3 field missing"), 0);
+	if (!TEST(F_ROWS3))
+	    ERROR(_("rows3 field missing"), 0);
+    else {			/* use 2D */
+	cellhd->ew_res3 = cellhd->ew_res;
+	cellhd->ns_res3 = cellhd->ns_res;
+	cellhd->cols3 = cellhd->cols;
+	cellhd->rows3 = cellhd->rows;
+    /* Adjust and complete the cell header  */
+    if ((err = Rast_adjust_Cell_head(cellhd, TEST(F_ROWS), TEST(F_COLS))))
+	ERROR(err, 0);
+    return NULL;
+static int scan_item(const char *buf, char *label, char *value)
+    /* skip blank lines */
+    if (sscanf(buf, "%1s", label) != 1)
+	return 0;
+    /* skip comment lines */
+    if (*label == '#')
+	return 0;
+    /* must be label: value */
+    if (sscanf(buf, "%[^:]:%[^\n]", label, value) != 2)
+	return -1;
+    G_strip(label);
+    G_strip(value);
+    return 1;
+static int scan_int(const char *buf, int *n)
+    char dummy[3];
+    *dummy = 0;
+    return (sscanf(buf, "%d%1s", n, dummy) == 1 && *dummy == 0);
+static double scan_double(const char *buf, double *n)
+    char dummy[3];
+    *dummy = 0;
+    return (sscanf(buf, "%lf%1s", n, dummy) == 1 && *dummy == 0);
+static char *error(const char *msg, int line)
+    char buf[1024];
+    if (line)
+	sprintf(buf, _("line %d: <%s>"), line, msg);
+    else
+	sprintf(buf, "<%s>", msg);
+    return G_store(buf);
Copied: grass/trunk/lib/raster/reclass.c (from rev 37989, grass/trunk/lib/gis/reclass.c)
--- grass/trunk/lib/raster/reclass.c	                        (rev 0)
+++ grass/trunk/lib/raster/reclass.c	2009-06-20 22:03:23 UTC (rev 38003)
@@ -0,0 +1,405 @@
+ * \file gis/reclass.c
+ * \brief GIS Library - Check if raster map is reclassified
+#include <grass/gis.h>
+#include <grass/glocale.h>
+static const char NULL_STRING[] = "null";
+static int reclass_type(FILE *, char **, char **);
+static FILE *fopen_cellhd_old(const char *, const char *);
+static FILE *fopen_cellhd_new(const char *);
+static int get_reclass_table(FILE *, struct Reclass *);
+ * \brief Check if raster map is reclassified
+ * This function determines if the raster map <i>name</i> in
+ * <i>mapset</i> is a reclass file. If it is, then the name and mapset
+ * of the referenced raster map are copied into the <i>r_name</i> and
+ * <i>r_mapset</i> buffers.
+ * \param[out] r_name name of reference map
+ * \param[out] r_mapset mapset where reference map lives
+ * \returns 1 if it is a reclass file
+ * \return 0 if it is not
+ * \return -1 if there was a problem reading the raster header
+int Rast_is_reclass(const char *name, const char *mapset, char *rname,
+		 char *rmapset)
+    FILE *fd;
+    int type;
+    fd = fopen_cellhd_old(name, mapset);
+    if (fd == NULL)
+	return -1;
+    type = reclass_type(fd, &rname, &rmapset);
+    fclose(fd);
+    if (type < 0)
+	return -1;
+    else
+	return type != 0;
+ * \brief Get child reclass maps list
+ * This function generates a child reclass maps list from the
+ * cell_misc/reclassed_to file which stores this list. The
+ * cell_misc/reclassed_to file is written by Rast_put_reclass().
+ * Rast_is_reclassed_to() is used by <tt>g.rename</tt>, <tt>g.remove</tt>
+ * and <tt>r.reclass</tt> to prevent accidentally deleting the parent
+ * map of a reclassed raster map.
+ * \param[out] nrmaps number of reference maps
+ * \param[out] rmaps array of names of reference maps
+ * \return number of reference maps
+int Rast_is_reclassed_to(const char *name, const char *mapset, int *nrmaps,
+		      char ***rmaps)
+    FILE *fd;
+    int i, j, k, l;
+    char buf2[256], buf3[256];
+    fd = G_fopen_old_misc("cell_misc", "reclassed_to", name, mapset);
+    if (fd == NULL) {
+	return -1;
+    if (rmaps)
+	*rmaps = NULL;
+    for (i = 0; !feof(fd) && fgets(buf2, 255, fd);) {
+	l = strlen(buf2);
+	for (j = 0, k = 0; j < l; j++) {
+	    if (buf2[j] == '#' ||
+		((buf2[j] == ' ' || buf2[j] == '\t' || buf2[j] == '\n') && k))
+		break;
+	    else if (buf2[j] != ' ' && buf2[j] != '\t')
+		buf3[k++] = buf2[j];
+	if (k) {
+	    buf3[k] = 0;
+	    i++;
+	    if (rmaps) {
+		*rmaps = (char **)G_realloc(*rmaps, i * sizeof(char *));
+		(*rmaps)[i - 1] = (char *)G_malloc(k + 1);
+		strncpy((*rmaps)[i - 1], buf3, k);
+		(*rmaps)[i - 1][k] = 0;
+    if (nrmaps)
+	*nrmaps = i;
+    if (i && rmaps) {
+	i++;
+	(*rmaps)[i - 1] = NULL;
+    return i;
+  \brief Get reclass
+  \param[out] reclass pointer to Reclass structure
+  \return -1 on error
+  \return type code
+int Rast_get_reclass(const char *name, const char *mapset,
+		  struct Reclass *reclass)
+    FILE *fd;
+    int stat;
+    if (fd == NULL)
+	return -1;
+    reclass->name = NULL;
+    reclass->mapset = NULL;
+    reclass->type = reclass_type(fd, &reclass->name, &reclass->mapset);
+    if (reclass->type <= 0) {
+	fclose(fd);
+	return reclass->type;
+    switch (reclass->type) {
+    case RECLASS_TABLE:
+	stat = get_reclass_table(fd, reclass);
+	break;
+    default:
+	stat = -1;
+    fclose(fd);
+    if (stat < 0) {
+	if (stat == -2)
+	    G_warning(_("Too many reclass categories for <%s@%s>"),
+		      name, mapset);
+	else
+	    G_warning(_("Illegal reclass format in header file for <%s@%s>"),
+		      name, mapset);
+	stat = -1;
+    return stat;
+  \brief Free Reclass structure
+  \param reclass pointer to Reclass structure
+void Rast_free_reclass(struct Reclass *reclass)
+	if (reclass->num > 0)
+	    G_free(reclass->table);
+	reclass->num = 0;
+	if (reclass->name)
+	    G_free(reclass->name);
+	if (reclass->mapset)
+	    G_free(reclass->mapset);
+	break;
+    default:
+	break;
+static int reclass_type(FILE * fd, char **rname, char **rmapset)
+    char buf[128];
+    char label[128], arg[128];
+    int i;
+    int type;
+    /* Check to see if this is a reclass file */
+    if (fgets(buf, sizeof(buf), fd) == NULL)
+	return 0;
+    if (strncmp(buf, "reclas", 6))
+	return 0;
+    /* later may add other types of reclass */
+    type = RECLASS_TABLE;
+    /* Read the mapset and file name of the REAL cell file */
+    if (*rname)
+	**rname = '\0';
+    if (*rmapset)
+	**rmapset = '\0';
+    for (i = 0; i < 2; i++) {
+	if (fgets(buf, sizeof buf, fd) == NULL)
+	    return -1;
+	if (sscanf(buf, "%[^:]:%s", label, arg) != 2)
+	    return -1;
+	if (strncmp(label, "maps", 4) == 0) {
+	    if (*rmapset)
+		strcpy(*rmapset, arg);
+	    else
+		*rmapset = G_store(arg);
+	else if (strncmp(label, "name", 4) == 0) {
+	    if (*rname)
+		strcpy(*rname, arg);
+	    else
+		*rname = G_store(arg);
+	else
+	    return -1;
+    if (**rmapset && **rname)
+	return type;
+    else
+	return -1;
+static FILE *fopen_cellhd_old(const char *name, const char *mapset)
+    return G_fopen_old("cellhd", name, mapset);
+  \brief Put reclass
+  \return 1 on success
+int Rast_put_reclass(const char *name, const struct Reclass *reclass)
+    FILE *fd;
+    long min, max;
+    int i;
+    char buf1[GPATH_MAX], buf2[GNAME_MAX], buf3[GNAME_MAX], *p;
+	if (reclass->min > reclass->max || reclass->num <= 0) {
+	    G_fatal_error(_("Illegal reclass request"));
+	    return -1;
+	break;
+    default:
+	G_fatal_error(_("Illegal reclass type"));
+	return -1;
+    fd = fopen_cellhd_new(name);
+    if (fd == NULL) {
+	G_warning(_("Unable to create header file for <%s@%s>"),
+		  name, G_mapset());
+	return -1;
+    fprintf(fd, "reclass\n");
+    fprintf(fd, "name: %s\n", reclass->name);
+    fprintf(fd, "mapset: %s\n", reclass->mapset);
+    /* find first non-null entry */
+    for (min = 0; min < reclass->num; min++)
+	if (!Rast_is_c_null_value(&reclass->table[min]))
+	    break;
+    /* find last non-zero entry */
+    for (max = reclass->num - 1; max >= 0; max--)
+	if (!Rast_is_c_null_value(&reclass->table[max]))
+	    break;
+     * if the resultant table is empty, write out a dummy table
+     * else write out the table
+     *   first entry is #min
+     *   rest are translations for cat min+i
+    if (min > max)
+	fprintf(fd, "0\n");
+    else {
+	fprintf(fd, "#%ld\n", (long)reclass->min + min);
+	while (min <= max) {
+	    if (Rast_is_c_null_value(&reclass->table[min]))
+		fprintf(fd, "%s\n", NULL_STRING);
+	    else
+		fprintf(fd, "%ld\n", (long)reclass->table[min]);
+	    min++;
+    fclose(fd);
+    strcpy(buf2, reclass->name);
+    if ((p = strchr(buf2, '@')))
+	*p = 0;
+    G__file_name_misc(buf1, "cell_misc", "reclassed_to", reclass->name,
+		      reclass->mapset);
+    fd = fopen(buf1, "a+");
+    if (fd == NULL) {
+#if 0
+	G_warning(_("Unable to create dependency file in <%s@%s>"),
+		  buf2, reclass->mapset);
+#endif
+	return 1;
+    fseek(fd, 0L, SEEK_SET);
+    sprintf(buf2, "%s@%s\n", name, G_mapset());
+    for (i = 0; !feof(fd) && fgets(buf3, 255, fd);) {
+	if (!(strcmp(buf2, buf3))) {
+	    i = 1;
+	    break;
+    if (!i) {
+	fprintf(fd, "%s@%s\n", name, G_mapset());
+    fclose(fd);
+    return 1;
+static FILE *fopen_cellhd_new(const char *name)
+    return G_fopen_new("cellhd", name);
+static int get_reclass_table(FILE * fd, struct Reclass *reclass)
+    char buf[128];
+    int n;
+    int first, null_str_size;
+    CELL cat;
+    long len;
+     * allocate the table, expanding as each entry is read
+     * note that G_realloc() will become G_malloc() if ptr in
+     * NULL
+    reclass->min = 0;
+    reclass->table = NULL;
+    null_str_size = strlen(NULL_STRING);
+    n = 0;
+    first = 1;
+    while (fgets(buf, sizeof buf, fd)) {
+	if (first) {
+	    first = 0;
+	    if (sscanf(buf, "#%d", &cat) == 1) {
+		reclass->min = cat;
+		continue;
+	if (strncmp(buf, NULL_STRING, null_str_size) == 0)
+	    Rast_set_c_null_value(&cat, 1);
+	else {
+	    if (sscanf(buf, "%d", &cat) != 1)
+		return -1;
+	n++;
+	len = (long)n *sizeof(CELL);
+	if (len != (int)len) {	/* check for int overflow */
+	    if (reclass->table != NULL)
+	    return -2;
+	reclass->table = (CELL *) G_realloc((char *)reclass->table, (int)len);
+	reclass->table[n - 1] = cat;
+    reclass->max = reclass->min + n - 1;
+    reclass->num = n;
+    return 1;
Copied: grass/trunk/lib/raster/sample.c (from rev 37989, grass/trunk/lib/gis/sample.c)
--- grass/trunk/lib/raster/sample.c	                        (rev 0)
+++ grass/trunk/lib/raster/sample.c	2009-06-20 22:03:23 UTC (rev 38003)
@@ -0,0 +1,340 @@
+   \file gis/sample.c
+   \brief GIS library - Sampling methods (extract a cell value from
+   raster map)
+   1/2006: moved to libgis from v.sample/v.drape for clone removal
+   (C) 2001-2009 by the GRASS Development Team
+   This program is free software under the GNU General Public License
+   (>=v2).  Read the file COPYING that comes with GRASS for details.
+   \author James Darrell McCauley <darrell mccauley-usa.com>, http://mccauley-usa.com/
+#include <math.h>
+/* prototypes */
+static double scancatlabel(const char *);
+static void raster_row_error(const struct Cell_head *window, double north,
+			     double east);
+ *  \brief Extract a cell value from raster map.
+ *  Extract a cell value from raster map at given northing and easting
+ *  with a sampled 3x3 window using a specified interpolation method.
+ *  - NEAREST  neighbor interpolation
+ *  - BILINEAR bilinear interpolation
+ *  - CUBIC    cubic interpolation
+ *  \param fd file descriptor
+ *  \param window region settings
+ *  \param cats categories
+ *  \param north northing position
+ *  \param east easting position
+ *  \param usedesc flag to scan category label
+ *  \param itype interpolation method
+ *  \return cell value at given position
+DCELL Rast_get_raster_sample(int fd,
+			  const struct Cell_head *window,
+			  struct Categories *cats,
+			  double north, double east,
+			  int usedesc, INTERP_TYPE itype)
+    double retval;
+    switch (itype) {
+    case NEAREST:
+	retval = Rast_get_raster_sample_nearest(fd, window, cats, north, east, usedesc);
+	break;
+    case BILINEAR:
+	retval = Rast_get_raster_sample_bilinear(fd, window, cats, north, east, usedesc);
+	break;
+    case CUBIC:
+	retval = Rast_get_raster_sample_cubic(fd, window, cats, north, east, usedesc);
+	break;
+    default:
+	G_fatal_error("Rast_get_raster_sample: %s",
+		      _("Unknown interpolation type"));
+    return retval;
+ *  \brief Extract a cell value from raster map (neighbor interpolation)
+ *  with a sampled 3x3 window using a neighbor interpolation.
+DCELL Rast_get_raster_sample_nearest(int fd,
+				  double north, double east, int usedesc)
+    int row, col;
+    DCELL result;
+    DCELL *maprow = Rast_allocate_d_raster_buf();
+    /* convert northing and easting to row and col, resp */
+    row = (int)floor(G_northing_to_row(north, window));
+    col = (int)floor(G_easting_to_col(east, window));
+    if (row < 0 || row >= G_window_rows() ||
+	col < 0 || col >= G_window_cols()) {
+	Rast_set_d_null_value(&result, 1);
+	goto done;
+    if (Rast_get_d_raster_row(fd, maprow, row) < 0)
+	raster_row_error(window, north, east);
+    if (Rast_is_d_null_value(&maprow[col])) {
+	goto done;
+    if (usedesc) {
+	char *buf = Rast_get_cat(maprow[col], cats);
+	G_squeeze(buf);
+	result = scancatlabel(buf);
+    else
+	result = maprow[col];
+done:
+    G_free(maprow);
+    return result;
+ *  \brief Extract a cell value from raster map (bilinear interpolation).
+ *  with a sampled 3x3 window using a bilinear interpolation.
+DCELL Rast_get_raster_sample_bilinear(int fd,
+    int row, col;
+    double grid[2][2];
+    DCELL *arow = Rast_allocate_d_raster_buf();
+    DCELL *brow = Rast_allocate_d_raster_buf();
+    double frow, fcol, trow, tcol;
+    DCELL result;
+    frow = G_northing_to_row(north, window);
+    fcol = G_easting_to_col(east, window);
+    row = (int)floor(frow - 0.5);
+    col = (int)floor(fcol - 0.5);
+    trow = frow - row - 0.5;
+    tcol = fcol - col - 0.5;
+    if (row < 0 || row + 1 >= G_window_rows() ||
+	col < 0 || col + 1 >= G_window_cols()) {
+	goto done;
+    if (Rast_get_d_raster_row(fd, arow, row) < 0)
+    if (Rast_get_d_raster_row(fd, brow, row + 1) < 0)
+    if (Rast_is_d_null_value(&arow[col]) || Rast_is_d_null_value(&arow[col + 1]) ||
+	Rast_is_d_null_value(&brow[col]) || Rast_is_d_null_value(&brow[col + 1])) {
+	goto done;
+     * now were ready to do bilinear interpolation over
+     * arow[col], arow[col+1],
+     * brow[col], brow[col+1]
+    if (usedesc) {
+	char *buf;
+	G_squeeze(buf = Rast_get_cat((int)arow[col], cats));
+	grid[0][0] = scancatlabel(buf);
+	G_squeeze(buf = Rast_get_cat((int)arow[col + 1], cats));
+	grid[0][1] = scancatlabel(buf);
+	G_squeeze(buf = Rast_get_cat((int)brow[col], cats));
+	grid[1][0] = scancatlabel(buf);
+	G_squeeze(buf = Rast_get_cat((int)brow[col + 1], cats));
+	grid[1][1] = scancatlabel(buf);
+    else {
+	grid[0][0] = arow[col];
+	grid[0][1] = arow[col + 1];
+	grid[1][0] = brow[col];
+	grid[1][1] = brow[col + 1];
+    result = Rast_interp_bilinear(tcol, trow,
+			       grid[0][0], grid[0][1], grid[1][0], grid[1][1]);
+done:
+    G_free(arow);
+    G_free(brow);
+    return result;
+ *  \brief Extract a cell value from raster map (cubic interpolation).
+ *  with a sampled 3x3 window using a cubic interpolation.
+DCELL Rast_get_raster_sample_cubic(int fd,
+    int i, j, row, col;
+    double grid[4][4];
+    DCELL *rows[4];
+    DCELL result;
+    for (i = 0; i < 4; i++)
+	rows[i] = Rast_allocate_d_raster_buf();
+    row = (int)floor(frow - 1.5);
+    col = (int)floor(fcol - 1.5);
+    trow = frow - row - 1.5;
+    tcol = fcol - col - 1.5;
+    if (row < 0 || row + 3 >= G_window_rows() ||
+	col < 0 || col + 3 >= G_window_cols()) {
+	goto done;
+	if (Rast_get_d_raster_row(fd, rows[i], row + i) < 0)
+	for (j = 0; j < 4; j++)
+	    if (Rast_is_d_null_value(&rows[i][col + j])) {
+		goto done;
+     * now were ready to do cubic interpolation over
+     * arow[col], arow[col+1], arow[col+2], arow[col+3],
+     * brow[col], brow[col+1], brow[col+2], brow[col+3],
+     * crow[col], crow[col+1], crow[col+2], crow[col+3],
+     * drow[col], drow[col+1], drow[col+2], drow[col+3],
+    if (usedesc) {
+	char *buf;
+	for (i = 0; i < 4; i++) {
+	    for (j = 0; j < 4; j++) {
+		G_squeeze(buf = Rast_get_cat(rows[i][col + j], cats));
+		grid[i][j] = scancatlabel(buf);
+    else {
+		grid[i][j] = rows[i][col + j];
+    result = Rast_interp_bicubic(tcol, trow,
+			      grid[0][0], grid[0][1], grid[0][2], grid[0][3],
+			      grid[1][0], grid[1][1], grid[1][2], grid[1][3],
+			      grid[2][0], grid[2][1], grid[2][2], grid[2][3],
+			      grid[3][0], grid[3][1], grid[3][2], grid[3][3]);
+done:
+	G_free(rows[i]);
+    return result;
+static double scancatlabel(const char *str)
+    double val;
+    if (strcmp(str, "no data") != 0)
+	sscanf(str, "%lf", &val);
+    else {
+	G_warning(_("\"no data\" label found; setting to zero"));
+	val = 0.0;
+    return val;
+			     double east)
+    G_debug(3, "DIAG: \tRegion is: n=%g s=%g e=%g w=%g",
+	    window->north, window->south, window->east, window->west);
+    G_debug(3, "      \tData point is north=%g east=%g", north, east);
+    G_fatal_error(_("Problem reading raster map"));
Copied: grass/trunk/lib/raster/zero_cell.c (from rev 37989, grass/trunk/lib/gis/zero_cell.c)
--- grass/trunk/lib/raster/zero_cell.c	                        (rev 0)
+++ grass/trunk/lib/raster/zero_cell.c	2009-06-20 22:03:23 UTC (rev 38003)
@@ -0,0 +1,56 @@
+ * \file gis/zero_cell.c
+ * \brief GIS Library - Zero cell buffer functions.
+ * \brief Zero a raster CELL buffer.
+ * This routines assigns each member of the raster buffer array
+ * <i>buf</i> to zero. It assumes that <i>buf</i> has been allocated
+ * using Rast_allocate_cell_buf().
+ * \param buf data buffer
+void Rast_zero_cell_buf(CELL * buf)
+    int i = G_window_cols();
+    while (i--)
+	*buf++ = 0;
+ * \brief Zero a raster buffer.
+ * <i>rast</i> to zero. It assumes that <i>rast</i> has been allocated
+ * \param rast data buffer
+void Rast_zero_raster_buf(void *rast, RASTER_MAP_TYPE data_type)
+    int i;
+    unsigned char *ptr;
+    /* assuming that the size of unsigned char is 1 byte */
+    i = G_window_cols() * Rast_raster_size(data_type);
+    ptr = (unsigned char *)rast;
+    while (i--)
+	*ptr++ = 0;
Modified: grass/trunk/lib/rst/interp_float/input2d.c
--- grass/trunk/lib/rst/interp_float/input2d.c	2009-06-20 21:39:23 UTC (rev 38002)
+++ grass/trunk/lib/rst/interp_float/input2d.c	2009-06-20 22:03:23 UTC (rev 38003)
@@ -17,7 +17,9 @@
 #include <stdio.h>
 #include <stdlib.h>
 #include <math.h>
 #include <grass/site.h>
 #include <grass/bitmap.h>
 #include <grass/linkm.h>
@@ -33,8 +35,8 @@
     CELL *cellmask, *MASK;
     struct BM *bitmask;
-    if ((MASKfd = G_maskfd()) >= 0)
-	MASK = G_allocate_cell_buf();
+    if ((MASKfd = Rast_maskfd()) >= 0)
+	MASK = Rast_allocate_cell_buf();
     else
 	MASK = NULL;
@@ -47,8 +49,8 @@
 		G_fatal_error(_("Mask raster map <%s> not found"),
 			      params->maskmap);
-	    cellmask = G_allocate_cell_buf();
-	    cfmask = G_open_cell_old(params->maskmap, mapsetm);
+	    cellmask = Rast_allocate_cell_buf();
+	    cfmask = Rast_open_cell_old(params->maskmap, mapsetm);
 	else
 	    cellmask = NULL;
@@ -56,9 +58,9 @@
 	for (i = 0; i < params->nsizr; i++) {
 	    irev = params->nsizr - i - 1;
 	    if (cellmask)
-		G_get_map_row(cfmask, cellmask, i);
+		Rast_get_map_row(cfmask, cellmask, i);
 	    if (MASK)
-		G_get_map_row(MASKfd, MASK, i);
+		Rast_get_map_row(MASKfd, MASK, i);
 	    for (j = 0; j < params->nsizc; j++) {
 		if ((cellmask && cellmask[j] == 0) || (MASK && MASK[j] == 0))
 		    BM_set(bitmask, j, irev, 0);
Modified: grass/trunk/lib/rst/interp_float/interp2d.c
--- grass/trunk/lib/rst/interp_float/interp2d.c	2009-06-20 21:39:23 UTC (rev 38002)
+++ grass/trunk/lib/rst/interp_float/interp2d.c	2009-06-20 22:03:23 UTC (rev 38003)
@@ -26,7 +26,9 @@
 #include <stdio.h>
 #include <math.h>
 #include <unistd.h>
 #include <grass/interpf.h>
@@ -236,16 +238,16 @@
 	    else {
-		G_set_d_null_value(params->az + l, 1);
+		Rast_set_d_null_value(params->az + l, 1);
 		/*          fprintf (stderr, "zz=%f, az[l]=%f, c=%d\n", zz, params->az[l], l); */
 		if (cond1) {
-		    G_set_d_null_value(params->adx + l, 1);
-		    G_set_d_null_value(params->ady + l, 1);
+		    Rast_set_d_null_value(params->adx + l, 1);
+		    Rast_set_d_null_value(params->ady + l, 1);
 		    if (cond2) {
-			G_set_d_null_value(params->adxx + l, 1);
-			G_set_d_null_value(params->adyy + l, 1);
-			G_set_d_null_value(params->adxy + l, 1);
+			Rast_set_d_null_value(params->adxx + l, 1);
+			Rast_set_d_null_value(params->adyy + l, 1);
+			Rast_set_d_null_value(params->adxy + l, 1);
Modified: grass/trunk/lib/rst/interp_float/output2d.c
--- grass/trunk/lib/rst/interp_float/output2d.c	2009-06-20 21:39:23 UTC (rev 38002)
+++ grass/trunk/lib/rst/interp_float/output2d.c	2009-06-20 22:03:23 UTC (rev 38003)
@@ -15,7 +15,9 @@
 #include <stdio.h>
 #include <math.h>
@@ -54,13 +56,13 @@
 	     || (params->mcurv != NULL));
     cond1 = ((params->slope != NULL) || (params->aspect != NULL) || cond2);
-    cell1 = G_allocate_f_raster_buf();
+    cell1 = Rast_allocate_f_raster_buf();
      * G_set_embedded_null_value_mode(1);
     if (params->elev != NULL) {
-	cf1 = G_open_fp_cell_new(params->elev);
+	cf1 = Rast_open_fp_cell_new(params->elev);
 	if (cf1 < 0) {
 	    fprintf(stderr, "unable to create raster map %s\n", params->elev);
 	    return -1;
@@ -68,7 +70,7 @@
     if (params->slope != NULL) {
-	cf2 = G_open_fp_cell_new(params->slope);
+	cf2 = Rast_open_fp_cell_new(params->slope);
 	if (cf2 < 0) {
 		    params->slope);
@@ -77,7 +79,7 @@
     if (params->aspect != NULL) {
-	cf3 = G_open_fp_cell_new(params->aspect);
+	cf3 = Rast_open_fp_cell_new(params->aspect);
 	if (cf3 < 0) {
 		    params->aspect);
@@ -86,7 +88,7 @@
     if (params->pcurv != NULL) {
-	cf4 = G_open_fp_cell_new(params->pcurv);
+	cf4 = Rast_open_fp_cell_new(params->pcurv);
 	if (cf4 < 0) {
 		    params->pcurv);
@@ -95,7 +97,7 @@
     if (params->tcurv != NULL) {
-	cf5 = G_open_fp_cell_new(params->tcurv);
+	cf5 = Rast_open_fp_cell_new(params->tcurv);
 	if (cf5 < 0) {
 		    params->tcurv);
@@ -104,7 +106,7 @@
     if (params->mcurv != NULL) {
-	cf6 = G_open_fp_cell_new(params->mcurv);
+	cf6 = Rast_open_fp_cell_new(params->mcurv);
 	if (cf6 < 0) {
 		    params->mcurv);
@@ -157,7 +159,7 @@
 	     * for(j=0;j<params->nsizc;j++) fprintf(stderr,"%f ",cell1[j]);
 	     * fprintf(stderr,"\n");
-	    G_put_f_raster_row(cf1, cell1);
+	    Rast_put_f_raster_row(cf1, cell1);
@@ -174,7 +176,7 @@
 		return -1;
 	    fread(cell1, sizeof(FCELL), params->nsizc, params->Tmp_fd_dx);
-	    G_put_f_raster_row(cf2, cell1);
+	    Rast_put_f_raster_row(cf2, cell1);
@@ -190,7 +192,7 @@
 		return -1;
 	    fread(cell1, sizeof(FCELL), params->nsizc, params->Tmp_fd_dy);
-	    G_put_f_raster_row(cf3, cell1);
+	    Rast_put_f_raster_row(cf3, cell1);
@@ -206,7 +208,7 @@
 		return -1;
 	    fread(cell1, sizeof(FCELL), params->nsizc, params->Tmp_fd_xx);
-	    G_put_f_raster_row(cf4, cell1);
+	    Rast_put_f_raster_row(cf4, cell1);
@@ -222,7 +224,7 @@
 		return -1;
 	    fread(cell1, sizeof(FCELL), params->nsizc, params->Tmp_fd_yy);
-	    G_put_f_raster_row(cf5, cell1);
+	    Rast_put_f_raster_row(cf5, cell1);
@@ -238,49 +240,49 @@
 		return -1;
 	    fread(cell1, sizeof(FCELL), params->nsizc, params->Tmp_fd_xy);
-	    G_put_f_raster_row(cf6, cell1);
+	    Rast_put_f_raster_row(cf6, cell1);
     if (cf1)
-	G_close_cell(cf1);
+	Rast_close_cell(cf1);
     if (cf2)
-	G_close_cell(cf2);
+	Rast_close_cell(cf2);
     if (cf3)
-	G_close_cell(cf3);
+	Rast_close_cell(cf3);
     if (cf4)
-	G_close_cell(cf4);
+	Rast_close_cell(cf4);
     if (cf5)
-	G_close_cell(cf5);
+	Rast_close_cell(cf5);
     if (cf6)
-	G_close_cell(cf6);
+	Rast_close_cell(cf6);
     /* colortable for elevations */
-    G_init_colors(&colors);
+    Rast_init_colors(&colors);
     zstep = (FCELL) (zmaxac - zminac) / 5.;
     for (i = 1; i <= 5; i++) {
 	data1 = (FCELL) (zminac + (i - 1) * zstep);
 	data2 = (FCELL) (zminac + i * zstep);
 	switch (i) {
 	case 1:
-	    G_add_f_raster_color_rule(&data1, 0, 191, 191,
+	    Rast_add_f_raster_color_rule(&data1, 0, 191, 191,
 				      &data2, 0, 255, 0, &colors);
 	    break;
 	case 2:
-	    G_add_f_raster_color_rule(&data1, 0, 255, 0,
+	    Rast_add_f_raster_color_rule(&data1, 0, 255, 0,
 				      &data2, 255, 255, 0, &colors);
 	    break;
 	case 3:
-	    G_add_f_raster_color_rule(&data1, 255, 255, 0,
+	    Rast_add_f_raster_color_rule(&data1, 255, 255, 0,
 				      &data2, 255, 127, 0, &colors);
 	    break;
 	case 4:
-	    G_add_f_raster_color_rule(&data1, 255, 127, 0,
+	    Rast_add_f_raster_color_rule(&data1, 255, 127, 0,
 				      &data2, 191, 127, 63, &colors);
 	    break;
 	case 5:
-	    G_add_f_raster_color_rule(&data1, 191, 127, 63,
+	    Rast_add_f_raster_color_rule(&data1, 191, 127, 63,
 				      &data2, 20, 20, 20, &colors);
 	    break;
@@ -292,8 +294,8 @@
 	    fprintf(stderr, "file [%s] not found\n", params->elev);
 	    return -1;
-	G_write_colors(params->elev, mapset, &colors);
-	G_quantize_fp_map_range(params->elev, mapset,
+	Rast_write_colors(params->elev, mapset, &colors);
+	Rast_quantize_fp_map_range(params->elev, mapset,
 				(DCELL) zminac - 0.5, (DCELL) zmaxac + 0.5,
 				(CELL) (zminac - 0.5), (CELL) (zmaxac + 0.5));
@@ -303,53 +305,53 @@
 	if (!params->deriv) {
 	     * smin = (CELL) ((int)(gmin*scig)); smax = (CELL) gmax; fprintf
-	     * (stderr, "min %d max %d \n", smin,smax); G_make_rainbow_colors
+	     * (stderr, "min %d max %d \n", smin,smax); Rast_make_rainbow_colors
 	     * (&colors,smin,smax);
-	    G_add_color_rule(0, 255, 255, 255, 2, 255, 255, 0, &colors);
-	    G_add_color_rule(2, 255, 255, 0, 5, 0, 255, 0, &colors);
-	    G_add_color_rule(5, 0, 255, 0, 10, 0, 255, 255, &colors);
-	    G_add_color_rule(10, 0, 255, 255, 15, 0, 0, 255, &colors);
-	    G_add_color_rule(15, 0, 0, 255, 30, 255, 0, 255, &colors);
-	    G_add_color_rule(30, 255, 0, 255, 50, 255, 0, 0, &colors);
-	    G_add_color_rule(50, 255, 0, 0, 90, 0, 0, 0, &colors);
+	    Rast_add_color_rule(0, 255, 255, 255, 2, 255, 255, 0, &colors);
+	    Rast_add_color_rule(2, 255, 255, 0, 5, 0, 255, 0, &colors);
+	    Rast_add_color_rule(5, 0, 255, 0, 10, 0, 255, 255, &colors);
+	    Rast_add_color_rule(10, 0, 255, 255, 15, 0, 0, 255, &colors);
+	    Rast_add_color_rule(15, 0, 0, 255, 30, 255, 0, 255, &colors);
+	    Rast_add_color_rule(30, 255, 0, 255, 50, 255, 0, 0, &colors);
+	    Rast_add_color_rule(50, 255, 0, 0, 90, 0, 0, 0, &colors);
 	else {
 	    dat1 = (FCELL) - 5.0;	/* replace by min dx, amin1 (c1min,
 					 * c2min); */
 	    dat2 = (FCELL) - 0.1;
-	    G_add_f_raster_color_rule(&dat1, 127, 0, 255,
+	    Rast_add_f_raster_color_rule(&dat1, 127, 0, 255,
 				      &dat2, 0, 0, 255, &colors);
 	    dat1 = dat2;
 	    dat2 = (FCELL) - 0.01;
-	    G_add_f_raster_color_rule(&dat1, 0, 0, 255,
+	    Rast_add_f_raster_color_rule(&dat1, 0, 0, 255,
 				      &dat2, 0, 127, 255, &colors);
 	    dat1 = dat2;
 	    dat2 = (FCELL) - 0.001;
-	    G_add_f_raster_color_rule(&dat1, 0, 127, 255,
+	    Rast_add_f_raster_color_rule(&dat1, 0, 127, 255,
 				      &dat2, 0, 255, 255, &colors);
 	    dat1 = dat2;
 	    dat2 = (FCELL) 0.0;
-	    G_add_f_raster_color_rule(&dat1, 0, 255, 255,
+	    Rast_add_f_raster_color_rule(&dat1, 0, 255, 255,
 				      &dat2, 200, 255, 200, &colors);
 	    dat1 = dat2;
 	    dat2 = (FCELL) 0.001;
-	    G_add_f_raster_color_rule(&dat1, 200, 255, 200,
+	    Rast_add_f_raster_color_rule(&dat1, 200, 255, 200,
 				      &dat2, 255, 255, 0, &colors);
 	    dat1 = dat2;
 	    dat2 = (FCELL) 0.01;
-	    G_add_f_raster_color_rule(&dat1, 255, 255, 0,
+	    Rast_add_f_raster_color_rule(&dat1, 255, 255, 0,
 				      &dat2, 255, 127, 0, &colors);
 	    dat1 = dat2;
 	    dat2 = (FCELL) 0.1;
-	    G_add_f_raster_color_rule(&dat1, 255, 127, 0,
+	    Rast_add_f_raster_color_rule(&dat1, 255, 127, 0,
 				      &dat2, 255, 0, 0, &colors);
 	    dat1 = dat2;
 	    dat2 = (FCELL) 5.0;	/* replace by max dx, amax1 (c1max,
 				 * c2max); */
-	    G_add_f_raster_color_rule(&dat1, 255, 0, 0,
+	    Rast_add_f_raster_color_rule(&dat1, 255, 0, 0,
 				      &dat2, 255, 0, 200, &colors);
@@ -359,11 +361,11 @@
 		fprintf(stderr, "file [%s] not found\n", params->slope);
 		return -1;
-	    G_write_colors(params->slope, mapset, &colors);
-	    G_quantize_fp_map_range(params->slope, mapset, 0., 90., 0, 90);
+	    Rast_write_colors(params->slope, mapset, &colors);
+	    Rast_quantize_fp_map_range(params->slope, mapset, 0., 90., 0, 90);
 	    type = "raster";
-	    G_short_history(params->slope, type, &hist1);
+	    Rast_short_history(params->slope, type, &hist1);
 		sprintf(hist1.edhist[0], "The elevation map is %s",
 			params->elev);
@@ -373,8 +375,8 @@
 		sprintf(hist1.datsrc_1, "site file %s", input);
 	    hist1.edlinecnt = 1;
-	    G_command_history(&hist1);
-	    G_write_history(params->slope, &hist1);
+	    Rast_command_history(&hist1);
+	    Rast_write_history(params->slope, &hist1);
 	    if (params->ts)
 		G_write_raster_timestamp(params->slope, params->ts);
@@ -382,48 +384,48 @@
 	/* colortable for aspect */
-	    G_add_color_rule(0, 255, 255, 255, 0, 255, 255, 255, &colors);
-	    G_add_color_rule(1, 255, 255, 0, 90, 0, 255, 0, &colors);
-	    G_add_color_rule(90, 0, 255, 0, 180, 0, 255, 255, &colors);
-	    G_add_color_rule(180, 0, 255, 255, 270, 255, 0, 0, &colors);
-	    G_add_color_rule(270, 255, 0, 0, 360, 255, 255, 0, &colors);
+	    Rast_add_color_rule(0, 255, 255, 255, 0, 255, 255, 255, &colors);
+	    Rast_add_color_rule(1, 255, 255, 0, 90, 0, 255, 0, &colors);
+	    Rast_add_color_rule(90, 0, 255, 0, 180, 0, 255, 255, &colors);
+	    Rast_add_color_rule(180, 0, 255, 255, 270, 255, 0, 0, &colors);
+	    Rast_add_color_rule(270, 255, 0, 0, 360, 255, 255, 0, &colors);
 	else {
 	    dat1 = (FCELL) - 5.0;	/* replace by min dy, amin1 (c1min,
 					 * c2min); */
 	    dat1 = dat2;
 	    dat1 = dat2;
 	    dat1 = dat2;
 	    dat2 = (FCELL) 0.0;
 	    dat1 = dat2;
 	    dat1 = dat2;
 	    dat1 = dat2;
 	    dat2 = (FCELL) 0.1;
 	    dat1 = dat2;
 	    dat2 = (FCELL) 5.0;	/* replace by max dy, amax1 (c1max,
 				 * c2max); */
@@ -433,11 +435,11 @@
 		fprintf(stderr, "file [%s] not found\n", params->aspect);
 		return -1;
-	    G_write_colors(params->aspect, mapset, &colors);
-	    G_quantize_fp_map_range(params->aspect, mapset, 0., 360., 0, 360);
+	    Rast_write_colors(params->aspect, mapset, &colors);
+	    Rast_quantize_fp_map_range(params->aspect, mapset, 0., 360., 0, 360);
 	    type = "raster";
-	    G_short_history(params->aspect, type, &hist2);
+	    Rast_short_history(params->aspect, type, &hist2);
 		sprintf(hist2.edhist[0], "The elevation map is %s",
 			params->elev);
@@ -447,48 +449,48 @@
 		sprintf(hist2.datsrc_1, "site file %s", input);
 	    hist2.edlinecnt = 1;
-	    G_command_history(&hist2);
-	    G_write_history(params->aspect, &hist2);
+	    Rast_command_history(&hist2);
+	    Rast_write_history(params->aspect, &hist2);
 	    if (params->ts)
 		G_write_raster_timestamp(params->aspect, params->ts);
 	/* colortable for curvatures */
 	if (cond2) {
 	    dat1 = (FCELL) amin1(c1min, c2min);	/* for derivatives use min
 						 * dxx,dyy,dxy */
 	    dat1 = dat2;
 	    dat1 = dat2;
 	    dat2 = (FCELL) - 0.00001;
 	    dat1 = dat2;
 	    dat2 = (FCELL) 0.0;
 	    dat1 = dat2;
 	    dat2 = (FCELL) 0.00001;
 	    dat1 = dat2;
 	    dat1 = dat2;
 	    dat1 = dat2;
 	    dat2 = (FCELL) amax1(c1max, c2max);	/* for derivatives use max
 						 * dxx,dyy,dxy */
@@ -497,13 +499,13 @@
 		    fprintf(stderr, "file [%s] not found\n", params->pcurv);
 		    return -1;
-		G_write_colors(params->pcurv, mapset, &colors);
-		G_quantize_fp_map_range(params->pcurv, mapset, dat1, dat2,
+		Rast_write_colors(params->pcurv, mapset, &colors);
+		Rast_quantize_fp_map_range(params->pcurv, mapset, dat1, dat2,
 					(CELL) (dat1 * MULT),
 					(CELL) (dat2 * MULT));
 		type = "raster";
-		G_short_history(params->pcurv, type, &hist3);
+		Rast_short_history(params->pcurv, type, &hist3);
 		    sprintf(hist3.edhist[0], "The elevation map is %s",
 			    params->elev);
@@ -513,8 +515,8 @@
 		    sprintf(hist3.datsrc_1, "site file %s", input);
 		hist3.edlinecnt = 1;
-		G_command_history(&hist3);
-		G_write_history(params->pcurv, &hist3);
+		Rast_command_history(&hist3);
+		Rast_write_history(params->pcurv, &hist3);
 		if (params->ts)
 		    G_write_raster_timestamp(params->pcurv, params->ts);
@@ -525,13 +527,13 @@
 		    fprintf(stderr, "file [%s] not found\n", params->tcurv);
 		    return -1;
-		G_write_colors(params->tcurv, mapset, &colors);
-		G_quantize_fp_map_range(params->tcurv, mapset, dat1, dat2,
+		Rast_write_colors(params->tcurv, mapset, &colors);
+		Rast_quantize_fp_map_range(params->tcurv, mapset, dat1, dat2,
 		type = "raster";
-		G_short_history(params->tcurv, type, &hist4);
+		Rast_short_history(params->tcurv, type, &hist4);
 		    sprintf(hist4.edhist[0], "The elevation map is %s",
 			    params->elev);
@@ -541,8 +543,8 @@
 		    sprintf(hist4.datsrc_1, "site file %s", input);
 		hist4.edlinecnt = 1;
-		G_command_history(&hist4);
-		G_write_history(params->tcurv, &hist4);
+		Rast_command_history(&hist4);
+		Rast_write_history(params->tcurv, &hist4);
 		if (params->ts)
 		    G_write_raster_timestamp(params->tcurv, params->ts);
@@ -553,13 +555,13 @@
 		    fprintf(stderr, "file [%s] not found\n", params->mcurv);
 		    return -1;
-		G_write_colors(params->mcurv, mapset, &colors);
-		G_quantize_fp_map_range(params->mcurv, mapset, dat1, dat2,
+		Rast_write_colors(params->mcurv, mapset, &colors);
+		Rast_quantize_fp_map_range(params->mcurv, mapset, dat1, dat2,
 		type = "raster";
-		G_short_history(params->mcurv, type, &hist5);
+		Rast_short_history(params->mcurv, type, &hist5);
 		    sprintf(hist5.edhist[0], "The elevation map is %s",
 			    params->elev);
@@ -569,8 +571,8 @@
 		    sprintf(hist5.datsrc_1, "site file %s", input);
 		hist5.edlinecnt = 1;
-		G_command_history(&hist5);
-		G_write_history(params->mcurv, &hist5);
+		Rast_command_history(&hist5);
+		Rast_write_history(params->mcurv, &hist5);
 		if (params->ts)
 		    G_write_raster_timestamp(params->mcurv, params->ts);
@@ -584,7 +586,7 @@
 	    return -1;
 	type = "raster";
-	G_short_history(params->elev, type, &hist);
+	Rast_short_history(params->elev, type, &hist);
 	params->dmin = sqrt(params->dmin);
 	fprintf(stdout, "history initiated\n");
@@ -641,14 +643,14 @@
 	else
 	    sprintf(hist.datsrc_1, "site file %s", input);
-	G_command_history(&hist);
-	G_write_history(params->elev, &hist);
+	Rast_command_history(&hist);
+	Rast_write_history(params->elev, &hist);
 	if (params->ts)
 	    G_write_raster_timestamp(params->elev, params->ts);
-     * if (title) G_put_cell_title (output, title);
+     * if (title) Rast_put_cell_title (output, title);
     return 1;
Modified: grass/trunk/lib/rst/interp_float/resout2d.c
--- grass/trunk/lib/rst/interp_float/resout2d.c	2009-06-20 21:39:23 UTC (rev 38002)
+++ grass/trunk/lib/rst/interp_float/resout2d.c	2009-06-20 22:03:23 UTC (rev 38003)
@@ -15,10 +15,11 @@
 #include <stdio.h>
 #include <math.h>
@@ -63,10 +64,10 @@
     mapset = G_mapset();
 	if (cf1 < 0) {
 	    return -1;
@@ -74,7 +75,7 @@
 	if (cf2 < 0) {
 		    params->slope);
@@ -83,7 +84,7 @@
 	if (cf3 < 0) {
 		    params->aspect);
@@ -92,7 +93,7 @@
 	if (cf4 < 0) {
 		    params->pcurv);
@@ -101,7 +102,7 @@
 	if (cf5 < 0) {
 		    params->tcurv);
@@ -110,7 +111,7 @@
 	if (cf6 < 0) {
 		    params->mcurv);
@@ -143,7 +144,7 @@
 		return -1;
 	    fread(cell1, sizeof(FCELL), params->nsizc, params->Tmp_fd_z);
-	    if (G_put_f_raster_row(cf1, cell1) < 0) {
+	    if (Rast_put_f_raster_row(cf1, cell1) < 0) {
 		fprintf(stderr, "cannot write file\n");
 		return -1;
@@ -166,7 +167,7 @@
 	     * fprintf(stderr,"%f ",cell1[ii]); }
 	     * fprintf(stderr,"params->nsizc=%d \n",params->nsizc);
-	    if (G_put_f_raster_row(cf2, cell1) < 0) {
+	    if (Rast_put_f_raster_row(cf2, cell1) < 0) {
 		return -1;
@@ -184,7 +185,7 @@
 		return -1;
-	    if (G_put_f_raster_row(cf3, cell1) < 0) {
+	    if (Rast_put_f_raster_row(cf3, cell1) < 0) {
 		return -1;
@@ -202,7 +203,7 @@
 		return -1;
-	    if (G_put_f_raster_row(cf4, cell1) < 0) {
+	    if (Rast_put_f_raster_row(cf4, cell1) < 0) {
 		return -1;
@@ -220,7 +221,7 @@
 		return -1;
-	    if (G_put_f_raster_row(cf5, cell1) < 0) {
+	    if (Rast_put_f_raster_row(cf5, cell1) < 0) {
 		return -1;
@@ -238,7 +239,7 @@
 		return -1;
-	    if (G_put_f_raster_row(cf6, cell1) < 0) {
+	    if (Rast_put_f_raster_row(cf6, cell1) < 0) {
 		return -1;
@@ -246,17 +247,17 @@
     if (cf1)
     if (cf2)
     if (cf3)
     if (cf4)
     if (cf5)
     if (cf6)
     /* write colormaps and history for output cell files */
@@ -267,12 +268,12 @@
 	    fprintf(stderr, "file [%s] not found\n", input);
 	    return -1;
-	G_init_colors(&colors2);
+	Rast_init_colors(&colors2);
-	 * G_mark_colors_as_fp(&colors2);
+	 * Rast_mark_colors_as_fp(&colors2);
-	if (G_read_colors(input, maps, &colors) >= 0) {
+	if (Rast_read_colors(input, maps, &colors) >= 0) {
 	    if (colors.modular.rules) {
 		rule = colors.modular.rules;
@@ -282,7 +283,7 @@
 		for (; rule; rule = rule->prev) {
 		    value1 = rule->low.value * params->zmult;
 		    value2 = rule->high.value * params->zmult;
-		    G_add_modular_d_raster_color_rule(&value1, rule->low.red,
+		    Rast_add_modular_d_raster_color_rule(&value1, rule->low.red,
 						      rule->low.grn,
 						      rule->low.blu, &value2,
 						      rule->high.red,
@@ -301,7 +302,7 @@
-		    G_add_d_raster_color_rule(&value1, rule->low.red,
+		    Rast_add_d_raster_color_rule(&value1, rule->low.red,
 					      rule->low.grn, rule->low.blu,
 					      &value2, rule->high.red,
 					      rule->high.grn, rule->high.blu,
@@ -316,11 +317,11 @@
 		return -1;
-	    if (G_write_colors(params->elev, maps, &colors2) < 0) {
+	    if (Rast_write_colors(params->elev, maps, &colors2) < 0) {
 		fprintf(stderr, "Cannot write color table\n");
 		return -1;
 				    zminac - 0.5, zmaxac + 0.5,
@@ -332,14 +333,14 @@
     /* colortable for slopes */
     if (cond1 & (!params->deriv)) {
 	    maps = NULL;
@@ -348,11 +349,11 @@
 		return -1;
-	    G_write_colors(params->slope, maps, &colors);
+	    Rast_write_colors(params->slope, maps, &colors);
 	    type = "raster";
 			params->elev);
@@ -360,16 +361,16 @@
 	    sprintf(hist1.datsrc_1, "raster map %s", input);
 	    maps = NULL;
@@ -378,11 +379,11 @@
 		return -1;
-	    G_write_colors(params->aspect, maps, &colors);
+	    Rast_write_colors(params->aspect, maps, &colors);
 	    type = "raster";
 			params->elev);
@@ -390,45 +391,45 @@
 	    sprintf(hist2.datsrc_1, "raster map %s", input);
 	if (cond2) {
-	    G_add_f_raster_color_rule(&dat1, 50, 0, 155,
+	    Rast_add_f_raster_color_rule(&dat1, 50, 0, 155,
 	    dat1 = dat2;
 	    dat1 = dat2;
 	    dat1 = dat2;
 	    dat2 = (FCELL) 0.00;
 	    dat1 = dat2;
 	    dat1 = dat2;
 	    dat1 = dat2;
 	    dat1 = dat2;
 				      &dat2, 155, 0, 20, &colors);
 	    maps = NULL;
@@ -437,16 +438,16 @@
 		    return -1;
-		G_write_colors(params->pcurv, maps, &colors);
+		Rast_write_colors(params->pcurv, maps, &colors);
 		fprintf(stderr, "color map written\n");
 					dat1, dat2,
 		type = "raster";
 			    params->elev);
@@ -454,7 +455,7 @@
 		sprintf(hist3.datsrc_1, "raster map %s", input);
@@ -464,13 +465,13 @@
 		    return -1;
-		G_write_colors(params->tcurv, maps, &colors);
+		Rast_write_colors(params->tcurv, maps, &colors);
 					dat1, dat2, (CELL) (dat1 * MULT),
 		type = "raster";
 			    params->elev);
@@ -478,7 +479,7 @@
 		sprintf(hist4.datsrc_1, "raster map %s", input);
@@ -488,14 +489,14 @@
 		    return -1;
-		G_write_colors(params->mcurv, maps, &colors);
+		Rast_write_colors(params->mcurv, maps, &colors);
 					dat1, dat2,
 		type = "raster";
 			    params->elev);
@@ -503,7 +504,7 @@
 		sprintf(hist5.datsrc_1, "raster map %s", input);
@@ -514,7 +515,7 @@
 	    fprintf(stderr, "file [%s] not found \n", params->elev);
 	    return -1;
-	G_short_history(params->elev, "raster", &hist);
+	Rast_short_history(params->elev, "raster", &hist);
 	if (smooth != NULL)
 	    sprintf(hist.edhist[0], "tension=%f, smoothing=%s",
@@ -532,7 +533,7 @@
 	hist.edlinecnt = 5;
     /* change region to initial region */
Modified: grass/trunk/lib/rst/interp_float/ressegm2d.c
--- grass/trunk/lib/rst/interp_float/ressegm2d.c	2009-06-20 21:39:23 UTC (rev 38002)
+++ grass/trunk/lib/rst/interp_float/ressegm2d.c	2009-06-20 22:03:23 UTC (rev 38003)
@@ -21,7 +21,9 @@
 #include <stdio.h>
 #include <stdlib.h>
 #include <math.h>
 #include <grass/gmath.h>
@@ -168,7 +170,7 @@
 						0, params->KMAX2);
 	m1 = 0;
 	for (k = 1; k <= p_size; k++) {
-	    if (!G_is_f_null_value(&(in_points[k - 1].z))) {
+	    if (!Rast_is_f_null_value(&(in_points[k - 1].z))) {
 		data->points[m1].x = in_points[k - 1].x / (*dnorm);
 		data->points[m1].y = in_points[k - 1].y / (*dnorm);
 		/*        data->points[m1].z = (double) (in_points[k - 1].z) / (*dnorm); */
@@ -316,7 +318,7 @@
 	    for (k = 0; k <= last_row - first_row; k++) {
 		for (l = first_col - 1; l < last_col; l++) {
 		    index = k * inp_cols + l;
-		    if (!G_is_f_null_value(&(in_points[index].z))) {
+		    if (!Rast_is_f_null_value(&(in_points[index].z))) {
 			/* if the point is inside the segment (not overlapping) */
 			if ((in_points[index].x - x_or >= 0) &&
 			    (in_points[index].y - y_or >= 0) &&
@@ -491,19 +493,19 @@
     double x, y, sm;		/* input data and smoothing */
     int m1, m2;			/* loop counters */
-    int ret_val, ret_val1;	/* return values of G_get_map_row */
+    int ret_val, ret_val1;	/* return values of Rast_get_map_row */
     static FCELL *cellinp = NULL;	/* cell buffer for input data */
     static FCELL *cellsmooth = NULL;	/* cell buffer for smoothing */
     if (!cellinp)
-	cellinp = G_allocate_f_raster_buf();
+	cellinp = Rast_allocate_f_raster_buf();
     if (!cellsmooth)
-	cellsmooth = G_allocate_f_raster_buf();
+	cellsmooth = Rast_allocate_f_raster_buf();
     for (m1 = 0; m1 <= last_row - first_row; m1++) {
 	ret_val =
-	    G_get_f_raster_row(fdinp, cellinp, inp_rows - m1 - first_row);
+	    Rast_get_f_raster_row(fdinp, cellinp, inp_rows - m1 - first_row);
 	if (ret_val < 0) {
 	    fprintf(stderr, "Cannot get row %d (return value = %d)\n", m1,
 		    ret_val);
@@ -511,7 +513,7 @@
 	if (fdsmooth >= 0) {
 	    ret_val1 =
-		G_get_f_raster_row(fdsmooth, cellsmooth,
+		Rast_get_f_raster_row(fdsmooth, cellsmooth,
 	    if (ret_val1 < 0) {
 		fprintf(stderr, "Cannot get smoothing row\n");
@@ -530,12 +532,12 @@
 	    points[m1 * inp_cols + m2].x = x - params->x_orig;
 	    points[m1 * inp_cols + m2].y = y - params->y_orig;
-	    if (!G_is_f_null_value(cellinp + m2)) {
+	    if (!Rast_is_f_null_value(cellinp + m2)) {
 		points[m1 * inp_cols + m2].z =
 		    cellinp[m2] * params->zmult - zmin;
 	    else {
-		G_set_f_null_value(&(points[m1 * inp_cols + m2].z), 1);
+		Rast_set_f_null_value(&(points[m1 * inp_cols + m2].z), 1);
 	    /*              fprintf (stdout,"sm: %f\n",sm); */
@@ -585,17 +587,17 @@
 	     * params->az[l] = 0.;
 	    if (cond1) {
 		 * params->adx[l] = (FCELL)0.; params->ady[l] = (FCELL)0.;
 		if (cond2) {
 		     * params->adxx[l] = (FCELL)0.; params->adyy[l] = (FCELL)0.;
 		     * params->adxy[l] = (FCELL)0.;
Modified: grass/trunk/lib/stats/c_ave.c
--- grass/trunk/lib/stats/c_ave.c	2009-06-20 21:39:23 UTC (rev 38002)
+++ grass/trunk/lib/stats/c_ave.c	2009-06-20 22:03:23 UTC (rev 38003)
@@ -1,4 +1,5 @@
 void c_ave(DCELL * result, DCELL * values, int n, const void *closure)
@@ -10,7 +11,7 @@
     count = 0;
     for (i = 0; i < n; i++) {
-	if (G_is_d_null_value(&values[i]))
+	if (Rast_is_d_null_value(&values[i]))
 	    continue;
 	sum += values[i];
@@ -18,7 +19,7 @@
     if (count == 0)
-	G_set_d_null_value(result, 1);
+	Rast_set_d_null_value(result, 1);
     else
 	*result = sum / count;
@@ -33,7 +34,7 @@
     count = 0.0;
-	if (G_is_d_null_value(&values[i][0]))
+	if (Rast_is_d_null_value(&values[i][0]))
 	    continue;
 	sum += values[i][0] * values[i][1];
@@ -41,7 +42,7 @@
     if (count == 0)
     else
Modified: grass/trunk/lib/stats/c_count.c
--- grass/trunk/lib/stats/c_count.c	2009-06-20 21:39:23 UTC (rev 38002)
+++ grass/trunk/lib/stats/c_count.c	2009-06-20 22:03:23 UTC (rev 38003)
@@ -1,4 +1,5 @@
 void c_count(DCELL * result, DCELL * values, int n, const void *closure)
@@ -8,7 +9,7 @@
     count = 0;
-	if (!G_is_d_null_value(&values[i]))
+	if (!Rast_is_d_null_value(&values[i]))
 	    count++;
     *result = count;
@@ -22,7 +23,7 @@
     count = 0.0;
-	if (!G_is_d_null_value(&values[i][0]))
+	if (!Rast_is_d_null_value(&values[i][0]))
 	    count += values[i][1];
     *result = count;
Modified: grass/trunk/lib/stats/c_intr.c
--- grass/trunk/lib/stats/c_intr.c	2009-06-20 21:39:23 UTC (rev 38002)
+++ grass/trunk/lib/stats/c_intr.c	2009-06-20 22:03:23 UTC (rev 38003)
@@ -1,4 +1,5 @@
 #include <grass/stats.h>
 void c_intr(DCELL * result, DCELL * values, int n, const void *closure)
@@ -8,8 +9,8 @@
     int diff;
     int i;
-    if (G_is_d_null_value(&values[n / 2])) {
+    if (Rast_is_d_null_value(&values[n / 2])) {
 	return;
@@ -18,7 +19,7 @@
     diff = 0;
 	    continue;
 	count++;
Modified: grass/trunk/lib/stats/c_kurt.c
--- grass/trunk/lib/stats/c_kurt.c	2009-06-20 21:39:23 UTC (rev 38002)
+++ grass/trunk/lib/stats/c_kurt.c	2009-06-20 22:03:23 UTC (rev 38003)
@@ -1,4 +1,5 @@
 void c_kurt(DCELL * result, DCELL * values, int n, const void *closure)
@@ -10,7 +11,7 @@
     count = 0;
 	    continue;
 	sum += values[i];
@@ -18,7 +19,7 @@
     if (count == 0) {
 	return;
@@ -29,7 +30,7 @@
 	DCELL d;
 	    continue;
 	d = values[i] - ave;
@@ -52,7 +53,7 @@
     count = 0;
 	    continue;
@@ -60,7 +61,7 @@
     if (count == 0) {
 	return;
@@ -71,7 +72,7 @@
 	DCELL d;
 	    continue;
 	d = values[i][0] - ave;
Modified: grass/trunk/lib/stats/c_max.c
--- grass/trunk/lib/stats/c_max.c	2009-06-20 21:39:23 UTC (rev 38002)
+++ grass/trunk/lib/stats/c_max.c	2009-06-20 22:03:23 UTC (rev 38003)
@@ -1,22 +1,23 @@
 void c_max(DCELL * result, DCELL * values, int n, const void *closure)
     DCELL max;
     int i;
-    G_set_d_null_value(&max, 1);
+    Rast_set_d_null_value(&max, 1);
 	    continue;
-	if (G_is_d_null_value(&max) || max < values[i])
+	if (Rast_is_d_null_value(&max) || max < values[i])
 	    max = values[i];
-    if (G_is_d_null_value(&max))
+    if (Rast_is_d_null_value(&max))
     else
 	*result = max;
@@ -26,18 +27,18 @@
     DCELL max;
     int i;
 	    continue;
-	if (G_is_d_null_value(&max) || max < values[i][0])
+	if (Rast_is_d_null_value(&max) || max < values[i][0])
 	    max = values[i][0];
     else
 	*result = max;
Modified: grass/trunk/lib/stats/c_maxx.c
--- grass/trunk/lib/stats/c_maxx.c	2009-06-20 21:39:23 UTC (rev 38002)
+++ grass/trunk/lib/stats/c_maxx.c	2009-06-20 22:03:23 UTC (rev 38003)
@@ -1,25 +1,26 @@
 void c_maxx(DCELL * result, DCELL * values, int n, const void *closure)
     DCELL max, maxx;
     int i;
-    G_set_d_null_value(&maxx, 1);
+    Rast_set_d_null_value(&maxx, 1);
 	    continue;
-	if (G_is_d_null_value(&max) || max < values[i]) {
+	if (Rast_is_d_null_value(&max) || max < values[i]) {
 	    max = values[i];
 	    maxx = i;
-    if (G_is_d_null_value(&maxx))
+    if (Rast_is_d_null_value(&maxx))
     else
 	*result = maxx;
Modified: grass/trunk/lib/stats/c_median.c
--- grass/trunk/lib/stats/c_median.c	2009-06-20 21:39:23 UTC (rev 38002)
+++ grass/trunk/lib/stats/c_median.c	2009-06-20 22:03:23 UTC (rev 38003)
@@ -1,4 +1,5 @@
 void c_median(DCELL * result, DCELL * values, int n, const void *closure)
@@ -6,7 +7,7 @@
     n = sort_cell(values, n);
     if (n < 1)
     else
 	*result = (values[(n - 1) / 2] + values[n / 2]) / 2;
@@ -20,7 +21,7 @@
     n = sort_cell_w(values, n);
     if (n < 1) {
 	return;
Modified: grass/trunk/lib/stats/c_min.c
--- grass/trunk/lib/stats/c_min.c	2009-06-20 21:39:23 UTC (rev 38002)
+++ grass/trunk/lib/stats/c_min.c	2009-06-20 22:03:23 UTC (rev 38003)
@@ -1,22 +1,23 @@
 void c_min(DCELL * result, DCELL * values, int n, const void *closure)
     DCELL min;
     int i;
-    G_set_d_null_value(&min, 1);
+    Rast_set_d_null_value(&min, 1);
 	    continue;
-	if (G_is_d_null_value(&min) || min > values[i])
+	if (Rast_is_d_null_value(&min) || min > values[i])
 	    min = values[i];
-    if (G_is_d_null_value(&min))
+    if (Rast_is_d_null_value(&min))
     else
 	*result = min;
@@ -26,18 +27,18 @@
     DCELL min;
     int i;
 	    continue;
-	if (G_is_d_null_value(&min) || min > values[i][0])
+	if (Rast_is_d_null_value(&min) || min > values[i][0])
 	    min = values[i][0];
     else
 	*result = min;
Modified: grass/trunk/lib/stats/c_minx.c
--- grass/trunk/lib/stats/c_minx.c	2009-06-20 21:39:23 UTC (rev 38002)
+++ grass/trunk/lib/stats/c_minx.c	2009-06-20 22:03:23 UTC (rev 38003)
@@ -1,26 +1,26 @@
 void c_minx(DCELL * result, DCELL * values, int n, const void *closure)
     DCELL min, minx;
     int i;
-    G_set_d_null_value(&minx, 1);
+    Rast_set_d_null_value(&minx, 1);
 	    continue;
-	if (G_is_d_null_value(&min) || min > values[i]) {
+	if (Rast_is_d_null_value(&min) || min > values[i]) {
 	    min = values[i];
 	    minx = i;
-    if (G_is_d_null_value(&minx))
+    if (Rast_is_d_null_value(&minx))
     else
 	*result = minx;
Modified: grass/trunk/lib/stats/c_mode.c
--- grass/trunk/lib/stats/c_mode.c	2009-06-20 21:39:23 UTC (rev 38002)
+++ grass/trunk/lib/stats/c_mode.c	2009-06-20 22:03:23 UTC (rev 38003)
@@ -1,4 +1,5 @@
 void c_mode(DCELL * result, DCELL * values, int n, const void *closure)
@@ -29,7 +30,7 @@
     if (max == 0)
     else
 	*result = mode;
@@ -62,7 +63,7 @@
     if (max == 0.0)
     else
 	*result = mode;
Modified: grass/trunk/lib/stats/c_percentile.c
--- grass/trunk/lib/stats/c_percentile.c	2009-06-20 21:39:23 UTC (rev 38002)
+++ grass/trunk/lib/stats/c_percentile.c	2009-06-20 22:03:23 UTC (rev 38003)
@@ -1,5 +1,7 @@
 #include <math.h>
 void c_quant(DCELL * result, DCELL * values, int n, const void *closure)
@@ -11,7 +13,7 @@
     if (n < 1) {
 	return;
@@ -52,7 +54,7 @@
     if (n < 1) {
 	return;
Modified: grass/trunk/lib/stats/c_range.c
--- grass/trunk/lib/stats/c_range.c	2009-06-20 21:39:23 UTC (rev 38002)
+++ grass/trunk/lib/stats/c_range.c	2009-06-20 22:03:23 UTC (rev 38003)
@@ -1,26 +1,27 @@
 void c_range(DCELL * result, DCELL * values, int n, const void *closure)
     DCELL min, max;
     int i;
 	    continue;
 	    min = values[i];
 	    max = values[i];
-    if (G_is_d_null_value(&min) || G_is_d_null_value(&max))
+    if (Rast_is_d_null_value(&min) || Rast_is_d_null_value(&max))
     else
 	*result = max - min;
Modified: grass/trunk/lib/stats/c_reg.c
--- grass/trunk/lib/stats/c_reg.c	2009-06-20 21:39:23 UTC (rev 38002)
+++ grass/trunk/lib/stats/c_reg.c	2009-06-20 22:03:23 UTC (rev 38003)
@@ -1,4 +1,5 @@
 #define REGRESSION_SLOPE	0
 #define REGRESSION_OFFSET	1
@@ -16,7 +17,7 @@
     count = 0;
 	    continue;
 	xsum += i;
@@ -25,7 +26,7 @@
     if (count < 2) {
 	return;
@@ -34,13 +35,13 @@
     numer = 0.0;
 	    numer += i * values[i];
     numer -= count * xbar * ybar;
     denom = 0.0;
 	    denom += (DCELL) i *i;
     denom -= count * xbar * xbar;
@@ -48,7 +49,7 @@
     if (which == REGRESSION_COEFF_DET) {
 	denom2 = 0.0;
 		denom2 += values[i] * values[i];
 	denom2 -= count * ybar * ybar;
@@ -64,13 +65,13 @@
 	*result = (numer * numer) / (denom * denom2);
 	break;
     default:
 	break;
     /* Check for NaN */
     if (*result != *result)
 void c_reg_m(DCELL * result, DCELL * values, int n, const void *closure)
@@ -100,7 +101,7 @@
     count = 0;
 	    continue;
 	xsum += i * values[i][1];
@@ -109,7 +110,7 @@
     if (count < 2) {
 	return;
@@ -118,13 +119,13 @@
     numer = 0.0;
 	    numer += i * values[i][0] * values[i][1];
     denom = 0.0;
 	    denom += (DCELL) i *i * values[i][1];
@@ -132,7 +133,7 @@
 	denom2 = 0.0;
 		denom2 += values[i][0] * values[i][0] * values[i][1];
@@ -148,13 +149,13 @@
 	break;
     default:
 	break;
     /* Check for NaN */
 void w_reg_m(DCELL * result, DCELL(*values)[2], int n, const void *closure)
Modified: grass/trunk/lib/stats/c_skew.c
--- grass/trunk/lib/stats/c_skew.c	2009-06-20 21:39:23 UTC (rev 38002)
+++ grass/trunk/lib/stats/c_skew.c	2009-06-20 22:03:23 UTC (rev 38003)
@@ -1,5 +1,7 @@
 #include <math.h>
 void c_skew(DCELL * result, DCELL * values, int n, const void *closure)
@@ -11,7 +13,7 @@
     count = 0;
 	    continue;
 	sum += values[i];
@@ -19,7 +21,7 @@
     if (count == 0) {
 	return;
@@ -30,7 +32,7 @@
 	DCELL d;
 	    continue;
@@ -53,7 +55,7 @@
     count = 0;
 	    continue;
@@ -61,7 +63,7 @@
     if (count == 0) {
 	return;
@@ -72,7 +74,7 @@
 	DCELL d;
 	    continue;
Modified: grass/trunk/lib/stats/c_stddev.c
--- grass/trunk/lib/stats/c_stddev.c	2009-06-20 21:39:23 UTC (rev 38002)
+++ grass/trunk/lib/stats/c_stddev.c	2009-06-20 22:03:23 UTC (rev 38003)
@@ -1,5 +1,7 @@
 #include <math.h>
 void c_stddev(DCELL * result, DCELL * values, int n, const void *closure)
@@ -8,8 +10,8 @@
     c_var(&var, values, n, closure);
-    if (G_is_d_null_value(&var))
+    if (Rast_is_d_null_value(&var))
     else
 	*result = sqrt(var);
@@ -20,8 +22,8 @@
     w_var(&var, values, n, closure);
     else
Modified: grass/trunk/lib/stats/c_sum.c
--- grass/trunk/lib/stats/c_sum.c	2009-06-20 21:39:23 UTC (rev 38002)
+++ grass/trunk/lib/stats/c_sum.c	2009-06-20 22:03:23 UTC (rev 38003)
@@ -1,4 +1,5 @@
+#include <grass/Rast.h>
 void c_sum(DCELL * result, DCELL * values, int n, const void *closure)
@@ -10,7 +11,7 @@
     count = 0;
 	    continue;
 	sum += values[i];
@@ -18,7 +19,7 @@
     if (count == 0)
     else
 	*result = sum;
@@ -33,7 +34,7 @@
     count = 0.0;
 	    continue;
@@ -41,7 +42,7 @@
     if (count == 0)
     else
 	*result = sum;
Modified: grass/trunk/lib/stats/c_var.c
--- grass/trunk/lib/stats/c_var.c	2009-06-20 21:39:23 UTC (rev 38002)
+++ grass/trunk/lib/stats/c_var.c	2009-06-20 22:03:23 UTC (rev 38003)
@@ -1,4 +1,5 @@
 void c_var(DCELL * result, DCELL * values, int n, const void *closure)
@@ -10,7 +11,7 @@
     count = 0;
 	    continue;
 	sum += values[i];
@@ -18,7 +19,7 @@
     if (count == 0) {
 	return;
@@ -29,7 +30,7 @@
 	DCELL d;
 	    continue;
@@ -49,7 +50,7 @@
     count = 0;
 	    continue;
@@ -57,7 +58,7 @@
     if (count == 0) {
 	return;
@@ -68,7 +69,7 @@
 	DCELL d;
 	    continue;
Modified: grass/trunk/lib/stats/sort_cell.c
--- grass/trunk/lib/stats/sort_cell.c	2009-06-20 21:39:23 UTC (rev 38002)
+++ grass/trunk/lib/stats/sort_cell.c	2009-06-20 22:03:23 UTC (rev 38003)
@@ -1,18 +1,20 @@
 #include <stdlib.h>
 static int ascending(const void *aa, const void *bb)
     const DCELL *a = aa, *b = bb;
-    if (G_is_d_null_value((DCELL *) a) && G_is_d_null_value((DCELL *) b))
+    if (Rast_is_d_null_value((DCELL *) a) && Rast_is_d_null_value((DCELL *) b))
 	return 0;
-    if (G_is_d_null_value((DCELL *) a))
+    if (Rast_is_d_null_value((DCELL *) a))
 	return 1;
-    if (G_is_d_null_value((DCELL *) b))
+    if (Rast_is_d_null_value((DCELL *) b))
 	return -1;
     return (*a < *b) ? -1 : (*a > *b) ? 1 : 0;
@@ -25,7 +27,7 @@
     qsort(array, n, sizeof(DCELL), ascending);
-	if (G_is_d_null_value(&array[i]))
+	if (Rast_is_d_null_value(&array[i]))
 	    break;
     return i;
@@ -38,7 +40,7 @@
     qsort(array, n, 2 * sizeof(DCELL), ascending);
-	if (G_is_d_null_value(&array[i][0]))
+	if (Rast_is_d_null_value(&array[i][0]))
 	    break;
     return i;
Modified: grass/trunk/ps/ps.map/catval.c
--- grass/trunk/ps/ps.map/catval.c	2009-06-20 21:39:23 UTC (rev 38002)
+++ grass/trunk/ps/ps.map/catval.c	2009-06-20 22:03:23 UTC (rev 38003)
@@ -16,6 +16,7 @@
 #include <grass/Vect.h>
 #include <grass/dbmi.h>
Modified: grass/trunk/ps/ps.map/distance.c
--- grass/trunk/ps/ps.map/distance.c	2009-06-20 21:39:23 UTC (rev 38002)
+++ grass/trunk/ps/ps.map/distance.c	2009-06-20 22:03:23 UTC (rev 38003)
@@ -1,4 +1,5 @@
 double distance(double east, double west)
Modified: grass/trunk/ps/ps.map/do_geogrid.c
--- grass/trunk/ps/ps.map/do_geogrid.c	2009-06-20 21:39:23 UTC (rev 38002)
+++ grass/trunk/ps/ps.map/do_geogrid.c	2009-06-20 22:03:23 UTC (rev 38003)
@@ -8,6 +8,7 @@
 #include <string.h>
 #include <math.h>
 #include <grass/gprojects.h>
Modified: grass/trunk/ps/ps.map/do_header.c
--- grass/trunk/ps/ps.map/do_header.c	2009-06-20 21:39:23 UTC (rev 38002)
+++ grass/trunk/ps/ps.map/do_header.c	2009-06-20 22:03:23 UTC (rev 38003)
@@ -129,7 +129,7 @@
 		    apply(G_whoami(), fmt, text);
 		    break;
 		case 'x':
-		    apply(G_mask_info(), fmt, text);
+		    apply(Rast_mask_info(), fmt, text);
 		    break;
 		case 0:
 		    continue;
Modified: grass/trunk/ps/ps.map/do_labels.c
--- grass/trunk/ps/ps.map/do_labels.c	2009-06-20 21:39:23 UTC (rev 38002)
+++ grass/trunk/ps/ps.map/do_labels.c	2009-06-20 22:03:23 UTC (rev 38003)
@@ -238,7 +238,7 @@
 	if (FIELD("color")) {
-	    ret = G_str_to_color(value, &r, &g, &b);
+	    ret = Rast_str_to_color(value, &r, &g, &b);
 	    if (ret == 1)
 		set_color(&color, r, g, b);
 	    else
@@ -248,7 +248,7 @@
 	if (FIELD("hcolor")) {
 	    if (ret == 1)
 		set_color(&hcolor, r, g, b);
 	    else if (ret == 2)
@@ -279,7 +279,7 @@
 	       if(strncmp(value, "none", 4)==0) opaque = 0;
 	    if (ret == 1)
 		set_color(&background, r, g, b);
 	    else if (ret == 2)
@@ -289,7 +289,7 @@
 	if (FIELD("border")) {
 	    if (ret == 1)
 		set_color(&border, r, g, b);
 	    else if (ret == 2)
Modified: grass/trunk/ps/ps.map/do_masking.c
--- grass/trunk/ps/ps.map/do_masking.c	2009-06-20 21:39:23 UTC (rev 38002)
+++ grass/trunk/ps/ps.map/do_masking.c	2009-06-20 22:03:23 UTC (rev 38003)
@@ -6,6 +6,7 @@
 #include <stdlib.h>
 #include <unistd.h>
 #include "ps_info.h"
Modified: grass/trunk/ps/ps.map/do_plt.c
--- grass/trunk/ps/ps.map/do_plt.c	2009-06-20 21:39:23 UTC (rev 38002)
+++ grass/trunk/ps/ps.map/do_plt.c	2009-06-20 22:03:23 UTC (rev 38003)
@@ -5,6 +5,7 @@
 #include <string.h>
 #include <grass/symbol.h>
 #include "clr.h"
Modified: grass/trunk/ps/ps.map/do_psfiles.c
--- grass/trunk/ps/ps.map/do_psfiles.c	2009-06-20 21:39:23 UTC (rev 38002)
+++ grass/trunk/ps/ps.map/do_psfiles.c	2009-06-20 22:03:23 UTC (rev 38003)
@@ -4,6 +4,7 @@
Modified: grass/trunk/ps/ps.map/do_vectors.c
--- grass/trunk/ps/ps.map/do_vectors.c	2009-06-20 21:39:23 UTC (rev 38002)
+++ grass/trunk/ps/ps.map/do_vectors.c	2009-06-20 22:03:23 UTC (rev 38003)
@@ -8,6 +8,7 @@
 #include <string.h>
Modified: grass/trunk/ps/ps.map/error.c
--- grass/trunk/ps/ps.map/error.c	2009-06-20 21:39:23 UTC (rev 38002)
+++ grass/trunk/ps/ps.map/error.c	2009-06-20 22:03:23 UTC (rev 38003)
@@ -1,6 +1,7 @@
 #include <stdio.h>
 #include <unistd.h>
 #include "local_proto.h"
 extern FILE *tracefd;
Modified: grass/trunk/ps/ps.map/get_font.c
--- grass/trunk/ps/ps.map/get_font.c	2009-06-20 21:39:23 UTC (rev 38002)
+++ grass/trunk/ps/ps.map/get_font.c	2009-06-20 22:03:23 UTC (rev 38003)
@@ -4,6 +4,7 @@
 int get_font(char *data)
Modified: grass/trunk/ps/ps.map/input.c
--- grass/trunk/ps/ps.map/input.c	2009-06-20 21:39:23 UTC (rev 38002)
+++ grass/trunk/ps/ps.map/input.c	2009-06-20 22:03:23 UTC (rev 38003)
@@ -3,6 +3,7 @@
 #include <unistd.h>
 #include <string.h>
Modified: grass/trunk/ps/ps.map/main.c
--- grass/trunk/ps/ps.map/main.c	2009-06-20 21:39:23 UTC (rev 38002)
+++ grass/trunk/ps/ps.map/main.c	2009-06-20 22:03:23 UTC (rev 38003)
@@ -24,6 +24,7 @@
 #include <signal.h>
 #include <errno.h>
 #include "map_info.h"
@@ -408,11 +409,11 @@
 		b = 255.0 * B;
 		if (strncmp(catsbuf, "null", 4) == 0) {
-		    G_set_null_value_color(r, g, b, &PS.colors);
+		    Rast_set_null_value_color(r, g, b, &PS.colors);
 		    continue;
 		if (strncmp(catsbuf, "default", 7) == 0) {
-		    G_set_default_color(r, g, b, &PS.colors);
+		    Rast_set_default_color(r, g, b, &PS.colors);
 		    continue;
 		if ((count = parse_val_list(catsbuf, &val_list)) < 0) {
@@ -422,7 +423,7 @@
 		for (i = 0; i < count; i += 2) {
 		    dmin = val_list[i];
 		    dmax = val_list[i + 1];
-		    G_add_d_raster_color_rule(&dmin, r, g, b, &dmax, r, g, b,
+		    Rast_add_d_raster_color_rule(&dmin, r, g, b, &dmax, r, g, b,
 					      &PS.colors);
 		G_free(val_list);
@@ -709,7 +710,7 @@
 	if (KEY("maskcolor")) {
 	    int ret, r, g, b;
-	    ret = G_str_to_color(data, &r, &g, &b);
+	    ret = Rast_str_to_color(data, &r, &g, &b);
 	    if (ret == 1) {
 		PS.mask_r = r / 255.0;
 		PS.mask_g = g / 255.0;
Modified: grass/trunk/ps/ps.map/makeprocs.c
--- grass/trunk/ps/ps.map/makeprocs.c	2009-06-20 21:39:23 UTC (rev 38002)
+++ grass/trunk/ps/ps.map/makeprocs.c	2009-06-20 22:03:23 UTC (rev 38003)
@@ -6,6 +6,7 @@
Modified: grass/trunk/ps/ps.map/map_setup.c
--- grass/trunk/ps/ps.map/map_setup.c	2009-06-20 21:39:23 UTC (rev 38002)
+++ grass/trunk/ps/ps.map/map_setup.c	2009-06-20 22:03:23 UTC (rev 38003)
@@ -4,6 +4,7 @@
 #include "group.h"
Modified: grass/trunk/ps/ps.map/outl_io.c
--- grass/trunk/ps/ps.map/outl_io.c	2009-06-20 21:39:23 UTC (rev 38002)
+++ grass/trunk/ps/ps.map/outl_io.c	2009-06-20 22:03:23 UTC (rev 38003)
@@ -1,5 +1,6 @@
 #include <stdlib.h>
@@ -40,13 +41,13 @@
 	    blank_line(buf);
 	else {
-	    G_set_null_value(ptr, 1, map_type);
-	    ptr = G_incr_void_ptr(ptr, raster_size);
+	    Rast_set_null_value(ptr, 1, map_type);
+	    ptr = Rast_incr_void_ptr(ptr, raster_size);
-	    G_get_raster_row(in_file_d, ptr, row_count++, map_type);
+	    Rast_get_raster_row(in_file_d, ptr, row_count++, map_type);
-	    ptr = G_incr_void_ptr(ptr, raster_size * (row_length + 1));
+	    ptr = Rast_incr_void_ptr(ptr, raster_size * (row_length + 1));
     return (row_length + 2);
@@ -54,7 +55,7 @@
 static int blank_line(void *buf)
-    G_set_null_value(buf, row_length + 2, map_type);
+    Rast_set_null_value(buf, row_length + 2, map_type);
     return 0;
@@ -63,11 +64,11 @@
     /* open raster map */
     sscanf(cell, "%s", cell_name);
-    if ((in_file_d = G_open_cell_old(cell_name, "")) < 0)
+    if ((in_file_d = Rast_open_cell_old(cell_name, "")) < 0)
 	G_fatal_error(_("Unable to open raster map <%s>"), cell_name);
-    map_type = G_get_raster_map_type(in_file_d);
-    raster_size = G_raster_size(map_type);
+    map_type = Rast_get_raster_map_type(in_file_d);
+    raster_size = Rast_raster_size(map_type);
     first_read = 1;
     last_read = 0;
     row_count = 0;
@@ -77,7 +78,7 @@
 int o_close_file(void)
-    G_close_cell(in_file_d);
+    Rast_close_cell(in_file_d);
     return 0;
Modified: grass/trunk/ps/ps.map/parse_list.c
--- grass/trunk/ps/ps.map/parse_list.c	2009-06-20 21:39:23 UTC (rev 38002)
+++ grass/trunk/ps/ps.map/parse_list.c	2009-06-20 22:03:23 UTC (rev 38003)
@@ -20,6 +20,7 @@
  * count will be negative if list is not valid
 int parse_val_list(char *buf, DCELL ** list)
Modified: grass/trunk/ps/ps.map/ps_clrtbl.c
--- grass/trunk/ps/ps.map/ps_clrtbl.c	2009-06-20 21:39:23 UTC (rev 38002)
+++ grass/trunk/ps/ps.map/ps_clrtbl.c	2009-06-20 22:03:23 UTC (rev 38003)
@@ -30,18 +30,18 @@
     G_message(_("Creating color table for <%s in %s>..."),
 	      ct.name, ct.mapset);
-    if (G_read_cats(ct.name, ct.mapset, &PS.cats) == -1) {
+    if (Rast_read_cats(ct.name, ct.mapset, &PS.cats) == -1) {
 	G_warning(_("Category file for <%s> not available"), ct.name);
 	return 1;
-    if (G_read_colors(ct.name, ct.mapset, &colors) == -1)
+    if (Rast_read_colors(ct.name, ct.mapset, &colors) == -1)
 	G_warning(_("Unable to read colors for colorbar"));
     do_color = (PS.grey == 0 && PS.level == 2);
     /* How many categories to show */
-    num_cats = G_number_of_raster_cats(&PS.cats);
+    num_cats = Rast_number_of_raster_cats(&PS.cats);
     G_debug(3, "clrtbl: %d categories", num_cats);
     if (!num_cats) {
 	G_warning(_("Your cats/ file is invalid. A cats/ file with categories "
@@ -88,7 +88,7 @@
 	    fprintf(PS.fp, "(%s)\n", "no data");
 	else
-		    G_get_ith_d_raster_cat(&PS.cats, i - 1, &dmin, &dmax));
+		    Rast_get_ith_d_raster_cat(&PS.cats, i - 1, &dmin, &dmax));
     fprintf(PS.fp, "] def\n");
@@ -135,7 +135,7 @@
 	    /* fill box and outline in black */
 	    if (i)
-		label = G_get_ith_d_raster_cat(&PS.cats, i - 1, &dmin, &dmax);
+		label = Rast_get_ith_d_raster_cat(&PS.cats, i - 1, &dmin, &dmax);
 	    x1 = l + (double)j *72.0 * col_width;
@@ -146,9 +146,9 @@
 		/* set box fill color */
 		if (!i)
-		    G_get_null_value_color(&R, &G, &B, &colors);
+		    Rast_get_null_value_color(&R, &G, &B, &colors);
 		else
-		    G_get_d_raster_color(&dmin, &R, &G, &B, &colors);
+		    Rast_get_d_raster_color(&dmin, &R, &G, &B, &colors);
 		if (do_color)
 		    fprintf(PS.fp, "%.3f %.3f %.3f C\n",
@@ -179,7 +179,7 @@
 		    val = dmin + (double)jj *(dmax - dmin) / NSTEPS;
-		    G_get_d_raster_color(&val, &R, &G, &B, &colors);
+		    Rast_get_d_raster_color(&val, &R, &G, &B, &colors);
 			    (double)R / 255., (double)G / 255.,
 			    (double)B / 255.);
@@ -222,7 +222,7 @@
     if (PS.min_y > y)
 	PS.min_y = y;
-    G_free_colors(&colors);
+    Rast_free_colors(&colors);
     return 0;
Modified: grass/trunk/ps/ps.map/ps_fclrtbl.c
--- grass/trunk/ps/ps.map/ps_fclrtbl.c	2009-06-20 21:39:23 UTC (rev 38002)
+++ grass/trunk/ps/ps.map/ps_fclrtbl.c	2009-06-20 22:03:23 UTC (rev 38003)
@@ -47,12 +47,12 @@
     /* Get color range */
-    if (G_read_fp_range(ct.name, ct.mapset, &range) == -1) {
+    if (Rast_read_fp_range(ct.name, ct.mapset, &range) == -1) {
 	G_warning(_("Range information not available (run r.support)"));
 	return 1;
-    G_get_fp_range_min_max(&range, &dmin, &dmax);
+    Rast_get_fp_range_min_max(&range, &dmin, &dmax);
     /* override if range command is set */
     if (ct.range_override) {
@@ -65,7 +65,7 @@
 	return 1;
@@ -132,7 +132,7 @@
     for (i = 0; i < ncols; i++) {
 	/*      val = dmin + i * step;   flip */
 	val = dmax - i * step;
 	if (do_color)
 	    fprintf(PS.fp, "%.3f %.3f %.3f C\n", (double)R / 255.,
@@ -248,7 +248,7 @@
     /* print units label, if present */
-    if (G_read_raster_units(ct.name, ct.mapset, units) != 0)
+    if (Rast_read_raster_units(ct.name, ct.mapset, units) != 0)
         units[0] = '\0';
     if(strlen(units)) {
@@ -322,7 +322,7 @@
 	fprintf(PS.fp, "TIB\n");
     return 0;
Modified: grass/trunk/ps/ps.map/ps_header.c
--- grass/trunk/ps/ps.map/ps_header.c	2009-06-20 21:39:23 UTC (rev 38002)
+++ grass/trunk/ps/ps.map/ps_header.c	2009-06-20 22:03:23 UTC (rev 38003)
@@ -6,6 +6,7 @@
 #include <stdio.h>
 #include <unistd.h>
 static long bb_offset;
@@ -18,7 +19,7 @@
     int cats_ok;
     if (PS.do_raster)
-	cats_ok = G_read_cats(PS.cell_name, PS.cell_mapset, &cats) >= 0;
+	cats_ok = Rast_read_cats(PS.cell_name, PS.cell_mapset, &cats) >= 0;
     /* write PostScript header */
     /*fprintf(PS.fp, "%%!PS-Adobe-2.0 EPSF-1.2\n"); */
Modified: grass/trunk/ps/ps.map/ps_info.h
--- grass/trunk/ps/ps.map/ps_info.h	2009-06-20 21:39:23 UTC (rev 38002)
+++ grass/trunk/ps/ps.map/ps_info.h	2009-06-20 22:03:23 UTC (rev 38003)
@@ -1,4 +1,5 @@
 #include <grass/gis.h>
 /* Font sizes */
 #define PS_FONT_MAX_SIZE      50
Modified: grass/trunk/ps/ps.map/ps_outline.c
--- grass/trunk/ps/ps.map/ps_outline.c	2009-06-20 21:39:23 UTC (rev 38002)
+++ grass/trunk/ps/ps.map/ps_outline.c	2009-06-20 22:03:23 UTC (rev 38003)
@@ -7,6 +7,7 @@
 #include <stdio.h>
 #include <string.h>
 #include <grass/glocale.h>
@@ -113,7 +114,7 @@
     bottom = 1;			/*   line from raster map */
     scan_length = read_next();
     k = 0;
     while (read_next()) {	/* read rest of file, one row at *//*   a time */
 	n1 = G_row_to_northing((double)row - 1., &(PS.w));
 	n2 = G_row_to_northing((double)row, &(PS.w));
@@ -123,13 +124,13 @@
 	    e1 = G_col_to_easting((double)col - 1., &(PS.w));
 	    e2 = G_col_to_easting((double)col, &(PS.w));
 	    e3 = G_col_to_easting((double)col + 1., &(PS.w));
-	    tl = G_incr_void_ptr(buffer[top], col * raster_size);
+	    tl = Rast_incr_void_ptr(buffer[top], col * raster_size);
 	    /* top left in window */
-	    tr = G_incr_void_ptr(buffer[top], (col + 1) * raster_size);
+	    tr = Rast_incr_void_ptr(buffer[top], (col + 1) * raster_size);
 	    /* top right in window */
-	    bl = G_incr_void_ptr(buffer[bottom], col * raster_size);
+	    bl = Rast_incr_void_ptr(buffer[bottom], col * raster_size);
 	    /* bottom left in window */
-	    br = G_incr_void_ptr(buffer[bottom], (col + 1) * raster_size);
+	    br = Rast_incr_void_ptr(buffer[bottom], (col + 1) * raster_size);
 	    /* bottom right in window */
 	    draw_boundaries();
 	    if (k == 3)
@@ -144,9 +145,9 @@
 static int draw_boundaries(void)
-    if (G_raster_cmp(bl, br, map_type) != 0)
+    if (Rast_raster_cmp(bl, br, map_type) != 0)
 	draw_bot();
-    if (G_raster_cmp(tr, br, map_type) != 0)
+    if (Rast_raster_cmp(tr, br, map_type) != 0)
 	draw_rite();
     return 0;
Modified: grass/trunk/ps/ps.map/ps_raster.c
--- grass/trunk/ps/ps.map/ps_raster.c	2009-06-20 21:39:23 UTC (rev 38002)
+++ grass/trunk/ps/ps.map/ps_raster.c	2009-06-20 22:03:23 UTC (rev 38003)
@@ -2,7 +2,7 @@
  ** Author: Paul W. Carlson     3/92
- ** ps_get_map_row is substituted by G_get_map_row_nomask
+ ** ps_get_map_row is substituted by Rast_get_map_row_nomask
  ** writing mask file is done separately by function ps_write_mask_row
  ** which used code previously in ps_get_map_row. This is done because
  ** sometimes the raster map is not drawn, but we still need a mask
@@ -12,6 +12,7 @@
 #include <stdlib.h>
 #include "group.h"
@@ -26,7 +27,7 @@
     CELL *maskbuf;
     int maskfd, r, g, b;
-    maskfd = G_maskfd();
+    maskfd = Rast_maskfd();
     if (maskfd < 0)
 	/* there is no mask */
@@ -35,7 +36,7 @@
 	return 0;
     if (maskfd >= 0)
-	maskbuf = G_allocate_cell_buf();
+	maskbuf = Rast_allocate_cell_buf();
     /* if masked, open a file to hold the PostScript mask data */
     if (maskfd >= 0 && PS.mask_needed) {
@@ -43,13 +44,13 @@
 	    G_fatal_error(_("Can't create temporary PostScript mask file."));
 	/* get no data rgb values for mask */
-	G_get_null_value_color(&r, &g, &b, &PS.colors);
+	Rast_get_null_value_color(&r, &g, &b, &PS.colors);
 	PS.r0 = (double)r / 255.0;
 	PS.g0 = (double)g / 255.0;
 	PS.b0 = (double)b / 255.0;
 	for (row = 0; row < PS.w.rows; row++) {
-	    G_get_map_row_nomask(maskfd, maskbuf, row);
+	    Rast_get_map_row_nomask(maskfd, maskbuf, row);
 	    ps_write_mask_row(maskbuf);
 	fclose(ps_mask_fp);
@@ -107,15 +108,15 @@
     /* build the image RGB string */
     if (PS.do_raster) {
-	map_type = G_get_raster_map_type(PS.cell_fd);
-	cellbuf = G_allocate_raster_buf(map_type);
+	map_type = Rast_get_raster_map_type(PS.cell_fd);
+	cellbuf = Rast_allocate_raster_buf(map_type);
 	n = 0;
-	    G_get_raster_row(PS.cell_fd, cellbuf, row, map_type);
+	    Rast_get_raster_row(PS.cell_fd, cellbuf, row, map_type);
 	    if ((row % PS.row_delta) == 0) {
 		ptr = cellbuf;
 		for (col = 0; col < PS.w.cols; col += PS.col_delta) {
-		    G_get_raster_color(ptr, &r, &g, &b, &PS.colors, map_type);
+		    Rast_get_raster_color(ptr, &r, &g, &b, &PS.colors, map_type);
 		    /* if color raster */
 		    if (doing_color) {
@@ -137,8 +138,8 @@
 		    ptr =
-			G_incr_void_ptr(ptr,
-					G_raster_size(map_type) *
+			Rast_incr_void_ptr(ptr,
+					Rast_raster_size(map_type) *
 					PS.col_delta);
@@ -148,20 +149,20 @@
 	void *cptr[3];
 	for (i = 0; i < 3; i++) {
-	    grp_map_type[i] = G_get_raster_map_type(grp.fd[i]);
-	    cbuf[i] = G_allocate_raster_buf(grp_map_type[i]);
+	    grp_map_type[i] = Rast_get_raster_map_type(grp.fd[i]);
+	    cbuf[i] = Rast_allocate_raster_buf(grp_map_type[i]);
 	n = 0;
-		G_get_raster_row(grp.fd[i], cbuf[i], row, grp_map_type[i]);
+		Rast_get_raster_row(grp.fd[i], cbuf[i], row, grp_map_type[i]);
 		cptr[i] = cbuf[i];
-			G_get_raster_color(cptr[i], &rr, &gg, &bb,
+			Rast_get_raster_color(cptr[i], &rr, &gg, &bb,
 					   &(grp.colors[i]), grp_map_type[i]);
 			if (i == 0)
 			    r = rr;
@@ -169,8 +170,8 @@
 			    g = gg;
 			if (i == 2)
 			    b = bb;
-			cptr[i] = G_incr_void_ptr(cptr[i],
-						  G_raster_size(grp_map_type
+			cptr[i] = Rast_incr_void_ptr(cptr[i],
+						  Rast_raster_size(grp_map_type
 								[0]) *
 						  PS.col_delta);
@@ -192,14 +193,14 @@
     /* we're done with the cell stuff */
     if (PS.do_raster) {
 	if (!PS.do_colortable)
-	    G_free_colors(&PS.colors);
-	G_close_cell(PS.cell_fd);
+	    Rast_free_colors(&PS.colors);
+	Rast_close_cell(PS.cell_fd);
 	G_free(cellbuf);
     else {
-	    G_free_colors(&(grp.colors[i]));
-	    G_close_cell(grp.fd[i]);
+	    Rast_free_colors(&(grp.colors[i]));
+	    Rast_close_cell(grp.fd[i]);
 	    G_free(cbuf[i]);
 	I_free_group_ref(&grp.ref);
Modified: grass/trunk/ps/ps.map/ps_vareas.c
--- grass/trunk/ps/ps.map/ps_vareas.c	2009-06-20 21:39:23 UTC (rev 38002)
+++ grass/trunk/ps/ps.map/ps_vareas.c	2009-06-20 22:03:23 UTC (rev 38003)
@@ -5,6 +5,7 @@
@@ -103,7 +104,7 @@
     else {
 	rgbstring = db_get_string(cv_rgb->val.s);
 	if (rgbstring == NULL ||
-	    G_str_to_color(rgbstring, &red, &grn, &blu) != 1) {
+	    Rast_str_to_color(rgbstring, &red, &grn, &blu) != 1) {
 	    G_warning(_("Invalid RGB color definition in column <%s> for category [%d]"),
 		      vector.layer[vec].rgbcol, cat);
 	    rgbstring = NULL;
Modified: grass/trunk/ps/ps.map/ps_vlines.c
--- grass/trunk/ps/ps.map/ps_vlines.c	2009-06-20 21:39:23 UTC (rev 38002)
+++ grass/trunk/ps/ps.map/ps_vlines.c	2009-06-20 22:03:23 UTC (rev 38003)
@@ -6,6 +6,7 @@
@@ -120,7 +121,7 @@
 	    else {
 		    rgbstring = NULL;
Modified: grass/trunk/ps/ps.map/ps_vpoints.c
--- grass/trunk/ps/ps.map/ps_vpoints.c	2009-06-20 21:39:23 UTC (rev 38002)
+++ grass/trunk/ps/ps.map/ps_vpoints.c	2009-06-20 22:03:23 UTC (rev 38003)
@@ -201,7 +201,7 @@
 	    else {
 		    rgbstring = NULL;
Modified: grass/trunk/ps/ps.map/r_border.c
--- grass/trunk/ps/ps.map/r_border.c	2009-06-20 21:39:23 UTC (rev 38002)
+++ grass/trunk/ps/ps.map/r_border.c	2009-06-20 22:03:23 UTC (rev 38003)
@@ -43,7 +43,7 @@
 	    continue;
 	if (KEY("color")) {
 	    if (ret == 1) {
 		color_R = r / 255.;
 		color_G = g / 255.;
Modified: grass/trunk/ps/ps.map/r_cell.c
--- grass/trunk/ps/ps.map/r_cell.c	2009-06-20 21:39:23 UTC (rev 38002)
+++ grass/trunk/ps/ps.map/r_cell.c	2009-06-20 22:03:23 UTC (rev 38003)
@@ -14,28 +14,28 @@
     PS.do_colortable = 0;
     if (PS.cell_fd >= 0) {
 	G_free(PS.cell_name);
 	PS.cell_fd = -1;
     sprintf(fullname, "%s in %s", name, mapset);
-    if (G_read_colors(name, mapset, &PS.colors) == -1) {
+    if (Rast_read_colors(name, mapset, &PS.colors) == -1) {
 	error(fullname, "", "can't read color table");
 	return 0;
-    G_get_color_range(&PS.min_color, &PS.max_color, &PS.colors);
+    Rast_get_color_range(&PS.min_color, &PS.max_color, &PS.colors);
     /* open raster map for reading */
-    if ((PS.cell_fd = G_open_cell_old(name, mapset)) < 0) {
+    if ((PS.cell_fd = Rast_open_cell_old(name, mapset)) < 0) {
 	error(fullname, "", "can't open raster map");
 	return 0;
-    strcpy(PS.celltitle, G_get_cell_title(name, mapset));
+    strcpy(PS.celltitle, Rast_get_cell_title(name, mapset));
     G_strip(PS.celltitle);
     if (PS.celltitle[0] == 0)
 	sprintf(PS.celltitle, "(%s)", name);
Modified: grass/trunk/ps/ps.map/r_colortable.c
--- grass/trunk/ps/ps.map/r_colortable.c	2009-06-20 21:39:23 UTC (rev 38002)
+++ grass/trunk/ps/ps.map/r_colortable.c	2009-06-20 22:03:23 UTC (rev 38003)
@@ -168,7 +168,7 @@
     /* set default if legend type was not specified */
     if (ct.discrete == -1) {
-	if (G_raster_map_is_fp(ct.name, ct.mapset))
+	if (Rast_raster_map_is_fp(ct.name, ct.mapset))
 	    ct.discrete = FALSE;
 	else
 	    ct.discrete = TRUE;
Modified: grass/trunk/ps/ps.map/r_group.c
--- grass/trunk/ps/ps.map/r_group.c	2009-06-20 21:39:23 UTC (rev 38002)
+++ grass/trunk/ps/ps.map/r_group.c	2009-06-20 22:03:23 UTC (rev 38003)
@@ -5,6 +5,7 @@
 #include <string.h>
 #include "group.h"
@@ -18,9 +19,9 @@
     PS.do_raster = 0;
 	PS.cell_fd = -1;
@@ -41,7 +42,7 @@
     /* read in colors */
-	if (G_read_colors(grp.name[i], grp.mapset[i], &(grp.colors[i])) == -1) {
+	if (Rast_read_colors(grp.name[i], grp.mapset[i], &(grp.colors[i])) == -1) {
 	    sprintf(fullname, "%s in %s", grp.name[i], grp.mapset[i]);
 	    return 0;
@@ -50,10 +51,10 @@
     /* open raster maps for reading */
-	if ((grp.fd[i] = G_open_cell_old(grp.name[i], grp.mapset[i])) < 0) {
+	if ((grp.fd[i] = Rast_open_cell_old(grp.name[i], grp.mapset[i])) < 0) {
 	    return 0;
Modified: grass/trunk/ps/ps.map/r_labels.c
--- grass/trunk/ps/ps.map/r_labels.c	2009-06-20 21:39:23 UTC (rev 38002)
+++ grass/trunk/ps/ps.map/r_labels.c	2009-06-20 22:03:23 UTC (rev 38003)
@@ -1,5 +1,6 @@
 #include <string.h>
 #include "labels.h"
Modified: grass/trunk/ps/ps.map/r_plt.c
--- grass/trunk/ps/ps.map/r_plt.c	2009-06-20 21:39:23 UTC (rev 38002)
+++ grass/trunk/ps/ps.map/r_plt.c	2009-06-20 22:03:23 UTC (rev 38003)
@@ -44,7 +44,7 @@
 	    continue;
 	if (KEY("color")) {
 	    if (ret == 1) {
 		color_R = r;
 		color_G = g;
@@ -58,7 +58,7 @@
 	    continue;
 	if (KEY("fcolor")) {
 	    if (ret == 1) {
 		fcolor_R = r;
 		fcolor_G = g;
@@ -220,7 +220,7 @@
 	if (KEY("color")) {
 	    if (ret == 1) {
 		color_R = r;
 		color_G = g;
@@ -292,7 +292,7 @@
 	if (KEY("color")) {
 	    if (ret == 1) {
 		color_R = r;
 		color_G = g;
@@ -307,7 +307,7 @@
 	    if (ret == 1) {
 		fcolor_R = r;
 		fcolor_G = g;
Modified: grass/trunk/ps/ps.map/r_rgb.c
--- grass/trunk/ps/ps.map/r_rgb.c	2009-06-20 21:39:23 UTC (rev 38002)
+++ grass/trunk/ps/ps.map/r_rgb.c	2009-06-20 22:03:23 UTC (rev 38003)
@@ -23,9 +23,9 @@
     PS.do_raster = 0;
 	PS.cell_fd = -1;
@@ -66,17 +66,17 @@
 	grp.mapset[i] = G_store(mapset);
 	    return 0;
 	    return 0;
Modified: grass/trunk/ps/ps.map/r_text.c
--- grass/trunk/ps/ps.map/r_text.c	2009-06-20 21:39:23 UTC (rev 38002)
+++ grass/trunk/ps/ps.map/r_text.c	2009-06-20 22:03:23 UTC (rev 38003)
@@ -97,7 +97,7 @@
 	if (KEY("color")) {
 	    if (ret == 1)
 	    else if (ret == 2)
@@ -109,7 +109,7 @@
 	if (KEY("hcolor")) {
 	    if (ret == 1)
 	    else if (ret == 2)
@@ -123,7 +123,7 @@
 	if (KEY("background")) {
 	    if (ret == 1)
 	    else if (ret == 2) {
@@ -137,7 +137,7 @@
 	if (KEY("border")) {
 	    if (ret == 1)
 	    else if (ret == 2)
Modified: grass/trunk/ps/ps.map/r_vareas.c
--- grass/trunk/ps/ps.map/r_vareas.c	2009-06-20 21:39:23 UTC (rev 38002)
+++ grass/trunk/ps/ps.map/r_vareas.c	2009-06-20 22:03:23 UTC (rev 38003)
@@ -9,6 +9,7 @@
 #include <stdlib.h>
 #include <string.h>
 #include "vector.h"
@@ -125,7 +126,7 @@
 	if (KEY("color")) {
 	    if (ret == 1)
 		set_color(&(vector.layer[vec].color), r, g, b);
 	    else if (ret == 2)
@@ -143,7 +144,7 @@
 	if (KEY("fcolor")) {	/* area color */
 	    if (ret == 1)
 		set_color(&(vector.layer[vec].fcolor), r, g, b);
 	    else if (ret == 2)
Modified: grass/trunk/ps/ps.map/r_vlines.c
--- grass/trunk/ps/ps.map/r_vlines.c	2009-06-20 21:39:23 UTC (rev 38002)
+++ grass/trunk/ps/ps.map/r_vlines.c	2009-06-20 22:03:23 UTC (rev 38003)
@@ -247,7 +247,7 @@
 	if (KEY("color")) {
 	    if (ret == 1)
 	    else if (ret == 2)
@@ -265,7 +265,7 @@
 	    if (ret == 1)
 		set_color(&(vector.layer[vec].hcolor), r, g, b);
 	    else if (ret == 2)
Modified: grass/trunk/ps/ps.map/r_vpoints.c
--- grass/trunk/ps/ps.map/r_vpoints.c	2009-06-20 21:39:23 UTC (rev 38002)
+++ grass/trunk/ps/ps.map/r_vpoints.c	2009-06-20 22:03:23 UTC (rev 38003)
@@ -10,6 +10,7 @@
 #include <stdlib.h>
 #include <string.h>
 #include "vector.h"
@@ -148,7 +149,7 @@
 	if (KEY("color")) {
 	    if (ret == 1)
 	    else if (ret == 2)
@@ -160,7 +161,7 @@
 	if (KEY("fcolor")) {	/* fill color */
 	    if (ret == 1)
 	    else if (ret == 2)
Modified: grass/trunk/ps/ps.map/r_wind.c
--- grass/trunk/ps/ps.map/r_wind.c	2009-06-20 21:39:23 UTC (rev 38002)
+++ grass/trunk/ps/ps.map/r_wind.c	2009-06-20 22:03:23 UTC (rev 38003)
@@ -53,7 +53,7 @@
 	if (KEY("color")) {
 	    if (ret == 1) {
 		color_R = r;
 		color_G = g;
Modified: grass/trunk/ps/ps.map/read_cfg.c
--- grass/trunk/ps/ps.map/read_cfg.c	2009-06-20 21:39:23 UTC (rev 38002)
+++ grass/trunk/ps/ps.map/read_cfg.c	2009-06-20 22:03:23 UTC (rev 38003)
@@ -13,6 +13,7 @@
 #include <stdio.h>
 #include <math.h>
 #include "paper.h"
Modified: grass/trunk/ps/ps.map/scale.c
--- grass/trunk/ps/ps.map/scale.c	2009-06-20 21:39:23 UTC (rev 38002)
+++ grass/trunk/ps/ps.map/scale.c	2009-06-20 22:03:23 UTC (rev 38003)
@@ -8,6 +8,7 @@
 #include <stdlib.h>
 #include <string.h>
Modified: grass/trunk/ps/ps.map/scan_gis.c
--- grass/trunk/ps/ps.map/scan_gis.c	2009-06-20 21:39:23 UTC (rev 38002)
+++ grass/trunk/ps/ps.map/scan_gis.c	2009-06-20 22:03:23 UTC (rev 38003)
@@ -1,6 +1,7 @@
 #include <unistd.h>
 #include <string.h>
 int scan_gis(char *element, char *desc, char *key, char *data,
Modified: grass/trunk/ps/ps.map/session.c
--- grass/trunk/ps/ps.map/session.c	2009-06-20 21:39:23 UTC (rev 38002)
+++ grass/trunk/ps/ps.map/session.c	2009-06-20 22:03:23 UTC (rev 38003)
@@ -1,5 +1,6 @@
 #include <stdio.h>
 static char cur[2000];
Modified: grass/trunk/ps/ps.map/vect.c
--- grass/trunk/ps/ps.map/vect.c	2009-06-20 21:39:23 UTC (rev 38002)
+++ grass/trunk/ps/ps.map/vect.c	2009-06-20 22:03:23 UTC (rev 38003)
@@ -8,6 +8,7 @@
 #include <math.h>
 #include "vector.h"
 #define LENGTH(DX, DY)  (  sqrt( (DX*DX)+(DY*DY) )  )
Modified: grass/trunk/ps/ps.map/vector.c
--- grass/trunk/ps/ps.map/vector.c	2009-06-20 21:39:23 UTC (rev 38002)
+++ grass/trunk/ps/ps.map/vector.c	2009-06-20 22:03:23 UTC (rev 38003)
@@ -2,6 +2,7 @@
 #include <stdio.h>
 #include <string.h>
 #include "vector.h"
Modified: grass/trunk/raster/r.basins.fill/main.c
--- grass/trunk/raster/r.basins.fill/main.c	2009-06-20 21:39:23 UTC (rev 38002)
+++ grass/trunk/raster/r.basins.fill/main.c	2009-06-20 22:03:23 UTC (rev 38003)
@@ -27,6 +27,7 @@
 #include <string.h>
 #include <stdio.h>
@@ -89,8 +90,8 @@
     drain_name = drain_opt->answer;
-    /* this isn't a nice thing to do. G_align_window() should be used first */
-    G_get_cellhd(drain_name, "", &window);
+    /* this isn't a nice thing to do. Rast_align_window() should be used first */
+    Rast_get_cellhd(drain_name, "", &window);
     G_set_window(&window);
     nrows = G_window_rows();
@@ -103,7 +104,7 @@
     drain = read_map(drain_name, NOMASK, nrows, ncols);
     ridge = read_map(ridge_name, NOMASK, nrows, ncols);
-    partfd = G_open_cell_new(part_name);
+    partfd = Rast_open_cell_new(part_name);
     if (partfd < 0)
 	G_fatal_error(_("Unable to create raster map <%s>"), part_name);
@@ -152,10 +153,10 @@
     /* write out partitioned watershed map */
     for (row = 0; row < nrows; row++)
-	G_put_raster_row(partfd, drain + (row * ncols), CELL_TYPE);
+	Rast_put_raster_row(partfd, drain + (row * ncols), CELL_TYPE);
     G_message(_("Creating support files for <%s>..."), part_name);
-    G_close_cell(partfd);
+    Rast_close_cell(partfd);
     exit(EXIT_SUCCESS);
Modified: grass/trunk/raster/r.basins.fill/read_map.c
--- grass/trunk/raster/r.basins.fill/read_map.c	2009-06-20 21:39:23 UTC (rev 38002)
+++ grass/trunk/raster/r.basins.fill/read_map.c	2009-06-20 22:03:23 UTC (rev 38003)
@@ -17,6 +17,7 @@
@@ -32,16 +33,16 @@
     map = (CELL *) G_malloc(nrows * ncols * sizeof(CELL));
     /* open the map */
-    if ((fd = G_open_cell_old(name, "")) < 0)
+    if ((fd = Rast_open_cell_old(name, "")) < 0)
 	G_fatal_error(_("Unable to open <%s>"), name);
     /* read the map */
     G_message(_("Reading <%s> ... "), name);
     if (nomask)
-	get_row = G_get_map_row_nomask;
+	get_row = Rast_get_map_row_nomask;
     else
-	get_row = G_get_map_row;
+	get_row = Rast_get_map_row;
     for (row = 0; row < nrows; row++) {
 	G_percent(row, nrows, 10);
@@ -50,7 +51,7 @@
     G_percent(nrows, nrows, 10);
-    G_close_cell(fd);
+    Rast_close_cell(fd);
     return map;
Modified: grass/trunk/raster/r.bitpattern/main.c
--- grass/trunk/raster/r.bitpattern/main.c	2009-06-20 21:39:23 UTC (rev 38002)
+++ grass/trunk/raster/r.bitpattern/main.c	2009-06-20 22:03:23 UTC (rev 38003)
@@ -36,6 +36,7 @@
 #include <stdlib.h>
 #include <string.h>
 extern CELL f_c(CELL);
@@ -96,24 +97,24 @@
     patv = atoi(patval->answer);
     /*if Gispf() error */
-    if ((infd = G_open_cell_old(name, "")) < 0)
+    if ((infd = Rast_open_cell_old(name, "")) < 0)
 	G_fatal_error(_("Unable to open raster map <%s>"), name);
     /* determine the inputmap type (CELL/FCELL/DCELL) */
-    data_type = G_get_raster_map_type(infd);
+    data_type = Rast_get_raster_map_type(infd);
-    if (G_get_cellhd(name, "", &cellhd) < 0)
+    if (Rast_get_cellhd(name, "", &cellhd) < 0)
 	G_fatal_error(_("Unable to read header of raster map <%s>"), name);
     /* Allocate input buffer */
-    inrast = G_allocate_raster_buf(data_type);
+    inrast = Rast_allocate_raster_buf(data_type);
     /* Allocate output buffer, use input map data_type */
     ncols = G_window_cols();
-    outrast = G_allocate_raster_buf(data_type);
+    outrast = Rast_allocate_raster_buf(data_type);
-    if ((outfd = G_open_raster_new(result, data_type)) < 0)
+    if ((outfd = Rast_open_raster_new(result, data_type)) < 0)
 	G_fatal_error(_("Unable to create raster map <%s>"), result);
@@ -123,7 +124,7 @@
 	    G_percent(row, nrows, 2);
 	/* read input map */
-	if (G_get_raster_row(infd, inrast, row, data_type) < 0)
+	if (Rast_get_raster_row(infd, inrast, row, data_type) < 0)
 	    G_fatal_error(_("Unable to read raster map <%s> row %d"), name,
 			  row);
@@ -139,14 +140,14 @@
-	if (G_put_raster_row(outfd, outrast, data_type) < 0)
+	if (Rast_put_raster_row(outfd, outrast, data_type) < 0)
 	    G_fatal_error(_("Unable to write to <%s>"), result);
     G_free(inrast);
     G_free(outrast);
-    G_close_cell(infd);
-    G_close_cell(outfd);
+    Rast_close_cell(infd);
+    Rast_close_cell(outfd);
     return (EXIT_SUCCESS);
Modified: grass/trunk/raster/r.buffer/distance.h
--- grass/trunk/raster/r.buffer/distance.h	2009-06-20 21:39:23 UTC (rev 38002)
+++ grass/trunk/raster/r.buffer/distance.h	2009-06-20 22:03:23 UTC (rev 38003)
@@ -23,6 +23,8 @@
 #define __DISTANCE_H__
 struct Distance
Modified: grass/trunk/raster/r.buffer/find_dist.c
--- grass/trunk/raster/r.buffer/find_dist.c	2009-06-20 21:39:23 UTC (rev 38002)
+++ grass/trunk/raster/r.buffer/find_dist.c	2009-06-20 22:03:23 UTC (rev 38003)
@@ -20,6 +20,7 @@
 #include "distance.h"
Modified: grass/trunk/raster/r.buffer/init.c
--- grass/trunk/raster/r.buffer/init.c	2009-06-20 21:39:23 UTC (rev 38002)
+++ grass/trunk/raster/r.buffer/init.c	2009-06-20 22:03:23 UTC (rev 38003)
@@ -21,6 +21,7 @@
 int init_grass(void)
Modified: grass/trunk/raster/r.buffer/main.c
--- grass/trunk/raster/r.buffer/main.c	2009-06-20 21:39:23 UTC (rev 38002)
+++ grass/trunk/raster/r.buffer/main.c	2009-06-20 22:03:23 UTC (rev 38003)
@@ -160,15 +160,15 @@
     make_support_files(output, units);
     /* write map history (meta data) */
-    G_short_history(output, "raster", &hist);
+    Rast_short_history(output, "raster", &hist);
     sprintf(hist.datsrc_1, "%s", input);
     if (strlen(opt3->answer) < (RECORD_LEN - 14)) {
 	sprintf(hist.edhist[0], "Buffer distance%s:", ndist > 1 ? "s" : "");
 	sprintf(hist.edhist[1], " %s %s", opt3->answer, units);
 	hist.edlinecnt = 2;
-    G_write_history(output, &hist);
+    Rast_write_history(output, &hist);
     exit(EXIT_SUCCESS);
Modified: grass/trunk/raster/r.buffer/read_map.c
--- grass/trunk/raster/r.buffer/read_map.c	2009-06-20 21:39:23 UTC (rev 38002)
+++ grass/trunk/raster/r.buffer/read_map.c	2009-06-20 22:03:23 UTC (rev 38003)
@@ -22,6 +22,7 @@
 #include <stdlib.h>
+#include <grass/glocale.h>
     /* read the input map. convert non-nulls to 1 */
@@ -37,11 +38,11 @@
     map = (MAPTYPE *) G_malloc(window.rows * window.cols * sizeof(MAPTYPE));
-    fd = G_open_cell_old(input, mapset);
+    fd = Rast_open_cell_old(input, mapset);
     if (fd < 0)
 	G_fatal_error(_("Unable to open raster map <%s>"), input);
-    cell = G_allocate_cell_buf();
+    cell = Rast_allocate_cell_buf();
     ptr = map;
@@ -59,7 +60,7 @@
 	hit = 0;
 	G_percent(row, window.rows, 2);
-	if (G_get_c_raster_row(fd, cell, row) < 0)
+	if (Rast_get_c_raster_row(fd, cell, row) < 0)
 			  G_fully_qualified_name(input, mapset), row);
@@ -81,7 +82,7 @@
 	    else {		/* use NULL */
-		if ((*ptr++ = !G_is_c_null_value(cell++))) {
+		if ((*ptr++ = !Rast_is_c_null_value(cell++))) {
 		    if (minrow < 0)
 			minrow = row;
 		    maxrow = row;
@@ -99,7 +100,7 @@
 	cell -= window.cols;
-    G_close_cell(fd);
     G_free(cell);
     return 0;
Modified: grass/trunk/raster/r.buffer/support.c
--- grass/trunk/raster/r.buffer/support.c	2009-06-20 21:39:23 UTC (rev 38002)
+++ grass/trunk/raster/r.buffer/support.c	2009-06-20 22:03:23 UTC (rev 38003)
@@ -29,9 +29,9 @@
     CELL cat;
     char label[128];
-    G_init_cats((CELL) 1, "Distance Zones", &pcats);
+    Rast_init_cats((CELL) 1, "Distance Zones", &pcats);
-    G_set_cat(cat = 1, "distances calculated from these locations", &pcats);
+    Rast_set_cat(cat = 1, "distances calculated from these locations", &pcats);
     for (cat = 0; cat < ndist; cat++) {
 	if (cat == 0)
 	    sprintf(label, "0-%s %s", distances[cat].label, units);
@@ -50,11 +50,11 @@
-	G_set_cat(cat + ZONE_INCR, label, &pcats);
+	Rast_set_cat(cat + ZONE_INCR, label, &pcats);
-    G_write_cats(output, &pcats);
-    G_free_cats(&pcats);
+    Rast_write_cats(output, &pcats);
+    Rast_free_cats(&pcats);
     return 0;
Modified: grass/trunk/raster/r.buffer/write_map.c
--- grass/trunk/raster/r.buffer/write_map.c	2009-06-20 21:39:23 UTC (rev 38002)
+++ grass/trunk/raster/r.buffer/write_map.c	2009-06-20 22:03:23 UTC (rev 38003)
@@ -35,16 +35,16 @@
     register MAPTYPE *ptr;
     int k;
-    fd_out = G_open_cell_new(output);
+    fd_out = Rast_open_cell_new(output);
     if (fd_out < 0)
 	G_fatal_error(_("Unable to create raster map <%s>"), output);
     if (offset) {
-	fd_in = G_open_cell_old(output, G_mapset());
+	fd_in = Rast_open_cell_old(output, G_mapset());
 	if (fd_in < 0)
 	    G_fatal_error(_("Unable to open raster map <%s>"), output);
     G_message(_("Writing output raster map <%s>..."), output);
     ptr = map;
@@ -57,7 +57,7 @@
 		*cell++ = (CELL) * ptr++;
 	else {
-	    if (G_get_map_row_nomask(fd_in, cell, row) < 0)
+	    if (Rast_get_map_row_nomask(fd_in, cell, row) < 0)
 			      output, row);
@@ -72,9 +72,9 @@
 	/* set 0 to NULL */
 	for (k = 0; k < window.cols; k++)
 	    if (cell[k] == 0)
-		G_set_null_value(&cell[k], 1, CELL_TYPE);
+		Rast_set_null_value(&cell[k], 1, CELL_TYPE);
-	if (G_put_raster_row(fd_out, cell, CELL_TYPE) < 0)
+	if (Rast_put_raster_row(fd_out, cell, CELL_TYPE) < 0)
 	    G_fatal_error(_("Failed writing raster map <%s> row %d"), output,
 			  row);
@@ -83,9 +83,9 @@
     G_free(cell);
     if (offset)
-	G_close_cell(fd_in);
+	Rast_close_cell(fd_in);
-    G_close_cell(fd_out);
+    Rast_close_cell(fd_out);
     return 0;
Modified: grass/trunk/raster/r.carve/enforce.h
--- grass/trunk/raster/r.carve/enforce.h	2009-06-20 21:39:23 UTC (rev 38002)
+++ grass/trunk/raster/r.carve/enforce.h	2009-06-20 22:03:23 UTC (rev 38003)
@@ -22,6 +22,7 @@
 #include <stdio.h>
 #include <grass/bitmap.h>
Modified: grass/trunk/raster/r.carve/enforce_ds.c
--- grass/trunk/raster/r.carve/enforce_ds.c	2009-06-20 21:39:23 UTC (rev 38002)
+++ grass/trunk/raster/r.carve/enforce_ds.c	2009-06-20 22:03:23 UTC (rev 38003)
@@ -20,6 +20,7 @@
 #include <stdio.h>
 #include <string.h>
 #include "enforce.h"
@@ -73,7 +74,7 @@
     /* allocate and clear memory for entire raster */
     rbuf =
 	G_calloc(G_window_rows() * G_window_cols(),
-		 G_raster_size(parm->raster_type));
+		 Rast_raster_size(parm->raster_type));
     /* first read whole elevation file into buf */
     read_raster(rbuf, infd, parm->raster_type);
@@ -315,7 +316,7 @@
     rastrows = G_window_rows();
     rastcols = G_window_cols();
     /* kludge - fix for lat_lon */
     rowoff = rad / wind.ns_res;
@@ -335,7 +336,7 @@
 	    CELL *cbuf = data;
-	    if (!(G_is_c_null_value(&cbuf[row1 * rastcols + col1])))
+	    if (!(Rast_is_c_null_value(&cbuf[row1 * rastcols + col1])))
 		min = cbuf[row1 * rastcols + col1];
 	break;
@@ -343,7 +344,7 @@
 	    FCELL *fbuf = data;
-	    if (!(G_is_f_null_value(&fbuf[row1 * rastcols + col1])))
+	    if (!(Rast_is_f_null_value(&fbuf[row1 * rastcols + col1])))
 		min = fbuf[row1 * rastcols + col1];
 	break;
@@ -351,7 +352,7 @@
 	    DCELL *dbuf = data;
-	    if (!(G_is_d_null_value(&dbuf[row1 * rastcols + col1])))
+	    if (!(Rast_is_d_null_value(&dbuf[row1 * rastcols + col1])))
 		min = dbuf[row1 * rastcols + col1];
 	break;
@@ -370,12 +371,12 @@
 			CELL *cbuf = data;
-			if (G_is_d_null_value(&min)) {
-			    if (!(G_is_c_null_value(&cbuf[r * rastcols + c])))
+			if (Rast_is_d_null_value(&min)) {
+			    if (!(Rast_is_c_null_value(&cbuf[r * rastcols + c])))
 				min = cbuf[r * rastcols + c];
 			else {
 				if (cbuf[r * rastcols + c] < min)
@@ -385,12 +386,12 @@
 			FCELL *fbuf = data;
-			    if (!(G_is_f_null_value(&fbuf[r * rastcols + c])))
+			    if (!(Rast_is_f_null_value(&fbuf[r * rastcols + c])))
 				min = fbuf[r * rastcols + c];
 			else {
 				if (fbuf[r * rastcols + c] < min)
@@ -400,12 +401,12 @@
 			DCELL *dbuf = data;
-			    if (!(G_is_d_null_value(&dbuf[r * rastcols + c])))
+			    if (!(Rast_is_d_null_value(&dbuf[r * rastcols + c])))
 				min = dbuf[r * rastcols + c];
 			else {
 				if (dbuf[r * rastcols + c] < min)
Modified: grass/trunk/raster/r.carve/main.c
--- grass/trunk/raster/r.carve/main.c	2009-06-20 21:39:23 UTC (rev 38002)
+++ grass/trunk/raster/r.carve/main.c	2009-06-20 22:03:23 UTC (rev 38003)
@@ -22,6 +22,7 @@
 #include <errno.h>
 #include <math.h>
@@ -160,15 +161,15 @@
     if ((rmapset = G_find_file2("cell", parm.inrast->answer, "")) == NULL)
 	G_fatal_error(_("Raster map <%s> not found"), parm.inrast->answer);
-    if ((infd = G_open_cell_old(parm.inrast->answer, rmapset)) == -1)
+    if ((infd = Rast_open_cell_old(parm.inrast->answer, rmapset)) == -1)
-    parm.raster_type = G_get_raster_map_type(infd);
+    parm.raster_type = Rast_get_raster_map_type(infd);
     /* open new map for output */
     if ((outfd =
-	 G_open_raster_new(parm.outrast->answer, parm.raster_type)) < 0)
+	 Rast_open_raster_new(parm.outrast->answer, parm.raster_type)) < 0)
 		      parm.outrast->answer);
@@ -178,8 +179,8 @@
     enforce_downstream(infd, outfd, &Map, &outMap, &parm);
     close_vect(&Map, 0);
     if (parm.outvect->answer)
Modified: grass/trunk/raster/r.carve/raster.c
--- grass/trunk/raster/r.carve/raster.c	2009-06-20 21:39:23 UTC (rev 38002)
+++ grass/trunk/raster/r.carve/raster.c	2009-06-20 22:03:23 UTC (rev 38003)
@@ -1,5 +1,6 @@
 #include <stdlib.h>
@@ -14,9 +15,9 @@
     for (i = 0; i < rows; i++) {
 	G_percent(i + 1, rows, 10);
-	G_get_raster_row(fd, tmpbuf, i, rtype);
+	Rast_get_raster_row(fd, tmpbuf, i, rtype);
 	tmpbuf =
-	    G_incr_void_ptr(tmpbuf, G_raster_size(rtype) * G_window_cols());
+	    Rast_incr_void_ptr(tmpbuf, Rast_raster_size(rtype) * G_window_cols());
     return tmpbuf;
@@ -34,9 +35,9 @@
 	G_percent(i, rows, 10);
-	G_put_raster_row(fd, tmpbuf, rtype);
+	Rast_put_raster_row(fd, tmpbuf, rtype);
 	tmpbuf =
     return tmpbuf;
Modified: grass/trunk/raster/r.carve/support.c
--- grass/trunk/raster/r.carve/support.c	2009-06-20 21:39:23 UTC (rev 38002)
+++ grass/trunk/raster/r.carve/support.c	2009-06-20 22:03:23 UTC (rev 38003)
@@ -20,6 +20,7 @@
 #include <string.h>
 #include <stdio.h>
@@ -35,13 +36,13 @@
     struct History hist;
     /* write command line to history */
-    G_short_history(parm->outrast->answer, "raster", &hist);
+    Rast_short_history(parm->outrast->answer, "raster", &hist);
     sprintf(hist.edhist[0], "%s version %.2f", G_program_name(), APP_VERSION);
     sprintf(hist.edhist[1], "stream width: %.2f", parm->swidth * 2);
     sprintf(hist.datsrc_1, "raster elevation file: %s", parm->inrast->answer);
     sprintf(hist.datsrc_2, "vector stream file: %s", parm->invect->answer);
     hist.edlinecnt = 2;
-    return G_write_history(parm->outrast->answer, &hist);
+    return Rast_write_history(parm->outrast->answer, &hist);
Modified: grass/trunk/raster/r.carve/vect.c
--- grass/trunk/raster/r.carve/vect.c	2009-06-20 21:39:23 UTC (rev 38002)
+++ grass/trunk/raster/r.carve/vect.c	2009-06-20 22:03:23 UTC (rev 38003)
@@ -19,6 +19,7 @@
 #include <stdio.h>
Modified: grass/trunk/raster/r.category/cats.c
--- grass/trunk/raster/r.category/cats.c	2009-06-20 21:39:23 UTC (rev 38002)
+++ grass/trunk/raster/r.category/cats.c	2009-06-20 22:03:23 UTC (rev 38003)
@@ -18,6 +18,7 @@
 #include <stdlib.h>
@@ -31,37 +32,37 @@
     struct Cell_head cellhd;
     /* set the window to the cell header */
-    if (G_get_cellhd(name, mapset, &cellhd) < 0)
+    if (Rast_get_cellhd(name, mapset, &cellhd) < 0)
 	G_fatal_error(_("Cannot read header of raster map <%s> in <%s>"),
 		      name, mapset);
     G_set_window(&cellhd);
     /* open the raster map */
-    fd = G_open_cell_old(name, mapset);
+    fd = Rast_open_cell_old(name, mapset);
     if (fd < 0)
 	G_fatal_error(_("Cannot open cell file of raster map <%s> in <%s>"),
 		      name, mapset);
-    G_init_cell_stats(&statf);
+    Rast_init_cell_stats(&statf);
     /* read the raster map */
     G_verbose_message(_("Reading <%s> in <%s>"), name, mapset);
 	if (G_verbose() > G_verbose_std())
-	if (G_get_c_raster_row_nomask(fd, cell, row) < 0)
+	if (Rast_get_c_raster_row_nomask(fd, cell, row) < 0)
 	    exit(EXIT_SUCCESS);
-	G_update_cell_stats(cell, ncols, &statf);
+	Rast_update_cell_stats(cell, ncols, &statf);
     /* done */
-    G_close_cell(fd);
     G_free(cell);
-    G_rewind_cell_stats(&statf);
+    Rast_rewind_cell_stats(&statf);
     return 0;
@@ -71,7 +72,7 @@
     long count;
     CELL cat;
-    if (G_next_cell_stat(&cat, &count, &statf)) {
+    if (Rast_next_cell_stat(&cat, &count, &statf)) {
 	*x = cat;
 	return 1;
Modified: grass/trunk/raster/r.category/main.c
--- grass/trunk/raster/r.category/main.c	2009-06-20 21:39:23 UTC (rev 38002)
+++ grass/trunk/raster/r.category/main.c	2009-06-20 22:03:23 UTC (rev 38003)
@@ -21,6 +21,7 @@
 #include <stdio.h>
 #include <string.h>
@@ -124,7 +125,7 @@
     if (mapset == NULL)
 	G_fatal_error(_("Raster map <%s> not found"), name);
-    map_type = G_raster_map_type(name, mapset);
+    map_type = Rast_raster_map_type(name, mapset);
     /* create category labels */
@@ -146,20 +147,20 @@
 			      parm.raster->answer);
-	    if ((fd = G_open_cell_old(name, mapset)) < 0)
+	    if ((fd = Rast_open_cell_old(name, mapset)) < 0)
-	    G_init_raster_cats("", &cats);
+	    Rast_init_raster_cats("", &cats);
-	    if (0 > G_read_cats(parm.raster->answer, cmapset, &cats))
+	    if (0 > Rast_read_cats(parm.raster->answer, cmapset, &cats))
 		G_fatal_error(_("Unable to read category file of raster map <%s@%s>"),
 			      parm.raster->answer, cmapset);
-	    if (G_write_cats(name, &cats) >= 0)
+	    if (Rast_write_cats(name, &cats) >= 0)
 		G_message(_("Category table for <%s> set from <%s>"), name,
-	    G_close_cell(fd);
 	/* load cats from rules file */
@@ -178,7 +179,7 @@
 				  parm.file->answer);
 	    for (;;) {
 		char buf[1024], label[1024];
@@ -188,12 +189,12 @@
 		    break;
 		if (sscanf(buf, "%lf:%lf:%[^\n]", &d1, &d2, label) == 3)
-		    G_set_d_raster_cat(&d1, &d2, label, &cats);
+		    Rast_set_d_raster_cat(&d1, &d2, label, &cats);
 		else if (sscanf(buf, "%lf:%[^\n]", &d1, label) == 2)
-		    G_set_d_raster_cat(&d1, &d1, label, &cats);
+		    Rast_set_d_raster_cat(&d1, &d1, label, &cats);
-	    if (G_write_cats(name, &cats) < 0)
+	    if (Rast_write_cats(name, &cats) < 0)
 		G_fatal_error(_("Cannot create category file for <%s>"),
 			      name);
@@ -207,9 +208,9 @@
 	    double m1, a1, m2, a2;
 	    /* read existing values */
-	    if (0 > G_read_cats(name, G_mapset(), &cats))
+	    if (0 > Rast_read_cats(name, G_mapset(), &cats))
 		G_warning(_("Unable to read category file of raster map <%s@%s>"),
 			  name, G_mapset());
@@ -237,18 +238,18 @@
 		a2 = atof(parm.fmt_coeff->answers[3]);
-	    G_set_cats_fmt(fmt_str, m1, a1, m2, a2, &cats);
+	    Rast_set_cats_fmt(fmt_str, m1, a1, m2, a2, &cats);
-	    if (G_write_cats(name, &cats) != 1)
+	    if (Rast_write_cats(name, &cats) != 1)
 			      name);
-	G_free_cats(&cats);
+	Rast_free_cats(&cats);
 	exit(EXIT_SUCCESS);
     else {
-	if (G_read_cats(name, mapset, &cats) < 0)
+	if (Rast_read_cats(name, mapset, &cats) < 0)
 	    G_fatal_error(_("Unable to read category file of raster map <%s> in <%s>"),
 			  name, mapset);
@@ -301,7 +302,7 @@
     char *label;
-    G_squeeze(label = G_get_cat((CELL) x, &cats));
+    G_squeeze(label = Rast_get_cat((CELL) x, &cats));
     fprintf(stdout, "%ld%c%s\n", x, fs, label);
     return 0;
@@ -313,7 +314,7 @@
     DCELL dtmp;
     dtmp = x;
-    G_squeeze(label = G_get_d_raster_cat(&dtmp, &cats));
+    G_squeeze(label = Rast_get_d_raster_cat(&dtmp, &cats));
     sprintf(tmp, "%.10f", x);
     G_trim_decimal(tmp);
     fprintf(stdout, "%s%c%s\n", tmp, fs, label);
Modified: grass/trunk/raster/r.circle/main.c
--- grass/trunk/raster/r.circle/main.c	2009-06-20 21:39:23 UTC (rev 38002)
+++ grass/trunk/raster/r.circle/main.c	2009-06-20 22:03:23 UTC (rev 38003)
@@ -21,6 +21,7 @@
 #include <strings.h>
 #include <math.h>
 typedef int FILEDESC;
@@ -123,7 +124,7 @@
     G_get_set_window(&w);
-    if ((cellfile = G_open_cell_new(out_file->answer)) == -1)
+    if ((cellfile = Rast_open_cell_new(out_file->answer)) == -1)
 		      out_file->answer);
@@ -140,17 +141,17 @@
 		int_buf[c] =
 		    (int)(distance(pt, cur, fmin, fmax, binary) * fmult);
 		if (int_buf[c] == 0)
-		    G_set_null_value(&int_buf[c], 1, CELL_TYPE);
+		    Rast_set_null_value(&int_buf[c], 1, CELL_TYPE);
-	    G_put_raster_row(cellfile, int_buf, CELL_TYPE);
+	    Rast_put_raster_row(cellfile, int_buf, CELL_TYPE);
     G_free(int_buf);
-    G_close_cell(cellfile);
-    G_short_history(out_file->answer, "raster", &history);
-    G_command_history(&history);
-    G_write_history(out_file->answer, &history);
+    Rast_close_cell(cellfile);
+    Rast_short_history(out_file->answer, "raster", &history);
+    Rast_command_history(&history);
+    Rast_write_history(out_file->answer, &history);
     G_done_msg(_("Raster map <%s> created."),
 	       out_file->answer);
Modified: grass/trunk/raster/r.clump/clump.c
--- grass/trunk/raster/r.clump/clump.c	2009-06-20 21:39:23 UTC (rev 38002)
+++ grass/trunk/raster/r.clump/clump.c	2009-06-20 22:03:23 UTC (rev 38003)
@@ -18,6 +18,7 @@
 #include <time.h>
@@ -97,7 +98,7 @@
 	G_message(_("Pass %d..."), pass);
-	    if (G_get_map_row(in_fd, cur_in + 1, row) < 0)
+	    if (Rast_get_map_row(in_fd, cur_in + 1, row) < 0)
 		G_fatal_error(_("Unable to read raster map row %d "),
 			      row);
@@ -220,7 +221,7 @@
 		   for (col = 1; col <= ncols; col++)
 		   out_cell[col] = index[cur_clump[col]];
-		   if (G_put_raster_row (out_fd, out_cell+1, CELL_TYPE) < 0)
+		   if (Rast_put_raster_row (out_fd, out_cell+1, CELL_TYPE) < 0)
 		   G_fatal_error (_("Unable to properly write output raster map"));
 		col = ncols;
@@ -232,9 +233,9 @@
 		for (column = 0; column < ncols; column++) {
 		    if (out_cell[column] == 0)
-			G_set_null_value(&out_cell[column], 1, CELL_TYPE);
+			Rast_set_null_value(&out_cell[column], 1, CELL_TYPE);
-		if (G_put_raster_row(out_fd, out_cell, CELL_TYPE) < 0)
+		if (Rast_put_raster_row(out_fd, out_cell, CELL_TYPE) < 0)
 		    G_fatal_error(_("Failed writing raster map row %d"),
 				  row);
Modified: grass/trunk/raster/r.clump/main.c
--- grass/trunk/raster/r.clump/main.c	2009-06-20 21:39:23 UTC (rev 38002)
+++ grass/trunk/raster/r.clump/main.c	2009-06-20 22:03:23 UTC (rev 38003)
@@ -19,6 +19,7 @@
 #include <stdlib.h>
 #include <string.h>
@@ -66,11 +67,11 @@
     strcpy(name, INPUT);
-    in_fd = G_open_cell_old(name, "");
+    in_fd = Rast_open_cell_old(name, "");
     if (in_fd < 0)
 	G_fatal_error(_("Unable to open raster map <%s>"), INPUT);
-    out_fd = G_open_cell_new(OUTPUT);
+    out_fd = Rast_open_cell_new(OUTPUT);
     if (out_fd < 0)
 	G_fatal_error(_("Unable to create raster map <%s>"), OUTPUT);
@@ -78,8 +79,8 @@
     G_debug(1, "Creating support files...");
-    G_close_cell(in_fd);
-    G_close_cell(out_fd);
+    Rast_close_cell(in_fd);
+    Rast_close_cell(out_fd);
     /* build title */
@@ -88,11 +89,11 @@
     else
 	sprintf(title, "clump of <%s@%s>", name, G_mapset());
-    G_put_cell_title(OUTPUT, title);
-    G_read_range(OUTPUT, G_mapset(), &range);
-    G_get_range_min_max(&range, &min, &max);
-    G_make_random_colors(&colr, min, max);
-    G_write_colors(OUTPUT, G_mapset(), &colr);
+    Rast_put_cell_title(OUTPUT, title);
+    Rast_read_range(OUTPUT, G_mapset(), &range);
+    Rast_get_range_min_max(&range, &min, &max);
+    Rast_make_random_colors(&colr, min, max);
+    Rast_write_colors(OUTPUT, G_mapset(), &colr);
     G_done_msg(_("%d clumps."), range.max);
Modified: grass/trunk/raster/r.coin/coin.h
--- grass/trunk/raster/r.coin/coin.h	2009-06-20 21:39:23 UTC (rev 38002)
+++ grass/trunk/raster/r.coin/coin.h	2009-06-20 22:03:23 UTC (rev 38003)
@@ -20,6 +20,8 @@
 #define __COIN_H__
 struct stats_table
Modified: grass/trunk/raster/r.coin/main.c
--- grass/trunk/raster/r.coin/main.c	2009-06-20 21:39:23 UTC (rev 38002)
+++ grass/trunk/raster/r.coin/main.c	2009-06-20 22:03:23 UTC (rev 38003)
@@ -19,6 +19,7 @@
 #include <stdlib.h>
 #include <string.h>
 #include "coin.h"
@@ -103,7 +104,7 @@
     /* now make a temorary region with the same boundaries only 1 x 1 */
     window.rows = 1;
     window.cols = 1;
-    G_adjust_Cell_head(&window, 1, 1);
+    Rast_adjust_Cell_head(&window, 1, 1);
     G_begin_cell_area_calculations();
Modified: grass/trunk/raster/r.coin/make_coin.c
--- grass/trunk/raster/r.coin/make_coin.c	2009-06-20 21:39:23 UTC (rev 38002)
+++ grass/trunk/raster/r.coin/make_coin.c	2009-06-20 22:03:23 UTC (rev 38003)
@@ -20,6 +20,7 @@
 #include <stdlib.h>
 #include "coin.h"
 static int cmp(const void *, const void *);
@@ -132,8 +133,8 @@
 	reversed = 1;
-    title1 = G_get_cell_title(map1name, "");
-    title2 = G_get_cell_title(map2name, "");
+    title1 = Rast_get_cell_title(map1name, "");
+    title2 = Rast_get_cell_title(map2name, "");
     /* determine where no data (cat 0) is */
     for (no_data1 = ncat1 - 1; no_data1 >= 0; no_data1--)
Modified: grass/trunk/raster/r.coin/print_hdr.c
--- grass/trunk/raster/r.coin/print_hdr.c	2009-06-20 21:39:23 UTC (rev 38002)
+++ grass/trunk/raster/r.coin/print_hdr.c	2009-06-20 22:03:23 UTC (rev 38003)
@@ -70,7 +70,7 @@
     fprintf(dumpfile, "|%78.78s|\n", fill);
     fprintf(dumpfile, "| Layer 1: %-15.15s-- %-50.49s|\n", map1name, title1);
     fprintf(dumpfile, "| Layer 2: %-15.15s-- %-50.49s|\n", map2name, title2);
-    fprintf(dumpfile, "| Mask:    %-68.68s|\n", G_mask_info());
+    fprintf(dumpfile, "| Mask:    %-68.68s|\n", Rast_mask_info());
     fprintf(dumpfile, "| Units:   %-68.68s|\n", unit_type);
     fprintf(dumpfile, "|%78.78s|\n", midline);
Modified: grass/trunk/raster/r.colors/local_proto.h
--- grass/trunk/raster/r.colors/local_proto.h	2009-06-20 21:39:23 UTC (rev 38002)
+++ grass/trunk/raster/r.colors/local_proto.h	2009-06-20 22:03:23 UTC (rev 38003)
@@ -21,6 +21,7 @@
 #define __LOCAL_PROTO_H__
 /* stats.c */
 int get_stats(const char *, const char *, struct Cell_stats *);
Modified: grass/trunk/raster/r.colors/main.c
--- grass/trunk/raster/r.colors/main.c	2009-06-20 21:39:23 UTC (rev 38002)
+++ grass/trunk/raster/r.colors/main.c	2009-06-20 22:03:23 UTC (rev 38003)
@@ -26,6 +26,7 @@
 #include <string.h>
 #include <sys/types.h>
@@ -265,7 +266,7 @@
     if (remove) {
-	int stat = G_remove_colors(name, mapset);
+	int stat = Rast_remove_colors(name, mapset);
 	if (stat < 0)
 	    G_fatal_error(_("Unable to remove color table of raster map <%s>"), name);
@@ -275,18 +276,18 @@
     G_suppress_warnings(1);
-    have_colors = G_read_colors(name, mapset, &colors);
+    have_colors = Rast_read_colors(name, mapset, &colors);
     /*if (have_colors >= 0)
-       G_free_colors(&colors); */
+       Rast_free_colors(&colors); */
     if (have_colors > 0 && !overwrite)
 	exit(EXIT_SUCCESS);
     G_suppress_warnings(0);
-    fp = G_raster_map_is_fp(name, mapset);
-    G_read_fp_range(name, mapset, &range);
-    G_get_fp_range_min_max(&range, &min, &max);
+    fp = Rast_raster_map_is_fp(name, mapset);
+    Rast_read_fp_range(name, mapset, &range);
+    Rast_get_fp_range_min_max(&range, &min, &max);
     if (is_from_stdin) {
 	if (!read_color_rules(stdin, &colors, min, max, fp))
@@ -299,37 +300,37 @@
 	if (strcmp(style, "random") == 0) {
 	    if (fp)
 		G_fatal_error(_("Color table 'random' is not supported for floating point raster map"));
-	    G_make_random_colors(&colors, (CELL) min, (CELL) max);
+	    Rast_make_random_colors(&colors, (CELL) min, (CELL) max);
 	else if (strcmp(style, "grey.eq") == 0) {
 	    if (fp)
 		G_fatal_error(_("Color table 'grey.eq' is not supported for floating point raster map"));
 	    if (!have_stats)
 		have_stats = get_stats(name, mapset, &statf);
-	    G_make_histogram_eq_colors(&colors, &statf);
+	    Rast_make_histogram_eq_colors(&colors, &statf);
 	else if (strcmp(style, "grey.log") == 0) {
 	    if (fp)
 		G_fatal_error(_("Color table 'grey.log' is not supported for floating point raster map"));
 	    if (!have_stats)
-	    G_make_histogram_log_colors(&colors, &statf, (CELL) min,
+	    Rast_make_histogram_log_colors(&colors, &statf, (CELL) min,
 					(CELL) max);
 	else if (find_rule(style))
-	    G_make_fp_colors(&colors, style, min, max);
+	    Rast_make_fp_colors(&colors, style, min, max);
 	else
 	    G_fatal_error(_("Unknown color request '%s'"), style);
     else if (rules) {
-	if (!G_load_fp_colors(&colors, rules, min, max)) {
+	if (!Rast_load_fp_colors(&colors, rules, min, max)) {
 	    /* for backwards compatibility try as std name; remove for GRASS 7 */
 	    char path[GPATH_MAX];
 	    /* don't bother with native dirsep as not needed for backwards compatibility */
 	    sprintf(path, "%s/etc/colors/%s", G_gisbase(), rules);
-	    if (!G_load_fp_colors(&colors, path, min, max))
+	    if (!Rast_load_fp_colors(&colors, path, min, max))
 		G_fatal_error(_("Unable to load rules file <%s>"), rules);
@@ -339,44 +340,44 @@
 	if (cmapset == NULL)
 	    G_fatal_error(_("Raster map <%s> not found"), cmap);
-	if (G_read_colors(cmap, cmapset, &colors) < 0)
+	if (Rast_read_colors(cmap, cmapset, &colors) < 0)
 	    G_fatal_error(_("Unable to read color table for raster map <%s>"), cmap);
     if (fp)
-	G_mark_colors_as_fp(&colors);
+	Rast_mark_colors_as_fp(&colors);
     if (flag.n->answer)
-	G_invert_colors(&colors);
+	Rast_invert_colors(&colors);
     if (flag.e->answer) {
 	if (fp) {
 	    struct FP_stats fpstats;
 	    get_fp_stats(name, mapset, &fpstats, min, max, flag.g->answer, flag.a->answer);
-	    G_histogram_eq_colors_fp(&colors_tmp, &colors, &fpstats);
+	    Rast_histogram_eq_colors_fp(&colors_tmp, &colors, &fpstats);
 	else {
 	    if (!have_stats)
-	    G_histogram_eq_colors(&colors_tmp, &colors, &statf);
+	    Rast_histogram_eq_colors(&colors_tmp, &colors, &statf);
 	colors = colors_tmp;
     if (flag.g->answer) {
-	G_log_colors(&colors_tmp, &colors, 100);
+	Rast_log_colors(&colors_tmp, &colors, 100);
     if (flag.a->answer) {
-	G_abs_log_colors(&colors_tmp, &colors, 100);
+	Rast_abs_log_colors(&colors_tmp, &colors, 100);
     if (fp)
-    if (G_write_colors(name, mapset, &colors) >= 0)
+    if (Rast_write_colors(name, mapset, &colors) >= 0)
 	G_message(_("Color table for raster map <%s> set to '%s'"), name,
 		  is_from_stdin ? "rules" : style ? style : rules ? rules :
 		  cmap);
Modified: grass/trunk/raster/r.colors/rules.c
--- grass/trunk/raster/r.colors/rules.c	2009-06-20 21:39:23 UTC (rev 38002)
+++ grass/trunk/raster/r.colors/rules.c	2009-06-20 22:03:23 UTC (rev 38003)
@@ -22,6 +22,7 @@
 #include <unistd.h>
 #include <string.h>
@@ -56,10 +57,10 @@
 		    (long)max);
-    if (!G_read_color_rules(colors, min, max, read_rule, fp))
+    if (!Rast_read_color_rules(colors, min, max, read_rule, fp))
 	return 0;
-    G_get_d_color_range(&rulemin, &rulemax, colors);
+    Rast_get_d_color_range(&rulemin, &rulemax, colors);
     G_debug(3, "rulemin=%.1f rulemax=%.1f", rulemin, rulemax);
     if (rulemin > min || rulemax < max)
@@ -116,7 +117,7 @@
 	ret =
-	    G_parse_color_rule(min, max, buf, val, r, g, b, norm, nval, dflt);
+	    Rast_parse_color_rule(min, max, buf, val, r, g, b, norm, nval, dflt);
 	if (ret == 0)
 	    return 1;
@@ -128,7 +129,7 @@
 static void badrule(int tty, const char *s, int code)
-    const char *err = G_parse_color_rule_error(code);
+    const char *err = Rast_parse_color_rule_error(code);
     if (tty)
 	G_warning(_("bad rule (%s); rule not added"), err);
Modified: grass/trunk/raster/r.colors/stats.c
--- grass/trunk/raster/r.colors/stats.c	2009-06-20 21:39:23 UTC (rev 38002)
+++ grass/trunk/raster/r.colors/stats.c	2009-06-20 22:03:23 UTC (rev 38003)
@@ -20,6 +20,7 @@
 #include <math.h>
 #include <stdlib.h>
@@ -29,26 +30,26 @@
     int row, nrows, ncols;
     int fd;
 		      G_fully_qualified_name(name, mapset));
-    G_init_cell_stats(statf);
+    Rast_init_cell_stats(statf);
     G_verbose_message(_("Reading raster map <%s>..."),
 			  G_fully_qualified_name(name, mapset), row);
-	G_update_cell_stats(cell, ncols, statf);
+	Rast_update_cell_stats(cell, ncols, statf);
-    G_close_cell(fd);
     G_free(cell);
     return 1;
@@ -62,11 +63,11 @@
     int row, col, nrows, ncols;
     int fd;
 	G_fatal_error("Unable to open raster map <%s>",
-    dcell = G_allocate_d_raster_buf();
+    dcell = Rast_allocate_d_raster_buf();
@@ -109,7 +110,7 @@
-	if (G_get_d_raster_row(fd, dcell, row) < 0)
+	if (Rast_get_d_raster_row(fd, dcell, row) < 0)
@@ -117,7 +118,7 @@
 	    DCELL x;
 	    int i;
-	    if (G_is_d_null_value(&dcell[col]))
+	    if (Rast_is_d_null_value(&dcell[col]))
 		continue;
 	    x = dcell[col];
@@ -135,6 +136,6 @@
-    G_close_cell(fd);
     G_free(dcell);
Modified: grass/trunk/raster/r.colors.out/main.c
--- grass/trunk/raster/r.colors.out/main.c	2009-06-20 21:39:23 UTC (rev 38002)
+++ grass/trunk/raster/r.colors.out/main.c	2009-06-20 22:03:23 UTC (rev 38003)
@@ -18,6 +18,7 @@
 #include <stdlib.h>
 #include <string.h>
 static FILE *fp;
@@ -83,11 +84,11 @@
     file = opt.file->answer;
     perc = flag.p->answer ? 1 : 0;
-    if (G_read_colors(name, "", &colors) < 0)
+    if (Rast_read_colors(name, "", &colors) < 0)
 	G_fatal_error(_("Can't read color table for <%s>"));
-    G_read_fp_range(name, "", &range);
+    Rast_read_fp_range(name, "", &range);
     if (!file || strcmp(file, "-") == 0)
 	fp = stdout;
@@ -101,23 +102,23 @@
 	/* 3.0 format */
 	CELL lo, hi;
-	G_get_color_range(&lo, &hi, &colors);
+	Rast_get_color_range(&lo, &hi, &colors);
 	for (i = lo; i <= hi; i++) {
 	    unsigned char r, g, b, set;
 	    DCELL val = (DCELL) i;
-	    G_lookup_colors(&i, &r, &g, &b, &set, 1, &colors);
+	    Rast_lookup_colors(&i, &r, &g, &b, &set, 1, &colors);
 	    write_rule(&val, r, g, b);
     else {
-	count = G_colors_count(&colors);
+	count = Rast_colors_count(&colors);
 	for (i = 0; i < count; i++) {
 	    DCELL val1, val2;
 	    unsigned char r1, g1, b1, r2, g2, b2;
-	    G_get_f_color_rule(
+	    Rast_get_f_color_rule(
 		&val1, &r1, &g1, &b1,
 		&val2, &r2, &g2, &b2,
 		&colors, count - 1 - i);
@@ -129,9 +130,9 @@
 	int r, g, b;
-	G_get_null_value_color(&r, &g, &b, &colors);
+	Rast_get_null_value_color(&r, &g, &b, &colors);
 	fprintf(fp, "nv %d %d %d\n", r, g, b);
-	G_get_default_color(&r, &g, &b, &colors);
+	Rast_get_default_color(&r, &g, &b, &colors);
 	fprintf(fp, "default %d %d %d\n", r, g, b);
Modified: grass/trunk/raster/r.composite/main.c
--- grass/trunk/raster/r.composite/main.c	2009-06-20 21:39:23 UTC (rev 38002)
+++ grass/trunk/raster/r.composite/main.c	2009-06-20 22:03:23 UTC (rev 38003)
@@ -20,6 +20,7 @@
 #include <string.h>
 struct band
@@ -150,15 +151,15 @@
 	b->name = b->opt_name->answer;
 	/* Make sure map is available */
-	if ((b->file = G_open_cell_old(b->name, "")) == -1)
+	if ((b->file = Rast_open_cell_old(b->name, "")) == -1)
 	    G_fatal_error(_("Unable to open raster map <%s>"), b->name);
-	b->type = G_get_raster_map_type(b->file);
+	b->type = Rast_get_raster_map_type(b->file);
-	b->size = G_raster_size(b->type);
+	b->size = Rast_raster_size(b->type);
 	/* Reading color lookup table */
-	if (G_read_colors(b->name, "", &b->colors) == -1)
+	if (Rast_read_colors(b->name, "", &b->colors) == -1)
 	    G_fatal_error(_("Unable to read color file of raster map <%s>"), b->name);
 	for (j = 0; j < 3; j++)
@@ -179,10 +180,10 @@
     /* open output files */
     out_name = opt_out->answer;
-    if ((out_file = G_open_cell_new(out_name)) < 0)
+    if ((out_file = Rast_open_cell_new(out_name)) < 0)
 	G_fatal_error(_("Unable to create raster map <%s>"), out_name);
-    out_array = G_allocate_cell_buf();
+    out_array = Rast_allocate_cell_buf();
     /* Make color table */
     make_color_cube(&out_colors);
@@ -195,7 +196,7 @@
 	    struct band *b = &B[i];
-	    if (G_get_raster_row_colors(b->file, atrow, &b->colors,
+	    if (Rast_get_raster_row_colors(b->file, atrow, &b->colors,
 					b->array[0],
 					b->array[1], b->array[2], nulls) < 0)
 		G_fatal_error(_("Error reading raster map <%s>"),
@@ -215,7 +216,7 @@
 	    int val[3];
 	    if (nulls[atcol]) {
-		G_set_c_null_value(&out_array[atcol], 1);
+		Rast_set_c_null_value(&out_array[atcol], 1);
 		continue;
@@ -245,21 +246,21 @@
 		(val[2] * B[1].levels + val[1]) * B[0].levels + val[0];
-	if (G_put_raster_row(out_file, out_array, CELL_TYPE) < 0)
+	if (Rast_put_raster_row(out_file, out_array, CELL_TYPE) < 0)
 	    G_fatal_error(_("Failed writing raster map <%s>"), out_name);
     G_percent(window.rows, window.rows, 1);
     /* Close the input files */
-	G_close_cell(B[i].file);
+	Rast_close_cell(B[i].file);
     /* Close the output file */
-    G_close_cell(out_file);
-    G_write_colors(out_name, G_mapset(), &out_colors);
-    G_short_history(out_name, "raster", &history);
-    G_write_history(out_name, &history);
+    Rast_close_cell(out_file);
+    Rast_write_colors(out_name, G_mapset(), &out_colors);
+    Rast_short_history(out_name, "raster", &history);
+    Rast_write_history(out_name, &history);
     G_done_msg(_("Raster map <%s> created."), out_name);
@@ -283,7 +284,7 @@
     int g, b;
     int i = 0;
-    G_init_colors(colors);
+    Rast_init_colors(colors);
     G_message(_("Creating color table for output raster map..."));
@@ -296,7 +297,7 @@
 	    CELL i0 = i;
 	    CELL i1 = i + mr;
-	    G_add_c_raster_color_rule(&i0, 0, grn, blu,
+	    Rast_add_c_raster_color_rule(&i0, 0, grn, blu,
 				      &i1, 255, grn, blu, colors);
 	    i += nr;
Modified: grass/trunk/raster/r.compress/main.c
--- grass/trunk/raster/r.compress/main.c	2009-06-20 21:39:23 UTC (rev 38002)
+++ grass/trunk/raster/r.compress/main.c	2009-06-20 22:03:23 UTC (rev 38003)
@@ -27,7 +27,7 @@
  *        Next byte(s): category number. The number of bytes is determined
  *                      by the number of bytes in a cell
- * The normal G_open_cell(), and G_put_raster_row() do the compression
+ * The normal G_open_cell(), and Rast_put_raster_row() do the compression
  * This program must only check that the file is not a reclass file and
  * is not already compressed.
@@ -40,6 +40,7 @@
 #include <unistd.h>
+#include <grass/Rast.h>
 static off_t newsize, oldsize;
@@ -102,7 +103,7 @@
 	G_warning(_("[%s] not found"), name);
 	return 1;
-    if (G_is_reclass(name, G_mapset(), rname, rmapset) > 0) {
+    if (Rast_is_reclass(name, G_mapset(), rname, rmapset) > 0) {
 	G_warning(uncompress
 		  _("[%s] is a reclass file of map <%s> in mapset <%s> - can't uncompress")
@@ -112,16 +113,16 @@
 	return 1;
-    map_type = G_raster_map_type(name, G_mapset());
+    map_type = Rast_raster_map_type(name, G_mapset());
-    colr_ok = G_read_colors(name, G_mapset(), &colr) > 0;
-    hist_ok = G_read_history(name, G_mapset(), &hist) >= 0;
-    cats_ok = G_read_cats(name, G_mapset(), &cats) >= 0;
+    colr_ok = Rast_read_colors(name, G_mapset(), &colr) > 0;
+    hist_ok = Rast_read_history(name, G_mapset(), &hist) >= 0;
+    cats_ok = Rast_read_cats(name, G_mapset(), &cats) >= 0;
     if (map_type != CELL_TYPE) {
-	G_quant_init(&quant);
-	quant_ok = G_read_quant(name, G_mapset(), &quant);
+	Rast_quant_init(&quant);
+	quant_ok = Rast_read_quant(name, G_mapset(), &quant);
@@ -129,18 +130,18 @@
 	return 1;
     if (colr_ok) {
-	G_write_colors(name, G_mapset(), &colr);
-	G_free_colors(&colr);
+	Rast_write_colors(name, G_mapset(), &colr);
+	Rast_free_colors(&colr);
     if (hist_ok)
-	G_write_history(name, &hist);
+	Rast_write_history(name, &hist);
     if (cats_ok) {
-	cats.num = G_number_of_cats(name, G_mapset());
-	G_write_cats(name, &cats);
+	cats.num = Rast_number_of_cats(name, G_mapset());
+	Rast_write_cats(name, &cats);
     if (map_type != CELL_TYPE && quant_ok)
-	G_write_quant(name, G_mapset(), &quant);
+	Rast_write_quant(name, G_mapset(), &quant);
     diff = newsize - oldsize;
     if (diff < 0)
@@ -170,7 +171,7 @@
     int new, old, nrows, row;
     void *rast;
-    if (G_get_cellhd(name, G_mapset(), &cellhd) < 0) {
+    if (Rast_get_cellhd(name, G_mapset(), &cellhd) < 0) {
 	G_warning("Problem reading cell header for [%s]", name);
 	return 1;
@@ -190,48 +191,48 @@
-    old = G_open_cell_old(name, G_mapset());
+    old = Rast_open_cell_old(name, G_mapset());
     if (old < 0)
 	return 1;
     if (uncompress) {
 	if (map_type == CELL_TYPE) {
-	    G_set_cell_format(cellhd.format);
-	    new = G_open_cell_new_uncompressed(name);
+	    Rast_set_cell_format(cellhd.format);
+	    new = Rast_open_cell_new_uncompressed(name);
 	else {
-	    G_set_fp_type(map_type);
-	    new = G_open_fp_cell_new_uncompressed(name);
+	    Rast_set_fp_type(map_type);
+	    new = Rast_open_fp_cell_new_uncompressed(name);
     else
-	new = G_open_raster_new(name, map_type);
+	new = Rast_open_raster_new(name, map_type);
     if (new < 0)
 	return 1;
-    rast = G_allocate_raster_buf(map_type);
+    rast = Rast_allocate_raster_buf(map_type);
     oldsize = lseek(old, (off_t) 0, SEEK_END);
     /* the null file is written automatically */
-	if (G_get_raster_row_nomask(old, rast, row, map_type) < 0)
+	if (Rast_get_raster_row_nomask(old, rast, row, map_type) < 0)
 	    break;
-	if (G_put_raster_row(new, rast, map_type) < 0)
+	if (Rast_put_raster_row(new, rast, map_type) < 0)
 	    break;
     G_free(rast);
-    G_close_cell(old);
+    Rast_close_cell(old);
     if (row < nrows) {
-	G_unopen_cell(new);
+	Rast_unopen_cell(new);
 	return 1;
-    G_close_cell(new);
+    Rast_close_cell(new);
     newsize = 0;
     newsize = lseek(old, (off_t) 0, SEEK_END);
     return 0;
Modified: grass/trunk/raster/r.contour/cont.c
--- grass/trunk/raster/r.contour/cont.c	2009-06-20 21:39:23 UTC (rev 38002)
+++ grass/trunk/raster/r.contour/cont.c	2009-06-20 22:03:23 UTC (rev 38003)
@@ -26,6 +26,7 @@
 #include <stdio.h>
 #include <math.h>
 #include <grass/Vect.h>
@@ -339,11 +340,11 @@
     p1 = curr->edge;
     p2 = (curr->edge + 1) % 4;
-    if (G_raster_cmp(&curr->z[p1], &curr->z[p2], DCELL_TYPE) == 0)
+    if (Rast_raster_cmp(&curr->z[p1], &curr->z[p2], DCELL_TYPE) == 0)
 	ratio = 1;
-    else if (G_is_d_null_value(&curr->z[p1]))
+    else if (Rast_is_d_null_value(&curr->z[p1]))
 	ratio = 1 / 2;
-    else if (G_is_d_null_value(&curr->z[p2]))
+    else if (Rast_is_d_null_value(&curr->z[p2]))
 	ratio = 1 / 2;
     else
 	ratio = (level - curr->z[p1]) / (curr->z[p2] - curr->z[p1]);
Modified: grass/trunk/raster/r.contour/main.c
--- grass/trunk/raster/r.contour/main.c	2009-06-20 21:39:23 UTC (rev 38002)
+++ grass/trunk/raster/r.contour/main.c	2009-06-20 22:03:23 UTC (rev 38003)
@@ -45,6 +45,7 @@
 #include <ctype.h>
 #include <float.h>
 #include <grass/dbmi.h>
@@ -131,11 +132,11 @@
     name = map->answer;
-    fd = G_open_cell_old(name, "");
+    fd = Rast_open_cell_old(name, "");
     if (fd < 0)
-    if (G_read_fp_range(name, "", &range) < 0)
+    if (Rast_read_fp_range(name, "", &range) < 0)
 	G_fatal_error(_("Unable to read fp range of raster map <%s>"),
 		      name);
@@ -219,7 +220,7 @@
     for (i = 0; i < nrow; i++) {
 	z_array[i] = (DCELL *) G_malloc(ncol * sizeof(DCELL));
-	G_get_d_raster_row(fd, z_array[i], i);
+	Rast_get_d_raster_row(fd, z_array[i], i);
 	G_percent(i + 1, nrow, 2);
     return z_array;
@@ -238,9 +239,9 @@
     double *lev;
     double tmp;
-    G_get_fp_range_min_max(range, &zmin, &zmax);
+    Rast_get_fp_range_min_max(range, &zmin, &zmax);
-    if (!G_is_d_null_value(&zmin) && !G_is_d_null_value(&zmax))
+    if (!Rast_is_d_null_value(&zmin) && !Rast_is_d_null_value(&zmax))
 	G_verbose_message(_("Range of data: min=%f, max=%f"), zmin, zmax);
     else
 	G_verbose_message(_("Range of data: empty"));
Modified: grass/trunk/raster/r.cost/btree.c
--- grass/trunk/raster/r.cost/btree.c	2009-06-20 21:39:23 UTC (rev 38002)
+++ grass/trunk/raster/r.cost/btree.c	2009-06-20 22:03:23 UTC (rev 38003)
@@ -38,6 +38,7 @@
 #include "local_proto.h"
 #include "memory.h"
 #include <stdlib.h>
Modified: grass/trunk/raster/r.cost/main.c
--- grass/trunk/raster/r.cost/main.c	2009-06-20 21:39:23 UTC (rev 38002)
+++ grass/trunk/raster/r.cost/main.c	2009-06-20 22:03:23 UTC (rev 38003)
@@ -61,6 +61,7 @@
 #include <sys/stat.h>
 #include <fcntl.h>
 #include <grass/site.h>
 #include <grass/segment.h>
 #include "cost.h"
@@ -260,7 +261,7 @@
     H_DIAG_fac =
 	(double)sqrt((double)(NS_fac * NS_fac + 4 * EW_fac * EW_fac));
-    G_set_d_null_value(&null_cost, 1);
+    Rast_set_d_null_value(&null_cost, 1);
     if (flag2->answer)
 	total_reviewed = 16;
@@ -303,7 +304,7 @@
     if ((opt6->answer == NULL) ||
 	(sscanf(opt6->answer, "%lf", &null_cost) != 1)) {
 	G_debug(1, "Null cells excluded from cost evaluation");
     else if (keep_nulls)
 	G_debug(1, "Null cell will be retained into output raster map");
@@ -314,10 +315,10 @@
 	    G_fatal_error(_("Vector map <%s> not found"), opt7->answer);
-    if (!G_is_d_null_value(&null_cost)) {
+    if (!Rast_is_d_null_value(&null_cost)) {
 	if (null_cost < 0.0) {
 	    G_warning(_("Assigning negative cost to null cell. Null cells excluded."));
     else {
@@ -347,13 +348,13 @@
     /*  Open cost cell layer for reading  */
-    cost_fd = G_open_cell_old(cost_layer, cost_mapset);
+    cost_fd = Rast_open_cell_old(cost_layer, cost_mapset);
     if (cost_fd < 0)
 	G_fatal_error(_("Unable to open raster map <%s>"), cost_layer);
-    data_type = G_get_raster_map_type(cost_fd);
-    cell = G_allocate_raster_buf(data_type);
+    data_type = Rast_get_raster_map_type(cost_fd);
+    cell = Rast_allocate_raster_buf(data_type);
     /*   Parameters for map submatrices   */
@@ -419,12 +420,12 @@
 	int i;
 	double p;
-	dsize = G_raster_size(data_type);
+	dsize = Rast_raster_size(data_type);
 	p = 0.0;
-	    if (G_get_raster_row(cost_fd, cell, row, data_type) < 0)
+	    if (Rast_get_raster_row(cost_fd, cell, row, data_type) < 0)
 			      cost_layer, row);
@@ -433,39 +434,39 @@
 	    switch (data_type) {
 	    case CELL_TYPE:
-		    if (G_is_null_value(ptr2, data_type)) {
+		    if (Rast_is_null_value(ptr2, data_type)) {
 			p = null_cost;
 		    else {
 			p = *(int *)ptr2;
 		    segment_put(&in_seg, &p, row, i);
-		    ptr2 = G_incr_void_ptr(ptr2, dsize);
+		    ptr2 = Rast_incr_void_ptr(ptr2, dsize);
 		break;
 	    case FCELL_TYPE:
 			p = null_cost;
 		    else {
 			p = *(float *)ptr2;
 		break;
 	    case DCELL_TYPE:
 			p = null_cost;
 		    else {
 			p = *(double *)ptr2;
 		break;
@@ -485,7 +486,7 @@
 	fbuff = (double *)G_malloc(ncols * sizeof(double));
-	G_set_d_null_value(fbuff, ncols);
+	Rast_set_d_null_value(fbuff, ncols);
@@ -506,7 +507,7 @@
 	    int i;
 	    fbuff =
 		(double *)G_malloc((unsigned int)(ncols * sizeof(double)));
@@ -629,16 +630,16 @@
 	search_mapset = G_find_file("cell", opt9->answer, "");
-	fd = G_open_cell_old(opt9->answer, search_mapset);
+	fd = Rast_open_cell_old(opt9->answer, search_mapset);
 	if (fd < 0)
 			  opt9->answer);
-	data_type2 = G_get_raster_map_type(fd);
+	data_type2 = Rast_get_raster_map_type(fd);
-	dsize2 = G_raster_size(data_type2);
+	dsize2 = Rast_raster_size(data_type2);
-	cell2 = G_allocate_raster_buf(data_type2);
+	cell2 = Rast_allocate_raster_buf(data_type2);
 	if (!cell2)
 	    G_fatal_error(_("Unable to allocate memory"));
@@ -646,17 +647,17 @@
 	G_message(_("Reading raster map <%s>..."), opt9->answer);
-	    if (G_get_raster_row(fd, cell2, row, data_type2) < 0)
+	    if (Rast_get_raster_row(fd, cell2, row, data_type2) < 0)
 			      opt9->answer, row);
 	    ptr2 = cell2;
 	    for (col = 0; col < ncols; col++) {
 		/* Did I understand that concept of cummulative cost map? - (pmx) 12 april 2000 */
-		if (!G_is_null_value(ptr2, data_type2)) {
+		if (!Rast_is_null_value(ptr2, data_type2)) {
 		    double cellval;
 		    if (start_with_raster_vals == 1) {
-			cellval = G_get_raster_value_d(ptr2, data_type2);
+			cellval = Rast_get_raster_value_d(ptr2, data_type2);
 			new_cell = insert(cellval, row, col);
 			segment_put(&out_seg, &cellval, row, col);
@@ -667,12 +668,12 @@
 		    got_one = 1;
-		ptr2 = G_incr_void_ptr(ptr2, dsize2);
+		ptr2 = Rast_incr_void_ptr(ptr2, dsize2);
 	G_percent(1, 1, 2);
-	G_close_cell(fd);
 	G_free(cell2);
 	if (!got_one)
@@ -724,7 +725,7 @@
 	/* If I've already been updated, delete me */
 	segment_get(&out_seg, &old_min_cost, pres_cell->row, pres_cell->col);
-	if (!G_is_d_null_value(&old_min_cost)) {
+	if (!Rast_is_d_null_value(&old_min_cost)) {
 	    if (pres_cell->min_cost > old_min_cost) {
 		delete(pres_cell);
 		pres_cell = get_lowest();
@@ -929,7 +930,7 @@
 		break;
-	    if (G_is_d_null_value(&min_cost))
+	    if (Rast_is_d_null_value(&min_cost))
 		continue;
 	    segment_get(&out_seg, &old_min_cost, row, col);
@@ -937,7 +938,7 @@
 		segment_get(&out_seg2, &old_cur_dir, row, col);
-	    if (G_is_d_null_value(&old_min_cost)) {
+	    if (Rast_is_d_null_value(&old_min_cost)) {
 		segment_put(&out_seg, &min_cost, row, col);
 		new_cell = insert(min_cost, row, col);
 		if (dir == 1) {
@@ -974,11 +975,11 @@
   OUT:
     /*  Open cumulative cost layer for writing   */
-    cum_fd = G_open_raster_new(cum_cost_layer, data_type);
+    cum_fd = Rast_open_raster_new(cum_cost_layer, data_type);
     if (dir == 1) {
-	dir_fd = G_open_raster_new(move_dir_layer, dir_data_type);
-	dir_cell = G_allocate_raster_buf(dir_data_type);
+	dir_fd = Rast_open_raster_new(move_dir_layer, dir_data_type);
+	dir_cell = Rast_allocate_raster_buf(dir_data_type);
     /*  Write pending updates by segment_put() to output map   */
@@ -992,7 +993,7 @@
     G_message(_("Writing raster map <%s>..."), cum_cost_layer);
     if (keep_nulls) {
-	cell2 = G_allocate_raster_buf(data_type);
+	cell2 = Rast_allocate_raster_buf(data_type);
     if (data_type == CELL_TYPE) {
@@ -1002,7 +1003,7 @@
 	    if (keep_nulls) {
-		if (G_get_raster_row(cost_fd, cell2, row, data_type) < 0)
+		if (Rast_get_raster_row(cost_fd, cell2, row, data_type) < 0)
 				  cost_layer, row);
@@ -1010,14 +1011,14 @@
 	    p2 = cell2;
 		if (keep_nulls) {
-		    if (G_is_null_value(p2++, data_type)) {
-			G_set_null_value((p + col), 1, data_type);
+		    if (Rast_is_null_value(p2++, data_type)) {
+			Rast_set_null_value((p + col), 1, data_type);
 			continue;
 		segment_get(&out_seg, &min_cost, row, col);
-		if (G_is_d_null_value(&min_cost)) {
+		if (Rast_is_d_null_value(&min_cost)) {
 		else {
 		    if (min_cost > peak)
@@ -1025,7 +1026,7 @@
 		    *(p + col) = (int)(min_cost + .5);
-	    G_put_raster_row(cum_fd, cell, data_type);
+	    Rast_put_raster_row(cum_fd, cell, data_type);
     else if (data_type == FCELL_TYPE) {
@@ -1035,7 +1036,7 @@
 	    if (keep_nulls) {
 				  cost_layer, row);
@@ -1043,14 +1044,14 @@
 	    p2 = cell2;
 		if (keep_nulls) {
 			continue;
 		else {
@@ -1058,7 +1059,7 @@
 		    *(p + col) = (float)(min_cost);
     else if (data_type == DCELL_TYPE) {
@@ -1068,7 +1069,7 @@
 	    if (keep_nulls) {
 				  cost_layer, row);
@@ -1076,14 +1077,14 @@
 	    p2 = cell2;
 		if (keep_nulls) {
 			continue;
 		else {
@@ -1091,7 +1092,7 @@
 		    *(p + col) = min_cost;
     G_percent(1, 1, 1);
@@ -1106,7 +1107,7 @@
 		segment_get(&out_seg2, &cur_dir, row, col);
 		*(p + col) = cur_dir;
-	    G_put_raster_row(dir_fd, dir_cell, dir_data_type);
+	    Rast_put_raster_row(dir_fd, dir_cell, dir_data_type);
@@ -1117,10 +1118,10 @@
     if (dir == 1) {
 	segment_release(&out_seg2);
-    G_close_cell(cost_fd);
-    G_close_cell(cum_fd);
+    Rast_close_cell(cost_fd);
+    Rast_close_cell(cum_fd);
     if (dir == 1) {
-	G_close_cell(dir_fd);
+	Rast_close_cell(dir_fd);
     close(in_fd);		/* close all files */
     close(out_fd);
@@ -1133,22 +1134,22 @@
 	unlink(dir_out_file);
-    G_short_history(cum_cost_layer, "raster", &history);
-    G_write_history(cum_cost_layer, &history);
+    Rast_short_history(cum_cost_layer, "raster", &history);
+    Rast_write_history(cum_cost_layer, &history);
     if (dir == 1) {
-	G_short_history(move_dir_layer, "raster", &history);
-	G_write_history(move_dir_layer, &history);
+	Rast_short_history(move_dir_layer, "raster", &history);
+	Rast_write_history(move_dir_layer, &history);
     /*  Create colours for output map    */
-     * G_read_range (cum_cost_layer, current_mapset, &range);
-     * G_get_range_min_max(&range, &min, &max);
+     * Rast_read_range (cum_cost_layer, current_mapset, &range);
+     * Rast_get_range_min_max(&range, &min, &max);
      * G_make_color_wave(&colors,min, max);
-     * G_write_colors (cum_cost_layer,current_mapset,&colors);
+     * Rast_write_colors (cum_cost_layer,current_mapset,&colors);
     G_done_msg(_("Peak cost value: %f."), peak);
Modified: grass/trunk/raster/r.cost/memory.c
--- grass/trunk/raster/r.cost/memory.c	2009-06-20 21:39:23 UTC (rev 38002)
+++ grass/trunk/raster/r.cost/memory.c	2009-06-20 22:03:23 UTC (rev 38003)
@@ -26,6 +26,7 @@
 #include <string.h>
 #include <errno.h>
 #include <grass/gis.h>
 #include "memory.h"
 #define NUM_IN_BLOCK	1024*8
Modified: grass/trunk/raster/r.covar/main.c
--- grass/trunk/raster/r.covar/main.c	2009-06-20 21:39:23 UTC (rev 38002)
+++ grass/trunk/raster/r.covar/main.c	2009-06-20 22:03:23 UTC (rev 38003)
@@ -21,6 +21,7 @@
 #include <string.h>
 #include <math.h>
@@ -73,9 +74,9 @@
     sum2 = (double **)G_malloc(nfiles * sizeof(double *));
     for (i = 0; i < nfiles; i++) {
 	sum2[i] = (double *)G_calloc(nfiles, sizeof(double));
-	dcell[i] = G_allocate_d_raster_buf();
+	dcell[i] = Rast_allocate_d_raster_buf();
 	name = maps->answers[i];
-	fd[i] = G_open_cell_old(name, "");
+	fd[i] = Rast_open_cell_old(name, "");
 	if (fd[i] < 0)
@@ -88,13 +89,13 @@
-	    if (G_get_d_raster_row(fd[i], dcell[i], row) < 0)
+	    if (Rast_get_d_raster_row(fd[i], dcell[i], row) < 0)
 		exit(1);
 	    /* ignore cells where any of the maps has null value */
-		if (G_is_d_null_value(&dcell[i][col]))
+		if (Rast_is_d_null_value(&dcell[i][col]))
 		    break;
 	    if (i != nfiles)
 		continue;
Modified: grass/trunk/raster/r.cross/cats.c
--- grass/trunk/raster/r.cross/cats.c	2009-06-20 21:39:23 UTC (rev 38002)
+++ grass/trunk/raster/r.cross/cats.c	2009-06-20 22:03:23 UTC (rev 38003)
@@ -48,7 +48,7 @@
 	lbl = get_label(cat[i], &labels[i]);
 	strcat(buf, lbl);
-    G_set_cat(result, buf, pcats);
+    Rast_set_cat(result, buf, pcats);
     return 0;
@@ -57,7 +57,7 @@
     char *lbl;
     static char temp[256];
-    lbl = G_get_cat(cat, labels);
+    lbl = Rast_get_cat(cat, labels);
     if (*lbl == 0)
 	sprintf(lbl = temp, "category %ld", (long)cat);
     return lbl;
Modified: grass/trunk/raster/r.cross/cross.c
--- grass/trunk/raster/r.cross/cross.c	2009-06-20 21:39:23 UTC (rev 38002)
+++ grass/trunk/raster/r.cross/cross.c	2009-06-20 22:03:23 UTC (rev 38003)
@@ -38,7 +38,7 @@
     /* allocate i/o buffers for each raster map */
-	cell[i] = G_allocate_cell_buf();
+	cell[i] = Rast_allocate_cell_buf();
     result_cell = cell[0];
     /* initialize the reclass table */
@@ -54,13 +54,13 @@
 	G_percent(row, nrows, 5);
 	/* read the primary file first, even if not first in the list */
-	if (G_get_map_row(fd[primary], cell[0], row) < 0)
+	if (Rast_get_map_row(fd[primary], cell[0], row) < 0)
 	    exit(1);
 	/* read the others */
 	col = 1;
-	    if (i != primary && G_get_map_row(fd[i], cell[col++], row) < 0)
+	    if (i != primary && Rast_get_map_row(fd[i], cell[col++], row) < 0)
 		exit(1);
 	    zero = 1;
@@ -170,7 +170,7 @@
 		pnode->right = N;	/* add right */
-	G_put_raster_row(outfd, result_cell, CELL_TYPE);
+	Rast_put_raster_row(outfd, result_cell, CELL_TYPE);
     G_percent(nrows, nrows, 5);
Modified: grass/trunk/raster/r.cross/glob.h
--- grass/trunk/raster/r.cross/glob.h	2009-06-20 21:39:23 UTC (rev 38002)
+++ grass/trunk/raster/r.cross/glob.h	2009-06-20 22:03:23 UTC (rev 38003)
@@ -20,6 +20,8 @@
 #define __R_CROSS_GLOB_H__
 #define NFILES 30		/* maximum number of layers */
 #define SHIFT 6			/* 2^SHIFT cats per node */
Modified: grass/trunk/raster/r.cross/main.c
--- grass/trunk/raster/r.cross/main.c	2009-06-20 21:39:23 UTC (rev 38002)
+++ grass/trunk/raster/r.cross/main.c	2009-06-20 22:03:23 UTC (rev 38003)
@@ -107,10 +107,10 @@
 	if (!mapset)
 	names[nfiles] = name;
-	fd[nfiles] = G_open_cell_old(name, mapset);
+	fd[nfiles] = Rast_open_cell_old(name, mapset);
 	if (fd[nfiles] < 0)
-	G_read_range(name, mapset, &range);
+	Rast_read_range(name, mapset, &range);
 	ncats = range.max - range.min;
 	if (nfiles == 0 || ncats > max_cats) {
@@ -122,7 +122,7 @@
     if (nfiles <= 1)
 	G_fatal_error(_("Must specify 2 or more input maps"));
     output = parm.output->answer;
-    outfd = G_open_cell_new(output);
+    outfd = Rast_open_cell_new(output);
     if (outfd < 0)
@@ -135,7 +135,7 @@
     strcat(buf, " and ");
     strcat(buf, names[i]);
-    G_init_cats((CELL) 0, buf, &pcats);
+    Rast_init_cats((CELL) 0, buf, &pcats);
     /* first step is cross product, but un-ordered */
     result = cross(fd, non_zero, primary, outfd);
@@ -145,8 +145,8 @@
     /* now close all files */
-	G_close_cell(fd[i]);
+	Rast_close_cell(fd[i]);
     if (result <= 0)
 	exit(0);
@@ -157,7 +157,7 @@
     table = (CELL *) G_calloc(result + 1, sizeof(CELL));
 	mapset = G_find_cell2(names[i], "");
-	G_read_cats(names[i], mapset, &labels[i]);
+	Rast_read_cats(names[i], mapset, &labels[i]);
     for (ncats = 0; ncats <= result; ncats++) {
@@ -166,22 +166,22 @@
-	G_free_cats(&labels[i]);
+	Rast_free_cats(&labels[i]);
     /* reopen the output cell for reading and for writing */
-    fd[0] = G_open_cell_old(output, G_mapset());
+    fd[0] = Rast_open_cell_old(output, G_mapset());
     renumber(fd[0], outfd);
     G_message(_("Creating support files for <%s>..."), output);
-    G_close_cell(fd[0]);
+    Rast_close_cell(fd[0]);
     if (result > 0) {
-	G_make_random_colors(&pcolr, (CELL) 1, result);
-	G_write_colors(output, G_mapset(), &pcolr);
+	Rast_make_random_colors(&pcolr, (CELL) 1, result);
+	Rast_write_colors(output, G_mapset(), &pcolr);
     G_message(_("%ld categories"), (long)result);
Modified: grass/trunk/raster/r.cross/renumber.c
--- grass/trunk/raster/r.cross/renumber.c	2009-06-20 21:39:23 UTC (rev 38002)
+++ grass/trunk/raster/r.cross/renumber.c	2009-06-20 22:03:23 UTC (rev 38003)
@@ -27,19 +27,19 @@
     CELL *cell, *c;
     int row, col;
     G_message(_("%s: STEP 3 ... "), G_program_name());
-	if (G_get_map_row(in, c = cell, row) < 0)
+	if (Rast_get_map_row(in, c = cell, row) < 0)
 	    exit(1);
 	col = ncols;
 	while (col-- > 0) {
 	    *c = table[*c];
 	    c++;
-	if (G_put_raster_row(out, cell, CELL_TYPE) < 0)
+	if (Rast_put_raster_row(out, cell, CELL_TYPE) < 0)
 	    exit(1);
Modified: grass/trunk/raster/r.describe/describe.c
--- grass/trunk/raster/r.describe/describe.c	2009-06-20 21:39:23 UTC (rev 38002)
+++ grass/trunk/raster/r.describe/describe.c	2009-06-20 22:03:23 UTC (rev 38003)
@@ -17,6 +17,7 @@
@@ -39,25 +40,25 @@
     int (*get_row)(int, CELL *, int);
     if (windowed) {
-	get_row = G_get_c_raster_row;
+	get_row = Rast_get_c_raster_row;
     else {
-	if (G_get_cellhd(name, "", &window) < 0)
+	if (Rast_get_cellhd(name, "", &window) < 0)
 	    G_fatal_error(_("Unable to get cell header for <%s>"), name);
-	get_row = G_get_c_raster_row_nomask;
+	get_row = Rast_get_c_raster_row_nomask;
     if (fd < 0)
 	return 0;
-    map_type = G_get_raster_map_type(fd);
+    map_type = Rast_get_raster_map_type(fd);
     if (as_int)
 	map_type = CELL_TYPE;	/* read as int */
     /* allocate the cell buffer */
-    buf = G_allocate_cell_buf();
+    buf = Rast_allocate_cell_buf();
     if (map_type != CELL_TYPE && range)
 	/* this will make it report fp range */
@@ -68,7 +69,7 @@
     /* start the cell stats */
     if (!range) {
     else {
 	zero = 0;
@@ -83,11 +84,11 @@
     /* set up quantization rules */
-	G_quant_init(&q);
-	G_read_fp_range(name, "", &r);
-	G_get_fp_range_min_max(&r, &dmin, &dmax);
-	G_quant_add_rule(&q, dmin, dmax, 1, nsteps);
-	G_set_quant_rules(fd, &q);
+	Rast_quant_init(&q);
+	Rast_read_fp_range(name, "", &r);
+	Rast_get_fp_range_min_max(&r, &dmin, &dmax);
+	Rast_quant_add_rule(&q, dmin, dmax, 1, nsteps);
+	Rast_set_quant_rules(fd, &q);
@@ -100,7 +101,7 @@
 	    break;
 	if (range) {
 	    for (col = ncols; col-- > 0; b++) {
-		if (G_is_c_null_value(b))
+		if (Rast_is_c_null_value(b))
 		    null = 1;
 		else if (*b == 0)
 		    zero = 1;
@@ -123,10 +124,10 @@
 	else
-	    G_update_cell_stats(buf, ncols, &statf);
+	    Rast_update_cell_stats(buf, ncols, &statf);
     G_percent(nrows, nrows, 2);
-    G_close_cell(fd);
     G_free(buf);
     if (range) {
@@ -138,7 +139,7 @@
 		       no_data_str, skip_nulls);
     else {
 	if (compact)
 	    compact_list(&statf, dmin, dmax, no_data_str, skip_nulls,
@@ -147,7 +148,7 @@
 	    long_list(&statf, dmin, dmax, no_data_str, skip_nulls, map_type,
 		      nsteps);
-	G_free_cell_stats(&statf);
+	Rast_free_cell_stats(&statf);
     return 1;
Modified: grass/trunk/raster/r.describe/dumplist.c
--- grass/trunk/raster/r.describe/dumplist.c	2009-06-20 21:39:23 UTC (rev 38002)
+++ grass/trunk/raster/r.describe/dumplist.c	2009-06-20 22:03:23 UTC (rev 38003)
@@ -18,6 +18,7 @@
 #include <string.h>
 static int show(CELL, CELL, int *, DCELL, DCELL, RASTER_MAP_TYPE, int);
@@ -30,11 +31,11 @@
     CELL cat;
     long count;			/* not used, but required by cell stats call */
-    G_get_stats_for_null_value(&count, statf);
+    Rast_get_stats_for_null_value(&count, statf);
     if (count != 0 && !skip_nulls)
 	fprintf(stdout, "%s\n", no_data_str);
-    while (G_next_cell_stat(&cat, &count, statf)) {
+    while (Rast_next_cell_stat(&cat, &count, statf)) {
 	    fprintf(stdout, "%f-%f\n",
 		    dmin + (double)(cat - 1) * (dmax - dmin) / nsteps,
@@ -56,16 +57,16 @@
     len = 0;
 	fprintf(stdout, "%s ", no_data_str);
-    if (!G_next_cell_stat(&cat1, &count, statf))
+    if (!Rast_next_cell_stat(&cat1, &count, statf))
 	/* map doesn't contain any non-null data */
 	return 1;
     cat2 = cat1;
-    while (G_next_cell_stat(&temp, &count, statf)) {
+    while (Rast_next_cell_stat(&temp, &count, statf)) {
 	if (temp != cat2 + (CELL) 1) {
 	    show(cat1, cat2, &len, dmin, dmax, map_type, nsteps);
 	    cat1 = temp;
Modified: grass/trunk/raster/r.describe/main.c
--- grass/trunk/raster/r.describe/main.c	2009-06-20 21:39:23 UTC (rev 38002)
+++ grass/trunk/raster/r.describe/main.c	2009-06-20 22:03:23 UTC (rev 38003)
@@ -20,6 +20,7 @@
 #include <string.h>
 #include <stdio.h>
Modified: grass/trunk/raster/r.describe/tree.c
--- grass/trunk/raster/r.describe/tree.c	2009-06-20 21:39:23 UTC (rev 38002)
+++ grass/trunk/raster/r.describe/tree.c	2009-06-20 22:03:23 UTC (rev 38003)
@@ -17,6 +17,7 @@
 #define INCR 10
Modified: grass/trunk/raster/r.digit/digitize.c
--- grass/trunk/raster/r.digit/digitize.c	2009-06-20 21:39:23 UTC (rev 38002)
+++ grass/trunk/raster/r.digit/digitize.c	2009-06-20 22:03:23 UTC (rev 38003)
@@ -27,7 +27,7 @@
     int any;
     struct Categories labels;
-    G_init_cats((CELL) 0, "", &labels);
+    Rast_init_cats((CELL) 0, "", &labels);
     any = 0;
     for (;;) {
 	switch (get_type()) {
Modified: grass/trunk/raster/r.digit/get_label.c
--- grass/trunk/raster/r.digit/get_label.c	2009-06-20 21:39:23 UTC (rev 38002)
+++ grass/trunk/raster/r.digit/get_label.c	2009-06-20 22:03:23 UTC (rev 38003)
@@ -44,7 +44,7 @@
     for (;;) {
 	fprintf(stdout, _("Enter a label for category %ld [%s] "),
-		cat, G_get_cat((CELL) cat, labels));
+		cat, Rast_get_cat((CELL) cat, labels));
 	if (!G_gets(buffer))
 	    continue;;
 	G_strip(buffer);
@@ -64,10 +64,10 @@
 	cat = get_cat(type);
 	lbl = get_label(cat, labels);
 	fprintf(stdout, "%ld [%s]\n", cat,
-		*lbl ? lbl : G_get_cat((CELL) cat, labels));
+		*lbl ? lbl : Rast_get_cat((CELL) cat, labels));
     } while (!G_yes(_("Look ok? "), 1));
     if (*lbl)
-	G_set_cat((CELL) cat, lbl, labels);
+	Rast_set_cat((CELL) cat, lbl, labels);
     fprintf(fd, "= %ld %s\n", cat, lbl);
     return (0);
Modified: grass/trunk/raster/r.distance/defs.h
--- grass/trunk/raster/r.distance/defs.h	2009-06-20 21:39:23 UTC (rev 38002)
+++ grass/trunk/raster/r.distance/defs.h	2009-06-20 22:03:23 UTC (rev 38003)
@@ -20,6 +20,7 @@
 #define __R_DIST_DEFS_H__
 struct EdgeList			/* keep track of edge cells */
Modified: grass/trunk/raster/r.distance/distance.c
--- grass/trunk/raster/r.distance/distance.c	2009-06-20 21:39:23 UTC (rev 38002)
+++ grass/trunk/raster/r.distance/distance.c	2009-06-20 22:03:23 UTC (rev 38003)
@@ -86,14 +86,14 @@
     /* NOTE: no need to controll, if the map exists. it should be checked in edge.c */
     mapset = G_find_cell2(name1, "");
-    maptype1 = G_raster_map_type(name1, mapset);
-    mapd1 = G_open_cell_old(name1, mapset);
-    inrast1 = G_allocate_raster_buf(maptype1);
+    maptype1 = Rast_raster_map_type(name1, mapset);
+    mapd1 = Rast_open_cell_old(name1, mapset);
+    inrast1 = Rast_allocate_raster_buf(maptype1);
     mapset = G_find_cell2(name2, "");
-    maptype2 = G_raster_map_type(name2, mapset);
-    mapd2 = G_open_cell_old(name2, mapset);
-    inrast2 = G_allocate_raster_buf(maptype2);
+    maptype2 = Rast_raster_map_type(name2, mapset);
+    mapd2 = Rast_open_cell_old(name2, mapset);
+    inrast2 = Rast_allocate_raster_buf(maptype2);
     G_message(_("Reading maps  <%s,%s> while finding 0 distance ..."), name1,
 	      name2);
@@ -105,9 +105,9 @@
-	if (G_get_raster_row(mapd1, inrast1, row, maptype1) < 0)
+	if (Rast_get_raster_row(mapd1, inrast1, row, maptype1) < 0)
 	    G_fatal_error("Could not read from <%s>", name1);
-	if (G_get_raster_row(mapd2, inrast2, row, maptype2) < 0)
+	if (Rast_get_raster_row(mapd2, inrast2, row, maptype2) < 0)
 	    G_fatal_error("Could not read from <%s>", name2);
@@ -137,8 +137,8 @@
 		break;
-	    if (!G_is_null_value(&cell1, maptype1) &&
-		!G_is_null_value(&cell2, maptype2)) {
+	    if (!Rast_is_null_value(&cell1, maptype1) &&
+		!Rast_is_null_value(&cell2, maptype2)) {
 		*zerro_row = row;
 		*zerro_col = col;
@@ -148,8 +148,8 @@
 		G_free(inrast2);
 		/* closing raster maps */
-		G_close_cell(mapd1);
-		G_close_cell(mapd2);
+		Rast_close_cell(mapd1);
+		Rast_close_cell(mapd2);
 		return 1;
@@ -159,8 +159,8 @@
     G_free(inrast2);
     return 0;
Modified: grass/trunk/raster/r.distance/edges.c
--- grass/trunk/raster/r.distance/edges.c	2009-06-20 21:39:23 UTC (rev 38002)
+++ grass/trunk/raster/r.distance/edges.c	2009-06-20 22:03:23 UTC (rev 38003)
@@ -54,7 +54,7 @@
 	buf2[col] = 0;
-    fd = G_open_cell_old(map->name, map->mapset);
+    fd = Rast_open_cell_old(map->name, map->mapset);
     if (fd < 0)
 	exit(1);
@@ -69,7 +69,7 @@
 	buf2 = tmp;
 	/* read a row */
-	if (G_get_map_row(fd, &buf1[1], row) < 0)
+	if (Rast_get_map_row(fd, &buf1[1], row) < 0)
 	    exit(1);
 	for (col = 1; col <= ncols; col++) {
@@ -83,7 +83,7 @@
-    G_close_cell(fd);
     G_free(buf0);
     G_free(buf1);
Modified: grass/trunk/raster/r.distance/labels.c
--- grass/trunk/raster/r.distance/labels.c	2009-06-20 21:39:23 UTC (rev 38002)
+++ grass/trunk/raster/r.distance/labels.c	2009-06-20 22:03:23 UTC (rev 38003)
@@ -21,13 +21,13 @@
 void read_labels(struct Map *map)
-    if (G_read_cats(map->name, map->mapset, &map->labels) < 0)
+    if (Rast_read_cats(map->name, map->mapset, &map->labels) < 0)
 	exit(1);
 char *get_label(struct Map *map, CELL cat)
-    char *G_get_cat();
+    char *Rast_get_cat();
-    return G_get_cat(cat, &map->labels);
+    return Rast_get_cat(cat, &map->labels);
Modified: grass/trunk/raster/r.distance/main.c
--- grass/trunk/raster/r.distance/main.c	2009-06-20 21:39:23 UTC (rev 38002)
+++ grass/trunk/raster/r.distance/main.c	2009-06-20 22:03:23 UTC (rev 38003)
@@ -20,6 +20,7 @@
 #include <stdio.h>
 #include "defs.h"
 int main(int argc, char *argv[])
Modified: grass/trunk/raster/r.distance/parse.c
--- grass/trunk/raster/r.distance/parse.c	2009-06-20 21:39:23 UTC (rev 38002)
+++ grass/trunk/raster/r.distance/parse.c	2009-06-20 22:03:23 UTC (rev 38003)
@@ -20,6 +20,7 @@
 #include <stdio.h>
 #include "defs.h"
 void parse(int argc, char *argv[], struct Parms *parms)
Modified: grass/trunk/raster/r.drain/filldir.c
--- grass/trunk/raster/r.drain/filldir.c	2009-06-20 21:39:23 UTC (rev 38002)
+++ grass/trunk/raster/r.drain/filldir.c	2009-06-20 22:03:23 UTC (rev 38003)
@@ -3,6 +3,7 @@
 #include <limits.h>
 #include <float.h>
 #include "tinf.h"
 #include "local.h"
@@ -45,7 +46,7 @@
 	offset = j * bpe();
 	center = bnd->b[1] + offset;
 	if (is_null(center)) {
-	    G_set_c_null_value(dir + j, 1);
+	    Rast_set_c_null_value(dir + j, 1);
 	    continue;
Modified: grass/trunk/raster/r.drain/main.c
--- grass/trunk/raster/r.drain/main.c	2009-06-20 21:39:23 UTC (rev 38002)
+++ grass/trunk/raster/r.drain/main.c	2009-06-20 22:03:23 UTC (rev 38003)
@@ -40,6 +40,7 @@
 #include <unistd.h>
@@ -180,7 +181,7 @@
 			  ("Direction raster not specified, if direction flag is on, a direction raster must be given"));
 	strcpy(dir_name, opt3->answer);
-	dir_data_type = G_raster_map_type(dir_name, "");
+	dir_data_type = Rast_raster_map_type(dir_name, "");
     if (costmode == 0) {
 	if (opt3->answer) {
@@ -202,7 +203,7 @@
 	Vect_hist_command(&vout);
     /*      allocate cell buf for the map layer */
-    in_type = G_raster_map_type(map_name, "");
+    in_type = Rast_raster_map_type(map_name, "");
     /* set the pointers for multi-typed functions */
     set_func_pointers(in_type);
@@ -342,7 +343,7 @@
     in_buf = get_buf();
     /* open the original map and get its file id  */
-    map_id = G_open_cell_old(map_name, "");
+    map_id = Rast_open_cell_old(map_name, "");
     /* get some temp files */
     tempfile1 = G_tempfile();
@@ -356,19 +357,19 @@
 	get_row(map_id, in_buf, i);
 	write(fe, in_buf, bnd.sz);
-    G_close_cell(map_id);
+    Rast_close_cell(map_id);
     if (costmode == 1) {
-	dir_buf = G_allocate_d_raster_buf();
-	dir_id = G_open_cell_old(dir_name, "");
+	dir_buf = Rast_allocate_d_raster_buf();
+	dir_id = Rast_open_cell_old(dir_name, "");
 	tempfile3 = G_tempfile();
 	dir_fd = open(tempfile3, O_RDWR | O_CREAT, 0666);
 	for (i = 0; i < nrows; i++) {
-	    G_get_d_raster_row(dir_id, dir_buf, i);
+	    Rast_get_d_raster_row(dir_id, dir_buf, i);
 	    write(dir_fd, dir_buf, ncols * sizeof(DCELL));
-	G_close_cell(dir_id);
+	Rast_close_cell(dir_id);
     /* only necessary for non-dir drain */
@@ -415,8 +416,8 @@
 	/* Output will be a cell map */
 	/* open a new file and allocate an output buffer */
-	new_id = G_open_cell_new(new_map_name);
-	out_buf = G_allocate_c_raster_buf();
+	new_id = Rast_open_cell_new(new_map_name);
+	out_buf = Rast_allocate_c_raster_buf();
 	/* mark each cell */
 	thispoint = list;
@@ -446,21 +447,21 @@
 		  new_map_name);
 	    G_percent(i, nrows, 2);
-	    G_set_c_null_value(out_buf, ncols);
+	    Rast_set_c_null_value(out_buf, ncols);
 	    thispoint = list;
 	    while (thispoint->next != NULL) {
 		if (thispoint->row == i)
 		    out_buf[thispoint->col] = (int)thispoint->value;
 		thispoint = thispoint->next;
-	    G_put_c_raster_row(new_id, out_buf);
+	    Rast_put_c_raster_row(new_id, out_buf);
 	G_percent(1, 1, 1);
     else {			/* mode = 1 or 2 */
 	/* Output will be of the same type as input */
-	new_id = G_open_raster_new(new_map_name, in_type);
+	new_id = Rast_open_raster_new(new_map_name, in_type);
 	out_buf = get_buf();
 	bsz = ncols * bpe();
@@ -545,13 +546,13 @@
     /* close files and free buffers */
-    G_close_cell(new_id);
+    Rast_close_cell(new_id);
-    G_put_cell_title(new_map_name, "Surface flow trace");
+    Rast_put_cell_title(new_map_name, "Surface flow trace");
-    G_short_history(new_map_name, "raster", &history);
-    G_write_history(new_map_name, &history);
+    Rast_short_history(new_map_name, "raster", &history);
+    Rast_write_history(new_map_name, &history);
     close(fe);
     close(fd);
@@ -577,7 +578,7 @@
     CELL direction;
     CELL *dir;
-    dir = G_allocate_c_raster_buf();
+    dir = Rast_allocate_c_raster_buf();
     next_row = list->row;
     next_col = list->col;
@@ -643,7 +644,7 @@
     DCELL direction;
     DCELL *dir_buf;
Modified: grass/trunk/raster/r.drain/resolve.c
--- grass/trunk/raster/r.drain/resolve.c	2009-06-20 21:39:23 UTC (rev 38002)
+++ grass/trunk/raster/r.drain/resolve.c	2009-06-20 22:03:23 UTC (rev 38003)
@@ -1,6 +1,7 @@
 #include <stdlib.h>
 #include <string.h>
 #include "tinf.h"
 CELL select_dir(CELL i)
@@ -38,7 +39,7 @@
     int k;
     cwork = p2[j];
-    if (G_is_c_null_value(p2 + j) || cwork >= 0 || cwork == -256)
+    if (Rast_is_c_null_value(p2 + j) || cwork >= 0 || cwork == -256)
 	return;
     cwork = -cwork;
@@ -110,7 +111,7 @@
 	read(fd, bnd->b[0], bnd->sz);
 	for (j = 1; j < bnd->ns - 1; j += 1) {
 	    offset = j * isz;
-	    if (G_is_c_null_value((void *)(bnd->b[0] + offset)))
+	    if (Rast_is_c_null_value((void *)(bnd->b[0] + offset)))
 		continue;
 	    memcpy(&cvalue, bnd->b[0] + offset, isz);
 	    if (cvalue > 0)
Modified: grass/trunk/raster/r.drain/tinf.c
--- grass/trunk/raster/r.drain/tinf.c	2009-06-20 21:39:23 UTC (rev 38002)
+++ grass/trunk/raster/r.drain/tinf.c	2009-06-20 22:03:23 UTC (rev 38003)
@@ -2,6 +2,7 @@
 #include <float.h>
 #include <math.h>
 #include "tinf.h"
 int (*is_null) (void *);
@@ -92,29 +93,29 @@
 /* check for null values */
 int is_null_c(void *value)
-    return G_is_c_null_value((CELL *) value);
+    return Rast_is_c_null_value((CELL *) value);
 int is_null_f(void *value)
-    return G_is_f_null_value((FCELL *) value);
+    return Rast_is_f_null_value((FCELL *) value);
 int is_null_d(void *value)
-    return G_is_d_null_value((DCELL *) value);
+    return Rast_is_d_null_value((DCELL *) value);
 /* set null values in buffer */
 void set_null_value_c(void *value, int num)
-    G_set_c_null_value((CELL *) value, num);
+    Rast_set_c_null_value((CELL *) value, num);
 void set_null_value_f(void *value, int num)
-    G_set_f_null_value((FCELL *) value, num);
+    Rast_set_f_null_value((FCELL *) value, num);
 void set_null_value_d(void *value, int num)
-    G_set_d_null_value((DCELL *) value, num);
+    Rast_set_d_null_value((DCELL *) value, num);
 /* return the size of the current type */
@@ -198,49 +199,49 @@
 /* Read one line from a raster map */
 int get_row_c(int fd, void *row, int n)
-    return G_get_c_raster_row(fd, (CELL *) row, n);
+    return Rast_get_c_raster_row(fd, (CELL *) row, n);
 int get_row_f(int fd, void *row, int n)
-    return G_get_f_raster_row(fd, (FCELL *) row, n);
+    return Rast_get_f_raster_row(fd, (FCELL *) row, n);
 int get_row_d(int fd, void *row, int n)
-    return G_get_d_raster_row(fd, (DCELL *) row, n);
+    return Rast_get_d_raster_row(fd, (DCELL *) row, n);
 /* Write one row to a raster map */
 int put_row_c(int fd, void *row)
-    return G_put_c_raster_row(fd, (CELL *) row);
+    return Rast_put_c_raster_row(fd, (CELL *) row);
 int put_row_f(int fd, void *row)
-    return G_put_f_raster_row(fd, (FCELL *) row);
+    return Rast_put_f_raster_row(fd, (FCELL *) row);
 int put_row_d(int fd, void *row)
-    return G_put_d_raster_row(fd, (DCELL *) row);
+    return Rast_put_d_raster_row(fd, (DCELL *) row);
 /* Allocate memory for one line of data */
 void *get_buf_c(void)
-    return (void *)G_allocate_c_raster_buf();
+    return (void *)Rast_allocate_c_raster_buf();
 void *get_buf_f(void)
-    return (void *)G_allocate_f_raster_buf();
+    return (void *)Rast_allocate_f_raster_buf();
 void *get_buf_d(void)
-    return (void *)G_allocate_d_raster_buf();
+    return (void *)Rast_allocate_d_raster_buf();
 /* initialize memory to a minimum value */
@@ -336,7 +337,7 @@
     rc = -HUGE_VAL;
     pedge = (CELL *) line2;
-    if (!G_is_c_null_value(pedge)) {
+    if (!Rast_is_c_null_value(pedge)) {
 	rc = (*(CELL *) line1 - *pedge) / cnst;
     return rc;
@@ -349,7 +350,7 @@
     rc = -HUGE_VAL;
     pedge = (FCELL *) line2;
-    if (!G_is_f_null_value(pedge)) {
+    if (!Rast_is_f_null_value(pedge)) {
 	rc = (*(FCELL *) line1 - *pedge) / cnst;
     return rc;
@@ -362,7 +363,7 @@
     rc = -HUGE_VAL;
     pedge = (DCELL *) line2;
-    if (!G_is_d_null_value(pedge)) {
+    if (!Rast_is_d_null_value(pedge)) {
 	rc = (*(DCELL *) line1 - *pedge) / cnst;
     return rc;
Modified: grass/trunk/raster/r.external/main.c
--- grass/trunk/raster/r.external/main.c	2009-06-20 21:39:23 UTC (rev 38002)
+++ grass/trunk/raster/r.external/main.c	2009-06-20 22:03:23 UTC (rev 38003)
@@ -20,6 +20,7 @@
 #include <math.h>
 #include <string.h>
 #include <grass/imagery.h>
 #include <grass/gprojects.h>
 #include <grass/glocale.h>
@@ -318,7 +319,7 @@
     if(!(bGotMin && bGotMax))
 	GDALComputeRasterMinMax(hBand, !exact_range, info->range);
-    G_init_colors(&info->colors);
+    Rast_init_colors(&info->colors);
     if (GDALGetRasterColorTable(hBand) != NULL) {
 	GDALColorTableH hCT;
@@ -336,7 +337,7 @@
 	    if (sEntry.c4 == 0)
 		continue;
-	    G_set_color(i, sEntry.c1, sEntry.c2, sEntry.c3, &info->colors);
+	    Rast_set_color(i, sEntry.c1, sEntry.c2, sEntry.c3, &info->colors);
     else {
@@ -344,13 +345,13 @@
 	    /* set full 0..255 range to grey scale: */
 	    G_verbose_message(_("Setting grey color table for <%s> (full 8bit range)"),
 			      output);
-	    G_make_grey_scale_colors(&info->colors, 0, 255);
+	    Rast_make_grey_scale_colors(&info->colors, 0, 255);
 	else  {
 	    /* set data range to grey scale: */
 	    G_verbose_message(_("Setting grey color table for <%s> (data range)"),
 			      output);
 				     (int) info->range[0], (int) info->range[1]);
@@ -447,10 +448,10 @@
     struct Quant quant;
-    G_quant_round(&quant);
+    Rast_quant_round(&quant);
-    if (G_write_quant(output, G_mapset(), &quant) < 0)
+    if (Rast_write_quant(output, G_mapset(), &quant) < 0)
 	G_warning(_("Unable to write quant file"));
@@ -460,7 +461,7 @@
     struct History history;
-    G_put_cellhd(output, cellhd);
+    Rast_put_cellhd(output, cellhd);
     make_cell(output, info);
@@ -471,27 +472,27 @@
 	range.min = (CELL)info->range[0];
 	range.max = (CELL)info->range[1];
 	range.first_time = 0;
-	G_write_range(output, &range);
+	Rast_write_range(output, &range);
     else {
 	struct FPRange fprange;
 	fprange.min = info->range[0];
 	fprange.max = info->range[1];
 	fprange.first_time = 0;
-	G_write_fp_range(output, &fprange);
+	Rast_write_fp_range(output, &fprange);
 	write_fp_format(output, info);
 	write_fp_quant(output);
     G_verbose_message(_("Creating support files for %s"), output);
-    G_short_history(output, "raster", &history);
-    G_write_history(output, &history);
+    Rast_short_history(output, "raster", &history);
+    Rast_write_history(output, &history);
-    G_write_colors(output, G_mapset(), &info->colors);
+    Rast_write_colors(output, G_mapset(), &info->colors);
     if (title)
-	G_put_cell_title(output, title);
+	Rast_put_cell_title(output, title);
     G_message(_("<%s> created"), output);
Modified: grass/trunk/raster/r.fill.dir/dopolys.c
--- grass/trunk/raster/r.fill.dir/dopolys.c	2009-06-20 21:39:23 UTC (rev 38002)
+++ grass/trunk/raster/r.fill.dir/dopolys.c	2009-06-20 22:03:23 UTC (rev 38003)
@@ -1,6 +1,7 @@
 #include <unistd.h>
 #include <stdlib.h>
 void recurse_list(int flag, int *cells, int sz, int start)
@@ -54,7 +55,7 @@
     for (i = 1; i < nl - 1; i += 1) {
 	read(fd, dir, bufsz);
 	for (j = 1; j < ns - 1; j += 1) {
-	    if (G_is_c_null_value(&dir[j]) || dir[j] >= 0)
+	    if (Rast_is_c_null_value(&dir[j]) || dir[j] >= 0)
 		continue;
 	    cells[found++] = i;
 	    cells[found++] = j;
Modified: grass/trunk/raster/r.fill.dir/filldir.c
--- grass/trunk/raster/r.fill.dir/filldir.c	2009-06-20 21:39:23 UTC (rev 38002)
+++ grass/trunk/raster/r.fill.dir/filldir.c	2009-06-20 22:03:23 UTC (rev 38003)
@@ -5,6 +5,7 @@
 #include <limits.h>
 #include <float.h>
 #include "tinf.h"
 /* get the slope between two cells and return a slope direction */
@@ -89,7 +90,7 @@
 	offset = j * bpe();
 	    continue;
Modified: grass/trunk/raster/r.fill.dir/main.c
--- grass/trunk/raster/r.fill.dir/main.c	2009-06-20 21:39:23 UTC (rev 38002)
+++ grass/trunk/raster/r.fill.dir/main.c	2009-06-20 22:03:23 UTC (rev 38003)
@@ -48,6 +48,7 @@
 #include <unistd.h>
 #define DEBUG
@@ -173,10 +174,10 @@
 	G_fatal_error(_("Raster map <%s> not found"), map_name);
     /* open the maps and get their file id  */
-    map_id = G_open_cell_old(map_name, map_mapset);
+    map_id = Rast_open_cell_old(map_name, map_mapset);
-    in_type = G_get_raster_map_type(map_id);
+    in_type = Rast_get_raster_map_type(map_id);
@@ -215,7 +216,7 @@
     /* fill single-cell holes and take a first stab at flow directions */
     G_message(_("Filling sinks..."));
@@ -249,25 +250,25 @@
     G_free(bnd.b[1]);
     G_free(bnd.b[2]);
     bufsz = ncols * sizeof(CELL);
     lseek(fe, 0, SEEK_SET);
     lseek(fd, 0, SEEK_SET);
-    dir_id = G_open_raster_new(dir_name, CELL_TYPE);
+    dir_id = Rast_open_raster_new(dir_name, CELL_TYPE);
     if (opt5->answer != NULL) {
 	lseek(fm, 0, SEEK_SET);
-	bas_id = G_open_raster_new(bas_name, CELL_TYPE);
+	bas_id = Rast_open_raster_new(bas_name, CELL_TYPE);
 	    read(fm, out_buf, bufsz);
-	    G_put_raster_row(bas_id, out_buf, CELL_TYPE);
+	    Rast_put_raster_row(bas_id, out_buf, CELL_TYPE);
-	G_close_cell(bas_id);
+	Rast_close_cell(bas_id);
 	close(fm);
@@ -280,14 +281,14 @@
 	for (j = 0; j < ncols; j += 1)
 	    out_buf[j] = dir_type(type, out_buf[j]);
-	G_put_raster_row(dir_id, out_buf, CELL_TYPE);
+	Rast_put_raster_row(dir_id, out_buf, CELL_TYPE);
     close(fe);
     close(fd);
     G_free(in_buf);
Modified: grass/trunk/raster/r.fill.dir/ppupdate.c
--- grass/trunk/raster/r.fill.dir/ppupdate.c	2009-06-20 21:39:23 UTC (rev 38002)
+++ grass/trunk/raster/r.fill.dir/ppupdate.c	2009-06-20 22:03:23 UTC (rev 38003)
@@ -1,6 +1,7 @@
 #include <stdlib.h>
 #include <string.h>
 #include "tinf.h"
 struct links
@@ -70,7 +71,7 @@
 	    /* check to see if the cell is non-null and in a basin */
 	    here = (CELL *) basins->b[1] + j;
-	    if (G_is_c_null_value(here) || *here < 0)
+	    if (Rast_is_c_null_value(here) || *here < 0)
 		continue;
 	    ii = *here;
Modified: grass/trunk/raster/r.fill.dir/resolve.c
--- grass/trunk/raster/r.fill.dir/resolve.c	2009-06-20 21:39:23 UTC (rev 38002)
+++ grass/trunk/raster/r.fill.dir/resolve.c	2009-06-20 22:03:23 UTC (rev 38003)
@@ -1,6 +1,7 @@
 #include <stdlib.h>
 #include <string.h>
 #include "tinf.h"
@@ -39,7 +40,7 @@
     int k;
     cwork = p2[j];
 	return;
     cwork = -cwork;
@@ -111,7 +112,7 @@
 	    offset = j * isz;
-	    if (G_is_c_null_value((CELL *) (bnd->b[0] + offset)))
+	    if (Rast_is_c_null_value((CELL *) (bnd->b[0] + offset)))
 		continue;
 	    if (cvalue > 0)
Modified: grass/trunk/raster/r.fill.dir/tinf.c
--- grass/trunk/raster/r.fill.dir/tinf.c	2009-06-20 21:39:23 UTC (rev 38002)
+++ grass/trunk/raster/r.fill.dir/tinf.c	2009-06-20 22:03:23 UTC (rev 38003)
@@ -2,6 +2,7 @@
 #include <float.h>
 #include <math.h>
 #include "tinf.h"
 /* To add a new multitype function, use the function below to initialize
@@ -87,15 +88,15 @@
@@ -179,49 +180,49 @@
 void *get_buf_c()
 void *get_buf_f()
 void *get_buf_d()
@@ -317,7 +318,7 @@
     rc = -HUGE_VAL;
     return rc;
@@ -330,7 +331,7 @@
     rc = -HUGE_VAL;
     return rc;
@@ -343,7 +344,7 @@
     rc = -HUGE_VAL;
     return rc;
Modified: grass/trunk/raster/r.fill.dir/wtrshed.c
--- grass/trunk/raster/r.fill.dir/wtrshed.c	2009-06-20 21:39:23 UTC (rev 38002)
+++ grass/trunk/raster/r.fill.dir/wtrshed.c	2009-06-20 22:03:23 UTC (rev 38003)
@@ -2,6 +2,7 @@
 #include <stdlib.h>
 struct whereandwhat
@@ -26,37 +27,37 @@
     if (i > 0) {
 	edge = dir[i - 1].p[j - 1];
-	if (bas[i - 1].p[j - 1] == -1 && !G_is_c_null_value(&edge) &&
+	if (bas[i - 1].p[j - 1] == -1 && !Rast_is_c_null_value(&edge) &&
 	    edge == 4)
 	    rc += recurse_cell(flag, i - 1, j - 1, nl, ns, bas, dir);
 	edge = dir[i - 1].p[j];
-	if (bas[i - 1].p[j] == -1 && !G_is_c_null_value(&edge) && edge == 8)
+	if (bas[i - 1].p[j] == -1 && !Rast_is_c_null_value(&edge) && edge == 8)
 	    rc += recurse_cell(flag, i - 1, j, nl, ns, bas, dir);
 	edge = dir[i - 1].p[j + 1];
-	if (bas[i - 1].p[j + 1] == -1 && !G_is_c_null_value(&edge) &&
+	if (bas[i - 1].p[j + 1] == -1 && !Rast_is_c_null_value(&edge) &&
 	    edge == 16)
 	    rc += recurse_cell(flag, i - 1, j + 1, nl, ns, bas, dir);
     edge = dir[i].p[j - 1];
-    if (bas[i].p[j - 1] == -1 && !G_is_c_null_value(&edge) && edge == 2)
+    if (bas[i].p[j - 1] == -1 && !Rast_is_c_null_value(&edge) && edge == 2)
 	rc += recurse_cell(flag, i, j - 1, nl, ns, bas, dir);
     edge = dir[i].p[j + 1];
-    if (bas[i].p[j + 1] == -1 && !G_is_c_null_value(&edge) && edge == 32)
+    if (bas[i].p[j + 1] == -1 && !Rast_is_c_null_value(&edge) && edge == 32)
 	rc += recurse_cell(flag, i, j + 1, nl, ns, bas, dir);
     if (i < nl - 1) {
 	edge = dir[i + 1].p[j - 1];
-	if (bas[i + 1].p[j - 1] == -1 && !G_is_c_null_value(&edge) &&
+	if (bas[i + 1].p[j - 1] == -1 && !Rast_is_c_null_value(&edge) &&
 	    edge == 1)
 	    rc += recurse_cell(flag, i + 1, j - 1, nl, ns, bas, dir);
 	edge = dir[i + 1].p[j];
-	if (bas[i + 1].p[j] == -1 && !G_is_c_null_value(&edge) && edge == 128)
+	if (bas[i + 1].p[j] == -1 && !Rast_is_c_null_value(&edge) && edge == 128)
 	    rc += recurse_cell(flag, i + 1, j, nl, ns, bas, dir);
 	edge = dir[i + 1].p[j + 1];
-	if (bas[i + 1].p[j + 1] == -1 && !G_is_c_null_value(&edge) &&
+	if (bas[i + 1].p[j + 1] == -1 && !Rast_is_c_null_value(&edge) &&
 	    edge == 64)
 	    rc += recurse_cell(flag, i + 1, j + 1, nl, ns, bas, dir);
Modified: grass/trunk/raster/r.flow/aspect.c
--- grass/trunk/raster/r.flow/aspect.c	2009-06-20 21:39:23 UTC (rev 38002)
+++ grass/trunk/raster/r.flow/aspect.c	2009-06-20 22:03:23 UTC (rev 38003)
@@ -26,6 +26,7 @@
 #include <math.h>
 #include "r.flow.h"
Modified: grass/trunk/raster/r.flow/aspect.h
--- grass/trunk/raster/r.flow/aspect.h	2009-06-20 21:39:23 UTC (rev 38002)
+++ grass/trunk/raster/r.flow/aspect.h	2009-06-20 22:03:23 UTC (rev 38003)
@@ -1,4 +1,5 @@
  * aspect_fly: calculates aspect on the fly based on elevation map in z
Modified: grass/trunk/raster/r.flow/io.c
--- grass/trunk/raster/r.flow/io.c	2009-06-20 21:39:23 UTC (rev 38002)
+++ grass/trunk/raster/r.flow/io.c	2009-06-20 22:03:23 UTC (rev 38003)
@@ -62,10 +62,10 @@
     if (mapset == NULL)
 	G_fatal_error(_("Raster map <%s> not found"), fname);
-    if (chd && (G_get_cellhd(fname, mapset, chd) < 0))
+    if (chd && (Rast_get_cellhd(fname, mapset, chd) < 0))
 	G_fatal_error(_("Unable to get header for %s"), fname);
-    return G_open_cell_old(fname, mapset);
+    return Rast_open_cell_old(fname, mapset);
 void read_input_files(void)
@@ -82,13 +82,13 @@
 	G_fatal_error(_("Elevation file's resolution differs from current region resolution"));
     for (row = 0; row < region.rows; row++) {
-	G_get_d_raster_row(fd, el.buf[row], row);
+	Rast_get_d_raster_row(fd, el.buf[row], row);
 	if (parm.seg)
 	    put_row_seg(el, row);
     if (parm.seg)
 	segment_flush(el.seg);
-    G_close_cell(fd);
+    Rast_close_cell(fd);
     if (parm.aspin) {
 	G_message(_("Reading input files: aspect"));
@@ -99,29 +99,29 @@
 			    "current region resolution"));
-	    G_get_d_raster_row(fd, as.buf[row], row);
+	    Rast_get_d_raster_row(fd, as.buf[row], row);
 	    if (parm.seg)
 		put_row_seg(as, row);
 	if (parm.seg)
 	    segment_flush(as.seg);
-	G_close_cell(fd);
     if (parm.barin) {
 	G_message(_("Reading input files: barrier"));
-	barc = G_allocate_d_raster_buf();
+	barc = Rast_allocate_d_raster_buf();
 	fd = open_existing_cell_file(parm.barin, &hd);
-	    G_get_d_raster_row(fd, barc, row);
+	    Rast_get_d_raster_row(fd, barc, row);
 	    for (col = 0; col < region.cols; col++) {
 		BM_set(bitbar, col, row, (barc[col] != 0));
 		if (parm.dsout && barc[col] != 0)
 		    put(ds, row, col, -1);
-	G_close_cell(fd);
@@ -163,7 +163,7 @@
     if (parm.lgout &&
-	((lgfd = G_open_raster_new(parm.lgout, FCELL_TYPE)) < 0))
+	((lgfd = Rast_open_raster_new(parm.lgout, FCELL_TYPE)) < 0))
 	G_fatal_error(_("Unable to create raster map <%s>"), parm.lgout);
     if (parm.flout && (Vect_open_new(&fl, parm.flout, 0) < 0))
@@ -179,7 +179,7 @@
 	    close(ds.sfd);
     /*   if (parm.lgout)
-       G_close_cell(lgfd); */
+       Rast_close_cell(lgfd); */
     if (parm.flout) {
 	Vect_build(&fl);
 	Vect_close(&fl);
@@ -197,30 +197,30 @@
 	G_fatal_error(_("Cannot reset current region"));
     G_message(_("Writing density file"));
-    dsfd = G_open_raster_new(parm.dsout, DCELL_TYPE);
+    dsfd = Rast_open_raster_new(parm.dsout, DCELL_TYPE);
     if (dsfd < 0)
 	G_fatal_error(_("Unable to create raster map <%s>"), parm.dsout);
-	G_put_raster_row(dsfd, get_row(ds, row), DCELL_TYPE);
+	Rast_put_raster_row(dsfd, get_row(ds, row), DCELL_TYPE);
 	    if (ds.buf[row][col] > dsmax)
 		dsmax = ds.buf[row][col];
-    G_close_cell(dsfd);
+    Rast_close_cell(dsfd);
-    G_init_colors(&colors);
+    Rast_init_colors(&colors);
-    G_add_color_rule(-1, 0, 0, 0, -1, 0, 0, 0, &colors);
-    G_add_color_rule(0, 255, 255, 255, 5, 255, 255, 0, &colors);
-    G_add_color_rule(5, 255, 255, 0, 30, 0, 255, 255, &colors);
-    G_add_color_rule(30, 0, 255, 255, 100, 0, 127, 255, &colors);
-    G_add_color_rule(100, 0, 127, 255, 1000, 0, 0, 255, &colors);
-    G_add_color_rule(1000, 0, 0, 255, (CELL) dsmax, 0, 0, 0, &colors);
+    Rast_add_color_rule(-1, 0, 0, 0, -1, 0, 0, 0, &colors);
+    Rast_add_color_rule(0, 255, 255, 255, 5, 255, 255, 0, &colors);
+    Rast_add_color_rule(5, 255, 255, 0, 30, 0, 255, 255, &colors);
+    Rast_add_color_rule(30, 0, 255, 255, 100, 0, 127, 255, &colors);
+    Rast_add_color_rule(100, 0, 127, 255, 1000, 0, 0, 255, &colors);
+    Rast_add_color_rule(1000, 0, 0, 255, (CELL) dsmax, 0, 0, 0, &colors);
     if ((mapset = G_find_file("cell", parm.dsout, "")) == NULL)
 	G_fatal_error(_("Unable to find file %s"), parm.dsout);
-    G_write_colors(parm.dsout, mapset, &colors);
+    Rast_write_colors(parm.dsout, mapset, &colors);
Modified: grass/trunk/raster/r.flow/io.h
--- grass/trunk/raster/r.flow/io.h	2009-06-20 21:39:23 UTC (rev 38002)
+++ grass/trunk/raster/r.flow/io.h	2009-06-20 22:03:23 UTC (rev 38003)
@@ -1,4 +1,5 @@
 /********************************* I/O **********************************/
Modified: grass/trunk/raster/r.flow/main.c
--- grass/trunk/raster/r.flow/main.c	2009-06-20 21:39:23 UTC (rev 38002)
+++ grass/trunk/raster/r.flow/main.c	2009-06-20 22:03:23 UTC (rev 38003)
@@ -29,6 +29,7 @@
 #include <stdlib.h>		/* for the random number generation */
 #include <time.h>
 #include "r.flow.h"
 #include "mem.h"
@@ -117,8 +118,8 @@
     if (!(a1 == UNDEF || a2 == UNDEF) &&
-	!(G_is_d_null_value(&a1) || G_is_d_null_value(&a2)))
-	/*    if (!(G_is_d_null_value(&a1) || G_is_d_null_value(&a2))) */
+	!(Rast_is_d_null_value(&a1) || Rast_is_d_null_value(&a2)))
+	/*    if (!(Rast_is_d_null_value(&a1) || Rast_is_d_null_value(&a2))) */
 	if ((d = a1 - a2) >= D_PI || d <= -D_PI) {
 	    if (a2 > D_PI)
@@ -307,7 +308,7 @@
     /*    double     x, y, length, xstep, ystep, roffset, coffset; */
     double x, y, length, xstep, ystep;
-    FCELL *lg = G_allocate_f_raster_buf();
+    FCELL *lg = Rast_allocate_f_raster_buf();
     struct line_pnts *points = Vect_new_line_struct();
     struct line_cats *cats = Vect_new_cats_struct();
     int loopstep = (!parm.dsout && !parm.lgout && parm.flout) ? parm.skip : 1;
@@ -367,7 +368,7 @@
 		while (fls.index <= parm.bound &&
 		       (pts.z != UNDEFZ && pts.theta >= 0 && pts.theta <= 360)
-		       /*  (!G_is_d_null_value(&pts.z) && pts.theta != UNDEF) && */
+		       /*  (!Rast_is_d_null_value(&pts.z) && pts.theta != UNDEF) && */
 		       next_point(&pts, &ads, bbs, &length));
@@ -384,7 +385,7 @@
 	if (parm.lgout)
-	    G_put_f_raster_row(lgfd, lg);
+	    Rast_put_f_raster_row(lgfd, lg);
     G_free(fls.px);
@@ -395,7 +396,7 @@
     Vect_destroy_cats_struct(cats);
     if (parm.lgout)
@@ -578,14 +579,14 @@
     if (parm.dsout) {
-	G_short_history(parm.dsout, "raster", &history);
-	G_command_history(&history);
-	G_write_history(parm.dsout, &history);
+	Rast_short_history(parm.dsout, "raster", &history);
+	Rast_command_history(&history);
+	Rast_write_history(parm.dsout, &history);
     if (parm.lgout) {
-	G_short_history(parm.lgout, "raster", &history);
-	G_write_history(parm.lgout, &history);
+	Rast_short_history(parm.lgout, "raster", &history);
+	Rast_write_history(parm.lgout, &history);
     exit(EXIT_SUCCESS);
Modified: grass/trunk/raster/r.flow/mem.c
--- grass/trunk/raster/r.flow/mem.c	2009-06-20 21:39:23 UTC (rev 38002)
+++ grass/trunk/raster/r.flow/mem.c	2009-06-20 22:03:23 UTC (rev 38003)
@@ -25,6 +25,7 @@
 #include "r.flow.h"
 #include "io.h"
@@ -75,10 +76,10 @@
     if (!parm.mem) {
 	G_debug(1, "Allocating memory: aspect");
 	as.buf = (DCELL **) G_calloc(region.rows, sizeof(DCELL *));
-	as.buf[0] = (DCELL *) G_allocate_raster_buf(DCELL_TYPE);
+	as.buf[0] = (DCELL *) Rast_allocate_raster_buf(DCELL_TYPE);
 	    as.buf[row] = parm.seg ?
-		as.buf[0] : (DCELL *) G_allocate_raster_buf(DCELL_TYPE);
+		as.buf[0] : (DCELL *) Rast_allocate_raster_buf(DCELL_TYPE);
     if (parm.barin) {
@@ -89,10 +90,10 @@
     if (parm.dsout) {
 	G_debug(1, "Allocating memory: density");
 	ds.buf = (DCELL **) G_calloc(region.rows, sizeof(DCELL *));
-	ds.buf[0] = (DCELL *) G_allocate_raster_buf(DCELL_TYPE);
+	ds.buf[0] = (DCELL *) Rast_allocate_raster_buf(DCELL_TYPE);
 	    ds.buf[row] = parm.seg ?
-		ds.buf[0] : (DCELL *) G_allocate_raster_buf(DCELL_TYPE);
+		ds.buf[0] : (DCELL *) Rast_allocate_raster_buf(DCELL_TYPE);
     if (parm.flout) {
Modified: grass/trunk/raster/r.flow/mem.h
--- grass/trunk/raster/r.flow/mem.h	2009-06-20 21:39:23 UTC (rev 38002)
+++ grass/trunk/raster/r.flow/mem.h	2009-06-20 22:03:23 UTC (rev 38003)
@@ -2,6 +2,7 @@
 /************************** MEMORY MANAGEMENT ***************************/
 #define KB 1024
 #define MB (KB * KB)
 #define SEGSINMEM 9
Modified: grass/trunk/raster/r.flow/precomp.c
--- grass/trunk/raster/r.flow/precomp.c	2009-06-20 21:39:23 UTC (rev 38002)
+++ grass/trunk/raster/r.flow/precomp.c	2009-06-20 22:03:23 UTC (rev 38003)
@@ -25,6 +25,7 @@
 #include "r.flow.h"
 #include "io.h"
@@ -177,7 +178,7 @@
 	    if (aspect(row, col) == 0)
 		/* put(as, row, col, (int) UNDEF); */
-		G_set_d_null_value(&(as.buf[row][col]), 1);
+		Rast_set_d_null_value(&(as.buf[row][col]), 1);
 	    else if (aspect(row, col) < 90)
 		put(as, row, col, 90 - aspect(row, col));
 	    else
@@ -201,7 +202,7 @@
 	    temp = aspect_fly(n++, c++, s++, d);
 	    if (temp == UNDEF)
 	    else
 		put(as, row, col, temp);
Modified: grass/trunk/raster/r.flow/r.flow.h
--- grass/trunk/raster/r.flow/r.flow.h	2009-06-20 21:39:23 UTC (rev 38002)
+++ grass/trunk/raster/r.flow/r.flow.h	2009-06-20 22:03:23 UTC (rev 38003)
@@ -32,6 +32,7 @@
 #include <math.h>
 #include <grass/bitmap.h>
Modified: grass/trunk/raster/r.grow/main.c
--- grass/trunk/raster/r.grow/main.c	2009-06-20 21:39:23 UTC (rev 38002)
+++ grass/trunk/raster/r.grow/main.c	2009-06-20 22:03:23 UTC (rev 38003)
@@ -182,22 +182,22 @@
     else
 	G_fatal_error(_("Unknown metric: [%s]."), opt.met->answer);
-    in_fd = G_open_cell_old(in_name, "");
+    in_fd = Rast_open_cell_old(in_name, "");
     if (in_fd < 0)
 	G_fatal_error(_("Unable to open raster map <%s>"), in_name);
-    type = G_get_raster_map_type(in_fd);
+    type = Rast_get_raster_map_type(in_fd);
-    out_fd = G_open_raster_new(out_name, type);
+    out_fd = Rast_open_raster_new(out_name, type);
     if (out_fd < 0)
-    if (G_read_cats(in_name, "", &cats) == -1) {
+    if (Rast_read_cats(in_name, "", &cats) == -1) {
 	G_warning(_("Error reading category file for <%s>"), in_name);
-	G_init_cats(0, "", &cats);
+	Rast_init_cats(0, "", &cats);
-    if (G_read_colors(in_name, "", &colr) == -1) {
+    if (Rast_read_colors(in_name, "", &colr) == -1) {
 	G_warning(_("Error in reading color file for <%s>"), in_name);
 	colrfile = 0;
@@ -205,35 +205,35 @@
 	colrfile = 1;
     if (opt.old->answer && oldval >= 0)
-	G_set_cat(oldval, "original cells", &cats);
+	Rast_set_cat(oldval, "original cells", &cats);
     if (opt.new->answer)
-	G_set_cat(newval, "grown cells", &cats);
+	Rast_set_cat(newval, "grown cells", &cats);
     in_rows = G_malloc((size * 2 + 1) * sizeof(DCELL *));
     for (row = 0; row <= size * 2; row++)
-	in_rows[row] = G_allocate_d_raster_buf();
+	in_rows[row] = Rast_allocate_d_raster_buf();
-    out_row = G_allocate_d_raster_buf();
+    out_row = Rast_allocate_d_raster_buf();
     for (row = 0; row < size; row++)
-	G_get_d_raster_row(in_fd, in_rows[size + row], row);
+	Rast_get_d_raster_row(in_fd, in_rows[size + row], row);
     for (row = 0; row < nrows; row++) {
 	DCELL *tmp;
 	int i;
 	if (row + size < nrows)
-	    G_get_d_raster_row(in_fd, in_rows[size * 2], row + size);
+	    Rast_get_d_raster_row(in_fd, in_rows[size * 2], row + size);
 	    DCELL *c = &in_rows[size][col];
-	    if (!G_is_d_null_value(c)) {
+	    if (!Rast_is_d_null_value(c)) {
 		if (opt.old->answer) {
 		    if (oldval < 0)
-			G_set_d_null_value(&out_row[col], 1);
+			Rast_set_d_null_value(&out_row[col], 1);
 		    else
 			out_row[col] = oldval;
@@ -254,17 +254,17 @@
 		c = &in_rows[size + dy][x];
 		    out_row[col] = opt.new->answer ? newval : *c;
 		    break;
 	    if (i == count)
-	G_put_d_raster_row(out_fd, out_row);
+	Rast_put_d_raster_row(out_fd, out_row);
 	G_percent(row, nrows, 2);
@@ -276,19 +276,19 @@
-    G_close_cell(in_fd);
-    G_close_cell(out_fd);
+    Rast_close_cell(in_fd);
+    Rast_close_cell(out_fd);
-    if (G_write_cats(out_name, &cats) == -1)
+    if (Rast_write_cats(out_name, &cats) == -1)
 	G_warning(_("Error writing category file for <%s>"), out_name);
     if (colrfile)
-	if (G_write_colors(out_name, G_mapset(), &colr) == -1)
+	if (Rast_write_colors(out_name, G_mapset(), &colr) == -1)
 	    G_warning(_("Error writing color file for <%s>"), out_name);
     return EXIT_SUCCESS;
Modified: grass/trunk/raster/r.grow.distance/main.c
--- grass/trunk/raster/r.grow.distance/main.c	2009-06-20 21:39:23 UTC (rev 38002)
+++ grass/trunk/raster/r.grow.distance/main.c	2009-06-20 22:03:23 UTC (rev 38003)
@@ -24,6 +24,7 @@
 #include <unistd.h>
 #include <fcntl.h>
 static struct Cell_head window;
@@ -98,7 +99,7 @@
     if (col + dx >= ncols)
 	return;
-    if (G_is_c_null_value(&xrow[col + dx]))
+    if (Rast_is_c_null_value(&xrow[col + dx]))
 	return;
     x = xrow[col + dx] + dx;
@@ -108,7 +109,7 @@
 	? (*distance) (xres * x, yres * y)
 	: geodesic_distance(col, row, col + x, row + y);
-    if (!G_is_d_null_value(&dist_row[col]) && dist_row[col] < d)
+    if (!Rast_is_d_null_value(&dist_row[col]) && dist_row[col] < d)
 	return;
     dist_row[col] = d;
@@ -207,18 +208,18 @@
     if (flag.m->answer)
 	scale = G_database_units_to_meters_factor();
     if (in_fd < 0)
     if (dist_name) {
-	dist_fd = G_open_raster_new(dist_name, DCELL_TYPE);
+	dist_fd = Rast_open_raster_new(dist_name, DCELL_TYPE);
 	if (dist_fd < 0)
 	    G_fatal_error(_("Unable to create distance map <%s>"), dist_name);
     if (val_name) {
-	val_fd = G_open_raster_new(val_name, DCELL_TYPE);
+	val_fd = Rast_open_raster_new(val_name, DCELL_TYPE);
 	if (val_fd < 0)
 	    G_fatal_error(_("Unable to create value map <%s>"), val_name);
@@ -233,40 +234,40 @@
     xres = window.ew_res;
     yres = window.ns_res;
-    in_row = G_allocate_d_raster_buf();
+    in_row = Rast_allocate_d_raster_buf();
-    old_val_row = G_allocate_d_raster_buf();
-    new_val_row = G_allocate_d_raster_buf();
+    old_val_row = Rast_allocate_d_raster_buf();
+    new_val_row = Rast_allocate_d_raster_buf();
-    old_x_row = G_allocate_c_raster_buf();
-    old_y_row = G_allocate_c_raster_buf();
-    new_x_row = G_allocate_c_raster_buf();
-    new_y_row = G_allocate_c_raster_buf();
+    old_x_row = Rast_allocate_c_raster_buf();
+    old_y_row = Rast_allocate_c_raster_buf();
+    new_x_row = Rast_allocate_c_raster_buf();
+    new_y_row = Rast_allocate_c_raster_buf();
-    dist_row = G_allocate_d_raster_buf();
+    dist_row = Rast_allocate_d_raster_buf();
     if (dist_name && strcmp(opt.met->answer, "euclidean") == 0)
     else
 	out_row = dist_row;
-    G_set_c_null_value(old_x_row, ncols);
-    G_set_c_null_value(old_y_row, ncols);
+    Rast_set_c_null_value(old_x_row, ncols);
+    Rast_set_c_null_value(old_y_row, ncols);
 	int irow = nrows - 1 - row;
-	G_set_c_null_value(new_x_row, ncols);
-	G_set_c_null_value(new_y_row, ncols);
+	Rast_set_c_null_value(new_x_row, ncols);
+	Rast_set_c_null_value(new_y_row, ncols);
-	G_set_d_null_value(dist_row, ncols);
+	Rast_set_d_null_value(dist_row, ncols);
-	G_get_d_raster_row(in_fd, in_row, irow);
+	Rast_get_d_raster_row(in_fd, in_row, irow);
-	    if (!G_is_d_null_value(&in_row[col])) {
+	    if (!Rast_is_d_null_value(&in_row[col])) {
 		new_x_row[col] = 0;
 		new_y_row[col] = 0;
 		dist_row[col] = 0;
@@ -295,10 +296,10 @@
@@ -335,11 +336,11 @@
 		    out_row[col] *= scale;
-	    G_put_d_raster_row(dist_fd, out_row);
+	    Rast_put_d_raster_row(dist_fd, out_row);
 	if (val_name)
-	    G_put_d_raster_row(val_fd, new_val_row);
+	    Rast_put_d_raster_row(val_fd, new_val_row);
 	swap_rows();
@@ -350,22 +351,22 @@
     remove(temp_name);
     if (dist_name)
-	G_close_cell(dist_fd);
+	Rast_close_cell(dist_fd);
     if (val_name)
-	G_close_cell(val_fd);
+	Rast_close_cell(val_fd);
     if (val_name) {
-	if (G_read_colors(in_name, "", &colors) < 0)
+	if (Rast_read_colors(in_name, "", &colors) < 0)
 	    G_fatal_error(_("Unable to read color table for raster map <%s>"), in_name);
-	G_write_colors(val_name, G_mapset(), &colors);
+	Rast_write_colors(val_name, G_mapset(), &colors);
     if (dist_name) {
-	G_read_fp_range(dist_name, G_mapset(), &range);
-	G_get_fp_range_min_max(&range, &min, &max);
-	G_make_fp_colors(&colors, "rainbow", min, max);
-	G_write_colors(dist_name, G_mapset(), &colors);
+	Rast_read_fp_range(dist_name, G_mapset(), &range);
+	Rast_get_fp_range_min_max(&range, &min, &max);
+	Rast_make_fp_colors(&colors, "rainbow", min, max);
+	Rast_write_colors(dist_name, G_mapset(), &colors);
Modified: grass/trunk/raster/r.gwflow/main.c
--- grass/trunk/raster/r.gwflow/main.c	2009-06-20 21:39:23 UTC (rev 38002)
+++ grass/trunk/raster/r.gwflow/main.c	2009-06-20 22:03:23 UTC (rev 38003)
@@ -20,6 +20,7 @@
 #include <string.h>
 #include <math.h>
 #include <grass/N_pde.h>
 #include <grass/N_gwflow.h>
@@ -501,7 +502,7 @@
 		count++;
 	    else {
-		G_set_null_value(&val, 1, DCELL_TYPE);
+		Rast_set_null_value(&val, 1, DCELL_TYPE);
 	    N_put_array_2d_d_value(target, x, y, val);
Modified: grass/trunk/raster/r.his/his.c
--- grass/trunk/raster/r.his/his.c	2009-06-20 21:39:23 UTC (rev 38002)
+++ grass/trunk/raster/r.his/his.c	2009-06-20 22:03:23 UTC (rev 38003)
@@ -1,5 +1,6 @@
+#include <grass/Rast.h>
 #include "his.h"
@@ -65,10 +66,10 @@
     int i;
-    G_init_colors(gray);
+    Rast_init_colors(gray);
     for (i = 0; i < 256; i++)
-	G_set_color((CELL) i, i, i, i, gray);
+	Rast_set_color((CELL) i, i, i, i, gray);
     return 0;
Modified: grass/trunk/raster/r.his/main.c
--- grass/trunk/raster/r.his/main.c	2009-06-20 21:39:23 UTC (rev 38002)
+++ grass/trunk/raster/r.his/main.c	2009-06-20 22:03:23 UTC (rev 38003)
@@ -17,6 +17,7 @@
 #include <stdio.h>
 #include <string.h>
 #include <grass/display.h>
 #include <grass/display_raster.h>
 #include "his.h"
@@ -122,7 +123,7 @@
     name_h = opt_h->answer;
     /* Make sure map is available */
-    if ((hue_file = G_open_cell_old(name_h, "")) == -1)
+    if ((hue_file = Rast_open_cell_old(name_h, "")) == -1)
 	G_fatal_error(_("Unable to open raster map <%s>"), name_h);
     hue_r = G_malloc(window.cols);
@@ -133,7 +134,7 @@
     dummy = G_malloc(window.cols);
     /* Reading color lookup table */
-    if (G_read_colors(name_h, "", &hue_colors) == -1)
+    if (Rast_read_colors(name_h, "", &hue_colors) == -1)
 	G_fatal_error(_("Color file for <%s> not available"), name_h);
     int_used = 0;
@@ -143,14 +144,14 @@
 	name_i = opt_i->answer;
 	int_used = 1;
-	if ((int_file = G_open_cell_old(name_i, "")) == -1)
+	if ((int_file = Rast_open_cell_old(name_i, "")) == -1)
 	    G_fatal_error(_("Unable to open raster map <%s>"), name_i);
 	int_r = G_malloc(window.cols);
 	int_n = G_malloc(window.cols);
-	if (G_read_colors(name_i, "", &int_colors) == -1)
+	if (Rast_read_colors(name_i, "", &int_colors) == -1)
 	    G_fatal_error(_("Color file for <%s> not available"), name_i);
@@ -162,14 +163,14 @@
 	    sat_used = 1;
-	    if ((sat_file = G_open_cell_old(name_s, "")) == -1)
+	    if ((sat_file = Rast_open_cell_old(name_s, "")) == -1)
 		G_fatal_error(_("Unable to open raster map <%s>"), name_s);
 	    sat_r = G_malloc(window.cols);
 	    sat_n = G_malloc(window.cols);
-	    if (G_read_colors(name_s, "", &sat_colors) == -1)
+	    if (Rast_read_colors(name_s, "", &sat_colors) == -1)
 		G_fatal_error(_("Color file for <%s> not available"), name_s);
@@ -178,7 +179,7 @@
     if (opt_r->answer != NULL) {
 	name_r = opt_r->answer;
-	if ((r_file = G_open_cell_new(name_r)) < 0)
+	if ((r_file = Rast_open_cell_new(name_r)) < 0)
 	    r_used = 0;
 	else
 	    r_used = 1;
@@ -189,7 +190,7 @@
     if (opt_g->answer != NULL) {
 	name_g = opt_g->answer;
-	if ((g_file = G_open_cell_new(name_g)) < 0)
+	if ((g_file = Rast_open_cell_new(name_g)) < 0)
 	    g_used = 0;
 	else
 	    g_used = 1;
@@ -200,15 +201,15 @@
     if (opt_b->answer != NULL) {
 	name_b = opt_b->answer;
-	if ((b_file = G_open_cell_new(name_b)) < 0)
+	if ((b_file = Rast_open_cell_new(name_b)) < 0)
 	    b_used = 0;
 	else
 	    b_used = 1;
-    r_array = G_allocate_cell_buf();
-    g_array = G_allocate_cell_buf();
-    b_array = G_allocate_cell_buf();
+    r_array = Rast_allocate_cell_buf();
+    g_array = Rast_allocate_cell_buf();
+    b_array = Rast_allocate_cell_buf();
     /* Make color table */
     make_gray_scale(&gray_colors);
@@ -221,15 +222,15 @@
     for (atrow = 0; atrow < window.rows; atrow++) {
 	G_percent(atrow, window.rows, 2);
-	if (G_get_raster_row_colors
+	if (Rast_get_raster_row_colors
 	    (hue_file, atrow, &hue_colors, hue_r, hue_g, hue_b, hue_n) < 0)
 	    G_fatal_error(_("Error reading 'hue' map"));
 	if (int_used &&
-	    (G_get_raster_row_colors
+	    (Rast_get_raster_row_colors
 	     (int_file, atrow, &int_colors, int_r, dummy, dummy, int_n) < 0))
 	    G_fatal_error(_("Error reading 'intensity' map"));
 	if (sat_used &&
 	     (sat_file, atrow, &sat_colors, sat_r, dummy, dummy, sat_n) < 0))
 	    G_fatal_error(_("Error reading 'saturation' map"));
@@ -238,9 +239,9 @@
 		if (hue_n[atcol]
 		    || (int_used && int_n[atcol])
 		    || (sat_used && sat_n[atcol])) {
-		    G_set_c_null_value(&r_array[atcol], 1);
-		    G_set_c_null_value(&g_array[atcol], 1);
-		    G_set_c_null_value(&b_array[atcol], 1);
+		    Rast_set_c_null_value(&r_array[atcol], 1);
+		    Rast_set_c_null_value(&g_array[atcol], 1);
+		    Rast_set_c_null_value(&b_array[atcol], 1);
 		    continue;
@@ -257,49 +258,49 @@
 	if (r_used)
-	    if (G_put_raster_row(r_file, r_array, CELL_TYPE) < 0)
+	    if (Rast_put_raster_row(r_file, r_array, CELL_TYPE) < 0)
 		r_used = 0;
 	if (g_used)
-	    if (G_put_raster_row(g_file, g_array, CELL_TYPE) < 0)
+	    if (Rast_put_raster_row(g_file, g_array, CELL_TYPE) < 0)
 		g_used = 0;
 	if (b_used)
-	    if (G_put_raster_row(b_file, b_array, CELL_TYPE) < 0)
+	    if (Rast_put_raster_row(b_file, b_array, CELL_TYPE) < 0)
 		b_used = 0;
     G_percent(window.rows, window.rows, 5);
     /* Close the cell files */
-    G_close_cell(hue_file);
+    Rast_close_cell(hue_file);
     if (int_used)
-	G_close_cell(int_file);
+	Rast_close_cell(int_file);
     if (sat_used)
-	G_close_cell(sat_file);
+	Rast_close_cell(sat_file);
     if (r_used) {
-	G_close_cell(r_file);
-	G_write_colors(name_r, G_mapset(), &gray_colors);
-	G_short_history(name_r, "raster", &history);
-	G_write_history(name_r, &history);
-	G_put_cell_title(name_r, "Red extracted from HIS");
+	Rast_close_cell(r_file);
+	Rast_write_colors(name_r, G_mapset(), &gray_colors);
+	Rast_short_history(name_r, "raster", &history);
+	Rast_write_history(name_r, &history);
+	Rast_put_cell_title(name_r, "Red extracted from HIS");
     if (g_used) {
-	G_close_cell(g_file);
-	G_write_colors(name_g, G_mapset(), &gray_colors);
-	G_short_history(name_g, "raster", &history);
-	G_write_history(name_g, &history);
-	G_put_cell_title(name_g, "Green extracted from HIS");
+	Rast_close_cell(g_file);
+	Rast_write_colors(name_g, G_mapset(), &gray_colors);
+	Rast_short_history(name_g, "raster", &history);
+	Rast_write_history(name_g, &history);
+	Rast_put_cell_title(name_g, "Green extracted from HIS");
     if (b_used) {
-	G_close_cell(b_file);
-	G_write_colors(name_b, G_mapset(), &gray_colors);
-	G_short_history(name_b, "raster", &history);
-	G_write_history(name_b, &history);
-	G_put_cell_title(name_b, "Blue extracted from HIS");
+	Rast_close_cell(b_file);
+	Rast_write_colors(name_b, G_mapset(), &gray_colors);
+	Rast_short_history(name_b, "raster", &history);
+	Rast_write_history(name_b, &history);
+	Rast_put_cell_title(name_b, "Blue extracted from HIS");
Modified: grass/trunk/raster/r.horizon/main.c
--- grass/trunk/raster/r.horizon/main.c	2009-06-20 21:39:23 UTC (rev 38002)
+++ grass/trunk/raster/r.horizon/main.c	2009-06-20 22:03:23 UTC (rev 38003)
@@ -35,6 +35,7 @@
 #include <string.h>
 #include <math.h>
@@ -536,7 +537,7 @@
     int l, i, j, k;
     int lmax, kmax;
-    cell1 = G_allocate_f_raster_buf();
+    cell1 = Rast_allocate_f_raster_buf();
     z = (float **)G_malloc(sizeof(float *) * (m));
     z100 = (float **)G_malloc(sizeof(float *) * (m100));
@@ -552,22 +553,22 @@
     if ((mapset = G_find_cell2(elevin, "")) == NULL)
 	G_fatal_error(_("Raster map <%s> not found"), elevin);
-    fd1 = G_open_cell_old(elevin, mapset);
+    fd1 = Rast_open_cell_old(elevin, mapset);
     for (row = 0; row < m; row++) {
-	G_get_f_raster_row(fd1, cell1, row);
+	Rast_get_f_raster_row(fd1, cell1, row);
 	for (j = 0; j < n; j++) {
 	    row_rev = m - row - 1;
-	    if (!G_is_f_null_value(cell1 + j))
+	    if (!Rast_is_f_null_value(cell1 + j))
 		z[row_rev][j] = (float)cell1[j];
 	    else
 		z[row_rev][j] = UNDEFZ;
-    G_close_cell(fd1);
+    Rast_close_cell(fd1);
     /*create low resolution array 100 */
     for (i = 0; i < m100; i++) {
@@ -616,8 +617,8 @@
 	exit(EXIT_FAILURE);
     if (horizon != NULL) {
-	fd1 = G_open_fp_cell_new(shad_filename);
+	fd1 = Rast_open_fp_cell_new(shad_filename);
 	if (fd1 < 0)
 	    G_fatal_error(_("Unable to create raster map %s"), shad_filename);
@@ -637,16 +638,16 @@
 	    for (j = 0; j < numcols; j++) {
 		if (horizon_raster[i][j] == UNDEFZ)
-		    G_set_f_null_value(cell1 + j, 1);
+		    Rast_set_f_null_value(cell1 + j, 1);
 		else
 		    cell1[j] = (FCELL) horizon_raster[i][j];
-	    G_put_f_raster_row(fd1, cell1);
+	    Rast_put_f_raster_row(fd1, cell1);
     }				/* End loop over rows. */
@@ -1264,9 +1265,9 @@
 		    exit(0);
-	    G_short_history(shad_filename, "raster", &history);
-	    G_write_history(shad_filename, &history);
+	    Rast_short_history(shad_filename, "raster", &history);
+	    Rast_write_history(shad_filename, &history);
Modified: grass/trunk/raster/r.in.arc/gethead.c
--- grass/trunk/raster/r.in.arc/gethead.c	2009-06-20 21:39:23 UTC (rev 38002)
+++ grass/trunk/raster/r.in.arc/gethead.c	2009-06-20 22:03:23 UTC (rev 38003)
@@ -1,6 +1,7 @@
 #include <string.h>
 #include <ctype.h>
 #include "local_proto.h"
@@ -97,7 +98,7 @@
 	return 0;
-    if (err = G_adjust_Cell_head(cellhd, 1, 1)) {
+    if (err = Rast_adjust_Cell_head(cellhd, 1, 1)) {
 	G_warning(err);
 	return 0;
Modified: grass/trunk/raster/r.in.arc/main.c
--- grass/trunk/raster/r.in.arc/main.c	2009-06-20 21:39:23 UTC (rev 38002)
+++ grass/trunk/raster/r.in.arc/main.c	2009-06-20 22:03:23 UTC (rev 38003)
@@ -22,6 +22,7 @@
 #include <unistd.h>
 #endif
@@ -140,16 +141,16 @@
     switch (rtype) {
     case CELL_TYPE:
-	cell = G_allocate_c_raster_buf();
+	cell = Rast_allocate_c_raster_buf();
 	break;
     case FCELL_TYPE:
-	fcell = G_allocate_f_raster_buf();
+	fcell = Rast_allocate_f_raster_buf();
 	break;
     case DCELL_TYPE:
-	dcell = G_allocate_d_raster_buf();
+	dcell = Rast_allocate_d_raster_buf();
 	break;
-    cf = G_open_raster_new(output, rtype);
+    cf = Rast_open_raster_new(output, rtype);
     if (cf < 0)
 	G_fatal_error(_("Unable to create raster map <%s>"), output);
@@ -157,28 +158,28 @@
 	for (col = 0; col < ncols; col++) {
 	    if (fscanf(fd, "%lf", &x) != 1) {
-		G_unopen_cell(cf);
+		Rast_unopen_cell(cf);
 		G_fatal_error(_("Data conversion failed at row %d, col %d"),
 			      row + 1, col + 1);
 	    switch (rtype) {
 	    case CELL_TYPE:
 		if ((int)x == missingval)
-		    G_set_c_null_value(cell + col, 1);
+		    Rast_set_c_null_value(cell + col, 1);
 		else
 		    cell[col] = (CELL) x *mult_fact;
 		break;
 	    case FCELL_TYPE:
-		    G_set_f_null_value(fcell + col, 1);
+		    Rast_set_f_null_value(fcell + col, 1);
 		else
 		    fcell[col] = (FCELL) x *mult_fact;
 		break;
 	    case DCELL_TYPE:
-		    G_set_d_null_value(dcell + col, 1);
+		    Rast_set_d_null_value(dcell + col, 1);
 		else
 		    dcell[col] = (DCELL) x *mult_fact;
@@ -187,23 +188,23 @@
 	switch (rtype) {
 	case CELL_TYPE:
-	    G_put_c_raster_row(cf, cell);
+	    Rast_put_c_raster_row(cf, cell);
 	    break;
 	case FCELL_TYPE:
-	    G_put_f_raster_row(cf, fcell);
+	    Rast_put_f_raster_row(cf, fcell);
 	    break;
 	case DCELL_TYPE:
-	    G_put_d_raster_row(cf, dcell);
+	    Rast_put_d_raster_row(cf, dcell);
 	    break;
     /* G_message(_("CREATING SUPPORT FILES FOR %s"), output); */
-    G_close_cell(cf);
+    Rast_close_cell(cf);
     if (title)
     exit(EXIT_SUCCESS);
Modified: grass/trunk/raster/r.in.ascii/gethead.c
--- grass/trunk/raster/r.in.ascii/gethead.c	2009-06-20 21:39:23 UTC (rev 38002)
+++ grass/trunk/raster/r.in.ascii/gethead.c	2009-06-20 22:03:23 UTC (rev 38003)
@@ -2,6 +2,7 @@
 #include <string.h>
 #include <math.h>
@@ -171,7 +172,7 @@
 	if (strcmp(label, "multiplier") == 0) {
-	    if (G_is_d_null_value(mult)) {	/* if mult not set on commant line */
+	    if (Rast_is_d_null_value(mult)) {	/* if mult not set on commant line */
 		if (sscanf(value, "%lf", mult) != 1) {
 		    G_warning(_("illegal multiplier field: using 1.0"));
 		    *mult = 1.0;
@@ -205,7 +206,7 @@
     if (!(*nval))
 	*nval = G_store("*");
 	*mult = 1.0;
     /* if data type is not set, then scan data to find out data type */
     if (*d_type < 0) {
@@ -220,7 +221,7 @@
-    if ((err = G_adjust_Cell_head(cellhd, 1, 1))) {
+    if ((err = Rast_adjust_Cell_head(cellhd, 1, 1))) {
 	G_warning(err);
 	return 0;
Modified: grass/trunk/raster/r.in.ascii/main.c
--- grass/trunk/raster/r.in.ascii/main.c	2009-06-20 21:39:23 UTC (rev 38002)
+++ grass/trunk/raster/r.in.ascii/main.c	2009-06-20 22:03:23 UTC (rev 38003)
@@ -21,6 +21,7 @@
 #include <stdlib.h>
 #include <string.h>
@@ -130,7 +131,7 @@
     if ((title = parm.title->answer))
 	G_strip(title);
     if (strcmp(parm.mult->answer, "1.0 or read from header") == 0)
-	G_set_d_null_value(&mult, 1);
+	Rast_set_d_null_value(&mult, 1);
     else if ((sscanf(parm.mult->answer, "%lf", &mult)) != 1)
 	G_fatal_error(_("Wrong entry for multiplier: %s"), parm.mult->answer);
     if (strcmp(parm.nv->answer, "* or read from header") == 0)
@@ -197,35 +198,35 @@
 		      G_window_cols());
-    rast_ptr = G_allocate_raster_buf(data_type);
+    rast_ptr = Rast_allocate_raster_buf(data_type);
     rast = rast_ptr;
-    cf = G_open_raster_new(output, data_type);
+    cf = Rast_open_raster_new(output, data_type);
     if (cf < 0)
 	    if (fscanf(fd, "%s", y) != 1) {
 			      row + 1, col + 1);
 	    if (strcmp(y, null_val_str)) {
 		x = atof(y);
 		if ((float)x == GS_BLANK) {
-		    G_set_null_value(rast_ptr, 1, data_type);
+		    Rast_set_null_value(rast_ptr, 1, data_type);
 		else {
-		    G_set_raster_value_d(rast_ptr,
+		    Rast_set_raster_value_d(rast_ptr,
 					 (DCELL) (x * mult), data_type);
 	    else {
-	    rast_ptr = G_incr_void_ptr(rast_ptr, G_raster_size(data_type));
+	    rast_ptr = Rast_incr_void_ptr(rast_ptr, Rast_raster_size(data_type));
-	fwrite(rast, G_raster_size(data_type), ncols, ft);
+	fwrite(rast, Rast_raster_size(data_type), ncols, ft);
 	rast_ptr = rast;
@@ -233,7 +234,7 @@
     sz = 0;
     if (direction < 0) {
-	sz = -ncols * G_raster_size(data_type);
+	sz = -ncols * Rast_raster_size(data_type);
 	fseek(ft, sz, SEEK_END);
 	sz *= 2;
@@ -242,21 +243,21 @@
     for (row = 0; row < nrows; row += 1) {
-	fread(rast, G_raster_size(data_type), ncols, ft);
-	G_put_raster_row(cf, rast, data_type);
+	fread(rast, Rast_raster_size(data_type), ncols, ft);
+	Rast_put_raster_row(cf, rast, data_type);
 	fseek(ft, sz, SEEK_CUR);
     fclose(ft);
     unlink(temp);
-    G_close_cell(cf);
     if (title)
     G_done_msg(" ");
Modified: grass/trunk/raster/r.in.bin/main.c
--- grass/trunk/raster/r.in.bin/main.c	2009-06-20 21:39:23 UTC (rev 38002)
+++ grass/trunk/raster/r.in.bin/main.c	2009-06-20 22:03:23 UTC (rev 38003)
@@ -14,6 +14,7 @@
 #include <unistd.h>
 #include <sys/stat.h>
 #include "gmt_grd.h"
@@ -405,7 +406,7 @@
 	/* Adjust Cell Header to match resolution */
-	if (err = G_adjust_Cell_head(&cellhd, 0, 0)) {
+	if (err = Rast_adjust_Cell_head(&cellhd, 0, 0)) {
 	    G_fatal_error("%s", err);
 	    exit(EXIT_FAILURE);
@@ -417,7 +418,7 @@
     if (!flag.gmt_hd->answer) {
 	/* Adjust Cell Header to New Values */
-	if (err = G_adjust_Cell_head(&cellhd, 1, 1)) {
+	if (err = Rast_adjust_Cell_head(&cellhd, 1, 1)) {
 	    exit(EXIT_FAILURE);
@@ -480,18 +481,18 @@
     if (flag.f->answer) {
 	map_type = FCELL_TYPE;
     else if (flag.d->answer) {
 	map_type = DCELL_TYPE;
     else {
-    cf = G_open_raster_new(output, map_type);
+    cf = Rast_open_raster_new(output, map_type);
     if (cf < 0) {
 	exit(EXIT_FAILURE);
@@ -513,7 +514,7 @@
     for (row = 0; row < grass_nrows; row++) {
 	if (fread(x_v, bytes * ncols, 1, fd) != 1) {
 	    G_fatal_error(_("Conversion failed at row %d"), row);
 	    exit(EXIT_FAILURE);
@@ -559,34 +560,34 @@
 	    if (parm.anull->answer) {
 		    if (fcell[col] == (float)nul_val)
-			G_set_f_null_value(&fcell[col], 1);
+			Rast_set_f_null_value(&fcell[col], 1);
 		else {
 		    if (cell[col] == (int)nul_val)
-			G_set_c_null_value(&cell[col], 1);
+			Rast_set_c_null_value(&cell[col], 1);
 	if (flag.f->answer)
 	else
 	G_percent(row + 1, nrows, 2);
     G_debug(1, "Creating support files for %s", output);
-    G_close_cell(cf);
     if (title)
     exit(EXIT_SUCCESS);
Modified: grass/trunk/raster/r.in.gdal/main.c
--- grass/trunk/raster/r.in.gdal/main.c	2009-06-20 21:39:23 UTC (rev 38002)
+++ grass/trunk/raster/r.in.gdal/main.c	2009-06-20 22:03:23 UTC (rev 38003)
@@ -22,6 +22,7 @@
 #include <math.h>
 #include <string.h>
 #include <grass/gis.h>
@@ -460,7 +461,7 @@
 	ImportBand(hBand, output, NULL);
 	if (title)
@@ -505,7 +506,7 @@
 	    ImportBand(hBand, szBandName, &ref);
 	    if (title)
-		G_put_cell_title(szBandName, title);
+		Rast_put_cell_title(szBandName, title);
 	I_put_group_ref(output, &ref);
@@ -678,7 +679,7 @@
     char outputReal[GNAME_MAX], outputImg[GNAME_MAX];
     char *nullFlags = NULL;
     int (*raster_open_new_func) (const char *, RASTER_MAP_TYPE) =
-	G_open_raster_new;
+	Rast_open_raster_new;
@@ -698,8 +699,8 @@
 	data_type = CELL_TYPE;
 	eGDT = GDT_Int32;
 	complex = FALSE;
-	G_set_cell_format(0);
-	/* raster_open_new_func = G_open_raster_new_uncompressed; *//* ?? */
+	Rast_set_cell_format(0);
+	/* raster_open_new_func = Rast_open_raster_new_uncompressed; *//* ?? */
 	break;
     case GDT_Int16:
@@ -707,15 +708,15 @@
 	eGDT = GDT_Int32;
 	complex = FALSE;
-	G_set_cell_format(1);
+	Rast_set_cell_format(1);
 	break;
     default:
 	eGDT = GDT_Int32;
 	complex = FALSE;
-	G_set_cell_format(3);
+	Rast_set_cell_format(3);
 	break;
@@ -736,8 +737,8 @@
 	if (cfI < 0)
 	    G_fatal_error(_("Unable to create raster map <%s>"), outputImg);
-	cellReal = G_allocate_raster_buf(data_type);
-	cellImg = G_allocate_raster_buf(data_type);
+	cellReal = Rast_allocate_raster_buf(data_type);
+	cellImg = Rast_allocate_raster_buf(data_type);
 	bufComplex = (float *)G_malloc(sizeof(float) * ncols * 2);
 	if (group_ref != NULL) {
@@ -753,7 +754,7 @@
 	    I_add_file_to_group_ref((char *)output, G_mapset(), group_ref);
-	cell = G_allocate_raster_buf(data_type);
+	cell = Rast_allocate_raster_buf(data_type);
@@ -790,8 +791,8 @@
 			    bufComplex[indx * 2 + 1];
-		G_put_raster_row(cfR, cellReal, data_type);
-		G_put_raster_row(cfI, cellImg, data_type);
+		Rast_put_raster_row(cfR, cellReal, data_type);
+		Rast_put_raster_row(cfI, cellImg, data_type);
 	    }			/* end of complex */
 	    else {		/* single band */
 		GDALRasterIO(hBand, GF_Read, 0, row - 1, ncols, 1,
@@ -815,10 +816,10 @@
-		    G_insert_null_values(cell, nullFlags, ncols, data_type);
+		    Rast_insert_null_values(cell, nullFlags, ncols, data_type);
-		G_put_raster_row(cf, cell, data_type);
+		Rast_put_raster_row(cf, cell, data_type);
 	    }			/* end of not complex */
@@ -848,10 +849,10 @@
@@ -861,25 +862,25 @@
     if (complex) {
 	G_debug(1, "Creating support files for %s", outputReal);
-	G_close_cell(cfR);
-	G_short_history((char *)outputReal, "raster", &history);
-	G_write_history((char *)outputReal, &history);
+	Rast_close_cell(cfR);
+	Rast_short_history((char *)outputReal, "raster", &history);
+	Rast_write_history((char *)outputReal, &history);
 	G_debug(1, "Creating support files for %s", outputImg);
-	G_close_cell(cfI);
-	G_short_history((char *)outputImg, "raster", &history);
-	G_write_history((char *)outputImg, &history);
+	Rast_close_cell(cfI);
+	Rast_short_history((char *)outputImg, "raster", &history);
+	Rast_write_history((char *)outputImg, &history);
 	G_free(bufComplex);
     else {
-	G_close_cell(cf);
-	G_short_history((char *)output, "raster", &history);
-	G_write_history((char *)output, &history);
+	Rast_short_history((char *)output, "raster", &history);
+	Rast_write_history((char *)output, &history);
     if (nullFlags != NULL)
@@ -897,7 +898,7 @@
 	hCT = GDALGetRasterColorTable(hBand);
 	for (iColor = 0; iColor < GDALGetColorEntryCount(hCT); iColor++) {
 	    GDALColorEntry sEntry;
@@ -905,10 +906,10 @@
 	    if (sEntry.c4 == 0)
 		continue;
-	    G_set_color(iColor, sEntry.c1, sEntry.c2, sEntry.c3, &colors);
+	    Rast_set_color(iColor, sEntry.c1, sEntry.c2, sEntry.c3, &colors);
-	G_write_colors((char *)output, G_mapset(), &colors);
+	Rast_write_colors((char *)output, G_mapset(), &colors);
     else {			/* no color table present */
@@ -920,9 +921,9 @@
 	    G_verbose_message(_("Setting grey color table for <%s> (8bit, full range)"),
 			      output);
-	    G_make_grey_scale_colors(&colors, 0, 255);	/* full range */
+	    Rast_make_grey_scale_colors(&colors, 0, 255);	/* full range */
 	if ((GDALGetRasterDataType(hBand) == GDT_UInt16)) {
 	    /* found 0..65535 data: we set to grey scale: */
@@ -932,12 +933,12 @@
 	    G_verbose_message(_("Setting grey color table for <%s> (16bit, image range)"),
 			      output);
-	    G_read_range((char *)output, G_mapset(), &range);
-	    G_get_range_min_max(&range, &min, &max);
+	    Rast_read_range((char *)output, G_mapset(), &range);
+	    Rast_get_range_min_max(&range, &min, &max);
-	    G_make_grey_scale_colors(&colors, min, max);	/* image range */
+	    Rast_make_grey_scale_colors(&colors, min, max);	/* image range */
Modified: grass/trunk/raster/r.in.gridatb/file_io.c
--- grass/trunk/raster/r.in.gridatb/file_io.c	2009-06-20 21:39:23 UTC (rev 38002)
+++ grass/trunk/raster/r.in.gridatb/file_io.c	2009-06-20 22:03:23 UTC (rev 38003)
@@ -1,5 +1,6 @@
 #include <stdlib.h>
@@ -42,7 +43,7 @@
-    fd = G_open_raster_new(oname, FCELL_TYPE);
+    fd = Rast_open_raster_new(oname, FCELL_TYPE);
     cell = (FCELL *) G_malloc(sizeof(FCELL) * cellhd.cols);
@@ -53,20 +54,20 @@
 	    idx = 9999.0;
 	    fscanf(fp, "%f", &idx);
 	    if (idx >= 9999.0) {
-		G_set_f_null_value(&(cell[j]), 1);
+		Rast_set_f_null_value(&(cell[j]), 1);
 	    else {
 		cell[j] = idx;
-	G_put_f_raster_row(fd, cell);
+	Rast_put_f_raster_row(fd, cell);
     G_percent(i, cellhd.rows, 2);
     fclose(fp);
-    G_close_cell(fd);
-    G_put_cell_title(oname, buf);
-    G_put_cellhd(oname, &cellhd);
+    Rast_put_cell_title(oname, buf);
+    Rast_put_cellhd(oname, &cellhd);
     return;
Modified: grass/trunk/raster/r.in.gridatb/local_proto.h
--- grass/trunk/raster/r.in.gridatb/local_proto.h	2009-06-20 21:39:23 UTC (rev 38002)
+++ grass/trunk/raster/r.in.gridatb/local_proto.h	2009-06-20 22:03:23 UTC (rev 38003)
@@ -1,5 +1,6 @@
 #include <stdio.h>
 int check_ready(void);
 int adjcellhd(struct Cell_head *cellhd);
Modified: grass/trunk/raster/r.in.gridatb/main.c
--- grass/trunk/raster/r.in.gridatb/main.c	2009-06-20 21:39:23 UTC (rev 38002)
+++ grass/trunk/raster/r.in.gridatb/main.c	2009-06-20 22:03:23 UTC (rev 38003)
@@ -19,6 +19,7 @@
 struct Cell_head cellhd;
Modified: grass/trunk/raster/r.in.mat/main.c
--- grass/trunk/raster/r.in.mat/main.c	2009-06-20 21:39:23 UTC (rev 38002)
+++ grass/trunk/raster/r.in.mat/main.c	2009-06-20 22:03:23 UTC (rev 38003)
@@ -36,6 +36,7 @@
 #include <stdlib.h>
 #include <string.h>
 /* typedef unsigned short uint16;
@@ -294,21 +295,21 @@
 		G_debug(1, " double map");
 		array_data =
-		    G_calloc(mrows * (ncols + 1), G_raster_size(map_type));
+		    G_calloc(mrows * (ncols + 1), Rast_raster_size(map_type));
 		fread(array_data, sizeof(double), mrows * ncols, fp1);
 		break;
 	    case 1:
 		G_debug(1, " float map");
 		array_data =
 		fread(array_data, sizeof(float), mrows * ncols, fp1);
 		break;
 	    case 2:
 		G_debug(1, " int map");
 		map_type = CELL_TYPE;
 		array_data =
 		fread(array_data, sizeof(int), mrows * ncols, fp1);
 		break;
 	    default:
@@ -388,7 +389,7 @@
     region.proj = G_projection();
     region.zone = G_zone();
-    err = G_adjust_Cell_head(&region, 1, 1);
+    err = Rast_adjust_Cell_head(&region, 1, 1);
     if (err)
 	G_fatal_error(err);
     G_set_window(&region);
@@ -406,9 +407,9 @@
     G_verbose_message("");
     /* prep memory */
-    raster = G_allocate_raster_buf(map_type);
+    raster = Rast_allocate_raster_buf(map_type);
-    cf = G_open_raster_new(map_name, map_type);
+    cf = Rast_open_raster_new(map_name, map_type);
     if (cf < 0)
 	G_fatal_error(_("Unable to create raster map <%s>"), outfile);
@@ -423,54 +424,54 @@
 	    array_ptr = array_data;
 	    array_ptr =
-		G_incr_void_ptr(array_ptr,
+		Rast_incr_void_ptr(array_ptr,
 				(row +
-				 col * mrows) * G_raster_size(map_type));
+				 col * mrows) * Rast_raster_size(map_type));
 	    if (is_nan(array_ptr, map_type))
-		G_set_null_value(rastline_ptr, 1, map_type);
+		Rast_set_null_value(rastline_ptr, 1, map_type);
 	    else {
 		switch (map_type) {
 		case CELL_TYPE:
 		    pval_i = (int *)array_ptr;
-		    G_set_raster_value_c(rastline_ptr, (CELL) pval_i[0],
+		    Rast_set_raster_value_c(rastline_ptr, (CELL) pval_i[0],
 					 map_type);
 		    break;
 		case FCELL_TYPE:
 		    pval_f = (float *)array_ptr;
-		    G_set_raster_value_f(rastline_ptr, (FCELL) pval_f[0],
+		    Rast_set_raster_value_f(rastline_ptr, (FCELL) pval_f[0],
 					 map_type);
 		    break;
 		case DCELL_TYPE:
 		    pval_d = (double *)array_ptr;
-		    G_set_raster_value_d(rastline_ptr, (DCELL) pval_d[0],
+		    Rast_set_raster_value_d(rastline_ptr, (DCELL) pval_d[0],
 					 map_type);
 		    break;
 		default:
-		    G_close_cell(cf);
 		    G_fatal_error(_("Please contact the GRASS development team"));
 	    rastline_ptr =
-		G_incr_void_ptr(rastline_ptr, G_raster_size(map_type));
+		Rast_incr_void_ptr(rastline_ptr, Rast_raster_size(map_type));
 #ifdef DEBUG
 	fprintf(stderr, "row[%d]=[", row);
 	rastline_ptr = raster;
-	    if (G_is_null_value(rastline_ptr, map_type))
+	    if (Rast_is_null_value(rastline_ptr, map_type))
 		fprintf(stderr, "_");
 	    else
 		fprintf(stderr, "+");
 	    rastline_ptr =
 	fprintf(stderr, "]\n");
 #endif
-	if (1 != G_put_raster_row(cf, raster, map_type)) {
-	    G_close_cell(cf);
+	if (1 != Rast_put_raster_row(cf, raster, map_type)) {
 	    G_fatal_error(_("Writing raster map, row %d"), row);
@@ -479,7 +480,7 @@
     G_percent(row, mrows, 5);	/* finish it off */
-    G_close_cell(cf);
     G_free(array_data);
     G_free(raster);
@@ -488,11 +489,11 @@
     if (!have_title)
 	strncpy(map_title, infile, 1023);
-    G_put_cell_title(map_name, map_title);
+    Rast_put_cell_title(map_name, map_title);
-    G_short_history(map_name, "raster", &history);
-    G_write_history(map_name, &history);
+    Rast_short_history(map_name, "raster", &history);
+    Rast_write_history(map_name, &history);
     G_done_msg("");
@@ -516,7 +517,7 @@
     switch (dtype) {
     case CELL_TYPE:		/* int doesn't have a IEEE NaN value, but we'll accept GRASS's version */
-	if (G_is_null_value(p, dtype))
+	if (Rast_is_null_value(p, dtype))
 	    return 1;
 	break;
     case FCELL_TYPE:
Modified: grass/trunk/raster/r.in.poly/get_item.c
--- grass/trunk/raster/r.in.poly/get_item.c	2009-06-20 21:39:23 UTC (rev 38002)
+++ grass/trunk/raster/r.in.poly/get_item.c	2009-06-20 22:03:23 UTC (rev 38003)
@@ -1,4 +1,5 @@
 int get_item(FILE * fd, int *type, long *cat, double **x, double **y,
 	     int *count, struct Categories *labels)
@@ -65,7 +66,7 @@
 	    /* probably change this as G_getl2() doesn't store the new line (?) */
 	    if (sscanf(buf + 1, "%ld%[^\n]", cat, lbl) == 2) {
 		G_strip(lbl);
-		G_set_cat((CELL) * cat, lbl, labels);
+		Rast_set_cat((CELL) * cat, lbl, labels);
 	    continue;
Modified: grass/trunk/raster/r.in.poly/getformat.c
--- grass/trunk/raster/r.in.poly/getformat.c	2009-06-20 21:39:23 UTC (rev 38002)
+++ grass/trunk/raster/r.in.poly/getformat.c	2009-06-20 22:03:23 UTC (rev 38003)
@@ -1,4 +1,5 @@
 #include "format.h"
 int getformat(FILE * fd)
Modified: grass/trunk/raster/r.in.poly/main.c
--- grass/trunk/raster/r.in.poly/main.c	2009-06-20 21:39:23 UTC (rev 38002)
+++ grass/trunk/raster/r.in.poly/main.c	2009-06-20 22:03:23 UTC (rev 38003)
@@ -13,6 +13,7 @@
 #include <stdlib.h>
Modified: grass/trunk/raster/r.in.poly/poly2rast.c
--- grass/trunk/raster/r.in.poly/poly2rast.c	2009-06-20 21:39:23 UTC (rev 38002)
+++ grass/trunk/raster/r.in.poly/poly2rast.c	2009-06-20 22:03:23 UTC (rev 38003)
@@ -1,6 +1,7 @@
 #include <stdlib.h>
 #include <string.h>
 #include "format.h"
@@ -31,7 +32,7 @@
 	exit(EXIT_FAILURE);
-    rfd = G_open_cell_new(raster_map);
+    rfd = Rast_open_cell_new(raster_map);
     if (rfd < 0)
 	G_fatal_error(_("Can't create raster map <%s>"), raster_map);
@@ -39,7 +40,7 @@
 	title = "";
     G_strip(title);
-    G_init_cats((CELL) 0, title, &labels);
+    Rast_init_cats((CELL) 0, title, &labels);
     format = getformat(ifd);
     npasses = begin_rasterization(nrows, format);
@@ -80,15 +81,15 @@
     if (stat < 0) {
-	G_unopen_cell(rfd);
+	Rast_unopen_cell(rfd);
 	return 1;
-    G_close_cell(rfd);
-    G_write_cats(raster_map, &labels);
-    G_short_history(raster_map, "raster", &history);
-    G_write_history(raster_map, &history);
+    Rast_close_cell(rfd);
+    Rast_write_cats(raster_map, &labels);
+    Rast_short_history(raster_map, "raster", &history);
+    Rast_write_history(raster_map, &history);
     return 0;
Modified: grass/trunk/raster/r.in.poly/raster.c
--- grass/trunk/raster/r.in.poly/raster.c	2009-06-20 21:39:23 UTC (rev 38002)
+++ grass/trunk/raster/r.in.poly/raster.c	2009-06-20 22:03:23 UTC (rev 38003)
@@ -1,4 +1,5 @@
 #include "format.h"
@@ -81,7 +82,7 @@
 	break;
     if (format != USE_CELL)
-	cell = G_allocate_cell_buf();
+	cell = Rast_allocate_cell_buf();
     at_row = 0;
     configure_plot();
@@ -157,7 +158,7 @@
 	    for (j = 0; j < page.cols; j++) {
 		cell[j] = (CELL) raster.c[i][j];
 		if (cell[j] == 0)
-		    G_set_null_value(&cell[j], 1, CELL_TYPE);
+		    Rast_set_null_value(&cell[j], 1, CELL_TYPE);
 	    break;
@@ -165,7 +166,7 @@
 		cell[j] = (CELL) raster.u[i][j];
 		if (cell[j] == 0)
 	    break;
@@ -173,19 +174,19 @@
 		cell[j] = (CELL) raster.s[i][j];
 		if (cell[j] == 0)
 	    break;
 	case USE_CELL:
 	    cell = raster.cell[i];
 	    if (cell == 0)
-		G_set_null_value(&cell, 1, CELL_TYPE);
+		Rast_set_null_value(&cell, 1, CELL_TYPE);
 	    break;
 	G_percent(i, page.rows, 2);
-	if (G_put_raster_row(fd, cell, CELL_TYPE) < 0)
+	if (Rast_put_raster_row(fd, cell, CELL_TYPE) < 0)
 	    return ERROR;
Modified: grass/trunk/raster/r.in.xyz/local_proto.h
--- grass/trunk/raster/r.in.xyz/local_proto.h	2009-06-20 21:39:23 UTC (rev 38002)
+++ grass/trunk/raster/r.in.xyz/local_proto.h	2009-06-20 22:03:23 UTC (rev 38003)
@@ -19,6 +19,7 @@
 #define BUFFSIZE 256
Modified: grass/trunk/raster/r.in.xyz/main.c
--- grass/trunk/raster/r.in.xyz/main.c	2009-06-20 21:39:23 UTC (rev 38002)
+++ grass/trunk/raster/r.in.xyz/main.c	2009-06-20 22:03:23 UTC (rev 38003)
@@ -22,6 +22,7 @@
 #include <math.h>
 #include <sys/types.h>
@@ -427,18 +428,18 @@
     if (!scan_flag->answer) {
 	/* allocate memory (test for enough before we start) */
 	if (bin_n)
-	    n_array = G_calloc(rows * (cols + 1), G_raster_size(CELL_TYPE));
+	    n_array = G_calloc(rows * (cols + 1), Rast_raster_size(CELL_TYPE));
 	if (bin_min)
-	    min_array = G_calloc(rows * (cols + 1), G_raster_size(rtype));
+	    min_array = G_calloc(rows * (cols + 1), Rast_raster_size(rtype));
 	if (bin_max)
-	    max_array = G_calloc(rows * (cols + 1), G_raster_size(rtype));
+	    max_array = G_calloc(rows * (cols + 1), Rast_raster_size(rtype));
 	if (bin_sum)
-	    sum_array = G_calloc(rows * (cols + 1), G_raster_size(rtype));
+	    sum_array = G_calloc(rows * (cols + 1), Rast_raster_size(rtype));
 	if (bin_sumsq)
-	    sumsq_array = G_calloc(rows * (cols + 1), G_raster_size(rtype));
+	    sumsq_array = G_calloc(rows * (cols + 1), Rast_raster_size(rtype));
 	if (bin_index)
 	    index_array =
-		G_calloc(rows * (cols + 1), G_raster_size(CELL_TYPE));
+		G_calloc(rows * (cols + 1), Rast_raster_size(CELL_TYPE));
 	/* and then free it again */
 	if (bin_n)
@@ -492,7 +493,7 @@
     /* open output map */
-    out_fd = G_open_raster_new(outmap, rtype);
+    out_fd = Rast_open_raster_new(outmap, rtype);
     if (out_fd < 0)
 	G_fatal_error(_("Unable to create raster map <%s>"), outmap);
@@ -515,7 +516,7 @@
 	estimated_lines = -1;
     /* allocate memory for a single row of output data */
-    raster_row = G_allocate_raster_buf(rtype);
+    raster_row = Rast_allocate_raster_buf(rtype);
     G_message(_("Scanning data ..."));
@@ -541,33 +542,33 @@
 	if (bin_n) {
 	    G_debug(2, "allocating n_array");
 	    blank_array(n_array, rows, cols, CELL_TYPE, 0);
 	if (bin_min) {
 	    G_debug(2, "allocating min_array");
 	    blank_array(min_array, rows, cols, rtype, -1);	/* fill with NULLs */
 	if (bin_max) {
 	    G_debug(2, "allocating max_array");
 	    blank_array(max_array, rows, cols, rtype, -1);	/* fill with NULLs */
 	if (bin_sum) {
 	    G_debug(2, "allocating sum_array");
 	    blank_array(sum_array, rows, cols, rtype, 0);
 	if (bin_sumsq) {
 	    G_debug(2, "allocating sumsq_array");
 	    blank_array(sumsq_array, rows, cols, rtype, 0);
 	if (bin_index) {
 	    G_debug(2, "allocating index_array");
 	    index_array =
 	    blank_array(index_array, rows, cols, CELL_TYPE, -1);	/* fill with NULLs */
@@ -688,22 +689,22 @@
 	    if (bin_index) {
 		ptr = index_array;
 		ptr =
-		    G_incr_void_ptr(ptr,
+		    Rast_incr_void_ptr(ptr,
 				    ((arr_row * cols) +
-				     arr_col) * G_raster_size(CELL_TYPE));
+				     arr_col) * Rast_raster_size(CELL_TYPE));
-		if (G_is_null_value(ptr, CELL_TYPE)) {	/* first node */
+		if (Rast_is_null_value(ptr, CELL_TYPE)) {	/* first node */
 		    head_id = new_node();
 		    nodes[head_id].next = -1;
 		    nodes[head_id].z = z;
-		    G_set_raster_value_c(ptr, head_id, CELL_TYPE);	/* store index to head */
+		    Rast_set_raster_value_c(ptr, head_id, CELL_TYPE);	/* store index to head */
 		else {		/* head is already there */
-		    head_id = G_get_raster_value_c(ptr, CELL_TYPE);	/* get index to head */
+		    head_id = Rast_get_raster_value_c(ptr, CELL_TYPE);	/* get index to head */
 		    head_id = add_node(head_id, z);
 		    if (head_id != -1)
 	}			/* while !EOF */
@@ -719,55 +720,55 @@
 	    switch (method) {
 	    case METHOD_N:	/* n is a straight copy */
-		G_raster_cpy(raster_row,
+		Rast_raster_cpy(raster_row,
 			     n_array +
-			     (row * cols * G_raster_size(CELL_TYPE)), cols,
+			     (row * cols * Rast_raster_size(CELL_TYPE)), cols,
 			     CELL_TYPE);
 		break;
 	    case METHOD_MIN:
-			     min_array + (row * cols * G_raster_size(rtype)),
+			     min_array + (row * cols * Rast_raster_size(rtype)),
 			     cols, rtype);
 		break;
 	    case METHOD_MAX:
-			     max_array + (row * cols * G_raster_size(rtype)),
+			     max_array + (row * cols * Rast_raster_size(rtype)),
 			     cols, rtype);
 		break;
 	    case METHOD_SUM:
-			     sum_array + (row * cols * G_raster_size(rtype)),
+			     sum_array + (row * cols * Rast_raster_size(rtype)),
 			     cols, rtype);
 		break;
 	    case METHOD_RANGE:	/* (max-min) */
 		ptr = raster_row;
 		for (col = 0; col < cols; col++) {
-		    offset = (row * cols + col) * G_raster_size(rtype);
-		    min = G_get_raster_value_d(min_array + offset, rtype);
-		    max = G_get_raster_value_d(max_array + offset, rtype);
-		    G_set_raster_value_d(ptr, max - min, rtype);
-		    ptr = G_incr_void_ptr(ptr, G_raster_size(rtype));
+		    offset = (row * cols + col) * Rast_raster_size(rtype);
+		    min = Rast_get_raster_value_d(min_array + offset, rtype);
+		    max = Rast_get_raster_value_d(max_array + offset, rtype);
+		    Rast_set_raster_value_d(ptr, max - min, rtype);
+		    ptr = Rast_incr_void_ptr(ptr, Rast_raster_size(rtype));
 		break;
 	    case METHOD_MEAN:	/* (sum / n) */
 		ptr = raster_row;
-		    n_offset = (row * cols + col) * G_raster_size(CELL_TYPE);
-		    n = G_get_raster_value_c(n_array + n_offset, CELL_TYPE);
-		    sum = G_get_raster_value_d(sum_array + offset, rtype);
+		    n_offset = (row * cols + col) * Rast_raster_size(CELL_TYPE);
+		    n = Rast_get_raster_value_c(n_array + n_offset, CELL_TYPE);
+		    sum = Rast_get_raster_value_d(sum_array + offset, rtype);
 		    if (n == 0)
-			G_set_null_value(ptr, 1, rtype);
+			Rast_set_null_value(ptr, 1, rtype);
 		    else
-			G_set_raster_value_d(ptr, (sum / n), rtype);
+			Rast_set_raster_value_d(ptr, (sum / n), rtype);
 		break;
@@ -776,45 +777,45 @@
 	    case METHOD_COEFF_VAR:	/*  100 * stdev / mean    */
 		ptr = raster_row;
-		    sumsq = G_get_raster_value_d(sumsq_array + offset, rtype);
+		    sumsq = Rast_get_raster_value_d(sumsq_array + offset, rtype);
 		    if (n == 0)
 		    else {
 			variance = (sumsq - sum * sum / n) / n;
 			if (variance < GRASS_EPSILON)
 			    variance = 0.0;
 			if (method == METHOD_STDDEV)
-			    G_set_raster_value_d(ptr, sqrt(variance), rtype);
+			    Rast_set_raster_value_d(ptr, sqrt(variance), rtype);
 			else if (method == METHOD_VARIANCE)
-			    G_set_raster_value_d(ptr, variance, rtype);
+			    Rast_set_raster_value_d(ptr, variance, rtype);
 			else if (method == METHOD_COEFF_VAR)
 						 100 * sqrt(variance) / (sum /
 									 n),
 						 rtype);
 		break;
 	    case METHOD_MEDIAN:	/* median, if only one point in cell we will use that */
 		ptr = raster_row;
-		    if (G_is_null_value(index_array + n_offset, CELL_TYPE))	/* no points in cell */
+		    if (Rast_is_null_value(index_array + n_offset, CELL_TYPE))	/* no points in cell */
 		    else {	/* one or more points in cell */
 			head_id =
-			    G_get_raster_value_c(index_array + n_offset,
+			    Rast_get_raster_value_c(index_array + n_offset,
 						 CELL_TYPE);
 			node_id = head_id;
@@ -826,7 +827,7 @@
 			if (n == 1)	/* only one point, use that */
-			    G_set_raster_value_d(ptr, nodes[head_id].z,
+			    Rast_set_raster_value_d(ptr, nodes[head_id].z,
 						 rtype);
 			else if (n % 2 != 0) {	/* odd number of points: median_i = (n + 1) / 2 */
 			    n = (n + 1) / 2;
@@ -834,7 +835,7 @@
 			    for (j = 1; j < n; j++)	/* get "median element" */
 				node_id = nodes[node_id].next;
-			    G_set_raster_value_d(ptr, nodes[node_id].z,
+			    Rast_set_raster_value_d(ptr, nodes[node_id].z,
 						 rtype);
 			else {	/* even number of points: median = (val_below + val_above) / 2 */
@@ -847,21 +848,21 @@
 			    z = (nodes[node_id].z +
 				 nodes[nodes[node_id].next].z) / 2;
-			    G_set_raster_value_d(ptr, z, rtype);
+			    Rast_set_raster_value_d(ptr, z, rtype);
 		break;
 	    case METHOD_PERCENTILE:	/* rank = (pth*(n+1))/100; interpolate linearly */
 		ptr = raster_row;
 		    else {
 			head_id =
 						 CELL_TYPE);
 			node_id = head_id;
 			n = 0;
@@ -892,20 +893,20 @@
 			z = (z + nodes[node_id].z) / 2;
 		break;
 	    case METHOD_SKEWNESS:	/* skewness = sum(xi-mean)^3/(N-1)*s^3 */
 		ptr = raster_row;
 		    else {
 			head_id =
 						 CELL_TYPE);
 			node_id = head_id;
@@ -940,20 +941,20 @@
 				    sumdev / ((n - 1) *
 					      pow(sqrt(variance), 3));
-			G_set_raster_value_d(ptr, skew, rtype);
+			Rast_set_raster_value_d(ptr, skew, rtype);
 		break;
 	    case METHOD_TRIMMEAN:
 		ptr = raster_row;
 		    else {
 			head_id =
 						 CELL_TYPE);
 			node_id = head_id;
@@ -997,9 +998,9 @@
 			    mean = sum / n;
-			G_set_raster_value_d(ptr, mean, rtype);
+			Rast_set_raster_value_d(ptr, mean, rtype);
 		break;
@@ -1008,8 +1009,8 @@
 	    /* write out line of raster data */
-	    if (1 != G_put_raster_row(out_fd, raster_row, rtype)) {
+	    if (1 != Rast_put_raster_row(out_fd, raster_row, rtype)) {
 		G_fatal_error(_("Writing map, row %d"),
 			      ((pass - 1) * rows) + row);
@@ -1044,17 +1045,17 @@
 	fclose(in_fp);
     /* close raster file & write history */
     sprintf(title, "Raw x,y,z data binned into a raster grid by cell %s",
 	    method_opt->answer);
-    G_put_cell_title(outmap, title);
+    Rast_put_cell_title(outmap, title);
-    G_short_history(outmap, "raster", &history);
+    Rast_short_history(outmap, "raster", &history);
     strncpy(history.datsrc_1, infile, RECORD_LEN);
     history.datsrc_1[RECORD_LEN - 1] = '\0';	/* strncpy() doesn't null terminate if maxfill */
-    G_write_history(outmap, &history);
+    Rast_write_history(outmap, &history);
     sprintf(buff, _("%lu points found in region."), count_total);
Modified: grass/trunk/raster/r.in.xyz/support.c
--- grass/trunk/raster/r.in.xyz/support.c	2009-06-20 21:39:23 UTC (rev 38002)
+++ grass/trunk/raster/r.in.xyz/support.c	2009-06-20 22:03:23 UTC (rev 38003)
@@ -9,14 +9,15 @@
 static void *get_cell_ptr(void *array, int cols, int row, int col,
 			  RASTER_MAP_TYPE map_type)
-    return G_incr_void_ptr(array,
+    return Rast_incr_void_ptr(array,
 			   ((row * (size_t) cols) +
-			    col) * G_raster_size(map_type));
+			    col) * Rast_raster_size(map_type));
 int blank_array(void *array, int nrows, int ncols, RASTER_MAP_TYPE map_type,
@@ -32,12 +33,12 @@
     switch (value) {
     case 0:
 	/* fill with 0 */
-	/* simpler to use G_raster_cpy() or similar ?? */
+	/* simpler to use Rast_raster_cpy() or similar ?? */
-		G_set_raster_value_c(ptr, 0, map_type);
-		ptr = G_incr_void_ptr(ptr, G_raster_size(map_type));
+		Rast_set_raster_value_c(ptr, 0, map_type);
+		ptr = Rast_incr_void_ptr(ptr, Rast_raster_size(map_type));
 	break;
@@ -45,7 +46,7 @@
     case -1:
 	/* fill with NULL */
 	/* alloc for col+1, do we come up (nrows) short? no. */
-	G_set_null_value(array, nrows * ncols, map_type);
+	Rast_set_null_value(array, nrows * ncols, map_type);
 	break;
     default:
@@ -61,8 +62,8 @@
     void *ptr = get_cell_ptr(array, cols, row, col, CELL_TYPE);
     CELL old_n;
-    old_n = G_get_raster_value_c(ptr, CELL_TYPE);
-    G_set_raster_value_c(ptr, (1 + old_n), CELL_TYPE);
+    old_n = Rast_get_raster_value_c(ptr, CELL_TYPE);
+    Rast_set_raster_value_c(ptr, (1 + old_n), CELL_TYPE);
     return 0;
@@ -74,12 +75,12 @@
     void *ptr = get_cell_ptr(array, cols, row, col, map_type);
     DCELL old_val;
-    if (G_is_null_value(ptr, map_type))
-	G_set_raster_value_d(ptr, (DCELL) value, map_type);
+    if (Rast_is_null_value(ptr, map_type))
+	Rast_set_raster_value_d(ptr, (DCELL) value, map_type);
     else {
-	old_val = G_get_raster_value_d(ptr, map_type);
+	old_val = Rast_get_raster_value_d(ptr, map_type);
 	if (value < old_val)
     return 0;
@@ -91,12 +92,12 @@
     DCELL old_val;
     else {
 	if (value > old_val)
     return 0;
@@ -109,8 +110,8 @@
     DCELL old_val;
-    G_set_raster_value_d(ptr, value + old_val, map_type);
+    Rast_set_raster_value_d(ptr, value + old_val, map_type);
     return 0;
@@ -122,8 +123,8 @@
     DCELL old_val;
-    G_set_raster_value_d(ptr, (value * value) + old_val, map_type);
+    Rast_set_raster_value_d(ptr, (value * value) + old_val, map_type);
     return 0;
Modified: grass/trunk/raster/r.info/main.c
--- grass/trunk/raster/r.info/main.c	2009-06-20 21:39:23 UTC (rev 38002)
+++ grass/trunk/raster/r.info/main.c	2009-06-20 22:03:23 UTC (rev 38003)
@@ -20,6 +20,7 @@
 #include <string.h>
 #include <stdarg.h>
 #include <grass/glocale.h>
@@ -117,15 +118,15 @@
     if ((mapset = G_find_cell2(name, "")) == NULL)
 	G_fatal_error(_("Raster map <%s> not found"), name);
-    head_ok = G_get_cellhd(name, "", &cellhd) >= 0;
-    cats_ok = G_read_cats(name, "", &cats) >= 0;
-    hist_ok = G_read_history(name, "", &hist) >= 0;
-    is_reclass = G_get_reclass(name, "", &reclass);
-    data_type = G_raster_map_type(name, "");
+    head_ok = Rast_get_cellhd(name, "", &cellhd) >= 0;
+    cats_ok = Rast_read_cats(name, "", &cats) >= 0;
+    hist_ok = Rast_read_history(name, "", &hist) >= 0;
+    is_reclass = Rast_get_reclass(name, "", &reclass);
+    data_type = Rast_raster_map_type(name, "");
-    if (G_read_raster_units(name, "", units) != 0)
+    if (Rast_read_raster_units(name, "", units) != 0)
 	units[0] = '\0';
-    if (G_read_raster_vdatum(name, "", vdatum) != 0)
+    if (Rast_read_raster_vdatum(name, "", vdatum) != 0)
 	vdatum[0] = '\0';
     /*Check the Timestamp */
@@ -138,9 +139,9 @@
 	    second_time_ok = 1;
-    if (G_read_fp_range(name, "", &range) < 0)
+    if (Rast_read_fp_range(name, "", &range) < 0)
 	G_fatal_error(_("Unable to read range file"));
-    G_get_fp_range_min_max(&range, &zmin, &zmax);
+    Rast_get_fp_range_min_max(&range, &zmin, &zmax);
     out = stdout;
@@ -228,7 +229,7 @@
 			 tmp1, tmp2, tmp3);
 	    if (data_type == CELL_TYPE) {
-		if (2 == G_read_range(name, "", &crange))
+		if (2 == Rast_read_range(name, "", &crange))
 		    compose_line(out,
 				 "  Range of data:    min = NULL  max = NULL");
 		else
@@ -282,7 +283,7 @@
 	    for (i = 0; i < reclass.num; i++) {
 		CELL x = reclass.table[i];
-		if (G_is_c_null_value(&x))
+		if (Rast_is_c_null_value(&x))
 		    continue;
 		if (first || x < mincat)
 		    mincat = x;
@@ -320,7 +321,7 @@
 	if (rflag->answer) {
-		if (2 == G_read_range(name, "", &crange)) {
+		if (2 == Rast_read_range(name, "", &crange)) {
 		    fprintf(out, "min=NULL\n");
 		    fprintf(out, "max=NULL\n");
Modified: grass/trunk/raster/r.info/reclas_txt.c
--- grass/trunk/raster/r.info/reclas_txt.c	2009-06-20 21:39:23 UTC (rev 38002)
+++ grass/trunk/raster/r.info/reclas_txt.c	2009-06-20 22:03:23 UTC (rev 38003)
@@ -1,5 +1,6 @@
 #include <string.h>
Modified: grass/trunk/raster/r.kappa/calc_kappa.c
--- grass/trunk/raster/r.kappa/calc_kappa.c	2009-06-20 21:39:23 UTC (rev 38002)
+++ grass/trunk/raster/r.kappa/calc_kappa.c	2009-06-20 22:03:23 UTC (rev 38003)
@@ -1,5 +1,6 @@
 #include <stdlib.h>
 #include "kappa.h"
Modified: grass/trunk/raster/r.kappa/kappa.h
--- grass/trunk/raster/r.kappa/kappa.h	2009-06-20 21:39:23 UTC (rev 38002)
+++ grass/trunk/raster/r.kappa/kappa.h	2009-06-20 22:03:23 UTC (rev 38003)
@@ -1,5 +1,6 @@
 #include <math.h>
 struct _gstats_
Modified: grass/trunk/raster/r.kappa/main.c
--- grass/trunk/raster/r.kappa/main.c	2009-06-20 21:39:23 UTC (rev 38002)
+++ grass/trunk/raster/r.kappa/main.c	2009-06-20 22:03:23 UTC (rev 38003)
@@ -24,6 +24,7 @@
 #include <stdio.h>
 #include <string.h>
 #include "kappa.h"
@@ -145,5 +146,5 @@
     layers = (LAYER *) G_realloc(layers, 2 * sizeof(LAYER));
     layers[n].name = G_store(name);
     layers[n].mapset = mapset;
-    G_read_cats(name, mapset, &layers[n].labels);
+    Rast_read_cats(name, mapset, &layers[n].labels);
Modified: grass/trunk/raster/r.kappa/mask.c
--- grass/trunk/raster/r.kappa/mask.c	2009-06-20 21:39:23 UTC (rev 38002)
+++ grass/trunk/raster/r.kappa/mask.c	2009-06-20 22:03:23 UTC (rev 38003)
@@ -19,7 +19,7 @@
     results = NULL;
     if (G_find_cell("MASK", G_mapset()) == NULL)
 	return "none";
-    if (G_get_reclass("MASK", G_mapset(), &reclass) <= 0) {
+    if (Rast_get_reclass("MASK", G_mapset(), &reclass) <= 0) {
 	sprintf(text, "MASK in %s", G_mapset());
 	return append(results, text);
@@ -39,7 +39,7 @@
 	results = append(results, " ");
 	results = append(results, text);
     } while (next >= 0);
-    G_free_reclass(&reclass);
+    Rast_free_reclass(&reclass);
     return results;
Modified: grass/trunk/raster/r.kappa/prt_hdr.c
--- grass/trunk/raster/r.kappa/prt_hdr.c	2009-06-20 21:39:23 UTC (rev 38002)
+++ grass/trunk/raster/r.kappa/prt_hdr.c	2009-06-20 22:03:23 UTC (rev 38003)
@@ -31,7 +31,7 @@
     len = strlen(label);
     for (i = 0; i < nlayers; i++) {
-	titles = G_get_cats_title(&(layers[i].labels));
+	titles = Rast_get_cats_title(&(layers[i].labels));
 	if (titles)
 	    G_strip(titles);
 	if (titles == NULL || *titles == 0)
Modified: grass/trunk/raster/r.kappa/prt_label.c
--- grass/trunk/raster/r.kappa/prt_label.c	2009-06-20 21:39:23 UTC (rev 38002)
+++ grass/trunk/raster/r.kappa/prt_label.c	2009-06-20 22:03:23 UTC (rev 38003)
@@ -23,7 +23,7 @@
 	fprintf(fd, "MAP%-d Category Description\n", i + 1);
 	for (j = 0; j < ncat; j++) {
 	    cats = rlst;
-	    cl = G_get_cat((CELL) cats[j], &(layers[i].labels));
+	    cl = Rast_get_cat((CELL) cats[j], &(layers[i].labels));
 	    if (cl)
 		G_strip(cl);
 	    if (cl == NULL || *cl == 0)
Modified: grass/trunk/raster/r.kappa/prt_mat.c
--- grass/trunk/raster/r.kappa/prt_mat.c	2009-06-20 21:39:23 UTC (rev 38002)
+++ grass/trunk/raster/r.kappa/prt_mat.c	2009-06-20 22:03:23 UTC (rev 38003)
@@ -1,5 +1,6 @@
 #include <stdlib.h>
 #include "kappa.h"
Modified: grass/trunk/raster/r.kappa/stats.c
--- grass/trunk/raster/r.kappa/stats.c	2009-06-20 21:39:23 UTC (rev 38002)
+++ grass/trunk/raster/r.kappa/stats.c	2009-06-20 22:03:23 UTC (rev 38003)
@@ -2,6 +2,7 @@
 #include <string.h>
 #include <unistd.h>
 #include "kappa.h"
Modified: grass/trunk/raster/r.lake/main.c
--- grass/trunk/raster/r.lake/main.c	2009-06-20 21:39:23 UTC (rev 38002)
+++ grass/trunk/raster/r.lake/main.c	2009-06-20 22:03:23 UTC (rev 38003)
@@ -36,6 +36,7 @@
 #include <stdlib.h>
 /* Saves map file from 2d array. NULL must be 0. Also meanwhile calculates area and volume. */
@@ -60,7 +61,7 @@
 	    if (flag == 1)	/* Create negative map */
 		out[row][col] = 0 - out[row][col];
 	    if (out[row][col] == 0) {
-		G_set_f_null_value(&out[row][col], 1);
+		Rast_set_f_null_value(&out[row][col], 1);
 	    if (out[row][col] > 0 || out[row][col] < 0) {
 		G_debug(5, "volume %f += cellsize %f  * value %f [%d,%d]",
@@ -75,7 +76,7 @@
 	    if (out[row][col] < *min_depth)
 		*min_depth = out[row][col];
-	if (G_put_f_raster_row(out_fd, out[row]) == -1)
+	if (Rast_put_f_raster_row(out_fd, out[row]) == -1)
 	    G_fatal_error(_("Failed writing output raster map row %d"), row);
 	G_percent(row + 1, rows, 5);
@@ -212,7 +213,7 @@
     /* If lakemap is set, write to it, else is set overwrite flag and we should write to seedmap. */
     if (lakemap) {
-	lake_fd = G_open_raster_new(lakemap, 1);
+	lake_fd = Rast_open_raster_new(lakemap, 1);
 	if (lake_fd < 0)
 	    G_fatal_error(_("Unable to create raster map <%s>"), lakemap);
@@ -237,13 +238,13 @@
     /* Open terran map */
-    in_terran_fd = G_open_cell_old(terrainmap, "");
+    in_terran_fd = Rast_open_cell_old(terrainmap, "");
     if (in_terran_fd < 0)
 	G_fatal_error(_("Unable to open raster map <%s>"), terrainmap);
     /* Open seed map */
     if (smap_opt->answer) {
-	out_fd = G_open_cell_old(seedmap, "");
+	out_fd = Rast_open_cell_old(seedmap, "");
 	if (out_fd < 0)
 	    G_fatal_error(_("Unable to open raster map <%s>"), seedmap);
@@ -262,12 +263,12 @@
 	out_water[row] = (FCELL *) G_calloc(cols, sizeof(FCELL));
 	/* In newly created space load data from file. */
-	if (G_get_f_raster_row(in_terran_fd, in_terran[row], row) != 1)
+	if (Rast_get_f_raster_row(in_terran_fd, in_terran[row], row) != 1)
 	    G_fatal_error(_("Unable to read raster map <%s> row %d"),
 			  terrainmap, row);
-	    if (G_get_f_raster_row(out_fd, out_water[row], row) != 1)
+	    if (Rast_get_f_raster_row(out_fd, out_water[row], row) != 1)
 			      seedmap, row);
@@ -284,14 +285,14 @@
     /* Close seed map for reading. */
     /* Open output map for writing. */
     if (lakemap) {
 	out_fd = lake_fd;
     else {
-	out_fd = G_open_raster_new(seedmap, 1);
+	out_fd = Rast_open_raster_new(seedmap, 1);
 	if (out_fd < 0)
 	    G_fatal_error(_("Unable to create raster map <%s>"), seedmap);
@@ -367,27 +368,27 @@
     G_warning(_("Volume is correct only if lake depth (terrain raster map) is in meters"));
     /* Close all files. Lake map gets written only now. */
-    G_close_cell(in_terran_fd);
+    Rast_close_cell(in_terran_fd);
     /* Add blue color gradient from light bank to dark depth */
-    G_init_colors(&colr);
+    Rast_init_colors(&colr);
     if (negative_flag->answer == 1) {
-	G_add_f_raster_color_rule(&max_depth, 0, 240, 255,
+	Rast_add_f_raster_color_rule(&max_depth, 0, 240, 255,
 				  &min_depth, 0, 50, 170, &colr);
     else {
-	G_add_f_raster_color_rule(&min_depth, 0, 240, 255,
+	Rast_add_f_raster_color_rule(&min_depth, 0, 240, 255,
 				  &max_depth, 0, 50, 170, &colr);
-    if (G_write_colors(lakemap, G_mapset(), &colr) != 1)
+    if (Rast_write_colors(lakemap, G_mapset(), &colr) != 1)
 	G_fatal_error(_("Unable to read color file of raster map <%s>"),
 		      lakemap);
-    G_short_history(lakemap, "raster", &history);
-    G_write_history(lakemap, &history);
+    Rast_short_history(lakemap, "raster", &history);
+    Rast_write_history(lakemap, &history);
Modified: grass/trunk/raster/r.le/r.le.patch/driver.c
--- grass/trunk/raster/r.le/r.le.patch/driver.c	2009-06-20 21:39:23 UTC (rev 38002)
+++ grass/trunk/raster/r.le/r.le.patch/driver.c	2009-06-20 22:03:23 UTC (rev 38003)
@@ -72,7 +72,7 @@
        map remains open on finput while all the programs
        run, so it is globally available */
-    if (0 > (finput = G_open_cell_old(choice->fn, G_mapset()))) {
+    if (0 > (finput = Rast_open_cell_old(choice->fn, G_mapset()))) {
 	fprintf(stderr, "\n");
 	fprintf(stderr,
 		"   ******* *************************************************\n");
@@ -90,7 +90,7 @@
        double (DCELL_TYPE) and make globally available */
     else
-	data_type = G_raster_map_type(choice->fn, G_mapset());
+	data_type = Rast_raster_map_type(choice->fn, G_mapset());
     /* if using a moving window, get the parameters,
@@ -122,7 +122,7 @@
     /* when everything is done, close the raster map
        and print a completion message */
-    G_close_cell(finput);
+    Rast_close_cell(finput);
     fputs("\nR.LE.PATCH IS DONE;  ", stderr);
     if (choice->wrum != 'm')
 	fputs("OUTPUT FILES IN SUBDIRECTORY \"r.le.out\"\n", stderr);
@@ -551,49 +551,49 @@
 	    sprintf(cmdbuf, "%s %s", "g.rename -o", "rast=a1,a1bak");
 	    system(cmdbuf);
-	a1 = G_open_raster_new("a1", DCELL_TYPE);
+	a1 = Rast_open_raster_new("a1", DCELL_TYPE);
     if (choice->att[2]) {
 	if (G_find_cell("a2", G_mapset()) != NULL) {
 	    sprintf(cmdbuf, "%s %s", "g.rename -o", "rast=a2,a2bak");
 	    system(cmdbuf);
-	a2 = G_open_raster_new("a2", DCELL_TYPE);
+	a2 = Rast_open_raster_new("a2", DCELL_TYPE);
     if (choice->att[3]) {
 	if (G_find_cell("a3", G_mapset()) != NULL) {
 	    sprintf(cmdbuf, "%s %s", "g.rename -o", "rast=a3,a3bak");
 	    system(cmdbuf);
-	a3 = G_open_raster_new("a3", DCELL_TYPE);
+	a3 = Rast_open_raster_new("a3", DCELL_TYPE);
     if (choice->att[4]) {
 	if (G_find_cell("a4", G_mapset()) != NULL) {
 	    sprintf(cmdbuf, "%s %s", "g.rename -o", "rast=a4,a4bak");
 	    system(cmdbuf);
-	a4 = G_open_raster_new("a4", DCELL_TYPE);
+	a4 = Rast_open_raster_new("a4", DCELL_TYPE);
     if (choice->att[5]) {
 	if (G_find_cell("a5", G_mapset()) != NULL) {
 	    sprintf(cmdbuf, "%s %s", "g.rename -o", "rast=a5,a5bak");
 	    system(cmdbuf);
-	a5 = G_open_raster_new("a5", DCELL_TYPE);
+	a5 = Rast_open_raster_new("a5", DCELL_TYPE);
     if (choice->att[6]) {
 	if (G_find_cell("a6", G_mapset()) != NULL) {
 	    sprintf(cmdbuf, "%s %s", "g.rename -o", "rast=a6,a6bak");
 	    system(cmdbuf);
-	a6 = G_open_raster_new("a6", DCELL_TYPE);
+	a6 = Rast_open_raster_new("a6", DCELL_TYPE);
     if (choice->att[7]) {
 	if (G_find_cell("a7", G_mapset()) != NULL) {
 	    sprintf(cmdbuf, "%s %s", "g.rename -o", "rast=a7,a7bak");
 	    system(cmdbuf);
-	a7 = G_open_raster_new("a7", DCELL_TYPE);
+	a7 = Rast_open_raster_new("a7", DCELL_TYPE);
     if (choice->att[8]) {
@@ -601,7 +601,7 @@
 	    sprintf(cmdbuf, "%s %s", "g.rename -o", "rast=a8,a8bak");
 	    system(cmdbuf);
-	a8 = G_open_raster_new("a8", DCELL_TYPE);
+	a8 = Rast_open_raster_new("a8", DCELL_TYPE);
     if (choice->size[1]) {
@@ -609,42 +609,42 @@
 	    sprintf(cmdbuf, "%s %s", "g.rename -o", "rast=s1,s1bak");
 	    system(cmdbuf);
-	s1 = G_open_raster_new("s1", DCELL_TYPE);
+	s1 = Rast_open_raster_new("s1", DCELL_TYPE);
     if (choice->size[2]) {
 	if (G_find_cell("s2", G_mapset()) != NULL) {
 	    sprintf(cmdbuf, "%s %s", "g.rename -o", "rast=s2,s2bak");
 	    system(cmdbuf);
-	s2 = G_open_raster_new("s2", DCELL_TYPE);
+	s2 = Rast_open_raster_new("s2", DCELL_TYPE);
     if (choice->size[3]) {
 	if (G_find_cell("s3", G_mapset()) != NULL) {
 	    sprintf(cmdbuf, "%s %s", "g.rename -o", "rast=s3,s3bak");
 	    system(cmdbuf);
-	s3 = G_open_raster_new("s3", DCELL_TYPE);
+	s3 = Rast_open_raster_new("s3", DCELL_TYPE);
     if (choice->size[4]) {
 	if (G_find_cell("s4", G_mapset()) != NULL) {
 	    sprintf(cmdbuf, "%s %s", "g.rename -o", "rast=s4,s4bak");
 	    system(cmdbuf);
-	s4 = G_open_raster_new("s4", DCELL_TYPE);
+	s4 = Rast_open_raster_new("s4", DCELL_TYPE);
     if (choice->size[5]) {
 	if (G_find_cell("s5", G_mapset()) != NULL) {
 	    sprintf(cmdbuf, "%s %s", "g.rename -o", "rast=s5,s5bak");
 	    system(cmdbuf);
-	s5 = G_open_raster_new("s5", DCELL_TYPE);
+	s5 = Rast_open_raster_new("s5", DCELL_TYPE);
     if (choice->size[6]) {
 	if (G_find_cell("s6", G_mapset()) != NULL) {
 	    sprintf(cmdbuf, "%s %s", "g.rename -o", "rast=s6,s6bak");
 	    system(cmdbuf);
-	s6 = G_open_raster_new("s6", DCELL_TYPE);
+	s6 = Rast_open_raster_new("s6", DCELL_TYPE);
     if (choice->size[7]) {
@@ -652,7 +652,7 @@
 	    sprintf(cmdbuf, "%s %s", "g.rename -o", "rast=s7,s7bak");
 	    system(cmdbuf);
-	s7 = G_open_raster_new("s7", DCELL_TYPE);
+	s7 = Rast_open_raster_new("s7", DCELL_TYPE);
     if (choice->size[8]) {
@@ -660,7 +660,7 @@
 	    sprintf(cmdbuf, "%s %s", "g.rename -o", "rast=s8,s8bak");
 	    system(cmdbuf);
-	s8 = G_open_raster_new("s8", DCELL_TYPE);
+	s8 = Rast_open_raster_new("s8", DCELL_TYPE);
     if (choice->core[1]) {
@@ -668,70 +668,70 @@
 	    sprintf(cmdbuf, "%s %s", "g.rename -o", "rast=c1,c1bak");
 	    system(cmdbuf);
-	c1 = G_open_raster_new("c1", DCELL_TYPE);
+	c1 = Rast_open_raster_new("c1", DCELL_TYPE);
     if (choice->core[2]) {
 	if (G_find_cell("c2", G_mapset()) != NULL) {
 	    sprintf(cmdbuf, "%s %s", "g.rename -o", "rast=c2,c2bak");
 	    system(cmdbuf);
-	c2 = G_open_raster_new("c2", DCELL_TYPE);
+	c2 = Rast_open_raster_new("c2", DCELL_TYPE);
     if (choice->core[3]) {
 	if (G_find_cell("c3", G_mapset()) != NULL) {
 	    sprintf(cmdbuf, "%s %s", "g.rename -o", "rast=c3,c3bak");
 	    system(cmdbuf);
-	c3 = G_open_raster_new("c3", DCELL_TYPE);
+	c3 = Rast_open_raster_new("c3", DCELL_TYPE);
     if (choice->core[4]) {
 	if (G_find_cell("c4", G_mapset()) != NULL) {
 	    sprintf(cmdbuf, "%s %s", "g.rename -o", "rast=c4,c4bak");
 	    system(cmdbuf);
-	c4 = G_open_raster_new("c4", DCELL_TYPE);
+	c4 = Rast_open_raster_new("c4", DCELL_TYPE);
     if (choice->core[5]) {
 	if (G_find_cell("c5", G_mapset()) != NULL) {
 	    sprintf(cmdbuf, "%s %s", "g.rename -o", "rast=c5,c5bak");
 	    system(cmdbuf);
-	c5 = G_open_raster_new("c5", DCELL_TYPE);
+	c5 = Rast_open_raster_new("c5", DCELL_TYPE);
     if (choice->core[6]) {
 	if (G_find_cell("c6", G_mapset()) != NULL) {
 	    sprintf(cmdbuf, "%s %s", "g.rename -o", "rast=c6,c6bak");
 	    system(cmdbuf);
-	c6 = G_open_raster_new("c6", DCELL_TYPE);
+	c6 = Rast_open_raster_new("c6", DCELL_TYPE);
     if (choice->core[7]) {
 	if (G_find_cell("c7", G_mapset()) != NULL) {
 	    sprintf(cmdbuf, "%s %s", "g.rename -o", "rast=c7,c7bak");
 	    system(cmdbuf);
-	c7 = G_open_raster_new("c7", DCELL_TYPE);
+	c7 = Rast_open_raster_new("c7", DCELL_TYPE);
     if (choice->core[8]) {
 	if (G_find_cell("c8", G_mapset()) != NULL) {
 	    sprintf(cmdbuf, "%s %s", "g.rename -o", "rast=c8,c8bak");
 	    system(cmdbuf);
-	c8 = G_open_raster_new("c8", DCELL_TYPE);
+	c8 = Rast_open_raster_new("c8", DCELL_TYPE);
     if (choice->core[9]) {
 	if (G_find_cell("c9", G_mapset()) != NULL) {
 	    sprintf(cmdbuf, "%s %s", "g.rename -o", "rast=c9,c9bak");
 	    system(cmdbuf);
-	c9 = G_open_raster_new("c9", DCELL_TYPE);
+	c9 = Rast_open_raster_new("c9", DCELL_TYPE);
     if (choice->core[10]) {
 	if (G_find_cell("c10", G_mapset()) != NULL) {
 	    sprintf(cmdbuf, "%s %s", "g.rename -o", "rast=c10,c10bak");
 	    system(cmdbuf);
-	c10 = G_open_raster_new("c10", DCELL_TYPE);
+	c10 = Rast_open_raster_new("c10", DCELL_TYPE);
     if (choice->shape[1]) {
@@ -739,42 +739,42 @@
 	    sprintf(cmdbuf, "%s %s", "g.rename -o", "rast=h1,h1bak");
 	    system(cmdbuf);
-	h1 = G_open_raster_new("h1", DCELL_TYPE);
+	h1 = Rast_open_raster_new("h1", DCELL_TYPE);
     if (choice->shape[2]) {
 	if (G_find_cell("h2", G_mapset()) != NULL) {
 	    sprintf(cmdbuf, "%s %s", "g.rename -o", "rast=h2,h2bak");
 	    system(cmdbuf);
-	h2 = G_open_raster_new("h2", DCELL_TYPE);
+	h2 = Rast_open_raster_new("h2", DCELL_TYPE);
     if (choice->shape[3]) {
 	if (G_find_cell("h3", G_mapset()) != NULL) {
 	    sprintf(cmdbuf, "%s %s", "g.rename -o", "rast=h3,h3bak");
 	    system(cmdbuf);
-	h3 = G_open_raster_new("h3", DCELL_TYPE);
+	h3 = Rast_open_raster_new("h3", DCELL_TYPE);
     if (choice->shape[4]) {
 	if (G_find_cell("h4", G_mapset()) != NULL) {
 	    sprintf(cmdbuf, "%s %s", "g.rename -o", "rast=h4,h4bak");
 	    system(cmdbuf);
-	h4 = G_open_raster_new("h4", DCELL_TYPE);
+	h4 = Rast_open_raster_new("h4", DCELL_TYPE);
     if (choice->shape[5]) {
 	if (G_find_cell("h5", G_mapset()) != NULL) {
 	    sprintf(cmdbuf, "%s %s", "g.rename -o", "rast=h5,h5bak");
 	    system(cmdbuf);
-	h5 = G_open_raster_new("h5", DCELL_TYPE);
+	h5 = Rast_open_raster_new("h5", DCELL_TYPE);
     if (choice->shape[6]) {
 	if (G_find_cell("h6", G_mapset()) != NULL) {
 	    sprintf(cmdbuf, "%s %s", "g.rename -o", "rast=h6,h6bak");
 	    system(cmdbuf);
-	h6 = G_open_raster_new("h6", DCELL_TYPE);
+	h6 = Rast_open_raster_new("h6", DCELL_TYPE);
     if (choice->boundary[1]) {
@@ -782,7 +782,7 @@
 	    sprintf(cmdbuf, "%s %s", "g.rename -o", "rast=n1,n1bak");
 	    system(cmdbuf);
-	n1 = G_open_raster_new("n1", DCELL_TYPE);
+	n1 = Rast_open_raster_new("n1", DCELL_TYPE);
     if (choice->boundary[2]) {
@@ -790,7 +790,7 @@
 	    sprintf(cmdbuf, "%s %s", "g.rename -o", "rast=n2,n2bak");
 	    system(cmdbuf);
-	n2 = G_open_raster_new("n2", DCELL_TYPE);
+	n2 = Rast_open_raster_new("n2", DCELL_TYPE);
     if (choice->boundary[3]) {
@@ -798,7 +798,7 @@
 	    sprintf(cmdbuf, "%s %s", "g.rename -o", "rast=n3,n3bak");
 	    system(cmdbuf);
-	n3 = G_open_raster_new("n3", DCELL_TYPE);
+	n3 = Rast_open_raster_new("n3", DCELL_TYPE);
     if (choice->boundary[4]) {
@@ -806,7 +806,7 @@
 	    sprintf(cmdbuf, "%s %s", "g.rename -o", "rast=n4,n4bak");
 	    system(cmdbuf);
-	n4 = G_open_raster_new("n4", DCELL_TYPE);
+	n4 = Rast_open_raster_new("n4", DCELL_TYPE);
     if (choice->perim[1]) {
@@ -814,42 +814,42 @@
 	    sprintf(cmdbuf, "%s %s", "g.rename -o", "rast=p1,p1bak");
 	    system(cmdbuf);
-	p1 = G_open_raster_new("p1", DCELL_TYPE);
+	p1 = Rast_open_raster_new("p1", DCELL_TYPE);
     if (choice->perim[2]) {
 	if (G_find_cell("p2", G_mapset()) != NULL) {
 	    sprintf(cmdbuf, "%s %s", "g.rename -o", "rast=p2,p2bak");
 	    system(cmdbuf);
-	p2 = G_open_raster_new("p2", DCELL_TYPE);
+	p2 = Rast_open_raster_new("p2", DCELL_TYPE);
     if (choice->perim[3]) {
 	if (G_find_cell("p3", G_mapset()) != NULL) {
 	    sprintf(cmdbuf, "%s %s", "g.rename -o", "rast=p3,p3bak");
 	    system(cmdbuf);
-	p3 = G_open_raster_new("p3", DCELL_TYPE);
+	p3 = Rast_open_raster_new("p3", DCELL_TYPE);
     if (choice->perim[4]) {
 	if (G_find_cell("p4", G_mapset()) != NULL) {
 	    sprintf(cmdbuf, "%s %s", "g.rename -o", "rast=p4,p4bak");
 	    system(cmdbuf);
-	p4 = G_open_raster_new("p4", DCELL_TYPE);
+	p4 = Rast_open_raster_new("p4", DCELL_TYPE);
     if (choice->perim[5]) {
 	if (G_find_cell("p5", G_mapset()) != NULL) {
 	    sprintf(cmdbuf, "%s %s", "g.rename -o", "rast=p5,p5bak");
 	    system(cmdbuf);
-	p5 = G_open_raster_new("p5", DCELL_TYPE);
+	p5 = Rast_open_raster_new("p5", DCELL_TYPE);
     if (choice->perim[6]) {
 	if (G_find_cell("p6", G_mapset()) != NULL) {
 	    sprintf(cmdbuf, "%s %s", "g.rename -o", "rast=p6,p6bak");
 	    system(cmdbuf);
-	p6 = G_open_raster_new("p6", DCELL_TYPE);
+	p6 = Rast_open_raster_new("p6", DCELL_TYPE);
     /* get the moving window parameters */
@@ -915,7 +915,7 @@
     fprintf(stderr,
 	    "   warning may be printed or appear in a window; ignore this warning.\n");
     fprintf(stderr, "If a MASK is present there will be no warning.\n");
-    fmask = G_open_cell_old("MASK", G_mapset());
+    fmask = Rast_open_cell_old("MASK", G_mapset());
     /* allocate memory for the buffer that
@@ -933,7 +933,7 @@
        a row of the MASK, if there is a MASK */
     if (fmask > 0)
-	row_buf = G_allocate_raster_buf(CELL_TYPE);
+	row_buf = Rast_allocate_raster_buf(CELL_TYPE);
     /* main loop for clipping & measuring
        using the moving-window */
@@ -955,8 +955,8 @@
 	   process */
 	if (fmask > 0) {
-	    G_zero_raster_buf(row_buf, CELL_TYPE);
-	    G_get_raster_row_nomask(fmask, row_buf, y0 + i + u_l / 2,
+	    Rast_zero_raster_buf(row_buf, CELL_TYPE);
+	    Rast_get_raster_row_nomask(fmask, row_buf, y0 + i + u_l / 2,
 				    CELL_TYPE);
 	    /* for each cell whose value is "1"
@@ -1006,937 +1006,937 @@
 	   maps; the map location is adjusted to the center
 	   of the moving window */
-	tmp_buf = G_allocate_raster_buf(DCELL_TYPE);
-	nulltmp = G_allocate_null_buf();
+	tmp_buf = Rast_allocate_raster_buf(DCELL_TYPE);
+	nulltmp = Rast_allocate_null_buf();
 	if (choice->att[1]) {
-	    G_zero_raster_buf(tmp_buf, DCELL_TYPE);
-	    G_set_null_value(tmp_buf, x0 + nc + u_w, DCELL_TYPE);
+	    Rast_zero_raster_buf(tmp_buf, DCELL_TYPE);
+	    Rast_set_null_value(tmp_buf, x0 + nc + u_w, DCELL_TYPE);
 	    if (i == 0) {
 		for (b = 0; b < u_l / 2; b++)
-		    G_put_d_raster_row(a1, tmp_buf);
+		    Rast_put_d_raster_row(a1, tmp_buf);
 	    if (i < nr) {
 		for (m = 0; m < nc; m++) {
 		    if (*(*(buff + m) + 0) > -BIG)
 			*(tmp_buf + (x0 + m + u_w / 2)) = *(*(buff + m) + 0);
 	    if (i == nr - 1) {
-		tmp_buf2 = G_allocate_raster_buf(DCELL_TYPE);
-		G_set_null_value(tmp_buf2, x0 + nc + u_w, DCELL_TYPE);
+		tmp_buf2 = Rast_allocate_raster_buf(DCELL_TYPE);
+		Rast_set_null_value(tmp_buf2, x0 + nc + u_w, DCELL_TYPE);
-		    G_put_d_raster_row(a1, tmp_buf2);
+		    Rast_put_d_raster_row(a1, tmp_buf2);
 		G_free(tmp_buf2);
 	    if (i == 0) {
-		    G_put_d_raster_row(a2, tmp_buf);
+		    Rast_put_d_raster_row(a2, tmp_buf);
 	    if (i < nr) {
 		    if (*(*(buff + m) + 1) > -BIG)
 			*(tmp_buf + (x0 + m + u_w / 2)) = *(*(buff + m) + 1);
 	    if (i == nr - 1) {
-		    G_put_d_raster_row(a2, tmp_buf2);
+		    Rast_put_d_raster_row(a2, tmp_buf2);
 		G_free(tmp_buf2);
 	    if (i == 0) {
-		    G_put_d_raster_row(a3, tmp_buf);
+		    Rast_put_d_raster_row(a3, tmp_buf);
 	    if (i < nr) {
 		    if (*(*(buff + m) + 2) > -BIG)
 			*(tmp_buf + (x0 + m + u_w / 2)) = *(*(buff + m) + 2);
 	    if (i == nr - 1) {
-		    G_put_d_raster_row(a3, tmp_buf2);
+		    Rast_put_d_raster_row(a3, tmp_buf2);
 		G_free(tmp_buf2);
 	    if (i == 0) {
-		    G_put_d_raster_row(a4, tmp_buf);
+		    Rast_put_d_raster_row(a4, tmp_buf);
 	    if (i < nr) {
 		    if (*(*(buff + m) + 3) > -BIG)
 			*(tmp_buf + (x0 + m + u_w / 2)) = *(*(buff + m) + 3);
 	    if (i == nr - 1) {
-		    G_put_d_raster_row(a4, tmp_buf2);
+		    Rast_put_d_raster_row(a4, tmp_buf2);
 		G_free(tmp_buf2);
 	    if (i == 0) {
-		    G_put_d_raster_row(a5, tmp_buf);
+		    Rast_put_d_raster_row(a5, tmp_buf);
 	    if (i < nr) {
 		    if (*(*(buff + m) + 4) > -BIG)
 			*(tmp_buf + (x0 + m + u_w / 2)) = *(*(buff + m) + 4);
 	    if (i == nr - 1) {
-		    G_put_d_raster_row(a5, tmp_buf2);
+		    Rast_put_d_raster_row(a5, tmp_buf2);
 		G_free(tmp_buf2);
 	    if (i == 0) {
-		    G_put_d_raster_row(a6, tmp_buf);
+		    Rast_put_d_raster_row(a6, tmp_buf);
 	    if (i < nr) {
 		    if (*(*(buff + m) + 5) > -BIG)
 			*(tmp_buf + (x0 + m + u_w / 2)) = *(*(buff + m) + 5);
 	    if (i == nr - 1) {
-		    G_put_d_raster_row(a6, tmp_buf2);
+		    Rast_put_d_raster_row(a6, tmp_buf2);
 		G_free(tmp_buf2);
 	    if (i == 0) {
-		    G_put_d_raster_row(a7, tmp_buf);
+		    Rast_put_d_raster_row(a7, tmp_buf);
 	    if (i < nr) {
 		    if (*(*(buff + m) + 6) > -BIG)
 			*(tmp_buf + (x0 + m + u_w / 2)) = *(*(buff + m) + 6);
 	    if (i == nr - 1) {
-		    G_put_d_raster_row(a7, tmp_buf2);
+		    Rast_put_d_raster_row(a7, tmp_buf2);
 		G_free(tmp_buf2);
 	    if (i == 0) {
-		    G_put_d_raster_row(s1, tmp_buf);
+		    Rast_put_d_raster_row(s1, tmp_buf);
 	    if (i < nr) {
 		    if (*(*(buff + m) + 7) > -BIG)
 			*(tmp_buf + (x0 + m + u_w / 2)) = *(*(buff + m) + 7);
 	    if (i == nr - 1) {
-		    G_put_d_raster_row(s1, tmp_buf2);
+		    Rast_put_d_raster_row(s1, tmp_buf2);
 		G_free(tmp_buf2);
 	    if (i == 0) {
-		    G_put_d_raster_row(s2, tmp_buf);
+		    Rast_put_d_raster_row(s2, tmp_buf);
 	    if (i < nr) {
 		    if (*(*(buff + m) + 8) > -BIG)
 			*(tmp_buf + (x0 + m + u_w / 2)) = *(*(buff + m) + 8);
 	    if (i == nr - 1) {
-		    G_put_d_raster_row(s2, tmp_buf2);
+		    Rast_put_d_raster_row(s2, tmp_buf2);
 		G_free(tmp_buf2);
 	    if (i == 0) {
-		    G_put_d_raster_row(s3, tmp_buf);
+		    Rast_put_d_raster_row(s3, tmp_buf);
 	    if (i < nr) {
 		    if (*(*(buff + m) + 9) > -BIG)
 			*(tmp_buf + (x0 + m + u_w / 2)) = *(*(buff + m) + 9);
 	    if (i == nr - 1) {
-		    G_put_d_raster_row(s3, tmp_buf2);
+		    Rast_put_d_raster_row(s3, tmp_buf2);
 		G_free(tmp_buf2);
 	    if (i == 0) {
-		    G_put_d_raster_row(s4, tmp_buf);
+		    Rast_put_d_raster_row(s4, tmp_buf);
 	    if (i < nr) {
 		    if (*(*(buff + m) + 10) > -BIG)
 			*(tmp_buf + (x0 + m + u_w / 2)) = *(*(buff + m) + 10);
 	    if (i == nr - 1) {
-		    G_put_d_raster_row(s4, tmp_buf2);
+		    Rast_put_d_raster_row(s4, tmp_buf2);
 		G_free(tmp_buf2);
 	    if (i == 0) {
-		    G_put_d_raster_row(s5, tmp_buf);
+		    Rast_put_d_raster_row(s5, tmp_buf);
 	    if (i < nr) {
 		    if (*(*(buff + m) + 11) > -BIG)
 			*(tmp_buf + (x0 + m + u_w / 2)) = *(*(buff + m) + 11);
 	    if (i == nr - 1) {
-		    G_put_d_raster_row(s5, tmp_buf2);
+		    Rast_put_d_raster_row(s5, tmp_buf2);
 		G_free(tmp_buf2);
 	    if (i == 0) {
-		    G_put_d_raster_row(s6, tmp_buf);
+		    Rast_put_d_raster_row(s6, tmp_buf);
 	    if (i < nr) {
 		    if (*(*(buff + m) + 12) > -BIG)
 			*(tmp_buf + (x0 + m + u_w / 2)) = *(*(buff + m) + 12);
 	    if (i == nr - 1) {
-		    G_put_d_raster_row(s6, tmp_buf2);
+		    Rast_put_d_raster_row(s6, tmp_buf2);
 		G_free(tmp_buf2);
 	    if (i == 0) {
-		    G_put_d_raster_row(c1, tmp_buf);
+		    Rast_put_d_raster_row(c1, tmp_buf);
 	    if (i < nr) {
 		    if (*(*(buff + m) + 13) > -BIG)
 			*(tmp_buf + (x0 + m + u_w / 2)) = *(*(buff + m) + 13);
 	    if (i == nr - 1) {
-		    G_put_d_raster_row(c1, tmp_buf2);
+		    Rast_put_d_raster_row(c1, tmp_buf2);
 		G_free(tmp_buf2);
 	    if (i == 0) {
-		    G_put_d_raster_row(c2, tmp_buf);
+		    Rast_put_d_raster_row(c2, tmp_buf);
 	    if (i < nr) {
 		    if (*(*(buff + m) + 14) > -BIG)
 			*(tmp_buf + (x0 + m + u_w / 2)) = *(*(buff + m) + 14);
 	    if (i == nr - 1) {
-		    G_put_d_raster_row(c2, tmp_buf2);
+		    Rast_put_d_raster_row(c2, tmp_buf2);
 		G_free(tmp_buf2);
 	    if (i == 0) {
-		    G_put_d_raster_row(c3, tmp_buf);
+		    Rast_put_d_raster_row(c3, tmp_buf);
 	    if (i < nr) {
 		    if (*(*(buff + m) + 15) > -BIG)
 			*(tmp_buf + (x0 + m + u_w / 2)) = *(*(buff + m) + 15);
 	    if (i == nr - 1) {
-		    G_put_d_raster_row(c3, tmp_buf2);
+		    Rast_put_d_raster_row(c3, tmp_buf2);
 		G_free(tmp_buf2);
 	    if (i == 0) {
-		    G_put_d_raster_row(c4, tmp_buf);
+		    Rast_put_d_raster_row(c4, tmp_buf);
 	    if (i < nr) {
 		    if (*(*(buff + m) + 16) > -BIG)
 			*(tmp_buf + (x0 + m + u_w / 2)) = *(*(buff + m) + 16);
 	    if (i == nr - 1) {
-		    G_put_d_raster_row(c4, tmp_buf2);
+		    Rast_put_d_raster_row(c4, tmp_buf2);
 		G_free(tmp_buf2);
 	    if (i == 0) {
-		    G_put_d_raster_row(c5, tmp_buf);
+		    Rast_put_d_raster_row(c5, tmp_buf);
 	    if (i < nr) {
 		    if (*(*(buff + m) + 17) > -BIG)
 			*(tmp_buf + (x0 + m + u_w / 2)) = *(*(buff + m) + 17);
 	    if (i == nr - 1) {
-		    G_put_d_raster_row(c5, tmp_buf2);
+		    Rast_put_d_raster_row(c5, tmp_buf2);
 		G_free(tmp_buf2);
 	    if (i == 0) {
-		    G_put_d_raster_row(c6, tmp_buf);
+		    Rast_put_d_raster_row(c6, tmp_buf);
 	    if (i < nr) {
 		    if (*(*(buff + m) + 18) > -BIG)
 			*(tmp_buf + (x0 + m + u_w / 2)) = *(*(buff + m) + 18);
 	    if (i == nr - 1) {
-		    G_put_d_raster_row(c6, tmp_buf2);
+		    Rast_put_d_raster_row(c6, tmp_buf2);
 		G_free(tmp_buf2);
 	    if (i == 0) {
-		    G_put_d_raster_row(c7, tmp_buf);
+		    Rast_put_d_raster_row(c7, tmp_buf);
 	    if (i < nr) {
 		    if (*(*(buff + m) + 19) > -BIG)
 			*(tmp_buf + (x0 + m + u_w / 2)) = *(*(buff + m) + 19);
 	    if (i == nr - 1) {
-		    G_put_d_raster_row(c7, tmp_buf2);
+		    Rast_put_d_raster_row(c7, tmp_buf2);
 		G_free(tmp_buf2);
 	    if (i == 0) {
-		    G_put_d_raster_row(c8, tmp_buf);
+		    Rast_put_d_raster_row(c8, tmp_buf);
 	    if (i < nr) {
 		    if (*(*(buff + m) + 20) > -BIG)
 			*(tmp_buf + (x0 + m + u_w / 2)) = *(*(buff + m) + 20);
 	    if (i == nr - 1) {
-		    G_put_d_raster_row(c8, tmp_buf2);
+		    Rast_put_d_raster_row(c8, tmp_buf2);
 		G_free(tmp_buf2);
 	    if (i == 0) {
-		    G_put_d_raster_row(c9, tmp_buf);
+		    Rast_put_d_raster_row(c9, tmp_buf);
 	    if (i < nr) {
 		    if (*(*(buff + m) + 21) > -BIG)
 			*(tmp_buf + (x0 + m + u_w / 2)) = *(*(buff + m) + 21);
 	    if (i == nr - 1) {
-		    G_put_d_raster_row(c9, tmp_buf2);
+		    Rast_put_d_raster_row(c9, tmp_buf2);
 		G_free(tmp_buf2);
 	    if (i == 0) {
-		    G_put_d_raster_row(c10, tmp_buf);
+		    Rast_put_d_raster_row(c10, tmp_buf);
 	    if (i < nr) {
 		    if (*(*(buff + m) + 22) > -BIG)
 			*(tmp_buf + (x0 + m + u_w / 2)) = *(*(buff + m) + 22);
 	    if (i == nr - 1) {
-		    G_put_d_raster_row(c10, tmp_buf2);
+		    Rast_put_d_raster_row(c10, tmp_buf2);
 		G_free(tmp_buf2);
 	    if (i == 0) {
-		    G_put_d_raster_row(h1, tmp_buf);
+		    Rast_put_d_raster_row(h1, tmp_buf);
 	    if (i < nr) {
 		    if (*(*(buff + m) + 23) > -BIG)
 			*(tmp_buf + (x0 + m + u_w / 2)) = *(*(buff + m) + 23);
 	    if (i == nr - 1) {
-		    G_put_d_raster_row(h1, tmp_buf2);
+		    Rast_put_d_raster_row(h1, tmp_buf2);
 		G_free(tmp_buf2);
 	    if (i == 0) {
-		    G_put_d_raster_row(h2, tmp_buf);
+		    Rast_put_d_raster_row(h2, tmp_buf);
 	    if (i < nr) {
 		    if (*(*(buff + m) + 24) > -BIG)
 			*(tmp_buf + (x0 + m + u_w / 2)) = *(*(buff + m) + 24);
 	    if (i == nr - 1) {
-		    G_put_d_raster_row(h2, tmp_buf2);
+		    Rast_put_d_raster_row(h2, tmp_buf2);
 		G_free(tmp_buf2);
 	    if (i == 0) {
-		    G_put_d_raster_row(h3, tmp_buf);
+		    Rast_put_d_raster_row(h3, tmp_buf);
 	    if (i < nr) {
 		    if (*(*(buff + m) + 25) > -BIG)
 			*(tmp_buf + (x0 + m + u_w / 2)) = *(*(buff + m) + 25);
 	    if (i == nr - 1) {
-		    G_put_d_raster_row(h3, tmp_buf2);
+		    Rast_put_d_raster_row(h3, tmp_buf2);
 		G_free(tmp_buf2);
 	    if (i == 0) {
-		    G_put_d_raster_row(h4, tmp_buf);
+		    Rast_put_d_raster_row(h4, tmp_buf);
 	    if (i < nr) {
 		    if (*(*(buff + m) + 26) > -BIG)
 			*(tmp_buf + (x0 + m + u_w / 2)) = *(*(buff + m) + 26);
 	    if (i == nr - 1) {
-		    G_put_d_raster_row(h4, tmp_buf2);
+		    Rast_put_d_raster_row(h4, tmp_buf2);
 		G_free(tmp_buf2);
 	    if (i == 0) {
-		    G_put_d_raster_row(h5, tmp_buf);
+		    Rast_put_d_raster_row(h5, tmp_buf);
 	    if (i < nr) {
 		    if (*(*(buff + m) + 27) > -BIG)
 			*(tmp_buf + (x0 + m + u_w / 2)) = *(*(buff + m) + 27);
 	    if (i == nr - 1) {
-		    G_put_d_raster_row(h5, tmp_buf2);
+		    Rast_put_d_raster_row(h5, tmp_buf2);
 		G_free(tmp_buf2);
 	    if (i == 0) {
-		    G_put_d_raster_row(h6, tmp_buf);
+		    Rast_put_d_raster_row(h6, tmp_buf);
 	    if (i < nr) {
 		    if (*(*(buff + m) + 28) > -BIG)
 			*(tmp_buf + (x0 + m + u_w / 2)) = *(*(buff + m) + 28);
 	    if (i == nr - 1) {
-		    G_put_d_raster_row(h6, tmp_buf2);
+		    Rast_put_d_raster_row(h6, tmp_buf2);
 		G_free(tmp_buf2);
 	    if (i == 0) {
-		    G_put_d_raster_row(n1, tmp_buf);
+		    Rast_put_d_raster_row(n1, tmp_buf);
 	    if (i < nr) {
 		    if (*(*(buff + m) + 29) > -BIG)
 			*(tmp_buf + (x0 + m + u_w / 2)) = *(*(buff + m) + 29);
 	    if (i == nr - 1) {
-		    G_put_d_raster_row(n1, tmp_buf2);
+		    Rast_put_d_raster_row(n1, tmp_buf2);
 		G_free(tmp_buf2);
 	    if (i == 0) {
-		    G_put_d_raster_row(p1, tmp_buf);
+		    Rast_put_d_raster_row(p1, tmp_buf);
 	    if (i < nr) {
 		    if (*(*(buff + m) + 30) > -BIG)
 			*(tmp_buf + (x0 + m + u_w / 2)) = *(*(buff + m) + 30);
 	    if (i == nr - 1) {
-		    G_put_d_raster_row(p1, tmp_buf2);
+		    Rast_put_d_raster_row(p1, tmp_buf2);
 		G_free(tmp_buf2);
 	    if (i == 0) {
-		    G_put_d_raster_row(p2, tmp_buf);
+		    Rast_put_d_raster_row(p2, tmp_buf);
 	    if (i < nr) {
 		    if (*(*(buff + m) + 31) > -BIG)
 			*(tmp_buf + (x0 + m + u_w / 2)) = *(*(buff + m) + 31);
 	    if (i == nr - 1) {
-		    G_put_d_raster_row(p2, tmp_buf2);
+		    Rast_put_d_raster_row(p2, tmp_buf2);
 		G_free(tmp_buf2);
 	    if (i == 0) {
-		    G_put_d_raster_row(p3, tmp_buf);
+		    Rast_put_d_raster_row(p3, tmp_buf);
 	    if (i < nr) {
 		    if (*(*(buff + m) + 32) > -BIG)
 			*(tmp_buf + (x0 + m + u_w / 2)) = *(*(buff + m) + 32);
 	    if (i == nr - 1) {
-		    G_put_d_raster_row(p3, tmp_buf2);
+		    Rast_put_d_raster_row(p3, tmp_buf2);
 		G_free(tmp_buf2);
 	    if (i == 0) {
-		    G_put_d_raster_row(p4, tmp_buf);
+		    Rast_put_d_raster_row(p4, tmp_buf);
 	    if (i < nr) {
 		    if (*(*(buff + m) + 33) > -BIG)
 			*(tmp_buf + (x0 + m + u_w / 2)) = *(*(buff + m) + 33);
 	    if (i == nr - 1) {
-		    G_put_d_raster_row(p4, tmp_buf2);
+		    Rast_put_d_raster_row(p4, tmp_buf2);
 		G_free(tmp_buf2);
 	    if (i == 0) {
-		    G_put_d_raster_row(p5, tmp_buf);
+		    Rast_put_d_raster_row(p5, tmp_buf);
 	    if (i < nr) {
 		    if (*(*(buff + m) + 34) > -BIG)
 			*(tmp_buf + (x0 + m + u_w / 2)) = *(*(buff + m) + 34);
 	    if (i == nr - 1) {
-		    G_put_d_raster_row(p5, tmp_buf2);
+		    Rast_put_d_raster_row(p5, tmp_buf2);
 		G_free(tmp_buf2);
 	    if (i == 0) {
-		    G_put_d_raster_row(p6, tmp_buf);
+		    Rast_put_d_raster_row(p6, tmp_buf);
 	    if (i < nr) {
 		    if (*(*(buff + m) + 35) > -BIG)
 			*(tmp_buf + (x0 + m + u_w / 2)) = *(*(buff + m) + 35);
 	    if (i == nr - 1) {
-		    G_put_d_raster_row(p6, tmp_buf2);
+		    Rast_put_d_raster_row(p6, tmp_buf2);
 		G_free(tmp_buf2);
 	    if (i == 0) {
-		    G_put_d_raster_row(a8, tmp_buf);
+		    Rast_put_d_raster_row(a8, tmp_buf);
 	    if (i < nr) {
 		    if (*(*(buff + m) + 36) > -BIG)
 			*(tmp_buf + (x0 + m + u_w / 2)) = *(*(buff + m) + 36);
 	    if (i == nr - 1) {
-		    G_put_d_raster_row(a8, tmp_buf2);
+		    Rast_put_d_raster_row(a8, tmp_buf2);
 		G_free(tmp_buf2);
 	    if (i == 0) {
-		    G_put_d_raster_row(s7, tmp_buf);
+		    Rast_put_d_raster_row(s7, tmp_buf);
 	    if (i < nr) {
 		    if (*(*(buff + m) + 37) > -BIG)
 			*(tmp_buf + (x0 + m + u_w / 2)) = *(*(buff + m) + 37);
 	    if (i == nr - 1) {
-		    G_put_d_raster_row(s7, tmp_buf2);
+		    Rast_put_d_raster_row(s7, tmp_buf2);
 		G_free(tmp_buf2);
 	    if (i == 0) {
-		    G_put_d_raster_row(s8, tmp_buf);
+		    Rast_put_d_raster_row(s8, tmp_buf);
 	    if (i < nr) {
 		    if (*(*(buff + m) + 38) > -BIG)
 			*(tmp_buf + (x0 + m + u_w / 2)) = *(*(buff + m) + 38);
 	    if (i == nr - 1) {
-		    G_put_d_raster_row(s8, tmp_buf2);
+		    Rast_put_d_raster_row(s8, tmp_buf2);
 		G_free(tmp_buf2);
 	    if (i == 0) {
-		    G_put_d_raster_row(n2, tmp_buf);
+		    Rast_put_d_raster_row(n2, tmp_buf);
 	    if (i < nr) {
 		    if (*(*(buff + m) + 39) > -BIG)
 			*(tmp_buf + (x0 + m + u_w / 2)) = *(*(buff + m) + 39);
 	    if (i == nr - 1) {
-		    G_put_d_raster_row(n2, tmp_buf2);
+		    Rast_put_d_raster_row(n2, tmp_buf2);
 		G_free(tmp_buf2);
 	    if (i == 0) {
-		    G_put_d_raster_row(n3, tmp_buf);
+		    Rast_put_d_raster_row(n3, tmp_buf);
 	    if (i < nr) {
 		    if (*(*(buff + m) + 40) > -BIG)
 			*(tmp_buf + (x0 + m + u_w / 2)) = *(*(buff + m) + 40);
 	    if (i == nr - 1) {
-		    G_put_d_raster_row(n3, tmp_buf2);
+		    Rast_put_d_raster_row(n3, tmp_buf2);
 		G_free(tmp_buf2);
 	    if (i == 0) {
-		    G_put_d_raster_row(n4, tmp_buf);
+		    Rast_put_d_raster_row(n4, tmp_buf);
 	    if (i < nr) {
 		    if (*(*(buff + m) + 41) > -BIG)
 			*(tmp_buf + (x0 + m + u_w / 2)) = *(*(buff + m) + 41);
 	    if (i == nr - 1) {
-		    G_put_d_raster_row(n4, tmp_buf2);
+		    Rast_put_d_raster_row(n4, tmp_buf2);
 		G_free(tmp_buf2);
@@ -1964,259 +1964,259 @@
-	G_close_cell(a1);
+	Rast_close_cell(a1);
 	set_colors("a1");
 	sprintf(cmdbuf, "%s %s", "r.compress", "a1");
 	system(cmdbuf);
-	G_close_cell(a2);
+	Rast_close_cell(a2);
 	set_colors("a2");
 	sprintf(cmdbuf, "%s %s", "r.compress", "a2");
 	system(cmdbuf);
-	G_close_cell(a3);
+	Rast_close_cell(a3);
 	set_colors("a3");
 	sprintf(cmdbuf, "%s %s", "r.compress", "a3");
 	system(cmdbuf);
-	G_close_cell(a4);
+	Rast_close_cell(a4);
 	set_colors("a4");
 	sprintf(cmdbuf, "%s %s", "r.compress", "a4");
 	system(cmdbuf);
-	G_close_cell(a5);
+	Rast_close_cell(a5);
 	set_colors("a5");
 	sprintf(cmdbuf, "%s %s", "r.compress", "a5");
 	system(cmdbuf);
-	G_close_cell(a6);
+	Rast_close_cell(a6);
 	set_colors("a6");
 	sprintf(cmdbuf, "%s %s", "r.compress", "a6");
 	system(cmdbuf);
-	G_close_cell(a7);
+	Rast_close_cell(a7);
 	set_colors("a7");
 	sprintf(cmdbuf, "%s %s", "r.compress", "a7");
 	system(cmdbuf);
-	G_close_cell(a8);
+	Rast_close_cell(a8);
 	set_colors("a8");
 	sprintf(cmdbuf, "%s %s", "r.compress", "a8");
 	system(cmdbuf);
-	G_close_cell(s1);
+	Rast_close_cell(s1);
 	set_colors("s1");
 	sprintf(cmdbuf, "%s %s", "r.compress", "s1");
 	system(cmdbuf);
-	G_close_cell(s2);
+	Rast_close_cell(s2);
 	set_colors("s2");
 	sprintf(cmdbuf, "%s %s", "r.compress", "s2");
 	system(cmdbuf);
-	G_close_cell(s3);
+	Rast_close_cell(s3);
 	set_colors("s3");
 	sprintf(cmdbuf, "%s %s", "r.compress", "s3");
 	system(cmdbuf);
-	G_close_cell(s4);
+	Rast_close_cell(s4);
 	set_colors("s4");
 	sprintf(cmdbuf, "%s %s", "r.compress", "s4");
 	system(cmdbuf);
-	G_close_cell(s5);
+	Rast_close_cell(s5);
 	set_colors("s5");
 	sprintf(cmdbuf, "%s %s", "r.compress", "s5");
 	system(cmdbuf);
-	G_close_cell(s6);
+	Rast_close_cell(s6);
 	set_colors("s6");
 	sprintf(cmdbuf, "%s %s", "r.compress", "s6");
 	system(cmdbuf);
-	G_close_cell(s7);
+	Rast_close_cell(s7);
 	set_colors("s7");
 	sprintf(cmdbuf, "%s %s", "r.compress", "s7");
 	system(cmdbuf);
-	G_close_cell(s8);
+	Rast_close_cell(s8);
 	set_colors("s8");
 	sprintf(cmdbuf, "%s %s", "r.compress", "s8");
 	system(cmdbuf);
-	G_close_cell(c1);
+	Rast_close_cell(c1);
 	set_colors("c1");
 	sprintf(cmdbuf, "%s %s", "r.compress", "c1");
 	system(cmdbuf);
-	G_close_cell(c2);
+	Rast_close_cell(c2);
 	set_colors("c2");
 	sprintf(cmdbuf, "%s %s", "r.compress", "c2");
 	system(cmdbuf);
-	G_close_cell(c3);
+	Rast_close_cell(c3);
 	set_colors("c3");
 	sprintf(cmdbuf, "%s %s", "r.compress", "c3");
 	system(cmdbuf);
-	G_close_cell(c4);
+	Rast_close_cell(c4);
 	set_colors("c4");
 	sprintf(cmdbuf, "%s %s", "r.compress", "c4");
 	system(cmdbuf);
-	G_close_cell(c5);
+	Rast_close_cell(c5);
 	set_colors("c5");
 	sprintf(cmdbuf, "%s %s", "r.compress", "c5");
 	system(cmdbuf);
-	G_close_cell(c6);
+	Rast_close_cell(c6);
 	set_colors("c6");
 	sprintf(cmdbuf, "%s %s", "r.compress", "c6");
 	system(cmdbuf);
-	G_close_cell(c7);
+	Rast_close_cell(c7);
 	set_colors("c7");
 	sprintf(cmdbuf, "%s %s", "r.compress", "c7");
 	system(cmdbuf);
-	G_close_cell(c8);
+	Rast_close_cell(c8);
 	set_colors("c8");
 	sprintf(cmdbuf, "%s %s", "r.compress", "c8");
 	system(cmdbuf);
-	G_close_cell(c9);
+	Rast_close_cell(c9);
 	set_colors("c9");
 	sprintf(cmdbuf, "%s %s", "r.compress", "c9");
 	system(cmdbuf);
-	G_close_cell(c10);
+	Rast_close_cell(c10);
 	set_colors("c10");
 	sprintf(cmdbuf, "%s %s", "r.compress", "c10");
 	system(cmdbuf);
-	G_close_cell(h1);
+	Rast_close_cell(h1);
 	set_colors("h1");
 	sprintf(cmdbuf, "%s %s", "r.compress", "h1");
 	system(cmdbuf);
-	G_close_cell(h2);
+	Rast_close_cell(h2);
 	set_colors("h2");
 	sprintf(cmdbuf, "%s %s", "r.compress", "h2");
 	system(cmdbuf);
-	G_close_cell(h3);
+	Rast_close_cell(h3);
 	set_colors("h3");
 	sprintf(cmdbuf, "%s %s", "r.compress", "h3");
 	system(cmdbuf);
-	G_close_cell(h4);
+	Rast_close_cell(h4);
 	set_colors("h4");
 	sprintf(cmdbuf, "%s %s", "r.compress", "h4");
 	system(cmdbuf);
-	G_close_cell(h5);
+	Rast_close_cell(h5);
 	set_colors("h5");
 	sprintf(cmdbuf, "%s %s", "r.compress", "h5");
 	system(cmdbuf);
-	G_close_cell(h6);
+	Rast_close_cell(h6);
 	set_colors("h6");
 	sprintf(cmdbuf, "%s %s", "r.compress", "h6");
 	system(cmdbuf);
-	G_close_cell(n1);
+	Rast_close_cell(n1);
 	set_colors("n1");
 	sprintf(cmdbuf, "%s %s", "r.compress", "n1");
 	system(cmdbuf);
-	G_close_cell(n2);
+	Rast_close_cell(n2);
 	set_colors("n2");
 	sprintf(cmdbuf, "%s %s", "r.compress", "n2");
 	system(cmdbuf);
-	G_close_cell(n3);
+	Rast_close_cell(n3);
 	set_colors("n3");
 	sprintf(cmdbuf, "%s %s", "r.compress", "n3");
 	system(cmdbuf);
-	G_close_cell(n4);
+	Rast_close_cell(n4);
 	set_colors("n4");
 	sprintf(cmdbuf, "%s %s", "r.compress", "n4");
 	system(cmdbuf);
-	G_close_cell(p1);
+	Rast_close_cell(p1);
 	set_colors("p1");
 	sprintf(cmdbuf, "%s %s", "r.compress", "p1");
 	system(cmdbuf);
-	G_close_cell(p2);
+	Rast_close_cell(p2);
 	set_colors("p2");
 	sprintf(cmdbuf, "%s %s", "r.compress", "p2");
 	system(cmdbuf);
-	G_close_cell(p3);
+	Rast_close_cell(p3);
 	set_colors("p3");
 	sprintf(cmdbuf, "%s %s", "r.compress", "p3");
 	system(cmdbuf);
-	G_close_cell(p4);
+	Rast_close_cell(p4);
 	set_colors("p4");
 	sprintf(cmdbuf, "%s %s", "r.compress", "p4");
 	system(cmdbuf);
-	G_close_cell(p5);
+	Rast_close_cell(p5);
 	set_colors("p5");
 	sprintf(cmdbuf, "%s %s", "r.compress", "p5");
 	system(cmdbuf);
-	G_close_cell(p6);
+	Rast_close_cell(p6);
 	set_colors("p6");
 	sprintf(cmdbuf, "%s %s", "r.compress", "p6");
 	system(cmdbuf);
-    G_close_cell(fmask);
+    Rast_close_cell(fmask);
     return;
@@ -2234,9 +2234,9 @@
     struct Colors colors;
     struct FPRange fprange;
-    G_read_fp_range(name, G_mapset(), &fprange);
-    G_make_gyr_fp_colors(&colors, fprange.min, fprange.max);
-    G_write_colors(name, G_mapset(), &colors);
+    Rast_read_fp_range(name, G_mapset(), &fprange);
+    Rast_make_gyr_fp_colors(&colors, fprange.min, fprange.max);
+    Rast_write_colors(name, G_mapset(), &colors);
     return;
@@ -2702,18 +2702,18 @@
 	if (choice->units) {
 	    strcpy(unitname, "units_");
 	    strcat(unitname, istr);
-	    fd = G_open_raster_new(unitname, CELL_TYPE);
-	    unit_buf = G_allocate_raster_buf(CELL_TYPE);
+	    fd = Rast_open_raster_new(unitname, CELL_TYPE);
+	    unit_buf = Rast_allocate_raster_buf(CELL_TYPE);
 	    for (k = 1; k < wind.rows + 1; k++) {
-		G_zero_raster_buf(unit_buf, CELL_TYPE);
-		G_set_null_value(unit_buf, wind.cols + 1, CELL_TYPE);
+		Rast_zero_raster_buf(unit_buf, CELL_TYPE);
+		Rast_set_null_value(unit_buf, wind.cols + 1, CELL_TYPE);
 		for (m = 1; m < wind.cols + 1; m++) {
 		    if (*(*(units + k) + m))
 			*(unit_buf + m - 1) = *(*(units + k) + m);
-		G_put_raster_row(fd, unit_buf, CELL_TYPE);
+		Rast_put_raster_row(fd, unit_buf, CELL_TYPE);
-	    G_close_cell(fd);
+	    Rast_close_cell(fd);
 	    G_free(unit_buf);
@@ -2817,11 +2817,11 @@
     else {
 	regcnt = 0;
-	fr = G_open_cell_old(choice->reg, G_mapset());
+	fr = Rast_open_cell_old(choice->reg, G_mapset());
 	for (i = 0; i < nrows; i++) {
-	    G_get_raster_row(fr, row_buf, i, CELL_TYPE);
+	    Rast_get_raster_row(fr, row_buf, i, CELL_TYPE);
 	    for (j = 0; j < ncols; j++) {
 		if (*(row_buf + j) > 0) {
 		    if (regcnt == 0)
@@ -2872,7 +2872,7 @@
 			  0.0);
 	    ptrthis = ptrthis->next;
-	G_close_cell(fr);
+	Rast_close_cell(fr);
 	G_free(row_buf);
 	G_free(ptrnew);
Modified: grass/trunk/raster/r.le/r.le.patch/patch.h
--- grass/trunk/raster/r.le/r.le.patch/patch.h	2009-06-20 21:39:23 UTC (rev 38002)
+++ grass/trunk/raster/r.le/r.le.patch/patch.h	2009-06-20 22:03:23 UTC (rev 38003)
@@ -32,6 +32,7 @@
 #include <stdlib.h>
 #include <string.h>
 #include <grass/gis.h>
+#include <grass/Rast.h>
 #define  SML   0.5
 #define  MIN   2
Modified: grass/trunk/raster/r.le/r.le.patch/trace.c
--- grass/trunk/raster/r.le/r.le.patch/trace.c	2009-06-20 21:39:23 UTC (rev 38002)
+++ grass/trunk/raster/r.le/r.le.patch/trace.c	2009-06-20 22:03:23 UTC (rev 38003)
@@ -105,7 +105,7 @@
     name = choice->fn;
     mapset = G_mapset();
-    data_type = G_raster_map_type(name, mapset);
+    data_type = Rast_raster_map_type(name, mapset);
     /* dynamically allocate storage for the
        buffer that will hold the contents of
@@ -113,7 +113,7 @@
     buf = (DCELL **) G_calloc(nrows + 3, sizeof(DCELL *));
     for (i = 0; i < nrows + 3; i++) {
-	buf[i] = (DCELL *) G_allocate_raster_buf(DCELL_TYPE);
+	buf[i] = (DCELL *) Rast_allocate_raster_buf(DCELL_TYPE);
@@ -123,7 +123,7 @@
     null_buf = (DCELL **) G_calloc(nrows + 3, sizeof(DCELL *));
-	null_buf[i] = (DCELL *) G_allocate_raster_buf(DCELL_TYPE);
+	null_buf[i] = (DCELL *) Rast_allocate_raster_buf(DCELL_TYPE);
     /* if a map of patch cores was requested,
@@ -134,10 +134,10 @@
     if (choice->coremap) {
 	cor = (DCELL **) G_calloc(nrows + 3, sizeof(DCELL *));
-	    cor[i] = (DCELL *) G_allocate_raster_buf(DCELL_TYPE);
+	    cor[i] = (DCELL *) Rast_allocate_raster_buf(DCELL_TYPE);
-	    G_set_null_value(cor[i], ncols + 3, DCELL_TYPE);
+	    Rast_set_null_value(cor[i], ncols + 3, DCELL_TYPE);
@@ -148,7 +148,7 @@
     if (choice->patchmap) {
 	pat = (CELL **) G_calloc(nrows + 3, sizeof(CELL *));
-	    pat[i] = (CELL *) G_allocate_raster_buf(CELL_TYPE);
+	    pat[i] = (CELL *) Rast_allocate_raster_buf(CELL_TYPE);
     /* clip out the sampling area */
@@ -178,11 +178,11 @@
 	   categories, history, quant) into the
 	   corresponding data structures */
-	infd = G_open_cell_old(name, mapset);
-	colr_ok = G_read_colors(name, mapset, &colr) > 0;
-	cats_ok = G_read_raster_cats(name, mapset, &cats) >= 0;
-	hist_ok = G_read_history(name, mapset, &hist) >= 0;
-	range_ok = G_read_range(name, mapset, &range) >= 0;
+	infd = Rast_open_cell_old(name, mapset);
+	colr_ok = Rast_read_colors(name, mapset, &colr) > 0;
+	cats_ok = Rast_read_raster_cats(name, mapset, &cats) >= 0;
+	hist_ok = Rast_read_history(name, mapset, &hist) >= 0;
+	range_ok = Rast_read_range(name, mapset, &range) >= 0;
 	/* 2. if map is floating point, then read
 	   the rules for quantization into the quant
@@ -190,17 +190,17 @@
 	   them by rounding floating point values */
 	if (data_type != CELL_TYPE) {
-	    G_quant_init(&quant);
-	    if (G_read_quant(name, mapset, &quant) <= 0)
-		G_quant_round(&quant);
+	    Rast_quant_init(&quant);
+	    if (Rast_read_quant(name, mapset, &quant) <= 0)
+		Rast_quant_round(&quant);
 	/* 3. initialize appropriate data structures */
 	if (cats_ok)
-	    G_init_raster_cats(G_get_raster_cats_title(&cats), &newcats);
+	    Rast_init_raster_cats(Rast_get_raster_cats_title(&cats), &newcats);
-	    G_init_cell_stats(&stats);
+	    Rast_init_cell_stats(&stats);
 	/* 4. open an output map called "interior" and
@@ -209,41 +209,41 @@
 	switch (data_type) {
 	case CELL_TYPE:
-	    cor_cell_buf = G_allocate_raster_buf(CELL_TYPE);
-	    fe = G_open_raster_new("interior", CELL_TYPE);
+	    cor_cell_buf = Rast_allocate_raster_buf(CELL_TYPE);
+	    fe = Rast_open_raster_new("interior", CELL_TYPE);
 	    for (i = 1; i < nrows + 1; i++) {
-		G_zero_raster_buf(cor_cell_buf, CELL_TYPE);
+		Rast_zero_raster_buf(cor_cell_buf, CELL_TYPE);
 		for (j = 1; j < ncols + 1; j++)
 		    *(cor_cell_buf + j - 1) = (int)(*(*(cor + i) + j));
-		if (G_put_raster_row(fe, cor_cell_buf, CELL_TYPE) < 0)
+		if (Rast_put_raster_row(fe, cor_cell_buf, CELL_TYPE) < 0)
 		    exit(EXIT_FAILURE);
-		G_update_cell_stats(cor_cell_buf, ncols + 1, &stats);
+		Rast_update_cell_stats(cor_cell_buf, ncols + 1, &stats);
 	    break;
 	case FCELL_TYPE:
-	    cor_fcell_buf = G_allocate_raster_buf(FCELL_TYPE);
-	    fe = G_open_raster_new("interior", FCELL_TYPE);
+	    cor_fcell_buf = Rast_allocate_raster_buf(FCELL_TYPE);
+	    fe = Rast_open_raster_new("interior", FCELL_TYPE);
-		G_zero_raster_buf(cor_fcell_buf, FCELL_TYPE);
+		Rast_zero_raster_buf(cor_fcell_buf, FCELL_TYPE);
 		for (j = 1; j < ncols + 1; j++) {
 		    *(cor_fcell_buf + j - 1) = (float)(*(*(cor + i) + j));
-		if (G_put_raster_row(fe, cor_fcell_buf, FCELL_TYPE) < 0)
+		if (Rast_put_raster_row(fe, cor_fcell_buf, FCELL_TYPE) < 0)
 		    exit(EXIT_FAILURE);
 	    break;
 	case DCELL_TYPE:
-	    cor_dcell_buf = G_allocate_raster_buf(DCELL_TYPE);
-	    fe = G_open_raster_new("interior", DCELL_TYPE);
+	    cor_dcell_buf = Rast_allocate_raster_buf(DCELL_TYPE);
+	    fe = Rast_open_raster_new("interior", DCELL_TYPE);
-		G_zero_raster_buf(cor_dcell_buf, DCELL_TYPE);
+		Rast_zero_raster_buf(cor_dcell_buf, DCELL_TYPE);
 		    *(cor_dcell_buf + j - 1) = (double)(*(*(cor + i) + j));
-		if (G_put_raster_row(fe, cor_dcell_buf, DCELL_TYPE) < 0)
+		if (Rast_put_raster_row(fe, cor_dcell_buf, DCELL_TYPE) < 0)
 		    exit(EXIT_FAILURE);
 	    break;
@@ -255,14 +255,14 @@
        complete the details of map creation */
-	fd = G_open_raster_new("num", CELL_TYPE);
+	fd = Rast_open_raster_new("num", CELL_TYPE);
-	    pat_buf = G_allocate_raster_buf(CELL_TYPE);
-	    G_zero_raster_buf(pat_buf, CELL_TYPE);
+	    pat_buf = Rast_allocate_raster_buf(CELL_TYPE);
+	    Rast_zero_raster_buf(pat_buf, CELL_TYPE);
 		*(pat_buf + j - 1) = *(*(pat + i) + j);
-	    if (G_put_raster_row(fd, pat_buf, CELL_TYPE) < 0)
+	    if (Rast_put_raster_row(fd, pat_buf, CELL_TYPE) < 0)
 		exit(EXIT_FAILURE);
@@ -356,7 +356,7 @@
        memory allocated for it */
-	G_close_cell(fd);
 	G_free(pat_buf);
@@ -367,67 +367,67 @@
        memory allocated for the cor_buf */
-	G_close_cell(fe);
-	G_rewind_cell_stats(&stats);
-	G_rewind_raster_cats(&cats);
+	Rast_close_cell(fe);
+	Rast_rewind_cell_stats(&stats);
+	Rast_rewind_raster_cats(&cats);
 	if (cats_ok && data_type == CELL_TYPE) {
 	    long count;
 	    void *rast1, *rast2;
 	    rast1 = cor_cell_buf;
-	    rast2 = G_incr_void_ptr(rast1, G_raster_size(CELL_TYPE));
-	    while (G_next_cell_stat(rast1, &count, &stats))
-		G_set_raster_cat(rast1, rast2, G_get_raster_cat(rast1, &cats,
+	    rast2 = Rast_incr_void_ptr(rast1, Rast_raster_size(CELL_TYPE));
+	    while (Rast_next_cell_stat(rast1, &count, &stats))
+		Rast_set_raster_cat(rast1, rast2, Rast_get_raster_cat(rast1, &cats,
 								CELL_TYPE),
 				 &newcats, CELL_TYPE);
-	    G_write_raster_cats("interior", &newcats);
-	    G_free_raster_cats(&cats);
-	    G_free_raster_cats(&newcats);
-	    G_free_cell_stats(&stats);
+	    Rast_write_raster_cats("interior", &newcats);
+	    Rast_free_raster_cats(&cats);
+	    Rast_free_raster_cats(&newcats);
+	    Rast_free_cell_stats(&stats);
 	if (colr_ok) {
 		CELL min, max, cmin, cmax;
-		G_read_range("interior", mapset, &range);
-		G_get_range_min_max(&range, &min, &max);
-		G_get_color_range(&cmin, &cmax, &colr);
+		Rast_read_range("interior", mapset, &range);
+		Rast_get_range_min_max(&range, &min, &max);
+		Rast_get_color_range(&cmin, &cmax, &colr);
 		if (min > cmin)
 		    cmin = min;
 		if (max < cmax)
 		    cmax = max;
-		G_set_color_range(cmin, cmax, &colr);
+		Rast_set_color_range(cmin, cmax, &colr);
 	    else {
 		DCELL dmin, dmax;
 		CELL cmin, cmax;
-		G_read_fp_range("interior", mapset, &fprange);
-		G_get_fp_range_min_max(&fprange, &dmin, &dmax);
+		Rast_read_fp_range("interior", mapset, &fprange);
+		Rast_get_fp_range_min_max(&fprange, &dmin, &dmax);
 		if (dmin > cmin)
 		    cmin = dmin;
 		if (dmax < cmax)
 		    cmax = dmax;
-	    G_write_colors("interior", mapset, &colr);
+	    Rast_write_colors("interior", mapset, &colr);
 	if (range_ok) {
-		G_write_range("interior", &range);
+		Rast_write_range("interior", &range);
 	    else
-		G_write_fp_range("interior", &fprange);
+		Rast_write_fp_range("interior", &fprange);
 	if (hist_ok)
-	    G_write_history("interior", &hist);
+	    Rast_write_history("interior", &hist);
-	G_free_cats(&cats);
-	G_free_colors(&colr);
+	Rast_free_cats(&cats);
+	Rast_free_colors(&colr);
 	case CELL_TYPE:
 	    G_free(cor_cell_buf);
@@ -510,7 +510,7 @@
        an integer (CELL_TYPE) map */
     if (choice->wrum == 'r') {
-	if (0 > (fr = G_open_cell_old(choice->reg, G_mapset()))) {
+	if (0 > (fr = Rast_open_cell_old(choice->reg, G_mapset()))) {
 	    fprintf(stderr,
 		    "   *******************************************************\n");
@@ -524,7 +524,7 @@
 	    exit(EXIT_FAILURE);
-	if (G_raster_map_type(choice->reg, G_mapset()) > 0) {
+	if (Rast_raster_map_type(choice->reg, G_mapset()) > 0) {
 	    fprintf(stderr,
@@ -540,12 +540,12 @@
 	    exit(EXIT_FAILURE);
-	tmp1 = G_allocate_raster_buf(CELL_TYPE);
-	G_zero_raster_buf(tmp1, CELL_TYPE);
+	tmp1 = Rast_allocate_raster_buf(CELL_TYPE);
+	Rast_zero_raster_buf(tmp1, CELL_TYPE);
 	fprintf(stderr, "Analyzing region number %d...\n", index);
     /* allocate memory to store a row of the
@@ -555,15 +555,15 @@
     case CELL_TYPE:
-	tmp = G_allocate_raster_buf(CELL_TYPE);
+	tmp = Rast_allocate_raster_buf(CELL_TYPE);
 	tmpname = "tmp";
 	break;
     case FCELL_TYPE:
-	ftmp = G_allocate_raster_buf(FCELL_TYPE);
+	ftmp = Rast_allocate_raster_buf(FCELL_TYPE);
 	tmpname = "ftmp";
 	break;
     case DCELL_TYPE:
-	dtmp = G_allocate_raster_buf(DCELL_TYPE);
+	dtmp = Rast_allocate_raster_buf(DCELL_TYPE);
 	tmpname = "dtmp";
 	break;
@@ -596,7 +596,7 @@
 	   map row in the region file */
-	    G_get_raster_row_nomask(fr, tmp1, i, CELL_TYPE);
+	    Rast_get_raster_row_nomask(fr, tmp1, i, CELL_TYPE);
 	/* initialize each element of the
 	   row buffer to 0; this row buffer
@@ -606,16 +606,16 @@
 	case CELL_TYPE:
-	    G_zero_raster_buf(tmp, data_type);
-	    G_get_raster_row(finput, tmp, i, data_type);
+	    Rast_zero_raster_buf(tmp, data_type);
+	    Rast_get_raster_row(finput, tmp, i, data_type);
 	    break;
 	case FCELL_TYPE:
-	    G_zero_raster_buf(ftmp, data_type);
-	    G_get_raster_row(finput, ftmp, i, data_type);
+	    Rast_zero_raster_buf(ftmp, data_type);
+	    Rast_get_raster_row(finput, ftmp, i, data_type);
 	    break;
 	case DCELL_TYPE:
-	    G_zero_raster_buf(dtmp, data_type);
-	    G_get_raster_row(finput, dtmp, i, data_type);
+	    Rast_zero_raster_buf(dtmp, data_type);
+	    Rast_get_raster_row(finput, dtmp, i, data_type);
 	    break;
@@ -629,17 +629,17 @@
 	case CELL_TYPE:
 	    rastptr = tmp;
 	    for (x = 0; x < col0; x++)
-		rastptr = G_incr_void_ptr(rastptr, G_raster_size(CELL_TYPE));
+		rastptr = Rast_incr_void_ptr(rastptr, Rast_raster_size(CELL_TYPE));
 	    break;
 	case FCELL_TYPE:
 	    rastptr = ftmp;
-		rastptr = G_incr_void_ptr(rastptr, G_raster_size(FCELL_TYPE));
+		rastptr = Rast_incr_void_ptr(rastptr, Rast_raster_size(FCELL_TYPE));
 	    break;
 	case DCELL_TYPE:
 	    rastptr = dtmp;
-		rastptr = G_incr_void_ptr(rastptr, G_raster_size(DCELL_TYPE));
+		rastptr = Rast_incr_void_ptr(rastptr, Rast_raster_size(DCELL_TYPE));
 	    break;
@@ -655,7 +655,7 @@
 	    case CELL_TYPE:
-		if (G_is_null_value(rastptr, CELL_TYPE)) {
+		if (Rast_is_null_value(rastptr, CELL_TYPE)) {
 		    *(*(null_buf + i + 1 - row0) + j + 1 - col0) = 1.0;
 		    if (i == row0 + nrows / 2 && j == col0 + ncols / 2)
 			*centernull = 1;
@@ -667,11 +667,11 @@
 		    else
 		break;
 	    case FCELL_TYPE:
-		if (G_is_null_value(rastptr, FCELL_TYPE)) {
+		if (Rast_is_null_value(rastptr, FCELL_TYPE)) {
 			*centernull = 1;
@@ -683,11 +683,11 @@
 		    else
 		break;
 	    case DCELL_TYPE:
-		if (G_is_null_value(rastptr, DCELL_TYPE)) {
+		if (Rast_is_null_value(rastptr, DCELL_TYPE)) {
 			*centernull = 1;
@@ -699,7 +699,7 @@
 		    else
 		break;
@@ -773,7 +773,7 @@
 	G_free(tmp1);
-	G_close_cell(fr);
     return;
@@ -996,7 +996,7 @@
     patchmap = (CELL **) G_calloc(nrows + 3, sizeof(CELL *));
     for (m = 0; m < nrows + 3; m++)
-	patchmap[m] = (CELL *) G_allocate_raster_buf(CELL_TYPE);
+	patchmap[m] = (CELL *) Rast_allocate_raster_buf(CELL_TYPE);
     /* print on the screen a message indicating
        that tracing has reached a certain patch */
Modified: grass/trunk/raster/r.le/r.le.pixel/cellclip.c
--- grass/trunk/raster/r.le/r.le.pixel/cellclip.c	2009-06-20 21:39:23 UTC (rev 38002)
+++ grass/trunk/raster/r.le/r.le.pixel/cellclip.c	2009-06-20 22:03:23 UTC (rev 38003)
@@ -58,7 +58,7 @@
     name = choice->fn;
@@ -253,14 +253,14 @@
        i, j       = indices to rows and cols of the arrays
     /* if sampling by region was chosen, check
        for the region map and make sure it is
 	    fprintf(stderr,
@@ -274,7 +274,7 @@
 	    exit(1);
 	    fprintf(stderr,
@@ -290,8 +290,8 @@
 	    exit(1);
@@ -302,15 +302,15 @@
     case CELL_TYPE:
 	tmpname = "tmp";
 	break;
     case FCELL_TYPE:
 	tmpname = "ftmp";
 	break;
     case DCELL_TYPE:
 	tmpname = "dtmp";
 	break;
@@ -319,7 +319,7 @@
        null values corresponding to the raster
        map */
     /* if circles are used for sampling, then
        calculate the center of the area to be
@@ -338,7 +338,7 @@
@@ -349,20 +349,20 @@
 	case CELL_TYPE:
-	    G_get_raster_row(finput, tmp, i, CELL_TYPE);
+	    Rast_get_raster_row(finput, tmp, i, CELL_TYPE);
 	    break;
 	case FCELL_TYPE:
-	    G_get_raster_row(finput, ftmp, i, FCELL_TYPE);
+	    Rast_get_raster_row(finput, ftmp, i, FCELL_TYPE);
 	    break;
 	case DCELL_TYPE:
-	    G_get_raster_row(finput, dtmp, i, DCELL_TYPE);
+	    Rast_get_raster_row(finput, dtmp, i, DCELL_TYPE);
 	    break;
-	G_get_null_value_row(finput, nulltmp, i);
+	Rast_get_null_value_row(finput, nulltmp, i);
 	/* for all the columns one by one */
@@ -436,7 +436,7 @@
 	G_free(tmp1);
-	G_close_cell(fr);
     G_free(nulltmp);
     return;
Modified: grass/trunk/raster/r.le/r.le.pixel/driver.c
--- grass/trunk/raster/r.le/r.le.pixel/driver.c	2009-06-20 21:39:23 UTC (rev 38002)
+++ grass/trunk/raster/r.le/r.le.pixel/driver.c	2009-06-20 22:03:23 UTC (rev 38003)
@@ -51,7 +51,7 @@
     /* check for input raster map */
 	fprintf(stdout, "\n");
 	fprintf(stdout,
 		"   ********************************************************\n");
@@ -69,7 +69,7 @@
     else
        and start the moving window driver */
@@ -138,7 +138,7 @@
 	    unit_driver();
     fputs("R.LE.PIXEL IS DONE;  ", stderr);
@@ -198,28 +198,28 @@
 	    sprintf(cmdbuf, "%s %s", "g.rename -o", "rast=b1,b1bak");
 	    system(cmdbuf);
-	b1 = G_open_raster_new("b1", DCELL_TYPE);
+	b1 = Rast_open_raster_new("b1", DCELL_TYPE);
 	if (G_find_cell("b2", G_mapset()) != NULL) {
 	    sprintf(cmdbuf, "%s %s", "g.rename -o", "rast=b2,b2bak");
 	    system(cmdbuf);
-	b2 = G_open_raster_new("b2", DCELL_TYPE);
+	b2 = Rast_open_raster_new("b2", DCELL_TYPE);
 	if (G_find_cell("b3", G_mapset()) != NULL) {
 	    sprintf(cmdbuf, "%s %s", "g.rename -o", "rast=b3,b3bak");
 	    system(cmdbuf);
-	b3 = G_open_raster_new("b3", DCELL_TYPE);
+	b3 = Rast_open_raster_new("b3", DCELL_TYPE);
 	if (G_find_cell("b4", G_mapset()) != NULL) {
 	    sprintf(cmdbuf, "%s %s", "g.rename -o", "rast=b4,b4bak");
 	    system(cmdbuf);
-	b4 = G_open_raster_new("b4", DCELL_TYPE);
+	b4 = Rast_open_raster_new("b4", DCELL_TYPE);
     if (choice->div[1]) {
@@ -227,28 +227,28 @@
 	    sprintf(cmdbuf, "%s %s", "g.rename -o", "rast=d1,d1bak");
 	    system(cmdbuf);
-	d1 = G_open_raster_new("d1", DCELL_TYPE);
+	d1 = Rast_open_raster_new("d1", DCELL_TYPE);
     if (choice->div[2]) {
 	if (G_find_cell("d2", G_mapset()) != NULL) {
 	    sprintf(cmdbuf, "%s %s", "g.rename -o", "rast=d2,d2bak");
 	    system(cmdbuf);
-	d2 = G_open_raster_new("d2", DCELL_TYPE);
+	d2 = Rast_open_raster_new("d2", DCELL_TYPE);
     if (choice->div[3]) {
 	if (G_find_cell("d3", G_mapset()) != NULL) {
 	    sprintf(cmdbuf, "%s %s", "g.rename -o", "rast=d3,d3bak");
 	    system(cmdbuf);
-	d3 = G_open_raster_new("d3", DCELL_TYPE);
+	d3 = Rast_open_raster_new("d3", DCELL_TYPE);
     if (choice->div[4]) {
 	if (G_find_cell("d4", G_mapset()) != NULL) {
 	    sprintf(cmdbuf, "%s %s", "g.rename -o", "rast=d4,d4bak");
 	    system(cmdbuf);
-	d4 = G_open_raster_new("d4", DCELL_TYPE);
+	d4 = Rast_open_raster_new("d4", DCELL_TYPE);
     if (choice->te2[1]) {
@@ -256,35 +256,35 @@
 	    sprintf(cmdbuf, "%s %s", "g.rename -o", "rast=t1,t1bak");
 	    system(cmdbuf);
-	t1 = G_open_raster_new("t1", DCELL_TYPE);
+	t1 = Rast_open_raster_new("t1", DCELL_TYPE);
     if (choice->te2[2]) {
 	if (G_find_cell("t2", G_mapset()) != NULL) {
 	    sprintf(cmdbuf, "%s %s", "g.rename -o", "rast=t2,t2bak");
 	    system(cmdbuf);
-	t2 = G_open_raster_new("t2", DCELL_TYPE);
+	t2 = Rast_open_raster_new("t2", DCELL_TYPE);
     if (choice->te2[3]) {
 	if (G_find_cell("t3", G_mapset()) != NULL) {
 	    sprintf(cmdbuf, "%s %s", "g.rename -o", "rast=t3,t3bak");
 	    system(cmdbuf);
-	t3 = G_open_raster_new("t3", DCELL_TYPE);
+	t3 = Rast_open_raster_new("t3", DCELL_TYPE);
     if (choice->te2[4]) {
 	if (G_find_cell("t4", G_mapset()) != NULL) {
 	    sprintf(cmdbuf, "%s %s", "g.rename -o", "rast=t4,t4bak");
 	    system(cmdbuf);
-	t4 = G_open_raster_new("t4", DCELL_TYPE);
+	t4 = Rast_open_raster_new("t4", DCELL_TYPE);
     if (choice->te2[5]) {
 	if (G_find_cell("t5", G_mapset()) != NULL) {
 	    sprintf(cmdbuf, "%s %s", "g.rename -o", "rast=t5,t5bak");
 	    system(cmdbuf);
-	t5 = G_open_raster_new("t5", DCELL_TYPE);
+	t5 = Rast_open_raster_new("t5", DCELL_TYPE);
     if (choice->jux[1]) {
@@ -292,28 +292,28 @@
 	    sprintf(cmdbuf, "%s %s", "g.rename -o", "rast=j1,j1bak");
 	    system(cmdbuf);
-	j1 = G_open_raster_new("j1", DCELL_TYPE);
+	j1 = Rast_open_raster_new("j1", DCELL_TYPE);
     if (choice->jux[2]) {
 	if (G_find_cell("j2", G_mapset()) != NULL) {
 	    sprintf(cmdbuf, "%s %s", "g.rename -o", "rast=j2,j2bak");
 	    system(cmdbuf);
-	j2 = G_open_raster_new("j2", DCELL_TYPE);
+	j2 = Rast_open_raster_new("j2", DCELL_TYPE);
     if (choice->edg[1]) {
 	if (G_find_cell("e1", G_mapset()) != NULL) {
 	    sprintf(cmdbuf, "%s %s", "g.rename -o", "rast=e1,e1bak");
 	    system(cmdbuf);
-	e1 = G_open_raster_new("e1", DCELL_TYPE);
+	e1 = Rast_open_raster_new("e1", DCELL_TYPE);
     if (choice->edg[2]) {
 	if (G_find_cell("e2", G_mapset()) != NULL) {
 	    sprintf(cmdbuf, "%s %s", "g.rename -o", "rast=e2,e2bak");
 	    system(cmdbuf);
-	e2 = G_open_raster_new("e2", DCELL_TYPE);
+	e2 = Rast_open_raster_new("e2", DCELL_TYPE);
@@ -383,7 +383,7 @@
     fprintf(stdout,
     fprintf(stdout, "If a MASK is present there will be no warning.\n");
     /* allocate memory for the buffer */
@@ -400,7 +400,7 @@
        there is a mask */
     if (fmask > 0)
     if (choice->edg[2] || choice->jux[0]) {
@@ -423,17 +423,17 @@
 	case CELL_TYPE:
 	    break;
 	case FCELL_TYPE:
 	    break;
 	case DCELL_TYPE:
 	    break;
-	nul_buf = G_allocate_null_buf();
+	nul_buf = Rast_allocate_null_buf();
 	/* go through the search area
 	   pixel by pixel */
@@ -442,20 +442,20 @@
 	    case (CELL_TYPE):
-		G_zero_raster_buf(tmp, CELL_TYPE);
+		Rast_zero_raster_buf(tmp, CELL_TYPE);
 		break;
 	    case (FCELL_TYPE):
-		G_zero_raster_buf(ftmp, FCELL_TYPE);
+		Rast_zero_raster_buf(ftmp, FCELL_TYPE);
 		break;
 	    case (DCELL_TYPE):
-		G_zero_raster_buf(dtmp, DCELL_TYPE);
+		Rast_zero_raster_buf(dtmp, DCELL_TYPE);
 		break;
-	    G_get_null_value_row(finput, nul_buf, i);
+	    Rast_get_null_value_row(finput, nul_buf, i);
 	    for (j = 0; j < nc; j++) {
@@ -524,8 +524,8 @@
 	   process */
 	if (fmask > 0) {
 				    CELL_TYPE);
@@ -578,380 +578,380 @@
 	    if (i == 0) {
-		    G_put_d_raster_row(b1, tmp_buf);
+		    Rast_put_d_raster_row(b1, tmp_buf);
 	    if (i < nr) {
 	    if (i == nr - 1) {
-		    G_put_d_raster_row(b1, tmp_buf2);
+		    Rast_put_d_raster_row(b1, tmp_buf2);
 		G_free(tmp_buf2);
 	    if (i == 0) {
-		    G_put_d_raster_row(b2, tmp_buf);
+		    Rast_put_d_raster_row(b2, tmp_buf);
 	    if (i < nr) {
 	    if (i == nr - 1) {
-		    G_put_d_raster_row(b2, tmp_buf2);
+		    Rast_put_d_raster_row(b2, tmp_buf2);
 		G_free(tmp_buf2);
 	    if (i == 0) {
-		    G_put_d_raster_row(b3, tmp_buf);
+		    Rast_put_d_raster_row(b3, tmp_buf);
 	    if (i < nr) {
 	    if (i == nr - 1) {
-		    G_put_d_raster_row(b3, tmp_buf2);
+		    Rast_put_d_raster_row(b3, tmp_buf2);
 		G_free(tmp_buf2);
 	    if (i == 0) {
-		    G_put_d_raster_row(b4, tmp_buf);
+		    Rast_put_d_raster_row(b4, tmp_buf);
 	    if (i < nr) {
 	    if (i == nr - 1) {
-		    G_put_d_raster_row(b4, tmp_buf2);
+		    Rast_put_d_raster_row(b4, tmp_buf2);
 		G_free(tmp_buf2);
 	    if (i == 0) {
-		    G_put_d_raster_row(d1, tmp_buf);
+		    Rast_put_d_raster_row(d1, tmp_buf);
 	    if (i < nr) {
 	    if (i == nr - 1) {
-		    G_put_d_raster_row(d1, tmp_buf2);
+		    Rast_put_d_raster_row(d1, tmp_buf2);
 		G_free(tmp_buf2);
 	    if (i == 0) {
-		    G_put_d_raster_row(d2, tmp_buf);
+		    Rast_put_d_raster_row(d2, tmp_buf);
 	    if (i < nr) {
 	    if (i == nr - 1) {
-		    G_put_d_raster_row(d2, tmp_buf2);
+		    Rast_put_d_raster_row(d2, tmp_buf2);
 		G_free(tmp_buf2);
 	    if (i == 0) {
-		    G_put_d_raster_row(d3, tmp_buf);
+		    Rast_put_d_raster_row(d3, tmp_buf);
 	    if (i < nr) {
 	    if (i == nr - 1) {
-		    G_put_d_raster_row(d3, tmp_buf2);
+		    Rast_put_d_raster_row(d3, tmp_buf2);
 		G_free(tmp_buf2);
 	    if (i == 0) {
-		    G_put_d_raster_row(d4, tmp_buf);
+		    Rast_put_d_raster_row(d4, tmp_buf);
 	    if (i < nr) {
 	    if (i == nr - 1) {
-		    G_put_d_raster_row(d4, tmp_buf2);
+		    Rast_put_d_raster_row(d4, tmp_buf2);
 		G_free(tmp_buf2);
 	    if (i == 0) {
-		    G_put_d_raster_row(t1, tmp_buf);
+		    Rast_put_d_raster_row(t1, tmp_buf);
 	    if (i < nr) {
 	    if (i == nr - 1) {
-		    G_put_d_raster_row(t1, tmp_buf2);
+		    Rast_put_d_raster_row(t1, tmp_buf2);
 		G_free(tmp_buf2);
 	    if (i == 0) {
-		    G_put_d_raster_row(t2, tmp_buf);
+		    Rast_put_d_raster_row(t2, tmp_buf);
 	    if (i < nr) {
 	    if (i == nr - 1) {
-		    G_put_d_raster_row(t2, tmp_buf2);
+		    Rast_put_d_raster_row(t2, tmp_buf2);
 		G_free(tmp_buf2);
 	    if (i == 0) {
-		    G_put_d_raster_row(t3, tmp_buf);
+		    Rast_put_d_raster_row(t3, tmp_buf);
 	    if (i < nr) {
 	    if (i == nr - 1) {
-		    G_put_d_raster_row(t3, tmp_buf2);
+		    Rast_put_d_raster_row(t3, tmp_buf2);
 		G_free(tmp_buf2);
 	    if (i == 0) {
-		    G_put_d_raster_row(t4, tmp_buf);
+		    Rast_put_d_raster_row(t4, tmp_buf);
 	    if (i < nr) {
 	    if (i == nr - 1) {
-		    G_put_d_raster_row(t4, tmp_buf2);
+		    Rast_put_d_raster_row(t4, tmp_buf2);
 		G_free(tmp_buf2);
 	    if (i == 0) {
-		    G_put_d_raster_row(t5, tmp_buf);
+		    Rast_put_d_raster_row(t5, tmp_buf);
 	    if (i < nr) {
 	    if (i == nr - 1) {
-		    G_put_d_raster_row(t5, tmp_buf2);
+		    Rast_put_d_raster_row(t5, tmp_buf2);
 		G_free(tmp_buf2);
 	    if (i == 0) {
-		    G_put_d_raster_row(j1, tmp_buf);
+		    Rast_put_d_raster_row(j1, tmp_buf);
 	    if (i < nr) {
 	    if (i == nr - 1) {
-		    G_put_d_raster_row(j1, tmp_buf2);
+		    Rast_put_d_raster_row(j1, tmp_buf2);
 		G_free(tmp_buf2);
 	    if (i == 0) {
-		    G_put_d_raster_row(j2, tmp_buf);
+		    Rast_put_d_raster_row(j2, tmp_buf);
 	    if (i < nr) {
 	    if (i == nr - 1) {
-		    G_put_d_raster_row(j2, tmp_buf2);
+		    Rast_put_d_raster_row(j2, tmp_buf2);
 		G_free(tmp_buf2);
 	    if (i == 0) {
-		    G_put_d_raster_row(e1, tmp_buf);
+		    Rast_put_d_raster_row(e1, tmp_buf);
 	    if (i < nr) {
 	    if (i == nr - 1) {
-		    G_put_d_raster_row(e1, tmp_buf2);
+		    Rast_put_d_raster_row(e1, tmp_buf2);
 		G_free(tmp_buf2);
 	    if (i == 0) {
-		    G_put_d_raster_row(e2, tmp_buf);
+		    Rast_put_d_raster_row(e2, tmp_buf);
 	    if (i < nr) {
 	    if (i == nr - 1) {
-		    G_put_d_raster_row(e2, tmp_buf2);
+		    Rast_put_d_raster_row(e2, tmp_buf2);
 		G_free(tmp_buf2);
@@ -980,109 +980,109 @@
-	G_close_cell(b1);
+	Rast_close_cell(b1);
 	set_colors("b1");
 	sprintf(cmdbuf, "%s %s", "r.compress", "b1");
 	system(cmdbuf);
-	G_close_cell(b2);
+	Rast_close_cell(b2);
 	set_colors("b2");
 	sprintf(cmdbuf, "%s %s", "r.compress", "b2");
 	system(cmdbuf);
-	G_close_cell(b3);
+	Rast_close_cell(b3);
 	set_colors("b3");
 	sprintf(cmdbuf, "%s %s", "r.compress", "b3");
 	system(cmdbuf);
-	G_close_cell(b4);
+	Rast_close_cell(b4);
 	set_colors("b4");
 	sprintf(cmdbuf, "%s %s", "r.compress", "b4");
 	system(cmdbuf);
-	G_close_cell(d1);
+	Rast_close_cell(d1);
 	set_colors("d1");
 	sprintf(cmdbuf, "%s %s", "r.compress", "d1");
 	system(cmdbuf);
-	G_close_cell(d2);
+	Rast_close_cell(d2);
 	set_colors("d2");
 	sprintf(cmdbuf, "%s %s", "r.compress", "d2");
 	system(cmdbuf);
-	G_close_cell(d3);
+	Rast_close_cell(d3);
 	set_colors("d3");
 	sprintf(cmdbuf, "%s %s", "r.compress", "d3");
 	system(cmdbuf);
-	G_close_cell(d4);
+	Rast_close_cell(d4);
 	set_colors("d4");
 	sprintf(cmdbuf, "%s %s", "r.compress", "d4");
 	system(cmdbuf);
-	G_close_cell(t1);
+	Rast_close_cell(t1);
 	set_colors("t1");
 	sprintf(cmdbuf, "%s %s", "r.compress", "t1");
 	system(cmdbuf);
-	G_close_cell(t2);
+	Rast_close_cell(t2);
 	set_colors("t2");
 	sprintf(cmdbuf, "%s %s", "r.compress", "t2");
 	system(cmdbuf);
-	G_close_cell(t3);
+	Rast_close_cell(t3);
 	set_colors("t3");
 	sprintf(cmdbuf, "%s %s", "r.compress", "t3");
 	system(cmdbuf);
-	G_close_cell(t4);
+	Rast_close_cell(t4);
 	set_colors("t4");
 	sprintf(cmdbuf, "%s %s", "r.compress", "t4");
 	system(cmdbuf);
-	G_close_cell(t5);
+	Rast_close_cell(t5);
 	set_colors("t5");
 	sprintf(cmdbuf, "%s %s", "r.compress", "t5");
 	system(cmdbuf);
-	G_close_cell(j1);
+	Rast_close_cell(j1);
 	set_colors("j1");
 	sprintf(cmdbuf, "%s %s", "r.compress", "j1");
 	system(cmdbuf);
-	G_close_cell(j2);
+	Rast_close_cell(j2);
 	set_colors("j2");
 	sprintf(cmdbuf, "%s %s", "r.compress", "j2");
 	system(cmdbuf);
-	G_close_cell(e1);
+	Rast_close_cell(e1);
 	set_colors("e1");
 	sprintf(cmdbuf, "%s %s", "r.compress", "e1");
 	system(cmdbuf);
-	G_close_cell(e2);
+	Rast_close_cell(e2);
 	set_colors("e2");
 	sprintf(cmdbuf, "%s %s", "r.compress", "e2");
 	system(cmdbuf);
     return;
@@ -1101,9 +1101,9 @@
     return;
@@ -1346,17 +1346,17 @@
 	case CELL_TYPE:
 	    break;
 	case FCELL_TYPE:
 	    break;
 	case DCELL_TYPE:
 	    break;
 	   pixel by pixel */
@@ -1365,20 +1365,20 @@
 	    case (CELL_TYPE):
 		break;
 	    case (FCELL_TYPE):
 		break;
 	    case (DCELL_TYPE):
 		break;
 	    for (j = 0; j < wind.cols; j++) {
@@ -1524,18 +1524,18 @@
 		for (m = 1; m < wind.cols + 3; m++) {
-	    G_close_cell(fd);
 	    G_free(unit_buf);
@@ -1638,7 +1638,7 @@
     REGLIST *ptrfirst, *ptrthis, *ptrnew;
     RASTER_MAP_TYPE data_type;
     nrows = G_window_rows();
     ncols = G_window_cols();
@@ -1665,17 +1665,17 @@
 	case CELL_TYPE:
 	    break;
 	case FCELL_TYPE:
 	    break;
 	case DCELL_TYPE:
 	    break;
 	   pixel by pixel */
@@ -1684,20 +1684,20 @@
 	    case (CELL_TYPE):
 		break;
 	    case (FCELL_TYPE):
 		break;
 	    case (DCELL_TYPE):
 		break;
@@ -1750,11 +1750,11 @@
     else {
 	regcnt = 0;
 		if (*(row_buf + j)) {
 		    if (regcnt == 0)
@@ -1805,7 +1805,7 @@
 			  cntwhole, 0.0);
-	G_close_cell(fr);
 	G_free(row_buf);
 	G_free(ptrnew);
Modified: grass/trunk/raster/r.le/r.le.pixel/pixel.h
--- grass/trunk/raster/r.le/r.le.pixel/pixel.h	2009-06-20 21:39:23 UTC (rev 38002)
+++ grass/trunk/raster/r.le/r.le.pixel/pixel.h	2009-06-20 22:03:23 UTC (rev 38003)
@@ -26,6 +26,7 @@
 #include <stdlib.h>
 #include <string.h>
 #define  BIG   1000000000.0
 #define  MAX   800
Modified: grass/trunk/raster/r.le/r.le.pixel/texture.c
--- grass/trunk/raster/r.le/r.le.pixel/texture.c	2009-06-20 21:39:23 UTC (rev 38002)
+++ grass/trunk/raster/r.le/r.le.pixel/texture.c	2009-06-20 22:03:23 UTC (rev 38003)
@@ -37,7 +37,7 @@
 struct Categories cats;
-char *G_get_cat();
+char *Rast_get_cat();
 					/* declare a counter for the number
 					   of pixels with non-null values
@@ -259,7 +259,7 @@
     DCELL **edgemap_d, *edge_buf_d, *zscor_buf;
     /* set the contents of the arrays
        used to stored the results of the
@@ -464,42 +464,42 @@
     /* if the edge map was requested */
     if (choice->edgemap) {
-	fc = G_open_raster_new("edge", data_type);
+	fc = Rast_open_raster_new("edge", data_type);
 	case (CELL_TYPE):
-	    edge_buf_c = G_allocate_raster_buf(CELL_TYPE);
+	    edge_buf_c = Rast_allocate_raster_buf(CELL_TYPE);
-		G_zero_raster_buf(edge_buf_c, CELL_TYPE);
-		G_set_null_value(edge_buf_c, ncols + 1, CELL_TYPE);
+		Rast_zero_raster_buf(edge_buf_c, CELL_TYPE);
+		Rast_set_null_value(edge_buf_c, ncols + 1, CELL_TYPE);
 		    if (*(*(edgenull + i) + j) == 0)
 			*(edge_buf_c + j - 1) = edgemap_c[i][j];
-		G_put_raster_row(fc, edge_buf_c, CELL_TYPE);
+		Rast_put_raster_row(fc, edge_buf_c, CELL_TYPE);
 	    break;
 	case (FCELL_TYPE):
-	    edge_buf_f = G_allocate_raster_buf(FCELL_TYPE);
+	    edge_buf_f = Rast_allocate_raster_buf(FCELL_TYPE);
-		G_zero_raster_buf(edge_buf_f, FCELL_TYPE);
-		G_set_null_value(edge_buf_f, ncols + 1, FCELL_TYPE);
+		Rast_zero_raster_buf(edge_buf_f, FCELL_TYPE);
+		Rast_set_null_value(edge_buf_f, ncols + 1, FCELL_TYPE);
 			*(edge_buf_f + j - 1) = edgemap_f[i][j];
-		G_put_raster_row(fc, edge_buf_f, FCELL_TYPE);
+		Rast_put_raster_row(fc, edge_buf_f, FCELL_TYPE);
 	    break;
 	case (DCELL_TYPE):
-	    edge_buf_d = G_allocate_raster_buf(DCELL_TYPE);
+	    edge_buf_d = Rast_allocate_raster_buf(DCELL_TYPE);
-		G_zero_raster_buf(edge_buf_d, DCELL_TYPE);
-		G_set_null_value(edge_buf_d, ncols + 1, DCELL_TYPE);
+		Rast_zero_raster_buf(edge_buf_d, DCELL_TYPE);
+		Rast_set_null_value(edge_buf_d, ncols + 1, DCELL_TYPE);
 			*(edge_buf_d + j - 1) = edgemap_d[i][j];
-		G_put_raster_row(fc, edge_buf_d, DCELL_TYPE);
+		Rast_put_raster_row(fc, edge_buf_d, DCELL_TYPE);
 	    break;
@@ -526,17 +526,17 @@
 	    G_free(edgenull[i]);
 	G_free(edgenull);
-	G_close_cell(fc);
+	Rast_close_cell(fc);
     /* if the zscore map was requested */
     if (choice->z) {
-	fd = G_open_raster_new("zscores", DCELL_TYPE);
-	zscor_buf = G_allocate_raster_buf(DCELL_TYPE);
+	fd = Rast_open_raster_new("zscores", DCELL_TYPE);
+	zscor_buf = Rast_allocate_raster_buf(DCELL_TYPE);
-	    G_zero_raster_buf(zscor_buf, DCELL_TYPE);
-	    G_set_null_value(zscor_buf, ncols + 1, DCELL_TYPE);
+	    Rast_zero_raster_buf(zscor_buf, DCELL_TYPE);
+	    Rast_set_null_value(zscor_buf, ncols + 1, DCELL_TYPE);
 		if (attr[1] > 0.0)
 		    if ((buf[i][j] || buf[i][j] == 0) &&
@@ -544,10 +544,10 @@
 			*(zscor_buf + j - 1) =
 			    (buf[i][j] - attr[0]) / attr[1];
-	    G_put_raster_row(fd, zscor_buf, DCELL_TYPE);
+	    Rast_put_raster_row(fd, zscor_buf, DCELL_TYPE);
 	G_free(zscor_buf);
-	G_close_cell(fd);
     /* open the output files and
Modified: grass/trunk/raster/r.le/r.le.setup/mv_wind.c
--- grass/trunk/raster/r.le/r.le.setup/mv_wind.c	2009-06-20 21:39:23 UTC (rev 38002)
+++ grass/trunk/raster/r.le/r.le.setup/mv_wind.c	2009-06-20 22:03:23 UTC (rev 38003)
@@ -103,7 +103,7 @@
 	fprintf(stderr,
 		"    If a MASK is present there will be no warning.\n");
@@ -338,7 +338,7 @@
 	    t = t0;
     /* if neither, then exit */
Modified: grass/trunk/raster/r.le/r.le.setup/polytocell/bmf_to_cll.c
--- grass/trunk/raster/r.le/r.le.setup/polytocell/bmf_to_cll.c	2009-06-20 21:39:23 UTC (rev 38002)
+++ grass/trunk/raster/r.le/r.le.setup/polytocell/bmf_to_cll.c	2009-06-20 22:03:23 UTC (rev 38003)
@@ -48,7 +48,7 @@
     num_rows = col_b;
     num_cols = col_e;
-    if (G_get_cellhd(argv[1], mapset = G_mapset(), &wind)) {
+    if (Rast_get_cellhd(argv[1], mapset = G_mapset(), &wind)) {
 	fprintf(stderr, "ERROR bmif_to_cell: can't read cellhd file for %s\n",
 		argv[1]);
 	quit();
@@ -66,9 +66,9 @@
     G_set_window(&wind);
-    record = G_allocate_cell_buf();
+    record = Rast_allocate_cell_buf();
-    if ((newmap = G_open_cell_new(argv[1])) == -1) {
+    if ((newmap = Rast_open_cell_new(argv[1])) == -1) {
 	fprintf(stderr, "ERROR bmif_to_cell: can't open raster map %s\n",
 		argv[1]);
 	quit();
@@ -91,17 +91,17 @@
 	if (cur_row > num_rows) {
 	    while (atrow < num_rows) {
-		G_put_map_row(newmap, record);
+		Rast_put_map_row(newmap, record);
 		atrow++;
-	    G_close_cell(newmap);
+	    Rast_close_cell(newmap);
 	    goto finish;
 	/* write out enough rows to get to current row */
 	while (atrow < cur_row + ROW_SHIFT) {
 	    atrow++;
@@ -114,17 +114,17 @@
 	while (cur_row == (atrow - ROW_SHIFT));
-    fprintf(stderr, "Close: %d\n", G_close_cell(newmap));
+    fprintf(stderr, "Close: %d\n", Rast_close_cell(newmap));
   finish:
     G_suppress_warnings(1);
-    stat = G_read_vector_cats(argv[1], mapset, &cats);
+    stat = Rast_read_vector_cats(argv[1], mapset, &cats);
     G_suppress_warnings(0);
     if (stat >= 0) {		/* if cats file existed */
 	printf("Copying vector category file\n");
-	stat = G_write_cats(argv[1], &cats);
+	stat = Rast_write_cats(argv[1], &cats);
     exit(0);
Modified: grass/trunk/raster/r.le/r.le.setup/sample.c
--- grass/trunk/raster/r.le/r.le.setup/sample.c	2009-06-20 21:39:23 UTC (rev 38002)
+++ grass/trunk/raster/r.le/r.le.setup/sample.c	2009-06-20 22:03:23 UTC (rev 38003)
@@ -102,7 +102,7 @@
 		"    and a WARNING may be printed that can be ignored.\n");
 	fprintf(stderr,
 	fprintf(stderr, "\n");
@@ -118,7 +118,7 @@
 	else if (d == 2)
 	    graph_unit(t0, b0, l0, r0, name, name1, name2, msc, fmask);
     else
@@ -353,18 +353,18 @@
 		if (fmask > 0) {
 		    count = 0;
-		    fr = G_open_cell_old(n1, G_mapset());
+		    fr = Rast_open_cell_old(n1, G_mapset());
 		    for (j = t; j < b; j++) {
-			G_get_raster_row(fr, row_buf, j, CELL_TYPE);
+			Rast_get_raster_row(fr, row_buf, j, CELL_TYPE);
 			for (k = l; k < r; k++) {
 			    if (*(row_buf + k))
 				count++;
 		    G_free(row_buf);
-		    G_close_cell(fr);
 		    cnt = (double)(count);
 		    if (cnt)
 			cnt = sqrt(cnt);
@@ -410,18 +410,18 @@
 		    if (fmask > 0) {
 			count = 0;
 				if (*(row_buf + k))
 				    count++;
 			G_free(row_buf);
-			G_close_cell(fr);
 			if (cnt)
 			    cnt = sqrt(cnt);
@@ -956,14 +956,14 @@
 		   the unit will be within the mask area */
 		if (fmask > 0) {
-		    row_buf = G_allocate_cell_buf();
-		    G_get_map_row_nomask(fmask, row_buf, t + top1);
+		    row_buf = Rast_allocate_cell_buf();
+		    Rast_get_map_row_nomask(fmask, row_buf, t + top1);
 		    if (!
 			(*(row_buf + l + left1) &&
 			 *(row_buf + l + left1 + u_w - 1)))
 			goto back;
-		    G_zero_cell_buf(row_buf);
-		    G_get_map_row_nomask(fmask, row_buf, t + top1 + u_l - 1);
+		    Rast_zero_cell_buf(row_buf);
+		    Rast_get_map_row_nomask(fmask, row_buf, t + top1 + u_l - 1);
 		    if (!
@@ -1407,8 +1407,8 @@
 		   corners of the unit are in the mask */
 		if (fmask > 0) {
-		    G_get_map_row_nomask(fmask, row_buf, at);
+		    Rast_get_map_row_nomask(fmask, row_buf, at);
 		    if (!(*(row_buf + al) && *(row_buf + ar - 1))) {
 			fprintf(stderr,
 				"\n    The unit would be outside the mask; ");
@@ -1417,8 +1417,8 @@
 			G_free(row_buf);
 			goto back1;
-		    G_get_map_row_nomask(fmask, row_buf, ab - 1);
+		    Rast_get_map_row_nomask(fmask, row_buf, ab - 1);
 			fprintf(stderr,
@@ -1529,8 +1529,8 @@
 		if (fmask > 0) {
 			fprintf(stderr,
@@ -1539,8 +1539,8 @@
 			G_free(row_buf);
 			goto back2;
 			fprintf(stderr,
Modified: grass/trunk/raster/r.le/r.le.setup/setup.c
--- grass/trunk/raster/r.le/r.le.setup/setup.c	2009-06-20 21:39:23 UTC (rev 38002)
+++ grass/trunk/raster/r.le/r.le.setup/setup.c	2009-06-20 22:03:23 UTC (rev 38003)
@@ -122,8 +122,8 @@
     colors_old = (struct Colors *)G_malloc(1 * sizeof(struct Colors));
-    G_init_colors(colors_old);
-    G_read_colors(name, G_mapset(), colors_old);
+    Rast_init_colors(colors_old);
+    Rast_read_colors(name, G_mapset(), colors_old);
     G_system("clear");
     paint_map(name, name1, name2);
@@ -238,8 +238,8 @@
     /* reset the colortable and exit */
     else if (method == 7) {
-	G_write_colors(name, G_mapset(), colors_old);
-	G_free_colors(colors_old);
+	Rast_write_colors(name, G_mapset(), colors_old);
+	Rast_free_colors(colors_old);
 	/*     R_close_driver(); */
 	G_system("d.frame -e");
 	exit(0);
@@ -624,7 +624,7 @@
     fprintf(tmp, "E\n");
     fclose(tmp);
     G_get_set_window(&wind);
-    G_put_cellhd(name, &wind);
+    Rast_put_cellhd(name, &wind);
     /* make a GRASS raster map from the
        region boundary pts, using the
@@ -642,9 +642,9 @@
     /* set the color table for the regions
        file to color wave */
-    G_init_colors(&colors);
-    G_make_wave_colors(&colors, 1, class);
+    Rast_init_colors(&colors);
+    Rast_make_wave_colors(&colors, 1, class);
     /* overlay the region file on the
        screen */
@@ -711,8 +711,8 @@
     double etmp;
-    G_read_range(name, G_mapset(), &range);
+    Rast_read_range(name, G_mapset(), &range);
     G_system("clear");
   again:
@@ -738,39 +738,39 @@
     while (d > 10 || d < 1);
     if (d == 1) {
-	G_make_aspect_colors(&colors, min, max);
+	Rast_make_aspect_colors(&colors, min, max);
     else if (d == 2) {
-	G_make_ramp_colors(&colors, min, max);
+	Rast_make_ramp_colors(&colors, min, max);
     else if (d == 3) {
-	G_make_wave_colors(&colors, min, max);
+	Rast_make_wave_colors(&colors, min, max);
     else if (d == 4) {
-	G_make_grey_scale_colors(&colors, min, max);
+	Rast_make_grey_scale_colors(&colors, min, max);
     else if (d == 5) {
-	G_make_rainbow_colors(&colors, min, max);
+	Rast_make_rainbow_colors(&colors, min, max);
     else if (d == 6) {
-	G_make_random_colors(&colors, min, max);
+	Rast_make_random_colors(&colors, min, max);
     else if (d == 7) {
-	G_make_ryg_colors(&colors, min, max);
+	Rast_make_ryg_colors(&colors, min, max);
     else if (d == 8) {
-	G_make_gyr_colors(&colors, min, max);
+	Rast_make_gyr_colors(&colors, min, max);
     else if (d == 9) {
     else if (d == 10) {
 	return;
@@ -802,8 +802,8 @@
     else if (d == 2)
 	return;
     else if (d == 3) {
     else if (d == 4)
 	*colors_old = colors;
Modified: grass/trunk/raster/r.le/r.le.setup/setup.h
--- grass/trunk/raster/r.le/r.le.setup/setup.h	2009-06-20 21:39:23 UTC (rev 38002)
+++ grass/trunk/raster/r.le/r.le.setup/setup.h	2009-06-20 22:03:23 UTC (rev 38003)
@@ -28,6 +28,7 @@
 #include "stdlib.h"
 #include "string.h"
 #include "sys/types.h"
Modified: grass/trunk/raster/r.le/r.le.trace/main.c
--- grass/trunk/raster/r.le/r.le.trace/main.c	2009-06-20 21:39:23 UTC (rev 38002)
+++ grass/trunk/raster/r.le/r.le.trace/main.c	2009-06-20 22:03:23 UTC (rev 38003)
@@ -435,7 +435,7 @@
     name = choice->fn;
@@ -443,7 +443,7 @@
@@ -453,7 +453,7 @@
@@ -553,7 +553,7 @@
        map remains open on finput while all the programs
        run, so it is globally available */
-    if (0 > (finput = G_open_cell_old(choice->fn, G_mapset()))) {
+    if (0 > (finput = Rast_open_cell_old(choice->fn, G_mapset()))) {
 	fprintf(stderr,
@@ -567,7 +567,7 @@
     else
-	data_type = G_raster_map_type(choice->fn, G_mapset());
+	data_type = Rast_raster_map_type(choice->fn, G_mapset());
        raster map, depending on the type of
@@ -576,15 +576,15 @@
     case CELL_TYPE:
 	tmpname = "tmp";
 	break;
     case FCELL_TYPE:
 	tmpname = "ftmp";
 	break;
     case DCELL_TYPE:
 	tmpname = "dtmp";
 	break;
@@ -609,16 +609,16 @@
 	case CELL_TYPE:
 	    break;
 	case FCELL_TYPE:
 	    break;
 	case DCELL_TYPE:
 	    break;
@@ -632,17 +632,17 @@
 	case CELL_TYPE:
 	    rastptr = tmp;
 	    break;
 	case FCELL_TYPE:
 	    rastptr = ftmp;
 	    break;
 	case DCELL_TYPE:
 	    rastptr = dtmp;
 	    break;
@@ -657,7 +657,7 @@
 	    case CELL_TYPE:
 			*centernull = 1;
@@ -665,11 +665,11 @@
 		else {
 		    *(*(null_buf + i + 1 - row0) + j + 1 - col0) = 0.0;
 		break;
 	    case FCELL_TYPE:
 			*centernull = 1;
@@ -677,11 +677,11 @@
 		else {
 		break;
 	    case DCELL_TYPE:
 			*centernull = 1;
@@ -689,7 +689,7 @@
 		else {
 		break;
@@ -932,7 +932,7 @@
     /* if this is the first patch to be traced,
        then set the next patch on the patch list
Modified: grass/trunk/raster/r.le/r.le.trace/r.le.trace.h
--- grass/trunk/raster/r.le/r.le.trace/r.le.trace.h	2009-06-20 21:39:23 UTC (rev 38002)
+++ grass/trunk/raster/r.le/r.le.trace/r.le.trace.h	2009-06-20 22:03:23 UTC (rev 38003)
@@ -26,6 +26,7 @@
 #include "stdlib.h"
 #include "string.h"
 #define EQ(a, b)    (a-b < 0.01 && a-b > -0.01 )
 #define BIG   500000000.0
Modified: grass/trunk/raster/r.li/r.li.cwed/cwed.c
--- grass/trunk/raster/r.li/r.li.cwed/cwed.c	2009-06-20 21:39:23 UTC (rev 38002)
+++ grass/trunk/raster/r.li/r.li.cwed/cwed.c	2009-06-20 22:03:23 UTC (rev 38003)
@@ -12,6 +12,7 @@
 #include <grass/glocale.h>
 #include <fcntl.h>		/* for O_RDONLY usage */
@@ -159,7 +160,7 @@
 	return RLI_ERRORE;
-    if (G_get_cellhd(ad->raster, "", &hd) == -1) {
+    if (Rast_get_cellhd(ad->raster, "", &hd) == -1) {
 	G_fatal_error("can't read raster header");
 	return RLI_ERRORE;
@@ -340,7 +341,7 @@
-    buf_sup = G_allocate_cell_buf();
+    buf_sup = Rast_allocate_cell_buf();
     if (buf_sup == NULL) {
 	G_fatal_error("malloc buf_sup failed");
 	return RLI_ERRORE;
@@ -349,13 +350,13 @@
     c1.t = CELL_TYPE;
     c2.t = CELL_TYPE;
-    buf_corr = G_allocate_cell_buf();
+    buf_corr = Rast_allocate_cell_buf();
     if (buf_corr == NULL) {
 	G_fatal_error("error malloc buf_corr");
 	return RLI_ERRORE;
-    G_set_c_null_value(buf_sup + ad->x, ad->cl);	/*the first time buf_sup is all null */
+    Rast_set_c_null_value(buf_sup + ad->x, ad->cl);	/*the first time buf_sup is all null */
     for (j = 0; j < ad->rl; j++) {	/* for each row */
 	buf_corr = RLI_get_cell_raster_row(fd, j + ad->y, ad);	/* read row of raster */
 	if (j > 0) {		/* not first row */
@@ -369,20 +370,20 @@
-	G_set_c_null_value(&prevCell, 1);
-	G_set_c_null_value(&corrCell, 1);
+	Rast_set_c_null_value(&prevCell, 1);
+	Rast_set_c_null_value(&corrCell, 1);
 	for (i = 0; i < ad->cl; i++) {	/* for each cell in the row */
 	    area++;
 	    corrCell = buf_corr[i + ad->x];
 	    if (masked && mask_corr[i + ad->x] == 0) {
 		area--;
-	    if (!(G_is_null_value(&corrCell, CELL_TYPE))) {
+	    if (!(Rast_is_null_value(&corrCell, CELL_TYPE))) {
 		supCell = buf_sup[i + ad->x];
 		/* calculate how many edge the cell has */
-		if (((!G_is_null_value(&prevCell, CELL_TYPE))) &&
+		if (((!Rast_is_null_value(&prevCell, CELL_TYPE))) &&
 		    (corrCell != prevCell)) {
 		    int r = 0;
@@ -395,7 +396,7 @@
-		if ((!(G_is_null_value(&supCell, CELL_TYPE))) &&
+		if ((!(Rast_is_null_value(&supCell, CELL_TYPE))) &&
 		    (corrCell != supCell)) {
 		    int r = 0;
@@ -481,7 +482,7 @@
-    buf_sup = G_allocate_d_raster_buf();
+    buf_sup = Rast_allocate_d_raster_buf();
 	return RLI_ERRORE;
@@ -490,9 +491,9 @@
     c1.t = DCELL_TYPE;
     c2.t = DCELL_TYPE;
-    buf_corr = G_allocate_d_raster_buf();
+    buf_corr = Rast_allocate_d_raster_buf();
-    G_set_d_null_value(buf_sup + ad->x, ad->cl);	/*the first time buf_sup is all null */
+    Rast_set_d_null_value(buf_sup + ad->x, ad->cl);	/*the first time buf_sup is all null */
 	buf_corr = RLI_get_dcell_raster_row(fd, j + ad->y, ad);	/* read row of raster */
@@ -506,19 +507,19 @@
 		return RLI_ERRORE;
-	G_set_d_null_value(&prevCell, 1);
-	G_set_d_null_value(&corrCell, 1);
+	Rast_set_d_null_value(&prevCell, 1);
+	Rast_set_d_null_value(&corrCell, 1);
 	    area++;
 		area--;
-	    if (!(G_is_null_value(&corrCell, DCELL_TYPE))) {
+	    if (!(Rast_is_null_value(&corrCell, DCELL_TYPE))) {
-		if (((!G_is_null_value(&prevCell, DCELL_TYPE))) &&
+		if (((!Rast_is_null_value(&prevCell, DCELL_TYPE))) &&
 		    int r = 0;
@@ -530,7 +531,7 @@
-		if ((!(G_is_null_value(&supCell, DCELL_TYPE))) &&
+		if ((!(Rast_is_null_value(&supCell, DCELL_TYPE))) &&
 		    int r = 0;
@@ -617,14 +618,14 @@
     /* allocate and inizialize buffers */
-    buf_sup = G_allocate_f_raster_buf();
+    buf_sup = Rast_allocate_f_raster_buf();
 	return RLI_ERRORE;
-    G_set_f_null_value(buf_sup + ad->x, ad->cl);	/*the first time buf_sup is all null */
+    Rast_set_f_null_value(buf_sup + ad->x, ad->cl);	/*the first time buf_sup is all null */
-    buf_corr = G_allocate_f_raster_buf();
+    buf_corr = Rast_allocate_f_raster_buf();
 	G_fatal_error("malloc buf_corr failed");
 	return RLI_ERRORE;
@@ -646,19 +647,19 @@
 		return RLI_ERRORE;
-	G_set_f_null_value(&prevCell, 1);
-	G_set_f_null_value(&corrCell, 1);
+	Rast_set_f_null_value(&prevCell, 1);
+	Rast_set_f_null_value(&corrCell, 1);
 	    area++;
 		area--;
-	    if (!(G_is_null_value(&corrCell, FCELL_TYPE))) {
+	    if (!(Rast_is_null_value(&corrCell, FCELL_TYPE))) {
-		if (((!G_is_null_value(&prevCell, FCELL_TYPE))) &&
+		if (((!Rast_is_null_value(&prevCell, FCELL_TYPE))) &&
 		    int r = 0;
@@ -670,7 +671,7 @@
-		if ((!(G_is_null_value(&supCell, FCELL_TYPE))) &&
+		if ((!(Rast_is_null_value(&supCell, FCELL_TYPE))) &&
 		    int r = 0;
@@ -737,22 +738,22 @@
     switch (ce1.t) {
     case CELL_TYPE:
-	    if ((G_is_null_value(&ce1.val.c, CELL_TYPE)) ||
-		(G_is_null_value(&ce2.val.c, CELL_TYPE)))
+	    if ((Rast_is_null_value(&ce1.val.c, CELL_TYPE)) ||
+		(Rast_is_null_value(&ce2.val.c, CELL_TYPE)))
 		return _ERR;
 	    break;
     case DCELL_TYPE:
-	    if ((G_is_null_value(&ce1.val.dc, DCELL_TYPE)) ||
-		(G_is_null_value(&ce2.val.dc, DCELL_TYPE)))
+	    if ((Rast_is_null_value(&ce1.val.dc, DCELL_TYPE)) ||
+		(Rast_is_null_value(&ce2.val.dc, DCELL_TYPE)))
 		return _ERR;
 	    break;
     case FCELL_TYPE:
-	    if ((G_is_null_value(&ce1.val.fc, FCELL_TYPE)) ||
-		(G_is_null_value(&ce2.val.fc, FCELL_TYPE)))
+	    if ((Rast_is_null_value(&ce1.val.fc, FCELL_TYPE)) ||
+		(Rast_is_null_value(&ce2.val.fc, FCELL_TYPE)))
 		return _ERR;
 	    break;
@@ -824,22 +825,22 @@
     switch (c1.t) {
     case CELL_TYPE:
-	    if ((G_is_null_value(&(c1.val.c), CELL_TYPE)) ||
-		(G_is_null_value(&(c2.val.c), CELL_TYPE)))
+	    if ((Rast_is_null_value(&(c1.val.c), CELL_TYPE)) ||
+		(Rast_is_null_value(&(c2.val.c), CELL_TYPE)))
 		return RLI_ERRORE;
 	    break;
     case DCELL_TYPE:
-	    if ((G_is_null_value(&(c1.val.dc), DCELL_TYPE)) ||
-		(G_is_null_value(&(c2.val.dc), DCELL_TYPE)))
+	    if ((Rast_is_null_value(&(c1.val.dc), DCELL_TYPE)) ||
+		(Rast_is_null_value(&(c2.val.dc), DCELL_TYPE)))
 		return RLI_ERRORE;
 	    break;
     case FCELL_TYPE:
-	    if ((G_is_null_value(&(c1.val.fc), FCELL_TYPE)) ||
-		(G_is_null_value(&(c2.val.fc), FCELL_TYPE)))
+	    if ((Rast_is_null_value(&(c1.val.fc), FCELL_TYPE)) ||
+		(Rast_is_null_value(&(c2.val.fc), FCELL_TYPE)))
 		return RLI_ERRORE;
 	    break;
Modified: grass/trunk/raster/r.li/r.li.cwed/utility.c
--- grass/trunk/raster/r.li/r.li.cwed/utility.c	2009-06-20 21:39:23 UTC (rev 38002)
+++ grass/trunk/raster/r.li/r.li.cwed/utility.c	2009-06-20 22:03:23 UTC (rev 38003)
@@ -10,6 +10,7 @@
 #include <string.h>
Modified: grass/trunk/raster/r.li/r.li.daemon/GenericCell.h
--- grass/trunk/raster/r.li/r.li.daemon/GenericCell.h	2009-06-20 21:39:23 UTC (rev 38002)
+++ grass/trunk/raster/r.li/r.li.daemon/GenericCell.h	2009-06-20 22:03:23 UTC (rev 38003)
@@ -9,6 +9,7 @@
 #ifndef GENERICCELL_H
Modified: grass/trunk/raster/r.li/r.li.daemon/avl.c
--- grass/trunk/raster/r.li/r.li.daemon/avl.c	2009-06-20 21:39:23 UTC (rev 38002)
+++ grass/trunk/raster/r.li/r.li.daemon/avl.c	2009-06-20 22:03:23 UTC (rev 38003)
@@ -8,6 +8,7 @@
  *       \BUGS: please send bugs reports to pallecch at cli.di.unipi.it
 #include <string.h>
Modified: grass/trunk/raster/r.li/r.li.daemon/avlID.c
--- grass/trunk/raster/r.li/r.li.daemon/avlID.c	2009-06-20 21:39:23 UTC (rev 38002)
+++ grass/trunk/raster/r.li/r.li.daemon/avlID.c	2009-06-20 22:03:23 UTC (rev 38003)
@@ -12,6 +12,7 @@
 #include <stdlib.h>
Modified: grass/trunk/raster/r.li/r.li.daemon/daemon.c
--- grass/trunk/raster/r.li/r.li.daemon/daemon.c	2009-06-20 21:39:23 UTC (rev 38002)
+++ grass/trunk/raster/r.li/r.li.daemon/daemon.c	2009-06-20 22:03:23 UTC (rev 38003)
@@ -31,6 +31,7 @@
 #endif
 #include "daemon.h"
@@ -112,7 +113,7 @@
 	/* struct Cell_head cellhd_r, cellhd_new;
 	   char *mapset; */
 	/*creating new raster file */
-	mv_fd = G_open_raster_new(output, DCELL_TYPE);
+	mv_fd = Rast_open_raster_new(output, DCELL_TYPE);
 	if (mv_fd < 0)
 	    G_fatal_error(_("Unable to create raster map <%s>"), output);
@@ -267,10 +268,10 @@
 	write_raster(mv_fd, random_access, g);
 	close(random_access);
 	unlink(random_access_name);
-	G_close_cell(mv_fd);
-	G_short_history(output, "raster", &history);
-	G_command_history(&history);
-	G_write_history(output, &history);
+	Rast_close_cell(mv_fd);
+	Rast_short_history(output, "raster", &history);
+	Rast_command_history(&history);
+	Rast_write_history(output, &history);
@@ -315,7 +316,7 @@
     rel_cl = atof(strtok(NULL, "\n"));
     /*finding raster map */
-    if (G_get_cellhd(raster, "", &cellhd) == -1)
+    if (Rast_get_cellhd(raster, "", &cellhd) == -1)
 	G_fatal_error(_("Cannot read raster header file"));
     /*calculating absolute sampling frame definition */
     sf_x = (int)rint(cellhd.cols * rel_x);
@@ -686,10 +687,10 @@
     file_buf = malloc(cols * sizeof(double));
     lseek(random_access, 0, SEEK_SET);
-    cell_buf = G_allocate_d_raster_buf();
-    G_set_d_null_value(cell_buf, G_window_cols() + 1);
+    cell_buf = Rast_allocate_d_raster_buf();
+    Rast_set_d_null_value(cell_buf, G_window_cols() + 1);
     for (i = 0; i < g->sf_y + ((int)g->rl / 2); i++) {
-	G_put_raster_row(mv_fd, cell_buf, DCELL_TYPE);
+	Rast_put_raster_row(mv_fd, cell_buf, DCELL_TYPE);
     for (i = 0; i < rows; i++) {
 	letti = read(random_access, file_buf, (cols * sizeof(double)));
@@ -698,10 +699,10 @@
 	for (j = 0; j < cols; j++) {
 	    cell_buf[j + center] = file_buf[j];
     for (i = 0; i < G_window_rows() - g->sf_y - g->rows; i++)
     return 1;
Modified: grass/trunk/raster/r.li/r.li.daemon/daemon.h
--- grass/trunk/raster/r.li/r.li.daemon/daemon.h	2009-06-20 21:39:23 UTC (rev 38002)
+++ grass/trunk/raster/r.li/r.li.daemon/daemon.h	2009-06-20 22:03:23 UTC (rev 38003)
@@ -18,6 +18,7 @@
 #include "list.h"
Modified: grass/trunk/raster/r.li/r.li.daemon/ipc.c
--- grass/trunk/raster/r.li/r.li.daemon/ipc.c	2009-06-20 21:39:23 UTC (rev 38002)
+++ grass/trunk/raster/r.li/r.li.daemon/ipc.c	2009-06-20 22:03:23 UTC (rev 38003)
@@ -19,6 +19,7 @@
 #include <unistd.h>
 #include "ipc.h"
Modified: grass/trunk/raster/r.li/r.li.daemon/list.c
--- grass/trunk/raster/r.li/r.li.daemon/list.c	2009-06-20 21:39:23 UTC (rev 38002)
+++ grass/trunk/raster/r.li/r.li.daemon/list.c	2009-06-20 22:03:23 UTC (rev 38003)
@@ -16,6 +16,7 @@
 #include <stdlib.h>
 #include "daemon.h"
Modified: grass/trunk/raster/r.li/r.li.daemon/worker.c
--- grass/trunk/raster/r.li/r.li.daemon/worker.c	2009-06-20 21:39:23 UTC (rev 38002)
+++ grass/trunk/raster/r.li/r.li.daemon/worker.c	2009-06-20 22:03:23 UTC (rev 38003)
@@ -30,6 +30,7 @@
 #endif
 #include "daemon.h"
 #include "defs.h"
@@ -58,13 +59,13 @@
     pid = getpid();
     ad = malloc(sizeof(struct area_entry));
     /* open raster map */
-    fd = G_open_cell_old(raster, "");
-    if (G_get_cellhd(raster, "", &hd) == -1) {
+    fd = Rast_open_cell_old(raster, "");
+    if (Rast_get_cellhd(raster, "", &hd) == -1) {
 	G_message(_("CHILD[pid = %i] cannot open raster map"), pid);
 	exit(EXIT_FAILURE);
     /* read data type to allocate cache */
-    data_type = G_raster_map_type(raster, "");
+    data_type = Rast_raster_map_type(raster, "");
     /* calculate rows in cache */
     case CELL_TYPE:{
@@ -160,19 +161,19 @@
 	    case CELL_TYPE:{
 		    for (i = 0; i < (ad->rl - used); i++) {
-			cm->cache[used + i] = G_allocate_cell_buf();
+			cm->cache[used + i] = Rast_allocate_cell_buf();
 		break;
 	    case DCELL_TYPE:{
 		    for (i = 0; i < ad->rl - used; i++) {
-			dm->cache[used + i] = G_allocate_d_raster_buf();
+			dm->cache[used + i] = Rast_allocate_d_raster_buf();
 		break;
 	    case FCELL_TYPE:{
-			fm->cache[used + i] = G_allocate_f_raster_buf();
+			fm->cache[used + i] = Rast_allocate_f_raster_buf();
 		break;
@@ -209,7 +210,7 @@
 	receive(rec_ch, &toReceive);
     /* close raster map */
-    G_close_cell(fd);
     /* close channels */
     close(rec_ch);
@@ -228,24 +229,24 @@
     buf = malloc(cl * sizeof(int));
     /* open raster */
-    if (G_get_cellhd(raster, "", &cell) == -1)
+    if (Rast_get_cellhd(raster, "", &cell) == -1)
 	return NULL;
     /* open raster */
-    if (G_get_cellhd(mask, "", &oldcell) == -1)
+    if (Rast_get_cellhd(mask, "", &oldcell) == -1)
 	return NULL;
     add_row = 1.0 * oldcell.rows / rl;
     add_col = 1.0 * oldcell.cols / cl;
     tmp_file = G_tempfile();
     mask_fd = open(tmp_file, O_RDWR | O_CREAT, 0755);
-    old_fd = G_open_cell_old(mask, "");
-    old = G_allocate_cell_buf();
+    old_fd = Rast_open_cell_old(mask, "");
+    old = Rast_allocate_cell_buf();
     for (i = 0; i < rl; i++) {
 	int riga;
 	riga = (int)rint(i * add_row);
-	G_get_map_row_nomask(old_fd, old, riga);
+	Rast_get_map_row_nomask(old_fd, old, riga);
 	for (j = 0; j < cl; j++) {
 	    int colonna;
@@ -267,7 +268,7 @@
     if (ad->cm->contents[hash] == row)
 	return ad->cm->cache[hash];
     else {
-	G_get_raster_row(fd, ad->cm->cache[hash], row, CELL_TYPE);
+	Rast_get_raster_row(fd, ad->cm->cache[hash], row, CELL_TYPE);
 	ad->cm->contents[hash] = row;
@@ -282,7 +283,7 @@
     if (ad->dm->contents[hash] == row)
 	return ad->dm->cache[hash];
     else {
-	G_get_raster_row(fd, ad->dm->cache[hash], row, DCELL_TYPE);
+	Rast_get_raster_row(fd, ad->dm->cache[hash], row, DCELL_TYPE);
 	ad->dm->contents[hash] = row;
@@ -297,7 +298,7 @@
     if (ad->fm->contents[hash] == row)
 	return ad->fm->cache[hash];
     else {
-	G_get_raster_row(fd, ad->fm->cache[hash], row, FCELL_TYPE);
+	Rast_get_raster_row(fd, ad->fm->cache[hash], row, FCELL_TYPE);
 	ad->fm->contents[hash] = row;
Modified: grass/trunk/raster/r.li/r.li.dominance/dominance.c
--- grass/trunk/raster/r.li/r.li.dominance/dominance.c	2009-06-20 21:39:23 UTC (rev 38002)
+++ grass/trunk/raster/r.li/r.li.dominance/dominance.c	2009-06-20 22:03:23 UTC (rev 38003)
@@ -12,6 +12,7 @@
 #include <stdlib.h>
@@ -72,7 +73,7 @@
     struct Cell_head hd;
 	return RLI_ERRORE;
@@ -157,7 +158,7 @@
-    G_set_c_null_value(&precCell, 1);
+    Rast_set_c_null_value(&precCell, 1);
     /*for each row */
@@ -178,13 +179,13 @@
 	    corrCell = buf[i + ad->x];
 	    if (masked && mask_buf[i + ad->x] == 0) {
 		area--;
 		a = 1;
-		if (G_is_null_value(&precCell, cc.t)) {
+		if (Rast_is_null_value(&precCell, cc.t)) {
 		    precCell = corrCell;
@@ -368,7 +369,7 @@
-    G_set_d_null_value(&precCell, 1);
+    Rast_set_d_null_value(&precCell, 1);
     /*for each row */
@@ -388,13 +389,13 @@
 		area--;
 		a = 1;
-		if (G_is_null_value(&precCell, DCELL_TYPE)) {
+		if (Rast_is_null_value(&precCell, DCELL_TYPE)) {
 		if (corrCell != precCell) {
@@ -572,7 +573,7 @@
-    G_set_f_null_value(&precCell, 1);
+    Rast_set_f_null_value(&precCell, 1);
     /*for each row */
@@ -592,13 +593,13 @@
 	    area++;
 		area--;
 		a = 1;
-		if (G_is_null_value(&precCell, FCELL_TYPE)) {
+		if (Rast_is_null_value(&precCell, FCELL_TYPE)) {
Modified: grass/trunk/raster/r.li/r.li.edgedensity/edgedensity.c
--- grass/trunk/raster/r.li/r.li.edgedensity/edgedensity.c	2009-06-20 21:39:23 UTC (rev 38002)
+++ grass/trunk/raster/r.li/r.li.edgedensity/edgedensity.c	2009-06-20 22:03:23 UTC (rev 38003)
@@ -11,6 +11,7 @@
 #include <stdlib.h>
@@ -81,7 +82,7 @@
     int ris = -1;
     double indice = 0;
 	return RLI_ERRORE;
@@ -167,13 +168,13 @@
 	masked = TRUE;
 	return RLI_ERRORE;
     for (j = 0; j < ad->rl; j++) {	/* for each raster row */
@@ -188,12 +189,12 @@
 	    buf_inf = RLI_get_cell_raster_row(fd, 1 + j + ad->y, ad);
 	else {
-	    buf_inf = G_allocate_cell_buf();
+	    buf_inf = Rast_allocate_cell_buf();
 	    if (buf_inf == NULL) {
 		G_fatal_error("malloc buf_inf failed");
 		return RLI_ERRORE;
-	    G_set_c_null_value(buf_inf + ad->x, ad->cl);
+	    Rast_set_c_null_value(buf_inf + ad->x, ad->cl);
 	/*read mask if needed */
@@ -219,9 +220,9 @@
-	G_set_c_null_value(&nextCell, 1);
+	Rast_set_c_null_value(&nextCell, 1);
 	    area++;
@@ -229,15 +230,15 @@
 		area--;
 		if ((i + 1) == ad->cl)	/*last cell of the row */
 		else if (masked && mask_corr[i + 1 + ad->x] == 0)
 		else
 		    nextCell = buf_corr[i + 1 + ad->x];
@@ -245,30 +246,30 @@
 		if (masked && mask_inf[i + ad->x] == 0)
-		    G_set_c_null_value(&infCell, 1);
+		    Rast_set_c_null_value(&infCell, 1);
 		else
 		    infCell = buf_inf[i + ad->x];
-		if ((G_is_null_value(&prevCell, CELL_TYPE)) ||
+		if ((Rast_is_null_value(&prevCell, CELL_TYPE)) ||
 		    bordoCorr++;
-		if ((G_is_null_value(&supCell, CELL_TYPE)) ||
+		if ((Rast_is_null_value(&supCell, CELL_TYPE)) ||
 		    bordoCorr++;
-		if ((G_is_null_value(&infCell, CELL_TYPE)) ||
+		if ((Rast_is_null_value(&infCell, CELL_TYPE)) ||
 		    (corrCell != infCell)) {
 		    bordoCorr++;
-		if ((G_is_null_value(&nextCell, CELL_TYPE)) ||
+		if ((Rast_is_null_value(&nextCell, CELL_TYPE)) ||
 		    (corrCell != nextCell)) {
 		    bordoCorr++;
@@ -428,13 +429,13 @@
 	masked = TRUE;
 	return RLI_ERRORE;
@@ -450,13 +451,13 @@
 	    buf_inf = RLI_get_dcell_raster_row(fd, 1 + j + ad->y, ad);
 	else {
-	    buf_inf = G_allocate_d_raster_buf();
+	    buf_inf = Rast_allocate_d_raster_buf();
 		return RLI_ERRORE;
-	    G_set_d_null_value(buf_inf + ad->x, ad->cl);
+	    Rast_set_d_null_value(buf_inf + ad->x, ad->cl);
@@ -483,9 +484,9 @@
-	G_set_d_null_value(&nextCell, 1);
+	Rast_set_d_null_value(&nextCell, 1);
@@ -494,18 +495,18 @@
 		area--;
 		else
@@ -513,30 +514,30 @@
-		    G_set_d_null_value(&infCell, 1);
+		    Rast_set_d_null_value(&infCell, 1);
 		else
-		if ((G_is_null_value(&prevCell, DCELL_TYPE)) ||
+		if ((Rast_is_null_value(&prevCell, DCELL_TYPE)) ||
 		    bordoCorr++;
-		if ((G_is_null_value(&supCell, DCELL_TYPE)) ||
+		if ((Rast_is_null_value(&supCell, DCELL_TYPE)) ||
 		    bordoCorr++;
-		if ((G_is_null_value(&infCell, DCELL_TYPE)) ||
+		if ((Rast_is_null_value(&infCell, DCELL_TYPE)) ||
 		    bordoCorr++;
-		if ((G_is_null_value(&nextCell, DCELL_TYPE)) ||
+		if ((Rast_is_null_value(&nextCell, DCELL_TYPE)) ||
 		    bordoCorr++;
@@ -693,13 +694,13 @@
 	masked = TRUE;
 	return RLI_ERRORE;
@@ -715,13 +716,13 @@
 	    buf_inf = RLI_get_fcell_raster_row(fd, 1 + j + ad->y, ad);
 	else {
-	    buf_inf = G_allocate_f_raster_buf();
+	    buf_inf = Rast_allocate_f_raster_buf();
 	    if (mask_inf == NULL) {
 		G_fatal_error("malloc mask_inf failed");
 		return RLI_ERRORE;
-	    G_set_f_null_value(buf_inf + ad->x, ad->cl);
+	    Rast_set_f_null_value(buf_inf + ad->x, ad->cl);
@@ -748,9 +749,9 @@
-	G_set_f_null_value(&nextCell, 1);
+	Rast_set_f_null_value(&nextCell, 1);
 	    area++;
@@ -758,16 +759,16 @@
 		area--;
 		else
@@ -775,30 +776,30 @@
-		    G_set_f_null_value(&infCell, 1);
+		    Rast_set_f_null_value(&infCell, 1);
 		else
-		if ((G_is_null_value(&prevCell, FCELL_TYPE)) ||
+		if ((Rast_is_null_value(&prevCell, FCELL_TYPE)) ||
 		    bordoCorr++;
-		if ((G_is_null_value(&supCell, FCELL_TYPE)) ||
+		if ((Rast_is_null_value(&supCell, FCELL_TYPE)) ||
 		    bordoCorr++;
-		if ((G_is_null_value(&infCell, FCELL_TYPE)) ||
+		if ((Rast_is_null_value(&infCell, FCELL_TYPE)) ||
 		    bordoCorr++;
-		if ((G_is_null_value(&nextCell, FCELL_TYPE)) ||
+		if ((Rast_is_null_value(&nextCell, FCELL_TYPE)) ||
 		    bordoCorr++;
Modified: grass/trunk/raster/r.li/r.li.mpa/mpa.c
--- grass/trunk/raster/r.li/r.li.mpa/mpa.c	2009-06-20 21:39:23 UTC (rev 38002)
+++ grass/trunk/raster/r.li/r.li.mpa/mpa.c	2009-06-20 22:03:23 UTC (rev 38003)
@@ -13,6 +13,7 @@
 #include <stdlib.h>
@@ -68,7 +69,7 @@
     double indice = 0;
 	return RLI_ERRORE;
@@ -149,10 +150,10 @@
 	for (i = 0; i < ad->cl; i++) {	/*for each cell in the row */
 	    area++;
-		G_set_c_null_value(&buf[i + ad->x], 1);
+		Rast_set_c_null_value(&buf[i + ad->x], 1);
 		area--;
-	    if (!(G_is_null_value(&buf[i + ad->x], CELL_TYPE))) {	/*if it's a cell to consider */
+	    if (!(Rast_is_null_value(&buf[i + ad->x], CELL_TYPE))) {	/*if it's a cell to consider */
 		somma = somma + buf[i + ad->x];
@@ -214,9 +215,9 @@
 	    area++;
 	    if ((masked) && (mask_buf[i + ad->x] == 0)) {
 		area--;
-		G_set_d_null_value(&buf[i + ad->x], 1);
+		Rast_set_d_null_value(&buf[i + ad->x], 1);
-	    if (!(G_is_null_value(&buf[i + ad->x], DCELL_TYPE))) {
+	    if (!(Rast_is_null_value(&buf[i + ad->x], DCELL_TYPE))) {
@@ -280,9 +281,9 @@
 		area--;
-		G_set_f_null_value(&buf[i + ad->x], 1);
+		Rast_set_f_null_value(&buf[i + ad->x], 1);
-	    if (!(G_is_null_value(&buf[i + ad->x], FCELL_TYPE))) {
+	    if (!(Rast_is_null_value(&buf[i + ad->x], FCELL_TYPE))) {
Modified: grass/trunk/raster/r.li/r.li.mps/mps.c
--- grass/trunk/raster/r.li/r.li.mps/mps.c	2009-06-20 21:39:23 UTC (rev 38002)
+++ grass/trunk/raster/r.li/r.li.mps/mps.c	2009-06-20 22:03:23 UTC (rev 38003)
@@ -12,6 +12,7 @@
 #include <stdlib.h>
@@ -69,7 +70,7 @@
     double indice = 0;
 	return RLI_ERRORE;
     switch (ad->data_type) {
@@ -164,19 +165,19 @@
 	return RLI_ERRORE;
 	return RLI_ERRORE;
-    buf = G_allocate_cell_buf();
+    buf = Rast_allocate_cell_buf();
     if (buf == NULL) {
 	G_fatal_error("malloc buf failed");
 	return RLI_ERRORE;
 	mask_patch_sup[i] = 0;
@@ -196,23 +197,23 @@
 		return RLI_ERRORE;
 	    /*valid cell */
 		area++;
 		if (i > 0)
 		    precCell = buf[i - 1 + ad->x];
 		if (j == 0)
-		    G_set_c_null_value(&supCell, 1);
+		    Rast_set_c_null_value(&supCell, 1);
 		else
@@ -534,19 +535,19 @@
 	return RLI_ERRORE;
 	return RLI_ERRORE;
-    buf = G_allocate_d_raster_buf();
+    buf = Rast_allocate_d_raster_buf();
     if (buf == NULL) {
 	return RLI_ERRORE;
@@ -565,22 +566,22 @@
 		return RLI_ERRORE;
 		area++;
 		if (i > 0)
 		if (j == 0)
-		    G_set_d_null_value(&supCell, 1);
+		    Rast_set_d_null_value(&supCell, 1);
 		else
@@ -904,20 +905,20 @@
 	return RLI_ERRORE;
 	return RLI_ERRORE;
-    buf = G_allocate_f_raster_buf();
+    buf = Rast_allocate_f_raster_buf();
     if (buf == NULL) {
 	return RLI_ERRORE;
@@ -936,20 +937,20 @@
 		return RLI_ERRORE;
 	    if (((masked) && (mask_buf[i + ad->x] == 0))) {
 		area++;
 		if (i > 0)
 		if (j == 0)
-		    G_set_f_null_value(&supCell, 1);
+		    Rast_set_f_null_value(&supCell, 1);
 		else
Modified: grass/trunk/raster/r.li/r.li.padcv/padcv.c
--- grass/trunk/raster/r.li/r.li.padcv/padcv.c	2009-06-20 21:39:23 UTC (rev 38002)
+++ grass/trunk/raster/r.li/r.li.padcv/padcv.c	2009-06-20 22:03:23 UTC (rev 38003)
@@ -12,6 +12,7 @@
 #include <stdlib.h>
@@ -57,7 +58,7 @@
     int ris = RLI_OK;
 	return RLI_ERRORE;
@@ -153,19 +154,19 @@
 	G_fatal_error("malloc mask_patch_corr failed");
 	return RLI_ERRORE;
 	return RLI_ERRORE;
     if (buf == NULL)
 	return RLI_ERRORE;
@@ -188,7 +189,7 @@
 		return RLI_ERRORE;
@@ -196,16 +197,16 @@
 		area--;
-	    if (!(G_is_null_value(&corrCell, gc.t)))
+	    if (!(Rast_is_null_value(&corrCell, gc.t)))
 		areaPatch++;
 		if (i > 0)
 		if (j == 0)
 		else
@@ -575,19 +576,19 @@
 	return RLI_ERRORE;
 	return RLI_ERRORE;
     if (buf == NULL)
 	return RLI_ERRORE;
@@ -610,7 +611,7 @@
 		return RLI_ERRORE;
 	    /* for each dcell in the row */
@@ -618,16 +619,16 @@
 		area--;
 		areaPatch++;
 		if (i > 0)
 		if (j == 0)
 		else
@@ -996,19 +997,19 @@
 	return RLI_ERRORE;
 	return RLI_ERRORE;
     if (buf == NULL)
 	return RLI_ERRORE;
@@ -1031,7 +1032,7 @@
 		return RLI_ERRORE;
 	    /* for each fcell in the row */
@@ -1039,16 +1040,16 @@
 		area--;
 		areaPatch++;
 		if (i > 0)
 		if (j == 0)
 		else
Modified: grass/trunk/raster/r.li/r.li.padrange/padrange.c
--- grass/trunk/raster/r.li/r.li.padrange/padrange.c	2009-06-20 21:39:23 UTC (rev 38002)
+++ grass/trunk/raster/r.li/r.li.padrange/padrange.c	2009-06-20 22:03:23 UTC (rev 38003)
@@ -12,6 +12,7 @@
 #include <stdlib.h>
@@ -60,7 +61,7 @@
     int ris = RLI_OK;
 	return RLI_ERRORE;
@@ -161,19 +162,19 @@
 	return RLI_ERRORE;
 	return RLI_ERRORE;
     if (buf == NULL) {
 	return RLI_ERRORE;
-	    if (!(G_is_null_value(&corrCell, gc.t))) {
+	    if (!(Rast_is_null_value(&corrCell, gc.t))) {
 		areaPatch++;
 		if (i > 0)
 		if (j == 0)
 		else
@@ -561,19 +562,19 @@
 	return RLI_ERRORE;
 	return RLI_ERRORE;
     if (buf == NULL)
 	return RLI_ERRORE;
@@ -594,21 +595,21 @@
 		return RLI_ERRORE;
 		areaPatch++;
 		if (i > 0)
 		if (j == 0)
 		else
@@ -953,19 +954,19 @@
 	return RLI_ERRORE;
 	return RLI_ERRORE;
     if (buf == NULL)
 	return RLI_ERRORE;
 	mask_patch_corr[i] = 0;
@@ -988,22 +989,22 @@
 		return RLI_ERRORE;
 		areaPatch++;
 		if (i > 0)
 		if (j == 0)
 		else
Modified: grass/trunk/raster/r.li/r.li.padsd/padsd.c
--- grass/trunk/raster/r.li/r.li.padsd/padsd.c	2009-06-20 21:39:23 UTC (rev 38002)
+++ grass/trunk/raster/r.li/r.li.padsd/padsd.c	2009-06-20 22:03:23 UTC (rev 38003)
@@ -12,6 +12,7 @@
 #include <stdlib.h>
@@ -57,7 +58,7 @@
     int ris = RLI_OK;
 	return RLI_ERRORE;
@@ -152,19 +153,19 @@
 	return RLI_ERRORE;
 	return RLI_ERRORE;
     if (buf == NULL)
 	return RLI_ERRORE;
@@ -187,7 +188,7 @@
 		return RLI_ERRORE;
@@ -195,16 +196,16 @@
 		area--;
 		areaPatch++;
 		if (i > 0)
 		if (j == 0)
 		else
@@ -574,19 +575,19 @@
 	return RLI_ERRORE;
 	return RLI_ERRORE;
     if (buf == NULL)
 	return RLI_ERRORE;
@@ -609,7 +610,7 @@
 		return RLI_ERRORE;
@@ -617,16 +618,16 @@
 		area--;
 		areaPatch++;
 		if (i > 0)
 		if (j == 0)
 		else
@@ -992,19 +993,19 @@
 	return RLI_ERRORE;
 	return RLI_ERRORE;
     if (buf == NULL)
 	return RLI_ERRORE;
@@ -1027,7 +1028,7 @@
 		return RLI_ERRORE;
@@ -1035,16 +1036,16 @@
 		area--;
 		areaPatch++;
 		if (i > 0)
 		if (j == 0)
 		else
Modified: grass/trunk/raster/r.li/r.li.patchdensity/main.c
--- grass/trunk/raster/r.li/r.li.patchdensity/main.c	2009-06-20 21:39:23 UTC (rev 38002)
+++ grass/trunk/raster/r.li/r.li.patchdensity/main.c	2009-06-20 22:03:23 UTC (rev 38003)
@@ -18,6 +18,7 @@
 #include <stdlib.h>
 #include <fcntl.h>
 #include <grass/gis.h>
+#include <grass/Rast.h>
 #include "../r.li.daemon/daemon.h"
@@ -66,10 +67,10 @@
     double EW_DIST1, EW_DIST2, NS_DIST1, NS_DIST2;
     int mask_fd = -1, *mask_buf, *mask_sup, null_count = 0;
-    G_set_c_null_value(&complete_value, 1);
+    Rast_set_c_null_value(&complete_value, 1);
 	return 0;
-    sup = G_allocate_cell_buf();
+    sup = Rast_allocate_cell_buf();
     /* open mask if needed */
     if (ad->mask == 1) {
@@ -114,7 +115,7 @@
 		return 0;
 	    for (k = 0; k < ad->cl; k++) {
 		if (mask_buf[k] == 0) {
-		    G_set_c_null_value(mask_buf + k, 1);
+		    Rast_set_c_null_value(mask_buf + k, 1);
 		    null_count++;
@@ -123,7 +124,7 @@
 	if (complete_line) {
-	    if (!G_is_null_value(&(buf[ad->x]), CELL_TYPE) &&
+	    if (!Rast_is_null_value(&(buf[ad->x]), CELL_TYPE) &&
 		buf[ad->x] != complete_value)
 		count++;
@@ -131,7 +132,7 @@
 		if (buf[j + ad->x] != buf[j + 1 + ad->x]) {
 		    complete_line = 0;
-		    if (!G_is_null_value(&(buf[j + 1 + ad->x]), CELL_TYPE) &&
+		    if (!Rast_is_null_value(&(buf[j + 1 + ad->x]), CELL_TYPE) &&
 			buf[j + 1 + ad->x] != complete_value)
 			count++;
@@ -155,13 +156,13 @@
 		else {
 		    if (connected &&
-			!G_is_null_value(&(buf[j + ad->x]), CELL_TYPE))
+			!Rast_is_null_value(&(buf[j + ad->x]), CELL_TYPE))
 			other_above = 1;
 		if (j < ad->cl - 1 && buf[j + ad->x] != buf[j + 1 + ad->x]) {
 		    complete_line = 0;
 		    if (!connected &&
-			!G_is_null_value(&(buf[j + ad->x]), CELL_TYPE)) {
+			!Rast_is_null_value(&(buf[j + ad->x]), CELL_TYPE)) {
 			count++;
 			connected = 0;
@@ -175,7 +176,7 @@
 	    if (!connected &&
 		sup[ad->cl - 1 + ad->x] != buf[ad->cl - 1 + ad->x]) {
-		if (!G_is_null_value(&(buf[ad->cl - 1 + ad->x]), CELL_TYPE)) {
+		if (!Rast_is_null_value(&(buf[ad->cl - 1 + ad->x]), CELL_TYPE)) {
 		    count++;
 		    complete_line = 0;
Modified: grass/trunk/raster/r.li/r.li.patchnum/main.c
--- grass/trunk/raster/r.li/r.li.patchnum/main.c	2009-06-20 21:39:23 UTC (rev 38002)
+++ grass/trunk/raster/r.li/r.li.patchnum/main.c	2009-06-20 22:03:23 UTC (rev 38003)
@@ -19,6 +19,7 @@
 #include <stdlib.h>
 #include <fcntl.h>
@@ -63,10 +64,10 @@
     CELL complete_value;
 	return 0;
@@ -97,7 +98,7 @@
 		return 0;
 		    null_count++;
@@ -106,7 +107,7 @@
 		count++;
@@ -114,7 +115,7 @@
 		    complete_line = 0;
 			count++;
@@ -138,13 +139,13 @@
 		else {
 		    if (connected &&
 			other_above = 1;
 		    complete_line = 0;
 		    if (!connected &&
 			count++;
 			connected = 0;
@@ -158,7 +159,7 @@
 	    if (!connected &&
 		    count++;
 		    complete_line = 0;
Modified: grass/trunk/raster/r.li/r.li.richness/richness.c
--- grass/trunk/raster/r.li/r.li.richness/richness.c	2009-06-20 21:39:23 UTC (rev 38002)
+++ grass/trunk/raster/r.li/r.li.richness/richness.c	2009-06-20 22:03:23 UTC (rev 38003)
@@ -13,6 +13,7 @@
 #include <stdlib.h>
@@ -67,7 +68,7 @@
     double indice = 0;
 	return RLI_ERRORE;
@@ -140,7 +141,7 @@
 	masked = TRUE;
@@ -156,12 +157,12 @@
-	    if (!(G_is_null_value(&corrCell, uc.t))) {
+	    if (!(Rast_is_null_value(&corrCell, uc.t))) {
 		a = 1;
-		if (G_is_null_value(&precCell, uc.t)) {
+		if (Rast_is_null_value(&precCell, uc.t)) {
@@ -298,7 +299,7 @@
 	masked = TRUE;
 	if (masked) {
@@ -314,13 +315,13 @@
 		a = 1;
@@ -460,7 +461,7 @@
 	masked = TRUE;
@@ -479,12 +480,12 @@
 		a = 1;
Modified: grass/trunk/raster/r.li/r.li.shannon/shannon.c
--- grass/trunk/raster/r.li/r.li.shannon/shannon.c	2009-06-20 21:39:23 UTC (rev 38002)
+++ grass/trunk/raster/r.li/r.li.shannon/shannon.c	2009-06-20 22:03:23 UTC (rev 38003)
@@ -12,6 +12,7 @@
 #include <stdlib.h>
@@ -68,7 +69,7 @@
     double indice = 0;
 	return RLI_ERRORE;
@@ -153,7 +154,7 @@
     /*for each row */
@@ -174,13 +175,13 @@
 		area--;
 		a = 1;
@@ -360,7 +361,7 @@
     /*for each row */
@@ -380,13 +381,13 @@
 		area--;
 		a = 1;
@@ -563,7 +564,7 @@
     /*for each row */
@@ -583,13 +584,13 @@
 	    area++;
 		area--;
 		a = 1;
Modified: grass/trunk/raster/r.li/r.li.shape/main.c
--- grass/trunk/raster/r.li/r.li.shape/main.c	2009-06-20 21:39:23 UTC (rev 38002)
+++ grass/trunk/raster/r.li/r.li.shape/main.c	2009-06-20 22:03:23 UTC (rev 38003)
@@ -20,6 +20,7 @@
 #include <stdlib.h>
 #include <fcntl.h>
@@ -68,8 +69,8 @@
     int i = 0, k = 0;
     int *mask_buf;
 	return 0;
Modified: grass/trunk/raster/r.li/r.li.simpson/simpson.c
--- grass/trunk/raster/r.li/r.li.simpson/simpson.c	2009-06-20 21:39:23 UTC (rev 38002)
+++ grass/trunk/raster/r.li/r.li.simpson/simpson.c	2009-06-20 22:03:23 UTC (rev 38003)
@@ -13,6 +13,7 @@
 #include <stdlib.h>
@@ -67,7 +68,7 @@
     double indice = 0;
 	return RLI_ERRORE;
@@ -149,7 +150,7 @@
 	masked = TRUE;
@@ -166,13 +167,13 @@
 		area--;
 		a = 1;
@@ -338,7 +339,7 @@
 	masked = TRUE;
 	if (masked) {
@@ -355,14 +356,14 @@
 		area--;
 		a = 1;
@@ -527,7 +528,7 @@
 	masked = TRUE;
@@ -547,13 +548,13 @@
 		area--;
 		a = 1;
Modified: grass/trunk/raster/r.los/delete.c
--- grass/trunk/raster/r.los/delete.c	2009-06-20 21:39:23 UTC (rev 38002)
+++ grass/trunk/raster/r.los/delete.c	2009-06-20 22:03:23 UTC (rev 38003)
@@ -11,6 +11,7 @@
 #include <stdlib.h>
 #include <grass/segment.h>
 #include "point.h"
Modified: grass/trunk/raster/r.los/main.c
--- grass/trunk/raster/r.los/main.c	2009-06-20 21:39:23 UTC (rev 38002)
+++ grass/trunk/raster/r.los/main.c	2009-06-20 22:03:23 UTC (rev 38003)
@@ -34,6 +34,7 @@
 #include <math.h>
 #include <fcntl.h>
 #include <grass/gprojects.h>
@@ -179,41 +180,41 @@
     /*  read header info for elevation layer        */
-    if (G_get_cellhd(elev_layer, old_mapset, &cellhd_elev) < 0)
+    if (Rast_get_cellhd(elev_layer, old_mapset, &cellhd_elev) < 0)
 	G_fatal_error(_("[%s]: Cannot read map header"), elev_layer);
     /*  if pattern layer present, read in its header info   */
     if (patt_flag == TRUE) {
-	if (G_get_cellhd(patt_layer, patt_mapset, &cellhd_patt) < 0)
+	if (Rast_get_cellhd(patt_layer, patt_mapset, &cellhd_patt) < 0)
 	    G_fatal_error(_("[%s]: Cannot read map header"), patt_layer);
 	/*  allocate buffer space for row-io to layer           */
-	cell = G_allocate_raster_buf(CELL_TYPE);
+	cell = Rast_allocate_raster_buf(CELL_TYPE);
-    fcell = G_allocate_raster_buf(FCELL_TYPE);
+    fcell = Rast_allocate_raster_buf(FCELL_TYPE);
     /*  find number of rows and columns in elevation map    */
     /*      open elevation overlay file for reading         */
-    old = G_open_cell_old(elev_layer, old_mapset);
+    old = Rast_open_cell_old(elev_layer, old_mapset);
     if (old < 0)
 	G_fatal_error(_("Unable to open raster map <%s>"), elev_layer);
     /*      open cell layer for writing output              */
-    new = G_open_raster_new(out_layer, FCELL_TYPE);
+    new = Rast_open_raster_new(out_layer, FCELL_TYPE);
     if (new < 0)
 	G_fatal_error(_("Unable to create raster map <%s>"), out_layer);
     /* if pattern layer specified, open it for reading      */
-	patt = G_open_cell_old(patt_layer, patt_mapset);
+	patt = Rast_open_cell_old(patt_layer, patt_mapset);
 	if (patt < 0)
 	    G_fatal_error(_("Unable to open raster map <%s>"), patt_layer);
-	if (G_get_raster_map_type(patt) != CELL_TYPE)
+	if (Rast_get_raster_map_type(patt) != CELL_TYPE)
 	    G_fatal_error(_("Pattern map should be a binary 0/1 CELL map"));
@@ -266,7 +267,7 @@
 	patt_fd = open(patt_name, 2);
 	segment_init(&seg_patt, patt_fd, 4);
 	for (row = 0; row < nrows; row++) {
-	    if (G_get_raster_row(patt, cell, row, CELL_TYPE) < 0)
+	    if (Rast_get_raster_row(patt, cell, row, CELL_TYPE) < 0)
 		G_fatal_error(_("Unable to read raster map <%s> row %d"),
 			      patt_layer, row);
 	    segment_put_row(&seg_patt, cell, row);
@@ -274,7 +275,7 @@
-	if (G_get_raster_row(old, fcell, row, FCELL_TYPE) < 0)
+	if (Rast_get_raster_row(old, fcell, row, FCELL_TYPE) < 0)
 			  elev_layer, row);
 	segment_put_row(&seg_in, fcell, row);
@@ -381,8 +382,8 @@
 	for (col = 0; col < ncols; col++)
 	    /* set to NULL if beyond max_dist (0) or blocked view (1) */
 	    if (fcell[col] == 0 || fcell[col] == 1)
-		G_set_null_value(&fcell[col], 1, FCELL_TYPE);
-	if (G_put_raster_row(new, fcell, FCELL_TYPE) < 0)
+		Rast_set_null_value(&fcell[col], 1, FCELL_TYPE);
+	if (Rast_put_raster_row(new, fcell, FCELL_TYPE) < 0)
 	    G_fatal_error(_("Failed writing raster map <%s> row %d"),
 			  out_layer, row);
@@ -397,26 +398,26 @@
     close(out_fd);
     unlink(in_name);		/* remove temp files as well */
     unlink(out_name);
-    G_close_cell(old);
-    G_close_cell(new);
+    Rast_close_cell(old);
+    Rast_close_cell(new);
 	close(patt_fd);
-	G_close_cell(patt);
+	Rast_close_cell(patt);
     /*      create category file for output map             */
-    G_read_cats(out_layer, current_mapset, &cats);
-    G_set_cats_fmt("$1 degree$?s", 1.0, 0.0, 0.0, 0.0, &cats);
-    G_write_cats(out_layer, &cats);
+    Rast_read_cats(out_layer, current_mapset, &cats);
+    Rast_set_cats_fmt("$1 degree$?s", 1.0, 0.0, 0.0, 0.0, &cats);
+    Rast_write_cats(out_layer, &cats);
     sprintf(title, "Line of sight %.2fm above %s", obs_elev, opt3->answer);
-    G_put_cell_title(out_layer, title);
-    G_write_raster_units(out_layer, "degrees");
+    Rast_put_cell_title(out_layer, title);
+    Rast_write_raster_units(out_layer, "degrees");
-    G_short_history(out_layer, "raster", &history);
-    G_write_history(out_layer, &history);
+    Rast_short_history(out_layer, "raster", &history);
+    Rast_write_history(out_layer, &history);
     /* release that last tiny bit of memory ... */
     if ( DELAYED_DELETE != NULL ) {
Modified: grass/trunk/raster/r.los/make_list.c
--- grass/trunk/raster/r.los/make_list.c	2009-06-20 21:39:23 UTC (rev 38002)
+++ grass/trunk/raster/r.los/make_list.c	2009-06-20 22:03:23 UTC (rev 38003)
@@ -12,6 +12,7 @@
 #include <math.h>
 #include "point.h"
 #include "local_proto.h"
Modified: grass/trunk/raster/r.los/make_point.c
--- grass/trunk/raster/r.los/make_point.c	2009-06-20 21:39:23 UTC (rev 38002)
+++ grass/trunk/raster/r.los/make_point.c	2009-06-20 22:03:23 UTC (rev 38003)
@@ -13,6 +13,7 @@
 #include "point.h"
 /* #define NULL 0  should be (char *0), or just let the compiler fix it. */
Modified: grass/trunk/raster/r.los/mark_pts.c
--- grass/trunk/raster/r.los/mark_pts.c	2009-06-20 21:39:23 UTC (rev 38002)
+++ grass/trunk/raster/r.los/mark_pts.c	2009-06-20 22:03:23 UTC (rev 38003)
@@ -12,6 +12,7 @@
 #include "point.h"
 #define		PT_TO_MARK_X		PT_TO_MARK->x
 #define		PT_TO_MARK_Y		PT_TO_MARK->y
Modified: grass/trunk/raster/r.los/pts_elim.c
--- grass/trunk/raster/r.los/pts_elim.c	2009-06-20 21:39:23 UTC (rev 38002)
+++ grass/trunk/raster/r.los/pts_elim.c	2009-06-20 22:03:23 UTC (rev 38003)
@@ -12,6 +12,7 @@
 #include <math.h>
 #include "point.h"
@@ -113,7 +114,7 @@
 			    row_viewpt - CHECKED_PT_Y,
 			    col_viewpt + CHECKED_PT_X);
-		if (mask == 0 || G_is_null_value(&mask, CELL_TYPE)) {
+		if (mask == 0 || Rast_is_null_value(&mask, CELL_TYPE)) {
 		    head = delete(CHECKED_PT, head, seg_out_p,
 				  row_viewpt, col_viewpt);
 		    goto next_iter;
@@ -200,7 +201,7 @@
 	if (patt_flag == 1) {
 	    segment_get(seg_patt_p, &mask, row_viewpt - BLOCKING_PT_Y,
 			col_viewpt + BLOCKING_PT_X);
 	      /* Commenting out the following fixes a bug in r.los.
 		 In that program the 8 cells around the viewpoint
Modified: grass/trunk/raster/r.los/radians.h
--- grass/trunk/raster/r.los/radians.h	2009-06-20 21:39:23 UTC (rev 38002)
+++ grass/trunk/raster/r.los/radians.h	2009-06-20 22:03:23 UTC (rev 38003)
@@ -10,6 +10,7 @@
 #define		PI		M_PI
 #define		PIBYFOUR 	M_PI_4
Modified: grass/trunk/raster/r.mapcalc/column_shift.c
--- grass/trunk/raster/r.mapcalc/column_shift.c	2009-06-20 21:39:23 UTC (rev 38002)
+++ grass/trunk/raster/r.mapcalc/column_shift.c	2009-06-20 22:03:23 UTC (rev 38003)
@@ -1,5 +1,6 @@
 #include <stdlib.h>
 #include "expression.h"
 #include "globals.h"
Modified: grass/trunk/raster/r.mapcalc/evaluate.c
--- grass/trunk/raster/r.mapcalc/evaluate.c	2009-06-20 21:39:23 UTC (rev 38002)
+++ grass/trunk/raster/r.mapcalc/evaluate.c	2009-06-20 22:03:23 UTC (rev 38003)
@@ -3,6 +3,7 @@
 #include <unistd.h>
 #include "mapcalc.h"
@@ -23,7 +24,7 @@
 static void allocate_buf(expression * e)
-    e->buf = G_malloc(columns * G_raster_size(e->res_type));
+    e->buf = G_malloc(columns * Rast_raster_size(e->res_type));
 static void set_buf(expression * e, void *buf)
Modified: grass/trunk/raster/r.mapcalc/expression.c
--- grass/trunk/raster/r.mapcalc/expression.c	2009-06-20 21:39:23 UTC (rev 38002)
+++ grass/trunk/raster/r.mapcalc/expression.c	2009-06-20 22:03:23 UTC (rev 38003)
@@ -4,6 +4,7 @@
 #include <string.h>
Modified: grass/trunk/raster/r.mapcalc/expression.h
--- grass/trunk/raster/r.mapcalc/expression.h	2009-06-20 21:39:23 UTC (rev 38002)
+++ grass/trunk/raster/r.mapcalc/expression.h	2009-06-20 22:03:23 UTC (rev 38003)
@@ -112,12 +112,12 @@
 extern func_desc func_descs[];
-#define IS_NULL_C(x) (G_is_c_null_value((x)))
-#define IS_NULL_F(x) (G_is_f_null_value((x)))
-#define IS_NULL_D(x) (G_is_d_null_value((x)))
+#define IS_NULL_C(x) (Rast_is_c_null_value((x)))
+#define IS_NULL_F(x) (Rast_is_f_null_value((x)))
+#define IS_NULL_D(x) (Rast_is_d_null_value((x)))
-#define SET_NULL_C(x) (G_set_c_null_value((x),1))
-#define SET_NULL_F(x) (G_set_f_null_value((x),1))
-#define SET_NULL_D(x) (G_set_d_null_value((x),1))
+#define SET_NULL_C(x) (Rast_set_c_null_value((x),1))
+#define SET_NULL_F(x) (Rast_set_f_null_value((x),1))
+#define SET_NULL_D(x) (Rast_set_d_null_value((x),1))
 #endif /* __EXPRESSION_H_ */
Modified: grass/trunk/raster/r.mapcalc/map.c
--- grass/trunk/raster/r.mapcalc/map.c	2009-06-20 21:39:23 UTC (rev 38002)
+++ grass/trunk/raster/r.mapcalc/map.c	2009-06-20 22:03:23 UTC (rev 38003)
@@ -10,6 +10,7 @@
 #endif
 #include <grass/btree.h>
@@ -92,7 +93,7 @@
     sub->valid = G_calloc(cache->nrows, 1);
     sub->buf = G_malloc(cache->nrows * sizeof(void *));
     for (i = 0; i < cache->nrows; i++)
-	sub->buf[i] = G_allocate_raster_buf(data_type);
+	sub->buf[i] = Rast_allocate_raster_buf(data_type);
     cache->sub[data_type] = sub;
@@ -143,7 +144,7 @@
     if (i >= 0 && i < cache->nrows) {
 	if (!sub->valid[i]) {
-	    G_get_raster_row(cache->fd, sub->buf[i], row + i, data_type);
+	    Rast_get_raster_row(cache->fd, sub->buf[i], row + i, data_type);
 	    sub->valid[i] = 1;
 	return sub->buf[i];
@@ -152,7 +153,7 @@
     if (i <= -cache->nrows || i >= cache->nrows * 2 - 1) {
 	memset(sub->valid, 0, cache->nrows);
 	sub->row = i;
-	G_get_raster_row(cache->fd, sub->buf[0], row, data_type);
+	Rast_get_raster_row(cache->fd, sub->buf[0], row, data_type);
 	sub->valid[0] = 1;
 	return sub->buf[0];
@@ -180,7 +181,7 @@
     G__freea(tmp);
     G__freea(vtmp);
-    G_get_raster_row(cache->fd, sub->buf[i], row, data_type);
+    Rast_get_raster_row(cache->fd, sub->buf[i], row, data_type);
     sub->valid[i] = 1;
     return sub->buf[i];
@@ -189,7 +190,7 @@
 static void cache_get(struct row_cache *cache, void *buf, int row, int res_type)
     void *p = cache_get_raw(cache, row, res_type);
-    memcpy(buf, p, columns * G_raster_size(res_type));
+    memcpy(buf, p, columns * Rast_raster_size(res_type));
@@ -201,7 +202,7 @@
 static void init_colors(struct map *m)
-    if (G_read_colors((char *)m->name, (char *)m->mapset, &m->colors) < 0)
+    if (Rast_read_colors((char *)m->name, (char *)m->mapset, &m->colors) < 0)
 	G_fatal_error(_("Unable to read color file for raster map <%s@%s>"),
 		      m->name, m->mapset);
@@ -210,7 +211,7 @@
 static void init_cats(struct map *m)
-    if (G_read_cats((char *)m->name, (char *)m->mapset, &m->cats) < 0)
+    if (Rast_read_cats((char *)m->name, (char *)m->mapset, &m->cats) < 0)
 	G_fatal_error(_("Unable to read category file of raster map <%s@%s>"),
@@ -230,7 +231,7 @@
     unsigned char *set = G__alloca(columns);
     int i;
-    G_lookup_d_raster_colors(rast, red, grn, blu, set, ncols, &m->colors);
+    Rast_lookup_d_raster_colors(rast, red, grn, blu, set, ncols, &m->colors);
     switch (mod) {
     case 'r':
@@ -338,7 +339,7 @@
 	if (!btree_find(btree, &key, &ptr)) {
 	    values = vbuf;
 	    for (i = 0; i < NCATS; i++) {
-		if ((label = G_get_cat((CELL) (i + key), pcats)) == NULL
+		if ((label = Rast_get_cat((CELL) (i + key), pcats)) == NULL
 		    || sscanf(label, "%lf", values) != 1)
 		    SET_NULL_D(values);
 		values++;
@@ -364,7 +365,7 @@
 static void read_row(int fd, void *buf, int row, int res_type)
-    if (G_get_raster_row(fd, buf, row, res_type) < 0)
+    if (Rast_get_raster_row(fd, buf, row, res_type) < 0)
 	G_fatal_error(_("Unable to read raster map row %d"), row);
@@ -428,7 +429,7 @@
     if (m->fd < 0)
 	return;
-    if (G_close_cell(m->fd) < 0)
+    if (Rast_close_cell(m->fd) < 0)
 	G_fatal_error(_("Unable to close raster map <%s@%s>"),
@@ -438,12 +439,12 @@
     if (m->have_cats) {
 	btree_free(&m->btree);
-	G_free_cats(&m->cats);
+	Rast_free_cats(&m->cats);
 	m->have_cats = 0;
     if (m->have_colors) {
-	G_free_colors(&m->colors);
+	Rast_free_colors(&m->colors);
 	m->have_colors = 0;
@@ -465,7 +466,7 @@
     case 'M':
 	tmpname = G_store((char *)name);
 	mapset = G_find_cell2(tmpname, "");
-	result = mapset ? G_raster_map_type(tmpname, mapset) : -1;
+	result = mapset ? Rast_raster_map_type(tmpname, mapset) : -1;
 	G_free(tmpname);
 	return result;
     case '@':
@@ -505,7 +506,7 @@
     if (!mapset)
 	G_fatal_error(_("Raster map <%s> not found"), name);
-    fd = G_open_cell_old(name, mapset);
+    fd = Rast_open_cell_old(name, mapset);
     if (fd < 0)
 	G_fatal_error(_("Unable to open raster map <%s@%s>"), name, mapset);
@@ -570,7 +571,7 @@
     if (use_colors)
 	init_colors(m);
-    m->fd = G_open_cell_old(name, mapset);
+    m->fd = Rast_open_cell_old(name, mapset);
     if (m->fd < 0)
@@ -657,7 +658,7 @@
     int fd;
-    fd = G_open_raster_new((char *)name, res_type);
+    fd = Rast_open_raster_new((char *)name, res_type);
     if (fd < 0)
 	G_fatal_error(_("Unable to create raster map <%s>"), name);
@@ -666,19 +667,19 @@
 void put_map_row(int fd, void *buf, int res_type)
-    if (G_put_raster_row(fd, buf, res_type) < 0)
+    if (Rast_put_raster_row(fd, buf, res_type) < 0)
 	G_fatal_error(_("Failed writing raster map row"));
 void close_output_map(int fd)
-    if (G_close_cell(fd) < 0)
+    if (Rast_close_cell(fd) < 0)
 	G_fatal_error(_("Unable to close raster map"));
 void unopen_output_map(int fd)
-    G_unopen_cell(fd);
+    Rast_unopen_cell(fd);
@@ -688,11 +689,11 @@
     const struct map *m = &maps[idx];
-    if (G_read_cats((char *)m->name, (char *)m->mapset, &cats) < 0)
+    if (Rast_read_cats((char *)m->name, (char *)m->mapset, &cats) < 0)
 	return;
-    G_write_cats((char *)dst, &cats);
-    G_free_cats(&cats);
+    Rast_write_cats((char *)dst, &cats);
+    Rast_free_cats(&cats);
 void copy_colors(const char *dst, int idx)
@@ -700,11 +701,11 @@
     struct Colors colr;
-    if (G_read_colors((char *)m->name, (char *)m->mapset, &colr) <= 0)
+    if (Rast_read_colors((char *)m->name, (char *)m->mapset, &colr) <= 0)
 	return;
-    G_write_colors((char *)dst, G_mapset(), &colr);
-    G_free_colors(&colr);
+    Rast_write_colors((char *)dst, G_mapset(), &colr);
+    Rast_free_colors(&colr);
 void copy_history(const char *dst, int idx)
@@ -712,10 +713,10 @@
     struct History hist;
-    if (G_read_history((char *)m->name, (char *)m->mapset, &hist) < 0)
+    if (Rast_read_history((char *)m->name, (char *)m->mapset, &hist) < 0)
 	return;
-    G_write_history((char *)dst, &hist);
+    Rast_write_history((char *)dst, &hist);
 void create_history(const char *dst, expression * e)
@@ -727,7 +728,7 @@
     int len = strlen(expr);
     int i;
-    G_short_history((char *)dst, "raster", &hist);
+    Rast_short_history((char *)dst, "raster", &hist);
     for (i = 0; i < MAXEDLINES; i++) {
 	int n;
@@ -755,7 +756,7 @@
     hist.edlinecnt = i;
     G_free(expr);
Modified: grass/trunk/raster/r.mapcalc/map3.c
--- grass/trunk/raster/r.mapcalc/map3.c	2009-06-20 21:39:23 UTC (rev 38002)
+++ grass/trunk/raster/r.mapcalc/map3.c	2009-06-20 22:03:23 UTC (rev 38003)
@@ -5,6 +5,7 @@
 #include <unistd.h>
 #include <grass/G3d.h>
@@ -198,7 +199,7 @@
     int i;
     switch (mod) {
     case 'r':
@@ -297,7 +298,7 @@
 	    values = vbuf;
 		    SET_NULL_D(values);
 		values++;
@@ -369,12 +370,12 @@
     if (m->have_cats) {
 	m->have_cats = 0;
 	m->have_colors = 0;
@@ -626,7 +627,7 @@
 	return;
     G3d_writeCats((char *)dst, &cats);
@@ -638,7 +639,7 @@
 	return;
     G3d_writeColors((char *)dst, G_mapset(), &colr);
Modified: grass/trunk/raster/r.mapcalc/mapcalc.h
--- grass/trunk/raster/r.mapcalc/mapcalc.h	2009-06-20 21:39:23 UTC (rev 38002)
+++ grass/trunk/raster/r.mapcalc/mapcalc.h	2009-06-20 22:03:23 UTC (rev 38003)
@@ -8,6 +8,7 @@
 #include <grass/config.h>
Modified: grass/trunk/raster/r.mapcalc/xabs.c
--- grass/trunk/raster/r.mapcalc/xabs.c	2009-06-20 21:39:23 UTC (rev 38002)
+++ grass/trunk/raster/r.mapcalc/xabs.c	2009-06-20 22:03:23 UTC (rev 38003)
@@ -2,6 +2,7 @@
 #include <math.h>
 #include "func_proto.h"
Modified: grass/trunk/raster/r.mapcalc/xacos.c
--- grass/trunk/raster/r.mapcalc/xacos.c	2009-06-20 21:39:23 UTC (rev 38002)
+++ grass/trunk/raster/r.mapcalc/xacos.c	2009-06-20 22:03:23 UTC (rev 38003)
@@ -3,6 +3,7 @@
 #include <math.h>
Modified: grass/trunk/raster/r.mapcalc/xadd.c
--- grass/trunk/raster/r.mapcalc/xadd.c	2009-06-20 21:39:23 UTC (rev 38002)
+++ grass/trunk/raster/r.mapcalc/xadd.c	2009-06-20 22:03:23 UTC (rev 38003)
@@ -1,5 +1,6 @@
Modified: grass/trunk/raster/r.mapcalc/xand.c
--- grass/trunk/raster/r.mapcalc/xand.c	2009-06-20 21:39:23 UTC (rev 38002)
+++ grass/trunk/raster/r.mapcalc/xand.c	2009-06-20 22:03:23 UTC (rev 38003)
@@ -1,5 +1,6 @@
Modified: grass/trunk/raster/r.mapcalc/xand2.c
--- grass/trunk/raster/r.mapcalc/xand2.c	2009-06-20 21:39:23 UTC (rev 38002)
+++ grass/trunk/raster/r.mapcalc/xand2.c	2009-06-20 22:03:23 UTC (rev 38003)
@@ -1,5 +1,6 @@
Modified: grass/trunk/raster/r.mapcalc/xasin.c
--- grass/trunk/raster/r.mapcalc/xasin.c	2009-06-20 21:39:23 UTC (rev 38002)
+++ grass/trunk/raster/r.mapcalc/xasin.c	2009-06-20 22:03:23 UTC (rev 38003)
@@ -3,6 +3,7 @@
 #include <math.h>
Modified: grass/trunk/raster/r.mapcalc/xatan.c
--- grass/trunk/raster/r.mapcalc/xatan.c	2009-06-20 21:39:23 UTC (rev 38002)
+++ grass/trunk/raster/r.mapcalc/xatan.c	2009-06-20 22:03:23 UTC (rev 38003)
@@ -3,6 +3,7 @@
 #include <math.h>
Modified: grass/trunk/raster/r.mapcalc/xbitand.c
--- grass/trunk/raster/r.mapcalc/xbitand.c	2009-06-20 21:39:23 UTC (rev 38002)
+++ grass/trunk/raster/r.mapcalc/xbitand.c	2009-06-20 22:03:23 UTC (rev 38003)
@@ -1,5 +1,6 @@
Modified: grass/trunk/raster/r.mapcalc/xbitnot.c
--- grass/trunk/raster/r.mapcalc/xbitnot.c	2009-06-20 21:39:23 UTC (rev 38002)
+++ grass/trunk/raster/r.mapcalc/xbitnot.c	2009-06-20 22:03:23 UTC (rev 38003)
@@ -1,5 +1,6 @@
Modified: grass/trunk/raster/r.mapcalc/xbitor.c
--- grass/trunk/raster/r.mapcalc/xbitor.c	2009-06-20 21:39:23 UTC (rev 38002)
+++ grass/trunk/raster/r.mapcalc/xbitor.c	2009-06-20 22:03:23 UTC (rev 38003)
@@ -1,5 +1,6 @@
Modified: grass/trunk/raster/r.mapcalc/xbitxor.c
--- grass/trunk/raster/r.mapcalc/xbitxor.c	2009-06-20 21:39:23 UTC (rev 38002)
+++ grass/trunk/raster/r.mapcalc/xbitxor.c	2009-06-20 22:03:23 UTC (rev 38003)
@@ -1,5 +1,6 @@
Modified: grass/trunk/raster/r.mapcalc/xcoor.c
--- grass/trunk/raster/r.mapcalc/xcoor.c	2009-06-20 21:39:23 UTC (rev 38002)
+++ grass/trunk/raster/r.mapcalc/xcoor.c	2009-06-20 22:03:23 UTC (rev 38003)
@@ -1,5 +1,6 @@
 #include "globals2.h"
Modified: grass/trunk/raster/r.mapcalc/xcoor3.c
--- grass/trunk/raster/r.mapcalc/xcoor3.c	2009-06-20 21:39:23 UTC (rev 38002)
+++ grass/trunk/raster/r.mapcalc/xcoor3.c	2009-06-20 22:03:23 UTC (rev 38003)
@@ -1,5 +1,6 @@
 #include "globals3.h"
Modified: grass/trunk/raster/r.mapcalc/xcos.c
--- grass/trunk/raster/r.mapcalc/xcos.c	2009-06-20 21:39:23 UTC (rev 38002)
+++ grass/trunk/raster/r.mapcalc/xcos.c	2009-06-20 22:03:23 UTC (rev 38003)
@@ -2,6 +2,7 @@
 #include <math.h>
Modified: grass/trunk/raster/r.mapcalc/xdiv.c
--- grass/trunk/raster/r.mapcalc/xdiv.c	2009-06-20 21:39:23 UTC (rev 38002)
+++ grass/trunk/raster/r.mapcalc/xdiv.c	2009-06-20 22:03:23 UTC (rev 38003)
@@ -1,5 +1,6 @@
Modified: grass/trunk/raster/r.mapcalc/xdouble.c
--- grass/trunk/raster/r.mapcalc/xdouble.c	2009-06-20 21:39:23 UTC (rev 38002)
+++ grass/trunk/raster/r.mapcalc/xdouble.c	2009-06-20 22:03:23 UTC (rev 38003)
@@ -2,6 +2,7 @@
 #include <stdlib.h>
Modified: grass/trunk/raster/r.mapcalc/xeq.c
--- grass/trunk/raster/r.mapcalc/xeq.c	2009-06-20 21:39:23 UTC (rev 38002)
+++ grass/trunk/raster/r.mapcalc/xeq.c	2009-06-20 22:03:23 UTC (rev 38003)
@@ -1,5 +1,6 @@
Modified: grass/trunk/raster/r.mapcalc/xeval.c
--- grass/trunk/raster/r.mapcalc/xeval.c	2009-06-20 21:39:23 UTC (rev 38002)
+++ grass/trunk/raster/r.mapcalc/xeval.c	2009-06-20 22:03:23 UTC (rev 38003)
@@ -1,5 +1,6 @@
Modified: grass/trunk/raster/r.mapcalc/xexp.c
--- grass/trunk/raster/r.mapcalc/xexp.c	2009-06-20 21:39:23 UTC (rev 38002)
+++ grass/trunk/raster/r.mapcalc/xexp.c	2009-06-20 22:03:23 UTC (rev 38003)
@@ -2,6 +2,7 @@
 #include <math.h>
Modified: grass/trunk/raster/r.mapcalc/xfloat.c
--- grass/trunk/raster/r.mapcalc/xfloat.c	2009-06-20 21:39:23 UTC (rev 38002)
+++ grass/trunk/raster/r.mapcalc/xfloat.c	2009-06-20 22:03:23 UTC (rev 38003)
@@ -2,6 +2,7 @@
 #include <stdlib.h>
Modified: grass/trunk/raster/r.mapcalc/xge.c
--- grass/trunk/raster/r.mapcalc/xge.c	2009-06-20 21:39:23 UTC (rev 38002)
+++ grass/trunk/raster/r.mapcalc/xge.c	2009-06-20 22:03:23 UTC (rev 38003)
@@ -1,5 +1,6 @@
Modified: grass/trunk/raster/r.mapcalc/xgraph.c
--- grass/trunk/raster/r.mapcalc/xgraph.c	2009-06-20 21:39:23 UTC (rev 38002)
+++ grass/trunk/raster/r.mapcalc/xgraph.c	2009-06-20 22:03:23 UTC (rev 38003)
@@ -2,6 +2,7 @@
 #include <stdlib.h>
Modified: grass/trunk/raster/r.mapcalc/xgt.c
--- grass/trunk/raster/r.mapcalc/xgt.c	2009-06-20 21:39:23 UTC (rev 38002)
+++ grass/trunk/raster/r.mapcalc/xgt.c	2009-06-20 22:03:23 UTC (rev 38003)
@@ -1,5 +1,6 @@
Modified: grass/trunk/raster/r.mapcalc/xif.c
--- grass/trunk/raster/r.mapcalc/xif.c	2009-06-20 21:39:23 UTC (rev 38002)
+++ grass/trunk/raster/r.mapcalc/xif.c	2009-06-20 22:03:23 UTC (rev 38003)
@@ -1,5 +1,6 @@
Modified: grass/trunk/raster/r.mapcalc/xint.c
--- grass/trunk/raster/r.mapcalc/xint.c	2009-06-20 21:39:23 UTC (rev 38002)
+++ grass/trunk/raster/r.mapcalc/xint.c	2009-06-20 22:03:23 UTC (rev 38003)
@@ -2,6 +2,7 @@
 #include <stdlib.h>
Modified: grass/trunk/raster/r.mapcalc/xisnull.c
--- grass/trunk/raster/r.mapcalc/xisnull.c	2009-06-20 21:39:23 UTC (rev 38002)
+++ grass/trunk/raster/r.mapcalc/xisnull.c	2009-06-20 22:03:23 UTC (rev 38003)
@@ -1,5 +1,6 @@
Modified: grass/trunk/raster/r.mapcalc/xle.c
--- grass/trunk/raster/r.mapcalc/xle.c	2009-06-20 21:39:23 UTC (rev 38002)
+++ grass/trunk/raster/r.mapcalc/xle.c	2009-06-20 22:03:23 UTC (rev 38003)
@@ -1,5 +1,6 @@
Modified: grass/trunk/raster/r.mapcalc/xlog.c
--- grass/trunk/raster/r.mapcalc/xlog.c	2009-06-20 21:39:23 UTC (rev 38002)
+++ grass/trunk/raster/r.mapcalc/xlog.c	2009-06-20 22:03:23 UTC (rev 38003)
@@ -2,6 +2,7 @@
 #include <math.h>
Modified: grass/trunk/raster/r.mapcalc/xlt.c
--- grass/trunk/raster/r.mapcalc/xlt.c	2009-06-20 21:39:23 UTC (rev 38002)
+++ grass/trunk/raster/r.mapcalc/xlt.c	2009-06-20 22:03:23 UTC (rev 38003)
@@ -1,5 +1,6 @@
Modified: grass/trunk/raster/r.mapcalc/xmax.c
--- grass/trunk/raster/r.mapcalc/xmax.c	2009-06-20 21:39:23 UTC (rev 38002)
+++ grass/trunk/raster/r.mapcalc/xmax.c	2009-06-20 22:03:23 UTC (rev 38003)
@@ -2,6 +2,7 @@
 #include <stdlib.h>
Modified: grass/trunk/raster/r.mapcalc/xmedian.c
--- grass/trunk/raster/r.mapcalc/xmedian.c	2009-06-20 21:39:23 UTC (rev 38002)
+++ grass/trunk/raster/r.mapcalc/xmedian.c	2009-06-20 22:03:23 UTC (rev 38003)
@@ -2,6 +2,7 @@
 #include <stdlib.h>
@@ -47,7 +48,7 @@
     static void *array;
     static int alloc;
-    int size = argc * G_raster_size(argt[0]);
+    int size = argc * Rast_raster_size(argt[0]);
     int i, j;
     if (argc < 1)
Modified: grass/trunk/raster/r.mapcalc/xmin.c
--- grass/trunk/raster/r.mapcalc/xmin.c	2009-06-20 21:39:23 UTC (rev 38002)
+++ grass/trunk/raster/r.mapcalc/xmin.c	2009-06-20 22:03:23 UTC (rev 38003)
@@ -2,6 +2,7 @@
 #include <stdlib.h>
Modified: grass/trunk/raster/r.mapcalc/xmod.c
--- grass/trunk/raster/r.mapcalc/xmod.c	2009-06-20 21:39:23 UTC (rev 38002)
+++ grass/trunk/raster/r.mapcalc/xmod.c	2009-06-20 22:03:23 UTC (rev 38003)
@@ -1,5 +1,6 @@
Modified: grass/trunk/raster/r.mapcalc/xmode.c
--- grass/trunk/raster/r.mapcalc/xmode.c	2009-06-20 21:39:23 UTC (rev 38002)
+++ grass/trunk/raster/r.mapcalc/xmode.c	2009-06-20 22:03:23 UTC (rev 38003)
@@ -2,6 +2,7 @@
 #include <stdlib.h>
Modified: grass/trunk/raster/r.mapcalc/xmul.c
--- grass/trunk/raster/r.mapcalc/xmul.c	2009-06-20 21:39:23 UTC (rev 38002)
+++ grass/trunk/raster/r.mapcalc/xmul.c	2009-06-20 22:03:23 UTC (rev 38003)
@@ -1,5 +1,6 @@
Modified: grass/trunk/raster/r.mapcalc/xne.c
--- grass/trunk/raster/r.mapcalc/xne.c	2009-06-20 21:39:23 UTC (rev 38002)
+++ grass/trunk/raster/r.mapcalc/xne.c	2009-06-20 22:03:23 UTC (rev 38003)
@@ -1,5 +1,6 @@
Modified: grass/trunk/raster/r.mapcalc/xneg.c
--- grass/trunk/raster/r.mapcalc/xneg.c	2009-06-20 21:39:23 UTC (rev 38002)
+++ grass/trunk/raster/r.mapcalc/xneg.c	2009-06-20 22:03:23 UTC (rev 38003)
@@ -1,5 +1,6 @@
Modified: grass/trunk/raster/r.mapcalc/xnot.c
--- grass/trunk/raster/r.mapcalc/xnot.c	2009-06-20 21:39:23 UTC (rev 38002)
+++ grass/trunk/raster/r.mapcalc/xnot.c	2009-06-20 22:03:23 UTC (rev 38003)
@@ -1,5 +1,6 @@
Modified: grass/trunk/raster/r.mapcalc/xnull.c
--- grass/trunk/raster/r.mapcalc/xnull.c	2009-06-20 21:39:23 UTC (rev 38002)
+++ grass/trunk/raster/r.mapcalc/xnull.c	2009-06-20 22:03:23 UTC (rev 38003)
@@ -1,5 +1,6 @@
Modified: grass/trunk/raster/r.mapcalc/xor.c
--- grass/trunk/raster/r.mapcalc/xor.c	2009-06-20 21:39:23 UTC (rev 38002)
+++ grass/trunk/raster/r.mapcalc/xor.c	2009-06-20 22:03:23 UTC (rev 38003)
@@ -1,5 +1,6 @@
Modified: grass/trunk/raster/r.mapcalc/xor2.c
--- grass/trunk/raster/r.mapcalc/xor2.c	2009-06-20 21:39:23 UTC (rev 38002)
+++ grass/trunk/raster/r.mapcalc/xor2.c	2009-06-20 22:03:23 UTC (rev 38003)
@@ -1,5 +1,6 @@
Modified: grass/trunk/raster/r.mapcalc/xpow.c
--- grass/trunk/raster/r.mapcalc/xpow.c	2009-06-20 21:39:23 UTC (rev 38002)
+++ grass/trunk/raster/r.mapcalc/xpow.c	2009-06-20 22:03:23 UTC (rev 38003)
@@ -2,6 +2,7 @@
 #include <math.h>
Modified: grass/trunk/raster/r.mapcalc/xrand.c
--- grass/trunk/raster/r.mapcalc/xrand.c	2009-06-20 21:39:23 UTC (rev 38002)
+++ grass/trunk/raster/r.mapcalc/xrand.c	2009-06-20 22:03:23 UTC (rev 38003)
@@ -3,6 +3,7 @@
Modified: grass/trunk/raster/r.mapcalc/xres.c
--- grass/trunk/raster/r.mapcalc/xres.c	2009-06-20 21:39:23 UTC (rev 38002)
+++ grass/trunk/raster/r.mapcalc/xres.c	2009-06-20 22:03:23 UTC (rev 38003)
@@ -1,5 +1,6 @@
Modified: grass/trunk/raster/r.mapcalc/xres3.c
--- grass/trunk/raster/r.mapcalc/xres3.c	2009-06-20 21:39:23 UTC (rev 38002)
+++ grass/trunk/raster/r.mapcalc/xres3.c	2009-06-20 22:03:23 UTC (rev 38003)
@@ -1,5 +1,6 @@
Modified: grass/trunk/raster/r.mapcalc/xround.c
--- grass/trunk/raster/r.mapcalc/xround.c	2009-06-20 21:39:23 UTC (rev 38002)
+++ grass/trunk/raster/r.mapcalc/xround.c	2009-06-20 22:03:23 UTC (rev 38003)
@@ -2,6 +2,7 @@
 #include <limits.h>
Modified: grass/trunk/raster/r.mapcalc/xrowcol.c
--- grass/trunk/raster/r.mapcalc/xrowcol.c	2009-06-20 21:39:23 UTC (rev 38002)
+++ grass/trunk/raster/r.mapcalc/xrowcol.c	2009-06-20 22:03:23 UTC (rev 38003)
@@ -1,5 +1,6 @@
Modified: grass/trunk/raster/r.mapcalc/xshiftl.c
--- grass/trunk/raster/r.mapcalc/xshiftl.c	2009-06-20 21:39:23 UTC (rev 38002)
+++ grass/trunk/raster/r.mapcalc/xshiftl.c	2009-06-20 22:03:23 UTC (rev 38003)
@@ -1,5 +1,6 @@
Modified: grass/trunk/raster/r.mapcalc/xshiftr.c
--- grass/trunk/raster/r.mapcalc/xshiftr.c	2009-06-20 21:39:23 UTC (rev 38002)
+++ grass/trunk/raster/r.mapcalc/xshiftr.c	2009-06-20 22:03:23 UTC (rev 38003)
@@ -1,5 +1,6 @@
Modified: grass/trunk/raster/r.mapcalc/xshiftru.c
--- grass/trunk/raster/r.mapcalc/xshiftru.c	2009-06-20 21:39:23 UTC (rev 38002)
+++ grass/trunk/raster/r.mapcalc/xshiftru.c	2009-06-20 22:03:23 UTC (rev 38003)
@@ -1,5 +1,6 @@
Modified: grass/trunk/raster/r.mapcalc/xsin.c
--- grass/trunk/raster/r.mapcalc/xsin.c	2009-06-20 21:39:23 UTC (rev 38002)
+++ grass/trunk/raster/r.mapcalc/xsin.c	2009-06-20 22:03:23 UTC (rev 38003)
@@ -2,6 +2,7 @@
 #include <math.h>
Modified: grass/trunk/raster/r.mapcalc/xsqrt.c
--- grass/trunk/raster/r.mapcalc/xsqrt.c	2009-06-20 21:39:23 UTC (rev 38002)
+++ grass/trunk/raster/r.mapcalc/xsqrt.c	2009-06-20 22:03:23 UTC (rev 38003)
@@ -2,6 +2,7 @@
 #include <math.h>
Modified: grass/trunk/raster/r.mapcalc/xsub.c
--- grass/trunk/raster/r.mapcalc/xsub.c	2009-06-20 21:39:23 UTC (rev 38002)
+++ grass/trunk/raster/r.mapcalc/xsub.c	2009-06-20 22:03:23 UTC (rev 38003)
@@ -1,5 +1,6 @@
Modified: grass/trunk/raster/r.mapcalc/xtan.c
--- grass/trunk/raster/r.mapcalc/xtan.c	2009-06-20 21:39:23 UTC (rev 38002)
+++ grass/trunk/raster/r.mapcalc/xtan.c	2009-06-20 22:03:23 UTC (rev 38003)
@@ -3,6 +3,7 @@
 #include <math.h>
Modified: grass/trunk/raster/r.mfilter/apply.c
--- grass/trunk/raster/r.mfilter/apply.c	2009-06-20 21:39:23 UTC (rev 38002)
+++ grass/trunk/raster/r.mfilter/apply.c	2009-06-20 22:03:23 UTC (rev 38003)
@@ -21,7 +21,7 @@
 	for (r = 0; r < size; r++)
 	    for (c = 0; c < size; c++) {
-		if (G_is_d_null_value(&input[r][c]))
+		if (Rast_is_d_null_value(&input[r][c]))
 		    continue;
 		v += input[r][c] * matrix[r][c];
 		divisor += filter->dmatrix[r][c];
@@ -31,13 +31,13 @@
 	if (have_result)
 	    v /= divisor;
 	else
-	    G_set_d_null_value(&v, 1);
+	    Rast_set_d_null_value(&v, 1);
     else {
-		if (G_is_d_null_value(&input[r][c])) {
+		if (Rast_is_d_null_value(&input[r][c])) {
 		    return v;
Modified: grass/trunk/raster/r.mfilter/execute.c
--- grass/trunk/raster/r.mfilter/execute.c	2009-06-20 21:39:23 UTC (rev 38002)
+++ grass/trunk/raster/r.mfilter/execute.c	2009-06-20 22:03:23 UTC (rev 38003)
@@ -87,7 +87,7 @@
 	col = ccount;
 	while (col--) {
 	    if (null_only) {
-		if (G_is_d_null_value(&box[mid][mid]))
+		if (Rast_is_d_null_value(&box[mid][mid]))
 		    *cp++ = apply_filter(filter, box);
 		else
 		    *cp++ = box[mid][mid];
Modified: grass/trunk/raster/r.mfilter/filter.h
--- grass/trunk/raster/r.mfilter/filter.h	2009-06-20 21:39:23 UTC (rev 38002)
+++ grass/trunk/raster/r.mfilter/filter.h	2009-06-20 22:03:23 UTC (rev 38003)
@@ -1,4 +1,5 @@
 #include <grass/rowio.h>
 typedef struct
Modified: grass/trunk/raster/r.mfilter/getrow.c
--- grass/trunk/raster/r.mfilter/getrow.c	2009-06-20 21:39:23 UTC (rev 38002)
+++ grass/trunk/raster/r.mfilter/getrow.c	2009-06-20 22:03:23 UTC (rev 38003)
@@ -2,13 +2,14 @@
 #include <unistd.h>
 #include <sys/types.h>
 #include "glob.h"
 int getmaprow(int fd, void *buf, int row, int len)
-    if (G_get_d_raster_row(fd, (DCELL *) buf, row) < 0)
+    if (Rast_get_d_raster_row(fd, (DCELL *) buf, row) < 0)
 	G_fatal_error(_("Cannot read raster row %d"), row);
     return 1;
Modified: grass/trunk/raster/r.mfilter/main.c
--- grass/trunk/raster/r.mfilter/main.c	2009-06-20 21:39:23 UTC (rev 38002)
+++ grass/trunk/raster/r.mfilter/main.c	2009-06-20 22:03:23 UTC (rev 38003)
@@ -19,6 +19,7 @@
 #include <string.h>
 #include <stdio.h>
 #include "filter.h"
@@ -131,7 +132,7 @@
     perform_filter(in_name, out_name, filter, nfilters, repeat);
-    G_put_cell_title(out_name, title);
+    Rast_put_cell_title(out_name, title);
     exit(EXIT_SUCCESS);
Modified: grass/trunk/raster/r.mfilter/perform.c
--- grass/trunk/raster/r.mfilter/perform.c	2009-06-20 21:39:23 UTC (rev 38002)
+++ grass/trunk/raster/r.mfilter/perform.c	2009-06-20 22:03:23 UTC (rev 38003)
@@ -20,7 +20,7 @@
     DCELL *cell;
-    cell = G_allocate_d_raster_buf();
+    cell = Rast_allocate_d_raster_buf();
     count = 0;
     for (pass = 0; pass < repeat; pass++) {
@@ -29,7 +29,7 @@
 	    G_debug(1, "Filter %d", n + 1);
 	    if (count == 0) {
-		in = G_open_cell_old(in_name, "");
+		in = Rast_open_cell_old(in_name, "");
 		G_debug(1, "Open raster map %s = %d", in_name, in);
@@ -45,7 +45,7 @@
 		G_debug(1, "Closing raster map");
-		G_close_cell(in);
+		Rast_close_cell(in);
 		in = out;
 		close(creat(tmp2 = G_tempfile(), 0666));
 		out = open(tmp2, 2);
@@ -72,13 +72,13 @@
     if (count == 1)
-	G_close_cell(in);
     else if (count > 1)
 	close(in);
     /* copy final result to output raster map */
     in = out;
-    out = G_open_fp_cell_new(out_name);
+    out = Rast_open_fp_cell_new(out_name);
     if (out < 0) {
 	G_fatal_error(_("Cannot create raster map <%s>"), out_name);
@@ -86,17 +86,17 @@
     G_message(_("Writing raster map <%s>"), out_name);
 	getrow(in, cell, row, buflen);
-	G_put_d_raster_row(out, cell);
+	Rast_put_d_raster_row(out, cell);
-    /* remove the temporary files before closing so that the G_close_cell()
+    /* remove the temporary files before closing so that the Rast_close_cell()
        has more disk to work with
     if (count > 0)
 	unlink(tmp1);
     if (count > 1)
 	unlink(tmp2);
-    G_close_cell(out);
+    Rast_close_cell(out);
     return 0;
Modified: grass/trunk/raster/r.mode/main.c
--- grass/trunk/raster/r.mode/main.c	2009-06-20 21:39:23 UTC (rev 38002)
+++ grass/trunk/raster/r.mode/main.c	2009-06-20 22:03:23 UTC (rev 38003)
@@ -24,6 +24,7 @@
 #include <unistd.h>
 #include <string.h>
@@ -81,7 +82,7 @@
     covermap = parm.cover->answer;
     outmap = parm.output->answer;
-    if (G_read_cats(covermap, "", &cover_cats) < 0) {
+    if (Rast_read_cats(covermap, "", &cover_cats) < 0) {
 	G_fatal_error(_("%s: Unable to read category labels"), covermap);
@@ -104,7 +105,7 @@
 	    max = value;
 	if (basecat != catb) {
-	    write_reclass(reclass, catb, catc, G_get_cat(catc, &cover_cats));
+	    write_reclass(reclass, catb, catc, Rast_get_cat(catc, &cover_cats));
 	    catb = basecat;
 	    catc = covercat;
 	    max = value;
@@ -117,7 +118,7 @@
     if (first) {
 	catb = catc = 0;
     pclose(stats);
     pclose(reclass);
Modified: grass/trunk/raster/r.mode/read_stats.c
--- grass/trunk/raster/r.mode/read_stats.c	2009-06-20 21:39:23 UTC (rev 38002)
+++ grass/trunk/raster/r.mode/read_stats.c	2009-06-20 22:03:23 UTC (rev 38003)
@@ -1,6 +1,7 @@
 #include <stdlib.h>
 #include <stdio.h>
 int read_stats(FILE * fd, long *cat1, long *cat2, double *value)
Modified: grass/trunk/raster/r.neighbors/bufs.c
--- grass/trunk/raster/r.neighbors/bufs.c	2009-06-20 21:39:23 UTC (rev 38002)
+++ grass/trunk/raster/r.neighbors/bufs.c	2009-06-20 22:03:23 UTC (rev 38003)
@@ -1,4 +1,5 @@
 #include "ncb.h"
@@ -19,7 +20,7 @@
     ncb.buf = (DCELL **) G_malloc(ncb.nsize * sizeof(DCELL *));
     for (i = 0; i < ncb.nsize; i++) {
 	ncb.buf[i] = (DCELL *) G_malloc(bufsize);
-	G_set_d_null_value(ncb.buf[i], G_window_cols() + 2 * ncb.nsize);
+	Rast_set_d_null_value(ncb.buf[i], G_window_cols() + 2 * ncb.nsize);
     return 0;
Modified: grass/trunk/raster/r.neighbors/divr_cats.c
--- grass/trunk/raster/r.neighbors/divr_cats.c	2009-06-20 21:39:23 UTC (rev 38002)
+++ grass/trunk/raster/r.neighbors/divr_cats.c	2009-06-20 22:03:23 UTC (rev 38003)
@@ -1,8 +1,9 @@
 #include "ncb.h"
 int divr_cats(void)
-    G_set_cats_fmt("$1 $?different categories$category$", 1.0, 0.0, 0.0, 0.0,
+    Rast_set_cats_fmt("$1 $?different categories$category$", 1.0, 0.0, 0.0, 0.0,
 		   &ncb.cats);
     return 0;
Modified: grass/trunk/raster/r.neighbors/gather.c
--- grass/trunk/raster/r.neighbors/gather.c	2009-06-20 21:39:23 UTC (rev 38002)
+++ grass/trunk/raster/r.neighbors/gather.c	2009-06-20 22:03:23 UTC (rev 38003)
@@ -1,4 +1,5 @@
 #include "ncb.h"
@@ -58,8 +59,8 @@
 	    if (ncb.mask && !ncb.mask[row][col])
 		continue;
-	    if (G_is_d_null_value(c))
-		G_set_d_null_value(&values[n], 1);
+	    if (Rast_is_d_null_value(c))
+		Rast_set_d_null_value(&values[n], 1);
 	    else
 		values[n] = *c;
@@ -81,8 +82,8 @@
 	for (col = 0; col < ncb.nsize; col++) {
 	    DCELL *c = &ncb.buf[row][offset + col];
-		G_set_d_null_value(&values[n][0], 1);
+		Rast_set_d_null_value(&values[n][0], 1);
 	    else
 		values[n][0] = *c;
Modified: grass/trunk/raster/r.neighbors/intr_cats.c
--- grass/trunk/raster/r.neighbors/intr_cats.c	2009-06-20 21:39:23 UTC (rev 38002)
+++ grass/trunk/raster/r.neighbors/intr_cats.c	2009-06-20 22:03:23 UTC (rev 38003)
@@ -1,9 +1,10 @@
 #include "ncb.h"
 int intr_cats(void)
-    G_set_cats_fmt("$1% dispersion", 1.0, -1.0, 0.0, 0.0, &ncb.cats);
+    Rast_set_cats_fmt("$1% dispersion", 1.0, -1.0, 0.0, 0.0, &ncb.cats);
     return 0;
Modified: grass/trunk/raster/r.neighbors/main.c
--- grass/trunk/raster/r.neighbors/main.c	2009-06-20 21:39:23 UTC (rev 38002)
+++ grass/trunk/raster/r.neighbors/main.c	2009-06-20 22:03:23 UTC (rev 38003)
@@ -22,6 +22,7 @@
 #include <stdlib.h>
 #include <unistd.h>
 #include <grass/glocale.h>
 #include <grass/stats.h>
 #include "ncb.h"
@@ -203,7 +204,7 @@
     ncb.newcell = parm.output->answer;
     if (!flag.align->answer) {
-	if (G_get_cellhd(ncb.oldcell, "", &cellhd) < 0)
+	if (Rast_get_cellhd(ncb.oldcell, "", &cellhd) < 0)
 	    exit(EXIT_FAILURE);
 	G_get_window(&window);
 	G_align_window(&window, &cellhd);
@@ -214,11 +215,11 @@
     ncols = G_window_cols();
     /* open raster maps */
-    if ((in_fd = G_open_cell_old(ncb.oldcell, "")) < 0)
+    if ((in_fd = Rast_open_cell_old(ncb.oldcell, "")) < 0)
 		      ncb.oldcell);
-    map_type = G_get_raster_map_type(in_fd);
+    map_type = Rast_get_raster_map_type(in_fd);
     /* get the method */
     for (method = 0; (p = menu[method].name); method++)
@@ -247,7 +248,7 @@
     if (copycolr) {
 	G_suppress_warnings(1);
 	copycolr =
-	    (G_read_colors(ncb.oldcell, "", &colr) > 0);
+	    (Rast_read_colors(ncb.oldcell, "", &colr) > 0);
 	G_suppress_warnings(0);
@@ -267,7 +268,7 @@
     /* allocate the cell buffers */
     allocate_bufs();
-    result = G_allocate_d_raster_buf();
+    result = Rast_allocate_d_raster_buf();
     /* get title, initialize the category and stat info */
     if (parm.title->answer)
@@ -284,12 +285,12 @@
 	readcell(in_fd, readrow++, nrows, ncols);
-    in_fd = G_open_cell_old(ncb.oldcell, "");
+    in_fd = Rast_open_cell_old(ncb.oldcell, "");
     if (in_fd < 0)
 	exit(EXIT_FAILURE);
     /*open the new raster map */
-    out_fd = G_open_raster_new(ncb.newcell, map_type);
+    out_fd = Rast_open_raster_new(ncb.newcell, map_type);
     if (out_fd < 0)
 	exit(EXIT_FAILURE);
@@ -314,37 +315,37 @@
 		n = gather(values, col);
 	    if (n < 0)
-		G_set_d_null_value(rp, 1);
+		Rast_set_d_null_value(rp, 1);
 	    else {
 		if (newvalue_w)
 		    newvalue_w(rp, values_w, n, closure);
 		else
 		    newvalue(rp, values, n, closure);
-		if (half && !G_is_d_null_value(rp))
+		if (half && !Rast_is_d_null_value(rp))
 		    *rp += 0.5;
-	G_put_d_raster_row(out_fd, result);
+	Rast_put_d_raster_row(out_fd, result);
     G_percent(row, nrows, 2);
-    G_close_cell(out_fd);
-    G_close_cell(in_fd);
+    Rast_close_cell(out_fd);
+    Rast_close_cell(in_fd);
     /* put out category info */
     null_cats();
     if ((cat_names = menu[method].cat_names))
 	cat_names();
-    G_write_cats(ncb.newcell, &ncb.cats);
+    Rast_write_cats(ncb.newcell, &ncb.cats);
     if (copycolr)
-	G_write_colors(ncb.newcell, G_mapset(), &colr);
+	Rast_write_colors(ncb.newcell, G_mapset(), &colr);
-    G_short_history(ncb.newcell, "raster", &history);
-    G_write_history(ncb.newcell, &history);
+    Rast_short_history(ncb.newcell, "raster", &history);
+    Rast_write_history(ncb.newcell, &history);
     exit(EXIT_SUCCESS);
Modified: grass/trunk/raster/r.neighbors/null_cats.c
--- grass/trunk/raster/r.neighbors/null_cats.c	2009-06-20 21:39:23 UTC (rev 38002)
+++ grass/trunk/raster/r.neighbors/null_cats.c	2009-06-20 22:03:23 UTC (rev 38003)
@@ -1,12 +1,13 @@
 #include "ncb.h"
 int null_cats(void)
     int ncats;
-    ncats = G_number_of_cats(ncb.newcell, G_mapset());
-    G_init_cats(ncats, ncb.title, &ncb.cats);
+    ncats = Rast_number_of_cats(ncb.newcell, G_mapset());
+    Rast_init_cats(ncats, ncb.title, &ncb.cats);
     return 0;
Modified: grass/trunk/raster/r.neighbors/readcell.c
--- grass/trunk/raster/r.neighbors/readcell.c	2009-06-20 21:39:23 UTC (rev 38002)
+++ grass/trunk/raster/r.neighbors/readcell.c	2009-06-20 22:03:23 UTC (rev 38003)
@@ -1,5 +1,6 @@
 #include <unistd.h>
 #include "ncb.h"
@@ -8,9 +9,9 @@
     rotate_bufs();
     if (row < nrows)
-	G_get_d_raster_row(fd, ncb.buf[ncb.nsize - 1] + ncb.dist, row);
+	Rast_get_d_raster_row(fd, ncb.buf[ncb.nsize - 1] + ncb.dist, row);
     else
-	G_set_d_null_value(ncb.buf[ncb.nsize - 1] + ncb.dist, ncols);
+	Rast_set_d_null_value(ncb.buf[ncb.nsize - 1] + ncb.dist, ncols);
     return 0;
Modified: grass/trunk/raster/r.neighbors/readweights.c
--- grass/trunk/raster/r.neighbors/readweights.c	2009-06-20 21:39:23 UTC (rev 38002)
+++ grass/trunk/raster/r.neighbors/readweights.c	2009-06-20 22:03:23 UTC (rev 38003)
@@ -1,6 +1,7 @@
 #include <stdio.h>
 #include <math.h>
 #include "ncb.h"
Modified: grass/trunk/raster/r.null/main.c
--- grass/trunk/raster/r.null/main.c	2009-06-20 21:39:23 UTC (rev 38002)
+++ grass/trunk/raster/r.null/main.c	2009-06-20 22:03:23 UTC (rev 38003)
@@ -15,6 +15,7 @@
 #include <string.h>
 #include <unistd.h>
 #include "mask.h"
@@ -112,7 +113,7 @@
     if (mapset == NULL)
-    is_reclass = (G_is_reclass(name, mapset, rname, rmapset) > 0);
+    is_reclass = (Rast_is_reclass(name, mapset, rname, rmapset) > 0);
     if (is_reclass)
 	G_fatal_error(_("Raster map <%s> is a reclass of map <%s@%s>. "
 			"Consider to generate a copy with r.mapcalc. Exiting."),
@@ -131,7 +132,7 @@
 			  parms.null->answer);
-    map_type = G_raster_map_type(name, mapset);
+    map_type = Rast_raster_map_type(name, mapset);
     if (only_null && G_find_file2_misc("cell_misc", "null", name, mapset))
 	G_fatal_error(_("Raster map <%s> already has a null bitmap file"), name);
@@ -153,15 +154,15 @@
     parse_vallist(parms.setnull->answers, &d_mask);
-    if (G_get_cellhd(name, mapset, &cellhd) < 0)
+    if (Rast_get_cellhd(name, mapset, &cellhd) < 0)
 	G_fatal_error(_("Unable to read header of raster map <%s>"),
 		      G_fully_qualified_name(name, mapset));
     if (create) {
 	/* write a file of no-nulls */
-	null_bits = (unsigned char *)G__allocate_null_bits(cellhd.cols);
+	null_bits = (unsigned char *)Rast__allocate_null_bits(cellhd.cols);
 	/* init all cells to 0's */
-	for (col = 0; col < G__null_bitstream_size(cellhd.cols); col++)
+	for (col = 0; col < Rast__null_bitstream_size(cellhd.cols); col++)
 	    null_bits[col] = 0;
 	null_fd = G_open_new_misc("cell_misc", "null", name);
@@ -171,7 +172,7 @@
 	for (row = 0; row < cellhd.rows; row++) {
 	    G_percent(row, cellhd.rows, 1);
-	    if (G__write_null_bits(null_fd, null_bits, row, cellhd.cols, 0) <
+	    if (Rast__write_null_bits(null_fd, null_bits, row, cellhd.cols, 0) <
 		0)
 		G_fatal_error(_("Error writing null row %d"), row);
@@ -275,13 +276,13 @@
     int quant_ok;
-    colr_ok = G_read_colors(name, mapset, &colr) > 0;
-    hist_ok = G_read_history(name, mapset, &hist) >= 0;
-    cats_ok = G_read_raster_cats(name, mapset, &cats) >= 0;
+    colr_ok = Rast_read_colors(name, mapset, &colr) > 0;
+    hist_ok = Rast_read_history(name, mapset, &hist) >= 0;
+    cats_ok = Rast_read_raster_cats(name, mapset, &cats) >= 0;
     if (map_type != CELL_TYPE) {
-	G_quant_init(&quant);
-	quant_ok = G_read_quant(name, mapset, &quant);
+	Rast_quant_init(&quant);
+	quant_ok = Rast_read_quant(name, mapset, &quant);
@@ -289,18 +290,18 @@
 	return 1;
     if (colr_ok) {
-	G_write_colors(name, mapset, &colr);
+	Rast_write_colors(name, mapset, &colr);
     if (hist_ok)
-	G_write_history(name, &hist);
+	Rast_write_history(name, &hist);
     if (cats_ok) {
-	cats.num = G_number_of_cats(name, mapset);
-	G_write_raster_cats(name, &cats);
+	cats.num = Rast_number_of_cats(name, mapset);
+	Rast_write_raster_cats(name, &cats);
     if (map_type != CELL_TYPE && quant_ok)
-	G_write_quant(name, mapset, &quant);
+	Rast_write_quant(name, mapset, &quant);
     return 0;
@@ -312,16 +313,16 @@
     G_set_window(&cellhd);
-    old = G_open_cell_old(name, mapset);
+    old = Rast_open_cell_old(name, mapset);
     if (old < 0)
 	G_fatal_error(_("Unable to open raster map <%s>"), name);
-    new = G_open_raster_new(name, map_type);
+    new = Rast_open_raster_new(name, map_type);
     if (new < 0)
-    rast = G_allocate_raster_buf(map_type);
+    rast = Rast_allocate_raster_buf(map_type);
     G_verbose_message(_("Writing new data for raster map <%s>..."), name);
@@ -329,7 +330,7 @@
-	if (G_get_raster_row_nomask(old, rast, row, map_type) < 0) {
+	if (Rast_get_raster_row_nomask(old, rast, row, map_type) < 0) {
 	    G_warning(_("Unable to read raster map <%s> row %d"),
 		      name, row);
 	    break;
@@ -337,7 +338,7 @@
 	mask_raster_array(rast, cellhd.cols, change_null, map_type);
-	if (G_put_raster_row(new, rast, map_type) < 0) {
+	if (Rast_put_raster_row(new, rast, map_type) < 0) {
 	    G_warning(_("Failed writing raster map <%s> row %d"),
 		      name, row);
 	    break;
@@ -345,12 +346,12 @@
     G_free(rast);
     if (row < cellhd.rows) {
-	G_unopen_cell(new);
+	Rast_unopen_cell(new);
 	return 1;
     return 0;
Modified: grass/trunk/raster/r.null/mask.c
--- grass/trunk/raster/r.null/mask.c	2009-06-20 21:39:23 UTC (rev 38002)
+++ grass/trunk/raster/r.null/mask.c	2009-06-20 22:03:23 UTC (rev 38003)
@@ -1,4 +1,5 @@
 #include "mask.h"
@@ -29,12 +30,12 @@
     DCELL x;
     while (ncols-- > 0) {
-	x = G_get_raster_value_d(rast, data_type);
-	if (change_null && G_is_null_value(rast, data_type))
-	    G_set_raster_value_d(rast, new_null, data_type);
+	x = Rast_get_raster_value_d(rast, data_type);
+	if (change_null && Rast_is_null_value(rast, data_type))
+	    Rast_set_raster_value_d(rast, new_null, data_type);
 	if (mask_d_select(&x, &d_mask))
-	    G_set_null_value(rast, 1, data_type);
-	rast = G_incr_void_ptr(rast, G_raster_size(data_type));
+	    Rast_set_null_value(rast, 1, data_type);
+	rast = Rast_incr_void_ptr(rast, Rast_raster_size(data_type));
     return 0;
@@ -55,7 +56,7 @@
 int mask_match_d_interval(DCELL x, d_Interval * I)
-    if (G_is_d_null_value(&x))
+    if (Rast_is_d_null_value(&x))
 	return 0;
     if (I->inf < 0)
Modified: grass/trunk/raster/r.out.arc/main.c
--- grass/trunk/raster/r.out.arc/main.c	2009-06-20 21:39:23 UTC (rev 38002)
+++ grass/trunk/raster/r.out.arc/main.c	2009-06-20 22:03:23 UTC (rev 38003)
@@ -3,6 +3,7 @@
 #include <math.h>
 #include <stdio.h>
@@ -115,17 +116,17 @@
     sprintf(null_str, "-9999");
-    fd = G_open_cell_old(parm.map->answer, "");
+    fd = Rast_open_cell_old(parm.map->answer, "");
     if (fd < 0)
 	G_fatal_error(_("Unable to open raster map <%s>"), parm.map->answer);
-    map_type = G_get_raster_map_type(fd);
+    map_type = Rast_get_raster_map_type(fd);
     out_type = map_type;
-       null_row = G_allocate_null_buf();
+       null_row = Rast_allocate_null_buf();
-    raster = G_allocate_raster_buf(out_type);
+    raster = Rast_allocate_raster_buf(out_type);
     nrows = G_window_rows();
@@ -170,15 +171,15 @@
-	if (G_get_raster_row(fd, raster, row, out_type) < 0)
+	if (Rast_get_raster_row(fd, raster, row, out_type) < 0)
 	    exit(EXIT_FAILURE);
-	   if (G_get_null_value_row(fd, null_row, row) < 0)
+	   if (Rast_get_null_value_row(fd, null_row, row) < 0)
 	   exit(EXIT_FAILURE);
 	for (col = 0, ptr = raster; col < ncols; col++,
-	     ptr = G_incr_void_ptr(ptr, G_raster_size(out_type))) {
-	    if (!G_is_null_value(ptr, out_type)) {
+	     ptr = Rast_incr_void_ptr(ptr, Rast_raster_size(out_type))) {
+	    if (!Rast_is_null_value(ptr, out_type)) {
 		if (out_type == CELL_TYPE)
 		    fprintf(fp, "%d", *((CELL *) ptr));
@@ -215,7 +216,7 @@
     /* make sure it got to 100% */
     G_percent(1, 1, 2);
-    G_close_cell(fd);
+    Rast_close_cell(fd);
     fclose(fp);
     exit(EXIT_SUCCESS);
Modified: grass/trunk/raster/r.out.ascii/formspecific.c
--- grass/trunk/raster/r.out.ascii/formspecific.c	2009-06-20 21:39:23 UTC (rev 38002)
+++ grass/trunk/raster/r.out.ascii/formspecific.c	2009-06-20 22:03:23 UTC (rev 38003)
@@ -1,5 +1,6 @@
 #include <stdio.h>
 /* write the GRASS ASCII heading */
 int writeGRASSheader(FILE * fp)
@@ -32,17 +33,17 @@
     void *ptr, *raster;
     char cell_buf[300];
 	    return (row);
@@ -85,29 +86,29 @@
     int row, col, colcnt;
     void *ptr, *raster;
 	    return (row);
 	colcnt = 0;
 	    if (out_type == CELL_TYPE) {
-		if (G_is_null_value(ptr, out_type))
+		if (Rast_is_null_value(ptr, out_type))
 		    *((CELL *) ptr) = 0;
 		fprintf(fp, " %d", *((CELL *) ptr));
 	    else if (out_type == FCELL_TYPE) {
 		    *((FCELL *) ptr) = 0;
 		fprintf(fp, "%*.*e", dp + 6, dp - 1, *((FCELL *) ptr));
 	    else if (out_type == DCELL_TYPE) {
 		    *((DCELL *) ptr) = 0;
 		fprintf(fp, "%*.*e", dp + 6, dp - 1, *((DCELL *) ptr));
@@ -133,7 +134,7 @@
     struct FPRange range;
     DCELL Z_MIN, Z_MAX;
-    if (G_read_fp_range(name, "", &range) < 0)
+    if (Rast_read_fp_range(name, "", &range) < 0)
 	return 1;
     fprintf(fp, "DSAA \n");
@@ -154,7 +155,7 @@
 		      G_projection() == PROJECTION_LL ? -1 : 0);
     fprintf(fp, "%s %s\n", fromc, toc);
-    G_get_fp_range_min_max(&range, &Z_MIN, &Z_MAX);
+    Rast_get_fp_range_min_max(&range, &Z_MIN, &Z_MAX);
     fprintf(fp, "%f %f\n", (double)Z_MIN, (double)Z_MAX);
     return 0;
@@ -171,19 +172,19 @@
     void *ptr, *raster;
     char cell_buf[300];
     for (row = nrows - 1; row >= 0; row--) {
 	G_percent((row - nrows) * (-1), nrows, 2);
 	    return (row);
 	colcnt = 0;
 	    colcnt += 1;
Modified: grass/trunk/raster/r.out.ascii/main.c
--- grass/trunk/raster/r.out.ascii/main.c	2009-06-20 21:39:23 UTC (rev 38002)
+++ grass/trunk/raster/r.out.ascii/main.c	2009-06-20 22:03:23 UTC (rev 38003)
@@ -21,6 +21,7 @@
 #include <math.h>
 #include <string.h>
 #include "localproto.h"
@@ -141,11 +142,11 @@
     name = parm.map->answer;
     /* open raster map */
-    fd = G_open_cell_old(name, "");
+    fd = Rast_open_cell_old(name, "");
     if (fd < 0)
     if (!flag.int_out->answer)
@@ -193,7 +194,7 @@
     /* tidy up and go away */
-    G_close_cell(fd);
     fclose(fp);
     exit(EXIT_SUCCESS);
Modified: grass/trunk/raster/r.out.bin/main.c
--- grass/trunk/raster/r.out.bin/main.c	2009-06-20 21:39:23 UTC (rev 38002)
+++ grass/trunk/raster/r.out.bin/main.c	2009-06-20 22:03:23 UTC (rev 38003)
@@ -13,6 +13,7 @@
 #include <stdlib.h>
 #include <string.h>
 #include "./gmt_grd.h"
@@ -122,11 +123,11 @@
     G_get_window(&region);
     if (fd < 0)
     else
@@ -153,8 +154,8 @@
     /* Set up Parameters for GMT header */
     if (flag.gmt_hd->answer) {
-	G_read_fp_range(name, "", &range);
+	Rast_read_fp_range(name, "", &range);
 	header.nx = region.cols;
 	header.ny = region.rows;
@@ -273,7 +274,7 @@
 	fclose(fp_2);
     /* Write out GMT Header if required */
@@ -331,13 +332,13 @@
     G_message(_("c=%d"), region.cols);
 	    G_fatal_error(_("Reading map"));
 		    number_i = *((CELL *) ptr);
 		    if (flag.swap->answer)
@@ -382,7 +383,7 @@
     G_percent(row, nrows, 2);	/* finish it off */
-    G_close_cell(fd);
     fclose(fp);
     exit(EXIT_SUCCESS);
Modified: grass/trunk/raster/r.out.gdal/export_band.c
--- grass/trunk/raster/r.out.gdal/export_band.c	2009-06-20 21:39:23 UTC (rev 38002)
+++ grass/trunk/raster/r.out.gdal/export_band.c	2009-06-20 22:03:23 UTC (rev 38003)
@@ -15,6 +15,7 @@
 #include "cpl_string.h"
@@ -49,7 +50,7 @@
     int ret = 0;
     /* Open GRASS raster */
     if (fd < 0) {
 	G_warning(_("Unable to open raster map <%s>"), name);
 	return -1;
@@ -64,12 +65,12 @@
     /* Get min/max values. */
-    if (G_read_fp_range(name, mapset, &sRange) == -1) {
+    if (Rast_read_fp_range(name, mapset, &sRange) == -1) {
 	bHaveMinMax = FALSE;
     else {
 	bHaveMinMax = TRUE;
-	G_get_fp_range_min_max(&sRange, &dfCellMin, &dfCellMax);
+	Rast_get_fp_range_min_max(&sRange, &dfCellMin, &dfCellMax);
     /* suppress useless warnings */
@@ -78,13 +79,13 @@
     CPLPopErrorHandler();
     /* use default color rules if no color rules are given */
-    if (G_read_colors(name, mapset, &sGrassColors) >= 0) {
+    if (Rast_read_colors(name, mapset, &sGrassColors) >= 0) {
 	int maxcolor, i;
 	CELL min, max;
 	char key[200], value[200];
 	int rcount;
-	G_get_color_range(&min, &max, &sGrassColors);
+	Rast_get_color_range(&min, &max, &sGrassColors);
 	if (bHaveMinMax) {
 	    if (max < dfCellMax) {
 		maxcolor = max;
@@ -109,7 +110,7 @@
-	rcount = G_colors_count(&sGrassColors);
+	rcount = Rast_colors_count(&sGrassColors);
 	G_debug(3, "dfCellMin: %f, dfCellMax: %f, maxcolor: %d", dfCellMin,
 		dfCellMax, maxcolor);
@@ -121,7 +122,7 @@
 		int nRed, nGreen, nBlue;
 		GDALColorEntry sColor;
-		if (G_get_color
+		if (Rast_get_color
 		    (iColor, &nRed, &nGreen, &nBlue, &sGrassColors)) {
 		    sColor.c1 = nRed;
 		    sColor.c2 = nGreen;
@@ -129,7 +130,7 @@
 		    sColor.c4 = 255;
 		    G_debug(3,
-			    "G_get_color: Y, rcount %d, nRed %d, nGreen %d, nBlue %d",
+			    "Rast_get_color: Y, rcount %d, nRed %d, nGreen %d, nBlue %d",
 			    rcount, nRed, nGreen, nBlue);
 		    GDALSetColorEntry(hCT, iColor, &sColor);
@@ -140,7 +141,7 @@
 		    sColor.c4 = 0;
 		    G_debug(3,
-			    "G_get_color: N, rcount %d, nRed %d, nGreen %d, nBlue %d",
+			    "Rast_get_color: N, rcount %d, nRed %d, nGreen %d, nBlue %d",
@@ -163,7 +164,7 @@
 	    DCELL val1, val2;
 	    unsigned char r1, g1, b1, r2, g2, b2;
-	    G_get_f_color_rule(&val1, &r1, &g1, &b1, &val2, &r2, &g2, &b2,
+	    Rast_get_f_color_rule(&val1, &r1, &g1, &b1, &val2, &r2, &g2, &b2,
 			       &sGrassColors, i);
@@ -175,7 +176,7 @@
     /* Create GRASS raster buffer */
-    void *bufer = G_allocate_raster_buf(maptype);
+    void *bufer = Rast_allocate_raster_buf(maptype);
     if (bufer == NULL) {
 	G_warning(_("Unable to allocate buffer for reading raster map"));
@@ -208,12 +209,12 @@
 	for (row = 0; row < rows; row++) {
-	    if (G_get_raster_row(fd, bufer, row, maptype) < 0) {
+	    if (Rast_get_raster_row(fd, bufer, row, maptype) < 0) {
 			  name, row);
 		return -1;
-	    G_get_null_value_row(fd, nulls, row);
+	    Rast_get_null_value_row(fd, nulls, row);
 	    for (col = 0; col < cols; col++)
 		if (nulls[col]) {
 		    ((FCELL *) bufer)[col] = fnullval;
@@ -250,12 +251,12 @@
 			  name, row);
 		return -1;
 		if (nulls[col]) {
 		    ((DCELL *) bufer)[col] = dnullval;
@@ -292,12 +293,12 @@
 			  name, row);
 		return -1;
 		if (nulls[col]) {
 		    ((CELL *) bufer)[col] = inullval;
Modified: grass/trunk/raster/r.out.gdal/main.c
--- grass/trunk/raster/r.out.gdal/main.c	2009-06-20 21:39:23 UTC (rev 38002)
+++ grass/trunk/raster/r.out.gdal/main.c	2009-06-20 22:03:23 UTC (rev 38003)
@@ -24,6 +24,7 @@
 #include <math.h>
 #include <string.h>
 #include <grass/imagery.h>
@@ -346,14 +347,14 @@
     export_min = TYPE_FLOAT64_MIN;
     export_max = TYPE_FLOAT64_MAX;
     for (band = 0; band < ref.nfiles; band++) {
 	    (ref.file[band].name, ref.file[band].mapset, &sRange) == -1) {
 	    G_warning(_("Could not read data range of raster <%s>"),
 		      ref.file[band].name);
 	else {
 	    if (band == 0) {
 		export_min = dfCellMin;
 		export_max = dfCellMax;
@@ -379,7 +380,7 @@
     /* GDAL datatype not set by user, determine suitable datatype */
     if (datatype == GDT_Unknown) {
 	/* Use raster data type from first GRASS raster in a group */
-	maptype = G_raster_map_type(ref.file[0].name, ref.file[0].mapset);
+	maptype = Rast_raster_map_type(ref.file[0].name, ref.file[0].mapset);
 	if (maptype == FCELL_TYPE) {
 	    datatype = GDT_Float32;
@@ -428,7 +429,7 @@
 	/* Precision tests */
 	    testmaptype =
-		G_raster_map_type(ref.file[band].name, ref.file[band].mapset);
+		Rast_raster_map_type(ref.file[band].name, ref.file[band].mapset);
 	    /* Exporting floating point rasters to some integer type ? */
 	    if ((testmaptype == FCELL_TYPE || testmaptype == DCELL_TYPE) &&
 		(datatype == GDT_Byte || datatype == GDT_Int16 ||
Modified: grass/trunk/raster/r.out.gridatb/file_io.c
--- grass/trunk/raster/r.out.gridatb/file_io.c	2009-06-20 21:39:23 UTC (rev 38002)
+++ grass/trunk/raster/r.out.gridatb/file_io.c	2009-06-20 22:03:23 UTC (rev 38003)
@@ -13,24 +13,24 @@
     FCELL *fcell;
     RASTER_MAP_TYPE data_type;
-    fd = G_open_cell_old(iname, "");
+    fd = Rast_open_cell_old(iname, "");
     if (fd < 0)
 	G_fatal_error("%s - could not read", iname);
-    data_type = G_get_raster_map_type(fd);
+    data_type = Rast_get_raster_map_type(fd);
     switch (data_type) {
     case CELL_TYPE:
-	cell = G_allocate_c_raster_buf();
+	cell = Rast_allocate_c_raster_buf();
 	break;
     case FCELL_TYPE:
-	fcell = G_allocate_f_raster_buf();
+	fcell = Rast_allocate_f_raster_buf();
 	break;
     case DCELL_TYPE:
-	dcell = G_allocate_d_raster_buf();
+	dcell = Rast_allocate_d_raster_buf();
 	break;
-    G_get_cellhd(iname, "", &cellhd);
+    Rast_get_cellhd(iname, "", &cellhd);
     adjcellhdval = adjcellhd(&cellhd);
     switch (adjcellhdval) {
@@ -47,20 +47,20 @@
     fp = fopen(file, "w");
-    fprintf(fp, "%s\n", G_get_cell_title(iname, ""));
+    fprintf(fp, "%s\n", Rast_get_cell_title(iname, ""));
     fprintf(fp, "%d %d %lf\n", cellhd.cols, cellhd.rows, cellhd.ns_res);
 	G_percent(row, cellhd.rows, 2);
 	case CELL_TYPE:
-	    if (G_get_c_raster_row(fd, cell, row) < 0) {
-		G_close_cell(fd);
+	    if (Rast_get_c_raster_row(fd, cell, row) < 0) {
 		exit(1);
 	    for (col = 0; col < cellhd.cols; col++) {
-		if (G_is_c_null_value(&cell[col]))
+		if (Rast_is_c_null_value(&cell[col]))
 		    fprintf(fp, "  9999.00 ");
 		else
 		    fprintf(fp, "%9.2f ", (float)cell[col]);
@@ -69,13 +69,13 @@
 	    break;
 	case FCELL_TYPE:
-	    if (G_get_f_raster_row(fd, fcell, row) < 0) {
-		G_close_cell(fd);
+	    if (Rast_get_f_raster_row(fd, fcell, row) < 0) {
 		exit(1);
-		if (G_is_f_null_value(&fcell[col]))
+		if (Rast_is_f_null_value(&fcell[col]))
 		else
 		    fprintf(fp, "%9.2f ", (float)fcell[col]);
@@ -84,13 +84,13 @@
 	    break;
 	case DCELL_TYPE:
-	    if (G_get_d_raster_row(fd, dcell, row) < 0) {
-		G_close_cell(fd);
+	    if (Rast_get_d_raster_row(fd, dcell, row) < 0) {
 		exit(1);
-		if (G_is_d_null_value(&dcell[col]))
+		if (Rast_is_d_null_value(&dcell[col]))
 		else
 		    fprintf(fp, "%9.2lf ", (double)dcell[col]);
@@ -100,7 +100,7 @@
 	    break;
-    G_close_cell(fd);
     return;
Modified: grass/trunk/raster/r.out.gridatb/local_proto.h
--- grass/trunk/raster/r.out.gridatb/local_proto.h	2009-06-20 21:39:23 UTC (rev 38002)
+++ grass/trunk/raster/r.out.gridatb/local_proto.h	2009-06-20 22:03:23 UTC (rev 38003)
@@ -1,5 +1,6 @@
 #include <stdio.h>
 void check_ready(void);
 int adjcellhd(struct Cell_head *cellhd);
Modified: grass/trunk/raster/r.out.gridatb/main.c
--- grass/trunk/raster/r.out.gridatb/main.c	2009-06-20 21:39:23 UTC (rev 38002)
+++ grass/trunk/raster/r.out.gridatb/main.c	2009-06-20 22:03:23 UTC (rev 38003)
@@ -17,6 +17,7 @@
 #include <stdio.h>
Modified: grass/trunk/raster/r.out.mat/main.c
--- grass/trunk/raster/r.out.mat/main.c	2009-06-20 21:39:23 UTC (rev 38002)
+++ grass/trunk/raster/r.out.mat/main.c	2009-06-20 22:03:23 UTC (rev 38003)
@@ -17,6 +17,7 @@
 #include <stdlib.h>
 #include <string.h>
 int main(int argc, char *argv[])
@@ -81,11 +82,11 @@
     outfile = G_malloc(strlen(basename) + 5);
     sprintf(outfile, "%s.mat", basename);
-    fd = G_open_cell_old(infile, "");
+    fd = Rast_open_cell_old(infile, "");
     if (fd < 0)
 	G_fatal_error(_("Unable to open raster map <%s>"), infile);
     /* open bin file for writing */
     fp1 = fopen(outfile, "wb");
@@ -138,7 +139,7 @@
     /********** Write title (if there is one) **********/
-    maptitle = G_get_cell_title(infile, "");
+    maptitle = Rast_get_cell_title(infile, "");
     if (strlen(maptitle) >= 1) {
 	/** write text element (map title) **/
@@ -294,10 +295,10 @@
     /* data array, by increasing column */
     raster =
 	G_calloc((G_window_rows() + 1) * (G_window_cols() + 1),
-		 G_raster_size(map_type));
+		 Rast_raster_size(map_type));
     G_debug(1, "mem alloc is %d bytes\n",	/* I think _cols()+1 is unneeded? */
-	    G_raster_size(map_type) * (G_window_rows() +
+	    Rast_raster_size(map_type) * (G_window_rows() +
 				       1) * (G_window_cols() + 1));
     G_verbose_message(_("Reading in map ... "));
@@ -305,9 +306,9 @@
     /* load entire map into memory */
     for (row = 0, ptr = raster; row < mrows; row++,
 	 ptr =
-	 G_incr_void_ptr(ptr,
-			 (G_window_cols() + 1) * G_raster_size(map_type))) {
-	if (G_get_raster_row(fd, ptr, row, map_type) < 0)
+	 Rast_incr_void_ptr(ptr,
+			 (G_window_cols() + 1) * Rast_raster_size(map_type))) {
+	if (Rast_get_raster_row(fd, ptr, row, map_type) < 0)
 	    G_fatal_error("reading map");
 	G_percent(row, mrows, 2);
@@ -317,18 +318,18 @@
     G_verbose_message(_("Writing out map..."));
     /* then write it to disk */
-    /* NoGood: fwrite(raster, G_raster_size(map_type), mrows*ncols, fp1); */
+    /* NoGood: fwrite(raster, Rast_raster_size(map_type), mrows*ncols, fp1); */
     for (col = 0; col < ncols; col++) {
 	for (row = 0; row < mrows; row++) {
 	    ptr = raster;
 	    ptr =
 				(col +
 				 row * (ncols +
-					1)) * G_raster_size(map_type));
+					1)) * Rast_raster_size(map_type));
-	    if (!G_is_null_value(ptr, map_type)) {
+	    if (!Rast_is_null_value(ptr, map_type)) {
 		if (map_type == CELL_TYPE) {
 		    val_i = *((CELL *) ptr);
 		    fwrite(&val_i, sizeof(int), 1, fp1);
Modified: grass/trunk/raster/r.out.mpeg/main.c
--- grass/trunk/raster/r.out.mpeg/main.c	2009-06-20 21:39:23 UTC (rev 38002)
+++ grass/trunk/raster/r.out.mpeg/main.c	2009-06-20 22:03:23 UTC (rev 38003)
@@ -40,6 +40,7 @@
 #include <unistd.h>
 #include <grass/gis.h>
+#include <grass/Rast.h>
 #include "rom_proto.h"
@@ -281,23 +282,23 @@
 	    if (!quiet)
 		G_message("\r%s <%s>", _("Reading file"), name);
 	    if (fd < 0)
-	    if (G_read_colors(name, "", &colors) < 0)
+	    if (Rast_read_colors(name, "", &colors) < 0)
 		G_fatal_error(_("Unable to read color table for <%s>"), name);
-	    rtype = G_get_raster_map_type(fd);
-	    voidc = G_allocate_raster_buf(rtype);
+	    rtype = Rast_get_raster_map_type(fd);
+	    voidc = Rast_allocate_raster_buf(rtype);
 	    for (row = 0; row < vrows; row++) {
-		if (G_get_raster_row(fd, voidc,
+		if (Rast_get_raster_row(fd, voidc,
 				     (int)(row / vscale), rtype) < 0)
 		    G_fatal_error(_("Error reading row <%d>"), row);
 		rowoff = (vyoff + row) * ncols;
-		G_lookup_raster_colors(voidc, tr, tg, tb,
+		Rast_lookup_raster_colors(voidc, tr, tg, tb,
 				       tset, tsiz, &colors, rtype);
 		for (col = 0; col < vcols; col++) {
@@ -314,7 +315,7 @@
-	    G_close_cell(fd);
 	yfiles[cnt] = G_tempfile();
Modified: grass/trunk/raster/r.out.mpeg/write.c
--- grass/trunk/raster/r.out.mpeg/write.c	2009-06-20 21:39:23 UTC (rev 38002)
+++ grass/trunk/raster/r.out.mpeg/write.c	2009-06-20 22:03:23 UTC (rev 38003)
@@ -22,6 +22,7 @@
 #include <math.h>
 #include <unistd.h>
Modified: grass/trunk/raster/r.out.png/main.c
--- grass/trunk/raster/r.out.png/main.c	2009-06-20 21:39:23 UTC (rev 38002)
+++ grass/trunk/raster/r.out.png/main.c	2009-06-20 22:03:23 UTC (rev 38003)
@@ -37,6 +37,7 @@
 #endif /* _MYINCLUDE_H */
 #define DEF_RED 255
@@ -151,12 +152,12 @@
     G_message(_("rows = %d, cols = %d"), w.rows, w.cols);
     /* open raster map for reading */
-    if ((cellfile = G_open_cell_old(rast->answer, "")) == -1)
+    if ((cellfile = Rast_open_cell_old(rast->answer, "")) == -1)
 	G_fatal_error(_("Unable to open cellfile for <%s>"), rastermap);
-    cell_buf = G_allocate_c_raster_buf();
-    fcell_buf = G_allocate_f_raster_buf();
-    dcell_buf = G_allocate_d_raster_buf();
+    cell_buf = Rast_allocate_c_raster_buf();
+    fcell_buf = Rast_allocate_f_raster_buf();
+    dcell_buf = Rast_allocate_d_raster_buf();
     ored = G_malloc(w.cols);
     ogrn = G_malloc(w.cols);
@@ -221,9 +222,9 @@
 	struct Colors colors;
-	G_read_colors(rast->answer, "", &colors);
+	Rast_read_colors(rast->answer, "", &colors);
-	rtype = G_get_raster_map_type(cellfile);
+	rtype = Rast_get_raster_map_type(cellfile);
 	if (rtype == CELL_TYPE)
 	    voidc = (CELL *) cell_buf;
 	else if (rtype == FCELL_TYPE)
@@ -251,9 +252,9 @@
 	    for (row = 0; row < w.rows; row++) {
 		G_percent(row, w.rows, 5);
-		if (G_get_raster_row(cellfile, (void *)voidc, row, rtype) < 0)
+		if (Rast_get_raster_row(cellfile, (void *)voidc, row, rtype) < 0)
 		    exit(EXIT_FAILURE);
-		G_lookup_raster_colors((void *)voidc, ored, ogrn, oblu, set,
+		Rast_lookup_raster_colors((void *)voidc, ored, ogrn, oblu, set,
 				       w.cols, &colors, rtype);
 		pp = line;
@@ -291,7 +292,7 @@
 	    G_warning("don't know how to write grey scale!\n");
-	G_free_colors(&colors);
+	Rast_free_colors(&colors);
     G_free(cell_buf);
@@ -301,7 +302,7 @@
     G_free(ogrn);
     G_free(oblu);
     G_free(set);
-    G_close_cell(cellfile);
+    Rast_close_cell(cellfile);
Modified: grass/trunk/raster/r.out.pov/main.c
--- grass/trunk/raster/r.out.pov/main.c	2009-06-20 21:39:23 UTC (rev 38002)
+++ grass/trunk/raster/r.out.pov/main.c	2009-06-20 22:03:23 UTC (rev 38003)
@@ -39,6 +39,7 @@
 #include <string.h>
 #include <math.h>
 void writeHeader(FILE * outf);
@@ -161,7 +162,7 @@
     if (fd < 0)
@@ -173,7 +174,7 @@
     if (NULL == (outf = fopen(outfilename, "wb")))
 	G_fatal_error(_("Unable to open output file <%s>"), outfilename);
-    cell = G_allocate_cell_buf();
+    cell = Rast_allocate_cell_buf();
@@ -195,9 +196,9 @@
     northMost = region.north;
     southMost = region.south;
-    G_init_range(&range);
-    G_read_range(name, "", &range);
-    G_get_range_min_max(&range, &range_min, &range_max);
+    Rast_init_range(&range);
+    Rast_read_range(name, "", &range);
+    Rast_get_range_min_max(&range, &range_min, &range_max);
     if (range.min < 0 || range.max < 0)
 	G_warning(_("Negative elevation values in input"));
@@ -219,7 +220,7 @@
     (void)processProfiles(fd, outf);
     fclose(outf);
-    G_close_cell(fd);
     exit(EXIT_SUCCESS);
@@ -259,9 +260,9 @@
     int c, r;
     double tempFloat;
     for (r = 0; r < rowCount; r++) {
-	if (G_get_map_row(inputFile, cell, r) < 0)
+	if (Rast_get_map_row(inputFile, cell, r) < 0)
 	    exit(1);
 	/* break; */
Modified: grass/trunk/raster/r.out.ppm/main.c
--- grass/trunk/raster/r.out.ppm/main.c	2009-06-20 21:39:23 UTC (rev 38002)
+++ grass/trunk/raster/r.out.ppm/main.c	2009-06-20 22:03:23 UTC (rev 38003)
@@ -21,6 +21,7 @@
 #include <stdlib.h>
 #define DEF_RED 255
@@ -95,12 +96,12 @@
 	G_fatal_error(_("Unable to open raster map <%s>"), rast->answer);
@@ -146,9 +147,9 @@
@@ -161,10 +162,10 @@
 	if (!gscale->answer) {	/* 24BIT COLOR IMAGE */
 				  rast->answer, row);
 		for (col = 0; col < w.cols; col++) {
@@ -185,9 +186,9 @@
 		    exit(1);
@@ -205,7 +206,7 @@
     G_free(cell_buf);
@@ -215,7 +216,7 @@
     G_free(ogrn);
     G_free(oblu);
     G_free(set);
        if(!do_stdout)
Modified: grass/trunk/raster/r.out.ppm3/main.c
--- grass/trunk/raster/r.out.ppm3/main.c	2009-06-20 21:39:23 UTC (rev 38002)
+++ grass/trunk/raster/r.out.ppm3/main.c	2009-06-20 22:03:23 UTC (rev 38003)
@@ -18,6 +18,7 @@
 #include <stdlib.h>
 #define DEF_RED 255
@@ -99,18 +100,18 @@
 	char *name = B[i].opt->answer;
 	/* Open raster map */
-	if ((B[i].file = G_open_cell_old(name, "")) == -1)
+	if ((B[i].file = Rast_open_cell_old(name, "")) == -1)
 	/* Get map type (CELL/FCELL/DCELL) */
-	B[i].type = G_get_raster_map_type(B[i].file);
+	B[i].type = Rast_get_raster_map_type(B[i].file);
 	/* Get color table */
-	if (G_read_colors(name, "", &B[i].colors) == -1)
+	if (Rast_read_colors(name, "", &B[i].colors) == -1)
 	    G_fatal_error(_("Color file for <%s> not available"), name);
 	/* Allocate input buffer */
-	B[i].array = G_allocate_raster_buf(B[i].type);
+	B[i].array = Rast_allocate_raster_buf(B[i].type);
 	/* Allocate output buffers */
 	B[i].buf = (unsigned char *)G_malloc(w.cols);
@@ -158,10 +159,10 @@
 	for (i = 0; i < 3; i++) {
-	    if (G_get_raster_row(B[i].file, B[i].array, row, B[i].type) < 0)
-		G_fatal_error("G_get_raster_row failed");
+	    if (Rast_get_raster_row(B[i].file, B[i].array, row, B[i].type) < 0)
+		G_fatal_error("Rast_get_raster_row failed");
-	    G_lookup_raster_colors(B[i].array,
+	    Rast_lookup_raster_colors(B[i].array,
 				   (i == 0) ? B[i].buf : dummy,
 				   (i == 1) ? B[i].buf : dummy,
 				   (i == 2) ? B[i].buf : dummy,
@@ -186,11 +187,11 @@
     fclose(fp);
-	G_free_colors(&B[i].colors);
+	Rast_free_colors(&B[i].colors);
 	G_free(B[i].array);
 	G_free(B[i].buf);
 	G_free(B[i].mask);
-	G_close_cell(B[i].file);
+	Rast_close_cell(B[i].file);
     exit(EXIT_SUCCESS);
Modified: grass/trunk/raster/r.out.tiff/main.c
--- grass/trunk/raster/r.out.tiff/main.c	2009-06-20 21:39:23 UTC (rev 38002)
+++ grass/trunk/raster/r.out.tiff/main.c	2009-06-20 22:03:23 UTC (rev 38003)
@@ -50,6 +50,7 @@
 #include <tiffio.h>
 #include "rasterfile.h"
@@ -138,25 +139,25 @@
     palette = pflag->answer;
     tfw = tflag->answer;
-    if ((G_get_cellhd(inopt->answer, "", &cellhd) < 0))
+    if ((Rast_get_cellhd(inopt->answer, "", &cellhd) < 0))
 		      inopt->answer);
     G_get_window(&cellhd);
-    G_read_colors(inopt->answer, "", &colors);
-    if ((isfp = G_raster_map_is_fp(inopt->answer, "")))
+    Rast_read_colors(inopt->answer, "", &colors);
+    if ((isfp = Rast_raster_map_is_fp(inopt->answer, "")))
 	G_warning(_("Raster map <%s>> is a floating point "
 		    "map. Fractional values will be rounded to integer"),
 		  inopt->answer);
-    G_set_null_value_color(255, 255, 255, &colors);
+    Rast_set_null_value_color(255, 255, 255, &colors);
     if (palette && (colors.cmax - colors.cmin > 255))
 	G_fatal_error(_("Color map for palette must have less "
 			"than 256 colors for the available range of data"));
-    if ((in = G_open_cell_old(inopt->answer, "")) < 0)
+    if ((in = Rast_open_cell_old(inopt->answer, "")) < 0)
 	G_fatal_error(_("Unable to open raster map <%s>"), inopt->answer);
     basename = G_store(outopt->answer);
@@ -199,7 +200,7 @@
 #define	SCALE(x)	(((x)*((1L<<16)-1))/255)
 	for (i = colors.cmin; i <= colors.cmax; i++, redp++, grnp++, blup++) {
-	    G_get_color(i, &red, &grn, &blu, &colors);
+	    Rast_get_color(i, &red, &grn, &blu, &colors);
 	    *redp = (unsigned short) (SCALE(red));
 	    *grnp = (unsigned short) (SCALE(grn));
 	    *blup = (unsigned short) (SCALE(blu));
@@ -241,7 +242,7 @@
 	/* allocate cell buffers */
 	for (i = 0; i < tilelength; i++)
-	    cells[i] = G_allocate_cell_buf();
+	    cells[i] = Rast_allocate_cell_buf();
 	/* build tiff tiles from grass buffer */
 	for (row = 0; row < imagelength; row += tilelength) {
@@ -251,7 +252,7 @@
 	    uint32 colb = 0;
 	    for (i = 0; i < nrow; i++) {
-		if (G_get_c_raster_row(in, cells[i], row + i) < 0)
+		if (Rast_get_c_raster_row(in, cells[i], row + i) < 0)
 		    G_fatal_error(_("Reading raster map..."));
@@ -288,7 +289,7 @@
 		    else {
 			for (j = 0; j < width; j++) {
-			    G_get_color(cellptr[col + j], &red, &grn, &blu,
+			    Rast_get_color(cellptr[col + j], &red, &grn, &blu,
 					&colors);
 			    *tptr++ = (unsigned char) red;
 			    *tptr++ = (unsigned char) grn;
@@ -338,7 +339,7 @@
 	    G_percent(row, h.ras_height, 2);
-	    if (G_get_c_raster_row(in, cell, row) < 0)
+	    if (Rast_get_c_raster_row(in, cell, row) < 0)
 		exit(EXIT_FAILURE);
 	    cellptr = cell;
@@ -348,7 +349,7 @@
 	    else {
 		for (col = 0; col < h.ras_width; col++) {
-		    G_get_color(cell[col], &red, &grn, &blu, &colors);
+		    Rast_get_color(cell[col], &red, &grn, &blu, &colors);
 		    *tmpptr++ = (unsigned char) red;
 		    *tmpptr++ = (unsigned char) grn;
 		    *tmpptr++ = (unsigned char) blu;
Modified: grass/trunk/raster/r.out.vrml/main.c
--- grass/trunk/raster/r.out.vrml/main.c	2009-06-20 21:39:23 UTC (rev 38002)
+++ grass/trunk/raster/r.out.vrml/main.c	2009-06-20 22:03:23 UTC (rev 38003)
@@ -19,6 +19,7 @@
 #include <string.h>
 #include <stdlib.h>
 #include "pv.h"
@@ -80,7 +81,7 @@
     G_get_set_window(&W);
-    if ((elevfd = G_open_cell_old(rast_el->answer, "")) == -1)
+    if ((elevfd = Rast_open_cell_old(rast_el->answer, "")) == -1)
 	G_fatal_error("Unable to open cellfile for <%s>", rast_el->answer);
@@ -90,32 +91,32 @@
 	DCELL dmin, dmax;
 	struct FPRange fp_range;
-	is_fp = G_raster_map_is_fp(rast_el->answer, "");
+	is_fp = Rast_raster_map_is_fp(rast_el->answer, "");
 	if (is_fp) {
-	    if (G_read_fp_range(rast_el->answer, "", &fp_range) != 1) {
+	    if (Rast_read_fp_range(rast_el->answer, "", &fp_range) != 1) {
 		G_fatal_error(_("Range info for [%s] not available (run r.support)"),
 			      rast_el->answer);
-	    G_get_fp_range_min_max(&fp_range, &dmin, &dmax);
+	    Rast_get_fp_range_min_max(&fp_range, &dmin, &dmax);
 	    min = dmin;
 	    max = dmax;
 	else {
-	    if (G_read_range(rast_el->answer, "", &range) == -1) {
+	    if (Rast_read_range(rast_el->answer, "", &range) == -1) {
 		G_fatal_error(_("Range info for <%s> not available (run r.support)"),
 			      rast_el->answer);
-	    G_get_range_min_max(&range, &cmin, &cmax);
+	    Rast_get_range_min_max(&range, &cmin, &cmax);
 	    min = cmin;
 	    max = cmax;
     if (rast_co->answer) {
-	if ((colorfd = G_open_cell_old(rast_co->answer, "")) == -1)
+	if ((colorfd = Rast_open_cell_old(rast_co->answer, "")) == -1)
 	    G_warning(_("Unable to open cellfile for <%s>"), rast_co->answer);
 	else {
-	    G_read_colors(rast_co->answer, "", &colr);
+	    Rast_read_colors(rast_co->answer, "", &colr);
 	    color_ok = 1;
@@ -159,9 +160,9 @@
     vrml_end(vout);
-    G_close_cell(elevfd);
+    Rast_close_cell(elevfd);
     if (color_ok)
-	G_close_cell(colorfd);
+	Rast_close_cell(colorfd);
     return (EXIT_SUCCESS);
Modified: grass/trunk/raster/r.out.vrml/put_grid.c
--- grass/trunk/raster/r.out.vrml/put_grid.c	2009-06-20 21:39:23 UTC (rev 38002)
+++ grass/trunk/raster/r.out.vrml/put_grid.c	2009-06-20 22:03:23 UTC (rev 38003)
@@ -47,7 +47,7 @@
 	    if (!shh)
 		G_percent(row, rows - 1, 10);
-	    G_get_f_raster_row(elevfd, tf, row);
+	    Rast_get_f_raster_row(elevfd, tf, row);
 	    coordz = G_row_to_northing((double)row, w);
 	    do_coordcnv(&coordz, 'z');
@@ -57,7 +57,7 @@
 		do_coordcnv(&coordx, 'x');
 		/* HACK: no nulls in vrml grid */
-		if (G_is_f_null_value(tf))
+		if (Rast_is_f_null_value(tf))
 		    *tf = 0.0;
 		coordy = *tf;
 		do_coordcnv(&coordy, 'y');
@@ -98,8 +98,8 @@
 	    if (!shh)
 		G_percent(row, rows - 1, 5);
-	    G_get_f_raster_row(colorfd, tf, row);
-	    G_lookup_f_raster_colors(tf, red, green, blue, set, cols, colr);
+	    Rast_get_f_raster_row(colorfd, tf, row);
+	    Rast_lookup_f_raster_colors(tf, red, green, blue, set, cols, colr);
 	    for (col = 0; col < cols; col++) {
 		sprintf(str, "%.3f %.3f %.3f,",
Modified: grass/trunk/raster/r.out.vrml/pv.h
--- grass/trunk/raster/r.out.vrml/pv.h	2009-06-20 21:39:23 UTC (rev 38002)
+++ grass/trunk/raster/r.out.vrml/pv.h	2009-06-20 22:03:23 UTC (rev 38003)
@@ -1,4 +1,5 @@
 /*  VRML VERSION - only 1.0 currently supported
    #define VRML2
Modified: grass/trunk/raster/r.out.vtk/main.c
--- grass/trunk/raster/r.out.vtk/main.c	2009-06-20 21:39:23 UTC (rev 38002)
+++ grass/trunk/raster/r.out.vtk/main.c	2009-06-20 22:03:23 UTC (rev 38003)
@@ -19,6 +19,7 @@
 #include <stdlib.h>
 #include <string.h>
 #include "writeascii.h"
@@ -122,12 +123,12 @@
 	G_debug(3, _("Open Raster file %s"), param.elevationmap->answer);
-	fd = G_open_cell_old(param.elevationmap->answer, "");
+	fd = Rast_open_cell_old(param.elevationmap->answer, "");
 	if (fd < 0)
-	out_type = G_get_raster_map_type(fd);
+	out_type = Rast_get_raster_map_type(fd);
 	/*The write the Coordinates */
 	if (param.usestruct->answer) {
@@ -150,7 +151,7 @@
 					    region, out_type, null_value,
 					    scale, polytype, digits);
-	G_close_cell(fd);
     else {
 	/*Should pointdata or celldata be written */
@@ -185,15 +186,15 @@
 	    G_debug(3, _("Open Raster file %s"), param.input->answers[i]);
-	    fd = G_open_cell_old(param.input->answers[i], "");
+	    fd = Rast_open_cell_old(param.input->answers[i], "");
 	    if (fd < 0)
 	    /*Now write the data */
 	    write_vtk_data(fd, fp, param.input->answers[i], region, out_type,
 			   null_value, digits);
-	    G_close_cell(fd);
@@ -210,11 +211,11 @@
 			param.rgbmaps->answers[i]);
-		rgbfd[i] = G_open_cell_old(param.rgbmaps->answers[i], "");
+		rgbfd[i] = Rast_open_cell_old(param.rgbmaps->answers[i], "");
 		if (rgbfd[i] < 0)
-		celltype[i] = G_get_raster_map_type(rgbfd[i]);
+		celltype[i] = Rast_get_raster_map_type(rgbfd[i]);
 	    /*Maps have to be from the same type */
@@ -235,7 +236,7 @@
 	    /*Close the maps */
-		G_close_cell(rgbfd[i]);
+		Rast_close_cell(rgbfd[i]);
@@ -253,11 +254,11 @@
 		vectfd[i] =
-		    G_open_cell_old(param.vectmaps->answers[i], "");
+		    Rast_open_cell_old(param.vectmaps->answers[i], "");
 		if (vectfd[i] < 0)
 				  param.vectmaps->answers[i]);
-		celltype[i] = G_get_raster_map_type(vectfd[i]);
+		celltype[i] = Rast_get_raster_map_type(vectfd[i]);
@@ -278,7 +279,7 @@
 	    /*Close the maps */
-		G_close_cell(vectfd[i]);
+		Rast_close_cell(vectfd[i]);
Modified: grass/trunk/raster/r.out.vtk/parameters.c
--- grass/trunk/raster/r.out.vtk/parameters.c	2009-06-20 21:39:23 UTC (rev 38002)
+++ grass/trunk/raster/r.out.vtk/parameters.c	2009-06-20 22:03:23 UTC (rev 38003)
@@ -16,6 +16,7 @@
 #include "parameters.h"
Modified: grass/trunk/raster/r.out.vtk/writeascii.c
--- grass/trunk/raster/r.out.vtk/writeascii.c	2009-06-20 21:39:23 UTC (rev 38002)
+++ grass/trunk/raster/r.out.vtk/writeascii.c	2009-06-20 22:03:23 UTC (rev 38003)
@@ -20,6 +20,7 @@
 #include <stdlib.h>
 #include <string.h>
 #include "globaldefs.h"
@@ -37,7 +38,7 @@
     double val = nullval;
     if (MapType == CELL_TYPE) {
-	if (G_is_null_value(ptr, MapType)) {
+	if (Rast_is_null_value(ptr, MapType)) {
 	    val = nullval;
 	else {
@@ -45,7 +46,7 @@
     if (MapType == FCELL_TYPE) {
 	    val = nullval;
 	else {
@@ -53,7 +54,7 @@
     if (MapType == DCELL_TYPE) {
 	    val = nullval;
 	else {
@@ -173,14 +174,14 @@
 	nullvalue = 0;
     rowcount = 0;
 	colcount = 0;
-	if (G_get_raster_row(fd, raster, row, out_type) < 0) {
+	if (Rast_get_raster_row(fd, raster, row, out_type) < 0) {
 	    G_fatal_error(_("Unable to read row %i\n"), row);
 	    return;
@@ -189,7 +190,7 @@
 	nspos -= y_extent;
-	     col++, ptr = G_incr_void_ptr(ptr, G_raster_size(out_type))) {
+	     col++, ptr = Rast_incr_void_ptr(ptr, Rast_raster_size(out_type))) {
 	    ewpos =
 		region.ew_res / 2 + region.west + colcount * region.ew_res;
 	    ewpos -= x_extent;
@@ -234,14 +235,14 @@
     /*First we are writing the coordinate points, the elevation cell is only used for the z coordinate */
     rowcount = 0;
 	colcount = 0;
 	G_percent((row - nrows) * (-1), nrows, 10);
 	    return;
@@ -250,7 +251,7 @@
 	nspos -= y_extent;
 	    ewpos =
 	    ewpos -= x_extent;
@@ -348,18 +349,18 @@
     fprintf(fp, "LOOKUP_TABLE default\n");
 	    return;
 	    value = get_raster_value_as_double(out_type, ptr, nullvalue);
 	    fprintf(fp, "%.*f ", dp, value);
@@ -393,22 +394,22 @@
     fprintf(fp, "COLOR_SCALARS %s 3\n", varname);
-    redraster = G_allocate_raster_buf(out_type);
-    greenraster = G_allocate_raster_buf(out_type);
-    blueraster = G_allocate_raster_buf(out_type);
+    redraster = Rast_allocate_raster_buf(out_type);
+    greenraster = Rast_allocate_raster_buf(out_type);
+    blueraster = Rast_allocate_raster_buf(out_type);
-	if (G_get_raster_row(redfd, redraster, row, out_type) < 0) {
+	if (Rast_get_raster_row(redfd, redraster, row, out_type) < 0) {
 	    return;
-	if (G_get_raster_row(greenfd, greenraster, row, out_type) < 0) {
+	if (Rast_get_raster_row(greenfd, greenraster, row, out_type) < 0) {
 	    return;
-	if (G_get_raster_row(bluefd, blueraster, row, out_type) < 0) {
+	if (Rast_get_raster_row(bluefd, blueraster, row, out_type) < 0) {
 	    return;
@@ -416,9 +417,9 @@
 	for (col = 0, redptr = redraster, greenptr = greenraster, blueptr =
 	     blueraster; col < ncols;
 	     col++, redptr =
-	     G_incr_void_ptr(redptr, G_raster_size(out_type)), greenptr =
-	     G_incr_void_ptr(greenptr, G_raster_size(out_type)), blueptr =
-	     G_incr_void_ptr(blueptr, G_raster_size(out_type))) {
+	     Rast_incr_void_ptr(redptr, Rast_raster_size(out_type)), greenptr =
+	     Rast_incr_void_ptr(greenptr, Rast_raster_size(out_type)), blueptr =
+	     Rast_incr_void_ptr(blueptr, Rast_raster_size(out_type))) {
 	    r = get_raster_value_as_double(out_type, redptr, 0.0);
 	    g = get_raster_value_as_double(out_type, greenptr, 0.0);
@@ -460,22 +461,22 @@
     fprintf(fp, "VECTORS %s float\n", varname);
-    xraster = G_allocate_raster_buf(out_type);
-    yraster = G_allocate_raster_buf(out_type);
-    zraster = G_allocate_raster_buf(out_type);
+    xraster = Rast_allocate_raster_buf(out_type);
+    yraster = Rast_allocate_raster_buf(out_type);
+    zraster = Rast_allocate_raster_buf(out_type);
-	if (G_get_raster_row(xfd, xraster, row, out_type) < 0) {
+	if (Rast_get_raster_row(xfd, xraster, row, out_type) < 0) {
 	    return;
-	if (G_get_raster_row(yfd, yraster, row, out_type) < 0) {
+	if (Rast_get_raster_row(yfd, yraster, row, out_type) < 0) {
 	    return;
-	if (G_get_raster_row(zfd, zraster, row, out_type) < 0) {
+	if (Rast_get_raster_row(zfd, zraster, row, out_type) < 0) {
 	    return;
@@ -483,9 +484,9 @@
 	for (col = 0, xptr = xraster, yptr = yraster, zptr =
 	     zraster; col < ncols;
 	     col++, xptr =
-	     G_incr_void_ptr(xptr, G_raster_size(out_type)), yptr =
-	     G_incr_void_ptr(yptr, G_raster_size(out_type)), zptr =
-	     G_incr_void_ptr(zptr, G_raster_size(out_type))) {
+	     Rast_incr_void_ptr(xptr, Rast_raster_size(out_type)), yptr =
+	     Rast_incr_void_ptr(yptr, Rast_raster_size(out_type)), zptr =
+	     Rast_incr_void_ptr(zptr, Rast_raster_size(out_type))) {
 	    x = get_raster_value_as_double(out_type, xptr, 0.0);
 	    y = get_raster_value_as_double(out_type, yptr, 0.0);
Modified: grass/trunk/raster/r.param.scale/close_down.c
--- grass/trunk/raster/r.param.scale/close_down.c	2009-06-20 21:39:23 UTC (rev 38002)
+++ grass/trunk/raster/r.param.scale/close_down.c	2009-06-20 22:03:23 UTC (rev 38003)
@@ -17,13 +17,13 @@
     char map_title[RECORD_LEN], map_type[32];
     /* Close connection with existing input raster. */
-    G_unopen_cell(fd_in);
+    Rast_unopen_cell(fd_in);
     /* Write output raster map and close connection. */
-    G_close_cell(fd_out);
+    Rast_close_cell(fd_out);
     /* write out map metadata */
-    G_short_history(rast_out_name, "raster", &history);
+    Rast_short_history(rast_out_name, "raster", &history);
     strncpy(history.datsrc_1, rast_in_name, RECORD_LEN-1);
     history.datsrc_1[RECORD_LEN-1] = '\0';
@@ -36,7 +36,7 @@
     case SLOPE:
 	strcpy(map_type, "Magnitude of maximum gradient");
-	G_write_raster_units(rast_out_name, "degrees");
+	Rast_write_raster_units(rast_out_name, "degrees");
 	strcpy(history.edhist[0],
 	    "Slope is given for steepest slope angle and measured in degrees.");
@@ -45,7 +45,7 @@
     case ASPECT:
 	strcpy(map_type, "Direction of maximum gradient");
 	    "Flow direction (aspect): W=0, E=180, N=+90, S=-90 degrees");
@@ -117,11 +117,11 @@
 	break;
-    G_command_history(&history);
-    G_write_history(rast_out_name, &history);
+    Rast_command_history(&history);
+    Rast_write_history(rast_out_name, &history);
     sprintf(map_title, "DEM terrain parameter: %s", map_type);
-    G_put_cell_title(rast_out_name, map_title);
+    Rast_put_cell_title(rast_out_name, map_title);
     return;
Modified: grass/trunk/raster/r.param.scale/interface.c
--- grass/trunk/raster/r.param.scale/interface.c	2009-06-20 21:39:23 UTC (rev 38002)
+++ grass/trunk/raster/r.param.scale/interface.c	2009-06-20 22:03:23 UTC (rev 38003)
@@ -14,6 +14,7 @@
 #include <stdlib.h>
 #include <string.h>
 #include "param.h"
Modified: grass/trunk/raster/r.param.scale/nrutil.c
--- grass/trunk/raster/r.param.scale/nrutil.c	2009-06-20 21:39:23 UTC (rev 38002)
+++ grass/trunk/raster/r.param.scale/nrutil.c	2009-06-20 22:03:23 UTC (rev 38003)
@@ -2,6 +2,7 @@
 #include <stddef.h>
 #include <stdlib.h>
 #include "nrutil.h"
Modified: grass/trunk/raster/r.param.scale/open_files.c
--- grass/trunk/raster/r.param.scale/open_files.c	2009-06-20 21:39:23 UTC (rev 38002)
+++ grass/trunk/raster/r.param.scale/open_files.c	2009-06-20 22:03:23 UTC (rev 38003)
@@ -14,6 +14,7 @@
 #include "param.h"
@@ -22,17 +23,17 @@
     /* Open existing file and set the input file descriptor. */
-    if ((fd_in = G_open_cell_old(rast_in_name, "")) < 0)
+    if ((fd_in = Rast_open_cell_old(rast_in_name, "")) < 0)
 	G_fatal_error(_("Cannot open raster map <%s>"), rast_in_name);
     /* Open new file and set the output file descriptor. */
     if (mparam != FEATURE) {
-	if ((fd_out = G_open_raster_new(rast_out_name, DCELL_TYPE)) < 0)
+	if ((fd_out = Rast_open_raster_new(rast_out_name, DCELL_TYPE)) < 0)
 	    G_fatal_error(_("Cannot create raster map <%s>"), rast_out_name);
     else {
-	if ((fd_out = G_open_raster_new(rast_out_name, CELL_TYPE)) < 0)
+	if ((fd_out = Rast_open_raster_new(rast_out_name, CELL_TYPE)) < 0)
Modified: grass/trunk/raster/r.param.scale/param.h
--- grass/trunk/raster/r.param.scale/param.h	2009-06-20 21:39:23 UTC (rev 38002)
+++ grass/trunk/raster/r.param.scale/param.h	2009-06-20 22:03:23 UTC (rev 38003)
@@ -9,6 +9,7 @@
 				/* programs. It sets up the necessary   */
 				/* prototypes for GRASS library calls.  */
 #include <math.h>
Modified: grass/trunk/raster/r.param.scale/process.c
--- grass/trunk/raster/r.param.scale/process.c	2009-06-20 21:39:23 UTC (rev 38002)
+++ grass/trunk/raster/r.param.scale/process.c	2009-06-20 22:03:23 UTC (rev 38003)
@@ -15,6 +15,7 @@
 #include <stdlib.h>
 #include <grass/gmath.h>
 #include "param.h"
@@ -86,9 +87,9 @@
     /* Reserve `wsize' rows of memory.      */
-	row_out = G_allocate_raster_buf(DCELL_TYPE);	/* Initialise output row buffer.     */
+	row_out = Rast_allocate_raster_buf(DCELL_TYPE);	/* Initialise output row buffer.     */
     else
-	featrow_out = G_allocate_raster_buf(CELL_TYPE);	/* Initialise output row buffer.  */
+	featrow_out = Rast_allocate_raster_buf(CELL_TYPE);	/* Initialise output row buffer.  */
     window_ptr = (DCELL *) G_malloc(SQR(wsize) * sizeof(DCELL));
     /* Reserve enough memory for local wind. */
@@ -146,13 +147,13 @@
 	for (wind_row = 0; wind_row < EDGE; wind_row++)
-	    G_put_raster_row(fd_out, row_out, DCELL_TYPE);	/* Write out the edge cells as NULL.    */
+	    Rast_put_raster_row(fd_out, row_out, DCELL_TYPE);	/* Write out the edge cells as NULL.    */
     else
-	    G_put_raster_row(fd_out, featrow_out, CELL_TYPE);	/* Write out the edge cells as NULL.    */
+	    Rast_put_raster_row(fd_out, featrow_out, CELL_TYPE);	/* Write out the edge cells as NULL.    */
     for (wind_row = 0; wind_row < wsize - 1; wind_row++)
-	G_get_raster_row(fd_in, row_in + (wind_row * ncols), wind_row,
+	Rast_get_raster_row(fd_in, row_in + (wind_row * ncols), wind_row,
 			 DCELL_TYPE);
     /* Read in enough of the first rows to  */
     /* allow window to be examined.         */
@@ -160,7 +161,7 @@
     for (row = EDGE; row < (nrows - EDGE); row++) {
 	G_percent(row + 1, nrows - EDGE, 2);
-	G_get_raster_row(fd_in, row_in + ((wsize - 1) * ncols), row + EDGE,
+	Rast_get_raster_row(fd_in, row_in + ((wsize - 1) * ncols), row + EDGE,
 			 DCELL_TYPE);
 	for (col = EDGE; col < (ncols - EDGE); col++) {
@@ -210,10 +211,10 @@
-	    G_put_raster_row(fd_out, row_out, DCELL_TYPE);	/* Write the row buffer to the output   */
+	    Rast_put_raster_row(fd_out, row_out, DCELL_TYPE);	/* Write the row buffer to the output   */
 	/* raster.                              */
 	else			/* write FEATURE to CELL */
-	    G_put_raster_row(fd_out, featrow_out, CELL_TYPE);	/* Write the row buffer to the output       */
+	    Rast_put_raster_row(fd_out, featrow_out, CELL_TYPE);	/* Write the row buffer to the output       */
 	/* raster.                              */
 	/* 'Shuffle' rows down one, and read in */
@@ -226,9 +227,9 @@
     for (wind_row = 0; wind_row < EDGE; wind_row++) {
 	else
Modified: grass/trunk/raster/r.param.scale/write_cats.c
--- grass/trunk/raster/r.param.scale/write_cats.c	2009-06-20 21:39:23 UTC (rev 38002)
+++ grass/trunk/raster/r.param.scale/write_cats.c	2009-06-20 22:03:23 UTC (rev 38003)
@@ -13,6 +13,7 @@
 #include "param.h"
@@ -25,29 +26,29 @@
     /*                            INITIALISE                                  */
-    G_init_cats((CELL) 0, "", &cats);
-    G_set_raster_cats_title("Surface Features", &cats);
+    Rast_init_cats((CELL) 0, "", &cats);
+    Rast_set_raster_cats_title("Surface Features", &cats);
     /*                      FILL OUT CATEGORIES STRUCTURE                     */
-    G_set_cat(FLAT, " Planar", &cats);
-    G_set_cat(PIT, " Pit", &cats);
-    G_set_cat(PEAK, " Peak", &cats);
-    G_set_cat(RIDGE, " Ridge", &cats);
-    G_set_cat(CHANNEL, " Channel", &cats);
-    G_set_cat(PASS, " Pass (saddle)", &cats);
+    Rast_set_cat(FLAT, " Planar", &cats);
+    Rast_set_cat(PIT, " Pit", &cats);
+    Rast_set_cat(PEAK, " Peak", &cats);
+    Rast_set_cat(RIDGE, " Ridge", &cats);
+    Rast_set_cat(CHANNEL, " Channel", &cats);
+    Rast_set_cat(PASS, " Pass (saddle)", &cats);
     /*                     WRITE OUT CATEGORIES STRUCTURE                     */
-    if (G_write_cats(rast_out_name, &cats) <= 0)
+    if (Rast_write_cats(rast_out_name, &cats) <= 0)
 	G_warning(_("Cannot write category file for raster map <%s>"),
 		  rast_out_name);
-    G_free_cats(&cats);
+    Rast_free_cats(&cats);
     return;
Modified: grass/trunk/raster/r.param.scale/write_cols.c
--- grass/trunk/raster/r.param.scale/write_cols.c	2009-06-20 21:39:23 UTC (rev 38002)
+++ grass/trunk/raster/r.param.scale/write_cols.c	2009-06-20 22:03:23 UTC (rev 38003)
@@ -20,17 +20,17 @@
     struct Colors colours;
-    G_init_colors(&colours);
+    Rast_init_colors(&colours);
-    G_add_color_rule(FLAT, 180, 180, 180,	/* White      */
+    Rast_add_color_rule(FLAT, 180, 180, 180,	/* White      */
 		     PIT, 0, 0, 0, &colours);	/* Black      */
-    G_add_color_rule(CHANNEL, 0, 0, 255,	/* Blue       */
+    Rast_add_color_rule(CHANNEL, 0, 0, 255,	/* Blue       */
 		     PASS, 0, 255, 0, &colours);	/* Green      */
-    G_add_color_rule(RIDGE, 255, 255, 0,	/* Yellow     */
+    Rast_add_color_rule(RIDGE, 255, 255, 0,	/* Yellow     */
 		     PEAK, 255, 0, 0, &colours);	/* Red        */
-    G_write_colors(rast_out_name, G_mapset(), &colours);
+    Rast_write_colors(rast_out_name, G_mapset(), &colours);
-    G_free_colors(&colours);
+    Rast_free_colors(&colours);
Modified: grass/trunk/raster/r.patch/do_patch.c
--- grass/trunk/raster/r.patch/do_patch.c	2009-06-20 21:39:23 UTC (rev 38002)
+++ grass/trunk/raster/r.patch/do_patch.c	2009-06-20 22:03:23 UTC (rev 38003)
@@ -1,4 +1,5 @@
  * patch in non-zero data over zero data
  * keep track of the categories which are patched in
@@ -13,8 +14,8 @@
     /* insert 0 check here */
-    return G_is_null_value(rast, data_type) ||
-	G_get_raster_value_d(rast, data_type) != 0.0 ? 0 : 1;
+    return Rast_is_null_value(rast, data_type) ||
+	Rast_get_raster_value_d(rast, data_type) != 0.0 ? 0 : 1;
@@ -28,35 +29,35 @@
 	if (ZEROFLAG) {		/* use 0 for transparency instead of NULL */
 	    if (G_is_zero_value(result, out_type) ||
-		G_is_null_value(result, out_type)) {
+		Rast_is_null_value(result, out_type)) {
 		/* Don't patch hole with a null, just mark as more */
-		if (G_is_null_value(patch, out_type))
+		if (Rast_is_null_value(patch, out_type))
 		    more = 1;
 		else {
 		    /* Mark that there is more to be done if we patch with 0 */
 		    if (G_is_zero_value(patch, out_type))
 			more = 1;
-		    G_raster_cpy(result, patch, 1, out_type);
+		    Rast_raster_cpy(result, patch, 1, out_type);
-			G_update_cell_stats((CELL *) result, 1, statf);
+			Rast_update_cell_stats((CELL *) result, 1, statf);
 	    }			/* ZERO support */
 	else {			/* use NULL for transparency instead of 0 */
-	    if (G_is_null_value(result, out_type)) {
+	    if (Rast_is_null_value(result, out_type)) {
 		    more = 1;
 		else {
 	    }			/* NULL support */
-	result = G_incr_void_ptr(result, G_raster_size(out_type));
-	patch = G_incr_void_ptr(patch, G_raster_size(out_type));
+	result = Rast_incr_void_ptr(result, Rast_raster_size(out_type));
+	patch = Rast_incr_void_ptr(patch, Rast_raster_size(out_type));
     return more;
Modified: grass/trunk/raster/r.patch/main.c
--- grass/trunk/raster/r.patch/main.c	2009-06-20 21:39:23 UTC (rev 38002)
+++ grass/trunk/raster/r.patch/main.c	2009-06-20 22:03:23 UTC (rev 38003)
@@ -17,6 +17,7 @@
 #include <stdlib.h>
 #include <unistd.h>
 #include "nfiles.h"
 #include "local_proto.h"
@@ -98,7 +99,7 @@
 	if (!ok)
 	    continue;
 	if (fd < 0) {
 	    ok = 0;
 	    continue;
@@ -106,25 +107,25 @@
 	infd[i] = fd;
 	if (map_type == FCELL_TYPE && out_type == CELL_TYPE)
 	    out_type = FCELL_TYPE;
 	else if (map_type == DCELL_TYPE)
 	    out_type = DCELL_TYPE;
-	G_init_cell_stats(&statf[i]);
+	Rast_init_cell_stats(&statf[i]);
     if (!ok)
 	G_fatal_error(_("One or more input raster maps not found"));
     rname = opt2->answer;
-    outfd = G_open_raster_new(new_name = rname, out_type);
+    outfd = Rast_open_raster_new(new_name = rname, out_type);
     if (outfd < 0)
 	G_fatal_error(_("Unable to create raster map <%s>"), new_name);
-    presult = G_allocate_raster_buf(out_type);
-    patch = G_allocate_raster_buf(out_type);
+    presult = Rast_allocate_raster_buf(out_type);
+    patch = Rast_allocate_raster_buf(out_type);
@@ -132,28 +133,28 @@
     G_verbose_message(_("Percent complete..."));
     for (row = 0; row < nrows; row++) {
-	if (G_get_raster_row(infd[0], presult, row, out_type) < 0)
+	if (Rast_get_raster_row(infd[0], presult, row, out_type) < 0)
 	    G_fatal_error(_("Unable to read raster map <%s> row %d"),
 			  names[0], row);
-	    G_update_cell_stats((CELL *) presult, ncols, &statf[0]);
+	    Rast_update_cell_stats((CELL *) presult, ncols, &statf[0]);
 	for (i = 1; i < nfiles; i++) {
-	    if (G_get_raster_row(infd[i], patch, row, out_type) < 0)
+	    if (Rast_get_raster_row(infd[i], patch, row, out_type) < 0)
 			      names[i], row);
 	    if (!do_patch
 		(presult, patch, &statf[i], ncols, out_type, ZEROFLAG))
 		break;
-	G_put_raster_row(outfd, presult, out_type);
+	Rast_put_raster_row(outfd, presult, out_type);
     G_free(patch);
     G_free(presult);
     for (i = 0; i < nfiles; i++)
-	G_close_cell(infd[i]);
+	Rast_close_cell(infd[i]);
      * build the new cats and colors. do this before closing the new
      * file, in case the new file is one of the patching files as well.
@@ -162,15 +163,15 @@
     support(names, statf, nfiles, &cats, &cats_ok, &colr, &colr_ok, out_type);
     /* now close (and create) the result */
-    G_close_cell(outfd);
+    Rast_close_cell(outfd);
     if (cats_ok)
-	G_write_cats(new_name, &cats);
+	Rast_write_cats(new_name, &cats);
     if (colr_ok)
-	G_write_colors(new_name, G_mapset(), &colr);
+	Rast_write_colors(new_name, G_mapset(), &colr);
-    G_short_history(new_name, "raster", &history);
-    G_write_history(new_name, &history);
+    Rast_short_history(new_name, "raster", &history);
+    Rast_write_history(new_name, &history);
     exit(EXIT_SUCCESS);
Modified: grass/trunk/raster/r.patch/support.c
--- grass/trunk/raster/r.patch/support.c	2009-06-20 21:39:23 UTC (rev 38002)
+++ grass/trunk/raster/r.patch/support.c	2009-06-20 22:03:23 UTC (rev 38003)
@@ -1,4 +1,5 @@
  * creates new category and color structures from the patching
  * files category and color files
@@ -26,10 +27,10 @@
     *cats_ok = 1;
     *colr_ok = 1;
-    if (G_read_cats(names[0], "", cats) < 0)
+    if (Rast_read_cats(names[0], "", cats) < 0)
 	*cats_ok = 0;
-    if (G_read_colors(names[0], "", colr) < 0)
+    if (Rast_read_colors(names[0], "", colr) < 0)
 	*colr_ok = 0;
@@ -37,33 +38,33 @@
 	return 0;
-	do_cats = *cats_ok && (G_read_cats(names[i], "", &pcats) >= 0);
+	do_cats = *cats_ok && (Rast_read_cats(names[i], "", &pcats) >= 0);
-	do_colr = *colr_ok && (G_read_colors(names[i], "", &pcolr) >= 0);
+	do_colr = *colr_ok && (Rast_read_colors(names[i], "", &pcolr) >= 0);
 	if (!do_cats && !do_colr)
 	    continue;
-	    G_rewind_cell_stats(statf + i);
-	    while (G_next_cell_stat(&n, &count, statf + i))
-		if (n && !G_find_cell_stat(n, &count, statf)) {
+	    Rast_rewind_cell_stats(statf + i);
+	    while (Rast_next_cell_stat(&n, &count, statf + i))
+		if (n && !Rast_find_cell_stat(n, &count, statf)) {
 		    if (do_cats) {
-			G_update_cell_stats(&n, 1, statf);
-			G_set_cat(n, G_get_cat(n, &pcats), cats);
+			Rast_update_cell_stats(&n, 1, statf);
+			Rast_set_cat(n, Rast_get_cat(n, &pcats), cats);
 		    if (do_colr) {
-			G_get_color(n, &red, &grn, &blu, &pcolr);
-			G_set_color(n, red, grn, blu, colr);
+			Rast_get_color(n, &red, &grn, &blu, &pcolr);
+			Rast_set_color(n, red, grn, blu, colr);
 	/* else the color will be the color of the first map */
 	if (do_cats)
-	    G_free_cats(&pcats);
+	    Rast_free_cats(&pcats);
 	if (do_colr)
 	    /* otherwise this memory is used in colr pointer */
-	    G_free_colors(&pcolr);
+	    Rast_free_colors(&pcolr);
     return 1;
Modified: grass/trunk/raster/r.profile/local_proto.h
--- grass/trunk/raster/r.profile/local_proto.h	2009-06-20 21:39:23 UTC (rev 38002)
+++ grass/trunk/raster/r.profile/local_proto.h	2009-06-20 22:03:23 UTC (rev 38003)
@@ -3,6 +3,7 @@
 #include <string.h>
 #include <math.h>
 /* main.c */
Modified: grass/trunk/raster/r.profile/main.c
--- grass/trunk/raster/r.profile/main.c	2009-06-20 21:39:23 UTC (rev 38002)
+++ grass/trunk/raster/r.profile/main.c	2009-06-20 22:03:23 UTC (rev 38003)
@@ -9,6 +9,7 @@
 #include <stdlib.h>
@@ -128,12 +129,12 @@
 	coords = 1;
     /* Open Raster File */
-    if ((fd = G_open_cell_old(name, "")) < 0)
+    if ((fd = Rast_open_cell_old(name, "")) < 0)
     /* initialize color structure */
     if (clr)
-	G_read_colors(name, "", &colors);
+	Rast_read_colors(name, "", &colors);
     /* Open ASCII file for output or stdout */
     outfile = parm.output->answer;
@@ -145,7 +146,7 @@
 	G_fatal_error(_("Unable to open file <%s>"), outfile);
     /* Get Raster Type */
     /* Done with file */
     /* Show message giving output format */
@@ -212,11 +213,11 @@
-    G_close_cell(fd);
     fclose(fp);
     if (clr)
     exit(EXIT_SUCCESS);
 }				/* Done with main */
Modified: grass/trunk/raster/r.profile/read_rast.c
--- grass/trunk/raster/r.profile/read_rast.c	2009-06-20 21:39:23 UTC (rev 38002)
+++ grass/trunk/raster/r.profile/read_rast.c	2009-06-20 22:03:23 UTC (rev 38003)
@@ -8,6 +8,7 @@
@@ -23,8 +24,8 @@
     int outofbounds = FALSE;
     if (!dcell) {
-	G_set_c_null_value(&nullcell, 1);
+	Rast_set_c_null_value(&nullcell, 1);
 	nrows = window.rows;
 	ncols = window.cols;
@@ -38,7 +39,7 @@
 	outofbounds = TRUE;
     if (!outofbounds) {
-	if (row != cur_row && G_get_d_raster_row(fd, dcell, row) < 0)
+	if (row != cur_row && Rast_get_d_raster_row(fd, dcell, row) < 0)
 	    G_fatal_error(_("Unable to read raster map row %d"), row);
 	cur_row = row;
@@ -48,7 +49,7 @@
     fprintf(fp, " %f", dist);
-    if (outofbounds || G_is_d_null_value(&dcell[col]))
+    if (outofbounds || Rast_is_d_null_value(&dcell[col]))
 	fprintf(fp, " %s", null_string);
     else {
 	if (data_type == CELL_TYPE)
@@ -61,9 +62,9 @@
 	int red, green, blue;
 	if (outofbounds)
-	    G_get_color(nullcell, &red, &green, &blue, &colors);
+	    Rast_get_color(nullcell, &red, &green, &blue, &colors);
 	else
-	    G_get_d_raster_color(&dcell[col], &red, &green, &blue,
+	    Rast_get_d_raster_color(&dcell[col], &red, &green, &blue,
 				 &colors);
 	fprintf(fp, " %03d:%03d:%03d", red, green, blue);
Modified: grass/trunk/raster/r.proj/bilinear.c
--- grass/trunk/raster/r.proj/bilinear.c	2009-06-20 21:39:23 UTC (rev 38002)
+++ grass/trunk/raster/r.proj/bilinear.c	2009-06-20 22:03:23 UTC (rev 38003)
@@ -12,6 +12,7 @@
 #include <math.h>
 #include "r.proj.h"
 void p_bilinear(struct cache *ibuffer,	/* input buffer                  */
@@ -39,7 +40,7 @@
     /* check for out of bounds - if out of bounds set NULL value and return */
     if (row0 < 0 || row1 >= cellhd->rows || col0 < 0 || col1 >= cellhd->cols) {
-	G_set_null_value(obufptr, 1, cell_type);
+	Rast_set_null_value(obufptr, 1, cell_type);
 	return;
@@ -49,10 +50,10 @@
     c11 = CPTR(ibuffer, row1, col1);
     /* check for NULL values */
-    if (G_is_f_null_value(c00) ||
-	G_is_f_null_value(c01) ||
-	G_is_f_null_value(c10) || G_is_f_null_value(c11)) {
+    if (Rast_is_f_null_value(c00) ||
+	Rast_is_f_null_value(c01) ||
+	Rast_is_f_null_value(c10) || Rast_is_f_null_value(c11)) {
