[GRASS-SVN] r38014 - in grass/trunk: display/d.colortable
display/d.graph display/d.grid display/d.his
display/d.histogram display/d.labels display/d.legend
display/d.nviz display/d.path display/d.profile
display/d.rast display/d.rast.arrow display/d.rast.num
display/d.rgb display/d.thematic.area display/d.title
display/d.vect display/d.vect.chart general/g.mremove
general/g.region general/g.remove general/g.rename
general/manage/lister imagery/i.albedo imagery/i.atcorr
imagery/i.cca imagery/i.cluster imagery/i.eb.eta
imagery/i.eb.evapfr imagery/i.eb.h_SEBAL01
imagery/i.eb.soilheatflux imagery/i.emissivity
imagery/i.evapo.time_integration imagery/i.fft
imagery/i.gensig imagery/i.gensigset imagery/i.his.rgb
imagery/i.ifft imagery/i.latlong imagery/i.maxlik
imagery/i.modis.qc imagery/i.pca imagery/i.rectify
imagery/i.rgb.his imagery/i.smap imagery/i.sunhours
imagery/i.vi imagery/i.zc include include/Make lib/cluster
lib/display lib/g3d lib/gpde lib/nviz lib/ogsf lib/raster
lib/rst/interp_float lib/stats ps/ps.map raster/r.basins.fill
raster/r.bitpattern raster/r.buffer raster/r.carve
raster/r.category raster/r.circle raster/r.clump
raster/r.coin raster/r.colors raster/r.colors.out
raster/r.composite raster/r.compress raster/r.contour
raster/r.cost raster/r.covar raster/r.cross raster/r.describe
raster/r.distance raster/r.drain raster/r.external
raster/r.fill.dir raster/r.flow raster/r.grow.distance
raster/r.gwflow raster/r.his raster/r.horizon raster/r.in.arc
raster/r.in.ascii raster/r.in.bin raster/r.in.gdal
raster/r.in.gridatb raster/r.in.mat raster/r.in.poly
raster/r.in.xyz raster/r.info raster/r.kappa raster/r.lake
raster/r.le/r.le.patch raster/r.le/r.le.pixel
raster/r.le/r.le.setup raster/r.le/r.le.trace
raster/r.li/r.li.cwed raster/r.li/r.li.daemon
raster/r.li/r.li.dominance raster/r.li/r.li.edgedensity
raster/r.li/r.li.mpa raster/r.li/r.li.mps
raster/r.li/r.li.padcv raster/r.li/r.li.padrange
raster/r.li/r.li.padsd raster/r.li/r.li.patchdensity
raster/r.li/r.li.patchnum raster/r.li/r.li.richness
raster/r.li/r.li.shannon raster/r.li/r.li.shape
raster/r.li/r.li.simpson raster/r.los raster/r.mapcalc
raster/r.mfilter raster/r.mode raster/r.neighbors
raster/r.null raster/r.out.arc raster/r.out.ascii
raster/r.out.bin raster/r.out.gdal raster/r.out.gridatb
raster/r.out.mat raster/r.out.mpeg raster/r.out.png
raster/r.out.pov raster/r.out.ppm raster/r.out.ppm3
raster/r.out.tiff raster/r.out.vrml raster/r.out.vtk
raster/r.param.scale raster/r.patch raster/r.profile
raster/r.proj raster/r.quant raster/r.quantile
raster/r.random raster/r.random.cells raster/r.random.surface
raster/r.reclass raster/r.recode raster/r.region
raster/r.report raster/r.resamp.interp raster/r.resamp.rst
raster/r.resamp.stats raster/r.resample raster/r.rescale
raster/r.rescale.eq raster/r.ros raster/r.series
raster/r.slope.aspect raster/r.spread raster/r.spreadpath
raster/r.statistics raster/r.statistics2 raster/r.statistics3
raster/r.stats raster/r.sun2 raster/r.sunmask
raster/r.support raster/r.support.stats raster/r.surf.area
raster/r.surf.contour raster/r.surf.fractal
raster/r.surf.gauss raster/r.surf.idw raster/r.surf.idw2
raster/r.surf.random raster/r.terraflow raster/r.texture
raster/r.thin raster/r.to.rast3 raster/r.to.rast3elev
raster/r.to.vect raster/r.topidx raster/r.topmodel
raster/r.univar raster/r.uslek raster/r.usler raster/r.volume
raster/r.walk raster/r.water.outlet raster/r.watershed/front
raster/r.watershed/ram raster/r.watershed/seg
raster/r.watershed/shed raster/r.what raster/r.what.color
raster3d/r3.cross.rast raster3d/r3.gwflow raster3d/r3.mkdspf
raster3d/r3.out.vtk raster3d/r3.to.rast swig/python
vector/lidar/lidarlib vector/lidar/v.lidar.correction
vector/lidar/v.lidar.edgedetection
vector/lidar/v.lidar.growing vector/lidar/v.outlier
vector/lidar/v.surf.bspline vector/v.convert vector/v.drape
vector/v.extrude vector/v.kernel vector/v.neighbors
vector/v.sample vector/v.surf.idw vector/v.to.rast
vector/v.vol.rst vector/v.what.rast visualization/xganim
svn_grass at osgeo.org
Sun Jun 21 21:49:16 EDT 2009
Author: glynn
Date: 2009-06-21 21:49:13 -0400 (Sun, 21 Jun 2009)
New Revision: 38014
Added:
grass/trunk/include/raster.h
Removed:
grass/trunk/include/Rast.h
grass/trunk/display/d.colortable/main.c
grass/trunk/display/d.graph/do_graph.c
grass/trunk/display/d.graph/graphics.c
grass/trunk/display/d.graph/main.c
grass/trunk/display/d.grid/fiducial.c
grass/trunk/display/d.grid/main.c
grass/trunk/display/d.grid/plot.c
grass/trunk/display/d.grid/plotborder.c
grass/trunk/display/d.his/his.c
grass/trunk/display/d.his/main.c
grass/trunk/display/d.histogram/bar.c
grass/trunk/display/d.histogram/draw_slice.c
grass/trunk/display/d.histogram/get_stats.c
grass/trunk/display/d.histogram/main.c
grass/trunk/display/d.histogram/pie.c
grass/trunk/display/d.labels/color.c
grass/trunk/display/d.labels/do_labels.c
grass/trunk/display/d.labels/main.c
grass/trunk/display/d.legend/main.c
grass/trunk/display/d.nviz/main.c
grass/trunk/display/d.path/main.c
grass/trunk/display/d.path/select.c
grass/trunk/display/d.profile/main.c
grass/trunk/display/d.rast.arrow/main.c
grass/trunk/display/d.rast.num/main.c
grass/trunk/display/d.rast/display.c
grass/trunk/display/d.rast/main.c
grass/trunk/display/d.rast/mask.c
grass/trunk/display/d.rgb/main.c
grass/trunk/display/d.thematic.area/area.c
grass/trunk/display/d.thematic.area/main.c
grass/trunk/display/d.thematic.area/plot1.c
grass/trunk/display/d.title/fancy.c
grass/trunk/display/d.title/main.c
grass/trunk/display/d.title/normal.c
grass/trunk/display/d.vect.chart/bar.c
grass/trunk/display/d.vect.chart/main.c
grass/trunk/display/d.vect.chart/pie.c
grass/trunk/display/d.vect.chart/plot.c
grass/trunk/display/d.vect/area.c
grass/trunk/display/d.vect/attr.c
grass/trunk/display/d.vect/dir.c
grass/trunk/display/d.vect/label.c
grass/trunk/display/d.vect/main.c
grass/trunk/display/d.vect/plot1.c
grass/trunk/display/d.vect/topo.c
grass/trunk/display/d.vect/utils.c
grass/trunk/display/d.vect/zcoor.c
grass/trunk/general/g.mremove/check_reclass.c
grass/trunk/general/g.mremove/wc2regex.c
grass/trunk/general/g.region/adjust.c
grass/trunk/general/g.region/main.c
grass/trunk/general/g.region/printwindow.c
grass/trunk/general/g.region/zoom.c
grass/trunk/general/g.remove/main.c
grass/trunk/general/g.rename/main.c
grass/trunk/general/manage/lister/Makefile
grass/trunk/general/manage/lister/cell.c
grass/trunk/general/manage/lister/vector.c
grass/trunk/imagery/i.albedo/Makefile
grass/trunk/imagery/i.albedo/main.c
grass/trunk/imagery/i.atcorr/Makefile
grass/trunk/imagery/i.atcorr/main.cpp
grass/trunk/imagery/i.cca/Makefile
grass/trunk/imagery/i.cca/main.c
grass/trunk/imagery/i.cca/matrix.c
grass/trunk/imagery/i.cca/stats.c
grass/trunk/imagery/i.cca/transform.c
grass/trunk/imagery/i.cluster/Makefile
grass/trunk/imagery/i.cluster/checkpt.c
grass/trunk/imagery/i.cluster/main.c
grass/trunk/imagery/i.cluster/open_files.c
grass/trunk/imagery/i.cluster/print1.c
grass/trunk/imagery/i.cluster/print2.c
grass/trunk/imagery/i.cluster/print3.c
grass/trunk/imagery/i.cluster/print4.c
grass/trunk/imagery/i.cluster/print5.c
grass/trunk/imagery/i.cluster/print6.c
grass/trunk/imagery/i.cluster/timer.c
grass/trunk/imagery/i.eb.eta/Makefile
grass/trunk/imagery/i.eb.eta/main.c
grass/trunk/imagery/i.eb.evapfr/Makefile
grass/trunk/imagery/i.eb.evapfr/main.c
grass/trunk/imagery/i.eb.h_SEBAL01/Makefile
grass/trunk/imagery/i.eb.h_SEBAL01/main.c
grass/trunk/imagery/i.eb.soilheatflux/Makefile
grass/trunk/imagery/i.eb.soilheatflux/main.c
grass/trunk/imagery/i.emissivity/Makefile
grass/trunk/imagery/i.emissivity/main.c
grass/trunk/imagery/i.evapo.time_integration/Makefile
grass/trunk/imagery/i.evapo.time_integration/main.c
grass/trunk/imagery/i.fft/Makefile
grass/trunk/imagery/i.fft/main.c
grass/trunk/imagery/i.gensig/Makefile
grass/trunk/imagery/i.gensig/alloc.c
grass/trunk/imagery/i.gensig/can_invert.c
grass/trunk/imagery/i.gensig/closefiles.c
grass/trunk/imagery/i.gensig/covariance.c
grass/trunk/imagery/i.gensig/eigen.c
grass/trunk/imagery/i.gensig/get_train.c
grass/trunk/imagery/i.gensig/labels.c
grass/trunk/imagery/i.gensig/lookup_class.c
grass/trunk/imagery/i.gensig/means.c
grass/trunk/imagery/i.gensig/openfiles.c
grass/trunk/imagery/i.gensig/parse.c
grass/trunk/imagery/i.gensig/read_train.c
grass/trunk/imagery/i.gensigset/Makefile
grass/trunk/imagery/i.gensigset/closefiles.c
grass/trunk/imagery/i.gensigset/get_train.c
grass/trunk/imagery/i.gensigset/invert.c
grass/trunk/imagery/i.gensigset/labels.c
grass/trunk/imagery/i.gensigset/lookup_class.c
grass/trunk/imagery/i.gensigset/main.c
grass/trunk/imagery/i.gensigset/openfiles.c
grass/trunk/imagery/i.gensigset/parse.c
grass/trunk/imagery/i.gensigset/read_data.c
grass/trunk/imagery/i.gensigset/read_train.c
grass/trunk/imagery/i.gensigset/subcluster.c
grass/trunk/imagery/i.his.rgb/Makefile
grass/trunk/imagery/i.his.rgb/closefiles.c
grass/trunk/imagery/i.his.rgb/his2rgb.c
grass/trunk/imagery/i.his.rgb/main.c
grass/trunk/imagery/i.his.rgb/openfiles.c
grass/trunk/imagery/i.ifft/Makefile
grass/trunk/imagery/i.ifft/main.c
grass/trunk/imagery/i.latlong/Makefile
grass/trunk/imagery/i.latlong/main.c
grass/trunk/imagery/i.maxlik/Makefile
grass/trunk/imagery/i.maxlik/classify.c
grass/trunk/imagery/i.maxlik/hist.c
grass/trunk/imagery/i.maxlik/invert.c
grass/trunk/imagery/i.maxlik/main.c
grass/trunk/imagery/i.maxlik/open.c
grass/trunk/imagery/i.modis.qc/Makefile
grass/trunk/imagery/i.modis.qc/main.c
grass/trunk/imagery/i.pca/Makefile
grass/trunk/imagery/i.pca/main.c
grass/trunk/imagery/i.pca/support.c
grass/trunk/imagery/i.rectify/Makefile
grass/trunk/imagery/i.rectify/crs.c
grass/trunk/imagery/i.rectify/exec.c
grass/trunk/imagery/i.rectify/main.c
grass/trunk/imagery/i.rectify/perform.c
grass/trunk/imagery/i.rectify/rectify.c
grass/trunk/imagery/i.rectify/write.c
grass/trunk/imagery/i.rgb.his/Makefile
grass/trunk/imagery/i.rgb.his/closefiles.c
grass/trunk/imagery/i.rgb.his/main.c
grass/trunk/imagery/i.rgb.his/openfiles.c
grass/trunk/imagery/i.rgb.his/rgb2his.c
grass/trunk/imagery/i.smap/Makefile
grass/trunk/imagery/i.smap/closefiles.c
grass/trunk/imagery/i.smap/decimate.c
grass/trunk/imagery/i.smap/history.c
grass/trunk/imagery/i.smap/interp.c
grass/trunk/imagery/i.smap/invert.c
grass/trunk/imagery/i.smap/labels.c
grass/trunk/imagery/i.smap/model.c
grass/trunk/imagery/i.smap/multialloc.c
grass/trunk/imagery/i.smap/opencell.c
grass/trunk/imagery/i.smap/openfiles.c
grass/trunk/imagery/i.smap/parse.c
grass/trunk/imagery/i.smap/read_block.c
grass/trunk/imagery/i.smap/write_img.c
grass/trunk/imagery/i.sunhours/Makefile
grass/trunk/imagery/i.sunhours/main.c
grass/trunk/imagery/i.vi/Makefile
grass/trunk/imagery/i.vi/main.c
grass/trunk/imagery/i.zc/Makefile
grass/trunk/imagery/i.zc/main.c
grass/trunk/include/Make/Grass.make
grass/trunk/lib/cluster/c_point.c
grass/trunk/lib/display/Makefile
grass/trunk/lib/display/raster.c
grass/trunk/lib/display/raster2.c
grass/trunk/lib/display/setup.c
grass/trunk/lib/display/tran_colr.c
grass/trunk/lib/g3d/Makefile
grass/trunk/lib/g3d/g3dcats.c
grass/trunk/lib/g3d/g3dclose.c
grass/trunk/lib/g3d/g3dcolor.c
grass/trunk/lib/g3d/g3dfpxdr.c
grass/trunk/lib/g3d/g3dmisc.c
grass/trunk/lib/g3d/g3dnull.c
grass/trunk/lib/g3d/g3drange.c
grass/trunk/lib/g3d/g3dregion.c
grass/trunk/lib/g3d/g3dvolume.c
grass/trunk/lib/g3d/getblock.c
grass/trunk/lib/g3d/tileread.c
grass/trunk/lib/g3d/tilewrite.c
grass/trunk/lib/gpde/Makefile
grass/trunk/lib/gpde/N_arrays.c
grass/trunk/lib/gpde/N_arrays_calc.c
grass/trunk/lib/gpde/N_arrays_io.c
grass/trunk/lib/gpde/N_pde.h
grass/trunk/lib/nviz/Makefile
grass/trunk/lib/nviz/nviz.c
grass/trunk/lib/ogsf/GS2.c
grass/trunk/lib/ogsf/Gp3.c
grass/trunk/lib/ogsf/Gs3.c
grass/trunk/lib/ogsf/Gvl3.c
grass/trunk/lib/ogsf/Makefile
grass/trunk/lib/ogsf/gsd_legend.c
grass/trunk/lib/raster/Makefile
grass/trunk/lib/raster/alloc_cell.c
grass/trunk/lib/raster/auto_mask.c
grass/trunk/lib/raster/cats.c
grass/trunk/lib/raster/cell_stats.c
grass/trunk/lib/raster/cellstats_eq.c
grass/trunk/lib/raster/closecell.c
grass/trunk/lib/raster/color_compat.c
grass/trunk/lib/raster/color_free.c
grass/trunk/lib/raster/color_get.c
grass/trunk/lib/raster/color_hist.c
grass/trunk/lib/raster/color_look.c
grass/trunk/lib/raster/color_org.c
grass/trunk/lib/raster/color_rand.c
grass/trunk/lib/raster/color_read.c
grass/trunk/lib/raster/color_rule.c
grass/trunk/lib/raster/color_rules.c
grass/trunk/lib/raster/color_set.c
grass/trunk/lib/raster/color_write.c
grass/trunk/lib/raster/color_xform.c
grass/trunk/lib/raster/format.c
grass/trunk/lib/raster/fpreclass.c
grass/trunk/lib/raster/gdal.c
grass/trunk/lib/raster/get_cellhd.c
grass/trunk/lib/raster/get_row.c
grass/trunk/lib/raster/get_row_colr.c
grass/trunk/lib/raster/histo_eq.c
grass/trunk/lib/raster/histogram.c
grass/trunk/lib/raster/init.c
grass/trunk/lib/raster/mask_info.c
grass/trunk/lib/raster/maskfd.c
grass/trunk/lib/raster/null_val.c
grass/trunk/lib/raster/opencell.c
grass/trunk/lib/raster/put_row.c
grass/trunk/lib/raster/quant.c
grass/trunk/lib/raster/quant_io.c
grass/trunk/lib/raster/quant_rw.c
grass/trunk/lib/raster/range.c
grass/trunk/lib/raster/raster.c
grass/trunk/lib/raster/raster_metadata.c
grass/trunk/lib/raster/reclass.c
grass/trunk/lib/raster/sample.c
grass/trunk/lib/raster/set_window.c
grass/trunk/lib/raster/zero_cell.c
grass/trunk/lib/rst/interp_float/Makefile
grass/trunk/lib/rst/interp_float/input2d.c
grass/trunk/lib/rst/interp_float/interp2d.c
grass/trunk/lib/rst/interp_float/output2d.c
grass/trunk/lib/rst/interp_float/resout2d.c
grass/trunk/lib/rst/interp_float/ressegm2d.c
grass/trunk/lib/stats/Makefile
grass/trunk/lib/stats/c_ave.c
grass/trunk/lib/stats/c_count.c
grass/trunk/lib/stats/c_intr.c
grass/trunk/lib/stats/c_kurt.c
grass/trunk/lib/stats/c_max.c
grass/trunk/lib/stats/c_maxx.c
grass/trunk/lib/stats/c_median.c
grass/trunk/lib/stats/c_min.c
grass/trunk/lib/stats/c_minx.c
grass/trunk/lib/stats/c_mode.c
grass/trunk/lib/stats/c_percentile.c
grass/trunk/lib/stats/c_range.c
grass/trunk/lib/stats/c_reg.c
grass/trunk/lib/stats/c_skew.c
grass/trunk/lib/stats/c_stddev.c
grass/trunk/lib/stats/c_sum.c
grass/trunk/lib/stats/c_var.c
grass/trunk/lib/stats/sort_cell.c
grass/trunk/ps/ps.map/Makefile
grass/trunk/ps/ps.map/catval.c
grass/trunk/ps/ps.map/distance.c
grass/trunk/ps/ps.map/do_geogrid.c
grass/trunk/ps/ps.map/do_masking.c
grass/trunk/ps/ps.map/do_plt.c
grass/trunk/ps/ps.map/do_psfiles.c
grass/trunk/ps/ps.map/do_vectors.c
grass/trunk/ps/ps.map/error.c
grass/trunk/ps/ps.map/get_font.c
grass/trunk/ps/ps.map/input.c
grass/trunk/ps/ps.map/main.c
grass/trunk/ps/ps.map/makeprocs.c
grass/trunk/ps/ps.map/map_setup.c
grass/trunk/ps/ps.map/outl_io.c
grass/trunk/ps/ps.map/parse_list.c
grass/trunk/ps/ps.map/ps_header.c
grass/trunk/ps/ps.map/ps_info.h
grass/trunk/ps/ps.map/ps_outline.c
grass/trunk/ps/ps.map/ps_raster.c
grass/trunk/ps/ps.map/ps_vareas.c
grass/trunk/ps/ps.map/ps_vlines.c
grass/trunk/ps/ps.map/r_group.c
grass/trunk/ps/ps.map/r_labels.c
grass/trunk/ps/ps.map/r_vareas.c
grass/trunk/ps/ps.map/r_vpoints.c
grass/trunk/ps/ps.map/read_cfg.c
grass/trunk/ps/ps.map/scale.c
grass/trunk/ps/ps.map/scan_gis.c
grass/trunk/ps/ps.map/session.c
grass/trunk/ps/ps.map/vect.c
grass/trunk/ps/ps.map/vector.c
grass/trunk/raster/r.basins.fill/Makefile
grass/trunk/raster/r.basins.fill/main.c
grass/trunk/raster/r.basins.fill/read_map.c
grass/trunk/raster/r.bitpattern/Makefile
grass/trunk/raster/r.bitpattern/main.c
grass/trunk/raster/r.buffer/Makefile
grass/trunk/raster/r.buffer/distance.h
grass/trunk/raster/r.buffer/find_dist.c
grass/trunk/raster/r.buffer/init.c
grass/trunk/raster/r.carve/Makefile
grass/trunk/raster/r.carve/enforce.h
grass/trunk/raster/r.carve/enforce_ds.c
grass/trunk/raster/r.carve/main.c
grass/trunk/raster/r.carve/raster.c
grass/trunk/raster/r.carve/support.c
grass/trunk/raster/r.carve/vect.c
grass/trunk/raster/r.category/Makefile
grass/trunk/raster/r.category/cats.c
grass/trunk/raster/r.category/main.c
grass/trunk/raster/r.circle/Makefile
grass/trunk/raster/r.circle/main.c
grass/trunk/raster/r.clump/Makefile
grass/trunk/raster/r.clump/clump.c
grass/trunk/raster/r.clump/main.c
grass/trunk/raster/r.coin/Makefile
grass/trunk/raster/r.coin/coin.h
grass/trunk/raster/r.coin/main.c
grass/trunk/raster/r.coin/make_coin.c
grass/trunk/raster/r.colors.out/Makefile
grass/trunk/raster/r.colors.out/main.c
grass/trunk/raster/r.colors/Makefile
grass/trunk/raster/r.colors/local_proto.h
grass/trunk/raster/r.colors/main.c
grass/trunk/raster/r.colors/rules.c
grass/trunk/raster/r.colors/stats.c
grass/trunk/raster/r.composite/Makefile
grass/trunk/raster/r.composite/main.c
grass/trunk/raster/r.compress/Makefile
grass/trunk/raster/r.compress/main.c
grass/trunk/raster/r.contour/Makefile
grass/trunk/raster/r.contour/cont.c
grass/trunk/raster/r.contour/main.c
grass/trunk/raster/r.cost/Makefile
grass/trunk/raster/r.cost/btree.c
grass/trunk/raster/r.cost/main.c
grass/trunk/raster/r.cost/memory.c
grass/trunk/raster/r.covar/Makefile
grass/trunk/raster/r.covar/main.c
grass/trunk/raster/r.cross/Makefile
grass/trunk/raster/r.cross/glob.h
grass/trunk/raster/r.describe/Makefile
grass/trunk/raster/r.describe/describe.c
grass/trunk/raster/r.describe/dumplist.c
grass/trunk/raster/r.describe/main.c
grass/trunk/raster/r.describe/tree.c
grass/trunk/raster/r.distance/Makefile
grass/trunk/raster/r.distance/defs.h
grass/trunk/raster/r.distance/main.c
grass/trunk/raster/r.distance/parse.c
grass/trunk/raster/r.drain/Makefile
grass/trunk/raster/r.drain/filldir.c
grass/trunk/raster/r.drain/main.c
grass/trunk/raster/r.drain/resolve.c
grass/trunk/raster/r.drain/tinf.c
grass/trunk/raster/r.external/Makefile
grass/trunk/raster/r.external/main.c
grass/trunk/raster/r.fill.dir/Makefile
grass/trunk/raster/r.fill.dir/dopolys.c
grass/trunk/raster/r.fill.dir/filldir.c
grass/trunk/raster/r.fill.dir/main.c
grass/trunk/raster/r.fill.dir/ppupdate.c
grass/trunk/raster/r.fill.dir/resolve.c
grass/trunk/raster/r.fill.dir/tinf.c
grass/trunk/raster/r.fill.dir/wtrshed.c
grass/trunk/raster/r.flow/Makefile
grass/trunk/raster/r.flow/aspect.c
grass/trunk/raster/r.flow/aspect.h
grass/trunk/raster/r.flow/io.h
grass/trunk/raster/r.flow/main.c
grass/trunk/raster/r.flow/mem.c
grass/trunk/raster/r.flow/mem.h
grass/trunk/raster/r.flow/precomp.c
grass/trunk/raster/r.flow/r.flow.h
grass/trunk/raster/r.grow.distance/Makefile
grass/trunk/raster/r.grow.distance/main.c
grass/trunk/raster/r.gwflow/main.c
grass/trunk/raster/r.his/Makefile
grass/trunk/raster/r.his/his.c
grass/trunk/raster/r.his/main.c
grass/trunk/raster/r.horizon/Makefile
grass/trunk/raster/r.horizon/main.c
grass/trunk/raster/r.in.arc/Makefile
grass/trunk/raster/r.in.arc/gethead.c
grass/trunk/raster/r.in.arc/main.c
grass/trunk/raster/r.in.ascii/Makefile
grass/trunk/raster/r.in.ascii/gethead.c
grass/trunk/raster/r.in.ascii/main.c
grass/trunk/raster/r.in.bin/Makefile
grass/trunk/raster/r.in.bin/main.c
grass/trunk/raster/r.in.gdal/Makefile
grass/trunk/raster/r.in.gdal/main.c
grass/trunk/raster/r.in.gridatb/Makefile
grass/trunk/raster/r.in.gridatb/file_io.c
grass/trunk/raster/r.in.gridatb/local_proto.h
grass/trunk/raster/r.in.gridatb/main.c
grass/trunk/raster/r.in.mat/Makefile
grass/trunk/raster/r.in.mat/main.c
grass/trunk/raster/r.in.poly/Makefile
grass/trunk/raster/r.in.poly/get_item.c
grass/trunk/raster/r.in.poly/getformat.c
grass/trunk/raster/r.in.poly/main.c
grass/trunk/raster/r.in.poly/poly2rast.c
grass/trunk/raster/r.in.poly/raster.c
grass/trunk/raster/r.in.xyz/Makefile
grass/trunk/raster/r.in.xyz/local_proto.h
grass/trunk/raster/r.in.xyz/main.c
grass/trunk/raster/r.in.xyz/support.c
grass/trunk/raster/r.info/Makefile
grass/trunk/raster/r.info/main.c
grass/trunk/raster/r.info/reclas_txt.c
grass/trunk/raster/r.kappa/Makefile
grass/trunk/raster/r.kappa/calc_kappa.c
grass/trunk/raster/r.kappa/kappa.h
grass/trunk/raster/r.kappa/main.c
grass/trunk/raster/r.kappa/prt_mat.c
grass/trunk/raster/r.kappa/stats.c
grass/trunk/raster/r.lake/Makefile
grass/trunk/raster/r.lake/main.c
grass/trunk/raster/r.le/r.le.patch/patch.h
grass/trunk/raster/r.le/r.le.pixel/pixel.h
grass/trunk/raster/r.le/r.le.setup/setup.h
grass/trunk/raster/r.le/r.le.trace/r.le.trace.h
grass/trunk/raster/r.li/r.li.cwed/Makefile
grass/trunk/raster/r.li/r.li.cwed/cwed.c
grass/trunk/raster/r.li/r.li.cwed/utility.c
grass/trunk/raster/r.li/r.li.daemon/GenericCell.h
grass/trunk/raster/r.li/r.li.daemon/avl.c
grass/trunk/raster/r.li/r.li.daemon/avlID.c
grass/trunk/raster/r.li/r.li.daemon/daemon.c
grass/trunk/raster/r.li/r.li.daemon/daemon.h
grass/trunk/raster/r.li/r.li.daemon/ipc.c
grass/trunk/raster/r.li/r.li.daemon/list.c
grass/trunk/raster/r.li/r.li.daemon/worker.c
grass/trunk/raster/r.li/r.li.dominance/Makefile
grass/trunk/raster/r.li/r.li.dominance/dominance.c
grass/trunk/raster/r.li/r.li.edgedensity/Makefile
grass/trunk/raster/r.li/r.li.edgedensity/edgedensity.c
grass/trunk/raster/r.li/r.li.mpa/Makefile
grass/trunk/raster/r.li/r.li.mpa/mpa.c
grass/trunk/raster/r.li/r.li.mps/Makefile
grass/trunk/raster/r.li/r.li.mps/mps.c
grass/trunk/raster/r.li/r.li.padcv/Makefile
grass/trunk/raster/r.li/r.li.padcv/padcv.c
grass/trunk/raster/r.li/r.li.padrange/Makefile
grass/trunk/raster/r.li/r.li.padrange/padrange.c
grass/trunk/raster/r.li/r.li.padsd/Makefile
grass/trunk/raster/r.li/r.li.padsd/padsd.c
grass/trunk/raster/r.li/r.li.patchdensity/Makefile
grass/trunk/raster/r.li/r.li.patchdensity/main.c
grass/trunk/raster/r.li/r.li.patchnum/Makefile
grass/trunk/raster/r.li/r.li.patchnum/main.c
grass/trunk/raster/r.li/r.li.richness/Makefile
grass/trunk/raster/r.li/r.li.richness/richness.c
grass/trunk/raster/r.li/r.li.shannon/Makefile
grass/trunk/raster/r.li/r.li.shannon/shannon.c
grass/trunk/raster/r.li/r.li.shape/Makefile
grass/trunk/raster/r.li/r.li.shape/main.c
grass/trunk/raster/r.li/r.li.simpson/Makefile
grass/trunk/raster/r.li/r.li.simpson/simpson.c
grass/trunk/raster/r.los/Makefile
grass/trunk/raster/r.los/delete.c
grass/trunk/raster/r.los/main.c
grass/trunk/raster/r.los/make_list.c
grass/trunk/raster/r.los/make_point.c
grass/trunk/raster/r.los/mark_pts.c
grass/trunk/raster/r.los/pts_elim.c
grass/trunk/raster/r.los/radians.h
grass/trunk/raster/r.mapcalc/Makefile
grass/trunk/raster/r.mapcalc/column_shift.c
grass/trunk/raster/r.mapcalc/evaluate.c
grass/trunk/raster/r.mapcalc/expression.c
grass/trunk/raster/r.mapcalc/map.c
grass/trunk/raster/r.mapcalc/map3.c
grass/trunk/raster/r.mapcalc/mapcalc.h
grass/trunk/raster/r.mapcalc/xabs.c
grass/trunk/raster/r.mapcalc/xacos.c
grass/trunk/raster/r.mapcalc/xadd.c
grass/trunk/raster/r.mapcalc/xand.c
grass/trunk/raster/r.mapcalc/xand2.c
grass/trunk/raster/r.mapcalc/xasin.c
grass/trunk/raster/r.mapcalc/xatan.c
grass/trunk/raster/r.mapcalc/xbitand.c
grass/trunk/raster/r.mapcalc/xbitnot.c
grass/trunk/raster/r.mapcalc/xbitor.c
grass/trunk/raster/r.mapcalc/xbitxor.c
grass/trunk/raster/r.mapcalc/xcoor.c
grass/trunk/raster/r.mapcalc/xcoor3.c
grass/trunk/raster/r.mapcalc/xcos.c
grass/trunk/raster/r.mapcalc/xdiv.c
grass/trunk/raster/r.mapcalc/xdouble.c
grass/trunk/raster/r.mapcalc/xeq.c
grass/trunk/raster/r.mapcalc/xeval.c
grass/trunk/raster/r.mapcalc/xexp.c
grass/trunk/raster/r.mapcalc/xfloat.c
grass/trunk/raster/r.mapcalc/xge.c
grass/trunk/raster/r.mapcalc/xgraph.c
grass/trunk/raster/r.mapcalc/xgt.c
grass/trunk/raster/r.mapcalc/xif.c
grass/trunk/raster/r.mapcalc/xint.c
grass/trunk/raster/r.mapcalc/xisnull.c
grass/trunk/raster/r.mapcalc/xle.c
grass/trunk/raster/r.mapcalc/xlog.c
grass/trunk/raster/r.mapcalc/xlt.c
grass/trunk/raster/r.mapcalc/xmax.c
grass/trunk/raster/r.mapcalc/xmedian.c
grass/trunk/raster/r.mapcalc/xmin.c
grass/trunk/raster/r.mapcalc/xmod.c
grass/trunk/raster/r.mapcalc/xmode.c
grass/trunk/raster/r.mapcalc/xmul.c
grass/trunk/raster/r.mapcalc/xne.c
grass/trunk/raster/r.mapcalc/xneg.c
grass/trunk/raster/r.mapcalc/xnot.c
grass/trunk/raster/r.mapcalc/xnull.c
grass/trunk/raster/r.mapcalc/xor.c
grass/trunk/raster/r.mapcalc/xor2.c
grass/trunk/raster/r.mapcalc/xpow.c
grass/trunk/raster/r.mapcalc/xrand.c
grass/trunk/raster/r.mapcalc/xres.c
grass/trunk/raster/r.mapcalc/xres3.c
grass/trunk/raster/r.mapcalc/xround.c
grass/trunk/raster/r.mapcalc/xrowcol.c
grass/trunk/raster/r.mapcalc/xshiftl.c
grass/trunk/raster/r.mapcalc/xshiftr.c
grass/trunk/raster/r.mapcalc/xshiftru.c
grass/trunk/raster/r.mapcalc/xsin.c
grass/trunk/raster/r.mapcalc/xsqrt.c
grass/trunk/raster/r.mapcalc/xsub.c
grass/trunk/raster/r.mapcalc/xtan.c
grass/trunk/raster/r.mfilter/Makefile
grass/trunk/raster/r.mfilter/filter.h
grass/trunk/raster/r.mfilter/getrow.c
grass/trunk/raster/r.mfilter/main.c
grass/trunk/raster/r.mode/Makefile
grass/trunk/raster/r.mode/main.c
grass/trunk/raster/r.mode/read_stats.c
grass/trunk/raster/r.neighbors/bufs.c
grass/trunk/raster/r.neighbors/divr_cats.c
grass/trunk/raster/r.neighbors/gather.c
grass/trunk/raster/r.neighbors/intr_cats.c
grass/trunk/raster/r.neighbors/main.c
grass/trunk/raster/r.neighbors/null_cats.c
grass/trunk/raster/r.neighbors/readcell.c
grass/trunk/raster/r.neighbors/readweights.c
grass/trunk/raster/r.null/Makefile
grass/trunk/raster/r.null/main.c
grass/trunk/raster/r.null/mask.c
grass/trunk/raster/r.out.arc/Makefile
grass/trunk/raster/r.out.arc/main.c
grass/trunk/raster/r.out.ascii/Makefile
grass/trunk/raster/r.out.ascii/formspecific.c
grass/trunk/raster/r.out.ascii/main.c
grass/trunk/raster/r.out.bin/Makefile
grass/trunk/raster/r.out.bin/main.c
grass/trunk/raster/r.out.gdal/Makefile
grass/trunk/raster/r.out.gdal/export_band.c
grass/trunk/raster/r.out.gdal/main.c
grass/trunk/raster/r.out.gridatb/Makefile
grass/trunk/raster/r.out.gridatb/local_proto.h
grass/trunk/raster/r.out.gridatb/main.c
grass/trunk/raster/r.out.mat/Makefile
grass/trunk/raster/r.out.mat/main.c
grass/trunk/raster/r.out.mpeg/Makefile
grass/trunk/raster/r.out.mpeg/main.c
grass/trunk/raster/r.out.mpeg/write.c
grass/trunk/raster/r.out.png/Makefile
grass/trunk/raster/r.out.png/main.c
grass/trunk/raster/r.out.pov/Makefile
grass/trunk/raster/r.out.pov/main.c
grass/trunk/raster/r.out.ppm/Makefile
grass/trunk/raster/r.out.ppm/main.c
grass/trunk/raster/r.out.ppm3/Makefile
grass/trunk/raster/r.out.ppm3/main.c
grass/trunk/raster/r.out.tiff/Makefile
grass/trunk/raster/r.out.tiff/main.c
grass/trunk/raster/r.out.vrml/Makefile
grass/trunk/raster/r.out.vrml/main.c
grass/trunk/raster/r.out.vrml/pv.h
grass/trunk/raster/r.out.vtk/Makefile
grass/trunk/raster/r.out.vtk/main.c
grass/trunk/raster/r.out.vtk/parameters.c
grass/trunk/raster/r.out.vtk/writeascii.c
grass/trunk/raster/r.param.scale/Makefile
grass/trunk/raster/r.param.scale/interface.c
grass/trunk/raster/r.param.scale/nrutil.c
grass/trunk/raster/r.param.scale/open_files.c
grass/trunk/raster/r.param.scale/param.h
grass/trunk/raster/r.param.scale/process.c
grass/trunk/raster/r.param.scale/write_cats.c
grass/trunk/raster/r.patch/Makefile
grass/trunk/raster/r.patch/do_patch.c
grass/trunk/raster/r.patch/main.c
grass/trunk/raster/r.patch/support.c
grass/trunk/raster/r.profile/Makefile
grass/trunk/raster/r.profile/local_proto.h
grass/trunk/raster/r.profile/main.c
grass/trunk/raster/r.profile/read_rast.c
grass/trunk/raster/r.proj/Makefile
grass/trunk/raster/r.proj/bilinear.c
grass/trunk/raster/r.proj/bilinear_f.c
grass/trunk/raster/r.proj/bordwalk.c
grass/trunk/raster/r.proj/cubic.c
grass/trunk/raster/r.proj/cubic_f.c
grass/trunk/raster/r.proj/main.c
grass/trunk/raster/r.proj/nearest.c
grass/trunk/raster/r.proj/readcell.c
grass/trunk/raster/r.quant/Makefile
grass/trunk/raster/r.quant/global.h
grass/trunk/raster/r.quantile/Makefile
grass/trunk/raster/r.quantile/main.c
grass/trunk/raster/r.random.cells/Makefile
grass/trunk/raster/r.random.cells/flag.c
grass/trunk/raster/r.random.cells/indep.c
grass/trunk/raster/r.random.cells/init.c
grass/trunk/raster/r.random.cells/main.c
grass/trunk/raster/r.random.cells/random.c
grass/trunk/raster/r.random.cells/ransurf.h
grass/trunk/raster/r.random.surface/Makefile
grass/trunk/raster/r.random.surface/calcsurf.c
grass/trunk/raster/r.random.surface/gennorm.c
grass/trunk/raster/r.random.surface/init.c
grass/trunk/raster/r.random.surface/main.c
grass/trunk/raster/r.random.surface/random.c
grass/trunk/raster/r.random.surface/ransurf.h
grass/trunk/raster/r.random.surface/save.c
grass/trunk/raster/r.random/Makefile
grass/trunk/raster/r.random/count.c
grass/trunk/raster/r.random/main.c
grass/trunk/raster/r.random/random.c
grass/trunk/raster/r.random/support.c
grass/trunk/raster/r.reclass/Makefile
grass/trunk/raster/r.reclass/input.c
grass/trunk/raster/r.reclass/main.c
grass/trunk/raster/r.reclass/parse.c
grass/trunk/raster/r.reclass/range.c
grass/trunk/raster/r.reclass/reclass.c
grass/trunk/raster/r.reclass/rule.h
grass/trunk/raster/r.reclass/stats.c
grass/trunk/raster/r.recode/Makefile
grass/trunk/raster/r.recode/global.h
grass/trunk/raster/r.recode/main.c
grass/trunk/raster/r.region/Makefile
grass/trunk/raster/r.region/main.c
grass/trunk/raster/r.report/Makefile
grass/trunk/raster/r.report/global.h
grass/trunk/raster/r.report/maskinfo.c
grass/trunk/raster/r.resamp.interp/Makefile
grass/trunk/raster/r.resamp.interp/main.c
grass/trunk/raster/r.resamp.rst/main.c
grass/trunk/raster/r.resamp.stats/main.c
grass/trunk/raster/r.resample/Makefile
grass/trunk/raster/r.resample/main.c
grass/trunk/raster/r.rescale.eq/Makefile
grass/trunk/raster/r.rescale.eq/get_range.c
grass/trunk/raster/r.rescale.eq/get_stats.c
grass/trunk/raster/r.rescale.eq/main.c
grass/trunk/raster/r.rescale/Makefile
grass/trunk/raster/r.rescale/get_range.c
grass/trunk/raster/r.rescale/main.c
grass/trunk/raster/r.ros/Makefile
grass/trunk/raster/r.ros/main.c
grass/trunk/raster/r.ros/spot_dist.c
grass/trunk/raster/r.series/main.c
grass/trunk/raster/r.slope.aspect/Makefile
grass/trunk/raster/r.slope.aspect/main.c
grass/trunk/raster/r.slope.aspect/opennew.c
grass/trunk/raster/r.spread/Makefile
grass/trunk/raster/r.spread/collect_ori.c
grass/trunk/raster/r.spread/display.c
grass/trunk/raster/r.spread/insert2Ha.c
grass/trunk/raster/r.spread/main.c
grass/trunk/raster/r.spread/ram2out.c
grass/trunk/raster/r.spread/replaceHa.c
grass/trunk/raster/r.spread/select_linksB.c
grass/trunk/raster/r.spread/spot.c
grass/trunk/raster/r.spread/spread.c
grass/trunk/raster/r.spreadpath/Makefile
grass/trunk/raster/r.spreadpath/insert.c
grass/trunk/raster/r.spreadpath/main.c
grass/trunk/raster/r.statistics/Makefile
grass/trunk/raster/r.statistics/main.c
grass/trunk/raster/r.statistics/o_adev.c
grass/trunk/raster/r.statistics/o_average.c
grass/trunk/raster/r.statistics/o_distrib.c
grass/trunk/raster/r.statistics/o_divr.c
grass/trunk/raster/r.statistics/o_kurt.c
grass/trunk/raster/r.statistics/o_max.c
grass/trunk/raster/r.statistics/o_median.c
grass/trunk/raster/r.statistics/o_min.c
grass/trunk/raster/r.statistics/o_mode.c
grass/trunk/raster/r.statistics/o_sdev.c
grass/trunk/raster/r.statistics/o_skew.c
grass/trunk/raster/r.statistics/o_sum.c
grass/trunk/raster/r.statistics/o_var.c
grass/trunk/raster/r.statistics/read_stats.c
grass/trunk/raster/r.statistics2/Makefile
grass/trunk/raster/r.statistics2/main.c
grass/trunk/raster/r.statistics3/Makefile
grass/trunk/raster/r.statistics3/main.c
grass/trunk/raster/r.stats/Makefile
grass/trunk/raster/r.stats/global.h
grass/trunk/raster/r.stats/raw_stats.c
grass/trunk/raster/r.sun2/Makefile
grass/trunk/raster/r.sun2/main.c
grass/trunk/raster/r.sun2/rsunlib.c
grass/trunk/raster/r.sunmask/Makefile
grass/trunk/raster/r.sunmask/g_solposition.c
grass/trunk/raster/r.sunmask/main.c
grass/trunk/raster/r.sunmask/solpos00.c
grass/trunk/raster/r.support.stats/Makefile
grass/trunk/raster/r.support.stats/check.c
grass/trunk/raster/r.support.stats/histo.c
grass/trunk/raster/r.support.stats/main.c
grass/trunk/raster/r.support/Makefile
grass/trunk/raster/r.support/check.c
grass/trunk/raster/r.support/histo.c
grass/trunk/raster/r.support/main.c
grass/trunk/raster/r.surf.area/Makefile
grass/trunk/raster/r.surf.area/main.c
grass/trunk/raster/r.surf.contour/Makefile
grass/trunk/raster/r.surf.contour/contour.h
grass/trunk/raster/r.surf.contour/flag_create.c
grass/trunk/raster/r.surf.contour/flag_destroy.c
grass/trunk/raster/r.surf.contour/main.c
grass/trunk/raster/r.surf.fractal/Makefile
grass/trunk/raster/r.surf.fractal/frac.h
grass/trunk/raster/r.surf.fractal/spec_syn.c
grass/trunk/raster/r.surf.gauss/Makefile
grass/trunk/raster/r.surf.gauss/gaussurf.c
grass/trunk/raster/r.surf.gauss/main.c
grass/trunk/raster/r.surf.idw/Makefile
grass/trunk/raster/r.surf.idw/dist.c
grass/trunk/raster/r.surf.idw/ll.c
grass/trunk/raster/r.surf.idw/main.c
grass/trunk/raster/r.surf.idw/pi.h
grass/trunk/raster/r.surf.idw2/Makefile
grass/trunk/raster/r.surf.idw2/main.c
grass/trunk/raster/r.surf.idw2/read_cell.c
grass/trunk/raster/r.surf.random/Makefile
grass/trunk/raster/r.surf.random/main.c
grass/trunk/raster/r.surf.random/randsurf.c
grass/trunk/raster/r.terraflow/Makefile
grass/trunk/raster/r.terraflow/common.h
grass/trunk/raster/r.terraflow/main.cc
grass/trunk/raster/r.texture/Makefile
grass/trunk/raster/r.texture/h_measure.c
grass/trunk/raster/r.texture/main.c
grass/trunk/raster/r.thin/Makefile
grass/trunk/raster/r.thin/io.c
grass/trunk/raster/r.thin/main.c
grass/trunk/raster/r.thin/thin_lines.c
grass/trunk/raster/r.to.rast3/main.c
grass/trunk/raster/r.to.rast3elev/main.c
grass/trunk/raster/r.to.vect/Makefile
grass/trunk/raster/r.to.vect/areas.c
grass/trunk/raster/r.to.vect/areas_io.c
grass/trunk/raster/r.to.vect/lines.c
grass/trunk/raster/r.to.vect/lines_io.c
grass/trunk/raster/r.to.vect/main.c
grass/trunk/raster/r.to.vect/points.c
grass/trunk/raster/r.to.vect/util.c
grass/trunk/raster/r.topidx/Makefile
grass/trunk/raster/r.topidx/file_io.c
grass/trunk/raster/r.topidx/global.h
grass/trunk/raster/r.topidx/main.c
grass/trunk/raster/r.topidx/topidx.c
grass/trunk/raster/r.topmodel/Makefile
grass/trunk/raster/r.topmodel/file_io.c
grass/trunk/raster/r.topmodel/global.h
grass/trunk/raster/r.topmodel/topmodel.c
grass/trunk/raster/r.univar/globals.h
grass/trunk/raster/r.uslek/Makefile
grass/trunk/raster/r.uslek/main.c
grass/trunk/raster/r.usler/Makefile
grass/trunk/raster/r.usler/main.c
grass/trunk/raster/r.volume/Makefile
grass/trunk/raster/r.volume/centroids.c
grass/trunk/raster/r.volume/main.c
grass/trunk/raster/r.walk/Makefile
grass/trunk/raster/r.walk/btree.c
grass/trunk/raster/r.walk/main.c
grass/trunk/raster/r.walk/memory.c
grass/trunk/raster/r.water.outlet/Makefile
grass/trunk/raster/r.water.outlet/basin.h
grass/trunk/raster/r.water.outlet/flag_create.c
grass/trunk/raster/r.water.outlet/flag_destroy.c
grass/trunk/raster/r.water.outlet/main.c
grass/trunk/raster/r.watershed/front/Makefile
grass/trunk/raster/r.watershed/front/main.c
grass/trunk/raster/r.watershed/ram/Gwater.h
grass/trunk/raster/r.watershed/ram/Makefile
grass/trunk/raster/r.watershed/ram/close_maps.c
grass/trunk/raster/r.watershed/ram/do_astar.c
grass/trunk/raster/r.watershed/ram/do_cum.c
grass/trunk/raster/r.watershed/ram/flag_create.c
grass/trunk/raster/r.watershed/ram/flag_destroy.c
grass/trunk/raster/r.watershed/ram/init_vars.c
grass/trunk/raster/r.watershed/ram/main.c
grass/trunk/raster/r.watershed/ram/sg_factor.c
grass/trunk/raster/r.watershed/ram/usage.c
grass/trunk/raster/r.watershed/seg/Gwater.h
grass/trunk/raster/r.watershed/seg/Makefile
grass/trunk/raster/r.watershed/seg/bseg_close.c
grass/trunk/raster/r.watershed/seg/bseg_get.c
grass/trunk/raster/r.watershed/seg/bseg_open.c
grass/trunk/raster/r.watershed/seg/bseg_put.c
grass/trunk/raster/r.watershed/seg/bseg_read.c
grass/trunk/raster/r.watershed/seg/bseg_write.c
grass/trunk/raster/r.watershed/seg/cseg_close.c
grass/trunk/raster/r.watershed/seg/cseg_get.c
grass/trunk/raster/r.watershed/seg/cseg_open.c
grass/trunk/raster/r.watershed/seg/cseg_put.c
grass/trunk/raster/r.watershed/seg/cseg_read.c
grass/trunk/raster/r.watershed/seg/cseg_write.c
grass/trunk/raster/r.watershed/seg/do_astar.c
grass/trunk/raster/r.watershed/seg/do_cum.c
grass/trunk/raster/r.watershed/seg/dseg_close.c
grass/trunk/raster/r.watershed/seg/dseg_get.c
grass/trunk/raster/r.watershed/seg/dseg_open.c
grass/trunk/raster/r.watershed/seg/dseg_put.c
grass/trunk/raster/r.watershed/seg/dseg_read.c
grass/trunk/raster/r.watershed/seg/dseg_write.c
grass/trunk/raster/r.watershed/seg/init_vars.c
grass/trunk/raster/r.watershed/seg/main.c
grass/trunk/raster/r.watershed/seg/sg_factor.c
grass/trunk/raster/r.watershed/seg/sseg_close.c
grass/trunk/raster/r.watershed/seg/sseg_get.c
grass/trunk/raster/r.watershed/seg/sseg_open.c
grass/trunk/raster/r.watershed/seg/sseg_put.c
grass/trunk/raster/r.watershed/seg/usage.c
grass/trunk/raster/r.watershed/shed/watershed.h
grass/trunk/raster/r.what.color/Makefile
grass/trunk/raster/r.what.color/main.c
grass/trunk/raster/r.what/Makefile
grass/trunk/raster/r.what/main.c
grass/trunk/raster3d/r3.cross.rast/main.c
grass/trunk/raster3d/r3.gwflow/main.c
grass/trunk/raster3d/r3.mkdspf/calc_linefax.c
grass/trunk/raster3d/r3.mkdspf/iso_surface.c
grass/trunk/raster3d/r3.mkdspf/main.c
grass/trunk/raster3d/r3.mkdspf/r3_find.c
grass/trunk/raster3d/r3.out.vtk/errorHandling.c
grass/trunk/raster3d/r3.out.vtk/main.c
grass/trunk/raster3d/r3.out.vtk/parameters.c
grass/trunk/raster3d/r3.out.vtk/writeVTKData.c
grass/trunk/raster3d/r3.out.vtk/writeVTKHead.c
grass/trunk/raster3d/r3.to.rast/main.c
grass/trunk/swig/python/Makefile
grass/trunk/vector/lidar/lidarlib/TcholBand.c
grass/trunk/vector/lidar/lidarlib/raster.c
grass/trunk/vector/lidar/lidarlib/zones.c
grass/trunk/vector/lidar/v.lidar.correction/Makefile
grass/trunk/vector/lidar/v.lidar.correction/correction.c
grass/trunk/vector/lidar/v.lidar.correction/main.c
grass/trunk/vector/lidar/v.lidar.edgedetection/Makefile
grass/trunk/vector/lidar/v.lidar.edgedetection/edgedetection.c
grass/trunk/vector/lidar/v.lidar.edgedetection/main.c
grass/trunk/vector/lidar/v.lidar.growing/ConvexHull.c
grass/trunk/vector/lidar/v.lidar.growing/Makefile
grass/trunk/vector/lidar/v.lidar.growing/main.c
grass/trunk/vector/lidar/v.outlier/Makefile
grass/trunk/vector/lidar/v.outlier/main.c
grass/trunk/vector/lidar/v.outlier/outlier.c
grass/trunk/vector/lidar/v.surf.bspline/Makefile
grass/trunk/vector/lidar/v.surf.bspline/crosscorr.c
grass/trunk/vector/lidar/v.surf.bspline/main.c
grass/trunk/vector/v.convert/Makefile
grass/trunk/vector/v.convert/att.c
grass/trunk/vector/v.convert/dist.c
grass/trunk/vector/v.convert/main.c
grass/trunk/vector/v.convert/old2new.c
grass/trunk/vector/v.convert/read.c
grass/trunk/vector/v.drape/Makefile
grass/trunk/vector/v.drape/main.c
grass/trunk/vector/v.extrude/Makefile
grass/trunk/vector/v.extrude/main.c
grass/trunk/vector/v.kernel/Makefile
grass/trunk/vector/v.kernel/function.c
grass/trunk/vector/v.kernel/main.c
grass/trunk/vector/v.neighbors/Makefile
grass/trunk/vector/v.neighbors/main.c
grass/trunk/vector/v.sample/Makefile
grass/trunk/vector/v.sample/main.c
grass/trunk/vector/v.surf.idw/Makefile
grass/trunk/vector/v.surf.idw/main.c
grass/trunk/vector/v.surf.idw/read_sites.c
grass/trunk/vector/v.to.rast/Makefile
grass/trunk/vector/v.to.rast/do_areas.c
grass/trunk/vector/v.to.rast/do_lines.c
grass/trunk/vector/v.to.rast/main.c
grass/trunk/vector/v.to.rast/raster.c
grass/trunk/vector/v.to.rast/support.c
grass/trunk/vector/v.to.rast/vect2rast.c
grass/trunk/vector/v.vol.rst/dataoct.c
grass/trunk/vector/v.vol.rst/main.c
grass/trunk/vector/v.vol.rst/oct.c
grass/trunk/vector/v.vol.rst/user1.c
grass/trunk/vector/v.vol.rst/user2.c
grass/trunk/vector/v.vol.rst/user3.c
grass/trunk/vector/v.vol.rst/user4.c
grass/trunk/vector/v.vol.rst/vector.c
grass/trunk/vector/v.what.rast/Makefile
grass/trunk/vector/v.what.rast/main.c
grass/trunk/visualization/xganim/Makefile
grass/trunk/visualization/xganim/main.cc
Rename Rast.h->raster.h
Rename libgrass_rast -> libgrass_raster
Rename RASTR{LIB,DEP,_LIBNAME} -> RASTER_*
Fix definition of RASTERLIB
Fix EOLs for imagery/i.evapo.time_integration/main.c
Add SWIG wrapper for raster library
Modified: grass/trunk/display/d.colortable/main.c
--- grass/trunk/display/d.colortable/main.c 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/display/d.colortable/main.c 2009-06-22 01:49:13 UTC (rev 38014)
@@ -24,7 +24,7 @@
#include <math.h>
#include <grass/display.h>
#include <grass/gis.h>
-#include <grass/Rast.h>
+#include <grass/raster.h>
#include <grass/display_raster.h>
#include <grass/glocale.h>
Modified: grass/trunk/display/d.graph/do_graph.c
--- grass/trunk/display/d.graph/do_graph.c 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/display/d.graph/do_graph.c 2009-06-22 01:49:13 UTC (rev 38014)
@@ -1,7 +1,7 @@
#include <stdio.h>
#include <string.h>
#include <grass/symbol.h>
Modified: grass/trunk/display/d.graph/graphics.c
--- grass/trunk/display/d.graph/graphics.c 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/display/d.graph/graphics.c 2009-06-22 01:49:13 UTC (rev 38014)
@@ -1,6 +1,6 @@
#include <string.h>
#include "local_proto.h"
Modified: grass/trunk/display/d.graph/main.c
--- grass/trunk/display/d.graph/main.c 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/display/d.graph/main.c 2009-06-22 01:49:13 UTC (rev 38014)
@@ -31,7 +31,7 @@
#include <stdio.h>
#include <stdlib.h>
Modified: grass/trunk/display/d.grid/fiducial.c
--- grass/trunk/display/d.grid/fiducial.c 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/display/d.grid/fiducial.c 2009-06-22 01:49:13 UTC (rev 38014)
@@ -1,5 +1,5 @@
#include <grass/colors.h>
Modified: grass/trunk/display/d.grid/main.c
--- grass/trunk/display/d.grid/main.c 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/display/d.grid/main.c 2009-06-22 01:49:13 UTC (rev 38014)
@@ -21,7 +21,7 @@
#include <stdlib.h>
#include <string.h>
#include <grass/gprojects.h>
Modified: grass/trunk/display/d.grid/plot.c
--- grass/trunk/display/d.grid/plot.c 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/display/d.grid/plot.c 2009-06-22 01:49:13 UTC (rev 38014)
@@ -2,7 +2,7 @@
#include <string.h>
Modified: grass/trunk/display/d.grid/plotborder.c
--- grass/trunk/display/d.grid/plotborder.c 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/display/d.grid/plotborder.c 2009-06-22 01:49:13 UTC (rev 38014)
@@ -1,6 +1,6 @@
#include <math.h>
int plot_border(double grid_size, double east, double north)
Modified: grass/trunk/display/d.his/his.c
--- grass/trunk/display/d.his/his.c 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/display/d.his/his.c 2009-06-22 01:49:13 UTC (rev 38014)
@@ -1,6 +1,6 @@
#include "his.h"
Modified: grass/trunk/display/d.his/main.c
--- grass/trunk/display/d.his/main.c 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/display/d.his/main.c 2009-06-22 01:49:13 UTC (rev 38014)
@@ -23,7 +23,7 @@
#include <stdio.h>
#include <string.h>
Modified: grass/trunk/display/d.histogram/bar.c
--- grass/trunk/display/d.histogram/bar.c 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/display/d.histogram/bar.c 2009-06-22 01:49:13 UTC (rev 38014)
@@ -28,7 +28,7 @@
#include <string.h>
Modified: grass/trunk/display/d.histogram/draw_slice.c
--- grass/trunk/display/d.histogram/draw_slice.c 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/display/d.histogram/draw_slice.c 2009-06-22 01:49:13 UTC (rev 38014)
@@ -2,7 +2,7 @@
char percent[] = "%";
Modified: grass/trunk/display/d.histogram/get_stats.c
--- grass/trunk/display/d.histogram/get_stats.c 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/display/d.histogram/get_stats.c 2009-06-22 01:49:13 UTC (rev 38014)
@@ -4,7 +4,7 @@
#include <stdarg.h>
#include <unistd.h>
#include "options.h"
#include "dhist.h"
Modified: grass/trunk/display/d.histogram/main.c
--- grass/trunk/display/d.histogram/main.c 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/display/d.histogram/main.c 2009-06-22 01:49:13 UTC (rev 38014)
@@ -34,7 +34,7 @@
#include <stdlib.h>
#include <string.h>
Modified: grass/trunk/display/d.histogram/pie.c
--- grass/trunk/display/d.histogram/pie.c 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/display/d.histogram/pie.c 2009-06-22 01:49:13 UTC (rev 38014)
@@ -30,7 +30,7 @@
#include <string.h>
Modified: grass/trunk/display/d.labels/color.c
--- grass/trunk/display/d.labels/color.c 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/display/d.labels/color.c 2009-06-22 01:49:13 UTC (rev 38014)
@@ -16,7 +16,7 @@
/** ??? move these into libgis ??? (libraster for set_color_from_RGBA()) **/
Modified: grass/trunk/display/d.labels/do_labels.c
--- grass/trunk/display/d.labels/do_labels.c 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/display/d.labels/do_labels.c 2009-06-22 01:49:13 UTC (rev 38014)
@@ -3,7 +3,7 @@
#include <stdlib.h>
#include <math.h>
Modified: grass/trunk/display/d.labels/main.c
--- grass/trunk/display/d.labels/main.c 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/display/d.labels/main.c 2009-06-22 01:49:13 UTC (rev 38014)
@@ -19,7 +19,7 @@
#include <stdlib.h>
#include <math.h>
Modified: grass/trunk/display/d.legend/main.c
--- grass/trunk/display/d.legend/main.c 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/display/d.legend/main.c 2009-06-22 01:49:13 UTC (rev 38014)
@@ -29,7 +29,7 @@
#include <string.h>
#include <math.h>
Modified: grass/trunk/display/d.nviz/main.c
--- grass/trunk/display/d.nviz/main.c 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/display/d.nviz/main.c 2009-06-22 01:49:13 UTC (rev 38014)
@@ -24,7 +24,7 @@
#include <math.h>
#include <string.h>
#include "local.h"
Modified: grass/trunk/display/d.path/main.c
--- grass/trunk/display/d.path/main.c 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/display/d.path/main.c 2009-06-22 01:49:13 UTC (rev 38014)
@@ -20,7 +20,7 @@
#include <stdlib.h>
#include <string.h>
Modified: grass/trunk/display/d.path/select.c
--- grass/trunk/display/d.path/select.c 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/display/d.path/select.c 2009-06-22 01:49:13 UTC (rev 38014)
@@ -3,7 +3,7 @@
#include <unistd.h>
#include <math.h>
#include <grass/Vect.h>
Modified: grass/trunk/display/d.profile/main.c
--- grass/trunk/display/d.profile/main.c 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/display/d.profile/main.c 2009-06-22 01:49:13 UTC (rev 38014)
@@ -23,7 +23,7 @@
#include <stdlib.h>
#include <math.h>
Modified: grass/trunk/display/d.rast/display.c
--- grass/trunk/display/d.rast/display.c 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/display/d.rast/display.c 2009-06-22 01:49:13 UTC (rev 38014)
@@ -1,7 +1,7 @@
#include <stdlib.h>
Modified: grass/trunk/display/d.rast/main.c
--- grass/trunk/display/d.rast/main.c 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/display/d.rast/main.c 2009-06-22 01:49:13 UTC (rev 38014)
@@ -20,7 +20,7 @@
#include <stdlib.h>
#include "mask.h"
Modified: grass/trunk/display/d.rast/mask.c
--- grass/trunk/display/d.rast/mask.c 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/display/d.rast/mask.c 2009-06-22 01:49:13 UTC (rev 38014)
@@ -1,6 +1,6 @@
#include <stdlib.h>
#include "mask.h"
Modified: grass/trunk/display/d.rast.arrow/main.c
--- grass/trunk/display/d.rast.arrow/main.c 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/display/d.rast.arrow/main.c 2009-06-22 01:49:13 UTC (rev 38014)
@@ -38,7 +38,7 @@
#include <string.h>
#include <math.h>
Modified: grass/trunk/display/d.rast.num/main.c
--- grass/trunk/display/d.rast.num/main.c 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/display/d.rast.num/main.c 2009-06-22 01:49:13 UTC (rev 38014)
@@ -38,7 +38,7 @@
#include <string.h>
#include <math.h>
Modified: grass/trunk/display/d.rgb/main.c
--- grass/trunk/display/d.rgb/main.c 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/display/d.rgb/main.c 2009-06-22 01:49:13 UTC (rev 38014)
@@ -21,7 +21,7 @@
#include <stdlib.h>
#include <string.h>
Modified: grass/trunk/display/d.thematic.area/area.c
--- grass/trunk/display/d.thematic.area/area.c 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/display/d.thematic.area/area.c 2009-06-22 01:49:13 UTC (rev 38014)
@@ -4,7 +4,7 @@
#include <string.h>
#include <stdlib.h>
Modified: grass/trunk/display/d.thematic.area/main.c
--- grass/trunk/display/d.thematic.area/main.c 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/display/d.thematic.area/main.c 2009-06-22 01:49:13 UTC (rev 38014)
@@ -19,7 +19,7 @@
#include <dirent.h>
#include <grass/config.h>
Modified: grass/trunk/display/d.thematic.area/plot1.c
--- grass/trunk/display/d.thematic.area/plot1.c 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/display/d.thematic.area/plot1.c 2009-06-22 01:49:13 UTC (rev 38014)
@@ -2,7 +2,7 @@
#include <string.h>
Modified: grass/trunk/display/d.title/fancy.c
--- grass/trunk/display/d.title/fancy.c 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/display/d.title/fancy.c 2009-06-22 01:49:13 UTC (rev 38014)
@@ -1,5 +1,5 @@
void fancy(struct Cell_head *window, struct Categories *cats, FILE * fp)
Modified: grass/trunk/display/d.title/main.c
--- grass/trunk/display/d.title/main.c 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/display/d.title/main.c 2009-06-22 01:49:13 UTC (rev 38014)
@@ -21,7 +21,7 @@
Modified: grass/trunk/display/d.title/normal.c
--- grass/trunk/display/d.title/normal.c 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/display/d.title/normal.c 2009-06-22 01:49:13 UTC (rev 38014)
@@ -1,5 +1,5 @@
Modified: grass/trunk/display/d.vect/area.c
--- grass/trunk/display/d.vect/area.c 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/display/d.vect/area.c 2009-06-22 01:49:13 UTC (rev 38014)
@@ -4,7 +4,7 @@
#include <string.h>
Modified: grass/trunk/display/d.vect/attr.c
--- grass/trunk/display/d.vect/attr.c 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/display/d.vect/attr.c 2009-06-22 01:49:13 UTC (rev 38014)
@@ -1,6 +1,6 @@
#include <string.h>
Modified: grass/trunk/display/d.vect/dir.c
--- grass/trunk/display/d.vect/dir.c 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/display/d.vect/dir.c 2009-06-22 01:49:13 UTC (rev 38014)
@@ -1,5 +1,5 @@
Modified: grass/trunk/display/d.vect/label.c
--- grass/trunk/display/d.vect/label.c 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/display/d.vect/label.c 2009-06-22 01:49:13 UTC (rev 38014)
@@ -1,5 +1,5 @@
Modified: grass/trunk/display/d.vect/main.c
--- grass/trunk/display/d.vect/main.c 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/display/d.vect/main.c 2009-06-22 01:49:13 UTC (rev 38014)
@@ -18,7 +18,7 @@
#include <sys/types.h>
#include <dirent.h>
Modified: grass/trunk/display/d.vect/plot1.c
--- grass/trunk/display/d.vect/plot1.c 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/display/d.vect/plot1.c 2009-06-22 01:49:13 UTC (rev 38014)
@@ -2,7 +2,7 @@
#include <string.h>
Modified: grass/trunk/display/d.vect/topo.c
--- grass/trunk/display/d.vect/topo.c 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/display/d.vect/topo.c 2009-06-22 01:49:13 UTC (rev 38014)
@@ -1,5 +1,5 @@
Modified: grass/trunk/display/d.vect/utils.c
--- grass/trunk/display/d.vect/utils.c 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/display/d.vect/utils.c 2009-06-22 01:49:13 UTC (rev 38014)
@@ -1,5 +1,5 @@
Modified: grass/trunk/display/d.vect/zcoor.c
--- grass/trunk/display/d.vect/zcoor.c 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/display/d.vect/zcoor.c 2009-06-22 01:49:13 UTC (rev 38014)
@@ -1,7 +1,7 @@
/* Print z coordinate value for each node */
Modified: grass/trunk/display/d.vect.chart/bar.c
--- grass/trunk/display/d.vect.chart/bar.c 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/display/d.vect.chart/bar.c 2009-06-22 01:49:13 UTC (rev 38014)
@@ -1,5 +1,5 @@
#include <grass/dbmi.h>
Modified: grass/trunk/display/d.vect.chart/main.c
--- grass/trunk/display/d.vect.chart/main.c 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/display/d.vect.chart/main.c 2009-06-22 01:49:13 UTC (rev 38014)
@@ -18,7 +18,7 @@
#include <stdlib.h>
#include <string.h>
Modified: grass/trunk/display/d.vect.chart/pie.c
--- grass/trunk/display/d.vect.chart/pie.c 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/display/d.vect.chart/pie.c 2009-06-22 01:49:13 UTC (rev 38014)
@@ -1,6 +1,6 @@
#include <math.h>
Modified: grass/trunk/display/d.vect.chart/plot.c
--- grass/trunk/display/d.vect.chart/plot.c 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/display/d.vect.chart/plot.c 2009-06-22 01:49:13 UTC (rev 38014)
@@ -1,5 +1,5 @@
Modified: grass/trunk/general/g.mremove/check_reclass.c
--- grass/trunk/general/g.mremove/check_reclass.c 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/general/g.mremove/check_reclass.c 2009-06-22 01:49:13 UTC (rev 38014)
@@ -1,6 +1,6 @@
#include <string.h>
#include "global.h"
Modified: grass/trunk/general/g.mremove/wc2regex.c
--- grass/trunk/general/g.mremove/wc2regex.c 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/general/g.mremove/wc2regex.c 2009-06-22 01:49:13 UTC (rev 38014)
@@ -1,5 +1,5 @@
char *wc2regex(const char *wc)
Modified: grass/trunk/general/g.region/adjust.c
--- grass/trunk/general/g.region/adjust.c 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/general/g.region/adjust.c 2009-06-22 01:49:13 UTC (rev 38014)
@@ -1,5 +1,5 @@
Modified: grass/trunk/general/g.region/main.c
--- grass/trunk/general/g.region/main.c 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/general/g.region/main.c 2009-06-22 01:49:13 UTC (rev 38014)
@@ -16,7 +16,7 @@
#include <string.h>
#include <stdlib.h>
#include <grass/G3d.h>
Modified: grass/trunk/general/g.region/printwindow.c
--- grass/trunk/general/g.region/printwindow.c 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/general/g.region/printwindow.c 2009-06-22 01:49:13 UTC (rev 38014)
@@ -2,7 +2,7 @@
#include <stdlib.h>
#include <projects.h>
Modified: grass/trunk/general/g.region/zoom.c
--- grass/trunk/general/g.region/zoom.c 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/general/g.region/zoom.c 2009-06-22 01:49:13 UTC (rev 38014)
@@ -1,6 +1,6 @@
#include <stdlib.h>
Modified: grass/trunk/general/g.remove/main.c
--- grass/trunk/general/g.remove/main.c 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/general/g.remove/main.c 2009-06-22 01:49:13 UTC (rev 38014)
@@ -21,7 +21,7 @@
#include <stdlib.h>
#include <string.h>
#include <grass/list.h>
Modified: grass/trunk/general/g.rename/main.c
--- grass/trunk/general/g.rename/main.c 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/general/g.rename/main.c 2009-06-22 01:49:13 UTC (rev 38014)
@@ -20,7 +20,7 @@
#include <stdlib.h>
#include <string.h>
Modified: grass/trunk/general/manage/lister/Makefile
--- grass/trunk/general/manage/lister/Makefile 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/general/manage/lister/Makefile 2009-06-22 01:49:13 UTC (rev 38014)
@@ -1,7 +1,7 @@
MODULE_TOPDIR = ../../..
-LIBES = $(VECTLIB) $(DBMILIB) $(GISLIB) $(RASTRLIB) $(RASTRLIB)
-DEPENDENCIES = $(VECTDEP) $(DBMIDEP) $(GISDEP) $(RASTRDEP) $(RASTRDEP)
+LIBES = $(VECTLIB) $(DBMILIB) $(GISLIB) $(RASTERLIB)
+DEPENDENCIES = $(VECTDEP) $(DBMIDEP) $(GISDEP) $(RASTERDEP)
EXTRA_INC = $(VECT_INC)
EXTRA_CFLAGS = $(VECT_CFLAGS)
Modified: grass/trunk/general/manage/lister/cell.c
--- grass/trunk/general/manage/lister/cell.c 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/general/manage/lister/cell.c 2009-06-22 01:49:13 UTC (rev 38014)
@@ -1,7 +1,7 @@
#include <stdlib.h>
#include <string.h>
int main(int argc, char *argv[])
Modified: grass/trunk/general/manage/lister/vector.c
--- grass/trunk/general/manage/lister/vector.c 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/general/manage/lister/vector.c 2009-06-22 01:49:13 UTC (rev 38014)
@@ -1,7 +1,7 @@
#include <stdlib.h>
#include <string.h>
Modified: grass/trunk/imagery/i.albedo/Makefile
--- grass/trunk/imagery/i.albedo/Makefile 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/imagery/i.albedo/Makefile 2009-06-22 01:49:13 UTC (rev 38014)
@@ -2,8 +2,8 @@
PGM = i.albedo
-LIBES = $(GISLIB) $(RASTRLIB)
-DEPENDENCIES = $(GISDEP) $(RASTRDEP)
+LIBES = $(GISLIB) $(RASTERLIB)
+DEPENDENCIES = $(GISDEP) $(RASTERDEP)
include $(MODULE_TOPDIR)/include/Make/Module.make
Modified: grass/trunk/imagery/i.albedo/main.c
--- grass/trunk/imagery/i.albedo/main.c 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/imagery/i.albedo/main.c 2009-06-22 01:49:13 UTC (rev 38014)
@@ -18,7 +18,7 @@
#include <stdlib.h>
#include <string.h>
#define MAXFILES 8
Modified: grass/trunk/imagery/i.atcorr/Makefile
--- grass/trunk/imagery/i.atcorr/Makefile 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/imagery/i.atcorr/Makefile 2009-06-22 01:49:13 UTC (rev 38014)
@@ -4,8 +4,8 @@
LINK = $(CXX)
Modified: grass/trunk/imagery/i.atcorr/main.cpp
--- grass/trunk/imagery/i.atcorr/main.cpp 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/imagery/i.atcorr/main.cpp 2009-06-22 01:49:13 UTC (rev 38014)
@@ -37,7 +37,7 @@
extern "C" {
Modified: grass/trunk/imagery/i.cca/Makefile
--- grass/trunk/imagery/i.cca/Makefile 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/imagery/i.cca/Makefile 2009-06-22 01:49:13 UTC (rev 38014)
@@ -2,8 +2,8 @@
PGM = i.cca
-LIBES = $(IMAGERYLIB) $(GMATHLIB) $(GISLIB) $(RASTRLIB)
-DEPENDENCIES= $(IMAGERYDEP) $(GMATHDEP) $(GISDEP) $(RASTRDEP)
+LIBES = $(IMAGERYLIB) $(GMATHLIB) $(GISLIB) $(RASTERLIB)
+DEPENDENCIES= $(IMAGERYDEP) $(GMATHDEP) $(GISDEP) $(RASTERDEP)
Modified: grass/trunk/imagery/i.cca/main.c
--- grass/trunk/imagery/i.cca/main.c 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/imagery/i.cca/main.c 2009-06-22 01:49:13 UTC (rev 38014)
@@ -38,7 +38,7 @@
#include <string.h>
#include <math.h>
#include <grass/imagery.h>
#include <grass/gmath.h>
Modified: grass/trunk/imagery/i.cca/matrix.c
--- grass/trunk/imagery/i.cca/matrix.c 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/imagery/i.cca/matrix.c 2009-06-22 01:49:13 UTC (rev 38014)
@@ -1,6 +1,6 @@
#include <math.h>
Modified: grass/trunk/imagery/i.cca/stats.c
--- grass/trunk/imagery/i.cca/stats.c 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/imagery/i.cca/stats.c 2009-06-22 01:49:13 UTC (rev 38014)
@@ -1,5 +1,5 @@
Modified: grass/trunk/imagery/i.cca/transform.c
--- grass/trunk/imagery/i.cca/transform.c 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/imagery/i.cca/transform.c 2009-06-22 01:49:13 UTC (rev 38014)
@@ -1,6 +1,6 @@
#include <stdlib.h>
Modified: grass/trunk/imagery/i.cluster/Makefile
--- grass/trunk/imagery/i.cluster/Makefile 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/imagery/i.cluster/Makefile 2009-06-22 01:49:13 UTC (rev 38014)
@@ -2,8 +2,8 @@
PGM = i.cluster
-LIBES = $(CLUSTERLIB) $(IMAGERYLIB) $(GISLIB) $(RASTRLIB) $(GMATHLIB)
-DEPENDENCIES= $(CLUSTERDEP) $(IMAGERYDEP) $(GISDEP) $(RASTRDEP) $(GMATHDEP)
+LIBES = $(CLUSTERLIB) $(IMAGERYLIB) $(GISLIB) $(RASTERLIB) $(GMATHLIB)
+DEPENDENCIES= $(CLUSTERDEP) $(IMAGERYDEP) $(GISDEP) $(RASTERDEP) $(GMATHDEP)
Modified: grass/trunk/imagery/i.cluster/checkpt.c
--- grass/trunk/imagery/i.cluster/checkpt.c 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/imagery/i.cluster/checkpt.c 2009-06-22 01:49:13 UTC (rev 38014)
@@ -1,5 +1,5 @@
#include "global.h"
Modified: grass/trunk/imagery/i.cluster/main.c
--- grass/trunk/imagery/i.cluster/main.c 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/imagery/i.cluster/main.c 2009-06-22 01:49:13 UTC (rev 38014)
@@ -21,7 +21,7 @@
#include <stdlib.h>
#include <time.h>
#define GLOBAL
#include "global.h"
Modified: grass/trunk/imagery/i.cluster/open_files.c
--- grass/trunk/imagery/i.cluster/open_files.c 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/imagery/i.cluster/open_files.c 2009-06-22 01:49:13 UTC (rev 38014)
@@ -1,6 +1,6 @@
#include <stdlib.h>
#include "global.h"
Modified: grass/trunk/imagery/i.cluster/print1.c
--- grass/trunk/imagery/i.cluster/print1.c 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/imagery/i.cluster/print1.c 2009-06-22 01:49:13 UTC (rev 38014)
@@ -1,5 +1,5 @@
#include <grass/cluster.h>
Modified: grass/trunk/imagery/i.cluster/print2.c
--- grass/trunk/imagery/i.cluster/print2.c 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/imagery/i.cluster/print2.c 2009-06-22 01:49:13 UTC (rev 38014)
@@ -1,5 +1,5 @@
Modified: grass/trunk/imagery/i.cluster/print3.c
--- grass/trunk/imagery/i.cluster/print3.c 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/imagery/i.cluster/print3.c 2009-06-22 01:49:13 UTC (rev 38014)
@@ -1,5 +1,5 @@
Modified: grass/trunk/imagery/i.cluster/print4.c
--- grass/trunk/imagery/i.cluster/print4.c 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/imagery/i.cluster/print4.c 2009-06-22 01:49:13 UTC (rev 38014)
@@ -1,5 +1,5 @@
Modified: grass/trunk/imagery/i.cluster/print5.c
--- grass/trunk/imagery/i.cluster/print5.c 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/imagery/i.cluster/print5.c 2009-06-22 01:49:13 UTC (rev 38014)
@@ -1,5 +1,5 @@
Modified: grass/trunk/imagery/i.cluster/print6.c
--- grass/trunk/imagery/i.cluster/print6.c 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/imagery/i.cluster/print6.c 2009-06-22 01:49:13 UTC (rev 38014)
@@ -1,5 +1,5 @@
Modified: grass/trunk/imagery/i.cluster/timer.c
--- grass/trunk/imagery/i.cluster/timer.c 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/imagery/i.cluster/timer.c 2009-06-22 01:49:13 UTC (rev 38014)
@@ -1,6 +1,6 @@
#include <stdio.h>
#include "global.h"
Modified: grass/trunk/imagery/i.eb.eta/Makefile
--- grass/trunk/imagery/i.eb.eta/Makefile 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/imagery/i.eb.eta/Makefile 2009-06-22 01:49:13 UTC (rev 38014)
@@ -2,8 +2,8 @@
PGM = i.eb.eta
Modified: grass/trunk/imagery/i.eb.eta/main.c
--- grass/trunk/imagery/i.eb.eta/main.c 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/imagery/i.eb.eta/main.c 2009-06-22 01:49:13 UTC (rev 38014)
@@ -19,7 +19,7 @@
#include <stdlib.h>
#include <string.h>
double et_a(double r_net_day, double evap_fr, double tempk);
Modified: grass/trunk/imagery/i.eb.evapfr/Makefile
--- grass/trunk/imagery/i.eb.evapfr/Makefile 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/imagery/i.eb.evapfr/Makefile 2009-06-22 01:49:13 UTC (rev 38014)
@@ -2,8 +2,8 @@
PGM = i.eb.evapfr
Modified: grass/trunk/imagery/i.eb.evapfr/main.c
--- grass/trunk/imagery/i.eb.evapfr/main.c 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/imagery/i.eb.evapfr/main.c 2009-06-22 01:49:13 UTC (rev 38014)
@@ -19,7 +19,7 @@
#include <stdlib.h>
#include <string.h>
double evap_fr(double r_net, double g0, double h0);
Modified: grass/trunk/imagery/i.eb.h_SEBAL01/Makefile
--- grass/trunk/imagery/i.eb.h_SEBAL01/Makefile 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/imagery/i.eb.h_SEBAL01/Makefile 2009-06-22 01:49:13 UTC (rev 38014)
@@ -2,8 +2,8 @@
PGM = i.eb.h_SEBAL01
Modified: grass/trunk/imagery/i.eb.h_SEBAL01/main.c
--- grass/trunk/imagery/i.eb.h_SEBAL01/main.c 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/imagery/i.eb.h_SEBAL01/main.c 2009-06-22 01:49:13 UTC (rev 38014)
@@ -24,7 +24,7 @@
#include <stdlib.h>
#include <math.h>
double **G_alloc_matrix(int rows, int cols)
Modified: grass/trunk/imagery/i.eb.soilheatflux/Makefile
--- grass/trunk/imagery/i.eb.soilheatflux/Makefile 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/imagery/i.eb.soilheatflux/Makefile 2009-06-22 01:49:13 UTC (rev 38014)
@@ -2,8 +2,8 @@
PGM = i.eb.soilheatflux
Modified: grass/trunk/imagery/i.eb.soilheatflux/main.c
--- grass/trunk/imagery/i.eb.soilheatflux/main.c 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/imagery/i.eb.soilheatflux/main.c 2009-06-22 01:49:13 UTC (rev 38014)
@@ -19,7 +19,7 @@
#include <stdlib.h>
#include <string.h>
double g_0(double bbalb, double ndvi, double tempk, double rnet,
Modified: grass/trunk/imagery/i.emissivity/Makefile
--- grass/trunk/imagery/i.emissivity/Makefile 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/imagery/i.emissivity/Makefile 2009-06-22 01:49:13 UTC (rev 38014)
@@ -2,8 +2,8 @@
PGM = i.emissivity
Modified: grass/trunk/imagery/i.emissivity/main.c
--- grass/trunk/imagery/i.emissivity/main.c 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/imagery/i.emissivity/main.c 2009-06-22 01:49:13 UTC (rev 38014)
@@ -17,7 +17,7 @@
#include <stdlib.h>
#include <string.h>
double emissivity_generic(double ndvi);
Modified: grass/trunk/imagery/i.evapo.time_integration/Makefile
--- grass/trunk/imagery/i.evapo.time_integration/Makefile 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/imagery/i.evapo.time_integration/Makefile 2009-06-22 01:49:13 UTC (rev 38014)
@@ -2,8 +2,8 @@
PGM = i.evapo.time_integration
Modified: grass/trunk/imagery/i.evapo.time_integration/main.c
--- grass/trunk/imagery/i.evapo.time_integration/main.c 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/imagery/i.evapo.time_integration/main.c 2009-06-22 01:49:13 UTC (rev 38014)
@@ -1,436 +1,436 @@
- * MODULE: i.evapo.time_integration
- * AUTHOR(S): Yann Chemin - yann.chemin at gmail.com
- * Ines Cherif - icherif at yahoo.com
- * PURPOSE: Integrate in time the evapotranspiration from satellite,
- * following a daily pattern from meteorological ETo.
- * COPYRIGHT: (C) 2008-2009 by the GRASS Development Team
- * This program is free software under the GNU Lesser General Public
- * License. Read the file COPYING that comes with GRASS for details.
-#include <stdio.h>
-#include <stdlib.h>
-#include <string.h>
+ * MODULE: i.evapo.time_integration
+ * AUTHOR(S): Yann Chemin - yann.chemin at gmail.com
+ * Ines Cherif - icherif at yahoo.com
+ * PURPOSE: Integrate in time the evapotranspiration from satellite,
+ * following a daily pattern from meteorological ETo.
+ * COPYRIGHT: (C) 2008-2009 by the GRASS Development Team
+ * This program is free software under the GNU Lesser General Public
+ * License. Read the file COPYING that comes with GRASS for details.
+#include <stdio.h>
+#include <stdlib.h>
+#include <string.h>
-#include <grass/glocale.h>
-#define MAXFILES 400
-int main(int argc, char *argv[])
- struct Cell_head cellhd; /*region+header info */
- char *mapset; /*mapset name */
- int nrows, ncols;
- int row, col;
- struct GModule *module;
- struct Option *input, *input1, *input2, *input3, *input4, *input5, *output;
- struct History history; /*metadata */
- struct Colors colors; /*Color rules */
- char *name, *name1, *name2; /*input raster name */
- char *result; /*output raster name */
- /*File Descriptors */
- int nfiles, nfiles1, nfiles2;
- int infd[MAXFILES], infd1[MAXFILES], infd2[MAXFILES];
- int outfd;
- /* Pointers for file names */
- char **names;
- char **ptr;
- char **names1;
- char **ptr1;
- char **names2;
- char **ptr2;
- int DOYbeforeETa[MAXFILES], DOYafterETa[MAXFILES];
- int bfr, aft;
- int ok;
- int i = 0, j = 0;
- double etodoy; /*minimum ETo DOY */
- double startperiod, endperiod; /*first and last days (DOYs) of the period studied */
- void *inrast[MAXFILES], *inrast1[MAXFILES], *inrast2[MAXFILES];
- DCELL *outrast;
- RASTER_MAP_TYPE in_data_type[MAXFILES]; /* ETa */
- RASTER_MAP_TYPE in_data_type1[MAXFILES]; /* DOY of ETa */
- RASTER_MAP_TYPE in_data_type2[MAXFILES]; /* ETo */
- RASTER_MAP_TYPE out_data_type = DCELL_TYPE;
- G_gisinit(argv[0]);
- module = G_define_module();
- module->description =_("Computes temporal integration of satellite "
- "ET actual (ETa) following the daily ET reference "
- "(ETo) from meteorological station(s)");
- module->keywords = _("imagery, evapotranspiration, temporal, integration");
- /* Define the different options */
- input = G_define_standard_option(G_OPT_R_INPUTS);
- input->key = "eta";
- input->description = _("Names of satellite ETa raster maps [mm/d or cm/d]");
- input1 = G_define_standard_option(G_OPT_R_INPUTS);
- input1->key = "eta_doy";
- input1->description =
- _("Names of satellite ETa Day of Year (DOY) raster maps [0-400] [-]");
- input2 = G_define_standard_option(G_OPT_R_INPUTS);
- input2->key = "eto";
- input2->description =
- _("Names of meteorological station ETo raster maps [0-400] [mm/d or cm/d]");
- input3 = G_define_option();
- input3->key = "eto_doy_min";
- input3->type = TYPE_DOUBLE;
- input3->required = YES;
- input3->description = _("Value of DOY for ETo first day");
- input4 = G_define_option();
- input4->key = "start_period";
- input4->type = TYPE_DOUBLE;
- input4->required = YES;
- input4->description = _("Value of DOY for the first day of the period studied");
- input5 = G_define_option();
- input5->key = "end_period";
- input5->type = TYPE_DOUBLE;
- input5->required = YES;
- input5->description = _("Value of DOY for the last day of the period studied");
- output = G_define_standard_option(G_OPT_R_OUTPUT);
- /* init nfiles */
- nfiles = 1;
- nfiles1 = 1;
- nfiles2 = 1;
- if (G_parser(argc, argv))
- exit(EXIT_FAILURE);
- ok = 1;
- names = input->answers;
- ptr = input->answers;
- names1 = input1->answers;
- ptr1 = input1->answers;
- names2 = input2->answers;
- ptr2 = input2->answers;
- etodoy = atof(input3->answer);
- startperiod = atof(input4->answer);
- endperiod = atof(input5->answer);
- result = output->answer;
- if (endperiod<startperiod) {
- G_fatal_error(_("The DOY for end_period can not be smaller than start_period"));
- ok = 0;
- if (etodoy>startperiod) {
- G_fatal_error(_("The DOY for start_period can not be smaller than eto_doy_min"));
- ok = 0;
- if (G_legal_filename(result) < 0) {
- G_fatal_error(_("<%s> is an illegal name"), result);
- ok = 0;
- for (; *ptr != NULL; ptr++) {
- if (nfiles > MAXFILES)
- G_fatal_error(_("Too many ETa files. Only %d allowed."),
- MAXFILES);
- name = *ptr;
- /* find map in mapset */
- mapset = (char *) G_find_cell2(name, "");
- if (mapset == NULL) {
- G_fatal_error(_("Raster map <%s> not found"), name);
- ok = 0;
- if (!ok)
- continue;
- infd[nfiles] = Rast_open_cell_old(name, mapset);
- if (infd[nfiles] < 0) {
- ok = 0;
- continue;
- /* Allocate input buffer */
- in_data_type[nfiles] = Rast_raster_map_type(name, mapset);
- if ((infd[nfiles] = Rast_open_cell_old(name, mapset)) < 0)
- G_fatal_error(_("Unable to open raster map <%s>"), name);
- if ((Rast_get_cellhd(name, mapset, &cellhd)) < 0)
- G_fatal_error(_("Unable to read file header of raster map <%s>"), name);
- inrast[nfiles] = Rast_allocate_raster_buf(in_data_type[nfiles]);
- nfiles++;
- nfiles--;
- if (nfiles <= 1)
- G_fatal_error(_("The min specified input map is two"));
- ok = 1;
- for (; *ptr1 != NULL; ptr1++) {
- if (nfiles1 > MAXFILES)
- MAXFILES);
- name1 = *ptr1;
- mapset = (char *) G_find_cell2(name1, "");
- G_fatal_error(_("Raster map <%s> not found"), name1);
- ok = 0;
- if (!ok)
- continue;
- infd1[nfiles1] = Rast_open_cell_old(name1, mapset);
- if (infd1[nfiles1] < 0) {
- ok = 0;
- continue;
- in_data_type1[nfiles1] = Rast_raster_map_type(name1, mapset);
- if ((infd1[nfiles1] = Rast_open_cell_old(name1, mapset)) < 0)
- G_fatal_error(_("Unable to open raster map <%s>"), name1);
- if ((Rast_get_cellhd(name1, mapset, &cellhd)) < 0)
- G_fatal_error(_("Unable to read file header of raster map <%s>"), name1);
- inrast1[nfiles1] = Rast_allocate_raster_buf(in_data_type1[nfiles1]);
- nfiles1++;
- nfiles1--;
- if (nfiles1 <= 1)
- if (nfiles != nfiles1)
- G_fatal_error(_("ETa and ETa_DOY file numbers are not equal!"));
- ok = 1;
- for (; *ptr2 != NULL; ptr2++) {
- MAXFILES);
- name2 = *ptr2;
- mapset = (char *) G_find_cell2(name2, "");
- G_fatal_error(_("Raster map <%s> not found"), name2);
- ok = 0;
- if (!ok)
- continue;
- infd2[nfiles2] = Rast_open_cell_old(name2, mapset);
- if (infd2[nfiles2] < 0) {
- ok = 0;
- continue;
- in_data_type2[nfiles2] = Rast_raster_map_type(name2, mapset);
- if ((infd2[nfiles2] = Rast_open_cell_old(name2, mapset)) < 0) {
- G_fatal_error(_("Unable to open raster map <%s>"), name2);
- if ((Rast_get_cellhd(name2, mapset, &cellhd)) < 0) {
- G_fatal_error(_("Unable to read file header of raster map <%s>"), name2);
- inrast2[nfiles2] = Rast_allocate_d_raster_buf();
- nfiles2++;
- nfiles2--;
- if (nfiles2 <= 1)
- /* Allocate output buffer, use input map data_type */
- nrows = G_window_rows();
- ncols = G_window_cols();
- outrast = Rast_allocate_raster_buf(out_data_type);
- /* Create New raster files */
- if ((outfd = Rast_open_raster_new(result, 1)) < 0)
- G_fatal_error(_("Unable to create raster map <%s>"), result);
- /* Process pixels */
- double doy[MAXFILES];
- double sum[MAXFILES];
- for (row = 0; row < nrows; row++)
- DCELL d_out;
- DCELL d_ETrF[MAXFILES];
- DCELL d[MAXFILES];
- DCELL d1[MAXFILES];
- DCELL d2[MAXFILES];
- G_percent(row, nrows, 2);
- /* read input map */
- for (i = 1; i <= nfiles; i++)
- if ((Rast_get_d_raster_row(infd[i], inrast[i], row)) < 0)
- G_fatal_error(_("Unable to read raster map <%s> row %d"), name, row);
- for (i = 1; i <= nfiles1; i++)
- if ((Rast_get_d_raster_row(infd1[i], inrast1[i], row)) < 0)
- G_fatal_error(_("Unable to read raster map <%s> row %d"), name1, row);
- for (i = 1; i <= nfiles2; i++)
- if ((Rast_get_d_raster_row (infd2[i], inrast2[i], row)) < 0)
- G_fatal_error(_("Unable to read raster map <%s> row %d"), name2, row);
- /*process the data */
- for (col = 0; col < ncols; col++)
- int d1_null=0;
- int d_null=0;
- if (Rast_is_d_null_value(&((DCELL *) inrast[i])[col]))
- d_null=1;
- else
- d[i] = (double)((DCELL *) inrast[i])[col];
- if (Rast_is_d_null_value(&((DCELL *) inrast1[i])[col]))
- d1_null=1;
- else
- d1[i] = ((DCELL *) inrast1[i])[col];
- d2[i] = ((DCELL *) inrast2[i])[col];
- /* Find out the DOY of the eto image */
- if ( d_null==1 || d1_null==1 )
- Rast_set_d_null_value(&outrast[col],1);
- else
- doy[i] = d1[i] - etodoy+1;
- if (Rast_is_d_null_value(&d2[(int)doy[i]]) || d2[(int)doy[i]]==0 )
- else
- d_ETrF[i] = d[i] / d2[(int)doy[i]];
- /* do nothing */
- if ( d_null==1 || d1_null==1)
- /*G_message(" null value ");*/
- else
- DOYbeforeETa[i]=0; DOYafterETa[i]=0;
- if (i == 1)
- DOYbeforeETa[i] = startperiod;
- else
- int k=i-1;
- while (d1[k]>=startperiod )
- if (d1[k]<0) // case were d1[k] is null
- k=k-1;
- else
- DOYbeforeETa[i] = 1+((d1[i] + d1[k])/2.0);
- break;
- if (i == nfiles1)
- DOYafterETa[i] = endperiod;
- else
- int k=i+1;
- while (d1[k]<=endperiod)
- k=k+1;
- else
- DOYafterETa[i] = (d1[i] + d1[k]) / 2.0;
- break;
- sum[MAXFILES] = 0.0;
- if(d_null==1 || d1_null==1)
- /* do nothing */
- else
- if (DOYbeforeETa[i]==0 || DOYbeforeETa[i]==0 )
- else
- bfr = (int)DOYbeforeETa[i];
- aft = (int)DOYafterETa[i];
- sum[i]=0.0;
- for (j = bfr; j < aft; j++)
- sum[i] += d2[(int)(j-etodoy+1)];
- d_out = 0.0;
- if(d_null==1 || d_null==1)
- else
- d_out += d_ETrF[i] * sum[i];
- outrast[col] = d_out;
- if (Rast_put_raster_row(outfd, outrast, out_data_type) < 0)
- G_fatal_error(_("Unable to write to raster map<%s>"), result);
- for (i = 1; i <= nfiles; i++) {
- G_free(inrast[i]);
- Rast_close_cell(infd[i]);
- G_free(inrast1[i]);
- Rast_close_cell(infd1[i]);
- G_free(inrast2[i]);
- Rast_close_cell(infd2[i]);
- G_free(outrast);
- Rast_close_cell(outfd);
- /* Color table from 0.0 to 10.0 */
- Rast_init_colors(&colors);
- Rast_add_color_rule(0.0, 0, 0, 0, 10.0, 255, 255, 255, &colors);
- /* Metadata */
- Rast_short_history(result, "raster", &history);
- Rast_command_history(&history);
- Rast_write_history(result, &history);
- exit(EXIT_SUCCESS);
+#include <grass/glocale.h>
+#define MAXFILES 400
+int main(int argc, char *argv[])
+ struct Cell_head cellhd; /*region+header info */
+ char *mapset; /*mapset name */
+ int nrows, ncols;
+ int row, col;
+ struct GModule *module;
+ struct Option *input, *input1, *input2, *input3, *input4, *input5, *output;
+ struct History history; /*metadata */
+ struct Colors colors; /*Color rules */
+ char *name, *name1, *name2; /*input raster name */
+ char *result; /*output raster name */
+ /*File Descriptors */
+ int nfiles, nfiles1, nfiles2;
+ int infd[MAXFILES], infd1[MAXFILES], infd2[MAXFILES];
+ int outfd;
+ /* Pointers for file names */
+ char **names;
+ char **ptr;
+ char **names1;
+ char **ptr1;
+ char **names2;
+ char **ptr2;
+ int DOYbeforeETa[MAXFILES], DOYafterETa[MAXFILES];
+ int bfr, aft;
+ int ok;
+ int i = 0, j = 0;
+ double etodoy; /*minimum ETo DOY */
+ double startperiod, endperiod; /*first and last days (DOYs) of the period studied */
+ void *inrast[MAXFILES], *inrast1[MAXFILES], *inrast2[MAXFILES];
+ DCELL *outrast;
+ RASTER_MAP_TYPE in_data_type[MAXFILES]; /* ETa */
+ RASTER_MAP_TYPE in_data_type1[MAXFILES]; /* DOY of ETa */
+ RASTER_MAP_TYPE in_data_type2[MAXFILES]; /* ETo */
+ RASTER_MAP_TYPE out_data_type = DCELL_TYPE;
+ G_gisinit(argv[0]);
+ module = G_define_module();
+ module->description =_("Computes temporal integration of satellite "
+ "ET actual (ETa) following the daily ET reference "
+ "(ETo) from meteorological station(s)");
+ module->keywords = _("imagery, evapotranspiration, temporal, integration");
+ /* Define the different options */
+ input = G_define_standard_option(G_OPT_R_INPUTS);
+ input->key = "eta";
+ input->description = _("Names of satellite ETa raster maps [mm/d or cm/d]");
+ input1 = G_define_standard_option(G_OPT_R_INPUTS);
+ input1->key = "eta_doy";
+ input1->description =
+ _("Names of satellite ETa Day of Year (DOY) raster maps [0-400] [-]");
+ input2 = G_define_standard_option(G_OPT_R_INPUTS);
+ input2->key = "eto";
+ input2->description =
+ _("Names of meteorological station ETo raster maps [0-400] [mm/d or cm/d]");
+ input3 = G_define_option();
+ input3->key = "eto_doy_min";
+ input3->type = TYPE_DOUBLE;
+ input3->required = YES;
+ input3->description = _("Value of DOY for ETo first day");
+ input4 = G_define_option();
+ input4->key = "start_period";
+ input4->type = TYPE_DOUBLE;
+ input4->required = YES;
+ input4->description = _("Value of DOY for the first day of the period studied");
+ input5 = G_define_option();
+ input5->key = "end_period";
+ input5->type = TYPE_DOUBLE;
+ input5->required = YES;
+ input5->description = _("Value of DOY for the last day of the period studied");
+ output = G_define_standard_option(G_OPT_R_OUTPUT);
+ /* init nfiles */
+ nfiles = 1;
+ nfiles1 = 1;
+ nfiles2 = 1;
+ if (G_parser(argc, argv))
+ exit(EXIT_FAILURE);
+ ok = 1;
+ names = input->answers;
+ ptr = input->answers;
+ names1 = input1->answers;
+ ptr1 = input1->answers;
+ names2 = input2->answers;
+ ptr2 = input2->answers;
+ etodoy = atof(input3->answer);
+ startperiod = atof(input4->answer);
+ endperiod = atof(input5->answer);
+ result = output->answer;
+ if (endperiod<startperiod) {
+ G_fatal_error(_("The DOY for end_period can not be smaller than start_period"));
+ ok = 0;
+ if (etodoy>startperiod) {
+ G_fatal_error(_("The DOY for start_period can not be smaller than eto_doy_min"));
+ ok = 0;
+ if (G_legal_filename(result) < 0) {
+ G_fatal_error(_("<%s> is an illegal name"), result);
+ ok = 0;
+ for (; *ptr != NULL; ptr++) {
+ if (nfiles > MAXFILES)
+ G_fatal_error(_("Too many ETa files. Only %d allowed."),
+ MAXFILES);
+ name = *ptr;
+ /* find map in mapset */
+ mapset = (char *) G_find_cell2(name, "");
+ if (mapset == NULL) {
+ G_fatal_error(_("Raster map <%s> not found"), name);
+ ok = 0;
+ if (!ok)
+ continue;
+ infd[nfiles] = Rast_open_cell_old(name, mapset);
+ if (infd[nfiles] < 0) {
+ ok = 0;
+ continue;
+ /* Allocate input buffer */
+ in_data_type[nfiles] = Rast_raster_map_type(name, mapset);
+ if ((infd[nfiles] = Rast_open_cell_old(name, mapset)) < 0)
+ G_fatal_error(_("Unable to open raster map <%s>"), name);
+ if ((Rast_get_cellhd(name, mapset, &cellhd)) < 0)
+ G_fatal_error(_("Unable to read file header of raster map <%s>"), name);
+ inrast[nfiles] = Rast_allocate_raster_buf(in_data_type[nfiles]);
+ nfiles++;
+ nfiles--;
+ if (nfiles <= 1)
+ G_fatal_error(_("The min specified input map is two"));
+ ok = 1;
+ for (; *ptr1 != NULL; ptr1++) {
+ if (nfiles1 > MAXFILES)
+ MAXFILES);
+ name1 = *ptr1;
+ mapset = (char *) G_find_cell2(name1, "");
+ G_fatal_error(_("Raster map <%s> not found"), name1);
+ ok = 0;
+ if (!ok)
+ continue;
+ infd1[nfiles1] = Rast_open_cell_old(name1, mapset);
+ if (infd1[nfiles1] < 0) {
+ ok = 0;
+ continue;
+ in_data_type1[nfiles1] = Rast_raster_map_type(name1, mapset);
+ if ((infd1[nfiles1] = Rast_open_cell_old(name1, mapset)) < 0)
+ G_fatal_error(_("Unable to open raster map <%s>"), name1);
+ if ((Rast_get_cellhd(name1, mapset, &cellhd)) < 0)
+ G_fatal_error(_("Unable to read file header of raster map <%s>"), name1);
+ inrast1[nfiles1] = Rast_allocate_raster_buf(in_data_type1[nfiles1]);
+ nfiles1++;
+ nfiles1--;
+ if (nfiles1 <= 1)
+ if (nfiles != nfiles1)
+ G_fatal_error(_("ETa and ETa_DOY file numbers are not equal!"));
+ ok = 1;
+ for (; *ptr2 != NULL; ptr2++) {
+ MAXFILES);
+ name2 = *ptr2;
+ mapset = (char *) G_find_cell2(name2, "");
+ G_fatal_error(_("Raster map <%s> not found"), name2);
+ ok = 0;
+ if (!ok)
+ continue;
+ infd2[nfiles2] = Rast_open_cell_old(name2, mapset);
+ if (infd2[nfiles2] < 0) {
+ ok = 0;
+ continue;
+ in_data_type2[nfiles2] = Rast_raster_map_type(name2, mapset);
+ if ((infd2[nfiles2] = Rast_open_cell_old(name2, mapset)) < 0) {
+ G_fatal_error(_("Unable to open raster map <%s>"), name2);
+ if ((Rast_get_cellhd(name2, mapset, &cellhd)) < 0) {
+ G_fatal_error(_("Unable to read file header of raster map <%s>"), name2);
+ inrast2[nfiles2] = Rast_allocate_d_raster_buf();
+ nfiles2++;
+ nfiles2--;
+ if (nfiles2 <= 1)
+ /* Allocate output buffer, use input map data_type */
+ nrows = G_window_rows();
+ ncols = G_window_cols();
+ outrast = Rast_allocate_raster_buf(out_data_type);
+ /* Create New raster files */
+ if ((outfd = Rast_open_raster_new(result, 1)) < 0)
+ G_fatal_error(_("Unable to create raster map <%s>"), result);
+ /* Process pixels */
+ double doy[MAXFILES];
+ double sum[MAXFILES];
+ for (row = 0; row < nrows; row++)
+ DCELL d_out;
+ DCELL d_ETrF[MAXFILES];
+ DCELL d[MAXFILES];
+ DCELL d1[MAXFILES];
+ DCELL d2[MAXFILES];
+ G_percent(row, nrows, 2);
+ /* read input map */
+ for (i = 1; i <= nfiles; i++)
+ if ((Rast_get_d_raster_row(infd[i], inrast[i], row)) < 0)
+ G_fatal_error(_("Unable to read raster map <%s> row %d"), name, row);
+ for (i = 1; i <= nfiles1; i++)
+ if ((Rast_get_d_raster_row(infd1[i], inrast1[i], row)) < 0)
+ G_fatal_error(_("Unable to read raster map <%s> row %d"), name1, row);
+ for (i = 1; i <= nfiles2; i++)
+ if ((Rast_get_d_raster_row (infd2[i], inrast2[i], row)) < 0)
+ G_fatal_error(_("Unable to read raster map <%s> row %d"), name2, row);
+ /*process the data */
+ for (col = 0; col < ncols; col++)
+ int d1_null=0;
+ int d_null=0;
+ if (Rast_is_d_null_value(&((DCELL *) inrast[i])[col]))
+ d_null=1;
+ else
+ d[i] = (double)((DCELL *) inrast[i])[col];
+ if (Rast_is_d_null_value(&((DCELL *) inrast1[i])[col]))
+ d1_null=1;
+ else
+ d1[i] = ((DCELL *) inrast1[i])[col];
+ d2[i] = ((DCELL *) inrast2[i])[col];
+ /* Find out the DOY of the eto image */
+ if ( d_null==1 || d1_null==1 )
+ Rast_set_d_null_value(&outrast[col],1);
+ else
+ doy[i] = d1[i] - etodoy+1;
+ if (Rast_is_d_null_value(&d2[(int)doy[i]]) || d2[(int)doy[i]]==0 )
+ else
+ d_ETrF[i] = d[i] / d2[(int)doy[i]];
+ /* do nothing */
+ if ( d_null==1 || d1_null==1)
+ /*G_message(" null value ");*/
+ else
+ DOYbeforeETa[i]=0; DOYafterETa[i]=0;
+ if (i == 1)
+ DOYbeforeETa[i] = startperiod;
+ else
+ int k=i-1;
+ while (d1[k]>=startperiod )
+ if (d1[k]<0) // case were d1[k] is null
+ k=k-1;
+ else
+ DOYbeforeETa[i] = 1+((d1[i] + d1[k])/2.0);
+ break;
+ if (i == nfiles1)
+ DOYafterETa[i] = endperiod;
+ else
+ int k=i+1;
+ while (d1[k]<=endperiod)
+ k=k+1;
+ else
+ DOYafterETa[i] = (d1[i] + d1[k]) / 2.0;
+ break;
+ sum[MAXFILES] = 0.0;
+ if(d_null==1 || d1_null==1)
+ /* do nothing */
+ else
+ if (DOYbeforeETa[i]==0 || DOYbeforeETa[i]==0 )
+ else
+ bfr = (int)DOYbeforeETa[i];
+ aft = (int)DOYafterETa[i];
+ sum[i]=0.0;
+ for (j = bfr; j < aft; j++)
+ sum[i] += d2[(int)(j-etodoy+1)];
+ d_out = 0.0;
+ if(d_null==1 || d_null==1)
+ else
+ d_out += d_ETrF[i] * sum[i];
+ outrast[col] = d_out;
+ if (Rast_put_raster_row(outfd, outrast, out_data_type) < 0)
+ G_fatal_error(_("Unable to write to raster map<%s>"), result);
+ for (i = 1; i <= nfiles; i++) {
+ G_free(inrast[i]);
+ Rast_close_cell(infd[i]);
+ G_free(inrast1[i]);
+ Rast_close_cell(infd1[i]);
+ G_free(inrast2[i]);
+ Rast_close_cell(infd2[i]);
+ G_free(outrast);
+ Rast_close_cell(outfd);
+ /* Color table from 0.0 to 10.0 */
+ Rast_init_colors(&colors);
+ Rast_add_color_rule(0.0, 0, 0, 0, 10.0, 255, 255, 255, &colors);
+ /* Metadata */
+ Rast_short_history(result, "raster", &history);
+ Rast_command_history(&history);
+ Rast_write_history(result, &history);
+ exit(EXIT_SUCCESS);
Property changes on: grass/trunk/imagery/i.evapo.time_integration/main.c
___________________________________________________________________
+ text/x-csrc
+ native
Modified: grass/trunk/imagery/i.fft/Makefile
--- grass/trunk/imagery/i.fft/Makefile 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/imagery/i.fft/Makefile 2009-06-22 01:49:13 UTC (rev 38014)
@@ -2,8 +2,8 @@
PGM = i.fft
-LIBES = $(GMATHLIB) $(GISLIB) $(RASTRLIB) $(FFTWLIB) $(MATHLIB)
-DEPENDENCIES= $(GMATHDEP) $(GISDEP) $(RASTRDEP)
+LIBES = $(GMATHLIB) $(GISLIB) $(RASTERLIB) $(FFTWLIB) $(MATHLIB)
+DEPENDENCIES= $(GMATHDEP) $(GISDEP) $(RASTERDEP)
Modified: grass/trunk/imagery/i.fft/main.c
--- grass/trunk/imagery/i.fft/main.c 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/imagery/i.fft/main.c 2009-06-22 01:49:13 UTC (rev 38014)
@@ -37,7 +37,7 @@
#include <stdlib.h>
#include <math.h>
Modified: grass/trunk/imagery/i.gensig/Makefile
--- grass/trunk/imagery/i.gensig/Makefile 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/imagery/i.gensig/Makefile 2009-06-22 01:49:13 UTC (rev 38014)
@@ -2,8 +2,8 @@
PGM = i.gensig
-LIBES = $(IMAGERYLIB) $(GISLIB) $(RASTRLIB) $(GMATHLIB)
-DEPENDENCIES= $(IMAGERYDEP) $(GISDEP) $(RASTRDEP) $(GMATHDEP)
+LIBES = $(IMAGERYLIB) $(GISLIB) $(RASTERLIB) $(GMATHLIB)
+DEPENDENCIES= $(IMAGERYDEP) $(GISDEP) $(RASTERDEP) $(GMATHDEP)
Modified: grass/trunk/imagery/i.gensig/alloc.c
--- grass/trunk/imagery/i.gensig/alloc.c 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/imagery/i.gensig/alloc.c 2009-06-22 01:49:13 UTC (rev 38014)
@@ -1,5 +1,5 @@
double *vector(int nl, int nh)
Modified: grass/trunk/imagery/i.gensig/can_invert.c
--- grass/trunk/imagery/i.gensig/can_invert.c 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/imagery/i.gensig/can_invert.c 2009-06-22 01:49:13 UTC (rev 38014)
@@ -1,6 +1,6 @@
#include <math.h>
int can_invert(double **a, int n)
Modified: grass/trunk/imagery/i.gensig/closefiles.c
--- grass/trunk/imagery/i.gensig/closefiles.c 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/imagery/i.gensig/closefiles.c 2009-06-22 01:49:13 UTC (rev 38014)
@@ -1,4 +1,4 @@
#include "files.h"
Modified: grass/trunk/imagery/i.gensig/covariance.c
--- grass/trunk/imagery/i.gensig/covariance.c 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/imagery/i.gensig/covariance.c 2009-06-22 01:49:13 UTC (rev 38014)
@@ -1,6 +1,6 @@
#include <stdlib.h>
Modified: grass/trunk/imagery/i.gensig/eigen.c
--- grass/trunk/imagery/i.gensig/eigen.c 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/imagery/i.gensig/eigen.c 2009-06-22 01:49:13 UTC (rev 38014)
@@ -1,5 +1,5 @@
#include <math.h>
double **matrix(), *vector();
Modified: grass/trunk/imagery/i.gensig/get_train.c
--- grass/trunk/imagery/i.gensig/get_train.c 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/imagery/i.gensig/get_train.c 2009-06-22 01:49:13 UTC (rev 38014)
@@ -1,7 +1,7 @@
#include <stdlib.h>
#include <string.h>
Modified: grass/trunk/imagery/i.gensig/labels.c
--- grass/trunk/imagery/i.gensig/labels.c 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/imagery/i.gensig/labels.c 2009-06-22 01:49:13 UTC (rev 38014)
@@ -1,4 +1,4 @@
#include "parms.h"
#include "files.h"
Modified: grass/trunk/imagery/i.gensig/lookup_class.c
--- grass/trunk/imagery/i.gensig/lookup_class.c 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/imagery/i.gensig/lookup_class.c 2009-06-22 01:49:13 UTC (rev 38014)
@@ -1,5 +1,5 @@
/* build index of cell values from list */
/* -1 means not found in list */
Modified: grass/trunk/imagery/i.gensig/means.c
--- grass/trunk/imagery/i.gensig/means.c 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/imagery/i.gensig/means.c 2009-06-22 01:49:13 UTC (rev 38014)
@@ -1,5 +1,5 @@
#include <stdlib.h>
#include "signature.h"
Modified: grass/trunk/imagery/i.gensig/openfiles.c
--- grass/trunk/imagery/i.gensig/openfiles.c 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/imagery/i.gensig/openfiles.c 2009-06-22 01:49:13 UTC (rev 38014)
@@ -1,6 +1,6 @@
#include <stdlib.h>
Modified: grass/trunk/imagery/i.gensig/parse.c
--- grass/trunk/imagery/i.gensig/parse.c 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/imagery/i.gensig/parse.c 2009-06-22 01:49:13 UTC (rev 38014)
@@ -1,6 +1,6 @@
#include <stdlib.h>
#include "parms.h"
Modified: grass/trunk/imagery/i.gensig/read_train.c
--- grass/trunk/imagery/i.gensig/read_train.c 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/imagery/i.gensig/read_train.c 2009-06-22 01:49:13 UTC (rev 38014)
@@ -1,6 +1,6 @@
#include <stdlib.h>
Modified: grass/trunk/imagery/i.gensigset/Makefile
--- grass/trunk/imagery/i.gensigset/Makefile 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/imagery/i.gensigset/Makefile 2009-06-22 01:49:13 UTC (rev 38014)
@@ -2,8 +2,8 @@
PGM = i.gensigset
Modified: grass/trunk/imagery/i.gensigset/closefiles.c
--- grass/trunk/imagery/i.gensigset/closefiles.c 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/imagery/i.gensigset/closefiles.c 2009-06-22 01:49:13 UTC (rev 38014)
@@ -1,4 +1,4 @@
#include "files.h"
Modified: grass/trunk/imagery/i.gensigset/get_train.c
--- grass/trunk/imagery/i.gensigset/get_train.c 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/imagery/i.gensigset/get_train.c 2009-06-22 01:49:13 UTC (rev 38014)
@@ -1,6 +1,6 @@
#include <stdlib.h>
Modified: grass/trunk/imagery/i.gensigset/invert.c
--- grass/trunk/imagery/i.gensigset/invert.c 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/imagery/i.gensigset/invert.c 2009-06-22 01:49:13 UTC (rev 38014)
@@ -1,5 +1,5 @@
int invert(
Modified: grass/trunk/imagery/i.gensigset/labels.c
--- grass/trunk/imagery/i.gensigset/labels.c 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/imagery/i.gensigset/labels.c 2009-06-22 01:49:13 UTC (rev 38014)
@@ -1,4 +1,4 @@
#include "parms.h"
Modified: grass/trunk/imagery/i.gensigset/lookup_class.c
--- grass/trunk/imagery/i.gensigset/lookup_class.c 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/imagery/i.gensigset/lookup_class.c 2009-06-22 01:49:13 UTC (rev 38014)
@@ -1,5 +1,5 @@
Modified: grass/trunk/imagery/i.gensigset/main.c
--- grass/trunk/imagery/i.gensigset/main.c 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/imagery/i.gensigset/main.c 2009-06-22 01:49:13 UTC (rev 38014)
@@ -19,7 +19,7 @@
#include <stdlib.h>
#include "files.h"
Modified: grass/trunk/imagery/i.gensigset/openfiles.c
--- grass/trunk/imagery/i.gensigset/openfiles.c 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/imagery/i.gensigset/openfiles.c 2009-06-22 01:49:13 UTC (rev 38014)
@@ -1,6 +1,6 @@
#include <stdlib.h>
Modified: grass/trunk/imagery/i.gensigset/parse.c
--- grass/trunk/imagery/i.gensigset/parse.c 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/imagery/i.gensigset/parse.c 2009-06-22 01:49:13 UTC (rev 38014)
@@ -1,6 +1,6 @@
#include <stdlib.h>
#include "parms.h"
Modified: grass/trunk/imagery/i.gensigset/read_data.c
--- grass/trunk/imagery/i.gensigset/read_data.c 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/imagery/i.gensigset/read_data.c 2009-06-22 01:49:13 UTC (rev 38014)
@@ -1,6 +1,6 @@
#include <stdlib.h>
Modified: grass/trunk/imagery/i.gensigset/read_train.c
--- grass/trunk/imagery/i.gensigset/read_train.c 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/imagery/i.gensigset/read_train.c 2009-06-22 01:49:13 UTC (rev 38014)
@@ -1,6 +1,6 @@
#include <stdlib.h>
Modified: grass/trunk/imagery/i.gensigset/subcluster.c
--- grass/trunk/imagery/i.gensigset/subcluster.c 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/imagery/i.gensigset/subcluster.c 2009-06-22 01:49:13 UTC (rev 38014)
@@ -1,7 +1,7 @@
#include <math.h>
#include <stdlib.h>
Modified: grass/trunk/imagery/i.his.rgb/Makefile
--- grass/trunk/imagery/i.his.rgb/Makefile 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/imagery/i.his.rgb/Makefile 2009-06-22 01:49:13 UTC (rev 38014)
@@ -2,8 +2,8 @@
PGM = i.his.rgb
Modified: grass/trunk/imagery/i.his.rgb/closefiles.c
--- grass/trunk/imagery/i.his.rgb/closefiles.c 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/imagery/i.his.rgb/closefiles.c 2009-06-22 01:49:13 UTC (rev 38014)
@@ -1,6 +1,6 @@
#include <stdlib.h>
#include "globals.h"
/* This routine closes up the cell maps, frees up the row buffers and
Modified: grass/trunk/imagery/i.his.rgb/his2rgb.c
--- grass/trunk/imagery/i.his.rgb/his2rgb.c 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/imagery/i.his.rgb/his2rgb.c 2009-06-22 01:49:13 UTC (rev 38014)
@@ -17,7 +17,7 @@
each band is processed and written out. CWU GIS Lab: DBS 8/90 */
void his2rgb(CELL * rowbuffer[3], int columns)
Modified: grass/trunk/imagery/i.his.rgb/main.c
--- grass/trunk/imagery/i.his.rgb/main.c 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/imagery/i.his.rgb/main.c 2009-06-22 01:49:13 UTC (rev 38014)
@@ -22,7 +22,7 @@
#include <stdio.h>
#include <string.h>
Modified: grass/trunk/imagery/i.his.rgb/openfiles.c
--- grass/trunk/imagery/i.his.rgb/openfiles.c 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/imagery/i.his.rgb/openfiles.c 2009-06-22 01:49:13 UTC (rev 38014)
@@ -1,6 +1,6 @@
#include <stdio.h>
Modified: grass/trunk/imagery/i.ifft/Makefile
--- grass/trunk/imagery/i.ifft/Makefile 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/imagery/i.ifft/Makefile 2009-06-22 01:49:13 UTC (rev 38014)
@@ -2,8 +2,8 @@
PGM = i.ifft
Modified: grass/trunk/imagery/i.ifft/main.c
--- grass/trunk/imagery/i.ifft/main.c 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/imagery/i.ifft/main.c 2009-06-22 01:49:13 UTC (rev 38014)
@@ -34,7 +34,7 @@
#include <stdlib.h>
#include <math.h>
Modified: grass/trunk/imagery/i.latlong/Makefile
--- grass/trunk/imagery/i.latlong/Makefile 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/imagery/i.latlong/Makefile 2009-06-22 01:49:13 UTC (rev 38014)
@@ -2,8 +2,8 @@
PGM = i.latlong
-LIBES = $(GPROJLIB) $(GISLIB) $(RASTRLIB)
-DEPENDENCIES = $(GPROJDEP) $(GISDEP) $(RASTRDEP)
+LIBES = $(GPROJLIB) $(GISLIB) $(RASTERLIB)
+DEPENDENCIES = $(GPROJDEP) $(GISDEP) $(RASTERDEP)
EXTRA_INC = $(PROJINC)
Modified: grass/trunk/imagery/i.latlong/main.c
--- grass/trunk/imagery/i.latlong/main.c 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/imagery/i.latlong/main.c 2009-06-22 01:49:13 UTC (rev 38014)
@@ -16,7 +16,7 @@
#include <stdlib.h>
#include <string.h>
Modified: grass/trunk/imagery/i.maxlik/Makefile
--- grass/trunk/imagery/i.maxlik/Makefile 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/imagery/i.maxlik/Makefile 2009-06-22 01:49:13 UTC (rev 38014)
@@ -2,8 +2,8 @@
PGM = i.maxlik
Modified: grass/trunk/imagery/i.maxlik/classify.c
--- grass/trunk/imagery/i.maxlik/classify.c 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/imagery/i.maxlik/classify.c 2009-06-22 01:49:13 UTC (rev 38014)
@@ -1,5 +1,5 @@
#include "global.h"
Modified: grass/trunk/imagery/i.maxlik/hist.c
--- grass/trunk/imagery/i.maxlik/hist.c 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/imagery/i.maxlik/hist.c 2009-06-22 01:49:13 UTC (rev 38014)
@@ -1,5 +1,5 @@
int make_history(char *name, char *group, char *subgroup, char *sigfile)
struct History hist;
Modified: grass/trunk/imagery/i.maxlik/invert.c
--- grass/trunk/imagery/i.maxlik/invert.c 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/imagery/i.maxlik/invert.c 2009-06-22 01:49:13 UTC (rev 38014)
@@ -1,7 +1,7 @@
#include <stdlib.h>
#include <math.h>
#include "global.h"
Modified: grass/trunk/imagery/i.maxlik/main.c
--- grass/trunk/imagery/i.maxlik/main.c 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/imagery/i.maxlik/main.c 2009-06-22 01:49:13 UTC (rev 38014)
@@ -21,7 +21,7 @@
#include <stdlib.h>
#include "global.h"
Modified: grass/trunk/imagery/i.maxlik/open.c
--- grass/trunk/imagery/i.maxlik/open.c 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/imagery/i.maxlik/open.c 2009-06-22 01:49:13 UTC (rev 38014)
@@ -1,6 +1,6 @@
#include <stdlib.h>
#include "global.h"
Modified: grass/trunk/imagery/i.modis.qc/Makefile
--- grass/trunk/imagery/i.modis.qc/Makefile 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/imagery/i.modis.qc/Makefile 2009-06-22 01:49:13 UTC (rev 38014)
@@ -2,8 +2,8 @@
PGM = i.modis.qc
Modified: grass/trunk/imagery/i.modis.qc/main.c
--- grass/trunk/imagery/i.modis.qc/main.c 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/imagery/i.modis.qc/main.c 2009-06-22 01:49:13 UTC (rev 38014)
@@ -20,7 +20,7 @@
#include <stdlib.h>
#include <string.h>
/* MOD09Q1 Products (250m, 8-Days) */
Modified: grass/trunk/imagery/i.pca/Makefile
--- grass/trunk/imagery/i.pca/Makefile 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/imagery/i.pca/Makefile 2009-06-22 01:49:13 UTC (rev 38014)
@@ -2,8 +2,8 @@
PGM = i.pca
Modified: grass/trunk/imagery/i.pca/main.c
--- grass/trunk/imagery/i.pca/main.c 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/imagery/i.pca/main.c 2009-06-22 01:49:13 UTC (rev 38014)
@@ -22,7 +22,7 @@
#include <string.h>
#include <math.h>
Modified: grass/trunk/imagery/i.pca/support.c
--- grass/trunk/imagery/i.pca/support.c 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/imagery/i.pca/support.c 2009-06-22 01:49:13 UTC (rev 38014)
@@ -1,6 +1,6 @@
#include <string.h>
Modified: grass/trunk/imagery/i.rectify/Makefile
--- grass/trunk/imagery/i.rectify/Makefile 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/imagery/i.rectify/Makefile 2009-06-22 01:49:13 UTC (rev 38014)
@@ -2,8 +2,8 @@
PGM = i.rectify
Modified: grass/trunk/imagery/i.rectify/crs.c
--- grass/trunk/imagery/i.rectify/crs.c 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/imagery/i.rectify/crs.c 2009-06-22 01:49:13 UTC (rev 38014)
@@ -32,7 +32,7 @@
#include <math.h>
#include <limits.h>
#define MSDOS 1
Modified: grass/trunk/imagery/i.rectify/exec.c
--- grass/trunk/imagery/i.rectify/exec.c 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/imagery/i.rectify/exec.c 2009-06-22 01:49:13 UTC (rev 38014)
@@ -14,7 +14,7 @@
#include <time.h>
#include <unistd.h>
#include "global.h"
Modified: grass/trunk/imagery/i.rectify/main.c
--- grass/trunk/imagery/i.rectify/main.c 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/imagery/i.rectify/main.c 2009-06-22 01:49:13 UTC (rev 38014)
@@ -25,7 +25,7 @@
#include <stdlib.h>
#include <string.h>
#include "global.h"
Modified: grass/trunk/imagery/i.rectify/perform.c
--- grass/trunk/imagery/i.rectify/perform.c 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/imagery/i.rectify/perform.c 2009-06-22 01:49:13 UTC (rev 38014)
@@ -1,5 +1,5 @@
#include "global.h"
Modified: grass/trunk/imagery/i.rectify/rectify.c
--- grass/trunk/imagery/i.rectify/rectify.c 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/imagery/i.rectify/rectify.c 2009-06-22 01:49:13 UTC (rev 38014)
@@ -1,6 +1,6 @@
#include <unistd.h>
#include "global.h"
Modified: grass/trunk/imagery/i.rectify/write.c
--- grass/trunk/imagery/i.rectify/write.c 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/imagery/i.rectify/write.c 2009-06-22 01:49:13 UTC (rev 38014)
@@ -3,7 +3,7 @@
#include <fcntl.h>
#include <unistd.h>
#include "global.h"
Modified: grass/trunk/imagery/i.rgb.his/Makefile
--- grass/trunk/imagery/i.rgb.his/Makefile 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/imagery/i.rgb.his/Makefile 2009-06-22 01:49:13 UTC (rev 38014)
@@ -2,8 +2,8 @@
PGM = i.rgb.his
Modified: grass/trunk/imagery/i.rgb.his/closefiles.c
--- grass/trunk/imagery/i.rgb.his/closefiles.c 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/imagery/i.rgb.his/closefiles.c 2009-06-22 01:49:13 UTC (rev 38014)
@@ -1,6 +1,6 @@
#include <stdlib.h>
Modified: grass/trunk/imagery/i.rgb.his/main.c
--- grass/trunk/imagery/i.rgb.his/main.c 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/imagery/i.rgb.his/main.c 2009-06-22 01:49:13 UTC (rev 38014)
@@ -22,7 +22,7 @@
#include <stdlib.h>
#include <string.h>
Modified: grass/trunk/imagery/i.rgb.his/openfiles.c
--- grass/trunk/imagery/i.rgb.his/openfiles.c 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/imagery/i.rgb.his/openfiles.c 2009-06-22 01:49:13 UTC (rev 38014)
@@ -1,6 +1,6 @@
#include <stdio.h>
Modified: grass/trunk/imagery/i.rgb.his/rgb2his.c
--- grass/trunk/imagery/i.rgb.his/rgb2his.c 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/imagery/i.rgb.his/rgb2his.c 2009-06-22 01:49:13 UTC (rev 38014)
@@ -17,7 +17,7 @@
void rgb2his(CELL * rowbuffer[3], int columns)
Modified: grass/trunk/imagery/i.smap/Makefile
--- grass/trunk/imagery/i.smap/Makefile 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/imagery/i.smap/Makefile 2009-06-22 01:49:13 UTC (rev 38014)
@@ -2,8 +2,8 @@
PGM = i.smap
Modified: grass/trunk/imagery/i.smap/closefiles.c
--- grass/trunk/imagery/i.smap/closefiles.c 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/imagery/i.smap/closefiles.c 2009-06-22 01:49:13 UTC (rev 38014)
@@ -1,6 +1,6 @@
#include <unistd.h>
#include <grass/gis.h>
-#include <grass/Rast.h>
+#include <grass/raster.h>
#include "bouman.h"
Modified: grass/trunk/imagery/i.smap/decimate.c
--- grass/trunk/imagery/i.smap/decimate.c 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/imagery/i.smap/decimate.c 2009-06-22 01:49:13 UTC (rev 38014)
@@ -1,5 +1,5 @@
#include "bouman.h"
#include "region.h"
Modified: grass/trunk/imagery/i.smap/history.c
--- grass/trunk/imagery/i.smap/history.c 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/imagery/i.smap/history.c 2009-06-22 01:49:13 UTC (rev 38014)
@@ -1,5 +1,5 @@
void make_history(const char *name, const char *group, const char *subgroup, const char *sigfile)
Modified: grass/trunk/imagery/i.smap/interp.c
--- grass/trunk/imagery/i.smap/interp.c 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/imagery/i.smap/interp.c 2009-06-22 01:49:13 UTC (rev 38014)
@@ -1,7 +1,7 @@
#include <stdlib.h>
#include <math.h>
#include "bouman.h"
#include "region.h"
Modified: grass/trunk/imagery/i.smap/invert.c
--- grass/trunk/imagery/i.smap/invert.c 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/imagery/i.smap/invert.c 2009-06-22 01:49:13 UTC (rev 38014)
@@ -1,6 +1,6 @@
#include <math.h>
int invert(
Modified: grass/trunk/imagery/i.smap/labels.c
--- grass/trunk/imagery/i.smap/labels.c 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/imagery/i.smap/labels.c 2009-06-22 01:49:13 UTC (rev 38014)
@@ -1,4 +1,4 @@
#include "bouman.h"
Modified: grass/trunk/imagery/i.smap/model.c
--- grass/trunk/imagery/i.smap/model.c 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/imagery/i.smap/model.c 2009-06-22 01:49:13 UTC (rev 38014)
@@ -1,5 +1,5 @@
Modified: grass/trunk/imagery/i.smap/multialloc.c
--- grass/trunk/imagery/i.smap/multialloc.c 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/imagery/i.smap/multialloc.c 2009-06-22 01:49:13 UTC (rev 38014)
@@ -2,7 +2,7 @@
#include <stdio.h>
#include <stdarg.h>
Modified: grass/trunk/imagery/i.smap/opencell.c
--- grass/trunk/imagery/i.smap/opencell.c 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/imagery/i.smap/opencell.c 2009-06-22 01:49:13 UTC (rev 38014)
@@ -1,6 +1,6 @@
#include <stdlib.h>
Modified: grass/trunk/imagery/i.smap/openfiles.c
--- grass/trunk/imagery/i.smap/openfiles.c 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/imagery/i.smap/openfiles.c 2009-06-22 01:49:13 UTC (rev 38014)
@@ -1,6 +1,6 @@
#include <stdlib.h>
Modified: grass/trunk/imagery/i.smap/parse.c
--- grass/trunk/imagery/i.smap/parse.c 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/imagery/i.smap/parse.c 2009-06-22 01:49:13 UTC (rev 38014)
@@ -1,6 +1,6 @@
#include <stdlib.h>
#include "bouman.h"
Modified: grass/trunk/imagery/i.smap/read_block.c
--- grass/trunk/imagery/i.smap/read_block.c 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/imagery/i.smap/read_block.c 2009-06-22 01:49:13 UTC (rev 38014)
@@ -1,6 +1,6 @@
#include <stdlib.h>
Modified: grass/trunk/imagery/i.smap/write_img.c
--- grass/trunk/imagery/i.smap/write_img.c 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/imagery/i.smap/write_img.c 2009-06-22 01:49:13 UTC (rev 38014)
@@ -1,4 +1,4 @@
Modified: grass/trunk/imagery/i.sunhours/Makefile
--- grass/trunk/imagery/i.sunhours/Makefile 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/imagery/i.sunhours/Makefile 2009-06-22 01:49:13 UTC (rev 38014)
@@ -2,8 +2,8 @@
PGM = i.sunhours
Modified: grass/trunk/imagery/i.sunhours/main.c
--- grass/trunk/imagery/i.sunhours/main.c 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/imagery/i.sunhours/main.c 2009-06-22 01:49:13 UTC (rev 38014)
@@ -19,7 +19,7 @@
#include <string.h>
#include <math.h>
#define PI 3.1415927
Modified: grass/trunk/imagery/i.vi/Makefile
--- grass/trunk/imagery/i.vi/Makefile 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/imagery/i.vi/Makefile 2009-06-22 01:49:13 UTC (rev 38014)
@@ -2,8 +2,8 @@
PGM = i.vi
Modified: grass/trunk/imagery/i.vi/main.c
--- grass/trunk/imagery/i.vi/main.c 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/imagery/i.vi/main.c 2009-06-22 01:49:13 UTC (rev 38014)
@@ -29,7 +29,7 @@
#include <stdlib.h>
#include <string.h>
double s_r(double redchan, double nirchan);
Modified: grass/trunk/imagery/i.zc/Makefile
--- grass/trunk/imagery/i.zc/Makefile 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/imagery/i.zc/Makefile 2009-06-22 01:49:13 UTC (rev 38014)
@@ -2,8 +2,8 @@
PGM = i.zc
-LIBES = $(IMAGERYLIB) $(GMATHLIB) $(GISLIB) $(RASTRLIB) $(FFTWLIB)
-DEPENDENCIES= $(IMAGERYDEP) $(GMATHDEP) $(GISDEP) $(RASTRDEP) $(GISDEP) $(RASTRDEP)
+LIBES = $(IMAGERYLIB) $(GMATHLIB) $(GISLIB) $(RASTERLIB) $(FFTWLIB)
Modified: grass/trunk/imagery/i.zc/main.c
--- grass/trunk/imagery/i.zc/main.c 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/imagery/i.zc/main.c 2009-06-22 01:49:13 UTC (rev 38014)
@@ -22,7 +22,7 @@
#include <stdlib.h>
#include <math.h>
Modified: grass/trunk/include/Make/Grass.make
--- grass/trunk/include/Make/Grass.make 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/include/Make/Grass.make 2009-06-22 01:49:13 UTC (rev 38014)
@@ -135,6 +135,7 @@
LINKM_LIBNAME = grass_linkm
LOCK_LIBNAME = grass_lock
MANAGE_LIBNAME = grass_manage
+RASTER_LIBNAME = grass_raster
ROWIO_LIBNAME = grass_rowio
SEGMENT_LIBNAME = grass_segment
STATS_LIBNAME = grass_stats
@@ -142,9 +143,6 @@
XGI_LIBNAME = grass_Xgi
XPM_LIBNAME = grass_Xpm
-# Raster
-RASTR_LIBNAME = grass_rast
# Vector
DIG_LIBNAME = grass_dig
DIG2_LIBNAME = grass_dig2
@@ -234,6 +232,7 @@
LINKMLIB = -l$(LINKM_LIBNAME)
LOCKLIB = -l$(LOCK_LIBNAME)
MANAGELIB = -l$(MANAGE_LIBNAME)
+RASTERLIB = -l$(RASTER_LIBNAME) $(GISLIB)
ROWIOLIB = -l$(ROWIO_LIBNAME)
SEGMENTLIB = -l$(SEGMENT_LIBNAME) $(GISLIB)
STATSLIB = -l$(STATS_LIBNAME) $(GISLIB)
@@ -241,9 +240,6 @@
XGILIB = -l$(XGI_LIBNAME)
XPMLIB = -l$(XPM_LIBNAME)
-# Raster
-RASTRLIB = -l$(RASTR_LIBNAME) $(DATETIMELIB) $(XDRLIB) $(SOCKLIB) $(INTLLIB)
# DBMI
DBMIBASELIB = -l$(DBMIBASE_LIBNAME) $(GISLIB)
DBMICLIENTLIB = -l$(DBMICLIENT_LIBNAME) $(DBMIBASELIB) $(GISLIB)
@@ -332,6 +328,7 @@
IORTHODEP = $(BASE_LIBDIR)/$(LIB_PREFIX)$(IORTHO_LIBNAME)$(LIB_SUFFIX)
LINKMDEP = $(BASE_LIBDIR)/$(LIB_PREFIX)$(LINKM_LIBNAME)$(LIB_SUFFIX)
LOCKDEP = $(BASE_LIBDIR)/$(LIB_PREFIX)$(LOCK_LIBNAME)$(LIB_SUFFIX)
+RASTERDEP = $(BASE_LIBDIR)/$(LIB_PREFIX)$(RASTER_LIBNAME)$(LIB_SUFFIX)
ROWIODEP = $(BASE_LIBDIR)/$(LIB_PREFIX)$(ROWIO_LIBNAME)$(LIB_SUFFIX)
SEGMENTDEP = $(BASE_LIBDIR)/$(LIB_PREFIX)$(SEGMENT_LIBNAME)$(LIB_SUFFIX)
STATSDEP = $(BASE_LIBDIR)/$(LIB_PREFIX)$(STATS_LIBNAME)$(LIB_SUFFIX)
@@ -339,9 +336,6 @@
XGIDEP = $(BASE_LIBDIR)/$(LIB_PREFIX)$(XGI_LIBNAME)$(LIB_SUFFIX)
XPMDEP = $(BASE_LIBDIR)/$(LIB_PREFIX)$(XPM_LIBNAME)$(LIB_SUFFIX)
-# Raster
-RASTRDEP = $(BASE_LIBDIR)/$(LIB_PREFIX)$(RASTR_LIBNAME)$(LIB_SUFFIX)
# DBMI
DBMIBASEDEP = $(BASE_LIBDIR)/$(LIB_PREFIX)$(DBMIBASE_LIBNAME)$(LIB_SUFFIX)
DBMICLIENTDEP = $(BASE_LIBDIR)/$(LIB_PREFIX)$(DBMICLIENT_LIBNAME)$(LIB_SUFFIX)
Deleted: grass/trunk/include/Rast.h
--- grass/trunk/include/Rast.h 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/include/Rast.h 2009-06-22 01:49:13 UTC (rev 38014)
@@ -1,537 +0,0 @@
-#ifndef GRASS_RAST_H
-#define GRASS_RAST_H
-#include <grass/gis.h>
-/* --- ANSI prototypes for the lib/raster functions --- */
-/* alloc_cell.c */
-size_t Rast_raster_size(RASTER_MAP_TYPE);
-CELL *Rast_allocate_cell_buf(void);
-void *Rast_allocate_raster_buf(RASTER_MAP_TYPE);
-CELL *Rast_allocate_c_raster_buf(void);
-FCELL *Rast_allocate_f_raster_buf(void);
-DCELL *Rast_allocate_d_raster_buf(void);
-char *Rast_allocate_null_buf(void);
-unsigned char *Rast__allocate_null_bits(int);
-int Rast__null_bitstream_size(int);
-/* auto_mask.c */
-int Rast__check_for_auto_masking(void);
-void Rast_suppress_masking(void);
-void Rast_unsuppress_masking(void);
-/* cats.c */
-int Rast_read_cats(const char *, const char *, struct Categories *);
-int Rast_read_raster_cats(const char *, const char *, struct Categories *);
-int Rast_read_vector_cats(const char *, const char *, struct Categories *);
-CELL Rast_number_of_cats(const char *, const char *);
-char *Rast_get_cats_title(const struct Categories *);
-char *Rast_get_raster_cats_title(const struct Categories *);
-char *Rast_get_cat(CELL, struct Categories *);
-char *Rast_get_c_raster_cat(CELL *, struct Categories *);
-char *Rast_get_f_raster_cat(FCELL *, struct Categories *);
-char *Rast_get_d_raster_cat(DCELL *, struct Categories *);
-char *Rast_get_raster_cat(void *, struct Categories *, RASTER_MAP_TYPE);
-void Rast_unmark_raster_cats(struct Categories *);
-void Rast_mark_c_raster_cats(const CELL *, int, struct Categories *);
-void Rast_mark_f_raster_cats(const FCELL *, int, struct Categories *);
-void Rast_mark_d_raster_cats(const DCELL *, int, struct Categories *);
-int Rast_mark_raster_cats(const void *, int, struct Categories *, RASTER_MAP_TYPE);
-void Rast_rewind_raster_cats(struct Categories *);
-char *Rast_get_next_marked_d_raster_cat(struct Categories *, DCELL *, DCELL *,
- long *);
-char *Rast_get_next_marked_c_raster_cat(struct Categories *, CELL *, CELL *,
- long *);
-char *Rast_get_next_marked_f_raster_cat(struct Categories *, FCELL *, FCELL *,
- long *);
-char *Rast_get_next_marked_raster_cat(struct Categories *, void *, void *,
- long *, RASTER_MAP_TYPE);
-int Rast_set_cat(CELL, const char *, struct Categories *);
-int Rast_set_c_raster_cat(const CELL *, const CELL *, const char *, struct Categories *);
-int Rast_set_f_raster_cat(const FCELL *, const FCELL *, const char *, struct Categories *);
-int Rast_set_d_raster_cat(const DCELL *, const DCELL *, const char *, struct Categories *);
-int Rast_set_raster_cat(const void *, const void *, const char *, struct Categories *,
- RASTER_MAP_TYPE);
-int Rast_write_cats(const char *, struct Categories *);
-int Rast_write_raster_cats(const char *, struct Categories *);
-int Rast_write_vector_cats(const char *, struct Categories *);
-char *Rast_get_ith_d_raster_cat(const struct Categories *, int, DCELL *,
- DCELL *);
-char *Rast_get_ith_f_raster_cat(const struct Categories *, int, void *, void *);
-char *Rast_get_ith_c_raster_cat(const struct Categories *, int, void *, void *);
-char *Rast_get_ith_raster_cat(const struct Categories *, int, void *, void *,
- RASTER_MAP_TYPE);
-void Rast_init_cats(CELL, const char *, struct Categories *);
-void Rast_init_raster_cats(const char *, struct Categories *);
-void Rast_set_cats_title(const char *, struct Categories *);
-void Rast_set_raster_cats_title(const char *, struct Categories *);
-void Rast_set_cats_fmt(const char *, double, double, double, double,
- struct Categories *);
-void Rast_set_raster_cats_fmt(const char *, double, double, double, double,
-void Rast_free_cats(struct Categories *);
-void Rast_free_raster_cats(struct Categories *);
-void Rast_copy_raster_cats(struct Categories *, const struct Categories *);
-int Rast_number_of_raster_cats(struct Categories *);
-int Rast_sort_cats(struct Categories *);
-/* cell_stats.c */
-void Rast_init_cell_stats(struct Cell_stats *);
-int Rast_update_cell_stats(const CELL *, int, struct Cell_stats *);
-int Rast_find_cell_stat(CELL, long *, const struct Cell_stats *);
-int Rast_rewind_cell_stats(struct Cell_stats *);
-int Rast_next_cell_stat(CELL *, long *, struct Cell_stats *);
-void Rast_get_stats_for_null_value(long *, const struct Cell_stats *);
-void Rast_free_cell_stats(struct Cell_stats *);
-/* cell_title.c */
-char *Rast_get_cell_title(const char *, const char *);
-/* cellstats_eq.c */
-int Rast_cell_stats_histo_eq(struct Cell_stats *, CELL, CELL, CELL, CELL, int,
- void (*)(CELL, CELL, CELL));
-/* closecell.c */
-int Rast_close_cell(int);
-int Rast_unopen_cell(int);
-/* color_compat.c */
-void Rast_make_ryg_colors(struct Colors *, CELL, CELL);
-void Rast_make_ryg_fp_colors(struct Colors *, DCELL, DCELL);
-void Rast_make_aspect_colors(struct Colors *, CELL, CELL);
-void Rast_make_aspect_fp_colors(struct Colors *, DCELL, DCELL);
-void Rast_make_byr_colors(struct Colors *, CELL, CELL);
-void Rast_make_byr_fp_colors(struct Colors *, DCELL, DCELL);
-void Rast_make_bgyr_colors(struct Colors *, CELL, CELL);
-void Rast_make_bgyr_fp_colors(struct Colors *, DCELL, DCELL);
-void Rast_make_byg_colors(struct Colors *, CELL, CELL);
-void Rast_make_byg_fp_colors(struct Colors *, DCELL, DCELL);
-void Rast_make_grey_scale_colors(struct Colors *, CELL, CELL);
-void Rast_make_grey_scale_fp_colors(struct Colors *, DCELL, DCELL);
-void Rast_make_gyr_colors(struct Colors *, CELL, CELL);
-void Rast_make_gyr_fp_colors(struct Colors *, DCELL, DCELL);
-void Rast_make_rainbow_colors(struct Colors *, CELL, CELL);
-void Rast_make_rainbow_fp_colors(struct Colors *, DCELL, DCELL);
-void Rast_make_ramp_colors(struct Colors *, CELL, CELL);
-void Rast_make_ramp_fp_colors(struct Colors *, DCELL, DCELL);
-void Rast_make_wave_colors(struct Colors *, CELL, CELL);
-void Rast_make_wave_fp_colors(struct Colors *, DCELL, DCELL);
-/* color_free.c */
-void Rast_free_colors(struct Colors *);
-void Rast__color_free_rules(struct _Color_Info_ *);
-void Rast__color_free_lookup(struct _Color_Info_ *);
-void Rast__color_free_fp_lookup(struct _Color_Info_ *);
-void Rast__color_reset(struct Colors *);
-/* color_get.c */
-int Rast_get_color(CELL, int *, int *, int *, struct Colors *);
-int Rast_get_raster_color(const void *, int *, int *, int *, struct Colors *,
- RASTER_MAP_TYPE);
-int Rast_get_c_raster_color(const CELL *, int *, int *, int *, struct Colors *);
-int Rast_get_f_raster_color(const FCELL *, int *, int *, int *, struct Colors *);
-int Rast_get_d_raster_color(const DCELL *, int *, int *, int *, struct Colors *);
-void Rast_get_null_value_color(int *, int *, int *, const struct Colors *);
-void Rast_get_default_color(int *, int *, int *, const struct Colors *);
-/* color_hist.c */
-void Rast_make_histogram_eq_colors(struct Colors *, struct Cell_stats *);
-void Rast_make_histogram_log_colors(struct Colors *, struct Cell_stats *, int, int);
-/* color_init.c */
-void Rast_init_colors(struct Colors *);
-/* color_insrt.c */
-int Rast__insert_color_into_lookup(CELL, int, int, int, struct _Color_Info_ *);
-/* color_invrt.c */
-int Rast_invert_colors(struct Colors *);
-/* color_look.c */
-void Rast_lookup_colors(const CELL *, unsigned char *, unsigned char *,
- unsigned char *, unsigned char *, int, struct Colors *);
-void Rast_lookup_c_raster_colors(const CELL *, unsigned char *, unsigned char *,
- struct Colors *);
-void Rast_lookup_raster_colors(const void *, unsigned char *, unsigned char *,
- struct Colors *, RASTER_MAP_TYPE);
-void Rast_lookup_f_raster_colors(const FCELL *, unsigned char *, unsigned char *,
- struct Colors *);
-void Rast_lookup_d_raster_colors(const DCELL *, unsigned char *, unsigned char *,
- struct Colors *);
-void Rast__lookup_colors(const void *, unsigned char *, unsigned char *,
- unsigned char *, unsigned char *, int, struct Colors *,
- int, int, RASTER_MAP_TYPE);
-void Rast__interpolate_color_rule(DCELL, unsigned char *, unsigned char *,
- unsigned char *, const struct _Color_Rule_ *);
-/* color_org.c */
-void Rast__organize_colors(struct Colors *);
-/* color_rand.c */
-void Rast_make_random_colors(struct Colors *, CELL, CELL);
-/* color_range.c */
-void Rast_set_color_range(CELL, CELL, struct Colors *);
-void Rast_set_d_color_range(DCELL, DCELL, struct Colors *);
-void Rast_get_color_range(CELL *, CELL *, const struct Colors *);
-void Rast_get_d_color_range(DCELL *, DCELL *, const struct Colors *);
-/* color_read.c */
-int Rast_read_colors(const char *, const char *, struct Colors *);
-void Rast_mark_colors_as_fp(struct Colors *);
-/* color_remove.c */
-int Rast_remove_colors(const char *, const char *);
-/* color_rule.c */
-void Rast_add_d_raster_color_rule(const DCELL *, int, int, int,
- const DCELL *, int, int, int,
- struct Colors *);
-void Rast_add_f_raster_color_rule(const FCELL *, int, int, int,
- const FCELL *, int, int, int,
- struct Colors *);
-void Rast_add_c_raster_color_rule(const CELL *, int, int, int,
- const CELL *, int, int, int,
- struct Colors *);
-void Rast_add_raster_color_rule(const void *, int, int, int,
- const void *, int, int, int,
-void Rast_add_color_rule(const CELL, int, int, int,
- const CELL, int, int, int,
- struct Colors *);
-int Rast_add_modular_d_raster_color_rule(const DCELL *, int, int, int,
- struct Colors *);
-int Rast_add_modular_f_raster_color_rule(const FCELL *, int, int, int,
- struct Colors *);
-int Rast_add_modular_c_raster_color_rule(const CELL *, int, int, int,
- struct Colors *);
-int Rast_add_modular_raster_color_rule(const void *, int, int, int,
-int Rast_add_modular_color_rule(CELL, int, int, int,
- CELL, int, int, int,
- struct Colors *);
-/* color_rule_get.c */
-int Rast_colors_count(const struct Colors *);
-int Rast_get_f_color_rule(DCELL *, unsigned char *, unsigned char *,
- unsigned char *, DCELL *, unsigned char *,
- const struct Colors *, int);
-/* color_rules.c */
-typedef int read_rule_fn(void *, DCELL, DCELL,
- DCELL *, int *, int *, int *, int *, int *, int *);
-int Rast_parse_color_rule(DCELL, DCELL, const char *, DCELL *, int *, int *,
- int *, int *, int *, int *);
-const char *Rast_parse_color_rule_error(int);
-int Rast_read_color_rule(void *, DCELL, DCELL, DCELL *, int *, int *, int *,
- int *, int *, int *);
-int Rast_read_color_rules(struct Colors *, DCELL, DCELL, read_rule_fn *, void *);
-int Rast_load_colors(struct Colors *, const char *, CELL, CELL);
-int Rast_load_fp_colors(struct Colors *, const char *, DCELL, DCELL);
-void Rast_make_colors(struct Colors *, const char *, CELL, CELL);
-void Rast_make_fp_colors(struct Colors *, const char *, DCELL, DCELL);
-/* color_set.c */
-void Rast_set_color(CELL, int, int, int, struct Colors *);
-void Rast_set_d_color(DCELL, int, int, int, struct Colors *);
-void Rast_set_null_value_color(int, int, int, struct Colors *);
-void Rast_set_default_color(int, int, int, struct Colors *);
-/* color_shift.c */
-void Rast_shift_colors(int, struct Colors *);
-void Rast_shift_d_colors(DCELL, struct Colors *);
-/* color_str.c */
-int Rast_str_to_color(const char *, int *, int *, int *);
-/* color_write.c */
-int Rast_write_colors(const char *, const char *, struct Colors *);
-void Rast__write_colors(FILE *, struct Colors *);
-/* color_xform.c */
-void Rast_histogram_eq_colors(struct Colors *, struct Colors *,
- struct Cell_stats *);
-void Rast_histogram_eq_colors_fp(struct Colors *,
- struct Colors *, struct FP_stats *);
-void Rast_log_colors(struct Colors *, struct Colors *, int);
-void Rast_abs_log_colors(struct Colors *, struct Colors *, int);
-/* format.c */
-int Rast__check_format(int);
-int Rast__read_row_ptrs(int);
-int Rast__write_row_ptrs(int);
-/* fpreclass.c */
-void Rast_fpreclass_clear(struct FPReclass *);
-void Rast_fpreclass_reset(struct FPReclass *);
-void Rast_fpreclass_init(struct FPReclass *);
-void Rast_fpreclass_set_domain(struct FPReclass *, DCELL, DCELL);
-void Rast_fpreclass_set_range(struct FPReclass *, DCELL, DCELL);
-int Rast_fpreclass_get_limits(const struct FPReclass *, DCELL *, DCELL *,
- DCELL *, DCELL *);
-int Rast_fpreclass_nof_rules(const struct FPReclass *);
-void Rast_fpreclass_get_ith_rule(const struct FPReclass *, int, DCELL *, DCELL *,
-void Rast_fpreclass_set_neg_infinite_rule(struct FPReclass *, DCELL, DCELL);
-int Rast_fpreclass_get_neg_infinite_rule(const struct FPReclass *, DCELL *,
- DCELL *);
-void Rast_fpreclass_set_pos_infinite_rule(struct FPReclass *, DCELL, DCELL);
-int Rast_fpreclass_get_pos_infinite_rule(const struct FPReclass *, DCELL *,
- DCELL *);
-void Rast_fpreclass_add_rule(struct FPReclass *, DCELL, DCELL, DCELL, DCELL);
-void Rast_fpreclass_reverse_rule_order(struct FPReclass *);
-DCELL Rast_fpreclass_get_cell_value(const struct FPReclass *, DCELL);
-void Rast_fpreclass_perform_di(const struct FPReclass *, const DCELL *, CELL *,
- int);
-void Rast_fpreclass_perform_df(const struct FPReclass *, const DCELL *, FCELL *,
- int);
-void Rast_fpreclass_perform_dd(const struct FPReclass *, const DCELL *, DCELL *,
- int);
-void Rast_fpreclass_perform_fi(const struct FPReclass *, const FCELL *, CELL *,
- int);
-void Rast_fpreclass_perform_ff(const struct FPReclass *, const FCELL *, FCELL *,
- int);
-void Rast_fpreclass_perform_fd(const struct FPReclass *, const FCELL *, DCELL *,
- int);
-void Rast_fpreclass_perform_ii(const struct FPReclass *, const CELL *, CELL *,
- int);
-void Rast_fpreclass_perform_if(const struct FPReclass *, const CELL *, FCELL *,
- int);
-void Rast_fpreclass_perform_id(const struct FPReclass *, const CELL *, DCELL *,
- int);
-/* gdal.c */
-void Rast_init_gdal(void);
-struct GDAL_link *Rast_get_gdal_link(const char *, const char *);
-struct GDAL_link *Rast_create_gdal_link(const char *, RASTER_MAP_TYPE);
-void Rast_close_gdal_link(struct GDAL_link *);
-int Rast_close_gdal_write_link(struct GDAL_link *);
-/* get_cellhd.c */
-int Rast_get_cellhd(const char *, const char *, struct Cell_head *);
-/* get_row.c */
-int Rast_get_map_row_nomask(int, CELL *, int);
-int Rast_get_raster_row_nomask(int, void *, int, RASTER_MAP_TYPE);
-int Rast_get_c_raster_row_nomask(int, CELL *, int);
-int Rast_get_f_raster_row_nomask(int, FCELL *, int);
-int Rast_get_d_raster_row_nomask(int, DCELL *, int);
-int Rast_get_map_row(int, CELL *, int);
-int Rast_get_raster_row(int, void *, int, RASTER_MAP_TYPE);
-int Rast_get_c_raster_row(int, CELL *, int);
-int Rast_get_f_raster_row(int, FCELL *, int);
-int Rast_get_d_raster_row(int, DCELL *, int);
-int Rast_get_null_value_row(int, char *, int);
-/* get_row_colr.c */
-int Rast_get_raster_row_colors(int, int, struct Colors *,
- unsigned char *, unsigned char *, unsigned char *,
- unsigned char *);
-/* histo_eq.c */
-void Rast_histogram_eq(const struct Histogram *, unsigned char **,
- CELL *, CELL *);
-/* histogram.c */
-void Rast_init_histogram(struct Histogram *);
-int Rast_read_histogram(const char *, const char *, struct Histogram *);
-int Rast_write_histogram(const char *, const struct Histogram *);
-int Rast_write_histogram_cs(const char *, struct Cell_stats *);
-void Rast_make_histogram_cs(struct Cell_stats *, struct Histogram *);
-int Rast_get_histogram_num(const struct Histogram *);
-CELL Rast_get_histogram_cat(int, const struct Histogram *);
-long Rast_get_histogram_count(int, const struct Histogram *);
-void Rast_free_histogram(struct Histogram *);
-int Rast_sort_histogram(struct Histogram *);
-int Rast_sort_histogram_by_count(struct Histogram *);
-void Rast_remove_histogram(const char *);
-int Rast_add_histogram(CELL, long, struct Histogram *);
-int Rast_set_histogram(CELL, long, struct Histogram *);
-void Rast_extend_histogram(CELL, long, struct Histogram *);
-void Rast_zero_histogram(struct Histogram *);
-/* history.c */
-int Rast_read_history(const char *, const char *, struct History *);
-int Rast_write_history(const char *, struct History *);
-void Rast_short_history(const char *, const char *, struct History *);
-int Rast_command_history(struct History *);
-/* init.c */
-void Rast__init(void);
-void Rast__check_init(void);
-void Rast_init_all(void);
-/* interp.c */
-DCELL Rast_interp_linear(double, DCELL, DCELL);
-DCELL Rast_interp_bilinear(double, double, DCELL, DCELL, DCELL, DCELL);
-DCELL Rast_interp_cubic(double, DCELL, DCELL, DCELL, DCELL);
-DCELL Rast_interp_bicubic(double, double,
- DCELL, DCELL, DCELL, DCELL, DCELL, DCELL, DCELL, DCELL,
- DCELL);
-/* mask_info.c */
-char *Rast_mask_info(void);
-int Rast__mask_info(char *, char *);
-/* maskfd.c */
-int Rast_maskfd(void);
-/* null_val.c */
-void Rast__set_null_value(void *, int, int, RASTER_MAP_TYPE);
-void Rast_set_null_value(void *, int, RASTER_MAP_TYPE);
-void Rast_set_c_null_value(CELL *, int);
-void Rast_set_f_null_value(FCELL *, int);
-void Rast_set_d_null_value(DCELL *, int);
-int Rast_is_null_value(const void *, RASTER_MAP_TYPE);
-int Rast_is_c_null_value(const CELL *);
-int Rast_is_f_null_value(const FCELL *);
-int Rast_is_d_null_value(const DCELL *);
-void Rast_insert_null_values(void *, char *, int, RASTER_MAP_TYPE);
-void Rast_insert_c_null_values(CELL *, char *, int);
-void Rast_insert_f_null_values(FCELL *, char *, int);
-void Rast_insert_d_null_values(DCELL *, char *, int);
-int Rast__check_null_bit(const unsigned char *, int, int);
-void Rast__convert_01_flags(const char *, unsigned char *, int);
-void Rast__convert_flags_01(char *, const unsigned char *, int);
-void Rast__init_null_bits(unsigned char *, int);
-/* opencell.c */
-int Rast_open_cell_old(const char *, const char *);
-int Rast__open_cell_old(const char *, const char *);
-int Rast_open_cell_new(const char *);
-int Rast_open_cell_new_uncompressed(const char *);
-void Rast_want_histogram(int);
-void Rast_set_cell_format(int);
-int Rast_cellvalue_format(CELL);
-int Rast_open_fp_cell_new(const char *);
-int Rast_open_fp_cell_new_uncompressed(const char *);
-int Rast_set_fp_type(RASTER_MAP_TYPE);
-int Rast_raster_map_is_fp(const char *, const char *);
-RASTER_MAP_TYPE Rast_raster_map_type(const char *, const char *);
-RASTER_MAP_TYPE Rast__check_fp_type(const char *, const char *);
-RASTER_MAP_TYPE Rast_get_raster_map_type(int);
-int Rast_open_raster_new(const char *, RASTER_MAP_TYPE);
-int Rast_open_raster_new_uncompressed(const char *, RASTER_MAP_TYPE);
-int Rast_set_quant_rules(int, struct Quant *);
-/* put_cellhd.c */
-int Rast_put_cellhd(const char *, struct Cell_head *);
-/* put_row.c */
-int Rast_put_map_row(int, const CELL *);
-int Rast_put_raster_row(int, const void *, RASTER_MAP_TYPE);
-int Rast_put_c_raster_row(int, const CELL *);
-int Rast_put_f_raster_row(int, const FCELL *);
-int Rast_put_d_raster_row(int, const DCELL *);
-int Rast__open_null_write(int);
-int Rast__write_null_bits(int, const unsigned char *, int, int, int);
-/* put_title.c */
-int Rast_put_cell_title(const char *, const char *);
-/* quant.c */
-void Rast_quant_clear(struct Quant *);
-void Rast_quant_free(struct Quant *);
-int Rast__quant_organize_fp_lookup(struct Quant *);
-void Rast_quant_init(struct Quant *);
-int Rast_quant_is_truncate(const struct Quant *);
-int Rast_quant_is_round(const struct Quant *);
-void Rast_quant_truncate(struct Quant *);
-void Rast_quant_round(struct Quant *);
-int Rast_quant_get_limits(const struct Quant *, DCELL *, DCELL *, CELL *,
- CELL *);
-int Rast_quant_nof_rules(const struct Quant *);
-void Rast_quant_get_ith_rule(const struct Quant *, int, DCELL *, DCELL *, CELL *,
- CELL *);
-void Rast_quant_set_neg_infinite_rule(struct Quant *, DCELL, CELL);
-int Rast_quant_get_neg_infinite_rule(const struct Quant *, DCELL *, CELL *);
-void Rast_quant_set_pos_infinite_rule(struct Quant *, DCELL, CELL);
-int Rast_quant_get_pos_infinite_rule(const struct Quant *, DCELL *, CELL *);
-void Rast_quant_add_rule(struct Quant *, DCELL, DCELL, CELL, CELL);
-void Rast_quant_reverse_rule_order(struct Quant *);
-CELL Rast_quant_get_cell_value(struct Quant *, DCELL);
-void Rast_quant_perform_d(struct Quant *, const DCELL *, CELL *, int);
-void Rast_quant_perform_f(struct Quant *, const FCELL *, CELL *, int);
-struct Quant_table *Rast__quant_get_rule_for_d_raster_val(const struct Quant *,
- DCELL);
-/* quant_io.c */
-int Rast__quant_import(const char *, const char *, struct Quant *);
-int Rast__quant_export(const char *, const char *, const struct Quant *);
-/* quant_rw.c */
-int Rast_truncate_fp_map(const char *, const char *);
-int Rast_round_fp_map(const char *, const char *);
-int Rast_quantize_fp_map(const char *, const char *, CELL, CELL);
-int Rast_quantize_fp_map_range(const char *, const char *, DCELL, DCELL, CELL,
- CELL);
-int Rast_write_quant(const char *, const char *, const struct Quant *);
-int Rast_read_quant(const char *, const char *, struct Quant *);
-/* range.c */
-void Rast__remove_fp_range(const char *);
-void Rast_construct_default_range(struct Range *);
-int Rast_read_fp_range(const char *, const char *, struct FPRange *);
-int Rast_read_range(const char *, const char *, struct Range *);
-int Rast_write_range(const char *, const struct Range *);
-int Rast_write_fp_range(const char *, const struct FPRange *);
-void Rast_update_range(CELL, struct Range *);
-void Rast_update_fp_range(DCELL, struct FPRange *);
-void Rast_row_update_range(const CELL *, int, struct Range *);
-void Rast__row_update_range(const CELL *, int, struct Range *, int);
-void Rast_row_update_fp_range(const void *, int, struct FPRange *,
- RASTER_MAP_TYPE);
-void Rast_init_range(struct Range *);
-void Rast_get_range_min_max(const struct Range *, CELL *, CELL *);
-void Rast_init_fp_range(struct FPRange *);
-void Rast_get_fp_range_min_max(const struct FPRange *, DCELL *, DCELL *);
-/* raster.c */
-void *Rast_incr_void_ptr(const void *, const size_t);
-int Rast_raster_cmp(const void *, const void *, RASTER_MAP_TYPE);
-void Rast_raster_cpy(void *, const void *, int, RASTER_MAP_TYPE);
-void Rast_set_raster_value_c(void *, CELL, RASTER_MAP_TYPE);
-void Rast_set_raster_value_f(void *, FCELL, RASTER_MAP_TYPE);
-void Rast_set_raster_value_d(void *, DCELL, RASTER_MAP_TYPE);
-CELL Rast_get_raster_value_c(const void *, RASTER_MAP_TYPE);
-FCELL Rast_get_raster_value_f(const void *, RASTER_MAP_TYPE);
-DCELL Rast_get_raster_value_d(const void *, RASTER_MAP_TYPE);
-/* raster_metadata.c */
-int Rast_read_raster_units(const char *, const char *, char *);
-int Rast_read_raster_vdatum(const char *, const char *, char *);
-int Rast_write_raster_units(const char *, const char *);
-int Rast_write_raster_vdatum(const char *, const char *);
-int Rast__raster_misc_read_line(const char *, const char *, const char *,
- char *);
-int Rast__raster_misc_write_line(const char *, const char *, const char *);
-/* reclass.c */
-int Rast_is_reclass(const char *, const char *, char *, char *);
-int Rast_is_reclassed_to(const char *, const char *, int *, char ***);
-int Rast_get_reclass(const char *, const char *, struct Reclass *);
-void Rast_free_reclass(struct Reclass *);
-int Rast_put_reclass(const char *, const struct Reclass *);
-/* sample.c */
-DCELL Rast_get_raster_sample_nearest(int, const struct Cell_head *, struct Categories *, double, double, int);
-DCELL Rast_get_raster_sample_bilinear(int, const struct Cell_head *, struct Categories *, double, double, int);
-DCELL Rast_get_raster_sample_cubic(int, const struct Cell_head *, struct Categories *, double, double, int);
-DCELL Rast_get_raster_sample(int, const struct Cell_head *, struct Categories *, double, double, int, INTERP_TYPE);
-/* set_window.c */
-int Rast_set_window(struct Cell_head *);
-/* zero_cell.c */
-void Rast_zero_cell_buf(CELL *);
-void Rast_zero_raster_buf(void *, RASTER_MAP_TYPE);
-#endif
Copied: grass/trunk/include/raster.h (from rev 38013, grass/trunk/include/Rast.h)
--- grass/trunk/include/raster.h (rev 0)
+++ grass/trunk/include/raster.h 2009-06-22 01:49:13 UTC (rev 38014)
@@ -0,0 +1,537 @@
+#ifndef GRASS_RAST_H
+#define GRASS_RAST_H
+#include <grass/gis.h>
+/* --- ANSI prototypes for the lib/raster functions --- */
+/* alloc_cell.c */
+size_t Rast_raster_size(RASTER_MAP_TYPE);
+CELL *Rast_allocate_cell_buf(void);
+void *Rast_allocate_raster_buf(RASTER_MAP_TYPE);
+CELL *Rast_allocate_c_raster_buf(void);
+FCELL *Rast_allocate_f_raster_buf(void);
+DCELL *Rast_allocate_d_raster_buf(void);
+char *Rast_allocate_null_buf(void);
+unsigned char *Rast__allocate_null_bits(int);
+int Rast__null_bitstream_size(int);
+/* auto_mask.c */
+int Rast__check_for_auto_masking(void);
+void Rast_suppress_masking(void);
+void Rast_unsuppress_masking(void);
+/* cats.c */
+int Rast_read_cats(const char *, const char *, struct Categories *);
+int Rast_read_raster_cats(const char *, const char *, struct Categories *);
+int Rast_read_vector_cats(const char *, const char *, struct Categories *);
+CELL Rast_number_of_cats(const char *, const char *);
+char *Rast_get_cats_title(const struct Categories *);
+char *Rast_get_raster_cats_title(const struct Categories *);
+char *Rast_get_cat(CELL, struct Categories *);
+char *Rast_get_c_raster_cat(CELL *, struct Categories *);
+char *Rast_get_f_raster_cat(FCELL *, struct Categories *);
+char *Rast_get_d_raster_cat(DCELL *, struct Categories *);
+char *Rast_get_raster_cat(void *, struct Categories *, RASTER_MAP_TYPE);
+void Rast_unmark_raster_cats(struct Categories *);
+void Rast_mark_c_raster_cats(const CELL *, int, struct Categories *);
+void Rast_mark_f_raster_cats(const FCELL *, int, struct Categories *);
+void Rast_mark_d_raster_cats(const DCELL *, int, struct Categories *);
+int Rast_mark_raster_cats(const void *, int, struct Categories *, RASTER_MAP_TYPE);
+void Rast_rewind_raster_cats(struct Categories *);
+char *Rast_get_next_marked_d_raster_cat(struct Categories *, DCELL *, DCELL *,
+ long *);
+char *Rast_get_next_marked_c_raster_cat(struct Categories *, CELL *, CELL *,
+ long *);
+char *Rast_get_next_marked_f_raster_cat(struct Categories *, FCELL *, FCELL *,
+ long *);
+char *Rast_get_next_marked_raster_cat(struct Categories *, void *, void *,
+ long *, RASTER_MAP_TYPE);
+int Rast_set_cat(CELL, const char *, struct Categories *);
+int Rast_set_c_raster_cat(const CELL *, const CELL *, const char *, struct Categories *);
+int Rast_set_f_raster_cat(const FCELL *, const FCELL *, const char *, struct Categories *);
+int Rast_set_d_raster_cat(const DCELL *, const DCELL *, const char *, struct Categories *);
+int Rast_set_raster_cat(const void *, const void *, const char *, struct Categories *,
+ RASTER_MAP_TYPE);
+int Rast_write_cats(const char *, struct Categories *);
+int Rast_write_raster_cats(const char *, struct Categories *);
+int Rast_write_vector_cats(const char *, struct Categories *);
+char *Rast_get_ith_d_raster_cat(const struct Categories *, int, DCELL *,
+ DCELL *);
+char *Rast_get_ith_f_raster_cat(const struct Categories *, int, void *, void *);
+char *Rast_get_ith_c_raster_cat(const struct Categories *, int, void *, void *);
+char *Rast_get_ith_raster_cat(const struct Categories *, int, void *, void *,
+ RASTER_MAP_TYPE);
+void Rast_init_cats(CELL, const char *, struct Categories *);
+void Rast_init_raster_cats(const char *, struct Categories *);
+void Rast_set_cats_title(const char *, struct Categories *);
+void Rast_set_raster_cats_title(const char *, struct Categories *);
+void Rast_set_cats_fmt(const char *, double, double, double, double,
+ struct Categories *);
+void Rast_set_raster_cats_fmt(const char *, double, double, double, double,
+void Rast_free_cats(struct Categories *);
+void Rast_free_raster_cats(struct Categories *);
+void Rast_copy_raster_cats(struct Categories *, const struct Categories *);
+int Rast_number_of_raster_cats(struct Categories *);
+int Rast_sort_cats(struct Categories *);
+/* cell_stats.c */
+void Rast_init_cell_stats(struct Cell_stats *);
+int Rast_update_cell_stats(const CELL *, int, struct Cell_stats *);
+int Rast_find_cell_stat(CELL, long *, const struct Cell_stats *);
+int Rast_rewind_cell_stats(struct Cell_stats *);
+int Rast_next_cell_stat(CELL *, long *, struct Cell_stats *);
+void Rast_get_stats_for_null_value(long *, const struct Cell_stats *);
+void Rast_free_cell_stats(struct Cell_stats *);
+/* cell_title.c */
+char *Rast_get_cell_title(const char *, const char *);
+/* cellstats_eq.c */
+int Rast_cell_stats_histo_eq(struct Cell_stats *, CELL, CELL, CELL, CELL, int,
+ void (*)(CELL, CELL, CELL));
+/* closecell.c */
+int Rast_close_cell(int);
+int Rast_unopen_cell(int);
+/* color_compat.c */
+void Rast_make_ryg_colors(struct Colors *, CELL, CELL);
+void Rast_make_ryg_fp_colors(struct Colors *, DCELL, DCELL);
+void Rast_make_aspect_colors(struct Colors *, CELL, CELL);
+void Rast_make_aspect_fp_colors(struct Colors *, DCELL, DCELL);
+void Rast_make_byr_colors(struct Colors *, CELL, CELL);
+void Rast_make_byr_fp_colors(struct Colors *, DCELL, DCELL);
+void Rast_make_bgyr_colors(struct Colors *, CELL, CELL);
+void Rast_make_bgyr_fp_colors(struct Colors *, DCELL, DCELL);
+void Rast_make_byg_colors(struct Colors *, CELL, CELL);
+void Rast_make_byg_fp_colors(struct Colors *, DCELL, DCELL);
+void Rast_make_grey_scale_colors(struct Colors *, CELL, CELL);
+void Rast_make_grey_scale_fp_colors(struct Colors *, DCELL, DCELL);
+void Rast_make_gyr_colors(struct Colors *, CELL, CELL);
+void Rast_make_gyr_fp_colors(struct Colors *, DCELL, DCELL);
+void Rast_make_rainbow_colors(struct Colors *, CELL, CELL);
+void Rast_make_rainbow_fp_colors(struct Colors *, DCELL, DCELL);
+void Rast_make_ramp_colors(struct Colors *, CELL, CELL);
+void Rast_make_ramp_fp_colors(struct Colors *, DCELL, DCELL);
+void Rast_make_wave_colors(struct Colors *, CELL, CELL);
+void Rast_make_wave_fp_colors(struct Colors *, DCELL, DCELL);
+/* color_free.c */
+void Rast_free_colors(struct Colors *);
+void Rast__color_free_rules(struct _Color_Info_ *);
+void Rast__color_free_lookup(struct _Color_Info_ *);
+void Rast__color_free_fp_lookup(struct _Color_Info_ *);
+void Rast__color_reset(struct Colors *);
+/* color_get.c */
+int Rast_get_color(CELL, int *, int *, int *, struct Colors *);
+int Rast_get_raster_color(const void *, int *, int *, int *, struct Colors *,
+ RASTER_MAP_TYPE);
+int Rast_get_c_raster_color(const CELL *, int *, int *, int *, struct Colors *);
+int Rast_get_f_raster_color(const FCELL *, int *, int *, int *, struct Colors *);
+int Rast_get_d_raster_color(const DCELL *, int *, int *, int *, struct Colors *);
+void Rast_get_null_value_color(int *, int *, int *, const struct Colors *);
+void Rast_get_default_color(int *, int *, int *, const struct Colors *);
+/* color_hist.c */
+void Rast_make_histogram_eq_colors(struct Colors *, struct Cell_stats *);
+void Rast_make_histogram_log_colors(struct Colors *, struct Cell_stats *, int, int);
+/* color_init.c */
+void Rast_init_colors(struct Colors *);
+/* color_insrt.c */
+int Rast__insert_color_into_lookup(CELL, int, int, int, struct _Color_Info_ *);
+/* color_invrt.c */
+int Rast_invert_colors(struct Colors *);
+/* color_look.c */
+void Rast_lookup_colors(const CELL *, unsigned char *, unsigned char *,
+ unsigned char *, unsigned char *, int, struct Colors *);
+void Rast_lookup_c_raster_colors(const CELL *, unsigned char *, unsigned char *,
+ struct Colors *);
+void Rast_lookup_raster_colors(const void *, unsigned char *, unsigned char *,
+ struct Colors *, RASTER_MAP_TYPE);
+void Rast_lookup_f_raster_colors(const FCELL *, unsigned char *, unsigned char *,
+ struct Colors *);
+void Rast_lookup_d_raster_colors(const DCELL *, unsigned char *, unsigned char *,
+ struct Colors *);
+void Rast__lookup_colors(const void *, unsigned char *, unsigned char *,
+ unsigned char *, unsigned char *, int, struct Colors *,
+ int, int, RASTER_MAP_TYPE);
+void Rast__interpolate_color_rule(DCELL, unsigned char *, unsigned char *,
+ unsigned char *, const struct _Color_Rule_ *);
+/* color_org.c */
+void Rast__organize_colors(struct Colors *);
+/* color_rand.c */
+void Rast_make_random_colors(struct Colors *, CELL, CELL);
+/* color_range.c */
+void Rast_set_color_range(CELL, CELL, struct Colors *);
+void Rast_set_d_color_range(DCELL, DCELL, struct Colors *);
+void Rast_get_color_range(CELL *, CELL *, const struct Colors *);
+void Rast_get_d_color_range(DCELL *, DCELL *, const struct Colors *);
+/* color_read.c */
+int Rast_read_colors(const char *, const char *, struct Colors *);
+void Rast_mark_colors_as_fp(struct Colors *);
+/* color_remove.c */
+int Rast_remove_colors(const char *, const char *);
+/* color_rule.c */
+void Rast_add_d_raster_color_rule(const DCELL *, int, int, int,
+ const DCELL *, int, int, int,
+ struct Colors *);
+void Rast_add_f_raster_color_rule(const FCELL *, int, int, int,
+ const FCELL *, int, int, int,
+ struct Colors *);
+void Rast_add_c_raster_color_rule(const CELL *, int, int, int,
+ const CELL *, int, int, int,
+ struct Colors *);
+void Rast_add_raster_color_rule(const void *, int, int, int,
+ const void *, int, int, int,
+void Rast_add_color_rule(const CELL, int, int, int,
+ const CELL, int, int, int,
+ struct Colors *);
+int Rast_add_modular_d_raster_color_rule(const DCELL *, int, int, int,
+ struct Colors *);
+int Rast_add_modular_f_raster_color_rule(const FCELL *, int, int, int,
+ struct Colors *);
+int Rast_add_modular_c_raster_color_rule(const CELL *, int, int, int,
+ struct Colors *);
+int Rast_add_modular_raster_color_rule(const void *, int, int, int,
+int Rast_add_modular_color_rule(CELL, int, int, int,
+ CELL, int, int, int,
+ struct Colors *);
+/* color_rule_get.c */
+int Rast_colors_count(const struct Colors *);
+int Rast_get_f_color_rule(DCELL *, unsigned char *, unsigned char *,
+ unsigned char *, DCELL *, unsigned char *,
+ const struct Colors *, int);
+/* color_rules.c */
+typedef int read_rule_fn(void *, DCELL, DCELL,
+ DCELL *, int *, int *, int *, int *, int *, int *);
+int Rast_parse_color_rule(DCELL, DCELL, const char *, DCELL *, int *, int *,
+ int *, int *, int *, int *);
+const char *Rast_parse_color_rule_error(int);
+int Rast_read_color_rule(void *, DCELL, DCELL, DCELL *, int *, int *, int *,
+ int *, int *, int *);
+int Rast_read_color_rules(struct Colors *, DCELL, DCELL, read_rule_fn *, void *);
+int Rast_load_colors(struct Colors *, const char *, CELL, CELL);
+int Rast_load_fp_colors(struct Colors *, const char *, DCELL, DCELL);
+void Rast_make_colors(struct Colors *, const char *, CELL, CELL);
+void Rast_make_fp_colors(struct Colors *, const char *, DCELL, DCELL);
+/* color_set.c */
+void Rast_set_color(CELL, int, int, int, struct Colors *);
+void Rast_set_d_color(DCELL, int, int, int, struct Colors *);
+void Rast_set_null_value_color(int, int, int, struct Colors *);
+void Rast_set_default_color(int, int, int, struct Colors *);
+/* color_shift.c */
+void Rast_shift_colors(int, struct Colors *);
+void Rast_shift_d_colors(DCELL, struct Colors *);
+/* color_str.c */
+int Rast_str_to_color(const char *, int *, int *, int *);
+/* color_write.c */
+int Rast_write_colors(const char *, const char *, struct Colors *);
+void Rast__write_colors(FILE *, struct Colors *);
+/* color_xform.c */
+void Rast_histogram_eq_colors(struct Colors *, struct Colors *,
+ struct Cell_stats *);
+void Rast_histogram_eq_colors_fp(struct Colors *,
+ struct Colors *, struct FP_stats *);
+void Rast_log_colors(struct Colors *, struct Colors *, int);
+void Rast_abs_log_colors(struct Colors *, struct Colors *, int);
+/* format.c */
+int Rast__check_format(int);
+int Rast__read_row_ptrs(int);
+int Rast__write_row_ptrs(int);
+/* fpreclass.c */
+void Rast_fpreclass_clear(struct FPReclass *);
+void Rast_fpreclass_reset(struct FPReclass *);
+void Rast_fpreclass_init(struct FPReclass *);
+void Rast_fpreclass_set_domain(struct FPReclass *, DCELL, DCELL);
+void Rast_fpreclass_set_range(struct FPReclass *, DCELL, DCELL);
+int Rast_fpreclass_get_limits(const struct FPReclass *, DCELL *, DCELL *,
+ DCELL *, DCELL *);
+int Rast_fpreclass_nof_rules(const struct FPReclass *);
+void Rast_fpreclass_get_ith_rule(const struct FPReclass *, int, DCELL *, DCELL *,
+void Rast_fpreclass_set_neg_infinite_rule(struct FPReclass *, DCELL, DCELL);
+int Rast_fpreclass_get_neg_infinite_rule(const struct FPReclass *, DCELL *,
+ DCELL *);
+void Rast_fpreclass_set_pos_infinite_rule(struct FPReclass *, DCELL, DCELL);
+int Rast_fpreclass_get_pos_infinite_rule(const struct FPReclass *, DCELL *,
+ DCELL *);
+void Rast_fpreclass_add_rule(struct FPReclass *, DCELL, DCELL, DCELL, DCELL);
+void Rast_fpreclass_reverse_rule_order(struct FPReclass *);
+DCELL Rast_fpreclass_get_cell_value(const struct FPReclass *, DCELL);
+void Rast_fpreclass_perform_di(const struct FPReclass *, const DCELL *, CELL *,
+ int);
+void Rast_fpreclass_perform_df(const struct FPReclass *, const DCELL *, FCELL *,
+ int);
+void Rast_fpreclass_perform_dd(const struct FPReclass *, const DCELL *, DCELL *,
+ int);
+void Rast_fpreclass_perform_fi(const struct FPReclass *, const FCELL *, CELL *,
+ int);
+void Rast_fpreclass_perform_ff(const struct FPReclass *, const FCELL *, FCELL *,
+ int);
+void Rast_fpreclass_perform_fd(const struct FPReclass *, const FCELL *, DCELL *,
+ int);
+void Rast_fpreclass_perform_ii(const struct FPReclass *, const CELL *, CELL *,
+ int);
+void Rast_fpreclass_perform_if(const struct FPReclass *, const CELL *, FCELL *,
+ int);
+void Rast_fpreclass_perform_id(const struct FPReclass *, const CELL *, DCELL *,
+ int);
+/* gdal.c */
+void Rast_init_gdal(void);
+struct GDAL_link *Rast_get_gdal_link(const char *, const char *);
+struct GDAL_link *Rast_create_gdal_link(const char *, RASTER_MAP_TYPE);
+void Rast_close_gdal_link(struct GDAL_link *);
+int Rast_close_gdal_write_link(struct GDAL_link *);
+/* get_cellhd.c */
+int Rast_get_cellhd(const char *, const char *, struct Cell_head *);
+/* get_row.c */
+int Rast_get_map_row_nomask(int, CELL *, int);
+int Rast_get_raster_row_nomask(int, void *, int, RASTER_MAP_TYPE);
+int Rast_get_c_raster_row_nomask(int, CELL *, int);
+int Rast_get_f_raster_row_nomask(int, FCELL *, int);
+int Rast_get_d_raster_row_nomask(int, DCELL *, int);
+int Rast_get_map_row(int, CELL *, int);
+int Rast_get_raster_row(int, void *, int, RASTER_MAP_TYPE);
+int Rast_get_c_raster_row(int, CELL *, int);
+int Rast_get_f_raster_row(int, FCELL *, int);
+int Rast_get_d_raster_row(int, DCELL *, int);
+int Rast_get_null_value_row(int, char *, int);
+/* get_row_colr.c */
+int Rast_get_raster_row_colors(int, int, struct Colors *,
+ unsigned char *, unsigned char *, unsigned char *,
+ unsigned char *);
+/* histo_eq.c */
+void Rast_histogram_eq(const struct Histogram *, unsigned char **,
+ CELL *, CELL *);
+/* histogram.c */
+void Rast_init_histogram(struct Histogram *);
+int Rast_read_histogram(const char *, const char *, struct Histogram *);
+int Rast_write_histogram(const char *, const struct Histogram *);
+int Rast_write_histogram_cs(const char *, struct Cell_stats *);
+void Rast_make_histogram_cs(struct Cell_stats *, struct Histogram *);
+int Rast_get_histogram_num(const struct Histogram *);
+CELL Rast_get_histogram_cat(int, const struct Histogram *);
+long Rast_get_histogram_count(int, const struct Histogram *);
+void Rast_free_histogram(struct Histogram *);
+int Rast_sort_histogram(struct Histogram *);
+int Rast_sort_histogram_by_count(struct Histogram *);
+void Rast_remove_histogram(const char *);
+int Rast_add_histogram(CELL, long, struct Histogram *);
+int Rast_set_histogram(CELL, long, struct Histogram *);
+void Rast_extend_histogram(CELL, long, struct Histogram *);
+void Rast_zero_histogram(struct Histogram *);
+/* history.c */
+int Rast_read_history(const char *, const char *, struct History *);
+int Rast_write_history(const char *, struct History *);
+void Rast_short_history(const char *, const char *, struct History *);
+int Rast_command_history(struct History *);
+/* init.c */
+void Rast__init(void);
+void Rast__check_init(void);
+void Rast_init_all(void);
+/* interp.c */
+DCELL Rast_interp_linear(double, DCELL, DCELL);
+DCELL Rast_interp_bilinear(double, double, DCELL, DCELL, DCELL, DCELL);
+DCELL Rast_interp_cubic(double, DCELL, DCELL, DCELL, DCELL);
+DCELL Rast_interp_bicubic(double, double,
+ DCELL, DCELL, DCELL, DCELL, DCELL, DCELL, DCELL, DCELL,
+ DCELL);
+/* mask_info.c */
+char *Rast_mask_info(void);
+int Rast__mask_info(char *, char *);
+/* maskfd.c */
+int Rast_maskfd(void);
+/* null_val.c */
+void Rast__set_null_value(void *, int, int, RASTER_MAP_TYPE);
+void Rast_set_null_value(void *, int, RASTER_MAP_TYPE);
+void Rast_set_c_null_value(CELL *, int);
+void Rast_set_f_null_value(FCELL *, int);
+void Rast_set_d_null_value(DCELL *, int);
+int Rast_is_null_value(const void *, RASTER_MAP_TYPE);
+int Rast_is_c_null_value(const CELL *);
+int Rast_is_f_null_value(const FCELL *);
+int Rast_is_d_null_value(const DCELL *);
+void Rast_insert_null_values(void *, char *, int, RASTER_MAP_TYPE);
+void Rast_insert_c_null_values(CELL *, char *, int);
+void Rast_insert_f_null_values(FCELL *, char *, int);
+void Rast_insert_d_null_values(DCELL *, char *, int);
+int Rast__check_null_bit(const unsigned char *, int, int);
+void Rast__convert_01_flags(const char *, unsigned char *, int);
+void Rast__convert_flags_01(char *, const unsigned char *, int);
+void Rast__init_null_bits(unsigned char *, int);
+/* opencell.c */
+int Rast_open_cell_old(const char *, const char *);
+int Rast__open_cell_old(const char *, const char *);
+int Rast_open_cell_new(const char *);
+int Rast_open_cell_new_uncompressed(const char *);
+void Rast_want_histogram(int);
+void Rast_set_cell_format(int);
+int Rast_cellvalue_format(CELL);
+int Rast_open_fp_cell_new(const char *);
+int Rast_open_fp_cell_new_uncompressed(const char *);
+int Rast_set_fp_type(RASTER_MAP_TYPE);
+int Rast_raster_map_is_fp(const char *, const char *);
+RASTER_MAP_TYPE Rast_raster_map_type(const char *, const char *);
+RASTER_MAP_TYPE Rast__check_fp_type(const char *, const char *);
+RASTER_MAP_TYPE Rast_get_raster_map_type(int);
+int Rast_open_raster_new(const char *, RASTER_MAP_TYPE);
+int Rast_open_raster_new_uncompressed(const char *, RASTER_MAP_TYPE);
+int Rast_set_quant_rules(int, struct Quant *);
+/* put_cellhd.c */
+int Rast_put_cellhd(const char *, struct Cell_head *);
+/* put_row.c */
+int Rast_put_map_row(int, const CELL *);
+int Rast_put_raster_row(int, const void *, RASTER_MAP_TYPE);
+int Rast_put_c_raster_row(int, const CELL *);
+int Rast_put_f_raster_row(int, const FCELL *);
+int Rast_put_d_raster_row(int, const DCELL *);
+int Rast__open_null_write(int);
+int Rast__write_null_bits(int, const unsigned char *, int, int, int);
+/* put_title.c */
+int Rast_put_cell_title(const char *, const char *);
+/* quant.c */
+void Rast_quant_clear(struct Quant *);
+void Rast_quant_free(struct Quant *);
+int Rast__quant_organize_fp_lookup(struct Quant *);
+void Rast_quant_init(struct Quant *);
+int Rast_quant_is_truncate(const struct Quant *);
+int Rast_quant_is_round(const struct Quant *);
+void Rast_quant_truncate(struct Quant *);
+void Rast_quant_round(struct Quant *);
+int Rast_quant_get_limits(const struct Quant *, DCELL *, DCELL *, CELL *,
+ CELL *);
+int Rast_quant_nof_rules(const struct Quant *);
+void Rast_quant_get_ith_rule(const struct Quant *, int, DCELL *, DCELL *, CELL *,
+ CELL *);
+void Rast_quant_set_neg_infinite_rule(struct Quant *, DCELL, CELL);
+int Rast_quant_get_neg_infinite_rule(const struct Quant *, DCELL *, CELL *);
+void Rast_quant_set_pos_infinite_rule(struct Quant *, DCELL, CELL);
+int Rast_quant_get_pos_infinite_rule(const struct Quant *, DCELL *, CELL *);
+void Rast_quant_add_rule(struct Quant *, DCELL, DCELL, CELL, CELL);
+void Rast_quant_reverse_rule_order(struct Quant *);
+CELL Rast_quant_get_cell_value(struct Quant *, DCELL);
+void Rast_quant_perform_d(struct Quant *, const DCELL *, CELL *, int);
+void Rast_quant_perform_f(struct Quant *, const FCELL *, CELL *, int);
+struct Quant_table *Rast__quant_get_rule_for_d_raster_val(const struct Quant *,
+ DCELL);
+/* quant_io.c */
+int Rast__quant_import(const char *, const char *, struct Quant *);
+int Rast__quant_export(const char *, const char *, const struct Quant *);
+/* quant_rw.c */
+int Rast_truncate_fp_map(const char *, const char *);
+int Rast_round_fp_map(const char *, const char *);
+int Rast_quantize_fp_map(const char *, const char *, CELL, CELL);
+int Rast_quantize_fp_map_range(const char *, const char *, DCELL, DCELL, CELL,
+ CELL);
+int Rast_write_quant(const char *, const char *, const struct Quant *);
+int Rast_read_quant(const char *, const char *, struct Quant *);
+/* range.c */
+void Rast__remove_fp_range(const char *);
+void Rast_construct_default_range(struct Range *);
+int Rast_read_fp_range(const char *, const char *, struct FPRange *);
+int Rast_read_range(const char *, const char *, struct Range *);
+int Rast_write_range(const char *, const struct Range *);
+int Rast_write_fp_range(const char *, const struct FPRange *);
+void Rast_update_range(CELL, struct Range *);
+void Rast_update_fp_range(DCELL, struct FPRange *);
+void Rast_row_update_range(const CELL *, int, struct Range *);
+void Rast__row_update_range(const CELL *, int, struct Range *, int);
+void Rast_row_update_fp_range(const void *, int, struct FPRange *,
+ RASTER_MAP_TYPE);
+void Rast_init_range(struct Range *);
+void Rast_get_range_min_max(const struct Range *, CELL *, CELL *);
+void Rast_init_fp_range(struct FPRange *);
+void Rast_get_fp_range_min_max(const struct FPRange *, DCELL *, DCELL *);
+/* raster.c */
+void *Rast_incr_void_ptr(const void *, const size_t);
+int Rast_raster_cmp(const void *, const void *, RASTER_MAP_TYPE);
+void Rast_raster_cpy(void *, const void *, int, RASTER_MAP_TYPE);
+void Rast_set_raster_value_c(void *, CELL, RASTER_MAP_TYPE);
+void Rast_set_raster_value_f(void *, FCELL, RASTER_MAP_TYPE);
+void Rast_set_raster_value_d(void *, DCELL, RASTER_MAP_TYPE);
+CELL Rast_get_raster_value_c(const void *, RASTER_MAP_TYPE);
+FCELL Rast_get_raster_value_f(const void *, RASTER_MAP_TYPE);
+DCELL Rast_get_raster_value_d(const void *, RASTER_MAP_TYPE);
+/* raster_metadata.c */
+int Rast_read_raster_units(const char *, const char *, char *);
+int Rast_read_raster_vdatum(const char *, const char *, char *);
+int Rast_write_raster_units(const char *, const char *);
+int Rast_write_raster_vdatum(const char *, const char *);
+int Rast__raster_misc_read_line(const char *, const char *, const char *,
+ char *);
+int Rast__raster_misc_write_line(const char *, const char *, const char *);
+/* reclass.c */
+int Rast_is_reclass(const char *, const char *, char *, char *);
+int Rast_is_reclassed_to(const char *, const char *, int *, char ***);
+int Rast_get_reclass(const char *, const char *, struct Reclass *);
+void Rast_free_reclass(struct Reclass *);
+int Rast_put_reclass(const char *, const struct Reclass *);
+/* sample.c */
+DCELL Rast_get_raster_sample_nearest(int, const struct Cell_head *, struct Categories *, double, double, int);
+DCELL Rast_get_raster_sample_bilinear(int, const struct Cell_head *, struct Categories *, double, double, int);
+DCELL Rast_get_raster_sample_cubic(int, const struct Cell_head *, struct Categories *, double, double, int);
+DCELL Rast_get_raster_sample(int, const struct Cell_head *, struct Categories *, double, double, int, INTERP_TYPE);
+/* set_window.c */
+int Rast_set_window(struct Cell_head *);
+/* zero_cell.c */
+void Rast_zero_cell_buf(CELL *);
+void Rast_zero_raster_buf(void *, RASTER_MAP_TYPE);
+#endif
Modified: grass/trunk/lib/cluster/c_point.c
--- grass/trunk/lib/cluster/c_point.c 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/lib/cluster/c_point.c 2009-06-22 01:49:13 UTC (rev 38014)
@@ -17,7 +17,7 @@
* note: if all values in x are zero, the point is rejected
#include <grass/cluster.h>
static int extend(struct Cluster *, int);
Modified: grass/trunk/lib/display/Makefile
--- grass/trunk/lib/display/Makefile 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/lib/display/Makefile 2009-06-22 01:49:13 UTC (rev 38014)
@@ -1,7 +1,7 @@
MODULE_TOPDIR = ../..
EXTRA_LIBS=$(GISLIB) $(DRIVERLIB) $(PNGDRIVERLIB) $(PSDRIVERLIB) \
- $(HTMLDRIVERLIB) $(RASTRLIB)
+ $(HTMLDRIVERLIB) $(RASTERLIB)
EXTRA_INC = -I../driver
ifneq ($(USE_CAIRO),)
Modified: grass/trunk/lib/display/raster.c
--- grass/trunk/lib/display/raster.c 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/lib/display/raster.c 2009-06-22 01:49:13 UTC (rev 38014)
@@ -27,7 +27,7 @@
#include <stdlib.h>
#include <grass/display_raster.h>
#include <grass/display.h>
Modified: grass/trunk/lib/display/raster2.c
--- grass/trunk/lib/display/raster2.c 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/lib/display/raster2.c 2009-06-22 01:49:13 UTC (rev 38014)
@@ -30,7 +30,7 @@
#include <stdlib.h>
Modified: grass/trunk/lib/display/setup.c
--- grass/trunk/lib/display/setup.c 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/lib/display/setup.c 2009-06-22 01:49:13 UTC (rev 38014)
@@ -11,7 +11,7 @@
#include <string.h>
Modified: grass/trunk/lib/display/tran_colr.c
--- grass/trunk/lib/display/tran_colr.c 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/lib/display/tran_colr.c 2009-06-22 01:49:13 UTC (rev 38014)
@@ -6,7 +6,7 @@
#include <grass/colors.h>
#include <grass/glocale.h>
Modified: grass/trunk/lib/g3d/Makefile
--- grass/trunk/lib/g3d/Makefile 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/lib/g3d/Makefile 2009-06-22 01:49:13 UTC (rev 38014)
@@ -2,7 +2,7 @@
LIB_NAME = $(G3D_LIBNAME)
-EXTRA_LIBS = $(GISLIB) $(RASTRLIB)
+EXTRA_LIBS = $(GISLIB) $(RASTERLIB)
include $(MODULE_TOPDIR)/include/Make/Lib.make
include $(MODULE_TOPDIR)/include/Make/Doxygen.make
Modified: grass/trunk/lib/g3d/g3dcats.c
--- grass/trunk/lib/g3d/g3dcats.c 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/lib/g3d/g3dcats.c 2009-06-22 01:49:13 UTC (rev 38014)
@@ -6,7 +6,7 @@
#include <rpc/xdr.h>
#include "G3d_intern.h"
Modified: grass/trunk/lib/g3d/g3dclose.c
--- grass/trunk/lib/g3d/g3dclose.c 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/lib/g3d/g3dclose.c 2009-06-22 01:49:13 UTC (rev 38014)
@@ -6,7 +6,7 @@
#include <sys/types.h>
#include <unistd.h>
Modified: grass/trunk/lib/g3d/g3dcolor.c
--- grass/trunk/lib/g3d/g3dcolor.c 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/lib/g3d/g3dcolor.c 2009-06-22 01:49:13 UTC (rev 38014)
@@ -8,7 +8,7 @@
Modified: grass/trunk/lib/g3d/g3dfpxdr.c
--- grass/trunk/lib/g3d/g3dfpxdr.c 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/lib/g3d/g3dfpxdr.c 2009-06-22 01:49:13 UTC (rev 38014)
@@ -6,7 +6,7 @@
#include <rpc/types.h>
Modified: grass/trunk/lib/g3d/g3dmisc.c
--- grass/trunk/lib/g3d/g3dmisc.c 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/lib/g3d/g3dmisc.c 2009-06-22 01:49:13 UTC (rev 38014)
@@ -6,7 +6,7 @@
Modified: grass/trunk/lib/g3d/g3dnull.c
--- grass/trunk/lib/g3d/g3dnull.c 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/lib/g3d/g3dnull.c 2009-06-22 01:49:13 UTC (rev 38014)
@@ -3,7 +3,7 @@
#include <unistd.h>
Modified: grass/trunk/lib/g3d/g3drange.c
--- grass/trunk/lib/g3d/g3drange.c 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/lib/g3d/g3drange.c 2009-06-22 01:49:13 UTC (rev 38014)
@@ -6,7 +6,7 @@
Modified: grass/trunk/lib/g3d/g3dregion.c
--- grass/trunk/lib/g3d/g3dregion.c 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/lib/g3d/g3dregion.c 2009-06-22 01:49:13 UTC (rev 38014)
@@ -1,7 +1,7 @@
#include <stdio.h>
#include <grass/G3d.h>
Modified: grass/trunk/lib/g3d/g3dvolume.c
--- grass/trunk/lib/g3d/g3dvolume.c 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/lib/g3d/g3dvolume.c 2009-06-22 01:49:13 UTC (rev 38014)
@@ -3,7 +3,7 @@
#include <unistd.h>
Modified: grass/trunk/lib/g3d/getblock.c
--- grass/trunk/lib/g3d/getblock.c 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/lib/g3d/getblock.c 2009-06-22 01:49:13 UTC (rev 38014)
@@ -3,7 +3,7 @@
#include <unistd.h>
Modified: grass/trunk/lib/g3d/tileread.c
--- grass/trunk/lib/g3d/tileread.c 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/lib/g3d/tileread.c 2009-06-22 01:49:13 UTC (rev 38014)
@@ -5,7 +5,7 @@
static int
Modified: grass/trunk/lib/g3d/tilewrite.c
--- grass/trunk/lib/g3d/tilewrite.c 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/lib/g3d/tilewrite.c 2009-06-22 01:49:13 UTC (rev 38014)
@@ -5,7 +5,7 @@
Modified: grass/trunk/lib/gpde/Makefile
--- grass/trunk/lib/gpde/Makefile 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/lib/gpde/Makefile 2009-06-22 01:49:13 UTC (rev 38014)
@@ -4,7 +4,7 @@
#EXTRA_CFLAGS=-fopenmp
#EXTRA_LIBS=$(GISLIB) $(G3DLIB) -lgomp $(MATHLIB)
-EXTRA_LIBS=$(GISLIB) $(G3DLIB) $(RASTRLIB)
+EXTRA_LIBS=$(GISLIB) $(G3DLIB) $(RASTERLIB)
LIB_NAME = $(GPDE_LIBNAME)
Modified: grass/trunk/lib/gpde/N_arrays.c
--- grass/trunk/lib/gpde/N_arrays.c 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/lib/gpde/N_arrays.c 2009-06-22 01:49:13 UTC (rev 38014)
@@ -19,7 +19,7 @@
#include <math.h>
#include <grass/N_pde.h>
Modified: grass/trunk/lib/gpde/N_arrays_calc.c
--- grass/trunk/lib/gpde/N_arrays_calc.c 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/lib/gpde/N_arrays_calc.c 2009-06-22 01:49:13 UTC (rev 38014)
@@ -18,7 +18,7 @@
#include <math.h>
Modified: grass/trunk/lib/gpde/N_arrays_io.c
--- grass/trunk/lib/gpde/N_arrays_io.c 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/lib/gpde/N_arrays_io.c 2009-06-22 01:49:13 UTC (rev 38014)
@@ -18,7 +18,7 @@
#include <math.h>
-#include <grass/Rast.h>
+#include <grass/raster.h>
Modified: grass/trunk/lib/gpde/N_pde.h
--- grass/trunk/lib/gpde/N_pde.h 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/lib/gpde/N_pde.h 2009-06-22 01:49:13 UTC (rev 38014)
@@ -16,7 +16,7 @@
Modified: grass/trunk/lib/nviz/Makefile
--- grass/trunk/lib/nviz/Makefile 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/lib/nviz/Makefile 2009-06-22 01:49:13 UTC (rev 38014)
@@ -4,7 +4,7 @@
EXTRA_LIBS = $(GISLIB) $(BITMAPLIB) $(VECTLIB) $(OPENGLLIB) \
$(OPENGLULIB) $(TIFFLIBPATH) $(TIFFLIB) $(FFMPEGLIBPATH) \
- $(FFMPEGLIB) $(SITESLIB) $(G3DLIB) $(OGSFLIB) $(RASTRLIB)
+ $(FFMPEGLIB) $(SITESLIB) $(G3DLIB) $(OGSFLIB) $(RASTERLIB)
Modified: grass/trunk/lib/nviz/nviz.c
--- grass/trunk/lib/nviz/nviz.c 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/lib/nviz/nviz.c 2009-06-22 01:49:13 UTC (rev 38014)
@@ -16,7 +16,7 @@
\date 2008
#include <grass/nviz.h>
Modified: grass/trunk/lib/ogsf/GS2.c
--- grass/trunk/lib/ogsf/GS2.c 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/lib/ogsf/GS2.c 2009-06-22 01:49:13 UTC (rev 38014)
@@ -43,7 +43,7 @@
#endif
#include <grass/gstypes.h>
Modified: grass/trunk/lib/ogsf/Gp3.c
--- grass/trunk/lib/ogsf/Gp3.c 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/lib/ogsf/Gp3.c 2009-06-22 01:49:13 UTC (rev 38014)
@@ -19,7 +19,7 @@
#include <stdlib.h>
#include <grass/site.h>
#include <grass/Vect.h>
Modified: grass/trunk/lib/ogsf/Gs3.c
--- grass/trunk/lib/ogsf/Gs3.c 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/lib/ogsf/Gs3.c 2009-06-22 01:49:13 UTC (rev 38014)
@@ -20,7 +20,7 @@
#include <string.h>
#include <grass/bitmap.h>
Modified: grass/trunk/lib/ogsf/Gvl3.c
--- grass/trunk/lib/ogsf/Gvl3.c 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/lib/ogsf/Gvl3.c 2009-06-22 01:49:13 UTC (rev 38014)
@@ -17,7 +17,7 @@
Modified: grass/trunk/lib/ogsf/Makefile
--- grass/trunk/lib/ogsf/Makefile 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/lib/ogsf/Makefile 2009-06-22 01:49:13 UTC (rev 38014)
@@ -2,7 +2,7 @@
EXTRA_LIBS=$(GISLIB) $(BITMAPLIB) $(VECTLIB) $(XLIBPATH) $(OPENGLLIB) \
- $(FFMPEGLIB) $(SITESLIB) $(G3DLIB) $(RASTRLIB)
+ $(FFMPEGLIB) $(SITESLIB) $(G3DLIB) $(RASTERLIB)
LIB_NAME = $(OGSF_LIBNAME)
Modified: grass/trunk/lib/ogsf/gsd_legend.c
--- grass/trunk/lib/ogsf/gsd_legend.c 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/lib/ogsf/gsd_legend.c 2009-06-22 01:49:13 UTC (rev 38014)
@@ -32,7 +32,7 @@
#endif
Modified: grass/trunk/lib/raster/Makefile
--- grass/trunk/lib/raster/Makefile 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/lib/raster/Makefile 2009-06-22 01:49:13 UTC (rev 38014)
@@ -3,7 +3,7 @@
GDAL_LINK = $(USE_GDAL)
GDAL_DYNAMIC = 1
-LIB_NAME = $(RASTR_LIBNAME)
+LIB_NAME = $(RASTER_LIBNAME)
EXTRA_LIBS = $(XDRLIB) $(SOCKLIB) $(DATETIMELIB) $(PTHREADLIBPATH) \
$(PTHREADLIB) $(INTLLIB) $(MATHLIB) $(GISLIB)
EXTRA_INC = $(ZLIBINCPATH) $(PTHREADINCPATH)
Modified: grass/trunk/lib/raster/alloc_cell.c
--- grass/trunk/lib/raster/alloc_cell.c 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/lib/raster/alloc_cell.c 2009-06-22 01:49:13 UTC (rev 38014)
@@ -14,7 +14,7 @@
#include <math.h>
/* convert type "RASTER_MAP_TYPE" into index */
#define F2I(map_type) \
Modified: grass/trunk/lib/raster/auto_mask.c
--- grass/trunk/lib/raster/auto_mask.c 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/lib/raster/auto_mask.c 2009-06-22 01:49:13 UTC (rev 38014)
@@ -17,7 +17,7 @@
#include <stdlib.h>
#include "G.h"
Modified: grass/trunk/lib/raster/cats.c
--- grass/trunk/lib/raster/cats.c 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/lib/raster/cats.c 2009-06-22 01:49:13 UTC (rev 38014)
@@ -72,7 +72,7 @@
#include <string.h>
static void get_cond(char **, char *, DCELL);
Modified: grass/trunk/lib/raster/cell_stats.c
--- grass/trunk/lib/raster/cell_stats.c 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/lib/raster/cell_stats.c 2009-06-22 01:49:13 UTC (rev 38014)
@@ -14,7 +14,7 @@
#include <stdlib.h>
#define INCR 10
#define SHIFT 6
Modified: grass/trunk/lib/raster/cellstats_eq.c
--- grass/trunk/lib/raster/cellstats_eq.c 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/lib/raster/cellstats_eq.c 2009-06-22 01:49:13 UTC (rev 38014)
@@ -1,5 +1,5 @@
int Rast_cell_stats_histo_eq(struct Cell_stats *statf, CELL min1, CELL max1, /* input range to be rescaled */
CELL min2, CELL max2, /* output range */
Modified: grass/trunk/lib/raster/closecell.c
--- grass/trunk/lib/raster/closecell.c 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/lib/raster/closecell.c 2009-06-22 01:49:13 UTC (rev 38014)
@@ -24,7 +24,7 @@
#include <signal.h>
#include "G.h"
Modified: grass/trunk/lib/raster/color_compat.c
--- grass/trunk/lib/raster/color_compat.c 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/lib/raster/color_compat.c 2009-06-22 01:49:13 UTC (rev 38014)
@@ -12,7 +12,7 @@
* \brief Make color wave (integer)
Modified: grass/trunk/lib/raster/color_free.c
--- grass/trunk/lib/raster/color_free.c 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/lib/raster/color_free.c 2009-06-22 01:49:13 UTC (rev 38014)
@@ -14,7 +14,7 @@
#include <stdlib.h>
* \brief Free color structure memory
Modified: grass/trunk/lib/raster/color_get.c
--- grass/trunk/lib/raster/color_get.c 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/lib/raster/color_get.c 2009-06-22 01:49:13 UTC (rev 38014)
@@ -12,7 +12,7 @@
* \brief Get a category color.
Modified: grass/trunk/lib/raster/color_hist.c
--- grass/trunk/lib/raster/color_hist.c 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/lib/raster/color_hist.c 2009-06-22 01:49:13 UTC (rev 38014)
@@ -14,7 +14,7 @@
#include <math.h>
* \brief Make histogram-stretched grey colors
Modified: grass/trunk/lib/raster/color_look.c
--- grass/trunk/lib/raster/color_look.c 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/lib/raster/color_look.c 2009-06-22 01:49:13 UTC (rev 38014)
@@ -15,7 +15,7 @@
#include <math.h>
* \brief Lookup an array of colors
Modified: grass/trunk/lib/raster/color_org.c
--- grass/trunk/lib/raster/color_org.c 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/lib/raster/color_org.c 2009-06-22 01:49:13 UTC (rev 38014)
@@ -1,7 +1,7 @@
#include <stdlib.h>
#define LOOKUP_COLORS 2048
Modified: grass/trunk/lib/raster/color_rand.c
--- grass/trunk/lib/raster/color_rand.c 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/lib/raster/color_rand.c 2009-06-22 01:49:13 UTC (rev 38014)
@@ -3,7 +3,7 @@
#include <stdlib.h> /* For rand() and srand() */
#define MAX_COLORS 1024
Modified: grass/trunk/lib/raster/color_read.c
--- grass/trunk/lib/raster/color_read.c 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/lib/raster/color_read.c 2009-06-22 01:49:13 UTC (rev 38014)
@@ -15,7 +15,7 @@
#include <string.h>
static int read_colors(const char *, const char *, const char *,
Modified: grass/trunk/lib/raster/color_rule.c
--- grass/trunk/lib/raster/color_rule.c 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/lib/raster/color_rule.c 2009-06-22 01:49:13 UTC (rev 38014)
@@ -12,7 +12,7 @@
#define LIMIT(x) if (x < 0) x = 0; else if (x > 255) x = 255;
Modified: grass/trunk/lib/raster/color_rules.c
--- grass/trunk/lib/raster/color_rules.c 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/lib/raster/color_rules.c 2009-06-22 01:49:13 UTC (rev 38014)
@@ -23,7 +23,7 @@
#include <stdio.h>
struct rule
Modified: grass/trunk/lib/raster/color_set.c
--- grass/trunk/lib/raster/color_set.c 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/lib/raster/color_set.c 2009-06-22 01:49:13 UTC (rev 38014)
@@ -12,7 +12,7 @@
* \brief Set a category color (CELL)
Modified: grass/trunk/lib/raster/color_write.c
--- grass/trunk/lib/raster/color_write.c 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/lib/raster/color_write.c 2009-06-22 01:49:13 UTC (rev 38014)
@@ -17,7 +17,7 @@
#include <stdio.h>
#define PRECISION 30
#define THRESHOLD .0000000000000000000000000000005 /* .5 * 10 ^(-30) */
Modified: grass/trunk/lib/raster/color_xform.c
--- grass/trunk/lib/raster/color_xform.c 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/lib/raster/color_xform.c 2009-06-22 01:49:13 UTC (rev 38014)
@@ -43,7 +43,7 @@
#include <math.h>
* \brief make histogram-stretched version of existing color table
Modified: grass/trunk/lib/raster/format.c
--- grass/trunk/lib/raster/format.c 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/lib/raster/format.c 2009-06-22 01:49:13 UTC (rev 38014)
@@ -3,7 +3,7 @@
#include <grass/config.h>
#include "G.h"
Modified: grass/trunk/lib/raster/fpreclass.c
--- grass/trunk/lib/raster/fpreclass.c 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/lib/raster/fpreclass.c 2009-06-22 01:49:13 UTC (rev 38014)
@@ -242,7 +242,7 @@
Modified: grass/trunk/lib/raster/gdal.c
--- grass/trunk/lib/raster/gdal.c 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/lib/raster/gdal.c 2009-06-22 01:49:13 UTC (rev 38014)
@@ -5,7 +5,7 @@
#include "G.h"
Modified: grass/trunk/lib/raster/get_cellhd.c
--- grass/trunk/lib/raster/get_cellhd.c 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/lib/raster/get_cellhd.c 2009-06-22 01:49:13 UTC (rev 38014)
@@ -15,7 +15,7 @@
#include <stdlib.h>
Modified: grass/trunk/lib/raster/get_row.c
--- grass/trunk/lib/raster/get_row.c 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/lib/raster/get_row.c 2009-06-22 01:49:13 UTC (rev 38014)
@@ -19,7 +19,7 @@
#include "G.h"
Modified: grass/trunk/lib/raster/get_row_colr.c
--- grass/trunk/lib/raster/get_row_colr.c 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/lib/raster/get_row_colr.c 2009-06-22 01:49:13 UTC (rev 38014)
@@ -13,7 +13,7 @@
#include "G.h"
Modified: grass/trunk/lib/raster/histo_eq.c
--- grass/trunk/lib/raster/histo_eq.c 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/lib/raster/histo_eq.c 2009-06-22 01:49:13 UTC (rev 38014)
@@ -10,7 +10,7 @@
* inputs are histo, output is map,min,max
void Rast_histogram_eq(const struct Histogram *histo,
unsigned char **map, CELL *min, CELL *max)
Modified: grass/trunk/lib/raster/histogram.c
--- grass/trunk/lib/raster/histogram.c 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/lib/raster/histogram.c 2009-06-22 01:49:13 UTC (rev 38014)
@@ -1,7 +1,7 @@
#include <stdlib.h>
#define LIST struct Histogram_list
Modified: grass/trunk/lib/raster/init.c
--- grass/trunk/lib/raster/init.c 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/lib/raster/init.c 2009-06-22 01:49:13 UTC (rev 38014)
@@ -21,7 +21,7 @@
#include <locale.h>
#include "../raster/G.h"
Modified: grass/trunk/lib/raster/mask_info.c
--- grass/trunk/lib/raster/mask_info.c 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/lib/raster/mask_info.c 2009-06-22 01:49:13 UTC (rev 38014)
@@ -29,7 +29,7 @@
#include <string.h>
Modified: grass/trunk/lib/raster/maskfd.c
--- grass/trunk/lib/raster/maskfd.c 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/lib/raster/maskfd.c 2009-06-22 01:49:13 UTC (rev 38014)
@@ -12,7 +12,7 @@
#include "G.h"
Modified: grass/trunk/lib/raster/null_val.c
--- grass/trunk/lib/raster/null_val.c 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/lib/raster/null_val.c 2009-06-22 01:49:13 UTC (rev 38014)
@@ -20,7 +20,7 @@
/* Grass and local include files */
static void EmbedGivenNulls(void *, char *, RASTER_MAP_TYPE, int);
Modified: grass/trunk/lib/raster/opencell.c
--- grass/trunk/lib/raster/opencell.c 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/lib/raster/opencell.c 2009-06-22 01:49:13 UTC (rev 38014)
@@ -22,7 +22,7 @@
#include "G.h"
Modified: grass/trunk/lib/raster/put_row.c
--- grass/trunk/lib/raster/put_row.c 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/lib/raster/put_row.c 2009-06-22 01:49:13 UTC (rev 38014)
@@ -81,7 +81,7 @@
#include <fcntl.h>
#include "G.h"
Modified: grass/trunk/lib/raster/quant.c
--- grass/trunk/lib/raster/quant.c 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/lib/raster/quant.c 2009-06-22 01:49:13 UTC (rev 38014)
@@ -20,7 +20,7 @@
#include <stdlib.h>
static int double_comp(const void *, const void *);
Modified: grass/trunk/lib/raster/quant_io.c
--- grass/trunk/lib/raster/quant_io.c 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/lib/raster/quant_io.c 2009-06-22 01:49:13 UTC (rev 38014)
@@ -61,7 +61,7 @@
#include <string.h>
Modified: grass/trunk/lib/raster/quant_rw.c
--- grass/trunk/lib/raster/quant_rw.c 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/lib/raster/quant_rw.c 2009-06-22 01:49:13 UTC (rev 38014)
@@ -15,7 +15,7 @@
#include <string.h>
Modified: grass/trunk/lib/raster/range.c
--- grass/trunk/lib/raster/range.c 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/lib/raster/range.c 2009-06-22 01:49:13 UTC (rev 38014)
@@ -15,7 +15,7 @@
#include <rpc/types.h> /* need this for sgi */
#include "G.h"
Modified: grass/trunk/lib/raster/raster.c
--- grass/trunk/lib/raster/raster.c 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/lib/raster/raster.c 2009-06-22 01:49:13 UTC (rev 38014)
@@ -13,7 +13,7 @@
#include <stdlib.h>
* \brief Advance void pointer
Modified: grass/trunk/lib/raster/raster_metadata.c
--- grass/trunk/lib/raster/raster_metadata.c 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/lib/raster/raster_metadata.c 2009-06-22 01:49:13 UTC (rev 38014)
@@ -14,7 +14,7 @@
#include <string.h>
Modified: grass/trunk/lib/raster/reclass.c
--- grass/trunk/lib/raster/reclass.c 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/lib/raster/reclass.c 2009-06-22 01:49:13 UTC (rev 38014)
@@ -14,7 +14,7 @@
#include <string.h>
static const char NULL_STRING[] = "null";
Modified: grass/trunk/lib/raster/sample.c
--- grass/trunk/lib/raster/sample.c 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/lib/raster/sample.c 2009-06-22 01:49:13 UTC (rev 38014)
@@ -19,7 +19,7 @@
#include <math.h>
/* prototypes */
Modified: grass/trunk/lib/raster/set_window.c
--- grass/trunk/lib/raster/set_window.c 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/lib/raster/set_window.c 2009-06-22 01:49:13 UTC (rev 38014)
@@ -12,7 +12,7 @@
#include "G.h"
Modified: grass/trunk/lib/raster/zero_cell.c
--- grass/trunk/lib/raster/zero_cell.c 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/lib/raster/zero_cell.c 2009-06-22 01:49:13 UTC (rev 38014)
@@ -12,7 +12,7 @@
* \brief Zero a raster CELL buffer.
Modified: grass/trunk/lib/rst/interp_float/Makefile
--- grass/trunk/lib/rst/interp_float/Makefile 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/lib/rst/interp_float/Makefile 2009-06-22 01:49:13 UTC (rev 38014)
@@ -1,11 +1,11 @@
MODULE_TOPDIR = ../../..
EXTRA_LIBS=$(GISLIB) $(VECTLIB) $(SITESLIB) $(BITMAPLIB) \
- $(QTREELIB) $(INTERPDATALIB) $(DBMILIB) $(GMATHLIB) $(RASTRLIB)
+ $(QTREELIB) $(INTERPDATALIB) $(DBMILIB) $(GMATHLIB) $(RASTERLIB)
LIB_NAME = $(INTERPFL_LIBNAME)
-DEPENDENCIES = $(GISDEP) $(RASTRDEP)
+DEPENDENCIES = $(GISDEP) $(RASTERDEP)
Modified: grass/trunk/lib/rst/interp_float/input2d.c
--- grass/trunk/lib/rst/interp_float/input2d.c 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/lib/rst/interp_float/input2d.c 2009-06-22 01:49:13 UTC (rev 38014)
@@ -19,7 +19,7 @@
#include <math.h>
#include <grass/linkm.h>
Modified: grass/trunk/lib/rst/interp_float/interp2d.c
--- grass/trunk/lib/rst/interp_float/interp2d.c 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/lib/rst/interp_float/interp2d.c 2009-06-22 01:49:13 UTC (rev 38014)
@@ -28,7 +28,7 @@
#include <unistd.h>
#include <grass/interpf.h>
Modified: grass/trunk/lib/rst/interp_float/output2d.c
--- grass/trunk/lib/rst/interp_float/output2d.c 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/lib/rst/interp_float/output2d.c 2009-06-22 01:49:13 UTC (rev 38014)
@@ -17,7 +17,7 @@
#include <math.h>
Modified: grass/trunk/lib/rst/interp_float/resout2d.c
--- grass/trunk/lib/rst/interp_float/resout2d.c 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/lib/rst/interp_float/resout2d.c 2009-06-22 01:49:13 UTC (rev 38014)
@@ -17,7 +17,7 @@
#include <math.h>
Modified: grass/trunk/lib/rst/interp_float/ressegm2d.c
--- grass/trunk/lib/rst/interp_float/ressegm2d.c 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/lib/rst/interp_float/ressegm2d.c 2009-06-22 01:49:13 UTC (rev 38014)
@@ -23,7 +23,7 @@
#include <math.h>
#include <grass/gmath.h>
Modified: grass/trunk/lib/stats/Makefile
--- grass/trunk/lib/stats/Makefile 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/lib/stats/Makefile 2009-06-22 01:49:13 UTC (rev 38014)
@@ -1,6 +1,6 @@
-EXTRA_LIBS=$(GISLIB) $(RASTRLIB)
+EXTRA_LIBS=$(GISLIB) $(RASTERLIB)
LIB_NAME = $(STATS_LIBNAME)
Modified: grass/trunk/lib/stats/c_ave.c
--- grass/trunk/lib/stats/c_ave.c 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/lib/stats/c_ave.c 2009-06-22 01:49:13 UTC (rev 38014)
@@ -1,5 +1,5 @@
void c_ave(DCELL * result, DCELL * values, int n, const void *closure)
Modified: grass/trunk/lib/stats/c_count.c
--- grass/trunk/lib/stats/c_count.c 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/lib/stats/c_count.c 2009-06-22 01:49:13 UTC (rev 38014)
@@ -1,5 +1,5 @@
void c_count(DCELL * result, DCELL * values, int n, const void *closure)
Modified: grass/trunk/lib/stats/c_intr.c
--- grass/trunk/lib/stats/c_intr.c 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/lib/stats/c_intr.c 2009-06-22 01:49:13 UTC (rev 38014)
@@ -1,5 +1,5 @@
#include <grass/stats.h>
void c_intr(DCELL * result, DCELL * values, int n, const void *closure)
Modified: grass/trunk/lib/stats/c_kurt.c
--- grass/trunk/lib/stats/c_kurt.c 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/lib/stats/c_kurt.c 2009-06-22 01:49:13 UTC (rev 38014)
@@ -1,5 +1,5 @@
void c_kurt(DCELL * result, DCELL * values, int n, const void *closure)
Modified: grass/trunk/lib/stats/c_max.c
--- grass/trunk/lib/stats/c_max.c 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/lib/stats/c_max.c 2009-06-22 01:49:13 UTC (rev 38014)
@@ -1,5 +1,5 @@
void c_max(DCELL * result, DCELL * values, int n, const void *closure)
Modified: grass/trunk/lib/stats/c_maxx.c
--- grass/trunk/lib/stats/c_maxx.c 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/lib/stats/c_maxx.c 2009-06-22 01:49:13 UTC (rev 38014)
@@ -1,5 +1,5 @@
void c_maxx(DCELL * result, DCELL * values, int n, const void *closure)
Modified: grass/trunk/lib/stats/c_median.c
--- grass/trunk/lib/stats/c_median.c 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/lib/stats/c_median.c 2009-06-22 01:49:13 UTC (rev 38014)
@@ -1,5 +1,5 @@
void c_median(DCELL * result, DCELL * values, int n, const void *closure)
Modified: grass/trunk/lib/stats/c_min.c
--- grass/trunk/lib/stats/c_min.c 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/lib/stats/c_min.c 2009-06-22 01:49:13 UTC (rev 38014)
@@ -1,5 +1,5 @@
void c_min(DCELL * result, DCELL * values, int n, const void *closure)
Modified: grass/trunk/lib/stats/c_minx.c
--- grass/trunk/lib/stats/c_minx.c 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/lib/stats/c_minx.c 2009-06-22 01:49:13 UTC (rev 38014)
@@ -1,5 +1,5 @@
void c_minx(DCELL * result, DCELL * values, int n, const void *closure)
Modified: grass/trunk/lib/stats/c_mode.c
--- grass/trunk/lib/stats/c_mode.c 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/lib/stats/c_mode.c 2009-06-22 01:49:13 UTC (rev 38014)
@@ -1,5 +1,5 @@
void c_mode(DCELL * result, DCELL * values, int n, const void *closure)
Modified: grass/trunk/lib/stats/c_percentile.c
--- grass/trunk/lib/stats/c_percentile.c 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/lib/stats/c_percentile.c 2009-06-22 01:49:13 UTC (rev 38014)
@@ -1,7 +1,7 @@
#include <math.h>
void c_quant(DCELL * result, DCELL * values, int n, const void *closure)
Modified: grass/trunk/lib/stats/c_range.c
--- grass/trunk/lib/stats/c_range.c 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/lib/stats/c_range.c 2009-06-22 01:49:13 UTC (rev 38014)
@@ -1,5 +1,5 @@
void c_range(DCELL * result, DCELL * values, int n, const void *closure)
Modified: grass/trunk/lib/stats/c_reg.c
--- grass/trunk/lib/stats/c_reg.c 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/lib/stats/c_reg.c 2009-06-22 01:49:13 UTC (rev 38014)
@@ -1,5 +1,5 @@
#define REGRESSION_SLOPE 0
#define REGRESSION_OFFSET 1
Modified: grass/trunk/lib/stats/c_skew.c
--- grass/trunk/lib/stats/c_skew.c 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/lib/stats/c_skew.c 2009-06-22 01:49:13 UTC (rev 38014)
@@ -1,7 +1,7 @@
#include <math.h>
void c_skew(DCELL * result, DCELL * values, int n, const void *closure)
Modified: grass/trunk/lib/stats/c_stddev.c
--- grass/trunk/lib/stats/c_stddev.c 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/lib/stats/c_stddev.c 2009-06-22 01:49:13 UTC (rev 38014)
@@ -1,7 +1,7 @@
#include <math.h>
void c_stddev(DCELL * result, DCELL * values, int n, const void *closure)
Modified: grass/trunk/lib/stats/c_sum.c
--- grass/trunk/lib/stats/c_sum.c 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/lib/stats/c_sum.c 2009-06-22 01:49:13 UTC (rev 38014)
@@ -1,5 +1,5 @@
void c_sum(DCELL * result, DCELL * values, int n, const void *closure)
Modified: grass/trunk/lib/stats/c_var.c
--- grass/trunk/lib/stats/c_var.c 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/lib/stats/c_var.c 2009-06-22 01:49:13 UTC (rev 38014)
@@ -1,5 +1,5 @@
void c_var(DCELL * result, DCELL * values, int n, const void *closure)
Modified: grass/trunk/lib/stats/sort_cell.c
--- grass/trunk/lib/stats/sort_cell.c 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/lib/stats/sort_cell.c 2009-06-22 01:49:13 UTC (rev 38014)
@@ -1,7 +1,7 @@
#include <stdlib.h>
static int ascending(const void *aa, const void *bb)
Modified: grass/trunk/ps/ps.map/Makefile
--- grass/trunk/ps/ps.map/Makefile 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/ps/ps.map/Makefile 2009-06-22 01:49:13 UTC (rev 38014)
@@ -3,8 +3,8 @@
PGM=ps.map
PROLOG=$(ETC)/paint/prolog.ps
-LIBES = $(VECTLIB) $(GPROJLIB) $(SYMBLIB) $(GISLIB) $(RASTRLIB) $(DATETIMELIB) $(IMAGERYLIB) $(GMATHLIB)
-DEPENDENCIES = $(VECTDEP) $(SYMBDEP) $(GISDEP) $(RASTRDEP) $(DATETIMEDEP) $(IMAGERYDEP) $(GMATHDEP)
+LIBES = $(VECTLIB) $(GPROJLIB) $(SYMBLIB) $(GISLIB) $(RASTERLIB) $(DATETIMELIB) $(IMAGERYLIB) $(GMATHLIB)
+DEPENDENCIES = $(VECTDEP) $(SYMBDEP) $(GISDEP) $(RASTERDEP) $(DATETIMEDEP) $(IMAGERYDEP) $(GMATHDEP)
EXTRA_INC = $(VECT_INC) $(PROJINC)
EXTRA_CFLAGS = $(VECT_CFLAGS)
Modified: grass/trunk/ps/ps.map/catval.c
--- grass/trunk/ps/ps.map/catval.c 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/ps/ps.map/catval.c 2009-06-22 01:49:13 UTC (rev 38014)
@@ -16,7 +16,7 @@
#include <grass/dbmi.h>
Modified: grass/trunk/ps/ps.map/distance.c
--- grass/trunk/ps/ps.map/distance.c 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/ps/ps.map/distance.c 2009-06-22 01:49:13 UTC (rev 38014)
@@ -1,5 +1,5 @@
double distance(double east, double west)
Modified: grass/trunk/ps/ps.map/do_geogrid.c
--- grass/trunk/ps/ps.map/do_geogrid.c 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/ps/ps.map/do_geogrid.c 2009-06-22 01:49:13 UTC (rev 38014)
@@ -8,7 +8,7 @@
#include <string.h>
#include <math.h>
#include <grass/gprojects.h>
Modified: grass/trunk/ps/ps.map/do_masking.c
--- grass/trunk/ps/ps.map/do_masking.c 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/ps/ps.map/do_masking.c 2009-06-22 01:49:13 UTC (rev 38014)
@@ -6,7 +6,7 @@
#include <stdlib.h>
#include <unistd.h>
#include "ps_info.h"
Modified: grass/trunk/ps/ps.map/do_plt.c
--- grass/trunk/ps/ps.map/do_plt.c 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/ps/ps.map/do_plt.c 2009-06-22 01:49:13 UTC (rev 38014)
@@ -5,7 +5,7 @@
#include <string.h>
#include <grass/symbol.h>
#include "clr.h"
Modified: grass/trunk/ps/ps.map/do_psfiles.c
--- grass/trunk/ps/ps.map/do_psfiles.c 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/ps/ps.map/do_psfiles.c 2009-06-22 01:49:13 UTC (rev 38014)
@@ -4,7 +4,7 @@
Modified: grass/trunk/ps/ps.map/do_vectors.c
--- grass/trunk/ps/ps.map/do_vectors.c 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/ps/ps.map/do_vectors.c 2009-06-22 01:49:13 UTC (rev 38014)
@@ -8,7 +8,7 @@
#include <string.h>
Modified: grass/trunk/ps/ps.map/error.c
--- grass/trunk/ps/ps.map/error.c 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/ps/ps.map/error.c 2009-06-22 01:49:13 UTC (rev 38014)
@@ -1,7 +1,7 @@
#include <stdio.h>
#include <unistd.h>
#include "local_proto.h"
extern FILE *tracefd;
Modified: grass/trunk/ps/ps.map/get_font.c
--- grass/trunk/ps/ps.map/get_font.c 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/ps/ps.map/get_font.c 2009-06-22 01:49:13 UTC (rev 38014)
@@ -4,7 +4,7 @@
int get_font(char *data)
Modified: grass/trunk/ps/ps.map/input.c
--- grass/trunk/ps/ps.map/input.c 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/ps/ps.map/input.c 2009-06-22 01:49:13 UTC (rev 38014)
@@ -3,7 +3,7 @@
#include <unistd.h>
#include <string.h>
Modified: grass/trunk/ps/ps.map/main.c
--- grass/trunk/ps/ps.map/main.c 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/ps/ps.map/main.c 2009-06-22 01:49:13 UTC (rev 38014)
@@ -24,7 +24,7 @@
#include <signal.h>
#include <errno.h>
#include "map_info.h"
Modified: grass/trunk/ps/ps.map/makeprocs.c
--- grass/trunk/ps/ps.map/makeprocs.c 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/ps/ps.map/makeprocs.c 2009-06-22 01:49:13 UTC (rev 38014)
@@ -6,7 +6,7 @@
Modified: grass/trunk/ps/ps.map/map_setup.c
--- grass/trunk/ps/ps.map/map_setup.c 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/ps/ps.map/map_setup.c 2009-06-22 01:49:13 UTC (rev 38014)
@@ -4,7 +4,7 @@
#include "group.h"
Modified: grass/trunk/ps/ps.map/outl_io.c
--- grass/trunk/ps/ps.map/outl_io.c 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/ps/ps.map/outl_io.c 2009-06-22 01:49:13 UTC (rev 38014)
@@ -1,6 +1,6 @@
#include <stdlib.h>
Modified: grass/trunk/ps/ps.map/parse_list.c
--- grass/trunk/ps/ps.map/parse_list.c 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/ps/ps.map/parse_list.c 2009-06-22 01:49:13 UTC (rev 38014)
@@ -20,7 +20,7 @@
* count will be negative if list is not valid
int parse_val_list(char *buf, DCELL ** list)
Modified: grass/trunk/ps/ps.map/ps_header.c
--- grass/trunk/ps/ps.map/ps_header.c 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/ps/ps.map/ps_header.c 2009-06-22 01:49:13 UTC (rev 38014)
@@ -6,7 +6,7 @@
#include <stdio.h>
#include <unistd.h>
static long bb_offset;
Modified: grass/trunk/ps/ps.map/ps_info.h
--- grass/trunk/ps/ps.map/ps_info.h 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/ps/ps.map/ps_info.h 2009-06-22 01:49:13 UTC (rev 38014)
@@ -1,5 +1,5 @@
/* Font sizes */
#define PS_FONT_MAX_SIZE 50
Modified: grass/trunk/ps/ps.map/ps_outline.c
--- grass/trunk/ps/ps.map/ps_outline.c 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/ps/ps.map/ps_outline.c 2009-06-22 01:49:13 UTC (rev 38014)
@@ -7,7 +7,7 @@
#include <stdio.h>
#include <string.h>
Modified: grass/trunk/ps/ps.map/ps_raster.c
--- grass/trunk/ps/ps.map/ps_raster.c 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/ps/ps.map/ps_raster.c 2009-06-22 01:49:13 UTC (rev 38014)
@@ -12,7 +12,7 @@
#include <stdlib.h>
#include "group.h"
Modified: grass/trunk/ps/ps.map/ps_vareas.c
--- grass/trunk/ps/ps.map/ps_vareas.c 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/ps/ps.map/ps_vareas.c 2009-06-22 01:49:13 UTC (rev 38014)
@@ -5,7 +5,7 @@
Modified: grass/trunk/ps/ps.map/ps_vlines.c
--- grass/trunk/ps/ps.map/ps_vlines.c 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/ps/ps.map/ps_vlines.c 2009-06-22 01:49:13 UTC (rev 38014)
@@ -6,7 +6,7 @@
Modified: grass/trunk/ps/ps.map/r_group.c
--- grass/trunk/ps/ps.map/r_group.c 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/ps/ps.map/r_group.c 2009-06-22 01:49:13 UTC (rev 38014)
@@ -5,7 +5,7 @@
#include <string.h>
#include "group.h"
Modified: grass/trunk/ps/ps.map/r_labels.c
--- grass/trunk/ps/ps.map/r_labels.c 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/ps/ps.map/r_labels.c 2009-06-22 01:49:13 UTC (rev 38014)
@@ -1,6 +1,6 @@
#include <string.h>
#include "labels.h"
Modified: grass/trunk/ps/ps.map/r_vareas.c
--- grass/trunk/ps/ps.map/r_vareas.c 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/ps/ps.map/r_vareas.c 2009-06-22 01:49:13 UTC (rev 38014)
@@ -9,7 +9,7 @@
#include <stdlib.h>
#include <string.h>
#include "vector.h"
Modified: grass/trunk/ps/ps.map/r_vpoints.c
--- grass/trunk/ps/ps.map/r_vpoints.c 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/ps/ps.map/r_vpoints.c 2009-06-22 01:49:13 UTC (rev 38014)
@@ -10,7 +10,7 @@
#include <stdlib.h>
#include <string.h>
#include "vector.h"
Modified: grass/trunk/ps/ps.map/read_cfg.c
--- grass/trunk/ps/ps.map/read_cfg.c 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/ps/ps.map/read_cfg.c 2009-06-22 01:49:13 UTC (rev 38014)
@@ -13,7 +13,7 @@
#include <stdio.h>
#include <math.h>
#include "paper.h"
Modified: grass/trunk/ps/ps.map/scale.c
--- grass/trunk/ps/ps.map/scale.c 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/ps/ps.map/scale.c 2009-06-22 01:49:13 UTC (rev 38014)
@@ -8,7 +8,7 @@
#include <stdlib.h>
#include <string.h>
Modified: grass/trunk/ps/ps.map/scan_gis.c
--- grass/trunk/ps/ps.map/scan_gis.c 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/ps/ps.map/scan_gis.c 2009-06-22 01:49:13 UTC (rev 38014)
@@ -1,7 +1,7 @@
#include <unistd.h>
#include <string.h>
int scan_gis(char *element, char *desc, char *key, char *data,
Modified: grass/trunk/ps/ps.map/session.c
--- grass/trunk/ps/ps.map/session.c 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/ps/ps.map/session.c 2009-06-22 01:49:13 UTC (rev 38014)
@@ -1,6 +1,6 @@
#include <stdio.h>
static char cur[2000];
Modified: grass/trunk/ps/ps.map/vect.c
--- grass/trunk/ps/ps.map/vect.c 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/ps/ps.map/vect.c 2009-06-22 01:49:13 UTC (rev 38014)
@@ -8,7 +8,7 @@
#include <math.h>
#include "vector.h"
#define LENGTH(DX, DY) ( sqrt( (DX*DX)+(DY*DY) ) )
Modified: grass/trunk/ps/ps.map/vector.c
--- grass/trunk/ps/ps.map/vector.c 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/ps/ps.map/vector.c 2009-06-22 01:49:13 UTC (rev 38014)
@@ -2,7 +2,7 @@
#include <stdio.h>
#include <string.h>
#include "vector.h"
Modified: grass/trunk/raster/r.basins.fill/Makefile
--- grass/trunk/raster/r.basins.fill/Makefile 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/raster/r.basins.fill/Makefile 2009-06-22 01:49:13 UTC (rev 38014)
@@ -2,8 +2,8 @@
PGM = r.basins.fill
-LIBES = $(GISLIB) $(RASTRLIB)
+LIBES = $(GISLIB) $(RASTERLIB)
include $(MODULE_TOPDIR)/include/Make/Module.make
Modified: grass/trunk/raster/r.basins.fill/main.c
--- grass/trunk/raster/r.basins.fill/main.c 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/raster/r.basins.fill/main.c 2009-06-22 01:49:13 UTC (rev 38014)
@@ -27,7 +27,7 @@
#include <string.h>
#include <stdio.h>
Modified: grass/trunk/raster/r.basins.fill/read_map.c
--- grass/trunk/raster/r.basins.fill/read_map.c 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/raster/r.basins.fill/read_map.c 2009-06-22 01:49:13 UTC (rev 38014)
@@ -17,7 +17,7 @@
Modified: grass/trunk/raster/r.bitpattern/Makefile
--- grass/trunk/raster/r.bitpattern/Makefile 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/raster/r.bitpattern/Makefile 2009-06-22 01:49:13 UTC (rev 38014)
@@ -2,8 +2,8 @@
PGM = r.bitpattern
Modified: grass/trunk/raster/r.bitpattern/main.c
--- grass/trunk/raster/r.bitpattern/main.c 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/raster/r.bitpattern/main.c 2009-06-22 01:49:13 UTC (rev 38014)
@@ -36,7 +36,7 @@
#include <stdlib.h>
#include <string.h>
#include <grass/gis.h>
extern CELL f_c(CELL);
Modified: grass/trunk/raster/r.buffer/Makefile
--- grass/trunk/raster/r.buffer/Makefile 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/raster/r.buffer/Makefile 2009-06-22 01:49:13 UTC (rev 38014)
@@ -2,8 +2,8 @@
PGM = r.buffer2
Modified: grass/trunk/raster/r.buffer/distance.h
--- grass/trunk/raster/r.buffer/distance.h 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/raster/r.buffer/distance.h 2009-06-22 01:49:13 UTC (rev 38014)
@@ -23,8 +23,8 @@
#define __DISTANCE_H__
struct Distance
Modified: grass/trunk/raster/r.buffer/find_dist.c
--- grass/trunk/raster/r.buffer/find_dist.c 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/raster/r.buffer/find_dist.c 2009-06-22 01:49:13 UTC (rev 38014)
@@ -20,7 +20,7 @@
#include "distance.h"
Modified: grass/trunk/raster/r.buffer/init.c
--- grass/trunk/raster/r.buffer/init.c 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/raster/r.buffer/init.c 2009-06-22 01:49:13 UTC (rev 38014)
@@ -21,7 +21,7 @@
int init_grass(void)
Modified: grass/trunk/raster/r.carve/Makefile
--- grass/trunk/raster/r.carve/Makefile 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/raster/r.carve/Makefile 2009-06-22 01:49:13 UTC (rev 38014)
@@ -2,8 +2,8 @@
PGM = r.carve
-LIBES = $(SITESLIB) $(VECTLIB) $(DBMILIB) $(BITMAPLIB) $(LINKMLIB) $(SEGMENTLIB) $(GISLIB) $(RASTRLIB)
-DEPENDENCIES = $(VECTDEP) $(DBMIDEP) $(BITMAPDEP) $(LINKMDEP) $(SEGMENTDEP) $(GISDEP) $(RASTRDEP)
+LIBES = $(SITESLIB) $(VECTLIB) $(DBMILIB) $(BITMAPLIB) $(LINKMLIB) $(SEGMENTLIB) $(GISLIB) $(RASTERLIB)
+DEPENDENCIES = $(VECTDEP) $(DBMIDEP) $(BITMAPDEP) $(LINKMDEP) $(SEGMENTDEP) $(GISDEP) $(RASTERDEP)
Modified: grass/trunk/raster/r.carve/enforce.h
--- grass/trunk/raster/r.carve/enforce.h 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/raster/r.carve/enforce.h 2009-06-22 01:49:13 UTC (rev 38014)
@@ -22,7 +22,7 @@
#include <stdio.h>
Modified: grass/trunk/raster/r.carve/enforce_ds.c
--- grass/trunk/raster/r.carve/enforce_ds.c 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/raster/r.carve/enforce_ds.c 2009-06-22 01:49:13 UTC (rev 38014)
@@ -20,7 +20,7 @@
#include <stdio.h>
#include <string.h>
#include "enforce.h"
Modified: grass/trunk/raster/r.carve/main.c
--- grass/trunk/raster/r.carve/main.c 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/raster/r.carve/main.c 2009-06-22 01:49:13 UTC (rev 38014)
@@ -22,7 +22,7 @@
#include <errno.h>
#include <math.h>
Modified: grass/trunk/raster/r.carve/raster.c
--- grass/trunk/raster/r.carve/raster.c 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/raster/r.carve/raster.c 2009-06-22 01:49:13 UTC (rev 38014)
@@ -1,6 +1,6 @@
#include <stdlib.h>
Modified: grass/trunk/raster/r.carve/support.c
--- grass/trunk/raster/r.carve/support.c 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/raster/r.carve/support.c 2009-06-22 01:49:13 UTC (rev 38014)
@@ -20,7 +20,7 @@
#include <string.h>
#include <stdio.h>
Modified: grass/trunk/raster/r.carve/vect.c
--- grass/trunk/raster/r.carve/vect.c 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/raster/r.carve/vect.c 2009-06-22 01:49:13 UTC (rev 38014)
@@ -19,7 +19,7 @@
#include <stdio.h>
Modified: grass/trunk/raster/r.category/Makefile
--- grass/trunk/raster/r.category/Makefile 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/raster/r.category/Makefile 2009-06-22 01:49:13 UTC (rev 38014)
@@ -2,8 +2,8 @@
PGM = r.category
Modified: grass/trunk/raster/r.category/cats.c
--- grass/trunk/raster/r.category/cats.c 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/raster/r.category/cats.c 2009-06-22 01:49:13 UTC (rev 38014)
@@ -18,7 +18,7 @@
#include <stdlib.h>
Modified: grass/trunk/raster/r.category/main.c
--- grass/trunk/raster/r.category/main.c 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/raster/r.category/main.c 2009-06-22 01:49:13 UTC (rev 38014)
@@ -21,7 +21,7 @@
#include <stdio.h>
#include <string.h>
Modified: grass/trunk/raster/r.circle/Makefile
--- grass/trunk/raster/r.circle/Makefile 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/raster/r.circle/Makefile 2009-06-22 01:49:13 UTC (rev 38014)
@@ -2,8 +2,8 @@
PGM = r.circle
Modified: grass/trunk/raster/r.circle/main.c
--- grass/trunk/raster/r.circle/main.c 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/raster/r.circle/main.c 2009-06-22 01:49:13 UTC (rev 38014)
@@ -21,7 +21,7 @@
#include <strings.h>
#include <math.h>
typedef int FILEDESC;
Modified: grass/trunk/raster/r.clump/Makefile
--- grass/trunk/raster/r.clump/Makefile 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/raster/r.clump/Makefile 2009-06-22 01:49:13 UTC (rev 38014)
@@ -2,8 +2,8 @@
PGM = r.clump
Modified: grass/trunk/raster/r.clump/clump.c
--- grass/trunk/raster/r.clump/clump.c 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/raster/r.clump/clump.c 2009-06-22 01:49:13 UTC (rev 38014)
@@ -18,7 +18,7 @@
#include <time.h>
Modified: grass/trunk/raster/r.clump/main.c
--- grass/trunk/raster/r.clump/main.c 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/raster/r.clump/main.c 2009-06-22 01:49:13 UTC (rev 38014)
@@ -19,7 +19,7 @@
#include <stdlib.h>
#include <string.h>
Modified: grass/trunk/raster/r.coin/Makefile
--- grass/trunk/raster/r.coin/Makefile 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/raster/r.coin/Makefile 2009-06-22 01:49:13 UTC (rev 38014)
@@ -2,8 +2,8 @@
PGM = r.coin
Modified: grass/trunk/raster/r.coin/coin.h
--- grass/trunk/raster/r.coin/coin.h 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/raster/r.coin/coin.h 2009-06-22 01:49:13 UTC (rev 38014)
@@ -20,8 +20,8 @@
#define __COIN_H__
struct stats_table
Modified: grass/trunk/raster/r.coin/main.c
--- grass/trunk/raster/r.coin/main.c 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/raster/r.coin/main.c 2009-06-22 01:49:13 UTC (rev 38014)
@@ -19,7 +19,7 @@
#include <stdlib.h>
#include <string.h>
#include "coin.h"
Modified: grass/trunk/raster/r.coin/make_coin.c
--- grass/trunk/raster/r.coin/make_coin.c 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/raster/r.coin/make_coin.c 2009-06-22 01:49:13 UTC (rev 38014)
@@ -20,7 +20,7 @@
#include <stdlib.h>
#include "coin.h"
static int cmp(const void *, const void *);
Modified: grass/trunk/raster/r.colors/Makefile
--- grass/trunk/raster/r.colors/Makefile 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/raster/r.colors/Makefile 2009-06-22 01:49:13 UTC (rev 38014)
@@ -2,8 +2,8 @@
PGM = r.colors
Modified: grass/trunk/raster/r.colors/local_proto.h
--- grass/trunk/raster/r.colors/local_proto.h 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/raster/r.colors/local_proto.h 2009-06-22 01:49:13 UTC (rev 38014)
@@ -21,7 +21,7 @@
#define __LOCAL_PROTO_H__
/* stats.c */
int get_stats(const char *, const char *, struct Cell_stats *);
Modified: grass/trunk/raster/r.colors/main.c
--- grass/trunk/raster/r.colors/main.c 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/raster/r.colors/main.c 2009-06-22 01:49:13 UTC (rev 38014)
@@ -26,7 +26,7 @@
#include <string.h>
Modified: grass/trunk/raster/r.colors/rules.c
--- grass/trunk/raster/r.colors/rules.c 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/raster/r.colors/rules.c 2009-06-22 01:49:13 UTC (rev 38014)
@@ -22,7 +22,7 @@
#include <unistd.h>
#include <string.h>
Modified: grass/trunk/raster/r.colors/stats.c
--- grass/trunk/raster/r.colors/stats.c 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/raster/r.colors/stats.c 2009-06-22 01:49:13 UTC (rev 38014)
@@ -20,7 +20,7 @@
#include <math.h>
#include <stdlib.h>
Modified: grass/trunk/raster/r.colors.out/Makefile
--- grass/trunk/raster/r.colors.out/Makefile 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/raster/r.colors.out/Makefile 2009-06-22 01:49:13 UTC (rev 38014)
@@ -2,8 +2,8 @@
PGM = r.colors.out
Modified: grass/trunk/raster/r.colors.out/main.c
--- grass/trunk/raster/r.colors.out/main.c 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/raster/r.colors.out/main.c 2009-06-22 01:49:13 UTC (rev 38014)
@@ -18,7 +18,7 @@
#include <stdlib.h>
#include <string.h>
static FILE *fp;
Modified: grass/trunk/raster/r.composite/Makefile
--- grass/trunk/raster/r.composite/Makefile 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/raster/r.composite/Makefile 2009-06-22 01:49:13 UTC (rev 38014)
@@ -2,8 +2,8 @@
PGM = r.composite
Modified: grass/trunk/raster/r.composite/main.c
--- grass/trunk/raster/r.composite/main.c 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/raster/r.composite/main.c 2009-06-22 01:49:13 UTC (rev 38014)
@@ -20,7 +20,7 @@
#include <string.h>
struct band
Modified: grass/trunk/raster/r.compress/Makefile
--- grass/trunk/raster/r.compress/Makefile 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/raster/r.compress/Makefile 2009-06-22 01:49:13 UTC (rev 38014)
@@ -2,8 +2,8 @@
PGM = r.compress
Modified: grass/trunk/raster/r.compress/main.c
--- grass/trunk/raster/r.compress/main.c 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/raster/r.compress/main.c 2009-06-22 01:49:13 UTC (rev 38014)
@@ -40,7 +40,7 @@
#include <unistd.h>
static off_t newsize, oldsize;
Modified: grass/trunk/raster/r.contour/Makefile
--- grass/trunk/raster/r.contour/Makefile 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/raster/r.contour/Makefile 2009-06-22 01:49:13 UTC (rev 38014)
@@ -3,8 +3,8 @@
PGM=r.contour
-LIBES = $(VECTLIB) $(DBMILIB) $(GISLIB) $(RASTRLIB)
-DEPENDENCIES = $(VECTDEP) $(DBMIDEP) $(GISDEP) $(RASTRDEP)
+LIBES = $(VECTLIB) $(DBMILIB) $(GISLIB) $(RASTERLIB)
+DEPENDENCIES = $(VECTDEP) $(DBMIDEP) $(GISDEP) $(RASTERDEP)
Modified: grass/trunk/raster/r.contour/cont.c
--- grass/trunk/raster/r.contour/cont.c 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/raster/r.contour/cont.c 2009-06-22 01:49:13 UTC (rev 38014)
@@ -26,7 +26,7 @@
#include <stdio.h>
#include <math.h>
Modified: grass/trunk/raster/r.contour/main.c
--- grass/trunk/raster/r.contour/main.c 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/raster/r.contour/main.c 2009-06-22 01:49:13 UTC (rev 38014)
@@ -45,7 +45,7 @@
#include <ctype.h>
#include <float.h>
Modified: grass/trunk/raster/r.cost/Makefile
--- grass/trunk/raster/r.cost/Makefile 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/raster/r.cost/Makefile 2009-06-22 01:49:13 UTC (rev 38014)
@@ -2,8 +2,8 @@
PGM = r.cost
-LIBES = $(SITESLIB) $(VECTLIB) $(GISLIB) $(RASTRLIB) $(SEGMENTLIB) $(DATETIMELIB)
-DEPENDENCIES = $(VECTDEP) $(GISDEP) $(RASTRDEP) $(SEGMENTDEP) $(DATETIMEDEP)
+LIBES = $(SITESLIB) $(VECTLIB) $(GISLIB) $(RASTERLIB) $(SEGMENTLIB) $(DATETIMELIB)
+DEPENDENCIES = $(VECTDEP) $(GISDEP) $(RASTERDEP) $(SEGMENTDEP) $(DATETIMEDEP)
Modified: grass/trunk/raster/r.cost/btree.c
--- grass/trunk/raster/r.cost/btree.c 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/raster/r.cost/btree.c 2009-06-22 01:49:13 UTC (rev 38014)
@@ -38,7 +38,7 @@
#include "memory.h"
#include <stdlib.h>
Modified: grass/trunk/raster/r.cost/main.c
--- grass/trunk/raster/r.cost/main.c 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/raster/r.cost/main.c 2009-06-22 01:49:13 UTC (rev 38014)
@@ -61,7 +61,7 @@
#include <sys/stat.h>
#include <fcntl.h>
#include <grass/segment.h>
#include "cost.h"
Modified: grass/trunk/raster/r.cost/memory.c
--- grass/trunk/raster/r.cost/memory.c 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/raster/r.cost/memory.c 2009-06-22 01:49:13 UTC (rev 38014)
@@ -26,7 +26,7 @@
#include <string.h>
#include <errno.h>
#include "memory.h"
#define NUM_IN_BLOCK 1024*8
Modified: grass/trunk/raster/r.covar/Makefile
--- grass/trunk/raster/r.covar/Makefile 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/raster/r.covar/Makefile 2009-06-22 01:49:13 UTC (rev 38014)
@@ -2,8 +2,8 @@
PGM = r.covar
Modified: grass/trunk/raster/r.covar/main.c
--- grass/trunk/raster/r.covar/main.c 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/raster/r.covar/main.c 2009-06-22 01:49:13 UTC (rev 38014)
@@ -21,7 +21,7 @@
#include <string.h>
#include <math.h>
Modified: grass/trunk/raster/r.cross/Makefile
--- grass/trunk/raster/r.cross/Makefile 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/raster/r.cross/Makefile 2009-06-22 01:49:13 UTC (rev 38014)
@@ -2,8 +2,8 @@
PGM = r.cross
Modified: grass/trunk/raster/r.cross/glob.h
--- grass/trunk/raster/r.cross/glob.h 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/raster/r.cross/glob.h 2009-06-22 01:49:13 UTC (rev 38014)
@@ -20,8 +20,8 @@
#define __R_CROSS_GLOB_H__
#define NFILES 30 /* maximum number of layers */
#define SHIFT 6 /* 2^SHIFT cats per node */
Modified: grass/trunk/raster/r.describe/Makefile
--- grass/trunk/raster/r.describe/Makefile 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/raster/r.describe/Makefile 2009-06-22 01:49:13 UTC (rev 38014)
@@ -2,8 +2,8 @@
PGM = r.describe
Modified: grass/trunk/raster/r.describe/describe.c
--- grass/trunk/raster/r.describe/describe.c 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/raster/r.describe/describe.c 2009-06-22 01:49:13 UTC (rev 38014)
@@ -17,7 +17,7 @@
Modified: grass/trunk/raster/r.describe/dumplist.c
--- grass/trunk/raster/r.describe/dumplist.c 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/raster/r.describe/dumplist.c 2009-06-22 01:49:13 UTC (rev 38014)
@@ -18,7 +18,7 @@
#include <string.h>
static int show(CELL, CELL, int *, DCELL, DCELL, RASTER_MAP_TYPE, int);
Modified: grass/trunk/raster/r.describe/main.c
--- grass/trunk/raster/r.describe/main.c 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/raster/r.describe/main.c 2009-06-22 01:49:13 UTC (rev 38014)
@@ -20,7 +20,7 @@
#include <string.h>
#include <stdio.h>
Modified: grass/trunk/raster/r.describe/tree.c
--- grass/trunk/raster/r.describe/tree.c 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/raster/r.describe/tree.c 2009-06-22 01:49:13 UTC (rev 38014)
@@ -17,7 +17,7 @@
#define INCR 10
Modified: grass/trunk/raster/r.distance/Makefile
--- grass/trunk/raster/r.distance/Makefile 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/raster/r.distance/Makefile 2009-06-22 01:49:13 UTC (rev 38014)
@@ -2,8 +2,8 @@
PGM = r.distance
Modified: grass/trunk/raster/r.distance/defs.h
--- grass/trunk/raster/r.distance/defs.h 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/raster/r.distance/defs.h 2009-06-22 01:49:13 UTC (rev 38014)
@@ -20,7 +20,7 @@
#define __R_DIST_DEFS_H__
struct EdgeList /* keep track of edge cells */
Modified: grass/trunk/raster/r.distance/main.c
--- grass/trunk/raster/r.distance/main.c 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/raster/r.distance/main.c 2009-06-22 01:49:13 UTC (rev 38014)
@@ -20,7 +20,7 @@
#include <stdio.h>
#include "defs.h"
int main(int argc, char *argv[])
Modified: grass/trunk/raster/r.distance/parse.c
--- grass/trunk/raster/r.distance/parse.c 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/raster/r.distance/parse.c 2009-06-22 01:49:13 UTC (rev 38014)
@@ -20,7 +20,7 @@
#include <stdio.h>
#include "defs.h"
void parse(int argc, char *argv[], struct Parms *parms)
Modified: grass/trunk/raster/r.drain/Makefile
--- grass/trunk/raster/r.drain/Makefile 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/raster/r.drain/Makefile 2009-06-22 01:49:13 UTC (rev 38014)
@@ -2,8 +2,8 @@
PGM = r.drain
Modified: grass/trunk/raster/r.drain/filldir.c
--- grass/trunk/raster/r.drain/filldir.c 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/raster/r.drain/filldir.c 2009-06-22 01:49:13 UTC (rev 38014)
@@ -3,7 +3,7 @@
#include <limits.h>
#include <float.h>
#include "tinf.h"
#include "local.h"
Modified: grass/trunk/raster/r.drain/main.c
--- grass/trunk/raster/r.drain/main.c 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/raster/r.drain/main.c 2009-06-22 01:49:13 UTC (rev 38014)
@@ -40,7 +40,7 @@
#include <unistd.h>
Modified: grass/trunk/raster/r.drain/resolve.c
--- grass/trunk/raster/r.drain/resolve.c 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/raster/r.drain/resolve.c 2009-06-22 01:49:13 UTC (rev 38014)
@@ -1,7 +1,7 @@
#include <stdlib.h>
#include <string.h>
#include "tinf.h"
CELL select_dir(CELL i)
Modified: grass/trunk/raster/r.drain/tinf.c
--- grass/trunk/raster/r.drain/tinf.c 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/raster/r.drain/tinf.c 2009-06-22 01:49:13 UTC (rev 38014)
@@ -2,7 +2,7 @@
#include <float.h>
#include <math.h>
#include "tinf.h"
int (*is_null) (void *);
Modified: grass/trunk/raster/r.external/Makefile
--- grass/trunk/raster/r.external/Makefile 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/raster/r.external/Makefile 2009-06-22 01:49:13 UTC (rev 38014)
@@ -2,8 +2,8 @@
PGM = r.external
-LIBES= $(GPROJLIB) $(GISLIB) $(RASTRLIB) $(IMAGERYLIB) $(GDALLIBS) $(GMATHLIB)
-DEPENDENCIES = $(GPROJDEP) $(GISDEP) $(RASTRDEP) $(IMAGERYDEP) $(GMATHDEP)
+LIBES= $(GPROJLIB) $(GISLIB) $(RASTERLIB) $(IMAGERYLIB) $(GDALLIBS) $(GMATHLIB)
+DEPENDENCIES = $(GPROJDEP) $(GISDEP) $(RASTERDEP) $(IMAGERYDEP) $(GMATHDEP)
EXTRA_INC = $(PROJINC) $(GDALCFLAGS)
Modified: grass/trunk/raster/r.external/main.c
--- grass/trunk/raster/r.external/main.c 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/raster/r.external/main.c 2009-06-22 01:49:13 UTC (rev 38014)
@@ -20,7 +20,7 @@
#include <math.h>
#include <string.h>
#include <grass/imagery.h>
Modified: grass/trunk/raster/r.fill.dir/Makefile
--- grass/trunk/raster/r.fill.dir/Makefile 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/raster/r.fill.dir/Makefile 2009-06-22 01:49:13 UTC (rev 38014)
@@ -2,8 +2,8 @@
PGM = r.fill.dir
Modified: grass/trunk/raster/r.fill.dir/dopolys.c
--- grass/trunk/raster/r.fill.dir/dopolys.c 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/raster/r.fill.dir/dopolys.c 2009-06-22 01:49:13 UTC (rev 38014)
@@ -1,7 +1,7 @@
#include <unistd.h>
#include <stdlib.h>
void recurse_list(int flag, int *cells, int sz, int start)
Modified: grass/trunk/raster/r.fill.dir/filldir.c
--- grass/trunk/raster/r.fill.dir/filldir.c 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/raster/r.fill.dir/filldir.c 2009-06-22 01:49:13 UTC (rev 38014)
@@ -5,7 +5,7 @@
#include <limits.h>
#include <float.h>
#include "tinf.h"
/* get the slope between two cells and return a slope direction */
Modified: grass/trunk/raster/r.fill.dir/main.c
--- grass/trunk/raster/r.fill.dir/main.c 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/raster/r.fill.dir/main.c 2009-06-22 01:49:13 UTC (rev 38014)
@@ -48,7 +48,7 @@
#include <unistd.h>
#define DEBUG
Modified: grass/trunk/raster/r.fill.dir/ppupdate.c
--- grass/trunk/raster/r.fill.dir/ppupdate.c 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/raster/r.fill.dir/ppupdate.c 2009-06-22 01:49:13 UTC (rev 38014)
@@ -1,7 +1,7 @@
#include <stdlib.h>
#include <string.h>
#include "tinf.h"
struct links
Modified: grass/trunk/raster/r.fill.dir/resolve.c
--- grass/trunk/raster/r.fill.dir/resolve.c 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/raster/r.fill.dir/resolve.c 2009-06-22 01:49:13 UTC (rev 38014)
@@ -1,7 +1,7 @@
#include <stdlib.h>
#include <string.h>
#include "tinf.h"
Modified: grass/trunk/raster/r.fill.dir/tinf.c
--- grass/trunk/raster/r.fill.dir/tinf.c 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/raster/r.fill.dir/tinf.c 2009-06-22 01:49:13 UTC (rev 38014)
@@ -2,7 +2,7 @@
#include <float.h>
#include <math.h>
#include "tinf.h"
/* To add a new multitype function, use the function below to initialize
Modified: grass/trunk/raster/r.fill.dir/wtrshed.c
--- grass/trunk/raster/r.fill.dir/wtrshed.c 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/raster/r.fill.dir/wtrshed.c 2009-06-22 01:49:13 UTC (rev 38014)
@@ -2,7 +2,7 @@
#include <stdlib.h>
struct whereandwhat
Modified: grass/trunk/raster/r.flow/Makefile
--- grass/trunk/raster/r.flow/Makefile 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/raster/r.flow/Makefile 2009-06-22 01:49:13 UTC (rev 38014)
@@ -2,8 +2,8 @@
PGM=r.flow
-LIBES = $(VECTLIB) $(DBMILIB) $(BITMAPLIB) $(LINKMLIB) $(SEGMENTLIB) $(GISLIB) $(RASTRLIB)
+LIBES = $(VECTLIB) $(DBMILIB) $(BITMAPLIB) $(LINKMLIB) $(SEGMENTLIB) $(GISLIB) $(RASTERLIB)
Modified: grass/trunk/raster/r.flow/aspect.c
--- grass/trunk/raster/r.flow/aspect.c 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/raster/r.flow/aspect.c 2009-06-22 01:49:13 UTC (rev 38014)
@@ -26,7 +26,7 @@
#include <math.h>
#include "r.flow.h"
Modified: grass/trunk/raster/r.flow/aspect.h
--- grass/trunk/raster/r.flow/aspect.h 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/raster/r.flow/aspect.h 2009-06-22 01:49:13 UTC (rev 38014)
@@ -1,5 +1,5 @@
* aspect_fly: calculates aspect on the fly based on elevation map in z
Modified: grass/trunk/raster/r.flow/io.h
--- grass/trunk/raster/r.flow/io.h 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/raster/r.flow/io.h 2009-06-22 01:49:13 UTC (rev 38014)
@@ -1,5 +1,5 @@
/********************************* I/O **********************************/
Modified: grass/trunk/raster/r.flow/main.c
--- grass/trunk/raster/r.flow/main.c 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/raster/r.flow/main.c 2009-06-22 01:49:13 UTC (rev 38014)
@@ -29,7 +29,7 @@
#include <stdlib.h> /* for the random number generation */
#include <time.h>
#include "r.flow.h"
#include "mem.h"
Modified: grass/trunk/raster/r.flow/mem.c
--- grass/trunk/raster/r.flow/mem.c 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/raster/r.flow/mem.c 2009-06-22 01:49:13 UTC (rev 38014)
@@ -25,7 +25,7 @@
#include "r.flow.h"
#include "io.h"
Modified: grass/trunk/raster/r.flow/mem.h
--- grass/trunk/raster/r.flow/mem.h 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/raster/r.flow/mem.h 2009-06-22 01:49:13 UTC (rev 38014)
@@ -2,7 +2,7 @@
/************************** MEMORY MANAGEMENT ***************************/
#define KB 1024
#define MB (KB * KB)
#define SEGSINMEM 9
Modified: grass/trunk/raster/r.flow/precomp.c
--- grass/trunk/raster/r.flow/precomp.c 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/raster/r.flow/precomp.c 2009-06-22 01:49:13 UTC (rev 38014)
@@ -25,7 +25,7 @@
#include "r.flow.h"
#include "io.h"
Modified: grass/trunk/raster/r.flow/r.flow.h
--- grass/trunk/raster/r.flow/r.flow.h 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/raster/r.flow/r.flow.h 2009-06-22 01:49:13 UTC (rev 38014)
@@ -32,7 +32,7 @@
#include <math.h>
Modified: grass/trunk/raster/r.grow.distance/Makefile
--- grass/trunk/raster/r.grow.distance/Makefile 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/raster/r.grow.distance/Makefile 2009-06-22 01:49:13 UTC (rev 38014)
@@ -2,8 +2,8 @@
PGM = r.grow.distance
-LIBES = $(GISLIB) $(RASTRLIB) $(MATHLIB)
+LIBES = $(GISLIB) $(RASTERLIB) $(MATHLIB)
Modified: grass/trunk/raster/r.grow.distance/main.c
--- grass/trunk/raster/r.grow.distance/main.c 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/raster/r.grow.distance/main.c 2009-06-22 01:49:13 UTC (rev 38014)
@@ -24,7 +24,7 @@
#include <unistd.h>
#include <fcntl.h>
static struct Cell_head window;
Modified: grass/trunk/raster/r.gwflow/main.c
--- grass/trunk/raster/r.gwflow/main.c 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/raster/r.gwflow/main.c 2009-06-22 01:49:13 UTC (rev 38014)
@@ -20,7 +20,7 @@
#include <string.h>
#include <math.h>
#include <grass/N_gwflow.h>
Modified: grass/trunk/raster/r.his/Makefile
--- grass/trunk/raster/r.his/Makefile 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/raster/r.his/Makefile 2009-06-22 01:49:13 UTC (rev 38014)
@@ -2,8 +2,8 @@
PGM = r.his
Modified: grass/trunk/raster/r.his/his.c
--- grass/trunk/raster/r.his/his.c 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/raster/r.his/his.c 2009-06-22 01:49:13 UTC (rev 38014)
@@ -1,6 +1,6 @@
#include "his.h"
Modified: grass/trunk/raster/r.his/main.c
--- grass/trunk/raster/r.his/main.c 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/raster/r.his/main.c 2009-06-22 01:49:13 UTC (rev 38014)
@@ -17,7 +17,7 @@
#include <stdio.h>
#include <string.h>
#include "his.h"
Modified: grass/trunk/raster/r.horizon/Makefile
--- grass/trunk/raster/r.horizon/Makefile 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/raster/r.horizon/Makefile 2009-06-22 01:49:13 UTC (rev 38014)
@@ -2,8 +2,8 @@
PGM = r.horizon
-LIBES = $(GPROJLIB) $(GISLIB) $(RASTRLIB)
+LIBES = $(GPROJLIB) $(GISLIB) $(RASTERLIB)
Modified: grass/trunk/raster/r.horizon/main.c
--- grass/trunk/raster/r.horizon/main.c 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/raster/r.horizon/main.c 2009-06-22 01:49:13 UTC (rev 38014)
@@ -35,7 +35,7 @@
#include <string.h>
#include <math.h>
Modified: grass/trunk/raster/r.in.arc/Makefile
--- grass/trunk/raster/r.in.arc/Makefile 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/raster/r.in.arc/Makefile 2009-06-22 01:49:13 UTC (rev 38014)
@@ -2,8 +2,8 @@
PGM = r.in.arc
Modified: grass/trunk/raster/r.in.arc/gethead.c
--- grass/trunk/raster/r.in.arc/gethead.c 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/raster/r.in.arc/gethead.c 2009-06-22 01:49:13 UTC (rev 38014)
@@ -1,7 +1,7 @@
#include <string.h>
#include <ctype.h>
Modified: grass/trunk/raster/r.in.arc/main.c
--- grass/trunk/raster/r.in.arc/main.c 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/raster/r.in.arc/main.c 2009-06-22 01:49:13 UTC (rev 38014)
@@ -22,7 +22,7 @@
#include <unistd.h>
#endif
#include <grass/glocale.h>
Modified: grass/trunk/raster/r.in.ascii/Makefile
--- grass/trunk/raster/r.in.ascii/Makefile 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/raster/r.in.ascii/Makefile 2009-06-22 01:49:13 UTC (rev 38014)
@@ -2,8 +2,8 @@
PGM = r.in.ascii
Modified: grass/trunk/raster/r.in.ascii/gethead.c
--- grass/trunk/raster/r.in.ascii/gethead.c 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/raster/r.in.ascii/gethead.c 2009-06-22 01:49:13 UTC (rev 38014)
@@ -2,7 +2,7 @@
#include <string.h>
#include <math.h>
Modified: grass/trunk/raster/r.in.ascii/main.c
--- grass/trunk/raster/r.in.ascii/main.c 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/raster/r.in.ascii/main.c 2009-06-22 01:49:13 UTC (rev 38014)
@@ -21,7 +21,7 @@
#include <stdlib.h>
#include <string.h>
Modified: grass/trunk/raster/r.in.bin/Makefile
--- grass/trunk/raster/r.in.bin/Makefile 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/raster/r.in.bin/Makefile 2009-06-22 01:49:13 UTC (rev 38014)
@@ -2,8 +2,8 @@
PGM = r.in.bin
Modified: grass/trunk/raster/r.in.bin/main.c
--- grass/trunk/raster/r.in.bin/main.c 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/raster/r.in.bin/main.c 2009-06-22 01:49:13 UTC (rev 38014)
@@ -14,7 +14,7 @@
#include <unistd.h>
#include "gmt_grd.h"
Modified: grass/trunk/raster/r.in.gdal/Makefile
--- grass/trunk/raster/r.in.gdal/Makefile 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/raster/r.in.gdal/Makefile 2009-06-22 01:49:13 UTC (rev 38014)
@@ -2,8 +2,8 @@
PGM = r.in.gdal
Modified: grass/trunk/raster/r.in.gdal/main.c
--- grass/trunk/raster/r.in.gdal/main.c 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/raster/r.in.gdal/main.c 2009-06-22 01:49:13 UTC (rev 38014)
@@ -22,7 +22,7 @@
#include <math.h>
#include <string.h>
Modified: grass/trunk/raster/r.in.gridatb/Makefile
--- grass/trunk/raster/r.in.gridatb/Makefile 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/raster/r.in.gridatb/Makefile 2009-06-22 01:49:13 UTC (rev 38014)
@@ -2,8 +2,8 @@
PGM = r.in.gridatb
Modified: grass/trunk/raster/r.in.gridatb/file_io.c
--- grass/trunk/raster/r.in.gridatb/file_io.c 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/raster/r.in.gridatb/file_io.c 2009-06-22 01:49:13 UTC (rev 38014)
@@ -1,6 +1,6 @@
#include <stdlib.h>
Modified: grass/trunk/raster/r.in.gridatb/local_proto.h
--- grass/trunk/raster/r.in.gridatb/local_proto.h 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/raster/r.in.gridatb/local_proto.h 2009-06-22 01:49:13 UTC (rev 38014)
@@ -1,6 +1,6 @@
#include <stdio.h>
int check_ready(void);
int adjcellhd(struct Cell_head *cellhd);
Modified: grass/trunk/raster/r.in.gridatb/main.c
--- grass/trunk/raster/r.in.gridatb/main.c 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/raster/r.in.gridatb/main.c 2009-06-22 01:49:13 UTC (rev 38014)
@@ -19,7 +19,7 @@
struct Cell_head cellhd;
Modified: grass/trunk/raster/r.in.mat/Makefile
--- grass/trunk/raster/r.in.mat/Makefile 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/raster/r.in.mat/Makefile 2009-06-22 01:49:13 UTC (rev 38014)
@@ -2,8 +2,8 @@
PGM = r.in.mat
Modified: grass/trunk/raster/r.in.mat/main.c
--- grass/trunk/raster/r.in.mat/main.c 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/raster/r.in.mat/main.c 2009-06-22 01:49:13 UTC (rev 38014)
@@ -36,7 +36,7 @@
#include <stdlib.h>
#include <string.h>
/* typedef unsigned short uint16;
Modified: grass/trunk/raster/r.in.poly/Makefile
--- grass/trunk/raster/r.in.poly/Makefile 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/raster/r.in.poly/Makefile 2009-06-22 01:49:13 UTC (rev 38014)
@@ -2,8 +2,8 @@
PGM = r.in.poly
Modified: grass/trunk/raster/r.in.poly/get_item.c
--- grass/trunk/raster/r.in.poly/get_item.c 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/raster/r.in.poly/get_item.c 2009-06-22 01:49:13 UTC (rev 38014)
@@ -1,5 +1,5 @@
int get_item(FILE * fd, int *type, long *cat, double **x, double **y,
int *count, struct Categories *labels)
Modified: grass/trunk/raster/r.in.poly/getformat.c
--- grass/trunk/raster/r.in.poly/getformat.c 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/raster/r.in.poly/getformat.c 2009-06-22 01:49:13 UTC (rev 38014)
@@ -1,5 +1,5 @@
-#include <grass/Rast.h>
+#include <grass/raster.h>
#include "format.h"
int getformat(FILE * fd)
Modified: grass/trunk/raster/r.in.poly/main.c
--- grass/trunk/raster/r.in.poly/main.c 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/raster/r.in.poly/main.c 2009-06-22 01:49:13 UTC (rev 38014)
@@ -13,7 +13,7 @@
#include <stdlib.h>
Modified: grass/trunk/raster/r.in.poly/poly2rast.c
--- grass/trunk/raster/r.in.poly/poly2rast.c 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/raster/r.in.poly/poly2rast.c 2009-06-22 01:49:13 UTC (rev 38014)
@@ -1,7 +1,7 @@
#include <stdlib.h>
#include <string.h>
#include "format.h"
Modified: grass/trunk/raster/r.in.poly/raster.c
--- grass/trunk/raster/r.in.poly/raster.c 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/raster/r.in.poly/raster.c 2009-06-22 01:49:13 UTC (rev 38014)
@@ -1,5 +1,5 @@
#include "format.h"
Modified: grass/trunk/raster/r.in.xyz/Makefile
--- grass/trunk/raster/r.in.xyz/Makefile 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/raster/r.in.xyz/Makefile 2009-06-22 01:49:13 UTC (rev 38014)
@@ -2,8 +2,8 @@
PGM = r.in.xyz
Modified: grass/trunk/raster/r.in.xyz/local_proto.h
--- grass/trunk/raster/r.in.xyz/local_proto.h 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/raster/r.in.xyz/local_proto.h 2009-06-22 01:49:13 UTC (rev 38014)
@@ -19,7 +19,7 @@
#define BUFFSIZE 256
Modified: grass/trunk/raster/r.in.xyz/main.c
--- grass/trunk/raster/r.in.xyz/main.c 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/raster/r.in.xyz/main.c 2009-06-22 01:49:13 UTC (rev 38014)
@@ -22,7 +22,7 @@
#include <math.h>
#include <sys/types.h>
Modified: grass/trunk/raster/r.in.xyz/support.c
--- grass/trunk/raster/r.in.xyz/support.c 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/raster/r.in.xyz/support.c 2009-06-22 01:49:13 UTC (rev 38014)
@@ -9,7 +9,7 @@
static void *get_cell_ptr(void *array, int cols, int row, int col,
Modified: grass/trunk/raster/r.info/Makefile
--- grass/trunk/raster/r.info/Makefile 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/raster/r.info/Makefile 2009-06-22 01:49:13 UTC (rev 38014)
@@ -2,8 +2,8 @@
PGM = r.info
Modified: grass/trunk/raster/r.info/main.c
--- grass/trunk/raster/r.info/main.c 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/raster/r.info/main.c 2009-06-22 01:49:13 UTC (rev 38014)
@@ -20,7 +20,7 @@
#include <string.h>
#include <stdarg.h>
Modified: grass/trunk/raster/r.info/reclas_txt.c
--- grass/trunk/raster/r.info/reclas_txt.c 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/raster/r.info/reclas_txt.c 2009-06-22 01:49:13 UTC (rev 38014)
@@ -1,6 +1,6 @@
#include <string.h>
Modified: grass/trunk/raster/r.kappa/Makefile
--- grass/trunk/raster/r.kappa/Makefile 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/raster/r.kappa/Makefile 2009-06-22 01:49:13 UTC (rev 38014)
@@ -2,8 +2,8 @@
PGM = r.kappa
Modified: grass/trunk/raster/r.kappa/calc_kappa.c
--- grass/trunk/raster/r.kappa/calc_kappa.c 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/raster/r.kappa/calc_kappa.c 2009-06-22 01:49:13 UTC (rev 38014)
@@ -1,6 +1,6 @@
#include <stdlib.h>
#include "kappa.h"
Modified: grass/trunk/raster/r.kappa/kappa.h
--- grass/trunk/raster/r.kappa/kappa.h 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/raster/r.kappa/kappa.h 2009-06-22 01:49:13 UTC (rev 38014)
@@ -1,6 +1,6 @@
#include <math.h>
struct _gstats_
Modified: grass/trunk/raster/r.kappa/main.c
--- grass/trunk/raster/r.kappa/main.c 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/raster/r.kappa/main.c 2009-06-22 01:49:13 UTC (rev 38014)
@@ -24,7 +24,7 @@
#include <stdio.h>
#include <string.h>
#include "kappa.h"
Modified: grass/trunk/raster/r.kappa/prt_mat.c
--- grass/trunk/raster/r.kappa/prt_mat.c 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/raster/r.kappa/prt_mat.c 2009-06-22 01:49:13 UTC (rev 38014)
@@ -1,6 +1,6 @@
#include <stdlib.h>
#include "kappa.h"
Modified: grass/trunk/raster/r.kappa/stats.c
--- grass/trunk/raster/r.kappa/stats.c 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/raster/r.kappa/stats.c 2009-06-22 01:49:13 UTC (rev 38014)
@@ -2,7 +2,7 @@
#include <string.h>
#include <unistd.h>
#include "kappa.h"
Modified: grass/trunk/raster/r.lake/Makefile
--- grass/trunk/raster/r.lake/Makefile 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/raster/r.lake/Makefile 2009-06-22 01:49:13 UTC (rev 38014)
@@ -4,8 +4,8 @@
PGM = r.lake
Modified: grass/trunk/raster/r.lake/main.c
--- grass/trunk/raster/r.lake/main.c 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/raster/r.lake/main.c 2009-06-22 01:49:13 UTC (rev 38014)
@@ -36,7 +36,7 @@
#include <stdlib.h>
/* Saves map file from 2d array. NULL must be 0. Also meanwhile calculates area and volume. */
Modified: grass/trunk/raster/r.le/r.le.patch/patch.h
--- grass/trunk/raster/r.le/r.le.patch/patch.h 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/raster/r.le/r.le.patch/patch.h 2009-06-22 01:49:13 UTC (rev 38014)
@@ -32,7 +32,7 @@
#include <stdlib.h>
#include <string.h>
#define SML 0.5
#define MIN 2
Modified: grass/trunk/raster/r.le/r.le.pixel/pixel.h
--- grass/trunk/raster/r.le/r.le.pixel/pixel.h 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/raster/r.le/r.le.pixel/pixel.h 2009-06-22 01:49:13 UTC (rev 38014)
@@ -26,7 +26,7 @@
#include <stdlib.h>
#include <string.h>
#define BIG 1000000000.0
#define MAX 800
Modified: grass/trunk/raster/r.le/r.le.setup/setup.h
--- grass/trunk/raster/r.le/r.le.setup/setup.h 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/raster/r.le/r.le.setup/setup.h 2009-06-22 01:49:13 UTC (rev 38014)
@@ -28,7 +28,7 @@
#include "stdlib.h"
#include "string.h"
#include "sys/types.h"
Modified: grass/trunk/raster/r.le/r.le.trace/r.le.trace.h
--- grass/trunk/raster/r.le/r.le.trace/r.le.trace.h 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/raster/r.le/r.le.trace/r.le.trace.h 2009-06-22 01:49:13 UTC (rev 38014)
@@ -26,7 +26,7 @@
#include "stdlib.h"
#include "string.h"
#define EQ(a, b) (a-b < 0.01 && a-b > -0.01 )
#define BIG 500000000.0
Modified: grass/trunk/raster/r.li/r.li.cwed/Makefile
--- grass/trunk/raster/r.li/r.li.cwed/Makefile 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/raster/r.li/r.li.cwed/Makefile 2009-06-22 01:49:13 UTC (rev 38014)
@@ -8,9 +8,9 @@
RLI_LIB = -l$(LIB_NAME)
-LIBES = $(GISLIB) $(RASTRLIB) $(RLI_LIB)
+LIBES = $(GISLIB) $(RASTERLIB) $(RLI_LIB)
-DEPENDENCIES = $(GISDEP) $(RASTRDEP) $(LIB_NAME )
+DEPENDENCIES = $(GISDEP) $(RASTERDEP) $(LIB_NAME )
Modified: grass/trunk/raster/r.li/r.li.cwed/cwed.c
--- grass/trunk/raster/r.li/r.li.cwed/cwed.c 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/raster/r.li/r.li.cwed/cwed.c 2009-06-22 01:49:13 UTC (rev 38014)
@@ -12,7 +12,7 @@
#include <fcntl.h> /* for O_RDONLY usage */
Modified: grass/trunk/raster/r.li/r.li.cwed/utility.c
--- grass/trunk/raster/r.li/r.li.cwed/utility.c 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/raster/r.li/r.li.cwed/utility.c 2009-06-22 01:49:13 UTC (rev 38014)
@@ -10,7 +10,7 @@
#include <string.h>
Modified: grass/trunk/raster/r.li/r.li.daemon/GenericCell.h
--- grass/trunk/raster/r.li/r.li.daemon/GenericCell.h 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/raster/r.li/r.li.daemon/GenericCell.h 2009-06-22 01:49:13 UTC (rev 38014)
@@ -9,7 +9,7 @@
#ifndef GENERICCELL_H
Modified: grass/trunk/raster/r.li/r.li.daemon/avl.c
--- grass/trunk/raster/r.li/r.li.daemon/avl.c 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/raster/r.li/r.li.daemon/avl.c 2009-06-22 01:49:13 UTC (rev 38014)
@@ -8,7 +8,7 @@
* \BUGS: please send bugs reports to pallecch at cli.di.unipi.it
#include <string.h>
Modified: grass/trunk/raster/r.li/r.li.daemon/avlID.c
--- grass/trunk/raster/r.li/r.li.daemon/avlID.c 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/raster/r.li/r.li.daemon/avlID.c 2009-06-22 01:49:13 UTC (rev 38014)
@@ -12,7 +12,7 @@
#include <stdlib.h>
Modified: grass/trunk/raster/r.li/r.li.daemon/daemon.c
--- grass/trunk/raster/r.li/r.li.daemon/daemon.c 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/raster/r.li/r.li.daemon/daemon.c 2009-06-22 01:49:13 UTC (rev 38014)
@@ -31,7 +31,7 @@
#endif
#include "daemon.h"
Modified: grass/trunk/raster/r.li/r.li.daemon/daemon.h
--- grass/trunk/raster/r.li/r.li.daemon/daemon.h 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/raster/r.li/r.li.daemon/daemon.h 2009-06-22 01:49:13 UTC (rev 38014)
@@ -18,7 +18,7 @@
#include "list.h"
Modified: grass/trunk/raster/r.li/r.li.daemon/ipc.c
--- grass/trunk/raster/r.li/r.li.daemon/ipc.c 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/raster/r.li/r.li.daemon/ipc.c 2009-06-22 01:49:13 UTC (rev 38014)
@@ -19,7 +19,7 @@
#include <unistd.h>
#include "ipc.h"
Modified: grass/trunk/raster/r.li/r.li.daemon/list.c
--- grass/trunk/raster/r.li/r.li.daemon/list.c 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/raster/r.li/r.li.daemon/list.c 2009-06-22 01:49:13 UTC (rev 38014)
@@ -16,7 +16,7 @@
#include <stdlib.h>
#include "daemon.h"
Modified: grass/trunk/raster/r.li/r.li.daemon/worker.c
--- grass/trunk/raster/r.li/r.li.daemon/worker.c 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/raster/r.li/r.li.daemon/worker.c 2009-06-22 01:49:13 UTC (rev 38014)
@@ -30,7 +30,7 @@
#endif
#include "daemon.h"
#include "defs.h"
Modified: grass/trunk/raster/r.li/r.li.dominance/Makefile
--- grass/trunk/raster/r.li/r.li.dominance/Makefile 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/raster/r.li/r.li.dominance/Makefile 2009-06-22 01:49:13 UTC (rev 38014)
@@ -8,9 +8,9 @@
Modified: grass/trunk/raster/r.li/r.li.dominance/dominance.c
--- grass/trunk/raster/r.li/r.li.dominance/dominance.c 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/raster/r.li/r.li.dominance/dominance.c 2009-06-22 01:49:13 UTC (rev 38014)
@@ -12,7 +12,7 @@
#include <stdlib.h>
Modified: grass/trunk/raster/r.li/r.li.edgedensity/Makefile
--- grass/trunk/raster/r.li/r.li.edgedensity/Makefile 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/raster/r.li/r.li.edgedensity/Makefile 2009-06-22 01:49:13 UTC (rev 38014)
@@ -8,9 +8,9 @@
Modified: grass/trunk/raster/r.li/r.li.edgedensity/edgedensity.c
--- grass/trunk/raster/r.li/r.li.edgedensity/edgedensity.c 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/raster/r.li/r.li.edgedensity/edgedensity.c 2009-06-22 01:49:13 UTC (rev 38014)
@@ -11,7 +11,7 @@
#include <stdlib.h>
Modified: grass/trunk/raster/r.li/r.li.mpa/Makefile
--- grass/trunk/raster/r.li/r.li.mpa/Makefile 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/raster/r.li/r.li.mpa/Makefile 2009-06-22 01:49:13 UTC (rev 38014)
@@ -8,9 +8,9 @@
Modified: grass/trunk/raster/r.li/r.li.mpa/mpa.c
--- grass/trunk/raster/r.li/r.li.mpa/mpa.c 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/raster/r.li/r.li.mpa/mpa.c 2009-06-22 01:49:13 UTC (rev 38014)
@@ -13,7 +13,7 @@
#include <stdlib.h>
Modified: grass/trunk/raster/r.li/r.li.mps/Makefile
--- grass/trunk/raster/r.li/r.li.mps/Makefile 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/raster/r.li/r.li.mps/Makefile 2009-06-22 01:49:13 UTC (rev 38014)
@@ -8,9 +8,9 @@
Modified: grass/trunk/raster/r.li/r.li.mps/mps.c
--- grass/trunk/raster/r.li/r.li.mps/mps.c 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/raster/r.li/r.li.mps/mps.c 2009-06-22 01:49:13 UTC (rev 38014)
@@ -12,7 +12,7 @@
#include <stdlib.h>
Modified: grass/trunk/raster/r.li/r.li.padcv/Makefile
--- grass/trunk/raster/r.li/r.li.padcv/Makefile 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/raster/r.li/r.li.padcv/Makefile 2009-06-22 01:49:13 UTC (rev 38014)
@@ -8,9 +8,9 @@
Modified: grass/trunk/raster/r.li/r.li.padcv/padcv.c
--- grass/trunk/raster/r.li/r.li.padcv/padcv.c 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/raster/r.li/r.li.padcv/padcv.c 2009-06-22 01:49:13 UTC (rev 38014)
@@ -12,7 +12,7 @@
#include <stdlib.h>
Modified: grass/trunk/raster/r.li/r.li.padrange/Makefile
--- grass/trunk/raster/r.li/r.li.padrange/Makefile 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/raster/r.li/r.li.padrange/Makefile 2009-06-22 01:49:13 UTC (rev 38014)
@@ -8,9 +8,9 @@
Modified: grass/trunk/raster/r.li/r.li.padrange/padrange.c
--- grass/trunk/raster/r.li/r.li.padrange/padrange.c 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/raster/r.li/r.li.padrange/padrange.c 2009-06-22 01:49:13 UTC (rev 38014)
@@ -12,7 +12,7 @@
#include <stdlib.h>
Modified: grass/trunk/raster/r.li/r.li.padsd/Makefile
--- grass/trunk/raster/r.li/r.li.padsd/Makefile 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/raster/r.li/r.li.padsd/Makefile 2009-06-22 01:49:13 UTC (rev 38014)
@@ -8,9 +8,9 @@
Modified: grass/trunk/raster/r.li/r.li.padsd/padsd.c
--- grass/trunk/raster/r.li/r.li.padsd/padsd.c 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/raster/r.li/r.li.padsd/padsd.c 2009-06-22 01:49:13 UTC (rev 38014)
@@ -12,7 +12,7 @@
#include <stdlib.h>
Modified: grass/trunk/raster/r.li/r.li.patchdensity/Makefile
--- grass/trunk/raster/r.li/r.li.patchdensity/Makefile 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/raster/r.li/r.li.patchdensity/Makefile 2009-06-22 01:49:13 UTC (rev 38014)
@@ -8,9 +8,9 @@
Modified: grass/trunk/raster/r.li/r.li.patchdensity/main.c
--- grass/trunk/raster/r.li/r.li.patchdensity/main.c 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/raster/r.li/r.li.patchdensity/main.c 2009-06-22 01:49:13 UTC (rev 38014)
@@ -18,7 +18,7 @@
#include <stdlib.h>
#include <fcntl.h>
#include "../r.li.daemon/daemon.h"
Modified: grass/trunk/raster/r.li/r.li.patchnum/Makefile
--- grass/trunk/raster/r.li/r.li.patchnum/Makefile 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/raster/r.li/r.li.patchnum/Makefile 2009-06-22 01:49:13 UTC (rev 38014)
@@ -8,9 +8,9 @@
Modified: grass/trunk/raster/r.li/r.li.patchnum/main.c
--- grass/trunk/raster/r.li/r.li.patchnum/main.c 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/raster/r.li/r.li.patchnum/main.c 2009-06-22 01:49:13 UTC (rev 38014)
@@ -19,7 +19,7 @@
#include <stdlib.h>
#include <fcntl.h>
Modified: grass/trunk/raster/r.li/r.li.richness/Makefile
--- grass/trunk/raster/r.li/r.li.richness/Makefile 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/raster/r.li/r.li.richness/Makefile 2009-06-22 01:49:13 UTC (rev 38014)
@@ -8,9 +8,9 @@
Modified: grass/trunk/raster/r.li/r.li.richness/richness.c
--- grass/trunk/raster/r.li/r.li.richness/richness.c 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/raster/r.li/r.li.richness/richness.c 2009-06-22 01:49:13 UTC (rev 38014)
@@ -13,7 +13,7 @@
#include <stdlib.h>
Modified: grass/trunk/raster/r.li/r.li.shannon/Makefile
--- grass/trunk/raster/r.li/r.li.shannon/Makefile 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/raster/r.li/r.li.shannon/Makefile 2009-06-22 01:49:13 UTC (rev 38014)
@@ -8,9 +8,9 @@
Modified: grass/trunk/raster/r.li/r.li.shannon/shannon.c
--- grass/trunk/raster/r.li/r.li.shannon/shannon.c 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/raster/r.li/r.li.shannon/shannon.c 2009-06-22 01:49:13 UTC (rev 38014)
@@ -12,7 +12,7 @@
#include <stdlib.h>
Modified: grass/trunk/raster/r.li/r.li.shape/Makefile
--- grass/trunk/raster/r.li/r.li.shape/Makefile 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/raster/r.li/r.li.shape/Makefile 2009-06-22 01:49:13 UTC (rev 38014)
@@ -8,9 +8,9 @@
Modified: grass/trunk/raster/r.li/r.li.shape/main.c
--- grass/trunk/raster/r.li/r.li.shape/main.c 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/raster/r.li/r.li.shape/main.c 2009-06-22 01:49:13 UTC (rev 38014)
@@ -20,7 +20,7 @@
#include <stdlib.h>
#include <fcntl.h>
Modified: grass/trunk/raster/r.li/r.li.simpson/Makefile
--- grass/trunk/raster/r.li/r.li.simpson/Makefile 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/raster/r.li/r.li.simpson/Makefile 2009-06-22 01:49:13 UTC (rev 38014)
@@ -8,9 +8,9 @@
Modified: grass/trunk/raster/r.li/r.li.simpson/simpson.c
--- grass/trunk/raster/r.li/r.li.simpson/simpson.c 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/raster/r.li/r.li.simpson/simpson.c 2009-06-22 01:49:13 UTC (rev 38014)
@@ -13,7 +13,7 @@
#include <stdlib.h>
Modified: grass/trunk/raster/r.los/Makefile
--- grass/trunk/raster/r.los/Makefile 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/raster/r.los/Makefile 2009-06-22 01:49:13 UTC (rev 38014)
@@ -2,8 +2,8 @@
PGM = r.los
-LIBES = $(SEGMENTLIB) $(GPROJLIB) $(GISLIB) $(RASTRLIB)
-DEPENDENCIES = $(SEGMENTDEP) $(GPROJDEP) $(GISDEP) $(RASTRDEP)
+LIBES = $(SEGMENTLIB) $(GPROJLIB) $(GISLIB) $(RASTERLIB)
+DEPENDENCIES = $(SEGMENTDEP) $(GPROJDEP) $(GISDEP) $(RASTERDEP)
Modified: grass/trunk/raster/r.los/delete.c
--- grass/trunk/raster/r.los/delete.c 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/raster/r.los/delete.c 2009-06-22 01:49:13 UTC (rev 38014)
@@ -11,7 +11,7 @@
#include <stdlib.h>
#include "point.h"
Modified: grass/trunk/raster/r.los/main.c
--- grass/trunk/raster/r.los/main.c 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/raster/r.los/main.c 2009-06-22 01:49:13 UTC (rev 38014)
@@ -34,7 +34,7 @@
#include <math.h>
#include <fcntl.h>
Modified: grass/trunk/raster/r.los/make_list.c
--- grass/trunk/raster/r.los/make_list.c 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/raster/r.los/make_list.c 2009-06-22 01:49:13 UTC (rev 38014)
@@ -12,7 +12,7 @@
#include <math.h>
#include "point.h"
Modified: grass/trunk/raster/r.los/make_point.c
--- grass/trunk/raster/r.los/make_point.c 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/raster/r.los/make_point.c 2009-06-22 01:49:13 UTC (rev 38014)
@@ -13,7 +13,7 @@
#include "point.h"
/* #define NULL 0 should be (char *0), or just let the compiler fix it. */
Modified: grass/trunk/raster/r.los/mark_pts.c
--- grass/trunk/raster/r.los/mark_pts.c 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/raster/r.los/mark_pts.c 2009-06-22 01:49:13 UTC (rev 38014)
@@ -12,7 +12,7 @@
#include "point.h"
#define PT_TO_MARK_X PT_TO_MARK->x
#define PT_TO_MARK_Y PT_TO_MARK->y
Modified: grass/trunk/raster/r.los/pts_elim.c
--- grass/trunk/raster/r.los/pts_elim.c 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/raster/r.los/pts_elim.c 2009-06-22 01:49:13 UTC (rev 38014)
@@ -12,7 +12,7 @@
#include <math.h>
#include "point.h"
Modified: grass/trunk/raster/r.los/radians.h
--- grass/trunk/raster/r.los/radians.h 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/raster/r.los/radians.h 2009-06-22 01:49:13 UTC (rev 38014)
@@ -10,7 +10,7 @@
#define PI M_PI
#define PIBYFOUR M_PI_4
Modified: grass/trunk/raster/r.mapcalc/Makefile
--- grass/trunk/raster/r.mapcalc/Makefile 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/raster/r.mapcalc/Makefile 2009-06-22 01:49:13 UTC (rev 38014)
@@ -12,8 +12,8 @@
include $(MODULE_TOPDIR)/include/Make/Multi.make
EXTRA_CFLAGS = $(READLINEINCPATH) $(PTHREADINCPATH)
-LIBES2 = $(GISLIB) $(RASTRLIB) $(BTREELIB) $(READLINELIBPATH) $(READLINELIB) $(HISTORYLIB) $(PTHREADLIBPATH) $(PTHREADLIB)
-LIBES3 = $(G3DLIB) $(GISLIB) $(RASTRLIB) $(BTREELIB) $(READLINELIBPATH) $(READLINELIB) $(HISTORYLIB) $(PTHREADLIBPATH) $(PTHREADLIB)
+LIBES2 = $(GISLIB) $(RASTERLIB) $(BTREELIB) $(READLINELIBPATH) $(READLINELIB) $(HISTORYLIB) $(PTHREADLIBPATH) $(PTHREADLIB)
+LIBES3 = $(G3DLIB) $(GISLIB) $(RASTERLIB) $(BTREELIB) $(READLINELIBPATH) $(READLINELIB) $(HISTORYLIB) $(PTHREADLIBPATH) $(PTHREADLIB)
default: multi
Modified: grass/trunk/raster/r.mapcalc/column_shift.c
--- grass/trunk/raster/r.mapcalc/column_shift.c 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/raster/r.mapcalc/column_shift.c 2009-06-22 01:49:13 UTC (rev 38014)
@@ -1,6 +1,6 @@
#include <stdlib.h>
#include "expression.h"
#include "globals.h"
Modified: grass/trunk/raster/r.mapcalc/evaluate.c
--- grass/trunk/raster/r.mapcalc/evaluate.c 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/raster/r.mapcalc/evaluate.c 2009-06-22 01:49:13 UTC (rev 38014)
@@ -3,7 +3,7 @@
#include <unistd.h>
#include "mapcalc.h"
Modified: grass/trunk/raster/r.mapcalc/expression.c
--- grass/trunk/raster/r.mapcalc/expression.c 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/raster/r.mapcalc/expression.c 2009-06-22 01:49:13 UTC (rev 38014)
@@ -4,7 +4,7 @@
#include <string.h>
Modified: grass/trunk/raster/r.mapcalc/map.c
--- grass/trunk/raster/r.mapcalc/map.c 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/raster/r.mapcalc/map.c 2009-06-22 01:49:13 UTC (rev 38014)
@@ -10,7 +10,7 @@
#endif
#include <grass/btree.h>
Modified: grass/trunk/raster/r.mapcalc/map3.c
--- grass/trunk/raster/r.mapcalc/map3.c 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/raster/r.mapcalc/map3.c 2009-06-22 01:49:13 UTC (rev 38014)
@@ -5,7 +5,7 @@
#include <unistd.h>
#include <grass/G3d.h>
Modified: grass/trunk/raster/r.mapcalc/mapcalc.h
--- grass/trunk/raster/r.mapcalc/mapcalc.h 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/raster/r.mapcalc/mapcalc.h 2009-06-22 01:49:13 UTC (rev 38014)
@@ -8,7 +8,7 @@
#include <grass/config.h>
Modified: grass/trunk/raster/r.mapcalc/xabs.c
--- grass/trunk/raster/r.mapcalc/xabs.c 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/raster/r.mapcalc/xabs.c 2009-06-22 01:49:13 UTC (rev 38014)
@@ -2,7 +2,7 @@
#include <math.h>
#include "func_proto.h"
Modified: grass/trunk/raster/r.mapcalc/xacos.c
--- grass/trunk/raster/r.mapcalc/xacos.c 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/raster/r.mapcalc/xacos.c 2009-06-22 01:49:13 UTC (rev 38014)
@@ -3,7 +3,7 @@
#include <math.h>
Modified: grass/trunk/raster/r.mapcalc/xadd.c
--- grass/trunk/raster/r.mapcalc/xadd.c 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/raster/r.mapcalc/xadd.c 2009-06-22 01:49:13 UTC (rev 38014)
@@ -1,6 +1,6 @@
Modified: grass/trunk/raster/r.mapcalc/xand.c
--- grass/trunk/raster/r.mapcalc/xand.c 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/raster/r.mapcalc/xand.c 2009-06-22 01:49:13 UTC (rev 38014)
@@ -1,6 +1,6 @@
Modified: grass/trunk/raster/r.mapcalc/xand2.c
--- grass/trunk/raster/r.mapcalc/xand2.c 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/raster/r.mapcalc/xand2.c 2009-06-22 01:49:13 UTC (rev 38014)
@@ -1,6 +1,6 @@
Modified: grass/trunk/raster/r.mapcalc/xasin.c
--- grass/trunk/raster/r.mapcalc/xasin.c 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/raster/r.mapcalc/xasin.c 2009-06-22 01:49:13 UTC (rev 38014)
@@ -3,7 +3,7 @@
#include <math.h>
Modified: grass/trunk/raster/r.mapcalc/xatan.c
--- grass/trunk/raster/r.mapcalc/xatan.c 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/raster/r.mapcalc/xatan.c 2009-06-22 01:49:13 UTC (rev 38014)
@@ -3,7 +3,7 @@
#include <math.h>
Modified: grass/trunk/raster/r.mapcalc/xbitand.c
--- grass/trunk/raster/r.mapcalc/xbitand.c 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/raster/r.mapcalc/xbitand.c 2009-06-22 01:49:13 UTC (rev 38014)
@@ -1,6 +1,6 @@
Modified: grass/trunk/raster/r.mapcalc/xbitnot.c
--- grass/trunk/raster/r.mapcalc/xbitnot.c 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/raster/r.mapcalc/xbitnot.c 2009-06-22 01:49:13 UTC (rev 38014)
@@ -1,6 +1,6 @@
Modified: grass/trunk/raster/r.mapcalc/xbitor.c
--- grass/trunk/raster/r.mapcalc/xbitor.c 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/raster/r.mapcalc/xbitor.c 2009-06-22 01:49:13 UTC (rev 38014)
@@ -1,6 +1,6 @@
Modified: grass/trunk/raster/r.mapcalc/xbitxor.c
--- grass/trunk/raster/r.mapcalc/xbitxor.c 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/raster/r.mapcalc/xbitxor.c 2009-06-22 01:49:13 UTC (rev 38014)
@@ -1,6 +1,6 @@
Modified: grass/trunk/raster/r.mapcalc/xcoor.c
--- grass/trunk/raster/r.mapcalc/xcoor.c 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/raster/r.mapcalc/xcoor.c 2009-06-22 01:49:13 UTC (rev 38014)
@@ -1,6 +1,6 @@
#include "globals2.h"
Modified: grass/trunk/raster/r.mapcalc/xcoor3.c
--- grass/trunk/raster/r.mapcalc/xcoor3.c 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/raster/r.mapcalc/xcoor3.c 2009-06-22 01:49:13 UTC (rev 38014)
@@ -1,6 +1,6 @@
#include "globals3.h"
Modified: grass/trunk/raster/r.mapcalc/xcos.c
--- grass/trunk/raster/r.mapcalc/xcos.c 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/raster/r.mapcalc/xcos.c 2009-06-22 01:49:13 UTC (rev 38014)
@@ -2,7 +2,7 @@
#include <math.h>
Modified: grass/trunk/raster/r.mapcalc/xdiv.c
--- grass/trunk/raster/r.mapcalc/xdiv.c 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/raster/r.mapcalc/xdiv.c 2009-06-22 01:49:13 UTC (rev 38014)
@@ -1,6 +1,6 @@
Modified: grass/trunk/raster/r.mapcalc/xdouble.c
--- grass/trunk/raster/r.mapcalc/xdouble.c 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/raster/r.mapcalc/xdouble.c 2009-06-22 01:49:13 UTC (rev 38014)
@@ -2,7 +2,7 @@
#include <stdlib.h>
Modified: grass/trunk/raster/r.mapcalc/xeq.c
--- grass/trunk/raster/r.mapcalc/xeq.c 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/raster/r.mapcalc/xeq.c 2009-06-22 01:49:13 UTC (rev 38014)
@@ -1,6 +1,6 @@
Modified: grass/trunk/raster/r.mapcalc/xeval.c
--- grass/trunk/raster/r.mapcalc/xeval.c 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/raster/r.mapcalc/xeval.c 2009-06-22 01:49:13 UTC (rev 38014)
@@ -1,6 +1,6 @@
Modified: grass/trunk/raster/r.mapcalc/xexp.c
--- grass/trunk/raster/r.mapcalc/xexp.c 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/raster/r.mapcalc/xexp.c 2009-06-22 01:49:13 UTC (rev 38014)
@@ -2,7 +2,7 @@
#include <math.h>
Modified: grass/trunk/raster/r.mapcalc/xfloat.c
--- grass/trunk/raster/r.mapcalc/xfloat.c 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/raster/r.mapcalc/xfloat.c 2009-06-22 01:49:13 UTC (rev 38014)
@@ -2,7 +2,7 @@
#include <stdlib.h>
Modified: grass/trunk/raster/r.mapcalc/xge.c
--- grass/trunk/raster/r.mapcalc/xge.c 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/raster/r.mapcalc/xge.c 2009-06-22 01:49:13 UTC (rev 38014)
@@ -1,6 +1,6 @@
Modified: grass/trunk/raster/r.mapcalc/xgraph.c
--- grass/trunk/raster/r.mapcalc/xgraph.c 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/raster/r.mapcalc/xgraph.c 2009-06-22 01:49:13 UTC (rev 38014)
@@ -2,7 +2,7 @@
#include <stdlib.h>
Modified: grass/trunk/raster/r.mapcalc/xgt.c
--- grass/trunk/raster/r.mapcalc/xgt.c 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/raster/r.mapcalc/xgt.c 2009-06-22 01:49:13 UTC (rev 38014)
@@ -1,6 +1,6 @@
Modified: grass/trunk/raster/r.mapcalc/xif.c
--- grass/trunk/raster/r.mapcalc/xif.c 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/raster/r.mapcalc/xif.c 2009-06-22 01:49:13 UTC (rev 38014)
@@ -1,6 +1,6 @@
Modified: grass/trunk/raster/r.mapcalc/xint.c
--- grass/trunk/raster/r.mapcalc/xint.c 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/raster/r.mapcalc/xint.c 2009-06-22 01:49:13 UTC (rev 38014)
@@ -2,7 +2,7 @@
#include <stdlib.h>
Modified: grass/trunk/raster/r.mapcalc/xisnull.c
--- grass/trunk/raster/r.mapcalc/xisnull.c 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/raster/r.mapcalc/xisnull.c 2009-06-22 01:49:13 UTC (rev 38014)
@@ -1,6 +1,6 @@
Modified: grass/trunk/raster/r.mapcalc/xle.c
--- grass/trunk/raster/r.mapcalc/xle.c 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/raster/r.mapcalc/xle.c 2009-06-22 01:49:13 UTC (rev 38014)
@@ -1,6 +1,6 @@
Modified: grass/trunk/raster/r.mapcalc/xlog.c
--- grass/trunk/raster/r.mapcalc/xlog.c 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/raster/r.mapcalc/xlog.c 2009-06-22 01:49:13 UTC (rev 38014)
@@ -2,7 +2,7 @@
#include <math.h>
Modified: grass/trunk/raster/r.mapcalc/xlt.c
--- grass/trunk/raster/r.mapcalc/xlt.c 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/raster/r.mapcalc/xlt.c 2009-06-22 01:49:13 UTC (rev 38014)
@@ -1,6 +1,6 @@
Modified: grass/trunk/raster/r.mapcalc/xmax.c
--- grass/trunk/raster/r.mapcalc/xmax.c 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/raster/r.mapcalc/xmax.c 2009-06-22 01:49:13 UTC (rev 38014)
@@ -2,7 +2,7 @@
#include <stdlib.h>
Modified: grass/trunk/raster/r.mapcalc/xmedian.c
--- grass/trunk/raster/r.mapcalc/xmedian.c 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/raster/r.mapcalc/xmedian.c 2009-06-22 01:49:13 UTC (rev 38014)
@@ -2,7 +2,7 @@
#include <stdlib.h>
Modified: grass/trunk/raster/r.mapcalc/xmin.c
--- grass/trunk/raster/r.mapcalc/xmin.c 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/raster/r.mapcalc/xmin.c 2009-06-22 01:49:13 UTC (rev 38014)
@@ -2,7 +2,7 @@
#include <stdlib.h>
Modified: grass/trunk/raster/r.mapcalc/xmod.c
--- grass/trunk/raster/r.mapcalc/xmod.c 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/raster/r.mapcalc/xmod.c 2009-06-22 01:49:13 UTC (rev 38014)
@@ -1,6 +1,6 @@
Modified: grass/trunk/raster/r.mapcalc/xmode.c
--- grass/trunk/raster/r.mapcalc/xmode.c 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/raster/r.mapcalc/xmode.c 2009-06-22 01:49:13 UTC (rev 38014)
@@ -2,7 +2,7 @@
#include <stdlib.h>
Modified: grass/trunk/raster/r.mapcalc/xmul.c
--- grass/trunk/raster/r.mapcalc/xmul.c 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/raster/r.mapcalc/xmul.c 2009-06-22 01:49:13 UTC (rev 38014)
@@ -1,6 +1,6 @@
Modified: grass/trunk/raster/r.mapcalc/xne.c
--- grass/trunk/raster/r.mapcalc/xne.c 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/raster/r.mapcalc/xne.c 2009-06-22 01:49:13 UTC (rev 38014)
@@ -1,6 +1,6 @@
Modified: grass/trunk/raster/r.mapcalc/xneg.c
--- grass/trunk/raster/r.mapcalc/xneg.c 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/raster/r.mapcalc/xneg.c 2009-06-22 01:49:13 UTC (rev 38014)
@@ -1,6 +1,6 @@
Modified: grass/trunk/raster/r.mapcalc/xnot.c
--- grass/trunk/raster/r.mapcalc/xnot.c 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/raster/r.mapcalc/xnot.c 2009-06-22 01:49:13 UTC (rev 38014)
@@ -1,6 +1,6 @@
Modified: grass/trunk/raster/r.mapcalc/xnull.c
--- grass/trunk/raster/r.mapcalc/xnull.c 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/raster/r.mapcalc/xnull.c 2009-06-22 01:49:13 UTC (rev 38014)
@@ -1,6 +1,6 @@
Modified: grass/trunk/raster/r.mapcalc/xor.c
--- grass/trunk/raster/r.mapcalc/xor.c 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/raster/r.mapcalc/xor.c 2009-06-22 01:49:13 UTC (rev 38014)
@@ -1,6 +1,6 @@
Modified: grass/trunk/raster/r.mapcalc/xor2.c
--- grass/trunk/raster/r.mapcalc/xor2.c 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/raster/r.mapcalc/xor2.c 2009-06-22 01:49:13 UTC (rev 38014)
@@ -1,6 +1,6 @@
Modified: grass/trunk/raster/r.mapcalc/xpow.c
--- grass/trunk/raster/r.mapcalc/xpow.c 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/raster/r.mapcalc/xpow.c 2009-06-22 01:49:13 UTC (rev 38014)
@@ -2,7 +2,7 @@
#include <math.h>
Modified: grass/trunk/raster/r.mapcalc/xrand.c
--- grass/trunk/raster/r.mapcalc/xrand.c 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/raster/r.mapcalc/xrand.c 2009-06-22 01:49:13 UTC (rev 38014)
@@ -3,7 +3,7 @@
Modified: grass/trunk/raster/r.mapcalc/xres.c
--- grass/trunk/raster/r.mapcalc/xres.c 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/raster/r.mapcalc/xres.c 2009-06-22 01:49:13 UTC (rev 38014)
@@ -1,6 +1,6 @@
Modified: grass/trunk/raster/r.mapcalc/xres3.c
--- grass/trunk/raster/r.mapcalc/xres3.c 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/raster/r.mapcalc/xres3.c 2009-06-22 01:49:13 UTC (rev 38014)
@@ -1,6 +1,6 @@
Modified: grass/trunk/raster/r.mapcalc/xround.c
--- grass/trunk/raster/r.mapcalc/xround.c 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/raster/r.mapcalc/xround.c 2009-06-22 01:49:13 UTC (rev 38014)
@@ -2,7 +2,7 @@
#include <limits.h>
#include <grass/gis.h>
Modified: grass/trunk/raster/r.mapcalc/xrowcol.c
--- grass/trunk/raster/r.mapcalc/xrowcol.c 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/raster/r.mapcalc/xrowcol.c 2009-06-22 01:49:13 UTC (rev 38014)
@@ -1,6 +1,6 @@
Modified: grass/trunk/raster/r.mapcalc/xshiftl.c
--- grass/trunk/raster/r.mapcalc/xshiftl.c 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/raster/r.mapcalc/xshiftl.c 2009-06-22 01:49:13 UTC (rev 38014)
@@ -1,6 +1,6 @@
Modified: grass/trunk/raster/r.mapcalc/xshiftr.c
--- grass/trunk/raster/r.mapcalc/xshiftr.c 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/raster/r.mapcalc/xshiftr.c 2009-06-22 01:49:13 UTC (rev 38014)
@@ -1,6 +1,6 @@
Modified: grass/trunk/raster/r.mapcalc/xshiftru.c
--- grass/trunk/raster/r.mapcalc/xshiftru.c 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/raster/r.mapcalc/xshiftru.c 2009-06-22 01:49:13 UTC (rev 38014)
@@ -1,6 +1,6 @@
Modified: grass/trunk/raster/r.mapcalc/xsin.c
--- grass/trunk/raster/r.mapcalc/xsin.c 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/raster/r.mapcalc/xsin.c 2009-06-22 01:49:13 UTC (rev 38014)
@@ -2,7 +2,7 @@
#include <math.h>
Modified: grass/trunk/raster/r.mapcalc/xsqrt.c
--- grass/trunk/raster/r.mapcalc/xsqrt.c 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/raster/r.mapcalc/xsqrt.c 2009-06-22 01:49:13 UTC (rev 38014)
@@ -2,7 +2,7 @@
#include <math.h>
Modified: grass/trunk/raster/r.mapcalc/xsub.c
--- grass/trunk/raster/r.mapcalc/xsub.c 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/raster/r.mapcalc/xsub.c 2009-06-22 01:49:13 UTC (rev 38014)
@@ -1,6 +1,6 @@
Modified: grass/trunk/raster/r.mapcalc/xtan.c
--- grass/trunk/raster/r.mapcalc/xtan.c 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/raster/r.mapcalc/xtan.c 2009-06-22 01:49:13 UTC (rev 38014)
@@ -3,7 +3,7 @@
#include <math.h>
Modified: grass/trunk/raster/r.mfilter/Makefile
--- grass/trunk/raster/r.mfilter/Makefile 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/raster/r.mfilter/Makefile 2009-06-22 01:49:13 UTC (rev 38014)
@@ -2,8 +2,8 @@
PGM = r.mfilter
-LIBES = $(ROWIOLIB) $(GISLIB) $(RASTRLIB)
-DEPENDENCIES = $(ROWIODEP) $(GISDEP) $(RASTRDEP)
+LIBES = $(ROWIOLIB) $(GISLIB) $(RASTERLIB)
+DEPENDENCIES = $(ROWIODEP) $(GISDEP) $(RASTERDEP)
include $(MODULE_TOPDIR)/include/Make/Module.make
Modified: grass/trunk/raster/r.mfilter/filter.h
--- grass/trunk/raster/r.mfilter/filter.h 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/raster/r.mfilter/filter.h 2009-06-22 01:49:13 UTC (rev 38014)
@@ -1,5 +1,5 @@
#include <grass/rowio.h>
typedef struct
Modified: grass/trunk/raster/r.mfilter/getrow.c
--- grass/trunk/raster/r.mfilter/getrow.c 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/raster/r.mfilter/getrow.c 2009-06-22 01:49:13 UTC (rev 38014)
@@ -2,7 +2,7 @@
#include <unistd.h>
#include "glob.h"
#include "local_proto.h"
Modified: grass/trunk/raster/r.mfilter/main.c
--- grass/trunk/raster/r.mfilter/main.c 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/raster/r.mfilter/main.c 2009-06-22 01:49:13 UTC (rev 38014)
@@ -19,7 +19,7 @@
#include <string.h>
#include <stdio.h>
#include "filter.h"
Modified: grass/trunk/raster/r.mode/Makefile
--- grass/trunk/raster/r.mode/Makefile 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/raster/r.mode/Makefile 2009-06-22 01:49:13 UTC (rev 38014)
@@ -2,8 +2,8 @@
PGM = r.mode
Modified: grass/trunk/raster/r.mode/main.c
--- grass/trunk/raster/r.mode/main.c 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/raster/r.mode/main.c 2009-06-22 01:49:13 UTC (rev 38014)
@@ -24,7 +24,7 @@
#include <unistd.h>
#include <string.h>
Modified: grass/trunk/raster/r.mode/read_stats.c
--- grass/trunk/raster/r.mode/read_stats.c 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/raster/r.mode/read_stats.c 2009-06-22 01:49:13 UTC (rev 38014)
@@ -1,7 +1,7 @@
#include <stdlib.h>
#include <stdio.h>
int read_stats(FILE * fd, long *cat1, long *cat2, double *value)
Modified: grass/trunk/raster/r.neighbors/bufs.c
--- grass/trunk/raster/r.neighbors/bufs.c 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/raster/r.neighbors/bufs.c 2009-06-22 01:49:13 UTC (rev 38014)
@@ -1,5 +1,5 @@
#include "ncb.h"
Modified: grass/trunk/raster/r.neighbors/divr_cats.c
--- grass/trunk/raster/r.neighbors/divr_cats.c 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/raster/r.neighbors/divr_cats.c 2009-06-22 01:49:13 UTC (rev 38014)
@@ -1,5 +1,5 @@
#include "ncb.h"
int divr_cats(void)
Modified: grass/trunk/raster/r.neighbors/gather.c
--- grass/trunk/raster/r.neighbors/gather.c 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/raster/r.neighbors/gather.c 2009-06-22 01:49:13 UTC (rev 38014)
@@ -1,5 +1,5 @@
#include "ncb.h"
Modified: grass/trunk/raster/r.neighbors/intr_cats.c
--- grass/trunk/raster/r.neighbors/intr_cats.c 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/raster/r.neighbors/intr_cats.c 2009-06-22 01:49:13 UTC (rev 38014)
@@ -1,5 +1,5 @@
#include "ncb.h"
int intr_cats(void)
Modified: grass/trunk/raster/r.neighbors/main.c
--- grass/trunk/raster/r.neighbors/main.c 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/raster/r.neighbors/main.c 2009-06-22 01:49:13 UTC (rev 38014)
@@ -22,7 +22,7 @@
#include <stdlib.h>
#include <unistd.h>
#include <grass/stats.h>
#include "ncb.h"
Modified: grass/trunk/raster/r.neighbors/null_cats.c
--- grass/trunk/raster/r.neighbors/null_cats.c 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/raster/r.neighbors/null_cats.c 2009-06-22 01:49:13 UTC (rev 38014)
@@ -1,5 +1,5 @@
#include "ncb.h"
int null_cats(void)
Modified: grass/trunk/raster/r.neighbors/readcell.c
--- grass/trunk/raster/r.neighbors/readcell.c 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/raster/r.neighbors/readcell.c 2009-06-22 01:49:13 UTC (rev 38014)
@@ -1,6 +1,6 @@
#include <unistd.h>
#include "ncb.h"
Modified: grass/trunk/raster/r.neighbors/readweights.c
--- grass/trunk/raster/r.neighbors/readweights.c 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/raster/r.neighbors/readweights.c 2009-06-22 01:49:13 UTC (rev 38014)
@@ -1,7 +1,7 @@
#include <stdio.h>
#include <math.h>
#include "ncb.h"
Modified: grass/trunk/raster/r.null/Makefile
--- grass/trunk/raster/r.null/Makefile 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/raster/r.null/Makefile 2009-06-22 01:49:13 UTC (rev 38014)
@@ -2,8 +2,8 @@
PGM = r.null
Modified: grass/trunk/raster/r.null/main.c
--- grass/trunk/raster/r.null/main.c 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/raster/r.null/main.c 2009-06-22 01:49:13 UTC (rev 38014)
@@ -15,7 +15,7 @@
#include <string.h>
#include <unistd.h>
#include "mask.h"
Modified: grass/trunk/raster/r.null/mask.c
--- grass/trunk/raster/r.null/mask.c 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/raster/r.null/mask.c 2009-06-22 01:49:13 UTC (rev 38014)
@@ -1,5 +1,5 @@
#include "mask.h"
Modified: grass/trunk/raster/r.out.arc/Makefile
--- grass/trunk/raster/r.out.arc/Makefile 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/raster/r.out.arc/Makefile 2009-06-22 01:49:13 UTC (rev 38014)
@@ -2,8 +2,8 @@
PGM = r.out.arc
Modified: grass/trunk/raster/r.out.arc/main.c
--- grass/trunk/raster/r.out.arc/main.c 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/raster/r.out.arc/main.c 2009-06-22 01:49:13 UTC (rev 38014)
@@ -3,7 +3,7 @@
#include <math.h>
#include <stdio.h>
Modified: grass/trunk/raster/r.out.ascii/Makefile
--- grass/trunk/raster/r.out.ascii/Makefile 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/raster/r.out.ascii/Makefile 2009-06-22 01:49:13 UTC (rev 38014)
@@ -2,8 +2,8 @@
PGM = r.out.ascii
Modified: grass/trunk/raster/r.out.ascii/formspecific.c
--- grass/trunk/raster/r.out.ascii/formspecific.c 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/raster/r.out.ascii/formspecific.c 2009-06-22 01:49:13 UTC (rev 38014)
@@ -1,6 +1,6 @@
#include <stdio.h>
/* write the GRASS ASCII heading */
int writeGRASSheader(FILE * fp)
Modified: grass/trunk/raster/r.out.ascii/main.c
--- grass/trunk/raster/r.out.ascii/main.c 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/raster/r.out.ascii/main.c 2009-06-22 01:49:13 UTC (rev 38014)
@@ -21,7 +21,7 @@
#include <math.h>
#include <string.h>
#include "localproto.h"
Modified: grass/trunk/raster/r.out.bin/Makefile
--- grass/trunk/raster/r.out.bin/Makefile 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/raster/r.out.bin/Makefile 2009-06-22 01:49:13 UTC (rev 38014)
@@ -2,8 +2,8 @@
PGM = r.out.bin
Modified: grass/trunk/raster/r.out.bin/main.c
--- grass/trunk/raster/r.out.bin/main.c 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/raster/r.out.bin/main.c 2009-06-22 01:49:13 UTC (rev 38014)
@@ -13,7 +13,7 @@
#include <stdlib.h>
#include <string.h>
#include "./gmt_grd.h"
Modified: grass/trunk/raster/r.out.gdal/Makefile
--- grass/trunk/raster/r.out.gdal/Makefile 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/raster/r.out.gdal/Makefile 2009-06-22 01:49:13 UTC (rev 38014)
@@ -2,8 +2,8 @@
PGM = r.out.gdal
-LIBES= $(GPROJLIB) $(GISLIB) $(RASTRLIB) $(GDALLIBS) $(IMAGERYLIB) $(DBMIBASELIB)
+LIBES= $(GPROJLIB) $(GISLIB) $(RASTERLIB) $(GDALLIBS) $(IMAGERYLIB) $(DBMIBASELIB)
Modified: grass/trunk/raster/r.out.gdal/export_band.c
--- grass/trunk/raster/r.out.gdal/export_band.c 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/raster/r.out.gdal/export_band.c 2009-06-22 01:49:13 UTC (rev 38014)
@@ -15,7 +15,7 @@
#include "cpl_string.h"
Modified: grass/trunk/raster/r.out.gdal/main.c
--- grass/trunk/raster/r.out.gdal/main.c 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/raster/r.out.gdal/main.c 2009-06-22 01:49:13 UTC (rev 38014)
@@ -24,7 +24,7 @@
#include <math.h>
#include <string.h>
#include <grass/gprojects.h>
Modified: grass/trunk/raster/r.out.gridatb/Makefile
--- grass/trunk/raster/r.out.gridatb/Makefile 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/raster/r.out.gridatb/Makefile 2009-06-22 01:49:13 UTC (rev 38014)
@@ -2,8 +2,8 @@
PGM = r.out.gridatb
Modified: grass/trunk/raster/r.out.gridatb/local_proto.h
--- grass/trunk/raster/r.out.gridatb/local_proto.h 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/raster/r.out.gridatb/local_proto.h 2009-06-22 01:49:13 UTC (rev 38014)
@@ -1,6 +1,6 @@
#include <stdio.h>
void check_ready(void);
Modified: grass/trunk/raster/r.out.gridatb/main.c
--- grass/trunk/raster/r.out.gridatb/main.c 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/raster/r.out.gridatb/main.c 2009-06-22 01:49:13 UTC (rev 38014)
@@ -17,7 +17,7 @@
#include <stdio.h>
Modified: grass/trunk/raster/r.out.mat/Makefile
--- grass/trunk/raster/r.out.mat/Makefile 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/raster/r.out.mat/Makefile 2009-06-22 01:49:13 UTC (rev 38014)
@@ -2,8 +2,8 @@
PGM = r.out.mat
Modified: grass/trunk/raster/r.out.mat/main.c
--- grass/trunk/raster/r.out.mat/main.c 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/raster/r.out.mat/main.c 2009-06-22 01:49:13 UTC (rev 38014)
@@ -17,7 +17,7 @@
#include <stdlib.h>
#include <string.h>
Modified: grass/trunk/raster/r.out.mpeg/Makefile
--- grass/trunk/raster/r.out.mpeg/Makefile 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/raster/r.out.mpeg/Makefile 2009-06-22 01:49:13 UTC (rev 38014)
@@ -2,8 +2,8 @@
PGM = r.out.mpeg
Modified: grass/trunk/raster/r.out.mpeg/main.c
--- grass/trunk/raster/r.out.mpeg/main.c 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/raster/r.out.mpeg/main.c 2009-06-22 01:49:13 UTC (rev 38014)
@@ -40,7 +40,7 @@
#include <unistd.h>
#include "rom_proto.h"
Modified: grass/trunk/raster/r.out.mpeg/write.c
--- grass/trunk/raster/r.out.mpeg/write.c 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/raster/r.out.mpeg/write.c 2009-06-22 01:49:13 UTC (rev 38014)
@@ -22,7 +22,7 @@
#include <math.h>
#include <unistd.h>
Modified: grass/trunk/raster/r.out.png/Makefile
--- grass/trunk/raster/r.out.png/Makefile 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/raster/r.out.png/Makefile 2009-06-22 01:49:13 UTC (rev 38014)
@@ -3,8 +3,8 @@
EXTRA_CFLAGS=$(PNGINC)
-LIBES = $(GISLIB) $(RASTRLIB) $(PNGLIB)
+LIBES = $(GISLIB) $(RASTERLIB) $(PNGLIB)
Modified: grass/trunk/raster/r.out.png/main.c
--- grass/trunk/raster/r.out.png/main.c 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/raster/r.out.png/main.c 2009-06-22 01:49:13 UTC (rev 38014)
@@ -37,7 +37,7 @@
#endif /* _MYINCLUDE_H */
#define DEF_RED 255
Modified: grass/trunk/raster/r.out.pov/Makefile
--- grass/trunk/raster/r.out.pov/Makefile 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/raster/r.out.pov/Makefile 2009-06-22 01:49:13 UTC (rev 38014)
@@ -2,8 +2,8 @@
PGM = r.out.pov
Modified: grass/trunk/raster/r.out.pov/main.c
--- grass/trunk/raster/r.out.pov/main.c 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/raster/r.out.pov/main.c 2009-06-22 01:49:13 UTC (rev 38014)
@@ -39,7 +39,7 @@
#include <string.h>
#include <math.h>
void writeHeader(FILE * outf);
Modified: grass/trunk/raster/r.out.ppm/Makefile
--- grass/trunk/raster/r.out.ppm/Makefile 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/raster/r.out.ppm/Makefile 2009-06-22 01:49:13 UTC (rev 38014)
@@ -2,8 +2,8 @@
PGM = r.out.ppm
Modified: grass/trunk/raster/r.out.ppm/main.c
--- grass/trunk/raster/r.out.ppm/main.c 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/raster/r.out.ppm/main.c 2009-06-22 01:49:13 UTC (rev 38014)
@@ -21,7 +21,7 @@
#include <stdlib.h>
#define DEF_RED 255
Modified: grass/trunk/raster/r.out.ppm3/Makefile
--- grass/trunk/raster/r.out.ppm3/Makefile 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/raster/r.out.ppm3/Makefile 2009-06-22 01:49:13 UTC (rev 38014)
@@ -2,8 +2,8 @@
PGM = r.out.ppm3
Modified: grass/trunk/raster/r.out.ppm3/main.c
--- grass/trunk/raster/r.out.ppm3/main.c 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/raster/r.out.ppm3/main.c 2009-06-22 01:49:13 UTC (rev 38014)
@@ -18,7 +18,7 @@
#include <stdlib.h>
#define DEF_RED 255
Modified: grass/trunk/raster/r.out.tiff/Makefile
--- grass/trunk/raster/r.out.tiff/Makefile 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/raster/r.out.tiff/Makefile 2009-06-22 01:49:13 UTC (rev 38014)
@@ -6,8 +6,8 @@
EXTRA_CFLAGS = $(TIFFINCPATH)
-LIBES = $(GISLIB) $(RASTRLIB) $(TIFFLIBPATH) $(TIFFLIB)
+LIBES = $(GISLIB) $(RASTERLIB) $(TIFFLIBPATH) $(TIFFLIB)
ifneq ($(strip $(TIFFLIB)),)
default: cmd
Modified: grass/trunk/raster/r.out.tiff/main.c
--- grass/trunk/raster/r.out.tiff/main.c 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/raster/r.out.tiff/main.c 2009-06-22 01:49:13 UTC (rev 38014)
@@ -50,7 +50,7 @@
#include <tiffio.h>
#include "rasterfile.h"
Modified: grass/trunk/raster/r.out.vrml/Makefile
--- grass/trunk/raster/r.out.vrml/Makefile 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/raster/r.out.vrml/Makefile 2009-06-22 01:49:13 UTC (rev 38014)
@@ -2,8 +2,8 @@
PGM = r.out.vrml
Modified: grass/trunk/raster/r.out.vrml/main.c
--- grass/trunk/raster/r.out.vrml/main.c 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/raster/r.out.vrml/main.c 2009-06-22 01:49:13 UTC (rev 38014)
@@ -19,7 +19,7 @@
#include <string.h>
#include <stdlib.h>
#include "pv.h"
Modified: grass/trunk/raster/r.out.vrml/pv.h
--- grass/trunk/raster/r.out.vrml/pv.h 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/raster/r.out.vrml/pv.h 2009-06-22 01:49:13 UTC (rev 38014)
@@ -1,5 +1,5 @@
/* VRML VERSION - only 1.0 currently supported
#define VRML2
Modified: grass/trunk/raster/r.out.vtk/Makefile
--- grass/trunk/raster/r.out.vtk/Makefile 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/raster/r.out.vtk/Makefile 2009-06-22 01:49:13 UTC (rev 38014)
@@ -2,8 +2,8 @@
PGM = r.out.vtk
Modified: grass/trunk/raster/r.out.vtk/main.c
--- grass/trunk/raster/r.out.vtk/main.c 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/raster/r.out.vtk/main.c 2009-06-22 01:49:13 UTC (rev 38014)
@@ -19,7 +19,7 @@
#include <stdlib.h>
#include <string.h>
#include "writeascii.h"
Modified: grass/trunk/raster/r.out.vtk/parameters.c
--- grass/trunk/raster/r.out.vtk/parameters.c 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/raster/r.out.vtk/parameters.c 2009-06-22 01:49:13 UTC (rev 38014)
@@ -16,7 +16,7 @@
#include "parameters.h"
Modified: grass/trunk/raster/r.out.vtk/writeascii.c
--- grass/trunk/raster/r.out.vtk/writeascii.c 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/raster/r.out.vtk/writeascii.c 2009-06-22 01:49:13 UTC (rev 38014)
@@ -20,7 +20,7 @@
#include <stdlib.h>
#include <string.h>
#include "globaldefs.h"
Modified: grass/trunk/raster/r.param.scale/Makefile
--- grass/trunk/raster/r.param.scale/Makefile 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/raster/r.param.scale/Makefile 2009-06-22 01:49:13 UTC (rev 38014)
@@ -2,8 +2,8 @@
PGM = r.param.scale
-LIBES = $(GISLIB) $(RASTRLIB) $(GMATHLIB)
-DEPENDENCIES = $(GISDEP) $(RASTRDEP) $(GMATHDEP)
+LIBES = $(GISLIB) $(RASTERLIB) $(GMATHLIB)
+DEPENDENCIES = $(GISDEP) $(RASTERDEP) $(GMATHDEP)
Modified: grass/trunk/raster/r.param.scale/interface.c
--- grass/trunk/raster/r.param.scale/interface.c 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/raster/r.param.scale/interface.c 2009-06-22 01:49:13 UTC (rev 38014)
@@ -14,7 +14,7 @@
#include <stdlib.h>
#include <string.h>
#include "param.h"
Modified: grass/trunk/raster/r.param.scale/nrutil.c
--- grass/trunk/raster/r.param.scale/nrutil.c 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/raster/r.param.scale/nrutil.c 2009-06-22 01:49:13 UTC (rev 38014)
@@ -2,7 +2,7 @@
#include <stddef.h>
#include <stdlib.h>
#include "nrutil.h"
Modified: grass/trunk/raster/r.param.scale/open_files.c
--- grass/trunk/raster/r.param.scale/open_files.c 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/raster/r.param.scale/open_files.c 2009-06-22 01:49:13 UTC (rev 38014)
@@ -14,7 +14,7 @@
#include "param.h"
Modified: grass/trunk/raster/r.param.scale/param.h
--- grass/trunk/raster/r.param.scale/param.h 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/raster/r.param.scale/param.h 2009-06-22 01:49:13 UTC (rev 38014)
@@ -9,7 +9,7 @@
/* programs. It sets up the necessary */
/* prototypes for GRASS library calls. */
#include <math.h>
Modified: grass/trunk/raster/r.param.scale/process.c
--- grass/trunk/raster/r.param.scale/process.c 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/raster/r.param.scale/process.c 2009-06-22 01:49:13 UTC (rev 38014)
@@ -15,7 +15,7 @@
#include <stdlib.h>
#include <grass/gmath.h>
#include "param.h"
Modified: grass/trunk/raster/r.param.scale/write_cats.c
--- grass/trunk/raster/r.param.scale/write_cats.c 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/raster/r.param.scale/write_cats.c 2009-06-22 01:49:13 UTC (rev 38014)
@@ -13,7 +13,7 @@
#include "param.h"
Modified: grass/trunk/raster/r.patch/Makefile
--- grass/trunk/raster/r.patch/Makefile 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/raster/r.patch/Makefile 2009-06-22 01:49:13 UTC (rev 38014)
@@ -2,8 +2,8 @@
PGM = r.patch
Modified: grass/trunk/raster/r.patch/do_patch.c
--- grass/trunk/raster/r.patch/do_patch.c 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/raster/r.patch/do_patch.c 2009-06-22 01:49:13 UTC (rev 38014)
@@ -1,5 +1,5 @@
* patch in non-zero data over zero data
* keep track of the categories which are patched in
Modified: grass/trunk/raster/r.patch/main.c
--- grass/trunk/raster/r.patch/main.c 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/raster/r.patch/main.c 2009-06-22 01:49:13 UTC (rev 38014)
@@ -17,7 +17,7 @@
#include <stdlib.h>
#include <unistd.h>
#include "nfiles.h"
Modified: grass/trunk/raster/r.patch/support.c
--- grass/trunk/raster/r.patch/support.c 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/raster/r.patch/support.c 2009-06-22 01:49:13 UTC (rev 38014)
@@ -1,5 +1,5 @@
* creates new category and color structures from the patching
* files category and color files
Modified: grass/trunk/raster/r.profile/Makefile
--- grass/trunk/raster/r.profile/Makefile 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/raster/r.profile/Makefile 2009-06-22 01:49:13 UTC (rev 38014)
@@ -2,8 +2,8 @@
PGM = r.profile
Modified: grass/trunk/raster/r.profile/local_proto.h
--- grass/trunk/raster/r.profile/local_proto.h 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/raster/r.profile/local_proto.h 2009-06-22 01:49:13 UTC (rev 38014)
@@ -3,7 +3,7 @@
#include <string.h>
#include <math.h>
/* main.c */
Modified: grass/trunk/raster/r.profile/main.c
--- grass/trunk/raster/r.profile/main.c 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/raster/r.profile/main.c 2009-06-22 01:49:13 UTC (rev 38014)
@@ -9,7 +9,7 @@
#include <stdlib.h>
Modified: grass/trunk/raster/r.profile/read_rast.c
--- grass/trunk/raster/r.profile/read_rast.c 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/raster/r.profile/read_rast.c 2009-06-22 01:49:13 UTC (rev 38014)
@@ -8,7 +8,7 @@
Modified: grass/trunk/raster/r.proj/Makefile
--- grass/trunk/raster/r.proj/Makefile 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/raster/r.proj/Makefile 2009-06-22 01:49:13 UTC (rev 38014)
@@ -2,8 +2,8 @@
PGM = r.proj
-DEPENDENCIES = $(GPROJDEP) $(GISDEP) $(RASTRDEP)
+DEPENDENCIES = $(GPROJDEP) $(GISDEP) $(RASTERDEP)
EXTRA_INC = $(PROJINC)
Modified: grass/trunk/raster/r.proj/bilinear.c
--- grass/trunk/raster/r.proj/bilinear.c 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/raster/r.proj/bilinear.c 2009-06-22 01:49:13 UTC (rev 38014)
@@ -12,7 +12,7 @@
#include <math.h>
#include "r.proj.h"
void p_bilinear(struct cache *ibuffer, /* input buffer */
Modified: grass/trunk/raster/r.proj/bilinear_f.c
--- grass/trunk/raster/r.proj/bilinear_f.c 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/raster/r.proj/bilinear_f.c 2009-06-22 01:49:13 UTC (rev 38014)
@@ -9,7 +9,7 @@
#include "r.proj.h"
void p_bilinear_f(struct cache *ibuffer, /* input buffer */
Modified: grass/trunk/raster/r.proj/bordwalk.c
--- grass/trunk/raster/r.proj/bordwalk.c 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/raster/r.proj/bordwalk.c 2009-06-22 01:49:13 UTC (rev 38014)
@@ -28,7 +28,7 @@
#include <math.h>
#include <stdio.h>
Modified: grass/trunk/raster/r.proj/cubic.c
--- grass/trunk/raster/r.proj/cubic.c 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/raster/r.proj/cubic.c 2009-06-22 01:49:13 UTC (rev 38014)
@@ -13,7 +13,7 @@
#include <math.h>
#include "r.proj.h"
Modified: grass/trunk/raster/r.proj/cubic_f.c
--- grass/trunk/raster/r.proj/cubic_f.c 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/raster/r.proj/cubic_f.c 2009-06-22 01:49:13 UTC (rev 38014)
@@ -10,7 +10,7 @@
#include "r.proj.h"
void p_cubic_f(struct cache *ibuffer, /* input buffer */
Modified: grass/trunk/raster/r.proj/main.c
--- grass/trunk/raster/r.proj/main.c 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/raster/r.proj/main.c 2009-06-22 01:49:13 UTC (rev 38014)
@@ -58,7 +58,7 @@
#include <string.h>
#include <unistd.h>
#include "r.proj.h"
Modified: grass/trunk/raster/r.proj/nearest.c
--- grass/trunk/raster/r.proj/nearest.c 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/raster/r.proj/nearest.c 2009-06-22 01:49:13 UTC (rev 38014)
@@ -6,7 +6,7 @@
#include <math.h>
#include "r.proj.h"
void p_nearest(struct cache *ibuffer, /* input buffer */
Modified: grass/trunk/raster/r.proj/readcell.c
--- grass/trunk/raster/r.proj/readcell.c 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/raster/r.proj/readcell.c 2009-06-22 01:49:13 UTC (rev 38014)
@@ -11,7 +11,7 @@
#include <fcntl.h>
#include <unistd.h>
#include "r.proj.h"
Modified: grass/trunk/raster/r.quant/Makefile
--- grass/trunk/raster/r.quant/Makefile 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/raster/r.quant/Makefile 2009-06-22 01:49:13 UTC (rev 38014)
@@ -2,8 +2,8 @@
PGM = r.quant
Modified: grass/trunk/raster/r.quant/global.h
--- grass/trunk/raster/r.quant/global.h 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/raster/r.quant/global.h 2009-06-22 01:49:13 UTC (rev 38014)
@@ -1,5 +1,5 @@
extern struct Quant quant_struct;
extern CELL old_min, old_max;
Modified: grass/trunk/raster/r.quantile/Makefile
--- grass/trunk/raster/r.quantile/Makefile 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/raster/r.quantile/Makefile 2009-06-22 01:49:13 UTC (rev 38014)
@@ -2,8 +2,8 @@
PGM = r.quantile
Modified: grass/trunk/raster/r.quantile/main.c
--- grass/trunk/raster/r.quantile/main.c 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/raster/r.quantile/main.c 2009-06-22 01:49:13 UTC (rev 38014)
@@ -14,7 +14,7 @@
#include <string.h>
#include <math.h>
struct bin
Modified: grass/trunk/raster/r.random/Makefile
--- grass/trunk/raster/r.random/Makefile 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/raster/r.random/Makefile 2009-06-22 01:49:13 UTC (rev 38014)
@@ -2,8 +2,8 @@
PGM = r.random
-LIBES = $(VECTLIB) $(GISLIB) $(RASTRLIB) $(SEGMENTLIB) $(DATETIMELIB)
-DEPENDENCIES = $(VECTDEP) $(GISDEP) $(RASTRDEP) $(SEGMENTDEP) $(DATETIMEDEP)
+LIBES = $(VECTLIB) $(GISLIB) $(RASTERLIB) $(SEGMENTLIB) $(DATETIMELIB)
+DEPENDENCIES = $(VECTDEP) $(GISDEP) $(RASTERDEP) $(SEGMENTDEP) $(DATETIMEDEP)
EXTRA_INC = $(VECT_INC)
EXTRA_CFLAGS = $(VECT_CFLAGS)
Modified: grass/trunk/raster/r.random/count.c
--- grass/trunk/raster/r.random/count.c 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/raster/r.random/count.c 2009-06-22 01:49:13 UTC (rev 38014)
@@ -3,7 +3,7 @@
#include <math.h>
#include <unistd.h>
#include <grass/glocale.h>
Modified: grass/trunk/raster/r.random/main.c
--- grass/trunk/raster/r.random/main.c 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/raster/r.random/main.c 2009-06-22 01:49:13 UTC (rev 38014)
@@ -22,7 +22,7 @@
#include <stdlib.h>
Modified: grass/trunk/raster/r.random/random.c
--- grass/trunk/raster/r.random/random.c 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/raster/r.random/random.c 2009-06-22 01:49:13 UTC (rev 38014)
@@ -1,6 +1,6 @@
#include <stdlib.h>
#include <grass/dbmi.h>
#include <grass/Vect.h>
Modified: grass/trunk/raster/r.random/support.c
--- grass/trunk/raster/r.random/support.c 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/raster/r.random/support.c 2009-06-22 01:49:13 UTC (rev 38014)
@@ -1,5 +1,5 @@
Modified: grass/trunk/raster/r.random.cells/Makefile
--- grass/trunk/raster/r.random.cells/Makefile 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/raster/r.random.cells/Makefile 2009-06-22 01:49:13 UTC (rev 38014)
@@ -2,8 +2,8 @@
PGM = r.random.cells
Modified: grass/trunk/raster/r.random.cells/flag.c
--- grass/trunk/raster/r.random.cells/flag.c 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/raster/r.random.cells/flag.c 2009-06-22 01:49:13 UTC (rev 38014)
@@ -1,6 +1,6 @@
#include <stdlib.h>
#include "flag.h"
Modified: grass/trunk/raster/r.random.cells/indep.c
--- grass/trunk/raster/r.random.cells/indep.c 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/raster/r.random.cells/indep.c 2009-06-22 01:49:13 UTC (rev 38014)
@@ -1,6 +1,6 @@
/* indep.c */
#include "ransurf.h"
Modified: grass/trunk/raster/r.random.cells/init.c
--- grass/trunk/raster/r.random.cells/init.c 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/raster/r.random.cells/init.c 2009-06-22 01:49:13 UTC (rev 38014)
@@ -3,7 +3,7 @@
#include <unistd.h>
Modified: grass/trunk/raster/r.random.cells/main.c
--- grass/trunk/raster/r.random.cells/main.c 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/raster/r.random.cells/main.c 2009-06-22 01:49:13 UTC (rev 38014)
@@ -18,7 +18,7 @@
#include <stdlib.h>
Modified: grass/trunk/raster/r.random.cells/random.c
--- grass/trunk/raster/r.random.cells/random.c 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/raster/r.random.cells/random.c 2009-06-22 01:49:13 UTC (rev 38014)
@@ -1,6 +1,6 @@
/* random.c */
Modified: grass/trunk/raster/r.random.cells/ransurf.h
--- grass/trunk/raster/r.random.cells/ransurf.h 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/raster/r.random.cells/ransurf.h 2009-06-22 01:49:13 UTC (rev 38014)
@@ -3,7 +3,7 @@
#include <stdio.h>
#include <math.h>
#include "flag.h"
#define ODD(a) ((a) & 1)
Modified: grass/trunk/raster/r.random.surface/Makefile
--- grass/trunk/raster/r.random.surface/Makefile 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/raster/r.random.surface/Makefile 2009-06-22 01:49:13 UTC (rev 38014)
@@ -2,8 +2,8 @@
PGM = r.random.surface
Modified: grass/trunk/raster/r.random.surface/calcsurf.c
--- grass/trunk/raster/r.random.surface/calcsurf.c 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/raster/r.random.surface/calcsurf.c 2009-06-22 01:49:13 UTC (rev 38014)
@@ -1,7 +1,7 @@
/* calcsurf.c */
#include <stdlib.h>
Modified: grass/trunk/raster/r.random.surface/gennorm.c
--- grass/trunk/raster/r.random.surface/gennorm.c 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/raster/r.random.surface/gennorm.c 2009-06-22 01:49:13 UTC (rev 38014)
@@ -1,7 +1,7 @@
/* gennorm.c */
#include <math.h>
void GenNorm(void)
Modified: grass/trunk/raster/r.random.surface/init.c
--- grass/trunk/raster/r.random.surface/init.c 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/raster/r.random.surface/init.c 2009-06-22 01:49:13 UTC (rev 38014)
@@ -5,7 +5,7 @@
#include <unistd.h>
Modified: grass/trunk/raster/r.random.surface/main.c
--- grass/trunk/raster/r.random.surface/main.c 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/raster/r.random.surface/main.c 2009-06-22 01:49:13 UTC (rev 38014)
@@ -24,7 +24,7 @@
#include <stdlib.h>
#include <stdio.h>
-#include <grass/Rast.h>
+#include <grass/raster.h>
Modified: grass/trunk/raster/r.random.surface/random.c
--- grass/trunk/raster/r.random.surface/random.c 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/raster/r.random.surface/random.c 2009-06-22 01:49:13 UTC (rev 38014)
@@ -1,6 +1,6 @@
/* random.c */
#define M1 259200
Modified: grass/trunk/raster/r.random.surface/ransurf.h
--- grass/trunk/raster/r.random.surface/ransurf.h 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/raster/r.random.surface/ransurf.h 2009-06-22 01:49:13 UTC (rev 38014)
@@ -5,7 +5,7 @@
#include <stdio.h>
#include <math.h>
Modified: grass/trunk/raster/r.random.surface/save.c
--- grass/trunk/raster/r.random.surface/save.c 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/raster/r.random.surface/save.c 2009-06-22 01:49:13 UTC (rev 38014)
@@ -1,7 +1,7 @@
/* save.c */
#include <string.h>
Modified: grass/trunk/raster/r.reclass/Makefile
--- grass/trunk/raster/r.reclass/Makefile 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/raster/r.reclass/Makefile 2009-06-22 01:49:13 UTC (rev 38014)
@@ -2,8 +2,8 @@
PGM = r.reclass
Modified: grass/trunk/raster/r.reclass/input.c
--- grass/trunk/raster/r.reclass/input.c 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/raster/r.reclass/input.c 2009-06-22 01:49:13 UTC (rev 38014)
@@ -2,7 +2,7 @@
#include <unistd.h>
#include <string.h>
int input(FILE * fp, int tty, char *buf)
Modified: grass/trunk/raster/r.reclass/main.c
--- grass/trunk/raster/r.reclass/main.c 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/raster/r.reclass/main.c 2009-06-22 01:49:13 UTC (rev 38014)
@@ -19,7 +19,7 @@
#include <string.h>
#include <unistd.h>
#include "rule.h"
Modified: grass/trunk/raster/r.reclass/parse.c
--- grass/trunk/raster/r.reclass/parse.c 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/raster/r.reclass/parse.c 2009-06-22 01:49:13 UTC (rev 38014)
@@ -1,6 +1,6 @@
#include <string.h>
#include "rule.h"
Modified: grass/trunk/raster/r.reclass/range.c
--- grass/trunk/raster/r.reclass/range.c 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/raster/r.reclass/range.c 2009-06-22 01:49:13 UTC (rev 38014)
@@ -1,5 +1,5 @@
int new_range(char *name, struct Reclass *reclass)
Modified: grass/trunk/raster/r.reclass/reclass.c
--- grass/trunk/raster/r.reclass/reclass.c 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/raster/r.reclass/reclass.c 2009-06-22 01:49:13 UTC (rev 38014)
@@ -1,7 +1,7 @@
#include <stdlib.h>
#include <string.h>
#include "rule.h"
Modified: grass/trunk/raster/r.reclass/rule.h
--- grass/trunk/raster/r.reclass/rule.h 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/raster/r.reclass/rule.h 2009-06-22 01:49:13 UTC (rev 38014)
@@ -1,6 +1,6 @@
#include <stdio.h>
#define RULE struct _rule_
RULE {
Modified: grass/trunk/raster/r.reclass/stats.c
--- grass/trunk/raster/r.reclass/stats.c 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/raster/r.reclass/stats.c 2009-06-22 01:49:13 UTC (rev 38014)
@@ -1,5 +1,5 @@
#include "rule.h"
#define LIST struct Histogram_list
Modified: grass/trunk/raster/r.recode/Makefile
--- grass/trunk/raster/r.recode/Makefile 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/raster/r.recode/Makefile 2009-06-22 01:49:13 UTC (rev 38014)
@@ -2,8 +2,8 @@
PGM = r.recode
Modified: grass/trunk/raster/r.recode/global.h
--- grass/trunk/raster/r.recode/global.h 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/raster/r.recode/global.h 2009-06-22 01:49:13 UTC (rev 38014)
@@ -1,6 +1,6 @@
#include <stdio.h>
extern RASTER_MAP_TYPE in_type;
extern RASTER_MAP_TYPE out_type;
Modified: grass/trunk/raster/r.recode/main.c
--- grass/trunk/raster/r.recode/main.c 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/raster/r.recode/main.c 2009-06-22 01:49:13 UTC (rev 38014)
@@ -19,7 +19,7 @@
#include <string.h>
#include <unistd.h>
#include "global.h"
Modified: grass/trunk/raster/r.region/Makefile
--- grass/trunk/raster/r.region/Makefile 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/raster/r.region/Makefile 2009-06-22 01:49:13 UTC (rev 38014)
@@ -2,8 +2,8 @@
PGM = r.region
Modified: grass/trunk/raster/r.region/main.c
--- grass/trunk/raster/r.region/main.c 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/raster/r.region/main.c 2009-06-22 01:49:13 UTC (rev 38014)
@@ -16,7 +16,7 @@
#include <string.h>
#include <stdlib.h>
Modified: grass/trunk/raster/r.report/Makefile
--- grass/trunk/raster/r.report/Makefile 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/raster/r.report/Makefile 2009-06-22 01:49:13 UTC (rev 38014)
@@ -2,8 +2,8 @@
PGM = r.report
Modified: grass/trunk/raster/r.report/global.h
--- grass/trunk/raster/r.report/global.h 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/raster/r.report/global.h 2009-06-22 01:49:13 UTC (rev 38014)
@@ -6,7 +6,7 @@
#endif
extern struct Cell_head window;
Modified: grass/trunk/raster/r.report/maskinfo.c
--- grass/trunk/raster/r.report/maskinfo.c 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/raster/r.report/maskinfo.c 2009-06-22 01:49:13 UTC (rev 38014)
@@ -1,6 +1,6 @@
#include <string.h>
static char *append(char *, char *);
static int do_text(char *, long, long);
Modified: grass/trunk/raster/r.resamp.interp/Makefile
--- grass/trunk/raster/r.resamp.interp/Makefile 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/raster/r.resamp.interp/Makefile 2009-06-22 01:49:13 UTC (rev 38014)
@@ -2,8 +2,8 @@
PGM = r.resamp.interp
Modified: grass/trunk/raster/r.resamp.interp/main.c
--- grass/trunk/raster/r.resamp.interp/main.c 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/raster/r.resamp.interp/main.c 2009-06-22 01:49:13 UTC (rev 38014)
@@ -17,7 +17,7 @@
#include <string.h>
#include <math.h>
static int neighbors;
Modified: grass/trunk/raster/r.resamp.rst/main.c
--- grass/trunk/raster/r.resamp.rst/main.c 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/raster/r.resamp.rst/main.c 2009-06-22 01:49:13 UTC (rev 38014)
@@ -37,7 +37,7 @@
#include <grass/linkm.h>
#include <grass/bitmap.h>
#include "surf.h"
Modified: grass/trunk/raster/r.resamp.stats/main.c
--- grass/trunk/raster/r.resamp.stats/main.c 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/raster/r.resamp.stats/main.c 2009-06-22 01:49:13 UTC (rev 38014)
@@ -16,7 +16,7 @@
#include <string.h>
#include <math.h>
Modified: grass/trunk/raster/r.resample/Makefile
--- grass/trunk/raster/r.resample/Makefile 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/raster/r.resample/Makefile 2009-06-22 01:49:13 UTC (rev 38014)
@@ -2,8 +2,8 @@
PGM = r.resample
Modified: grass/trunk/raster/r.resample/main.c
--- grass/trunk/raster/r.resample/main.c 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/raster/r.resample/main.c 2009-06-22 01:49:13 UTC (rev 38014)
@@ -23,7 +23,7 @@
#include <string.h>
#include <stdio.h>
int main(int argc, char *argv[])
Modified: grass/trunk/raster/r.rescale/Makefile
--- grass/trunk/raster/r.rescale/Makefile 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/raster/r.rescale/Makefile 2009-06-22 01:49:13 UTC (rev 38014)
@@ -2,8 +2,8 @@
PGM = r.rescale
Modified: grass/trunk/raster/r.rescale/get_range.c
--- grass/trunk/raster/r.rescale/get_range.c 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/raster/r.rescale/get_range.c 2009-06-22 01:49:13 UTC (rev 38014)
@@ -1,6 +1,6 @@
#include <stdlib.h>
Modified: grass/trunk/raster/r.rescale/main.c
--- grass/trunk/raster/r.rescale/main.c 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/raster/r.rescale/main.c 2009-06-22 01:49:13 UTC (rev 38014)
@@ -16,7 +16,7 @@
#include <stdio.h>
#include <string.h>
Modified: grass/trunk/raster/r.rescale.eq/Makefile
--- grass/trunk/raster/r.rescale.eq/Makefile 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/raster/r.rescale.eq/Makefile 2009-06-22 01:49:13 UTC (rev 38014)
@@ -2,8 +2,8 @@
PGM = r.rescale.eq
Modified: grass/trunk/raster/r.rescale.eq/get_range.c
--- grass/trunk/raster/r.rescale.eq/get_range.c 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/raster/r.rescale.eq/get_range.c 2009-06-22 01:49:13 UTC (rev 38014)
@@ -1,5 +1,5 @@
int get_range(struct Cell_stats *statf, CELL * min, CELL * max, int zero)
Modified: grass/trunk/raster/r.rescale.eq/get_stats.c
--- grass/trunk/raster/r.rescale.eq/get_stats.c 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/raster/r.rescale.eq/get_stats.c 2009-06-22 01:49:13 UTC (rev 38014)
@@ -1,6 +1,6 @@
#include <stdlib.h>
Modified: grass/trunk/raster/r.rescale.eq/main.c
--- grass/trunk/raster/r.rescale.eq/main.c 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/raster/r.rescale.eq/main.c 2009-06-22 01:49:13 UTC (rev 38014)
@@ -17,7 +17,7 @@
#include <stdio.h>
#include <string.h>
Modified: grass/trunk/raster/r.ros/Makefile
--- grass/trunk/raster/r.ros/Makefile 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/raster/r.ros/Makefile 2009-06-22 01:49:13 UTC (rev 38014)
@@ -2,8 +2,8 @@
PGM = r.ros
Modified: grass/trunk/raster/r.ros/main.c
--- grass/trunk/raster/r.ros/main.c 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/raster/r.ros/main.c 2009-06-22 01:49:13 UTC (rev 38014)
@@ -68,7 +68,7 @@
#include <stdio.h>
#include <math.h>
Modified: grass/trunk/raster/r.ros/spot_dist.c
--- grass/trunk/raster/r.ros/spot_dist.c 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/raster/r.ros/spot_dist.c 2009-06-22 01:49:13 UTC (rev 38014)
@@ -33,7 +33,7 @@
#include <math.h>
Modified: grass/trunk/raster/r.series/main.c
--- grass/trunk/raster/r.series/main.c 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/raster/r.series/main.c 2009-06-22 01:49:13 UTC (rev 38014)
@@ -18,7 +18,7 @@
#include <unistd.h>
Modified: grass/trunk/raster/r.slope.aspect/Makefile
--- grass/trunk/raster/r.slope.aspect/Makefile 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/raster/r.slope.aspect/Makefile 2009-06-22 01:49:13 UTC (rev 38014)
@@ -2,8 +2,8 @@
PGM = r.slope.aspect
Modified: grass/trunk/raster/r.slope.aspect/main.c
--- grass/trunk/raster/r.slope.aspect/main.c 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/raster/r.slope.aspect/main.c 2009-06-22 01:49:13 UTC (rev 38014)
@@ -26,7 +26,7 @@
#include <string.h>
#include <math.h>
Modified: grass/trunk/raster/r.slope.aspect/opennew.c
--- grass/trunk/raster/r.slope.aspect/opennew.c 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/raster/r.slope.aspect/opennew.c 2009-06-22 01:49:13 UTC (rev 38014)
@@ -1,6 +1,6 @@
#include <stdlib.h>
Modified: grass/trunk/raster/r.spread/Makefile
--- grass/trunk/raster/r.spread/Makefile 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/raster/r.spread/Makefile 2009-06-22 01:49:13 UTC (rev 38014)
@@ -6,10 +6,10 @@
MOD_OBJS := $(filter-out display.o,$(AUTO_OBJS))
-# LIBES = $(DISPLAYLIB) $(GISLIB) $(RASTRLIB)
-# DEPENDENCIES = $(DISPLAYDEP) $(GISDEP) $(RASTRDEP)
+# LIBES = $(DISPLAYLIB) $(GISLIB) $(RASTERLIB)
+# DEPENDENCIES = $(DISPLAYDEP) $(GISDEP) $(RASTERDEP)
Modified: grass/trunk/raster/r.spread/collect_ori.c
--- grass/trunk/raster/r.spread/collect_ori.c 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/raster/r.spread/collect_ori.c 2009-06-22 01:49:13 UTC (rev 38014)
@@ -12,7 +12,7 @@
#include <stdio.h>
#include <stdlib.h>
#include "cmd_line.h"
#include "costHa.h"
Modified: grass/trunk/raster/r.spread/display.c
--- grass/trunk/raster/r.spread/display.c 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/raster/r.spread/display.c 2009-06-22 01:49:13 UTC (rev 38014)
@@ -3,7 +3,7 @@
#include <string.h>
#include <time.h>
#include <grass/display.h>
#include <grass/display_raster.h>
Modified: grass/trunk/raster/r.spread/insert2Ha.c
--- grass/trunk/raster/r.spread/insert2Ha.c 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/raster/r.spread/insert2Ha.c 2009-06-22 01:49:13 UTC (rev 38014)
@@ -12,7 +12,7 @@
#include "cell_ptrHa.h"
Modified: grass/trunk/raster/r.spread/main.c
--- grass/trunk/raster/r.spread/main.c 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/raster/r.spread/main.c 2009-06-22 01:49:13 UTC (rev 38014)
@@ -31,7 +31,7 @@
#include <sys/types.h>
#include <unistd.h>
#include "costHa.h"
Modified: grass/trunk/raster/r.spread/ram2out.c
--- grass/trunk/raster/r.spread/ram2out.c 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/raster/r.spread/ram2out.c 2009-06-22 01:49:13 UTC (rev 38014)
@@ -1,6 +1,6 @@
#include <stdio.h>
#include "costHa.h"
Modified: grass/trunk/raster/r.spread/replaceHa.c
--- grass/trunk/raster/r.spread/replaceHa.c 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/raster/r.spread/replaceHa.c 2009-06-22 01:49:13 UTC (rev 38014)
@@ -12,7 +12,7 @@
#include <stdio.h>
#include <stdlib.h>
#include "costHa.h"
Modified: grass/trunk/raster/r.spread/select_linksB.c
--- grass/trunk/raster/r.spread/select_linksB.c 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/raster/r.spread/select_linksB.c 2009-06-22 01:49:13 UTC (rev 38014)
@@ -20,7 +20,7 @@
#include <stdio.h>
#include <math.h>
#include "costHa.h"
Modified: grass/trunk/raster/r.spread/spot.c
--- grass/trunk/raster/r.spread/spot.c 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/raster/r.spread/spot.c 2009-06-22 01:49:13 UTC (rev 38014)
@@ -44,7 +44,7 @@
#include <stdio.h>
#include <math.h>
#include "costHa.h"
Modified: grass/trunk/raster/r.spread/spread.c
--- grass/trunk/raster/r.spread/spread.c 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/raster/r.spread/spread.c 2009-06-22 01:49:13 UTC (rev 38014)
@@ -33,7 +33,7 @@
#include <stdlib.h>
#include <math.h>
#include "costHa.h"
Modified: grass/trunk/raster/r.spreadpath/Makefile
--- grass/trunk/raster/r.spreadpath/Makefile 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/raster/r.spreadpath/Makefile 2009-06-22 01:49:13 UTC (rev 38014)
@@ -2,8 +2,8 @@
PGM = r.spreadpath
-LIBES = $(SEGMENTLIB) $(GISLIB) $(RASTRLIB)
-DEPENDENCIES = $(SEGMENTDEP) $(GISDEP) $(RASTRDEP)
+LIBES = $(SEGMENTLIB) $(GISLIB) $(RASTERLIB)
+DEPENDENCIES = $(SEGMENTDEP) $(GISDEP) $(RASTERDEP)
Modified: grass/trunk/raster/r.spreadpath/insert.c
--- grass/trunk/raster/r.spreadpath/insert.c 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/raster/r.spreadpath/insert.c 2009-06-22 01:49:13 UTC (rev 38014)
@@ -1,5 +1,5 @@
#include <grass/segment.h>
#include "point.h"
Modified: grass/trunk/raster/r.spreadpath/main.c
--- grass/trunk/raster/r.spreadpath/main.c 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/raster/r.spreadpath/main.c 2009-06-22 01:49:13 UTC (rev 38014)
@@ -33,7 +33,7 @@
#include <fcntl.h>
#include "stash.h"
Modified: grass/trunk/raster/r.statistics/Makefile
--- grass/trunk/raster/r.statistics/Makefile 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/raster/r.statistics/Makefile 2009-06-22 01:49:13 UTC (rev 38014)
@@ -2,8 +2,8 @@
PGM = r.statistics
Modified: grass/trunk/raster/r.statistics/main.c
--- grass/trunk/raster/r.statistics/main.c 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/raster/r.statistics/main.c 2009-06-22 01:49:13 UTC (rev 38014)
@@ -18,7 +18,7 @@
#include <string.h>
#include <stdlib.h>
#include "method.h"
Modified: grass/trunk/raster/r.statistics/o_adev.c
--- grass/trunk/raster/r.statistics/o_adev.c 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/raster/r.statistics/o_adev.c 2009-06-22 01:49:13 UTC (rev 38014)
@@ -3,7 +3,7 @@
#include <stdlib.h>
#include <unistd.h>
#include "method.h"
Modified: grass/trunk/raster/r.statistics/o_average.c
--- grass/trunk/raster/r.statistics/o_average.c 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/raster/r.statistics/o_average.c 2009-06-22 01:49:13 UTC (rev 38014)
@@ -1,7 +1,7 @@
#include <stdlib.h>
#include <unistd.h>
#include "method.h"
Modified: grass/trunk/raster/r.statistics/o_distrib.c
--- grass/trunk/raster/r.statistics/o_distrib.c 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/raster/r.statistics/o_distrib.c 2009-06-22 01:49:13 UTC (rev 38014)
@@ -1,7 +1,7 @@
#include <stdlib.h>
#include <unistd.h>
#include "method.h"
Modified: grass/trunk/raster/r.statistics/o_divr.c
--- grass/trunk/raster/r.statistics/o_divr.c 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/raster/r.statistics/o_divr.c 2009-06-22 01:49:13 UTC (rev 38014)
@@ -1,7 +1,7 @@
#include <stdlib.h>
#include <unistd.h>
#include "method.h"
int
Modified: grass/trunk/raster/r.statistics/o_kurt.c
--- grass/trunk/raster/r.statistics/o_kurt.c 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/raster/r.statistics/o_kurt.c 2009-06-22 01:49:13 UTC (rev 38014)
@@ -3,7 +3,7 @@
#include <stdlib.h>
#include <unistd.h>
#include "method.h"
Modified: grass/trunk/raster/r.statistics/o_max.c
--- grass/trunk/raster/r.statistics/o_max.c 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/raster/r.statistics/o_max.c 2009-06-22 01:49:13 UTC (rev 38014)
@@ -1,7 +1,7 @@
#include <stdlib.h>
#include <unistd.h>
#include "method.h"
int
Modified: grass/trunk/raster/r.statistics/o_median.c
--- grass/trunk/raster/r.statistics/o_median.c 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/raster/r.statistics/o_median.c 2009-06-22 01:49:13 UTC (rev 38014)
@@ -1,7 +1,7 @@
#include <stdlib.h>
#include <unistd.h>
#include "method.h"
/* function prototypes */
Modified: grass/trunk/raster/r.statistics/o_min.c
--- grass/trunk/raster/r.statistics/o_min.c 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/raster/r.statistics/o_min.c 2009-06-22 01:49:13 UTC (rev 38014)
@@ -1,7 +1,7 @@
#include <stdlib.h>
#include <unistd.h>
#include "method.h"
int
Modified: grass/trunk/raster/r.statistics/o_mode.c
--- grass/trunk/raster/r.statistics/o_mode.c 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/raster/r.statistics/o_mode.c 2009-06-22 01:49:13 UTC (rev 38014)
@@ -1,7 +1,7 @@
#include <stdlib.h>
#include <unistd.h>
#include "method.h"
int
Modified: grass/trunk/raster/r.statistics/o_sdev.c
--- grass/trunk/raster/r.statistics/o_sdev.c 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/raster/r.statistics/o_sdev.c 2009-06-22 01:49:13 UTC (rev 38014)
@@ -3,7 +3,7 @@
#include <stdlib.h>
#include <unistd.h>
#include "method.h"
Modified: grass/trunk/raster/r.statistics/o_skew.c
--- grass/trunk/raster/r.statistics/o_skew.c 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/raster/r.statistics/o_skew.c 2009-06-22 01:49:13 UTC (rev 38014)
@@ -3,7 +3,7 @@
#include <stdlib.h>
#include <unistd.h>
#include "method.h"
Modified: grass/trunk/raster/r.statistics/o_sum.c
--- grass/trunk/raster/r.statistics/o_sum.c 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/raster/r.statistics/o_sum.c 2009-06-22 01:49:13 UTC (rev 38014)
@@ -1,7 +1,7 @@
#include <stdlib.h>
#include <unistd.h>
#include "method.h"
Modified: grass/trunk/raster/r.statistics/o_var.c
--- grass/trunk/raster/r.statistics/o_var.c 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/raster/r.statistics/o_var.c 2009-06-22 01:49:13 UTC (rev 38014)
@@ -3,7 +3,7 @@
#include <stdlib.h>
#include <unistd.h>
#include "method.h"
Modified: grass/trunk/raster/r.statistics/read_stats.c
--- grass/trunk/raster/r.statistics/read_stats.c 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/raster/r.statistics/read_stats.c 2009-06-22 01:49:13 UTC (rev 38014)
@@ -1,7 +1,7 @@
#include <stdlib.h>
#include <stdio.h>
Modified: grass/trunk/raster/r.statistics2/Makefile
--- grass/trunk/raster/r.statistics2/Makefile 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/raster/r.statistics2/Makefile 2009-06-22 01:49:13 UTC (rev 38014)
@@ -2,8 +2,8 @@
PGM = r.statistics2
Modified: grass/trunk/raster/r.statistics2/main.c
--- grass/trunk/raster/r.statistics2/main.c 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/raster/r.statistics2/main.c 2009-06-22 01:49:13 UTC (rev 38014)
@@ -21,7 +21,7 @@
#include <stdlib.h>
#include <math.h>
#include <grass/spawn.h>
Modified: grass/trunk/raster/r.statistics3/Makefile
--- grass/trunk/raster/r.statistics3/Makefile 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/raster/r.statistics3/Makefile 2009-06-22 01:49:13 UTC (rev 38014)
@@ -2,8 +2,8 @@
PGM = r.statistics3
Modified: grass/trunk/raster/r.statistics3/main.c
--- grass/trunk/raster/r.statistics3/main.c 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/raster/r.statistics3/main.c 2009-06-22 01:49:13 UTC (rev 38014)
@@ -14,7 +14,7 @@
#include <string.h>
#include <math.h>
Modified: grass/trunk/raster/r.stats/Makefile
--- grass/trunk/raster/r.stats/Makefile 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/raster/r.stats/Makefile 2009-06-22 01:49:13 UTC (rev 38014)
@@ -2,8 +2,8 @@
PGM = r.stats
Modified: grass/trunk/raster/r.stats/global.h
--- grass/trunk/raster/r.stats/global.h 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/raster/r.stats/global.h 2009-06-22 01:49:13 UTC (rev 38014)
@@ -1,5 +1,5 @@
extern char *no_data_str;
extern int nfiles;
Modified: grass/trunk/raster/r.stats/raw_stats.c
--- grass/trunk/raster/r.stats/raw_stats.c 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/raster/r.stats/raw_stats.c 2009-06-22 01:49:13 UTC (rev 38014)
@@ -1,6 +1,6 @@
#include <stdlib.h>
#include "global.h"
int raw_stats(int fd[], int with_coordinates, int with_xy, int with_labels)
Modified: grass/trunk/raster/r.sun2/Makefile
--- grass/trunk/raster/r.sun2/Makefile 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/raster/r.sun2/Makefile 2009-06-22 01:49:13 UTC (rev 38014)
@@ -2,8 +2,8 @@
PGM = r.sun
-LIBES = $(GPROJLIB) $(GISLIB) $(RASTRLIB)
+LIBES = $(GPROJLIB) $(GISLIB) $(RASTERLIB)
Modified: grass/trunk/raster/r.sun2/main.c
--- grass/trunk/raster/r.sun2/main.c 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/raster/r.sun2/main.c 2009-06-22 01:49:13 UTC (rev 38014)
@@ -34,7 +34,7 @@
#include <stdlib.h>
#include <math.h>
#include "sunradstruct.h"
Modified: grass/trunk/raster/r.sun2/rsunlib.c
--- grass/trunk/raster/r.sun2/rsunlib.c 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/raster/r.sun2/rsunlib.c 2009-06-22 01:49:13 UTC (rev 38014)
@@ -32,7 +32,7 @@
#include <stdio.h>
#include <math.h>
Modified: grass/trunk/raster/r.sunmask/Makefile
--- grass/trunk/raster/r.sunmask/Makefile 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/raster/r.sunmask/Makefile 2009-06-22 01:49:13 UTC (rev 38014)
@@ -2,8 +2,8 @@
PGM = r.sunmask
Modified: grass/trunk/raster/r.sunmask/g_solposition.c
--- grass/trunk/raster/r.sunmask/g_solposition.c 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/raster/r.sunmask/g_solposition.c 2009-06-22 01:49:13 UTC (rev 38014)
@@ -31,7 +31,7 @@
#include <string.h>
#include <stdio.h>
#include "solpos00.h"
Modified: grass/trunk/raster/r.sunmask/main.c
--- grass/trunk/raster/r.sunmask/main.c 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/raster/r.sunmask/main.c 2009-06-22 01:49:13 UTC (rev 38014)
@@ -45,7 +45,7 @@
#include <string.h>
#include <math.h>
Modified: grass/trunk/raster/r.sunmask/solpos00.c
--- grass/trunk/raster/r.sunmask/solpos00.c 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/raster/r.sunmask/solpos00.c 2009-06-22 01:49:13 UTC (rev 38014)
@@ -96,7 +96,7 @@
#include <string.h>
#include <stdio.h>
Modified: grass/trunk/raster/r.support/Makefile
--- grass/trunk/raster/r.support/Makefile 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/raster/r.support/Makefile 2009-06-22 01:49:13 UTC (rev 38014)
@@ -2,8 +2,8 @@
PGM = r.support
Modified: grass/trunk/raster/r.support/check.c
--- grass/trunk/raster/r.support/check.c 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/raster/r.support/check.c 2009-06-22 01:49:13 UTC (rev 38014)
@@ -1,6 +1,6 @@
#include <stdlib.h>
Modified: grass/trunk/raster/r.support/histo.c
--- grass/trunk/raster/r.support/histo.c 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/raster/r.support/histo.c 2009-06-22 01:49:13 UTC (rev 38014)
@@ -1,6 +1,6 @@
#include <stdlib.h>
Modified: grass/trunk/raster/r.support/main.c
--- grass/trunk/raster/r.support/main.c 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/raster/r.support/main.c 2009-06-22 01:49:13 UTC (rev 38014)
@@ -23,7 +23,7 @@
#include <stdlib.h>
#include <string.h>
Modified: grass/trunk/raster/r.support.stats/Makefile
--- grass/trunk/raster/r.support.stats/Makefile 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/raster/r.support.stats/Makefile 2009-06-22 01:49:13 UTC (rev 38014)
@@ -2,8 +2,8 @@
PGM = r.support.stats
Modified: grass/trunk/raster/r.support.stats/check.c
--- grass/trunk/raster/r.support.stats/check.c 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/raster/r.support.stats/check.c 2009-06-22 01:49:13 UTC (rev 38014)
@@ -17,7 +17,7 @@
#include <stdlib.h>
Modified: grass/trunk/raster/r.support.stats/histo.c
--- grass/trunk/raster/r.support.stats/histo.c 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/raster/r.support.stats/histo.c 2009-06-22 01:49:13 UTC (rev 38014)
@@ -17,7 +17,7 @@
#include <stdlib.h>
Modified: grass/trunk/raster/r.support.stats/main.c
--- grass/trunk/raster/r.support.stats/main.c 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/raster/r.support.stats/main.c 2009-06-22 01:49:13 UTC (rev 38014)
@@ -18,7 +18,7 @@
#include <stdlib.h>
#include <string.h>
Modified: grass/trunk/raster/r.surf.area/Makefile
--- grass/trunk/raster/r.surf.area/Makefile 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/raster/r.surf.area/Makefile 2009-06-22 01:49:13 UTC (rev 38014)
@@ -2,8 +2,8 @@
PGM = r.surf.area
Modified: grass/trunk/raster/r.surf.area/main.c
--- grass/trunk/raster/r.surf.area/main.c 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/raster/r.surf.area/main.c 2009-06-22 01:49:13 UTC (rev 38014)
@@ -56,7 +56,7 @@
#include <stdio.h>
#include <math.h>
Modified: grass/trunk/raster/r.surf.contour/Makefile
--- grass/trunk/raster/r.surf.contour/Makefile 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/raster/r.surf.contour/Makefile 2009-06-22 01:49:13 UTC (rev 38014)
@@ -2,8 +2,8 @@
PGM = r.surf.contour
Modified: grass/trunk/raster/r.surf.contour/contour.h
--- grass/trunk/raster/r.surf.contour/contour.h 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/raster/r.surf.contour/contour.h 2009-06-22 01:49:13 UTC (rev 38014)
@@ -1,7 +1,7 @@
#include <stdio.h>
#include <math.h>
#include "flag.h"
#define NODE struct _n_o_d_e_
Modified: grass/trunk/raster/r.surf.contour/flag_create.c
--- grass/trunk/raster/r.surf.contour/flag_create.c 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/raster/r.surf.contour/flag_create.c 2009-06-22 01:49:13 UTC (rev 38014)
@@ -1,6 +1,6 @@
#include <stdlib.h>
#include "flag.h"
FLAG *flag_create(int nrows, int ncols)
Modified: grass/trunk/raster/r.surf.contour/flag_destroy.c
--- grass/trunk/raster/r.surf.contour/flag_destroy.c 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/raster/r.surf.contour/flag_destroy.c 2009-06-22 01:49:13 UTC (rev 38014)
@@ -1,6 +1,6 @@
#include <stdlib.h>
#include "flag.h"
int flag_destroy(FLAG * flags)
Modified: grass/trunk/raster/r.surf.contour/main.c
--- grass/trunk/raster/r.surf.contour/main.c 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/raster/r.surf.contour/main.c 2009-06-22 01:49:13 UTC (rev 38014)
@@ -25,7 +25,7 @@
#include "contour.h"
#include <unistd.h>
int nrows;
Modified: grass/trunk/raster/r.surf.fractal/Makefile
--- grass/trunk/raster/r.surf.fractal/Makefile 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/raster/r.surf.fractal/Makefile 2009-06-22 01:49:13 UTC (rev 38014)
@@ -2,8 +2,8 @@
PGM = r.surf.fractal
-LIBES = $(GMATHLIB) $(GISLIB) $(RASTRLIB) $(FFTWLIB)
-DEPENDENCIES = $(GMATHDEP) $(GISDEP) $(RASTRDEP)
+LIBES = $(GMATHLIB) $(GISLIB) $(RASTERLIB) $(FFTWLIB)
+DEPENDENCIES = $(GMATHDEP) $(GISDEP) $(RASTERDEP)
EXTRA_INC = $(FFTWINC)
Modified: grass/trunk/raster/r.surf.fractal/frac.h
--- grass/trunk/raster/r.surf.fractal/frac.h 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/raster/r.surf.fractal/frac.h 2009-06-22 01:49:13 UTC (rev 38014)
@@ -13,7 +13,7 @@
#include <stdlib.h>
#include <string.h>
Modified: grass/trunk/raster/r.surf.fractal/spec_syn.c
--- grass/trunk/raster/r.surf.fractal/spec_syn.c 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/raster/r.surf.fractal/spec_syn.c 2009-06-22 01:49:13 UTC (rev 38014)
@@ -23,7 +23,7 @@
#include <unistd.h>
#include <math.h>
#include "frac.h"
Modified: grass/trunk/raster/r.surf.gauss/Makefile
--- grass/trunk/raster/r.surf.gauss/Makefile 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/raster/r.surf.gauss/Makefile 2009-06-22 01:49:13 UTC (rev 38014)
@@ -2,8 +2,8 @@
PGM = r.surf.gauss
Modified: grass/trunk/raster/r.surf.gauss/gaussurf.c
--- grass/trunk/raster/r.surf.gauss/gaussurf.c 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/raster/r.surf.gauss/gaussurf.c 2009-06-22 01:49:13 UTC (rev 38014)
@@ -9,7 +9,7 @@
#include <unistd.h>
#include <math.h>
Modified: grass/trunk/raster/r.surf.gauss/main.c
--- grass/trunk/raster/r.surf.gauss/main.c 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/raster/r.surf.gauss/main.c 2009-06-22 01:49:13 UTC (rev 38014)
@@ -16,7 +16,7 @@
#include <stdlib.h>
#include <stdio.h>
Modified: grass/trunk/raster/r.surf.idw/Makefile
--- grass/trunk/raster/r.surf.idw/Makefile 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/raster/r.surf.idw/Makefile 2009-06-22 01:49:13 UTC (rev 38014)
@@ -2,8 +2,8 @@
PGM = r.surf.idw
Modified: grass/trunk/raster/r.surf.idw/dist.c
--- grass/trunk/raster/r.surf.idw/dist.c 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/raster/r.surf.idw/dist.c 2009-06-22 01:49:13 UTC (rev 38014)
@@ -1,6 +1,6 @@
#include <math.h>
#include "pi.h"
/* distance from point to point along a geodesic
Modified: grass/trunk/raster/r.surf.idw/ll.c
--- grass/trunk/raster/r.surf.idw/ll.c 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/raster/r.surf.idw/ll.c 2009-06-22 01:49:13 UTC (rev 38014)
@@ -2,7 +2,7 @@
#include <stdlib.h>
#include "main.h"
Modified: grass/trunk/raster/r.surf.idw/main.c
--- grass/trunk/raster/r.surf.idw/main.c 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/raster/r.surf.idw/main.c 2009-06-22 01:49:13 UTC (rev 38014)
@@ -35,7 +35,7 @@
#include <stdlib.h>
#include <math.h>
#include "main.h"
Modified: grass/trunk/raster/r.surf.idw/pi.h
--- grass/trunk/raster/r.surf.idw/pi.h 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/raster/r.surf.idw/pi.h 2009-06-22 01:49:13 UTC (rev 38014)
@@ -1,6 +1,6 @@
#include <math.h>
#define PI M_PI
#define Radians(x) ((x) * PI/180.0)
Modified: grass/trunk/raster/r.surf.idw2/Makefile
--- grass/trunk/raster/r.surf.idw2/Makefile 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/raster/r.surf.idw2/Makefile 2009-06-22 01:49:13 UTC (rev 38014)
@@ -2,8 +2,8 @@
PGM = r.surf.idw2
-LIBES = $(GISLIB) $(RASTRLIB) $(DATETIMELIB)
-DEPENDENCIES = $(GISDEP) $(RASTRDEP) $(DATETIMEDEP)
+LIBES = $(GISLIB) $(RASTERLIB) $(DATETIMELIB)
+DEPENDENCIES = $(GISDEP) $(RASTERDEP) $(DATETIMEDEP)
Modified: grass/trunk/raster/r.surf.idw2/main.c
--- grass/trunk/raster/r.surf.idw2/main.c 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/raster/r.surf.idw2/main.c 2009-06-22 01:49:13 UTC (rev 38014)
@@ -17,7 +17,7 @@
#include <stdlib.h>
#include <unistd.h>
Modified: grass/trunk/raster/r.surf.idw2/read_cell.c
--- grass/trunk/raster/r.surf.idw2/read_cell.c 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/raster/r.surf.idw2/read_cell.c 2009-06-22 01:49:13 UTC (rev 38014)
@@ -1,7 +1,7 @@
#include <stdlib.h>
#include <unistd.h>
Modified: grass/trunk/raster/r.surf.random/Makefile
--- grass/trunk/raster/r.surf.random/Makefile 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/raster/r.surf.random/Makefile 2009-06-22 01:49:13 UTC (rev 38014)
@@ -2,8 +2,8 @@
PGM = r.surf.random
Modified: grass/trunk/raster/r.surf.random/main.c
--- grass/trunk/raster/r.surf.random/main.c 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/raster/r.surf.random/main.c 2009-06-22 01:49:13 UTC (rev 38014)
@@ -16,7 +16,7 @@
#include <stdlib.h>
#include <grass/gis.h>
Modified: grass/trunk/raster/r.surf.random/randsurf.c
--- grass/trunk/raster/r.surf.random/randsurf.c 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/raster/r.surf.random/randsurf.c 2009-06-22 01:49:13 UTC (rev 38014)
@@ -1,7 +1,7 @@
#include <unistd.h>
#include <math.h>
Modified: grass/trunk/raster/r.terraflow/Makefile
--- grass/trunk/raster/r.terraflow/Makefile 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/raster/r.terraflow/Makefile 2009-06-22 01:49:13 UTC (rev 38014)
@@ -2,8 +2,8 @@
PGM = r.terraflow
-LIBES = $(GISLIB) $(RASTRLIB) $(IOSTREAMLIB)
-DEPENDENCIES = $(GISDEP) $(RASTRDEP) $(IOSTREAMDEP)
+LIBES = $(GISLIB) $(RASTERLIB) $(IOSTREAMLIB)
+DEPENDENCIES = $(GISDEP) $(RASTERDEP) $(IOSTREAMDEP)
Modified: grass/trunk/raster/r.terraflow/common.h
--- grass/trunk/raster/r.terraflow/common.h 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/raster/r.terraflow/common.h 2009-06-22 01:49:13 UTC (rev 38014)
@@ -31,7 +31,7 @@
#include "types.h" /* for dimension_type */
extern "C" {
Modified: grass/trunk/raster/r.terraflow/main.cc
--- grass/trunk/raster/r.terraflow/main.cc 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/raster/r.terraflow/main.cc 2009-06-22 01:49:13 UTC (rev 38014)
@@ -31,7 +31,7 @@
extern "C" {
Modified: grass/trunk/raster/r.texture/Makefile
--- grass/trunk/raster/r.texture/Makefile 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/raster/r.texture/Makefile 2009-06-22 01:49:13 UTC (rev 38014)
@@ -2,8 +2,8 @@
PGM = r.texture
Modified: grass/trunk/raster/r.texture/h_measure.c
--- grass/trunk/raster/r.texture/h_measure.c 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/raster/r.texture/h_measure.c 2009-06-22 01:49:13 UTC (rev 38014)
@@ -25,7 +25,7 @@
#include <stdlib.h>
#include <math.h>
#define RADIX 2.0
Modified: grass/trunk/raster/r.texture/main.c
--- grass/trunk/raster/r.texture/main.c 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/raster/r.texture/main.c 2009-06-22 01:49:13 UTC (rev 38014)
@@ -25,7 +25,7 @@
#include <stdlib.h>
#include <string.h>
#include "h_measure.h"
Modified: grass/trunk/raster/r.thin/Makefile
--- grass/trunk/raster/r.thin/Makefile 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/raster/r.thin/Makefile 2009-06-22 01:49:13 UTC (rev 38014)
@@ -2,8 +2,8 @@
PGM = r.thin
-LIBES = $(ROWIOLIB) $(GISLIB) $(RASTRLIB)
-DEPENDENCIES = $(ROWIODEP) $(GISDEP) $(RASTRDEP)
+LIBES = $(ROWIOLIB) $(GISLIB) $(RASTERLIB)
+DEPENDENCIES = $(ROWIODEP) $(GISDEP) $(RASTERDEP)
include $(MODULE_TOPDIR)/include/Make/Module.make
Modified: grass/trunk/raster/r.thin/io.c
--- grass/trunk/raster/r.thin/io.c 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/raster/r.thin/io.c 2009-06-22 01:49:13 UTC (rev 38014)
@@ -34,7 +34,7 @@
#include <fcntl.h>
#include <grass/config.h>
#include <grass/rowio.h>
Modified: grass/trunk/raster/r.thin/main.c
--- grass/trunk/raster/r.thin/main.c 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/raster/r.thin/main.c 2009-06-22 01:49:13 UTC (rev 38014)
@@ -36,7 +36,7 @@
#include <stdio.h>
#include <unistd.h>
#include "local_proto.h"
Modified: grass/trunk/raster/r.thin/thin_lines.c
--- grass/trunk/raster/r.thin/thin_lines.c 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/raster/r.thin/thin_lines.c 2009-06-22 01:49:13 UTC (rev 38014)
@@ -16,7 +16,7 @@
#include <stdio.h>
#include <unistd.h>
Modified: grass/trunk/raster/r.to.rast3/main.c
--- grass/trunk/raster/r.to.rast3/main.c 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/raster/r.to.rast3/main.c 2009-06-22 01:49:13 UTC (rev 38014)
@@ -19,7 +19,7 @@
#include <stdlib.h>
#include <string.h>
#include <grass/G3d.h>
Modified: grass/trunk/raster/r.to.rast3elev/main.c
--- grass/trunk/raster/r.to.rast3elev/main.c 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/raster/r.to.rast3elev/main.c 2009-06-22 01:49:13 UTC (rev 38014)
@@ -19,7 +19,7 @@
#include <stdlib.h>
#include <string.h>
Modified: grass/trunk/raster/r.to.vect/Makefile
--- grass/trunk/raster/r.to.vect/Makefile 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/raster/r.to.vect/Makefile 2009-06-22 01:49:13 UTC (rev 38014)
@@ -4,8 +4,8 @@
-LIBES = $(VECTLIB) $(DBMILIB) $(GISLIB) $(RASTRLIB)
-DEPENDENCIES = $(VECTDEP) $(DBMIDEP) $(GISDEP) $(RASTRDEP)
+LIBES = $(VECTLIB) $(DBMILIB) $(GISLIB) $(RASTERLIB)
+DEPENDENCIES = $(VECTDEP) $(DBMIDEP) $(GISDEP) $(RASTERDEP)
Modified: grass/trunk/raster/r.to.vect/areas.c
--- grass/trunk/raster/r.to.vect/areas.c 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/raster/r.to.vect/areas.c 2009-06-22 01:49:13 UTC (rev 38014)
@@ -68,7 +68,7 @@
#include <stdio.h>
#include <unistd.h>
#include "global.h"
Modified: grass/trunk/raster/r.to.vect/areas_io.c
--- grass/trunk/raster/r.to.vect/areas_io.c 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/raster/r.to.vect/areas_io.c 2009-06-22 01:49:13 UTC (rev 38014)
@@ -17,7 +17,7 @@
#include <string.h>
#include <math.h>
Modified: grass/trunk/raster/r.to.vect/lines.c
--- grass/trunk/raster/r.to.vect/lines.c 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/raster/r.to.vect/lines.c 2009-06-22 01:49:13 UTC (rev 38014)
@@ -31,7 +31,7 @@
#include <stdio.h>
#include <unistd.h>
#include "global.h"
Modified: grass/trunk/raster/r.to.vect/lines_io.c
--- grass/trunk/raster/r.to.vect/lines_io.c 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/raster/r.to.vect/lines_io.c 2009-06-22 01:49:13 UTC (rev 38014)
@@ -33,7 +33,7 @@
#endif
Modified: grass/trunk/raster/r.to.vect/main.c
--- grass/trunk/raster/r.to.vect/main.c 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/raster/r.to.vect/main.c 2009-06-22 01:49:13 UTC (rev 38014)
@@ -20,7 +20,7 @@
#include <stdlib.h>
#include <string.h>
Modified: grass/trunk/raster/r.to.vect/points.c
--- grass/trunk/raster/r.to.vect/points.c 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/raster/r.to.vect/points.c 2009-06-22 01:49:13 UTC (rev 38014)
@@ -4,7 +4,7 @@
#include <stdlib.h>
#include <strings.h>
Modified: grass/trunk/raster/r.to.vect/util.c
--- grass/trunk/raster/r.to.vect/util.c 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/raster/r.to.vect/util.c 2009-06-22 01:49:13 UTC (rev 38014)
@@ -8,7 +8,7 @@
#endif
Modified: grass/trunk/raster/r.topidx/Makefile
--- grass/trunk/raster/r.topidx/Makefile 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/raster/r.topidx/Makefile 2009-06-22 01:49:13 UTC (rev 38014)
@@ -2,8 +2,8 @@
PGM = r.topidx
Modified: grass/trunk/raster/r.topidx/file_io.c
--- grass/trunk/raster/r.topidx/file_io.c 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/raster/r.topidx/file_io.c 2009-06-22 01:49:13 UTC (rev 38014)
@@ -1,6 +1,6 @@
#include <string.h>
#include "global.h"
Modified: grass/trunk/raster/r.topidx/global.h
--- grass/trunk/raster/r.topidx/global.h 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/raster/r.topidx/global.h 2009-06-22 01:49:13 UTC (rev 38014)
@@ -1,5 +1,5 @@
#define cv(i,j) cell[i][j]
#define av(i,j) a[i][j]
Modified: grass/trunk/raster/r.topidx/main.c
--- grass/trunk/raster/r.topidx/main.c 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/raster/r.topidx/main.c 2009-06-22 01:49:13 UTC (rev 38014)
@@ -21,7 +21,7 @@
#define _MAIN_C_
#include <stdlib.h>
#include "global.h"
Modified: grass/trunk/raster/r.topidx/topidx.c
--- grass/trunk/raster/r.topidx/topidx.c 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/raster/r.topidx/topidx.c 2009-06-22 01:49:13 UTC (rev 38014)
@@ -1,6 +1,6 @@
#include <math.h>
#include "global.h"
Modified: grass/trunk/raster/r.topmodel/Makefile
--- grass/trunk/raster/r.topmodel/Makefile 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/raster/r.topmodel/Makefile 2009-06-22 01:49:13 UTC (rev 38014)
@@ -2,8 +2,8 @@
PGM = r.topmodel
Modified: grass/trunk/raster/r.topmodel/file_io.c
--- grass/trunk/raster/r.topmodel/file_io.c 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/raster/r.topmodel/file_io.c 2009-06-22 01:49:13 UTC (rev 38014)
@@ -1,5 +1,5 @@
#include "global.h"
Modified: grass/trunk/raster/r.topmodel/global.h
--- grass/trunk/raster/r.topmodel/global.h 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/raster/r.topmodel/global.h 2009-06-22 01:49:13 UTC (rev 38014)
@@ -5,7 +5,7 @@
#include <math.h>
#include <time.h>
#define FILL 0x1
Modified: grass/trunk/raster/r.topmodel/topmodel.c
--- grass/trunk/raster/r.topmodel/topmodel.c 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/raster/r.topmodel/topmodel.c 2009-06-22 01:49:13 UTC (rev 38014)
@@ -1,5 +1,5 @@
#include "global.h"
Modified: grass/trunk/raster/r.univar/globals.h
--- grass/trunk/raster/r.univar/globals.h 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/raster/r.univar/globals.h 2009-06-22 01:49:13 UTC (rev 38014)
@@ -19,7 +19,7 @@
#include <stdlib.h>
#include <math.h>
Modified: grass/trunk/raster/r.uslek/Makefile
--- grass/trunk/raster/r.uslek/Makefile 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/raster/r.uslek/Makefile 2009-06-22 01:49:13 UTC (rev 38014)
@@ -2,8 +2,8 @@
PGM = r.uslek
Modified: grass/trunk/raster/r.uslek/main.c
--- grass/trunk/raster/r.uslek/main.c 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/raster/r.uslek/main.c 2009-06-22 01:49:13 UTC (rev 38014)
@@ -20,7 +20,7 @@
#include <stdlib.h>
#include <string.h>
#define POLYGON_DIMENSION 20
Modified: grass/trunk/raster/r.usler/Makefile
--- grass/trunk/raster/r.usler/Makefile 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/raster/r.usler/Makefile 2009-06-22 01:49:13 UTC (rev 38014)
@@ -2,8 +2,8 @@
PGM = r.usler
Modified: grass/trunk/raster/r.usler/main.c
--- grass/trunk/raster/r.usler/main.c 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/raster/r.usler/main.c 2009-06-22 01:49:13 UTC (rev 38014)
@@ -18,7 +18,7 @@
#include <stdlib.h>
#include <string.h>
double elswaify_1985(double annual_pmm);
Modified: grass/trunk/raster/r.volume/Makefile
--- grass/trunk/raster/r.volume/Makefile 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/raster/r.volume/Makefile 2009-06-22 01:49:13 UTC (rev 38014)
@@ -4,8 +4,8 @@
-LIBES = $(SITESLIB) $(VECTLIB) $(GISLIB) $(RASTRLIB)
-DEPENDENCIES = $(SITESDEP) $(VECTDEP) $(GISDEP) $(RASTRDEP)
+LIBES = $(SITESLIB) $(VECTLIB) $(GISLIB) $(RASTERLIB)
+DEPENDENCIES = $(SITESDEP) $(VECTDEP) $(GISDEP) $(RASTERDEP)
Modified: grass/trunk/raster/r.volume/centroids.c
--- grass/trunk/raster/r.volume/centroids.c 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/raster/r.volume/centroids.c 2009-06-22 01:49:13 UTC (rev 38014)
@@ -17,7 +17,7 @@
* col = sigma(col)/n.
int centroids(int fd, /* File descriptor of map layer to process */
/* This file is assumed to be opened before calling */
Modified: grass/trunk/raster/r.volume/main.c
--- grass/trunk/raster/r.volume/main.c 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/raster/r.volume/main.c 2009-06-22 01:49:13 UTC (rev 38014)
@@ -25,7 +25,7 @@
#include <stdlib.h>
#include <string.h>
#include <grass/site.h>
Modified: grass/trunk/raster/r.walk/Makefile
--- grass/trunk/raster/r.walk/Makefile 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/raster/r.walk/Makefile 2009-06-22 01:49:13 UTC (rev 38014)
@@ -2,8 +2,8 @@
PGM = r.walk
-LIBES = $(SITESLIB) $(VECTLIB) $(GISLIB) $(RASTRLIB) $(SEGMENTLIB) $(DATETIMELIB)
+LIBES = $(SITESLIB) $(VECTLIB) $(GISLIB) $(RASTERLIB) $(SEGMENTLIB) $(DATETIMELIB)
Modified: grass/trunk/raster/r.walk/btree.c
--- grass/trunk/raster/r.walk/btree.c 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/raster/r.walk/btree.c 2009-06-22 01:49:13 UTC (rev 38014)
@@ -15,7 +15,7 @@
#include "memory.h"
#include <stdlib.h>
Modified: grass/trunk/raster/r.walk/main.c
--- grass/trunk/raster/r.walk/main.c 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/raster/r.walk/main.c 2009-06-22 01:49:13 UTC (rev 38014)
@@ -100,7 +100,7 @@
#include <sys/stat.h>
#include <fcntl.h>
#include "cost.h"
Modified: grass/trunk/raster/r.walk/memory.c
--- grass/trunk/raster/r.walk/memory.c 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/raster/r.walk/memory.c 2009-06-22 01:49:13 UTC (rev 38014)
@@ -17,7 +17,7 @@
#include <string.h>
#include <errno.h>
#include "memory.h"
#define NUM_IN_BLOCK 1024*8
Modified: grass/trunk/raster/r.water.outlet/Makefile
--- grass/trunk/raster/r.water.outlet/Makefile 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/raster/r.water.outlet/Makefile 2009-06-22 01:49:13 UTC (rev 38014)
@@ -2,8 +2,8 @@
PGM = r.water.outlet
Modified: grass/trunk/raster/r.water.outlet/basin.h
--- grass/trunk/raster/r.water.outlet/basin.h 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/raster/r.water.outlet/basin.h 2009-06-22 01:49:13 UTC (rev 38014)
@@ -1,6 +1,6 @@
#include <math.h>
#include "ramseg.h"
#include "flag.h"
Modified: grass/trunk/raster/r.water.outlet/flag_create.c
--- grass/trunk/raster/r.water.outlet/flag_create.c 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/raster/r.water.outlet/flag_create.c 2009-06-22 01:49:13 UTC (rev 38014)
@@ -1,5 +1,5 @@
#include "flag.h"
Modified: grass/trunk/raster/r.water.outlet/flag_destroy.c
--- grass/trunk/raster/r.water.outlet/flag_destroy.c 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/raster/r.water.outlet/flag_destroy.c 2009-06-22 01:49:13 UTC (rev 38014)
@@ -1,5 +1,5 @@
#include "flag.h"
Modified: grass/trunk/raster/r.water.outlet/main.c
--- grass/trunk/raster/r.water.outlet/main.c 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/raster/r.water.outlet/main.c 2009-06-22 01:49:13 UTC (rev 38014)
@@ -25,7 +25,7 @@
#include <stdio.h>
#include <string.h>
#include "basin.h"
Modified: grass/trunk/raster/r.watershed/front/Makefile
--- grass/trunk/raster/r.watershed/front/Makefile 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/raster/r.watershed/front/Makefile 2009-06-22 01:49:13 UTC (rev 38014)
@@ -2,8 +2,8 @@
PGM = r.watershed
Modified: grass/trunk/raster/r.watershed/front/main.c
--- grass/trunk/raster/r.watershed/front/main.c 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/raster/r.watershed/front/main.c 2009-06-22 01:49:13 UTC (rev 38014)
@@ -18,7 +18,7 @@
#include <stdio.h>
#include <string.h>
int write_hist(char *, char *, char *, int, int);
Modified: grass/trunk/raster/r.watershed/ram/Gwater.h
--- grass/trunk/raster/r.watershed/ram/Gwater.h 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/raster/r.watershed/ram/Gwater.h 2009-06-22 01:49:13 UTC (rev 38014)
@@ -8,7 +8,7 @@
/* last modified 03/26/91 */
#include <math.h>
#include "ramseg.h"
#include "flag.h"
Modified: grass/trunk/raster/r.watershed/ram/Makefile
--- grass/trunk/raster/r.watershed/ram/Makefile 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/raster/r.watershed/ram/Makefile 2009-06-22 01:49:13 UTC (rev 38014)
@@ -2,8 +2,8 @@
PGM = r.watershed.ram
include $(MODULE_TOPDIR)/include/Make/Etc.make
include $(MODULE_TOPDIR)/include/Make/NoHtml.make
Modified: grass/trunk/raster/r.watershed/ram/close_maps.c
--- grass/trunk/raster/r.watershed/ram/close_maps.c 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/raster/r.watershed/ram/close_maps.c 2009-06-22 01:49:13 UTC (rev 38014)
@@ -1,7 +1,7 @@
#include "Gwater.h"
#include <unistd.h>
Modified: grass/trunk/raster/r.watershed/ram/do_astar.c
--- grass/trunk/raster/r.watershed/ram/do_astar.c 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/raster/r.watershed/ram/do_astar.c 2009-06-22 01:49:13 UTC (rev 38014)
@@ -1,7 +1,7 @@
#include "Gwater.h"
#include "do_astar.h"
int do_astar(void)
Modified: grass/trunk/raster/r.watershed/ram/do_cum.c
--- grass/trunk/raster/r.watershed/ram/do_cum.c 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/raster/r.watershed/ram/do_cum.c 2009-06-22 01:49:13 UTC (rev 38014)
@@ -1,6 +1,6 @@
#include "Gwater.h"
Modified: grass/trunk/raster/r.watershed/ram/flag_create.c
--- grass/trunk/raster/r.watershed/ram/flag_create.c 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/raster/r.watershed/ram/flag_create.c 2009-06-22 01:49:13 UTC (rev 38014)
@@ -1,5 +1,5 @@
#include "flag.h"
Modified: grass/trunk/raster/r.watershed/ram/flag_destroy.c
--- grass/trunk/raster/r.watershed/ram/flag_destroy.c 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/raster/r.watershed/ram/flag_destroy.c 2009-06-22 01:49:13 UTC (rev 38014)
@@ -1,5 +1,5 @@
#include "flag.h"
Modified: grass/trunk/raster/r.watershed/ram/init_vars.c
--- grass/trunk/raster/r.watershed/ram/init_vars.c 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/raster/r.watershed/ram/init_vars.c 2009-06-22 01:49:13 UTC (rev 38014)
@@ -2,7 +2,7 @@
#include <string.h>
#include "Gwater.h"
int ele_round(double);
Modified: grass/trunk/raster/r.watershed/ram/main.c
--- grass/trunk/raster/r.watershed/ram/main.c 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/raster/r.watershed/ram/main.c 2009-06-22 01:49:13 UTC (rev 38014)
@@ -20,7 +20,7 @@
#include <unistd.h>
#include "Gwater.h"
Modified: grass/trunk/raster/r.watershed/ram/sg_factor.c
--- grass/trunk/raster/r.watershed/ram/sg_factor.c 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/raster/r.watershed/ram/sg_factor.c 2009-06-22 01:49:13 UTC (rev 38014)
@@ -1,6 +1,6 @@
#include "Gwater.h"
CELL *ril_buf;
Modified: grass/trunk/raster/r.watershed/ram/usage.c
--- grass/trunk/raster/r.watershed/ram/usage.c 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/raster/r.watershed/ram/usage.c 2009-06-22 01:49:13 UTC (rev 38014)
@@ -1,7 +1,7 @@
#include <stdlib.h>
#include <stdio.h>
Modified: grass/trunk/raster/r.watershed/seg/Gwater.h
--- grass/trunk/raster/r.watershed/seg/Gwater.h 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/raster/r.watershed/seg/Gwater.h 2009-06-22 01:49:13 UTC (rev 38014)
@@ -8,7 +8,7 @@
#include <math.h>
#include "cseg.h"
#define AR_SIZE 16
Modified: grass/trunk/raster/r.watershed/seg/Makefile
--- grass/trunk/raster/r.watershed/seg/Makefile 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/raster/r.watershed/seg/Makefile 2009-06-22 01:49:13 UTC (rev 38014)
@@ -2,8 +2,8 @@
PGM = r.watershed.seg
-LIBES = $(GISLIB) $(RASTRLIB) $(SEGMENTLIB)
-DEPENDENCIES = $(GISDEP) $(RASTRDEP) $(SEGMENTDEP)
+LIBES = $(GISLIB) $(RASTERLIB) $(SEGMENTLIB)
+DEPENDENCIES = $(GISDEP) $(RASTERDEP) $(SEGMENTDEP)
Modified: grass/trunk/raster/r.watershed/seg/bseg_close.c
--- grass/trunk/raster/r.watershed/seg/bseg_close.c 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/raster/r.watershed/seg/bseg_close.c 2009-06-22 01:49:13 UTC (rev 38014)
@@ -1,5 +1,5 @@
#include <unistd.h>
#include "cseg.h"
Modified: grass/trunk/raster/r.watershed/seg/bseg_get.c
--- grass/trunk/raster/r.watershed/seg/bseg_get.c 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/raster/r.watershed/seg/bseg_get.c 2009-06-22 01:49:13 UTC (rev 38014)
@@ -1,5 +1,5 @@
#include "cseg.h"
Modified: grass/trunk/raster/r.watershed/seg/bseg_open.c
--- grass/trunk/raster/r.watershed/seg/bseg_open.c 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/raster/r.watershed/seg/bseg_open.c 2009-06-22 01:49:13 UTC (rev 38014)
@@ -1,5 +1,5 @@
#include <unistd.h>
#include <fcntl.h>
Modified: grass/trunk/raster/r.watershed/seg/bseg_put.c
--- grass/trunk/raster/r.watershed/seg/bseg_put.c 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/raster/r.watershed/seg/bseg_put.c 2009-06-22 01:49:13 UTC (rev 38014)
@@ -1,5 +1,5 @@
#include "cseg.h"
Modified: grass/trunk/raster/r.watershed/seg/bseg_read.c
--- grass/trunk/raster/r.watershed/seg/bseg_read.c 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/raster/r.watershed/seg/bseg_read.c 2009-06-22 01:49:13 UTC (rev 38014)
@@ -1,5 +1,5 @@
#include <unistd.h>
#include "cseg.h"
Modified: grass/trunk/raster/r.watershed/seg/bseg_write.c
--- grass/trunk/raster/r.watershed/seg/bseg_write.c 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/raster/r.watershed/seg/bseg_write.c 2009-06-22 01:49:13 UTC (rev 38014)
@@ -1,5 +1,5 @@
#include "cseg.h"
static char *me = "bseg_write_cell";
Modified: grass/trunk/raster/r.watershed/seg/cseg_close.c
--- grass/trunk/raster/r.watershed/seg/cseg_close.c 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/raster/r.watershed/seg/cseg_close.c 2009-06-22 01:49:13 UTC (rev 38014)
@@ -1,5 +1,5 @@
#include <unistd.h>
#include "cseg.h"
Modified: grass/trunk/raster/r.watershed/seg/cseg_get.c
--- grass/trunk/raster/r.watershed/seg/cseg_get.c 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/raster/r.watershed/seg/cseg_get.c 2009-06-22 01:49:13 UTC (rev 38014)
@@ -1,5 +1,5 @@
#include "cseg.h"
Modified: grass/trunk/raster/r.watershed/seg/cseg_open.c
--- grass/trunk/raster/r.watershed/seg/cseg_open.c 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/raster/r.watershed/seg/cseg_open.c 2009-06-22 01:49:13 UTC (rev 38014)
@@ -1,5 +1,5 @@
#include <unistd.h>
#include <fcntl.h>
#include "cseg.h"
Modified: grass/trunk/raster/r.watershed/seg/cseg_put.c
--- grass/trunk/raster/r.watershed/seg/cseg_put.c 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/raster/r.watershed/seg/cseg_put.c 2009-06-22 01:49:13 UTC (rev 38014)
@@ -1,5 +1,5 @@
#include "cseg.h"
Modified: grass/trunk/raster/r.watershed/seg/cseg_read.c
--- grass/trunk/raster/r.watershed/seg/cseg_read.c 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/raster/r.watershed/seg/cseg_read.c 2009-06-22 01:49:13 UTC (rev 38014)
@@ -1,5 +1,5 @@
#include "cseg.h"
Modified: grass/trunk/raster/r.watershed/seg/cseg_write.c
--- grass/trunk/raster/r.watershed/seg/cseg_write.c 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/raster/r.watershed/seg/cseg_write.c 2009-06-22 01:49:13 UTC (rev 38014)
@@ -1,5 +1,5 @@
#include "cseg.h"
Modified: grass/trunk/raster/r.watershed/seg/do_astar.c
--- grass/trunk/raster/r.watershed/seg/do_astar.c 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/raster/r.watershed/seg/do_astar.c 2009-06-22 01:49:13 UTC (rev 38014)
@@ -1,7 +1,7 @@
#include <stdlib.h>
#include <unistd.h>
#include "Gwater.h"
Modified: grass/trunk/raster/r.watershed/seg/do_cum.c
--- grass/trunk/raster/r.watershed/seg/do_cum.c 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/raster/r.watershed/seg/do_cum.c 2009-06-22 01:49:13 UTC (rev 38014)
@@ -1,7 +1,7 @@
#include "Gwater.h"
#include <unistd.h>
Modified: grass/trunk/raster/r.watershed/seg/dseg_close.c
--- grass/trunk/raster/r.watershed/seg/dseg_close.c 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/raster/r.watershed/seg/dseg_close.c 2009-06-22 01:49:13 UTC (rev 38014)
@@ -1,5 +1,5 @@
#include <unistd.h>
#include "cseg.h"
Modified: grass/trunk/raster/r.watershed/seg/dseg_get.c
--- grass/trunk/raster/r.watershed/seg/dseg_get.c 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/raster/r.watershed/seg/dseg_get.c 2009-06-22 01:49:13 UTC (rev 38014)
@@ -1,5 +1,5 @@
#include "cseg.h"
Modified: grass/trunk/raster/r.watershed/seg/dseg_open.c
--- grass/trunk/raster/r.watershed/seg/dseg_open.c 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/raster/r.watershed/seg/dseg_open.c 2009-06-22 01:49:13 UTC (rev 38014)
@@ -1,5 +1,5 @@
#include <unistd.h>
#include <fcntl.h>
Modified: grass/trunk/raster/r.watershed/seg/dseg_put.c
--- grass/trunk/raster/r.watershed/seg/dseg_put.c 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/raster/r.watershed/seg/dseg_put.c 2009-06-22 01:49:13 UTC (rev 38014)
@@ -1,5 +1,5 @@
#include "cseg.h"
Modified: grass/trunk/raster/r.watershed/seg/dseg_read.c
--- grass/trunk/raster/r.watershed/seg/dseg_read.c 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/raster/r.watershed/seg/dseg_read.c 2009-06-22 01:49:13 UTC (rev 38014)
@@ -1,5 +1,5 @@
#include "cseg.h"
Modified: grass/trunk/raster/r.watershed/seg/dseg_write.c
--- grass/trunk/raster/r.watershed/seg/dseg_write.c 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/raster/r.watershed/seg/dseg_write.c 2009-06-22 01:49:13 UTC (rev 38014)
@@ -1,5 +1,5 @@
#include "cseg.h"
Modified: grass/trunk/raster/r.watershed/seg/init_vars.c
--- grass/trunk/raster/r.watershed/seg/init_vars.c 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/raster/r.watershed/seg/init_vars.c 2009-06-22 01:49:13 UTC (rev 38014)
@@ -3,7 +3,7 @@
#include <unistd.h>
#include "Gwater.h"
Modified: grass/trunk/raster/r.watershed/seg/main.c
--- grass/trunk/raster/r.watershed/seg/main.c 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/raster/r.watershed/seg/main.c 2009-06-22 01:49:13 UTC (rev 38014)
@@ -21,7 +21,7 @@
#include <unistd.h>
#include "Gwater.h"
Modified: grass/trunk/raster/r.watershed/seg/sg_factor.c
--- grass/trunk/raster/r.watershed/seg/sg_factor.c 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/raster/r.watershed/seg/sg_factor.c 2009-06-22 01:49:13 UTC (rev 38014)
@@ -1,6 +1,6 @@
#include "Gwater.h"
Modified: grass/trunk/raster/r.watershed/seg/sseg_close.c
--- grass/trunk/raster/r.watershed/seg/sseg_close.c 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/raster/r.watershed/seg/sseg_close.c 2009-06-22 01:49:13 UTC (rev 38014)
@@ -1,5 +1,5 @@
#include <unistd.h>
#include "cseg.h"
Modified: grass/trunk/raster/r.watershed/seg/sseg_get.c
--- grass/trunk/raster/r.watershed/seg/sseg_get.c 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/raster/r.watershed/seg/sseg_get.c 2009-06-22 01:49:13 UTC (rev 38014)
@@ -1,5 +1,5 @@
#include "cseg.h"
Modified: grass/trunk/raster/r.watershed/seg/sseg_open.c
--- grass/trunk/raster/r.watershed/seg/sseg_open.c 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/raster/r.watershed/seg/sseg_open.c 2009-06-22 01:49:13 UTC (rev 38014)
@@ -1,5 +1,5 @@
#include <unistd.h>
#include <fcntl.h>
Modified: grass/trunk/raster/r.watershed/seg/sseg_put.c
--- grass/trunk/raster/r.watershed/seg/sseg_put.c 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/raster/r.watershed/seg/sseg_put.c 2009-06-22 01:49:13 UTC (rev 38014)
@@ -1,5 +1,5 @@
#include "cseg.h"
Modified: grass/trunk/raster/r.watershed/seg/usage.c
--- grass/trunk/raster/r.watershed/seg/usage.c 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/raster/r.watershed/seg/usage.c 2009-06-22 01:49:13 UTC (rev 38014)
@@ -1,7 +1,7 @@
#include <stdio.h>
#include <stdlib.h>
#include <grass/glocale.h>
Modified: grass/trunk/raster/r.watershed/shed/watershed.h
--- grass/trunk/raster/r.watershed/shed/watershed.h 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/raster/r.watershed/shed/watershed.h 2009-06-22 01:49:13 UTC (rev 38014)
@@ -4,7 +4,7 @@
#include <stdio.h>
#define RAM_NAME "ram"
#define SEG_NAME "seg"
Modified: grass/trunk/raster/r.what/Makefile
--- grass/trunk/raster/r.what/Makefile 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/raster/r.what/Makefile 2009-06-22 01:49:13 UTC (rev 38014)
@@ -2,8 +2,8 @@
PGM = r.what
Modified: grass/trunk/raster/r.what/main.c
--- grass/trunk/raster/r.what/main.c 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/raster/r.what/main.c 2009-06-22 01:49:13 UTC (rev 38014)
@@ -21,7 +21,7 @@
#include <unistd.h>
#include <string.h>
struct order
Modified: grass/trunk/raster/r.what.color/Makefile
--- grass/trunk/raster/r.what.color/Makefile 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/raster/r.what.color/Makefile 2009-06-22 01:49:13 UTC (rev 38014)
@@ -2,8 +2,8 @@
PGM = r.what.color
Modified: grass/trunk/raster/r.what.color/main.c
--- grass/trunk/raster/r.what.color/main.c 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/raster/r.what.color/main.c 2009-06-22 01:49:13 UTC (rev 38014)
@@ -20,7 +20,7 @@
#include <unistd.h>
#include <string.h>
static const char *fmt;
Modified: grass/trunk/raster3d/r3.cross.rast/main.c
--- grass/trunk/raster3d/r3.cross.rast/main.c 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/raster3d/r3.cross.rast/main.c 2009-06-22 01:49:13 UTC (rev 38014)
@@ -19,7 +19,7 @@
#include <stdlib.h>
#include <string.h>
Modified: grass/trunk/raster3d/r3.gwflow/main.c
--- grass/trunk/raster3d/r3.gwflow/main.c 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/raster3d/r3.gwflow/main.c 2009-06-22 01:49:13 UTC (rev 38014)
@@ -19,7 +19,7 @@
#include <stdlib.h>
#include <string.h>
#include <grass/N_pde.h>
Modified: grass/trunk/raster3d/r3.mkdspf/calc_linefax.c
--- grass/trunk/raster3d/r3.mkdspf/calc_linefax.c 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/raster3d/r3.mkdspf/calc_linefax.c 2009-06-22 01:49:13 UTC (rev 38014)
@@ -1,6 +1,6 @@
#include <stdlib.h>
#include "vizual.h"
Modified: grass/trunk/raster3d/r3.mkdspf/iso_surface.c
--- grass/trunk/raster3d/r3.mkdspf/iso_surface.c 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/raster3d/r3.mkdspf/iso_surface.c 2009-06-22 01:49:13 UTC (rev 38014)
@@ -2,7 +2,7 @@
#include <math.h>
#include "vizual.h"
Modified: grass/trunk/raster3d/r3.mkdspf/main.c
--- grass/trunk/raster3d/r3.mkdspf/main.c 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/raster3d/r3.mkdspf/main.c 2009-06-22 01:49:13 UTC (rev 38014)
@@ -44,7 +44,7 @@
#include <math.h>
#include "vizual.h"
Modified: grass/trunk/raster3d/r3.mkdspf/r3_find.c
--- grass/trunk/raster3d/r3.mkdspf/r3_find.c 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/raster3d/r3.mkdspf/r3_find.c 2009-06-22 01:49:13 UTC (rev 38014)
@@ -5,7 +5,7 @@
#include <string.h>
-#include <grass/Rast.h>
+#include <grass/raster.h>
Modified: grass/trunk/raster3d/r3.out.vtk/errorHandling.c
--- grass/trunk/raster3d/r3.out.vtk/errorHandling.c 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/raster3d/r3.out.vtk/errorHandling.c 2009-06-22 01:49:13 UTC (rev 38014)
@@ -19,7 +19,7 @@
#include <stdlib.h>
#include <string.h>
#include "globalDefs.h"
Modified: grass/trunk/raster3d/r3.out.vtk/main.c
--- grass/trunk/raster3d/r3.out.vtk/main.c 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/raster3d/r3.out.vtk/main.c 2009-06-22 01:49:13 UTC (rev 38014)
@@ -19,7 +19,7 @@
#include <stdlib.h>
#include <string.h>
Modified: grass/trunk/raster3d/r3.out.vtk/parameters.c
--- grass/trunk/raster3d/r3.out.vtk/parameters.c 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/raster3d/r3.out.vtk/parameters.c 2009-06-22 01:49:13 UTC (rev 38014)
@@ -16,7 +16,7 @@
#include "parameters.h"
Modified: grass/trunk/raster3d/r3.out.vtk/writeVTKData.c
--- grass/trunk/raster3d/r3.out.vtk/writeVTKData.c 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/raster3d/r3.out.vtk/writeVTKData.c 2009-06-22 01:49:13 UTC (rev 38014)
@@ -19,7 +19,7 @@
#include <stdlib.h>
#include <string.h>
Modified: grass/trunk/raster3d/r3.out.vtk/writeVTKHead.c
--- grass/trunk/raster3d/r3.out.vtk/writeVTKHead.c 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/raster3d/r3.out.vtk/writeVTKHead.c 2009-06-22 01:49:13 UTC (rev 38014)
@@ -19,7 +19,7 @@
#include <stdlib.h>
#include <string.h>
Modified: grass/trunk/raster3d/r3.to.rast/main.c
--- grass/trunk/raster3d/r3.to.rast/main.c 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/raster3d/r3.to.rast/main.c 2009-06-22 01:49:13 UTC (rev 38014)
@@ -19,7 +19,7 @@
#include <stdlib.h>
#include <string.h>
Modified: grass/trunk/swig/python/Makefile
--- grass/trunk/swig/python/Makefile 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/swig/python/Makefile 2009-06-22 01:49:13 UTC (rev 38014)
@@ -10,11 +10,12 @@
DOXNAME=
DOXINPUT=grasspython.dox
-MODULES = utils date grass math proj imagery vector display stats \
+MODULES = utils date grass raster math proj imagery vector display stats \
dbmi g3d arraystats cluster trans vedit
date_LIBS = $(DATETIMELIB)
grass_LIBS = $(GISLIB)
+raster_LIBS = $(RASTERLIB)
math_LIBS = $(GMATHLIB)
proj_LIBS = $(GPROJLIB)
imagery_LIBS = $(IMAGERYLIB)
@@ -85,6 +86,7 @@
date_wrap.c: $(GISBASE)/include/grass/P_datetime.h
grass_wrap.c: $(GISBASE)/include/grass/gis.h
grass_wrap.c: $(GISBASE)/include/grass/gisdefs.h
+raster_wrap.c: $(GISBASE)/include/grass/raster.h
math_wrap.c: $(GISBASE)/include/grass/gmath.h
proj_wrap.c: $(GISBASE)/include/grass/gprojects.h
imagery_wrap.c: $(GISBASE)/include/grass/imagedefs.h
@@ -102,4 +104,3 @@
cluster_wrap.c: $(GISBASE)/include/grass/cluster.h
trans_wrap.c: $(GISBASE)/include/grass/transform.h
vedit_wrap.c: $(GISBASE)/include/grass/vedit.h
-utils_wrap.c:
Modified: grass/trunk/vector/lidar/lidarlib/TcholBand.c
--- grass/trunk/vector/lidar/lidarlib/TcholBand.c 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/vector/lidar/lidarlib/TcholBand.c 2009-06-22 01:49:13 UTC (rev 38014)
@@ -2,7 +2,7 @@
#include <stdio.h>
#include <math.h>
#include <grass/PolimiFunct.h>
Modified: grass/trunk/vector/lidar/lidarlib/raster.c
--- grass/trunk/vector/lidar/lidarlib/raster.c 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/vector/lidar/lidarlib/raster.c 2009-06-22 01:49:13 UTC (rev 38014)
@@ -3,7 +3,7 @@
#include <string.h>
#include <grass/Vect.h>
#include <grass/dbmi.h>
Modified: grass/trunk/vector/lidar/lidarlib/zones.c
--- grass/trunk/vector/lidar/lidarlib/zones.c 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/vector/lidar/lidarlib/zones.c 2009-06-22 01:49:13 UTC (rev 38014)
@@ -3,7 +3,7 @@
#include <string.h>
Modified: grass/trunk/vector/lidar/v.lidar.correction/Makefile
--- grass/trunk/vector/lidar/v.lidar.correction/Makefile 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/vector/lidar/v.lidar.correction/Makefile 2009-06-22 01:49:13 UTC (rev 38014)
@@ -2,8 +2,8 @@
PGM = v.lidar.correction
-LIBES = $(LIDARLIB) $(VECTLIB) $(DBMILIB) $(GISLIB) $(RASTRLIB) $(MATHLIB) $(SEGMENTLIB) $(GMATHLIB)
-DEPENDENCIES= $(LIDARDEP) $(VECTDEP) $(DBMIDEP) $(GISDEP) $(RASTRDEP) $(BSPLINE_ARCH_OBJ) $(GMATHDEP)
+LIBES = $(LIDARLIB) $(VECTLIB) $(DBMILIB) $(GISLIB) $(RASTERLIB) $(MATHLIB) $(SEGMENTLIB) $(GMATHLIB)
+DEPENDENCIES= $(LIDARDEP) $(VECTDEP) $(DBMIDEP) $(GISDEP) $(RASTERDEP) $(BSPLINE_ARCH_OBJ) $(GMATHDEP)
EXTRA_INC = $(VECT_INC)
EXTRA_CFLAGS = $(VECT_CFLAGS)
Modified: grass/trunk/vector/lidar/v.lidar.correction/correction.c
--- grass/trunk/vector/lidar/v.lidar.correction/correction.c 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/vector/lidar/v.lidar.correction/correction.c 2009-06-22 01:49:13 UTC (rev 38014)
@@ -22,7 +22,7 @@
#include <string.h>
#include <math.h>
Modified: grass/trunk/vector/lidar/v.lidar.correction/main.c
--- grass/trunk/vector/lidar/v.lidar.correction/main.c 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/vector/lidar/v.lidar.correction/main.c 2009-06-22 01:49:13 UTC (rev 38014)
@@ -23,7 +23,7 @@
#include <math.h>
Modified: grass/trunk/vector/lidar/v.lidar.edgedetection/Makefile
--- grass/trunk/vector/lidar/v.lidar.edgedetection/Makefile 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/vector/lidar/v.lidar.edgedetection/Makefile 2009-06-22 01:49:13 UTC (rev 38014)
@@ -2,8 +2,8 @@
PGM = v.lidar.edgedetection
-DEPENDENCIES= $(LIDARDEP) $(VECTDEP) $(DBMIDEP) $(GISDEP) $(RASTRDEP) $(GMATHDEP)
+DEPENDENCIES= $(LIDARDEP) $(VECTDEP) $(DBMIDEP) $(GISDEP) $(RASTERDEP) $(GMATHDEP)
Modified: grass/trunk/vector/lidar/v.lidar.edgedetection/edgedetection.c
--- grass/trunk/vector/lidar/v.lidar.edgedetection/edgedetection.c 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/vector/lidar/v.lidar.edgedetection/edgedetection.c 2009-06-22 01:49:13 UTC (rev 38014)
@@ -28,7 +28,7 @@
#include <string.h>
#include <math.h>
/* #include <grass/PolimiFunct.h> */
Modified: grass/trunk/vector/lidar/v.lidar.edgedetection/main.c
--- grass/trunk/vector/lidar/v.lidar.edgedetection/main.c 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/vector/lidar/v.lidar.edgedetection/main.c 2009-06-22 01:49:13 UTC (rev 38014)
@@ -27,7 +27,7 @@
#include <string.h>
#include <math.h>
Modified: grass/trunk/vector/lidar/v.lidar.growing/ConvexHull.c
--- grass/trunk/vector/lidar/v.lidar.growing/ConvexHull.c 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/vector/lidar/v.lidar.growing/ConvexHull.c 2009-06-22 01:49:13 UTC (rev 38014)
@@ -2,7 +2,7 @@
#include <stdlib.h>
#include <string.h>
#include "growing.h"
Modified: grass/trunk/vector/lidar/v.lidar.growing/Makefile
--- grass/trunk/vector/lidar/v.lidar.growing/Makefile 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/vector/lidar/v.lidar.growing/Makefile 2009-06-22 01:49:13 UTC (rev 38014)
@@ -2,8 +2,8 @@
PGM = v.lidar.growing
Modified: grass/trunk/vector/lidar/v.lidar.growing/main.c
--- grass/trunk/vector/lidar/v.lidar.growing/main.c 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/vector/lidar/v.lidar.growing/main.c 2009-06-22 01:49:13 UTC (rev 38014)
@@ -25,7 +25,7 @@
#include <math.h>
Modified: grass/trunk/vector/lidar/v.outlier/Makefile
--- grass/trunk/vector/lidar/v.outlier/Makefile 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/vector/lidar/v.outlier/Makefile 2009-06-22 01:49:13 UTC (rev 38014)
@@ -2,8 +2,8 @@
PGM = v.outlier
Modified: grass/trunk/vector/lidar/v.outlier/main.c
--- grass/trunk/vector/lidar/v.outlier/main.c 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/vector/lidar/v.outlier/main.c 2009-06-22 01:49:13 UTC (rev 38014)
@@ -23,7 +23,7 @@
#include <math.h>
Modified: grass/trunk/vector/lidar/v.outlier/outlier.c
--- grass/trunk/vector/lidar/v.outlier/outlier.c 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/vector/lidar/v.outlier/outlier.c 2009-06-22 01:49:13 UTC (rev 38014)
@@ -3,7 +3,7 @@
#include <string.h>
#include <math.h>
Modified: grass/trunk/vector/lidar/v.surf.bspline/Makefile
--- grass/trunk/vector/lidar/v.surf.bspline/Makefile 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/vector/lidar/v.surf.bspline/Makefile 2009-06-22 01:49:13 UTC (rev 38014)
@@ -2,8 +2,8 @@
PGM = v.surf.bspline
Modified: grass/trunk/vector/lidar/v.surf.bspline/crosscorr.c
--- grass/trunk/vector/lidar/v.surf.bspline/crosscorr.c 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/vector/lidar/v.surf.bspline/crosscorr.c 2009-06-22 01:49:13 UTC (rev 38014)
@@ -22,7 +22,7 @@
#include <string.h>
#include <math.h>
Modified: grass/trunk/vector/lidar/v.surf.bspline/main.c
--- grass/trunk/vector/lidar/v.surf.bspline/main.c 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/vector/lidar/v.surf.bspline/main.c 2009-06-22 01:49:13 UTC (rev 38014)
@@ -22,7 +22,7 @@
#include <string.h>
#include <math.h>
Modified: grass/trunk/vector/v.convert/Makefile
--- grass/trunk/vector/v.convert/Makefile 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/vector/v.convert/Makefile 2009-06-22 01:49:13 UTC (rev 38014)
@@ -3,8 +3,8 @@
PGM=v.convert
-LIBES = $(VECTLIB) $(VECTLIB_REAL) $(DBMILIB) $(GISLIB) $(RASTRLIB)
+LIBES = $(VECTLIB) $(VECTLIB_REAL) $(DBMILIB) $(GISLIB) $(RASTERLIB)
Modified: grass/trunk/vector/v.convert/att.c
--- grass/trunk/vector/v.convert/att.c 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/vector/v.convert/att.c 2009-06-22 01:49:13 UTC (rev 38014)
@@ -3,7 +3,7 @@
#include <unistd.h>
#include <string.h>
Modified: grass/trunk/vector/v.convert/dist.c
--- grass/trunk/vector/v.convert/dist.c 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/vector/v.convert/dist.c 2009-06-22 01:49:13 UTC (rev 38014)
@@ -1,6 +1,6 @@
#include <stdlib.h>
#include "conv.h"
Modified: grass/trunk/vector/v.convert/main.c
--- grass/trunk/vector/v.convert/main.c 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/vector/v.convert/main.c 2009-06-22 01:49:13 UTC (rev 38014)
@@ -20,7 +20,7 @@
#include <stdio.h>
#include <stdlib.h>
#include "conv.h"
Modified: grass/trunk/vector/v.convert/old2new.c
--- grass/trunk/vector/v.convert/old2new.c 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/vector/v.convert/old2new.c 2009-06-22 01:49:13 UTC (rev 38014)
@@ -2,7 +2,7 @@
#include <stdlib.h>
#include <string.h>
#include "conv.h"
Modified: grass/trunk/vector/v.convert/read.c
--- grass/trunk/vector/v.convert/read.c 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/vector/v.convert/read.c 2009-06-22 01:49:13 UTC (rev 38014)
@@ -2,7 +2,7 @@
#include <stdlib.h>
#include <string.h>
#include "conv.h"
Modified: grass/trunk/vector/v.drape/Makefile
--- grass/trunk/vector/v.drape/Makefile 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/vector/v.drape/Makefile 2009-06-22 01:49:13 UTC (rev 38014)
@@ -3,8 +3,8 @@
PGM = v.drape
-LIBES = $(VECTLIB) $(GISLIB) $(RASTRLIB)
-DEPENDENCIES= $(VECTDEP) $(GISDEP) $(RASTRDEP)
+LIBES = $(VECTLIB) $(GISLIB) $(RASTERLIB)
+DEPENDENCIES= $(VECTDEP) $(GISDEP) $(RASTERDEP)
Modified: grass/trunk/vector/v.drape/main.c
--- grass/trunk/vector/v.drape/main.c 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/vector/v.drape/main.c 2009-06-22 01:49:13 UTC (rev 38014)
@@ -30,7 +30,7 @@
#include <stdlib.h>
Modified: grass/trunk/vector/v.extrude/Makefile
--- grass/trunk/vector/v.extrude/Makefile 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/vector/v.extrude/Makefile 2009-06-22 01:49:13 UTC (rev 38014)
@@ -2,8 +2,8 @@
PGM = v.extrude
Modified: grass/trunk/vector/v.extrude/main.c
--- grass/trunk/vector/v.extrude/main.c 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/vector/v.extrude/main.c 2009-06-22 01:49:13 UTC (rev 38014)
@@ -23,7 +23,7 @@
#include <stdio.h>
#include <stdlib.h>
Modified: grass/trunk/vector/v.kernel/Makefile
--- grass/trunk/vector/v.kernel/Makefile 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/vector/v.kernel/Makefile 2009-06-22 01:49:13 UTC (rev 38014)
@@ -2,8 +2,8 @@
PGM=v.kernel
-LIBES = $(VECTLIB) $(DBMILIB) $(GMATHLIB) $(GISLIB) $(RASTRLIB) $(DATETIMELIB)
-DEPENDENCIES = $(VECTDEP) $(DBMIDEP) $(GMATHDEP) $(GISDEP) $(RASTRDEP) $(DATETIMEDEP)
+LIBES = $(VECTLIB) $(DBMILIB) $(GMATHLIB) $(GISLIB) $(RASTERLIB) $(DATETIMELIB)
+DEPENDENCIES = $(VECTDEP) $(DBMIDEP) $(GMATHDEP) $(GISDEP) $(RASTERDEP) $(DATETIMEDEP)
Modified: grass/trunk/vector/v.kernel/function.c
--- grass/trunk/vector/v.kernel/function.c 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/vector/v.kernel/function.c 2009-06-22 01:49:13 UTC (rev 38014)
@@ -1,6 +1,6 @@
#include <math.h>
#include "global.h"
Modified: grass/trunk/vector/v.kernel/main.c
--- grass/trunk/vector/v.kernel/main.c 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/vector/v.kernel/main.c 2009-06-22 01:49:13 UTC (rev 38014)
@@ -20,7 +20,7 @@
#include <stdlib.h>
#include <float.h>
#include <grass/gmath.h>
Modified: grass/trunk/vector/v.neighbors/Makefile
--- grass/trunk/vector/v.neighbors/Makefile 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/vector/v.neighbors/Makefile 2009-06-22 01:49:13 UTC (rev 38014)
@@ -2,8 +2,8 @@
PGM = v.neighbors
-DEPENDENCIES = $(VECTDEP) $(GISDEP) $(RASTRDEP)
+DEPENDENCIES = $(VECTDEP) $(GISDEP) $(RASTERDEP)
Modified: grass/trunk/vector/v.neighbors/main.c
--- grass/trunk/vector/v.neighbors/main.c 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/vector/v.neighbors/main.c 2009-06-22 01:49:13 UTC (rev 38014)
@@ -19,7 +19,7 @@
#include <stdlib.h>
#include <unistd.h>
Modified: grass/trunk/vector/v.sample/Makefile
--- grass/trunk/vector/v.sample/Makefile 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/vector/v.sample/Makefile 2009-06-22 01:49:13 UTC (rev 38014)
@@ -2,8 +2,8 @@
PGM = v.sample
Modified: grass/trunk/vector/v.sample/main.c
--- grass/trunk/vector/v.sample/main.c 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/vector/v.sample/main.c 2009-06-22 01:49:13 UTC (rev 38014)
@@ -43,7 +43,7 @@
#include <string.h>
#include <math.h>
Modified: grass/trunk/vector/v.surf.idw/Makefile
--- grass/trunk/vector/v.surf.idw/Makefile 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/vector/v.surf.idw/Makefile 2009-06-22 01:49:13 UTC (rev 38014)
@@ -2,8 +2,8 @@
PGM = v.surf.idw
-LIBES = $(VECTLIB) $(GISLIB) $(RASTRLIB) $(DATETIMELIB)
-DEPENDENCIES= $(VECTDEP) $(GISDEP) $(RASTRDEP) $(DATETIMEDEP)
+LIBES = $(VECTLIB) $(GISLIB) $(RASTERLIB) $(DATETIMELIB)
+DEPENDENCIES= $(VECTDEP) $(GISDEP) $(RASTERDEP) $(DATETIMEDEP)
Modified: grass/trunk/vector/v.surf.idw/main.c
--- grass/trunk/vector/v.surf.idw/main.c 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/vector/v.surf.idw/main.c 2009-06-22 01:49:13 UTC (rev 38014)
@@ -18,7 +18,7 @@
#include <stdlib.h>
#include <math.h>
int search_points = 12;
Modified: grass/trunk/vector/v.surf.idw/read_sites.c
--- grass/trunk/vector/v.surf.idw/read_sites.c 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/vector/v.surf.idw/read_sites.c 2009-06-22 01:49:13 UTC (rev 38014)
@@ -2,7 +2,7 @@
#include <stdlib.h>
#include "proto.h"
Modified: grass/trunk/vector/v.to.rast/Makefile
--- grass/trunk/vector/v.to.rast/Makefile 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/vector/v.to.rast/Makefile 2009-06-22 01:49:13 UTC (rev 38014)
@@ -3,8 +3,8 @@
PGM=v.to.rast
Modified: grass/trunk/vector/v.to.rast/do_areas.c
--- grass/trunk/vector/v.to.rast/do_areas.c 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/vector/v.to.rast/do_areas.c 2009-06-22 01:49:13 UTC (rev 38014)
@@ -1,6 +1,6 @@
#include <stdlib.h>
Modified: grass/trunk/vector/v.to.rast/do_lines.c
--- grass/trunk/vector/v.to.rast/do_lines.c 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/vector/v.to.rast/do_lines.c 2009-06-22 01:49:13 UTC (rev 38014)
@@ -1,6 +1,6 @@
#include <math.h>
Modified: grass/trunk/vector/v.to.rast/main.c
--- grass/trunk/vector/v.to.rast/main.c 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/vector/v.to.rast/main.c 2009-06-22 01:49:13 UTC (rev 38014)
@@ -20,7 +20,7 @@
#include <stdlib.h>
#include <string.h>
Modified: grass/trunk/vector/v.to.rast/raster.c
--- grass/trunk/vector/v.to.rast/raster.c 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/vector/v.to.rast/raster.c 2009-06-22 01:49:13 UTC (rev 38014)
@@ -1,5 +1,5 @@
#include "local.h"
Modified: grass/trunk/vector/v.to.rast/support.c
--- grass/trunk/vector/v.to.rast/support.c 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/vector/v.to.rast/support.c 2009-06-22 01:49:13 UTC (rev 38014)
@@ -8,7 +8,7 @@
#include <string.h>
#include <stdio.h>
Modified: grass/trunk/vector/v.to.rast/vect2rast.c
--- grass/trunk/vector/v.to.rast/vect2rast.c 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/vector/v.to.rast/vect2rast.c 2009-06-22 01:49:13 UTC (rev 38014)
@@ -1,6 +1,6 @@
#include <string.h>
Modified: grass/trunk/vector/v.vol.rst/dataoct.c
--- grass/trunk/vector/v.vol.rst/dataoct.c 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/vector/v.vol.rst/dataoct.c 2009-06-22 01:49:13 UTC (rev 38014)
@@ -29,7 +29,7 @@
#include <stdio.h>
#include <stdlib.h>
#include "dataoct.h"
#include "externs.h"
#include "user.h"
Modified: grass/trunk/vector/v.vol.rst/main.c
--- grass/trunk/vector/v.vol.rst/main.c 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/vector/v.vol.rst/main.c 2009-06-22 01:49:13 UTC (rev 38014)
@@ -33,7 +33,7 @@
#include <unistd.h>
#include "userglobs.h"
Modified: grass/trunk/vector/v.vol.rst/oct.c
--- grass/trunk/vector/v.vol.rst/oct.c 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/vector/v.vol.rst/oct.c 2009-06-22 01:49:13 UTC (rev 38014)
@@ -30,7 +30,7 @@
#include <stdlib.h>
#include <math.h>
#include "oct.h"
Modified: grass/trunk/vector/v.vol.rst/user1.c
--- grass/trunk/vector/v.vol.rst/user1.c 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/vector/v.vol.rst/user1.c 2009-06-22 01:49:13 UTC (rev 38014)
@@ -30,7 +30,7 @@
#include <stdlib.h>
#include <math.h>
Modified: grass/trunk/vector/v.vol.rst/user2.c
--- grass/trunk/vector/v.vol.rst/user2.c 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/vector/v.vol.rst/user2.c 2009-06-22 01:49:13 UTC (rev 38014)
@@ -30,7 +30,7 @@
#include <math.h>
#include <stdlib.h>
#include "oct.h"
#include "surf.h"
Modified: grass/trunk/vector/v.vol.rst/user3.c
--- grass/trunk/vector/v.vol.rst/user3.c 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/vector/v.vol.rst/user3.c 2009-06-22 01:49:13 UTC (rev 38014)
@@ -32,7 +32,7 @@
#include <unistd.h>
#include <fcntl.h>
Modified: grass/trunk/vector/v.vol.rst/user4.c
--- grass/trunk/vector/v.vol.rst/user4.c 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/vector/v.vol.rst/user4.c 2009-06-22 01:49:13 UTC (rev 38014)
@@ -31,7 +31,7 @@
#include <math.h>
#include <unistd.h>
#include "oct.h"
#include "surf.h"
Modified: grass/trunk/vector/v.vol.rst/vector.c
--- grass/trunk/vector/v.vol.rst/vector.c 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/vector/v.vol.rst/vector.c 2009-06-22 01:49:13 UTC (rev 38014)
@@ -32,7 +32,7 @@
#include <unistd.h>
#include <fcntl.h>
Modified: grass/trunk/vector/v.what.rast/Makefile
--- grass/trunk/vector/v.what.rast/Makefile 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/vector/v.what.rast/Makefile 2009-06-22 01:49:13 UTC (rev 38014)
@@ -3,8 +3,8 @@
PGM=v.what.rast
Modified: grass/trunk/vector/v.what.rast/main.c
--- grass/trunk/vector/v.what.rast/main.c 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/vector/v.what.rast/main.c 2009-06-22 01:49:13 UTC (rev 38014)
@@ -20,7 +20,7 @@
#include <stdlib.h>
#include <string.h>
Modified: grass/trunk/visualization/xganim/Makefile
--- grass/trunk/visualization/xganim/Makefile 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/visualization/xganim/Makefile 2009-06-22 01:49:13 UTC (rev 38014)
@@ -4,8 +4,8 @@
EXTRA_CFLAGS = $(WXWIDGETSCXXFLAGS) -DWXINTL_NO_GETTEXT_MACRO
-LIBES = $(GISLIB) $(RASTRLIB) $(WXWIDGETSLIB)
+LIBES = $(GISLIB) $(RASTERLIB) $(WXWIDGETSLIB)
Modified: grass/trunk/visualization/xganim/main.cc
--- grass/trunk/visualization/xganim/main.cc 2009-06-21 15:58:17 UTC (rev 38013)
+++ grass/trunk/visualization/xganim/main.cc 2009-06-22 01:49:13 UTC (rev 38014)
@@ -30,7 +30,7 @@
extern "C" {
