[GRASS-SVN] r38021 - in grass-addons/gipe: . i.eb.eta
svn_grass at osgeo.org
Mon Jun 22 04:29:56 EDT 2009
Author: ychemin
Date: 2009-06-22 04:29:56 -0400 (Mon, 22 Jun 2009)
New Revision: 38021
grass-addons/gipe/Makefile.imagery
grass-addons/gipe/gmmenu.tcl
grass-addons/gipe/i.eb.eta/main.c
grass-addons/gipe/readme.gipe
removed i.sattime, Landsat .MTL files have satellite time embedded now
Modified: grass-addons/gipe/Makefile.imagery
--- grass-addons/gipe/Makefile.imagery 2009-06-22 08:25:13 UTC (rev 38020)
+++ grass-addons/gipe/Makefile.imagery 2009-06-22 08:29:56 UTC (rev 38021)
@@ -29,7 +29,6 @@
i.evapo.TSA \
i.lmf \
i.modis.stateqa \
- i.sattime \
i.vi.mpi \
i.water \
i.wi
Modified: grass-addons/gipe/gmmenu.tcl
--- grass-addons/gipe/gmmenu.tcl 2009-06-22 08:25:13 UTC (rev 38020)
+++ grass-addons/gipe/gmmenu.tcl 2009-06-22 08:29:56 UTC (rev 38021)
@@ -584,7 +584,6 @@
{separator}
{command {[G_msg "Lat/long maps"]} {} "i.latlong" {} -command {execute i.latlong }}
{command {[G_msg "Sunshine hours (potential)"]} {} "i.sunhours" {} -command {execute i.sunhours }}
- {command {[G_msg "Satellite overpass time"]} {} "i.sattime" {} -command {execute i.sattime }}
{separator}
{command {[G_msg "LMF temporal splinning"]} {} "i.lmf" {} -command {execute i.lmf }}
Modified: grass-addons/gipe/i.eb.eta/main.c
--- grass-addons/gipe/i.eb.eta/main.c 2009-06-22 08:25:13 UTC (rev 38020)
+++ grass-addons/gipe/i.eb.eta/main.c 2009-06-22 08:29:56 UTC (rev 38021)
@@ -24,207 +24,108 @@
int main(int argc, char *argv[])
- struct Cell_head cellhd; /*region+header info */
- char *mapset; /*mapset name */
int nrows, ncols;
int row, col;
struct GModule *module;
struct Option *input1, *input2, *input3, *output1;
- struct Flag *flag1;
struct History history; /*metadata */
- /* FMEO Declarations**************** */
- char *name; /*input raster name */
char *result1; /*output raster name */
- /*File Descriptors */
int infd_rnetday, infd_evapfr, infd_tempk;
int outfd1;
char *rnetday, *evapfr, *tempk;
- int i = 0, j = 0;
void *inrast_rnetday, *inrast_evapfr, *inrast_tempk;
DCELL * outrast1;
- RASTER_MAP_TYPE data_type_output = DCELL_TYPE;
- RASTER_MAP_TYPE data_type_rnetday;
- RASTER_MAP_TYPE data_type_evapfr;
- RASTER_MAP_TYPE data_type_tempk;
+ G_gisinit(argv[0]);
- G_gisinit(argv[0]);
module = G_define_module();
module->keywords = _("actual evapotranspiration, energy balance, SEBAL");
module->description =
_("actual evapotranspiration for diurnal period (Bastiaanssen, 1995)");
- /* Define the different options */
- input1 = G_define_standard_option(G_OPT_R_INPUT);
- input1->key = _("rnetday");
+ /* Define the different options */
+ input1 = G_define_standard_option(G_OPT_R_INPUT);
+ input1->key = "rnetday";
input1->description = _("Name of the diurnal Net Radiation map [W/m2]");
- input1->answer = _("rnetday");
+ input1->answer = "rnetday";
input2 = G_define_standard_option(G_OPT_R_INPUT);
- input2->key = _("evapfr");
+ input2->key = "evapfr";
input2->description = _("Name of the evaporative fraction map [-]");
- input2->answer = _("evapfr");
+ input2->answer = "evapfr";
input3 = G_define_standard_option(G_OPT_R_INPUT);
- input3->key = _("tempk");
+ input3->key = "tempk";
input3->description = _("Name of the surface skin temperature [K]");
- input3->answer = _("tempk");
+ input3->answer = "tempk";
output1 = G_define_standard_option(G_OPT_R_OUTPUT);
- output1->key = _("eta");
output1->description =
_("Name of the output actual diurnal evapotranspiration layer");
output1->answer = _("eta");
- if (G_parser(argc, argv))
- exit(EXIT_FAILURE);
+ if (G_parser(argc, argv))
+ exit(EXIT_FAILURE);
rnetday = input1->answer;
evapfr = input2->answer;
tempk = input3->answer;
result1 = output1->answer;
- mapset = G_find_cell2(rnetday, "");
- if (mapset == NULL) {
- G_fatal_error(_("cell file [%s] not found"), rnetday);
- data_type_rnetday = G_raster_map_type(rnetday, mapset);
- if ((infd_rnetday = G_open_cell_old(rnetday, mapset)) < 0)
+ if ((infd_rnetday = G_open_cell_old(rnetday, "")) < 0)
G_fatal_error(_("Cannot open cell file [%s]"), rnetday);
- if (G_get_cellhd(rnetday, mapset, &cellhd) < 0)
- G_fatal_error(_("Cannot read file header of [%s])"), rnetday);
- inrast_rnetday = G_allocate_raster_buf(data_type_rnetday);
+ inrast_rnetday = G_allocate_d_raster_buf();
- mapset = G_find_cell2(evapfr, "");
- G_fatal_error(_("cell file [%s] not found"), evapfr);
- data_type_evapfr = G_raster_map_type(evapfr, mapset);
- if ((infd_evapfr = G_open_cell_old(evapfr, mapset)) < 0)
+ if ((infd_evapfr = G_open_cell_old(evapfr, "")) < 0)
G_fatal_error(_("Cannot open cell file [%s]"), evapfr);
- if (G_get_cellhd(evapfr, mapset, &cellhd) < 0)
- G_fatal_error(_("Cannot read file header of [%s]"), evapfr);
- inrast_evapfr = G_allocate_raster_buf(data_type_evapfr);
+ inrast_evapfr = G_allocate_d_raster_buf();
- mapset = G_find_cell2(tempk, "");
- G_fatal_error(_("Cell file [%s] not found"), tempk);
- data_type_tempk = G_raster_map_type(tempk, mapset);
- if ((infd_tempk = G_open_cell_old(tempk, mapset)) < 0)
+ if ((infd_tempk = G_open_cell_old(tempk, "")) < 0)
G_fatal_error(_("Cannot open cell file [%s]"), tempk);
- if (G_get_cellhd(tempk, mapset, &cellhd) < 0)
- G_fatal_error(_("Cannot read file header of [%s]"), tempk);
- inrast_tempk = G_allocate_raster_buf(data_type_tempk);
+ inrast_tempk = G_allocate_d_raster_buf();
- G_debug(3, "number of rows %d", cellhd.rows);
nrows = G_window_rows();
ncols = G_window_cols();
- outrast1 = G_allocate_raster_buf(data_type_output);
+ outrast1 = G_allocate_d_raster_buf();
- /* Create New raster files */
- if ((outfd1 = G_open_raster_new(result1, data_type_output)) < 0)
- G_fatal_error(_("Could not open <%s>"), result1);
+ if ((outfd1 = G_open_raster_new(result1, data_type_output)) < 0)
+ G_fatal_error(_("Could not open <%s>"), result1);
- /* Process pixels */
- for (row = 0; row < nrows; row++)
- DCELL d;
+ /* Process pixels */
+ for (row = 0; row < nrows; row++)
+ DCELL d;
DCELL d_rnetday;
DCELL d_evapfr;
DCELL d_tempk;
G_percent(row, nrows, 2);
- /* read input maps */
- if (G_get_raster_row
- (infd_rnetday, inrast_rnetday, row, data_type_rnetday) < 0)
+ /* read input maps */
+ if (G_get_d_raster_row(infd_rnetday,inrast_rnetday,row)<0)
G_fatal_error(_("Could not read from <%s>"), rnetday);
- (infd_evapfr, inrast_evapfr, row, data_type_evapfr) < 0)
+ if (G_get_d_raster_row(infd_evapfr,inrast_evapfr,row)<0)
G_fatal_error(_("Could not read from <%s>"), evapfr);
- if (G_get_raster_row(infd_tempk, inrast_tempk, row, data_type_tempk)
- < 0)
+ if (G_get_d_raster_row(infd_tempk,inrast_tempk,row)<0)
G_fatal_error(_("Could not read from <%s>"), tempk);
- /*process the data */
- for (col = 0; col < ncols; col++)
- switch (data_type_rnetday) {
- case CELL_TYPE:
- d_rnetday = (double)((CELL *) inrast_rnetday)[col];
- break;
- case FCELL_TYPE:
- d_rnetday = (double)((FCELL *) inrast_rnetday)[col];
- break;
- case DCELL_TYPE:
+ /*process the data */
+ for (col = 0; col < ncols; col++)
d_rnetday = ((DCELL *) inrast_rnetday)[col];
- break;
- switch (data_type_evapfr) {
- case CELL_TYPE:
- d_evapfr = (double)((CELL *) inrast_evapfr)[col];
- break;
- case FCELL_TYPE:
- d_evapfr = (double)((FCELL *) inrast_evapfr)[col];
- break;
- case DCELL_TYPE:
d_evapfr = ((DCELL *) inrast_evapfr)[col];
- break;
- switch (data_type_tempk) {
- case CELL_TYPE:
- d_tempk = (double)((CELL *) inrast_tempk)[col];
- break;
- case FCELL_TYPE:
- d_tempk = (double)((FCELL *) inrast_tempk)[col];
- break;
- case DCELL_TYPE:
d_tempk = ((DCELL *) inrast_tempk)[col];
- break;
if (G_is_d_null_value(&d_rnetday) ||
G_is_d_null_value(&d_evapfr) ||
- G_is_d_null_value(&d_tempk)) {
+ G_is_d_null_value(&d_tempk))
G_set_d_null_value(&outrast1[col], 1);
else {
- /* calculate soil heat flux */
- d = et_a(d_rnetday, d_evapfr, d_tempk);
+ d = et_a(d_rnetday, d_evapfr, d_tempk);
outrast1[col] = d;
- if (G_put_raster_row(outfd1, outrast1, data_type_output) < 0)
- G_fatal_error(_("Cannot write to output raster file"));
+ if (G_put_d_raster_row(outfd1,outrast1) < 0)
+ G_fatal_error(_("Cannot write to output raster file"));
G_free(inrast_rnetday);
G_free(inrast_evapfr);
G_free(inrast_tempk);
Modified: grass-addons/gipe/readme.gipe
--- grass-addons/gipe/readme.gipe 2009-06-22 08:25:13 UTC (rev 38020)
+++ grass-addons/gipe/readme.gipe 2009-06-22 08:29:56 UTC (rev 38021)
@@ -20,7 +20,8 @@
20081012: Added i.latlong, removed i.latitude and i.longitude
20081012: Moved i.latlong to main SVN
20081020: Moved i.sunhours, i.emissivity to main SVN
-20090619: Moved i.eb.g0, i.eb.evapfr, i.eb.h_SEBAL01 to main SVN
+20090619: Moved i.eb.g0, i.eb.evapfr, i.eb.h_SEBAL01, i.eb.eta to main SVN
+20090619: Renamed i.eb.g0 to i.eb.soilheatflux inside main SVN
Imagery modules
@@ -37,7 +38,7 @@
-----IMPORT from DN to reflectance, radiance temperature or potential ET -------------
i.dn2full.l5: imports DN into radiance or reflectance/temperature for Landsat 5
-i.dn.full.l7: imports DN into radiance or reflectance/temperature for Landsat 7
+i.dn2full.l7: imports DN into radiance or reflectance/temperature for Landsat 7
i.dn2potrad.l5: Calculates potential Evapotranspiration from Landsat 5 DN directly
i.dn2potrad.l7: Calculates potential Evapotranspiration from Landsat 7 DN directly
i.dn2ref.ast: imports DN into radiance or reflectance for Terra-ASTER (not temperature)
@@ -47,7 +48,7 @@
-----ENERGY balance-------------------------------------------------------------------
i.eb.deltat: Energy-Balance: Calculates a generic Soil to Air temperature difference
i.eb.disp: Energy-Balance: Calculates the displacement height above canopy
-i.eb.eta: Energy-Balance: Calculates the Actual Evapotranspiration
+**i.eb.eta: (Now in main SVN) Energy-Balance: Calculates the Actual Evapotranspiration
**i.eb.evapfr: (Now in main SVN) Energy-Balance: Calculates the Evaporative Fraction (and soil moisture)
**i.eb.g0: (Now in main SVN) Energy-Balance: Calculates the Soil Heat Flux
i.eb.h0: Energy-Balance: Calculates the Sensible Heat Flux
@@ -77,7 +78,7 @@
-----Utilities-----------------------------------------------------------------------
**i.latlong: Calculates latitude/longitude by reprojecting without datum transform
**i.qc.modis: (Now in Main SVN as i.modis.qc) Converts Terra-MODIS Quality Assessment bits to numeric classes
-i.sattime: Calculates the time of satellite overpass
+<i.sattime>: Calculates the time of satellite overpass -> REMOVED (not needed since Landsat MTL has it now)
**i.sunhours: (now in main SVN) Calculates potential sunshine hours
