[GRASS-SVN] r38038 - in grass/branches/develbranch_6/scripts:
db.dropcol db.droptable
svn_grass at osgeo.org
Tue Jun 23 09:58:16 EDT 2009
Author: martinl
Date: 2009-06-23 09:58:16 -0400 (Tue, 23 Jun 2009)
New Revision: 38038
grass/branches/develbranch_6/scripts/db.dropcol/db.dropcol
grass/branches/develbranch_6/scripts/db.droptable/db.droptable
trac #661
Modified: grass/branches/develbranch_6/scripts/db.dropcol/db.dropcol
--- grass/branches/develbranch_6/scripts/db.dropcol/db.dropcol 2009-06-23 13:52:42 UTC (rev 38037)
+++ grass/branches/develbranch_6/scripts/db.dropcol/db.dropcol 2009-06-23 13:58:16 UTC (rev 38038)
@@ -32,7 +32,7 @@
#% key_desc : name
#% description: Table from which to drop attribute column
#% required : yes
-#% gisprompt: old,dbtable,dbtable
+#% gisprompt: old_dbtable,dbtable,dbtable
#%end
#%option
@@ -40,7 +40,7 @@
#% type: string
#% description: Name of the column
#% required : yes
-#% gisprompt: old,dbcolumn,dbcolumn
+#% gisprompt: old_dbcolumn,dbcolumn,dbcolumn
#%end
Modified: grass/branches/develbranch_6/scripts/db.droptable/db.droptable
--- grass/branches/develbranch_6/scripts/db.droptable/db.droptable 2009-06-23 13:52:42 UTC (rev 38037)
+++ grass/branches/develbranch_6/scripts/db.droptable/db.droptable 2009-06-23 13:58:16 UTC (rev 38038)
@@ -30,7 +30,7 @@
#% key_desc : name
#% description: Table to drop
#% required : yes
#%end
if [ -z "$GISBASE" ] ; then
