[GRASS-SVN] r38061 - in grass/trunk: db/db.columns db/db.connect
db/db.copy db/db.createdb db/db.databases db/db.describe
db/db.drivers db/db.dropdb db/db.droptable db/db.execute
db/db.login db/db.select db/db.tables display/d.barscale
display/d.colorlist display/d.colors display/d.colortable
display/d.erase display/d.extract display/d.font
display/d.fontlist display/d.geodesic display/d.graph
display/d.grid display/d.his display/d.histogram
display/d.info display/d.labels display/d.legend
display/d.linegraph display/d.measure display/d.nviz
display/d.path display/d.profile display/d.rast
display/d.rast.arrow display/d.rast.num display/d.rgb
display/d.rhumbline display/d.text display/d.thematic.area
display/d.title display/d.vect display/d.vect.chart
display/d.what.rast display/d.what.vect display/d.where
display/d.zoom doc/raster/r.example doc/vector/v.example
general/g.access general/g.cairocomp general/g.copy
general/g.dirseps general/g.filename general/g.findetc
general/g.findfile general/g.gisenv general/g.gui
general/g.list general/g.mapset general/g.mapsets
general/g.message general/g.mkfontcap general/g.mlist
general/g.mremove general/g.parser general/g.pnmcomp
general/g.proj general/g.region general/g.remove
general/g.rename general/g.setproj general/g.tempfile
general/g.transform general/g.version imagery/i.albedo
imagery/i.biomass imagery/i.cca imagery/i.class
imagery/i.cluster imagery/i.eb.eta imagery/i.eb.evapfr
imagery/i.eb.h_SEBAL01 imagery/i.eb.soilheatflux
imagery/i.emissivity imagery/i.evapo.time_integration
imagery/i.fft imagery/i.gensig imagery/i.gensigset
imagery/i.group imagery/i.his.rgb imagery/i.ifft
imagery/i.latlong imagery/i.maxlik imagery/i.modis.qc
imagery/i.pca imagery/i.points imagery/i.rectify
imagery/i.rgb.his imagery/i.smap imagery/i.sunhours
imagery/i.target imagery/i.vi imagery/i.vpoints imagery/i.zc
include lib/gis misc/m.cogo ps/ps.map raster/r.basins.fill
raster/r.bitpattern raster/r.buffer raster/r.carve
raster/r.category raster/r.circle raster/r.clump
raster/r.coin raster/r.colors raster/r.colors.out
raster/r.composite raster/r.compress raster/r.contour
raster/r.cost raster/r.covar raster/r.cross raster/r.describe
raster/r.digit raster/r.distance raster/r.drain
raster/r.external raster/r.external.out raster/r.fill.dir
raster/r.flow raster/r.grow raster/r.grow.distance
raster/r.gwflow raster/r.his raster/r.horizon raster/r.in.arc
raster/r.in.ascii raster/r.in.bin raster/r.in.gdal
raster/r.in.gridatb raster/r.in.mat raster/r.in.poly
raster/r.in.xyz raster/r.info raster/r.kappa raster/r.lake
raster/r.le/r.le.patch raster/r.le/r.le.pixel
raster/r.le/r.le.setup raster/r.le/r.le.trace
raster/r.li/r.li.cwed raster/r.li/r.li.dominance
raster/r.li/r.li.edgedensity raster/r.li/r.li.mpa
raster/r.li/r.li.mps raster/r.li/r.li.padcv
raster/r.li/r.li.padrange raster/r.li/r.li.padsd
raster/r.li/r.li.patchdensity raster/r.li/r.li.patchnum
raster/r.li/r.li.richness raster/r.li/r.li.shannon
raster/r.li/r.li.shape raster/r.li/r.li.simpson raster/r.los
raster/r.mapcalc raster/r.mfilter raster/r.mode
raster/r.neighbors raster/r.null raster/r.out.arc
raster/r.out.ascii raster/r.out.bin raster/r.out.gdal
raster/r.out.gridatb raster/r.out.mat raster/r.out.mpeg
raster/r.out.png raster/r.out.pov raster/r.out.ppm
raster/r.out.ppm3 raster/r.out.tiff raster/r.out.vrml
raster/r.out.vtk raster/r.param.scale raster/r.patch
raster/r.profile raster/r.proj raster/r.quant
raster/r.quantile raster/r.random raster/r.random.cells
raster/r.random.surface raster/r.reclass raster/r.recode
raster/r.region raster/r.report raster/r.resamp.interp
raster/r.resamp.rst raster/r.resamp.stats raster/r.resample
raster/r.rescale raster/r.rescale.eq raster/r.ros
raster/r.series raster/r.slope.aspect raster/r.spread
raster/r.spreadpath raster/r.statistics raster/r.statistics2
raster/r.statistics3 raster/r.stats raster/r.sun
raster/r.sun2 raster/r.sunmask raster/r.support
raster/r.support.stats raster/r.surf.area
raster/r.surf.contour raster/r.surf.fractal
raster/r.surf.gauss raster/r.surf.idw raster/r.surf.idw2
raster/r.surf.random raster/r.texture raster/r.thin
raster/r.timestamp raster/r.to.rast3 raster/r.to.rast3elev
raster/r.to.vect raster/r.topidx raster/r.topmodel
raster/r.transect raster/r.univar raster/r.uslek
raster/r.usler raster/r.volume raster/r.walk
raster/r.water.outlet raster/r.watershed/front raster/r.what
raster/r.what.color raster/simwe/r.sim.sediment
raster/simwe/r.sim.water raster3d/base raster3d/r3.cross.rast
raster3d/r3.gwflow raster3d/r3.in.ascii raster3d/r3.in.v5d
raster3d/r3.info raster3d/r3.mkdspf raster3d/r3.out.ascii
raster3d/r3.out.v5d raster3d/r3.out.vtk raster3d/r3.stats
raster3d/r3.timestamp raster3d/r3.to.rast sites/s.in.ascii
sites/s.out.ascii swig/perl/R_slope_aspect/r_slope_aspect
vector/lidar/v.lidar.correction vector/lidar/v.lidar.edgedetection
vector/lidar/v.lidar.growing vector/lidar/v.outlier
vector/lidar/v.surf.bspline vector/v.buffer vector/v.build
vector/v.build.polylines vector/v.category vector/v.class
vector/v.clean vector/v.clean/test vector/v.convert
vector/v.db.connect vector/v.db.select vector/v.delaunay
vector/v.distance vector/v.drape vector/v.edit
vector/v.external vector/v.extract vector/v.extrude
vector/v.generalize vector/v.hull vector/v.in.ascii
vector/v.in.db vector/v.in.dwg vector/v.in.dxf
vector/v.in.ogr vector/v.in.region vector/v.in.sites
vector/v.info vector/v.kcv vector/v.kernel vector/v.label
vector/v.label.sa vector/v.lrs/v.lrs.create
vector/v.lrs/v.lrs.label vector/v.lrs/v.lrs.segment
vector/v.lrs/v.lrs.where vector/v.mkgrid vector/v.neighbors
vector/v.net vector/v.net.alloc vector/v.net.iso
vector/v.net.path vector/v.net.salesman vector/v.net.steiner
vector/v.net.visibility vector/v.normal vector/v.out.ascii
vector/v.out.dxf vector/v.out.ogr vector/v.out.pov
vector/v.out.svg vector/v.out.vtk vector/v.overlay
vector/v.parallel vector/v.patch vector/v.perturb
vector/v.proj vector/v.qcount vector/v.random
vector/v.reclass vector/v.sample vector/v.segment
vector/v.select vector/v.split vector/v.support
vector/v.surf.idw vector/v.surf.rst vector/v.to.3d
vector/v.to.db vector/v.to.points vector/v.to.rast
vector/v.to.rast3 vector/v.transform vector/v.type
vector/v.univar vector/v.vol.rst vector/v.voronoi
vector/v.what vector/v.what.rast visualization/nviz/src
visualization/nviz2/cmd visualization/ximgview
svn_grass at osgeo.org
Wed Jun 24 12:57:00 EDT 2009
Author: martinl
Date: 2009-06-24 12:56:59 -0400 (Wed, 24 Jun 2009)
New Revision: 38061
grass/trunk/db/db.columns/main.c
grass/trunk/db/db.connect/main.c
grass/trunk/db/db.copy/main.c
grass/trunk/db/db.createdb/main.c
grass/trunk/db/db.databases/main.c
grass/trunk/db/db.describe/main.c
grass/trunk/db/db.drivers/main.c
grass/trunk/db/db.dropdb/main.c
grass/trunk/db/db.droptable/main.c
grass/trunk/db/db.execute/main.c
grass/trunk/db/db.login/main.c
grass/trunk/db/db.select/main.c
grass/trunk/db/db.tables/main.c
grass/trunk/display/d.barscale/main.c
grass/trunk/display/d.colorlist/main.c
grass/trunk/display/d.colors/main.c
grass/trunk/display/d.colortable/main.c
grass/trunk/display/d.erase/main.c
grass/trunk/display/d.extract/main.c
grass/trunk/display/d.font/main.c
grass/trunk/display/d.fontlist/main.c
grass/trunk/display/d.geodesic/main.c
grass/trunk/display/d.graph/main.c
grass/trunk/display/d.grid/main.c
grass/trunk/display/d.his/main.c
grass/trunk/display/d.histogram/main.c
grass/trunk/display/d.info/main.c
grass/trunk/display/d.labels/main.c
grass/trunk/display/d.legend/main.c
grass/trunk/display/d.linegraph/main.c
grass/trunk/display/d.measure/main.c
grass/trunk/display/d.nviz/main.c
grass/trunk/display/d.path/main.c
grass/trunk/display/d.profile/main.c
grass/trunk/display/d.rast.arrow/main.c
grass/trunk/display/d.rast.num/main.c
grass/trunk/display/d.rast/main.c
grass/trunk/display/d.rgb/main.c
grass/trunk/display/d.rhumbline/main.c
grass/trunk/display/d.text/main.c
grass/trunk/display/d.thematic.area/main.c
grass/trunk/display/d.title/main.c
grass/trunk/display/d.vect.chart/main.c
grass/trunk/display/d.vect/main.c
grass/trunk/display/d.what.rast/main.c
grass/trunk/display/d.what.vect/main.c
grass/trunk/display/d.where/main.c
grass/trunk/display/d.zoom/main.c
grass/trunk/doc/raster/r.example/main.c
grass/trunk/doc/vector/v.example/main.c
grass/trunk/general/g.access/main.c
grass/trunk/general/g.cairocomp/main.c
grass/trunk/general/g.copy/main.c
grass/trunk/general/g.dirseps/main.c
grass/trunk/general/g.filename/main.c
grass/trunk/general/g.findetc/main.c
grass/trunk/general/g.findfile/main.c
grass/trunk/general/g.gisenv/main.c
grass/trunk/general/g.gui/main.c
grass/trunk/general/g.list/main.c
grass/trunk/general/g.mapset/main.c
grass/trunk/general/g.mapsets/main.c
grass/trunk/general/g.message/main.c
grass/trunk/general/g.mkfontcap/main.c
grass/trunk/general/g.mlist/main.c
grass/trunk/general/g.mremove/main.c
grass/trunk/general/g.parser/main.c
grass/trunk/general/g.pnmcomp/main.c
grass/trunk/general/g.proj/main.c
grass/trunk/general/g.region/main.c
grass/trunk/general/g.remove/main.c
grass/trunk/general/g.rename/main.c
grass/trunk/general/g.setproj/main.c
grass/trunk/general/g.tempfile/main.c
grass/trunk/general/g.transform/main.c
grass/trunk/general/g.version/main.c
grass/trunk/imagery/i.albedo/main.c
grass/trunk/imagery/i.biomass/main.c
grass/trunk/imagery/i.cca/main.c
grass/trunk/imagery/i.class/main.c
grass/trunk/imagery/i.cluster/main.c
grass/trunk/imagery/i.eb.eta/main.c
grass/trunk/imagery/i.eb.evapfr/main.c
grass/trunk/imagery/i.eb.h_SEBAL01/main.c
grass/trunk/imagery/i.eb.soilheatflux/main.c
grass/trunk/imagery/i.emissivity/main.c
grass/trunk/imagery/i.evapo.time_integration/main.c
grass/trunk/imagery/i.fft/main.c
grass/trunk/imagery/i.gensig/main.c
grass/trunk/imagery/i.gensigset/main.c
grass/trunk/imagery/i.group/main.c
grass/trunk/imagery/i.his.rgb/main.c
grass/trunk/imagery/i.ifft/main.c
grass/trunk/imagery/i.latlong/main.c
grass/trunk/imagery/i.maxlik/main.c
grass/trunk/imagery/i.modis.qc/main.c
grass/trunk/imagery/i.pca/main.c
grass/trunk/imagery/i.points/main.c
grass/trunk/imagery/i.rectify/main.c
grass/trunk/imagery/i.rgb.his/main.c
grass/trunk/imagery/i.smap/main.c
grass/trunk/imagery/i.sunhours/main.c
grass/trunk/imagery/i.target/main.c
grass/trunk/imagery/i.vi/main.c
grass/trunk/imagery/i.vpoints/main.c
grass/trunk/imagery/i.zc/main.c
grass/trunk/include/gis.h
grass/trunk/include/gisdefs.h
grass/trunk/lib/gis/parser.c
grass/trunk/misc/m.cogo/main.c
grass/trunk/ps/ps.map/main.c
grass/trunk/raster/r.basins.fill/main.c
grass/trunk/raster/r.bitpattern/main.c
grass/trunk/raster/r.buffer/main.c
grass/trunk/raster/r.carve/main.c
grass/trunk/raster/r.category/main.c
grass/trunk/raster/r.circle/main.c
grass/trunk/raster/r.clump/main.c
grass/trunk/raster/r.coin/main.c
grass/trunk/raster/r.colors.out/main.c
grass/trunk/raster/r.colors/main.c
grass/trunk/raster/r.composite/main.c
grass/trunk/raster/r.compress/main.c
grass/trunk/raster/r.contour/main.c
grass/trunk/raster/r.cost/main.c
grass/trunk/raster/r.covar/main.c
grass/trunk/raster/r.cross/main.c
grass/trunk/raster/r.describe/main.c
grass/trunk/raster/r.digit/main.c
grass/trunk/raster/r.distance/main.c
grass/trunk/raster/r.drain/main.c
grass/trunk/raster/r.external.out/main.c
grass/trunk/raster/r.external/main.c
grass/trunk/raster/r.fill.dir/main.c
grass/trunk/raster/r.flow/main.c
grass/trunk/raster/r.grow.distance/main.c
grass/trunk/raster/r.grow/main.c
grass/trunk/raster/r.gwflow/main.c
grass/trunk/raster/r.his/main.c
grass/trunk/raster/r.horizon/main.c
grass/trunk/raster/r.in.arc/main.c
grass/trunk/raster/r.in.ascii/main.c
grass/trunk/raster/r.in.bin/main.c
grass/trunk/raster/r.in.gdal/main.c
grass/trunk/raster/r.in.gridatb/main.c
grass/trunk/raster/r.in.mat/main.c
grass/trunk/raster/r.in.poly/main.c
grass/trunk/raster/r.in.xyz/main.c
grass/trunk/raster/r.info/main.c
grass/trunk/raster/r.kappa/main.c
grass/trunk/raster/r.lake/main.c
grass/trunk/raster/r.le/r.le.patch/main.c
grass/trunk/raster/r.le/r.le.pixel/main.c
grass/trunk/raster/r.le/r.le.setup/main.c
grass/trunk/raster/r.le/r.le.trace/main.c
grass/trunk/raster/r.li/r.li.cwed/cwed.c
grass/trunk/raster/r.li/r.li.dominance/dominance.c
grass/trunk/raster/r.li/r.li.edgedensity/edgedensity.c
grass/trunk/raster/r.li/r.li.mpa/mpa.c
grass/trunk/raster/r.li/r.li.mps/mps.c
grass/trunk/raster/r.li/r.li.padcv/padcv.c
grass/trunk/raster/r.li/r.li.padrange/padrange.c
grass/trunk/raster/r.li/r.li.padsd/padsd.c
grass/trunk/raster/r.li/r.li.patchdensity/main.c
grass/trunk/raster/r.li/r.li.patchnum/main.c
grass/trunk/raster/r.li/r.li.richness/richness.c
grass/trunk/raster/r.li/r.li.shannon/shannon.c
grass/trunk/raster/r.li/r.li.shape/main.c
grass/trunk/raster/r.li/r.li.simpson/simpson.c
grass/trunk/raster/r.los/main.c
grass/trunk/raster/r.mapcalc/main.c
grass/trunk/raster/r.mfilter/main.c
grass/trunk/raster/r.mode/main.c
grass/trunk/raster/r.neighbors/main.c
grass/trunk/raster/r.null/main.c
grass/trunk/raster/r.out.arc/main.c
grass/trunk/raster/r.out.ascii/main.c
grass/trunk/raster/r.out.bin/main.c
grass/trunk/raster/r.out.gdal/main.c
grass/trunk/raster/r.out.gridatb/main.c
grass/trunk/raster/r.out.mat/main.c
grass/trunk/raster/r.out.mpeg/main.c
grass/trunk/raster/r.out.png/main.c
grass/trunk/raster/r.out.pov/main.c
grass/trunk/raster/r.out.ppm/main.c
grass/trunk/raster/r.out.ppm3/main.c
grass/trunk/raster/r.out.tiff/main.c
grass/trunk/raster/r.out.vrml/main.c
grass/trunk/raster/r.out.vtk/main.c
grass/trunk/raster/r.param.scale/interface.c
grass/trunk/raster/r.patch/main.c
grass/trunk/raster/r.profile/main.c
grass/trunk/raster/r.proj/main.c
grass/trunk/raster/r.quant/main.c
grass/trunk/raster/r.quantile/main.c
grass/trunk/raster/r.random.cells/main.c
grass/trunk/raster/r.random.surface/main.c
grass/trunk/raster/r.random/main.c
grass/trunk/raster/r.reclass/main.c
grass/trunk/raster/r.recode/main.c
grass/trunk/raster/r.region/main.c
grass/trunk/raster/r.report/main.c
grass/trunk/raster/r.resamp.interp/main.c
grass/trunk/raster/r.resamp.rst/main.c
grass/trunk/raster/r.resamp.stats/main.c
grass/trunk/raster/r.resample/main.c
grass/trunk/raster/r.rescale.eq/main.c
grass/trunk/raster/r.rescale/main.c
grass/trunk/raster/r.ros/main.c
grass/trunk/raster/r.series/main.c
grass/trunk/raster/r.slope.aspect/main.c
grass/trunk/raster/r.spread/main.c
grass/trunk/raster/r.spreadpath/main.c
grass/trunk/raster/r.statistics/main.c
grass/trunk/raster/r.statistics2/main.c
grass/trunk/raster/r.statistics3/main.c
grass/trunk/raster/r.stats/main.c
grass/trunk/raster/r.sun/main.c
grass/trunk/raster/r.sun2/main.c
grass/trunk/raster/r.sunmask/main.c
grass/trunk/raster/r.support.stats/main.c
grass/trunk/raster/r.support/main.c
grass/trunk/raster/r.surf.area/main.c
grass/trunk/raster/r.surf.contour/main.c
grass/trunk/raster/r.surf.fractal/main.c
grass/trunk/raster/r.surf.gauss/main.c
grass/trunk/raster/r.surf.idw/main.c
grass/trunk/raster/r.surf.idw2/main.c
grass/trunk/raster/r.surf.random/main.c
grass/trunk/raster/r.texture/main.c
grass/trunk/raster/r.thin/main.c
grass/trunk/raster/r.timestamp/main.c
grass/trunk/raster/r.to.rast3/main.c
grass/trunk/raster/r.to.rast3elev/main.c
grass/trunk/raster/r.to.vect/main.c
grass/trunk/raster/r.topidx/main.c
grass/trunk/raster/r.topmodel/main.c
grass/trunk/raster/r.transect/main.c
grass/trunk/raster/r.univar/r.univar_main.c
grass/trunk/raster/r.univar/r3.univar_main.c
grass/trunk/raster/r.uslek/main.c
grass/trunk/raster/r.usler/main.c
grass/trunk/raster/r.volume/main.c
grass/trunk/raster/r.walk/main.c
grass/trunk/raster/r.water.outlet/main.c
grass/trunk/raster/r.watershed/front/main.c
grass/trunk/raster/r.what.color/main.c
grass/trunk/raster/r.what/main.c
grass/trunk/raster/simwe/r.sim.sediment/main.c
grass/trunk/raster/simwe/r.sim.water/main.c
grass/trunk/raster3d/base/r3.mask.main.c
grass/trunk/raster3d/base/r3.null.main.c
grass/trunk/raster3d/r3.cross.rast/main.c
grass/trunk/raster3d/r3.gwflow/main.c
grass/trunk/raster3d/r3.in.ascii/main.c
grass/trunk/raster3d/r3.in.v5d/main.c
grass/trunk/raster3d/r3.info/r3.info.main.c
grass/trunk/raster3d/r3.mkdspf/main.c
grass/trunk/raster3d/r3.out.ascii/main.c
grass/trunk/raster3d/r3.out.v5d/main.c
grass/trunk/raster3d/r3.out.vtk/main.c
grass/trunk/raster3d/r3.stats/main.c
grass/trunk/raster3d/r3.timestamp/r3.timestamp.main.c
grass/trunk/raster3d/r3.to.rast/main.c
grass/trunk/sites/s.in.ascii/main.c
grass/trunk/sites/s.out.ascii/main.c
grass/trunk/swig/perl/R_slope_aspect/r_slope_aspect/r_slope_aspect.c
grass/trunk/vector/lidar/v.lidar.correction/main.c
grass/trunk/vector/lidar/v.lidar.edgedetection/main.c
grass/trunk/vector/lidar/v.lidar.growing/main.c
grass/trunk/vector/lidar/v.outlier/main.c
grass/trunk/vector/lidar/v.surf.bspline/main.c
grass/trunk/vector/v.buffer/main.c
grass/trunk/vector/v.build.polylines/main.c
grass/trunk/vector/v.build/main.c
grass/trunk/vector/v.category/main.c
grass/trunk/vector/v.class/main.c
grass/trunk/vector/v.clean/main.c
grass/trunk/vector/v.clean/test/topocheck.c
grass/trunk/vector/v.convert/main.c
grass/trunk/vector/v.db.connect/main.c
grass/trunk/vector/v.db.select/main.c
grass/trunk/vector/v.delaunay/main.c
grass/trunk/vector/v.distance/main.c
grass/trunk/vector/v.drape/main.c
grass/trunk/vector/v.edit/main.c
grass/trunk/vector/v.external/main.c
grass/trunk/vector/v.extract/main.c
grass/trunk/vector/v.extrude/main.c
grass/trunk/vector/v.generalize/main.c
grass/trunk/vector/v.hull/main.c
grass/trunk/vector/v.in.ascii/main.c
grass/trunk/vector/v.in.db/main.c
grass/trunk/vector/v.in.dwg/main.c
grass/trunk/vector/v.in.dxf/main.c
grass/trunk/vector/v.in.ogr/main.c
grass/trunk/vector/v.in.region/main.c
grass/trunk/vector/v.in.sites/main.c
grass/trunk/vector/v.info/main.c
grass/trunk/vector/v.kcv/main.c
grass/trunk/vector/v.kernel/main.c
grass/trunk/vector/v.label.sa/main.c
grass/trunk/vector/v.label/main.c
grass/trunk/vector/v.lrs/v.lrs.create/main.c
grass/trunk/vector/v.lrs/v.lrs.label/main.c
grass/trunk/vector/v.lrs/v.lrs.segment/main.c
grass/trunk/vector/v.lrs/v.lrs.where/main.c
grass/trunk/vector/v.mkgrid/main.c
grass/trunk/vector/v.neighbors/main.c
grass/trunk/vector/v.net.alloc/main.c
grass/trunk/vector/v.net.iso/main.c
grass/trunk/vector/v.net.path/main.c
grass/trunk/vector/v.net.salesman/main.c
grass/trunk/vector/v.net.steiner/main.c
grass/trunk/vector/v.net.visibility/main.c
grass/trunk/vector/v.net/main.c
grass/trunk/vector/v.normal/main.c
grass/trunk/vector/v.out.ascii/main.c
grass/trunk/vector/v.out.dxf/main.c
grass/trunk/vector/v.out.ogr/main.c
grass/trunk/vector/v.out.pov/main.c
grass/trunk/vector/v.out.svg/main.c
grass/trunk/vector/v.out.vtk/main.c
grass/trunk/vector/v.overlay/main.c
grass/trunk/vector/v.parallel/main.c
grass/trunk/vector/v.patch/main.c
grass/trunk/vector/v.perturb/main.c
grass/trunk/vector/v.proj/main.c
grass/trunk/vector/v.qcount/main.c
grass/trunk/vector/v.random/main.c
grass/trunk/vector/v.reclass/main.c
grass/trunk/vector/v.sample/main.c
grass/trunk/vector/v.segment/main.c
grass/trunk/vector/v.select/main.c
grass/trunk/vector/v.split/main.c
grass/trunk/vector/v.support/main.c
grass/trunk/vector/v.surf.idw/main.c
grass/trunk/vector/v.surf.rst/main.c
grass/trunk/vector/v.to.3d/main.c
grass/trunk/vector/v.to.db/main.c
grass/trunk/vector/v.to.points/main.c
grass/trunk/vector/v.to.rast/main.c
grass/trunk/vector/v.to.rast3/main.c
grass/trunk/vector/v.transform/main.c
grass/trunk/vector/v.type/main.c
grass/trunk/vector/v.univar/main.c
grass/trunk/vector/v.vol.rst/main.c
grass/trunk/vector/v.voronoi/main.c
grass/trunk/vector/v.what.rast/main.c
grass/trunk/vector/v.what/main.c
grass/trunk/visualization/nviz/src/nviz_init.c
grass/trunk/visualization/nviz2/cmd/main.c
grass/trunk/visualization/ximgview/main.c
use array for keywords (to avoid duplicate locales)
G_add_keyword() and G_set_keywords() added to gislib
modules updated
Modified: grass/trunk/db/db.columns/main.c
--- grass/trunk/db/db.columns/main.c 2009-06-24 16:38:17 UTC (rev 38060)
+++ grass/trunk/db/db.columns/main.c 2009-06-24 16:56:59 UTC (rev 38061)
@@ -89,7 +89,8 @@
/* Set description */
module = G_define_module();
- module->keywords = _("database, attribute table");
+ G_add_keyword(_("database"));
+ G_add_keyword(_("attribute table"));
module->description = _("List all columns for a given table.");
if (G_parser(argc, argv))
Modified: grass/trunk/db/db.connect/main.c
--- grass/trunk/db/db.connect/main.c 2009-06-24 16:38:17 UTC (rev 38060)
+++ grass/trunk/db/db.connect/main.c 2009-06-24 16:56:59 UTC (rev 38061)
@@ -42,7 +42,8 @@
_("Prints/sets general DB connection for current mapset and exits.");
Modified: grass/trunk/db/db.copy/main.c
--- grass/trunk/db/db.copy/main.c 2009-06-24 16:38:17 UTC (rev 38060)
+++ grass/trunk/db/db.copy/main.c 2009-06-24 16:56:59 UTC (rev 38061)
@@ -31,7 +31,9 @@
- module->keywords = _("database, attribute table, SQL");
+ G_add_keyword(_("SQL"));
module->label = _("Copy a table.");
_("Either 'from_table' (optionally with 'where') can be used "
Modified: grass/trunk/db/db.createdb/main.c
--- grass/trunk/db/db.createdb/main.c 2009-06-24 16:38:17 UTC (rev 38060)
+++ grass/trunk/db/db.createdb/main.c 2009-06-24 16:56:59 UTC (rev 38061)
@@ -68,7 +68,8 @@
- module->keywords = _("database, SQL");
module->description = _("Creates an empty database.");
Modified: grass/trunk/db/db.databases/main.c
--- grass/trunk/db/db.databases/main.c 2009-06-24 16:38:17 UTC (rev 38060)
+++ grass/trunk/db/db.databases/main.c 2009-06-24 16:56:59 UTC (rev 38061)
@@ -87,7 +87,8 @@
_("List all databases for a given driver and location.");
Modified: grass/trunk/db/db.describe/main.c
--- grass/trunk/db/db.describe/main.c 2009-06-24 16:38:17 UTC (rev 38060)
+++ grass/trunk/db/db.describe/main.c 2009-06-24 16:56:59 UTC (rev 38061)
@@ -122,7 +122,8 @@
module->description = _("Describes a table in detail.");
Modified: grass/trunk/db/db.drivers/main.c
--- grass/trunk/db/db.drivers/main.c 2009-06-24 16:38:17 UTC (rev 38060)
+++ grass/trunk/db/db.drivers/main.c 2009-06-24 16:56:59 UTC (rev 38061)
@@ -71,7 +71,8 @@
module->description = _("List all database drivers.");
Modified: grass/trunk/db/db.dropdb/main.c
--- grass/trunk/db/db.dropdb/main.c 2009-06-24 16:38:17 UTC (rev 38060)
+++ grass/trunk/db/db.dropdb/main.c 2009-06-24 16:56:59 UTC (rev 38061)
@@ -68,7 +68,8 @@
module->description = _("Removes a database.");
Modified: grass/trunk/db/db.droptable/main.c
--- grass/trunk/db/db.droptable/main.c 2009-06-24 16:38:17 UTC (rev 38060)
+++ grass/trunk/db/db.droptable/main.c 2009-06-24 16:56:59 UTC (rev 38061)
@@ -75,7 +75,8 @@
module->description = _("Removes a table from database.");
Modified: grass/trunk/db/db.execute/main.c
--- grass/trunk/db/db.execute/main.c 2009-06-24 16:38:17 UTC (rev 38060)
+++ grass/trunk/db/db.execute/main.c 2009-06-24 16:56:59 UTC (rev 38061)
@@ -103,7 +103,9 @@
module->description = _("Executes any SQL statement.");
input = G_define_standard_option(G_OPT_F_INPUT);
Modified: grass/trunk/db/db.login/main.c
--- grass/trunk/db/db.login/main.c 2009-06-24 16:38:17 UTC (rev 38060)
+++ grass/trunk/db/db.login/main.c 2009-06-24 16:56:59 UTC (rev 38061)
@@ -40,7 +40,8 @@
G_gisinit(argv[0]);
module->description = _("Sets user/password for driver/database.");
driver = G_define_standard_option(G_OPT_DB_DRIVER);
Modified: grass/trunk/db/db.select/main.c
--- grass/trunk/db/db.select/main.c 2009-06-24 16:38:17 UTC (rev 38060)
+++ grass/trunk/db/db.select/main.c 2009-06-24 16:56:59 UTC (rev 38061)
@@ -232,7 +232,9 @@
module->description = _("Selects data from table.");
Modified: grass/trunk/db/db.tables/main.c
--- grass/trunk/db/db.tables/main.c 2009-06-24 16:38:17 UTC (rev 38060)
+++ grass/trunk/db/db.tables/main.c 2009-06-24 16:56:59 UTC (rev 38061)
@@ -92,7 +92,8 @@
module->description = _("Lists all tables for a given database.");
Modified: grass/trunk/display/d.barscale/main.c
--- grass/trunk/display/d.barscale/main.c 2009-06-24 16:38:17 UTC (rev 38060)
+++ grass/trunk/display/d.barscale/main.c 2009-06-24 16:56:59 UTC (rev 38061)
@@ -49,7 +49,8 @@
G_gisinit(argv[0]);
- module->keywords = _("display, cartography");
+ G_add_keyword(_("display"));
+ G_add_keyword(_("cartography"));
module->description = _("Displays a barscale on the graphics monitor.");
feet = G_define_flag();
Modified: grass/trunk/display/d.colorlist/main.c
--- grass/trunk/display/d.colorlist/main.c 2009-06-24 16:38:17 UTC (rev 38060)
+++ grass/trunk/display/d.colorlist/main.c 2009-06-24 16:56:59 UTC (rev 38061)
@@ -32,7 +32,7 @@
G_gisinit(argv[0]);
- module->keywords = _("display");
"Output a list of all available display colors with a configurable "
"separator (default is comma).";
Modified: grass/trunk/display/d.colors/main.c
--- grass/trunk/display/d.colors/main.c 2009-06-24 16:38:17 UTC (rev 38060)
+++ grass/trunk/display/d.colors/main.c 2009-06-24 16:56:59 UTC (rev 38061)
@@ -37,7 +37,7 @@
G_gisinit(argv[0]);
"Allows the user to interactively change the color table "
"of a raster map layer displayed on the graphics monitor.";
Modified: grass/trunk/display/d.colortable/main.c
--- grass/trunk/display/d.colortable/main.c 2009-06-24 16:38:17 UTC (rev 38060)
+++ grass/trunk/display/d.colortable/main.c 2009-06-24 16:56:59 UTC (rev 38061)
@@ -60,7 +60,8 @@
G_gisinit(argv[0]);
- module->keywords = _("display, setup");
+ G_add_keyword(_("setup"));
_("Displays the color table associated with a raster map layer.");
Modified: grass/trunk/display/d.erase/main.c
--- grass/trunk/display/d.erase/main.c 2009-06-24 16:38:17 UTC (rev 38060)
+++ grass/trunk/display/d.erase/main.c 2009-06-24 16:56:59 UTC (rev 38061)
@@ -26,7 +26,7 @@
G_gisinit(argv[0]);
_("Erase the contents of the active display frame with user defined color");
Modified: grass/trunk/display/d.extract/main.c
--- grass/trunk/display/d.extract/main.c 2009-06-24 16:38:17 UTC (rev 38060)
+++ grass/trunk/display/d.extract/main.c 2009-06-24 16:56:59 UTC (rev 38061)
@@ -46,7 +46,7 @@
G_gisinit(argv[0]);
_("Selects and extracts vectors with mouse into new vector map.");
Modified: grass/trunk/display/d.font/main.c
--- grass/trunk/display/d.font/main.c 2009-06-24 16:38:17 UTC (rev 38060)
+++ grass/trunk/display/d.font/main.c 2009-06-24 16:56:59 UTC (rev 38061)
@@ -42,7 +42,7 @@
G_gisinit(argv[0]);
_("Selects the font in which text will be displayed "
"on the user's graphics monitor.");
Modified: grass/trunk/display/d.fontlist/main.c
--- grass/trunk/display/d.fontlist/main.c 2009-06-24 16:38:17 UTC (rev 38060)
+++ grass/trunk/display/d.fontlist/main.c 2009-06-24 16:56:59 UTC (rev 38061)
@@ -35,7 +35,7 @@
G_gisinit(argv[0]);
module->description = _("Lists the available fonts.");
flagl = G_define_flag();
Modified: grass/trunk/display/d.geodesic/main.c
--- grass/trunk/display/d.geodesic/main.c 2009-06-24 16:38:17 UTC (rev 38060)
+++ grass/trunk/display/d.geodesic/main.c 2009-06-24 16:56:59 UTC (rev 38061)
@@ -40,7 +40,7 @@
G_gisinit(argv[0]);
_("Displays a geodesic line, tracing the shortest distance "
"between two geographic points along a great circle, in "
Modified: grass/trunk/display/d.graph/main.c
--- grass/trunk/display/d.graph/main.c 2009-06-24 16:38:17 UTC (rev 38060)
+++ grass/trunk/display/d.graph/main.c 2009-06-24 16:56:59 UTC (rev 38061)
@@ -54,7 +54,8 @@
G_gisinit(argv[0]);
_("Program for generating and displaying simple graphics on the "
"display monitor.");
Modified: grass/trunk/display/d.grid/main.c
--- grass/trunk/display/d.grid/main.c 2009-06-24 16:38:17 UTC (rev 38060)
+++ grass/trunk/display/d.grid/main.c 2009-06-24 16:56:59 UTC (rev 38061)
@@ -48,7 +48,8 @@
G_gisinit(argv[0]);
_("Overlays a user-specified grid "
"in the active display frame on the graphics monitor.");
Modified: grass/trunk/display/d.his/main.c
--- grass/trunk/display/d.his/main.c 2009-06-24 16:38:17 UTC (rev 38060)
+++ grass/trunk/display/d.his/main.c 2009-06-24 16:56:59 UTC (rev 38061)
@@ -59,7 +59,7 @@
G_gisinit(argv[0]);
_("Displays the result obtained by combining "
"hue, intensity, and saturation (his) values "
Modified: grass/trunk/display/d.histogram/main.c
--- grass/trunk/display/d.histogram/main.c 2009-06-24 16:38:17 UTC (rev 38060)
+++ grass/trunk/display/d.histogram/main.c 2009-06-24 16:56:59 UTC (rev 38061)
@@ -81,7 +81,7 @@
G_gisinit(argv[0]);
_("Displays a histogram in the form of a pie or bar chart "
"for a user-specified raster map.");
Modified: grass/trunk/display/d.info/main.c
--- grass/trunk/display/d.info/main.c 2009-06-24 16:38:17 UTC (rev 38060)
+++ grass/trunk/display/d.info/main.c 2009-06-24 16:56:59 UTC (rev 38061)
@@ -28,7 +28,7 @@
G_gisinit(argv[0]);
_("Display information about the active display monitor");
Modified: grass/trunk/display/d.labels/main.c
--- grass/trunk/display/d.labels/main.c 2009-06-24 16:38:17 UTC (rev 38060)
+++ grass/trunk/display/d.labels/main.c 2009-06-24 16:56:59 UTC (rev 38061)
@@ -40,7 +40,7 @@
_("Displays text labels (created with v.label) "
"to the active frame on the graphics monitor.");
Modified: grass/trunk/display/d.legend/main.c
--- grass/trunk/display/d.legend/main.c 2009-06-24 16:38:17 UTC (rev 38060)
+++ grass/trunk/display/d.legend/main.c 2009-06-24 16:56:59 UTC (rev 38061)
@@ -81,7 +81,8 @@
G_gisinit(argv[0]);
_("Displays a legend for a raster map in the active frame "
"of the graphics monitor.");
Modified: grass/trunk/display/d.linegraph/main.c
--- grass/trunk/display/d.linegraph/main.c 2009-06-24 16:38:17 UTC (rev 38060)
+++ grass/trunk/display/d.linegraph/main.c 2009-06-24 16:56:59 UTC (rev 38061)
@@ -116,7 +116,7 @@
_("Generates and displays simple line graphs in the active graphics monitor display frame.");
Modified: grass/trunk/display/d.measure/main.c
--- grass/trunk/display/d.measure/main.c 2009-06-24 16:38:17 UTC (rev 38060)
+++ grass/trunk/display/d.measure/main.c 2009-06-24 16:56:59 UTC (rev 38061)
@@ -43,7 +43,7 @@
G_gisinit(argv[0]);
_("Measures the lengths and areas of features drawn "
"by the user in the active display frame on the "
Modified: grass/trunk/display/d.nviz/main.c
--- grass/trunk/display/d.nviz/main.c 2009-06-24 16:38:17 UTC (rev 38060)
+++ grass/trunk/display/d.nviz/main.c 2009-06-24 16:56:59 UTC (rev 38061)
@@ -65,7 +65,7 @@
module->description = _("Creates fly-through script to run in NVIZ.");
parm.opt1 = G_define_standard_option(G_OPT_R_INPUT);
Modified: grass/trunk/display/d.path/main.c
--- grass/trunk/display/d.path/main.c 2009-06-24 16:38:17 UTC (rev 38060)
+++ grass/trunk/display/d.path/main.c 2009-06-24 16:56:59 UTC (rev 38061)
@@ -45,7 +45,8 @@
G_gisinit(argv[0]);
- module->keywords = _("display, networking");
+ G_add_keyword(_("networking"));
_("Finds shortest path for selected starting and ending node.");
Modified: grass/trunk/display/d.profile/main.c
--- grass/trunk/display/d.profile/main.c 2009-06-24 16:38:17 UTC (rev 38060)
+++ grass/trunk/display/d.profile/main.c 2009-06-24 16:56:59 UTC (rev 38061)
@@ -187,7 +187,7 @@
module->description = _("Plots profile of a transect.");
/* set up command line */
Modified: grass/trunk/display/d.rast/main.c
--- grass/trunk/display/d.rast/main.c 2009-06-24 16:38:17 UTC (rev 38060)
+++ grass/trunk/display/d.rast/main.c 2009-06-24 16:56:59 UTC (rev 38061)
@@ -50,7 +50,8 @@
G_gisinit(argv[0]);
- module->keywords = _("display, raster");
+ G_add_keyword(_("raster"));
_("Displays and overlays raster map layers "
Modified: grass/trunk/display/d.rast.arrow/main.c
--- grass/trunk/display/d.rast.arrow/main.c 2009-06-24 16:38:17 UTC (rev 38060)
+++ grass/trunk/display/d.rast.arrow/main.c 2009-06-24 16:56:59 UTC (rev 38061)
@@ -92,7 +92,7 @@
G_gisinit(argv[0]);
_("Draws arrows representing cell aspect direction "
"for a raster map containing aspect data.");
Modified: grass/trunk/display/d.rast.num/main.c
--- grass/trunk/display/d.rast.num/main.c 2009-06-24 16:38:17 UTC (rev 38060)
+++ grass/trunk/display/d.rast.num/main.c 2009-06-24 16:56:59 UTC (rev 38061)
@@ -68,7 +68,7 @@
G_gisinit(argv[0]);
_("Overlays cell category values on a raster map layer "
"displayed to the graphics monitor.");
Modified: grass/trunk/display/d.rgb/main.c
--- grass/trunk/display/d.rgb/main.c 2009-06-24 16:38:17 UTC (rev 38060)
+++ grass/trunk/display/d.rgb/main.c 2009-06-24 16:56:59 UTC (rev 38061)
@@ -49,7 +49,7 @@
G_gisinit(argv[0]);
_("Displays three user-specified raster map layers "
"as red, green, and blue overlays in the active graphics frame.");
Modified: grass/trunk/display/d.rhumbline/main.c
--- grass/trunk/display/d.rhumbline/main.c 2009-06-24 16:38:17 UTC (rev 38060)
+++ grass/trunk/display/d.rhumbline/main.c 2009-06-24 16:56:59 UTC (rev 38061)
@@ -40,7 +40,7 @@
G_gisinit(argv[0]);
_("Displays the rhumbline joining two longitude/latitude coordinates.");
Modified: grass/trunk/display/d.text/main.c
--- grass/trunk/display/d.text/main.c 2009-06-24 16:38:17 UTC (rev 38060)
+++ grass/trunk/display/d.text/main.c 2009-06-24 16:56:59 UTC (rev 38061)
@@ -133,7 +133,7 @@
G_gisinit(argv[0]);
_("Draws text in the active display frame on the graphics monitor using the current font.");
Modified: grass/trunk/display/d.thematic.area/main.c
--- grass/trunk/display/d.thematic.area/main.c 2009-06-24 16:38:17 UTC (rev 38060)
+++ grass/trunk/display/d.thematic.area/main.c 2009-06-24 16:56:59 UTC (rev 38061)
@@ -73,7 +73,7 @@
G_gisinit(argv[0]);
_("Displays a thematic vector area map in the active "
"frame on the graphics monitor.");
Modified: grass/trunk/display/d.title/main.c
--- grass/trunk/display/d.title/main.c 2009-06-24 16:38:17 UTC (rev 38060)
+++ grass/trunk/display/d.title/main.c 2009-06-24 16:56:59 UTC (rev 38061)
@@ -46,7 +46,7 @@
G_gisinit(argv[0]);
_("Create a TITLE for a raster map in a form suitable "
"for display with d.text.");
Modified: grass/trunk/display/d.vect/main.c
--- grass/trunk/display/d.vect/main.c 2009-06-24 16:38:17 UTC (rev 38060)
+++ grass/trunk/display/d.vect/main.c 2009-06-24 16:56:59 UTC (rev 38061)
@@ -118,7 +118,8 @@
G_gisinit(argv[0]);
- module->keywords = _("display, vector");
+ G_add_keyword(_("vector"));
_("Displays vector data in the active "
Modified: grass/trunk/display/d.vect.chart/main.c
--- grass/trunk/display/d.vect.chart/main.c 2009-06-24 16:38:17 UTC (rev 38060)
+++ grass/trunk/display/d.vect.chart/main.c 2009-06-24 16:56:59 UTC (rev 38061)
@@ -60,7 +60,8 @@
_("Displays charts of vector data in the active frame "
"on the graphics monitor.");
Modified: grass/trunk/display/d.what.rast/main.c
--- grass/trunk/display/d.what.rast/main.c 2009-06-24 16:38:17 UTC (rev 38060)
+++ grass/trunk/display/d.what.rast/main.c 2009-06-24 16:56:59 UTC (rev 38061)
@@ -45,7 +45,7 @@
G_gisinit(argv[0]);
_("Allows the user to interactively query the category contents "
"of multiple raster map layers at user specified locations "
Modified: grass/trunk/display/d.what.vect/main.c
--- grass/trunk/display/d.what.vect/main.c 2009-06-24 16:38:17 UTC (rev 38060)
+++ grass/trunk/display/d.what.vect/main.c 2009-06-24 16:56:59 UTC (rev 38061)
@@ -53,7 +53,7 @@
G_gisinit(argv[0]);
_("Allows the user to interactively query a vector map layer "
"at user-selected locations within the current geographic region.");
Modified: grass/trunk/display/d.where/main.c
--- grass/trunk/display/d.where/main.c 2009-06-24 16:38:17 UTC (rev 38060)
+++ grass/trunk/display/d.where/main.c 2009-06-24 16:56:59 UTC (rev 38061)
@@ -40,7 +40,7 @@
G_gisinit(argv[0]);
_("Identifies the geographic coordinates associated with "
"point locations given in display coordinates.");
Modified: grass/trunk/display/d.zoom/main.c
--- grass/trunk/display/d.zoom/main.c 2009-06-24 16:38:17 UTC (rev 38060)
+++ grass/trunk/display/d.zoom/main.c 2009-06-24 16:56:59 UTC (rev 38061)
@@ -58,7 +58,7 @@
G_gisinit(argv[0]);
_("Allows the user to change the current geographic "
"region settings interactively, with a mouse.");
Modified: grass/trunk/doc/raster/r.example/main.c
--- grass/trunk/doc/raster/r.example/main.c 2009-06-24 16:38:17 UTC (rev 38060)
+++ grass/trunk/doc/raster/r.example/main.c 2009-06-24 16:56:59 UTC (rev 38061)
@@ -82,7 +82,9 @@
/* initialize module */
- module->keywords = _("raster, keyword2, keyword3");
+ G_add_keyword(_("keyword2"));
+ G_add_keyword(_("keyword3"));
module->description = _("My first raster module");
/* Define the different options as defined in gis.h */
Modified: grass/trunk/doc/vector/v.example/main.c
--- grass/trunk/doc/vector/v.example/main.c 2009-06-24 16:38:17 UTC (rev 38060)
+++ grass/trunk/doc/vector/v.example/main.c 2009-06-24 16:56:59 UTC (rev 38061)
@@ -47,7 +47,9 @@
- module->keywords = _("vector, keyword2, keyword3");
module->description = _("My first vector module");
Modified: grass/trunk/general/g.access/main.c
--- grass/trunk/general/g.access/main.c 2009-06-24 16:38:17 UTC (rev 38060)
+++ grass/trunk/general/g.access/main.c 2009-06-24 16:56:59 UTC (rev 38061)
@@ -34,7 +34,7 @@
G_gisinit(argv[0]);
- module->keywords = _("general");
+ G_add_keyword(_("general"));
_("Controls access to the current mapset for other users on the system.");
Modified: grass/trunk/general/g.cairocomp/main.c
--- grass/trunk/general/g.cairocomp/main.c 2009-06-24 16:38:17 UTC (rev 38060)
+++ grass/trunk/general/g.cairocomp/main.c 2009-06-24 16:56:59 UTC (rev 38061)
@@ -190,7 +190,7 @@
G_gisinit(argv[0]);
module->description = _("Overlays multiple X Pixmaps");
opt.in = G_define_option();
Modified: grass/trunk/general/g.copy/main.c
--- grass/trunk/general/g.copy/main.c 2009-06-24 16:38:17 UTC (rev 38060)
+++ grass/trunk/general/g.copy/main.c 2009-06-24 16:56:59 UTC (rev 38061)
@@ -37,7 +37,8 @@
read_list(0);
- module->keywords = _("general, map management");
+ G_add_keyword(_("map management"));
_("Copies available data files in the user's current mapset "
"search path and location to the appropriate element "
Modified: grass/trunk/general/g.dirseps/main.c
--- grass/trunk/general/g.dirseps/main.c 2009-06-24 16:38:17 UTC (rev 38060)
+++ grass/trunk/general/g.dirseps/main.c 2009-06-24 16:56:59 UTC (rev 38061)
@@ -30,7 +30,7 @@
G_no_gisinit();
- module->keywords = "general";
module->label =
_("Internal GRASS utility for converting directory separator characters.");
Modified: grass/trunk/general/g.filename/main.c
--- grass/trunk/general/g.filename/main.c 2009-06-24 16:38:17 UTC (rev 38060)
+++ grass/trunk/general/g.filename/main.c 2009-06-24 16:56:59 UTC (rev 38061)
@@ -36,7 +36,7 @@
G_gisinit(argv[0]);
module->description = _("Prints GRASS data base file names.");
/* Define the different options */
Modified: grass/trunk/general/g.findetc/main.c
--- grass/trunk/general/g.findetc/main.c 2009-06-24 16:38:17 UTC (rev 38060)
+++ grass/trunk/general/g.findetc/main.c 2009-06-24 16:56:59 UTC (rev 38061)
@@ -25,7 +25,7 @@
struct Option *opt1;
module->description = "Searches for GRASS support files.";
G_gisinit(argv[0]);
Modified: grass/trunk/general/g.findfile/main.c
--- grass/trunk/general/g.findfile/main.c 2009-06-24 16:38:17 UTC (rev 38060)
+++ grass/trunk/general/g.findfile/main.c 2009-06-24 16:56:59 UTC (rev 38061)
@@ -32,7 +32,7 @@
struct Flag *n_flag;
_("Searches for GRASS data base files "
"and sets variables for the shell.");
Modified: grass/trunk/general/g.gisenv/main.c
--- grass/trunk/general/g.gisenv/main.c 2009-06-24 16:38:17 UTC (rev 38060)
+++ grass/trunk/general/g.gisenv/main.c 2009-06-24 16:56:59 UTC (rev 38061)
@@ -35,7 +35,7 @@
G_no_gisinit();
_("Outputs and modifies the user's current GRASS variable settings.");
Modified: grass/trunk/general/g.gui/main.c
--- grass/trunk/general/g.gui/main.c 2009-06-24 16:38:17 UTC (rev 38060)
+++ grass/trunk/general/g.gui/main.c 2009-06-24 16:56:59 UTC (rev 38061)
@@ -33,7 +33,8 @@
G_gisinit(argv[0]);
- module->keywords = _("general, gui");
+ G_add_keyword(_("gui"));
_("Launches a GRASS graphical user interface (GUI) session.");
Modified: grass/trunk/general/g.list/main.c
--- grass/trunk/general/g.list/main.c 2009-06-24 16:38:17 UTC (rev 38060)
+++ grass/trunk/general/g.list/main.c 2009-06-24 16:56:59 UTC (rev 38061)
@@ -41,7 +41,8 @@
read_list(0);
_("Lists available GRASS data base files "
"of the user-specified data type to standard output.");
Modified: grass/trunk/general/g.mapset/main.c
--- grass/trunk/general/g.mapset/main.c 2009-06-24 16:38:17 UTC (rev 38060)
+++ grass/trunk/general/g.mapset/main.c 2009-06-24 16:56:59 UTC (rev 38061)
@@ -42,7 +42,8 @@
G_gisinit(argv[0]);
- module->keywords = _("general, settings");
+ G_add_keyword(_("settings"));
module->description = _("Change current mapset.");
mapset_opt = G_define_option();
Modified: grass/trunk/general/g.mapsets/main.c
--- grass/trunk/general/g.mapsets/main.c 2009-06-24 16:38:17 UTC (rev 38060)
+++ grass/trunk/general/g.mapsets/main.c 2009-06-24 16:56:59 UTC (rev 38061)
@@ -56,7 +56,8 @@
G_gisinit(argv[0]);
_("Modifies the user's current mapset "
"search path, affecting the user's access to data existing "
Modified: grass/trunk/general/g.message/main.c
--- grass/trunk/general/g.message/main.c 2009-06-24 16:38:17 UTC (rev 38060)
+++ grass/trunk/general/g.message/main.c 2009-06-24 16:56:59 UTC (rev 38061)
@@ -29,7 +29,7 @@
G_gisinit(argv[0]);
module->label =
_("Prints a message, warning, or fatal error the GRASS way.");
Modified: grass/trunk/general/g.mkfontcap/main.c
--- grass/trunk/general/g.mkfontcap/main.c 2009-06-24 16:38:17 UTC (rev 38060)
+++ grass/trunk/general/g.mkfontcap/main.c 2009-06-24 16:56:59 UTC (rev 38061)
@@ -24,6 +24,7 @@
#include <grass/gis.h>
#include <grass/fontcap.h>
+#include <grass/glocale.h>
#include "local_proto.h"
@@ -66,29 +67,29 @@
G_no_gisinit();
- "Generates the font configuration file by scanning various directories "
- "for fonts";
+ _("Generates the font configuration file by scanning various directories "
+ "for fonts");
overwrite = G_define_flag();
overwrite->key = 'o';
overwrite->description =
- "Overwrite font configuration file if already existing";
+ _("Overwrite font configuration file if already existing");
tostdout = G_define_flag();
tostdout->key = 's';
tostdout->description =
- "Write font configuration file to standard output instead of "
- "$GISBASE/etc";
+ _("Write font configuration file to standard output instead of "
+ "$GISBASE/etc");
extradirs = G_define_option();
extradirs->key = "extradirs";
extradirs->type = TYPE_STRING;
extradirs->required = NO;
extradirs->description =
- "Comma-separated list of extra directories to scan for "
- "Freetype-compatible fonts as well as the defaults (see documentation)";
+ _("Comma-separated list of extra directories to scan for "
+ "Freetype-compatible fonts as well as the defaults (see documentation)");
exit(EXIT_FAILURE);
@@ -104,9 +105,9 @@
if (!stat(fontcapfile, &status)) { /* File exists? */
if (!overwrite->answer)
- G_fatal_error
- ("Fontcap file %s already exists; use -%c flag if you "
- "wish to overwrite it", fontcapfile, overwrite->key);
+ G_fatal_error(_("Fontcap file %s already exists; use -%c flag if you "
+ "wish to overwrite it"),
+ fontcapfile, overwrite->key);
@@ -116,7 +117,8 @@
/* Prepare list of directories to search */
if (extradirs->answer) {
#ifndef HAVE_FT2BUILD_H
- G_warning("This GRASS installation was compiled without Freetype support, extradirs parameter ignored");
+ G_warning(_("This GRASS installation was compiled without "
+ "Freetype support, extradirs parameter ignored"));
#endif
char *str = G_store(extradirs->answer);
@@ -142,7 +144,7 @@
else {
outstream = fopen(fontcapfile, "w");
if (outstream == NULL)
- G_fatal_error("Cannot open %s for writing: %s", fontcapfile,
+ G_fatal_error(_("Cannot open %s for writing: %s"), fontcapfile,
strerror(errno));
Modified: grass/trunk/general/g.mlist/main.c
--- grass/trunk/general/g.mlist/main.c 2009-06-24 16:38:17 UTC (rev 38060)
+++ grass/trunk/general/g.mlist/main.c 2009-06-24 16:56:59 UTC (rev 38061)
@@ -62,7 +62,8 @@
G_gisinit(argv[0]);
Modified: grass/trunk/general/g.mremove/main.c
--- grass/trunk/general/g.mremove/main.c 2009-06-24 16:38:17 UTC (rev 38060)
+++ grass/trunk/general/g.mremove/main.c 2009-06-24 16:56:59 UTC (rev 38061)
@@ -53,7 +53,8 @@
G_gisinit(argv[0]);
_("Removes data base element files from "
"the user's current mapset.");
Modified: grass/trunk/general/g.parser/main.c
--- grass/trunk/general/g.parser/main.c 2009-06-24 16:38:17 UTC (rev 38060)
+++ grass/trunk/general/g.parser/main.c 2009-06-24 16:56:59 UTC (rev 38061)
@@ -102,7 +102,7 @@
if (strcasecmp(cmd, "keywords") == 0) {
- ctx->module->keywords = translate(strdup(arg));
+ G_set_keywords(translate(strdup(arg)));
return;
Modified: grass/trunk/general/g.pnmcomp/main.c
--- grass/trunk/general/g.pnmcomp/main.c 2009-06-24 16:38:17 UTC (rev 38060)
+++ grass/trunk/general/g.pnmcomp/main.c 2009-06-24 16:56:59 UTC (rev 38061)
@@ -278,7 +278,7 @@
G_gisinit(argv[0]);
module->description = "Overlays multiple PPM image files";
Modified: grass/trunk/general/g.proj/main.c
--- grass/trunk/general/g.proj/main.c 2009-06-24 16:38:17 UTC (rev 38060)
+++ grass/trunk/general/g.proj/main.c 2009-06-24 16:56:59 UTC (rev 38061)
@@ -57,7 +57,7 @@
* (to create a new location) when none exists */
#ifdef HAVE_OGR
_("Converts co-ordinate system descriptions (i.e. projection "
Modified: grass/trunk/general/g.region/main.c
--- grass/trunk/general/g.region/main.c 2009-06-24 16:38:17 UTC (rev 38060)
+++ grass/trunk/general/g.region/main.c 2009-06-24 16:56:59 UTC (rev 38061)
@@ -58,7 +58,7 @@
G_gisinit(argv[0]);
_("Manages the boundary definitions for the " "geographic region.");
Modified: grass/trunk/general/g.remove/main.c
--- grass/trunk/general/g.remove/main.c 2009-06-24 16:38:17 UTC (rev 38060)
+++ grass/trunk/general/g.remove/main.c 2009-06-24 16:56:59 UTC (rev 38061)
@@ -98,7 +98,8 @@
read_list(0);
Modified: grass/trunk/general/g.rename/main.c
--- grass/trunk/general/g.rename/main.c 2009-06-24 16:38:17 UTC (rev 38060)
+++ grass/trunk/general/g.rename/main.c 2009-06-24 16:56:59 UTC (rev 38061)
@@ -40,7 +40,8 @@
read_list(0);
_("Renames data base element files in the user's current mapset.");
Modified: grass/trunk/general/g.setproj/main.c
--- grass/trunk/general/g.setproj/main.c 2009-06-24 16:38:17 UTC (rev 38060)
+++ grass/trunk/general/g.setproj/main.c 2009-06-24 16:56:59 UTC (rev 38061)
@@ -75,7 +75,8 @@
G_gisinit(argv[0]);
- module->keywords = _("general, projection");
+ G_add_keyword(_("projection"));
_("Interactively reset the location's projection settings.");
Modified: grass/trunk/general/g.tempfile/main.c
--- grass/trunk/general/g.tempfile/main.c 2009-06-24 16:38:17 UTC (rev 38060)
+++ grass/trunk/general/g.tempfile/main.c 2009-06-24 16:56:59 UTC (rev 38061)
@@ -33,7 +33,7 @@
G_gisinit(argv[0]);
"Creates a temporary file and prints the file name.";
Modified: grass/trunk/general/g.transform/main.c
--- grass/trunk/general/g.transform/main.c 2009-06-24 16:38:17 UTC (rev 38060)
+++ grass/trunk/general/g.transform/main.c 2009-06-24 16:56:59 UTC (rev 38061)
@@ -246,7 +246,9 @@
/* Get Args */
- module->keywords = _("general, transformation, GCP");
+ G_add_keyword(_("transformation"));
+ G_add_keyword(_("GCP"));
_("Computes a coordinate transformation based on the control points.");
Modified: grass/trunk/general/g.version/main.c
--- grass/trunk/general/g.version/main.c 2009-06-24 16:38:17 UTC (rev 38060)
+++ grass/trunk/general/g.version/main.c 2009-06-24 16:56:59 UTC (rev 38061)
@@ -31,7 +31,7 @@
G_gisinit(argv[0]);
module->description = _("Displays version and copyright information.");
copyright = G_define_flag();
Modified: grass/trunk/imagery/i.albedo/main.c
--- grass/trunk/imagery/i.albedo/main.c 2009-06-24 16:38:17 UTC (rev 38060)
+++ grass/trunk/imagery/i.albedo/main.c 2009-06-24 16:56:59 UTC (rev 38061)
@@ -84,7 +84,9 @@
G_gisinit(argv[0]);
- module->keywords = _("imagery, albedo, surface reflectance");
+ G_add_keyword(_("imagery"));
+ G_add_keyword(_("albedo"));
+ G_add_keyword(_("surface reflectance"));
module->description = _("Broad Band Albedo from Surface Reflectance.");
Modified: grass/trunk/imagery/i.biomass/main.c
--- grass/trunk/imagery/i.biomass/main.c 2009-06-24 16:38:17 UTC (rev 38060)
+++ grass/trunk/imagery/i.biomass/main.c 2009-06-24 16:56:59 UTC (rev 38061)
@@ -45,7 +45,10 @@
G_gisinit(argv[0]);
- module->keywords = _("imagery, biomass, fpar, yield");
+ G_add_keyword(_("biomass"));
+ G_add_keyword(_("fpar"));
+ G_add_keyword(_("yield"));
_("Computes biomass growth, precursor of crop yield calculation");
Modified: grass/trunk/imagery/i.cca/main.c
--- grass/trunk/imagery/i.cca/main.c 2009-06-24 16:38:17 UTC (rev 38060)
+++ grass/trunk/imagery/i.cca/main.c 2009-06-24 16:56:59 UTC (rev 38061)
@@ -81,7 +81,7 @@
G_gisinit(argv[0]);
- module->keywords = _("imagery");
_("Canonical components analysis (cca) "
"program for image processing.");
Modified: grass/trunk/imagery/i.class/main.c
--- grass/trunk/imagery/i.class/main.c 2009-06-24 16:38:17 UTC (rev 38060)
+++ grass/trunk/imagery/i.class/main.c 2009-06-24 16:56:59 UTC (rev 38061)
@@ -88,7 +88,7 @@
G_gisinit(argv[0]);
module->label =
_("Generates spectral signatures for an image by allowing the user "
"to outline regions of interest.");
Modified: grass/trunk/imagery/i.cluster/main.c
--- grass/trunk/imagery/i.cluster/main.c 2009-06-24 16:38:17 UTC (rev 38060)
+++ grass/trunk/imagery/i.cluster/main.c 2009-06-24 16:56:59 UTC (rev 38061)
@@ -72,7 +72,9 @@
G_gisinit(argv[0]);
- module->keywords = _("imagery, classification, signatures");
+ G_add_keyword(_("classification"));
+ G_add_keyword(_("signatures"));
module->label =
_("Generates spectral signatures for land cover "
"types in an image using a clustering algorithm.");
Modified: grass/trunk/imagery/i.eb.eta/main.c
--- grass/trunk/imagery/i.eb.eta/main.c 2009-06-24 16:38:17 UTC (rev 38060)
+++ grass/trunk/imagery/i.eb.eta/main.c 2009-06-24 16:56:59 UTC (rev 38061)
@@ -40,7 +40,10 @@
G_gisinit(argv[0]);
- module->keywords = _("imagery, actual evapotranspiration, energy balance, SEBAL");
+ G_add_keyword(_("actual evapotranspiration"));
+ G_add_keyword(_("energy balance"));
+ G_add_keyword(_("SEBAL"));
_("actual evapotranspiration for diurnal period (Bastiaanssen, 1995)");
Modified: grass/trunk/imagery/i.eb.evapfr/main.c
--- grass/trunk/imagery/i.eb.evapfr/main.c 2009-06-24 16:38:17 UTC (rev 38060)
+++ grass/trunk/imagery/i.eb.evapfr/main.c 2009-06-24 16:56:59 UTC (rev 38061)
@@ -46,7 +46,7 @@
G_gisinit(argv[0]);
+ G_add_keyword(_(""));
_("imagery, evaporative fraction, soil moisture, energy balance, SEBAL");
_("Computes evaporative fraction (Bastiaanssen, 1995) and "
Modified: grass/trunk/imagery/i.eb.h_SEBAL01/main.c
--- grass/trunk/imagery/i.eb.h_SEBAL01/main.c 2009-06-24 16:38:17 UTC (rev 38060)
+++ grass/trunk/imagery/i.eb.h_SEBAL01/main.c 2009-06-24 16:56:59 UTC (rev 38061)
@@ -82,7 +82,11 @@
module->description = _("Computes sensible Heat Flux iteration SEBAL 01");
- module->keywords = _("imagery, evaporative fraction, soil moisture, energy balance, SEBAL");
+ G_add_keyword(_("evaporative fraction"));
+ G_add_keyword(_("soil moisture"));
/* Define different options */
input_Rn = G_define_standard_option(G_OPT_R_INPUT);
Modified: grass/trunk/imagery/i.eb.soilheatflux/main.c
--- grass/trunk/imagery/i.eb.soilheatflux/main.c 2009-06-24 16:38:17 UTC (rev 38060)
+++ grass/trunk/imagery/i.eb.soilheatflux/main.c 2009-06-24 16:56:59 UTC (rev 38061)
@@ -46,7 +46,10 @@
G_gisinit(argv[0]);
- module->keywords = _("imagery, soil heat flux, energy balance, SEBAL");
+ G_add_keyword(_("soil heat flux"));
module->description = _("Soil heat flux approximation (Bastiaanssen, 1995)");
Modified: grass/trunk/imagery/i.emissivity/main.c
--- grass/trunk/imagery/i.emissivity/main.c 2009-06-24 16:38:17 UTC (rev 38060)
+++ grass/trunk/imagery/i.emissivity/main.c 2009-06-24 16:56:59 UTC (rev 38061)
@@ -41,7 +41,9 @@
G_gisinit(argv[0]);
- module->keywords = _("emissivity, land flux, energy balance");
+ G_add_keyword(_("emissivity"));
+ G_add_keyword(_("land flux"));
_("Emissivity from NDVI, generic method for spares land.");
Modified: grass/trunk/imagery/i.evapo.time_integration/main.c
--- grass/trunk/imagery/i.evapo.time_integration/main.c 2009-06-24 16:38:17 UTC (rev 38060)
+++ grass/trunk/imagery/i.evapo.time_integration/main.c 2009-06-24 16:56:59 UTC (rev 38061)
@@ -76,7 +76,10 @@
module->description =_("Computes temporal integration of satellite "
"ET actual (ETa) following the daily ET reference "
"(ETo) from meteorological station(s)");
- module->keywords = _("imagery, evapotranspiration, temporal, integration");
+ G_add_keyword(_("evapotranspiration"));
+ G_add_keyword(_("temporal"));
+ G_add_keyword(_("integration"));
input = G_define_standard_option(G_OPT_R_INPUTS);
Modified: grass/trunk/imagery/i.fft/main.c
--- grass/trunk/imagery/i.fft/main.c 2009-06-24 16:38:17 UTC (rev 38060)
+++ grass/trunk/imagery/i.fft/main.c 2009-06-24 16:56:59 UTC (rev 38061)
@@ -75,7 +75,8 @@
G_gisinit(argv[0]);
- module->keywords = _("imagery, FFT");
+ G_add_keyword(_("FFT"));
_("Fast Fourier Transform (FFT) for image processing.");
Modified: grass/trunk/imagery/i.gensig/main.c
--- grass/trunk/imagery/i.gensig/main.c 2009-06-24 16:38:17 UTC (rev 38060)
+++ grass/trunk/imagery/i.gensig/main.c 2009-06-24 16:56:59 UTC (rev 38061)
@@ -36,7 +36,10 @@
G_gisinit(argv[0]);
- module->keywords = _("imagery, classification, supervised, MLC");
+ G_add_keyword(_("supervised"));
+ G_add_keyword(_("MLC"));
_("Generates statistics for i.maxlik from raster map.");
Modified: grass/trunk/imagery/i.gensigset/main.c
--- grass/trunk/imagery/i.gensigset/main.c 2009-06-24 16:38:17 UTC (rev 38060)
+++ grass/trunk/imagery/i.gensigset/main.c 2009-06-24 16:56:59 UTC (rev 38061)
@@ -37,7 +37,10 @@
G_gisinit(argv[0]);
- module->keywords = _("imagery, classification, supervised, SMAP");
+ G_add_keyword(_("SMAP"));
_("Generates statistics for i.smap from raster map.");
Modified: grass/trunk/imagery/i.group/main.c
--- grass/trunk/imagery/i.group/main.c 2009-06-24 16:38:17 UTC (rev 38060)
+++ grass/trunk/imagery/i.group/main.c 2009-06-24 16:56:59 UTC (rev 38061)
@@ -50,7 +50,7 @@
G_gisinit(argv[0]);
_("Creates, edits, and lists groups and subgroups of imagery files.");
Modified: grass/trunk/imagery/i.his.rgb/main.c
--- grass/trunk/imagery/i.his.rgb/main.c 2009-06-24 16:38:17 UTC (rev 38060)
+++ grass/trunk/imagery/i.his.rgb/main.c 2009-06-24 16:56:59 UTC (rev 38061)
@@ -43,7 +43,10 @@
- module->keywords = _("imagery, color transformation, RGB, HIS");
+ G_add_keyword(_("color transformation"));
+ G_add_keyword(_("RGB"));
+ G_add_keyword(_("HIS"));
_("Transforms raster maps from HIS (Hue-Intensity-Saturation) color space to "
"RGB (Red-Green-Blue) color space.");
Modified: grass/trunk/imagery/i.ifft/main.c
--- grass/trunk/imagery/i.ifft/main.c 2009-06-24 16:38:17 UTC (rev 38060)
+++ grass/trunk/imagery/i.ifft/main.c 2009-06-24 16:56:59 UTC (rev 38061)
@@ -74,7 +74,8 @@
_("Inverse Fast Fourier Transform (IFFT) for image processing.");
Modified: grass/trunk/imagery/i.latlong/main.c
--- grass/trunk/imagery/i.latlong/main.c 2009-06-24 16:38:17 UTC (rev 38060)
+++ grass/trunk/imagery/i.latlong/main.c 2009-06-24 16:56:59 UTC (rev 38061)
@@ -53,7 +53,10 @@
G_gisinit(argv[0]);
- module->keywords = _("imagery, latitude, longitude, projection");
+ G_add_keyword(_("latitude"));
+ G_add_keyword(_("longitude"));
module->description = _("creates a latitude/longitude map");
Modified: grass/trunk/imagery/i.maxlik/main.c
--- grass/trunk/imagery/i.maxlik/main.c 2009-06-24 16:38:17 UTC (rev 38060)
+++ grass/trunk/imagery/i.maxlik/main.c 2009-06-24 16:56:59 UTC (rev 38061)
@@ -57,7 +57,9 @@
G_gisinit(argv[0]);
- module->keywords = _("imagery, classification, MLC");
module->label =
_("Classifies the cell spectral reflectances in imagery data.");
Modified: grass/trunk/imagery/i.modis.qc/main.c
--- grass/trunk/imagery/i.modis.qc/main.c 2009-06-24 16:38:17 UTC (rev 38060)
+++ grass/trunk/imagery/i.modis.qc/main.c 2009-06-24 16:56:59 UTC (rev 38061)
@@ -81,7 +81,10 @@
G_gisinit(argv[0]);
- module->keywords = _("QC, Quality Control, surface reflectance, Modis");
+ G_add_keyword(_("QC"));
+ G_add_keyword(_("Quality Control"));
+ G_add_keyword(_("Modis"));
_("Extract quality control parameters from Modis QC layers");
Modified: grass/trunk/imagery/i.pca/main.c
--- grass/trunk/imagery/i.pca/main.c 2009-06-24 16:38:17 UTC (rev 38060)
+++ grass/trunk/imagery/i.pca/main.c 2009-06-24 16:56:59 UTC (rev 38061)
@@ -61,7 +61,9 @@
G_gisinit(argv[0]);
- module->keywords = _("imagery, image transformation, PCA");
+ G_add_keyword(_("image transformation"));
+ G_add_keyword(_("PCA"));
module->description = _("Principal components analysis (pca) program "
"for image processing.");
Modified: grass/trunk/imagery/i.points/main.c
--- grass/trunk/imagery/i.points/main.c 2009-06-24 16:38:17 UTC (rev 38060)
+++ grass/trunk/imagery/i.points/main.c 2009-06-24 16:56:59 UTC (rev 38061)
@@ -93,7 +93,7 @@
G_gisinit(argv[0]);
_("Mark ground control points on image to be rectified.");
Modified: grass/trunk/imagery/i.rectify/main.c
--- grass/trunk/imagery/i.rectify/main.c 2009-06-24 16:38:17 UTC (rev 38060)
+++ grass/trunk/imagery/i.rectify/main.c 2009-06-24 16:56:59 UTC (rev 38061)
@@ -84,7 +84,8 @@
G_gisinit(argv[0]);
- module->keywords = _("imagery, rectify");
+ G_add_keyword(_("rectify"));
_("Rectifies an image by computing a coordinate "
"transformation for each pixel in the image based on the "
Modified: grass/trunk/imagery/i.rgb.his/main.c
--- grass/trunk/imagery/i.rgb.his/main.c 2009-06-24 16:38:17 UTC (rev 38060)
+++ grass/trunk/imagery/i.rgb.his/main.c 2009-06-24 16:56:59 UTC (rev 38061)
@@ -43,7 +43,10 @@
_("Transforms raster maps from RGB (Red-Green-Blue) color space to "
"HIS (Hue-Intensity-Saturation) color space.");
Modified: grass/trunk/imagery/i.smap/main.c
--- grass/trunk/imagery/i.smap/main.c 2009-06-24 16:38:17 UTC (rev 38060)
+++ grass/trunk/imagery/i.smap/main.c 2009-06-24 16:56:59 UTC (rev 38061)
@@ -35,7 +35,10 @@
G_gisinit(argv[0]);
_("Performs contextual image classification "
"using sequential maximum a posteriori (SMAP) estimation.");
Modified: grass/trunk/imagery/i.sunhours/main.c
--- grass/trunk/imagery/i.sunhours/main.c 2009-06-24 16:38:17 UTC (rev 38060)
+++ grass/trunk/imagery/i.sunhours/main.c 2009-06-24 16:56:59 UTC (rev 38061)
@@ -44,7 +44,9 @@
G_gisinit(argv[0]);
- module->keywords = _("sunshine, hours, daytime");
+ G_add_keyword(_("sunshine"));
+ G_add_keyword(_("hours"));
+ G_add_keyword(_("daytime"));
module->description = _("creates a sunshine hours map");
Modified: grass/trunk/imagery/i.target/main.c
--- grass/trunk/imagery/i.target/main.c 2009-06-24 16:38:17 UTC (rev 38060)
+++ grass/trunk/imagery/i.target/main.c 2009-06-24 16:56:59 UTC (rev 38061)
@@ -42,7 +42,7 @@
G_gisinit(argv[0]);
_("Targets an imagery group to a GRASS location and mapset.");
Modified: grass/trunk/imagery/i.vi/main.c
--- grass/trunk/imagery/i.vi/main.c 2009-06-24 16:38:17 UTC (rev 38060)
+++ grass/trunk/imagery/i.vi/main.c 2009-06-24 16:56:59 UTC (rev 38061)
@@ -73,7 +73,9 @@
G_gisinit(argv[0]);
- module->keywords = _("imagery, vegetation index, biophysical parameters");
+ G_add_keyword(_("vegetation index"));
+ G_add_keyword(_("biophysical parameters"));
module->label =
_("Calculates different types of vegetation indices.");
module->description = _("Uses red and nir bands mostly, "
Modified: grass/trunk/imagery/i.vpoints/main.c
--- grass/trunk/imagery/i.vpoints/main.c 2009-06-24 16:38:17 UTC (rev 38060)
+++ grass/trunk/imagery/i.vpoints/main.c 2009-06-24 16:56:59 UTC (rev 38061)
@@ -91,7 +91,7 @@
G_gisinit(argv[0]);
_("Set registration points for an imagery group from a vector map "
"or keyboard entry.");
Modified: grass/trunk/imagery/i.zc/main.c
--- grass/trunk/imagery/i.zc/main.c 2009-06-24 16:38:17 UTC (rev 38060)
+++ grass/trunk/imagery/i.zc/main.c 2009-06-24 16:56:59 UTC (rev 38061)
@@ -49,7 +49,7 @@
G_gisinit(argv[0]);
_("Zero-crossing \"edge detection\" raster "
"function for image processing.");
Modified: grass/trunk/include/gis.h
--- grass/trunk/include/gis.h 2009-06-24 16:38:17 UTC (rev 38060)
+++ grass/trunk/include/gis.h 2009-06-24 16:56:59 UTC (rev 38061)
@@ -625,7 +625,7 @@
const char *label; /* Optional short description for GUI */
const char *description; /* String describing module */
- const char *keywords; /* Keywords describing module */
+ const char **keywords; /* Keywords describing module */
/* further items are possible: author(s), version */
int overwrite; /* overwrite old files */
int verbose; /* print all informations about progress and so on */
Modified: grass/trunk/include/gisdefs.h
--- grass/trunk/include/gisdefs.h 2009-06-24 16:38:17 UTC (rev 38060)
+++ grass/trunk/include/gisdefs.h 2009-06-24 16:56:59 UTC (rev 38061)
@@ -442,6 +442,8 @@
int G_parser(int, char **);
void G_usage(void);
char *G_recreate_command(void);
+void G_add_keyword(const char *);
+void G_set_keywords(const char *);
/* paths.c */
int G_mkdir(const char *);
Modified: grass/trunk/lib/gis/parser.c
--- grass/trunk/lib/gis/parser.c 2009-06-24 16:38:17 UTC (rev 38060)
+++ grass/trunk/lib/gis/parser.c 2009-06-24 16:56:59 UTC (rev 38061)
@@ -108,6 +108,8 @@
int no_interactive;
int n_opts;
int n_flags;
+ int n_keys;
+ int n_keys_alloc;
int overwrite;
int quiet;
int has_required;
@@ -145,6 +147,8 @@
static int check_multiple_opts(void);
static int check_overwrite(void);
static void split_gisprompt(const char *, char *, char *, char *);
+static void define_keywords(void);
+static void print_keywords(FILE *, void (*)(FILE *, const char *));
static void G_gui(void);
static void G_usage_xml(void);
@@ -699,13 +703,14 @@
struct GModule *module;
/* Allocate memory */
module = &st->module_info;
/* Zero structure */
G_zero((char *)module, sizeof(struct GModule));
+ /* Allocate keywords array */
+ define_keywords();
return (module);
@@ -1065,8 +1070,9 @@
fprintf(stderr, " %s\n", st->module_info.description);
if (st->module_info.keywords) {
- fprintf(stderr, _("\nKeywords:\n"));
- fprintf(stderr, " %s\n", st->module_info.keywords);
+ fprintf(stderr, _("\nKeywords:\n "));
+ print_keywords(stderr, NULL);
+ fprintf(stderr, "\n");
fprintf(stderr, _("\nUsage:\n "));
@@ -1309,7 +1315,7 @@
fprintf(stdout, "\t<keywords>\n\t\t");
- print_escaped_for_xml(stdout, st->module_info.keywords);
+ print_keywords(stdout, print_escaped_for_xml);
fprintf(stdout, "\n\t</keywords>\n");
@@ -1541,7 +1547,7 @@
fprintf(stdout, "<h2>%s</h2>\n", _("KEYWORDS"));
- fprintf(stdout, "%s", st->module_info.keywords);
+ print_keywords(stdout, NULL);
fprintf(stdout, "\n");
fprintf(stdout, "<h2>%s</h2>\n", _("SYNOPSIS"));
@@ -1767,8 +1773,11 @@
fprintf(fp, "#%% label: %s\n", st->module_info.label);
if (st->module_info.description)
fprintf(fp, "#%% description: %s\n", st->module_info.description);
- if (st->module_info.keywords)
- fprintf(fp, "#%% keywords: %s\n", st->module_info.keywords);
+ if (st->module_info.keywords) {
+ fprintf(fp, "#%% keywords: ");
+ print_keywords(fp, NULL);
+ fprintf(fp, "\n");
fprintf(fp, "#%%End\n");
if (st->n_flags) {
@@ -2579,3 +2588,55 @@
return (buff);
+void define_keywords(void)
+ st->n_keys = 0;
+ st->n_keys_alloc = 0;
+ \brief Add keyword to the list
+ \param module pointer to GModule structure
+ \param keyword keyword string
+void G_add_keyword(const char *keyword)
+ if (st->n_keys >= st->n_keys_alloc) {
+ st->n_keys_alloc += 10;
+ st->module_info.keywords = (const char **) G_realloc(st->module_info.keywords,
+ st->n_keys_alloc * sizeof(char *));
+ st->module_info.keywords[st->n_keys++] = G_store(keyword);
+void print_keywords(FILE *fd, void (*format)(FILE *, const char *))
+ int i;
+ for(i = 0; i < st->n_keys; i++) {
+ if (!format) {
+ fprintf(fd, "%s", st->module_info.keywords[i]);
+ else {
+ format(fd, st->module_info.keywords[i]);
+ if (i < st->n_keys - 1)
+ fprintf(fd, ", ");
+ fflush(fd);
+ \brief Set keywords from the string
+ \param keywords keywords separated by commas
+void G_set_keywords(const char *keywords)
+ st->module_info.keywords = (const char**)G_tokenize(keywords, ",");
+ st->n_keys = st->n_keys_alloc = G_number_of_tokens((char **)st->module_info.keywords);
Modified: grass/trunk/misc/m.cogo/main.c
--- grass/trunk/misc/m.cogo/main.c 2009-06-24 16:38:17 UTC (rev 38060)
+++ grass/trunk/misc/m.cogo/main.c 2009-06-24 16:56:59 UTC (rev 38061)
@@ -222,7 +222,7 @@
G_gisinit(argv[0]);
- module->keywords = _("miscellaneous");
+ G_add_keyword(_("miscellaneous"));
module->label = _("A simple utility for converting bearing and "
"distance measurements to coordinates and vice versa.");
module->description = _("It assumes a cartesian coordinate system");
Modified: grass/trunk/ps/ps.map/main.c
--- grass/trunk/ps/ps.map/main.c 2009-06-24 16:38:17 UTC (rev 38060)
+++ grass/trunk/ps/ps.map/main.c 2009-06-24 16:56:59 UTC (rev 38061)
@@ -113,7 +113,9 @@
- module->keywords = _("postscript, map, printing");
+ G_add_keyword(_("postscript"));
+ G_add_keyword(_("map"));
+ G_add_keyword(_("printing"));
module->description = _("Hardcopy PostScript map output utility.");
rflag = G_define_flag();
Modified: grass/trunk/raster/r.basins.fill/main.c
--- grass/trunk/raster/r.basins.fill/main.c 2009-06-24 16:38:17 UTC (rev 38060)
+++ grass/trunk/raster/r.basins.fill/main.c 2009-06-24 16:56:59 UTC (rev 38061)
@@ -51,7 +51,7 @@
G_gisinit(argv[0]);
- module->keywords = _("raster");
_("Generates a raster map layer showing " "watershed subbasins.");
Modified: grass/trunk/raster/r.bitpattern/main.c
--- grass/trunk/raster/r.bitpattern/main.c 2009-06-24 16:38:17 UTC (rev 38060)
+++ grass/trunk/raster/r.bitpattern/main.c 2009-06-24 16:56:59 UTC (rev 38061)
@@ -60,7 +60,7 @@
G_gisinit(argv[0]);
module->description = _("Compares bit patterns with a raster map.");
Modified: grass/trunk/raster/r.buffer/main.c
--- grass/trunk/raster/r.buffer/main.c 2009-06-24 16:38:17 UTC (rev 38060)
+++ grass/trunk/raster/r.buffer/main.c 2009-06-24 16:56:59 UTC (rev 38061)
@@ -63,7 +63,8 @@
pgm_name = argv[0];
- module->keywords = _("raster, buffer");
+ G_add_keyword(_("buffer"));
_("Creates a raster map layer showing buffer zones "
"surrounding cells that contain non-NULL category values.");
Modified: grass/trunk/raster/r.carve/main.c
--- grass/trunk/raster/r.carve/main.c 2009-06-24 16:38:17 UTC (rev 38060)
+++ grass/trunk/raster/r.carve/main.c 2009-06-24 16:56:59 UTC (rev 38061)
@@ -71,7 +71,7 @@
G_gisinit(argv[0]);
module->description = _("Takes vector stream data, transforms it "
"to raster and subtracts depth from the output DEM.");
Modified: grass/trunk/raster/r.category/main.c
--- grass/trunk/raster/r.category/main.c 2009-06-24 16:38:17 UTC (rev 38060)
+++ grass/trunk/raster/r.category/main.c 2009-06-24 16:56:59 UTC (rev 38061)
@@ -49,7 +49,7 @@
G_gisinit(argv[0]);
_("Manages category values and labels associated "
"with user-specified raster map layers.");
Modified: grass/trunk/raster/r.circle/main.c
--- grass/trunk/raster/r.circle/main.c 2009-06-24 16:38:17 UTC (rev 38060)
+++ grass/trunk/raster/r.circle/main.c 2009-06-24 16:56:59 UTC (rev 38061)
@@ -49,7 +49,7 @@
G_gisinit(argv[0]);
_("Creates a raster map containing concentric "
"rings around a given point.");
Modified: grass/trunk/raster/r.clump/main.c
--- grass/trunk/raster/r.clump/main.c 2009-06-24 16:38:17 UTC (rev 38060)
+++ grass/trunk/raster/r.clump/main.c 2009-06-24 16:56:59 UTC (rev 38061)
@@ -43,7 +43,9 @@
- module->keywords = _("raster, statistics, reclass");
+ G_add_keyword(_("statistics"));
+ G_add_keyword(_("reclass"));
_("Recategorizes data in a raster map by grouping cells "
"that form physically discrete areas into unique categories.");
Modified: grass/trunk/raster/r.coin/main.c
--- grass/trunk/raster/r.coin/main.c 2009-06-24 16:38:17 UTC (rev 38060)
+++ grass/trunk/raster/r.coin/main.c 2009-06-24 16:56:59 UTC (rev 38061)
@@ -63,7 +63,7 @@
G_gisinit(argv[0]);
_("Tabulates the mutual occurrence (coincidence) "
"of categories for two raster map layers.");
Modified: grass/trunk/raster/r.colors/main.c
--- grass/trunk/raster/r.colors/main.c 2009-06-24 16:38:17 UTC (rev 38060)
+++ grass/trunk/raster/r.colors/main.c 2009-06-24 16:56:59 UTC (rev 38061)
@@ -162,7 +162,8 @@
G_gisinit(argv[0]);
- module->keywords = _("raster, color table");
+ G_add_keyword(_("color table"));
_("Creates/modifies the color table associated with a raster map layer.");
Modified: grass/trunk/raster/r.colors.out/main.c
--- grass/trunk/raster/r.colors.out/main.c 2009-06-24 16:38:17 UTC (rev 38060)
+++ grass/trunk/raster/r.colors.out/main.c 2009-06-24 16:56:59 UTC (rev 38061)
@@ -60,7 +60,8 @@
G_gisinit(argv[0]);
_("Exports the color table associated with a raster map layer.");
Modified: grass/trunk/raster/r.composite/main.c
--- grass/trunk/raster/r.composite/main.c 2009-06-24 16:38:17 UTC (rev 38060)
+++ grass/trunk/raster/r.composite/main.c 2009-06-24 16:56:59 UTC (rev 38061)
@@ -69,7 +69,8 @@
G_gisinit(argv[0]);
- module->keywords = _("raster, composite");
+ G_add_keyword(_("composite"));
_("Combines red, green and blue raster maps into "
"a single composite raster map.");
Modified: grass/trunk/raster/r.compress/main.c
--- grass/trunk/raster/r.compress/main.c 2009-06-24 16:38:17 UTC (rev 38060)
+++ grass/trunk/raster/r.compress/main.c 2009-06-24 16:56:59 UTC (rev 38061)
@@ -59,7 +59,7 @@
G_gisinit(argv[0]);
module->description = _("Compresses and decompresses raster maps.");
map = G_define_option();
Modified: grass/trunk/raster/r.contour/main.c
--- grass/trunk/raster/r.contour/main.c 2009-06-24 16:38:17 UTC (rev 38060)
+++ grass/trunk/raster/r.contour/main.c 2009-06-24 16:56:59 UTC (rev 38061)
@@ -83,7 +83,10 @@
G_gisinit(argv[0]);
- module->keywords = _("raster, DEM, contours, vector");
+ G_add_keyword(_("DEM"));
+ G_add_keyword(_("contours"));
module->description = _("Produces a vector map of specified "
"contours from a raster map.");
Modified: grass/trunk/raster/r.cost/main.c
--- grass/trunk/raster/r.cost/main.c 2009-06-24 16:38:17 UTC (rev 38060)
+++ grass/trunk/raster/r.cost/main.c 2009-06-24 16:56:59 UTC (rev 38061)
@@ -137,7 +137,9 @@
G_gisinit(argv[0]);
- module->keywords = _("raster, cost surface, cumulative costs");
+ G_add_keyword(_("cost surface"));
+ G_add_keyword(_("cumulative costs"));
_("Creates a raster map showing the "
"cumulative cost of moving between different "
Modified: grass/trunk/raster/r.covar/main.c
--- grass/trunk/raster/r.covar/main.c 2009-06-24 16:38:17 UTC (rev 38060)
+++ grass/trunk/raster/r.covar/main.c 2009-06-24 16:56:59 UTC (rev 38061)
@@ -48,7 +48,7 @@
G_gisinit(argv[0]);
_("Outputs a covariance/correlation matrix "
"for user-specified raster map layer(s).");
Modified: grass/trunk/raster/r.cross/main.c
--- grass/trunk/raster/r.cross/main.c 2009-06-24 16:38:17 UTC (rev 38060)
+++ grass/trunk/raster/r.cross/main.c 2009-06-24 16:56:59 UTC (rev 38061)
@@ -70,7 +70,7 @@
_("Creates a cross product of the category values from "
"multiple raster map layers.");
Modified: grass/trunk/raster/r.describe/main.c
--- grass/trunk/raster/r.describe/main.c 2009-06-24 16:38:17 UTC (rev 38060)
+++ grass/trunk/raster/r.describe/main.c 2009-06-24 16:56:59 UTC (rev 38061)
@@ -51,7 +51,7 @@
G_gisinit(argv[0]);
_("Prints terse list of category values found in a raster map layer.");
Modified: grass/trunk/raster/r.digit/main.c
--- grass/trunk/raster/r.digit/main.c 2009-06-24 16:38:17 UTC (rev 38060)
+++ grass/trunk/raster/r.digit/main.c 2009-06-24 16:56:59 UTC (rev 38061)
@@ -41,7 +41,7 @@
G_gisinit(argv[0]);
_("Interactive tool used to draw and save vector features on a graphics"
" monitor using a pointing device (mouse) and save to a raster map.");
Modified: grass/trunk/raster/r.distance/main.c
--- grass/trunk/raster/r.distance/main.c 2009-06-24 16:38:17 UTC (rev 38060)
+++ grass/trunk/raster/r.distance/main.c 2009-06-24 16:56:59 UTC (rev 38061)
@@ -35,7 +35,7 @@
_("Locates the closest points between objects in two raster maps.");
Modified: grass/trunk/raster/r.drain/main.c
--- grass/trunk/raster/r.drain/main.c 2009-06-24 16:38:17 UTC (rev 38060)
+++ grass/trunk/raster/r.drain/main.c 2009-06-24 16:56:59 UTC (rev 38061)
@@ -103,7 +103,7 @@
G_gisinit(argv[0]);
_("Traces a flow through an elevation model on a raster map.");
Modified: grass/trunk/raster/r.external/main.c
--- grass/trunk/raster/r.external/main.c 2009-06-24 16:38:17 UTC (rev 38060)
+++ grass/trunk/raster/r.external/main.c 2009-06-24 16:56:59 UTC (rev 38061)
@@ -520,7 +520,8 @@
G_gisinit(argv[0]);
- module->keywords = _("raster, import");
+ G_add_keyword(_("import"));
_("Link GDAL supported raster file to a binary raster map layer.");
Modified: grass/trunk/raster/r.external.out/main.c
--- grass/trunk/raster/r.external.out/main.c 2009-06-24 16:38:17 UTC (rev 38060)
+++ grass/trunk/raster/r.external.out/main.c 2009-06-24 16:56:59 UTC (rev 38061)
@@ -179,7 +179,8 @@
GDALAllRegister();
Modified: grass/trunk/raster/r.fill.dir/main.c
--- grass/trunk/raster/r.fill.dir/main.c 2009-06-24 16:38:17 UTC (rev 38060)
+++ grass/trunk/raster/r.fill.dir/main.c 2009-06-24 16:56:59 UTC (rev 38061)
@@ -83,7 +83,7 @@
G_gisinit(argv[0]);
_("Filters and generates a depressionless elevation map and a flow "
"direction map from a given elevation layer.");
Modified: grass/trunk/raster/r.flow/main.c
--- grass/trunk/raster/r.flow/main.c 2009-06-24 16:38:17 UTC (rev 38060)
+++ grass/trunk/raster/r.flow/main.c 2009-06-24 16:56:59 UTC (rev 38061)
@@ -418,7 +418,7 @@
G_gisinit(argv[0]);
- module->keywords = "raster";
_("Construction of slope curves (flowlines), flowpath lengths, "
"and flowline densities (upslope areas) from a raster "
Modified: grass/trunk/raster/r.grow/main.c
--- grass/trunk/raster/r.grow/main.c 2009-06-24 16:38:17 UTC (rev 38060)
+++ grass/trunk/raster/r.grow/main.c 2009-06-24 16:56:59 UTC (rev 38061)
@@ -119,7 +119,7 @@
G_gisinit(argv[0]);
_("Generates a raster map layer "
"with contiguous areas grown by one cell.");
Modified: grass/trunk/raster/r.grow.distance/main.c
--- grass/trunk/raster/r.grow.distance/main.c 2009-06-24 16:38:17 UTC (rev 38060)
+++ grass/trunk/raster/r.grow.distance/main.c 2009-06-24 16:56:59 UTC (rev 38061)
@@ -146,7 +146,7 @@
G_gisinit(argv[0]);
_("Generates a raster map layer of distance to features in input layer.");
Modified: grass/trunk/raster/r.gwflow/main.c
--- grass/trunk/raster/r.gwflow/main.c 2009-06-24 16:38:17 UTC (rev 38060)
+++ grass/trunk/raster/r.gwflow/main.c 2009-06-24 16:56:59 UTC (rev 38061)
@@ -221,7 +221,7 @@
G_gisinit(argv[0]);
_("Numerical calculation program for transient, confined and unconfined groundwater flow in two dimensions.");
Modified: grass/trunk/raster/r.his/main.c
--- grass/trunk/raster/r.his/main.c 2009-06-24 16:38:17 UTC (rev 38060)
+++ grass/trunk/raster/r.his/main.c 2009-06-24 16:56:59 UTC (rev 38061)
@@ -59,7 +59,7 @@
G_gisinit(argv[0]);
_("Generates red, green and blue raster map layers "
"combining hue, intensity and saturation (HIS) "
Modified: grass/trunk/raster/r.horizon/main.c
--- grass/trunk/raster/r.horizon/main.c 2009-06-24 16:38:17 UTC (rev 38060)
+++ grass/trunk/raster/r.horizon/main.c 2009-06-24 16:56:59 UTC (rev 38061)
@@ -176,7 +176,7 @@
G_gisinit(argv[0]);
module->label =
_("Horizon angle computation from a digital elevation model.");
Modified: grass/trunk/raster/r.in.arc/main.c
--- grass/trunk/raster/r.in.arc/main.c 2009-06-24 16:38:17 UTC (rev 38060)
+++ grass/trunk/raster/r.in.arc/main.c 2009-06-24 16:56:59 UTC (rev 38061)
@@ -57,7 +57,7 @@
G_gisinit(argv[0]);
_("Converts an ESRI ARC/INFO ascii raster file (GRID) "
"into a (binary) raster map layer.");
Modified: grass/trunk/raster/r.in.ascii/main.c
--- grass/trunk/raster/r.in.ascii/main.c 2009-06-24 16:38:17 UTC (rev 38060)
+++ grass/trunk/raster/r.in.ascii/main.c 2009-06-24 16:56:59 UTC (rev 38061)
@@ -66,7 +66,9 @@
G_gisinit(argv[0]);
- module->keywords = _("raster, import, conversion");
+ G_add_keyword(_("conversion"));
_("Converts ASCII raster file to binary raster map layer.");
Modified: grass/trunk/raster/r.in.bin/main.c
--- grass/trunk/raster/r.in.bin/main.c 2009-06-24 16:38:17 UTC (rev 38060)
+++ grass/trunk/raster/r.in.bin/main.c 2009-06-24 16:56:59 UTC (rev 38061)
@@ -120,7 +120,8 @@
_("Import a binary raster file into a GRASS raster map layer.");
Modified: grass/trunk/raster/r.in.gdal/main.c
--- grass/trunk/raster/r.in.gdal/main.c 2009-06-24 16:38:17 UTC (rev 38060)
+++ grass/trunk/raster/r.in.gdal/main.c 2009-06-24 16:56:59 UTC (rev 38061)
@@ -77,7 +77,8 @@
G_gisinit(argv[0]);
_("Import GDAL supported raster file into a binary raster map layer.");
Modified: grass/trunk/raster/r.in.gridatb/main.c
--- grass/trunk/raster/r.in.gridatb/main.c 2009-06-24 16:38:17 UTC (rev 38060)
+++ grass/trunk/raster/r.in.gridatb/main.c 2009-06-24 16:56:59 UTC (rev 38061)
@@ -42,7 +42,7 @@
_("Imports GRIDATB.FOR map file (TOPMODEL) into GRASS raster map");
Modified: grass/trunk/raster/r.in.mat/main.c
--- grass/trunk/raster/r.in.mat/main.c 2009-06-24 16:38:17 UTC (rev 38060)
+++ grass/trunk/raster/r.in.mat/main.c 2009-06-24 16:56:59 UTC (rev 38061)
@@ -89,7 +89,7 @@
G_gisinit(argv[0]);
_("Imports a binary MAT-File(v4) to a GRASS raster.");
Modified: grass/trunk/raster/r.in.poly/main.c
--- grass/trunk/raster/r.in.poly/main.c 2009-06-24 16:38:17 UTC (rev 38060)
+++ grass/trunk/raster/r.in.poly/main.c 2009-06-24 16:56:59 UTC (rev 38061)
@@ -26,7 +26,8 @@
G_gisinit(argv[0]);
_("Creates raster maps from ASCII polygon/line/point data files.");
Modified: grass/trunk/raster/r.in.xyz/main.c
--- grass/trunk/raster/r.in.xyz/main.c 2009-06-24 16:38:17 UTC (rev 38060)
+++ grass/trunk/raster/r.in.xyz/main.c 2009-06-24 16:56:59 UTC (rev 38061)
@@ -157,7 +157,9 @@
G_gisinit(argv[0]);
- module->keywords = _("raster, import, LIDAR");
+ G_add_keyword(_("LIDAR"));
_("Create a raster map from an assemblage of many coordinates using univariate statistics.");
Modified: grass/trunk/raster/r.info/main.c
--- grass/trunk/raster/r.info/main.c 2009-06-24 16:38:17 UTC (rev 38060)
+++ grass/trunk/raster/r.info/main.c 2009-06-24 16:56:59 UTC (rev 38061)
@@ -67,7 +67,8 @@
G_gisinit(argv[0]);
+ G_add_keyword(_("metadata"));
_("Output basic information about a raster map layer.");
Modified: grass/trunk/raster/r.kappa/main.c
--- grass/trunk/raster/r.kappa/main.c 2009-06-24 16:38:17 UTC (rev 38060)
+++ grass/trunk/raster/r.kappa/main.c 2009-06-24 16:56:59 UTC (rev 38061)
@@ -65,7 +65,7 @@
G_gisinit(argv[0]);
_("Calculate error matrix and kappa "
"parameter for accuracy assessment of classification " "result.");
Modified: grass/trunk/raster/r.lake/main.c
--- grass/trunk/raster/r.lake/main.c 2009-06-24 16:38:17 UTC (rev 38060)
+++ grass/trunk/raster/r.lake/main.c 2009-06-24 16:56:59 UTC (rev 38061)
@@ -148,7 +148,7 @@
G_gisinit(argv[0]);
module->description = _("Fills lake from seed at given level.");
tmap_opt = G_define_standard_option(G_OPT_R_ELEV);
Modified: grass/trunk/raster/r.le/r.le.patch/main.c
--- grass/trunk/raster/r.le/r.le.patch/main.c 2009-06-24 16:38:17 UTC (rev 38060)
+++ grass/trunk/raster/r.le/r.le.patch/main.c 2009-06-24 16:56:59 UTC (rev 38061)
@@ -45,7 +45,7 @@
choice = (struct CHOICE *)G_calloc(1, sizeof(struct CHOICE));
_("Calculates attribute, patch size, core (interior) size, shape, "
"fractal dimension, and perimeter measures for sets of patches "
Modified: grass/trunk/raster/r.le/r.le.pixel/main.c
--- grass/trunk/raster/r.le/r.le.pixel/main.c 2009-06-24 16:38:17 UTC (rev 38060)
+++ grass/trunk/raster/r.le/r.le.pixel/main.c 2009-06-24 16:56:59 UTC (rev 38061)
@@ -42,7 +42,7 @@
_("Contains a set of measures for attributes, diversity, texture, "
"juxtaposition, and edge.");
Modified: grass/trunk/raster/r.le/r.le.setup/main.c
--- grass/trunk/raster/r.le/r.le.setup/main.c 2009-06-24 16:38:17 UTC (rev 38060)
+++ grass/trunk/raster/r.le/r.le.setup/main.c 2009-06-24 16:56:59 UTC (rev 38061)
@@ -54,7 +54,7 @@
G_gisinit(argv[0]);
_("Interactive tool used to setup the sampling and analysis framework "
"that will be used by the other r.le programs.");
Modified: grass/trunk/raster/r.le/r.le.trace/main.c
--- grass/trunk/raster/r.le/r.le.trace/main.c 2009-06-24 16:38:17 UTC (rev 38060)
+++ grass/trunk/raster/r.le/r.le.trace/main.c 2009-06-24 16:56:59 UTC (rev 38061)
@@ -53,7 +53,7 @@
_("Displays the boundary of each r.le patch and shows how the boundary "
"is traced, displays the attribute, size, perimeter and shape "
Modified: grass/trunk/raster/r.li/r.li.cwed/cwed.c
--- grass/trunk/raster/r.li/r.li.cwed/cwed.c 2009-06-24 16:38:17 UTC (rev 38060)
+++ grass/trunk/raster/r.li/r.li.cwed/cwed.c 2009-06-24 16:56:59 UTC (rev 38061)
@@ -45,7 +45,9 @@
module = G_define_module();
_("Calculates contrast weighted edge density index on a raster map");
- module->keywords = _("raster, landscape structure analysis, patch index");
+ G_add_keyword(_("landscape structure analysis"));
+ G_add_keyword(_("patch index"));
/* define options */
Modified: grass/trunk/raster/r.li/r.li.dominance/dominance.c
--- grass/trunk/raster/r.li/r.li.dominance/dominance.c 2009-06-24 16:38:17 UTC (rev 38060)
+++ grass/trunk/raster/r.li/r.li.dominance/dominance.c 2009-06-24 16:56:59 UTC (rev 38061)
@@ -40,7 +40,7 @@
_("Calculates dominance's diversity index on a raster map");
_("raster, landscape structure analysis, diversity index");
Modified: grass/trunk/raster/r.li/r.li.edgedensity/edgedensity.c
--- grass/trunk/raster/r.li/r.li.edgedensity/edgedensity.c 2009-06-24 16:38:17 UTC (rev 38060)
+++ grass/trunk/raster/r.li/r.li.edgedensity/edgedensity.c 2009-06-24 16:56:59 UTC (rev 38061)
@@ -37,7 +37,9 @@
_("Calculates edge density index on a raster map, using a 4 neighbour algorithm");
Modified: grass/trunk/raster/r.li/r.li.mpa/mpa.c
--- grass/trunk/raster/r.li/r.li.mpa/mpa.c 2009-06-24 16:38:17 UTC (rev 38060)
+++ grass/trunk/raster/r.li/r.li.mpa/mpa.c 2009-06-24 16:56:59 UTC (rev 38061)
@@ -38,7 +38,9 @@
_("Calculates mean pixel attribute index on a raster map");
raster = G_define_standard_option(G_OPT_R_MAP);
Modified: grass/trunk/raster/r.li/r.li.mps/mps.c
--- grass/trunk/raster/r.li/r.li.mps/mps.c 2009-06-24 16:38:17 UTC (rev 38060)
+++ grass/trunk/raster/r.li/r.li.mps/mps.c 2009-06-24 16:56:59 UTC (rev 38061)
@@ -39,7 +39,9 @@
_("Calculates mean patch size index on a raster map, using a 4 neighbour algorithm");
Modified: grass/trunk/raster/r.li/r.li.padcv/padcv.c
--- grass/trunk/raster/r.li/r.li.padcv/padcv.c 2009-06-24 16:38:17 UTC (rev 38060)
+++ grass/trunk/raster/r.li/r.li.padcv/padcv.c 2009-06-24 16:56:59 UTC (rev 38061)
@@ -36,7 +36,9 @@
_("Calculates coefficient of variation of patch area on a raster map");
Modified: grass/trunk/raster/r.li/r.li.padrange/padrange.c
--- grass/trunk/raster/r.li/r.li.padrange/padrange.c 2009-06-24 16:38:17 UTC (rev 38060)
+++ grass/trunk/raster/r.li/r.li.padrange/padrange.c 2009-06-24 16:56:59 UTC (rev 38061)
@@ -38,7 +38,9 @@
_("Calculates range of patch area size on a raster map");
Modified: grass/trunk/raster/r.li/r.li.padsd/padsd.c
--- grass/trunk/raster/r.li/r.li.padsd/padsd.c 2009-06-24 16:38:17 UTC (rev 38060)
+++ grass/trunk/raster/r.li/r.li.padsd/padsd.c 2009-06-24 16:56:59 UTC (rev 38061)
@@ -36,7 +36,9 @@
_("Calculates standard deviation of patch area a raster map");
Modified: grass/trunk/raster/r.li/r.li.patchdensity/main.c
--- grass/trunk/raster/r.li/r.li.patchdensity/main.c 2009-06-24 16:38:17 UTC (rev 38060)
+++ grass/trunk/raster/r.li/r.li.patchdensity/main.c 2009-06-24 16:56:59 UTC (rev 38061)
@@ -31,7 +31,9 @@
_("Calculates patch density index on a raster map, using a 4 neighbour algorithm");
Modified: grass/trunk/raster/r.li/r.li.patchnum/main.c
--- grass/trunk/raster/r.li/r.li.patchnum/main.c 2009-06-24 16:38:17 UTC (rev 38060)
+++ grass/trunk/raster/r.li/r.li.patchnum/main.c 2009-06-24 16:56:59 UTC (rev 38061)
@@ -32,7 +32,9 @@
_("Calculates patch number index on a raster map, using a 4 neighbour algorithm.");
Modified: grass/trunk/raster/r.li/r.li.richness/richness.c
--- grass/trunk/raster/r.li/r.li.richness/richness.c 2009-06-24 16:38:17 UTC (rev 38060)
+++ grass/trunk/raster/r.li/r.li.richness/richness.c 2009-06-24 16:56:59 UTC (rev 38061)
@@ -38,7 +38,7 @@
_("raster, landscape structure analysis, dominance index");
Modified: grass/trunk/raster/r.li/r.li.shannon/shannon.c
--- grass/trunk/raster/r.li/r.li.shannon/shannon.c 2009-06-24 16:38:17 UTC (rev 38060)
+++ grass/trunk/raster/r.li/r.li.shannon/shannon.c 2009-06-24 16:56:59 UTC (rev 38061)
@@ -37,7 +37,7 @@
_("Calculates Shannon's diversity index on a raster map");
Modified: grass/trunk/raster/r.li/r.li.shape/main.c
--- grass/trunk/raster/r.li/r.li.shape/main.c 2009-06-24 16:38:17 UTC (rev 38060)
+++ grass/trunk/raster/r.li/r.li.shape/main.c 2009-06-24 16:56:59 UTC (rev 38061)
@@ -32,7 +32,9 @@
G_gisinit(argv[0]);
module->description = _("Calculates shape index on a raster map");
Modified: grass/trunk/raster/r.li/r.li.simpson/simpson.c
--- grass/trunk/raster/r.li/r.li.simpson/simpson.c 2009-06-24 16:38:17 UTC (rev 38060)
+++ grass/trunk/raster/r.li/r.li.simpson/simpson.c 2009-06-24 16:56:59 UTC (rev 38061)
@@ -38,7 +38,7 @@
_("Calculates Simpson's diversity index on a raster map");
Modified: grass/trunk/raster/r.los/main.c
--- grass/trunk/raster/r.los/main.c 2009-06-24 16:38:17 UTC (rev 38060)
+++ grass/trunk/raster/r.los/main.c 2009-06-24 16:56:59 UTC (rev 38061)
@@ -90,7 +90,7 @@
G_gisinit(argv[0]);
module->description = _("Line-of-sight raster analysis program.");
Modified: grass/trunk/raster/r.mapcalc/main.c
--- grass/trunk/raster/r.mapcalc/main.c 2009-06-24 16:38:17 UTC (rev 38060)
+++ grass/trunk/raster/r.mapcalc/main.c 2009-06-24 16:56:59 UTC (rev 38061)
@@ -108,7 +108,7 @@
G_gisinit(argv[0]);
module->description = _("Raster map calculator.");
module->overwrite = 1;
Modified: grass/trunk/raster/r.mfilter/main.c
--- grass/trunk/raster/r.mfilter/main.c 2009-06-24 16:38:17 UTC (rev 38060)
+++ grass/trunk/raster/r.mfilter/main.c 2009-06-24 16:56:59 UTC (rev 38061)
@@ -53,7 +53,8 @@
G_gisinit(argv[0]);
- module->keywords = _("raster, map algebra");
+ G_add_keyword(_("map algebra"));
module->description = _("Raster map matrix filter.");
Modified: grass/trunk/raster/r.mode/main.c
--- grass/trunk/raster/r.mode/main.c 2009-06-24 16:38:17 UTC (rev 38060)
+++ grass/trunk/raster/r.mode/main.c 2009-06-24 16:56:59 UTC (rev 38061)
@@ -48,7 +48,7 @@
G_gisinit(argv[0]);
_("Finds the mode of values in a cover map within "
"areas assigned the same category value in a "
Modified: grass/trunk/raster/r.neighbors/main.c
--- grass/trunk/raster/r.neighbors/main.c 2009-06-24 16:38:17 UTC (rev 38060)
+++ grass/trunk/raster/r.neighbors/main.c 2009-06-24 16:56:59 UTC (rev 38061)
@@ -111,7 +111,7 @@
G_gisinit(argv[0]);
_("Makes each cell category value a "
"function of the category values assigned to the cells "
Modified: grass/trunk/raster/r.null/main.c
--- grass/trunk/raster/r.null/main.c 2009-06-24 16:38:17 UTC (rev 38060)
+++ grass/trunk/raster/r.null/main.c 2009-06-24 16:56:59 UTC (rev 38061)
@@ -56,7 +56,8 @@
G_gisinit(argv[0]);
- module->keywords = _("raster, null data");
+ G_add_keyword(_("null data"));
module->description = _("Manages NULL-values of given raster map.");
parms.map = G_define_standard_option(G_OPT_R_MAP);
Modified: grass/trunk/raster/r.out.arc/main.c
--- grass/trunk/raster/r.out.arc/main.c 2009-06-24 16:38:17 UTC (rev 38060)
+++ grass/trunk/raster/r.out.arc/main.c 2009-06-24 16:56:59 UTC (rev 38061)
@@ -57,7 +57,7 @@
G_gisinit(argv[0]);
_("Converts a raster map layer into an ESRI ARCGRID file.");
Modified: grass/trunk/raster/r.out.ascii/main.c
--- grass/trunk/raster/r.out.ascii/main.c 2009-06-24 16:38:17 UTC (rev 38060)
+++ grass/trunk/raster/r.out.ascii/main.c 2009-06-24 16:56:59 UTC (rev 38061)
@@ -56,7 +56,8 @@
G_gisinit(argv[0]);
- module->keywords = _("raster, export");
+ G_add_keyword(_("export"));
_("Converts a raster map layer into an ASCII text file.");
Modified: grass/trunk/raster/r.out.bin/main.c
--- grass/trunk/raster/r.out.bin/main.c 2009-06-24 16:38:17 UTC (rev 38060)
+++ grass/trunk/raster/r.out.bin/main.c 2009-06-24 16:56:59 UTC (rev 38061)
@@ -60,7 +60,7 @@
G_gisinit(argv[0]);
module->description = _("Exports a GRASS raster to a binary array.");
Modified: grass/trunk/raster/r.out.gdal/main.c
--- grass/trunk/raster/r.out.gdal/main.c 2009-06-24 16:38:17 UTC (rev 38060)
+++ grass/trunk/raster/r.out.gdal/main.c 2009-06-24 16:56:59 UTC (rev 38061)
@@ -126,7 +126,8 @@
_("Exports GRASS raster maps into GDAL supported formats.");
flag_l = G_define_flag();
flag_l->key = 'l';
Modified: grass/trunk/raster/r.out.gridatb/main.c
--- grass/trunk/raster/r.out.gridatb/main.c 2009-06-24 16:38:17 UTC (rev 38060)
+++ grass/trunk/raster/r.out.gridatb/main.c 2009-06-24 16:56:59 UTC (rev 38061)
@@ -45,7 +45,7 @@
/* Set description */
_("Exports GRASS raster map to GRIDATB.FOR map file (TOPMODEL)");
Modified: grass/trunk/raster/r.out.mat/main.c
--- grass/trunk/raster/r.out.mat/main.c 2009-06-24 16:38:17 UTC (rev 38060)
+++ grass/trunk/raster/r.out.mat/main.c 2009-06-24 16:56:59 UTC (rev 38061)
@@ -59,7 +59,8 @@
G_gisinit(argv[0]);
module->description = _("Exports a GRASS raster to a binary MAT-File.");
Modified: grass/trunk/raster/r.out.mpeg/main.c
--- grass/trunk/raster/r.out.mpeg/main.c 2009-06-24 16:38:17 UTC (rev 38060)
+++ grass/trunk/raster/r.out.mpeg/main.c 2009-06-24 16:56:59 UTC (rev 38061)
@@ -83,7 +83,7 @@
G_gisinit(argv[0]);
module->description = _("Raster File Series to MPEG Conversion Program.");
for (i = 0; i < MAXVIEWS; i++) {
Modified: grass/trunk/raster/r.out.png/main.c
--- grass/trunk/raster/r.out.png/main.c 2009-06-24 16:38:17 UTC (rev 38060)
+++ grass/trunk/raster/r.out.png/main.c 2009-06-24 16:56:59 UTC (rev 38061)
@@ -125,7 +125,7 @@
"Export GRASS raster as non-georeferenced PNG image format.";
Modified: grass/trunk/raster/r.out.pov/main.c
--- grass/trunk/raster/r.out.pov/main.c 2009-06-24 16:38:17 UTC (rev 38060)
+++ grass/trunk/raster/r.out.pov/main.c 2009-06-24 16:56:59 UTC (rev 38061)
@@ -118,7 +118,7 @@
G_gisinit(argv[0]);
_("Converts a raster map layer into a height-field file for POVRAY.");
Modified: grass/trunk/raster/r.out.ppm/main.c
--- grass/trunk/raster/r.out.ppm/main.c 2009-06-24 16:38:17 UTC (rev 38060)
+++ grass/trunk/raster/r.out.ppm/main.c 2009-06-24 16:56:59 UTC (rev 38061)
@@ -50,7 +50,8 @@
G_gisinit(argv[0]);
_("Converts a GRASS raster map to a PPM image file "
"at the pixel resolution of the currently defined region.");
Modified: grass/trunk/raster/r.out.ppm3/main.c
--- grass/trunk/raster/r.out.ppm3/main.c 2009-06-24 16:38:17 UTC (rev 38060)
+++ grass/trunk/raster/r.out.ppm3/main.c 2009-06-24 16:56:59 UTC (rev 38061)
@@ -53,7 +53,7 @@
G_gisinit(argv[0]);
_("Converts 3 GRASS raster layers (R,G,B) to a PPM image file "
"at the pixel resolution of the CURRENTLY DEFINED REGION.");
Modified: grass/trunk/raster/r.out.tiff/main.c
--- grass/trunk/raster/r.out.tiff/main.c 2009-06-24 16:38:17 UTC (rev 38060)
+++ grass/trunk/raster/r.out.tiff/main.c 2009-06-24 16:56:59 UTC (rev 38061)
@@ -89,7 +89,8 @@
_("Exports a GRASS raster map to a 8/24bit TIFF image file "
Modified: grass/trunk/raster/r.out.vrml/main.c
--- grass/trunk/raster/r.out.vrml/main.c 2009-06-24 16:38:17 UTC (rev 38060)
+++ grass/trunk/raster/r.out.vrml/main.c 2009-06-24 16:56:59 UTC (rev 38061)
@@ -44,7 +44,9 @@
shh = color_ok = 0;
- module->keywords = _("raster, export, VRML");
+ G_add_keyword(_("VRML"));
_("Export a raster map to the Virtual Reality Modeling Language (VRML)");
Modified: grass/trunk/raster/r.out.vtk/main.c
--- grass/trunk/raster/r.out.vtk/main.c 2009-06-24 16:38:17 UTC (rev 38060)
+++ grass/trunk/raster/r.out.vtk/main.c 2009-06-24 16:56:59 UTC (rev 38061)
@@ -56,7 +56,7 @@
G_gisinit(argv[0]);
module->description = _("Converts raster maps into the VTK-Ascii format");
/* Get parameters from user */
Modified: grass/trunk/raster/r.param.scale/interface.c
--- grass/trunk/raster/r.param.scale/interface.c 2009-06-24 16:38:17 UTC (rev 38060)
+++ grass/trunk/raster/r.param.scale/interface.c 2009-06-24 16:56:59 UTC (rev 38061)
@@ -51,7 +51,8 @@
- module->keywords = _("raster, geomorphology");
+ G_add_keyword(_("raster"));
+ G_add_keyword(_("geomorphology"));
module->label = _("Extracts terrain parameters from a DEM.");
module->description = _("Uses a multi-scale approach"
" by taking fitting quadratic parameters to any size window (via least squares).");
Modified: grass/trunk/raster/r.patch/main.c
--- grass/trunk/raster/r.patch/main.c 2009-06-24 16:38:17 UTC (rev 38060)
+++ grass/trunk/raster/r.patch/main.c 2009-06-24 16:56:59 UTC (rev 38061)
@@ -51,7 +51,7 @@
G_gisinit(argv[0]);
_("Creates a composite raster map layer by using "
"known category values from one (or more) map layer(s) "
Modified: grass/trunk/raster/r.profile/main.c
--- grass/trunk/raster/r.profile/main.c 2009-06-24 16:38:17 UTC (rev 38060)
+++ grass/trunk/raster/r.profile/main.c 2009-06-24 16:56:59 UTC (rev 38061)
@@ -47,7 +47,7 @@
_("Outputs the raster map layer values lying on user-defined line(s).");
Modified: grass/trunk/raster/r.proj/main.c
--- grass/trunk/raster/r.proj/main.c 2009-06-24 16:38:17 UTC (rev 38060)
+++ grass/trunk/raster/r.proj/main.c 2009-06-24 16:56:59 UTC (rev 38061)
@@ -135,7 +135,8 @@
G_gisinit(argv[0]);
- module->keywords = _("raster, projection");
_("Re-projects a raster map from one location to the current location.");
Modified: grass/trunk/raster/r.quant/main.c
--- grass/trunk/raster/r.quant/main.c 2009-06-24 16:38:17 UTC (rev 38060)
+++ grass/trunk/raster/r.quant/main.c 2009-06-24 16:56:59 UTC (rev 38061)
@@ -44,7 +44,7 @@
G_gisinit(argv[0]);
_("Produces the quantization file for a floating-point map.");
Modified: grass/trunk/raster/r.quantile/main.c
--- grass/trunk/raster/r.quantile/main.c 2009-06-24 16:38:17 UTC (rev 38060)
+++ grass/trunk/raster/r.quantile/main.c 2009-06-24 16:56:59 UTC (rev 38061)
@@ -252,7 +252,8 @@
G_gisinit(argv[0]);
- module->keywords = _("raster, statistics");
module->description = _("Compute quantiles using two passes.");
opt.input = G_define_standard_option(G_OPT_R_INPUT);
Modified: grass/trunk/raster/r.random/main.c
--- grass/trunk/raster/r.random/main.c 2009-06-24 16:38:17 UTC (rev 38060)
+++ grass/trunk/raster/r.random/main.c 2009-06-24 16:56:59 UTC (rev 38061)
@@ -48,7 +48,7 @@
G_gisinit(argv[0]);
_("Creates a raster map layer and vector point map "
"containing randomly located points.");
Modified: grass/trunk/raster/r.random.cells/main.c
--- grass/trunk/raster/r.random.cells/main.c 2009-06-24 16:38:17 UTC (rev 38060)
+++ grass/trunk/raster/r.random.cells/main.c 2009-06-24 16:56:59 UTC (rev 38061)
@@ -42,7 +42,9 @@
G_gisinit(argv[0]);
- module->keywords = _("raster, random, cell");
+ G_add_keyword(_("random"));
+ G_add_keyword(_("cell"));
_("Generates random cell values with spatial dependence.");
Modified: grass/trunk/raster/r.random.surface/main.c
--- grass/trunk/raster/r.random.surface/main.c 2009-06-24 16:38:17 UTC (rev 38060)
+++ grass/trunk/raster/r.random.surface/main.c 2009-06-24 16:56:59 UTC (rev 38061)
@@ -54,7 +54,9 @@
G_gisinit(argv[0]);
- module->keywords = _("raster, random, surface");
+ G_add_keyword(_("surface"));
_("Generates random surface(s) with spatial dependence.");
Modified: grass/trunk/raster/r.reclass/main.c
--- grass/trunk/raster/r.reclass/main.c 2009-06-24 16:38:17 UTC (rev 38060)
+++ grass/trunk/raster/r.reclass/main.c 2009-06-24 16:56:59 UTC (rev 38061)
@@ -47,7 +47,7 @@
G_gisinit(argv[0]);
_("Creates a new map layer whose category values are based "
"upon a reclassification of the categories in an existing "
Modified: grass/trunk/raster/r.recode/main.c
--- grass/trunk/raster/r.recode/main.c 2009-06-24 16:38:17 UTC (rev 38060)
+++ grass/trunk/raster/r.recode/main.c 2009-06-24 16:56:59 UTC (rev 38061)
@@ -45,7 +45,7 @@
G_gisinit(argv[0]);
module->description = _("Recodes categorical raster maps.");
parm.input = G_define_standard_option(G_OPT_R_INPUT);
Modified: grass/trunk/raster/r.region/main.c
--- grass/trunk/raster/r.region/main.c 2009-06-24 16:38:17 UTC (rev 38060)
+++ grass/trunk/raster/r.region/main.c 2009-06-24 16:56:59 UTC (rev 38061)
@@ -49,7 +49,7 @@
G_gisinit(argv[0]);
_("Sets the boundary definitions for a raster map.");
Modified: grass/trunk/raster/r.report/main.c
--- grass/trunk/raster/r.report/main.c 2009-06-24 16:38:17 UTC (rev 38060)
+++ grass/trunk/raster/r.report/main.c 2009-06-24 16:56:59 UTC (rev 38061)
@@ -61,7 +61,8 @@
G_gisinit(argv[0]);
module->description = _("Reports statistics for raster map layers.");
parse_command_line(argc, argv);
Modified: grass/trunk/raster/r.resamp.interp/main.c
--- grass/trunk/raster/r.resamp.interp/main.c 2009-06-24 16:38:17 UTC (rev 38060)
+++ grass/trunk/raster/r.resamp.interp/main.c 2009-06-24 16:56:59 UTC (rev 38061)
@@ -69,7 +69,8 @@
G_gisinit(argv[0]);
- module->keywords = _("raster, resample");
+ G_add_keyword(_("resample"));
_("Resamples raster map layers to a finer grid using interpolation.");
Modified: grass/trunk/raster/r.resamp.rst/main.c
--- grass/trunk/raster/r.resamp.rst/main.c 2009-06-24 16:38:17 UTC (rev 38060)
+++ grass/trunk/raster/r.resamp.rst/main.c 2009-06-24 16:56:59 UTC (rev 38061)
@@ -145,7 +145,7 @@
G_gisinit(argv[0]);
_("Reinterpolates and optionally computes topographic analysis from "
"input raster map to a new raster map (possibly with "
Modified: grass/trunk/raster/r.resamp.stats/main.c
--- grass/trunk/raster/r.resamp.stats/main.c 2009-06-24 16:38:17 UTC (rev 38060)
+++ grass/trunk/raster/r.resamp.stats/main.c 2009-06-24 16:56:59 UTC (rev 38061)
@@ -259,7 +259,8 @@
G_gisinit(argv[0]);
_("Resamples raster map layers to a coarser grid using aggregation.");
Modified: grass/trunk/raster/r.resample/main.c
--- grass/trunk/raster/r.resample/main.c 2009-06-24 16:38:17 UTC (rev 38060)
+++ grass/trunk/raster/r.resample/main.c 2009-06-24 16:56:59 UTC (rev 38061)
@@ -51,7 +51,7 @@
G_gisinit(argv[0]);
_("GRASS raster map layer data resampling capability.");
Modified: grass/trunk/raster/r.rescale/main.c
--- grass/trunk/raster/r.rescale/main.c 2009-06-24 16:38:17 UTC (rev 38060)
+++ grass/trunk/raster/r.rescale/main.c 2009-06-24 16:56:59 UTC (rev 38061)
@@ -40,7 +40,7 @@
G_gisinit(argv[0]);
_("Rescales the range of category values " "in a raster map layer.");
Modified: grass/trunk/raster/r.rescale.eq/main.c
--- grass/trunk/raster/r.rescale.eq/main.c 2009-06-24 16:38:17 UTC (rev 38060)
+++ grass/trunk/raster/r.rescale.eq/main.c 2009-06-24 16:56:59 UTC (rev 38061)
@@ -44,7 +44,7 @@
_("Rescales histogram equalized the range of category "
"values in a raster map layer.");
Modified: grass/trunk/raster/r.ros/main.c
--- grass/trunk/raster/r.ros/main.c 2009-06-24 16:38:17 UTC (rev 38060)
+++ grass/trunk/raster/r.ros/main.c 2009-06-24 16:56:59 UTC (rev 38061)
@@ -210,7 +210,7 @@
_("Generates three, or four raster map layers showing 1) the base "
"(perpendicular) rate of spread (ROS), 2) the maximum (forward) ROS, "
Modified: grass/trunk/raster/r.series/main.c
--- grass/trunk/raster/r.series/main.c 2009-06-24 16:38:17 UTC (rev 38060)
+++ grass/trunk/raster/r.series/main.c 2009-06-24 16:56:59 UTC (rev 38061)
@@ -127,7 +127,8 @@
G_gisinit(argv[0]);
- module->keywords = _("raster, series");
+ G_add_keyword(_("series"));
_("Makes each output cell value a "
"function of the values assigned to the corresponding cells "
Modified: grass/trunk/raster/r.slope.aspect/main.c
--- grass/trunk/raster/r.slope.aspect/main.c 2009-06-24 16:38:17 UTC (rev 38060)
+++ grass/trunk/raster/r.slope.aspect/main.c 2009-06-24 16:56:59 UTC (rev 38061)
@@ -148,7 +148,8 @@
G_gisinit(argv[0]);
- module->keywords = _("raster, terrain analysis");
+ G_add_keyword(_("terrain analysis"));
_("Generates raster map layers of slope, aspect, curvatures and "
"partial derivatives from a raster map layer of true elevation "
Modified: grass/trunk/raster/r.spread/main.c
--- grass/trunk/raster/r.spread/main.c 2009-06-24 16:38:17 UTC (rev 38060)
+++ grass/trunk/raster/r.spread/main.c 2009-06-24 16:56:59 UTC (rev 38061)
@@ -99,7 +99,7 @@
module->label =
_("Simulates elliptically anisotropic spread on a graphics window and "
"generates a raster map of the cumulative time of spread, "
Modified: grass/trunk/raster/r.spreadpath/main.c
--- grass/trunk/raster/r.spreadpath/main.c 2009-06-24 16:38:17 UTC (rev 38060)
+++ grass/trunk/raster/r.spreadpath/main.c 2009-06-24 16:56:59 UTC (rev 38061)
@@ -86,7 +86,7 @@
_("Recursively traces the least cost path backwards to "
"cells from which the cumulative cost was determined.");
Modified: grass/trunk/raster/r.statistics/main.c
--- grass/trunk/raster/r.statistics/main.c 2009-06-24 16:38:17 UTC (rev 38060)
+++ grass/trunk/raster/r.statistics/main.c 2009-06-24 16:56:59 UTC (rev 38061)
@@ -57,7 +57,8 @@
G_gisinit(argv[0]);
_("Calculates category or object oriented statistics.");
Modified: grass/trunk/raster/r.statistics2/main.c
--- grass/trunk/raster/r.statistics2/main.c 2009-06-24 16:38:17 UTC (rev 38060)
+++ grass/trunk/raster/r.statistics2/main.c 2009-06-24 16:56:59 UTC (rev 38061)
@@ -98,7 +98,8 @@
G_gisinit(argv[0]);
Modified: grass/trunk/raster/r.statistics3/main.c
--- grass/trunk/raster/r.statistics3/main.c 2009-06-24 16:38:17 UTC (rev 38060)
+++ grass/trunk/raster/r.statistics3/main.c 2009-06-24 16:56:59 UTC (rev 38061)
@@ -388,7 +388,8 @@
G_gisinit(argv[0]);
module->description = _("Compute category quantiles using two passes.");
opt.basemap = G_define_standard_option(G_OPT_R_BASE);
Modified: grass/trunk/raster/r.stats/main.c
--- grass/trunk/raster/r.stats/main.c 2009-06-24 16:38:17 UTC (rev 38060)
+++ grass/trunk/raster/r.stats/main.c 2009-06-24 16:56:59 UTC (rev 38061)
@@ -99,7 +99,8 @@
G_gisinit(argv[0]);
_("Generates area statistics for raster map layers.");
Modified: grass/trunk/raster/r.sun/main.c
--- grass/trunk/raster/r.sun/main.c 2009-06-24 16:38:17 UTC (rev 38060)
+++ grass/trunk/raster/r.sun/main.c 2009-06-24 16:56:59 UTC (rev 38061)
@@ -170,7 +170,7 @@
G_gisinit(argv[0]);
module->label = _("Solar irradiance and irradiation model.");
_("Computes direct (beam), diffuse and reflected solar irradiation raster "
Modified: grass/trunk/raster/r.sun2/main.c
--- grass/trunk/raster/r.sun2/main.c 2009-06-24 16:38:17 UTC (rev 38060)
+++ grass/trunk/raster/r.sun2/main.c 2009-06-24 16:56:59 UTC (rev 38061)
@@ -224,7 +224,7 @@
G_gisinit(argv[0]);
Modified: grass/trunk/raster/r.sunmask/main.c
--- grass/trunk/raster/r.sunmask/main.c 2009-06-24 16:38:17 UTC (rev 38060)
+++ grass/trunk/raster/r.sunmask/main.c 2009-06-24 16:56:59 UTC (rev 38061)
@@ -123,7 +123,7 @@
G_gisinit(argv[0]);
_("Calculates cast shadow areas from sun position and DEM. Either "
"A: exact sun position is specified, or B: date/time to calculate "
Modified: grass/trunk/raster/r.support/main.c
--- grass/trunk/raster/r.support/main.c 2009-06-24 16:38:17 UTC (rev 38060)
+++ grass/trunk/raster/r.support/main.c 2009-06-24 16:56:59 UTC (rev 38061)
@@ -53,7 +53,8 @@
G_gisinit(argv[0]);
- module->keywords = _("raster, metadata");
module->description = _("Allows creation and/or modification of "
"raster map layer support files.");
Modified: grass/trunk/raster/r.support.stats/main.c
--- grass/trunk/raster/r.support.stats/main.c 2009-06-24 16:38:17 UTC (rev 38060)
+++ grass/trunk/raster/r.support.stats/main.c 2009-06-24 16:56:59 UTC (rev 38061)
@@ -35,7 +35,8 @@
module->description = _("Update raster map statistics");
parm.raster = G_define_standard_option(G_OPT_R_MAP);
Modified: grass/trunk/raster/r.surf.area/main.c
--- grass/trunk/raster/r.surf.area/main.c 2009-06-24 16:38:17 UTC (rev 38060)
+++ grass/trunk/raster/r.surf.area/main.c 2009-06-24 16:56:59 UTC (rev 38061)
@@ -85,7 +85,7 @@
G_gisinit(argv[0]);
module->description = _("Surface area estimation for rasters.");
surf = G_define_option();
Modified: grass/trunk/raster/r.surf.contour/main.c
--- grass/trunk/raster/r.surf.contour/main.c 2009-06-24 16:38:17 UTC (rev 38060)
+++ grass/trunk/raster/r.surf.contour/main.c 2009-06-24 16:56:59 UTC (rev 38061)
@@ -58,7 +58,7 @@
G_gisinit(argv[0]);
_("Surface generation program from rasterized contours.");
Modified: grass/trunk/raster/r.surf.fractal/main.c
--- grass/trunk/raster/r.surf.fractal/main.c 2009-06-24 16:38:17 UTC (rev 38060)
+++ grass/trunk/raster/r.surf.fractal/main.c 2009-06-24 16:56:59 UTC (rev 38061)
@@ -35,7 +35,9 @@
G_gisinit(argv[0]); /* Link with GRASS interface. */
- module->keywords = _("raster, DEM, fractal");
+ G_add_keyword(_("fractal"));
_("Creates a fractal surface of a given fractal dimension.");
Modified: grass/trunk/raster/r.surf.gauss/main.c
--- grass/trunk/raster/r.surf.gauss/main.c 2009-06-24 16:38:17 UTC (rev 38060)
+++ grass/trunk/raster/r.surf.gauss/main.c 2009-06-24 16:56:59 UTC (rev 38061)
@@ -35,7 +35,7 @@
G_gisinit(argv[0]);
_("GRASS module to produce a raster map layer of "
"gaussian deviates whose mean and standard deviation "
Modified: grass/trunk/raster/r.surf.idw/main.c
--- grass/trunk/raster/r.surf.idw/main.c 2009-06-24 16:38:17 UTC (rev 38060)
+++ grass/trunk/raster/r.surf.idw/main.c 2009-06-24 16:56:59 UTC (rev 38061)
@@ -100,7 +100,8 @@
G_gisinit(argv[0]);
- module->keywords = _("raster, interpolation");
+ G_add_keyword(_("interpolation"));
_("Surface interpolation utility for raster map.");
Modified: grass/trunk/raster/r.surf.idw2/main.c
--- grass/trunk/raster/r.surf.idw2/main.c 2009-06-24 16:38:17 UTC (rev 38060)
+++ grass/trunk/raster/r.surf.idw2/main.c 2009-06-24 16:56:59 UTC (rev 38061)
@@ -58,7 +58,7 @@
G_gisinit(argv[0]);
module->description = _("Surface generation program.");
Modified: grass/trunk/raster/r.surf.random/main.c
--- grass/trunk/raster/r.surf.random/main.c 2009-06-24 16:38:17 UTC (rev 38060)
+++ grass/trunk/raster/r.surf.random/main.c 2009-06-24 16:56:59 UTC (rev 38061)
@@ -33,7 +33,7 @@
G_gisinit(argv[0]);
_("Produces a raster map layer of uniform random "
"deviates whose range can be expressed by the user.");
Modified: grass/trunk/raster/r.texture/main.c
--- grass/trunk/raster/r.texture/main.c 2009-06-24 16:38:17 UTC (rev 38060)
+++ grass/trunk/raster/r.texture/main.c 2009-06-24 16:56:59 UTC (rev 38061)
@@ -72,7 +72,7 @@
G_gisinit(argv[0]);
_("Generate images with textural features from a raster map.");
Modified: grass/trunk/raster/r.thin/main.c
--- grass/trunk/raster/r.thin/main.c 2009-06-24 16:38:17 UTC (rev 38060)
+++ grass/trunk/raster/r.thin/main.c 2009-06-24 16:56:59 UTC (rev 38061)
@@ -53,7 +53,7 @@
G_gisinit(argv[0]);
_("Thins non-zero cells that denote linear "
"features in a raster map layer.");
Modified: grass/trunk/raster/r.timestamp/main.c
--- grass/trunk/raster/r.timestamp/main.c 2009-06-24 16:38:17 UTC (rev 38060)
+++ grass/trunk/raster/r.timestamp/main.c 2009-06-24 16:56:59 UTC (rev 38061)
@@ -31,7 +31,7 @@
G_gisinit(argv[0]);
module->description = _("Print/add/remove a timestamp for a raster map.");
Modified: grass/trunk/raster/r.to.rast3/main.c
--- grass/trunk/raster/r.to.rast3/main.c 2009-06-24 16:38:17 UTC (rev 38060)
+++ grass/trunk/raster/r.to.rast3/main.c 2009-06-24 16:56:59 UTC (rev 38061)
@@ -191,7 +191,9 @@
G_gisinit(argv[0]);
- module->keywords = _("raster, volume, conversion");
+ G_add_keyword(_("volume"));
_("Converts 2D raster map slices to one 3D raster volume map.");
Modified: grass/trunk/raster/r.to.rast3elev/main.c
--- grass/trunk/raster/r.to.rast3elev/main.c 2009-06-24 16:38:17 UTC (rev 38060)
+++ grass/trunk/raster/r.to.rast3elev/main.c 2009-06-24 16:56:59 UTC (rev 38061)
@@ -355,7 +355,10 @@
G_gisinit(argv[0]);
- module->keywords = _("raster, raster3d, voxel, conversion");
+ G_add_keyword(_("raster3d"));
+ G_add_keyword(_("voxel"));
_("Creates a 3D volume map based on 2D elevation and value raster maps.");
Modified: grass/trunk/raster/r.to.vect/main.c
--- grass/trunk/raster/r.to.vect/main.c 2009-06-24 16:38:17 UTC (rev 38060)
+++ grass/trunk/raster/r.to.vect/main.c 2009-06-24 16:56:59 UTC (rev 38061)
@@ -68,7 +68,7 @@
G_gisinit(argv[0]);
module->description = _("Converts a raster map into a vector map layer.");
in_opt = G_define_standard_option(G_OPT_R_INPUT);
Modified: grass/trunk/raster/r.topidx/main.c
--- grass/trunk/raster/r.topidx/main.c 2009-06-24 16:38:17 UTC (rev 38060)
+++ grass/trunk/raster/r.topidx/main.c 2009-06-24 16:56:59 UTC (rev 38061)
@@ -36,7 +36,7 @@
G_gisinit(argv[0]);
_("Creates topographic index [ln(a/tan(beta))] map from elevation map.");
Modified: grass/trunk/raster/r.topmodel/main.c
--- grass/trunk/raster/r.topmodel/main.c 2009-06-24 16:38:17 UTC (rev 38060)
+++ grass/trunk/raster/r.topmodel/main.c 2009-06-24 16:56:59 UTC (rev 38061)
@@ -59,7 +59,7 @@
G_gisinit(argv[0]);
_("Simulates TOPMODEL which is a physically based hydrologic model.");
Modified: grass/trunk/raster/r.transect/main.c
--- grass/trunk/raster/r.transect/main.c 2009-06-24 16:38:17 UTC (rev 38060)
+++ grass/trunk/raster/r.transect/main.c 2009-06-24 16:56:59 UTC (rev 38061)
@@ -47,7 +47,7 @@
G_gisinit(argv[0]);
_("Outputs raster map layer values lying along "
"user defined transect line(s).");
Modified: grass/trunk/raster/r.univar/r.univar_main.c
--- grass/trunk/raster/r.univar/r.univar_main.c 2009-06-24 16:38:17 UTC (rev 38060)
+++ grass/trunk/raster/r.univar/r.univar_main.c 2009-06-24 16:56:59 UTC (rev 38061)
@@ -70,7 +70,8 @@
G_gisinit(argv[0]);
_("Calculates univariate statistics from the non-null cells of a raster map.");
Modified: grass/trunk/raster/r.univar/r3.univar_main.c
--- grass/trunk/raster/r.univar/r3.univar_main.c 2009-06-24 16:38:17 UTC (rev 38060)
+++ grass/trunk/raster/r.univar/r3.univar_main.c 2009-06-24 16:56:59 UTC (rev 38061)
@@ -74,7 +74,8 @@
G_gisinit(argv[0]);
- module->keywords = _("raster3d, statistics");
_("Calculates univariate statistics from the non-null 3d cells of a raster3d map.");
Modified: grass/trunk/raster/r.uslek/main.c
--- grass/trunk/raster/r.uslek/main.c 2009-06-24 16:38:17 UTC (rev 38060)
+++ grass/trunk/raster/r.uslek/main.c 2009-06-24 16:56:59 UTC (rev 38061)
@@ -50,7 +50,10 @@
G_gisinit(argv[0]);
- module->keywords = _("raster, soil, erosion, USLE");
+ G_add_keyword(_("soil"));
+ G_add_keyword(_("erosion"));
+ G_add_keyword(_("USLE"));
module->description = _("USLE Soil Erodibility Factor (K)");
/* Define the different options */
Modified: grass/trunk/raster/r.usler/main.c
--- grass/trunk/raster/r.usler/main.c 2009-06-24 16:38:17 UTC (rev 38060)
+++ grass/trunk/raster/r.usler/main.c 2009-06-24 16:56:59 UTC (rev 38061)
@@ -48,7 +48,10 @@
G_gisinit(argv[0]);
- module->keywords = _("raster, rainfall, erosion, USLE");
+ G_add_keyword(_("rainfall"));
module->description = _("Computes USLE R factor, Rainfall erosivity index.");
input2 = G_define_standard_option(G_OPT_R_INPUT);
Modified: grass/trunk/raster/r.volume/main.c
--- grass/trunk/raster/r.volume/main.c 2009-06-24 16:38:17 UTC (rev 38060)
+++ grass/trunk/raster/r.volume/main.c 2009-06-24 16:56:59 UTC (rev 38061)
@@ -55,7 +55,7 @@
G_gisinit(argv[0]);
_("Calculates the volume of data \"clumps\", "
"and (optionally) produces a GRASS vector points map "
Modified: grass/trunk/raster/r.walk/main.c
--- grass/trunk/raster/r.walk/main.c 2009-06-24 16:38:17 UTC (rev 38060)
+++ grass/trunk/raster/r.walk/main.c 2009-06-24 16:56:59 UTC (rev 38061)
@@ -185,7 +185,7 @@
G_gisinit(argv[0]);
_("Outputs a raster map layer showing the "
"anisotropic cumulative cost of moving between different "
Modified: grass/trunk/raster/r.water.outlet/main.c
--- grass/trunk/raster/r.water.outlet/main.c 2009-06-24 16:38:17 UTC (rev 38060)
+++ grass/trunk/raster/r.water.outlet/main.c 2009-06-24 16:56:59 UTC (rev 38061)
@@ -62,7 +62,7 @@
module->description = _("Watershed basin creation program.");
opt1 = G_define_option();
opt1->key = "drainage";
Modified: grass/trunk/raster/r.watershed/front/main.c
--- grass/trunk/raster/r.watershed/front/main.c 2009-06-24 16:38:17 UTC (rev 38060)
+++ grass/trunk/raster/r.watershed/front/main.c 2009-06-24 16:56:59 UTC (rev 38061)
@@ -53,7 +53,7 @@
module->description = _("Watershed basin analysis program.");
opt1 = G_define_standard_option(G_OPT_R_ELEV);
Modified: grass/trunk/raster/r.what/main.c
--- grass/trunk/raster/r.what/main.c 2009-06-24 16:38:17 UTC (rev 38060)
+++ grass/trunk/raster/r.what/main.c 2009-06-24 16:56:59 UTC (rev 38061)
@@ -89,7 +89,7 @@
_("Queries raster map layers on their category values and category labels.");
Modified: grass/trunk/raster/r.what.color/main.c
--- grass/trunk/raster/r.what.color/main.c 2009-06-24 16:38:17 UTC (rev 38060)
+++ grass/trunk/raster/r.what.color/main.c 2009-06-24 16:56:59 UTC (rev 38061)
@@ -85,7 +85,7 @@
G_gisinit(argv[0]);
module->description = _("Queries colors for a raster map layer.");
opt.input = G_define_option();
Modified: grass/trunk/raster/simwe/r.sim.sediment/main.c
--- grass/trunk/raster/simwe/r.sim.sediment/main.c 2009-06-24 16:38:17 UTC (rev 38060)
+++ grass/trunk/raster/simwe/r.sim.sediment/main.c 2009-06-24 16:56:59 UTC (rev 38061)
@@ -108,7 +108,10 @@
G_gisinit(argv[0]);
- module->keywords = _("raster, sediment flow, erosion, deposition");
+ G_add_keyword(_("sediment flow"));
+ G_add_keyword(_("deposition"));
_("Sediment transport and erosion/deposition simulation "
"using path sampling method (SIMWE)");
Modified: grass/trunk/raster/simwe/r.sim.water/main.c
--- grass/trunk/raster/simwe/r.sim.water/main.c 2009-06-24 16:38:17 UTC (rev 38060)
+++ grass/trunk/raster/simwe/r.sim.water/main.c 2009-06-24 16:56:59 UTC (rev 38061)
@@ -115,7 +115,9 @@
G_gisinit(argv[0]);
- module->keywords = _("raster, flow, hydrology");
+ G_add_keyword(_("flow"));
+ G_add_keyword(_("hydrology"));
_("Overland flow hydrologic simulation using "
"path sampling method (SIMWE)");
Modified: grass/trunk/raster3d/base/r3.mask.main.c
--- grass/trunk/raster3d/base/r3.mask.main.c 2009-06-24 16:38:17 UTC (rev 38060)
+++ grass/trunk/raster3d/base/r3.mask.main.c 2009-06-24 16:56:59 UTC (rev 38061)
@@ -130,7 +130,8 @@
G_gisinit(argv[0]);
- module->keywords = _("raster3d, voxel");
_("Establishes the current working 3D raster mask.");
Modified: grass/trunk/raster3d/base/r3.null.main.c
--- grass/trunk/raster3d/base/r3.null.main.c 2009-06-24 16:38:17 UTC (rev 38060)
+++ grass/trunk/raster3d/base/r3.null.main.c 2009-06-24 16:56:59 UTC (rev 38061)
@@ -199,7 +199,8 @@
G_gisinit(argv[0]);
_("Explicitly create the 3D NULL-value bitmap file.");
Modified: grass/trunk/raster3d/r3.cross.rast/main.c
--- grass/trunk/raster3d/r3.cross.rast/main.c 2009-06-24 16:38:17 UTC (rev 38060)
+++ grass/trunk/raster3d/r3.cross.rast/main.c 2009-06-24 16:56:59 UTC (rev 38061)
@@ -267,7 +267,8 @@
G_gisinit(argv[0]);
_("Creates cross section 2D raster map from 3d raster map based on 2D elevation map");
Modified: grass/trunk/raster3d/r3.gwflow/main.c
--- grass/trunk/raster3d/r3.gwflow/main.c 2009-06-24 16:38:17 UTC (rev 38060)
+++ grass/trunk/raster3d/r3.gwflow/main.c 2009-06-24 16:56:59 UTC (rev 38061)
@@ -165,7 +165,8 @@
G_gisinit(argv[0]);
_("Numerical calculation program for transient, confined groundwater flow in three dimensions");
Modified: grass/trunk/raster3d/r3.in.ascii/main.c
--- grass/trunk/raster3d/r3.in.ascii/main.c 2009-06-24 16:38:17 UTC (rev 38060)
+++ grass/trunk/raster3d/r3.in.ascii/main.c 2009-06-24 16:56:59 UTC (rev 38061)
@@ -237,7 +237,9 @@
G_gisinit(argv[0]);
- module->keywords = _("raster3d, voxel, import");
_("Convert a 3D ASCII raster text file into a (binary) 3D raster map layer");
Modified: grass/trunk/raster3d/r3.in.v5d/main.c
--- grass/trunk/raster3d/r3.in.v5d/main.c 2009-06-24 16:38:17 UTC (rev 38060)
+++ grass/trunk/raster3d/r3.in.v5d/main.c 2009-06-24 16:56:59 UTC (rev 38061)
@@ -190,7 +190,8 @@
G_gisinit(argv[0]);
" import of 3-dimensional Vis5D files (i.e. the v5d file with 1 variable and 1 time step)";
Modified: grass/trunk/raster3d/r3.info/r3.info.main.c
--- grass/trunk/raster3d/r3.info/r3.info.main.c 2009-06-24 16:38:17 UTC (rev 38060)
+++ grass/trunk/raster3d/r3.info/r3.info.main.c 2009-06-24 16:56:59 UTC (rev 38061)
@@ -75,7 +75,8 @@
G_gisinit(argv[0]);
_("Outputs basic information about a user-specified 3D raster map layer.");
Modified: grass/trunk/raster3d/r3.mkdspf/main.c
--- grass/trunk/raster3d/r3.mkdspf/main.c 2009-06-24 16:38:17 UTC (rev 38060)
+++ grass/trunk/raster3d/r3.mkdspf/main.c 2009-06-24 16:56:59 UTC (rev 38061)
@@ -76,7 +76,8 @@
G_gisinit(argv[0]);
_("Creates a display file from an existing grid3 file according to specified threshold levels.");
Modified: grass/trunk/raster3d/r3.out.ascii/main.c
--- grass/trunk/raster3d/r3.out.ascii/main.c 2009-06-24 16:38:17 UTC (rev 38060)
+++ grass/trunk/raster3d/r3.out.ascii/main.c 2009-06-24 16:56:59 UTC (rev 38061)
@@ -241,7 +241,9 @@
/* Initialize GRASS */
G_gisinit(argv[0]);
- module->keywords = _("raster3d, voxel, export");
_("Converts a 3D raster map layer into an ASCII text file");
Modified: grass/trunk/raster3d/r3.out.v5d/main.c
--- grass/trunk/raster3d/r3.out.v5d/main.c 2009-06-24 16:38:17 UTC (rev 38060)
+++ grass/trunk/raster3d/r3.out.v5d/main.c 2009-06-24 16:56:59 UTC (rev 38061)
@@ -286,7 +286,8 @@
G_gisinit(argv[0]);
_("Export of GRASS 3D raster map to 3-dimensional Vis5D file.");
Modified: grass/trunk/raster3d/r3.out.vtk/main.c
--- grass/trunk/raster3d/r3.out.vtk/main.c 2009-06-24 16:38:17 UTC (rev 38060)
+++ grass/trunk/raster3d/r3.out.vtk/main.c 2009-06-24 16:56:59 UTC (rev 38061)
@@ -378,7 +378,8 @@
G_gisinit(argv[0]);
_("Converts 3D raster maps (G3D) into the VTK-Ascii format");
Modified: grass/trunk/raster3d/r3.stats/main.c
--- grass/trunk/raster3d/r3.stats/main.c 2009-06-24 16:38:17 UTC (rev 38060)
+++ grass/trunk/raster3d/r3.stats/main.c 2009-06-24 16:56:59 UTC (rev 38061)
@@ -565,7 +565,8 @@
G_gisinit(argv[0]);
module->description = _("Generates volume statistics for raster3d maps.");
Modified: grass/trunk/raster3d/r3.timestamp/r3.timestamp.main.c
--- grass/trunk/raster3d/r3.timestamp/r3.timestamp.main.c 2009-06-24 16:38:17 UTC (rev 38060)
+++ grass/trunk/raster3d/r3.timestamp/r3.timestamp.main.c 2009-06-24 16:56:59 UTC (rev 38061)
@@ -40,7 +40,8 @@
G_gisinit(argv[0]);
_("Print/add/remove a timestamp for a 3D raster map");
Modified: grass/trunk/raster3d/r3.to.rast/main.c
--- grass/trunk/raster3d/r3.to.rast/main.c 2009-06-24 16:38:17 UTC (rev 38060)
+++ grass/trunk/raster3d/r3.to.rast/main.c 2009-06-24 16:56:59 UTC (rev 38061)
@@ -213,7 +213,8 @@
G_gisinit(argv[0]);
module->description = _("Converts 3D raster maps to 2D raster maps");
Modified: grass/trunk/sites/s.in.ascii/main.c
--- grass/trunk/sites/s.in.ascii/main.c 2009-06-24 16:38:17 UTC (rev 38060)
+++ grass/trunk/sites/s.in.ascii/main.c 2009-06-24 16:56:59 UTC (rev 38061)
@@ -47,7 +47,7 @@
G_gisinit(me = argv[0]);
- module->keywords = _("sites");
+ G_add_keyword(_("sites"));
"Convert an ASCII listing of site locations "
"into a GRASS site list file.";
Modified: grass/trunk/sites/s.out.ascii/main.c
--- grass/trunk/sites/s.out.ascii/main.c 2009-06-24 16:38:17 UTC (rev 38060)
+++ grass/trunk/sites/s.out.ascii/main.c 2009-06-24 16:56:59 UTC (rev 38061)
@@ -44,7 +44,7 @@
G_gisinit(argv[0]);
"Converts a GRASS site list file into an ASCII listing of "
"site locations and their descriptions.";
Modified: grass/trunk/swig/perl/R_slope_aspect/r_slope_aspect/r_slope_aspect.c
--- grass/trunk/swig/perl/R_slope_aspect/r_slope_aspect/r_slope_aspect.c 2009-06-24 16:38:17 UTC (rev 38060)
+++ grass/trunk/swig/perl/R_slope_aspect/r_slope_aspect/r_slope_aspect.c 2009-06-24 16:56:59 UTC (rev 38061)
@@ -150,7 +150,7 @@
G_gisinit(argv[0]);
Modified: grass/trunk/vector/lidar/v.lidar.correction/main.c
--- grass/trunk/vector/lidar/v.lidar.correction/main.c 2009-06-24 16:38:17 UTC (rev 38060)
+++ grass/trunk/vector/lidar/v.lidar.correction/main.c 2009-06-24 16:56:59 UTC (rev 38061)
@@ -63,7 +63,8 @@
/* Options' declaration */
- module->keywords = _("vector, LIDAR");
+ G_add_keyword(_("vector"));
_("Correction of the v.lidar.growing output. It is the last of the three algorithms for LIDAR filtering.");
Modified: grass/trunk/vector/lidar/v.lidar.edgedetection/main.c
--- grass/trunk/vector/lidar/v.lidar.edgedetection/main.c 2009-06-24 16:38:17 UTC (rev 38060)
+++ grass/trunk/vector/lidar/v.lidar.edgedetection/main.c 2009-06-24 16:56:59 UTC (rev 38061)
@@ -71,7 +71,9 @@
- module->keywords = _("vector, LIDAR, edges");
+ G_add_keyword(_("edges"));
_("Detects the object's edges from a LIDAR data set.");
Modified: grass/trunk/vector/lidar/v.lidar.growing/main.c
--- grass/trunk/vector/lidar/v.lidar.growing/main.c 2009-06-24 16:38:17 UTC (rev 38060)
+++ grass/trunk/vector/lidar/v.lidar.growing/main.c 2009-06-24 16:56:59 UTC (rev 38061)
@@ -74,7 +74,8 @@
/* Options' declaration */ ;
_("Building contour determination and Region Growing "
"algorithm for determining the building inside");
Modified: grass/trunk/vector/lidar/v.outlier/main.c
--- grass/trunk/vector/lidar/v.outlier/main.c 2009-06-24 16:38:17 UTC (rev 38060)
+++ grass/trunk/vector/lidar/v.outlier/main.c 2009-06-24 16:56:59 UTC (rev 38061)
@@ -65,7 +65,8 @@
- module->keywords = _("vector, statistics");
module->description = _("Removes outliers from vector point data.");
in_opt = G_define_standard_option(G_OPT_V_INPUT);
Modified: grass/trunk/vector/lidar/v.surf.bspline/main.c
--- grass/trunk/vector/lidar/v.surf.bspline/main.c 2009-06-24 16:38:17 UTC (rev 38060)
+++ grass/trunk/vector/lidar/v.surf.bspline/main.c 2009-06-24 16:56:59 UTC (rev 38061)
@@ -79,7 +79,8 @@
module = G_define_module(); {
- module->keywords = _("vector, interpolation");
+G_add_keyword(_("vector"));
+G_add_keyword(_("interpolation"));
_("Bicubic or bilinear spline interpolation with Tykhonov regularization.");
Modified: grass/trunk/vector/v.buffer/main.c
--- grass/trunk/vector/v.buffer/main.c 2009-06-24 16:38:17 UTC (rev 38060)
+++ grass/trunk/vector/v.buffer/main.c 2009-06-24 16:56:59 UTC (rev 38061)
@@ -142,7 +142,8 @@
- module->keywords = _("vector, buffer");
_("Creates a buffer around features of given type (areas must contain centroid).");
Modified: grass/trunk/vector/v.build/main.c
--- grass/trunk/vector/v.build/main.c 2009-06-24 16:38:17 UTC (rev 38060)
+++ grass/trunk/vector/v.build/main.c 2009-06-24 16:56:59 UTC (rev 38061)
@@ -31,7 +31,8 @@
G_gisinit(argv[0]);
- module->keywords = _("vector, topology");
+ G_add_keyword(_("topology"));
module->description = _("Creates topology for GRASS vector map.");
map_opt = G_define_standard_option(G_OPT_V_MAP);
Modified: grass/trunk/vector/v.build.polylines/main.c
--- grass/trunk/vector/v.build.polylines/main.c 2009-06-24 16:38:17 UTC (rev 38060)
+++ grass/trunk/vector/v.build.polylines/main.c 2009-06-24 16:56:59 UTC (rev 38061)
@@ -106,7 +106,9 @@
G_gisinit(argv[0]);
- module->keywords = _("vector, geometry, topology");
+ G_add_keyword(_("geometry"));
module->description = _("Builds polylines from lines or boundaries.");
/* Define the options */
Modified: grass/trunk/vector/v.category/main.c
--- grass/trunk/vector/v.category/main.c 2009-06-24 16:38:17 UTC (rev 38060)
+++ grass/trunk/vector/v.category/main.c 2009-06-24 16:56:59 UTC (rev 38061)
@@ -64,7 +64,8 @@
int nfreps, rtype, fld;
- module->keywords = _("vector, category");
+ G_add_keyword(_("category"));
_("Attach, delete or report vector categories to map geometry.");
Modified: grass/trunk/vector/v.class/main.c
--- grass/trunk/vector/v.class/main.c 2009-06-24 16:38:17 UTC (rev 38060)
+++ grass/trunk/vector/v.class/main.c 2009-06-24 16:56:59 UTC (rev 38061)
@@ -41,7 +41,8 @@
struct GASTATS stats;
_("Classifies attribute data, e.g. for thematic mapping");
Modified: grass/trunk/vector/v.clean/main.c
--- grass/trunk/vector/v.clean/main.c 2009-06-24 16:38:17 UTC (rev 38060)
+++ grass/trunk/vector/v.clean/main.c 2009-06-24 16:56:59 UTC (rev 38061)
@@ -39,7 +39,8 @@
G_gisinit(argv[0]);
module->description = _("Toolset for cleaning topology of vector map.");
Modified: grass/trunk/vector/v.clean/test/topocheck.c
--- grass/trunk/vector/v.clean/test/topocheck.c 2009-06-24 16:38:17 UTC (rev 38060)
+++ grass/trunk/vector/v.clean/test/topocheck.c 2009-06-24 16:56:59 UTC (rev 38061)
@@ -39,7 +39,7 @@
G_gisinit(argv[0]);
- module->keywords = _("vector");
module->description = "Break lines at intersections.";
Modified: grass/trunk/vector/v.convert/main.c
--- grass/trunk/vector/v.convert/main.c 2009-06-24 16:38:17 UTC (rev 38060)
+++ grass/trunk/vector/v.convert/main.c 2009-06-24 16:56:59 UTC (rev 38061)
@@ -33,7 +33,9 @@
struct GModule *module;
- module->keywords = _("vector, import, conversion");
module->description = _("Imports older versions of GRASS vector maps.");
/* input vector map */
Modified: grass/trunk/vector/v.db.connect/main.c
--- grass/trunk/vector/v.db.connect/main.c 2009-06-24 16:38:17 UTC (rev 38060)
+++ grass/trunk/vector/v.db.connect/main.c 2009-06-24 16:56:59 UTC (rev 38061)
@@ -46,7 +46,9 @@
/* set up the options and flags for the command line parser */
- module->keywords = _("vector, database, attribute table");
+ G_add_keyword(_("database"));
+ G_add_keyword(_("attribute table"));
_("Prints/sets DB connection for a vector map to attribute table.");
Modified: grass/trunk/vector/v.db.select/main.c
--- grass/trunk/vector/v.db.select/main.c 2009-06-24 16:38:17 UTC (rev 38060)
+++ grass/trunk/vector/v.db.select/main.c 2009-06-24 16:56:59 UTC (rev 38061)
@@ -48,7 +48,9 @@
int i, line, area, init_box, cat;
module->description = _("Prints vector map attributes.");
Modified: grass/trunk/vector/v.delaunay/main.c
--- grass/trunk/vector/v.delaunay/main.c 2009-06-24 16:38:17 UTC (rev 38060)
+++ grass/trunk/vector/v.delaunay/main.c 2009-06-24 16:56:59 UTC (rev 38061)
@@ -59,7 +59,7 @@
/* GRASS related manipulations */
G_gisinit(argv[0]);
module->description = _("Creates a Delaunay triangulation from an input "
"vector map containing points or centroids.");
Modified: grass/trunk/vector/v.distance/main.c
--- grass/trunk/vector/v.distance/main.c 2009-06-24 16:38:17 UTC (rev 38060)
+++ grass/trunk/vector/v.distance/main.c 2009-06-24 16:56:59 UTC (rev 38061)
@@ -111,7 +111,9 @@
G_gisinit(argv[0]);
_("Finds the nearest element in vector map 'to' for elements in vector map 'from'.");
Modified: grass/trunk/vector/v.drape/main.c
--- grass/trunk/vector/v.drape/main.c 2009-06-24 16:38:17 UTC (rev 38060)
+++ grass/trunk/vector/v.drape/main.c 2009-06-24 16:56:59 UTC (rev 38061)
@@ -146,7 +146,9 @@
G_gisinit(argv[0]);
- module->keywords = _("vector, geometry, sampling");
+ G_add_keyword(_("sampling"));
_("Converts vector map to 3D by sampling of elevation raster map.");
Modified: grass/trunk/vector/v.edit/main.c
--- grass/trunk/vector/v.edit/main.c 2009-06-24 16:38:17 UTC (rev 38060)
+++ grass/trunk/vector/v.edit/main.c 2009-06-24 16:56:59 UTC (rev 38061)
@@ -51,7 +51,9 @@
G_gisinit(argv[0]);
- module->keywords = _("vector, editing, geometry");
+ G_add_keyword(_("editing"));
module->description = _("Edits a vector map, allows adding, deleting "
"and modifying selected vector features.");
Modified: grass/trunk/vector/v.external/main.c
--- grass/trunk/vector/v.external/main.c 2009-06-24 16:38:17 UTC (rev 38060)
+++ grass/trunk/vector/v.external/main.c 2009-06-24 16:56:59 UTC (rev 38061)
@@ -55,7 +55,7 @@
sprintf(buf, "%s,%s", buf, OGR_Dr_GetName(Ogr_driver));
module->label =
_("Creates a new vector as a read-only link to OGR layer.");
module->description = G_store(buf);
Modified: grass/trunk/vector/v.extract/main.c
--- grass/trunk/vector/v.extract/main.c 2009-06-24 16:38:17 UTC (rev 38060)
+++ grass/trunk/vector/v.extract/main.c 2009-06-24 16:56:59 UTC (rev 38061)
@@ -88,7 +88,8 @@
- module->keywords = _("vector, extract");
+ G_add_keyword(_("extract"));
_("Selects vector objects from an existing vector map and "
"creates a new map containing only the selected objects.");
Modified: grass/trunk/vector/v.extrude/main.c
--- grass/trunk/vector/v.extrude/main.c 2009-06-24 16:38:17 UTC (rev 38060)
+++ grass/trunk/vector/v.extrude/main.c 2009-06-24 16:56:59 UTC (rev 38061)
@@ -65,7 +65,9 @@
char *comment;
- module->keywords = _("vector, geometry, 3D");
+ G_add_keyword(_("3D"));
_("Extrudes flat vector object to 3D with defined height.");
Modified: grass/trunk/vector/v.generalize/main.c
--- grass/trunk/vector/v.generalize/main.c 2009-06-24 16:38:17 UTC (rev 38060)
+++ grass/trunk/vector/v.generalize/main.c 2009-06-24 16:56:59 UTC (rev 38061)
@@ -75,7 +75,7 @@
/* initialize module */
+ G_add_keyword(_(""));
_("vector, generalization, simplification, smoothing, displacement, network generalization");
module->description = _("Vector based generalization.");
Modified: grass/trunk/vector/v.hull/main.c
--- grass/trunk/vector/v.hull/main.c 2009-06-24 16:38:17 UTC (rev 38060)
+++ grass/trunk/vector/v.hull/main.c 2009-06-24 16:56:59 UTC (rev 38061)
@@ -284,7 +284,8 @@
G_gisinit(argv[0]);
- module->keywords = _("vector, geometry");
_("Uses a GRASS vector points map to produce a convex hull vector map.");
Modified: grass/trunk/vector/v.in.ascii/main.c
--- grass/trunk/vector/v.in.ascii/main.c 2009-06-24 16:38:17 UTC (rev 38060)
+++ grass/trunk/vector/v.in.ascii/main.c 2009-06-24 16:56:59 UTC (rev 38061)
@@ -45,7 +45,8 @@
G_gisinit(argv[0]);
- module->keywords = _("vector, import");
_("Creates a vector map from ASCII points file or ASCII vector file.");
Modified: grass/trunk/vector/v.in.db/main.c
--- grass/trunk/vector/v.in.db/main.c 2009-06-24 16:38:17 UTC (rev 38060)
+++ grass/trunk/vector/v.in.db/main.c 2009-06-24 16:56:59 UTC (rev 38061)
@@ -49,7 +49,10 @@
G_gisinit(argv[0]);
- module->keywords = _("vector, import, database, points");
+ G_add_keyword(_("points"));
_("Creates new vector (points) map from database table containing coordinates.");
Modified: grass/trunk/vector/v.in.dwg/main.c
--- grass/trunk/vector/v.in.dwg/main.c 2009-06-24 16:38:17 UTC (rev 38060)
+++ grass/trunk/vector/v.in.dwg/main.c 2009-06-24 16:56:59 UTC (rev 38061)
@@ -79,7 +79,8 @@
G_gisinit(argv[0]);
module->description = _("Converts DWG/DXF to GRASS vector map");
in_opt = G_define_standard_option(G_OPT_F_INPUT);
Modified: grass/trunk/vector/v.in.dxf/main.c
--- grass/trunk/vector/v.in.dxf/main.c 2009-06-24 16:38:17 UTC (rev 38060)
+++ grass/trunk/vector/v.in.dxf/main.c 2009-06-24 16:56:59 UTC (rev 38061)
@@ -61,7 +61,8 @@
G_gisinit(argv[0]);
_("Converts files in DXF format to GRASS vector map format.");
Modified: grass/trunk/vector/v.in.ogr/main.c
--- grass/trunk/vector/v.in.ogr/main.c 2009-06-24 16:38:17 UTC (rev 38060)
+++ grass/trunk/vector/v.in.ogr/main.c 2009-06-24 16:56:59 UTC (rev 38061)
@@ -100,7 +100,8 @@
G_gisinit(argv[0]);
module->description = _("Convert OGR vector layers to GRASS vector map.");
dsn_opt = G_define_option();
Modified: grass/trunk/vector/v.in.region/main.c
--- grass/trunk/vector/v.in.region/main.c 2009-06-24 16:38:17 UTC (rev 38060)
+++ grass/trunk/vector/v.in.region/main.c 2009-06-24 16:56:59 UTC (rev 38061)
@@ -35,7 +35,7 @@
G_gisinit(argv[0]);
module->description = _("Create a new vector from the current region.");
out_opt = G_define_standard_option(G_OPT_V_OUTPUT);
Modified: grass/trunk/vector/v.in.sites/main.c
--- grass/trunk/vector/v.in.sites/main.c 2009-06-24 16:38:17 UTC (rev 38060)
+++ grass/trunk/vector/v.in.sites/main.c 2009-06-24 16:56:59 UTC (rev 38061)
@@ -54,7 +54,9 @@
G_gisinit(argv[0]);
- module->keywords = _("vector, import, sites");
_("Converts a GRASS site_lists file into a vector map.");
Modified: grass/trunk/vector/v.info/main.c
--- grass/trunk/vector/v.info/main.c 2009-06-24 16:38:17 UTC (rev 38060)
+++ grass/trunk/vector/v.info/main.c 2009-06-24 16:56:59 UTC (rev 38061)
@@ -61,7 +61,9 @@
G_gisinit(argv[0]);
- module->keywords = _("vector, metadata, history");
+ G_add_keyword(_("history"));
_("Outputs basic information about a user-specified vector map.");
Modified: grass/trunk/vector/v.kcv/main.c
--- grass/trunk/vector/v.kcv/main.c 2009-06-24 16:38:17 UTC (rev 38060)
+++ grass/trunk/vector/v.kcv/main.c 2009-06-24 16:56:59 UTC (rev 38061)
@@ -72,7 +72,8 @@
dbString sql;
+ G_add_keyword(_("statistics"));
_("Randomly partition points into test/train sets.");
Modified: grass/trunk/vector/v.kernel/main.c
--- grass/trunk/vector/v.kernel/main.c 2009-06-24 16:38:17 UTC (rev 38060)
+++ grass/trunk/vector/v.kernel/main.c 2009-06-24 16:56:59 UTC (rev 38061)
@@ -105,7 +105,8 @@
G_gisinit(argv[0]);
- module->keywords = _("vector, kernel density");
+ G_add_keyword(_("kernel density"));
_("Generates a raster density map from vector points data using a moving 2D isotropic Gaussian kernel or "
"optionally generates a vector density map on vector network with a 1D kernel.");
Modified: grass/trunk/vector/v.label/main.c
--- grass/trunk/vector/v.label/main.c 2009-06-24 16:38:17 UTC (rev 38060)
+++ grass/trunk/vector/v.label/main.c 2009-06-24 16:56:59 UTC (rev 38061)
@@ -56,7 +56,8 @@
G_gisinit(argv[0]);
- module->keywords = _("vector, paint labels");
+ G_add_keyword(_("paint labels"));
_("Creates paint labels for a vector map from attached attributes.");
Modified: grass/trunk/vector/v.label.sa/main.c
--- grass/trunk/vector/v.label.sa/main.c 2009-06-24 16:38:17 UTC (rev 38060)
+++ grass/trunk/vector/v.label.sa/main.c 2009-06-24 16:56:59 UTC (rev 38061)
@@ -35,7 +35,8 @@
G_gisinit(argv[0]);
_("Create optimally placed labels for vector map(s)");
Modified: grass/trunk/vector/v.lrs/v.lrs.create/main.c
--- grass/trunk/vector/v.lrs/v.lrs.create/main.c 2009-06-24 16:38:17 UTC (rev 38060)
+++ grass/trunk/vector/v.lrs/v.lrs.create/main.c 2009-06-24 16:56:59 UTC (rev 38061)
@@ -118,7 +118,9 @@
G_gisinit(argv[0]);
- module->keywords = _("vector, LRS, networking");
+ G_add_keyword(_("LRS"));
+ G_add_keyword(_("networking"));
module->description = _("Create Linear Reference System");
in_lines_opt = G_define_standard_option(G_OPT_V_INPUT);
Modified: grass/trunk/vector/v.lrs/v.lrs.label/main.c
--- grass/trunk/vector/v.lrs/v.lrs.label/main.c 2009-06-24 16:38:17 UTC (rev 38060)
+++ grass/trunk/vector/v.lrs/v.lrs.label/main.c 2009-06-24 16:56:59 UTC (rev 38061)
@@ -99,7 +99,9 @@
G_gisinit(argv[0]);
module->description = _("Create stationing from input lines, "
"and linear reference system");
Modified: grass/trunk/vector/v.lrs/v.lrs.segment/main.c
--- grass/trunk/vector/v.lrs/v.lrs.segment/main.c 2009-06-24 16:38:17 UTC (rev 38060)
+++ grass/trunk/vector/v.lrs/v.lrs.segment/main.c 2009-06-24 16:56:59 UTC (rev 38061)
@@ -67,7 +67,9 @@
G_gisinit(argv[0]);
_("Creates points/segments from input lines, linear reference "
"system and positions read from stdin or a file.");
Modified: grass/trunk/vector/v.lrs/v.lrs.where/main.c
--- grass/trunk/vector/v.lrs/v.lrs.where/main.c 2009-06-24 16:38:17 UTC (rev 38060)
+++ grass/trunk/vector/v.lrs/v.lrs.where/main.c 2009-06-24 16:56:59 UTC (rev 38061)
@@ -54,7 +54,9 @@
G_gisinit(argv[0]);
_("Finds line id and real km+offset for given points in vector map "
"using linear reference system.");
Modified: grass/trunk/vector/v.mkgrid/main.c
--- grass/trunk/vector/v.mkgrid/main.c 2009-06-24 16:38:17 UTC (rev 38060)
+++ grass/trunk/vector/v.mkgrid/main.c 2009-06-24 16:56:59 UTC (rev 38061)
@@ -59,7 +59,7 @@
_("Creates a GRASS vector map of a user-defined grid.");
Modified: grass/trunk/vector/v.neighbors/main.c
--- grass/trunk/vector/v.neighbors/main.c 2009-06-24 16:38:17 UTC (rev 38060)
+++ grass/trunk/vector/v.neighbors/main.c 2009-06-24 16:56:59 UTC (rev 38061)
@@ -45,7 +45,9 @@
G_gisinit(argv[0]);
- module->keywords = _("vector, raster, aggregation");
+ G_add_keyword(_("aggregation"));
module->description = "Makes each cell value a "
"function of the attribute values assigned to the vector points or centroids "
"around it, and stores new cell values in an output raster map layer.";
Modified: grass/trunk/vector/v.net/main.c
--- grass/trunk/vector/v.net/main.c 2009-06-24 16:38:17 UTC (rev 38060)
+++ grass/trunk/vector/v.net/main.c 2009-06-24 16:56:59 UTC (rev 38061)
@@ -42,7 +42,8 @@
G_gisinit(argv[0]);
- module->keywords = _("vector, networking");
module->description = _("Performs network maintenance.");
define_options(&opt);
Modified: grass/trunk/vector/v.net.alloc/main.c
--- grass/trunk/vector/v.net.alloc/main.c 2009-06-24 16:38:17 UTC (rev 38060)
+++ grass/trunk/vector/v.net.alloc/main.c 2009-06-24 16:56:59 UTC (rev 38061)
@@ -57,7 +57,8 @@
G_gisinit(argv[0]);
module->label =
_("Allocate subnets for nearest centres (direction from centre).");
Modified: grass/trunk/vector/v.net.iso/main.c
--- grass/trunk/vector/v.net.iso/main.c 2009-06-24 16:38:17 UTC (rev 38060)
+++ grass/trunk/vector/v.net.iso/main.c 2009-06-24 16:56:59 UTC (rev 38061)
@@ -69,7 +69,8 @@
module->label = _("Splits net by cost isolines.");
_("Splits net to bands between cost isolines (direction from centre). "
"Centre node must be opened (costs >= 0). "
Modified: grass/trunk/vector/v.net.path/main.c
--- grass/trunk/vector/v.net.path/main.c 2009-06-24 16:38:17 UTC (rev 38060)
+++ grass/trunk/vector/v.net.path/main.c 2009-06-24 16:56:59 UTC (rev 38061)
@@ -37,7 +37,8 @@
G_gisinit(argv[0]);
module->description = _("Finds shortest path on vector network.");
input_opt = G_define_standard_option(G_OPT_V_INPUT);
Modified: grass/trunk/vector/v.net.salesman/main.c
--- grass/trunk/vector/v.net.salesman/main.c 2009-06-24 16:38:17 UTC (rev 38060)
+++ grass/trunk/vector/v.net.salesman/main.c 2009-06-24 16:56:59 UTC (rev 38061)
@@ -93,7 +93,8 @@
G_gisinit(argv[0]);
module->label =
_("Creates a cycle connecting given nodes (Traveling salesman problem).");
Modified: grass/trunk/vector/v.net.steiner/main.c
--- grass/trunk/vector/v.net.steiner/main.c 2009-06-24 16:38:17 UTC (rev 38060)
+++ grass/trunk/vector/v.net.steiner/main.c 2009-06-24 16:56:59 UTC (rev 38061)
@@ -341,7 +341,8 @@
G_gisinit(argv[0]);
module->label =
_("Create Steiner tree for the network and given terminals");
Modified: grass/trunk/vector/v.net.visibility/main.c
--- grass/trunk/vector/v.net.visibility/main.c 2009-06-24 16:38:17 UTC (rev 38060)
+++ grass/trunk/vector/v.net.visibility/main.c 2009-06-24 16:56:59 UTC (rev 38061)
@@ -42,7 +42,9 @@
- module->keywords = _("vector, path, visibility");
+ G_add_keyword(_("path"));
+ G_add_keyword(_("visibility"));
module->description = _("Visibility graph construction.");
/* define the arguments needed */
Modified: grass/trunk/vector/v.normal/main.c
--- grass/trunk/vector/v.normal/main.c 2009-06-24 16:38:17 UTC (rev 38060)
+++ grass/trunk/vector/v.normal/main.c 2009-06-24 16:56:59 UTC (rev 38061)
@@ -75,7 +75,8 @@
G_gisinit(argv[0]);
module->description = _("Tests for normality for points.");
parm.input = G_define_option();
parm.input->key = "map";
Modified: grass/trunk/vector/v.out.ascii/main.c
--- grass/trunk/vector/v.out.ascii/main.c 2009-06-24 16:38:17 UTC (rev 38060)
+++ grass/trunk/vector/v.out.ascii/main.c 2009-06-24 16:56:59 UTC (rev 38061)
@@ -42,7 +42,8 @@
G_gisinit(argv[0]);
- module->keywords = _("vector, export");
_("Converts a GRASS binary vector map to a GRASS ASCII vector map.");
Modified: grass/trunk/vector/v.out.dxf/main.c
--- grass/trunk/vector/v.out.dxf/main.c 2009-06-24 16:38:17 UTC (rev 38060)
+++ grass/trunk/vector/v.out.dxf/main.c 2009-06-24 16:56:59 UTC (rev 38061)
@@ -47,7 +47,8 @@
_("Exports GRASS vector map layers to DXF file format.");
Modified: grass/trunk/vector/v.out.ogr/main.c
--- grass/trunk/vector/v.out.ogr/main.c 2009-06-24 16:38:17 UTC (rev 38060)
+++ grass/trunk/vector/v.out.ogr/main.c 2009-06-24 16:56:59 UTC (rev 38061)
@@ -82,7 +82,8 @@
/* Module options */
_("Converts to one of the supported OGR vector formats.");
Modified: grass/trunk/vector/v.out.pov/main.c
--- grass/trunk/vector/v.out.pov/main.c 2009-06-24 16:38:17 UTC (rev 38060)
+++ grass/trunk/vector/v.out.pov/main.c 2009-06-24 16:56:59 UTC (rev 38061)
@@ -39,7 +39,8 @@
"Converts to POV-Ray format, GRASS x,y,z -> POV-Ray x,z,y";
Modified: grass/trunk/vector/v.out.svg/main.c
--- grass/trunk/vector/v.out.svg/main.c 2009-06-24 16:38:17 UTC (rev 38060)
+++ grass/trunk/vector/v.out.svg/main.c 2009-06-24 16:56:59 UTC (rev 38061)
@@ -69,7 +69,8 @@
/* parse command-line */
module->description = _("Exports a GRASS vector map to SVG.");
Modified: grass/trunk/vector/v.out.vtk/main.c
--- grass/trunk/vector/v.out.vtk/main.c 2009-06-24 16:38:17 UTC (rev 38060)
+++ grass/trunk/vector/v.out.vtk/main.c 2009-06-24 16:56:59 UTC (rev 38061)
@@ -44,7 +44,7 @@
G_gisinit(argv[0]);
_("Converts a GRASS binary vector map to VTK ASCII output.");
Modified: grass/trunk/vector/v.overlay/main.c
--- grass/trunk/vector/v.overlay/main.c 2009-06-24 16:38:17 UTC (rev 38060)
+++ grass/trunk/vector/v.overlay/main.c 2009-06-24 16:56:59 UTC (rev 38061)
@@ -51,7 +51,8 @@
pre[1] = "b";
module->description = _("Overlays two vector maps.");
in_opt[0] = G_define_standard_option(G_OPT_V_INPUT);
Modified: grass/trunk/vector/v.parallel/main.c
--- grass/trunk/vector/v.parallel/main.c 2009-06-24 16:38:17 UTC (rev 38060)
+++ grass/trunk/vector/v.parallel/main.c 2009-06-24 16:56:59 UTC (rev 38061)
@@ -40,7 +40,8 @@
G_gisinit(argv[0]);
module->description = _("Creates parallel line to input vector lines.");
Modified: grass/trunk/vector/v.patch/main.c
--- grass/trunk/vector/v.patch/main.c 2009-06-24 16:38:17 UTC (rev 38060)
+++ grass/trunk/vector/v.patch/main.c 2009-06-24 16:56:59 UTC (rev 38061)
@@ -65,7 +65,7 @@
G_gisinit(argv[0]);
module->description = _("Create a new vector map layer "
"by combining other vector map layers.");
Modified: grass/trunk/vector/v.perturb/main.c
--- grass/trunk/vector/v.perturb/main.c 2009-06-24 16:38:17 UTC (rev 38060)
+++ grass/trunk/vector/v.perturb/main.c 2009-06-24 16:56:59 UTC (rev 38061)
@@ -69,7 +69,7 @@
G_gisinit(argv[0]);
_("Random location perturbations of GRASS vector points");
Modified: grass/trunk/vector/v.proj/main.c
--- grass/trunk/vector/v.proj/main.c 2009-06-24 16:38:17 UTC (rev 38060)
+++ grass/trunk/vector/v.proj/main.c 2009-06-24 16:56:59 UTC (rev 38061)
@@ -60,7 +60,8 @@
G_gisinit(argv[0]);
- module->keywords = _("vector, projection");
+ G_add_keyword(_("projection"));
module->description = _("Allows projection conversion of vector maps.");
Modified: grass/trunk/vector/v.qcount/main.c
--- grass/trunk/vector/v.qcount/main.c 2009-06-24 16:38:17 UTC (rev 38060)
+++ grass/trunk/vector/v.qcount/main.c 2009-06-24 16:56:59 UTC (rev 38061)
@@ -64,7 +64,8 @@
G_gisinit(argv[0]);
module->description = _("Indices for quadrat counts of sites lists.");
Modified: grass/trunk/vector/v.random/main.c
--- grass/trunk/vector/v.random/main.c 2009-06-24 16:38:17 UTC (rev 38060)
+++ grass/trunk/vector/v.random/main.c 2009-06-24 16:56:59 UTC (rev 38061)
@@ -81,7 +81,8 @@
G_gisinit(argv[0]);
module->description = _("Randomly generate a 2D/3D vector points map.");
parm.output = G_define_standard_option(G_OPT_V_OUTPUT);
Modified: grass/trunk/vector/v.reclass/main.c
--- grass/trunk/vector/v.reclass/main.c 2009-06-24 16:38:17 UTC (rev 38060)
+++ grass/trunk/vector/v.reclass/main.c 2009-06-24 16:56:59 UTC (rev 38061)
@@ -61,7 +61,9 @@
G_gisinit(argv[0]);
- module->keywords = _("vector, reclass, attributes");
+ G_add_keyword(_("reclass"));
+ G_add_keyword(_("attributes"));
_("Changes vector category values for an existing vector map "
"according to results of SQL queries or a value in attribute table column.");
Modified: grass/trunk/vector/v.sample/main.c
--- grass/trunk/vector/v.sample/main.c 2009-06-24 16:38:17 UTC (rev 38060)
+++ grass/trunk/vector/v.sample/main.c 2009-06-24 16:56:59 UTC (rev 38061)
@@ -83,7 +83,7 @@
G_gisinit(argv[0]);
_("Samples a raster map at vector point locations.");
Modified: grass/trunk/vector/v.segment/main.c
--- grass/trunk/vector/v.segment/main.c 2009-06-24 16:38:17 UTC (rev 38060)
+++ grass/trunk/vector/v.segment/main.c 2009-06-24 16:56:59 UTC (rev 38061)
@@ -49,7 +49,8 @@
G_gisinit(argv[0]);
_("Creates points/segments from input vector lines and positions.");
Modified: grass/trunk/vector/v.select/main.c
--- grass/trunk/vector/v.select/main.c 2009-06-24 16:38:17 UTC (rev 38060)
+++ grass/trunk/vector/v.select/main.c 2009-06-24 16:56:59 UTC (rev 38061)
@@ -49,7 +49,8 @@
pre[1] = "b";
- module->keywords = _("vector, spatial query");
+ G_add_keyword(_("spatial query"));
_("Selects features from vector map (A) by features from other vector map (B).");
Modified: grass/trunk/vector/v.split/main.c
--- grass/trunk/vector/v.split/main.c 2009-06-24 16:38:17 UTC (rev 38060)
+++ grass/trunk/vector/v.split/main.c 2009-06-24 16:56:59 UTC (rev 38061)
@@ -39,7 +39,8 @@
G_gisinit(argv[0]);
module->description = "Split lines to shorter segments.";
Modified: grass/trunk/vector/v.support/main.c
--- grass/trunk/vector/v.support/main.c 2009-06-24 16:38:17 UTC (rev 38060)
+++ grass/trunk/vector/v.support/main.c 2009-06-24 16:56:59 UTC (rev 38061)
@@ -36,7 +36,8 @@
- module->keywords = _("vector, metadata");
+ G_add_keyword(_("metadata"));
module->description = _("Updates vector map metadata.");
/* Define the different options as defined in gis.h */
Modified: grass/trunk/vector/v.surf.idw/main.c
--- grass/trunk/vector/v.surf.idw/main.c 2009-06-24 16:38:17 UTC (rev 38060)
+++ grass/trunk/vector/v.surf.idw/main.c 2009-06-24 16:56:59 UTC (rev 38061)
@@ -84,7 +84,8 @@
G_gisinit(argv[0]);
_("Surface interpolation from vector point data by Inverse "
"Distance Squared Weighting.");
Modified: grass/trunk/vector/v.surf.rst/main.c
--- grass/trunk/vector/v.surf.rst/main.c 2009-06-24 16:38:17 UTC (rev 38060)
+++ grass/trunk/vector/v.surf.rst/main.c 2009-06-24 16:56:59 UTC (rev 38061)
@@ -145,7 +145,7 @@
G_gisinit(argv[0]);
_("Spatial approximation and topographic analysis from given "
"point or isoline data in vector format to floating point "
Modified: grass/trunk/vector/v.to.3d/main.c
--- grass/trunk/vector/v.to.3d/main.c 2009-06-24 16:38:17 UTC (rev 38060)
+++ grass/trunk/vector/v.to.3d/main.c 2009-06-24 16:56:59 UTC (rev 38061)
@@ -33,7 +33,9 @@
G_gisinit(argv[0]);
- module->keywords = _("vector, transformation, 3D");
+ G_add_keyword(_("transformation"));
_("Performs transformation of 2D vector features to 3D.");
Modified: grass/trunk/vector/v.to.db/main.c
--- grass/trunk/vector/v.to.db/main.c 2009-06-24 16:38:17 UTC (rev 38060)
+++ grass/trunk/vector/v.to.db/main.c 2009-06-24 16:56:59 UTC (rev 38061)
@@ -33,7 +33,9 @@
G_gisinit(argv[0]);
module->description = _("Populates database values from vector features.");
Modified: grass/trunk/vector/v.to.points/main.c
--- grass/trunk/vector/v.to.points/main.c 2009-06-24 16:38:17 UTC (rev 38060)
+++ grass/trunk/vector/v.to.points/main.c 2009-06-24 16:56:59 UTC (rev 38061)
@@ -169,7 +169,8 @@
G_gisinit(argv[0]);
_("Create points along input lines in new vector with 2 layers.");
Modified: grass/trunk/vector/v.to.rast/main.c
--- grass/trunk/vector/v.to.rast/main.c 2009-06-24 16:38:17 UTC (rev 38060)
+++ grass/trunk/vector/v.to.rast/main.c 2009-06-24 16:56:59 UTC (rev 38061)
@@ -36,7 +36,9 @@
G_gisinit(argv[0]);
- module->keywords = _("vector, raster, conversion");
+ G_add_keyword(_("conversion"));
module->description = _("Converts a binary GRASS vector map "
"into a GRASS raster map .");
Modified: grass/trunk/vector/v.to.rast3/main.c
--- grass/trunk/vector/v.to.rast3/main.c 2009-06-24 16:38:17 UTC (rev 38060)
+++ grass/trunk/vector/v.to.rast3/main.c 2009-06-24 16:56:59 UTC (rev 38061)
@@ -42,7 +42,9 @@
dbCatValArray cvarr;
- module->keywords = _("vector, volume, conversion");
"(only points) layer into a 3D GRASS raster map layer.");
Modified: grass/trunk/vector/v.transform/main.c
--- grass/trunk/vector/v.transform/main.c 2009-06-24 16:38:17 UTC (rev 38060)
+++ grass/trunk/vector/v.transform/main.c 2009-06-24 16:56:59 UTC (rev 38061)
@@ -80,7 +80,8 @@
G_gisinit(argv[0]);
- module->keywords = _("vector, transformation");
_("Performs an affine transformation (shift, scale and rotate, "
"or GPCs) on vector map.");
Modified: grass/trunk/vector/v.type/main.c
--- grass/trunk/vector/v.type/main.c 2009-06-24 16:38:17 UTC (rev 38060)
+++ grass/trunk/vector/v.type/main.c 2009-06-24 16:56:59 UTC (rev 38061)
@@ -43,7 +43,8 @@
#endif
module->description = _("Change the type of geometry elements.");
Modified: grass/trunk/vector/v.univar/main.c
--- grass/trunk/vector/v.univar/main.c 2009-06-24 16:38:17 UTC (rev 38060)
+++ grass/trunk/vector/v.univar/main.c 2009-06-24 16:56:59 UTC (rev 38061)
@@ -61,7 +61,8 @@
int perc;
_("Calculates univariate statistics for attribute. Variance and standard "
"deviation is calculated only for points if specified.");
Modified: grass/trunk/vector/v.vol.rst/main.c
--- grass/trunk/vector/v.vol.rst/main.c 2009-06-24 16:38:17 UTC (rev 38060)
+++ grass/trunk/vector/v.vol.rst/main.c 2009-06-24 16:56:59 UTC (rev 38061)
@@ -237,7 +237,7 @@
G_gisinit(argv[0]);
_("Interpolates point data to a G3D grid volume using "
"regularized spline with tension (RST) algorithm.");
Modified: grass/trunk/vector/v.voronoi/main.c
--- grass/trunk/vector/v.voronoi/main.c 2009-06-24 16:38:17 UTC (rev 38060)
+++ grass/trunk/vector/v.voronoi/main.c 2009-06-24 16:56:59 UTC (rev 38061)
@@ -114,7 +114,7 @@
G_gisinit(argv[0]);
module->description = _("Creates a Voronoi diagram from an input vector "
"map containing points or centroids.");
Modified: grass/trunk/vector/v.what/main.c
--- grass/trunk/vector/v.what/main.c 2009-06-24 16:38:17 UTC (rev 38060)
+++ grass/trunk/vector/v.what/main.c 2009-06-24 16:56:59 UTC (rev 38061)
@@ -50,7 +50,8 @@
G_gisinit(argv[0]);
- module->keywords = _("vector, querying");
+ G_add_keyword(_("querying"));
module->description = _("Queries a vector map layer at given locations.");
opt1 = G_define_standard_option(G_OPT_V_MAP);
Modified: grass/trunk/vector/v.what.rast/main.c
--- grass/trunk/vector/v.what.rast/main.c 2009-06-24 16:38:17 UTC (rev 38060)
+++ grass/trunk/vector/v.what.rast/main.c 2009-06-24 16:56:59 UTC (rev 38061)
@@ -77,7 +77,9 @@
G_gisinit(argv[0]);
- module->keywords = _("vector, raster, attribute table");
_("Uploads raster values at positions of vector points to the table.");
Modified: grass/trunk/visualization/nviz/src/nviz_init.c
--- grass/trunk/visualization/nviz/src/nviz_init.c 2009-06-24 16:38:17 UTC (rev 38060)
+++ grass/trunk/visualization/nviz/src/nviz_init.c 2009-06-24 16:56:59 UTC (rev 38061)
@@ -50,7 +50,9 @@
- module->keywords = _("raster, vector, visualization");
+ G_add_keyword(_("visualization"));
_("nviz - Visualization and animation tool for GRASS data.");
Modified: grass/trunk/visualization/nviz2/cmd/main.c
--- grass/trunk/visualization/nviz2/cmd/main.c 2009-06-24 16:38:17 UTC (rev 38060)
+++ grass/trunk/visualization/nviz2/cmd/main.c 2009-06-24 16:56:59 UTC (rev 38061)
@@ -43,7 +43,10 @@
G_gisinit(argv[0]);
- module->keywords = _("visualization, raster, vector, raster3d");
module->description = _("Experimental NVIZ CLI prototype.");
params = (struct GParams *)G_malloc(sizeof(struct GParams));
Modified: grass/trunk/visualization/ximgview/main.c
--- grass/trunk/visualization/ximgview/main.c 2009-06-24 16:38:17 UTC (rev 38060)
+++ grass/trunk/visualization/ximgview/main.c 2009-06-24 16:56:59 UTC (rev 38061)
@@ -287,7 +287,7 @@
G_gisinit(argv[0]);
- module->keywords = _("display");
+ G_add_keyword(_("display"));
module->description = _("View BMP images from the PNG driver.");
opt.image = G_define_option();
