[GRASS-SVN] r38070 - grass-addons/vector/v.autokrige
svn_grass at osgeo.org
Thu Jun 25 08:46:21 EDT 2009
Author: mathieug
Date: 2009-06-25 08:46:21 -0400 (Thu, 25 Jun 2009)
New Revision: 38070
Added:
grass-addons/vector/v.autokrige/v_autokrige.py
Removed:
grass-addons/vector/v.autokrige/v.autokrige.py
renamed module. Added local kriging options.
Deleted: grass-addons/vector/v.autokrige/v.autokrige.py
--- grass-addons/vector/v.autokrige/v.autokrige.py 2009-06-25 08:27:18 UTC (rev 38069)
+++ grass-addons/vector/v.autokrige/v.autokrige.py 2009-06-25 12:46:21 UTC (rev 38070)
@@ -1,421 +0,0 @@
-#!/usr/bin/python
-#-*- coding: utf-8 -*-
-# MODULE: v.autokrige.py
-# AUTHOR(S): Mathieu Grelier (greliermathieu at gmail.com)
-# PURPOSE: automatic kriging interpolation from vector point data
-# REQUIREMENTS:
-# - statistical software : R (http://www.r-project.org/)
-# - R packages :
-# - spgrass6 (http://cran.r-project.org/web/packages/spgrass6/index.html)
-# - automap (http://intamap.geo.uu.nl/~paul/Downloads.html) packages
-# - imagemagick : convert program
-# COPYRIGHT: (C) 2009 Mathieu Grelier
-# This program is free software under the GNU General Public
-# License (>=v2). Read the file COPYING that comes with GRASS
-# for details.
-#%Module
-#% description: automatic kriging interpolation from vector point data
-#% keywords: kriging, autokrige, RGrass
-#%End
-#%option
-#% key: input
-#% type: string
-#% gisprompt: old,vector,vector
-#% description: Name of the vector containing sites data (values to interpolate) and geometry. Must not contain any null values.
-#% required : yes
-#%end
-#%option
-#% key: column
-#% type: string
-#% description: Attribute column to interpolate (must be numeric).
-#% required : yes
-#%end
-#%option
-#% key: nbcell
-#% type: integer
-#% answer: 100
-#% description: number of cell of the created grid. If set, GRASS region is affected.
-#% required : no
-#%end
-#%option
-#% key: models
-#% type: string
-#% options: Exp,Sph,Gau,Mat
-#% multiple : yes
-#% answer:
-#% description: List of variogram models to be automatically tested. Select only one to fix the model.
-#% required : no
-#%end
-#%option
-#% key: range
-#% type: integer
-#% description: Range value. Automatically fixed if not set.
-#% required : no
-#%end
-#%option
-#% key: nugget
-#% type: double
-#% description: Nugget value. Automatically fixed if not set
-#% required : no
-#%end
-#%option
-#% key: sill
-#% type: double
-#% description: Sill value. Automatically fixed if not set
-#% required : no
-#%end
-#%option
-#% key: output
-#% type: string
-#% answer: autokrige
-#% description: Name of the raster to produce
-#% required : yes
-#%end
-#%option
-#% key: colormap
-#% type: string
-#% answer: bcyor
-#% description: Colormap file to use to colorize the raster
-#% required : no
-#%end
-#%flag
-#% key: v
-#% description: Create variance raster also
-#%end
-#%flag
-#% key: r
-#% description: Don't set region from sites extent. Region would have been previously set in grass.
-#%end
-#%flag
-#% key: l
-#% description: Log R output to v.autokrige.py.log.
-#%end
-import sys
-import os
-import re
-from subprocess import Popen, PIPE
-import traceback
-##see http://trac.osgeo.org/grass/browser/grass/trunk/lib/python
-from grass import core as grass
-##only needed to use debugger. See http://aspn.activestate.com/ASPN/Downloads/Komodo/RemoteDebugging
-from dbgp.client import brk
-class AutoKrige():
- def __init__(self, options, flags):
- ##options
- self.input = options['input']
- self.column = options['column']
- self.nbcell = options['nbcell'] if options['nbcell'].strip() != '' else None
- self.models = options['models'] if options['models'].strip() != '' else None
- self.range = options['range'] if options['range'].strip() != '' else None
- self.nugget = options['nugget'] if options['nugget'].strip() != '' else None
- self.sill = options['sill'] if options['sill'].strip() != '' else None
- self.output = options['output']
- self.colormap = options['colormap'] if options['colormap'].strip() != '' else 'bcyor'
- ##flags
- self.varianceFlag = True if flags['v'] is True else False
- self.regionFlag = True if flags['r'] is True else False
- self.logROutput = True if flags['l'] is True else False
- ##others
- self.RscriptFile = None
- logfilename = 'v.autokrige.py.log'
- self.logfile = os.path.join(os.getenv('LOGDIR'),logfilename) if os.getenv('LOGDIR') else logfilename
- def __checkLayers(self, input, output):
- Preliminary checks before starting kriging.
- Note : for this to work with grass6.3, in find_file function from core.py,
- command should be (n flag removed because 6.4 specific):
- s = read_command("g.findfile", element = element, file = name, mapset = mapset)
- ##Test for input vector map.
- testInput = grass.find_file(input, element = 'vector')
- if testInput['fullname'] == '':
- raise AutoKrigeError("vector map " + input + " not found in mapset search path.")
- ##Test if output raster map already exists.
- testOutput = grass.find_file(output, element = 'cell')
- if testOutput['fullname'] != '':
- if not grass.overwrite() is True:
- raise AutoKrigeError("raster map " + output + " already exists in mapset search path. \n \
-Use the --o flag to overwrite.")
- else:
- print "Warning: raster map " + output + " will be overwritten."
- ##Test also variance raster.
- if self.varianceFlag is True:
- testVarOutput = grass.find_file(output + '_var', element = 'cell')
- if testVarOutput['fullname'] != '':
- else:
- print "Warning: raster map " + output + '_var' + " will be overwritten."
- def __getGridCellSize(self, input, nbcell):
- """Define kriged grid cell size. Raster resolution but also computation time depends on it.
- We take region resolution as cell size but we can fix this resolution with the nbcell parameter.
- Only one value is needed because the R script use square cells."""
- if self.regionFlag is not True:
- grass.run_command("g.region", vect = input)
- if nbcell is not None:
- self.__fixRegionResFromNumberOfCells(nbcell)
- regionParams = grass.region()
- cellsize = float(regionParams['nsres']) if float(regionParams['nsres']) > float(regionParams['ewres']) \
- else float(regionParams['ewres'])
- return cellsize
- def __fixRegionResFromNumberOfCells(self, nbcell=100):
- """Adjust one of the two region dimensions so that we have a maximum of 'nbcell' cells in both."""
- nsResForGivenNbCell = (float(regionParams['n'])- float(regionParams['s'])) / float(nbcell)
- ewResForGivenNbCell = (float(regionParams['e'])- float(regionParams['w'])) / float(nbcell)
- tmpRegionRes = nsResForGivenNbCell if nsResForGivenNbCell > ewResForGivenNbCell else ewResForGivenNbCell
- grass.use_temp_region
- grass.run_command("g.region", res = tmpRegionRes)
- def __prepareRScriptArguments(self, cellsize, models=None, range=None, nugget=None, sill=None):
- """Group all R arguments in a dictionnary"""
- ##1)Models
- ##The script will try to create the R argument as expected in the R script,
- ##to avoid string manipulations with R.
- RargumentsDict = {}
- if models is None:
- ##it is important not to have any space between commas and following slashes
- RargumentsDict['models']='c(\\"Sph\\",\\"Exp\\",\\"Gau\\",\\"Mat\\")'
- else:
- ##conversion to R arguments in the expected format, starting from model1,model2...
- ##add c(" at the beginning and add ") at the end
- RargumentsDict['models'] = 'c(\\"' + models + '\\")'
- ##replace commas by \",\"
- p = re.compile(',')
- RargumentsDict['models'] = p.sub('\\",\\"',RargumentsDict['models'])
- ##2)Range, nugget, sill
- RargumentsDict['range'] = range if range is not None else 'NA'
- RargumentsDict['nugget'] = nugget if nugget is not None else 'NA'
- RargumentsDict['sill'] = sill if sill is not None else 'NA'
- return RargumentsDict
- def __writeRScript(self):
- RscriptFile = grass.tempfile()
- fileHandle = open(RscriptFile, 'a')
- script = """
- options(echo = FALSE)
- args <- commandArgs()
- ##start at index 5 because first arguments are R options
- cat("arguments:","\n")
- sitesG <- args[5]
- column <- args[6]
- rastername <- args[7]
- cellsize <- as.numeric(args[8])
- models <- args[9]
- modelslist <- eval(parse(text = models))
- range <- as.numeric(args[10])
- if(args[10] == "NA") {nugget = NA} else {nugget <- as.numeric(args[11])}
- if(args[12] == "NA") {sill = NA} else {sill <- as.numeric(args[12])}
- writevarrast <- as.logical(args[13])
- ##print arguments
- cat("sitesG:",sitesG,"\n")
- cat("column:",column,"\n")
- cat("rastername:",rastername,"\n")
- cat("cellsize:",cellsize,"\n")
- cat("modelslist:",modelslist,"\n")
- cat("range:",range,"\n")
- cat("nugget:",nugget,"\n")
- cat("sill:",sill,"\n")
- cat("writevarrast:",writevarrast,"\n")
- ##variogram plot function
- plot.autoKrigeVariogramAndFittedModel = function(x, sp.layout = NULL, ...)
- ##Function adapted from plot.autoKrige in automap package.
- ##Prints only the variogram and model as we already have the map output in GRASS.
- library(lattice)
- shift = 0.03
- labels = as.character(x$exp_var$np)
- vario = xyplot(gamma ~ dist, data = x$exp_var, panel = automap:::autokrige.vgm.panel,
- labels = labels, shift = shift, model = x$var_model,# subscripts = TRUE,
- direction = c(x$exp_var$dir.hor[1], x$exp_var$dir.ver[1]),
- ylim = c(min(0, 1.04 * min(x$exp_var$gamma)), 1.04 * max(x$exp_var$gamma)),
- xlim = c(0, 1.04 * max(x$exp_var$dist)), xlab = "Distance", ylab = "Semi-variance",
- main = "Experimental variogram and fitted variogram model", mode = "direct",...)
- print(vario, position = c(0,0,1,1))
- ##autokrige script
- tryCatch({
- ##libraries
- library(spgrass6)
- library(automap)
- ##retrieve sites in a SpatialPointsDataFrame object
- cat("retrieve sites from GRASS","\n")
- sitesR <- readVECT6(sitesG, ignore.stderr = F)
- cat("retrieve metadata","\n")
- G <- gmeta6()
- cat("GridTopology creation","\n")
- grd <- gmeta2grd()
- ##this is necessary to ensure that we have square cells
- ##the more this number is small, the more the kriged map resolution is high
- slot(grd, "cellsize") <- c(cellsize, cellsize)
- ##creation of another grid object: SpatialGridDataFrame
- ##this is a matrix whose values receive spatial coordinates associated to interpolated values
- ##matrix size must be equal to the number of GridTopology cells
- ##we create first a classical data.frame
- data <- data.frame(list(k=rep(1,(floor(G$cols)*floor(G$rows)))))
- cat("SpatialGridDataFrame creation","\n")
- mask_SG <- SpatialGridDataFrame(grd, data=data, CRS(G$proj4))
- ##add coordinates system
- attr(sitesR, "proj4string") <-CRS(G$proj4)
- cat("ordinary kriging","\n")
- #[note : ajouter une option pour permettre de réaliser le krigeage universel]
- kriging_result = autoKrige(as.formula(paste(column,"~",1)), sitesR[column], mask_SG, model = modelslist, fix.values = c(nugget,range,sill), debug.level=-1, verbose=TRUE)
- cat("send raster to GRASS","\n")
- writeRAST6(kriging_result$krige_output,rastername,zcol=1,NODATA=0)
- cat("Generated",rastername," "); cat("", sep="\n")
- if(writevarrast == T) {
- varrastername = paste(rastername, "_var", sep = "")
- writeRAST6(kriging_result$krige_output,varrastername,zcol=2,NODATA=0)
- cat("Generated",varrastername," "); cat("", sep="\n")
- ##plot experimental and model variogram
- cat("plot kriging results","\n")
- ##see R FAQ 7.19. Plotting to png can produce errors if R version < 2.7
- ##we use the pdf driver then we will convert to png
- options(device="pdf")
- try(plot.autoKrigeVariogramAndFittedModel(kriging_result))
- cat("R script done","\n")
- quit(status = 0)
- }, interrupt = function(ex) {
- cat("An interrupt was detected while executing R script.\n");
- quit(status = 4)
- error = function(ex) {
- cat("Error while executing R script.\n");
- cat(conditionMessage(ex), "\n")
- quit(status = 5)
- ) ## tryCatch()
- fileHandle.write(script)
- fileHandle.close()
- return RscriptFile
- def __finalize(self, output, colormap):
- Group operations non-related to kriging.
- We don't want to stop execution if an error occurs here.
- try:
- ##convert plot to png
- self.__execShellCommand('convert -alpha off Rplots.pdf autokrige_result.png')
- grass.try_remove('Rplots.pdf')
- ##apply colormap
- grass.run_command("r.colors", map = output, rules = colormap, quiet = True)
- grass.run_command("r.colors", map = output + '_var', rules = colormap, quiet = True)
- except:
- pass
- def __execShellCommand(self, command, stderrRedirection=False, logFile=False):
- """General purpose function, maybe should be added in some way to core.py """
- if logFile is not False:
- command = command + ' >> ' + logFile
- if stderrRedirection is True:
- command = command + " 2>&1"
- p = Popen(command, shell=True, stdout=PIPE)
- retcode = p.wait()
- com = p.communicate()
- if retcode == 0:
- return com[0]
- else:
- errorMessage = ''
- for elem in com:
- errorMessage += str(elem) + "\n"
- raise AutoKrigeError(errorMessage)
- def runAutoKrige(self):
- """Autokrige class public method"""
- ##1)Necessary checks
- self.__checkLayers(self.input, self.output)
- ##2)Adjust interpolation resolution
- cellsize = self.__getGridCellSize(self.input, self.nbcell)
- ##3)Put all R arguments in a dict
- RargsDict = self.__prepareRScriptArguments(cellsize, self.models, self.range, \
- self.nugget, self.sill)
- ##4)Execute R from GRASS
- self.RscriptFile = self.__writeRScript()
- ##spgrass6 cause : column name in R has only the 10 first characters of the original column name
- ##may change with future versions of spgrass6
- Rcolumnname = self.column[0:10]
- writeVarRast = 'T' if self.varianceFlag is True else 'F'
- print "RGrass is working..."
- autoKrigeCommand = 'R --vanilla --slave --args ' + self.input + ' ' + Rcolumnname + ' ' + \
- self.output + ' ' + str(cellsize) + ' "' + RargsDict['models'] + '" ' + \
- RargsDict['range'] + ' ' + RargsDict['nugget'] + ' ' + RargsDict['sill'] \
- + ' ' + writeVarRast + ' < "' + self.RscriptFile + '"'
- logFileArg = self.logfile if self.logROutput is True else False
- self.__execShellCommand(autoKrigeCommand, stderrRedirection=True, logFile=logFileArg)
- ##5)Finalize output
- self.__finalize(self.output, self.colormap)
-class AutoKrigeError(Exception):
- """Errors specific to Autokrige class"""
- def __init__(self, message=''):
- self.details = '\nDetails:\n'
- exceptionType, exceptionValue, exceptionTraceback = sys.exc_info()
- self.details += repr(traceback.format_exception(exceptionType, exceptionValue, exceptionTraceback))
- self.message = message + "\n" + self.details
-def main():
- exitStatus = 0
- try:
- autoKrige = AutoKrige(options, flags)
- autoKrige.runAutoKrige()
- except AutoKrigeError, e1:
- print >> sys.stderr, "Error \n:", e1.message
- exitStatus = 1
- except:
- errorMessage = "Unexpected error \n:"
- print >> sys.stderr, errorMessage
- traceback.print_exc()
- exitStatus = 1
- else:
- print "Done"
- finally:
- grass.try_remove(autoKrige.RscriptFile)
- sys.exit(exitStatus)
-if __name__ == "__main__":
- ### DEBUG : uncomment to start local debugging session
- #brk(host="localhost", port=9000)
- if grass.find_program('R'):
- options, flags = grass.parser()
- main()
- else:
- print "R required, please install R first"
Added: grass-addons/vector/v.autokrige/v_autokrige.py
--- grass-addons/vector/v.autokrige/v_autokrige.py (rev 0)
+++ grass-addons/vector/v.autokrige/v_autokrige.py 2009-06-25 12:46:21 UTC (rev 38070)
@@ -0,0 +1,435 @@
+#!/usr/bin/python
+#-*- coding: utf-8 -*-
+# MODULE: v_autokrige.py
+# AUTHOR(S): Mathieu Grelier (greliermathieu at gmail.com)
+# PURPOSE: automatic kriging interpolation from vector point data
+# REQUIREMENTS:
+# - statistical software : R (http://www.r-project.org/)
+# - R packages :
+# - spgrass6 (http://cran.r-project.org/web/packages/spgrass6/index.html)
+# - automap (http://intamap.geo.uu.nl/~paul/Downloads.html) packages
+# - optionnal :
+# - imagemagick : convert program
+# COPYRIGHT: (C) 2009 Mathieu Grelier
+# This program is free software under the GNU General Public
+# License (>=v2). Read the file COPYING that comes with GRASS
+# for details.
+#%Module
+#% description: automatic kriging interpolation from vector point data
+#% keywords: kriging, autokrige, RGrass
+#%End
+#%option
+#% key: input
+#% type: string
+#% gisprompt: old,vector,vector
+#% description: Name of the vector containing sites data (values to interpolate) and geometry. Must not contain any null values.
+#% required : yes
+#%end
+#%option
+#% key: column
+#% type: string
+#% description: Attribute column to interpolate (must be numeric).
+#% required : yes
+#%end
+#%option
+#% key: nbcell
+#% type: integer
+#% answer: 100
+#% description: number of cell of the created grid. If set, GRASS region is affected.
+#% required : no
+#%end
+#%option
+#% key: models
+#% type: string
+#% options: Exp,Sph,Gau,Mat
+#% multiple : yes
+#% answer:
+#% description: List of variogram models to be automatically tested. Select only one to fix the model.
+#% required : no
+#%end
+#%option
+#% key: range
+#% type: integer
+#% description: Range value. Automatically fixed if not set.
+#% required : no
+#%end
+#%option
+#% key: nugget
+#% type: double
+#% description: Nugget value. Automatically fixed if not set
+#% required : no
+#%end
+#%option
+#% key: sill
+#% type: double
+#% description: Sill value. Automatically fixed if not set
+#% required : no
+#%end
+#%option
+#% key: nmax
+#% type: double
+#% description: Local kriging. Number of nearest observations that should be used for a kriging prediction. Default : all observations are used.
+#% required : no
+#%end
+#%option
+#% key: maxdist
+#% type: double
+#% description: Local kriging. Maximum distance for observations from the prediction location to be included for prediction. Default : no limitation.
+#% required : no
+#%end
+#%option
+#% key: output
+#% type: string
+#% answer: autokrige
+#% description: Name of the raster to produce
+#% required : yes
+#%end
+#%option
+#% key: colormap
+#% type: string
+#% answer: bcyor
+#% description: Colormap file to use to colorize the raster
+#% required : no
+#%end
+#%flag
+#% key: v
+#% description: Create variance raster also
+#%end
+#%flag
+#% key: r
+#% description: Don't set region from sites extent. Region would have been previously set in grass.
+#%end
+#%flag
+#% key: l
+#% description: Log R output to v_autokrige.py.log.
+#%end
+import sys
+import os
+import re
+from subprocess import Popen, PIPE
+import traceback
+##see http://trac.osgeo.org/grass/browser/grass/trunk/lib/python
+from grass import core as grass
+##only needed to use debugger. See http://aspn.activestate.com/ASPN/Downloads/Komodo/RemoteDebugging
+from dbgp.client import brk
+class AutoKrige():
+ def __init__(self, options, flags):
+ ##options
+ self.input = options['input']
+ self.column = options['column']
+ self.nbcell = options['nbcell'] if options['nbcell'].strip() != '' else None
+ self.models = options['models'] if options['models'].strip() != '' else None
+ self.range = options['range'] if options['range'].strip() != '' else 'NA'
+ self.nugget = options['nugget'] if options['nugget'].strip() != '' else 'NA'
+ self.sill = options['sill'] if options['sill'].strip() != '' else 'NA'
+ self.nmax = options['nmax'] if options['nmax'].strip() != '' else 'Inf'
+ self.maxdist = options['maxdist'] if options['maxdist'].strip() != '' else 'Inf'
+ self.output = options['output']
+ self.colormap = options['colormap'] if options['colormap'].strip() != '' else 'bcyor'
+ ##flags
+ self.varianceFlag = True if flags['v'] is True else False
+ self.regionFlag = True if flags['r'] is True else False
+ self.logROutput = True if flags['l'] is True else False
+ ##others
+ self.RscriptFile = None
+ logfilename = 'v_autokrige.py.log'
+ self.logfile = os.path.join(os.getenv('LOGDIR'),logfilename) if os.getenv('LOGDIR') else logfilename
+ def __checkLayers(self, input, output):
+ Preliminary checks before starting kriging.
+ Note : for this to work with grass6.3, in find_file function from core.py,
+ command should be (n flag removed because 6.4 specific):
+ s = read_command("g.findfile", element = element, file = name, mapset = mapset)
+ ##Test for input vector map.
+ testInput = grass.find_file(input, element = 'vector')
+ if testInput['fullname'] == '':
+ raise AutoKrigeError("vector map " + input + " not found in mapset search path.")
+ ##Test if output raster map already exists.
+ testOutput = grass.find_file(output, element = 'cell')
+ if testOutput['fullname'] != '':
+ if not grass.overwrite() is True:
+ raise AutoKrigeError("raster map " + output + " already exists in mapset search path. \n \
+Use the --o flag to overwrite.")
+ else:
+ print "Warning: raster map " + output + " will be overwritten."
+ ##Test also variance raster.
+ if self.varianceFlag is True:
+ testVarOutput = grass.find_file(output + '_var', element = 'cell')
+ if testVarOutput['fullname'] != '':
+ else:
+ print "Warning: raster map " + output + '_var' + " will be overwritten."
+ def __getGridCellSize(self, input, nbcell):
+ """Define kriged grid cell size. Raster resolution but also computation time depends on it.
+ We take region resolution as cell size but we can fix this resolution with the nbcell parameter.
+ Only one value is needed because the R script use square cells."""
+ if self.regionFlag is not True:
+ grass.run_command("g.region", vect = input)
+ if nbcell is not None:
+ self.__fixRegionResFromNumberOfCells(nbcell)
+ regionParams = grass.region()
+ cellsize = float(regionParams['nsres']) if float(regionParams['nsres']) > float(regionParams['ewres']) \
+ else float(regionParams['ewres'])
+ return cellsize
+ def __fixRegionResFromNumberOfCells(self, nbcell=100):
+ """Adjust one of the two region dimensions so that we have a maximum of 'nbcell' cells in both."""
+ nsResForGivenNbCell = (float(regionParams['n'])- float(regionParams['s'])) / float(nbcell)
+ ewResForGivenNbCell = (float(regionParams['e'])- float(regionParams['w'])) / float(nbcell)
+ tmpRegionRes = nsResForGivenNbCell if nsResForGivenNbCell > ewResForGivenNbCell else ewResForGivenNbCell
+ grass.use_temp_region
+ grass.run_command("g.region", res = tmpRegionRes)
+ def __prepareRModelsString(self, models=None):
+ """Try to create the R argument as expected in the R script,
+ to avoid string manipulations with R."""
+ modelsString = ''
+ if models is None:
+ ##it is important not to have any space between commas and following slashes
+ modelsString = 'c(\\"Sph\\",\\"Exp\\",\\"Gau\\",\\"Mat\\")'
+ else:
+ ##conversion to R arguments in the expected format, starting from model1,model2...
+ ##add c(" at the beginning and add ") at the end
+ RargumentsDict['models'] = 'c(\\"' + models + '\\")'
+ ##replace commas by \",\"
+ p = re.compile(',')
+ modelsString = p.sub('\\",\\"',RargumentsDict['models'])
+ return modelsString
+ def __writeRScript(self):
+ RscriptFile = grass.tempfile()
+ fileHandle = open(RscriptFile, 'a')
+ script = """
+ options(echo = FALSE)
+ args <- commandArgs()
+ ##start at index 5 because first arguments are R options
+ cat("arguments:","\n")
+ sitesG <- args[5]
+ column <- args[6]
+ rastername <- args[7]
+ cellsize <- as.numeric(args[8])
+ models <- args[9]
+ modelslist <- eval(parse(text = models))
+ range <- as.numeric(args[10])
+ if(args[11] == "NA") {nugget = NA} else {nugget <- as.numeric(args[11])}
+ if(args[12] == "NA") {sill = NA} else {sill <- as.numeric(args[12])}
+ if(args[13] == "Inf") {nobsmax = Inf} else {nobsmax <- as.numeric(args[13])}
+ if(args[14] == "Inf") {maxdistance = Inf} else {maxdistance <- as.numeric(args[14])}
+ writevarrast <- as.logical(args[15])
+ ##preparing UK implementation
+ predictors <- as.character(args[16])
+ ##print arguments
+ cat("sitesG:",sitesG,"\n")
+ cat("column:",column,"\n")
+ cat("rastername:",rastername,"\n")
+ cat("cellsize:",cellsize,"\n")
+ cat("modelslist:",modelslist,"\n")
+ cat("range:",range,"\n")
+ cat("nugget:",nugget,"\n")
+ cat("sill:",sill,"\n")
+ cat("nobsmax:",nobsmax,"\n")
+ cat("maxdistance:",maxdistance,"\n")
+ cat("writevarrast:",writevarrast,"\n")
+ cat("predictors:",predictors,"\n")
+ ##variogram plot function
+ plot.autoKrigeVariogramAndFittedModel = function(x, sp.layout = NULL, ...)
+ ##Function adapted from plot.autoKrige in automap package.
+ ##Prints only the variogram and model as we already have the map output in GRASS.
+ library(lattice)
+ shift = 0.03
+ labels = as.character(x$exp_var$np)
+ vario = xyplot(gamma ~ dist, data = x$exp_var, panel = automap:::autokrige.vgm.panel,
+ labels = labels, shift = shift, model = x$var_model,# subscripts = TRUE,
+ direction = c(x$exp_var$dir.hor[1], x$exp_var$dir.ver[1]),
+ ylim = c(min(0, 1.04 * min(x$exp_var$gamma)), 1.04 * max(x$exp_var$gamma)),
+ xlim = c(0, 1.04 * max(x$exp_var$dist)), xlab = "Distance", ylab = "Semi-variance",
+ main = "Experimental variogram and fitted variogram model", mode = "direct",...)
+ print(vario, position = c(0,0,1,1))
+ ##autokrige script
+ tryCatch({
+ ##libraries
+ library(spgrass6)
+ library(automap)
+ ##retrieve sites in a SpatialPointsDataFrame object
+ cat("retrieve sites from GRASS","\n")
+ sitesR <- readVECT6(sitesG, ignore.stderr = F)
+ cat("retrieve metadata","\n")
+ G <- gmeta6()
+ cat("GridTopology creation","\n")
+ grd <- gmeta2grd()
+ ##this is necessary to ensure that we have square cells
+ ##the more this number is small, the more the kriged map resolution is high
+ slot(grd, "cellsize") <- c(cellsize, cellsize)
+ ##creation of another grid object: SpatialGridDataFrame
+ ##this is a matrix whose values receive spatial coordinates associated to interpolated values
+ ##matrix size must be equal to the number of GridTopology cells
+ ##we create first a classical data.frame
+ data <- data.frame(list(k=rep(1,(floor(G$cols)*floor(G$rows)))))
+ cat("SpatialGridDataFrame creation","\n")
+ mask_SG <- SpatialGridDataFrame(grd, data=data, CRS(G$proj4))
+ ##add coordinates system
+ attr(sitesR, "proj4string") <-CRS(G$proj4)
+ cat("ordinary kriging","\n")
+ #[note : ajouter une option pour permettre de réaliser le krigeage universel]
+ kriging_result = autoKrige(as.formula(paste(column,"~",predictors)), sitesR[column], mask_SG, model = modelslist, fix.values = c(nugget,range,sill), debug.level=-1, verbose=TRUE, nmax=nobsmax, maxdist=maxdistance)
+ cat("send raster to GRASS","\n")
+ writeRAST6(kriging_result$krige_output,rastername,zcol=1,NODATA=0)
+ cat("Generated",rastername," "); cat("", sep="\n")
+ if(writevarrast == T) {
+ varrastername = paste(rastername, "_var", sep = "")
+ writeRAST6(kriging_result$krige_output,varrastername,zcol=2,NODATA=0)
+ cat("Generated",varrastername," "); cat("", sep="\n")
+ ##plot experimental and model variogram
+ cat("plot kriging results","\n")
+ ##see R FAQ 7.19. Plotting to png can produce errors if R version < 2.7
+ ##we use the pdf driver then we will convert to png
+ options(device="pdf")
+ try(plot.autoKrigeVariogramAndFittedModel(kriging_result))
+ cat("R script done","\n")
+ quit(status = 0)
+ }, interrupt = function(ex) {
+ cat("An interrupt was detected while executing R script.\n");
+ quit(status = 4)
+ error = function(ex) {
+ cat("Error while executing R script.\n");
+ cat(conditionMessage(ex), "\n")
+ quit(status = 5)
+ ) ## tryCatch()
+ fileHandle.write(script)
+ fileHandle.close()
+ return RscriptFile
+ def __finalize(self, output, colormap):
+ Group operations non-related to kriging.
+ We don't want to stop execution if an error occurs here.
+ try:
+ ##convert plot to png
+ self.__execShellCommand('convert -alpha off Rplots.pdf autokrige_result.png')
+ grass.try_remove('Rplots.pdf')
+ ##apply colormap
+ grass.run_command("r.colors", map = output, rules = colormap, quiet = True)
+ grass.run_command("r.colors", map = output + '_var', rules = colormap, quiet = True)
+ except:
+ pass
+ def __execShellCommand(self, command, stderrRedirection=False, logFile=False):
+ """General purpose function, maybe should be added in some way to core.py """
+ if logFile is not False:
+ command = command + ' >> ' + logFile
+ if stderrRedirection is True:
+ command = command + " 2>&1"
+ p = Popen(command, shell=True, stdout=PIPE)
+ retcode = p.wait()
+ com = p.communicate()
+ if retcode == 0:
+ return com[0]
+ else:
+ errorMessage = ''
+ for elem in com:
+ errorMessage += str(elem) + "\n"
+ raise AutoKrigeError(errorMessage)
+ def runAutoKrige(self):
+ """Autokrige class public method"""
+ ##1)Necessary checks
+ self.__checkLayers(self.input, self.output)
+ ##2)Adjust interpolation resolution
+ cellsize = self.__getGridCellSize(self.input, self.nbcell)
+ ##3)Execute R from GRASS
+ self.RscriptFile = self.__writeRScript()
+ ##spgrass6 cause : column name in R has only the 10 first characters of the original column name
+ ##may change with future versions of spgrass6
+ Rcolumnname = self.column[0:10]
+ writeVarRast = 'T' if self.varianceFlag is True else 'F'
+ print "RGrass is working..."
+ ##ordinary kriging for now
+ predictors = '1'
+ autoKrigeCommand = 'R --vanilla --slave --args ' + self.input + ' ' + Rcolumnname + ' ' + \
+ self.output + ' ' + str(cellsize) + ' "' + self.__prepareRModelsString() + '" ' + \
+ self.range + ' ' + self.nugget + ' ' + self.sill \
+ + ' ' + self.nmax + ' ' + self.maxdist + ' ' \
+ + writeVarRast + ' ' + predictors + ' < "' + self.RscriptFile + '"'
+ logFileArg = self.logfile if self.logROutput is True else False
+ self.__execShellCommand(autoKrigeCommand, stderrRedirection=True, logFile=logFileArg)
+ ##4)Finalize output
+ self.__finalize(self.output, self.colormap)
+class AutoKrigeError(Exception):
+ """Errors specific to Autokrige class"""
+ def __init__(self, message=''):
+ self.details = '\nDetails:\n'
+ exceptionType, exceptionValue, exceptionTraceback = sys.exc_info()
+ self.details += repr(traceback.format_exception(exceptionType, exceptionValue, exceptionTraceback))
+ self.message = message + "\n" + self.details
+def main():
+ exitStatus = 0
+ try:
+ autoKrige = AutoKrige(options, flags)
+ autoKrige.runAutoKrige()
+ except AutoKrigeError, e1:
+ print >> sys.stderr, "Error \n:", e1.message
+ exitStatus = 1
+ except:
+ errorMessage = "Unexpected error \n:"
+ print >> sys.stderr, errorMessage
+ traceback.print_exc()
+ exitStatus = 1
+ else:
+ print "Done"
+ finally:
+ grass.try_remove(autoKrige.RscriptFile)
+ sys.exit(exitStatus)
+if __name__ == "__main__":
+ ### DEBUG : uncomment to start local debugging session
+ #brk(host="localhost", port=9000)
+ if grass.find_program('R'):
+ options, flags = grass.parser()
+ main()
+ else:
+ print "R required, please install R first"
