[GRASS-SVN] r38074 - in grass/branches/develbranch_6/gui/wxpython:
gui_modules vdigit
svn_grass at osgeo.org
Thu Jun 25 14:22:53 EDT 2009
Author: martinl
Date: 2009-06-25 14:22:52 -0400 (Thu, 25 Jun 2009)
New Revision: 38074
grass/branches/develbranch_6/gui/wxpython/gui_modules/mapdisp_window.py
grass/branches/develbranch_6/gui/wxpython/gui_modules/vdigit.py
grass/branches/develbranch_6/gui/wxpython/vdigit/vertex.cpp
wxGUI/vdigit: update geometry attributes on move/remove vertex
Modified: grass/branches/develbranch_6/gui/wxpython/gui_modules/mapdisp_window.py
--- grass/branches/develbranch_6/gui/wxpython/gui_modules/mapdisp_window.py 2009-06-25 17:14:48 UTC (rev 38073)
+++ grass/branches/develbranch_6/gui/wxpython/gui_modules/mapdisp_window.py 2009-06-25 18:22:52 UTC (rev 38074)
@@ -21,6 +21,7 @@
import time
import math
import sys
+import tempfile
import wx
@@ -30,6 +31,7 @@
import gcmd
import utils
import globalvar
+import gselect
from debug import Debug
from preferences import globalSettings as UserSettings
from units import ConvertValue as UnitsConvertValue
@@ -1198,6 +1200,51 @@
dialog.SetColumnValue(layer, column, val)
dialog.OnReset()
+ def __geomAttrbUpdate(self, fids):
+ """!Update geometry atrributes of currently selected features
+ @param fid list feature id
+ mapLayer = self.parent.toolbars['vdigit'].GetLayer()
+ vectorName = mapLayer.GetName()
+ digit = self.parent.digit
+ item = self.tree.FindItemByData('maplayer', mapLayer)
+ vdigit = self.tree.GetPyData(item)[0]['vdigit']
+ if vdigit is None or not vdigit.has_key('geomAttr'):
+ return
+ dbInfo = gselect.VectorDBInfo(vectorName)
+ sqlfile = tempfile.NamedTemporaryFile(mode="w")
+ for fid in fids:
+ for layer, cats in digit.GetLineCats(fid).iteritems():
+ table = dbInfo.GetTable(layer)
+ for attrb, item in vdigit['geomAttr'].iteritems():
+ val = -1
+ if attrb == 'length':
+ val = digit.GetLineLength(fid)
+ type = attrb
+ elif attrb == 'area':
+ val = digit.GetAreaSize(fid)
+ type = attrb
+ elif attrb == 'perimeter':
+ val = digit.GetAreaPerimeter(fid)
+ type = 'length'
+ if val < 0:
+ continue
+ val = UnitsConvertValue(val, type, item['units'])
+ for cat in cats:
+ sqlfile.write('UPDATE %s SET %s = %f WHERE %s = %d;\n' % \
+ (table, item['column'], val,
+ dbInfo.GetKeyColumn(layer), cat))
+ sqlfile.file.flush()
+ gcmd.RunCommand('db.execute',
+ parent = True,
+ quiet = True,
+ input = sqlfile.name)
def __updateATM(self):
"""!Update open Attribute Table Manager
@@ -1917,8 +1964,11 @@
return
elif digitToolbar.GetAction() == "moveVertex":
# move vertex
- if digitClass.MoveSelectedVertex(pFrom, move) < 0:
+ fid = digitClass.MoveSelectedVertex(pFrom, move)
+ if fid < 0:
return
+ self.__geomAttrbUpdate([fid,])
del self.vdigitMove
@@ -2019,12 +2069,15 @@
return
elif digitToolbar.GetAction() == "addVertex":
# add vertex
- if digitClass.AddVertex(self.Pixel2Cell(self.mouse['begin'])) < 0:
+ fid = digitClass.AddVertex(self.Pixel2Cell(self.mouse['begin']))
+ if fid < 0:
return
elif digitToolbar.GetAction() == "removeVertex":
# remove vertex
- if digitClass.RemoveVertex(self.Pixel2Cell(self.mouse['begin'])) < 0:
+ fid = digitClass.RemoveVertex(self.Pixel2Cell(self.mouse['begin']))
+ if fid < 0:
return
elif digitToolbar.GetAction() in ("copyCats", "copyAttrs"):
try:
if digitToolbar.GetAction() == 'copyCats':
Modified: grass/branches/develbranch_6/gui/wxpython/gui_modules/vdigit.py
--- grass/branches/develbranch_6/gui/wxpython/gui_modules/vdigit.py 2009-06-25 17:14:48 UTC (rev 38073)
+++ grass/branches/develbranch_6/gui/wxpython/gui_modules/vdigit.py 2009-06-25 18:22:52 UTC (rev 38074)
@@ -355,7 +355,7 @@
@param coords click coordinates
@param move X,Y direction
- @return 1 vertex moved
+ @return id of new feature
@return 0 vertex not moved (not found, line is not selected)
snap, thresh = self.__getSnapThreshold()
@@ -378,7 +378,7 @@
@param coords coordinates to add vertex
- @return 1 vertex added
@return 0 nothing changed
@return -1 on failure
@@ -395,7 +395,7 @@
@param coords coordinates to remove vertex
- @return 1 vertex removed
Modified: grass/branches/develbranch_6/gui/wxpython/vdigit/vertex.cpp
--- grass/branches/develbranch_6/gui/wxpython/vdigit/vertex.cpp 2009-06-25 17:14:48 UTC (rev 38073)
+++ grass/branches/develbranch_6/gui/wxpython/vdigit/vertex.cpp 2009-06-25 18:22:52 UTC (rev 38074)
@@ -28,7 +28,7 @@
\param thresh_coords threshold value to identify vertex position
\param thresh_snap threshold value to snap moved vertex
- \param 1 vertex moved
+ \param id id of the new feature
\param 0 nothing changed
\param -1 error
@@ -95,7 +95,7 @@
Vect_destroy_line_struct(point);
- return ret;
+ return nlines + 1; // feature is write at the end of the file
@@ -107,7 +107,7 @@
\param x,y,z coordinates (z is used only if map is 3d
\param thresh threshold value to identify vertex position
- \param 1 vertex added/removed
\param -1 error
@@ -155,5 +155,5 @@
- return ret;
