[GRASS-SVN] r38087 - in grass/trunk: include lib/gis
    svn_grass at osgeo.org
    Fri Jun 26 05:48:06 EDT 2009
Author: martinl
Date: 2009-06-26 05:48:05 -0400 (Fri, 26 Jun 2009)
New Revision: 38087
   grass/trunk/include/gis.h
   grass/trunk/lib/gis/gislib.dox
update gislib dox - add definition of categories, range, history
structures
Modified: grass/trunk/include/gis.h
--- grass/trunk/include/gis.h	2009-06-26 09:24:52 UTC (rev 38086)
+++ grass/trunk/include/gis.h	2009-06-26 09:48:05 UTC (rev 38087)
@@ -258,21 +258,21 @@
 struct Cell_head
-    int format;			/* max numer of bytes per cell minus 1          */
+    int format;			/* max number of bytes per cell minus 1         */
     int compressed;		/* 0 = uncompressed, 1 = compressed, -1 pre 3.0 */
     int rows;			/* number of rows in the data 2D                */
     int rows3;			/* number of rows in the data 3D                */
     int cols;			/* number of columns in the data 2D             */
     int cols3;			/* number of columns in the data 3D             */
     int depths;			/* number of depths in data                     */
-    int proj;			/* Projection (see #defines above)              */
-    int zone;			/* Projection zone                              */
-    double ew_res;		/* East to West cell size 2D                    */
-    double ew_res3;		/* East to West cell size 3D                    */
-    double ns_res;		/* North to South cell size 2D                  */
-    double ns_res3;		/* North to South cell size 3D                  */
-    double tb_res;		/* Top to Bottom cell size                      */
-    double north;		/* coordinates of layer                         */
+    int proj;			/* projection (see #defines above)              */
+    int zone;			/* projection zone                              */
+    double ew_res;		/* east to west cell size 2D                    */
+    double ew_res3;		/* east to west cell size 3D                    */
+    double ns_res;		/* north to south cell size 2D                  */
+    double ns_res3;		/* north to south cell size 3D                  */
+    double tb_res;		/* top to bottom cell size                      */
+    double north;		/* coordinates of map layer                     */
     double south;
     double east;
     double west;
Modified: grass/trunk/lib/gis/gislib.dox
--- grass/trunk/lib/gis/gislib.dox	2009-06-26 09:24:52 UTC (rev 38086)
+++ grass/trunk/lib/gis/gislib.dox	2009-06-26 09:48:05 UTC (rev 38087)
@@ -21,9 +21,9 @@
  - \subpage Creating_and_Opening_a_New_Database_File
  - \subpage Database_File_Management
-- \subpage The_Region
- - \subpage The_Database_Region
- - \subpage The_Active_Module_Region
+- \subpage Region
+ - \subpage Database_Region
+ - \subpage Active_Module_Region
 - \subpage Projection_Information
  - \subpage Latitude_Longitude_Databases
@@ -501,7 +501,7 @@
 remove these other files as well, specific calls must be made for each
 related <i>element</i>.
-\section The_Region The Region
+\section Region Region
 The region concept is explained in \ref Region. It can be thought of as a
 two-dimensional matrix with known boundaries and rectangular cells.
@@ -518,7 +518,7 @@
 \ref GIS_Library_Data_Structures.
-\subsection The_Database_Region The Database Region
+\subsection Database_Region Database Region
 Reading and writing the user's database region are done by the
 following routines:
@@ -564,7 +564,7 @@
  - G_get_default_window()
-\subsection The_Active_Module_Region The Active Module Region
+\subsection Active_Module_Region Active Module Region
 The <em>active module region</em> is the one that is used when reading
 and writing raster file data. This region determines the resampling
@@ -2107,17 +2107,26 @@
 \code
 struct Cell_head
- int format;     /* number of bytes per cell */
- int compressed; /* compressed(1) or not compressed(0) */
- int rows, cols; /* number of rows and columns */
- int proj;       /* projection */
- int zone;       /* zone */
- double ew_res;  /* east-west resolution */
- double ns_res;  /* north-south resolution */
- double north;   /* northern edge */
- double south;   /* southern edge */
- double east;    /* eastern edge */
- double west;    /* western edge */
+    int compressed;		/* 0 = uncompressed, 1 = compressed, -1 pre 3.0 */
+    int rows;			/* number of rows in the data 2D                */
+    int rows3;			/* number of rows in the data 3D                */
+    int cols;			/* number of columns in the data 2D             */
+    int cols3;			/* number of columns in the data 3D             */
+    int depths;			/* number of depths in data                     */
+    double south;
+    double east;
+    double west;
+    double top;
+    double bottom;
 \endcode
@@ -2132,28 +2141,71 @@
 projection is described by <i>proj</i> and the related zone for the
 projection by <i>zone</i>. The <i>rows</i> and <i>cols</i> indicate
 the number of rows and columns in the raster file, or in the
-region. See \ref Raster_Header_Format for more information about
+region. See \ref Raster_Header_File for more information about
 raster headers, and \ref Region for more information about regions.
 The routines described in \ref Raster_Header_File use this structure.
 \subsection struct_Categories struct Categories
 The <i>Categories</i> structure contains a title for the map layer,
 the largest category in the map layer, an automatic label generation
 rule for missing labels, and a list of category labels.
+\code
+struct Categories
+    CELL ncats;			/* total number of categories              */
+    CELL num;			/* the highest cell values. Only exists
+				   for backwards compatibility = (CELL)
+				   max_fp_values in quant rules            */
+    char *title;		/* name of data layer                      */
+    char *fmt;			/* printf-like format to generate labels   */
+    float m1;			/* multiplication coefficient 1            */
+    float a1;			/* addition coefficient 1                  */
+    float m2;			/* multiplication coefficient 2            */
+    float a2;			/* addition coefficient 2                  */
+    struct Quant q;		/* rules mapping cell values to index in
+				   list of labels                          */
+    char **labels;		/* array of labels of size num             */
+    int *marks;			/* was the value with this label was used? */
+    int nalloc;
+    int last_marked_rule;
+\endcode
 This structure should be accessed using the routines described in
 \ref Raster_Category_File.
 \subsection struct_Colors struct Colors
 The color data structure holds red, green, and blue color intensities
 for raster categories. The structure has become so complicated that it
 will not be described in this manual.
+\code
+struct Colors
+    int version;		/* set by read_colors: -1=old, 1=new */
+    DCELL shift;
+    int invert;
+    int is_float;		/* defined on floating point raster data? */
+    int null_set;		/* the colors for null are set? */
+    unsigned char null_red;
+    unsigned char null_grn;
+    unsigned char null_blu;
+    int undef_set;		/* the colors for cells not in range are set? */
+    unsigned char undef_red;
+    unsigned char undef_grn;
+    unsigned char undef_blu;
+    struct _Color_Info_ fixed;
+    struct _Color_Info_ modular;
+    DCELL cmin;
+    DCELL cmax;
+    int organizing;
+\endcode
 The routines described in \ref Raster_Color_Table must be used
 to store and retrieve color information using this structure.
@@ -2206,10 +2258,26 @@
 \subsection struct_Range struct Range
+The <i>Range</i> (<i>FPRange</i> for floating point raster maps)
+structure contains the minimum and maximum values which occur in a
+raster file.
-The <i>Range</i> structure contains the minimum and maximum values which occur
-in a raster file.
+\code
+struct Range
+    CELL min;
+    CELL max;
+    int first_time;		/* whether or not range was updated */
+struct FPRange
+    DCELL min;
+    DCELL max;
+\endcode
 The routines described in \ref Raster_Range_File should be used to access
 this structure.
