[GRASS-SVN] r38089 - grass-addons/vector/v.krige
svn_grass at osgeo.org
Fri Jun 26 10:43:42 EDT 2009
Author: aghisla
Date: 2009-06-26 10:43:41 -0400 (Fri, 26 Jun 2009)
New Revision: 38089
grass-addons/vector/v.krige/v.krige.py
kriging with gstat available! - not yet completely bound to interface
Modified: grass-addons/vector/v.krige/v.krige.py
--- grass-addons/vector/v.krige/v.krige.py 2009-06-26 10:11:19 UTC (rev 38088)
+++ grass-addons/vector/v.krige/v.krige.py 2009-06-26 14:43:41 UTC (rev 38089)
@@ -73,10 +73,10 @@
self.InputDataMap = gselect.VectorSelect(parent = self,
ftype = 'points',
updateOnPopup = False)
+ #@FIXME: still does slow down interface creation. Thread? Put it elsewhere?
wx.CallAfter(self.InputDataMap.GetElementList)
flexSizer.Add(item = self.InputDataMap)
flexSizer.Add(item = wx.StaticText(self, id=wx.ID_ANY, label=_("Column:")),
flag=wx.ALIGN_CENTER_VERTICAL)
self.InputDataColumn = gselect.ColumnSelect(self, id=wx.ID_ANY)
@@ -126,7 +126,8 @@
def CreatePage(self, package):
if robjects.r.require(package) and robjects.r.require('spgrass6'):
classobj = eval("RBook"+package+"Panel")
- setattr(self, "RBook"+package+"Panel", (classobj(self, id=wx.ID_ANY)))
+ setattr(self, "RBook"+package+"Panel", (classobj(self, id=wx.ID_ANY)))
+ getattr(self, "RBook"+package+"Panel")
self.RPackagesBook.AddPage(page=getattr(self, "RBook"+package+"Panel"), text=package)
else:
pass
@@ -151,10 +152,18 @@
#1. get the data in R format, i.e. SpatialPointsDataFrame
InputData = robjects.r.readVECT6(self.InputDataMap.GetValue(), type= 'point')
+ #1.5 create the grid where to estimate values. Not used by block-kriging
+ Grid = robjects.r.gmeta2grd()
+ ##create the spatialgriddataframe with these settings
+ GridPredicted = robjects.r.SpatialGridDataFrame(Grid,
+ data=robjects.r['data.frame']
+ (k=robjects.r.rep(1,grass.region()['cols']*grass.region()['rows'])),
+ proj4string=robjects.r.CRS(robjects.r.proj4string(InputData)))
#2. collect options
Column = self.InputDataColumn.GetValue()
#@TODO(anne): pick up parameters if user chooses to set variogram parameters.
- #3. Fit variogram
+ #3. Fit variogram. For the moment in batch mode, no interactive window. Stay tuned!
self.parent.log.write(_("Variogram fitting"))
Formula = robjects.r['as.formula'](robjects.r.paste(Column, "~ 1"))
Variogram = SelectedPanel.FitVariogram(Formula, InputData)
@@ -165,11 +174,13 @@
#4. Kriging
self.parent.log.write('Kriging...')
- SelectedPanel.DoKriging()
-# self.parent.log.write('Kriging performed..')
+ KrigingResult = SelectedPanel.DoKriging(formula = Formula, data = InputData, grid = GridPredicted, model = Variogram)
+ self.parent.log.write('Kriging performed..')
#5. Format output
+ robjects.r.writeRAST6(KrigingResult, vname = 'KrigingResult', zcol='var1.pred')
+ self.parent.log.write('Wow! Succeeded! Ready for another run.')
def OnCloseWindow(self, event):
""" Cancel button pressed"""
@@ -209,9 +220,9 @@
# unlock options as soon as they are available. Stone soup!
VariogramSizer = wx.StaticBoxSizer(wx.StaticBox(self, id=wx.ID_ANY,
label=_("Variogram fitting")), wx.VERTICAL)
- VariogramCheckBox = wx.CheckBox(self, id=wx.ID_ANY, label=_("Auto-fit variogram"))
- VariogramCheckBox.SetValue(state = True) # check it by default
- ParametersSizer = wx.FlexGridSizer(cols=3, hgap=5, vgap=5)
+ self.VariogramCheckBox = wx.CheckBox(self, id=wx.ID_ANY, label=_("Auto-fit variogram"))
+ self.VariogramCheckBox.SetValue(state = True) # check it by default
+ self.ParametersSizer = wx.FlexGridSizer(cols=3, hgap=5, vgap=5)
for n in ["Sill", "Nugget", "Range"]:
setattr(self, n+"Sizer", (wx.BoxSizer(wx.HORIZONTAL)))
@@ -220,13 +231,13 @@
a = getattr(self, n+"Sizer")
a.Add(getattr(self, n+"Text"), proportion=0, flag=wx.ALIGN_LEFT | wx.ALIGN_CENTER | wx.ALL, border=3)
a.Add(getattr(self, n+"Ctrl"), proportion=0, flag=wx.ALIGN_RIGHT | wx.ALL, border=3)
- ParametersSizer.Add(a)#, proportion = 0, flag=wx.EXPAND | wx.ALL, border=3)
+ self.ParametersSizer.Add(a)#, proportion = 0, flag=wx.EXPAND | wx.ALL, border=3)
- VariogramSizer.Add(VariogramCheckBox, proportion=1, flag=wx.EXPAND | wx.ALL, border=3)
- VariogramSizer.Add(ParametersSizer, proportion=0, flag=wx.EXPAND | wx.ALL, border=3)
- #@TODO(anne); hides Parameters when Autofit variogram is selected
-# VariogramCheckBox.Bind(wx.EVT_CHECKBOX, self.HideOptions)
+ VariogramSizer.Add(self.VariogramCheckBox, proportion=1, flag=wx.EXPAND | wx.ALL, border=3)
+ VariogramSizer.Add(self.ParametersSizer, proportion=0, flag=wx.EXPAND | wx.ALL, border=3)
+ self.VariogramCheckBox.Bind(wx.EVT_CHECKBOX, self.HideOptions)
self.KrigingList = ["Ordinary kriging", "Universal Kriging", "Block kriging"] #@FIXME: i18n on the list?
KrigingRadioBox = wx.RadioBox(self, id=wx.ID_ANY, label=_("Kriging techniques"),
pos=wx.DefaultPosition, size=wx.DefaultSize,
@@ -245,32 +256,43 @@
pass
def HideOptions(self, event):
- for n in self.ParametersSizer.GetChildren(): n.Disable()
- #@TODO(anne): set it right.
+ pass
class RBookautomapPanel(RBookPanel):
""" Subclass of RBookPanel, with specific automap options and kriging functions. """
- #def __init__(self, parent, *args, **kwargs):
- # RBookPanel.__init__(self, parent, *args, **kwargs)
+ def __init__(self, parent, *args, **kwargs):
+ RBookPanel.__init__(self, parent, *args, **kwargs)
- def FitVariogram(self, Formula, InputData):
- return robjects.r.autofitVariogram(Formula, InputData)
+ def FitVariogram(self, formula, data):
+ return robjects.r.autofitVariogram(formula, data)
def DoKriging():
#BUG: automap autoKrige() does not seem to handle projected data.
#current workaround would be create projected grid with estimation locations..
pass
+ def HideOptions(self, event):
+ #for n in self.ParametersSizer.GetChildren(): n.Enable(False)
+ if self.VariogramCheckBox.IsChecked():
+ for n in self.ParametersSizer.GetChildren(): n.Show(False)
+ else:
+ for n in self.ParametersSizer.GetChildren(): n.Show(True)
+ #@TODO(anne): set it right. It costs too much code and hides options instead of disabling them
class RBookgstatPanel(RBookPanel):
""" Subclass of RBookPanel, with specific gstat options and kriging functions. """
- pass
+ DataVariogram = robjects.r.variogram(formula, data)
+ VariogramModel = robjects.r['fit.variogram'](DataVariogram, model = robjects.r.vgm(1, "Lin"))
+ #@TODO: hardcoded on rs dataset. There is a trend indeed.
+ return VariogramModel
- def DoKriging():
- pass
+ def DoKriging(self, formula, data, grid, model):
+ KrigingResult = robjects.r.krige(formula, data, grid, model)
+ return KrigingResult
class RBookgeoRPanel(RBookPanel):
""" Subclass of RBookPanel, with specific geoR options and kriging functions. """
@@ -281,7 +303,8 @@
pass
def DoKriging():
- pass
+ pass
def main(argv=None):
if argv is None:
argv = sys.argv
