[GRASS-SVN] r38092 -
grass/branches/develbranch_6/gui/wxpython/gui_modules
svn_grass at osgeo.org
Sat Jun 27 06:17:37 EDT 2009
Author: martinl
Date: 2009-06-27 06:17:37 -0400 (Sat, 27 Jun 2009)
New Revision: 38092
grass/branches/develbranch_6/gui/wxpython/gui_modules/mapdisp.py
grass/branches/develbranch_6/gui/wxpython/gui_modules/mapdisp_window.py
grass/branches/develbranch_6/gui/wxpython/gui_modules/wxgui_utils.py
wxGUI: indicate if MASK is available (change mapdisplay title)
minor doxygen updates
(merge from trunk, r38091)
Modified: grass/branches/develbranch_6/gui/wxpython/gui_modules/mapdisp.py
--- grass/branches/develbranch_6/gui/wxpython/gui_modules/mapdisp.py 2009-06-27 10:14:10 UTC (rev 38091)
+++ grass/branches/develbranch_6/gui/wxpython/gui_modules/mapdisp.py 2009-06-27 10:17:37 UTC (rev 38092)
@@ -109,7 +109,8 @@
self.page = page # Notebook page holding the layer tree
self.layerbook = notebook # Layer Manager layer tree notebook
self.parent = parent
+ self.title = title
# available cursors
Modified: grass/branches/develbranch_6/gui/wxpython/gui_modules/mapdisp_window.py
--- grass/branches/develbranch_6/gui/wxpython/gui_modules/mapdisp_window.py 2009-06-27 10:14:10 UTC (rev 38091)
+++ grass/branches/develbranch_6/gui/wxpython/gui_modules/mapdisp_window.py 2009-06-27 10:17:37 UTC (rev 38092)
@@ -1,4 +1,4 @@
@package mapdisp_window.py
@brief GIS map display canvas, buffered window.
@@ -25,6 +25,8 @@
import wx
+import grass.script as grass
import dbm
import dbm_dialogs
import gdialogs
@@ -42,7 +44,7 @@
from vdigit import PseudoDC
class MapWindow(object):
Abstract map window class
Parent for BufferedWindow class (2D display mode) and
@@ -67,13 +69,13 @@
def EraseMap(self):
Erase the canvas (virtual method)
pass
def UpdateMap(self):
Updates the canvas anytime there is a change to the
underlaying images or to the geometry of the canvas.
@@ -95,7 +97,7 @@
pass
def GetSelectedLayer(self, type = 'layer', multi = False):
Get selected layer from layer tree
@param type 'item' / 'layer' / 'nviz'
@@ -142,7 +144,7 @@
return ret
class BufferedWindow(MapWindow, wx.Window):
A Buffered window class.
When the drawing needs to change, you app needs to call the
@@ -244,7 +246,7 @@
self.lastpos = (0, 0)
def Draw(self, pdc, img=None, drawid=None, pdctype='image', coords=[0, 0, 0, 0]):
Draws map and overlay decorations
if drawid == None:
@@ -379,7 +381,7 @@
return drawid
def TextBounds(self, textinfo):
Return text boundary data
@param textinfo text metadata (text, font, color, rotation)
@@ -414,7 +416,7 @@
return coords, boxw, boxh
def OnPaint(self, event):
Draw PseudoDC's to buffered paint DC
self.pdc for background and decorations
@@ -496,7 +498,7 @@
self.redrawAll = False
def OnSize(self, event):
Scale map image so that it is
the same size as the Window
@@ -532,7 +534,7 @@
self.parent.StatusbarUpdate()
def OnIdle(self, event):
Only re-render a composite map image from GRASS during
idle time instead of multiple times during resizing.
@@ -542,7 +544,7 @@
event.Skip()
def SaveToFile(self, FileName, FileType):
This draws the psuedo DC to a buffer that
can be saved to a file.
@@ -553,7 +555,7 @@
self.buffer.SaveFile(FileName, FileType)
def GetOverlay(self):
Converts rendered overlay files to wx.Image
Updates self.imagedict
@@ -571,7 +573,7 @@
return imgs
def GetImage(self):
Converts redered map files to wx.Image
Updates self.imagedict (id=99)
@@ -590,7 +592,7 @@
return img
def UpdateMap(self, render=True, renderVector=True):
@@ -622,7 +624,7 @@
# update layer dictionary if there has been a change in layers
if self.tree and self.tree.reorder == True:
self.tree.ReorderLayers()
# reset flag for auto-rendering
if self.tree:
self.tree.rerender = False
@@ -663,7 +665,7 @@
return False
self.Draw(self.pdc, self.img, drawid=id)
# render vector map layer
@@ -709,10 +711,10 @@
for id in self.textdict.keys():
self.Draw(self.pdc, img=self.textdict[id], drawid=id,
pdctype='text', coords=[10, 10, 10, 10])
# optionally draw computational extent box
self.DrawCompRegionExtent()
# redraw pdcTmp if needed
@@ -731,7 +733,6 @@
# clear measurement
if self.mouse["use"] == "measure":
self.ClearLines(pdc=self.pdcTmp)
self.polycoords = []
@@ -741,25 +742,30 @@
self.SetCursor(self.parent.cursors["default"])
stop = time.clock()
# hide process bar
self.parent.onRenderGauge.Hide()
- # update statusbar
+ # update statusbar
### self.Map.SetRegion()
+ if grass.find_file(name = 'MASK', element = 'cell')['name']:
+ # mask found
+ self.parent.SetTitle(self.parent.title + _(' (masked)'))
+ else:
+ self.parent.SetTitle(self.parent.title)
Debug.msg (2, "BufferedWindow.UpdateMap(): render=%s, renderVector=%s -> time=%g" % \
(render, renderVector, (stop-start)))
return True
def DrawCompRegionExtent(self):
Draw computational region extent in the display
Display region is drawn as a blue box inside the computational region,
@@ -787,7 +793,7 @@
self.DrawLines(pdc=self.pdcDec, polycoords=self.regionCoords)
def IsInRegion(self, region, refRegion):
Test if 'region' is inside of 'refRegion'
@param region input region
@@ -805,7 +811,7 @@
return False
def EraseMap(self):
Erase the canvas
self.Draw(self.pdc, pdctype='clear')
@@ -817,7 +823,7 @@
self.Draw(self.pdcTmp, pdctype='clear')
def DragMap(self, moveto):
Drag the entire map image for panning.
@@ -836,7 +842,7 @@
return True
def DragItem(self, id, event):
Drag an overlay decoration item
if id == 99 or id == '' or id == None: return
@@ -867,7 +873,7 @@
self.lastpos = (event.GetX(), event.GetY())
def MouseDraw(self, pdc=None, begin=None, end=None):
Mouse box or line from 'begin' to 'end'
If not given from self.mouse['begin'] to self.mouse['end'].
@@ -918,7 +924,7 @@
self.Draw(pdc, drawid=self.lineid, pdctype='line', coords=mousecoords)
def DrawLines(self, pdc=None, polycoords=None):
Draw polyline in PseudoDC
Set self.pline to wx.NEW_ID + 1
@@ -989,7 +995,7 @@
return self.lineid
def MouseActions(self, event):
Mouse motion and button click notifier
if not self.processMouse:
@@ -1036,7 +1042,7 @@
# event.Skip()
def OnMouseWheel(self, event):
Mouse wheel moved
self.processMouse = False
@@ -1070,7 +1076,7 @@
# event.Skip()
def OnDragging(self, event):
Mouse dragging with left button down
Debug.msg (5, "BufferedWindow.MouseAction(): Dragging")
@@ -1107,7 +1113,7 @@
# event.Skip()
def OnLeftDownVDigitAddLine(self, event):
Left mouse button down - vector digitizer add new line
action
@@ -1262,7 +1268,7 @@
atm.LoadData(layer)
def OnLeftDownVDigitEditLine(self, event):
Left mouse button down - vector digitizer edit linear feature
- add new vertex.
@@ -1274,7 +1280,7 @@
self.DrawLines(pdc=self.pdcTmp)
def OnLeftDownVDigitMoveLine(self, event):
Left mouse button down - vector digitizer move feature/vertex,
edit linear feature
@@ -1298,7 +1304,7 @@
self.pdcTmp.SetPen(self.polypen)
def OnLeftDownVDigitDisplayCA(self, event):
Left mouse button down - vector digitizer display categories
or attributes action
@@ -1379,7 +1385,7 @@
self.UpdateMap(render=False)
def OnLeftDownVDigitCopyCA(self, event):
Left mouse button down - vector digitizer copy categories
@@ -1393,7 +1399,7 @@
self.mouse['box'] = 'box'
def OnLeftDownVDigitCopyLine(self, event):
Left mouse button down - vector digitizer copy lines action
digitToolbar = self.parent.toolbars['vdigit']
@@ -1404,7 +1410,7 @@
self.layerTmp = None
def OnLeftDownVDigitBulkLine(self, event):
Left mouse button down - vector digitizer label 3d vector
lines
@@ -1425,7 +1431,7 @@
self.DrawLines(self.pdcTmp, begin, end)
def OnLeftDown(self, event):
Left mouse button pressed
Debug.msg (5, "BufferedWindow.OnLeftDown(): use=%s" % \
@@ -1520,7 +1526,7 @@
event.Skip()
def OnLeftUpVDigitVarious(self, event):
Left mouse button up - vector digitizer various actions
@@ -1654,7 +1660,7 @@
self.UpdateMap(render=False, renderVector=False)
def OnLeftUpVDigitModifyLine(self, event):
Left mouse button up - vector digitizer split line, add/remove
vertex action
@@ -1692,7 +1698,7 @@
def OnLeftUpVDigitCopyLine(self, event):
Left mouse button up - vector digitizer copy feature action
@@ -1745,7 +1751,7 @@
self.redrawAll = None
def OnLeftUpVDigitBulkLine(self, event):
Left mouse button up - vector digitizer z-bulk line action
@@ -1765,7 +1771,7 @@
def OnLeftUpVDigitConnectLine(self, event):
Left mouse button up - vector digitizer connect line action
@@ -1775,7 +1781,7 @@
def OnLeftUp(self, event):
Left mouse button released
Debug.msg (5, "BufferedWindow.OnLeftUp(): use=%s" % \
@@ -1896,7 +1902,7 @@
self.currtxtid = None
def OnButtonDClick(self, event):
Mouse button double click
Debug.msg (5, "BufferedWindow.OnButtonDClick(): use=%s" % \
@@ -1938,7 +1944,7 @@
self.parent.OnAddLegend(None)
def OnRightDown(self, event):
Right mouse button pressed
Debug.msg (5, "BufferedWindow.OnRightDown(): use=%s" % \
@@ -1975,7 +1981,7 @@
event.Skip()
def OnRightUp(self, event):
Right mouse button released
Debug.msg (5, "BufferedWindow.OnRightUp(): use=%s" % \
@@ -2159,7 +2165,7 @@
event.Skip()
def OnMiddleDown(self, event):
Middle mouse button pressed
@@ -2224,7 +2230,7 @@
self.redrawAll = True
def OnMouseMoving(self, event):
Motion event and no mouse buttons were pressed
@@ -2291,7 +2297,7 @@
event.Skip()
def ClearLines(self, pdc=None):
Clears temporary drawn lines from PseudoDC
if not pdc:
@@ -2316,7 +2322,7 @@
return True
def Pixel2Cell(self, (x, y)):
Convert image coordinates to real word coordinates
Input : int x, int y
@@ -2347,7 +2353,7 @@
return (east, north)
def Cell2Pixel(self, (east, north)):
Convert real word coordinates to image coordinates
@@ -2374,7 +2380,7 @@
return (x, y)
def Zoom(self, begin, end, zoomtype):
Calculates new region while (un)zoom/pan-ing
x1, y1 = begin
@@ -2450,7 +2456,7 @@
def ZoomBack(self):
Zoom to previous extents in zoomhistory list
@@ -2476,7 +2482,7 @@
def ZoomHistory(self, n, s, e, w):
Manages a list of last 10 zoom extents
Return removed history item if exists
@@ -2497,20 +2503,20 @@
return removed
def OnZoomToMap(self, event):
Set display extents to match selected raster (including NULLs)
or vector map.
self.ZoomToMap()
def OnZoomToRaster(self, event):
Set display extents to match selected raster map (ignore NULLs)
self.ZoomToMap(ignoreNulls = True)
def ZoomToMap(self, layers = None, ignoreNulls = False, render = True):
or vector map(s).
@@ -2557,7 +2563,7 @@
def ZoomToWind(self, event):
Set display geometry to match computational
region settings (set with g.region)
@@ -2572,7 +2578,7 @@
def ZoomToDefault(self, event):
Set display geometry to match default region settings
self.Map.region = self.Map.GetRegion(default=True)
@@ -2586,7 +2592,7 @@
def DisplayToWind(self, event):
Set computational region (WIND file) to
match display extents
@@ -2611,7 +2617,7 @@
os.environ["GRASS_REGION"] = tmpreg
def ZoomToSaved(self, event):
Set display geometry to match extents in
saved region file
@@ -2658,7 +2664,7 @@
dlg.Destroy()
def SaveDisplayRegion(self, event):
Save display extents to named region file.
@@ -2690,7 +2696,7 @@
dlg.Destroy()
def SaveRegion(self, wind):
Save region settings
new = self.Map.AlignResolution()
Modified: grass/branches/develbranch_6/gui/wxpython/gui_modules/wxgui_utils.py
--- grass/branches/develbranch_6/gui/wxpython/gui_modules/wxgui_utils.py 2009-06-27 10:14:10 UTC (rev 38091)
+++ grass/branches/develbranch_6/gui/wxpython/gui_modules/wxgui_utils.py 2009-06-27 10:17:37 UTC (rev 38092)
@@ -108,10 +108,10 @@
Map=self.Map, auimgr=self.auimgr)
# title
- self.mapdisplay.SetTitle(_("GRASS GIS Map Display: " +
- str(self.disp_idx + 1) +
- " - Location: " + grass.gisenv()["LOCATION_NAME"]))
+ self.mapdisplay.title = _("GRASS GIS Map Display: %d - Location: %s") % \
+ (self.disp_idx + 1, grass.gisenv()["LOCATION_NAME"])
+ self.mapdisplay.SetTitle(self.mapdisplay.title)
# show new display
if kargs['showMapDisplay'] is True:
self.mapdisplay.Show()
