[GRASS-SVN] r38094 - in grass/trunk: gui/wxpython/docs gui/wxpython/gui_modules raster/r.watershed/front scripts scripts/db.dropcolumn scripts/v.colors scripts/v.db.addcol scripts/v.db.addtable scripts/v.db.dropcol scripts/v.db.droptable scripts/v.db.renamecol vector vector/v.db.connect vector/v.transform vector/v.vol.rst
Sat Jun 27 06:55:30 EDT 2009
Author: martinl
Date: 2009-06-27 06:55:30 -0400 (Sat, 27 Jun 2009)
New Revision: 38094
Added:
   grass/trunk/scripts/v.db.dropcol/v.db.dropcolumn.html
   grass/trunk/scripts/v.db.dropcol/v.db.dropcolumn.py
Removed:
   grass/trunk/scripts/v.db.dropcol/v.db.dropcol.html
   grass/trunk/scripts/v.db.dropcol/v.db.dropcol.py
   grass/trunk/gui/wxpython/docs/wxGUI.Attribute_Table_Manager.html
   grass/trunk/gui/wxpython/gui_modules/dbm.py
   grass/trunk/raster/r.watershed/front/r.watershed.html
   grass/trunk/scripts/Makefile
   grass/trunk/scripts/db.dropcolumn/db.dropcolumn.html
   grass/trunk/scripts/v.colors/v.colors.py
   grass/trunk/scripts/v.db.addcol/v.db.addcol.html
   grass/trunk/scripts/v.db.addtable/v.db.addtable.html
   grass/trunk/scripts/v.db.dropcol/Makefile
   grass/trunk/scripts/v.db.droptable/v.db.droptable.html
   grass/trunk/scripts/v.db.renamecol/v.db.renamecol.html
   grass/trunk/scripts/v.db.renamecol/v.db.renamecol.py
   grass/trunk/vector/v.db.connect/v.db.connect.html
   grass/trunk/vector/v.transform/v.transform.html
   grass/trunk/vector/v.vol.rst/v.vol.rst.html
   grass/trunk/vector/vectorintro.html
v.db.dropcol renamed to v.db.dropcolumn (part 1)
Modified: grass/trunk/gui/wxpython/docs/wxGUI.Attribute_Table_Manager.html
--- grass/trunk/gui/wxpython/docs/wxGUI.Attribute_Table_Manager.html	2009-06-27 10:41:41 UTC (rev 38093)
+++ grass/trunk/gui/wxpython/docs/wxGUI.Attribute_Table_Manager.html	2009-06-27 10:55:30 UTC (rev 38094)
@@ -30,7 +30,7 @@
 <em>
   <a href="v.db.addcol.html">v.db.addcol</a>,
   <a href="v.db.connect.html">v.db.connect</a>,
-  <a href="v.db.dropcol.html">v.db.dropcol</a>,
+  <a href="v.db.dropcolumn.html">v.db.dropcolumn</a>,
   <a href="v.db.renamecol.html">v.db.renamecol</a>,
   <a href="v.what.html">v.what</a>
 </em>
Modified: grass/trunk/gui/wxpython/gui_modules/dbm.py
--- grass/trunk/gui/wxpython/gui_modules/dbm.py	2009-06-27 10:41:41 UTC (rev 38093)
+++ grass/trunk/gui/wxpython/gui_modules/dbm.py	2009-06-27 10:55:30 UTC (rev 38094)
@@ -1545,7 +1545,7 @@
         item = list.GetFirstSelected()
         while item != -1:
-            self.listOfCommands.append(('v.db.dropcol',
+            self.listOfCommands.append(('v.db.dropcolumn',
                                         { 'map' : self.vectorName,
                                           'layer' : self.layer,
                                           'column' : list.GetItemText(item) }
@@ -1568,7 +1568,7 @@
         table = self.mapDBInfo.layers[self.layer]['table']
         cols = self.mapDBInfo.GetColumns(table)
         for col in cols:
                                           'column' : col }
Modified: grass/trunk/raster/r.watershed/front/r.watershed.html
--- grass/trunk/raster/r.watershed/front/r.watershed.html	2009-06-27 10:41:41 UTC (rev 38093)
+++ grass/trunk/raster/r.watershed/front/r.watershed.html	2009-06-27 10:55:30 UTC (rev 38094)
@@ -398,7 +398,7 @@
   r.thin in=rwater.course out=rwater.course.Thin
   r.colors -gn rwater.course.Thin color=grey
   r.to.vect in=rwater.course.Thin out=rwater_course feature=line
-  v.db.dropcol map=rwater_course column=label
+  v.db.dropcolumn map=rwater_course column=label
 </pre></div>
 <!-- can't set line attribute to catchment it is in as v.what.rast and
   v.distance only work for point features. Could create endpoint node
@@ -412,7 +412,7 @@
 <div class="code"><pre>
   r.watershed elev=elevation.dem basin=rwater.basin thresh=15000
   r.to.vect -s in=rwater.basin out=rwater_basins feature=area
-  v.db.dropcol map=rwater_basins column=label
+  v.db.dropcolumn map=rwater_basins column=label
   v.db.renamecol map=rwater_basins column=value,catchment
 </pre></div>
 <br>
Modified: grass/trunk/scripts/Makefile
--- grass/trunk/scripts/Makefile	2009-06-27 10:41:41 UTC (rev 38093)
+++ grass/trunk/scripts/Makefile	2009-06-27 10:55:30 UTC (rev 38094)
@@ -42,7 +42,7 @@
 	v.db.addcol \
 	v.db.addtable \
 	v.db.join \
-	v.db.dropcol \
+	v.db.dropcolumn \
 	v.db.droptable \
 	v.db.renamecol \
 	v.db.reconnect.all \
Modified: grass/trunk/scripts/db.dropcolumn/db.dropcolumn.html
--- grass/trunk/scripts/db.dropcolumn/db.dropcolumn.html	2009-06-27 10:41:41 UTC (rev 38093)
+++ grass/trunk/scripts/db.dropcolumn/db.dropcolumn.html	2009-06-27 10:55:30 UTC (rev 38094)
@@ -32,7 +32,7 @@
 <em><a HREF="db.droptable.html">db.droptable</a></em>,
 <em><a HREF="db.execute.html">db.execute</a></em>,
-<em><a HREF="v.db.dropcol.html">v.db.dropcol</a></em>
+<em><a HREF="v.db.dropcolumn.html">v.db.dropcolumn</a></em>
 <h2>AUTHOR</h2>
Modified: grass/trunk/scripts/v.colors/v.colors.py
--- grass/trunk/scripts/v.colors/v.colors.py	2009-06-27 10:41:41 UTC (rev 38093)
+++ grass/trunk/scripts/v.colors/v.colors.py	2009-06-27 10:55:30 UTC (rev 38094)
@@ -304,7 +304,7 @@
     else:
 	grass.run_command('g.remove', rast = tmp_colr)
-    #v.db.dropcol map=vcol_test col=GRASSRGB
+    #v.db.dropcolumn map=vcol_test col=GRASSRGB
     #d.vect -a vcol_test icon=basic/circle color=none size=8
 if __name__ == "__main__":
Modified: grass/trunk/scripts/v.db.addcol/v.db.addcol.html
--- grass/trunk/scripts/v.db.addcol/v.db.addcol.html	2009-06-27 10:41:41 UTC (rev 38093)
+++ grass/trunk/scripts/v.db.addcol/v.db.addcol.html	2009-06-27 10:55:30 UTC (rev 38094)
@@ -34,7 +34,7 @@
 <em><a HREF="v.db.addtable.html">v.db.addtable</a></em>,
 <em><a HREF="v.db.connect.html">v.db.connect</a></em>,
-<em><a HREF="v.db.dropcol.html">v.db.dropcol</a></em>,
+<em><a HREF="v.db.dropcolumn.html">v.db.dropcolumn</a></em>,
 <em><a HREF="v.db.droptable.html">v.db.droptable</a></em>,
 <em><a HREF="v.db.select.html">v.db.select</a></em>,
 <em><a HREF="v.db.update.html">v.db.update</a></em>
Modified: grass/trunk/scripts/v.db.addtable/v.db.addtable.html
--- grass/trunk/scripts/v.db.addtable/v.db.addtable.html	2009-06-27 10:41:41 UTC (rev 38093)
+++ grass/trunk/scripts/v.db.addtable/v.db.addtable.html	2009-06-27 10:55:30 UTC (rev 38094)
@@ -48,7 +48,7 @@
 <em><a HREF="v.category.html">v.category</a></em>,
 <em><a HREF="v.db.addcol.html">v.db.addcol</a></em>,
 <em><a HREF="v.db.update.html">v.db.update</a></em><br>
Modified: grass/trunk/scripts/v.db.dropcol/Makefile
--- grass/trunk/scripts/v.db.dropcol/Makefile	2009-06-27 10:41:41 UTC (rev 38093)
+++ grass/trunk/scripts/v.db.dropcol/Makefile	2009-06-27 10:55:30 UTC (rev 38094)
@@ -1,6 +1,6 @@
 MODULE_TOPDIR = ../..
-PGM = v.db.dropcol
+PGM = v.db.dropcolumn
 include $(MODULE_TOPDIR)/include/Make/Script.make
Deleted: grass/trunk/scripts/v.db.dropcol/v.db.dropcol.html
--- grass/trunk/scripts/v.db.dropcol/v.db.dropcol.html	2009-06-27 10:41:41 UTC (rev 38093)
+++ grass/trunk/scripts/v.db.dropcol/v.db.dropcol.html	2009-06-27 10:55:30 UTC (rev 38094)
@@ -1,38 +0,0 @@
-<h2>DESCRIPTION</h2>
-<em>v.db.dropcol</em> drops a column from the attribute table connected
-to a given vector map. It automatically checks the connection for the specified
-layer. <em>v.db.dropcol</em> omits to delete the 'cat' column which is
-relevant to keep the connection between vector map and table.
-<h2>NOTES</h2>
-v.db.dropcol is a front-end to <em>db.execute</em> to allow easier usage.
-The existing database connection(s) can be verified with <em>v.db.connect</em>.
-<h2>EXAMPLES</h2>
-Dropping a column:<br>
-<div class="code"><pre>
-v.db.dropcol sentiero_brenta_points column=slope
-v.info -c sentiero_brenta_points
-</pre></div>
-<h2>SEE ALSO</h2>
-<em><a HREF="db.droptable.html">db.droptable</a></em>,
-<em><a HREF="db.execute.html">db.execute</a></em>,
-<em><a HREF="v.db.addcol.html">v.db.addcol</a></em>,
-<em><a HREF="v.db.addtable.html">v.db.addtable</a></em>,
-<em><a HREF="v.db.connect.html">v.db.connect</a></em>,
-<em><a HREF="v.db.droptable.html">v.db.droptable</a></em>,
-<em><a HREF="v.db.select.html">v.db.select</a></em>,
-<em><a HREF="v.db.update.html">v.db.update</a></em>
-<h2>AUTHOR</h2>
-Markus Neteler
-<p><i>Last changed: $Date$</i>
Deleted: grass/trunk/scripts/v.db.dropcol/v.db.dropcol.py
--- grass/trunk/scripts/v.db.dropcol/v.db.dropcol.py	2009-06-27 10:41:41 UTC (rev 38093)
+++ grass/trunk/scripts/v.db.dropcol/v.db.dropcol.py	2009-06-27 10:55:30 UTC (rev 38094)
@@ -1,120 +0,0 @@
-#!/usr/bin/env python
-# MODULE:       v.db.dropcolumn
-# AUTHOR(S):    Markus Neteler
-#               Converted to Python by Glynn Clements
-# PURPOSE:      interface to db.execute to drop a column from the
-#               attribute table connected to a given vector map
-#               - Based on v.db.addcol
-#               - with special trick for SQLite
-# COPYRIGHT:    (C) 2007 by the GRASS Development Team
-#               This program is free software under the GNU General Public
-#               License (>=v2). Read the file COPYING that comes with GRASS
-#               for details.
-#%Module
-#%  description: Drops a column from the attribute table connected to a given vector map.
-#%  keywords: vector, database, attribute table
-#%End
-#%option
-#% key: map
-#% type: string
-#% gisprompt: old,vector,vector
-#% key_desc : name
-#% description: Vector map for which to drop attribute column
-#% required : yes
-#%end
-#%option
-#% key: layer
-#% type: integer
-#% description: Layer where to drop column
-#% answer: 1
-#% required : no
-#%end
-#%option
-#% key: column
-#% type: string
-#% description: Name of the column
-#% required : yes
-#%end
-import sys
-import os
-import string
-import grass.script as grass
-def main():
-    map = options['map']
-    layer = options['layer']
-    column = options['column']
-    mapset = grass.gisenv()['MAPSET']
-    # does map exist in CURRENT mapset?
-    if not grass.find_file(map, element = 'vector', mapset = mapset):
-	grass.fatal("Vector map <%s> not found in current mapset" % map)
-    f = grass.vector_layer_db(map, layer)
-    table = f['table']
-    keycol = f['key']
-    database = f['database']
-    driver = f['driver']
-    if not table:
-	grass.fatal("There is no table connected to the input vector map Cannot delete any column")
-    if column == keycol:
-	grass.fatal("Cannot delete <$col> column as it is needed to keep table <%s> connected to the input vector map <%s>" % (table, map))
-    if not grass.vector_columns(map, layer).has_key(column):
-	grass.fatal("Column <%s> not found in table <%s>" % (column, table))
-    if driver == "sqlite":
-	#echo "Using special trick for SQLite"
-	# http://www.sqlite.org/faq.html#q13
-	colnames = []
-	coltypes = []
-	for f in grass.db_describe(table)['cols']:
-	    if f[0] == column:
-		continue
-	    colnames.append(f[0])
-	    coltypes.append("%s %s" % (f[0], f[1]))
-	colnames = ", ".join(colnames)
-	coltypes = ", ".join(coltypes)
-	cmds = [
-	    "BEGIN TRANSACTION",
-	    "CREATE TEMPORARY TABLE ${table}_backup(${coldef})",
-	    "INSERT INTO ${table}_backup SELECT ${colnames} FROM ${table}",
-	    "DROP TABLE ${table}",
-	    "CREATE TABLE ${table}(${coldef})",
-	    "INSERT INTO ${table} SELECT ${colnames} FROM ${table}_backup",
-	    "DROP TABLE ${table}_backup",
-	    "COMMIT"
-	tmpl = string.Template(';\n'.join(cmds))
-	sql = tmpl.substitute(table = table, coldef = coltypes, colnames = colnames)
-    else:
-	sql = "ALTER TABLE %s DROP COLUMN %s" % (table, column)
-    if grass.write_command('db.execute', database = database, driver = driver,
-			   stdin = sql) != 0:
-	grass.fatal("Cannot continue (problem deleting column).")
-    # write cmd history:
-    grass.vector_history(map)
-if __name__ == "__main__":
-    options, flags = grass.parser()
-    main()
Copied: grass/trunk/scripts/v.db.dropcol/v.db.dropcolumn.html (from rev 38090, grass/trunk/scripts/v.db.dropcol/v.db.dropcol.html)
--- grass/trunk/scripts/v.db.dropcol/v.db.dropcolumn.html	                        (rev 0)
+++ grass/trunk/scripts/v.db.dropcol/v.db.dropcolumn.html	2009-06-27 10:55:30 UTC (rev 38094)
@@ -0,0 +1,38 @@
+<h2>DESCRIPTION</h2>
+<em>v.db.dropcolumn</em> drops a column from the attribute table connected
+to a given vector map. It automatically checks the connection for the specified
+layer. <em>v.db.dropcolumn</em> omits to delete the 'cat' column which is
+relevant to keep the connection between vector map and table.
+<h2>NOTES</h2>
+v.db.dropcolumn is a front-end to <em>db.execute</em> to allow easier usage.
+The existing database connection(s) can be verified with <em>v.db.connect</em>.
+<h2>EXAMPLES</h2>
+Dropping a column:<br>
+<div class="code"><pre>
+v.db.dropcolumn sentiero_brenta_points column=slope
+v.info -c sentiero_brenta_points
+</pre></div>
+<h2>SEE ALSO</h2>
+<em><a HREF="db.droptable.html">db.droptable</a></em>,
+<em><a HREF="db.execute.html">db.execute</a></em>,
+<em><a HREF="v.db.addcol.html">v.db.addcol</a></em>,
+<em><a HREF="v.db.addtable.html">v.db.addtable</a></em>,
+<em><a HREF="v.db.connect.html">v.db.connect</a></em>,
+<em><a HREF="v.db.droptable.html">v.db.droptable</a></em>,
+<em><a HREF="v.db.select.html">v.db.select</a></em>,
+<em><a HREF="v.db.update.html">v.db.update</a></em>
+<h2>AUTHOR</h2>
+Markus Neteler
+<p><i>Last changed: $Date$</i>
Property changes on: grass/trunk/scripts/v.db.dropcol/v.db.dropcolumn.html
___________________________________________________________________
Added: svn:mime-type
   + text/html
Added: svn:keywords
   + Author Date Id
Added: svn:mergeinfo
Added: svn:eol-style
   + native
Copied: grass/trunk/scripts/v.db.dropcol/v.db.dropcolumn.py (from rev 38090, grass/trunk/scripts/v.db.dropcol/v.db.dropcol.py)
--- grass/trunk/scripts/v.db.dropcol/v.db.dropcolumn.py	                        (rev 0)
+++ grass/trunk/scripts/v.db.dropcol/v.db.dropcolumn.py	2009-06-27 10:55:30 UTC (rev 38094)
@@ -0,0 +1,120 @@
+#!/usr/bin/env python
+# MODULE:       v.db.dropcolumn
+# AUTHOR(S):    Markus Neteler
+#               Converted to Python by Glynn Clements
+# PURPOSE:      interface to db.execute to drop a column from the
+#               attribute table connected to a given vector map
+#               - Based on v.db.addcol
+#               - with special trick for SQLite
+# COPYRIGHT:    (C) 2007 by the GRASS Development Team
+#               This program is free software under the GNU General Public
+#               License (>=v2). Read the file COPYING that comes with GRASS
+#               for details.
+#%Module
+#%  description: Drops a column from the attribute table connected to a given vector map.
+#%  keywords: vector, database, attribute table
+#%End
+#%option
+#% key: map
+#% type: string
+#% gisprompt: old,vector,vector
+#% key_desc : name
+#% description: Vector map for which to drop attribute column
+#% required : yes
+#%end
+#%option
+#% key: layer
+#% type: integer
+#% description: Layer where to drop column
+#% answer: 1
+#% required : no
+#%end
+#%option
+#% key: column
+#% type: string
+#% description: Name of the column
+#% required : yes
+#%end
+import sys
+import os
+import string
+import grass.script as grass
+def main():
+    map = options['map']
+    layer = options['layer']
+    column = options['column']
+    mapset = grass.gisenv()['MAPSET']
+    # does map exist in CURRENT mapset?
+    if not grass.find_file(map, element = 'vector', mapset = mapset):
+	grass.fatal("Vector map <%s> not found in current mapset" % map)
+    f = grass.vector_layer_db(map, layer)
+    table = f['table']
+    keycol = f['key']
+    database = f['database']
+    driver = f['driver']
+    if not table:
+	grass.fatal("There is no table connected to the input vector map Cannot delete any column")
+    if column == keycol:
+	grass.fatal("Cannot delete <$col> column as it is needed to keep table <%s> connected to the input vector map <%s>" % (table, map))
+    if not grass.vector_columns(map, layer).has_key(column):
+	grass.fatal("Column <%s> not found in table <%s>" % (column, table))
+    if driver == "sqlite":
+	#echo "Using special trick for SQLite"
+	# http://www.sqlite.org/faq.html#q13
+	colnames = []
+	coltypes = []
+	for f in grass.db_describe(table)['cols']:
+	    if f[0] == column:
+		continue
+	    colnames.append(f[0])
+	    coltypes.append("%s %s" % (f[0], f[1]))
+	colnames = ", ".join(colnames)
+	coltypes = ", ".join(coltypes)
+	cmds = [
+	    "BEGIN TRANSACTION",
+	    "CREATE TEMPORARY TABLE ${table}_backup(${coldef})",
+	    "INSERT INTO ${table}_backup SELECT ${colnames} FROM ${table}",
+	    "DROP TABLE ${table}",
+	    "CREATE TABLE ${table}(${coldef})",
+	    "INSERT INTO ${table} SELECT ${colnames} FROM ${table}_backup",
+	    "DROP TABLE ${table}_backup",
+	    "COMMIT"
+	tmpl = string.Template(';\n'.join(cmds))
+	sql = tmpl.substitute(table = table, coldef = coltypes, colnames = colnames)
+    else:
+	sql = "ALTER TABLE %s DROP COLUMN %s" % (table, column)
+    if grass.write_command('db.execute', database = database, driver = driver,
+			   stdin = sql) != 0:
+	grass.fatal("Cannot continue (problem deleting column).")
+    # write cmd history:
+    grass.vector_history(map)
+if __name__ == "__main__":
+    options, flags = grass.parser()
+    main()
Property changes on: grass/trunk/scripts/v.db.dropcol/v.db.dropcolumn.py
Added: svn:executable
   + native
Modified: grass/trunk/scripts/v.db.droptable/v.db.droptable.html
--- grass/trunk/scripts/v.db.droptable/v.db.droptable.html	2009-06-27 10:41:41 UTC (rev 38093)
+++ grass/trunk/scripts/v.db.droptable/v.db.droptable.html	2009-06-27 10:55:30 UTC (rev 38094)
@@ -25,7 +25,7 @@
Modified: grass/trunk/scripts/v.db.renamecol/v.db.renamecol.html
--- grass/trunk/scripts/v.db.renamecol/v.db.renamecol.html	2009-06-27 10:41:41 UTC (rev 38093)
+++ grass/trunk/scripts/v.db.renamecol/v.db.renamecol.html	2009-06-27 10:55:30 UTC (rev 38094)
@@ -37,7 +37,7 @@
Modified: grass/trunk/scripts/v.db.renamecol/v.db.renamecol.py
--- grass/trunk/scripts/v.db.renamecol/v.db.renamecol.py	2009-06-27 10:41:41 UTC (rev 38093)
+++ grass/trunk/scripts/v.db.renamecol/v.db.renamecol.py	2009-06-27 10:55:30 UTC (rev 38094)
@@ -7,7 +7,7 @@
-#               - Based on v.db.dropcol
+#               - Based on v.db.dropcolumn
 #               - with special trick for SQLite and DBF (here the new col is
 #                 added/values copied/old col deleted)
@@ -105,7 +105,7 @@
 	grass.run_command('v.db.addcol', map = map, layer = layer, column = colspec)
 	sql = "UPDATE %s SET %s=%s" % (table, newcol, oldcol)
 	grass.write_command('db.execute', database = database, driver = driver, stdin = sql)
-	grass.run_command('v.db.dropcol', map = map, layer = layer, column = oldcol)
+	grass.run_command('v.db.dropcolumn', map = map, layer = layer, column = oldcol)
     else:
 	sql = "ALTER TABLE %s RENAME %s TO %s" % (table, oldcol, newcol)
Modified: grass/trunk/vector/v.db.connect/v.db.connect.html
--- grass/trunk/vector/v.db.connect/v.db.connect.html	2009-06-27 10:41:41 UTC (rev 38093)
+++ grass/trunk/vector/v.db.connect/v.db.connect.html	2009-06-27 10:55:30 UTC (rev 38094)
@@ -196,7 +196,7 @@
 <a HREF="v.db.addtable.html">v.db.addtable</a>,
 <a HREF="v.db.droptable.html">v.db.droptable</a>,
 <a HREF="v.db.addcol.html">v.db.addcol</a>,
-<a HREF="v.db.dropcol.html">v.db.dropcol</a>,
+<a HREF="v.db.dropcolumn.html">v.db.dropcolumn</a>,
 <a HREF="v.external.html">v.external</a>,
 <a HREF="v.in.db.html">v.in.db</a>,
 <a HREF="v.overlay.html">v.overlay</a>
Modified: grass/trunk/vector/v.transform/v.transform.html
--- grass/trunk/vector/v.transform/v.transform.html	2009-06-27 10:41:41 UTC (rev 38093)
+++ grass/trunk/vector/v.transform/v.transform.html	2009-06-27 10:55:30 UTC (rev 38094)
@@ -99,7 +99,7 @@
 # perform transformation to 3D
 v.transform -t myarchsites output=myarchsites3d column="zshift:zs" table=myarchsites
 # drop table containing transformation parameters
-v.db.dropcol myarchsites3d col=zs
+v.db.dropcolumn myarchsites3d col=zs
 </pre></div>
 The resulting map is a 3D vector map.
Modified: grass/trunk/vector/v.vol.rst/v.vol.rst.html
--- grass/trunk/vector/v.vol.rst/v.vol.rst.html	2009-06-27 10:41:41 UTC (rev 38093)
+++ grass/trunk/vector/v.vol.rst/v.vol.rst.html	2009-06-27 10:55:30 UTC (rev 38094)
@@ -86,9 +86,9 @@
 v.info -t elevrand_3d
 # remove the now superfluous 'x', 'y' and 'value' (z) columns
-v.db.dropcol elevrand_3d col=x
-v.db.dropcol elevrand_3d col=y
-v.db.dropcol elevrand_3d col=value
+v.db.dropcolumn elevrand_3d col=x
+v.db.dropcolumn elevrand_3d col=y
+v.db.dropcolumn elevrand_3d col=value
 # add attribute to interpolate
 # (Soil range types taken from the USDA Soil Survey)
Modified: grass/trunk/vector/vectorintro.html
--- grass/trunk/vector/vectorintro.html	2009-06-27 10:41:41 UTC (rev 38093)
+++ grass/trunk/vector/vectorintro.html	2009-06-27 10:55:30 UTC (rev 38094)
@@ -198,7 +198,7 @@
 However, this can be performed in a single step using <a href="v.db.addtable.html">v.db.addtable</a>
 along with the definition of table column types. Column adding and dropping
 can be done with <a HREF="v.db.addcol.html">v.db.addcol</a> and
-<a HREF="v.db.dropcol.html">v.db.dropcol</a>. A table column can be renamed with
+<a HREF="v.db.dropcolumn.html">v.db.dropcolumn</a>. A table column can be renamed with
 <a HREF="v.db.renamecol.html">v.db.renamecol</a>. To drop a table from a map, use
 <a HREF="v.db.droptable.html">v.db.droptable</a>. Values in a table can be updated
 with <a HREF="v.db.update.html">v.db.update</a>. Tables can be joined with with
