[GRASS-SVN] r38099 - in grass/trunk: display/d.colors
display/d.histogram display/d.legend display/d.what.rast
imagery/i.gensig imagery/i.gensigset imagery/i.maxlik
imagery/i.smap include lib/g3d lib/ogsf lib/raster ps/ps.map
raster/r.buffer raster/r.category raster/r.compress
raster/r.cross raster/r.digit raster/r.distance raster/r.grow
raster/r.in.poly raster/r.kappa raster/r.le/r.le.patch
raster/r.le/r.le.pixel raster/r.mapcalc raster/r.mode
raster/r.neighbors raster/r.null raster/r.param.scale
raster/r.patch raster/r.random raster/r.random.surface
raster/r.reclass raster/r.report raster/r.resample
raster/r.slope.aspect raster/r.statistics
raster/r.statistics2 raster/r.stats raster/r.to.vect
raster/r.volume raster/r.watershed/shed raster/r.what
swig/perl/R_slope_aspect/r_slope_aspect vector/v.to.rast
svn_grass at osgeo.org
Sat Jun 27 12:25:07 EDT 2009
Author: martinl
Date: 2009-06-27 12:25:06 -0400 (Sat, 27 Jun 2009)
New Revision: 38099
grass/trunk/display/d.colors/curses.c
grass/trunk/display/d.histogram/bar.c
grass/trunk/display/d.histogram/get_stats.c
grass/trunk/display/d.histogram/pie.c
grass/trunk/display/d.legend/main.c
grass/trunk/display/d.what.rast/what.c
grass/trunk/imagery/i.gensig/get_train.c
grass/trunk/imagery/i.gensigset/get_train.c
grass/trunk/imagery/i.maxlik/main.c
grass/trunk/imagery/i.smap/labels.c
grass/trunk/include/raster.h
grass/trunk/lib/g3d/g3dcats.c
grass/trunk/lib/g3d/g3dclose.c
grass/trunk/lib/ogsf/Gs3.c
grass/trunk/lib/ogsf/gsd_legend.c
grass/trunk/lib/raster/cats.c
grass/trunk/lib/raster/sample.c
grass/trunk/ps/ps.map/ps_clrtbl.c
grass/trunk/raster/r.buffer/support.c
grass/trunk/raster/r.category/main.c
grass/trunk/raster/r.compress/main.c
grass/trunk/raster/r.cross/cats.c
grass/trunk/raster/r.digit/get_label.c
grass/trunk/raster/r.distance/labels.c
grass/trunk/raster/r.grow/Makefile
grass/trunk/raster/r.grow/main.c
grass/trunk/raster/r.in.poly/get_item.c
grass/trunk/raster/r.kappa/prt_label.c
grass/trunk/raster/r.le/r.le.patch/trace.c
grass/trunk/raster/r.le/r.le.pixel/cellclip.c
grass/trunk/raster/r.le/r.le.pixel/driver.c
grass/trunk/raster/r.le/r.le.pixel/texture.c
grass/trunk/raster/r.mapcalc/map.c
grass/trunk/raster/r.mapcalc/map3.c
grass/trunk/raster/r.mode/main.c
grass/trunk/raster/r.neighbors/divr_cats.c
grass/trunk/raster/r.neighbors/intr_cats.c
grass/trunk/raster/r.neighbors/null_cats.c
grass/trunk/raster/r.null/main.c
grass/trunk/raster/r.param.scale/param.h
grass/trunk/raster/r.param.scale/write_cats.c
grass/trunk/raster/r.patch/support.c
grass/trunk/raster/r.random.surface/save.c
grass/trunk/raster/r.random/support.c
grass/trunk/raster/r.reclass/parse.c
grass/trunk/raster/r.reclass/reclass.c
grass/trunk/raster/r.report/prt_report.c
grass/trunk/raster/r.resample/main.c
grass/trunk/raster/r.slope.aspect/main.c
grass/trunk/raster/r.statistics/o_adev.c
grass/trunk/raster/r.statistics/o_average.c
grass/trunk/raster/r.statistics/o_divr.c
grass/trunk/raster/r.statistics/o_kurt.c
grass/trunk/raster/r.statistics/o_max.c
grass/trunk/raster/r.statistics/o_median.c
grass/trunk/raster/r.statistics/o_min.c
grass/trunk/raster/r.statistics/o_mode.c
grass/trunk/raster/r.statistics/o_sdev.c
grass/trunk/raster/r.statistics/o_skew.c
grass/trunk/raster/r.statistics/o_sum.c
grass/trunk/raster/r.statistics/o_var.c
grass/trunk/raster/r.statistics2/main.c
grass/trunk/raster/r.stats/raw_stats.c
grass/trunk/raster/r.stats/stats.c
grass/trunk/raster/r.to.vect/areas_io.c
grass/trunk/raster/r.to.vect/util.c
grass/trunk/raster/r.volume/main.c
grass/trunk/raster/r.watershed/shed/print.c
grass/trunk/raster/r.what/main.c
grass/trunk/swig/perl/R_slope_aspect/r_slope_aspect/r_slope_aspect.c
grass/trunk/vector/v.to.rast/support.c
rasterlib: fns from cats.c cleaned up, see http://trac.osgeo.org/grass/wiki/Grass7/RasterLib
Modified: grass/trunk/display/d.colors/curses.c
--- grass/trunk/display/d.colors/curses.c 2009-06-27 11:05:11 UTC (rev 38098)
+++ grass/trunk/display/d.colors/curses.c 2009-06-27 16:25:06 UTC (rev 38099)
@@ -85,18 +85,18 @@
if (at_cat == current_cat) {
if (!at_cat)
sprintf(buffer, "-> %3s %s", "N",
- Rast_get_c_raster_cat(&tmp, pcats));
+ Rast_get_c_cat(&tmp, pcats));
else
sprintf(buffer, "-> %3d %s", at_cat - 1,
- Rast_get_cat(at_cat - 1, pcats));
+ Rast_get_c_cat(at_cat - 1, pcats));
else {
if (!at_cat)
sprintf(buffer, " %3s %s", "N",
else
sprintf(buffer, " %3d %s", at_cat - 1,
wmove(CAT_WIN, at_line++, 1);
waddstr(CAT_WIN, buffer);
Modified: grass/trunk/display/d.histogram/bar.c
--- grass/trunk/display/d.histogram/bar.c 2009-06-27 11:05:11 UTC (rev 38098)
+++ grass/trunk/display/d.histogram/bar.c 2009-06-27 16:25:06 UTC (rev 38099)
@@ -216,7 +216,7 @@
/* draw the bar as a box */
if (!Rast_is_c_null_value(&bar_color) && is_fp) {
if (cat_ranges)
- Rast_get_ith_d_raster_cat(&cats, bar_color,
+ Rast_get_ith_d_cat(&cats, bar_color,
&dmin, &dmax);
else {
dmin = range_dmin + i * (range_dmax - range_dmin) / nsteps;
@@ -269,7 +269,7 @@
/* draw the bar as a line */
if (is_fp) {
if (cat_ranges)
&dmin, &dmax);
else {
Modified: grass/trunk/display/d.histogram/get_stats.c
--- grass/trunk/display/d.histogram/get_stats.c 2009-06-27 11:05:11 UTC (rev 38098)
+++ grass/trunk/display/d.histogram/get_stats.c 2009-06-27 16:25:06 UTC (rev 38099)
@@ -54,9 +54,9 @@
is_fp = Rast_raster_map_is_fp(mapname, "");
if (is_fp) {
if (cat_ranges) {
- if (Rast_read_raster_cats(mapname, "", &cats) < 0)
+ if (Rast_read_cats(mapname, "", &cats) < 0)
G_fatal_error("Can't read category file");
- if (Rast_number_of_raster_cats(&cats) <= 0) {
+ if (Rast_number_of_cats(&cats) <= 0) {
G_warning("There are no labeled cats, using nsteps argument");
cat_ranges = 0;
Modified: grass/trunk/display/d.histogram/pie.c
--- grass/trunk/display/d.histogram/pie.c 2009-06-27 11:05:11 UTC (rev 38098)
+++ grass/trunk/display/d.histogram/pie.c 2009-06-27 16:25:06 UTC (rev 38099)
@@ -187,7 +187,7 @@
draw = YES;
if (is_fp) {
if (cat_ranges)
- Rast_get_ith_d_raster_cat(&cats, (CELL) i, &dmin, &dmax);
+ Rast_get_ith_d_cat(&cats, (CELL) i, &dmin, &dmax);
else {
dmax = range_dmin + (i + 1) * (range_dmax - range_dmin) / nsteps;
@@ -227,7 +227,7 @@
draw = YES;
if (is_fp) {
if (cat_ranges)
else {
Modified: grass/trunk/display/d.legend/main.c
--- grass/trunk/display/d.legend/main.c 2009-06-27 11:05:11 UTC (rev 38098)
+++ grass/trunk/display/d.legend/main.c 2009-06-27 16:25:06 UTC (rev 38099)
@@ -372,9 +372,9 @@
for (i = min_ind, j = 1, k = 0; j <= do_cats && i <= max_ind;
j++, i += thin) {
if (!flip)
- cstr = Rast_get_cat(i, &cats);
+ cstr = Rast_get_c_cat(&i, &cats);
else
- cstr = Rast_get_cat((max_ind - (i - min_ind)), &cats);
+ cstr = Rast_get_c_cat((max_ind - (i - min_ind)), &cats);
if (!use_catlist)
catlist[j - 1] = (double)i;
@@ -405,7 +405,7 @@
opt8->answers[i], min_ind, max_ind);
- cstr = Rast_get_cat(catlist[i], &cats);
+ cstr = Rast_get_c_cat(&(catlist[i]), &cats);
if (!cstr[0]) { /* no cat label found, skip str output */
if (hide_nodata)
continue;
@@ -604,7 +604,7 @@
max_ind - k * (double)(max_ind - min_ind) / (steps -
1);
- cstr = Rast_get_cat(tcell, &cats);
+ cstr = Rast_get_c_cat(tcell, &cats);
if (!cstr[0]) /* no cats found, disable str output */
hide_catstr = 1;
else
@@ -780,9 +780,9 @@
/* for(i=min_ind, j=1, k=0; j<=do_cats && i<=max_ind; j++, i+=thin) */
if (!flip)
else
- cstr = Rast_get_cat(catlist[catlistCount - i - 1], &cats);
+ cstr = Rast_get_c_cat(&(catlist[catlistCount - i - 1]), &cats);
Modified: grass/trunk/display/d.what.rast/what.c
--- grass/trunk/display/d.what.rast/what.c 2009-06-27 11:05:11 UTC (rev 38098)
+++ grass/trunk/display/d.what.rast/what.c 2009-06-27 16:25:06 UTC (rev 38099)
@@ -61,7 +61,7 @@
"ERROR reading raster map", terse, fs, map_type[i]);
else if (map_type[i] == CELL_TYPE) {
show_cat(width, mwidth, name[i], mapset[i], buf[col],
- Rast_get_c_raster_cat(&buf[col], &cats[i]), terse, fs,
+ Rast_get_c_cat(&buf[col], &cats[i]), terse, fs,
map_type[i]);
continue;
@@ -79,7 +79,7 @@
"ERROR reading fcell file", terse, fs);
else
show_dval(width, mwidth, name[i], mapset[i], dbuf[col],
- Rast_get_d_raster_cat(&dbuf[col], &cats[i]), terse,
+ Rast_get_d_cat(&dbuf[col], &cats[i]), terse,
fs);
Modified: grass/trunk/imagery/i.gensig/get_train.c
--- grass/trunk/imagery/i.gensig/get_train.c 2009-06-27 11:05:11 UTC (rev 38098)
+++ grass/trunk/imagery/i.gensig/get_train.c 2009-06-27 16:25:06 UTC (rev 38099)
@@ -48,7 +48,7 @@
S->sig[n].status = 1;
S->sig[n].npoints = count;
strncpy(S->sig[n].desc,
- Rast_get_cat(cat, &files->training_labels),
+ Rast_get_c_cat(&cat, &files->training_labels),
sizeof(S->sig[n].desc)
n++;
Modified: grass/trunk/imagery/i.gensigset/get_train.c
--- grass/trunk/imagery/i.gensigset/get_train.c 2009-06-27 11:05:11 UTC (rev 38098)
+++ grass/trunk/imagery/i.gensigset/get_train.c 2009-06-27 16:25:06 UTC (rev 38099)
@@ -48,7 +48,7 @@
while (Rast_next_cell_stat(&cat, &count, &cell_stats)) {
if (count > 1) {
Sig = I_NewClassSig(S);
- I_SetClassTitle(Sig, Rast_get_cat(cat, &files->training_labels));
+ I_SetClassTitle(Sig, Rast_get_c_cat(&cat, &files->training_labels));
Sig->classnum = cat;
/* initialize this class with maxsubclasses (by allocating them) */
for (i = 0; i < parms->maxsubclasses; i++)
Modified: grass/trunk/imagery/i.maxlik/main.c
--- grass/trunk/imagery/i.maxlik/main.c 2009-06-27 11:05:11 UTC (rev 38098)
+++ grass/trunk/imagery/i.maxlik/main.c 2009-06-27 16:25:06 UTC (rev 38099)
@@ -38,6 +38,7 @@
char *class_name, *reject_name;
double *B;
double *P;
+CELL cat;
int main(int argc, char *argv[])
@@ -123,39 +124,30 @@
if (reject_fd > 0)
Rast_close_cell(reject_fd);
- Rast_init_cats((CELL) S.nsigs, "Maximum Likelihood Classification", &cats);
+ Rast_init_cats("Maximum Likelihood Classification", &cats);
for (i = 0; i < S.nsigs; i++) {
- if (*S.sig[i].desc)
- Rast_set_cat((CELL) (i + 1), S.sig[i].desc, &cats);
+ if (*S.sig[i].desc) {
+ cat = i + 1;
+ Rast_set_c_cat(&cat, &cat, S.sig[i].desc, &cats);
Rast_write_cats(class_name, &cats);
Rast_free_cats(&cats);
if (reject_fd > 0) {
char title[100];
+ char *label[] = { "no data", "0.1%", "0.5%",
+ "1%", "2%", "5%", "10%",
+ "20%", "30%", "50%", "70%",
+ "80%", "90%", "95%", "98%",
+ "99%", "100%", "bad" };
sprintf(title, "Rejection Probability for %s", class_name);
- Rast_init_cats((CELL) 17, title, &cats);
+ Rast_init_cats(title, &cats);
Rast_set_cats_title(title, &cats);
- Rast_set_cat((CELL) 0, "no data", &cats);
- Rast_set_cat((CELL) 1, "0.1%", &cats);
- Rast_set_cat((CELL) 2, "0.5%", &cats);
- Rast_set_cat((CELL) 3, "1%", &cats);
- Rast_set_cat((CELL) 4, "2%", &cats);
- Rast_set_cat((CELL) 5, "5%", &cats);
- Rast_set_cat((CELL) 6, "10%", &cats);
- Rast_set_cat((CELL) 7, "20%", &cats);
- Rast_set_cat((CELL) 8, "30%", &cats);
- Rast_set_cat((CELL) 9, "50%", &cats);
- Rast_set_cat((CELL) 10, "70%", &cats);
- Rast_set_cat((CELL) 11, "80%", &cats);
- Rast_set_cat((CELL) 12, "90%", &cats);
- Rast_set_cat((CELL) 13, "95%", &cats);
- Rast_set_cat((CELL) 14, "98%", &cats);
- Rast_set_cat((CELL) 15, "99%", &cats);
- Rast_set_cat((CELL) 16, "100%", &cats);
- Rast_set_cat((CELL) 17, "bad", &cats);
+ for(i = 0; i < (int) (sizeof(label) / sizeof (char *)); i++) {
+ Rast_set_c_cat(&i, &i, label[i], &cats);
Rast_write_cats(reject_name, &cats);
Modified: grass/trunk/imagery/i.smap/labels.c
--- grass/trunk/imagery/i.smap/labels.c 2009-06-27 11:05:11 UTC (rev 38098)
+++ grass/trunk/imagery/i.smap/labels.c 2009-06-27 16:25:06 UTC (rev 38099)
@@ -8,10 +8,12 @@
int n;
struct ClassSig *C;
- Rast_init_cats((CELL) 0, S->title, &files->output_labels);
+ Rast_init_cats(S->title, &files->output_labels);
for (n = 0; n < S->nclasses; n++) {
C = &S->ClassSig[n];
- Rast_set_cat((CELL) C->classnum, C->title, &files->output_labels);
+ Rast_set_c_cat((CELL*) &(C->classnum),
+ (CELL*) &(C->classnum),
+ C->title, &files->output_labels);
return 0;
Modified: grass/trunk/include/raster.h
--- grass/trunk/include/raster.h 2009-06-27 11:05:11 UTC (rev 38098)
+++ grass/trunk/include/raster.h 2009-06-27 16:25:06 UTC (rev 38099)
@@ -21,57 +21,47 @@
/* cats.c */
int Rast_read_cats(const char *, const char *, struct Categories *);
-int Rast_read_raster_cats(const char *, const char *, struct Categories *);
int Rast_read_vector_cats(const char *, const char *, struct Categories *);
-CELL Rast_number_of_cats(const char *, const char *);
+CELL Rast_get_max_c_cat(const char *, const char *);
char *Rast_get_cats_title(const struct Categories *);
-char *Rast_get_raster_cats_title(const struct Categories *);
-char *Rast_get_cat(CELL, struct Categories *);
-char *Rast_get_c_raster_cat(CELL *, struct Categories *);
-char *Rast_get_f_raster_cat(FCELL *, struct Categories *);
-char *Rast_get_d_raster_cat(DCELL *, struct Categories *);
-char *Rast_get_raster_cat(void *, struct Categories *, RASTER_MAP_TYPE);
-void Rast_unmark_raster_cats(struct Categories *);
-void Rast_mark_c_raster_cats(const CELL *, int, struct Categories *);
-void Rast_mark_f_raster_cats(const FCELL *, int, struct Categories *);
-void Rast_mark_d_raster_cats(const DCELL *, int, struct Categories *);
-int Rast_mark_raster_cats(const void *, int, struct Categories *, RASTER_MAP_TYPE);
-void Rast_rewind_raster_cats(struct Categories *);
-char *Rast_get_next_marked_d_raster_cat(struct Categories *, DCELL *, DCELL *,
+char *Rast_get_c_cat(CELL *, struct Categories *);
+char *Rast_get_f_cat(FCELL *, struct Categories *);
+char *Rast_get_d_cat(DCELL *, struct Categories *);
+char *Rast_get_cat(void *, struct Categories *, RASTER_MAP_TYPE);
+void Rast_unmark_cats(struct Categories *);
+void Rast_mark_c_cats(const CELL *, int, struct Categories *);
+void Rast_mark_f_cats(const FCELL *, int, struct Categories *);
+void Rast_mark_d_cats(const DCELL *, int, struct Categories *);
+int Rast_mark_cats(const void *, int, struct Categories *, RASTER_MAP_TYPE);
+void Rast_rewind_cats(struct Categories *);
+char *Rast_get_next_marked_d_cat(struct Categories *, DCELL *, DCELL *,
+ long *);
+char *Rast_get_next_marked_c_cat(struct Categories *, CELL *, CELL *,
+ long *);
+char *Rast_get_next_marked_f_cat(struct Categories *, FCELL *, FCELL *,
long *);
-char *Rast_get_next_marked_c_raster_cat(struct Categories *, CELL *, CELL *,
- long *);
-char *Rast_get_next_marked_f_raster_cat(struct Categories *, FCELL *, FCELL *,
- long *);
-char *Rast_get_next_marked_raster_cat(struct Categories *, void *, void *,
- long *, RASTER_MAP_TYPE);
-int Rast_set_cat(CELL, const char *, struct Categories *);
-int Rast_set_c_raster_cat(const CELL *, const CELL *, const char *, struct Categories *);
-int Rast_set_f_raster_cat(const FCELL *, const FCELL *, const char *, struct Categories *);
-int Rast_set_d_raster_cat(const DCELL *, const DCELL *, const char *, struct Categories *);
-int Rast_set_raster_cat(const void *, const void *, const char *, struct Categories *,
- RASTER_MAP_TYPE);
+char *Rast_get_next_marked_cat(struct Categories *, void *, void *,
+ long *, RASTER_MAP_TYPE);
+int Rast_set_c_cat(const CELL *, const CELL *, const char *, struct Categories *);
+int Rast_set_f_cat(const FCELL *, const FCELL *, const char *, struct Categories *);
+int Rast_set_d_cat(const DCELL *, const DCELL *, const char *, struct Categories *);
+int Rast_set_cat(const void *, const void *, const char *, struct Categories *,
+ RASTER_MAP_TYPE);
int Rast_write_cats(const char *, struct Categories *);
-int Rast_write_raster_cats(const char *, struct Categories *);
int Rast_write_vector_cats(const char *, struct Categories *);
-char *Rast_get_ith_d_raster_cat(const struct Categories *, int, DCELL *,
- DCELL *);
-char *Rast_get_ith_f_raster_cat(const struct Categories *, int, void *, void *);
-char *Rast_get_ith_c_raster_cat(const struct Categories *, int, void *, void *);
-char *Rast_get_ith_raster_cat(const struct Categories *, int, void *, void *,
- RASTER_MAP_TYPE);
-void Rast_init_cats(CELL, const char *, struct Categories *);
-void Rast_init_raster_cats(const char *, struct Categories *);
+char *Rast_get_ith_d_cat(const struct Categories *, int, DCELL *,
+ DCELL *);
+char *Rast_get_ith_f_cat(const struct Categories *, int, void *, void *);
+char *Rast_get_ith_c_cat(const struct Categories *, int, void *, void *);
+char *Rast_get_ith_cat(const struct Categories *, int, void *, void *,
+ RASTER_MAP_TYPE);
+void Rast_init_cats(const char *, struct Categories *);
void Rast_set_cats_title(const char *, struct Categories *);
-void Rast_set_raster_cats_title(const char *, struct Categories *);
void Rast_set_cats_fmt(const char *, double, double, double, double,
- struct Categories *);
-void Rast_set_raster_cats_fmt(const char *, double, double, double, double,
void Rast_free_cats(struct Categories *);
-void Rast_free_raster_cats(struct Categories *);
-void Rast_copy_raster_cats(struct Categories *, const struct Categories *);
-int Rast_number_of_raster_cats(struct Categories *);
+void Rast_copy_cats(struct Categories *, const struct Categories *);
+int Rast_number_of_cats(struct Categories *);
int Rast_sort_cats(struct Categories *);
/* cell_stats.c */
Modified: grass/trunk/lib/g3d/g3dcats.c
--- grass/trunk/lib/g3d/g3dcats.c 2009-06-27 11:05:11 UTC (rev 38098)
+++ grass/trunk/lib/g3d/g3dcats.c 2009-06-27 16:25:06 UTC (rev 38099)
@@ -52,7 +52,7 @@
/* write the cat numbers:label */
for (i = 0; i < Rast_quant_nof_rules(&cats->q); i++) {
- descr = Rast_get_ith_d_raster_cat(cats, i, &val1, &val2);
+ descr = Rast_get_ith_d_cat(cats, i, &val1, &val2);
if ((cats->fmt && cats->fmt[0]) || (descr && descr[0])) {
if (val1 == val2) {
sprintf(str1, "%.10f", val1);
@@ -104,7 +104,7 @@
goto error;
G_strip(buff);
- Rast_init_raster_cats(buff, pcats);
+ Rast_init_cats(buff, pcats);
if (num >= 0)
pcats->num = num;
@@ -119,7 +119,7 @@
goto error;
if (sscanf(buff, "%f %f %f %f", &m1, &a1, &m2, &a2) != 4)
goto error;
- Rast_set_raster_cats_fmt(fmt, m1, a1, m2, a2, pcats);
+ Rast_set_cats_fmt(fmt, m1, a1, m2, a2, pcats);
/* Read all category names */
@@ -130,7 +130,7 @@
break;
if (old)
- Rast_set_cat(cat, buff, pcats);
+ Rast_set_c_cat(&cat, &cat, buff, pcats);
else {
*label = 0;
if (sscanf(buff, "%1s", label) != 1)
@@ -141,11 +141,11 @@
/* try to read a range of data */
if (sscanf(buff, "%lf:%lf:%[^\n]", &val1, &val2, label) == 3)
- Rast_set_raster_cat(&val1, &val2, label, pcats, DCELL_TYPE);
+ Rast_set_cat(&val1, &val2, label, pcats, DCELL_TYPE);
else if (sscanf(buff, "%d:%[^\n]", &cat, label) >= 1)
- Rast_set_raster_cat(&cat, &cat, label, pcats, CELL_TYPE);
+ Rast_set_cat(&cat, &cat, label, pcats, CELL_TYPE);
else if (sscanf(buff, "%lf:%[^\n]", &val1, label) >= 1)
- Rast_set_raster_cat(&val1, &val1, label, pcats, DCELL_TYPE);
+ Rast_set_cat(&val1, &val1, label, pcats, DCELL_TYPE);
else
goto error;
Modified: grass/trunk/lib/g3d/g3dclose.c
--- grass/trunk/lib/g3d/g3dclose.c 2009-06-27 11:05:11 UTC (rev 38098)
+++ grass/trunk/lib/g3d/g3dclose.c 2009-06-27 16:25:06 UTC (rev 38099)
@@ -21,7 +21,7 @@
G3d_removeColor(map->fileName);
/* create empty cats file */
- Rast_init_raster_cats(NULL, &cats);
+ Rast_init_cats(NULL, &cats);
G3d_writeCats(map->fileName, &cats);
Modified: grass/trunk/lib/ogsf/Gs3.c
--- grass/trunk/lib/ogsf/Gs3.c 2009-06-27 11:05:11 UTC (rev 38098)
+++ grass/trunk/lib/ogsf/Gs3.c 2009-06-27 16:25:06 UTC (rev 38099)
@@ -849,11 +849,11 @@
else if (Rast_is_c_null_value(&buf[dcol])) {
sprintf(catstr, "(NULL) %s",
- Rast_get_c_raster_cat(&buf[dcol], &cats));
+ Rast_get_c_cat(&buf[dcol], &cats));
else {
sprintf(catstr, "(%d) %s", buf[dcol],
G_free(buf);
@@ -868,11 +868,11 @@
else if (Rast_is_d_null_value(&dbuf[dcol])) {
- Rast_get_d_raster_cat(&dbuf[dcol], &cats));
+ Rast_get_d_cat(&dbuf[dcol], &cats));
else {
sprintf(catstr, "(%g) %s", dbuf[dcol],
G_free(dbuf);
Modified: grass/trunk/lib/ogsf/gsd_legend.c
--- grass/trunk/lib/ogsf/gsd_legend.c 2009-06-27 11:05:11 UTC (rev 38098)
+++ grass/trunk/lib/ogsf/gsd_legend.c 2009-06-27 16:25:06 UTC (rev 38099)
@@ -403,7 +403,7 @@
if (is_fp) {
tdcell = discrete ? Listcats[k] : labvals[k];
if (cat_labs) {
- cstr = Rast_get_d_raster_cat(&tdcell, &cats);
+ cstr = Rast_get_d_cat(&tdcell, &cats);
if (cat_labs && !cat_vals) {
sprintf(buff, "%s", cstr);
@@ -424,10 +424,10 @@
tcell = discrete ? Listnum ?
Listcats[k] : min + k : labvals[k];
- sprintf(buff, "%s", Rast_get_cat(tcell, &cats));
+ sprintf(buff, "%s", Rast_get_c_cat(&tcell, &cats));
else {
if (cat_labs && cat_vals) {
+ cstr = Rast_get_c_cat(&tcell, &cats);
if (cstr[0])
sprintf(buff, "%*d) %s", iprec, tcell, cstr);
else
@@ -635,9 +635,9 @@
labpos = 1. - labpos;
if (cat_labs) {
if (!is_fp)
else
Modified: grass/trunk/lib/raster/cats.c
--- grass/trunk/lib/raster/cats.c 2009-06-27 11:05:11 UTC (rev 38098)
+++ grass/trunk/lib/raster/cats.c 2009-06-27 16:25:06 UTC (rev 38099)
@@ -89,14 +89,12 @@
* \brief Read raster category file
- * \todo Remove, the function Rast_read_raster_cats()
* The category file for raster map <i>name</i> in <i>mapset</i> is
* read into the <i>cats</i> structure. If there is an error reading
* the category file, a diagnostic message is printed and -1 is
* returned. Otherwise, 0 is returned.
- * \param name map name
+ * \param name raster map name
* \param mapset mapset name
* \param[out] cats pointer to Cats structure
@@ -104,44 +102,21 @@
* \return 0 on success
int Rast_read_cats(const char *name,
- const char *mapset, struct Categories *pcats)
+ const char *mapset, struct Categories *pcats)
- return Rast_read_raster_cats(name, mapset, pcats);
- * \brief Read raster category file
- * The category file for raster map <i>name</i> in <i>mapset</i> is
- * read into the <i>cats</i> structure. If there is an error reading
- * the category file, a diagnostic message is printed and -1 is
- * returned. Otherwise, 0 is returned.
- * \param mapset mapset name
- * \param[out] cats pointer to Cats structure
- * \return -1 on error
- * \return 0 on success
-int Rast_read_raster_cats(const char *name,
- char *type;
switch (read_cats("cats", name, mapset, pcats, 1)) {
case -2:
- type = "missing";
+ G_warning(_("Category support for <%s@%s> missing"),
+ name, mapset);
break;
case -1:
- type = "invalid";
+ G_warning(_("Category support for <%s@%s> invalid"),
+ name, mapset);
break;
default:
return 0;
- G_warning(_("Category support for <%s@%s> %s"),
- name, mapset, type);
return -1;
@@ -149,13 +124,15 @@
* \brief Read vector category file
* <b>Note:</b> This function works with <b>old</b> vector format.
- * The category file for vector map <i>name</i> in <i>mapset</i> is
+ * \todo: To be moved to the vector library
+ * The category file for vector map <i>name</i> in <i>mapset</i> is
+ * read into the <i>cats</i> structure. If there is an error reading
+ * the category file, a diagnostic message is printed and -1 is
+ * \param name vector map name
@@ -165,34 +142,32 @@
int Rast_read_vector_cats(const char *name,
- char *type;
switch (read_cats("dig_cats", name, mapset, pcats, 1)) {
case -2:
- type = "missing";
+ G_warning(_("Category support for vector map <%s@%s> missing"),
+ name, mapset);
break;
case -1:
- type = "invalid";
+ G_warning(_("Category support for vector map <%s@%s> invalid"),
+ name, mapset);
break;
default:
return 0;
- G_warning(_("Category support for vector map <%s@%s> %s"),
return -1;
\brief Get number of categories
- \param name map name
+ \param name raster map name
\return -1 on error
\return number of cats
-CELL Rast_number_of_cats(const char *name, const char *mapset)
+CELL Rast_get_max_c_cat(const char *name, const char *mapset)
struct Range range;
CELL min, max;
@@ -248,7 +223,7 @@
G_strip(buff);
/* G_ascii_check(buff) ; */
if (num >= 0)
pcats->num = num;
@@ -263,7 +238,7 @@
goto error;
goto error;
@@ -273,7 +248,7 @@
if (G_getl(buff, sizeof buff, fd) == 0)
break;
if (old)
else {
*label = 0;
@@ -284,11 +259,11 @@
/* for fp maps try to read a range of data */
if (fp_map
&& sscanf(buff, "%lf:%lf:%[^\n]", &val1, &val2, label) == 3)
else
goto error;
@@ -304,7 +279,7 @@
* \brief Get title from category structure struct
- * \todo Remove from GIS Library, replace by Rast_get_raster_cats_title().
+ * \todo Remove from GIS Library, replace by Rast_get_c_cats_title().
* Map layers store a one-line title in the category structure as
* well. This routine returns a pointer to the title contained in the
@@ -317,55 +292,12 @@
* \return title
* \return "" if missing
char *Rast_get_cats_title(const struct Categories *pcats)
- return Rast_get_raster_cats_title(pcats);
- * \brief Get raster cats title
- * Returns pointer to a string with title.
- * \param pcats pointer to Categories structure
- * \return title
- * \return "" if missing
-char *Rast_get_raster_cats_title(const struct Categories *pcats)
return pcats->title ? pcats->title : "";
- * \brief Get a raster category label
- * \todo Remove from GIS Library, replaced by Rast_get_c_raster_cat().
- * This routine looks up category <i>num</i> in the <i>pcats</i>
- * structure and returns a pointer to a string which is the label for
- * the category. A legal pointer is always returned. If the category
- * does not exist in <i>pcats</i>, then a pointer to the empty string
- * "" is returned.
- * <b>Warning:</b> The pointer that is returned points to a hidden
- * static buffer. Successive calls to Rast_get_cat() overwrite this
- * buffer.
- * \param num cell value
- * \return pointer to category label
- * \return "" if category is not found
-char *Rast_get_cat(CELL num, struct Categories *pcats)
- return Rast_get_c_raster_cat(&num, pcats);
* \brief Get a raster category label (CELL)
* This routine looks up category <i>rast</i> in the <i>pcats</i>
@@ -375,7 +307,7 @@
* "" is returned.
+ * static buffer. Successive calls to Rast_get_c_cat() overwrite this
* buffer.
* \param rast cell value
@@ -384,9 +316,9 @@
-char *Rast_get_c_raster_cat(CELL * rast, struct Categories *pcats)
+char *Rast_get_c_cat(CELL * rast, struct Categories *pcats)
- return Rast_get_raster_cat(rast, pcats, CELL_TYPE);
+ return Rast_get_cat(rast, pcats, CELL_TYPE);
@@ -399,7 +331,7 @@
* "" is returned.
* buffer.
@@ -408,9 +340,9 @@
-char *Rast_get_f_raster_cat(FCELL * rast, struct Categories *pcats)
+char *Rast_get_f_cat(FCELL * rast, struct Categories *pcats)
- return Rast_get_raster_cat(rast, pcats, FCELL_TYPE);
+ return Rast_get_cat(rast, pcats, FCELL_TYPE);
@@ -423,7 +355,7 @@
* "" is returned.
* buffer.
@@ -432,9 +364,9 @@
-char *Rast_get_d_raster_cat(DCELL * rast, struct Categories *pcats)
+char *Rast_get_d_cat(DCELL * rast, struct Categories *pcats)
- return Rast_get_raster_cat(rast, pcats, DCELL_TYPE);
+ return Rast_get_cat(rast, pcats, DCELL_TYPE);
@@ -447,7 +379,7 @@
* "" is returned.
* buffer.
@@ -457,8 +389,8 @@
-char *Rast_get_raster_cat(void *rast,
- struct Categories *pcats, RASTER_MAP_TYPE data_type)
+char *Rast_get_cat(void *rast,
+ struct Categories *pcats, RASTER_MAP_TYPE data_type)
static char label[1024];
char *f, *l, *v;
@@ -477,7 +409,7 @@
val = Rast_get_raster_value_d(rast, data_type);
i = Rast_quant_get_cell_value(&pcats->q, val);
- G_debug(5, "Rast_get_raster_cat(): val %lf found i %d", val, i);
+ G_debug(5, "Rast_get_cat(): val %lf found i %d", val, i);
if (!Rast_is_c_null_value(&i) && i < pcats->ncats) {
if (pcats->labels[i] != NULL)
@@ -524,7 +456,7 @@
* \brief Sets marks for all categories to 0.
* This initializes Categories structure for subsequest calls to
- * Rast_mark_raster_cats() for each row of data, where non-zero mark for
+ * Rast_mark_cats() for each row of data, where non-zero mark for
* i-th label means that some of the cells in rast_row are labeled
* with i-th label and fall into i-th data range. These marks help
* determine from the Categories structure which labels were used and
@@ -532,7 +464,7 @@
-void Rast_unmark_raster_cats(struct Categories *pcats)
+void Rast_unmark_cats(struct Categories *pcats)
int i;
@@ -555,10 +487,10 @@
-void Rast_mark_c_raster_cats(const CELL * rast_row,
- int ncols, struct Categories *pcats)
+void Rast_mark_c_cats(const CELL * rast_row,
+ int ncols, struct Categories *pcats)
- Rast_mark_raster_cats(rast_row, ncols, pcats, CELL_TYPE);
+ Rast_mark_cats(rast_row, ncols, pcats, CELL_TYPE);
@@ -576,10 +508,10 @@
-void Rast_mark_f_raster_cats(const FCELL * rast_row,
+void Rast_mark_f_cats(const FCELL * rast_row,
- Rast_mark_raster_cats(rast_row, ncols, pcats, FCELL_TYPE);
+ Rast_mark_cats(rast_row, ncols, pcats, FCELL_TYPE);
@@ -597,10 +529,10 @@
-void Rast_mark_d_raster_cats(const DCELL * rast_row,
+void Rast_mark_d_cats(const DCELL * rast_row,
- Rast_mark_raster_cats(rast_row, ncols, pcats, DCELL_TYPE);
+ Rast_mark_cats(rast_row, ncols, pcats, DCELL_TYPE);
@@ -620,9 +552,9 @@
* \return 1 on success
-int Rast_mark_raster_cats(const void *rast_row,
- int ncols, struct Categories *pcats,
- RASTER_MAP_TYPE data_type)
+int Rast_mark_cats(const void *rast_row,
+ int ncols, struct Categories *pcats,
+ RASTER_MAP_TYPE data_type)
CELL i;
@@ -642,12 +574,12 @@
* \brief Rewind raster categories
- * After call to this function Rast_get_next_marked_raster_cat() returns
+ * After call to this function Rast_get_next_marked_cat() returns
* the first marked cat label.
-void Rast_rewind_raster_cats(struct Categories *pcats)
+void Rast_rewind_cats(struct Categories *pcats)
pcats->last_marked_rule = -1;
@@ -662,9 +594,9 @@
\return NULL if not found
\return description if found
-char *Rast_get_next_marked_d_raster_cat(struct Categories *pcats,
- DCELL * rast1, DCELL * rast2,
- long *count)
+char *Rast_get_next_marked_d_cat(struct Categories *pcats,
+ DCELL * rast1, DCELL * rast2,
+ long *count)
char *descr = NULL;
int found, i;
@@ -675,7 +607,7 @@
G_debug(3, "last marked %d nrules %d\n", pcats->last_marked_rule, Rast_quant_nof_rules(&pcats->q));
for (i = pcats->last_marked_rule + 1; i < Rast_quant_nof_rules(&pcats->q); i++) {
- descr = Rast_get_ith_d_raster_cat(pcats, i, rast1, rast2);
+ descr = Rast_get_ith_d_cat(pcats, i, rast1, rast2);
G_debug(5, "%d %d", i, pcats->marks[i]);
if (pcats->marks[i]) {
found = 1;
@@ -701,11 +633,11 @@
-char *Rast_get_next_marked_c_raster_cat(struct Categories *pcats,
- CELL * rast1, CELL * rast2,
- long *count)
+char *Rast_get_next_marked_c_cat(struct Categories *pcats,
+ CELL * rast1, CELL * rast2,
+ long *count)
- return Rast_get_next_marked_raster_cat(pcats, rast1, rast2, count,
+ return Rast_get_next_marked_cat(pcats, rast1, rast2, count,
CELL_TYPE);
@@ -719,11 +651,11 @@
-char *Rast_get_next_marked_f_raster_cat(struct Categories *pcats,
+char *Rast_get_next_marked_f_cat(struct Categories *pcats,
FCELL * rast1, FCELL * rast2,
long *count)
FCELL_TYPE);
@@ -738,14 +670,14 @@
-char *Rast_get_next_marked_raster_cat(struct Categories *pcats,
- void *rast1, void *rast2,
- long *count, RASTER_MAP_TYPE data_type)
+char *Rast_get_next_marked_cat(struct Categories *pcats,
+ void *rast1, void *rast2,
+ long *count, RASTER_MAP_TYPE data_type)
DCELL val1, val2;
char *lab;
- lab = Rast_get_next_marked_d_raster_cat(pcats, &val1, &val2, count);
+ lab = Rast_get_next_marked_d_cat(pcats, &val1, &val2, count);
Rast_set_raster_value_d(rast1, val1, data_type);
Rast_set_raster_value_d(rast2, val2, data_type);
return lab;
@@ -818,30 +750,7 @@
*f = ff;
- * \brief Set a raster category label
- * \todo To be removed, replaced by Rast_set_c_raster_cat().
- * The <i>label</i> is copied into the <i>pcats</i> structure for
- * category <i>num</i>.
- * \param num raster cell
- * \param label category label
- * \return 0 if null value detected
- * \return 1 on success
-int Rast_set_cat(CELL num, const char *label, struct Categories *pcats)
- return Rast_set_c_raster_cat(&num, &num, label, pcats);
* \brief Set a raster category label (CELL)
* Adds the label for range <i>rast1</i> through <i>rast2</i> in
@@ -855,10 +764,10 @@
-int Rast_set_c_raster_cat(const CELL * rast1, const CELL * rast2,
- const char *label, struct Categories *pcats)
+int Rast_set_c_cat(const CELL * rast1, const CELL * rast2,
+ const char *label, struct Categories *pcats)
- return Rast_set_raster_cat(rast1, rast2, label, pcats, CELL_TYPE);
+ return Rast_set_cat(rast1, rast2, label, pcats, CELL_TYPE);
@@ -873,10 +782,10 @@
* \return
-int Rast_set_f_raster_cat(const FCELL * rast1, const FCELL * rast2,
+int Rast_set_f_cat(const FCELL * rast1, const FCELL * rast2,
- return Rast_set_raster_cat(rast1, rast2, label, pcats, FCELL_TYPE);
+ return Rast_set_cat(rast1, rast2, label, pcats, FCELL_TYPE);
@@ -893,21 +802,21 @@
-int Rast_set_d_raster_cat(const DCELL * rast1, const DCELL * rast2,
+int Rast_set_d_cat(const DCELL * rast1, const DCELL * rast2,
long len;
DCELL dtmp1, dtmp2;
int i;
char *descr;
- /* DEBUG fprintf(stderr,"Rast_set_d_raster_cat(rast1 = %p,rast2 = %p,label = '%s',pcats = %p)\n",
+ /* DEBUG fprintf(stderr,"Rast_set_d_cat(rast1 = %p,rast2 = %p,label = '%s',pcats = %p)\n",
rast1,rast2,label,pcats); */
if (Rast_is_d_null_value(rast1))
return 0;
if (Rast_is_d_null_value(rast2))
return 0;
- /* DEBUG fprintf (stderr, "Rast_set_d_raster_cat(): adding quant rule: %f %f %d %d\n", *rast1, *rast2, pcats->ncats, pcats->ncats); */
+ /* DEBUG fprintf (stderr, "Rast_set_d_cat(): adding quant rule: %f %f %d %d\n", *rast1, *rast2, pcats->ncats, pcats->ncats); */
/* the set_cat() functions are used in many places to reset the labels
for the range (or cat) with existing label. In this case we don't
want to store both rules with identical range even though the result
@@ -917,7 +826,7 @@
the label for this range has been sen, and if it has, overwrite it */
for (i = 0; i < pcats->ncats; i++) {
- descr = Rast_get_ith_d_raster_cat(pcats, i, &dtmp1, &dtmp2);
+ descr = Rast_get_ith_d_cat(pcats, i, &dtmp1, &dtmp2);
if ((dtmp1 == *rast1 && dtmp2 == *rast2)
|| (dtmp1 == *rast2 && dtmp2 == *rast1)) {
@@ -929,29 +838,29 @@
/* when rule for this range does not exist */
- /* DEBUG fprintf (stderr, "Rast_set_d_raster_cat(): New rule: adding %d %p\n", i, pcats->labels); */
+ /* DEBUG fprintf (stderr, "Rast_set_d_cat(): New rule: adding %d %p\n", i, pcats->labels); */
Rast_quant_add_rule(&pcats->q, *rast1, *rast2, pcats->ncats, pcats->ncats);
pcats->ncats++;
if (pcats->nalloc < pcats->ncats) {
- /* DEBUG fprintf (stderr, "Rast_set_d_raster_cat(): need more space nalloc = %d ncats = %d\n", pcats->nalloc,pcats->ncats); */
+ /* DEBUG fprintf (stderr, "Rast_set_d_cat(): need more space nalloc = %d ncats = %d\n", pcats->nalloc,pcats->ncats); */
len = (pcats->nalloc + 256) * sizeof(char *);
- /* DEBUG fprintf (stderr, "Rast_set_d_raster_cat(): allocating %d labels(%d)\n", pcats->nalloc + 256,(int)len); */
+ /* DEBUG fprintf (stderr, "Rast_set_d_cat(): allocating %d labels(%d)\n", pcats->nalloc + 256,(int)len); */
if (len != (int)len) { /* make sure len doesn't overflow int */
pcats->ncats--;
return -1;
- /* DEBUG fprintf(stderr,"Rast_set_d_raster_cat(): pcats->nalloc = %d, pcats->labels = (%p), len = %d\n",pcats->nalloc,pcats->labels,(int)len); */
+ /* DEBUG fprintf(stderr,"Rast_set_d_cat(): pcats->nalloc = %d, pcats->labels = (%p), len = %d\n",pcats->nalloc,pcats->labels,(int)len); */
if (pcats->nalloc) {
- /* DEBUG fprintf(stderr,"Rast_set_d_raster_cat(): Realloc-ing pcats->labels (%p)\n",pcats->labels); */
+ /* DEBUG fprintf(stderr,"Rast_set_d_cat(): Realloc-ing pcats->labels (%p)\n",pcats->labels); */
pcats->labels =
(char **)G_realloc((char *)pcats->labels, (int)len);
else {
- /* DEBUG fprintf(stderr,"Rast_set_d_raster_cat(): alloc-ing new labels pointer array\n"); */
+ /* DEBUG fprintf(stderr,"Rast_set_d_cat(): alloc-ing new labels pointer array\n"); */
pcats->labels = (char **)G_malloc((int)len);
/* fflush(stderr); */
- /* DEBUG fprintf (stderr, "Rast_set_d_raster_cats(): allocating %d marks(%d)\n", pcats->nalloc + 256,(int)len); */
+ /* DEBUG fprintf (stderr, "Rast_set_d_cats(): allocating %d marks(%d)\n", pcats->nalloc + 256,(int)len); */
len = (pcats->nalloc + 256) * sizeof(int);
pcats->ncats--;
@@ -963,7 +872,7 @@
pcats->marks = (int *)G_malloc((int)len);
pcats->nalloc += 256;
- /* DEBUG fprintf(stderr,"Rast_set_d_raster_cats(): store new label\n"); */
+ /* DEBUG fprintf(stderr,"Rast_set_d_cats(): store new label\n"); */
pcats->labels[pcats->ncats - 1] = G_store(label);
G_newlines_to_spaces(pcats->labels[pcats->ncats - 1]);
G_strip(pcats->labels[pcats->ncats - 1]);
@@ -976,14 +885,14 @@
pcats->num = (CELL) * rast1;
if ((CELL) * rast2 > pcats->num)
pcats->num = (CELL) * rast2;
- /* DEBUG fprintf(stderr,"Rast_set_d_raster_cat(): done\n"); */
+ /* DEBUG fprintf(stderr,"Rast_set_d_cat(): done\n"); */
/* DEBUG fflush(stderr); */
return 1;
- * \brief Set a raster category label (DCELL)
+ * \brief Set a raster category label
* category structure <i>pcats</i>.
@@ -998,21 +907,21 @@
-int Rast_set_raster_cat(const void *rast1, const void *rast2,
+int Rast_set_cat(const void *rast1, const void *rast2,
DCELL val1, val2;
val1 = Rast_get_raster_value_d(rast1, data_type);
val2 = Rast_get_raster_value_d(rast2, data_type);
- return Rast_set_d_raster_cat(&val1, &val2, label, pcats);
+ return Rast_set_d_cat(&val1, &val2, label, pcats);
* \brief Write raster category file
- * \todo To be removed, replaced by Rast_write_raster_cats().
+ * \todo To be removed, replaced by Rast_write_cats().
* Writes the category file for the raster map <i>name</i> in the
* current mapset from the <i>cats</i> structure.
@@ -1029,29 +938,12 @@
- * \brief Write raster category file
- * Writes the category file for the raster map <i>name</i> in the
- * current mapset from the <i>cats</i> structure.
- * \param cats pointer to Categories structure
- * \return -1 is returned (no diagnostic is printed)
-int Rast_write_raster_cats(const char *name, struct Categories *cats)
- return write_cats("cats", name, cats);
* \brief Write vector category file
* <b>Note:</b> Used for only old vector format!
+ * \todo Move to the vector library.
@@ -1095,7 +987,7 @@
if (val1 == val2) {
@@ -1131,8 +1023,8 @@
* \return "" on error
* \return pointer to category description
-char *Rast_get_ith_d_raster_cat(const struct Categories *pcats,
- int i, DCELL * rast1, DCELL * rast2)
+char *Rast_get_ith_d_cat(const struct Categories *pcats,
+ int i, DCELL * rast1, DCELL * rast2)
int index;
@@ -1159,14 +1051,14 @@
-char *Rast_get_ith_f_raster_cat(const struct Categories *pcats,
- int i, void *rast1, void *rast2)
+char *Rast_get_ith_f_cat(const struct Categories *pcats,
+ int i, void *rast1, void *rast2)
RASTER_MAP_TYPE data_type = FCELL_TYPE;
char *tmp;
DCELL val1, val2;
- tmp = Rast_get_ith_d_raster_cat(pcats, i, &val1, &val2);
+ tmp = Rast_get_ith_d_cat(pcats, i, &val1, &val2);
return tmp;
@@ -1186,14 +1078,14 @@
-char *Rast_get_ith_c_raster_cat(const struct Categories *pcats,
+char *Rast_get_ith_c_cat(const struct Categories *pcats,
RASTER_MAP_TYPE data_type = CELL_TYPE;
char *tmp;
DCELL val1, val2;
return tmp;
@@ -1214,13 +1106,13 @@
-char *Rast_get_ith_raster_cat(const struct Categories *pcats, int i, void *rast1,
- void *rast2, RASTER_MAP_TYPE data_type)
+char *Rast_get_ith_cat(const struct Categories *pcats, int i, void *rast1,
+ void *rast2, RASTER_MAP_TYPE data_type)
char *tmp;
DCELL val1, val2;
return tmp;
@@ -1237,32 +1129,19 @@
* For example:
\code
struct Categories cats;
- Rast_init_cats ((CELL)0, * "", &cats);
+ Rast_init_cats ("", &cats);
\endcode
- * \param num raster value
- * \param title title
-void Rast_init_cats(CELL num, const char *title, struct Categories *pcats)
- Rast_init_raster_cats(title, pcats);
- pcats->num = num;
- * \brief Initialize category structure
+ * \todo Eliminate pcats->num. Num has no meaning in new Categories
+ * structure and only stores (int) largets data value for backwards
+ * compatibility.
- * Same as existing Rast_init_raster_cats() only ncats argument is
- * missign. ncats has no meaning in new Categories structure and only
- * stores (int) largets data value for backwards compatibility.
-void Rast_init_raster_cats(const char *title, struct Categories *pcats)
+void Rast_init_cats(const char *title, struct Categories *pcats)
- Rast_set_raster_cats_title(title, pcats);
+ Rast_set_cats_title(title, pcats);
pcats->labels = NULL;
pcats->nalloc = 0;
pcats->ncats = 0;
@@ -1279,7 +1158,7 @@
* \brief Set title in category structure
- * \todo To be removed, replaced by Rast_set_raster_cats_title().
+ * \todo To be removed, replaced by Rast_set_cats_title().
* The <i>title</i> is copied into the <i>pcats</i> structure.
@@ -1288,19 +1167,6 @@
void Rast_set_cats_title(const char *title, struct Categories *pcats)
- * \brief Set title in category structure
- * The <i>title</i> is copied into the <i>pcats</i> structure.
-void Rast_set_raster_cats_title(const char *title, struct Categories *pcats)
if (title == NULL)
title = "";
pcats->title = G_store(title);
@@ -1311,32 +1177,14 @@
\brief Set category fmt (?)
- \todo To be removed, replaced by Rast_set_raster_cats_fmt().
\param fmt
\param m1,
\param a1,m2,a2
void Rast_set_cats_fmt(const char *fmt, double m1, double a1, double m2,
- double a2, struct Categories *pcats)
+ double a2, struct Categories *pcats)
- \brief Set category fmt (?)
- \param fmt
- \param m1,
- \param a1,m2,a2
- \param pcats pointer to Categories structure
-void Rast_set_raster_cats_fmt(const char *fmt, double m1, double a1, double m2,
pcats->m1 = m1;
pcats->a1 = a1;
pcats->m2 = m2;
@@ -1350,30 +1198,15 @@
* \brief Free category structure memory
- * \todo To be removed, replaced by Rast_free_raster_cats().
+ * \todo To be removed, replaced by Rast_free_cats().
* Frees memory allocated by Rast_read_cats(), Rast_init_cats() and
- * Rast_set_cat().
+ * Rast_set_c_cat().
void Rast_free_cats(struct Categories *pcats)
- Rast_free_raster_cats(pcats);
- * \brief Free category structure memory
- * Frees memory allocated by Rast_read_cats(), Rast_init_cats() and
- * Rast_set_cat().
-void Rast_free_raster_cats(struct Categories *pcats)
int i;
if (pcats->title != NULL) {
@@ -1407,17 +1240,17 @@
* \param pcats_to pointer to destination Categories structure
* \param pcats_from pointer to source Categories structure
-void Rast_copy_raster_cats(struct Categories *pcats_to,
- const struct Categories *pcats_from)
+void Rast_copy_cats(struct Categories *pcats_to,
+ const struct Categories *pcats_from)
int i;
char *descr;
DCELL d1, d2;
- Rast_init_raster_cats(pcats_from->title, pcats_to);
+ Rast_init_cats(pcats_from->title, pcats_to);
for (i = 0; i < pcats_from->ncats; i++) {
- descr = Rast_get_ith_d_raster_cat(pcats_from, i, &d1, &d2);
- Rast_set_d_raster_cat(&d1, &d2, descr, pcats_to);
+ descr = Rast_get_ith_d_cat(pcats_from, i, &d1, &d2);
+ Rast_set_d_cat(&d1, &d2, descr, pcats_to);
@@ -1428,7 +1261,7 @@
\return number of categories
-int Rast_number_of_raster_cats(struct Categories *pcats)
+int Rast_number_of_cats(struct Categories *pcats)
return pcats->ncats;
@@ -1452,22 +1285,22 @@
ncats = pcats->ncats;
G_debug(3, "Rast_sort_cats(): Copying to save cats buffer");
- Rast_copy_raster_cats(&save_cats, pcats);
+ Rast_copy_cats(&save_cats, pcats);
+ Rast_free_cats(pcats);
indexes = (int *)G_malloc(sizeof(int) * ncats);
for (i = 0; i < ncats; i++)
indexes[i] = i;
qsort(indexes, ncats, sizeof(int), cmp);
- Rast_init_raster_cats(save_cats.title, pcats);
+ Rast_init_cats(save_cats.title, pcats);
for (i = 0; i < ncats; i++) {
- descr = Rast_get_ith_d_raster_cat(&save_cats, indexes[i], &d1, &d2);
+ descr = Rast_get_ith_d_cat(&save_cats, indexes[i], &d1, &d2);
G_debug(4, " Write sorted cats, pcats = %p pcats->labels = %p",
pcats, pcats->labels);
- Rast_set_d_raster_cat(&d1, &d2, descr, pcats);
+ Rast_set_d_cat(&d1, &d2, descr, pcats);
- Rast_free_raster_cats(&save_cats);
+ Rast_free_cats(&save_cats);
return 0;
Modified: grass/trunk/lib/raster/sample.c
--- grass/trunk/lib/raster/sample.c 2009-06-27 11:05:11 UTC (rev 38098)
+++ grass/trunk/lib/raster/sample.c 2009-06-27 16:25:06 UTC (rev 38099)
@@ -116,7 +116,7 @@
if (usedesc) {
- char *buf = Rast_get_cat(maprow[col], cats);
+ char *buf = Rast_get_c_cat((CELL *) &(maprow[col]), cats);
G_squeeze(buf);
result = scancatlabel(buf);
@@ -194,13 +194,13 @@
if (usedesc) {
char *buf;
- G_squeeze(buf = Rast_get_cat((int)arow[col], cats));
+ G_squeeze(buf = Rast_get_c_cat((int*) &(arow[col]), cats));
grid[0][0] = scancatlabel(buf);
- G_squeeze(buf = Rast_get_cat((int)arow[col + 1], cats));
+ G_squeeze(buf = Rast_get_c_cat((CELL *) &(arow[col + 1]), cats));
grid[0][1] = scancatlabel(buf);
- G_squeeze(buf = Rast_get_cat((int)brow[col], cats));
+ G_squeeze(buf = Rast_get_c_cat((CELL *) &(brow[col]), cats));
grid[1][0] = scancatlabel(buf);
- G_squeeze(buf = Rast_get_cat((int)brow[col + 1], cats));
+ G_squeeze(buf = Rast_get_c_cat((CELL *) &(brow[col + 1]), cats));
grid[1][1] = scancatlabel(buf);
else {
@@ -289,7 +289,7 @@
for (i = 0; i < 4; i++) {
for (j = 0; j < 4; j++) {
- G_squeeze(buf = Rast_get_cat(rows[i][col + j], cats));
+ G_squeeze(buf = Rast_get_c_cat((CELL *) &(rows[i][col + j]), cats));
grid[i][j] = scancatlabel(buf);
Modified: grass/trunk/ps/ps.map/ps_clrtbl.c
--- grass/trunk/ps/ps.map/ps_clrtbl.c 2009-06-27 11:05:11 UTC (rev 38098)
+++ grass/trunk/ps/ps.map/ps_clrtbl.c 2009-06-27 16:25:06 UTC (rev 38099)
@@ -42,7 +42,7 @@
do_color = (PS.grey == 0 && PS.level == 2);
/* How many categories to show */
- num_cats = Rast_number_of_raster_cats(&PS.cats);
+ num_cats = Rast_number_of_cats(&PS.cats);
G_debug(3, "clrtbl: %d categories", num_cats);
if (!num_cats) {
G_warning(_("Your cats/ file is invalid. A cats/ file with categories "
@@ -89,7 +89,7 @@
fprintf(PS.fp, "(%s)\n", "no data");
else
- Rast_get_ith_d_raster_cat(&PS.cats, i - 1, &dmin, &dmax));
+ Rast_get_ith_d_cat(&PS.cats, i - 1, &dmin, &dmax));
fprintf(PS.fp, "] def\n");
@@ -136,7 +136,7 @@
/* fill box and outline in black */
if (i)
- label = Rast_get_ith_d_raster_cat(&PS.cats, i - 1, &dmin, &dmax);
+ label = Rast_get_ith_d_cat(&PS.cats, i - 1, &dmin, &dmax);
x1 = l + (double)j *72.0 * col_width;
Modified: grass/trunk/raster/r.buffer/support.c
--- grass/trunk/raster/r.buffer/support.c 2009-06-27 11:05:11 UTC (rev 38098)
+++ grass/trunk/raster/r.buffer/support.c 2009-06-27 16:25:06 UTC (rev 38099)
@@ -27,15 +27,17 @@
struct Categories pcats;
+ int i;
CELL cat;
char label[128];
- Rast_init_cats((CELL) 1, "Distance Zones", &pcats);
+ Rast_init_cats("Distance Zones", &pcats);
- Rast_set_cat(cat = 1, "distances calculated from these locations", &pcats);
- for (cat = 0; cat < ndist; cat++) {
- if (cat == 0)
- sprintf(label, "0-%s %s", distances[cat].label, units);
+ cat = 1;
+ Rast_set_c_cat(&cat, &cat, "distances calculated from these locations", &pcats);
+ for (i = 0; i < ndist; i++) {
+ if (i == 0)
+ sprintf(label, "0-%s %s", distances[i].label, units);
else {
/* improved next, but it would be perfect to achieve (example):
* 0-100.55 meters
@@ -47,11 +49,12 @@
*but it's better that the original code. MN 1/2002
- sprintf(label, "%s-%s %s", distances[cat - 1].label,
- distances[cat].label, units);
+ sprintf(label, "%s-%s %s", distances[i - 1].label,
+ distances[i].label, units);
- Rast_set_cat(cat + ZONE_INCR, label, &pcats);
+ cat = i + ZONE_INCR;
+ Rast_set_c_cat(&cat, &cat, label, &pcats);
Rast_write_cats(output, &pcats);
Modified: grass/trunk/raster/r.category/main.c
--- grass/trunk/raster/r.category/main.c 2009-06-27 11:05:11 UTC (rev 38098)
+++ grass/trunk/raster/r.category/main.c 2009-06-27 16:25:06 UTC (rev 38099)
@@ -150,7 +150,7 @@
if ((fd = Rast_open_cell_old(name, mapset)) < 0)
G_fatal_error(_("Unable to open raster map <%s>"), name);
- Rast_init_raster_cats("", &cats);
+ Rast_init_cats("", &cats);
if (0 > Rast_read_cats(parm.raster->answer, cmapset, &cats))
G_fatal_error(_("Unable to read category file of raster map <%s@%s>"),
@@ -179,7 +179,7 @@
parm.file->answer);
for (;;) {
char buf[1024], label[1024];
@@ -189,9 +189,9 @@
break;
if (sscanf(buf, "%lf:%lf:%[^\n]", &d1, &d2, label) == 3)
- Rast_set_d_raster_cat(&d1, &d2, label, &cats);
+ Rast_set_d_cat(&d1, &d2, label, &cats);
else if (sscanf(buf, "%lf:%[^\n]", &d1, label) == 2)
- Rast_set_d_raster_cat(&d1, &d1, label, &cats);
+ Rast_set_d_cat(&d1, &d1, label, &cats);
if (Rast_write_cats(name, &cats) < 0)
@@ -208,7 +208,7 @@
double m1, a1, m2, a2;
/* read existing values */
if (0 > Rast_read_cats(name, G_mapset(), &cats))
G_warning(_("Unable to read category file of raster map <%s@%s>"),
@@ -302,7 +302,7 @@
char *label;
- G_squeeze(label = Rast_get_cat((CELL) x, &cats));
+ G_squeeze(label = Rast_get_c_cat((CELL *) &x, &cats));
fprintf(stdout, "%ld%c%s\n", x, fs, label);
return 0;
@@ -314,7 +314,7 @@
DCELL dtmp;
dtmp = x;
- G_squeeze(label = Rast_get_d_raster_cat(&dtmp, &cats));
+ G_squeeze(label = Rast_get_d_cat(&dtmp, &cats));
sprintf(tmp, "%.10f", x);
G_trim_decimal(tmp);
fprintf(stdout, "%s%c%s\n", tmp, fs, label);
Modified: grass/trunk/raster/r.compress/main.c
--- grass/trunk/raster/r.compress/main.c 2009-06-27 11:05:11 UTC (rev 38098)
+++ grass/trunk/raster/r.compress/main.c 2009-06-27 16:25:06 UTC (rev 38099)
@@ -136,7 +136,7 @@
if (hist_ok)
Rast_write_history(name, &hist);
if (cats_ok) {
- cats.num = Rast_number_of_cats(name, G_mapset());
+ cats.num = Rast_get_max_c_cat(name, G_mapset());
Rast_write_cats(name, &cats);
Modified: grass/trunk/raster/r.cross/cats.c
--- grass/trunk/raster/r.cross/cats.c 2009-06-27 11:05:11 UTC (rev 38098)
+++ grass/trunk/raster/r.cross/cats.c 2009-06-27 16:25:06 UTC (rev 38099)
@@ -49,7 +49,7 @@
lbl = get_label(cat[i], &labels[i]);
strcat(buf, lbl);
- Rast_set_cat(result, buf, pcats);
+ Rast_set_c_cat(&result, &result, buf, pcats);
return 0;
@@ -58,7 +58,7 @@
char *lbl;
static char temp[256];
- lbl = Rast_get_cat(cat, labels);
+ lbl = Rast_get_c_cat(&cat, labels);
if (*lbl == 0)
sprintf(lbl = temp, "category %ld", (long)cat);
return lbl;
Modified: grass/trunk/raster/r.digit/get_label.c
--- grass/trunk/raster/r.digit/get_label.c 2009-06-27 11:05:11 UTC (rev 38098)
+++ grass/trunk/raster/r.digit/get_label.c 2009-06-27 16:25:06 UTC (rev 38099)
@@ -44,7 +44,7 @@
for (;;) {
fprintf(stdout, _("Enter a label for category %ld [%s] "),
- cat, Rast_get_cat((CELL) cat, labels));
+ cat, Rast_get_c_cat((CELL *) &cat, labels));
if (!G_gets(buffer))
continue;;
G_strip(buffer);
@@ -64,10 +64,10 @@
cat = get_cat(type);
lbl = get_label(cat, labels);
fprintf(stdout, "%ld [%s]\n", cat,
- *lbl ? lbl : Rast_get_cat((CELL) cat, labels));
+ *lbl ? lbl : Rast_get_c_cat((CELL) cat, labels));
} while (!G_yes(_("Look ok? "), 1));
if (*lbl)
- Rast_set_cat((CELL) cat, lbl, labels);
+ Rast_set_c_cat((CELL *) &cat, (CELL *) &cat, lbl, labels);
fprintf(fd, "= %ld %s\n", cat, lbl);
return (0);
Modified: grass/trunk/raster/r.distance/labels.c
--- grass/trunk/raster/r.distance/labels.c 2009-06-27 11:05:11 UTC (rev 38098)
+++ grass/trunk/raster/r.distance/labels.c 2009-06-27 16:25:06 UTC (rev 38099)
@@ -30,7 +30,5 @@
char *get_label(struct Map *map, CELL cat)
- char *Rast_get_cat();
- return Rast_get_cat(cat, &map->labels);
+ return Rast_get_c_cat(&cat, &map->labels);
Modified: grass/trunk/raster/r.grow/Makefile
--- grass/trunk/raster/r.grow/Makefile 2009-06-27 11:05:11 UTC (rev 38098)
+++ grass/trunk/raster/r.grow/Makefile 2009-06-27 16:25:06 UTC (rev 38099)
@@ -2,8 +2,8 @@
PGM = r.grow
-LIBES = $(GISLIB)
-DEPENDENCIES = $(GISDEP)
+LIBES = $(GISLIB) $(RASTERLIB)
+DEPENDENCIES = $(GISDEP) $(RASTERDEP)
include $(MODULE_TOPDIR)/include/Make/Module.make
Modified: grass/trunk/raster/r.grow/main.c
--- grass/trunk/raster/r.grow/main.c 2009-06-27 11:05:11 UTC (rev 38098)
+++ grass/trunk/raster/r.grow/main.c 2009-06-27 16:25:06 UTC (rev 38099)
@@ -21,9 +21,9 @@
#include <stdlib.h>
#include <string.h>
#include <grass/gis.h>
+#include <grass/raster.h>
#include <grass/glocale.h>
#define MAX(a, b) ((a) > (b) ? (a) : (b))
static int size;
@@ -194,7 +194,7 @@
if (Rast_read_cats(in_name, "", &cats) == -1) {
G_warning(_("Error reading category file for <%s>"), in_name);
- Rast_init_cats(0, "", &cats);
if (Rast_read_colors(in_name, "", &colr) == -1) {
@@ -205,10 +205,10 @@
colrfile = 1;
if (opt.old->answer && oldval >= 0)
- Rast_set_cat(oldval, "original cells", &cats);
+ Rast_set_c_cat(&oldval, &oldval, "original cells", &cats);
if (opt.new->answer)
- Rast_set_cat(newval, "grown cells", &cats);
+ Rast_set_c_cat(&newval, &newval,"grown cells", &cats);
in_rows = G_malloc((size * 2 + 1) * sizeof(DCELL *));
Modified: grass/trunk/raster/r.in.poly/get_item.c
--- grass/trunk/raster/r.in.poly/get_item.c 2009-06-27 11:05:11 UTC (rev 38098)
+++ grass/trunk/raster/r.in.poly/get_item.c 2009-06-27 16:25:06 UTC (rev 38099)
@@ -66,7 +66,7 @@
/* probably change this as G_getl2() doesn't store the new line (?) */
if (sscanf(buf + 1, "%ld%[^\n]", cat, lbl) == 2) {
G_strip(lbl);
- Rast_set_cat((CELL) * cat, lbl, labels);
+ Rast_set_c_cat((CELL*) cat, (CELL *) cat, lbl, labels);
continue;
Modified: grass/trunk/raster/r.kappa/prt_label.c
--- grass/trunk/raster/r.kappa/prt_label.c 2009-06-27 11:05:11 UTC (rev 38098)
+++ grass/trunk/raster/r.kappa/prt_label.c 2009-06-27 16:25:06 UTC (rev 38099)
@@ -24,7 +24,7 @@
fprintf(fd, "MAP%-d Category Description\n", i + 1);
for (j = 0; j < ncat; j++) {
cats = rlst;
- cl = Rast_get_cat((CELL) cats[j], &(layers[i].labels));
+ cl = Rast_get_c_cat((CELL *) &(cats[j]), &(layers[i].labels));
if (cl)
G_strip(cl);
if (cl == NULL || *cl == 0)
Modified: grass/trunk/raster/r.le/r.le.patch/trace.c
--- grass/trunk/raster/r.le/r.le.patch/trace.c 2009-06-27 11:05:11 UTC (rev 38098)
+++ grass/trunk/raster/r.le/r.le.patch/trace.c 2009-06-27 16:25:06 UTC (rev 38099)
@@ -180,7 +180,7 @@
infd = Rast_open_cell_old(name, mapset);
colr_ok = Rast_read_colors(name, mapset, &colr) > 0;
- cats_ok = Rast_read_raster_cats(name, mapset, &cats) >= 0;
+ cats_ok = Rast_read_cats(name, mapset, &cats) >= 0;
hist_ok = Rast_read_history(name, mapset, &hist) >= 0;
range_ok = Rast_read_range(name, mapset, &range) >= 0;
@@ -198,7 +198,7 @@
/* 3. initialize appropriate data structures */
if (cats_ok)
- Rast_init_raster_cats(Rast_get_raster_cats_title(&cats), &newcats);
+ Rast_init_cats(Rast_get_cats_title(&cats), &newcats);
if (data_type == CELL_TYPE)
Rast_init_cell_stats(&stats);
@@ -369,7 +369,7 @@
if (choice->coremap) {
Rast_close_cell(fe);
Rast_rewind_cell_stats(&stats);
- Rast_rewind_raster_cats(&cats);
+ Rast_rewind_cats(&cats);
if (cats_ok && data_type == CELL_TYPE) {
long count;
@@ -378,12 +378,12 @@
rast1 = cor_cell_buf;
rast2 = G_incr_void_ptr(rast1, Rast_cell_size(CELL_TYPE));
while (Rast_next_cell_stat(rast1, &count, &stats))
- Rast_set_raster_cat(rast1, rast2, Rast_get_raster_cat(rast1, &cats,
+ Rast_set_cat(rast1, rast2, Rast_get_cat(rast1, &cats,
CELL_TYPE),
&newcats, CELL_TYPE);
- Rast_write_raster_cats("interior", &newcats);
- Rast_free_raster_cats(&cats);
- Rast_free_raster_cats(&newcats);
+ Rast_write_cats("interior", &newcats);
+ Rast_free_cats(&cats);
+ Rast_free_cats(&newcats);
Rast_free_cell_stats(&stats);
Modified: grass/trunk/raster/r.le/r.le.pixel/cellclip.c
--- grass/trunk/raster/r.le/r.le.pixel/cellclip.c 2009-06-27 11:05:11 UTC (rev 38098)
+++ grass/trunk/raster/r.le/r.le.pixel/cellclip.c 2009-06-27 16:25:06 UTC (rev 38099)
@@ -21,6 +21,7 @@
#include "pixel.h"
#include <grass/config.h>
#include "local_proto.h"
Modified: grass/trunk/raster/r.le/r.le.pixel/driver.c
--- grass/trunk/raster/r.le/r.le.pixel/driver.c 2009-06-27 11:05:11 UTC (rev 38098)
+++ grass/trunk/raster/r.le/r.le.pixel/driver.c 2009-06-27 16:25:06 UTC (rev 38099)
@@ -23,9 +23,9 @@
#include "pixel.h"
int finput, g_scale = 1, g_unit = 1;
extern struct CHOICE *choice;
char cmdbuf[100];
Modified: grass/trunk/raster/r.le/r.le.pixel/texture.c
--- grass/trunk/raster/r.le/r.le.pixel/texture.c 2009-06-27 11:05:11 UTC (rev 38098)
+++ grass/trunk/raster/r.le/r.le.pixel/texture.c 2009-06-27 16:25:06 UTC (rev 38099)
@@ -19,6 +19,7 @@
#include "pixel.h"
@@ -37,7 +38,6 @@
-char *Rast_get_cat();
/* declare a counter for the number
of pixels with non-null values
Modified: grass/trunk/raster/r.mapcalc/map.c
--- grass/trunk/raster/r.mapcalc/map.c 2009-06-27 11:05:11 UTC (rev 38098)
+++ grass/trunk/raster/r.mapcalc/map.c 2009-06-27 16:25:06 UTC (rev 38099)
@@ -340,7 +340,8 @@
if (!btree_find(btree, &key, &ptr)) {
values = vbuf;
for (i = 0; i < NCATS; i++) {
- if ((label = Rast_get_cat((CELL) (i + key), pcats)) == NULL
+ CELL cat = i + key;
+ if ((label = Rast_get_c_cat((CELL *) cat, pcats)) == NULL
|| sscanf(label, "%lf", values) != 1)
SET_NULL_D(values);
values++;
Modified: grass/trunk/raster/r.mapcalc/map3.c
--- grass/trunk/raster/r.mapcalc/map3.c 2009-06-27 11:05:11 UTC (rev 38098)
+++ grass/trunk/raster/r.mapcalc/map3.c 2009-06-27 16:25:06 UTC (rev 38099)
@@ -298,8 +298,9 @@
values = vbuf;
+ int cat = i + key;
+ if ((label = Rast_get_c_cat((CELL *) &cat, pcats)) == NULL
SET_NULL_D(values);
values++;
Modified: grass/trunk/raster/r.mode/main.c
--- grass/trunk/raster/r.mode/main.c 2009-06-27 11:05:11 UTC (rev 38098)
+++ grass/trunk/raster/r.mode/main.c 2009-06-27 16:25:06 UTC (rev 38099)
@@ -105,7 +105,7 @@
max = value;
if (basecat != catb) {
- write_reclass(reclass, catb, catc, Rast_get_cat(catc, &cover_cats));
+ write_reclass(reclass, catb, catc, Rast_get_c_cat((CELL *) &catc, &cover_cats));
catb = basecat;
catc = covercat;
max = value;
@@ -118,7 +118,7 @@
if (first) {
catb = catc = 0;
pclose(stats);
pclose(reclass);
Modified: grass/trunk/raster/r.neighbors/divr_cats.c
--- grass/trunk/raster/r.neighbors/divr_cats.c 2009-06-27 11:05:11 UTC (rev 38098)
+++ grass/trunk/raster/r.neighbors/divr_cats.c 2009-06-27 16:25:06 UTC (rev 38099)
@@ -4,7 +4,7 @@
int divr_cats(void)
Rast_set_cats_fmt("$1 $?different categories$category$", 1.0, 0.0, 0.0, 0.0,
- &ncb.cats);
+ &ncb.cats);
return 0;
Modified: grass/trunk/raster/r.neighbors/intr_cats.c
--- grass/trunk/raster/r.neighbors/intr_cats.c 2009-06-27 11:05:11 UTC (rev 38098)
+++ grass/trunk/raster/r.neighbors/intr_cats.c 2009-06-27 16:25:06 UTC (rev 38099)
@@ -5,6 +5,6 @@
int intr_cats(void)
Rast_set_cats_fmt("$1% dispersion", 1.0, -1.0, 0.0, 0.0, &ncb.cats);
return 0;
Modified: grass/trunk/raster/r.neighbors/null_cats.c
--- grass/trunk/raster/r.neighbors/null_cats.c 2009-06-27 11:05:11 UTC (rev 38098)
+++ grass/trunk/raster/r.neighbors/null_cats.c 2009-06-27 16:25:06 UTC (rev 38099)
@@ -4,10 +4,7 @@
int null_cats(void)
- int ncats;
+ Rast_init_cats(ncb.title, &ncb.cats);
- ncats = Rast_number_of_cats(ncb.newcell, G_mapset());
- Rast_init_cats(ncats, ncb.title, &ncb.cats);
return 0;
Modified: grass/trunk/raster/r.null/main.c
--- grass/trunk/raster/r.null/main.c 2009-06-27 11:05:11 UTC (rev 38098)
+++ grass/trunk/raster/r.null/main.c 2009-06-27 16:25:06 UTC (rev 38099)
@@ -279,7 +279,7 @@
G_suppress_warnings(1);
if (map_type != CELL_TYPE) {
Rast_quant_init(&quant);
@@ -297,8 +297,8 @@
if (hist_ok)
if (cats_ok) {
- cats.num = Rast_number_of_cats(name, mapset);
- Rast_write_raster_cats(name, &cats);
+ cats.num = Rast_get_max_c_cat(name, mapset);
+ Rast_write_cats(name, &cats);
if (map_type != CELL_TYPE && quant_ok)
Modified: grass/trunk/raster/r.param.scale/param.h
--- grass/trunk/raster/r.param.scale/param.h 2009-06-27 11:05:11 UTC (rev 38098)
+++ grass/trunk/raster/r.param.scale/param.h 2009-06-27 16:25:06 UTC (rev 38099)
@@ -23,27 +23,27 @@
#define RAD2DEG 57.29578
#define DEG2RAD 0.017453293
-#define TINY 1.0e-20;
+#define TINY 1.0e-20
/* Bug? start with 1 as G_set_cats() doesn't accept 0 category */
-#define FLAT ((CELL)1)
-#define PIT ((CELL)2)
-#define CHANNEL ((CELL)3)
-#define PASS ((CELL)4)
-#define RIDGE ((CELL)5)
-#define PEAK ((CELL)6)
+#define FLAT 1
+#define PIT 2
+#define CHANNEL 3
+#define PASS 4
+#define RIDGE 5
+#define PEAK 6
-#define NUM_CATS ((CELL)7)
+#define NUM_CATS 7
-#define ELEV 1
-#define SLOPE 2
-#define ASPECT 3
-#define PROFC 4
-#define PLANC 5
-#define LONGC 6
-#define CROSC 7
-#define MINIC 8
-#define MAXIC 9
+#define ELEV 1
+#define SLOPE 2
+#define ASPECT 3
+#define PROFC 4
+#define PLANC 5
+#define LONGC 6
+#define CROSC 7
+#define MINIC 8
+#define MAXIC 9
#define FEATURE 10
/* The six quadratic coefficients are stored in the array coeff */
Modified: grass/trunk/raster/r.param.scale/write_cats.c
--- grass/trunk/raster/r.param.scale/write_cats.c 2009-06-27 11:05:11 UTC (rev 38098)
+++ grass/trunk/raster/r.param.scale/write_cats.c 2009-06-27 16:25:06 UTC (rev 38099)
@@ -21,24 +21,31 @@
void write_cats(void)
+ CELL cat;
/* INITIALISE */
- Rast_init_cats((CELL) 0, "", &cats);
- Rast_set_raster_cats_title("Surface Features", &cats);
+ Rast_set_cats_title("Surface Features", &cats);
/* FILL OUT CATEGORIES STRUCTURE */
- Rast_set_cat(FLAT, " Planar", &cats);
- Rast_set_cat(PIT, " Pit", &cats);
- Rast_set_cat(PEAK, " Peak", &cats);
- Rast_set_cat(RIDGE, " Ridge", &cats);
- Rast_set_cat(CHANNEL, " Channel", &cats);
- Rast_set_cat(PASS, " Pass (saddle)", &cats);
+ cat = FLAT;
+ Rast_set_c_cat(&cat, &cat, " Planar", &cats);
+ cat = PIT;
+ Rast_set_c_cat(&cat, &cat, " Pit", &cats);
+ cat = PEAK;
+ Rast_set_c_cat(&cat, &cat, " Peak", &cats);
+ cat = RIDGE;
+ Rast_set_c_cat(&cat, &cat, " Ridge", &cats);
+ cat = CHANNEL;
+ Rast_set_c_cat(&cat, &cat, " Channel", &cats);
+ cat = PASS;
+ Rast_set_c_cat(&cat, &cat, " Pass (saddle)", &cats);
/* WRITE OUT CATEGORIES STRUCTURE */
Modified: grass/trunk/raster/r.patch/support.c
--- grass/trunk/raster/r.patch/support.c 2009-06-27 11:05:11 UTC (rev 38098)
+++ grass/trunk/raster/r.patch/support.c 2009-06-27 16:25:06 UTC (rev 38099)
@@ -50,7 +50,7 @@
if (n && !Rast_find_cell_stat(n, &count, statf)) {
if (do_cats) {
Rast_update_cell_stats(&n, 1, statf);
- Rast_set_cat(n, Rast_get_cat(n, &pcats), cats);
+ Rast_set_c_cat(&n, &n, Rast_get_c_cat((CELL *) &n, &pcats), cats);
if (do_colr) {
Rast_get_color(n, &red, &grn, &blu, &pcolr);
Modified: grass/trunk/raster/r.random/support.c
--- grass/trunk/raster/r.random/support.c 2009-06-27 11:05:11 UTC (rev 38098)
+++ grass/trunk/raster/r.random/support.c 2009-06-27 16:25:06 UTC (rev 38099)
@@ -24,15 +24,15 @@
inraster = theState->inraster;
nulls = theState->nulls;
- if (Rast_read_raster_cats(inraster, "", &cats) >= 0) {
+ if (Rast_read_cats(inraster, "", &cats) >= 0) {
sprintf(title, "Random points on <%s>", inraster);
if (theState->use_nulls)
- Rast_set_raster_cat(nulls.data.v,
+ Rast_set_cat(nulls.data.v,
nulls.data.v,
"Points with NULL values in original",
&cats, nulls.type);
- Rast_write_raster_cats(theState->outraster, &cats);
+ Rast_write_cats(theState->outraster, &cats);
/* write history for output raster */
Modified: grass/trunk/raster/r.random.surface/save.c
--- grass/trunk/raster/r.random.surface/save.c 2009-06-27 11:05:11 UTC (rev 38098)
+++ grass/trunk/raster/r.random.surface/save.c 2009-06-27 16:25:06 UTC (rev 38099)
@@ -15,7 +15,8 @@
struct Colors Colr;
char String[80], Label[240];
struct History history;
+ CELL cat;
G_debug(2, "SaveMap()");
OutFD = Rast_open_cell_new(OutNames[NumMap]);
@@ -187,14 +188,15 @@
TheoryCovariance( TheoryName, Label);
- Rast_init_cats(CatInfo.NumCat, Label, &Cats);
+ Rast_init_cats(Label, &Cats);
for (Index = 0; Index < CatInfo.NumCat; Index++) {
if (CatInfo.NumValue[Index] != 0) {
CatInfo.Average[Index] /= CatInfo.NumValue[Index];
sprintf(Label, "%+lf %+lf to %+lf",
CatInfo.Average[Index],
CatInfo.Min[Index], CatInfo.Max[Index]);
- Rast_set_cat(1 + Index, Label, &Cats);
+ cat = Index + 1;
+ Rast_set_c_cat(&cat, &cat, Label, &Cats);
Modified: grass/trunk/raster/r.reclass/parse.c
--- grass/trunk/raster/r.reclass/parse.c 2009-06-27 11:05:11 UTC (rev 38098)
+++ grass/trunk/raster/r.reclass/parse.c 2009-06-27 16:25:06 UTC (rev 38099)
@@ -142,7 +142,7 @@
if (*rules == NULL)
*rules = *tail;
if (*label)
- Rast_set_cat(new, label, cats);
+ Rast_set_c_cat(&new, &new, label, cats);
return count;
Modified: grass/trunk/raster/r.reclass/reclass.c
--- grass/trunk/raster/r.reclass/reclass.c 2009-06-27 11:05:11 UTC (rev 38098)
+++ grass/trunk/raster/r.reclass/reclass.c 2009-06-27 16:25:06 UTC (rev 38099)
@@ -161,13 +161,13 @@
for (i = 0; i < rec->num; i++)
if (is_default[i]) {
int x = i + rec->min;
- char *label = Rast_get_cat(x, &old_cats);
+ char *label = Rast_get_c_cat(&x, &old_cats);
- Rast_set_cat(x, label, cats);
+ Rast_set_c_cat(&x, &x, label, cats);
else if (default_rule)
- Rast_set_cat(DEFAULT, default_label, cats);
+ Rast_set_c_cat(&DEFAULT, &DEFAULT, default_label, cats);
static int _reclass( /* const */ RULE * rules, struct Categories *cats,
Modified: grass/trunk/raster/r.report/prt_report.c
--- grass/trunk/raster/r.report/prt_report.c 2009-06-27 11:05:11 UTC (rev 38098)
+++ grass/trunk/raster/r.report/prt_report.c 2009-06-27 16:25:06 UTC (rev 38099)
@@ -270,7 +270,7 @@
else { /* find out which floating point range to print */
if (cat_ranges)
- descr = Rast_get_ith_d_raster_cat(&layers[nl].labels, *pval,
+ descr = Rast_get_ith_d_cat(&layers[nl].labels, *pval,
&dLow, &dHigh);
else {
dLow = (DMAX[nl] - DMIN[nl]) / nsteps *
@@ -296,13 +296,13 @@
static char str[500];
if (!is_fp[nl] || as_int)
- return Rast_get_cat(cat, &layers[nl].labels);
+ return Rast_get_c_cat(&cat, &layers[nl].labels);
else { /* find or construct the label for
if (Rast_is_c_null_value(&tmp))
return G_store("no data");
if (cat_ranges)
- return Rast_get_ith_d_raster_cat(&layers[nl].labels, cat,
+ return Rast_get_ith_d_cat(&layers[nl].labels, cat,
&dLow, &dHigh);
else {
dLow = (DMAX[nl] - DMIN[nl]) / (double)nsteps *
@@ -310,8 +310,8 @@
dHigh = (DMAX[nl] - DMIN[nl]) / (double)nsteps *
(double)cat + DMIN[nl];
sprintf(str, "from %s to %s",
- Rast_get_d_raster_cat(&dLow, &layers[nl].labels),
- Rast_get_d_raster_cat(&dHigh, &layers[nl].labels));
+ Rast_get_d_cat(&dLow, &layers[nl].labels),
+ Rast_get_d_cat(&dHigh, &layers[nl].labels));
return str;
} /* fp label */
Modified: grass/trunk/raster/r.resample/main.c
--- grass/trunk/raster/r.resample/main.c 2009-06-27 11:05:11 UTC (rev 38098)
+++ grass/trunk/raster/r.resample/main.c 2009-06-27 16:25:06 UTC (rev 38099)
@@ -83,8 +83,8 @@
colr_ok = Rast_read_colors(name, "", &colr) > 0;
cats_ok = Rast_read_cats(name, "", &cats) >= 0;
if (cats_ok) {
- Rast_unmark_raster_cats(&cats);
- Rast_init_cats((CELL) 0, Rast_get_cats_title(&cats), &newcats);
+ Rast_unmark_cats(&cats);
infd = Rast_open_cell_old(name, "");
@@ -122,7 +122,7 @@
G_fatal_error(_("Error reading row %d"), row);
if (Rast_put_raster_row(outfd, rast, out_type) < 0)
G_fatal_error(_("Error writing row %d"), row);
- Rast_mark_raster_cats(rast, ncols, &cats, data_type);
+ Rast_mark_cats(rast, ncols, &cats, data_type);
G_percent(row, nrows, 2);
@@ -133,7 +133,7 @@
Rast_close_cell(outfd);
if (cats_ok) {
long count;
@@ -143,10 +143,10 @@
rast2 = G_incr_void_ptr(rast, Rast_cell_size(data_type));
G_message(_("Creating new cats file..."));
- while (Rast_get_next_marked_raster_cat(&cats,
+ while (Rast_get_next_marked_cat(&cats,
rast1, rast2, &count, data_type))
- Rast_get_raster_cat(rast1, &cats, data_type),
+ Rast_get_cat(rast1, &cats, data_type),
&newcats, data_type);
Rast_write_cats(result, &newcats);
Modified: grass/trunk/raster/r.slope.aspect/main.c
--- grass/trunk/raster/r.slope.aspect/main.c 2009-06-27 11:05:11 UTC (rev 38098)
+++ grass/trunk/raster/r.slope.aspect/main.c 2009-06-27 16:25:06 UTC (rev 38099)
@@ -75,6 +75,7 @@
DCELL *c1, *c2, *c3, *c4, *c5, *c6, *c7, *c8, *c9;
DCELL tmp1, tmp2;
FCELL dat1, dat2;
+ CELL cat;
void *asp_raster, *asp_ptr = NULL;
void *slp_raster, *slp_ptr = NULL;
void *pcurv_raster, *pcurv_ptr = NULL;
@@ -1008,8 +1009,8 @@
Rast_quantize_fp_map_range(aspect_name, G_mapset(), 0., 360., 0,
360);
- Rast_read_raster_cats(aspect_name, G_mapset(), &cats);
+ Rast_read_cats(aspect_name, G_mapset(), &cats);
("Aspect counterclockwise in degrees from east", &cats);
G_verbose_message(_("Min computed aspect %.4f, max computed aspect %.4f"),
@@ -1041,22 +1042,24 @@
sprintf(buf, "%d degree%s ccw from east", i,
i == 1 ? "" : "s");
if (data_type == CELL_TYPE) {
- Rast_set_cat(i, buf, &cats);
+ Rast_set_c_cat((CELL *) &i, (CELL *) &i, buf, &cats);
continue;
tmp1 = (double)i - .5;
tmp2 = (double)i + .5;
- Rast_set_d_raster_cat(&tmp1, &tmp2, buf, &cats);
+ Rast_set_d_cat(&tmp1, &tmp2, buf, &cats);
- if (data_type == CELL_TYPE)
- Rast_set_cat(0, "no aspect", &cats);
+ if (data_type == CELL_TYPE) {
+ cat = 0;
+ Rast_set_c_cat(&cat, &cat, "no aspect", &cats);
else {
tmp1 = 0.;
tmp2 = .5;
- Rast_set_d_raster_cat(&tmp1, &tmp2, "no aspect", &cats);
+ Rast_set_d_cat(&tmp1, &tmp2, "no aspect", &cats);
- Rast_write_raster_cats(aspect_name, &cats);
+ Rast_write_cats(aspect_name, &cats);
/* write colors for aspect file */
Rast_init_colors(&colors);
@@ -1110,11 +1113,11 @@
(CELL) ceil(max_slp));
- Rast_read_raster_cats(slope_name, G_mapset(), &cats);
+ Rast_read_cats(slope_name, G_mapset(), &cats);
if (deg)
- Rast_set_raster_cats_title("slope in degrees", &cats);
+ Rast_set_cats_title("slope in degrees", &cats);
else if (perc)
- Rast_set_raster_cats_title("percent slope", &cats);
+ Rast_set_cats_title("percent slope", &cats);
G_verbose_message(_("Min computed slope %.4f, max computed slope %.4f"),
min_slp, max_slp);
@@ -1129,9 +1132,9 @@
sprintf(buf, "%d percent", i);
/* INCR_BY_ONE
- Rast_set_cat(i+1, buf, &cats);
+ Rast_set_c_cat(i+1, buf, &cats);
+ Rast_set_c_cat(&i, &i, buf, &cats);
continue;
/* INCR_BY_ONE
@@ -1140,22 +1143,24 @@
tmp1 = (DCELL) i - .5;
tmp2 = (DCELL) i + .5;
- Rast_set_cat(0, "zero slope", &cats);
+ cat = 0;
+ Rast_set_c_cat(&cat, &cat, "zero slope", &cats);
/* INCR_BY_ONE
- Rast_set_cat(0, "no data", &cats);
+ Rast_set_c_cat(0, "no data", &cats);
else {
tmp1 = 0;
tmp2 = 0.5;
- Rast_set_d_raster_cat(&tmp1, &tmp2, "zero slope", &cats);
+ Rast_set_d_cat(&tmp1, &tmp2, "zero slope", &cats);
/* INCR_BY_ONE
- Rast_set_d_raster_cat (&tmp1, &tmp1, "no data", &cats);
+ Rast_set_d_cat (&tmp1, &tmp1, "no data", &cats);
- Rast_write_raster_cats(slope_name, &cats);
+ Rast_write_cats(slope_name, &cats);
/* writing history file */
Rast_short_history(slope_name, "raster", &hist);
@@ -1227,7 +1232,8 @@
Rast_read_cats(pcurv_name, G_mapset(), &cats);
Rast_set_cats_title("profile curvature", &cats);
- Rast_set_cat((CELL) 0, "no profile curve", &cats);
+ cat = 0;
+ Rast_set_c_cat(&cat, &cat, "no profile curve", &cats);
Rast_short_history(pcurv_name, "raster", &hist);
@@ -1253,7 +1259,8 @@
Rast_read_cats(tcurv_name, G_mapset(), &cats);
Rast_set_cats_title("tangential curvature", &cats);
- Rast_set_cat((CELL) 0, "no tangential curve", &cats);
+ cat = 0;
+ Rast_set_c_cat(&cat, &cat, "no tangential curve", &cats);
Rast_short_history(tcurv_name, "raster", &hist);
@@ -1277,7 +1284,8 @@
Rast_read_cats(dx_name, G_mapset(), &cats);
Rast_set_cats_title("E-W slope", &cats);
- Rast_set_cat((CELL) 0, "no E-W slope", &cats);
+ cat = 0;
+ Rast_set_c_cat(&cat, &cat, "no E-W slope", &cats);
Rast_short_history(dx_name, "raster", &hist);
@@ -1301,7 +1309,8 @@
Rast_read_cats(dy_name, G_mapset(), &cats);
Rast_set_cats_title("N-S slope", &cats);
- Rast_set_cat((CELL) 0, "no N-S slope", &cats);
+ cat = 0;
+ Rast_set_c_cat(&cat, &cat, "no N-S slope", &cats);
Rast_short_history(dy_name, "raster", &hist);
@@ -1325,7 +1334,8 @@
Rast_read_cats(dxx_name, G_mapset(), &cats);
Rast_set_cats_title("DXX", &cats);
- Rast_set_cat((CELL) 0, "DXX", &cats);
+ cat = 0;
+ Rast_set_c_cat(&cat, &cat, "DXX", &cats);
Rast_short_history(dxx_name, "raster", &hist);
@@ -1349,7 +1359,8 @@
Rast_read_cats(dyy_name, G_mapset(), &cats);
Rast_set_cats_title("DYY", &cats);
- Rast_set_cat((CELL) 0, "DYY", &cats);
+ cat = 0;
+ Rast_set_c_cat(&cat, &cat, "DYY", &cats);
Rast_short_history(dyy_name, "raster", &hist);
@@ -1373,7 +1384,8 @@
Rast_read_cats(dxy_name, G_mapset(), &cats);
Rast_set_cats_title("DXY", &cats);
- Rast_set_cat((CELL) 0, "DXY", &cats);
+ cat = 0;
+ Rast_set_c_cat(&cat, &cat, "DXY", &cats);
Rast_short_history(dxy_name, "raster", &hist);
Modified: grass/trunk/raster/r.statistics/o_adev.c
--- grass/trunk/raster/r.statistics/o_adev.c 2009-06-27 11:05:11 UTC (rev 38098)
+++ grass/trunk/raster/r.statistics/o_adev.c 2009-06-27 16:25:06 UTC (rev 38099)
@@ -54,7 +54,7 @@
if (usecats)
- sscanf(Rast_get_cat((CELL) covercat, cats), "%lf", &x);
+ sscanf(Rast_get_c_cat((CELL *) &covercat, cats), "%lf", &x);
else
x = covercat;
Modified: grass/trunk/raster/r.statistics/o_average.c
--- grass/trunk/raster/r.statistics/o_average.c 2009-06-27 11:05:11 UTC (rev 38098)
+++ grass/trunk/raster/r.statistics/o_average.c 2009-06-27 16:25:06 UTC (rev 38099)
@@ -54,7 +54,7 @@
catb = basecat;
if (usecats)
else
x = covercat;
sum1 += x * area;
Modified: grass/trunk/raster/r.statistics/o_divr.c
--- grass/trunk/raster/r.statistics/o_divr.c 2009-06-27 11:05:11 UTC (rev 38098)
+++ grass/trunk/raster/r.statistics/o_divr.c 2009-06-27 16:25:06 UTC (rev 38099)
@@ -31,7 +31,7 @@
catc = 0;
- write_reclass(reclass_fd, catb, catc, Rast_get_cat(catc, cats),
+ write_reclass(reclass_fd, catb, catc, Rast_get_c_cat((CELL *) &catc, cats),
usecats);
catb = basecat;
catc = 0;
@@ -39,7 +39,7 @@
catc++;
if (!first)
- write_reclass(reclass_fd, catb, catc, Rast_get_cat(catc, cats), usecats);
+ write_reclass(reclass_fd, catb, catc, Rast_get_c_cat((CELL *) &catc, cats), usecats);
pclose(stats_fd);
pclose(reclass_fd);
Modified: grass/trunk/raster/r.statistics/o_kurt.c
--- grass/trunk/raster/r.statistics/o_kurt.c 2009-06-27 11:05:11 UTC (rev 38098)
+++ grass/trunk/raster/r.statistics/o_kurt.c 2009-06-27 16:25:06 UTC (rev 38099)
@@ -53,7 +53,7 @@
if (usecats)
else
x = covercat;
Modified: grass/trunk/raster/r.statistics/o_max.c
--- grass/trunk/raster/r.statistics/o_max.c 2009-06-27 11:05:11 UTC (rev 38098)
+++ grass/trunk/raster/r.statistics/o_max.c 2009-06-27 16:25:06 UTC (rev 38099)
@@ -30,7 +30,7 @@
- write_reclass(reclass, catb, catc, Rast_get_cat(catc, cats),
+ write_reclass(reclass, catb, catc, Rast_get_c_cat((CELL *) &catc, cats),
usecats);
catb = basecat;
catc = covercat;
@@ -44,7 +44,7 @@
catb = catc = 0;
- write_reclass(reclass, catb, catc, Rast_get_cat(catc, cats), usecats);
+ write_reclass(reclass, catb, catc, Rast_get_c_cat((CELL *) &catc, cats), usecats);
pclose(stats);
pclose(reclass);
Modified: grass/trunk/raster/r.statistics/o_median.c
--- grass/trunk/raster/r.statistics/o_median.c 2009-06-27 11:05:11 UTC (rev 38098)
+++ grass/trunk/raster/r.statistics/o_median.c 2009-06-27 16:25:06 UTC (rev 38099)
@@ -42,7 +42,7 @@
catc = median(&stats);
usecats);
catb = basecat;
stats.n = 0;
@@ -60,7 +60,7 @@
if (!first) {
pclose(stats_fd);
Modified: grass/trunk/raster/r.statistics/o_min.c
--- grass/trunk/raster/r.statistics/o_min.c 2009-06-27 11:05:11 UTC (rev 38098)
+++ grass/trunk/raster/r.statistics/o_min.c 2009-06-27 16:25:06 UTC (rev 38099)
@@ -30,7 +30,7 @@
usecats);
catb = basecat;
catc = covercat;
@@ -44,7 +44,7 @@
catb = catc = 0;
pclose(stats);
pclose(reclass);
Modified: grass/trunk/raster/r.statistics/o_mode.c
--- grass/trunk/raster/r.statistics/o_mode.c 2009-06-27 11:05:11 UTC (rev 38098)
+++ grass/trunk/raster/r.statistics/o_mode.c 2009-06-27 16:25:06 UTC (rev 38099)
@@ -32,7 +32,7 @@
usecats);
catb = basecat;
catc = covercat;
@@ -49,7 +49,7 @@
catb = catc = 0;
pclose(stats);
pclose(reclass);
Modified: grass/trunk/raster/r.statistics/o_sdev.c
--- grass/trunk/raster/r.statistics/o_sdev.c 2009-06-27 11:05:11 UTC (rev 38098)
+++ grass/trunk/raster/r.statistics/o_sdev.c 2009-06-27 16:25:06 UTC (rev 38099)
@@ -56,7 +56,7 @@
if (usecats)
else
x = covercat;
Modified: grass/trunk/raster/r.statistics/o_skew.c
--- grass/trunk/raster/r.statistics/o_skew.c 2009-06-27 11:05:11 UTC (rev 38098)
+++ grass/trunk/raster/r.statistics/o_skew.c 2009-06-27 16:25:06 UTC (rev 38099)
@@ -55,7 +55,7 @@
if (usecats)
else
x = covercat;
Modified: grass/trunk/raster/r.statistics/o_sum.c
--- grass/trunk/raster/r.statistics/o_sum.c 2009-06-27 11:05:11 UTC (rev 38098)
+++ grass/trunk/raster/r.statistics/o_sum.c 2009-06-27 16:25:06 UTC (rev 38099)
@@ -56,7 +56,7 @@
catb = basecat;
if (usecats)
else
x = covercat;
sum1 += x * area;
Modified: grass/trunk/raster/r.statistics/o_var.c
--- grass/trunk/raster/r.statistics/o_var.c 2009-06-27 11:05:11 UTC (rev 38098)
+++ grass/trunk/raster/r.statistics/o_var.c 2009-06-27 16:25:06 UTC (rev 38099)
@@ -56,7 +56,7 @@
if (usecats)
else
x = covercat;
Modified: grass/trunk/raster/r.statistics2/main.c
--- grass/trunk/raster/r.statistics2/main.c 2009-06-27 11:05:11 UTC (rev 38098)
+++ grass/trunk/raster/r.statistics2/main.c 2009-06-27 16:25:06 UTC (rev 38099)
@@ -270,7 +270,7 @@
v = cover_buf[col];
if (usecats)
- sscanf(Rast_get_cat((CELL) v, &cats), "%lf", &v);
+ sscanf(Rast_get_c_cat((CELL *) &v, &cats), "%lf", &v);
if (count)
count[n]++;
@@ -349,7 +349,7 @@
v = cover_buf[col];
if (usecats)
d = v - mean[n];
if (sumu)
Modified: grass/trunk/raster/r.stats/raw_stats.c
--- grass/trunk/raster/r.stats/raw_stats.c 2009-06-27 11:05:11 UTC (rev 38098)
+++ grass/trunk/raster/r.stats/raw_stats.c 2009-06-27 16:25:06 UTC (rev 38099)
@@ -82,14 +82,14 @@
fprintf(stdout, "%s%s", i ? fs : "", no_data_str);
if (with_labels)
fprintf(stdout, "%s%s", fs,
- Rast_get_cat(null_cell, &labels[i]));
+ Rast_get_c_cat(&null_cell, &labels[i]));
else if (map_type[i] == CELL_TYPE) {
fprintf(stdout, "%s%ld", i ? fs : "",
(long)*((CELL *) rastp[i]));
if (with_labels && !is_fp[i])
- Rast_get_cat(*((CELL *) rastp[i]), &labels[i]));
+ Rast_get_c_cat((CELL *) rastp[i], &labels[i]));
else { /* floating point cell */
@@ -99,7 +99,7 @@
fprintf(stdout, "%s%s", i ? fs : "", str1);
if (with_labels)
- Rast_get_d_raster_cat((DCELL *) rastp[i],
+ Rast_get_d_cat((DCELL *) rastp[i],
&labels[i]));
rastp[i] =
Modified: grass/trunk/raster/r.stats/stats.c
--- grass/trunk/raster/r.stats/stats.c 2009-06-27 11:05:11 UTC (rev 38098)
+++ grass/trunk/raster/r.stats/stats.c 2009-06-27 16:25:06 UTC (rev 38099)
@@ -242,7 +242,7 @@
if (with_percents)
fprintf(stdout, "%s0.00%%", fs);
if (with_labels)
- fprintf(stdout, "%s%s", fs, Rast_get_cat(null_cell, &labels[i]));
+ fprintf(stdout, "%s%s", fs, Rast_get_c_cat(&null_cell, &labels[i]));
fprintf(stdout, "\n");
else {
@@ -271,14 +271,14 @@
if (with_labels && !(raw_output && is_fp[i]))
else if (raw_output || !is_fp[i] || as_int) {
(long)node->values[i]);
- Rast_get_cat((CELL) node->values[i],
+ Rast_get_c_cat((CELL*) &(node->values[i]),
&labels[i]));
@@ -316,8 +316,8 @@
labels[i].labels[node->values[i]]);
else
fprintf(stdout, "%sfrom %s to %s", fs,
- Rast_get_d_raster_cat(&dLow, &labels[i]),
- Rast_get_d_raster_cat(&dHigh, &labels[i]));
+ Rast_get_d_cat(&dLow, &labels[i]),
+ Rast_get_d_cat(&dHigh, &labels[i]));
Modified: grass/trunk/raster/r.to.vect/areas_io.c
--- grass/trunk/raster/r.to.vect/areas_io.c 2009-06-27 11:05:11 UTC (rev 38098)
+++ grass/trunk/raster/r.to.vect/areas_io.c 2009-06-27 16:25:06 UTC (rev 38099)
@@ -357,7 +357,7 @@
db_append_string(&sql, buf);
if (has_cats) {
- temp_buf = Rast_get_cat(p->cat, &RastCats);
+ temp_buf = Rast_get_c_cat(&(p->cat), &RastCats);
db_set_string(&label, temp_buf);
db_double_quote_string(&label);
Modified: grass/trunk/raster/r.to.vect/util.c
--- grass/trunk/raster/r.to.vect/util.c 2009-06-27 11:05:11 UTC (rev 38098)
+++ grass/trunk/raster/r.to.vect/util.c 2009-06-27 16:25:06 UTC (rev 38099)
@@ -141,7 +141,7 @@
if (has_cats) {
char *lab;
- lab = Rast_get_cat(val, &RastCats); /*cats are loaded only for CELL type */
+ lab = Rast_get_c_cat(&val, &RastCats); /*cats are loaded only for CELL type */
db_set_string(&label, lab);
Modified: grass/trunk/raster/r.volume/main.c
--- grass/trunk/raster/r.volume/main.c 2009-06-27 11:05:11 UTC (rev 38098)
+++ grass/trunk/raster/r.volume/main.c 2009-06-27 16:25:06 UTC (rev 38099)
@@ -133,7 +133,7 @@
/* initialize data accumulation arrays */
- max = Rast_number_of_cats(clumpmap, clump_mapset);
+ max = Rast_get_max_c_cat(clumpmap, clump_mapset);
sum = (double *)G_malloc((max + 1) * sizeof(double));
count = (long int *)G_malloc((max + 1) * sizeof(long int));
@@ -164,7 +164,7 @@
if (i > max)
G_fatal_error(
"Row=%d Col=%d Cat=%d in clump map [%s]; max=%d.\n"
- "Cat value > max returned by Rast_number_of_cats.",
+ "Cat value > max returned by Rast_get_max_c_cat.",
row, col, i, clumpmap, max);
if (i < 1)
continue; /* ignore zeros and negs */
Modified: grass/trunk/raster/r.watershed/shed/print.c
--- grass/trunk/raster/r.watershed/shed/print.c 2009-06-27 11:05:11 UTC (rev 38098)
+++ grass/trunk/raster/r.watershed/shed/print.c 2009-06-27 16:25:06 UTC (rev 38099)
@@ -67,7 +67,7 @@
do_cat = &(output->maps[b].basins[c].first_cat);
while ((output->maps[b].do_cats != 0) && do_cat) {
cat_name =
- Rast_get_cat(do_cat->cat_val, &(output->maps[b].cats));
+ Rast_get_c_cat(&(do_cat->cat_val), &(output->maps[b].cats));
switch (output->type_area) {
case 1:
sprintf(area, "%.3f acres",
Modified: grass/trunk/raster/r.what/main.c
--- grass/trunk/raster/r.what/main.c 2009-06-27 11:05:11 UTC (rev 38098)
+++ grass/trunk/raster/r.what/main.c 2009-06-27 16:25:06 UTC (rev 38099)
@@ -404,7 +404,7 @@
if (withcats)
fprintf(stdout, "%c%s", fs,
- Rast_get_cat(cache[point].value[i], &cats[i]));
+ Rast_get_c_cat(&(cache[point].value[i]), &cats[i]));
if (flag4->answer)
fprintf(stdout, "%c%s", fs, cache[point].clr_buf[i]);
Modified: grass/trunk/swig/perl/R_slope_aspect/r_slope_aspect/r_slope_aspect.c
--- grass/trunk/swig/perl/R_slope_aspect/r_slope_aspect/r_slope_aspect.c 2009-06-27 11:05:11 UTC (rev 38098)
+++ grass/trunk/swig/perl/R_slope_aspect/r_slope_aspect/r_slope_aspect.c 2009-06-27 16:25:06 UTC (rev 38099)
@@ -1035,8 +1035,8 @@
360);
G_message(_("Min computed aspect %.4f, max computed aspect %.4f"),
@@ -1068,22 +1068,22 @@
i == 1 ? "" : "s");
+ Rast_set_c_cat(i, buf, &cats);
continue;
+ Rast_set_c_cat(0, "no aspect", &cats);
else {
tmp1 = 0.;
tmp2 = .5;
@@ -1137,11 +1137,11 @@
if (deg)
else if (perc)
G_message(_("Min computed slope %.4f, max computed slope %.4f"),
min_slp, max_slp);
@@ -1156,9 +1156,9 @@
/* INCR_BY_ONE
continue;
/* INCR_BY_ONE
@@ -1167,22 +1167,22 @@
+ Rast_set_c_cat(0, "zero slope", &cats);
/* INCR_BY_ONE
else {
tmp1 = 0;
tmp2 = 0.5;
/* INCR_BY_ONE
@@ -1253,8 +1253,8 @@
Rast_round_fp_map(pcurv_name, G_mapset());
- Rast_set_cats_title("profile curvature", &cats);
+ Rast_set_c_cats_title("profile curvature", &cats);
+ Rast_set_c_cat((CELL) 0, "no profile curve", &cats);
@@ -1279,8 +1279,8 @@
Rast_round_fp_map(tcurv_name, G_mapset());
- Rast_set_cats_title("tangential curvature", &cats);
+ Rast_set_c_cats_title("tangential curvature", &cats);
+ Rast_set_c_cat((CELL) 0, "no tangential curve", &cats);
@@ -1303,8 +1303,8 @@
Rast_round_fp_map(dx_name, G_mapset());
- Rast_set_cats_title("E-W slope", &cats);
+ Rast_set_c_cats_title("E-W slope", &cats);
+ Rast_set_c_cat((CELL) 0, "no E-W slope", &cats);
@@ -1327,8 +1327,8 @@
Rast_round_fp_map(dy_name, G_mapset());
- Rast_set_cats_title("N-S slope", &cats);
+ Rast_set_c_cats_title("N-S slope", &cats);
+ Rast_set_c_cat((CELL) 0, "no N-S slope", &cats);
@@ -1351,8 +1351,8 @@
Rast_round_fp_map(dxx_name, G_mapset());
- Rast_set_cats_title("DXX", &cats);
+ Rast_set_c_cats_title("DXX", &cats);
+ Rast_set_c_cat((CELL) 0, "DXX", &cats);
@@ -1375,8 +1375,8 @@
Rast_round_fp_map(dyy_name, G_mapset());
- Rast_set_cats_title("DYY", &cats);
+ Rast_set_c_cats_title("DYY", &cats);
+ Rast_set_c_cat((CELL) 0, "DYY", &cats);
@@ -1399,8 +1399,8 @@
Rast_round_fp_map(dxy_name, G_mapset());
- Rast_set_cats_title("DXY", &cats);
+ Rast_set_c_cats_title("DXY", &cats);
+ Rast_set_c_cat((CELL) 0, "DXY", &cats);
Modified: grass/trunk/vector/v.to.rast/support.c
--- grass/trunk/vector/v.to.rast/support.c 2009-06-27 11:05:11 UTC (rev 38098)
+++ grass/trunk/vector/v.to.rast/support.c 2009-06-27 16:25:06 UTC (rev 38099)
@@ -71,11 +71,11 @@
int update_cats(const char *raster_name)
/* TODO: maybe attribute transfer from vector map?
- Use Rast_set_raster_cat() somewhere */
+ Use Rast_set_cat() somewhere */
- Rast_init_cats((CELL) 0, raster_name, &cats);
+ Rast_init_cats(raster_name, &cats);
Rast_write_cats(raster_name, &cats);
return 0;
@@ -257,7 +257,7 @@
} *my_labels_rules;
/* init raster categories */
- Rast_init_cats((CELL) 0, "Categories", &rast_cats);
+ Rast_init_cats("Categories", &rast_cats);
if (!(fd = Rast_open_cell_old(rast_name, G_mapset())))
G_fatal_error(_("Unable to open raster map <%s>"), rast_name);
@@ -265,7 +265,7 @@
switch (use) {
case USE_ATTR:
- Rast_set_raster_cats_title("Labels", &rast_cats);
+ Rast_set_cats_title("Labels", &rast_cats);
int is_fp = Rast_raster_map_is_fp(rast_name, G_mapset());
/* open vector map and database driver */
@@ -362,16 +362,17 @@
if (is_fp) {
/* add label */
for (i = 0; i < labels_n_values - 1; i++)
- Rast_set_raster_cat(&my_labels_rules[i].d,
+ Rast_set_cat(&my_labels_rules[i].d,
&my_labels_rules[i + 1].d,
db_get_string(&my_labels_rules[i].label),
&rast_cats, DCELL_TYPE);
else {
for (i = 0; i < labels_n_values; i++)
- Rast_set_cat(my_labels_rules[i].i,
- db_get_string(&my_labels_rules[i].label),
- &rast_cats);
+ Rast_set_c_cat(&(my_labels_rules[i].i),
+ &(my_labels_rules[i].i),
+ db_get_string(&my_labels_rules[i].label),
+ &rast_cats);
break;
@@ -383,7 +384,7 @@
struct Range range;
map_type = Rast_raster_map_type(rast_name, G_mapset());
- Rast_set_raster_cats_title("Values", &rast_cats);
+ Rast_set_cats_title("Values", &rast_cats);
if (map_type == CELL_TYPE) {
CELL min, max;
@@ -392,7 +393,7 @@
Rast_get_range_min_max(&range, &min, &max);
sprintf(msg, "Value %d", val);
- Rast_set_raster_cat(&min, &max, msg, &rast_cats, map_type);
+ Rast_set_cat(&min, &max, msg, &rast_cats, map_type);
else {
DCELL fmin, fmax;
@@ -401,7 +402,7 @@
Rast_get_fp_range_min_max(&fprange, &fmin, &fmax);
sprintf(msg, "Value %.4f", (double)val);
- Rast_set_raster_cat(&fmin, &fmax, msg, &rast_cats, map_type);
+ Rast_set_cat(&fmin, &fmax, msg, &rast_cats, map_type);
@@ -424,7 +425,7 @@
G_fatal_error(_("Cannot allocate memory for row buffer"));
- Rast_set_raster_cats_title("Categories", &rast_cats);
+ Rast_set_cats_title("Categories", &rast_cats);
rows = G_window_rows();
@@ -442,7 +443,7 @@
char msg[80];
sprintf(msg, "Category %d", n);
- Rast_set_raster_cat(&n, &n, msg, &rast_cats, map_type);
+ Rast_set_cat(&n, &n, msg, &rast_cats, map_type);
G_free(rowbuf);
@@ -456,7 +457,7 @@
char msg[64];
- Rast_set_raster_cats_title("Degrees", &rast_cats);
+ Rast_set_cats_title("Degrees", &rast_cats);
for (i = 1; i <= 360; i++) {
sprintf(msg, "%d degrees", i);
@@ -464,7 +465,7 @@
if (i == 360) {
fmin = 359.5;
fmax = 360.0;
fmin = 0.0;
fmax = 0.5;
@@ -473,7 +474,7 @@
fmax = i + 0.5;
break;
