[GRASS-SVN] r38114 - grass-addons/vector/v.krige
svn_grass at osgeo.org
Mon Jun 29 09:57:40 EDT 2009
Author: aghisla
Date: 2009-06-29 09:57:40 -0400 (Mon, 29 Jun 2009)
New Revision: 38114
grass-addons/vector/v.krige/v.krige.py
added the widget for output map name - minor edits
Modified: grass-addons/vector/v.krige/v.krige.py
--- grass-addons/vector/v.krige/v.krige.py 2009-06-29 09:49:36 UTC (rev 38113)
+++ grass-addons/vector/v.krige/v.krige.py 2009-06-29 13:57:40 UTC (rev 38114)
@@ -107,7 +107,22 @@
self.RPackagesBook.SetSelection(0)
KrigingSizer.Add(self.RPackagesBook, proportion=1, flag=wx.EXPAND)
-# 3. Run Button and Quit Button
+# 3. Output Parameters.
+ OutputSizer = wx.StaticBoxSizer(wx.StaticBox(self, id=wx.ID_ANY, label=_("Output")), wx.HORIZONTAL)
+ OutputParameters = wx.FlexGridSizer(cols=3, hgap=5, vgap=5)
+ OutputParameters.AddGrowableCol(1)
+ OutputParameters.Add(item = wx.StaticText(self, id=wx.ID_ANY, label=_("Name of the output map:")),
+ flag = wx.ALIGN_CENTER_VERTICAL)
+ self.OutputMapName = wx.TextCtrl(self, id=wx.ID_ANY)
+ OutputParameters.Add(item=self.OutputMapName, flag=wx.EXPAND | wx.ALL)
+ self.OverwriteCheckBox = wx.CheckBox(self, id=wx.ID_ANY, label=_("Allow output files to overwrite existing files"))
+ self.OverwriteCheckBox.SetValue(state = False)
+ OutputParameters.Add(self.OverwriteCheckBox)
+ OutputSizer.Add(OutputParameters, proportion=0, flag=wx.EXPAND | wx.ALL, border=3)
+# 4. Run Button and Quit Button
ButtonSizer = wx.BoxSizer(wx.HORIZONTAL)
QuitButton = wx.Button(self, id=wx.ID_EXIT)
QuitButton.Bind(wx.EVT_BUTTON, self.OnCloseWindow)
@@ -120,6 +135,7 @@
Sizer = wx.BoxSizer(wx.VERTICAL)
Sizer.Add(InputBoxSizer, proportion=0, flag=wx.EXPAND | wx.ALL, border=self.border)
Sizer.Add(KrigingSizer, proportion=0, flag=wx.EXPAND | wx.ALL, border=self.border)
+ Sizer.Add(OutputSizer, proportion=0, flag=wx.EXPAND | wx.ALL, border=self.border)
Sizer.Add(ButtonSizer, proportion=0, flag=wx.ALIGN_RIGHT | wx.ALL, border=self.border)
self.SetSizerAndFit(Sizer)
@@ -154,10 +170,11 @@
InputData = robjects.r.readVECT6(self.InputDataMap.GetValue(), type= 'point')
#1.5 create the grid where to estimate values. Not used by block-kriging
Grid = robjects.r.gmeta2grd()
+ Region = grass.region()
##create the spatialgriddataframe with these settings
GridPredicted = robjects.r.SpatialGridDataFrame(Grid,
data=robjects.r['data.frame']
- (k=robjects.r.rep(1,grass.region()['cols']*grass.region()['rows'])),
+ (k=robjects.r.rep(1,Region['cols']*Region['rows'])),
proj4string=robjects.r.CRS(robjects.r.proj4string(InputData)))
#2. collect options
@@ -175,11 +192,12 @@
#4. Kriging
self.parent.log.write('Kriging...')
KrigingResult = SelectedPanel.DoKriging(formula = Formula, data = InputData, grid = GridPredicted, model = Variogram)
self.parent.log.write('Kriging performed..')
#5. Format output
- robjects.r.writeRAST6(KrigingResult, vname = 'KrigingResult', zcol='var1.pred')
+ print self.OutputMapName.GetValue()
+ robjects.r.writeRAST6(KrigingResult, vname = self.OutputMapName.GetValue(), zcol='var1.pred',
+ overwrite = self.OverwriteCheckBox.GetValue())
self.parent.log.write('Wow! Succeeded! Ready for another run.')
def OnCloseWindow(self, event):
@@ -238,10 +256,10 @@
self.VariogramCheckBox.Bind(wx.EVT_CHECKBOX, self.HideOptions)
- self.KrigingList = ["Ordinary kriging", "Universal Kriging", "Block kriging"] #@FIXME: i18n on the list?
+ KrigingList = ["Ordinary kriging", "Universal Kriging", "Block kriging"] #@FIXME: i18n on the list?
KrigingRadioBox = wx.RadioBox(self, id=wx.ID_ANY, label=_("Kriging techniques"),
pos=wx.DefaultPosition, size=wx.DefaultSize,
- choices=self.KrigingList, majorDimension=1, style=wx.RA_SPECIFY_COLS)
+ choices=KrigingList, majorDimension=1, style=wx.RA_SPECIFY_COLS)
Sizer.Add(VariogramSizer, proportion=0, flag=wx.EXPAND | wx.ALL, border=3)
@@ -262,19 +280,21 @@
""" Subclass of RBookPanel, with specific automap options and kriging functions. """
def __init__(self, parent, *args, **kwargs):
RBookPanel.__init__(self, parent, *args, **kwargs)
+ #@TODO: hide sill nugget value widgets
def FitVariogram(self, formula, data):
return robjects.r.autofitVariogram(formula, data)
- def DoKriging():
- #BUG: automap autoKrige() does not seem to handle projected data.
- #current workaround would be create projected grid with estimation locations..
- pass
+ def DoKriging(self, formula, data, grid, **kwargs):
+ KrigingResult = robjects.r.autoKrige(formula, data, grid)
+ return KrigingResult.r['krige_output']
def HideOptions(self, event):
#for n in self.ParametersSizer.GetChildren(): n.Enable(False)
- if self.VariogramCheckBox.IsChecked():
- for n in self.ParametersSizer.GetChildren(): n.Show(False)
+ if not self.VariogramCheckBox.IsChecked():
+ for n in self.ParametersSizer.GetChildren():
+ print n
+ if not n.IsSizer(): n.Enable(False) #n.Show(False)
else:
for n in self.ParametersSizer.GetChildren(): n.Show(True)
#@TODO(anne): set it right. It costs too much code and hides options instead of disabling them
