[GRASS-SVN] r38118 - in grass/trunk: include lib/raster raster/r.colors
Mon Jun 29 15:19:09 EDT 2009
Author: martinl
Date: 2009-06-29 15:19:06 -0400 (Mon, 29 Jun 2009)
New Revision: 38118
   grass/trunk/include/raster.h
   grass/trunk/lib/raster/color_xform.c
   grass/trunk/raster/r.colors/main.c
rasterlib: fns from color_xform.c renamed, see
http://trac.osgeo.org/grass/wiki/Grass7/RasterLib
Modified: grass/trunk/include/raster.h
--- grass/trunk/include/raster.h	2009-06-29 19:00:14 UTC (rev 38117)
+++ grass/trunk/include/raster.h	2009-06-29 19:19:06 UTC (rev 38118)
@@ -237,7 +237,7 @@
 /* color_xform.c */
 void Rast_histogram_eq_colors(struct Colors *, struct Colors *,
 			   struct Cell_stats *);
-void Rast_histogram_eq_colors_fp(struct Colors *,
+void Rast_histogram_eq_fp_colors(struct Colors *,
 			      struct Colors *, struct FP_stats *);
 void Rast_log_colors(struct Colors *, struct Colors *, int);
 void Rast_abs_log_colors(struct Colors *, struct Colors *, int);
Modified: grass/trunk/lib/raster/color_xform.c
--- grass/trunk/lib/raster/color_xform.c	2009-06-29 19:00:14 UTC (rev 38117)
+++ grass/trunk/lib/raster/color_xform.c	2009-06-29 19:19:06 UTC (rev 38118)
@@ -1,66 +1,34 @@
+ * \file raster/color_xform.c
- * MODULE:       gis library
- * AUTHOR(S):    Glynn Clements <glynn at gclements.plus.com>
- * COPYRIGHT:    (C) 2007 Glynn Clements
+ * \brief Raster Library - Colors management
- *  This program is free software; you can redistribute it and/or modify
- *  it under the terms of the GNU General Public License as published by
- *  the Free Software Foundation; either version 2 of the License, or
- *  (at your option) any later version.
+ * (C) 2001-2009 by the GRASS Development Team
- *  This program is distributed in the hope that it will be useful,
- *  but WITHOUT ANY WARRANTY; without even the implied warranty of
- *  MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.  See the
- *  GNU General Public License for more details.
+ * This program is free software under the GNU General Public License
+ * (>=v2). Read the file COPYING that comes with GRASS for details.
+ * \author Original author CERL
- *  Rast_histogram_eq_colors (dst, src, statf)
- *   struct Colors *dst         struct to hold new colors
- *   struct Colors *src         struct containing original colors
- *   struct Cell_stats *statf   cell stats info
- *  Generates histogram equalized version of an existing color table from
- *  cell stats structure info.
- *  Rast_log_colors (dst, src, samples)
- *   int samples                number of samples
- *  Generates logarithmically-scaled version of an existing color table.
 #include <math.h>
 #include <grass/gis.h>
 #include <grass/raster.h>
- * \brief make histogram-stretched version of existing color table
+ * \brief Make histogram-stretched version of existing color table
- * Generates a histogram
- * contrast-stretched color table that goes from the histogram
- * information in the Cell_stats structure <b>statf.</b>  (See
- * Raster_Histograms).
+ * Generates a histogram contrast-stretched color table that goes from
+ * the histogram information in the Cell_stats structure <i>statf</i>.
+ * (See \ref Raster_Histograms).
- *  \param dst
- *  \param src
- *  \param statf
- *  \return
+ * \param[out] dst struct to hold new colors
+ * \param src struct containing original colors
+ * \param statf cell stats info
 void Rast_histogram_eq_colors(struct Colors *dst,
-			   struct Colors *src, struct Cell_stats *statf)
+			      struct Colors *src, struct Cell_stats *statf)
     DCELL min, max;
     int red, grn, blu;
@@ -117,21 +85,18 @@
- * \brief make histogram-stretched version of existing color table (FP version)
+ * \brief Make histogram-stretched version of existing color table (FP version)
- * information in the FP_stats structure <b>statf.</b>  (See
+ * the histogram information in the FP_stats structure <b>statf.</b>
- *  \param dst
- *  \param src
- *  \param statf
- *  \return void
-void Rast_histogram_eq_colors_fp(struct Colors *dst,
-			      struct Colors *src, struct FP_stats *statf)
+void Rast_histogram_eq_fp_colors(struct Colors *dst,
+				 struct Colors *src, struct FP_stats *statf)
     DCELL min, max;
     int red, grn, blu;
@@ -187,12 +152,11 @@
- * \brief make logarithmically-scaled version of an existing color table
+ * \brief Make logarithmically-scaled version of an existing color table
- *  \param dst
- *  \param src
- *  \param samples
- *  \return
+ * \param samples number of samples
 void Rast_log_colors(struct Colors *dst, struct Colors *src, int samples)
@@ -247,14 +211,13 @@
- * \brief make logarithmically-scaled version of an existing color table, allowing for signed values
+ * table, allowing for signed values
- *  \param dst
- *  \param src
- *  \param samples
- *  \return
 void Rast_abs_log_colors(struct Colors *dst, struct Colors *src, int samples)
     DCELL min, max;
@@ -316,4 +279,3 @@
 	blu = blu2;
Modified: grass/trunk/raster/r.colors/main.c
--- grass/trunk/raster/r.colors/main.c	2009-06-29 19:00:14 UTC (rev 38117)
+++ grass/trunk/raster/r.colors/main.c	2009-06-29 19:19:06 UTC (rev 38118)
@@ -355,7 +355,7 @@
 	if (fp) {
 	    struct FP_stats fpstats;
 	    get_fp_stats(name, mapset, &fpstats, min, max, flag.g->answer, flag.a->answer);
-	    Rast_histogram_eq_colors_fp(&colors_tmp, &colors, &fpstats);
+	    Rast_histogram_eq_fp_colors(&colors_tmp, &colors, &fpstats);
 	else {
 	    if (!have_stats)
