[GRASS-SVN] r38123 - grass-addons/vector/v.krige
svn_grass at osgeo.org
Tue Jun 30 11:03:23 EDT 2009
Author: aghisla
Date: 2009-06-30 11:03:23 -0400 (Tue, 30 Jun 2009)
New Revision: 38123
grass-addons/vector/v.krige/v.krige.py
small interface improvements
Modified: grass-addons/vector/v.krige/v.krige.py
--- grass-addons/vector/v.krige/v.krige.py 2009-06-29 21:28:21 UTC (rev 38122)
+++ grass-addons/vector/v.krige/v.krige.py 2009-06-30 15:03:23 UTC (rev 38123)
@@ -97,7 +97,6 @@
for Rpackage in ["automap", "gstat", "geoR"]:
self.CreatePage(package = Rpackage)
#@TODO(anne): check this dependency at the beginning.
if self.RPackagesBook.GetPageCount() == 0:
wx.MessageBox(parent=self,
@@ -114,7 +113,7 @@
OutputParameters.AddGrowableCol(1)
OutputParameters.Add(item = wx.StaticText(self, id=wx.ID_ANY, label=_("Name of the output map:")),
flag = wx.ALIGN_CENTER_VERTICAL)
- self.OutputMapName = wx.TextCtrl(self, id=wx.ID_ANY)
+ self.OutputMapName = wx.TextCtrl(self, id=wx.ID_ANY, size=(250,-1))
OutputParameters.Add(item=self.OutputMapName, flag=wx.EXPAND | wx.ALL)
self.OverwriteCheckBox = wx.CheckBox(self, id=wx.ID_ANY, label=_("Allow output files to overwrite existing files"))
self.OverwriteCheckBox.SetValue(state = False)
@@ -149,13 +148,12 @@
pass
def OnInputDataChanged(self, event):
- """Refreshes list of columns
- @todo: layer select
- self.InputDataColumn.InsertColumns(vector = event.GetString(),
+ """ Refreshes list of columns and fills output map name TextCtrl """
+ MapName = event.GetString()
+ self.InputDataColumn.InsertColumns(vector = MapName,
layer = 1, excludeKey = True,
type = ['integer', 'double precision'])
+ self.OutputMapName.SetValue(MapName.split("@")[0]+"_kriging")
def OnRunButton(self,event):
""" Execute R analysis. """
@@ -192,13 +190,13 @@
#4. Kriging
self.parent.log.write('Kriging...')
KrigingResult = SelectedPanel.DoKriging(formula = Formula, data = InputData, grid = GridPredicted, model = Variogram)
- self.parent.log.write('Kriging performed..')
+ self.parent.log.write('Kriging performed.')
#5. Format output
- print self.OutputMapName.GetValue()
+ #@IDEA: set a generic f(x) for this too? seems like, because zcol= is only the first peculiar arg for gstat.
robjects.r.writeRAST6(KrigingResult, vname = self.OutputMapName.GetValue(), zcol='var1.pred',
overwrite = self.OverwriteCheckBox.GetValue())
- self.parent.log.write('Wow! Succeeded! Ready for another run.')
+ self.parent.log.write('Yippee! Succeeded! Ready for another run.')
def OnCloseWindow(self, event):
""" Cancel button pressed"""
@@ -240,16 +238,13 @@
label=_("Variogram fitting")), wx.VERTICAL)
self.VariogramCheckBox = wx.CheckBox(self, id=wx.ID_ANY, label=_("Auto-fit variogram"))
self.VariogramCheckBox.SetValue(state = True) # check it by default
- self.ParametersSizer = wx.FlexGridSizer(cols=3, hgap=5, vgap=5)
+ self.ParametersSizer = wx.FlexGridSizer(cols=2, hgap=5, vgap=5)
for n in ["Sill", "Nugget", "Range"]:
- setattr(self, n+"Sizer", (wx.BoxSizer(wx.HORIZONTAL)))
setattr(self, n+"Text", (wx.StaticText(self, id= wx.ID_ANY, label = _(n))))
setattr(self, n+"Ctrl", (wx.SpinCtrl(self, id = wx.ID_ANY, max=sys.maxint)))
- a = getattr(self, n+"Sizer")
- a.Add(getattr(self, n+"Text"), proportion=0, flag=wx.ALIGN_LEFT | wx.ALIGN_CENTER | wx.ALL, border=3)
- a.Add(getattr(self, n+"Ctrl"), proportion=0, flag=wx.ALIGN_RIGHT | wx.ALL, border=3)
- self.ParametersSizer.Add(a)#, proportion = 0, flag=wx.EXPAND | wx.ALL, border=3)
+ self.ParametersSizer.Add(getattr(self, n+"Text"))
+ self.ParametersSizer.Add(getattr(self, n+"Ctrl"))
VariogramSizer.Add(self.VariogramCheckBox, proportion=1, flag=wx.EXPAND | wx.ALL, border=3)
VariogramSizer.Add(self.ParametersSizer, proportion=0, flag=wx.EXPAND | wx.ALL, border=3)
