[GRASS-SVN] r36153 - grass-addons/misc/m.eigensystem
Sun Mar 1 04:19:34 EST 2009
Author: hamish
Date: 2009-03-01 04:19:34 -0500 (Sun, 01 Mar 2009)
New Revision: 36153
   grass-addons/misc/m.eigensystem/m.eigensystem.html
   grass-addons/misc/m.eigensystem/main.f
update comments and help page
Modified: grass-addons/misc/m.eigensystem/m.eigensystem.html
--- grass-addons/misc/m.eigensystem/m.eigensystem.html	2009-03-01 08:42:18 UTC (rev 36152)
+++ grass-addons/misc/m.eigensystem/m.eigensystem.html	2009-03-01 09:19:34 UTC (rev 36153)
@@ -33,7 +33,10 @@
 which is the number of rows and columns in the matrix;
 the remainder of the file is the matrix, i.e.,
 K lines, each containing K real numbers.
-For example:
+For example:<BR>
+<I>(Examples in this help page use the Spearfish-imagery sample dataset
+maps spot.ms.1, spot.ms.2, and spot.ms.3)</I>
 <P>
 <PRE>
           3
@@ -73,7 +76,7 @@
 <P>
-For the example input matrix, the output would be:
+For the example input matrix above, the output would be:
 <PRE>
           E  1159.7452017844    0.0000000000   88.38
           V     0.6910021591    0.0000000000
@@ -129,6 +132,7 @@
 matrix of any data set is symmetric
 and thus has only real eigen values and vectors.
 <H2>PRINCIPLE COMPONENTS</H2>
 To perform principle component transformation on GRASS data layers,
@@ -141,12 +145,12 @@
 to form the desired components.
 For example, to get the eigen vectors for 3 layers:
-<PRE>
-<B>(echo 3; r.covar map.1,map.2,map.3) | m.eigensystem</B>
-</PRE>
+<div class="code"><PRE>
+   <B>(echo 3; r.covar map.1,map.2,map.3) | m.eigensystem</B>
+</PRE></div>
-Note that since m.covar only outputs the matrix, we must manually prepend the matrix
-size (3) using the echo command.
+Note that since m.covar only outputs the matrix, we must manually prepend
+the matrix size (3) using the echo command.
 <P>
@@ -154,27 +158,41 @@
 Then, using the W vector, new maps are created:
-<PRE>
-<B>r.mapcalc</B> 'pc.1 = 21.2395*map.1 + 22.1470*map.2 + 14.7696*map.3'
-<B>r.mapcalc</B> 'pc.2 =  2.9083*map.1 +  4.4599*map.2  - 10.8699*map.3'
-<B>r.mapcalc</B> 'pc.3 =  1.8175*map.1  -  1.6232*map.2 \-  0.1797*map.3'
-</PRE>
+   <B>r.mapcalc</B> 'pc.1 = 21.2395*map.1 + 22.1470*map.2 + 14.7696*map.3'
+   <B>r.mapcalc</B> 'pc.2 =  2.9083*map.1 +  4.4599*map.2  - 10.8699*map.3'
+   <B>r.mapcalc</B> 'pc.3 =  1.8175*map.1  -  1.6232*map.2 -  0.1797*map.3'
+</PRE></div>
 <H2>NOTES</H2>
 The source code for this program requires a Fortran compiler.
+<P>
+The equivalent <em>i.pca</em> command is:
+   i.pca in=spot.ms.1,spot.ms.2,spot.ms.3 out=spot_pca
+</PRE></div>
 <H2>SEE ALSO</H2>
-<EM><A HREF="r.covar.html">r.covar</A></EM><br>
-<EM><A HREF="r.mapcalc.html">r.mapcalc</A></EM><br>
-<EM><A HREF="r.rescale.html">r.rescale</A></EM>
+<EM>
+<A HREF="i.pca.html">i.pca</A><br>
+<A HREF="r.covar.html">r.covar</A><br>
+<A HREF="r.mapcalc.html">r.mapcalc</A><br>
+<A HREF="r.rescale.html">r.rescale</A>
+</EM>
 <H2>AUTHOR</H2>
-This code uses routines from the EISPACK system.  The interface was coded by
-Michael Shapiro, U.S.Army Construction Engineering
-Research Laboratory
-<p><i>Last changed: $Date: 2002/01/25 05:45:33 $</i>
+This code uses routines from the EISPACK system.<BR>
+The interface was coded by Michael Shapiro, U.S.Army Construction Engineering
+ Research Laboratory
+<p>
+<i>Last changed: $Date: 2002/01/25 05:45:33 $</i>
 </body>
 </html>
Modified: grass-addons/misc/m.eigensystem/main.f
--- grass-addons/misc/m.eigensystem/main.f	2009-03-01 08:42:18 UTC (rev 36152)
+++ grass-addons/misc/m.eigensystem/main.f	2009-03-01 09:19:34 UTC (rev 36153)
@@ -24,16 +24,20 @@
 C
 C Currently, the max value for N is 30
 C
-C The output is N sets of values. One E line and N V lines
+C The output is N sets of values. One E line and N V W lines
 C
 C  E   real  imaginary   percent-importance
 C  V   real  imaginary
 C  N   real  imaginary
+C  W   real  imaginary
 C      ...
 C
 C where E is the eigen value (and it relative importance)
 C and   V are the eigenvector for this eigenvalue.
 C       N are the normalized eigenvector for this eigenvalue.
+C       W are the N vector multiplied by the square root of the magnitude
+C         of the eigen value (E).
 C
        DOUBLE PRECISION A(30,30),W1,W2,WR(30),WI(30),Z(30,30),FV1(30)
        DOUBLE PRECISION SUM1,SUM2
