[GRASS-SVN] r36163 - grass/branches/develbranch_6/imagery/i.pca
svn_grass at osgeo.org
Sun Mar 1 09:52:06 EST 2009
Author: hamish
Date: 2009-03-01 09:52:06 -0500 (Sun, 01 Mar 2009)
New Revision: 36163
grass/branches/develbranch_6/imagery/i.pca/description.html
grass/branches/develbranch_6/imagery/i.pca/main.c
better opt descriptions
Modified: grass/branches/develbranch_6/imagery/i.pca/description.html
--- grass/branches/develbranch_6/imagery/i.pca/description.html 2009-03-01 12:31:15 UTC (rev 36162)
+++ grass/branches/develbranch_6/imagery/i.pca/description.html 2009-03-01 14:52:06 UTC (rev 36163)
@@ -8,7 +8,7 @@
the input data in decreasing order of variance
("contrast"). The output raster map layers are assigned
names with .1, .2, ... .n suffixes. The current geographic
-region definition and mask settings are respected when
+region definition and MASK settings are respected when
reading the input raster map layers. When the rescale
option is used, the output files are rescaled to fit the
min,max range.
@@ -16,36 +16,35 @@
<H2>OPTIONS</H2>
<H3>Parameters:</H3>
<DL>
<DT><B>input=</B><EM>name,name</EM>[<EM>,name,name</EM>,...]
<DD>Name of two or more input raster map layers.
<DT><B>output=</B><EM>name</EM>
<DD>The output raster map layer name to which suffixes are
added. Each output raster map layer is assigned this
user-specified <EM>name</EM> with a numerical (.1, .2, ...
.n) suffix.
<DT><B>rescale=</B><EM>min,max</EM>
<DD>The optional output category range. (Default: 0,255) If
rescale=0,0, no rescaling is performed on output files.
<DD>If output is rescaled, the output raster will be of type CELL. If
the output is not rescaled, the output raster will be of type DCELL.
</DL>
<H2>NOTES</H2>
Richards (1986) gives a good example of the application of principal
components analysis (pca) to a time series of LANDSAT images of a burned
region in Australia.
+<P>
+Eigenvalue and eigenvector information is stored in the output maps'
+history files. View with <em>r.info</em>.
<H2>SEE ALSO</H2>
Richards, John A.,
@@ -61,14 +60,17 @@
<P>
-<EM><A HREF="i.cca.html">i.cca</A></EM><br>
-<EM><A HREF="i.class.html">i.class</A></EM><br>
-<EM><A HREF="i.fft.html">i.fft</A></EM><br>
-<EM><A HREF="i.ifft.html">i.ifft</A></EM><br>
-<EM><A HREF="m.eigensystem.html">m.eigensystem</A></EM><br>
-<EM><A HREF="r.covar.html">r.covar</A></EM><br>
-<EM><A HREF="r.mapcalc.html">r.mapcalc</A></EM>
+<EM>
+<A HREF="i.cca.html">i.cca</A><br>
+<A HREF="i.class.html">i.class</A><br>
+<A HREF="i.fft.html">i.fft</A><br>
+<A HREF="i.ifft.html">i.ifft</A><br>
+<A HREF="m.eigensystem.html">m.eigensystem</A><br>
+<A HREF="r.covar.html">r.covar</A><br>
+<A HREF="r.mapcalc.html">r.mapcalc</A>
+</EM>
<H2>AUTHOR</H2>
David Satnik, GIS Laboratory
@@ -82,4 +84,5 @@
Rewritten for GRASS 6.x and major modifications by <br>
Brad Douglas
-<p><i>Last changed: $Date$</i>
+<p>
+<i>Last changed: $Date$</i>
Modified: grass/branches/develbranch_6/imagery/i.pca/main.c
--- grass/branches/develbranch_6/imagery/i.pca/main.c 2009-03-01 12:31:15 UTC (rev 36162)
+++ grass/branches/develbranch_6/imagery/i.pca/main.c 2009-03-01 14:52:06 UTC (rev 36163)
@@ -66,7 +66,12 @@
/* Define options */
opt_in = G_define_standard_option(G_OPT_R_INPUTS);
+ opt_in->description = _("Name of two or more input raster maps");
opt_out = G_define_standard_option(G_OPT_R_OUTPUT);
+ opt_out->label = _("Base name for output raster maps");
+ opt_out->description =
+ _("A numerical suffix will be added for each component map");
opt_scale = G_define_option();
opt_scale->key = "rescale";
@@ -75,7 +80,7 @@
opt_scale->required = NO;
opt_scale->answer = "0,255";
opt_scale->description =
- _("Rescaling range output (For no rescaling use 0,0)");
+ _("Rescaling range for output maps (for no rescaling use 0,0)");
if (G_parser(argc, argv))
exit(EXIT_FAILURE);
