[GRASS-SVN] r36221 - in grass/branches/releasebranch_6_4/gui/wxpython: nviz vdigit
Fri Mar 6 18:14:47 EST 2009
Author: martinl
Date: 2009-03-06 18:14:47 -0500 (Fri, 06 Mar 2009)
New Revision: 36221
Added:
   grass/branches/releasebranch_6_4/gui/wxpython/nviz/setup.py
   grass/branches/releasebranch_6_4/gui/wxpython/vdigit/setup.py
   grass/branches/releasebranch_6_4/gui/wxpython/nviz/nviz.h
   grass/branches/releasebranch_6_4/gui/wxpython/vdigit/digit.cpp
   grass/branches/releasebranch_6_4/gui/wxpython/vdigit/driver.h
   grass/branches/releasebranch_6_4/gui/wxpython/vdigit/driver_draw.cpp
   grass/branches/releasebranch_6_4/gui/wxpython/vdigit/message.cpp
wxGUI osgeo4w patch applied (by jef)
     http://trac.osgeo.org/grass/ticket/519
     (merge from devbr6, r36220)
Modified: grass/branches/releasebranch_6_4/gui/wxpython/nviz/nviz.h
--- grass/branches/releasebranch_6_4/gui/wxpython/nviz/nviz.h	2009-03-06 22:53:41 UTC (rev 36220)
+++ grass/branches/releasebranch_6_4/gui/wxpython/nviz/nviz.h	2009-03-06 23:14:47 UTC (rev 36221)
@@ -1,6 +1,9 @@
 #ifndef WXNVIZ_H
 #define WXNVIZ_H
+// For compilers that support precompilation, includes "wx.h".
+#include <wx/wxprec.h>
 #include <vector>
 extern "C" {
@@ -10,8 +13,6 @@
 #include <grass/gstypes.h>
-// For compilers that support precompilation, includes "wx.h".
-#include <wx/wxprec.h>
 #ifdef __BORLANDC__
 #pragma hdrstop
Copied: grass/branches/releasebranch_6_4/gui/wxpython/nviz/setup.py (from rev 36220, grass/branches/develbranch_6/gui/wxpython/nviz/setup.py)
--- grass/branches/releasebranch_6_4/gui/wxpython/nviz/setup.py	                        (rev 0)
+++ grass/branches/releasebranch_6_4/gui/wxpython/nviz/setup.py	2009-03-06 23:14:47 UTC (rev 36221)
@@ -0,0 +1,24 @@
+# currently used only for osgeo4w
+# TODO: use instead of Makefile
+from distutils.core import setup, Extension
+setup(
+	ext_modules= [
+		Extension(
+			'_grass6_wxnviz',
+			sources=[
+				"grass6_wxnviz.i",
+				"change_view.cpp",
+				"draw.cpp",
+				"init.cpp",
+				"lights.cpp",
+				"load.cpp",
+				"surface.cpp",
+				"vector.cpp",
+				"volume.cpp",
+			swig_opts=['-c++','-shadow'],
+			libraries=['grass_gis','grass_nviz','grass_ogsf','grass_g3d']
Modified: grass/branches/releasebranch_6_4/gui/wxpython/vdigit/digit.cpp
--- grass/branches/releasebranch_6_4/gui/wxpython/vdigit/digit.cpp	2009-03-06 22:53:41 UTC (rev 36220)
+++ grass/branches/releasebranch_6_4/gui/wxpython/vdigit/digit.cpp	2009-03-06 23:14:47 UTC (rev 36221)
@@ -15,6 +15,12 @@
 #include "driver.h"
 #include "digit.h"
+#ifdef _WIN32
+#ifndef _CPPRTTI
+#error "compile with /GR!"
+#endif
+#endif
    \brief Initialize digit interface used by SWIG
Modified: grass/branches/releasebranch_6_4/gui/wxpython/vdigit/driver.h
--- grass/branches/releasebranch_6_4/gui/wxpython/vdigit/driver.h	2009-03-06 22:53:41 UTC (rev 36220)
+++ grass/branches/releasebranch_6_4/gui/wxpython/vdigit/driver.h	2009-03-06 23:14:47 UTC (rev 36221)
@@ -24,6 +24,7 @@
 #include <Python.h>
 #include "pseudodc.h"
+#include <wx/gdicmn.h>
 extern "C" {
 #include <grass/gis.h>
Modified: grass/branches/releasebranch_6_4/gui/wxpython/vdigit/driver_draw.cpp
--- grass/branches/releasebranch_6_4/gui/wxpython/vdigit/driver_draw.cpp	2009-03-06 22:53:41 UTC (rev 36220)
+++ grass/branches/releasebranch_6_4/gui/wxpython/vdigit/driver_draw.cpp	2009-03-06 23:14:47 UTC (rev 36221)
@@ -19,6 +19,7 @@
 #include "driver.h"
    \brief Draw content of the vector map to device
@@ -193,7 +194,7 @@
     double x, y, z;
     // convert EN -> xy
-    wxPoint wxPoints[points->n_points];
+    wxPoint *wxPoints = new wxPoint[points->n_points];
     for (int i = 0; i < points->n_points; i++) {
 	Cell2Pixel(points->x[i], points->y[i], points->z[i],
@@ -204,6 +205,8 @@
     // draw polygon
     dc->DrawPolygon(points->n_points, wxPoints);
+    delete [] wxPoints;
     return 1;
@@ -352,7 +355,7 @@
 	    else {
-		wxPoint wxPoints[pointsScreen->GetCount()];
+		wxPoint *wxPoints = new wxPoint[pointsScreen->GetCount()];
 		for (size_t i = 0; i < pointsScreen->GetCount(); i++) {
 		    wxPoint *point_beg = (wxPoint *) pointsScreen->Item(i)->GetData();
 		    wxPoints[i] = *point_beg;
@@ -360,6 +363,8 @@
 		pdc->DrawLines(pointsScreen->GetCount(), wxPoints);
 		if (!IsSelected(line) && settings.direction.enabled) {
 		    DrawDirectionArrow();
 		    // restore pen
@@ -679,13 +684,13 @@
     double angle_symb;
     angle_symb = angle - M_PI / 2.;
-    x = x1 + size * std::cos(angle_symb);
-    y = y1 - size * std::sin(angle_symb);
+    x = x1 + size * cos(angle_symb);
+    y = y1 - size * sin(angle_symb);
     dc->DrawLine((wxCoord) x, (wxCoord) y, (wxCoord) x0, (wxCoord) y0);
     angle_symb = M_PI / 2. + angle;
     dc->DrawLine((wxCoord) x0, (wxCoord) y0, (wxCoord) x, (wxCoord) y);
     return 1;
Modified: grass/branches/releasebranch_6_4/gui/wxpython/vdigit/message.cpp
--- grass/branches/releasebranch_6_4/gui/wxpython/vdigit/message.cpp	2009-03-06 22:53:41 UTC (rev 36220)
+++ grass/branches/releasebranch_6_4/gui/wxpython/vdigit/message.cpp	2009-03-06 23:14:47 UTC (rev 36221)
@@ -91,8 +91,7 @@
 void DisplayDriver::BackgroundMapMsg(const char *bgmap)
     wxString msg;
-    msg.Printf(_("Unable to open background vector map <%s>. "
-		 "Please check digitizer settings."),
+    msg.Printf(_("Unable to open background vector map <%s>. Please check digitizer settings."),
 	       wxString (bgmap, wxConvUTF8).c_str());
     wxMessageDialog dlg(parentWin, msg,
 			msgCaption, wxOK | wxICON_ERROR | wxCENTRE);
Copied: grass/branches/releasebranch_6_4/gui/wxpython/vdigit/setup.py (from rev 36220, grass/branches/develbranch_6/gui/wxpython/vdigit/setup.py)
--- grass/branches/releasebranch_6_4/gui/wxpython/vdigit/setup.py	                        (rev 0)
+++ grass/branches/releasebranch_6_4/gui/wxpython/vdigit/setup.py	2009-03-06 23:14:47 UTC (rev 36221)
@@ -0,0 +1,27 @@
+setup(
+	ext_modules= [
+		Extension(
+			'_grass6_wxvdigit',
+			sources=[
+				"grass6_wxvdigit.i",
+				"cats.cpp",
+				"driver.cpp",
+				"driver_draw.cpp",
+				"driver_select.cpp",
+				"line.cpp",
+				"message.cpp",
+				"select.cpp",
+				"undo.cpp",
+				"vertex.cpp",
+				"pseudodc.cpp",
+				"digit.cpp"
+			libraries=['grass_dbmibase', 'grass_dbmiclient', 'grass_vect','grass_gis','grass_vedit','gdal_i', 'wxbase28u', 'wxmsw28u_core']
