[GRASS-SVN] r36223 -
grass/branches/releasebranch_6_4/lib/vector/vedit
svn_grass at osgeo.org
Fri Mar 6 19:01:37 EST 2009
Author: martinl
Date: 2009-03-06 19:01:37 -0500 (Fri, 06 Mar 2009)
New Revision: 36223
grass/branches/releasebranch_6_4/lib/vector/vedit/select.c
grass/branches/releasebranch_6_4/lib/vector/vedit/snap.c
veditlib: osgeo4w patch applied (by jef) - trac #519
(merge from devbr6, r36222)
Modified: grass/branches/releasebranch_6_4/lib/vector/vedit/select.c
--- grass/branches/releasebranch_6_4/lib/vector/vedit/select.c 2009-03-06 23:51:15 UTC (rev 36222)
+++ grass/branches/releasebranch_6_4/lib/vector/vedit/select.c 2009-03-07 00:01:37 UTC (rev 36223)
@@ -138,6 +138,12 @@
int ltype;
double length;
+ int i, cat_curr;
+ int node1, node2, node; /* nodes */
+ int nnode1, nnode2; /* number of line in node */
+ double nx, ny, nz; /* node coordinates */
+ struct ilist *exclude, *found; /* line id of nearest lines */
+ struct line_cats *Cats_curr;
if (!Vect_line_alive(Map, line))
return -1;
@@ -171,13 +177,6 @@
return -1;
/* check if line is dangle */
- int i, cat_curr;
- int node1, node2, node; /* nodes */
- int nnode1, nnode2; /* number of line in node */
- double nx, ny, nz; /* node coordinates */
- struct ilist *exclude, *found; /* line id of nearest lines */
- struct line_cats *Cats_curr;
Vect_get_line_nodes(Map, line, &node1, &node2);
node = -1;
Modified: grass/branches/releasebranch_6_4/lib/vector/vedit/snap.c
--- grass/branches/releasebranch_6_4/lib/vector/vedit/snap.c 2009-03-06 23:51:15 UTC (rev 36222)
+++ grass/branches/releasebranch_6_4/lib/vector/vedit/snap.c 2009-03-07 00:01:37 UTC (rev 36223)
@@ -180,7 +180,7 @@
int to_vertex)
int i, line, type;
- int nlines_modified;
+ int nlines_modified = 0;
struct line_pnts *Points;
struct line_cats *Cats;
