[GRASS-SVN] r36241 - in grass/branches/develbranch_6: locale/po
vector/v.surf.rst
svn_grass at osgeo.org
Sun Mar 8 01:13:46 EST 2009
Author: neteler
Date: 2009-03-08 01:13:40 -0500 (Sun, 08 Mar 2009)
New Revision: 36241
grass/branches/develbranch_6/locale/po/grassmods_ar.po
grass/branches/develbranch_6/locale/po/grassmods_cs.po
grass/branches/develbranch_6/locale/po/grassmods_de.po
grass/branches/develbranch_6/locale/po/grassmods_el.po
grass/branches/develbranch_6/locale/po/grassmods_es.po
grass/branches/develbranch_6/locale/po/grassmods_fr.po
grass/branches/develbranch_6/locale/po/grassmods_hi.po
grass/branches/develbranch_6/locale/po/grassmods_it.po
grass/branches/develbranch_6/locale/po/grassmods_ja.po
grass/branches/develbranch_6/locale/po/grassmods_ko.po
grass/branches/develbranch_6/locale/po/grassmods_lv.po
grass/branches/develbranch_6/locale/po/grassmods_mr.po
grass/branches/develbranch_6/locale/po/grassmods_pl.po
grass/branches/develbranch_6/locale/po/grassmods_pt.po
grass/branches/develbranch_6/locale/po/grassmods_pt_br.po
grass/branches/develbranch_6/locale/po/grassmods_ru.po
grass/branches/develbranch_6/locale/po/grassmods_sl.po
grass/branches/develbranch_6/locale/po/grassmods_th.po
grass/branches/develbranch_6/locale/po/grassmods_tr.po
grass/branches/develbranch_6/locale/po/grassmods_vi.po
grass/branches/develbranch_6/locale/po/grassmods_zh.po
grass/branches/develbranch_6/vector/v.surf.rst/main.c
msg cosmetics
Modified: grass/branches/develbranch_6/locale/po/grassmods_ar.po
--- grass/branches/develbranch_6/locale/po/grassmods_ar.po 2009-03-08 05:41:52 UTC (rev 36240)
+++ grass/branches/develbranch_6/locale/po/grassmods_ar.po 2009-03-08 06:13:40 UTC (rev 36241)
@@ -16566,7 +16566,7 @@
msgstr "اÙÙ
خرج Ù٠خطأ Ø§ÙØ¥Ø³ØªÙÙØ§Ø¡"
#: ../vector/lidar/v.surf.bspline/main.c:145 ../vector/v.surf.rst/main.c:206
-msgid "Field value. If set to 0, z coordinates are used. (3D vector only)"
+msgid "If set to 0, z coordinates are used. (3D vector only)"
msgstr ""
#: ../vector/lidar/v.surf.bspline/main.c:155
Modified: grass/branches/develbranch_6/locale/po/grassmods_cs.po
--- grass/branches/develbranch_6/locale/po/grassmods_cs.po 2009-03-08 05:41:52 UTC (rev 36240)
+++ grass/branches/develbranch_6/locale/po/grassmods_cs.po 2009-03-08 06:13:40 UTC (rev 36241)
@@ -23665,7 +23665,7 @@
msgstr "Pou¾ij napìtí závislé na mìøítku"
#: ../vector/v.surf.rst/main.c:206 ../vector/lidar/v.surf.bspline/main.c:147
msgstr ""
"Èíslo vrstvy. Pokud nastaveno na 0, jsou pou¾ity souøadnice z (pouze u 3D "
"vektorù)"
Modified: grass/branches/develbranch_6/locale/po/grassmods_de.po
--- grass/branches/develbranch_6/locale/po/grassmods_de.po 2009-03-08 05:41:52 UTC (rev 36240)
+++ grass/branches/develbranch_6/locale/po/grassmods_de.po 2009-03-08 06:13:40 UTC (rev 36241)
@@ -16242,8 +16242,8 @@
msgstr "Name der Karte, die Interpolationsfehler enthält."
-msgstr "Feldwert. Wenn 0, dann wird die Z-Koordinate genutzt (nur bei 3D-Vektoren)."
+msgstr "Wenn 0, dann wird die Z-Koordinate genutzt (nur bei 3D-Vektoren)."
msgid "Attribute table column with values to interpolate (if layer>0)"
Modified: grass/branches/develbranch_6/locale/po/grassmods_el.po
--- grass/branches/develbranch_6/locale/po/grassmods_el.po 2009-03-08 05:41:52 UTC (rev 36240)
+++ grass/branches/develbranch_6/locale/po/grassmods_el.po 2009-03-08 06:13:40 UTC (rev 36241)
@@ -16419,7 +16419,7 @@
msgstr ""
Modified: grass/branches/develbranch_6/locale/po/grassmods_es.po
--- grass/branches/develbranch_6/locale/po/grassmods_es.po 2009-03-08 05:41:52 UTC (rev 36240)
+++ grass/branches/develbranch_6/locale/po/grassmods_es.po 2009-03-08 06:13:40 UTC (rev 36241)
@@ -16881,7 +16881,7 @@
msgstr "Tipo spline de interpolación"
#: ../vector/lidar/v.surf.bspline/main.c:147 ../vector/v.surf.rst/main.c:206
msgstr ""
"Valor de campo. Si se establece a 0, se usarán las coordenadas Z (sólo "
"vectoriales 3D)"
Modified: grass/branches/develbranch_6/locale/po/grassmods_fr.po
--- grass/branches/develbranch_6/locale/po/grassmods_fr.po 2009-03-08 05:41:52 UTC (rev 36240)
+++ grass/branches/develbranch_6/locale/po/grassmods_fr.po 2009-03-08 06:13:40 UTC (rev 36241)
@@ -17787,10 +17787,9 @@
msgstr "La valeur en sortie est l'erreur d'interpolation"
msgstr ""
-"Valeur du champ. Si fixée à 0, les coordonnées z sont utilisées (vecteur 3D "
-"seulement)"
+"Si fixée à 0, les coordonnées z sont utilisées (vecteur 3D seulement)"
Modified: grass/branches/develbranch_6/locale/po/grassmods_hi.po
--- grass/branches/develbranch_6/locale/po/grassmods_hi.po 2009-03-08 05:41:52 UTC (rev 36240)
+++ grass/branches/develbranch_6/locale/po/grassmods_hi.po 2009-03-08 06:13:40 UTC (rev 36241)
@@ -16936,7 +16936,7 @@
#, fuzzy
msgstr "फà¥à¤²à¥à¤¡ सà¥à¤ à¤à¤¼à¥à¤¡"
Modified: grass/branches/develbranch_6/locale/po/grassmods_it.po
--- grass/branches/develbranch_6/locale/po/grassmods_it.po 2009-03-08 05:41:52 UTC (rev 36240)
+++ grass/branches/develbranch_6/locale/po/grassmods_it.po 2009-03-08 06:13:40 UTC (rev 36241)
@@ -16545,7 +16545,7 @@
msgstr ""
msgstr ""
Modified: grass/branches/develbranch_6/locale/po/grassmods_ja.po
--- grass/branches/develbranch_6/locale/po/grassmods_ja.po 2009-03-08 05:41:52 UTC (rev 36240)
+++ grass/branches/develbranch_6/locale/po/grassmods_ja.po 2009-03-08 06:13:40 UTC (rev 36241)
@@ -16899,7 +16899,7 @@
#, fuzzy
msgstr "���"
Modified: grass/branches/develbranch_6/locale/po/grassmods_ko.po
--- grass/branches/develbranch_6/locale/po/grassmods_ko.po 2009-03-08 05:41:52 UTC (rev 36240)
+++ grass/branches/develbranch_6/locale/po/grassmods_ko.po 2009-03-08 06:13:40 UTC (rev 36241)
@@ -15817,7 +15817,7 @@
msgstr ""
msgstr ""
Modified: grass/branches/develbranch_6/locale/po/grassmods_lv.po
--- grass/branches/develbranch_6/locale/po/grassmods_lv.po 2009-03-08 05:41:52 UTC (rev 36240)
+++ grass/branches/develbranch_6/locale/po/grassmods_lv.po 2009-03-08 06:13:40 UTC (rev 36241)
@@ -16401,7 +16401,7 @@
msgstr ""
msgstr ""
Modified: grass/branches/develbranch_6/locale/po/grassmods_mr.po
--- grass/branches/develbranch_6/locale/po/grassmods_mr.po 2009-03-08 05:41:52 UTC (rev 36240)
+++ grass/branches/develbranch_6/locale/po/grassmods_mr.po 2009-03-08 06:13:40 UTC (rev 36241)
@@ -15954,7 +15954,7 @@
msgstr ""
msgstr ""
Modified: grass/branches/develbranch_6/locale/po/grassmods_pl.po
--- grass/branches/develbranch_6/locale/po/grassmods_pl.po 2009-03-08 05:41:52 UTC (rev 36240)
+++ grass/branches/develbranch_6/locale/po/grassmods_pl.po 2009-03-08 06:13:40 UTC (rev 36241)
@@ -16540,7 +16540,7 @@
msgstr "Wynik jest bÅÄdem interpolacji"
msgstr ""
Modified: grass/branches/develbranch_6/locale/po/grassmods_pt.po
--- grass/branches/develbranch_6/locale/po/grassmods_pt.po 2009-03-08 05:41:52 UTC (rev 36240)
+++ grass/branches/develbranch_6/locale/po/grassmods_pt.po 2009-03-08 06:13:40 UTC (rev 36241)
@@ -17270,10 +17270,9 @@
msgstr "Saída é o erro de interpolação"
msgstr ""
-"Valor do campo. Se definido em 0, coordenadas z serão usadas. (vetor 3D "
-"apenas)"
+"Se definido em 0, coordenadas z serão usadas. (vetor 3D apenas)"
Modified: grass/branches/develbranch_6/locale/po/grassmods_pt_br.po
--- grass/branches/develbranch_6/locale/po/grassmods_pt_br.po 2009-03-08 05:41:52 UTC (rev 36240)
+++ grass/branches/develbranch_6/locale/po/grassmods_pt_br.po 2009-03-08 06:13:40 UTC (rev 36241)
@@ -17273,10 +17273,9 @@
msgstr ""
-"apenas)"
Modified: grass/branches/develbranch_6/locale/po/grassmods_ru.po
--- grass/branches/develbranch_6/locale/po/grassmods_ru.po 2009-03-08 05:41:52 UTC (rev 36240)
+++ grass/branches/develbranch_6/locale/po/grassmods_ru.po 2009-03-08 06:13:40 UTC (rev 36241)
@@ -16549,10 +16549,9 @@
msgstr "Сплайн инÑеÑполÑÑиÑ"
msgstr ""
-"ÐнаÑение полÑ. ÐÑли ÑÑÑановлено в 0, иÑполÑзÑÑÑÑÑ ÐºÐ¾Ð¾ÑдинаÑÑ z (ÑолÑко 3D "
-"векÑоÑ)"
+"ÐÑли ÑÑÑановлено в 0, иÑполÑзÑÑÑÑÑ ÐºÐ¾Ð¾ÑдинаÑÑ z (ÑолÑко 3D векÑоÑ)"
Modified: grass/branches/develbranch_6/locale/po/grassmods_sl.po
--- grass/branches/develbranch_6/locale/po/grassmods_sl.po 2009-03-08 05:41:52 UTC (rev 36240)
+++ grass/branches/develbranch_6/locale/po/grassmods_sl.po 2009-03-08 06:13:40 UTC (rev 36241)
@@ -16828,7 +16828,7 @@
msgstr "Izhodni rastrski sloj naj vsebuje interpolacijske napake"
msgstr ""
Modified: grass/branches/develbranch_6/locale/po/grassmods_th.po
--- grass/branches/develbranch_6/locale/po/grassmods_th.po 2009-03-08 05:41:52 UTC (rev 36240)
+++ grass/branches/develbranch_6/locale/po/grassmods_th.po 2009-03-08 06:13:40 UTC (rev 36241)
@@ -16174,8 +16174,8 @@
msgstr "à¸à¸à¸´à¸ Spline à¸à¸à¸à¸à¸²à¸£ interpolation"
-msgstr "à¸à¹à¸² Field. à¸à¹à¸²à¸à¸³à¸«à¸à¸à¹à¸à¹à¸ 0, à¸à¸°à¹à¸à¹à¸à¹à¸²à¸à¸´à¸à¸±à¸ z à¹à¸à¸. (à¹à¸à¹à¸²à¸à¸±à¹à¸ 3D vector)"
+msgstr "à¸à¹à¸²à¸à¸³à¸«à¸à¸à¹à¸à¹à¸ 0, à¸à¸°à¹à¸à¹à¸à¹à¸²à¸à¸´à¸à¸±à¸ z à¹à¸à¸. (à¹à¸à¹à¸²à¸à¸±à¹à¸ 3D vector)"
Modified: grass/branches/develbranch_6/locale/po/grassmods_tr.po
--- grass/branches/develbranch_6/locale/po/grassmods_tr.po 2009-03-08 05:41:52 UTC (rev 36240)
+++ grass/branches/develbranch_6/locale/po/grassmods_tr.po 2009-03-08 06:13:40 UTC (rev 36241)
@@ -15759,7 +15759,7 @@
msgstr ""
msgstr ""
Modified: grass/branches/develbranch_6/locale/po/grassmods_vi.po
--- grass/branches/develbranch_6/locale/po/grassmods_vi.po 2009-03-08 05:41:52 UTC (rev 36240)
+++ grass/branches/develbranch_6/locale/po/grassmods_vi.po 2009-03-08 06:13:40 UTC (rev 36241)
@@ -17118,9 +17118,9 @@
msgstr "Kiá»u ÄÆ°á»ng spline cá»§a phép ná»i suy"
msgstr ""
-"Giá trá» trưá»ng. Nếu là 0, các tá»a Äá» z ÄÆ°á»£c dùng. (ChỠáp dụng cho vector 3D)"
+"Nếu là 0, các tá»a Äá» z ÄÆ°á»£c dùng. (ChỠáp dụng cho vector 3D)"
Modified: grass/branches/develbranch_6/locale/po/grassmods_zh.po
--- grass/branches/develbranch_6/locale/po/grassmods_zh.po 2009-03-08 05:41:52 UTC (rev 36240)
+++ grass/branches/develbranch_6/locale/po/grassmods_zh.po 2009-03-08 06:13:40 UTC (rev 36241)
@@ -16537,7 +16537,7 @@
msgstr "è¾åºçæ¯å
æè¯¯å·®"
msgstr "åæ®µå¼ãå¦æè®¾ç½®ä¸º0ï¼å表æä½¿ç¨ z åæ ã(ä»
ç¨äº 3D ç¢é)"
Modified: grass/branches/develbranch_6/vector/v.surf.rst/main.c
--- grass/branches/develbranch_6/vector/v.surf.rst/main.c 2009-03-08 05:41:52 UTC (rev 36240)
+++ grass/branches/develbranch_6/vector/v.surf.rst/main.c 2009-03-08 06:13:40 UTC (rev 36241)
@@ -203,7 +203,7 @@
parm.field = G_define_standard_option(G_OPT_V_FIELD);
parm.field->description =
- _("Field value. If set to 0, z coordinates are used. (3D vector only)");
+ _("If set to 0, z coordinates are used. (3D vector only)");
parm.field->answer = "1";
parm.zcol = G_define_option();
