[GRASS-SVN] r36251 - in grass/branches/releasebranch_6_4:
gui/wxpython/gui_modules vector/v.surf.rst
svn_grass at osgeo.org
Sun Mar 8 09:12:39 EDT 2009
Author: martinl
Date: 2009-03-08 09:12:39 -0400 (Sun, 08 Mar 2009)
New Revision: 36251
grass/branches/releasebranch_6_4/gui/wxpython/gui_modules/gselect.py
grass/branches/releasebranch_6_4/gui/wxpython/gui_modules/menuform.py
grass/branches/releasebranch_6_4/vector/v.surf.rst/main.c
v.surf.rst: allow layer '0' in wxGUI dialog
(merge from devbr6, r36250)
Modified: grass/branches/releasebranch_6_4/gui/wxpython/gui_modules/gselect.py
--- grass/branches/releasebranch_6_4/gui/wxpython/gui_modules/gselect.py 2009-03-08 12:50:12 UTC (rev 36250)
+++ grass/branches/releasebranch_6_4/gui/wxpython/gui_modules/gselect.py 2009-03-08 13:12:39 UTC (rev 36251)
@@ -414,36 +414,37 @@
def __init__(self, parent,
id=wx.ID_ANY, pos=wx.DefaultPosition,
size=globalvar.DIALOG_LAYER_SIZE,
- vector=None, choices=[], all=False, default=None):
+ vector=None, choices=[], initial=['1'], default=None):
super(LayerSelect, self).__init__(parent, id, pos=pos, size=size,
choices=choices)
- self.all = all
+ # initial choices (force '1' to be included)
+ self.initial = initial
+ if '1' not in self.initial:
+ self.initial.append('1')
- self.SetName("LayerSelect")
# default value
self.default = default
+ self.SetName("LayerSelect")
if len(choices) > 1:
return
if vector:
self.InsertLayers(vector)
else:
- if all:
- self.SetItems(['-1', '1'])
- else:
- self.SetItems(['1'])
+ self.SetItems(self.initial)
self.SetStringSelection('1')
def InsertLayers(self, vector):
"""Insert layers for a vector into the layer combobox"""
- layerchoices = utils.GetVectorNumberOfLayers(vector)
+ layerchoices = []
+ if self.initial:
+ layerchoices = copy.copy(self.initial)
+ layerchoices += utils.GetVectorNumberOfLayers(vector)
- if self.all:
- layerchoices.insert(0, '-1')
if len(layerchoices) > 1:
self.SetItems(layerchoices)
Modified: grass/branches/releasebranch_6_4/gui/wxpython/gui_modules/menuform.py
--- grass/branches/releasebranch_6_4/gui/wxpython/gui_modules/menuform.py 2009-03-08 12:50:12 UTC (rev 36250)
+++ grass/branches/releasebranch_6_4/gui/wxpython/gui_modules/menuform.py 2009-03-08 13:12:39 UTC (rev 36251)
@@ -915,7 +915,7 @@
tab[section] = wx.ScrolledWindow( parent=self.notebook )
tab[section].SetScrollRate(10,10)
tabsizer[section] = wx.BoxSizer(orient=wx.VERTICAL)
- self.notebook.AddPage( tab[section], text=section )
+ self.notebook.AddPage( tab[section], text=section.replace('_', ' '))
# are we running from command line?
### add 'command output' tab regardless standalone dialog
@@ -1160,7 +1160,8 @@
'dbtable',
'dbcolumn',
'layer',
- 'layer_all') and \
+ 'layer_all',
+ 'layer_zero') and \
p.get('element', '') != 'file':
if p.get('multiple', 'no') == 'yes':
multiple = True
@@ -1194,21 +1195,25 @@
'dbtable',
'dbcolumn',
'layer',
- 'layer_all'):
+ 'layer_all',
+ 'layer_zero'):
win = wx.TextCtrl(parent=which_panel, value = p.get('default',''),
size=globalvar.DIALOG_TEXTCTRL_SIZE)
win.Bind(wx.EVT_TEXT, self.OnSetValue)
else:
if p.get('prompt', '') in ('layer',
- 'layer_all'):
+ 'layer_all',
+ 'layer_zero'):
+ initial = ['1']
if p.get('prompt', '') == 'layer_all':
- all = True
- else:
- all = False
+ initial.insert(0, '-1')
+ if p.get('prompt', '') == 'layer_zero':
+ initial.insert(0, '0')
if p.get('age', 'old_layer') == 'old_layer':
win = gselect.LayerSelect(parent=which_panel,
- all=all,
+ initial=initial,
default=p['default'])
p['wxGetValue'] = win.GetStringSelection
win.Bind(wx.EVT_CHOICE, self.OnUpdateSelection)
Modified: grass/branches/releasebranch_6_4/vector/v.surf.rst/main.c
--- grass/branches/releasebranch_6_4/vector/v.surf.rst/main.c 2009-03-08 12:50:12 UTC (rev 36250)
+++ grass/branches/releasebranch_6_4/vector/v.surf.rst/main.c 2009-03-08 13:12:39 UTC (rev 36251)
@@ -205,6 +205,7 @@
parm.field->description =
_("If set to 0, z coordinates are used. (3D vector only)");
parm.field->answer = "1";
+ parm.field->gisprompt = "old_layer,layer,layer_zero";
parm.zcol = G_define_option();
parm.zcol->key = "zcolumn";
