[GRASS-SVN] r36264 - grass/branches/develbranch_6/gui/tcltk/gis.m
svn_grass at osgeo.org
Sun Mar 8 18:12:28 EDT 2009
Author: cmbarton
Date: 2009-03-08 18:12:28 -0400 (Sun, 08 Mar 2009)
New Revision: 36264
grass/branches/develbranch_6/gui/tcltk/gis.m/profile.tcl
fix profile module so that numbers of points to plot are limited to < 500, to prevent hanging in large, high-resolution maps.
Modified: grass/branches/develbranch_6/gui/tcltk/gis.m/profile.tcl
--- grass/branches/develbranch_6/gui/tcltk/gis.m/profile.tcl 2009-03-08 19:45:28 UTC (rev 36263)
+++ grass/branches/develbranch_6/gui/tcltk/gis.m/profile.tcl 2009-03-08 22:12:28 UTC (rev 36264)
@@ -366,7 +366,7 @@
set tottlength [expr {$tottlength + $tlength}]
lappend pcoordslist $tottlength
monitor_annotate $measurement_annotation_handle " --segment length\t= $tlength\n"
monitor_annotate $measurement_annotation_handle "cumulative length\t= $tottlength\n"
@@ -523,8 +523,40 @@
$pcan create line $right $bottom $right [expr $bottom + 5]
$pcan create line [expr $left - 5] $top $left $top
+ # Keep total points in profile graph to under 500 to prevent freezing in
+ # large, high resolution maps
+ set ns 0.0
+ set ew 0.0
+ set max_res 0.0
+ set max_dim 0.0
+ set transect_res 0
+ if {![catch {open [concat "|g.region" "-gp" "2> $devnull"] r} input]} {
+ while {[gets $input line] >= 0} {
+ set reglst [split $line "="]
+ set parts([lindex $reglst 0]) [lindex $reglst 1]
+ if {[catch {close $input} error]} {
+ GmLib::errmsg $error [G_msg "Error reading region values"]
+ set ns [expr abs($parts(n) - $parts(s))]
+ set ew [expr abs($parts(e) - $parts(w))]
+ set max_res [expr {$parts(nsres) > $parts(ewres) ? $parts(nsres):$parts(ewres)}]
+ set max_dim [expr {$ns > $ew ? $ns:$ew}]
+ if { [expr (2 * $max_dim) / $max_res] > 500} {
+ set transect_res [expr (2 * $max_dim / 500)]
+ } else {
+ set transect_res $max_res
# run r.profile first time to calculate total transect distance (needed for lat lon regions)
- if {![catch {open "|r.profile input=$pmap profile=$pcoords null=nan 2> $devnull" r} input]} {
+ if {![catch {open "|r.profile input=$pmap profile=$pcoords res=$transect_res null=nan 2> $devnull" r} input]} {
if { [regexp -nocase {^([0-9].*) ([[.-.]0-9na].*)$} $line trash dist elev] } {
set cumdist $dist
@@ -593,7 +625,7 @@
# run r.profile again to
# convert dist elev (stdout) to xy coordinates of profile line
if { [string equal "$elev" "nan" ] } {
