[GRASS-SVN] r36273 - in grass/trunk/raster/r.watershed: front ram seg
Mon Mar 9 04:59:34 EDT 2009
Author: mmetz
Date: 2009-03-09 04:59:34 -0400 (Mon, 09 Mar 2009)
New Revision: 36273
   grass/trunk/raster/r.watershed/front/main.c
   grass/trunk/raster/r.watershed/front/r.watershed.html
   grass/trunk/raster/r.watershed/ram/Gwater.h
   grass/trunk/raster/r.watershed/ram/close_maps.c
   grass/trunk/raster/r.watershed/ram/do_astar.c
   grass/trunk/raster/r.watershed/ram/init_vars.c
   grass/trunk/raster/r.watershed/ram/main.c
   grass/trunk/raster/r.watershed/ram/sg_factor.c
   grass/trunk/raster/r.watershed/seg/Gwater.h
   grass/trunk/raster/r.watershed/seg/close_maps.c
   grass/trunk/raster/r.watershed/seg/init_vars.c
   grass/trunk/raster/r.watershed/seg/main.c
   grass/trunk/raster/r.watershed/seg/sg_factor.c
added flag for absolute flow accumulation, some minor bugs fixed
Modified: grass/trunk/raster/r.watershed/front/main.c
--- grass/trunk/raster/r.watershed/front/main.c	2009-03-09 08:54:47 UTC (rev 36272)
+++ grass/trunk/raster/r.watershed/front/main.c	2009-03-09 08:59:34 UTC (rev 36273)
@@ -6,8 +6,8 @@
  *               Brad Douglas <rez touchofmadness.com>,
  *               Hamish Bowman <hamish_b yahoo.com>
  *               Markus Metz <markus.metz.giswork gmail.com>
- * PURPOSE:      Watershed determination
- * COPYRIGHT:    (C) 1999-2008 by the GRASS Development Team
+ * PURPOSE:      Hydrological analysis
+ * COPYRIGHT:    (C) 1999-2009 by the GRASS Development Team
  *               This program is free software under the GNU General Public
  *               License (>=v2). Read the file COPYING that comes with GRASS
@@ -38,7 +38,6 @@
     struct Option *opt10;
     struct Option *opt11;
     struct Option *opt12;
-    struct Option *opt13;
     struct Option *opt14;
     struct Option *opt15;
     struct Option *opt16;
@@ -46,6 +45,7 @@
     struct Flag *flag_sfd;
     struct Flag *flag_flow;
     struct Flag *flag_seg;
+    struct Flag *flag_abs;
     struct GModule *module;
     G_gisinit(argv[0]);
@@ -103,16 +103,14 @@
 	_("Input value: minimum size of exterior watershed basin");
     opt6->required = NO;
     opt6->type = TYPE_INTEGER;
-    opt6->gisprompt = "new,cell,raster";
     opt6->guisection = _("Input_options");
     opt7 = G_define_option();
     opt7->key = "max_slope_length";
     opt7->description =
-	_("Input value: maximum length of surface flow, for USLE");
+	_("Input value: maximum length of surface flow in map units, for USLE");
     opt7->required = NO;
     opt7->type = TYPE_DOUBLE;
-    opt7->gisprompt = "new,cell,raster";
     opt7->guisection = _("Input_options");
     opt8 = G_define_option();
@@ -158,6 +156,7 @@
     opt12->gisprompt = "new,cell,raster";
     opt12->guisection = _("Output_options");
+/* to be removed completely. visual display of results is now done with accumulation output
     opt13 = G_define_option();
     opt13->key = "visual";
     opt13->description =
@@ -166,7 +165,7 @@
     opt13->type = TYPE_STRING;
     opt13->gisprompt = "new,cell,raster";
     opt13->guisection = _("Output_options");
     opt14 = G_define_option();
     opt14->key = "length_slope";
     opt14->description =
@@ -213,9 +212,18 @@
     flag_seg = G_define_flag();
     flag_seg->key = 'm';
+    flag_seg->label =
+	_("Enable disk swap memory option: Operation is slow");
     flag_seg->description =
-	_("Enable disk swap memory option: Operation is slow");
+	_("Only needed if memory requirements exceed available RAM; see manual on how to calculate memory requirements");
+    flag_abs = G_define_flag();
+    flag_abs->key = 'a';
+    flag_abs->label =
+	_("Use positive flow accumulation even for likely underestimates");
+    flag_abs->description =
+	_("See manual for a detailed description of flow accumulation output");
     if (G_parser(argc, argv))
 	exit(EXIT_FAILURE);
@@ -228,7 +236,6 @@
 	&& (opt10->answer == NULL)
 	&& (opt11->answer == NULL)
 	&& (opt12->answer == NULL)
-	&& (opt13->answer == NULL)
 	&& (opt14->answer == NULL)
 	&& (opt15->answer == NULL)) {
 	G_fatal_error(_("Sorry, you must choose an output map."));
@@ -270,6 +277,9 @@
     if (flag_flow->answer)
 	strcat(command, " -4");
+    if (flag_abs->answer)
+	strcat(command, " -a");
     if (opt1->answer) {
 	strcat(command, " el=");
 	strcat(command, "\"");
@@ -350,12 +360,13 @@
-    if (opt13->answer) {
+/*    if (opt13->answer) {
 	strcat(command, " di=");
 	strcat(command, opt13->answer);
     if (opt14->answer) {
 	strcat(command, " LS=");
@@ -410,10 +421,10 @@
 	write_hist(opt12->answer,
 		   "Watershed half-basins", opt1->answer, flag_seg->answer,
 		   flag_sfd->answer);
+    /* if (opt13->answer)
 	write_hist(opt13->answer,
 		   "Watershed visualization map (filtered accumulation map)",
-		   opt1->answer, flag_seg->answer, flag_sfd->answer);
+		   opt1->answer, flag_seg->answer, flag_sfd->answer); */
     if (opt14->answer)
 	write_hist(opt14->answer,
 		   "Watershed slope length and steepness (LS) factor",
Modified: grass/trunk/raster/r.watershed/front/r.watershed.html
--- grass/trunk/raster/r.watershed/front/r.watershed.html	2009-03-09 08:54:47 UTC (rev 36272)
+++ grass/trunk/raster/r.watershed/front/r.watershed.html	2009-03-09 08:59:34 UTC (rev 36273)
@@ -40,6 +40,13 @@
 surface flow (allows horizontal, vertical, and diagonal flow of water).
 This flag will also make the drainage basins look more homogeneous.
+<dt><em>-a</em>
+<dd>Use positive flow accumulation even for likely underestimates. When this
+flag is not set, cells with a flow accumulation value that is likely to be
+an underestimate are converted to the negative. See below for a detailed
+description of flow accumulation output.
 <dt><em>memory</em>
 <dd>Maximum amount of memory in MB to be used with -m set. More memory
@@ -151,14 +158,6 @@
 cells of the watershed basin are given odd values which are one less
 than the value of the watershed basin.
-<dt><em>visual</em>
-<dd>Output map: useful for visual display of results.
-Surface runoff accumulation with the values
-modified to provide for easy display.  All negative accumulation values
-are changed to zero.  All positive values above the basin threshold
-are given the value of the <em>threshold</em> parameter.
 <dt><em>length_slope</em>
 <dd>Output map: slope length and steepness (LS) factor for the Revised
@@ -212,14 +211,13 @@
 MFD, water flow is distributed to all neighbouring cells with lower
 elevation, using slope towards neighbouring cells as a weighing factor
 for proportional distribution. The A<sup>T</sup> least-cost path is
-always included. As a result, depressions and obstacles are overflown
+always included. As a result, depressions and obstacles are traversed
 with a gracefull flow convergence before the overflow. The convergence
 factor causes flow accumulation to converge more strongly with higher
 values. The supported range is 1 to 10, recommended is a convergence
 factor of 5 (Holmgren, 1994). If many small sliver basins are created
 with MFD, setting the convergence factor to a higher value can reduce
 the amount of small sliver basins.
-<br>See example below with the North Carolina dataset for using MFD mode.
 <h4>In-memory mode and disk swap mode</h4>
 There are two versions of this program: <em>ram</em> and <em>seg</em>.
@@ -264,17 +262,6 @@
 using the values from the <em>neighborhood</em> output map layer that
 represents the minimum elevation within the region of the coarser cell.
-<h4>High-resolution elevation maps with floating point values</h4>
-To get better results with high resolution elevation maps with
-floating point values, it may be necessary to multiply the original map
-with e.g. 100 to change elevation units from meters to cm, because
-<em>r.watershed</em> reads input elevation maps as integer. This allows
-control over how much detail is required to obtain useful results with a
-given dataset and region setting. Remember to adjust any <em>slope length
-and steepness (LS) factor</em> or <em>slope steepness (S) factor</em>
-output accordingly. See example below for using <em>r.mapcalc</em> to
-convert elevation from meter to millimeter.
 <h4>Basin threshold</h4>
 The minimum size of drainage basins, defined by the <em>threshold</em>
 parameter, is only relevant for those watersheds with a single stream
@@ -306,6 +293,16 @@
 <h4>Further processing of output layers</h4>
 <p>
+Problem areas, i.e. those parts of a basin with a likely underestimate of
+flow accumulation, can be easily identified with e.g.
+<div class="code"><pre>
+  r.mapcalc "problems = if(flow_acc < 0, basin, null())"
+</pre></div>
+If the region of interest contains such problem areas, and this is not
+desired, the computational region must be expanded until the catchment
+area for the region of interest is completely included.
+<p>
 To isolate an individual river network using the output of this module,
 a number of approaches may be considered.
 <ol>
@@ -318,6 +315,11 @@
   starting point.
 </ol>
+All individual river networks in the stream segments output can be
+identified through their ultimate outlet points. These points are all
+cells in the stream segments output with negative drainage direction.
+These points can be used as start points for <em>r.water.outlet</em> or
+<em>v.net.iso</em>.
 <p>
 To create <i>river mile</i> segmentation from a vectorized streams map,
@@ -349,7 +351,7 @@
 <br>
 <p>
-Set a nice color table for the accumulation map:
+Set a different color table for the accumulation map:
   MAP=rwater.accum
   r.watershed elev=elevation.dem accum=$MAP
@@ -380,7 +382,7 @@
 it to a vector output map. The accumulation cut-off, and therefore fractal
 dimension, is arbitrary; in this example we use the map's mean number of
 upstream catchment cells (calculated in the above example by <em>r.univar</em>)
-as the cut-off value.
+as the cut-off value. This only works with SFD, not with MFD.
   r.watershed elev=elevation.dem accum=rwater.accum
@@ -424,18 +426,6 @@
 </pre></div>
 <br>
-<i>This example uses the North Carolina sample dataset.</i>
-<p>
-Using MFD mode on a LIDAR elevation dataset:
-<br>Convert elevation values of elev_lid972_1m from meter to millimeter
-then compare MFD mode with default medium flow convergence to SFD mode.
-<div class="code"><pre>
-  r.mapcalc "elev_lid972_1m.1mm = round(elev_lid972_1m * 1000.0)"
-  r.watershed elevation=elev_lid972_1m.1mm accumulation=elev_lid972_1m.1mm.acc drainage=elev_lid972_1m.1mm.dir convergence=5
-  r.watershed -s elevation=elev_lid972_1m.1mm accumulation=elev_lid972_1m.1mm.acc.sfd drainage=elev_lid972_1m.1mm.dir.sfd
-</pre></div>
 <a name="references"></a>
 <h2>REFERENCES</h2>
@@ -496,7 +486,7 @@
 Original version:
 Charles Ehlschlaeger, U.S. Army Construction Engineering Research Laboratory
 <br>
-Faster sorting algorithm:
+Faster sorting algorithm and MFD support:
 Markus Metz &lt;markus.metz.giswork at gmail.com&gt;
 <p>
Modified: grass/trunk/raster/r.watershed/ram/Gwater.h
--- grass/trunk/raster/r.watershed/ram/Gwater.h	2009-03-09 08:54:47 UTC (rev 36272)
+++ grass/trunk/raster/r.watershed/ram/Gwater.h	2009-03-09 08:59:34 UTC (rev 36273)
@@ -40,7 +40,7 @@
 extern struct Cell_head window;
-extern int mfd, c_fac;
+extern int mfd, c_fac, abs_acc, ele_scale;
 extern int *heap_index, heap_size;
 extern int first_astar, first_cum, nxt_avail_pt, total_cells, do_points;
 extern SHORT nrows, ncols;
@@ -53,7 +53,6 @@
 extern POINT *astar_pts;
 extern CELL *dis, *alt, *asp, *bas, *haf, *r_h, *dep;
 extern DCELL *wat;
-extern CELL *ril_buf;
 extern int ril_fd;
 extern double *s_l, *s_g, *l_s;
 extern CELL one, zero;
Modified: grass/trunk/raster/r.watershed/ram/close_maps.c
--- grass/trunk/raster/r.watershed/ram/close_maps.c	2009-03-09 08:54:47 UTC (rev 36272)
+++ grass/trunk/raster/r.watershed/ram/close_maps.c	2009-03-09 08:59:34 UTC (rev 36273)
@@ -30,19 +30,38 @@
 	    G_warning(_("unable to open new accum map layer."));
 	else {
-	    for (r = 0; r < nrows; r++) {
-		G_set_d_null_value(dbuf, ncols);	/* reset row to all NULL */
-		for (c = 0; c < ncols; c++) {
-		    dvalue = wat[SEG_INDEX(wat_seg, r, c)];
-		    if (G_is_d_null_value(&dvalue) == 0 && dvalue) {
-			dbuf[c] = dvalue;
-			dvalue = ABS(dvalue);
-			sum += dvalue;
-			sum_sqr += dvalue * dvalue;
+	    if (abs_acc) {
+		G_warning("Writing out only positive flow accumulation values.");
+		G_warning("Cells with a likely underestimate for flow accumulation can no longer be identified.");
+		for (r = 0; r < nrows; r++) {
+		    G_set_d_null_value(dbuf, ncols);	/* reset row to all NULL */
+		    for (c = 0; c < ncols; c++) {
+			dvalue = wat[SEG_INDEX(wat_seg, r, c)];
+			if (G_is_d_null_value(&dvalue) == 0 && dvalue) {
+			    dvalue = ABS(dvalue);
+			    dbuf[c] = dvalue;
+			    sum += dvalue;
+			    sum_sqr += dvalue * dvalue;
+		    G_put_raster_row(fd, dbuf, DCELL_TYPE);
-		G_put_raster_row(fd, dbuf, DCELL_TYPE);
+	    else {
+			    dbuf[c] = dvalue;
+			    sum += dvalue;
 	    if (G_close_cell(fd) < 0)
 		G_warning(_("Close failed."));
Modified: grass/trunk/raster/r.watershed/ram/do_astar.c
--- grass/trunk/raster/r.watershed/ram/do_astar.c	2009-03-09 08:54:47 UTC (rev 36272)
+++ grass/trunk/raster/r.watershed/ram/do_astar.c	2009-03-09 08:59:34 UTC (rev 36273)
@@ -92,6 +92,8 @@
+    /* this was a lot of indentation, all in the sake of speed... */
+    /* improve code aesthetics? */
     G_percent(count, do_points, 3);	/* finish it */
     if (mfd == 0)
 	flag_destroy(worked);
@@ -134,9 +136,9 @@
 /* new drop point routine for min heap */
 int drop_pt(void)
-    int child, childr, parent;
+    register int child, childr, parent;
     CELL ele, eler;
-    int i;
+    register int i;
     if (heap_size == 1) {
 	heap_index[1] = -1;
@@ -152,17 +154,15 @@
     while ((child = GET_CHILD(parent)) <= heap_size) {
 	/* select child with lower ele, if equal, older child
-	 * older child is older startpoint for flow path, important
-	 * chances are good that the left child will be the older child,
-	 * but just to make sure we test */
+	 * older child is older startpoint for flow path, important */
 	ele =
 	    alt[SEG_INDEX
 		(alt_seg, astar_pts[heap_index[child]].r,
 		 astar_pts[heap_index[child]].c)];
 	if (child < heap_size) {
 	    childr = child + 1;
-	    i = 1;
-	    while (childr <= heap_size && i < 3) {
+	    i = child + 3; /* change the number, GET_CHILD() and GET_PARENT() to play with different d-ary heaps */
+	    while (childr <= heap_size && childr < i) {
 		eler =
 		    alt[SEG_INDEX
 			(alt_seg, astar_pts[heap_index[childr]].r,
@@ -170,15 +170,23 @@
 		if (eler < ele) {
 		    child = childr;
 		    ele = eler;
-		    /* make sure we get the oldest child */
+		/* make sure we get the oldest child */
 		else if (ele == eler &&
 			 heap_index[child] > heap_index[childr]) {
 		    child = childr;
 		childr++;
-		i++;
+		/* i++; */
+	    /* break if childr > last entry? that saves sifting up again
+	     * OTOH, this is another comparison
+	     * we have a max heap height of 20: log(INT_MAX)/log(n children per node)
+	     * that would give us in the worst case 20*2 additional comparisons with 3 children
+	     * the last entry will never go far up again, less than half the way
+	     * so the additional comparisons for going all the way down
+	     * and then a bit up again are likely less than 20*2 */
+	    /* find the error in this reasoning */
 	/* move hole down */
@@ -210,7 +218,7 @@
 /* standard sift-up routine for d-ary min heap */
 int sift_up(int start, CELL ele)
-    int parent, parentp, child, childp;
+    register int parent, parentp, child, childp;
     CELL elep;
     child = start;
Modified: grass/trunk/raster/r.watershed/ram/init_vars.c
--- grass/trunk/raster/r.watershed/ram/init_vars.c	2009-03-09 08:54:47 UTC (rev 36272)
+++ grass/trunk/raster/r.watershed/ram/init_vars.c	2009-03-09 08:59:34 UTC (rev 36273)
@@ -4,12 +4,16 @@
 #include <grass/gis.h>
 #include <grass/glocale.h>
+int ele_round(double);
 int init_vars(int argc, char *argv[])
     SHORT r, c;
     CELL *buf, alt_value, wat_value, asp_value, block_value;
-    int fd, index;
+    DCELL dvalue;
+    void *elebuf, *ptr;
+    int fd, index, ele_map_type;
+    size_t ele_size;
     char MASK_flag;
     G_gisinit(argv[0]);
@@ -26,6 +30,8 @@
     sides = 8;
     mfd = 1;
     c_fac = 5;
+    abs_acc = 0;
+    ele_scale = 1;
     for (r = 1; r < argc; r++) {
 	if (sscanf(argv[r], "el=%[^\n]", ele_name) == 1)
 	    ele_flag++;
@@ -71,6 +77,8 @@
 	else if (sscanf(argv[r], "conv=%d", &c_fac) == 1) ;
 	else if (strcmp(argv[r], "-s") == 0)
 	    mfd = 0;
+	else if (strcmp(argv[r], "-a") == 0)
+	    abs_acc = 1;
 	else
 	    usage(argv[0]);
@@ -118,7 +126,7 @@
 		window.ns_res * window.ns_res);
     if (sides == 4)
 	diag *= 0.5;
-    buf = G_allocate_cell_buf();
     alt =
 	(CELL *) G_malloc(sizeof(CELL) * size_array(&alt_seg, nrows, ncols));
     if (er_flag) {
@@ -126,45 +134,79 @@
 	    (CELL *) G_malloc(sizeof(CELL) * size_array(&r_h_seg, nrows, ncols));
+    swale = flag_create(nrows, ncols);
+    in_list = flag_create(nrows, ncols);
+    worked = flag_create(nrows, ncols);
+    /* open elevation input */
     fd = G_open_cell_old(ele_name, "");
     if (fd < 0) {
 	G_fatal_error(_("unable to open elevation map layer"));
-    swale = flag_create(nrows, ncols);
-    in_list = flag_create(nrows, ncols);
-    worked = flag_create(nrows, ncols);
+    ele_map_type = G_get_raster_map_type(fd);
+    ele_size = G_raster_size(ele_map_type);
+    elebuf = G_allocate_raster_buf(ele_map_type);
+    if (ele_map_type == FCELL_TYPE || ele_map_type == DCELL_TYPE)
+	ele_scale = 1000; 	/* should be enough to do the trick */
+    /* read elevation input and mark NULL/masked cells */
     MASK_flag = 0;
     do_points = nrows * ncols;
-	G_get_c_raster_row(fd, buf, r);
+	G_get_raster_row(fd, elebuf, r, ele_map_type);
+	ptr = elebuf;
 	    index = SEG_INDEX(alt_seg, r, c);
-	    alt_value = alt[index] = buf[c];
-	    if (er_flag) {
-		r_h[index] = buf[c];
 	    /* all flags need to be manually set to zero */
 	    flag_unset(swale, r, c);
 	    flag_unset(in_list, r, c);
 	    flag_unset(worked, r, c);
-	    /* check for masked and NULL cells here */
-	    if (G_is_c_null_value(&alt_value)) {
+	    /* check for masked and NULL cells */
+	    if (G_is_null_value(ptr, ele_map_type)) {
 		FLAG_SET(worked, r, c);
 		FLAG_SET(in_list, r, c);
+		G_set_c_null_value(&alt_value, 1);
 		do_points--;
+	    else {
+		if (ele_map_type == CELL_TYPE) {
+		    alt_value = *((CELL *)ptr);
+		else if (ele_map_type == FCELL_TYPE) {
+		    dvalue = *((FCELL *)ptr);
+		    dvalue *= ele_scale;
+		    alt_value = ele_round(dvalue);
+		else if (ele_map_type == DCELL_TYPE) {
+		    dvalue = *((DCELL *)ptr);
+	    alt[index] = alt_value;
+	    if (er_flag) {
+		r_h[index] = alt_value;
+	    ptr = G_incr_void_ptr(ptr, ele_size);
     G_close_cell(fd);
+    G_free(elebuf);
     if (do_points < nrows * ncols)
 	MASK_flag = 1;
+    /* initialize flow accumulation ... */
     wat =
 	(DCELL *) G_malloc(sizeof(DCELL) *
 			   size_array(&wat_seg, nrows, ncols));
+    buf = G_allocate_cell_buf();
     if (run_flag) {
+	/* ... with input map flow: amount of overland flow per cell */
 	fd = G_open_cell_old(run_name, "");
 	if (fd < 0) {
 	    G_fatal_error(_("unable to open runoff map layer"));
@@ -186,6 +228,7 @@
 	G_close_cell(fd);
     else {
+	/* ... with 1.0 */
 		if (MASK_flag) {
@@ -234,6 +277,8 @@
 	G_close_cell(fd);
+    G_free(buf);
     if (ril_flag) {
 	ril_fd = G_open_cell_old(ril_name, "");
 	if (ril_fd < 0) {
@@ -410,3 +455,17 @@
     return 0;
+int ele_round(double x)
+    int n;
+    if (x >= 0.0)
+	n = x + .5;
+    else {
+	n = -x + .5;
+	n = -n;
+    return n;
Modified: grass/trunk/raster/r.watershed/ram/main.c
--- grass/trunk/raster/r.watershed/ram/main.c	2009-03-09 08:54:47 UTC (rev 36272)
+++ grass/trunk/raster/r.watershed/ram/main.c	2009-03-09 08:59:34 UTC (rev 36273)
@@ -7,8 +7,8 @@
  *               Hamish Bowman <hamish_b yahoo com>,
@@ -24,7 +24,7 @@
-int mfd, c_fac;
+int mfd, c_fac, abs_acc, ele_scale;
 SHORT nrows, ncols;
@@ -37,7 +37,6 @@
 POINT *astar_pts;
 DCELL *wat;
-CELL *ril_buf;
 int ril_fd;
 CELL one, zero;
Modified: grass/trunk/raster/r.watershed/ram/sg_factor.c
--- grass/trunk/raster/r.watershed/ram/sg_factor.c	2009-03-09 08:54:47 UTC (rev 36272)
+++ grass/trunk/raster/r.watershed/ram/sg_factor.c	2009-03-09 08:59:34 UTC (rev 36273)
@@ -2,6 +2,7 @@
+CELL *ril_buf;
 int sg_factor(void)
@@ -11,6 +12,9 @@
     G_message(_("SECTION 4: RUSLE LS and/or S factor determination."));
+    if (ril_flag)
+	ril_buf = G_allocate_cell_buf();
 	G_percent(r, nrows, 3);
 	if (ril_flag) {
@@ -20,7 +24,7 @@
 	    low_elev = alt[SEG_INDEX(alt_seg, r, c)];
 	    hih_elev = r_h[SEG_INDEX(r_h_seg, r, c)];
 	    length = s_l[SEG_INDEX(s_l_seg, r, c)];
-	    height = hih_elev - low_elev;
+	    height = 1.0 * (hih_elev - low_elev) / ele_scale;
 	    if (length > max_length) {
 		height *= max_length / length;
 		length = max_length;
@@ -66,7 +70,7 @@
     /* rill_ratio equation from Steve Warren */
     rill_ratio *= .5 + .005 * ril + .0001 * ril * ril;
     s_l_exp = rill_ratio / (1 + rill_ratio);
-    L = 100 * pow((slope_length / 72.6), s_l_exp);
+    L = pow((slope_length / 72.6), s_l_exp);
     l_s[SEG_INDEX(l_s_seg, r, c)] = L * S;
     return 0;
Modified: grass/trunk/raster/r.watershed/seg/Gwater.h
--- grass/trunk/raster/r.watershed/seg/Gwater.h	2009-03-09 08:54:47 UTC (rev 36272)
+++ grass/trunk/raster/r.watershed/seg/Gwater.h	2009-03-09 08:59:34 UTC (rev 36273)
@@ -43,7 +43,7 @@
 extern SSEG heap_index;
 extern int heap_size;
Modified: grass/trunk/raster/r.watershed/seg/close_maps.c
--- grass/trunk/raster/r.watershed/seg/close_maps.c	2009-03-09 08:54:47 UTC (rev 36272)
+++ grass/trunk/raster/r.watershed/seg/close_maps.c	2009-03-09 08:59:34 UTC (rev 36273)
@@ -17,24 +17,50 @@
     dseg_close(&slp);
     cseg_close(&alt);
     if (wat_flag) {
-	dseg_write_cellfile(&wat, wat_name);
+	sum = sum_sqr = stddev = 0.0;
+	dbuf = G_allocate_d_raster_buf();
+	if (abs_acc) {
-	/* get standard deviation */
-	fd = G_open_cell_old(wat_name, "");
-	if (fd < 0) {
-	    G_fatal_error(_("unable to open flow accumulation map layer"));
+	    fd = G_open_raster_new(wat_name, DCELL_TYPE);
+	    if (fd < 0) {
+		G_warning(_("unable to open new accum map layer."));
+		    dseg_get(&wat, &dvalue, r, c);
+			dbuf[c] = dvalue;
+			sum += dvalue;
+	    if (G_close_cell(fd) < 0)
+		G_warning(_("Close failed."));
+	else {
+	    dseg_write_cellfile(&wat, wat_name);
-	sum = sum_sqr = stddev = 0.0;
-	dbuf = G_allocate_d_raster_buf();
-	    G_get_d_raster_row(fd, dbuf, r);
-		dvalue = dbuf[c];
-		    sum += dvalue;
+	    /* get standard deviation */
+	    fd = G_open_cell_old(wat_name, "");
+	    if (fd < 0) {
+		G_fatal_error(_("unable to open flow accumulation map layer"));
+		G_get_d_raster_row(fd, dbuf, r);
+		    dvalue = dbuf[c];
+			sum += dvalue;
Modified: grass/trunk/raster/r.watershed/seg/init_vars.c
--- grass/trunk/raster/r.watershed/seg/init_vars.c	2009-03-09 08:54:47 UTC (rev 36272)
+++ grass/trunk/raster/r.watershed/seg/init_vars.c	2009-03-09 08:59:34 UTC (rev 36273)
@@ -5,6 +5,7 @@
@@ -17,7 +18,11 @@
     int max_bytes;
     CELL *buf, alt_value, asp_value, worked_value, block_value;
     DCELL wat_value;
+    DCELL dvalue;
     char MASK_flag;
+    int ele_map_type;
+    size_t ele_size;
     G_gisinit(argv[0]);
     ele_flag = wat_flag = asp_flag = pit_flag = run_flag = ril_flag = 0;
@@ -33,6 +38,8 @@
     sides = 8;
     mfd = 1;
     c_fac = 5;
+    abs_acc = 0;
+    ele_scale = 1;
     segs_mb = 300;
@@ -80,6 +87,8 @@
 	    mfd = 0;
+	    abs_acc = 1;
 	else
 	    usage(argv[0]);
@@ -171,31 +180,63 @@
 	cseg_read_cell(&r_h, ele_name, "");
-    /* NULL cells in input elevation map */
     bseg_open(&in_list, seg_rows, seg_cols, num_open_segs);
     bseg_open(&worked, seg_rows, seg_cols, num_open_segs);
-    G_debug(1, "Checking for masked and NULL cells in input elevation <%s>.", ele_name);
-    MASK_flag = 0;
-    do_points = nrows * ncols;
+    G_verbose_message("Checking for masked and NULL cells in input elevation <%s>", ele_name);
     if (fd < 0) {
+    MASK_flag = 0;
+    do_points = nrows * ncols;
+	ptr = elebuf;
-	    alt_value = buf[c];
 		bseg_put(&worked, &one, r, c);
 		bseg_put(&in_list, &one, r, c);
 		do_points--;
+	    else {
+	    cseg_put(&alt, &alt_value, r, c);
+	    if (er_flag) {
+		cseg_put(&r_h, &alt_value, r, c);
     G_close_cell(fd);
-    G_free(buf);
+    G_free(elebuf);
 	MASK_flag = 1;
@@ -515,3 +556,17 @@
     return 0;
+    int n;
+    if (x >= 0.0)
+	n = x + .5;
+    else {
+	n = -x + .5;
+	n = -n;
+    return n;
Modified: grass/trunk/raster/r.watershed/seg/main.c
--- grass/trunk/raster/r.watershed/seg/main.c	2009-03-09 08:54:47 UTC (rev 36272)
+++ grass/trunk/raster/r.watershed/seg/main.c	2009-03-09 08:59:34 UTC (rev 36273)
@@ -8,8 +8,8 @@
  *               Hamish Bowman <hamish_b yahoo.com>,
- * PURPOSE:      Watershed determination using the GRASS segmentation lib
+ * PURPOSE:      Hydrological analysis using the GRASS segmentation lib
@@ -25,7 +25,7 @@
-int mfd, c_fac;
 SSEG heap_index;
 int heap_size;
Modified: grass/trunk/raster/r.watershed/seg/sg_factor.c
--- grass/trunk/raster/r.watershed/seg/sg_factor.c	2009-03-09 08:54:47 UTC (rev 36272)
+++ grass/trunk/raster/r.watershed/seg/sg_factor.c	2009-03-09 08:59:34 UTC (rev 36273)
@@ -17,7 +17,7 @@
 	    cseg_get(&r_h, &hih_elev, r, c);
 	    dseg_get(&s_l, &length, r, c);
 	    cseg_get(&asp, &downer, r, c);
@@ -32,7 +32,6 @@
 		len_slp_equ(length, sin_theta, S, r, c);
 	    if (sg_flag) {
-		S *= 100.0;
 		dseg_put(&s_g, &S, r, c);
@@ -60,7 +59,7 @@
     rill_ratio *= .5 + .005 * rill + .0001 * rill * rill;
-    LS = S * 100 * pow((slope_length / 72.6), s_l_exp);
+    LS = S * pow((slope_length / 72.6), s_l_exp);
     dseg_put(&l_s, &LS, r, c);
     return 0;
