[GRASS-SVN] r36316 - grass/trunk/gui/wxpython/gui_modules
svn_grass at osgeo.org
Tue Mar 10 14:53:33 EDT 2009
Author: cmbarton
Date: 2009-03-10 14:53:33 -0400 (Tue, 10 Mar 2009)
New Revision: 36316
grass/trunk/gui/wxpython/gui_modules/location_wizard.py
Fixed not creating location in new GISDbase.
Modified: grass/trunk/gui/wxpython/gui_modules/location_wizard.py
--- grass/trunk/gui/wxpython/gui_modules/location_wizard.py 2009-03-10 18:51:12 UTC (rev 36315)
+++ grass/trunk/gui/wxpython/gui_modules/location_wizard.py 2009-03-10 18:53:33 UTC (rev 36316)
@@ -46,6 +46,7 @@
import gcmd
import globalvar
import utils
+import grass
try:
import subprocess
except:
@@ -1850,6 +1851,21 @@
dlg.ShowModal()
dlg.Destroy()
return False
+ # current GISDbase or a new one?
+ current_gdb = grass.gisenv()['GISDBASE']
+ if current_gdb != database:
+ # change to new GISDbase or create new one
+ if os.path.isdir(database) != True:
+ # create new directory
+ os.mkdir(database)
+ # change to new GISDbase directory
+ grass.run_command('g.gisenv', set='GISDBASE=%s' % database)
+ wx.MessageBox(parent=self.wizard,
+ message=_("You will need to change the default GIS data directory in the GRASS startup screen"),
+ caption=("Location <%s> will be created in GIS data directory <%s>") % \
+ (location,database), style=wx.OK | wx.ICON_ERROR)
if coordsys == "xy":
success = self.XYCreate()
