[GRASS-SVN] r36343 - in grass-addons/vector: . v.out.postgis
svn_grass at osgeo.org
Thu Mar 12 11:33:42 EDT 2009
Author: martinl
Date: 2009-03-12 11:33:42 -0400 (Thu, 12 Mar 2009)
New Revision: 36343
Added:
grass-addons/vector/v.out.postgis/
grass-addons/vector/v.out.postgis/v.out.postgis.py
v.out.postgis added (Python)
Added: grass-addons/vector/v.out.postgis/v.out.postgis.py
--- grass-addons/vector/v.out.postgis/v.out.postgis.py (rev 0)
+++ grass-addons/vector/v.out.postgis/v.out.postgis.py 2009-03-12 15:33:42 UTC (rev 36343)
@@ -0,0 +1,127 @@
+#!/usr/bin/env python
+# MODULE: v.out.postgis
+# AUTHOR: Martin Landa <landa.martin gmail.com>
+# PURPOSE: Converts GRASS vectors into PostGIS
+# COPYRIGHT: (c) 2009 Martin Landa, and the GRASS Development Team
+# This program is free software under the GNU General Public
+# License (>=v2). Read the file COPYING that comes with GRASS
+# for details.
+#%Module
+#% description: Converts GRASS vector map(s) into PostGIS
+#% keywords: vector, conversion
+#%End
+#%flag
+#% key: a
+#% description: Convert all vector maps in the mapset
+#%end
+#%option
+#% key: input
+#% type: string
+#% gisprompt: old,vector,vector
+#% key_desc: name
+#% description: Name of vector map to be converted
+#%required: no
+#%end
+#%option
+#% key: dbname
+#% type: string
+#% key_desc: name
+#% description: Name of PostGIS database
+#% required: yes
+#%end
+#%option
+#% key: output
+#% type: string
+#% gisprompt: new,vector,vector
+#% key_desc: name
+#% description: Name for output vector map
+#% required: no
+#%end
+import sys
+import grass
+def main():
+ if not flags['a'] and not options['input']:
+ grass.fatal('Parameter <input> required')
+ map_input = []
+ map_output = []
+ if flags['a']:
+ mapset = grass.gisenv()['MAPSET']
+ map_input = map_output = grass.mlist_grouped(type = 'vect',
+ mapset = mapset)[mapset]
+ else:
+ map_input = [options['input']]
+ if not flags['a']:
+ if not options['output']:
+ map_output = map_input
+ else:
+ map_output = [options['output']]
+ i = 0
+ for imap in map_input:
+ # determine feature type
+ ret = grass.read_command('v.info',
+ flags = 't',
+ map = imap)
+ if not ret:
+ grass.fatal('Unable to get information about vector map <%s>' % imap)
+ info = {}
+ for line in ret.splitlines():
+ key, value = line.split('=')
+ info[key.strip()] = int(value.strip())
+ # extension needed?
+ fnum = 0
+ if info['points'] > 0:
+ fnum += 1
+ if info['lines'] > 0:
+ fnum += 1
+ if info['areas'] > 0:
+ fnum += 1
+ for ftype in ('points', 'lines', 'areas'):
+ if info[ftype] < 1:
+ continue
+ omap = map_output[i]
+ if fnum != 1:
+ omap += '_' + ftype
+ grass.message('Converting <%s> to <%s> (%s)...' % \
+ (imap, omap, ftype))
+ if grass.overwrite():
+ grass.run_command('v.out.ogr',
+ input = imap,
+ type = ftype.rstrip('s'),
+ dsn = "PG:dbname=%s" % options['dbname'],
+ olayer = omap,
+ format = 'PostgreSQL',
+ lco = "OVERWRITE=YES")
+ else:
+ input = imap,
+ olayer = omap,
+ format = 'PostgreSQL')
+ i += 1
+ return 0
+if __name__ == "__main__":
+ options, flags = grass.parser()
+ sys.exit(main())
