[GRASS-SVN] r36348 - grass/trunk/gui/wxpython/gui_modules
svn_grass at osgeo.org
Thu Mar 12 19:11:15 EDT 2009
Author: martinl
Date: 2009-03-12 19:11:15 -0400 (Thu, 12 Mar 2009)
New Revision: 36348
grass/trunk/gui/wxpython/gui_modules/location_wizard.py
wxGUI/location wizard: some MS Windows-related issues
(merge from relbr64, r36346)
Modified: grass/trunk/gui/wxpython/gui_modules/location_wizard.py
--- grass/trunk/gui/wxpython/gui_modules/location_wizard.py 2009-03-12 23:08:51 UTC (rev 36347)
+++ grass/trunk/gui/wxpython/gui_modules/location_wizard.py 2009-03-12 23:11:15 UTC (rev 36348)
@@ -624,13 +624,17 @@
return None
data = []
+ str = str.lower()
for i in range(len(self.sourceData)):
- value = self.sourceData[i][index]
- if str.lower() in value.lower():
- data.append(self.sourceData[i])
+ try:
+ value = self.sourceData[i][index].lower()
+ if str in value:
+ data.append(self.sourceData[i])
+ except UnicodeDecodeError:
+ # osgeo4w problem (should be fixed)
+ pass
self.Populate(data)
if len(data) > 0:
return data[0]
else:
@@ -1251,7 +1255,7 @@
# buttons
self.bbrowse = self.MakeButton(_("Browse"))
- self.bbcodes = self.MakeButton(_("Browse EPSG Codes"))
+ self.bbcodes = self.MakeButton(_("Reload EPSG Codes"))
# search box
self.searchb = wx.SearchCtrl(self, size=(200,-1),
@@ -1352,15 +1356,15 @@
self.epsgdesc = self.epsgparams = ''
def OnSearch(self, event):
- str = self.searchb.GetValue()
+ value = self.searchb.GetValue()
if self.epsglist.GetItemCount() == 0:
event.Skip()
return
try:
- self.epsgcode = self.epsglist.Search(index=1, str=str)[0]
+ self.epsgcode = self.epsglist.Search(index=1, str=value)[0]
self.tcode.SetValue(str(self.epsgcode))
- except:
+ except IndexError:
self.epsgcode = None
self.tcode.SetValue('')
