[GRASS-SVN] r36359 -
grass/branches/releasebranch_6_4/vector/v.surf.rst
svn_grass at osgeo.org
Fri Mar 13 11:58:40 EDT 2009
Author: martinl
Date: 2009-03-13 11:58:40 -0400 (Fri, 13 Mar 2009)
New Revision: 36359
grass/branches/releasebranch_6_4/vector/v.surf.rst/main.c
v.surt.rst: parameters/sections reordered to less tabs
(merge from trunk, r36353)
Modified: grass/branches/releasebranch_6_4/vector/v.surf.rst/main.c
--- grass/branches/releasebranch_6_4/vector/v.surf.rst/main.c 2009-03-13 15:57:26 UTC (rev 36358)
+++ grass/branches/releasebranch_6_4/vector/v.surf.rst/main.c 2009-03-13 15:58:40 UTC (rev 36359)
@@ -187,17 +187,18 @@
flag.cv->key = 'c';
flag.cv->description =
_("Perform cross-validation procedure without raster approximation");
+ flag.cv->guisection = _("Parameters");
flag.cprght = G_define_flag();
flag.cprght->key = 't';
flag.cprght->description = _("Use scale dependent tension");
- flag.cprght->guisection = _("Settings");
+ flag.cprght->guisection = _("Parameters");
flag.deriv = G_define_flag();
flag.deriv->key = 'd';
flag.deriv->description =
_("Output partial derivatives instead of topographic parameters");
- flag.deriv->guisection = _("Output_options");
+ flag.deriv->guisection = _("Outputs");
parm.input = G_define_standard_option(G_OPT_V_INPUT);
@@ -206,70 +207,104 @@
_("If set to 0, z coordinates are used. (3D vector only)");
parm.field->answer = "1";
parm.field->gisprompt = "old_layer,layer,layer_zero";
+ parm.field->guisection = _("Selection");
- parm.zcol = G_define_option();
- parm.zcol->key = "zcolumn";
- parm.zcol->type = TYPE_STRING;
- parm.zcol->required = NO;
- parm.zcol->description =
- _("Name of the attribute column with values to be used for approximation (if layer>0)");
parm.wheresql = G_define_standard_option(G_OPT_WHERE);
+ parm.wheresql->guisection = _("Selection");
parm.elev = G_define_standard_option(G_OPT_R_OUTPUT);
parm.elev->key = "elev";
parm.elev->required = NO;
parm.elev->description = _("Output surface raster map (elevation)");
+ parm.elev->guisection = _("Outputs");
parm.slope = G_define_standard_option(G_OPT_R_OUTPUT);
parm.slope->key = "slope";
parm.slope->required = NO;
parm.slope->description = _("Output slope raster map");
- parm.slope->guisection = _("Output_options");
+ parm.slope->guisection = _("Outputs");
parm.aspect = G_define_standard_option(G_OPT_R_OUTPUT);
parm.aspect->key = "aspect";
parm.aspect->required = NO;
parm.aspect->description = _("Output aspect raster map");
- parm.aspect->guisection = _("Output_options");
+ parm.aspect->guisection = _("Outputs");
parm.pcurv = G_define_standard_option(G_OPT_R_OUTPUT);
parm.pcurv->key = "pcurv";
parm.pcurv->required = NO;
parm.pcurv->description = _("Output profile curvature raster map");
- parm.pcurv->guisection = _("Output_options");
+ parm.pcurv->guisection = _("Outputs");
parm.tcurv = G_define_standard_option(G_OPT_R_OUTPUT);
parm.tcurv->key = "tcurv";
parm.tcurv->required = NO;
parm.tcurv->description = _("Output tangential curvature raster map");
- parm.tcurv->guisection = _("Output_options");
+ parm.tcurv->guisection = _("Outputs");
parm.mcurv = G_define_standard_option(G_OPT_R_OUTPUT);
parm.mcurv->key = "mcurv";
parm.mcurv->required = NO;
parm.mcurv->description = _("Output mean curvature raster map");
- parm.mcurv->guisection = _("Output_options");
+ parm.mcurv->guisection = _("Outputs");
+ parm.devi = G_define_option();
+ parm.devi->key = "devi";
+ parm.devi->type = TYPE_STRING;
+ parm.devi->required = NO;
+ parm.devi->gisprompt = "new,vector,vector";
+ parm.devi->description = _("Output deviations vector point file");
+ parm.devi->guisection = _("Outputs");
+ parm.cvdev = G_define_standard_option(G_OPT_V_OUTPUT);
+ parm.cvdev->key = "cvdev";
+ parm.cvdev->required = NO;
+ parm.cvdev->description =
+ _("Output cross-validation errors vector point file");
+ parm.cvdev->guisection = _("Outputs");
+ parm.treefile = G_define_standard_option(G_OPT_V_OUTPUT);
+ parm.treefile->key = "treefile";
+ parm.treefile->required = NO;
+ parm.treefile->description =
+ _("Output vector map showing quadtree segmentation");
+ parm.treefile->guisection = _("Outputs");
+ parm.overfile = G_define_standard_option(G_OPT_V_OUTPUT);
+ parm.overfile->key = "overfile";
+ parm.overfile->required = NO;
+ parm.overfile->description =
+ _("Output vector map showing overlapping windows");
+ parm.overfile->guisection = _("Outputs");
parm.maskmap = G_define_standard_option(G_OPT_R_INPUT);
parm.maskmap->key = "maskmap";
parm.maskmap->required = NO;
parm.maskmap->description = _("Name of the raster map used as mask");
+ parm.maskmap->guisection = _("Parameters");
+ parm.zcol = G_define_option();
+ parm.zcol->key = "zcolumn";
+ parm.zcol->type = TYPE_STRING;
+ parm.zcol->required = NO;
+ parm.zcol->description =
+ _("Name of the attribute column with values to be used for approximation (if layer>0)");
+ parm.zcol->guisection = _("Parameters");
parm.fi = G_define_option();
parm.fi->key = "tension";
parm.fi->type = TYPE_DOUBLE;
parm.fi->answer = TENSION;
parm.fi->required = NO;
parm.fi->description = _("Tension parameter");
- parm.fi->guisection = _("Settings");
+ parm.fi->guisection = _("Parameters");
parm.rsm = G_define_option();
parm.rsm->key = "smooth";
parm.rsm->type = TYPE_DOUBLE;
parm.rsm->required = NO;
parm.rsm->description = _("Smoothing parameter");
- parm.rsm->guisection = _("Settings");
+ parm.rsm->guisection = _("Parameters");
parm.scol = G_define_option();
parm.scol->key = "scolumn";
@@ -277,7 +312,7 @@
parm.scol->required = NO;
parm.scol->description =
_("Name of the attribute column with smoothing parameters");
- parm.scol->guisection = _("Settings");
+ parm.scol->guisection = _("Parameters");
parm.segmax = G_define_option();
parm.segmax->key = "segmax";
@@ -285,7 +320,7 @@
parm.segmax->answer = MAXSEGM;
parm.segmax->required = NO;
parm.segmax->description = _("Maximum number of points in a segment");
- parm.segmax->guisection = _("Settings");
+ parm.segmax->guisection = _("Parameters");
parm.npmin = G_define_option();
parm.npmin->key = "npmin";
@@ -294,7 +329,7 @@
parm.npmin->required = NO;
parm.npmin->description =
_("Minimum number of points for approximation in a segment (>segmax)");
- parm.npmin->guisection = _("Settings");
+ parm.npmin->guisection = _("Parameters");
parm.dmin = G_define_option();
parm.dmin->key = "dmin";
@@ -303,7 +338,7 @@
parm.dmin->answer = dminchar;
parm.dmin->description =
_("Minimum distance between points (to remove almost identical points)");
- parm.dmin->guisection = _("Settings");
+ parm.dmin->guisection = _("Parameters");
parm.dmax = G_define_option();
parm.dmax->key = "dmax";
@@ -312,7 +347,7 @@
parm.dmax->answer = dmaxchar;
parm.dmax->description =
_("Maximum distance between points on isoline (to insert additional points)");
- parm.dmax->guisection = _("Settings");
+ parm.dmax->guisection = _("Parameters");
parm.zmult = G_define_option();
parm.zmult->key = "zmult";
@@ -321,51 +356,22 @@
parm.zmult->required = NO;
parm.zmult->description =
_("Conversion factor for values used for approximation");
- parm.zmult->guisection = _("Settings");
+ parm.zmult->guisection = _("Parameters");
- parm.devi = G_define_option();
- parm.devi->key = "devi";
- parm.devi->type = TYPE_STRING;
- parm.devi->required = NO;
- parm.devi->gisprompt = "new,vector,vector";
- parm.devi->description = _("Output deviations vector point file");
- parm.devi->guisection = _("Analysis");
- parm.cvdev = G_define_standard_option(G_OPT_V_OUTPUT);
- parm.cvdev->key = "cvdev";
- parm.cvdev->required = NO;
- parm.cvdev->description =
- _("Output cross-validation errors vector point file");
- parm.cvdev->guisection = _("Analysis");
- parm.treefile = G_define_standard_option(G_OPT_V_OUTPUT);
- parm.treefile->key = "treefile";
- parm.treefile->required = NO;
- parm.treefile->description =
- _("Output vector map showing quadtree segmentation");
- parm.treefile->guisection = _("Analysis");
- parm.overfile = G_define_standard_option(G_OPT_V_OUTPUT);
- parm.overfile->key = "overfile";
- parm.overfile->required = NO;
- parm.overfile->description =
- _("Output vector map showing overlapping windows");
- parm.overfile->guisection = _("Analysis");
parm.theta = G_define_option();
parm.theta->key = "theta";
parm.theta->type = TYPE_DOUBLE;
parm.theta->required = NO;
parm.theta->description =
_("Anisotropy angle (in degrees counterclockwise from East)");
- parm.theta->guisection = _("Anisotropy");
+ parm.theta->guisection = _("Parameters");
parm.scalex = G_define_option();
parm.scalex->key = "scalex";
parm.scalex->type = TYPE_DOUBLE;
parm.scalex->required = NO;
parm.scalex->description = _("Anisotropy scaling factor");
- parm.scalex->guisection = _("Anisotropy");
+ parm.scalex->guisection = _("Parameters");
if (G_parser(argc, argv))
