[GRASS-SVN] r36438 - grass/trunk/gui/wxpython/docs
svn_grass at osgeo.org
Fri Mar 20 09:57:39 EDT 2009
Author: martinl
Date: 2009-03-20 09:57:38 -0400 (Fri, 20 Mar 2009)
New Revision: 36438
grass/trunk/gui/wxpython/docs/wxGUI.Nviz.html
grass/trunk/gui/wxpython/docs/wxGUI.Vector_Digitizing_Tool.html
wxGUI: note "experimental prototype in manual pages of vdigit and nviz extensions"
(merge from devbr6, r36437)
Modified: grass/trunk/gui/wxpython/docs/wxGUI.Nviz.html
--- grass/trunk/gui/wxpython/docs/wxGUI.Nviz.html 2009-03-20 13:55:41 UTC (rev 36437)
+++ grass/trunk/gui/wxpython/docs/wxGUI.Nviz.html 2009-03-20 13:57:38 UTC (rev 36438)
@@ -251,6 +251,10 @@
<li>...</li>
</ul>
+<p>
+<b>Please note that the wxGUI Nviz extension is under active development and
+distributed as "Experimental Prototype".</b>
<h2>SEE ALSO</h2>
See also <a href="http://grass.osgeo.org/wiki/WxNVIZ">Wiki</a> page.
Modified: grass/trunk/gui/wxpython/docs/wxGUI.Vector_Digitizing_Tool.html
--- grass/trunk/gui/wxpython/docs/wxGUI.Vector_Digitizing_Tool.html 2009-03-20 13:55:41 UTC (rev 36437)
+++ grass/trunk/gui/wxpython/docs/wxGUI.Vector_Digitizing_Tool.html 2009-03-20 13:57:38 UTC (rev 36438)
@@ -34,27 +34,8 @@
digitizer toolbar also allows switching easily between vector maps to be
edited.
-<h2>NOTES</h2>
+<h3>DIGITIZER TOOLBAR</h3>
-<i>Dead (deleted)</i> are internally only marked in the geometry file
-as 'dead' but it remains there and occupies space. Any vector module
-used afterwards on this vector map which really reads and writes
-vector geometry (so not <em><a href="g.copy.html">g.copy</a></em>)
-will writes only features which are 'alive'.
-<p>
-<i>Added or modified</i> vector features are <i>snapped</i> to
-existing vector features ('Settings->General->Snapping', nodes or vertices)
-based on 'Settings->General->Snapping threshold' value. To
-disable snapping set the snapping threshold to '0'.
-<p>
-If the digitizer crashes for some reason you can repair the vector map
-which was left open with the <em>v.build</em> module.
-<h2>Digitizer toolbar</h2>
<center>
<br><img src="wxGUI_vector_digitizer_toolbar.jpg" border="1"><br><br>
</center>
@@ -221,6 +202,28 @@
</dl>
+<h2>NOTES</h2>
+<i>Dead (deleted)</i> are internally only marked in the geometry file
+as 'dead' but it remains there and occupies space. Any vector module
+used afterwards on this vector map which really reads and writes
+vector geometry (so not <em><a href="g.copy.html">g.copy</a></em>)
+will writes only features which are 'alive'.
+<p>
+<i>Added or modified</i> vector features are <i>snapped</i> to
+existing vector features ('Settings->General->Snapping', nodes or vertices)
+based on 'Settings->General->Snapping threshold' value. To
+disable snapping set the snapping threshold to '0'.
+<p>
+If the digitizer crashes for some reason you can repair the vector map
+which was left open with the <em>v.build</em> module.
+<p>
+<b>Please note that vector digitizer is under active development and
<h2>SEE ALSO</h2>
<em>
