[GRASS-SVN] r36458 - grass/branches/releasebranch_6_3/vector/lidar/v.surf.bspline
Mon Mar 23 10:32:11 EDT 2009
Author: neteler
Date: 2009-03-23 10:32:11 -0400 (Mon, 23 Mar 2009)
New Revision: 36458
   grass/branches/releasebranch_6_3/vector/lidar/v.surf.bspline/crosscorr.c
   grass/branches/releasebranch_6_3/vector/lidar/v.surf.bspline/main.c
src code formatted with grass_indent.sh
Modified: grass/branches/releasebranch_6_3/vector/lidar/v.surf.bspline/crosscorr.c
--- grass/branches/releasebranch_6_3/vector/lidar/v.surf.bspline/crosscorr.c	2009-03-23 14:22:02 UTC (rev 36457)
+++ grass/branches/releasebranch_6_3/vector/lidar/v.surf.bspline/crosscorr.c	2009-03-23 14:32:11 UTC (rev 36458)
@@ -1,3 +1,4 @@
  * MODULE:       v.surf.bspline
@@ -16,30 +17,23 @@
-/*INCLUDES*/
-#include <stdlib.h>
-#include <string.h>
+ /*INCLUDES*/
+#include <stdlib.h>
+#include <string.h>
 #include <grass/gis.h>
 #include <grass/Vect.h>
 #include <grass/dbmi.h>
 #include <grass/glocale.h>
 #include <grass/config.h>
 #include <grass/PolimiFunct.h>
 #include "bspline.h"
 #define NDATA_MAX 100
 #define PARAM_LAMBDA 6
 #define PARAM_SPLINE 0
 #define SWAP(a, b) {double t=a; a=b; b=t;}
-    int
-cross_correlation (struct Map_info* Map, double passWE, double passNS)
+int cross_correlation(struct Map_info *Map, double passWE, double passNS)
        Map: Map in which cross crorrelation will take values
        passWE: spline step in West-East direction
@@ -49,119 +43,129 @@
        TRUE on success
        FALSE on failure
-    int bilin=TRUE;					/*booleans*/
+    int bilin = TRUE;		/*booleans */
     int nsplx, nsply, nparam_spl, ndata;
-    double *mean, *rms, *stdev, rms_min, stdev_min;
+    double *mean, *rms, *stdev, rms_min, stdev_min;
-    double lambda[PARAM_LAMBDA] = {0.0001, 0.001, 0.01, 0.1, 1.0, 10.0};  	/* Fixed values (by the moment) */
+    double lambda[PARAM_LAMBDA] = { 0.0001, 0.001, 0.01, 0.1, 1.0, 10.0 };	/* Fixed values (by the moment) */
-    double *TN, *Q, *parVect;			/* Interpolation and least-square vectors*/
-    double **N, **obsVect;			/* Interpolation and least-square matrix*/
+    double *TN, *Q, *parVect;	/* Interpolation and least-square vectors */
+    double **N, **obsVect;	/* Interpolation and least-square matrix */
     struct Point *observ;
     struct Stats stat_vect;
-    /*struct line_pnts *points;*/
-    /*struct line_cats *Cats;*/
+    /*struct line_pnts *points; */
+    /*struct line_cats *Cats; */
     struct Cell_head region;
-    G_get_window (&region);
+    G_get_window(&region);
     extern int bspline_field;
     extern char *bspline_column;
     dbCatValArray cvarr;
-    G_debug (5, "CrossCorrelation: Some tests using different lambda_i values will be done");
+    G_debug(5,
+	    "CrossCorrelation: Some tests using different lambda_i values will be done");
-    ndata = Vect_get_num_lines (Map);
+    ndata = Vect_get_num_lines(Map);
-    if (ndata > NDATA_MAX)
-	G_warning (_("CrossCorrelation: %d are too many points. "
+    if (ndata > NDATA_MAX)
+	G_warning(_("CrossCorrelation: %d are too many points. "
 		    "The cross validation would take too much time"), ndata);
-    /*points = Vect_new_line_struct ();*/
-    /*Cats = Vect_new_cats_struct ();*/
+    /*points = Vect_new_line_struct (); */
+    /*Cats = Vect_new_cats_struct (); */
     /* Current region is read and points recorded into observ */
-    observ = P_Read_Vector_Region_Map (Map, &region, &ndata, 1024, 1);
-    G_debug (5, "CrossCorrelation: %d points read in region. ", ndata);
-    fprintf (stdout, _("CrossCorrelation: %d points read in region.\n"), ndata);
-    if (ndata > 50)
-	G_warning (_("CrossCorrelation: Maybe, it takes too long. "
+    observ = P_Read_Vector_Region_Map(Map, &region, &ndata, 1024, 1);
+    G_debug(5, "CrossCorrelation: %d points read in region. ", ndata);
+    fprintf(stdout, _("CrossCorrelation: %d points read in region.\n"),
+	    ndata);
+    if (ndata > 50)
+	G_warning(_("CrossCorrelation: Maybe, it takes too long. "
 		    "It will depend on how many points you are considering"));
-    else
-	G_debug (5, "CrossCorrelation: It shouldn't take too long.");
+    else
+	G_debug(5, "CrossCorrelation: It shouldn't take too long.");
-    if (ndata > 0) {			/* If at least one point is in the region */
-	int i, j, lbd;			/* lbd: lambda index */
-	int BW, lbd_min	;		/* lbd_min: index where minimun is found */
+    if (ndata > 0) {		/* If at least one point is in the region */
+	int i, j, lbd;		/* lbd: lambda index */
+	int BW, lbd_min;	/* lbd_min: index where minimun is found */
 	double mean_reg, *obs_mean;
 	int nrec, ctype = 0;
 	struct field_info *Fi;
 	dbDriver *driver_cats;
-	mean = G_alloc_vector (PARAM_LAMBDA);	/* Alloc as much mean, rms and stdev values as the total*/
-	rms = G_alloc_vector (PARAM_LAMBDA);	/* number of parameter used used for cross validation*/
-	stdev = G_alloc_vector (PARAM_LAMBDA);
+	mean = G_alloc_vector(PARAM_LAMBDA);	/* Alloc as much mean, rms and stdev values as the total */
+	rms = G_alloc_vector(PARAM_LAMBDA);	/* number of parameter used used for cross validation */
+	stdev = G_alloc_vector(PARAM_LAMBDA);
-	/* Working with attributes*/
+	/* Working with attributes */
 	if (bspline_field > 0) {
-	    db_CatValArray_init ( &cvarr );
+	    db_CatValArray_init(&cvarr);
-	    Fi = Vect_get_field (Map, bspline_field);
-	    if ( Fi == NULL )
-		G_fatal_error (_("CrossCorrelation: Cannot read field info"));
+	    Fi = Vect_get_field(Map, bspline_field);
+	    if (Fi == NULL)
+		G_fatal_error(_("CrossCorrelation: Cannot read field info"));
-	    driver_cats = db_start_driver_open_database ( Fi->driver, Fi->database );
-	    G_debug (1, _("CrossCorrelation: driver=%s db=%s"), Fi->driver, Fi->database);
+	    driver_cats =
+		db_start_driver_open_database(Fi->driver, Fi->database);
+	    G_debug(1, _("CrossCorrelation: driver=%s db=%s"), Fi->driver,
+		    Fi->database);
-	    if ( driver_cats == NULL )
-		G_fatal_error(_("CrossCorrelation: Cannot open database %s by driver %s"), Fi->database, Fi->driver);
+	    if (driver_cats == NULL)
+		G_fatal_error(_("CrossCorrelation: Cannot open database %s by driver %s"),
+			      Fi->database, Fi->driver);
-	    nrec = db_select_CatValArray ( driver_cats, Fi->table, Fi->key, bspline_column, NULL, &cvarr );
-	    G_debug (3, "nrec = %d", nrec );
+	    nrec =
+		db_select_CatValArray(driver_cats, Fi->table, Fi->key,
+				      bspline_column, NULL, &cvarr);
+	    G_debug(3, "nrec = %d", nrec);
 	    ctype = cvarr.ctype;
-	    if ( ctype != DB_C_TYPE_INT && ctype != DB_C_TYPE_DOUBLE )
-		G_fatal_error ( _("CrossCorrelation: Column type not supported") );
+	    if (ctype != DB_C_TYPE_INT && ctype != DB_C_TYPE_DOUBLE)
+		G_fatal_error(_("CrossCorrelation: Column type not supported"));
-	    if ( nrec < 0 )
-		G_fatal_error (_("CrossCorrelation: Cannot select data from table"));
+	    if (nrec < 0)
+		G_fatal_error(_("CrossCorrelation: Cannot select data from table"));
-	    G_message ( _("CrossCorrelation: %d records selected from table"), nrec);
+	    G_message(_("CrossCorrelation: %d records selected from table"),
+		      nrec);
-	    db_close_database_shutdown_driver (driver_cats);
+	    db_close_database_shutdown_driver(driver_cats);
 	/* Setting number of splines as a function of WE and SN spline steps */
-	nsplx = ceil ((region.east - region.west)/passWE);
-	nsply = ceil ((region.north - region.south)/passNS);
-	nparam_spl = nsplx * nsply; 	/* Total number of splines */
+	nsplx = ceil((region.east - region.west) / passWE);
+	nsply = ceil((region.north - region.south) / passNS);
+	nparam_spl = nsplx * nsply;	/* Total number of splines */
 	if (nparam_spl > 22900)
-	    G_fatal_error (_("CrossCorrelation: Too many splines (%d x %d). "
-			"Consider changing spline steps \"sie=\" \"sin=\"."), nsplx, nsply);
+	    G_fatal_error(_("CrossCorrelation: Too many splines (%d x %d). "
+			    "Consider changing spline steps \"sie=\" \"sin=\"."),
+			  nsplx, nsply);
-	BW = P_get_BandWidth (bilin, nsply); 	/**/
+	BW = P_get_BandWidth(bilin, nsply);
+	    /*Least Squares system */
+	    N = G_alloc_matrix(nparam_spl, BW);	/* Normal matrix */
+	TN = G_alloc_vector(nparam_spl);	/* vector */
+	parVect = G_alloc_vector(nparam_spl);	/* Parameters vector */
+	obsVect = G_alloc_matrix(ndata, 3);	/* Observation vector */
+	Q = G_alloc_vector(ndata);	/* "a priori" var-cov matrix */
-	/*Least Squares system*/
-	N = G_alloc_matrix (nparam_spl, BW);		/* Normal matrix */
-	TN = G_alloc_vector (nparam_spl);		/* vector */
-	parVect = G_alloc_vector (nparam_spl);		/* Parameters vector */
-	obsVect = G_alloc_matrix (ndata, 3);	 	/* Observation vector */
-	Q = G_alloc_vector (ndata);			/* "a priori" var-cov matrix */
+	obs_mean = G_alloc_vector(ndata);
+	stat_vect = alloc_Stats(ndata);
-	obs_mean = G_alloc_vector (ndata);
- 	stat_vect = alloc_Stats (ndata);
+	for (lbd = 0; lbd < PARAM_LAMBDA; lbd++) {	/* For each lambda value */
-	for (lbd=0; lbd < PARAM_LAMBDA; lbd++) {	/* For each lambda value */
+	    fprintf(stdout,
+		    _("CrossCorrelation: Begining cross validation with "
+		      "lambda_i=%.4f ...\n"), lambda[lbd]);
-	    fprintf (stdout, _("CrossCorrelation: Begining cross validation with "
-			"lambda_i=%.4f ...\n"), lambda[lbd]);
 	       How cross correlation algorithm is done:
 	       For each cicle, only the first ndata-1 "observ" elements are considered for the
@@ -171,208 +175,242 @@
 	       At the end of the cicle, the last point, that is, the ndata-1 index, and the point
 	       with j index are swapped.
-	    for (j=0; j<ndata; j++) {			/* Cross Correlation will use all ndata points*/
-		double out_x, out_y, out_z;		/* This point is let out */
-		for (i=0; i<ndata; i++) {		/* Each time, only the first ndata-1 points */
-		    double dval;			/* are considered in the interpolation*/
+	    for (j = 0; j < ndata; j++) {	/* Cross Correlation will use all ndata points */
+		double out_x, out_y, out_z;	/* This point is let out */
+		for (i = 0; i < ndata; i++) {	/* Each time, only the first ndata-1 points */
+		    double dval;	/* are considered in the interpolation */
 		    /* Setting obsVect vector & Q matrix */
-		    Q[i] = 1;					/* Q=I */
+		    Q[i] = 1;	/* Q=I */
 		    obsVect[i][0] = observ[i].coordX;
 		    obsVect[i][1] = observ[i].coordY;
-		    if (bspline_field > 0){
+		    if (bspline_field > 0) {
 			int cat, ival, ret;
-			/*type = Vect_read_line (Map, points, Cats, observ[i].lineID);*/
-			/*if ( !(type & GV_POINTS ) ) continue;*/
+			/*type = Vect_read_line (Map, points, Cats, observ[i].lineID); */
+			/*if ( !(type & GV_POINTS ) ) continue; */
-			/*Vect_cat_get ( Cats, bspline_field, &cat );*/
+			/*Vect_cat_get ( Cats, bspline_field, &cat ); */
 			cat = observ[i].cat;
-			if ( cat < 0 ) continue;
+			if (cat < 0)
+			    continue;
-			if ( ctype == DB_C_TYPE_INT ) {
-			    ret = db_CatValArray_get_value_int ( &cvarr, cat, &ival );
+			if (ctype == DB_C_TYPE_INT) {
+			    ret =
+				db_CatValArray_get_value_int(&cvarr, cat,
+							     &ival);
 			    obsVect[i][2] = ival;
-			    obs_mean [i]= ival;
-			} else {		 /* DB_C_TYPE_DOUBLE */
-			    ret = db_CatValArray_get_value_double ( &cvarr, cat, &dval );
+			    obs_mean[i] = ival;
+			else {	/* DB_C_TYPE_DOUBLE */
+			    ret =
+				db_CatValArray_get_value_double(&cvarr, cat,
+								&dval);
 			    obsVect[i][2] = dval;
-			    obs_mean [i] = dval;
+			    obs_mean[i] = dval;
-			if ( ret != DB_OK ) {
-			    G_warning (_("CrossCorrelation: No record for point (cat = %d)"), cat);
+			if (ret != DB_OK) {
+			    G_warning(_("CrossCorrelation: No record for point (cat = %d)"),
+				      cat);
 			    continue;
-		    else {
-			obsVect[i][2] = observ[i].coordZ;
-			obs_mean [i] = observ[i].coordZ;
+		    else {
+			obsVect[i][2] = observ[i].coordZ;
+			obs_mean[i] = observ[i].coordZ;
-		} /* i index */
+		}		/* i index */
 		/* Mean calculation for every point less the last one */
-		mean_reg = calc_mean (obs_mean, ndata-1);
+		mean_reg = calc_mean(obs_mean, ndata - 1);
 		    obsVect[i][2] -= mean_reg;
 		/* This is let out */
-		out_x = observ[ndata-1].coordX;
-		out_y = observ[ndata-1].coordY;
-		out_z = obsVect[ndata-1][2];
+		out_x = observ[ndata - 1].coordX;
+		out_y = observ[ndata - 1].coordY;
+		out_z = obsVect[ndata - 1][2];
-		if (bilin) {		/* Bilinear interpolation */
-		    normalDefBilin (N, TN, Q, obsVect, passWE, passNS, nsplx, nsply, region.west,
-			    region.south, ndata-1, nparam_spl, BW);
-		    nCorrectGrad (N, lambda[lbd], nsplx, nsply, passWE, passNS);
-		else {			/* Bicubic interpolation */
-		    normalDefBicubic (N, TN, Q, obsVect, passWE, passNS, nsplx, nsply, region.west,
+		if (bilin) {	/* Bilinear interpolation */
+		    normalDefBilin(N, TN, Q, obsVect, passWE, passNS, nsplx,
+				   nsply, region.west, region.south,
+				   ndata - 1, nparam_spl, BW);
+		    nCorrectGrad(N, lambda[lbd], nsplx, nsply, passWE,
+				 passNS);
+		else {		/* Bicubic interpolation */
+		    normalDefBicubic(N, TN, Q, obsVect, passWE, passNS, nsplx,
+				 passNS);
 		   if (bilin) interpolation (&interp, P_BILINEAR);
 		   else interpolation (&interp, P_BICUBIC);
-		tcholSolve (N, TN, parVect, nparam_spl, BW);
+		tcholSolve(N, TN, parVect, nparam_spl, BW);
 		/* Estimation of j-point */
-		if (bilin)
-		    stat_vect.estima[j] = dataInterpolateBilin (out_x, out_y, passWE, passNS,
-			    nsplx, nsply, region.west, region.south, parVect);
+		if (bilin)
+		    stat_vect.estima[j] =
+			dataInterpolateBilin(out_x, out_y, passWE, passNS,
+					     nsplx, nsply, region.west,
+					     region.south, parVect);
-		else
+		else
-		/*Difference between estimated and observated i-point*/
+		/*Difference between estimated and observated i-point */
 		stat_vect.error[j] = out_z - stat_vect.estima[j];
-		G_debug (1, "CrossCorrelation: stat_vect.error[%d]  =  %lf", j, stat_vect.error[j]);
+		G_debug(1, "CrossCorrelation: stat_vect.error[%d]  =  %lf", j,
+			stat_vect.error[j]);
-		observ = swap (observ, j, ndata-1);	/* Once the last value is let out, it is swap with j-value */
+		observ = swap(observ, j, ndata - 1);	/* Once the last value is let out, it is swap with j-value */
-	    mean[lbd] = calc_mean (stat_vect.error, stat_vect.n_points);
-	    rms[lbd] = calc_root_mean_square (stat_vect.error, stat_vect.n_points);
-	    stdev[lbd] = calc_standard_deviation (stat_vect.error, stat_vect.n_points);
+	    mean[lbd] = calc_mean(stat_vect.error, stat_vect.n_points);
+	    rms[lbd] =
+		calc_root_mean_square(stat_vect.error, stat_vect.n_points);
+	    stdev[lbd] =
+		calc_standard_deviation(stat_vect.error, stat_vect.n_points);
-	    fprintf (stdout, _("CrossCorrelation: Mean = %.5lf\n"), mean[lbd]);
-	    fprintf (stdout, _("CrossCorrelation: Root Means Square (RMS) = %.5lf\n"), rms[lbd]);
-	    fprintf (stdout, "\n---------------------o-o-------------------\n\n");
-	}	/* ENDFOR each lambda value */
+	    fprintf(stdout, _("CrossCorrelation: Mean = %.5lf\n"), mean[lbd]);
+	    fprintf(stdout,
+		    _("CrossCorrelation: Root Means Square (RMS) = %.5lf\n"),
+		    rms[lbd]);
+	    fprintf(stdout,
+		    "\n---------------------o-o-------------------\n\n");
+	}			/* ENDFOR each lambda value */
-	G_free_matrix (N);
-	G_free_vector (TN);
-	G_free_vector (Q);
-	G_free_matrix (obsVect);
-	G_free_vector (parVect);
+	G_free_matrix(N);
+	G_free_vector(TN);
+	G_free_vector(Q);
+	G_free_matrix(obsVect);
+	G_free_vector(parVect);
 #ifdef nodef
-	/*TODO: if the minimum lambda is wanted, the function declaration must be changed*/
-	/*At this moment, consider rms only*/
-	rms_min = find_minimum (rms, &lbd_min);
-	stdev_min = find_minimum (stdev, &lbd_min);
+	/*TODO: if the minimum lambda is wanted, the function declaration must be changed */
+	/*At this moment, consider rms only */
+	rms_min = find_minimum(rms, &lbd_min);
+	stdev_min = find_minimum(stdev, &lbd_min);
-	/* Writing some output*/
-	fprintf (stdout, _("CrossCorrelation: Different number of splines and lambda_i values have " \
-		    "been taken for the cross correlation\n"));
-	fprintf (stdout, _("CrossCorrelation: The minimum value for the test (rms=%lf) was obtained with:\n"), rms_min);
-	fprintf (stdout, _("CrossCorrelation: lambda_i = %.3f\n"), lambda[lbd_min]);
+	/* Writing some output */
+	fprintf(stdout,
+		_("CrossCorrelation: Different number of splines and lambda_i values have "
+		 "been taken for the cross correlation\n"));
+	fprintf(stdout,
+		_("CrossCorrelation: The minimum value for the test (rms=%lf) was obtained with:\n"),
+		rms_min);
+	fprintf(stdout, _("CrossCorrelation: lambda_i = %.3f\n"),
+		lambda[lbd_min]);
 	*lambda_min = lambda[lbd_min];
 #endif
-	fprintf (stdout, _("Now, the results into a table:\n"));
-	fprintf (stdout, _(" lambda    | mean        | rms         |\n"));
-	    fprintf (stdout, _(" %-10.5f| %-12.4f| %-12.4f|\n"),lambda[lbd], mean[lbd], rms[lbd]);
+	fprintf(stdout, _("Now, the results into a table:\n"));
+	fprintf(stdout, _(" lambda    | mean        | rms         |\n"));
+	    fprintf(stdout, _(" %-10.5f| %-12.4f| %-12.4f|\n"), lambda[lbd],
+		    mean[lbd], rms[lbd]);
-	fprintf (stdout, _("\nResults are over.\n"));
+	fprintf(stdout, _("\nResults are over.\n"));
-	G_free_vector (mean);
-	G_free_vector (rms);
-     }	/* ENDIF (ndata > 0) */
-     else
-	G_warning (_("CrossCorrelation: No point lies into the current region"));
+	G_free_vector(mean);
+	G_free_vector(rms);
+    }				/* ENDIF (ndata > 0) */
+    else
+	G_warning(_("CrossCorrelation: No point lies into the current region"));
-    G_free (observ);
+    G_free(observ);
     return TRUE;
 #ifdef nodef
-void interpolation (struct ParamInterp *interp, boolean bilin) {
+void interpolation(struct ParamInterp *interp, boolean bilin)
     if (bilin == P_BILINEAR) {	/* Bilinear interpolation */
-	normalDefBilin (interp->N, interp->TN, interp->Q, interp->obsVect, interp->passoE,
-		interp->passoN, interp->nsplx, interp->nsply, interp->region.west,
-		interp->region.south, interp->ndata, interp->nparam_spl, interp->BW);
+	normalDefBilin(interp->N, interp->TN, interp->Q, interp->obsVect,
+		       interp->passoE, interp->passoN, interp->nsplx,
+		       interp->nsply, interp->region.west,
+		       interp->region.south, interp->ndata,
+		       interp->nparam_spl, interp->BW);
-	nCorrectGrad (interp->N, interp->lambda[lbd], interp->nsplx, interp->nsply,
-		interp->passoE, interp->passoN);
-	normalDefBicubic (interp->N, interp->TN, interp->Q, interp->obsVect, interp->passoE,
+	nCorrectGrad(interp->N, interp->lambda[lbd], interp->nsplx,
+		     interp->nsply, interp->passoE, interp->passoN);
+	normalDefBicubic(interp->N, interp->TN, interp->Q, interp->obsVect,
-    return TRUE;
+    return TRUE;
 #endif
-double
-calc_mean (double *values, int nvalues) {
+double calc_mean(double *values, int nvalues)
     int i;
-    double sum=.0;
+    double sum = .0;
-    if (nvalues == 0) return .0;
-    for (i=0; i < nvalues; i++)
+    if (nvalues == 0)
+	return .0;
+    for (i = 0; i < nvalues; i++)
 	sum += values[i];
-    return sum/nvalues;
+    return sum / nvalues;
-double
-calc_root_mean_square (double *values, int nvalues) {
+double calc_root_mean_square(double *values, int nvalues)
     int i;
-    double rms, sum=.0;
+    double rms, sum = .0;
+    if (nvalues == 0)
+	return .0;
-	sum += pow (values[i], 2)/nvalues;
+	sum += pow(values[i], 2) / nvalues;
     rms = sqrt(sum);
-    return  rms;
+    return rms;
-double
-calc_standard_deviation (double *values, int nvalues) {
+double calc_standard_deviation(double *values, int nvalues)
     double mean, rms, stdev;
-    if ( nvalues == 0) return .0;
+    if (nvalues == 0)
+	return .0;
-    rms = calc_root_mean_square (values, nvalues);
-    mean = calc_mean (values, nvalues);
+    rms = calc_root_mean_square(values, nvalues);
+    mean = calc_mean(values, nvalues);
-    stdev = sqrt (pow(rms, 2) - pow(mean, 2));
+    stdev = sqrt(pow(rms, 2) - pow(mean, 2));
     return stdev;
-struct
-Stats alloc_Stats (int n) {
-    double *err, *stm;
+struct Stats alloc_Stats(int n)
+    double *err, *stm;
     struct Stats stat;
     stat.n_points = n;
-    err = (double *) G_calloc (n, sizeof(double));
-    stm = (double *) G_calloc (n, sizeof(double));
+    err = (double *)G_calloc(n, sizeof(double));
+    stm = (double *)G_calloc(n, sizeof(double));
     stat.error = err;
     stat.estima = stm;
@@ -380,14 +418,14 @@
     return stat;
-double
-find_minimum (double *values, int *l_min) {
-    int l;
+double find_minimum(double *values, int *l_min)
+    int l;
     double min;
-    min =  values[0];
+    min = values[0];
-    for (l=0; l<PARAM_LAMBDA; l++) {
+    for (l = 0; l < PARAM_LAMBDA; l++) {
 	if (min > values[l]) {
 	    min = values[l];
 	    *l_min = l;
@@ -396,14 +434,13 @@
     return min;
-struct Point*
-swap (struct Point *point, int a, int b) {
-    SWAP (point[a].coordX, point[b].coordX);  /* Once the last value is let out, it is swap with j-value */
-    SWAP (point[a].coordY, point[b].coordY);
-    SWAP (point[a].coordZ, point[b].coordZ);
-    SWAP (point[a].cat, point[b].cat);
+struct Point *swap(struct Point *point, int a, int b)
+    SWAP(point[a].coordX, point[b].coordX);	/* Once the last value is let out, it is swap with j-value */
+    SWAP(point[a].coordY, point[b].coordY);
+    SWAP(point[a].coordZ, point[b].coordZ);
+    SWAP(point[a].cat, point[b].cat);
     return point;
Modified: grass/branches/releasebranch_6_3/vector/lidar/v.surf.bspline/main.c
--- grass/branches/releasebranch_6_3/vector/lidar/v.surf.bspline/main.c	2009-03-23 14:22:02 UTC (rev 36457)
+++ grass/branches/releasebranch_6_3/vector/lidar/v.surf.bspline/main.c	2009-03-23 14:32:11 UTC (rev 36458)
@@ -1,3 +1,4 @@
@@ -16,49 +17,45 @@
-/*INCLUDES*/
+ /*INCLUDES*/
-/*GLOBAL VARIABLES*/
+    /*GLOBAL VARIABLES */
 int bspline_field;
-    int
-main (int argc,char *argv[])
+int main(int argc, char *argv[])
     /* Variables' declarations */
-    int  nsply, nsplx, nlines, nrows, ncols, subregion_row, subregion_col;
-    int last_row, last_column, grid, bilin, ext, flag_auxiliar, cross; 	/* booleans */
-    double passoN, passoE, lambda, mean;
+    int nsply, nsplx, nlines, nrows, ncols, subregion_row, subregion_col;
+    int last_row, last_column, grid, bilin, ext, flag_auxiliar, cross;	/* booleans */
+    double passoN, passoE, lambda, mean;
-    char *mapset, *dvr, *db, *vector, *map, table_name[1024], title[64];
+    char *mapset, *dvr, *db, *vector, *map, table_name[1024], title[64];
     int dim_vect, nparameters, BW;
-    int *lineVect;				/* Vector restoring primitive's ID*/
-    double **raster_matrix;			/* Matrix to store the auxiliar raster values*/
-    double *TN, *Q, *parVect;			/* Interpolating and least-square vectors*/
+    int *lineVect;		/* Vector restoring primitive's ID */
+    double **raster_matrix;	/* Matrix to store the auxiliar raster values */
+    double *TN, *Q, *parVect;	/* Interpolating and least-square vectors */
     /* Structs' declarations */
     int raster;
     struct Map_info In, In_ext, Out;
     struct History history;
     struct GModule *module;
-    struct Option *in_opt, *in_ext_opt, *out_opt, *out_map_opt, *passoE_opt,
-		  *passoN_opt, *lambda_f_opt, *type, *dfield_opt, *col_opt;
+    struct Option *in_opt, *in_ext_opt, *out_opt, *out_map_opt, *passoE_opt,
+	*passoN_opt, *lambda_f_opt, *type, *dfield_opt, *col_opt;
     struct Flag *cross_corr_flag;
     struct Reg_dimens dims;
@@ -78,68 +75,69 @@
     /* Options' declaration */
     module = G_define_module(); {
 	module->keywords = _("vector, interpolation");
-	module->description =
-	   _("Bicubic or bilinear spline interpolation with Tykhonov regularization.");
+	module->description =
+	    _("Bicubic or bilinear spline interpolation with Tykhonov regularization.");
-    cross_corr_flag = G_define_flag (); {
+    cross_corr_flag = G_define_flag(); {
 	cross_corr_flag->key = 'c';
-	cross_corr_flag->description =
+	cross_corr_flag->description =
 	    _("Find best parameters using a cross validation method");
     in_opt = G_define_standard_option(G_OPT_V_INPUT);
-    in_ext_opt = G_define_standard_option (G_OPT_V_INPUT); {
-	in_ext_opt->key 	= "sparse";
-	in_ext_opt->required 	= NO;
-	in_ext_opt->description = _("Name of input vector map of sparse points");
+    in_ext_opt = G_define_standard_option(G_OPT_V_INPUT); {
+	in_ext_opt->key = "sparse";
+	in_ext_opt->required = NO;
+	in_ext_opt->description =
+	    _("Name of input vector map of sparse points");
     out_opt = G_define_standard_option(G_OPT_V_OUTPUT);
-	out_opt->required       = NO;
+    out_opt->required = NO;
     out_map_opt = G_define_standard_option(G_OPT_R_OUTPUT);
-	out_map_opt->key 	  = "raster";
-	out_map_opt->required 	  = NO;
+    out_map_opt->key = "raster";
+    out_map_opt->required = NO;
     passoE_opt = G_define_option(); {
-	passoE_opt->key		= "sie";
-	passoE_opt->type	= TYPE_DOUBLE;
-	passoE_opt->required	= NO;
-	passoE_opt->answer 	= "4";
-	passoE_opt->description	=
+	passoE_opt->key = "sie";
+	passoE_opt->type = TYPE_DOUBLE;
+	passoE_opt->required = NO;
+	passoE_opt->answer = "4";
+	passoE_opt->description =
 	    _("Interpolation spline step value in east direction");
-	passoE_opt->guisection	= _("Settings");
+	passoE_opt->guisection = _("Settings");
     passoN_opt = G_define_option(); {
-	passoN_opt->key		= "sin";
-	passoN_opt->type	= TYPE_DOUBLE;
-	passoN_opt->required	= NO;
-	passoN_opt->answer 	= "4";
-	passoN_opt->description	=
-	    _("Interpolation spline step value in north direction");
-	passoN_opt->guisection	= _("Settings");
+	passoN_opt->key = "sin";
+	passoN_opt->type = TYPE_DOUBLE;
+	passoN_opt->required = NO;
+	passoN_opt->answer = "4";
+	passoN_opt->description =
+	    _("Interpolation spline step value in north direction");
+	passoN_opt->guisection = _("Settings");
     type = G_define_option(); {
-	type->key	  = "type";
-	type->type	  = TYPE_STRING;
-	type->required	  = NO;
-	type->description = _("Spline type of interpolation");
-	type->options	  = "bilinear,bicubic";
-	type->answer	  = "bilinear";
-	type->guisection  = _("Settings");
+	type->key = "type";
+	type->type = TYPE_STRING;
+	type->required = NO;
+	type->description = _("Spline type of interpolation");
+	type->options = "bilinear,bicubic";
+	type->answer = "bilinear";
+	type->guisection = _("Settings");
     lambda_f_opt = G_define_option(); {
-	lambda_f_opt->key    	  = "lambda_i";
-	lambda_f_opt->type	  = TYPE_DOUBLE;
-	lambda_f_opt->required	  = NO;
-	lambda_f_opt->description =_("Thychonov regularization weigth");
-	lambda_f_opt->answer	  = "1";
-	lambda_f_opt->guisection  = _("Settings");
+	lambda_f_opt->key = "lambda_i";
+	lambda_f_opt->type = TYPE_DOUBLE;
+	lambda_f_opt->required = NO;
+	lambda_f_opt->description = _("Thychonov regularization weigth");
+	lambda_f_opt->answer = "1";
+	lambda_f_opt->guisection = _("Settings");
     dfield_opt = G_define_standard_option(G_OPT_V_FIELD); {
@@ -149,29 +147,30 @@
 	dfield_opt->guisection = _("Settings");
-    col_opt = G_define_option() ; {
-	col_opt->key        = "column" ;
-	col_opt->type       = TYPE_STRING ;
-	col_opt->required   = NO ;
-	col_opt->description= _("Attribute table column with values to interpolate (if layer>0)");
-	col_opt->guisection = _("Settings") ;
+    col_opt = G_define_option(); {
+	col_opt->key = "column";
+	col_opt->type = TYPE_STRING;
+	col_opt->required = NO;
+	col_opt->description =
+	    _("Attribute table column with values to interpolate (if layer>0)");
+	col_opt->guisection = _("Settings");
-    /* Parsing */
+    /* Parsing */
     G_gisinit(argv[0]);
-    if (G_parser (argc, argv))
-	exit(EXIT_FAILURE);
+    if (G_parser(argc, argv))
+	exit(EXIT_FAILURE);
-    if (!strcmp(type->answer,"bilinear"))
+    if (!strcmp(type->answer, "bilinear"))
 	bilin = P_BILINEAR;
     else
 	bilin = P_BICUBIC;
-    passoN = atof (passoN_opt->answer);
-    passoE = atof (passoE_opt->answer);
-    lambda = atof (lambda_f_opt->answer);
-    bspline_field = atoi (dfield_opt->answer);
+    passoN = atof(passoN_opt->answer);
+    passoE = atof(passoE_opt->answer);
+    lambda = atof(lambda_f_opt->answer);
+    bspline_field = atoi(dfield_opt->answer);
     bspline_column = col_opt->answer;
     flag_auxiliar = FALSE;
@@ -180,206 +179,220 @@
     vector = out_opt->answer;
     map = out_map_opt->answer;
-    if ( !(db=G__getenv2("DB_DATABASE",G_VAR_MAPSET)) )
-	G_fatal_error (_("Unable to read name of database"));
+    if (!(db = G__getenv2("DB_DATABASE", G_VAR_MAPSET)))
+	G_fatal_error(_("Unable to read name of database"));
-    if ( !(dvr = G__getenv2("DB_DRIVER",G_VAR_MAPSET)) )
-	G_fatal_error (_("Unable to read name of driver"));
+    if (!(dvr = G__getenv2("DB_DRIVER", G_VAR_MAPSET)))
+	G_fatal_error(_("Unable to read name of driver"));
     /* Setting auxiliar table's name */
     if (vector)
-	sprintf (table_name, "%s_aux", out_opt->answer);
+	sprintf(table_name, "%s_aux", out_opt->answer);
     /* Open driver and database */
-    if (db_table_exists (dvr, db, &table_name)){  /*Something went wrong in a
-						    previous v.surf.bspline execution*/
+    if (db_table_exists(dvr, db, &table_name)) {	/*Something went wrong in a
+							   previous v.surf.bspline execution */
 	dbString sql;
 	char buf[1024];
-	driver = db_start_driver_open_database (dvr, db);
+	driver = db_start_driver_open_database(dvr, db);
 	if (driver == NULL)
-	    G_fatal_error( _("No database connection for driver <%s> is defined. "
-			"Run db.connect."), dvr);
+	    G_fatal_error(_("No database connection for driver <%s> is defined. "
+			   "Run db.connect."), dvr);
-	db_init_string (&sql);
-	db_zero_string (&sql);
-	sprintf (buf, "drop table %s", table_name);
-	db_append_string (&sql, buf);
-	if (db_execute_immediate (driver, &sql) != DB_OK)
-	    G_fatal_error (_("It was not possible to drop <%s> table. "
-			"Nothing will be done. Try to drop it manually."), table_name);
+	db_init_string(&sql);
+	db_zero_string(&sql);
+	sprintf(buf, "drop table %s", table_name);
+	db_append_string(&sql, buf);
+	if (db_execute_immediate(driver, &sql) != DB_OK)
+	    G_fatal_error(_("It was not possible to drop <%s> table. "
+			    "Nothing will be done. Try to drop it manually."),
+			  table_name);
-	db_close_database_shutdown_driver (driver);
+	db_close_database_shutdown_driver(driver);
-    if (vector && map)
-	G_fatal_error (_("Choose either vector or raster output, not both"));
+    if (vector && map)
+	G_fatal_error(_("Choose either vector or raster output, not both"));
 #ifdef nodef
     if (!vector && !map && !cross_corr_flag->answer)
-	G_fatal_error (_("No raster nor vector output"));
+	G_fatal_error(_("No raster nor vector output"));
 #endif
     /* Open input vector */
-    if ((mapset = G_find_vector2 (in_opt->answer, "")) == NULL)
-	G_fatal_error ( _("Vector map <%s> not found"), in_opt->answer);
+    if ((mapset = G_find_vector2(in_opt->answer, "")) == NULL)
+	G_fatal_error(_("Vector map <%s> not found"), in_opt->answer);
-    Vect_set_open_level (1); 		/* WITHOUT TOPOLOGY */
-    if (1 > Vect_open_old (&In, in_opt->answer, mapset))
-	G_fatal_error (_("Unable to open vector map <%s> at the topological level"),
-		       in_opt->answer);
+    Vect_set_open_level(1);	/* WITHOUT TOPOLOGY */
+    if (1 > Vect_open_old(&In, in_opt->answer, mapset))
+	G_fatal_error(_("Unable to open vector map <%s> at the topological level"),
+		      in_opt->answer);
     /* Open input ext vector */
-    if (!in_ext_opt->answer){
+    if (!in_ext_opt->answer) {
 	ext = FALSE;
-	G_warning ( _("No vector map to interpolate. "
-		    "Interpolation will be done with <%s> vector map"), in_opt->answer);
-    } else {
+	G_warning(_("No vector map to interpolate. "
+		    "Interpolation will be done with <%s> vector map"),
+		  in_opt->answer);
+    else {
 	ext = TRUE;
-	G_warning (_("<%s> vector map will be interpolated"), in_ext_opt->answer);
+	G_warning(_("<%s> vector map will be interpolated"),
+		  in_ext_opt->answer);
-	if ((mapset = G_find_vector2 (in_ext_opt->answer, "")) == NULL)
-	    G_fatal_error ( _("Vector map <%s> not found"), in_ext_opt->answer);
+	if ((mapset = G_find_vector2(in_ext_opt->answer, "")) == NULL)
+	    G_fatal_error(_("Vector map <%s> not found"), in_ext_opt->answer);
-	if (1 > Vect_open_old (&In_ext, in_ext_opt->answer, mapset))
-			   in_opt->answer);
+	if (1 > Vect_open_old(&In_ext, in_ext_opt->answer, mapset))
+			  in_opt->answer);
     /* Open output map */
     /* vector output */
     if (vector && !map) {
-	if ( strcmp(dvr, "dbf") == 0)
-	    G_fatal_error (_("Sorry, <%s> driver is not allowed for vector output in this module. " \
-			"Try with a raster output or other driver."), dvr);
+	if (strcmp(dvr, "dbf") == 0)
+	    G_fatal_error(_("Sorry, <%s> driver is not allowed for vector output in this module. "
+			   "Try with a raster output or other driver."), dvr);
-	Vect_check_input_output_name (in_opt->answer, out_opt->answer, GV_FATAL_EXIT);
+	Vect_check_input_output_name(in_opt->answer, out_opt->answer,
+				     GV_FATAL_EXIT);
 	grid = FALSE;
-	if (0 > Vect_open_new (&Out, out_opt->answer, WITH_Z))
-	    G_fatal_error (_("Unable to create vector map <%s>"), out_opt->answer);
+	if (0 > Vect_open_new(&Out, out_opt->answer, WITH_Z))
+	    G_fatal_error(_("Unable to create vector map <%s>"),
+			  out_opt->answer);
 	/* Copy vector Head File */
 	if (ext == FALSE) {
-	    Vect_copy_head_data (&In, &Out);
-	    Vect_hist_copy (&In, &Out);
-	} else {
-	    Vect_copy_head_data (&In_ext, &Out);
-	    Vect_hist_copy (&In_ext, &Out);
-	Vect_hist_command (&Out);
+	    Vect_copy_head_data(&In, &Out);
+	    Vect_hist_copy(&In, &Out);
+	else {
+	    Vect_copy_head_data(&In_ext, &Out);
+	    Vect_hist_copy(&In_ext, &Out);
+	Vect_hist_command(&Out);
     /* raster output */
     raster = -1;
-    G_set_fp_type (DCELL_TYPE);
+    G_set_fp_type(DCELL_TYPE);
     if (!vector && map) {
 	grid = TRUE;
-	if (G_find_cell (out_map_opt->answer, G_mapset()) != NULL)
-	    G_fatal_error (_("Raster <%s> already exist."), out_map_opt->answer);
+	   if (G_find_cell (out_map_opt->answer, G_mapset()) != NULL)
+	   G_fatal_error (_("Raster <%s> already exist."), out_map_opt->answer);
-	if ((raster = G_open_fp_cell_new (out_map_opt->answer)) < 0)
-	    G_fatal_error (_("Unable to create raster map <%s>"), out_map_opt->answer);
+	if ((raster = G_open_fp_cell_new(out_map_opt->answer)) < 0)
+	    G_fatal_error(_("Unable to create raster map <%s>"),
+			  out_map_opt->answer);
-	Fi = Vect_get_field (&In, bspline_field);
-	if ( Fi == NULL )
-	    G_fatal_error (_("Cannot read field info"));
+	Fi = Vect_get_field(&In, bspline_field);
+	if (Fi == NULL)
+	    G_fatal_error(_("Cannot read field info"));
-	/*G_debug (0, _("driver=%s db=%s"), Fi->driver, Fi->database);*/
-    	G_fatal_error (_("Unable to open database <%s> by driver <%s>"), Fi->database, Fi->driver);
-        nrec = db_select_CatValArray ( driver_cats, Fi->table, Fi->key, col_opt->answer, NULL, &cvarr );
-        ctype = cvarr.ctype;
-	    G_fatal_error ( _("Column type not supported") );
-        if ( nrec < 0 )
-	    G_fatal_error (_("Unable to select data from table"));
-        G_message ( _("[%d] records selected from table"), nrec);
+	driver_cats = db_start_driver_open_database(Fi->driver, Fi->database);
+	/*G_debug (0, _("driver=%s db=%s"), Fi->driver, Fi->database); */
+	    G_fatal_error(_("Unable to open database <%s> by driver <%s>"),
+	nrec =
+				  col_opt->answer, NULL, &cvarr);
+	ctype = cvarr.ctype;
+	    G_fatal_error(_("Column type not supported"));
+	if (nrec < 0)
+	    G_fatal_error(_("Unable to select data from table"));
+	G_message(_("[%d] records selected from table"), nrec);
-    /*Cross-correlation begins*/
-    if (cross_corr_flag->answer) {		/* CROSS-CORRELATION WILL BE DONE*/
-	G_debug (1, "CrossCorrelation()");
-	/*cross = cross_correlation (&In, &passoE, &passoN, &lambda);*/
-	cross = cross_correlation (&In, passoE, passoN);
+    /*Cross-correlation begins */
+    if (cross_corr_flag->answer) {	/* CROSS-CORRELATION WILL BE DONE */
+	G_debug(1, "CrossCorrelation()");
+	/*cross = cross_correlation (&In, &passoE, &passoN, &lambda); */
+	cross = cross_correlation(&In, passoE, passoN);
 	if (cross != TRUE)
-	    G_fatal_error (_("Cross validation didn't finish correctly"));
-	else {
-	    G_debug (1, "Cross validation finished correctly");
+	    G_fatal_error(_("Cross validation didn't finish correctly"));
+	else {
+	    G_debug(1, "Cross validation finished correctly");
-	    Vect_close (&In);
-	    if (ext != FALSE) Vect_close (&In_ext);
-	    if (vector) Vect_close (&Out);
+	    Vect_close(&In);
+	    if (ext != FALSE)
+		Vect_close(&In_ext);
+	    if (vector)
+		Vect_close(&Out);
-	    if (map) G_close_cell (raster);
+	    if (map)
+		G_close_cell(raster);
-	    G_done_msg (_("Cross Validation was success!"));
-	    exit (EXIT_SUCCESS);
+	    G_done_msg(_("Cross Validation was success!"));
+	    exit(EXIT_SUCCESS);
-	/*G_debug (0, _("passoE = %f, passoN=%f, lambda_i=%f"), passoE, passoN, lambda);*/
+	/*G_debug (0, _("passoE = %f, passoN=%f, lambda_i=%f"), passoE, passoN, lambda); */
     /* Interpolation begins */
-    G_debug (1, "Interpolation()");
+    G_debug(1, "Interpolation()");
     if (driver == NULL)
-    /* Setting regions and boxes */
-    G_debug (1, "Interpolation: Setting regions and boxes");
-    G_get_window (&original_reg);
-    G_get_window (&elaboration_reg);
-    Vect_region_box (&elaboration_reg, &overlap_box);
-    Vect_region_box (&elaboration_reg, &general_box);
+    /* Setting regions and boxes */
+    G_debug(1, "Interpolation: Setting regions and boxes");
+    G_get_window(&original_reg);
+    G_get_window(&elaboration_reg);
+    Vect_region_box(&elaboration_reg, &overlap_box);
+    Vect_region_box(&elaboration_reg, &general_box);
     /* Alloc raster matrix */
     if (raster) {
 	double nrows_ncols;
-	nrows = G_window_rows ();
-	ncols = G_window_cols ();
-	nrows_ncols = (double) nrows*ncols;
-	if ((nrows_ncols) > 30000000) /* about 5500x5500 cells */
-	    G_fatal_error (_("Interpolation: The region resolution is too high: %d cells. "
-			"Consider to change it."), nrows_ncols);
-	/*raster_matrix = G_alloc_fmatrix (nrows, ncols);  Is it neccesary a double precision??*/
-	raster_matrix = G_alloc_matrix (nrows, ncols);
+	nrows = G_window_rows();
+	ncols = G_window_cols();
+	nrows_ncols = (double)nrows *ncols;
+	if ((nrows_ncols) > 30000000)	/* about 5500x5500 cells */
+	    G_fatal_error(_("Interpolation: The region resolution is too high: %d cells. "
+			   "Consider to change it."), nrows_ncols);
+	/*raster_matrix = G_alloc_fmatrix (nrows, ncols);  Is it neccesary a double precision?? */
+	raster_matrix = G_alloc_matrix(nrows, ncols);
     /* Fixxing parameters of the elaboration region */
-    P_zero_dim (&dims);					/* Set to zero the dim struct*/
+    P_zero_dim(&dims);		/* Set to zero the dim struct */
     dims.latoE = NSPLX_MAX * passoE;
     dims.latoN = NSPLY_MAX * passoN;
     dims.overlap = OVERLAP_SIZE * passoE;
-    P_get_orlo (bilin, &dims, passoE, passoN);		/* Set the last two dim elements*/
+    P_get_orlo(bilin, &dims, passoE, passoN);	/* Set the last two dim elements */
-    /* Creating line and categories structs */
-    points = Vect_new_line_struct ();
-    Cats = Vect_new_cats_struct ();
-    nlines = Vect_get_num_lines (&In);
+    /* Creating line and categories structs */
+    points = Vect_new_line_struct();
+    Cats = Vect_new_cats_struct();
+    nlines = Vect_get_num_lines(&In);
       | Subdividing and working with tiles:
@@ -392,26 +405,33 @@
     subregion_row = 0;
     last_row = FALSE;
-    while (last_row == FALSE){		/* For each row */
-	subregion_row++;
-	P_set_regions(&elaboration_reg, &general_box, &overlap_box, dims, GENERAL_ROW);
+    while (last_row == FALSE) {	/* For each row */
+	subregion_row++;
+	P_set_regions(&elaboration_reg, &general_box, &overlap_box, dims,
+		      GENERAL_ROW);
-	if (elaboration_reg.north > original_reg.north) {		/* First row */
+	if (elaboration_reg.north > original_reg.north) {	/* First row */
-	    P_set_regions(&elaboration_reg, &general_box, &overlap_box, dims, FIRST_ROW);
-	    nsply = ceil((elaboration_reg.north - elaboration_reg.south)/passoN);
-	    G_debug (1, "Interpolation: nsply = %d", nsply);
-	    if (nsply > NSPLY_MAX)
+			  FIRST_ROW);
+	    nsply =
+		ceil((elaboration_reg.north -
+		      elaboration_reg.south) / passoN);
+	    G_debug(1, "Interpolation: nsply = %d", nsply);
+	    if (nsply > NSPLY_MAX)
 		nsply = NSPLY_MAX;
-	if (elaboration_reg.south <= original_reg.south) {		/* Last row */
+	if (elaboration_reg.south <= original_reg.south) {	/* Last row */
-	    P_set_regions(&elaboration_reg, &general_box, &overlap_box, dims, LAST_ROW);
-	    nsply=ceil((elaboration_reg.north - elaboration_reg.south)/passoN);
+			  LAST_ROW);
+	    nsply =
 	    last_row = TRUE;
 		nsply = NSPLY_MAX;
@@ -419,231 +439,273 @@
 	last_column = FALSE;
 	subregion_col = 0;
-	while (last_column == FALSE){	/* For each column */
+	while (last_column == FALSE) {	/* For each column */
 	    int npoints = 0;
 	    subregion_col++;
-	    P_set_regions(&elaboration_reg, &general_box, &overlap_box, dims, GENERAL_COLUMN);
+			  GENERAL_COLUMN);
-	    if (elaboration_reg.west < original_reg.west)  {		/* First column */
+	    if (elaboration_reg.west < original_reg.west) {	/* First column */
-		P_set_regions(&elaboration_reg, &general_box, &overlap_box, dims, FIRST_COLUMN);
-		nsplx=ceil((elaboration_reg.east - elaboration_reg.west)/passoE);
-		if (nsplx > NSPLX_MAX)
+			      dims, FIRST_COLUMN);
+		nsplx =
+		    ceil((elaboration_reg.east -
+			  elaboration_reg.west) / passoE);
+		if (nsplx > NSPLX_MAX)
 		    nsplx = NSPLX_MAX;
-	    if (elaboration_reg.east >= original_reg.east) {		/* Last column */
+	    if (elaboration_reg.east >= original_reg.east) {	/* Last column */
-		P_set_regions(&elaboration_reg, &general_box, &overlap_box, dims, LAST_COLUMN);
+			      dims, LAST_COLUMN);
 		last_column = TRUE;
+		nsplx =
 		    nsplx = NSPLX_MAX;
-	    G_debug (1, "Interpolation: (%d,%d): subregion bounds",
-		     subregion_row, subregion_col);
-	    G_debug (1, "Interpolation: \t\tNORTH:%.2f\t",
-		     elaboration_reg.north);
-	    G_debug (1, "Interpolation: WEST:%.2f\t\tEAST:%.2f",
-		     elaboration_reg.west, elaboration_reg.east);
-	    G_debug (1, "Interpolation: \t\tSOUTH:%.2f",
-		     elaboration_reg.south);
+	    G_debug(1, "Interpolation: (%d,%d): subregion bounds",
+		    subregion_row, subregion_col);
+	    G_debug(1, "Interpolation: \t\tNORTH:%.2f\t",
+		    elaboration_reg.north);
+	    G_debug(1, "Interpolation: WEST:%.2f\t\tEAST:%.2f",
+		    elaboration_reg.west, elaboration_reg.east);
+	    G_debug(1, "Interpolation: \t\tSOUTH:%.2f",
+		    elaboration_reg.south);
-	    /*Setting the active region*/
+	    /*Setting the active region */
 	    dim_vect = nsplx * nsply;
-	    observ = P_Read_Vector_Region_Map (&In, &elaboration_reg, &npoints, dim_vect, bspline_field);
-	    G_debug (1, "Interpolation: (%d,%d): Number of points in <elaboration_box> is %d",
-		     subregion_row, subregion_col, npoints);
-	    if (npoints > 0) {				/*  */
+	    observ =
+		P_Read_Vector_Region_Map(&In, &elaboration_reg, &npoints,
+					 dim_vect, bspline_field);
+	    G_debug(1,
+		    "Interpolation: (%d,%d): Number of points in <elaboration_box> is %d",
+		    subregion_row, subregion_col, npoints);
+	    if (npoints > 0) {	/*  */
 		int i;
 		double *obs_mean;
 		nparameters = nsplx * nsply;
-		N = G_alloc_matrix (nparameters, BW);		/* Normal matrix */
-		TN = G_alloc_vector (nparameters);		/* vector */
-		parVect = G_alloc_vector (nparameters);		/* Parameters vector */
-		obsVect = G_alloc_matrix (npoints, 3);	/* Observation vector */
-		Q = G_alloc_vector (npoints);		/* "a priori" var-cov matrix */
-		lineVect = G_alloc_ivector (npoints);	/*  */
-		obs_mean = G_alloc_vector (npoints);
+		N = G_alloc_matrix(nparameters, BW);	/* Normal matrix */
+		TN = G_alloc_vector(nparameters);	/* vector */
+		parVect = G_alloc_vector(nparameters);	/* Parameters vector */
+		obsVect = G_alloc_matrix(npoints, 3);	/* Observation vector */
+		Q = G_alloc_vector(npoints);	/* "a priori" var-cov matrix */
+		lineVect = G_alloc_ivector(npoints);	/*  */
+		obs_mean = G_alloc_vector(npoints);
 		if (bspline_field <= 0)
-		    mean = P_Mean_Calc (&elaboration_reg, observ, npoints);
+		    mean = P_Mean_Calc(&elaboration_reg, observ, npoints);
-		for (i=0; i<npoints; i++) {		/* Setting obsVect vector & Q matrix */
+		for (i = 0; i < npoints; i++) {	/* Setting obsVect vector & Q matrix */
 		    double dval;
 		    lineVect[i] = observ[i].lineID;
 			int cat, ival, ret, type;
+			if (cat < 0)
+			    continue;
+			    ret =
+							     &ival);
-			    obs_mean [i] = ival;
+			    ret =
+								&dval);
-			    G_warning (_("Interpolation: (%d,%d): No record for point (cat = %d)"),
-				    subregion_row, subregion_col, cat);
+			    G_warning(_("Interpolation: (%d,%d): No record for point (cat = %d)"),
+				      subregion_row, subregion_col, cat);
 			    continue;
-		    else {
-		    } /*obsVect[i][2] = observ[i].coordZ - mean; */
+		    else {
+		    }		/*obsVect[i][2] = observ[i].coordZ - mean; */
-		/* Mean calculation for every point*/
+		/* Mean calculation for every point */
-		    mean = calc_mean (obs_mean, npoints);
+		    mean = calc_mean(obs_mean, npoints);
-		G_debug (1 ,"Interpolation: (%d,%d): mean=%lf",
-			 subregion_row, subregion_col, mean);
+		G_debug(1, "Interpolation: (%d,%d): mean=%lf",
+			subregion_row, subregion_col, mean);
 		    obsVect[i][2] -= mean;
-		G_free (observ);
+		G_free(observ);
-		    G_debug (1 , "Interpolation: (%d,%d): Bilinear interpolation...",
-		    normalDefBilin (N, TN, Q, obsVect, passoE, passoN, nsplx, nsply, elaboration_reg.west,
-			    elaboration_reg.south, npoints, nparameters, BW);
-		    nCorrectGrad (N, lambda, nsplx, nsply, passoE, passoN);
-		else{
-		    G_debug (1, "Interpolation: (%d,%d): Bicubic interpolation...",
-		    normalDefBicubic(N, TN, Q, obsVect, passoE, passoN, nsplx, nsply, elaboration_reg.west,
+		    G_debug(1,
+			    "Interpolation: (%d,%d): Bilinear interpolation...",
+		    normalDefBilin(N, TN, Q, obsVect, passoE, passoN, nsplx,
+				   nsply, elaboration_reg.west,
+				   elaboration_reg.south, npoints,
+				   nparameters, BW);
 		    nCorrectGrad(N, lambda, nsplx, nsply, passoE, passoN);
+		else {
+		    G_debug(1,
+			    "Interpolation: (%d,%d): Bicubic interpolation...",
+		    normalDefBicubic(N, TN, Q, obsVect, passoE, passoN, nsplx,
+				     nparameters, BW);
+		    nCorrectGrad(N, lambda, nsplx, nsply, passoE, passoN);
 		tcholSolve(N, TN, parVect, nparameters, BW);
+		G_free_matrix(N);
+		G_free_vector(Q);
-		if (grid == FALSE) {		/*OBSERVATION POINTS INTERPOLATION*/
+		if (grid == FALSE) {	/*OBSERVATION POINTS INTERPOLATION */
 		    /* Auxiliar table creation */
 		    if (flag_auxiliar == FALSE) {
-			G_debug (1, "Interpolation: Creating auxiliar table for archiving "
-				 "overlapping zones");
-			if ((flag_auxiliar = P_Create_Aux_Table (driver, table_name)) == FALSE) {
-			    P_Drop_Aux_Table (driver, table_name);
-			    G_fatal_error (_("Interpolation: Creating table: "
-				"It was impossible to create table <%s>."), table_name);
+			G_debug(1,
+				"Interpolation: Creating auxiliar table for archiving "
+				"overlapping zones");
+			if ((flag_auxiliar =
+			     P_Create_Aux_Table(driver,
+						table_name)) == FALSE) {
+			    P_Drop_Aux_Table(driver, table_name);
+			    G_fatal_error(_("Interpolation: Creating table: "
+					    "It was impossible to create table <%s>."),
+					  table_name);
 		    if (ext == FALSE) {
-			G_debug (1 , "Interpolation: (%d,%d): Sparse_Points...",
-			P_Sparse_Points (&Out, &elaboration_reg, general_box, overlap_box, obsVect,
-				parVect, lineVect, passoE, passoN, dims.overlap, nsplx, nsply, npoints,
-				bilin, Cats, driver, mean, table_name);
+			G_debug(1, "Interpolation: (%d,%d): Sparse_Points...",
+			P_Sparse_Points(&Out, &elaboration_reg, general_box,
+					overlap_box, obsVect, parVect,
+					lineVect, passoE, passoN,
+					dims.overlap, nsplx, nsply, npoints,
+					bilin, Cats, driver, mean,
+					table_name);
-		    else {		/* FLAG_EXT == TRUE*/
-			int npoints_ext, *lineVect_ext=NULL;
-			double **obsVect_ext; /*, mean_ext = .0;*/
+		    else {	/* FLAG_EXT == TRUE */
+			int npoints_ext, *lineVect_ext = NULL;
+			double **obsVect_ext;	/*, mean_ext = .0; */
 			struct Point *observ_ext;
-			observ_ext = P_Read_Vector_Region_Map (&In_ext, &elaboration_reg, &npoints_ext, dim_vect, 1);
+			observ_ext =
+			    P_Read_Vector_Region_Map(&In_ext,
+						     &elaboration_reg,
+						     &npoints_ext, dim_vect,
+						     1);
-			obsVect_ext = G_alloc_matrix (npoints_ext, 3);	/* Observation vector_ext */
-			lineVect_ext = G_alloc_ivector (npoints_ext);
+			obsVect_ext = G_alloc_matrix(npoints_ext, 3);	/* Observation vector_ext */
+			lineVect_ext = G_alloc_ivector(npoints_ext);
-			for (i=0; i<npoints_ext; i++) {		/* Setting obsVect_ext vector & Q matrix */
+			for (i = 0; i < npoints_ext; i++) {	/* Setting obsVect_ext vector & Q matrix */
 			    obsVect_ext[i][0] = observ_ext[i].coordX;
 			    obsVect_ext[i][1] = observ_ext[i].coordY;
-			    obsVect_ext[i][2] = observ_ext[i].coordZ-mean;
+			    obsVect_ext[i][2] = observ_ext[i].coordZ - mean;
 			    lineVect_ext[i] = observ_ext[i].lineID;
-			G_free (observ_ext);
-			G_debug (1, "Interpolation: (%d,%d): Sparse_Points...",
-			P_Sparse_Points (&Out, &elaboration_reg, general_box, overlap_box, obsVect_ext,
-				parVect, lineVect_ext, passoE, passoN, dims.overlap, nsplx, nsply, npoints_ext,
-			G_free_matrix (obsVect_ext);
-			G_free_ivector (lineVect_ext);
+			G_free(observ_ext);
+					overlap_box, obsVect_ext, parVect,
+					lineVect_ext, passoE, passoN,
+					npoints_ext, bilin, Cats, driver,
+					mean, table_name);
+			G_free_matrix(obsVect_ext);
+			G_free_ivector(lineVect_ext);
 		    }		/* END FLAG_EXT == TRUE */
 		}		/* END IF GRID == FLASE */
-		else {			/*GRID INTERPOLATION ==> INTERPOLATION INTO A RASTER*/
+		else {		/*GRID INTERPOLATION ==> INTERPOLATION INTO A RASTER */
 		    flag_auxiliar = TRUE;
-		    G_debug (1, "Interpolation: (%d,%d): Regular_Points...",
-		    raster_matrix = P_Regular_Points (&elaboration_reg, general_box, overlap_box, raster_matrix,
-			    parVect, passoN, passoE, dims.overlap, mean, nsplx, nsply, nrows, ncols, bilin);
+		    G_debug(1, "Interpolation: (%d,%d): Regular_Points...",
+		    raster_matrix =
+			P_Regular_Points(&elaboration_reg, general_box,
+					 overlap_box, raster_matrix, parVect,
+					 passoN, passoE, dims.overlap, mean,
+					 nsplx, nsply, nrows, ncols, bilin);
-		G_free_ivector (lineVect);
+		G_free_ivector(lineVect);
-	} /*! END WHILE; last_column = TRUE*/
-    } /*! END WHILE; last_row = TRUE*/
+	}			/*! END WHILE; last_column = TRUE */
+    }				/*! END WHILE; last_row = TRUE */
     /* Writing into the output vector map the points from the overlaping zones */
     if (flag_auxiliar == TRUE) {
 	    if (ext == FALSE)
-		P_Aux_to_Vector (&In, &Out, driver, table_name);
+		P_Aux_to_Vector(&In, &Out, driver, table_name);
 	    else
-		P_Aux_to_Vector (&In_ext, &Out, driver, table_name);
+		P_Aux_to_Vector(&In_ext, &Out, driver, table_name);
 	    /* Dropping auxiliar table */
-	    G_debug (1, "%s: Dropping <%s>", argv[0], table_name);
-	    if (P_Drop_Aux_Table (driver, table_name) != DB_OK)
+	    G_debug(1, "%s: Dropping <%s>", argv[0], table_name);
+	    if (P_Drop_Aux_Table(driver, table_name) != DB_OK)
 		G_fatal_error(_("Auxiliar table could not be dropped"));
 	else {
-	    P_Aux_to_Raster (raster_matrix, raster);
-	    G_free_matrix (raster_matrix);
+	    P_Aux_to_Raster(raster_matrix, raster);
+	    G_free_matrix(raster_matrix);
-    Vect_close (&In);
+    Vect_close(&In);
+    if (ext != FALSE)
+    if (vector)
+	Vect_close(&Out);
     if (map) {
 	/* set map title */
 	sprintf(title, "%s interpolation with Tykhonov regularization",
-	    type->answer);
+		type->answer);
 	G_put_cell_title(out_map_opt->answer, title);
 	/* write map history */
 	G_short_history(out_map_opt->answer, "raster", &history);
@@ -651,8 +713,7 @@
 	G_write_history(out_map_opt->answer, &history);
-    G_done_msg ("");
+    G_done_msg(" ");
-}	/*END MAIN*/
+}				/*END MAIN */
