[GRASS-SVN] r36461 - in grass/branches/releasebranch_6_4: locale/po vector/lidar/v.surf.bspline
Mon Mar 23 10:53:21 EDT 2009
Author: neteler
Date: 2009-03-23 10:53:20 -0400 (Mon, 23 Mar 2009)
New Revision: 36461
   grass/branches/releasebranch_6_4/locale/po/grassmods_cs.po
   grass/branches/releasebranch_6_4/locale/po/grassmods_fr.po
   grass/branches/releasebranch_6_4/vector/lidar/v.surf.bspline/main.c
less foggy msg
Modified: grass/branches/releasebranch_6_4/locale/po/grassmods_cs.po
--- grass/branches/releasebranch_6_4/locale/po/grassmods_cs.po	2009-03-23 14:51:32 UTC (rev 36460)
+++ grass/branches/releasebranch_6_4/locale/po/grassmods_cs.po	2009-03-23 14:53:20 UTC (rev 36461)
@@ -27116,7 +27116,7 @@
 #: ../vector/lidar/v.surf.bspline/main.c:236
 #, c-format
 msgid ""
-"No vector map of sparse points to interpolate. Interpolation will be done "
+"No vector map of sparse points to interpolate was specified. Interpolation will be done "
 "with <%s> vector map"
 msgstr ""
 "®ádná vektorová mapa pro interpolaci. Interpolace bude aplikována na "
Modified: grass/branches/releasebranch_6_4/locale/po/grassmods_fr.po
--- grass/branches/releasebranch_6_4/locale/po/grassmods_fr.po	2009-03-23 14:51:32 UTC (rev 36460)
+++ grass/branches/releasebranch_6_4/locale/po/grassmods_fr.po	2009-03-23 14:53:20 UTC (rev 36461)
@@ -24399,7 +24399,7 @@
 #, c-format
 msgid ""
 msgstr ""
Modified: grass/branches/releasebranch_6_4/vector/lidar/v.surf.bspline/main.c
--- grass/branches/releasebranch_6_4/vector/lidar/v.surf.bspline/main.c	2009-03-23 14:51:32 UTC (rev 36460)
+++ grass/branches/releasebranch_6_4/vector/lidar/v.surf.bspline/main.c	2009-03-23 14:53:20 UTC (rev 36461)
@@ -234,7 +234,7 @@
     /* Open input ext vector */
     if (!in_ext_opt->answer) {
 	ext = FALSE;
-	G_message(_("No vector map of sparse points to interpolate. "
+	G_message(_("No vector map of sparse points to interpolate was specified. "
 		    "Interpolation will be done with <%s> vector map"),
 		  in_opt->answer);
