[GRASS-SVN] r36492 - grass/trunk/lib/vector/diglib
svn_grass at osgeo.org
Fri Mar 27 08:20:31 EDT 2009
Author: mmetz
Date: 2009-03-27 08:20:31 -0400 (Fri, 27 Mar 2009)
New Revision: 36492
grass/trunk/lib/vector/diglib/plus.c
grass/trunk/lib/vector/diglib/struct_alloc.c
diglib free structures modified
Modified: grass/trunk/lib/vector/diglib/plus.c
--- grass/trunk/lib/vector/diglib/plus.c 2009-03-26 20:10:48 UTC (rev 36491)
+++ grass/trunk/lib/vector/diglib/plus.c 2009-03-27 12:20:31 UTC (rev 36492)
@@ -120,11 +120,7 @@
if (Node == NULL)
continue;
- if (Node->alloc_lines > 0) {
- free(Node->lines);
- free(Node->angles);
- free(Node);
+ dig_free_node(Node);
free(Plus->Node);
@@ -152,7 +148,7 @@
if (Line == NULL)
continue;
- free(Line);
+ dig_free_line(Line);
free(Plus->Line);
@@ -188,13 +184,7 @@
if (Area == NULL)
continue;
- if (Area->alloc_lines > 0)
- free(Area->lines);
- if (Area->alloc_isles > 0)
- free(Area->isles);
- free(Area);
+ dig_free_area(Area);
free(Plus->Area);
@@ -222,10 +212,7 @@
if (Isle == NULL)
continue;
- if (Isle->alloc_lines > 0)
- free(Isle->lines);
- free(Isle);
+ dig_free_isle(Isle);
free(Plus->Isle);
Modified: grass/trunk/lib/vector/diglib/struct_alloc.c
--- grass/trunk/lib/vector/diglib/struct_alloc.c 2009-03-26 20:10:48 UTC (rev 36491)
+++ grass/trunk/lib/vector/diglib/struct_alloc.c 2009-03-27 12:20:31 UTC (rev 36492)
@@ -44,7 +44,7 @@
Node = (P_NODE *) malloc(sizeof(P_NODE));
if (Node == NULL)
- return NULL;
+ return NULL;
Node->n_lines = 0;
Node->alloc_lines = 0;
@@ -57,8 +57,11 @@
/* free node structure */
void dig_free_node(P_NODE *Node)
+ if (Node->alloc_lines > 0) {
+ free(Node->lines);
+ free(Node->angles);
free(Node);
@@ -80,12 +83,12 @@
p = realloc(node->lines, num * sizeof(plus_t));
if (p == NULL)
- return -1;
+ return -1;
node->lines = (plus_t *) p;
p = realloc(node->angles, num * sizeof(float));
if (p == NULL)
- return -1;
+ return -1;
node->angles = (float *)p;
node->alloc_lines = num;
@@ -107,7 +110,7 @@
size = Plus->alloc_nodes + 1 + add;
p = realloc(Plus->Node, size * sizeof(P_NODE *));
if (p == NULL)
- return -1;
+ return -1;
Plus->Node = (P_NODE **) p;
Plus->alloc_nodes = size - 1;
@@ -122,7 +125,7 @@
Line = (P_LINE *) malloc(sizeof(P_LINE));
if (Line == NULL)
- return NULL;
+ return NULL;
return (Line);
@@ -147,7 +150,7 @@
size = Plus->alloc_lines + 1 + add;
p = realloc(Plus->Line, size * sizeof(P_LINE *));
if (p == NULL)
- return -1;
+ return -1;
Plus->Line = (P_LINE **) p;
Plus->alloc_lines = size - 1;
@@ -169,7 +172,7 @@
size = Plus->alloc_areas + 1 + add;
p = realloc(Plus->Area, size * sizeof(P_AREA *));
if (p == NULL)
- return -1;
+ return -1;
Plus->Area = (P_AREA **) p;
Plus->alloc_areas = size - 1;
@@ -192,7 +195,7 @@
size = Plus->alloc_isles + 1 + add;
p = realloc(Plus->Isle, size * sizeof(P_ISLE *));
if (p == NULL)
- return -1;
+ return -1;
Plus->Isle = (P_ISLE **) p;
Plus->alloc_isles = size - 1;
@@ -207,7 +210,7 @@
Area = (P_AREA *) malloc(sizeof(P_AREA));
if (Area == NULL)
- return NULL;
+ return NULL;
Area->n_lines = 0;
Area->alloc_lines = 0;
@@ -225,8 +228,12 @@
/* free area structure */
void dig_free_area(P_AREA *Area)
+ if (Area->alloc_lines > 0)
+ free(Area->lines);
+ if (Area->alloc_isles > 0)
+ free(Area->isles);
free(Area);
@@ -237,7 +244,7 @@
Isle = (P_ISLE *) malloc(sizeof(P_ISLE));
if (Isle == NULL)
- return NULL;
+ return NULL;
Isle->n_lines = 0;
Isle->alloc_lines = 0;
@@ -251,7 +258,9 @@
/* free isle structure */
void dig_free_isle(P_ISLE *Isle)
+ if (Isle->alloc_lines > 0)
+ free(Isle->lines);
free(Isle);
@@ -268,7 +277,7 @@
if (!(p =
dig__alloc_space(num, &alloced, 50, (char *)points->x,
sizeof(double)))) {
- return (dig_out_of_memory());
+ return (dig_out_of_memory());
points->x = (double *)p;
@@ -277,7 +286,7 @@
if (!(p =
dig__alloc_space(num, &alloced, 50, (char *)points->y,
sizeof(double)))) {
points->y = (double *)p;
@@ -286,7 +295,7 @@
if (!(p =
dig__alloc_space(num, &alloced, 50, (char *)points->z,
sizeof(double)))) {
points->z = (double *)p;
@@ -308,7 +317,7 @@
if (!(p =
dig__alloc_space(num, &alloced, 1, (int *)cats->field,
sizeof(int)))) {
cats->field = (int *)p;
@@ -316,7 +325,7 @@
if (!(p =
dig__alloc_space(num, &alloced, 1, (int *)cats->cat,
sizeof(int)))) {
cats->cat = (int *)p;
@@ -338,7 +347,7 @@
p = realloc(area->lines, num * sizeof(plus_t));
if (p == NULL)
- return -1;
+ return -1;
area->lines = (plus_t *) p;
area->alloc_lines = num;
@@ -361,7 +370,7 @@
p = realloc(area->isles, num * sizeof(plus_t));
if (p == NULL)
- return -1;
+ return -1;
area->isles = (plus_t *) p;
area->alloc_isles = num;
@@ -384,7 +393,7 @@
p = realloc(isle->lines, num * sizeof(plus_t));
if (p == NULL)
- return -1;
+ return -1;
isle->lines = (plus_t *) p;
isle->alloc_lines = num;
