[GRASS-SVN] r36501 - grass/trunk/gui/wxpython/gui_modules
svn_grass at osgeo.org
Sat Mar 28 09:35:22 EDT 2009
Author: martinl
Date: 2009-03-28 09:35:22 -0400 (Sat, 28 Mar 2009)
New Revision: 36501
grass/trunk/gui/wxpython/gui_modules/render.py
wxGUI: fix overlays
(merge from devbr6, r36500)
Modified: grass/trunk/gui/wxpython/gui_modules/render.py
--- grass/trunk/gui/wxpython/gui_modules/render.py 2009-03-28 13:24:06 UTC (rev 36500)
+++ grass/trunk/gui/wxpython/gui_modules/render.py 2009-03-28 13:35:22 UTC (rev 36501)
@@ -126,11 +126,11 @@
# prepare command for each layer
- layertypes = ['raster', 'rgb', 'his', 'shaded', 'rastarrow', 'rastnum',
+ layertypes = ('raster', 'rgb', 'his', 'shaded', 'rastarrow', 'rastnum',
'vector','thememap','themechart',
'grid', 'geodesic', 'rhumb', 'labels',
'command',
- 'overlay']
+ 'overlay')
if self.type not in layertypes:
raise gcmd.GStdError(_("<%(name)s>: layer type <%(type)s> is not supported yet.") % \
@@ -1210,8 +1210,7 @@
return self.overlays[-1]
- def ChangeOverlay(self, id, type, command,
- l_active=True, l_hidden=False, l_opacity=1, l_render=False):
+ def ChangeOverlay(self, id, render=False, **kargs):
Change overlay properities
@@ -1228,20 +1227,27 @@
overlay = self.GetOverlay(id, list=False)
if overlay is None:
- overlay = Overlay(id, type, command,
- l_active, l_hidden, l_opacity)
- else:
- overlay.id = id
- overlay.name = type
- overlay.cmdlist = command
- overlay.active = l_active
- overlay.hidden = l_hidden
- overlay.opacity = l_opacity
+ overlay = Overlay(id, type = None, cmd = None)
+ if kargs.has_key('type'):
+ overlay.SetName(kargs['type']) # type -> overlay
+ if kargs.has_key('command'):
+ overlay.SetCmd(kargs['command'])
+ if kargs.has_key('active'):
+ overlay.SetActive(kargs['active'])
- if l_render and command != [] and not overlay.Render():
+ if kargs.has_key('hidden'):
+ overlay.SetHidden(kargs['hidden'])
+ if kargs.has_key('opacity'):
+ overlay.SetOpacity(kargs['opacity'])
+ if render and command != [] and not overlay.Render():
raise gcmd.GException(_("Unable render overlay <%s>") %
(name))
return overlay
def GetOverlay(self, id, list=False):
