[GRASS-SVN] r36522 - grass/branches/develbranch_6/gui/wxpython/gui_modules
Mon Mar 30 03:15:36 EDT 2009
Author: cmbarton
Date: 2009-03-30 03:15:36 -0400 (Mon, 30 Mar 2009)
New Revision: 36522
   grass/branches/develbranch_6/gui/wxpython/gui_modules/mapdisp.py
   grass/branches/develbranch_6/gui/wxpython/gui_modules/nviz_mapdisp.py
   grass/branches/develbranch_6/gui/wxpython/gui_modules/nviz_tools.py
Bug fix for wxnviz. It now starts and quits and restarts without errors. It also does not have to reload maps previously loaded. Panel switching works without duplicate pages and overlayed panels.
Modified: grass/branches/develbranch_6/gui/wxpython/gui_modules/mapdisp.py
--- grass/branches/develbranch_6/gui/wxpython/gui_modules/mapdisp.py	2009-03-29 21:16:34 UTC (rev 36521)
+++ grass/branches/develbranch_6/gui/wxpython/gui_modules/mapdisp.py	2009-03-30 07:15:36 UTC (rev 36522)
@@ -392,6 +392,7 @@
                                                        mapWindow=self.MapWindow3D)
                 self.MapWindow3D.OnPaint(None) # -> LoadData
                 self.MapWindow3D.Show()
+                self.MapWindow3D.UpdateView(None)
             self.nvizToolWin.Show()
@@ -443,7 +444,7 @@
             # hide nviz tools
             self.nvizToolWin.Hide()
             # unload data
-            self.MapWindow3D.Reset()
+#            self.MapWindow3D.Reset()
             # switch from MapWindowGL to MapWindow
             self._mgr.DetachPane(self.MapWindow3D)
             self.MapWindow3D.Hide()
@@ -459,6 +460,7 @@
             if self.tree:
                 self.tree.EnableItemType(type='3d-raster', enable=False)
+            self.MapWindow.UpdateMap()
         self.toolbars['map'].combo.SetValue (_("2D view"))
         self.toolbars['map'].Enable2D(True)
Modified: grass/branches/develbranch_6/gui/wxpython/gui_modules/nviz_mapdisp.py
--- grass/branches/develbranch_6/gui/wxpython/gui_modules/nviz_mapdisp.py	2009-03-29 21:16:34 UTC (rev 36521)
+++ grass/branches/develbranch_6/gui/wxpython/gui_modules/nviz_mapdisp.py	2009-03-30 07:15:36 UTC (rev 36522)
@@ -128,13 +128,19 @@
         self.Bind(EVT_UPDATE_PROP, self.UpdateMapObjProperties)
         self.Bind(EVT_UPDATE_VIEW, self.UpdateView)
+        self.Bind(wx.EVT_CLOSE, self.OnClose)
+    def OnClose(self, event):
+        # cleanup when window actually closes (on quit) and not just is hidden
+        self.Reset()
     def OnEraseBackground(self, event):
         pass # do nothing, to avoid flashing on MSW
     def OnSize(self, event):
         self.size = self.parent.GetClientSize()
         if self.GetContext():
-            Debug.msg(3, "GLCanvas.OnPaint(): w=%d, h=%d" % \
+            Debug.msg(3, "GLCanvas.OnSize(): w=%d, h=%d" % \
                       (self.size.width, self.size.height))
             self.SetCurrent()
             self.nvizClass.ResizeWindow(self.size.width,
@@ -152,9 +158,10 @@
             self.nvizClass.InitView()
             self.initView = True
+        self.LoadDataLayers()
+        self.UnloadDataLayers()
         if not self.init:
-            self.LoadDataLayers()
             self.ResetView()
             if hasattr(self.parent, "nvizToolWin"):
@@ -174,7 +181,7 @@
                 win.SetItems(self.GetLayerNames('raster'))
             self.init = True
         self.UpdateMap()
     def OnMouseAction(self, event):
@@ -231,10 +238,10 @@
                                self.view['persp']['value'],
                                self.view['twist']['value'])
-        if event.zExag:
+        if event and event.zExag:
             self.nvizClass.SetZExag(self.view['z-exag']['value'])
-        event.Skip()
+        if event: event.Skip()
     def UpdateMap(self, render=True):
@@ -343,39 +350,78 @@
         listOfItems = []
         item = self.tree.GetFirstChild(self.tree.root)[0]
         self._GetDataLayers(item, listOfItems)
         start = time.time()
         while(len(listOfItems) > 0):
             item = listOfItems.pop()
             type = self.tree.GetPyData(item)[0]['type']
-            try:
-                if type == 'raster':
-                    self.LoadRaster(item)
-                elif type == '3d-raster':
-                    self.LoadRaster3d(item)
-            except gcmd.NvizError, e:
-                print >> sys.stderr, "Nviz:" + e.message
+            if item not in self.layers:
+                try:
+                    if type == 'raster':
+                        self.LoadRaster(item)
+                    elif type == '3d-raster':
+                        self.LoadRaster3d(item)
+                except gcmd.NvizError, e:
+                    print >> sys.stderr, "Nviz:" + e.message
-            try:
-                if type == 'vector':
-                    data = self.tree.GetPyData(item)[0]['nviz']
-                    vecType = []
-                    if data and data.has_key('vector'):
-                        for v in ('lines', 'points'):
-                            if data['vector'][v]:
-                                vecType.append(v)
-                    self.LoadVector(item, vecType)
+                try:
+                    if type == 'vector':
+                        data = self.tree.GetPyData(item)[0]['nviz']
+                        vecType = []
+                        if data and data.has_key('vector'):
+                            for v in ('lines', 'points'):
+                                if data['vector'][v]:
+                                    vecType.append(v)
+                        self.LoadVector(item, vecType)
+                self.init = False
         stop = time.time()
         Debug.msg(3, "GLWindow.LoadDataLayers(): time=%f" % (stop-start))
         # print stop - start
+    def UnloadDataLayers(self):
+        """Unload any layers that have been deleted from layer tree"""
+        if not self.tree:
+            return
+        listOfItems = []
+        item = self.tree.GetFirstChild(self.tree.root)[0]
+        self._GetDataLayers(item, listOfItems)
+        start = time.time()
+        for layer in self.layers:
+            if layer not in listOfItems:
+                ltype = self.tree.GetPyData(layer)[0]['type']
+                try:
+                    if ltype == 'raster':
+                        self.UnloadRaster(layer)
+                    elif ltype == '3d-raster':
+                        self.UnloadRaster3d(layer)
+                    elif ltype == 'vector':
+                        data = self.tree.GetPyData(layer)[0]['nviz']
+                        vecType = []
+                                    vecType.append(v)
+                        self.UnloadVector(layer, vecType)
+                    self.UpdateView(None)
+                self.parent.nvizToolWin.UpdateSettings()
+        stop = time.time()
+        Debug.msg(3, "GLWindow.UnloadDataLayers(): time=%f" % (stop-start))
     def SetMapObjProperties(self, item, id, nvizType):
         """Set map object properties
Modified: grass/branches/develbranch_6/gui/wxpython/gui_modules/nviz_tools.py
--- grass/branches/develbranch_6/gui/wxpython/gui_modules/nviz_tools.py	2009-03-29 21:16:34 UTC (rev 36521)
+++ grass/branches/develbranch_6/gui/wxpython/gui_modules/nviz_tools.py	2009-03-30 07:15:36 UTC (rev 36522)
@@ -39,7 +39,8 @@
     def __init__(self, parent=None, id=wx.ID_ANY, title=_("Nviz tools"),
                  pos=wx.DefaultPosition, size=wx.DefaultSize,
-                 style=wx.DEFAULT_FRAME_STYLE, mapWindow=None):
+                 mapWindow=None,
+                 style=wx.CAPTION|wx.MINIMIZE_BOX|wx.RESIZE_BORDER):
         self.parent = parent # MapFrame
         self.lmgr = self.parent.GetLayerManager() # GMFrame
@@ -2304,60 +2305,32 @@
        max)
                 self.FindWindowById(self.win['view']['height'][control]).SetRange(hmin,
        hmax)
-        elif pageId == 'surface':
-            if self.notebook.GetSelection() != self.page['surface']['id']:
-                for page in ('vector', 'volume'):
+        elif pageId in ('surface', 'vector', 'volume'):
+            if self.notebook.GetSelection() != self.page[pageId]['id']:
+                for page in ('surface', 'vector', 'volume'):
                     if self.page[page]['id'] > -1:
                         self.notebook.RemovePage(self.page[page]['id'])
                         self.page[page]['id'] = -1
+                        oldpanel = wx.FindWindowById(self.page[page]['panel'])
+                        oldpanel.Hide()
-                self.page['surface']['id'] = 1
+                self.page[pageId]['id'] = 1
                 self.page['settings']['id'] = 2
-                panel = wx.FindWindowById(self.page['surface']['panel'])
-                self.notebook.InsertPage(n=self.page['surface']['id'],
+                panel = wx.FindWindowById(self.page[pageId]['panel'])
+                self.notebook.InsertPage(n=self.page[pageId]['id'],
                                          page=panel,
                                          text=" %s " % _("Layer properties"),
                                          select=True)
-            self.UpdateSurfacePage(layer, data['surface'])
+            if pageId == 'surface':
+                self.UpdateSurfacePage(layer, data['surface'])
+            elif pageId == 'vector':
+                self.UpdateVectorPage(layer, data['vector'])
+            elif pageId == 'volume':
-        elif pageId == 'vector':
-            if self.notebook.GetSelection() != self.page['vector']['id']:
-                for page in ('surface', 'volume'):
-                    if self.page[page]['id'] > -1:
-                        self.notebook.RemovePage(self.page[page]['id'])
-                        self.page[page]['id'] = -1
-                self.page['vector']['id'] = 1
-                self.page['settings']['id'] = 2
-                panel = wx.FindWindowById(self.page['vector']['panel'])
-                self.notebook.InsertPage(n=self.page['vector']['id'],
-                                         page=panel,
-                                         text=" %s " % _("Layer properties"),
-                                         select=True)
-            self.UpdateVectorPage(layer, data['vector'])
-        elif pageId == 'volume':
-            if self.notebook.GetSelection() != self.page['volume']['id']:
-                for page in ('surface', 'vector'):
-                self.page['volume']['id'] = 1
-                panel = wx.FindWindowById(self.page['volume']['panel'])
-                self.notebook.InsertPage(n=self.page['volume']['id'],
-                                         page=panel,
-                                         select=True)
-            self.UpdateVolumePage(layer, data['volume'])
+        self.notebook.Update()
         self.pageChanging = False
     def UpdateSurfacePage(self, layer, data):
