[GRASS-SVN] r36530 - grass/trunk/lib/vector/Vlib
svn_grass at osgeo.org
Mon Mar 30 10:32:03 EDT 2009
Author: martinl
Date: 2009-03-30 10:32:02 -0400 (Mon, 30 Mar 2009)
New Revision: 36530
grass/trunk/lib/vector/Vlib/build_nat.c
grass/trunk/lib/vector/Vlib/geos.c
ignore dead line in Vect_read_line_geos()
debug message cosmetics
Modified: grass/trunk/lib/vector/Vlib/build_nat.c
--- grass/trunk/lib/vector/Vlib/build_nat.c 2009-03-30 12:20:23 UTC (rev 36529)
+++ grass/trunk/lib/vector/Vlib/build_nat.c 2009-03-30 14:32:02 UTC (rev 36530)
@@ -75,7 +75,7 @@
line = abs(lines[j]);
BLine = plus->Line[line];
offset = BLine->offset;
- G_debug(3, " line[%d] = %d, offset = %ld", j, line, offset);
+ G_debug(3, " line[%d] = %d, offset = %lu", j, line, (unsigned long) offset);
type = Vect_read_line(Map, Points, NULL, line);
if (lines[j] > 0)
direction = GV_FORWARD;
@@ -541,7 +541,7 @@
offset = Map->head.last_offset;
- G_debug(3, "Register line: offset = %ld", offset);
+ G_debug(3, "Register line: offset = %lu", (unsigned long) offset);
lineid = dig_add_line(plus, type, Points, offset);
dig_line_box(Points, &box);
if (lineid == 1)
Modified: grass/trunk/lib/vector/Vlib/geos.c
--- grass/trunk/lib/vector/Vlib/geos.c 2009-03-30 12:20:23 UTC (rev 36529)
+++ grass/trunk/lib/vector/Vlib/geos.c 2009-03-30 14:32:02 UTC (rev 36530)
@@ -51,7 +51,7 @@
dim = 2;
- if (type < 0)
+ if (type < 1) /* ignore dead lines */
return NULL;
return Vect_line_to_geos(Map, Points, type);
