[GRASS-SVN] r36538 - grass/trunk
svn_grass at osgeo.org
Mon Mar 30 14:56:18 EDT 2009
Author: martinl
Date: 2009-03-30 14:56:18 -0400 (Mon, 30 Mar 2009)
New Revision: 36538
grass/trunk/configure
grass/trunk/configure.in
default without-geos
Modified: grass/trunk/configure
--- grass/trunk/configure 2009-03-30 18:44:11 UTC (rev 36537)
+++ grass/trunk/configure 2009-03-30 18:56:18 UTC (rev 36538)
@@ -75,7 +75,7 @@
e.g. '--with-gdal=/usr/local/bin/gdal-config')"
ac_help="$ac_help
--with-geos[=path/geos-config] enable GEOS support (geos-config with path, \
-e.g. '--with-geos=/usr/local/bin/geos-config')"
+e.g. '--with-geos=/usr/local/bin/geos-config', default: no)"
ac_help="$ac_help
--with-includes=DIRS site include files are in DIRS"
ac_help="$ac_help
@@ -3023,6 +3023,8 @@
if test "${with_geos+set}" = set; then
withval="$with_geos"
+else
+ with_geos="no"
fi
@@ -3430,7 +3432,7 @@
# Done checking fortran
echo $ac_n "checking for additional include dirs""... $ac_c" 1>&6
-echo "configure:3434: checking for additional include dirs" >&5
+echo "configure:3436: checking for additional include dirs" >&5
case "$with_includes" in
y | ye | yes | n | no)
{ echo "configure: error: *** You must supply a directory to list --with-includes." 1>&2; exit 1; }
@@ -3453,7 +3455,7 @@
# With libs option
echo $ac_n "checking for additional library dirs""... $ac_c" 1>&6
-echo "configure:3457: checking for additional library dirs" >&5
+echo "configure:3459: checking for additional library dirs" >&5
case "$with_libs" in
{ echo "configure: error: *** You must supply a directory list to --with-libs." 1>&2; exit 1; }
@@ -3487,7 +3489,7 @@
# SVR4 /usr/ucb/install, which tries to use the nonexistent group "staff"
# ./install, which can be erroneously created by make from ./install.sh.
echo $ac_n "checking for a BSD compatible install""... $ac_c" 1>&6
-echo "configure:3491: checking for a BSD compatible install" >&5
+echo "configure:3493: checking for a BSD compatible install" >&5
if test -z "$INSTALL"; then
IFS="${IFS= }"; ac_save_IFS="$IFS"; IFS=":"
@@ -3540,7 +3542,7 @@
# Extract the first word of "flex", so it can be a program name with args.
set dummy flex; ac_word=$2
echo $ac_n "checking for $ac_word""... $ac_c" 1>&6
-echo "configure:3544: checking for $ac_word" >&5
+echo "configure:3546: checking for $ac_word" >&5
if test -n "$LEX"; then
ac_cv_prog_LEX="$LEX" # Let the user override the test.
@@ -3571,13 +3573,13 @@
*) ac_lib=l ;;
esac
echo $ac_n "checking for yywrap in -l$ac_lib""... $ac_c" 1>&6
-echo "configure:3575: checking for yywrap in -l$ac_lib" >&5
+echo "configure:3577: checking for yywrap in -l$ac_lib" >&5
ac_lib_var=`echo $ac_lib'_'yywrap | sed 'y%./+-%__p_%'`
ac_save_LIBS="$LIBS"
LIBS="-l$ac_lib $LIBS"
cat > conftest.$ac_ext <<EOF
-#line 3581 "configure"
+#line 3583 "configure"
#include "confdefs.h"
/* Override any gcc2 internal prototype to avoid an error. */
/* We use char because int might match the return type of a gcc2
@@ -3588,7 +3590,7 @@
yywrap()
; return 0; }
EOF
-if { (eval echo configure:3592: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:3594: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_lib_$ac_lib_var=yes"
else
@@ -3613,7 +3615,7 @@
# Extract the first word of "lex", so it can be a program name with args.
set dummy lex; ac_word=$2
-echo "configure:3617: checking for $ac_word" >&5
+echo "configure:3619: checking for $ac_word" >&5
case "$LEXPATH" in
@@ -3653,7 +3655,7 @@
# Extract the first word of "$ac_prog", so it can be a program name with args.
set dummy $ac_prog; ac_word=$2
-echo "configure:3657: checking for $ac_word" >&5
+echo "configure:3659: checking for $ac_word" >&5
if test -n "$YACC"; then
ac_cv_prog_YACC="$YACC" # Let the user override the test.
@@ -3684,7 +3686,7 @@
# Extract the first word of "yacc", so it can be a program name with args.
set dummy yacc; ac_word=$2
-echo "configure:3688: checking for $ac_word" >&5
+echo "configure:3690: checking for $ac_word" >&5
case "$YACCPATH" in
@@ -3722,7 +3724,7 @@
# Extract the first word of "ranlib", so it can be a program name with args.
set dummy ranlib; ac_word=$2
-echo "configure:3726: checking for $ac_word" >&5
+echo "configure:3728: checking for $ac_word" >&5
if test -n "$RANLIB"; then
ac_cv_prog_RANLIB="$RANLIB" # Let the user override the test.
@@ -3751,7 +3753,7 @@
-echo "configure:3755: checking for $ac_word" >&5
+echo "configure:3757: checking for $ac_word" >&5
if test -n "$AR"; then
ac_cv_prog_AR="$AR" # Let the user override the test.
@@ -3782,7 +3784,7 @@
-echo "configure:3786: checking for $ac_word" >&5
+echo "configure:3788: checking for $ac_word" >&5
if test -n "$ENV"; then
ac_cv_prog_ENV="$ENV" # Let the user override the test.
@@ -3811,7 +3813,7 @@
# Extract the first word of "perl", so it can be a program name with args.
set dummy perl; ac_word=$2
-echo "configure:3815: checking for $ac_word" >&5
+echo "configure:3817: checking for $ac_word" >&5
case "$PERL" in
@@ -3842,10 +3844,10 @@
fi
echo $ac_n "checking for ANSI C header files""... $ac_c" 1>&6
-echo "configure:3846: checking for ANSI C header files" >&5
+echo "configure:3848: checking for ANSI C header files" >&5
-#line 3849 "configure"
+#line 3851 "configure"
#include <stdlib.h>
#include <stdarg.h>
@@ -3853,7 +3855,7 @@
#include <float.h>
EOF
ac_try="$ac_cpp conftest.$ac_ext >/dev/null 2>conftest.out"
-{ (eval echo configure:3857: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:3859: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
ac_err=`grep -v '^ *+' conftest.out | grep -v "^conftest.${ac_ext}\$"`
if test -z "$ac_err"; then
rm -rf conftest*
@@ -3870,7 +3872,7 @@
if test $ac_cv_header_stdc = yes; then
# SunOS 4.x string.h does not declare mem*, contrary to ANSI.
-#line 3874 "configure"
+#line 3876 "configure"
#include <string.h>
EOF
@@ -3888,7 +3890,7 @@
# ISC 2.0.2 stdlib.h does not declare free, contrary to ANSI.
-#line 3892 "configure"
+#line 3894 "configure"
#include <stdlib.h>
EOF
@@ -3909,7 +3911,7 @@
else
-#line 3913 "configure"
+#line 3915 "configure"
#include <ctype.h>
#define ISLOWER(c) ('a' <= (c) && (c) <= 'z')
@@ -3920,7 +3922,7 @@
exit (0); }
EOF
-if { (eval echo configure:3924: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext} && (./conftest; exit) 2>/dev/null
+if { (eval echo configure:3926: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext} && (./conftest; exit) 2>/dev/null
then
else
@@ -3947,15 +3949,15 @@
do
ac_safe=`echo "$ac_hdr" | sed 'y%./+-%__p_%'`
echo $ac_n "checking for $ac_hdr""... $ac_c" 1>&6
-echo "configure:3951: checking for $ac_hdr" >&5
+echo "configure:3953: checking for $ac_hdr" >&5
-#line 3954 "configure"
+#line 3956 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:3959: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:3961: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -3984,15 +3986,15 @@
do
-echo "configure:3988: checking for $ac_hdr" >&5
+echo "configure:3990: checking for $ac_hdr" >&5
-#line 3991 "configure"
+#line 3993 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:3996: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:3998: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -4021,15 +4023,15 @@
do
-echo "configure:4025: checking for $ac_hdr" >&5
+echo "configure:4027: checking for $ac_hdr" >&5
-#line 4028 "configure"
+#line 4030 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:4033: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:4035: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -4058,15 +4060,15 @@
do
-echo "configure:4062: checking for $ac_hdr" >&5
+echo "configure:4064: checking for $ac_hdr" >&5
-#line 4065 "configure"
+#line 4067 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:4070: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:4072: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -4095,15 +4097,15 @@
do
-echo "configure:4099: checking for $ac_hdr" >&5
+echo "configure:4101: checking for $ac_hdr" >&5
-#line 4102 "configure"
+#line 4104 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:4107: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:4109: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -4129,10 +4131,10 @@
done
echo $ac_n "checking whether time.h and sys/time.h may both be included""... $ac_c" 1>&6
-echo "configure:4133: checking whether time.h and sys/time.h may both be included" >&5
+echo "configure:4135: checking whether time.h and sys/time.h may both be included" >&5
-#line 4136 "configure"
+#line 4138 "configure"
#include <sys/types.h>
#include <sys/time.h>
@@ -4141,7 +4143,7 @@
struct tm *tp;
; return 0; }
EOF
-if { (eval echo configure:4145: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:4147: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
rm -rf conftest*
ac_cv_header_time=yes
else
@@ -4161,10 +4163,10 @@
fi
echo $ac_n "checking for off_t""... $ac_c" 1>&6
-echo "configure:4165: checking for off_t" >&5
+echo "configure:4167: checking for off_t" >&5
-#line 4168 "configure"
+#line 4170 "configure"
#if STDC_HEADERS
@@ -4191,10 +4193,10 @@
fi
echo $ac_n "checking for uid_t in sys/types.h""... $ac_c" 1>&6
-echo "configure:4195: checking for uid_t in sys/types.h" >&5
+echo "configure:4197: checking for uid_t in sys/types.h" >&5
-#line 4198 "configure"
+#line 4200 "configure"
EOF
@@ -4222,10 +4224,10 @@
fi
echo $ac_n "checking return type of signal handlers""... $ac_c" 1>&6
-echo "configure:4226: checking return type of signal handlers" >&5
+echo "configure:4228: checking return type of signal handlers" >&5
-#line 4229 "configure"
+#line 4231 "configure"
#include <signal.h>
@@ -4242,7 +4244,7 @@
int i;
; return 0; }
EOF
-if { (eval echo configure:4246: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:4248: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
rm -rf conftest*
ac_cv_type_signal=void
else
@@ -4260,10 +4262,10 @@
echo $ac_n "checking for Cygwin environment""... $ac_c" 1>&6
-echo "configure:4264: checking for Cygwin environment" >&5
+echo "configure:4266: checking for Cygwin environment" >&5
-#line 4267 "configure"
+#line 4269 "configure"
int main() {
@@ -4274,7 +4276,7 @@
return __CYGWIN__;
; return 0; }
EOF
-if { (eval echo configure:4278: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:4280: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
rm -rf conftest*
ac_cv_cygwin=yes
else
@@ -4292,10 +4294,10 @@
for ac_func in ftime gethostname gettimeofday lseek nice time uname
do
echo $ac_n "checking for $ac_func""... $ac_c" 1>&6
-echo "configure:4296: checking for $ac_func" >&5
+echo "configure:4298: checking for $ac_func" >&5
-#line 4299 "configure"
+#line 4301 "configure"
/* System header to define __stub macros and hopefully few prototypes,
which can conflict with char $ac_func(); below. */
@@ -4318,7 +4320,7 @@
; return 0; }
EOF
-if { (eval echo configure:4322: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4324: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_func_$ac_func=yes"
else
@@ -4344,10 +4346,10 @@
for ac_func in seteuid setpriority setreuid setruid
do
-echo "configure:4348: checking for $ac_func" >&5
+echo "configure:4350: checking for $ac_func" >&5
-#line 4351 "configure"
+#line 4353 "configure"
@@ -4370,7 +4372,7 @@
; return 0; }
EOF
-if { (eval echo configure:4374: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4376: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -4396,10 +4398,10 @@
for ac_func in drand48
do
-echo "configure:4400: checking for $ac_func" >&5
+echo "configure:4402: checking for $ac_func" >&5
-#line 4403 "configure"
+#line 4405 "configure"
@@ -4422,7 +4424,7 @@
; return 0; }
EOF
-if { (eval echo configure:4426: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4428: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -4448,10 +4450,10 @@
for ac_func in putenv setenv
do
-echo "configure:4452: checking for $ac_func" >&5
+echo "configure:4454: checking for $ac_func" >&5
-#line 4455 "configure"
+#line 4457 "configure"
@@ -4474,7 +4476,7 @@
; return 0; }
EOF
-if { (eval echo configure:4478: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4480: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -4500,10 +4502,10 @@
for ac_func in nanosleep
do
-echo "configure:4504: checking for $ac_func" >&5
+echo "configure:4506: checking for $ac_func" >&5
-#line 4507 "configure"
+#line 4509 "configure"
@@ -4526,7 +4528,7 @@
; return 0; }
EOF
-if { (eval echo configure:4530: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4532: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -4551,13 +4553,13 @@
if test "$cross_compiling" != "yes" ; then
echo $ac_n "checking whether setpgrp takes no argument""... $ac_c" 1>&6
-echo "configure:4555: checking whether setpgrp takes no argument" >&5
+echo "configure:4557: checking whether setpgrp takes no argument" >&5
if test "$cross_compiling" = yes; then
{ echo "configure: error: cannot check setpgrp if cross compiling" 1>&2; exit 1; }
else
-#line 4561 "configure"
+#line 4563 "configure"
#ifdef HAVE_UNISTD_H
@@ -4577,7 +4579,7 @@
EOF
-if { (eval echo configure:4581: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext} && (./conftest; exit) 2>/dev/null
+if { (eval echo configure:4583: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext} && (./conftest; exit) 2>/dev/null
then
ac_cv_func_setpgrp_void=no
else
@@ -4605,16 +4607,16 @@
fi
echo $ac_n "checking for long long int""... $ac_c" 1>&6
-echo "configure:4609: checking for long long int" >&5
+echo "configure:4611: checking for long long int" >&5
-#line 4611 "configure"
+#line 4613 "configure"
int main() {
long long int x;
; return 0; }
EOF
-if { (eval echo configure:4618: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:4620: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
rm -rf conftest*
echo "$ac_t""yes" 1>&6
@@ -4634,7 +4636,7 @@
rm -f conftest*
echo $ac_n "checking for W11""... $ac_c" 1>&6
-echo "configure:4638: checking for W11" >&5
+echo "configure:4640: checking for W11" >&5
case "$enable_w11" in
yes|no) echo "$ac_t"""$enable_w11"" 1>&6 ;;
*) { echo "configure: error: *** You must answer yes or no." 1>&2; exit 1; } ;;
@@ -4662,7 +4664,7 @@
# Uses ac_ vars as temps to allow command line to override cache and checks.
# --without-x overrides everything else, but does not touch the cache.
echo $ac_n "checking for X""... $ac_c" 1>&6
-echo "configure:4666: checking for X" >&5
+echo "configure:4668: checking for X" >&5
# Check whether --with-x or --without-x was given.
if test "${with_x+set}" = set; then
@@ -4722,12 +4724,12 @@
# First, try using that file with no special directory specified.
-#line 4726 "configure"
+#line 4728 "configure"
#include <$x_direct_test_include>
EOF
-{ (eval echo configure:4731: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:4733: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -4796,14 +4798,14 @@
LIBS="-l$x_direct_test_library $LIBS"
-#line 4800 "configure"
+#line 4802 "configure"
int main() {
${x_direct_test_function}()
; return 0; }
EOF
-if { (eval echo configure:4807: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4809: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
LIBS="$ac_save_LIBS"
# We can link X programs with no special library path.
@@ -4908,17 +4910,17 @@
case "`(uname -sr) 2>/dev/null`" in
"SunOS 5"*)
echo $ac_n "checking whether -R must be followed by a space""... $ac_c" 1>&6
-echo "configure:4912: checking whether -R must be followed by a space" >&5
+echo "configure:4914: checking whether -R must be followed by a space" >&5
ac_xsave_LIBS="$LIBS"; LIBS="$LIBS -R$x_libraries"
-#line 4915 "configure"
+#line 4917 "configure"
int main() {
; return 0; }
EOF
-if { (eval echo configure:4922: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4924: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
ac_R_nospace=yes
else
@@ -4934,14 +4936,14 @@
else
LIBS="$ac_xsave_LIBS -R $x_libraries"
-#line 4938 "configure"
+#line 4940 "configure"
int main() {
; return 0; }
EOF
-if { (eval echo configure:4945: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4947: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
ac_R_space=yes
else
@@ -4973,13 +4975,13 @@
# libraries were built with DECnet support. And karl at cs.umb.edu says
# the Alpha needs dnet_stub (dnet does not exist).
echo $ac_n "checking for dnet_ntoa in -ldnet""... $ac_c" 1>&6
-echo "configure:4977: checking for dnet_ntoa in -ldnet" >&5
+echo "configure:4979: checking for dnet_ntoa in -ldnet" >&5
ac_lib_var=`echo dnet'_'dnet_ntoa | sed 'y%./+-%__p_%'`
LIBS="-ldnet $LIBS"
-#line 4983 "configure"
+#line 4985 "configure"
@@ -4990,7 +4992,7 @@
dnet_ntoa()
; return 0; }
EOF
-if { (eval echo configure:4994: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4996: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -5011,13 +5013,13 @@
if test $ac_cv_lib_dnet_dnet_ntoa = no; then
echo $ac_n "checking for dnet_ntoa in -ldnet_stub""... $ac_c" 1>&6
-echo "configure:5015: checking for dnet_ntoa in -ldnet_stub" >&5
+echo "configure:5017: checking for dnet_ntoa in -ldnet_stub" >&5
ac_lib_var=`echo dnet_stub'_'dnet_ntoa | sed 'y%./+-%__p_%'`
LIBS="-ldnet_stub $LIBS"
-#line 5021 "configure"
+#line 5023 "configure"
@@ -5028,7 +5030,7 @@
dnet_ntoa()
; return 0; }
EOF
-if { (eval echo configure:5032: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5034: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -5056,10 +5058,10 @@
# The nsl library prevents programs from opening the X display
# on Irix 5.2, according to dickey at clark.net.
echo $ac_n "checking for gethostbyname""... $ac_c" 1>&6
-echo "configure:5060: checking for gethostbyname" >&5
+echo "configure:5062: checking for gethostbyname" >&5
-#line 5063 "configure"
+#line 5065 "configure"
which can conflict with char gethostbyname(); below. */
@@ -5082,7 +5084,7 @@
; return 0; }
EOF
-if { (eval echo configure:5086: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5088: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_func_gethostbyname=yes"
else
@@ -5102,13 +5104,13 @@
if test $ac_cv_func_gethostbyname = no; then
echo $ac_n "checking for gethostbyname in -lnsl""... $ac_c" 1>&6
-echo "configure:5106: checking for gethostbyname in -lnsl" >&5
+echo "configure:5108: checking for gethostbyname in -lnsl" >&5
ac_lib_var=`echo nsl'_'gethostbyname | sed 'y%./+-%__p_%'`
LIBS="-lnsl $LIBS"
-#line 5112 "configure"
+#line 5114 "configure"
@@ -5119,7 +5121,7 @@
gethostbyname()
; return 0; }
EOF
-if { (eval echo configure:5123: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5125: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -5148,10 +5150,10 @@
# -lsocket must be given before -lnsl if both are needed.
# We assume that if connect needs -lnsl, so does gethostbyname.
echo $ac_n "checking for connect""... $ac_c" 1>&6
-echo "configure:5152: checking for connect" >&5
+echo "configure:5154: checking for connect" >&5
-#line 5155 "configure"
+#line 5157 "configure"
which can conflict with char connect(); below. */
@@ -5174,7 +5176,7 @@
; return 0; }
EOF
-if { (eval echo configure:5178: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5180: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_func_connect=yes"
else
@@ -5194,13 +5196,13 @@
if test $ac_cv_func_connect = no; then
echo $ac_n "checking for connect in -lsocket""... $ac_c" 1>&6
-echo "configure:5198: checking for connect in -lsocket" >&5
+echo "configure:5200: checking for connect in -lsocket" >&5
ac_lib_var=`echo socket'_'connect | sed 'y%./+-%__p_%'`
LIBS="-lsocket $X_EXTRA_LIBS $LIBS"
-#line 5204 "configure"
+#line 5206 "configure"
@@ -5211,7 +5213,7 @@
connect()
; return 0; }
EOF
-if { (eval echo configure:5215: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5217: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -5234,10 +5236,10 @@
# gomez at mi.uni-erlangen.de says -lposix is necessary on A/UX.
echo $ac_n "checking for remove""... $ac_c" 1>&6
-echo "configure:5238: checking for remove" >&5
+echo "configure:5240: checking for remove" >&5
-#line 5241 "configure"
+#line 5243 "configure"
which can conflict with char remove(); below. */
@@ -5260,7 +5262,7 @@
; return 0; }
EOF
-if { (eval echo configure:5264: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5266: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_func_remove=yes"
else
@@ -5280,13 +5282,13 @@
if test $ac_cv_func_remove = no; then
echo $ac_n "checking for remove in -lposix""... $ac_c" 1>&6
-echo "configure:5284: checking for remove in -lposix" >&5
+echo "configure:5286: checking for remove in -lposix" >&5
ac_lib_var=`echo posix'_'remove | sed 'y%./+-%__p_%'`
LIBS="-lposix $LIBS"
-#line 5290 "configure"
+#line 5292 "configure"
@@ -5297,7 +5299,7 @@
remove()
; return 0; }
EOF
-if { (eval echo configure:5301: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5303: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -5320,10 +5322,10 @@
# BSDI BSD/OS 2.1 needs -lipc for XOpenDisplay.
echo $ac_n "checking for shmat""... $ac_c" 1>&6
-echo "configure:5324: checking for shmat" >&5
+echo "configure:5326: checking for shmat" >&5
-#line 5327 "configure"
+#line 5329 "configure"
which can conflict with char shmat(); below. */
@@ -5346,7 +5348,7 @@
; return 0; }
EOF
-if { (eval echo configure:5350: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5352: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_func_shmat=yes"
else
@@ -5366,13 +5368,13 @@
if test $ac_cv_func_shmat = no; then
echo $ac_n "checking for shmat in -lipc""... $ac_c" 1>&6
-echo "configure:5370: checking for shmat in -lipc" >&5
+echo "configure:5372: checking for shmat in -lipc" >&5
ac_lib_var=`echo ipc'_'shmat | sed 'y%./+-%__p_%'`
LIBS="-lipc $LIBS"
-#line 5376 "configure"
+#line 5378 "configure"
@@ -5383,7 +5385,7 @@
shmat()
; return 0; }
EOF
-if { (eval echo configure:5387: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5389: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -5415,13 +5417,13 @@
# libraries we check for below, so use a different variable.
# --interran at uluru.Stanford.EDU, kb at cs.umb.edu.
echo $ac_n "checking for IceConnectionNumber in -lICE""... $ac_c" 1>&6
-echo "configure:5419: checking for IceConnectionNumber in -lICE" >&5
+echo "configure:5421: checking for IceConnectionNumber in -lICE" >&5
ac_lib_var=`echo ICE'_'IceConnectionNumber | sed 'y%./+-%__p_%'`
LIBS="-lICE $X_EXTRA_LIBS $LIBS"
-#line 5425 "configure"
+#line 5427 "configure"
@@ -5432,7 +5434,7 @@
IceConnectionNumber()
; return 0; }
EOF
-if { (eval echo configure:5436: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5438: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -5472,12 +5474,12 @@
LIBS=""
echo $ac_n "checking for library containing cuserid""... $ac_c" 1>&6
-echo "configure:5476: checking for library containing cuserid" >&5
+echo "configure:5478: checking for library containing cuserid" >&5
ac_func_search_save_LIBS="$LIBS"
ac_cv_search_cuserid="no"
-#line 5481 "configure"
+#line 5483 "configure"
@@ -5488,7 +5490,7 @@
cuserid()
; return 0; }
EOF
-if { (eval echo configure:5492: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5494: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
ac_cv_search_cuserid="none required"
else
@@ -5499,7 +5501,7 @@
test "$ac_cv_search_cuserid" = "no" && for i in compat; do
LIBS="-l$i $ac_func_search_save_LIBS"
-#line 5503 "configure"
+#line 5505 "configure"
@@ -5510,7 +5512,7 @@
cuserid()
; return 0; }
EOF
-if { (eval echo configure:5514: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5516: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
ac_cv_search_cuserid="-l$i"
break
@@ -5536,10 +5538,10 @@
# Note: -lxdr -liberty -lws2_32 is for MinGW
echo $ac_n "checking for xdrmem_create""... $ac_c" 1>&6
-echo "configure:5540: checking for xdrmem_create" >&5
+echo "configure:5542: checking for xdrmem_create" >&5
-#line 5543 "configure"
+#line 5545 "configure"
which can conflict with char xdrmem_create(); below. */
@@ -5562,7 +5564,7 @@
; return 0; }
EOF
-if { (eval echo configure:5566: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5568: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_func_xdrmem_create=yes"
else
@@ -5580,13 +5582,13 @@
echo "$ac_t""no" 1>&6
echo $ac_n "checking for xdrmem_create in -lsun""... $ac_c" 1>&6
-echo "configure:5584: checking for xdrmem_create in -lsun" >&5
+echo "configure:5586: checking for xdrmem_create in -lsun" >&5
ac_lib_var=`echo sun'_'xdrmem_create | sed 'y%./+-%__p_%'`
LIBS="-lsun $LIBS"
-#line 5590 "configure"
+#line 5592 "configure"
@@ -5597,7 +5599,7 @@
xdrmem_create()
; return 0; }
EOF
-if { (eval echo configure:5601: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5603: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -5616,13 +5618,13 @@
echo $ac_n "checking for xdrmem_create in -lnsl""... $ac_c" 1>&6
-echo "configure:5620: checking for xdrmem_create in -lnsl" >&5
+echo "configure:5622: checking for xdrmem_create in -lnsl" >&5
ac_lib_var=`echo nsl'_'xdrmem_create | sed 'y%./+-%__p_%'`
LIBS="-lnsl $LIBS"
-#line 5626 "configure"
+#line 5628 "configure"
@@ -5633,7 +5635,7 @@
xdrmem_create()
; return 0; }
EOF
-if { (eval echo configure:5637: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5639: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -5652,13 +5654,13 @@
echo $ac_n "checking for xdrmem_create in -lrpclib""... $ac_c" 1>&6
-echo "configure:5656: checking for xdrmem_create in -lrpclib" >&5
+echo "configure:5658: checking for xdrmem_create in -lrpclib" >&5
ac_lib_var=`echo rpclib'_'xdrmem_create | sed 'y%./+-%__p_%'`
LIBS="-lrpclib $LIBS"
-#line 5662 "configure"
+#line 5664 "configure"
@@ -5669,7 +5671,7 @@
xdrmem_create()
; return 0; }
EOF
-if { (eval echo configure:5673: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5675: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -5688,13 +5690,13 @@
echo $ac_n "checking for xdrmem_create in -lxdr""... $ac_c" 1>&6
-echo "configure:5692: checking for xdrmem_create in -lxdr" >&5
+echo "configure:5694: checking for xdrmem_create in -lxdr" >&5
ac_lib_var=`echo xdr'_'xdrmem_create | sed 'y%./+-%__p_%'`
LIBS="-lxdr -liberty -lws2_32 $LIBS"
-#line 5698 "configure"
+#line 5700 "configure"
@@ -5705,7 +5707,7 @@
xdrmem_create()
; return 0; }
EOF
-if { (eval echo configure:5709: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5711: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -5739,10 +5741,10 @@
for ac_func in asprintf
do
-echo "configure:5743: checking for $ac_func" >&5
+echo "configure:5745: checking for $ac_func" >&5
-#line 5746 "configure"
+#line 5748 "configure"
@@ -5765,7 +5767,7 @@
; return 0; }
EOF
-if { (eval echo configure:5769: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5771: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -5792,10 +5794,10 @@
# Test if mathlib needs -lm flag or is included with libc
echo $ac_n "checking for atan""... $ac_c" 1>&6
-echo "configure:5796: checking for atan" >&5
+echo "configure:5798: checking for atan" >&5
-#line 5799 "configure"
+#line 5801 "configure"
which can conflict with char atan(); below. */
@@ -5818,7 +5820,7 @@
; return 0; }
EOF
-if { (eval echo configure:5822: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5824: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_func_atan=yes"
else
@@ -5836,13 +5838,13 @@
echo $ac_n "checking for atan in -lm""... $ac_c" 1>&6
-echo "configure:5840: checking for atan in -lm" >&5
+echo "configure:5842: checking for atan in -lm" >&5
ac_lib_var=`echo m'_'atan | sed 'y%./+-%__p_%'`
LIBS="-lm $LIBS"
-#line 5846 "configure"
+#line 5848 "configure"
@@ -5853,7 +5855,7 @@
atan()
; return 0; }
EOF
-if { (eval echo configure:5857: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5859: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -5880,10 +5882,10 @@
echo $ac_n "checking for dlsym""... $ac_c" 1>&6
-echo "configure:5884: checking for dlsym" >&5
+echo "configure:5886: checking for dlsym" >&5
-#line 5887 "configure"
+#line 5889 "configure"
which can conflict with char dlsym(); below. */
@@ -5906,7 +5908,7 @@
; return 0; }
EOF
-if { (eval echo configure:5910: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5912: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_func_dlsym=yes"
else
@@ -5924,13 +5926,13 @@
echo $ac_n "checking for dlsym in -ldl""... $ac_c" 1>&6
-echo "configure:5928: checking for dlsym in -ldl" >&5
+echo "configure:5930: checking for dlsym in -ldl" >&5
ac_lib_var=`echo dl'_'dlsym | sed 'y%./+-%__p_%'`
LIBS="-ldl $LIBS"
-#line 5934 "configure"
+#line 5936 "configure"
@@ -5941,7 +5943,7 @@
dlsym()
; return 0; }
EOF
-if { (eval echo configure:5945: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5947: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -5968,10 +5970,10 @@
echo $ac_n "checking for iconv""... $ac_c" 1>&6
-echo "configure:5972: checking for iconv" >&5
+echo "configure:5974: checking for iconv" >&5
-#line 5975 "configure"
+#line 5977 "configure"
which can conflict with char iconv(); below. */
@@ -5994,7 +5996,7 @@
; return 0; }
EOF
-if { (eval echo configure:5998: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6000: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_func_iconv=yes"
else
@@ -6012,13 +6014,13 @@
echo $ac_n "checking for iconv in -liconv""... $ac_c" 1>&6
-echo "configure:6016: checking for iconv in -liconv" >&5
+echo "configure:6018: checking for iconv in -liconv" >&5
ac_lib_var=`echo iconv'_'iconv | sed 'y%./+-%__p_%'`
LIBS="-liconv $LIBS"
-#line 6022 "configure"
+#line 6024 "configure"
@@ -6029,7 +6031,7 @@
iconv()
; return 0; }
EOF
-if { (eval echo configure:6033: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6035: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -6048,13 +6050,13 @@
echo $ac_n "checking for iconv in -lgiconv""... $ac_c" 1>&6
-echo "configure:6052: checking for iconv in -lgiconv" >&5
+echo "configure:6054: checking for iconv in -lgiconv" >&5
ac_lib_var=`echo giconv'_'iconv | sed 'y%./+-%__p_%'`
LIBS="-lgiconv $LIBS"
-#line 6058 "configure"
+#line 6060 "configure"
@@ -6065,7 +6067,7 @@
iconv()
; return 0; }
EOF
-if { (eval echo configure:6069: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6071: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -6084,10 +6086,10 @@
echo $ac_n "checking for libiconv""... $ac_c" 1>&6
-echo "configure:6088: checking for libiconv" >&5
+echo "configure:6090: checking for libiconv" >&5
-#line 6091 "configure"
+#line 6093 "configure"
which can conflict with char libiconv(); below. */
@@ -6110,7 +6112,7 @@
; return 0; }
EOF
-if { (eval echo configure:6114: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6116: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_func_libiconv=yes"
else
@@ -6128,13 +6130,13 @@
echo $ac_n "checking for libiconv in -liconv""... $ac_c" 1>&6
-echo "configure:6132: checking for libiconv in -liconv" >&5
+echo "configure:6134: checking for libiconv in -liconv" >&5
ac_lib_var=`echo iconv'_'libiconv | sed 'y%./+-%__p_%'`
-#line 6138 "configure"
+#line 6140 "configure"
@@ -6145,7 +6147,7 @@
libiconv()
; return 0; }
EOF
-if { (eval echo configure:6149: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6151: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -6164,13 +6166,13 @@
echo $ac_n "checking for libiconv in -lgiconv""... $ac_c" 1>&6
-echo "configure:6168: checking for libiconv in -lgiconv" >&5
+echo "configure:6170: checking for libiconv in -lgiconv" >&5
ac_lib_var=`echo giconv'_'libiconv | sed 'y%./+-%__p_%'`
-#line 6174 "configure"
+#line 6176 "configure"
@@ -6181,7 +6183,7 @@
libiconv()
; return 0; }
EOF
-if { (eval echo configure:6185: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6187: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -6218,10 +6220,10 @@
have_socket=1
echo $ac_n "checking for socket""... $ac_c" 1>&6
-echo "configure:6222: checking for socket" >&5
+echo "configure:6224: checking for socket" >&5
-#line 6225 "configure"
+#line 6227 "configure"
which can conflict with char socket(); below. */
@@ -6244,7 +6246,7 @@
; return 0; }
EOF
-if { (eval echo configure:6248: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6250: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_func_socket=yes"
else
@@ -6262,13 +6264,13 @@
echo $ac_n "checking for socket in -lsocket""... $ac_c" 1>&6
-echo "configure:6266: checking for socket in -lsocket" >&5
+echo "configure:6268: checking for socket in -lsocket" >&5
ac_lib_var=`echo socket'_'socket | sed 'y%./+-%__p_%'`
LIBS="-lsocket $LIBS"
-#line 6272 "configure"
+#line 6274 "configure"
@@ -6279,7 +6281,7 @@
socket()
; return 0; }
EOF
-if { (eval echo configure:6283: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6285: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -6327,7 +6329,7 @@
echo $ac_n "checking for location of zlib includes""... $ac_c" 1>&6
-echo "configure:6331: checking for location of zlib includes" >&5
+echo "configure:6333: checking for location of zlib includes" >&5
case "$with_zlib_includes" in
{ echo "configure: error: *** You must supply a directory to --with-zlib-includes." 1>&2; exit 1; }
@@ -6353,15 +6355,15 @@
do
-echo "configure:6357: checking for $ac_hdr" >&5
+echo "configure:6359: checking for $ac_hdr" >&5
-#line 6360 "configure"
+#line 6362 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:6365: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:6367: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -6395,7 +6397,7 @@
echo $ac_n "checking for location of zlib library""... $ac_c" 1>&6
-echo "configure:6399: checking for location of zlib library" >&5
+echo "configure:6401: checking for location of zlib library" >&5
case "$with_zlib_libs" in
{ echo "configure: error: *** You must supply a directory to --with-zlib-libs." 1>&2; exit 1; }
@@ -6420,13 +6422,13 @@
echo $ac_n "checking for deflate in -lz""... $ac_c" 1>&6
-echo "configure:6424: checking for deflate in -lz" >&5
+echo "configure:6426: checking for deflate in -lz" >&5
ac_lib_var=`echo z'_'deflate | sed 'y%./+-%__p_%'`
LIBS="-lz $LIBS"
-#line 6430 "configure"
+#line 6432 "configure"
@@ -6437,7 +6439,7 @@
deflate()
; return 0; }
EOF
-if { (eval echo configure:6441: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6443: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -6485,7 +6487,7 @@
echo $ac_n "checking for location of External PROJ.4 includes""... $ac_c" 1>&6
-echo "configure:6489: checking for location of External PROJ.4 includes" >&5
+echo "configure:6491: checking for location of External PROJ.4 includes" >&5
case "$with_proj_includes" in
{ echo "configure: error: *** You must supply a directory to --with-proj-includes." 1>&2; exit 1; }
@@ -6511,15 +6513,15 @@
do
-echo "configure:6515: checking for $ac_hdr" >&5
+echo "configure:6517: checking for $ac_hdr" >&5
-#line 6518 "configure"
+#line 6520 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:6523: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:6525: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -6556,7 +6558,7 @@
else
echo $ac_n "checking External PROJ.4 version""... $ac_c" 1>&6
-echo "configure:6560: checking External PROJ.4 version" >&5
+echo "configure:6562: checking External PROJ.4 version" >&5
ac_save_cppflags="$CPPFLAGS"
CPPFLAGS="$PROJINC $CPPFLAGS"
@@ -6564,7 +6566,7 @@
echo "$ac_t""unknown (cross-compiling)" 1>&6
else
-#line 6568 "configure"
+#line 6570 "configure"
#include <stdio.h>
@@ -6576,7 +6578,7 @@
EOF
-if { (eval echo configure:6580: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext} && (./conftest; exit) 2>/dev/null
+if { (eval echo configure:6582: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext} && (./conftest; exit) 2>/dev/null
then
proj_ver=`cat conftestdata`
echo "$ac_t""$proj_ver" 1>&6
@@ -6601,7 +6603,7 @@
echo $ac_n "checking for location of External PROJ.4 library""... $ac_c" 1>&6
-echo "configure:6605: checking for location of External PROJ.4 library" >&5
+echo "configure:6607: checking for location of External PROJ.4 library" >&5
case "$with_proj_libs" in
{ echo "configure: error: *** You must supply a directory to --with-proj-libs." 1>&2; exit 1; }
@@ -6626,13 +6628,13 @@
echo $ac_n "checking for pj_get_def in -lproj""... $ac_c" 1>&6
-echo "configure:6630: checking for pj_get_def in -lproj" >&5
+echo "configure:6632: checking for pj_get_def in -lproj" >&5
ac_lib_var=`echo proj'_'pj_get_def | sed 'y%./+-%__p_%'`
LIBS="-lproj $LIBS"
-#line 6636 "configure"
+#line 6638 "configure"
@@ -6643,7 +6645,7 @@
pj_get_def()
; return 0; }
EOF
-if { (eval echo configure:6647: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6649: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -6677,7 +6679,7 @@
echo $ac_n "checking for location of External PROJ.4 data files""... $ac_c" 1>&6
-echo "configure:6681: checking for location of External PROJ.4 data files" >&5
+echo "configure:6683: checking for location of External PROJ.4 data files" >&5
case "$with_proj_share" in
{ echo "configure: error: *** You must supply a directory to --with-proj-share." 1>&2; exit 1; }
@@ -6701,14 +6703,14 @@
# LOC_CHECK_SHARE does not work when cross compiling
if test "$cross_compiling" = "yes" ; then
echo $ac_n "checking for epsg""... $ac_c" 1>&6
-echo "configure:6705: checking for epsg" >&5
+echo "configure:6707: checking for epsg" >&5
else
ac_safe=`echo "$PROJSHARE/epsg" | sed 'y%./+-%__p_%'`
echo $ac_n "checking for $PROJSHARE/epsg""... $ac_c" 1>&6
-echo "configure:6712: checking for $PROJSHARE/epsg" >&5
+echo "configure:6714: checking for $PROJSHARE/epsg" >&5
{ echo "configure: error: Cannot check for file existence when cross compiling" 1>&2; exit 1; }
@@ -6740,7 +6742,7 @@
# Extract the first word of "nad2bin", so it can be a program name with args.
set dummy nad2bin; ac_word=$2
-echo "configure:6744: checking for $ac_word" >&5
+echo "configure:6746: checking for $ac_word" >&5
case "$NAD2BIN" in
@@ -6780,7 +6782,7 @@
echo $ac_n "checking whether to use regex""... $ac_c" 1>&6
-echo "configure:6784: checking whether to use regex" >&5
+echo "configure:6786: checking whether to use regex" >&5
echo "$ac_t"""$with_regex"" 1>&6
case "$with_regex" in
"no") USE_REGEX= ;;
@@ -6800,7 +6802,7 @@
echo $ac_n "checking for location of regex includes""... $ac_c" 1>&6
-echo "configure:6804: checking for location of regex includes" >&5
+echo "configure:6806: checking for location of regex includes" >&5
case "$with_regex_includes" in
{ echo "configure: error: *** You must supply a directory to --with-regex-includes." 1>&2; exit 1; }
@@ -6826,15 +6828,15 @@
do
-echo "configure:6830: checking for $ac_hdr" >&5
+echo "configure:6832: checking for $ac_hdr" >&5
-#line 6833 "configure"
+#line 6835 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:6838: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:6840: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -6868,7 +6870,7 @@
echo $ac_n "checking for location of regex library""... $ac_c" 1>&6
-echo "configure:6872: checking for location of regex library" >&5
+echo "configure:6874: checking for location of regex library" >&5
case "$with_regex_libs" in
{ echo "configure: error: *** You must supply a directory to --with-regex-libs." 1>&2; exit 1; }
@@ -6893,10 +6895,10 @@
LIBS=" $LIBS"
LDFLAGS=" $LDFLAGS"
echo $ac_n "checking for regcomp""... $ac_c" 1>&6
-echo "configure:6897: checking for regcomp" >&5
+echo "configure:6899: checking for regcomp" >&5
-#line 6900 "configure"
+#line 6902 "configure"
which can conflict with char regcomp(); below. */
@@ -6919,7 +6921,7 @@
; return 0; }
EOF
-if { (eval echo configure:6923: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6925: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_func_regcomp=yes"
else
@@ -6946,13 +6948,13 @@
echo $ac_n "checking for regcomp in -lregex""... $ac_c" 1>&6
-echo "configure:6950: checking for regcomp in -lregex" >&5
+echo "configure:6952: checking for regcomp in -lregex" >&5
ac_lib_var=`echo regex'_'regcomp | sed 'y%./+-%__p_%'`
LIBS="-lregex $LIBS"
-#line 6956 "configure"
+#line 6958 "configure"
@@ -6963,7 +6965,7 @@
regcomp()
; return 0; }
EOF
-if { (eval echo configure:6967: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6969: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -7013,7 +7015,7 @@
echo $ac_n "checking whether to use Readline""... $ac_c" 1>&6
-echo "configure:7017: checking whether to use Readline" >&5
+echo "configure:7019: checking whether to use Readline" >&5
echo "$ac_t"""$with_readline"" 1>&6
case "$with_readline" in
"no") USE_READLINE= ;;
@@ -7034,7 +7036,7 @@
echo $ac_n "checking for location of Readline includes""... $ac_c" 1>&6
-echo "configure:7038: checking for location of Readline includes" >&5
+echo "configure:7040: checking for location of Readline includes" >&5
case "$with_readline_includes" in
{ echo "configure: error: *** You must supply a directory to --with-readline-includes." 1>&2; exit 1; }
@@ -7060,15 +7062,15 @@
do
-echo "configure:7064: checking for $ac_hdr" >&5
+echo "configure:7066: checking for $ac_hdr" >&5
-#line 7067 "configure"
+#line 7069 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:7072: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:7074: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -7104,15 +7106,15 @@
do
-echo "configure:7108: checking for $ac_hdr" >&5
+echo "configure:7110: checking for $ac_hdr" >&5
-#line 7111 "configure"
+#line 7113 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:7116: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:7118: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -7146,7 +7148,7 @@
echo $ac_n "checking for location of Readline library""... $ac_c" 1>&6
-echo "configure:7150: checking for location of Readline library" >&5
+echo "configure:7152: checking for location of Readline library" >&5
case "$with_readline_libs" in
{ echo "configure: error: *** You must supply a directory to --with-readline-libs." 1>&2; exit 1; }
@@ -7171,13 +7173,13 @@
echo $ac_n "checking for readline in -lreadline""... $ac_c" 1>&6
-echo "configure:7175: checking for readline in -lreadline" >&5
+echo "configure:7177: checking for readline in -lreadline" >&5
ac_lib_var=`echo readline'_'readline | sed 'y%./+-%__p_%'`
LIBS="-lreadline $LIBS"
-#line 7181 "configure"
+#line 7183 "configure"
@@ -7188,7 +7190,7 @@
readline()
; return 0; }
EOF
-if { (eval echo configure:7192: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:7194: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -7223,13 +7225,13 @@
echo $ac_n "checking for add_history in -lhistory""... $ac_c" 1>&6
-echo "configure:7227: checking for add_history in -lhistory" >&5
+echo "configure:7229: checking for add_history in -lhistory" >&5
ac_lib_var=`echo history'_'add_history | sed 'y%./+-%__p_%'`
LIBS="-lhistory $LIBS"
-#line 7233 "configure"
+#line 7235 "configure"
@@ -7240,7 +7242,7 @@
add_history()
; return 0; }
EOF
-if { (eval echo configure:7244: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:7246: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -7283,7 +7285,7 @@
echo $ac_n "checking whether to use JPEG""... $ac_c" 1>&6
-echo "configure:7287: checking whether to use JPEG" >&5
+echo "configure:7289: checking whether to use JPEG" >&5
echo "$ac_t"""$with_jpeg"" 1>&6
case "$with_jpeg" in
"no") USE_JPEG= ;;
@@ -7303,7 +7305,7 @@
echo $ac_n "checking for location of JPEG includes""... $ac_c" 1>&6
-echo "configure:7307: checking for location of JPEG includes" >&5
+echo "configure:7309: checking for location of JPEG includes" >&5
case "$with_jpeg_includes" in
{ echo "configure: error: *** You must supply a directory to --with-jpeg-includes." 1>&2; exit 1; }
@@ -7329,15 +7331,15 @@
do
-echo "configure:7333: checking for $ac_hdr" >&5
+echo "configure:7335: checking for $ac_hdr" >&5
-#line 7336 "configure"
+#line 7338 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:7341: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:7343: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -7371,7 +7373,7 @@
echo $ac_n "checking for location of JPEG library""... $ac_c" 1>&6
-echo "configure:7375: checking for location of JPEG library" >&5
+echo "configure:7377: checking for location of JPEG library" >&5
case "$with_jpeg_libs" in
{ echo "configure: error: *** You must supply a directory to --with-jpeg-libs." 1>&2; exit 1; }
@@ -7398,13 +7400,13 @@
echo $ac_n "checking for jpeg_start_compress in -ljpeg""... $ac_c" 1>&6
-echo "configure:7402: checking for jpeg_start_compress in -ljpeg" >&5
+echo "configure:7404: checking for jpeg_start_compress in -ljpeg" >&5
ac_lib_var=`echo jpeg'_'jpeg_start_compress | sed 'y%./+-%__p_%'`
LIBS="-ljpeg $LIBS"
-#line 7408 "configure"
+#line 7410 "configure"
@@ -7415,7 +7417,7 @@
jpeg_start_compress()
; return 0; }
EOF
-if { (eval echo configure:7419: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:7421: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -7434,13 +7436,13 @@
-echo "configure:7438: checking for jpeg_start_compress in -ljpeg" >&5
+echo "configure:7440: checking for jpeg_start_compress in -ljpeg" >&5
LIBS="-ljpeg $ZLIB $LIBS"
-#line 7444 "configure"
+#line 7446 "configure"
@@ -7451,7 +7453,7 @@
; return 0; }
EOF
-if { (eval echo configure:7455: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:7457: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -7500,7 +7502,7 @@
# GDAL option
echo $ac_n "checking whether to use GDAL""... $ac_c" 1>&6
-echo "configure:7504: checking whether to use GDAL" >&5
+echo "configure:7506: checking whether to use GDAL" >&5
GDAL_LIBS=
GDAL_CFLAGS=
@@ -7518,7 +7520,7 @@
# Extract the first word of "gdal-config", so it can be a program name with args.
set dummy gdal-config; ac_word=$2
-echo "configure:7522: checking for $ac_word" >&5
+echo "configure:7524: checking for $ac_word" >&5
case "$GDAL_CONFIG" in
@@ -7573,14 +7575,14 @@
LIBS="$LIBS $GDAL_LIBS"
CFLAGS="$CFLAGS $GDAL_CFLAGS"
-#line 7577 "configure"
+#line 7579 "configure"
#include <gdal.h>
int main() {
GDALOpen("foo", GA_ReadOnly);
; return 0; }
EOF
-if { (eval echo configure:7584: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:7586: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
else
echo "configure: failed program was:" >&5
@@ -7589,14 +7591,14 @@
LIBS="$LIBS $GDAL_DEP_LIBS"
-#line 7593 "configure"
+#line 7595 "configure"
#include <gdal.h>
int main() {
; return 0; }
EOF
-if { (eval echo configure:7600: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:7602: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
GDAL_LIBS="$GDAL_LIBS $GDAL_DEP_LIBS"
else
@@ -7628,7 +7630,7 @@
# GEOS option
echo $ac_n "checking whether to use GEOS""... $ac_c" 1>&6
-echo "configure:7632: checking whether to use GEOS" >&5
+echo "configure:7634: checking whether to use GEOS" >&5
GEOS_LIBS=
GGEOS_CFLAGS=
@@ -7645,7 +7647,7 @@
# Extract the first word of "geos-config", so it can be a program name with args.
set dummy geos-config; ac_word=$2
-echo "configure:7649: checking for $ac_word" >&5
+echo "configure:7651: checking for $ac_word" >&5
case "$GEOS_CONFIG" in
@@ -7700,7 +7702,7 @@
echo $ac_n "checking whether to use TIFF""... $ac_c" 1>&6
-echo "configure:7704: checking whether to use TIFF" >&5
+echo "configure:7706: checking whether to use TIFF" >&5
echo "$ac_t"""$with_tiff"" 1>&6
case "$with_tiff" in
"no") USE_TIFF= ;;
@@ -7720,7 +7722,7 @@
echo $ac_n "checking for location of TIFF includes""... $ac_c" 1>&6
-echo "configure:7724: checking for location of TIFF includes" >&5
+echo "configure:7726: checking for location of TIFF includes" >&5
case "$with_tiff_includes" in
{ echo "configure: error: *** You must supply a directory to --with-tiff-includes." 1>&2; exit 1; }
@@ -7746,15 +7748,15 @@
do
-echo "configure:7750: checking for $ac_hdr" >&5
+echo "configure:7752: checking for $ac_hdr" >&5
-#line 7753 "configure"
+#line 7755 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:7758: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:7760: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -7788,7 +7790,7 @@
echo $ac_n "checking for location of TIFF library""... $ac_c" 1>&6
-echo "configure:7792: checking for location of TIFF library" >&5
+echo "configure:7794: checking for location of TIFF library" >&5
case "$with_tiff_libs" in
{ echo "configure: error: *** You must supply a directory to --with-tiff-libs." 1>&2; exit 1; }
@@ -7819,13 +7821,13 @@
echo $ac_n "checking for TIFFOpen in -ltiff""... $ac_c" 1>&6
-echo "configure:7823: checking for TIFFOpen in -ltiff" >&5
+echo "configure:7825: checking for TIFFOpen in -ltiff" >&5
ac_lib_var=`echo tiff'_'TIFFOpen | sed 'y%./+-%__p_%'`
LIBS="-ltiff $LIBS"
-#line 7829 "configure"
+#line 7831 "configure"
@@ -7836,7 +7838,7 @@
TIFFOpen()
; return 0; }
EOF
-if { (eval echo configure:7840: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:7842: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -7855,13 +7857,13 @@
-echo "configure:7859: checking for TIFFOpen in -ltiff" >&5
+echo "configure:7861: checking for TIFFOpen in -ltiff" >&5
LIBS="-ltiff $MATHLIB $LIBS"
-#line 7865 "configure"
+#line 7867 "configure"
@@ -7872,7 +7874,7 @@
TIFFOpen()
; return 0; }
EOF
-if { (eval echo configure:7876: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:7878: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -7891,13 +7893,13 @@
-echo "configure:7895: checking for TIFFOpen in -ltiff" >&5
+echo "configure:7897: checking for TIFFOpen in -ltiff" >&5
LIBS="-ltiff $ZLIB $LIBS"
-#line 7901 "configure"
+#line 7903 "configure"
@@ -7908,7 +7910,7 @@
TIFFOpen()
; return 0; }
EOF
-if { (eval echo configure:7912: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:7914: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -7927,13 +7929,13 @@
-echo "configure:7931: checking for TIFFOpen in -ltiff" >&5
+echo "configure:7933: checking for TIFFOpen in -ltiff" >&5
LIBS="-ltiff $ZLIB $MATHLIB $LIBS"
-#line 7937 "configure"
+#line 7939 "configure"
@@ -7944,7 +7946,7 @@
TIFFOpen()
; return 0; }
EOF
-if { (eval echo configure:7948: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:7950: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -7963,13 +7965,13 @@
-echo "configure:7967: checking for TIFFOpen in -ltiff" >&5
+echo "configure:7969: checking for TIFFOpen in -ltiff" >&5
LIBS="-ltiff $JPEGLIBPATH $JPEGLIB $LIBS"
-#line 7973 "configure"
+#line 7975 "configure"
@@ -7980,7 +7982,7 @@
TIFFOpen()
; return 0; }
EOF
-if { (eval echo configure:7984: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:7986: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -7999,13 +8001,13 @@
-echo "configure:8003: checking for TIFFOpen in -ltiff" >&5
+echo "configure:8005: checking for TIFFOpen in -ltiff" >&5
LIBS="-ltiff $JPEGLIBPATH $JPEGLIB $MATHLIB $LIBS"
-#line 8009 "configure"
+#line 8011 "configure"
@@ -8016,7 +8018,7 @@
TIFFOpen()
; return 0; }
EOF
-if { (eval echo configure:8020: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8022: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -8035,13 +8037,13 @@
-echo "configure:8039: checking for TIFFOpen in -ltiff" >&5
+echo "configure:8041: checking for TIFFOpen in -ltiff" >&5
LIBS="-ltiff $JPEGLIBPATH $JPEGLIB $ZLIB $LIBS"
-#line 8045 "configure"
+#line 8047 "configure"
@@ -8052,7 +8054,7 @@
TIFFOpen()
; return 0; }
EOF
-if { (eval echo configure:8056: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8058: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -8071,13 +8073,13 @@
-echo "configure:8075: checking for TIFFOpen in -ltiff" >&5
+echo "configure:8077: checking for TIFFOpen in -ltiff" >&5
LIBS="-ltiff $JPEGLIBPATH $JPEGLIB $ZLIB $MATHLIB $LIBS"
-#line 8081 "configure"
+#line 8083 "configure"
@@ -8088,7 +8090,7 @@
TIFFOpen()
; return 0; }
EOF
-if { (eval echo configure:8092: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8094: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -8186,7 +8188,7 @@
echo $ac_n "checking whether to use PNG""... $ac_c" 1>&6
-echo "configure:8190: checking whether to use PNG" >&5
+echo "configure:8192: checking whether to use PNG" >&5
echo "$ac_t"""$with_png"" 1>&6
case "$with_png" in
"no") USE_PNG= ;;
@@ -8205,7 +8207,7 @@
echo $ac_n "checking for location of PNG includes""... $ac_c" 1>&6
-echo "configure:8209: checking for location of PNG includes" >&5
+echo "configure:8211: checking for location of PNG includes" >&5
case "$with_png_includes" in
{ echo "configure: error: *** You must supply a directory to --with-png-includes." 1>&2; exit 1; }
@@ -8231,15 +8233,15 @@
do
-echo "configure:8235: checking for $ac_hdr" >&5
+echo "configure:8237: checking for $ac_hdr" >&5
-#line 8238 "configure"
+#line 8240 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:8243: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:8245: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -8273,7 +8275,7 @@
echo $ac_n "checking for location of PNG library""... $ac_c" 1>&6
-echo "configure:8277: checking for location of PNG library" >&5
+echo "configure:8279: checking for location of PNG library" >&5
case "$with_png_libs" in
{ echo "configure: error: *** You must supply a directory to --with-png-libs." 1>&2; exit 1; }
@@ -8298,13 +8300,13 @@
echo $ac_n "checking for png_read_image in -lpng""... $ac_c" 1>&6
-echo "configure:8302: checking for png_read_image in -lpng" >&5
+echo "configure:8304: checking for png_read_image in -lpng" >&5
ac_lib_var=`echo png'_'png_read_image | sed 'y%./+-%__p_%'`
LIBS="-lpng $ZLIB $MATHLIB $LIBS"
-#line 8308 "configure"
+#line 8310 "configure"
@@ -8315,7 +8317,7 @@
png_read_image()
; return 0; }
EOF
-if { (eval echo configure:8319: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8321: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -8357,7 +8359,7 @@
echo $ac_n "checking whether to use Tcl/Tk""... $ac_c" 1>&6
-echo "configure:8361: checking whether to use Tcl/Tk" >&5
+echo "configure:8363: checking whether to use Tcl/Tk" >&5
echo "$ac_t"""$with_tcltk"" 1>&6
case "$with_tcltk" in
"no") USE_TCLTK= ;;
@@ -8377,7 +8379,7 @@
echo $ac_n "checking for location of Tcl/Tk includes""... $ac_c" 1>&6
-echo "configure:8381: checking for location of Tcl/Tk includes" >&5
+echo "configure:8383: checking for location of Tcl/Tk includes" >&5
case "$with_tcltk_includes" in
y | ye | yes | n | no)
{ echo "configure: error: *** You must supply a directory to --with-tcltk-includes." 1>&2; exit 1; }
@@ -8403,15 +8405,15 @@
do
-echo "configure:8407: checking for $ac_hdr" >&5
+echo "configure:8409: checking for $ac_hdr" >&5
-#line 8410 "configure"
+#line 8412 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:8415: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:8417: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -8448,15 +8450,15 @@
do
-echo "configure:8452: checking for $ac_hdr" >&5
+echo "configure:8454: checking for $ac_hdr" >&5
-#line 8455 "configure"
+#line 8457 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:8460: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:8462: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -8490,7 +8492,7 @@
echo $ac_n "checking Tcl version""... $ac_c" 1>&6
-echo "configure:8494: checking Tcl version" >&5
+echo "configure:8496: checking Tcl version" >&5
CPPFLAGS="$TCLINCDIR $CPPFLAGS"
@@ -8498,7 +8500,7 @@
else
-#line 8502 "configure"
+#line 8504 "configure"
#include <stdio.h>
@@ -8510,7 +8512,7 @@
EOF
-if { (eval echo configure:8514: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext} && (./conftest; exit) 2>/dev/null
+if { (eval echo configure:8516: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext} && (./conftest; exit) 2>/dev/null
then
tcl_ver=`cat conftestdata`
echo "$ac_t""$tcl_ver" 1>&6
@@ -8528,7 +8530,7 @@
echo $ac_n "checking Tk version""... $ac_c" 1>&6
-echo "configure:8532: checking Tk version" >&5
+echo "configure:8534: checking Tk version" >&5
CPPFLAGS="$TCLINCDIR $X_CFLAGS $CPPFLAGS"
@@ -8536,7 +8538,7 @@
else
cat > conftest.$ac_ext <<EOF
-#line 8540 "configure"
+#line 8542 "configure"
#include "confdefs.h"
#include <stdio.h>
@@ -8548,7 +8550,7 @@
EOF
-if { (eval echo configure:8552: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext} && (./conftest; exit) 2>/dev/null
+if { (eval echo configure:8554: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext} && (./conftest; exit) 2>/dev/null
then
tk_ver=`cat conftestdata`
echo "$ac_t""$tk_ver" 1>&6
@@ -8577,7 +8579,7 @@
echo $ac_n "checking for location of Tcl/Tk library""... $ac_c" 1>&6
-echo "configure:8581: checking for location of Tcl/Tk library" >&5
+echo "configure:8583: checking for location of Tcl/Tk library" >&5
case "$with_tcltk_libs" in
{ echo "configure: error: *** You must supply a directory to --with-tcltk-libs." 1>&2; exit 1; }
@@ -8607,13 +8609,13 @@
echo $ac_n "checking for Tcl_Init in -ltcl""... $ac_c" 1>&6
-echo "configure:8611: checking for Tcl_Init in -ltcl" >&5
+echo "configure:8613: checking for Tcl_Init in -ltcl" >&5
ac_lib_var=`echo tcl'_'Tcl_Init | sed 'y%./+-%__p_%'`
ac_save_LIBS="$LIBS"
LIBS="-ltcl $MATHLIB $LIBS"
-#line 8617 "configure"
+#line 8619 "configure"
/* Override any gcc2 internal prototype to avoid an error. */
/* We use char because int might match the return type of a gcc2
@@ -8624,7 +8626,7 @@
Tcl_Init()
; return 0; }
EOF
-if { (eval echo configure:8628: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8630: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_lib_$ac_lib_var=yes"
else
@@ -8643,13 +8645,13 @@
-echo "configure:8647: checking for Tcl_Init in -ltcl" >&5
+echo "configure:8649: checking for Tcl_Init in -ltcl" >&5
LIBS="-ltcl $MATHLIB $DLLIB $LIBS"
-#line 8653 "configure"
+#line 8655 "configure"
@@ -8660,7 +8662,7 @@
Tcl_Init()
; return 0; }
EOF
-if { (eval echo configure:8664: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8666: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -8687,13 +8689,13 @@
echo $ac_n "checking for Tcl_Init in -ltcl$tcltk_ver""... $ac_c" 1>&6
-echo "configure:8691: checking for Tcl_Init in -ltcl$tcltk_ver" >&5
+echo "configure:8693: checking for Tcl_Init in -ltcl$tcltk_ver" >&5
ac_lib_var=`echo tcl$tcltk_ver'_'Tcl_Init | sed 'y%./+-%__p_%'`
LIBS="-ltcl$tcltk_ver $MATHLIB $LIBS"
-#line 8697 "configure"
+#line 8699 "configure"
@@ -8704,7 +8706,7 @@
Tcl_Init()
; return 0; }
EOF
-if { (eval echo configure:8708: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8710: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -8723,13 +8725,13 @@
-echo "configure:8727: checking for Tcl_Init in -ltcl$tcltk_ver" >&5
+echo "configure:8729: checking for Tcl_Init in -ltcl$tcltk_ver" >&5
LIBS="-ltcl$tcltk_ver $MATHLIB $DLLIB $LIBS"
-#line 8733 "configure"
+#line 8735 "configure"
@@ -8740,7 +8742,7 @@
Tcl_Init()
; return 0; }
EOF
-if { (eval echo configure:8744: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8746: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -8767,13 +8769,13 @@
echo $ac_n "checking for Tcl_Init in -ltcl$tcltk_ver2""... $ac_c" 1>&6
-echo "configure:8771: checking for Tcl_Init in -ltcl$tcltk_ver2" >&5
+echo "configure:8773: checking for Tcl_Init in -ltcl$tcltk_ver2" >&5
ac_lib_var=`echo tcl$tcltk_ver2'_'Tcl_Init | sed 'y%./+-%__p_%'`
LIBS="-ltcl$tcltk_ver2 $MATHLIB $LIBS"
-#line 8777 "configure"
+#line 8779 "configure"
@@ -8784,7 +8786,7 @@
Tcl_Init()
; return 0; }
EOF
-if { (eval echo configure:8788: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8790: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -8803,13 +8805,13 @@
-echo "configure:8807: checking for Tcl_Init in -ltcl$tcltk_ver2" >&5
+echo "configure:8809: checking for Tcl_Init in -ltcl$tcltk_ver2" >&5
LIBS="-ltcl$tcltk_ver2 $MATHLIB $DLLIB $LIBS"
-#line 8813 "configure"
+#line 8815 "configure"
@@ -8820,7 +8822,7 @@
Tcl_Init()
; return 0; }
EOF
-if { (eval echo configure:8824: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8826: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -8898,13 +8900,13 @@
echo $ac_n "checking for Tk_MainWindow in -ltk""... $ac_c" 1>&6
-echo "configure:8902: checking for Tk_MainWindow in -ltk" >&5
+echo "configure:8904: checking for Tk_MainWindow in -ltk" >&5
ac_lib_var=`echo tk'_'Tk_MainWindow | sed 'y%./+-%__p_%'`
LIBS="-ltk $TCLLIB $MATHLIB $LIBS"
-#line 8908 "configure"
+#line 8910 "configure"
@@ -8915,7 +8917,7 @@
Tk_MainWindow()
; return 0; }
EOF
-if { (eval echo configure:8919: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8921: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -8934,13 +8936,13 @@
-echo "configure:8938: checking for Tk_MainWindow in -ltk" >&5
+echo "configure:8940: checking for Tk_MainWindow in -ltk" >&5
LIBS="-ltk $TCLLIB $MATHLIB $X_LIBS $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $LIBS"
-#line 8944 "configure"
+#line 8946 "configure"
@@ -8951,7 +8953,7 @@
Tk_MainWindow()
; return 0; }
EOF
-if { (eval echo configure:8955: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8957: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -8978,13 +8980,13 @@
echo $ac_n "checking for Tk_MainWindow in -ltk$tcltk_ver""... $ac_c" 1>&6
-echo "configure:8982: checking for Tk_MainWindow in -ltk$tcltk_ver" >&5
+echo "configure:8984: checking for Tk_MainWindow in -ltk$tcltk_ver" >&5
ac_lib_var=`echo tk$tcltk_ver'_'Tk_MainWindow | sed 'y%./+-%__p_%'`
LIBS="-ltk$tcltk_ver $TCLLIB $MATHLIB $LIBS"
-#line 8988 "configure"
+#line 8990 "configure"
@@ -8995,7 +8997,7 @@
Tk_MainWindow()
; return 0; }
EOF
-if { (eval echo configure:8999: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9001: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -9014,13 +9016,13 @@
-echo "configure:9018: checking for Tk_MainWindow in -ltk$tcltk_ver" >&5
+echo "configure:9020: checking for Tk_MainWindow in -ltk$tcltk_ver" >&5
LIBS="-ltk$tcltk_ver $TCLLIB $MATHLIB $X_LIBS $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $LIBS"
-#line 9024 "configure"
+#line 9026 "configure"
@@ -9031,7 +9033,7 @@
Tk_MainWindow()
; return 0; }
EOF
-if { (eval echo configure:9035: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9037: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -9058,13 +9060,13 @@
echo $ac_n "checking for Tk_MainWindow in -ltk$tcltk_ver2""... $ac_c" 1>&6
-echo "configure:9062: checking for Tk_MainWindow in -ltk$tcltk_ver2" >&5
+echo "configure:9064: checking for Tk_MainWindow in -ltk$tcltk_ver2" >&5
ac_lib_var=`echo tk$tcltk_ver2'_'Tk_MainWindow | sed 'y%./+-%__p_%'`
LIBS="-ltk$tcltk_ver2 $TCLLIB $MATHLIB $LIBS"
-#line 9068 "configure"
+#line 9070 "configure"
@@ -9075,7 +9077,7 @@
Tk_MainWindow()
; return 0; }
EOF
-if { (eval echo configure:9079: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9081: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -9094,13 +9096,13 @@
-echo "configure:9098: checking for Tk_MainWindow in -ltk$tcltk_ver2" >&5
+echo "configure:9100: checking for Tk_MainWindow in -ltk$tcltk_ver2" >&5
LIBS="-ltk$tcltk_ver2 $TCLLIB $MATHLIB $X_LIBS $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $LIBS"
-#line 9104 "configure"
+#line 9106 "configure"
@@ -9111,7 +9113,7 @@
Tk_MainWindow()
; return 0; }
EOF
-if { (eval echo configure:9115: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9117: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -9203,7 +9205,7 @@
echo $ac_n "checking whether to use PostgreSQL""... $ac_c" 1>&6
-echo "configure:9207: checking whether to use PostgreSQL" >&5
+echo "configure:9209: checking whether to use PostgreSQL" >&5
echo "$ac_t"""$with_postgres"" 1>&6
case "$with_postgres" in
"no") USE_POSTGRES= ;;
@@ -9230,7 +9232,7 @@
echo $ac_n "checking for location of PostgreSQL includes""... $ac_c" 1>&6
-echo "configure:9234: checking for location of PostgreSQL includes" >&5
+echo "configure:9236: checking for location of PostgreSQL includes" >&5
case "$with_postgres_includes" in
{ echo "configure: error: *** You must supply a directory to --with-postgres-includes." 1>&2; exit 1; }
@@ -9256,15 +9258,15 @@
do
ac_safe=`echo "$ac_hdr" | sed 'y%./+-%__p_%'`
echo $ac_n "checking for $ac_hdr""... $ac_c" 1>&6
-echo "configure:9260: checking for $ac_hdr" >&5
+echo "configure:9262: checking for $ac_hdr" >&5
-#line 9263 "configure"
+#line 9265 "configure"
#include <$ac_hdr>
EOF
ac_try="$ac_cpp conftest.$ac_ext >/dev/null 2>conftest.out"
-{ (eval echo configure:9268: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:9270: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
ac_err=`grep -v '^ *+' conftest.out | grep -v "^conftest.${ac_ext}\$"`
if test -z "$ac_err"; then
rm -rf conftest*
@@ -9302,7 +9304,7 @@
echo $ac_n "checking for location of PostgreSQL library""... $ac_c" 1>&6
-echo "configure:9306: checking for location of PostgreSQL library" >&5
+echo "configure:9308: checking for location of PostgreSQL library" >&5
case "$with_postgres_libs" in
{ echo "configure: error: *** You must supply a directory to --with-postgres-libs." 1>&2; exit 1; }
@@ -9331,13 +9333,13 @@
echo $ac_n "checking for PQsetdbLogin in -lpq""... $ac_c" 1>&6
-echo "configure:9335: checking for PQsetdbLogin in -lpq" >&5
+echo "configure:9337: checking for PQsetdbLogin in -lpq" >&5
ac_lib_var=`echo pq'_'PQsetdbLogin | sed 'y%./+-%__p_%'`
LIBS="-lpq $LIBS"
-#line 9341 "configure"
+#line 9343 "configure"
@@ -9348,7 +9350,7 @@
PQsetdbLogin()
; return 0; }
EOF
-if { (eval echo configure:9352: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9354: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -9367,13 +9369,13 @@
-echo "configure:9371: checking for PQsetdbLogin in -lpq" >&5
+echo "configure:9373: checking for PQsetdbLogin in -lpq" >&5
LIBS="-lpq -lssl -lcrypto $LIBS"
-#line 9377 "configure"
+#line 9379 "configure"
@@ -9384,7 +9386,7 @@
PQsetdbLogin()
; return 0; }
EOF
-if { (eval echo configure:9388: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9390: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -9403,13 +9405,13 @@
-echo "configure:9407: checking for PQsetdbLogin in -lpq" >&5
+echo "configure:9409: checking for PQsetdbLogin in -lpq" >&5
LIBS="-lpq -lcrypt $LIBS"
-#line 9413 "configure"
+#line 9415 "configure"
@@ -9420,7 +9422,7 @@
PQsetdbLogin()
; return 0; }
EOF
-if { (eval echo configure:9424: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9426: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -9439,13 +9441,13 @@
-echo "configure:9443: checking for PQsetdbLogin in -lpq" >&5
+echo "configure:9445: checking for PQsetdbLogin in -lpq" >&5
LIBS="-lpq -lcrypt -lssl -lcrypto $LIBS"
-#line 9449 "configure"
+#line 9451 "configure"
@@ -9456,7 +9458,7 @@
PQsetdbLogin()
; return 0; }
EOF
-if { (eval echo configure:9460: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9462: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -9513,13 +9515,13 @@
ac_save_ldflags="$LDFLAGS"
LDFLAGS="$LDFLAGS $PQLIBPATH"
echo $ac_n "checking for PQcmdTuples in -lpq""... $ac_c" 1>&6
-echo "configure:9517: checking for PQcmdTuples in -lpq" >&5
+echo "configure:9519: checking for PQcmdTuples in -lpq" >&5
ac_lib_var=`echo pq'_'PQcmdTuples | sed 'y%./+-%__p_%'`
LIBS="-lpq $LIBS"
-#line 9523 "configure"
+#line 9525 "configure"
@@ -9530,7 +9532,7 @@
PQcmdTuples()
; return 0; }
EOF
-if { (eval echo configure:9534: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9536: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -9552,13 +9554,13 @@
-echo "configure:9556: checking for PQcmdTuples in -lpq" >&5
+echo "configure:9558: checking for PQcmdTuples in -lpq" >&5
-#line 9562 "configure"
+#line 9564 "configure"
@@ -9569,7 +9571,7 @@
PQcmdTuples()
; return 0; }
EOF
-if { (eval echo configure:9573: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9575: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -9612,7 +9614,7 @@
echo $ac_n "checking whether to use MySQL""... $ac_c" 1>&6
-echo "configure:9616: checking whether to use MySQL" >&5
+echo "configure:9618: checking whether to use MySQL" >&5
echo "$ac_t"""$with_mysql"" 1>&6
case "$with_mysql" in
"no") USE_MYSQL= ;;
@@ -9632,7 +9634,7 @@
echo $ac_n "checking for location of MySQL includes""... $ac_c" 1>&6
-echo "configure:9636: checking for location of MySQL includes" >&5
+echo "configure:9638: checking for location of MySQL includes" >&5
case "$with_mysql_includes" in
{ echo "configure: error: *** You must supply a directory to --with-mysql-includes." 1>&2; exit 1; }
@@ -9658,15 +9660,15 @@
do
-echo "configure:9662: checking for $ac_hdr" >&5
+echo "configure:9664: checking for $ac_hdr" >&5
-#line 9665 "configure"
+#line 9667 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:9670: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:9672: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -9703,7 +9705,7 @@
echo $ac_n "checking for location of MySQL library""... $ac_c" 1>&6
-echo "configure:9707: checking for location of MySQL library" >&5
+echo "configure:9709: checking for location of MySQL library" >&5
case "$with_mysql_libs" in
{ echo "configure: error: *** You must supply a directory to --with-mysql-libs." 1>&2; exit 1; }
@@ -9734,13 +9736,13 @@
echo $ac_n "checking for mysql_query in -lmysqlclient""... $ac_c" 1>&6
-echo "configure:9738: checking for mysql_query in -lmysqlclient" >&5
+echo "configure:9740: checking for mysql_query in -lmysqlclient" >&5
ac_lib_var=`echo mysqlclient'_'mysql_query | sed 'y%./+-%__p_%'`
LIBS="-lmysqlclient $LIBS"
-#line 9744 "configure"
+#line 9746 "configure"
@@ -9751,7 +9753,7 @@
mysql_query()
; return 0; }
EOF
-if { (eval echo configure:9755: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9757: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -9770,13 +9772,13 @@
-echo "configure:9774: checking for mysql_query in -lmysqlclient" >&5
+echo "configure:9776: checking for mysql_query in -lmysqlclient" >&5
LIBS="-lmysqlclient $MATHLIB $LIBS"
-#line 9780 "configure"
+#line 9782 "configure"
@@ -9787,7 +9789,7 @@
mysql_query()
; return 0; }
EOF
-if { (eval echo configure:9791: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9793: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -9806,13 +9808,13 @@
-echo "configure:9810: checking for mysql_query in -lmysqlclient" >&5
+echo "configure:9812: checking for mysql_query in -lmysqlclient" >&5
LIBS="-lmysqlclient $SOCKLIB $LIBS"
-#line 9816 "configure"
+#line 9818 "configure"
@@ -9823,7 +9825,7 @@
mysql_query()
; return 0; }
EOF
-if { (eval echo configure:9827: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9829: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -9842,13 +9844,13 @@
-echo "configure:9846: checking for mysql_query in -lmysqlclient" >&5
+echo "configure:9848: checking for mysql_query in -lmysqlclient" >&5
LIBS="-lmysqlclient $SOCKLIB $MATHLIB $LIBS"
-#line 9852 "configure"
+#line 9854 "configure"
@@ -9859,7 +9861,7 @@
mysql_query()
; return 0; }
EOF
-if { (eval echo configure:9863: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9865: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -9878,13 +9880,13 @@
-echo "configure:9882: checking for mysql_query in -lmysqlclient" >&5
+echo "configure:9884: checking for mysql_query in -lmysqlclient" >&5
LIBS="-lmysqlclient $ZLIB $LIBS"
-#line 9888 "configure"
+#line 9890 "configure"
@@ -9895,7 +9897,7 @@
mysql_query()
; return 0; }
EOF
-if { (eval echo configure:9899: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9901: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -9914,13 +9916,13 @@
-echo "configure:9918: checking for mysql_query in -lmysqlclient" >&5
+echo "configure:9920: checking for mysql_query in -lmysqlclient" >&5
LIBS="-lmysqlclient $ZLIB $MATHLIB $LIBS"
-#line 9924 "configure"
+#line 9926 "configure"
@@ -9931,7 +9933,7 @@
mysql_query()
; return 0; }
EOF
-if { (eval echo configure:9935: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9937: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -9950,13 +9952,13 @@
-echo "configure:9954: checking for mysql_query in -lmysqlclient" >&5
+echo "configure:9956: checking for mysql_query in -lmysqlclient" >&5
LIBS="-lmysqlclient $ZLIB $SOCKLIB $LIBS"
-#line 9960 "configure"
+#line 9962 "configure"
@@ -9967,7 +9969,7 @@
mysql_query()
; return 0; }
EOF
-if { (eval echo configure:9971: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9973: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -9986,13 +9988,13 @@
-echo "configure:9990: checking for mysql_query in -lmysqlclient" >&5
+echo "configure:9992: checking for mysql_query in -lmysqlclient" >&5
LIBS="-lmysqlclient $ZLIB $SOCKLIB $MATHLIB $LIBS"
-#line 9996 "configure"
+#line 9998 "configure"
@@ -10003,7 +10005,7 @@
mysql_query()
; return 0; }
EOF
-if { (eval echo configure:10007: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10009: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -10093,7 +10095,7 @@
# Extract the first word of "mysql_config", so it can be a program name with args.
set dummy mysql_config; ac_word=$2
echo $ac_n "checking for $ac_word""... $ac_c" 1>&6
-echo "configure:10097: checking for $ac_word" >&5
+echo "configure:10099: checking for $ac_word" >&5
case "$MYSQLD_CONFIG" in
@@ -10142,10 +10144,10 @@
LIBS="$MYSQLDLIB $LIBS"
echo $ac_n "checking for mysql_server_init""... $ac_c" 1>&6
-echo "configure:10146: checking for mysql_server_init" >&5
+echo "configure:10148: checking for mysql_server_init" >&5
-#line 10149 "configure"
+#line 10151 "configure"
/* System header to define __stub macros and hopefully few prototypes,
which can conflict with char mysql_server_init(); below. */
@@ -10171,7 +10173,7 @@
; return 0; }
EOF
-if { (eval echo configure:10175: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10177: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_func_mysql_server_init=yes"
else
@@ -10223,7 +10225,7 @@
echo $ac_n "checking whether to use SQLite""... $ac_c" 1>&6
-echo "configure:10227: checking whether to use SQLite" >&5
+echo "configure:10229: checking whether to use SQLite" >&5
echo "$ac_t"""$with_sqlite"" 1>&6
case "$with_sqlite" in
"no") USE_SQLITE= ;;
@@ -10243,7 +10245,7 @@
echo $ac_n "checking for location of SQLite includes""... $ac_c" 1>&6
-echo "configure:10247: checking for location of SQLite includes" >&5
+echo "configure:10249: checking for location of SQLite includes" >&5
case "$with_sqlite_includes" in
{ echo "configure: error: *** You must supply a directory to --with-sqlite-includes." 1>&2; exit 1; }
@@ -10269,15 +10271,15 @@
do
-echo "configure:10273: checking for $ac_hdr" >&5
+echo "configure:10275: checking for $ac_hdr" >&5
-#line 10276 "configure"
+#line 10278 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:10281: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:10283: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -10320,7 +10322,7 @@
echo $ac_n "checking for location of SQLite library""... $ac_c" 1>&6
-echo "configure:10324: checking for location of SQLite library" >&5
+echo "configure:10326: checking for location of SQLite library" >&5
case "$with_sqlite_libs" in
{ echo "configure: error: *** You must supply a directory to --with-sqlite-libs." 1>&2; exit 1; }
@@ -10347,13 +10349,13 @@
echo $ac_n "checking for sqlite3_open in -lsqlite3""... $ac_c" 1>&6
-echo "configure:10351: checking for sqlite3_open in -lsqlite3" >&5
+echo "configure:10353: checking for sqlite3_open in -lsqlite3" >&5
ac_lib_var=`echo sqlite3'_'sqlite3_open | sed 'y%./+-%__p_%'`
LIBS="-lsqlite3 $LIBS"
-#line 10357 "configure"
+#line 10359 "configure"
@@ -10364,7 +10366,7 @@
sqlite3_open()
; return 0; }
EOF
-if { (eval echo configure:10368: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10370: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -10383,13 +10385,13 @@
-echo "configure:10387: checking for sqlite3_open in -lsqlite3" >&5
+echo "configure:10389: checking for sqlite3_open in -lsqlite3" >&5
LIBS="-lsqlite3 $MATHLIB $LIBS"
-#line 10393 "configure"
+#line 10395 "configure"
@@ -10400,7 +10402,7 @@
sqlite3_open()
; return 0; }
EOF
-if { (eval echo configure:10404: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10406: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -10453,7 +10455,7 @@
echo $ac_n "checking whether to use FFMPEG""... $ac_c" 1>&6
-echo "configure:10457: checking whether to use FFMPEG" >&5
+echo "configure:10459: checking whether to use FFMPEG" >&5
echo "$ac_t"""$with_ffmpeg"" 1>&6
case "$with_ffmpeg" in
"no") USE_FFMPEG= ;;
@@ -10473,7 +10475,7 @@
echo $ac_n "checking for location of FFMPEG includes""... $ac_c" 1>&6
-echo "configure:10477: checking for location of FFMPEG includes" >&5
+echo "configure:10479: checking for location of FFMPEG includes" >&5
case "$with_ffmpeg_includes" in
{ echo "configure: error: *** You must supply a directory to --with-ffmpeg-includes." 1>&2; exit 1; }
@@ -10499,15 +10501,15 @@
do
-echo "configure:10503: checking for $ac_hdr" >&5
+echo "configure:10505: checking for $ac_hdr" >&5
-#line 10506 "configure"
+#line 10508 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:10511: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:10513: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -10543,15 +10545,15 @@
do
-echo "configure:10547: checking for $ac_hdr" >&5
+echo "configure:10549: checking for $ac_hdr" >&5
-#line 10550 "configure"
+#line 10552 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:10555: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:10557: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -10587,15 +10589,15 @@
do
-echo "configure:10591: checking for $ac_hdr" >&5
+echo "configure:10593: checking for $ac_hdr" >&5
-#line 10594 "configure"
+#line 10596 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:10599: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:10601: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -10638,7 +10640,7 @@
echo $ac_n "checking for location of FFMPEG library""... $ac_c" 1>&6
-echo "configure:10642: checking for location of FFMPEG library" >&5
+echo "configure:10644: checking for location of FFMPEG library" >&5
case "$with_ffmpeg_libs" in
{ echo "configure: error: *** You must supply a directory to --with-ffmpeg-libs." 1>&2; exit 1; }
@@ -10665,13 +10667,13 @@
echo $ac_n "checking for av_free in -lavutil""... $ac_c" 1>&6
-echo "configure:10669: checking for av_free in -lavutil" >&5
+echo "configure:10671: checking for av_free in -lavutil" >&5
ac_lib_var=`echo avutil'_'av_free | sed 'y%./+-%__p_%'`
LIBS="-lavutil $LIBS"
-#line 10675 "configure"
+#line 10677 "configure"
@@ -10682,7 +10684,7 @@
av_free()
; return 0; }
EOF
-if { (eval echo configure:10686: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10688: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -10701,13 +10703,13 @@
echo "$ac_t""no" 1>&6
-echo "configure:10705: checking for av_free in -lavutil" >&5
+echo "configure:10707: checking for av_free in -lavutil" >&5
LIBS="-lavutil $MATHLIB $LIBS"
-#line 10711 "configure"
+#line 10713 "configure"
@@ -10718,7 +10720,7 @@
av_free()
; return 0; }
EOF
-if { (eval echo configure:10722: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10724: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -10763,13 +10765,13 @@
echo $ac_n "checking for avcodec_init in -lavcodec""... $ac_c" 1>&6
-echo "configure:10767: checking for avcodec_init in -lavcodec" >&5
+echo "configure:10769: checking for avcodec_init in -lavcodec" >&5
ac_lib_var=`echo avcodec'_'avcodec_init | sed 'y%./+-%__p_%'`
LIBS="-lavcodec $FFMPEGLIB $LIBS"
-#line 10773 "configure"
+#line 10775 "configure"
@@ -10780,7 +10782,7 @@
avcodec_init()
; return 0; }
EOF
-if { (eval echo configure:10784: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10786: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -10799,13 +10801,13 @@
-echo "configure:10803: checking for avcodec_init in -lavcodec" >&5
+echo "configure:10805: checking for avcodec_init in -lavcodec" >&5
LIBS="-lavcodec $FFMPEGLIB $MATHLIB $LIBS"
-#line 10809 "configure"
+#line 10811 "configure"
@@ -10816,7 +10818,7 @@
avcodec_init()
; return 0; }
EOF
-if { (eval echo configure:10820: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10822: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -10861,13 +10863,13 @@
echo $ac_n "checking for av_set_parameters in -lavformat""... $ac_c" 1>&6
-echo "configure:10865: checking for av_set_parameters in -lavformat" >&5
+echo "configure:10867: checking for av_set_parameters in -lavformat" >&5
ac_lib_var=`echo avformat'_'av_set_parameters | sed 'y%./+-%__p_%'`
LIBS="-lavformat $FFMPEGLIB $LIBS"
-#line 10871 "configure"
+#line 10873 "configure"
@@ -10878,7 +10880,7 @@
av_set_parameters()
; return 0; }
EOF
-if { (eval echo configure:10882: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10884: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -10897,13 +10899,13 @@
-echo "configure:10901: checking for av_set_parameters in -lavformat" >&5
+echo "configure:10903: checking for av_set_parameters in -lavformat" >&5
LIBS="-lavformat $FFMPEGLIB $MATHLIB $LIBS"
-#line 10907 "configure"
+#line 10909 "configure"
@@ -10914,7 +10916,7 @@
av_set_parameters()
; return 0; }
EOF
-if { (eval echo configure:10918: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10920: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -10974,7 +10976,7 @@
OPENGL_WINDOWS=
echo $ac_n "checking whether to use OpenGL""... $ac_c" 1>&6
-echo "configure:10978: checking whether to use OpenGL" >&5
+echo "configure:10980: checking whether to use OpenGL" >&5
echo "$ac_t"""$with_opengl"" 1>&6
case "$with_opengl" in
n|no)
@@ -11008,7 +11010,7 @@
echo $ac_n "checking for location of OpenGL includes""... $ac_c" 1>&6
-echo "configure:11012: checking for location of OpenGL includes" >&5
+echo "configure:11014: checking for location of OpenGL includes" >&5
case "$with_opengl_includes" in
{ echo "configure: error: *** You must supply a directory to --with-opengl-includes." 1>&2; exit 1; }
@@ -11034,15 +11036,15 @@
do
-echo "configure:11038: checking for $ac_hdr" >&5
+echo "configure:11040: checking for $ac_hdr" >&5
-#line 11041 "configure"
+#line 11043 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:11046: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:11048: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -11076,7 +11078,7 @@
echo $ac_n "checking for location of OpenGL library""... $ac_c" 1>&6
-echo "configure:11080: checking for location of OpenGL library" >&5
+echo "configure:11082: checking for location of OpenGL library" >&5
case "$with_opengl_libs" in
{ echo "configure: error: *** You must supply a directory to --with-opengl-libs." 1>&2; exit 1; }
@@ -11105,13 +11107,13 @@
echo $ac_n "checking for glBegin in -lGL""... $ac_c" 1>&6
-echo "configure:11109: checking for glBegin in -lGL" >&5
+echo "configure:11111: checking for glBegin in -lGL" >&5
ac_lib_var=`echo GL'_'glBegin | sed 'y%./+-%__p_%'`
LIBS="-lGL $X_LIBS $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $MATHLIB $LIBS"
-#line 11115 "configure"
+#line 11117 "configure"
@@ -11122,7 +11124,7 @@
glBegin()
; return 0; }
EOF
-if { (eval echo configure:11126: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11128: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -11141,13 +11143,13 @@
-echo "configure:11145: checking for glBegin in -lGL" >&5
+echo "configure:11147: checking for glBegin in -lGL" >&5
LIBS="-lGL $X_LIBS $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $MATHLIB -lXext $LIBS"
-#line 11151 "configure"
+#line 11153 "configure"
@@ -11158,7 +11160,7 @@
glBegin()
; return 0; }
EOF
-if { (eval echo configure:11162: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11164: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -11177,13 +11179,13 @@
-echo "configure:11181: checking for glBegin in -lGL" >&5
+echo "configure:11183: checking for glBegin in -lGL" >&5
LIBS="-lGL $X_LIBS $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $MATHLIB -lpthread $LIBS"
-#line 11187 "configure"
+#line 11189 "configure"
@@ -11194,7 +11196,7 @@
glBegin()
; return 0; }
EOF
-if { (eval echo configure:11198: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11200: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -11213,13 +11215,13 @@
-echo "configure:11217: checking for glBegin in -lGL" >&5
+echo "configure:11219: checking for glBegin in -lGL" >&5
LIBS="-lGL $X_LIBS $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $MATHLIB -lpthread -lXext $LIBS"
-#line 11223 "configure"
+#line 11225 "configure"
@@ -11230,7 +11232,7 @@
glBegin()
; return 0; }
EOF
-if { (eval echo configure:11234: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11236: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -11292,13 +11294,13 @@
echo $ac_n "checking for gluBeginCurve in -lGLU""... $ac_c" 1>&6
-echo "configure:11296: checking for gluBeginCurve in -lGLU" >&5
+echo "configure:11298: checking for gluBeginCurve in -lGLU" >&5
ac_lib_var=`echo GLU'_'gluBeginCurve | sed 'y%./+-%__p_%'`
LIBS="-lGLU $OPENGLLIB $X_LIBS $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $MATHLIB $LIBS"
-#line 11302 "configure"
+#line 11304 "configure"
@@ -11309,7 +11311,7 @@
gluBeginCurve()
; return 0; }
EOF
-if { (eval echo configure:11313: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11315: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -11328,13 +11330,13 @@
-echo "configure:11332: checking for gluBeginCurve in -lGLU" >&5
+echo "configure:11334: checking for gluBeginCurve in -lGLU" >&5
LIBS="-lGLU $OPENGLLIB $X_LIBS $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $MATHLIB -lstdc++ $LIBS"
-#line 11338 "configure"
+#line 11340 "configure"
@@ -11345,7 +11347,7 @@
gluBeginCurve()
; return 0; }
EOF
-if { (eval echo configure:11349: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11351: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -11392,10 +11394,10 @@
LIBS=" $OPENGLLIB $LIBS"
LDFLAGS=" $LDFLAGS"
echo $ac_n "checking for glXCreatePbuffer""... $ac_c" 1>&6
-echo "configure:11396: checking for glXCreatePbuffer" >&5
+echo "configure:11398: checking for glXCreatePbuffer" >&5
-#line 11399 "configure"
+#line 11401 "configure"
which can conflict with char glXCreatePbuffer(); below. */
@@ -11418,7 +11420,7 @@
; return 0; }
EOF
-if { (eval echo configure:11422: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11424: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_func_glXCreatePbuffer=yes"
else
@@ -11455,10 +11457,10 @@
LDFLAGS=" $LDFLAGS"
echo $ac_n "checking for glXCreateGLXPixmap""... $ac_c" 1>&6
-echo "configure:11459: checking for glXCreateGLXPixmap" >&5
+echo "configure:11461: checking for glXCreateGLXPixmap" >&5
-#line 11462 "configure"
+#line 11464 "configure"
which can conflict with char glXCreateGLXPixmap(); below. */
@@ -11481,7 +11483,7 @@
; return 0; }
EOF
-if { (eval echo configure:11485: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11487: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_func_glXCreateGLXPixmap=yes"
else
@@ -11524,7 +11526,7 @@
echo $ac_n "checking for location of OpenGL framework""... $ac_c" 1>&6
-echo "configure:11528: checking for location of OpenGL framework" >&5
+echo "configure:11530: checking for location of OpenGL framework" >&5
case "$with_opengl_framework" in
{ echo "configure: error: *** You must supply a directory to --with-opengl-framework." 1>&2; exit 1; }
@@ -11548,15 +11550,15 @@
do
-echo "configure:11552: checking for $ac_hdr" >&5
+echo "configure:11554: checking for $ac_hdr" >&5
-#line 11555 "configure"
+#line 11557 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:11560: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:11562: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -11592,10 +11594,10 @@
LIBS="-framework OpenGL -framework AGL -framework ApplicationServices $LIBS"
LDFLAGS="$OPENGLPATH $LDFLAGS"
echo $ac_n "checking for glBegin""... $ac_c" 1>&6
-echo "configure:11596: checking for glBegin" >&5
+echo "configure:11598: checking for glBegin" >&5
-#line 11599 "configure"
+#line 11601 "configure"
which can conflict with char glBegin(); below. */
@@ -11618,7 +11620,7 @@
; return 0; }
EOF
-if { (eval echo configure:11622: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11624: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_func_glBegin=yes"
else
@@ -11655,10 +11657,10 @@
echo $ac_n "checking for gluBeginCurve""... $ac_c" 1>&6
-echo "configure:11659: checking for gluBeginCurve" >&5
+echo "configure:11661: checking for gluBeginCurve" >&5
-#line 11662 "configure"
+#line 11664 "configure"
which can conflict with char gluBeginCurve(); below. */
@@ -11681,7 +11683,7 @@
; return 0; }
EOF
-if { (eval echo configure:11685: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11687: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_func_gluBeginCurve=yes"
else
@@ -11729,7 +11731,7 @@
-echo "configure:11733: checking for location of OpenGL includes" >&5
+echo "configure:11735: checking for location of OpenGL includes" >&5
@@ -11755,15 +11757,15 @@
do
-echo "configure:11759: checking for $ac_hdr" >&5
+echo "configure:11761: checking for $ac_hdr" >&5
-#line 11762 "configure"
+#line 11764 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:11767: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:11769: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -11797,7 +11799,7 @@
-echo "configure:11801: checking for location of OpenGL library" >&5
+echo "configure:11803: checking for location of OpenGL library" >&5
@@ -11822,18 +11824,18 @@
ac_save_libs="$LIBS"
echo $ac_n "checking for OpenGL library""... $ac_c" 1>&6
-echo "configure:11826: checking for OpenGL library" >&5
+echo "configure:11828: checking for OpenGL library" >&5
LDFLAGS="$OPENGL_LIB_PATH $LDFLAGS"
LIBS="-lopengl32 "
-#line 11830 "configure"
+#line 11832 "configure"
#include <GL/gl.h>
int main() {
glEnd();
; return 0; }
EOF
-if { (eval echo configure:11837: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11839: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
echo "$ac_t""found" 1>&6
@@ -11857,18 +11859,18 @@
echo $ac_n "checking for GLU library""... $ac_c" 1>&6
-echo "configure:11861: checking for GLU library" >&5
+echo "configure:11863: checking for GLU library" >&5
LIBS="-lglu32 $OPENGLLIB "
-#line 11865 "configure"
+#line 11867 "configure"
#include <GL/glu.h>
int main() {
gluNewQuadric();
; return 0; }
EOF
-if { (eval echo configure:11872: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11874: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
@@ -11917,7 +11919,7 @@
echo $ac_n "checking whether to use ODBC""... $ac_c" 1>&6
-echo "configure:11921: checking whether to use ODBC" >&5
+echo "configure:11923: checking whether to use ODBC" >&5
echo "$ac_t"""$with_odbc"" 1>&6
case "$with_odbc" in
"no") USE_ODBC= ;;
@@ -11936,7 +11938,7 @@
echo $ac_n "checking for location of ODBC includes""... $ac_c" 1>&6
-echo "configure:11940: checking for location of ODBC includes" >&5
+echo "configure:11942: checking for location of ODBC includes" >&5
case "$with_odbc_includes" in
{ echo "configure: error: *** You must supply a directory to --with-odbc-includes." 1>&2; exit 1; }
@@ -11962,15 +11964,15 @@
do
-echo "configure:11966: checking for $ac_hdr" >&5
+echo "configure:11968: checking for $ac_hdr" >&5
-#line 11969 "configure"
+#line 11971 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:11974: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:11976: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -12004,7 +12006,7 @@
echo $ac_n "checking for location of ODBC library""... $ac_c" 1>&6
-echo "configure:12008: checking for location of ODBC library" >&5
+echo "configure:12010: checking for location of ODBC library" >&5
case "$with_odbc_libs" in
{ echo "configure: error: *** You must supply a directory to --with-odbc-libs." 1>&2; exit 1; }
@@ -12029,13 +12031,13 @@
echo $ac_n "checking for SQLConnect in -lodbc""... $ac_c" 1>&6
-echo "configure:12033: checking for SQLConnect in -lodbc" >&5
+echo "configure:12035: checking for SQLConnect in -lodbc" >&5
ac_lib_var=`echo odbc'_'SQLConnect | sed 'y%./+-%__p_%'`
LIBS="-lodbc $ICONVLIB $LIBS"
-#line 12039 "configure"
+#line 12041 "configure"
@@ -12046,7 +12048,7 @@
SQLConnect()
; return 0; }
EOF
-if { (eval echo configure:12050: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12052: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -12071,13 +12073,13 @@
echo $ac_n "checking for SQLConnect in -liodbc""... $ac_c" 1>&6
-echo "configure:12075: checking for SQLConnect in -liodbc" >&5
+echo "configure:12077: checking for SQLConnect in -liodbc" >&5
ac_lib_var=`echo iodbc'_'SQLConnect | sed 'y%./+-%__p_%'`
LIBS="-liodbc $LIBS"
-#line 12081 "configure"
+#line 12083 "configure"
@@ -12088,7 +12090,7 @@
SQLConnect()
; return 0; }
EOF
-if { (eval echo configure:12092: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12094: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -12113,11 +12115,11 @@
echo $ac_n "checking for ODBC library""... $ac_c" 1>&6
-echo "configure:12117: checking for ODBC library" >&5
+echo "configure:12119: checking for ODBC library" >&5
LDFLAGS="$ODBCLIB $LDFLAGS"
LIBS="-lodbc32 "
-#line 12121 "configure"
+#line 12123 "configure"
#include <windows.h>
#include <sql.h>
@@ -12125,7 +12127,7 @@
SQLAllocEnv((SQLHENV *)0);
; return 0; }
EOF
-if { (eval echo configure:12129: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12131: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
@@ -12174,7 +12176,7 @@
echo $ac_n "checking whether to use FFTW""... $ac_c" 1>&6
-echo "configure:12178: checking whether to use FFTW" >&5
+echo "configure:12180: checking whether to use FFTW" >&5
echo "$ac_t"""$with_fftw"" 1>&6
case "$with_fftw" in
"no") USE_FFTW= ;;
@@ -12193,7 +12195,7 @@
echo $ac_n "checking for location of FFTW includes""... $ac_c" 1>&6
-echo "configure:12197: checking for location of FFTW includes" >&5
+echo "configure:12199: checking for location of FFTW includes" >&5
case "$with_fftw_includes" in
{ echo "configure: error: *** You must supply a directory to --with-fftw-includes." 1>&2; exit 1; }
@@ -12219,15 +12221,15 @@
do
-echo "configure:12223: checking for $ac_hdr" >&5
+echo "configure:12225: checking for $ac_hdr" >&5
-#line 12226 "configure"
+#line 12228 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:12231: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:12233: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -12255,15 +12257,15 @@
do
-echo "configure:12259: checking for $ac_hdr" >&5
+echo "configure:12261: checking for $ac_hdr" >&5
-#line 12262 "configure"
+#line 12264 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:12267: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:12269: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -12291,15 +12293,15 @@
do
-echo "configure:12295: checking for $ac_hdr" >&5
+echo "configure:12297: checking for $ac_hdr" >&5
-#line 12298 "configure"
+#line 12300 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:12303: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:12305: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -12345,7 +12347,7 @@
echo $ac_n "checking for location of FFTW library""... $ac_c" 1>&6
-echo "configure:12349: checking for location of FFTW library" >&5
+echo "configure:12351: checking for location of FFTW library" >&5
case "$with_fftw_libs" in
{ echo "configure: error: *** You must supply a directory to --with-fftw-libs." 1>&2; exit 1; }
@@ -12370,13 +12372,13 @@
echo $ac_n "checking for fftw_execute in -lfftw3""... $ac_c" 1>&6
-echo "configure:12374: checking for fftw_execute in -lfftw3" >&5
+echo "configure:12376: checking for fftw_execute in -lfftw3" >&5
ac_lib_var=`echo fftw3'_'fftw_execute | sed 'y%./+-%__p_%'`
LIBS="-lfftw3 $MATHLIB $LIBS"
-#line 12380 "configure"
+#line 12382 "configure"
@@ -12387,7 +12389,7 @@
fftw_execute()
; return 0; }
EOF
-if { (eval echo configure:12391: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12393: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -12412,13 +12414,13 @@
echo $ac_n "checking for fftwnd_one in -lfftw""... $ac_c" 1>&6
-echo "configure:12416: checking for fftwnd_one in -lfftw" >&5
+echo "configure:12418: checking for fftwnd_one in -lfftw" >&5
ac_lib_var=`echo fftw'_'fftwnd_one | sed 'y%./+-%__p_%'`
LIBS="-lfftw $MATHLIB $LIBS"
-#line 12422 "configure"
+#line 12424 "configure"
@@ -12429,7 +12431,7 @@
fftwnd_one()
; return 0; }
EOF
-if { (eval echo configure:12433: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12435: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -12454,13 +12456,13 @@
echo $ac_n "checking for fftwnd_one in -ldfftw""... $ac_c" 1>&6
-echo "configure:12458: checking for fftwnd_one in -ldfftw" >&5
+echo "configure:12460: checking for fftwnd_one in -ldfftw" >&5
ac_lib_var=`echo dfftw'_'fftwnd_one | sed 'y%./+-%__p_%'`
LIBS="-ldfftw $MATHLIB $LIBS"
-#line 12464 "configure"
+#line 12466 "configure"
@@ -12471,7 +12473,7 @@
fftwnd_one()
; return 0; }
EOF
-if { (eval echo configure:12475: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12477: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -12528,7 +12530,7 @@
echo $ac_n "checking whether to use BLAS""... $ac_c" 1>&6
-echo "configure:12532: checking whether to use BLAS" >&5
+echo "configure:12534: checking whether to use BLAS" >&5
echo "$ac_t"""$with_blas"" 1>&6
case "$with_blas" in
"no") USE_BLAS= ;;
@@ -12549,7 +12551,7 @@
echo $ac_n "checking for location of BLAS includes""... $ac_c" 1>&6
-echo "configure:12553: checking for location of BLAS includes" >&5
+echo "configure:12555: checking for location of BLAS includes" >&5
case "$with_blas_includes" in
{ echo "configure: error: *** You must supply a directory to --with-blas-includes." 1>&2; exit 1; }
@@ -12569,7 +12571,7 @@
echo $ac_n "checking for location of BLAS library""... $ac_c" 1>&6
-echo "configure:12573: checking for location of BLAS library" >&5
+echo "configure:12575: checking for location of BLAS library" >&5
case "$with_blas_libs" in
{ echo "configure: error: *** You must supply a directory to --with-blas-libs." 1>&2; exit 1; }
@@ -12595,15 +12597,15 @@
do
-echo "configure:12599: checking for $ac_hdr" >&5
+echo "configure:12601: checking for $ac_hdr" >&5
-#line 12602 "configure"
+#line 12604 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:12607: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:12609: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -12638,13 +12640,13 @@
echo $ac_n "checking for dnrm2_ in -lblas""... $ac_c" 1>&6
-echo "configure:12642: checking for dnrm2_ in -lblas" >&5
+echo "configure:12644: checking for dnrm2_ in -lblas" >&5
ac_lib_var=`echo blas'_'dnrm2_ | sed 'y%./+-%__p_%'`
LIBS="-lblas $MATHLIB $LIBS"
-#line 12648 "configure"
+#line 12650 "configure"
@@ -12655,7 +12657,7 @@
dnrm2_()
; return 0; }
EOF
-if { (eval echo configure:12659: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12661: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -12674,13 +12676,13 @@
-echo "configure:12678: checking for dnrm2_ in -lblas" >&5
+echo "configure:12680: checking for dnrm2_ in -lblas" >&5
LIBS="-lblas $MATHLIB -lg2c $LIBS"
-#line 12684 "configure"
+#line 12686 "configure"
@@ -12691,7 +12693,7 @@
dnrm2_()
; return 0; }
EOF
-if { (eval echo configure:12695: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12697: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -12735,13 +12737,13 @@
save_LDFLAGS="$LDFLAGS"
LDFLAGS="$BLASLIB $LDFLAGS"
echo $ac_n "checking for ATL_xerbla in -latlas""... $ac_c" 1>&6
-echo "configure:12739: checking for ATL_xerbla in -latlas" >&5
+echo "configure:12741: checking for ATL_xerbla in -latlas" >&5
ac_lib_var=`echo atlas'_'ATL_xerbla | sed 'y%./+-%__p_%'`
LIBS="-latlas $LIBS"
-#line 12745 "configure"
+#line 12747 "configure"
@@ -12752,7 +12754,7 @@
ATL_xerbla()
; return 0; }
EOF
-if { (eval echo configure:12756: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12758: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -12767,13 +12769,13 @@
if eval "test \"`echo '$ac_cv_lib_'$ac_lib_var`\" = yes"; then
echo "$ac_t""yes" 1>&6
echo $ac_n "checking for sgemm_ in -lf77blas""... $ac_c" 1>&6
-echo "configure:12771: checking for sgemm_ in -lf77blas" >&5
+echo "configure:12773: checking for sgemm_ in -lf77blas" >&5
ac_lib_var=`echo f77blas'_'sgemm_ | sed 'y%./+-%__p_%'`
LIBS="-lf77blas -latlas $LIBS"
-#line 12777 "configure"
+#line 12779 "configure"
@@ -12784,7 +12786,7 @@
sgemm_()
; return 0; }
EOF
-if { (eval echo configure:12788: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12790: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -12799,13 +12801,13 @@
echo $ac_n "checking for cblas_dgemm in -lcblas""... $ac_c" 1>&6
-echo "configure:12803: checking for cblas_dgemm in -lcblas" >&5
+echo "configure:12805: checking for cblas_dgemm in -lcblas" >&5
ac_lib_var=`echo cblas'_'cblas_dgemm | sed 'y%./+-%__p_%'`
LIBS="-lcblas -lf77blas -latlas $LIBS"
-#line 12809 "configure"
+#line 12811 "configure"
@@ -12816,7 +12818,7 @@
cblas_dgemm()
; return 0; }
EOF
-if { (eval echo configure:12820: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12822: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -12861,16 +12863,16 @@
save_LIBS="$LIBS"
LIBS="$vlib_flags $LIBS"
echo $ac_n "checking for sgemm in $vlib_flags""... $ac_c" 1>&6
-echo "configure:12865: checking for sgemm in $vlib_flags" >&5
+echo "configure:12867: checking for sgemm in $vlib_flags" >&5
-#line 12867 "configure"
+#line 12869 "configure"
int main() {
sgemm
; return 0; }
EOF
-if { (eval echo configure:12874: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12876: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
blas_ok=yes; BLASLIB="$vlib_flags"
else
@@ -12888,13 +12890,13 @@
# BLAS in PhiPACK libraries? (requires generic BLAS, too)
if test $blas_ok = no; then
echo $ac_n "checking for sgemm_ in -lblas""... $ac_c" 1>&6
-echo "configure:12892: checking for sgemm_ in -lblas" >&5
+echo "configure:12894: checking for sgemm_ in -lblas" >&5
ac_lib_var=`echo blas'_'sgemm_ | sed 'y%./+-%__p_%'`
LIBS="-lblas $LIBS"
-#line 12898 "configure"
+#line 12900 "configure"
@@ -12905,7 +12907,7 @@
sgemm_()
; return 0; }
EOF
-if { (eval echo configure:12909: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12911: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -12920,13 +12922,13 @@
echo $ac_n "checking for dgemm_ in -ldgemm""... $ac_c" 1>&6
-echo "configure:12924: checking for dgemm_ in -ldgemm" >&5
+echo "configure:12926: checking for dgemm_ in -ldgemm" >&5
ac_lib_var=`echo dgemm'_'dgemm_ | sed 'y%./+-%__p_%'`
LIBS="-ldgemm -lblas $LIBS"
-#line 12930 "configure"
+#line 12932 "configure"
@@ -12937,7 +12939,7 @@
dgemm_()
; return 0; }
EOF
-if { (eval echo configure:12941: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12943: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -12952,13 +12954,13 @@
echo $ac_n "checking for sgemm_ in -lsgemm""... $ac_c" 1>&6
-echo "configure:12956: checking for sgemm_ in -lsgemm" >&5
+echo "configure:12958: checking for sgemm_ in -lsgemm" >&5
ac_lib_var=`echo sgemm'_'sgemm_ | sed 'y%./+-%__p_%'`
LIBS="-lsgemm -lblas $LIBS"
-#line 12962 "configure"
+#line 12964 "configure"
@@ -12969,7 +12971,7 @@
sgemm_()
; return 0; }
EOF
-if { (eval echo configure:12973: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12975: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -13003,13 +13005,13 @@
if test "x$GCC" != xyes; then # only works with Sun CC
echo $ac_n "checking for acosp in -lsunmath""... $ac_c" 1>&6
-echo "configure:13007: checking for acosp in -lsunmath" >&5
+echo "configure:13009: checking for acosp in -lsunmath" >&5
ac_lib_var=`echo sunmath'_'acosp | sed 'y%./+-%__p_%'`
LIBS="-lsunmath $LIBS"
-#line 13013 "configure"
+#line 13015 "configure"
@@ -13020,7 +13022,7 @@
acosp()
; return 0; }
EOF
-if { (eval echo configure:13024: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13026: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -13035,13 +13037,13 @@
echo $ac_n "checking for sgemm_ in -lsunperf""... $ac_c" 1>&6
-echo "configure:13039: checking for sgemm_ in -lsunperf" >&5
+echo "configure:13041: checking for sgemm_ in -lsunperf" >&5
ac_lib_var=`echo sunperf'_'sgemm_ | sed 'y%./+-%__p_%'`
LIBS="-lsunperf -lsunmath $LIBS"
-#line 13045 "configure"
+#line 13047 "configure"
@@ -13052,7 +13054,7 @@
sgemm_()
; return 0; }
EOF
-if { (eval echo configure:13056: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13058: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -13082,13 +13084,13 @@
# Generic BLAS library
-echo "configure:13086: checking for sgemm_ in -lblas" >&5
+echo "configure:13088: checking for sgemm_ in -lblas" >&5
LIBS="-lblas $LIBS"
-#line 13092 "configure"
+#line 13094 "configure"
@@ -13099,7 +13101,7 @@
sgemm_()
; return 0; }
EOF
-if { (eval echo configure:13103: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13105: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -13138,7 +13140,7 @@
echo $ac_n "checking whether to use LAPACK""... $ac_c" 1>&6
-echo "configure:13142: checking whether to use LAPACK" >&5
+echo "configure:13144: checking whether to use LAPACK" >&5
echo "$ac_t"""$with_lapack"" 1>&6
case "$with_lapack" in
"no") USE_LAPACK= ;;
@@ -13163,7 +13165,7 @@
echo $ac_n "checking for location of LAPACK includes""... $ac_c" 1>&6
-echo "configure:13167: checking for location of LAPACK includes" >&5
+echo "configure:13169: checking for location of LAPACK includes" >&5
case "$with_lapack_includes" in
{ echo "configure: error: *** You must supply a directory to --with-lapack-includes." 1>&2; exit 1; }
@@ -13183,7 +13185,7 @@
echo $ac_n "checking for location of LAPACK library""... $ac_c" 1>&6
-echo "configure:13187: checking for location of LAPACK library" >&5
+echo "configure:13189: checking for location of LAPACK library" >&5
case "$with_lapack_libs" in
{ echo "configure: error: *** You must supply a directory to --with-lapack-libs." 1>&2; exit 1; }
@@ -13209,15 +13211,15 @@
do
-echo "configure:13213: checking for $ac_hdr" >&5
+echo "configure:13215: checking for $ac_hdr" >&5
-#line 13216 "configure"
+#line 13218 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:13221: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:13223: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -13249,10 +13251,10 @@
save_LIBS="$LIBS"; LIBS="$LIBS $BLASLIB $MATHLIB $FLIBS"
save_LDFLAGS="$LDFLAGS"; LDFLAGS="$LAPACKLIB $LDFLAGS"
echo $ac_n "checking for dsegv_""... $ac_c" 1>&6
-echo "configure:13253: checking for dsegv_" >&5
+echo "configure:13255: checking for dsegv_" >&5
-#line 13256 "configure"
+#line 13258 "configure"
which can conflict with char dsegv_(); below. */
@@ -13275,7 +13277,7 @@
; return 0; }
EOF
-if { (eval echo configure:13279: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13281: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_func_dsegv_=yes"
else
@@ -13302,13 +13304,13 @@
save_libs="$LIBS"; LIBS="$BLASLIB $MATHLIB $LIBS"
echo $ac_n "checking for desgv_ in -llapack""... $ac_c" 1>&6
-echo "configure:13306: checking for desgv_ in -llapack" >&5
+echo "configure:13308: checking for desgv_ in -llapack" >&5
ac_lib_var=`echo lapack'_'desgv_ | sed 'y%./+-%__p_%'`
LIBS="-llapack $FLIBS $LIBS"
-#line 13312 "configure"
+#line 13314 "configure"
@@ -13319,7 +13321,7 @@
desgv_()
; return 0; }
EOF
-if { (eval echo configure:13323: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13325: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -13351,13 +13353,13 @@
echo $ac_n "checking for dgesv_ in -llapack""... $ac_c" 1>&6
-echo "configure:13355: checking for dgesv_ in -llapack" >&5
+echo "configure:13357: checking for dgesv_ in -llapack" >&5
ac_lib_var=`echo lapack'_'dgesv_ | sed 'y%./+-%__p_%'`
LIBS="-llapack $BLASLIB $MATHLIB $LIBS"
-#line 13361 "configure"
+#line 13363 "configure"
@@ -13368,7 +13370,7 @@
dgesv_()
; return 0; }
EOF
-if { (eval echo configure:13372: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13374: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -13387,13 +13389,13 @@
-echo "configure:13391: checking for dgesv_ in -llapack" >&5
+echo "configure:13393: checking for dgesv_ in -llapack" >&5
LIBS="-llapack $BLASLIB $MATHLIB -lg2c $LIBS"
-#line 13397 "configure"
+#line 13399 "configure"
@@ -13404,7 +13406,7 @@
dgesv_()
; return 0; }
EOF
-if { (eval echo configure:13408: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13410: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -13460,7 +13462,7 @@
echo $ac_n "checking whether to use Cairo""... $ac_c" 1>&6
-echo "configure:13464: checking whether to use Cairo" >&5
+echo "configure:13466: checking whether to use Cairo" >&5
echo "$ac_t"""$with_cairo"" 1>&6
case "$with_cairo" in
"no") USE_CAIRO= ;;
@@ -13486,7 +13488,7 @@
echo $ac_n "checking for location of cairo includes""... $ac_c" 1>&6
-echo "configure:13490: checking for location of cairo includes" >&5
+echo "configure:13492: checking for location of cairo includes" >&5
case "$with_cairo_includes" in
y | ye | yes | n | no)
{ echo "configure: error: *** You must supply a directory to --with-cairo-includes." 1>&2; exit 1; }
@@ -13512,15 +13514,15 @@
do
-echo "configure:13516: checking for $ac_hdr" >&5
+echo "configure:13518: checking for $ac_hdr" >&5
cat > conftest.$ac_ext <<EOF
-#line 13519 "configure"
+#line 13521 "configure"
#include "confdefs.h"
#include <$ac_hdr>
EOF
-{ (eval echo configure:13524: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:13526: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -13556,7 +13558,7 @@
echo $ac_n "checking for location of cairo library""... $ac_c" 1>&6
-echo "configure:13560: checking for location of cairo library" >&5
+echo "configure:13562: checking for location of cairo library" >&5
case "$with_cairo_libs" in
{ echo "configure: error: *** You must supply a directory to --with-cairo-libs." 1>&2; exit 1; }
@@ -13576,7 +13578,7 @@
echo $ac_n "checking for cairo linking flags""... $ac_c" 1>&6
-echo "configure:13580: checking for cairo linking flags" >&5
+echo "configure:13582: checking for cairo linking flags" >&5
case "$with_cairo_ldflags" in
{ echo "configure: error: *** You must supply a directory to --with-cairo-ldflags." 1>&2; exit 1; }
@@ -13592,10 +13594,10 @@
LIBS=" $CAIROLIB $LIBS"
LDFLAGS=" $LDFLAGS"
echo $ac_n "checking for cairo_create""... $ac_c" 1>&6
-echo "configure:13596: checking for cairo_create" >&5
+echo "configure:13598: checking for cairo_create" >&5
-#line 13599 "configure"
+#line 13601 "configure"
which can conflict with char cairo_create(); below. */
@@ -13618,7 +13620,7 @@
; return 0; }
EOF
-if { (eval echo configure:13622: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13624: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_func_cairo_create=yes"
else
@@ -13652,10 +13654,10 @@
LDFLAGS=" $LDFLAGS"
echo $ac_n "checking for cairo_xlib_surface_create_with_xrender_format""... $ac_c" 1>&6
-echo "configure:13656: checking for cairo_xlib_surface_create_with_xrender_format" >&5
+echo "configure:13658: checking for cairo_xlib_surface_create_with_xrender_format" >&5
-#line 13659 "configure"
+#line 13661 "configure"
which can conflict with char cairo_xlib_surface_create_with_xrender_format(); below. */
@@ -13678,7 +13680,7 @@
; return 0; }
EOF
-if { (eval echo configure:13682: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13684: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_func_cairo_xlib_surface_create_with_xrender_format=yes"
else
@@ -13720,7 +13722,7 @@
echo $ac_n "checking whether to use FreeType""... $ac_c" 1>&6
-echo "configure:13724: checking whether to use FreeType" >&5
+echo "configure:13726: checking whether to use FreeType" >&5
echo "$ac_t"""$with_freetype"" 1>&6
case "$with_freetype" in
"no") USE_FREETYPE= ;;
@@ -13739,7 +13741,7 @@
echo $ac_n "checking for location of FreeType includes""... $ac_c" 1>&6
-echo "configure:13743: checking for location of FreeType includes" >&5
+echo "configure:13745: checking for location of FreeType includes" >&5
case "$with_freetype_includes" in
{ echo "configure: error: *** You must supply a directory to --with-freetype-includes." 1>&2; exit 1; }
@@ -13765,15 +13767,15 @@
do
-echo "configure:13769: checking for $ac_hdr" >&5
+echo "configure:13771: checking for $ac_hdr" >&5
-#line 13772 "configure"
+#line 13774 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:13777: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:13779: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -13807,7 +13809,7 @@
echo $ac_n "checking for location of FreeType library""... $ac_c" 1>&6
-echo "configure:13811: checking for location of FreeType library" >&5
+echo "configure:13813: checking for location of FreeType library" >&5
case "$with_freetype_libs" in
{ echo "configure: error: *** You must supply a directory to --with-freetype-libs." 1>&2; exit 1; }
@@ -13832,13 +13834,13 @@
echo $ac_n "checking for FT_Init_FreeType in -lfreetype""... $ac_c" 1>&6
-echo "configure:13836: checking for FT_Init_FreeType in -lfreetype" >&5
+echo "configure:13838: checking for FT_Init_FreeType in -lfreetype" >&5
ac_lib_var=`echo freetype'_'FT_Init_FreeType | sed 'y%./+-%__p_%'`
ac_save_LIBS="$LIBS"
LIBS="-lfreetype $LIBS"
-#line 13842 "configure"
+#line 13844 "configure"
/* Override any gcc2 internal prototype to avoid an error. */
/* We use char because int might match the return type of a gcc2
@@ -13849,7 +13851,7 @@
FT_Init_FreeType()
; return 0; }
EOF
-if { (eval echo configure:13853: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13855: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_lib_$ac_lib_var=yes"
else
@@ -13890,7 +13892,7 @@
echo $ac_n "checking whether to use NLS""... $ac_c" 1>&6
-echo "configure:13894: checking whether to use NLS" >&5
+echo "configure:13896: checking whether to use NLS" >&5
echo "$ac_t"""$with_nls"" 1>&6
case "$with_nls" in
"no") USE_NLS= ;;
@@ -13910,10 +13912,10 @@
echo $ac_n "checking for gettext""... $ac_c" 1>&6
-echo "configure:13914: checking for gettext" >&5
+echo "configure:13916: checking for gettext" >&5
-#line 13917 "configure"
+#line 13919 "configure"
which can conflict with char gettext(); below. */
@@ -13936,7 +13938,7 @@
; return 0; }
EOF
-if { (eval echo configure:13940: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13942: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_func_gettext=yes"
else
@@ -13954,13 +13956,13 @@
echo $ac_n "checking for gettext in -lintl""... $ac_c" 1>&6
-echo "configure:13958: checking for gettext in -lintl" >&5
+echo "configure:13960: checking for gettext in -lintl" >&5
ac_lib_var=`echo intl'_'gettext | sed 'y%./+-%__p_%'`
LIBS="-lintl $LIBS"
-#line 13964 "configure"
+#line 13966 "configure"
@@ -13971,7 +13973,7 @@
gettext()
; return 0; }
EOF
-if { (eval echo configure:13975: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13977: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -14006,7 +14008,7 @@
echo $ac_n "checking whether to use C++""... $ac_c" 1>&6
-echo "configure:14010: checking whether to use C++" >&5
+echo "configure:14012: checking whether to use C++" >&5
echo "$ac_t"""$with_cxx"" 1>&6
case "$with_cxx" in
"no") USE_CXX= ;;
@@ -14022,7 +14024,7 @@
# Extract the first word of "$ac_prog", so it can be a program name with args.
set dummy $ac_prog; ac_word=$2
-echo "configure:14026: checking for $ac_word" >&5
+echo "configure:14028: checking for $ac_word" >&5
if test -n "$CXX"; then
ac_cv_prog_CXX="$CXX" # Let the user override the test.
@@ -14051,7 +14053,7 @@
echo $ac_n "checking whether the C++ compiler ($CXX $CXXFLAGS $LDFLAGS) works""... $ac_c" 1>&6
-echo "configure:14055: checking whether the C++ compiler ($CXX $CXXFLAGS $LDFLAGS) works" >&5
+echo "configure:14057: checking whether the C++ compiler ($CXX $CXXFLAGS $LDFLAGS) works" >&5
ac_ext=C
# CXXFLAGS is not in ac_cpp because -g, -O, etc. are not valid cpp options.
@@ -14062,12 +14064,12 @@
cat > conftest.$ac_ext << EOF
-#line 14066 "configure"
+#line 14068 "configure"
int main(){return(0);}
EOF
-if { (eval echo configure:14071: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:14073: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
ac_cv_prog_cxx_works=yes
# If we can't run a trivial program, we are probably using a cross compiler.
if (./conftest; exit) 2>/dev/null; then
@@ -14093,19 +14095,19 @@
{ echo "configure: error: installation or configuration problem: C++ compiler cannot create executables." 1>&2; exit 1; }
fi
echo $ac_n "checking whether the C++ compiler ($CXX $CXXFLAGS $LDFLAGS) is a cross-compiler""... $ac_c" 1>&6
-echo "configure:14097: checking whether the C++ compiler ($CXX $CXXFLAGS $LDFLAGS) is a cross-compiler" >&5
+echo "configure:14099: checking whether the C++ compiler ($CXX $CXXFLAGS $LDFLAGS) is a cross-compiler" >&5
echo "$ac_t""$ac_cv_prog_cxx_cross" 1>&6
cross_compiling=$ac_cv_prog_cxx_cross
echo $ac_n "checking whether we are using GNU C++""... $ac_c" 1>&6
-echo "configure:14102: checking whether we are using GNU C++" >&5
+echo "configure:14104: checking whether we are using GNU C++" >&5
cat > conftest.C <<EOF
#ifdef __GNUC__
yes;
#endif
EOF
-if { ac_try='${CXX-g++} -E conftest.C'; { (eval echo configure:14109: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }; } | egrep yes >/dev/null 2>&1; then
+if { ac_try='${CXX-g++} -E conftest.C'; { (eval echo configure:14111: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }; } | egrep yes >/dev/null 2>&1; then
ac_cv_prog_gxx=yes
else
ac_cv_prog_gxx=no
@@ -14123,7 +14125,7 @@
ac_save_CXXFLAGS="$CXXFLAGS"
CXXFLAGS=
echo $ac_n "checking whether ${CXX-g++} accepts -g""... $ac_c" 1>&6
-echo "configure:14127: checking whether ${CXX-g++} accepts -g" >&5
+echo "configure:14129: checking whether ${CXX-g++} accepts -g" >&5
echo 'void f(){}' > conftest.cc
if test -z "`${CXX-g++} -g -c conftest.cc 2>&1`"; then
@@ -14164,7 +14166,7 @@
echo $ac_n "checking whether to use openDWG""... $ac_c" 1>&6
-echo "configure:14168: checking whether to use openDWG" >&5
+echo "configure:14170: checking whether to use openDWG" >&5
echo "$ac_t"""$with_opendwg"" 1>&6
case "$with_opendwg" in
"no") USE_OPENDWG= ;;
@@ -14184,7 +14186,7 @@
echo $ac_n "checking for location of openDGW includes""... $ac_c" 1>&6
-echo "configure:14188: checking for location of openDGW includes" >&5
+echo "configure:14190: checking for location of openDGW includes" >&5
case "$with_opendwg_includes" in
{ echo "configure: error: *** You must supply a directory to --with-opendwg-includes." 1>&2; exit 1; }
@@ -14210,15 +14212,15 @@
do
ac_safe=`echo "$ac_hdr" | sed 'y%./+-%__p_%'`
echo $ac_n "checking for $ac_hdr""... $ac_c" 1>&6
-echo "configure:14214: checking for $ac_hdr" >&5
+echo "configure:14216: checking for $ac_hdr" >&5
-#line 14217 "configure"
+#line 14219 "configure"
#include <$ac_hdr>
EOF
ac_try="$ac_cpp conftest.$ac_ext >/dev/null 2>conftest.out"
-{ (eval echo configure:14222: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:14224: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
ac_err=`grep -v '^ *+' conftest.out | grep -v "^conftest.${ac_ext}\$"`
if test -z "$ac_err"; then
rm -rf conftest*
@@ -14252,7 +14254,7 @@
echo $ac_n "checking for location of openDWG library""... $ac_c" 1>&6
-echo "configure:14256: checking for location of openDWG library" >&5
+echo "configure:14258: checking for location of openDWG library" >&5
case "$with_opendwg_libs" in
{ echo "configure: error: *** You must supply a directory to --with-opendwg-libs." 1>&2; exit 1; }
@@ -14293,7 +14295,7 @@
echo $ac_n "checking whether to use POSIX threads""... $ac_c" 1>&6
-echo "configure:14297: checking whether to use POSIX threads" >&5
+echo "configure:14299: checking whether to use POSIX threads" >&5
echo "$ac_t"""$with_pthread"" 1>&6
case "$with_pthread" in
"no") USE_PTHREAD= ;;
@@ -14313,7 +14315,7 @@
echo $ac_n "checking for location of POSIX threads includes""... $ac_c" 1>&6
-echo "configure:14317: checking for location of POSIX threads includes" >&5
+echo "configure:14319: checking for location of POSIX threads includes" >&5
case "$with_pthread_includes" in
{ echo "configure: error: *** You must supply a directory to --with-pthread-includes." 1>&2; exit 1; }
@@ -14339,15 +14341,15 @@
do
-echo "configure:14343: checking for $ac_hdr" >&5
+echo "configure:14345: checking for $ac_hdr" >&5
-#line 14346 "configure"
+#line 14348 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:14351: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:14353: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -14381,7 +14383,7 @@
echo $ac_n "checking for location of POSIX threads library""... $ac_c" 1>&6
-echo "configure:14385: checking for location of POSIX threads library" >&5
+echo "configure:14387: checking for location of POSIX threads library" >&5
case "$with_pthread_libs" in
{ echo "configure: error: *** You must supply a directory to --with-pthread-libs." 1>&2; exit 1; }
@@ -14406,10 +14408,10 @@
LIBS=" $LIBS"
LDFLAGS=" $LDFLAGS"
echo $ac_n "checking for pthread_create""... $ac_c" 1>&6
-echo "configure:14410: checking for pthread_create" >&5
+echo "configure:14412: checking for pthread_create" >&5
-#line 14413 "configure"
+#line 14415 "configure"
which can conflict with char pthread_create(); below. */
@@ -14432,7 +14434,7 @@
; return 0; }
EOF
-if { (eval echo configure:14436: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:14438: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_func_pthread_create=yes"
else
@@ -14459,13 +14461,13 @@
echo $ac_n "checking for pthread_create in -lpthread""... $ac_c" 1>&6
-echo "configure:14463: checking for pthread_create in -lpthread" >&5
+echo "configure:14465: checking for pthread_create in -lpthread" >&5
ac_lib_var=`echo pthread'_'pthread_create | sed 'y%./+-%__p_%'`
LIBS="-lpthread $LIBS"
-#line 14469 "configure"
+#line 14471 "configure"
@@ -14476,7 +14478,7 @@
pthread_create()
; return 0; }
EOF
-if { (eval echo configure:14480: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:14482: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -14532,7 +14534,7 @@
if test "$enable_largefile" = yes; then
echo $ac_n "checking for special C compiler options needed for large files""... $ac_c" 1>&6
-echo "configure:14536: checking for special C compiler options needed for large files" >&5
+echo "configure:14538: checking for special C compiler options needed for large files" >&5
ac_cv_sys_largefile_CC=no
largefile_cc_opt=""
@@ -14540,7 +14542,7 @@
# IRIX 6.2 and later do not support large files by default,
# so use the C compiler's -n32 option if that helps.
-#line 14544 "configure"
+#line 14546 "configure"
#include <sys/types.h>
/* Check that off_t can represent 2**63 - 1 correctly.
@@ -14556,7 +14558,7 @@
; return 0; }
EOF
-if { (eval echo configure:14560: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:14562: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
else
echo "configure: failed program was:" >&5
@@ -14565,7 +14567,7 @@
ac_save_CC="${CC-cc}"
CC="$CC -n32"
-#line 14569 "configure"
+#line 14571 "configure"
@@ -14581,7 +14583,7 @@
; return 0; }
EOF
-if { (eval echo configure:14585: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:14587: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
rm -rf conftest*
ac_cv_sys_largefile_CC=' -n32'
else
@@ -14601,11 +14603,11 @@
fi
echo $ac_n "checking for _FILE_OFFSET_BITS value needed for large files""... $ac_c" 1>&6
-echo "configure:14605: checking for _FILE_OFFSET_BITS value needed for large files" >&5
+echo "configure:14607: checking for _FILE_OFFSET_BITS value needed for large files" >&5
ac_cv_sys_file_offset_bits=no
-#line 14609 "configure"
+#line 14611 "configure"
@@ -14621,14 +14623,14 @@
; return 0; }
EOF
-if { (eval echo configure:14625: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:14627: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
else
cat conftest.$ac_ext >&5
rm -rf conftest*
-#line 14632 "configure"
+#line 14634 "configure"
#define _FILE_OFFSET_BITS 64
@@ -14646,7 +14648,7 @@
; return 0; }
EOF
-if { (eval echo configure:14650: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:14652: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
rm -rf conftest*
ac_cv_sys_file_offset_bits=64
else
@@ -14665,11 +14667,11 @@
fi
echo $ac_n "checking for _LARGE_FILES value needed for large files""... $ac_c" 1>&6
-echo "configure:14669: checking for _LARGE_FILES value needed for large files" >&5
+echo "configure:14671: checking for _LARGE_FILES value needed for large files" >&5
ac_cv_sys_large_files=no
-#line 14673 "configure"
+#line 14675 "configure"
@@ -14685,14 +14687,14 @@
; return 0; }
EOF
-if { (eval echo configure:14689: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:14691: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
else
rm -rf conftest*
-#line 14696 "configure"
+#line 14698 "configure"
#define _LARGE_FILES 1
@@ -14710,7 +14712,7 @@
; return 0; }
EOF
-if { (eval echo configure:14714: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:14716: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
rm -rf conftest*
ac_cv_sys_large_files=1
else
@@ -14729,25 +14731,25 @@
fi
echo $ac_n "checking for _LARGEFILE_SOURCE value needed for large files""... $ac_c" 1>&6
-echo "configure:14733: checking for _LARGEFILE_SOURCE value needed for large files" >&5
+echo "configure:14735: checking for _LARGEFILE_SOURCE value needed for large files" >&5
ac_cv_sys_largefile_source=no
-#line 14737 "configure"
+#line 14739 "configure"
#include <stdio.h>
int main() {
return !fseeko;
; return 0; }
EOF
-if { (eval echo configure:14744: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:14746: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
else
rm -rf conftest*
-#line 14751 "configure"
+#line 14753 "configure"
#define _LARGEFILE_SOURCE 1
#include <stdio.h>
@@ -14756,7 +14758,7 @@
return !fseeko;
; return 0; }
EOF
-if { (eval echo configure:14760: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:14762: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
rm -rf conftest*
ac_cv_sys_largefile_source=1
else
@@ -14777,10 +14779,10 @@
fi
echo $ac_n "checking if system supports Large Files at all""... $ac_c" 1>&6
-echo "configure:14781: checking if system supports Large Files at all" >&5
+echo "configure:14783: checking if system supports Large Files at all" >&5
-#line 14784 "configure"
+#line 14786 "configure"
#include <stdio.h>
@@ -14812,7 +14814,7 @@
#endif
; return 0; }
EOF
-if { (eval echo configure:14816: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:14818: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
rm -rf conftest*
ac_cv_largefiles=yes
else
@@ -14841,7 +14843,7 @@
# Python check
echo $ac_n "checking whether to use Python""... $ac_c" 1>&6
-echo "configure:14845: checking whether to use Python" >&5
+echo "configure:14847: checking whether to use Python" >&5
PYTHONINC=
PYTHONCFLAGS=
@@ -14861,7 +14863,7 @@
# Extract the first word of "python-config", so it can be a program name with args.
set dummy python-config; ac_word=$2
echo $ac_n "checking for $ac_word""... $ac_c" 1>&6
-echo "configure:14865: checking for $ac_word" >&5
+echo "configure:14867: checking for $ac_word" >&5
case "$PY_CONFIG" in
@@ -14906,15 +14908,15 @@
do
-echo "configure:14910: checking for $ac_hdr" >&5
+echo "configure:14912: checking for $ac_hdr" >&5
-#line 14913 "configure"
+#line 14915 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:14918: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:14920: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -14954,7 +14956,7 @@
# Extract the first word of "swig", so it can be a program name with args.
set dummy swig; ac_word=$2
-echo "configure:14958: checking for $ac_word" >&5
+echo "configure:14960: checking for $ac_word" >&5
case "$SWIG" in
@@ -15000,7 +15002,7 @@
# Enable wxWidgets support (for wxGUI)
echo $ac_n "checking whether to use wxWidgets""... $ac_c" 1>&6
-echo "configure:15004: checking whether to use wxWidgets" >&5
+echo "configure:15006: checking whether to use wxWidgets" >&5
WXVERSION=
WXWIDGETSCXXFLAGS=
@@ -15020,7 +15022,7 @@
# Extract the first word of "wx-config", so it can be a program name with args.
set dummy wx-config; ac_word=$2
-echo "configure:15024: checking for $ac_word" >&5
+echo "configure:15026: checking for $ac_word" >&5
case "$WX_CONFIG" in
@@ -15068,7 +15070,7 @@
REQWX="2.8.1"
echo $ac_n "checking wxWidgets version""... $ac_c" 1>&6
-echo "configure:15072: checking wxWidgets version" >&5
+echo "configure:15074: checking wxWidgets version" >&5
if WXVERSION=`"$WX_CONFIG" --version`; then
echo "$ac_t""$WXVERSION" 1>&6
else
@@ -15091,15 +15093,15 @@
do
-echo "configure:15095: checking for $ac_hdr" >&5
+echo "configure:15097: checking for $ac_hdr" >&5
-#line 15098 "configure"
+#line 15100 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:15103: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:15105: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -15691,6 +15693,9 @@
echo " OpenGL platform: ${OPENGL_TYPE}"
+echo ""
echo " MacOSX application: `if test -n "${MACOSX_APP}" ; then echo yes ; else echo no ; fi`"
echo ""
Modified: grass/trunk/configure.in
--- grass/trunk/configure.in 2009-03-30 18:44:11 UTC (rev 36537)
+++ grass/trunk/configure.in 2009-03-30 18:56:18 UTC (rev 36538)
@@ -211,7 +211,7 @@
AC_ARG_WITH(geos,
[ --with-geos[=path/geos-config] enable GEOS support (geos-config with path, \
-e.g. '--with-geos=/usr/local/bin/geos-config')])
+e.g. '--with-geos=/usr/local/bin/geos-config', default: no)],, with_geos="no")
AC_ARG_WITH(includes,
[ --with-includes=DIRS site include files are in DIRS])
@@ -1773,6 +1773,7 @@
LOC_MSG([ Building shared libraries: ${shared_ok}])
LOC_MSG([ 64bit support: ${do64bit}])
LOC_MSG([ OpenGL platform: ${OPENGL_TYPE}])
+LOC_MSG()
LOC_MSG_USE(MacOSX application,MACOSX_APP)
LOC_MSG()
LOC_MSG_USE(NVIZ,USE_TOGL)
