[GRASS-SVN] r36547 - grass/trunk/lib/vector/Vlib
svn_grass at osgeo.org
Tue Mar 31 11:04:43 EDT 2009
Author: mmetz
Date: 2009-03-31 11:04:43 -0400 (Tue, 31 Mar 2009)
New Revision: 36547
grass/trunk/lib/vector/Vlib/snap.c
Snap lines: use closest anchor, not first best, lighter on memory and a bit faster
Modified: grass/trunk/lib/vector/Vlib/snap.c
--- grass/trunk/lib/vector/Vlib/snap.c 2009-03-31 05:34:35 UTC (rev 36546)
+++ grass/trunk/lib/vector/Vlib/snap.c 2009-03-31 15:04:43 UTC (rev 36547)
@@ -5,7 +5,7 @@
* Higher level functions for reading/writing/manipulating vectors.
- * (C) 2001-2008 by the GRASS Development Team
+ * (C) 2001-2009 by the GRASS Development Team
* This program is free software under the
* GNU General Public License (>=v2).
@@ -13,8 +13,9 @@
* for details.
* \author Radim Blazek
+ * update to GRASS 7 Markus Metz
- * \date 2001
+ * \date 2009
#include <stdlib.h>
@@ -22,6 +23,7 @@
#include <grass/gis.h>
#include <grass/Vect.h>
#include <grass/glocale.h>
+#include <grass/vect/rbtree.h>
/* function prototypes */
static int sort_new(const void *pa, const void *pb);
@@ -30,6 +32,7 @@
typedef struct
double x, y;
+ double anchor_x, anchor_y;
int anchor; /* 0 - anchor, do not snap this point, that means snap others to this */
/* >0 - index of anchor to which snap this point */
/* -1 - init value */
@@ -37,6 +40,7 @@
typedef struct
int anchor;
double along;
} NEW;
@@ -48,6 +52,32 @@
return 1;
+/* function used by binary tree to compare items */
+int compare_snappnts(const void *Xpnta, const void *Xpntb)
+ XPNT *a, *b;
+ a = (XPNT *)Xpnta;
+ b = (XPNT *)Xpntb;
+ if (a->x > b->x)
+ return 1;
+ else if (a->x < b->x)
+ return -1;
+ else {
+ if (a->y > b->y)
+ return 1;
+ else if (a->y < b->y)
+ return -1;
+ else
+ return 0;
+ G_warning("Break polygons: Bug in binary tree!");
+ return 1;
* \brief Snap selected lines to existing vertex in threshold.
@@ -76,6 +106,13 @@
| 2
+ The algorithm selects anchor vertices and snaps non-anchor vertices
+ to these anchors.
+ The distance between anchor vertices is always > threshold.
+ If there is more than one anchor vertex within threshold around a
+ non-anchor vertex, this vertex is snapped to the nearest anchor
+ vertex within threshold.
void
Vect_snap_lines_list(struct Map_info *Map, struct ilist *List_lines,
@@ -85,19 +122,17 @@
struct line_cats *Cats;
int line, ltype, line_idx;
double thresh2;
+ double xmin, xmax, ymin, ymax;
- struct Node *RTree;
+ struct RB_TREE *RBTree;
+ struct RB_TRAV RBTrav1, RBTrav2;
int point; /* index in points array */
int nanchors, ntosnap; /* number of anchors and number of points to be snapped */
int nsnapped, ncreated; /* number of snapped verices, number of new vertices (on segments) */
int apoints, npoints, nvertices; /* number of allocated points, registered points, vertices */
- XPNT *XPnts; /* Array of points */
+ XPNT *XPnt_found, *XPnt_found2, XPnt_search; /* snap points */
NEW *New = NULL; /* Array of new points */
int anew = 0, nnew; /* allocated new points , number of new points */
- struct Rect rect;
- struct ilist *List;
- int *Index = NULL; /* indexes of anchors for vertices */
- int aindex = 0; /* allocated Index */
if (List_lines->n_values < 1)
return;
@@ -105,16 +140,15 @@
Points = Vect_new_line_struct();
NPoints = Vect_new_line_struct();
Cats = Vect_new_cats_struct();
- List = Vect_new_list();
- RTree = RTreeNewIndex();
+ RBTree = rbtree_create(compare_snappnts, sizeof(XPNT));
thresh2 = thresh * thresh;
- /* Go through all lines in vector, and add each point to structure of points */
+ /* Go through all lines in vector, and add each point to search tree
+ * points are kept sorted in search tree first by x, then by y */
apoints = 0;
point = 1; /* index starts from 1 ! */
nvertices = 0;
- XPnts = NULL;
G_verbose_message(_("Snap vertices Pass 1: select points"));
@@ -135,87 +169,105 @@
G_debug(3, " vertex v = %d", v);
nvertices++;
- /* Box */
- rect.boundary[0] = Points->x[v];
- rect.boundary[3] = Points->x[v];
- rect.boundary[1] = Points->y[v];
- rect.boundary[4] = Points->y[v];
- rect.boundary[2] = 0;
- rect.boundary[5] = 0;
+ XPnt_search.x = Points->x[v];
+ XPnt_search.y = Points->y[v];
/* Already registered ? */
- Vect_reset_list(List);
- RTreeSearch(RTree, &rect, (void *)add_item, List);
- G_debug(3, "List : nvalues = %d", List->n_values);
+ XPnt_found = rbtree_find(RBTree, &XPnt_search);
- if (List->n_values == 0) { /* Not found */
- /* Add to tree and to structure */
- RTreeInsertRect(&rect, point, &RTree, 0);
- if ((point - 1) == apoints) {
- apoints += 10000;
- XPnts =
- (XPNT *) G_realloc(XPnts,
- (apoints + 1) * sizeof(XPNT));
- XPnts[point].x = Points->x[v];
- XPnts[point].y = Points->y[v];
- XPnts[point].anchor = -1;
+ if (XPnt_found == NULL) { /* Not found */
+ /* Add to tree */
+ XPnt_search.anchor = -1;
+ XPnt_search.anchor_x = Points->x[v];
+ XPnt_search.anchor_y = Points->y[v];
+ rbtree_insert(RBTree, &XPnt_search);
point++;
+ } /* end of points selection */
G_percent(line_idx, List_lines->n_values, 2); /* finish it */
npoints = point - 1;
- /* Go through all registered points and if not yet marked mark it as anchor and assign this anchor
- * to all not yet marked points in threshold */
- G_verbose_message(_("Snap vertices Pass 2: assign points to snap to"));
+ /* Go through all registered points and if not yet marked,
+ * mark it as anchor and assign this anchor to all not yet marked
+ * points within threshold.
+ * Update anchor for marked points if new anchor is closer. */
+ G_verbose_message(_("Snap vertices Pass 2: assign anchor vertices"));
nanchors = ntosnap = 0;
- for (point = 1; point <= npoints; point++) {
- int i;
+ rbtree_init_trav(&RBTrav1, RBTree);
+ rbtree_init_trav(&RBTrav2, RBTree);
+ point = 1;
+ /* XPnts in the old version were not sorted, this causes subtle differences */
+ while ((XPnt_found = rbtree_traverse(&RBTrav1)) != NULL) {
+ double dx, dy, dist2;
G_percent(point, npoints, 2);
G_debug(3, " point = %d", point);
- if (XPnts[point].anchor >= 0)
+ point++;
+ if (XPnt_found->anchor >= 0)
continue;
- XPnts[point].anchor = 0; /* make it anchor */
+ XPnt_found->anchor = 0; /* make it anchor */
nanchors++;
/* Find points in threshold */
- rect.boundary[0] = XPnts[point].x - thresh;
- rect.boundary[3] = XPnts[point].x + thresh;
- rect.boundary[1] = XPnts[point].y - thresh;
- rect.boundary[4] = XPnts[point].y + thresh;
+ xmin = XPnt_found->x - thresh;
+ xmax = XPnt_found->x + thresh;
+ ymin = XPnt_found->y - thresh;
+ ymax = XPnt_found->y + thresh;
- G_debug(4, " %d points in threshold box", List->n_values);
+ XPnt_search.x = xmin;
+ XPnt_search.y = ymin;
- for (i = 0; i < List->n_values; i++) {
- int pointb;
- double dx, dy, dist2;
+ /* traverse search tree from start point onwards */
+ while ((XPnt_found2 = rbtree_traverse_start(&RBTrav2, &XPnt_search)) != NULL) {
+ if (XPnt_found2->x > xmax)
+ break; /* outside x search limit */
+ /* not an anchor, and within y search limits */
+ if (XPnt_found2->anchor != 0 &&
+ XPnt_found2->y >= ymin && XPnt_found2->y <= ymax) {
- pointb = List->value[i];
- if (pointb == point)
- continue;
+ dx = XPnt_found2->x - XPnt_found->x;
+ dy = XPnt_found2->y - XPnt_found->y;
+ if (dx == 0 && dy == 0) /* XPnt_found2 == XPnt_found */
+ continue;
+ dist2 = dx * dx + dy * dy;
- dx = XPnts[pointb].x - XPnts[point].x;
- dy = XPnts[pointb].y - XPnts[point].y;
- dist2 = dx * dx + dy * dy;
+ if (dist2 > thresh2) /* outside threshold */
+ continue;
+ /* doesn't have an anchor yet */
+ if (XPnt_found2->anchor == -1) {
+ XPnt_found2->anchor = 1;
+ XPnt_found2->anchor_x = XPnt_found->x;
+ XPnt_found2->anchor_y = XPnt_found->y;
+ ntosnap++;
+ else { /* check distance to previously assigned anchor */
+ double dist2_a;
- if (dist2 <= thresh2) {
- XPnts[pointb].anchor = point;
- ntosnap++;
+ dx = XPnt_found2->anchor_x - XPnt_found2->x;
+ dy = XPnt_found2->anchor_y - XPnt_found2->y;
+ dist2_a = dx * dx + dy * dy;
+ /* replace old anchor */
+ if (dist2 < dist2_a) {
+ } /* end of anchor assignment */
/* Go through all lines and:
* 1) for all vertices: if not anchor snap it to its anchor
@@ -226,7 +278,7 @@
G_verbose_message(_("Snap vertices Pass 3: snap to assigned points"));
for (line_idx = 0; line_idx < List_lines->n_values; line_idx++) {
- int v, spoint, anchor;
+ int v;
int changed = 0;
@@ -239,52 +291,38 @@
ltype = Vect_read_line(Map, Points, Cats, line);
- if (Points->n_points >= aindex) {
- aindex = Points->n_points;
- Index = (int *)G_realloc(Index, aindex * sizeof(int));
/* Snap all vertices */
+ G_debug(2, "snap vertices");
for (v = 0; v < Points->n_points; v++) {
- /* Box */
/* Find point ( should always find one point ) */
- spoint = List->value[0];
- anchor = XPnts[spoint].anchor;
+ G_fatal_error("Snap lines: could not find vertex");
- if (anchor > 0) { /* to be snapped */
- Points->x[v] = XPnts[anchor].x;
- Points->y[v] = XPnts[anchor].y;
+ if (XPnt_found->anchor > 0) { /* to be snapped */
+ Points->x[v] = XPnt_found->anchor_x;
+ Points->y[v] = XPnt_found->anchor_y;
nsnapped++;
changed = 1;
- Index[v] = anchor; /* point on new location */
- else {
- Index[v] = spoint; /* old point */
/* New points */
Vect_reset_line(NPoints);
/* Snap all segments to anchors in threshold */
+ G_debug(2, "snap segments");
for (v = 0; v < Points->n_points - 1; v++) {
int i;
- double x1, x2, y1, y2, xmin, xmax, ymin, ymax;
+ double x1, x2, y1, y2;
+ double dist2, along;
+ int status;
- G_debug(3, " segment = %d end anchors : %d %d", v, Index[v],
- Index[v + 1]);
x1 = Points->x[v];
x2 = Points->x[v + 1];
y1 = Points->y[v];
@@ -293,72 +331,62 @@
Vect_append_point(NPoints, Points->x[v], Points->y[v],
Points->z[v]);
- /* Box */
- if (x1 <= x2) {
- xmin = x1;
- xmax = x2;
- else {
- xmin = x2;
- xmax = x1;
- if (y1 <= y2) {
- ymin = y1;
- ymax = y2;
- else {
- ymin = y2;
- ymax = y1;
+ /* Search limits */
+ xmin = (x1 < x2 ? x1 : x2) - thresh;
+ xmax = (x1 > x2 ? x1 : x2) + thresh;
+ ymin = (y1 < y2 ? y1 : y2) - thresh;
+ ymax = (y1 > y2 ? y1 : y2) + thresh;
- rect.boundary[0] = xmin - thresh;
- rect.boundary[3] = xmax + thresh;
- rect.boundary[1] = ymin - thresh;
- rect.boundary[4] = ymax + thresh;
- /* Find points */
- G_debug(3, " %d points in box", List->n_values);
- /* Snap to anchor in threshold different from end points */
+ /* Find points within search limits */
nnew = 0;
- double dist2, along;
+ G_debug(3, "snap segment");
- spoint = List->value[i];
- G_debug(4, " spoint = %d anchor = %d", spoint,
- XPnts[spoint].anchor);
+ /* found point must be within y search limits */
+ if (XPnt_found2->y < ymin || XPnt_found2->y > ymax)
+ continue;
- if (spoint == Index[v] || spoint == Index[v + 1])
- continue; /* end point */
- if (XPnts[spoint].anchor > 0)
+ /* found point must be anchor */
+ if (XPnt_found2->anchor > 0)
continue; /* point is not anchor */
+ /* found point must not be end point */
+ if ((XPnt_found2->x == x1 && XPnt_found2->y == y1) ||
+ (XPnt_found2->x == x2 && XPnt_found2->y == y2))
+ continue; /* end point */
/* Check the distance */
dist2 =
- dig_distance2_point_to_line(XPnts[spoint].x,
- XPnts[spoint].y, 0, x1, y1, 0,
+ dig_distance2_point_to_line(XPnt_found2->x,
+ XPnt_found2->y, 0, x1, y1, 0,
x2, y2, 0, 0, NULL, NULL,
- NULL, &along, NULL);
+ NULL, &along, &status);
G_debug(4, " distance = %lf", sqrt(dist2));
+ /* status == 0 if point is w/in segment space
+ * avoids messy lines and boundaries */
+ if (status == 0 && dist2 <= thresh2) {
G_debug(4, " anchor in thresh, along = %lf", along);
if (nnew == anew) {
anew += 100;
New = (NEW *) G_realloc(New, anew * sizeof(NEW));
- New[nnew].anchor = spoint;
+ New[nnew].anchor_x = XPnt_found2->x;
+ New[nnew].anchor_y = XPnt_found2->y;
New[nnew].along = along;
nnew++;
G_debug(3, " nnew = %d", nnew);
/* insert new vertices */
if (nnew > 0) {
@@ -366,10 +394,8 @@
qsort(New, sizeof(char) * nnew, sizeof(NEW), sort_new);
for (i = 0; i < nnew; i++) {
- anchor = New[i].anchor;
- /* Vect_line_insert_point ( Points, ++v, XPnts[anchor].x, XPnts[anchor].y, 0); */
- Vect_append_point(NPoints, XPnts[anchor].x,
- XPnts[anchor].y, 0);
+ Vect_append_point(NPoints, New[i].anchor_x,
+ New[i].anchor_y, 0);
ncreated++;
changed = 1;
@@ -399,10 +425,8 @@
Vect_destroy_line_struct(Points);
Vect_destroy_line_struct(NPoints);
Vect_destroy_cats_struct(Cats);
- G_free(XPnts);
- G_free(Index);
G_free(New);
- RTreeDestroyNode(RTree);
+ rbtree_destroy(RBTree);
G_verbose_message(_("Snapped vertices: %d"), nsnapped);
G_verbose_message(_("New vertices: %d"), ncreated);
