[GRASS-SVN] r36955 - grass/trunk
Sun May 3 00:45:06 EDT 2009
Author: hamish
Date: 2009-05-03 00:45:05 -0400 (Sun, 03 May 2009)
New Revision: 36955
   grass/trunk/configure
   grass/trunk/configure.in
=yes doesn't need basename, minor whitespace/reorder
Modified: grass/trunk/configure
--- grass/trunk/configure	2009-05-03 04:39:50 UTC (rev 36954)
+++ grass/trunk/configure	2009-05-03 04:45:05 UTC (rev 36955)
@@ -65,15 +65,16 @@
 ac_help="$ac_help
   --with-pthread          support POSIX threads functionality (default: no)"
 ac_help="$ac_help
-  --with-python[=path/python-config] enable support for Python SWIG bindings (python-config with path, \
-e.g. '--with-python=/usr/bin/python2.5-config', default: no)"
+  --with-gdal[=path/gdal-config] enable GDAL/OGR support (gdal-config with path, \
+e.g. '--with-gdal=/usr/local/bin/gdal-config')"
 ac_help="$ac_help
+  --with-python[=path/python-config] enable support for Python SWIG bindings \
+(python-config with path, e.g. '--with-python=/usr/bin/python2.5-config', \
+default: no)"
+ac_help="$ac_help
   --with-wxwidgets[=path/wx-config] enable wxWidgets support (wx-config with path, \
 e.g. '--with-wxwidgets=/usr/local/bin/wx-config', default: no)"
 ac_help="$ac_help
-  --with-gdal[=path/gdal-config] enable GDAL/OGR support (gdal-config with path, \
-e.g. '--with-gdal=/usr/local/bin/gdal-config')"
-ac_help="$ac_help
   --with-geos[=path/geos-config] enable GEOS support (geos-config with path, \
 e.g. '--with-geos=/usr/local/bin/geos-config', default: no)"
 ac_help="$ac_help
@@ -734,7 +735,7 @@
 fi
 echo $ac_n "checking host system type""... $ac_c" 1>&6
-echo "configure:738: checking host system type" >&5
+echo "configure:739: checking host system type" >&5
 host_alias=$host
 case "$host_alias" in
@@ -757,7 +758,7 @@
 # Extract the first word of "gcc", so it can be a program name with args.
 set dummy gcc; ac_word=$2
 echo $ac_n "checking for $ac_word""... $ac_c" 1>&6
-echo "configure:761: checking for $ac_word" >&5
+echo "configure:762: checking for $ac_word" >&5
 if test -n "$CC"; then
   ac_cv_prog_CC="$CC" # Let the user override the test.
@@ -784,7 +785,7 @@
   # Extract the first word of "cc", so it can be a program name with args.
 set dummy cc; ac_word=$2
-echo "configure:788: checking for $ac_word" >&5
+echo "configure:789: checking for $ac_word" >&5
@@ -832,7 +833,7 @@
       # Extract the first word of "cl", so it can be a program name with args.
 set dummy cl; ac_word=$2
-echo "configure:836: checking for $ac_word" >&5
+echo "configure:837: checking for $ac_word" >&5
@@ -861,7 +862,7 @@
 fi
 echo $ac_n "checking whether the C compiler ($CC $CFLAGS $LDFLAGS) works""... $ac_c" 1>&6
-echo "configure:865: checking whether the C compiler ($CC $CFLAGS $LDFLAGS) works" >&5
+echo "configure:866: checking whether the C compiler ($CC $CFLAGS $LDFLAGS) works" >&5
 ac_ext=c
 # CFLAGS is not in ac_cpp because -g, -O, etc. are not valid cpp options.
@@ -872,12 +873,12 @@
 cat > conftest.$ac_ext << EOF
-#line 876 "configure"
+#line 877 "configure"
 #include "confdefs.h"
 main(){return(0);}
 EOF
-if { (eval echo configure:881: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:882: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   ac_cv_prog_cc_works=yes
   # If we can't run a trivial program, we are probably using a cross compiler.
   if (./conftest; exit) 2>/dev/null; then
@@ -903,19 +904,19 @@
   { echo "configure: error: installation or configuration problem: C compiler cannot create executables." 1>&2; exit 1; }
 fi
 echo $ac_n "checking whether the C compiler ($CC $CFLAGS $LDFLAGS) is a cross-compiler""... $ac_c" 1>&6
-echo "configure:907: checking whether the C compiler ($CC $CFLAGS $LDFLAGS) is a cross-compiler" >&5
+echo "configure:908: checking whether the C compiler ($CC $CFLAGS $LDFLAGS) is a cross-compiler" >&5
 echo "$ac_t""$ac_cv_prog_cc_cross" 1>&6
 cross_compiling=$ac_cv_prog_cc_cross
 echo $ac_n "checking whether we are using GNU C""... $ac_c" 1>&6
-echo "configure:912: checking whether we are using GNU C" >&5
+echo "configure:913: checking whether we are using GNU C" >&5
 cat > conftest.c <<EOF
 #ifdef __GNUC__
   yes;
 #endif
 EOF
-if { ac_try='${CC-cc} -E conftest.c'; { (eval echo configure:919: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }; } | egrep yes >/dev/null 2>&1; then
+if { ac_try='${CC-cc} -E conftest.c'; { (eval echo configure:920: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }; } | egrep yes >/dev/null 2>&1; then
   ac_cv_prog_gcc=yes
 else
   ac_cv_prog_gcc=no
@@ -933,7 +934,7 @@
 ac_save_CFLAGS="$CFLAGS"
 CFLAGS=
 echo $ac_n "checking whether ${CC-cc} accepts -g""... $ac_c" 1>&6
-echo "configure:937: checking whether ${CC-cc} accepts -g" >&5
+echo "configure:938: checking whether ${CC-cc} accepts -g" >&5
 echo 'void f(){}' > conftest.c
 if test -z "`${CC-cc} -g -c conftest.c 2>&1`"; then
@@ -962,10 +963,10 @@
 fi
 echo $ac_n "checking for Cygwin environment""... $ac_c" 1>&6
-echo "configure:966: checking for Cygwin environment" >&5
+echo "configure:967: checking for Cygwin environment" >&5
 cat > conftest.$ac_ext <<EOF
-#line 969 "configure"
+#line 970 "configure"
 int main() {
@@ -976,7 +977,7 @@
 return __CYGWIN__;
 ; return 0; }
 EOF
-if { (eval echo configure:980: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:981: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
   rm -rf conftest*
   ac_cv_cygwin=yes
 else
@@ -992,17 +993,17 @@
 CYGWIN=
 test "$ac_cv_cygwin" = yes && CYGWIN=yes
 echo $ac_n "checking for mingw32 environment""... $ac_c" 1>&6
-echo "configure:996: checking for mingw32 environment" >&5
+echo "configure:997: checking for mingw32 environment" >&5
-#line 999 "configure"
+#line 1000 "configure"
 int main() {
 return __MINGW32__;
 ; return 0; }
 EOF
-if { (eval echo configure:1006: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:1007: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
   rm -rf conftest*
   ac_cv_mingw32=yes
 else
@@ -1020,7 +1021,7 @@
 echo $ac_n "checking for executable suffix""... $ac_c" 1>&6
-echo "configure:1024: checking for executable suffix" >&5
+echo "configure:1025: checking for executable suffix" >&5
 if test "$CYGWIN" = yes || test "$MINGW32" = yes; then
   ac_cv_exeext=.exe
@@ -1039,23 +1040,23 @@
 IEEEFLAG=
 echo $ac_n "checking for full floating-point support""... $ac_c" 1>&6
-echo "configure:1043: checking for full floating-point support" >&5
+echo "configure:1044: checking for full floating-point support" >&5
 if test "$cross_compiling" = yes; then
      echo "$ac_t""unknown (cross-compiling)" 1>&6
 echo $ac_n "checking whether "cc -mieee" works""... $ac_c" 1>&6
-echo "configure:1048: checking whether "cc -mieee" works" >&5
+echo "configure:1049: checking whether "cc -mieee" works" >&5
 ac_save_cflags=${CFLAGS}
 CFLAGS="$CFLAGS -mieee"
-#line 1052 "configure"
+#line 1053 "configure"
 int main() {
 ; return 0; }
 EOF
-if { (eval echo configure:1059: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:1060: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
   rm -rf conftest*
      echo "$ac_t""yes" 1>&6
         IEEEFLAG="-mieee"
@@ -1071,7 +1072,7 @@
 else
-#line 1075 "configure"
+#line 1076 "configure"
 #include <float.h>
@@ -1085,7 +1086,7 @@
 EOF
-if { (eval echo configure:1089: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext} && (./conftest; exit) 2>/dev/null
+if { (eval echo configure:1090: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext} && (./conftest; exit) 2>/dev/null
 then
@@ -1098,14 +1099,14 @@
   CFLAGS=-mieee
 echo $ac_n "checking for full floating-point support with -mieee""... $ac_c" 1>&6
-echo "configure:1102: checking for full floating-point support with -mieee" >&5
+echo "configure:1103: checking for full floating-point support with -mieee" >&5
     { echo "configure: error: *** INTERNAL CONFIGURE ERROR" 1>&2; exit 1; }
 else
-#line 1109 "configure"
+#line 1110 "configure"
 #include <float.h>
@@ -1119,7 +1120,7 @@
 EOF
-if { (eval echo configure:1123: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext} && (./conftest; exit) 2>/dev/null
+if { (eval echo configure:1124: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext} && (./conftest; exit) 2>/dev/null
 then
     IEEEFLAG="-mieee"
@@ -1156,7 +1157,7 @@
 # Extract the first word of "pwd", so it can be a program name with args.
 set dummy pwd; ac_word=$2
-echo "configure:1160: checking for $ac_word" >&5
+echo "configure:1161: checking for $ac_word" >&5
 case "$pwd" in
@@ -1194,7 +1195,7 @@
 fi
 echo $ac_n "checking for source directory""... $ac_c" 1>&6
-echo "configure:1198: checking for source directory" >&5
+echo "configure:1199: checking for source directory" >&5
 if test -z "$srcdir" ; then
   SRCDIR=`$pwd`
@@ -1205,7 +1206,7 @@
 echo "$ac_t"""$SRCDIR"" 1>&6
 echo $ac_n "checking for build directory""... $ac_c" 1>&6
-echo "configure:1209: checking for build directory" >&5
+echo "configure:1210: checking for build directory" >&5
 DSTDIR=`$pwd`
 WINDSTDIR=`$winpwd`
@@ -1290,7 +1291,7 @@
 echo $ac_n "checking for MacOSX App""... $ac_c" 1>&6
-echo "configure:1294: checking for MacOSX App" >&5
+echo "configure:1295: checking for MacOSX App" >&5
 case "$enable_macosx_app" in
 	yes)	MACOSX_APP=1	;;
 	no)	MACOSX_APP=	;;
@@ -1313,7 +1314,7 @@
     echo $ac_n "checking how to build libraries""... $ac_c" 1>&6
-echo "configure:1317: checking how to build libraries" >&5
+echo "configure:1318: checking how to build libraries" >&5
     # Check whether --enable-shared or --disable-shared was given.
 if test "${enable_shared+set}" = set; then
   enableval="$enable_shared"
@@ -1356,7 +1357,7 @@
 # Extract the first word of "ranlib", so it can be a program name with args.
 set dummy ranlib; ac_word=$2
-echo "configure:1360: checking for $ac_word" >&5
+echo "configure:1361: checking for $ac_word" >&5
 if test -n "$RANLIB"; then
   ac_cv_prog_RANLIB="$RANLIB" # Let the user override the test.
@@ -1381,7 +1382,7 @@
 fi
 echo $ac_n "checking how to run the C preprocessor""... $ac_c" 1>&6
-echo "configure:1385: checking how to run the C preprocessor" >&5
+echo "configure:1386: checking how to run the C preprocessor" >&5
 # On Suns, sometimes $CPP names a directory.
 if test -n "$CPP" && test -d "$CPP"; then
   CPP=
@@ -1394,13 +1395,13 @@
   # On the NeXT, cc -E runs the code through the compiler's parser,
   # not just through cpp.
-#line 1398 "configure"
+#line 1399 "configure"
 #include <assert.h>
 Syntax Error
 EOF
 ac_try="$ac_cpp conftest.$ac_ext >/dev/null 2>conftest.out"
-{ (eval echo configure:1404: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:1405: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
 ac_err=`grep -v '^ *+' conftest.out | grep -v "^conftest.${ac_ext}\$"`
 if test -z "$ac_err"; then
@@ -1411,13 +1412,13 @@
   rm -rf conftest*
   CPP="${CC-cc} -E -traditional-cpp"
-#line 1415 "configure"
+#line 1416 "configure"
 #include <assert.h>
 Syntax Error
 EOF
-{ (eval echo configure:1421: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:1422: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
@@ -1428,13 +1429,13 @@
   rm -rf conftest*
   CPP="${CC-cc} -nologo -E"
-#line 1432 "configure"
+#line 1433 "configure"
 #include <assert.h>
 Syntax Error
 EOF
-{ (eval echo configure:1438: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:1439: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
@@ -1462,7 +1463,7 @@
     # Step 0.a: Enable 64 bit support?
     echo $ac_n "checking if 64bit support is requested""... $ac_c" 1>&6
-echo "configure:1466: checking if 64bit support is requested" >&5
+echo "configure:1467: checking if 64bit support is requested" >&5
     # Check whether --enable-64bit or --disable-64bit was given.
 if test "${enable_64bit+set}" = set; then
   enableval="$enable_64bit"
@@ -1482,7 +1483,7 @@
     # Step 0.b: Enable Solaris 64 bit VIS support?
     echo $ac_n "checking if 64bit Sparc VIS support is requested""... $ac_c" 1>&6
-echo "configure:1486: checking if 64bit Sparc VIS support is requested" >&5
+echo "configure:1487: checking if 64bit Sparc VIS support is requested" >&5
     # Check whether --enable-64bit-vis or --disable-64bit-vis was given.
 if test "${enable_64bit_vis+set}" = set; then
   enableval="$enable_64bit_vis"
@@ -1506,7 +1507,7 @@
     # there are a few systems, like Next, where this doesn't work.
     echo $ac_n "checking system version (for dynamic loading)""... $ac_c" 1>&6
-echo "configure:1510: checking system version (for dynamic loading)" >&5
+echo "configure:1511: checking system version (for dynamic loading)" >&5
     if test -f /usr/lib/NextStep/software_version; then
 	system=NEXTSTEP-`awk '/3/,/3/' /usr/lib/NextStep/software_version`
     else
@@ -1532,13 +1533,13 @@
     # Linux can use either -ldl or -ldld for dynamic loading.
     echo $ac_n "checking for dlopen in -ldl""... $ac_c" 1>&6
-echo "configure:1536: checking for dlopen in -ldl" >&5
+echo "configure:1537: checking for dlopen in -ldl" >&5
 ac_lib_var=`echo dl'_'dlopen | sed 'y%./+-%__p_%'`
 ac_save_LIBS="$LIBS"
 LIBS="-ldl  $LIBS"
-#line 1542 "configure"
+#line 1543 "configure"
 /* Override any gcc2 internal prototype to avoid an error.  */
 /* We use char because int might match the return type of a gcc2
@@ -1549,7 +1550,7 @@
 dlopen()
 ; return 0; }
 EOF
-if { (eval echo configure:1553: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:1554: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_lib_$ac_lib_var=yes"
 else
@@ -1596,7 +1597,7 @@
     # Extract the first word of "ar", so it can be a program name with args.
 set dummy ar; ac_word=$2
-echo "configure:1600: checking for $ac_word" >&5
+echo "configure:1601: checking for $ac_word" >&5
 if test -n "$AR"; then
   ac_cv_prog_AR="$AR" # Let the user override the test.
@@ -1725,13 +1726,13 @@
 	    # known GMT value.
 	    echo $ac_n "checking for gettimeofday in -lbsd""... $ac_c" 1>&6
-echo "configure:1729: checking for gettimeofday in -lbsd" >&5
+echo "configure:1730: checking for gettimeofday in -lbsd" >&5
 ac_lib_var=`echo bsd'_'gettimeofday | sed 'y%./+-%__p_%'`
 LIBS="-lbsd  $LIBS"
-#line 1735 "configure"
+#line 1736 "configure"
@@ -1742,7 +1743,7 @@
 gettimeofday()
 ; return 0; }
 EOF
-if { (eval echo configure:1746: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:1747: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -1783,13 +1784,13 @@
 	    # is always linked to, for compatibility.
 	    echo $ac_n "checking for inet_ntoa in -lbind""... $ac_c" 1>&6
-echo "configure:1787: checking for inet_ntoa in -lbind" >&5
+echo "configure:1788: checking for inet_ntoa in -lbind" >&5
 ac_lib_var=`echo bind'_'inet_ntoa | sed 'y%./+-%__p_%'`
 LIBS="-lbind  $LIBS"
-#line 1793 "configure"
+#line 1794 "configure"
@@ -1800,7 +1801,7 @@
 inet_ntoa()
 ; return 0; }
 EOF
-if { (eval echo configure:1804: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:1805: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -1861,13 +1862,13 @@
 	    SHLIB_SUFFIX=".sl"
 	    echo $ac_n "checking for shl_load in -ldld""... $ac_c" 1>&6
-echo "configure:1865: checking for shl_load in -ldld" >&5
+echo "configure:1866: checking for shl_load in -ldld" >&5
 ac_lib_var=`echo dld'_'shl_load | sed 'y%./+-%__p_%'`
 LIBS="-ldld  $LIBS"
-#line 1871 "configure"
+#line 1872 "configure"
@@ -1878,7 +1879,7 @@
 shl_load()
 ; return 0; }
 EOF
-if { (eval echo configure:1882: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:1883: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -1943,13 +1944,13 @@
 	HP-UX-*.08.*|HP-UX-*.09.*|HP-UX-*.10.*)
 	    SHLIB_SUFFIX=".sl"
-echo "configure:1947: checking for shl_load in -ldld" >&5
+echo "configure:1948: checking for shl_load in -ldld" >&5
 LIBS="-ldld  $LIBS"
-#line 1953 "configure"
+#line 1954 "configure"
@@ -1960,7 +1961,7 @@
 shl_load()
 ; return 0; }
 EOF
-if { (eval echo configure:1964: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:1965: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -2082,15 +2083,15 @@
 	    else
 		ac_safe=`echo "dld.h" | sed 'y%./+-%__p_%'`
 echo $ac_n "checking for dld.h""... $ac_c" 1>&6
-echo "configure:2086: checking for dld.h" >&5
+echo "configure:2087: checking for dld.h" >&5
-#line 2089 "configure"
+#line 2090 "configure"
 #include <dld.h>
 EOF
-{ (eval echo configure:2094: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:2095: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -2150,15 +2151,15 @@
 	    else
-echo "configure:2154: checking for dld.h" >&5
+echo "configure:2155: checking for dld.h" >&5
-#line 2157 "configure"
+#line 2158 "configure"
 #include <dld.h>
 EOF
-{ (eval echo configure:2162: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:2163: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -2255,9 +2256,9 @@
 	    CC_SEARCH_FLAGS=""
 	    LD_SEARCH_FLAGS=""
 	    echo $ac_n "checking for ELF""... $ac_c" 1>&6
-echo "configure:2259: checking for ELF" >&5
+echo "configure:2260: checking for ELF" >&5
-#line 2261 "configure"
+#line 2262 "configure"
 #ifdef __ELF__
@@ -2287,15 +2288,15 @@
 	    # Not available on all versions:  check for include file.
 	    ac_safe=`echo "dlfcn.h" | sed 'y%./+-%__p_%'`
 echo $ac_n "checking for dlfcn.h""... $ac_c" 1>&6
-echo "configure:2291: checking for dlfcn.h" >&5
+echo "configure:2292: checking for dlfcn.h" >&5
-#line 2294 "configure"
+#line 2295 "configure"
 #include <dlfcn.h>
 EOF
-{ (eval echo configure:2299: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:2300: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -2319,9 +2320,9 @@
 		CC_SEARCH_FLAGS='-Wl,-rpath,${LIB_RUNTIME_DIR}'
 		LD_SEARCH_FLAGS='-rpath ${LIB_RUNTIME_DIR}'
-echo "configure:2323: checking for ELF" >&5
+echo "configure:2324: checking for ELF" >&5
-#line 2325 "configure"
+#line 2326 "configure"
 #ifdef __ELF__
@@ -2645,17 +2646,17 @@
 	    # that don't grok the -Bexport option.  Test that it does.
 	    hold_ldflags=$LDFLAGS
 	    echo $ac_n "checking for ld accepts -Bexport flag""... $ac_c" 1>&6
-echo "configure:2649: checking for ld accepts -Bexport flag" >&5
+echo "configure:2650: checking for ld accepts -Bexport flag" >&5
 	    LDFLAGS="${LDFLAGS} -Wl,-Bexport"
-#line 2652 "configure"
+#line 2653 "configure"
 int main() {
 int i;
 ; return 0; }
 EOF
-if { (eval echo configure:2659: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:2660: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   found=yes
 else
@@ -2993,6 +2994,14 @@
 fi
+# Check whether --with-gdal or --without-gdal was given.
+if test "${with_gdal+set}" = set; then
+  withval="$with_gdal"
+fi
 # Check whether --with-python or --without-python was given.
 if test "${with_python+set}" = set; then
   withval="$with_python"
@@ -3001,6 +3010,7 @@
   with_python="no"
 fi
 # Check whether --with-wxwidgets or --without-wxwidgets was given.
 if test "${with_wxwidgets+set}" = set; then
   withval="$with_wxwidgets"
@@ -3012,13 +3022,6 @@
 # With includes and libs options
-# Check whether --with-gdal or --without-gdal was given.
-if test "${with_gdal+set}" = set; then
-  withval="$with_gdal"
-fi
 # Check whether --with-geos or --without-geos was given.
 if test "${with_geos+set}" = set; then
   withval="$with_geos"
@@ -3432,7 +3435,7 @@
 # Done checking fortran
 echo $ac_n "checking for additional include dirs""... $ac_c" 1>&6
-echo "configure:3436: checking for additional include dirs" >&5
+echo "configure:3439: checking for additional include dirs" >&5
 case "$with_includes" in
 y | ye | yes | n | no)
 	{ echo "configure: error: *** You must supply a directory to list --with-includes." 1>&2; exit 1; }
@@ -3455,7 +3458,7 @@
 # With libs option
 echo $ac_n "checking for additional library dirs""... $ac_c" 1>&6
-echo "configure:3459: checking for additional library dirs" >&5
+echo "configure:3462: checking for additional library dirs" >&5
 case "$with_libs" in
 	{ echo "configure: error: *** You must supply a directory list to --with-libs." 1>&2; exit 1; }
@@ -3489,7 +3492,7 @@
 # SVR4 /usr/ucb/install, which tries to use the nonexistent group "staff"
 # ./install, which can be erroneously created by make from ./install.sh.
 echo $ac_n "checking for a BSD compatible install""... $ac_c" 1>&6
-echo "configure:3493: checking for a BSD compatible install" >&5
+echo "configure:3496: checking for a BSD compatible install" >&5
 if test -z "$INSTALL"; then
   IFS="${IFS= 	}"; ac_save_IFS="$IFS"; IFS=":"
@@ -3542,7 +3545,7 @@
 # Extract the first word of "flex", so it can be a program name with args.
 set dummy flex; ac_word=$2
-echo "configure:3546: checking for $ac_word" >&5
+echo "configure:3549: checking for $ac_word" >&5
 if test -n "$LEX"; then
   ac_cv_prog_LEX="$LEX" # Let the user override the test.
@@ -3573,13 +3576,13 @@
   *) ac_lib=l ;;
   esac
   echo $ac_n "checking for yywrap in -l$ac_lib""... $ac_c" 1>&6
-echo "configure:3577: checking for yywrap in -l$ac_lib" >&5
+echo "configure:3580: checking for yywrap in -l$ac_lib" >&5
 ac_lib_var=`echo $ac_lib'_'yywrap | sed 'y%./+-%__p_%'`
 LIBS="-l$ac_lib  $LIBS"
-#line 3583 "configure"
+#line 3586 "configure"
@@ -3590,7 +3593,7 @@
 yywrap()
 ; return 0; }
 EOF
-if { (eval echo configure:3594: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:3597: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -3615,7 +3618,7 @@
     # Extract the first word of "lex", so it can be a program name with args.
 set dummy lex; ac_word=$2
-echo "configure:3619: checking for $ac_word" >&5
+echo "configure:3622: checking for $ac_word" >&5
 case "$LEXPATH" in
@@ -3655,7 +3658,7 @@
 # Extract the first word of "$ac_prog", so it can be a program name with args.
 set dummy $ac_prog; ac_word=$2
-echo "configure:3659: checking for $ac_word" >&5
+echo "configure:3662: checking for $ac_word" >&5
 if test -n "$YACC"; then
   ac_cv_prog_YACC="$YACC" # Let the user override the test.
@@ -3686,7 +3689,7 @@
     # Extract the first word of "yacc", so it can be a program name with args.
 set dummy yacc; ac_word=$2
-echo "configure:3690: checking for $ac_word" >&5
+echo "configure:3693: checking for $ac_word" >&5
 case "$YACCPATH" in
@@ -3724,7 +3727,7 @@
-echo "configure:3728: checking for $ac_word" >&5
+echo "configure:3731: checking for $ac_word" >&5
@@ -3753,7 +3756,7 @@
-echo "configure:3757: checking for $ac_word" >&5
+echo "configure:3760: checking for $ac_word" >&5
@@ -3784,7 +3787,7 @@
-echo "configure:3788: checking for $ac_word" >&5
+echo "configure:3791: checking for $ac_word" >&5
 if test -n "$ENV"; then
   ac_cv_prog_ENV="$ENV" # Let the user override the test.
@@ -3813,7 +3816,7 @@
 # Extract the first word of "perl", so it can be a program name with args.
 set dummy perl; ac_word=$2
-echo "configure:3817: checking for $ac_word" >&5
+echo "configure:3820: checking for $ac_word" >&5
 case "$PERL" in
@@ -3844,10 +3847,10 @@
 fi
 echo $ac_n "checking for ANSI C header files""... $ac_c" 1>&6
-echo "configure:3848: checking for ANSI C header files" >&5
+echo "configure:3851: checking for ANSI C header files" >&5
-#line 3851 "configure"
+#line 3854 "configure"
 #include <stdlib.h>
 #include <stdarg.h>
@@ -3855,7 +3858,7 @@
 #include <float.h>
 EOF
-{ (eval echo configure:3859: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:3862: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -3872,7 +3875,7 @@
 if test $ac_cv_header_stdc = yes; then
   # SunOS 4.x string.h does not declare mem*, contrary to ANSI.
-#line 3876 "configure"
+#line 3879 "configure"
 #include <string.h>
 EOF
@@ -3890,7 +3893,7 @@
   # ISC 2.0.2 stdlib.h does not declare free, contrary to ANSI.
-#line 3894 "configure"
+#line 3897 "configure"
 #include <stdlib.h>
 EOF
@@ -3911,7 +3914,7 @@
 else
-#line 3915 "configure"
+#line 3918 "configure"
 #include <ctype.h>
 #define ISLOWER(c) ('a' <= (c) && (c) <= 'z')
@@ -3922,7 +3925,7 @@
 exit (0); }
 EOF
-if { (eval echo configure:3926: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext} && (./conftest; exit) 2>/dev/null
+if { (eval echo configure:3929: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext} && (./conftest; exit) 2>/dev/null
 then
 else
@@ -3949,15 +3952,15 @@
 do
 ac_safe=`echo "$ac_hdr" | sed 'y%./+-%__p_%'`
 echo $ac_n "checking for $ac_hdr""... $ac_c" 1>&6
-echo "configure:3953: checking for $ac_hdr" >&5
+echo "configure:3956: checking for $ac_hdr" >&5
-#line 3956 "configure"
+#line 3959 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:3961: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:3964: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -3986,15 +3989,15 @@
 do
-echo "configure:3990: checking for $ac_hdr" >&5
+echo "configure:3993: checking for $ac_hdr" >&5
-#line 3993 "configure"
+#line 3996 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:3998: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:4001: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -4023,15 +4026,15 @@
 do
-echo "configure:4027: checking for $ac_hdr" >&5
+echo "configure:4030: checking for $ac_hdr" >&5
-#line 4030 "configure"
+#line 4033 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:4035: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:4038: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -4060,15 +4063,15 @@
 do
-echo "configure:4064: checking for $ac_hdr" >&5
+echo "configure:4067: checking for $ac_hdr" >&5
-#line 4067 "configure"
+#line 4070 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:4072: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:4075: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -4097,15 +4100,15 @@
 do
-echo "configure:4101: checking for $ac_hdr" >&5
+echo "configure:4104: checking for $ac_hdr" >&5
-#line 4104 "configure"
+#line 4107 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:4109: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:4112: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -4131,10 +4134,10 @@
 done
 echo $ac_n "checking whether time.h and sys/time.h may both be included""... $ac_c" 1>&6
-echo "configure:4135: checking whether time.h and sys/time.h may both be included" >&5
+echo "configure:4138: checking whether time.h and sys/time.h may both be included" >&5
-#line 4138 "configure"
+#line 4141 "configure"
 #include <sys/types.h>
 #include <sys/time.h>
@@ -4143,7 +4146,7 @@
 struct tm *tp;
 ; return 0; }
 EOF
-if { (eval echo configure:4147: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:4150: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
   rm -rf conftest*
   ac_cv_header_time=yes
 else
@@ -4163,10 +4166,10 @@
 fi
 echo $ac_n "checking for off_t""... $ac_c" 1>&6
-echo "configure:4167: checking for off_t" >&5
+echo "configure:4170: checking for off_t" >&5
-#line 4170 "configure"
+#line 4173 "configure"
 #if STDC_HEADERS
@@ -4193,10 +4196,10 @@
 fi
 echo $ac_n "checking for uid_t in sys/types.h""... $ac_c" 1>&6
-echo "configure:4197: checking for uid_t in sys/types.h" >&5
+echo "configure:4200: checking for uid_t in sys/types.h" >&5
-#line 4200 "configure"
+#line 4203 "configure"
 EOF
@@ -4224,10 +4227,10 @@
 fi
 echo $ac_n "checking return type of signal handlers""... $ac_c" 1>&6
-echo "configure:4228: checking return type of signal handlers" >&5
+echo "configure:4231: checking return type of signal handlers" >&5
-#line 4231 "configure"
+#line 4234 "configure"
 #include <signal.h>
@@ -4244,7 +4247,7 @@
 int i;
 ; return 0; }
 EOF
-if { (eval echo configure:4248: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:4251: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
   rm -rf conftest*
   ac_cv_type_signal=void
 else
@@ -4262,10 +4265,10 @@
-echo "configure:4266: checking for Cygwin environment" >&5
+echo "configure:4269: checking for Cygwin environment" >&5
-#line 4269 "configure"
+#line 4272 "configure"
 int main() {
@@ -4276,7 +4279,7 @@
 return __CYGWIN__;
 ; return 0; }
 EOF
-if { (eval echo configure:4280: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:4283: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
   rm -rf conftest*
   ac_cv_cygwin=yes
 else
@@ -4294,10 +4297,10 @@
 for ac_func in ftime gethostname gettimeofday lseek nice time uname
 do
 echo $ac_n "checking for $ac_func""... $ac_c" 1>&6
-echo "configure:4298: checking for $ac_func" >&5
+echo "configure:4301: checking for $ac_func" >&5
-#line 4301 "configure"
+#line 4304 "configure"
 /* System header to define __stub macros and hopefully few prototypes,
     which can conflict with char $ac_func(); below.  */
@@ -4320,7 +4323,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:4324: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4327: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_$ac_func=yes"
 else
@@ -4346,10 +4349,10 @@
 for ac_func in seteuid setpriority setreuid setruid
 do
-echo "configure:4350: checking for $ac_func" >&5
+echo "configure:4353: checking for $ac_func" >&5
-#line 4353 "configure"
+#line 4356 "configure"
@@ -4372,7 +4375,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:4376: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4379: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -4398,10 +4401,10 @@
 for ac_func in drand48
 do
-echo "configure:4402: checking for $ac_func" >&5
+echo "configure:4405: checking for $ac_func" >&5
-#line 4405 "configure"
+#line 4408 "configure"
@@ -4424,7 +4427,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:4428: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4431: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -4450,10 +4453,10 @@
 for ac_func in putenv setenv
 do
-echo "configure:4454: checking for $ac_func" >&5
+echo "configure:4457: checking for $ac_func" >&5
-#line 4457 "configure"
+#line 4460 "configure"
@@ -4476,7 +4479,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:4480: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4483: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -4502,10 +4505,10 @@
 for ac_func in nanosleep
 do
-echo "configure:4506: checking for $ac_func" >&5
+echo "configure:4509: checking for $ac_func" >&5
-#line 4509 "configure"
+#line 4512 "configure"
@@ -4528,7 +4531,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:4532: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4535: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -4553,13 +4556,13 @@
 if test "$cross_compiling" != "yes" ; then
 echo $ac_n "checking whether setpgrp takes no argument""... $ac_c" 1>&6
-echo "configure:4557: checking whether setpgrp takes no argument" >&5
+echo "configure:4560: checking whether setpgrp takes no argument" >&5
   { echo "configure: error: cannot check setpgrp if cross compiling" 1>&2; exit 1; }
 else
-#line 4563 "configure"
+#line 4566 "configure"
 #ifdef HAVE_UNISTD_H
@@ -4579,7 +4582,7 @@
 EOF
-if { (eval echo configure:4583: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext} && (./conftest; exit) 2>/dev/null
+if { (eval echo configure:4586: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext} && (./conftest; exit) 2>/dev/null
 then
   ac_cv_func_setpgrp_void=no
 else
@@ -4607,16 +4610,16 @@
 fi
 echo $ac_n "checking for long long int""... $ac_c" 1>&6
-echo "configure:4611: checking for long long int" >&5
+echo "configure:4614: checking for long long int" >&5
-#line 4613 "configure"
+#line 4616 "configure"
 int main() {
 long long int x;
 ; return 0; }
 EOF
-if { (eval echo configure:4620: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:4623: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
   rm -rf conftest*
@@ -4636,7 +4639,7 @@
 rm -f conftest*
 echo $ac_n "checking for W11""... $ac_c" 1>&6
-echo "configure:4640: checking for W11" >&5
+echo "configure:4643: checking for W11" >&5
 case "$enable_w11" in
 	yes|no)	echo "$ac_t"""$enable_w11"" 1>&6	;;
 	*)	{ echo "configure: error: *** You must answer yes or no." 1>&2; exit 1; }	;;
@@ -4664,7 +4667,7 @@
 # Uses ac_ vars as temps to allow command line to override cache and checks.
 # --without-x overrides everything else, but does not touch the cache.
 echo $ac_n "checking for X""... $ac_c" 1>&6
-echo "configure:4668: checking for X" >&5
+echo "configure:4671: checking for X" >&5
 # Check whether --with-x or --without-x was given.
 if test "${with_x+set}" = set; then
@@ -4724,12 +4727,12 @@
   # First, try using that file with no special directory specified.
-#line 4728 "configure"
+#line 4731 "configure"
 #include <$x_direct_test_include>
 EOF
-{ (eval echo configure:4733: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:4736: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -4798,14 +4801,14 @@
   LIBS="-l$x_direct_test_library $LIBS"
-#line 4802 "configure"
+#line 4805 "configure"
 int main() {
 ${x_direct_test_function}()
 ; return 0; }
 EOF
-if { (eval echo configure:4809: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4812: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   LIBS="$ac_save_LIBS"
 # We can link X programs with no special library path.
@@ -4910,17 +4913,17 @@
     case "`(uname -sr) 2>/dev/null`" in
     "SunOS 5"*)
       echo $ac_n "checking whether -R must be followed by a space""... $ac_c" 1>&6
-echo "configure:4914: checking whether -R must be followed by a space" >&5
+echo "configure:4917: checking whether -R must be followed by a space" >&5
       ac_xsave_LIBS="$LIBS"; LIBS="$LIBS -R$x_libraries"
-#line 4917 "configure"
+#line 4920 "configure"
 int main() {
 ; return 0; }
 EOF
-if { (eval echo configure:4924: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4927: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   ac_R_nospace=yes
 else
@@ -4936,14 +4939,14 @@
       else
 	LIBS="$ac_xsave_LIBS -R $x_libraries"
-#line 4940 "configure"
+#line 4943 "configure"
 int main() {
 ; return 0; }
 EOF
-if { (eval echo configure:4947: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4950: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   ac_R_space=yes
 else
@@ -4975,13 +4978,13 @@
     # libraries were built with DECnet support.  And karl at cs.umb.edu says
     # the Alpha needs dnet_stub (dnet does not exist).
     echo $ac_n "checking for dnet_ntoa in -ldnet""... $ac_c" 1>&6
-echo "configure:4979: checking for dnet_ntoa in -ldnet" >&5
+echo "configure:4982: checking for dnet_ntoa in -ldnet" >&5
 ac_lib_var=`echo dnet'_'dnet_ntoa | sed 'y%./+-%__p_%'`
 LIBS="-ldnet  $LIBS"
-#line 4985 "configure"
+#line 4988 "configure"
@@ -4992,7 +4995,7 @@
 dnet_ntoa()
 ; return 0; }
 EOF
-if { (eval echo configure:4996: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4999: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -5013,13 +5016,13 @@
     if test $ac_cv_lib_dnet_dnet_ntoa = no; then
       echo $ac_n "checking for dnet_ntoa in -ldnet_stub""... $ac_c" 1>&6
-echo "configure:5017: checking for dnet_ntoa in -ldnet_stub" >&5
+echo "configure:5020: checking for dnet_ntoa in -ldnet_stub" >&5
 ac_lib_var=`echo dnet_stub'_'dnet_ntoa | sed 'y%./+-%__p_%'`
 LIBS="-ldnet_stub  $LIBS"
-#line 5023 "configure"
+#line 5026 "configure"
@@ -5030,7 +5033,7 @@
 dnet_ntoa()
 ; return 0; }
 EOF
-if { (eval echo configure:5034: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5037: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -5058,10 +5061,10 @@
     # The nsl library prevents programs from opening the X display
     # on Irix 5.2, according to dickey at clark.net.
     echo $ac_n "checking for gethostbyname""... $ac_c" 1>&6
-echo "configure:5062: checking for gethostbyname" >&5
+echo "configure:5065: checking for gethostbyname" >&5
-#line 5065 "configure"
+#line 5068 "configure"
     which can conflict with char gethostbyname(); below.  */
@@ -5084,7 +5087,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:5088: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5091: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_gethostbyname=yes"
 else
@@ -5104,13 +5107,13 @@
     if test $ac_cv_func_gethostbyname = no; then
       echo $ac_n "checking for gethostbyname in -lnsl""... $ac_c" 1>&6
-echo "configure:5108: checking for gethostbyname in -lnsl" >&5
+echo "configure:5111: checking for gethostbyname in -lnsl" >&5
 ac_lib_var=`echo nsl'_'gethostbyname | sed 'y%./+-%__p_%'`
 LIBS="-lnsl  $LIBS"
-#line 5114 "configure"
+#line 5117 "configure"
@@ -5121,7 +5124,7 @@
 gethostbyname()
 ; return 0; }
 EOF
-if { (eval echo configure:5125: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5128: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -5150,10 +5153,10 @@
     # -lsocket must be given before -lnsl if both are needed.
     # We assume that if connect needs -lnsl, so does gethostbyname.
     echo $ac_n "checking for connect""... $ac_c" 1>&6
-echo "configure:5154: checking for connect" >&5
+echo "configure:5157: checking for connect" >&5
-#line 5157 "configure"
+#line 5160 "configure"
     which can conflict with char connect(); below.  */
@@ -5176,7 +5179,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:5180: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5183: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_connect=yes"
 else
@@ -5196,13 +5199,13 @@
     if test $ac_cv_func_connect = no; then
       echo $ac_n "checking for connect in -lsocket""... $ac_c" 1>&6
-echo "configure:5200: checking for connect in -lsocket" >&5
+echo "configure:5203: checking for connect in -lsocket" >&5
 ac_lib_var=`echo socket'_'connect | sed 'y%./+-%__p_%'`
 LIBS="-lsocket $X_EXTRA_LIBS $LIBS"
-#line 5206 "configure"
+#line 5209 "configure"
@@ -5213,7 +5216,7 @@
 connect()
 ; return 0; }
 EOF
-if { (eval echo configure:5217: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5220: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -5236,10 +5239,10 @@
     # gomez at mi.uni-erlangen.de says -lposix is necessary on A/UX.
     echo $ac_n "checking for remove""... $ac_c" 1>&6
-echo "configure:5240: checking for remove" >&5
+echo "configure:5243: checking for remove" >&5
-#line 5243 "configure"
+#line 5246 "configure"
     which can conflict with char remove(); below.  */
@@ -5262,7 +5265,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:5266: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5269: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_remove=yes"
 else
@@ -5282,13 +5285,13 @@
     if test $ac_cv_func_remove = no; then
       echo $ac_n "checking for remove in -lposix""... $ac_c" 1>&6
-echo "configure:5286: checking for remove in -lposix" >&5
+echo "configure:5289: checking for remove in -lposix" >&5
 ac_lib_var=`echo posix'_'remove | sed 'y%./+-%__p_%'`
 LIBS="-lposix  $LIBS"
-#line 5292 "configure"
+#line 5295 "configure"
@@ -5299,7 +5302,7 @@
 remove()
 ; return 0; }
 EOF
-if { (eval echo configure:5303: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5306: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -5322,10 +5325,10 @@
     # BSDI BSD/OS 2.1 needs -lipc for XOpenDisplay.
     echo $ac_n "checking for shmat""... $ac_c" 1>&6
-echo "configure:5326: checking for shmat" >&5
+echo "configure:5329: checking for shmat" >&5
-#line 5329 "configure"
+#line 5332 "configure"
     which can conflict with char shmat(); below.  */
@@ -5348,7 +5351,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:5352: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5355: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_shmat=yes"
 else
@@ -5368,13 +5371,13 @@
     if test $ac_cv_func_shmat = no; then
       echo $ac_n "checking for shmat in -lipc""... $ac_c" 1>&6
-echo "configure:5372: checking for shmat in -lipc" >&5
+echo "configure:5375: checking for shmat in -lipc" >&5
 ac_lib_var=`echo ipc'_'shmat | sed 'y%./+-%__p_%'`
 LIBS="-lipc  $LIBS"
-#line 5378 "configure"
+#line 5381 "configure"
@@ -5385,7 +5388,7 @@
 shmat()
 ; return 0; }
 EOF
-if { (eval echo configure:5389: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5392: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -5417,13 +5420,13 @@
   # libraries we check for below, so use a different variable.
   #  --interran at uluru.Stanford.EDU, kb at cs.umb.edu.
   echo $ac_n "checking for IceConnectionNumber in -lICE""... $ac_c" 1>&6
-echo "configure:5421: checking for IceConnectionNumber in -lICE" >&5
+echo "configure:5424: checking for IceConnectionNumber in -lICE" >&5
 ac_lib_var=`echo ICE'_'IceConnectionNumber | sed 'y%./+-%__p_%'`
 LIBS="-lICE $X_EXTRA_LIBS $LIBS"
-#line 5427 "configure"
+#line 5430 "configure"
@@ -5434,7 +5437,7 @@
 IceConnectionNumber()
 ; return 0; }
 EOF
-if { (eval echo configure:5438: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5441: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -5474,12 +5477,12 @@
 LIBS=""
 echo $ac_n "checking for library containing cuserid""... $ac_c" 1>&6
-echo "configure:5478: checking for library containing cuserid" >&5
+echo "configure:5481: checking for library containing cuserid" >&5
 ac_func_search_save_LIBS="$LIBS"
 ac_cv_search_cuserid="no"
-#line 5483 "configure"
+#line 5486 "configure"
@@ -5490,7 +5493,7 @@
 cuserid()
 ; return 0; }
 EOF
-if { (eval echo configure:5494: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5497: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   ac_cv_search_cuserid="none required"
 else
@@ -5501,7 +5504,7 @@
 test "$ac_cv_search_cuserid" = "no" && for i in compat; do
 LIBS="-l$i  $ac_func_search_save_LIBS"
-#line 5505 "configure"
+#line 5508 "configure"
@@ -5512,7 +5515,7 @@
 cuserid()
 ; return 0; }
 EOF
-if { (eval echo configure:5516: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5519: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   ac_cv_search_cuserid="-l$i"
 break
@@ -5538,10 +5541,10 @@
 # Note: -lxdr -liberty -lws2_32 is for MinGW
 echo $ac_n "checking for xdrmem_create""... $ac_c" 1>&6
-echo "configure:5542: checking for xdrmem_create" >&5
+echo "configure:5545: checking for xdrmem_create" >&5
-#line 5545 "configure"
+#line 5548 "configure"
     which can conflict with char xdrmem_create(); below.  */
@@ -5564,7 +5567,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:5568: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5571: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_xdrmem_create=yes"
 else
@@ -5582,13 +5585,13 @@
   echo "$ac_t""no" 1>&6
 echo $ac_n "checking for xdrmem_create in -lsun""... $ac_c" 1>&6
-echo "configure:5586: checking for xdrmem_create in -lsun" >&5
+echo "configure:5589: checking for xdrmem_create in -lsun" >&5
 ac_lib_var=`echo sun'_'xdrmem_create | sed 'y%./+-%__p_%'`
 LIBS="-lsun  $LIBS"
-#line 5592 "configure"
+#line 5595 "configure"
@@ -5599,7 +5602,7 @@
 xdrmem_create()
 ; return 0; }
 EOF
-if { (eval echo configure:5603: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5606: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -5618,13 +5621,13 @@
 echo $ac_n "checking for xdrmem_create in -lnsl""... $ac_c" 1>&6
-echo "configure:5622: checking for xdrmem_create in -lnsl" >&5
+echo "configure:5625: checking for xdrmem_create in -lnsl" >&5
 ac_lib_var=`echo nsl'_'xdrmem_create | sed 'y%./+-%__p_%'`
 LIBS="-lnsl  $LIBS"
-#line 5628 "configure"
+#line 5631 "configure"
@@ -5635,7 +5638,7 @@
 xdrmem_create()
 ; return 0; }
 EOF
-if { (eval echo configure:5639: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5642: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -5654,13 +5657,13 @@
 echo $ac_n "checking for xdrmem_create in -lrpclib""... $ac_c" 1>&6
-echo "configure:5658: checking for xdrmem_create in -lrpclib" >&5
+echo "configure:5661: checking for xdrmem_create in -lrpclib" >&5
 ac_lib_var=`echo rpclib'_'xdrmem_create | sed 'y%./+-%__p_%'`
 LIBS="-lrpclib  $LIBS"
-#line 5664 "configure"
+#line 5667 "configure"
@@ -5671,7 +5674,7 @@
 xdrmem_create()
 ; return 0; }
 EOF
-if { (eval echo configure:5675: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5678: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -5690,13 +5693,13 @@
 echo $ac_n "checking for xdrmem_create in -lxdr""... $ac_c" 1>&6
-echo "configure:5694: checking for xdrmem_create in -lxdr" >&5
+echo "configure:5697: checking for xdrmem_create in -lxdr" >&5
 ac_lib_var=`echo xdr'_'xdrmem_create | sed 'y%./+-%__p_%'`
 LIBS="-lxdr -liberty -lws2_32  $LIBS"
-#line 5700 "configure"
+#line 5703 "configure"
@@ -5707,7 +5710,7 @@
 xdrmem_create()
 ; return 0; }
 EOF
-if { (eval echo configure:5711: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5714: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -5741,10 +5744,10 @@
 for ac_func in asprintf
 do
-echo "configure:5745: checking for $ac_func" >&5
+echo "configure:5748: checking for $ac_func" >&5
-#line 5748 "configure"
+#line 5751 "configure"
@@ -5767,7 +5770,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:5771: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5774: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -5794,10 +5797,10 @@
 # Test if mathlib needs -lm flag or is included with libc
 echo $ac_n "checking for atan""... $ac_c" 1>&6
-echo "configure:5798: checking for atan" >&5
+echo "configure:5801: checking for atan" >&5
-#line 5801 "configure"
+#line 5804 "configure"
     which can conflict with char atan(); below.  */
@@ -5820,7 +5823,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:5824: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5827: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_atan=yes"
 else
@@ -5838,13 +5841,13 @@
 echo $ac_n "checking for atan in -lm""... $ac_c" 1>&6
-echo "configure:5842: checking for atan in -lm" >&5
+echo "configure:5845: checking for atan in -lm" >&5
 ac_lib_var=`echo m'_'atan | sed 'y%./+-%__p_%'`
 LIBS="-lm  $LIBS"
-#line 5848 "configure"
+#line 5851 "configure"
@@ -5855,7 +5858,7 @@
 atan()
 ; return 0; }
 EOF
-if { (eval echo configure:5859: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5862: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -5882,10 +5885,10 @@
 echo $ac_n "checking for dlsym""... $ac_c" 1>&6
-echo "configure:5886: checking for dlsym" >&5
+echo "configure:5889: checking for dlsym" >&5
-#line 5889 "configure"
+#line 5892 "configure"
     which can conflict with char dlsym(); below.  */
@@ -5908,7 +5911,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:5912: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5915: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_dlsym=yes"
 else
@@ -5926,13 +5929,13 @@
 echo $ac_n "checking for dlsym in -ldl""... $ac_c" 1>&6
-echo "configure:5930: checking for dlsym in -ldl" >&5
+echo "configure:5933: checking for dlsym in -ldl" >&5
 ac_lib_var=`echo dl'_'dlsym | sed 'y%./+-%__p_%'`
 LIBS="-ldl  $LIBS"
-#line 5936 "configure"
+#line 5939 "configure"
@@ -5943,7 +5946,7 @@
 dlsym()
 ; return 0; }
 EOF
-if { (eval echo configure:5947: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5950: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -5970,10 +5973,10 @@
 echo $ac_n "checking for iconv""... $ac_c" 1>&6
-echo "configure:5974: checking for iconv" >&5
+echo "configure:5977: checking for iconv" >&5
-#line 5977 "configure"
+#line 5980 "configure"
     which can conflict with char iconv(); below.  */
@@ -5996,7 +5999,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:6000: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6003: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_iconv=yes"
 else
@@ -6014,13 +6017,13 @@
 echo $ac_n "checking for iconv in -liconv""... $ac_c" 1>&6
-echo "configure:6018: checking for iconv in -liconv" >&5
+echo "configure:6021: checking for iconv in -liconv" >&5
 ac_lib_var=`echo iconv'_'iconv | sed 'y%./+-%__p_%'`
 LIBS="-liconv  $LIBS"
-#line 6024 "configure"
+#line 6027 "configure"
@@ -6031,7 +6034,7 @@
 iconv()
 ; return 0; }
 EOF
-if { (eval echo configure:6035: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6038: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -6050,13 +6053,13 @@
 echo $ac_n "checking for iconv in -lgiconv""... $ac_c" 1>&6
-echo "configure:6054: checking for iconv in -lgiconv" >&5
+echo "configure:6057: checking for iconv in -lgiconv" >&5
 ac_lib_var=`echo giconv'_'iconv | sed 'y%./+-%__p_%'`
 LIBS="-lgiconv  $LIBS"
-#line 6060 "configure"
+#line 6063 "configure"
@@ -6067,7 +6070,7 @@
 iconv()
 ; return 0; }
 EOF
-if { (eval echo configure:6071: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6074: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -6086,10 +6089,10 @@
 echo $ac_n "checking for libiconv""... $ac_c" 1>&6
-echo "configure:6090: checking for libiconv" >&5
+echo "configure:6093: checking for libiconv" >&5
-#line 6093 "configure"
+#line 6096 "configure"
     which can conflict with char libiconv(); below.  */
@@ -6112,7 +6115,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:6116: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6119: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_libiconv=yes"
 else
@@ -6130,13 +6133,13 @@
 echo $ac_n "checking for libiconv in -liconv""... $ac_c" 1>&6
-echo "configure:6134: checking for libiconv in -liconv" >&5
+echo "configure:6137: checking for libiconv in -liconv" >&5
 ac_lib_var=`echo iconv'_'libiconv | sed 'y%./+-%__p_%'`
-#line 6140 "configure"
+#line 6143 "configure"
@@ -6147,7 +6150,7 @@
 libiconv()
 ; return 0; }
 EOF
-if { (eval echo configure:6151: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6154: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -6166,13 +6169,13 @@
 echo $ac_n "checking for libiconv in -lgiconv""... $ac_c" 1>&6
-echo "configure:6170: checking for libiconv in -lgiconv" >&5
+echo "configure:6173: checking for libiconv in -lgiconv" >&5
 ac_lib_var=`echo giconv'_'libiconv | sed 'y%./+-%__p_%'`
-#line 6176 "configure"
+#line 6179 "configure"
@@ -6183,7 +6186,7 @@
 libiconv()
 ; return 0; }
 EOF
-if { (eval echo configure:6187: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6190: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -6220,10 +6223,10 @@
 have_socket=1
 echo $ac_n "checking for socket""... $ac_c" 1>&6
-echo "configure:6224: checking for socket" >&5
+echo "configure:6227: checking for socket" >&5
-#line 6227 "configure"
+#line 6230 "configure"
     which can conflict with char socket(); below.  */
@@ -6246,7 +6249,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:6250: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6253: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_socket=yes"
 else
@@ -6264,13 +6267,13 @@
 echo $ac_n "checking for socket in -lsocket""... $ac_c" 1>&6
-echo "configure:6268: checking for socket in -lsocket" >&5
+echo "configure:6271: checking for socket in -lsocket" >&5
 ac_lib_var=`echo socket'_'socket | sed 'y%./+-%__p_%'`
 LIBS="-lsocket  $LIBS"
-#line 6274 "configure"
+#line 6277 "configure"
@@ -6281,7 +6284,7 @@
 socket()
 ; return 0; }
 EOF
-if { (eval echo configure:6285: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6288: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -6329,7 +6332,7 @@
 echo $ac_n "checking for location of zlib includes""... $ac_c" 1>&6
-echo "configure:6333: checking for location of zlib includes" >&5
+echo "configure:6336: checking for location of zlib includes" >&5
 case "$with_zlib_includes" in
 	{ echo "configure: error: *** You must supply a directory to --with-zlib-includes." 1>&2; exit 1; }
@@ -6355,15 +6358,15 @@
 do
-echo "configure:6359: checking for $ac_hdr" >&5
+echo "configure:6362: checking for $ac_hdr" >&5
-#line 6362 "configure"
+#line 6365 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:6367: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:6370: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -6397,7 +6400,7 @@
 echo $ac_n "checking for location of zlib library""... $ac_c" 1>&6
-echo "configure:6401: checking for location of zlib library" >&5
+echo "configure:6404: checking for location of zlib library" >&5
 case "$with_zlib_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-zlib-libs." 1>&2; exit 1; }
@@ -6422,13 +6425,13 @@
 echo $ac_n "checking for deflate in -lz""... $ac_c" 1>&6
-echo "configure:6426: checking for deflate in -lz" >&5
+echo "configure:6429: checking for deflate in -lz" >&5
 ac_lib_var=`echo z'_'deflate | sed 'y%./+-%__p_%'`
 LIBS="-lz  $LIBS"
-#line 6432 "configure"
+#line 6435 "configure"
@@ -6439,7 +6442,7 @@
 deflate()
 ; return 0; }
 EOF
-if { (eval echo configure:6443: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6446: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -6487,7 +6490,7 @@
 echo $ac_n "checking for location of External PROJ.4 includes""... $ac_c" 1>&6
-echo "configure:6491: checking for location of External PROJ.4 includes" >&5
+echo "configure:6494: checking for location of External PROJ.4 includes" >&5
 case "$with_proj_includes" in
 	{ echo "configure: error: *** You must supply a directory to --with-proj-includes." 1>&2; exit 1; }
@@ -6513,15 +6516,15 @@
 do
-echo "configure:6517: checking for $ac_hdr" >&5
+echo "configure:6520: checking for $ac_hdr" >&5
-#line 6520 "configure"
+#line 6523 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:6525: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:6528: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -6558,7 +6561,7 @@
 else
 echo $ac_n "checking External PROJ.4 version""... $ac_c" 1>&6
-echo "configure:6562: checking External PROJ.4 version" >&5
+echo "configure:6565: checking External PROJ.4 version" >&5
 ac_save_cppflags="$CPPFLAGS"
 CPPFLAGS="$PROJINC $CPPFLAGS"
@@ -6566,7 +6569,7 @@
 else
-#line 6570 "configure"
+#line 6573 "configure"
 #include <stdio.h>
@@ -6578,7 +6581,7 @@
 EOF
-if { (eval echo configure:6582: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext} && (./conftest; exit) 2>/dev/null
+if { (eval echo configure:6585: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext} && (./conftest; exit) 2>/dev/null
 then
      proj_ver=`cat conftestdata`
         echo "$ac_t""$proj_ver" 1>&6
@@ -6603,7 +6606,7 @@
 echo $ac_n "checking for location of External PROJ.4 library""... $ac_c" 1>&6
-echo "configure:6607: checking for location of External PROJ.4 library" >&5
+echo "configure:6610: checking for location of External PROJ.4 library" >&5
 case "$with_proj_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-proj-libs." 1>&2; exit 1; }
@@ -6628,13 +6631,13 @@
 echo $ac_n "checking for pj_get_def in -lproj""... $ac_c" 1>&6
-echo "configure:6632: checking for pj_get_def in -lproj" >&5
+echo "configure:6635: checking for pj_get_def in -lproj" >&5
 ac_lib_var=`echo proj'_'pj_get_def | sed 'y%./+-%__p_%'`
 LIBS="-lproj  $LIBS"
-#line 6638 "configure"
+#line 6641 "configure"
@@ -6645,7 +6648,7 @@
 pj_get_def()
 ; return 0; }
 EOF
-if { (eval echo configure:6649: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6652: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -6679,7 +6682,7 @@
 echo $ac_n "checking for location of External PROJ.4 data files""... $ac_c" 1>&6
-echo "configure:6683: checking for location of External PROJ.4 data files" >&5
+echo "configure:6686: checking for location of External PROJ.4 data files" >&5
 case "$with_proj_share" in
         { echo "configure: error: *** You must supply a directory to --with-proj-share." 1>&2; exit 1; }
@@ -6703,14 +6706,14 @@
 # LOC_CHECK_SHARE does not work when cross compiling
 if test "$cross_compiling" = "yes" ; then
     echo $ac_n "checking for epsg""... $ac_c" 1>&6
-echo "configure:6707: checking for epsg" >&5
+echo "configure:6710: checking for epsg" >&5
 else
 ac_safe=`echo "$PROJSHARE/epsg" | sed 'y%./+-%__p_%'`
 echo $ac_n "checking for $PROJSHARE/epsg""... $ac_c" 1>&6
-echo "configure:6714: checking for $PROJSHARE/epsg" >&5
+echo "configure:6717: checking for $PROJSHARE/epsg" >&5
     { echo "configure: error: Cannot check for file existence when cross compiling" 1>&2; exit 1; }
@@ -6742,7 +6745,7 @@
 # Extract the first word of "nad2bin", so it can be a program name with args.
 set dummy nad2bin; ac_word=$2
-echo "configure:6746: checking for $ac_word" >&5
+echo "configure:6749: checking for $ac_word" >&5
 case "$NAD2BIN" in
@@ -6782,7 +6785,7 @@
 echo $ac_n "checking whether to use regex""... $ac_c" 1>&6
-echo "configure:6786: checking whether to use regex" >&5
+echo "configure:6789: checking whether to use regex" >&5
 echo "$ac_t"""$with_regex"" 1>&6
 case "$with_regex" in
 	"no")	USE_REGEX=	;;
@@ -6802,7 +6805,7 @@
 echo $ac_n "checking for location of regex includes""... $ac_c" 1>&6
-echo "configure:6806: checking for location of regex includes" >&5
+echo "configure:6809: checking for location of regex includes" >&5
 case "$with_regex_includes" in
 	{ echo "configure: error: *** You must supply a directory to --with-regex-includes." 1>&2; exit 1; }
@@ -6828,15 +6831,15 @@
 do
-echo "configure:6832: checking for $ac_hdr" >&5
+echo "configure:6835: checking for $ac_hdr" >&5
-#line 6835 "configure"
+#line 6838 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:6840: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:6843: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -6870,7 +6873,7 @@
 echo $ac_n "checking for location of regex library""... $ac_c" 1>&6
-echo "configure:6874: checking for location of regex library" >&5
+echo "configure:6877: checking for location of regex library" >&5
 case "$with_regex_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-regex-libs." 1>&2; exit 1; }
@@ -6895,10 +6898,10 @@
 LIBS="  $LIBS"
 LDFLAGS=" $LDFLAGS"
 echo $ac_n "checking for regcomp""... $ac_c" 1>&6
-echo "configure:6899: checking for regcomp" >&5
+echo "configure:6902: checking for regcomp" >&5
-#line 6902 "configure"
+#line 6905 "configure"
     which can conflict with char regcomp(); below.  */
@@ -6921,7 +6924,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:6925: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6928: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_regcomp=yes"
 else
@@ -6948,13 +6951,13 @@
 echo $ac_n "checking for regcomp in -lregex""... $ac_c" 1>&6
-echo "configure:6952: checking for regcomp in -lregex" >&5
+echo "configure:6955: checking for regcomp in -lregex" >&5
 ac_lib_var=`echo regex'_'regcomp | sed 'y%./+-%__p_%'`
 LIBS="-lregex  $LIBS"
-#line 6958 "configure"
+#line 6961 "configure"
 #include "confdefs.h"
@@ -6965,7 +6968,7 @@
 regcomp()
 ; return 0; }
 EOF
-if { (eval echo configure:6969: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6972: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -7015,7 +7018,7 @@
 echo $ac_n "checking whether to use Readline""... $ac_c" 1>&6
-echo "configure:7019: checking whether to use Readline" >&5
+echo "configure:7022: checking whether to use Readline" >&5
 echo "$ac_t"""$with_readline"" 1>&6
 case "$with_readline" in
 	"no")	USE_READLINE=	;;
@@ -7036,7 +7039,7 @@
 echo $ac_n "checking for location of Readline includes""... $ac_c" 1>&6
-echo "configure:7040: checking for location of Readline includes" >&5
+echo "configure:7043: checking for location of Readline includes" >&5
 case "$with_readline_includes" in
 	{ echo "configure: error: *** You must supply a directory to --with-readline-includes." 1>&2; exit 1; }
@@ -7062,15 +7065,15 @@
 do
-echo "configure:7066: checking for $ac_hdr" >&5
+echo "configure:7069: checking for $ac_hdr" >&5
-#line 7069 "configure"
+#line 7072 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:7074: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:7077: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -7106,15 +7109,15 @@
 do
-echo "configure:7110: checking for $ac_hdr" >&5
+echo "configure:7113: checking for $ac_hdr" >&5
-#line 7113 "configure"
+#line 7116 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:7118: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:7121: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -7148,7 +7151,7 @@
 echo $ac_n "checking for location of Readline library""... $ac_c" 1>&6
-echo "configure:7152: checking for location of Readline library" >&5
+echo "configure:7155: checking for location of Readline library" >&5
 case "$with_readline_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-readline-libs." 1>&2; exit 1; }
@@ -7173,13 +7176,13 @@
 echo $ac_n "checking for readline in -lreadline""... $ac_c" 1>&6
-echo "configure:7177: checking for readline in -lreadline" >&5
+echo "configure:7180: checking for readline in -lreadline" >&5
 ac_lib_var=`echo readline'_'readline | sed 'y%./+-%__p_%'`
 LIBS="-lreadline  $LIBS"
 cat > conftest.$ac_ext <<EOF
-#line 7183 "configure"
+#line 7186 "configure"
@@ -7190,7 +7193,7 @@
 readline()
 ; return 0; }
 EOF
-if { (eval echo configure:7194: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:7197: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -7225,13 +7228,13 @@
 echo $ac_n "checking for add_history in -lhistory""... $ac_c" 1>&6
-echo "configure:7229: checking for add_history in -lhistory" >&5
+echo "configure:7232: checking for add_history in -lhistory" >&5
 ac_lib_var=`echo history'_'add_history | sed 'y%./+-%__p_%'`
 LIBS="-lhistory  $LIBS"
-#line 7235 "configure"
+#line 7238 "configure"
@@ -7242,7 +7245,7 @@
 add_history()
 ; return 0; }
 EOF
-if { (eval echo configure:7246: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:7249: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -7285,7 +7288,7 @@
 echo $ac_n "checking whether to use JPEG""... $ac_c" 1>&6
-echo "configure:7289: checking whether to use JPEG" >&5
+echo "configure:7292: checking whether to use JPEG" >&5
 echo "$ac_t"""$with_jpeg"" 1>&6
 case "$with_jpeg" in
 	"no")	USE_JPEG=	;;
@@ -7305,7 +7308,7 @@
 echo $ac_n "checking for location of JPEG includes""... $ac_c" 1>&6
-echo "configure:7309: checking for location of JPEG includes" >&5
+echo "configure:7312: checking for location of JPEG includes" >&5
 case "$with_jpeg_includes" in
 	{ echo "configure: error: *** You must supply a directory to --with-jpeg-includes." 1>&2; exit 1; }
@@ -7331,15 +7334,15 @@
 do
-echo "configure:7335: checking for $ac_hdr" >&5
+echo "configure:7338: checking for $ac_hdr" >&5
-#line 7338 "configure"
+#line 7341 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:7343: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:7346: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -7373,7 +7376,7 @@
 echo $ac_n "checking for location of JPEG library""... $ac_c" 1>&6
-echo "configure:7377: checking for location of JPEG library" >&5
+echo "configure:7380: checking for location of JPEG library" >&5
 case "$with_jpeg_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-jpeg-libs." 1>&2; exit 1; }
@@ -7400,13 +7403,13 @@
 echo $ac_n "checking for jpeg_start_compress in -ljpeg""... $ac_c" 1>&6
-echo "configure:7404: checking for jpeg_start_compress in -ljpeg" >&5
+echo "configure:7407: checking for jpeg_start_compress in -ljpeg" >&5
 ac_lib_var=`echo jpeg'_'jpeg_start_compress | sed 'y%./+-%__p_%'`
 LIBS="-ljpeg  $LIBS"
-#line 7410 "configure"
+#line 7413 "configure"
@@ -7417,7 +7420,7 @@
 jpeg_start_compress()
 ; return 0; }
 EOF
-if { (eval echo configure:7421: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:7424: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -7436,13 +7439,13 @@
-echo "configure:7440: checking for jpeg_start_compress in -ljpeg" >&5
+echo "configure:7443: checking for jpeg_start_compress in -ljpeg" >&5
 LIBS="-ljpeg $ZLIB $LIBS"
-#line 7446 "configure"
+#line 7449 "configure"
@@ -7453,7 +7456,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:7457: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:7460: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -7502,7 +7505,7 @@
 # GDAL option
 echo $ac_n "checking whether to use GDAL""... $ac_c" 1>&6
-echo "configure:7506: checking whether to use GDAL" >&5
+echo "configure:7509: checking whether to use GDAL" >&5
 GDAL_LIBS=
 GDAL_CFLAGS=
@@ -7520,7 +7523,7 @@
   # Extract the first word of "gdal-config", so it can be a program name with args.
 set dummy gdal-config; ac_word=$2
 echo $ac_n "checking for $ac_word""... $ac_c" 1>&6
-echo "configure:7524: checking for $ac_word" >&5
+echo "configure:7527: checking for $ac_word" >&5
 case "$GDAL_CONFIG" in
@@ -7575,14 +7578,14 @@
   LIBS="$LIBS $GDAL_LIBS"
   CFLAGS="$CFLAGS $GDAL_CFLAGS"
-#line 7579 "configure"
+#line 7582 "configure"
 #include <gdal.h>
 int main() {
 GDALOpen("foo", GA_ReadOnly);
 ; return 0; }
 EOF
-if { (eval echo configure:7586: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:7589: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
 else
   echo "configure: failed program was:" >&5
@@ -7591,14 +7594,14 @@
   LIBS="$LIBS $GDAL_DEP_LIBS"
-#line 7595 "configure"
+#line 7598 "configure"
 #include <gdal.h>
 int main() {
 ; return 0; }
 EOF
-if { (eval echo configure:7602: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:7605: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   GDAL_LIBS="$GDAL_LIBS $GDAL_DEP_LIBS"
 else
@@ -7630,7 +7633,7 @@
 # GEOS option
 echo $ac_n "checking whether to use GEOS""... $ac_c" 1>&6
-echo "configure:7634: checking whether to use GEOS" >&5
+echo "configure:7637: checking whether to use GEOS" >&5
 GEOS_LIBS=
 GGEOS_CFLAGS=
@@ -7647,7 +7650,7 @@
   # Extract the first word of "geos-config", so it can be a program name with args.
 set dummy geos-config; ac_word=$2
-echo "configure:7651: checking for $ac_word" >&5
+echo "configure:7654: checking for $ac_word" >&5
 case "$GEOS_CONFIG" in
@@ -7695,15 +7698,15 @@
 do
-echo "configure:7699: checking for $ac_hdr" >&5
+echo "configure:7702: checking for $ac_hdr" >&5
-#line 7702 "configure"
+#line 7705 "configure"
 #include <$ac_hdr>
 EOF
 ac_try="$ac_cpp conftest.$ac_ext >/dev/null 2>conftest.out"
-{ (eval echo configure:7707: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:7710: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
 ac_err=`grep -v '^ *+' conftest.out | grep -v "^conftest.${ac_ext}\$"`
 if test -z "$ac_err"; then
   rm -rf conftest*
@@ -7747,7 +7750,7 @@
 echo $ac_n "checking whether to use TIFF""... $ac_c" 1>&6
-echo "configure:7751: checking whether to use TIFF" >&5
+echo "configure:7754: checking whether to use TIFF" >&5
 echo "$ac_t"""$with_tiff"" 1>&6
 case "$with_tiff" in
 	"no")	USE_TIFF=	;;
@@ -7767,7 +7770,7 @@
 echo $ac_n "checking for location of TIFF includes""... $ac_c" 1>&6
-echo "configure:7771: checking for location of TIFF includes" >&5
+echo "configure:7774: checking for location of TIFF includes" >&5
 case "$with_tiff_includes" in
 	{ echo "configure: error: *** You must supply a directory to --with-tiff-includes." 1>&2; exit 1; }
@@ -7793,15 +7796,15 @@
 do
-echo "configure:7797: checking for $ac_hdr" >&5
+echo "configure:7800: checking for $ac_hdr" >&5
-#line 7800 "configure"
+#line 7803 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:7805: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:7808: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -7835,7 +7838,7 @@
 echo $ac_n "checking for location of TIFF library""... $ac_c" 1>&6
-echo "configure:7839: checking for location of TIFF library" >&5
+echo "configure:7842: checking for location of TIFF library" >&5
 case "$with_tiff_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-tiff-libs." 1>&2; exit 1; }
@@ -7866,13 +7869,13 @@
 echo $ac_n "checking for TIFFOpen in -ltiff""... $ac_c" 1>&6
-echo "configure:7870: checking for TIFFOpen in -ltiff" >&5
+echo "configure:7873: checking for TIFFOpen in -ltiff" >&5
 ac_lib_var=`echo tiff'_'TIFFOpen | sed 'y%./+-%__p_%'`
 ac_save_LIBS="$LIBS"
 LIBS="-ltiff  $LIBS"
-#line 7876 "configure"
+#line 7879 "configure"
 /* Override any gcc2 internal prototype to avoid an error.  */
 /* We use char because int might match the return type of a gcc2
@@ -7883,7 +7886,7 @@
 TIFFOpen()
 ; return 0; }
 EOF
-if { (eval echo configure:7887: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:7890: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_lib_$ac_lib_var=yes"
 else
@@ -7902,13 +7905,13 @@
-echo "configure:7906: checking for TIFFOpen in -ltiff" >&5
+echo "configure:7909: checking for TIFFOpen in -ltiff" >&5
 LIBS="-ltiff $MATHLIB $LIBS"
-#line 7912 "configure"
+#line 7915 "configure"
@@ -7919,7 +7922,7 @@
 TIFFOpen()
 ; return 0; }
 EOF
-if { (eval echo configure:7923: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:7926: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -7938,13 +7941,13 @@
-echo "configure:7942: checking for TIFFOpen in -ltiff" >&5
+echo "configure:7945: checking for TIFFOpen in -ltiff" >&5
 LIBS="-ltiff $ZLIB $LIBS"
-#line 7948 "configure"
+#line 7951 "configure"
@@ -7955,7 +7958,7 @@
 TIFFOpen()
 ; return 0; }
 EOF
-if { (eval echo configure:7959: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:7962: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -7974,13 +7977,13 @@
-echo "configure:7978: checking for TIFFOpen in -ltiff" >&5
+echo "configure:7981: checking for TIFFOpen in -ltiff" >&5
 LIBS="-ltiff $ZLIB $MATHLIB $LIBS"
-#line 7984 "configure"
+#line 7987 "configure"
@@ -7991,7 +7994,7 @@
 TIFFOpen()
 ; return 0; }
 EOF
-if { (eval echo configure:7995: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:7998: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -8010,13 +8013,13 @@
-echo "configure:8014: checking for TIFFOpen in -ltiff" >&5
+echo "configure:8017: checking for TIFFOpen in -ltiff" >&5
 LIBS="-ltiff $JPEGLIBPATH $JPEGLIB $LIBS"
-#line 8020 "configure"
+#line 8023 "configure"
@@ -8027,7 +8030,7 @@
 TIFFOpen()
 ; return 0; }
 EOF
-if { (eval echo configure:8031: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8034: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -8046,13 +8049,13 @@
-echo "configure:8050: checking for TIFFOpen in -ltiff" >&5
+echo "configure:8053: checking for TIFFOpen in -ltiff" >&5
 LIBS="-ltiff $JPEGLIBPATH $JPEGLIB $MATHLIB $LIBS"
-#line 8056 "configure"
+#line 8059 "configure"
@@ -8063,7 +8066,7 @@
 TIFFOpen()
 ; return 0; }
 EOF
-if { (eval echo configure:8067: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8070: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -8082,13 +8085,13 @@
-echo "configure:8086: checking for TIFFOpen in -ltiff" >&5
+echo "configure:8089: checking for TIFFOpen in -ltiff" >&5
 LIBS="-ltiff $JPEGLIBPATH $JPEGLIB $ZLIB $LIBS"
-#line 8092 "configure"
+#line 8095 "configure"
@@ -8099,7 +8102,7 @@
 TIFFOpen()
 ; return 0; }
 EOF
-if { (eval echo configure:8103: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8106: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -8118,13 +8121,13 @@
-echo "configure:8122: checking for TIFFOpen in -ltiff" >&5
+echo "configure:8125: checking for TIFFOpen in -ltiff" >&5
 LIBS="-ltiff $JPEGLIBPATH $JPEGLIB $ZLIB $MATHLIB $LIBS"
-#line 8128 "configure"
+#line 8131 "configure"
@@ -8135,7 +8138,7 @@
 TIFFOpen()
 ; return 0; }
 EOF
-if { (eval echo configure:8139: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8142: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -8233,7 +8236,7 @@
 echo $ac_n "checking whether to use PNG""... $ac_c" 1>&6
-echo "configure:8237: checking whether to use PNG" >&5
+echo "configure:8240: checking whether to use PNG" >&5
 echo "$ac_t"""$with_png"" 1>&6
 case "$with_png" in
 	"no")	USE_PNG=	;;
@@ -8252,7 +8255,7 @@
 echo $ac_n "checking for location of PNG includes""... $ac_c" 1>&6
-echo "configure:8256: checking for location of PNG includes" >&5
+echo "configure:8259: checking for location of PNG includes" >&5
 case "$with_png_includes" in
 	{ echo "configure: error: *** You must supply a directory to --with-png-includes." 1>&2; exit 1; }
@@ -8278,15 +8281,15 @@
 do
-echo "configure:8282: checking for $ac_hdr" >&5
+echo "configure:8285: checking for $ac_hdr" >&5
-#line 8285 "configure"
+#line 8288 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:8290: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:8293: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -8320,7 +8323,7 @@
 echo $ac_n "checking for location of PNG library""... $ac_c" 1>&6
-echo "configure:8324: checking for location of PNG library" >&5
+echo "configure:8327: checking for location of PNG library" >&5
 case "$with_png_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-png-libs." 1>&2; exit 1; }
@@ -8345,13 +8348,13 @@
 echo $ac_n "checking for png_read_image in -lpng""... $ac_c" 1>&6
-echo "configure:8349: checking for png_read_image in -lpng" >&5
+echo "configure:8352: checking for png_read_image in -lpng" >&5
 ac_lib_var=`echo png'_'png_read_image | sed 'y%./+-%__p_%'`
 LIBS="-lpng $ZLIB $MATHLIB $LIBS"
-#line 8355 "configure"
+#line 8358 "configure"
@@ -8362,7 +8365,7 @@
 png_read_image()
 ; return 0; }
 EOF
-if { (eval echo configure:8366: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8369: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -8404,7 +8407,7 @@
 echo $ac_n "checking whether to use Tcl/Tk""... $ac_c" 1>&6
-echo "configure:8408: checking whether to use Tcl/Tk" >&5
+echo "configure:8411: checking whether to use Tcl/Tk" >&5
 echo "$ac_t"""$with_tcltk"" 1>&6
 case "$with_tcltk" in
 	"no")	USE_TCLTK=	;;
@@ -8424,7 +8427,7 @@
 echo $ac_n "checking for location of Tcl/Tk includes""... $ac_c" 1>&6
-echo "configure:8428: checking for location of Tcl/Tk includes" >&5
+echo "configure:8431: checking for location of Tcl/Tk includes" >&5
 case "$with_tcltk_includes" in
 	{ echo "configure: error: *** You must supply a directory to --with-tcltk-includes." 1>&2; exit 1; }
@@ -8450,15 +8453,15 @@
 do
-echo "configure:8454: checking for $ac_hdr" >&5
+echo "configure:8457: checking for $ac_hdr" >&5
-#line 8457 "configure"
+#line 8460 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:8462: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:8465: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -8495,15 +8498,15 @@
 do
-echo "configure:8499: checking for $ac_hdr" >&5
+echo "configure:8502: checking for $ac_hdr" >&5
-#line 8502 "configure"
+#line 8505 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:8507: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:8510: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -8537,7 +8540,7 @@
 echo $ac_n "checking Tcl version""... $ac_c" 1>&6
-echo "configure:8541: checking Tcl version" >&5
+echo "configure:8544: checking Tcl version" >&5
 CPPFLAGS="$TCLINCDIR $CPPFLAGS"
 if test "$cross_compiling" = yes; then
@@ -8545,7 +8548,7 @@
     echo "$ac_t""unknown (cross-compiling)" 1>&6
 else
-#line 8549 "configure"
+#line 8552 "configure"
 #include <stdio.h>
@@ -8557,7 +8560,7 @@
 EOF
-if { (eval echo configure:8561: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext} && (./conftest; exit) 2>/dev/null
+if { (eval echo configure:8564: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext} && (./conftest; exit) 2>/dev/null
 then
      tcl_ver=`cat conftestdata`
     echo "$ac_t""$tcl_ver" 1>&6
@@ -8575,7 +8578,7 @@
 echo $ac_n "checking Tk version""... $ac_c" 1>&6
-echo "configure:8579: checking Tk version" >&5
+echo "configure:8582: checking Tk version" >&5
 CPPFLAGS="$TCLINCDIR $X_CFLAGS $CPPFLAGS"
@@ -8583,7 +8586,7 @@
 else
-#line 8587 "configure"
+#line 8590 "configure"
 #include <stdio.h>
@@ -8595,7 +8598,7 @@
 EOF
-if { (eval echo configure:8599: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext} && (./conftest; exit) 2>/dev/null
+if { (eval echo configure:8602: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext} && (./conftest; exit) 2>/dev/null
 then
      tk_ver=`cat conftestdata`
     echo "$ac_t""$tk_ver" 1>&6
@@ -8624,7 +8627,7 @@
 echo $ac_n "checking for location of Tcl/Tk library""... $ac_c" 1>&6
-echo "configure:8628: checking for location of Tcl/Tk library" >&5
+echo "configure:8631: checking for location of Tcl/Tk library" >&5
 case "$with_tcltk_libs" in
 y | ye | yes | n | no)
 	{ echo "configure: error: *** You must supply a directory to --with-tcltk-libs." 1>&2; exit 1; }
@@ -8654,13 +8657,13 @@
 echo $ac_n "checking for Tcl_Init in -ltcl""... $ac_c" 1>&6
-echo "configure:8658: checking for Tcl_Init in -ltcl" >&5
+echo "configure:8661: checking for Tcl_Init in -ltcl" >&5
 ac_lib_var=`echo tcl'_'Tcl_Init | sed 'y%./+-%__p_%'`
 LIBS="-ltcl $MATHLIB $LIBS"
-#line 8664 "configure"
+#line 8667 "configure"
@@ -8671,7 +8674,7 @@
 Tcl_Init()
 ; return 0; }
 EOF
-if { (eval echo configure:8675: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8678: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -8690,13 +8693,13 @@
-echo "configure:8694: checking for Tcl_Init in -ltcl" >&5
+echo "configure:8697: checking for Tcl_Init in -ltcl" >&5
 LIBS="-ltcl $MATHLIB $DLLIB $LIBS"
-#line 8700 "configure"
+#line 8703 "configure"
@@ -8707,7 +8710,7 @@
 Tcl_Init()
 ; return 0; }
 EOF
-if { (eval echo configure:8711: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8714: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -8734,13 +8737,13 @@
 echo $ac_n "checking for Tcl_Init in -ltcl$tcltk_ver""... $ac_c" 1>&6
-echo "configure:8738: checking for Tcl_Init in -ltcl$tcltk_ver" >&5
+echo "configure:8741: checking for Tcl_Init in -ltcl$tcltk_ver" >&5
 ac_lib_var=`echo tcl$tcltk_ver'_'Tcl_Init | sed 'y%./+-%__p_%'`
 LIBS="-ltcl$tcltk_ver $MATHLIB $LIBS"
-#line 8744 "configure"
+#line 8747 "configure"
@@ -8751,7 +8754,7 @@
 Tcl_Init()
 ; return 0; }
 EOF
-if { (eval echo configure:8755: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8758: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -8770,13 +8773,13 @@
-echo "configure:8774: checking for Tcl_Init in -ltcl$tcltk_ver" >&5
+echo "configure:8777: checking for Tcl_Init in -ltcl$tcltk_ver" >&5
 LIBS="-ltcl$tcltk_ver $MATHLIB $DLLIB $LIBS"
-#line 8780 "configure"
+#line 8783 "configure"
@@ -8787,7 +8790,7 @@
 Tcl_Init()
 ; return 0; }
 EOF
-if { (eval echo configure:8791: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8794: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -8814,13 +8817,13 @@
 echo $ac_n "checking for Tcl_Init in -ltcl$tcltk_ver2""... $ac_c" 1>&6
-echo "configure:8818: checking for Tcl_Init in -ltcl$tcltk_ver2" >&5
+echo "configure:8821: checking for Tcl_Init in -ltcl$tcltk_ver2" >&5
 ac_lib_var=`echo tcl$tcltk_ver2'_'Tcl_Init | sed 'y%./+-%__p_%'`
 LIBS="-ltcl$tcltk_ver2 $MATHLIB $LIBS"
-#line 8824 "configure"
+#line 8827 "configure"
@@ -8831,7 +8834,7 @@
 Tcl_Init()
 ; return 0; }
 EOF
-if { (eval echo configure:8835: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8838: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -8850,13 +8853,13 @@
-echo "configure:8854: checking for Tcl_Init in -ltcl$tcltk_ver2" >&5
+echo "configure:8857: checking for Tcl_Init in -ltcl$tcltk_ver2" >&5
 LIBS="-ltcl$tcltk_ver2 $MATHLIB $DLLIB $LIBS"
-#line 8860 "configure"
+#line 8863 "configure"
@@ -8867,7 +8870,7 @@
 Tcl_Init()
 ; return 0; }
 EOF
-if { (eval echo configure:8871: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8874: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -8945,13 +8948,13 @@
 echo $ac_n "checking for Tk_MainWindow in -ltk""... $ac_c" 1>&6
-echo "configure:8949: checking for Tk_MainWindow in -ltk" >&5
+echo "configure:8952: checking for Tk_MainWindow in -ltk" >&5
 ac_lib_var=`echo tk'_'Tk_MainWindow | sed 'y%./+-%__p_%'`
 LIBS="-ltk $TCLLIB $MATHLIB $LIBS"
-#line 8955 "configure"
+#line 8958 "configure"
@@ -8962,7 +8965,7 @@
 Tk_MainWindow()
 ; return 0; }
 EOF
-if { (eval echo configure:8966: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8969: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -8981,13 +8984,13 @@
-echo "configure:8985: checking for Tk_MainWindow in -ltk" >&5
+echo "configure:8988: checking for Tk_MainWindow in -ltk" >&5
 LIBS="-ltk $TCLLIB $MATHLIB $X_LIBS $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $LIBS"
-#line 8991 "configure"
+#line 8994 "configure"
@@ -8998,7 +9001,7 @@
 Tk_MainWindow()
 ; return 0; }
 EOF
-if { (eval echo configure:9002: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9005: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -9025,13 +9028,13 @@
 echo $ac_n "checking for Tk_MainWindow in -ltk$tcltk_ver""... $ac_c" 1>&6
-echo "configure:9029: checking for Tk_MainWindow in -ltk$tcltk_ver" >&5
+echo "configure:9032: checking for Tk_MainWindow in -ltk$tcltk_ver" >&5
 ac_lib_var=`echo tk$tcltk_ver'_'Tk_MainWindow | sed 'y%./+-%__p_%'`
 LIBS="-ltk$tcltk_ver $TCLLIB $MATHLIB $LIBS"
-#line 9035 "configure"
+#line 9038 "configure"
@@ -9042,7 +9045,7 @@
 Tk_MainWindow()
 ; return 0; }
 EOF
-if { (eval echo configure:9046: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9049: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -9061,13 +9064,13 @@
-echo "configure:9065: checking for Tk_MainWindow in -ltk$tcltk_ver" >&5
+echo "configure:9068: checking for Tk_MainWindow in -ltk$tcltk_ver" >&5
 LIBS="-ltk$tcltk_ver $TCLLIB $MATHLIB $X_LIBS $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $LIBS"
-#line 9071 "configure"
+#line 9074 "configure"
@@ -9078,7 +9081,7 @@
 Tk_MainWindow()
 ; return 0; }
 EOF
-if { (eval echo configure:9082: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9085: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -9105,13 +9108,13 @@
 echo $ac_n "checking for Tk_MainWindow in -ltk$tcltk_ver2""... $ac_c" 1>&6
-echo "configure:9109: checking for Tk_MainWindow in -ltk$tcltk_ver2" >&5
+echo "configure:9112: checking for Tk_MainWindow in -ltk$tcltk_ver2" >&5
 ac_lib_var=`echo tk$tcltk_ver2'_'Tk_MainWindow | sed 'y%./+-%__p_%'`
 LIBS="-ltk$tcltk_ver2 $TCLLIB $MATHLIB $LIBS"
-#line 9115 "configure"
+#line 9118 "configure"
@@ -9122,7 +9125,7 @@
 Tk_MainWindow()
 ; return 0; }
 EOF
-if { (eval echo configure:9126: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9129: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -9141,13 +9144,13 @@
-echo "configure:9145: checking for Tk_MainWindow in -ltk$tcltk_ver2" >&5
+echo "configure:9148: checking for Tk_MainWindow in -ltk$tcltk_ver2" >&5
 LIBS="-ltk$tcltk_ver2 $TCLLIB $MATHLIB $X_LIBS $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $LIBS"
-#line 9151 "configure"
+#line 9154 "configure"
@@ -9158,7 +9161,7 @@
 Tk_MainWindow()
 ; return 0; }
 EOF
-if { (eval echo configure:9162: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9165: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -9250,7 +9253,7 @@
 echo $ac_n "checking whether to use PostgreSQL""... $ac_c" 1>&6
-echo "configure:9254: checking whether to use PostgreSQL" >&5
+echo "configure:9257: checking whether to use PostgreSQL" >&5
 echo "$ac_t"""$with_postgres"" 1>&6
 case "$with_postgres" in
 	"no")	USE_POSTGRES=	;;
@@ -9277,7 +9280,7 @@
 echo $ac_n "checking for location of PostgreSQL includes""... $ac_c" 1>&6
-echo "configure:9281: checking for location of PostgreSQL includes" >&5
+echo "configure:9284: checking for location of PostgreSQL includes" >&5
 case "$with_postgres_includes" in
 	{ echo "configure: error: *** You must supply a directory to --with-postgres-includes." 1>&2; exit 1; }
@@ -9303,15 +9306,15 @@
 do
 ac_safe=`echo "$ac_hdr" | sed 'y%./+-%__p_%'`
 echo $ac_n "checking for $ac_hdr""... $ac_c" 1>&6
-echo "configure:9307: checking for $ac_hdr" >&5
+echo "configure:9310: checking for $ac_hdr" >&5
-#line 9310 "configure"
+#line 9313 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:9315: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:9318: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -9349,7 +9352,7 @@
 echo $ac_n "checking for location of PostgreSQL library""... $ac_c" 1>&6
-echo "configure:9353: checking for location of PostgreSQL library" >&5
+echo "configure:9356: checking for location of PostgreSQL library" >&5
 case "$with_postgres_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-postgres-libs." 1>&2; exit 1; }
@@ -9378,13 +9381,13 @@
 echo $ac_n "checking for PQsetdbLogin in -lpq""... $ac_c" 1>&6
-echo "configure:9382: checking for PQsetdbLogin in -lpq" >&5
+echo "configure:9385: checking for PQsetdbLogin in -lpq" >&5
 ac_lib_var=`echo pq'_'PQsetdbLogin | sed 'y%./+-%__p_%'`
 LIBS="-lpq  $LIBS"
-#line 9388 "configure"
+#line 9391 "configure"
@@ -9395,7 +9398,7 @@
 PQsetdbLogin()
 ; return 0; }
 EOF
-if { (eval echo configure:9399: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9402: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -9414,13 +9417,13 @@
-echo "configure:9418: checking for PQsetdbLogin in -lpq" >&5
+echo "configure:9421: checking for PQsetdbLogin in -lpq" >&5
 LIBS="-lpq -lssl -lcrypto $LIBS"
-#line 9424 "configure"
+#line 9427 "configure"
@@ -9431,7 +9434,7 @@
 PQsetdbLogin()
 ; return 0; }
 EOF
-if { (eval echo configure:9435: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9438: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -9450,13 +9453,13 @@
-echo "configure:9454: checking for PQsetdbLogin in -lpq" >&5
+echo "configure:9457: checking for PQsetdbLogin in -lpq" >&5
 LIBS="-lpq -lcrypt $LIBS"
-#line 9460 "configure"
+#line 9463 "configure"
@@ -9467,7 +9470,7 @@
 PQsetdbLogin()
 ; return 0; }
 EOF
-if { (eval echo configure:9471: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9474: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -9486,13 +9489,13 @@
-echo "configure:9490: checking for PQsetdbLogin in -lpq" >&5
+echo "configure:9493: checking for PQsetdbLogin in -lpq" >&5
 LIBS="-lpq -lcrypt -lssl -lcrypto $LIBS"
-#line 9496 "configure"
+#line 9499 "configure"
@@ -9503,7 +9506,7 @@
 PQsetdbLogin()
 ; return 0; }
 EOF
-if { (eval echo configure:9507: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9510: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -9560,13 +9563,13 @@
 ac_save_ldflags="$LDFLAGS"
 LDFLAGS="$LDFLAGS $PQLIBPATH"
 echo $ac_n "checking for PQcmdTuples in -lpq""... $ac_c" 1>&6
-echo "configure:9564: checking for PQcmdTuples in -lpq" >&5
+echo "configure:9567: checking for PQcmdTuples in -lpq" >&5
 ac_lib_var=`echo pq'_'PQcmdTuples | sed 'y%./+-%__p_%'`
 LIBS="-lpq  $LIBS"
-#line 9570 "configure"
+#line 9573 "configure"
@@ -9577,7 +9580,7 @@
 PQcmdTuples()
 ; return 0; }
 EOF
-if { (eval echo configure:9581: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9584: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -9599,13 +9602,13 @@
-echo "configure:9603: checking for PQcmdTuples in -lpq" >&5
+echo "configure:9606: checking for PQcmdTuples in -lpq" >&5
-#line 9609 "configure"
+#line 9612 "configure"
@@ -9616,7 +9619,7 @@
 PQcmdTuples()
 ; return 0; }
 EOF
-if { (eval echo configure:9620: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9623: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -9659,7 +9662,7 @@
 echo $ac_n "checking whether to use MySQL""... $ac_c" 1>&6
-echo "configure:9663: checking whether to use MySQL" >&5
+echo "configure:9666: checking whether to use MySQL" >&5
 echo "$ac_t"""$with_mysql"" 1>&6
 case "$with_mysql" in
 	"no")	USE_MYSQL=	;;
@@ -9679,7 +9682,7 @@
 echo $ac_n "checking for location of MySQL includes""... $ac_c" 1>&6
-echo "configure:9683: checking for location of MySQL includes" >&5
+echo "configure:9686: checking for location of MySQL includes" >&5
 case "$with_mysql_includes" in
 	{ echo "configure: error: *** You must supply a directory to --with-mysql-includes." 1>&2; exit 1; }
@@ -9705,15 +9708,15 @@
 do
-echo "configure:9709: checking for $ac_hdr" >&5
+echo "configure:9712: checking for $ac_hdr" >&5
-#line 9712 "configure"
+#line 9715 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:9717: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:9720: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -9750,7 +9753,7 @@
 echo $ac_n "checking for location of MySQL library""... $ac_c" 1>&6
-echo "configure:9754: checking for location of MySQL library" >&5
+echo "configure:9757: checking for location of MySQL library" >&5
 case "$with_mysql_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-mysql-libs." 1>&2; exit 1; }
@@ -9781,13 +9784,13 @@
 echo $ac_n "checking for mysql_query in -lmysqlclient""... $ac_c" 1>&6
-echo "configure:9785: checking for mysql_query in -lmysqlclient" >&5
+echo "configure:9788: checking for mysql_query in -lmysqlclient" >&5
 ac_lib_var=`echo mysqlclient'_'mysql_query | sed 'y%./+-%__p_%'`
 LIBS="-lmysqlclient  $LIBS"
-#line 9791 "configure"
+#line 9794 "configure"
@@ -9798,7 +9801,7 @@
 mysql_query()
 ; return 0; }
 EOF
-if { (eval echo configure:9802: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9805: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -9817,13 +9820,13 @@
-echo "configure:9821: checking for mysql_query in -lmysqlclient" >&5
+echo "configure:9824: checking for mysql_query in -lmysqlclient" >&5
 LIBS="-lmysqlclient $MATHLIB $LIBS"
-#line 9827 "configure"
+#line 9830 "configure"
@@ -9834,7 +9837,7 @@
 mysql_query()
 ; return 0; }
 EOF
-if { (eval echo configure:9838: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9841: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -9853,13 +9856,13 @@
-echo "configure:9857: checking for mysql_query in -lmysqlclient" >&5
+echo "configure:9860: checking for mysql_query in -lmysqlclient" >&5
 LIBS="-lmysqlclient $SOCKLIB $LIBS"
-#line 9863 "configure"
+#line 9866 "configure"
@@ -9870,7 +9873,7 @@
 mysql_query()
 ; return 0; }
 EOF
-if { (eval echo configure:9874: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9877: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -9889,13 +9892,13 @@
-echo "configure:9893: checking for mysql_query in -lmysqlclient" >&5
+echo "configure:9896: checking for mysql_query in -lmysqlclient" >&5
 LIBS="-lmysqlclient $SOCKLIB $MATHLIB $LIBS"
-#line 9899 "configure"
+#line 9902 "configure"
@@ -9906,7 +9909,7 @@
 mysql_query()
 ; return 0; }
 EOF
-if { (eval echo configure:9910: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9913: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -9925,13 +9928,13 @@
-echo "configure:9929: checking for mysql_query in -lmysqlclient" >&5
+echo "configure:9932: checking for mysql_query in -lmysqlclient" >&5
 LIBS="-lmysqlclient $ZLIB $LIBS"
-#line 9935 "configure"
+#line 9938 "configure"
@@ -9942,7 +9945,7 @@
 mysql_query()
 ; return 0; }
 EOF
-if { (eval echo configure:9946: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9949: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -9961,13 +9964,13 @@
-echo "configure:9965: checking for mysql_query in -lmysqlclient" >&5
+echo "configure:9968: checking for mysql_query in -lmysqlclient" >&5
 LIBS="-lmysqlclient $ZLIB $MATHLIB $LIBS"
-#line 9971 "configure"
+#line 9974 "configure"
@@ -9978,7 +9981,7 @@
 mysql_query()
 ; return 0; }
 EOF
-if { (eval echo configure:9982: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9985: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -9997,13 +10000,13 @@
-echo "configure:10001: checking for mysql_query in -lmysqlclient" >&5
+echo "configure:10004: checking for mysql_query in -lmysqlclient" >&5
 LIBS="-lmysqlclient $ZLIB $SOCKLIB $LIBS"
-#line 10007 "configure"
+#line 10010 "configure"
@@ -10014,7 +10017,7 @@
 mysql_query()
 ; return 0; }
 EOF
-if { (eval echo configure:10018: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10021: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -10033,13 +10036,13 @@
-echo "configure:10037: checking for mysql_query in -lmysqlclient" >&5
+echo "configure:10040: checking for mysql_query in -lmysqlclient" >&5
 LIBS="-lmysqlclient $ZLIB $SOCKLIB $MATHLIB $LIBS"
-#line 10043 "configure"
+#line 10046 "configure"
@@ -10050,7 +10053,7 @@
 mysql_query()
 ; return 0; }
 EOF
-if { (eval echo configure:10054: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10057: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -10140,7 +10143,7 @@
   # Extract the first word of "mysql_config", so it can be a program name with args.
 set dummy mysql_config; ac_word=$2
-echo "configure:10144: checking for $ac_word" >&5
+echo "configure:10147: checking for $ac_word" >&5
 case "$MYSQLD_CONFIG" in
@@ -10189,10 +10192,10 @@
     LIBS="$MYSQLDLIB $LIBS"
     echo $ac_n "checking for mysql_server_init""... $ac_c" 1>&6
-echo "configure:10193: checking for mysql_server_init" >&5
+echo "configure:10196: checking for mysql_server_init" >&5
-#line 10196 "configure"
+#line 10199 "configure"
 /* System header to define __stub macros and hopefully few prototypes,
     which can conflict with char mysql_server_init(); below.  */
@@ -10218,7 +10221,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:10222: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10225: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_mysql_server_init=yes"
 else
@@ -10270,7 +10273,7 @@
 echo $ac_n "checking whether to use SQLite""... $ac_c" 1>&6
-echo "configure:10274: checking whether to use SQLite" >&5
+echo "configure:10277: checking whether to use SQLite" >&5
 echo "$ac_t"""$with_sqlite"" 1>&6
 case "$with_sqlite" in
 	"no")	USE_SQLITE=	;;
@@ -10290,7 +10293,7 @@
 echo $ac_n "checking for location of SQLite includes""... $ac_c" 1>&6
-echo "configure:10294: checking for location of SQLite includes" >&5
+echo "configure:10297: checking for location of SQLite includes" >&5
 case "$with_sqlite_includes" in
 	{ echo "configure: error: *** You must supply a directory to --with-sqlite-includes." 1>&2; exit 1; }
@@ -10316,15 +10319,15 @@
 do
-echo "configure:10320: checking for $ac_hdr" >&5
+echo "configure:10323: checking for $ac_hdr" >&5
-#line 10323 "configure"
+#line 10326 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:10328: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:10331: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -10367,7 +10370,7 @@
 echo $ac_n "checking for location of SQLite library""... $ac_c" 1>&6
-echo "configure:10371: checking for location of SQLite library" >&5
+echo "configure:10374: checking for location of SQLite library" >&5
 case "$with_sqlite_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-sqlite-libs." 1>&2; exit 1; }
@@ -10394,13 +10397,13 @@
 echo $ac_n "checking for sqlite3_open in -lsqlite3""... $ac_c" 1>&6
-echo "configure:10398: checking for sqlite3_open in -lsqlite3" >&5
+echo "configure:10401: checking for sqlite3_open in -lsqlite3" >&5
 ac_lib_var=`echo sqlite3'_'sqlite3_open | sed 'y%./+-%__p_%'`
 LIBS="-lsqlite3  $LIBS"
-#line 10404 "configure"
+#line 10407 "configure"
@@ -10411,7 +10414,7 @@
 sqlite3_open()
 ; return 0; }
 EOF
-if { (eval echo configure:10415: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10418: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -10430,13 +10433,13 @@
-echo "configure:10434: checking for sqlite3_open in -lsqlite3" >&5
+echo "configure:10437: checking for sqlite3_open in -lsqlite3" >&5
 LIBS="-lsqlite3 $MATHLIB $LIBS"
-#line 10440 "configure"
+#line 10443 "configure"
@@ -10447,7 +10450,7 @@
 sqlite3_open()
 ; return 0; }
 EOF
-if { (eval echo configure:10451: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10454: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -10500,7 +10503,7 @@
 echo $ac_n "checking whether to use FFMPEG""... $ac_c" 1>&6
-echo "configure:10504: checking whether to use FFMPEG" >&5
+echo "configure:10507: checking whether to use FFMPEG" >&5
 echo "$ac_t"""$with_ffmpeg"" 1>&6
 case "$with_ffmpeg" in
 	"no")	USE_FFMPEG=	;;
@@ -10520,7 +10523,7 @@
 echo $ac_n "checking for location of FFMPEG includes""... $ac_c" 1>&6
-echo "configure:10524: checking for location of FFMPEG includes" >&5
+echo "configure:10527: checking for location of FFMPEG includes" >&5
 case "$with_ffmpeg_includes" in
 	{ echo "configure: error: *** You must supply a directory to --with-ffmpeg-includes." 1>&2; exit 1; }
@@ -10546,15 +10549,15 @@
 do
-echo "configure:10550: checking for $ac_hdr" >&5
+echo "configure:10553: checking for $ac_hdr" >&5
-#line 10553 "configure"
+#line 10556 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:10558: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:10561: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -10590,15 +10593,15 @@
 do
-echo "configure:10594: checking for $ac_hdr" >&5
+echo "configure:10597: checking for $ac_hdr" >&5
-#line 10597 "configure"
+#line 10600 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:10602: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:10605: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -10634,15 +10637,15 @@
 do
-echo "configure:10638: checking for $ac_hdr" >&5
+echo "configure:10641: checking for $ac_hdr" >&5
-#line 10641 "configure"
+#line 10644 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:10646: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:10649: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -10685,7 +10688,7 @@
 echo $ac_n "checking for location of FFMPEG library""... $ac_c" 1>&6
-echo "configure:10689: checking for location of FFMPEG library" >&5
+echo "configure:10692: checking for location of FFMPEG library" >&5
 case "$with_ffmpeg_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-ffmpeg-libs." 1>&2; exit 1; }
@@ -10712,13 +10715,13 @@
 echo $ac_n "checking for av_free in -lavutil""... $ac_c" 1>&6
-echo "configure:10716: checking for av_free in -lavutil" >&5
+echo "configure:10719: checking for av_free in -lavutil" >&5
 ac_lib_var=`echo avutil'_'av_free | sed 'y%./+-%__p_%'`
 LIBS="-lavutil  $LIBS"
-#line 10722 "configure"
+#line 10725 "configure"
@@ -10729,7 +10732,7 @@
 av_free()
 ; return 0; }
 EOF
-if { (eval echo configure:10733: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10736: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -10748,13 +10751,13 @@
   echo "$ac_t""no" 1>&6
-echo "configure:10752: checking for av_free in -lavutil" >&5
+echo "configure:10755: checking for av_free in -lavutil" >&5
 LIBS="-lavutil $MATHLIB $LIBS"
-#line 10758 "configure"
+#line 10761 "configure"
@@ -10765,7 +10768,7 @@
 av_free()
 ; return 0; }
 EOF
-if { (eval echo configure:10769: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10772: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -10810,13 +10813,13 @@
 echo $ac_n "checking for avcodec_init in -lavcodec""... $ac_c" 1>&6
-echo "configure:10814: checking for avcodec_init in -lavcodec" >&5
+echo "configure:10817: checking for avcodec_init in -lavcodec" >&5
 ac_lib_var=`echo avcodec'_'avcodec_init | sed 'y%./+-%__p_%'`
 LIBS="-lavcodec $FFMPEGLIB  $LIBS"
-#line 10820 "configure"
+#line 10823 "configure"
@@ -10827,7 +10830,7 @@
 avcodec_init()
 ; return 0; }
 EOF
-if { (eval echo configure:10831: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10834: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -10846,13 +10849,13 @@
-echo "configure:10850: checking for avcodec_init in -lavcodec" >&5
+echo "configure:10853: checking for avcodec_init in -lavcodec" >&5
 LIBS="-lavcodec $FFMPEGLIB $MATHLIB $LIBS"
-#line 10856 "configure"
+#line 10859 "configure"
@@ -10863,7 +10866,7 @@
 avcodec_init()
 ; return 0; }
 EOF
-if { (eval echo configure:10867: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10870: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -10908,13 +10911,13 @@
 echo $ac_n "checking for av_set_parameters in -lavformat""... $ac_c" 1>&6
-echo "configure:10912: checking for av_set_parameters in -lavformat" >&5
+echo "configure:10915: checking for av_set_parameters in -lavformat" >&5
 ac_lib_var=`echo avformat'_'av_set_parameters | sed 'y%./+-%__p_%'`
 LIBS="-lavformat $FFMPEGLIB  $LIBS"
-#line 10918 "configure"
+#line 10921 "configure"
@@ -10925,7 +10928,7 @@
 av_set_parameters()
 ; return 0; }
 EOF
-if { (eval echo configure:10929: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10932: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -10944,13 +10947,13 @@
-echo "configure:10948: checking for av_set_parameters in -lavformat" >&5
+echo "configure:10951: checking for av_set_parameters in -lavformat" >&5
 LIBS="-lavformat $FFMPEGLIB $MATHLIB $LIBS"
-#line 10954 "configure"
+#line 10957 "configure"
@@ -10961,7 +10964,7 @@
 av_set_parameters()
 ; return 0; }
 EOF
-if { (eval echo configure:10965: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10968: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -11021,7 +11024,7 @@
 OPENGL_WINDOWS=
 echo $ac_n "checking whether to use OpenGL""... $ac_c" 1>&6
-echo "configure:11025: checking whether to use OpenGL" >&5
+echo "configure:11028: checking whether to use OpenGL" >&5
 echo "$ac_t"""$with_opengl"" 1>&6
 case "$with_opengl" in
 	n|no)
@@ -11055,7 +11058,7 @@
 echo $ac_n "checking for location of OpenGL includes""... $ac_c" 1>&6
-echo "configure:11059: checking for location of OpenGL includes" >&5
+echo "configure:11062: checking for location of OpenGL includes" >&5
 case "$with_opengl_includes" in
 	{ echo "configure: error: *** You must supply a directory to --with-opengl-includes." 1>&2; exit 1; }
@@ -11081,15 +11084,15 @@
 do
-echo "configure:11085: checking for $ac_hdr" >&5
+echo "configure:11088: checking for $ac_hdr" >&5
-#line 11088 "configure"
+#line 11091 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:11093: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:11096: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -11123,7 +11126,7 @@
 echo $ac_n "checking for location of OpenGL library""... $ac_c" 1>&6
-echo "configure:11127: checking for location of OpenGL library" >&5
+echo "configure:11130: checking for location of OpenGL library" >&5
 case "$with_opengl_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-opengl-libs." 1>&2; exit 1; }
@@ -11152,13 +11155,13 @@
 echo $ac_n "checking for glBegin in -lGL""... $ac_c" 1>&6
-echo "configure:11156: checking for glBegin in -lGL" >&5
+echo "configure:11159: checking for glBegin in -lGL" >&5
 ac_lib_var=`echo GL'_'glBegin | sed 'y%./+-%__p_%'`
 LIBS="-lGL $X_LIBS $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $MATHLIB  $LIBS"
-#line 11162 "configure"
+#line 11165 "configure"
@@ -11169,7 +11172,7 @@
 glBegin()
 ; return 0; }
 EOF
-if { (eval echo configure:11173: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11176: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -11188,13 +11191,13 @@
-echo "configure:11192: checking for glBegin in -lGL" >&5
+echo "configure:11195: checking for glBegin in -lGL" >&5
 LIBS="-lGL $X_LIBS $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $MATHLIB -lXext $LIBS"
-#line 11198 "configure"
+#line 11201 "configure"
@@ -11205,7 +11208,7 @@
 glBegin()
 ; return 0; }
 EOF
-if { (eval echo configure:11209: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11212: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -11224,13 +11227,13 @@
-echo "configure:11228: checking for glBegin in -lGL" >&5
+echo "configure:11231: checking for glBegin in -lGL" >&5
 LIBS="-lGL $X_LIBS $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $MATHLIB -lpthread $LIBS"
-#line 11234 "configure"
+#line 11237 "configure"
@@ -11241,7 +11244,7 @@
 glBegin()
 ; return 0; }
 EOF
-if { (eval echo configure:11245: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11248: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -11260,13 +11263,13 @@
-echo "configure:11264: checking for glBegin in -lGL" >&5
+echo "configure:11267: checking for glBegin in -lGL" >&5
 LIBS="-lGL $X_LIBS $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $MATHLIB -lpthread -lXext $LIBS"
-#line 11270 "configure"
+#line 11273 "configure"
@@ -11277,7 +11280,7 @@
 glBegin()
 ; return 0; }
 EOF
-if { (eval echo configure:11281: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11284: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -11339,13 +11342,13 @@
 echo $ac_n "checking for gluBeginCurve in -lGLU""... $ac_c" 1>&6
-echo "configure:11343: checking for gluBeginCurve in -lGLU" >&5
+echo "configure:11346: checking for gluBeginCurve in -lGLU" >&5
 ac_lib_var=`echo GLU'_'gluBeginCurve | sed 'y%./+-%__p_%'`
 LIBS="-lGLU $OPENGLLIB $X_LIBS $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $MATHLIB  $LIBS"
-#line 11349 "configure"
+#line 11352 "configure"
@@ -11356,7 +11359,7 @@
 gluBeginCurve()
 ; return 0; }
 EOF
-if { (eval echo configure:11360: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11363: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -11375,13 +11378,13 @@
-echo "configure:11379: checking for gluBeginCurve in -lGLU" >&5
+echo "configure:11382: checking for gluBeginCurve in -lGLU" >&5
 LIBS="-lGLU $OPENGLLIB $X_LIBS $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $MATHLIB -lstdc++ $LIBS"
-#line 11385 "configure"
+#line 11388 "configure"
@@ -11392,7 +11395,7 @@
 gluBeginCurve()
 ; return 0; }
 EOF
-if { (eval echo configure:11396: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11399: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -11439,10 +11442,10 @@
 LIBS=" $OPENGLLIB $LIBS"
 LDFLAGS=" $LDFLAGS"
 echo $ac_n "checking for glXCreatePbuffer""... $ac_c" 1>&6
-echo "configure:11443: checking for glXCreatePbuffer" >&5
+echo "configure:11446: checking for glXCreatePbuffer" >&5
-#line 11446 "configure"
+#line 11449 "configure"
     which can conflict with char glXCreatePbuffer(); below.  */
@@ -11465,7 +11468,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:11469: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11472: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_glXCreatePbuffer=yes"
 else
@@ -11502,10 +11505,10 @@
 LDFLAGS=" $LDFLAGS"
 echo $ac_n "checking for glXCreateGLXPixmap""... $ac_c" 1>&6
-echo "configure:11506: checking for glXCreateGLXPixmap" >&5
+echo "configure:11509: checking for glXCreateGLXPixmap" >&5
-#line 11509 "configure"
+#line 11512 "configure"
     which can conflict with char glXCreateGLXPixmap(); below.  */
@@ -11528,7 +11531,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:11532: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11535: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_glXCreateGLXPixmap=yes"
 else
@@ -11571,7 +11574,7 @@
 echo $ac_n "checking for location of OpenGL framework""... $ac_c" 1>&6
-echo "configure:11575: checking for location of OpenGL framework" >&5
+echo "configure:11578: checking for location of OpenGL framework" >&5
 case "$with_opengl_framework" in
 	{ echo "configure: error: *** You must supply a directory to --with-opengl-framework." 1>&2; exit 1; }
@@ -11595,15 +11598,15 @@
 do
-echo "configure:11599: checking for $ac_hdr" >&5
+echo "configure:11602: checking for $ac_hdr" >&5
-#line 11602 "configure"
+#line 11605 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:11607: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:11610: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -11639,10 +11642,10 @@
 LIBS="-framework OpenGL -framework AGL -framework ApplicationServices  $LIBS"
 LDFLAGS="$OPENGLPATH $LDFLAGS"
 echo $ac_n "checking for glBegin""... $ac_c" 1>&6
-echo "configure:11643: checking for glBegin" >&5
+echo "configure:11646: checking for glBegin" >&5
-#line 11646 "configure"
+#line 11649 "configure"
     which can conflict with char glBegin(); below.  */
@@ -11665,7 +11668,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:11669: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11672: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_glBegin=yes"
 else
@@ -11702,10 +11705,10 @@
 echo $ac_n "checking for gluBeginCurve""... $ac_c" 1>&6
-echo "configure:11706: checking for gluBeginCurve" >&5
+echo "configure:11709: checking for gluBeginCurve" >&5
-#line 11709 "configure"
+#line 11712 "configure"
     which can conflict with char gluBeginCurve(); below.  */
@@ -11728,7 +11731,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:11732: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11735: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_gluBeginCurve=yes"
 else
@@ -11776,7 +11779,7 @@
-echo "configure:11780: checking for location of OpenGL includes" >&5
+echo "configure:11783: checking for location of OpenGL includes" >&5
@@ -11802,15 +11805,15 @@
 do
-echo "configure:11806: checking for $ac_hdr" >&5
+echo "configure:11809: checking for $ac_hdr" >&5
-#line 11809 "configure"
+#line 11812 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:11814: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:11817: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -11844,7 +11847,7 @@
-echo "configure:11848: checking for location of OpenGL library" >&5
+echo "configure:11851: checking for location of OpenGL library" >&5
@@ -11869,18 +11872,18 @@
 ac_save_libs="$LIBS"
 echo $ac_n "checking for OpenGL library""... $ac_c" 1>&6
-echo "configure:11873: checking for OpenGL library" >&5
+echo "configure:11876: checking for OpenGL library" >&5
 LDFLAGS="$OPENGL_LIB_PATH $LDFLAGS"
 LIBS="-lopengl32  "
-#line 11877 "configure"
+#line 11880 "configure"
 #include <GL/gl.h>
 int main() {
 glEnd();
 ; return 0; }
 EOF
-if { (eval echo configure:11884: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11887: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 echo "$ac_t""found" 1>&6
@@ -11904,18 +11907,18 @@
 echo $ac_n "checking for GLU library""... $ac_c" 1>&6
-echo "configure:11908: checking for GLU library" >&5
+echo "configure:11911: checking for GLU library" >&5
 LIBS="-lglu32 $OPENGLLIB "
-#line 11912 "configure"
+#line 11915 "configure"
 #include <GL/glu.h>
 int main() {
 gluNewQuadric();
 ; return 0; }
 EOF
-if { (eval echo configure:11919: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11922: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
@@ -11964,7 +11967,7 @@
 echo $ac_n "checking whether to use ODBC""... $ac_c" 1>&6
-echo "configure:11968: checking whether to use ODBC" >&5
+echo "configure:11971: checking whether to use ODBC" >&5
 echo "$ac_t"""$with_odbc"" 1>&6
 case "$with_odbc" in
 	"no")	USE_ODBC=	;;
@@ -11983,7 +11986,7 @@
 echo $ac_n "checking for location of ODBC includes""... $ac_c" 1>&6
-echo "configure:11987: checking for location of ODBC includes" >&5
+echo "configure:11990: checking for location of ODBC includes" >&5
 case "$with_odbc_includes" in
 	{ echo "configure: error: *** You must supply a directory to --with-odbc-includes." 1>&2; exit 1; }
@@ -12009,15 +12012,15 @@
 do
-echo "configure:12013: checking for $ac_hdr" >&5
+echo "configure:12016: checking for $ac_hdr" >&5
-#line 12016 "configure"
+#line 12019 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:12021: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:12024: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -12051,7 +12054,7 @@
 echo $ac_n "checking for location of ODBC library""... $ac_c" 1>&6
-echo "configure:12055: checking for location of ODBC library" >&5
+echo "configure:12058: checking for location of ODBC library" >&5
 case "$with_odbc_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-odbc-libs." 1>&2; exit 1; }
@@ -12076,13 +12079,13 @@
 echo $ac_n "checking for SQLConnect in -lodbc""... $ac_c" 1>&6
-echo "configure:12080: checking for SQLConnect in -lodbc" >&5
+echo "configure:12083: checking for SQLConnect in -lodbc" >&5
 ac_lib_var=`echo odbc'_'SQLConnect | sed 'y%./+-%__p_%'`
 LIBS="-lodbc $ICONVLIB  $LIBS"
-#line 12086 "configure"
+#line 12089 "configure"
@@ -12093,7 +12096,7 @@
 SQLConnect()
 ; return 0; }
 EOF
-if { (eval echo configure:12097: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12100: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -12118,13 +12121,13 @@
 echo $ac_n "checking for SQLConnect in -liodbc""... $ac_c" 1>&6
-echo "configure:12122: checking for SQLConnect in -liodbc" >&5
+echo "configure:12125: checking for SQLConnect in -liodbc" >&5
 ac_lib_var=`echo iodbc'_'SQLConnect | sed 'y%./+-%__p_%'`
 LIBS="-liodbc  $LIBS"
-#line 12128 "configure"
+#line 12131 "configure"
 #include "confdefs.h"
@@ -12135,7 +12138,7 @@
 SQLConnect()
 ; return 0; }
 EOF
-if { (eval echo configure:12139: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12142: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -12160,11 +12163,11 @@
 echo $ac_n "checking for ODBC library""... $ac_c" 1>&6
-echo "configure:12164: checking for ODBC library" >&5
+echo "configure:12167: checking for ODBC library" >&5
 LDFLAGS="$ODBCLIB $LDFLAGS"
 LIBS="-lodbc32  "
-#line 12168 "configure"
+#line 12171 "configure"
 #include <windows.h>
 #include <sql.h>
@@ -12172,7 +12175,7 @@
 SQLAllocEnv((SQLHENV *)0);
 ; return 0; }
 EOF
-if { (eval echo configure:12176: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12179: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
@@ -12221,7 +12224,7 @@
 echo $ac_n "checking whether to use FFTW""... $ac_c" 1>&6
-echo "configure:12225: checking whether to use FFTW" >&5
+echo "configure:12228: checking whether to use FFTW" >&5
 echo "$ac_t"""$with_fftw"" 1>&6
 case "$with_fftw" in
 	"no")	USE_FFTW=	;;
@@ -12240,7 +12243,7 @@
 echo $ac_n "checking for location of FFTW includes""... $ac_c" 1>&6
-echo "configure:12244: checking for location of FFTW includes" >&5
+echo "configure:12247: checking for location of FFTW includes" >&5
 case "$with_fftw_includes" in
 	{ echo "configure: error: *** You must supply a directory to --with-fftw-includes." 1>&2; exit 1; }
@@ -12266,15 +12269,15 @@
 do
-echo "configure:12270: checking for $ac_hdr" >&5
+echo "configure:12273: checking for $ac_hdr" >&5
-#line 12273 "configure"
+#line 12276 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:12278: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:12281: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -12302,15 +12305,15 @@
 do
-echo "configure:12306: checking for $ac_hdr" >&5
+echo "configure:12309: checking for $ac_hdr" >&5
-#line 12309 "configure"
+#line 12312 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:12314: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:12317: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -12338,15 +12341,15 @@
 do
-echo "configure:12342: checking for $ac_hdr" >&5
+echo "configure:12345: checking for $ac_hdr" >&5
 cat > conftest.$ac_ext <<EOF
-#line 12345 "configure"
+#line 12348 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:12350: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:12353: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -12392,7 +12395,7 @@
 echo $ac_n "checking for location of FFTW library""... $ac_c" 1>&6
-echo "configure:12396: checking for location of FFTW library" >&5
+echo "configure:12399: checking for location of FFTW library" >&5
 case "$with_fftw_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-fftw-libs." 1>&2; exit 1; }
@@ -12417,13 +12420,13 @@
 echo $ac_n "checking for fftw_execute in -lfftw3""... $ac_c" 1>&6
-echo "configure:12421: checking for fftw_execute in -lfftw3" >&5
+echo "configure:12424: checking for fftw_execute in -lfftw3" >&5
 ac_lib_var=`echo fftw3'_'fftw_execute | sed 'y%./+-%__p_%'`
 LIBS="-lfftw3 $MATHLIB $LIBS"
-#line 12427 "configure"
+#line 12430 "configure"
@@ -12434,7 +12437,7 @@
 fftw_execute()
 ; return 0; }
 EOF
-if { (eval echo configure:12438: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12441: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -12459,13 +12462,13 @@
 echo $ac_n "checking for fftwnd_one in -lfftw""... $ac_c" 1>&6
-echo "configure:12463: checking for fftwnd_one in -lfftw" >&5
+echo "configure:12466: checking for fftwnd_one in -lfftw" >&5
 ac_lib_var=`echo fftw'_'fftwnd_one | sed 'y%./+-%__p_%'`
 LIBS="-lfftw $MATHLIB $LIBS"
-#line 12469 "configure"
+#line 12472 "configure"
@@ -12476,7 +12479,7 @@
 fftwnd_one()
 ; return 0; }
 EOF
-if { (eval echo configure:12480: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12483: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -12501,13 +12504,13 @@
 echo $ac_n "checking for fftwnd_one in -ldfftw""... $ac_c" 1>&6
-echo "configure:12505: checking for fftwnd_one in -ldfftw" >&5
+echo "configure:12508: checking for fftwnd_one in -ldfftw" >&5
 ac_lib_var=`echo dfftw'_'fftwnd_one | sed 'y%./+-%__p_%'`
 LIBS="-ldfftw $MATHLIB $LIBS"
-#line 12511 "configure"
+#line 12514 "configure"
@@ -12518,7 +12521,7 @@
 fftwnd_one()
 ; return 0; }
 EOF
-if { (eval echo configure:12522: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12525: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -12575,7 +12578,7 @@
 echo $ac_n "checking whether to use BLAS""... $ac_c" 1>&6
-echo "configure:12579: checking whether to use BLAS" >&5
+echo "configure:12582: checking whether to use BLAS" >&5
 echo "$ac_t"""$with_blas"" 1>&6
 case "$with_blas" in
 	"no")	USE_BLAS=	;;
@@ -12596,7 +12599,7 @@
 echo $ac_n "checking for location of BLAS includes""... $ac_c" 1>&6
-echo "configure:12600: checking for location of BLAS includes" >&5
+echo "configure:12603: checking for location of BLAS includes" >&5
 case "$with_blas_includes" in
 	{ echo "configure: error: *** You must supply a directory to --with-blas-includes." 1>&2; exit 1; }
@@ -12616,7 +12619,7 @@
 echo $ac_n "checking for location of BLAS library""... $ac_c" 1>&6
-echo "configure:12620: checking for location of BLAS library" >&5
+echo "configure:12623: checking for location of BLAS library" >&5
 case "$with_blas_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-blas-libs." 1>&2; exit 1; }
@@ -12642,15 +12645,15 @@
 do
-echo "configure:12646: checking for $ac_hdr" >&5
+echo "configure:12649: checking for $ac_hdr" >&5
-#line 12649 "configure"
+#line 12652 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:12654: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:12657: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -12685,13 +12688,13 @@
 echo $ac_n "checking for dnrm2_ in -lblas""... $ac_c" 1>&6
-echo "configure:12689: checking for dnrm2_ in -lblas" >&5
+echo "configure:12692: checking for dnrm2_ in -lblas" >&5
 ac_lib_var=`echo blas'_'dnrm2_ | sed 'y%./+-%__p_%'`
 LIBS="-lblas $MATHLIB  $LIBS"
-#line 12695 "configure"
+#line 12698 "configure"
@@ -12702,7 +12705,7 @@
 dnrm2_()
 ; return 0; }
 EOF
-if { (eval echo configure:12706: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12709: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -12721,13 +12724,13 @@
-echo "configure:12725: checking for dnrm2_ in -lblas" >&5
+echo "configure:12728: checking for dnrm2_ in -lblas" >&5
 LIBS="-lblas $MATHLIB -lg2c $LIBS"
-#line 12731 "configure"
+#line 12734 "configure"
@@ -12738,7 +12741,7 @@
 dnrm2_()
 ; return 0; }
 EOF
-if { (eval echo configure:12742: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12745: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -12782,13 +12785,13 @@
 save_LDFLAGS="$LDFLAGS"
 LDFLAGS="$BLASLIB $LDFLAGS"
 echo $ac_n "checking for ATL_xerbla in -latlas""... $ac_c" 1>&6
-echo "configure:12786: checking for ATL_xerbla in -latlas" >&5
+echo "configure:12789: checking for ATL_xerbla in -latlas" >&5
 ac_lib_var=`echo atlas'_'ATL_xerbla | sed 'y%./+-%__p_%'`
 LIBS="-latlas  $LIBS"
-#line 12792 "configure"
+#line 12795 "configure"
@@ -12799,7 +12802,7 @@
 ATL_xerbla()
 ; return 0; }
 EOF
-if { (eval echo configure:12803: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12806: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -12814,13 +12817,13 @@
 if eval "test \"`echo '$ac_cv_lib_'$ac_lib_var`\" = yes"; then
   echo "$ac_t""yes" 1>&6
   echo $ac_n "checking for sgemm_ in -lf77blas""... $ac_c" 1>&6
-echo "configure:12818: checking for sgemm_ in -lf77blas" >&5
+echo "configure:12821: checking for sgemm_ in -lf77blas" >&5
 ac_lib_var=`echo f77blas'_'sgemm_ | sed 'y%./+-%__p_%'`
 LIBS="-lf77blas -latlas $LIBS"
-#line 12824 "configure"
+#line 12827 "configure"
@@ -12831,7 +12834,7 @@
 sgemm_()
 ; return 0; }
 EOF
-if { (eval echo configure:12835: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12838: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -12846,13 +12849,13 @@
   echo $ac_n "checking for cblas_dgemm in -lcblas""... $ac_c" 1>&6
-echo "configure:12850: checking for cblas_dgemm in -lcblas" >&5
+echo "configure:12853: checking for cblas_dgemm in -lcblas" >&5
 ac_lib_var=`echo cblas'_'cblas_dgemm | sed 'y%./+-%__p_%'`
 LIBS="-lcblas -lf77blas -latlas $LIBS"
-#line 12856 "configure"
+#line 12859 "configure"
@@ -12863,7 +12866,7 @@
 cblas_dgemm()
 ; return 0; }
 EOF
-if { (eval echo configure:12867: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12870: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -12908,16 +12911,16 @@
 	save_LIBS="$LIBS"
 	LIBS="$vlib_flags $LIBS"
 	echo $ac_n "checking for sgemm in $vlib_flags""... $ac_c" 1>&6
-echo "configure:12912: checking for sgemm in $vlib_flags" >&5
+echo "configure:12915: checking for sgemm in $vlib_flags" >&5
-#line 12914 "configure"
+#line 12917 "configure"
 int main() {
 sgemm
 ; return 0; }
 EOF
-if { (eval echo configure:12921: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12924: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   blas_ok=yes; BLASLIB="$vlib_flags"
 else
@@ -12935,13 +12938,13 @@
 # BLAS in PhiPACK libraries? (requires generic BLAS, too)
 if test $blas_ok = no; then
 	echo $ac_n "checking for sgemm_ in -lblas""... $ac_c" 1>&6
-echo "configure:12939: checking for sgemm_ in -lblas" >&5
+echo "configure:12942: checking for sgemm_ in -lblas" >&5
 ac_lib_var=`echo blas'_'sgemm_ | sed 'y%./+-%__p_%'`
 ac_save_LIBS="$LIBS"
 LIBS="-lblas  $LIBS"
-#line 12945 "configure"
+#line 12948 "configure"
 /* Override any gcc2 internal prototype to avoid an error.  */
 /* We use char because int might match the return type of a gcc2
@@ -12952,7 +12955,7 @@
 sgemm_()
 ; return 0; }
 EOF
-if { (eval echo configure:12956: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12959: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_lib_$ac_lib_var=yes"
 else
@@ -12967,13 +12970,13 @@
   echo $ac_n "checking for dgemm_ in -ldgemm""... $ac_c" 1>&6
-echo "configure:12971: checking for dgemm_ in -ldgemm" >&5
+echo "configure:12974: checking for dgemm_ in -ldgemm" >&5
 ac_lib_var=`echo dgemm'_'dgemm_ | sed 'y%./+-%__p_%'`
 LIBS="-ldgemm -lblas $LIBS"
-#line 12977 "configure"
+#line 12980 "configure"
@@ -12984,7 +12987,7 @@
 dgemm_()
 ; return 0; }
 EOF
-if { (eval echo configure:12988: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12991: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -12999,13 +13002,13 @@
   echo $ac_n "checking for sgemm_ in -lsgemm""... $ac_c" 1>&6
-echo "configure:13003: checking for sgemm_ in -lsgemm" >&5
+echo "configure:13006: checking for sgemm_ in -lsgemm" >&5
 ac_lib_var=`echo sgemm'_'sgemm_ | sed 'y%./+-%__p_%'`
 LIBS="-lsgemm -lblas $LIBS"
-#line 13009 "configure"
+#line 13012 "configure"
@@ -13016,7 +13019,7 @@
 sgemm_()
 ; return 0; }
 EOF
-if { (eval echo configure:13020: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13023: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -13050,13 +13053,13 @@
 	if test "x$GCC" != xyes; then # only works with Sun CC
 		echo $ac_n "checking for acosp in -lsunmath""... $ac_c" 1>&6
-echo "configure:13054: checking for acosp in -lsunmath" >&5
+echo "configure:13057: checking for acosp in -lsunmath" >&5
 ac_lib_var=`echo sunmath'_'acosp | sed 'y%./+-%__p_%'`
 LIBS="-lsunmath  $LIBS"
-#line 13060 "configure"
+#line 13063 "configure"
@@ -13067,7 +13070,7 @@
 acosp()
 ; return 0; }
 EOF
-if { (eval echo configure:13071: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13074: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -13082,13 +13085,13 @@
   echo $ac_n "checking for sgemm_ in -lsunperf""... $ac_c" 1>&6
-echo "configure:13086: checking for sgemm_ in -lsunperf" >&5
+echo "configure:13089: checking for sgemm_ in -lsunperf" >&5
 ac_lib_var=`echo sunperf'_'sgemm_ | sed 'y%./+-%__p_%'`
 LIBS="-lsunperf -lsunmath $LIBS"
-#line 13092 "configure"
+#line 13095 "configure"
@@ -13099,7 +13102,7 @@
 sgemm_()
 ; return 0; }
 EOF
-if { (eval echo configure:13103: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13106: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -13129,13 +13132,13 @@
 # Generic BLAS library
-echo "configure:13133: checking for sgemm_ in -lblas" >&5
+echo "configure:13136: checking for sgemm_ in -lblas" >&5
 LIBS="-lblas  $LIBS"
-#line 13139 "configure"
+#line 13142 "configure"
@@ -13146,7 +13149,7 @@
 sgemm_()
 ; return 0; }
 EOF
-if { (eval echo configure:13150: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13153: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -13185,7 +13188,7 @@
 echo $ac_n "checking whether to use LAPACK""... $ac_c" 1>&6
-echo "configure:13189: checking whether to use LAPACK" >&5
+echo "configure:13192: checking whether to use LAPACK" >&5
 echo "$ac_t"""$with_lapack"" 1>&6
 case "$with_lapack" in
 	"no")	USE_LAPACK=	;;
@@ -13210,7 +13213,7 @@
 echo $ac_n "checking for location of LAPACK includes""... $ac_c" 1>&6
-echo "configure:13214: checking for location of LAPACK includes" >&5
+echo "configure:13217: checking for location of LAPACK includes" >&5
 case "$with_lapack_includes" in
 	{ echo "configure: error: *** You must supply a directory to --with-lapack-includes." 1>&2; exit 1; }
@@ -13230,7 +13233,7 @@
 echo $ac_n "checking for location of LAPACK library""... $ac_c" 1>&6
-echo "configure:13234: checking for location of LAPACK library" >&5
+echo "configure:13237: checking for location of LAPACK library" >&5
 case "$with_lapack_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-lapack-libs." 1>&2; exit 1; }
@@ -13256,15 +13259,15 @@
 do
-echo "configure:13260: checking for $ac_hdr" >&5
+echo "configure:13263: checking for $ac_hdr" >&5
-#line 13263 "configure"
+#line 13266 "configure"
 #include <$ac_hdr>
 EOF
 ac_try="$ac_cpp conftest.$ac_ext >/dev/null 2>conftest.out"
-{ (eval echo configure:13268: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:13271: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
 ac_err=`grep -v '^ *+' conftest.out | grep -v "^conftest.${ac_ext}\$"`
 if test -z "$ac_err"; then
   rm -rf conftest*
@@ -13296,10 +13299,10 @@
 	save_LIBS="$LIBS"; LIBS="$LIBS $BLASLIB $MATHLIB $FLIBS"
 	save_LDFLAGS="$LDFLAGS"; LDFLAGS="$LAPACKLIB $LDFLAGS"
 	echo $ac_n "checking for dsegv_""... $ac_c" 1>&6
-echo "configure:13300: checking for dsegv_" >&5
+echo "configure:13303: checking for dsegv_" >&5
-#line 13303 "configure"
+#line 13306 "configure"
     which can conflict with char dsegv_(); below.  */
@@ -13322,7 +13325,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:13326: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13329: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_dsegv_=yes"
 else
@@ -13349,13 +13352,13 @@
 	save_libs="$LIBS"; LIBS="$BLASLIB $MATHLIB $LIBS"
 	echo $ac_n "checking for desgv_ in -llapack""... $ac_c" 1>&6
-echo "configure:13353: checking for desgv_ in -llapack" >&5
+echo "configure:13356: checking for desgv_ in -llapack" >&5
 ac_lib_var=`echo lapack'_'desgv_ | sed 'y%./+-%__p_%'`
 LIBS="-llapack $FLIBS $LIBS"
-#line 13359 "configure"
+#line 13362 "configure"
@@ -13366,7 +13369,7 @@
 desgv_()
 ; return 0; }
 EOF
-if { (eval echo configure:13370: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13373: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -13398,13 +13401,13 @@
 echo $ac_n "checking for dgesv_ in -llapack""... $ac_c" 1>&6
-echo "configure:13402: checking for dgesv_ in -llapack" >&5
+echo "configure:13405: checking for dgesv_ in -llapack" >&5
 ac_lib_var=`echo lapack'_'dgesv_ | sed 'y%./+-%__p_%'`
 LIBS="-llapack $BLASLIB $MATHLIB  $LIBS"
-#line 13408 "configure"
+#line 13411 "configure"
@@ -13415,7 +13418,7 @@
 dgesv_()
 ; return 0; }
 EOF
-if { (eval echo configure:13419: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13422: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -13434,13 +13437,13 @@
-echo "configure:13438: checking for dgesv_ in -llapack" >&5
+echo "configure:13441: checking for dgesv_ in -llapack" >&5
 LIBS="-llapack $BLASLIB $MATHLIB -lg2c $LIBS"
-#line 13444 "configure"
+#line 13447 "configure"
@@ -13451,7 +13454,7 @@
 dgesv_()
 ; return 0; }
 EOF
-if { (eval echo configure:13455: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13458: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -13507,7 +13510,7 @@
 echo $ac_n "checking whether to use Cairo""... $ac_c" 1>&6
-echo "configure:13511: checking whether to use Cairo" >&5
+echo "configure:13514: checking whether to use Cairo" >&5
 echo "$ac_t"""$with_cairo"" 1>&6
 case "$with_cairo" in
 	"no")	USE_CAIRO=	;;
@@ -13533,7 +13536,7 @@
 echo $ac_n "checking for location of cairo includes""... $ac_c" 1>&6
-echo "configure:13537: checking for location of cairo includes" >&5
+echo "configure:13540: checking for location of cairo includes" >&5
 case "$with_cairo_includes" in
 	{ echo "configure: error: *** You must supply a directory to --with-cairo-includes." 1>&2; exit 1; }
@@ -13559,15 +13562,15 @@
 do
-echo "configure:13563: checking for $ac_hdr" >&5
+echo "configure:13566: checking for $ac_hdr" >&5
-#line 13566 "configure"
+#line 13569 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:13571: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:13574: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -13603,7 +13606,7 @@
 echo $ac_n "checking for location of cairo library""... $ac_c" 1>&6
-echo "configure:13607: checking for location of cairo library" >&5
+echo "configure:13610: checking for location of cairo library" >&5
 case "$with_cairo_libs" in
 y | ye | yes | n | no)
 	{ echo "configure: error: *** You must supply a directory to --with-cairo-libs." 1>&2; exit 1; }
@@ -13623,7 +13626,7 @@
 echo $ac_n "checking for cairo linking flags""... $ac_c" 1>&6
-echo "configure:13627: checking for cairo linking flags" >&5
+echo "configure:13630: checking for cairo linking flags" >&5
 case "$with_cairo_ldflags" in
 	{ echo "configure: error: *** You must supply a directory to --with-cairo-ldflags." 1>&2; exit 1; }
@@ -13639,10 +13642,10 @@
 LIBS=" $CAIROLIB $LIBS"
 LDFLAGS=" $LDFLAGS"
 echo $ac_n "checking for cairo_create""... $ac_c" 1>&6
-echo "configure:13643: checking for cairo_create" >&5
+echo "configure:13646: checking for cairo_create" >&5
-#line 13646 "configure"
+#line 13649 "configure"
     which can conflict with char cairo_create(); below.  */
@@ -13665,7 +13668,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:13669: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13672: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_cairo_create=yes"
 else
@@ -13699,10 +13702,10 @@
 LDFLAGS=" $LDFLAGS"
 echo $ac_n "checking for cairo_xlib_surface_create_with_xrender_format""... $ac_c" 1>&6
-echo "configure:13703: checking for cairo_xlib_surface_create_with_xrender_format" >&5
+echo "configure:13706: checking for cairo_xlib_surface_create_with_xrender_format" >&5
-#line 13706 "configure"
+#line 13709 "configure"
     which can conflict with char cairo_xlib_surface_create_with_xrender_format(); below.  */
@@ -13725,7 +13728,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:13729: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13732: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_cairo_xlib_surface_create_with_xrender_format=yes"
 else
@@ -13758,10 +13761,10 @@
 LDFLAGS=" $LDFLAGS"
 echo $ac_n "checking for cairo_xlib_surface_get_xrender_format""... $ac_c" 1>&6
-echo "configure:13762: checking for cairo_xlib_surface_get_xrender_format" >&5
+echo "configure:13765: checking for cairo_xlib_surface_get_xrender_format" >&5
-#line 13765 "configure"
+#line 13768 "configure"
     which can conflict with char cairo_xlib_surface_get_xrender_format(); below.  */
@@ -13784,7 +13787,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:13788: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13791: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_cairo_xlib_surface_get_xrender_format=yes"
 else
@@ -13826,7 +13829,7 @@
 echo $ac_n "checking whether to use FreeType""... $ac_c" 1>&6
-echo "configure:13830: checking whether to use FreeType" >&5
+echo "configure:13833: checking whether to use FreeType" >&5
 echo "$ac_t"""$with_freetype"" 1>&6
 case "$with_freetype" in
 	"no")	USE_FREETYPE=	;;
@@ -13845,7 +13848,7 @@
 echo $ac_n "checking for location of FreeType includes""... $ac_c" 1>&6
-echo "configure:13849: checking for location of FreeType includes" >&5
+echo "configure:13852: checking for location of FreeType includes" >&5
 case "$with_freetype_includes" in
 	{ echo "configure: error: *** You must supply a directory to --with-freetype-includes." 1>&2; exit 1; }
@@ -13871,15 +13874,15 @@
 do
-echo "configure:13875: checking for $ac_hdr" >&5
+echo "configure:13878: checking for $ac_hdr" >&5
-#line 13878 "configure"
+#line 13881 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:13883: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:13886: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -13913,7 +13916,7 @@
 echo $ac_n "checking for location of FreeType library""... $ac_c" 1>&6
-echo "configure:13917: checking for location of FreeType library" >&5
+echo "configure:13920: checking for location of FreeType library" >&5
 case "$with_freetype_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-freetype-libs." 1>&2; exit 1; }
@@ -13938,13 +13941,13 @@
 echo $ac_n "checking for FT_Init_FreeType in -lfreetype""... $ac_c" 1>&6
-echo "configure:13942: checking for FT_Init_FreeType in -lfreetype" >&5
+echo "configure:13945: checking for FT_Init_FreeType in -lfreetype" >&5
 ac_lib_var=`echo freetype'_'FT_Init_FreeType | sed 'y%./+-%__p_%'`
 LIBS="-lfreetype  $LIBS"
-#line 13948 "configure"
+#line 13951 "configure"
@@ -13955,7 +13958,7 @@
 FT_Init_FreeType()
 ; return 0; }
 EOF
-if { (eval echo configure:13959: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13962: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -13996,7 +13999,7 @@
 echo $ac_n "checking whether to use NLS""... $ac_c" 1>&6
-echo "configure:14000: checking whether to use NLS" >&5
+echo "configure:14003: checking whether to use NLS" >&5
 echo "$ac_t"""$with_nls"" 1>&6
 case "$with_nls" in
 	"no")	USE_NLS=	;;
@@ -14016,10 +14019,10 @@
 echo $ac_n "checking for gettext""... $ac_c" 1>&6
-echo "configure:14020: checking for gettext" >&5
+echo "configure:14023: checking for gettext" >&5
-#line 14023 "configure"
+#line 14026 "configure"
     which can conflict with char gettext(); below.  */
@@ -14042,7 +14045,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:14046: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:14049: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_gettext=yes"
 else
@@ -14060,13 +14063,13 @@
 echo $ac_n "checking for gettext in -lintl""... $ac_c" 1>&6
-echo "configure:14064: checking for gettext in -lintl" >&5
+echo "configure:14067: checking for gettext in -lintl" >&5
 ac_lib_var=`echo intl'_'gettext | sed 'y%./+-%__p_%'`
 LIBS="-lintl  $LIBS"
-#line 14070 "configure"
+#line 14073 "configure"
@@ -14077,7 +14080,7 @@
 gettext()
 ; return 0; }
 EOF
-if { (eval echo configure:14081: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:14084: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -14112,7 +14115,7 @@
 echo $ac_n "checking whether to use C++""... $ac_c" 1>&6
-echo "configure:14116: checking whether to use C++" >&5
+echo "configure:14119: checking whether to use C++" >&5
 echo "$ac_t"""$with_cxx"" 1>&6
 case "$with_cxx" in
 	"no")	USE_CXX=	;;
@@ -14128,7 +14131,7 @@
 # Extract the first word of "$ac_prog", so it can be a program name with args.
 set dummy $ac_prog; ac_word=$2
 echo $ac_n "checking for $ac_word""... $ac_c" 1>&6
-echo "configure:14132: checking for $ac_word" >&5
+echo "configure:14135: checking for $ac_word" >&5
 if test -n "$CXX"; then
   ac_cv_prog_CXX="$CXX" # Let the user override the test.
@@ -14157,7 +14160,7 @@
 echo $ac_n "checking whether the C++ compiler ($CXX $CXXFLAGS $LDFLAGS) works""... $ac_c" 1>&6
-echo "configure:14161: checking whether the C++ compiler ($CXX $CXXFLAGS $LDFLAGS) works" >&5
+echo "configure:14164: checking whether the C++ compiler ($CXX $CXXFLAGS $LDFLAGS) works" >&5
 ac_ext=C
 # CXXFLAGS is not in ac_cpp because -g, -O, etc. are not valid cpp options.
@@ -14168,12 +14171,12 @@
 cat > conftest.$ac_ext << EOF
-#line 14172 "configure"
+#line 14175 "configure"
 int main(){return(0);}
 EOF
-if { (eval echo configure:14177: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:14180: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   ac_cv_prog_cxx_works=yes
   # If we can't run a trivial program, we are probably using a cross compiler.
   if (./conftest; exit) 2>/dev/null; then
@@ -14199,19 +14202,19 @@
   { echo "configure: error: installation or configuration problem: C++ compiler cannot create executables." 1>&2; exit 1; }
 fi
 echo $ac_n "checking whether the C++ compiler ($CXX $CXXFLAGS $LDFLAGS) is a cross-compiler""... $ac_c" 1>&6
-echo "configure:14203: checking whether the C++ compiler ($CXX $CXXFLAGS $LDFLAGS) is a cross-compiler" >&5
+echo "configure:14206: checking whether the C++ compiler ($CXX $CXXFLAGS $LDFLAGS) is a cross-compiler" >&5
 echo "$ac_t""$ac_cv_prog_cxx_cross" 1>&6
 cross_compiling=$ac_cv_prog_cxx_cross
 echo $ac_n "checking whether we are using GNU C++""... $ac_c" 1>&6
-echo "configure:14208: checking whether we are using GNU C++" >&5
+echo "configure:14211: checking whether we are using GNU C++" >&5
 cat > conftest.C <<EOF
 #ifdef __GNUC__
   yes;
 #endif
 EOF
-if { ac_try='${CXX-g++} -E conftest.C'; { (eval echo configure:14215: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }; } | egrep yes >/dev/null 2>&1; then
+if { ac_try='${CXX-g++} -E conftest.C'; { (eval echo configure:14218: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }; } | egrep yes >/dev/null 2>&1; then
   ac_cv_prog_gxx=yes
 else
   ac_cv_prog_gxx=no
@@ -14229,7 +14232,7 @@
 ac_save_CXXFLAGS="$CXXFLAGS"
 CXXFLAGS=
 echo $ac_n "checking whether ${CXX-g++} accepts -g""... $ac_c" 1>&6
-echo "configure:14233: checking whether ${CXX-g++} accepts -g" >&5
+echo "configure:14236: checking whether ${CXX-g++} accepts -g" >&5
 echo 'void f(){}' > conftest.cc
 if test -z "`${CXX-g++} -g -c conftest.cc 2>&1`"; then
@@ -14270,7 +14273,7 @@
 echo $ac_n "checking whether to use openDWG""... $ac_c" 1>&6
-echo "configure:14274: checking whether to use openDWG" >&5
+echo "configure:14277: checking whether to use openDWG" >&5
 echo "$ac_t"""$with_opendwg"" 1>&6
 case "$with_opendwg" in
 	"no")	USE_OPENDWG=	;;
@@ -14290,7 +14293,7 @@
 echo $ac_n "checking for location of openDGW includes""... $ac_c" 1>&6
-echo "configure:14294: checking for location of openDGW includes" >&5
+echo "configure:14297: checking for location of openDGW includes" >&5
 case "$with_opendwg_includes" in
 	{ echo "configure: error: *** You must supply a directory to --with-opendwg-includes." 1>&2; exit 1; }
@@ -14316,15 +14319,15 @@
 do
 ac_safe=`echo "$ac_hdr" | sed 'y%./+-%__p_%'`
 echo $ac_n "checking for $ac_hdr""... $ac_c" 1>&6
-echo "configure:14320: checking for $ac_hdr" >&5
+echo "configure:14323: checking for $ac_hdr" >&5
-#line 14323 "configure"
+#line 14326 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:14328: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:14331: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -14358,7 +14361,7 @@
 echo $ac_n "checking for location of openDWG library""... $ac_c" 1>&6
-echo "configure:14362: checking for location of openDWG library" >&5
+echo "configure:14365: checking for location of openDWG library" >&5
 case "$with_opendwg_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-opendwg-libs." 1>&2; exit 1; }
@@ -14399,7 +14402,7 @@
 echo $ac_n "checking whether to use POSIX threads""... $ac_c" 1>&6
-echo "configure:14403: checking whether to use POSIX threads" >&5
+echo "configure:14406: checking whether to use POSIX threads" >&5
 echo "$ac_t"""$with_pthread"" 1>&6
 case "$with_pthread" in
 	"no")	USE_PTHREAD=	;;
@@ -14419,7 +14422,7 @@
 echo $ac_n "checking for location of POSIX threads includes""... $ac_c" 1>&6
-echo "configure:14423: checking for location of POSIX threads includes" >&5
+echo "configure:14426: checking for location of POSIX threads includes" >&5
 case "$with_pthread_includes" in
 	{ echo "configure: error: *** You must supply a directory to --with-pthread-includes." 1>&2; exit 1; }
@@ -14445,15 +14448,15 @@
 do
-echo "configure:14449: checking for $ac_hdr" >&5
+echo "configure:14452: checking for $ac_hdr" >&5
-#line 14452 "configure"
+#line 14455 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:14457: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:14460: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -14487,7 +14490,7 @@
 echo $ac_n "checking for location of POSIX threads library""... $ac_c" 1>&6
-echo "configure:14491: checking for location of POSIX threads library" >&5
+echo "configure:14494: checking for location of POSIX threads library" >&5
 case "$with_pthread_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-pthread-libs." 1>&2; exit 1; }
@@ -14512,10 +14515,10 @@
 LIBS="  $LIBS"
 LDFLAGS=" $LDFLAGS"
 echo $ac_n "checking for pthread_create""... $ac_c" 1>&6
-echo "configure:14516: checking for pthread_create" >&5
+echo "configure:14519: checking for pthread_create" >&5
-#line 14519 "configure"
+#line 14522 "configure"
     which can conflict with char pthread_create(); below.  */
@@ -14538,7 +14541,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:14542: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:14545: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_pthread_create=yes"
 else
@@ -14565,13 +14568,13 @@
 echo $ac_n "checking for pthread_create in -lpthread""... $ac_c" 1>&6
-echo "configure:14569: checking for pthread_create in -lpthread" >&5
+echo "configure:14572: checking for pthread_create in -lpthread" >&5
 ac_lib_var=`echo pthread'_'pthread_create | sed 'y%./+-%__p_%'`
 LIBS="-lpthread  $LIBS"
-#line 14575 "configure"
+#line 14578 "configure"
@@ -14582,7 +14585,7 @@
 pthread_create()
 ; return 0; }
 EOF
-if { (eval echo configure:14586: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:14589: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -14638,7 +14641,7 @@
    if test "$enable_largefile" = yes; then
      echo $ac_n "checking for special C compiler options needed for large files""... $ac_c" 1>&6
-echo "configure:14642: checking for special C compiler options needed for large files" >&5
+echo "configure:14645: checking for special C compiler options needed for large files" >&5
 ac_cv_sys_largefile_CC=no
         largefile_cc_opt=""
@@ -14646,7 +14649,7 @@
 	  # IRIX 6.2 and later do not support large files by default,
 	  # so use the C compiler's -n32 option if that helps.
-#line 14650 "configure"
+#line 14653 "configure"
 #include <sys/types.h>
     /* Check that off_t can represent 2**63 - 1 correctly.
@@ -14662,7 +14665,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:14666: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:14669: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
 else
   echo "configure: failed program was:" >&5
@@ -14671,7 +14674,7 @@
   ac_save_CC="${CC-cc}"
 	     CC="$CC -n32"
-#line 14675 "configure"
+#line 14678 "configure"
@@ -14687,7 +14690,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:14691: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:14694: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
   rm -rf conftest*
   ac_cv_sys_largefile_CC=' -n32'
 else
@@ -14707,11 +14710,11 @@
      fi
      echo $ac_n "checking for _FILE_OFFSET_BITS value needed for large files""... $ac_c" 1>&6
-echo "configure:14711: checking for _FILE_OFFSET_BITS value needed for large files" >&5
+echo "configure:14714: checking for _FILE_OFFSET_BITS value needed for large files" >&5
 ac_cv_sys_file_offset_bits=no
-#line 14715 "configure"
+#line 14718 "configure"
@@ -14727,14 +14730,14 @@
 ; return 0; }
 EOF
-if { (eval echo configure:14731: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:14734: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
 else
   cat conftest.$ac_ext >&5
   rm -rf conftest*
-#line 14738 "configure"
+#line 14741 "configure"
 #define _FILE_OFFSET_BITS 64
@@ -14752,7 +14755,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:14756: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:14759: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
   rm -rf conftest*
   ac_cv_sys_file_offset_bits=64
 else
@@ -14771,11 +14774,11 @@
    fi
      echo $ac_n "checking for _LARGE_FILES value needed for large files""... $ac_c" 1>&6
-echo "configure:14775: checking for _LARGE_FILES value needed for large files" >&5
+echo "configure:14778: checking for _LARGE_FILES value needed for large files" >&5
 ac_cv_sys_large_files=no
-#line 14779 "configure"
+#line 14782 "configure"
@@ -14791,14 +14794,14 @@
 ; return 0; }
 EOF
-if { (eval echo configure:14795: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:14798: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
 else
   rm -rf conftest*
-#line 14802 "configure"
+#line 14805 "configure"
 #define _LARGE_FILES 1
@@ -14816,7 +14819,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:14820: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:14823: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
   rm -rf conftest*
   ac_cv_sys_large_files=1
 else
@@ -14835,25 +14838,25 @@
    fi
      echo $ac_n "checking for _LARGEFILE_SOURCE value needed for large files""... $ac_c" 1>&6
-echo "configure:14839: checking for _LARGEFILE_SOURCE value needed for large files" >&5
+echo "configure:14842: checking for _LARGEFILE_SOURCE value needed for large files" >&5
 ac_cv_sys_largefile_source=no
-#line 14843 "configure"
+#line 14846 "configure"
 #include <stdio.h>
 int main() {
 return !fseeko;
 ; return 0; }
 EOF
-if { (eval echo configure:14850: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:14853: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
 else
   rm -rf conftest*
-#line 14857 "configure"
+#line 14860 "configure"
 #define _LARGEFILE_SOURCE 1
 #include <stdio.h>
@@ -14862,7 +14865,7 @@
 return !fseeko;
 ; return 0; }
 EOF
-if { (eval echo configure:14866: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:14869: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
   rm -rf conftest*
   ac_cv_sys_largefile_source=1
 else
@@ -14883,10 +14886,10 @@
    fi
 echo $ac_n "checking if system supports Large Files at all""... $ac_c" 1>&6
-echo "configure:14887: checking if system supports Large Files at all" >&5
+echo "configure:14890: checking if system supports Large Files at all" >&5
-#line 14890 "configure"
+#line 14893 "configure"
 #include <stdio.h>
@@ -14918,7 +14921,7 @@
 #endif
 ; return 0; }
 EOF
-if { (eval echo configure:14922: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:14925: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
   rm -rf conftest*
   ac_cv_largefiles=yes
 else
@@ -14947,7 +14950,7 @@
 # Python check
 echo $ac_n "checking whether to use Python""... $ac_c" 1>&6
-echo "configure:14951: checking whether to use Python" >&5
+echo "configure:14954: checking whether to use Python" >&5
 PYTHONINC=
 PYTHONCFLAGS=
@@ -14967,7 +14970,7 @@
   # Extract the first word of "python-config", so it can be a program name with args.
 set dummy python-config; ac_word=$2
-echo "configure:14971: checking for $ac_word" >&5
+echo "configure:14974: checking for $ac_word" >&5
 case "$PY_CONFIG" in
@@ -15012,15 +15015,15 @@
 do
-echo "configure:15016: checking for $ac_hdr" >&5
+echo "configure:15019: checking for $ac_hdr" >&5
-#line 15019 "configure"
+#line 15022 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:15024: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:15027: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -15060,7 +15063,7 @@
   # Extract the first word of "swig", so it can be a program name with args.
 set dummy swig; ac_word=$2
-echo "configure:15064: checking for $ac_word" >&5
+echo "configure:15067: checking for $ac_word" >&5
 case "$SWIG" in
@@ -15106,7 +15109,7 @@
 # Enable wxWidgets support (for wxGUI)
 echo $ac_n "checking whether to use wxWidgets""... $ac_c" 1>&6
-echo "configure:15110: checking whether to use wxWidgets" >&5
+echo "configure:15113: checking whether to use wxWidgets" >&5
 WXVERSION=
 WXWIDGETSCXXFLAGS=
@@ -15119,14 +15122,14 @@
 else
   USE_WXWIDGETS="1"
-  if test "`basename $with_wxwidgets`" != "yes" ; then
+  if test "$with_wxwidgets" != "yes" ; then
     WX_CONFIG="$with_wxwidgets"
   fi
   # Extract the first word of "wx-config", so it can be a program name with args.
 set dummy wx-config; ac_word=$2
-echo "configure:15130: checking for $ac_word" >&5
+echo "configure:15133: checking for $ac_word" >&5
 case "$WX_CONFIG" in
@@ -15174,7 +15177,7 @@
  REQWX="2.8.1"
  echo $ac_n "checking wxWidgets version""... $ac_c" 1>&6
-echo "configure:15178: checking wxWidgets version" >&5
+echo "configure:15181: checking wxWidgets version" >&5
  if WXVERSION=`"$WX_CONFIG" --version`; then
    echo "$ac_t""$WXVERSION" 1>&6
  else
@@ -15197,15 +15200,15 @@
 do
-echo "configure:15201: checking for $ac_hdr" >&5
+echo "configure:15204: checking for $ac_hdr" >&5
-#line 15204 "configure"
+#line 15207 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:15209: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:15212: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
Modified: grass/trunk/configure.in
--- grass/trunk/configure.in	2009-05-03 04:39:50 UTC (rev 36954)
+++ grass/trunk/configure.in	2009-05-03 04:45:05 UTC (rev 36955)
@@ -196,19 +196,22 @@
 LOC_ARG_WITH(opendwg, openDWG, no)
 LOC_ARG_WITH(regex, regex)
 LOC_ARG_WITH(pthread, POSIX threads, no)
+AC_ARG_WITH(gdal,
+[  --with-gdal[=path/gdal-config] enable GDAL/OGR support (gdal-config with path, \
+e.g. '--with-gdal=/usr/local/bin/gdal-config')])
 AC_ARG_WITH(python,
-[  --with-python[=path/python-config] enable support for Python SWIG bindings (python-config with path, \
-e.g. '--with-python=/usr/bin/python2.5-config', default: no)],, with_python="no")
+[  --with-python[=path/python-config] enable support for Python SWIG bindings \
+(python-config with path, e.g. '--with-python=/usr/bin/python2.5-config', \
+default: no)],, with_python="no")
 AC_ARG_WITH(wxwidgets,
 [  --with-wxwidgets[=path/wx-config] enable wxWidgets support (wx-config with path, \
 e.g. '--with-wxwidgets=/usr/local/bin/wx-config', default: no)],, with_wxwidgets="no")
 # With includes and libs options
-AC_ARG_WITH(gdal,
-[  --with-gdal[=path/gdal-config] enable GDAL/OGR support (gdal-config with path, \
-e.g. '--with-gdal=/usr/local/bin/gdal-config')])
 AC_ARG_WITH(geos,
 [  --with-geos[=path/geos-config] enable GEOS support (geos-config with path, \
 e.g. '--with-geos=/usr/local/bin/geos-config', default: no)],, with_geos="no")
@@ -1691,7 +1694,7 @@
 else
   AC_MSG_RESULT(yes)
   USE_WXWIDGETS="1"
   fi
