[GRASS-SVN] r36977 - grass/trunk/raster/r.resamp.rst
svn_grass at osgeo.org
Mon May 4 10:37:15 EDT 2009
Author: martinl
Date: 2009-05-04 10:37:15 -0400 (Mon, 04 May 2009)
New Revision: 36977
grass/trunk/raster/r.resamp.rst/main.c
r.resamp.rst: move 'elev' to output options
(merge from devbr6, r36975)
Modified: grass/trunk/raster/r.resamp.rst/main.c
--- grass/trunk/raster/r.resamp.rst/main.c 2009-05-04 14:35:35 UTC (rev 36976)
+++ grass/trunk/raster/r.resamp.rst/main.c 2009-05-04 14:37:15 UTC (rev 36977)
@@ -151,12 +151,7 @@
"different resolution) using regularized spline with "
"tension and smoothing.");
- parm.input = G_define_option();
- parm.input->key = "input";
- parm.input->type = TYPE_STRING;
- parm.input->required = YES;
- parm.input->gisprompt = "old,cell,raster";
- parm.input->description = _("Name of input raster map");
+ parm.input = G_define_standard_option(G_OPT_R_INPUT);
parm.res_ew = G_define_option();
parm.res_ew->key = "ew_res";
@@ -176,6 +171,7 @@
parm.elev->required = NO;
parm.elev->gisprompt = "new,cell,raster";
parm.elev->description = _("Output z-file (elevation) map");
+ parm.elev->guisection = _("Output");
parm.slope = G_define_option();
parm.slope->key = "slope";
@@ -183,7 +179,7 @@
parm.slope->required = NO;
parm.slope->gisprompt = "new,cell,raster";
parm.slope->description = _("Output slope map (or fx)");
- parm.slope->guisection = _("Output_options");
+ parm.slope->guisection = _("Output");
parm.aspect = G_define_option();
parm.aspect->key = "aspect";
@@ -191,7 +187,7 @@
parm.aspect->required = NO;
parm.aspect->gisprompt = "new,cell,raster";
parm.aspect->description = _("Output aspect map (or fy)");
- parm.aspect->guisection = _("Output_options");
+ parm.aspect->guisection = _("Output");
parm.pcurv = G_define_option();
parm.pcurv->key = "pcurv";
@@ -199,7 +195,7 @@
parm.pcurv->required = NO;
parm.pcurv->gisprompt = "new,cell,raster";
parm.pcurv->description = _("Output profile curvature map (or fxx)");
- parm.pcurv->guisection = _("Output_options");
+ parm.pcurv->guisection = _("Output");
parm.tcurv = G_define_option();
parm.tcurv->key = "tcurv";
@@ -207,7 +203,7 @@
parm.tcurv->required = NO;
parm.tcurv->gisprompt = "new,cell,raster";
parm.tcurv->description = _("Output tangential curvature map (or fyy)");
- parm.tcurv->guisection = _("Output_options");
+ parm.tcurv->guisection = _("Output");
parm.mcurv = G_define_option();
parm.mcurv->key = "mcurv";
@@ -215,7 +211,7 @@
parm.mcurv->required = NO;
parm.mcurv->gisprompt = "new,cell,raster";
parm.mcurv->description = _("Output mean curvature map (or fxy)");
- parm.mcurv->guisection = _("Output_options");
+ parm.mcurv->guisection = _("Output");
parm.smooth = G_define_option();
parm.smooth->key = "smooth";
@@ -279,7 +275,7 @@
flag.deriv->key = 'd';
flag.deriv->description =
_("Output partial derivatives instead of topographic parameters");
- flag.deriv->guisection = _("Output_options");
+ flag.deriv->guisection = _("Output");
if (G_parser(argc, argv))
exit(EXIT_FAILURE);
