[GRASS-SVN] r36993 - grass/trunk/gui/wxpython/gui_modules
Mon May 4 14:02:27 EDT 2009
Author: martinl
Date: 2009-05-04 14:02:27 -0400 (Mon, 04 May 2009)
New Revision: 36993
   grass/trunk/gui/wxpython/gui_modules/menuform.py
wxGUI: run UpdateSelection() in the thread
Modified: grass/trunk/gui/wxpython/gui_modules/menuform.py
--- grass/trunk/gui/wxpython/gui_modules/menuform.py	2009-05-04 16:46:39 UTC (rev 36992)
+++ grass/trunk/gui/wxpython/gui_modules/menuform.py	2009-05-04 18:02:27 UTC (rev 36993)
@@ -43,7 +43,7 @@
 @todo
  - verify option value types
- - use DOM instead of SAX
+ - use DOM instead of SAX (is it really necessary? ML)
 import sys
@@ -54,6 +54,7 @@
 import time
 import copy
 import locale
+from threading import Thread
 ### i18N
 import gettext
@@ -64,11 +65,11 @@
     globalvar.CheckForWx()
 import wx
+import wx.html
 import wx.lib.flatnotebook as FN
 import wx.lib.colourselect as csel
 import wx.lib.filebrowsebutton as filebrowse
 from wx.lib.expando import ExpandoTextCtrl, EVT_ETC_LAYOUT_NEEDED
-import wx.html
 # Do the python 2.0 standard xml thing and map it on the old names
 import xml.sax
@@ -161,6 +162,107 @@
     """Escapes ampersands with additional ampersand for GUI"""
     return string.replace(text, "&", "&&")
+class UpdateThread(Thread):
+    """Update dialog widgets in the thread"""
+    def __init__(self, parent, eventId, task):
+        Thread.__init__(self)
+        self.parent = parent
+        self.eventId = eventId
+        self.task = task
+        self.setDaemon(True)
+        self.start()
+    def run(self):
+        # get widget id
+        if not self.eventId:
+            for p in self.task.params:
+                if p.get('gisprompt', False) == False:
+                    continue
+                prompt = p.get('element', '')
+                if prompt == 'vector':
+                    name = p.get('name', '')
+                    if name in ('map', 'input'):
+                        eventId = p['wxId']
+            if eventId is None:
+                return
+        p = self.task.get_param(self.eventId, element='wxId', raiseError=True)
+        if not p or \
+                not p.has_key('wxId-bind'):
+            return
+        # get widget prompt
+        pType = p.get('prompt', '')
+        if not pType:
+            return
+        # check for map/input parameter
+        pMap = self.task.get_param('map', raiseError=False)
+        if not pMap:
+            pMap = self.task.get_param('input', raiseError=False)
+        if pMap:
+            map = pMap.get('value', '')
+        else:
+            map = None
+        # avoid multiple updating
+        columns = []
+        # update reference widgets
+        for uid in p['wxId-bind']:
+            win = self.parent.FindWindowById(uid)
+            name = win.GetName()
+            if name == 'LayerSelect':
+                win.InsertLayers(map)
+            elif name == 'TableSelect':
+                pDriver = self.task.get_param('dbdriver', element='prompt', raiseError=False)
+                driver = db = None
+                if pDriver:
+                    driver = pDriver['value']
+                pDb = self.task.get_param('dbname', element='prompt', raiseError=False)
+                if pDb:
+                    db = pDb['value']
+                win.InsertTables(driver, db)
+            elif name == 'ColumnSelect':
+                if not columns:
+                    pLayer = self.task.get_param('layer', element='element', raiseError=False)
+                    if pLayer:
+                        if pLayer.get('value', '') != '':
+                            layer = int(pLayer.get('value', 1))
+                        else:
+                            layer = int(pLayer.get('default', 1))
+                    else:
+                        layer = 1
+                    if map:
+                        win.InsertColumns(map, layer)
+                        columns = win.GetItems()
+                    else: # table
+                        if pDriver:
+                            driver = pDriver.get('value', None)
+                        if pDb:
+                            db = pDb.get('value', None)
+                        pTable = self.task.get_param('dbtable', element='element', raiseError=False)
+                        if pTable and \
+                                pTable.get('value', '') != '':
+                            if driver and db:
+                                win.InsertTableColumns(pTable.get('value'), driver, db)
+                            else:
+                                win.InsertTableColumns(pTable.get('value'))
+                else:
+                   win.SetItems(columns)
 class testSAXContentHandler(HandlerBase):
 # SAX compliant
     def characters(self, ch, start, length):
@@ -1533,97 +1635,11 @@
         Update dialog (layers, tables, columns, etc.)
-        # get widget id
-        if not event:
-            id = None
-            for p in self.task.params:
-                if p.get('gisprompt', False) == False:
-                    continue
-                prompt = p.get('element', '')
-                if prompt == 'vector':
-                    name = p.get('name', '')
-                    if name in ('map', 'input'):
-                        id = p['wxId']
-            if id is None:
-                return
+        if event:
+            UpdateThread(self, event.GetId(), self.task)
         else:
-            id = event.GetId()
+            UpdateThread(self, None, self.task)
-        p = self.task.get_param(id, element='wxId', raiseError=False)
-        if not p or \
-                not p.has_key('wxId-bind'):
-            return
-        # get widget prompt
-        pType = p.get('prompt', '')
-        if not pType:
-            return
-        # check for map/input parameter
-        pMap = self.task.get_param('map', raiseError=False)
-        if not pMap:
-            pMap = self.task.get_param('input', raiseError=False)
-        if pMap:
-            map = pMap.get('value', '')
-        else:
-            map = None
-        # avoid multiple updating
-        columns = []
-        # update reference widgets
-        for uid in p['wxId-bind']:
-            win = self.FindWindowById(uid)
-            name = win.GetName()
-            if name == 'LayerSelect':
-                win.InsertLayers(map)
-            elif name == 'TableSelect':
-                pDriver = self.task.get_param('dbdriver', element='prompt', raiseError=False)
-                driver = db = None
-                if pDriver:
-                    driver = pDriver['value']
-                pDb = self.task.get_param('dbname', element='prompt', raiseError=False)
-                if pDb:
-                    db = pDb['value']
-                win.InsertTables(driver, db)
-            elif name == 'ColumnSelect':
-                if not columns:
-                    pLayer = self.task.get_param('layer', element='element', raiseError=False)
-                    if pLayer:
-                        if pLayer.get('value', '') != '':
-                            layer = int(pLayer.get('value', 1))
-                        else:
-                            layer = int(pLayer.get('default', 1))
-                    else:
-                        layer = 1
-                    if map:
-                        win.InsertColumns(map, layer)
-                        columns = win.GetItems()
-                    else: # table
-                        if pDriver:
-                            driver = pDriver.get('value', None)
-                        if pDb:
-                            db = pDb.get('value', None)
-                        pTable = self.task.get_param('dbtable', element='element', raiseError=False)
-                        if pTable and \
-                                pTable.get('value', '') != '':
-                            if driver and db:
-                                win.InsertTableColumns(pTable.get('value'), driver, db)
-                            else:
-                                win.InsertTableColumns(pTable.get('value'))
-                else:
-                   win.SetItems(columns)
     def createCmd( self, ignoreErrors = False ):
         Produce a command line string (list) or feeding into GRASS.
