[GRASS-SVN] r37031 -
grass/branches/releasebranch_6_4/gui/wxpython/gui_modules
svn_grass at osgeo.org
Thu May 7 05:53:37 EDT 2009
Author: martinl
Date: 2009-05-07 05:53:37 -0400 (Thu, 07 May 2009)
New Revision: 37031
grass/branches/releasebranch_6_4/gui/wxpython/gui_modules/menuform.py
wxGUI: run UpdateSelection() in the thread
(merge from devbr6, r37011, r37012)
Modified: grass/branches/releasebranch_6_4/gui/wxpython/gui_modules/menuform.py
--- grass/branches/releasebranch_6_4/gui/wxpython/gui_modules/menuform.py 2009-05-06 18:11:54 UTC (rev 37030)
+++ grass/branches/releasebranch_6_4/gui/wxpython/gui_modules/menuform.py 2009-05-07 09:53:37 UTC (rev 37031)
@@ -43,7 +43,7 @@
@todo
- verify option value types
- - use DOM instead of SAX
+ - use DOM instead of SAX (is it really necessary? ML)
import sys
@@ -54,6 +54,8 @@
import time
import copy
import locale
+from threading import Thread
+import Queue
### i18N
import gettext
@@ -64,11 +66,12 @@
globalvar.CheckForWx()
import wx
+import wx.html
import wx.lib.flatnotebook as FN
import wx.lib.colourselect as csel
import wx.lib.filebrowsebutton as filebrowse
from wx.lib.expando import ExpandoTextCtrl, EVT_ETC_LAYOUT_NEEDED
-import wx.html
+from wx.lib.newevent import NewEvent
# Do the python 2.0 standard xml thing and map it on the old names
import xml.sax
@@ -103,6 +106,8 @@
utils.reexec_with_pythonw()
+wxUpdateDialog, EVT_DIALOG_UPDATE = NewEvent()
# From lib/gis/col_str.c, except purple which is mentioned
# there but not given RGB values
str2rgb = {'aqua': (100, 128, 255),
@@ -160,6 +165,142 @@
"""Escapes ampersands with additional ampersand for GUI"""
return string.replace(text, "&", "&&")
+class UpdateThread(Thread):
+ """Update dialog widgets in the thread"""
+ def __init__(self, parent, event, eventId, task):
+ Thread.__init__(self)
+ self.parent = parent
+ self.event = event
+ self.eventId = eventId
+ self.task = task
+ self.setDaemon(True)
+ # list of functions which updates the dialog
+ self.data = {}
+ def run(self):
+ # get widget id
+ if not self.eventId:
+ for p in self.task.params:
+ if p.get('gisprompt', False) == False:
+ continue
+ prompt = p.get('element', '')
+ if prompt == 'vector':
+ name = p.get('name', '')
+ if name in ('map', 'input'):
+ self.eventId = p['wxId']
+ if self.eventId is None:
+ return
+ p = self.task.get_param(self.eventId, element='wxId', raiseError=False)
+ if not p or \
+ not p.has_key('wxId-bind'):
+ return
+ # get widget prompt
+ pType = p.get('prompt', '')
+ if not pType:
+ return
+ # check for map/input parameter
+ pMap = self.task.get_param('map', raiseError=False)
+ if not pMap:
+ pMap = self.task.get_param('input', raiseError=False)
+ if pMap:
+ map = pMap.get('value', '')
+ else:
+ map = None
+ # update reference widgets
+ for uid in p['wxId-bind']:
+ win = self.parent.FindWindowById(uid)
+ name = win.GetName()
+ if name == 'LayerSelect':
+ self.data[win.InsertLayers] = { 'vector' : map }
+ elif name == 'TableSelect':
+ pDriver = self.task.get_param('dbdriver', element='prompt', raiseError=False)
+ driver = db = None
+ if pDriver:
+ driver = pDriver['value']
+ pDb = self.task.get_param('dbname', element='prompt', raiseError=False)
+ if pDb:
+ db = pDb['value']
+ self.data[win.InsertTables] = { 'driver' : driver,
+ 'database' : db }
+ elif name == 'ColumnSelect':
+ pLayer = self.task.get_param('layer', element='element', raiseError=False)
+ if pLayer:
+ if pLayer.get('value', '') != '':
+ layer = int(pLayer.get('value', 1))
+ else:
+ layer = int(pLayer.get('default', 1))
+ else:
+ layer = 1
+ if map:
+ self.data[win.InsertColumns] = { 'vector' : map, 'layer' : layer }
+ else: # table
+ if pDriver:
+ driver = pDriver.get('value', None)
+ if pDb:
+ db = pDb.get('value', None)
+ pTable = self.task.get_param('dbtable', element='element', raiseError=False)
+ if pTable and \
+ pTable.get('value', '') != '':
+ if driver and db:
+ self.data[win.InsertTableColumns] = { 'table' : pTable.get('value'),
+ 'driver' : driver,
+ 'database' : db }
+ else:
+ self.data[win.InsertTableColumns] = { 'table' : pTable.get('value') }
+def UpdateDialog(parent, event, eventId, task):
+ return UpdateThread(parent, event, eventId, task)
+class UpdateQThread(Thread):
+ requestId = 0
+ def __init__(self, parent, requestQ, resultQ, **kwds):
+ Thread.__init__(self, **kwds)
+ self.parent = parent # cmdPanel
+ self.requestQ = requestQ
+ self.resultQ = resultQ
+ self.start()
+ def Update(self, callable, *args, **kwds):
+ UpdateQThread.requestId += 1
+ self.request = None
+ self.requestQ.put((UpdateQThread.requestId, callable, args, kwds))
+ return UpdateQThread.requestId
+ def run(self):
+ while True:
+ requestId, callable, args, kwds = self.requestQ.get()
+ requestTime = time.time()
+ self.request = callable(*args, **kwds)
+ self.resultQ.put((requestId, self.request.run()))
+ event = wxUpdateDialog(data = self.request.data)
+ wx.PostEvent(self.parent, event)
class testSAXContentHandler(HandlerBase):
# SAX compliant
def characters(self, ch, start, length):
@@ -752,6 +893,12 @@
self.notebookpanel.constrained_size[1] -
self.notebookpanel.panelMinHeight))
+ # thread to update dialog
+ # create queues
+ self.requestQ = Queue.Queue()
+ self.resultQ = Queue.Queue()
+ self.updateThread = UpdateQThread(self.notebookpanel, self.requestQ, self.resultQ)
self.Layout()
def updateValuesHook(self):
@@ -1414,6 +1561,12 @@
self.hasMain = tab.has_key( _('Required') ) # publish, to enclosing Frame for instance
+ self.Bind(EVT_DIALOG_UPDATE, self.OnUpdateDialog)
+ def OnUpdateDialog(self, event):
+ for fn, kwargs in event.data.iteritems():
+ fn(**kwargs)
def OnVerbosity(self, event):
"""Verbosity level changed"""
verbose = self.FindWindowById(self.task.get_flag('verbose')['wxId'])
@@ -1532,97 +1685,19 @@
Update dialog (layers, tables, columns, etc.)
- # get widget id
- if not event:
- id = None
- for p in self.task.params:
- if p.get('gisprompt', False) == False:
- continue
- prompt = p.get('element', '')
- if prompt == 'vector':
- name = p.get('name', '')
- if name in ('map', 'input'):
- id = p['wxId']
- if id is None:
- return
+ if event:
+ self.parent.updateThread.Update(UpdateDialog,
+ self,
+ event,
+ event.GetId(),
+ self.task)
else:
- id = event.GetId()
+ self,
+ None,
+ None,
+ self.task)
- p = self.task.get_param(id, element='wxId', raiseError=False)
- if not p or \
- not p.has_key('wxId-bind'):
- return
- # get widget prompt
- pType = p.get('prompt', '')
- if not pType:
- return
- # check for map/input parameter
- pMap = self.task.get_param('map', raiseError=False)
- if not pMap:
- pMap = self.task.get_param('input', raiseError=False)
- if pMap:
- map = pMap.get('value', '')
- else:
- map = None
- # avoid multiple updating
- columns = []
- # update reference widgets
- for uid in p['wxId-bind']:
- win = self.FindWindowById(uid)
- name = win.GetName()
- if name == 'LayerSelect':
- win.InsertLayers(map)
- elif name == 'TableSelect':
- pDriver = self.task.get_param('dbdriver', element='prompt', raiseError=False)
- driver = db = None
- if pDriver:
- driver = pDriver['value']
- pDb = self.task.get_param('dbname', element='prompt', raiseError=False)
- if pDb:
- db = pDb['value']
- win.InsertTables(driver, db)
- elif name == 'ColumnSelect':
- if not columns:
- pLayer = self.task.get_param('layer', element='element', raiseError=False)
- if pLayer:
- if pLayer.get('value', '') != '':
- layer = int(pLayer.get('value', 1))
- else:
- layer = int(pLayer.get('default', 1))
- else:
- layer = 1
- if map:
- win.InsertColumns(map, layer)
- columns = win.GetItems()
- else: # table
- if pDriver:
- driver = pDriver.get('value', None)
- if pDb:
- db = pDb.get('value', None)
- pTable = self.task.get_param('dbtable', element='element', raiseError=False)
- if pTable and \
- pTable.get('value', '') != '':
- if driver and db:
- win.InsertTableColumns(pTable.get('value'), driver, db)
- else:
- win.InsertTableColumns(pTable.get('value'))
- else:
- win.SetItems(columns)
def createCmd( self, ignoreErrors = False ):
Produce a command line string (list) or feeding into GRASS.
