[GRASS-SVN] r37033 - grass/trunk/vector/v.in.ogr
svn_grass at osgeo.org
Thu May 7 06:17:49 EDT 2009
Author: mmetz
Date: 2009-05-07 06:17:49 -0400 (Thu, 07 May 2009)
New Revision: 37033
grass/trunk/vector/v.in.ogr/geom.c
fix for ticket #577, skip empty features
Modified: grass/trunk/vector/v.in.ogr/geom.c
--- grass/trunk/vector/v.in.ogr/geom.c 2009-05-07 09:55:27 UTC (rev 37032)
+++ grass/trunk/vector/v.in.ogr/geom.c 2009-05-07 10:17:49 UTC (rev 37033)
@@ -31,7 +31,7 @@
centroid(OGRGeometryH hGeom, CENTR * Centr, SPATIAL_INDEX * Sindex, int field,
int cat, double min_area, int type)
- int i, j, np, nr, ret;
+ int i, valid_isles, j, np, nr, ret;
static int first = 1;
static struct line_pnts *Points;
struct line_pnts **IPoints;
@@ -90,15 +90,17 @@
IPoints =
(struct line_pnts **)G_malloc((nr - 1) *
sizeof(struct line_pnts *));
+ valid_isles = 0;
for (i = 1; i < nr; i++) {
- IPoints[i - 1] = Vect_new_line_struct();
hRing = OGR_G_GetGeometryRef(hGeom, i);
- np = OGR_G_GetPointCount(hRing);
- for (j = 0; j < np; j++) {
- Vect_append_point(IPoints[i - 1], OGR_G_GetX(hRing, j),
- OGR_G_GetY(hRing, j), OGR_G_GetZ(hRing, j));
+ if ((np = OGR_G_GetPointCount(hRing)) > 0) {
+ IPoints[valid_isles] = Vect_new_line_struct();
+ for (j = 0; j < np; j++) {
+ Vect_append_point(IPoints[valid_isles], OGR_G_GetX(hRing, j),
+ OGR_G_GetY(hRing, j), OGR_G_GetZ(hRing, j));
+ valid_isles++;
@@ -119,8 +121,8 @@
continue; /* outside */
in = 1;
- for (j = 1; j < nr; j++) {
- ret = Vect_point_in_poly(x, y, IPoints[j - 1]);
+ for (j = 0; j < valid_isles; j++) {
+ ret = Vect_point_in_poly(x, y, IPoints[j]);
if (ret == 1) { /* centroid in inner ring */
in = 0;
break; /* inside isle */
@@ -135,11 +137,10 @@
- for (i = 1; i < nr; i++) {
- Vect_destroy_line_struct(IPoints[i - 1]);
+ for (i = 0; i < valid_isles; i++) {
+ Vect_destroy_line_struct(IPoints[i]);
- if (nr > 1)
- G_free(IPoints);
+ G_free(IPoints);
/* I did not test this because I did not have files of these types */
@@ -161,7 +162,7 @@
geom(OGRGeometryH hGeom, struct Map_info *Map, int field, int cat,
double min_area, int type, int mk_centr)
- int i, j, np, nr, ret, otype;
+ int i, valid_isles, j, np, nr, ret, otype;
@@ -187,6 +188,10 @@
eType = wkbFlatten(OGR_G_GetGeometryType(hGeom));
if (eType == wkbPoint) {
+ if ((np = OGR_G_GetPointCount(hGeom)) == 0) {
+ G_warning(_("Skipping empty geometry feature"));
+ return 0;
Vect_append_point(Points, OGR_G_GetX(hGeom, 0), OGR_G_GetY(hGeom, 0),
OGR_G_GetZ(hGeom, 0));
if (type & GV_CENTROID)
@@ -196,7 +201,10 @@
Vect_write_line(Map, otype, Points, Cats);
else if (eType == wkbLineString) {
- np = OGR_G_GetPointCount(hGeom);
+ return 0;
for (i = 0; i < np; i++) {
Vect_append_point(Points, OGR_G_GetX(hGeom, i),
@@ -212,15 +220,19 @@
else if (eType == wkbPolygon) {
G_debug(3, "Polygon");
- n_polygons++;
- nr = OGR_G_GetGeometryCount(hGeom);
/* SFS: 1 exterior boundary and 0 or more interior boundaries.
* So I hope that exterior is the first one, even if it is not explicitly told */
/* Area */
hRing = OGR_G_GetGeometryRef(hGeom, 0);
+ if ((np = OGR_G_GetPointCount(hRing)) == 0) {
+ return 0;
+ n_polygons++;
+ nr = OGR_G_GetGeometryCount(hGeom);
Vect_reset_line(Points);
Vect_append_point(Points, OGR_G_GetX(hRing, j),
@@ -249,41 +261,48 @@
IPoints =
+ valid_isles = 0;
G_debug(3, "Inner ring %d", i);
+ else {
- if (IPoints[i - 1]->n_points < 4)
- G_warning(_("Degenerate island ([%d] vertices)"),
- IPoints[i - 1]->n_points);
- size = G_area_of_polygon(Points->x, Points->y, Points->n_points);
- if (size < min_area) {
- G_warning(_("Island size [%.1e], island not imported"), size);
+ if (IPoints[valid_isles]->n_points < 4)
+ G_warning(_("Degenerate island ([%d] vertices)"),
+ IPoints[i - 1]->n_points);
+ size = G_area_of_polygon(Points->x, Points->y, Points->n_points);
+ if (size < min_area) {
+ G_warning(_("Island size [%.1e], island not imported"), size);
+ else {
+ if (type & GV_LINE)
+ otype = GV_LINE;
+ else
+ otype = GV_BOUNDARY;
+ Vect_write_line(Map, otype, IPoints[valid_isles], BCats);
+ valid_isles++;
- else {
- if (type & GV_LINE)
- otype = GV_LINE;
- else
- otype = GV_BOUNDARY;
- Vect_write_line(Map, otype, IPoints[i - 1], BCats);
+ } /* inner rings done */
/* Centroid */
/* Vect_get_point_in_poly_isl() would fail for degenerate polygon */
if (mk_centr) {
if (Points->n_points >= 4) {
ret =
- Vect_get_point_in_poly_isl(Points, IPoints, nr - 1, &x,
+ Vect_get_point_in_poly_isl(Points, IPoints, valid_isles, &x,
&y);
if (ret == -1) {
G_warning(_("Cannot calculate centroid"));
@@ -321,8 +340,8 @@
G_free(IPoints);
