[GRASS-SVN] r37047 - grass/branches/releasebranch_6_4/ps/ps.map
svn_grass at osgeo.org
Fri May 8 03:31:06 EDT 2009
Author: hamish
Date: 2009-05-08 03:31:05 -0400 (Fri, 08 May 2009)
New Revision: 37047
grass/branches/releasebranch_6_4/ps/ps.map/colortable.h
grass/branches/releasebranch_6_4/ps/ps.map/description.html
grass/branches/releasebranch_6_4/ps/ps.map/ps_clrtbl.c
grass/branches/releasebranch_6_4/ps/ps.map/ps_fclrtbl.c
grass/branches/releasebranch_6_4/ps/ps.map/ps_map.c
grass/branches/releasebranch_6_4/ps/ps.map/r_colortable.c
backport legend type control from devbr6
Modified: grass/branches/releasebranch_6_4/ps/ps.map/colortable.h
--- grass/branches/releasebranch_6_4/ps/ps.map/colortable.h 2009-05-08 06:35:43 UTC (rev 37046)
+++ grass/branches/releasebranch_6_4/ps/ps.map/colortable.h 2009-05-08 07:31:05 UTC (rev 37047)
@@ -9,7 +9,7 @@
double x, y, width;
double min, max;
- double height; /* fp legend height */
+ double height; /* fp legend height */
char *font;
char *name;
char *mapset;
@@ -18,6 +18,7 @@
int cols;
int nodata;
int tickbar;
+ int discrete; /* force discrete bands or continuous gradient */
int range_override;
Modified: grass/branches/releasebranch_6_4/ps/ps.map/description.html
--- grass/branches/releasebranch_6_4/ps/ps.map/description.html 2009-05-08 06:35:43 UTC (rev 37046)
+++ grass/branches/releasebranch_6_4/ps/ps.map/description.html 2009-05-08 07:31:05 UTC (rev 37047)
@@ -178,10 +178,21 @@
For vectors and some plotting commands you can also specify
'<tt>none</tt>' or '<tt>R:G:B</tt>' (e.g '<tt>255:0:0</tt>').
</DD>
+<DT><B>yes|no</B>
+<DD>For options that take a yes or no answer, you can simply use the
+letters "y" or "n", or type out the full words "Yes" or "No" if you
+prefer. It is not case-sensitive. Typically the option with have a
+default answer and you only need to specify one if you wish to
+override it.
+</DD>
</DL>
<P>
<BR>
<h3>Command usage</h3>
<a name="border"></a>
@@ -219,7 +230,7 @@
<a name="colortable"></a>
<H2>colortable</H2>
-Prints the color table for the raster map layer anywhere on the page.
+Prints the color table legend for the raster map layer anywhere on the page.
<PRE>
USAGE: <B>colortable</B> [y|n]
<B>where</B> x y
@@ -233,53 +244,82 @@
<B>color</B> text color
<B>nodata</B> [Y|n]
<B>tickbar</B> [y|N]
+ <B>discrete</B> [y|n]
<B>end</B>
</PRE>
-The color table will display the colors for each raster map layer
-category value and the category label.
-If <B>raster</B> is omitted, the colortable defaults to a previously
+For a categorical (CELL) map the color table will create a legend displaying
+the colors for each of a raster map's category values along with its
+associated category label. For a floating point (FCELL or DCELL) map a
+continuous gradient legend will be created.
+<P>
+If <B>raster</B> is omitted, the colortable defaults to the previously
registered raster layer.
-The legend's <B>range</B> can be adjusted for floating point rasters, but if
-set beyond the extent of the map's range be sure that you have set up color
-rules with <em>r.colors</em> which cover this range.
The default location for the colortable is immediately below any other
map legend information, starting at the left margin.
The default text color is black.
Omitting the <B>colortable</B> instruction would result in
-no color table. For floating point legends <B>width</B> is width of color
-band only. <B>height</B> is used only for floating point legend.
-Adding the <B>nodata n</B> instruction will prevent the "no data" box
-from being drawn (category based legends only).
+no color table.
+<P>
+If the colortable is turned off with a "<tt>colortable N</tt>"
+instruction the <B>end</B> command should not be given as the
+main command will be treated as a single line instruction.
+<P>
+See also the <a href="#vlegend">vlegend</a> command for creating vector map
+legends.
-Adding the <B>tickbar y</B> instruction will change the tick mark style
-so that ticks are drawn across the color table instead of protruding out
-to the right (floating point legends only).
-If the map has been given a data units label with r.support then this
-label will be displayed.
-<!-- bonus prize for code explorers: you can switch the label placement by
- editing the label_posn variable in ps.map/ps_fclrtbl.c -->
+<h4>Categorical (CELL) Maps</h4>
+Adding the <B>nodata N</B> instruction will prevent the "no data" box
+from being drawn (category based legends only). If you have manually
+added a "no data" label to the cats/ file it will be shown regardless.
<P>
<B>Note</B>: Be careful about asking for color tables for integer
raster map layers which have many categories, such as elevation.
This could result in the printing of an extremely long color table!
+In this situation it is useful to use the <B>discrete N</B> instruction
+to force a continuous color gradient legend.
<P>
-Another issue is that the color table only includes categories which
+Be aware that the color table only includes categories which
have a label. If there are only a few categories, you can use
-r.support to manually add labels. If there are too many categories to
-do this by hand, you can supply a label rules file to the r.category
+<em>r.support</em> to manually add labels. If there are too many categories to
+do this by hand, you can supply a label rules file to the <em>r.category</em>
module.
-<P>
-If the colortable is turned off with a "<tt>colortable n</tt>"
-instruction the <B>end</B> command should not be given as the
-main command will be treated as a single line instruction.
+<h4>Floating point (FCELL and DCELL) Maps</h4>
+The legend's <B>range</B> can be adjusted for floating point rasters, but if
+set beyond the extent of the map's range be sure that you have set up color
+rules with <em>r.colors</em> which cover this range.
+If the map has been given a data-units label with <em>r.support</em>
+then this label will be displayed.
+<!-- bonus prize for code explorers: you can switch the label placement by
+ editing the label_posn variable in ps.map/ps_fclrtbl.c -->
+For floating point legends <B>width</B> is width of color
+band only. <B>height</B> is used only for floating point legend.
+Adding the <B>tickbar Y</B> instruction will change the tick mark style
+so that ticks are drawn across the color table instead of protruding out
+to the right (floating point legends only).
+Adding the <B>discrete Y</B> instruction will command the program to treat
+the map as a categorical map. In this way the legend can be created with
+discrete range bands instead of a continuous gradient. You must use the
+<em>r.category</em> or <em>r.support</em> module to set up the range labels
+first.
+<BR>
<P>
This example would print a color table immediately below any other map legend
information, starting at the left margin, with 4 columns:
<PRE>
-EXAMPLE:
+EXAMPLE:
<B>colortable</B> y
<B>cols</B> 4
<B>width</B> 4
@@ -1497,6 +1537,9 @@
<a href="#rectangle">rectangle</a>, <a href="#point">point</a>, and
<a href="#text">text</a> instructions.
<P>
+See also the <a href="#colortable">colortable</a> command for creating
+raster map legends.
+<P>
This example prints the vector legend
immediately below the map and starting 4.5 inches from the left edge
of the page, using a 12/72 inch Helvetica font.
Modified: grass/branches/releasebranch_6_4/ps/ps.map/ps_clrtbl.c
--- grass/branches/releasebranch_6_4/ps/ps.map/ps_clrtbl.c 2009-05-08 06:35:43 UTC (rev 37046)
+++ grass/branches/releasebranch_6_4/ps/ps.map/ps_clrtbl.c 2009-05-08 07:31:05 UTC (rev 37047)
@@ -44,10 +44,10 @@
num_cats = G_number_of_raster_cats(&PS.cats);
G_debug(3, "clrtbl: %d categories", num_cats);
if (!num_cats) {
- G_warning(_("Your cats/ file is invalid. A cats/ file with "
- "categories and labels is required for 'colortable' when using "
- "CELL rasters. No colortable will be assigned to this output "
- "postscript file."));
+ G_warning(_("Your cats/ file is invalid. A cats/ file with categories "
+ "and labels is required for 'colortable' when using "
+ "categorical legends; see the r.category help page. "
+ "Colortable creation has been skipped."));
return 1;
Modified: grass/branches/releasebranch_6_4/ps/ps.map/ps_fclrtbl.c
--- grass/branches/releasebranch_6_4/ps/ps.map/ps_fclrtbl.c 2009-05-08 06:35:43 UTC (rev 37046)
+++ grass/branches/releasebranch_6_4/ps/ps.map/ps_fclrtbl.c 2009-05-08 07:31:05 UTC (rev 37047)
@@ -267,8 +267,8 @@
/* select label position */
label_posn = 3;
/* 1 2
- 3
- 5 4 */
+ 3
+ 5 4 */
switch (label_posn) {
case 1:
/* above the tick numbers */
Modified: grass/branches/releasebranch_6_4/ps/ps.map/ps_map.c
--- grass/branches/releasebranch_6_4/ps/ps.map/ps_map.c 2009-05-08 06:35:43 UTC (rev 37046)
+++ grass/branches/releasebranch_6_4/ps/ps.map/ps_map.c 2009-05-08 07:31:05 UTC (rev 37047)
@@ -145,10 +145,10 @@
/* do the colortable, if requested */
if (PS.do_colortable) {
- if (G_raster_map_is_fp(ct.name, ct.mapset))
+ if (ct.discrete == TRUE)
+ PS_colortable();
+ else
PS_fcolortable();
- else
- PS_colortable();
/* do comments, if any */
Modified: grass/branches/releasebranch_6_4/ps/ps.map/r_colortable.c
--- grass/branches/releasebranch_6_4/ps/ps.map/r_colortable.c 2009-05-08 06:35:43 UTC (rev 37046)
+++ grass/branches/releasebranch_6_4/ps/ps.map/r_colortable.c 2009-05-08 07:31:05 UTC (rev 37047)
@@ -22,7 +22,9 @@
"fontsize fontsize",
"color color",
"nodata Y|n",
- "tickbar y|N" ""
+ "tickbar y|N"
+ "discrete y|n"
int read_colortable(void)
@@ -30,7 +32,7 @@
char buf[1024];
char *key, *data;
char name[GNAME_MAX], mapset[GMAPSET_MAX];
- int color, fontsize, cols, nodata, tickbar;
+ int color, fontsize, cols, nodata, tickbar, discrete;
double w, h, x, y;
int range_override;
double min, max, tmpD;
@@ -40,8 +42,9 @@
color = BLACK;
cols = 1;
h = w = x = y = 0.0;
- ct.nodata = 1;
- ct.tickbar = 0;
+ ct.nodata = TRUE;
+ ct.tickbar = FALSE;
+ ct.discrete = -1; /* default: TRUE for CELL map, FALSE for FP maps */
range_override = FALSE;
while (input(2, buf, help)) {
@@ -138,8 +141,15 @@
continue;
+ if (KEY("discrete")) {
+ discrete = yesno(key, data);
+ ct.discrete = discrete;
+ continue;
error(key, data, "illegal colortabe sub-request");
ct.x = x;
ct.y = y;
if (fontsize)
@@ -156,6 +166,14 @@
+ /* set default if legend type was not specified */
+ if (ct.discrete == -1) {
+ if (G_raster_map_is_fp(ct.name, ct.mapset))
+ ct.discrete = FALSE;
+ else
+ ct.discrete = TRUE;
ct.min = min;
ct.max = max;
ct.range_override = range_override;
